AeroElectric-Archive.digest.vol-mi
May 03, 2014 - June 13, 2014
Subject: Re: How do I prevent starter engaged LED from failing?
Date: May 03, 2014
Eric, I am not knowledgeable enough about the characteristics of a starter motor to answer. In my circuit, any diode, zener or not, will short out a negative voltage. A 16 volt zener will short out any positive voltage above 16. Attach your latest circuit idea for others to comment on. It would be interesting to learn more about starters, any induced voltages during normal operations and also the voltage output and current capabilities of a starter that remains engaged with the engine after starting. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422759#422759 ________________________________________________________________________________
Date: May 03, 2014
failing? At 04:02 PM 5/3/2014, you wrote: > >Eric, >I am not knowledgeable enough about the characteristics of a starter >motor to answer. In my circuit, any diode, zener or not, will short >out a negative voltage. A 16 volt zener will short out any positive >voltage above 16. Attach your latest circuit idea for others to comment on. > It would be interesting to learn more about starters, any induced > voltages during normal operations and also the voltage output and > current capabilities of a starter that remains engaged with the > engine after starting. Joe's circuit would be fine for fixtures with integrate resistors . . . and in fact, it wouldn't need to be a zener. The 'concern' is minor and speaks to the potential for a negative going transient to punch the junction in the LED . . . Now, given that LEDs with integral resistors abound in other vehicular systems . . . and no doubt few if any have a protection diode for the LED. http://forums.matronics.com//files/led_102.jpg If I were qualifying the LED fixture for use on aircraft, I would be obligated to prove it invulnerable to both positive and negative going spikes . . . albeit very short ones . . . at voltages considerably greater than the LED's reverse voltage stand-off characteristics. For my purposes, I choose to simply include the diode and not worry about it. The fact that we put such protection in has more to do with legacy qualification philosophies that go back 50+ years . . . but given that the LED is attached to a starter motor terminal DOWNSTREAM of a starter contactor, then the concerns are more profound. It's a simple experiment. Just hook it up and see what happens. You're unlikely to have BOTH a stuck starter contactor and a toasted LED in the same event. If your bare-foot LED fixture stands up to the first few dozen starts, it seem likely that a few hundreds more is not going to be any more likely to toast it. Bob . . . ________________________________________________________________________________
Date: May 03, 2014
Subject: Re: lm7321 substitute
At 11:31 AM 5/1/2014, you wrote: > >Earlier in the thread I saw a mention of a rail to rail input >requirement. If that is still needed, note the common mode input >voltage range of Vdd - 1.35 volts maximum for the TLV27x. Seems to >indicate the input range is not really rail to rail and I'd expect >the output to swing hard to the full on supply voltage whenever the >input is within 1.35v of the supply voltage. > >Ken Good catch . . . thought I had that covered. After several asphalt meditations last week, I came to the conclusion that while the rail-to-rail i/o buffer would offer a 'simple' solution, it wasn't very elegant. I'm working on a drawing that uses a R-t-R output op amp in an inverting configuration which does two good things for us. (1) We can add pots that set gain and offset such that the builder can exploit ALL the bars in the trim indicator display even if the pot doesn't run full mechanical stroke and (2) we can drive any number of indicators from the single amplifier. Refresh my memory . . . does the orange lead on a RayAllen bar graph display output 5 volts or something else? Ken, thanks for the heads-up . . . Bob . . . ________________________________________________________________________________
Date: May 04, 2014
Subject: Dual trim indicator buffer
Here's the drawing I alluded to last night . . . http://tinyurl.com/pdacqjp Had a power failure yesterday afternoon which led to a discovery that my AutoCAD backup feature had not been set up on this machine . . . lost 90% of the work and had to put it back together this morning. Well considered critical review from kindred herders of electrons is solicited and welcome. This project could be laid up on a board that would fit into a 15 pin d-sub housing. The pots will allow adjustment of gain over a 1 to 2x range. Offset is good for about 30% of range. This will allow a builder to make the trim indicator display full, as-installed stroke of the actuator. Bob . . . ________________________________________________________________________________
Date: May 04, 2014
Subject: Alternative battery technologies . . .
The battery-buzz these days is focused on lithium . . . and for good reason. They ARE lighter yet retain many of the desirable qualities of a lead=acid battery for engine cranking. Another rising-star wannabe is a product by FireFly Energy . . . an svrla battery that features a carbon foam plate material with a advertised gee-whiz feature of offering a lower weight replacement for the legacy lead grids. This is not a 'new' idea . . . I think the patents have already been renewed once . . . but only recently have potential consumers of this technology been able to put their hands on real product. http://tinyurl.com/kfzsj5p This is a group 31 battery (read BIG) that weighed in at 73.6 pounds and presented and open circuit voltage of 13.09V at ~20C right out of the box. A 600A load drops voltage to 9.30V. Therefor (13.1 - 9.30)/600 = 0.00633 Ohms internal resistance. Okay, how about available capacity under various loads? Emacs! When discharged at 5A, it took 20+ hours to take it down to 10.0V. So one could say that the capacity of this battery at 20-hour rate is over 100aH. Not bad for a 75# battery. At higher rates, we see that the capacity drops off pretty much like all other batteries . . . the 50A discharge delivered only 80Ah . . . one might extrapolate from this data that the battery's one-hour rate (as an aircraft battery would clock in at about 65Ah. Again, not bad for a 12V, 75# battery. From the data taken, we can estimate that a 24V cousin of the same active materials would be slightly more than the 75# due to addition of extra cell walls. The internal resistance would go up by a factor of 4. Twice as many half-sized cells in series. A 4x increase in internal resistance would have a profound effect on delivered capacity at the higher rates. In other words, when sliced up and reassembled as a 24V battery, this device would not be able to deliver 1/2 the one-hour rate deduced above . . . it's more likely to be down to something like 20Ah or so. I'm going to see if I can model the 24v version and do some predicted plots. From the aircraft perspective, the 24v version would be unable to start a turbine engine. While the capacity is there at moderate discharge rates . . . internal resistance kills its cranking abilities. The plots above include some charging performance data on a Schumacher XC75W picked up new at a Walmart store a few weeks ago. http://tinyurl.com/k7fatrm On the outside of the box it says 3A charger/maintainer, 5A charger, 20A charger and 75A engine cranking output. Okay, the first recharge cycle of the 100Ah "AGM" battery under test produced the recharge curve in black. It topped off at about 15.7 volts and had the battery 'wheezing' from the vent valves. The second recharge in the "GEL" mode produced the curve in blue which topped off at 14.8 volts. MUCH better. The third recharge in the "STD" mode produced the curve in red which again topped off at 15.7 volts and squeezed a few more molecules of disassociated hydrogen and oxygen from the cell vents. Clearly, this charger is not programmed for the advertised service. Either I have a bad charger or Schumacher has stubbed their toe. This is like finding a Fluke voltmeter that's only good to 2% or so . . . I am told that Schumacher's engineering staff is willing to talk. I'll be looking for a contact in that venue to discuss my findings on this particular Schumahcer product. In the mean time, know that the 20A rate appears to be a modulated 'peak' rate. Time to stuff 100Ah plus back into this battery at the 20A setting on the charger took 8+ hours. Not a big deal. It was reasonably expeditious and didn't abuse the battery in the GEL mode . . . other modes are yet to be explained/understood. So what about these 'new' technologies? Mixed bag. Clearly the carbon foam battery plate is not ready for prime-time in aviation. Service in anything but moderate rate discharge in RV's, boats, etc would be disappointing at anything over .3C rates. Pretty sure I'm not ready to poke out $375 for one of these things. Tho I AM glad my client was willing . . . The charger was disappointing on two fronts. It's clearly NOT a 20A fast charger. It's also unsuited to the tasks advertised for maintenance of AGM/Flooded batteries. MUCH too abusive. A learned professor once opined "Numbers not accompanied by degrees of uncertainty are meaningless" (Walter Lewin). Another pretty sharp cookie was known to have said, " . . . when you cannot measure [a thing], when you cannot express it in numbers, your knowledge is of a meagre and unsatisfactory kind . . ."(Lord Kelvin). This is a good illustration of the difficulties encountered by the CONSUMING community when factions of the SUPPLIER community get into rock-throwing contests (Recall the tiff that Odyssey got into with one of the battery maintainer guys? I forget which). It would have been good and responsible for both parties to publish the numbers instead of throwing rocks with consumers caught in the middle. Now that I have the numbers . . . I can go back to the folks who have claimed certain kinds of performance based on those numbers for clarification . . . Watch this space. Bob . . . ________________________________________________________________________________
Date: May 05, 2014
I have had an LED indicate "Gear in transit" for 10 years with no protection.... Best... Bob Verwey On 3 May 2014 23:02, user9253 wrote: > > Eric, > I am not knowledgeable enough about the characteristics of a starter motor > to answer. In my circuit, any diode, zener or not, will short out a > negative voltage. A 16 volt zener will short out any positive voltage > above 16. Attach your latest circuit idea for others to comment on. > It would be interesting to learn more about starters, any induced > voltages during normal operations and also the voltage output and current > capabilities of a starter that remains engaged with the engine after > starting. > Joe > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422759#422759 > > ________________________________________________________________________________
Subject: Intercom to Radio Wiring
Date: May 05, 2014
This is a question regarding technique rather than specific equipment. I'm about to start my third try to wire my 4 place intercom to my radio. My goal is to get all the wires at the connector to actually look semi-decent and not the fat-collection-of-rats-nest bundle that has resulted from my first two attempts. It CAN be done, I've seen it. I just don't know any of the secrets ... wondering what they are ? Is there a technique or process/pattern to this ? With all the wires coming in - 3 from each headset connection, 2 additional pair for ptt, power and then the connections to the radio - there's gotta be something I'm missing because I've seen it done nicely ... I checked the aeroconnections site and used a couple of the tricks there, but they really didn't get me very far. Any advice other than hiring the task out ? Thanks --Ron ________________________________________________________________________________
Date: May 05, 2014
Subject: Re: Intercom to Radio Wiring
Hi Ron, I ran into the same problem. This was my solution to combining the left audio, right audio, and ground signals for the right front and rear passengers: http://jaredyates.com/bearhawk/wp-content/uploads/2011/06/P1010720.jpg I brought all of the incoming wires into a regular machined-pin 25-pin d-sub connector. Then I used an opposite-sex solder d-sub to make the one shown in the picture. I soldered a little piece of wire across the appropriate pins. I think in the final configuration I stripped a 5/8" or so long piece off of the end of a longer wire, soldered the stripped part across the cups, and then connected the other end of that wire to the intercom input. This would be an option if you run out of pins. I didn't take a picture of the final configuration, but I think I did run short of pins on at least one of them. When it was done I potted the whole thing to keep it from shorting. As for the ptt and the rest, my intercom might have been a little bit different. I had an input pin for each front seat occupant, so that when the right front keys, only his mic goes to the radio, etc. Mine were also only single wires- one end went to the intercom, then the other end went to local ground after passing through the switch. Another problem was turning big shields into wires that I could crimp into machined pins. I used crimped on terminals of various types. If I had a large size change, I might crimp a yellow "handshake" connector on the big clump of shields, and then crimp a red one onto a single 22-gauge piece of wire that went to the machined pin. Sometimes I would bring two large clumps of shields into each end of a yellow splice, then stick a 22-gauge wire in one of the ends along with the shields. I'll not imply that the above is necessarily the best way- my mission wasn't to win any awards, but just to have a reliable mode of transportation- but so far it is all working just fine. In the end, I wouldn't say it's a rat's nest (though some might), but perhaps more of a bird's nest. On Mon, May 5, 2014 at 6:59 AM, Ron Walker wrote: > > This is a question regarding technique rather than specific equipment. > > I'm about to start my third try to wire my 4 place intercom to my radio. > My goal is to get all the wires at the connector to actually look > semi-decent and not the fat-collection-of-rats-nest bundle that has > resulted from my first two attempts. It CAN be done, I've seen it. I > just don't know any of the secrets ... wondering what they are ? > > Is there a technique or process/pattern to this ? With all the wires > coming in - 3 from each headset connection, 2 additional pair for ptt, > power and then the connections to the radio - there's gotta be something > I'm missing because I've seen it done nicely ... > > I checked the aeroconnections site and used a couple of the tricks > there, but they really didn't get me very far. > > Any advice other than hiring the task out ? > > Thanks > > --Ron > > ________________________________________________________________________________
Date: May 05, 2014
failing? At 12:07 AM 5/5/2014, you wrote: >I have had an LED indicate "Gear in transit" for 10 years with no >protection.... > >Best... > Thanks Bob . . .I'm not surprised. Folks who don't work up to their eyeballs in TC aviation have some difficult grasping the significance of the hat-dances we do to get a part holy-watered. The control of emitted stresses and demonstrating immunity to external stresses under DO160/MilSTD704 is a kind of 99+ percentile hedge against conditions known to manifest in at least some situations. There's an alternator regulator on Bonanzas and Barons that NEVER saw the lights of a DO160 test lab. It was added to the airplane's TC WWWAAaaayy back when . . . before Part 23 aviation got so tightly wrapped up in mandated hat-dancing. If the airframe manufacturer accomplished enough testing on the airplane to demonstrate 99+ percent 'suitability to task' then the addition was allowed. This particular design has a vulnerability to certain noises from brush bounce in alternators that causes the OV protection to trip. Further, there's a 1= percent probability that new alternators of this vintage will exhibit the noise. Ever so often, on at least 3 occasions I was involved in over the last 30 years, that 1 percent minus stress comes together with a 1 percent minus vulnerability and you get a rash of airplanes that can't be delivered because the alternator(s) keep tripping off line under certain conditions. The obvious fix is to put a fully qualified, regulator on. But with production volumes so low, nobody is very excited about launching in to a new design program . . . even when I have the design already done! So, a suitable 'band-aid' not unlike those things we've resorted to for over a century has erected a reasonable wall of separation between the waring factions and all is now serene in the universe. What does this have to do with adding protection to the LED indicators attached directly to a bus-driven source? Simply this: The probability that any given led is going to get toasted by one of the stresses predicted by DO160/MilSTD704 is very low. But as experienced practitioners of the design arts, probability does not figure into robustness of a design. DO160/MilSTD704 is not a probability game, it's a robustness game. As a matter of design goals, I recommend the diode as depicted in the drawings. But as Bob (and no doubt many others) has observed . . . Gee, been doing this for years without the protection and I've had no problems. The lesson-learned here has nothing to do with holding the LED-toasting dragons at bay and leaving the pilot unaware of a stuck contactor . . . it's about ROBUST design that chooses to ignore low probability events and design for worst case. Here's where your failure mode effects analysis tools come into play. Suppose the LED DOES get toasted. How long will it take you to discover that fact and what is the probability that LED failure will be co-incident with an LED-toasting dragon? If your checklist for engine cranking includes something like: STARTER - Engage. Observe STARTER ENGAGED light is illuminated. When engine starts STARTER - Disengage. Observe START ENGAGED light is dark. . . . and you're covered with the same blanket that has enveloped many other 'unprotected' installations. DO160/MilSTD704 robustness is but one of many tools we can apply to reduction of risk. Knowledge and understanding is the most powerful of those tools. Bob . . . ________________________________________________________________________________
Date: May 05, 2014
At 06:51 AM 5/5/2014, you wrote: >Hi Ron, I ran into the same problem. =C2 This was >my solution to combining the left audio, right >audio, and ground signals for the right front and rear passengers: > ><http://jaredyates.com/bearhawk/wp-content/uploads/2011/06/P1010720.jpg>htt p://jaredyates.com/bearhawk/wp-content/uploads/2011/06/P1010720.jpg Looks like a good lick to me . . . One of my pet peeves concerning the design of many appliances is the dearth of pin-outs necessary for graceful termination of wires in a common installation. Many times it's not a big deal to the next larger size d-sub connector on the product to assist the installer in termination of multiple wires to grounds or paralleled loads. Mr. Yates' solution is a rational and robust solution to your installation problem . . . perhaps a bit more 'bulk' than soldering them into heat-shrink covered lumps . . . but certainly more elegant in appearance and maintainability. Bob . . . ________________________________________________________________________________
Date: May 05, 2014
If your using Bob's technique to terminate the shields, make the pig tails long enough so they are just outside the hood of the D-sub. The short length of un-shielded wire should not cause any problem. You can also daisy chain all the grounds into the minimum required number before it enters the hood. Otherwise there may be too much bulk to get the hood on. Tim > On May 5, 2014, at 3:59 AM, Ron Walker wrote: > > > This is a question regarding technique rather than specific equipment. > > I'm about to start my third try to wire my 4 place intercom to my radio. > My goal is to get all the wires at the connector to actually look > semi-decent and not the fat-collection-of-rats-nest bundle that has > resulted from my first two attempts. It CAN be done, I've seen it. I > just don't know any of the secrets ... wondering what they are ? > > Is there a technique or process/pattern to this ? With all the wires > coming in - 3 from each headset connection, 2 additional pair for ptt, > power and then the connections to the radio - there's gotta be something > I'm missing because I've seen it done nicely ... > > I checked the aeroconnections site and used a couple of the tricks > there, but they really didn't get me very far. > > Any advice other than hiring the task out ? > > Thanks > > --Ron > > > > > > ________________________________________________________________________________
Date: May 05, 2014
I totally agree. One of the benefits of packaging the audio products that I have developed in d-sub backshells is that there are a lot more pins availa ble for grounds. In fact, I usually reserve a whole row of pins for ground, whether they are needed or not. This simplifies installation and saves time and money. The availability of a whole class of through-hole components that have a max imum height sized to fit in these packages makes even small volume designs f easible without having to resort to surface mount devices. Cheers, Vern Little Vx Aviation ========================== ========================== Sent from my iThing. It is responsible for all gramma and typo terrors. > On May 5, 2014, at 6:46 AM, "Robert L. Nuckolls, III" <nuckolls.bob@aeroel ectric.com> wrote: > > At 06:51 AM 5/5/2014, you wrote: >> Hi Ron, I ran into the same problem. =C3=82 This was my solution to combi ning the left audio, right audio, and ground signals for the right front and rear passengers: >> >> http://jaredyates.com/bearhawk/wp-content/uploads/2011/06/P1010720.jpg > > Looks like a good lick to me . . . > > One of my pet peeves concerning the design of many > appliances is the dearth of pin-outs necessary > for graceful termination of wires in a common > installation. > > Many times it's not a big deal to the next > larger size d-sub connector on the product to > assist the installer in termination of multiple > wires to grounds or paralleled loads. > > Mr. Yates' solution is a rational and robust > solution to your installation problem . . . > perhaps a bit more 'bulk' than soldering > them into heat-shrink covered lumps . . . but > certainly more elegant in appearance and > maintainability. > > > Bob . . . > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: May 05, 2014
_____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, May 04, 2014 9:16 AM Subject: AeroElectric-List: Alternative battery technologies . . . The battery-buzz these days is focused on lithium . . . and for good reason. They ARE lighter yet retain many of the desirable qualities of a lead=acid battery for engine cranking. Another rising-star wannabe is a product by FireFly Energy . . . an svrla battery that features a carbon foam plate material with a advertised gee-whiz feature of offering a lower weight replacement for the legacy lead grids. This is not a 'new' idea . . . I think the patents have already been renewed once . . . but only recently have potential consumers of this technology been able to put their hands on real product. http://tinyurl.com/kfzsj5p This is a group 31 battery (read BIG) that weighed in at 73.6 pounds and presented and open circuit voltage of 13.09V at ~20C right out of the box. A 600A load drops voltage to 9.30V. Therefor (13.1 - 9.30)/600 = 0.00633 Ohms internal resistance. Okay, how about available capacity under various loads? Emacs! When discharged at 5A, it took 20+ hours to take it down to 10.0V. So one could say that the capacity of this battery at 20-hour rate is over 100aH. Not bad for a 75# battery. At higher rates, we see that the capacity drops off pretty much like all other batteries . . . the 50A discharge delivered only 80Ah . . . one might extrapolate from this data that the battery's one-hour rate (as an aircraft battery would clock in at about 65Ah. Again, not bad for a 12V, 75# battery. >From the data taken, we can estimate that a 24V cousin of the same active materials would be slightly more than the 75# due to addition of extra cell walls. The internal resistance would go up by a factor of 4. Twice as many half-sized cells in series. A 4x increase in internal resistance would have a profound effect on delivered capacity at the higher rates. In other words, when sliced up and reassembled as a 24V battery, this device would not be able to deliver 1/2 the one-hour rate deduced above . . . it's more likely to be down to something like 20Ah or so. I'm going to see if I can model the 24v version and do some predicted plots. >From the aircraft perspective, the 24v version would be unable to start a turbine engine. While the capacity is there at moderate discharge rates . . . internal resistance kills its cranking abilities. The plots above include some charging performance data on a Schumacher XC75W picked up new at a Walmart store a few weeks ago. http://tinyurl.com/k7fatrm On the outside of the box it says 3A charger/maintainer, 5A charger, 20A charger and 75A engine cranking output. Okay, the first recharge cycle of the 100Ah "AGM" battery under test produced the recharge curve in black. It topped off at about 15.7 volts and had the battery 'wheezing' from the vent valves. The second recharge in the "GEL" mode produced the curve in blue which topped off at 14.8 volts. MUCH better. The third recharge in the "STD" mode produced the curve in red which again topped off at 15.7 volts and squeezed a few more molecules of disassociated hydrogen and oxygen from the cell vents. Clearly, this charger is not programmed for the advertised service. Either I have a bad charger or Schumacher has stubbed their toe. This is like finding a Fluke voltmeter that's only good to 2% or so . . . I am told that Schumacher's engineering staff is willing to talk. I'll be looking for a contact in that venue to discuss my findings on this particular Schumahcer product. In the mean time, know that the 20A rate appears to be a modulated 'peak' rate. Time to stuff 100Ah plus back into this battery at the 20A setting on the charger took 8+ hours. Not a big deal. It was reasonably expeditious and didn't abuse the battery in the GEL mode . . . other modes are yet to be explained/understood. So what about these 'new' technologies? Mixed bag. Clearly the carbon foam battery plate is not ready for prime-time in aviation. Service in anything but moderate rate discharge in RV's, boats, etc would be disappointing at anything over .3C rates. Pretty sure I'm not ready to poke out $375 for one of these things. Tho I AM glad my client was willing . . . The charger was disappointing on two fronts. It's clearly NOT a 20A fast charger. It's also unsuited to the tasks advertised for maintenance of AGM/Flooded batteries. MUCH too abusive. A learned professor once opined "Numbers not accompanied by degrees of uncertainty are meaningless" (Walter Lewin). Another pretty sharp cookie was known to have said, " . . . when you cannot measure [a thing], when you cannot express it in numbers, your knowledge is of a meagre and unsatisfactory kind . . ."(Lord Kelvin). This is a good illustration of the difficulties encountered by the CONSUMING community when factions of the SUPPLIER community get into rock-throwing contests (Recall the tiff that Odyssey got into with one of the battery maintainer guys? I forget which). It would have been good and responsible for both parties to publish the numbers instead of throwing rocks with consumers caught in the middle. Now that I have the numbers . . . I can go back to the folks who have claimed certain kinds of performance based on those numbers for clarification . . . Watch this space. Bob . . . ________________________________________________________________________________
Date: May 05, 2014
Excellent study and report Bob. Thanks for sharing. Bevan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, May 04, 2014 9:16 AM Subject: AeroElectric-List: Alternative battery technologies . . . The battery-buzz these days is focused on lithium . . . and for good reason. They ARE lighter yet retain many of the desirable qualities of a lead=acid battery for engine cranking. Another rising-star wannabe is a product by FireFly Energy . . . an svrla battery that features a carbon foam plate material with a advertised gee-whiz feature of offering a lower weight replacement for the legacy lead grids. This is not a 'new' idea . . . I think the patents have already been renewed once . . . but only recently have potential consumers of this technology been able to put their hands on real product. http://tinyurl.com/kfzsj5p This is a group 31 battery (read BIG) that weighed in at 73.6 pounds and presented and open circuit voltage of 13.09V at ~20C right out of the box. A 600A load drops voltage to 9.30V. Therefor (13.1 - 9.30)/600 = 0.00633 Ohms internal resistance. Okay, how about available capacity under various loads? Emacs! When discharged at 5A, it took 20+ hours to take it down to 10.0V. So one could say that the capacity of this battery at 20-hour rate is over 100aH. Not bad for a 75# battery. At higher rates, we see that the capacity drops off pretty much like all other batteries . . . the 50A discharge delivered only 80Ah . . . one might extrapolate from this data that the battery's one-hour rate (as an aircraft battery would clock in at about 65Ah. Again, not bad for a 12V, 75# battery. >From the data taken, we can estimate that a 24V cousin of the same active materials would be slightly more than the 75# due to addition of extra cell walls. The internal resistance would go up by a factor of 4. Twice as many half-sized cells in series. A 4x increase in internal resistance would have a profound effect on delivered capacity at the higher rates. In other words, when sliced up and reassembled as a 24V battery, this device would not be able to deliver 1/2 the one-hour rate deduced above . . . it's more likely to be down to something like 20Ah or so. I'm going to see if I can model the 24v version and do some predicted plots. >From the aircraft perspective, the 24v version would be unable to start a turbine engine. While the capacity is there at moderate discharge rates . . . internal resistance kills its cranking abilities. The plots above include some charging performance data on a Schumacher XC75W picked up new at a Walmart store a few weeks ago. http://tinyurl.com/k7fatrm On the outside of the box it says 3A charger/maintainer, 5A charger, 20A charger and 75A engine cranking output. Okay, the first recharge cycle of the 100Ah "AGM" battery under test produced the recharge curve in black. It topped off at about 15.7 volts and had the battery 'wheezing' from the vent valves. The second recharge in the "GEL" mode produced the curve in blue which topped off at 14.8 volts. MUCH better. The third recharge in the "STD" mode produced the curve in red which again topped off at 15.7 volts and squeezed a few more molecules of disassociated hydrogen and oxygen from the cell vents. Clearly, this charger is not programmed for the advertised service. Either I have a bad charger or Schumacher has stubbed their toe. This is like finding a Fluke voltmeter that's only good to 2% or so . . . I am told that Schumacher's engineering staff is willing to talk. I'll be looking for a contact in that venue to discuss my findings on this particular Schumahcer product. In the mean time, know that the 20A rate appears to be a modulated 'peak' rate. Time to stuff 100Ah plus back into this battery at the 20A setting on the charger took 8+ hours. Not a big deal. It was reasonably expeditious and didn't abuse the battery in the GEL mode . . . other modes are yet to be explained/understood. So what about these 'new' technologies? Mixed bag. Clearly the carbon foam battery plate is not ready for prime-time in aviation. Service in anything but moderate rate discharge in RV's, boats, etc would be disappointing at anything over .3C rates. Pretty sure I'm not ready to poke out $375 for one of these things. Tho I AM glad my client was willing . . . The charger was disappointing on two fronts. It's clearly NOT a 20A fast charger. It's also unsuited to the tasks advertised for maintenance of AGM/Flooded batteries. MUCH too abusive. A learned professor once opined "Numbers not accompanied by degrees of uncertainty are meaningless" (Walter Lewin). Another pretty sharp cookie was known to have said, " . . . when you cannot measure [a thing], when you cannot express it in numbers, your knowledge is of a meagre and unsatisfactory kind . . ."(Lord Kelvin). This is a good illustration of the difficulties encountered by the CONSUMING community when factions of the SUPPLIER community get into rock-throwing contests (Recall the tiff that Odyssey got into with one of the battery maintainer guys? I forget which). It would have been good and responsible for both parties to publish the numbers instead of throwing rocks with consumers caught in the middle. Now that I have the numbers . . . I can go back to the folks who have claimed certain kinds of performance based on those numbers for clarification . . . Watch this space. Bob . . . ________________________________________________________________________________
Date: May 05, 2014
At 10:38 AM 5/5/2014, you wrote: >I totally agree. One of the benefits of packaging the audio >products that I have developed in d-sub backshells is that there are >a lot more pins available for grounds. In fact, I usually reserve a >whole row of pins for ground, whether they are needed or not. > >This simplifies installation and saves time and money. > >The availability of a whole class of through-hole components that >have a maximum height sized to fit in these packages makes even >small volume designs feasible without having to resort to surface >mount devices. Isn't this business fun? Bob . . . ________________________________________________________________________________
Date: May 05, 2014
At 10:41 AM 5/5/2014, you wrote: >Excellent study and report Bob. Thanks for sharing. > >Bevan You're welcome. The next phase of the study will involve disassembly of the battery. We want to see if our 'predictors' based on experience and deduction about this technology were correct. About 8 years ago we spent a little money getting to know the designers a little better. Funny thing about that physics-stuff . . . you cannot shuffle the numbers and simple- ideas at the convenience of marketing department. Attempts to ignore -or- shuffle can be embarrassing, expensive and sometimes dangerous. Bob . . . ________________________________________________________________________________
Date: May 05, 2014
Joe and Bob, I thought that an LED was a type of diode. It seems like one should not have to stick a second diode on the circuit when using an LED. For your review, here is an attachment of my solution. My engine/starter is in a state of storage so the LED based circuit cannot be tested yet. I chickened out and replaced the diode with a mini bulb. Seemed like the simplest way in my case. Thank you, Eric Schlanser Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422865#422865 Attachments: http://forums.matronics.com//files/starter_warn_light_circuit3_451.pdf ________________________________________________________________________________
Date: May 05, 2014
Subject: Re: trim indicator buffer
> Well considered critical review from kindred herders > of electrons is solicited and welcome. I would add another 0.1 from pin 3 to ground, to keep noisy trim pots from making the reading jumpy, and maybe another one between pins 2 and 6 to slow down the op amp. ________________________________________________________________________________
Date: May 05, 2014
failing? At 05:48 PM 5/5/2014, you wrote: > >Joe and Bob, > >I thought that an LED was a type of diode. It seems like one should >not have to stick a second diode on the circuit when using an LED. It IS a diode. It has ratings and limits like any other diode. When caused to conduct current in a forward direction, it exhibits a voltage drop quite a bit higher than power steering or detection diodes . . . and it emits light while doing it. Apply voltage in the reverse direction and you not only get no light . . . you may punch out the magic stuff between the terminals that emits the light. Here's an exemplar set of plots on a bright, white LED. http://tinyurl.com/q4f25xe Emacs! For a diode rated at 30 mA, one selects a resistor that produces no more than 30 mA at maximum expected system voltage (call it 15v). In the curve above we see that voltage drop is 3.4V at 30 mA. (15-3.4)/.030 = 386 ohms. So the resistor to choose is no smaller than this calculated value to stay below the diode's rated maximum operating current. Emacs! Reverse voltage is another mater. Note that around 18volts, the current takes a sharp spike toward very high . . . read damaged junction. Now, the SOURCE of a reverse voltage in our applications MUST be reactive. I.e., inductive response to rapid drop in applied current . . . like a contactor opening up. The inductive culprit is not necessarily a DEVICE . . . even long wires between the battery and the victim device can offer the inductive storage need to offer a reverse voltage spike. It WILL be short, it may not have much energy in it . . . but it quite likely to exceed 18 volts. Hence, legacy design goals include the addition of a diode across the LED wired to conduct in case such a led-killing dragon should come along. Not saying it WILL . . . in fact, many builders are flying 'unprotected' leds with no regrets. There are Bonanzas with low probability of an antagonist jumping up to irritate a less-than- robust regulator . . . rare but not zero. > > >For your review, here is an attachment of my solution. My >engine/starter is in a state of storage so the LED based circuit >cannot be tested yet. I chickened out and replaced the diode with a >mini bulb. Seemed like the simplest way in my case. Can you articulate the source of your 'fear?' I thought that the explanations and experiences shared here on the List would have assuaged your concerns. By all means, use the LED without protection . . . and simply watch it for failure. It's a no-risk event easily spotted throughout its lifetime on the airplane. I'm concerned that you were offered 'too much' information . . . that's always a risk in this data exchange venue . . . it was never intended to be a 'cook book . . . do this and trust me'. But the fact that you 'chickened out' and regressed to a legacy technology suggests that the List did not serve you well. Don't hesitate to bring perceptions of poor service to my attention or anyone else's . . . this List is all about reducing risk through knowledge and understanding . . . not about anointing any one process or technology. Bob . . . ________________________________________________________________________________
Date: May 06, 2014
> I thought that an LED was a type of diode. It seems like one should not have to stick a second diode on the circuit when using an LED. I do not think that either Bob or I recommending using a protection diode. I only offered a circuit containing one to help answer the question. Actually, I think that an incandescent lamp is more likely to fail than a LED. I think an indicator light (if used) should be connected in parallel with the starter motor, and not connected to the contactor coil. Then the lamp will illuminate whenever the starter motor is rotating and for whatever reason. Someone correct me if I am wrong. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422877#422877 ________________________________________________________________________________
Date: May 06, 2014
failing? At 05:59 AM 5/6/2014, you wrote: > > > > I thought that an LED was a type of diode. It seems like one > should not have to stick a second diode on the circuit when using an LED. > >I do not think that either Bob or I recommending using a protection diode. Correct. My assertions went to the point of robust design goals. Here's how the protection diode works should one choose to include it. There are lots of airplanes flying with commerical off the shelf, internally regulated alternators too . . . without the legacy ov protection. Again, builder's choice. > I only offered a circuit containing one to help answer the > question. Actually, I think that an incandescent lamp is more > likely to fail than a LED. Agreed although in this case were talking about two different failure modes. Incandescent lamps will wear out and are subject to vibration. LEDs are essentially longer lived than the airplane itself assuming that it's free of all electrical over-stresses. > I think an indicator light (if used) should be connected in > parallel with the starter motor, and not connected to the contactor coil. Good catch. I missed that feature. Yes, the purpose of the light is to warn of a stuck starter contactor. Hence, it would be wired to the motor terminals. > Then the lamp will illuminate whenever the starter motor is > rotating and for whatever reason. Someone correct me if I am wrong. Bob . . . ________________________________________________________________________________
Date: May 06, 2014
failing? =0A=0Acomments a the bottom...=0A=0A=0A________________________________=0A From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>=0ATo: aeroe lectric-list(at)matronics.com =0ASent: Tuesday, May 6, 2014 4:33 AM=0ASubject: Re: AeroElectric-List: Re: How do I prevent starter engaged LED from fai , III" =0A=0AAt 05:59 AM 5/6/2014, you wrote >=0A>=0A>=0A> > I thought that an LED was a type of diode. It seems like on e =0A> should not have to stick a second diode on the circuit when using an LED.=0A>=0A>I do not think that either Bob or I recommending using a prote ction diode.=0A=0A- - - Correct. My assertions went to the point of =0A- - - robust design goals. Here's how the protection=0A- - - diode works should one choose to include it.=0A- - - There are lots of airplanes flying with commerical=0A- - - off the shelf, internally regulated alternators=0A- - - too . . . without the legacy ov protec tion.=0A- - - Again, builder's choice.=0A=0A>- I only offered a ci rcuit containing one to help answer the =0A> question.- Actually, I think that an incandescent lamp is more =0A> likely to fail than a LED.=0A=0A- - - Agreed although in this case were talking about=0A- - - two different failure modes. Incandescent lamps=0A- - - will wear out and are subject to vibration.=0A- - - LEDs are essentially longer lived than the=0A- - - airplane itself assuming that it's free=0A- - - of all electrical over-stresses.=0A=0A>- I think an indicator light (if used) should be connected in =0A> parallel with the starter motor, and not connected to the contactor coil.=0A=0A- - - Good catch. I missed that feature. Yes,=0A- - - the purpose of the light is to warn of=0A - - - a stuck starter contactor. Hence, it=0A- - - would be wir ed to the motor terminals.=0A=0A=0A=0A>- Then the lamp will illuminate w henever the starter motor is =0A> rotating and for whatever reason.- Some one correct me if I am wrong.=0A=0AThe original drawing submitted by the or iginal poster showed the light across=0Athe motor terminals of the starter. =0A=0ACare must be taken to get on the correct terminal on the starter.- If you get =0Aan indicator, LED or incandescent, across the starter "shift" solenoid (that's=0Athe one built into the starter which engages the drive pinion) you=0Awill indeed have a dragon by the tail.- The inductive kick when the shift =0Asolenoid de-energizes is a flame-thrower.=0A=0A-Jeff=0A == ________________________________________________________________________________
Date: May 06, 2014
Bob(s) and Joe, It's not about poor "service" from this list. Quite the contrary. And the great body of knowledge herein is why I came to this list to find out the answer to my questions. I have learned so much here it's why I have been able to create and wire my plane. Couldn't have done it without you. Not having full understanding of an LED is why I used the mini bulb. Your explanations made the use of the LED so much clearer that I could have used it had I seen your posts before I chickened out and installed the mini bulb. When the mini bulb fails, I'll try the LED. Although, the mini bulb has a 5k hours ave life! Also, I was not able to test the LED by running the starter. Also, the two original diagrams showing two different ways to add the diode to the circuit had me wondering which was correct. As far as monitoring the starter contactor rather than the terminals on the starter, I have to say I followed an old drawing I had from the aeroelectric.com site. It was http://www.aeroelectric.com/Pictures/Contactors/Starter_Contactor/s702wire.jpg When I search for it now, I find I am not able to access it. It was a picture of an auto style start contactor with two large posts and two small posts. The small posts were labelled S and I. The picture said the I post could be used for a starter monitoring light. I'll agree the starter would be a better device to monitor. THanks for the tips. Eric Schlanser . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422930#422930 ________________________________________________________________________________
Date: May 07, 2014
Subject: Re: Time delay, flicker filter etc.
