AeroElectric-Archive.digest.vol-pd
October 15, 2019 - November 01, 2019
      >>>> potentially kills the battery (again, I don't know this for a fact).
      >>>> So, the question is, "Does anyone know of a solar battery
      >>>> maintainer designed to service LiFePo batteries?"
      >>>> O
Subject: Re: Wiring Diagrams and Pictures
Date: Oct 15, 2019
Mauledriver(at)nc.rr.com wrote: > just some random pics from my RV10 build of some years ago.... Thanks so much! I made contact with Aerotronics and Jason Smith helped me out greatly and supplied me with a custom wiring diagram for my setup. Can't say enough about Aerotronics! -------- Currently building a Bearhawk 4 Place. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491827#491827 ________________________________________________________________________________
Date: Oct 15, 2019
Subject: Re: Maintainer's for LiFePo batteries
Hi Ernest; Please consider what I am going to say to be a "data point," not a recommendation. I have a "Battery Tender" LiFePO4 battery and a "Battery Tender" maintainer, which is specifically designed for the given battery. I have had very good luck with this combination. It has been in the plane since wiring started, and allows checking each circuit as it is installed. Recently I have started the engine about a dozen times and the battery has lots of energy to start the 2700 cc six cyl. Corvair engine. I leave the maintainer on all the time, except when the plane is out of the hangar for running. The battery is in the engine compartment, which gets quite hot during engine runs. So far the battery shows no ill effects. Please note the aircraft has not yet flown. Cheers! Stu. ----- Original Message ----- From: "Ernest Christley" <echristley(at)att.net> Sent: Tuesday, October 15, 2019 7:18:37 AM Subject: AeroElectric-List: Maintainer's for LiFePo batteries I'm still looking for a solar powered "maintainer" that will work with a LiFePo battery, and would really like a pointer if someone has found a good solution. I'm using the Scorpion battery to start my 120Hp Corvair. I'm VERY happy with how fast and how long it will spin the Corvair when it is charged, but I've been asking a lot from this battery due to carb issues that I've been having to work through. Lots of cranking, without much engine running to recharge. I bought one of the Harbor Freight, solar maintainers. I put it on and left it for a few days. The battery was completely dead when I came back. The battery was swollen, but I can't be sure if that was from an overcharge or from excessive exhaust heat. The solar panel says that it will put out as much as 18V...if I remember correctly...meaning the panel had the potential to exceed voltage that the battery is rated for. Disassembly of the battery found that two of the "bags" were swollen much larger than the the others. I have since added heat deflectors, and replaced the battery. (A future investigation is to see if I can remove the swollen bags, and make a smaller capacity battery out of the remainder...to power LED lights in the gazebo in my backyard...not for airplane use.) Getting a slow, battery-friendly charge to an airplane sitting on a ramp is a PIA. Charging from a car, with it dumping whatever the alternator will produce or whatever the battery will swallow, works, but is cringe-worthy. The 100mA output from the readily-available $20 panels takes a long time, but WILL top a battery off eventually (18Ahr/100mA =>180hr @ 9hr/day => 20 days). I find that acceptable, because my plane tends to sit idle on the ramp for long periods of time anyway. During that "top off" time, the solar panels are fine on a LiFePo, because the voltage drops below the max whenever there is a significant load on it. It's that period after the top off, when the panel reaches its open circuit voltage and exceeds what the battery can accept that potentially kills the battery (again, I don't know this for a fact). So, the question is, "Does anyone know of a solar battery maintainer designed to service LiFePo batteries?" O ________________________________________________________________________________
Date: Oct 15, 2019
