AeroElectric-Archive.digest.vol-fm
February 27, 2006 - March 09, 2006
From: | "David Carter" <dcarter11(at)sbcglobal.net> |
Subject: | Re: Static Dischargers |
I believe p-static is principally the noise created by static electricity
jumping from skin panel to skin panel on the way aft and finally off of the
plane in elevator and rudders. I think fiberglass stuff up front is a big
source of buildup. You could try running a wire from nose to tail, with good
electrical connection at each end - this might let the static build up on
fiberglass cowl (I'm thinking RV series aircraft) bleed off by going from
front to back without jumping a lot of little skin gaps along the way (don't
ask me why the fore-aft longerons wouldn't do the same).
David
----- Original Message -----
Sent: Monday, February 27, 2006 9:10 AM
Subject: AeroElectric-List: Static Dischargers
> Hopefully some of you can help me out. Last week I finally got to fly in
> some actual IMC in my plane (total of 4 hours actual). After about 15
> minutes in the clouds, my radio transmissions became more and more filled
> with static. Still understandable, but not very clear. No static when just
> listenning to controllers or talking without transmitting. Slowly cleared
> up after exiting clouds. I think this is a static build up problem and
> wondered what others thought. My airplane is an CH640 and I have braided
> grounding straps across rudder and horizontal tail hinges. They didn't
> specify static wicks in the design. I know that static dischargers should
> be out and back as far as possible, but otherwise am not sure about
> placement and how many I may need. Is there any general advise concerning
> placement and number, or is it basically a trial and error process to see
> what works?
> http://forums.matronics.com/viewtopic.php?p=17053#17053
Subject: | Static Dischargers |
Yes, we know of p-static. It's a real problem in our fast plastic airplanes.
The only solution the factory ever came up with was a copper mesh imbedded
in the glass close to the surface, this was also their solution to lightning
protection. I believe the same solution was used on the SR-20/22. Others
(builders) have had some success with conductive primer. Static wicks won't
work on our airplanes.
Bruce
www.glasair.org
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David
Carter
Sent: Monday, February 27, 2006 11:09 PM
Subject: Re: AeroElectric-List: Static Dischargers
David
> what works?
Subject: | High Current Diodes |
Instead of a contactor and switch why not use one of these high current
diodes to protect a ground power plug (power in but not out)? Or at least
to eliminate the need for a disconnect switch by preventing "back flow" from
engergizing the contactor? Would these also be appropriate for feeding a
larger secondary bus?
http://www.surplussales.com/Semiconductors/Diodes-3.html
Or is there a dangerous failure mode or quirk in their specs I'm missing?
Thanks!
Scott.
From: | "steveadams" <dr_steve_adams(at)yahoo.com> |
Thanks for all the suggestions. I have over 150 hours flying, and this never happened
before. I was flying down to Florida, straight and level when it first
happened. As I said, it cleared slowly after leaving the clouds. I then took a
few flights VFR and everything was fine. Then again coming home I was in the
clouds and it happened again, but not as bad. On my plane the cowl is fiberglass,
but the cabin is carbon fiber and the rest of the plane is metal. Com 1 antenna
is on top, and com 2 is on the bottom. Static was worse on #1, but also
present on com 2, again, only with transmission. Maybe it is something other than
p-static. The CH640 airframe is the same as the Alarus, which does not have
static wicks, and from people I have talked to it has no p-static problems.
The 640 is about 30 KTS faster though, which could make a difference. I guess
it is worth finding a few static wicks and seeing if it makes a difference.
http://forums.matronics.com/viewtopic.php?p=18363#18363
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> |
>never happened before. I was flying down to Florida, straight and level
>when it first happened. As I said, it cleared slowly after leaving the
>clouds. I then took a few flights VFR and everything was fine. Then again
>coming home I was in the clouds and it happened again, but not as bad. On
>my plane the cowl is fiberglass, but the cabin is carbon fiber and the
>rest of the plane is metal. Com 1 antenna is on top, and com 2 is on the
>bottom. Static was worse on #1, but also present on com 2, again, only
>with transmission. Maybe it is something other than p-static. The CH640
>airframe is the same as the Alarus, which does not have static wicks, and
>from people I have talked to it has no p-static problems. The 640 is about
>30 KTS faster though, which could make a difference. I guess it is worth
You bring up an interesting point. Not every owner
of a particular airplane has p-static problems to
report . . .
It's a HIGHLY variable phenomenon. EVERY airplane has
a p-static charge on it to some degree or another, it's
only in the right combination of variables that noise
levels rise sufficiently to be heard on radios. In severe
cases, we've had p-static eat away at structural parts of
the airplane . . . e.g. window glazing. The results
of your experimenting may not be known until you seem
to have slain the dragon by not having problems over a
series of similar conditions . . . which could take years.
It's quite disappointing than to have a solution
in place for a couple of years and encounter conditions
further out on the bell-curve and find that you're only
partially successful.
What you're experiencing is not new/startling. In fact,
it's so commonplace and has such a problematic history
of solutions that first response from those who have
wrestled with it is sympathy and best wishes for a lucky
break. Folks who do this professionally have access to
expensive test and development tools and techniques
that are not going to be available to the OBAM aircraft
community. So, please do experiment and let us know of
your findings. But I would also caution that what works
for you may only be a starting point for determining
what mitigates someone else's problems at a later date.
Good luck!
From: | " Peter Laurence" <Dr.Laurence(at)mbdi.org> |
Subject: | Re: Lr-3 question Z diagram question |
> Hello I am installing a Lr-3c regulator from B+c. I was wondering if
> anybody had made up a temp sensor for this regulator without buying the 85
> dollar one from B+C.
> I have seen several items on this list about Shotsky diodes. The Digikey
> book has 4 pages of them . Would they be better to use then the regular 4
> terminal diode that is listed in the Z diagrams for the endurance bus? If
> so which one to get? Thanks
Try Eric Jones' Perihelion Design
Perihelion Design He has them.
Peter>
Subject: | Re: d-sub panel connector source |
> remind me where I can get a panel mount d-sub connector for laptop
> interconnectivity with the Dynon and GRT EFIS I hope to install one day.
> I've checked websites and list archives with no joy. I know this was
> recently discussed.
> Thanks.
> -Bill B
Try
Digi-Key Corporation - USA Home Page
or http://mouser.com/>
Peter
Subject: | Re: High Current Diodes |
>Thanks!
Depends on your design goals for ground power functionality.
I produced the article at:
http://aeroelectric.com/articles/grndpwr.pdf
. . . based on requests for a ground power installation.
After having experienced a situation where the guy on the
ground had his back to me when he shot 28v to my 14v airplane
that I crafted a system with reverse polarity protection,
absolute control of incoming power by pilot -AND- ov
protection.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
Subject: | d-sub panel connector source |
http://steinair.com/ should have them.
Bruce
www.glasair.org
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Peter
Laurence
Sent: Tuesday, February 28, 2006 8:08 AM
Subject: Re: AeroElectric-List: d-sub panel connector source
> recently discussed.
> Thanks.
> -Bill B
Try
Peter
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Startup (Bob N) |
Subject: | Re: Strange alternator behavior at Startup (Bob |
N)
> Bob, most of what you wrote has nothing to do with the topic?
> It is not a debate of IF you should use a I-VR alternator, but I will
> try to address you question, fully knowing you will never be
> satisfied.
> >Bob N wrote
> >If they have understanding to offer, the block diagrams,
> >schematics, test results, etc are in order. That's what I offer and I
> >expect no less.
> Just call them Bob. What's the big deal.
> Bob you provide a wealth of knowledge and experience. I think
> we all can say is of immense help and enjoyment to us amateur
> airplane electricians. Your help to airplane builders in garages
> and hangers world over is with out dispute. Even if I dont agree
> with you, that does not mean I dont understand your point or
> disrespect your accomplishments.
You can't have it both ways George. If my experience and
accomplishments have value, then there must be some useful
application of tools and philosophies upon which those
accomplishments are based. In one breath you extoll the
virtues of those accomplishments, and in the next you brush
my opinion aside because it does not agree with the one you
formed by calling folks on the phone. I talk to lots of people
and I read lots of data sheets but these are STARTING places . . .
I asked you to help explain the inner workings of an exemplar
regulator with a goal of seeing if advertising hype (and the opinions
of those you talked to on the phone) have foundation in physics
and simple-ideas.
After sorting out the sand in data sheets, it's a good idea
to hit lab and RUN the thing. It's not common but I've discovered
things about people's products that they had no understanding
of (and we didn't either until after a few $hundred thousands$
went down the tubes in warranty work).
Real engineering (and teaching) can be accomplished only when
the activities are supported by an understanding and artful
assemblage of simple-ideas. If you choose to drive your career
and tutelage based on telephone conversations and faithful
acceptance of bang-for-the-buck-bullets on data sheets, it's
your choice - but not mine. What you have accepted and now
promote as FACT has yet to be demonstrated.
I'll publish the MC33092 trade study to show others on the list
how the most successful engineering is conducted. By the way,
"work product" is anything which you have created. The trade
study will be my work product based on the products of others
offered as a potential guide for the future efforts of still
more folks. That's what engineers do George . . . make sure
all the bits and pieces fit smoothly into the whole.
> > recently discussed.
These are popcorn parts (everyone has them). See if Radio Shack has
the size you need. The folks at http://digikey.com certainly have
them as do hundreds of other electronics suppliers. Also check out
the article at:
http://aeroelectric.com/articles/matenlok/matenlok.html
(open barrel d-sub pins are installed the same way
with the same tool) and . . .
http://aeroelectric.com/articles/dsubs/d_solder.html
Morning, David (and everyone)...
In my prior life as an engineer at a pharmaceutical company, I spent
years trying to convince management how to solve static buildup problems
with dry powder transfer systems (Desenex Foot Powder, and Caldesene
Baby Powder, among others). Of course, being budget conscious, they
didn't want to change out the plastic tubing for conductive tubing. And
I couldn't just do it, as every change required extensive documentation
and testing followed by FDA approval before it could be implemented.
Understandably, the line operators and mechanics would complain every
time the air was dry, and they got zapped when they came too near a
transfer line (whether it was a vacuum cleaner hose or the main product
flex line). During the summer, when the air was warm and more humid,
there was no problem. The humidity in the air was the conductor.
But, every winter, after the first dry, cold day, I would get a
call...fix it....
Of course, they wouldn't listen to my suggestion...spend the money and
replace the plastic with conductive tubing...so, the managers came up
with many methods they thought would cure it. The mechanics wasted
hours hooking up all kind of crazy gadgets the managers thought of or
heard about that never worked. When they finally used conductive plastic
and ss line, they solved the problems.
As you all know, static buildup occurs on NON-CONDUCTIVE surfaces. So,
if you attach a grounded, conductive wire or braid to such a surface, it
will keep THAT SPOT discharged. Being non-conductive, the rest of the
object can't discharge as the current can't "flow".
An inch away, on the non-conductive surface, the charge will build just
as it always has, looking for a place to jump to when the voltage gets
sufficient. Like your finger, or eventually the wire you hooked up if
it's not too far away (or your radio antenna lead). It can't traverse
along the non-conductive surface to the wire until the voltage is high
enough to make the jump. And that creates noise and/or sparks.
A single wire or braid attached to a single point cannot discharge the
entire plastic surface. As was mentioned already, creating a conducting
surface that contacts every point of the plastic to allow bleeding at
that point, and within a reasonable distance either side of it, will.
Like a fine mesh wire screen. Or a conductive surface.
Or, a metal airplane....
Harley Dixon
Long EZ N28EZ
>David
>From: "steveadams" <dr_steve_adams(at)yahoo.com>
>To:
>>what works?
>>Read this topic online here:
Subject: | Re: RE: Update: Strange alternator behavior at Startup |
Robert L. Nuckolls, III wrote:
>> Oh.
>> Well that is very interesting Brian. Could it be that my IGN wire is
>> dead?
>> I have the IGN with voltage applied before cranking (I think. I have not
>> checked it since initial install) and I have an idiot light installed
>> which does work as expected. I will check that IGN wire next time I have
>> the cowl off to verify it is supplying power before cranking. Based on
>> your note below, it is quite possible the IGN wire is doing nothing.
>> Wonder why temperature is at play though.
>> Ill check it and report back.
> Brian, have you been holding out on us?
Uh, no. I thought this was common knowledge about IR alternators.
> I've not been aware of
> any automotive products that would ultimately self-excite at
> any time interval or speed conditions. An interesting phenomenon to
> contemplate.
Almost every IR alternator I have played with exhibits this characteristic.
Now it may be that new ones have no residual magnetism in the field
armature and therefore cannot self excite. OTOH, *I* have not run into
one that would not self excite once you turned it fast enough.
> Just last year I shared the following from my experience with
> the alternators on Bonanzas and Barons:
Yeah. I just assumed that is how they were supposed to work too. And
just the act of using them for awhile builds up magnetism in the
armature. I suspect that, even if they don't self-excite when brand new,
they will after having been used for several hours.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Subject: | Re: Mike's LED Position lights |
Did you compare your measured light output with the FAA required light
output?
You can do a reasonably good job with one-foot piece of string, a
protractor, and a photographic light meter that can read ambient light.
Here is a list of some of the points you should check on the red and
green lights:
+/- Azimuth (off the nose) +/-Elevation CP
0 0 40
0 15 28
0 20 20
0 30 12
0 50 2
20 30 9
25 to 110 30 1.5
Azimuth is the number of degrees off the nose.
Elevation is the number of degrees off the horizon.
The white tail light is even more difficult to get proper light output.
Here are a few points to check on the tail light:
+/- Azimuth (off the tail) +/-Elevation CP
0 to 70 0 20
0 to 70 15 14
0 to 70 20 10
0 to 70 30 6
It takes a LOT of white LEDs to fill the required FAA pattern.
Bill Dube'
mchristian(at)canetics.com wrote:
>I used the Nova EPSX - 402 supply for something like $80. It is fully potted
for
>"extreme" conditions and has two strobe outlets, 3.75 amps draw and 12 diffrerent
>selectable flash patterns in a box 4.7" X 4.4" X 1.7" to feed two wingtip
>strobes ($18 each). It works great.
>For position lights, I used three luxeon stars - one red one green, and you guessed it, one white. They are only $6.00 each. I put them in series with a calculated power resistor and they are so bright it is hard to look at. Total draw for position lights is one amp or less. I thermally bonded them to little thin sheetmetal brackets and mounted them under some Kutzleman clear plastic domes with the strobe heads. Since then, Kutzleman has come out with their streamline combo (www.kestrobes.com) essentially doing the same thing for $94 that I made for less than $40 each.
>Total cost of strobe and position light system is less than $180.
>Mike
>reposting to get subject line to adhere...
From: | "Mark R Steitle" <mark.steitle(at)austin.utexas.edu> |
Richard,
Thanks for the information (url). Looks pretty simple, until you
actually try it yourself for real!
Thought you would find this post from the Aero-electric list of
interest. Bill Dube makes LED clearance light kits for experimental
a/c. Good info to keep on hand if you're going to build your own LED
lights. The Luxeon lights are much brighter than the regular leds.
See ya,
Mark
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill
Dube
Sent: Tuesday, February 28, 2006 2:25 PM
Subject: AeroElectric-List: Re: Mike's LED Position lights
output?
green lights:
0 0 40
0 15 28
0 20 20
0 30 12
0 50 2
20 30 9
25 to 110 30 1.5
0 to 70 0 20
0 to 70 15 14
0 to 70 20 10
0 to 70 30 6
Bill Dube'
potted for
diffrerent
wingtip
>Mike
Subject: | Re: Update: Strange alternator behavior at Startup |
Michael
If it makes you feel better I have some IGN wire sleuthing to do as well
although it is not near the top of my to do list at the moment.
My brand new mini ND IR alternator (100211-1680) draws 3.3 amp field
current through the B-lead any time the OV contactor is closed with the
engine not running. The IGN terminal is simultaneously energised so my
next test is to see if this still happens with the IGN wire
disconnected. If so then it is shopping time for another regulator but
of course on mine it is difficult to get at that wire to test it. I
thought most of these things were smart enough to not energise the field
until the rotor was turning but maybe not. Or perhaps it is just annoyed
because I'm not allowing it to draw its normal 4 ma of standby current
that it would draw from the battery if I wasn't using an OV contactor ;)
It charges and regulates perfectly when the engine is running.
Ken
Brian Lloyd wrote:
>Stewart, Michael (ISS Atlanta) wrote:
>>Oh.
>>dead?
>Could be.
I have the RV wingtip tanks designed for the surface mounted nav lights, so
the option of the enclosed wingtip leading edge lights is not available to
me. Are there any l.e.d. nav/strobe combinations available that meet the FAA
requirements?
Terry
RV-8A
Seattle
I also used luxeons for position lights (2 high-intensity lambertians on
each side) and presented it to our EAA meeting as well as our local
IA/DAR. The DAR had no problem signing off on the intensity and
distribution of the position lights. I previously provided a link to
the EAA article on this for those who were interested.
Luxeons are really the only practical and affordable LEDS that will meet
the position lighting requirements.
Making strobes using LEDS are another matter, as it is very tough to get
to 400 cp. Even many of the non-aviation strobes and power supplies
won't meet this requirement. There are some options other than
Whelan(=$$$, however.
Scott Gettings
From: Mark R Steitle <mark.steitle(at)austin.utexas.edu>
Date: Tuesday, February 28, 2006 4:10 pm
Subject: RE: AeroElectric-List: Re: Mike's LED Position lights
> Richard,
> See ya,
> Mark
> BillDube
> To: aeroelectric-list(at)matronics.com
> light
> output?
> light.
> red and
> green lights:
> 0 0 40
> 0 15 28
> 0 20 20
> 0 30 12
> 0 50 2
> 20 30 9
> 25 to 110 30 1.5
> output.
> 0 to 70 0 20
> 0 to 70 15 14
> 0 to 70 20 10
> 0 to 70 30 6
> Bill Dube'
> fullypotted for
> and 12
> diffrerent
> wingtip
> green, and
> less. I
> madefor less than $40 each.
> >Mike
From: | "Alan K. Adamson" <aadamson(at)highrf.com> |
Might try these guys... I have a set and really like them.
www.gs-air.com
Alan
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Terry
Watson
Sent: Tuesday, February 28, 2006 4:40 PM
requirements?
Terry
RV-8A
Seattle
From: | "richard titsworth" <rtitsworth(at)mindspring.com> |
Alan,
Do you have the XPAK 604-HR strobe driver listed on their website?
I'd like to put a strobe driver in each wingtip and have a low voltage
synchronizer line between them, rather than 1 central driver and coax (to
minimize noise). The picture of the driver on the website seems to have
several (extra/additional) connectors/pinouts but I can't tell what they do
or if it supports a low voltage synchronizer circuit between multiple
drivers.
Do you know? Beyond the multiple strobe outputs and power/ground, what are
the other connectors for?
Rick Titsworth
Detroit
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alan K.
Adamson
Sent: Tuesday, February 28, 2006 5:39 PM
www.gs-air.com
Alan
Watson
requirements?
Terry
RV-8A
Seattle
Thanks Alan. That's just what I was looking for.
Terry
Adamson
Sent: Tuesday, February 28, 2006 2:39 PM
www.gs-air.com
From: | "LarryRobertHelming" <lhelming(at)sigecom.net> |
I have the one central control power supply. I do not have any noise. So,
I don't understand you concerns about wanting to minimize it. It is not
there to start with. I wired per the instructions and did nothing special
beyond that.
The extra connectors are for different flashing patterns.
Indiana Larry, RV7 "SunSeeker" 90+ hours flying and XPAK power supply.
"Please use the information and opinions I express with responsibility, and
at your own risk."
From: "richard titsworth" <rtitsworth(at)mindspring.com>
Sent: Tuesday, February 28, 2006 5:26 PM
> Alan,
> do
> drivers.
> are
> Rick Titsworth
> Detroit
> Adamson
> www.gs-air.com
> Alan
> Watson
> so
> FAA
> requirements?
> Thanks,
> Terry
> RV-8A
> Seattle
I don't have that model, I have a different generation version (actually
still made but only 2 channel). Those other ports are for diagnosis and
flash selection. The manufacturer is www.strobe.com
I got the entire kit from gs-air.com and it included "shielded" hookup wire.
If you want separate PS's all over the place, then the only game in town is
the certified aeroflash units. I'm not sure if they have a discounted
non-certified version or not.
Hope that helps.
Alan
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of richard
titsworth
Sent: Tuesday, February 28, 2006 6:27 PM
Alan,
drivers.
Rick Titsworth
Detroit
Adamson
www.gs-air.com
Alan
Watson
requirements?
Terry
RV-8A
Seattle
From: | "Michael Hinchcliff" <cfi(at)conwaycorp.net> |
Subject: | Re: KLN35A Pin/Installation Diagram |
Sent: Saturday, February 18, 2006 5:12 PM
Subject: Re: AeroElectric-List: KLN35A Pin/Installation Diagram
> 2.) How are the alphabetic rows on the connectors arranged
>> since they don't line up with their order from their numbered
>> counterparts? For example, on the P1, why are pins 22 and Z
> adjacent
>> instead of 22 and V? On the P4001, pins 15 and S are adjacent
> instead
>> of 15 and O? Make sense?
> Ah hah! I think I sense your confusion. Not all the letters are used
> since one might get similar looking letters confused with some
> numbers if the wires are labeled...i.e. 1 and i, etc.....
> Look at the letter codes in the list and find out which ones are not
> used. Makes it confusing but there is a reason....
> Jim Baker
> 580.788.2779
> '71 SV, 492TC
> Elmore City, OK
I resolved my KLN35A Pinout problem. I bought the product install manual on
eBay for $13 bucks and it answers all of my questions and then some. Jim,
as an FYI, the pin out diagram you sent me for data in/out pins are indeed
the same (K,H,J). Thank you again for your assistance!
Michael H.
