craigb(at)onthenet.com.au Guest
Posted: Fri Jul 26, 2013 3:00 pm Post subject: G Load testing |
I have seen a few photos on the group over the years with
a/c inverted and bags of sand, concrete, gold coins etc stacked
evenly on the wings to simulate the G loading, question is how are
people supporting the weight for this test through the fuselage itself
obviously the top of the cockpit would be insufficient to take such a load
of what 8000+ pounds, assuming 6g x 1370lb, or do I have the math wrong on
this
my thoughts were it may be easier to keep the A/C upright and load the
weight
into the cockpit with the whole lot supported by cradle and a few extra
supports under each wing
Posted: Sat Jul 27, 2013 12:46 am Post subject: G Load testing |
wrong thought Craig. It has to be done the standard way. Design load is 4.5 G (from dilute memory)
Don't try it without a qualified Inspector, easy to break something.
Graham
Sent: Saturday, 27 July 2013, 0:00
Subject: Europa-List: G Load testing
--> Europa-List message posted by: "craig" <craigb(at)onthenet.com.au (craigb(at)onthenet.com.au)>
this
weight
into the cockpit with the whole lot supported by cradle and-> http://forums.matronics.comhttp://www.======================
Posted: Sat Jul 27, 2013 2:52 am Post subject: G Load testing |
Yes but doesn’t there have to be a 50% safety margin on g load
After all you could pull nearly 6 g in a turn (80 degrees bank) taking
Evasive action for example.
But back to the original question how does one support the a/c adequately for the testing in the inverted
position
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON
Sent: Saturday, July 27, 2013 6:44 PM
Subject: Re: G Load testing
Graham
Subject: G Load testing
this
weight
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 0123456789
Checked by AVG - www.avg.com
07/26/13
Posted: Sat Jul 27, 2013 4:06 am Post subject: G Load testing |
craig a écrit :
Graig and all,
The 50 % margin is for calculation only, especially in a homebuilt.
Contrary to popular belief, the 4.5 g load for instance, is a
once-in-a-lifetime limit not to be inflicted on the airframe repeatedly.
Safe load is considered to be approximately 80% of certified load.
| Quote: | After all you could pull nearly 6 g in a turn (80 degrees bank) taking
Any airplane can break in flight if mishandled.
It would take a really ham fisted pilot to reach as high as 6g.
Additionally in peacetime I would advise to only perform avoiding
actions
Best regards,
Gilles
http://contrails.free.fr
