AeroElectric-Archive.digest.vol-ma
October 26, 2013 - November 19, 2013
      controlled landing ????
      In order to stop, the engine must have been denied either fuel, spark or
      mechanical integrity, and for it to restart you must determine and restore
      whichever element is missing before the starter will be of any use. (and
      you've had to aerodynamically stall the airframe to stop the engine's wind
      milling rotation) With all the redundancies and complexities you're
      proposing you're unlikely to troubleshoot and solve the problem in the air.
      It's excellent to think up and have a solution for the various scenarios,
      but at some point you need to follow the KISS principle and not layer one
      "what if" on top of another. The likelihood of two or more failures on any
      one flight on a properly designed and maintained aircraft are exceeding
      unlikely.
      By all means design for any single "what if" or failure you can possibly
      conceive, but to layer one on top of another on top of another and try to
      have a work-around is just going to increase the likelihood of a problem not
      decrease it.
      Just my unsolicited two cents which you're quite entitled to delete or
      ignore (or deposit in the bank if you so desire)
      Bob McC
        _____
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Fred Klein Sent: Saturday, October 26, 2013 1:30 PM
Subject: Re: EXP 2 Bus workaround
On Oct 26, 2013, at 10:09 AM, Robert L. Nuckolls, III wrote: Can you spin your starter w/ the Master Switch off? Why would you want access to the starter with the master switch off? Under what conditions would you first have the switch off and then find that the engine has assumed a condition that needs encouragement to get running again? Assuming that the engine is at risk for doing such a thing, what prevents you from turning the master switch back on? Bob...my imagination knows no limits...I'm thinkin the Master's off after detecting smoke and acrid smells coming from the panel...I'm wanting to avoid the risk of flippin the Master back on and exacerbating the situation which caused me to flip it off in the first place. Fred ________________________________________________________________________________
Date: Oct 26, 2013
At 01:21 PM 10/26/2013, you wrote: >On Oct 26, 2013, at 10:56 AM, Robert L. Nuckolls, III wrote: > >>Even so, unless you've got a clutched PRSU then you're >> not going to need the starter anyhow. If the engine >> has lost power due to same event that's causing smoke >> . . . it's likely that mitigation of risk for >> that cause is far outside the manipulation of any switches. > >Bob...I wouldn't disagree with you. > >The origin of this question arose when you noted that my Revision XX >diagram showed the starter switch fed from the engine (sorry, MP) >bus rather than the main bus...I still don't see the down side if I >were to do this. You're still wrapped around the axles of distraction. Let's get your list of loads spread out on the hypothetical architecture I published . . . and sift the FEMA/operational sands for that configuration. Then we can begin to study a means by which the EXP-Bus can morph into the same architecture. It may be that the starter switch gets powered from someplace different simply because you've run out of polyfuses on a particular bus. But downside or upside cannot be discussed until after roll-call. I have a finite amount of time to offer to this process . . . Bob . . . ________________________________________________________________________________
Date: Oct 26, 2013
Subject: EXP 2 Bus workaround
At 01:36 PM 10/26/2013, you wrote: >Fred; > >Not meaning to be critical or judgmental, but your "properly >designed" and maintained electrical system has somehow found a way >to generate "smoke in the cockpit" and you've turned off the master >switch. So far so good. >The electrical problem (or fire) has progressed to the point of >stopping the engine and now you want to be further distracted by >operating the starter to turn over the failed engine rather than to >"FLY THE AIRCRAFT" to a controlled landing ???? Gently my friend. Members here on the is are, for the most part, not aviation professionals. Fewer still have a grasp on the materials, processes and what-if analysis that goes into crafting the elegant solution. There was a time when Z-19 was considered a 'solution' and to be sure, every feature on it operates in a predicable manner with no surprises. Fred's willingness to participate in this exercise has prompted a review of the ideas on which Z-19 stands along with brain-storming for simpler alternatives based on better ideas. Fred has mentioned that a friend of his opined that many band-aid-on-top-of-band-aid designs on airplanes to be products of ignorance and poor logic. Yup, those things happen. I've watched it my whole career in situations where I was one of many and with little influence. It doesn't even take a design by committed/regulation to produce an accident waiting to happen. Review the materials I posted on the N811HB accident. Many individuals who monitor the List have expressed a reluctance to post lest they become targets of words that fall outside the realm of entertaining and persuasive information. This is a classroom and it's my greatest wish that people carry knowledge out the door that adds value to their aviation experience. Bob . . . ________________________________________________________________________________
Date: Oct 26, 2013
I have learned a lot in your classroom. Thanks Bob. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411476#411476 ________________________________________________________________________________
Date: Oct 26, 2013
At 02:51 PM 10/26/2013, you wrote: > >I have learned a lot in your classroom. Thanks Bob. . . . and you've been an honorable participant for which I thank YOU. Bob . . . ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Oct 26, 2013
_____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, October 26, 2013 3:38 PM Subject: RE: AeroElectric-List: EXP 2 Bus workaround At 01:36 PM 10/26/2013, you wrote: Fred; Not meaning to be critical or judgmental, but your =13properly designed=14 and maintained electrical system has somehow found a way to generate =13smoke in the cockpit=14 and you=12ve turned off the master switch. So far so good. The electrical problem (or fire) has progressed to the point of stopping the engine and now you want to be further distracted by operating the starter to turn over the failed engine rather than to =13FLY THE AIRCRAFT=14 to a controlled landing ???? Gently my friend. Was trying to be. If it came across differently, that was not the intention. I apologize. Members here on the is are, for the most part, not aviation professionals. Fewer still have a grasp on the materials, processes and what-if analysis that goes into crafting the elegant solution. There was a time when Z-19 was considered a 'solution' and to be sure, every feature on it operates in a predicable manner with no surprises. Agree Fred's willingness to participate in this exercise has prompted a review of the ideas on which Z-19 stands along with brain-storming for simpler alternatives based on better ideas. And many of his (and others) scenarios point to the areas of potential improvement. Fred has mentioned that a friend of his opined that many band-aid-on-top-of-band-aid designs on airplanes to be products of ignorance and poor logic. Yup, those things happen. Part of the point of my original comment was intended to not lose sight of that philosophy. I've watched it my whole career in situations where I was one of many and with little influence. It doesn't even take a design by committed/regulation to produce an accident waiting to happen. Review the materials I posted on the N811HB accident. Exactly. Many individuals who monitor the List have expressed a reluctance to post lest they become targets of words that fall outside the realm of entertaining and persuasive information. Myself included, but part of the issue is not that the thoughts are intended to be critical or demeaning in any way shape or form but that perhaps the command of English usage or even the degree of articulation is lacking so that comments are misinterpreted. This is a classroom and it's my greatest wish that people carry knowledge out the door that adds value to their aviation experience. Absolutely. I've learned immeasurably through lurking here many years, but as you've stated I'm often reluctant to share because of the fear of misstating my thoughts or verbalizing in a way that is open to misinterpretation. E-mails lack the intonations of a face to face conversation that sometimes conveys as much meaning as the actual words. Bob . . . Once again, if my wording was inappropriate, I apologize. I'll keep quiet now. Bob McC ________________________________________________________________________________
Date: Oct 26, 2013
> Gently my friend. >Was trying to be. If it came across differently, that was not the >intention. I apologize. Understand. Perhaps is was the bold, technicolor font that offered a poor first blush. That is a down-side for keyboard communications. We can be deprived of useful communications data when relying on the written word. No value to be shared in 'being quiet' . . . the ideas you proffered were sound. I'm kind of 'stoked with this thread. There's not been a new z-figure in years. This is a good thing that these things get debated. Fred's worries about the smoke+silence failure prompted a thought on my part that perhaps Engine A switch ought to power from the battery with backup being Engine B from the main bus. This is backwards from how we've used the e-bus but it does suggest better human factors for powering down the electrics while leaving the engine up. Bob . . . ________________________________________________________________________________
Date: Oct 26, 2013
On Oct 26, 2013, at 11:36 AM, Bob McCallum wrote: > Not meaning to be critical or judgmental, but your =93properly designed=94 and maintained electrical system has somehow found a way to generate =93smoke in the cockpit=94 and you=92ve turned off the master switch. So far so good. Thanks Bob M....I needed that...sometimes my imagination needs a comeuppance and a breath of fresh air...Fred ________________________________________________________________________________
Date: Oct 26, 2013
On Oct 26, 2013, at 12:25 PM, Robert L. Nuckolls, III wrote: > You're still wrapped around the axles of distraction. > Let's get your list of loads spread out on the > hypothetical architecture I published . . . and sift > the FEMA/operational sands for that configuration. I'm on it Bob...thanks, Fred ________________________________________________________________________________
Date: Oct 26, 2013
I have drawn a schematic (attached) for Fred using the EXP Bus. It might not be as good as Bob's designs, but I think it is better than many TC aircraft electrical systems. Fred definitely does not want to take a soldering iron to the circuit board. So I could not make some changes that I would like to. If Fred decides to use my schematic, the only changes that he will have to make will be pulling fast-on connectors off from switches and moving them around. The main feature of this schematic is the addition of a master relay that is in parallel with the battery contactor. Not to worry, this relay can not be energized while starting the engine. The switch, that is normally the master switch, must be off in order to start the engine. This also serves as a theft deterrent because a thief will turn on what he thinks is the master switch, but the engine will not start. The former avionics master switch now controls the battery contactor. Since the new master switch also turns on the alternator field, the former ALT switch can now be used for the second fuel pump. I think that the EXP Bus has enough switches so that additional switches will not have to be added to the panel. Now that I am all done with the schematic and stand back and look at the big picture, I see that in case the EXP Bus smokes, shutting off the master switches will also kill the engine. How to fix that? How about an Engine bus fed by the master relay and also by a diode from the EXP Bus? Comments are welcome. Just do not be too hard on me. :-) Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411483#411483 Attachments: http://forums.matronics.com//files/fred_exp_2_bus_200.dwg http://forums.matronics.com//files/fred_exp_2_bus_152.pdf ________________________________________________________________________________
Date: Oct 26, 2013
Subject: EXP 2 Bus workaround - Master Solenoid Failure
=0A=0AI really enjoy this what-if stuff, so here goes...=0A=0A=0AI'm referr ing to Bob's drawing sent out yesterday afternoon, Z-08_Full.pdf.- It app ears that people are touching on this issue but I have not seen it clearly stated. =0A=0A=0AGiven:=0A1. Stated design goal: To be able to survive any single component failure w/ little or no drama.=0A=0A2. Electrically-depend ent engine=0A=0A3. Engine/prop does not windmill, because of some kind of P SRU =0A4. You are flying w/ Engine A switch On=0A5. Engine B switch Off=0A =0A=0AScenario:=0A1. You are in flight and Main Batt Contactor fails (coil burns up, loose wire, whatever)=0A=0A2. Engine shuts down, prop stops=0A=0A 3. Pilot takes several seconds to gather his thoughts=0A4. Pilot turns Engi ne B switch On - power restored to engine systems except starter=0A=0A5. Pi lot hits starter button to re-light.- Starter inop because failed Main Ba tt Contactor is in series w/ Starter Contactor.=0A6. Forced landing=0A=0A7. Failure to meet design goal - single component failure causes forced landi ============= ________________________________________________________________________________
Date: Oct 26, 2013
Subject: Re: EXP 2 Bus workaround - Master Solenoid Failure
At 08:47 PM 10/26/2013, you wrote: >I really enjoy this what-if stuff, so here goes... > >I'm referring to Bob's drawing sent out yesterday afternoon, >Z-08_Full.pdf. It appears that people are touching on this issue >but I have not seen it clearly stated. > >Given: >1. Stated design goal: To be able to survive any single component >failure w/ little or no drama. >2. Electrically-dependent engine >3. Engine/prop does not windmill, because of some kind of PSRU Turns out not true. >4. You are flying w/ Engine A switch On >5. Engine B switch Off > >Scenario: >1. You are in flight and Main Batt Contactor fails (coil burns up, >loose wire, whatever) Okay . . . >2. Engine shuts down, prop stops No, the alternator doesn't quite producing just because the battery is off line. Further, based on the exchange with Fred/Bob Mc/Bob N I realized that the Engine source coming from the battery should be switched by ENG A. Next iteration will show that. But it's also possible that the pilot would be unaware of the loss of contactor until the next flight when turning battery switch on doesn't light things up. >3. Pilot takes several seconds to gather his thoughts >4. Pilot turns Engine B switch On - power restored to engine systems >except starter . . . but engine IS windmilling >5. Pilot hits starter button to re-light. Starter inop because >failed Main Batt Contactor is in series w/ Starter Contactor. >6. Forced landing >7. Failure to meet design goal - single component failure causes >forced landing :( >8. Thanks for playing... inaccurate statement of premises . . . Bob . . . ________________________________________________________________________________
Date: Oct 26, 2013
At 10:15 PM 10/26/2013, you wrote: > > >At 08:47 PM 10/26/2013, you wrote: > >>I really enjoy this what-if stuff, so here goes... >> >>I'm referring to Bob's drawing sent out yesterday afternoon, >>Z-08_Full.pdf. It appears that people are touching on this issue >>but I have not seen it clearly stated. Actually, there IS a compelling reason to move the starter button source to the MP-Bus . . . E-bus and Main bus on the EXP-Bus assembly have fixed numbers of protected load-taps. Moving the starter control to the MP-Bus frees up a load-tap on the EXP-Bus. But this still doesn't help you use the starter in-flight with a contator crapped . . . you may be able to energize the starter contactor but because the battery contactor is open, there's no FAT wire power to the contactor. Bob . . . ________________________________________________________________________________
Date: Oct 26, 2013
=0AI believe that some of the installations of the Rotax 912 (and probably other power systems) do not windmill (but the 912 may not be electrically-d ependent ).=0A=0AHowever, I don't think you can categorically say that ALL engines will windmill.- In addition some flight conditions may cause a wi ndmilling prop to stop.- A possible scenario: The pilot becomes task satu rated on the electrical failure and lets the airspeed bleed down and the pr op stops.=0A=0A=0ADooh! I forgot about the alternator - BUT - I've never tr usted an alternator that was not connected to a battery, therefore I would be reluctant to have that as a fall back.=0A=0A=0AWhat about moving the sta rter feed to the battery side of the master?=0A=0A=0A-Jeff=0A=0A=0A=0A_____ ___________________________=0A From: "Robert L. Nuckolls, III" <nuckolls.bo b(at)aeroelectric.com>=0ATo: aeroelectric-list(at)matronics.com =0ASent: Saturday , October 26, 2013 8:15 PM=0ASubject: Re: AeroElectric-List: EXP 2 Bus work around - Master Solenoid Failure =0A =0A=0A--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" =0A=0AA t 08:47 PM 10/26/2013, you wrote:=0A=0A> I really enjoy this what-if stuff, so here goes...=0A> =0A> I'm referring to Bob's drawing sent out yesterday afternoon, Z-08_Full.pdf.- It appears that people are touching on this i ssue but I have not seen it clearly stated.=0A> =0A> Given:=0A> 1. Stated d esign goal: To be able to survive any single component failure w/ little or no drama.=0A> 2. Electrically-dependent engine=0A> 3. Engine/prop does not windmill, because of some kind of PSRU=0A=0A- Turns out not true.=0A=0A > 4. You are flying w/ Engine A switch On=0A> 5. Engine B switch Off=0A> =0A> Scenario:=0A> 1. You are in flight and Main Batt Contactor fails (coil burns up, loose wire, whatever)=0A=0A- Okay . . .=0A=0A> 2. Engine shut s down, prop stops=0A=0A=0A- No, the alternator doesn't quite producing just=0A- because the battery is off line. Further, based on=0A- the e xchange with Fred/Bob Mc/Bob N I realized that=0A- the Engine source com ing from the battery should=0A- be switched by ENG A. Next iteration wil l show that.=0A=0A- But it's also possible that the pilot would be unawa re=0A- of the loss of contactor until the next flight=0A- when turnin g battery switch on doesn't light things up.=0A=0A> 3. Pilot takes several seconds to gather his thoughts=0A> 4. Pilot turns Engine B switch On - powe r restored to engine systems except starter=0A=0A- . . . but engine IS w indmilling=0A=0A> 5. Pilot hits starter button to re-light.- Starter inop because failed Main Batt Contactor is in series w/ Starter Contactor.=0A> 6. Forced landing=0A> 7. Failure to meet design goal - single component fai lure causes forced landing :(=0A> 8. Thanks for playing...=0A=0A- inaccu ============== ________________________________________________________________________________
Date: Oct 27, 2013
Subject: Battery contactor failure
At 12:00 AM 10/27/2013, you wrote: >I believe that some of the installations of the Rotax 912 (and >probably other power systems) do not windmill (but the 912 may not >be electrically-dependent ). Only if the fuel is delivered by engine driven pump or gravity. The ignition is electronic driven directly from magnets on the starter ring gear. >However, I don't think you can categorically say that ALL engines >will windmill. In addition some flight conditions may cause a >windmilling prop to stop. A possible scenario: The pilot becomes >task saturated on the electrical failure and lets the airspeed bleed >down and the prop stops. That's s double failure again. Failure tolerant systems with a plan-b do not saturate pilots. >Dooh! I forgot about the alternator - BUT - I've never trusted an >alternator that was not connected to a battery, therefore I would be >reluctant to have that as a fall back. Because you know them to be unreliable or simply don't know. Actually, Cessna and others who opted for the split rocker switch were probably in violation of legacy design goals. Until that time, airplanes flew nicely on either battery, generator or both. When the alternator came along, the airframe guys elected to put alternators on even tho they were not plug-n-play for the failure tolerance offered by generators. The Bonanza and Barons continued to offer alternator- only operations but if I recall correctly, the Liberal airplanes had split rockers. PM alternators are easy to get on-line without a battery and it may well be that belt-driven alternators on a Lycoming are too. They run very fast. I need to get some time on B&C's test bench and run some experiments. >What about moving the starter feed to the battery side of the master? If you're willing to have an always hot feeder to a starter contactor . . . Bob . . . ________________________________________________________________________________
Date: Oct 27, 2013
Good Morning All, I have not followed all of this thread, but agree that not all engines windmill like our friendly Continentals and Lycomings. I have about twenty hours flying a Legend Cub powered by the Jabiru engine. It is a nice smooth running engine, but if it runs out of fuel or the mags are shut off, the prop stops! Happy Skies, Old Bob In a message dated 10/27/2013 3:32:26 A.M. Central Daylight Time, jluckey(at)pacbell.net writes: I believe that some of the installations of the Rotax 912 (and probably other power systems) do not windmill (but the 912 may not be electrically-dependent ). However, I don't think you can categorically say that ALL engines will windmill. In addition some flight conditions may cause a windmilling prop to stop. A possible scenario: The pilot becomes task saturated on the electrical failure and lets the airspeed bleed down and the prop stops. Dooh! I forgot about the alternator - BUT - I've never trusted an alternator that was not connected to a battery, therefore I would be reluctant to have that as a fall back. What about moving the starter feed to the battery side of the master? -Jeff ________________________________________________________________________________
Date: Oct 27, 2013
Old Bob Just curious whether you've tried it and whether it was the 4, 6, or 8 cylinder jab? (You probably have tried it or talked to someone who has if you posted it.) There were lots of opinions that my geared setup would not windmill but it most certainly does. More opinions than facts as is often the case on the internet. For sure there are some known engines/reduction units that do not windmill. (break) I like the concept of minimal connections and components in the truly essential engine circuits so I like feeding them directly from battery busses. Engine stoppage occurs far more often than the need to kill every last electric circuit in a dire emergency. (I'm sure that a significant percentage of engine out landings/crashes occur with the battery master still on anyway). I favor feeding "keep it running" engine circuits directly from battery busses. Sure, route backups through the master if one wishes but not primary circuits. Then regardless of windmilling, I see little need to wire such that an engine can be cranked with the master off or with a failed battery contactor. That caters to multiple failures and raises other safety concerns IMO. Ken On 27/10/2013 5:31 AM, BobsV35B(at)aol.com wrote: > Good Morning All, > I have not followed all of this thread, but agree that not all engines > windmill like our friendly Continentals and Lycomings. I have about > twenty hours flying a Legend Cub powered by the Jabiru engine. It is a > nice smooth running engine, but if it runs out of fuel or the mags are > shut off, the prop stops! > Happy Skies, > Old Bob > In a message dated 10/27/2013 3:32:26 A.M. Central Daylight Time, > jluckey(at)pacbell.net writes: > > > I believe that some of the installations of the Rotax 912 (and > probably other power systems) do not windmill (but the 912 may not > be electrically-dependent ). > > However, I don't think you can categorically say that ALL engines > will windmill. In addition some flight conditions may cause a > windmilling prop to stop. A possible scenario: The pilot becomes > task saturated on the electrical failure and lets the airspeed bleed > down and the prop stops. > > Dooh! I forgot about the alternator - BUT - I've never trusted an > alternator that was not connected to a battery, therefore I would be > reluctant to have that as a fall back. > > What about moving the starter feed to the battery side of the master? > > -Jeff > > ________________________________________________________________________________
Date: Oct 27, 2013
Subject: Re: Battery contactor failure
=0A=0AMy comment is italics=0A=0A=0A-Jeff=0A=0A=0A_________________________ _______=0A From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> =0ATo: aeroelectric-list(at)matronics.com =0ASent: Saturday, October 26, 2013 9:32 PM=0ASubject: AeroElectric-List: Battery contactor failure=0A =0A=0A-- bob(at)aeroelectric.com>=0A=0AAt 12:00 AM 10/27/2013, you wrote:=0A=0A> I beli eve that some of the installations of the Rotax 912 (and probably other pow er systems) do not windmill (but the 912 may not be electrically-dependent ).=0A=0AOnly if the fuel is delivered by engine driven pump=0Aor gravity. T he ignition is electronic driven directly=0Afrom magnets on the starter rin g gear.=0A=0A> However, I don't think you can categorically say that ALL en gines will windmill.- In addition some flight conditions may cause a wind milling prop to stop.- A possible scenario: The pilot becomes task satura ted on the electrical failure and lets the airspeed bleed down and the prop stops.=0A=0AThat's s double failure again. Failure tolerant systems=0Awith a plan-b do not saturate pilots.=0A=0ADisagree - There is way too much cas e history of pilots becoming distracted, over seemingly trivial issues, to suggest that you can write-off this scenario.=0A=0A> Dooh! I forgot about t he alternator - BUT - I've never trusted an alternator that was not connect ed to a battery, therefore I would be reluctant to have that as a fall back .=0A=0A- Because you know them to be unreliable or simply=0A- don't kno w. Actually, Cessna and others who opted=0A- for the split rocker switch were probably in violation=0A- of legacy design goals.=0A=0AOnce upon a t ime waaay back in the late 70s I had seen a few alternators lose voltage re gulation when battery became disconnected.- This was in the marine enviro nment.- Regulators are most certainly better now but those experiences ha ve stuck with me.=0A=0A- Until that time, airplanes flew nicely on either =0A- battery, generator or both. When the alternator=0A- came along, th e airframe guys elected to put=0A- alternators on even tho they were not plug-n-play=0A- for the failure tolerance offered by generators.=0A=0A- The Bonanza and Barons continued to offer alternator-=0A- only operation s but if I recall correctly, the Liberal=0A- airplanes had split rockers. =0A=0A- PM alternators are easy to get on-line without a=0A- battery an d it may well be that belt-driven alternators=0A- on a Lycoming are too. They run very fast. I need to=0A- get some time on B&C's test bench and r un some experiments.=0A=0A> What about moving the starter feed to the batte ry side of the master?=0A=0A- If you're willing to have an always hot fee der to a=0A- starter contactor . . .=0A=0AAre there reasons to not do thi s?Is that any worse than having an always hot feed to the "main" bus?=0A- == ________________________________________________________________________________
Date: Oct 27, 2013
> If you're willing to have an always hot feeder to a > starter contactor . . . That doesn't sound very safe when you're on he ground. Keys are out, master e tc off, someone is by the prop and someone else accidentally actuates the st arter by pushing the starter button or whatever. Even if the engine doesn't s tart you can still do some damage. ________________________________________________________________________________
Date: Oct 27, 2013
Good Morning Ken You wrote: "Just curious whether you've tried it and whether it was the 4, 6, or 8 cylinder jab? (You probably have tried it or talked to someone who has if you posted it.)" I flew the airplane over twenty hours in less than a week flying off a lot of the required time for an experimental category airplane. It was at the factory in Texas, so I did have the factory folks to help with any difficulties encountered. The runways were long and the traffic was nil so I had no hesitation to do things that would cause the engine to quit. I never had to make a "forced" landing as the starter always worked, but I did shut off the fuel at least once just to check how well it would restart. Same for shutting off the ignition. It also quit at low speeds if the idle RPM was set on the low side. To get a nice short Cub style three point landing, the idle RPM had to be so low that the engine would quit and the prop would stop turning well before touchdown. I do not recall the exact airspeed at which the prop would stop, but it was not much below sixty mph. It has been over five years since I did that test flying. That was the only feature of the Jabiru install that I really did not care for. If it were up to me, I would have used the O-200 Continental or an O- 320 Lycoming. The high idle made for longer than necessary ground roll out and/or excessive use of the brakes. It is a 6 cylinder 3300 Jabiru with the BMW carburetor. Happy Skies, Old Bob ________________________________________________________________________________
Date: Oct 27, 2013
=0A=0A=0A=0A________________________________=0A From: Sacha <uuccio(at)gmail.c om>=0ATo: "aeroelectric-list(at)matronics.com" =0ASent: Sunday, October 27, 2013 6:24 AM=0ASubject: Re: AeroElectric-Li st: Re: EXP 2 Bus workaround=0A =0A=0A=0A-If you're willing to have an al ways hot feeder to a=0A>-starter contactor . . .=0A=0AThat doesn't sound very safe when you're on he ground. Keys are out, master etc off, someone i s by the prop and someone else accidentally actuates the starter by pushing the starter button or whatever. Even if the engine doesn't start you can s till do some damage. =0A=0AThat is not the case, with the master off you wi ll not be able to crank as the coil circuit for starter contactor will not 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 -=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Oct 27, 2013
>That doesn't sound very safe when you're on he ground. Keys are out, >master etc off, someone is by the prop and someone else accidentally >actuates the starter by pushing the starter button or whatever. Even >if the engine doesn't start you can still do some damage. There are TWO inputs to a starter contactor. FAT wire power to operate the motor and small wire power through the starter switch to energize the contactor coil. One COULD consider an always hot FAT wire that bypasses the battery contactor while shutting down the power source for the starter push-button. But this is contrary to legacy design goals for achieving max-dark on an electrical system when all switches are OFF. Bob . . . ________________________________________________________________________________
Date: Oct 27, 2013
Subject: Accident library addition
I was made aware of this incident involving a LA235 that appeared to have suffered electrical system difficulties. http://tinyurl.com/mwo3f4x The NTSB said 'everything was working but the battery was dead.' This engine seems to have run out of fuel because transfer pumps were deprived of power to bring fuel to a header tank. The documents are markedly devoid of a finding for root cause. The narrative paints and image of an owner/pilot who hasn't got a clue for the significance of "anomalies" in system operation. The airplane had been begging for help for perhaps two months before the accident. His notion of making the airplane flightworthy was to install a freshly charged battery . . . that failed minutes after takeoff. His header tank must have been nearly dry at takeoff which begs the question as to his use of a checklist for verification if header tank fuel and functionality of the transfer pumps were working and the altrrnator was charging the battery. As near as we can tell, nothing was broken. No parts had failed to do their intended task except that a working alternator failed to charge a battery. This accident has more to teach about the technical skills and operational philosophy of the owner/operator than about the design of an electrical system. Bob . . . ________________________________________________________________________________
Subject: Contactors