Robert L. Nuckolls, III a crit : > > > >> >> A time constant of 2 second would be adequate I suppose. >> Could some variation of the fuel level flicker filter do ? >> >> Thanks in advance for your suggestions, and keep on the good job > > Referring to the assembly details in . . . > > http://tinyurl.com/nxmo3us > > That comparator only has about 0.5% hysteresis . . . > try reducing the value of R108 down to 100K > which will raise the hysteresis by a factor of ~5x Hi Bob, Thank you for responding. What I did not state clearly is that somewhere along the build we switched from Aeroelectric's battery management module to Perihelion's because for some reasons we could not discover, the ABMM did not like the presence of EV200 contactors. Since the new battery management module is potted, I was wondering if a proper filter could be devised as a "bolt-on" unit to be insered in series on the sense - or the contactor actuation - side. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: May 06, 2014
> >Hi Bob, > >Thank you for responding. >What I did not state clearly is that somewhere along the build we >switched from Aeroelectric's battery management module to >Perihelion's because for some reasons we could not discover, the >ABMM did not like the presence of EV200 contactors. >Since the new battery management module is potted, I was wondering >if a proper filter could be devised as a "bolt-on" unit to be >insered in series on the sense - or the contactor actuation - side. oh . . . okay . . . wish we'd talked about this earlier . . . The EV200 contactors are known noise sources. Not sure why, it's not difficult to control. I think I've got a sample from the factory around here somewhere. Might see if I can get a peek at it in the lab with some really good equipment. In the mean time, I take it that the original ABMM is no longer available. You'd have to check with Eric on his recommendations but I'm guessing that you might get away with feeding the ABMM's + input terminal through a diode (Schottky would be best but not critical). Then put a capacitor across the ABMM input power terminals . . . something like 100uF. This would drive the module at the higher voltage more consistent with the peaks. As an aside, I'm studying a line of rectifier regulators for PM alternators, both single and 3-phase, that are head-and-shoulders above legacy technologies for voltage regulation stability. Further, they are thermally robust. The Ducati R/R supplied with the Rotax engines is pretty sorry compared to these new ones. Just getting a REAL regulator on your airplane may make Eric's ABMM happier too. Bob . . . ________________________________________________________________________________
Date: May 06, 2014
failing? At 05:41 PM 5/6/2014, you wrote: > >Bob(s) and Joe, > >It's not about poor "service" from this list. Quite the contrary. >And the great body of knowledge herein is why I came to this list to >find out the answer to my questions. I have learned so much here >it's why I have been able to create and wire my plane. Couldn't have >done it without you. > Not having full understanding of an LED is why I used the mini > bulb. Your explanations made the use of the LED so much clearer > that I could have used it had I seen your posts before I chickened > out and installed the mini bulb. When the mini bulb fails, I'll try > the LED. Although, the mini bulb has a 5k hours ave life! Also, I > was not able to test the LED by running the starter. Also, the two > original diagrams showing two different ways to add the diode to > the circuit had me wondering which was correct. I saw those . . . and didn't see a difference in them . . . > As far as monitoring the starter contactor rather than the > terminals on the starter, I have to say I followed an old drawing I > had from the aeroelectric.com site. It was > >http://www.aeroelectric.com/Pictures/Contactors/Starter_Contactor/s702wire.jpg > it's still there. it got filed under "Starter Contactors" http://tinyurl.com/o5turon >When I search for it now, I find I am not able to access it. It was >a picture of an auto style start contactor with two large posts and >two small posts. The small posts were labelled S and I. The picture >said the I post could be used for a starter monitoring light. I'll >agree the starter would be a better device to monitor. THanks for the tips. The wiring suggested in S702wire.jpg might make more sense if you saw the schematic . . . Actually, the "I" terminal is just fine . . . that's a THIRD stationary contact within the S702-1 contactor that duplicates the connections between the two FAT terminals thusly . . . Emacs! Bob . . . ________________________________________________________________________________
Subject: Re: Single ground vs. distributed ground
Date: May 06, 2014
Don, I have a Glasair (i.e. all fiberglass) airplane, which I bought rather than built. I am rewiring to install new equipment and I've discovered no less than 5 grounding locations. I have one (large) main ground bus, along with smaller ground buses located in various regions behind the panel: one on the floor, one on the pilot's side, one on the side of my nag/com stack, etc. So long as these buses are connected and that you stay away from ground loops, you should be fine with multiple grounds. My radios and such were fine before I tore everything apart. The only issue I had was loose/improperly installed coax connectors and a bum engine monitor. Be sure to keep your maximum voltage drop to less than 0.5V (as per the AC 43.13-2B) if you have a 14V system. I am increasing a few of my ground wires between the various smaller ground buses or terminal blocks: maybe from a #14 AWG up to a #12 or #10 AWG. I run a 60A alternator and use #4 AWG for my battery and starter (long runs) but a #6 AWG for my alternator line to the hot bus. My battery has two #4 AWG ground lines, one running to the main ground bus while the other runs to the engine case. Moderation is always a plus, but having more than one ground bus in a glass airplane is not the end of the world. Plan your layout well, as I can attest to the fact that trying to track a rat's nest of wires after the fact is NOT fun. Best wishes and have fun! Travis Los Alamos, NM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422938#422938 ________________________________________________________________________________
Subject: Special Coax Connectors: Apollo Nav/Coms...
Date: May 06, 2014
Hello, I am looking for some (apparently) special coax connectors for my Apollo (now Garmin) nav/coms. The old connectors are made by Delta Electronics Manufacturing Corp., part number 4205018N995-000, and are slip-on on one side with a metal flare to help guide the radio coax connector into place, then a center-wire solder and twist-on shielding connection the other end. There are two rectangular flanges for mounting to the nav/com tray. I am told that these are standard for the older Apollo radios but they are somewhat difficult to come by. If anyone is selling any or knows of anyone who has any, i would appreciate it. These connectors float on the tray, which also helps for easy alignment when sliding the radio into the tray. I just need new connectors so I can switch to my RG400 coax from the RG58. Let's see if I can add some photos. -------- Travis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422941#422941 Attachments: http://forums.matronics.com//files/img_20140504_094054_732.jpg http://forums.matronics.com//files/img_20140504_094042_166.jpg http://forums.matronics.com//files/img_20140504_094028_185.jpg http://forums.matronics.com//files/img_20140504_094003_108.jpg ________________________________________________________________________________
Date: May 06, 2014
Subject: Re: Special Coax Connectors: Apollo Nav/Coms...
Why go to all the bother of upgrading to RG400 for nav/coms?? They are in the 108-137MHz range, where there is not much performance difference between the RRG-58 and RG-400. Properly installed RG58 with decent antennas can give over 100nm range. How much more do you need?? On 5/6/2014 9:12 PM, Dragoon6 wrote: > > Hello, > > I am looking for some (apparently) special coax connectors for my Apollo (now Garmin) nav/coms. The old connectors are made by Delta Electronics Manufacturing Corp., part number 4205018N995-000, and are slip-on on one side with a metal flare to help guide the radio coax connector into place, then a center-wire solder and twist-on shielding connection the other end. There are two rectangular flanges for mounting to the nav/com tray. > > I am told that these are standard for the older Apollo radios but they are somewhat difficult to come by. If anyone is selling any or knows of anyone who has any, i would appreciate it. > > These connectors float on the tray, which also helps for easy alignment when sliding the radio into the tray. I just need new connectors so I can switch to my RG400 coax from the RG58. Let's see if I can add some photos. > > -------- > Travis > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422941#422941 > > > Attachments: > > http://forums.matronics.com//files/img_20140504_094054_732.jpg > http://forums.matronics.com//files/img_20140504_094042_166.jpg > http://forums.matronics.com//files/img_20140504_094028_185.jpg > http://forums.matronics.com//files/img_20140504_094003_108.jpg > > ________________________________________________________________________________
Subject: Re: connectors
Date: May 07, 2014
I have been engaged in a futile search trying to find the d-sub connectors that go between a Gat 1 link trainer and it's recorder and it's performance indicator. The body of the male,pin, connector is part No. 200345-2 and I think the socket part no. is 200346-2. I need two female and three male sockets and the backshells and fasteners that go with them. Does anyone know where I might find these old connectors ? ____________________________________________________________ FREE Stock Report How to Invest in the $70 Billion Bottled Water Boom http://thirdpartyoffers.juno.com/TGL3141/536a37a3a92c037a268cbst04vuc ________________________________________________________________________________
Date: May 07, 2014
> > I have been engaged in a futile search trying to find the d-sub > connectors that go between a Gat 1 link trainer and it's recorder > and it's performance indicator. > The body of the male,pin, connector is part No. 200345-2 and I > think the socket part no. is 200346-2. > I need two female and three male sockets and the backshells > and fasteners that go with them. Does anyone know where I > might find these old connectors ? D-subs have not changed much over many years. If these are, in fact, D-subs you should be able to identify them by the number of rows of pins and number of pins. Go to your local Radio Shack and they will probably have them. Roger ________________________________________________________________________________
Date: May 07, 2014
Larry,=0A=0AI did a search on GAT-1 flight simulator and the search return ed a number of links which could be of assistance. =C2-It included units on e-Bay, boxes of manuals & spare parts, etc.=0A=0AGive that a try...=0A Blue skies & tailwinds,=0ABob Borger=0AEuropa XS Tri, Rotax 914 w/ Interco oler & Airmaster C/S Prop=0ALittle Toot Sport Biplane, Lycoming AEIO-320 E XP=0A3705 Lynchburg Dr.=0ACorinth, TX 76208-5331=0AH: 940-497-2123=0AC: 81 7-992-1117=0A=0AOn May 07, 2014, at 08:39 AM, Larry Mac Donald =0A=0AI have been engaged in a futile s earch trying to find the d-sub =0Aconnectors that go between a Gat 1 link trainer and it's recorder =0Aand it's performance indicator.=0AThe body of the male,pin, connector is part No. 200345-2 and I=0Athink the socket par t no. is 200346-2.=0AI need two female and three male sockets and the back shells =0Aand fasteners that go with them. Does anyone know where I =0Amig ht find these old connectors ?=0A_________________________________________ ___________________=0AFREE Stock Report=0AHow to Invest in the $70 Billion Bottled Water Boom=0Ahttp://thirdpartyoffers.juno.com/TGL3141/536a37a3a92 ========0A=0A=0A=0A ________________________________________________________________________________
Date: May 07, 2014
At 08:39 AM 5/7/2014, you wrote: > >I have been engaged in a futile search trying to find the d-sub >connectors that go between a Gat 1 link trainer and it's recorder >and it's performance indicator. >The body of the male,pin, connector is part No. 200345-2 and I >think the socket part no. is 200346-2. >I need two female and three male sockets and the backshells >and fasteners that go with them. Does anyone know where I >might find these old connectors ? Actually, those are a pretty vintage connector. I think the first time I saw them on a piece of avionics they were called "Winchester" connectors. Amp took them over as their "M" series and now they're TE (Tyco Connectivity) parts and going obsolete. Everything you wanted to know about these connectors and mating parts is here http://tinyurl.com/n5elt9t Newark, Allied, Mouser et. als. may have some stocks. Otherwise, your doomed to beating the bushes of the obsolete and wayward parts brokers . . . http://tinyurl.com/l32clrc Bob . . . ________________________________________________________________________________
Date: May 07, 2014
At 11:12 PM 5/6/2014, you wrote: > > >Hello, > >I am looking for some (apparently) special coax connectors for my >Apollo (now Garmin) nav/coms. The old connectors are made by Delta >Electronics Manufacturing Corp., part number 4205018N995-000, and >are slip-on on one side with a metal flare to help guide the radio >coax connector into place, then a center-wire solder and twist-on >shielding connection the other end. There are two rectangular >flanges for mounting to the nav/com tray. > >I am told that these are standard for the older Apollo radios but >they are somewhat difficult to come by. If anyone is selling any or >knows of anyone who has any, i would appreciate it. > >These connectors float on the tray, which also helps for easy >alignment when sliding the radio into the tray. I just need new >connectors so I can switch to my RG400 coax from the RG58. Let's see >if I can add some photos. Those are a real odd-ball tray connector for coax. Most manufacturers went with the TED 9-29-10 connector . . . legend has it that they designed that connector for Ed King waaaayyyy back when. They became popular and were adopted by almost everybody and are still in production. http://tinyurl.com/ob7xtyq I've never encountered the connector you've cited. If you could get me some clearer photos, I'd like to add them to the archives. As to your particular question, are you replacing RG58 because it's damaged or now too short? As Kelly pointed out, unless there are mechanical reasons for replacing the coax, performance gains for replacing it are trivial. Can you unscrew the cap on the back of the connector? I think you'll find an access port to a soldered connection to center conductor under that cap. I note that the shield connection appears to be the legacy BNC-style clamp-ring and gasket. With some care on the workbench, you can salvage and reinstall the old connector. If coax replacement IS indicated, you can also cut off the old RG58 to leave a 6" or so flying lead which you can terminate with a cable female BNC . . . then extend your new installation from that point without risk to the old connector. I'll bet that critter is not easy to find and probably expensive if you do find it. Bob . . . ________________________________________________________________________________
Date: May 07, 2014
Hi Bob, I don't believe he's talking about those (king/icom/etc..)...I think specifically the Delta P/N mentioned used by Apollo/UPSat/Garmin...which are these (not my picture): http://2.bp.blogspot.com/-FBkFonYU8-0/UUHdBy2NWmI/AAAAAAAAHW0/FYiLVN28ZB0/s4 00/IMG_2594.JPG As noted, you can easily install RG58 or RG400 into this connector and they are reusable. They are rare because they are no longer in production, but we have a slew of them in stock just due to normal business with these over the years. What's harder to find is the little shoulder nuts that allow those to float...we have to turn some down by hand on the lathe if we need them! Cheers, Stein -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, May 07, 2014 10:13 AM Subject: Re: AeroElectric-List: Special Coax Connectors: Apollo Nav/Coms... --> At 11:12 PM 5/6/2014, you wrote: > > Those are a real odd-ball tray connector for coax. Most manufacturers went with the TED 9-29-10 connector . . . legend has it that they designed that connector for Ed King waaaayyyy back when. They became popular and were adopted by almost everybody and are still in production. http://tinyurl.com/ob7xtyq I've never encountered the connector you've cited. If you could get me some clearer photos, I'd like to add them to the archives. As to your particular question, are you replacing RG58 because it's damaged or now too short? As Kelly pointed out, unless there are mechanical reasons for replacing the coax, performance gains for replacing it are trivial. Can you unscrew the cap on the back of the connector? I think you'll find an access port to a soldered connection to center conductor under that cap. I note that the shield connection appears to be the legacy BNC-style clamp-ring and gasket. With some care on the workbench, you can salvage and reinstall the old connector. If coax replacement IS indicated, you can also cut off the old RG58 to leave a 6" or so flying lead which you can terminate with a cable female BNC . . . then extend your new installation from that point without risk to the old connector. I'll bet that critter is not easy to find and probably expensive if you do find it. Bob . . . ________________________________________________________________________________
Date: May 07, 2014
Subject: stuck starter motor
If you put a lamp on the I terminal of the contactor it will indicate a stuck contactor, and probably a running starter motor. If you put the bulb across the starter, it will only indicate if the starter has voltage going to it, i.e. stuck contactor. If the starter engagement device (Bendix) is stuck to keep the motor running without the contactor being engaged there will be no voltage generated unless it is a permanent magnet starter motor. Unless the old Delco starter has enough residual magnetism (does it?) in the field to light a bulb, be it an incandescent or and LED. I'll take the connection to the I terminal, thank you. Jurgen Amtmann, RV6 ________________________________________________________________________________
Date: May 07, 2014
Oh!! Stein, can you send me that schematic in the background (installation instructions for this Delta connector) of the image you attached to your reply? Knowing the proper installation procedures would help if I have to re-use the old connectors. >From your image I see that RG400 can, in fact, work in this style of connector. That's very reassuring. Rather than leave a pig tail of RG58 on the back of the tray, I'd rather go with RG400 the whole way. I've been busy and have not been able to locate any Delta Electronics Manufacturing Corp. distributors: DEMC would not sell directly to me as I'm not a business. Stein, if you know where I could get 4 to 6 of these connectors that would be great. Just the installation instructions though would be a big plus. Travis Los Alamos, NM adverb.elephant(at)gmail.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422982#422982 ________________________________________________________________________________
Subject: Fusable link
Date: May 08, 2014
Hi Guys (Bob) I see that Z11 is using a fuse block as opposed the CBs (no problem there), can you tell me why the feed to the 5a CB has a fuse able link, why not use a fuse in the distribution fuse block Best regards John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422991#422991 ________________________________________________________________________________
Subject: Re: Fusable link
Date: May 08, 2014
Ps: the 5amp CB did relate to the alternator feed circuit John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422992#422992 ________________________________________________________________________________
Date: May 08, 2014
At 06:09 AM 5/8/2014, you wrote: Hi Guys (Bob) I see that Z11 is using a fuse block as opposed the CBs (no problem there), can you tell me why the feed to the 5a CB has a fuse able link, why not use a fuse in the distribution fuse block Best regards John The length of wire from fuse block feeder terminal out to the circuit breaker is an EXTENSION of the bus. In larger aircraft the bus feeders will sometimes be protected by a VERY robust fusible device like the ANN/ANL series of "current limiters" . . . http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bu http://tinyurl.com/lrjm5y3 http://tinyurl.com/k7o3l3q Note that these devices, while 'rated' at some value like 100A, they will CARRY 2x their rated current almost indefinitely. At the same time, when subjected to a hard fault of 5 to 10x rated current, they open in tens of milliseconds. Legacy design goals for aircraft suggest that this extension of the bus up to your panel mounted circuit breaker needs a 'current limiter' but not like the devices cited above. It's much smaller and designed to protect the longer run of wire to the breaker. Protection with a response many times longer than the breaker it feeds. This question came up on the List a few years ago . . . Q: Drawing Z24 shows how to add an OV protection module for an internally regulated power supply. It requires the use of a 5A circuit breaker and also of a fuselink attached to the main connection of the main bus. The question: Can we replace the fuselink by using one of the outputs on the main bus protected by a larger fuse (say 15amps)? I would like for sure the breaker to let go before the fuse. A: Some 5A breakers will open a 15A fuse. Fuses are MUCH faster than breakers. This is why I prefer the fusible link The risks of positioning fuses upstream of breakers is illustrated in the accident case I chronicled here http://tinyurl.com/msfmldj and demonstrated here http://tinyurl.com/ppdv5fg The automotive world has used fusible links in this capacity for decades and they've served well in the capacity of mini-limiters. Bob . . . ________________________________________________________________________________
Date: May 08, 2014
Subject: FYI - LMR195 coax
I installed a new antenna on the roof yesterday and wired it to the radio with LMR195 coax. While this stuff has appealing performance specs, it is NOT a drop-in-replacement for the legacy coaxes that feature one or more braided outer conductors. Emacs! Unlike the RG142 illustrated above I found that the braid wires on this coax are very small and few. The coax's shield performance is bounded by the foil shield. The outer braid is just a means by which connection can be made to the foil and is relatively fragile compared to the two heavy layers of braid in RG142/400 The installer must take extra care in the 3rd cut and removal of the outer jacket so as not to damage the braid. Further, the 2nd cut designed to remove the shield from a stub of center insulation is problematic. Again, depth of cut and subsequent removal of the foil shield (tightly bonded to the insulation) is tricky. I got my connectors installed and the feed line performs as expected . . . but I would caution builders to work with some scraps of this coax and some 'training connectors' to refine their technique. I'll put LMR195 coax termination on the list of comic books to be crafted for the website. Bob . . . ________________________________________________________________________________
Date: May 08, 2014
So a ANL current limiter off the main battery protecting the whole system would not be a bad idea ? John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423017#423017 ________________________________________________________________________________
Date: May 08, 2014
At 01:21 PM 5/8/2014, you wrote: > > >So a ANL current limiter off the main battery protecting the whole >system would not be a bad idea ? Not a bad idea . . . but not a good one either. Current limiters have value for fault isolation in complex bus structures . . . which are generally not found in Part 23 airplanes. The fat wires between battery, main bus and starter terminal are usually of such robustness that any fault to ground would be more likely to burn a hole in fault location as opposed to opening any limiter in the path. Single light TC aircraft have never been fitted with such protection that I know of. Bob . . . ________________________________________________________________________________
Date: May 08, 2014
=0A=0AFrom: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>=0ATo: aeroelectric-list(at)matronics.com =0ASent: Thursday, May 8, 2014 5:32 PM=0AS ubject: Re: AeroElectric-List: Re: Fusable link=0A =0A=0A--> AeroElectric-L ist message posted by: "Robert L. Nuckolls, III" <nuckolls.bob@aeroelectric .com>=0A=0AAt 01:21 PM 5/8/2014, you wrote:=0A>--> AeroElectric-List messag e posted by: "JOHN TIPTON" =0A>=0A>=0A>So a ANL c urrent limiter off the main battery protecting the whole =0A>system would n ot be a bad idea ?=0A=0A- Not a bad idea . . . but not a good one either . Current=0A- limiters have value for fault isolation in complex bus=0A - structures . . . which are generally not found in Part=0A- 23 airpl anes.=0A=0A- The fat wires between battery, main bus and starter=0A- terminal are usually of such robustness that any=0A- fault to ground wou ld be more likely to burn a hole=0A- in fault location as opposed to ope ning any limiter=0A- in the path.=0A=0ANot sure what that means... ??? - =0A=0AIf it is "robust" wouldn't it carry enough current to blow the li miter?=0AAre you suggesting that "welding/burning" aluminum does not draw a lot of current?=0AHave you ever tested that hypothesis?=0A=0AEven if some of the above is true, a current limiter still could provide some protection =0Afrom a "hard" fault, could it not?=0A=0A-Jeff=0A=0A=0A- Single light TC aircraft have never been fitted with=0A- such protection that I know - - - - - - - - - - - - - -Matt Dralle, List Adm ===== ________________________________________________________________________________
Date: May 09, 2014
> >Not sure what that means... ??? > >If it is "robust" wouldn't it carry enough current to blow the limiter? >Are you suggesting that "welding/burning" aluminum does not draw a >lot of current? >Have you ever tested that hypothesis? Actually, it doesn't. Recall the anecdote about the C90 parting and elevator control cable with a soft fault to a wire. A 40A breaker didn't trip nor was the wire itself seriously damaged. http://tinyurl.com/n3dqkb2 >Even if some of the above is true, a current limiter still could >provide some protection >from a "hard" fault, could it not? Define 'hard' fault . . . and hypothesize how one comes into existence. What kind of circuit closure has to happen to carry hundreds of amps of current? Consider how a contactor is built specific to that goal. Now, how does such a connection happen along the pathway for a fat wire as it travels about the airplane? The #1 failure in wires is simple disconnect. #2 is insulation failure by virtue of mechanical intrusion . . . abrasion or sharp edge cutting due to poor support combined with vibration. What is the quality of first contact? It's tentative, low force, high resistance event that produces some arcing but is generally far short of that required to put the wire at risk or even open it's upstream current limiter. Then there's the probability: #1 failure is rare, #2 several magnitudes more rare, and if a composite airplane, a few magnitudes more rare yet. The few times I've seen the result of a battery cable insulation chaffing and taking the conductor to ground, the fault self cleared when the offending aluminum burned away. When breakers open in airplanes, the most likely cause is failure in the powered device . . . not because of compromised insulation in the wire-run. If you want to put a current limiter in your battery line, by all means. I'm only suggesting that your airplane will be one of a very few in a constellation of tens of thousands. Bob . . . ________________________________________________________________________________
Subject: how to build a 16AWG fuse link
Date: May 09, 2014
I'm building a 16 AWG fuse link for a 12AWG wire (the one that goes from the Alternator to the starter contactor in e.g. Z16M). I was thinking of simply solder splicing a piece of 16AWG onto the end of the 12AWG wire and heat-shrinking the whole thing. Is that correct or is there anything else I need to know? The link at http://www.aeroelectric.com/articles/fuselink/fuselink.html says "contact us for manufacturing larger fuselinks than 20AWG" so I was left wondering. Sacha ________________________________________________________________________________
Date: May 09, 2014
=0A=0A=0A=0A________________________________=0A From: "Robert L. Nuckolls, III" =0ATo: aeroelectric-list(at)matronics.com =0ASent: Friday, May 9, 2014 3:00 AM=0ASubject: Re: AeroElectric-List: Re: uckolls, III" =0A=0A=0A>=0A>Not sure what th at means... ???=0A>=0A>If it is "robust" wouldn't it carry enough current t o blow the limiter?=0A>Are you suggesting that "welding/burning" aluminum d oes not draw a =0A>lot of current?=0A>Have you ever tested that hypothesis? =0A=0A=0A- - Actually, it doesn't. Recall the anecdote about=0A- - the C90 parting and elevator control cable with=0A- - a soft fault to a wire. A 40A breaker didn't trip=0A- - nor was the wire itself seriousl y damaged.=0A=0Ahttp://tinyurl.com/n3dqkb2=0A=0A=0A>Even if some of the abo ve is true, a current limiter still could =0A>provide some protection=0A>fr om a "hard" fault, could it not?=0A=0A- - Define 'hard' fault . . . and hypothesize how=0A- - one comes into existence.=0A=0ABob - I think you side stepped the question...=0A=0A".. current limiter still could =0Aprovi de some protection=0Afrom a "hard" fault, could it not? "=0A=0Aregardless o f how the hard fault happens.=0A=0ALet's consider the worst case scenario w here=0Awe have a crash and a hard-fault occurs.=0A=0A=0A=0A- - What kin d of circuit closure has to happen to=0A- - carry hundreds of amps of c urrent? Consider=0A- - how a contactor is built specific to=0A- - t hat goal. Now, how does such a connection=0A- - happen along the pathwa y for a fat wire as=0A- - it travels about the airplane?=0A=0A- - T he #1 failure in wires is simple disconnect.=0A- - #2 is insulation fai lure by virtue of mechanical=0A- - intrusion . . . abrasion or sharp ed ge cutting=0A- - due to poor support combined with vibration.=0A- - What is the quality of first contact? It's tentative,=0A- - low force, high resistance event that produces=0A- - some arcing but is generally far short of that=0A- - required to put the wire at risk or even open =0A- - it's upstream current limiter.=0A=0A- - Then there's the pro bability: #1 failure=0A- - is rare, #2 several magnitudes more rare, an d=0A- - if a composite airplane, a few magnitudes more=0A- - rare y et.=0A=0A- - The few times I've seen the result of a battery=0A- - cable insulation chaffing and taking the conductor=0A- - to ground, the fault self cleared when the offending=0A- - aluminum burned away. When breakers open in=0A- - airplanes, the most likely cause is failure=0A - - in the powered device . . . not because of=0A- - compromised in sulation in the wire-run.=0A=0A- - If you want to put a current limiter in your=0A- - battery line, by all means. I'm only suggesting=0A- - that your airplane will be one of a very few=0A- - in a constellati ============== ________________________________________________________________________________
Date: May 09, 2014
Subject: Re: how to build a 16AWG fuse link
At 08:09 AM 5/9/2014, you wrote: > >I'm building a 16 AWG fuse link for a 12AWG wire (the one that goes from the >Alternator to the starter contactor in e.g. Z16M). > >I was thinking of simply solder splicing a piece of 16AWG onto the end of >the 12AWG wire and heat-shrinking the whole thing. Is that correct or is >there anything else I need to know? > >The link at http://www.aeroelectric.com/articles/fuselink/fuselink.html says >"contact us for manufacturing larger fuselinks than 20AWG" so I was left >wondering. Solder and shrink would be fine. An alternative would be a COTS automotive offering: http://tinyurl.com/kuroczv I'm going to revise that drawing in the future to put a MAXI fuse holder or perhaps one of these in that location. http://tinyurl.com/kyu8huo I've got some of these in surplus stock. I'll mail you one if you want to go that route. Bob . . . ________________________________________________________________________________
Subject: Re: How to lose both ignition systems?
Date: May 09, 2014
Hello Bob and AEC. Can we re visit this one. I've read the NTSB accident natative, but I need a sketch to follow this builders mistake. Thanks, Bill nuckolls.bob(at)aeroelect wrote: > At 03:29 PM 8/29/2013, you wrote: > > > > > > > > > Bob, I was at your seminar at EAA431Brodhead, WI this Spring. > > > > There was a discussion on an accident involving a Lancair Dual LSE > > Ignition failure. I could not find it in a simple NSTB search > > assuming I even have enough details right to do so. > > > > The builder had supplied each LSE from an independent source, but > > failed to consider something else. Something about fuse & CB's in series maybe? > > > > Can you detail what happened to take down both LSE's? It's likely > > that sketch will be necessary. > > > > > > Yes. That case settled a few weeks ago. I'm going to publish > my reports and demonstration videos that were produced in > support of the technical analysis. I need to 'sanitize' them > a little so as to avoid causing unwarranted discomfort on > the part of the participants. > > In any case, it is unlikely that anyone here on the > List would repeat the error . . . an error that grew out > of a combination of 'redundancy' features stacked on top > of each other combined with a poor selection of components > wherein both systems shared hardware in the power path. > > Run each ignition from a separate protective device on > the battery bus . . . or separate battery busses if there > are two batteries. Simple, direct, no shared hardware > and truly redundant. > > > > > > Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423077#423077 ________________________________________________________________________________
Date: May 09, 2014
At 12:47 PM 5/9/2014, you wrote: > > >Hello Bob and AEC. >Can we re visit this one. I've read the NTSB accident natative, but >I need a sketch to follow this builders mistake. > >Thanks, Bill > See N811HB at . . . http://tinyurl.com/ky7szec . . . for a detailed data dump Bob . . . ________________________________________________________________________________
Date: May 09, 2014
Thanks Bob. I was thinking a 30A slow blow fuse (they only exist in Maxi blade sizes) might be appropriate but I can't find one here locally nor an appropriately sized fuse holder. I'd be happy to buy a couple off you if you have some spares (i say a couple as I could use one on one of the circuits on my sailboat too). > On May 9, 2014, at 18:07, "Robert L. Nuckolls, III" wrote: > > > At 08:09 AM 5/9/2014, you wrote: >> >> I'm building a 16 AWG fuse link for a 12AWG wire (the one that goes from the >> Alternator to the starter contactor in e.g. Z16M). >> >> I was thinking of simply solder splicing a piece of 16AWG onto the end of >> the 12AWG wire and heat-shrinking the whole thing. Is that correct or is >> there anything else I need to know? >> >> The link at http://www.aeroelectric.com/articles/fuselink/fuselink.html says >> "contact us for manufacturing larger fuselinks than 20AWG" so I was left >> wondering. > > Solder and shrink would be fine. An alternative > would be a COTS automotive offering: > > http://tinyurl.com/kuroczv > > I'm going to revise that drawing in the future to put a > MAXI fuse holder or perhaps one of these > in that location. > > http://tinyurl.com/kyu8huo > > I've got some of these in surplus stock. I'll > mail you one if you want to go that route. > > > > > > Bob . . . > > > > ________________________________________________________________________________
Date: May 09, 2014
At 04:08 PM 5/9/2014, you wrote: > >Thanks Bob. >I was thinking a 30A slow blow fuse (they only exist in Maxi blade >sizes) might be appropriate but I can't find one here locally nor an >appropriately sized fuse holder. Doesn't need to be "slow blo" . . . unless they've upsized your alternator, it's only good for about 20A, A 30A fuse of any style would be find. Bob . . . ________________________________________________________________________________
Subject: When to use Shielded Wire?
Date: May 09, 2014
I am getting ready to purchase the wire for my project and need to know what wire to purchase. I have read Bobs articles and plan to purchase 18 and 22 gauge wire. I have an EFIS, Garmin 430, PS Engineering Audio Panel, and a KT76 transponder. I will have electronic ignition and LED lights. My question is what wire needs to be shielded and what wire doesnt need shielding? Is it better to just use shielded wire on everything? Seems like extra weight. Is it better to use shielded wire with numerous separate wires inside? or shielded wire with a single wire inside the shielding? Thanks for the help! Justin ________________________________________________________________________________
Date: May 10, 2014
Subject: Re: When to use Shielded Wire?
