AeroElectric-Archive.digest.vol-jr
August 20, 2010 - September 03, 2010
       own personal contacts in the FSDO, or you may be able to find a FAAST te
      am rep who can go to bat for you with the FSDO. Wearing both Tech Counsel
      or and FAAST hats I can talk to my FAAST FAA rep, who has an office in th
      e local FSDO, but works for the regional FSDO. He has the experience and
      contacts on the inside to at least get answers, and if they aren't satisf
      actory, then you can bring in the big guns. But it often does work to sol
      ve things at the lowest possible level, before people get their heels dug
       in defending their position. Especially when a colleague can gently say
      to the inspector, you know that memo was rescinded last year, maybe while
       you were on vacation. That way everyone saves face.
      >> Kelly
      >> On 8/19/2010 7:29 AM, Steve wrote:
      >>> -->  AeroElectric-List message posted by: Steve Thomas
      >>> Let me offer an alternative view.  I just recently had my project cer
      tificated, working through the Van Nuys FSDO.  The folks in the Van Nuys
      office held up my certification for months, having pulled out of the arch
      ives a memo restricting flights of experimentals from my home airport.  T
      he memo had long since been cancelled, but when I applied for my certific
      ation through my DAR, they simply responded with a "No."  They did not of
      fer any alternatives, just ,"No".  They actually told my DAR that I could
       appeal the decision, but the chances for a different outcome was nil.  I
       had to engage the National EAA for help, and two months later, the FSDO
      finally relented.
      >>> Further, the FSDO refused to issue a repairman certificate until I ha
      d completed my 40 hour flight test period, for which they had no authorit
      y at all.
      >>> My experience indicates that the FSDO is not your friend.  Your milea
      ge may vary.
Date: Aug 20, 2010
Subject: Re: Vertex VXA700 information needed
At 05:19 AM 8/20/2010, you wrote: >Hi Bob >If the higher resolution is still unacceptable, let me know and I >can e-mail you an even higher resolution photo. >Ron Parigoris I can get what I need from the photos. Thanks! Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Aug 20, 2010
Subject: Searching for Mr. GoodTool
>I want to order replacement tips for the Amp 91285-1 tool but am >confused on the ones to order. I believe I should order the YELLOW, >RED and BROWN tips for normal density 20AWG machined (crimped) D-Sub pins. > >http://www.aeroelectric.com/Mfgr_Data/Connectors/AMP_Tyco/91285-1_Extraction_Tool.pdf It's less expensive to order the whole new tool which DigiKey offers for $12.15 See: http://tinyurl.com/2cy6sky Unless you're ordering LOTS of replacement blades for a production effort, you'll find that single quantities of the three blades costs you about 3x more than the whole new tool. >What is the POSTED tip (BLUE and BLACK tip)? Is for the wire-wrap/ECB-SolderIn type pins illustrated in figures 5 and 6 of the instructions for use of the tool. Bob . . . ________________________________________________________________________________
Date: Aug 20, 2010
Subject: Re: OT starting build
> >By the way, my airworthiness inspector was so clueless that I had to >point him to the FAA website for the correct wording for the oplims >and pretty much had to write them myself for their approval. I could tell you story about my experience with a FSDO in NJ while trying to assist a Twin Comanche owner install a Z-14 architecture while making the airplane about 40 pounds lighter. Then there's the saga Alaskan L-40 Fiasco of some years back . . . http://www.aeroelectric.com/Reference_Docs/FAA/Alaskan_L-40_Fiasco/ I've observed no signs that things are getting any better. Over 40+ years observation of FAA transactions in the TC aircraft world, the expense of getting a repair, a product improvement or a new idea to market becomes more costly every year. If the practices of 1980, 1990, or 2000 were demonstrated to be higher risk ("Go forth young man and make aviation SAFER"), then perhaps growth of the certification mountain would be understandable and justified. But out of tens of thousands of devices of my design produced by my employers over the last 40 years, I'll bet not one has failed in a manner that caused loss of an airframe or life. Further, had today's cert standards been applied to those products, its a sure bet that the numbers of such devices still in service would be no greater than it has proven to be without such standards. Such are the virtues of failure tolerant design. I further observe that folks in charge of making decisions on behalf the FAA are increasingly ignorant of the technology, processes and hazard assessment over which they preside. Present trends plotted into the future do not bode well when experience and common sense are replaced by policy and procedure. Bob . . . ________________________________________________________________________________
Subject: Audio Panel hookup
Date: Aug 20, 2010
I've seen this referenced on one other forum, but no responses, so I figured I'd try it here. I've got an SL30 and SL40 that I'm trying to wire to a PSE 8000/9000 type audio panel. The radio's each have the following Mic Mic lo Phone Phone lo tx key The audio panel however only has Mic Phone Com lo tx key Basically there is only one ground or lo for the radio on each at the audio panel. So do you use it to connect both the mic lo *and* the phone lo? Secondly, if connecting multiple unswitched outputs that all have their own output adjustment levels, do you still need to connect a 100ohm, 1/2w resistor in series with their output at the audio panel? Thanks in advance, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309557#309557 ________________________________________________________________________________
Date: Aug 20, 2010
Subject: Re: Plane Power IR Alternator Implementation in Z-13/8
At 10:27 AM 8/20/2010, you wrote: I'm thinking about using one of these as the belt driven alternator in Z-13/8: http://www.plane-power.com/AL12-EI60.htm It's their experimental, internally regulated alternator that also comes with built in crowbar over voltage protection. I'm not sure that I have a full understanding of the OV protection and control issues of IR alternators and how they pertain to this unit. I have 3 primary questions- one for the AEC and two for Plane Power, though I welcome any insight about all three from the AEC readers. So first, is it correct to say that Z24, Z24A, and the associated text on page Z-5 apply to IR alternators as they come off of the auto parts shelf, and not really to this unit? Correct . . . The P-P devices are not off-the-shelf automotive. Based on their conceptual wiring picture here: http://www.plane-power.com/images/AL12_EI60%20Installation.pdf Primary Question 1: How would I make the wiring connections in Z13/8 with this unit? Should their field enable lead go to the 2-3 DC Power Master Switch with the 5A crowbar in the same place as Z13/8 depicts it? Also, what about that other optional alternator off lead (see 3 below)? I think I understand that the battery dump issue (described at http://www.aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf) is a problem in Z13/8 because we would like to occasionally (preflight, first flight of the day, etc?) turn the primary alternator and master off, and turn the ebus alternate feed on to test those associated switching systems. Is that correct? No. "Battery Dump" is defined as the sudden reduction of heavy alternator loads wherein the major portion of that load included battery recharge current and it's the BATTERY that's being disconnected. There are no operational procedures that call for such a "test". Further, the way the Z-figures are drawn, such a test could not be conducted for the battery is always disconnected AFTER the alternator is shut down. Primary Question 2: Will it do any physical damage to anything to turn off the 2-3 DC Power Master Switch while the engine is running (assuming that I need to)? It has been a legacy design goal for all TC aircraft to configure the system such that an alternator (or generator) may be turned on or off at any time under any conditions without hazard to other components in the system. An alternator that is controlled by breaking the field lead without breaking the b-lead MEETS this design goal. So, no . . . the P-P alternator may be turned on or off at anytime without concern for hazard to any compoent. Primary Question 3: Does opening their Alternator Field Enable Switch fully shut down the alternator field? Yes If the crowbar protection circuit pops that 5A CB, I should hope that opening that switch "switch"??? Do you mean "breaker"? Yes, opening that breaker offers a quiet, orderly and benign disabling of the alternator. . . . would completely shut down the alternator field too. If so, then what does that other "optional alternator off" lead do? That's not a control, it's an indicator light which has some limited ability to annunciate alternator failure and has been used in cars for decades. However, active notification of low voltage by an independent sensing system is the legacy approach to watching for and announcing alternator failure. Would I need to hook it up at all, and/or would I need to still hook it up with a switch in the line? Is there a failure mode in the other circuit that would require me to turn off a switch in the second line to shut the alternator off? You can drop the P-P product directly into any of the z-figures by simply eliminating any illustrated external regulators and/or crowbar ov protection modules. I was going to call plane power to ask them a few of these questions but I need to make sure that I know what to ask about. Thanks in advance. I've discussed Plane-Power design philosophy with them at length. It's a certainty that their answers will be along the same lines as that which I've offered above. Bob . . . ________________________________________________________________________________
Date: Aug 20, 2010
Subject: Battery cables and Firewall Penetrations
At 11:58 PM 8/19/2010, you wrote: That particular Terminal Feed Through Connector is only rated 250A @48VDC. You would probably be better served purchasing the 400A @48VDC version from Blue Sea Systems. http://bluesea.com/products/2206 They also carry both Black and Red and they are identical to the ones on Ebay except in a larger amperage rating and slightly larger physical size. I wouldn't be surprised if they were cheaper from Blue Sky either. $11/each seems kinda pricey to me. Emacs! But are price, voltage and current ratings the only features of concern? You're going to poke a substantial hole in a "firewall" that's ostensibly configured to keep products of a fuel-fed fire out of the cockpit. Then you propose to plug that hole with some form of plastic. Here's a trip to the assembly line of one manufacturer that has spent several decades of time, talent and resources developing techniques for bringing stuff through the fire wall but without compromising fire wall integrity. http://www.aeroelectric.com/articles/Firewall_Penetration/firewall.html I'll further quote from AC43-13 which is one of many documents where we are admonished to be aware of the flame retarding characteristics of devices that penetrate the firewall: 11-232. TYPES OF CONNECTORS. Connectors must be identified by an original identification number derived from MIL Specification (MS) or OAM specification. Figure 11-35 provides some examples of MS connector types. Several different types are shown in figures 11-36 and 11-37. a. Environmental Classes. Environment- resistant connectors are used in applications where they will probably be subjected to fluids, vibration, thermal, mechanical shock, corrosive elements, etc. Firewall class connectors incorporating these same features should, in addition, be able to prevent the penetration of the fire through the aircraft firewall connector opening and continue to function without failure for a specified period of time when exposed to fire. So unless you're changing the name of of your firewall to "engine compartment aft bulkhead", I'll suggest there is value in attending to maintenance of firewall integrity. Bob . . . ________________________________________________________________________________
Subject: Re: Audio Panel hookup
Date: Aug 20, 2010
Answered my first question and for those that might need to know. Yes, on the radios to audio panel, you connect the to "lo"'s together and then to the phone low on the audio panel. As for the unswitched audio's.... I'm still checking on that one. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309562#309562 ________________________________________________________________________________
Date: Aug 20, 2010
Ooops! You are absolutely correct. I misread what he was asking for and thought he meant the aft bulkhead and not the engine firewall. But, before I would discount the use of the connectors that had been previously mentioned I would still contact the manufacturer and inquire as to the serviceability of that particular connector. You might find that it actually fits the bill perfectly. Jim _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, August 20, 2010 3:29 PM Subject: AeroElectric-List: Battery cables and Firewall Penetrations At 11:58 PM 8/19/2010, you wrote: That particular Terminal Feed Through Connector is only rated 250A @48VDC. You would probably be better served purchasing the 400A @48VDC version from Blue Sea Systems. http://bluesea.com/products/2206 They also carry both Black and Red and they are identical to the ones on Ebay except in a larger amperage rating and slightly larger physical size. I wouldn=12t be surprised if they were cheaper from Blue Sky either. $11/each seems kinda pricey to me. Emacs! But are price, voltage and current ratings the only features of concern? You're going to poke a substantial hole in a "firewall" that's ostensibly configured to keep products of a fuel-fed fire out of the cockpit. Then you propose to plug that hole with some form of plastic. Here's a trip to the assembly line of one manufacturer that has spent several decades of time, talent and resources developing techniques for bringing stuff through the fire wall but without compromising fire wall integrity. http://www.aeroelectric.com/articles/Firewall_Penetration/firewall.html I'll further quote from AC43-13 which is one of many documents where we are admonished to be aware of the flame retarding characteristics of devices that penetrate the firewall: 11-232. TYPES OF CONNECTORS. Connectors must be identified by an original identification number derived from MIL Specification (MS) or OAM specification. Figure 11-35 provides some examples of MS connector types. Several different types are shown in figures 11-36 and 11-37. a. Environmental Classes. Environment- resistant connectors are used in applications where they will probably be subjected to fluids, vibration, thermal, mechanical shock, corrosive elements, etc. Firewall class connectors incorporating these same features should, in addition, be able to prevent the penetration of the fire through the aircraft firewall connector opening and continue to function without failure for a specified period of time when exposed to fire. So unless you're changing the name of of your firewall to "engine compartment aft bulkhead", I'll suggest there is value in attending to maintenance of firewall integrity. Bob . . . ________________________________________________________________________________
Subject: Re: Alternator putting out too much amperage
Date: Aug 20, 2010
> My questions are this: Will the high amperage fry my radios and EFIS even though it shows it is only putting out 13.6 volts. No it will not. Chances are that the ammeter is lying to you. Even if it is telling the truth and the alternator is putting out high amperage, that high current is only being delivered to equipment that asks for it. Your electronics will only use the current that they were designed to use, regardless of the alternator current output (as long as there is not an over-voltage condition). The exception is defective equipment that asks for more current than normal. In that case, it is not the alternator's fault for delivering too much current. It is the defective equipment's fault for asking for too much. Even if some device fails and draws too much current, that will not cause other devices to use higher current. It is highly unlikely that there is actually 40amps of current being used by anything on your aircraft. First of all, it would probably blow a fuse. If there is no fuse, 40amps times 13.6volts = over 500 watts. That is a lot of heat and it would be very noticeable. Like Bob and Neal suggested, most likely the current sensor is the wrong size or the ammeter is not calibrated correctly. Good luck, Jim. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309588#309588 ________________________________________________________________________________
Date: Aug 20, 2010
Any idea where you can get such a fitting Bob? The ones I see at ACS look like they would cut insulation. Thanks, Tim _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, August 20, 2010 12:29 PM Subject: AeroElectric-List: Battery cables and Firewall Penetrations At 11:58 PM 8/19/2010, you wrote: That particular Terminal Feed Through Connector is only rated 250A @48VDC. You would probably be better served purchasing the 400A @48VDC version from Blue Sea Systems. http://bluesea.com/products/2206 They also carry both Black and Red and they are identical to the ones on Ebay except in a larger amperage rating and slightly larger physical size. I wouldn't be surprised if they were cheaper from Blue Sky either. $11/each seems kinda pricey to me. Emacs! But are price, voltage and current ratings the only features of concern? You're going to poke a substantial hole in a "firewall" that's ostensibly configured to keep products of a fuel-fed fire out of the cockpit. Then you propose to plug that hole with some form of plastic. Here's a trip to the assembly line of one manufacturer that has spent several decades of time, talent and resources developing techniques for bringing stuff through the fire wall but without compromising fire wall integrity. http://www.aeroelectric.com/articles/Firewall_Penetration/firewall.html I'll further quote from AC43-13 which is one of many documents where we are admonished to be aware of the flame retarding characteristics of devices that penetrate the firewall: 11-232. TYPES OF CONNECTORS. Connectors must be identified by an original identification number derived from MIL Specification (MS) or OAM specification. Figure 11-35 provides some examples of MS connector types. Several different types are shown in figures 11-36 and 11-37. a. Environmental Classes. Environment- resistant connectors are used in applications where they will probably be subjected to fluids, vibration, thermal, mechanical shock, corrosive elements, etc. Firewall class connectors incorporating these same features should, in addition, be able to prevent the penetration of the fire through the aircraft firewall connector opening and continue to function without failure for a specified period of time when exposed to fire. So unless you're changing the name of of your firewall to "engine compartment aft bulkhead", I'll suggest there is value in attending to maintenance of firewall integrity. Bob . . . Checked by AVG - www.avg.com 11:35:00 ________________________________________________________________________________
Date: Aug 20, 2010
At 09:06 PM 8/20/2010, you wrote: >Any idea where you can get such a fitting Bob? The ones I see at ACS >look like they would cut insulation. >Thanks, Tim > Which ACS catalog number are you looking at? Bob . . . ________________________________________________________________________________
Date: Aug 20, 2010
These: http://www.aircraftspruce.com/catalog/appages/firewallshields.php I like the idea of the 90=B0 bend but have not seen anything close. Tim _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, August 20, 2010 7:15 PM Subject: RE: AeroElectric-List: Battery cables and Firewall Penetrations At 09:06 PM 8/20/2010, you wrote: Any idea where you can get such a fitting Bob? The ones I see at ACS look like they would cut insulation. Thanks, Tim Which ACS catalog number are you looking at? Bob . . . Checked by AVG - www.avg.com 11:35:00 ________________________________________________________________________________
Date: Aug 21, 2010
Subject: Re: Battery cables and Firewall Penetrations
Tim... (if I may interrupt here, Bob...) Those ACS fittings you are referring to, Tim, are designed to take grommets inside the holes (except the small one which already has a rubber backing) to prevent damage to the wire. From the description on the ACS page: /Both types of shield ... accommodate rubber grommets up to outside diameter. Actual hole size in 2 piece shields is slightly larger than indicated to prevent chafing cable...Use grommets that fit tightly around the cable or wire to insure a good seal./ Harley ----------------------------------------------------------------- On 8/21/2010 12:02 AM, Tim Andres wrote: > > These: > http://www.aircraftspruce.com/catalog/appages/firewallshields.php > > I like the idea of the 90 bend but have not seen anything close. > > Tim > > ----------------------------------------------------------------- > > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On > Behalf Of *Robert L. Nuckolls, III > *Sent:* Friday, August 20, 2010 7:15 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* RE: AeroElectric-List: Battery cables and Firewall > Penetrations > > At 09:06 PM 8/20/2010, you wrote: > > Any idea where you can get such a fitting Bob? The ones I see > at ACS look like they would cut insulation. > Thanks, Tim > > > Which ACS catalog number are you looking at? > > Bob . . . > > * * > * * > ** > ** > ** > *http://www.matronics.com/Navigator?AeroElectric-List* > ** > ** > *http://forums.matronics.com* > ** > ** > *http://www.matronics.com/contribution* > * * > > Checked by AVG - www.avg.com > 11:35:00 > > * > > > * ________________________________________________________________________________
Date: Aug 21, 2010
Bob, thanks for your help! Your answer clarifies many of my questions. I was surprised by your answer about the test. Did I understand correctly that there is never a time to intentionally turn off the primary alternator and battery for the purpose of testing the SD-8 and it's associated circuitry's ability to supply the Ebus? On Fri, Aug 20, 2010 at 3:02 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > > At 10:27 AM 8/20/2010, you wrote: > I'm thinking about using one of these as the belt driven alternator in > Z-13/8: > > http://www.plane-power.com/AL12-EI60.htm > > It's their experimental, internally regulated alternator that also comes > with built in crowbar over voltage protection. I'm not sure that I have a > full understanding of the OV protection and control issues of IR alternators > and how they pertain to this unit. > > I have 3 primary questions- one for the AEC and two for Plane Power, though > I welcome any insight about all three from the AEC readers. > > So first, is it correct to say that Z24, Z24A, and the associated text on > page Z-5 apply to IR alternators as they come off of the auto parts shelf, > and not really to this unit? > > Correct . . . The P-P devices are not off-the-shelf > automotive. > > > Based on their conceptual wiring picture here: > http://www.plane-power.com/images/AL12_EI60%20Installation.pdf > > Primary Question 1: How would I make the wiring connections in Z13/8 with > this unit? Should their field enable lead go to the 2-3 DC Power Master > Switch with the 5A crowbar in the same place as Z13/8 depicts it? Also, > what about that other optional alternator off lead (see 3 below)? > > I think I understand that the battery dump issue (described at > http://www.aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf) > is a problem in Z13/8 because we would like to occasionally (preflight, > first flight of the day, etc?) turn the primary alternator and master off, > and turn the ebus alternate feed on to test those associated switching > systems. Is that correct? > > No. "Battery Dump" is defined as the sudden reduction > of heavy alternator loads wherein the major portion > of that load included battery recharge current and > it's the BATTERY that's being disconnected. There > are no operational procedures that call for such > a "test". Further, the way the Z-figures are drawn, > such a test could not be conducted for the battery > is always disconnected AFTER the alternator is shut down. > > > Primary Question 2: Will it do any physical damage to anything to turn off > the 2-3 DC Power Master Switch while the engine is running (assuming that I > need to)? > > It has been a legacy design goal for all TC aircraft > to configure the system such that an alternator (or > generator) may be turned on or off at any time under > any conditions without hazard to other components > in the system. An alternator that is controlled > by breaking the field lead without breaking the > b-lead MEETS this design goal. So, no . . . the P-P > alternator may be turned on or off at anytime without > concern for hazard to any compoent. > > > Primary Question 3: Does opening their Alternator Field Enable Switch fully > shut down the alternator field? > > > Yes > > If the crowbar protection circuit pops that 5A CB, I should hope that > opening that switch > > "switch"??? Do you mean "breaker"? Yes, opening that > breaker offers a quiet, orderly and benign disabling > of the alternator. > > . . . would completely shut down the alternator field too. If so, then > what does that other "optional alternator off" lead do? > > That's not a control, it's an indicator light which > has some limited ability to annunciate alternator failure > and has been used in cars for decades. However, active > notification of low voltage by an independent sensing > system is the legacy approach to watching for and > announcing alternator failure. > > > Would I need to hook it up at all, and/or would I need to still hook it up > with a switch in the line? Is there a failure mode in the other circuit > that would require me to turn off a switch in the second line to shut the > alternator off? > > You can drop the P-P product directly into any > of the z-figures by simply eliminating any illustrated > external regulators and/or crowbar ov protection > modules. > > I was going to call plane power to ask them a few of these questions but I > need to make sure that I know what to ask about. Thanks in advance. > > I've discussed Plane-Power design philosophy with > them at length. It's a certainty that their answers > will be along the same lines as that which I've offered > above. > > Bob . . . > > ________________________________________________________________________________
Date: Aug 21, 2010
Subject: New operations model for the AeroElectric Connection
Last year we made the decision to make the 'Connection more utilitarian and accessible by offering electronic versions. This was not done without some considerations of risk. In the Internet age, a popular/useful file "released into the wild" may suddenly propagate with amazing speed. Such is the case with the AeroElectric Connection. The .pdf version has been picked up on a host of file-sharing services and now enjoys circulation numbers in the tens of thousands of copies. There's an obvious down-side. This means that the publication side of the AeroElectric Connection ceases to be as strong source of revenue. The up-side is that the simple-ideas and recipes for success described therein enjoy much wider circulation to the benefit of the OBAM aviation community as a whole. Coincidentally, I have just read a book called "The Future of a Radical Price - Free" wherein the author describes economic and marketing models that exploit giving certain value away in order to promote the exchange of other value. This business model has been operating on the Internet for years and continues to grow . . . which demonstrates its value. Consideration of his advice combined with previous events cited marks a milestone in my own experiences and prompts a new modus operandi for the AeroElectric Connection. Beginning immediately, the printed copy price of the 'Connection will drop to $23 postage paid (media mail) in the us. $30 overseas (priority mail). Buying the printed book will be more convenient and probably less expensive than printing 300+ pages on your own printer. The PDF file has been loaded to the website for download at no charge. The Revision 13 to the 'Connection will offer a complete update and re-formatting of the book. Most chapters including the Z-figures will make direct references to a range of products and services offered by the AeroElectric Connection. There are big plans for expanding our design, manufacturing and consulting services on behalf of the OBAM aviation community. We will probably bring Appendix C (catalog and source-book of products) back. Anyone who has recently purchased a book or CD at current prices who feels short changed by the price reduction is encouraged to drop us a line. Our warranty offers a guarantee of perceived value for the lifetime of any product. Drop us a note and we'll make it right with you. All of our dealers will be getting shipments of additional books equal to 1/2 their present inventory to adjust their return on investment for having purchased quantities of the book. Bob . . . ________________________________________________________________________________
Subject: Re: Jasco Alternator and Panel Ground Questions
Date: Aug 21, 2010
Thanks, Bob. Your book sure takes alot of the mystery out of the wiring process - I'm already on my second highlighter! Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309623#309623 ________________________________________________________________________________
Date: Aug 21, 2010
At 09:02 AM 8/21/2010, you wrote: >Bob, thanks for your help! Your answer clarifies many of my >questions. I was surprised by your answer about the test. Did I >understand correctly that there is never a time to intentionally >turn off the primary alternator and battery for the purpose of >testing the SD-8 and it's associated circuitry's ability to supply the Ebus? Sure, you can do that. BATTERY DUMP is dependent upon sequences of events. First you have to have a heavily loaded alternator (engine rpm high, discharged battery that is demanding and receiving most of the alternator's output). Then you unhook the battery while leaving the alternator on line. The effect is much like the tug of war game where one of the opposing sides suddenly releases their grip on the rope when the other side is concentrating on a max effort. There's no way that the other side can keep from falling on their butts. The folks who design regulators must strive for a magic compromise between stability (SLOW response) and and accuracy (HIGH gain). In engineering-speak this is often referred to as "damping ratio". See: http://www.aeroelectric.com/Pictures/Curves/damping_ratio.gif Here you see the time versus temperature plots for various servo-systems tailored to hold a mass at some constant temperature. Raising the temperature of a large mass takes a lot of watts. But the device controlling the heater has to be fitted with some anticipatory features. If you're pouting out kilojoules of heat into kilograms of mass, you'd better start throttling things back as the system approaches the desired temperature. You can slow things way down and have an "over damped" system that is free of oscillations and overshoot. On the other hand, a high gain/ fast response characteristic may bring the temperature to the set point faster and with more accuracy, but tendency to overshoot and "wiggle" about the set-point is greater. This system is said to be "under damped". Now, imagine a controller that is optimally damped (middle curve). Consider what happens if the heater is turned on but sometime along the temperature rise cycle, you suddenly reduce the mass being heated by say 90%. What's a poor controller to do? Now unable to detect the loss of mass, the probability for overshoot and oscillation is huge. The battery is electrical "mass" which your regulator expects to be in place all the time. Hence the design goal that calls for alternators not to be switched on/off without a battery being on line too. If you study what happens while sitting at the controls and flipping switches, there's no way you can produce that sudden reduction of "mass". Alternators are never switched on/off without a battery being tied to the bus. Hence the design goals are satisfied and risks to the system are reduced to insignificance. Bob . . . ________________________________________________________________________________
Date: Aug 21, 2010
Subject: Re: New operations model for the AeroElectric Connection
If you don't mind a suggestion. Look at the Rotax model for distributing its engine manuals. They are free, but they are locked. You cannot cut or copy text out of them. If you want to send some significant point to someone, you have to re-type it. I think it assures that the manuals will not be corrupted either by accident or malicious intent. Just a thought. Rick Girard On Sat, Aug 21, 2010 at 9:35 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > *Last year we made the decision to make the 'Connection more utilitarian > and accessible by > offering electronic versions. This was not done without some considerations > of risk. > > In the Internet age, a popular/useful file "released into the wild" may > suddenly propagate with > amazing speed. Such is the case with the AeroElectric Connection. The .pdf > version has been > picked up on a host of file-sharing services and now enjoys circulation > numbers in the tens of > thousands of copies. > > There's an obvious down-side. This means that the publication side of the > AeroElectric Connection ceases > to be as strong source of revenue. The up-side is that the simple-ideas and > recipes for success described > therein enjoy much wider circulation to the benefit of the OBAM aviation > community as a whole. > > Coincidentally, I have just read a book called "The Future of a Radical > Price - Free" wherein > the author describes economic and marketing models that exploit giving > certain value away in > order to promote the exchange of other value. This business model has been > operating on the > Internet for years and continues to grow . . . which demonstrates its > value. Consideration of his > advice combined with previous events cited marks a milestone in my own > experiences and > prompts a new modus operandi for the AeroElectric Connection. > > Beginning immediately, the printed copy price of the 'Connection will drop > to $23 postage > paid (media mail) in the us. $30 overseas (priority mail). Buying the > printed book will be > more convenient and probably less expensive than printing 300+ pages on > your own printer. > The PDF file has been loaded to the website for download at no charge. > > The Revision 13 to the 'Connection will offer a complete update and > re-formatting of the book. > Most chapters including the Z-figures will make direct references to a > range of products and services > offered by the AeroElectric Connection. There are big plans for expanding > our design, manufacturing > and consulting services on behalf of the OBAM aviation community. We will > probably bring Appendix C > (catalog and source-book of products) back. > > Anyone who has recently purchased a book or CD at current prices who feels > short changed by the > price reduction is encouraged to drop us a line. Our warranty offers a > guarantee of perceived > value for the lifetime of any product. Drop us a note and we'll make it > right with you. All of > our dealers will be getting shipments of additional books equal to 1/2 > their present inventory > to adjust their return on investment for having purchased quantities of the > book. > > > Bob . . . > * > > * > > * > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM ________________________________________________________________________________
Date: Aug 21, 2010
Anyone who has recently purchased a book or CD at current prices who feels short changed by the price reduction is encouraged to drop us a line. Our warranty offers a guarantee of perceived value for the lifetime of any product. Drop us a note and we'll make it right with you Bob . . . As I recall, I paid $35 for my book, which is a $12 difference from todays price. I feel that I have gotten at least an order of magnitude more in value from this forum and the Aeroelectric website, so... lets call it even. What you do is much appreciated, hope you stay with us for a long time to come. Roger ________________________________________________________________________________
Date: Aug 21, 2010
Bob I just wanted to pass on my thanks for all you do for our community. I followed your diagrams and ideas on my Glasair and the electrical has been a non issue for the years I have been flying. Exactly what I wanted. The info and assistance I recieved was worth far more than the cost of your book. Thanks again Jim James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Sat, August 21, 2010 8:35:25 AM Subject: AeroElectric-List: New operations model for the AeroElectric Connection Last year we made the decision to make the 'Connection more utilitarian and accessible by offering electronic versions. This was not done without some considerations of risk. In the Internet age, a popular/useful file "released into the wild" may suddenly propagate with amazing speed. Such is the case with the AeroElectric Connection. The .pdf version has been picked up on a host of file-sharing services and now enjoys circulation numbers in the tens of thousands of copies. There's an obvious down-side. This means that the publication side of the AeroElectric Connection ceases to be as strong source of revenue. The up-side is that the simple-ideas and recipes for success described therein enjoy much wider circulation to the benefit of the OBAM aviation community as a whole. Coincidentally, I have just read a book called "The Future of a Radical Price - Free" wherein the author describes economic and marketing models that exploit giving certain value away in order to promote the exchange of other value. This business model has been operating on the Internet for years and continues to grow . . . which demonstrates its value. Consideration of his advice combined with previous events cited marks a milestone in my own experiences and prompts a new modus operandi for the AeroElectric Connection. Beginning immediately, the printed copy price of the 'Connection will drop to $23 postage paid (media mail) in the us. $30 overseas (priority mail). Buying the printed book will be more convenient and probably less expensive than printing 300+ pages on your own printer. The PDF file has been loaded to the website for download at no charge. The Revision 13 to the 'Connection will offer a complete update and re-formatting of the book. Most chapters including the Z-figures will make direct references to a range of products and services offered by the AeroElectric Connection. There are big plans for expanding our design, manufacturing and consulting services on behalf of the OBAM aviation community. We will probably bring Appendix C (catalog and source-book of products) back. Anyone who has recently purchased a book or CD at current prices who feels short changed by the price reduction is encouraged to drop us a line. Our warranty offers a guarantee of perceived value for the lifetime of any product. Drop us a note and we'll make it right with you. All of our dealers will be getting shipments of additional books equal to 1/2 their present inventory to adjust their return on investment for having purchased quantities of the book. Bob . . . ________________________________________________________________________________
Date: Aug 21, 2010
At 10:55 AM 8/21/2010, you wrote: >If you don't mind a suggestion. Look at the Rotax model for >distributing its engine manuals. They are free, but they are locked. >You cannot cut or copy text out of them. If you want to send some >significant point to someone, you have to re-type it. I think it >assures that the manuals will not be corrupted either by accident >or malicious intent. Just a thought. Yeah, I'll be doing that. But by the next time a new revision hits the www, there will be uncountable opportunities for accidental or malicious adventure for what's already out there. Such is the risk of being an inhabitant of our planet! Interestingly enough, I had several experiences at OSH many years ago where somebody walked up to the booth with a binder that contained a 'Connection that was obviously copied. Many of the pages were not "square". I never bothered to inquire and it really didn't matter. Knowing the circumstances would not have altered the reality. Best thing was to move on and build good airplanes. Bob . . . ________________________________________________________________________________
Date: Aug 21, 2010
At 11:05 AM 8/21/2010, you wrote: >Anyone who has recently purchased a book or CD at current prices who >feels short changed by the >price reduction is encouraged to drop us a line. Our warranty offers >a guarantee of perceived >value for the lifetime of any product. Drop us a note and we'll make >it right with you > >Bob . . . > >As I recall, I paid $35 for my book, which is a $12 difference from >todays price. I feel that I have gotten at least an order of >magnitude more in value from this forum and the Aeroelectric >website, so... lets call it even. > >What you do is much appreciated, hope you stay with us for a long >time to come. Thank you my friend. That's the plan. Bob . . . ________________________________________________________________________________
Date: Aug 21, 2010
At 11:34 AM 8/21/2010, you wrote: >Bob >I just wanted to pass on my thanks for all you do for our >community. I followed your diagrams and ideas on my Glasair and the >electrical has been a non issue for the years I have been >flying. Exactly what I wanted. The info and assistance I recieved >was worth far more than the cost of your book. >Thanks again Thank YOU! I'm pleased that the work is useful. Bob . . . ________________________________________________________________________________
Date: Aug 21, 2010
Bob, I purchased your book a few years back for 35 dollars. I am currently updated through rev 12 (I think). I appreciate what you do for the OBAM community so much that I will probably buy your new format and rev 13 book just to do my part in helping keep the revenue stream flowing. Thanks for everything Dave ________________________________________________________________________________
Date: Aug 21, 2010
Subject: Re: Tray Connectors...A Bad Idea.