Date: Oct 27, 2013
The requirement for a main battery contactor comes from the FAA's requirement to have the main battery disconnected "by one hand" in the event of a forced landing. Cutting off the main source of electrical energy should reduce the chance of ignition one supposes. NASCAR and various racing groups have the same problem but they usually have decided that a contactor failure is to be avoided by the elimination of electrical coil-type contactors, instead choosing rugged mechanical switches like "Flaming River Battery Switches". So keep in mind: 1) A contactor won't fail if you don't have one. 2) A contactor by regulations only has to open, not close. Sort of like a parachute. 3) Really big switches can be used instead of small switches and contactors. My Grandfather's Chevy had a starter footswitch. Still seems like a good idea. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411531#411531 ________________________________________________________________________________
Date: Oct 27, 2013
I figured out the reason for D3 in the EXP2Bus (questioned in a previous post). When the master switch is open, D3 prevents current from flowing in series through the master contactor coil and into the EXP2Bus. I drew a new schematic (pdf attached) using the EXP2Bus and also a separate Engine Bus. I also have a dwg version if anyone is interested. The Engine bus is fed from two paths so that any one failure will not cut power to the engine. The EXP2Bus also has outputs that can supply engine loads. An endurance bus is not needed because the SkyView and GPS both have internal backup batteries. The COM radio is powered by either the EXP2Bus or by the ENG bus through dual diodes inside of the EXP2Bus (CLRNC DEL input). Comments and suggestions welcome. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411532#411532 Attachments: http://forums.matronics.com//files/exp2_and_eng_bus_548.pdf ________________________________________________________________________________
Date: Oct 27, 2013
Bob, What are your thoughts on having a separate switch for the alternator field versus using the second half of a double pole master switch? I know that your designs use a progressive transfer switch with the center position battery only with the alternator off. But I am thinking about the EXP2Bus (or any electrical system) that does not have the progressive transfer switch, just a common DPDT switch. Assuming the pilot has a plan B, for instance an E-Bus, she could shut off the one DPDT Master-Alt switch in the event of an alternator failure. Most likely the pilot will want the master off anyway to conserve the battery. Or is it better to have a separate Alt switch? Thanks, Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411535#411535 ________________________________________________________________________________
Date: Oct 27, 2013
>>> If you're willing to have an always hot feeder to a >>> starter contactor . . . >> >> That doesn't sound very safe when you're on he ground. Keys are out, mast er etc off, someone is by the prop and someone else accidentally actuates th e starter by pushing the starter button or whatever. Even if the engine does n't start you can still do some damage. >> >> That is not the case, with the master off you will not be able to crank a s the coil circuit for starter contactor will not be powered. See dwg. You're correct, sorry I spoke before i took a look at the actual circuit. Sacha Ps. What is the issue with wether the prop windmills or stops? Is it that t he engine is easier to restart if the prop is windmilling? ________________________________________________________________________________
Date: Oct 27, 2013
>>> That doesn't sound very safe when you're on he ground. Keys are out, master etc off, someone is by the prop and someone else accidentally actuates the starter by pushing the starter button or whatever. Even if the engine doesn't start you can still do some damage. >> >> There are TWO inputs to a starter contactor. >> FAT wire power to operate the motor and >> small wire power through the starter switch >> to energize the contactor coil. One COULD >> consider an always hot FAT wire that bypasses >> the battery contactor while shutting down >> the power source for the starter push-button. >> But this is contrary to legacy design goals >> for achieving max-dark on an electrical system >> when all switches are OFF. >> Got it, thanks! ________________________________________________________________________________
Date: Oct 27, 2013
At 11:53 AM 10/27/2013, you wrote: > >Bob, >What are your thoughts on having a separate switch for the >alternator field versus using the second half of a double pole master switch? Depends on how well the alternator performs without a battery. It would be nice to have it run independently of the battery. > I know that your designs use a progressive transfer switch with > the center position battery only with the alternator off. But I am > thinking about the EXP2Bus (or any electrical system) that does not > have the progressive transfer switch, just a common DPDT > switch. Assuming the pilot has a plan B, for instance an E-Bus, > she could shut off the one DPDT Master-Alt switch in the event of > an alternator failure. Most likely the pilot will want the master > off anyway to conserve the battery. The ideas behind the e-bus was to offer a means by which everything not needed during en route flight, i.e. cruising for an hour or more watching the ground go by. This includes the battery contactor which draws .8 to 1.0 amps by itself . . . as much as one or two more radios. > Or is it better to have a separate Alt switch? It's nice to turn battery on leaving alternator off for ground ops. A non-rotating alternator draws about 3A of field current and gets hot. When the system is fitted with crowbar ov protection, then there's a circuit breaker that can be pulled to disable the alternator for maintenance. Some of my earlier drawings were dpdt bat/alt switch + circuit breaker. But there was such a love affair going on over the split rocker switch that I decided to describe a replacement for the same functionality in a toggle switch. Whether or not a separate switch is advised is predicated on alternator performance sans battery. Bob . . . ________________________________________________________________________________
Date: Oct 27, 2013
If the prop is windmilling then the starter isn't needed for a restart. All you need is to provide fuel and spark, it already turning. Bob McC _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sacha Sent: Sunday, October 27, 2013 2:05 PM Subject: Re: AeroElectric-List: Re: EXP 2 Bus workaround If you're willing to have an always hot feeder to a starter contactor . . . That doesn't sound very safe when you're on he ground. Keys are out, master etc off, someone is by the prop and someone else accidentally actuates the starter by pushing the starter button or whatever. Even if the engine doesn't start you can still do some damage. That is not the case, with the master off you will not be able to crank as the coil circuit for starter contactor will not be powered. See dwg. You're correct, sorry I spoke before i took a look at the actual circuit. Sacha Ps. What is the issue with wether the prop windmills or stops? Is it that the engine is easier to restart if the prop is windmilling? ________________________________________________________________________________
Subject: Re: hypothetical question
Date: Oct 28, 2013
Rob, If you tried to fly from NY to Paris using a magnetic compass in 1927, you'd probably not make it. Lindbergh's primary navigation device was an "Earth Inductor Compass" see: http://en.wikipedia.org/wiki/Earth_inductor_compass I stand by what I said. A magnetic compass is a pretty weak tool for long-distance navigation. On aircraft, the pilot steers compass courses, but aerial navigation depends on making corrections to account for all sorts of disturbances from the straight line course. As you approach the magnetic poles, the magnetic compass becomes worthless, when you cross the equator, the compensators have to be flipped. Then there are the dozen compass errors they teach in ground school. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411576#411576 ________________________________________________________________________________
Subject: Re: Accident library addition
Date: Oct 28, 2013
Simplicity does have its virtues, especially when things start going to hell. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411581#411581 ________________________________________________________________________________
Date: Oct 28, 2013
Subject: Re: Contactors
Erics suggestion that a mechanical master switch be considered over a "solenoid" contactor seems to have merit. On small OBAM aircraft one is always looking for ways to introduce a weight saving synergy. I am reworking the panel on my LongEz with a Dynon Skyview and can see that my current consumption will reduce using modern avionics. This then opens up the possibility of removing the 40amp alternator from the aft of my Lycoming (worst place for weight on a pusher) and replacing it with a 20amp unit in place of one magneto, and with a (B&C SD20) 20amp unit, one scrutinises all consumers to reduce appetites where possible. While populating my electrical load schedule, I was taken aback to see that the master contactor takes a constant 2amps. That would make it the most hungry consumer of watts in my aircraft, 10% of my alternators output going to keep the master latched. Thus I'm struggling to see why I should not use a mechanical master along the lines of that suggested by Eric; ( http://www.flamingriver.com/index.php/products/c0015/s0001/FR1013) particularly as I'm at the "clean sheet" stage. And I've had an electrical master fail on a certified aircraft (PA30). Am I missing something here? Bill Allen LongEz160 N99BA On 27 October 2013 17:52, Eric M. Jones wrote: > emjones(at)charter.net> > > The requirement for a main battery contactor comes from the FAA's > requirement to have the main battery disconnected "by one hand" in the > event of a forced landing. Cutting off the main source of electrical energy > should reduce the chance of ignition one supposes. > > NASCAR and various racing groups have the same problem but they usually > have decided that a contactor failure is to be avoided by the elimination > of electrical coil-type contactors, instead choosing rugged mechanical > switches like "Flaming River Battery Switches". > > So keep in mind: > > 1) A contactor won't fail if you don't have one. > 2) A contactor by regulations only has to open, not close. Sort of like a > parachute. > 3) Really big switches can be used instead of small switches and > contactors. My Grandfather's Chevy had a starter footswitch. Still seems > like a good idea. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411531#411531 > > ________________________________________________________________________________
Date: Oct 28, 2013
Bill, Be aware that the main contactor is best replaced by a big switch in the same location. That is, a remote actuator (like a long actuator rod) is best. Flaming River sells these, but you can make one. Since flaps and ailerons and rudders, etc. use remote mechanical actuators, most builders can do something like this. Remember you only have to have the ability to turn OFF the battery. Harbor Freight sells the big switches too. Roll your own actuator. There comes a time in designing a big airplane when contactors are necessary, but small single engine homebuilts probably don't need them. Since FAA regulations are to turn OFF the battery in an emergency, one might add some contacts to turn ON the ELT, turn off the fuel, etc. when one emergency T-handle is pulled. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411630#411630 ________________________________________________________________________________
Date: Oct 16, 2013
Subject: Charging the Aux Battery
At 11:41 AM 10/1/2013, you wrote: > > >Bob > >Thank you for the dissertation about the theme I had proposed. >I confess that I still didn't read it thoroughly, so I will have to digest >it conveniently. > >Meanwhile, I can confirm that my question was not academic, I am building an >RV-10 and did consider the Dual battery, One main Alternator - one Aux >alternator system. > >So far, I am considering a variation of the Z-14 architecture, but still >didn't reach the "end of the line" in what regards the final schematic, so >would appreciate all suggestions. Okay, start with Z-14 and tell us what you would do differently and why that seems to be a good idea. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2013
This then opens up the possibility of removing the 40amp alternator from the aft of my Lycoming (worst place for weight on a pusher) and replacing it with a 20amp unit in place of one magneto, and with a (B&C SD20) 20amp unit, one scrutinises all consumers to reduce appetites where possible. The B&C 20A machine drives from a vacuum pump pad. I don't think you want to replace any magnetos with other than an electronic ignition. While populating my electrical load schedule, I was taken aback to see that the master contactor takes a constant 2amps. That would make it the most hungry consumer of watts in my aircraft, 10% of my alternators output going to keep the master latched. Actually, it's more like 1 amp cold and drops to about .6 amps warm for a Cole-Hersee contactor. See http://tinyurl.com/k6bwdqo http://tinyurl.com/mpcgp3t Thus I'm struggling to see why I should not use a mechanical master along the lines of that suggested by Eric; (http://www.flamingriver.com/index.php/products/c0015/s0001/FR1013) particularly as I'm at the "clean sheet" stage. And I've had an electrical master fail on a certified aircraft (PA30). That works too. The Piper Pacer and Tri-Pacers were originally fitted with manual battery switches and starter push-buttons. How did the contactor fail . . . and how did you become aware of the failiure? If your system is architectured for failure tolerance, a contactor failure is not an emergency; only a maintenance event. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2013
Hi Bob, Thanks for the reply. 1. Yes, well caught, the B&C SD20 fits on the vacpad not the mag location. My mis-type. - trying to colour in one point (the draw of the master relay) and not paying attention to the details. I'm using a Pmag-E and an LSEas ignition systems. 2. Your tests showing the real draw on the master solenoid are very revealing, presuming that the master solenoid I have from Aircraft Spruce ( http://www.aircraftspruce.com/catalog/elpages/masterrelay.php?clickkey=10293 ) is a Cole-Hersee - I'm unfamiliar with the term but gather from googling that they are to solenoids what Hoover is to vacuum cleaners. However, 0.8amps is still almost the equivalent of a Garmin 430 (0.2a stby), Funkwerk Com (0.1a stby),DynonXPDR-262 (0.15a stby) and AeroLED Navlights(0.4a). All are "brochure figures" unless I've misread them. 3. The failure I experienced on my PA30 was on the ground. I found a totally dead system with a good battery, and traced it quickly to the master relay not activating. A new unit fixed it, and upon stripping the old one, I found moisture penetration of the internals to be the cause. Cleaning it up got it working again, but not to the point that I wanted to risk the disruption it could cause if it failed again. Had it failed in flight I would not have lost engine power, but would have lost all ships power, unless there is an e-bus on a 1966 PA30 that I'm not aware of, which is possible. If you'd like me to mail it to you for dissection, I can do that. 4. What I've learnt from this (ie, point 2 above) is to actually measure the current used by each of the consumers one plans to use. If the acceptance of 2amps for the master relay (but actually 0.8amps) is read across in this way for all other units, it's easily possible to end up with an alternator, wires, switches, fuses etc all way oversize and overweight. regards, Bill Allen On 29 October 2013 11:18, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com**> > > > This then opens up the possibility of removing the 40amp alternator from > the aft of my Lycoming (worst place for weight on a pusher) and replacing > it with a 20amp unit in place of one magneto, and with a (B&C SD20) 20amp > unit, one scrutinises all consumers to reduce appetites where possible. > > The B&C 20A machine drives from a vacuum > pump pad. I don't think you want to replace > any magnetos with other than an electronic > ignition. > > > While populating my electrical load schedule, I was taken aback to see > that the master contactor takes a constant 2amps. That would make it the > most hungry consumer of watts in my aircraft, 10% of my alternators output > going to keep the master latched. > > Actually, it's more like 1 amp cold and drops to about > .6 amps warm for a Cole-Hersee contactor. See > > http://tinyurl.com/k6bwdqo > http://tinyurl.com/mpcgp3t > > > Thus I'm struggling to see why I should not use a mechanical master along > the lines of that suggested by Eric; (http://www.flamingriver.com/** > index.php/products/c0015/**s0001/FR1013<http://www.flamingriver.com/index.php/products/c0015/s0001/FR1013>) > particularly as I'm at the "clean sheet" stage. And I've had an electrical > master fail on a certified aircraft (PA30). > > That works too. The Piper Pacer and Tri-Pacers > were originally fitted with manual battery switches > and starter push-buttons. > > How did the contactor fail . . . and how did > you become aware of the failiure? If your > system is architectured for failure tolerance, > a contactor failure is not an emergency; only > a maintenance event. > > > Bob . . . > > ________________________________________________________________________________
Subject: King KT78 Manual
Date: Oct 29, 2013
Does anyone have a copy of the King KT78 manual and or pinouts? I tried a google search and came across a link to one at www.gobookee.org but they want a 'credit card verification' to download a 'free' document and I'm suspicious. J Alternatively, does anyone have any experience with gobookee? Johannesburg Jay ________________________________________________________________________________
Subject: Transponder Interference with Icom A-22 Comm Radio
Date: Oct 29, 2013
I just installed a Sandia Transponder with an Icom A-22 handheld radio hard wired into the electrical system. On the first flight, ATC had a difficult time understanding me and I heard "clicks" in then headset while receiving. Not knowing if it was RF interference from the transponder OR feedback from the aircraft 12 volt power system, I removed the hard wire power from the radio and used the battery pack... Everything worked great. I even placed the VHF receiver within a inch of the transponder antenna while it was being interrogated and it still worked fine. Seems I am having some strange pulses running through the 12V system while the transponder is ON because it is eliminated when I remove acft power from it and use the battery pack. QUESTION - Is there something I can do or install that will isolate electrically the Comm Radio from getting this feedback from the transponder OR is there something I can add to the Transponder Power feed? -------- Titan Tornado II with Jab 3300 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411680#411680 ________________________________________________________________________________
Date: Oct 29, 2013
Subject: Harbor Freight sells the big switches too
"Harbor Freight sells the big switches too. Roll your own actuator." The one I bought at HF was of poor quality and I would not use it on a motorhome. Skip Simpson ________________________________________________________________________________
Subject: Contactors
Date: Oct 29, 2013
What about using a Kilovac EV200 with a circuit saver ? Any experience with them ?? They pull in under high A.. then the circuit saver lowers the current to hold the relay closed... (but I am told the circuit saver is 'noisy' ... i.e. lots of EMC ...) Anyone have any comments ?? _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Allen Sent: 29 October 2013 13:28 Subject: Re: AeroElectric-List: Contactors Hi Bob, Thanks for the reply. 1. Yes, well caught, the B&C SD20 fits on the vacpad not the mag location. My mis-type. - trying to colour in one point (the draw of the master relay) and not paying attention to the details. I'm using a Pmag-E and an LSE as ignition systems. 2. Your tests showing the real draw on the master solenoid are very revealing, presuming that the master solenoid I have from Aircraft Spruce (http://www.aircraftspruce.com/catalog/elpages/masterrelay.php?clickkey=1029 3 <http://www.aircraftspruce.com/catalog/elpages/masterrelay.php?clickkey=1029 3> ) is a Cole-Hersee - I'm unfamiliar with the term but gather from googling that they are to solenoids what Hoover is to vacuum cleaners. However, 0.8amps is still almost the equivalent of a Garmin 430 (0.2a stby), Funkwerk Com (0.1a stby),DynonXPDR-262 (0.15a stby) and AeroLED Navlights (0.4a). All are "brochure figures" unless I've misread them. 3. The failure I experienced on my PA30 was on the ground. I found a totally dead system with a good battery, and traced it quickly to the master relay not activating. A new unit fixed it, and upon stripping the old one, I found moisture penetration of the internals to be the cause. Cleaning it up got it working again, but not to the point that I wanted to risk the disruption it could cause if it failed again. Had it failed in flight I would not have lost engine power, but would have lost all ships power, unless there is an e-bus on a 1966 PA30 that I'm not aware of, which is possible. If you'd like me to mail it to you for dissection, I can do that. 4. What I've learnt from this (ie, point 2 above) is to actually measure the current used by each of the consumers one plans to use. If the acceptance of 2amps for the master relay (but actually 0.8amps) is read across in this way for all other units, it's easily possible to end up with an alternator, wires, switches, fuses etc all way oversize and overweight. regards, Bill Allen On 29 October 2013 11:18, Robert L. Nuckolls, III > wrote: > This then opens up the possibility of removing the 40amp alternator from the aft of my Lycoming (worst place for weight on a pusher) and replacing it with a 20amp unit in place of one magneto, and with a (B&C SD20) 20amp unit, one scrutinises all consumers to reduce appetites where possible. The B&C 20A machine drives from a vacuum pump pad. I don't think you want to replace any magnetos with other than an electronic ignition. While populating my electrical load schedule, I was taken aback to see that the master contactor takes a constant 2amps. That would make it the most hungry consumer of watts in my aircraft, 10% of my alternators output going to keep the master latched. Actually, it's more like 1 amp cold and drops to about .6 amps warm for a Cole-Hersee contactor. See http://tinyurl.com/k6bwdqo http://tinyurl.com/mpcgp3t Thus I'm struggling to see why I should not use a mechanical master along the lines of that suggested by Eric; (http://www.flamingriver.com/index.php/products/c0015/s0001/FR1013 <http://www.flamingriver.com/index.php/products/c0015/s0001/FR1013> ) particularly as I'm at the "clean sheet" stage. And I've had an electrical master fail on a certified aircraft (PA30). That works too. The Piper Pacer and Tri-Pacers were originally fitted with manual battery switches and starter push-buttons. How did the contactor fail . . . and how did you become aware of the failiure? If your system is architectured for failure tolerance, a contactor failure is not an emergency; only a maintenance event. Bob . . . =================================== -List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List =================================== http://forums.matronics.com =================================== le, List Admin. ="_blank">http://www.matronics.com/contribution =================================== <http://www.matronics.com/Navigator?AeroElectric-List> <http://www.matronics.com/contribution> http://www.w3.org/TR/REC-html40">
What about using a Kilovac EV200 with a circuit saver ? Any experience with them ??  They pull in under high A.. then the circuit saver lowers the current to hold the relay closed… (but I am told the circuit saver is ‘noisy’ … i.e. lots of EMC …)
Hi Bob,
2. Your tests showing the real draw on the master solenoid are very revealing, presuming that the master solenoid I have from Aircraft Spruce (http://www.aircraftspruce.com/catalog/elpages/masterre lay.php?clickkey=10293 ) is a Cole-Hersee - I'm unfamiliar with the term but gather from googling that they are to solenoids what Hoover is to vacuum cleaners.
regards,
Bill Allen
On 29 October 2013 11:18, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
   ignition.
http://tinyurl.com/k6bwdqo>
http://tinyurl.com/mpcgp3t>
http://www.flamingriver.com/index.php/products/c0015/s 0001/FR1013) particularly as I'm at the "clean sheet" stage. And I've had an electrical master fail on a certified aircraft (PA30).
http://www
      contribution
Date: Oct 29, 2013
Jay, I have one for KT78A. If you want, send me your email address. Best, Jerry Folkerts From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jay Hyde Sent: Tuesday, October 29, 2013 10:55 AM Subject: AeroElectric-List: King KT78 Manual Does anyone have a copy of the King KT78 manual and or pinouts? I tried a google search and came across a link to one at www.gobookee.org but they want a 'credit card verification' to download a 'free' document and I'm suspicious. J Alternatively, does anyone have any experience with gobookee? Johannesburg Jay ________________________________________________________________________________
Date: Oct 29, 2013
Subject: Re: King KT78 Manual
At 10:55 AM 10/29/2013, you wrote: >Does anyone have a copy of the King KT78 manual and or pinouts? Check here http://tinyurl.com/kcwmt6f Bob . . . ________________________________________________________________________________
Date: Oct 29, 2013
At 08:28 AM 10/29/2013, you wrote: >Hi Bob, > >Thanks for the reply. > >1. Yes, well caught, the B&C SD20 fits on the vacpad not the mag >location. My mis-type. - trying to colour in one point (the draw of >the master relay) and not paying attention to the details. I'm >using a Pmag-E and an LSE as ignition systems. Okay, you've got a 15a current budget . . . 5A of rated output should be 'walled off' for battery recharging in flight . . . and remember, the SD-20 doesn't give you any useful output until you're airborne. >2. Your tests showing the real draw on the master solenoid are very >revealing, presuming that the master solenoid I have from Aircraft >Spruce >(<http://www.aircraftspruce.com/catalog/elpages/masterrelay.php?clickkey=10293>http://www.aircraftspruce.com/catalog/elpages/masterrelay.php?clickkey=10293 >) is a Cole-Hersee - I'm unfamiliar with the term but gather from >googling that they are to solenoids what Hoover is to vacuum cleaners. >However, 0.8amps is still almost the equivalent of a Garmin 430 >(0.2a stby), Funkwerk Com (0.1a stby),DynonXPDR-262 (0.15a stby) and >AeroLED Navlights (0.4a). All are "brochure figures" unless I've misread them. So do all the math. Get this form http://tinyurl.com/7jqypwj and do an inventory of every electrical load . . . including the battery contactor. Don't fuss with bus-decisions yet, just get a read on total loads under various flight conditions. > >3. The failure I experienced on my PA30 was on the ground. I found a >totally dead system with a good battery, and traced it quickly to >the master relay not activating. A new unit fixed it, and upon >stripping the old one, I found moisture penetration of the internals >to be the cause. Cleaning it up got it working again, but not to the >point that I wanted to risk the disruption it could cause if it failed again.to Surely your anticipated system can function with the battery contactor open . . . whether it opens from failure or the fact that you shut it off, getting to an airport of intended destination shouldn't be a foreboding task. >Had it failed in flight I would not have lost engine power, but >would have lost all ships power, unless there is an e-bus on a 1966 >PA30 that I'm not aware of, which is possible. No, they don't have that feature . . . but if it were my airplane . . . it would. Do you have a flight-bag back-up? http://tinyurl.com/lg3n4gh >If you'd like me to mail it to you for dissection, I can do that. Not useful at this stage. The major point is that it failed on the ground. I won't say that failures in fight never happen . . . but they are exceedingly rare. If one has failed in flight, I'd give pretty good odds that the pilot was 'warned' . . . probably conducted more than one flight where the contactor had to be 'jiggered' in some way before the panel lit up . . . and he doesn't even know what an e-bus is. I'd also give pretty good odds that the contactor you replaced had been in service for a considerable period of time. I'm supposed to get a networked computer at Cessna on Monday. I'd should be able to search the archives for history on part numbers used for both production and spares on the single engine line going back a very long way. >4. What I've learnt from this (ie, point 2 above) is to actually >measure the current used by each of the consumers one plans to use. That's never wrong. When you get all the numbers, give us a list of your findings. > If the acceptance of 2amps for the master relay (but actually > 0.8amps) is read across in this way for all other units, it's > easily possible to end up with an alternator, wires, switches, > fuses etc all way oversize and overweight. That's not typical. I've never seen a value greater than 1.0A assigned to battery contactors on single engine airplanes. Further, the numbers from installation manuals on items used in TC aircraft should be golden. Updating load analysis and weight and balance for any changes to an airplane is pretty much a given for which the manufacturer is obligated to support with good numbers. Add 'em all up and see if you've busted your 15A bubble. Running loads only, intermittent loads like flap motors, trim motors, transmitters, etc are not significant energy consumers. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2013
Subject: Contactors
At 04:44 PM 10/29/2013, you wrote: >What about using a Kilovac EV200 with a circuit >saver ? Any experience with them ?? They pull >in under high A.. then the circuit saver lowers >the current to hold the relay closed=85 (but I am >told the circuit saver is =91noisy=92 =85 i.e. lots of EMC =85) > >Anyone have any comments ?? A fine contactor with a price to match . . . and yes . . . pwm management of holding current is not noise free. Most users have not found the noise to be a problem. I think I've got an EV200 in the skunk-werks box of goodies somewhere . . . if I can put my hands on it, I'll see if I can get the EMC lab gurus to do a quick conducted survey on it. We'll have a contactor-cooler product available pretty soon. The 9024 4-function module will include that capability. I'll it checked for conducted emissions too. The goal would be to offer a low cost alternative to lowering operating current (and temperature rise) on the generic contactors. Reduced operating temp should improve on what has already been a good service life. But aside from weight and cost, the EV200 is a fine opportunity for increased service life assuming you find $value$ in the exchange. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2013
Subject: Trusting a chargers reputation, what an idiot!
Hi group I'm an idiot. I purchased an Odyssey PC545 a while back and listened to the distributors rhetoric, blah, blah blah I best buy one of his magical chargers custom suited for an odyssey battery. Wasn't very much so I bought one. My battery is aft located on my Europa Monowheel, so a bit of contortion needed to get to it. No problem. Very early on the strain relief for the insulation at the charger broke in half, so I was just measuring the charger output at the break (which is easily located forward). Today we were working on the flap control and were crawling around in the back of the aeroplane and decided we should check the voltage at the battery with the charger connected. The charger was indicating float (green) and at the forward break in the insulation at 13.54 volts. When we tested at the battery, it was only 12.75 volts? Closer inspection revealed really poor solder connection to the battery clamps. There is a plating on the clamps, and the solder never stuck real well. EZ fix, scratch, mild activated flux and solder. Just a note, best check charge voltage right at the battery, don't trust a green LED saying all is well. Ron Parigoris ________________________________________________________________________________
Date: Oct 30, 2013
Subject: Re: Trusting a chargers reputation, what an idiot!