Subject: | Ground Power circuit diagram query & suggestion |
Hi Bob,
I don't understand the need for a push-to-test lamp in your Low Cost
Ground Power circuit (rev C 07/21/05).
Surely it would provide a more useful function if it were a regular lamp
directly connected to ground, therefore providing either;
(a) a warning of presence of a ground power source, or;
(b) a warning that the switch/breaker for ground power contactor is
still closed (where the ground power contactor is held closed by ship's
battery). This function seems important since the contactor takes
nearly a Amp to maintain.
Either of those without having to press a button to find out. Since you
need some ground power-side volts to light it anyway, it will normally
be off AND "un-testable".
Better still, you could use a bi-colour LED, with GREEN for correct
polarity and RED for inverted (help save a contactor diode if you
reverse-connect the leads to the 4x4)
My 1st post & just getting my head round all the issues, so excuse me if
I missed something obvious. Looking forward to the book arriving
tomorrow.
Andy Grimshaw
grimmers1(at)ntlworld.com
Jodel DR200 group home-build (panel & electrics still on the drawing
board)
UK
The DAR didn't measure the light output. They very rarely have the
equipment to do so.
If it doesn't bother you to have less light than required by the
FAA, then use whatever position lights will pass muster with your local
DAR. Most folks want position lights that are at least as bright as the
FAA requires, not just bright enough for the DAR to sign them off.
Not so. If you design a light that meets the FAA requirements, you
need quite a few of the Luxeon LEDs. It turns out to be less expensive
to fill the FAA required light pattern with high-brightness 5 mm LEDs.
In lumens per dollar, you are better off with 5 mm LEDs.
You will notice that on the Luxeon spec sheets, they never tell you
the candlepower output. They won't tell you when you call up. You have
to buy one and measure it. They don't tell you because they don't want
you to be able to directly compare the output of their lights with other
LEDs.
The Luxeon LEDs are good if you require a very bright point source,
like for a projector. If it is OK to have the light spread out with more
than one LED, then 5 mm LEDs provide much more light per dollar.
My LED position lights put out more than what the FAA requires in
all directions, and they are less expensive than any other LED position
light on the market (some of which do not put out the light required by
the FAA.)
Bill Dube'
Subject: | Re: AeroElectric-List Digest: 15 Msgs - 02/26/06 |
Hi Gary, I never heard of that company, but it looks like they have a good
price on the oil filter adapter. The company I bought the engine from was
AERO, Inc. They sell all the ECI stuff, and the part no of the filter
adapter is AEL22772-1. AEL is the ECI parts number. I thiunk it lists for
$199, but call them at 800-362-3044. I don't think they have a web site.
Regards, Frank
Sent: Monday, February 27, 2006 2:55 AM
Subject: AeroElectric-List Digest: 15 Msgs - 02/26/06
> Online Versions of Today's List Digest Archive
> Today's complete AeroElectric-List Digest can also be found in either of
> the
> two Web Links listed below. The .html file includes the Digest formatted
> in HTML for viewing with a web browser and features Hyperlinked Indexes
> and Message Navigation. The .txt file includes the plain ASCII version
> of the AeroElectric-List Digest and can be viewed with a generic text
> editor
> such as Notepad or with a web browser.
> HTML Version:
> http://www.matronics.com/digest/aeroelectric-list/Digest.AeroElectric-List.2006-02-26.html
> Text Version:
> http://www.matronics.com/digest/aeroelectric-list/Digest.AeroElectric-List.2006-02-26.txt
> EMail Version of Today's List Digest Archive
> AeroElectric-List Digest Archive
> Total Messages Posted Sun 02/26/06: 15
> Today's Message Index:
> 1. 01:24 AM - Re: Temperature compensation, UMA CHT (Gilles Tatry)
> 2. 05:11 AM - Re: Re: Gotcha! (BobsV35B(at)aol.com)
> 3. 05:56 AM - Re: Baclup Battery monitor - Aux batt charge (Tim
> Olson)
> 4. 07:33 AM - Re: LED position lights + strobe (Eric Newton)
> 5. 09:27 AM - Re: Re: Gotcha! (Brian Lloyd)
> 6. 09:30 AM - Re: Electrical System Design for 2 Stroke Engines (Bill
> Czygan)
> 7. 11:36 AM - Re: Temperature compensation, UMA CHT (Robert L.
> Nuckolls, III)
> 8. 12:26 PM - Re: Temperature compensation, UMA CHT (Gilles Tatry)
> 9. 12:40 PM - Re: Strange alternator behavior at Startup (Mickey and
> Bob N.) ()
> 10. 01:03 PM - Mic and Headset Jack Installation (SMITHBKN(at)aol.com)
> 11. 02:05 PM - Re: Mic and Headset Jack Installation (SteinAir, Inc.)
> 12. 07:28 PM - Re: Temperature compensation, UMA CHT (Robert L.
> Nuckolls, III)
> 13. 07:28 PM - Re: Re: Strange alternator behavior at Startup (Mickey
> and Bob N.) (Robert L. Nuckolls, III)
> 14. 07:35 PM - Re: Mic and Headset Jack Installation (Robert L.
> Nuckolls, III)
> 15. 07:43 PM - Re: Re: Electrical System Design for 2 Stroke Engines
> ________________________________ Message 1
> From: "Gilles Tatry" <gilles.tatry(at)wanadoo.fr>
> Subject: Re: AeroElectric-List: Temperature compensation, UMA CHT
> You are absolutely right, Bob!
> Except that I am not concerned with cold, but hot weather flying, when an
> open cockpitt is delightful...
> It is the worst case for engine temp, and also the worst for CHT reading.
> With the cold junction at the back of the instrument, CHT can read about
> 20
> C less than reality. If the cold junction was in the engine compartment,
> reading might be somewhere in the middle of the scale, or lower, instead
> of
> close to, or even higher than the engine CHT limitation...
> Too late indeed to change the instrument, wich size is very specific: the
> panel is built and wired, I don't want to do it again.
> Moreover, I am highly interested indeed in this intellectual challenge,
> and
> learn a lot...
> Thank you for the help!
> Gilles
> From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
> Sent: Thursday, February 23, 2006 3:54 PM
>>>Ok, maybe I'm being dense here, but here goes:
>>>If the 594 is used, no further cold junction compensation is necessary
>>>from the TC side is necessary. If the UMA instrument needs it, then I
>>>suggest dropping it. Use a simple microprocessor (about $1) and an LED
>>>display ($40?) instead. Some of the micros have an LED display driver
>>>already built-in, IIRC. Check out Freescale's website.
>> I don't think the UMA bothers to use dynamic cold-junction
>> compensation. Their cold junction is at the back of the instrument
>> and the calibration is optimized at a 20C cockpit. So
>> ranges of temperatures that most pilots are willing to
>> endure in the cockpit is assumed to introduce insignificant
>> error.
>> Possibly true for most enclosed cockpit/pilot combinations.
>> This is an open cockpit a/c where the owner says his
>> motivations to fly outweigh other pilot's inhibitions
>> (maybe he has a heated flight-suit). In any case, the
>> stated accuracy of the stock gage is found deficient for
>> his needs.
>> The idea is to apply EXTERNAL signal conditioning using
>> the 594 and drive the instrument with whatever combination
>> of constant current/voltage seems best. This allows us
>> to provide offset/scale-factor pots that will permit
>> calibration to number probably better than the off-the-shelf
>> instrument. Dynamic cold-junction compensation comes with
>> the package.
>>>If he's married to the UMA, then enjoy the exercises 8-).
>> That's the major rub. He has the instruments, they're both
>> physically attractive for their size (tiny panel) and round
>> dials but a tad short on performance. Just ONE of life's
>> little challenges . . .
>> Bob . . .
> ________________________________ Message 2
> From: BobsV35B(at)aol.com
> Subject: Re: AeroElectric-List: Re: Gotcha!
> In a message dated 2/26/2006 12:36:01 A.M. Central Standard Time,
> gmcjetpilot(at)yahoo.com writes:
> So before you all point finger, if it can happen to a Pro crew, it can
> happen
> to you or me. First I can't believe an Apollo 820 GPS is legal for long
> range
> Oceanic flight. It would not meet the requirements to cross the Atlantic.
> Second the out of date data base blows me away. With that said they would
> have been better off using the old data base way points, even out of
> date. They could check the lat/longs against a chart or flight plane.
> Entering lat / longs much more error prone than entering a way point ID.
> Good Morning George,
> Don't get carried away with your indignation. There are many small, low
> cost, navigation devices that are approved for operation as sole source
> guidance
> for flight across the North Atlantic. Included among them are the Trimble
> 2000
> Approach and Approach Plus, Garmin GNC 300 XL and the Apollo NMC 2001.
> There
> are probably many more, but that is NOT an area of my expertise.
> Incidentally, I do agree with you that errors are easy to make. I was
> flying
> long haul when we first got rid of the live navigators (we had errors
> with
> them too!) and went to INS navigation. I realize that current practice
> among
> air carriers is much more regulated than it was in my day, but I never
> liked
> the 'two man' loading scheme. I always loaded my FMC's by having one of
> us
> load from the chart and the other from the flight plan. (We only used two
> FMC's
> on my airline) After we had independently loaded the data, we then cross
> checked the two units to assure that both had the same data loaded. No
> cross
> filling allowed in my cockpit.
> You would be amazed at how many errors we found in the early computer
> generated flight plans!
> Happy Skies,
> Old Bob
> AKA
> Bob Siegfried
> Ancient Aviator
> Stearman N3977A
> Brookeridge Air Park LL22
> Downers Grove, IL 60516
> 630 985-8503
> ________________________________ Message 3
> From: Tim Olson <Tim(at)MyRV10.com>
> Subject: Re: AeroElectric-List: Baclup Battery monitor - Aux batt charge
>>> The problem with diodes is they all have a forward volt drop, standard
>>> diodes are about 1 volt drop. So if your system charges at say 14.2
>>> volts, your second battery will only see 13.2V.
>> Which is a major issue for recharging the standby battery
>> to 100% of capacity.
>>> I believe the Shotkey (sp?) diode has a much lower drop...Althouigh I
>>> don't know what it is.
> I trimmed much of the thread for brevity on this single issue.
> I'm now flying in my RV-10 with a schematic as shown here:
> http://www.myrv10.com/N104CD/electrical/N104CD_Electrical_Schematic_Rev5.pdf
> By using a couple of different diodes, (one was Eric's schottky),
> I've now got a system with a couple of benefits:
> * charges the aux battery through a schottky with a lower Vdrop at all
> times.
> * Powers the E-Bus from the Avionics bus, whenever the avionics bus is
> on.
> * Powers the E-Bus directly from the aux battery when E-Bus is on.
> I use the E-Bus switch during startup to start the EFIS and EIS before
> I crank the engine, and I get no Voltage drops rebooting my E-Bus items.
> After engine start, I fire up the avioinics bus, and the rest of my
> stuff comes online. I then shut OFF my E-Bus feed switch and if you
> trace back the wiring, you'll see that I don't lose power during the
> switch because of the diodes, and, I get the benefit of a diode-free
> path from the alternator to the Aux battery. So, even though the
> charging circuit is there with the schottky, I'll get the benefit
> of getting 100% voltage to the aux battery for a full charge.
> The rest of the system works great for me too. Some breakers,
> some fuses. I do use a keyswitch with my Lightspeed and a Mag,
> which works great, but I couldn't illustrate the switching of the
> circuit using the keyswitch model, so I drew it as switches and it's
> innacurate.
> The Aux Alternator section is currently not installed. I'm waiting
> for Plane-Power to come out with their aux alternator to save a bunch
> of cost. It would be a nice thing to have, but actually with the
> large set of aux batteries and the wiring that I have, it's nearing
> overkill to add that to the system unless I plan not to land when
> I have a problem.
> Sorry to chop the thread. I've changed the subject line to accomodate.
> Tim
> Tim Olson - RV-10 N104CD - Flying
> ________________________________ Message 4
> From: "Eric Newton" <enewton57(at)cableone.net>
> Subject: Re: AeroElectric-List: LED position lights + strobe
> Could be this one:
> http://www.creativair.com/cva/product_info.php?cPath=3D21&products_id=3D44
> Eric
> ________________________________ Message 5
> From: Brian Lloyd <brian-yak(at)lloyd.com>
> gmcjetpilot(at)yahoo.com wrote:
>> This is the first problem. Before I went across the pond I had 2 weeks
>> of
>> ground school, of which many days spent on long range nav, simulator
>> training and at least one flight with a training Captain over
>> the Atlantic. This poor crew was set up to fail.
> Well, there is training and there is training. It is quite possible for
> the captain and crew to ensure their own training and to make a plan for
> how to deal with contingencies. It would make a lot of sense for the
> crew to think about their lack of training and then go get the
> information they needed. A lot has been written on the subject and the
> basics of navigation are well understood. That is what I did and I had
> no problems with long-range, over-water navigation. It is when you
> believe in your computers too much that you start to have problems.
>> happen
>> range
>> Oceanic flight.
> When making a ferry flight you can get away with a lot. I have flown my
> Comanche across the Atlantic twice, once non-stop. There are a lot of
> opportunities to screw up in 11 hours with nothing to look at but ocean.
> None of my equipment was "approved" for long-range ocean flight but it
> served me adequately well. My primary electronic nav was a LORAN which I
> knew would stop working when it got out of range of the Canadian chain
> and would remain unusable until I got within range of the North Atlantic
> chain.
> My HF was an old Collins KWM-2 that I had retuned to work in the
> aviation bands. The Canadian authorities laughed saying they hadn't seen
> someone use a KWM-2 for many years. I had designed an e-bus to ensure
> that I would have my electronic nav gear in case of a loss of the main
> electrical system. The Canadian DOT inspector at Moncton felt that my
> e-bus design was pretty neat and eliminated the need for a separate
> battery-operated LF DF radio.
> So my real primary nav was DR backed up with LORAN and using ADF and VOR
> for secondary backup. Everything worked as planned, including the loss
> of LORAN navigation about 5 hours into the flight. The only surprise is
> that we didn't get LORAN back until we were almost to Ireland. By then I
> had VOR. ADF surprised me by working from mid-Atlantic. (BBC used to
> have a very high-power LW station at 201 KHz if I recall. The
> programming wasn't great but the signal kept the ADF needle pointed
> where we were going.) Regardless, my DR planning got me to my
> destination within 30 seconds of flight-plan time.
> I kept a navigation log that cross-referenced DR and LORAN data. When
> the LORAN quit working we were on DR-only but had good intermediate nav
> data to start from. When I finally got my LORAN back we were only about
> 5 miles off-course. DR works a lot better than most people give it
> credit for.
> And, yes, I would do it again using the same equipment.
> ________________________________ Message 6
> From: Bill Czygan <bczygan(at)yahoo.com>
> Subject: AeroElectric-List: Re: Electrical System Design for 2 Stroke
> Engines
> Bob,
> Thank you for the kind welcome. Yes, I am new to this list and to
> aircraft
> construction. I am an Extra class Amateur Radio Operator (Ham), so I am
> supposed
> to know a few basic things about electricity. At my age (55), it is a race
> to see if the learning, or the forgetting, is winning. Thank you for
> taking the
> time to direct me to the right information. You, and the members, have put
> together
> a valuable resource here. It is obvious that I need to do some serious
> studying to come up to speed, enough to even pose useful questions. That I
> will
> do right now. Meanwhile, I have put together a BLOG to help UL pilots
> transition
> to Sport Pilot. One of the things I am doing is advising them on how to
> transition their UL aircraft. Many of them will need to create electrical
> systems,
> as I will. If you don't mind, I would like to provide a link to this list
> for them. My site is here:
> http://sptraining.blogspot.com/
> Again, thank you for the help.
> Yours,
> Bill Czygan
> AA8MF
> Quicksilver MXIIA
> ________________________________ Message 7
>>20
>>of
>>and
>>learn a lot...
> Have you the tools and where-with-all to get
> the measurements we need?
> Bob . . .
> ________________________________ Message 8
> I will probably be able to send you the measurements shortly, thanks to
> well-equipped friends.
> Sent: Sunday, February 26, 2006 8:30 PM
>>>20
>>>of
>>>and
>>>learn a lot...
>> Bob . . .
> ________________________________ Message 9
> From: <gmcjetpilot(at)yahoo.com>
> Subject: AeroElectric-List: Re: Strange alternator behavior at Startup
> (Mickey
> and Bob N.)
> Dear Bob N.:
> I have no Idea what you are talking about again and why its relavant,
> but God Bless you.
> COMMENTS BELOW (..............) ; Cheers George
> >Subject: Re: Strange alternator behavior at Startup (Mickey and
> Bob N.)
> >>Mickey wants to turn his car off at 100 mph and
> >> AND
> >> Bob N. wants proof.
> >Not proof sir . . . UNDERSTANDING. I see those words on the
> 4-color
> >brochures and bang-for-the-buck bullets at the top of data
> >sheets . . . all of which ASSUME that your understanding
> >of their words is the same as their understanding of
> >their words.
> (BOB,CALL TRANSPO, TALK TO ENGINEERS:1800-TRANSPO/800-872-6776)
> >> As far as control of I-VR alternators, it would be wonderful to
> use
> >> and trust the IGN wire. We could put a crow-bar on the CB to
> the
> >> IGN lead. However you can't depend on it (apparently from
> >> historical & empirical data). That's why a pullable CB on the
> B-
> >> lead, to positively isolate the alternator, independent of
> anything
> is
> >> suggested. Another way to achieve the same isolation is the
> crow
> >> bar and over voltage relay on the B-lead. That works also but
> its
> >> heavy, costly, complicated and potentially can cause nuisance
> >> trips. In defense of the crow-bar it is automatic. The pullable
> CB
> >> needs pilot action. The choice is the builders. As Bob N. says
> if
> >> you can't take the small chance of an OV, than use an External
> >> Regulator and OV module of some kind. if for no other reason
> >> it is simple. However there is no guarantee that will work
> 100%
> >> There's no 100% system.
> > . . . and nobody has ever claimed there was. For Part 25
> airplanes
> >we're chartered to do the fault trees with probabilities
> applied to
> >each branch. When just one of those numbers is assumed, the
> result
> >suffers from a garbage-in-garbage out syndrome. That's why I
> >have come to believe that they add little value in determining
> our
> >future field experience. I can show you dozens of carefully
> calculated
> >predictions of golden operations in fielded systems that don't
> >even come close. That's why failure tolerance is so much easier
> to
> >embrace that hoped-for failure proof.
> (BOB, I have an EXPERIMENTAL AIRCRAFT; Don't give a RIP about Part 25 or
> 23)
> >I'm working on an article that will illustrate the pitfalls of
> >accepting the bang-for-the-buck bullets -OR- the four-color
> >brochures at face value. Soon . . .
> (BOB, What? U lost me (again), call Transpo, they'll help your
> UNDERSTANDING)
> Bob . . .
> (George, I am done. Peace)
> ________________________________ Message 10
> From: SMITHBKN(at)aol.com
> Subject: AeroElectric-List: Mic and Headset Jack Installation
> Group,
> I've read the AeroElectric connection, searched the archives, etc. but
> can't
> develop an answer to the following question: when I went to install my
> jacks I
> found that I could either drill a ~3/8" hole that would allow the threaded
> post of the jack to pass through, or b) drill a slightly larger hole that
> would
> allow the threaded post PLUS the small shoulder to pass through.
> I purchased some of the isolation washers from B&C and they slip easily
> over
> the threaded post of the jack but won't go down over the shoulder at the
> base
> of the post.
> If I use the ~3/8" hole it appears the threaded portion of the jack could
> contact the panel as it passes through it, even with use of the isolation
> washers. So I guess I'm not sure what the isolation washers are doing.
> Need some help ......, Thanks,
> Jeff
> RV-7A
> smithbkn(at)aol.com
> ________________________________ Message 11
> From: "SteinAir, Inc." <stein(at)steinair.com>
> Subject: RE: AeroElectric-List: Mic and Headset Jack Installation
> If you have the higher end jacks, then the "shoulder" on the threaded part
> of the jack is still part of the center ring or threaded portion. The
> goal
> of the insulated washers is to completely isolate that part of the jack
> (center ring) from the metal panel and airframe ground... It's still a
> good
> idea to use the washers on the jacks, so drill the hold large enough to
> allow the insualting washers.
> Cheers,
> Stein.
>>[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of
>>SMITHBKN(at)aol.com
>>Sent: Sunday, February 26, 2006 3:02 PM
>>Group,
>>but can't
>>install my jacks I
>>hole that would
>>easily over
>>at the base
>>of the post.
>>Jeff
>>RV-7A
>>smithbkn(at)aol.com
> ________________________________ Message 12
> Great!
> Bob . . .
> ________________________________ Message 13
> From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Startup (Mickey and
> Bob N.)
> Subject: Re: AeroElectric-List: Re: Strange alternator behavior at
> Startup (Mickey
> and Bob N.)
> Startup (Mickey and Bob N.)
>>Dear Bob N.:
>> but God Bless you.
> Proof is for math problems and courts. Understanding is what real
> teachers
> offer. Engineers are dependent upon understanding for responsible
> conduct
> of their craft.
> If they have understanding to offer, the block diagrams, schematics,
> test results, etc are in order. That's what I offer and I expect no
> less. Every simple idea I've had to offer was explained at length,
> often illustrated and in many cases based on lessons-learned from
> the past 40 years of cooking (and burning a few fingers) in this
> particular kitchen.
>> to use
>> the
>> B-
>> anything is
>> crow
>> its
>> pullable CB
>> says if
>> External
>> 100%
>> airplanes
>> applied to
>> result
>> determining our
>> calculated
>> don't
>> easier to
>> or 23)
> I wasn't suggesting you should. It was an ILLUSTRATION of just how
> much we've come to depend on tools (and faith in the talent of
> others) that started out with high ideals but failed in the
> marketplace. All the analysis in the world does not replace
> the repeatable experiment.