At 07:44 AM 8/18/2010, you wrote: > >I am sure the notion of sliding a piece of electronics into a tray >with the connector on the back has some informative design history, >but it is a horrible idea for aircraft (and even cars). In general >you should avoid it and replace the connector with a hanging one >where the connections aren't attached to two separately moving bodies. It's true that connectors at the rear of slide-in accessories mating with connectors on captive trays have extra-ordinary design requirements. And there were a few radios wherein the designers had to learn the weaknesses in the worst way - field experience. Many of the first radios for GA aircraft didn't even mount on the panel. Take this cute little feller . . . http://tinyurl.com/29sfmdd This radio was battery powered and not intended to be mounted solidly to the airplane. See the leather carrying handle? One sat it in the seat, plugged in an antenna, headphones and mic and voila! You had an airborne radio communications system. The antenna was in fact, a device adapted from a car radio installation. You talked on a VHF frequency determined by which crystal you plugged into the panel (see slots for two other frequencies) and listened for the ground facility to reply over the local radio range, LF beacon or marker transmitter. Not too many years after, folks began to find ways to mount these new fangled devices to the panel and it didn't take long to realize that it was MUCH easier to do installation and maintenance if the mounting tray and harness was captive to the airplane and the radio simply slides into the tray. Exemplar radios included this device. http://tinyurl.com/29hm578 You can see the head of the radio-to-tray jackscrew at the upper edge of the LF receiver bezel. http://tinyurl.com/2c5hu4w The other end of the jackscrew can be seen here along with the Cinch-Jones connectors that mated with connectors captive to the tray. These connectors are still in production. http://tinyurl.com/yhm37ow At the same time, other manufacturers elected not to participate in that adventure. As I recall, this radio's installation tray http://tinyurl.com/3xklhct did not capture the mating connectors. The maintenance person had to crawl under the panel to mate/de-mate harnesses with the radio. Even today, the installed size and wire-count of some radios . . . http://tinyurl.com/2u58jrb doesn't offer practical tray designs and their mating harness connectors are captive directly to the radio chassis. Aircraft radios did suffer a sort of "dark ages" when connectors intended to engage card- edge fingers were pressed into service on new designs. King radio (and others) built a LOT of devices that used this genre' of wire to board connector: Emacs! That accepted pins looking like this: Emacs! At Cessna in 1963 or so, we did an audio distribution board that mounted some relays and provided a sort of junction box for integrating a stack of radios into the single-engine product line. The card-edge connector was imply not designed to perform well in the aircraft environment. The in-house experiment only lasted a few years. Recall that good connection science calls for low surface area, high-pressure contact between pin and socket. The thin, gold-plated fingers of soft copper and the wide, low pressure springs in the pins simply did not rise to the task. Further, these connectors are probably the most fragile interconnect devices ever. They are entirely suited for SOME limited applications and are still made . . . but you won't (or at least shouldn't) find them in a product destined for use in an airplane. These connectors are not well contained. Dust laden with moisture, oils, and grit can accumulate over time. There's no wire support to keep harness wiggles from "working" the pins in their housings. I'd venture a guess that 90+ percent of my observations of "connector grief" with panel mounted radios in light aircraft have involved a variant of a card-edge-to-wire product. Having said that, I'm not sure I'd recommend a great migration to modifying any radio that's still in service utilizing this connector style. It would probably be useful to install new pins in all the holes. Clean the card edge fingers with a solvent wetted swab (resist any temptation to buff with ANY form of abrasive), that gold plating is VERY thin! Then provide bundle support for the wires close to where they exit the connector housing. Beyond this example of mis-applied technologies, I think the researcher will find that tray mounted harness connectors have enjoyed secure, happy and long lived associations with their radio mounted mates. The design has been widely practiced over the full range of avionics from the present day descendant of the Mitchell Airboy up to and including electro-whizzies in military and spacecraft. The magic happens when the connector pin-socket combinations are truly crafted to the task, harnesses don't hang from the pin's insulation grip, housings do a good job of shielding pins from the environmental crud, and finally, the radio is properly captive in the tray by proper tightening of the retaining hardware. By the way, if any of you are interested in a little museum trip down Avionics Lane, I'll invite you to look over the collection of pictures here: http://aeroelectric.com/Pictures/Radios/ Some of us grey beards have had the pleasure of cranking on a few of these very same knobs. My first flying lesson in a rudder-pedal fitted included a how-to session on one of these: http://tinyurl.com/3xklhct Bob . . . ________________________________________________________________________________
From: "Ralph & Maria Finch" <ralphmariafinch(at)gmail.com>
Subject: Tray Connectors...A Bad Idea.
Date: Aug 21, 2010
Bob-you are the man. Your knowledge and *understanding* of both electrical issues and their history of development is truly remarkable and seldom seen nowadays in any field. Old School of the best kind. A tip-of-the-hat from Ralph Finch Davis, California, USA RV-9A QB-SA ________________________________________________________________________________
Date: Aug 21, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
I knew when this was posted it would generate an interesting dialog but didn't expect an avionics history lesson. Great stuff! Thanks Bob and Eric. Robert L. Nuckolls, III wrote: > At 07:44 AM 8/18/2010, you wrote: >> >> >> I am sure the notion of sliding a piece of electronics into a tray >> with the connector on the back has some informative design history, >> but it is a horrible idea for aircraft (and even cars). In general >> you should avoid it and replace the connector with a hanging one >> where the connections aren't attached to two separately moving bodies. > > It's true that connectors at the rear of > slide-in accessories mating with connectors > on captive trays have extra-ordinary design > requirements. And there were a few radios > wherein the designers had to learn the > weaknesses in the worst way - field experience. > > Many of the first radios for GA aircraft didn't > even mount on the panel. Take this cute little > feller . . . > > * http://tinyurl.com/29sfmdd* > > This radio was battery powered and not intended > snippety snip ________________________________________________________________________________
Date: Aug 21, 2010
Subject: Tray Connectors...OOPS.
Somehow the image for the card-edge-finger pin got replace by a second housing image. Here's the corrected piece. B . . . >I am sure the notion of sliding a piece of electronics into a tray >with the connector on the back has some informative design history, >but it is a horrible idea for aircraft (and even cars). In general >you should avoid it and replace the connector with a hanging one >where the connections aren't attached to two separately moving bodies. It's true that connectors at the rear of slide-in accessories mating with connectors on captive trays have extra-ordinary design requirements. And there were a few radios wherein the designers had to learn the weaknesses in the worst way - field experience. Many of the first radios for GA aircraft didn't even mount on the panel. Take this cute little feller . . . http://tinyurl.com/29sfmdd This radio was battery powered and not intended to be mounted solidly to the airplane. See the leather carrying handle? One sat it in the seat, plugged in an antenna, headphones and mic and voila! You had an airborne radio communications system. The antenna was in fact, a device adapted from a car radio installation. You talked on a VHF frequency determined by which crystal you plugged into the panel (see slots for two other frequencies) and listened for the ground facility to reply over the local radio range, LF beacon or marker transmitter. Not too many years after, folks began to find ways to mount these new fangled devices to the panel and it didn't take long to realize that it was MUCH easier to do installation and maintenance if the mounting tray and harness was captive to the airplane and the radio simply slides into the tray. Exemplar radios included this device. http://tinyurl.com/29hm578 You can see the head of the radio-to-tray jackscrew at the upper edge of the LF receiver bezel. http://tinyurl.com/2c5hu4w The other end of the jackscrew can be seen here along with the Cinch-Jones connectors that mated with connectors captive to the tray. These connectors are still in production. http://tinyurl.com/yhm37ow At the same time, other manufacturers elected not to participate in that adventure. As I recall, this radio's installation tray http://tinyurl.com/3xklhct did not capture the mating connectors. The maintenance person had to crawl under the panel to mate/de-mate harnesses with the radio. Even today, the installed size and wire-count of some radios . . . http://tinyurl.com/2u58jrb doesn't offer practical tray designs and their mating harness connectors are captive directly to the radio chassis. Aircraft radios did suffer a sort of "dark ages" when connectors intended to engage card- edge fingers were pressed into service on new designs. King radio (and others) built a LOT of devices that used this genre' of wire to board connector: [] That accepted pins looking like this: [] At Cessna in 1963 or so, we did an audio distribution board that mounted some relays and provided a sort of junction box for integrating a stack of radios into the single-engine product line. The card-edge connector was imply not designed to perform well in the aircraft environment. The in-house experiment only lasted a few years. Recall that good connection science calls for low surface area, high-pressure contact between pin and socket. The thin, gold-plated fingers of soft copper and the wide, low pressure springs in the pins simply did not rise to the task. Further, these connectors are probably the most fragile interconnect devices ever. They are entirely suited for SOME limited applications and are still made . . . but you won't (or at least shouldn't) find them in a product destined for use in an airplane. These connectors are not well contained. Dust laden with moisture, oils, and grit can accumulate over time. There's no wire support to keep harness wiggles from "working" the pins in their housings. I'd venture a guess that 90+ percent of my observations of "connector grief" with panel mounted radios in light aircraft have involved a variant of a card-edge-to-wire product. Having said that, I'm not sure I'd recommend a great migration to modifying any radio that's still in service utilizing this connector style. It would probably be useful to install new pins in all the holes. Clean the card edge fingers with a solvent wetted swab (resist any temptation to buff with ANY form of abrasive), that gold plating is VERY thin! Then provide bundle support for the wires close to where they exit the connector housing. Beyond this example of mis-applied technologies, I think the researcher will find that tray mounted harness connectors have enjoyed secure, happy and long lived associations with their radio mounted mates. The design has been widely practiced over the full range of avionics from the present day descendant of the Mitchell Airboy up to and including electro-whizzies in military and spacecraft. The magic happens when the connector pin-socket combinations are truly crafted to the task, harnesses don't hang from the pin's insulation grip, housings do a good job of shielding pins from the environmental crud, and finally, the radio is properly captive in the tray by proper tightening of the retaining hardware. By the way, if any of you are interested in a little museum trip down Avionics Lane, I'll invite you to look over the collection of pictures here: http://aeroelectric.com/Pictures/Radios/ Some of us grey beards have had the pleasure of cranking on a few of these very same knobs. My first flying lesson in a rudder-pedal fitted included a how-to session on one of these: http://tinyurl.com/3xklhct Bob . . . ________________________________________________________________________________
Date: Aug 21, 2010
Good Afternoon 'Lectric Bob. And prior to that ultra modern Mitchel VHF set, we used Bill Lear's portable in a small suitcase which transmitted on 3105kc and allowed us to receive the "Beam" on low frequency. It even had a built in loop antenna. We could rotate the whole radio and get a bearing to or from the station. With a little judicious maneuvering, we could figure out whether the station was ahead or behind us in a as little as ten minutes or so. The biggest problem with it was finding a long wire antenna. With such an antenna, we could talk to a tower from as far as fifteen miles away. Great stuff. Happy Skies, Old Bob In a message dated 8/21/2010 1:29:29 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: At 07:44 AM 8/18/2010, you wrote: --> AeroElectric-List message posted by: "Eric M. Jones" I am sure the notion of sliding a piece of electronics into a tray with the connector on the back has some informative design history, but it is a horrible idea for aircraft (and even cars). In general you should avoid it and replace the connector with a hanging one where the connections aren't attached to two separately moving bodies. It's true that connectors at the rear of slide-in accessories mating with connectors on captive trays have extra-ordinary design requirements. And there were a few radios wherein the designers had to learn the weaknesses in the worst way - field experience. Many of the first radios for GA aircraft didn't even mount on the panel. Take this cute little feller . . . _http://tinyurl.com/29sfmdd_ (http://tinyurl.com/29sfmdd) This radio was battery powered and not intended to be mounted solidly to the airplane. See the leather carrying handle? One sat it in the seat, plugged in an antenna, headphones and mic and voila! You had an airborne radio communications system. The antenna was in fact, a device adapted from a car radio installation. You talked on a VHF frequency determined by which crystal you plugged into the panel (see slots for two other frequencies) and listened for the ground facility to reply over the local radio range, LF beacon or marker transmitter. Not too many years after, folks began to find ways to mount these new fangled devices to the panel and it didn't take long to realize that it was MUCH easier to do installation and maintenance if the mounting tray and harness was captive to the airplane and the radio simply slides into the tray. Exemplar radios included this device. _http://tinyurl.com/29hm578_ (http://tinyurl.com/29hm578) You can see the head of the radio-to-tray jackscrew at the upper edge of the LF receiver bezel. _http://tinyurl.com/2c5hu4w_ (http://tinyurl.com/2c5hu4w) The other end of the jackscrew can be seen here along with the Cinch-Jones connectors that mated with connectors captive to the tray. These connectors are still in production. _http://tinyurl.com/yhm37ow_ (http://tinyurl.com/yhm37ow) At the same time, other manufacturers elected not to participate in that adventure. As I recall, this radio's installation tray _http://tinyurl.com/3xklhct_ (http://tinyurl.com/3xklhct) did not capture the mating connectors. The maintenance person had to crawl under the panel to mate/de-mate harnesses with the radio. Even today, the installed size and wire-count of some radios . . . _http://tinyurl.com/2u58jrb_ (http://tinyurl.com/2u58jrb) doesn't offer practical tray designs and their mating harness connectors are captive directly to the radio chassis. Aircraft radios did suffer a sort of "dark ages" when connectors intended to engage card- edge fingers were pressed into service on new designs. King radio (and others) built a LOT of devices that used this genre' of wire to board connector: That accepted pins looking like this: At Cessna in 1963 or so, we did an audio distribution board that mounted some relays and provided a sort of junction box for integrating a stack of radios into the single-engine product line. The card-edge connector was imply not designed to perform well in the aircraft environment. The in-house experiment only lasted a few years. Recall that good connection science calls for low surface area, high-pressure contact between pin and socket. The thin, gold-plated fingers of soft copper and the wide, low pressure springs in the pins simply did not rise to the task. Further, these connectors are probably the most fragile interconnect devices ever. They are entirely suited for SOME limited applications and are still made . . . but you won't (or at least shouldn't) find them in a product destined for use in an airplane. These connectors are not well contained. Dust laden with moisture, oils, and grit can accumulate over time. There's no wire support to keep harness wiggles from "working" the pins in their housings. I'd venture a guess that 90+ percent of my observations of "connector grief" with panel mounted radios in light aircraft have involved a variant of a card-edge-to-wire product. Having said that, I'm not sure I'd recommend a great migration to modifying any radio that's still in service utilizing this connector style. It would probably be useful to install new pins in all the holes. Clean the card edge fingers with a solvent wetted swab (resist any temptation to buff with ANY form of abrasive), that gold plating is VERY thin! Then provide bundle support for the wires close to where they exit the connector housing. Beyond this example of mis-applied technologies, I think the researcher will find that tray mounted harness connectors have enjoyed secure, happy and long lived associations with their radio mounted mates. The design has been widely practiced over the full range of avionics from the present day descendant of the Mitchell Airboy up to and including electro-whizzies in military and spacecraft. The magic happens when the connector pin-socket combinations are truly crafted to the task, harnesses don't hang from the pin's insulation grip, housings do a good job of shielding pins from the environmental crud, and finally, the radio is properly captive in the tray by proper tightening of the retaining hardware. By the way, if any of you are interested in a little museum trip down Avionics Lane, I'll invite you to look over the collection of pictures here: _http://aeroelectric.com/Pictures/Radios/ _ (http://aeroelectric.com/Pictures/Radios/) Some of us grey beards have had the pleasure of cranking on a few of these very same knobs. My first flying lesson in a rudder-pedal fitted included a how-to session on one of these: _http://tinyurl.com/3xklhct_ (http://tinyurl.com/3xklhct) Bob . . . ________________________________________________________________________________
From: "David & Elaine Lamphere" <dalamphere(at)comcast.net>
Subject: Lowrance Airmap GPS Updates
Date: Aug 21, 2010
I was asked to forward this information on in case you guys hadn't heard.... Please be advised - not only does Lowrance NOT make/sell any more Aviation GPS units, you cannot get a Jeppeson navdata update for them either! I just looked at the LEI site - no updates since April. I then sent a note to Jeppeson to see if they would supply any data updates for Lowrance units. Below is the query and dismal answer: ======== Subject: Data updates It appears that Lowrance no longer supplies the Jepp updates for their 1000 and 2000C GPS units. Will these updates be supplied by you for downloading? ======== Their response: Thank you for contacting us. We apologize for the long delay in responding to you Unfortunately, we have stopped all support on all Lowrance Units Lowrance has shut down there Aviation Group and we have no further word if they will continue! When they shut down, we stopped all Navdata Production for those units. I myself, have the Airmap 2000c and now it's a good paperweight! I'm forced to buy a Garmin Sorry Sir ======================= ________________________________________________________________________________
Date: Aug 21, 2010
At 02:01 PM 8/21/2010, you wrote: > > >Bob-you are the man. Your knowledge and *understanding* of both electrical >issues and their history of development is truly remarkable and seldom seen >nowadays in any field. Old School of the best kind. Thank you Ralph. Unfortunately, it just may be 'old school'. Now that I'm "out in the wild" myself I'm observing what might just be a cultural shift in the reverence for history. Most folks exposures to the study of history involves the memorization of names, places, dates and events. I've benefited from the study of practical history. What recipes for success have been demonstrated in the past . . . and what can we glean from those stories for (1) not having to re-invent the wheel, (2) discovery of those timeless, simple-ideas that are equally applicable but perhaps in a different recipe? A sort of connect-the-dots exercise that improves upon one's situational awareness. To forsake an understanding the past leads to a sort of intellectual entropy. Even as the magnitude of activity increases, so does the quantity of smoke and steam. Smoke from by-products of combustion, steam as a manifestation of energy needed to convert water to vapor. Both byproducts representing value expended never to be recovered. Sharing of practical history amongst folks on this and similar lists goes a long way to the reduction of smoke and steam while maximizing the value of what happens in our workshops. It's my pleasure to exercise these talents but without the list, that exercise is at risk of becoming only more smoke and steam. I thank you all for being there. Bob . . . ________________________________________________________________________________
Date: Aug 21, 2010
Subject: Aircraft radios of yesteryear
At 04:02 PM 8/21/2010, you wrote: >Good Afternoon 'Lectric Bob. > >And prior to that ultra modern Mitchel VHF set, we used Bill Lear's >portable in a small suitcase which transmitted on 3105kc and allowed >us to receive the "Beam" on low frequency. It even had a built in >loop antenna. We could rotate the whole radio and get a bearing to >or from the station. With a little judicious maneuvering, we could >figure out whether the station was ahead or behind us in a as little >as ten minutes or so. If you ever run across any pictures, literature or stories about that era, I'd be pleased to get links/sources. > >The biggest problem with it was finding a long wire antenna. With >such an antenna, we could talk to a tower from as far as fifteen >miles away. Great stuff. Yeah, I wrote and illustrated an Accessory Kit for Cessna to put a Sun H.F. transceiver . . . http://www.aeroelectric.com/Pictures/Radios/Sun_Air_2.jpg in the Military 185 (U17) aircraft at the Pawnee Plant. We had a fixed wire that ran from cabin top to vertical fin and then out to the right wing tip. Then a trailing wire in the tailcone. For folks interested in such things you can see the kit instructions at: http://www.aeroelectric.com/Reference_Docs/Misc_PDF/AK-U-17-3B.pdf I'd forgotten about a ground adjustable loading coil installation behind the baggage compartment for making the fixed wire match the various installed crystals. Of course, if one was flying in a situation that allowed use of the trailing wire, you could run it out and tune it by watching the panel mounted antenna ammeter. Pretty heady stuff for HF in a small airplane in 1968. Bob . . . ________________________________________________________________________________
Date: Aug 21, 2010
Subject: Re: Aircraft radios of yesteryear
Good Evening 'Lectric Bob, You may have recalled that most of the early straight 35 Bonanzas came from the factory with an automatically extending and retracting trailing antenna. It extended at around 100 MPH and retracted at the same speed when slowing down. It can be seen on some of the advertising copy for the early machines. It had a small wind sock cone that mounted between the stabilators on a mast about six inches high. Next time you see a 1947 or 48 Bonanza take a look back there. Chances are you will see the remnants of the mast where it was sawed off after the trailing antenna was an abandoned. Unfortunately, an awful lot of them got ripped off by catching on an airport fence when folks made their approach just a bit too fast. The FCC did take away our 3105 frequency and designated 3023.5 in lieu thereof. Not sure just when that was but I think it was about 1948. Back when we were using 3105, the air carriers were using 6210. When we went to 3023.5 the frequency for air carriers was changed as well but I have forgotten what that frequency was. I will see what I can locate in some of my WWII text books. Happy Skies, Old Bob In a message dated 8/21/2010 4:55:53 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: At 04:02 PM 8/21/2010, you wrote: Good Afternoon 'Lectric Bob. And prior to that ultra modern Mitchell VHF set, we used Bill Lear's portable in a small suitcase which transmitted on 3105kc and allowed us to receive the "Beam" on low frequency. It even had a built in loop antenna. We could rotate the whole radio and get a bearing to or from the station. With a little judicious maneuvering, we could figure out whether the station was ahead or behind us in a as little as ten minutes or so. If you ever run across any pictures, literature or stories about that era, I'd be pleased to get links/sources. The biggest problem with it was finding a long wire antenna. With such an antenna, we could talk to a tower from as far as fifteen miles away. Great stuff. Yeah, I wrote and illustrated an Accessory Kit for Cessna to put a Sun H.F. transceiver . . . _http://www.aeroelectric.com/Pictures/Radios/Sun_Air_2.jpg _ (http://www.aeroelectric.com/Pictures/Radios/Sun_Air_2.jpg) in the Military 185 (U17) aircraft at the Pawnee Plant. We had a fixed wire that ran from cabin top to vertical fin and then out to the right wing tip. Then a trailing wire in the tailcone. For folks interested in such things you can see the kit instructions at: _http://www.aeroelectric.com/Reference_Docs/Misc_PDF/AK-U-17-3B.pdf _ (http://www.aeroelectric.com/Reference_Docs/Misc_PDF/AK-U-17-3B.pdf) I'd forgotten about a ground adjustable loading coil installation behind the baggage compartment for making the fixed wire match the various installed crystals. Of course, if one was flying in a situation that allowed use of the trailing wire, you could run it out and tune it by watching the panel mounted antenna ammeter. Pretty heady stuff for HF in a small airplane in 1968. Bob . . . (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
From: "Bruce B. Bell" <brucebell74(at)sbcglobal.net>
Date: Aug 21, 2010
My A-35 1949 Bonanza (D-1730) had one. Came out the factory door June 1948. ; From: BobsV35B(at)aol.com Sent: Saturday, August 21, 2010 5:47 PM Subject: Re: AeroElectric-List: Aircraft radios of yesteryear Good Evening 'Lectric Bob, You may have recalled that most of the early straight 35 Bonanzas came from the factory with an automatically extending and retracting trailing antenna. It extended at around 100 MPH and retracted at the same speed when slowing down. It can be seen on some of the advertising copy for the early machines. It had a small wind sock cone that mounted between the stabilators on a mast about six inches high. Next time you see a 1947 or 48 Bonanza take a look back there. Chances are you will see the remnants of the mast where it was sawed off after the trailing antenna was an abandoned. Unfortunately, an awful lot of them got ripped off by catching on an airport fence when folks made their approach just a bit too fast. The FCC did take away our 3105 frequency and designated 3023.5 in lieu thereof. Not sure just when that was but I think it was about 1948. Back when we were using 3105, the air carriers were using 6210. When we went to 3023.5 the frequency for air carriers was changed as well but I have forgotten what that frequency was. I will see what I can locate in some of my WWII text books. Happy Skies, Old Bob In a message dated 8/21/2010 4:55:53 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes: At 04:02 PM 8/21/2010, you wrote: Good Afternoon 'Lectric Bob. And prior to that ultra modern Mitchell VHF set, we used Bill Lear's portable in a small suitcase which transmitted on 3105kc and allowed us to receive the "Beam" on low frequency. It even had a built in loop antenna. We could rotate the whole radio and get a bearing to or from the station. With a little judicious maneuvering, we could figure out whether the station was ahead or behind us in a as little as ten minutes or so. If you ever run across any pictures, literature or stories about that era, I'd be pleased to get links/sources. The biggest problem with it was finding a long wire antenna. With such an antenna, we could talk to a tower from as far as fifteen miles away. Great stuff. Yeah, I wrote and illustrated an Accessory Kit for Cessna to put a Sun H.F. transceiver . . . http://www.aeroelectric.com/Pictures/Radios/Sun_Air_2.jpg in the Military 185 (U17) aircraft at the Pawnee Plant. We had a fixed wire that ran from cabin top to vertical fin and then out to the right wing tip. Then a trailing wire in the tailcone. For folks interested in such things you can see the kit instructions at: http://www.aeroelectric.com/Reference_Docs/Misc_PDF/AK-U-17-3B.pdf I'd forgotten about a ground adjustable loading coil installation behind the baggage compartment for making the fixed wire match the various installed crystals. Of course, if one was flying in a situation that allowed use of the trailing wire, you could run it out and tune it by watching the panel mounted antenna ammeter. Pretty heady stuff for HF in a small airplane in 1968. Bob . . . List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List ms.matronics.com/">http://forums.matronics.com tp://www.matronics.com/contribution">http://www.matronics.com/contributio n ________________________________________________________________________________
Subject: Re: Vertex VXA700 information needed
Date: Aug 21, 2010
Hi Vern We purchased an adapter cable and an external PTT switch when we purchased our VXA700. We ohmed out the harness and it indeed has two separate switches, one connects mic high when you push PTT, and the other switch grounds PTT high. I have a schematic for VXA 700 that Vertex support sent us, it does not include enough information to figure out why the harness would use two switches to do what they are doing. After several calls and finally cornered the support guy, he bowed out by saying Vertex doesn't make the harness and can't comment on it. He said the VXA 700 is not intended to be hooked up to an audio panel. I know that when we hook up the VXA 700 to our PMA4000 audio panel and use the harness I have with external PTT switch it works fine. I talked to PS Engineering and told him I wanted to use the mini DPDT relay as you can see on the right side near coin on second pic I posted to replicate two mechanical switches. I asked him if he thought it was OK to supply power to the coil of relay and have PMA4000 do the grounding when I push the PTT that is located on sticks and he thought that would be fine. Someone knows why my harness uses two separate switches to transmit. Vertex support does not know why. PS Engineering does not know why. I do not know why. I do know that the two switch arrangement works fine. My partner is an EE and thinks it best we replicate what we do know. His gut feeling is leaving mic connected all the time may not be a good thing to do. Perhaps someone could speculate why they may do this? Built into unit is a speaker and mic. Anyway there's our reasoning how and why we connected the four wire Vertex plug to our audio panel. You mention it may be a good idea to install a diode across the relay coil. We already finished harness and it would be a big effort to open up harness and get close to relay to install diode. You can see size of relay against a penny on the right side: http://www.europaowners.org/forums/gallery2.php?g2_itemId=81445&g2_imageViewsIndex=1 You can enlarge the pic to full size by selecting full size on top right of screen. The specifics are listed on schematic about the relay we are using. There is no mA draw of coil on information we have but it is not very much of a draw. Could get information off the data sheet. My question to you is what potential problem or problems could be caused by not using a diode across the coil of this mini relay? Do you think I should try harness as it is wired and if we experience a problem/s you describe, then install a diode? Or perhaps go half way between the two and install a diode about 6" away from the relay? BTW we are supplying power to the relay coil through a 324 wire that is about 20# long. I also have some snapjacks on hand if you think that a better choice. Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309694#309694 ________________________________________________________________________________
Date: Aug 21, 2010
Ron, I don't know why either, exactly, except that the PTT switch that Icom sold me for my A22 is set up the same way with two switches. Somewhere I got the idea is that one switch is NC and the other is NO. The NC is connected to the transmitter, the NO to the reciever. When the button is just sitting there doin' nothin', the transmitter is grounded and the receiver is open. Push the switch and the opposite happens the receiver is grounded out and the transmitter is open. The idea is to prevent the receiver and the transmitter from forming a feedback loop. Feel free to tell me I don't know what I'm talking about, there's a good chance I don't, but I seem to remember someone on this forum 'splainin' it that way somewhere in the distant past. Interesting that the VXA 220 uses a single switch in exactly the manner Bob described when I wrote in asking for help just this last May. Rick On Sat, Aug 21, 2010 at 8:52 PM, rparigoris wrote: > rparigor(at)suffolk.lib.ny.us> > > Hi Vern > > We purchased an adapter cable and an external PTT switch when we purchased > our VXA700. > > We ohmed out the harness and it indeed has two separate switches, one > connects mic high when you push PTT, and the other switch grounds PTT high. > > I have a schematic for VXA 700 that Vertex support sent us, it does not > include enough information to figure out why the harness would use two > switches to do what they are doing. > > After several calls and finally cornered the support guy, he bowed out by > saying Vertex doesn't make the harness and can't comment on it. He said the > VXA 700 is not intended to be hooked up to an audio panel. > > I know that when we hook up the VXA 700 to our PMA4000 audio panel and use > the harness I have with external PTT switch it works fine. > > I talked to PS Engineering and told him I wanted to use the mini DPDT relay > as you can see on the right side near coin on second pic I posted to > replicate two mechanical switches. I asked him if he thought it was OK to > supply power to the coil of relay and have PMA4000 do the grounding when I > push the PTT that is located on sticks and he thought that would be fine. > > Someone knows why my harness uses two separate switches to transmit. Vertex > support does not know why. PS Engineering does not know why. I do not know > why. > > I do know that the two switch arrangement works fine. My partner is an EE > and thinks it best we replicate what we do know. His gut feeling is leaving > mic connected all the time may not be a good thing to do. Perhaps someone > could speculate why they may do this? Built into unit is a speaker and mic. > > Anyway there's our reasoning how and why we connected the four wire Vertex > plug to our audio panel. > > You mention it may be a good idea to install a diode across the relay coil. > We already finished harness and it would be a big effort to open up harness > and get close to relay to install diode. > > You can see size of relay against a penny on the right side: > > http://www.europaowners.org/forums/gallery2.php?g2_itemId=81445&g2_imageViewsIndex=1 > > You can enlarge the pic to full size by selecting full size on top right of > screen. The specifics are listed on schematic about the relay we are using. > There is no mA draw of coil on information we have but it is not very much > of a draw. Could get information off the data sheet. > > My question to you is what potential problem or problems could be caused by > not using a diode across the coil of this mini relay? > > Do you think I should try harness as it is wired and if we experience a > problem/s you describe, then install a diode? > > Or perhaps go half way between the two and install a diode about 6" away > from the relay? BTW we are supplying power to the relay coil through a 324 > wire that is about 20# long. > > I also have some snapjacks on hand if you think that a better choice. > > Ron Parigoris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309694#309694 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Aug 21, 2010