At 10:58 PM 5/9/2014, you wrote: I am getting ready to purchase the wire for my project and need to know what wire to purchase. I have read Bob's articles and plan to purchase 18 and 22 gauge wire. I have an EFIS, Garmin 430, PS Engineering Audio Panel, and a KT76 transponder. I will have electronic ignition and LED lights. My question is what wire needs to be shielded and what wire doesn't need shielding? Is it better to just use shielded wire on everything? Seems like extra weight. Is it better to use shielded wire with numerous separate wires inside? or shielded wire with a single wire inside the shielding? Shielding of wires is the weakest of prophylactics against propagation of noise . . . and then effective on a very narrow range of antagonists. If you run two wires side-by-side in the same bundle wherein one wire carries something like millivolt levels of audio from one box to the other (potential victim wire) and the other wire carries some form of electronic violence (potential antagonist wire) then there is a potential for undesirable coupling of energy from the former into the later. Coupling in wire bundles predominates in two forms. Magnetic and electro-static. If the electronic violence is in the form of a high current where the antagonist wire presents a strong local magnetic field, then the effects of that field will be impressed upon the victim wire "longitudinally". The fix for this propagation mode is to break the common longitudinal path (read ground loop) by means of techniques like running potential victim signals on twisted pairs . . .perhaps even transformer coupled at one end. In other words, this propagation mode is best broken by judicious architecture of the victim's i/o ports. If the electronic violence is in the form of high voltage, fast rise-time wave-forms (like magneto p-leads and strobe trigger pulses) then the propagation mode becomes electro-static. The insulation around antagonist and victim wires become 'dielectric' components of a capacitor Albeit a tiny capacitor, effects of the signals on one wire can be impressed on top of the tiny signals in the other. This propagation mode can be broken by shielding one or the other of the two wires. It's best to shield the single antagonist (like the p-lead) so that you don't have to shield a hand-full of potential victims. MIL-STD-704/DO-160 design goals dictate that a product intended for installation on airplanes demonstrate minimum levels of immunity to external stresses along with limits to emitted violence. Products qualified to these design goals are expected to function in communal harmony WITHOUT special attention from the designers or installers of the system. I.e. no automatic inclusion of EXTERNAL prophylactics against propagation of noise. In some few cases (like p-leads and strobe wiring) electronic violence in the wires is a fundamental component of that system's functionality. I.e. it cannot be avoided. Hence, the learned designers and installers of such systems will take judicious steps to contain the noise. I.e. shielded wires and/or p-lead filters installed at the magnetos. Outside these special cases the system integrator. YOU, is held harmless from the need to worry about piling on more prophylactics against noise. The numbers and brutishness of such systems has been declining. "P-leads" from electronic ignitions don't carry magneto-like trash. LED strobes don't utilize fast-rise, HV trigger pulses. Given these advances in system features, I'd venture an assertion that the value of shielding of any wires in an airplane is minimal if not zero. The short answer to you question is: Unless called out on the installation drawings for a device, you don't need to shield the wires. Legacy practices for shielding wires in the communication and navigation systems is a hedge against poor practice in the design or wiring of a potentially antagonistic system that shares the wire bundle. If it's not on the drawing, don't shield it. Bob . . . ________________________________________________________________________________
Date: May 10, 2014
At 12:47 PM 5/9/2014, you wrote: > > >Hello Bob and AEC. >Can we re visit this one. I've read the NTSB accident natative, but >I need a sketch to follow this builders mistake. Bill, I didn't remember that the file-set I posted had a few of holes in it. hit these three links . . . http://tinyurl.com/kyfn4y2 http://tinyurl.com/lmbbrmg and particularly . . . this one http://tinyurl.com/k5593wo Bob . . . ________________________________________________________________________________
Date: May 10, 2014
Subject: 43o Card Edge Connector
I'm looking for help on what orientation the card edge connector used for shield termination on the back of a Garmin 430 should be inserted. It's a Garmin 336-00029-00 or AMP 583853-4 card edge connector. It has a "spring" side and a "barb" side. Not sure what to actually call them and that's the best I can do. :) Should the "barb" side face in, up, out or down in relation to the termination block when inserting on the back of the 430? Thanks, -Sean ________________________________________________________________________________
Subject: Re: 43o Card Edge Connector
Date: May 10, 2014
Can't answer your question, but FWIW, I don't use it. I really like Bob's avionics ground bus, I use one mounted close to the back of the radio stack. Tim > On May 10, 2014, at 3:35 PM, Sean Stephens wrote: > > > I'm looking for help on what orientation the card edge connector used for shield termination on the back of a Garmin 430 should be inserted. > > It's a Garmin 336-00029-00 or AMP 583853-4 card edge connector. It has a "spring" side and a "barb" side. Not sure what to actually call them and that's the best I can do. :) > > Should the "barb" side face in, up, out or down in relation to the termination block when inserting on the back of the 430? > > Thanks, > > -Sean > > > > ________________________________________________________________________________
Date: May 12, 2014
For those interested, I found the answer. The "spring" side of the connector is oriented on the inside of the termination block so it contacts the "card edge". > Tim Andres > May 10, 2014 at 7:26 PM > > > Can't answer your question, but FWIW, I don't use it. I really like > Bob's avionics ground bus, I use one mounted close to the back of the > radio stack. > Tim > > ________________________________________________________________________________
Date: May 14, 2014
Subject: Alternator Field Wiring Approaches
I just noticed an interesting wiring difference between Tony Bingelis' diagram on page 212 of Firewall Forward and the typical AeroElectric diagram. I bring this up as an interesting learning opportunity. On Z13-8 the 5A field breaker is fed from the main power bus. On Tony's diagram, it is fed from the 60A alternator breaker. Z13-8 has replaced this with an ANL current limiter, which is not pertinent to this discussion. The Z13-8 current limiter is located at the starter contactor, which avoids bringing the 4AWG wiring into the cockpit, which is obviously preferable. To me, the biggest consequence of the Z13-8 approach is that if the ANL current limiter blows, the regulator (sensing the sagging bus voltage) will attempt to drive the alternator to full output, which would be a "bad thing", since the output is likely shorted to ground. With Tony's approach, the voltage sensing path is unbroken when the 60A breaker pops. I say "bad thing", since I expect Bob to remind us the damages in this situation are inadequately qualified, probably not life-threatening, and besides, the alternator is self-limited to its maximum rating, which will probably clear the short. With Tony's approach, there would be much less of the "bad thing" :-) However, to gain the advantage of Tony's approach, some disadvantages must be accepted. Since we prefer the ANL current limiter be connected as shown at the starter contactor, it would mean we would have to run the wire from the 5A field breaker through the firewall. This would further mean more connections and more wire in the voltage sensing path, resulting is less accurate voltage regulation. Since the "bad thing" is not life-threatening, and extremely unlikely, it makes sense to me to use the Z13-8 approach, which provides shorter and more reliable wiring and better voltage regulation. I will be interested in others opinions of the two approaches. Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: May 14, 2014
Subject: Re: Alternator Field Wiring Approaches
where can we see a drawing of Tony's design?=0A=0AIt's tough to discuss w/o seeing the diagram...=0A=0A=0A=0A________________________________=0A From: Jeff Page =0ATo: Aero_Electric_List =0ASent: Wednesday, May 14, 2014 11:17 AM=0ASubject: AeroElect ric-List: Alternator Field Wiring Approaches=0A =0A=0A--> AeroElectric-List message posted by: Jeff Page =0A=0AI just noticed an inte resting wiring difference between Tony Bingelis'- =0Adiagram on page 212 of Firewall Forward and the typical AeroElectric- =0Adiagram.- I bring this up as an interesting learning opportunity.=0A=0AOn Z13-8 the 5A field breaker is fed from the main power bus.=0A=0AOn Tony's diagram, it is fed f rom the 60A alternator breaker.- Z13-8- =0Ahas replaced this with an AN L current limiter, which is not pertinent- =0Ato this discussion.- The Z13-8 current limiter is located at the- =0Astarter contactor, which avoi ds bringing the 4AWG wiring into the- =0Acockpit, which is obviously pref erable.=0A=0ATo me, the biggest consequence of the Z13-8 approach is that i f the- =0AANL current limiter blows, the regulator (sensing the sagging b us- =0Avoltage) will attempt to drive the alternator to full output, whic h- =0Awould be a "bad thing", since the output is likely shorted to groun d.- =0AWith Tony's approach, the voltage sensing path is unbroken when th e- =0A60A breaker pops.=0A=0AI say "bad thing", since I expect Bob to rem ind us the damages in this- =0Asituation are inadequately qualified, prob ably not life-threatening,- =0Aand besides, the alternator is self-limite d to its maximum rating,- =0Awhich will probably clear the short.=0A=0AWi th Tony's approach, there would be much less of the "bad thing" :-)=0A=0AHo wever, to gain the advantage of Tony's approach, some disadvantages- =0Am ust be accepted.=0A=0ASince we prefer the ANL current limiter be connected as shown at the- =0Astarter contactor, it would mean we would have to run the wire from- =0Athe 5A field breaker through the firewall.=0A=0AThis w ould further mean more connections and more wire in the voltage- =0Asensi ng path, resulting is less accurate voltage regulation.=0A=0ASince the "bad thing" is not life-threatening, and extremely unlikely,- =0Ait makes sen se to me to use the Z13-8 approach, which provides shorter- =0Aand more r eliable wiring and better voltage regulation.=0A=0AI will be interested in others opinions of the two approaches.=0A=0AJeff Page=0ADream Aircraft Tund ====================== ________________________________________________________________________________
Date: May 14, 2014
Subject: 'Ford' Voltage regulator
Guys, Does anyone have a part number for a generic 'Ford' voltage regulator? I know they are readily available in the US, but in the UK the first question is always, "What car does it come from...?" When you can't provide a model & year, or a part number most parts store guys give up. They must be available if only we could figure out what to ask for! Thanks in advance. Peter ________________________________________________________________________________
Date: May 14, 2014
Subject: Re: 'Ford' Voltage regulator
Peter, I used a "VR166" voltage regulator with my 40A B&C alternator and bought it from Amazon.com. Assuming this link is available in the UK, you can see it here: http://www.amazon.com/Standard-Motor-Products-VR166-Regulator/dp/B000C805SW Best, Joe Independence, OR Peter Pengilly wrote, On 5/14/2014 12:52: > > > Guys, > > Does anyone have a part number for a generic 'Ford' voltage regulator? > I know they are readily available in the US, but in the UK the first > question is always, > "What car does it come from...?" > When you can't provide a model & year, or a part number most parts store > guys give up. > They must be available if only we could figure out what to ask for! > Thanks in advance. > > Peter ________________________________________________________________________________
Date: May 14, 2014
Peter, Are you looking for the old "mechanical" type or the newer solid state model. . .?? If it is the newer integrated circuit type, here is my suggestion. Take your old unit into a marine or truck type parts house. Show them the unit ( remove any Cessna stickers off it ) and tell them that it is off a boat. There is no parts references really for boats. A smart parts guy will know the exact unit to pick. They usually also have a heavy duty unit. I would op for that model as it will only be a few dollars more. Last time I did this, it was a truck store. I started in with a mechanical type reg. Asked for the newer style unit that was a direct plug replacement. The parts guy knew what would work. He even offered to run the new regulator on his shop equipment and check the control voltage. Being a solid state unit, it is very easy to adjust this with the internal pot. David _______________________________________________________________________- ----- Original Message ----- From: "Peter Pengilly" <peter(at)sportingaero.com> Sent: Wednesday, May 14, 2014 12:52 PM Subject: AeroElectric-List: 'Ford' Voltage regulator > > > Guys, > > Does anyone have a part number for a generic 'Ford' voltage regulator? > I know they are readily available in the US, but in the UK the first > question is always, > "What car does it come from...?" > When you can't provide a model & year, or a part number most parts store > guys give up. > They must be available if only we could figure out what to ask for! > Thanks in advance. > > Peter > > > ________________________________________________________________________________
Date: May 14, 2014
At 02:52 PM 5/14/2014, you wrote: > > >Guys, > >Does anyone have a part number for a generic 'Ford' voltage regulator? >I know they are readily available in the US, but in the UK the first >question is always, >"What car does it come from...?" >When you can't provide a model & year, or a part number most parts >store guys give up. >They must be available if only we could figure out what to ask for! Yup . . . airplane parts business suffers from the same malady . . . no part number no part . . . assuming it's even in the system. That's one regulator that has a 99% chance of being 'correct' by simply observing it's shape. If it looks like this Emacs! It's going to work. Here's an array of options from a local US supplier. Used 1980 Ford Fairmont as baseline but if you look at other models over 1975-1990 model years, you find a similar array. http://tinyurl.com/m7ke8p2 other examples: http://tinyurl.com/od994zl http://tinyurl.com/l6qm8js http://tinyurl.com/m83q5q8 http://tinyurl.com/lro7dlh Poke around on the 'net long enough and you'll find this part offered on a dozen or more part numbers. You should be able to pick one up for about $20-30 . . . perhaps less. Bob . . . ________________________________________________________________________________
Date: May 14, 2014
At 04:47 PM 5/14/2014, you wrote: > >Peter, > >Are you looking for the old "mechanical" type or the newer solid >state model. . .?? >If it is the newer integrated circuit type, here is my suggestion. > >Take your old unit into a marine or truck type parts house. Show >them the unit ( remove any Cessna stickers off it ) and tell them >that it is off a boat. There is no parts references really for >boats. A smart parts guy will know the exact unit to pick. They >usually also have a heavy duty unit. I would op for that model as it >will only be a few dollars more. > >Last time I did this, it was a truck store. I started in with a >mechanical type reg. Asked for the newer style unit that was a >direct plug replacement. The parts guy knew what would work. He >even offered to run the new regulator on his shop equipment and >check the control voltage. Being a solid state unit, it is very easy >to adjust this with the internal pot. Good data . . . with one caveat . . . not ALL solid state replacements are not 'drop in' replacements for the manner in which Cessna used the "S" terminal and the o.v. module. http://tinyurl.com/7g7mn6l Tried the substitution on of our rental fleet a/c at Benton and had an uncontrolled runaway under some switch positions. Don't recall details right now but do the substitution in a Cessna with caution. Bob . . . ________________________________________________________________________________
Date: May 14, 2014
At 01:17 PM 5/14/2014, you wrote: > >I just noticed an interesting wiring difference between Tony Bingelis' >diagram on page 212 of Firewall Forward and the typical AeroElectric >diagram. I bring this up as an interesting learning opportunity. Would you scan the page and post it. Schematics are the ultimate communications tools in such discussions . . . Bob . . . ________________________________________________________________________________
Date: May 15, 2014
Here is a link to one of Tony Bingelis' articles about electrical systems, although not the one referenced by Jeff. See page 29. http://spirit.eaa.org/apps/magazines/eaa_issues/magazine_199005.pdf An interesting fact about this link is that the six digit number represents the year and month of the Sport Aviation issue. One can change those dates to read any issue in the archives. Here is an article written in 1993 by Bob Nuckolls on pages 80 -83. http://spirit.eaa.org/apps/magazines/eaa_issues/magazine_199302.pdf It is interesting to see that his drawings have evolved over the years. Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423304#423304 ________________________________________________________________________________
Date: May 15, 2014
Robert L. Nuckolls, III a crit : > > .... I take it that the original > ABMM is no longer available. You'd have > to check with Eric on his recommendations > but I'm guessing that you might get away > with feeding the ABMM's + input terminal > through a diode (Schottky would be best > but not critical). Then put a capacitor > across the ABMM input power terminals . . . > something like 100uF. This would drive the > module at the higher voltage more consistent > with the peaks. Hi Bob, Thank you once again for your response and advice. The original ABMM may still be somewhere in a drawer, I'll try to retrieve it. Many many moons ago I crafted a little webpage on the subject : http://contrails.free.fr/elec_lvwm_en.php It could help to clarify things. Will keep you posted on the result of the proposed mod. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: May 15, 2014
Thanks all for your suggestions - I'm looking for a solid state device so will try this tack. From Bob's links there is an ACDelco part that fits 2630 Fords, so that may be worth a try! Regards, Peter On 14/05/2014 22:47, David Lloyd wrote: > > > Peter, > > Are you looking for the old "mechanical" type or the newer solid state > model. . .?? > If it is the newer integrated circuit type, here is my suggestion. > > Take your old unit into a marine or truck type parts house. Show them > the unit ( remove any Cessna stickers off it ) and tell them that it > is off a boat. There is no parts references really for boats. A > smart parts guy will know the exact unit to pick. They usually also > have a heavy duty unit. I would op for that model as it will only be a > few dollars more. > > Last time I did this, it was a truck store. I started in with a > mechanical type reg. Asked for the newer style unit that was a direct > plug replacement. The parts guy knew what would work. He even > offered to run the new regulator on his shop equipment and check the > control voltage. Being a solid state unit, it is very easy to adjust > this with the internal pot. > David > > _______________________________________________________________________- > > > ----- Original Message ----- From: "Peter Pengilly" > > To: > Sent: Wednesday, May 14, 2014 12:52 PM > Subject: AeroElectric-List: 'Ford' Voltage regulator > > >> >> >> Guys, >> >> Does anyone have a part number for a generic 'Ford' voltage regulator? >> I know they are readily available in the US, but in the UK the first >> question is always, >> "What car does it come from...?" >> When you can't provide a model & year, or a part number most parts >> store guys give up. >> They must be available if only we could figure out what to ask for! >> Thanks in advance. >> >> Peter >> >> >> >> > > ________________________________________________________________________________
Subject: Equipping experimental for IFR
Date: May 16, 2014
5/16/2014 Hello Curt, You wrote: =9C.... trying to learn.=9D I really appreciate it when an EAB (Experimental Amateur Built) aircraft builder or owner comes out with an attitude like that =93 way to go! Some time back I created the attached document to help answer questions like yours. It has been published in Kitplanes magazine. Please let me know if you have any further questions. =98OC=99 Baker 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ================== Subject: Avionics-List: Equipping experimental for IFR From: "curts63" <curt.stein(at)verizon.net> I"m new to owning a plane and trying to learn. I bought a used experimental plane. The panel includes an MGL Voyager EFIS, Backup airspeed, Backup altimeter, Garmin 430W, Garmin GTX-327, Garmin 240 audio panel, and a Navworx ADS-B. The Voyager has the horizon, slip skid ball, compass, altimeter, airspeed, OAT, clock, timer, oil temp, oil pressure, RPM, CDI, glideslope, autopilot, and more. My question is, what is the required equipment for IFR and what testing has to be done prior to filing and flying? Any insight and guidance is greatly appreciated. Thanks, Curt ________________________________________________________________________________
Date: May 16, 2014
Subject: Re: Microphone Question
At 05:11 PM 5/14/2014, you wrote: Hi, Found your page on the web -- very helpful, thanks. I'm trying to find a way to use a Lectrosonics HM162MC Noise Cancelling Microphone (http://www.fullcompass.com/product/348924.html) in my Piper Dakota. The mic comes with a 2.5mm 2 conductor plug. I've looked everywhere for converters, but they do not exist. I'm happy to make one myself. The question is the wiring: Do I wire the tip from the 2 conductor 2.5mm plug to the ring of the 3 conductor .206" plug, and the sleeve of the 2.5mm to the sleeve of the .206" plug? Do I leave the tip not connected (so that my PTT still works)? Any recommendations on a source for .206" plugs? Will this work? http://www.ebay.com/itm/PHILMORE-3-16-206-MIKE-MICROPHONE-PLUG-FOR-COLLINS-DRAKE-AVIATION-524WT-/150998288305 No. Aviation communications systems are unique amongst the constellation of ways that people talk to each other. The first transmitters to go into airplanes used the same kind of microphone as telephones. Carbon granule. Simple, rugged, but needed to be POWERED by a voltage applied to the microphone audio line from within the transmitter. To this day, aviation microphones still supply power out to the mic . . . the transducer is no longer filled with carbon granules but it IS fitted with some form of active electronics designed to amplify the microphone's inherently tiny signal up to a level commensurate with the legacy carbon mic output. On the order of 1 volt peak to peak. Here's an example of a modern non-carbon microphone adapted to aviation service http://tinyurl.com/qf2nqhl Here's an in-depth explanation of the world of aviation microphones http://tinyurl.com/mffn8pm The data sheet for your microphone says it's 'electret' and speaks to requirements for a bias voltage. But it doesn't give us output voltage and impedance levels. It's sure to require more than a simple wiring adapter . . . some electronics are needed to let it masquerade as an 1950's carbon mic for aircraft. Emacs! Bob . . . ________________________________________________________________________________
Subject: Re: Equipping experimental for IFR
Date: May 16, 2014
5/16/2014 Hello Curt, You wrote: 1) Does it have to be field tested/certified prior to IFR flight .....? a) Lets take the certified part first. This extract: Fly WAAS Approaches GNS 430W comes with built-in WAAS navigation capabilities. It is approved to fly LPV glideslope approaches without reference to ground-based navaids of any kind. Featuring an advanced 15-channel receiver capable of five position updates per second, GNS 430W meets the FAA's stringent TSO C146a standards for WAAS "sole means" navigation providing vertical and lateral approach guidance into thousands of U.S. airports previously inaccessible in IFR conditions. copied from a Garmin page shows that the 430W is fully compliant with TSO C146a for sole means navigation including precision approaches. No further certification in the field is needed. b) Regarding field testing: There are no provisions in the federal regulatory system for the FAA to field test the avionics installation in your EAB aircraft. One may turn to an FAA approved MRO (Maintenance and Repair Organization) for such field testing, but that organization is obligated to comply with some regulatory provisions established for type certificated aircraft which do not apply to your EAB. In the MRO's misguided attempts to comply with type certificated aircraft criteria in regard to your EAB you can wind up with a real (and expensive) mess on your hands. So my recommendation is that you use an FAA approved MRO for the bench testing and repair of your individual avionics components when required, but do not attempt to have them field test any EAB entire avionics installation. b) .... does it need to be certified on an ongoing interval,... No regulatory recertification for the 430W is required, but there are the issues of navigation data base and software updates: a) Navigation Data Base Updates: This can be an ongoing chore / expense depending upon how you approach it. The ultimate (and most expensive) navigation data base update solution is to have a Jeppesen subscription that provides one an appropriate geographic navigation data base update every 26 days that you must download with your computer onto the navigation data base card for your 430W and then install in the unit. An alternative is to call Jeppesen to order and install a one time navigation data base download when you see the need. b) Software Updates: If you poke around digitally inside your 430W you will discover an amazingly large number of different software programs that control the various aspects of that box. You can write down the identity, including the version, of each of those software programs and carry it off to a nearby qualified Garmin dealer / servicing facility. They can check their Garmin files to see if there are any available updates to those software programs. Those updates will fall into categories such as mandatory (in Garmins opinion) or sort of nice to have. Use your judgment as to whether you want to go to the effort / expense to have any software updates done. Please let me know if you have any further questions. 'OC' ==================================================================================== From: Curt Sent: Friday, May 16, 2014 9:23 AM Subject: RE: Equipping experimental for IFR Owen, Thank you for the equipment list, that helps with whats needed for flight rules. The one outstanding question is with the Garmin 430W. Does it have to be field tested/certified prior to IFR flight and does it need to be certified on an ongoing interval, like the transponder? Sincerely, Curt Stein ==================================================== From: Owen Baker [mailto:bakerocb(at)cox.net] Sent: Friday, May 16, 2014 9:08 AM aeroelectric-list(at)matronics.com Subject: Equipping experimental for IFR 5/16/2014 Hello Curt, You wrote: .... trying to learn. I really appreciate it when an EAB (Experimental Amateur Built) aircraft builder or owner comes out with an attitude like that way to go! Some time back I created the attached document to help answer questions like yours. It has been published in Kitplanes magazine. Please let me know if you have any further questions. OC Baker 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ==================================================================== Subject: Avionics-List: Equipping experimental for IFR From: "curts63" <curt.stein(at)verizon.net> I"m new to owning a plane and trying to learn. I bought a used experimental plane. The panel includes an MGL Voyager EFIS, Backup airspeed, Backup altimeter, Garmin 430W, Garmin GTX-327, Garmin 240 audio panel, and a Navworx ADS-B. The Voyager has the horizon, slip skid ball, compass, altimeter, airspeed, OAT, clock, timer, oil temp, oil pressure, RPM, CDI, glideslope, autopilot, and more. My question is, what is the required equipment for IFR and what testing has to be done prior to filing and flying? Any insight and guidance is greatly appreciated. Thanks, Curt ________________________________________________________________________________
Date: May 16, 2014
OC, Where do I find the procedures to "poke around digitally inside your 430W"? I would like to check to see what software is loaded in my unit. Thanks, Bill -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Owen Baker Sent: Friday, May 16, 2014 11:42 AM Subject: AeroElectric-List: Re: Equipping experimental for IFR 5/16/2014 Hello Curt, You wrote: 1) "Does it have to be field tested/certified prior to IFR flight .....?" a) Let's take the "certified" part first. This extract: "Fly WAAS Approaches GNS 430W comes with built-in WAAS navigation capabilities. It is approved to fly LPV "glideslope" approaches without reference to ground-based navaids of any kind. Featuring an advanced 15-channel receiver capable of five position updates per second, GNS 430W meets the FAA's stringent TSO C146a standards for WAAS "sole means" navigation - providing vertical and lateral approach guidance into thousands of U.S. airports previously inaccessible in IFR conditions." copied from a Garmin page shows that the 430W is fully compliant with TSO C146a for "sole means" navigation including precision approaches. No further certification in the field is needed. b) Regarding field testing: There are no provisions in the federal regulatory system for the FAA to field test the avionics installation in your EAB aircraft. One may turn to an FAA approved MRO (Maintenance and Repair Organization) for such field testing, but that organization is obligated to comply with some regulatory provisions established for type certificated aircraft which do not apply to your EAB. In the MRO's misguided attempts to comply with type certificated aircraft criteria in regard to your EAB you can wind up with a real (and expensive) mess on your hands. So my recommendation is that you use an FAA approved MRO for the bench testing and repair of your individual avionics components when required, but do not attempt to have them field test any EAB entire avionics installation. b) ".... does it need to be certified on an ongoing interval,..." No regulatory recertification for the 430W is required, but there are the issues of navigation data base and software updates: a) Navigation Data Base Updates: This can be an ongoing chore / expense depending upon how you approach it. The ultimate (and most expensive) navigation data base update solution is to have a Jeppesen subscription that provides one an appropriate geographic navigation data base update every 26 days that you must download with your computer onto the navigation data base card for your 430W and then install in the unit. An alternative is to call Jeppesen to order and install a one time navigation data base download when you see the need. b) Software Updates: If you poke around digitally inside your 430W you will discover an amazingly large number of different software programs that control the various aspects of that box. You can write down the identity, including the version, of each of those software programs and carry it off to a nearby qualified Garmin dealer / servicing facility. They can check their Garmin files to see if there are any available updates to those software programs. Those updates will fall into categories such as mandatory (in Garmin's opinion) or sort of nice to have. Use your judgment as to whether you want to go to the effort / expense to have any software updates done. Please let me know if you have any further questions. 'OC' =========================================================================== ======== From: Curt Sent: Friday, May 16, 2014 9:23 AM Subject: RE: Equipping experimental for IFR Owen, Thank you for the equipment list, that helps with what's needed for flight rules. The one outstanding question is with the Garmin 430W. Does it have to be field tested/certified prior to IFR flight and does it need to be certified on an ongoing interval, like the transponder? Sincerely, Curt Stein ==================================================== From: Owen Baker [mailto:bakerocb(at)cox.net] Sent: Friday, May 16, 2014 9:08 AM aeroelectric-list(at)matronics.com Subject: Equipping experimental for IFR 5/16/2014 Hello Curt, You wrote: ".... trying to learn." I really appreciate it when an EAB (Experimental Amateur Built) aircraft builder or owner comes out with an attitude like that - way to go! Some time back I created the attached document to help answer questions like yours. It has been published in Kitplanes magazine. Please let me know if you have any further questions. 'OC' Baker 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ==================================================================== Subject: Avionics-List: Equipping experimental for IFR From: "curts63" <curt.stein(at)verizon.net> I"m new to owning a plane and trying to learn. I bought a used experimental plane. The panel includes an MGL Voyager EFIS, Backup airspeed, Backup altimeter, Garmin 430W, Garmin GTX-327, Garmin 240 audio panel, and a Navworx ADS-B. The Voyager has the horizon, slip skid ball, compass, altimeter, airspeed, OAT, clock, timer, oil temp, oil pressure, RPM, CDI, glideslope, autopilot, and more. My question is, what is the required equipment for IFR and what testing has to be done prior to filing and flying? Any insight and guidance is greatly appreciated. Thanks, Curt ________________________________________________________________________________
Date: May 16, 2014
5/16/2014 Hello Curt, You wrote: 1) "There are no mandatory tests like you would see in the VOR area where you're required to check the accuracy?" I am aware of no regulatory mandatory requirement to check the GPS accuracy performance of a Garmin 430W prior to filing and flying IFR. You may wish to check into the subject of RAIM (Receiver Autonomous Integrity Monitoring). 2) "So in conclusion, the 430w does not need any kind of test prior to using it in IFR conditions?"** As you imply in 1 above, if you are using the VOR capability of the 430W for IFR navigation then you must comply with 14 CFR 91.171. 3) "You don't need a signed flight manual supplement to go along with the POH?" Here you are treading into the area of trying to super impose regulatory requirements established by the FAA for type certificated aircraft onto the far thinner regulatory arena that EAB aircraft operate in. Where is the regulation that requires a POH for an EAB aircraft? Where is the regulation that says who is authorized to sign the flight manual supplement for an EAB aircraft POH?## 4) "I really appreciate you taking the time to educate me." It is my pleasure, sir. 5) "Thanks again for your assistance." You are welcome any time. 'OC' **PS: I would recommend extensive practice under VFR in VMC conditions with your aircraft's avionics installation before venturing into IFR under IMC conditions. ##PS: I am not saying that a good POH / supplement is not needed for safe flight in EAB aircraft, just that the FAA does not mandate those items by regulations and it is up to the builder / pilot of the EAB aircraft to create what is needed for safe flight for him and his aircraft. ======================================================= From: Curt Sent: Friday, May 16, 2014 3:26 PM Subject: RE: Equipping experimental for IFR Owen, So in conclusion, the 430w does not need any kind of test prior to using it in IFR conditions? There are no mandatory tests like you would see in the VOR area where you're required to check the accuracy? You don't need a signed flight manual supplement to go along with the POH? I do know about the monthly nav data updates from Jeppesen. I did purchase the expensive annual update package for my intended area of flying. Thanks again for your assistance. I really appreciate you taking the time to educate me. Curt ________________________________________________________________________________
Subject: Garmin 430W Software
Date: May 17, 2014
5/17/2014 Hello Bill Bradbury, Start with getting a copy of the 400W Series Pilot Guide & Reference and sitting down in front of an installed 430W. (The trainer version that I have installed on my computer will not allow me to check its installed software.) Using this Guide you can: 1) On page 149 select the AUX Page Group. 2) On page 149 select the Utility Page. 3) On page 158 select the Software Versions Page. 4) On page 164 see a discussion of the Software / Database Versions. I found eight different sets of software and their versions on my 430W: MAIN 2.0, GPS 2.4, COM 4.00, VLOC 2.06, G/S 2.03, IOFPGA 2.2, STAGE 1 2.01, and STAGE 2 2.00. I carried this listing over to our local qualified Garmin dealer / servicer and asked them to tell me if I was up to date. After a fair amount of struggle and searching they told me that: MAIN is required to be updated to 3.30 with an optional update to 5.3. GPS is required to be updated to 3.20 with and optional update to 5.0. Since I am not currently using my 430W for IFR flight purposes I am deferring any software updates until that need arises. I hope that this helps. Any other questions? =98OC=99 Baker 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ============== From: "Bill Bradburry" <bbradburry(at)verizon.net> Subject: RE: AeroElectric-List: Re: Equipping experimental for IFR OC, Where do I find the procedures to "poke around digitally inside your 430W"? I would like to check to see what software is loaded in my unit. Thanks, Bill ________________________________________________________________________________
Date: May 17, 2014
5/17/2014 Hello Curt Stein, You wrote: 1) =9CIn the case of the pitot static and transponder, they get tested every 24 months. Is this test different for VFR versus IFR?=9D The answer to your question is found in 14 CFR Sections 91.411 and 91.413 that require these inspections, and the related Appendices E and F of Part 43. (All available at the FAA web site.) A) 91.411 applies to any operation under IFR in controlled airspace. B) 91.413 is a bit more complicated. Please see that section and its referenced section 91.215 for details. C) It is unfortunate that the term =9Cpitot static and transponder checks=9D has come into common use when describing the tests required by 91.411 and 91.413. A review of those sections and the relevant appendicies of Part 43 shows that no test of the pitot system is required, but that extensive and detailed tests of the static system and transponder are required to include the altimeter viewed by the pilot, and the automatic altitude reporting system which consists of the encoder and the transponder. I guess that we are just stuck with that unfortunate common terminology, but I strongly urge all EAB builders and pilots to become familiar with the actual requirements of the regulations, including the technicians and organizations that are permitted / required to perform the tests involved. 2) =9CIs it required to have a backup instruments to the EFIS ? I know it's the better practice to have those, but are they required in experimental?=9D The regulatory requirements for EAB instruments have been covered in our previous exchange postings and the attached document. =98OC=99 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ================ Subject: Avionics-List: Re: Equipping experimental for IFR From: "curts63" <curt.stein(at)verizon.net> Ok, thanks. In the case of the pitot static and transponder, they get tested every 24 months. Is this test different for VFR versus IFR? For the Garmin 430W, I've heard that this requires a ground test and flight test? Is this something that needs to be repeated on a standard interval? Is it required to have a backup instruments to the EFIS ? I know it's the better practice to have those, but are they required in experimental? Curt ________________________________________________________________________________
Date: May 17, 2014
Subject: Re: lm7321 substitute
I'm working on a drawing that uses a R-t-R output op amp in an inverting configuration which does two good things for us. (1) We can add pots that set gain and offset such that the builder can exploit ALL the bars in the trim indicator display even if the pot doesn't run full mechanical stroke and (2) we can drive any number of indicators from the single amplifier. --------------- Sorry I dropped the ball on this. I'm wrestling with a computer with a dying operating system . . . it's had some 'quirks' for a couple years but I'm now contemplating a new build with Win7 . . . not exactly the way I'd like to blow away a day's worth of praying over a new computer! In any case, here's the drawing http://tinyurl.com/nmftvll By eliminating the not-well-considered goal of rail-to-rail input and output, crafting an inverting amplifier with R-t-R output offers some features cited above that seem to make it a better approach. Further, all the parts are available as thru-hole. This would be a candidate for packaging in a 15-pin d-sub housing which is what I've illustrated with pin numbers arbitrarily assigned to a board-edge connector . . . obviously, one might perf-board this circuit as well . . . Bob . . . ________________________________________________________________________________
Subject: KN-53 Installation Manual
Date: May 18, 2014
I'm looking for a pin-out guide or an installation manual for a KN-53 Nav Receiver. Thanks, Jerry Folkerts ________________________________________________________________________________
Subject: Schematic Z-17 questions
Date: May 18, 2014
I am rewiring a VeriEze (with O-200A) and putting in a new panel. Weight is always a factor and I am trying to keep it light, but after discussions with the gang, I am now convinced that a starting system (vs prop start) is next to mandatory. So the simplest system that meets this need is the Z-17 design, but I would like to use the B&C 200G (12amp) alternator instead of the SD8 (noted in the diagram). Is it a drop in substitute without modification to the wiring diagram? And is the 4AWG wiring for starting and primary ground wires still sufficient? Thanks, Matt Stecher VariEze N54EG rebuild ________________________________________________________________________________
Date: May 18, 2014
Subject: Re: Schematic Z-17 questions
At 01:21 PM 5/18/2014, you wrote: > > >I am rewiring a VeriEze (with O-200A) and putting in a new panel. > >Weight is always a factor and I am trying to keep it light, but after >discussions with the gang, I am now convinced that a starting system (vs >prop start) is next to mandatory. > >So the simplest system that meets this need is the Z-17 design, but I would >like to use the B&C 200G (12amp) alternator instead of the SD8 (noted in the >diagram). The SD-8 and the 200G are interchangeable schematic wise. Are you going with light weight starter too? Are you vfr and keeping magnetos? If so, you COULD consider a really light lithium battery mounted aft such that all your fat wires are short. >Is it a drop in substitute without modification to the wiring diagram? Yes . . . >And is the 4AWG wiring for starting and primary ground wires still >sufficient? Might even drop to 6AWG if the leads were short as hypothesized above . . . But if your battery has to go up front, you can probably get by with 4AWG in warm weather country . . . which may be a given with the VeriEze . . . Bob . . . ________________________________________________________________________________