Ron I am busy with a new build and have a similar problem...the battery voltage at the battery is 13.4 and the MGL Efis shows supply voltage as 12.9. I have checked all feeds and connectors, but cannot isolate the voltage drop.... Best... Bob Verwey On 30 October 2013 06:29, wrote: > Hi group > > I'm an idiot. I purchased an Odyssey PC545 a while back and listened to > the distributors rhetoric, blah, blah blah I best buy one of his magical > chargers custom suited for an odyssey battery. Wasn't very much so I bought > one. My battery is aft located on my Europa Monowheel, so a bit of > contortion needed to get to it. No problem. Very early on the strain relief > for the insulation at the charger broke in half, so I was just measuring > the charger output at the break (which is easily located forward). Today we > were working on the flap control and were crawling around in the back of > the aeroplane and decided we should check the voltage at the battery with > the charger connected. The charger was indicating float (green) and at the > forward break in the insulation at 13.54 volts. When we tested at the > battery, it was only 12.75 volts? Closer inspection revealed really poor > solder connection to the battery clamps. There is a plating on the clamps, > and the solder never stuck real well. EZ fix, scratch, mild activated flux > and solder. Just a note, best check charge voltage right at the battery, > don't trust a green LED saying all is well. > > Ron Parigoris > > * > > * > > ________________________________________________________________________________
Date: Oct 30, 2013
Thanks Bob- I received a copy from Stein; so helpful, thanks Stein! -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: 30 October 2013 01:56 AM Subject: Re: AeroElectric-List: King KT78 Manual --> At 10:55 AM 10/29/2013, you wrote: >Does anyone have a copy of the King KT78 manual and or pinouts? Check here http://tinyurl.com/kcwmt6f Bob . . . ________________________________________________________________________________
Date: Oct 30, 2013
Thanks- I was already sent a copy. As we have all mentioned, "ain't this list great!" J From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jerald Folkerts Sent: 30 October 2013 01:11 AM Subject: RE: AeroElectric-List: King KT78 Manual Jay, I have one for KT78A. If you want, send me your email address. Best, Jerry Folkerts From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jay Hyde Sent: Tuesday, October 29, 2013 10:55 AM Subject: AeroElectric-List: King KT78 Manual Does anyone have a copy of the King KT78 manual and or pinouts? I tried a google search and came across a link to one at www.gobookee.org but they want a 'credit card verification' to download a 'free' document and I'm suspicious. J Alternatively, does anyone have any experience with gobookee? Johannesburg Jay http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 30, 2013
At 01:38 AM 10/30/2013, you wrote: >Ron I am busy with a new build and have a similar problem...the >battery voltage at the battery is 13.4 and the MGL Efis shows supply >voltage as 12.9. I have checked all feeds and connectors, but cannot >isolate the voltage drop.... Are you sure the two instruments agree with each other? Measure some other common point of interest between the EFIS and your meter . . . see if they EVER agree. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2013
Hey there Bob-V, I agree with Bob-N :-) Even though I think that the MGL instrument is pretty good there may be a calibration issue; I would check both points with an independent meter and see what you get. Jay -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: 30 October 2013 01:23 PM Subject: Re: AeroElectric-List: Trusting a chargers reputation, what an idiot! --> At 01:38 AM 10/30/2013, you wrote: >Ron I am busy with a new build and have a similar problem...the battery >voltage at the battery is 13.4 and the MGL Efis shows supply voltage as >12.9. I have checked all feeds and connectors, but cannot isolate the >voltage drop.... Are you sure the two instruments agree with each other? Measure some other common point of interest between the EFIS and your meter . . . see if they EVER agree. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2013
> but they want a 'credit card verification' to download a 'free' document Do a search of "gobookee scam". After reading about the experiences of others, you will never give them your credit card number. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411750#411750 ________________________________________________________________________________
Date: Oct 30, 2013
> but they want a 'credit card verification' to download a 'free' document Do a search of "gobookee scam". After reading about the experiences of others, you will never give them your credit card number. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411751#411751 ________________________________________________________________________________
Subject: Re: Transponder Interference with Icom A-22 Comm Radio
Date: Oct 30, 2013
Maybe something like this ebay item # 131025623616 will help. I learned that sellers in China sometimes exaggerate the capabilities of their products. So divide the rated output of the DC to DC Converter by 2. Also note that most of these devices have a non-isolated output. I interpret that to mean that the negative input and negative output are connected together, if that is of any concern to you. I think that converters without a heat-sink can only handle up to one amp. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411752#411752 ________________________________________________________________________________
Date: Oct 30, 2013
Radio At 11:28 AM 10/29/2013, you wrote: I just installed a Sandia Transponder with an Icom A-22 handheld radio hard wired into the electrical system. On the first flight, ATC had a difficult time understanding me and I heard "clicks" in then headset while receiving. Not knowing if it was RF interference from the transponder OR feedback from the aircraft 12 volt power system, I removed the hard wire power from the radio and used the battery pack... Everything worked great. Radios of this variety are never qualified to DO160 recommendations for immunity to noise common to the vehicular dc bus. The exact nature of ATC's complaint would be good. The 'clicking' you describe is not particularly interesting. Further, the noise heard on your transmitted signal may be very different than anything you hear on receive. Is this test with engine running or not? Does it go away with the alternator off? Could you record a sample of the noise received by your listeners. Got access to a pocket recorder and second transceiver to run an experiment. Have somebody talk to you on the compromised radio so you can offer an interpretation of what you hear. I even placed the VHF receiver within a inch of the transponder antenna while it was being interrogated and it still worked fine. Since the complaint was against your transmitted signal, the experiment may not have any significance. Seems I am having some strange pulses running through the 12V system while the transponder is ON because it is eliminated when I remove acft power from it and use the battery pack. Check your transmitted signal with the radio hookd to the airplane with the transponder on/off, alternator on/of and any other electro-whizzies. QUESTION - Is there something I can do or install that will isolate electrically the Comm Radio from getting this feedback from the transponder OR is thernee something I can add to the Transponder Power feed? Not enough data for a specific suggestion. A simple noise filter may do the job but it would help to know exactly where the noise is coming from. Bob . . . ________________________________________________________________________________
Subject: Re: Alternator without a Battery
Date: Oct 30, 2013
Bob, It has taken days for me to respond because I couldn't get the website to respond to my enquiries and, consequently, I was unable to open your new drawing. Today I could! Thanks for your response. You state that you wouldn't shut down a battery unless there is smoke in the cockpit and, in which case you would shut down the alternator as well. If a battery is shorting and drawing more and more current from the alternator, why wouldn't you disconnect it or do you consider this too unlikely to design against? You ask why two batteries? I'm reconsidering. If the battery can be disconnected and the engine continues to run on only the alternator, then one battery probably meets my design goals. Thanks for the question. As you suggested, I've looked at your new drawing, but I don't think it meets all my design goals. A shorted battery can't be disconnected. I'll continue to study it w.r.t my other design goals. Thanks. Tom Sent from my iPad ________________________________________________________________________________
Subject: Contactors
Date: Oct 31, 2013
Hi Bob, It will be very interesting to hear what you find out about EMC if you get the chance to do it ... I will be very interesting to hear more about your contactor cooler circuit / module when you have it available ... will be ideal for a generic contactor All the best Jan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: 30 October 2013 00:30 Subject: RE: AeroElectric-List: Contactors At 04:44 PM 10/29/2013, you wrote: What about using a Kilovac EV200 with a circuit saver ? Any experience with them ?? They pull in under high A.. then the circuit saver lowers the current to hold the relay closed... (but I am told the circuit saver is 'noisy' ... i.e. lots of EMC ...) Anyone have any comments ?? A fine contactor with a price to match . . . and yes . . . pwm management of holding current is not noise free. Most users have not found the noise to be a problem. I think I've got an EV200 in the skunk-werks box of goodies somewhere . . . if I can put my hands on it, I'll see if I can get the EMC lab gurus to do a quick conducted survey on it. We'll have a contactor-cooler product available pretty soon. The 9024 4-function module will include that capability. I'll it checked for conducted emissions too. The goal would be to offer a low cost alternative to lowering operating current (and temperature rise) on the generic contactors. Reduced operating temp should improve on what has already been a good service life. But aside from weight and cost, the EV200 is a fine opportunity for increased service life assuming you find $value$ in the exchange. Bob . . . <http://www.matronics.com/Navigator?AeroElectric-List> <http://www.matronics.com/contribution> http://www.w3.org/TR/REC-html40">
Hi Bob,
It will be very interesting to hear what you find out about EMC if you get the chance to do it …
I will be very interesting to hear more about your contactor cooler circuit / module when you have it available … will be ideal for a generic contactor
All the best
Jan
  on it.
http://www
      contribution
Date: Oct 31, 2013
Hi Bob, You wrote; <> Noted. << So do all the math. Get this form http://tinyurl.com/7jqypwj and do an inventory of every electrical load . . . including the battery contactor.Don't fuss with bus-decisions yet, just get a read on total loads under various flight conditions.>> Got the form. Willdo. <> Presumably that's what the e-bus is there for in your designs, if not the architecture of Mr.Piper in 1966, when my PA30 was built. << Do you have a flight-bag back-up? http://tinyurl.com/lg3n4gh >> Yes I do. << I'd also give pretty good odds that the contactor you replaced had been in service for a considerable period of time >> I have no reason to doubt it was new with the aircraft, in 1966. What I've learnt from this is to actually measure the current used by each of the consumers one plans to use. <> Will do. Thanks. Bill Allen ** ** On 30 October 2013 02:22, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 08:28 AM 10/29/2013, you wrote: > > Hi Bob, > > Thanks for the reply. > > 1. Yes, well caught, the B&C SD20 fits on the vacpad not the mag location. > My mis-type. - trying to colour in one point (the draw of the master relay) > and not paying attention to the details. I'm using a Pmag-E and an LSE > as ignition systems. > > > Okay, you've got a 15a current budget . . . 5A of > rated output should be 'walled off' for battery > recharging in flight . . . and remember, the SD-20 > doesn't give you any useful output until you're airborne. > > 2. Your tests showing the real draw on the master solenoid are very > revealing, presuming that the master solenoid I have from Aircraft Spruce (http://www.aircraftspruce.com/catalog/elpages/masterrelay.php?clickkey=10293) is a Cole-Hersee - I'm unfamiliar with the term but gather from googling > that they are to solenoids what Hoover is to vacuum cleaners. > > However, 0.8amps is still almost the equivalent of a Garmin 430 (0.2a > stby), Funkwerk Com (0.1a stby),DynonXPDR-262 (0.15a stby) and AeroLED > Navlights (0.4a). All are "brochure figures" unless I've misread them. > > > So do all the math. Get this form > > http://tinyurl.com/7jqypwj > > and do an inventory of every electrical > load . . . including the battery contactor. > Don't fuss with bus-decisions yet, just > get a read on total loads under various > flight conditions. > > > 3. The failure I experienced on my PA30 was on the ground. I found a > totally dead system with a good battery, and traced it quickly to the > master relay not activating. A new unit fixed it, and upon stripping the > old one, I found moisture penetration of the internals to be the cause. > Cleaning it up got it working again, but not to the point that I wanted to > risk the disruption it could cause if it failed again.to > > > Surely your anticipated system can function > with the battery contactor open . . . whether > it opens from failure or the fact that you > shut it off, getting to an airport of intended > destination shouldn't be a foreboding task. > > > Had it failed in flight I would not have lost engine power, but would have > lost all ships power, unless there is an e-bus on a 1966 PA30 that I'm not > aware of, which is possible. > > > No, they don't have that feature . . . but if > it were my airplane . . . it would. > > Do you have a flight-bag back-up? > > http://tinyurl.com/lg3n4gh > > > If you'd like me to mail it to you for dissection, I can do that. > > > Not useful at this stage. The major point is that > it failed on the ground. I won't say that failures > in fight never happen . . . but they are exceedingly > rare. If one has failed in flight, I'd give pretty > good odds that the pilot was 'warned' . . . probably > conducted more than one flight where the contactor > had to be 'jiggered' in some way before the panel lit > up . . . and he doesn't even know what an e-bus is. > > I'd also give pretty good odds that the contactor > you replaced had been in service for a considerable > period of time. > > I'm supposed to get a networked computer at Cessna > on Monday. I'd should be able to search the archives > for history on part numbers used for both production > and spares on the single engine line going back a > very long way. > > > 4. What I've learnt from this (ie, point 2 above) is to actually measure > the current used by each of the consumers one plans to use. > > > That's never wrong. When you get all the numbers, give > us a list of your findings. > > > If the acceptance of 2amps for the master relay (but actually 0.8amps) is > read across in this way for all other units, it's easily possible to end up > with an alternator, wires, switches, fuses etc all way oversize and > overweight. > > > That's not typical. I've never seen a value greater > than 1.0A assigned to battery contactors on single > engine airplanes. Further, the numbers from installation > manuals on items used in TC aircraft should be golden. > Updating load analysis and weight and balance for > any changes to an airplane is pretty much a given for > which the manufacturer is obligated to support with > good numbers. > > Add 'em all up and see if you've busted your 15A > bubble. Running loads only, intermittent loads like > flap motors, trim motors, transmitters, etc are > not significant energy consumers. > > ** > > ** Bob . . . > > * > > * > > ________________________________________________________________________________
Date: Oct 31, 2013
Seems like the relay (contactor) that draws 0.8-2A (depending on how it's measured) is one that is sized to be capable of carrying starter currents (though not necessarily capable of switching them reliably). An architecture that uses such a contactor for all devices is probably fine when you have 40A+ to play with. But, in an application where you're on a tight energy budget, maybe it would make sense to have parallel contactors/relays. A smaller relay might be able to handle everything but starting current, and only consume 100-200mA to do it. The heavy one would only be energized when starting the engine. It may break the architecture goal of running the B-lead current through the heavy starter wire, but that may still be a good deal. Regards, Matt- On Thu, Oct 31, 2013 at 3:26 PM, Bill Allen wrote: > Hi Bob, > > You wrote; > > < rated output should be 'walled off' for battery > recharging in flight . . . and remember, the SD-20 > doesn't give you any useful output until you're airborne.>> > > Noted. > > << So do all the math. Get this form http://tinyurl.com/7jqypwj and do > an inventory of every electrical load . . . including the battery > contactor.Don't fuss with bus-decisions yet, just get a read on total > loads under various flight conditions.>> > > Got the form. Willdo. > > < it opens from failure or the fact that you shut it off, getting to an > airport of intended destination shouldn't be a foreboding task.>> > > Presumably that's what the e-bus is there for in your designs, if not the > architecture of Mr.Piper in 1966, when my PA30 was built. > > > << Do you have a flight-bag back-up? http://tinyurl.com/lg3n4gh >> Yes > I do. > > > << I'd also give pretty good odds that the contactor you replaced had > been in service for a considerable period of time >> > > I have no reason to doubt it was new with the aircraft, in 1966. > > What I've learnt from this is to actually measure the current used by > each of the consumers one plans to use. > > < us a list of your findings. Add 'em all up and see if you've busted > your 15A > bubble. Running loads only, intermittent loads like > flap motors, trim motors, transmitters, etc are > not significant energy consumers.>> > > > Will do. > > Thanks. > > Bill Allen > > > ** > > ** > > > On 30 October 2013 02:22, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 08:28 AM 10/29/2013, you wrote: >> >> Hi Bob, >> >> Thanks for the reply. >> >> 1. Yes, well caught, the B&C SD20 fits on the vacpad not the mag >> location. My mis-type. - trying to colour in one point (the draw of the >> master relay) and not paying attention to the details. I'm using a >> Pmag-E and an LSE as ignition systems. >> >> >> Okay, you've got a 15a current budget . . . 5A of >> rated output should be 'walled off' for battery >> recharging in flight . . . and remember, the SD-20 >> doesn't give you any useful output until you're airborne. >> >> 2. Your tests showing the real draw on the master solenoid are very >> revealing, presuming that the master solenoid I have from Aircraft Spruce (http://www.aircraftspruce.com/catalog/elpages/masterrelay.php?clickkey=10293) is a Cole-Hersee - I'm unfamiliar with the term but gather from googling >> that they are to solenoids what Hoover is to vacuum cleaners. >> >> However, 0.8amps is still almost the equivalent of a Garmin 430 (0.2a >> stby), Funkwerk Com (0.1a stby),DynonXPDR-262 (0.15a stby) and AeroLED >> Navlights (0.4a). All are "brochure figures" unless I've misread them. >> >> >> So do all the math. Get this form >> >> http://tinyurl.com/7jqypwj >> >> and do an inventory of every electrical >> load . . . including the battery contactor. >> Don't fuss with bus-decisions yet, just >> get a read on total loads under various >> flight conditions. >> >> >> >> >> 3. The failure I experienced on my PA30 was on the ground. I found a >> totally dead system with a good battery, and traced it quickly to the >> master relay not activating. A new unit fixed it, and upon stripping the >> old one, I found moisture penetration of the internals to be the cause. >> Cleaning it up got it working again, but not to the point that I wanted to >> risk the disruption it could cause if it failed again.to >> >> >> Surely your anticipated system can function >> with the battery contactor open . . . whether >> it opens from failure or the fact that you >> shut it off, getting to an airport of intended >> destination shouldn't be a foreboding task. >> >> >> Had it failed in flight I would not have lost engine power, but would >> have lost all ships power, unless there is an e-bus on a 1966 PA30 that I'm >> not aware of, which is possible. >> >> >> No, they don't have that feature . . . but if >> it were my airplane . . . it would. >> >> Do you have a flight-bag back-up? >> >> http://tinyurl.com/lg3n4gh >> >> >> >> >> If you'd like me to mail it to you for dissection, I can do that. >> >> >> Not useful at this stage. The major point is that >> it failed on the ground. I won't say that failures >> in fight never happen . . . but they are exceedingly >> rare. If one has failed in flight, I'd give pretty >> good odds that the pilot was 'warned' . . . probably >> conducted more than one flight where the contactor >> had to be 'jiggered' in some way before the panel lit >> up . . . and he doesn't even know what an e-bus is. >> >> I'd also give pretty good odds that the contactor >> you replaced had been in service for a considerable >> period of time. >> >> I'm supposed to get a networked computer at Cessna >> on Monday. I'd should be able to search the archives >> for history on part numbers used for both production >> and spares on the single engine line going back a >> very long way. >> >> >> >> 4. What I've learnt from this (ie, point 2 above) is to actually measure >> the current used by each of the consumers one plans to use. >> >> >> That's never wrong. When you get all the numbers, give >> us a list of your findings. >> >> >> >> If the acceptance of 2amps for the master relay (but actually 0.8amps) >> is read across in this way for all other units, it's easily possible to end >> up with an alternator, wires, switches, fuses etc all way oversize and >> overweight. >> >> >> That's not typical. I've never seen a value greater >> than 1.0A assigned to battery contactors on single >> engine airplanes. Further, the numbers from installation >> manuals on items used in TC aircraft should be golden. >> Updating load analysis and weight and balance for >> any changes to an airplane is pretty much a given for >> which the manufacturer is obligated to support with >> good numbers. >> >> Add 'em all up and see if you've busted your 15A >> bubble. Running loads only, intermittent loads like >> flap motors, trim motors, transmitters, etc are >> not significant energy consumers. >> >> ** >> >> ** Bob . . . >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > ________________________________________________________________________________
From: "Roger & Jean" <mrspudandcompany(at)verizon.net>
Subject: Aviation intercom
Date: Oct 31, 2013
Does anyone have the schematic or Manual for the WGA Model AIR-1177 Aviation Intercom System? I am trying to figure out the input and output jacks on the box. I intend to mount it in a panel along with an isolation amp. Roger ________________________________________________________________________________
Date: Nov 01, 2013
I use automotive "cube" relays (one for the master relay, one for alternator) rated at 70A. They are light and consume less than 300mA each. Is there a reason not to use them? The only potential drawback I'm aware of is that they can break the contact if subject to violent shocks. But loosing panel power for a few milliseconds doesn't seem such a big issue (the autopilot does reset but then in such violent turbulence you might be hand flying the thing in any case, and the GNS430 doesn't even notice any absence of power that lasts that little). Are there other risks I am not considering here? This is a VFR only machine and I'm a low time PPL so not the most experienced in these matters. Sacha ________________________________________________________________________________
Date: Nov 01, 2013
Sacha, I have used one of these Bosch 70amp relays for the master in my experimental Bonanza for the past 8 years - rock solid! I still use the caveman relay for the starter. Bob Verwey A35 ZU-DLW On 1 November 2013 07:10, Sacha wrote: > > I use automotive "cube" relays (one for the master relay, one for > alternator) rated at 70A. They are light and consume less than 300mA each. > Is there a reason not to use them? The only potential drawback I'm aware > of is that they can break the contact if subject to violent shocks. But > loosing panel power for a few milliseconds doesn't seem such a big issue > (the autopilot does reset but then in such violent turbulence you might be > hand flying the thing in any case, and the GNS430 doesn't even notice any > absence of power that lasts that little). > > Are there other risks I am not considering here? This is a VFR only > machine and I'm a low time PPL so not the most experienced in these matters. > > Sacha > > ________________________________________________________________________________
Date: Nov 01, 2013
Subject: PLEASE READ - Matronics Email List Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 01, 2013
At 09:21 PM 10/30/2013, you wrote: Bob, It has taken days for me to respond because I couldn't get the website to respond to my enquiries and, consequently, I was unable to open your new drawing. Today I could! Thanks for your response. No problem. I started at Cessna last Monday and the IT Spirits have yet to honor me with a CAT5 portal to the outside world . . . So I've been 'disconnected' to some degree as well . . . You state that you wouldn't shut down a battery unless there is smoke in the cockpit and, in which case you would shut down the alternator as well. If a battery is shorting and drawing more and more current from the alternator, why wouldn't you disconnect it or do you consider this too unlikely to design against? First, how does such a fault become known to you? You would need a battery-specific ammeter combined with a bus voltage indicator combined with the skills to monitor and interpret those readings for signs of failure. You ask why two batteries? I'm reconsidering. If the battery can be disconnected and the engine continues to run on only the alternator, then one battery probably meets my design goals. Thanks for the question. A design goal for discussions on this List is to identify drivers of risk based on useful study and exploitation of the physics. As you suggested, I've looked at your new drawing, but I don't think it meets all my design goals. A shorted battery can't be disconnected. I'll continue to study it w.r.t my other design goals. Thanks. Have you identified any instance where a 'shorted battery' took a system down? A battery is like a house plant. Given attention tailored to its needs, it will thrive and perform with great predictability . . . and reliability. Instances of battery failure are generally driven by failure to track the battery's condition and to service or replace it when performance falls below limits. I've not heard the phrase "shorted battery" uttered or written over the course of my career where the battery was not first subjected to abuses of poor system architecture and/or poorly implemented operation and maintenance. We're encouraged to change oil, plugs, add magic potions, install engine analyzers, and read voraciously from every author that claims to offer words of wisdom for getting the most from an engine. Now the battery is becoming an integral component of the system that spins the prop. I suggest that it be treated with no less curiosity and respect for capabilities and limits than your engine. I will suggest that design goals for your system include crafting and implementation of an architecture and maintenance that recognizes the role of the battery and optimizes conditions for it to perform. Bob . . . ________________________________________________________________________________
Date: Nov 01, 2013
Subject: Re: Aviation intercom
At 07:30 PM 10/31/2013, you wrote: >Does anyone have the schematic or Manual for the WGA Model AIR-1177 >Aviation Intercom System? I am trying to figure out the input and >output jacks on the box. I intend to mount it in a panel along with >an isolation amp. > >Roger I've not been able to find this product on the 'net. Where did you find this critter? Bob . . . ________________________________________________________________________________
Date: Nov 01, 2013
Subject: Re: A&P Student Battery/Starter Contactor Question
At 07:44 PM 10/31/2013, you wrote: Dear Bob, I just finished a very nice conversation with Bill Bainbridge at B and C Specialty Products, following through with a question to his company that I had sent through his website. I learned a great deal from Bill, though he's referred me to you for what was my initial question. Here was the original question: Hi Folks, I'm an A&P student at Miramar College in San Diego. I'm researching battery contactors and starter contactors, and haven't been able to figure out why battery contactors are negatively-controlled, and starter contactors are positively-controlled. Why can't both of them, (with slightly different wiring) both be, say, positively controlled? Is there some historical reason or some technical reason? I would so appreciate your expertise, as I heard you have a lot of expertise (from Lyle at Gibbs Repair Station here in San Diego). Thanks so much for your time. Regards. Bob, I've been reading through your FAQ's on contactors on your website--I'm learning much more than we learn in our A & P textbooks! However, I haven't quite been able to piece together the information for my answer. I think if I'm out in the bush wiring a plane together and I have two battery contactors and no starter contactor (as my instructor says... A & P Mechanics are the smartest people in the world, and they'll figure out a way to do something...:-)...) that's when I wonder why they are electrically wired differently. Hi Lisa, I don't know that there was any great debate for the realization of design goals beyond simplicity and convenience. Doing a pull-down circuit on a battery contactor is simpler. One could bring a wire off the hot side of a contactor into the cockpit mounted battery switch and back out to a pull-up terminal of a contactor coil . . . twice the wire and you need to fuse the hot end of the supply wire. I've seen starter contactors wired as a "pull to ground" control system, just no on airplanes. The legacy off-l-r-both-start key-switch could be wired to utilize a starter contactor with either pull-down or pull-up control. Power to control the starter contactor is already available from a bus in the cockpit so you don't have twice the wire . . . but you DO need circuit protection off the bus. It might have some roots in a system safety decision. A starter pull-down control line on a starter contactor is more likely to become faulted to ground and initiate unintended starter operation. A pull-up control line is less likely to get faulted to a source of power. The short answer to your question does not offer insights into any great thinking on the part of designers who adopted these conventions 100 years ago. Designers in those days were probably not into reliability studies of probability for hazardous failure. Bob . . . ________________________________________________________________________________
Date: Nov 01, 2013
Bob (and Roger)... I found the intercom on the maker's website, ( www.warrengregoire.com/aviation-intercoms.htm ) but no manuals or schematics there. However, there is contact information: * Warren Gregoire and Associates LLC* FOR PILOTS AND AIRCRAFT OWNERS 1933 Davis Street, Suite 276, San Leandro, CA 94577, USA HOURS* _ _TELEPHONES* */*TOLL-FREE*/ *1-800-634-0094* - USA and Canada 510-633-9353 - All Other Countries 510-633-9355 - FAX INTERNET* *warrengregoire(at)hotmail.com - Questions? warrengregoire(at)hotmail.com - Sales Department Harley Dixon ----------------------------------------------------------------- On 11/1/2013 8:13 AM, Robert L. Nuckolls, III wrote: > At 07:30 PM 10/31/2013, you wrote: >> Does anyone have the schematic or Manual for the WGA Model >> AIR-1177 Aviation Intercom System? I am trying to figure out >> the input and output jacks on the box. I intend to mount it >> in a panel along with an isolation amp. >> >> Roger > > I've not been able to find this product on the 'net. > Where did you find this critter? > > > Bob . . . > > * > * ________________________________________________________________________________
Date: Nov 01, 2013
Subject: Re: Contactors
At 12:10 AM 11/1/2013, you wrote: > >I use automotive "cube" relays (one for the master relay, one for >alternator) rated at 70A. They are light and consume less than 300mA >each. Is there a reason not to use them? The only potential >drawback I'm aware of is that they can break the contact if subject >to violent shocks. But loosing panel power for a few milliseconds >doesn't seem such a big issue (the autopilot does reset but then in >such violent turbulence you might be hand flying the thing in any >case, and the GNS430 doesn't even notice any absence of power that >lasts that little). > >Are there other risks I am not considering here? This is a VFR only >machine and I'm a low time PPL so not the most experienced in these matters. The legacy battery contactor is tasked with carrying normal operating loads usually in the tens of amps but predicated on getting an engine started . . . loads of perhaps 200A. Hence the selection of contactors that seem unnecessarily oversized to the task. But the one device can do it all. Some of the designs we're considering DO add smaller relays which function as a mini-contactor to handle loads other than starting and/or battery recharging. Bob . . . ________________________________________________________________________________
Date: Nov 01, 2013
At 12:21 AM 11/1/2013, you wrote: >Sacha, >I have used one of these Bosch 70amp relays for the master in my >experimental Bonanza for the past 8 years - rock solid! I still use >the caveman relay for the starter. > >Bob Verwey >A35 ZU-DLW But you don't crank the engine through it do you? Bob . . . ________________________________________________________________________________
From: "R. curtis" <mrspudandcompany(at)verizon.net>
Date: Nov 01, 2013
Does anyone have the schematic or Manual for the WGA Model AIR-1177 Aviatio n Intercom System=3F I am trying to figure out the input and output jacks on the box. I intend to mount it in a panel along with an isolation amp. I've not been able to find this product on the 'net. Where did you find this critter=3F A Google search brings it right up: http://www.warrengregoire.com/aviation- intercoms.htm Roger -- Do you have a slow PC=3F Try a Free scan http://www.spamfighter.com/SLOW-PCfi ghter=3Fcid=sigen ________________________________________________________________________________
Date: Nov 01, 2013
Subject: Contactors