Hi Rick If your Icom has two switches and is making one connection and breaking another when you push the PTT, it is different than my Vertex that makes two connections. On my Vertex VXA700 when you push the PTT one switch connects the mic high to pin 3 (mic high), this is a normal opened switch. The other switch connects mic low to pin 2 (PTT high), this is a normal opened switch. Thus my single relay is a double pole relay that just makes two connections when the PTT is depressed. My double pole relay is doing exactly the same thing as pressing the premade harness PTT I have, when the PTT is depressed, two individual single pole switches make. Would you mind taking an ohm meter to your set up and report back if in fact one switch is making and one breaking? If it is in fact like my Vertex where both switches make, I will give Icom and pick their brains! Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309709#309709 ________________________________________________________________________________
Date: Aug 22, 2010
Subject: Re: Lowrance Airmap GPS Updates
i have a 2 yr old 2000 that will fly for the first time this fall. what would you recommend for getting the latest update available for vfr? lowrance? bob noffs On Sat, Aug 21, 2010 at 4:10 PM, David & Elaine Lamphere < dalamphere(at)comcast.net> wrote: > I was asked to forward this information on in case you guys hadn't > heard.... > > Please be advised - not only does Lowrance NOT make/sell any more Aviation > GPS units, you cannot get > a Jeppeson navdata update for them either! I just looked at the LEI site - > no updates since April. > I then sent a note to Jeppeson to see if they would supply any data updates > for Lowrance units. > > Below is the query and dismal answer: > > ================================= > To: Support@JeppDirect > Subject: Data updates > > It appears that Lowrance no longer supplies the Jepp updates for their 1000 > and 2000C GPS units. > > Will these updates be supplied by you for downloading? > > ================================= > > Their response: > > *Thank you for contacting us. We apologize for the long delay in > responding to you* > > *Unfortunately, we have stopped all support on all Lowrance Units* > > *Lowrance has shut down there Aviation Group and we have no further word > if they will continue!* > > *When they shut down, we stopped all Navdata Production for those units. * > > *I myself, have the Airmap 2000c and now it's a good paperweight! * > > *I'm forced to buy a Garmin* > > ** > > *Sorry Sir* > > *========================* > > > * > > * > > ________________________________________________________________________________
Date: Aug 22, 2010
Bob, That's what I am trying to warn about, there are NO updates available from Lowrance or Jeppeson for the 2000!!! Us Lowrance owners are out in the cold, unless there is some boot-leg hacker somewhere that figures out something else... Bummer! Dave ----- Original Message ----- From: bob noffs To: aeroelectric-list(at)matronics.com Sent: Sunday, August 22, 2010 6:20 AM Subject: Re: AeroElectric-List: Lowrance Airmap GPS Updates i have a 2 yr old 2000 that will fly for the first time this fall. what would you recommend for getting the latest update available for vfr? lowrance? bob noffs On Sat, Aug 21, 2010 at 4:10 PM, David & Elaine Lamphere wrote: I was asked to forward this information on in case you guys hadn't heard.... Please be advised - not only does Lowrance NOT make/sell any more Aviation GPS units, you cannot get a Jeppeson navdata update for them either! I just looked at the LEI site - no updates since April. I then sent a note to Jeppeson to see if they would supply any data updates for Lowrance units. Below is the query and dismal answer: ======== To: Support@JeppDirect Subject: Data updates It appears that Lowrance no longer supplies the Jepp updates for their 1000 and 2000C GPS units. Will these updates be supplied by you for downloading? ======== Their response: Thank you for contacting us. We apologize for the long delay in responding to you Unfortunately, we have stopped all support on all Lowrance Units Lowrance has shut down there Aviation Group and we have no further word if they will continue! When they shut down, we stopped all Navdata Production for those units. I myself, have the Airmap 2000c and now it's a good paperweight! I'm forced to buy a Garmin Sorry Sir ======================= ________________________________________________________________________________
Date: Aug 22, 2010
Sure Ron, happy to help. I'll do it this afternoon when it's too hot to be outside anyway. What can I say, I'm a woose for this hot muggy weather. Rick On Sun, Aug 22, 2010 at 12:16 AM, rparigoris wrote: > rparigor(at)suffolk.lib.ny.us> > > Hi Rick > > If your Icom has two switches and is making one connection and breaking > another when you push the PTT, it is different than my Vertex that makes two > connections. > > On my Vertex VXA700 when you push the PTT one switch connects the mic high > to pin 3 (mic high), this is a normal opened switch. > > The other switch connects mic low to pin 2 (PTT high), this is a normal > opened switch. > > Thus my single relay is a double pole relay that just makes two connections > when the PTT is depressed. > > My double pole relay is doing exactly the same thing as pressing the > premade harness PTT I have, when the PTT is depressed, two individual > single pole switches make. > > Would you mind taking an ohm meter to your set up and report back if in > fact one switch is making and one breaking? > > If it is in fact like my Vertex where both switches make, I will give Icom > and pick their brains! > > Ron Parigoris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309709#309709 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Aug 22, 2010
Bob, I bought the book a few years ago, and thought it was extraordinarily good value. Recently though I've been feeling as though I've been short-changing you, because I've asked so many questions recently and you've always answered them with an obvious amount of time and care. Could you invite people to donate on a "donation-ware" basis? It's fairly common in software development -- you give something away for free and ask good folk to send a donation if they find it useful. It seems like an equitable way of doing business. I saw you have a PayPal setup for your online catalogue. Why not allow people to just randomly send you a few quid when they feel full of joy after hearing their master contactor clunk for the first time? Perhaps a page about it in the online version. Alternatively, presumably anyone could buy an hour's time on your online system, though that sets the price in stone, and I think that donation-ware works best when people send what they can afford, or just what they feel like sending. FWIW. James On Sat, Aug 21, 2010 at 5:45 PM, Robert L. Nuckolls, III wrote: > > > At 11:34 AM 8/21/2010, you wrote: >> >> Bob >> I just wanted to pass on my thanks for all you do for our community. I >> followed your diagrams and ideas on my Glasair and the electrical has been a >> non issue for the years I have been flying. Exactly what I wanted. The >> info and assistance I recieved was worth far more than the cost of your >> book. >> Thanks again > > Thank YOU! I'm pleased that the work is > useful. > > > Bob . . . > > ________________________________________________________________________________
Date: Aug 22, 2010
I found this out at OSH this year. Went to the Jepp tent to get an update and was told that Lowrance did not have a contract with Jepp and they could not do anything with my card. I don't know if, as a class of owners, there is anything that can be done legally, but I do know morally, Lowrance leaves a lot to be desired. Good business people don't just sever support without a warning and support for at least three years or so. I do also know that I will tell everyone I know NOT to buy Lowrance for their marine or other needs. Put doubt in their minds! Will Lowrance be there when you need them???? I found out! Kevin Boddicker Luana, IA TriQ 200 N7868B On Aug 22, 2010, at 6:09 AM, David & Elaine Lamphere wrote: > Bob, > > That's what I am trying to warn about, there are NO updates available from Lowrance or Jeppeson for the 2000!!! > Us Lowrance owners are out in the cold, unless there is some boot-leg hacker somewhere that figures out something else... > > Bummer! > > Dave > ----- Original Message ----- > From: bob noffs > To: aeroelectric-list(at)matronics.com > Sent: Sunday, August 22, 2010 6:20 AM > Subject: Re: AeroElectric-List: Lowrance Airmap GPS Updates > > i have a 2 yr old 2000 that will fly for the first time this fall. what would you recommend for getting the latest update available for vfr? lowrance? > bob noffs > > On Sat, Aug 21, 2010 at 4:10 PM, David & Elaine Lamphere wrote: > I was asked to forward this information on in case you guys hadn't heard.... > > Please be advised - not only does Lowrance NOT make/sell any more Aviation GPS units, you cannot get > a Jeppeson navdata update for them either! I just looked at the LEI site - no updates since April. > I then sent a note to Jeppeson to see if they would supply any data updates for Lowrance units. > > Below is the query and dismal answer: > > ======================== ========= > To: Support@JeppDirect > Subject: Data updates > It appears that Lowrance no longer supplies the Jepp updates for their 1000 and 2000C GPS units. > > Will these updates be supplied by you for downloading? > > ======== > > Their response: > > Thank you for contacting us. We apologize for the long delay in responding to you > > Unfortunately, we have stopped all support on all Lowrance Units > > Lowrance has shut down there Aviation Group and we have no further word if they will continue! > > When they shut down, we stopped all Navdata Production for those units. > > I myself, have the Airmap 2000c and now it's a good paperweight! > > I'm forced to buy a Garmin > > > Sorry Sir > > ======================== > > > > > > > ________________________________________________________________________________
Date: Aug 22, 2010
Ron, I am completely wrong in my memories about the Icom PTT for their headset adapter (Icom part no. OPC-499). The plug is a monaural 1/8" (two contacts). This switch is connected to the microphone socket only. When the PTT is open the three contacts of the microphone socket are open to each other. When the switch is pressed the middle contact is connected to the ground contact. So, essentially I was completely full of c*** with my memories last night. Sorry for the misdirection. Rick On Sun, Aug 22, 2010 at 7:42 AM, Richard Girard wrote: > Sure Ron, happy to help. I'll do it this afternoon when it's too hot to be > outside anyway. What can I say, I'm a woose for this hot muggy weather. > > Rick > > > On Sun, Aug 22, 2010 at 12:16 AM, rparigoris wrote: > >> rparigor(at)suffolk.lib.ny.us> >> >> Hi Rick >> >> If your Icom has two switches and is making one connection and breaking >> another when you push the PTT, it is different than my Vertex that makes two >> connections. >> >> On my Vertex VXA700 when you push the PTT one switch connects the mic high >> to pin 3 (mic high), this is a normal opened switch. >> >> The other switch connects mic low to pin 2 (PTT high), this is a normal >> opened switch. >> >> Thus my single relay is a double pole relay that just makes two >> connections when the PTT is depressed. >> >> My double pole relay is doing exactly the same thing as pressing the >> premade harness PTT I have, when the PTT is depressed, two individual >> single pole switches make. >> >> Would you mind taking an ohm meter to your set up and report back if in >> fact one switch is making and one breaking? >> >> If it is in fact like my Vertex where both switches make, I will give Icom >> and pick their brains! >> >> Ron Parigoris >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=309709#309709 >> >> >> >> >> >> >> >> >> >> >> > > > -- > Zulu Delta > Kolb Mk IIIC > 582 Gray head > 4.00 C gearbox > 3 blade WD > Thanks, Homer GBYM > > It is not bigotry to be certain we are right; but it is bigotry to be > unable to imagine how we might possibly have gone wrong. > - G.K. Chesterton > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Aug 22, 2010
Subject: Re: New operations model for the AeroElectric Connection
At 09:37 PM 8/21/2010, you wrote: >Gee Bob, > >I would have to second that. Your book and this web site are worth >a lot more than I paid for it. I would be more inclined to send a >donation than ask for a refund. The service you render here has >undoubtedly saved lives and airframes. I think that referencing >back to B & C is a really reasonable idea. I hope you're right . . . for that is my intent. But I am obligated to make the offer. You may recall some years back when products I offered were cited by some individuals as poorly designed, a source of great consternation and even damage to airplanes suffered by numerous 'victims'. The assertions fell apart when I reminded my antagonists of our no questions asked, lifetime guarantee of satisfaction for any product or service. I had received no claims for adjustment under our warranty. In fact, I offered a cash reward on top of a refund of purchase price for any dissatisfied customer who would come forth with their story. Nobody did. I'm certain that the vast majority of folks on this list and in the OBAM aircraft community understand the value of what we all do for each other here. At the same time, there is a need to erect honorable defenses against a few folks who can be exceedingly troublesome. Thank you all for your support and votes of confidence. I'll strive to remain worthy of your offers by growing the value of my offerings. Bob . . . ________________________________________________________________________________
Date: Aug 22, 2010
At 08:10 AM 8/22/2010, you wrote: Bob, I bought the book a few years ago, and thought it was extraordinarily good value. Recently though I've been feeling as though I've been short-changing you, because I've asked so many questions recently and you've always answered them with an obvious amount of time and care. I don't think it's all that one-sided. I too find great value in participating here on the List. The exercise hones my own ability to utilize time, talent and resources well. It's a situation not unlike that which I tried to explain to my bosses when I asked for the funds to finance a few Kaypro II computers, printers and software for the GP-180 engineering group. We had three computers in the group . . . all personally owned and brought in from home. I also wanted to buy all hazards insurance on the computers and let the guys take them home at night. The argument was that they would acquire a lot of skill in their use but not while on the timeclock! In spite of their amazement and gratification for the work I produced on MY Kaypro, they were reluctant or just unable to make the connection between an ability to do a task, the uniqueness of the computer as a tool, an acquisition of skill in its use because it was interesting or even fun . . . and that folks were willing to learn it on their own time. My participation here has been most useful in my professional endeavors. The ability to teach is a skill that can always be improved upon and our conversations here have more value than might be immediately obvious. Every great golfer needs to hit balls every day. Every good teacher needs to exercise those skills every day too. Could you invite people to donate on a "donation-ware" basis? It's fairly common in software development -- you give something away for free and ask good folk to send a donation if they find it useful. It seems like an equitable way of doing business. I've considered that. Certainly the 'Connection could be offered in the same business model as donor supported shareware. I saw you have a PayPal setup for your online catalogue. Why not allow people to just randomly send you a few quid when they feel full of joy after hearing their master contactor clunk for the first time? Perhaps a page about it in the online version. The 'Connection is at a fork in the road . . . several forks. Alternatively, presumably anyone could buy an hour's time on your online system, though that sets the price in stone, and I think that donation-ware works best when people send what they can afford, or just what they feel like sending. I have added one-on-one, fee-for-service consulting to the website catalog and I do have a couple such projects in the works. Your suggestions are on-point and worthy of deliberation in planning for the future. Thanks! Bob . . . ________________________________________________________________________________
Date: Aug 22, 2010
Bob, The connection has been invaluable to me and countless others. I'm happy that you have embraced the new reality of distribution, and I think it will pay big rewards, no matter how you measure them. I would like to put in a vote in favor of not trying to lock your document. It will only frustrate legitimate users, and since there are easily available tools to unlock any kind of "DRM", the people that want to "steal" your work will not in any way be inconvenienced. I would argue that if someone wants to share a snippet of an idea from your excellent tome by doing a copy/paste from a section of the document, requiring that they retype the text adds negative value to the world, and can also result in problematic typos. Thanks again for all the help you have provided me in the wiring of my aircraft, and more usefully, understanding electricity! -- Mickey Coggins ________________________________________________________________________________
Date: Aug 22, 2010
> >I would argue that if someone wants to share a snippet of an idea >from your excellent tome by doing a copy/paste from a section of the >document, requiring that they retype the text adds negative value to >the world, and can also result in problematic typos. >-- >Mickey Coggins Point taken. Thanks! Bob . . . ________________________________________________________________________________
Date: Aug 22, 2010
Lowrance makes good products with quite good user interfaces. However, they have pulled that exact same trick with (at least) two of their street models, with no prior warning. Ever since Thales bought out Lowrance, this has occurred. David M. Kevin Boddicker wrote: > I found this out at OSH this year. Went to the Jepp tent to get an > update and was told that Lowrance did not have a contract with Jepp > and they could not do anything with my card. I don't know if, as a > class of owners, there is anything that can be done legally, but I do > know morally, Lowrance leaves a lot to be desired. Good business > people don't just sever support without a warning and support for at > least three years or so. > I do also know that I will tell everyone I know NOT to buy Lowrance > for their marine or other needs. Put doubt in their minds! Will > Lowrance be there when you need them???? I found out! > Kevin Boddicker > Luana, IA > TriQ 200 N7868B > > On Aug 22, 2010, at 6:09 AM, David & Elaine Lamphere wrote: > >> Bob, >> That's what I am trying to warn about, there are *NO* *updates >> available from Lowrance or Jeppeson for the 2000*!!! >> Us Lowrance owners are out in the cold, unless there is some boot-leg >> hacker somewhere that figures out something else... >> Bummer! >> Dave >> >> ----- Original Message ----- >> *From:* bob noffs >> *To:* aeroelectric-list(at)matronics.com >> >> *Sent:* Sunday, August 22, 2010 6:20 AM >> *Subject:* Re: AeroElectric-List: Lowrance Airmap GPS Updates >> >> i have a 2 yr old 2000 that will fly for the first time this >> fall. what would you recommend for getting the latest update >> available for vfr? lowrance? >> bob noffs >> >> On Sat, Aug 21, 2010 at 4:10 PM, David & Elaine Lamphere >> > wrote: >> >> I was asked to forward this information on in case you guys >> hadn't heard.... >> Please be advised - not only does Lowrance NOT make/sell any >> more Aviation GPS units, you cannot get >> a Jeppeson navdata update for them either! I just looked at >> the LEI site - no updates since April. >> I then sent a note to Jeppeson to see if they would supply >> any data updates for Lowrance units. >> Below is the query and dismal answer: >> ================================= >> To: Support@JeppDirect >> Subject: Data updates >> >> It appears that Lowrance no longer supplies the Jepp updates >> for their 1000 and 2000C GPS units. >> >> Will these updates be supplied by you for downloading? >> >> ======== >> >> Their response: >> >> *Thank you for contacting us. We apologize for the long delay >> in responding to you* >> >> *Unfortunately, we have stopped all support on all Lowrance >> Units* >> >> *Lowrance has shut down there Aviation Group and we have no >> further word if they will continue!* >> >> *When they shut down, we stopped all Navdata Production for >> those units.* >> >> *I myself, have the Airmap 2000c and now it's a good >> paperweight! * >> >> *I'm forced to buy a Garmin* >> >> ** >> >> *Sorry Sir* >> >> *========================* >> >> >> * >> * >> >> * >> >> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> >> * >> > > * > > > * ________________________________________________________________________________
Date: Aug 22, 2010
Perceived Value? Then I need to send you another check! Stan Sutterfield Anyone who has recently purchased a book or CD at current prices who feels short changed by the price reduction is encouraged to drop us a line. Our warranty offers a guarantee of perceived value for the lifetime of any product. Drop us a note and we'll make it right with you. ________________________________________________________________________________
Date: Aug 22, 2010
FYI The David Clark PTT switch works the same way-disconnects the MIC until the PTT is pushed. I don't know why this is essential... it might be that for battery powered equipment, it reduces current drain (the mic bias) until required. Sometimes it becomes "because that's the way we've always done it". Bob may know better. As for the relay snubber, the diode can be added somewhere else. It's a low power relay, so the amount of coil energy involved is small-- a regular diode works fine. Good Luck V -------------------------------------------------- From: "rparigoris" <rparigor(at)suffolk.lib.ny.us> Sent: Saturday, August 21, 2010 6:52 PM Subject: AeroElectric-List: Re: Vertex VXA700 information needed > > > Hi Vern > > We purchased an adapter cable and an external PTT switch when we purchased > our VXA700. > > We ohmed out the harness and it indeed has two separate switches, one > connects mic high when you push PTT, and the other switch grounds PTT > high. > > I have a schematic for VXA 700 that Vertex support sent us, it does not > include enough information to figure out why the harness would use two > switches to do what they are doing. > > After several calls and finally cornered the support guy, he bowed out by > saying Vertex doesn't make the harness and can't comment on it. He said > the VXA 700 is not intended to be hooked up to an audio panel. > > I know that when we hook up the VXA 700 to our PMA4000 audio panel and use > the harness I have with external PTT switch it works fine. > > I talked to PS Engineering and told him I wanted to use the mini DPDT > relay as you can see on the right side near coin on second pic I posted to > replicate two mechanical switches. I asked him if he thought it was OK to > supply power to the coil of relay and have PMA4000 do the grounding when I > push the PTT that is located on sticks and he thought that would be fine. > > Someone knows why my harness uses two separate switches to transmit. > Vertex support does not know why. PS Engineering does not know why. I do > not know why. > > I do know that the two switch arrangement works fine. My partner is an EE > and thinks it best we replicate what we do know. His gut feeling is > leaving mic connected all the time may not be a good thing to do. Perhaps > someone could speculate why they may do this? Built into unit is a speaker > and mic. > > Anyway there's our reasoning how and why we connected the four wire Vertex > plug to our audio panel. > > You mention it may be a good idea to install a diode across the relay > coil. We already finished harness and it would be a big effort to open up > harness and get close to relay to install diode. > > You can see size of relay against a penny on the right side: > http://www.europaowners.org/forums/gallery2.php?g2_itemId=81445&g2_imageViewsIndex=1 > > You can enlarge the pic to full size by selecting full size on top right > of screen. The specifics are listed on schematic about the relay we are > using. There is no mA draw of coil on information we have but it is not > very much of a draw. Could get information off the data sheet. > > My question to you is what potential problem or problems could be caused > by not using a diode across the coil of this mini relay? > > Do you think I should try harness as it is wired and if we experience a > problem/s you describe, then install a diode? > > Or perhaps go half way between the two and install a diode about 6" away > from the relay? BTW we are supplying power to the relay coil through a 324 > wire that is about 20# long. > > I also have some snapjacks on hand if you think that a better choice. > > Ron Parigoris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309694#309694 > > > > Checked by AVG - www.avg.com > 06:35:00 > ________________________________________________________________________________
Date: Aug 22, 2010
Subject: Re: firewall shields... yet again
Date: Aug 22, 2010
Connection At 06:23 PM 8/22/2010, you wrote: > >Perceived Value? Then I need to send you another check! No. We made a deal and I'm happy with it. If you got more than you bargained for then I'm more pleased still. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Subject: B&C alt voltage goes right up to 16V
Date: Aug 22, 2010
I installed a b&c alt on an o200 with the PMR1C-14. After about 10 hrs on it with no problems one morning, after the airplane sat out in the rain, the voltage started going right up to 16V at takeoff power tripping the crowbar OV protection. I have not played with the setpoint since it was working fine at the beginning (stayed just under 14v) so it should not have changed. I can't see that water got into the regulator as it is potted in epoxy or similar. My battery acts fine, takes a charge in a reasonable amount of time and my volt meter is correct as I checked it with another and the crowbar goes off and just the right voltage. What could cause this? -------- Scott Black Montreal Jodel F11 O-200 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309831#309831 ________________________________________________________________________________
Date: Aug 22, 2010
All I can do is offer to return the favor, Bob, if you ever need any machine work for a project, I'd be happy to help. My little Kolb continues to fly along with zero electrical issues. Security like that is absolutely priceless, IMHO. Rick Girard On Sun, Aug 22, 2010 at 9:53 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:23 PM 8/22/2010, you wrote: > > > Perceived Value? Then I need to send you another check! > > > No. We made a deal and I'm happy with it. > If you got more than you bargained for > then I'm more pleased still. > > Bob . . . > //// > (o o) > ===========o00o=(_)=o00o======== > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ================================ > > * > > * > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: Avionics Master switch
From: "tomcostanza" <Tom(at)CostanzaAndAssociates.com>
Date: Aug 23, 2010
Before everyone yawns and says, "Not another question about avionics master switches", I'll ask you to indulge me. Suppose I had a "friend", who was paranoid about blowing-up his $10,000 WAAS gps, and $20,000 glass panel, and hadn't read Bob's epistles about fault tolerance specs, etc. But this "friend" didn't want the single point failure of an avionics master switch. Suppose also, that he had a progressive master switch (Off - Batt only/alternator field off - On/alternator field on). Why couldn't this "friend" shut down by turning off the master switch before shutting down the engine? Is this the bugaboo that the non-Aeroelectric crowd fears? ie. Is the sudden collapse of the alternator field the culprit everyone fears, or is it the limbo-like state of the alternator as the engine rpm winds down after pulling the mixture they fear? Would this procedure raise more concerns than it eased? I once had an instructor that shut off the alternator field and looked for a hiccup on the ammeter as part of a pre-takeoff check (avionics on at this point). This was the same instructor that "enlightened" me about the reason for shutting off all avionics before starting and before shutting down the engine. -------- Clear Skies, Tom Costanza Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309853#309853 ________________________________________________________________________________
Subject: Re: B&C alt voltage goes right up to 16V
Date: Aug 23, 2010
You confirmed that there is indeed an over-voltage condition. The voltage regulator is not doing its job, for whatever reason. The rain may or may not be a factor. Perhaps the regulator got too hot at some point. If you can not adjust the output voltage to within normal range, then the voltage regulator should be replaced. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309876#309876 ________________________________________________________________________________
Date: Aug 23, 2010
There is another possibility, depending on where in the circuit the voltage regulator measures the voltage. If there is a high resistance in the field circuit, the regulator might be seeing a lower voltage than is at the main bus. In that case, the regulator would tell the alternator to put out more. Make sure that all of the connections in the electrical system are secure, especially in the regulator sense and field circuits. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309881#309881 ________________________________________________________________________________
Subject: testing of backup alternator
Date: Aug 23, 2010
Bob, your recently responded to a couple of posts from Jared Yates, who was asking (in part) about testing of the backup alternator in a Z-13/8 sys tem. Cant speak for Jared, but Im not sure his real question was effectively answered and I am interested in this as well,, so thought I would follo w up. How do I go about assuring myself that my SD-8 will work as advert ised when called upon? Can I just turn off the master, flip on the switches for the SD-8 and the e-bus alternate feed, and wait to see if I get a low voltage warning light on my engine monitor? Can I do this on the groun d at idle, or do I need to have the RPM elevated? Feeling a bit boneheaded about this, but would be more boneheaded to not ask, and find out later my SD-8 was providing no backup at all. thanks for your service Erich Weaver ________________________________________________________________________________
Date: Aug 23, 2010
Subject: Re: Avionics Master switch
At 05:45 AM 8/23/2010, you wrote: > > >Before everyone yawns and says, "Not another question about avionics >master switches", I'll ask you to indulge me. > >Suppose I had a "friend", who was paranoid about blowing-up his >$10,000 WAAS gps, and $20,000 glass panel, and hadn't read Bob's >epistles about fault tolerance specs, etc. But this "friend" didn't >want the single point failure of an avionics master switch. Suppose >also, that he had a progressive master switch (Off - Batt >only/alternator field off - On/alternator field on). Why couldn't >this "friend" shut down by turning off the master switch before >shutting down the engine? Is this the bugaboo that the >non-Aeroelectric crowd fears? ie. Is the sudden collapse of the >alternator field the culprit everyone fears, or is it the limbo-like >state of the alternator as the engine rpm winds down after pulling >the mixture they fear? Would this procedure raise more concerns than it eased? No, the #1 "radio killer" is supposed to be the starter. Have you read? http://aeroelectric.com/articles/avmaster.pdf If one really wants an Avionics Master, it's easily added in series with the normal feed-path diode without major impact to failure mode effects analysis. There are but four energy sources that the designer needs to consider when configuring the electrical system. (1) Battery: Limited total energy but capable of great current due to low internal impedance. (2) Engine Driven Power: Usually an alternator capable of great total energy but current limited due magnetics and internal impedances. (3) Direct Lightning Strikes: Most light aircraft designers don't strive for resistance to lightning strokes. Lots of current, arcing, but again, not as much energy in the stroke as your alternator puts out in twenty minutes or so or the battery can deliver in a complete dumping of charge. (4) All other reactive sources are low energy, short duration events, routinely trapped off as a matter of design and qualification. Risks from battery and alternator faults have been easily managed by proper wire sizes, fuse/breaker sizes, ov-protection on the alternator. Legacy design goals call for designing to expect, withstand and make graceful recovery from events that lie within this envelope http://www.aeroelectric.com/Pictures/Curves/MSTD704_28V_Trans.jpg I can tell you that starting the engine does not exceed this recommendation. We also limit abnormal events to this envelope http://www.aeroelectric.com/Pictures/Curves/MSTD704_28V_OV.jpg . . . which is no big deal. >I once had an instructor that shut off the alternator field and >looked for a hiccup on the ammeter as part of a pre-takeoff check >(avionics on at this point). This was the same instructor that >"enlightened" me about the reason for shutting off all avionics >before starting and before shutting down the engine. He was simply repeating the mantra handed down to him by his teachers. I have gone on spike hunting expeditions on airplanes from C-150 to BeechJets and failed to see anything that exceeded the design goal limits . . . in fact, aside from starter inrush brownout . . . http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1_2.gif http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1.jpg http://www.aeroelectric.com/Pictures/Curves/95_GMC_Safari_3.gif http://www.aeroelectric.com/Pictures/Curves/95_GMC_Safari_1.gif http://www.aeroelectric.com/Pictures/Curves/turbine_start_a.jpg The rest of the things you see on the bus are exceedingly un-exciting. http://www.aeroelectric.com/Pictures/Curves/Safari_Bus_Noise_1.gif http://www.aeroelectric.com/Pictures/Curves/Safari_Bus_Noise_2.gif Bob . . . ________________________________________________________________________________
Date: Aug 23, 2010
At 10:23 PM 8/22/2010, you wrote: > >I installed a b&c alt on an o200 with the PMR1C-14. After about 10 >hrs on it with no problems one morning, after the airplane sat out >in the rain, the voltage started going right up to 16V at takeoff >power tripping the crowbar OV protection. I have not played with the >setpoint since it was working fine at the beginning (stayed just >under 14v) so it should not have changed. I can't see that water got >into the regulator as it is potted in epoxy or similar. My battery >acts fine, takes a charge in a reasonable amount of time and my volt >meter is correct as I checked it with another and the crowbar goes >off and just the right voltage. What could cause this? Only a failure within the PMR1C-14. Suggest you return it to B&C for a checkup. Bob . . . ________________________________________________________________________________
Date: Aug 23, 2010
Connection At 10:17 PM 8/22/2010, you wrote: >All I can do is offer to return the favor, Bob, if you ever need any >machine work for a project, I'd be happy to help. Do you have a mill with a digital readout? > My little Kolb continues to fly along with zero electrical issues. > Security like that is absolutely priceless, IMHO. Great news! Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Aug 23, 2010
At 09:19 AM 8/23/2010, you wrote: > >There is another possibility, depending on where in the circuit the >voltage regulator measures the voltage. If there is a high >resistance in the field circuit, the regulator might be seeing a >lower voltage than is at the main bus. In that case, the regulator >would tell the alternator to put out more. Make sure that all of >the connections in the electrical system are secure, especially in >the regulator sense and field circuits. The PMR1C-14 is a more robust version of the rectifier/regulators supplied with the majority of 20A or smaller PM alternators. VERY simple, and senses voltage right at the output lead of the regulator. If this particular regulator is misbehaving, it's unlikely that the problem lies outside the device. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Aug 23, 2010
Subject: Re: testing of backup alternator
At 01:46 PM 8/23/2010, you wrote: >Bob, your recently responded to a couple of posts from Jared Yates, >who was asking (in part) about testing of the backup alternator in a >Z-13/8 system. Cant speak for Jared, but Im not sure his real >question was effectively answered and I am interested in this as >well,, so thought I would follow up. How do I go about assuring >myself that my SD-8 will work as advertised when called upon? Can I >just turn off the master, flip on the switches for the SD-8 and the >e-bus alternate feed, and wait to see if I get a low voltage warning >light on my engine monitor? Can I do this on the ground at idle, or >do I need to have the RPM elevated? Feeling a bit boneheaded about >this, but would be more boneheaded to not ask, and find out later my >SD-8 was providing no backup at all. You can turn alternators on/off at any time under any conditions without regard to system safety or hazard to other components. The SD-8 does need a lot of RPM to produce full output. I doubt that you want to run a full-throttle preflight. During mag test you can turn the main alternator off and the SD-8 on. If the loadmeter shows ANY significant output, the alternator is probably fine even if low voltage warnings continue and the SD-8 output is less than 8-10 amps that you can expect at cruise. You can also wait until airborne and go to the SD-8 supported E-bus mode to test the system under more realistic conditions before you get too far from home. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Aug 24, 2010
