karolamy(at)roadrunner.co Guest
Posted: Sun Aug 25, 2013 7:26 pm Post subject: Engine Settling Measurement |
| Quote: | From you guys with Van's engine and cowl, and that have at least 50 plus hours of flying on your 10, how much did the engine settle relative to the fixed position of the cowl? My 6 settled about 3/32 and that was about what I planned for - lucky!
Also were you successful with only 1/8th inch gap between spinner bulkhead and forward cowl as per plans, or do you wish you had increased this gap just a bit to facilitate cowl removal?
I'm certain I'll get quite a variety of opinions, but that's ok, please just let em rip!!!
Thanks Much,
Rich
Posted: Mon Aug 26, 2013 2:29 am Post subject: Engine Settling Measurement |
My -4 settled a lot (~1/4") but my -10 did not settle any appreciable amount.
I'd leave as large of a gap behind the spinner that you are comfortable with for the reasons you gave. I didn't build a race plane, I was more of "I don't want to scratch the paint and I want to be able to cowl it myself."
YMMV
-Mike Kraus
RV-10 flying 150 hours
On Aug 25, 2013, at 11:21 PM, Karol Hansen <karolamy(at)roadrunner.com> wrote:
Thanks Much,
Rich
rv10flyer
Posted: Mon Aug 26, 2013 7:18 pm Post subject: Re: Engine Settling Measurement |
I built my cowl with prop spinner 1/8" higher. After i installed the .090" ss pins in the rear top hinge in place of alum .125" per instructions cowl dropped a little and rear gap enlarged. After 120 hours/20 mo my spinner is still about 1/8" higher than cowling. I think the engine settled less than 1/16" just like my cowl. I would recommend perfect alignment and not worry about it.
I left 1/8" clearance between backplate and cowl. It works but entirely too tight. I would recommend 1/4-3/8".
_________________ Wayne G. |
bill.peyton
Posted: Tue Aug 27, 2013 3:47 am Post subject: Re: Engine Settling Measurement |
Mine settled around 1/8, may be just a bit more. I left 1/4 gap and glad I did.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