From my newly acquired perch within the halls of Cessna Engineering I've discovered that the battery and starter contactors used on the single engine fleet have pretty much always been in the same style and ratings as the Cole-Hersee, RBM, Stancore, White-Rogers devices we've been discussing here on the List. Before the Great Shut-Down, Cessna purchased individual contactors for installation on the line. After the Great Resurrection, the contactors came to Cessna as part of a power distribution box mounting up to 4 such contactors. Battery, starter, alternator, ground- power. Of course, they're all 24 volt devices. During my earlier tenure at Cessna (64-69) the starter contactors were a low-duty cycle version of the battery contactor. They left something to be desired as SWITCHING devices for starter currents. I suspect that the modern starter contactors have exploited discoveries common to contemporary automotive starter contactors for small area, very high pressure contacts. http://tinyurl.com/96wy5mq Yes, there have been some serviceability issues managed by some modifications to the contact materials, springs, etc. etc. But the general configuration of the modern contactor has changed little since 1948. But in particular, there's no reason to believe that the modern encarnation of the 70 series device is any less suited to task as a battery contactor than it has been for many years. I dug up a 1960 copy of an Allied Electronics catalog hoping to discover the price of these devices back then. They don't appear in that catalog. Bob . . . ________________________________________________________________________________
Subject: Watts on resistors
Date: Nov 01, 2013
Bob and all The VP-X Pro installation manual recomends, in order to have Volt indication from the Aux Batt, to connect the + terminal to a certain pin in the box, trough a 1Kohm - 1W resistor. Problem is that I can only find 1Kohm - 2W resistor. So, to learn something else today, can someone please explain if there is any problem if I use the 2W instead of 1W resistor. (Please don't answer indicating a source for 1W resistors...) Regards Carlos ________________________________________________________________________________
Subject: Re: Watts on resistors
Date: Nov 01, 2013
> Problem is that I can only find 1Kohm - 2W resistor. So, to learn > something else today, can someone please explain if there is any problem > if I use the 2W instead of 1W resistor. The 2 watt resistor will work exactly the same in the circuit as a 1 watt. The only difference is that the 2 watt is somewhat larger with more surface area and can dissipate more heat without burning up. Roger -- Do you have a slow PC? Try a Free scan http://www.spamfighter.com/SLOW-PCfighter?cid=sigen ________________________________________________________________________________
Date: Nov 01, 2013
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
It should be no problem, Carlos, as long as you have enough room and the circuit isn't frequency sensitive. Wattage is the resistor's ability to dissipate heat, and the resistor is bigger as the wattage goes up. Henador Titzoff -------------------------------------------- On Fri, 11/1/13, Carlos Trigo wrote: Subject: AeroElectric-List: Watts on resistors To: "aeroelectric-list(at)matronics.com" Date: Friday, November 1, 2013, 7:21 AM --> AeroElectric-List message posted by: Carlos Trigo Bob and all The VP-X Pro installation manual recomends, in order to have Volt indication from the Aux Batt, to connect the + terminal to a certain pin in the box, trough a 1Kohm - 1W resistor. Problem is that I can only find 1Kohm - 2W resistor. So, to learn something else today, can someone please explain if there is any problem if I use the 2W instead of 1W resistor. (Please don't answer indicating a source for 1W resistors...) Regards Carlos Lists This Month -- Some AWESOME FREE Gifts!) Raiser. Click on more about Gifts provided www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com www.mrrace.com -Matt Dralle, List Admin. AeroElectric-List Email Forum - - MATRONICS WEB FORUMS - ________________________________________________________________________________
Date: Nov 01, 2013
At 09:21 AM 11/1/2013, you wrote: > >Bob and all > >The VP-X Pro installation manual recomends, in order to have Volt >indication from the Aux Batt, to connect the + terminal to a certain >pin in the box, trough a 1Kohm - 1W resistor. >Problem is that I can only find 1Kohm - 2W resistor. So, to learn >something else today, can someone please explain if there is any >problem if I use the 2W instead of 1W resistor. >(Please don't answer indicating a source for 1W resistors...) That's an easy one. The resistor is a substitute for a fuse. Further, it's called out as 1-watt for mechanical convenience and robustness. Examples: Some years back I suggested that the most valuable and often least accessible data point for diagnosing an alternator problem is to watch FIELD VOLTAGE behavior while putting an alternator through its paces. I published this little feature in Z-23 suggesting a permanently attached wire PROTECTED by a resistor leading from the alternator field to some handy point in the cockpit. Emacs! A fuse would be okay too. A 1/4 watt would work but 1/2 watt was mechanically more robust, 1w would have been better yet. So as long as you don't mind a larger 'lump' in your battery sense lead, a 2W resistor is okay as well. http://tinyurl.com/kyc6tq6 I think it was here on the List that I once suggested a tubular, 10-watt wire wound resistor with flag terminals as a suitable enclosure for a reed switch current sensor. Emacs! The 'jeep' was to put lead wires on the reed switch then epoxy into place down the center of the tubular resistor. Then wind an excitation coil around the center of the resistor over the reed. Calibrate closure current for the reed by adjusting coil turns. In this case, the actual value of the resistor wasn't critical . . . just needed to be high enough not to adversely affect current through the the coil. The resistor became a robust 'housing' for the current sense relay offering a convenient terminals to tie off ends of the coil. These are but two examples of many where the designer's 'sizing' of a component may not have obvious foundation in the original design goals for the part. Bob . . . ________________________________________________________________________________
Date: Nov 01, 2013
> The VP-X Pro installation manual recomends, in order to have > Volt indication from the Aux Batt, to connect the + terminal > to a certain pin in the box, trough a 1Kohm - 1W resistor. Hmmm . . . I think Marc harvested that concept for sense wire protection off of Z-23. Bob . . . ________________________________________________________________________________
Date: Nov 01, 2013
Hi Carlos, My view is 2W will be fine - it means that the resistor will cope with a higher voltage (45v) & so dissipate more energy. A 1W resistor will cope with 32v (theoretically). Peter On 01/11/2013 14:21, Carlos Trigo wrote: > > Bob and all > > The VP-X Pro installation manual recomends, in order to have Volt indication from the Aux Batt, to connect the + terminal to a certain pin in the box, trough a 1Kohm - 1W resistor. > Problem is that I can only find 1Kohm - 2W resistor. So, to learn something else today, can someone please explain if there is any problem if I use the 2W instead of 1W resistor. > (Please don't answer indicating a source for 1W resistors...) > > Regards > Carlos > > ________________________________________________________________________________
Date: Nov 01, 2013
So it sounds like they are using a resistor to protect the sensor wire from over current/unintentional ground instead of a fuse, is that the purpose here? Tim > On Nov 1, 2013, at 8:15 AM, "R. curtis" wrote: > > >> Problem is that I can only find 1Kohm - 2W resistor. So, to learn something else today, can someone please explain if there is any problem if I use the 2W instead of 1W resistor. > > The 2 watt resistor will work exactly the same in the circuit as a 1 watt. > The only difference is that the 2 watt is somewhat larger with more surface > area and can dissipate more heat without burning up. > > Roger > > -- > > Do you have a slow PC? Try a Free scan http://www.spamfighter.com/SLOW-PCfighter?cid=sigen > > > > > > ________________________________________________________________________________
Date: Nov 01, 2013
At 10:48 AM 11/1/2013, you wrote: > >So it sounds like they are using a resistor to protect the sensor >wire from over current/unintentional ground instead of a fuse, is >that the purpose here? >Tim Exactly. The input impedance to the instrumentation system is either sufficiently large that added 1K of resistance is insignificant . . . or is a calculated part of the input voltage divider. Bob . . . ________________________________________________________________________________
Date: Nov 01, 2013
>>> Sacha, >>> I have used one of these Bosch 70amp relays for the master in my experimental Bonanza for the past 8 years - rock solid! I still use the caveman relay for the starter. >>> >>> Bob Verwey >>> A35 ZU-DLW >> Thanks Bob V for the validation. >> But you don't crank the engine through it do you? No, the starter contactor is not the automotive type. ________________________________________________________________________________
Date: Nov 01, 2013
On Nov 1, 2013, at 13:37, "Robert L. Nuckolls, III" wrote: > > At 12:10 AM 11/1/2013, you wrote: >> >> I use automotive "cube" relays (one for the master relay, one for alternator) rated at 70A. They are light and consume less than 300mA each. Is there a reason not to use them? The only potential drawback I'm aware of is that they can break the contact if subject to violent shocks. But loosing panel power for a few milliseconds doesn't seem such a big issue (the autopilot does reset but then in such violent turbulence you might be hand flying the thing in any case, and the GNS430 doesn't even notice any absence of power that lasts that little). >> >> Are there other risks I am not considering here? This is a VFR only machine and I'm a low time PPL so not the most experienced in these matters. > > The legacy battery contactor is tasked with > carrying normal operating loads usually in > the tens of amps but predicated on getting an > engine started . . . loads of perhaps 200A. Ah. Ok now I understand your previous question. In my case the fat wire to the starter contactor is always hot. The master just activates the coil circuit. I now know this is against conventional design where master OFF is supposed to correspond to max darkness. In my case the total length of fat (positive) wire is approx 50cm (20"): battery to starter contactor to starter motor. ________________________________________________________________________________
Date: Nov 02, 2013
There is a potential problem in using only the starter contactor to switch the starter motor power - those contactors are known to occasionally weld themselves together. In that case, with only the starter contactor switching power to the starter, there is then no way of disengaging it from the running engine until the battery is flat (if that ever happens as the starter is now a generator). In the UK the authorities insist that a light is installed in the panel warning the pilot the starter remains energised, as there have been several accidents. The engaged starter saps a large amount of power from the engine and gets very hot, with unpleasant consequences. If a modern starter with a piggy-back solenoid is fitted, to avoid the master relay handling the starting current, the jumper that normally energises the solenoid can be brought into a cockpit switch to disable the starter if the the starter contactor does weld on. A small additional parts count, but the switch never does any switching except in emergency. Peter On 01/11/2013 17:44, Sacha wrote: > > > On Nov 1, 2013, at 13:37, "Robert L. Nuckolls, III" wrote: > >> >> At 12:10 AM 11/1/2013, you wrote: >>> >>> I use automotive "cube" relays (one for the master relay, one for alternator) rated at 70A. They are light and consume less than 300mA each. Is there a reason not to use them? The only potential drawback I'm aware of is that they can break the contact if subject to violent shocks. But loosing panel power for a few milliseconds doesn't seem such a big issue (the autopilot does reset but then in such violent turbulence you might be hand flying the thing in any case, and the GNS430 doesn't even notice any absence of power that lasts that little). >>> >>> Are there other risks I am not considering here? This is a VFR only machine and I'm a low time PPL so not the most experienced in these matters. >> The legacy battery contactor is tasked with >> carrying normal operating loads usually in >> the tens of amps but predicated on getting an >> engine started . . . loads of perhaps 200A. > Ah. Ok now I understand your previous question. In my case the fat wire to the starter contactor is always hot. The master just activates the coil circuit. > > I now know this is against conventional design where master OFF is supposed to correspond to max darkness. In my case the total length of fat (positive) wire is approx 50cm (20"): battery to starter contactor to starter motor. > > ________________________________________________________________________________
Subject: Contactors
Date: Nov 02, 2013
There is a potential problem in using only the starter contactor to switch the starter motor power - those contactors are known to occasionally weld themselves together. In that case, with only the starter contactor switching power to the starter, there is then no way of disengaging it from the running engine until the battery is flat (if that ever happens as the starter is now a generator). In the UK the authorities insist that a light is installed in the panel warning the pilot the starter remains energised, as there have been several accidents. The engaged starter saps a large amount of power from the engine and gets very hot, with unpleasant consequences. Good point, I hadn't thought of that failure mode. If a modern starter with a piggy-back solenoid is fitted, to avoid the master relay handling the starting current, the jumper that normally energises the solenoid can be brought into a cockpit switch to disable the starter if the the starter contactor does weld on. A small additional parts count, but the switch never does any switching except in emergency. You're speaking about the solenoid on the starter motor? I don't recall seeing any external jumper there (the engine is a Rotax 912). I'll have a check next time I'm down at the hangar. ________________________________________________________________________________
Date: Nov 02, 2013
> the battery is 13.4 and the MGL Efis shows supply voltage as 12.9. I have checked all feeds and connectors, but cannot isolate the voltage drop.... Subtracting 12.9 from 13.4 equals 0.5 volts which is the voltage drop across a diode. Is the MGL EFIS powered through an E-Bus diode? What happens when the E-Bus alternate feed path (if installed) is turned on? Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411967#411967 ________________________________________________________________________________
Date: Nov 02, 2013
Many thanks to all who responded. Apart from the aplication itself (resistor already installed), it's always a pleasure to learn something every day. And this list is one of the best to this purpose. Best Carlos From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: sexta-feira, 1 de Novembro de 2013 15:40 Subject: Re: AeroElectric-List: Watts on resistors At 09:21 AM 11/1/2013, you wrote: Bob and all The VP-X Pro installation manual recomends, in order to have Volt indication from the Aux Batt, to connect the + terminal to a certain pin in the box, trough a 1Kohm - 1W resistor. Problem is that I can only find 1Kohm - 2W resistor. So, to learn something else today, can someone please explain if there is any problem if I use the 2W instead of 1W resistor. (Please don't answer indicating a source for 1W resistors...) That's an easy one. The resistor is a substitute for a fuse. Further, it's called out as 1-watt for mechanical convenience and robustness. Examples: Some years back I suggested that the most valuable and often least accessible data point for diagnosing an alternator problem is to watch FIELD VOLTAGE behavior while putting an alternator through its paces. I published this little feature in Z-23 suggesting a permanently attached wire PROTECTED by a resistor leading from the alternator field to some handy point in the cockpit. Emacs! A fuse would be okay too. A 1/4 watt would work but 1/2 watt was mechanically more robust, 1w would have been better yet. So as long as you don't mind a larger 'lump' in your battery sense lead, a 2W resistor is okay as well. http://tinyurl.com/kyc6tq6 I think it was here on the List that I once suggested a tubular, 10-watt wire wound resistor with flag terminals as a suitable enclosure for a reed switch current sensor. Emacs! The 'jeep' was to put lead wires on the reed switch then epoxy into place down the center of the tubular resistor. Then wind an excitation coil around the center of the resistor over the reed. Calibrate closure current for the reed by adjusting coil turns. In this case, the actual value of the resistor wasn't critical . . . just needed to be high enough not to adversely affect current through the the coil. The resistor became a robust 'housing' for the current sense relay offering a convenient terminals to tie off ends of the coil. These are but two examples of many where the designer's 'sizing' of a component may not have obvious foundation in the original design goals for the part. Bob . . . ________________________________________________________________________________
Date: Nov 02, 2013
>> If a modern starter with a piggy-back solenoid is fitted, >> to avoid the master relay handling the starting current, the jumper that >> normally energises the solenoid can be brought into a cockpit switch to >> disable the starter if the the starter contactor does weld on. A small >> additional parts count, but the switch never does any switching except in >> emergency. > > You're speaking about the solenoid on the starter motor? I don't recall > seeing any external jumper there (the engine is a Rotax 912). I'll have a > check next time I'm down at the hangar. I couldn't find anything there unfortunately. The starter motor just has one terminal for the fat positive wire. ________________________________________________________________________________
Date: Nov 02, 2013
Does anyone have the schematic or Manual for the WGA Model AIR-1177 Aviat ion Intercom System=3F I am trying to figure out the input and output jacks on the box. I intend to mount it in a panel along with an isolation amp. The box has on-off volume and squelch controls. There are 3 cables comi ng out of each side of the box, one side for Pilot and the other for Copilo t. 2 of the cables are mic and headset jacks, and there is another cable wi th a 1/4=22 plug attached, and don't know where this gets plugged into. Also there are 3 small jacks on the end of the box marked EXP, COPILOT, AUX. D on't know what these are for either. I called the company some time ago and got some rather arrogant non ans wers so this is why I decided to ask on the list if anyone has any experien ce with this device. Any assistance appreciated. Roger -- Do you have a slow PC=3F Try a Free scan http://www.spamfighter.com/SLOW-PCfi ghter=3Fcid=sigen ________________________________________________________________________________
Subject: CONTACT EXTRACTOR
Date: Nov 03, 2013
Can someone give me the (working tip end) dimensions of the Bendix/King contact extraction tool p/n 047-05099-001 that is used to remove contacts p/n 030-01107-00xx as used on KT 76 and KX 155. Please no guesses I need a caliper on this one. I will be working under extremely difficult conditions. Apparently, this tool is also known as Molex p/n HT-1884 Thank you for your help. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411998#411998 ________________________________________________________________________________
Date: Nov 03, 2013
Sacha, Apologies, I'm not very familiar with Rotax components. It would be good to know how much current a Rotax starter pulls - I guess it is likely that as the engine is only 1200cc the draw would rather less than a starter for a 5/6 litre Lyc. I believe a Lyc starter pulls between 200 to 500A depending on starter type and compression ratio. If a Rotax pulls substantially less the potential for the starter contactor to weld itself shut would be lower (probably not a linear relationship), and so the risk of a problem that much lower. You may decide you can tolerate the risk without additional mitigations. Peter On 02/11/2013 21:10, Sacha wrote: > > >>> If a modern starter with a piggy-back solenoid is fitted, >>> to avoid the master relay handling the starting current, the jumper that >>> normally energises the solenoid can be brought into a cockpit switch to >>> disable the starter if the the starter contactor does weld on. A small >>> additional parts count, but the switch never does any switching except in >>> emergency. >> You're speaking about the solenoid on the starter motor? I don't recall >> seeing any external jumper there (the engine is a Rotax 912). I'll have a >> check next time I'm down at the hangar. > I couldn't find anything there unfortunately. The starter motor just has one terminal for the fat positive wire. > > ________________________________________________________________________________
Date: Nov 03, 2013
Thanks Peter Actually I realized today that I can easily use the semi-useless alternator off warning light that I fitted on my panel as a "starter on warning light" with minimal rewiring. Since 99.9% of the time I'm going to be on the ground while starting my engine, I think I can live with the fact of not being able to disable the starter motor if the contactor gets stuck somehow since I can just shut down the engine. Out of interest I will try to measure how many amps are drawn by the starter next time I'm down at the hangar. Though I suspect this would vary somewhat depending on temperature. I've almost finished the CAD drawings of my electrical system so I'll be submitting them to the list for review and criticism soon. Sacha On Nov 3, 2013, at 21:42, Peter Pengilly wrote: > Apologies, I'm not very familiar with Rotax components. It would be good to know how much current a Rotax starter pulls - I guess it is likely that as the engine is only 1200cc the draw would rather less than a starter for a 5/6 litre Lyc. I believe a Lyc starter pulls between 200 to 500A depending on starter type and compression ratio. If a Rotax pulls substantially less the potential for the starter contactor to weld itself shut would be lower (probably not a linear relationship), and so the risk of a problem that much lower. You may decide you can tolerate the risk without additional mitigations. ________________________________________________________________________________
Date: Nov 04, 2013
From: Etienne Phillips <etienne.phillips(at)gmail.com>
Hi Sacha Being able to pull the mixture control whilst on the ground will stop the engine from producing power, but if the start motor is still energised due to the failed contactor, won't it keep cranking until you pull a terminal off the battery? I'm not that familiar with the starters used in aviation (I hand-swing my engine), so am unsure if they have a disengage mechanism like they do on cars. Thanks Etienne On 4 November 2013 00:07, Sacha wrote: > > Thanks Peter > Actually I realized today that I can easily use the semi-useless > alternator off warning light that I fitted on my panel as a "starter on > warning light" with minimal rewiring. Since 99.9% of the time I'm going to > be on the ground while starting my engine, I think I can live with the > fact of not being able to disable the starter motor if the contactor gets > stuck somehow since I can just shut down the engine. > Out of interest I will try to measure how many amps are drawn by the > starter next time I'm down at the hangar. Though I suspect this would vary > somewhat depending on temperature. > I've almost finished the CAD drawings of my electrical system so I'll be > submitting them to the list for review and criticism soon. > Sacha > > On Nov 3, 2013, at 21:42, Peter Pengilly wrote: > > > Apologies, I'm not very familiar with Rotax components. It would be good > to know how much current a Rotax starter pulls - I guess it is likely that > as the engine is only 1200cc the draw would rather less than a starter for > a 5/6 litre Lyc. I believe a Lyc starter pulls between 200 to 500A > depending on starter type and compression ratio. If a Rotax pulls > substantially less the potential for the starter contactor to weld itself > shut would be lower (probably not a linear relationship), and so the risk > of a problem that much lower. You may decide you can tolerate the risk > without additional mitigations. > > ________________________________________________________________________________
Date: Nov 04, 2013
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 04, 2013
At 03:16 AM 11/2/2013, you wrote: > > >There is a potential problem in using only the starter contactor to >switch the starter motor power - those contactors are known to >occasionally weld themselves together. In that case, with only the >starter contactor switching power to the starter, there is then no >way of disengaging it from the running engine until the battery is flat This was a greater risk when starter contactors were intermittent duty versions of the battery contactors (large surface area, low pressure). The modern automotive contactor is a low area, very high pressure connection. These CAN stick but probably not if the battery is good. Too many batteries are flogged until they don't crank the engine any more . . . they've been unsuited for use on an airplane for some period of time before a soggy battery makes a 'soft closure' of a contactor and causes it to stick. > (if that ever happens as the starter is now a generator). Doesn't happen. Every starter has a disconnect mechanism that prevents a running engine from back-driving the starter. Consider that a starter armature runs at or near it's max horsepower rpm while cranking an engine at ~200 rpm. An engine running at 2000 rpm would drive a starter at 10x it's rated running speed . . . throws windings and/or tears up gearboxes. > In the UK the authorities insist that a light is installed in the > panel warning the pilot the starter remains energised, as there > have been several accidents. The engaged starter saps a large > amount of power from the engine and gets very hot, with unpleasant > consequences. Yes, the starter does continue to run from due to applied electrical energy. These are NOT efficient motors. They draw substantial current even when no mechanically loaded. Given their design goals for intermittent duty operation, they simply cannot reject internal heat generated while running unloaded Keep the battery in good shape and starter contactor sticking is very rare. Starter energized light is a simple hedge against taxiing out with a starter energized. Having a battery contactor carry starter current is a pretty cheap insurance. Bob . . . ________________________________________________________________________________
Subject: Contactors
Date: Nov 04, 2013
Being able to pull the mixture control whilst on the ground will stop the engine from producing power, but if the start motor is still energised due to the failed contactor, won't it keep cranking until you pull a terminal off the battery? I'm not that familiar with the starters used in aviation (I hand-swing my engine), so am unsure if they have a disengage mechanism like they do on cars. Hi Etienne, I'm not really sure either. But in any case it sounds manageable enough (though maybe expensive if the starter motor gets wrecked) if one is on the ground. By the way I stuck a loop-type ammeter on the ground cable today and set it to the MAX function and then got in and cranked away. I usually put the electric fuel pump on for 10 seconds before I start the engine and it usually starts immediately. This time I left the fuel pump off so I needed to crank the engine four or five times before it started. The maximum recorded current was 99.6 amps, i.e. 100A. Outside temp was 15C. I'm thinking that my automotive 70A relay might even take this kind of current if I decided to run the starter current through it since it's such a short amount of time. Or I could mount two 70A relays in parallel (total coil current would still only be 0.7 amps), but honestly I'm not sure it would be worth the hassle. What do people think? Sacha ________________________________________________________________________________
Date: Nov 04, 2013
> > >I couldn't find anything there unfortunately. The starter motor just >has one terminal for the fat positive wire. Rotax starter doesn't have a contactor/solenoid combo. Rotax uses a simple external contactor to control power to the motor. The pinion gear is extended inertially on spiral grooves cut into the motor shaft. Recommend you have either a battery contactor or manually operated battery switch. Bob . . . ________________________________________________________________________________
Date: Nov 04, 2013
Subject: Re: CONTACT EXTRACTOR
At 10:09 AM 11/3/2013, you wrote: > >Can someone give me the (working tip end) >dimensions of the Bendix/King contact extraction >tool p/n 047-05099-001 that is used to remove >contacts p/n 030-01107-00xx as used on KT 76 and >KX 155. Please =93 no guesses =93 I need a >caliper on this one. I will be working under extremely difficult conditions. > >Apparently, this tool is also known as Molex p/n HT-1884 >Thank you for your help. How many terminals do you need to extract? The tool size is not critical . . . it needs to fit inside the width of the slot in the connector housing and be no thicker than the depth of the slot. It's a thin blade that is used to depress the retention tang on the pin. Emacs! Unless you have bunch of terminals to pull, suggest you try a sewing needle inserted into the center of the slot. The tang is only about .4" inside and not hard to reach. Bob . . . ________________________________________________________________________________
Date: Nov 04, 2013
Subject: Re: Trusting a chargers reputation, what an idiot!
At 07:55 AM 11/2/2013, you wrote: > > > > the battery is 13.4 and the MGL Efis shows supply voltage as > 12.9. I have checked all feeds and connectors, but cannot isolate > the voltage drop.... > >Subtracting 12.9 from 13.4 equals 0.5 volts which is the voltage >drop across a diode. Is the MGL EFIS powered through an E-Bus >diode? What happens when the E-Bus alternate feed path (if >installed) is turned on? >Joe Excellent question!!!! Bob . . . ________________________________________________________________________________
Date: Nov 04, 2013
Bob, Thank you for your response. Fortunately, I have only two terminals to extract. I was hoping to get measurements of the actual tool; especially the blade thickness, so the contact would release easily, yet I wouldnt have to worry about permanently deforming the retainer clip. Also, I dont have a spare Bendix/King card edge connector body to give me the slot width, but I could probably guesstimate that. My idea was to cut a sliver of shim stock. Do YOU have a guess as to blade thickness of this tool? Yes, I may have to resort to the sewing needle approach, but I dont know if these old eyes will be able to keep the needle centered in the slot. Besides, trying different sizes, I can ruin only so many of my wifes sewing needles before there is hell to pay. Thanks again, Jerry King -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412114#412114 ________________________________________________________________________________
Date: Nov 04, 2013
> the battery is 13.4 and the MGL Efis shows supply voltage as >> 12.9. I have checked all feeds and connectors, but cannot isolate >> the voltage drop.... Were you able to measure the voltage at the connector going into the EFIS? If this measures at 13.4V, then you may have a calibration error in your EFIS. Roger ________________________________________________________________________________
Date: Nov 04, 2013
At 02:11 PM 11/4/2013, you wrote: > >Bob, Thank you for your response. Fortunately, >I have only two terminals to extract. >I was hoping to get measurements of the actual >tool; especially the blade thickness, so the >contact would release easily, yet I wouldnt >have to worry about permanently deforming the retainer clip. There is possibility of 'flattening' the clip even when the 'right tool' is used. I always tweak the clip to increase it's grip before re-inserting a used terminal back into the housing. > Also, I dont have a spare Bendix/King card > edge connector body to give me the slot width, > but I could probably guesstimate that. I don't think I've ever actually measured one. The last two that I made were fabricated from flat spring stock cabbaged from a pocket tape measure. I used a cutoff wheel in a Dremel to sculpt the material. Many moons ago I published this offering Vhttp://tinyurl.com/nknv4bk I believe these numbers were suited to the various versions of this pin retention methodology . . . but that was some time ago. >Yes, I may have to resort to the sewing needle >approach, but I dont know if these old eyes >will be able to keep the needle centered in the >slot. Besides, trying different sizes, I can >ruin only so many of my wifes sewing needles before there is hell to pay. Get your own needles. In fact, I think sewing machine needles are about the right thickness and they offer a 'handle' of sorts on the machine end. Again, a little sculpting with a Dremel would tailor them to the task. Bob . . . ________________________________________________________________________________
Date: Nov 04, 2013
I find that one of my very small flat screwdrivers (watchmaker type) often works well on these types of pins. Ken On 04/11/2013 6:50 PM, Robert L. Nuckolls, III wrote: > > > At 02:11 PM 11/4/2013, you wrote: >> >> >> Bob, Thank you for your response. Fortunately, I have only two >> terminals to extract. >> I was hoping to get measurements of the actual tool; especially the >> blade thickness, so the contact would release easily, yet I wouldnt >> have to worry about permanently deforming the retainer clip. > > There is possibility of 'flattening' the > clip even when the 'right tool' is used. > I always tweak the clip to increase it's > grip before re-inserting a used terminal > back into the housing. > >> Also, I dont have a spare Bendix/King card edge connector body to >> give me the slot width, but I could probably guesstimate that. > > I don't think I've ever actually measured one. > The last two that I made were fabricated from > flat spring stock cabbaged from a pocket tape > measure. I used a cutoff wheel in a Dremel to > sculpt the material. > > Many moons ago I published this offering > > Vhttp://tinyurl.com/nknv4bk > > I believe these numbers were suited to > the various versions of this pin retention > methodology . . . but that was some time ago. > > >> Yes, I may have to resort to the sewing needle approach, but I dont >> know if these old eyes will be able to keep the needle centered in the >> slot. Besides, trying different sizes, I can ruin only so many of my >> wifes sewing needles before there is hell to pay. > > Get your own needles. In fact, I think > sewing machine needles are about the right > thickness and they offer a 'handle' of sorts > on the machine end. Again, a little sculpting > with a Dremel would tailor them to the task. > > > Bob . . . > > --- This email is free from viruses and malware because avast! Antivirus protection is active. http://www.avast.com ________________________________________________________________________________
Subject: When is 2AWG not 2AWG?