Subject: GPS outage in fiberglass plane
I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board. I have the following problem. On the ground, panel mounted Garmin 430 and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes and I lose GPS signal on both almost simultaneously. Sometimes I get GPS signal back, sometimes I don't. Sometimes when I get GPS signal back it is intermittent. When I look at the 396 GPS page, it doesn't show ANY signal on ANY satellite. Sometime around touchdown I get GPS back ... I'm not really looking until taxiway, so don't know when, but ON the ground GPS seems to always be able to acquire. Two recent sample flights. Depart both GPSs working, then 40 minutes into flight, both drop GPS at about same time. This is a 2:20 flight. After another 30 minutes, 430 picks up satellites and maintains through rest of flight. The 396 doesn't pick up satellites until back on the ground. Return flight, both GPSs working on ground. Sometime around 30-40 minutes into flight, both drop GPS at about same time. After 1 hour - 1:15, the 396 reacquires satellites. The 430 never reacquires until back on ground. Notes: * The 396 is new to me. I had borrowed it previously on occasion and had similar occurrence twice. This was a few years back and, if I recall, both occurrences were an hour or more into flight. * The 430 was recently upgraded from 430 to 430W, but I'm still flying on the 430 antenna. As stated above, had problem before, but it seems MUCH more consistent now. * I had flight following on one of these occurrences and asked center if there was know problem. Answer was NO and about 3 planes on station reported no problems. * Both flights above, there was much humidity in the air and I was under a lowish cloud deck. I don't recall conditions on previous events. * I've tried using 396 plugged into cigarette lighter and running only on battery and it makes no difference. Any thoughts? Thanks, Jeff ________________________________________________________________________________
Subject: Re: GPS outage in fiberglass plane
Date: Aug 24, 2010
Jeff, First, you need to upgrade the antenna on the 430 to a WAAS antenna and ensure the antenna cable length is correct for proper performance of the 430. Now, on to the GPS signal problem. Some questions: 1. What are you using for the 396 antenna? Rod attached to the 396 or a remote antenna? If a remote antenna, what type? 2. Are the two units using a single antenna or do each have their own antenna? 3. How and where is/are the antenna/s located and mounted? 4. How is/are the antenna/s cabling routed? Looking for pinches or other defects in routing which could cause intermittent failures. 5. What is the condition of the antenna cable connection to the GPS units? Perhaps answers to these will help the troubleshoot. Good luck, Bob Borger Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232 http://www.biplaneforumgallery.com/index.php?cat=10046 Europa Flying! 3705 Lynchburg Dr. Corinth, TX 76208 Home: 940-497-2123 Cel: 817-992-1117 On Aug 24, 2010, at 5:54, Jeffrey Bougher wrote: > I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board. > > I have the following problem. On the ground, panel mounted Garmin 430 and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes and I lose GPS signal on both almost simultaneously. Sometimes I get GPS signal back, sometimes I don't. Sometimes when I get GPS signal back it is intermittent. When I look at the 396 GPS page, it doesn't show ANY signal on ANY satellite. Sometime around touchdown I get GPS back ... I'm not really looking until taxiway, so don't know when, but ON the ground GPS seems to always be able to acquire. > > Two recent sample flights. > Depart both GPSs working, then 40 minutes into flight, both drop GPS at about same time. This is a 2:20 flight. After another 30 minutes, 430 picks up satellites and maintains through rest of flight. The 396 doesn't pick up satellites until back on the ground. > > Return flight, both GPSs working on ground. Sometime around 30-40 minutes into flight, both drop GPS at about same time. After 1 hour - 1:15, the 396 reacquires satellites. The 430 never reacquires until back on ground. > > Notes: > * The 396 is new to me. I had borrowed it previously on occasion and had similar occurrence twice. This was a few years back and, if I recall, both occurrences were an hour or more into flight. > * The 430 was recently upgraded from 430 to 430W, but I'm still flying on the 430 antenna. As stated above, had problem before, but it seems MUCH more consistent now. > * I had flight following on one of these occurrences and asked center if there was know problem. Answer was NO and about 3 planes on station reported no problems. > * Both flights above, there was much humidity in the air and I was under a lowish cloud deck. I don't recall conditions on previous events. > * I've tried using 396 plugged into cigarette lighter and running only on battery and it makes no difference. > > Any thoughts? > > Thanks, > Jeff > > > > > ________________________________________________________________________________
Date: Aug 24, 2010
Something else that you might want to look at is the antenna cable length; in the MGL instrument this is a very specific length that comes already prepared with the antenna. The instructions say not to cut this but to bundle it; some people do cut the cable and shorten it but this seriously degrades the performance of the GPS as the cable is a tuned length. Not sure if this applies to other GPS makes but its likely, so check that the cable is as per the original factory specification. Jay _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert Borger Sent: 24 August 2010 03:05 PM Subject: Re: AeroElectric-List: GPS outage in fiberglass plane Jeff, First, you need to upgrade the antenna on the 430 to a WAAS antenna and ensure the antenna cable length is correct for proper performance of the 430. Now, on to the GPS signal problem. Some questions: 1. What are you using for the 396 antenna? Rod attached to the 396 or a remote antenna? If a remote antenna, what type? 2. Are the two units using a single antenna or do each have their own antenna? 3. How and where is/are the antenna/s located and mounted? 4. How is/are the antenna/s cabling routed? Looking for pinches or other defects in routing which could cause intermittent failures. 5. What is the condition of the antenna cable connection to the GPS units? Perhaps answers to these will help the troubleshoot. Good luck, Bob Borger Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232 http://www.biplaneforumgallery.com/index.php?cat=10046 Europa Flying! 3705 Lynchburg Dr. Corinth, TX 76208 Home: 940-497-2123 Cel: 817-992-1117 On Aug 24, 2010, at 5:54, Jeffrey Bougher wrote: I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board. I have the following problem. On the ground, panel mounted Garmin 430 and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes and I lose GPS signal on both almost simultaneously. Sometimes I get GPS signal back, sometimes I don't. Sometimes when I get GPS signal back it is intermittent. When I look at the 396 GPS page, it doesn't show ANY signal on ANY satellite. Sometime around touchdown I get GPS back ... I'm not really looking until taxiway, so don't know when, but ON the ground GPS seems to always be able to acquire. Two recent sample flights. Depart both GPSs working, then 40 minutes into flight, both drop GPS at about same time. This is a 2:20 flight. After another 30 minutes, 430 picks up satellites and maintains through rest of flight. The 396 doesn't pick up satellites until back on the ground. Return flight, both GPSs working on ground. Sometime around 30-40 minutes into flight, both drop GPS at about same time. After 1 hour - 1:15, the 396 reacquires satellites. The 430 never reacquires until back on ground. Notes: * The 396 is new to me. I had borrowed it previously on occasion and had similar occurrence twice. This was a few years back and, if I recall, both occurrences were an hour or more into flight. * The 430 was recently upgraded from 430 to 430W, but I'm still flying on the 430 antenna. As stated above, had problem before, but it seems MUCH more consistent now. * I had flight following on one of these occurrences and asked center if there was know problem. Answer was NO and about 3 planes on station reported no problems. * Both flights above, there was much humidity in the air and I was under a lowish cloud deck. I don't recall conditions on previous events. * I've tried using 396 plugged into cigarette lighter and running only on battery and it makes no difference. Any thoughts? Thanks, Jeff href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matro nics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution ________________________________________________________________________________
Date: Aug 24, 2010
I don't think it would affect the 396, but I don't understand why your avionics shop would leave the original antenna in place. It is not the same as the antenna for the 430W and I'm surprised it works at all. John Grosse Jay Hyde wrote: > > Something else that you might want to look at is the antenna cable > length; in the MGL instrument this is a very specific length that > comes already prepared with the antenna. The instructions say not to > cut this but to bundle it; some people do cut the cable and shorten it > but this seriously degrades the performance of the GPS as the cable is > a tuned length. > > Not sure if this applies to other GPS makes but its likely, so check > that the cable is as per the original factory specification. > > Jay > > ------------------------------------------------------------------------ > > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > *Robert Borger > *Sent:* 24 August 2010 03:05 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: GPS outage in fiberglass plane > > Jeff, > > First, you need to upgrade the antenna on the 430 to a WAAS antenna > and ensure the antenna cable length is correct for proper performance > of the 430. > > Now, on to the GPS signal problem. Some questions: > > 1. What are you using for the 396 antenna? Rod attached to the 396 or > a remote antenna? If a remote antenna, what type? > > 2. Are the two units using a single antenna or do each have their own > antenna? > > 3. How and where is/are the antenna/s located and mounted? > > 4. How is/are the antenna/s cabling routed? Looking for pinches or > other defects in routing which could cause intermittent failures. > > 5. What is the condition of the antenna cable connection to the GPS units? > > Perhaps answers to these will help the troubleshoot. > > Good luck, > > Bob Borger > > Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S > > http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232 > > http://www.biplaneforumgallery.com/index.php?cat=10046 > > Europa Flying! > > 3705 Lynchburg Dr. > > Corinth, TX 76208 > > Home: 940-497-2123 > > Cel: 817-992-1117 > > > On Aug 24, 2010, at 5:54, Jeffrey Bougher wrote: > > > I fly a purchased Velocity. I'm about 1/3 through Bob's book and > generally not good with electrical issues - hence the book. What I > have learned is that there is a lot of knowledge on this board. > > I have the following problem. On the ground, panel mounted Garmin 430 > and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes > and I lose GPS signal on both almost simultaneously. Sometimes I get > GPS signal back, sometimes I don't. Sometimes when I get GPS signal > back it is intermittent. When I look at the 396 GPS page, it doesn't > show ANY signal on ANY satellite. Sometime around touchdown I get GPS > back ... I'm not really looking until taxiway, so don't know when, but > ON the ground GPS seems to always be able to acquire. > > Two recent sample flights. > Depart both GPSs working, then 40 minutes into flight, both drop GPS > at about same time. This is a 2:20 flight. After another 30 minutes, > 430 picks up satellites and maintains through rest of flight. The 396 > doesn't pick up satellites until back on the ground. > > Return flight, both GPSs working on ground. Sometime around 30-40 > minutes into flight, both drop GPS at about same time. After 1 hour - > 1:15, the 396 reacquires satellites. The 430 never reacquires until > back on ground. > > Notes: > * The 396 is new to me. I had borrowed it previously on occasion and > had similar occurrence twice. This was a few years back and, if I > recall, both occurrences were an hour or more into flight. > * The 430 was recently upgraded from 430 to 430W, but I'm still flying > on the 430 antenna. As stated above, had problem before, but it seems > MUCH more consistent now. > * I had flight following on one of these occurrences and asked center > if there was know problem. Answer was NO and about 3 planes on > station reported no problems. > * Both flights above, there was much humidity in the air and I was > under a lowish cloud deck. I don't recall conditions on previous events. > * I've tried using 396 plugged into cigarette lighter and running only > on battery and it makes no difference. > > Any thoughts? > > Thanks, > Jeff > > * * > * * > *href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List* > *href="http://forums.matronics.com">http://forums.matronics.com* > *href="http://www.matronics.com/contribution">http://www.matronics.com/contribution* > * * > > * > > > * ________________________________________________________________________________
Date: Aug 24, 2010
The most common cause of loss of satellites (besides military jamming) is com or nav frequencies that interfere from other radios in the cockpit. The AC20-138A for GPS install calls out the frequencies that must be tested before a unit can be signed off in the aircraft. On 8/24/2010 7:24 AM, John Grosse wrote: > > > I don't think it would affect the 396, but I don't understand why your > avionics shop would leave the original antenna in place. It is not the > same as the antenna for the 430W and I'm surprised it works at all. > > John Grosse > > Jay Hyde wrote: >> >> Something else that you might want to look at is the antenna cable >> length; in the MGL instrument this is a very specific length that >> comes already prepared with the antenna. The instructions say not to >> cut this but to bundle it; some people do cut the cable and shorten >> it but this seriously degrades the performance of the GPS as the >> cable is a tuned length. >> >> Not sure if this applies to other GPS makes but its likely, so check >> that the cable is as per the original factory specification. >> >> Jay >> >> ------------------------------------------------------------------------ >> >> *From:* owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of >> *Robert Borger >> *Sent:* 24 August 2010 03:05 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: GPS outage in fiberglass plane >> >> Jeff, >> >> First, you need to upgrade the antenna on the 430 to a WAAS antenna >> and ensure the antenna cable length is correct for proper performance >> of the 430. >> >> Now, on to the GPS signal problem. Some questions: >> >> 1. What are you using for the 396 antenna? Rod attached to the 396 >> or a remote antenna? If a remote antenna, what type? >> >> 2. Are the two units using a single antenna or do each have their own >> antenna? >> >> 3. How and where is/are the antenna/s located and mounted? >> >> 4. How is/are the antenna/s cabling routed? Looking for pinches or >> other defects in routing which could cause intermittent failures. >> >> 5. What is the condition of the antenna cable connection to the GPS >> units? >> >> Perhaps answers to these will help the troubleshoot. >> >> Good luck, >> >> Bob Borger >> >> Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S >> >> http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232 >> >> http://www.biplaneforumgallery.com/index.php?cat=10046 >> >> Europa Flying! >> >> 3705 Lynchburg Dr. >> >> Corinth, TX 76208 >> >> Home: 940-497-2123 >> >> Cel: 817-992-1117 >> >> >> >> On Aug 24, 2010, at 5:54, Jeffrey Bougher wrote: >> >> >> >> I fly a purchased Velocity. I'm about 1/3 through Bob's book and >> generally not good with electrical issues - hence the book. What I >> have learned is that there is a lot of knowledge on this board. >> >> I have the following problem. On the ground, panel mounted Garmin >> 430 and portable Garmin 396 work fine. Take-off and fly for 20-45 >> minutes and I lose GPS signal on both almost simultaneously. >> Sometimes I get GPS signal back, sometimes I don't. Sometimes when I >> get GPS signal back it is intermittent. When I look at the 396 GPS >> page, it doesn't show ANY signal on ANY satellite. Sometime around >> touchdown I get GPS back ... I'm not really looking until taxiway, so >> don't know when, but ON the ground GPS seems to always be able to >> acquire. >> >> Two recent sample flights. >> Depart both GPSs working, then 40 minutes into flight, both drop GPS >> at about same time. This is a 2:20 flight. After another 30 >> minutes, 430 picks up satellites and maintains through rest of >> flight. The 396 doesn't pick up satellites until back on the ground. >> >> Return flight, both GPSs working on ground. Sometime around 30-40 >> minutes into flight, both drop GPS at about same time. After 1 hour >> - 1:15, the 396 reacquires satellites. The 430 never reacquires >> until back on ground. >> >> Notes: >> * The 396 is new to me. I had borrowed it previously on occasion and >> had similar occurrence twice. This was a few years back and, if I >> recall, both occurrences were an hour or more into flight. >> * The 430 was recently upgraded from 430 to 430W, but I'm still >> flying on the 430 antenna. As stated above, had problem before, but >> it seems MUCH more consistent now. >> * I had flight following on one of these occurrences and asked center >> if there was know problem. Answer was NO and about 3 planes on >> station reported no problems. >> * Both flights above, there was much humidity in the air and I was >> under a lowish cloud deck. I don't recall conditions on previous >> events. >> * I've tried using 396 plugged into cigarette lighter and running >> only on battery and it makes no difference. >> >> Any thoughts? >> >> Thanks, >> Jeff >> >> * * >> * * >> *href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List* >> >> *href="http://forums.matronics.com">http://forums.matronics.com* >> *href="http://www.matronics.com/contribution">http://www.matronics.com/contribution* >> >> * * >> >> * >> >> >> * > > ________________________________________________________________________________
Date: Aug 24, 2010
Jeff, I've had interference issues when two GPS active patch antennas were co-located on the glareshield - neither would acquire until one was turned off or moved a good bit away. I figured out what was up when I added the second GPS antenna (for an APRS tracker) and the Garmin 296 suddenly went "blind." Locating the tracker GPS puck antenna in the aft baggage area (perhaps 3.5 feet line of sight from the Garmin antenna) has completely solved the issue. Just a thought. Not sure why your problem only appears once airborne - that is most curious. Bill Boyd RV-6A On Tue, Aug 24, 2010 at 6:54 AM, Jeffrey Bougher wrote: > I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally > not good with electrical issues - hence the book. What I have learned is > that there is a lot of knowledge on this board. > > I have the following problem. On the ground, panel mounted Garmin 430 and > portable Garmin 396 work fine. Take-off and fly for 20-45 minutes and I > lose GPS signal on both almost simultaneously. Sometimes I get GPS signal > back, sometimes I don't. Sometimes when I get GPS signal back it is > intermittent. When I look at the 396 GPS page, it doesn't show ANY signal > on ANY satellite. Sometime around touchdown I get GPS back ... I'm not > really looking until taxiway, so don't know when, but ON the ground GPS > seems to always be able to acquire. > > Two recent sample flights. > Depart both GPSs working, then 40 minutes into flight, both drop GPS at > about same time. This is a 2:20 flight. After another 30 minutes, 430 > picks up satellites and maintains through rest of flight. The 396 doesn't > pick up satellites until back on the ground. > > Return flight, both GPSs working on ground. Sometime around 30-40 minutes > into flight, both drop GPS at about same time. After 1 hour - 1:15, the 396 > reacquires satellites. The 430 never reacquires until back on ground. > > Notes: > * The 396 is new to me. I had borrowed it previously on occasion and had > similar occurrence twice. This was a few years back and, if I recall, both > occurrences were an hour or more into flight. > * The 430 was recently upgraded from 430 to 430W, but I'm still flying on > the 430 antenna. As stated above, had problem before, but it seems MUCH > more consistent now. > * I had flight following on one of these occurrences and asked center if > there was know problem. Answer was NO and about 3 planes on station > reported no problems. > * Both flights above, there was much humidity in the air and I was under a > lowish cloud deck. I don't recall conditions on previous events. > * I've tried using 396 plugged into cigarette lighter and running only on > battery and it makes no difference. > > Any thoughts? > > Thanks, > Jeff > > * > > * > > ________________________________________________________________________________
Date: Aug 24, 2010
First, the 430W antenna is not compatible with the 430 and the fact that you had a problem before pretty much narrows it down to a bad and/or incorrect antenna. Where are your antennas located? What else is in close proximity to the them? I would suggest you make sure you have the correct antenna for each unit and it is placed where it will not be next to other electrical devices and has a good view of the sky. Fiberglass should only attenuate the signal very slightly and for our purposes can be considered not there. Assuming there is not some kind of special coatings on the glass. I'm just guessing here but could you have the 2 antennas mixed up? Tim Andres _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeffrey Bougher Sent: Tuesday, August 24, 2010 3:54 AM Subject: AeroElectric-List: GPS outage in fiberglass plane I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board. I have the following problem. On the ground, panel mounted Garmin 430 and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes and I lose GPS signal on both almost simultaneously. Sometimes I get GPS signal back, sometimes I don't. Sometimes when I get GPS signal back it is intermittent. When I look at the 396 GPS page, it doesn't show ANY signal on ANY satellite. Sometime around touchdown I get GPS back ... I'm not really looking until taxiway, so don't know when, but ON the ground GPS seems to always be able to acquire. Two recent sample flights. Depart both GPSs working, then 40 minutes into flight, both drop GPS at about same time. This is a 2:20 flight. After another 30 minutes, 430 picks up satellites and maintains through rest of flight. The 396 doesn't pick up satellites until back on the ground. Return flight, both GPSs working on ground. Sometime around 30-40 minutes into flight, both drop GPS at about same time. After 1 hour - 1:15, the 396 reacquires satellites. The 430 never reacquires until back on ground. Notes: * The 396 is new to me. I had borrowed it previously on occasion and had similar occurrence twice. This was a few years back and, if I recall, both occurrences were an hour or more into flight. * The 430 was recently upgraded from 430 to 430W, but I'm still flying on the 430 antenna. As stated above, had problem before, but it seems MUCH more consistent now. * I had flight following on one of these occurrences and asked center if there was know problem. Answer was NO and about 3 planes on station reported no problems. * Both flights above, there was much humidity in the air and I was under a lowish cloud deck. I don't recall conditions on previous events. * I've tried using 396 plugged into cigarette lighter and running only on battery and it makes no difference. Any thoughts? Thanks, Jeff Checked by AVG - www.avg.com 11:34:00 ________________________________________________________________________________
Date: Aug 24, 2010
Yes, my old Bridgeport has a DRO, but I just use dial indicators on my lathe when I have to work to better than a thousandth or so. Rick On Mon, Aug 23, 2010 at 11:38 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > At 10:17 PM 8/22/2010, you wrote: > >> All I can do is offer to return the favor, Bob, if you ever need any >> machine work for a project, I'd be happy to help. >> > > Do you have a mill with a digital readout? > > My little Kolb continues to fly along with zero electrical issues. >> Security like that is absolutely priceless, IMHO. >> > > Great news! > > > Bob . . . > //// > (o o) > ===========o00o=(_)=o00o======== > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ================================ > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Aug 24, 2010
On Tue, Aug 24, 2010 at 6:54 AM, Jeffrey Bougher wrote: I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board. I have the following problem. On the ground, panel mounted Garmin 430 and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes and I lose GPS signal on both almost simultaneously. Sometimes I get GPS signal back, sometimes I don't. Sometimes when I get GPS signal back it is intermittent. When I look at the 396 GPS page, it doesn't show ANY signal on ANY satellite. Sometime around touchdown I get GPS back ... I'm not really looking until taxiway, so don't know when, but ON the ground GPS seems to always be able to acquire. Thanks, Jeff My thought would be to operate your GPS on it's inernal battery, and when it fails, turn off your master switch to kill everything electrical, so the only thing still running is the engine. If the GPS comes back, then it is probably something in the panel, if it doesn't start working then the problem may be in the GPS. If it is in the panel, you can then go through a process of elimination by restoring power to the panel and shutting down each electronic device individually until the problem goes away. Roger ________________________________________________________________________________
Date: Aug 24, 2010
Nope, separate antennas. This is what baffles me. The only think they share in common is that they are GPSs, they are made by Garmin and they are in my plane :^). That is why I made sure on one trip that the 396 was not even plugged into the cigarette lighter - still lost signal at same time as 430. Jeff ________________________________ From: S. Ramirez <simon(at)synchdes.com> Cc: Jeffrey Bougher Sent: Tue, August 24, 2010 7:24:46 AM Subject: Re: AeroElectric-List: GPS outage in fiberglass plane Since both units drop out at the same time, Jeff, I will assume that they share the same antenna and thus lose signal somehow, probably due to vibration. Can you please confirm that the 430 and 396 are using the same antenna? Thanks. Simon Ramirez Oviedo, FL USA On 8/24/2010 6:54 AM, Jeffrey Bougher wrote: I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board. > >I have the following problem. On the ground, panel mounted Garmin 430 >and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes >and I lose GPS signal on both almost simultaneously. Sometimes I get >GPS signal back, sometimes I don't. Sometimes when I get GPS signal >back it is intermittent. When I look at the 396 GPS page, it doesn't >show ANY signal on ANY satellite. Sometime around touchdown I get GPS >back ... I'm not really looking until taxiway, so don't know when, but >ON the ground GPS seems to always be able to acquire. > >Two recent sample flights. >Depart both GPSs working, then 40 minutes into flight, both drop GPS >at about same time. This is a 2:20 flight. After another 30 minutes, >430 picks up satellites and maintains through rest of flight. The 396 >doesn't pick up satellites until back on the ground. > >Return flight, both GPSs working on ground. Sometime around 30-40 >minutes into flight, both drop GPS at about same time. After 1 hour - >1:15, the 396 reacquires satellites. The 430 never reacquires until >back on ground. > >Notes: >* The 396 is new to me. I had borrowed it previously on occasion and >had similar occurrence twice. This was a few years back and, if I >recall, both occurrences were an hour or more into flight. >* The 430 was recently upgraded from 430 to 430W, but I'm still flying >on the 430 antenna. As stated above, had problem before, but it seems >MUCH more consistent now. >* I had flight following on one of these occurrences and asked center >if there was know problem. Answer was NO and about 3 planes on >station reported no problems. >* Both flights above, there was much humidity in the air and I was >under a lowish cloud deck. I don't recall conditions on previous >events. >* I've tried using 396 plugged into cigarette lighter and running only >on battery and it makes no difference. > >Any thoughts? > >Thanks, >Jeff > > ________________________________________________________________________________
Date: Aug 24, 2010
I had a similar problem with my 496. It worked perfectly, but every once in a while would lose sall atellites and they would stay gone (no signal bars) for minutes at a time - even many minutes. I didn't spend a lot of time worrying about it since my plane is VFR and I can live without the GPS in the local area. One time I was far from home and it happened and that is how I stumbled on the problem. I had to revert to VOR navigation and while I was tuning the NAV radio I noticed that I could make the GPS signal come back. I noticed that when I tuned the NAV2 VOR receiver in my plane to 114.1 (or any frequency around it) that would completely kill the GPS. All other VOR frequencies worked fine. Sometimes it would be completely killed, and sometimes small bars would remain. What must be happening is that the local oscialltor in the TKM nav radio must have a harmonic that lands right on the GPS frequency. You could watch the signal bars go away on the GPS when you tuned the NAV radio. The handheld antenna on the 496 wasn't helping things, since I was able to show that that was how the interference was getting into the GPS. I suspect some other piece of equipment in your plane is interfering with your GPS. When the GPS(s) fail, start turning things off or tuning them to different frequencies. You'll find it. Good Luck, dave ----- Original Message ----- From: "Jeffrey Bougher" <jsbougher(at)yahoo.com> Sent: Tuesday, August 24, 2010 3:53:49 PM GMT -06:00 US/Canada Central Subject: Re: AeroElectric-List: GPS outage in fiberglass plane Nope, separate antennas. This is what baffles me. The only think they share in common is that they are GPSs, they are made by Garmin and they are in my plane :^). That is why I made sure on one trip that the 396 was not even plugged into the cigarette lighter - still lost signal at same time as 430. Jeff From: S. Ramirez <simon(at)synchdes.com> Cc: Jeffrey Bougher Sent: Tue, August 24, 2010 7:24:46 AM Subject: Re: AeroElectric-List: GPS outage in fiberglass plane Since both units drop out at the same time, Jeff, I will assume that they share the same antenna and thus lose signal somehow, probably due to vibration. Can you please confirm that the 430 and 396 are using the same antenna? Thanks. Simon Ramirez Oviedo, FL USA On 8/24/2010 6:54 AM, Jeffrey Bougher wrote: I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board. I have the following problem. On the ground, panel mounted Garmin 430 and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes and I lose GPS signal on both almost simultaneously. Sometimes I get GPS signal back, sometimes I don't. Sometimes when I get GPS signal back it is intermittent. When I look at the 396 GPS page, it doesn't show ANY signal on ANY satellite. Sometime around touchdown I get GPS back ... I'm not really looking until taxiway, so don't know when, but ON the ground GPS seems to always be able to acquire. Two recent sample flights. Depart both GPSs working, then 40 minutes into flight, both drop GPS at about same time. This is a 2:20 flight. After another 30 minutes, 430 picks up satellites and maintains through rest of flight. The 396 doesn't pick up satellites until back on the ground. Return flight, both GPSs working on ground. Sometime around 30-40 minutes into flight, both drop GPS at about same time. After 1 hour - 1:15, the 396 reacquires satellites. The 430 never reacquires until back on ground. Notes: * The 396 is new to me. I had borrowed it previously on occasion and had similar occurrence twice. This was a few years back and, if I recall, both occurrences were an hour or more into flight. * The 430 was recently upgraded from 430 to 430W, but I'm still flying on the 430 antenna. As stated above, had problem before, but it seems MUCH more consistent now. * I had flight following on one of these occurrences and asked center if there was know problem. Answer was NO and about 3 planes on station reported no problems. * Both flights above, there was much humidity in the air and I was under a lowish cloud deck. I don't recall conditions on previous events. * I've tried using 396 plugged into cigarette lighter and running only on battery and it makes no difference. Any thoughts? Thanks, Jeff ________________________________________________________________________________
Date: Aug 24, 2010
Also the coax on the 430w is much higher quality shielding than that a called out in the 430 install. If you don't have the 430w antenna, you really don't have a 430w! Bob Mitchell Twin comanche 42tp Garmin 430w Garmin 496 Sent from my iPad On Aug 24, 2010, at 4:40 PM, dave.gribble(at)mchsi.com wrote: > > I had a similar problem with my 496. It worked perfectly, but every once in a while would lose sall atellites and they would stay gone (no signal bars) for minutes at a time - even many minutes. > > I didn't spend a lot of time worrying about it since my plane is VFR and I can live without the GPS in the local area. One time I was far from home and it happened and that is how I stumbled on the problem. I had to revert to VOR navigation and while I was tuning the NAV radio I noticed that I could make the GPS signal come back. I noticed that when I tuned the NAV2 VOR receiver in my plane to 114.1 (or any frequency around it) that would completely kill the GPS. All other VOR frequencies worked fine. Sometimes it would be completely killed, and sometimes small bars would remain. > > What must be happening is that the local oscialltor in the TKM nav radio must have a harmonic that lands right on the GPS frequency. You could watch the signal bars go away on the GPS when you tuned the NAV radio. The handheld antenna on the 496 wasn't helping things, since I was able to show that that was how the interference was getting into the GPS. > > I suspect some other piece of equipment in your plane is interfering with your GPS. When the GPS(s) fail, start turning things off or tuning them to different frequencies. You'll find it. > > > Good Luck, > > dave > > ----- Original Message ----- > From: "Jeffrey Bougher" <jsbougher(at)yahoo.com> > To: "S. Ramirez" , aeroelectric-list(at)matronics.com > Sent: Tuesday, August 24, 2010 3:53:49 PM GMT -06:00 US/Canada Central > Subject: Re: AeroElectric-List: GPS outage in fiberglass plane > > > > Nope, separate antennas. This is what baffles me. The only think they share in common is that they are GPSs, they are made by Garmin and they are in my plane :^). That is why I made sure on one trip that the 396 was not even plugged into the cigarette lighter - still lost signal at same time as 430. > Jeff > > > > > From: S. Ramirez <simon(at)synchdes.com> > To: aeroelectric-list(at)matronics.com > Cc: Jeffrey Bougher > Sent: Tue, August 24, 2010 7:24:46 AM > Subject: Re: AeroElectric-List: GPS outage in fiberglass plane > > Since both units drop out at the same time, Jeff, I will assume that they share the same antenna and thus lose signal somehow, probably due to vibration. Can you please confirm that the 430 and 396 are using the same antenna? > > Thanks. > > Simon Ramirez > Oviedo, FL USA > > > On 8/24/2010 6:54 AM, Jeffrey Bougher wrote: > > > > I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board. > > I have the following problem. On the ground, panel mounted Garmin 430 and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes and I lose GPS signal on both almost simultaneously. Sometimes I get GPS signal back, sometimes I don't. Sometimes when I get GPS signal back it is intermittent. When I look at the 396 GPS page, it doesn't show ANY signal on ANY satellite. Sometime around touchdown I get GPS back ... I'm not really looking until taxiway, so don't know when, but ON the ground GPS seems to always be able to acquire. > > Two recent sample flights. > Depart both GPSs working, then 40 minutes into flight, both drop GPS at about same time. This is a 2:20 flight. After another 30 minutes, 430 picks up satellites and maintains through rest of flight. The 396 doesn't pick up satellites until back on the ground. > > Return flight, both GPSs working on ground. Sometime around 30-40 minutes into flight, both drop GPS at about same time. After 1 hour - 1:15, the 396 reacquires satellites. The 430 never reacquires until back on ground. > > Notes: > * The 396 is new to me. I had borrowed it previously on occasion and had similar occurrence twice. This was a few years back and, if I recall, both occurrences were an hour or more into flight. > * The 430 was recently upgraded from 430 to 430W, but I'm still flying on the 430 antenna. As stated above, had problem before, but it seems MUCH more consistent now. > * I had flight following on one of these occurrences and asked center if there was know problem. Answer was NO and about 3 planes on station reported no problems. > * Both flights above, there was much humidity in the air and I was under a lowish cloud deck. I don't recall conditions on previous events. > * I've tried using 396 plugged into cigarette lighter and running only on battery and it makes no difference. > > Any thoughts? > > Thanks, > Jeff > > > > > > > ________________________________________________________________________________
