Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27557 Location: Livermore CA USA
Posted: Sat Aug 31, 2013 5:35 pm Post subject: 3/16 vs 1/4 Brake Lines... |
At 06:22 PM 8/31/2013 Saturday, you wrote:
My RV8a project is ready for wheels, and I keep thinking about the brake system and lines. Seem to me like some weight could be saved by going with 3/16 brake lines, (smaller line and less fluid). Problem with small lines is the heavy viscosity of A/C hydraulic oil, especially when cold. Solution would be automotive Dot 3 or Dot 4, but are there compatability issues with the Matco master cylinders and Cleveland calipers? Maybe new o-rings could solve the problem? Anyone know the answer?
Hi Dennis,
Hum, you should actually put the parts and fluid between a 1/4" and a 3/16" system on a scale and weigh them. I think that you're going to find the difference in weight is almost negligible. Oh the other hand, the difference in braking capabilities could be deadly. Personally, I could stand to lose 50 lbs around my belly. That is some realy weight savings that would make my RV fly a lot better.
I've done a fair amount of custom stuff on my RV, but when it comes to engineered stuff like the size of the brake lines, and other dimensional stuff, Van's is the man. Van's hates fat airplanes. If he felt that 3/16" brake lines would be adequate, I know for certain that he would have used them.
Matt's $.02.
Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
_________________ Matt Dralle
Posted: Sat Aug 31, 2013 5:36 pm Post subject: 3/16 vs 1/4 Brake Lines... |
Hi Dennis,
Matt's $.02.
rwstracy(at)gmail.com Guest
Posted: Sat Aug 31, 2013 6:27 pm Post subject: 3/16 vs 1/4 Brake Lines... |
Dot 3 or 4 will destroy the rubber used in most AC brake components. At least that was true 10 years ago and I doubt that has changed.
Tracy
RV-4
RV-8
On Aug 31, 2013, at 21:34, Matt Dralle <dralle(at)matronics.com> wrote:
Hi Dennis,
Matt's $.02.
dan.pat.b(at)gmail.com Guest
Posted: Sat Aug 31, 2013 6:33 pm Post subject: 3/16 vs 1/4 Brake Lines... |
DennisRe use of 3/16" brake line instead of Vans' 1/4" - I'm not an engineer but the folks who design airplanes at Vans Aircraft are - they use 1/4" brake lines for a reason - my advice would be don't do it - there is a serious safety issue here - braking action would almost certainly be dangerously impacted - want to save a few ounces - Matt offered some great advice - go on a diet -
Dan Bergeron
RV-7A - N307TB
425 hours since first
flight on 8/6/09
On Sat, Aug 31, 2013 at 9:34 PM, Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)> wrote:
[quote]--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
>--> RV8-List message posted by: Dennis Fox <dennisfox(at)persona.ca (dennisfox(at)persona.ca)>
Hi Dennis,
Matt's $.02.
get="_blank">http://www.matronics.com/Navigator?RV-List
http://forums.matronics.com
le, List Admin.
decaclops(at)gmail.com Guest
Posted: Sat Aug 31, 2013 7:52 pm Post subject: 3/16 vs 1/4 Brake Lines... |
Nothing wrong with 3/16" lines operationally. They make for a harder
pedal feel. We're not moving very much fluid to where the difference in
size would be a detriment. Really, when you think about it, brakes are
for run up anyway. I use the MIL-PRF-83282 synthetic brake fluid. Van's
sells it as Royco 782. It has a higher flashpoint than 5606, but is
completely compatible. That means you can find something that will work
when you need some fluid away from home.
Ed Holyoke
On 8/31/2013 7:33 PM, Dan Bergeron wrote:
| Quote: | Dennis
Dan Bergeron
RV-7A - N307TB
flight on 8/6/09
<mailto:dennisfox(at)persona.ca>>
Hi Dennis,
Matt's $.02.
Flyer Mode
le, List Admin.
chaskuss(at)yahoo.com Guest
Posted: Sun Sep 01, 2013 5:54 am Post subject: 3/16 vs 1/4 Brake Lines... |
Tracy is correct about automotive brake fluids destroying the stock brake O-rings. Use of DOT 3 or 4 will require replacement of all the O-rings in your master cylinders, parking brake and calipers with items made from EPDM. See
http://en.wikipedia.org/wiki/EPDM_rubber
This material has the added benefit of having a higher temperature rating, when compared to the stock Nitrile [aka Buna N] O-rings. You would also have to change out the flex hoses coming off of the master cylinders from the stock Nitrile lined units to Teflon lined stainless steel items. Use of 3/16" lines will change the feel of the brakes, but not much else. The amount of fluid transfer during braking is small.
I can supply a set of EPDM O-rings if you are interested in swapping to DOT 4. No sense in using the lower rated DOT 3 fluid. For improved heat resistance with the standard fluids, replace the caliper O-rings with items made of Viton rubber.
On Sat, 8/31/13, Tracy <rwstracy(at)gmail.com> wrote:
Subject: Re: Re: 3/16 vs 1/4 Brake Lines...
To: "rv-list(at)matronics.com" <rv-list(at)matronics.com>
Date: Saturday, August 31, 2013, 10:27 PM
components.At least that was true 10 years
Tracy
RV-4
RV-8
<dennisfox(at)persona.ca>
> Hi Dennis,
have used them.
> Matt's $.02.
> Matt Dralle
Construction Log
Log
> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV
YouTube Channel
Landing Mishap...