Date: Nov 04, 2013
I purchased some 2AWG welding cable from McMaster-Carr. But the 2AWG ring terminals are too big. After trying all the ring terminals in my collection, the ones that fit are for 4AWG. Does welding cable have a smaller diameter than... regular wire? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412123#412123 ________________________________________________________________________________
Date: Nov 04, 2013
Subject: Re: When is 2AWG not 2AWG?
At 07:51 PM 11/4/2013, you wrote: > >I purchased some 2AWG welding cable from McMaster-Carr. But the 2AWG >ring terminals are too big. After trying all the ring terminals in >my collection, the ones that fit are for 4AWG. > >Does welding cable have a smaller diameter than... regular wire? The standard for sizing wire is predicated on the cross-section of copper . . . so a 10AWG SOLID wire will be a tad smaller in diameter than STRANDED wire due to the included air-space between strands. As a general rule, copper wires can be counted on to be as-advertised. Aluminum wire has a slightly higher resistance. Assuming that it is marked for AWG equivalency, then a 2AWG aluminum wire would be decidedly larger than it's copper cousin. Terminals are another matter. You cannot know the tooling for which the terminal was designed . . . which may indeed bring a 'too big' terminal down to size with the right squish. So pick the terminal with the tightest practical fit and then close the gap with wedges/solder or judicious application of force. The 'rating' for wire is more consistent and reliable than the sizing of terminals. Bob . . . ________________________________________________________________________________
Date: Nov 04, 2013
Thanks! :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412126#412126 ________________________________________________________________________________
Date: Nov 05, 2013
I run a wire direct from the Bat bus to the EFIS CB (2 amp) then via a switch to the EFIS. Sooooo, thinking out loud, it can only be the CB or the switch causing the voltage drop? My master switch is one of those manual types recently discussed on the list. All parts brand new, but worth checking! I imagine a .5v volt drop across the master could turn exiting once the starter starts pulling 200 amps! Best... Bob Verwey On 4 November 2013 21:20, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > nuckolls.bob(at)aeroelectric.com> > > At 07:55 AM 11/2/2013, you wrote: > >> >> >> > the battery is 13.4 and the MGL Efis shows supply voltage as 12.9. I >> have checked all feeds and connectors, but cannot isolate the voltage >> drop.... >> >> Subtracting 12.9 from 13.4 equals 0.5 volts which is the voltage drop >> across a diode. Is the MGL EFIS powered through an E-Bus diode? What >> happens when the E-Bus alternate feed path (if installed) is turned on? >> Joe >> > > Excellent question!!!! > > > Bob . . . > > ________________________________________________________________________________
Date: Nov 05, 2013
OK, I am armed. Wife gave me an assortment of different size sewing machine needles (much better to not stab yourself with) and I also raided my collection of jewelers screwdrivers. Now, if I could only see the back of the connector to tell which wire is which Bob & Ken, thank you very much for the tips. -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412132#412132 ________________________________________________________________________________
From: Bob McCallum <robert.mccallum2(at)sympatico.ca>
Date: Nov 05, 2013
But are you measuring the voltage at the EFIS using the same voltmeter with which you measured battery voltage? If you're simply depending on the EFIS reading then it could simply be the difference in calibration between the two instruments. Bob McC From: bob.verwey(at)gmail.com Date: Tue=2C 5 Nov 2013 07:14:59 +0200 Subject: Re: AeroElectric-List: Re: Trusting a chargers reputation=2C what an idiot! I run a wire direct from the Bat bus to the EFIS CB (2 amp) then via a swit ch to the EFIS. Sooooo=2C thinking out loud=2C it can only be the CB or the switch causing the voltage drop? My master switch is one of those manual t ypes recently discussed on the list. All parts brand new=2C but worth check ing! I imagine a .5v volt drop across the master could turn exiting once th e starter starts pulling 200 amps!=0A =0A Best...Bob Verwey On 4 November 2013 21:20=2C Robert L. Nuckolls=2C III <nuckolls.bob@aeroele ctric.com> wrote: =0A =0A lls.bob(at)aeroelectric.com> =0A =0A =0A =0A At 07:55 AM 11/2/2013=2C you wrote: =0A =0A =0A =0A =0A > the battery is 13.4 and the MGL Efis shows supply voltage as 12.9. I have checked all feeds and connectors=2C but cannot isolate the voltage drop... . =0A =0A Subtracting 12.9 from 13.4 equals 0.5 volts which is the voltage drop acros s a diode. Is the MGL EFIS powered through an E-Bus diode? What happens w hen the E-Bus alternate feed path (if installed) is turned on? =0A Joe =0A =0A =0A Excellent question!!!! =0A =0A =0A =0A Bob . . . =0A =0A =0A om" target="_blank">www.aeroelectric.com =0A ooks.com" target="_blank">www.buildersbooks.com =0A et="_blank">www.homebuilthelp.com =0A et="_blank">www.mypilotstore.com =0A "_blank">www.mrrace.com =0A ="_blank">http://www.matronics.com/contribution =0A le=2C List Admin. =0A =0A -List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-Li st =0A =0A http://forums.matronics.com =0A =0A =0A =0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Date: Nov 05, 2013
Did the Aeroelectric list address change? Suddenly many of my messages from the list are going to junk mail and are not being put into the proper folder. The new address seems to be: owner-aeroelectric-list-server(at)xenia.matronics.com what has occurred here? Did I miss something? Bill -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, November 04, 2013 6:50 PM Subject: Re: AeroElectric-List: Re: CONTACT EXTRACTOR At 02:11 PM 11/4/2013, you wrote: > >Bob, Thank you for your response. Fortunately, >I have only two terminals to extract. >I was hoping to get measurements of the actual >tool; especially the blade thickness, so the >contact would release easily, yet I wouldnt >have to worry about permanently deforming the retainer clip. There is possibility of 'flattening' the clip even when the 'right tool' is used. I always tweak the clip to increase it's grip before re-inserting a used terminal back into the housing. > Also, I dont have a spare Bendix/King card > edge connector body to give me the slot width, > but I could probably guesstimate that. I don't think I've ever actually measured one. The last two that I made were fabricated from flat spring stock cabbaged from a pocket tape measure. I used a cutoff wheel in a Dremel to sculpt the material. Many moons ago I published this offering Vhttp://tinyurl.com/nknv4bk I believe these numbers were suited to the various versions of this pin retention methodology . . . but that was some time ago. >Yes, I may have to resort to the sewing needle >approach, but I dont know if these old eyes >will be able to keep the needle centered in the >slot. Besides, trying different sizes, I can >ruin only so many of my wifes sewing needles before there is hell to pay. Get your own needles. In fact, I think sewing machine needles are about the right thickness and they offer a 'handle' of sorts on the machine end. Again, a little sculpting with a Dremel would tailor them to the task. Bob . . . ________________________________________________________________________________
Subject: Battery Tech
Date: Nov 05, 2013
Innovation in the world of batteries. I love this stuff! http://tiny.cc/jf625w ________________________________________________________________________________
Date: Nov 05, 2013
Subject: Bussing W58 Series Breakers
=0ADoes anyone have a picture showing a row of W58 series (reset-only)-ci rcuit breakers w/ .250 quick connect terminalsand how the feed side was bus sed?=0A=0AI can see using several quick connect terminals jumpered- toget her but i'm curious about other more elegant solutions.=0A=0ATIA=0A=0A-Jeff ________________________________________________________________________________
Date: Nov 05, 2013
No pictures.but copper bus bar across the terminals. Rene' Felker N423CF 801-721-6080 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeff Luckey Sent: Tuesday, November 05, 2013 7:54 PM Subject: AeroElectric-List: Bussing W58 Series Breakers Does anyone have a picture showing a row of W58 series (reset-only) circuit breakers w/ .250 quick connect terminals and how the feed side was bussed? I can see using several quick connect terminals jumpered together but i'm curious about other more elegant solutions. TIA -Jeff ________________________________________________________________________________
Subject: Re: Copper Foil width for VOR antenna
Date: Nov 05, 2013
So ... the first thing I did was to establish a baseline... this would be the Vee Dipole VOR antenna. With the folded balun. The antenna was tuned for best VSWR in the VOR band... the attached pic shows what was accomplished... it is essentially below 1:2... considering all the iron-mongery around the antenna... good enough :-). A more accurate tuning would be completed after the copper foil is glassed in... that way the dielectric of the glass would also be compensated for. The loop antennas to be experimented have to beat this to be worthy of consideration for install... stay tuned... for the loop antennas... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412159#412159 Attachments: http://forums.matronics.com//files/vor_half_wave_vee_wing_install_tuned_rg400_w_balun_small_214.jpg http://forums.matronics.com//files/vor_half_wave_vee_wing_install_tuned_rg400_w_balun_pre_install__swr_chartsmall_900.jpg ________________________________________________________________________________
Date: Nov 05, 2013
Subject: matronics servers have the flu
It seems that the ISP that hosts Matt's Internet portal did something dumb with their domain name servers. My access to any features on matronics have been sketchy at best. Matt's not getting very good answers from the so-called 'service reps' . . . I think we're in good hands . . . Matt's trying to chase the rats out of the woodpile. Bob . . . ________________________________________________________________________________
Date: Nov 05, 2013
Subject: Re: Bussing W58 Series Breakers
At 06:53 PM 11/5/2013, you wrote: >Does anyone have a picture showing a row of W58 series >(reset-only) circuit breakers w/ .250 quick connect terminals and >how the feed side was bussed? > >I can see using several quick connect terminals jumpered together >but i'm curious about other more elegant solutions. Keystone electronics makes a .250 wide faston socket for use on etched circuit boards. A bus-board could be fabricated to accept a row of these clips spaced at what ever matches your breaker layout. Emacs! This would make a very low parts count bus-bar for fast-on tabbed breakers. Bob . . . ________________________________________________________________________________
Date: Nov 06, 2013
Date: Nov 06, 2013
Subject: Network Issues At Matronics Last Few Days...
Dear Listers, Starting sometime on Friday November 1st, my Internet Service Provider (ISP) began "upgrading" their Domain Name Servers (DNS). DNS servers allow the resolution of computer names such as "www.matronics.com" to real addresses such as 64.81.74.3. This also impacts email delivery as well, since there is another layer of resolution that applies to email names. Because of this upgrade on the part of my ISP, DNS service started getting unreliable around Friday sometime, but I didn't notice it until sometime on Saturday. When I used a tool called "nslookup" to test the resolution of name-to-address, about 50-75% of the time my ISP's servers would response with an "SERVFAIL" indicating that they didn't know the answer. I opened a ticket with the ISP on Saturday, and by Sunday afternoon I had no feedback on the ticket so I called in to support. "We upgrading the DNS servers, and it should back by Sunday at 5pm." 5pm came and went with no resolution. Well, long story short by Tuesday morning things were still not fixed and in fact much worse. So, I opted to move all my DNS service to a different service provider. I have a lot of DNS entries, so it took a while to get everything moved over. It generally takes about 24 hours for a change like that to fully propagate across the Internet which would be Wednesday morning sometime. I've noticed that the Matronics web server traffic is picking up again, so many sites have already propagated the new information. I really should have just moved the DNS on Saturday when I first noticed the troubles, but with stuff like this, you just keep believing that it gonna be fixed any minute now.... And, in fact, that's what my ISP kept telling me... Its always a giant bummer when stuff like this happens and particularly during the Fund Raiser. I apologize to anyone that has tried to make a Contribution in the last few days and had issues or was simply unable to connect. By the time you read this email, the DNS should be fully propagated, and I ask that you please try again. The Contribution web site URL is: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your kind consideration and patience, Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 06, 2013
Now, why didn't I think of that???=0A=0AI may have a few of those clips lef t over from a previous project. Don't even need a circuit board, I could si mply solder them to a brass strip to form a buss.=0A=0A=0AThx Bob, =0A=0A =0A-Jeff=0A=0A=0A=0A________________________________=0A From: "Robert L. Nu ckolls, III" =0ATo: aeroelectric-list@matron ics.com =0ASent: Tuesday, November 5, 2013 8:53 PM=0ASubject: Re: AeroElect ric-List: Bussing W58 Series Breakers=0A =0A=0A=0AAt 06:53 PM 11/5/2013, yo u wrote:=0A=0A=0ADoes anyone have a picture=0Ashowing a row of W58 series ( reset-only)- circuit breakers w/ .250=0Aquick connect terminals and how t he feed side was bussed?=0A>=0A>I can see using several quick connect termi nals jumpered- together=0Abut i'm curious about other more elegant soluti ons.=0A>=0A=0AKeystone electronics makes a .250 wide=0Afaston socket for us e on etched circuit=0Aboards.- A bus-board could be fabricated=0Ato accep t a row of these clips spaced at=0Awhat ever matches your breaker layout. =0A=0A=0A -=0A=0AThis would make a very low parts count=0Abus-bar for fas t-on tabbed breakers.=0A=0A=0A=0A- Bob . . . ________________________________________________________________________________
Date: Nov 06, 2013
I think I'd like to give that a go too when I upgrade my current wiring. Can a circuit board carry enough current though? The copper layers don't look very thick. On the other hand, the brass strips that are found in home electrical stores seem a bit oversized to the task. Now, why didn't I think of that??? I may have a few of those clips left over from a previous project. Don't even need a circuit board, I could simply solder them to a brass strip to form a buss. ________________________________________________________________________________
Date: Nov 06, 2013
Can a circuit board carry enough current though=3F The copper layers don't look very thick. On the other hand, the brass strips that are found in h ome electrical stores seem a bit oversized to the task. Something I have found that works great is soft copper tubing. You can purchase by the foot at your local hardware store. Take a 1/4=22 diameter p iece and flatten gently with a hammer and it makes a great bus bar. If you want to attach it to the CB's with screws you can drill holes and screw it on or solder if you prefer. a similar method makes a nice forrest of tabs for grounding. Roger -- Do you have a slow PC=3F Try a Free scan http://www.spamfighter.com/SLOW-PCfi ghter=3Fcid=sigen ________________________________________________________________________________
Date: Nov 06, 2013
At 06:53 PM 11/5/2013, you wrote: Does anyone have a picture showing a row of W58 series (reset-only) circuit breakers w/ .250 quick connect terminals and how the feed side was bussed? I can see using several quick connect terminals jumpered together but i'm curious about other more elegant solutions. Keystone electronics makes a .250 wide FastOn socket for use on etched circuit boards. A bus-board could be fabricated to accept a row of these clips spaced at what ever matches your breaker layout. If you're really handy with sheet metal and getting rows of holes accurately located, you could fabricate from scratch . . . Emacs! Suggest you not try to bus more than 5 breakers at once. The finished bus-bar needs to press-on/ pry-off of n-terminals all at once. Unless I could locate the holes on a digitally indicated milling machine, I'd probably go the etched circuit board route. $60 will get you 3 boards 5 breakers long that can be sheared into 3 bus bars each. Enough material with precisely located holes to neatly tie 45 breakers together in groups of up to 5. Have you bought the breakers? They are available in screw terminal versions . . . Bob . . . ________________________________________________________________________________
Date: Nov 06, 2013
At 02:09 PM 11/6/2013, you wrote: >I think Id like to give that a go too when I >upgrade my current wiring Can a circuit board >carry enough current though? The copper layers >dont look very thick. On the other hand, the >brass strips that are found in home electrical >stores seem a bit oversized to the task. Yes, the number of breakers that can be fed from one piece of double sided board won't overheat it. You also connect the feeder wire as close as practical to the center so that copper clad is only 'feeding' two breakers. Bob . . . ________________________________________________________________________________
Date: Nov 06, 2013
At 01:49 PM 11/6/2013, you wrote: >Now, why didn't I think of that??? > >I may have a few of those clips left over from a previous project. >Don't even need a circuit board, I could simply solder them to a >brass strip to form a buss. yes. you need to fixture them to be VERY well aligned before soldering. Normal to the buss surface and no twisting of the breaker terminal. Bob . . . ________________________________________________________________________________
Date: Nov 06, 2013
=0AThe nice thing about using 3 or 4 insulated quick connect terminals =0Al ike this:=0A=0Ajumped together is that it makes the buss well insulated.- There would be no exposed B+ or metal bar.- (For the purposes of this di scussion lets call this a "jumper buss")=0A=0AWith a buss bar like the one shown below we lose that insulation -- also could be difficult to work with for several reasons: difficult to pry on and off, easily bend brass bar or break circuit board, etc.=0A=0AWhat are the problems, issues, cons of a "j umper buss"?=0A=0A=0A-Jeff=0A=0A=0A=0A________________________________=0A F rom: "Robert L. Nuckolls, III" =0ATo: aeroel ectric-list(at)matronics.com =0ASent: Wednesday, November 6, 2013 2:07 PM=0ASu bject: Re: AeroElectric-List: Bussing W58 Series Breakers=0A =0A=0A=0AAt 06 :53 PM 11/5/2013, you wrote:=0A=0ADoes anyone have a picture showing a row of W58 series (reset-only)-=0Acircuit breakers w/ .250 quick connect term inals and how the feed side=0Awas bussed?=0A=0AI can see using several quic k connect terminals jumpered- together=0Abut i'm curious about other more elegant solutions.=0A=0A=0AKeystone electronics makes a .250 wide=0AFastOn socket for use on etched circuit=0Aboards.- A bus-board could be fabrica ted=0Ato accept a row of these clips spaced at=0Awhat ever matches your bre aker layout.=0A=0AIf you're really handy with sheet metal and=0Agetting row s of holes accurately located, you=0Acould fabricate from scratch . . . =0A =0A=0A=0A- Suggest you not try to bus more than 5 breakers=0A- at once. The finished bus-bar needs to press-on/=0A- pry-off of n-terminals all a t once.- Unless=0A- I could locate the holes on a digitally indicated =0A- milling machine, I'd probably go the etched=0A- circuit board rout e. $60 will get you 3 boards=0A- 5 breakers long that can be sheared into 3=0A- bus bars each. Enough material with precisely=0A- located holes to neatly tie 45 breakers together=0A- in groups of up to 5.=0A=0A- Hav e you bought the breakers? They are available=0A- in screw terminal versi ons . . . =0A=0A- Bob . . . ________________________________________________________________________________
Date: Nov 06, 2013
At 08:29 PM 11/6/2013, you wrote: >The nice thing about using 3 or 4 insulated quick connect terminals >like this: >[] > > >jumped together is that it makes the buss well insulated. There >would be no exposed B+ or metal bar. (For the purposes of this >discussion lets call this a "jumper buss") > >With a buss bar like the one shown below we lose that insulation -- >also could be difficult to work with for several reasons: difficult >to pry on and off, easily bend brass bar or break circuit board, etc. > >What are the problems, issues, cons of a "jumper buss"? Technically not a 'buss' due to the daisy chain of serial connections . . . but lots of those breakers have been wired that way. Probably not high risk . . . but what's wrong with a nice fuse-block? Bob . . . ________________________________________________________________________________
Date: Nov 07, 2013
Subject: Coming Soon - The List of Contributors - Please Make
A Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2013
I do the same, however, the copper tube (I use the stuff that is used as water pipes in houses) is hard drawn and slightly brittle. To get around that I use a small blowtorch to heat it up until it glows red hot and then let it cool in air. That anneals it and makes it softer and more resistant to cracking and easier to form- like when you flatten it. Jay From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of R. curtis Sent: 06 November 2013 10:43 PM Subject: Re: AeroElectric-List: Bussing W58 Series Breakers Can a circuit board carry enough current though? The copper layers don't look very thick. On the other hand, the brass strips that are found in home electrical stores seem a bit oversized to the task. Something I have found that works great is soft copper tubing. You can purchase by the foot at your local hardware store. Take a 1/4" diameter piece and flatten gently with a hammer and it makes a great bus bar. If you want to attach it to the CB's with screws you can drill holes and screw it on or solder if you prefer. a similar method makes a nice forrest of tabs for grounding. Roger _____ . Do you have a slow PC? <http://www.spamfighter.com/SLOW-PCfighter?cid=sigen> Try a free scan! ________________________________________________________________________________
Date: Nov 07, 2013
C'mon guys, you can buy copper strip cut to size, and save yourself a lot of hassle. Plus it looks better! Best... Bob Verwey IO 470 A35 ZU-DLW On 7 November 2013 12:27, Jay Hyde wrote: > I do the same, however, the copper tube (I use the stuff that is used as > water pipes in houses) is hard drawn and slightly brittle. To get around > that I use a small blowtorch to heat it up until it glows red hot and the n > let it cool in air. That anneals it and makes it softer and more resista nt > to cracking and easier to form- like when you flatten it. > > > Jay > > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *R. curtis > *Sent:* 06 November 2013 10:43 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Bussing W58 Series Breakers > > > Can a circuit board carry enough current though? The copper layers don =92t > look very thick. On the other hand, the brass strips that are found in > home electrical stores seem a bit oversized to the task. > > > Something I have found that works great is soft copper tubing. You can > purchase by the foot at your local hardware store. Take a 1/4" diameter > piece and flatten gently with a hammer and it makes a great bus bar. If > you want to attach it to the CB's with screws you can drill holes and scr ew > it on or solder if you prefer. a similar method makes a nice forrest of > tabs for grounding. > > > Roger > > > ------------------------------ > > > . > SPAMfighter href="http://www.spamfighter.com/SLOW-PCfighter?cid=sigen ">slow > PC? Try a free scan! > > > *www.aeroelectric.com <http://www.aeroelectric.com>* > > *www.buildersbooks.com <http://www.buildersbooks.com>* > > *www.homebuilthelp.com <http://www.homebuilthelp.com>* > > *www.mypilotstore.com <http://www.mypilotstore.com>* > > *www.mrrace.com <http://www.mrrace.com>* > > *http://www.matronics.com/contribution * > > *http://www.matronics.com/Navigator?AeroElectric-List * > > *http://forums.matronics.com * > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== > * > > ________________________________________________________________________________
Date: Nov 07, 2013
At 04:38 AM 11/7/2013, you wrote: >C'mon guys, you can buy copper strip cut to size, and save yourself >a lot of hassle. Plus it looks better! > I'll second that but with foundations in physics. Review the articles on our website that cite the term "gas tight" http://tinyurl.com/mjjl9dt I'll remind Listers that connectivity-magic happens when two conductors are held together with such force and rigidity across compliant surfaces that (1) ingress of moisture laden air and (2) relative motion between conductors is prevented. This design goal is the reason why round-wires and terminals become decidedly un-round under the crush of a crimped joint -OR- encapsulated in a cocoon of metal in the soldered joint. The most problematic joints in a wiring system are installer-fabricated with poor regard for process. Threaded fasteners are particularly needful of attention to details of flatness, force and rigidity. This is why the fuse-blocks dropped onto B&C's counter at OSH turned out to be a kind of installer's dream for relief of worries about knowledge and skill sets. First, the metal to metal joints were minimized. All but the threaded stud on the end of the assembly are manufactured for integrity and service life. If the builder can get a nice flat flag on an AMP terminal cinched down on a 10-32 stud, probabilities for very low risk and cost of ownership are good. The circuit breakers under discussion are suited to service in appliances and/or systems were design goals call for protection of a single feeder. But lining a bunch of them up on a panel with some notion of bussing their supply terminals is a mis-application of original design goals. The technical definition of a buss is a conductive structure ideally comprised of one piece of metal from which numerous taps supply power to various loads in the system with an architecture that prevents any single failure from propagating beyond the single feeder. Here's a collection of pictures for a 'buss and breaker' structure removed from a legacy Piper airplane . . . http://tinyurl.com/lmbcm66 http://tinyurl.com/lucl439 http://tinyurl.com/myhmoew The OBAM aviation builder-sphere is replete with arguments against religious observation of legacy design goals, "Well, the guy next to me in the hanger has been flying this (you fill in the blank) for years and hasn't had a bit of trouble." Given that our art is beginning its second century of real-life application, there are constellations of lessons-learned derived from a distillation of proven recipes for success re-enforced by understanding of the physics upon which they're built. Nobody stands over us with a rule book under one arm and a citation book under the other . . . but there ARE folks who we pay to worry that would be glad to assume that role in our craft. That event will mark the time when innovation and exploration of new ideas will slow to a crawl . . . if not halt completely. We would do well to expand our understanding of the arts and science while propagating it to the greatest number of interested individuals. There will always be those who don't find value in this endeavor . . . most will survive with little more than an elevated cost of ownership and laundry soap for the underwear. But a few will become candidates for trial in the Court of Dark-n-Stormy Nights where the narrator was not on board the airplane. The short response is, "buy already mill-flat materials from which to craft buss bars and fat-terminal jumpers". It is the exceedingly rare OBAM aviation shop that can take a round piece of metal and achieve such flatness. See: http://tinyurl.com/khymmf3 http://tinyurl.com/leunhah Bob . . . ________________________________________________________________________________
Date: Nov 07, 2013
There seems to be a typo on this ebay site. I don't think that one cubic inch of copper weighs 4 pounds! ?? http://www.ebay.com/itm/48-oz-1-16-Flat-Copper-Sheet-Plate-4-x-4-/2711921244 76?pt=LH_DefaultDomain_0 <http://www.ebay.com/itm/48-oz-1-16-Flat-Copper-Sheet-Plate-4-x-4-/271192124 476?pt=LH_DefaultDomain_0&hash=item3f244f6c3c> &hash=item3f244f6c3c Bill _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, November 07, 2013 9:36 AM Subject: Re: AeroElectric-List: Bussing W58 Series Breakers At 04:38 AM 11/7/2013, you wrote: C'mon guys, you can buy copper strip cut to size, and save yourself a lot of hassle. Plus it looks better! I'll second that but with foundations in physics. Review the articles on our website that cite the term "gas tight" http://tinyurl.com/mjjl9dt I'll remind Listers that connectivity-magic happens when two conductors are held together with such force and rigidity across compliant surfaces that (1) ingress of moisture laden air and (2) relative motion between conductors is prevented. This design goal is the reason why round-wires and terminals become decidedly un-round under the crush of a crimped joint -OR- encapsulated in a cocoon of metal in the soldered joint. The most problematic joints in a wiring system are installer-fabricated with poor regard for process. Threaded fasteners are particularly needful of attention to details of flatness, force and rigidity. This is why the fuse-blocks dropped onto B&C's counter at OSH turned out to be a kind of installer's dream for relief of worries about knowledge and skill sets. First, the metal to metal joints were minimized. All but the threaded stud on the end of the assembly are manufactured for integrity and service life. If the builder can get a nice flat flag on an AMP terminal cinched down on a 10-32 stud, probabilities for very low risk and cost of ownership are good. The circuit breakers under discussion are suited to service in appliances and/or systems were design goals call for protection of a single feeder. But lining a bunch of them up on a panel with some notion of bussing their supply terminals is a mis-application of original design goals. The technical definition of a buss is a conductive structure ideally comprised of one piece of metal from which numerous taps supply power to various loads in the system with an architecture that prevents any single failure from propagating beyond the single feeder. Here's a collection of pictures for a 'buss and breaker' structure removed from a legacy Piper airplane . . . http://tinyurl.com/lmbcm66 http://tinyurl.com/lucl439 http://tinyurl.com/myhmoew The OBAM aviation builder-sphere is replete with arguments against religious observation of legacy design goals, "Well, the guy next to me in the hanger has been flying this (you fill in the blank) for years and hasn't had a bit of trouble." Given that our art is beginning its second century of real-life application, there are constellations of lessons-learned derived from a distillation of proven recipes for success re-enforced by understanding of the physics upon which they're built. Nobody stands over us with a rule book under one arm and a citation book under the other . . . but there ARE folks who we pay to worry that would be glad to assume that role in our craft. That event will mark the time when innovation and exploration of new ideas will slow to a crawl . . . if not halt completely. We would do well to expand our understanding of the arts and science while propagating it to the greatest number of interested individuals. There will always be those who don't find value in this endeavor . . . most will survive with little more than an elevated cost of ownership and laundry soap for the underwear. But a few will become candidates for trial in the Court of Dark-n-Stormy Nights where the narrator was not on board the airplane. The short response is, "buy already mill-flat materials from which to craft buss bars and fat-terminal jumpers". It is the exceedingly rare OBAM aviation shop that can take a round piece of metal and achieve such flatness. See: http://tinyurl.com/khymmf3 http://tinyurl.com/leunhah Bob . . . ________________________________________________________________________________