Date: Aug 25, 2010
Wow, thanks for all the comments and suggestions ... I had to get a notepad out to write them all down. I think I have answers to most questions. To troubleshoot, two suggestions that I'm definitely going to follow are: 1) Move the 396 antenna further from 430 antenna - I'll stick in armpit pocket in back seat - nothing but think fiberglass and some fabric between it and sky. 2) Next time it occurs, try changing radio frequencies one by one, I will include transponder. If this doesn't work, try killing each radio sequentially to see if that helps. 3) If above doesn't work, kill all electric and see if 396 picks up satellites. Now, to answer a few questions and see if this brings more light to the problem: * When I had 430W upgrade, I got new antenna. The puck mount is a smidge different so I need to modify mount on plane. Avionics shop said 430 would work fine with old antenna, but it wouldn't be a 430W. * The 430 antenna is mounted directly under the front access panel. It is probably within 1 foot of battery and ELT antenna. The 396 antenna is a Garmin remote antenna and sits on the glare shield - maybe 2 feet horizontally from the 430 antenna. * The 430 antenna has a pretty straight shot directly to radio. Cable was fabricated by avionics shop. It was replaced about 5 years ago when I had complete GPS failure due to bad wire ... mode this time is different (intermittent). The 396 antenna is also 5 years old, but in a little worse shape since it is not mounted and gets handled much more. The * The 396 antenna sits immediately next to the XM antenna on the glare shield. Both are routes somewhat haphazardly around the edge of the glareshield. I would say they are trapped between edge of glareshield and sidewall, but they are not pinched. The 396 cable has never been modified Final note, my experience means that I don't really trust GPS. I've stayed pretty good at flying VORs and always have 2 flight plans on my knee board - direct and VOR. Fortunately, I have a DME which makes VOR flying much easier. Unfortunately I don't have an RNAV like I used to have in my Cessna. I LOVED the RNAV and was going to put one in my Velocity, but had several people tell me they were maintenance nightmares. So far, the 430 has been the most troublesome part of my aircraft ownership experience. When it works it is all sugar and sunshine, when it goes out, it back to the VORs. On 8/24/2010 6:54 AM, Jeffrey Bougher wrote: I fly a purchased Velocity. I'm about 1/3 through Bob's book and generally not good with electrical issues - hence the book. What I have learned is that there is a lot of knowledge on this board. > >I have the following problem. On the ground, panel mounted Garmin 430 >and portable Garmin 396 work fine. Take-off and fly for 20-45 minutes >and I lose GPS signal on both almost simultaneously. Sometimes I get >GPS signal back, sometimes I don't. Sometimes when I get GPS signal >back it is intermittent. When I look at the 396 GPS page, it doesn't >show ANY signal on ANY satellite. Sometime around touchdown I get GPS >back ... I'm not really looking until taxiway, so don't know when, but >ON the ground GPS seems to always be able to acquire. > >Two recent sample flights. >Depart both GPSs working, then 40 minutes into flight, both drop GPS >at about same time. This is a 2:20 flight. After another 30 minutes, >430 picks up satellites and maintains through rest of flight. The 396 >doesn't pick up satellites until back on the ground. > >Return flight, both GPSs working on ground. Sometime around 30-40 >minutes into flight, both drop GPS at about same time. After 1 hour - >1:15, the 396 reacquires satellites. The 430 never reacquires until >back on ground. > >Notes: >* The 396 is new to me. I had borrowed it previously on occasion and >had similar occurrence twice. This was a few years back and, if I >recall, both occurrences were an hour or more into flight. >* The 430 was recently upgraded from 430 to 430W, but I'm still flying >on the 430 antenna. As stated above, had problem before, but it seems >MUCH more consistent now. >* I had flight following on one of these occurrences and asked center >if there was know problem. Answer was NO and about 3 planes on >station reported no problems. >* Both flights above, there was much humidity in the air and I was >under a lowish cloud deck. I don't recall conditions on previous >events. >* I've tried using 396 plugged into cigarette lighter and running only >on battery and it makes no difference. > >Any thoughts? > >Thanks, >Jeff > > ________________________________________________________________________________
Subject: GRT EIS-Fuel Sender
Date: Aug 25, 2010
Ive installed my senders (resistance type) and routed the 4.7v excitation and the required resistor to the sender Heres my question: How is it safe to route 4.7 volts to a fuel tank with current traveling through the tank? Spark kaboom? Is there something Im missing? -------- One Rivet at a Time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310086#310086 ________________________________________________________________________________
Date: Aug 25, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
I'd note that in the case of the 430W antenna (I understand you are using 430 antenna), a minimum level for the antenna coax is specified. A straight shot may not be ideal. The length of cable in all GPS antenna seems to be something to pay attention to (either reference installation manual or leave supplied coax alone and coil as required). I'm amazed at your experience because it's so different from mine. I've been using GPS since the very beginning (racing gliders adopted it day one because it circumvented some competitive rules regarding on board navigation). Equipped my Maule with a certified Garmin 300XL (crude by 430 standards), got my rating, and logged plenty of actual behind it. Still have a 396 in the Maule which was a signicant upgrade to the 300XL panel. All of the above has performed flawlessly from day 1. The 300XL was professionally installed. The rest of it was pretty ad hoc. I'm looking forward to limiting my ground based NAV to proficiency work in an almost flying RV10. You are really going to like your setup once you get it working reliably. Bill Jeffrey Bougher wrote: > Wow, thanks for all the comments and suggestions ... I had to get a > notepad out to write them all down. I think I have answers to most > questions. To troubleshoot, two suggestions that I'm definitely going > to follow are: > 1) Move the 396 antenna further from 430 antenna - I'll stick in > armpit pocket in back seat - nothing but think fiberglass and some > fabric between it and sky. > 2) Next time it occurs, try changing radio frequencies one by one, I > will include transponder. If this doesn't work, try killing each > radio sequentially to see if that helps. > 3) If above doesn't work, kill all electric and see if 396 picks up > satellites. > > Now, to answer a few questions and see if this brings more light to > the problem: > * When I had 430W upgrade, I got new antenna. The puck mount is a > smidge different so I need to modify mount on plane. Avionics shop > said 430 would work fine with old antenna, but it wouldn't be a 430W. > * The 430 antenna is mounted directly under the front access panel. > It is probably within 1 foot of battery and ELT antenna. The 396 > antenna is a Garmin remote antenna and sits on the glare shield - > maybe 2 feet horizontally from the 430 antenna. > * The 430 antenna has a pretty straight shot directly to radio. Cable > was fabricated by avionics shop. It was replaced about 5 years ago > when I had complete GPS failure due to bad wire ... mode this time is > different (intermittent). The 396 antenna is also 5 years old, but in > a little worse shape since it is not mounted and gets handled much > more. The > * The 396 antenna sits immediately next to the XM antenna on the glare > shield. Both are routes somewhat haphazardly around the edge of the > glareshield. I would say they are trapped between edge of glareshield > and sidewall, but they are not pinched. The 396 cable has never been > modified > > Final note, my experience means that I don't really trust GPS. I've > stayed pretty good at flying VORs and always have 2 flight plans on my > knee board - direct and VOR. Fortunately, I have a DME which makes > VOR flying much easier. Unfortunately I don't have an RNAV like I > used to have in my Cessna. I LOVED the RNAV and was going to put one > in my Velocity, but had several people tell me they were maintenance > nightmares. So far, the 430 has been the most troublesome part of my > aircraft ownership experience. When it works it is all sugar and > sunshine, when it goes out, it back to the VORs. > > On 8/24/2010 6:54 AM, Jeffrey Bougher wrote: >> I fly a purchased Velocity. I'm about 1/3 through Bob's book and >> generally not good with electrical issues - hence the book. What I >> have learned is that there is a lot of knowledge on this board. >> >> I have the following problem. On the ground, panel mounted Garmin >> 430 and portable Garmin 396 work fine. Take-off and fly for 20-45 >> minutes and I lose GPS signal on both almost simultaneously. >> Sometimes I get GPS signal back, sometimes I don't. Sometimes when I >> get GPS signal back it is intermittent. When I look at the 396 GPS >> page, it doesn't show ANY signal on ANY satellite. Sometime around >> touchdown I get GPS back ... I'm not really looking until taxiway, so >> don't know when, but ON the ground GPS seems to always be able to >> acquire. >> >> Two recent sample flights. >> Depart both GPSs working, then 40 minutes into flight, both drop GPS >> at about same time. This is a 2:20 flight. After another 30 >> minutes, 430 picks up satellites and maintains through rest of >> flight. The 396 doesn't pick up satellites until back on the ground. >> >> Return flight, both GPSs working on ground. Sometime around 30-40 >> minutes into flight, both drop GPS at about same time. After 1 hour >> - 1:15, the 396 reacquires satellites. The 430 never reacquires >> until back on ground. >> >> Notes: >> * The 396 is new to me. I had borrowed it previously on occasion and >> had similar occurrence twice. This was a few years back and, if I >> recall, both occurrences were an hour or more into flight. >> * The 430 was recently upgraded from 430 to 430W, but I'm still >> flying on the 430 antenna. As stated above, had problem before, but >> it seems MUCH more consistent now. >> * I had flight following on one of these occurrences and asked center >> if there was know problem. Answer was NO and about 3 planes on >> station reported no problems. >> * Both flights above, there was much humidity in the air and I was >> under a lowish cloud deck. I don't recall conditions on previous events. >> * I've tried using 396 plugged into cigarette lighter and running >> only on battery and it makes no difference. >> >> Any thoughts? >> >> Thanks, >> Jeff >> >> * >> >> >> * > > * > > > * ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 9 Msgs - 08/23/10
Date: Aug 25, 2010
Er ------Original Message------ From: AeroElectric-List Digest Server Sender: owner-aeroelectric-list-server(at)matronics.com ReplyTo: aeroelectric-list(at)matronics.com Subject: AeroElectric-List Digest: 9 Msgs - 08/23/10 Sent: Aug 24, 2010 00:55 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete AeroElectric-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the AeroElectric-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-08-23&Archive=AeroElectric Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 10-08-23&Archive=AeroElectric =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- AeroElectric-List Digest Archive --- Total Messages Posted Mon 08/23/10: 9 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 03:46 AM - Avionics Master switch (tomcostanza) 2. 06:40 AM - Re: B&C alt voltage goes right up to 16V (user9253) 3. 07:19 AM - Re: B&C alt voltage goes right up to 16V (user9253) 4. 11:49 AM - testing of backup alternator (Erich_Weaver(at)urscorp.com) 5. 09:38 PM - Re: Avionics Master switch (Robert L. Nuckolls, III) 6. 09:38 PM - Re: B&C alt voltage goes right up to 16V (Robert L. Nuckolls, III) 7. 09:41 PM - Re: Re: New operations model for the AeroElectric Connection (Robert L. Nuckolls, III) 8. 09:51 PM - Re: Re: B&C alt voltage goes right up to 16V (Robert L. Nuckolls, III) 9. 09:56 PM - Re: testing of backup alternator (Robert L. Nuckolls, III) ________________________________ Message 1 _____________________________________ Subject: AeroElectric-List: Avionics Master switch From: "tomcostanza" <Tom(at)CostanzaAndAssociates.com> Before everyone yawns and says, "Not another question about avionics master switches", I'll ask you to indulge me. Suppose I had a "friend", who was paranoid about blowing-up his $10,000 WAAS gps, and $20,000 glass panel, and hadn't read Bob's epistles about fault tolerance specs, etc. But this "friend" didn't want the single point failure of an avionics master switch. Suppose also, that he had a progressive master switch (Off - Batt only/alternator field off - On/alternator field on). Why couldn't this "friend" shut down by turning off the master switch before shutting down the engine? Is this the bugaboo that the non-Aeroelectric crowd fears? ie. Is the sudden collapse of the alternator field the culprit everyone fears, or is it the limbo-like state of the alternator as the engine rpm winds down after pulling the mixture they fear? Would this procedure raise more concerns than it eased? I once had an instructor that shut off the alternator field and looked for a hiccup on the ammeter as part of a pre-takeoff check (avionics on at this point). This was the same instructor that "enlightened" me about the reason for shutting off all avionics before starting and before shutting down the engine. -------- Clear Skies, Tom Costanza Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309853#309853 ________________________________ Message 2 _____________________________________ Subject: AeroElectric-List: Re: B&C alt voltage goes right up to 16V From: "user9253" <fran4sew(at)banyanol.com> You confirmed that there is indeed an over-voltage condition. The voltage regulator is not doing its job, for whatever reason. The rain may or may not be a Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
From: "Dennis & Anne Glaeser" <glaesers(at)wideopenwest.com>
Subject: Re: GRT EIS-Fuel Sender
Date: Aug 25, 2010
That type of circuit, especially at the low voltage and current levels, is not a spark hazard. There are thousands of planes that have been flying for many years with this type of fuel level sender. Stick 'em in and worry about the cost of the gas you're trying to ignite instead :-) Dennis -------------------------------- From: MHerder Date: Wed Aug 25 - 7:16 AM Ive installed my senders (resistance type) and routed the 4.7v excitation and the required resistor to the sender Heres my question: How is it safe to route 4.7 volts to a fuel tank with current traveling through the tank? Spark kaboom? Is there something Im missing? ________________________________________________________________________________
Date: Aug 26, 2010
At 09:13 AM 8/25/2010, you wrote: >"MHerder" > >Ive installed my senders (resistance type) and >routed the 4.7v excitation and the required resistor to the sender > >Heres my question: > >How is it safe to route 4.7 volts to a fuel tank >with current traveling through the tank? Spark kaboom? > >Is there something I'm missing? Cars have been running "current" into the fuel tanks for monitoring liquid level for a lot of years. See: http://www.aeroelectric.com/Reference_Docs/Patents/Circa_1923_Fuel_Gage.pdf While the stuff in the tank is indeed combustible, the range of conditions over which it becomes hazardous in storage does have boundaries. As long as there is any liquid fuel in a tank, the vapor above the liquid is close to saturated. I.e., a long ways away from the ideal stoichiometric ratio where ignition is easiest and the burning most violent. Further, even in ideal ratios of fuel and oxygen, the ignition source has to present a minimum packet of energy in order to trigger the chain reaction that is burning or even an explosion. Devices incapable of delivering these energy levels (adjusted for headroom) are called "intrinsically safe" . . . meaning that there are no combinations where the total system becomes hazardous. For example, the energy that flows in components of a capacity fuel sensor falls in the intrinsically safe category. Variable resistors adjusted by floats and paired with the right gages are also intrinsically safe. But assuming you put a real "sparker" in the tank, you're still not going to get a hazardous mixture until after all the liquid has evaporated and the remaining vapors are sufficiently diluted so as to approach the "oh s#$t" ratio. This just doesn't happen accidently in small airplanes. Doesn't happen in big airplanes either. This is why a "spark in the tank" hypothesis for any explosion aboard airplanes is unsupported by the physics or any demonstrable experiment. That "unusable fuel" has two important functions. (1) provide a low-spot for moisture collection and (2) keep the vapor in the tank saturated. So the short answer to your question is, don't worry about it. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Aug 26, 2010
Bob's answer with respect to explosive dangers with 100LL in the fuel tank is correct of course. If there is anyone out there thinking of diesel power, be aware that the situation with respect to jet fuel is different. Jet fuel vapor can easily reach explosive concentrations in a fuel tank and special venting requirements are usually recommended. See www.deltahawkengines.com/questi00.shtml#fuel for a discussion. On 08/26/2010 06:45 AM, Robert L. Nuckolls, III wrote: > > > At 09:13 AM 8/25/2010, you wrote: >> >> >> Ive installed my senders (resistance type) and routed the 4.7v >> excitation and the required resistor to the sender >> >> Heres my question: >> >> How is it safe to route 4.7 volts to a fuel tank with current >> traveling through the tank? Spark kaboom? >> >> Is there something I'm missing? > > Cars have been running "current" into the fuel > tanks for monitoring liquid level for a lot of > years. See: > > http://www.aeroelectric.com/Reference_Docs/Patents/Circa_1923_Fuel_Gage.pdf > > > While the stuff in the tank is indeed > combustible, the range of conditions over which > it becomes hazardous in storage does have > boundaries. > > As long as there is any liquid fuel > in a tank, the vapor above the liquid > is close to saturated. I.e., a long > ways away from the ideal stoichiometric > ratio where ignition is easiest and the > burning most violent. > > Further, even in ideal ratios of fuel > and oxygen, the ignition source has to present > a minimum packet of energy in order to trigger > the chain reaction that is burning or even > an explosion. Devices incapable of delivering > these energy levels (adjusted for headroom) are > called "intrinsically safe" . . . meaning > that there are no combinations where the total > system becomes hazardous. > > For example, the energy that flows in components > of a capacity fuel sensor falls in the intrinsically > safe category. Variable resistors adjusted by floats > and paired with the right gages are also intrinsically > safe. > > But assuming you put a real "sparker" in the > tank, you're still not going to get a hazardous > mixture until after all the liquid has evaporated > and the remaining vapors are sufficiently diluted > so as to approach the "oh s#$t" ratio. This just > doesn't happen accidently in small airplanes. > > Doesn't happen in big airplanes either. This is > why a "spark in the tank" hypothesis for any > explosion aboard airplanes is unsupported > by the physics or any demonstrable experiment. > > That "unusable fuel" has two important functions. > (1) provide a low-spot for moisture collection > and (2) keep the vapor in the tank saturated. > > So the short answer to your question is, don't > worry about it. > > > Bob . . . > //// > (o o) ________________________________________________________________________________
Subject: testing of backup alternator
Date: Aug 26, 2010
Erich, I didn't catch how many replies you had on this one. On my system I have a Dynon which monitors voltage internally and externally. Since I have the internal battery option, I can sit there with the SD-8 running (no interruption to the Dynon) and monitor the voltage activity on the master/essential bus via the Dynon. The key here is having something to monitor your system voltage that is not tied to switches and other things you've just lost when the alternator blows. That can come in many forms. I've seen some inexpensive LED panel voltage monitors that would do nicely. They're a nice feature to have when your world changes from inside the cockpit. A continued downward trend is warning enough to get down immediately. On the other hand you may feel you have enough output from the SD-8 to continue on to the next best/safest alternator shop (Pep Boys). Hopefully if you've reached that mode you've begun shutting off the air-conditioning, portable fridge, DVD etc. and are just running the minimums. On my ship the minimums take about 3-4 amps, Dynon, 1-radio, portable gps. Yes, the SD-8 seems to takes about a 1000 rpm to produce any sort of useable output. That may vary on your installation. If it's a sunny day I also have a solar charger to setup on the panel. That will at least power the GPS. And we're fly'n. Maybe the real question is whether it is worth real world testing - in my mind, absolutely. It's a great idea to test it in the air (better than on the ramp while your CHT's go through the roof) to see how much endurance you ultimately have. I would like to do the full test one day soon. Perhaps on a closed course over friendly terrain. I think most folks will wait for an emergency to perform the real test. In most cases that will be too late. It takes a bit of stomach to shut things down and really stretch the limit. I'm ok with that. You will want to land and re-start the main alternator after the test. From what I understand it's not recommended to re-start some of these alternators in flight. It may blow off the cowling and your firewall may melt. Best, Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Erich_Weaver(at)urscorp.com Sent: Monday, August 23, 2010 2:47 PM Subject: AeroElectric-List: testing of backup alternator Bob, your recently responded to a couple of posts from Jared Yates, who was asking (in part) about testing of the backup alternator in a Z-13/8 system. Cant speak for Jared, but Im not sure his real question was effectively answered and I am interested in this as well,, so thought I would follow up. How do I go about assuring myself that my SD-8 will work as advertised when called upon? Can I just turn off the master, flip on the switches for the SD-8 and the e-bus alternate feed, and wait to see if I get a low voltage warning light on my engine monitor? Can I do this on the ground at idle, or do I need to have the RPM elevated? Feeling a bit boneheaded about this, but would be more boneheaded to not ask, and find out later my SD-8 was providing no backup at all. thanks for your service Erich Weaver ________________________________________________________________________________
Date: Aug 26, 2010
Subject: Re: testing of backup alternator
On 08/26/2010 03:17 PM, longg(at)pjm.com wrote: > From what > I understand it's not recommended to re-start some of these alternators > in flight. It may blow off the cowling and your firewall may melt. Would absolutely love to see some real data to back up this claim... Can you point us to any references? Thanks, -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the New England Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: Aug 26, 2010
At 03:15 PM 8/26/2010, you wrote: > >On 08/26/2010 03:17 PM, longg(at)pjm.com wrote: > > From what > > I understand it's not recommended to re-start some of these alternators > > in flight. It may blow off the cowling and your firewall may melt. > > > Would absolutely love to see some real data to back up this claim... >Can you point us to any references? I've been testing alternators and generators on airplanes, laboratory test stands and an odd assortment of vehicles for 40+ years. We turn them on, off, no-load, full-load, you name it. Whether or not there's a battery on line. See chapter on engine driven power sources in: http://www.aeroelectric.com/Book/AEC12A_PDF.zip Having said that, there MAY be regulator characteristics (whether internal in or external) that present poor transient response without a battery on line. Indeed, this is one of the situations described by "load dump" in automotive parlance and "battery dump" in aviation parlance. Depending on how wildly the system behaves without a battery, SOME devices may be at risk if they're tied to the bus. This INCLUDES poorly designed regulators. This was the problem reported but not understood a few years back when some folks experienced alternator/regulator damage when switching a Z-24 system off with the alternator loaded. However, this is the exception. Bottom line is, as long as the battery stays tied to the alternator's b-lead, there's nothing you can do with switches on the panel that will hurt anything . . . In other words, transients generated by such activities do not exceed NORMAL operating transients as described in Mil-STD-704 and DO-160. Even with Z-24 configuration, an internally regulated alternator worth your hard-earned dollars is not at-risk for inadvertent switch positioning. Bob . . . ________________________________________________________________________________
Date: Aug 27, 2010
I definitely failed a John Deere PM regulator just by starting the engine on the ground with a totally dead battery. An immediate over voltage caused the crowbar OV module to trip the AC relay off, and the regulator evermore put out max voltage after the battery was recharged. I never have had a large capacitor in that system which might have helped. It was a sealed battery and they don't accept current for some time (if ever) when totally discharged. Undoubtedly the same failure would occur with a disconnected battery. Ken Robert L. Nuckolls, III wrote: > > > At 03:15 PM 8/26/2010, you wrote: >> >> On 08/26/2010 03:17 PM, longg(at)pjm.com wrote: >> > From what >> > I understand it's not recommended to re-start some of these alternators >> > in flight. It may blow off the cowling and your firewall may melt. >> >> >> Would absolutely love to see some real data to back up this >> claim... >> Can you point us to any references? > > I've been testing alternators and generators on airplanes, > laboratory test stands and an odd assortment of vehicles > for 40+ years. We turn them on, off, no-load, full-load, > you name it. Whether or not there's a battery on line. > See chapter on engine driven power sources in: > > http://www.aeroelectric.com/Book/AEC12A_PDF.zip > > Having said that, there MAY be regulator characteristics > (whether internal in or external) that present poor transient > response without a battery on line. Indeed, this is one > of the situations described by "load dump" in automotive > parlance and "battery dump" in aviation parlance. Depending > on how wildly the system behaves without a battery, SOME > devices may be at risk if they're tied to the bus. This > INCLUDES poorly designed regulators. This was the problem > reported but not understood a few years back when some > folks experienced alternator/regulator damage when switching > a Z-24 system off with the alternator loaded. However, > this is the exception. > > Bottom line is, as long as the battery stays tied to the > alternator's b-lead, there's nothing you can do with > switches on the panel that will hurt anything . . . > > In other words, transients generated by such activities > do not exceed NORMAL operating transients as described > in Mil-STD-704 and DO-160. Even with Z-24 configuration, > an internally regulated alternator worth your hard-earned > dollars is not at-risk for inadvertent switch positioning. > > Bob . . . > > ________________________________________________________________________________
Date: Aug 27, 2010
Subject: Re: Z-12 questions
At 11:52 PM 8/26/2010, you wrote: >Bob, > >I know you're a very busy man, so I hope I'm not imposing too much >by asking you a couple of questions. I'm hoping you can help shed >some light on these issues, for which I've been unable to find answers: No problem, it's what we do. > >1. My RV-8 will utilize a Z-12-based architecture, including a 60A >main alternator, and a 20A backup alternator from B&C mounted on the >vacuum pad. I am using the standard LR-3 and SB-1 alternator >controllers. My first question is: Does the "Aux Alternator" switch >normally stay ON during flight, so that the Aux alternator actually >provides power to the Main Bus all the time? Or should the switch >stay OFF, only to be switched on by the pilot in the event of a Main >alternator failure? The SB-1 alternator is specifically designed for STANDBY service and is normally installed with a setpoint down around 13.5 volts. Therefore, the second alternator installed for standby service is not intended to either share loads with the main alternator nor is it intended to charge the ship's battery. It's your option, you can leave it ON or OFF at all times for normal flight . . . if left ON, the SB-1 regulator will interpret the normal bus voltage of 14+ volts as "too high" and will completely relax thus driving the SB alternator field voltage to zero. In the event of main alternator shut down for any reason, the bus voltage would normally fall to battery support levels that start at about 12.5 volts and goes down from there. If the SB alternator is ON, this depression in bus votlage will cause the SB-1 regulator to wake up and bring the standby alternator into service. It will annunciate the fact by illuminating the SB ALT loaded light. If total loads on the SB alternator exceed 20A, the SB-1 will flash the warning light . . . the pilot is advised to reduce ship's electrical loads until flashing stops. If left OFF, you'll get a LO VOLTS warning light that prompts you to turn the sb alternator ON and then do the load-shedding exercise. > >2. My interpretation of the Z-12 architecture indicates that in the >event of a Main alternator failure, it would be the pilot's job to >manually load-shed the electrical system so that the total load was >below 20A. This is because the Aux alternator would feed the Main >Bus (and thence the Endurance Bus), so in the event of an Aux >alternator-only operation, most of the Main Bus items would have to >be turned off (or not used). My Endurance Bus will pull about 10A, >so I'd like to feed the Endurance Bus directly from the Aux >alternator (in addition to the normal feed path from the Main Bus). >That way, I could perform a quick, pre-selected load-shed operation >merely by turning off the Main Alternator switch and turning on the >Aux Alternator switch. (And, of course, I'd also have the E-Bus >Alternate feed from the Batt Bus, as a last-ditch backup.) So my >second question is: Is this a reasonable modification to the Z-12 >architecture? My goal is a simple, robust system, but I'd like the >convenience and pilot friendliness of a dirt-simple "load shed" >procedure, rather than a manual load-shed -- and having to ration >power to the Main Bus items. Then you're not talking about Z-12 (originally crafted to be a drop-in for type certificated aircraft that (1) doesn't have an e-bus and (2) would be exceedingly difficult under FAA rules to shuffle bus structures around. The system you're describing looks more like this http://tinyurl.com/24j8gh4 This is a more robust version of Z-13/8 where the 20A alternator is installed primarily to support an electrically dependent engine. No e-bus is shown because if you have a robust second alternator, there's no likelihood of needing to operate battery-only . . . that's two major failures on a single tank of fuel. Hence the simple direct connection for the sb alternator to the battery such that battery contactor failures are covered. "Last ditch" ???? You're spending too much time worrying about things that only happen in Hollywood's notions of how airplanes work. Modern alternators properly integrated into your airplane are very low failure rate items. It is unlikely that you will EVER find experience a pressing need to drop to SB alternator or a battery-only ops mode over the lifetime of your airplane. In 25 years of working with the OBAM aviation community, I've had but a handful of readers report that the s/b alternator or e-bus ops were found useful and functioned as advertised. If the airplane you're flying now is a TC aircraft, then it has no e-bus, no sb alternator, might even be a rented airplane where you have little knowledge of and zero control over ship's maintenance. This has always been my personal situation having never owned an airplane. So when I walk up to the airplane, I do it with the mind set that I don't care if the electrical system is going to work 100.0% of the time or not. I've got stuff in my flight bag that will allow me to operate any of the airplanes I fly in "J-3 mode" with a goal of aviating to airport of intended destination whether or not anything on the panel works. http://aeroelectric.com/Pictures/Misc/Failure_Tolerance.pdf No matter what electrical system is installed in your OBAM aircraft, the stuff in your flight bag should be similarly selected. If you've got smelly stuff in the cockpit that's suspiciously like wire or electrical accessory smoke, you might just want to shut everything off, dig out the REAL stand-by goodies and keep on truck'n. Actually, I've not turned a panel mounted nav radio on since I purchased my first hand-held GPS in '95. The $100 Magellans do 99% of everything I need the nav radio to do . . . how far, which direction, and ETA. Your questions give the distinct impression that you don't have much trust in the hardware for which you're crafting an architecture. Lack of trust comes from some combination of three conditions: (1) You KNOW you're installing certified junk on an airplane constrained by regulation to be forever less than the best we know how to do. (2) You don't personally possess a demonstrable, experience-based data set the confirms the reliability enjoyed by the OBAM aircraft community. (3) Your understanding of the system is diluted with a lot of extraneous noise exemplified by the majority of dark-n-stormy-night stories in the flying rags and the nail-biter scenarios dreamed up by Hollywood writers to make the actors look like the gods of failure mitigation. If you're crafting an airplane with an electrically dependent engine where all the engine support comes from the battery bus, then Z-08 is recommended. If your engine is not electrically dependent then Z-12 as depicted is recommended. When and if that low voltage warning light ever comes on, know that this is NOT an emergency You can finish your cup of coffee and decide what, if anything, you plan to do about it. The point is, there IS A PLAN that probably requires repositioning less than a half dozen switches until the light stops flashing. Hence, I'll suggest that your quest for "dirt simple" responses to a "last ditch" scenario are probably not a good investment of emotional capital or time. You need to tell us more about what equipment is installed on what kind of engine for the advice to me more specific. Bob . . . ________________________________________________________________________________
Date: Aug 27, 2010
At 07:28 AM 8/27/2010, you wrote: > >I definitely failed a John Deere PM regulator just by starting the >engine on the ground with a totally dead battery. >An immediate over voltage caused the crowbar OV module to trip the >AC relay off, Hmmm . . . It may be that the JD rectifier/regulator has some feature a bit short on robustness . . . but the scenario you describe is not one that immediately suggests this. It's a certainty that yard maintenance equipment is quite often jump-started into a dead battery. >and the regulator evermore put out max voltage after the battery was >recharged. This my have been an isolated failure. Have you replaced the r/r and found that everything works as expected? >I never have had a large capacitor in that system which might have helped. This would not have made any difference. >It was a sealed battery and they don't accept current for some time >(if ever) when totally discharged. Undoubtedly the same failure >would occur with a disconnected battery. Maybe, but does the owner's manual for any item of JD equipment caution against operations with a completely discharged but otherwise good battery? I'm not sure you have enough data about the manufacturer's design goals to arrive at this conclusion. Certainly the scenario you describe happens many times on perhaps thousands of mowers and tractors every summer . . . if they were blowing up R/R like popcorn, I have to believe there would be some scrambling around in the JD engineering community to fix it. Obviously, my earlier comment to this thread pertained only to wound-field alternators. The permanent magnet devices with rectifier/regulators are another breed of cat. Bob . . . ________________________________________________________________________________
