Fuel Flow thru Facet pump
clemwehner
PostPosted: Mon Sep 02, 2013 11:57 am    Post subject: Fuel Flow thru Facet pump Reply with quote
My son and I just did the fuel flow testing on our classic KF-IV with 912 and plastic header tank behind the seat. Before we did the test we decided to determine the best case fuel flow. We simply connected a 5/16 hose to the fuel tank and routed it alongside the aircraft fuel line through the fuselage ending at the carb. There was only a facet fuel pump in the line and nothing else-- no fittings, no valves, etc. The flow was a measly 4 ounces per minute, way below the guideline of 20 oz/min (1.5 X fuel requirements of the 912 at takeoff power and attitude). The results would undoubtedly be worse when running the fuel through the actual aircraft lines with its fittings, valves, and 912 pump.
We suspected the facet pump was limiting the fuel flow, so we took the pump out of the line and used just hose from the tank. This produced 40 oz/min—ten times more flow and double the flow test requirements.
We disassembled the facet pump and found it to be very simple. It has two one-way valves, one in each direction. The valve on the inlet side is held closed by a very weak spring that is easily opened by about 1 psi or less. BUT!!! it only opens about 1/16th inch and allows only a small amount of fuel to flow through it. Then the valve hits a much stronger spring that could open more, but only with the force generated by the running pump. So, it is true that gravity flow will pass through a facet pump, but it is very limited in volume to just a small stream, really not much more than a trickle.
Lots of people use facet pumps in their fuel systems, but I don’t see how it is possible that they met the gravity flow requirements. Does anyone have any experience with this that can offer some advice? It seems that without a facet pump, gravity flow meets the flow requirements, but with a facet pump it doesn’t even come close. Do pilots with this situation just ignore the test requirements?
Your thoughts most appreciated,
Clem
KFIV 912
Oklahoma
bobnoffs
PostPosted: Mon Sep 02, 2013 12:15 pm    Post subject: Fuel Flow thru Facet pump Reply with quote
there are many different facet pumps and their interior configuration is
different too. some have check valves, others don't. at least one shuts off
flow when the current is off[sounds like the one you have] . no one at acs
has a clue from what i could tell in my last conversation with them about
facet pumps. they sold me an inline backup elec. pump. when i turned off
the electric to my ''backup'' pump the fuel flow stopped instantly. very
different than the 40105 or 40104 which allow fuel to flow thru them. my
40104 easily allows flow thru it for a jab 3300 x 1.5
bob noffs
On Mon, Sep 2, 2013 at 2:57 PM, clemwehner <clemwehner(at)sbcglobal.net> wrote:
clemwehner
PostPosted: Mon Sep 02, 2013 1:04 pm    Post subject: Re: Fuel Flow thru Facet pump Reply with quote
We have Facet 40105 and facet 40106 pumps and both deliver the same volume of fuel through them at the gravity flow below the header tank.
We also get fuel flow through them at gravity flow, but the volume is only 4 oz per minute which is not nearly enough to meet the test requirements.
thanks,
Clem
Clem
Oklahoma
Kitfox IV-912, under construction since 1991
lcfitt(at)sbcglobal.net
PostPosted: Mon Sep 02, 2013 5:51 pm    Post subject: Fuel Flow thru Facet pump Reply with quote
Clem,
This was recently discussed in another forum. There was a link to the FAA
site that gives the test procedures and necessary results. What I took from
it was that there are different requirements for Gravity Flow systems and
Fuel Pump systems. I think what I took from that is that some designs do
not have any fuel pump in the system whatsoever. Since ours does have the
mechanical and some have the electric (facet) we might be comparing apples
to oranges.
One question I have is, are you measuring flow with only fuel in the header
tank, or are you measuring flow with minimal fuel in the wing tanks as
well. One of the guys in the other discussion mentioned the numerous Rotax
powered airplanes with low wings and essentially no head leading to fuel
flow and they would have zero flow without the engine driven pump or an
inline pump (facet). The discussion also mentioned that the engine driven
pump will lift fuel significantly.
Don't know for sure on all this, but it is something to think about.