Date: Nov 07, 2013
I disagree with letting it "cool in air" *unless* the alloys of copper water-pipe and spark-plug gaskets differ significantly which I doubt*.* As a fledgling A&P in 1973 we were taught to heat copper spark-plug gaskets to "cherry red" and *quench immediately in water*. I admit having no experience with allowing the gaskets to cool in air. Here's an EAA demo: http://www.eaavideo.org/video.aspx?v=57437956001 Respectfully - Bill SF bay area > On 7 November 2013 12:27, > you > wrote: > >> I do the same, however, the copper tube (I use the stuff that is used as >> water pipes in houses) is hard drawn and slightly brittle. To get around >> that I use a small blowtorch to heat it up until it glows red hot and then >> let it cool in air. That anneals it and makes it softer and more resistant >> to cracking and easier to form- like when you flatten it. >> > ________________________________________________________________________________
Date: Nov 07, 2013
At 09:08 AM 11/7/2013, you wrote: >There seems to be a typo on this ebay site. I don't think that one >cubic inch of copper weighs 4 pounds! ?? > ><http://www.ebay.com/itm/48-oz-1-16-Flat-Copper-Sheet-Plate-4-x-4-/271192124476?pt=LH_DefaultDomain_0&hash=item3f244f6c3c>http://www.ebay.com/itm/48-oz-1-16-Flat-Copper-Sheet-Plate-4-x-4-/271192124476?pt=LH_DefaultDomain_0&hash=item3f244f6c3c > >Bill > That's an unfortunate citation. In the time before etched circuit boards, copper was rated/sold by gage and/or thickness times some dimension that described area. Then came copper clad ecb materials where somebody thought it was a good idea to speak to the thickness of copper not in terms of thickness but in some new convention like 'ounces per square foot'. It's a close cousin to logic that speaks of 'circular mil area' of a wire. A 10AWG solid wire is 102 mils in diameter with a real cross section of 3.14 x (.051)^2 = 0.00816 square inches. 10AWG said to have a CMA of 102^2 or 10,400 'circular mils'. It's 'handier' to rate current density in a wire in Amps per CMA . . . it's a discipline specific vernacular for folks who work with wires a lot . . . but it bugs a physicist. The ounces per square foot are easier to measure/verify than the actual thickness of the copper where 1 ounce per square foot is 1.344 mils. Copper has a density of 5.168 oz/cu-in. So a sheet of copper 1" square and ".001344" thick will have weight of 5.168 x 0.001344 = .006945 oz/sq-in x 144 = 1.000 oz/sq foot. Getting back to the eBay ad, we have .062" thick for 0.323 oz/sq-in x 144 = 46.5 oz/sq-ft. Hence the citation for "48 oz" copper . . . a description that would be meaningless to guys who do copper gutters and flashing . . . or buss bars in airplanes. Bob . . . ________________________________________________________________________________
From: "R. curtis" <mrspudandcompany(at)verizon.net>
Date: Nov 07, 2013
I disagree with letting it =22cool in air=22 unless the alloys of copper wate r-pipe and spark-plug gaskets differ significantly which I doubt. Air cooling of the cherry red hot copper will anneal it, however it wil l anneal to a softer state if you quench the copper in water. Roger -- Do you have a slow PC=3F Try a Free scan http://www.spamfighter.com/SLOW-PCfi ghter=3Fcid=sigen ________________________________________________________________________________
Date: Nov 07, 2013
VGhhbmsgeW91IGZvciB0aGlzIGNsYXJpZmljYXRpb24uwqAKCkJpbGwKCkRvIG5vdCBhcmNoaXZl CgoKU2VudCB2aWEgdGhlIFNhbXN1bmcgR2FsYXh5IE5vdGXCriBJSSwgYW4gQVQmVCA0RyBMVEUg c21hcnRwaG9uZQoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLQpGcm9tOiAiUi4g Y3VydGlzIiA8bXJzcHVkYW5kY29tcGFueUB2ZXJpem9uLm5ldD4gCkRhdGU6IDExLzA3LzIwMTMg IDEwOjMyIEFNICAoR01ULTA4OjAwKSAKVG86IGFlcm9lbGVjdHJpYy1saXN0QG1hdHJvbmljcy5j b20gClN1YmplY3Q6IFJlOiBBZXJvRWxlY3RyaWMtTGlzdDogQnVzc2luZyBXNTggU2VyaWVzIEJy ZWFrZXJzIAogCgrCoApJIGRpc2FncmVlIHdpdGggbGV0dGluZyBpdCAiY29vbCBpbiBhaXIiwqB1 bmxlc3MgdGhlIGFsbG95cyBvZiBjb3BwZXIgd2F0ZXItcGlwZSBhbmQgc3BhcmstcGx1ZyBnYXNr ZXRzIGRpZmZlciBzaWduaWZpY2FudGx5IHdoaWNoIEkgZG91YnQuCsKgCkFpciBjb29saW5nIG9m IHRoZSBjaGVycnkgcmVkIGhvdCBjb3BwZXIgd2lsbCBhbm5lYWwgaXQsIGhvd2V2ZXIgaXQgd2ls bCBhbm5lYWwgdG8gYSBzb2Z0ZXIgc3RhdGUgaWYgeW91IHF1ZW5jaCB0aGUgY29wcGVyIGluIHdh dGVyLgrCoApSb2dlcgoKSSBhbSB1c2luZyB0aGUgRnJlZSB2ZXJzaW9uIG9mIFNQQU1maWdodGVy LgpTUEFNZmlnaHRlciBoYXMgcmVtb3ZlZCAxMzc4IG9mIG15IHNwYW0gZW1haWxzIHRvIGRhdGUu CgpEbyB5b3UgaGF2ZSBhIHNsb3cgUEM/IFRyeSBhIGZyZWUgc2NhbiEKCgpfLT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0KXy09 ICAgICAgIC0tIFBsZWFzZSBTdXBwb3J0IFlvdXIgTGlzdHMgVGhpcyBNb250aCAtLQpfLT0gICAg ICAgICAgIChBbmQgR2V0IFNvbWUgQVdFU09NRSBGUkVFIEdpZnRzISkKXy09Cl8tPSAgIE5vdmVt YmVyIGlzIHRoZSBBbm51YWwgTGlzdCBGdW5kIFJhaXNlci4gIENsaWNrIG9uCl8tPSAgIHRoZSBD b250cmlidXRpb24gbGluayBiZWxvdyB0byBmaW5kIG91dCBtb3JlIGFib3V0Cl8tPSAgIHRoaXMg eWVhcidzIFRlcnJpZmljIEZyZWUgSW5jZW50aXZlIEdpZnRzIHByb3ZpZGVkCl8tPSAgIGJ5Ogpf LT0KXy09ICAgICAqIEFlcm9FbGVjdHJpYyB3d3cuYWVyb2VsZWN0cmljLmNvbQpfLT0gICAgICog VGhlIEJ1aWxkZXIncyBCb29rc3RvcmUgd3d3LmJ1aWxkZXJzYm9va3MuY29tCl8tPSAgICAgKiBI b21lYnVpbHRIRUxQIHd3dy5ob21lYnVpbHRoZWxwLmNvbQpfLT0gICAgICogTXkgUGlsb3QgU3Rv cmUgd3d3Lm15cGlsb3RzdG9yZS5jb20KXy09ICAgICAqIFJhY2UgQ29uc3VsdGluZyB3d3cubXJy YWNlLmNvbQpfLT0KXy09ICAgTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGU6Cl8tPQpfLT0gICAt LT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT0KXy09ICAgVGhhbmsg eW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPQpfLT0gICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAg ICAgLSBUaGUgQWVyb0VsZWN0cmljLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRy b25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0 IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFy Y2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBh bmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29t L05hdmlnYXRvcj9BZXJvRWxlY3RyaWMtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAg LSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFp bGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0 cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0K ________________________________________________________________________________
Date: Nov 07, 2013
Subject: Copper sheet specs redux
I've had some direct emails asking about the selection of copper sheet for fabrication of bus bars. It seems that copper is sold in a market that adopted the Birmingham guage system as opposed to the Brown and Sharp tables common to the brass and aluminum markets. Then there's the stainless steel guys who have their own tables . . . sigh . . . This excerpt from a copper sheet gauge table illustrates the reason why our calculated weight earlier this morning was a bit different than the cited weight in the Ebay ad. The "48 oz" copper being offered was indeed a couple mils thicker than 1/16" thus explaining the difference. Emacs! When bussing breakers the maximum loads you might see on a bus bar can't be more than alternator rating. Assume 60A alternator. 10AWG wire example I cited earlier this morning has a cross section of 0.0082 sq-in. 10AWG round wire will produce a 10C rise with 30A of current flowing in it. If ALL alternator current is fed to the center of a one-piece bus bar and equally distributed to half the bus on each side, then the bus carries 30 A max, probably much less. A 16 Gauge copper buss bar (.065" thick) 1/2" wide has a copper cross section of .065 x .5 or 0.032 square inches. This is 4x larger than a 10AWG wire so we can expect temperature rise to be no more than 2.5 degrees C. Run all the current to one end of the bus bar such that the whole 60A flows through the copper. Heating value rises by the square of current. So 2x current is 4x heat or 4x temperature rise so we're back up to 10C max at end where the feeder is attached. The nice thing is that flat copper sheet will reject heat better than a round wire so the expected rise will be LESS than the round wire equivalent. Now, consider the same, 0.064" copper jumped between two contactor FAT wire terminals. Let's make the jumper 1" wide for 1/2 the resistance per inch of the bus bar example above. So 60A of alternator current would bring our rise down to 5C. Hit it with a 200A starter current for 3x current, 9x rise and the strip of copper could be expected to rise about 50C during cranking. But it's got more area than wire and is heat-sinked to the studs on either end so the heating will be less than 50C. Even less considering that most cranking intervals are but a few seconds . . . too short for the rise to stabilize. This little exercise suggests that .065" copper in 1/2" wide strips is just fine behind the panel . . . and 1" strips is okay between contactors, probably no more marginal for heat rejection than the starter itself. A piece of 1/8" copper would drop the 50C rise to 25C at 200A in 10AWG wire equivalents . . . MUCH more headroom. One could fabricate a thicker contactor-jumper from two layers of 1/16" copper. Get all the joints bright and clean. Torque the fasteners down tight. All will be right with the universe. Bob . . . ________________________________________________________________________________
Date: Nov 07, 2013
Hmmm, Your A&P school had it wrong. With pure copper, such as spark plug gaskets it makes zero difference whether you quench or not. Other metals are very different, but copper does not need quenching. http://en.wikipedia.org/wiki/Annealing_%28metallurgy%29 Quenching with most metals makes it harder, not softer. Copper again is an exception where quenching doesn't harden, but it doesn't soften either. On 11/7/2013 10:03 AM, Bill wrote: > I disagree with letting it "cool in air" */unless/* the alloys of > copper water-pipe and spark-plug gaskets differ significantly which I > doubt*.* > * > * > As a fledgling A&P in 1973 we were taught to heat copper spark-plug > gaskets to "cherry red" and */quench immediately in water/*. > I admit having no experience with allowing the gaskets to cool in air. > > Here's an EAA demo: > http://www.eaavideo.org/video.aspx?v=57437956001 > > Respectfully - > Bill > SF bay area > > On 7 November 2013 12:27, > you > wrote: > > I do the same, however, the copper tube (I use the stuff that > is used as water pipes in houses) is hard drawn and slightly > brittle. To get around that I use a small blowtorch to heat > it up until it glows red hot and then let it cool in air. > That anneals it and makes it softer and more resistant to > cracking and easier to form- like when you flatten it. > > * > > * ________________________________________________________________________________
Date: Nov 07, 2013
Hi Kelly - Likely it was a time consideration: quench instantly in water rather than gradually in air. BTW, water quenching wasn't learned in school. As a "fledgling A&P" I was a graduate, licensed and employed at an FBO/Repair Station (water quenching learned here). No matter, both systems work equally well. As I said initially below; "I admit having no experience with allowing the gaskets to cool in air". Now I know TWO systems. Thanks for the input - Bill On Thu, Nov 7, 2013 at 6:38 PM, Kelly McMullen wrote: > kellym(at)aviating.com> > > Hmmm, > Your A&P school had it wrong. With pure copper, such as spark plug gaskets > it makes zero difference whether you quench or not. > Other metals are very different, but copper does not need quenching. > http://en.wikipedia.org/wiki/Annealing_%28metallurgy%29 > Quenching with most metals makes it harder, not softer. Copper again is an > exception where quenching doesn't harden, but it doesn't soften either. > > On 11/7/2013 10:03 AM, Bill wrote: > >> I disagree with letting it "cool in air" */unless/* the alloys of copper >> water-pipe and spark-plug gaskets differ significantly which I doubt*.* >> * >> * >> As a fledgling A&P in 1973 we were taught to heat copper spark-plug >> gaskets to "cherry red" and */quench immediately in water/*. >> I admit having no experience with allowing the gaskets to cool in air. >> >> Here's an EAA demo: >> http://www.eaavideo.org/video.aspx?v=57437956001 >> >> Respectfully - >> Bill >> SF bay area >> >> On 7 November 2013 12:27, >> you >> wrote: >> >> I do the same, however, the copper tube (I use the stuff that >> is used as water pipes in houses) is hard drawn and slightly >> brittle. To get around that I use a small blowtorch to heat >> it up until it glows red hot and then let it cool in air. >> That anneals it and makes it softer and more resistant to >> cracking and easier to form- like when you flatten it. >> >> * >> >> * >> > > ________________________________________________________________________________
Date: Nov 07, 2013
Sure. I maintain enough extra gaskets that I put fresh ones on, the anneal the old ones at my leisure. I just string them on some old safety wire, heat, then let cool and they are ready for next plug servicing. On 11/7/2013 8:23 PM, Bill wrote: > Hi Kelly - > > Likely it was a time consideration: quench instantly in water rather > than gradually in air. > > BTW, water quenching wasn't learned in school. As a "fledgling A&P" I > was a graduate, licensed and employed at an FBO/Repair Station (water > quenching learned here). No matter, both systems work equally well. As > I said initially below; "I admit having no experience with allowing > the gaskets to cool in air". Now I know TWO systems. > > Thanks for the input - > Bill > > On Thu, Nov 7, 2013 at 6:38 PM, Kelly McMullen > wrote: > > > > > Hmmm, > Your A&P school had it wrong. With pure copper, such as spark plug > gaskets it makes zero difference whether you quench or not. > Other metals are very different, but copper does not need > quenching. http://en.wikipedia.org/wiki/Annealing_%28metallurgy%29 > Quenching with most metals makes it harder, not softer. Copper > again is an exception where quenching doesn't harden, but it > doesn't soften either. > > On 11/7/2013 10:03 AM, Bill wrote: > > I disagree with letting it "cool in air" */unless/* the alloys > of copper water-pipe and spark-plug gaskets differ > significantly which I doubt*.* > * > * > As a fledgling A&P in 1973 we were taught to heat copper > spark-plug gaskets to "cherry red" and */quench immediately in > water/*. > I admit having no experience with allowing the gaskets to cool > in air. > > Here's an EAA demo: > http://www.eaavideo.org/video.aspx?v=57437956001 > > Respectfully - > Bill > SF bay area > > On 7 November 2013 12:27, > you > wrote: > > I do the same, however, the copper tube (I use the > stuff that > is used as water pipes in houses) is hard drawn and > slightly > brittle. To get around that I use a small blowtorch > to heat > it up until it glows red hot and then let it cool in > air. That anneals it and makes it softer and more > resistant to > cracking and easier to form- like when you flatten it. > > * > > * > > > =================================== > om" target="_blank">www.aeroelectric.com > ooks.com" target="_blank">www.buildersbooks.com > et="_blank">www.homebuilthelp.com > et="_blank">www.mypilotstore.com > "_blank">www.mrrace.com > ="_blank">http://www.matronics.com/contribution > le, List Admin. > =================================== > -List" > target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > =================================== > http://forums.matronics.com > =================================== > > > * > > * ________________________________________________________________________________
Subject: Contactors
Date: Nov 08, 2013
Recommend you have either a battery contactor or manually operated battery switch. Yup, sounds like a good idea. For what it's worth there is an aircraft at my local field which uses the same automotive "cube" 70A relay that I'm using as a battery contactor. His engine is a Rotax 912 (the certified version although his a/c is not TC being of his own custom design). I measured the peak startup current this morning and it came to 110A, but the automotive relay seems to take this in its stride. The owner told me he's been running that way for 500 hours and 8 years without any problem. ________________________________________________________________________________
Date: Nov 08, 2013
Subject: Contactors
At 07:29 AM 11/8/2013, you wrote: > > Recommend you have either a battery contactor > or manually operated battery switch. > >Yup, sounds like a good idea. For what it's worth there is an aircraft at >my local field which uses the same automotive "cube" 70A relay that I'm >using as a battery contactor. His engine is a Rotax 912 (the certified >version although his a/c is not TC being of his own custom design). I >measured the peak startup current this morning and it came to 110A, but the >automotive relay seems to take this in its stride. The owner told me he's >been running that way for 500 hours and 8 years without any problem. The plastic 'cube' relays I've seen all feature fast-on tabs. The 70A versions too albeit larger ones. How do you make wired connections to this relay with robustness capable of carrying starter current? Can you take some pictures of the installations and post them? Bob . . . ________________________________________________________________________________
Subject: Re: Contactors
Date: Nov 09, 2013
On Nov 9, 2013, at 3:46, "Robert L. Nuckolls, III" <nuckolls.bob@aeroelectri c.com> wrote: > The plastic 'cube' relays I've seen all feature > fast-on tabs. The 70A versions too albeit larger > ones. How do you make wired connections to this > relay with robustness capable of carrying starter > current? Can you take some pictures of the installations > and post them? Yes the Faston tabs are 3/8" instead of the regular 1/4". Here's a pic I too k yesterday but its not easy to see how the connections are made on the cube . Sacha Note that he appears to be using something (on the left) that looks to me li ke a battery contactor in lieu of a starter contactor. The master contactor i s the red "384" series cube on the right. ________________________________________________________________________________
Date: Nov 09, 2013
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Minimizing audio interference
Date: Nov 10, 2013
I was going to post on VansAirforce in a thread about audio strobe noise, but decided to post here first to make sure that my post is accurate and correct. Let me know if it's not. Thanks, Joe Whenever current from separate loads shares the same conductor (wire or metal airframe), the current from one load can affect the current from another load. The interference can be minimized by: 1. Keeping the shared conductors as short as possible 2. Increasing the wire size of the shared conductor 3. Do not share a conductor with more than one load. 4. Keep the positive and negative conductors of the offending circuit together and twisted. If the microphone jack is not isolated from ground with insulating washers, then part of the mic current flows though the airframe which also carries current from other aircraft loads. This violates rule 3 above. The mic circuit is especially vulnerable because its signal gets amplified. If the strobe uses the airframe for the negative current path, this also violates rule 3 above. It is better to power the strobe with twisted positive and negative wires instead of using the airframe for the negative conductor. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412627#412627 ________________________________________________________________________________
Date: Nov 10, 2013
Subject: Re: Minimizing audio interference
At 07:59 AM 11/10/2013, you wrote: I was going to post on VansAirforce in a thread about audio strobe noise, but decided to post here first to make sure that my post is accurate and correct. Let me know if it's not. Thanks, Joe Whenever current from separate loads shares the same conductor (wire or metal airframe), the current from one load can affect the current from another load. The interference can be minimized by: 1. Keeping the shared conductors as short as possible Generally speaking, the only conductors that might be shared by an antagonist and potential victim are grounds . . . and grounding a victim onto a location already polluted with antagonistic perturbations is easily avoided with attention to the architecture of the ground system. See Figure Z-15 2. Increasing the wire size of the shared conductor Better yet . . . do not share . . . 3. Do not share a conductor with more than one load. . . . high on the list of design goals for the elegantly crafted airframe. 4. Keep the positive and negative conductors of the offending circuit together and twisted. Twisting speaks to magnetic coupling between antagonistic stimulus and potential victims. This coupling mode is weak. Further, it's unlikely that one finds it mechanically advantageous to route the wires for antagonists (generally airframe bundles) along with wires belonging to potential victims . . . generally situated on the panel. If the microphone jack is not isolated from ground with insulating washers, then part of the mic current flows though the airframe which also carries current from other aircraft loads. This violates rule 3 above. The mic circuit is especially vulnerable because its signal gets amplified. Yes If the strobe uses the airframe for the negative current path, this also violates rule 3 above. It is better to power the strobe with twisted positive and negative wires instead of using the airframe for the negative conductor. Not a great sin . . . the BIG guys ground nasty loads to airframes all the time. It's easy to craft TWO ground systems wherein the second is attentive to risks to potential victims. Noises from strobe systems heard on headphones and/or transmitted signals are almost always conducted by virtue of poor grounding choices for audio system wiring and rarely, radiated noises from strobe tubes into the co-located antennas. Wingtip mounted comm and vor antennas share this risk. Some avionics not designed in the spirit and intent of DO160 suggestions for immunity to bus noises may also exhibit vulnerability to strobes or other sources. This condition calls for adding filters to the victim's 14v supply. Bob . . . ________________________________________________________________________________
Date: Nov 10, 2013
> 3. Do not share a conductor with more than one load. > > . . . high on the list of design goals for the > elegantly crafted airframe. Am I right in assuming that this refers to properly fused wires from one of the busses and does not include the fat wires wich carry most if not all the loads in the aircraft. Roger -- Do you have a slow PC? Try a Free scan http://www.spamfighter.com/SLOW-PCfighter?cid=sigen ________________________________________________________________________________
Date: Nov 10, 2013
At 10:52 AM 11/10/2013, you wrote: 3. Do not share a conductor with more than one load. . . . high on the list of design goals for the elegantly crafted airframe. Am I right in assuming that this refers to properly fused wires from one of the busses and does not include the fat wires wich carry most if not all the loads in the aircraft. Obviously, everything in the airplane requiring power and ground will have a lot of conductors in common. It's known that some accessories tend to be antagonists (high currents, noisy, trashy voltage transients, strong RF emitters, etc.) while other things tend to be potential victims (stuff that processes tiny signals). We're getting off into the weeds with the 'shared conductors' terminology. When it comes to power distribution, all things electric 'share' conductors with each other. DO-160 or similar qualification protocols suggest means by which the most vulnerable of victims can get power from the noisiest of busses with little risk of difficulty. 99% of noise problems are founded on a very limited range of installation issues NONE of which have to do with twisting feeders, co-location of coax cables in wire bundles, or failure to include any sort of 'filter' on either a victim or antagonist . . . We've discussed the high order probabilities for noise in either transmitted or received signals when victim grounds that should be centralized on the panel get tied down somewhere else. A second order risk is seen when levels of transmitted RF rise to unusual levels in the vicinity of tha panel. This condition can present when the antenna is too close to the equipment installed . . . or a coax shield has detached in a connector causing the entire feedline to become a radiator. "Shared conductors" is not a good way to talk about a noise issue. You have a victim, an antagonist and a PROPAGATION MODE. Breaking the propagation mode is the path to noise-free Nirvana. Bob . . . ________________________________________________________________________________
Date: Nov 10, 2013
> "Shared conductors" is not a good way to talk > about a noise issue. What if we say that audio signals should not share conductors with other loads? An audio signal is unlikely to share a positive 12 volt wire. But many audio signals use ground as a common path in their circuit. A problem arises when other loads share the same ground conductor as the audio circuit. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412669#412669 ________________________________________________________________________________
Date: Nov 10, 2013
At 09:46 PM 11/10/2013, you wrote: > > > > "Shared conductors" is not a good way to talk > > about a noise issue. > >What if we say that audio signals should not share conductors with >other loads? An audio signal is unlikely to share a positive 12 >volt wire. But many audio signals use ground as a common path in >their circuit. A problem arises when other loads share the same >ground conductor as the audio circuit. >Joe "Audio signals" are not "loads". All devices in the airplane share a common 12v supply bus. Eventually, ALL grounds come together too. Study up on the 'ground loop' phenomenon illustrated in part here. http://tinyurl.com/6w87rvb The design task is to re-ground those devices marked Emacs! such that their shared grounds do not inject noises. Everybody needs a ground that's ultimately common with all other grounds. It's WHERE the grounds are placed and how they come together that produces the recipe for success. In the targets we used to build at Beech there were three ground systems. Power, analog and digital. Just as everything comes to ground at the forest of tabs in Figure Z-15, so too did all the grounds in the target come to a common point in the power distribution box . . . but what happened to them along the way determines their probability of offering in ingress point for noise into a potential victim. Bob . . . Bob . . . ________________________________________________________________________________
Date: Nov 11, 2013
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2013
I like it that Z15-3.1 shows not only the right way, but also the wrong way to ground devices. I understand that earphones and microphones should not be grounded locally, but should only be grounded at the panel end (intercom or radio). I am a little confused with the engine sensors. Grounding might be different for different types of sensors and their display (EMS or steam gauge). Some sensors are grounded automatically by nature of their construction and mounting. But for sensors that have isolated ground, I assume that the ground wire should terminate at the EMS or display device and not at the engine case. Of course always follow the manufactures installation instructions. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412750#412750 ________________________________________________________________________________
Date: Nov 11, 2013
Subject: Matronics Email Disruption Fixed...
Dear Listers, Starting around midnight this morning 11/11/13, the Matronics Barracuda spam filter that receives all incoming email from the Internet, developed a problem and started rejecting all incoming email. I just got off the phone with the Barracuda technical support and we have If you have posted to any of the Lists during this time, you will need to resend your email to the respective List. My apologies for the disruption! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: How does the Cessna Ground pwr socket work?
Date: Nov 11, 2013
Gents Just to be sure on how the Cessna (3-lug) ground power socket works: I followed figure Z-31A, where the third and thinner lug is connected to one of the contactor coil's terminal. Where does that thinner lug on the Cessna female socket gets power to energize the contactor's coil? Thanks Carlos ________________________________________________________________________________
Date: Nov 11, 2013
At 08:30 AM 11/11/2013, you wrote: > >I like it that Z15-3.1 shows not only the right way, but also the >wrong way to ground devices. I understand that earphones and >microphones should not be grounded locally, but should only be >grounded at the panel end (intercom or radio). > I am a little confused with the engine sensors. Grounding might > be different for different types of sensors and their display (EMS > or steam gauge). Some sensors are grounded automatically by nature > of their construction and mounting. Yes. Many oil pressure, oil temperature, CHT, EGT sensors are guilty of 'local grounding' . . . and for the manner in which they were originally intended to be used . . . it didnt' matter. > But for sensors that have isolated ground, I assume that the > ground wire should terminate at the EMS or display device and not > at the engine case. Of course always follow the manufactures > installation instructions. Oh, absolutely. But absent a end-to-end design goal, one has to play the DIY integration game. One useful way to deal with a locally grounded signal source looks like this: Emacs! There are low cost integrated circuits that do the task of making remote voltage measurements across hostile environments. Alternatively, one can take all grounds for the instrument to the crankcase. The same game is played in audio systems. I did the specification for design of an intercom system on the Lears that coupled all stations together by way of a transformer coupled, twisted pair . . . Intercoms scattered about the airplane could be grounded locally for power and control without the worry of noises on the ground- differences finding their way into the audio. Bob . . . ________________________________________________________________________________
Date: Nov 11, 2013
Subject: Re: How does the Cessna Ground pwr socket work?