Date: Aug 27, 2010
DJ, I do not but, based on Bob's generally reliable response I don't have to worry about pilot tales to complete my testing. As Bob indicated unless the battery is completely dead (not gonna happen in my case -on purpose - caus' the Lightspeed requires min 5 volts to run), I can safely switch on and off. That gives me the added comfort of continuing my flight say if the alt CB pops momentarily and I want to turn off the Alt to reset it. Naturally I'll only do that once in unknown circumstances. In most cases I could run a very long distance with the SD-8. One easy way to provide proof for yourself is to go out and do the tests. If so worried, turn off everything else first. If you don't know the limits of your machine, you don't know your machine. I'll be out testing. Glenn E. Long -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Thursday, August 26, 2010 4:15 PM Subject: Re: AeroElectric-List: testing of backup alternator On 08/26/2010 03:17 PM, longg(at)pjm.com wrote: > From what > I understand it's not recommended to re-start some of these alternators > in flight. It may blow off the cowling and your firewall may melt. Would absolutely love to see some real data to back up this claim... Can you point us to any references? Thanks, -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the New England Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: Aug 27, 2010
On 08/27/2010 10:31 AM, longg(at)pjm.com wrote: > One easy way to provide proof for yourself is to go out and do the > tests. If so worried, turn off everything else first. If you don't know > the limits of your machine, you don't know your machine. Hi Glenn, I've turned on and off the alternator with the engine running many times without incident. In particular, I was taking mild exception with your statements: >> From what >> I understand it's not recommended to re-start some of these > alternators >> in flight. It may blow off the cowling and your firewall may melt. which I do not believe are true, and was asking if there were any references where this had actually happened. I've certainly never heard of a cowling blowing off nor a firewall melting due to someone turning on their alternator... :-) Could be you were trying to be sarcastic, in which case I was hoping no one was actually thinking you were serious, and wanted to attempt to stop more Old Wives Tales on this topic... :-) Thanks, -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ Join us on the New England Aviation Forums - http://forum.deej.net/ ________________________________________________________________________________
Date: Aug 27, 2010
Yes a replacement regulator has worked perfectly for several hundred hours. You make a good point about the lawn equipment and dead batteries so maybe it was a one off failure. From what I've seen over the years though I think a dead flooded cell battery (as found in all the lawn equipment that I've seen) might have absorbed enough current to prevent the failure. So my theory is that the sealed AGM battery was the critical factor. It was a totally discharged battery. Anyway thought it might save someone a hundred dollars and some hassle to mention my experience. Ken Robert L. Nuckolls, III wrote: > > > At 07:28 AM 8/27/2010, you wrote: >> >> I definitely failed a John Deere PM regulator just by starting the >> engine on the ground with a totally dead battery. >> An immediate over voltage caused the crowbar OV module to trip the AC >> relay off, > > Hmmm . . . It may be that the JD rectifier/regulator > has some feature a bit short on robustness . . . but > the scenario you describe is not one that immediately > suggests this. It's a certainty that yard maintenance > equipment is quite often jump-started into a dead battery. > > >> and the regulator evermore put out max voltage after the battery was >> recharged. > > This my have been an isolated failure. Have you replaced > the r/r and found that everything works as expected? > >> I never have had a large capacitor in that system which might have >> helped. > > This would not have made any difference. > >> It was a sealed battery and they don't accept current for some time >> (if ever) when totally discharged. Undoubtedly the same failure would >> occur with a disconnected battery. > > Maybe, but does the owner's manual for any item > of JD equipment caution against operations with > a completely discharged but otherwise good battery? > I'm not sure you have enough data about the > manufacturer's design goals to arrive at this > conclusion. Certainly the scenario you describe > happens many times on perhaps thousands of mowers > and tractors every summer . . . if they were blowing > up R/R like popcorn, I have to believe there would > be some scrambling around in the JD engineering > community to fix it. > > Obviously, my earlier comment to this thread > pertained only to wound-field alternators. The > permanent magnet devices with rectifier/regulators > are another breed of cat. > > > Bob . . . > > > > ________________________________________________________________________________
Subject: Re: GPS outage in fiberglass plane
Date: Aug 27, 2010
This has been an interesting discussion to read through. I've had similar experiences with a Garmin 296 that had me baffled for a while. I first used my unit extensively on a Florida to Boston cross country flight in a LongEZ. Maybe I experienced a very brief lost of signal, but it was of no consequence. The unit provided excellent service. Then I started using it in a C172 and noticed a troubling occurence of dropouts. Tried new software, and different antenna. Eventually, I got to associate the dropouts with specific routes, some of which had known large ground antenna installations, so I thought it was just groundstation intereference. But no one I talked to seem to be experiencing GPS problems in the area. I have used the unit in another Cessna and while the dropouts were not at all as frequent, they still occurred unpredictably. I had lost faith in my GPS. I had learned from various sources that the navcoms could jam the GPS. So after reading this thread, I finally took the time to check this out. I had just come back from a flight during which the GPS performed flawlessly. While on the tiedown, with engine and everything running, I started to tune in the various com frequencies I use in my area. With the GPS screen set to show the sat reception bars, I quickly found that the bars would quickly pulse down to nothing when the frequency was set between 119.200 to 119.5. This was even without transmitting and it was dramatic. As it turns out, I am usually tuned within this frequency range when flying the routes I had associated with GPS loss. Since the G296 seems to work well in the LongEz, but with dropouts in the Cessna, the problem is with the Cessna radio and not the GPS. Not surprisingly, different radio installations have different RF signatures and tolerances. Maybe the Cessna radio is out of spec, maybe not, but it is good to know finally, what is causing my dropouts. Now if I'm lost and the GPS drops out, I know I can change frequencies or turn off the avionics and get re-oriented. --Jose Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310285#310285 ________________________________________________________________________________
Date: Aug 27, 2010
Interesting stuff. That's worth everyone with a GPS tucking away in the "for future reference" part of the brain. Thanks for taking the time to report this info. James On Fri, Aug 27, 2010 at 4:39 PM, Radioflyer wrote: > > This has been an interesting discussion to read through. I've had similar experiences with a Garmin 296 that had me baffled for a while. I first used my unit extensively on a Florida to Boston cross country flight in a LongEZ. Maybe I experienced a very brief lost of signal, but it was of no consequence. The unit provided excellent service. > > Then I started using it in a C172 and noticed a troubling occurence of dropouts. Tried new software, and different antenna. Eventually, I got to associate the dropouts with specific routes, some of which had known large ground antenna installations, so I thought it was just groundstation intereference. But no one I talked to seem to be experiencing GPS problems in the area. I have used the unit in another Cessna and while the dropouts were not at all as frequent, they still occurred unpredictably. I had lost faith in my GPS. > > I had learned from various sources that the navcoms could jam the GPS. So after reading this thread, I finally took the time to check this out. I had just come back from a flight during which the GPS performed flawlessly. While on the tiedown, with engine and everything running, I started to tune in the various com frequencies I use in my area. With the GPS screen set to show the sat reception bars, I quickly found that the bars would quickly pulse down to nothing when the frequency was set between 119.200 to 119.5. This was even without transmitting and it was dramatic. As it turns out, I am usually tuned within this frequency range when flying the routes I had associated with GPS loss. > > Since the G296 seems to work well in the LongEz, but with dropouts in the Cessna, the problem is with the Cessna radio and not the GPS. Not surprisingly, different radio installations have different RF signatures and tolerances. Maybe the Cessna radio is out of spec, maybe not, but it is good to know finally, what is causing my dropouts. Now if I'm lost and the GPS drops out, I know I can change frequencies or turn off the avionics and get re-oriented. > > --Jose > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310285#310285 > > ________________________________________________________________________________
Date: Aug 27, 2010
Subject: Re: Z-12 questions (corrections)
At 08:38 AM 8/27/2010, you wrote: >At 11:52 PM 8/26/2010, you wrote: >>Bob, >> >>I know you're a very busy man, so I hope I'm not imposing too much >>by asking you a couple of questions. I'm hoping you can help shed >>some light on these issues, for which I've been unable to find answers: > > No problem, it's what we do. >> >>1. My RV-8 will utilize a Z-12-based architecture, including a 60A >>main alternator, and a 20A backup alternator from B&C mounted on >>the vacuum pad. I am using the standard LR-3 and SB-1 alternator >>controllers. My first question is: Does the "Aux Alternator" switch >>normally stay ON during flight, so that the Aux alternator actually >>provides power to the Main Bus all the time? Or should the switch >>stay OFF, only to be switched on by the pilot in the event of a >>Main alternator failure? > > The SB-1 REGULATOR is specifically designed for STANDBY service > and is normally installed with a setpoint down around 13.5 volts. > Therefore, the second alternator installed for standby service USING THE SB-1 is not intended to either share loads with the main alternator nor is it intended to charge the ship's battery. > It's your option, you can leave it ON or OFF at all times for normal > flight . . . if left ON, the SB-1 regulator will interpret the > normal bus voltage of 14+ volts as "too high" and will completely > relax thus driving the SB alternator field voltage to zero. > > In the event of main alternator shut down for any reason, the > bus voltage would normally fall to battery support levels > that start at about 12.5 volts and goes down from there. > If the SB alternator is ON, this depression in bus votlage > will cause the SB-1 regulator to wake up and bring the > standby alternator into service. It will annunciate the fact > by illuminating the SB ALT loaded light. If total loads on > the SB alternator exceed 20A, the SB-1 will flash the warning > light . . . the pilot is advised to reduce ship's electrical > loads until flashing stops. > > If left OFF, you'll get a LO VOLTS warning light that > prompts you to turn the sb alternator ON and > then do the load-shedding exercise. ONE COULD RAISE THE SET-POINT ON AN SB-1 TO 14.4 VOLTS WHEREUPON IT WOULD BE CAPABLE OF BATTERY MAINTENANCE. IN THIS CASE, YOU WOULD LEAVE THE AUX ALTERNATOR OFF FOR NORMAL FLIGHT, TURN ON ONLY AFTER AN LV WARNING PROMPTED YOU. Y0U WOULD STILL HAVE THE AID FOR LOAD SHEDDING . . . YOU ONLY GIVE UP THE AUTO-SWITCHING FEATURE THE SB-1 WAS DESIGNED TO SUPPORT. >> >>2. My interpretation of the Z-12 architecture indicates that in the >>event of a Main alternator failure, it would be the pilot's job to >>manually load-shed the electrical system so that the total load was >>below 20A. This is because the Aux alternator would feed the Main >>Bus (and thence the Endurance Bus), so in the event of an Aux >>alternator-only operation, most of the Main Bus items would have to >>be turned off (or not used). My Endurance Bus will pull about 10A, >>so I'd like to feed the Endurance Bus directly from the Aux >>alternator (in addition to the normal feed path from the Main Bus). >>That way, I could perform a quick, pre-selected load-shed operation >>merely by turning off the Main Alternator switch and turning on the >>Aux Alternator switch. (And, of course, I'd also have the E-Bus >>Alternate feed from the Batt Bus, as a last-ditch backup.) So my >>second question is: Is this a reasonable modification to the Z-12 >>architecture? My goal is a simple, robust system, but I'd like the >>convenience and pilot friendliness of a dirt-simple "load shed" >>procedure, rather than a manual load-shed -- and having to ration >>power to the Main Bus items. > > Then you're not talking about Z-12 (originally crafted to > be a drop-in for type certificated aircraft that (1) doesn't > have an e-bus and (2) would be exceedingly difficult under > FAA rules to shuffle bus structures around. The system you're > describing looks more like this > >http://tinyurl.com/24j8gh4 > > This is a more robust version of Z-13/8 where the 20A > alternator is installed primarily to support an electrically > dependent engine. No e-bus is shown because if you have > a robust second alternator, there's no likelihood of needing > to operate battery-only . . . that's two major failures on > a single tank of fuel. Hence the simple direct connection > for the sb alternator to the battery such that battery > contactor failures are covered. > > "Last ditch" ???? You're spending too much time worrying > about things that only happen in Hollywood's notions of > how airplanes work. Modern alternators properly integrated > into your airplane are very low failure rate items. > > It is unlikely that you will EVER find experience a > pressing need to drop to SB alternator or a battery-only > ops mode over the lifetime of your airplane. In 25 years > of working with the OBAM aviation community, I've had > but a handful of readers report that the s/b alternator > or e-bus ops were found useful and functioned as advertised. > > If the airplane you're flying now is a TC aircraft, then > it has no e-bus, no sb alternator, might even be a rented > airplane where you have little knowledge of and zero > control over ship's maintenance. This has always been > my personal situation having never owned an airplane. > > So when I walk up to the airplane, I do it with the > mind set that I don't care if the electrical system > is going to work 100.0% of the time or not. I've got > stuff in my flight bag that will allow me to operate > any of the airplanes I fly in "J-3 mode" with a goal > of aviating to airport of intended destination whether > or not anything on the panel works. > >http://aeroelectric.com/Pictures/Misc/Failure_Tolerance.pdf > > No matter what electrical system is installed in your > OBAM aircraft, the stuff in your flight bag should be > similarly selected. If you've got smelly stuff in the > cockpit that's suspiciously like wire or electrical > accessory smoke, you might just want to shut everything > off, dig out the REAL stand-by goodies and keep on truck'n. > > Actually, I've not turned a panel mounted nav radio > on since I purchased my first hand-held GPS in '95. > The $100 Magellans do 99% of everything I need the > nav radio to do . . . how far, which direction, > and ETA. > > Your questions give the distinct impression that > you don't have much trust in the hardware for which > you're crafting an architecture. Lack of trust comes > from some combination of three conditions: > > (1) You KNOW you're installing certified junk on > an airplane constrained by regulation to be forever > less than the best we know how to do. > > (2) You don't personally possess a demonstrable, > experience-based data set the confirms the reliability > enjoyed by the OBAM aircraft community. > > (3) Your understanding of the system is diluted > with a lot of extraneous noise exemplified by the > majority of dark-n-stormy-night stories in the > flying rags and the nail-biter scenarios dreamed > up by Hollywood writers to make the actors look > like the gods of failure mitigation. > > If you're crafting an airplane with an electrically > dependent engine where all the engine support > comes from the battery bus, then Z-08 is recommended. > If your engine is not electrically dependent > then Z-12 as depicted is recommended. > > When and if that low voltage warning light ever > comes on, know that this is NOT an emergency > You can finish your cup of coffee and decide > what, if anything, you plan to do about it. > The point is, there IS A PLAN that probably > requires repositioning less than a half dozen > switches until the light stops flashing. > > Hence, I'll suggest that your quest for "dirt > simple" responses to a "last ditch" scenario > are probably not a good investment of emotional > capital or time. > > You need to tell us more about what equipment > is installed on what kind of engine for the > advice to me more specific. > > Bob . . . ________________________________________________________________________________
Date: Aug 27, 2010
Bob, you said: > That "unusable fuel" has two important functions. > (1) provide a low-spot for moisture collection > and (2) keep the vapor in the tank saturated. I spent a lot of time and effort to make sure that every drop in my fuel tanks was usable except for the debris sumps. The mains and header can be pumped dry except for sump fuel (4-6 ounces). Is the small amount of fuel in the sumps enough to keep a 12' long wing tank vapor-saturated? I wasn't ever worried about this before, but now that it's out on the line, just want to be sure I'm not committing a major oversight. J Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310335#310335 ________________________________________________________________________________
Date: Aug 27, 2010
You don't have to run the tanks dry. John Grosse jonlaury wrote: > --> AeroElectric-List message posted by: "jonlaury" > > Bob, you said: > > >> That "unusable fuel" has two important functions. >> (1) provide a low-spot for moisture collection >> and (2) keep the vapor in the tank saturated. >> > > > I spent a lot of time and effort to make sure that every drop in my fuel tanks was usable except for the debris sumps. The mains and header can be pumped dry except for sump fuel (4-6 ounces). > > Is the small amount of fuel in the sumps enough to keep a 12' long wing tank vapor-saturated? > > I wasn't ever worried about this before, but now that it's out on the line, just want to be sure I'm not committing a major oversight. > > J > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310335#310335 > > > ________________________________________________________________________________
Date: Aug 28, 2010
At 09:07 PM 8/27/2010, you wrote: > >Bob, you said: > > > That "unusable fuel" has two important functions. > > (1) provide a low-spot for moisture collection > > and (2) keep the vapor in the tank saturated. > > >I spent a lot of time and effort to make sure that every drop in my >fuel tanks was usable except for the debris sumps. The mains and >header can be pumped dry except for sump fuel (4-6 ounces). > >Is the small amount of fuel in the sumps enough to keep a 12' long >wing tank vapor-saturated? Are these 'sumps' part of the tank envelope or are they 'low spot' water separators plumbed to the tank through a fuel line? >I wasn't ever worried about this before, but now that it's out on >the line, just want to be sure I'm not committing a major oversight. I may have stubbed my toe on speaking of the "importance" of unusable fuel. I don't think that the designers deliberately shoot for a volume of unusable fuel just to meet some rule of thumb for reducing risk of explosion. I think it has just worked out that for most airplane tanks, the lowest spot in the tank was against the skin and that same spot becomes a good place to put a water drain. Obviously, plumbing a fuel line into the same location would look pretty ugly hanging out the bottom of the airplane. So fuel lines tend to tap through the tank wall at the lowest practical point . . . but obviously above the tank's low spot thus giving rise to "unusable fuel". I'm sure there are many instances of gasoline tanks on vehicles that are plumbed such that the total contents can be consumed by the engine. But unless the same tank is force-ventilated the vapor space mixture will remain very rich for long periods of time. But even after it becomes 'leaner', you still need an ignition source for the combination to become hazardous. I remember reading about WWII military fuel systems where a major consideration was taking a tracer through an empty fuel tank. At Cessna, we fitted some military airplane tanks with an open cell foam filler. While the foam reduced tank useful volume by about 5%, it had the effect of sucking the heat out of a flame front such that taking a tracer through a tank of stoichiometric mixture would not produce an explosion. It's hard to get an explosion to happen on purpose. I recall some conversations with a fellow who ran a test lab telling us about getting a mixture tuned up "just right" for the purposes of testing our motors for explosion proofing. He described a chamber with a hinged lid, foam gaskets all around the edges, and just enough weight to get a good seal. The chamber was fitted with mixing fans, a source of hydrocarbon (I think it was Butane), a source of ignition (spark plug through the wall), and equipment to allow us to run a motor inside. After putting what is believed to be the right amount of butane in the chamber, the motor run tests are conducted. When the prescribed tests are finished, he then sparks the mixture for the purpose of proving that the atmosphere was and is still hazardous. If things went right, the vapor lit off, the lid flies open and you get this fireball out the top. If things don't go right, nothing happens and the tests have to be repeated. Unless you plan to punch holes in your tanks and mount spark plugs in the holes, the practice of running the tanks dry offers no great hazard. If you're using fuel gaging systems that are shown to be intrinsically safe in a hazardous environment, you're good to go. Bob . . . ________________________________________________________________________________
Date: Aug 28, 2010
At 09:21 PM 8/27/2010, you wrote: > >You don't have to run the tanks dry. True . . . but if one intends to leave a specific volume of fuel in the tank, an accurate means of gaging is indicated. I just checked out my copy of part 23 where I found: ------------------------------ Sec. 23.971 Fuel tank sump. (a) Each fuel tank must have a drainable sump with an effective capacity, in the normal ground and flight attitudes, of 0.25 percent of the tank capacity, or 1/16 gallon, whichever is greater. (b) Each fuel tank must allow drainage of any hazardous quantity of water from any part of the tank to its sump with the airplane in the normal ground attitude. (c) Each reciprocating engine fuel system must have a sediment bowl or chamber that is accessible for drainage; has a capacity of 1 ounce for every 20 gallons of fuel tank capacity; and each fuel tank outlet is located so that, in the normal flight attitude, water will drain from all parts of the tank except the sump to the sediment bowl or chamber. (d) Each sump, sediment bowl, and sediment chamber drain required by paragraphs (a), (b), and (c) of this section must comply with the drain provisions of Sec. 23.999 (b)(1) and (b)(2). ------------------------------- So in TC airplanes, it would be a violation to design a tank with zero unusable fuel. This section gives us some insight into the existence of one or more drains in each tank plus a low spot drain (usually the gascolator) at the bottom of the fire wall. Bob . . . ________________________________________________________________________________
Date: Aug 28, 2010
I agree, but I am going to go one small step further and do the frequency test while on the ground the next time I go to the airport. I too have had GPS drop-out for brief periods and just thought that I had gotten a bum deal on EBAY on my little hand held Garmin 196. I still have a plan A and plan B since my little GPS is more for informational purposes only and is really a plan C. Thanks for starting this thread. My wife thinks I'm nuts for reading this "boring stuff" but I love learning new things and once again I found a little gem to check on. Chris [quote="james(at)etravel.org"]Interesting stuff. That's worth everyone with a GPS tucking away in the "for future reference" part of the brain. Thanks for taking the time to report this info. James While on the tiedown, with engine and everything running, I started to tune in the various com frequencies I use in my area. With the GPS screen set to show the sat reception bars, I quickly found that the bars would quickly pulse down to nothing when the frequency was set between 119.200 to 119.5. This was even without transmitting and it was dramatic. As it turns out, I am usually tuned within this frequency range when flying the routes I had associated with GPS loss. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310382#310382 ________________________________________________________________________________
Date: Aug 28, 2010
Subject: Noise in the intercom . . .
>Comments/Questions: I have alternator noise in my Sigtronics >intercom. I re-wired and re-routed the harness out of the tunnel >(Glasair III) to around the cockpit - no help. > >I get alternator noise with the intercom on, quiet with it off, and >/or the ALT CB pulled. I also get aditional noise when the fuel >pump or flap motor are run (but not always). I'm kinda stumped. > >I've [now] been told that pulling the CB can hurt the alternator...true? No >Also that a bad diode in the alternator can cause this noise? Sometimes . . . but if you have other accessories that cause noise too . . . then the problem is most likely more general and involves how the intercom was installed. >I had the alternator rebuilt to no effect, so I thought that had >eliminated the alternator, but I could be wrong. I also have >replaced the (B&C) voltage regulator. > >Suggestions and/or help would be appreciated. I'm sorry to hear that you've tried so many hopeful and expensive fixes without positive result. I note that you are not currently subscribed to the AeroElectric-List. Early on (after reading your symptoms) I and others on the list would have steered you toward an evaluation of your ground system. The problems you've described are almost certainly a function of shared pathways in the ground system for both victim (intercom) and antagonists (alternator, flaps, etc). These issues are also addressed in the chapters on Grounding and Noise found in the AeroElectric Connection. If you do not have a copy of the Connection you can download it here: http://www.aeroelectric.com/Book/AEC12A_PDF.zip I'll suggest also that you join us on the List for expanded support of your quest for solving this problem. Never met a noise dragon that couldn't be slain. Bob . . . ________________________________________________________________________________
Date: Aug 28, 2010
> > You don't have to run the tanks dry. > True and I probably won't 99% of the time. But I designed this multi-tank fuel system to be bullet proof if it is just ON. I don't want to inadvertently build in a gotcha if there's a need or a screw-up that runs a tank dry. Re Bob's Part 23 quote, by coincidence, my wing and header tanks (with integral, drainable debris sumps within the tank envelope) are configured in conformance, as they drain into a 32 oz. sump tank (w/drain) that feeds the pumps. So now all I have to do is remove the fuel tank spark plugs. :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310391#310391 ________________________________________________________________________________
Date: Aug 28, 2010
Subject: Re: splicing wire?
At 01:57 PM 8/28/2010, you wrote: >Good afternoon Bob >I have a question on splicing wire. I need to lengthen the wires to >my headset plugs from the intercom. ( NAT intercom). They currently >go to plugs in the center console. I was originally going to run >new wires all the way to the intercom. This is proving to be a >major undertaking. Everything is bundled and nicely tied and very >difficult to get to. Can I add a length of wire to the existing >without creating problems? Would there be any considerations I >would need to address? Sure. the big guys do it all the time. They use a product called solder-sleeves. You don't need to get THAT fancy. I've illustrated a poor-man's solder sleeve technique here: http://aeroelectric.com/Pictures/Wiring_Technique/Wire_treatment_3.jpg and a comic book on the technique here: http://aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html If you have some shields to deal with, just bring their pigtails together as if they were individual wires. This technique offers a minimum-bulk methodology for jointing wires and insulating the splice. If practical, you might want to trim the lengths of the existing wires so that the splices don't all bunch up next to each other in the finished bundle. Bob . . . ________________________________________________________________________________
Date: Aug 28, 2010
Thank you Bob!! James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Sat, August 28, 2010 1:26:30 PM Subject: AeroElectric-List: Re: splicing wire? At 01:57 PM 8/28/2010, you wrote: Good afternoon Bob >I have a question on splicing wire. I need to lengthen the wires to my headset >plugs from the intercom. ( NAT intercom). They currently go to plugs in the >center console. I was originally going to run new wires all the way to the >intercom. This is proving to be a major undertaking. Everything is bundled and >nicely tied and very difficult to get to. Can I add a length of wire to the >existing without creating problems? Would there be any considerations I would >need to address? Sure. the big guys do it all the time. They use a product called solder-sleeves. You don't need to get THAT fancy. I've illustrated a poor-man's solder sleeve technique here: http://aeroelectric.com/Pictures/Wiring_Technique/Wire_treatment_3.jpg and a comic book on the technique here: http://aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html If you have some shields to deal with, just bring their pigtails together as if they were individual wires. This technique offers a minimum-bulk methodology for jointing wires and insulating the splice. If practical, you might want to trim the lengths of the existing wires so that the splices don't all bunch up next to each other in the finished bundle. Bob . . . ________________________________________________________________________________
Subject: Icom 210 radio intercom switch
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Date: Aug 29, 2010
Hi I am wiring up my Icom 210 for my little 2 seater plane and plan to use the radios own internal intercom. In the wiring diagram there is a intercom switch, but for the life of me I cannot find what this is used for and if I need to wire it in or not? I though it was all built inwith this radio? Any Ideas out there? Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310464#310464 ________________________________________________________________________________
Date: Aug 29, 2010
Subject: re: GPS outage in fiberglass plane
I will add another data point concerning radios interfering with GPS reception. I recently installed a Garmin 430W in my Cessna 172 (probably doubled its value, but the unit will be removed for installation into the airplane I am building). I worked with an avionics shop that was willing to supervise me doing much of the work as a learning experience - and it was ! The Garmin installation manual cautions against installing the GPS antenna within 4 feet of other antennas. The cabin roof of the Cessna makes that goal impossible to meet. For simplicity, we chose to re-use the same mounting location as the old GPS antenna, which is a foot away from the antenna of the King KX-175B radio. There are a number of tests required in the Garmin installation manual, including transmitting with each radio on the following frequencies for 35 seconds, while watching the satellite reception screen: 121.150, 121.175, 121.200, 121.225, 121.250 131.200, 131.225, 131.250, 131.275, 131.300, 131.325, 131.350 In my case the 131MHz frequencies interfered. Not just slightly, but completely killed reception of all GPS satellites. The strength bars went to zero immediately. The 430W required more than a minute to recover after unkeying the transmitter. I swapped the COM antennas between the 430W and the KX-175B. The 430W produced a cleaner transmission that did not interfere with GPS reception. The transmissions of the KX-175B, with the antenna now 3 feet away from the GPS antenna, only slightly interfered (lost 10-20% of signal strength) and did not prevent reception from even the marginal satellites. So problem simply resolved. Where I fly, I rarely use frequencies in the 131MHz range, so without doing this test I might have happily flown for quite a number of hours, only to be confounded with lack of GPS navigation at some future point. I recommend everyone perform this test, since it is so quite and easy to do. Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Aug 29, 2010
Subject: Re: re: GPS outage in fiberglass plane
Keep in mind that it is not just transmitting that creates interference. Having the radio simply tuned to a frequency and turned on can also cause the problem. There are also nav frequencies that need to be checked. They are not in the AC, but this site has more detail of documented issues for specific radio models: http://www.scn.org/~bk269/gps.html On 8/29/2010 7:26 AM, Jeff Page wrote: > > I will add another data point concerning radios interfering with GPS > reception. > > I recently installed a Garmin 430W in my Cessna 172 (probably doubled > its value, but the unit will be removed for installation into the > airplane I am building). > I worked with an avionics shop that was willing to supervise me doing > much of the work as a learning experience - and it was ! > > The Garmin installation manual cautions against installing the GPS > antenna within 4 feet of other antennas. The cabin roof of the Cessna > makes that goal impossible to meet. > For simplicity, we chose to re-use the same mounting location as the > old GPS antenna, which is a foot away from the antenna of the King > KX-175B radio. > > There are a number of tests required in the Garmin installation > manual, including transmitting with each radio on the following > frequencies for 35 seconds, while watching the satellite reception > screen: > > 121.150, 121.175, 121.200, 121.225, 121.250 > 131.200, 131.225, 131.250, 131.275, 131.300, 131.325, 131.350 > > In my case the 131MHz frequencies interfered. Not just slightly, but > completely killed reception of all GPS satellites. The strength bars > went to zero immediately. The 430W required more than a minute to > recover after unkeying the transmitter. > > I swapped the COM antennas between the 430W and the KX-175B. The 430W > produced a cleaner transmission that did not interfere with GPS > reception. The transmissions of the KX-175B, with the antenna now 3 > feet away from the GPS antenna, only slightly interfered (lost 10-20% > of signal strength) and did not prevent reception from even the > marginal satellites. So problem simply resolved. > > Where I fly, I rarely use frequencies in the 131MHz range, so without > doing this test I might have happily flown for quite a number of > hours, only to be confounded with lack of GPS navigation at some > future point. > > I recommend everyone perform this test, since it is so quite and easy > to do. > > Jeff Page > Dream Aircraft Tundra #10 > > ________________________________________________________________________________
Date: Aug 29, 2010
Subject: Re: Icom 210 radio intercom switch
At 06:59 AM 8/29/2010, you wrote: > > >Hi >I am wiring up my Icom 210 for my little 2 seater plane and plan to >use the radios own internal intercom. > >In the wiring diagram there is a intercom switch, but for the life >of me I cannot find what this is used for and if I need to wire it >in or not? I though it was all built inwith this radio? I've looked over the operations manual for the A210 and there IS an intercom built in. However, it can be switched off and on from front panel controls. It's not clear to me in my quick trip through the manual what the external switch is for. My best guess is that it might be a way that a "back seater" can turn the intercom off and on. I'd bring a wire out from pin 10 on the radio that's long enough to gain access to the end AFTER installation. Tie it up in the wire bundle and hopefully forget it. If at some time the future it is discovered to be useful, the task of integrating its function into your project will be greatly eased. Perhaps other A210 users on the List can offer more detailed guidance. Bob . . . ________________________________________________________________________________
Subject: Z-11 Drawing with LR3C Controller?