Hi Charlie; You have not explained the reason for your focus on "solar." Is it because there is no 110V. electrical system in your hangar? Cheers! Stu. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Tuesday, October 15, 2019 9:43:05 AM Subject: Re: AeroElectric-List: Maintainer's for LiFePo batteries That's the general path I'd consider. Perhaps a perusal of hobby sites for a LiFePo charger that operates from a car battery would be a good place to start. Failing that, a small 12V-120vac inverter might get you there in somewhat plug&play fashion, though it would be a lot of monkey motion and not very efficient. solar panel>charge controller>inverter>charger Or..... https://www.amazon.com/DPJ-LiFePO4-Battery-Controller-SL03-4810A/dp/B07JG2V7TB/ref=asc_df_B07JG2V7TB/?tag=hyprod-20&linkCode=df0&hvadid=385172604940&hvpos=1o5&hvnetw=g&hvrand=16702995601745525769&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014228&hvtargid=pla-823507823024&psc=1&tag=&ref=&adgrpid=78287727493&hvpone=&hvptwo=&hvadid=385172604940&hvpos=1o5&hvnetw=g&hvrand=16702995601745525769&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014228&hvtargid=pla-823507823024 generally, https://www.google.com/search?rlz=1C1CHBF_enUS843US843&biw=1920&bih=975&sxsrf=ACYBGNSHIvwnyBkyd9OPRuYg3iDFSaANlA%3A1571157455562&ei=z_WlXYLHIZHQtAWcwrX4Bg&q=solar+charge+controller+for+lifepo4+battery&oq=solar+charge+controller+for+lifepo4+battery+&gs_l=psy-ab.1.0.0i30.199155.213105..214599...0.2..1.443.10450.1j16j19j9j1......0....1..gws-wiz.......0i71j35i39j0i22i30j35i304i39j0i8i13i30.YH6jrcsDRBs Charlie On 10/15/2019 11:08 AM, Jared Yates wrote: Can you make one, by using a 100w solar panel, a charge controller, and a 12v-powered liFe charging circuit? On October 15, 2019 11:45:24 Ernest Christley wrote:
Virus-free. www.avast.com ________________________________________________________________________________
Date: Oct 15, 2019
Well, because Earnest asked for a solar powered charger. Did I miss something? On 10/15/2019 12:08 PM, ashleysc(at)broadstripe.net wrote: > Hi Charlie; > You have not explained the reason for your focus on "solar." Is it > because there is no 110V. electrical system in your hangar? > Cheers! Stu. > > ------------------------------------------------------------------------ > *From: *"Charlie England" <ceengland7(at)gmail.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Tuesday, October 15, 2019 9:43:05 AM > *Subject: *Re: AeroElectric-List: Maintainer's for LiFePo batteries > > That's the general path I'd consider. Perhaps a perusal of hobby sites > for a LiFePo charger that operates from a car battery would be a good > place to start. Failing that, a small 12V-120vac inverter might get > you there in somewhat plug&play fashion, though it would be a lot of > monkey motion and not very efficient. > solar panel>charge controller>inverter>charger > > Or..... > https://www.amazon.com/DPJ-LiFePO4-Battery-Controller-SL03-4810A/dp/B07JG2V7TB/ref=asc_df_B07JG2V7TB/?tag=hyprod-20&linkCode=df0&hvadid=385172604940&hvpos=1o5&hvnetw=g&hvrand=16702995601745525769&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014228&hvtargid=pla-823507823024&psc=1&tag=&ref=&adgrpid=78287727493&hvpone=&hvptwo=&hvadid=385172604940&hvpos=1o5&hvnetw=g&hvrand=16702995601745525769&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014228&hvtargid=pla-823507823024 > generally, > https://www.google.com/search?rlz=1C1CHBF_enUS843US843&biw=1920&bih=975&sxsrf=ACYBGNSHIvwnyBkyd9OPRuYg3iDFSaANlA%3A1571157455562&ei=z_WlXYLHIZHQtAWcwrX4Bg&q=solar+charge+controller+for+lifepo4+battery&oq=solar+charge+controller+for+lifepo4+battery+&gs_l=psy-ab.1.0.0i30.199155.213105..214599...0.2..1.443.10450.1j16j19j9j1......0....1..gws-wiz.......0i71j35i39j0i22i30j35i304i39j0i8i13i30.YH6jrcsDRBs > > > Charlie > > On 10/15/2019 11:08 AM, Jared Yates wrote: > > Can you make one, by using a 100w solar panel, a charge > controller, and a 12v-powered liFe charging circuit? > > On October 15, 2019 11:45:24 Ernest Christley > wrote: > > I'm still looking for a solar powered "maintainer" that will > work with a LiFePo battery, and would really like a pointer if > someone has found a good solution. I'm using the Scorpion > battery to start my 120Hp Corvair. I'm VERY happy with how > fast and how long it will spin the Corvair when it is charged, > but I've been asking a lot from this battery due to carb > issues that I've been having to work through. Lots of > cranking, without much engine running to recharge. > > I bought one of the Harbor Freight, solar maintainers. I put > it on and left it for a few days. The battery was completely > dead when I came back. The battery was swollen, but I can't > be sure if that was from an overcharge or from excessive > exhaust heat. The solar panel says that it will put out as > much as 18V...if I remember correctly...meaning the panel had > the potential to exceed voltage that the battery is rated for. > Disassembly of the battery found that two of the "bags" were > swollen much larger than the the others. I have since added > heat deflectors, and replaced the battery. (A future > investigation is to see if I can