Date: May 18, 2014
Subject: Re: KN-53 Installation Manual
At 09:41 AM 5/18/2014, you wrote: >I'm looking for a pin-out guide or an installation manual for a >KN-53 Nav Receiver. >Thanks, >Jerry Folkerts The only think I have in my library is the pinout drawing http://tinyurl.com/png9tws Somebody here on the List may be able to help further . . . Bob . . . ________________________________________________________________________________
Subject: Strobe Switch - New evidence
Date: May 19, 2014
Bob, et. al., Once again my strobes quit working. Suspecting another Carling switch failure, that's what I checked first. To my surprise, the switch and its connections were pristine. However, the other end of the power line, a Molex connector at the Whelen Strobe Power Pack, was the problem. The power pin had overheated to the point where the Molex connector was blackened and melted around the pin. The other pin on the connector, a ground wire, was not affected. Replaced the Molex and the system is back in operation. The mystery deepens. Charlie Brame RV-6A N11CB San Antonio ________________________________________________________________________________
Subject: Re: Strobe Switch - New evidence
Date: May 19, 2014
> > Once again my strobes quit working. Suspecting another Carling switch > failure, that's what I checked first. To my surprise, the switch and its > connections were pristine. However, the other end of the power line, a > Molex connector at the Whelen Strobe Power Pack, was the problem. The > power pin had overheated to the point where the Molex connector was > blackened and melted around the pin. The other pin on the connector, a > ground wire, was not affected. Replaced the Molex and the system is back > in operation. The mystery deepens. Did you check the old connector to see if (1) there were any broken strands on the connector going into either side? (2) Were the wires on the pins stripped properly and a nice gas tight crimped connection? (3) Did there appear to be any corrosion on the pins? Sometimes it is difficult to see these things after the connection is burned up, but it is worth a look. Roger ________________________________________________________________________________
Date: May 19, 2014
Not a mystery at all. The strobe power pack is a constant-power device, which means that as the input voltage drops, the load current increases. If you have a resistive switch or connection, you'll get what's called 'thermal runaway'. This leads to burnt or charred switches, contacts or connectors. When I first discovered the problem about 7 years ago, It was the Carling switch rivets that were the root cause, but any deteriorating contact can cause it. Make it an annual inspection item for the strobe connectors and switches. Check your landing and taxi light circuits as well. Vern =================================================== Sent from my iThing. It is responsible for all gramma and typo terrors. > On May 19, 2014, at 7:01 AM, Charles Brame wrote: > > > Bob, et. al., > > Once again my strobes quit working. Suspecting another Carling switch failure, that's what I checked first. To my surprise, the switch and its connections were pristine. However, the other end of the power line, a Molex connector at the Whelen Strobe Power Pack, was the problem. The power pin had overheated to the point where the Molex connector was blackened and melted around the pin. The other pin on the connector, a ground wire, was not affected. Replaced the Molex and the system is back in operation. The mystery deepens. > > Charlie Brame > RV-6A N11CB > San Antonio > > > > ________________________________________________________________________________
Date: May 19, 2014
Not sure what strobe power supply you are using but I changed from one that many homebuilders were using (Plane Power?) to a Nova Electronics XPAK604X unit. It looks and mounts just like my old unit but it separates the switch from the power circuit with what I assume is an internal relay. I burned out a switch terminal on my original installation. I didn't fully understand the reasons but I swapped the original out for the Nova unit. It significantly shortened the power leads from over 10 feet to <2' (RV10). Just a thought. On 5/19/2014 10:01 AM, Charles Brame wrote: > > Bob, et. al., > > Once again my strobes quit working. Suspecting another Carling switch failure, that's what I checked first. To my surprise, the switch and its connections were pristine. However, the other end of the power line, a Molex connector at the Whelen Strobe Power Pack, was the problem. The power pin had overheated to the point where the Molex connector was blackened and melted around the pin. The other pin on the connector, a ground wire, was not affected. Replaced the Molex and the system is back in operation. The mystery deepens. > > Charlie Brame > RV-6A N11CB > San Antonio > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: May 19, 2014
At 10:27 AM 5/19/2014, you wrote: >You mention a light weight lithium battery. This is the second time >I have seen something about use of lithium batteries in airplanes. I >would like to hear more about things like reliability, things to be >aware of, the actual storage capacity (rather than just cranking >amps) and of course, after the 787 battery issues, fire potential. >The idea using a 3 or 4 pound battery is very appealing. There's a 4-part series coming out in Kitplanes about batteries with an emphasis on evaluation of lithium products for suitability to task in aircraft. Turns out that not all lithium products are the same . . . and it goes deeper than selection of the least-hazardous chemistry. MOST commercial off the shelf examples have no battery management system yet they claim to be drop-in replacements for lead-acid. The claims go even further to suggest that a 3# lithium battery has an 18 ah 'lead acid equivalency' . . . when the 18 ah battery weighs in at 15 pounds or more. "Lead acid equivalency" speaks to engine cranking ability and glosses over shortfalls in CAPACITY. For a vfr airplane having an engine that is free of electrical dependencies, one may down-size a battery with little attention to capacity. If getting the engine started is your only concern, then the lithium chemistry can offer some enticing weight savings. But if you have any concerns for battery-only endurance, then be sure the device you pick has the capacity to meet your alternator-out endurance requirements. It also turns out that optimal battery service life is achieved by cycling the battery's level of charge between 30 and 90%. By artificially limiting available energy on a cycle-by-cycle basis (most hybrid cars do this), then they battery can last a long time. Ideally, one never runs the ship's battery down . . . but it's there if you need it. So if you set the bus voltage to limit the battery to 90% of maximum capacity, then it should last a long time. But if you ever run it down on purpose or accidently . . . then maximizing the battery's serviceability usually calls for recharging with a battery management system (BMS). Folks flying the simpler, day-vfr airplanes are encouraged to experiment with the current offerings of lithium technology http://tinyurl.com/nlamrrw This battery claims to crank as well as a 16-18 a.h lead-acid at one 6th the weight. At that price, it almost certainly has no internal BMS. On the other hand, this 2.2 pound battery claims 400+ amps cranking ability . . . and I believe it is fitted with a full-time, capable battery management system. http://tinyurl.com/lcegge5 Bob . . . ________________________________________________________________________________
Date: May 19, 2014
There is also a gotcha in cold weather with lithium batteries - they don't work well (sorry I can't be specific to the type). When the battery has cold soaked at around freezing it will hardly turn over an O-360. But, a minute or two after an attempted start - I'm told 5 seconds of trying and barely cranking - the battery will have warmed itself up and happily spins the engine into life. Batteries on the firewall will probably be happy for the rest of the day (and also respond to the hair dryer in the oil door trick for 10 minutes while pre-flighting). Batteries in the aft fuselage will require the 'failed start' technique each time. No very scientific data or information on a minimum temperature when this technique doesn't work. Peter On 19/05/2014 20:27, Robert L. Nuckolls, III wrote: > > > At 10:27 AM 5/19/2014, you wrote: >> You mention a light weight lithium battery. This is the second time I >> have seen something about use of lithium batteries in airplanes. I >> would like to hear more about things like reliability, things to be >> aware of, the actual storage capacity (rather than just cranking >> amps) and of course, after the 787 battery issues, fire potential. >> The idea using a 3 or 4 pound battery is very appealing. > > There's a 4-part series coming out in Kitplanes > about batteries with an emphasis on evaluation of > lithium products for suitability to task in aircraft. > > Turns out that not all lithium products are the > same . . . and it goes deeper than selection of > the least-hazardous chemistry. > > MOST commercial off the shelf examples have no > battery management system yet they claim to be > drop-in replacements for lead-acid. The claims > go even further to suggest that a 3# lithium battery > has an 18 ah 'lead acid equivalency' . . . when > the 18 ah battery weighs in at 15 pounds or more. > > "Lead acid equivalency" speaks to engine cranking > ability and glosses over shortfalls in CAPACITY. > For a vfr airplane having an engine that is free > of electrical dependencies, one may down-size a > battery with little attention to capacity. If getting > the engine started is your only concern, then the > lithium chemistry can offer some enticing weight > savings. > > But if you have any concerns for battery-only > endurance, then be sure the device you pick > has the capacity to meet your alternator-out > endurance requirements. > > It also turns out that optimal battery service > life is achieved by cycling the battery's level > of charge between 30 and 90%. By artificially > limiting available energy on a cycle-by-cycle > basis (most hybrid cars do this), then they > battery can last a long time. > > Ideally, one never runs the ship's battery > down . . . but it's there if you need it. > So if you set the bus voltage to limit the > battery to 90% of maximum capacity, then > it should last a long time. > > But if you ever run it down on purpose or > accidently . . . then maximizing the battery's > serviceability usually calls for recharging > with a battery management system (BMS). > > Folks flying the simpler, day-vfr airplanes are > encouraged to experiment with the current offerings > of lithium technology > > http://tinyurl.com/nlamrrw > > This battery claims to crank as well as a 16-18 > a.h lead-acid at one 6th the weight. At that price, > it almost certainly has no internal BMS. > > On the other hand, this 2.2 pound battery claims > 400+ amps cranking ability . . . and I believe > it is fitted with a full-time, capable battery > management system. > > http://tinyurl.com/lcegge5 > > > Bob . . . > > ________________________________________________________________________________
Date: May 20, 2014
Thanks for your responses Bob, I have purchased an Aerovolts 12 cell lithium battery to give a try. It is billed as the choice for cranking an O-200 and is 4.4"x3.4"x4" and 2.5 lbs. I am shooting for an aft installation and as you said that will let me keep my heavy wires short. I would like to put it in the main spar, but not sure about drilling holes in it to run the wires out or for mounting the battery. If that does not work I am looking at the hell hole above the landing gear attachment. If the aft locations prove more trouble than they are worth than I am looking at the traditional battery spot in the nose and 2AWG wires. It warm most of the time here near Houston, but we do get a week or two worth of almost cold weather. Regards, Matt Stecher Katy TX Varieze N54EG rebuild From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Schematic Z-17 questions At 01:21 PM 5/18/2014, you wrote: > > >I am rewiring a VeriEze (with O-200A) and putting in a new panel. > >Weight is always a factor and I am trying to keep it light, but after >discussions with the gang, I am now convinced that a starting system >(vs prop start) is next to mandatory. > >So the simplest system that meets this need is the Z-17 design, but I >would like to use the B&C 200G (12amp) alternator instead of the SD8 >(noted in the diagram). The SD-8 and the 200G are interchangeable schematic wise. Are you going with light weight starter too? Are you vfr and keeping magnetos? If so, you COULD consider a really light lithium battery mounted aft such that all your fat wires are short. >Is it a drop in substitute without modification to the wiring diagram? Yes . . . >And is the 4AWG wiring for starting and primary ground wires still >sufficient? Might even drop to 6AWG if the leads were short as hypothesized above . . . But if your battery has to go up front, you can probably get by with 4AWG in warm weather country . . . which may be a given with the VeriEze . . . Bob . . . ________________________________________________________________________________
Date: May 20, 2014
At 09:33 PM 5/20/2014, you wrote: > > >Thanks for your responses Bob, > >I have purchased an Aerovolts 12 cell lithium battery to give a try. It is >billed as the choice for cranking an O-200 and is 4.4"x3.4"x4" and 2.5 lbs. Hmmmm . . . I'd sure like to do a family of cap check curves on it . . . I've looked over their website. They seem to offer a 'special charger' for 'improved life' but also says 'no special charger necessary'. Did any paperwork come with the battery that cautions about deep discharge and/or making sure the bus voltage is not too high? >I am shooting for an aft installation and as you said that will let me keep >my heavy wires short. I would like to put it in the main spar, but not sure >about drilling holes in it to run the wires out or for mounting the battery. >If that does not work I am looking at the hell hole above the landing gear >attachment. > >If the aft locations prove more trouble than they are worth than I am >looking at the traditional battery spot in the nose and 2AWG wires. It warm >most of the time here near Houston, but we do get a week or two worth of >almost cold weather. 4AWG is about 300 micro-ohms per foot WARM (160F from cranking). Assuming 24' round trip, a 200A cranking current will toss off 1.44 volts in the wire. 2AWG is 200 micro-ohms per foot and wouldn't warm up as much . . . so figure about 0.9 volts in wire drop for a net savings of about 0.5 volts out of a total of 9-10 volts at the starter motor terminals. 4AWG would probably be fine. Bob . . . ________________________________________________________________________________
Date: May 21, 2014
TWF0dCzCoApJIGFtIG5vdCBzdXJlIGlmIHlvdSBzaG91bGQgZHJpbGwgaG9sZXMgaW4gdGhlIFZh cmktRVogc3BhciwgwqBidXQgSSBrbm93IHRoYXQgdGhlIENvenkgc3BhciBzaG91bGQgbm90IGhh dmUgYW55IGhvbGVzLiBJIHBsYW4gb24gdXNpbmcgY2xpY2tib25kcyBvciBzb21ldGhpbmcgZXF1 aXZhbGVudCBpbnNpZGUgbXkgc3Bhci4gSSBwbGFuIG9uIHVzaW5nIHRoZW0gb24gdGhlIGZpcmV3 YWxsIHRvIG1pbmltaXplIHRoZSBob2xlcyBkcmlsbGVkIGluIHRoZSBmaXJld2FsbC7CoAoKTWlj aGFlbCBHYXJtb24gClNlbnQgZnJvbSBTYW1zdW5nIHRhYmxldAoKLS0tLS0tLS0gT3JpZ2luYWwg bWVzc2FnZSAtLS0tLS0tLQpGcm9tOiBNYXR0IFN0ZWNoZXIgPG1yY2MxMjM0QHNiY2dsb2JhbC5u ZXQ+IApEYXRlOiAwNS8yMC8yMDE0ICA5OjMzIFBNICAoR01ULTA2OjAwKSAKVG86IGFlcm9lbGVj dHJpYy1saXN0QG1hdHJvbmljcy5jb20gClN1YmplY3Q6IEFlcm9FbGVjdHJpYy1MaXN0OiBSZTog U2NoZW1hdGljIFotMTcgcXVlc3Rpb25zIAogCi0tPiBBZXJvRWxlY3RyaWMtTGlzdCBtZXNzYWdl IHBvc3RlZCBieTogIk1hdHQgU3RlY2hlciIgPG1yY2MxMjM0QHNiY2dsb2JhbC5uZXQ+CgpUaGFu a3MgZm9yIHlvdXIgcmVzcG9uc2VzIEJvYiwKCkkgaGF2ZSBwdXJjaGFzZWQgYW4gQWVyb3ZvbHRz IDEyIGNlbGwgbGl0aGl1bSBiYXR0ZXJ5IHRvIGdpdmUgYSB0cnkuIEl0IGlzCmJpbGxlZCBhcyB0 aGUgY2hvaWNlIGZvciBjcmFua2luZyBhbiBPLTIwMCBhbmQgaXMgNC40IngzLjQieDQiIGFuZCAy LjUgbGJzLgoKSSBhbSBzaG9vdGluZyBmb3IgYW4gYWZ0IGluc3RhbGxhdGlvbiBhbmQgYXMgeW91 IHNhaWQgdGhhdCB3aWxsIGxldCBtZSBrZWVwCm15IGhlYXZ5IHdpcmVzIHNob3J0LiBJIHdvdWxk IGxpa2UgdG8gcHV0IGl0IGluIHRoZSBtYWluIHNwYXIsIGJ1dCBub3Qgc3VyZQphYm91dCBkcmls bGluZyBob2xlcyBpbiBpdCB0byBydW4gdGhlIHdpcmVzIG91dCBvciBmb3IgbW91bnRpbmcgdGhl IGJhdHRlcnkuCklmIHRoYXQgZG9lcyBub3Qgd29yayBJIGFtIGxvb2tpbmcgYXQgdGhlIGhlbGwg aG9sZSBhYm92ZSB0aGUgbGFuZGluZyBnZWFyCmF0dGFjaG1lbnQuCgpJZiB0aGUgYWZ0IGxvY2F0 aW9ucyBwcm92ZSBtb3JlIHRyb3VibGUgdGhhbiB0aGV5IGFyZSB3b3J0aCB0aGFuIEkgYW0KbG9v a2luZyBhdCB0aGUgdHJhZGl0aW9uYWwgYmF0dGVyeSBzcG90IGluIHRoZSBub3NlIGFuZCAyQVdH IHdpcmVzLiBJdCB3YXJtCm1vc3Qgb2YgdGhlIHRpbWUgaGVyZSBuZWFyIEhvdXN0b24sIGJ1dCB3 ZSBkbyBnZXQgYSB3ZWVrIG9yIHR3byB3b3J0aCBvZgphbG1vc3QgY29sZCB3ZWF0aGVyLgoKUmVn YXJkcywKTWF0dCBTdGVjaGVyCkthdHkgVFgKVmFyaWV6ZSBONTRFRyByZWJ1aWxkCgpUaW1lOiAx MTo0Nzo1MCBBTSBQU1QgVVMKRnJvbTogIlJvYmVydCBMLiBOdWNrb2xscywgSUlJIiA8bnVja29s bHMuYm9iQGFlcm9lbGVjdHJpYy5jb20+ClN1YmplY3Q6IFJlOiBBZXJvRWxlY3RyaWMtTGlzdDog U2NoZW1hdGljIFotMTcgcXVlc3Rpb25zCgoKQXQgMDE6MjEgUE0gNS8xOC8yMDE0LCB5b3Ugd3Jv dGU6Cj48bXJjYzEyMzRAc2JjZ2xvYmFsLm5ldD4KPgo+SSBhbSByZXdpcmluZyBhIFZlcmlFemUg KHdpdGggTy0yMDBBKSBhbmQgcHV0dGluZyBpbiBhIG5ldyBwYW5lbC4KPgo+V2VpZ2h0IGlzIGFs d2F5cyBhIGZhY3RvciBhbmQgSSBhbSB0cnlpbmcgdG8ga2VlcCBpdCBsaWdodCwgYnV0IGFmdGVy IAo+ZGlzY3Vzc2lvbnMgd2l0aCB0aGUgZ2FuZywgSSBhbSBub3cgY29udmluY2VkIHRoYXQgYSBz dGFydGluZyBzeXN0ZW0gCj4odnMgcHJvcCBzdGFydCkgaXMgbmV4dCB0byBtYW5kYXRvcnkuCj4K PlNvIHRoZSBzaW1wbGVzdCBzeXN0ZW0gdGhhdCBtZWV0cyB0aGlzIG5lZWQgaXMgdGhlIFotMTcg ZGVzaWduLCBidXQgSSAKPndvdWxkIGxpa2UgdG8gdXNlIHRoZSBCJkMgMjAwRyAoMTJhbXApIGFs dGVybmF0b3IgaW5zdGVhZCBvZiB0aGUgU0Q4IAo+KG5vdGVkIGluIHRoZSBkaWFncmFtKS4KCsKg wqDCoCBUaGUgU0QtOCBhbmQgdGhlIDIwMEcgYXJlIGludGVyY2hhbmdlYWJsZSBzY2hlbWF0aWMK wqDCoMKgIHdpc2UuIEFyZSB5b3UgZ29pbmcgd2l0aCBsaWdodCB3ZWlnaHQgc3RhcnRlciB0b28/ CsKgwqDCoCBBcmUgeW91IHZmciBhbmQga2VlcGluZyBtYWduZXRvcz8gSWYgc28sIHlvdSBDT1VM RArCoMKgwqAgY29uc2lkZXIgYSByZWFsbHkgbGlnaHQgbGl0aGl1bSBiYXR0ZXJ5IG1vdW50ZWQK wqDCoMKgIGFmdCBzdWNoIHRoYXQgYWxsIHlvdXIgZmF0IHdpcmVzIGFyZSBzaG9ydC4KCj5JcyBp dCBhIGRyb3AgaW4gc3Vic3RpdHV0ZSB3aXRob3V0IG1vZGlmaWNhdGlvbiB0byB0aGUgd2lyaW5n IGRpYWdyYW0/CgrCoMKgwqAgWWVzIC4gLiAuCgoKPkFuZCBpcyB0aGUgNEFXRyB3aXJpbmcgZm9y IHN0YXJ0aW5nIGFuZCBwcmltYXJ5IGdyb3VuZCB3aXJlcyBzdGlsbCAKPnN1ZmZpY2llbnQ/CgrC oMKgwqAgTWlnaHQgZXZlbiBkcm9wIHRvIDZBV0cgaWYgdGhlIGxlYWRzIHdlcmUgc2hvcnQgYXMK wqDCoMKgIGh5cG90aGVzaXplZCBhYm92ZSAuIC4gLgoKwqDCoMKgIEJ1dCBpZiB5b3VyIGJhdHRl cnkgaGFzIHRvIGdvIHVwIGZyb250LCB5b3UgY2FuIHByb2JhYmx5CsKgwqDCoCBnZXQgYnkgd2l0 aCA0QVdHIGluIHdhcm0gd2VhdGhlciBjb3VudHJ5IC4gLiAuIHdoaWNoCsKgwqDCoCBtYXkgYmUg YSBnaXZlbiB3aXRoIHRoZSBWZXJpRXplIC4gLiAuCgoKwqDCoCBCb2IgLiAuIC4KCgpfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpf LT3CoMKgwqDCoMKgwqDCoMKgwqAgLSBUaGUgQWVyb0VsZWN0cmljLUxpc3QgRW1haWwgRm9ydW0g LQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3Nl Cl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9u LApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEs Cl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT3CoMKgIC0tPiBodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0Flcm9FbGVjdHJpYy1MaXN0Cl8tPQpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMg LQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVt cyEKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Xy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUg LQpfLT3CoCBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09wqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtTWF0dCBE cmFsbGUsIExpc3QgQWRtaW4uCl8tPcKgwqAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KCgoK ________________________________________________________________________________
Date: May 21, 2014
Subject: Need picture for product display at OSH2014
Still looking for a nose-on shot of a OBAM aircraft . . . probably tricycle gear . . . looking right down the center of spinner. Need to see it all out to wing tips. 1024 x 768 resolution or better would be nice too. Selected a/c will figure in table top display of the programmable wig-wag flasher we did here on the List as an open source project last year. It's going to be the first AeroElectric Connection product to be added to B&C's stable of offerings. Thanks! Bob . . . ________________________________________________________________________________
Date: May 21, 2014
At 06:06 PM 5/19/2014, you wrote: >Thanks Bob. Good info and I will watch for the Kitplanes articles. I >hear your concern about capacity and I was wondering about that. I >am thinking about an electrically dependent airplane with EFII but >also thinking about two alternators like your figure Z-13/8. Z-13/8 (or similar) is probably the-best- we-know-how-to-do for the down-sizing of battery capacity. I think I recall writing that mounting the SD-8 alternator on the vacated vacuum pump pad validates common practice in both the automotive and light aircraft worlds of flogging the battery until it simply won't crank the engine any more. When your airplane is fitted with THREE sources of energy of which only one is a battery, then you're firmer ground in spite of a flagging battery. By extension we can assert that once the battery is relieved of duties for flight in an endurance mode, then the battery can be (1) routinely flogged to death or (2) down-sized as long as it still cranks the engine. But we're still not very smart with respect to cost of ownership for these little power-houses. The satisfaction of having saved a few pounds may flag in the face of extra-ordinary maintenance to protect their easily insulted physics. In one of the Kitplanes articles I posed a question along the lines: "Okay you've shed 10 pounds of empty weight and freed up 30 cubic inches of volume. How will you used those newly acquired assets? Store sandwiches in the newly opened volume? Will a ten pound delta get you off fields you could not operate out of before . . . can you now climb over taller mountains?" Burt Rutan told us that it takes about 5 pounds of fuel to carry one pound of airplane around the world. So leaving 1 pound behind gave them either 6# lighter gross at t/o . . . or freed up nearly a gallon of gas for end of flight endurance . . . which in that airplane was about 100 miles! Those are the discussions and experiments we can be doing amongst members of the List . . . and Kitplanes offers us a forum to share our findings. Bob . . . ________________________________________________________________________________
Date: May 21, 2014
Subject: Re: Need picture for product display at OSH2014
At 06:01 PM 5/21/2014, you wrote: >Not a very interesting background, but is this what you want? EXACTLY! Thanks. Bob . . . ________________________________________________________________________________
Subject: Aerovoltz and Starter Draw (was Z-17 Schematic)
Date: May 21, 2014
The Aerovoltz is in the mail as they say and I can report the details as soon as I get it. You probably spell out how to build the cap check curves in your book so I will look into that. Good to know that 4awg should be sufficient at least that saves a little weight. I was having trouble figuring out how much current to assume was being drawn during a cold start to base the wire size calc on. Thanks, Matt > At 09:33 PM 5/20/2014, you wrote: >> >> >> Thanks for your responses Bob, >> >> I have purchased an Aerovolts 12 cell lithium battery to give a try. It is >> billed as the choice for cranking an O-200 and is 4.4"x3.4"x4" and 2.5 lbs. > > Hmmmm . . . I'd sure like to do a family of > cap check curves on it . . . > > I've looked over their website. They seem to offer > a 'special charger' for 'improved life' but also > says 'no special charger necessary'. > > Did any paperwork come with the battery that > cautions about deep discharge and/or making sure > the bus voltage is not too high? > > >> I am shooting for an aft installation and as you said that will let me keep >> my heavy wires short. I would like to put it in the main spar, but not sure >> about drilling holes in it to run the wires out or for mounting the battery. >> If that does not work I am looking at the hell hole above the landing gear >> attachment. >> >> If the aft locations prove more trouble than they are worth than I am >> looking at the traditional battery spot in the nose and 2AWG wires. It warm >> most of the time here near Houston, but we do get a week or two worth of >> almost cold weather. > > 4AWG is about 300 micro-ohms per foot WARM (160F > from cranking). Assuming 24' round trip, a 200A > cranking current will toss off 1.44 volts in the > wire. 2AWG is 200 micro-ohms per foot and wouldn't > warm up as much . . . so figure about 0.9 volts > in wire drop for a net savings of about 0.5 volts > out of a total of 9-10 volts at the starter motor > terminals. 4AWG would probably be fine. > > > Bob . . . > ________________________________________________________________________________
Date: May 22, 2014
Subject: Re: Aerovoltz and Starter Draw (was Z-17 Schematic)
At 07:45 PM 5/21/2014, you wrote: >In > >The Aerovoltz is in the mail as they say and I can report the >details as soon as I get it. >You probably spell out how to build the cap check curves in your >book so I will look into that. Actually the task is a bit more complicated. I did a report on a 'leading technology' battery http://tinyurl.com/qe6yy6c to explore its performance numbers. Turns out to be a pretty good 100AH battery for an RV or some such . . . http://tinyurl.com/nf47dgk . . . but demonstrates 0.0063 ohms internal resistance. A 24-volt incarnation of this same battery would give us about 38AH at the 1-hour rate in an airplane . . . but would have 0.024 ohms internal resistance! It wouldn't crank its way out of a wet paper sack. Gathering this class of data takes some test equipment. If you would volunteer your battery to receive about 4 charge-recharge cycles in accordance with manufacturer's recommendations for the test, I'd be pleased to gather and publish the data to the OBAM aviation community. >Good to know that 4awg should be sufficient at least that saves a >little weight. I was having trouble figuring out how much current to >assume was being drawn during a cold start to base the wire size calc on. Inrush can be higher but a 200A average cranking effort is about right . . . and by "cold" we mean below freezing when you probably wouldn't want to go flying anyhow. As I recall, cabin heat in that airplane is . . . shall we say . . . marginal? Bob . . . ________________________________________________________________________________
Date: May 22, 2014
Subject: Battery choice
I'm trying to decide on a battery. Many people are using the Odyssey PC680 with good results. It is a somewhat expensive battery: http://www.apexbattery.com/odyssey-pc680-marine-battery-marine-batteries-odyssey-marine-batteries.html?utm_source=googlepepla&utm_medium=adwords&id=18283950120&gclid=CIaiifviv74CFXRo7AodqxYANA In our UPS units we use a UB12180 battery (or equivalent), which is 1/3 the cost of the PC680 and has better specs: http://www.apexbattery.com/abiomed-bvs-5000-biventricular-support-battery-sealed-lead-acid-batteries-abiomed-batteries.html Are there any reasons why I should not be using this battery in my aircraft? My battery is mounted in the tail section, and it is not exposed to the direct heat and vibration of the engine compartment, if that makes any difference. -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: May 22, 2014
Subject: Re: Battery choice
On 5/22/2014 12:13 PM, Dj Merrill wrote: > > I'm trying to decide on a battery. Many people are using the Odyssey > PC680 with good results. It is a somewhat expensive battery: > > http://www.apexbattery.com/odyssey-pc680-marine-battery-marine-batteries-odyssey-marine-batteries.html?utm_source=googlepepla&utm_medium=adwords&id=18283950120&gclid=CIaiifviv74CFXRo7AodqxYANA > > In our UPS units we use a UB12180 battery (or equivalent), which is 1/3 > the cost of the PC680 and has better specs: > > http://www.apexbattery.com/abiomed-bvs-5000-biventricular-support-battery-sealed-lead-acid-batteries-abiomed-batteries.html > > Are there any reasons why I should not be using this battery in my > aircraft? > > My battery is mounted in the tail section, and it is not exposed to the > direct heat and vibration of the engine compartment, if that makes any > difference. > > -Dj > I did some digging a few years ago, & it seems that UPS and wheelchair/scooter batteries' chemistry is tweaked a bit differently from starting batteries. They are intended to be discharged somewhat slower, with deeper discharge (think 'marine' battery), but struggle a bit to deliver high short term bursts of energy, like you need to start a big engine. The easy way to spot the difference (if you can get full specs) is to compare the internal resistance numbers. For starting, lower is better. Another, less reliable way is to just look at the terminals. Many UPS batteries have terminals that are much too small to handle 200+ amps. I've been using 'brand-x' batteries in my planes for many years, & my experience is that some of the 18 AH rated batteries like the one you linked might struggle just a bit with a higher compression a/c engine, but you can usually buy a 20AH or 22AH model from the same series with almost identical case size, & it will provide almost enough 'grunt' to taxi the plane with the starter. :-) Price is still much lower than the Odyssey. Model number will be something like '12200' or '12220' instead of 12180 (the 18 indicated the AH rating). Most on-line battery sales operations now sell 'brand x' motorcycle/watercraft/etc starting batteries that are drop-in replacements for the Odyssey; that's the easiest way to get a suitable substitute at a lower price. FWIW, Charlie ________________________________________________________________________________
Date: May 22, 2014
In our UPS units we use a UB12180 battery (or equivalent), which is 1/3 the cost of the PC680 and has better specs: http://www.apexbattery.com/abiomed-bvs-5000-biventricular-support-battery-sealed-lead-acid-batteries-abiomed-batteries.html Are there any reasons why I should not be using this battery in my aircraft? None that I can think of . . . without a doubt the freshly installed battery will perform satisfactorily. The 18 Ah battery and form-factor have proven adequate to a huge segment of OBAM aircraft. The question that nobody can answer is cost of ownership for this battery. Figure sale price + shipping + maintenance costs for the less expensive battery. Is it likely that the more expensive battery will have a lower cost per flight hour than 3x the cheaper one? Probably not. 2x the cheaper one? Again, probably not. But that assertion is not supported with any data for either robustness + your working environment + possibly replacing the battery after cap-checks show it to be unsuitable for further flight. The risks are low. Try the less expensive battery and keep notes. Without having hard numbers on relative performance to stack against numbers for how YOU need to use the battery, nobody has the tools to either recommend or discourage the experiment. Let us know what you decide and what you find out in a year or so. Got a load tester? You might want to own one of these things. http://tinyurl.com/3gnnwrt This modern incarnation of 1930's technology is to batteries as a hammer is to nails. Bob . . . ________________________________________________________________________________
Date: May 22, 2014
DJ,=0A=0AI wonder if those stats for the cheaper battery are a little "opti mistic"?=0A=0A=0A-Jeff=0A=0A=0A________________________________=0A From: Dj Merrill =0ATo: aeroelectric-list(at)matronics.com =0ASent: Thu rsday, May 22, 2014 10:13 AM=0ASubject: AeroElectric-List: Battery choice t>=0A=0A--- I'm trying to decide on a battery.- Many people are usi ng the Odyssey=0APC680 with good results.- It is a somewhat expensive bat tery:=0A=0Ahttp://www.apexbattery.com/odyssey-pc680-marine-battery-marine-b atteries-odyssey-marine-batteries.html?utm_source=googlepepla&utm_medium =adwords&id=18283950120&gclid=CIaiifviv74CFXRo7AodqxYANA=0A=0A-- - In our UPS units we use a UB12180 battery (or equivalent), which is 1/3 =0Athe cost of the PC680 and has better specs:=0A=0Ahttp://www.apexbattery. com/abiomed-bvs-5000-biventricular-support-battery-sealed-lead-acid-batteri es-abiomed-batteries.html=0A=0A--- Are there any reasons why I should not be using this battery in my=0Aaircraft?=0A=0A--- My battery is m ounted in the tail section, and it is not exposed to the=0Adirect heat and vibration of the engine compartment, if that makes any=0Adifference.=0A=0A- Dj=0A=0A-- =0ADj Merrill - N1JOV - VP EAA Chapter 87=0ASportsman 2+2 Builde r #7118 N421DJ - http://deej.net/sportsman/=0AGlastar Flyer N866RH - http:/ = ________________________________________________________________________________
Date: May 22, 2014
On 5/22/2014 1:56 PM, Charlie England wrote: > but you can usually buy a 20AH or 22AH model from the same series with > almost identical case size, & it will provide almost enough 'grunt' to > taxi the plane with the starter. :-) Price is still much lower than > the Odyssey. Model number will be something like '12200' or '12220' > instead of 12180 (the 18 indicated the AH rating). Charlie, Good advice, thanks! $44 including shipping from Amazon for the UB12220 battery, 12v 22Ah in the same form factor. A plus is that it is 9 lbs lighter than the 25 Ah battery it will be replacing (a B and C model BC110-1). Bob, I will report back to the list as to how it performs. I have a low compression 150hp Lycoming O-320 with a light weight starter, so it should hopefully turn it over with no difficulty. -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: non-PC680 battery experience
Date: May 23, 2014
At original build, I also was looking at less-expensive alternatives to the PC680, especially since I have an electrically dependent Corvair engine and am using the 2-battery+PM alternator approach espoused by Bob, where I change the primary (starting) battery every year and keep last year=92s starting battery as the #2. So I purchased two fresh Universal Power UB12220 batteries from a local distributor. After about 7 months, I began having trouble with the primary battery cranking the very light, very easy to crank 190 c.i. engine. It got worse quickly and by the 8th month, I had replaced it with a PC680. At the annual, I moved that one to the #2 and put another PC680 in the #1 slot. No troubles since. I noted, in post-change research, that the specs for the UB12220 list the charging temp range as 0=B0-40=B0C and the discharging range as -15=B0-45=B0C. The storage limits are -15=B0-40=B0C. I operate out of Mesa, AZ and my son lives in Avon, CO, so I can guarantee that I exceeded those limits on both ends, but probably the worst effect was on the high end. With the #2 battery on the firewall, I bet it regularly sees 65=B0+, even in its insulated bracket. Heck, even for the #1 under the copilot=92s seat, we have ramp and hangar temps over 50=B0C for a good portion of the summer. So my purely anecdotally-based advice is to stick with batteries designed for motor vehicle use, especially if you have an electrically dependent airplane. If it=92ll survive on a Harley, it=92ll survive on your plane. The $80/year cost delta is pretty insignificant when you compare it to everything else. FWIW, Andy ------------------------ Andy Elliott, CL:480-695-9568 N601GE/Z601XLb/TD/Corvair 601 hrs since 11/08 <http://servi-aero.com/n601ge/4sale/> Web Site Link ________________________________________________________________________________
From: "H. Marvin Haught" <handainc(at)madisoncounty.net>
Subject: Re: non-PC680 battery experience
Date: May 23, 2014
Another anecdote as to "RV" type batteries: When I first bought my Pacer 22 years ago, the aircraft batteries I was using would only last a year. Plus, outgassing from the battery was eating up my battery box every 3 or 5 months. A good friend of mine advised me to buy a good, five year RV battery - almost exactly the same size as the aircraft battery I had been using, but with better cranking power....he had several airplanes and was using them in all of them. Now, I know this wasn't a "legal" installation, but I was sick of battery problems. That first RV battery lasted 6 years, was still cranking the airplane when I took it out, and lasted another couple of years in my lawnmower. In 20 years, I bought four batteries at around $55 to $60, all sealed type batteries. Except for one battery that was allowed to sit to long in a discharged state, none failed, but were replaced because of age. Using those batteries put an end to the outgassing and corrosion in the battery box, gave me reliable cranking power, and when camping, I ran my CPAP machine off of the battery. The battery still had enough power to crank the engine the next day. For their size, they are heavy, but have been the best solution for my use. When I sold my Pacer, the new owner installed one of the new lightweight batteries before we flew to Alaska. It worked fine in warm weather, but would not stand up to the cold when winter came. My new project is underway and is an experimental. I will again be using an RV battery, as they have been the best spark for my buck to this point. I will likely install two batteries in the project, which will be a back country airplane....both under the front seat right on the CG, as I will be using the aux battery to power my CPAP machine. M. Haught On May 23, 2014, at 7:35 AM, Dr. Andrew Elliott wrote: > At original build, I also was looking at less-expensive alternatives to the PC680, especially since I have an electrically dependent Corvair engine and am using the 2-battery+PM alternator approach espoused by Bob, where I change the primary (starting) battery every year and keep last year=92s starting battery as the #2. So I purchased two fresh Universal Power UB12220 batteries from a local distributor. > After about 7 months, I began having trouble with the primary battery cranking the very light, very easy to crank 190 c.i. engine. It got worse quickly and by the 8th month, I had replaced it with a PC680. At the annual, I moved that one to the #2 and put another PC680 in the #1 slot. No troubles since. > I noted, in post-change research, that the specs for the UB12220 list the charging temp range as 0=B0-40=B0C and the discharging range as -15=B0-45=B0C. The storage limits are -15=B0-40=B0C. I operate out of Mesa, AZ and my son lives in Avon, CO, so I can guarantee that I exceeded those limits on both ends, but probably the worst effect was on the high end. With the #2 battery on the firewall, I bet it regularly sees 65=B0+, even in its insulated bracket. Heck, even for the #1 under the copilot=92s seat, we have ramp and hangar temps over 50=B0C for a good portion of the summer. > So my purely anecdotally-based advice is to stick with batteries designed for motor vehicle use, especially if you have an electrically dependent airplane. If it=92ll survive on a Harley, it=92ll survive on your plane. The $80/year cost delta is pretty insignificant when you compare it to everything else. FWIW, > Andy > ------------------------ > Andy Elliott, CL:480-695-9568 > N601GE/Z601XLb/TD/Corvair > 601 hrs since 11/08 > Web Site Link > > > > > ________________________________________________________________________________
Date: May 23, 2014
> > So my purely anecdotally-based advice is to stick with batteries > designed for motor vehicle use, especially if you have an > electrically dependent airplane. If it'll survive on a Harley, > it'll survive on your plane. The $80/year cost delta is pretty > insignificant when you compare it to everything else. FWIW, Thanks Andy . . . good information. Bob . . . ________________________________________________________________________________
Date: May 23, 2014
> I will again be using an RV battery, as they have been the best > spark for my buck to this point. I will likely install two > batteries in the project, which will be a back country > airplane....both under the front seat right on the CG, as I will be > using the aux battery to power my CPAP machine. > >M. Haught When you say "RV" battery, I presume you're making reference to batteries tailored to deep cycle service in recreational vehicles . . . and yes, in the modern sealed, recombinant gas architecture, they should be very long lived in a light duty-cycle service like a light airplane. The elegant solution for batteries in airplanes is the product of a talented hat-dance around the features that drive weight, capacity and load-dumping ability. Ask Skip Koss about the music to which Concorde dances in the evolution of their products for aircraft. Earlier this week I mentioned an "RV" battery I was testing . . . a battery supposedly fitted with a leading edge technology that would reduce weight while at least not degrading capacity per unit volume and internal impedance . . . like grunting an over the road diesel engine to life. The thing I tested is an okay battery for capacity. 100 amp-hours plus at 20 hour rate, probably 75 amp- hours at a 1 hour rate. But it's ability to crank engines is problematic. In fact, a 24 volt incarnation of this product wouldn't get the typical piston engine airplane started. Now, it may well be a great RV battery in terms of service life . . . I'm not going to test for that. But your narrative underscores the uncertainty one experiences when staring at one of these things attempting to answer the question: "Should I use this in my airplane?" Emacs! ' Bottom line is that I don't have a clue . . . just as that Firefly battery came in a nice, colorful plastic case and proved that it would run my ham-rig for perhaps months on one charge, there was no way to know its true suitability to task without (1) testing and/ or (2) real-life feedback. Few manufacturers offer the hard-data offered by our legacy suppliers of known performance like Hawker-Enersys and Concorde. That doesn't mean one should avoid alternatives but do conduct the experiments at minimum risk. Bob . . . ________________________________________________________________________________
Subject: Wire tag ID needed
Date: May 23, 2014
Anyone know a source for these? Looks like the fastest way to label wires 'o n the fly'. It's on a wire for a Garmin 327 xponder I bought used. Thanks, Charlie Sent from my iPhone
Date: May 24, 2014
Subject: alternate batteries
> > I happened to be exploring some alternate battery battery options on the > 'net just yesterday, when something interesting popped out at me. Only one > referenced being a replacement for portable jump start units, and was > marketed under the Schumacher label. Does anyone know if there is some > difference in these batteries that might make them more appropriate for > engine cranking service, or is it all just advertising? ________________________________________________________________________________
Date: May 24, 2014
Subject: Re: alternate batteries
On 5/24/2014 12:01 PM, GLEN MATEJCEK wrote: > > I happened to be exploring some alternate battery battery options > on the 'net just yesterday, when something interesting popped out > at me. Only one referenced being a replacement for portable jump > start units, and was marketed under the Schumacher label. Does > anyone know if there is some difference in these batteries that > might make them more appropriate for engine cranking service, or > is it all just advertising? > > Look at internal impedance/resistance numbers. Easy to find for PC680; sometimes harder to find for brand x. Comparing batteries with the same ampere-hour ratings, batteries intended for relatively low current, long term discharge will have higher internal impedance than batteries intended for starting. Bob alluded to this in a recent post about a new battery he tested, that would last almost 'forever' running avionics, but couldn't supply enough power to start an engine. With the typical brand x SLA batteries I've seen over the last few years, up-sizing the AH rating by a few points (18 AH to 22AH, for example) gets the internal resistance low enough to match the higher priced PC680's starting ability. Going from 18 to 22 AH doesn't typically increase the size, at least not enough to matter. A lot of the brand x 18AH batteries are slightly smaller than a PC680. FWIW, Charlie ________________________________________________________________________________
