914 Fuel Flow Indicators
tonyrenshaw268(at)gmail.c
PostPosted: Sun Oct 20, 2013 12:59 pm    Post subject: 914 Fuel Flow Indicators Reply with quote
Gidday,
Could I please request input of the preferred brands of Fuel Flow Indicators currently in favour that cope well with a second transducer in calculating the 914 usage? I am working on my panel layout and it would be handy to tighten up in my thinking what is the best option. Thanks.
Tony Renshaw
Sent from my iPad
grahamsingleton(at)btinte
PostPosted: Sun Oct 20, 2013 1:34 pm    Post subject: 914 Fuel Flow Indicators Reply with quote
Hi Tony
best flow transducers are Floscan, you will need two. Sadly they aint't cheap!
If you can find a marine or automotive equivalent they will be cheaper. Dynon use an equivalen but can't remember what its called, someone will?
Graham
btw hope the forest fires don't bother you.
Sent: Sunday, 20 October 2013, 21:39
Subject: 914 Fuel Flow Indicators
--> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)>
Gidday,
Tony Renshaw
Sent from my iPadhttp://www.matronics.com/Navigator?Europa-Listhttp://forums.sp; - List Contribution Web Site -
_; &nb://www.matronics.com/contribution" =======
rlborger(at)mac.com
PostPosted: Sun Oct 20, 2013 1:35 pm    Post subject: 914 Fuel Flow Indicators Reply with quote
Gidday Tony,
I have a Grand Rapids EIS 4000 with fuel return option on my 914. ( http://www.grtavionics.com/eis4000.html )
I don't know what other engine instrumentation you already have so this may be serious overkill for your needs, but it has worked well as a total Engine Information System for me.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Oct 20, 2013, at 3:39 PM, Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
Gidday,
Tony Renshaw
davidjoyce(at)doctors.org
PostPosted: Mon Oct 21, 2013 12:28 am    Post subject: 914 Fuel Flow Indicators Reply with quote
Tony, if it really is just a fuel flow instrument you want
the FS450 with 2 Floscan transducers is or at least was
the best, but I would now go for an engine monitoring
system which includes fuel flow rather than a lot of
seperate instruments. An EIS will tell you as soon as
anything departs from your preset norms, rather than you
having to keep looking at lots of dials and potentially
missing that plane on a converging course. That is to say
that you have the chance of designing your panel so as to
minimize the time you need to spend looking at it
Regards, David Joyce, G - XSDJ
On Mon, 21 Oct 2013 07:39:10 +1100
Gidday,
Thanks.
Tony Renshaw
Sent from my iPad
Un/Subscription,
Forums!
Admin.
stranfaer(at)btinternet.c
PostPosted: Mon Oct 21, 2013 1:08 am    Post subject: 914 Fuel Flow Indicators Reply with quote
Dynon use "Cube"
hope this helps?
rgds
The other one
Sent to you from David Joyce
www.eastmidsspas.com
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
To: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
Sent: Sunday, 20 October 2013, 22:31
Subject: Re: 914 Fuel Flow Indicators
Hi Tony
Graham
Gidday,
Tony Renshaw
Sent from my iPad http://www.matronics.com/Navigator?Europa-List http://forums.sp;   - List Contribution Web Site -
[quote]ht; http://www.matronics.com/contri===============
h&jeuropa
PostPosted: Mon Oct 21, 2013 4:41 am    Post subject: Re: 914 Fuel Flow Indicators Reply with quote
The "cube" is made by EI. All the EFIS and engine monitor manufacturers use it now instead of FloScan transducers.
As suggested above, since you're just starting on your panel, consider a EFIS with full engine monitoring. We have two GRT Sport EFIS and a GRT EIS which really is the interface to the EFIS. Works great!
Jim & Heather
N241BW
Mono 914