> Unfortunately, there is so much faith in the up-front, computer
> aided analysis that we've totally divested ourselves of any kind
> of skunk works. At the same time, we're a bit dismayed that customer
> aircraft have become IR&D tools for fixing problems that analysis
> failed to reveal.
> You seem to think I'm trying to convince you of something . . . or
> sell
> you something. The only reason I offer you anything is as a courtesy
> from one engineer to another . . . but gee, without all the alphabet
> soup
> after my name, perhaps my biggest failing is knowing the right kind
> of
> words to use. I'm only trying to share my experience and
> observations
> based on that experience. The only folks who's approval I MUST have
> are those who send me money and expect a fair value in return.
> Everything
> else is the fun of considering simple-ideas . . . . and I DO enjoy
> it.
> I'm sorry if it's upsetting for you. I AM distressed that you don't
> seem to
> grasp what I'm driving at . . . a serious failing on my part as a
> teacher. Hmmmm . . . did you buy a copy of the 'Connection from me?
> Do
> you want your money back?
>> of
>> UNDERSTANDING)
> If that's what you did, then are you then a spokesperson for Transpo
> or have you developed an independent but supporting professional
> opinion you can share? Have you seen schematics, design
> philosophies,
> parts selection criteria? Would you/they share that with us? I get
> access
> to this stuff when I approve products for my boss, it's called
> preliminary
> and critical design reviews. But since you're going experimental, do
> you
> consider such tools superfluous, perhaps a waste of time? Is it no
> longer
> necessary that we understand how things work? Just field the pitch
> over the
> counter at OSH and plunk down the credit card? I may have to ask
> your
> forgiveness. I consider my OBAM aircraft customers just as deserving
> of the best-I-know-how-to-do as my TC aircraft customers.
> Tell you what. I'm about done with the trade study on the MC33092A.
> The task is see if there's some way we can adapt this marvelous
> piece of technology into a modern replacement for all the external
> regulators flying. Look over the data sheet and craft your own trade
> study. If it's at all suited, how can we adapt it to this task?
> Are there attractive alternatives? Are all the
> at the front of the data supported by explanation from within and
> and at least supported if not confirmed by your independent
> analysis?
> How do the features cited add value? Are any of the features nothing
> more than chrome on the bumpers and fox tails on the antennas?
> I've discovered some interesting points of design in the MC33022A
> that offer interesting hypothesis on behaviors of failed alternators
> cited recently on the List. It's been an enlightening exercise. When
> yours
> is done, send me a .pdf and I'll put it up on AeroElectric.com along
> with my own.
> You've tossed in tons of cabbages and tomatoes which I've attempted
> to field with thoughtful, illustrative answers. May I suggest this
> friendly competition. Let the List vote on the work product. Looser
> sends the winner a copy of his favorite book.
> If you 'dust' me, I'll be pleased to send you a copy of
> "The Professional Amateur" by T.A. Boyd. It's a biography of
> Charles F. Kettering - a scientist worthy of much respect and
> emulation . . . one of my personal heros.
> Bob . . .
> ________________________________ Message 14
> Subject: Re: AeroElectric-List: Mic and Headset Jack Installation
>>Group,
>>can't
>>jacks I
>>would
>>over
>>base
>>of the post.
> That isn't what they're supposed to do.
> Drill a 1/2" hole. Put the extruded washer on the jack first, extrusion
> facing up. Insert jack in hole from behind and place flat insulating
> washer on over the jack's barrel followed by the flat metal washer and
> finally the screw.
> The insulating washers will sandwich the panel material while the
> extrusion keeps the jack centered in the hole and isolated from
> the panel.
> Bob . . .
> ________________________________ Message 15
> From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Stroke Engines
> Subject: Re: AeroElectric-List: Re: Electrical System Design for 2
> Stroke Engines
> Stroke Engines
>>Bob,
>> aircraft construction. I am an Extra class Amateur Radio Operator (Ham),
>> so I am supposed to know a few basic things about electricity. At my age
>> (55), it is a race to see if the learning, or the forgetting, is winning.
>> Thank you for taking the time to direct me to the right information. You,
>> and the members, have put together a valuable resource here. It is
>> obvious that I need to do some serious studying to come up to speed,
>> enough to even pose useful questions. That I will do right now.
>> Meanwhile, I have put together a BLOG to help UL pilots transition to
>> systems, as I will. If you don't mind, I would like to provide a link to
>> this list for them. My site is here:
> You're correct . . . no EASY way to do it. The Vulcan mind-meld
> is not yet in anyone's bag of tricks. I got my novice ticket in
> spring of '56 in the 7th grade. Did a science class demo that failed
> miserably. Dropped a wire out the second story window for an antenna.
> My demo partner a few miles away heard me fine but noise from florescent
> lights wilted my SX-28 like a pansy in the Mojave sun.
> The website is an impressive effort. I wish you the best of luck
> helping this new effort get spooled up. The world can always use
> more pilots.
> Bob . . .
the FAA.)
Bill Dube'
Bill,
Can will you point me to your web site?
Peter
In a message dated 2/28/2006 8:02:43 P.M. Central Standard Time,
mstewart(at)iss.net writes:
So it would seem that it needs that initial rpm to get the juices
flowing in the cold.
I can live with that.
Thanks to whom ever it was that suggested an initial burst of RPM to get
her going. Worked
Best,
Good Evening Mike,
Do you really want to give it that short burst of power?
Personally, I like to warm up the engine at as low an RPM as possible
consistent with adequate oil pressure and any need for the crankshaft to throw
the
oil against the innards of the engine. I do not know what engine you have,
but I would not give it a burst above any RPM that I wanted to use for warm up
purposes.
Isn't that the whole idea behind doing a warm up?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
From: | "Lloyd, Daniel R." <LloydDR(at)wernerco.com> |
On their website all of the new version III's and V's all have spec
sheets with Lumen ratings and the appropriate charts to determine
viewing angles, and with more than 80% intensity over 140 degree
spectrum, it would be very easy to get the required fill rate of light
that the FAA requires, and with shaped reflectors, you can even cut off
the angles. Using fog lights from walmart($15) and replacing the halogen
bulbs with 4 Luxeons ($30), plus the power supply ($25) easily meets and
exceeds the requirements for much less money than you would think.
Just my .02
Dan
RV10
Dube
Sent: Tuesday, February 28, 2006 8:42 PM
Subject: Re: AeroElectric-List: Re: Mike's LED Position lights
on
equipment to do so.
meet
LEDs.
the FAA.)
Bill Dube'
From: | "Mitchell Goodrich" <mgoodrich(at)tampabay.rr.com> |
Hello All,
I am installing a back-up battery an would like to monitor
the condition (voltage) w/warning for it. Any ideas on
what to use???
Mitchell Goodrich
VEZE Tampa
From: | "Bill Schlatterer" <billschlatterer(at)sbcglobal.net> |
If using the Grand Rapids EFIS system, it monitors voltage on each of up to
three separate power sources. Other EFIS systems probably handle several as
well.
Bill S
7a wiring
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mitchell
Goodrich
Sent: Tuesday, February 28, 2006 10:19 PM
Subject: AeroElectric-List: Back-Up Battery
Hello All,
I am installing a back-up battery an would like to monitor the condition
(voltage) w/warning for it. Any ideas on what to use???
Mitchell Goodrich
VEZE Tampa
Subject: | RE: An Architecture Question - Z13 |
> What caused you to believe that a 60/20 combination of engine
> driven power sources was the most useful/practical? What operational
> consideration raises questions in the ability of one of the Z-figures
> to handle as presently configured?
Can't speak for Todd, but my thought pattern which arrived at a point
similar to his was:
I know that my alternator can't quite keep up with everything on while
taxing at relatively low RPM. A little extra help would be nice. I'd also
like to give the standby a little exercise as a way to ensure it's running.
If it's always in standby it would be easy for it to fail and not be noticed
-- until it was needed.
The Dynon product has an option of a built-in battery backup. It was an option
that I felt was unneeded since I was using Bob's e-bus wiring. I realize now
that I would like to have a separate battery for this purpose. I'd be interested
in knowing if anyone has installed this function using a small external battery.
A wiring diagram would be nice.
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Startup |
>her going. Worked
>Best,
>Mike
>Do not archive
>Good Evening Mike,
>throw the
>warm up
>purposes.
Absolutely. The behavior noted is NOT what we would
generally consider acceptable . . . the "work around"
described is functional but it's almost a certainty
that this alternator is either deprived of some accommodation
that allows it to come up normally at ramp idle -OR-
has a design feature that makes it a poor choice for
use on aircraft.
Subject: | Re: Back-Up Battery |
>Hello All,
>what to use???
It would help us to know how you intend to install
it. Like figure Z-30? There's a product about to be
added to our bag of tricks. You can see the data
package at:
http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf
It's a two channel low voltage, single channel latching
high voltage management module. Designed specifically
for generator installations on older airplanes, it's
still applicable to a variety of modern applications.
One might consider this device for any or all of its
functional features. It will cost about the same
as the current LVWarn/ABMM module . .
http://www.aeroelectric.com/Catalog/AEC/9005/9005-701B.pdf
but with 3x the functionality. So if you need only
one channel of LV warning (to watch your aux battery
circuit), you could certainly consider it. If you also
found uses for the remaining features, that's icing
on the cake.
Alternatively, you could craft your own LV warning
module by taking advantage of the ready-to-stuff
etched circuit board and fabrication package
offered at:
http://aeroelectric.com/articles/lvwarn/LVWarn-ABMM.html
and . .
http://aeroelectric.com/articles/lvwarn/9021-620.pdf
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> suggestion |
Subject: | Re: Ground Power circuit diagram query & suggestion |
>Hi Bob,
>tomorrow.
Certainly there are variations on the theme that provide
alternative flavors of functionality. The architecture cited
was crafted based on a customer's request for a hurry up
kit for a ground power jack, my experience with ground
power on aircraft and what was in my inventory of components
at the time.
You can certainly modify as you see fit. The important thing
is that you UNDERSTAND how the end product is going to work
and that features and performance are acceptable to you
as the systems designer and user.
Subject: | Re: RE: An Architecture Question - Z13 |
>similar to his was:
A bigger alternator doesn't automatically translate into
more snort at low rpm. If your modern, light weight
alternator is installed like B&C's with the stock 2.5" pulley
then you should be able to get nearly full output at taxi
RPMs.
Alternator sizing should be a function of your load analysis
for various cruising flight conditions. A 60/20 combo is
REALLY big, expensive and heavy comparted to 40/8. I'm not
suggesting you'll never need such capability, only that I'm
skeptical of most builder's plans to install this system without
also having evaluated system requirements in detail.
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> at Startup |
> >> Oh.
> >> dead?
Just yanking your chain my friend. We do know that SOME alternators
under SOME conditions will come up self excited and that this feature
is incidental to the system design requirements. After some thought about
this thread, I'm almost convinced that there's something amiss with
the system cited. It should snap to attention within seconds of
startup and at ordinary idle/taxi RPM levels.
> > contemplate.
Good data point. Since I've never attempted to utilize
this capability in a design, I've never explored the
feature in practice.
It stands to reason that since the retentivity of ANY magnetic
material is never zero, that the ability to self-excite probably
exists at SOME RPM even if scary to contemplate. It stands to
reason that many examples in the wild will exhibit the behavior
at fairly ordinary RPM levels.
From: | Mickey Coggins <mick-matronics(at)rv8.ch> |
Subject: | dampening circuit request |
Hi gurus of electrons,
As I mentioned in another thread, I want to have
a sensor that tells me when my coolant level is
too low.
I've ordered a Gems Sensors ELS-900, 12 VDC, Dry,
1/4" NPT, $54, part number 205300:
http://www.gemssensors.com/SpecTemplateStandard.asp?nProductGroupID=307
which is basically an optical on/off switch when it
goes from wet to dry. When the coolant is sloshing
around in the tank I suspect that my warning lamp
will be flickering on and off. Does anyone know of a
very simple way I could "dampen" this so that the
warning light will only come on if the sensor goes
dry for some period of time?
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Sorry. I tend to err on the literal side. ;-)
> feature
> thought about
> with
My experience with a LOT of alternators at this point is that they
need some RPM substantially higher than idle to self-excite. That is
why they use a small amount of current from the battery bus to
bootstrap them.
>> characteristic.
>> into
And I have messed with enough of them to believe
this is a common behavior.
>> brand new,
Right.
Antoine de Saint-Exupry
Subject: | Re: dampening circuit request |
>too low.
Sure . . .
First, a long time-delay (resistor/capacitor)
is the simplest but its an integrator of amplitude
with time. It prevents a jittering light but will
not insure that it never flashes at or during
operation at the level transition.
Given your particular application, you're not really
interested in minute/by/minute interpretation of a
level in the tank . . . like for a consumable (fuel).
If the level is so low that the light comes on even
once, then and investigation and remedy is called for.
What may work best for you is a latching circuit.
A small relay with holding contacts rigged so that
once actuated, the light stays on until reset (momentary
power down).
The 9011 module I've cited in other posts will be
re-incarnated as a low fuel warning for tanks with
floats. The presence of a microcontroller allows us
to craft warning protocols where the light doesn't
come on until the float voltage is at or below the
trip point for say 50% or more of the last 30 seconds.
After that, the light stays on until the voltage is
above the trip point for say 100% of the last two
minutes.
This would offer slosh filtering and precise, no
hesitation operation of the warning lights.
As you might guess, the options and approaches
to solution are great in number. What is your vision
of the elegant solution?
Gladly!
http://www.killacycle.com/Lights.htm
>the FAA.)
> Bill Dube'
>Bill,
>Peter
> Just my .02
>Dan
>RV10
The FAA requires specific candlepower in specific directions. (It
only makes sense to do so.)
Lumens don't give you candlepower directly. You can't calculate the
candlepower with the information they provide. Once you buy one, and
measure the candlepower, you realize that you can produce that same
candlepower using several, much less expensive, 5 mm LEDs.
Bill Dube'
From: | "Gilles Tatry" <gilles.tatry(at)wanadoo.fr> |
Subject: | Temperature compensation, UMA CHT |
Hi Bob,
Please find hereafter Jean-Pierre's analysis of my CHT compensation issue.
He got the instrument, did some bench testing, and proposes an interface
architecture as follows.
Any comment?
Gilles
----- Original Message -----
From: "CASTIELLO, Jean-pierre" <jean-pierre.castiello(at)airbus.com>
Sent: Wednesday, March 01, 2006 3:56 PM
Subject: AeroElectric-List: Temperature compensation, UMA CHT
Gilles,
here are some pictures of the CHT instrument.
There are 3 boards:
- input wiring, overvoltage protection(I guess );
- signal conditionning;
- air core indicator amplifier, that has 4 wires: 2 power (red and black),
and 2 signal (white and blue).
The idea is to design an interface to be input to the air core amplifier,
with minimum modifications to the unit, so that back is always possible ( a
bird in hand is worth ten in the bush ...).
I did some measurements on the unit in order to find the gain and offset
that the new interface should have.
I found the signal on the white wire on the air core amplifier (blue one is
still unknown to me, unless I do some reverse engineering on the signal
conditionning board, )
Measured voltage at this point:
for a 50C display -> 2.27V
150C -> 3.615V
280C -> 5.425VC
So this is an offset of 1.6V and a gain of 13.5mV / C
I do not know about the input voltage right at the connector because I was
not in a type J TC configuration and the corresponding voltage was
meaningless.
The complete excel file is available. Anyway the display seems to be linear
and an AD594 amplifier followed by some op-amp to compensate for gain and
offset should do.
Jean-Pierre
Bob, Thanks for your suggestions.
I'm not sure I understand what you've written here.
If I have 300cc in my 500cc tank, and I set
the sensor at about the 100cc level, then
a bit of sloshing should not cause the light
to flicker. However, if the level gets to
about 150cc or below, I might see flickering.
Is that what you are saying?
Exactly.
> power down).
This would be fine as long as I can be reasonably sure
it is not a false alarm.
> minutes.
That sounds perfect!
What you describe above sounds great, in terms of
function. I have no idea what kind of packaging
would be required for the microprocessor, but
obviously the smaller the better!
Perhaps if the 9011 solution is a ways down the road,
you could tell me how to hook up the previously mentioned
simple solution with the resister/capacitor. No hurry
on this - I've got the wires run and I can add
in the necessary bits and pieces later.
Many thanks,
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey,
A low-tech way to accomplish this would be to use an anti-slosh baffle
inside the tank to dampen out the waves. Admittedly, this solution
isn't as exciting.
Mark Steitle
-----Original Message-----
Mickey Coggins
Sent: Wednesday, March 01, 2006 2:11 PM
Subject: Re: AeroElectric-List: dampening circuit request
Exactly.
> power down).
> minutes.
Many thanks,
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> |
Yes . . . or even 110cc or 120cc etc. The closer
you get to the "calibrated" switch point, the more
likely you are to get periodic false lights. However,
if you see ANY light for even a transient condition
at say 150cc (1/2 normal) then there has been an
observable loss of liquid. It seems immaterial whether
the real average level = 100cc calibrated or 150cc
and produces transient trips. In this case, the latching
circuit is easy to implement and does the job.
>Exactly.
> > power down).
> > minutes.
The 9011 exists right now. See:
This could be re-programmed and offered with a variety
of capabilities controlled by software. The package
shown is going to house perhaps a dozen new products on
the drawing board.
I think I actually like the 'flicker' effect associated with being right
on the edge of min capacity. If the volume in the tank is dropping
slowly, then the flickering will start very intermittently, gradually grow
more frequent, then finally the light will stay on continuously. If,
however, the level is dropping rapidly (developed serious leak), then the
light will go from always off to always on very quickly - indicating that
landing as soon as possible is the best bet.
Procedurally, check the level in the system prior to starting the engine
and make the go-no-go level significantly higher than the sensor level.
Then, if the light turns on while on a flight of normal length, you _know_
you have a leak.
Matt-
>>Exactly.
>> > power down).
>> > minutes.
Subject: | Re: Strange alternator behavior at Startup (BobN) |
>>From: "Robert L. Nuckolls, III" nuckollsr(at)cox.net
>>Subject: Re: Strange alternator behavior at Startup (BobN)
>satisfied.
>>expect no less.
> Just call them Bob. What's the big deal?
>>and hangers world over is with out dispute. Even if I don't agree
>>with you, that does not mean I don't understand your point or
>>accomplishments are based. In one breath you extol the
>>and simple-ideas.
**Bob we have fundamental and philosophical differences. You want to
know the esoteric. I on the other hand want to understand how to install
and operate internally regulated ND alternator by looking at real world
operational issues, we all can learn from. When I say WE, I mean I-VR
alternator users. This is not a debate about I-VR Vs. E-VR, engineers or
spec sheets.
**Only you know what you want to know. A true scientist is unbiased.
You are a smart guy; go figure it out. Get an aftermarket ND I-VR; They
can cost $15-$25. Buy one and test it. Better yet go to the auto store and
buy lester 14684 (aka Vans Alt). Test it. You seem to ask questions for
questions sake. If you read what I have written, than you know how I
recommend to install and use an I-VR. If you want to verify spec sheets,
knock yourself out. DO IT, but stop talking about it.
**You always talk about testing, but you rarely do what you say you
are going to do. I can't count how many times you said, I am going to test
such and such, but your test data never materializes? Just do the research
yourself and stop asking me. OK, thanks. :-) We are all counting on U.
**Some how to make a point, you ask questions that people can not or
need not really answer (to your liking). It's a waste of time. USE DATA
WE HAVE. Trust it or don't trust it, that's your business. The rest of us
want to go fly and learn from other users of alternators with I-VR's.
**The data you want, IF YOU REALLY WANT IT, is out there. I think you
are just blowing smoke Bob. A true scientist or engineer does not need to
be spoon fed info but goes out and gets it. Go get it Bob.
**Agreed, you are smart, spec sheets can be wrong. So?
**Let me tell you where WE, us homebuilders are coming from. WE
want to fly, be safe and have fun. We want a good, inexpensive, reliable,
easily installed alternator that can be replaced anywh The 9011 exists right now.
See:
> the drawing board.
> Bob . . .
ere in the country
cheaply with a visit to a local AUTOPART store. Not a custom, esoteric
single source supplier specialty item (B&C). I LOVE that you want to know
the nitty-gritty of a spec sheet verses the real world. GREAT! U-Da-Man! **
**Go get'em Bob. My apathy is not born of ignorance but practicality.
Practically speaking it has worked in my plane and others for 10,000's of
hours with no problem. It has also worked in MILLION'S of cars trucks
and industrial equipment all over the works for over two decades. Test all
you want. I don't need to test a wheel to see if it will roll. I do want to learn
what the best tire pressure is so I can put fill it properly for best service.**
****I understand there are unknowns of the I-VR, but those unknowns are
falling fast as WE, I-VR users talk and compare notes. Understanding the
advantages of the I-VR as well as the limitations is critical. OK. In the
past much IGNORANCE was stated as fact on this list, most if it negative
and faults. This is so anti-scientific I could puke. I am not saying the I-
VR is perfect, the greatest thing since sliced bread BUT lets get real.
THERE ARE REAL ADVANTAGES INSIDE THE I-VR AND IN USING
THEM. The whole industry of small alternators has gone to I-VR.*****
**Lets, understand the real characteristics of the I-VR for airplane
operations, instead of lies & exaggerated OV tales. Understanding the
different ways they might fail and the symptoms prior to failure is what we
NEED. Details about a schematic or how engineers don't know what they
are doing is NOT important, except to you Mr. Bob N. You have a
crusade that you campaign. You also are VERY biased. It gets in the way
of being the teacher, engineer and scientist you fancy yourself as. I still
like you Bob, but you really have PO'ed a few people with this attitude
that WE need to prove things to YOU. Take it or leave it, but leave it alone
if you do not want to pursue it. Prove that is NOT that way. Sue me.
**That is not what WE want. I am sorry. I can't give you the knowledge
you seek oh wise one, this is a journey you must walk alone Sparky.
**This is not a big deal; Its an alternator. NO BIGGIE. There are millions
and millions of these ND alternators all over the world working famously.
