Posted: Mon Oct 21, 2013 3:56 am Post subject: Replacement bolts for lifting rings |
Does anyone have the correct designation number for the through bolts for the lifting rings?
I would like to remove the lifting rings and replace with the next size shorter bolts and nuts.
Ralph Capen
| | - The Matronics LycomingEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?LycomingEngines-List |
harley(at)agelesswings.co Guest
Posted: Mon Oct 21, 2013 4:08 am Post subject: Replacement bolts for lifting rings |
Morning, Ralph...
Not sure which engine you have, as you used the plural of ring...I only have one ring on my O-235 (HAD one ring). It was mounted with one of the case half bolts, so when I removed it, I just measured the existing case half bolt in the next hole over and used that size AN bolt/nut to replace the longer one that held the ring in place.
Larger engines may have a different attach method, however, so this may not apply in those cases.
Harley Dixon
Long EZ N28EZ
On 10/21/2013 7:55 AM, Ralph E. Capen wrote:
[quote] | Quote: | --> LycomingEngines-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net> (recapen(at)earthlink.net)
Ralph Capen
| [b]
Posted: Mon Oct 21, 2013 4:29 am Post subject: Replacement bolts for lifting rings |
IO360B1F6...two rings. One forward and one aft - on case half bolts like your single.
I would like to replace it with similar (coarse thread) about three sizes shorter.
Thanks.
Posted: Mon Oct 21, 2013 4:33 am Post subject: Replacement bolts for lifting rings |
These are standard AN hardware from Aircraft Spruce.
Carl
| Quote: | On Oct 21, 2013, at 7:55 AM, "Ralph E. Capen" <recapen(at)earthlink.net> wrote:
Ralph Capen