At 12:22 PM 11/11/2013, you wrote: > > >Gents > >Just to be sure on how the Cessna (3-lug) ground power socket works: > >I followed figure Z-31A, where the third and thinner lug is connected to one >of the contactor coil's terminal. > >Where does that thinner lug on the Cessna female socket gets power to >energize the contactor's coil? > >Thanks >Carlos That ground power connector has been around for a very long time . . . it dates back to WWII or earlier. The latest version MS3506 http://tinyurl.com/nc6ybc3 replaced the earlier version AN2552 back in the 60s http://www.pilotshop.rs/media/catalog/product/cache/1/image/128 The 'skinny' pin is smaller because it's not intended to carry much current . . . generally no more than what's needed to close the ground power contactor in the airplane. It's very robust for that current level because ground power jacks on an airplane take a beating . . . a contact physically sized for 2A or so wouldn't last long in the all-weather flight-line fast-moving-line-boy environment. The real 'magic' of this pin is based on its length. It's shorter than the other two. As you push a hot plug into the jack, the two current carrying pins are electrically engaged before the pilot pin . . . this means that the power pins cannot be loaded before they are engaged for carrying the load. Similarly, when you pull the plug, the pilot pin will break first, open the ground power contactor and prevent arcing at the power pins should they happen to be loaded at the break. Next time you're at an FBO and can take a peek at their ground power plug . . . I think every one I've seen had blackened and arc-pitted power contacts. No doubt damaged by hot-plugging or hot-disconnecting under load where the supported vehicle did not have a ground power contactor. Bob . . . ________________________________________________________________________________
Date: Nov 11, 2013
> > >Where does that thinner lug on the Cessna female socket gets power to >energize the contactor's coil? Oops!! . . . didn't answer the question. The pilot pin is often jumpered to the (+) power pin right next to it. In some cases, the ground power source control panel wants to manage the ground power contactor in the vehicle so a 3rd wire is brought back to the source for extra attention. In any case, the pilot pin gets + voltage from the same source as the adjacent power pin. Bob . . . ________________________________________________________________________________
Date: Nov 12, 2013
Thanks Bob Both explanations were welcome. Got the general idea and the trick of the designer. Best Carlos -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: segunda-feira, 11 de Novembro de 2013 22:19 Subject: Re: AeroElectric-List: How does the Cessna Ground pwr socket work? --> > > >Where does that thinner lug on the Cessna female socket gets power to >energize the contactor's coil? Oops!! . . . didn't answer the question. The pilot pin is often jumpered to the (+) power pin right next to it. In some cases, the ground power source control panel wants to manage the ground power contactor in the vehicle so a 3rd wire is brought back to the source for extra attention. In any case, the pilot pin gets + voltage from the same source as the adjacent power pin. Bob . . . ________________________________________________________________________________
Subject: Replacement Crimpers
Date: Nov 11, 2013
Bob, I need to replace my long serving Paladin crimpers, not due to wear, rather someone else decided they needed them more than I do. One of my criteria for the replacement is the use of field swappable dies. Having read your writings on crimpers for use with the common wire terminals Id like your opinion on the following dies the first one the Sargent 4100-40 is the leader in my opinion http://www.stanleysupplyservices.com/sargent-4100-40-insulated-terminal-die-set-10-22awg-double-crimp/p/685-440 The following 2 are both in the same class as far as I can see, and not quite to the standard of the Sargent. They are the AMP BM-534 http://www.automationdirect.com/static/specs/dinwiring.pdf and the Paladin PA2035 die set http://www.tessco.com/products/displayProductInfo.do?sku=420434&eventPage=1 Thanks, Bill Higdon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412861#412861 ________________________________________________________________________________
Date: Nov 12, 2013
Bob N, for us neophytes, please enlighten us on the triangular device in your sketch. Best... Bob Verwey IO 470 A35 Bonanza ZU-DLW On 11 November 2013 21:05, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 08:30 AM 11/11/2013, you wrote: > > > I like it that Z15-3.1 shows not only the right way, but also the wrong > way to ground devices. I understand that earphones and microphones should > not be grounded locally, but should only be grounded at the panel end > (intercom or radio). > I am a little confused with the engine sensors. Grounding might be > different for different types of sensors and their display (EMS or steam > gauge). Some sensors are grounded automatically by nature of their > construction and mounting. > > > Yes. Many oil pressure, oil temperature, CHT, EGT sensors are > guilty of 'local grounding' . . . and for the manner in which they > were originally intended to be used . . . it didnt' matter. > > But for sensors that have isolated ground, I assume that the ground > wire should terminate at the EMS or display device and not at the engine > case. Of course always follow the manufactures installation instructions. > > > Oh, absolutely. But absent a end-to-end design goal, > one has to play the DIY integration game. One useful > way to deal with a locally grounded signal source > looks like this: > > [image: Emacs!] > There are low cost integrated circuits that do the > task of making remote voltage measurements across > hostile environments. Alternatively, one can take all > grounds for the instrument to the crankcase. The same > game is played in audio systems. I did the specification > for design of an intercom system on the Lears that > coupled all stations together by way of a transformer > coupled, twisted pair . . . Intercoms scattered about > the airplane could be grounded locally for power and > control without the worry of noises on the ground- > differences finding their way into the audio. > > Bob . . . > ________________________________________________________________________________
Date: Nov 12, 2013
I believe that is an Op Amp - see http://en.wikipedia.org/wiki/Operational_amplifier Jay From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob Verwey Sent: 12 November 2013 09:43 AM Subject: Re: AeroElectric-List: Re: Minimizing audio interference Bob N, for us neophytes, please enlighten us on the triangular device in your sketch. Best... Bob Verwey IO 470 A35 Bonanza ZU-DLW On 11 November 2013 21:05, Robert L. Nuckolls, III wrote: At 08:30 AM 11/11/2013, you wrote: I like it that Z15-3.1 shows not only the right way, but also the wrong way to ground devices. I understand that earphones and microphones should not be grounded locally, but should only be grounded at the panel end (intercom or radio). I am a little confused with the engine sensors. Grounding might be different for different types of sensors and their display (EMS or steam gauge). Some sensors are grounded automatically by nature of their construction and mounting. Yes. Many oil pressure, oil temperature, CHT, EGT sensors are guilty of 'local grounding' . . . and for the manner in which they were originally intended to be used . . . it didnt' matter. But for sensors that have isolated ground, I assume that the ground wire should terminate at the EMS or display device and not at the engine case. Of course always follow the manufactures installation instructions. Oh, absolutely. But absent a end-to-end design goal, one has to play the DIY integration game. One useful way to deal with a locally grounded signal source looks like this: Emacs! There are low cost integrated circuits that do the task of making remote voltage measurements across hostile environments. Alternatively, one can take all grounds for the instrument to the crankcase. The same game is played in audio systems. I did the specification for design of an intercom system on the Lears that coupled all stations together by way of a transformer coupled, twisted pair . . . Intercoms scattered about the airplane could be grounded locally for power and control without the worry of noises on the ground- differences finding their way into the audio. Bob . . . ________________________________________________________________________________
Subject: Ground Wire Routing; Compass Issues
Date: Nov 12, 2013
Bob and Listers, Here's a question for the group from a new guy. It's prompted by the recent discussion (and couple of weeks ago) about minimizing radio noise and compass deviation. What is the best routing for the ground wire from my instrument panel forest of tabs to the firewall single point ground? Airplane is a modified open cockpit 1951 DeHavilland Super Chipmunk (IO-540) rebuilt over the past 4 years. For the configuration think Pitts S-2C: radio stack between the rear seat pilot's knees, VFR round gages with a handful of electric instruments and a (planned) mini-iPad portable mounted on the sidewall. Firewall forward is pure Pitts clone. The new electrical system is pretty much finished (I hope!) except for neatening up and securing the wire bundles. System was tested incrementally and everything worked first try except an issue with the electric compass noted below. I stuck exactly to the Z-11 architecture and have followed the Connection and discussion among this group for a couple of years. Pretty much every component is B&C (with lots of great installation guidance from TJ). Wire routing: I put the main and e-bus fuse blocks under the radio/xponder with a big wire bundle running vertically up to the panel then fanning out to instruments and switches via 18-22 AWG wires. Battery, contactors, regulator and single point ground are at the firewall about 6 feet forward of the rear instrument panel and radio stack/fuse blocks. Component location and wire bundle routing (either left, right or centerline) from the firewall to the rear cockpit were aimed to keep everything shortest from point A to point B. Radio and transponder antenna coax run aft centerline from the radio stack under the control stick and pilot's seat, bundled with the power wires for the lights, strobes, fuel pump and a remote compass detector. The lights, strobes and fuel pump are the only devices grounded locally; everything else grounds at the firewall. My main question is about the 6 AWG panel ground wire: it runs from the forest of tabs behind the right side of the panel, up the right sidewall then under the floor to the firewall ground. It's WIDELY separated from the 6 AWG main power wire that runs straight down the middle from the battery contactor to the fuse blocks between the pilot's knees. Was that routing a bad decision? A possible rerouting to ensure a clean radio and minimal compass deviation (I may not always have the portable GPS): collocate/twist together the 6 AWG ground fat wire with the 6 AWG main power wire running fuselage center. To do so, I'd need to run a new and longer ground wire from the right side of the panel via the bundle of small power and ground wires to centerline, then down to the radio stack/fuse blocks where it can join up with the 6 AWG main power wire, then forward under the centerline floor to the firewall. Question is prompted by this helpful info from Sacha a couple of weeks back: ". if they're kept very close together (eg by twisting) then as long as you are at a distance D away from the pair, where D is much greater than d, then the magnetic field becomes very small. Typically d is of the order of a few millimeters so if you're eg a meter away, then D is hundreds of times greater than d and the magnetic field is for all intents and purposes zero." "D" for my routing of panel wires is about 3 inches behind the wet compass and remote compass indicator. There are lots of small ground wires mixed in with power wires in this bundle; some wires go to the switches and instruments and some to the ground forest of tabs. Would it help to just wrap the wet compass and remote detector with shielding and leave wire routing as is? The electric compass indicator is fed from a remote detector (flux valve? don't know) behind the pilot's head far from anything else electrical. It's not a gyro, just an indicator. It had negligible deviation and worked fine before the rebuild. Have not tested deviation now because the airplane is still on blocks in a steel hangar. But when powered up the indicator has a steady oscillation left and right about 10 degrees, about once per second..if it doesn't settle out when I get the airplane out in the open then I have another problem. Unfortunately for the compass I installed a steel rollover bar behind the pilot's head close to the remote detector, knowing I was likely introducing a compass problem but scored the rollbar as priority. Well, now it's time to think about the compasses. Perhaps I can move the remote detector farther away from the rollbar but it's old, big (5-6 inch diameter cylinder) and heavy so space and balance are issues. Perhaps I could buy a new and lightweight remote compass system but would rather keep the current functioning system. I have one more unrelated question but I'll save that for another email. I've appreciated the expertise of the group over the past couple of years of reading the conversations, and thank you in advance for your suggestions! Mark Meredith Super Chipmunk N7DW (Google "Super Chipmunk Restoration" for pics/story of the rebuild and airplane's interesting history) ________________________________________________________________________________
Date: Nov 12, 2013
At 03:43 AM 11/12/2013, you wrote: >I believe that is an Op Amp ' see >http://en.wikipedia.org/wiki/Operational_amplifier > >Jay > >http://www.matni.com/Arabic/Elec-Info/LM741%20DETAILS/philk2w.j > Jay is correct. The "operational amplifier" has a rich history in the evolution of electronics. Check out the articles on Wikipedia about George Philbrick, Bob Widlar, Jim Williams, and Bob Pease just to name a few of the colorful pioneers of the electronic arts and sciences. The op-amp comes in many flavors and sizes tailored to a constellation of tasks. I cut my op-amp teeth about 1962 on this vacuum tube version that sold for a couple hundred dollars in 2013 money . . . Emacs! http://www.matni.com/Arabic/Elec-Info/LM741%20DETAILS/philk2w.j I doubt that there were more than a few dozen products available. The last op-amp I stuck to a board looked like a little brick of plastic about the size of a match head . . . Emacs! . . . and costs about $2. The Digikey site offers over 30,000 variations on the theme. We've come a long way baby . . . Bob . . . ________________________________________________________________________________
Date: Nov 12, 2013
Subject: Re: Replacement Crimpers
At 08:46 PM 11/11/2013, you wrote: > >Bob, >I need to replace my long serving Paladin >crimpers, not due to wear, rather someone else >decided they needed them more than I do. One of >my criteria for the replacement is the use of >field swappable dies. Having read your writings >on crimpers for use with the common wire >terminals Id like your opinion on the >following dies the first one the Sargent 4100-40 is the leader in my opinion I'm not really in a position to offer useful information on the various products. I've evaluated a few tools and compared with the performance of my $high$ Amp crimpers . . . and found most to be satisfactory alternatives. I started to look at exchangeable die-sets a few years back but the cost of serviceable complete tools was so low that the idea of making one handle do lots of jobs wasn't very attractive. Further, the costs of loose die-sets is driven by volume of sales . . . seems that die-sets could easily approach the cost of a complete tool! Sorry I can't be more helpful . . . Bob . . . ________________________________________________________________________________
Date: Nov 12, 2013
Subject: Re: wiring assistance
At 02:48 PM 11/12/2013, you wrote: Bob, know this a long shot but i need assistance to finish wiring my Glasair. i am hoping you know someone over this way that i could contact. i was told that Greg Richter has done this sort of thing but i have been unable to contact him. had a guy who was supposed to assist me but he is too busy now. according to him i am only about 6 working hours away from being finished but i can't get him back. i am located in the middle of South Carolina. basically what needs to b done to finish the install is 6 circuit breakers and connect, finish the transponder harness (it's 90% done), finish the audio panel harness (it's 85% done), wire the new electric tach, rehookup the old engine instruments, and calibrate the new GRT Hxr w/autopilot. the airplane has now been down 5 months which is absolutely ridiculous. any direction and guidance would be most appreciated. thanks. Wince Holliday N745CW Wince, I am not personally aware of anyone in your neighborhood who might be helpful . . . I've posted your query to the aeroelectric-list. Perhaps someone on the list can help or knows somebody who can. Bob . . . ________________________________________________________________________________
Date: Nov 13, 2013
Subject: Please Make A List Contribution Today; Some Nice Comments...
Dear Listers, I've been getting some very nice comments from Listers along with their List Support Contributions. I've shared a number of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of really nice gifts available this year, so please browse the selections and pickup something fun with your qualifying Contribution! You may use a credit card or your PayPal account here: http://www.matronics.com/contribution Or feel free to send a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator -------------------- What Listers Are Saying About The Lists -------------------- I wondered off for a few years & am coming back. I firmly believe you provide greater value to us than some magazine subscriptions. William F Thanks for helping me connect to people have truly blazed the trail. Terry M Thank you for the time and effort you put into keeping these lists going. I am on the verge of flying my RV 8 and would not be here without the help of Matronics. Michael W Thank you for providing a valuable service. Vaughn T Matt I like your forums. Jerry D Thank you for another year of service. Oscar Z Been a "member" for years - this has been a fantastic resource and a great gift to the aviation community. Reade G Thanks for the many years of support to RV builders. Roy H Best run list on the net. Roger C Thanks for your excellent forum! Fred D Truly respect your work and service to many readers!! Fergus K Thanks for an ad-free list! William A Thank you for your GREAT service. I read it every day. John B ..great service! Ralph C Thanks so much for being there. Your contribution to aviation knowledge is invaluable. Benjamin B Thank you for providing the list service. It's great! William V I'd never have finished my Glasair without them. Ronald C Thank you Matt for the valuable forum, am pleased to contribute! Jeffrey J Fine service. Byron G Thanks for your support of our community! Kenneth B -------------------- What Listers Are Saying About The Lists -------------------- ________________________________________________________________________________
Date: Nov 13, 2013
Subject: Carling G-Series switch configuration
Here is the link to the Carling G-Series toggle switch data: http://www.carlingtech.com/sites/default/files/documents/Carling-TS-G-Series-Ext.pdf I find the switching descriptions unclear. I believe a 2GH51-73 is a standard toggle switch, with quick connect terminals that operates as an AeroElectric 2-10. Can anyone confirm that ? And how would the 2GG switch actually operate ? Thanks, Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Nov 14, 2013
Subject: Re: Carling G-Series switch configuration
At 09:42 PM 11/13/2013, you wrote: > >Here is the link to the Carling G-Series toggle switch data: >http://www.carlingtech.com/sites/default/files/documents/Carling-TS-G-Series-Ext.pdf > >I find the switching descriptions unclear. > >I believe a 2GH51-73 is a standard toggle switch, with quick connect >terminals that operates as an AeroElectric 2-10. Can anyone confirm >that ? The 2GH switch is form, fit and function equivalent to the 2-10 switch. Carling just has a funny (?) way of describing it's operation which should be simply described as 2-pole, on-on-on, progressive transfer. Emacs! The isn't clear as to which of the 6 tab positions on the switch are populated. I'm thinking that a 2GG switch is a 2GH with three of the six tabs simply left off. Another variation on the theme is the 2GE switch having only 4 tabs . . . two are jumpered together to fabricate a SP3T operation out of the box. My guess says you can do any of these three functions using a GH switch with simple choices of how the terminals are wired (or not). I wrote to them about this probably 20 years ago . . . no response. Hmmm . . . maybe they did respond and just didn't tell me about it. Just found this document on Carling that http://tinyurl.com/mxv8g2l This document confirms the suppositions cited above. Bob . . . ________________________________________________________________________________
Subject: Trim motor speed control
Date: Nov 14, 2013
I have two trim motors that I need to control. The motors provided are 24v motors (3-5amps). But they are intended for with a 12v electrical system. This is done because the 12v motors on a 12v system turn too fast and you keep overshooting when you try to adjust the trim. This is the elevator trim motor. http://www.grainger.com/product/WARNER-LINEAR-Linear-Actuator-18G685?s_pp=false But my electrical system is 24v. Which means the motors will turn too fast. I looked for 48v versions and they're either too expensive or not available at all. So I'm going to have to slow down the existing motors. And to that end, I have come up with 3 possibilities: 1) Put in a DC-DC step down converter. I can get one for about $250. But it is a rather large box that I'll have to mount somewhere and put in the necessary breakers and wiring. I may need 14v for other things in the future so this wouldn't be the worst solution. http://www.lonestaraviation.com/Step-Down-Conveter-24V-to-13.8-Volts.html 2) I had picked up a motor speed controllers for the heater fan speed controller. But it's only $10! You know the old saying about something being too good to be true? http://www.amazon.com/dp/B009HKFAIQ/ref=pe_385040_30332190_pe_175190_21431760_M3T1_ST1_dp_1 3) Finally, I could get a dedicated trim motor controller. But I would need their "HD" version and I would need two them... at $245 each for a $490 total. http://www.tcwtech.com/safety_trim.html I've pretty much removed option #2 because I have to think that there's this $10 solution either generates noise, is unreliable, or... something else. So the question(s) are: Does anyone have any experience with a situation like this and if so, which path did you chose? Or does anyone have any opinions on which would be the best solution? And finally, is there an option that I haven't considered? (and changing my entire electrical system to 14v is NOT an option) :) Thanks, Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413041#413041 ________________________________________________________________________________
Subject: Re: Trim motor speed control
Date: Nov 14, 2013
I would call TCW. I sent my Firgelli linear actuator (pitch trim) to them for approval. It was rated well over his specification, but in this application never sees much of a load. He approved it and it I'm using it now. I would recommend his trim controller for just the stuck trim switch over ride protection alone. Speed control is also available and 2 speeds if you want that. I'm not sure if they work with 28 v systems. Tim > On Nov 14, 2013, at 9:45 AM, "donjohnston" <don@velocity-xl.com> wrote: > > > I have two trim motors that I need to control. The motors provided are 24v motors (3-5amps). But they are intended for with a 12v electrical system. This is done because the 12v motors on a 12v system turn too fast and you keep overshooting when you try to adjust the trim. > > This is the elevator trim motor. > http://www.grainger.com/product/WARNER-LINEAR-Linear-Actuator-18G685?s_pp=false > > But my electrical system is 24v. Which means the motors will turn too fast. I looked for 48v versions and they're either too expensive or not available at all. So I'm going to have to slow down the existing motors. And to that end, I have come up with 3 possibilities: > > 1) Put in a DC-DC step down converter. I can get one for about $250. But it is a rather large box that I'll have to mount somewhere and put in the necessary breakers and wiring. I may need 14v for other things in the future so this wouldn't be the worst solution. > http://www.lonestaraviation.com/Step-Down-Conveter-24V-to-13.8-Volts.html > > 2) I had picked up a motor speed controllers for the heater fan speed controller. But it's only $10! You know the old saying about something being too good to be true? > http://www.amazon.com/dp/B009HKFAIQ/ref=pe_385040_30332190_pe_175190_21431760_M3T1_ST1_dp_1 > > 3) Finally, I could get a dedicated trim motor controller. But I would need their "HD" version and I would need two them... at $245 each for a $490 total. > http://www.tcwtech.com/safety_trim.html > > I've pretty much removed option #2 because I have to think that there's this $10 solution either generates noise, is unreliable, or... something else. > > So the question(s) are: Does anyone have any experience with a situation like this and if so, which path did you chose? Or does anyone have any opinions on which would be the best solution? And finally, is there an option that I haven't considered? (and changing my entire electrical system to 14v is NOT an option) :) > > Thanks, > Don > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413041#413041 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 14, 2013
At 11:45 AM 11/14/2013, you wrote: I have two trim motors that I need to control. The motors provided are 24v motors (3-5amps). But they are intended for with a 12v electrical system. This is done because the 12v motors on a 12v system turn too fast and you keep overshooting when you try to adjust the trim. This is the elevator trim motor. http://www.grainger.com/product/WARNER-LINEAR-Linear-Actuator-18G685?s_pp=false First, why such a 'horse' of an actuator? What are the force, speed and travel requirements for moving the trim mechanism on your airplane? But my electrical system is 24v. Which means the motors will turn too fast. I looked for 48v versions and they're either too expensive or not available at all. So I'm going to have to slow down the existing motors. And to that end, I have come up with 3 possibilities: With a full load current rating of 2.3A (assuming that it's moving a 100# load), your voltage control task is pretty simple. But with a PM motor, inrush current is pretty high compared to the 2.3A max running load. 1) Put in a DC-DC step down converter. I can get one for about $250. But it is a rather large box that I'll have to mount somewhere and put in the necessary breakers and wiring. I may need 14v for other things in the future so this wouldn't be the worst solution.' How about this one? Rated for 8A (plenty of headroom) but in addition to an adjustable output voltage (controls speed) there's an adjustable current limit (controls inrush). Use this dc/dc converter upstream of your dpdt center off polarity control switch. Set voltage for max desired speed. Then set the current limit to some benign value well above max rated load for the actuator . . . say 3A. Bob . . . ________________________________________________________________________________
Date: Nov 14, 2013
Emacs! Bob . . . ________________________________________________________________________________
Date: Nov 14, 2013
Don, Agree with the others about the heftiness of your actuators. 100 pounds and 4 inch travel sounds like something for a jet. Finding a lower current actuator would ease your problem. But assuming you can't change actuators, here is a full featured 2 axis trim controller: Start with the circuit published in the June 2013 issue of Kitplanes (schematic attached). Modify the circuit to use an LM338 (40 volt, 5 amp, 7 amp surge, $2.03 from Mouser) instead of the LM317 shown. Power the low current logic part of the circuit with a separate regulator (LM317) set to supply 12 volts. The heat sink specified is more than adequate for both jobs. This gives you all the features of the fanciest commercial controllers for less than $35 in parts. If you do not have access to the Kitplanes issue email me off list for a set of figures, photos and text. Tom ________________________________________________________________________________
Date: Nov 14, 2013
My link to the suggested power supply didn't paste . . . her 'tis again. > How about this one? http://tinyurl.com/mk6vs4l > Rated for 8A (plenty of headroom) but > in addition to an adjustable output voltage > (controls speed) there's an adjustable > current limit (controls inrush). > > Use this dc/dc converter upstream of your > dpdt center off polarity control switch. > Set voltage for max desired speed. Then > set the current limit to some benign value > well above max rated load for the actuator . . . > say 3A. > > > Bob . . . > > >----- >No virus found in this message. >Checked by AVG - www.avg.com Bob . . . ________________________________________________________________________________
Date: Nov 14, 2013
Subject: re: wire routing
> > > "D" for my routing of panel wires is about 3 inches > behind the wet compass and remote compass indicator. There are > lots of small ground wires mixed in with power wires in this > bundle; some wires go to the switches and instruments and some to > the ground forest of tabs. Would it help to just wrap the wet > compass and remote detector with shielding and leave wire routing as is? Most of the situation you describe does not raise concerns for large effects on a compass except wires routed within inches of the wet compass. While still inside the hangar, you probably can't gage the effects of these wires. You will probably have to wait until you get outside. The magnitude and direction of interference will vary with orientation of the fuselage . . . i.e. compass 'heading'. Back in the old days of panel mounted radios with harnesses carrying perhaps 5A, it was not uncommon to see several degrees of error injected onto a compass reading when a radio was turned ON/OFF. An SD-20 alternator on the back of an engine had enough external field leakage to deflect the magnetic compass 10-15 degrees on some headings. That was 'fixed' with moving the compass from a point on the glare shield onto the windshield. Just raising the compass 12" or so reduced the effects to 'acceptable'. There's no way to accurately predict deleterious effects for the situation you describe . . . it's a try-it-and-see situation. Bob . . . ________________________________________________________________________________
Date: Nov 14, 2013
> > > This is the elevator trim motor. > > http://www.grainger.com/product/WARNER-LINEAR-Linear-Actuator-18G685?s_pp=false > > > First, why such a 'horse' of an actuator? > What are the force, speed and travel requirements > for moving the trim mechanism on your airplane? > One word... Canard. :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413053#413053 ________________________________________________________________________________
Date: Nov 14, 2013
Don, << why such a 'horse' of an actuator? ... One word... Canard. >> Must confess to still being confused. My Defiant had very light control forces which were still heavier than any Eze I've seen. Assume you are planning to use springs and not aerodynamic trim tabs? Could you supply more information? Tom ________________________________________________________________________________
Date: Nov 15, 2013
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2013
The aircraft is a Velocity XL. The trim motor is the one supplied by the factory. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413138#413138 ________________________________________________________________________________
Date: Nov 15, 2013
The aircraft is a Velocity XL. The trim motor is the one supplied by the factory. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413139#413139 ________________________________________________________________________________
Date: Nov 15, 2013
2GH _ _ _ _CIRCUIT 1 ON_ _ _ _2 CIRCUITS ON_ _ _ _ CIRCUIT 2 ON 2GG _ _ _ 2 CIRCUITS ON _ _ _ CIRCUIT 1 ON _ _ _ OFF The above is quoted from the Carlingswitch data sheet. I interpret this to mean that 2GH is always on, either circuit 1 or circuit 2 is on, or both are on. And 2GG is similar to the 2-10 switch. It can be off, or circuit 1 on, or both circuits 1 & 2 on. It is hard to know for sure without having the switch in hand. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413141#413141 ________________________________________________________________________________
Date: Nov 15, 2013
Motor Speed Control-- An important point of trim motor speed controlling is that the torque should not be reduced when the speed is reduced (in fact, it could go up...but not down). This makes regular voltage controllers undesirable except where torque isn't an issue. The second point is that trim speed should usually be reduced as a function of airspeed. Often this is critical and can give the pilot sudden difficulties. Tee-ing off the pitot line and using the pressure signal is easy to do. Many speed controls use an LM3524 modulating PWM chip and a P-fet to drive the trim motor that will take a voltage-input based on the pitot pressure. This makes the motor go faster at slow speeds and slower at high speeds. No input from the pilot is needed. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413143#413143 ________________________________________________________________________________
Subject: Switch S700 2-11
Date: Nov 15, 2013
Bob, I am looking for a switch that has three potions (Off/On/On). B&C has a switch S700 2-11 which is shown as On/On/Off but does not have a diagram which shows how this switch is wired. Can you provide a schematic of this switch? Mike Marker -------- Mike Marker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413150#413150 ________________________________________________________________________________
Date: Nov 15, 2013