They can't be all bad. They DO IN FACT HAVE control and logic
functions. I guess if you want to know the info, it's there. Asking me a
billion times will not change the fact I-VR have some real advantage over
E-VR's. Sorry Bob, Sorry B&C.
>>Real engineering (and teaching) can be accomplished only when
>>the activities are supported by an understanding and artful
>>assemblage of simple-ideas. If you choose to drive your career
>>and tutelage based on telephone conversations and faithful
>>acceptance of bang-for-the-buck-bullets on data sheets, it's
>>your choice - but not mine. What you have accepted and now
>>promote as FACT has yet to be demonstrated.
>>I'll publish the MC33092 trade study to show others on the list
>>how the most successful engineering is conducted. By the way,
>>"work product" is anything which you have created. The trade
>>study will be my work product based on the products of others
>>offered as a potential guide for the future efforts of still
>>more folks. That's what engineers do George . . . make sure
>>all the bits and pieces fit smoothly into the whole.
>>Bob . . .
**Bob N: Sorry, all I got from your above is blaaa blaaa, real engineer,
blaaa, blaaa blaaa, bang-for-the-buck-bullets, blaaa, blaaa , career and
tutelage, blaaa, blaaa blaaa. Whisky Tango Foxtrot! Focus, focus focus
Bob! Stick to the topic, for once.
** I know you are trying to tell me how important this is to you. I BELIEVE
YOU. However my apathy is not for lack of intelligence, education or ability.
Its that I don't care as an end user. Why? Because I have over 1000 hour
of reliable trouble free I-VR experience and my plane is wired so if it does
fail, the chance of causing harm to me or the airframe is S000OOOooo
remote, I can accept it (without a crow bar) using a CB, manually opened.
**With more operational experience of others WE have improved OUR
installation and OUR operational philosophy. My rule is essentially wire
and operate the alternator as if it where in the vehicle it was designed for.
I have some additional recommendations, below as a PS.
**Here are the top of the line CB's for the B-lead disconnect:
http://www.ti.com/snc/products/controls/acb-6752-12.htm
http://www.ti.com/snc/products/controls/acb-6752-1xx.htm
**If you want to look over Nippondenso or Motorola's REAL engineers
who designed the thing in the first place, go for it. I CAN'T tell you how
they design and make an IC chip, like an Intel Pentium chip, but I know
how to write an e-mail and call them and ask how it works. I know the
general theory of semiconductors and silicon wafers, but I don't need to
know everything about every IC to use a computer or alternator. I think
the engineers at these companies know a thing or two about testing Bob.
**I will concede and leave the REAL engineering to you. Good luck. I
suggest you pick up the phone and start to ask people who manufacture
the stuff. They may be able to guide you in a direction that will further
your knowledge. IF YOU DON'T TRY YOU WILL LEARN NOTHING.
**If you have any questions on how the I-VR work and not all the blaaa
blaaa, just ask me Mr. Bob N. I'll try to help you like I help anyone who
has a genuine I-VR question or concern. Again THIS IS NOT about can you,
should you, pros and cons or the I-VR verses E-VR. This is just for
people who USE the gosh darn I-VR. Once YOU understand WE ARE
GOING TO USE IT NO MATTER WHAT YOU SAY, than it'll get
easier for you Bob. Help or get out of the way Sir.
**Bob, please stop asking irrelevant questions for 99.9% of us, the users
of I-VR. We don't want stories or guesses either. The more we talk about
installation issues and REAL operational characteristics the better we will
understand how they work. Does B&C publish the internal design for
YOUR voltage regulator by the way? If so I want a copy. Single point failure?
**As far as COLD temp characteristics, THIS IS INTERESTING. This is
a real world field TEST. I never operated in these temps. So the point,
is this a NORMAL operating characteristics?; Next time anyone fly's
in fringed weather, sees a delay in charge or no charge until a specific
RPM, we know what's going on, good or bad. THAT IS IMPORTANT
and PRACTICAL. Bob, you have to think like a PILOT more on
operational issues, than just the esoterica of an electrical system.
**All the other personal stuff and REAL engineer comments are pointless,
Sparky. :-) I respect your position, I just think it adds no real value unless
you are going to get the first certified I-VR. Being experimental DON'T CARE.
**Take Care George (you owe me a book btw)
**PS some of my personal rules for installing and using a I-VR
alternator: Besides wiring and using the alternator as if it where installed
in the vehicle it was designed for, I recommend cooling air on the VR, no
continuous duty over 75% and pullable CB on panel for B-lead. Also
check or replace brushes every 200 to 500 hours. (I think they cost $1.95
each.) Be sure to use the warning light and remote voltage sense IF IT
HAS ONE. NOT ALL ND alternators have remote sense. Vans 14684
does NOT have remote volt sense. Also don't screw with turning the
alternator ON/OFF while its turning under load. WHY? Because every
guy I know of that does this seems to have problems and it DOES NOT
work that way in a Toyota or Geo Metro. THIS IS NOT ROCKET
SCEINCE. Last and I know this makes Bob mad, don't put an OV relay
and crow-bar unless you are darn sure it will not trip unnecessarily. Since
nuisance trips are hard to guarantee against, I would not do it at all, but
that is an individual choice. ALL manuals for ND alternator installation
say DO NOT operate the alternator with out the battery connected to the
battery. (sorry Paul). An OV relay does just that and can damage the
alternator. Its fine if you actually have an OV, but the chance of a OV that
you can't fix by manual opening of the CB is REAL slim, if you follow basics.
I'm new to this list, but... the tone of the message below is, IMHO,
appalling. Surely this list is not the place for such hyperbolic
personal attacks. May I also respectfully suggest, gmcpilot, you are a
little presumptuous to claim to speak for "WE builders". You don't speak
for me.
Please lighten up, and keep to technical discussion, without all the
personal invective. That's why most of us subscribe. Thanks.
Ron
>>AeroElectric-List message posted by:
>>Bob, most of what you wrote has nothing to do with the topic?
>>It is not a debate of IF you should use a I-VR alternator, but I will
>>try to address you question, fully knowing you will never be
>>satisfied.
>>>schematics, test results, etc are in order. That's what I offer and I
>>>expect no less.
> >>Bob you provide a wealth of knowledge and experience. I think
>>>we all can say is of immense help and enjoyment to us amateur
>>>airplane electricians. Your help to airplane builders in garages
>>>disrespect your accomplishments.
> >>You can't have it both ways George. If my experience and
>>>accomplishments have value, then there must be some useful
>>>application of tools and philosophies upon which those
>>>virtues of those accomplishments, and in the next you brush
>>>my opinion aside because it does not agree with the one you
>>>formed by calling folks on the phone. I talk to lots of people
>>>and I read lots of data sheets but these are STARTING places . . .
>>>I asked you to help explain the inner workings of an exemplar
>>>regulator with a goal of seeing if advertising hype (and the opinions
>>>of those you talked to on the phone) have foundation in physics
>>>and simple-ideas.
> spec sheets.
>>>After sorting out the sand in data sheets, it's a good idea
>>>to hit lab and RUN the thing. It's not common but I've discovered
>>>things about people's products that they had no understanding
>>>of (and we didn't either until after a few $hundred thousands$
>>>went down the tubes in warranty work).
> easily installed alternator that can be replaced anywhere in the country
>>>Bob . . .
Ron,
This tirade is typical of jmcjetpilot and has been going on for some
time. I don't know where Bob gets the patience. I love good,
productive banter and disagreement. I've been hoping for a new tone
from this poster for too long. I'm not even involved in the
discussion and I've finally had enough and have come to the
conclusion that a new mail filter is going into my mail client that
transfers mail from this poster directly to the trash. It's just not
worth the time.
> speak
> for me.
> Ron
Best Regards,
Steve
Steve,
Understood, and agreed. Nothing wrong with robust debate, and I too
favor erring on the side of openness and inclusion of wide-ranging
expression. But as you say, simple common courtesy requires _some_
limits. No doubt, we would all do well to review the policies Matronics
provides for congenial usage of these fine lists, which do address
appropriate online behavior.
We now return to our regularly scheduled programming -- all about them
@$%&@# LED's, alternators, and crowbar thingys! ;-)
Ron
Steve Thomas wrote:
> Ron,
> worth the time.
>>speak
>>for me.
>>Ron
Subject: | FAA Lighting requirements link |
You guys probably already have a copy of the FAA requirements for
lighting distribution. But for those that don't, here's a link:
http://home.comcast.net/~czy/Anticollision_lights.pdf
Bill Czygan
From: | Earl_Schroeder <Earl_Schroeder(at)juno.com> |
Subject: | Bob Hoover Air Show] |
Fasten your seat belts people.
*WOW...quite a performance by the famous pilot Bob Hoover. *
*Click here: *http://youtube.com/watch?v=vQpVI_aldB0&search=aircraft
<http://youtube.com/watch?v=vQpVI_aldB0&search=aircraft>
*A*
Subject: | Re: FAA Lighting requirements link |
Here are the relevant sections of the FAR:
http://www.flightsimaviation.com/data/FARS/part_23-1385.html
http://www.flightsimaviation.com/data/FARS/part_23-1387.html
http://www.flightsimaviation.com/data/FARS/part_23-1389.html
http://www.flightsimaviation.com/data/FARS/part_23-1391.html
http://www.flightsimaviation.com/data/FARS/part_23-1393.html
http://www.flightsimaviation.com/data/FARS/part_23-1395.html
http://www.flightsimaviation.com/data/FARS/part_23-1397.html
For anti-collision lights
http://www.flightsimaviation.com/data/FARS/part_23-1401.html
LED position lights (especially the tail light) can have a tough time
meeting 23.1391 though 23.1395. You have to fill the complete pattern
with at least the candlepower specified. Many folks just stick some LEDs
on the wingtips and figure it "looks good" without ever actually
measuring the light output at all angles.
I used a computer model to design my lights so they would give
proper coverage with the optimum number of LEDs. It was not at all a
simple task.
Bill Dube'
> Bill Czygan
Subject: | Seminar in Bloomington, IL |
We've finalized an agreement to do a weekend seminar in EAA
Chapter 129's hangar on the 4/5th of November in Bloomington,
Illinois. Details at:
http://aeroelectric.com/seminars/Bloomington.html
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
From: | "Fox5flyer" <morid(at)northland.lib.mi.us> |
Subject: | Dampening circuit request |
Subject: AeroElectric-List: dampening circuit request
too low.
http://www.gemssensors.com/SpecTemplateStandard.asp?nProductGroupID=3D307
Mickey
Not trying to dampen anything here Mickey, but why are you trying to fix a problem
that you don't even know that you have? Seems to me it would be best to just
fly the airplane and if it appears that a fix is needed then deal with it
as necessary.
Deke
Subject: | Re: Dampening circuit request |
> > fix a problem that you don't even know that you have? Seems to me it
> > would be best to just fly the airplane and if it appears that a fix
> > is needed then deal with it as necessary.
>Hi Deke,
>Not a bad idea. I was hoping that the response to my
>question would be something along the lines of
>"Heck, everyone knows you slap a 99 cent flux capacitor
>between the alpha and the gamma leads of your sensor,
>and that dampens it for ya."
>I'm pedaling as fast as I can on this electronics stuff!
>Mickey Coggins
>http://www.rv8.ch/
>#82007 finishing
Deke's point is well taken. I'm not convinced that
any auxiliary circuitry beyond perhaps the latching
relay is called for. With low fuel warnings (a commodity
that is used up EVERY flight) monitored by floats driving
analog gages, the gages are often lubricated with
50,000 centistoke silicon oil. The gage is fully free to
move on lubricated pivots but is damped to the extreme by
the very viscous oil. This is why most folks are unaware
of how variable the signal is coming in from the potentiometer
on the float . . . If you're in very rough air, the voltage
could be very hard to interpret without dampening systems
of some type.
In the case of your coolant warning, it's a small tank.
You're also monitoring a fluid level that is expected to
be fixed well above the warning point for all phases
of all flights. The fact that you get any warning
(flickering or not) is like the low voltage, low vacuum,
low oil pressure, etc lights coming on. At this point,
filtering or dampening for the purpose of having an orderly
behavior of lights on the panel is a secondary concern.
It's an event that should not be happening and demands
attention.
My sense is that the photo/optical sensor you've ordered
will work just fine. Go ahead and stick it through the
tank wall as planned. I doubt that you're going to
discover some operational quirks that demand extraordinary
signal conditioning.
Hi Mickey
Deke has echoed my thoughts.
I'm enjoying following this thread but having spent a couple of years
converting a Subaru and obsessing too much over various issues, this one
really doesn't sound like it is worth worrying about. I'd also just put
the sensor somewhere in the bottom third of the tank and fly it. The
liquid level will rise as the coolant heats up of course. Each to his
own but I'm finding that my simplest solutions are turning out to be the
best and have the least complications. I used a 0 to 28 psi pressure
sensor with an EIS 4000 and initial ground running looks like it is
going to work very well for a coolant loss monitor for me. It seems to
largely track the coolant temperature so far. I did use a
semi-transparent plastic reservoir from a Volvo so that the preflight
level can be checked so that might be why I'm less concerned about
monitoring the exact level.
Ken
Fox5flyer wrote:
>From: Mickey Coggins <mick-matronics(at)rv8.ch>
>too low.
>Thanks,
>Mickey
just fly the airplane and if it appears that a fix is needed then deal with it
as necessary.
>Deke
AMEN,
Harold
From: | "czechsix(at)juno.com" <czechsix(at)juno.com> |
Subject: | Re: RV-List: Backup battery - Lightspeed EI |
Hi Doug,
My RV is setup for day/night VFR and I have dual Lightspeeds. I pondered the electrical
system options extensively. I originally planned to go with two alternators
and one battery. The thing I kept coming back to is that with one battery,
you have a single-point failure for the entire electrical system. Notwithstanding
the opinion of others to the contrary, it IS possible to have a battery
lead break off or come loose. I know people who've had their car quit because
of this. I don't know anyone who has had their Lycoming quit from this--yet--but
one of the guys on the Aeroelectric List a couple years back did have a battery
lead break (in his case it did not result in engine failure, but if he
had been using a single battery architecture with dual elec igntion, it would
have!). People can argue that it was improper installation or poor maintenance
and that's fine, but it has happened and I prefer to design out the possibility
in my airplane. Even with dual alternators, if the backup alternator is off
and you lose connection to the battery, the alternator is not self-exciting for
startup so it does you no good (or at least I wouldn't bank on it). So you
lose everything including the engine at that point. I was not personally comfortable
with this setup in my plane and decided to go with single alternator, dual
battery setup instead.
Another advantage to the dual battery setup is that you can avoid the perceived
weakness in the Lightspeed system with the Skytec starter that has resulted in
damaging kickback with more than one installation. I won't get into the causes
and fixes and who's-to-blame thing, but if you have a small backup battery
that is isolated from the rest of the elec system, you can use it to power one
ignition while cranking the engine from the main battery. This is exactly what
I do on my plane with great results so far...I turn on only the ignition powered
by the backup battery, leaving the main one off. Crank it and it starts great
(even in winter in Iowa, with no primer system). Then I switch on the main
ignition and I'm good to go with no chance of kickback from low voltages on
the Lightspeed...
I wired mine pretty much like Klaus shows with a Schottky diode in between to isolate
the backup battery from the rest of the elec system. I elected not to put
in a switch like Klaus shows to switch the ignition between main and backup...I
didn't see an advantage to it and didn't want to be flipping switches to
get my engine started again (would prefer it doesn't quit to begin with!). I simply
wired my second igntion directly to the +/- terminals of the backup battery.
The main ignition is likewise wired directly to the +/- terminals of the
main battery. The only other thing I have connected to the backup battery is a
voltmeter just so I can monitor it (note: in my case the path to the voltmeter
is switched on/off with the ignition....this is because the voltmeter draws
a small current, so if you wired it always-on it would drain the battery while
the airplane is powered down).
I used a PowerSonic 2.9 Ah battery (PS-1229). It's light and relatively cheap (I
think about $25-30...you can Google it and get lots of hits). I plan to change
the battery every two years to ensure that it's reasonably fresh. I know Klaus
says 4.5 Ah but I thought that was overkill (unless you plan to be flying
over some really rugged terrain/ocean with no alternates within an hour or two
of flight). The 2.9 Ah batt is theoretically good for almost 3 hours of run time
on one ignition (drawing ~ 1A at cruise RPM's). In the unlikely event that
I ever find myself operating the engine soley on the backup battery, I will try
to have it on the ground within an hour. Remember, if you're flying in that
condition it means you've lost everything else in your panel so you're probably
not going to be wanting to continue a long XC under those circumstances! If
I upgrade to IFR I'll put the backup battery in the Dynon and make sure I have
fresh batteries in my handheld comm and GPS.
One nice thing about the PS-1229 is that it can fit into the standard Vans battery
tray along with an Odyssey PC-680. I have the PC-680 at the back of the tray
against the firewall and a piece of angle in front of it (to keep it from sliding
forward). The PS-1229 is in the front of the tray. There is about 3/4"
of space between the two so any sort of melt down/overheat condition of one battery
won't take out the other one.
FWIW, I made up a quick checklist in my POH for main alternator failure. If the
main alternator quits and I plan to continue my flight for over an hour, I will
turn OFF my backup-powered ignition to save the battery just in case it's needed.
I will continue to planned destination running the main igntion and reduced
panel loads (e-bus) and only turn the backup ignition ON when approaching
to land. This way if the main battery craps out on me prior to arrival at my
destination I will be able to keep the engine running with the fully-charged backup
system.
Some may say my setup is overkill, others will think it's inadequate. But it's
my airplane and this setup is one that I'm very comfortable with.
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D flying 8.3 hours...
Subject: RV-List: Backup battery - Lightspeed EI
--> RV-List message posted by: Doug Weiler
Fellow Listers:
I am contemplating converting my mag driven 0-360 to Lightspeed
electronic ignition. I may consider the dual Lightspeed installation.
Lightspeed calls for a 4.5 amp/hr backup battery (if I so choose). I need
something small and light to squeeze this installation in to my RV-4. For
those that have done this, what backup battery did you use?
Doug Weiler
N722DW, 275 hrs
Hi Doug,
the Lightspeed...
system.
--Mark Navratil
Cedar Rapids, Iowa
-- RV-List message posted by: Doug Weiler dcw(at)mnwing.org
Fellow Listers:
Doug Weiler
N722DW, 275 hrs
Subject: | Strange people behavior in debate |
I don't know about tirade, may be helpful tirade. Its no
different in tone or content than anything Bob writes. If you are
mad that I disagree than that is ridiculous, OK. Get over it, please :-)
If I say something improper, not true or unfair, than point out a
specific thing I said. I'll apologize if I said something wrong. I feel
I said nothing wrong, except to disagree with the Bob N, which is a
crime?
Any *specific* comment where I said something NOT true? Speak up.
Try reading what I write with a smile on your face and in good
humor, because that is the way I write it. :-) Think of it as a light
hearted comments with a smile and friendly suggestions.
I don't understand 90% of what Bob writes sometimes. It makes
no sense, and I mean it. Sorry? It is true. You translate some of the
comments he makes. I am not alone on this either folks. This is
not to be hurtful. Bob talks about REAL engineers, he saved the day
stories, strange analogies and phrases (bucket of bullets) and all
kind of weird stuff I don't understand not related to the topic. I don't
think I am alone here?
Besides the I-VR, the other RED flag topic is ENGINEERS.
Somehow he loves to make comments how he and only he
showed some engineers why something was wrong. OK. I find
that arrogant. If you did not know it, this list HATES engineers? Why?
I am laughing. No one is perfect, especially me, but if you want a
tirade, I learned it from Bob N. ; -) *Is that enough emoticons?*
For gosh darn sakes, lighten up folks. It is suppose to be fun. This
is just an alternator. Get perspective. Do what ever you want. This
is America I can say what I want as long as it is not intended to
damage. You all have thin skin. I have help many, look at that.
Sometimes the emperor has no clothes and its OK to say, HEY
you're naked. Some how Bob makes everything personal, and
disagreeing is an insult. He especially sees RED when it involves
I-VR's.
Let me do a little bragging like Bob does. ;-) lol , hahahaha
Since I have started my (helpful) tirades on this list there's NOW open
dialog on the topic, more people willing to make comments on their I-
VR.
People where afraid to EVEN admit they used an I-VR before.
Many useful details about wiring, operation and maintenance
have been discussed in the last year. I had something to to do with it.
Biggest improvement? Problems are now reported accurately.
Before every problem big or small was OH MY this GUY had smoke
and $30,000 dollars of damage from a ND alternator! Yea RIGHT.
Now a REALITY check (we now know the above is not true)
Read everything Bob has written you will find Bob's not a fan of
I-VR alternators and does not recommend using them. He will play
along, but his heart is not into it, OK. That is cool. Bob does
not support or know much about I-VR's by his own admission.
Bob has no incentive or desire to really promote and understand I-
VR alternators. If he did he would have tested them by now. Look
at the Plane Power Guy, he put effort into it, produces an I-VR's
with a self contained crow-bar. Brilliant. Of course he charges
a lot for his alternators, but theres NO reason we can not
modify our stock alternators the same way. Would Bob lead
the effort? (NO) Why? It would take business away from his
buddies at B&C. We all understand that and that is cool.
(NONE OF THE ABOVE IS BAD, I AM OK WITH ALL OF IT)
(AND IF I AM WRONG SHOW ME WHERE I AM WORNG?)
(I DO MAKE conjecture, but come on, you all know its true.)
When I say WE, who is WE? Well it is not YOU. :-)
There are lots of people who use I-VR alternators with no add on
OV protection. If that is YOU than you are part of We or Us.
If this does not describe YOU, than you are not part of the group.
Don't YOU be so presumptuous in thinking I was talking about
you. YOU know who YOU are. ;-) (am I emoticon-ing enough?)