Lowell
Sent: Monday, September 02, 2013 2:04 PM
Subject: Re: Fuel Flow thru Facet pump
thanks,
Clem
Clem
Oklahoma
http://forums.matronics.com/viewtopic.php?p=407938#407938
clemwehner
PostPosted: Mon Sep 02, 2013 7:47 pm    Post subject: Re: Fuel Flow thru Facet pump Reply with quote
Lowell,
We wanted to know what best case was with fuel flowing directly out of the wing tank, so we hooked a spare hose to the wing tank outlet and routed it thru the cockpit along the same path that the normal fuel lines run ending at the carb. We tried it with just the hose and then tried it again going thru a spare facet pump that we have. We did not involve the header since we were looking for best case.
Without the facet pump in the line there was plenty of fuel flow, but with the restriction of the facet pump (not running), there wasn't nearly enough to meet the test requirements for gravity flow. A lot of guys use facet pumps and I wonder if they actually conducted the flow test. I can't see how anyone could get the required flow with a facet pump in the line at 25 degrees attitude, since we couldn't get it at 12 degrees attitude setting on the gear.
Fuel will definitely gravity flow through a facet pump, but not nearly at the volume that's required. The recent EAA webinar said that 70% of homebuilders never actually do the flow test, but just assume that it'll be fine since their airplanes are based on existing designs. That's scary.
So we're at the point of doing the test with the actual aircraft's plumbing and we know it will be worse than our best case test using just the hose and no fittings, valves, etc.
I wonder if any Kitfox builders who have facet pumps have achieved the required 150% flow with actual testing. If not, what did they do about it? Would a bypass loop around the facet help, or do they just document the flow shortfall and make a flight restriction requiring use of the fuel pump in takeoff and high power climbs?
thanks for the help,
Clem
KF-IV, 912
Oklahoma
bobnoffs
PostPosted: Tue Sep 03, 2013 2:05 am    Post subject: Fuel Flow thru Facet pump Reply with quote
as i mentioned in an earlier post some facet models shut off fuel flow when they are turned off. when i talked to the facet rep he said there is supposedly a very weak check valve in these that is supposed to open somewhat. i immediately sent this model [don't remember the model but i got it from acs] back.
  anyone out there with the #40104 like mine that won't flow adequately?
 a wing tank must have about 3 psi?
 bob noffs
 and no one at acs can give you any useable info about these pumps.
On Mon, Sep 2, 2013 at 10:48 PM, clemwehner <clemwehner(at)sbcglobal.net (clemwehner(at)sbcglobal.net)> wrote:
[quote]--> Kitfox-List message posted by: "clemwehner" <clemwehner(at)sbcglobal.net (clemwehner(at)sbcglobal.net)>
Lowell,
Clem
KF-IV, 912
Oklahoma
http://forums.matronics.com/viewtopic.php?p=407958#407958
target="_blank">http://www.matronics.com/Navigator?Kitfox-List
le, List Admin.
mikeperkins
PostPosted: Tue Sep 03, 2013 5:25 am    Post subject: Re: Fuel Flow thru Facet pump Reply with quote
There is a way around needing to meet the gravity-feed minimum-flow requirement – two fuel pumps each capable independently of supply 1.5x max rate in all flight attitudes.
Think low-wing aircraft - none would pass a gravity-flow test. The FAA just wants two sources of fuel pressure, each sufficient on their own to operate the engine at full power in all flight attitudes. So for low-wing aircraft, the minimum is two fuel pumps or one pump plus a header tank, both of which separately meet the 1.5x requirement. (Kitfoxes, with their low-mounted header tank, will usually not meet the 1.5x requirement.)
If your desire is to have two Facet pumps plus the engine-driven fuel pump (three sources of pressure), one Facet pump could be switched on all the time but the other could be either on all the time or switched only switched on for TO and landing. For redundancy, the second pump naturally would be supplied by a separate switch and breaker. But for the FAA, a single Facet pump would be enough for their redundancy requirement.
As long as there are at least two independent fuel sources that meet the 1.5x requirement, it doesn’t matter that none of them are gravity-feed.