11/15/2013 Hello Don, Thanks for the quick response. I=92ve got the picture. Take a look at the Firgelli Automations FA-SC24 Actuator Speed Controller seen here: http://www.firgelliauto.com/product_info.php?cPath=99&products_id=362 Note the the 12V to 40V operating range. OC ==== From: Don Johnston Sent: Friday, November 15, 2013 10:36 AM Subject: Re: Trim motor speed control Owen, Thanks for reaching out to me. The aircraft is a Velocity-XL. I am trimming a canard-width elevator. I have been told by the factory and other builders that existing trim is right at the upper limit of usable speed. The trim motor is connected to a fiberglass leaf spring. Fon Sent from my Android mobile device. ________________________________________________________________________________
Date: Nov 15, 2013
Subject: Re: Switch S700 2-11
At 10:42 AM 11/15/2013, you wrote: > >Bob, > >I am looking for a switch that has three potions (Off/On/On). B&C >has a switch S700 2-11 which is shown as On/On/Off but does not have >a diagram which shows how this switch is wired. Can you provide a >schematic of this switch? What are you trying to do? You can wire an on-on-on to be off/on/on by simply leaving one terminal unused. Bob . . . ________________________________________________________________________________
Date: Nov 15, 2013
At 07:56 AM 11/15/2013, you wrote: > >Motor Speed Control-- > >An important point of trim motor speed controlling is that the >torque should not be reduced when the speed is reduced (in fact, it >could go up...but not down). This makes regular voltage controllers >undesirable except where torque isn't an issue. Not true. Speed and torque are not directly related in terms of motor performance. Speed of a motor is a function of terminal voltage AND load on the motor. Torque requirement for moving a flight control surface is a function of aero-dynamic loads. For example, the average torque needed to extend a flap from 0-10 degrees is often a small fraction of that required to push it all the way out to 30 degrees. Assuming one wishes to slow flap motion as it approaches fully deployed, there is risk of having the motor STALL under some conditions of load . . . the risk is a function of motor resistance and a REDUCTION in available torque at voltages intended to simply slow it down. It has NOTHING to do with the manner in which voltage is controlled. You can set the terminal voltage of the motor by means of regulated power supply, battery, PWM controller, variable resistor, you name it. As long as you're holding the motor voltage constant, then it's possible to experience an unintended STALL which is illustrated in the following plot of an exemplar motor's performance in a pitch trim actuator. Emacs! Folks that would like to explore all the details of my assertion are invited to download the data package at http://aeroelectric.com/articles/Motors The figure above is an excerpt from one of the figures in that data package. In high speed trim, applied voltage was 26.5 volts which means that for ALL other conditions, the motor speed can be predicted right off the plots. Aerodynamic loads reflected to the motor ranged from .72 oz-in to 1.82 oz-in. With high speed voltage applied, the motor can be expected to run someplace between 3870 and 5304 rpm for a variation of +/- 16%. With low speed voltage applied, the same motor's speed variance from center was predicted to be +/- 100 percent . . . with the motor stalling at max loads. The data package speaks to the characterization of motor stall current as (Eapplied-Ecemf)/Resistance of the motor. Motors being operated at FIXED voltages appear to 'lose torque' because their speed regulation is terrible compared to the higher speed operation. Note that torque-current demand on the motor at say 1.5 oz-in is exactly the same irrespective of speed (applied voltage). The motor appears 'crippled' because the SAME variations in current (CAB) over designed torque range is a LARGER PERCENTAGE of motor's predictable behavior at the lower speed (FDE). Virtually ALL voltage control methodologies popular with the OBAM aviation community are simply modifications to applied voltage. The seemingly 'crippled' behavior of the motor will be the same no matter HOW that voltage is adjusted. LM317, pwm . . . you pick it. There ARE ways to close the loop on speed control by sensing motor current and inserting a derived correction of speed by increasing terminal voltage as load increases . . . or by sensing motor speed with some form of tachometer and closing the loop on measured speed. Assertions for expecting loads on a motor to go UP as shaft speed goes down are incorrect, the flight surface has no way to know that it's moving slower . . . it IS influenced only by change of dynamic pressure and moment arms. >The second point is that trim speed should usually be reduced as a >function of airspeed. Often this is critical and can give the pilot >sudden difficulties. Tee-ing off the pitot line and using the >pressure signal is easy to do. I've designed a number of pitch trim controllers. The first two went on the Lear 55 and the second was a fleet retrofit to the 30 series. I proposed a continuously variable pitch trim rate based on IAS but it proved unnecessary. Trim rates optimized for cruising flight fell into one fairly narrow range, speeds for approach to landing in another narrow range. Turns out that approach:cruise trims in the Lear systems were 4:1 ratio. Use a flaps-not-stowed switch to select high speed and we were done. Bob . . . ________________________________________________________________________________
Date: Nov 15, 2013
At 11:46 AM 11/15/2013, you wrote: >11/15/2013 > >Hello Don, Thanks for the quick response. I've got the picture. Take >a look at the Firgelli Automations FA-SC24 Actuator Speed Controller seen here: > ><http://www.firgelliauto.com/product_info.php?cPath=99&products_id=362>http://www.firgelliauto.com/product_info.php?cPath=99&products_id=362 > >Note the the 12V to 40V operating range. Note also the notation: The FA-SC24 is intended to control the speed of one Linear actuator or motor, Do not connect two actuators/motors to the same FA-SC24. The slowest the actuator/motor will run is about 10% of the full speed. Reducing the speed can affect the maximum load the actuator can move. Motor current is proportional to load torque at any speed. There will come a time as voltage falls that STALL torque (Eapplied/Resistance of Motor) is some number smaller than load torque and the motor stalls. The load torque doesn't rise because the speed went down; ability to CARRY rated torque fell off because stall current came down proportionally with the drop in applied voltage. If we could wind the motor with unobtainium having zero resistance, the speed torque curve would not have that left-to-right, downward slope . . . it would be flat. This means that speed is absolutely locked to applied voltage no matter what load is applied. The same motor would be 100% efficient because it doesn't get hot! I've worked with designs that deliberately picked a too-large motor with lower values of internal resistance just to get a flatter speed-torque curve without use of external electronic controls. Bob . . . ________________________________________________________________________________
Date: Nov 15, 2013
Bob, I want to wire my electronic ignition switch such that to can select the Main or Aux battery bus (Off/Aux Bus/Main Bus). The drawing depicts what I'm thinking. I'm not sure that the S700 2-11 is internally wired as depicted...that is why I asked for clarification on the switch configuration. I also want to use this switch for a pulsed landing light (Off/On Steady/Pulsed) Mike Marker -------- Mike Marker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413171#413171 Attachments: http://forums.matronics.com//files/ign_sw_184.jpg ________________________________________________________________________________
Date: Nov 15, 2013
At 03:08 PM 11/15/2013, you wrote: > >Bob, > >I want to wire my electronic ignition switch such that to can select >the Main or Aux battery bus (Off/Aux Bus/Main Bus). The drawing >depicts what I'm thinking. I'm not sure that the S700 2-11 is >internally wired as depicted...that is why I asked for clarification >on the switch configuration. > >I also want to use this switch for a pulsed landing light (Off/On >Steady/Pulsed) The S700-2-10 switch can be wired for single pole three postion as shown below . . . just leave the lower throw terminal (3)unhooked and you get the desired behavior. Emacs! Bob . . . ________________________________________________________________________________
Subject: Re: Battery contactor failure
From: "anthonyharding" <anthonyharding41(at)gmail.com>
Date: Nov 15, 2013
Often this is a great time to install Battery Master Switch...Well then the main battery starter cable through the car is Dead after start up....So i gives a better suggestion you can used the well batteries and you can found the well shop at : http://www.johnslittlegadgetstore.com.au/.. Thanks.. -------- anthony harding Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413193#413193 ________________________________________________________________________________
Date: Nov 16, 2013
Thanks Bob! I made several failed attempts to figure out how to wire the S700 2-10 switch to perform desired function...but you drawing makes it obvious. So I'll be using the 2-10. Mike Marker -------- Mike Marker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413201#413201 ________________________________________________________________________________
Date: Nov 16, 2013
At 09:37 AM 11/16/2013, you wrote: > >Thanks Bob! I made several failed attempts to figure out how to >wire the S700 2-10 switch to perform desired function...but you >drawing makes it obvious. So I'll be using the 2-10. The 2-11 nomenclature is not carried over from the mil-specs like the other dash numbers. I think B&C added this callout to describe one of the variants of the 2-10 . . . which are fundamentally unnecessary since the 2-10 can be wired to accomplish the same tasks. Bob . . . ________________________________________________________________________________
Date: Nov 18, 2013
Subject: Fund Raiser Behind By 25% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 25%. We got off to a slow start this year with the network DNS issues on the kickoff weekend, so please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 18, 2013
Subject: Questions about Z-08
Bob,=0A-=0AIn the postings on running an alternator without a battery, yo u suggested I consider your new draft Z-08, which is buried in the long str eam on "EXP 2 Bus workaround."- The more I look at Z-08, the more I like the simplicity.- It seems to meet most of my design goals, but answers to a few questions would be helpful.=0A-=0A1.- What were your criteria in deciding to connect "Engine A" with a switch (1-3) and "Engine B" through a relay?- By the way, what does the "K2" inside a green hexagon indicate on the relays?=0A-=0A2.- You show both A and B connected to the "Motive Power Distribution Bus"-through a single stud and bolt connector.- I'v e read that lock washers do little to prevent a bolt from loosening.- Wha t do you do to give this type of connection the reliability one needs for c ritical components?- Or can we?- Wouldn't a different connection for A and B-be prudent?-=0A-=0A3.- With respect to screw type connectors, what about the ground connection to the-engine block?- The high vibrat ion of a running engine would seem to make these especially susceptible to loosening.- What about two block connections going to two brass bolts thr ough the firewall ground bus, or would this set up an electrically noisy gr ound loop?=0A-=0A4.- I found your discussions about single versus dual batteries and properly maintaining batteries to be interesting.- Since, a s I mentioned in an earlier post, I've experienced a car battery shorting w hile I was driving.- I accurately interpreted the limited info and stoppe d the car in a convenient place.- Yes, the battery did not get the kind o f attention you have suggested.- But will the next owner of my plane be a s conscientious as me?- So, what is the downside of changing the DC Power Master from OFF/BAT/BAT+ALT to OFF/ALT/ALT+BAT, assuming that ALT FIELD ca n be disconnected if the alternator needs to be disconnected?- If I did s o, I would use an MGL Battery Monitor to see both voltage and current acros s the battery.=0A-=0AI appreciate your approach to challenging people lik e me to think through our decisions.- Great forum?- Thanks.=0A=0ATom=0A =0AThomas E. Blejwas=0A12 Via Entrada=0ASandia Park, NM 87047=0A505-286-929 4=0Atomblejwas(at)yahoo.com ________________________________________________________________________________
Date: Nov 18, 2013
EMJ said: An important point of trim motor speed controlling is that the torque should not be reduced when the speed is reduced (in fact, it could go up...but not down). This makes regular voltage controllers undesirable except where torque isn't an issue. BN said: Not true. Speed and torque are not directly related in terms of motor performance. Speed of a motor is a function of terminal voltage AND load on the motor. EMJ said: Thats absurd and examples are so trivial I wont even bother to note one. Besides, I didnt say they were related. The point is that motor speed for trimming and flaps should be reduced at high airspeed to prevent overstressing the pilot and the aircraft. This is common practice. I didnt invent this idea. Furthermore reducing the voltage is a poor mans way to reduce the speed of any actuator. I didn't invent that idea either. BN said: Torque requirement for moving a flight control surface is a function of aero-dynamic loads. For example, the average torque needed to extend a flap from 0-10 degrees is often a small fraction of that required to push it all the way out to 30 degrees. Folks that would like to explore all the details of my assertion are invited to download the data package at http://aeroelectric.com/articles/Motors .... Virtually ALL voltage control methodologies popular with the OBAM aviation community are simply modifications to applied voltage. EMJ said: And they are all wrong. Start with yours. The modern methods for changing motor speed without reducing torque as I saidshould be used. BN said: Assertions for expecting loads on a motor to go UP as shaft speed goes down are incorrect EMJ said: And WHO said that Bob? I said the torque should not be reduced as the motor speed decreasesas is the case if the voltage is merely reduced. EMJ said: The second point is that trim speed should usually be reduced as a function of airspeed. Often this is critical and can give the pilot sudden difficulties. Tee-ing off the pitot line and using the pressure signal is easy to do. BN said: I've designed a number of pitch trim controllers. The first two went on the Lear 55 and the second was a fleet retrofit to the 30 series. I proposed a continuously variable pitch trim rate based on IAS but it proved unnecessary. Trim rates optimized for cruising flight fell into one fairly narrow range, speeds for approach to landing in another narrow range. Turns out that approach: cruise trims in the Lear systems were 4:1 ratio. Use a flaps-not-stowed switch to select high speed and we were done. EMJ said: Whatever... but Im not sure Learjet experience (where the amount of trim motion needed at 500 knots is tiny and the motor are big) is relevant for the stock RVs that have speed/trim problems using reduced voltage at high airspeeds. Thanks...the loyal (occasional) opposition. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413380#413380 ________________________________________________________________________________
Date: Nov 18, 2013
At 02:52 PM 11/18/2013, you wrote: > >EMJ said: An important point of trim motor speed >controlling is that the torque should not be >reduced when the speed is reduced (in fact, it >could go up...but not down). This makes regular >voltage controllers undesirable except where torque isn't an issue. Help me out. Are you talking about available torque or demanded torque? In the examples I cited and data plots published, torque demanded is a function of the mechanism being powered. I'm aware of no piece of machinery that demands more torque as the speed is reduced. A speed/torque 'curve' is not really curved but a straight line that depicts motor speed/torque performance based on terminal voltage applied. The 'curve' has downward slope and is set by the motor's internal resistance. Internal resistance limits AVAILABLE torque at that voltage. My assertion is that for any applied voltage you choose, performance of the motor is predictable and easily illustrated by plotting the appropriate 'curve'. >EMJ said: And they are all wrong. Start with >yours. The modern methods for changing motor >speed without reducing torque as I saidshould be used. Okay, suppose the target speed is satisfied by reducing applied voltage to say, 5 volts. Describe the mechanism by which a motor's performance is improved by using one form of voltage 'adjustment' over some other form. I.e., what is the "modern method" to which you refer? >EMJ said: And WHO said that Bob? I said the >torque should not be reduced as the motor speed >decreasesas is the case if the voltage is merely reduced. Okay, you've answered the question. My apologies. Yes, AVAILABLE torque can be degraded to the point where a motor is at risk for stalling at the lower extreme of RPM vs. available torque for the voltage applied. My assertion is that 5 volts average applied voltage produces the same performance irrespective of the mechanism by which that voltage is produced. >EMJ said: Whatever... but Im not sure Learjet >experience (where the amount of trim motion >needed at 500 knots is tiny and the motor are >big) is relevant for the stock RVs that have >speed/trim problems using reduced voltage at high airspeeds. No argument that adjustable trim rates for aircraft with broader operating speeds is a good thing and may apply to airplanes of any size . . . Pilots would like to ask for and get very tiny movements in the trim system at cruise. If the motor speed is optimized for that condition, then it's painfully slow for setting the airplane up to land. The idea that there was value in crafting a continuously adjustable trim rate was rejected as unnecessarily complex. Lear's pilots were quite happy with the 4:1 ratio. Trim motor motion on a Beechjet at Mach cruise needed to be so small that servoing to a speed was impossible. The smallest trim adjustment offered by the autopilot is a mere 133 milliseconds long. The Lear systems were SERVOed speed controllers where motor characteristics did not impact available torque from the motors. Voltage was adjusted to hold target speed irrespective of voltage or load. The controller that finally went onto the airplanes held +/- 1% of target speed over the full range of load, voltage and temperature. In the Lear system, tachometers on the motor shafts provided speed feedback data. The motors used in OBAM aircraft are seldom fitted with such devices. The PM motor CAN be used as it's own tach generator. If you PWM the applied voltage 0ne can sample the Cemf of the motor and use that value to report motor speed to the servo-loop. With a servoed speed control loop, the motor's speed/torque curve no longer defines performance limits at slow speed. The controller drives voltage to maintain target speed even at the maximum expected load. Bob . . . ________________________________________________________________________________
Date: Nov 18, 2013
Subject: Re: Questions about Z-08
At 01:57 PM 11/18/2013, you wrote: >Bob, > >In the postings on running an alternator without a battery, you >suggested I consider your new draft Z-08, which is buried in the >long stream on "EXP 2 Bus workaround." The more I look at Z-08, the >more I like the simplicity. It seems to meet most of my design >goals, but answers to a few questions would be helpful. > >1. What were your criteria in deciding to connect "Engine A" with a >switch (1-3) and "Engine B" through a relay? the wires associated with "A" go mostly cold with opening the battery contactor. The relay is a 'mini contactor' located adjacent to the battery hence the contactor control switch "B" on the panel > By the way, what does the "K2" inside a green hexagon indicate on > the relays? Artifact reference designators not yet germane to the drawing. > >2. You show both A and B connected to the "Motive Power >Distribution Bus" through a single stud and bolt connector. I've >read that lock washers do little to prevent a bolt from >loosening. What do you do to give this type of connection the >reliability one needs for critical components? Or can we? Wouldn't >a different connection for A and B be prudent? The fuseblock connection is a stud that can be secured with a locking nut . . . unlike headed screws that engage threaded holes on popular terminal strips. > >3. With respect to screw type connectors, what about the ground >connection to the engine block? The high vibration of a running >engine would seem to make these especially susceptible to >loosening. What about two block connections going to two brass >bolts through the firewall ground bus, or would this set up an >electrically noisy ground loop? You could use two straps to the engine if you wish . . . but some thread-locker on the single bolt would secure it. Vibration is not an automatic loosening force on a threaded fastener . . . it's mass who's cg is not centered on the bolt that provides loosening torque due to vibration. In this case, a terminal on a soft piece of wire or braid doesn't offer a significant mass. > >4. I found your discussions about single versus dual batteries and >properly maintaining batteries to be interesting. Since, as I >mentioned in an earlier post, I've experienced a car battery >shorting while I was driving. I accurately interpreted the limited >info and stopped the car in a convenient place. Yes, the battery >did not get the kind of attention you have suggested. But will the >next owner of my plane be as conscientious as me? It should be noted in your POH/Maintenance documents. There are numerous critical structures that receive annual and/or pre-flight inspection. Adding the battery(ies) to such a list isn't a far-fetched idea. > So, what is the downside of changing the DC Power Master from > OFF/BAT/BAT+ALT to OFF/ALT/ALT+BAT, assuming that ALT FIELD can be > disconnected if the alternator needs to be disconnected? If I did > so, I would use an MGL Battery Monitor to see both voltage and > current across the battery. With the crowbar ov protection, you could do the DC power switching as a simple two-pole, on-off device. You can pull the breaker to kill the altenrator field circuit. > >I appreciate your approach to challenging people like me to think >through our decisions. Great forum? Thanks. > I'm pleased that you find value in the exercise. I believe that the attentive builder is a much lower-risk pilot because he is privy to things our flight instructors never told us . . . or were included in the cookie-cutter POH. Bob . . . ________________________________________________________________________________
Subject: Re: EXP 2 Bus workaround
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Nov 19, 2013
Fred, I think we left this study dangling for lack of a list of proposed loads on your ship's bus structures. Have you had time to consider this? Doesn't need to be a drawing, just a text listing of each load . . . perhaps grouped by supply bus. Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413418#413418 ________________________________________________________________________________
Subject: Wow!...it's really going to happen.
Date: Nov 19, 2013
http://www.youtube.com/watch?v=cMaprpJKcls Pretty exciting stuff. Think of the area, internal and external, of a composite airframe, including spars, ribs, bulkheads...a flying battery. ________________________________________________________________________________
Date: Nov 19, 2013
Subject: Roll Servo Wiring for RV-10
Hi all, I am trying to get my wings closed up on my RV-10, but I would like to get all the wiring in first if possible. I haven't decided on an autopilot yet, but I was wondering if the roll servos that are out there would use a more or less similar wiring harness. If, for example, I got a SteinAir wiring harness for a Trutrak servo, would it be compatible with another AP? I guess I don't know how many different servos there are, do different AP's use basically the same servos? Kent ________________________________________________________________________________
Subject: Re: Roll Servo Wiring for RV-10
Date: Nov 19, 2013
You may be able to use the same wires perhaps relocating a few pins but the s ervos differ depending on which autopilot you use. I switched from a blue m ountain system to a truetrac and was able to use the same wires already inst alled just had to relocate the pins. Sent from my iPad On Nov 19, 2013, at 11:36 AM, "Kent Ogden" wrote: > Hi all, > > I am trying to get my wings closed up on my RV-10, but I would like to get all the wiring in first if possible. I haven't decided on an autopilot yet , but I was wondering if the roll servos that are out there would use a more or less similar wiring harness. If, for example, I got a SteinAir wiring h arness for a Trutrak servo, would it be compatible with another AP? I guess I don't know how many different servos there are, do different AP's use bas ically the same servos? > > Kent > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ________________________________________________________________________________
Date: Nov 19, 2013
Subject: Garmin Database Question.
Good Morning All, This is not particularly Aero Electric specific, but many of us do use either the GNS 430 or the 530 for navigation. I often play with the Garmin simulator so that maybe someday I will get good enough to use ten per cent of the capability instead of only five percent. Along that line, it would be nice to have a more current database than what Garmin supplies free. They are now using a 2007 based data bank. A year ago or so, someone posted a method whereby we could update the database on the free simulator. I tried that last spring and it worked great. However, I lost the procedure and would like to install a new update. Do any of you know how to do the update? Or, does anyone remember who posted the procedure? Sure wish I could find that old procedure. Happy Skies, Old Bob Stearman N3977A LL22 Downers Grove, IL ________________________________________________________________________________
Subject: USB pinouts
Date: Nov 19, 2013
I looked up the pinouts for a USB port on Wikipedia and ended up confused. They label pin 2 & 3 as data - and data + respectively. I need to know which is data transmit and data receive. Any help would be appreciated. I also don't like the 24ga wires included with the plug. Are there any USB plugs that I can add on my own wires or have 22ga wires? Thanks, Sheldon Olesen Sent from my iPad ________________________________________________________________________________
Date: Nov 19, 2013
Subject: Re: Garmin Database Question.
Bob, Check out this thread... http://www.vansairforce.com/community/showthread.php?t=76306 Not sure if it still applies. On 11/19/13, 10:49 AM, BobsV35B(at)aol.com wrote: > Good Morning All, > This is not particularly Aero Electric specific, but many of us do use > either the GNS 430 or the 530 for navigation. > I often play with the Garmin simulator so that maybe someday I will > get good enough to use ten per cent of the capability instead of only > five percent. Along that line, it would be nice to have a more > current database than what Garmin supplies free. They are now using a > 2007 based data bank. > A year ago or so, someone posted a method whereby we could update the > database on the free simulator. I tried that last spring and it worked > great. However, I lost the procedure and would like to install a new > update. Do any of you know how to do the update? > Or, does anyone remember who posted the procedure? > Sure wish I could find that old procedure. > Happy Skies, > Old Bob > Stearman N3977A > LL22 > Downers Grove, IL > * > > * ________________________________________________________________________________
Date: Nov 19, 2013
On 11/19/2013 11:36 AM, Kent Ogden wrote: I would determine the max number of wires required for any AP servo, then get the Trutrak harness with any extra wires bundled in with it. That number is probably zero. Stein can probably answer that one off the top of his head. You will find you have plenty of access for adding/changing the terminating plug once the wing is closed up. But routing the wire is much easier before you close things. A good service loop is desirable at that servo location in any case. Go for it. Bill > Hi all, > I am trying to get my wings closed up on my RV-10, but I would like to > get all the wiring in first if possible. I haven't decided on an > autopilot yet, but I was wondering if the roll servos that are out > there would use a more or less similar wiring harness. If, for > example, I got a SteinAir wiring harness for a Trutrak servo, would it > be compatible with another AP? I guess I don't know how many > different servos there are, do different AP's use basically the same > servos? > Kent > > * > > * ________________________________________________________________________________
Date: Nov 19, 2013
Subject: Re: USB pinouts
At 10:55 AM 11/19/2013, you wrote: > > >I looked up the pinouts for a USB port on Wikipedia and ended up >confused. They label pin 2 & 3 as data - and data + >respectively. I need to know which is data transmit and data >receive. Any help would be appreciated. The USB serial communications is 'party-line' communications on a twisted pair. The host controller (usually in your computer) queries the data bus to see who's out there and which of several modes of communications are being requested. Only one device can talk while all devices can listen. Hence, unlike RS232, there are no separate tx, rx lines. >I also don't like the 24ga wires included with the plug. Are there >any USB plugs that I can add on my own wires or have 22ga wires? Digikey sells all manner of serial data cable connectors. An exemplar A plug that would accept 22awg wire is here http://tinyurl.com/plg4goq They sell for about $3.50 When I need a USB cable that will carry power out to an accessory, I usually order a 'high current' pre-fab cable and cut one end off. You end up with a more compact, factory installed connector on the far end. Bob . . . ________________________________________________________________________________
Date: Nov 19, 2013
On 11/19/2013 11:55 AM, Sheldon Olesen wrote: > Are there any USB plugs that I can add on my own wires or have 22ga wires? http://www.mouser.com/ sells them. I just ordered the following parts to make up a USB cable to plug a SkyRadar ADSB unit into a GRT HX EFIS. I haven't made the cable yet so I can't say how hard it will be. 798-UX40-MB-5P UX40-MB-5P MINI B CBLE PLUG http://www.mouser.com/Search/ProductDetail.aspx?R=UX40-MB-5Pvirtualkey64550000virtualkey798-UX40-MB-5P 571-2040305-1 2040305-1 STD IND USB A KIT 4P http://www.mouser.com/Search/ProductDetail.aspx?R 40305-1virtualkey57100000virtualkey571-2040305-1 -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Nov 19, 2013
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
Subject: Re: Wow!...it's really going to happen.
Oh, yeah, I'm excited all right. You get an Albert Einstein looking guy to make a video about a technology that is so far fetched most people aren't going to believe it. But some do The proof in the pudding is to put you money where your mouth is. If you really think this stuff is pretty exciting, contact Per-Ivar Sellengren and tell him you're so excited you want to know where to send R&D money! Henador Titzoff -------------------------------------------- On Tue, 11/19/13, John Burnaby wrote: Subject: AeroElectric-List: Wow!...it's really going to happen. To: aeroelectric-list(at)matronics.com Date: Tuesday, November 19, 2013, 7:07 AM http://www.youtube.com/watch?v=cMaprpJKcls Pretty exciting stuff. Think of the area, internal and external, of a composite airframe, including spars, ribs, bulkheads...a flying battery. ________________________________________________________________________________
Date: Nov 19, 2013
Dynon sells 20" servo wire bundles which IIRC were 5 wire, which are specific to their servos. I do know Trutrak wiring is different, even though the servos physically interchange with each other. Dynon did a fair amount of development to magnify force and travel for their RV-10 elevator servo. I don't know what the others have, the Dynon was a simple install...drill a few holes and bolt it in. Well thought out. On 11/19/2013 10:27 AM, Bill Watson wrote: > On 11/19/2013 11:36 AM, Kent Ogden wrote: > I would determine the max number of wires required for any AP servo, > then get the Trutrak harness with any extra wires bundled in with it. > That number is probably zero. Stein can probably answer that one off > the top of his head. > > You will find you have plenty of access for adding/changing the > terminating plug once the wing is closed up. But routing the wire is > much easier before you close things. A good service loop is desirable > at that servo location in any case. Go for it. > > Bill > >> Hi all, >> I am trying to get my wings closed up on my RV-10, but I would like >> to get all the wiring in first if possible. I haven't decided on an >> autopilot yet, but I was wondering if the roll servos that are out >> there would use a more or less similar wiring harness. If, for >> example, I got a SteinAir wiring harness for a Trutrak servo, would >> it be compatible with another AP? I guess I don't know how many >> different servos there are, do different AP's use basically the same >> servos? >> Kent >> >> * >> >> * > > * > > * ________________________________________________________________________________
Date: Nov 19, 2013
Bob and DJ, thanks! Your suggestions are helpful and will be used. Thanks again, Sheldon Olesen Sent from my iPad ________________________________________________________________________________
Date: Nov 19, 2013
From: DeWitt Whittington <dee.whittington(at)gmail.com>
Kent, Please send your question to Chuck Busch at Trio Avionics in California. We have bought the Trio Pro Pilot and Gold Series servos for our Sportsman. Although we aren't flying yet, I still think Trio is the top of the heap for auto pilots in experimental aircraft. Email him at ezflyr82(at)cox.net or info(at)trioavionics.com He's a super nice guy. I always make it a point to talk to him and the Trio team at Oshkosh and Sun 'n Fun. If you ever get the chance, either in
October 26, 2013 - November 19, 2013
AeroElectric-Archive.digest.vol-ma