I do speak for a LARGE group. The group thinks that I-VR are
safe and can be used with out all the sensational, Oh My Gosh OV
stories. In a year and 1/2, the only OV reported were below 16
to 18 volts!!! Many times they where precipitated by the pilot doing
something dumb like turning the alternator OFF/ON under load. FACT
LAST OF MY (helpful) TIRADES
There are FOUR things Bob recommends, which are fine for an
E-VR, but are counter to safe, efficient use of an I-VR:
*Crow-Bar and OV relay: This violates all the
warnings the alternator manufacture recommends, ie do not
disconnect the b-lead from the battery. I take warnings to heart
and try not to out think it. IT SAY NO B-lead disconnect.
*Cooling Air- Bob says NO, but that is for alternators with NO I-
VR. Fact electronics like to be cool for longer life and greater
reliability.
*Warning Light- Bob attacks the (I-VR internal) warning light and
never mentioned it. OK I'll do some boasting. I am the only one that
promoted and recommended its use. Bob was typically negative
and said it would not work if the VR failed. WRONG (his bius showing)
*Fuse on B-Lead- A CB on this lead is important. Not as
important for an E-VR. I suppose a crow-bar OV relay is a
substitute for a CB you can manually trip. However item (1) is
don't use a crow bar OV relay. Fuses are great in the right
place.
So back off and have a beer and cool down you ALL. Lol, ha ha,
:-) and think of all the happy friendly emoticons you can.
I am not going to let bullies bully me. OK. I am gathering just
arguing my point passionately and not agreeing with Bob N.
is my biggest crime.
I am not naive, this is BOB's LIST. Its unfortunate its named
after Bob's company. We don't need to change the name,
just the attitude; all opinions, even non-aeroelectrical opinions are
welcomed. If Bob or the list thinks that open discussion is
welcomed they are not being honest.
We have the 1000lb Gorilla in the corner.
Bring the banana and say nice monkey, all is well.
Let the monkey throw poo on you and say nothing or else.
Yell at the poo throwing monkey, you will get ripped apart.
(Oh no! NOW I'M COMING UP WITH LAME analogies :-0
Bob is rubbing off on me. :-) ha ha ha, but mine make sense. :-)
LoL, ha ha ha, Take care all.
(I am done with this topic)
(fight amongst yourself)
Cheers George
Subject: | Changing the mag switches out for emag and pmag |
>> I'm ditching my old Slick mags and going to one Emag and one Pmag. My
>> wiring from switches to mags is from the old Z-9 drawing (same mag
>> wiring as in
>> Z-11). Emagair says that you should switch off power to both the
>> emag and the pmag because there is a drain on the battery when they
>> are powered up, so direct wiring from the battery bus without a
>> switch is out. Both
>> ignitions should be ON during start, as opposed to the disabling of
>> the right mag during startup now. Is there a way to retain the
>> switches I have, including the momentary "start" function on the left
>> mag switch rather than replace the switches with 1-3 switches as in
>> Z-12?
>> Thanks
>> Jerry Carter
>> RV-8A approaching 500 hrs
From: | "Rodney Dunham" <rdunhamtn(at)hotmail.com> |
"Tirade, a protracted speech usually marked by intemperate, vituperative, or
harshly censorious language." ...courtesy Merriam-Webster Online Dictionary
Yes George, it's a TIRADE! You are obviously mentally unstable and I suspect
in another manic phase of your bipolar affective disorder. See a
psychiatrist, get on some Lithium and rejoin the ranks of polite society.
George, you are NOT the moderator of this list, Bob is. You are NOT the
reason for the success of this list, Bob is. You do NOT represent a large
group of OBAM aircraft enthusiasts, Bob does. Without the immense
contribution Bob has made to the OBAM aircraft community WORLDWIDE this list
would not exist and you sir, would have no audience at all! If you doubt the
simple truth of this, get your own list and moderate it! Then the value of
your contribution to the OBAM aircraft community will become immediately
obvious. I'm willing to bet a month's wages (remember, I'm an MD, that's a
significant wager) that your list would not hold a candle to this list. Just
try it and see. Put your money where your mouth is!
Rodney
Subject: | Re: Strange people behavior in debate |
Okay . . .
Not true: This isn't about being a "fan" of anything. The aviation
community both commercial and military have adopted design
goals that I as supplier to those industries am expected
to meet. If a customer walks in the door looking to purchase
apples, you don't try to sell them oranges.
Not true: Since day-one, I've said that I cannot recommend
the IR alternator because I could deduce no way to incorporate
them into systems that comply with the design goals I've
cited many times: Ability to turn ON/OFF at will without
regard to operating conditions and free of concerns for
damage to the alternator or other equipment.
You accuse me of distorting science as a means to
protect the financial well being of B&C? Shame on you
sir! I AM testing some alternators to confirm the
design parameters under which some new products will
be offered that meet the design goals cited.
Not true: There are people who don't wear helmets while riding
motorcycles and others who do not wear seat belts
while driving . . . and the vast majority of those
individuals are alive and well today. But at the next
roll of the dice . . .
OV protection has been a part of engine driven power
sources in aircraft (and other $high$ systems) for
decades. This is because the risk of OV events is not
zero. The vast majority of those who fly without it
are no different than those who choose not to incorporate
risk mitigation activities in their cars or on their
motorcycles. They makes their choices and they takes
their chances. Please don't paint me as the heretic because
I don't RECOMMEND them in their current form.
Folks building OBAM airplanes may do as they wish based on
any logic that pleases them. When asked, I've only
explained my design decisions and recommendations based
on design goals established by the customers who
have seen fit to help me raise two families and pay my bills.
If folks here on the List find the work products of other
suppliers attractive, I would not discourage their use
except when they're not supported by common sense.
For example, the EXP-Bus probably performs exactly
as advertised and I perceive no safety issues. The common
sense question here is, "what are you getting for your
$time$ and are there alternative solutions with attractive
features." But to suggest that I would beat up on anyone
for installing an EXP-Bus or a stock IR alternator is
contrary to fact.
Not true. One individual of several reported voltmeter readings
that may in fact have pegged the instrument. Given the damage
to his battery, it's the opinion of myself and others that
the alternator suffered lost of voltage and was only limited
in output current by the magnetics of the device.
Others have reported alternator failures that produced
damage to avionics. I did not embellish those reports.
To brush them aside as overblown or misinterpreted
is tantamount to saying those victims are dishonest
and that I'm dishonest for promoting automatic protection
that has been a standard of the industry for decades.
Not true: B-lead disconnection under certain circumstances has been
shown to be hazardous to the alternator (for reasons we're
going to explore in the regulator trade-study paper). This
is a byproduct of a system installed with the intent of
providing OV protection for the rest of the airplane . . . I
did not even consider risks to the alternator itself. My bad.
This is why Z-24 was TEMPORARILY withdrawn until more suitable
techniques can be crafted.
> reliability.
Not true. I have never said that it was bad to cool any
device but at the same time, it's useful to know when
cooling is useful or necessary. The alternators for which
I have the most experience are externally regulated and
therefore do not contain devices common to internally
regulated alternators. If you're suggesting that the
IR alternator will always benefit from cooling air because
it incorporates the relatively fragile regulator, I cannot
dispute it.
My advice for cooling decisions has always been to consider
how many builders before us have suffered failures properly
attributed to lack of cooling. When in doubt, thermocouple
studies of the installed alternator are always in order.
Measurements trump conjecture any day.
I've never seen a blast tube installed on an automobile's
alternator so I've assumed that these devices were as robust
after regulators went inside as they were when regulators
were outside. I.e. I have no compelling observations to suggest
we have extraordinary concerns for cooling . . . for EITHER
style of machine. If you have data suggesting something
else, please share it with us.
Not true. As the regulator trade study will show, the warning light
system built into the internal regulator is on the same
chunk of silicon as regulator controls and other features.
I have not "attacked" it, only suggested that stresses that
might cause the regulator to misbehave and equally present
for the warning light functions. The design goals for my
other customers called for separation of functionality
between control, indication and protection.
Yes, I have an opinion for the reasons cited. It seems a logical
choice.
> place.
Note true. There are two different considerations: Fuses protect
wires such that failures in one wire do not propagate
through to other parts of a system. The pullable breaker
for OV protection is the same disconnect mechanism
as a b-lead contactor.
The breaker must be operated manually, the contactor may
be manual or automatic. It was the manual operation of the b-lead
contactor that brought load-dump vulnerabilities of
the IR alternator to light. Those issues will be addressed
and solved. The problem with simply pulling a b-lead breaker
will be the same as with the orignal Z-24 implementation:
Rapidly rising voltage across the contacts may ignite an
arc that won't go out. No big deal in the metal can under
the cowl. Really BIG deal in a plastic housed breaker on the panel.
Further, disconnection of a runaway alternator will protect
the rest of the airplane but results in destruction of
the alternator. The field winding for sure is toast. The
diodes are at risk too.
It's better that we figure out a way to bring things
to an orderly, quiet, low energy state such that nothing
burns, the pilot is advised of the need to switch to
Plan-B, and only the failed component need be replaced.
There were advantages cited for getting the b-lead
breaker off the panel. To bring it back into the cockpit
just to allow a pilot to do manual disconnection during
an OV event seems a step backwards when solutions
to protecting the alternator from its own load-dump
are at hand. And this goes back to the originally
stated design goal of carefree ON/OFF control of the
alternator at any time.
(If folks choose to give up this goal in favor of
George's recommendations, please know that you're
still welcome in my house. I have friends and relatives
who don't wear their helmets and seat belts either
but I don't rag them about it . . . and MOST of them
will probably lead happy, injury free lives.)
Your transgression is the promulgation of bad science based on
faith combined with your accusations of dishonorable behavior
on the part of those who have shared their experiences with
us. I've invited you to join me in an analysis of the
functionality of an exemplar internal regulator. I even
offered to make it a friendly competition.
You reacted by changing the rules of engagement, declaring
me in default under the new rules, claimed victory for
yourself and suggested I write for a mailing address for
the prize. That was pretty amazing . . . the next time
would you do that in slow motion? Perhaps we can see
exactly how the rabbit got into that hat.
Isn't that what we're doing now?
Not true: I've never ripped anyone. I've only offered alternative
views along with the simple-ideas that supported them.
When you could not respond in kind, you pointed fingers,
yelled unkindly things, and accused me and others of dishonorable
behavior. Your true colors have been enshrined in the archives
forever. You paint my behavior as trying to be king of the
sandbox but you're the only one throwing sand. My mother
would ban kids from the sandbox for throwing sand.
Invitation to debate: Please describe for us your
interpretation of the warning/protective features in the
MC33092 regulator chip and how well they conform to
the classic aircraft systems design goals. If not, what
goals should replace them?
From: | Ernest Christley <echristley(at)nc.rr.com> |
Matte, there's a fund-raiser idea. Print up some "I'm a Nuckoll-Head"
t-shirts.
Oh, the humor. 8*)
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o www.ernest.isa-geek.org |
>Peter,
>Of course you're right. Sorry for the tirade. I'll try to do better in the
>future.
>But... I consider myself part of the Aeroelectric Connection family. I
>consider Bob the head of that family. In any family worth belonging to, when
>someone attacks your kin you don't just sit idly by and expect your family
>member to "defend himself". You jump, and I do mean JUMP to that family
>member's aid. Bob has earned our respect!!! He has earned our loyalty. I do
>not consider it any bother at all to jump to his aid. He ain't heavy, he's
>my brother :o)
>Bob, if you're reading this, my wife still wants to bake you a cake for all
>the help you've been to her husband. If you're ever in eastern Tennessee or
>even northern Alabama or Georgia, you've got an open invitation to the guest
>room, dinner and your favorite cake. She makes this thing she calls an
>eclaire cake that is to die for! Of course, Mrs Nuckolls is also invited.
Your respect and kindness is appreciated. I will endeavor
to be worthy of both. Actually, Dr. Dee and I have been
considering a trek to Atlanta for a weekend seminar soon.
It's been two years since we visited that part of the country.
Alternatively, we could do it closer to home for you. Where
do you live?
Hi Rodney,
Thank you for your reply to "jetpilot". You put into words what
many of us think. I find that when he is on the list, I now just delete
his message and move on. Bob has helped me on several occasions
including phone calls to him direct. George needs his own list (and
lithium) where he can do "his thing" on internal regulated alternators.
Jim Nelson
I don't know about George, but I've found that I also learn things from
outspoken people. Just because they voice their concerns with some venom
doesn't invalidate the ideas they are trying to convey.
Bruce
www.glasair.org
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of James H
Nelson
Sent: Friday, March 03, 2006 10:29 AM
Subject: AeroElectric-List: RE: George
Hi Rodney,
Jim Nelson
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> and pmag |
Subject: | Re: Changing the mag switches out for emag and pmag |
> >> wiring as in
> >> switch is out. Both
> >> Z-12?
Emags are a unique product in that as the factory points out,
have TWO switchable functions: Power and control. Their installation
manuals suggest separate switches but in a quest for the minimalist
panel, I crafted the drawing for P-Mags at:
http://aeroelectric.com/articles/Rev11/AppZ_R11E.pdf Figure Z-33.
. . . now, be aware that the sequence of switching functions
depicted have been commented on by the good folks at E-magair
suggesting that switch movements should bring power on first
followed by activating the magneto.
My wiring diagram shows the opposite sequence, ignition "active"
first followed by supporting power. The reason is quite simple:
There are separate but divergent interests in the ownership
and operation of the p-mag:
(1) When sitting at the end of the runway doing a pre-flight,
the PILOT'S interest is "are the built in alternators for
each P-Mag functioning?" By wiring as I've suggested,
moving the switch from full up to the mid position deprives
a P-Mag of electrical support and (if the run-up RPMS are
high enough), the ignition will not falter when dropped
to the mid position. Of course, the opposite ignition
needs to be completely OFF at this time.
Pre-flight test would be:
RUN-UP RPM . . . . . Set
L-IGN Switch . . . . . . . OFF
R-IGN Switch . . . . . . . ON but no BAT (mid position)
Note engine does not falter
L-IGN Switch . . . . . . . ON but no BAT (mid position)
R-IGN Switch . . . . . . . OFF
Both IGN Switches . . . . BAT
(2) A secondary interest is what might be called the
maintenance mode for ground ops where the mechanic wants
to have the systems powered but inactive for using a
P-mag's built-in timing features -OR- for hand propping
the engine where again, it's useful to be able to hear
the timing buzzer.
In this mode, you MUST have battery power available to
the P-Mags even when in the inactive state. The diagram
shows a third switch (accessible through the oil check/
filler door?) that places temporary power on both
ignitions while leaving absolute control over activity
in the hands of whoever has access to pilot's controls
on the panel.
If one chooses this architecture, then a light on the
panel should be included to alert the pilot should
the switch be left in the maintenance position. Not
a big risk from a fight operations and safety perspective
but it WOULD run the battery down.
In answer to your specific question, it's my recommendation
that you get a 2-10 switch for the P-mag. Since the E-mag
is electrically dependent, a 2-3 switch to handle both sides
of the E-mag's switching needs is called for. Your existing
mag switches are not suited to this task.
OOPS! I just noted that a narrative for Figure Z-33 didn't
find its way into the published work. Rats! . . . just sent
Rev 11 back to the printers for another 1000 books. I'll get
the Z-notes updated and publish an errata sheet. I'm glad
you brought up this topic. It showed me where my homework
needs some attention.
From: | "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> |
Not sure I understand the need for the test switch.
If I understand correctly to enter "Test mode" one simply needs to leave
the P lead grounded (off) and apply power, in this case turn on the
master. Of course now the whole ship is powered up but this seems a
fairly small inconvenience considering that timing is a pretty simple
affair.
Am I correct in my understanding here?
Frank
Sent: Friday, March 03, 2006 8:00 AM
Subject: Re: AeroElectric-List: Changing the mag switches out for emag
and pmag
and pmag
> >> My wiring from switches to mags is from the old Z-9 drawing (same
> >> mag wiring as in Z-11). Emagair says that you should switch off
> >> power to both the emag and the pmag because there is a drain on the
> >> battery when they are powered up, so direct wiring from the battery
> >> bus without a switch is out. Both ignitions should be ON during
> >> start, as opposed to the disabling of the right mag during startup
> >> now. Is there a way to retain the switches I have, including the
> >> momentary "start" function on the left mag switch rather than
> >> replace the switches with 1-3 switches as in Z-12?
the timing buzzer.
on the panel.
Subject: | Changing the mag switches out for emag and |
pmag
>affair.
If you wire per Z-33 where powered support is available only
from the upper switch position for the purposes of confirming
a P-mag's internal power supply during pre-flight, then you
have no way to power up but ignition inactive (control lead
grounded) without the adding the third maintenance or test
switch switch.
Subject: | Composite planes, Metallic paint, Antennae |
Bob: I am sure you have answered this one 700 times but please once more
for the not yet informed: I have a Lancair IV which is carbon and fiberglass.
The aft upper fuse is fiberglass, under which is an antennae farm for com,
gps, elt, etc. This is all pretty standard, built generally IAW the kit
guidance. How it is time to select paint and I am considering SW Acry Glo
metallic Urethane. The question: will metallic urethane on the aft upper fuse
fiberglass section significantly degrade antennae performance?
thank you,
paul tackabury
Bruce,
There are proper ways to discuss ideas and "jetpilot" is, in my
humble opinion, out of bounds in his replys. If he wants to disect every
word that Bob writes, then let him directly e-mail Bob. We don't need to
get his "flaming" replys.
Jim
Subject: | Re: Seminar in the South |
I live very close to Knoxville, TN.
Even though I've wired one homebuilt according to the 'Connection and I'm
wiring another one right now, I'd love to attend a seminar. Every project
teaches me something and sends me back to the 'Connection for a re-read.
I keep tabs on your seminar schedule hoping to catch one in this general
area. Atlanta is close enough! I'll talk to the guys at EAA Chapter 17 on
Tuesday to see if there's an interest here in Knoxville. I'd be happy to
help organize. And of course, there's that cake :o)
Rodney
Rodney,
I live in Blue Ridge, GA and our Chapter in Blairsville would probably be
willing to participate in trying to get something together with you.
Contact me off-list smithhb(at)tds.net
Bret Smith
RV-9A (91314)
Mineral Bluff, GA
www.FlightInnovations.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Rodney
Dunham
Sent: Friday, March 03, 2006 7:42 PM
Subject: AeroElectric-List: Re: Seminar in the South
Rodney
>Bob, I think this is Allen Barrett from Barrett Performance Aircraft
>Engines. He's almost as "gold" as you :-)
>Bill S
>7a wiring
Agreed. I got a direct note from him and I'm impressed.
Hope to meet him sometime as Dr. Dee and I pass through
Tulsa several times a year on our way to see friends in
Sallisaw.
Oops, the note I received was from Allen and he gave me the short
history of the company founded by his father Monty. In any
case, I'm looking forward to meeting the Tulsa crowd and Allen
in particular. I'll plan a visit to their EAA chapter meeting.
>Bob,
There's nothing that says we can't do a presentation anywhere
except minimum participation levels. If you could put a dipstick
into the local enthusiasm level, it would be helpful. Generally
speaking if 10 folks are interested locally, the balance can be
made up from the surrounding area with advertising on my website.
We'd be pleased to meet the builders in Knoxville too!
Subject: | Continuous duty contactor wiring question |
Hi,
I've got a S701-1 contactor I purchased from B&C
http://www.bandc.biz/S701-1.html which I want to
use in a slightly different application.
I want to use it as suggested by Eric with his
OVP module. http://www.periheliondesign.com/LOVM.htm
The wiring for his OVP module requires that I
use the 12v line as the contactor control, not
the ground wire used in the battery contactor
application.
I've read the battery contactor information in
chapter 8 several times, but I still really
don't quite understand the role of the spike
suppression diode, nor whether or not I will
need one.
Should I use the spike suppression diode?
Should it be installed between the two
coil terminals? If so, does it matter
which terminal is (+) and which is (-)?
Thanks for any tips!
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
From: | "Paul McAllister" <paul.mcallister(at)qia.net> |
Mickey,
It is advisable to put spike suppression across the coil of any relay. It
can be accomplished with a diode connected in the reverse polarity to the
voltage source being used to energize it, or a transorb device with a rating
greater than the voltage being used to energize the coil.
The spike suppression is required to dissipate the voltage generated as a
result of the magnetic field collapsing when the relay is de energized.
I am curious as to the application and wondering if a relay of this size
might be overkill.... it really depends on what your application.
Paul
Has anyone else tried to modify a set of original wing tips into a
pair of tip
tanks? If so, I'd like to hear how you did it, and what kinds of issues
you
have had, if any. I'd also like to know how you made the modifications
and
the type of glass/resin you used..
Jon Johansen's don't appear to be available on Van's web site
anymore.
Fred Stucklen
RV-6A N926RV
Subject: | Re: Continuous duty contactor wiring question |
Mickey
A diode flows electrons (current) in one direction only exactly like a
one way check valve. That is why the schematic diagram of a diode even
looks like a one way arrow. The pointed end of the arrow is the end of
the diode that is usually marked with a white bar and that end must go
to the positive terminal of the coil. Otherwise the positive battery
current will flow through it to ground which will destroy the diode
and/or blow the fuse. Anytime you have a coil of wire just assume that
the current wants to keep flowing after you turn off the power. So the
diode lets the current keep flowing from the negative side of the coil
back into the positive side of the coil instead of out through other
circuitry where you might not want it to go. As mentioned the decaying
magnetic field can initiate a significant voltage spike so the diode
prevents that and lets the current goes round and round and lowly
dissipate as heat.
(We could debate which way electrons really flow but most of us still
think of electricity as flowing out of the positive battery terminal for
the above explanation.)
Ken
>Paul, Thanks for your help.
>I've got the diode that was delivered with the contactor, so
>I guess that would work. I'm still not clear on which direction
>to install the diode. It seems like with the two coil terminals
>it doesn't matter which side is positive or negative. Should
>the diode restrict flow from (+) to (-) or the other way around?
>I'll trust you on that one, but I don't understand. No biggie.