Log
at the Livermore
Forum -
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
Posted: Sun Sep 01, 2013 9:15 am Post subject: 3/16 vs 1/4 Brake Lines... |
We've installed 3/16" lines on several Lancairs since some need a particularly small OD to fit past part of the landing gear. They work very nicely and don't seem any different than 1/4" lines.
I second the opinion about using MIL-PRF-83282. There's not really any reason not to.
Dave Saylor
831-750-0284 CL
On Sat, Aug 31, 2013 at 8:51 PM, Ed <decaclops(at)gmail.com (decaclops(at)gmail.com)> wrote:
[quote] --> RV-List message posted by: Ed <decaclops(at)gmail.com (decaclops(at)gmail.com)>
Nothing wrong with 3/16" lines operationally. They make for a harder pedal feel. We're not moving very much fluid to where the difference in size would be a detriment. Really, when you think about it, brakes are for run up anyway. I use the MIL-PRF-83282 synthetic brake fluid. Van's sells it as Royco 782. It has a higher flashpoint than 5606, but is completely compatible. That means you can find something that will work when you need some fluid away from home.
Ed Holyoke
| Quote: | Dennis
Dan Bergeron
RV-7A - N307TB
flight on 8/6/09
<mailto:dennisfox(at)persona.ca (dennisfox(at)persona.ca)>>
Hi Dennis,
Matt's $.02.
Flyer Mode
le, List Admin.
target="_blank">http://www.matronics.com/Navigator?RV-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
vanremog(at)aol.com Guest
Posted: Sun Sep 01, 2013 9:26 am Post subject: 3/16 vs 1/4 Brake Lines... |
I applaud the fact that many of you have gotten educated over the years on the MIL-PRF-83282 fluid (developed in response to many military aircraft brake fires in the the early '50s) and the use of Viton O-rings. It only took us in GA fifty years to begin adopting it. IMO the 5606 should be consigned to the scrap bin of history.
I agree with the acceptability of the 3/16" lines as well. Been working fine for 15 yrs now on N1GV.
-GV
Bill Schlatterer
Posted: Sun Sep 01, 2013 10:02 am Post subject: 3/16 vs 1/4 Brake Lines... |
Also note that EDPM is not compatible with 5606 or 83282 ! I thought I
would do the Dot3 or 4 and put in the EDPM ORings but used 5606 later
assuming if good for D3 or D4 it would work as well. See results....not
pretty. Soo...my thought was why change up a good design, just use the
83282 which has a higher flash point and is compatible with anything you are
likely to find at an airport if you ever need a fill away from home. I
think there is also a better O'Ring for the stock 5606/83282 fluid as well.
Bill S
1.98 MB |
11777 Time(s) |
ceengland7(at)gmail.com Guest
Posted: Sun Sep 01, 2013 10:08 am Post subject: 3/16 vs 1/4 Brake Lines... |
You know, Van might have made the decision to use 1/4" for any number of reasons. It could be a combination of factors like: it's what they always used, parts stock commonality, ease of workability for inexperienced builders, etc. My -7 kit shipped with the old style black fabric covered flexible lines. Certainly not the best option, measured by several different standards.
Look how long it took them to switch to a modern airfoil. As great as the -3-- -8s fly, they finally switched to more modern airfoils on the later models.
On 09/01/2013 12:26 PM, vanremog(at)aol.com (vanremog(at)aol.com) wrote:
[quote] I applaud the fact that many of you have gotten educated over the years on the MIL-PRF-83282 fluid (developed in response to many military aircraft brake fires in the the early '50s) and the use of Viton O-rings. It only took us in GA fifty years to begin adopting it. IMO the 5606 should be consigned to the scrap bin of history.
-GV
Posted: Sun Sep 01, 2013 10:38 am Post subject: 3/16 vs 1/4 Brake Lines... |
Nitrile/BunaN Seals = Low temp petroleum-like hydraulic fluids 5606 (non-hygroscopic)
Viton (Fluorocarbon) Seals = Higher temp petroleum-like hydraulic fluids 83282 and many ATFs (non-hygroscopic)
EPDM Seals = Dot 3 and 4 glycol fluids (hygroscopic)
Natural Rubber Seals = Girling fluid (vegetable oil based)
Paul Valovich
Posted: Sun Sep 01, 2013 10:53 am Post subject: 3/16 vs 1/4 Brake Lines... |
I had some initial wear issues with my -8A left brake (built IAW Vans instructions) during Phase 1. Got those resolved and consider brakes to be a condition inspection item, pretty much ignored if working properly the rest of the time – over 330 hrs. I think substituting 3/16 lines would always induce a “Wonder if they’re still ok?” feeling. IMHO not worth the couple ounces of weight savings. If you are really into weight savings by the ounce there are a lot of other ways to approach your objectives.
Paul Valovich
N192NM
JohnCiolino(at)carolina.r Guest
Posted: Sun Sep 01, 2013 10:45 pm Post subject: 3/16 vs 1/4 Brake Lines... |
I installed 3/16” brake lines made by Bonaco. I asked them the question about 3/16 vs. ¼ and they pointed out that 3/16 is used on 3000lb race cars. Give them a call. They should also have my dimensions and pics of my lines running from the Grove gear to the caliper.
I have no expertise in brake engineering but my brakes are working well.
John Ciolino
RV-8
N894Y
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Saylor
Sent: Sunday, September 01, 2013 1:12 PM
To: rv-list(at)matronics.com
Dave Saylor
831-750-0284 CL
Ed Holyoke
Dennis
Dan Bergeron
RV-7A - N307TB
flight on 8/6/09
Hi Dennis,
Matt's $.02.
Flyer Mode
le, List Admin.
MS -
e -
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234567