Date: May 25, 2014
I buy my Odessey 680 at Wholesale Battery and the,last one was $110. See if there is one near you. They have good alkaline batts at good prices also, AA 9 volt, etc. Ron Burnett STL area Sent from my iPad May you have the blessings of the Lord today. > On May 22, 2014, at 12:13 PM, Dj Merrill wrote: > > > I'm trying to decide on a battery. Many people are using the Odyssey > PC680 with good results. It is a somewhat expensive battery: > > http://www.apexbattery.com/odyssey-pc680-marine-battery-marine-batteries-odyssey-marine-batteries.html?utm_source=googlepepla&utm_medium=adwords&id=18283950120&gclid=CIaiifviv74CFXRo7AodqxYANA > > In our UPS units we use a UB12180 battery (or equivalent), which is 1/3 > the cost of the PC680 and has better specs: > > http://www.apexbattery.com/abiomed-bvs-5000-biventricular-support-battery-sealed-lead-acid-batteries-abiomed-batteries.html > > Are there any reasons why I should not be using this battery in my > aircraft? > > My battery is mounted in the tail section, and it is not exposed to the > direct heat and vibration of the engine compartment, if that makes any > difference. > > -Dj > > -- > Dj Merrill - N1JOV - VP EAA Chapter 87 > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > > > ________________________________________________________________________________
Date: May 25, 2014
Subject: Alternate batteries
Howdy- Perhaps I phrased my question poorly. Were reliable internal impedance numbers consistently and readily available, identifying viable alternate batteries would be a snap. However, and as noted, finding the internal impedance of a battery can turn into a time consuming wild goose chase pretty quickly. If there were an accepted performance standard or threshold for so-called "jump start batteries", our task would be greatly simplified. ***snip*** > > > > I happened to be exploring some alternate battery battery options > > on the 'net just yesterday, when something interesting popped out > > at me. Only one referenced being a replacement for portable jump > > start units, and was marketed under the Schumacher label. Does > > anyone know if there is some difference in these batteries that > > might make them more appropriate for engine cranking service, or > > is it all just advertising? > > > > > Look at internal impedance/resistance numbers. Easy to find for PC680; > sometimes harder to find for brand x. Comparing batteries with the same > ampere-hour ratings, batteries intended for relatively low current, long > term discharge will have higher internal impedance than batteries > intended for starting. Bob alluded to this in a recent post about a new > battery he tested, that would last almost 'forever' running avionics, > but couldn't supply enough power to start an engine. > ***snip*** ________________________________________________________________________________
Date: May 25, 2014
Subject: Re: Alternate batteries
On 5/25/2014 12:09 PM, GLEN MATEJCEK wrote: > Howdy- > > Perhaps I phrased my question poorly. Were reliable internal > impedance numbers consistently and readily available, identifying > viable alternate batteries would be a snap. However, and as noted, > finding the internal impedance of a battery can turn into a time > consuming wild goose chase pretty quickly. If there were an accepted > performance standard or threshold for so-called "jump start > batteries", our task would be greatly simplified. > > ***snip*** > > > > I happened to be exploring some alternate battery battery > options > > on the 'net just yesterday, when something interesting > popped out > > at me. Only one referenced being a replacement for portable > jump > > start units, and was marketed under the Schumacher label. Does > > anyone know if there is some difference in these batteries that > > might make them more appropriate for engine cranking service, or > > is it all just advertising? > > > > > Look at internal impedance/resistance numbers. Easy to find for PC680; > sometimes harder to find for brand x. Comparing batteries with the > same > ampere-hour ratings, batteries intended for relatively low > current, long > term discharge will have higher internal impedance than batteries > intended for starting. Bob alluded to this in a recent post about > a new > battery he tested, that would last almost 'forever' running avionics, > but couldn't supply enough power to start an engine. > > > ***snip*** > Your followup question folds back on itself, and is basically unanswerable. Marketers say whatever they want to say, within the confines of their bosses at that particular company. There have been 'jump start' *assemblies* on the market that contained batteries labeled, for example, as 18 AH, that had guts in the battery that were really only around 12 AH. So 'suitability' is whatever the bosses say is suitable, when you're reading a spec sheet or advertising brochure. There are batteries designed for starting, and there are batteries designed for sustained loading at a much lower rate, as in a UPS or scooter. Some of the 'lower rate' type batteries will actually work fine for starting. The only way to know for sure on any particular battery is to test for yourself, or trust the word of someone who's already 'been there & done that'. I've used 'brand x' 18 AH & 22 AH batteries of both known & unknown internal impedances for over a decade with good service, in the deep south, with temps ranging from below freezing to over 100 degrees F. Most of that time, the battery was on the hot side of the firewall(s). Someone else has posted that he didn't have good service at temps that might have been 5-10 degrees higher. Don't forget that there are many many factors affecting whether a product works well. I try to find the internal impedance number if I can before I buy a particular battery, but I've bought them without knowing, & have usually gotten good service. As I said in an earlier post, the best inexpensive battery I've found is labeled **12220, with various prefixes depending on the seller. It's the same form factor as the 18 AH Odyssey. Bonus is an extra 4 AH if you have an electrically dependent a/c. Charlie ________________________________________________________________________________
Subject: Re: Wire tag ID needed
Date: May 25, 2014
That looks like a ScotchCode STD-TAG Grainger 2FYR9 See http://www.grainger.com/product/3M-Wire-Marker-Refill-Roll-3-2FYR9?s_pp=false -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423790#423790 ________________________________________________________________________________
Date: May 25, 2014
On 5/25/2014 9:36 PM, Eric M. Jones wrote: > > That looks like a ScotchCode STD-TAG > Grainger 2FYR9 > > See http://www.grainger.com/product/3M-Wire-Marker-Refill-Roll-3-2FYR9?s_pp=false > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net Excellent! Many thanks, Charlie ________________________________________________________________________________
Subject: Trio Avionics ProPilot 130 Mhz interference problem
(was noise problem on radio)
Date: May 27, 2014
Folks, I'm reporting back on the solution to a problem which has been plaguing me for over a year and which I've posted about a few times. Anytime my autopilot (a Trio Avionics ProPilot) is switched on, I would hear very loud noise on the radio. Yesterday I was down at the field trying to gather some data about the noise I hear on the radio which I only hear when my Autopilot is switched on. The first thing I confirmed was that the noise is also clearly audible (and so strong as to be unsquelchable) on my handheld radio, any time it is within a couple metres of the aircraft. While I was tinkering around, almost by mistake, I switched frequencies on the radio (in Italy ultralights are only allowed to use the 130 Mhz frequency): silence!!!! It turns out that the noise is only audible on 130.00 Mhz!!!!! In the evening I called the guys at Trio and they confirmed that they are aware of this interference problem. Chuck at Trio told me that they have a 10 Mhz oscillator in the box and that the 13th harmonic is what I was hearing on the radio. The solution involves substituting the oscillator with a 10.026 Mhz oscillator and Trio will perform this operation in-house or ship you the necessary part. So much for the hundred man-hours spent checking all my avionics interconnections, coaxial cables, etc!! Sacha ________________________________________________________________________________
Date: May 27, 2014
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
Subject: Re: Trio Avionics ProPilot 130 Mhz interference problem
(was noise problem on radio) Glad to hear you solved your problem, Sacha.- So much for vendors meeting standards like DO-160G.- This Trio product is designed incorrectly to me et this standard, and their switching frequencies to move it away from 130. 00 MHz is only a band-aid.=0A=0AWe had a discussion earlier about how an op en antenna cable could cause damage to a transmitter, and I explained how t he wave's voltage can double as it bounces back to the transmitter.- Bob said that today's avionics are protected against such damage.- I claim no t all electronics are designed to DO-160 and if they are, sometimes enginee rs make mistakes or the product is manufactured incorrectly.- As Bob said , it's a very small probability but it can happen.=0A=0A-=0AHenador Titzo ff=0A=0A=0A>________________________________=0A> From: Sacha <uuccio@gmail. com>=0A>To: aeroelectric-list(at)matronics.com =0A>Sent: Tuesday, May 27, 2014 2:23 AM=0A>Subject: AeroElectric-List: Trio Avionics ProPilot 130 Mhz inte rference problem (was noise problem on radio)=0A> =0A>=0A>--> AeroElectric- List message posted by: "Sacha" =0A>=0A>Folks,=0A>=0A>I'm reporting back on the solution to a problem which has been plaguing me=0A> for over a year and which I've posted about a few times. Anytime my=0A>auto pilot (a Trio Avionics ProPilot) is switched on, I would hear very loud=0A> noise on the radio.- =0A>=0A>Yesterday I was down at the field trying to gather some data about the noise=0A>I hear on the radio which I only hear w hen my Autopilot is switched on.=0A>The first thing I confirmed was that th e noise is also clearly audible (and=0A>so strong as to be unsquelchable) o n my handheld radio, any time it is=0A>within a couple metres of the aircra ft.- While I was tinkering around,=0A>almost by mistake, I switched freq uencies on the radio (in Italy ultralights=0A>are only allowed to use the 1 30 Mhz frequency): silence!!!!- It turns out=0A>that the noise is only au dible on 130.00 Mhz!!!!!=0A>=0A>In the evening I called the guys at Trio an d they confirmed that they are=0A>aware of this interference problem.- Ch uck at Trio told me that they have a=0A>10 Mhz oscillator in the box and th at the 13th harmonic is what I was=0A>hearing on the radio.- The solution involves substituting the oscillator=0A>with a 10.026 Mhz oscillator and T rio will perform this operation in-house=0A>or ship you the necessary part. - =0A>=0A>So much for the hundred man-hours spent checking all my avionic =========================0A =========================0A =========================0A >=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Date: May 28, 2014
(was noise problem on radio) At 05:33 PM 5/27/2014, you wrote: >Glad to hear you solved your problem, Sacha. So much for vendors >meeting standards like DO-160G. This Trio product is designed >incorrectly to meet this standard, and their switching frequencies >to move it away from 130.00 MHz is only a band-aid. > >We had a discussion earlier about how an open antenna cable could >cause damage to a transmitter, and I explained how the wave's >voltage can double as it bounces back to the transmitter. Bob said >that today's avionics are protected against such damage. I claim >not all electronics are designed to DO-160 and if they are, >sometimes engineers make mistakes or the product is manufactured >incorrectly. As Bob said, it's a very small probability but it can happen. We're talking about two different critters here . . . DO-160 is not a requirement but a validation guide for design goals. It's sorta like the covenants you sign with the homeowner's association that says you both understand and agree to certain behaviors. It gives you and your neighbors a level of confidence for friendly co-existence in a close knit community. Wrapping SWR protection around the final amplifier of a transmitter is a common sense recognition of risk followed by a behavior to design for SWR robustness -or- automatic reduction of drive to the final amplifier when excessive SWR is detected. Both approaches have been part of the best we know how to do for decades. Neither one is difficult. For writers in technical matters to make blanket statements warning against test operations into open transmission lines suggests that they simply choose not to avail themselves of pretty common knowledge. Consider the hand-held transceiver that can be keyed into a constellation of antennas presenting SWR values the hand-held designer has no control over . . . but it's no big deal . . . protection against such hazard is rudimentary to the contemporary design process. Not designing around the risks for high SWR is like opening the hood of a modern car to find a carburetor sitting on top of the engine . . . everybody looks at each other and asks "why would anyone do that?" On the other hand, my first contact with Trio suggests that they've treated DO-160 as a 'requirement'. Given that they do not sell into the TC aircraft market, they seem to think DO-160 is not applicable/ useful to their design efforts. I'll see if I can help them deduce the feature of their product that lets the interfering energy get outside their box . . . and hopefully there is a relatively painless solution. We'll see. It would be useful for them -AND- their customers to understand that DO-160 guidelines are recipes for blissful living in the community of airplane owners no matter where the airplane was built. Bob . . . ________________________________________________________________________________
Date: May 28, 2014
(was noise problem on radio) Thanks, Bob, for understanding that DO-160 is a verification standard that lists and specifies requirements for:=0A* temperature effects=0A=0A* altitude effects=0A=0A* humidity effects=0A=0A* shock and vibration e ffects=0A=0A* explosion susceptibility and water proofness =0A=0A* fl uids susceptibility, sand and dust intrusion=0A* fungus resistance=0A * salt and fog resistance=0A* magnetic effect on ship compass=0A* pow er input variations effects=0A=0A* voltage spike effects=0A=0A* audio frequency conducted susceptibility=0A* RF susceptibility and emissions =0A* lightning susceptibility=0A* icing effects=0A* ESD susceptibi lity=0A* flammability analysis=0ASince the above parameters are verified , it stands to reason that the avionics designer must design for them in or der to pass the DO-160 standard.- In Trio's case, they violated RF emissi ons requirements.=0A=0AIf you do talk to them, please note that the most li kely culprit is the PCB design.- Proper design here will contain the ener gy that leaks out the sides of the board and also- minimizes radiated RF energy by using microstrip and stripline designs.- There are tools such a s Mentor Graphics Hyperlynx that can simulate the design and thus minimize it by offering standard solutions as well as making changes and iterating t he simulation to see what effect the change made.- I've seen designs go f rom obnoxiously loud to very quiet by using proper design techniques and si mulation. =0A=0A=0AHenador Titzoff=0A=0A=0A>_______________________________ _=0A> From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>=0A>To : aeroelectric-list(at)matronics.com =0A>Sent: Wednesday, May 28, 2014 11:29 A M=0A>Subject: Re: AeroElectric-List: Trio Avionics ProPilot 130 Mhz inter ference problem (was noise problem on radio)=0A> =0A>=0A>=0A>At 05:33 PM 5/ 27/2014, you wrote:=0A>=0A>Glad to hear you solved your=0Aproblem, Sacha. - So much for vendors meeting standards like=0ADO-160G.- This Trio prod uct is designed incorrectly to meet this=0Astandard, and their switching fr equencies to move it away from 130.00 MHz=0Ais only a band-aid.=0A>>=0A>>We had a discussion earlier about how an open antenna cable could cause=0Adam age to a transmitter, and I explained how the wave's voltage can=0Adouble a s it bounces back to the transmitter.- Bob said that today's=0Aavionics a re protected against such damage.- I claim not all=0Aelectronics are desi gned to DO-160 and if they are, sometimes engineers=0Amake mistakes or the product is manufactured incorrectly.- As Bob=0Asaid, it's a very small pr obability but it can=0Ahappen.=0A>-- We're talking about two different critters here . . .=0A>-- DO-160 is not a requirement but a validation guide=0A>-- for design goals. It's sorta like the covenants you=0A>- - sign with the homeowner's association that says you=0A>-- both unde rstand and agree to certain behaviors. It=0A>-- gives you and your neig hbors a level of confidence=0A>-- for friendly co-existence in a close knit=0Acommunity.=0A>=0A>-- Wrapping SWR protection around the final am plifier=0A>-- of a transmitter is a common sense recognition of=0A>- - risk followed by a behavior to design for SWR=0Arobustness=0A>-- -o r- automatic reduction of drive to the final=0Aamplifier=0A>-- when exc essive SWR is detected. Both approaches have=0Abeen=0A>-- part of the b est we know how to do for decades. Neither=0A>-- one is difficult. For writers in technical matters=0A>-- to make blanket statements warning a gainst test=0A>-- operations into open transmission lines suggests=0A> -- that they simply choose not to avail themselves=0A>-- of pretty common knowledge. Consider the hand-held=0A>-- transceiver that can be keyed into a constellation=0A>-- of antennas presenting SWR values the hand-held=0A>-- designer has no control over . . . but it's no=0A>- - big deal . . . protection against such hazard=0A>-- is rudimentary to the contemporary design process.=0A>-- Not designing around the risk s for high=0A>-- SWR is like opening the hood of a modern car=0A>-- to find a carburetor sitting on top of the engine=0A>-- . . .- every body looks at each other and asks=0A>-- "why would anyone do that?"=0A> =0A>-- On the other hand, my first contact with Trio=0A>-- suggests that they've treated DO-160 as a=0A'requirement'.=0A>-- Given that the y do not sell into the TC aircraft=0A>-- market, they seem to think DO- 160 is not applicable/=0A>-- useful to their design efforts.=0A>=0A>- - I'll see if I can help them deduce the=0A>-- feature of their produ ct that lets the interfering=0A>-- energy get outside their box . . . a nd hopefully=0A>-- there is a relatively painless solution. We'll=0A> -- see. It would be useful for them -AND- their =0A>-- customers to understand that DO-160 guidelines =0A>-- are recipes for blissful livi ng in the=0A>-- community of airplane owners no matter where=0A>-- =========== =0A>=0A> ________________________________________________________________________________
Subject: Through-Hole Wire Metal
Date: May 28, 2014
Some resistors and capacitors have tinned copper leads and some have steel leads. Does it matter? It seems to me that copper is better because it does not rust. What do you think? Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423932#423932 ________________________________________________________________________________
Date: May 29, 2014
Subject: testing a coax lead
Hi folks, I am about to fly my RV 8 for the first time. Finished construction and am now tracking down glitches. I had a guy out to certify my pitot, static and transponder today. Pretty funny sequence. First, we couldn't get altitude data to the transponder. Turns out that you have to turn on the serial data feed in a GRT EFIS. Next, turned out the feed pin on was sub-D connector into the transponder was in the wrong spot. Finally got a read-out on the altitude. Last problem, the transponder signal was really weak. We disconnected the antenna and plugged the transponder directly into his tester. The unit, a Garmin 327, was working fine. That leaves the antenna and leads. I used a right angle adaptor as described in the comic book. One from the transponder and one into the antenna. Seems highly unlikely that there is a break in the cable itself. More likely, one of the connectors or the right angle adaptors is at fault.. Any good ideas about how to test this? I don't want to have the certification technician come out again until I am sure I have solved the problem. I also don't want to tear out the entire cable and start over--really inconvenient at this juncture. I didn't leave enough slack to cut off the connecters and start over so really, I just need to diagnose the location of the fault and repair it. Two questions: how to track down the fault; how to test the line and/or antenna to make sure it is functioning properly prior to calling out the technician again. Suggestions? Regards, Michael Wynn RV 8 Finished San Ramon, CA ________________________________________________________________________________
Date: May 29, 2014
>Glad to hear you solved your problem, Sacha. Thank you. > On the other hand, my first contact with Trio > suggests that they've treated DO-160 as a 'requirement'. > Given that they do not sell into the TC aircraft > market, they seem to think DO-160 is not applicable/ > useful to their design efforts. > I'll see if I can help them deduce the > feature of their product that lets the interfering > energy get outside their box . . . and hopefully > there is a relatively painless solution. We'll > see. It would be useful for them -AND- their > customers to understand that DO-160 guidelines > are recipes for blissful living in the > community of airplane owners no matter where > the airplane was built. Bob, I have met the folks at Trio personally and believe that they would appreciate your help. In fact they are the people who first pointed me to the AeroElectric list. I'll forward this conversation to them to see if they have any interest. Sacha ________________________________________________________________________________
Date: May 29, 2014
Subject: Re: Through-Hole Wire Metal
At 08:06 PM 5/28/2014, you wrote: > >Some resistors and capacitors have tinned copper leads and some have >steel leads. Does it matter? It seems to me that copper is better >because it does not rust. What do you think? All components crafted for use in electronic assemblies have a finish on leads that is conducive to soldering. The actual material is seldom an issue as long as they solder well. Bob . . . ________________________________________________________________________________
Date: May 29, 2014
Subject: Re: testing a coax lead
At 11:18 PM 5/28/2014, you wrote: >Hi folks, > >I am about to fly my RV 8 for the first time. Finished construction >and am now tracking down glitches. I had a guy out to certify my >pitot, static and transponder today. Pretty funny sequence. First, >we couldn't get altitude data to the transponder. Turns out that >you have to turn on the serial data feed in a GRT EFIS. Next, >turned out the feed pin on was sub-D connector into the transponder >was in the wrong spot. Finally got a read-out on the >altitude. Last problem, the transponder signal was really weak. > >We disconnected the antenna and plugged the transponder directly >into his tester. The unit, a Garmin 327, was working fine. That >leaves the antenna and leads. > >I used a right angle adaptor as described in the comic book. One >from the transponder and one into the antenna. Seems highly >unlikely that there is a break in the cable itself. More likely, >one of the connectors or the right angle adaptors is at fault.. Any >good ideas about how to test this? I don't want to have the >certification technician come out again until I am sure I have >solved the problem. I also don't want to tear out the entire cable >and start over--really inconvenient at this juncture. I didn't >leave enough slack to cut off the connecters and start over so >really, I just need to diagnose the location of the fault and repair it. > >Two questions: how to track down the fault; how to test the line >and/or antenna to make sure it is functioning properly prior to >calling out the technician again. Unfortunately, doing SWR checks on antennas at this frequency is beyond the range of most pieces of amateur radio equipment. Do an ohmmeter check from center pin to center pin . . . from connector body to connector body . . . I've never experienced any problems the po' boy's right angle connector . . . but simply replacing the DIY with an on-purpose connector wouldn't hurt. Do you have a RG-400 connector crimp tool? I can send you a connector. Bob . . . ________________________________________________________________________________
Date: May 29, 2014
Subject: circuit protection on contactors
We generally put some form of circuit protection (fuse, breaker, etc) on most of our circuits, including the circuit to activate the starter contactor, but we usually do not put any type of protection on the circuit to activate the master contactor or E-bus contactor. I am curious, why is this? Thanks, -Dj, in the middle of re-wiring for a panel upgrade -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Re: circuit protection on contactors
Date: May 29, 2014
The practice is to protect against wires shorting to ground. The circuit protection trips due to large fault current. The master or e-bus contactor control wires operate by grounding the conductor with a switch. The current in this circuit is limited by the resistance of the contactor coil, so it needs no protection. A short on this wire may cause undesirable behaviour, but it won't melt or catch fire. Vern =================================================== Sent from my iThing. It is responsible for all gramma and typo terrors. > On May 29, 2014, at 8:09 PM, Dj Merrill wrote: > > > We generally put some form of circuit protection (fuse, breaker, etc) on most of our circuits, including the circuit to activate the starter contactor, but we usually do not put any type of protection on the circuit to activate the master contactor or E-bus contactor. > > I am curious, why is this? > > Thanks, > > -Dj, in the middle of re-wiring for a panel upgrade > > -- > Dj Merrill - N1JOV - VP EAA Chapter 87 > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > > > ________________________________________________________________________________
Date: May 30, 2014
Hi Bob, It makes sense to start with an ohm meter just to look for continuity. I guess the next thing would be a coin flip to see which end to break open. Replacing the right angles on both ends should take care of the issue. Unless I do that, I won't know that I have fixed the issue unless something comes up in the continuity check. I do have an R400 crimp tool. I bought that and pretty much all my wiring stuff from B&C. Very good folks to do business with. They offer a right angle adaptor but not a right angle connector. Steinair offers them at $17.50 a pop. Yikes! I suppose in the overall scheme of things, that is just a drop in the proverbial bucket. It will cost more than that to get the transponder certification guy out again. If you have a spare dedicated right angle connector or two you are willing to donate to a worthy cause, that would be great. Otherwise, unless I can find an obvious error in my crimping or connectors, I will buy them from Steinair. As usual, thank you for your insights. The Aeroelectric Connection and this forum have been completely invaluable in planning and executing the wiring of my plane. Regards, Michael Wynn RV 8 Mostly Finished San Ramon, CA In a message dated 5/29/2014 5:47:43 P.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes: At 11:18 PM 5/28/2014, you wrote: Hi folks, I am about to fly my RV 8 for the first time. Finished construction and am now tracking down glitches. I had a guy out to certify my pitot, static and transponder today. Pretty funny sequence. First, we couldn't get altitude data to the transponder. Turns out that you have to turn on the serial data feed in a GRT EFIS. Next, turned out the feed pin on was sub-D connector into the transponder was in the wrong spot. Finally got a read-out on the altitude. Last problem, the transponder signal was really weak. We disconnected the antenna and plugged the transponder directly into his tester. The unit, a Garmin 327, was working fine. That leaves the antenna and leads. I used a right angle adaptor as described in the comic book. One from the transponder and one into the antenna. Seems highly unlikely that there is a break in the cable itself. More likely, one of the connectors or the right angle adaptors is at fault.. Any good ideas about how to test this? I don't want to have the certification technician come out again until I am sure I have solved the problem. I also don't want to tear out the entire cable and start over--really inconvenient at this juncture. I didn't leave enough slack to cut off the connecters and start over so really, I just need to diagnose the location of the fault and repair it. Two questions: how to track down the fault; how to test the line and/or antenna to make sure it is functioning properly prior to calling out the technician again. Unfortunately, doing SWR checks on antennas at this frequency is beyond the range of most pieces of amateur radio equipment. Do an ohmmeter check from center pin to center pin . . . from connector body to connector body . . . I've never experienced any problems the po' boy's right angle connector . . . but simply replacing the DIY with an on-purpose connector wouldn't hurt. Do you have a RG-400 connector crimp tool? I can send you a connector. Bob . . . ________________________________________________________________________________
(was n
Date: May 30, 2014
I designed PCBs for medical devices for 25 years. Some very high-power devices were so quiet that the test lab couldn't tell if the devices were on or not. So a device like Trio Avionics ProPilot and its interference problem does not seem to be a difficult fix. Changing the Xtal DOES seem like a bean-counter fix, but sometimes that is the only way to go. I'd LOVE to inspect the PCB. In the future Bob and many PCB layout gurus can suggest how to build a PCB and case that will generate fewer customer problems. My absolute conviction is: 1) Short and decoupled clock line; 2) Four layer PCB (solves 90% of the problems). 3) Examine and minimize every single current loop. I can suggest Kimmel and Gerke of course, but also many online guides like: http://www.ti.com/lit/an/scaa082/scaa082.pdf -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=424034#424034 ________________________________________________________________________________
Date: May 30, 2014
At 08:45 AM 5/30/2014, you wrote: >Hi Bob, > >It makes sense to start with an ohm meter just to look for >continuity. I guess the next thing would be a coin flip to see >which end to break open. Replacing the right angles on both ends >should take care of the issue. Unless I do that, I won't know that >I have fixed the issue unless something comes up in the continuity check. A reasonable conclusion. Do you have DIY rt angle connectors on both ends? > >I do have an R400 crimp tool. I bought that and pretty much all my >wiring stuff from B&C. Very good folks to do business with. They >offer a right angle adaptor but not a right angle >connector. Steinair offers them at $17.50 a pop. Yikes! I suppose >in the overall scheme of things, that is just a drop in the >proverbial bucket. It will cost more than that to get the >transponder certification guy out again. You're right. The short path to success is to simply replace 'em . . . I'll give B&C a heads-up on a more economical alternative. Shoot me your mailing address and I'll get some connectors in the mail to you today. > >If you have a spare dedicated right angle connector or two you are >willing to donate to a worthy cause, that would be >great. Otherwise, unless I can find an obvious error in my crimping >or connectors, I will buy them from Steinair. > >As usual, thank you for your insights. The Aeroelectric Connection >and this forum have been completely invaluable in planning and >executing the wiring of my plane. It's called the exercise of spontaneous organization. Groups of willing and able individuals gathering the sum of their time, talents and resources together in quest of a common goal. Took me 50+ years to acquire an understanding of the phenomenon . . . it's been going on for thousands of years. Works every time its tried but really easy to derail. I'm pleased that this List has been largely immune to derailments . . . Bob . . . ________________________________________________________________________________
Date: May 30, 2014
=0AI agree w/ everything that Vern said and add that this circuit is unique in that the length of the positive wire which provides power for the coil is usually very short - only an inch or two - from the big positive termina l to the little coil terminal on the relay/solenoid and that's why we can g et away with no circuit protection.- This is not the case with almost all other circuits.=0A=0A-Jeff=0A=0A=0A=0AOn Thursday, May 29, 2014 11:21 PM, Sprocket <sprocket@vx-aviation.com> wrote:=0A =0A=0A=0A--> AeroElectric-Lis t message posted by: Sprocket <sprocket@vx-aviation.com>=0A=0AThe practice is to protect against wires shorting to ground. The circuit protection trip s due to large fault current.=0A=0AThe master or e-bus contactor control wi res operate by grounding the conductor with a switch.- The current in thi s circuit is limited by the resistance of the contactor coil, so it needs n o protection.- A short on this wire may cause undesirable behaviour, but it won't melt or catch fire.=0A=0AVern=0A=0A========== ==================0ASent from my iThing. It is responsible for all gramma and typo terrors.=0A=0A> On May 29, 2014, at 8:09 PM, Dj Merrill wrote:=0A> =0A> --> AeroElectric-Lis t message posted by: Dj Merrill =0A> =0A> We generally put s ome form of circuit protection (fuse, breaker, etc) on most of our circuits , including the circuit to activate the starter contactor, but we usually d o not put any type of protection on the circuit to activate the master cont actor or E-bus contactor.=0A> =0A> I am curious, why is this?=0A> =0A> Than ks,=0A> =0A> -Dj, in the middle of re-wiring for a panel upgrade=0A> =0A> - - =0A> Dj Merrill - N1JOV - VP EAA Chapter 87=0A> Sportsman 2+2 Builder #71 18 N421DJ - http://deej.net/sportsman/=0A> Glastar Flyer N866RH - http://de =- - - - - - - - - - - - - - - -Matt Dralle ======== ________________________________________________________________________________
Date: May 30, 2014
Thanks all, that makes sense! -Dj On 5/30/2014 12:27 PM, Jeff Luckey wrote: > > I agree w/ everything that Vern said and add that this circuit is > unique in that the length of the positive wire which provides power > for the coil is usually very short - only an inch or two - from the > big positive terminal to the little coil terminal on the > relay/solenoid and that's why we can get away with no circuit > protection. This is not the case with almost all other circuits. > > -Jeff > > > On Thursday, May 29, 2014 11:21 PM, Sprocket > <sprocket@vx-aviation.com> wrote: > > > <sprocket@vx-aviation.com > > > The practice is to protect against wires shorting to ground. The > circuit protection trips due to large fault current. > > The master or e-bus contactor control wires operate by grounding the > conductor with a switch. The current in this circuit is limited by > the resistance of the contactor coil, so it needs no protection. A > short on this wire may cause undesirable behaviour, but it won't melt > or catch fire. > > Vern -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: May 30, 2014
I agree w/ everything that Vern said and add that this circuit is unique in that the length of the positive wire which provides power for the coil is usually very short - only an inch or two - from the big positive terminal to the little coil terminal on the relay/solenoid and that's why we can get away with no circuit protection. This is not the case with almost all other circuits. As a matter of fact most installations have no external wire going from the Fat Battery terminal to the coil. It is contained inside the sealed contactor so there is no access to it. Roger ________________________________________________________________________________
Date: May 30, 2014
problem (was n At 09:48 AM 5/30/2014, you wrote: I designed PCBs for medical devices for 25 years. Some very high-power devices were so quiet that the test lab couldn't tell if the devices were on or not. So a device like Trio Avionics ProPilot and its interference problem does not seem to be a difficult fix. Changing the Xtal DOES seem like a bean-counter fix, but sometimes that is the only way to go. I'd LOVE to inspect the PCB. Makes two of us . . . I've offered . . . we'll see . . . In the future Bob and many PCB layout gurus can suggest how to build a PCB and case that will generate fewer customer problems. My absolute conviction is: 1) Short and decoupled clock line; 2) Four layer PCB (solves 90% of the problems). 3) Examine and minimize every single current loop. Yup . . . another great prophylactic is to use micro-controllers where all the i/o and clocking is on-board . . . the radiation/ susceptibility apertures are exceedingly small on a chunk of LSI silicon! Sometimes you're hosed . . . working a project now that duty-cycle switches a PM motor at 300 amps and 14 Khz . . . they're closed to taming this beast but it wasn't easy. I can suggest Kimmel and Gerke of course, but also many online guides like: http://www.ti.com/lit/an/scaa082/scaa082.pdf Absolutely. Took their three-day seminar about 20 years ago from Mr. Kimmel hisself. Good teacher with eye-opening revelations to offer. Bob . . . ________________________________________________________________________________
Date: May 30, 2014
Subject: Info on MGL Enigma
While trying to fathom why the CHT readings on the MGL Enigma EFIS had stopped on my friend's Rotax 912 powered JA Highlander I delved into the manual for the EFIS and its RDAC unit (the box that all senders report to before their data is passed along to the EFIS). On page 6 or so of the RDAC manual there is a picture of the back of the Enigma with a note that the battery under a rectangular cover should be changed every two years. Upon removing said cover I discovered a CR2032 lithium battery. I checked its voltage output and found it to be 2.9 volts. A new one that the aircraft owner just happened to have in his tool kit (he maintains medical equipment for a living) put out 3.3 volts so we replaced the old one. More investigation into the setup menus for EFIS revealed that there is an option for a Rotax sender for the CHT setup and when we checked the unit we found it had reset to a J type thermocouple. Resetting it to the Rotax sender solved the problem and the EFIS began reporting good CHT values. Curious to find out if the low output of the CR2032 was responsible for the glitch in the CHT setup I delved into the manual for the EFIS and could find no reference to it in the manual's table of contents, index, or during a long skim of its contents. The same was true of the RADC manual with the exception of the picture and note mentioned earlier. Now we find that the same thing has happened to the oil pressure reading. Again the setup has been changed to reflect a different type of sender, only this time restoring it to the Rotax sender option has not fixed it. There are two sender options for each of resistive type senders and voltage type. On either resistive option (the Rotax option is a resistive sender) the bar graph on the EFIS locks up and does not read. When I set it to either of the voltage type it then reads but it reads backward, i.e. as the engine revs up the reading drops and vice versa. The oil pressure sender is a VDO unit and I have located it in VDO's technical offerings online. VDO recommends that the sender be installed dry with no teflon tape or thread sealant so that it will ground properly so we have an investigative path when we return to the airplane this weekend. MGL has taken the Enigma technical info off line and the aircraft's owner has not been able to find any information on the CR2032 battery as to what it does or how to change it properly. Does anyone out there know about it? Thanks, Rick Girard It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: May 30, 2014
Subject: Re: Info on MGL Enigma
On 5/30/2014 5:25 PM, Richard Girard wrote: > While trying to fathom why the CHT readings on the MGL Enigma EFIS had > stopped on my friend's Rotax 912 powered JA Highlander I delved into > the manual for the EFIS and its RDAC unit (the box that all senders > report to before their data is passed along to the EFIS). > On page 6 or so of the RDAC manual there is a picture of the back of > the Enigma with a note that the battery under a rectangular cover > should be changed every two years. Upon removing said cover I > discovered a CR2032 lithium battery. I checked its voltage output and > found it to be 2.9 volts. A new one that the aircraft owner just > happened to have in his tool kit (he maintains medical equipment for a > living) put out 3.3 volts so we replaced the old one. > More investigation into the setup menus for EFIS revealed that there > is an option for a Rotax sender for the CHT setup and when we checked > the unit we found it had reset to a J type thermocouple. Resetting it > to the Rotax sender solved the problem and the EFIS began reporting > good CHT values. > Curious to find out if the low output of the CR2032 was responsible > for the glitch in the CHT setup I delved into the manual for the EFIS > and could find no reference to it in the manual's table of contents, > index, or during a long skim of its contents. The same was true of the > RADC manual with the exception of the picture and note mentioned earlier. > Now we find that the same thing has happened to the oil pressure > reading. Again the setup has been changed to reflect a different type > of sender, only this time restoring it to the Rotax sender option has > not fixed it. There are two sender options for each of resistive type > senders and voltage type. On either resistive option (the Rotax option > is a resistive sender) the bar graph on the EFIS locks up and does not > read. When I set it to either of the voltage type it then reads but it > reads backward, i.e. as the engine revs up the reading drops and vice > versa. > The oil pressure sender is a VDO unit and I have located it in VDO's > technical offerings online. VDO recommends that the sender be > installed dry with no teflon tape or thread sealant so that it will > ground properly so we have an investigative path when we return to the > airplane this weekend. > MGL has taken the Enigma technical info off line and the aircraft's > owner has not been able to find any information on the CR2032 battery > as to what it does or how to change it properly. > Does anyone out there know about it? > > Thanks, > Rick Girard > > It isn't necessary to have relatives in Kansas City in order to be > unhappy. > - Groucho Marx > I can't help with specific info on the MGL, but using that battery for 'backup' is fairly common in electronics. If you use a desktop PC, odds are good that there's one on the motherboard. My old Garmin III Pilot gps has one in it. (Note that they make that case style in both a lithium 'primary' battery, and a lithium rechargeable battery, & it's sometimes difficult to tell which the mfgr is using.) In the applications I've seen, the battery keeps a CMOS memory alive, and that's where basic configuration settings are stored in a lot of devices. If the battery goes too low to keep the CMOS memory active, the device will forget whatever settings were stored there. I would think that more current tech, especially in an a/c device, would avoid using CMOS memory & the required battery, but some really high dollar avionics still use it. On many PC's, if the battery dies, after battery replacement you sometimes have to do a 'hard reset' by shorting a pair of pins on the motherboard to completely clear the CMOS memory before re-entering all the parameters needed. Sounds like it's time for a Skype call to S Africa. :-) Charlie ________________________________________________________________________________
