2) Your Full Name:
3) Your Email Address:
pictures@matronics.com
Email List Administrator
Submitted By:   tcstuart@adelphia.net
Email List:   Kolb-List,Ultralight-List
Name:
Clay Stuart
Date:
Feb 28 2004
Subject:   Xtra rear fuselage enclosure
    airplane_003.jpg Inside view of rear enclosure. Custom dual 8 gal fuel tanks. Note custom Rochester spiral sealed fuel gauge on R tank. I will be able to look over my shoulder through the Lexan to see gauge. Since both tanks will feed to a gascolator, it will show levels in both.
    airplane_004.jpg Another view, note blue vents on top. When tubing is attached, it will exit below the fuselage so no fuel will leak out in case of inverted position.
    airplane_005.jpg Outside view of L rear enclosure. With apologies to Uncle Craig, I bought a joggle tool and made the fuel door reinforcement plate. The fuel door is supplied with a Hartwell latch. The rear window also has a joggled plate support. It has 3 segments of piano hinges on the top and is shut with 2 camlocks. Presently I have the phillips type camlocks, but I may change to winged ones if I can get them to line up with the airstream. The metal is 0.32 except for the fuel doors which are 0.50.
    airplane_006.jpg Shows the fuel door open with the Hartwell latch.
    airplane_007.jpg Custom seats, note padded armrest in center.
    airplane_008.jpg Weather stripping along Lexan above doors.
    airplane_009.jpg R upper enclosure with fuel door. I have installed the Lexan window with camlocks for easy removal for access or storage.
  • UN/SUBSCRIBE
  • Full Archive Search Engine
  • 7-Day List Browsing
  • Browse the List Digests
  • Live Online Chat!
  • Archive Downloading
  • Photo Share
  • Other Email Lists
  • Contributions