>It is overkill for just a b-lead switch, but to simplify
>my wiring, the starter energy also flows through it.
>Thanks again,
>Mickey
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Antennae |
Subject: | Re: Composite planes, Metallic paint, Antennae |
>and fiberglass.
>upper fuse
>thank you,
Surface coatings chosen have no measurable effect on antenna
performance. Since carbon composite materials have a sheet resistance
on the order of 1000 times that of aluminum, they also make poor
ground planes under resonant monopole antennas. The goal is to
achieve a long lived, low resistance path between the antenna's
mounting base and the ground plane . . . which on your airplane
will need to be on the inside surface of the skin.
Make a solderable mounting base plate from brass or copper. They
may be thin. Copper hobby foil or brass shim stock (.010") are good
choices. bond your base plate to the underside of the antennas
mounting surface and then work to get good conductivity between
antenna and base plate via the bolts.
In the figure posted at:
http://www.aeroelectric.com/Pictures/Antenna/Antenna_Installation.gif
I've marked the critical conduction points with an (*). Here's
where all the magic happens. All other surfaces may be left as
supplied or as finished for corrosion protection. There's no
value in cleaning the entire surface of the base or large interfacing
surfaces between airframe, antenna and doubler (in this case your
doubler is the copper or brass sheet).
Then you need radials made from shim stock or copper tape. Wider the
better up to 2" or so. Same length as height of antenna. 4 is about
the minimum, no measurable differences beyond 8. They don't have
to lay flat (they might run up and over a doubler or other surface
feature). Solder these to the base plate.
This is described in more detail in the antenna chapter.
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> question |
>Hi,
>application.
Does Eric recommend this contactor for use with
his product? Last I heard, the high-voltage
EV series contactors were his associated product
of choice.
>need one.
See http://aeroelectric.com/articles/spikecatcher.pdf
>coil terminals?
What does Eric's installation drawings/instructions
say? He might have built the spike suppression diode
into the electronics. Perhaps his design does not
benefit from the diode or may even be detrimental
to it's intended function.
Remember folks, questions like this are ALWAYS
best addressed to the designer/manufacturer
of the product. It's risky and sometimes unethical
to inject ourselves into the relationship between
customer and supplier until it's determined
that the supplier simply doesn't know the answer
to your question or in some cases, is simply wrong.
Study the drawings, discuss your uncertainties
with the supplier. If you're not satisfied or
still skeptical, then go to the List for whatever
clarification and assistance may be available.
Absolutely. The banded end of the diode
faces the (+) terminal of the contactor.
Reversing the diode may cause serious
fault currents to flow and damage something.
From: | "Alan K. Adamson" <aadamson(at)highrf.com> |
Uh, might that be a question for the vanairforce.com forum and not an email
list dedicated to "electrical" discussions???
Alan
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Fred
Stucklen
Sent: Saturday, March 04, 2006 10:40 AM
Subject: AeroElectric-List: Tip Tanks
Has anyone else tried to modify a set of original wing tips into a pair
of tip tanks? If so, I'd like to hear how you did it, and what kinds of
issues you have had, if any. I'd also like to know how you made the
modifications and the type of glass/resin you used..
Jon Johansen's don't appear to be available on Van's web site anymore.
Fred Stucklen
RV-6A N926RV
Bob: Thanks for your prompt response to my question, BUT: I didn't
communicate my concern well and therefore need to retransmit. I am not interested
in a ground plane, I understand that one from your excellent chapter in the
"Connection" and used that info when installing my EXTERIOR antennae. My
concern is the INTERIOR antennae buried in the upper aft sections of the Lancair
IV under the fiberglass skin. Again this is the recommended place for com,
gps, etc and has been used successfully by many builders for years so I am not
concerned about that either. HOWEVER, I am considering a metallic paint and
wonder if the small amounts of metallic in the paint when applied over the
fiberglass will degrade the performance of these buried antennae. I don't
think metallic paints are used on radomes but I wonder if this is really a
concern for my installation. thanks for giving me a second chance, paul
http://www.highrf.com/gallery/Feb-06/DSCN1305
Here is my solution. Couple of notes.
3M makes a copper tape that has acrylic glue on the back and the glue is
conductive. They use it in EMI solutions. I first lined the Comm antenna
indent in the fuselage with said tape, then I ran the 22" radials out from
that area. I then got some copper flashing and made a conductive backing
plate. My original plan was to use some solder paste and put the backing
plate down and "wick" in some solder around the edges.... HOWEVER, I tested
my approach on a sample piece and determined that any soldering iron heat
(and I use a Metcal), would degrade the laminate So I'm going to use a
little conductive copper no-ox compound. Just a little as it goes a long
ways. One other note before I stuck down the radials I did sand down to the
exposed carbon so that at least I'd have some sort of electrical bond
between the radials and the bottom of the fuse.
I later came back and put a 2 bid of 1.7oz glass over each radial just to
provide protection.
That backing plate will be drilled for nutplates and rivets and once it's
down and held in place, I'll come back and drill and countersink a screw
from the outside (flush), and put a nut and washer on the inside. This stud
will then be ran back to the central ground.
Lot of discussion of this approach on the Lancair list. Seems some believe
that the ground plane needs to be on the outside and not inside....Oh, well,
I didn't want to "paint" the groundplane with copper/silver paint as I've
heard it will deteriorate over time... I figured this was next best.
Alan
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L.
Nuckolls, III Antennae
Sent: Saturday, March 04, 2006 11:20 AM
Subject: Re: AeroElectric-List: Composite planes, Metallic paint, Antennae
Antennae
>more for the not yet informed: I have a Lancair IV which is carbon and
>fiberglass.
>com, gps, elt, etc. This is all pretty standard, built generally IAW
>the kit guidance. How it is time to select paint and I am considering
>SW Acry Glo metallic Urethane. The question: will metallic urethane
>on the aft upper fuse fiberglass section significantly degrade antennae
>performance?
>thank you,
Just one comment, Radar uses a much higher frequency than Comm or Nav, etc.
So while the metal flake paint messes with radar returns due to it's
"reflectivity". I doubt it would do much to the comm antenna
Alan
PTACKABURY(at)aol.com
Sent: Saturday, March 04, 2006 11:38 AM
interested in a ground plane, I understand that one from your excellent
chapter in the "Connection" and used that info when installing my EXTERIOR
antennae. My concern is the INTERIOR antennae buried in the upper aft
sections of the Lancair IV under the fiberglass skin. Again this is the
recommended place for com, gps, etc and has been used successfully by many
builders for years so I am not concerned about that either. HOWEVER, I am
considering a metallic paint and wonder if the small amounts of metallic in
the paint when applied over the fiberglass will degrade the performance of
these buried antennae. I don't think metallic paints are used on radomes
but I wonder if this is really a concern for my installation. thanks for
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> |
Subject: | Re: Backup battery - Lightspeed EI |
>Hi Doug,
>the electrical system options extensively. I originally planned to go with
>two alternators and one battery. The thing I kept coming back to is that
>with one battery, you have a single-point failure for the entire
>electrical system. Notwithstanding the opinion of others to the contrary,
>it IS possible to have a battery lead break off or come loose.
The only cases I've seen for this are (1) batteries with lead posts where
the lead wires are much too stiff (e.g. 2AWG 22759 wire). (2) Another
case was where the builder had fabricated a stiff copper strap that bolted
one end to the battery (-) terminal an the other to the firewall. This
was a steel posted battery and it broke the terminal under vibration.
Make your short battery jumpers from 4AWG welding cable IRRESPECTIVE of wire
sizes used elsewhere in the system.
I'm not arguing against multiple battery installations, only suggesting
that risk mitigation for broken battery terminals is a no-brainer.
BTW, a little bird flew by a few days ago and whispered that a well
known supplier of PM alternators just might be bringing a new regulator
out that would be self-exciting. Don't quote me on that. The bird was
speaking in Swahili and the only words of that language I remember clearly
were the favorite expletives of my 8th grade science teacher. We shall
see . . .
Subject: | Re: Composite planes, Metallic paint, and Antennae |
>interested
>Lancair
>am not
No problem. Attenuation effects of the various paints is a crap
shoot. We've studied the effects of various coatings on our
nose radomes on the bizjets and yes, there are some paints
that you don't want to use. The manufacturer of the paint is
unlikely to know and the dealer is almost sure not to know
whether your paint of choice represents a hazard to GPS
performance. Antennas at lower frequencies are less likely
to be affected.
For the most part, paints with metal flecks in them don't seem
to offer much attenuation. Some builders have reported adequate
GPS performance when antennas are under a fabric skin with
several coats of aluminum prep. I don't recall any conversations
about VHF antennas under paint. But these data are all subjective.
The #1, always-works, foolproof method to evaluate your paint
is to set your GPS up for operation with the antenna in the
clear and get a reading on relative signal strengths. Take
a large plastic mixing bowel painted with your proposed coatings
and cover the antenna. Drops of 20% or less are probably not
going to noticeably affect your radio's performance. If the
paint is good for GPS, it's probably fine for other frequencies
too.
The #2, usually-works method is to find someone who has used
the same combination of materials and see what they report. The
risk here is that subjective measures of performance can yield
wildly variable results. In deference to the Repeatable Experiment,
I highly recommend #1.
Subject: | RE: Composite planes, Metallic paint, and Antennae |
>provide protection.
No auxiliary grounding of antenna bases is required or recommended.
I've seen some composite aircraft where the interiors had spider-webs
of wire supposedly installed to replace the lack of "grounds" offered
by metallic aircraft. There is no advantage in doing this and may
even make RF interference problems worse. The only things that need to
connect to your ground plane is the base of the antenna and the outer
braid of the coax feedline.
Absolutely not. Looks ugly, hard to do, doesn't work any better . . .
>....Oh, well,
Aside from the extra ground wire, what you describe should be just fine.
Fred,
Jon Johansen's tip tanks don't show up on his website either.
(http://www.flymore.com.au/)
I have a pair for my RV-8A that I bought a couple of years ago from another
RV builder. I recall that the location of the filler and possibly the vent
is different for a tailwheel aircraft than for a nosewheel one.
Mine have not been installed yet, so I would be glad to take some photos to
send you on how these are made. They are of the earlier wingtip design, and
they have a boss for mounting the surface mounted nav/strobe lights and a
tunnel through the tank for the wiring.
I also have a set of the older style wingtips from Van's that I have had
hanging on my wall as a sculpture for several years now.
Jon's site has a couple of other interesting products for RV's -- a heated
pitot tube and flush fuel tank drains.
Terry
RV-8A #80729
Finishing?
Seattle
pair of tip
you
and
anymore.
Fred Stucklen
RV-6A N926RV
Great, I haven't done that "extra ground" and can always do it later if
deemed necessary... For now, I'll leave it out of the design and try my
current approach (minus the extra ground wire).
Thanks Bob,
Alan
PS for those interested, Mouser carries that tape and It think it's a model
1181 or something like that. Google for 3m copper tape and you'll find it,
there is a smooth version and a "waffled" version. For obvious reasons, I
went with the smooth.
Nuckolls, III
Sent: Saturday, March 04, 2006 12:56 PM
Subject: AeroElectric-List: RE: Composite planes, Metallic paint, and
Antennae
>is conductive. They use it in EMI solutions. I first lined the Comm
>antenna indent in the fuselage with said tape, then I ran the 22"
>radials out from that area. I then got some copper flashing and made a
>conductive backing plate. My original plan was to use some solder
>paste and put the backing plate down and "wick" in some solder around
>the edges.... HOWEVER, I tested my approach on a sample piece and
>determined that any soldering iron heat (and I use a Metcal), would
>degrade the laminate So I'm going to use a little conductive copper
>no-ox compound. Just a little as it goes a long ways. One other note
>before I stuck down the radials I did sand down to the exposed carbon
>so that at least I'd have some sort of electrical bond between the radials
>to provide protection.
>it's down and held in place, I'll come back and drill and countersink a
>screw from the outside (flush), and put a nut and washer on the inside.
>This stud will then be ran back to the central ground.
>believe that the ground plane needs to be on the outside and not inside
>....Oh, well,
>I've heard it will deteriorate over time... I figured this was next best.
"The thing I kept coming back to is that with one battery, you have a
single-point failure for the entire electrical system"
I am building a Europa with a Rotax 914 turbo. It has 2 fuel pump, 1 needs
to be running to keep the motor running.
I plan on flying Day and Night VFR.
I also have both 27 foot span go fast wings and 48 foot span go pretty
fast glider wings.
On automobiles I have had batteries fail open upon start ups. My wife and
partner have had cars die in the road from a internal open battery. That
said I had a Cessna 170 for 19 years and never had a failure of battery,
but not to say it will not happen. I still feel uneasy bout getting a
battery opening, especial on start up.
I don't like the added weight of a second lead acid battery,especial
something able to help out with starting.
I am introducing a nontraditional demand, trying to start the motor in
air.
Now one may recommend a airstart, and that works, but you are spinning a
cold motor real quick real fast, hard on motor. Best to use starter.
I have a SD-20S as primary alternator and Rotax internal Generator (not
self exciting) as back up. It is wired using Z13/8 as a starting place.
If you tickled the Rotax generator/Ducati regulator/rectifier, I am
confident with our 48K microfarad capacitor it will remain alive and
running a fuel pump.
I used my head which uses the rest behind the right seat passengers head
to make me feel better.
I have a 13 cell GP 2200mA NiMh Battery (1.62 oz ea cell) that can supply
a few hundred amps for short periods, and easily the 50 or 60 amps the
starter requires. It lives nice in the headrest easily accessable by
pilot.
I have 3 inputs it can supply:
If all went to hell, can run aux pump on it (~ 2amp draw, so without test
and very cold battery at minimum I would say 30 minutes) Pulling 60 amps,
this battery will put out 2000mAs and then still be at .9volts per cell!
I can power E-Bus (which it will be diode isolated from to not accept a
charge, but 14.4V) even if it did try to charge would not hurt battery too
much). Now powering E-Bus can allow me to run things when soaring and not
touch main battery, or if my main battery failed upon a start up, could do
a airstart running aux pump from E-Bus, then tickle the rotax generator.
Can also plumb directly in parallel with main battery to help start.
Voltage of pack will be nominal 15.6 volts.
May sound complicated, layout is simple and intuitive. I feel very
comfortable with it.
Smoke or other electrical failure? In 10 seconds I can turn off main
battery switch (Flaming River on rear of headrest), E-Bus aux feed battery
switch (in headrest) and plumb NiMh battery to pump (right in headrest)
and now have a bit of time to think things through.
The panel is recessed in headrest 3/4" and has EL strip to illuminate
headrest panel. There is a mini Blue LED Voltmeter in there as well that
tells either Main or NiMh output.
Normal failure of main alternator, just switch off and turn on Rotax.
Starter solenoid sticks when doing a in flight start, or other failure on
that side of things, turn off main battery switch and select E-Bus
alternate feed and turn on Rotax Generator
If Battery failed opened upon restart, plumb NiMh to E-Bus to run pump and
do a airstart, then tickle Rotax. Although I could probably start on the
NiMh autonomous, best not do it in air.
Battery flat when away from home, parallel main with NiMh. If NiMh failed,
am on ground, so no big deal.
Downside is you can not use a lead acid charging system to charge a NiMh
direct. If not in a hurry a C/10 by 14 to 16 hour charge is best. If in a
hurry a 1C delta peak charge is OK. If in a real hurry or you want to ask
200 amps from battery you want it nice and warm, do a 2 or 3C delta peak
charge.
Since I fly electric models and gliders, and one reason for having a
Europa is to take me to far away soaring sites, I am set up with all the
stuff I need. As a matter of fact when transporting models, future designs
will (you guessed it) be made using 13 cell packs. Chargers run off normal
1 2volt system.
Long winded all right.
Anyway if you have a electrical dependent aeroplane, for not much weight
you can give yourself imn my opinion a versatile alternative.
Ron Parigoris
Oh yea it will power something like this as well:
http://www.yourzagi.com/wagmax.htm
>Alan
There are also dielectric loss issues at higher frequencies.
I think we've tested coatings and materials that had no metal
content but offered unacceptable reflections and/or refraction of the
radar signals. Except for these isolated examples I think you're correct
in that the lower frequency systems are less vulnerable
to coatings that might affect microwaves.
Alan,
Jim Wickert here. It is quite well known that foil internal antennas do function
well under carbon fiber cloth. they do however function very well under glass
substrate. Now with regard to paint. Per a quite an experienced individual
Jim Weir VP RST Engineering group who as published "The Reference Text, The
RST-820 Antenna which deals strictly with copper Tape Antennas, see quote>
"These antennas have worked in glass and fiberglass airplanes with almost every
kind of paint and dope (including the aluminum coat used on fabric as a UV protectant)
that we could find. A couple of times in the past two years there have
been reports that there is a new German metallic paint (sorry, I don't know
the brand) that makes ALL hidden antennas (not just ours) work poorly if at
all."
I know of builder that has his plane flying with a silver metallic paint and he
has no problems. Jims Ref manual is about $5.00 and well worth the price of
admission for any laying out antennas in composite planes
Take care, happy building
Jim Wickert
Vision Vair #159
Some will have it some will not!!
>From: "Alan K. Adamson" <aadamson(at)highrf.com>
>Sent: Mar 4, 2006 12:35 PM
>To: aeroelectric-list(at)matronics.com
>Subject: RE: AeroElectric-List: Composite planes, Metallic paint, Antennae
>Alan
Jim, thanks for the post. Can I ask for some clarification? Your quote
... "It is quite well known that foil internal antennas do function well
under carbon fiber cloth." Is that correct, or should there have been a
*NOT* before "function"? Are you trying to say, they do or do not work on
carbon?
Second and a point of clarification. The Lancair actually uses an "outside
antenna". It uses a bent whip from ComAnt. But I wanted to improve the
"ground plane" only, so I added those 4 "radials" of 22" and the base plate
to provide the counterpoise and conductive attach points for the external
antenna.
I know of one other Legacy that is completed this same way and he says his
Comm antenna works very well. I'm cautiously optimistic.
But I think I'll order that $5 book just the same.
Thanks and can ya clear up the opening quote for me?
Alan
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jim
Wickert
Sent: Saturday, March 04, 2006 10:21 PM
Alan,
function well under carbon fiber cloth. they do however function very well
under glass substrate. Now with regard to paint. Per a quite an
experienced individual Jim Weir VP RST Engineering group who as published
"The Reference Text, The RST-820 Antenna which deals strictly with copper
every kind of paint and dope (including the aluminum coat used on fabric as
a UV protectant) that we could find. A couple of times in the past two
years there have been reports that there is a new German metallic paint
(sorry, I don't know the brand) that makes ALL hidden antennas (not just
ours) work poorly if at all."
he has no problems. Jims Ref manual is about $5.00 and well worth the price
of admission for any laying out antennas in composite planes
Jim Wickert
Vision Vair #159
Antennae
etc.
>Alan
>Antennae
>not interested in a ground plane, I understand that one from your
>excellent chapter in the "Connection" and used that info when
>installing my EXTERIOR antennae. My concern is the INTERIOR antennae
>buried in the upper aft sections of the Lancair IV under the fiberglass
>skin. Again this is the recommended place for com, gps, etc and has
>been used successfully by many builders for years so I am not concerned
>the fiberglass will degrade the performance of these buried antennae.
>I don't think metallic paints are used on radomes but I wonder if this
>is really a concern for my installation. thanks for giving me a
>second chance, paul
Hi Mark
You sound like you are probably well aware of this but "theoretically"
I'd expect a lot less than 3 hours at 1 amp.
www.power-sonic.com/ps-1229.pdf
These specs indicate that at a 1 amp discharge rate you shouldn't expect
more than 2 hours under ideal conditions or perhaps 1.5 hours for a cold
battery. Apologies for nit-picking.
Ken
snip
snip
Subject: | Re: Soldering question--What am I doing wrong? |
Sounds like your technique is okay but I think the iron may be a bit small.
I like about 60w to keep the heat up when it touches the board. Make sure
you're heating both the pad on the board and the LED. You don't need to
take the old solder off to re-do a solder joint.
Greg
Just finished assembling my lights.
> I'm building the Creative Air LED nav light kits, working on the LED's.
> So here's what I am doing.
> First I clean up the boards and LED leads with alcohol.
> Put them in the boards & bend the wires.
> Tin the iron. It's a 15 watt iron.
> Put the iron on the connection, then apply the solder. Bill says the
> LED's
> are heat sensitive and to only hold the iron on them a couple seconds.
> Half the time the solder doesn't penetrate the board, so I only have a
> cone
> of solder on the lead on one side of the board, the side I am soldering
> on.
> To try to fix it, I try to solder it again.
> If that doesn't work (it rarely does), I remove most of the solder using
> the iron and a clean cotton swab to absorb the solder & try again. Rarely
> works.
> Some of these I try a dozen times & still no joy.
> How can I get a good soldered joint with a cone of solder on both sides of
> the board? I have been told that that's what I need for a good
> joint. Maybe that guy was wrong?
> Richard Scott
> RV-9A
>Hi Mark
Ken
This is not nit-picking. It's considered systems integration with
understanding. We've discussed many times here on the List how
a battery's useful capacity varies with load. We've also discussed
the pitfalls of using the battery's labeled capacity without KNOWING
what loads were used to rate that capacity.
For example, batteries for bizjets are rated for specific situations
where the generators are dead and you're required to power certain
systems for 30 minutes. Since battery manufacturers are not
regulated to do anything, their ratings may be stated in any
lucid manner they choose. Most manufacturers of batteries
label their products at a 20 hour discharge rate. Here's
a recap of situations we've discussed in the past:
In this figure, we can see the published capacity vs. load
curves for a popular 33 a.h. battery from Panasonic . . .
http://www.aeroelectric.com/Pictures/Curves/LA1233_Panasonic.gif
Note that the 33 a.h. rating is met with a 1.65A discharge
after 20 hours. Increase the load to 13.2A and you'll get
just under two hours of service for a useful capacity of
23.7 a.h. A substantial drop from the label rating.