Date: May 31, 2014
Shoot me your mailing address and I'll get some connectors in the mail to you today. Sorry, I tought I had some rt-angle connectors in inventory . . . I'm out. Here's the source I've used for years http://tinyurl.com/mfp9cfg takes awhile to get parts but they've been consistently good. I've just ordered 10 to refurbish my inventory. http://tinyurl.com/m6ywj9p Depending on how 'tight' you are for schedule, I can offer connectors in when my order gets here . . .will only take a few days longer than ordering for yourself . . . Bob . . . Bob . . . ________________________________________________________________________________
Date: May 31, 2014
I have forwarded this to my colleague, who happens to own MGL J. I call him on Monday to follow up. Jay From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: 31 May 2014 12:26 AM Subject: AeroElectric-List: Info on MGL Enigma While trying to fathom why the CHT readings on the MGL Enigma EFIS had stopped on my friend's Rotax 912 powered JA Highlander I delved into the manual for the EFIS and its RDAC unit (the box that all senders report to before their data is passed along to the EFIS). On page 6 or so of the RDAC manual there is a picture of the back of the Enigma with a note that the battery under a rectangular cover should be changed every two years. Upon removing said cover I discovered a CR2032 lithium battery. I checked its voltage output and found it to be 2.9 volts. A new one that the aircraft owner just happened to have in his tool kit (he maintains medical equipment for a living) put out 3.3 volts so we replaced the old one. More investigation into the setup menus for EFIS revealed that there is an option for a Rotax sender for the CHT setup and when we checked the unit we found it had reset to a J type thermocouple. Resetting it to the Rotax sender solved the problem and the EFIS began reporting good CHT values. Curious to find out if the low output of the CR2032 was responsible for the glitch in the CHT setup I delved into the manual for the EFIS and could find no reference to it in the manual's table of contents, index, or during a long skim of its contents. The same was true of the RADC manual with the exception of the picture and note mentioned earlier. Now we find that the same thing has happened to the oil pressure reading. Again the setup has been changed to reflect a different type of sender, only this time restoring it to the Rotax sender option has not fixed it. There are two sender options for each of resistive type senders and voltage type. On either resistive option (the Rotax option is a resistive sender) the bar graph on the EFIS locks up and does not read. When I set it to either of the voltage type it then reads but it reads backward, i.e. as the engine revs up the reading drops and vice versa. The oil pressure sender is a VDO unit and I have located it in VDO's technical offerings online. VDO recommends that the sender be installed dry with no teflon tape or thread sealant so that it will ground properly so we have an investigative path when we return to the airplane this weekend. MGL has taken the Enigma technical info off line and the aircraft's owner has not been able to find any information on the CR2032 battery as to what it does or how to change it properly. Does anyone out there know about it? Thanks, Rick Girard It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jun 01, 2014
Hi Bob, Yup. DIY right angles both ends. Unfortunately, out of town this weekend so I can't get to my testing. I will report back on my findings when I get to the hanger next week. Absolutely no sweat on the connectors. At $2 each, I think I will lay in a supply. This build is ten years in the making and I am waiting on the FAA for paperwork. Right now, I am shaking down glitches before that first flight. I think it is really important to not be in a hurry at this stage of the build. Safety is the paramount task. Thanks again for all your help. Michael Wynn RV 8 (Mostly) Finished San Ramon, CA In a message dated 5/30/2014 3:07:18 P.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes: At 08:45 AM 5/30/2014, you wrote: Hi Bob, It makes sense to start with an ohm meter just to look for continuity. I guess the next thing would be a coin flip to see which end to break open. Replacing the right angles on both ends should take care of the issue. Unless I do that, I won't know that I have fixed the issue unless something comes up in the continuity check. A reasonable conclusion. Do you have DIY rt angle connectors on both ends? I do have an R400 crimp tool. I bought that and pretty much all my wiring stuff from B&C. Very good folks to do business with. They offer a right angle adaptor but not a right angle connector. Steinair offers them at $17.50 a pop. Yikes! I suppose in the overall scheme of things, that is just a drop in the proverbial bucket. It will cost more than that to get the transponder certification guy out again. You're right. The short path to success is to simply replace 'em . . . I'll give B&C a heads-up on a more economical alternative. Shoot me your mailing address and I'll get some connectors in the mail to you today. If you have a spare dedicated right angle connector or two you are willing to donate to a worthy cause, that would be great. Otherwise, unless I can find an obvious error in my crimping or connectors, I will buy them from Steinair. As usual, thank you for your insights. The Aeroelectric Connection and this forum have been completely invaluable in planning and executing the wiring of my plane. It's called the exercise of spontaneous organization. Groups of willing and able individuals gathering the sum of their time, talents and resources together in quest of a common goal. Took me 50+ years to acquire an understanding of the phenomenon . . . it's been going on for thousands of years. Works every time its tried but really easy to derail. I'm pleased that this List has been largely immune to derailments . . . Bob . . . ________________________________________________________________________________
Date: Jun 02, 2014
Here is the reply from Rainier, the owner and founder of MGL: The CR2032 battery is only used to maintain items that change frequently like calculated fuel levels, local pressure settings etc. Setup is stored in a flash memory section of a secondary processor chip in the EFIS. This does not need a backup battery. If setup data stored here is not maintained there is usually only one cause: The supply voltage to that processor is raised briefly (micro-seconds to mill-seconds) above about 8V. This can happen if the supply to the EFIS contains sharp voltage spikes (typically caused by bad regulators or high voltage ignition is coupling into ground or supply). This can also happen if there are static discharges typically caused by airflow over metal parts that are not grounded. Eventually, this will damage the flash memory which is the part that dies first in our experience. When this happens we replace the processor chip. If you have a techie handy - it is a type ATMEL ATMega128. It is a SMD package but easy to solder/desolder if you have the experience. Once replaced I would also recommend replacing the 16Mhz crystal right next to this chip - it tends to wear out over a long time (we replace these as a matter of course when we get an Enigma in for repairs). No specific programming of the new processor needs to be done as the firmware will detect a new processor and do the programming and setup of this chip automatically (the first start-up will take a bit longer and you will see some messages on the display to this effect). Rainier -- MGL Avionics Postal: Postnet Suite X15 Somerset West 7129 South Africa Physical: 5 Fuchsia street Somerset West 7130 South Africa ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ HH Enterprises * Aircraft assembly, repair, wiring and avionics * Flight instruction * General and Electrical Engineering services (NHD Elec Eng, BTech Elec Eng, GDE ELec Eng) * Great dinner parties and conversation * General adventuring, climbing, kayaking and living Blog: www.rawhyde.wordpress.com <http://www.rawhyde.wordpress.com/> Cel: 083 300 8675 Email: jay(at)horriblehyde.com ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: 31 May 2014 01:20 AM Subject: Re: AeroElectric-List: Info on MGL Enigma On 5/30/2014 5:25 PM, Richard Girard wrote: While trying to fathom why the CHT readings on the MGL Enigma EFIS had stopped on my friend's Rotax 912 powered JA Highlander I delved into the manual for the EFIS and its RDAC unit (the box that all senders report to before their data is passed along to the EFIS). On page 6 or so of the RDAC manual there is a picture of the back of the Enigma with a note that the battery under a rectangular cover should be changed every two years. Upon removing said cover I discovered a CR2032 lithium battery. I checked its voltage output and found it to be 2.9 volts. A new one that the aircraft owner just happened to have in his tool kit (he maintains medical equipment for a living) put out 3.3 volts so we replaced the old one. More investigation into the setup menus for EFIS revealed that there is an option for a Rotax sender for the CHT setup and when we checked the unit we found it had reset to a J type thermocouple. Resetting it to the Rotax sender solved the problem and the EFIS began reporting good CHT values. Curious to find out if the low output of the CR2032 was responsible for the glitch in the CHT setup I delved into the manual for the EFIS and could find no reference to it in the manual's table of contents, index, or during a long skim of its contents. The same was true of the RADC manual with the exception of the picture and note mentioned earlier. Now we find that the same thing has happened to the oil pressure reading. Again the setup has been changed to reflect a different type of sender, only this time restoring it to the Rotax sender option has not fixed it. There are two sender options for each of resistive type senders and voltage type. On either resistive option (the Rotax option is a resistive sender) the bar graph on the EFIS locks up and does not read. When I set it to either of the voltage type it then reads but it reads backward, i.e. as the engine revs up the reading drops and vice versa. The oil pressure sender is a VDO unit and I have located it in VDO's technical offerings online. VDO recommends that the sender be installed dry with no teflon tape or thread sealant so that it will ground properly so we have an investigative path when we return to the airplane this weekend. MGL has taken the Enigma technical info off line and the aircraft's owner has not been able to find any information on the CR2032 battery as to what it does or how to change it properly. Does anyone out there know about it? Thanks, Rick Girard It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx I can't help with specific info on the MGL, but using that battery for 'backup' is fairly common in electronics. If you use a desktop PC, odds are good that there's one on the motherboard. My old Garmin III Pilot gps has one in it. (Note that they make that case style in both a lithium 'primary' battery, and a lithium rechargeable battery, & it's sometimes difficult to tell which the mfgr is using.) In the applications I've seen, the battery keeps a CMOS memory alive, and that's where basic configuration settings are stored in a lot of devices. If the battery goes too low to keep the CMOS memory active, the device will forget whatever settings were stored there. I would think that more current tech, especially in an a/c device, would avoid using CMOS memory & the required battery, but some really high dollar avionics still use it. On many PC's, if the battery dies, after battery replacement you sometimes have to do a 'hard reset' by shorting a pair of pins on the motherboard to completely clear the CMOS memory before re-entering all the parameters needed. Sounds like it's time for a Skype call to S Africa. :-) Charlie ________________________________________________________________________________
Date: Jun 02, 2014
At 04:02 AM 6/2/2014, you wrote: Here is the reply from Rainier, the owner and founder of MGL: The CR2032 battery is only used to maintain items that change frequently like calculated fuel levels, local pressure settings etc. Setup is stored in a flash memory section of a secondary processor chip in the EFIS. This does not need a backup battery. If setup data stored here is not maintained there is usually only one cause: The supply voltage to that processor is raised briefly (micro-seconds to mill-seconds) above about 8V. This can happen if the supply to the EFIS contains sharp voltage spikes (typically caused by bad regulators or high voltage ignition is coupling into ground or supply). This can also happen if there are static discharges typically caused by airflow over metal parts that are not grounded. Eventually, this will damage the flash memory which is the part that dies first in our experience. When this happens we replace the processor chip. If you have a techie handy - it is a type ATMEL ATMega128. It is a SMD package but easy to solder/desolder if you have the experience. Once replaced I would also recommend replacing the 16Mhz crystal right next to this chip - it tends to wear out over a long time (we replace these as a matter of course when we get an Enigma in for repairs). No specific programming of the new processor needs to be done as the firmware will detect a new processor and do the programming and setup of this chip automatically (the first start-up will take a bit longer and you will see some messages on the display to this effect). I am exceedingly skeptical of these assertions. I don't know of a single 5v regulator offered to the task of conditioning power for electronics that doesn't handily mitigate any of the commonly known variables on the ship's bus. DO-160 offers a clear and concise path to living confidently in the world of DC powered vehicles. Crystals that 'wear out'? Static discharges ? ! ? ! . . . again, for any piece of hardware to be qualified for installation on a TC aircraft, it has to be capable of withstanding discharges of a 150pF capacitor through 330 ohm resistor fed directly to every input/output pin on the device under test. TEN times for positive spikes, TEN more times for negative spikes. Sound brutal . . . but the components and architecture for designing to this level of stress is rudimentary and has been as common to the designer's toolbox as a hammer is to a carpenter's toolbox. I quit doing the test 25 years ago after learning what it took to pass . . . easily . . . every time. If the stresses cited are genuine risks to MGL's products, then they've failed to understand and embrace the real world stresses found in mobile DC powered system of all stripe . . . not the least of which are airplanes. Bob . . . ________________________________________________________________________________
Date: Jun 02, 2014
At 04:02 AM 6/2/2014, you wrote: Here is the reply from Rainier, the owner and founder of MGL: The CR2032 battery is only used to maintain items that change frequently like calculated fuel levels, local pressure settings etc. Setup is stored in a flash memory section of a secondary processor chip in the EFIS. This does not need a backup battery. If setup data stored here is not maintained there is usually only one cause: The supply voltage to that processor is raised briefly (micro-seconds to mill-seconds) above about 8V. This can happen if the supply to the EFIS contains sharp voltage spikes (typically caused by bad regulators or high voltage ignition is coupling into ground or supply).=C2 This can also happen if there are static discharges typically caused by airflow over metal parts that are not grounded. Eventually, this will damage the flash memory which is the part that dies first in our experience. When this happens we replace the processor chip. If you have a techie handy - it is a type ATMEL ATMega128. It is a SMD package but easy to solder/desolder if you have the experience. Once replaced I would also recommend replacing the 16Mhz crystal right next to this chip - it tends to wear out over a long time (we replace these as a matter of course when we get an Enigma in for repairs). No specific programming of the new processor needs to be done as the firmware will detect a new processor and do the programming and setup of this chip automatically (the first start-up will take a bit longer and you will see some messages on the display to this effect). I am exceedingly skeptical of these assertions. I don't know of a single 5v regulator offered to the task of conditioning power for electronics that doesn't handily mitigate any of the commonly known variables on the ship's bus. DO-160 offers a clear and concise path to living confidently in the world of DC powered vehicles. Crystals that 'wear out'? Static discharges ? ! ? ! . . . again, for any piece of hardware to be qualified for installation on a TC aircraft, it has to be capable of withstanding 15KV discharges of a 150pF capacitor through 330 ohm resistor fed directly to every input/output pin on the device under test. TEN times for positive spikes, TEN more times for negative spikes. Sound brutal . . . but the components and architecture for designing to this level of stress is rudimentary and has been as common to the designer's toolbox as a hammer is to a carpenter's toolbox. I quit doing the test 25 years ago after learning what it took to pass . . . easily . . . every time. If the stresses cited are genuine risks to MGL's products, then they've failed to understand and embrace the real world stresses found in mobile DC powered system of all stripe . . . not the least of which are airplanes. Bob . . . ________________________________________________________________________________
Subject: Bonding Straps
Date: Jun 02, 2014
In a mixed construction airplane (steel tube fuselage, wooden wings, aluminum structure flight controls, everything fabric covered) what would the down side be in not having everything electrically bonded? My electrical system is a two wire, 14v system with everything running to a "forest of tabs" ground bus on the firewall. The avionics (SL40 com, GTX 327 txdr) run to their own, dedicated ground bus which in turn is wired to the firewall ground bus. I'm doing the bonding per the original design, but I'm just curious. Would all the various assemblies of the airplane create static charges that would cripple the radios? Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=424217#424217 ________________________________________________________________________________
Date: Jun 03, 2014
Hello again listers, Here is a further response from Rainier: I did not say that spikes or similar ARE the cause of what it going on. It might be something completely unrelated. It's a pretty complex system. There are no old style linear regulators in the system. There are three high frequency switch mode supplies and all input power is protected by a heavy duty transorb apart from other filtering (mostly inductive/capacitive). Nevertheless, we are talking about a system that has multiple connectivity to other electrical systems on the aircraft - anything going on anywhere and the EFIS gets it. We are taking about transient events at RF frequencies. Do-160 simply does not cater for this on a long term bases. But that is another story. So, honestly, without actually having the system on a bench and investigating - and conclusively finding the cause, going on like that is not called for here. Getting back to the Flash memory - yes it does fail if it gets transient power events that make it through the system by whatever path. It may take years. However that is by no means the only possible cause. Flash is known to wear over time. Manufacturers of these devices guarantee 10 years of data retention typically, even if no writes take place - yet these devices are used throughout the industry for missions where it is assumed that they will never fail. Usually they don't. In this case we don't even know if this memory has failed. It might be something else - perhaps the communications link between main CPU and the processor that contains this memory has gone faulty. It could be anything. I'm guessing. That is all I can do without having the Enigma on my bench. Electronics do fail - does not matter how much money you spend on the components. Service history of the Enigma has been excellent. The number of Enigmas coming back to the factory for repairs is almost nil. That is not too surprising - it has been designed for open cockpit ultralights and it is quite tough. But they are getting older now and failures of electronic components become more of a factor. There is something called a "bathtub failure curve" - because it looks like it. Failures tend to occur when the device is new (partly the reason we run them for 48 hours at elevated temperatures during manufacture) - then things settle down and after some time failure rates start creeping up slowly as things age. Components that do age are crystals (They are mechanical devices - high frequency types in particular have a higher failure rate in our experience). Then we have ceramic capacitors - a typical EFIS has hundreds of them. Some start leaking after a while. Most of the time that is not an issue but sometimes it is. We don't use tantalums because of reliability concerns (good caps but they have an annoying tendency to blow up). Our electrolytics are top quality devices - can't even remember any failures. Then we get to the semiconductors. Well, here we have a pretty random failure pattern. They do die for no apparent reason. The rate is low but it does happen. Yes, we use aerospace, automotive and industrial spec devices - we do not use consumer graded devices at all. Most failures are perhaps related to PCB failures (usually thermal stress cracking vias). Some of our PCBs are high tech multi-layer. They are more sensitive - part of the process. Some assemblies are lead free and the entire industry has been battling for years with "tin-wiskers". Microscopic growths of tin between tracks and pads. Only visible under a microscope. Takes years to cause a problem. That we have had. Lucky this is not so much of an issue anymore as lead free processes and fluxes have improved and I have yet to see such an issue on anything produced in the last 4 or 5 years. "Cold solder joints" - that happens either via repeated thermal stress cracking a solder joint or a manufacturing defect that may take years to manifest itself. Yes, it happens. It passes all tests and optical quality controls (we use an automated AOI machine plus visual checks at various stages during the assembly process) - yet it still manages to avoid early detection. Sure, the rate is low but we make thousands of devices every month. Including devices not intended for aircraft (and not under our brand name). I would love a zero failure rate. Failures are bad. Everybody gets annoyed - from the customer to us. We can't have a zero failure rate - that is a pipe dream. But we can always work to reduce it to the barest minimum. If we did not do that we'd be out of business long ago. Most of our repairs are directly related to what we call "blow ups". Reverse polarity issues, connecting power or grounds to the wrong places etc. Interface driver chips (RS232, CAN, switches etc) blown for various reasons - the items directly connected to the outside World. All of that happens typically during installation. Mostly with the so called "professional installers, AMOs etc". I'm not kidding. We find the home builders are the ones with the least issues - perhaps because most take the time to study the docs and plan their wiring. There is no rush, no deadlines. That helps. Our statistics (which we do keep for obvious reasons) shows this trend very clearly. Instruments get dropped, might have a hard time during transport - sometimes they get soaked in water or oil. Anyway, I can't really comment on this Enigma until I see it myself (if that ever happens). If there is a problem, whatever the cause may be - we can fix it. That is the bottom line. Rainier -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: 02 June 2014 03:45 PM Subject: RE: AeroElectric-List: Info on MGL Enigma --> At 04:02 AM 6/2/2014, you wrote: Here is the reply from Rainier, the owner and founder of MGL: The CR2032 battery is only used to maintain items that change frequently like calculated fuel levels, local pressure settings etc. Setup is stored in a flash memory section of a secondary processor chip in the EFIS. This does not need a backup battery. If setup data stored here is not maintained there is usually only one cause: The supply voltage to that processor is raised briefly (micro-seconds to mill-seconds) above about 8V. This can happen if the supply to the EFIS contains sharp voltage spikes (typically caused by bad regulators or high voltage ignition is coupling into ground or supply). This can also happen if there are static discharges typically caused by airflow over metal parts that are not grounded. Eventually, this will damage the flash memory which is the part that dies first in our experience. When this happens we replace the processor chip. If you have a techie handy - it is a type ATMEL ATMega128. It is a SMD package but easy to solder/desolder if you have the experience. Once replaced I would also recommend replacing the 16Mhz crystal right next to this chip - it tends to wear out over a long time (we replace these as a matter of course when we get an Enigma in for repairs). No specific programming of the new processor needs to be done as the firmware will detect a new processor and do the programming and setup of this chip automatically (the first start-up will take a bit longer and you will see some messages on the display to this effect). I am exceedingly skeptical of these assertions. I don't know of a single 5v regulator offered to the task of conditioning power for electronics that doesn't handily mitigate any of the commonly known variables on the ship's bus. DO-160 offers a clear and concise path to living confidently in the world of DC powered vehicles. Crystals that 'wear out'? Static discharges ? ! ? ! . . . again, for any piece of hardware to be qualified for installation on a TC aircraft, it has to be capable of withstanding discharges of a 150pF capacitor through 330 ohm resistor fed directly to every input/output pin on the device under test. TEN times for positive spikes, TEN more times for negative spikes. Sound brutal . . . but the components and architecture for designing to this level of stress is rudimentary and has been as common to the designer's toolbox as a hammer is to a carpenter's toolbox. I quit doing the test 25 years ago after learning what it took to pass . . . easily . . . every time. If the stresses cited are genuine risks to MGL's products, then they've failed to understand and embrace the real world stresses found in mobile DC powered system of all stripe . . . not the least of which are airplanes. Bob . . . ________________________________________________________________________________
Subject: Off Delay Cabin Light
Date: Jun 03, 2014
The July 2014 issue of Kitplanes Magazine has an article by Jim Weir describing a circuit to delay turning off a light after the master switch is shut off. http://www.kitplanes.com/issues/31_7/builder_spotlight/aero_lectrics_july_2014_21035-1.html There is no power wire connected to Vcc pin 8 of the 555 IC. Was a wire inadvertently left off or will the circuit work as drawn? Joe -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=424276#424276 ________________________________________________________________________________
Date: Jun 03, 2014
Subject: Re: Off Delay Cabin Light
Perhaps it's been fixed; the online version has the connection. On Tue, Jun 3, 2014 at 5:35 AM, user9253 wrote: > > The July 2014 issue of Kitplanes Magazine has an article by Jim Weir > describing a circuit to delay turning off a light after the master switch > is shut off. > > http://www.kitplanes.com/issues/31_7/builder_spotlight/aero_lectrics_july_2014_21035-1.html > There is no power wire connected to Vcc pin 8 of the 555 IC. Was a wire > inadvertently left off or will the circuit work as drawn? > Joe > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=424276#424276 > > ________________________________________________________________________________
Date: Jun 03, 2014
Subject: Economical solid state pressure sensors
I only seem to get a few hundred hours out of name brand electromechanical engine pressure sensors so I tried a 30 psi $25. solid state Chinese sensor for coolant pressure monitoring. Quite a bit cheaper than what I was using and seemingly good specifications which I've copied below. While it calibrates perfectly at room temperature, it reads at least 5 psi low when it gets hot (ie. 4 psi when it should be 9). The zero point changes similarly and I confirmed all this with raw voltage readings and scope traces to make certain. This sensor was mounted on the firewall and tee'd into a 5/16" coolant hose so the coolant likely warmed it up to about 80*C. Seems it would need to be installed on a stub line on the cool side of the firewall to be useful. The temperature specification of Maximum:0.05%FS/C would indicate up to 1.5 psi zeroing error over a 100*C range which would be acceptable to me if that was the case and other errors were minor. This particular sensor may be outside of stated tolerances. In any case, the compensation temperature range of -20 to +80*C seems to be meaningless. I'd also hoped to replace the oil pressure sensor but it seems these economical sensors are not the answer for under the cowl. Ken Brand new pressure transducer. 316 Stainless steel body. Input: 0-30 psi(Gauge Pressure); Output: 0.5-4.5V linear voltage output. 0 psi outputs 0.5V, 15 psi outputs 2.5V, 30 psi outputs 4.5V. Works for oil,fuel or air pressure.Can be used in oil tank,gas tank,diesel tank etc. Accuracy: +/-1%FS; Thread: 1/8 NPT; Wiring Connector: Packard plug-in unit is included; Wiring: Red: +5V; Black: ground; Green: signal output; It's an advance pressure sender than traditional mechanical pressure sender; Overload Capacity: 2-4 times; Working Temperature: -40+120C; Compensation Temperature: -20+80C; Protection Class: IP67; Pressure Medium: The gas and liquid which is compatible with 316L stainless steel; Load Resistance: ((supply power-6.5V/0.02A); Long-term stability: Less than 0.1%FS/year; Temperature Effect on Zero: Typical:0.02%FS/C; Maximum:0.05%FS/C; Temperature Effect on Sensitivity: Typical:0.02%FS/C; Maximum:0.05%FS/C; Shock Resistance: 1000g; Anti-Shock: +/-0.01%FS(X,Y,Z axes, 200Hz/g); Response Time: 1ms; Insulation Resistance: >100m 500VDC; Weight: 55g; Explosion-proof Class: ExiaTTCT6; Electromagnetism Compatibility: EN50051-1. ________________________________________________________________________________
Date: Jun 03, 2014
It is hard to say that a 3V battery measuring 2.9V is dead or not depending on load. The nominal discharge current of the battery is 0.2 mA. Putting a 150k in parallel will show 2.9V or above for a still good battery. But since getting there is half the work, change it. http://www.adafruit.com/datasheets/maxell_cr2032_datasheet.pdf See DX.com (Deal Extreme) for a 10 pack of Sony 3V CR2032 Lithium Ion $5.98. Free shipping -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=424294#424294 ________________________________________________________________________________
Date: Jun 03, 2014
Subject: Re: Bonding Straps
At 12:26 PM 6/2/2014, you wrote: > >In a mixed construction airplane (steel tube fuselage, wooden wings, >aluminum structure flight controls, everything fabric covered) what >would the down side be in not having everything electrically >bonded? My electrical system is a two wire, 14v system with >everything running to a "forest of tabs" ground bus on the >firewall. The avionics (SL40 com, GTX 327 txdr) run to their own, >dedicated ground bus which in turn is wired to the firewall ground >bus. I'm doing the bonding per the original design, but I'm just >curious. Would all the various assemblies of the airplane create >static charges that would cripple the radios? > >Dan Bonding for static control, grounding for power distribution and grounding for antenna performance are largely separate issues. P-static is not an issue for low speed aircraft cruising in the lower atmospheres. Sounds like you've got the lights lit up so the only thing left is to provide adequate ground planes under antennas. But in no case is there value in tying every 'grounded' device to all other grounded devices. Bob . . . ________________________________________________________________________________
Date: Jun 03, 2014
Thanks Bob. Would there be any value in tying the avionics ground bus directly to the battery instead of to the main ground bus? (Putting the two ground buses in parallel instead of in series). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=424303#424303 ________________________________________________________________________________
Date: Jun 03, 2014
Subject: Re: Economical solid state pressure sensors
At 07:55 AM 6/3/2014, you wrote: I only seem to get a few hundred hours out of name brand electromechanical engine pressure sensors so I tried a 30 psi $25. solid state Chinese sensor for coolant pressure monitoring. Quite a bit cheaper than what I was using and seemingly good specifications which I've copied below. While it calibrates perfectly at room temperature, it reads at least 5 psi low when it gets hot (ie. 4 psi when it should be 9). The zero point changes similarly and I confirmed all this with raw voltage readings and scope traces to make certain. This sensor was mounted on the firewall and tee'd into a 5/16" coolant hose so the coolant likely warmed it up to about 80*C. Seems it would need to be installed on a stub line on the cool side of the firewall to be useful. The temperature specification of Maximum:0.05%FS/C would indicate up to 1.5 psi zeroing error over a 100*C range which would be acceptable to me if that was the case and other errors were minor. This particular sensor may be outside of stated tolerances. In any case, the compensation temperature range of -20 to +80*C seems to be meaningless. I'd also hoped to replace the oil pressure sensor but it seems these economical sensors are not the answer for under the cowl. I have one of those transducers in a 300 psi version . . . in fact . . . it's in my pocket right now. We ordered it in to consider for a future development program. I'll see if I can get a quick look-see on accuracy and temperature effects. The numbers you're citing are pretty poor . . . I can't imagine anyone putting so much into a stainless case and cutting short the electronics . . . electronics that are pretty much jelly-bean parts. If you're going to round-file the aberrant transducer, drop it to me in the mail . . . I'd like to peek at it on the bench too. Bob . . . ________________________________________________________________________________
Date: Jun 03, 2014
At 02:37 AM 6/3/2014, you wrote: Hello again listers, Here is a further response from Rainier: I did not say that spikes or similar ARE the cause of what it going on. It might be something completely unrelated. It's a pretty complex system. . . . then why even mention it? The customer does not benefit from a narration of possible causes . . . especially when those causes include things that 'might' be wrong with his airplane. But to assert that stresses external to the product's enclosure can zap a micro-controller does nothing to engender confidence in the rest of hardware under the best of circumstances. There are no old style linear regulators in the system. There are three high frequency switch mode supplies and all input power is protected by a heavy duty transorb apart from other filtering (mostly inductive/capacitive). Electronics do fail - does not matter how much money you spend on the components. Service history of the Enigma has been excellent. The number of Enigmas coming back to the factory for repairs is almost nil. When we conduct a reliability study on an assembly, powers-that-be don't really start smiling until your aggregate MTBF drops below 1 x 10 minus 7 failures per flight hour. For critical systems 1 x 10 minus 9 is the target. So if your device has 100 components in it, INDIVIDUAL failure rates have to be 100x better than the aggregate. If this guy has crystals that warrant routine replacement base on some fielded experience . . . he is well advised to change brands. intended for aircraft (and not under our brand name). I would love a zero failure rate. Failures are bad. Everybody gets annoyed - from the customer to us. We can't have a zero failure rate - that is a pipe dream. But we can always work to reduce it to the barest minimum. If we did not do that we'd be out of business long ago. Most of our repairs are directly related to what we call "blow ups". Reverse polarity issues, connecting power or grounds to the wrong places etc. Interface driver chips (RS232, CAN, switches etc) blown for various reasons - the items directly connected to the outside World. One cannot necessarily design every i/o port to withstand the vagaries of neophyte installations but failures of components not connected directly to the outside world is cause for concern. All of that happens typically during installation. Mostly with the so called "professional installers, AMOs etc". I'm not kidding. We find the home builders are the ones with the least issues - perhaps because most take the time to study the docs and plan their wiring. There is no rush, no deadlines. That helps. Our statistics (which we do keep for obvious reasons) shows this trend very clearly. Instruments get dropped, might have a hard time during transport - sometimes they get soaked in water or oil. Anyway, I can't really comment on this Enigma until I see it myself (if that ever happens). If there is a problem, whatever the cause may be - we can fix it. That is the bottom line. To be sure, nobody can offer "zero failure rates" but they can be exceedingly small. Builders anticipating operations over long stretches of unfriendly terrain or in IMC would be well advised to craft 'plan-b', 'plan-c' or whatever in the event the whole system goes belly-up. "Barest minimum" failure rates are un-quantified. If we had any hardware coming back from the field suffering some of the failures cited above . . . things around here would, shall we say, get very 'tense'? A display with this kind of data . .. Emacs! implies certain capabilities. Capabilities that require TC aircraft designers to go Level A software/hardware, careful partitioning of functions and probably dual screens. Do your own Failure Modes Effects Analysis based on how you need to use this hardware. Have a solid alternative for every situation when it isn't working. Bob . . . ________________________________________________________________________________
Date: Jun 03, 2014
At 10:52 AM 6/3/2014, you wrote: > >Thanks Bob. Would there be any value in tying the avionics ground >bus directly to the battery instead of to the main ground >bus? (Putting the two ground buses in parallel instead of in series). No . . . and especially not the battery(-) post. The battery is but one of many components that benefit by sharing a centralized ground but its (-) terminal point should not be that centralize ground location. If you have a panel ground for potential vicitims that is in turn tied ot the central ground on the fire wall, you're good to go. Bob . . . ________________________________________________________________________________
Date: Jun 03, 2014
Ok - thanks. That was the way I understood it. ----- Original Message ----- From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Re: Bonding Straps At 10:52 AM 6/3/2014, you wrote: > >Thanks Bob. Would there be any value in tying the avionics ground >bus directly to the battery instead of to the main ground >bus? (Putting the two ground buses in parallel instead of in series). No . . . and especially not the battery(-) post. The battery is but one of many components that benefit by sharing a centralized ground but its (-) terminal point should not be that centralize ground location. If you have a panel ground for potential vicitims that is in turn tied ot the central ground on the fire wall, you're good to go. Bob . . . ________________________________________________________________________________
Date: Jun 06, 2014
Subject: Power wiring for GNS 430W
The installation manual for the Garmin GNS 430W contains the following table summarizing the power connections: The unhelpful text says A power connection on P4006-44 is only required if NAV SUPERFLAG and/or G/S SUPERFLAG is utilized. The power inputs P4001-19 and -20 provide power for all functions of the 400W Series unit except the COM transmitter and the NAV & G/S SUPERFLAG outputs. I'm not using the nav superflag (I don't even know what it is). How should I wire the the power? Is it sufficient to supply power to P4001 pins 19 and 20 and P4002 pin 11? If so, what is the purpose of P4001 pins 15 and 72 and P4002 pin 12. Are they for connecting the box to a backup power source? Which ground pins should be connected? All of them, or would P4001 pin 77 and P4002 pin 21 suffice? ________________________________________________________________________________
Subject: TV SHOP CLOSED
Date: Jun 06, 2014
My wife's parents ran a radio/tv shop for 62 years. It is now closed. Would anyone on this list be interested in any of the stuff? Schematics? Capacitors? Scopes? Junk? I am starting to clean the place up and can post the thinks from time to time if there is an interest. Barry Carrollton, Ga ________________________________________________________________________________
Subject: Re: Power wiring for GNS 430W
Date: Jun 06, 2014
I'd connect all the grounds pointed out, look at diagram H5 for power connections. The reason for multiple power inputs like P4001 pins 19, 20 is because they are diode isolated, so this is where you can power one or both if you want to use a backup bus and the unit will then power from the pin with highest voltage present. If not tie them together like it shows in H5. Comm side, same deal, P4002 pins 11, 12 are diode isolated. For some reason the new GTN 650 does not offer isolated inputs, at least that's what I've been told. Tim > On Jun 6, 2014, at 8:11 AM, Alan Barnett wrote: > > The installation manual for the Garmin GNS 430W contains the following table summarizing the power > connections: > > > The unhelpful text says > > A power connection on P4006-44 is only required if NAV SUPERFLAG and/or G/S SUPERFLAG is > utilized. > The power inputs P4001-19 and -20 provide power for all functions of the 400W Series unit except the > COM transmitter and the NAV & G/S SUPERFLAG outputs. > > I'm not using the nav superflag (I don't even know what it is). How should I wire the the power? Is it sufficient to supply power to P4001 pins 19 and 20 and P4002 pin 11? If so, what is the purpose of P4001 pins 15 and 72 and P4002 pin 12. Are they for connecting the box to a backup power source? > > Which ground pins should be connected? All of them, or would P4001 pin 77 and P4002 pin 21 suffice? ________________________________________________________________________________
Date: Jun 06, 2014
Subject: Re: TV SHOP CLOSED
At 12:14 PM 6/6/2014, you wrote: >My wife's parents ran a radio/tv shop for 62 years. It is now closed. > >Would anyone on this list be interested in any of the stuff? >Schematics? Capacitors? Scopes? Junk? > >I am starting to clean the place up and can post the thinks from >time to time if there is an interest. > >Barry > >Carrollton, Ga Oh man . . . good thing you're so far away . . . I've got too much 'history' on my shelves already and your offer really has the juices going. Thanks for offering tho! Bob . . . ________________________________________________________________________________
Subject: Vans EGT gauge not working...