Mike Perkins
Havana, Illinois
Model I, 532, B gearbox, GSC prop
PostPosted: Tue Sep 03, 2013 8:22 am    Post subject: Fuel Flow thru Facet pump Reply with quote
This was essentially my take on the discussion on the other forum and what I
gathered from reading the specs from the FAA. I was led to understand
that gravity flow requirements were not dependent on whether the airplane
had high wing tanks conducive to gravity flow, but rather whether the fuel
system had fuel pumps in the system. A Sonex with Rotax 912, would not have
to prove any level of gravity fed fuel flow. We while flying the high wing
Kitfox have a two fold redundancy with an engine driven fuel pump and high
wings providing a level of gravity flow. One poster in the other forum
mentioned that he could maintain altitude with a failed engine driven fuel
pump relying only on gravity fed fuel.
Lowell
Sent: Tuesday, September 03, 2013 6:25 AM
requirement â?" two fuel pumps each capable independently of supply 1.5x
1.5x requirement, it doesnâ?Tt matter that none of them are gravity-feed.
Mike Perkins
Havana, Illinois
http://forums.matronics.com/viewtopic.php?p=407972#407972
n223rv(at)wolflakeairport
PostPosted: Tue Sep 03, 2013 10:02 am    Post subject: Fuel Flow thru Facet pump Reply with quote
So what is the purpose of the low mounted header tank? Why is the KitFox not designed with 2 lines (one from each tank) to a selector valve (left-right-both-off)?
Just curious.
-Mike
On Sep 3, 2013, at 12:21 PM, "Lowell Fitt" <lcfitt(at)sbcglobal.net> wrote:
This message cannot be displayed because of the way it is formatted. Ask the sender to send it again using a different format or email program. text/plain
mikeperkins
PostPosted: Wed Sep 04, 2013 6:38 am    Post subject: Re: Fuel Flow thru Facet pump Reply with quote
Mike,
All header tanks are installed with the same intention: insure fuel flow in 1) a dive, or 2) with one tank empty and the other tank unported due to a slip or skid.
Once upon a time, in the Model 1 and 2 days, fuel lines were commonly being routed uphill, over top of the door and then down between the windshield and the door, then back up to a firewall-mounted header tank. The biggest problem with this installation was requiring the fuel to go uphill over the doors because of the extremely low head pressure, or even negative head pressure, at that point in the system. Pulling fuel like this with a pump leads to vapor lock. Vapor lock is often associated with high temperatures, so thinking of it as an expanding "gas bubble" might be a better way to look at it. Anyway, to get around the problem of unreliable fuel flow, folks were resorting to installing primer bulbs over the doors, which had their own problems, and the whole thing was getting messy.
The switchover to the rear-mounted header tank arrangement occurred about 1990. The intention was to encourage routing that kept the fuel constantly going downhill immediately after leaving the wing tanks to prevent vapor lock. I switched my system over from the old way to the new way after it had all been plumbed but not flown. When I installed the rear-mounted header tank, I also added a valve just above the seat between each wing tank and the header tank. And I installed a main shutoff just forward and below the left door. The system has worked well for 400 hours.
Mike Perkins
Havana, Illinois
SWeidemann
PostPosted: Wed Sep 04, 2013 7:29 am    Post subject: Fuel Flow thru Facet pump Reply with quote
I agree with Mike's question. Why is a header tank necessary for such a system (Kitfox with low behind the seat header tank) where gravity should take care of ALL your fuel pressure needs? I have an ancient Luscombe with wing tanks that uses Mother Nature's Gravity System and has no fuel pump anywhere.
Sko
WestSouthWest
mikeperkins
PostPosted: Wed Sep 04, 2013 7:46 am    Post subject: Re: Fuel Flow thru Facet pump Reply with quote
The Luscombe's updraft carb is located much farther below the wing tanks than the the Kitfox's side-draft carbs. So the Luscombe's head pressure at the carb is going to be a lot higher, and so will the gravity fuel flow rate. That's my guess anyway.
Mike Perkins
Havana, Illinois
