Submitted By: wstucklen1@cox.net Email List: RV-List,RV3-List,RV4-List,RV6-List,RV7-List,RV8-List,RV9-List,RV10-List Name: Fred Stucklen
Date: Jan 2 2003
Subject: RV-6A IFR Inst Panel & Wiring Description: Here's what I'm currently building on the next RV-6A. The Panel was laid out using IntelliCAD, and, when plotted full size (at work), results in a very accurate overlay that was glued to the panel, then used as a drill template for all panel holes. Note the use of Auto Fuse blocks in the forward area, and the additional access panels installed in the front skin. This saves a lot of valuable panel space (but there's still room for breakers...). Also not how the F-668 Sub panel has been cut out (and re-enforced). The bar across the bottom of this panel is also used as the common ground for all instruments. he switch sub-panel (.040 T3) was formed on 3/4" plywood forms, with the curve hammered out with a wood block. results were no cracks and a strong area to mount the switches and throttle/mixture push-pull controls. If anyone wants more details, email me at wstucklen1@cox.net -Fred Stucklen
Front_Deck1.jpg Photo 1 Inst_panel_layout5.jpg Photo 2 Inst_Panel_layout.jpg Photo 3 Panel_Sub_Panel.jpg Photo 4 Wiring10.jpg Photo 5 Wiring11.jpg Photo 6 Wiring13.jpg Photo 7 Wiring2.jpg Photo 8