Date: Jun 06, 2014
My Vans EGT gauge does not work. Not flying yet, but have done engine start. And after a few minutes the EGT gauge is still pegged at 0. The CHT gauge does work. These gauges are hooked to a single cylinder. Its a brand new gauge and sender. Here's what I've done so far: 1) Verified power and ground to the gauge. 2) Verified continuity in the sender wires between the gauge and the space connectors. 3) Verified that the sender wires are on the correct terminal on the gauge. I'm not sure what to do next, but I would like to figure some way to determine if the problem is with the gauge, or the sender. How would I do that? Michael- ________________________________________________________________________________
Date: Jun 06, 2014
Subject: Re: Vans EGT gauge not working...
I don't know much about Van's EGT. However, the analog EGT gauges such as Alcor did not begin to register until temp got somewhere around 800-900 degrees. You won't get there with taxi power, but might with some leaning get there at runup power. You don't say what engine it is one. For carbureted engines it really isn't important. For fuel injected engines you really need an analyzer for all cylinders. On 6/6/2014 8:15 PM, Michael Burbidge wrote: > > My Vans EGT gauge does not work. Not flying yet, but have done engine start. And after a few minutes the EGT gauge is still pegged at 0. The CHT gauge does work. These gauges are hooked to a single cylinder. Its a brand new gauge and sender. > > Here's what I've done so far: > > 1) Verified power and ground to the gauge. > 2) Verified continuity in the sender wires between the gauge and the space connectors. > 3) Verified that the sender wires are on the correct terminal on the gauge. > > I'm not sure what to do next, but I would like to figure some way to determine if the problem is with the gauge, or the sender. > > How would I do that? > > Michael- > > ________________________________________________________________________________
Date: Jun 06, 2014
Carbureted engine. Taxi power only. So maybe it is working. Thanks Michael Sent from my iPhone > On Jun 6, 2014, at 8:44 PM, Kelly McMullen wrote: > > > I don't know much about Van's EGT. However, the analog EGT gauges such as Alcor did not begin to register until temp got somewhere around 800-900 degrees. You won't get there with taxi power, but might with some leaning get there at runup power. You don't say what engine it is one. For carbureted engines it really isn't important. For fuel injected engines you really need an analyzer for all cylinders. > >> On 6/6/2014 8:15 PM, Michael Burbidge wrote: >> >> My Vans EGT gauge does not work. Not flying yet, but have done engine start. And after a few minutes the EGT gauge is still pegged at 0. The CHT gauge does work. These gauges are hooked to a single cylinder. Its a brand new gauge and sender. >> >> Here's what I've done so far: >> >> 1) Verified power and ground to the gauge. >> 2) Verified continuity in the sender wires between the gauge and the space connectors. >> 3) Verified that the sender wires are on the correct terminal on the gauge. >> >> I'm not sure what to do next, but I would like to figure some way to determine if the problem is with the gauge, or the sender. >> >> How would I do that? >> >> Michael- > > > > > ________________________________________________________________________________
Date: Jun 07, 2014
Subject: Tyco W31 switch / breaker
I am in the process of refurbishing the panel in my aircraft, which uses Tyco W31 switch/breakers for some items (https://www.aircraftspruce.com/catalog/elpages/pbcircuitbrkr2.php). I noticed that the W31 terminals are labeled "Line", which I presume is for the electrical bus, and "Load", which I presume is for the device being switched. However, the person that wired this aircraft originally hooked them up backwards, with the copper bus bar connected to the "Load" terminal, and the devices being switched connected to the "Line" terminal. My question is, does it really matter? If it does, now would be the time to rewire since I have it all apart, however, the way it is hooked up at present does make for a neater and cleaner installation. It has been flying this way for over 15 years, but if it is "wrong", then I should probably make it "right". Thanks, -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Re: Tyco W31 switch / breaker
Date: Jun 07, 2014
It doesn't matter. These are thermal breakers so current direction can run either way. Vern =================================================== Sent from my iThing. It is responsible for all gramma and typo terrors. > On Jun 7, 2014, at 5:50 PM, Dj Merrill wrote: > > > I am in the process of refurbishing the panel in my aircraft, which uses Tyco W31 switch/breakers for some items (https://www.aircraftspruce.com/catalog/elpages/pbcircuitbrkr2.php). I noticed that the W31 terminals are labeled "Line", which I presume is for the electrical bus, and "Load", which I presume is for the device being switched. > > However, the person that wired this aircraft originally hooked them up backwards, with the copper bus bar connected to the "Load" terminal, and the devices being switched connected to the "Line" terminal. > > My question is, does it really matter? > > If it does, now would be the time to rewire since I have it all apart, however, the way it is hooked up at present does make for a neater and cleaner installation. It has been flying this way for over 15 years, but if it is "wrong", then I should probably make it "right". > > Thanks, > > -Dj > > -- > Dj Merrill - N1JOV - VP EAA Chapter 87 > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > > > ________________________________________________________________________________
Date: Jun 08, 2014
> 1) Verified power and ground to the gauge. > As far as I know, power to simple analog EGT/CHT indicating systems are for internal lighting only. First of all, its much easier to test the EGT system by removing the sender from the exhaust system and heating the tip with a propane torch to see if you get needle movement need another person in the cockpit to watch gauge. Please use some precautions here so as to not burn your airplane nor anyone elses down. A fire extinguisher AND a handy 5 gal bucket of water along with common sense can work wonders. If that didnt work, the next thing to do is reverse the wires and recheck. Yeah, I know, color code, yadda yadda Reverse the wires, reheat and see if needle moves If that still dont work, disconnect wires from the gauge and check for continuity at the wires. By measuring the wires, you are checking the sender and any extension leads and eliminating everything except the gauge. My Westach setup says sender resistance should be about 2.5 ohms for EGT, but meter lead resistance will add to this, so correct reading will be higher. You are really looking for continuity at this point. Now if all appears to be roughly correct, you could turn your digital meter to the millivolt scale, reheat the EGT probe and watch for a tiny millivolt output within seconds of applying flame. The gauge itself can be checked for continuity with a DIGITAL ohmmeter (the gauge is so sensitive that an analog meter can burn the darned thing out). Let me repeat - Test gauge using ONLY a digital ohmmeter Again, you are just looking for continuity, but Westach says somewhere between 8 & 15 ohms. Resistance readings may differ as EGT systems may use either J or K type thermocouples (sender), but you are mainly looking for continuity. These things generally either work well or not at all. Any resistance in the system or any corrosion will generally result in no or very low indication -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=424509#424509 ________________________________________________________________________________
Date: Jun 08, 2014
> > As far as I know, power to simple analog EGT/CHT indicating systems are > for internal lighting only. > > First of all, it?Ts much easier to test the EGT system by removing the > sender from the exhaust system and heating the tip with a propane torch to > see if you get needle movement ?" need another person in the cockpit to > watch gauge. Please use some precautions here so as to not burn your > airplane nor anyone elses down. A fire extinguisher AND a handy 5 gal > bucket of water along with common sense can work wonders. > > If that didn?Tt work, the next thing to do is reverse the wires and > recheck. Yeah, I know, color code, yadda yadda ?" Reverse the wires, > reheat and see if needle moves > > If that still don?Tt work, disconnect wires from the gauge and check for > continuity at the wires. By measuring the wires, you are checking the > sender and any extension leads and eliminating everything except the > gauge. > > My Westach setup says sender resistance should be about 2.5 ohms for EGT, > but meter lead resistance will add to this, so correct reading will be > higher. You are really looking for continuity at this point. Now if all > appears to be roughly correct, you could turn your digital meter to the > millivolt scale, reheat the EGT probe and watch for a tiny millivolt > output within seconds of applying flame. > > The gauge itself can be checked for continuity with a DIGITAL ohmmeter > (the gauge is so sensitive that an analog meter can burn the darned thing > out). > Let me repeat - Test gauge using ONLY a digital ohmmeter > > Again, you are just looking for continuity, but Westach says somewhere > between 8 & 15 ohms. > > Resistance readings may differ as EGT systems may use either J or K type > thermocouples (sender), but you are mainly looking for continuity. These > things generally either work well or not at all. > > Any resistance in the system or any corrosion will generally result in no > or very low indication Just one other thought on this. If you added an extension wire to the probe MAKE SURE that you used the proper wire. If it is a "J" type, Red and White wires, be certain that you use the red and white thermocouple extension wires. Use of other wires can give you gross errors. Roger ________________________________________________________________________________
Date: Jun 08, 2014
> However, the person that wired this aircraft originally hooked them up > backwards, with the copper bus bar connected to the "Load" terminal, and > the devices being switched connected to the "Line" terminal. > My question is, does it really matter? Some plumber installed an angle valve that had an arrow on the body. He installed it with the arrow pointing in the wrong direction. How did I learn this? Because the water pressure kept the valve washer stuck to the valve seat so opening the valve unscrewed the washer retaining screw. The valve quit working. Electricians know that a 3-wire flexible cord can only be attached to one end of the cord. Although you might think that a power cord comes out of each end identically, they are actually mirror images. Only one end installs onto (for example) hospital-grade plugs. MAYBE W31 circuit breakers have a proper line and load connection orientation because the conducting parts, arc suppression, hi-voltage withstand, inductive load, capacitance, wet operation, voltage breakdown to ground (or to the toggle), electrical approvals, or God-knows-what-else behaves somewhat differently in the opposite direction. Maybe this matters and maybe not. But if it doesn't matter, why did they mark it that way? Only the P&B/Tyco engineers can tell you and it would certainly be worth an email to find out. Please share it with us. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=424516#424516 ________________________________________________________________________________
Date: Jun 08, 2014
At 06:50 AM 6/8/2014, you wrote: > 1) Verified power and ground to the gauge. > As far as I know, power to simple analog EGT/CHT indicating systems are for internal lighting only. Van's line of analog instruments are built on a common frame of circuitry used to position pointers over approx 250 degrees of arc on the dial. Emacs! An exemplar instrument (ammeter) was examined in our shop some years back . . . http://tinyurl.com/mpx8hze This particular device was found to be rather sensitive to strong fields of radio frequency energy in the cockpit . . . First of all, it=99s much easier to test the EGT system by removing the sender from the exhaust system and heating the tip with a propane torch to see if you get needle movement =93 need another person in the cockpit to watch gauge. Please use some precautions here so as to not burn your airplane nor anyone elses down. A fire extinguisher AND a handy 5 gal bucket of water along with common sense can work wonders. If that didn=99t work, the next thing to do is reverse the wires and recheck. Yeah, I know, color code, yadda yadda =93 Reverse the wires, reheat and see if needle moves If that still don=99t work, disconnect wires from the gauge and check for continuity at the wires. By measuring the wires, you are checking the sender and any extension leads and eliminating everything except the gauge. My Westach setup says sender resistance should be about 2.5 ohms for EGT, but meter lead resistance will add to this, so correct reading will be higher. You are really looking for continuity at this point. Now if all appears to be roughly correct, you could turn your digital meter to the millivolt scale, reheat the EGT probe and watch for a tiny millivolt output within seconds of applying flame. The gauge itself can be checked for continuity with a DIGITAL ohmmeter (the gauge is so sensitive that an analog meter can burn the darned thing out). Let me repeat - Test gauge using ONLY a digital ohmmeter Not true . . . the non-electronic instruments designed to read millivolt levels DIRECTLY from a heated thermocouple have VERY low winding resistance as matter of necessity . . . as panel instruments they are generally designed for full scale indication with only tens of millivolts applied to the terminals at TENS of milliamps. "Self powered" instruments of yesteryear were often calibrated assuming thermocouple lead wires long enough to reach to the extreme engine locations on a large airplane. Lead wires for closer engines could be shortened and the lost-resistance compensated for by inserting a "thermocouple spool resistor" in one lead. http://www.dfwairparts.com/images/avionics/Aircraft_Thermocoupl The resistor was shipped with some too-large value (about 10 ohms as I recall). The installing technician could remove the cover and peel off turns of wire on the spools underneath the cover until the desired calibration was achieved. Again, you are just looking for continuity, but Westach says somewhere between 8 & 15 ohms. The input terminal to a Van's EGT will be considerably higher resistance. Signal conditioners inside the instrument are designed for insensitivity to total loop resistance of the thermocouple signal . . . this is goes to the goal of allowing thermocouples to be extended by any practical length without concern for instrument calibration as described above. Bob . . . ________________________________________________________________________________
Date: Jun 08, 2014
On 6/8/2014 12:41 PM, Eric M. Jones wrote: > Only the P&B/Tyco engineers can tell you and it would certainly be worth an email to find out. True, but I had my doubts that I'd find out the answer over the weekend, and waiting until Monday would have cost me an entire day's worth of work on the plane. With the collective wisdom of this group, I figured I had a chance that someone might know. > MAYBE W31 circuit breakers have a proper line and load connection orientation because the conducting parts, arc suppression, hi-voltage withstand, inductive load, capacitance, wet operation, voltage breakdown to ground (or to the toggle), electrical approvals, or God-knows-what-else behaves somewhat differently in the opposite direction. > Yes, this paralleled my own thoughts, and the first thing I did this morning was to re-wire everything the "right" way. It cost a couple of hours of effort, but my anal-retentiveness kept bugging me so it was worth it. Even if they were fine the other way, now my I's are crossed and my T's are dotted... ;-) Thanks for the replies, guys! -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jun 08, 2014
Furthermore, if it was important it would be specified in the datasheet, which it is not. Even the writing on the breaker is not specified, so it's technically not part of the device. If you used a breaker to tie two electrical buses together and it had a polarity, what would you do? It doesn't matter with these guys. Vern -----Original Message----- From: Sprocket Sent: Saturday, June 07, 2014 6:24 PM Subject: Re: AeroElectric-List: Tyco W31 switch / breaker It doesn't matter. These are thermal breakers so current direction can run either way. Vern =================================================== Sent from my iThing. It is responsible for all gramma and typo terrors. > On Jun 7, 2014, at 5:50 PM, Dj Merrill wrote: > > > I am in the process of refurbishing the panel in my aircraft, which uses > Tyco W31 switch/breakers for some items > (https://www.aircraftspruce.com/catalog/elpages/pbcircuitbrkr2.php). I > noticed that the W31 terminals are labeled "Line", which I presume is for > the electrical bus, and "Load", which I presume is for the device being > switched. > > However, the person that wired this aircraft originally hooked them up > backwards, with the copper bus bar connected to the "Load" terminal, and > the devices being switched connected to the "Line" terminal. > > My question is, does it really matter? > > If it does, now would be the time to rewire since I have it all apart, > however, the way it is hooked up at present does make for a neater and > cleaner installation. It has been flying this way for over 15 years, but > if it is "wrong", then I should probably make it "right". > > Thanks, > > -Dj > > -- > Dj Merrill - N1JOV - VP EAA Chapter 87 > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > ________________________________________________________________________________
Date: Jun 09, 2014
Subject: Fuse holders
I need to add circuit protection for my new avionics. I have no room in the panel, so I plan to put fuses behind the panel. I need suggestions for which fuse holder I should use. Is a fuse block preferable to inline fuse holders? What models do you recommend? Thanks for your help. Alan ________________________________________________________________________________
Subject: Re: COZY: Fuse holders
Date: Jun 08, 2014
ATC or ATM fuses are more durable than glass fuses and are becoming much more common. I'd put them in a device like this from B&C: http://www.bandc.biz/fuseholder8-slot.aspx Tim Andres > On Jun 8, 2014, at 9:39 PM, Alan Barnett wrote: > > I need to add circuit protection for my new avionics. I have no room in the panel, so I plan to put fuses behind the panel. I need suggestions for which fuse holder I should use. Is a fuse block preferable to inline fuse holders? What models do you recommend? > > Thanks for your help. > > Alan > ________________________________________________________________________________
Date: Jun 09, 2014
On 06/08/2014 11:40 PM, Vern Little wrote: > > Furthermore, if it was important it would be specified in the datasheet, > which it is not. Even the writing on the breaker is not specified, so > it's technically not part of the device. > If you used a breaker to tie two electrical buses together and it had a > polarity, what would you do? It doesn't matter with these guys. Also interesting, if you look at the picture at the top of the datasheet, it does NOT have the terminals labeled at all. https://www.aircraftspruce.com/catalog/pdf/tycoBreakers.pdf I have sent an email to Tyco tech support for clarification. (now thinking about putting it back the way it was... *sigh* ) -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jun 09, 2014
On 06/09/2014 10:31 AM, Dj Merrill wrote: > I have sent an email to Tyco tech support for clarification. and the official response from Tyco is: "Electrically it makes no difference to the breaker if line and load are swapped. But if you require UL approval on your product it must be wire line and load." -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jun 09, 2014
Ah ha! A regulatory requirement.- That explains it.=0A=0AThrough the year s I have seen lots of those breakers installed, and installed many myself, and never been concerned about the polarity.- Never had a problem.=0A=0AD j - thanks for following thru & getting the official response - very inform ative.=0A=0A-Jeff=0A=0A=0A=0AOn Monday, June 9, 2014 8:16 AM, Dj Merrill =0A=0AOn 06/09/2014 10:31 AM, Dj Merrill wrote:=0A > I have sent an email to Tyco tech support for clarification.=0A=0Aand the official response from Tyco is:=0A=0A"Electrically it makes no difference to the breaker if line and load are=0Aswapped.=0ABut if you require UL appr oval on your product it must be wire line and=0Aload."=0A=0A-Dj=0A=0A-- =0A Dj Merrill - N1JOV - VP EAA Chapter 87=0ASportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/=0AGlastar Flyer N866RH - http://deej.net/glas ==================== ________________________________________________________________________________
Subject: Right angle BNC
Date: Jun 09, 2014
Bob, I just received some of the right angle BNC connectors that we were discussing a couple of weeks ago. They do come with no instructions. I am assuming that the cable will be properly prepared and the center conductor will be soldered into the notch in the back end of the center conductor pin, then the barrel will crimp over the braid as in a standard straight connector. Am I correct that the center conductor will be soldered? Roger ________________________________________________________________________________
Date: Jun 09, 2014
Subject: Re: Right angle BNC
At 12:33 PM 6/9/2014, you wrote: > >Bob, > >I just received some of the right angle BNC connectors that we were >discussing a couple of weeks ago. They do come with no >instructions. I am assuming that the cable will be properly >prepared and the center conductor will be soldered into the notch in >the back end of the center conductor pin, then the barrel will crimp >over the braid as in a standard straight connector. > >Am I correct that the center conductor will be soldered? Correct. The trim dimensions for this connector are the same as for a straight connector . . . except the center conductor is a tad bit shorted and soldered to the notched stud as opposed to crimped. The treaded cap covers the finished joint. Bob . . . ________________________________________________________________________________
Date: Jun 10, 2014
>>Bob, >> >>I just received some of the right angle BNC connectors that we were >>discussing a couple of weeks ago. They do come with no >>instructions. I am assuming that the cable will be properly >>prepared and the center conductor will be soldered into the notch in >>the back end of the center conductor pin, then the barrel will crimp >>over the braid as in a standard straight connector. >> >>Am I correct that the center conductor will be soldered? > > Correct. The trim dimensions for this connector are > the same as for a straight connector . . . except > the center conductor is a tad bit shorted and soldered > to the notched stud as opposed to crimped. > > The treaded cap covers the finished joint. Just as I thought! Thanks for the confirmation, Bob Roger ________________________________________________________________________________
Subject: Direction Indicator Needs
Date: Jun 10, 2014
6/10/2014 Hello Aeroelectric and Avionics Listers, I know that there are many technically smart people on these lists and I would like to enlist your assistance. Picture this situation: There are hundreds (maybe thousands) of EAB (Experimental Amateur Built) IFR capable aircraft flying around with vacuum driven mechanical spinning mass gyroscopic attitude and directional indicators. A large percentage of these builders and pilots would like to (or need to) replace those indicators with something electronic (other than expensive electrical motor driven mechanical spinning mass gyroscopic) in nature and remove the entire vacuum system from their EAB. Replacing the attitude indicator does not appear to be a big problem in meeting the requirement of 14 CFR 91.205 (d) (8) =9CGyroscopic pitch and bank indicator (artificial horizon)=9D since there are several offerings available. Here are some: http://www.dynonavionics.com/docs/D6_intro.html http://trutrakap.com/product/gemini-pfd/ http://www.grtavionics.com/mini.html http://www.sandia.aero/?q=node/80 But there does not appear to be available an electronic directional indicator that would meet the 14 CFR 91.205 (d) (9) criteria for a =9CGyroscopic directional indicator (directional gyro or equivalent)=9D if one believes that the Regulatory intended direction to be indicated must indeed be the current aircraft magnetic heading and not the current aircraft magnetic course (provided by GPS) over the surface. I feel that somewhere in the electronic magic that MEMS << https://www.memsnet.org/mems/what_is.html >> and AHARS << http://www.microstrain.com/inertial/3DM-GX3-25?gclid=CjgKEAjw2dqcBRC2q- LXjpfxjnQSJAAeYF5LUC4gvWycBVg6DDW_mzzSdTyyF3q0yoQHrT6ij9VbvvD_BwE >> represents there must be a practical, relatively inexpensive means of creating a direction indicator that will meet the intended requirements of 14 CFR 91.205 (d) (9). If so, I (and probably many others) would like to buy one for my EAB airplane. How about it experts (and entrepreneurs) are my desires hopeless and unrealistic? OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ________________________________________________________________________________
Date: Jun 10, 2014
Subject: Re: Direction Indicator Needs
On 06/10/2014 02:24 PM, Owen Baker wrote: > But there does not appear to be available an electronic directional > indicator that would meet the 14 CFR 91.205 (d) (9) criteria for a > Gyroscopic directional indicator (directional gyro or equivalent) if > one believes that the Regulatory intended direction to be indicated must > indeed be the current aircraft magnetic heading and not the current > aircraft magnetic course (provided by GPS) over the surface. > I am not familiar with the other brands, but the GRT EFIS units come with an external magnetometer box which gives magnetic heading information to the EFIS. Is that what you are asking about? -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jun 10, 2014
Subject: Re: testing a coax lead
Problem solved. So, Bob, your will be gratified to know that you DIY right angle connector record remains intact. Nothing wrong with that. I started with continuity testing. The pin at the transponder did not have continuity with the pin at the antenna. My first thought was that I had fouled up the connector. For whatever reason, I tested the ground connector and discovered no continuity there, either. After a short head scratch, I tested all the other antennae and discovered that I had somehow switched the labels, and hence the connection, of the transponder antenna with the marker beacon antenna. For future reference, a transponder does not develop proper output when connected to a DIY marker beacon antenna. Fortunately, they were very close together so all I had to do was switch the antenna inputs. Not quite enough slack to reproduce the nicely glued DYI right angle, but the connection is solid enough and the transponder works per specs. So, thanks again for your help. Regards, Michael Wynn RV 8 Finished! San Ramon, CA In a message dated 5/31/2014 9:37:17 A.M. Pacific Daylight Time, nuckolls.bob(at)aeroelectric.com writes: --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" Shoot me your mailing address and I'll get some connectors in the mail to you today. Sorry, I tought I had some rt-angle connectors in inventory . . . I'm out. Here's the source I've used for years http://tinyurl.com/mfp9cfg takes awhile to get parts but they've been consistently good. I've just ordered 10 to refurbish my inventory. http://tinyurl.com/m6ywj9p Depending on how 'tight' you are for schedule, I can offer connectors in when my order gets here . . .will only take a few days longer than ordering for yourself . . . Bob . . . Bob . . . ________________________________________________________________________________
Date: Jun 10, 2014
6/10/2014 Hello Dj Merrill, Thanks for your quick response. You wrote: ".... an external magnetometer box which gives magnetic heading information to the EFIS." 1) See here for information on what constitutes a magnetometer: http://science.howstuffworks.com/magnetometer-info.htm If the heading that appears on the display, see here: http://www.grtavionics.com/mini.html#Features is simply the indication of a remotely located magnetometer (which is available for the Mini-X and Mini-AP, but not the Mini-B) then I don't think that will meet the intended requirement of 14 CFR 91.205 (d) (9) criteria for a Gyroscopic directional indicator (directional gyro or equivalent). 2) One other big downside of the Mini displays from GRT was GRT's failure to package the units such that they could be readily installed in a standard round nominally 3 inch instrument cut out hole where the old attitude indicator resides. See here: http://www.grtavionics.com/Mini%20Drawing%202.pdf Needing to cut panel metal to install a Mini unit from GRT in an existing panel raises the difficulty of a swap over significantly. Note that Sandia recognized the significance of this issue and packaged the SAI 340 - Quattro accordingly. See here: http://www.sandia.aero/?q=system/files/SAI340BroR2Web.pdf I am still searching. OC =================================================================== From: Dj Merrill Sent: Tuesday, June 10, 2014 3:34 PM Subject: Re: AeroElectric-List: Direction Indicator Needs I am not familiar with the other brands, but the GRT EFIS units come with an external magnetometer box which gives magnetic heading information to the EFIS. Is that what you are asking about? -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ================================================ On 06/10/2014 02:24 PM, Owen Baker wrote: > But there does not appear to be available an electronic directional > indicator that would meet the 14 CFR 91.205 (d) (9) criteria for a > Gyroscopic directional indicator (directional gyro or equivalent) if > one believes that the Regulatory intended direction to be indicated must > indeed be the current aircraft magnetic heading and not the current > aircraft magnetic course (provided by GPS) over the surface. > ________________________________________________________________________________
Date: Jun 10, 2014
The dynon d6 pilot guide says "Like a conventional gyro-stabilized magnetic compass, magnetic heading reacts immediately to turn rate so that heading changes are reflected immediately. It then uses magnetometer data over the long term to ensure that it remains correct. Additionally, heading is corrected for attitude so that it is accurate as you pitch and roll. " Sounds equivalent to a dg to me. The gemini feature list also includes "Track DG" On Tue, Jun 10, 2014 at 11:24 AM, Owen Baker wrote: > 6/10/2014 > > Hello Aeroelectric and Avionics Listers, I know that there are many > technically smart people on these lists and I would like to enlist your > assistance. > > Picture this situation: There are hundreds (maybe thousands) of EAB > (Experimental Amateur Built) IFR capable aircraft flying around with vacu um > driven mechanical spinning mass gyroscopic attitude and directional > indicators. A large percentage of these builders and pilots would like to > (or need to) replace those indicators with something electronic (other th an > expensive electrical motor driven mechanical spinning mass gyroscopic) in > nature and remove the entire vacuum system from their EAB. > > Replacing the attitude indicator does not appear to be a big problem in > meeting the requirement of 14 CFR 91.205 (d) (8) =9CGyroscopic pitc h and bank > indicator (artificial horizon)=9D since there are several offerings > available. Here are some: > > http://www.dynonavionics.com/docs/D6_intro.html > > http://trutrakap.com/product/gemini-pfd/ > > http://www.grtavionics.com/mini.html > > http://www.sandia.aero/?q=node/80 > > But there does not appear to be available an electronic directional > indicator that would meet the 14 CFR 91.205 (d) (9) criteria for a > =9CGyroscopic directional indicator (directional gyro or equivalent )=9D if one > believes that the Regulatory intended direction to be indicated must inde ed > be the current aircraft magnetic heading and not the current aircraft > magnetic course (provided by GPS) over the surface. > > I feel that somewhere in the electronic magic that MEMS > > << https://www.memsnet.org/mems/what_is.html >> > > and AHARS > > << > http://www.microstrain.com/inertial/3DM-GX3-25?gclid=CjgKEAjw2dqcBRC2q- LXjpfxjnQSJAAeYF5LUC4gvWycBVg6DDW_mzzSdTyyF3q0yoQHrT6ij9VbvvD_BwE > >> > > represents there must be a practical, relatively inexpensive means of > creating a direction indicator that will meet the intended requirements o f > 14 CFR 91.205 (d) (9). If so, I (and probably many others) would like to > buy one for my EAB airplane. > > How about it experts (and entrepreneurs) are my desires hopeless and > unrealistic? > > OC > > 'O C' Baker says "The best investment you can make is the effort to gathe r > and understand information." > > > * > =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jun 11, 2014
> > Hi O.C.- RE: > > http://www.grtavionics.com/mini.html#Features > > is simply the indication of a remotely located magnetometer (which is > available for the Mini-X and Mini-AP, but not the Mini-B) then I don't > think > that will meet the intended requirement of 14 CFR 91.205 (d) (9) criteria > for a Gyroscopic directional indicator (directional gyro or equivalent). > > > I'm curious as to why you are concerned this hardware would be inadequate. It seems to me that it fits the bill and then some. To reference what Ryan cited: > > The dynon d6 pilot guide says "Like a conventional gyro-stabilized magnetic > compass, magnetic heading reacts immediately to turn rate so that heading > changes are reflected immediately. It then uses magnetometer data over the > long term to ensure that it remains correct. Additionally, heading is > corrected for attitude so that it is accurate as you pitch and roll. " > Sounds equivalent to a dg to me. > > This would be quite a bit better than a DG- It won't precess, doesn't need to be manually synced to a compass, and there are no bearings to wear out. If your concern relates to the display, there are many certified drum-type DG's still flying today. That's not my first choice for a display, but it does work. Thoughts? ________________________________________________________________________________
From: Stuart Hutchison <stuart(at)stuarthutchison.com.au>
Date: Jun 11, 2014
G=99day OC, We have the same issue in Australia, with policy anchored to antiquated analogue designs. CASA, our FAA, was slammed by most sectors of the Aviation community in submissions to the Federal Government review (still underway) over recent months. In my mind the installation should be =98no less safe=99 than existing IFR instruments. There is a LOT left to be desired in many S/E Type Certified IFR aircraft that depend on a notoriously unreliable single vacuum pump to drive the two most important flight instruments on the panel, the attitude indicator and the DG, neither of which are required to have a built-in failure flag. These two instruments usually also drive the autopilot! The compass is fast becoming totally obsolete alongside a certified GPS, perhaps several, that measure point-to-point track. Among other things, magnetic heading from the magnetometer helps calculate wind, but if you know the track and groundspeed, who needs a wet compass?! Flying limited panel on the =98backup=99 electric turn and bank indicator (which actually indicates rate of change of heading, not roll and is gimbal limited to about rate 1 or 2) is extremely difficult in rough weather, which has resulted in numerous fatalities. CASA has yet to agree that system safety can be achieved a variety of ways, not the least by full redundancy. The Garmin 1000 is not fully redundant, which is why there is a backup three-pack to complement the PFD/MFD. A second AHRS, ADC and magnetometer would be required to make the system fully redundant, but software is also vulnerable to latent bugs and multiple systems can be expected to behave the same way under the same preconditions, so alternative hardware or staggered software versions seems like a good idea to me. CASA is wedded to outdated TSO=99s, arguing that if a piece of equipment is required by the Regs, then it must be approved in one of the recognised ways. In the absence of a specific approval, in most cases, that means a TSO. CASA don=99t seem to care that the most recent TSO for attitude indicators was published via typewriter in 1959. We do not want Dynon, AFS, GRT etc etc to required TSO=99s, nor is it necessary in order to achieve the equivalent form, fit, function and quality intended by the TSO. Like the US, Australia will slowly adopt =98performance-based=99 testing for equivalent functionality of non-TSO flight instruments, but the authorities are moving at a glacial pace. I think it is statistically significant that there are thousands of Dynon, AFS, GRT etc etc systems being operated VFR in the AB(E) community without systemic issues that would preclude them being used for IFR. Heated pitots becoming overcome with trapped moisture/ice are unhelpful for the IFR cause, but these are known issues that can and will be overcome in due course. All this is in relation to flight instruments of course. Communication/Navigation/Surveillance (CNS) systems are a different matter and should be TSO=99d if we expect to fly IFR in/around airspace with airliners and paying passengers. Cheers, Stu From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Owen Baker Sent: 11 June 2014 04:24 Subject: AeroElectric-List: Direction Indicator Needs 6/10/2014 Hello Aeroelectric and Avionics Listers, I know that there are many technically smart people on these lists and I would like to enlist your assistance. Picture this situation: There are hundreds (maybe thousands) of EAB (Experimental Amateur Built) IFR capable aircraft flying around with vacuum driven mechanical spinning mass gyroscopic attitude and directional indicators. A large percentage of these builders and pilots would like to (or need to) replace those indicators with something electronic (other than expensive electrical motor driven mechanical spinning mass gyroscopic) in nature and remove the entire vacuum system from their EAB. Replacing the attitude indicator does not appear to be a big problem in meeting the requirement of 14 CFR 91.205 (d) (8) =9CGyroscopic pitch and bank indicator (artificial horizon)=9D since there are several offerings available. Here are some: http://www.dynonavionics.com/docs/D6_intro.html <http://trutrakap.com/product/gemini-pfd/> http://trutrakap.com/product/gemini-pfd/ <http://www.grtavionics.com/mini.html> http://www.grtavionics.com/mini.html <http://www.sandia.aero/?q=node/80> http://www.sandia.aero/?q=node/80 But there does not appear to be available an electronic directional indicator that would meet the 14 CFR 91.205 (d) (9) criteria for a =9CGyroscopic directional indicator (directional gyro or equivalent)=9D if one believes that the Regulatory intended direction to be indicated must indeed be the current aircraft magnetic heading and not the current aircraft magnetic course (provided by GPS) over the surface. I feel that somewhere in the electronic magic that MEMS << https://www.memsnet.org/mems/what_is.html >> and AHARS << http://www.microstrain.com/inertial/3DM-GX3-25?gclid=CjgKEAjw2dqcBRC2q- LXjpfxjnQSJAAeYF5LUC4gvWycBVg6DDW_mzzSdTyyF3q0yoQHrT6ij9VbvvD_BwE >> represents there must be a practical, relatively inexpensive means of creating a direction indicator that will meet the intended requirements of 14 CFR 91.205 (d) (9). If so, I (and probably many others) would like to buy one for my EAB airplane. How about it experts (and entrepreneurs) are my desires hopeless and unrealistic? OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ________________________________________________________________________________
Date: Jun 11, 2014
Subject: Re Direction Indicator Needs
MGL also makes 2-1/4" and a 3-1/8" round-hole-mount displays for their AHRS and compass modules. It's about $1300 for attitude, TC and DG, or $500 for direction only, including the sensors. It would be up to you to be certain that these are equivalent to gyroscopic instruments. The sensors don't contain spinning masses but sense acceleration and attitude with multiple single-axis vibrating structures instead. The basic sensors are quite cheap; you can get a "10 degree of freedom" sensor module on a pc board for under $12 which includes 3 axes each of attitude, acceleration and magnetic field plus a barometric pressure sensor. Computations that used to take 30 pounds of synchros can now be done with a Kalman filter running on a fifty cent microcontroller chip. ________________________________________________________________________________
From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: 91.205 - NOT!
