n100rh(at)sbcglobal.net Guest
Posted: Tue Jul 23, 2013 3:33 pm Post subject: RotaxEngines-List Digest: 8 Msgs - 07/22/13 |
Thanks all, I will check all the ground straps.
Ralph
On 7/23/2013 12:00 AM, RotaxEngines-List Digest Server wrote:
| Quote: | *
Today's complete RotaxEngines-List Digest can also be found in either of the
of the RotaxEngines-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-07-22&Archive=RotaxEngines
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-07-22&Archive=RotaxEngines
RotaxEngines-List Digest Archive
Total Messages Posted Mon 07/22/13: 8
Today's Message Index:
1. 06:24 AM - Re: Starting carburetors (Roger Lee)
2. 06:25 AM - Re: RotaxEngines-List Digest: 8 Msgs - 07/10/13 (Roger Lee)
3. 06:49 AM - Re: Fuel distribution banjo fittings (Roger Lee)
4. 01:35 PM - Off topic - Roger Lee (pestar)
5. 01:38 PM - Re: Off topic - Roger Lee (Gilles Thesee)
6. 01:46 PM - Re: Off topic - Roger Lee (Roger Lee)
7. 02:28 PM - Re: Re: Off topic - Roger Lee (Craig Payne)
8. 09:23 PM - Re: Off topic - Roger Lee (Roger Lee)
Time: 06:24:14 AM PST US
Subject: Re: Starting carburetors
Hi Rick,
The chokes were marked and on the correct carb. If you switched them then switch
them back or they won't work. The center punch dot on the end of the choke shaft
should be facing the tube that looks like it is molded in the choke assembly.
Tighten the 4 screws well so there I are no leaks and they are supposed to
have blue Loctite. (Medium strength)
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center - Heavy Maint. Rated
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=405061#405061
Time: 06:25:43 AM PST US
Subject: Re: RotaxEngines-List Digest: 8 Msgs - 07/10/13
Hi Ralph,
I'm with Rick. Sounds like a poor ground. It could be a loose ground or a corroded
one.
Roger Lee
Tucson, Az.
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=405063#405063
Time: 06:49:17 AM PST US
Subject: Re: Fuel distribution banjo fittings
Parts needed.
>From IP manual dated Sept. 2011 rev 2 page 21-2
The number is the schematic number in the picture that corresponds to the actual
part number for ordering. The fuel return line comes off #7.
# 5 : 840518
6 : 950143. Need 5. Copper gaskets
7: 956312 banjo with restrictor for the recirculation line
8: 851327
9: 941785
11: 230150
12: 641733 fuel pressure line to gauge
13: 940872. Fuel in from pump and out to carbs (double banjo bolt)
Roger Lee
Tucson, Az.
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=405065#405065
________________________________ Message 4 _____________________________________
Time: 01:35:23 PM PST US
Subject: Off topic - Roger Lee
Roger
Are you going to Oshkosh. I am and if you are would like to give you a call.
Cheers Peter
Peter Armstrong
Auckland, New Zealand
DynAero MCR-4S (Do not shoot me ).
http://forums.matronics.com/viewtopic.php?p=405093#405093
________________________________ Message 5 _____________________________________
Time: 01:38:26 PM PST US
From: Gilles Thesee <Gilles.Thesee(at)ac-grenoble.fr>
Subject: Re: Off topic - Roger Lee
pestar a crit :
> Roger
You lucky guy !
Best regards,
