ASchlem
Posted: Wed Aug 28, 2013 8:21 pm Post subject: can you put a 582 on a mark ii |
I have a good twinstar mark II, I would like to upgrade to the 582. are there any reasons not to.
ASchlem
Posted: Thu Aug 29, 2013 8:58 am Post subject: Re: can you put a 582 on a mark ii |
I guess what I'm trying to ask is will the plane handle the extra weight and torque. Seems like I read that the larger spares and boom were added to the mark iii to handle the 582 and larger engines.
Eugene Zimmerman
Posted: Thu Aug 29, 2013 12:52 pm Post subject: Re: can you put a 582 on a mark ii |
Yes. I have a Mark II with a 582 on it since the early 1990's and have had no problems with it.
The extra power of a 582 is no problem on a MarkII as long as you respect the gross weight limitation and vne.
The main problem is, you will have to give up the wing fold ability since there is an interference issue between the wing and the location of the carburetors on a 582.