Date: Jun 12, 2014
Just a reminder to note that, as specifically stated in the heading section, 14CFR 91.205 applies to, and only to, "Powered civil aircraft with *standard* category U.S. airworthiness certificates". For the larger number of us who are building/flying experimental category aircraft, the applicable rules appear in your operating limits. The recommendations in 91.205 are good guidelines, but it's your ops limits, and the general requirement to have appropriate equipment to complete the planned flight, that rule here. Andy ------------------------ Andrew S Elliott, CFI ________________________________________________________________________________
Date: Jun 12, 2014
At 03:38 PM 6/10/2014, you wrote: Problem solved. So, Bob, your will be gratified to know that you DIY right angle connector record remains intact. Nothing wrong with that. Good to know . . . I started with continuity testing. The pin at the transponder did not have continuity with the pin at the antenna. My first thought was that I had fouled up the connector. For whatever reason, I tested the ground connector and discovered no continuity there, either. After a short head scratch, I tested all the other antennae and discovered that I had somehow switched the labels, and hence the connection, of the transponder antenna with the marker beacon antenna. For future reference, a transponder does not develop proper output when connected to a DIY marker beacon antenna. Fortunately, they were very close together so all I had to do was switch the antenna inputs. Not quite enough slack to reproduce the nicely glued DYI right angle, but the connection is solid enough and the transponder works per specs. The Devil is in the details . . . funny and frustrating how much $time$ can be expended running down the wrong rabbit hole. Been there, done that. Pleased that order has returned to your universe . . . Bob . . . ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jun 12, 2014
Subject: Re: 91.205 - NOT!
There are other examples of this in the FARs, where experimentals seem to be given a pass, but then the op limits put the reg back in. Modern op limits are gonna say: =8B(8) After completion of phase I flight testing, unless appropriate ly equipped for night and/or instrument flight in accordance with =C2=A7 91.205, this aircraft is to be operated under VFR, day only. (9) Aircraft instruments and equipment installed and used under =C2=A7 91.2 05 must be inspected and maintained in accordance with the requirements of part 91. Any maintenance or inspection of this equipment must be recorded in the aircraft maintenance records. =8BSo 91.205 gets handed back to us, per the op limits. The only caveat I know of is that some older op limits, which are still valid, might not refer back to 205.=8B --Dave On Thu, Jun 12, 2014 at 7:35 AM, Dr. Andrew Elliott wrote: > Just a reminder to note that, as specifically stated in the heading > section, 14CFR 91.205 applies to, and only to, =9CPowered civil air craft with > **standard** category U.S. airworthiness certificates=9D. For the larger > number of us who are building/flying experimental category aircraft, the > applicable rules appear in your operating limits. The recommendations in > 91.205 are good guidelines, but it=99s your ops limits, and the gen eral > requirement to have appropriate equipment to complete the planned flight, > that rule here. > > > Andy > > ------------------------ > > Andrew S Elliott, CFI > > > * > =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jun 12, 2014
In theory you may be right, and while ops limits vary from case to case, mine say "After completion of Phase I flight testing, unless appropriately equipped for night and/or instrument flight in accordance with 14 CFR 91.205, this aircraft is to be operated under VFR, day only." So for my airplane and anyone else who has that limit, the ops limits just circle back to 91.205, so your point doesn't really apply. On Thu, Jun 12, 2014 at 10:35 AM, Dr. Andrew Elliott wrote: > Just a reminder to note that, as specifically stated in the heading > section, 14CFR 91.205 applies to, and only to, =9CPowered civil air craft with > **standard** category U.S. airworthiness certificates=9D. For the larger > number of us who are building/flying experimental category aircraft, the > applicable rules appear in your operating limits. The recommendations in > 91.205 are good guidelines, but it=99s your ops limits, and the gen eral > requirement to have appropriate equipment to complete the planned flight, > that rule here. > > > Andy > > ------------------------ > > Andrew S Elliott, CFI > > > * > =========== www.matronics.com/Navigator?AeroElectric-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Subject: Direction Indicator Needs (Summary)
Date: Jun 12, 2014
6/12/2014 Hello Aeroelectric and Avionics Listers, On this subject back on 6/10/2014 I wrote: =9CI know that there are many technically smart people on these lists and I would like to enlist your assistance. Picture this situation: There are hundreds (maybe thousands) of EAB (Experimental Amateur Built) IFR capable aircraft flying around with vacuum driven mechanical spinning mass gyroscopic attitude and directional indicators. A large percentage of these builders and pilots would like to (or need to) replace those indicators with something electronic (other than expensive electrical motor driven mechanical spinning mass gyroscopic) in nature and remove the entire vacuum system from their EAB.=9D and =9CHow about it experts (and entrepreneurs) are my desires hopeless and unrealistic?=9D I want to now post what I have learned / concluded and express my gratitude to the several people who responded: 1) The two best choices for replacing my previous vacuum driven attitude gyro: a) The Sandia SAI 340 Quattro. See here: http://www.sandia.aero/?q=node/80 b) The Dynon EFIS-D6. See here: http://www.dynonavionics.com/docs/D6_intro.html 2) The best choice for replacing my previous vacuum driven directional gyro: The MGL Avionics Velocity Singles Horizon / Compass. See here: http://www.mglavionics.com/html/velocity_singles.html Many thanks again for all that posted help and I would be willing to discuss my choices if desired. OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ________________________________________________________________________________
Date: Jun 12, 2014
Subject: Starting an RV-6 with a Lycoming O-320
For several months my RV-6 has experienced starting problems. At first go the engine would hardly turn as there did not seem to be enough power from the starter motor. After repeated attempts things would progressively improve until there was enough power to start the engine. Since the end of last month the starter motor has simply not been able to provide enough power to start my engine. I removed the starter motor and had it tested. It jumped to life when exposed to enough voltage. Therefore this was apparently not the problem. Measurements initially seemed to indicate that the battery was OK. However, later it appeared that the battery could not provide enough tension. I removed it and measured it. It provides almost 11.7 V at present. I reckon that the battery is, if not the only problem, then one of the problems. A fellow aircraft owner told me that he believes that the problem is with the relay. That is why, according to him, in the past I initially had problems in starting but after several attempts I succeeded. Could this in your opinion be the case? Does anyone by chance know where can I find a replacement relay, which companies make suitable relays and what their part numbers are? As for my battery, it is an Odyssey PC 680 by Enersys. When in the hangar it is always kept under tension by a battery charger. Is this battery the optimal choice for a Lycoming O-320 powered RV-6 or RV-6A? Do you know whether any other batteries would be just as good or better? I have found sources for such a battery. Thanks. George Nielsen RV-6 PH-XGN The Hague, the Netherlands P.S. I have sent this on both the RV-6 and Lycoming lists. Please excuse me if you receive the same message more than once. ________________________________________________________________________________
Date: Jun 12, 2014
Subject: Re: Starting an RV-6 with a Lycoming O-320
George,=0A=0AThe PC 680 should be fine - lots of RVers use them.However, a resting battery voltage of 11.7 volts is a bad thing.- That is essentiall y a dead battery.- A healthy battery should have a resting voltage > 12.5 volts.=0A=0AI would start with a new battery.- If that does not solve th e problem we can look at the start solenoid (relay).=0A=0A=0AAlso, be advis ed that some battery charger/maintainers do not have the proper output for maintaining this type of battery and will actually decrease battery life. - There was a thread here on the Aeroelectric List some months ago where BobN analyzed the charge curves of a few battery maintainers and recommende d one.- I know it was a Schumacher and I think is was model number 1562A (around $20). (somebody please correct me if that's wrong)=0A=0A=0A-Jeff=0A =0A=0A=0A=0AOn Thursday, June 12, 2014 11:03 AM, George Nielsen =0A=0AFor several months my RV-6 has experi enced starting problems. At first =0Ago the engine would hardly turn as the re did not seem to be enough power =0Afrom the starter motor. After repeate d attempts things would =0Aprogressively improve until there was enough pow er to start the engine. =0ASince the end of last month the starter motor ha s simply not been able =0Ato provide enough power to start my engine.=0A=0A I removed the starter motor and had it tested. It jumped to life when =0Aex posed to enough voltage. Therefore this was apparently not the problem.=0A =0AMeasurements initially seemed to indicate that the battery was OK. =0AHo wever, later it appeared that the battery could not provide enough =0Atensi on. I removed it and measured it. It provides almost 11.7 V at =0Apresent. I reckon that the battery is, if not the only problem, then one =0Aof the p roblems.=0A=0AA fellow aircraft owner told me that he believes that the pro blem is =0Awith the relay. That is why, according to him, in the past I ini tially =0Ahad problems in starting but after several attempts I succeeded. Could =0Athis in your opinion be the case? Does anyone by chance know where can I =0Afind a replacement relay, which companies make suitable relays an d what =0Atheir part numbers are?=0A=0AAs for my battery, it is an Odyssey PC 680 by Enersys. When in the =0Ahangar it is always kept under tension by a battery charger. Is this =0Abattery the optimal choice for a Lycoming O- 320 powered RV-6 or RV-6A? =0ADo you know whether any other batteries would be just as good or better? =0AI have found sources for such a battery.=0A =0AThanks.=0A=0AGeorge Nielsen=0ARV-6 PH-XGN=0AThe Hague, the Netherlands =0A=0AP.S. I have sent this on both the RV-6 and Lycoming lists. Please exc ============== ________________________________________________________________________________
Date: Jun 12, 2014
Hi George, Since no one else has replied yet, I'll offer my thoughts. It is my understanding that the PC680 does not respond well to constant charge. I'm not sure if this battery is recoverable, but you can try. You may find some methods on the net, or someone else may chime in here. What is the open circuit voltage? What is the charger's voltage output? What is the battery charge about an hour after you remove the charger? How old is it? Has it bulged, enlarged or deformed in anyway? Have you contacted the manufacturer? The PC680 has a reputation as a very good battery for our applications. However, if you find you need to replace it, consider one of the new LiFePo such as EarthX and save about 11 LB. I am. Bevan Canada -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of George Nielsen Sent: Thursday, June 12, 2014 10:52 AM Subject: AeroElectric-List: Starting an RV-6 with a Lycoming O-320 --> For several months my RV-6 has experienced starting problems. At first go the engine would hardly turn as there did not seem to be enough power from the starter motor. After repeated attempts things would progressively improve until there was enough power to start the engine. Since the end of last month the starter motor has simply not been able to provide enough power to start my engine. I removed the starter motor and had it tested. It jumped to life when exposed to enough voltage. Therefore this was apparently not the problem. Measurements initially seemed to indicate that the battery was OK. However, later it appeared that the battery could not provide enough tension. I removed it and measured it. It provides almost 11.7 V at present. I reckon that the battery is, if not the only problem, then one of the problems. A fellow aircraft owner told me that he believes that the problem is with the relay. That is why, according to him, in the past I initially had problems in starting but after several attempts I succeeded. Could this in your opinion be the case? Does anyone by chance know where can I find a replacement relay, which companies make suitable relays and what their part numbers are? As for my battery, it is an Odyssey PC 680 by Enersys. When in the hangar it is always kept under tension by a battery charger. Is this battery the optimal choice for a Lycoming O-320 powered RV-6 or RV-6A? Do you know whether any other batteries would be just as good or better? I have found sources for such a battery. Thanks. George Nielsen RV-6 PH-XGN The Hague, the Netherlands P.S. I have sent this on both the RV-6 and Lycoming lists. Please excuse me if you receive the same message more than once. ________________________________________________________________________________
Date: Jun 12, 2014
Subject: Re: Direction Indicator Needs (Summary)
At 12:21 PM 6/12/2014, you wrote: >6/12/2014 > >Hello Aeroelectric and Avionics Listers, On this >subject back on 6/10/2014 I wrote: > >I know that there are many technically smart >people on these lists and I would like to enlist your assistance. > >Picture this situation: There are hundreds >(maybe thousands) of EAB (Experimental Amateur >Built) IFR capable aircraft flying around with >vacuum driven mechanical spinning mass >gyroscopic attitude and directional indicators. >A large percentage of these builders and pilots >would like to (or need to) replace those >indicators with something electronic (other than >expensive electrical motor driven mechanical >spinning mass gyroscopic) in nature and remove >the entire vacuum system from their EAB Exactly . . . which is what the TC world has been working toward for decades. A discussion I had with an FAA type some years ago about iron-gyro instruments hinged on the word "equivalent" with confidence levels supported by a plan-b. We kinda got wrapped around the AHRS axle; he was of the opinion that rate-based sensors would never replace a suite of spinning iron disks. But few contemporary offerings use real gyros yet are demonstrably capable of offering reliable presentations. Our venerable iron gyros were 'backed up' with needle- ball and airspeed . . . and indeed, the prudent driller of holes in clouds was encouraged to keep those skills sharp too. Ever since I wrote the article on hand-held GPS receivers for S.A. in 1997, I've not turned on an ADF, VOR or even a panel mounted GPS. There was a time that I gave away hand-helds suitable for airplanes (GPS310/315) as seminar door prizes . . . bought them at Walmart for $100. http://tinyurl.com/pzuzf7y I fly with dual GPS . . . two hand-helds stuck between glare-shield and windshield with little wads of windshield sealant. Dual displays that get fresh batteries out-bound and return legs. Totally independent of panel mounted equipment . . . I'd be perfectly comfortable poking through a layer needle, ball, airspeed -AND- GPS. In terms of complying with spirit and intent of the rules, the hand helds offer considerable redundancy to stuff already mounted on the panel. Bottom line is, what do YOU need to competently and confidently operate your airplane? If you call for clearance to poke holes in clouds, nobody gives a toot what's on your panel . . . except you. The only time individuals with an aire of authority care is when digging through the wreckage . . . at which time it will probably be discovered that no suite of instrumentation, holy-watered or not, would have made any difference. While we owned the airport at Benton, I did a lot of playing with the dual GPS. I devised approach profiles to our runway using the hand-helds that were quite capable of getting me on the ground comfortably at 400 and 1/2. Never needed to use them . . . but they worked. The nice thing about the hand-helds is, like the whisky compass, total independence from the panel mounted stuff. Put one or more of these puppies in your flight bag http://tinyurl.com/mrlquos and the pressures for selection of 'just the right panel mounted equipment' go WAAaayyyy down . . . Bob . . . ________________________________________________________________________________
Date: Jun 12, 2014
At 02:04 PM 6/12/2014, you wrote: >George, > >The PC 680 should be fine - lots of RVers use them. However, a >resting battery voltage of 11.7 volts is a bad thing. That is >essentially a dead battery. A healthy battery should have a resting >voltage > 12.5 volts. > >I would start with a new battery. If that does not solve the >problem we can look at the start solenoid (relay). Try using jumper cables to put a car battery in parallel with your ship's battery . . . if you see a marked improvement, then load check the battery. No improvement, start looking at interconnecting hardware and wiring. >Also, be advised that some battery charger/maintainers do not have >the proper output for maintaining this type of battery and will >actually decrease battery life. There was a thread here on the >Aeroelectric List some months ago where BobN analyzed the charge >curves of a few battery maintainers and recommended one. I know it >was a Schumacher and I think is was model number 1562A (around $20). >(somebody please correct me if that's wrong) That's the one. I've had good luck with the Battery Tenders too. I don't recall if I mentioned my disappointment with the charger-gods at Schumacher with the performance of an XC75W charger a couple weeks ago Emacs! This 'super whippy' product was supposed to massage any of the common technologies. In fact, when I tried the Standard and AGM modes during some battery tests, the thing peaked out at well over 15 volts . . . only the GEL mode proved to be a profile I'd want to use with ANY battery. I've still got it on my list of things to do to forward this data to Schumacher with some hope of receiving clarification. Bob . . . ________________________________________________________________________________
Date: Jun 13, 2014
6/13/2014 Hello Andrew Eliot, Does the attached document help clarify things for you? Thanks, OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ================== From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net> Subject: AeroElectric-List: 91.205 - NOT! Just a reminder to note that, as specifically stated in the heading section, 14CFR 91.205 applies to, and only to, "Powered civil aircraft with *standard* category U.S. airworthiness certificates". For the larger number of us who are building/flying experimental category aircraft, the applicable rules appear in your operating limits. The recommendations in 91.205 are good guidelines, but it's your ops limits, and the general requirement to have appropriate equipment to complete the planned flight, that rule here. Andy ------------------------ Andrew S Elliott, CFI ________________________________________________________________________________
Date: Jun 13, 2014
Boy. Did I ever suffer hard with the same squawk in a c182. Hope this helps. I tested the battery voltage WHILE CRANKING with a simple Simpson volt meter. The meter would dip from 12.5ish to 1.0ish under heavy load. That seemed resonable. Then I tested the starter voltage WHILE CRANKING. It was dipping to 5.5vdc on the compression strokes. Unreasonable. I put the meter from the battery + terminal to the starter + terminal. During cranking there was .75vdc of "drop" from the battery to the starter post. Seemed resonable. Then I connected the volt meter from the - terminal to the case of the starter. WHILE CRANKING there was 5.5 v of "loss". Further troubleshooting lead to the fact that the small straps at each lord mount were the only engine ground..... no where near enough. Big fat ground wire...... big fat smile. Since then one of my troubleshooting guideposts is........ use HIGH CURRENT to troubleshoot high current failures. Cautions apply.... you are spinning the meat clever out the front while troubleshooting.......murphy. Hope it helps -------- WWW.toddheffley.com www.theinterconnectco.com for lighting products AV-TS.com for Jet Aircraft Test Equipment Read this topic online here: http://forums.matronics.com/viewtopic.php?p=424793#424793 ________________________________________________________________________________
Date: Jun 13, 2014
Just 2 weeks ago I replaced a 6 mo old PC680 in my RV-6A with 0-360 Lyc. The engine had started fine the weekend before but now it wouldn't even hold the starter engaged. My panel volt meter showed 8.6v. when resting. I do not use a wall charger as I fly often enough. So I took the battery out and returned to the store where purchased. Later, after they "fully charged it" it was holding voltage at 13.3V yet wouldn't put out half of its CCA rating. Solution was a new battery under warranty replacement. YMMV Marty From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Starting an RV-6 with a Lycoming O-320 At 02:04 PM 6/12/2014, you wrote: >George, > >The PC 680 should be fine - lots of RVers use them. However, a >resting battery voltage of 11.7 volts is a bad thing. That is >essentially a dead battery. A healthy battery should have a resting >voltage > 12.5 volts. > >I would start with a new battery. If that does not solve the >problem we can look at the start solenoid (relay). Try using jumper cables to put a car battery in parallel with your ship's battery . . . if you see a marked improvement, then load check the battery. No improvement, start looking at interconnecting hardware and wiring. >Also, be advised that some battery charger/maintainers do not have >the proper output for maintaining this type of battery and will >actually decrease battery life. There was a thread here on the >Aeroelectric List some months ago where BobN analyzed the charge >curves of a few battery maintainers and recommended one. I know it >was a Schumacher and I think is was model number 1562A (around $20). >(somebody please correct me if that's wrong) That's the one. I've had good luck with the Battery Tenders too. I don't recall if I mentioned my disappointment with the charger-gods at Schumacher with the performance of an XC75W charger a couple weeks ago Emacs! This 'super whippy' product was supposed to massage any of the common technologies. In fact, when I tried the Standard and AGM modes during some battery tests, the thing peaked out at well over 15 volts . . . only the GEL mode proved to be a profile I'd want to use with ANY battery. I've still got it on my list of things to do to forward this data to Schumacher with some hope of receiving clarification. Bob ________________________________________________________________________________
Date: Jun 13, 2014
6/13/2015 Hello Ken, Thanks for your posting. You wrote: 1) There is also the Trutrak gemini ADI series for a drop in 3" replacement with gps track (not magnetic heading). I do not think that the units that provide only GPS track information, but not stabilized magnetic heading information, meet the intended requirements of 14 CFR 91.205 (d) (9) Gyroscopic direction indicator (directional gyro or equivalent)" for replacing my vacuum driven directional gyro. A case in point: Suppose that ATC tells the pilot to Fly heading XXX. I dont think that flying some very similar track instead will necessarily result in immediate danger or a flight violation (if the ATC controller is not happy with the movement of your aircraft he will most likely just issue you a new heading to fly), but I dont think that flying a track instead of a heading is what a conscientious pilot would want to do. 2) I would not expect the $500. MGL magnetic sensor and display to be a satisfactory replacement for a directional gyro. I've never flown it but the description says it won't be accurate during any turn unless you upgrade to the substantially more expensive AHRS. My comments: a) You write: .... the description says it won't be accurate during any turn unless you upgrade to the substantially more expensive AHRS. I can not find that information on the MGL web site. Can you please help me find it? http://www.mglavionics.com/html/velocity_singles.html b) You write: .... the description says it won't be accurate during any turn unless you upgrade to the substantially more expensive AHRS. I can not find any information on the MGL web site that states or implies that there is any improvement or relationship between a lone SP-6 Sensor, Tilt-compensated magnetic compass and the display of its heading information and the heading information displayed from a lone SP-7 Sensor Attitude indication and turn/bank indication. c) Here is an extract from the MGL web site: "Heading stability issues: You may find short term fluctuations of the heading occurring. These tend to be very small and are typically less than one degree. This could still cause the heading to fluctuate occasionally by a single degree. These fluctuations occur naturally in the earths magnetic field and can also be caused by nearby electrical equipment such as radios, lamps, electronic instrumentation or computers, even the ignition systems of engines. The AV-2 is specifically designed for fast response and thus may show residual fluctuations of the magnetic field that are impossible to filter out without causing delays in the update of the heading information." I can understand that there exists different levels of heading stability and instantaneous accuracy between the magnetic wet compass envisioned by 14 CFR 91.205 (b) (3) for VFR flight and a stabilized magnetic device that would meet 14 CFR 91.205 (d) (9) for IFR flight to perfection so it may come down to which device will meet both the intention of 14 CFR 91.205 (d) (9), but not to perfection, and the individual pilot's needs. d) You write: "I was surprised to learn that in my location at 45*N lattitude, the magnetic vector is tilted about 70 degrees below the horizon which makes attitude info pretty much essential to simulate a gyro compass." Understand. How does one determine whether or not some stabilized magnetic heading indication device indeed has attitude information incorporated at all into providing more accurate and instantaneous magnetic heading indication and to the level of that incorporation between the zero stabilization of a wet compass and perfection? 3) "Nothing like the noise from a spinning gyro to remind me that the master is still on." Any time my master switch is on and the alternator is not putting out the minimum acceptable voltage (such as after alternator failure or engine shut down) the B&C voltage regulator in my system is flashing a light on my instrument panel. See here: http://www.bandc.biz/alternatorcontrollerregulator14vhomebuilt.aspx Different strokes for different folks. Thanks again for your input. OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ============================================================= From: Ken <kleh(at)dialupatcost.ca> Subject: Re: Avionics-List: Direction Indicator Needs (Summary) There is also the Trutrak gemini ADI series for a drop in 3" replacement with gps track (not magnetic heading). These are rate sensing gyros so they are a bit different than spinning gyro's. If you hold a pitch attitude and there is an altitude change they function well. However with no corresponding altitude change they gradually return to displaying nose level. Not really a problem but if I decelerate very very slowly I can get the nose quite high while the display still reads a level flight attitude. Accordingly the gemini flashes an airpseed warning when the speed gets low. Similarly if you maintain a turn for a long time, the display will gradually indicate wings level unless it has heading or track information such as from a gps. I would not expect the $500. MGL magnetic sensor and display to be a satisfactory replacement for a directional gyro. I've never flown it but the description says it won't be accurate during any turn unless you upgrade to the substantially more expensive AHRS. I was surprised to learn that in my location at 45*N lattitude, the magnetic vector is tilted about 70 degrees below the horizon which makes attitude info pretty much essential to simulate a gyro compass. While it's as heavy as the removed vacuum pump, I've been running a $25. junk table 28volt T&B for quite some time powered with a $5. dc-dc converter on my 12 volt electrical system. Nothing like the noise from a spinning gyro to remind me that the master is still on. Ken ________________________________________________________________________________
Date: Jun 13, 2014
6/13/2014 Hello Andy, Thanks for your response. You wrote: Why do you think that it (91.205) does? 1) I agree, 91.205 does not normally apply to any aircraft that has a: Special Airworthiness Certificate, Category/Designation: Experimental. 2) Such an aircraft is limited to VFR day only flight. See here: "14 CFR 91.319 Aircraft having experimental certificates: Operating limitations. (d) (2) Operate under VFR, day only, unless otherwise specifically authorized by the Administrator;...." 3) However the entire context of the recent postings regarding the subject Direction Indicator Needs has been for IFR flight by an aircraft that has a: Special Airworthiness Certificate, Category/Designation: Experimental. Purpose: To operate Amateur Built Aircraft. Operating Limitations Dated XX/XX/XXXX Are Part Of This Certificate. Note: The terminology and entries in 1 and 2 above are taken directly from an issued FAA Form 8130-7 (10/82). 4) This below extract copied from the attached document states why 91.205 DOES APPLY for IFR or night flight for an aircraft certificated as in 3 above.(commonly referred to as an EAB (Experimental Amateur Built) aircraft): "The Special Airworthiness Certificate issued for each amateur built experimental aircraft includes specific Operating Limitations. Per FAA Order 8130.2G the Operating Limitations state: After completion of Phase I flight testing, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated under VFR, day only. The interpretation given this statement is that if the aircraft is appropriately equipped in accordance with 91.205 then the VFR day only limitation no longer applies and the aircraft can be flown at night or under IFR in IMC." 4) If the EAB in question does not contain the above quoted Operating Limitations extract then one must, as you say, look at the Operating Limitations for that specific aircraft to see what does apply. Please let me know if the above information does not clarify this issue. Thanks, OC ====================================================================== From: Dr. Andrew Elliott Sent: Friday, June 13, 2014 8:38 AM Subject: RE: 91.205 - NOT! It does not. In your list, 91.205 is the reference for nearly all requirements. And most clearly, 91.205 does not apply to experimental category aircraft. Why do you think that it does? Andy ================================================================== From: Owen Baker [mailto:bakerocb(at)cox.net] Sent: Friday, June 13, 2014 5:15 AM Subject: 91.205 - NOT! 6/13/2014 Hello Andrew Eliot, Does the attached document help clarify things for you? Thanks, OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ======================================================================================== From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net> Subject: AeroElectric-List: 91.205 - NOT! Just a reminder to note that, as specifically stated in the heading section, 14CFR 91.205 applies to, and only to, "Powered civil aircraft with *standard* category U.S. airworthiness certificates". For the larger number of us who are building/flying experimental category aircraft, the applicable rules appear in your operating limits. The recommendations in 91.205 are good guidelines, but it's your ops limits, and the general requirement to have appropriate equipment to complete the planned flight, that rule here. Andy ------------------------ Andrew S Elliott, CFI
May 03, 2014 - June 13, 2014
AeroElectric-Archive.digest.vol-mi