Here are curves produced here in our shop on a single 18 a.h.
SVLA battery . . .
http://www.aeroelectric.com/Pictures/Curves/1217_3n8_Discharge.pdf
Note that due to increased losses in the battery's internal impedance,
the useful capacity at 8A is 13.5 a.h. for an operating time of 1.7
hours. Useful capacity at 3 A is 16.8 a.h. for an operating time
of 5.6 hours.
Finally, here's a discharge curve for battery from Concord
for a bizjet with a label capacity of 37 a.h. . . .
http://www.aeroelectric.com/Pictures/Curves/Capacity_vs_Voltage.gif
Note that it produces 95% of rated capacity when discharged to
22v at 74A . . . this happens in 37/74 hours or 30 minutes.
If this battery were re-labeled with a 20 hour rate, the very
same battery could be called a 50+ a.h. battery.
I'm pleased that you picked up on this Ken, I missed it.
>snip
> cheap (I think about $25-30...you can Google it and get lots of hits). I
> plan to change the battery every two years to ensure that it's reasonably
> fresh. I know Klaus says 4.5 Ah but I thought that was overkill (unless
> you plan to be flying over some really rugged terrain/ocean with no
> alternates within an hour or two of flight). The 2.9 Ah batt is
> theoretically good for almost 3 hours of run time on one ignition
> (drawing ~ 1A at cruise RPM's). In the unlikely event that I ever find
> myself operating the engine soley on the backup battery, I will try to
>snip
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
Subject: | My bubble has burst . . . |
Some of you may recall that I did some studies on
energy content of the various alkaline AA cells some
time back and found that of all the brands I could
lay my hands on at the time, energy content was about
the same irrespective of price or advertising hype.
I was in Advance Auto Parts last week and they had a 24-pak
of Endurance brand alkaline AA cells for $4.88 . . . about
20 cents per cell. The best price in town. I purchased a
pack and just for grins, decided to run some on Brutus the
Battery Killer.
Tests in the past had produced data like:
http://www.aeroelectric.com/Pictures/Curves/El-Cheeso_Battery_Test.jpg
Two cells tested from my recent purchase look like this:
http://www.aeroelectric.com/Pictures/Curves/Endurance_AA.pdf
The 20-cent cell is decidedly lower in energy content. However,
in terms of cents per milliampere hour, still a reasonable deal
since the other bargain products are pushing 37 cents per cell.
I'll watch this product and buy another package in 6 months
to a year for a retest. The cells I have may have been produced
when the chef was having a bad day in the kitchen.
Subject: | Soldering question--What am I doing wrong? |
From: | "Dan Beadle" <Dan.Beadle(at)hq.inclinesoftworks.com> |
Sounds like you could use a little solder flux. . You want electronic
flux - not plumbing flux. Digikey sells water soluble flux pens that
work great. That makes the heat transfer to the PCB a lot better.
You want to heat mostly the PCB trace, especially if it is more massive
than the LED lead. Ideally, they both reach flow temperature at the
same time. The solder should flow evenly on PCB and lead with a concave
shape - not convex or bulbous.
If flux doesn't do it, get a larger iron. Radio Shack makes a
temperature controlled iron for about $70. Set it to about 600 degrees
and you get just the right amount of heat at the junction.
Dan
Greg@itmack
Sent: Sunday, March 05, 2006 1:10 AM
Subject: Re: AeroElectric-List: Soldering question--What am I doing
wrong?
small.
sure
Greg
LED's.
> LED's
> cone
soldering
> on.
using
Rarely
> works.
sides of
> Richard Scott
> RV-9A
From: | "Steve Glasgow" <willfly(at)carolina.rr.com> |
Artificial Horizon: RCA26AK-4-14V
This is an all electric Attitude Gyro that is un-lighted and has an 8 degree
panel tilt. It was completely overhauled, by Kelly MFG. CO. 1/10/2006, and
is under warranty till 01/10/07. It employs an electrically driven gyro
rotor with built-in inverter. Size: 3-3/8"x 7" Wt. 2.7 lbs. Mates with
MS3116E8-4S connector. $1,100 or best offer.
Steve Glasgow
N123SG RV-8
Cappy's Toy
704-362-0005
Bob: Thanks for the second prompt response. After considering your
recommendation for an experiment, a logical approach indeed, I am reconsidering
my
paint choices. Since I have six internal antennas in my Lancair, both in the
upper aft fuse and each wing tip and since I would like each to operate as
well as possible, I now think using any metallic coatings may be a bad idea.
Why introduce even a 20% degradation in performance if it can be avoided? So
rather than metallic, I think I will use pearl (plastic additives rather than
metallic) to achieve the desired effect. It is a bit more difficult to
apply and touch up, but it shouldn't effect nav/com reception--should it? paul
From: | "J. Mcculley" <mcculleyja(at)starpower.net> |
Also, I don't want to be a nit-picker but the legend on the graph of
your shop discharge test cited below indicates that the black line is a
17AH battery at 3 Amp discharge versus the red line being an 18AH
battery at 8 Amp discharge. Is this a typo or am I missing understanding
something? I see the 1217,3n8 notation in the web address which I assume
means a 12 volt,17AH battery?
> SVLA battery . . .
Robert L. Nuckolls, III wrote:
>>Hi Mark
> Bob . . .
Subject: | Re: My bubble has burst . . . |
Maybe you stumbled upon the reason there cheaper - inconsistent
output capacity - produced with lower tolerances, lower acceptance
levels (good bin v/s bad reject been), this all affects product cost
and shelf price.
jerb
>Battery Killer.
> Bob . . .
A real Gem, and a bit of truth
>Bob,
Good catch. I need to fix that. Both graphs were on the same
Panasonic LC-RD1217 battery . . .
http://www.aeroelectric.com/Reference_Docs/Battery/Panasonic/lc-rd1217p.pdf
The 18 a.h. reference is a typo.
>and shelf price.
Sure . . . but within certain boundaries. A blister-pack of
6-32 screws on Walgreen's hardware rack won't be made of
recycled pot metal, they won't be 3-18 stainless either.
Within narrower confines, theres only so much you can do
to a bread recipe before the product is no longer attractive
to any customer. And what savings are to be realized by manipulating
materials? Many high quality products keep prices low by eliminating
no value added activities like TV advertising, too many handlers
in the distribution loop, etc. There's rarely much to be gained
by short-changing the materials or manufacturing processes.
Over the years, we're seeing fewer products that are graded like
the old Sears catalogs that offered good, better and best.
Semiconductor companies have largely abandoned the military
parts business where they simply screened industrial grade parts
for more stringent performance limits. The market was tiny
and the labor great. Now if we want "mil-spec" parts, we
buy a bunch and screen them ourselves. It's interesting that
of the parts we do screen, fallout is very low. Usually zero.
We could save a lot of money in certificated aircraft if we
abandoned our long standing lovefest with anything mil-spec'd.
That class of product is approaching extinction because ordinary
consumers are demanding equal or BETTER parts than the
military wanted . . . and suppliers are building them.
So the interesting question to explore was just how much might
one diddle with the recipe for an alkaline battery just to
have a lower priced niche in on the shelves? I first considered
the question in an article for Sport Aviation a few years ago:
http://aeroelectric.com/articles/AA_Bat_Test.pdf
In that study, I determined that over a wide range of prices,
there was little variation in the alkaline batteries to
be sampled at the time.
I've tested a number of other house brands for folks who
sent them to me and found similar results. This new kid
on the block seems to be the exception . . . although still
a better value than a CopperTop or BunnyBattery purchased
at retail.
Just a little pothole in the life of those interested in
such things . . . I happen to suffer that affliction.
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> and Antennae |
>am reconsidering my
>the
>idea.
Whoa . . . I'm not suggesting for a moment that ANY paint you test
will produce any noticeable degradation. Odds are that it will produce
no effects you can observe. Further, if you DO conduct a test for a
particular
combination of coatings and find that it has no observable effect (or
perhaps
only barely twitches the readings) . . . that's GOOD data to share with
others.
>So rather than metallic, I think I will use pearl (plastic additives
>rather than
>it? paul
Probably won't . . . but there's no calibration on "probably". So much
of what passes for good advice is based on subjective observations.
A builder who reports great antenna performance and never talks to
stations more than 10 miles away might get similar results with a
wet string. On the other hand, a builder who is disappointed that
he can't hit an RCO out on the horizon of some leg of a favorite trip
might have an entirely different opinion on the same antenna. There's
nothing like numbers from the repeatable experiment to add real value
to one's advice.
Even if backyard experimenting is not your bag . . . risks
for using the paint you described are very low.
J. Mcculley wrote:
> Bob,
The curves look correct to me. They are a bit odd in that normally one
plots voltage against time for a given discharge rate (constant current)
but you can always divide the amp-hour scale by amps to get the hours.
what might be more interesting would be to plot the endpoints (11V or
10.5V, whatever you select for "dead") and the amp-hours delivered for
each discharge rate. That would show you how much energy is available
from your battery at different discharge rates. You could also calculate
Peukert's exponent for your battery so you can figure out its remaining
capacity even at varying discharge rates.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Is this a gelled electrolyte battery or an AGM battery? My guess from
looking at the voltage sag is that it is a gel-cell.
Subject: | Heated Pitot test |
I bought a used 12v heated pitot removed from a Piper Seminole off
of ebay claimed to be servicable and tested. I have never hooked up one of
these. It has two terminals to hook up wires. But accually has 2 wires now
soldered to one terminal and one wire soldered to the second terminal but
appears a second wire was at one time soldered to the second terminal.
The only verifiable markings are a "p" and an "s" I believe designate
which tube is the pitot and static ports. But no marking for positive or
negitive.
I will not be installing this for a while since I have a ways to go
on building my plane but wish to at least test it before storing it for
later.
Randy
Subject: | Re: Heated Pitot test |
> negitive.
> later.
Since the heating element is a resistor, there is no polarity. If it was
designed to work on either 12V or 24V there will be two elements. Use
them in series for 24V and in parallel for 12V.
And the latter is just a guess on my part.
From: | "Dennis Johnson" <pinetownd(at)volcano.net> |
Subject: | Zener Diodes and LEDs |
I'm making LED instrument floodlights and LED lights for an annunciator panel.
I expect the system voltage to vary between about 13.8 volts when the engine
and alternator are running, down to about 12.4 volts running just off a lightly
loaded battery.
When connecting the LEDs in a series string of three, the resistance required
to get the voltage to the recommended level for the LEDs at the 13.8 system voltage
is different than when the system voltage is 12.4. Although it doesn't
make a huge difference in the amount of light that comes out of the LEDs, it is
noticeable.
I'm wondering (which often gets me into trouble) if I couldn't use zener diodes
instead of resistors to solve the problem of the light output varying with system
voltage. For example, if I have an array of three LEDs, each with a Vf
of 1.7 volts, could I use a 5.1 volt zener diode instead of resistors?
I don't have any experience with zener diodes, but the catalogs make it sound like
they produce a stable voltage output when operated within their amperage limitations,
sort of like a cheap power supply. Digikey sells them for only a
little more than resistors, so cost isn't an issue. Admittedly, the varying light
output isn't a huge problem, but if it's just as easy and cheap to use zeners,
why use resistors?
Dennis Johnson
Lancair Legacy #257, wiring in (slow) progress
Subject: | Re: Zener Diodes and LEDs |
system voltage. For example, if I have an array of three LEDs, each with a Vf
Actually, that would make the problem worse. You would get a huge change
in light output with only a tiny change in voltage. Light output from an
LED is a function of the current through it and the current through an
LED is not linear with applied voltage. The resistor acts as a ballast
to make the current change more linear with voltage so that a 0.3V
change doesn't cause the LED to go from no output to full output.
What you really want to make is a constant current source. This would
make the light output independent of bus voltage.
Another way to stabilize light output is to regulate your bus voltage
down to something like 9V, using that to power your LEDs.
You can use a resistor and Zener diode to make a constant voltage source
for the LEDs as you say. This is not terribly efficient, but easy to
assemble.
You don't say what the current is that you need. Let's assume that it
is 100mA (.1A). If the system voltage is at 13.8V and you want to use
just fixed resistors, the voltage drop through the resistor would be
13.8-5.1 (target) or 8.7V. The R required would be Vd/I = R or 8.7/.1 R = 87 ohms...
So far, so good. But if the voltage in drops a bit, the same current
still gets dropped 8.7V by the R... causing the LEDs to dim a little.
You can get a constant 5.1V at the LEDs with a 5.1V Zener. Pick the
current you want and the lowest voltage you want. Let's stay with the
.1A and set the lower drop out at 10.1V for a Vd of 5V. To get a
current of .1A, you would need R to be 50 ohms. But at 13.8V, the drop
would not be enough. Zener to the rescue:
| -> LED1 -> LED2 -LED3 |
Hook up as Vin (14v) -> R ->| | ->
gnd
| -> Zener(Band-Cathode)---Zener Anode |
When the voltage goes above 10.1V, the Zener will conduct enough to
cause additional voltage drop through the R, holding the voltage at 5.1V
to the LEDs...
Finally, you have to look at the wattage for both the R and the Zener.
Continuing the example, the max drop across the R would be something
like 14.5-5.1 or 9.4V. Watts = V*V/R = 9.4v * 9.4 / 50 , so 1 Watt
would work in this example
For the Zener, the voltage drop is 5.1V, the current is the current
through the R (V/R or 9.4/50 = 188mA), less any current diverted to the
LEDs. Assuming they draw .1A, the current through the Zener would be
188-100, or 88mA. So the wattage would be V*I or 9.4*0.088 = .88W. So
use a 1W or larger Zener.
Hope this helps.
Dan
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brian
Lloyd
Sent: Sunday, March 05, 2006 4:25 PM
Subject: Re: AeroElectric-List: Zener Diodes and LEDs
zener diodes instead of resistors to solve the problem of the light
output varying with system voltage. For example, if I have an array of
three LEDs, each with a Vf of 1.7 volts, could I use a 5.1 volt zener
From: | "Richard E. Tasker" <retasker(at)optonline.net> |
Short answer.. No. Longer answer below...
Resistors limit the current through the LEDs to whatever you want (20 mA
maybe). More source voltage just means a little more current and a
little brighter LED. The extra voltage is dropped across the resistor,
not the LEDs. LEDs actually have a voltage current characteristic
similar to zeners which limit the voltage across themselves.
If you string the LEDs and a zener together, they will not emit any
light until the voltage reaches whatever minimum is required across the
LEDs and the zener - 10.2 volts in your case - and then burn out as the
voltage tries to go higher..
If what you are suggesting is to place a 5.1V zener in parallel with the
LEDs and a resistor in series with the zener and LEDs, that will sorta
work as long as you don't mind wasting some extra power. Since LEDs
have slightly different voltage drops and since this changes somewhat
with temperature and since the same happens with a zener, using a simple
circuit like you are suggesting won't really work. You would have to
use a zener nd two resistors to make something that would work and you
would be throwing away a significant amount of power, since what you
would be doing is constructing a simple shunt regulator. Basically you
would use the zener and a resistor to create a shunt regulated voltage
source and then string the LEDs and an additional resistor across the zener.
A better way to accomplish what you want to do would be to use a three
terminal regulator such as the LM317 and hook it up as a current sink in
series with the LEDs. This requires nothing more than a single resistor
and the LM317 and what happens is that the regulator operates to keep
the same current through the LEDs regardless what the external power
does - keeping the LEDs the same brightness as the voltage varies from
12.4 (or less) to 13.8. You can hook the power source to the regulator
and then the regulator to the LEDs and then to ground or you can hook
the power source to the LEDs and then to the regulator and then to
ground - make no difference as long as they are connected in series.
Download the datasheet from: http://www.national.com/pf/LM/LM317L.html
(about 1/4 down the page) and then look at the bottom of page 17 of the
datasheet for a current regulator. You do not need the pot, just a
fixed resistor works fine calculated per the accompanying formula (Vref
is 1.25V). So to get 20 mA you would use I=1.25/R, or R = 1.25/.02 or
62.5 ohms (or the closest standard resistor value).
The part is available from Digikey or Mouser or any number of other
electronics supply houses.
Or you can just use a resistor and live with the slight change in
brightness.
Any questions, ask :-) .
Dick Tasker
loaded battery.
is noticeable.
like they produce a stable voltage output when operated within their amperage
limitations, sort of like a cheap power supply. Digikey sells them for only a
light output isn't a huge problem, but if it's just as easy and cheap to use zeners,
why use resistors?
>Thanks,
>Dennis Johnson
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Better solution than mine. As you point out, the LEDs need constant
current, not constant voltage. Selecting a the zener higher voltage,
with current limiting behind it to the LEDs would work fine. But, with
less efficiency than a current regulator configuration.
Richard E. Tasker
Sent: Sunday, March 05, 2006 5:25 PM
zener.
brightness.
Dick Tasker
panel. I expect the system voltage to vary between about 13.8 volts
when the engine and alternator are running, down to about 12.4 volts
running just off a lightly loaded battery.
required to get the voltage to the recommended level for the LEDs at the
13.8 system voltage is different than when the system voltage is 12.4.
Although it doesn't make a huge difference in the amount of light that
comes out of the LEDs, it is noticeable.
sound like they produce a stable voltage output when operated within
their amperage limitations, sort of like a cheap power supply. Digikey
sells them for only a little more than resistors, so cost isn't an
issue. Admittedly, the varying light output isn't a huge problem, but
if it's just as easy and cheap to use zeners, why use resistors?
>Thanks,
>Dennis Johnson
Please Note:
however,
inconvenienced.
Subject: | Followup to Zener/LED Question |
I've already received a few excellent responses to my question about using zener
diodes to regulate power to an LED light. Thanks so much for your very thoughtful
answers. It's obvious that my understanding of LEDs is flawed. I have
a couple of basic questions to get me back on track and that will allow me to
fully understand your replies:
Assume an LED with a Vf of 2.1 volts and 20 mA rating:
1. If I hook the LED to a power supply fixed at 2.1 volts but with an unlimited
capacity to supply current, what would happen to the LED?
2. If I hook up the LED to a power supply set to 48 volts or so but with the current
limited to 20 mA, what would happen to the LED?
I have a handful of miscellaneous LEDs and I'd try the experiment myself if I had
a power supply.
It's a great day when I can learn something new, particularly if it's useful!
Dennis Johnson
Lancair Legacy --- currently revising my instrument panel LED lighting plan
Basically, you want a current limiter in the circuit. That is what the
resistor does. So your 48V/20ma example probably work (depending upon
the current spec of the LED). But if you hook to 2.1V supply, you may
get no output if the Vf is > 2.1V (high tolerance) or high current,
light, and maybe the magic smoke, if the Vf is < 2.1V
Dennis Johnson
Sent: Sunday, March 05, 2006 6:31 PM
Subject: AeroElectric-List: Followup to Zener/LED Question
using zener diodes to regulate power to an LED light. Thanks so much
for your very thoughtful answers. It's obvious that my understanding of
LEDs is flawed. I have a couple of basic questions to get me back on
track and that will allow me to fully understand your replies:
unlimited capacity to supply current, what would happen to the LED?
with the current limited to 20 mA, what would happen to the LED?
if I had a power supply.
useful!
Dennis Johnson
plan
Subject: | Re: Followup to Zener/LED Question |
Well, it depends on whether the power supply is exactly the 2.1 volts of
the zener Vf. If it is exactly the 2.1 volts then the zener will light
up with the 20 mA brightness. If it is a little higher (2.2V) it will
light up much brighter since it will draw much more current. A little
higher still and - Toast!
If you plot voltage on the X axis and current on the Y axis, a resistor
would be a straight line pointing up and to the right. A zener would be
"L" shaped with a little bit of rounding at the apex of the "L"- very
little current until it reaches the zener voltage and then the current
would rise very fast for just a little more voltage. An LED is similar
except the apex is a little more rounded than the zener. Zeners and
LEDs MUST have something to limit the current or they will overheat and
die when the voltage rises a little above the Vf or zener voltage.
It would light to whatever brightness that 20 mA creates. If you use a
resistor, the brightness would change if you varied the 48 volts. If
you used an active current limiter such as I described earlier, the
brightness would stay constant. If you plotted the active limiter as
above, you would get a straight horizontal line from about 3V to 38V
(the maximum voltage limit of the LM317). Below 3V or so you would get
essentially no current.
The only drawback to the active current limiter is that it doesn't allow
the LED to change brightness if you wanted to dim it with a normal
dimmer. You have to use one of the digital dimmers (pulse width
controlled) to dim it.
had a power supply.
>Thanks,
>Dennis Johnson
Please Note:
Ooops! Actually, in my previous post it would be a backwards "L" shape.
had a power supply.
>Thanks,
>Dennis Johnson
Please Note:
Randy,
There are two heating elements in the Piper style heated pitot
tube. One is a 70 watt unit, the other is 100 watts. I've seen the
wires of both heating elements crimped together before. Cut the wires
apart, so that you can insure that BOTH elements work. Check for
continuity between both wires of each element. I believe my pitot
elements ohm out at about 3 ohms. An infinite reading will be that
the element being tested is bad.
Connect each elements 2 wires to a 12 volt battery (check one
element at a time) using 16 or 14 AWG wire. The Pitot should start to
warm up in your hand within 30 to 60 seconds. Do not apply power for
a period of time longer than is needed to verify that each element works.
If you have a bad element, they can be replaced. A number of
outfits will charge you a hefty price for these parts. RV-9A builder
Peter Laurence tracked down the "source" for these units. They are
available for a reasonable price from HotWatt. See Peter's email to
me below for more info.
Charlie Kuss
Charlie,
Here is the info. Heaters are made by
Hotwatt Http://www.hotwatt.com/cartridg.htm
Hotwatt part #s
For Pitot: 13A7025 70 W 12V
Static 13A7026 100W 14V
Piper part #s
464-356 for the 70W 12V
464-357 for the 100W 14V
These are called cartridge heaters. They are 3"X 3/16" and 4"X 3/16"
Check the ceramic plug where the wire enters the cartridge. If
there's any movement of the wire, it should be replaced.