Date: Aug 29, 2010
Hi Bob, Just reading the note in Rev 12A about Fig Z-11 and it says that Z-11 was redrawn with the B&C combo regulator/OV/LV controller but in my book it doesn't have it. Is there a revised drawing that I can download somewhere? thanks, Dan warbirds(at)shaw.ca Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310520#310520 ________________________________________________________________________________
Date: Aug 29, 2010
Bob and Chris: I too am trying to use the A 210. I am using a flightcom intercom seperate from the one built in. I understand that the built in on e hasto use a push to talk button. And it is not voice activated. BTW Bob where can I obtain the book you have out. I have been trying to fined out . Thanks: Gordon > kolls.bob(at)aeroelectric.com> > > At 06:59 AM 8/29/2010=2C you wrote: > > > > > >Hi > >I am wiring up my Icom 210 for my little 2 seater plane and plan to > >use the radios own internal intercom. > > > >In the wiring diagram there is a intercom switch=2C but for the life > >of me I cannot find what this is used for and if I need to wire it > >in or not? I though it was all built inwith this radio? > > I've looked over the operations manual for the A210 and > there IS an intercom built in. However=2C it can be switched > off and on from front panel controls. It's not clear to me > in my quick trip through the manual what the external > switch is for. My best guess is that it might be a way > that a "back seater" can turn the intercom off and on. > > I'd bring a wire out from pin 10 on the radio that's > long enough to gain access to the end AFTER installation. > Tie it up in the wire bundle and hopefully forget it. > If at some time the future it is discovered to be > useful=2C the task of integrating its function into > your project will be greatly eased. > > Perhaps other A210 users on the List can offer more > detailed guidance. > > > Bob . . . > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Aug 29, 2010
Good Afternoon Bob I spliced the wires as you suggested. I spliced all wires including the shield. When all finished I have good intercom between headsets, the co pilot transmit works good, but the pilot headset has a whine/squeal when transmitting. What should I look for to correct this? Jim James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Sat, August 28, 2010 1:26:30 PM Subject: AeroElectric-List: Re: splicing wire? At 01:57 PM 8/28/2010, you wrote: Good afternoon Bob >I have a question on splicing wire. I need to lengthen the wires to my headset >plugs from the intercom. ( NAT intercom). They currently go to plugs in the >center console. I was originally going to run new wires all the way to the >intercom. This is proving to be a major undertaking. Everything is bundled and >nicely tied and very difficult to get to. Can I add a length of wire to the >existing without creating problems? Would there be any considerations I would >need to address? Sure. the big guys do it all the time. They use a product called solder-sleeves. You don't need to get THAT fancy. I've illustrated a poor-man's solder sleeve technique here: http://aeroelectric.com/Pictures/Wiring_Technique/Wire_treatment_3.jpg and a comic book on the technique here: http://aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html If you have some shields to deal with, just bring their pigtails together as if they were individual wires. This technique offers a minimum-bulk methodology for jointing wires and insulating the splice. If practical, you might want to trim the lengths of the existing wires so that the splices don't all bunch up next to each other in the finished bundle. Bob . . . ________________________________________________________________________________
Date: Aug 29, 2010
Subject: Molex Connectors out of production
Any of you folks who own Icom 200 series transceivers, I was tracking down connectors for a OBAM aircraft brother and note that the part is now or soon to be discontinued. >Comments/Questions: Bob, I'm stumped and I think the answer is >likely a simple one, but I cannot find it. I have an ICOM A200 radio >that I bought used, and had it checked out by an avionics shop about >a year ago. I'm building a Zenith CH 701 and now I cannot find the >Molex 4338-15 connector that is described in the installation >manual. I've search the internet and the only place that even lists >such a part number is in Australia. My guess is this is readily >available at an electronics store, but I don't know what to call it. >Can you help me? The 4338 is a model number. The actual part number you want is 09-50-6155 I'm told this part is obsolete and the manufacturer intends to discontinue the part. There is stock at Newark Electronics. http://tinyurl.com/29wlrrx You'll also need pins sold separately http://tinyurl.com/2arg72m Good luck. You might want to order spares! Went present stocks are gone, there won't be any more. Bob . . . ________________________________________________________________________________
Date: Aug 29, 2010
At 03:37 PM 8/29/2010, you wrote: >Bob and Chris: I too am trying to use the A 210. I am using a >flightcom intercom seperate from the one built in. I understand >that the built in one has to use a push to talk button. And it is >not voice activated. Funny you should offer this assertion. Here's a clip from the Icom A-210 Manual at http://aeroelectric.com/Mfgr_Data/Radios/Icom_A210/IC-A210_User%27s_Manual.pdf From page 20 Emacs! From page 27 Emacs! They use the words "voice activated" but the switching is suspicious. Provisions for an external intercom PTT suggests that it's not really voice activated but in fact a "hot mic" system that is turned ON by either the front panel control as described above or ON/OFF by external PTT switches wired to pin 10. I'd bet that the built-in feature is indeed a PTT intercom. Bob. . . > >BTW Bob where can I obtain the book you have out. I have been >trying to fined out. Thanks: Gordon You can get the bound book -OR- a .pdf version on CD + bonus Pak of data from our catalog at: https://matronics.com/aeroelectric/Catalog/AECcatalog.html you can download the .pdf version at: http://www.aeroelectric.com/Book/AEC12A_PDF.zip Bob . . . ________________________________________________________________________________
Date: Aug 29, 2010
Subject: Re: Z-11 Drawing with LR3C Controller?
At 03:06 PM 8/29/2010, you wrote: > >Hi Bob, > >Just reading the note in Rev 12A about Fig Z-11 and it says that >Z-11 was redrawn with the B&C combo regulator/OV/LV controller but >in my book it doesn't have it. I need to fix that note. Z-11 was intended to be the "poor builder's" elegant solution for an electrical system, hence the $10 regulator. > Is there a revised drawing that I can download somewhere? Z-12 uses the B&C LR series regulators. Just drop the wiring shown for the main alternator on Z-12 into Z-11. Bob . . . ________________________________________________________________________________
Date: Aug 29, 2010
At 07:54 PM 8/29/2010, you wrote: >Good Afternoon Bob >I spliced the wires as you suggested. I spliced all wires >including the shield. When all finished I have good intercom >between headsets, the co pilot transmit works good, but the pilot >headset has a whine/squeal when transmitting. What should I look >for to correct this? Is this a new condition that cropped up when you extended the wires? One side works but the pilot side doesn't . .. hmmm . . . might be a wiring error of some variety. Bob . . . ________________________________________________________________________________
Date: Aug 29, 2010
Yes it occurred after the splicing of the wires. Any suggestions where to look. All the features work, intercom and transmit/receive both pilot and co-pilot. The problem is in the transmit pilot side only. What type of error should I be looking for? Jim PS Your up late tonight James Robinson Glasair lll N79R Spanish Fork UT U77 ________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Sun, August 29, 2010 9:47:59 PM Subject: Re: AeroElectric-List: Re: splicing wire? At 07:54 PM 8/29/2010, you wrote: > Good Afternoon Bob > I spliced the wires as you suggested. I spliced all wires including the >shield. When all finished I have good intercom between headsets, the co pilot >transmit works good, but the pilot headset has a whine/squeal when >transmitting. What should I look for to correct this? Is this a new condition that cropped up when you extended the wires? One side works but the pilot side doesn't . .. hmmm . . . might be a wiring error of some variety. Bob . . . ________________________________________________________________________________
Date: Aug 29, 2010
Bob: I went thru all of this last week. I spent time on the phone with Da vid Graham(at)Moles.com. Phone 800-786-6539 ext: 555-2125 . He told me that connector 4338-15 that Icom has in their supplied parts for new transceive r are now obsolete .The Molex terminals (4366-GL) have a new part number an d is 8030304 and is available thru MOUSER ELECTRONICS. I ordered somelast week and was told it would be 5 days before they get any in. There 13 cent s each. Might try ICOM direct in Belview Washington. They usually have some of the se products. Gordon Any of you folks who own Icom 200 series transceivers=2C I was tracking down connectors for a OBAM aircraft brother and note that the part is now or soon to be discontinued. Comments/Questions: Bob=2C I'm stumped and I think the answer is likely a simple one=2C but I cannot find it. I have an ICOM A200 radio that I bought used=2C and had it checked out by an avionics shop about a year ago. I'm building a Zenith CH 701 and now I cannot find the Molex 4338-15 connector that is described in the installation manual. I've search the internet and the only place that even lists such a part number is in Australia. My guess is this is readily available at an electronics store=2C but I don't know what to call it. Can you help me? The 4338 is a model number. The actual part number you want is 09-50-6155 I'm told this part is obsolete and the manufacturer intends to discontinue the part. There is stock at Newark Electronics. http://tinyurl.com/29wlrrx You'll also need pins sold separately http://tinyurl.com/2arg72m Good luck. You might want to order spares! Went present stocks are gone=2C there won't be any more. Bob . . . ________________________________________________________________________________
Date: Aug 30, 2010
Ok - that's kinda what I was doing anyway, just thought I'd check for the deluxe schematic! thanks, Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310590#310590 ________________________________________________________________________________
Date: Aug 30, 2010
Bob, I am trying to get on the forum to ask/submit questions, but I cannot. I registered a few days ago, so I am in the system, but every time I try to log it, it says I am not a registered user. How can I get this cleared up? Thank you. Jeff Jeff Jacksonville, FL __i__ *-----o--o--(_)--o--o-----* -----Original Message----- From: Kelly McMullen <kellym(at)aviating.com> Sent: Sun, Aug 29, 2010 11:02 am Subject: Re: AeroElectric-List: re: GPS outage in fiberglass plane om> Keep in mind that it is not just transmitting that creates interference. Having the radio simply tuned to a frequency and turned on can also cause the problem. There are also nav frequencies that need to be checked. They are not in the AC, but this site has more detail of documented issues for specific radio models: http://www.scn.org/~bk269/gps.html On 8/29/2010 7:26 AM, Jeff Page wrote: > > I will add another data point concerning radios interfering with GPS > reception. > > I recently installed a Garmin 430W in my Cessna 172 (probably doubled > its value, but the unit will be removed for installation into the > airpl ane I am building). > I worked with an avionics shop that was willing to supervise me doing > much of the work as a learning experience - and it was ! > > The Garmin installation manual cautions against installing the GPS > ant enna within 4 feet of other antennas. The cabin roof of the Cessna > makes that goal impossible to meet. > For simplicity, we chose to re-use the same mounting location as the > old GPS antenna, which is a foot away from the antenna of the King > KX-1 75B radio. > > There are a number of tests required in the Garmin installation > manual , including transmitting with each radio on the following > frequencies fo r 35 seconds, while watching the satellite reception > screen: > > 121.150, 121.175, 121.200, 121.225, 121.250 > 131.200, 131.225, 131.250, 131.275, 131.300, 131.325, 131.350 > > In my case the 131MHz frequencies interfered. Not just slightly, but > completely killed reception of all GPS satellites. The strength bars > we nt to zero immediately. The 430W required more than a minute to > recover after unkeying the transmitter. > > I swapped the COM antennas between the 430W and the KX-175B. The 430W > produced a cleaner transmission that did not interfere with GPS > recepti on. The transmissions of the KX-175B, with the antenna now 3 > feet away from the GPS antenna, only slightly interfered (lost 10-20% > of signal strength) and did not prevent reception from even the > marginal satellit es. So problem simply resolved. > > Where I fly, I rarely use frequencies in the 131MHz range, so without > doing this test I might have happily flown for quite a number of > hours, only to be confounded with lack of GPS navigation at some > future point. > > I recommend everyone perform this test, since it is so quite and easy > to do. > > Jeff Page > Dream Aircraft Tundra #10 > > > > > > ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Aug 30, 2010
Subject: AeroElectric List access
At 06:44 AM 8/30/2010, you wrote: >Bob, > >I am trying to get on the forum to ask/submit questions, but I >cannot. I registered a few days ago, so I am in the system, but >every time I try to log it, it says I am not a registered user. How >can I get this cleared up? There are TWO gateways into the Matronics forums. One is by way of your browser. You don't need an email service for this activity. Use of this service requires a SEPARATE account creation using a unique user name and password. The other is by means of an e-mail forwarding service . . . all messages sent to a particular address are sent out to all subscribers. No log-on or password required. You have checked the subscription boxes for both individual postings and the daily digest off ALL postings for the day. I'll suggest you go back to http://matronics.com/subscribe and UN-check either the digest or real-time box. I recommend that you un-check the digest box. To ASK a question or start a new thread of discussion you simply craft an email message and send it to: aeroelectric-list(at)matronics.com To respond to any other posting, you simply hit the REPLY button on your e-mail client. You are getting this message because you REPLIED to a posting on another topic. I've changed the title of the topic so as to 'unhook' our conversation from the other one. Your difficulty is probably based on a an attempt to use the browser based service while your subscription is for the email service. You CAN do both. I occasionally use the browser based service when I'm away from my personal computers. When I checked your subscription status a few days ago, you WERE signed up for a number of other forums. I see that you are now subscribed to ONLY the AeroElectric List. Is this your intention? You may want to go back and re-check boxes for forums that were useful to you. Again, I recommend that you check ONLY the real-time and not the digest service. Bob . . . ________________________________________________________________________________
Date: Aug 30, 2010
Subject: Icom switch
I work on lightsports and we had the Icom 200 now going to the 210. I talked with them about the "switch". Basically it is a pilot isolate switch. My understanding, and I would confirm with Icom, is that without the switch, the intercom is always active which seems like a good thing, except that both mics are active when one PTT is pushed. This could lead to some interesting transmissions. Dan Ballin X-Air LLC ________________________________________________________________________________
Subject: noise in intercom
Date: Aug 30, 2010
Taylorcraft 19 with electrice start, generator, nav lights, transponder, pseII intercom, strobes, narco 120 radio. I just added the intercom to the plane. The headset plugs are not grounded as they are perfectly isolated in plastic mounts on wood in the wing. the wires are shielded and terminate at the unit only. At low rpm the intercom LED will flash between red and green back and forth. at that time the system is unusable. many times at cruise rpm and lower rpm as well i will hear a rhythmic tick sound, couple a second. previously i could hear my strobes squeal at low rpm but it was faint and the ground for them has been improved. the pse box has a default circuit that only allows the co pilot to function when there may be a problem. My unit goes to this function when my radio is turned off. My radio doesnt receive and i have been using a hand held. but i must keep power to my narco or the led on the intercom goes a yellow ish color and defaults to co pilot. if i turn the power on the radio on the intercom functions great but I end up being interrupted with noise or trash it pics up. any help would be great. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310703#310703 ________________________________________________________________________________
Subject: Splicing small wires
Date: Aug 30, 2010
I cannot pretend to be so wise as some on the net, but I do have a small note to make when splicing the #18-on-down size wires, especially when in crowded corners - I seem to specialize in wiring myself into a spiralling corner..... In radio I learned long ago you can't find the size you need to join two wires. I hit upon the model aircraft shops for copper/brass tubing which is nesting in size around these smaller wires. It's a pain to cut the tubing and smooth the ends so that fine wire can enter so I do this in tens at one time when the conditions dictate, either this or reading a good book. For a couple of bucks and a warder file plus small-tooth saw, you can have a pocketful of crimpable lengths just lying there waiting for redemption. The simple crimper slides easily into tight spaces, and we're not welding power cable here. Just a thought. Ferg Europa XS A064 wiring wiring wiring ________________________________________________________________________________
Date: Aug 30, 2010
Bob, I have one of these units. It works as voice activated to my satisfaction. It my have some components that I do not understand, but voice opens the squelch and squelch closes when silent. Many menus to filter through, but once set it is a fine unit. Kevin Boddicker TriQ 200 Luaua, IA. On Aug 29, 2010, at 10:43 PM, Robert L. Nuckolls, III wrote: > At 03:37 PM 8/29/2010, you wrote: >> Bob and Chris: I too am trying to use the A 210. I am using a flightcom intercom seperate from the one built in. I understand that the built in one has to use a push to talk button. And it is not voice activated. > > Funny you should offer this assertion. Here's a clip from > the Icom A-210 Manual at > > http://aeroelectric.com/Mfgr_Data/Radios/Icom_A210/IC-A210_User%27s_Manual .pdf > > =46rom page 20 > <232e5fd.jpg> > > =46rom page 27 > > <232e67a.jpg> > > > They use the words "voice activated" but the switching > is suspicious. Provisions for an external intercom PTT > suggests that it's not really voice activated but in fact > a "hot mic" system that is turned ON by either the > front panel control as described above or ON/OFF by > external PTT switches wired to pin 10. I'd bet that > the built-in feature is indeed a PTT intercom. > > Bob. . . > > >> >> BTW Bob where can I obtain the book you have out. I have been trying to fined out. Thanks: Gordon > > You can get the bound book -OR- a .pdf version on > CD + bonus Pak of data from our catalog at: > > https://matronics.com/aeroelectric/Catalog/AECcatalog.html > > you can download the .pdf version at: > > http://www.aeroelectric.com/Book/AEC12A_PDF.zip > > Bob . . . > ________________________________________________________________________________
Subject: Progressive switch for electric trim
Date: Aug 30, 2010
Bob, list, I was reading through a thread on Van's Air Force today and it got me thinking about the approaches to elevator trim control. There seemed to be two camps: People who use (on)-off-(on) type switches who have problems with sensitivity, and people who have some kind of high/low motor speed switch, either manually controlled or airspeed controlled with a Vertical Power (or similar) module. >From a usability versus complexity standpoint, I was imagining a progressive-speed switch, implemented as a 5-position switch: (second-up) : fast down trim (first-up) : slow down trim center : trim stop (first-down) : slow up trim (second-down) : fast up trim A quick search has not turned up any toggle switches of this kind, which may be the real problem with this approach. Have you seen this approach elsewhere, or have any part number suggestions? Thanks, --Daniel ________________________________________________________________________________
From: "Brian Gowland" <brian.gowland(at)mypostoffice.co.uk>
Subject: Re: Splicing small wires
Date: Aug 31, 2010
Splicing small wiresTry rolling a small copper/ brass/ali tube under a sharp blade, for perfect results in seconds. Regards Brian Hn700 Menestrel 11 ----- Original Message ----- From: Fergus Kyle To: 1AeroElectricLIST Sent: Monday, August 30, 2010 10:17 PM Subject: AeroElectric-List: Splicing small wires I cannot pretend to be so wise as some on the net, but I do have a small note to make when splicing the #18-on-down size wires, especially when in crowded corners - I seem to specialize in wiring myself into a spiralling corner..... In radio I learned long ago you can't find the size you need to join two wires. I hit upon the model aircraft shops for copper/brass tubing which is nesting in size around these smaller wires. It's a pain to cut the tubing and smooth the ends so that fine wire can enter so I do this in tens at one time when the conditions dictate, either this or reading a good book. For a couple of bucks and a warder file plus small-tooth saw, you can have a pocketful of crimpable lengths just lying there waiting for redemption. The simple crimper slides easily into tight spaces, and we're not welding power cable here. Just a thought. Ferg Europa XS A064 wiring wiring wiring ------------------------------------------------------------------------- ----- This email has been scanned by Netintelligence http://www.netintelligence.com/email ------------------------------------------------------------------------- ----- ______________________________________________ =0AThis email has b een scanned by Netintelligence =0Ahttp://www.netintelligence.com/e mail =0A ________________________________________________________________________________
Subject: Which connection from a Garmin 296 to my Dynon 180?
Date: Aug 31, 2010
Hi Guys. I know some of you have done this. Which wire on a Garmin 296 is the one that connects to EFIS pin #22 on a Dynon 180? My guess is that it is the DATA OUT 2(violet) in the Power/Data connector cable. This wire is described as to autopilot or NMEA device I have already cut (cannibalized) that cable to get at the power wire so it's already accessible. Thank you.....Geoff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310783#310783 ________________________________________________________________________________
Date: Aug 31, 2010
Subject: Re: Progressive switch for electric trim
At 10:05 PM 8/30/2010, you wrote: Bob, list, I was reading through a thread on Van's Air Force today and it got me thinking about the approaches to elevator trim control. There seemed to be two camps: People who use (on)-off-(on) type switches who have problems with sensitivity, and people who have some kind of high/low motor speed switch, either manually controlled or airspeed controlled with a Vertical Power (or similar) module. >From a usability versus complexity standpoint, I was imagining a progressive-speed switch, implemented as a 5-position switch: (second-up) : fast down trim (first-up) : slow down trim center : trim stop (first-down) : slow up trim (second-down) : fast up trim A quick search has not turned up any toggle switches of this kind, which may be the real problem with this approach. Have you seen this approach elsewhere, or have any part number suggestions? I's aware of no COTS (commercial off the shelf) switch with this characteristic. There have been lever operated, sping loaded to center, wafer switches but those go back a lot of years. I don't think they were a catalog item. I've spent a significant portion of my career working on motor driven trim systems for aircraft, mostly bizjets. I did get to put the first microprocessor controlled trim system on Roy Lopresti's M30 prototype at Mooney. This was a proof of concept controller that adjusted the servo gain scale factor on a servo/anti-servo tab. The goal was to provide a constant stick-force/G response irrespective of IAS. Initial flight tests were encouraging but the M30 program was scrapped for a host of reasons. We've had a number of discussions about trim systems here on the List. A search of the aeroelectric.com website using the words trim and speed will produce a number of hits. But in particular, may I suggest you review the article published at: http://www.aeroelectric.com/articles/Trim_System_Failures.pdf The "ideal" trim controller would adjust the motor's speed linearly over the full range of max to minimum depending on the airplane's IAS value. After crafting the trim speed controller for the Lear 55, I wrote and delivered a paper at an SAE convention where I hypothesized a number of possibilities for future designs. Two features of the paper talked about a way to control trim speed from a single processor in a manner that precludes a runaway in spite of worst case software failure. The other was a proposal to adjust motor speed based on the value of pitot pressure (IAS). Obviously, there's a huge difference between a performance of a Lear and an RV. A larger difference exists between the product development budgets for the two aircraft. Setting the "ideal" system aside, what operating characteristics might offer 90 plus percent of everything we'd like the trim system to do. An airplane spends MOST of its flight time in stable flight at max IAS. This configuration suggests a very slow trim rate that allows fine tuning of trim for holding altitude. A small percentage of flight time is spent in approach to landing where IAS is on the order of 90-100 kts and some degree of flaps are deployed. Here the trim speed needs to be faster to make timely adjustments to establish the desired IAS. On the Lears, the high speed trim was 4x faster than low speed trim. I've published a suggested schematic for a two speed trim system for small aircraft at: http://www.aeroelectric.com/PPS/Flight/Trim/Two_Speed_Trim_2.pdf This is modeled after the system flying on 30 series Lears where speed commands come from a switch on the flap system. With flaps full up, low speed is commanded. With flaps extended more than 10 degrees, high speed is commanded. I'm confident that a system crafted after this model will meet design goals for crafting a very utilitarian pitch trim system. The neat thing is that speed selection is automatically controlled by flight configuration. I could get this system qualified on a TC aircraft with a minimum of bureaucratic fuss. The controller should be fitted with screwdriver adjusted trim pots for speed selection. Over a series of flight tests, you can optimize system performance to meet your design goals. Bob . . . ________________________________________________________________________________
Date: Aug 31, 2010
At 09:11 PM 8/30/2010, you wrote: >Bob, >I have one of these units. It works as voice activated to my >satisfaction. It my have some components that I do not understand, >but voice opens the squelch and squelch closes when silent. Many >menus to filter through, but once set it is a fine unit. THANK YOU! There's no data better than hands-on data. That's what I would have hoped for. I've got some REALLY warm spots in my heart for Icom products that were established back in the days when I was putting repeaters on 1200 foot towers! Do you use the external intercom ptt switch? Bob . . . ________________________________________________________________________________
Date: Aug 31, 2010
No I do not. When the PPT is keyed, BOTH mics are hot. I just tell my passengers to be quiet when I transmit. While flying alone I cancel the intercom all together. Just pushing and holding one button on the face of the unit will cancel the intercom function. Repeat and it is back on. Kevin On Aug 31, 2010, at 7:34 AM, Robert L. Nuckolls, III wrote: > > At 09:11 PM 8/30/2010, you wrote: >> Bob, >> I have one of these units. It works as voice activated to my satisfaction. It my have some components that I do not understand, but voice opens the squelch and squelch closes when silent. Many menus to filter through, but once set it is a fine unit. > > THANK YOU! There's no data better than hands-on > data. That's what I would have hoped for. I've got > some REALLY warm spots in my heart for Icom products > that were established back in the days when I was > putting repeaters on 1200 foot towers! > > Do you use the external intercom ptt switch? > > > > Bob . . . > > > > > ________________________________________________________________________________
Date: Aug 31, 2010
At 08:16 AM 8/31/2010, you wrote: > >No I do not. When the PPT is keyed, BOTH mics are hot. I just tell >my passengers to be quiet when I transmit. While flying alone I >cancel the intercom all together. Just pushing and holding one >button on the face of the unit will cancel the intercom function. >Repeat and it is back on. Good info. Bob. . . ________________________________________________________________________________
Date: Aug 31, 2010
Subject: Re: AeroElectric List access
Bob, Wondering why you prefer the real-time emails? I've been using the digest version for years and I like the one-a-day email. Of course, getting the postings is delayed a day whereas the real-time ones are received same day. Seems like the real-time notices would tend to fill up the mailbox. Maybe I should switch to real-time. Is there a good reason? Stan Sutterfield I recommend that you check ONLY the real-time and not the digest service. ________________________________________________________________________________
Subject: Icom A210/A200 owners
Date: Aug 31, 2010
Hello List=2C I'm getting very close to hooking up all the components to my instrument panel=2C and I'd sure like some advice regarding my Icom A200.=2C to be put into the 2-place plane I'm building. I have a SoftComm International ATC-2 potable intercom that I got for my plane years ago. I also have a Icom A200 (mobile style). Basically=2C it the sa me a the regular A200=2C it's just that it comes more like a CB radio=3B attched mic via a c oiled cord=2C speaker that pluds into a 3mm plug recepticle=2C hot/grnd leads for power. Anyway=2C back to my question=3B For those guys that have experience wit h the built-in intercom function of the Icom radios=2C would you say that that alone is su fficient (for a 2-place)=2C or is the intercom part "lacking"=2C and in need of a separate dedicated in tercom? Frankly=2C if the concensus is that the Icom is up to the task=2C I'd rat her just go ahead and install a couple of jacks and be done with it. (the intercom part=2C I mean ) So=2C wuddaya think of the Icom intercom?? Thanks=2C Mike Welch ________________________________________________________________________________
Date: Aug 31, 2010
Sheesh=2C I should proof-read more. Overlook the typos. Thanks=2C Mike From: mdnanwelch7(at)hotmail.com Subject: AeroElectric-List: Icom A210/A200 owners Date: Tue=2C 31 Aug 2010 09:25:32 -0700 Hello List=2C I'm getting very close to hooking up all the components to my instrument panel=2C and I'd sure like some advice regarding my Icom A200.=2C to be put into the 2-place plane I'm building. I have a SoftComm International ATC-2 potable intercom that I got for my plane years ago. I also have a Icom A200 (mobile style). Basically=2C it the sa me a the regular A200=2C it's just that it comes more like a CB radio=3B attched mic via a c oiled cord=2C speaker that pluds into a 3mm plug recepticle=2C hot/grnd leads for power. Anyway=2C back to my question=3B For those guys that have experience wit h the built-in intercom function of the Icom radios=2C would you say that that alone is su fficient (for a 2-place)=2C or is the intercom part "lacking"=2C and in need of a separate dedicated in tercom? Frankly=2C if the concensus is that the Icom is up to the task=2C I'd rat her just go ahead and install a couple of jacks and be done with it. (the intercom part=2C I mean ) So=2C wuddaya think of the Icom intercom?? Thanks=2C Mike Welch ________________________________________________________________________________
Subject: Re: Which connection from a Garmin 296 to my Dynon
180?
