				 Posted: Sun Aug 25, 2013 2:36 pm    Post subject: Longer engine cables - throttle cable and mixture cable |
				During my 2nd condition inspection I see that both by throttle and
 mixture cables have started to wear through their sheathing in spots.  I
 know needing longer cables than the stock Vans cables is a common
 requirement.
 Where are people buying longer cables these days?
 I see in the archives that Dave Saylor identifies someone is
 California.  I also see ACS (not Aircraft Spruce?).
 Thanks.
  |  | - The Matronics RV10-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sun Aug 25, 2013 3:23 pm    Post subject: Longer engine cables - throttle cable and mixture cable |
				I sent this note to Van's a year and a half ago.  The response back was 'many people are using the recommended cable'.  The 50.5" cable from Van's worked just fine (standard Van's engine and push/pull controls).
 Carl
 From: Carl Froehlich [mailto:carl.froehlich(at)verizon.net]
 Sent: Wednesday, April 25, 2012 8:58 PM
 To: 'support(at)vansaircraft.com'
 Subject: RV-10 Throttle Cable too short
 I installed the Van’s recommended throttle cable (CT BLK THROTTLE 47.5) in my YIO-540 RV-10 project.  It is simply too short.  I just purchased and installed the IO-360 cable (CT BLK THROTTLE 50.5) and it fits better, but not perfect.
 Recommend offering a 49” cable for the RV-10 throttle control, or at least selling the 50.5” instead of the 47.5” cable to RV-10 builders.
 Your recommended prop and mixture cables worked well.
 Carl Froehlich
 40528
		Kelly McMullen
				 Posted: Sun Aug 25, 2013 3:42 pm    Post subject: Longer engine cables - throttle cable and mixture cable |
				Well, I am getting close to ordering my cables. I recall that ACS offers a higher quality cable than what Vans buys from them. Top quality cables also can be obtained from McFarlane, but are priced some where between 2 an 3 times Van's price. I need to talk to McFarlane as to what the real length of their cables that they list for the RV-10 measure, as they show for stock panel and for Aerosport panels but don't say what the length is on their website.
 On Sun, Aug 25, 2013 at 3:34 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
   	  | Quote: | 	 		  --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
  During my 2nd condition inspection I see that both by throttle and mixture cables have started to wear through their sheathing in spots.  I know needing longer cables than the stock Vans cables is a common requirement.
  I see in the archives that Dave Saylor identifies someone is California.  I also see ACS (not Aircraft Spruce?).
  Thanks.
  http://forums.matronics.com
  le, List Admin.
  - sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
		dave.saylor.aircrafters(a Guest
				 Posted: Sun Aug 25, 2013 6:12 pm    Post subject: Longer engine cables - throttle cable and mixture cable |
				California Push-Pull makes and sells CableCraft cables.  The green cables from Vans are also CableCraft, but I used a different spec that seems to handle heat better.  Look for 176-VTT part numbers.  The part numbers in the archives should be available from any CableCraft distributor.
 I changed my cables at around 500 hours.  The new ones have close to 800 now and are smooth as silk.
 Please note the measurements I gave are for a quadrant.
 Dave Saylor
 831-750-0284 CL
 [quote]  --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
  Thanks.
  " target="_blank">http://www.matronics.com/Navigator?RV10-List
  MS -
  e -
		jkreidler
  Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
				 Posted: Mon Aug 26, 2013 4:32 am    Post subject: Re: Longer engine cables - throttle cable and mixture cable |
				We used the throttle cable for the RV-7 which is 3" longer than the one supplied for the -10.  The mixture cable as supplied worked fine for us (standard panel with push pull).  - Jason
  _________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
		AirMike
				 Posted: Mon Aug 26, 2013 7:33 am    Post subject: Longer engine cables - throttle cable |
				Replaced my Vans cable at about 150 hrs. It developed a wear spot in the plastic shield material. I tried fixing it with tank sealant. That also wore thru. Probably best to start out with the proper cable. Vans is tooooo short!
  _________________ See you OSH '18
Q/B - sold. |