Peter Laurence
>negitive.
>later.
>Randy
Gel cells are almost non-existent in the wild. If you have a real
gel-cell it will probably say so in the literature and even on the
side of the battery. Gels are a modified flooded battery where
enough jello like stuff was added to make the normally liquid
stuff stay in place when the battery was inverted.
Globe Union were biggies in Gels about 25 years ago, Sonnenschein
makes them in Europe. The first spill proof battery B&C sold was
the Gates energy jelly-roll cells which were a true AGM, SVLA,
RG, Immmobilized Electrolyte, starved electrolyte battery . . . but
not a gel-cell. When the Gates product proved unworthy of flight
in aircraft, B&C switched to the Sonnenschein gels for a time but
those were replaced by the Genesis series (all the above types)
and ultimately STD'd onto a bunch of airplanes.
Gel-cells are popular for deep cycle applications like electric
wheelchairs. They seem to perform better than their dryer
cousins. I think B&C still has one gel-cell offering. Some folks
like Delmar Benjamin swear by them and he Bill aims to please.
The vast majority of lead-acid products are of the SVLA/RG
variety and you have to go out of your way to find a gel-cell.
Unfortunately, most of the storefronts who stock these modern
marvels refer to them as gel-cells and help perpetuate a huge
mis-information.
From: | "Malcolm Thomson" <mthomson(at)showmeproductions.com> |
Looks like this is what you need. See
http://www.periheliondesign.com/Vregflyer.htm
Malcolm.
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis
Johnson
Sent: Sunday, March 05, 2006 4:49 PM
Subject: AeroElectric-List: Zener Diodes and LEDs
panel. I expect the system voltage to vary between about 13.8 volts when
the engine and alternator are running, down to about 12.4 volts running just
Although it doesn't make a huge difference in the amount of light that comes
diodes instead of resistors to solve the problem of the light output
varying with system voltage. For example, if I have an array of three LEDs,
each with a Vf of 1.7 volts, could I use a 5.1 volt zener diode instead of
resistors?
sound like they produce a stable voltage output when operated within their
amperage limitations, sort of like a cheap power supply. Digikey sells them
for only a little more than resistors, so cost isn't an issue. Admittedly,
the varying light output isn't a huge problem, but if it's just as easy and
Dennis Johnson
Gel-cells are rather common in the boating community. They are clearly
delineated as such.
No argument there.
I happen to like gels myself as their acceptable absorption charge
voltage range overlaps with the acceptable float charge voltage range.
You can get away with a single-voltage charging system (like an
aircraft's alternator).
Also, gels seem to tolerate extended partial discharge better than AGMs.
This makes them more attractive in power systems where the battery does
not get completely recharged every time.
But their higher internal resistance makes them poor starting batteries
unless they are oversized for the task.
Gel-cells are RG (recombinant gas) batteries also. I am not familiar
with the term SVLA tho.
RG - recombinant gas
VRLA - valve-regulated lead-acid
AGM - absorbed glass-mat
GELA - gelled-electrolyte lead-acid
BTW, VRLA or RG can refer to *either* GELA or AGM batteries.
I am attaching a really good treatise on VRLA batteries from Deka-Penn.
Clearly they are trying to sell their own product and it is a bit
simplistic in some areas but their stuff on charging and discharging is
really good. The best thing about it is that it addresses the
differences in operation of GELA and AGM batteries.
I disagree. I have no trouble finding gel-cells and use them where I
think they will perform better. They have higher internal resistance
than do AGMs but they are less prone to failure on overcharge than are
AGMs. They also tolerate partial or complete discharge better than AGMs.
> mis-information.
Bob, I know the difference. I read the manufacturer's literature so I
know what I am buying. I don't trust what stores tell me because,
frankly, I usually know more about the topic than does the store. GELA
batteries are common enough that I would not pretend to know what is
inside the case unless the lit clearly states one way or another.
>J. Mcculley wrote:
> > Bob,
Yeah . . . I've had some conversation with the folks at WestMountainRadio
about this. Obviously, the ampere-hour is NOT a measure of energy. When
I purchased my first battery tester from them, I suggested some enhancements
for the next release of their software. We engineers would really like to
see constant wattage and constant resistance discharge functions in addition
to the standard constant current function. Then too, as you've noted, a
volts vs. time and energy vs. time plots would be more meaningful along
with an box on the graph that displayed watt-seconds of energy at the
endpoint.
He seemed receptive. I'll write again and see where that might set on his
stove's burners.
I'd REALLY like to recommend his tool to others in the battery business
but most would like some features besides the arcane and poorly-descriptive
ampere-hour display. He's 100% of the way there with hardware, what he
needs now is a really cool GUI.
But it is easily converted into energy (amp-hours x volts = watt-hours)
and it more readily conforms to how a battery works. Good batteries tend
to have very high coulombic efficiency (one coulomb removed requires one
coulomb to be replaced). I am used to batteries with coulombic
efficiencies on the order of 97%. The energy loss in a battery is a
function of the voltages involved, i.e. you need a higher voltage to
push the coulombs back into the battery than you get when taking them out.
(For those of you wondering what I am talking about, a coulomb is the
measure of a pot full of electrons. An amp is one coulomb of electrons
flowing through a wire in one second. Think of the cell of a battery as
a tank full of coulombs of electrons.)
> When
> endpoint.
> stove's burners.
Well, then let's build our own. Not hard to do. It is just some simple
hardware and then SMOP (small matter of programming).
Hardware consists of a load bank made up of a bunch of paralleled
MOSFETs driven from a D:A converter. (Use MOSFETs because they won't
current hog.) The battery voltage and current is measured by an A:D
converter. The software looks at these values and controls the load bank
to make it do what you want it to do.
Well, the hardware is the easy part. :-) I would like to see his tester.
You know, with the requirement for testing of batteries in certified
aircraft, you would think there would be a market for a good, cheap
battery tester.
From: | Ernest Christley <echristley(at)nc.rr.com> |
Subject: | bursting bubbles |
>From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
>Subject: AeroElectric-List: My bubble has burst . . .
Bob, could you make a note of the date of manufacture that should be
stamped on each battery when you do these test. It is my suspicion that
you will find more correlation between capacity and DOM than capacity
and cost.
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o www.ernest.isa-geek.org |
Subject: | Composite planes, Metallic paint, Antennae |
Alan,
Sorry fat fingers "DO Not" they are quite functional under glass and kelvar but
not Carbon Fiber. Take care.
Jim Wickert
Vision Vair #159
>Sent: Mar 4, 2006 10:08 PM
>carbon?
>antenna.
>Alan
>Wickert
>Alan,
>Jim Wickert
>Vision Vair #159
>Antennae
>etc.
>>Alan
>>Antennae
>>second chance, paul
Subject: | Re: bursting bubbles |
>and cost.
Excellent point. I know that a famous battery manufacturer
has suffered a number of manufacturing runs where the chef
was having a bad day. This could well be the same phenomenon.
This batch of batteries are marked "best if used by Dec 2012".
I suspect they were manufactured in Dec of 2005. I'll make
SURE the next package I buy is a different date.
Thanks for the suggestion.
Subject: | Power reqmts - buss evaluation? |
All,
I'm looking for a little help. I've got a panel design conceptualized, as a
result I need to verify the most optimal buss, switch breaker, breaker and
fuse counts.
http://www.highrf.com/Rockets/Panel%20Final.jpg - Panel layout
I've been using a spreadsheet that includes all the information including
some tables that show busses and what's on each buss. I'm primarily focused
on pull breakers, but all the detail are there for switch breakers and
fuses.
http://www.highrf.com/Rockets/Breaker%20Counts.xls - spreadsheet
This is a dual alt/batt 24v system with a 60 or 100amp main alt, and an
SD-20 as backup. It will be using a slightly modified Z14 (modified because
there is an avionics master on the primary buss.
Please let me know if you see any "gaping" holes in my thot process. The
airplane uses a Chelton dual screen EFIS with electric instrument backup.
There is no vacuum system.
Thanks for your time and any help is appreciated.
Alan
From: | Tim & Diane Shankland <tshank(at)core.com> |
Yes you can use zeners but you need resistors also. What you want to do
is to provide a stable voltage to drive the LED's so that the intensity
does not change with the battery voltage. Using the example of three
LED's each with a 1.7 volt drop connected in series with a desired
current of 20 mA. With the three LED's connected in series and the
cathode of the end one connected to ground connect the anode of the
other end of the string to a 45 ohm resistor. Connect that resistor to a
320 ohm resistor, connect that resistor to battery voltage. Connect a 6
volt zener diode cathode to the junction of the two resistors. Connect
the other end of the zener diode to ground. By the way I didn't check to
see if these values are exactly available this is just an example. When
operated at the minimum voltage of 12.4 volts at 20 mA the voltage drop
across the 320 ohm resistor will be 6.4 volts leaving 6 volts across the
zener diode which will not conduct. Now when operated the total voltage
drop across the three LED's will be 5.1 volt leaving 0.9.volts across
the 45 ohm resistor thus the current will be 20 mA. When the battery
voltage rises to 13.8 volts the zener will conduct current causing an
increased voltage drop across the 320 ohm resistor to maintain the
voltage across it at 6 volts and the LED's will have a stable current
source.
Tim Shankland
>Malcolm.
>Johnson
>resistors?
>Thanks,
>Dennis Johnson
Subject: | Attn: Collin von Ahlefeldt |
Tuesday, March 7, 2006
Collin,
Don't know if you subscribe to the List but on the odd chance
that you'll spot this . . .
I tried to respond to your direct inquiry but the e-mail bounced.
Perhaps a typo?
Comments/Questions: I am building an RV 6 with elevator trim in the 2 stick
grips. I have the coolie hat supplied by Van's and the 8A Mac servo but did
not buy the relay deck as i didnt know i would need it. Can i use your
drawing "Pitch trim" 8-20-00 and use four relays, one set(2) per coolie hat
or can i simply wire the coolie hats in parallel. What would happen if one
pilot would push down and the other one up on the coolie hat? What 12 volt
relay can i buy that would not vibrate in flight and accidently activate
the trim motor? Do you think i need a speed control for the elevator?
You can wire the switches in parallel. Simultaneous conflicting
commands will result in the motor simply stopping. No smoke,
no popped fuses, etc.
( Experience and common sense cannot be )
( replaced with policy and procedures. )
( R. L. Nuckolls III )
Subject: | Coolie hat as pointing device |
Hi Bob and Group,
On my Stag-Ez I've mounted a tablet PC to show moving maps in sectional
format (OziExplorer programs).
Although my tablet has got a sensitive display, I would need an easily
operable pointing device other than a mouse which is cumbersome to use in
the cockpit.
To this end, I thought I maybe could use the coolie hat and two buttons
(Infinity type) I've got on my stick grip: has someone already studied this
possibility and come up with some solution?
Thank you.
Gianni Zuliani
Tel/Fax +41 91 9710850
Mobile +41 79 3373439
Long-Ez >> Stag-Ez >> Stag-EzR
http://www.comgz.com/tristar.htm
From: | "Dave Morris \"BigD\"" <BigD(at)DaveMorris.com> |
Subject: | Re: Coolie hat as pointing device |
Doesn't your tablet PC have a touch screen? When you turn on your radios,
do you get noise from the tablet PC? See www.MyGlassCockpit.com for
something similar to what you're doing. I have not licked the RFI problem yet.
Dave Morris
At 02:33 AM 3/8/2006, you wrote:
>Hi Bob and Group,
>the cockpit.
>Thank you.
>Gianni Zuliani
Here's some ideas:
http://www.littlepc.com/keyboards_pointing.htm
Pax,
Ed Holyoke
-----Original Message-----
Gianni Zuliani
Sent: Wednesday, March 08, 2006 12:33 AM
Subject: AeroElectric-List: Coolie hat as pointing device
Hi Bob and Group,
in
the cockpit.
this
Thank you.
Gianni Zuliani
Go to Comp USA and pickup a flat panel pointing device. We did this on
one of our Lancair's with a tablet PC and it worked very well.
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed
Holyoke
Sent: Wednesday, March 08, 2006 8:30 AM
Subject: RE: AeroElectric-List: Coolie hat as pointing device
Here's some ideas:
Pax,
Ed Holyoke
Gianni Zuliani
Hi Bob and Group,
in
the cockpit.
this
Thank you.
Gianni Zuliani
1/16/2006
1/16/2006
Subject: | Heads-up on a double sided adhesive product |
I'm building some test fixtures for RAC with lots of lights
and switches on the front. I like to lay out placards in AutoCAD,
print to paper (sometimes colored) and then hot laminate.
I've used contact cements for years with good results to attach
the placards but I ran across a rather amazing product yesterday
that may surpass contact cements and/or other forms of double
sided adhesive:
Hobby Lobby stocks a stuff called SUPER TACKY Thermoweb. You can
find it on E-bay using that search term.
I was putting placard down on a panel yesterday and accidently
allowed the placard to settle poorly positioned onto the panel.
Past experiences with this were no big deal, peel it up and
reposition. This stuff grabbed on so hard that I wrinkled
the placard trying to get it off.
Also, this adhesive is advertised as a thermoset. It may
be just the ticket for mounting placards to various places
in an airplane. If anyone has a chance to try it on one or
more situations, I'd be pleased to know of your experiences
with it.
I'm stocking it here in the shop and will report any down-sides
I discover. I may also do an under-the hood test. I have some
blocks of steel that I use to test adhesives in real life.
I glue them to the underside of the hood of my van. If they
stay put for over a year, I call 'em good for flight
too.
Gianni Zuliani a crit :
>Hi Bob and Group,
>the cockpit.
Gianni,
Just wondering, my Dell Latitude laptop has one such little "micro
joystick" between the keys in the middle of my keyboard. Don't use it
much, but this may be what you're looking for.
The day you drop your laptop, just cannibalize it..;-)
FWIW,
Gilles Thesee
Grenoble, France
http://contrails.free.fr
Subject: | Re: Heads-up on a double sided adhesive product |
too.
And if they come loose, the drivers behind you have an interesting time...?
Good hint. I'll check this product out. I just used a combo of Scotch double-sided
foam tape and a perimeter fillet of GOOP to mount Bosch-style ice cube relays
to aluminum plate. The bond seems quite sturdy, but it took overnight to
achieve.
-Bill B.
From: Robert L. Nuckolls, III <nuckollsr(at)cox.net>
Subject: AeroElectric-List: Heads-up on a double sided adhesive product
sided adhesive:
with it.
too.
From: | Mickey Coggins <mick-matronics(at)rv8.ch> |
Subject: | Re: Continuous duty contactor wiring question |
> Remember folks, questions like this are ALWAYS
> best addressed to the designer/manufacturer
> of the product. ...
You are right. I was thinking of the product as
the contactor, and Eric's product as a switch.
In any case, Eric has a nifty product to protect
the coils from doing whatever bad thing it is
that they do. He calls them "snapjacks", and
they do the trick.
http://www.periheliondesign.com/suppressors.htm
Just an aside - I *really* like doing business
with Eric. He makes it easy to buy his stuff
(paypal, logical website) and gives me no hassle
about shipping international via USPS. Stuff
usually arrives three to five days after ordering.
Not to mention that he has some cool products!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> product |
>too.
> Bob . . .
No, there's a tether on the block to keep it from falling out.
>double-sided foam tape and a perimeter fillet of GOOP to mount Bosch-style
>ice cube relays to aluminum plate. The bond seems quite sturdy, but it
>took overnight to achieve.
The GOOP/Sho-Goo/E-6000 products are pretty robust but
as you've noted, they're a solvent based adhesive that takes
TIME to reach full strength. If you're mounting something as
light as a relay, a simple spot of E-6000 will do it. I've
tested this. We also used the E-6000 to attach bond studs.
http://www.aeroelectric.com/Pictures/Products/Bond_Stud_A.jpg
The stud shown was installed with JB Weld. It pass the pull
tests fine. E-6000 worked too and was easier to use.
I'm working on a new source for bond studs. I'll try this
thermoset adhesive on them when I get the samples.
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> question |
> > of the product. ...
>that they do.
In this case, systems integration issues go
beyond the magnetic field collapse in the
coils. Folks here on the list have raised
legitimate issues with respect to the contactor's
ability to reliably open a runaway alternator's
output. This has almost nothing to do with
the coil circuit and everything to do with
contact spreading velocity and ultimate gap
(or double gap) distance in the open contactor.
If Eric or anyone else has called out this
class of contactor as suited to the task when
combined with his product, then other folks
here on the list are ill prepared to dispute
it without an exchange of simple ideas that
support (or fail to support) the manufacturer's
design decision.
Therefore questions going to suitability
to task must to start with folks who
offer the product. If the simple-ideas
don't assemble correctly, others with knowledge
and experience can illuminate the errors
of logic.
Until I'm apprised differently, I can only
say that based on objections raised earlier
(for which we've seen no test data to the
contrary) I am skeptical of this contactor's
ability to handle the task (Note 1). I'd be delighted
to have that skepticism put to rest but
I'm not presently in a position do it myself.
Note 1. The "task" is to make/break the b-lead
of an alternator under a variety of conditions
the most important of which is OV management.
If the contactor is expected to be damaged in
an OV management event, so be it as long as the
event is handled to the benefit of the rest of
the airplane's systems. There are less stressful
make-break issues too. I would expect anyone who
recommends a device for this service to be capable
of articulating the capabilities and LIMITS of the
system.
From: | "John Schroeder" <jschroeder(at)perigee.net> |
Bob -
You have no idea how useful those studs are/were for our wiring. We used
E-6000 and the worked like a charm. Still could use a dozen of them to
replace the nylon-zip tie kind. We shaved off the double sided tape on the
nylon kind and used E-6000, but they are not as robust as the studs. Let
the list know when you get the studs.
John Schroeder
Lancair ES - Painting complete
> Bob . . .
Re pointing device, How about a Logitech Track ball, USB plug one hand
operation.
Thumb moves the ball, index finger left click or wheel, and middle finger
right click .
I gave up on the notebook touch pad, and this goes where the notebook
goes...wouldn't be without it
Harold
Out of curiosity, would a large capacitor across the contactor similar
to points ignition help? Or is there too much energy involved for a
reasonably sized capacitor to absorb?
Andrew Rowley
ajrow(at)westnet.com.au
We use trackballs on our airborne instruments. Other pointing devices
are hard to use in turbulent air. Touch pads are nearly impossible to
use in rough air.
Here is a picture of the instrument that I built a couple of years ago
on the NOAA WP3 Hurricane Hunter:
http://www.al.noaa.gov/2004/photos/P3/13.jpg
Notice the tiny track ball in the corner of the laptop tray. You "left
click" by pulling the trigger button with your index finger. It is quite
comfortable to work the ball with your thumb. Easy to use in rough air
as your thumb moves with your hand and the whole mouse moves with your
hand too.
Here is a link to the exact "finger" trackball:
http://www.sfcable.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=MS4-USB
I've seen them for sale at Walmart, but I couldn't find them on their
website.
I bet you could mount one on top of your control stick. (Be sure to buy
a spare. They are not ultra high quality.) We held ours in place with
Velcro. You can see how your hand could grip the stick while working the
trackball by looking at the picture in the advertisement. Just photoshop
a control stick in. :*)
Bill Dube'
>operation.
>right click .
>Harold
Excellent question! and I would bet that the answer is "yes". It
would function in very much the same manor as the ignition points
you cited and as arc-suppression duties as I discussed in the
'Connection in the OV Protection chapter and as shown across the
relay contacts on page 3 of:
http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf
It could be calculated if the system characteristics were
accurately known . . . or crafted by empirically during
bench tests.
From: | "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> |
>Bob -
I will. I've been besieged with requests and I've bugged the
junk dealer that supplied them until he's no long happy to
see me walk in the door. I owe him a 5th of his favorite.
In any case, I had dinner with some folks from Amphenol's
skunk works a couple of weeks ago. They're helping me with
a really small but super rugged wire and fiber optics combo
connector.
During the course of our discussions, I mentioned the bond studs
and we scratched on the back of a napkin for awhile. I think we've
got a reasonable design that won't break the bank for tooling or
minimum quantities . . . but I'll still have to buy 10-20 thousand
at a whack.
Hope to hear back from them soon. And you can bet that once I
have a bushel basket full of them on the shelf, I'm a sure
bet to make that fact known!
We have a CNC bar feed lathe.
It could make those fairly easily. We keep the machine pretty busy,
but we might be able to make those in a graveyard shift.
Any idea what the price point might be?
Regards, George
Sent: Wednesday, March 08, 2006 8:35 PM
Subject: AeroElectric-List: Re: Heads-up on a double sided adhesive
product
>Bob -
used
the
Let
connector.
at a whack.
Morning, Bill...
>>Here is a link to the exact "finger" trackball:<<
Now THAT'S a great little accessory! Can even use that here at the desktop!
Did a little search, and found it is offered on several websites for as
little as $11.95 and as much as $24.95 (its MSRP).
Also found a couple of WIRELESS finger trackball (logitech makes one)
for a bit more ($30-50)...that sounds like a possibility as well.
Also found this unique little unit...a wireless, rechargeable, RF finger
trackball! Not sure what's in the handle (probably batteries) but it
sure looks like the control stick might fit up inside it (at least mine,
which is still the plans called Long EZ version)...maybe replace the
batteries with a hard wired modification with the wires through the
stick? Make a neat looking control stick. Almost Thrustmaster style.
www.geeks.com/details.asp?invtid=FDM-B4D-RF&cat=MOU&cpc=MAC
Think I'll take a trip around the local stores this morning and see
what's available here (we have ALL the big stores here in Henrietta
within a mile or so of each other...Wal-Mart, Sam's, BJ's, Target, Best
Buy, CompUSA, Circuit City, Radio Shack, Sears, Wegman's , etc, etc.)
February 27, 2006 - March 09, 2006
AeroElectric-Archive.digest.vol-fm