Date: Aug 31, 2010
Never mind. My guess was right. Link below http://www.xenonowners.com/index.php?option=com_content&view=article&id=48:connecting-garmin-gps-to-dynon-efis&catid=10:avionics&Itemid=11 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310846#310846 ________________________________________________________________________________
Date: Aug 31, 2010
Subject: removing bendix king kma 24
I have a bendix king kma 24 that popped the 3 amp cb labeled spkr.The installation is about 2 years old and was done by a shop. I would like to remove the KMA 24 to bench test it and would like to know how to do it . Thanks Joe Motis Cherokee 180 CH 750 from prints. No archive ________________________________________________________________________________
Subject: Re: Icom A210/A200 owners
Date: Sep 01, 2010
Mike, The A200 intercom function has been criticized by many, including Stein Bruch in print and in forums. Most of the criticism centered around the A200 not being a voice activated intercom system. A separate broadcast/intercom switch needs to be mounted and you have to select one or the other and then activate the PTT switch to communicate. I combined my A200 with a PS Engineering PM-501 intercom and it works great. I really like my A200 and have gotten compliments on how clear the transmission sounds in the air. On the ground, though, i have been told that it is not quite so clear. Good luck, -------- David Gallagher 601 XL/Jabiru 3300 First flight 7/24/08 Upgraded 3/19/10 150+ hours and climbing! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310909#310909 ________________________________________________________________________________
Date: Sep 01, 2010
> The A200 intercom function has been criticized by many> -------- > David Gallagher Thanks=2C Dave. I get the impression this opionion about the Icom's intercom is fairly co mmon. I guess I'll go ahead and plan on the Softcomm intercom. Thanks. Mike Welch Kolb MkIII CX ________________________________________________________________________________
Date: Sep 01, 2010
At 10:18 AM 8/31/2010, you wrote: > >Bob, >Wondering why you prefer the real-time emails? I've been using the >digest version for years and I like the one-a-day email. Of course, >getting the postings is delayed a day whereas the real-time ones are >received same day. Seems like the real-time notices would tend to >fill up the mailbox. >Maybe I should switch to real-time. Is there a good reason? When you're checking into the List many times a day with some notion of staying current with conversations, it's best to get the real-time dumps. The digest- dump is faster, less expensive and more convenient for people with dial-up . . . especially those who need to access their ISP via a long-distance call. I suspect those are now a very tiny proportion of the List members . . . if not zero. But one dump per day of the last 24 hours worth of activity is pretty pedestrian for individuals who enjoy perhaps several exchanges a day on a topic. There's another matter of tiny significance. Neophyte List subscribers will sometimes reply to a digest- dump thinking that they're only replying to one item of interest in the dump but unless they know to trim out the non-relevant postings, their reply can be spectacularly verbose. Bob . . . ________________________________________________________________________________
Date: Sep 01, 2010
Subject: Re: removing bendix king kma 24
At 10:29 PM 8/31/2010, you wrote: > I have a bendix king kma 24 that popped the 3 amp cb labeled > spkr.The installation is about 2 years old and was done by a shop. >I would like to remove the KMA 24 to bench test it and would like to >know how to do it . Look for a recessed screw on the face. It may be a recessed hex drive that requires an allen-wrench. This is a long screw that accesses a nutplate in the back of the tray. Back the screw out and pull the guts from the tray. Bob . . . ________________________________________________________________________________
180?
Date: Sep 01, 2010
It looks like the your plan will work. The RV-12s (all of them) are wired like this: The Garmin x96 blue wire is connected to EMS pin 19 on the D-180. The FlightDEK-D180 Installation Guide also mentions this on the bottom of page 4-7. On the RV-12, EFIS pins 9, 10, & 22 are used for communicating with a PC. So there is more than one way to connect a GPS to the D-180. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310938#310938 ________________________________________________________________________________
Date: Sep 01, 2010
Yeah I think that one has a tab that rotates 90 as you turn the 3/32 Allen head screw. After 2~3 turns counterclockwise the unit should slip out of the tray. Dont unscrew it all the way or it will fall apart. Tim Andres -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, September 01, 2010 7:56 AM Subject: Re: AeroElectric-List: removing bendix king kma 24 At 10:29 PM 8/31/2010, you wrote: > I have a bendix king kma 24 that popped the 3 amp cb labeled > spkr.The installation is about 2 years old and was done by a shop. >I would like to remove the KMA 24 to bench test it and would like to >know how to do it . Look for a recessed screw on the face. It may be a recessed hex drive that requires an allen-wrench. This is a long screw that accesses a nutplate in the back of the tray. Back the screw out and pull the guts from the tray. Bob . . . Checked by AVG - www.avg.com 11:34:00 ________________________________________________________________________________
180?
Date: Sep 01, 2010
Geoff, Set your 296 Com output to either "Aviation IN/NMEA &VHF Out" or "NMEA In/NMEA Out." Either will work. Baud rate 0f 9600 was recommended. Also make sure to go into the 296's advanced com menu and set up for "normal" output rate. Pages 116-119 of the 296 manual shows these set-up pages. My Dynon and 296 have worked great together with these settings. -------- David Gallagher 601 XL/Jabiru 3300 First flight 7/24/08 Upgraded 3/19/10 150+ hours and climbing! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310941#310941 ________________________________________________________________________________
180?
Date: Sep 01, 2010
Thanks Guys......Geoff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310956#310956 ________________________________________________________________________________
Date: Sep 01, 2010
Here is what I found in my files (sorry, it may be a bit too instructive): KMA 24 removal Insert a 3/32, long allen wrench into the center access hole for the locking screw in the front panel. Gently engage the screw. Turn the screw counter-clockwise until the unit disengages from the mounting rack. Caution Do not overturn. Do not pull on the knobs. Do not pry the face plate. Do not touch the connector card at the rear of the unit to avoid electrostatic damage. Pull the sides of the unit gently to slide it out from the mounting rack. KMA 24 installation into rack Turn (by hand) and push the latch/locking lobe into the unit so the units bottom is flat and there is no lobe sticking out. Slide the unit into the rack. Engage the locking screw so that the latch front lobe touches the rack. Turn the locking screw clockwise to that the rear lobe engages the rack and starts pulling the unit into the rack. You can help by gently pushing the sides by hand. Caution do not over-tighten you can damage the locking mechanism. Rumen ---- "Robert L. Nuckolls wrote: > > At 10:29 PM 8/31/2010, you wrote: > > I have a bendix king kma 24 that popped the 3 amp cb labeled > > spkr.The installation is about 2 years old and was done by a shop. > >I would like to remove the KMA 24 to bench test it and would like to > >know how to do it . > > Look for a recessed screw on the face. It may be a > recessed hex drive that requires an allen-wrench. > This is a long screw that accesses a nutplate in > the back of the tray. Back the screw out and > pull the guts from the tray. > > Bob . . . > > > > > ________________________________________________________________________________
Date: Sep 01, 2010
At 10:24 AM 9/1/2010, you wrote: > >Yeah I think that one has a tab that rotates 90 as you turn the 3/32 Allen >head screw. After 2~3 turns counterclockwise the unit should slip out of the >tray. Dont unscrew it all the way or it will fall apart. Ahhhh . . . but of course. Folks haven't used the rear-panel nut plate in 40 years. Sometimes your sense of history can become distracting of the present! Good put Tim. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- ________________________________________________________________________________
Date: Sep 01, 2010
Thanks to everyone, as usual, the list beats all. Anyone care to venture why the speaker 3 amp breaker is popping? Is the am p a common failure point? Looked at the schematic and didnt see any thing remarkable.. Will know more after removing the unit and seeing if it is ships wiring or the KMA 24 that is popping the CB..Everything else works normal as far as I can tell wit the unit... Thanks again to all. Joe Motis Flying the 180 and building The CH 750 No archive On 9/1/10, Robert L. Nuckolls, III wrote: > > nuckolls.bob(at)aeroelectric.com> > > At 10:24 AM 9/1/2010, you wrote: > >> tim2542(at)sbcglobal.net> >> >> Yeah I think that one has a tab that rotates 90=B0 as you turn the 3/32 >> Allen >> head screw. After 2~3 turns counterclockwise the unit should slip out of >> the >> tray. Don=92t unscrew it all the way or it will fall apart. >> > > Ahhhh . . . but of course. Folks haven't used the > rear-panel nut plate in 40 years. Sometimes your > sense of history can become distracting of the > present! Good put Tim. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Sep 01, 2010
Does it have a separate fuse for the speaker? In any case I would check the 2 leads to the speaker from the connector at the back of the tray. Should be what, 8 or 16 ohms +/- between the leads? Also, no continuity to ground. At least with the unit removed that is. Hopefully you just have a wire with an unintentional ground or a bad speaker. Tim Andres. (Not an avionics tech and slept in my own bed last night) _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of joe motis Sent: Wednesday, September 01, 2010 6:37 PM Subject: Re: AeroElectric-List: removing bendix king kma 24 Thanks to everyone, as usual, the list beats all. Anyone care to venture why the speaker 3 amp breaker is popping? Is the amp a common failure point? Looked at the schematic and didnt see any thing remarkable.. Will know more after removing the unit and seeing if it is ships wiring or the KMA 24 that is popping the CB..Everything else works normal as far as I can tell wit the unit... Thanks again to all. Joe Motis Flying the 180 and building The CH 750 No archive On 9/1/10, Robert L. Nuckolls, III wrote: At 10:24 AM 9/1/2010, you wrote: Yeah I think that one has a tab that rotates 90=B0 as you turn the 3/32 Allen head screw. After 2~3 turns counterclockwise the unit should slip out of the tray. Don=92t unscrew it all the way or it will fall apart. Ahhhh . . . but of course. Folks haven't used the rear-panel nut plate in 40 years. Sometimes your sense of history can become distracting of the present! Good put Tim. Bob . . . --------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) --------------------------------------- browse enExtLink(window,event,this)" href="http://www.matronics.com/Navigator?AeroElectric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List OpenExtLink(window,event,this)" href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com Matt Dralle, List Admin. " href="http://www.matronics.com/contribution" target="_blank">http://w================ ====== 23:34:00 ________________________________________________________________________________
Date: Sep 01, 2010
Thanks Tim, good starting points. Will know more on Friday. Thanks Joe No archive On Wed, Sep 1, 2010 at 7:08 PM, Tim Andres wrote: > Does it have a separate fuse for the speaker? In any case I would check > the 2 leads to the speaker from the connector at the back of the tray. > Should be what, 8 or 16 ohms +/- between the leads? Also, no continuity to > ground. At least with the unit removed that is. Hopefully you just have a > wire with an unintentional ground or a bad speaker. > > Tim Andres. > > (Not an avionics tech and slept in my own bed last night) > > > ------------------------------ > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *joe motis > *Sent:* Wednesday, September 01, 2010 6:37 PM > > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: removing bendix king kma 24 > > > Thanks to everyone, as usual, the list beats all. > > Anyone care to venture why the speaker 3 amp breaker is popping? Is the > amp a common failure point? Looked at the schematic and didnt see any thi ng > remarkable.. Will know more after removing the unit and seeing if it is > ships wiring or the KMA 24 that is popping the CB..Everything else works > normal as far as I can tell wit the unit... > > > Thanks again to all. > > > Joe Motis Flying the 180 > > and building > > The CH 750 > > > No archive > > > On 9/1/10, *Robert L. Nuckolls, III* > wrote: > > nuckolls.bob(at)aeroelectric.com> > > At 10:24 AM 9/1/2010, you wrote: > > tim2542(at)sbcglobal.net> > > Yeah I think that one has a tab that rotates 90=B0 as you turn the 3/32 A llen > head screw. After 2~3 turns counterclockwise the unit should slip out of > the > tray. Don=92t unscrew it all the way or it will fall apart. > > > Ahhhh . . . but of course. Folks haven't used the > rear-panel nut plate in 40 years. Sometimes your > sense of history can become distracting of the > present! Good put Tim. > > > Bob . . . > > --------------------------------------- > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > --------------------------------------- browse > enExtLink(window,event,this)" href=" > http://www.matronics.com/Navigator?AeroElectric-List" target="_blank"> > http://www.matronics.com/Navigator?AeroElectric-List > OpenExtLink(window,event,this)" href="http://forums.matronics.com/" > target="_blank">http://forums.matronics.com > Matt Dralle, List Admin. > " href="http://www.matronics.com/contribution" target="_blank">http:/ /w > ====================== > > > * * > > * * > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?AeroElectric-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > .1.1/3106 > - Release Date: 08/31/10 23:34:00 > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Subject: one accessory affecting another ??????
Date: Sep 01, 2010
is it common for an intercom to receive different power level based on the radio being turned on or off? they share a common power wire. RADIO turned OFF the intercom led is inbetween red and green and defaulting to co pilot side only RADIO turned ON the intercom led is bright green and functioning well when i say turned on or off I mean that the knob on the radio is turned to the off position or on position the power wire stays hot always Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311034#311034 ________________________________________________________________________________
Date: Sep 02, 2010
Subject: Re: one accessory affecting another ??????
At 10:30 PM 9/1/2010, you wrote: is it common for an intercom to receive different power level based on the radio being turned on or off? they share a common power wire. RADIO turned OFF the intercom led is inbetween red and green and defaulting to co pilot side only RADIO turned ON the intercom led is bright green and functioning well when i say turned on or off I mean that the knob on the radio is turned to the off position or on position the power wire stays hot always Your narration has the "smell" of a noise issue. I'm not familiar with the 'red/green' thing on the intercom and you don't say what kind of radio is involved . . . but here's a WAG. Many modern radios have inverters to supply special power for operation of LCD and/or glow-discharge displays. These are potential antagonists for noise. Will they PROBABLY meet DO-160 requirements for how much noise is pushed back onto the power line, the intercom MIGHT be unusually susceptible. Try operating the intercom from a separate 12v source, like a test battery as described in the noise trouble shooting section of The 'Connection. If this makes the symptoms go away, consider adding a line noise filter in the +14v supply to the intercom. We have a filter you can try . . . if it doesn't do the job, you can return it. Bob . . . ________________________________________________________________________________
Date: Sep 02, 2010
I am not having the problem with the radio turned on and it pushing backfeeding through the power line but that the intercom will only perform with the radio turned ON Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311070#311070 ________________________________________________________________________________
Date: Sep 02, 2010
At 09:32 AM 9/2/2010, you wrote: > >I am not having the problem with the radio turned on and it pushing >backfeeding through the power line but that the intercom will only >perform with the radio turned ON Hmmm . . . blew that WAG out of the water. Still, operating the intercom from a separate power source like a battery would be an interesting thing to do. If two boxes are 'talking' to each other, you need to deduce the propagation pathway. The experiment would confirm/deny the +14v power leads as being part of that pathway. Bob . . . ________________________________________________________________________________
Subject: Splicing a shielded cable
Date: Sep 02, 2010
The dynon instructions call for a 4-conductor shielded cable from the panel to the remote compass. I'm planning to put the compass box in the wing, but would like to have a connector at the wing root to facilitate wing removal. What is the best type of connector to use in that case? ________________________________________________________________________________
Subject: Re: Intercom Noise
Date: Sep 02, 2010
Bob, More data points: I installed a portable intercom in my plane. Its plugged in the new Pilot mic & phone jacks. With only the internal 9v battery powering the unit, I still get the noise in my headsets, but it is tolerable. Intercom off = no noise. When I power the portable intercom from ships power the no ise is louder, but still tolerable...barely. Any ideas now? Jeff Darnall Jacksonville, FL 904-234-8718 __i__ *-----o--o--(_)--o--o-----* ________________________________________________________________________________
Date: Sep 02, 2010
I'd say it's time to look at your headsets. Bruce www.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of darnpilot(at)aol.com Sent: Thursday, September 02, 2010 8:17 PM Subject: AeroElectric-List: Re: Intercom Noise Bob, More data points: I installed a portable intercom in my plane. Its plugged in the new Pilot mic & phone jacks. With only the internal 9v battery powering the unit, I still get the noise in my headsets, but it is tolerable. Intercom off = no noise. When I power the portable intercom from ships power the noise is louder, but still tolerable...barely. Any ideas now? Jeff Darnall Jacksonville, FL 904-234-8718 __i__ *-----o--o--(_)--o--o-----* ________________________________________________________________________________
Date: Sep 02, 2010
Bruce. Why? Tell me more? I've used several different type headsets and they all have the same issue . Jeff Darnall Jacksonville, FL 904-234-8718 __i__ *-----o--o--(_)--o--o-----* -----Original Message----- From: Bruce Gray <bgray(at)glasair.org> Sent: Thu, Sep 2, 2010 8:41 pm Subject: RE: AeroElectric-List: Re: Intercom Noise I=99d say it=99s time to look at your headsets. Bruce www.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelect ric-list-server(at)matronics.com] On Behalf Of darnpilot(at)aol.com Sent: Thursday, September 02, 2010 8:17 PM Subject: AeroElectric-List: Re: Intercom Noise Bob, More data points: I installed a portable intercom in my plane. Its plugged in the new Pilot mic & phone jacks. With only the internal 9v battery powering the unit, I still get the noise in my headsets, but it is tolerable. Intercom off = no noise. When I power the portable intercom from ships power the no ise is louder, but still tolerable...barely. Any ideas now? Jeff Darnall Jacksonville, FL 904-234-8718 __i__ *-----o--o--(_)--o--o-----* - The AeroElectric-List Email Forum - --> http://www.matronics.com/Navigator?AeroElectric-List --> http://www.matronics.com/Navigator?AeroElectric-List - MATRONICS WEB FORUMS - - MATRONICS WEB FORUMS - --> http://forums.matronics.com --> http://forums.matronics.com - List Contribution Web Site - - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution ======================== =========== -= - The AeroElectric-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?AeroElectric-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Dual Shunts with Dynon EMS
Date: Sep 02, 2010
I have an SD-8 auxiliary alternator. I am using the Z-13 wiring scheme which has shunts for the primary and auxiliary alternator. I will be using a Dynon EMS. The Dynon has a single input for ammeter. I want to access the both shunts in the Z-13 wiring scheme. My initial design was to use a DPDT relay connected to the auxiliary alternator switch. With the switch in the off position, the primary alternator shunt would be connected to the EMS. With the switch in the on position the relay would disconnect the primary and connect the auxiliary alternator shunt. Question: Is a simpler alternative to hook both shunts to the single EMS input? And if I did this, would the reading be the sum of the two, if both alternators were active at the same time? ________________________________________________________________________________
Subject: Re: Dual Shunts with Dynon EMS
Date: Sep 03, 2010
Do not connect the two shunts in parallel. Doing that is the same as connecting the two alternators in parallel. The Dynon would read the higher of the two voltages, not the sum. Using a relay will work. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311197#311197 ________________________________________________________________________________
Date: Sep 03, 2010
Just my two cents worth but it is important to understand that many regulated power supplies and regulator ICs require a minimum load (current draw) before they will regulate. It is possible that the intercom does not draw enough current to do the job and a load ohm resistor across the input power but after the on/off switch might be required. This load resistor is an important circuit element even with LM317 regulators. They specify a Min Load Current of a few milliamps, but other supplies can be several tens of milliamps or more. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311203#311203 ________________________________________________________________________________
Subject: Re: Splicing a shielded cable
Date: Sep 03, 2010
I am building a Van's RV-12 that has a Dynon D-180 with a remote compass located in the tail. The Van's supplied cable is not shielded. Instead, individual wires are twisted together. Since shielding is optional, I would not be too concerned about making a splice at the wing root. This application is not critical like a coax carrying a radio frequency. Any type of connector should work, like a D-Sub or even a 4 pin automotive trailer hitch connector. Since Dynon uses a D-Sub on each end, that would be good choice for the splice. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311204#311204 ________________________________________________________________________________
Date: Sep 03, 2010
Automobiles now have a similar switch for electric windows. Pull (or push) the switch a bit to move the window, then pull (or push) it past a detent to automatically raise or lower the window. -------- Marc Ausman http://www.verticalpower.com "Move up to a modern electrical system" RV-7 IO-390 Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311205#311205 ________________________________________________________________________________
Date: Sep 03, 2010
I was planning to use a separate dpdt switch on the instrument panel, but I like the relay idea. Which relay were you planning to use? On Fri, Sep 3, 2010 at 7:08 AM, user9253 wrote: > > > > Do not connect the two shunts in parallel. Doing that is the same as > connecting the two alternators in parallel. The Dynon would read the higher > of the two voltages, not the sum. Using a relay will work. > Joe > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311197#311197 > > ________________________________________________________________________________
Date: Sep 03, 2010
Thanks Joe, that sounds like good information. On Fri, Sep 3, 2010 at 8:03 AM, user9253 wrote: > > > > I am building a Van's RV-12 that has a Dynon D-180 with a remote compass > located in the tail. The Van's supplied cable is not shielded. Instead, > individual wires are twisted together. Since shielding is optional, I would > not be too concerned about making a splice at the wing root. This > application is not critical like a coax carrying a radio frequency. Any > type of connector should work, like a D-Sub or even a 4 pin automotive > trailer hitch connector. Since Dynon uses a D-Sub on each end, that would > be good choice for the splice. > Joe > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311204#311204 > > ________________________________________________________________________________
Date: Sep 03, 2010
At 06:08 AM 9/3/2010, you wrote: > >Do not connect the two shunts in parallel. Doing that is the same >as connecting the two alternators in parallel. The Dynon would read >the higher of the two voltages, not the sum. Using a relay will work. >Joe Right on. I'll also suggest that unless the relay is really desirable from the perspective of reducing numbers of wires at the panel controls you might consider using just a DPDT switch as shown on the third page of: http://www.aeroelectric.com/Catalog/AEC/9007/AEC9007-700.pdf Bob . . . ________________________________________________________________________________
Date: Sep 03, 2010
At 07:17 PM 9/2/2010, you wrote: >Bob, > >More data points: >I installed a portable intercom in my plane. Its plugged in the new >Pilot mic & phone jacks. With only the internal 9v battery powering >the unit, I still get the noise in my headsets, but it is >tolerable. Intercom off = no noise. When I power the portable >intercom from ships power the noise is louder, but still tolerable...barely. Hmmmmm . . . What is the nature of the noise? whine, rumble, static, does it's pitch or repetition rate change with engine RPM. Does the noise go away if EVERYTHING else is off while only the radio/intercom pair is operating? Bob . . . ________________________________________________________________________________
Date: Sep 03, 2010
At 07:03 PM 9/2/2010, you wrote: > >The dynon instructions call for a 4-conductor shielded cable from >the panel to the remote compass. I'm planning to put the compass box >in the wing, but would like to have a connector at the wing root to >facilitate wing removal. What is the best type of connector to use >in that case? If the area is expected to stay DRY, then a machined-pin, D-sub is fine. Bob . . . ________________________________________________________________________________
Date: Sep 03, 2010
I thought about the using the switch directly and may still do that. Using the relay tied to the switch for the auxiliary alternator set it up so the shunt selection would occur when the auxiliary alternator was turned on, eliminating the need to toggle two switches. John -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, September 03, 2010 8:07 AM Subject: Re: AeroElectric-List: Re: Dual Shunts with Dynon EMS At 06:08 AM 9/3/2010, you wrote: > >Do not connect the two shunts in parallel. Doing that is the same >as connecting the two alternators in parallel. The Dynon would read >the higher of the two voltages, not the sum. Using a relay will work. >Joe Right on. I'll also suggest that unless the relay is really desirable from the perspective of reducing numbers of wires at the panel controls you might consider using just a DPDT switch as shown on the third page of: http://www.aeroelectric.com/Catalog/AEC/9007/AEC9007-700.pdf Bob . . . ________________________________________________________________________________
Date: Sep 03, 2010
Trouble shooting electronic gremlins requires a systematic approach. The most important thing to remember is to only change one variable at a time. If you have swapped headsets and the noise remained, we can rule out bad headsets. I would suggest the following decision tree. 1) Test the intercom in another aircraft if possible. If the problem follows the intercom, the intercom is bad. 2) Test with the engine and ALL other electrical devices OFF except the intercom. If no noise proceed to 3 3) Repeat 2 with engine running and ALT off. 4) Repeat 2 with engine and ALT on. 5) With engine off, turn on separately each other piece of electronics. 6) Repeat 5 with engine and ALT on. Get back to me with the results. Are you using shielded wire? Is the shield only grounded at one end (which is correct)? Bruce www.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of darnpilot(at)aol.com Sent: Thursday, September 02, 2010 8:46 PM Subject: Re: AeroElectric-List: Re: Intercom Noise Bruce. Why? Tell me more? I've used several different type headsets and they all have the same issue. Jeff Darnall Jacksonville, FL 904-234-8718 __i__ *-----o--o--(_)--o--o-----* -----Original Message----- From: Bruce Gray <bgray(at)glasair.org> Sent: Thu, Sep 2, 2010 8:41 pm Subject: RE: AeroElectric-List: Re: Intercom Noise I'd say it's time to look at your headsets. Bruce <http://www.glasair.org/> www.Glasair.org -----Original Message----- From: <mailto:owner-aeroelectric-list-server(at)matronics.com> owner-aeroelectric-list-server(at)matronics.com [ mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of darnpilot(at)aol.com Sent: Thursday, September 02, 2010 8:17 PM aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Re: Intercom Noise Bob, More data points: I installed a portable intercom in my plane. Its plugged in the new Pilot mic & phone jacks. With only the internal 9v battery powering the unit, I still get the noise in my headsets, but it is tolerable. Intercom off = no noise. When I power the portable intercom from ships power the noise is louder, but still tolerable...barely. Any ideas now? Jeff Darnall Jacksonville, FL 904-234-8718 __i__ *-----o--o--(_)--o--o-----* - The AeroElectric-List Email Forum - --> <http://www.matronics.com/Navigator?AeroElectric-List> http://www.matronics.com/Navigator?AeroElectric-List - MATRONICS WEB FORUMS - --> <http://forums.matronics.com/> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> <http://www.matronics.com/contribution> http://www.matronics.com/contribution =================================== List" target=_blank>http://www.matronics.com/Navigator?AeroElectric-List =================================== tp://forums.matronics.com =================================== _blank>http://www.matronics.com/contribution =================================== http://www.matronics.com/Navigator?AeroElectric-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 03, 2010
So use a 3PDT switch for turning on the aux alternator. One pole switches t he alternator on/off the other two switch the shunts. ???????? Bob McC > From: jvolkober(at)comcast.net > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Re: Dual Shunts with Dynon EMS > Date: Fri=2C 3 Sep 2010 09:15:21 -0700 > st.net> > > I thought about the using the switch directly and may still do that. Usin g > the relay tied to the switch for the auxiliary alternator set it up so th e > shunt selection would occur when the auxiliary alternator was turned on =2C > eliminating the need to toggle two switches. > > John > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. > Nuckolls=2C III > Sent: Friday=2C September 03=2C 2010 8:07 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Dual Shunts with Dynon EMS > > > > At 06:08 AM 9/3/2010=2C you wrote: om> > > > >Do not connect the two shunts in parallel. Doing that is the same > >as connecting the two alternators in parallel. The Dynon would read > >the higher of the two voltages=2C not the sum. Using a relay will work. > >Joe > > Right on. I'll also suggest that unless the > relay is really desirable from the perspective > of reducing numbers of wires at the panel controls > you might consider using just a DPDT switch > as shown on the third page of: > > http://www.aeroelectric.com/Catalog/AEC/9007/AEC9007-700.pdf > > > Bob . . . > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Spiral Wrapped Panel Wire Bundle
Date: Sep 03, 2010
Hello! I've changed the supporting structure for my instrument panel and subpanel for my Sonex and would like to get some feedback on my ideas for securing the wiring. The main panel is tilted per plans at 30 degrees and is attached via piano on top to the glareshield with a piano hinge, on the sides with nutplates, and to the subpanel with another piano hinge. The subpanel is from a 1/8" thick extruded angle, which is 1.5" tall and 5/8" deep. Pic 004 is the only one taken with the panel in the closed position. The others are with it tilted partially open for viewing. One concern is getting the wires going to the back of the MGL Enigma EFIS so they aren't dangling down onto the control cables. Looking at pic 006 you can see two white wires going into the left side of the EFIS. I'll move these (as well as a blue wire not shown) into the spiral wrap so they will exit the bundle to the left of the EFIS, about where the grey cable exits. This leaves only the wires going into the 9 pin connector. It came delivered with these wires looped around through the ferrite tube as shown. Orange and green for OAT will go to the red and green wires coming out of the wrap on the right. White won't be connected to anything. This leaves the black ground and red supply wires. I didn't make the black ground long enough, so I'll resplice it. This will allow enough slack to move the ferrite tube to a better place instead of dangling close to the control cables, and more importantly, the center flap and brake handles. So I'm wondering where a good place for this ferrite tube would be. If it needs to be secured, I could strap it on top of the 9 pin connector with a couple tie wraps around the outside of the tube. Or turn the tube 90 and run it through the middle. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311255#311255 Attachments: http://forums.matronics.com//files/panel_wire_bundle_006_140.jpg http://forums.matronics.com//files/panel_wire_bundle_004_128.jpg ________________________________________________________________________________
Subject: Re: Spiral Wrapped Panel Wire Bundle
Date: Sep 03, 2010
Another issue is securing the spiral wrapped bundle to the subpanel. I had thought of simply drilling holes every 6" through the top of the subpanel and cinching the bundle down with tie wraps. You can see a couple of temporary safety wire pieces twisted in place in the pics. But instead of doing this, I thought it would be better to support the bundle with those saddle anchors that can be riveted on. The final issue I have is where the spiral wrap drops below the top of the subpanel on the cabin's left side (right side in pics) and goes between a switch cover and the vertical face of the subpanel. I can't have it continue on top because the light with a red and black wire would interfere with it. I figure I could wrap this area with silicon tape to protect it against the edge of the subpanel. Or maybe adding another section of spiral wrap over the existing spiral wrap, making two layers of it. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311257#311257 Attachments: http://forums.matronics.com//files/panel_wire_bundle_007_195.jpg http://forums.matronics.com//files/panel_wire_bundle_008_298.jpg ________________________________________________________________________________
Date: Sep 03, 2010
Subject: Narco Com 810+
Looking to see if anyone has a -service- manual for the Narco 810/811 TSO in their library... TIA Ron Q. ________________________________________________________________________________
Date: Sep 03, 2010
Like this: I tend to have a habit of taking the long way around the bush. John -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of robert.mccallum2(at)sympatico.ca Sent: Friday, September 03, 2010 10:09 AM Subject: RE: AeroElectric-List: Re: Dual Shunts with Dynon EMS So use a 3PDT switch for turning on the aux alternator. One pole switches the alternator on/off the other two switch the shunts. ???????? Bob McC > From: jvolkober(at)comcast.net > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Re: Dual Shunts with Dynon EMS > Date: Fri, 3 Sep 2010 09:15:21 -0700 > > > I thought about the using the switch directly and may still do that. Using > the relay tied to the switch for the auxiliary alternator set it up so the > shunt selection would occur when the auxiliary alternator was turned on, > eliminating the need to toggle two switches. > > John > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. > Nuckolls, III > Sent: Friday, September 03, 2010 8:07 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Dual Shunts with Dynon EMS > > > > At 06:08 AM 9/3/2010, you wrote: > > > >Do not connect the two shunts in parallel. Doing that is the same > >as connecting the two alternators in parallel. The Dynon would read > >the higher of the two voltages, not the sum. Using a relay will work.
August 20, 2010 - September 03, 2010
AeroElectric-Archive.digest.vol-jr