remove the swollen bags, and > make a smaller capacity battery out of the remainder...to > power LED lights in the gazebo in my backyard...not for > airplane use.) > > Getting a slow, battery-friendly charge to an airplane sitting > on a ramp is a PIA. Charging from a car, with it dumping > whatever the alternator will produce or whatever the battery > will swallow, works, but is cringe-worthy. The 100mA output > from the readily-available $20 panels takes a long time, but > WILL top a battery off eventually (18Ahr/100mA =>180hr @ > 9hr/day => 20 days). I find that acceptable, because my plane > tends to sit idle on the ramp for long periods of time > anyway. During that "top off" time, the solar panels are fine > on a LiFePo, because the voltage drops below the max whenever > there is a significant load on it. It's that period after the > top off, when the panel reaches its open circuit voltage and > exceeds what the battery can accept that potentially kills the > battery (again, I don't know this for a fact). > > So, the question is, "Does anyone know of a solar battery > maintainer designed to service LiFePo batteries?" > > > O > > > > Virus-free. www.avast.com > > > > <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 15, 2019
Hi Charlie; No; I confess I didn't go far enough back in the e-mail chain to see who the original questioner was. The subject still begs the question: Does Earnest not have access to 110 V. in his hangar? Or does he tie-down outdoors? Or does he want to recharge battery(s) while camping at remote strips? Knowing situs would help determine best choice of hardware. Cheers! Stu. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Tuesday, October 15, 2019 10:51:48 AM Subject: Re: AeroElectric-List: Maintainer's for LiFePo batteries Well, because Earnest asked for a solar powered charger. Did I miss something? On 10/15/2019 12:08 PM, ashleysc(at)broadstripe.net wrote: Hi Charlie; You have not explained the reason for your focus on "solar." Is it because there is no 110V. electrical system in your hangar? Cheers! Stu. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Tuesday, October 15, 2019 9:43:05 AM Subject: Re: AeroElectric-List: Maintainer's for LiFePo batteries That's the general path I'd consider. Perhaps a perusal of hobby sites for a LiFePo charger that operates from a car battery would be a good place to start. Failing that, a small 12V-120vac inverter might get you there in somewhat plug&play fashion, though it would be a lot of monkey motion and not very efficient. solar panel>charge controller>inverter>charger Or..... https://www.amazon.com/DPJ-LiFePO4-Battery-Controller-SL03-4810A/dp/B07JG2V7TB/ref=asc_df_B07JG2V7TB/?tag=hyprod-20&linkCode=df0&hvadid=385172604940&hvpos=1o5&hvnetw=g&hvrand=16702995601745525769&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014228&hvtargid=pla-823507823024&psc=1&tag=&ref=&adgrpid=78287727493&hvpone=&hvptwo=&hvadid=385172604940&hvpos=1o5&hvnetw=g&hvrand=16702995601745525769&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014228&hvtargid=pla-823507823024 generally, https://www.google.com/search?rlz=1C1CHBF_enUS843US843&biw=1920&bih=975&sxsrf=ACYBGNSHIvwnyBkyd9OPRuYg3iDFSaANlA%3A1571157455562&ei=z_WlXYLHIZHQtAWcwrX4Bg&q=solar+charge+controller+for+lifepo4+battery&oq=solar+charge+controller+for+lifepo4+battery+&gs_l=psy-ab.1.0.0i30.199155.213105..214599...0.2..1.443.10450.1j16j19j9j1......0....1..gws-wiz.......0i71j35i39j0i22i30j35i304i39j0i8i13i30.YH6jrcsDRBs Charlie On 10/15/2019 11:08 AM, Jared Yates wrote:
Date: Oct 15, 2019
Stu,JNX doesn't have any hangar's available, so I'm parked on the ramp unt il they build some more. The $26 box may be the best choice, Charlie, except that it looks like over kill and will it run of such a small panel.=C2- I might be better off bui lding my own circuit.=C2- The idea being to not leave something sitting o n the outside of the airplane that I would be too upset about when someone walked off with it.=C2- Airplane people are an honest bunch overall, but there is always that one guy. I must say though, that I was hoping that someone had found one of the pane ls that I could just plug into the always hot cig-lighter socket. > wrote: Hi Charlie;No; I confess I didn't go far enough back in the e-mail chain t o see who the original questioner was. The subject still begs the question: Does Earnest not have access to 110 V. in his hangar? Or does he tie-down outdoors? Or does he want to recharge battery(s) while camping at remote st rips? Knowing situs would help determine best choice of hardware.Cheers!=C2 - =C2-Stu. From: "Charlie England" <ceengland7(at)gmail.com> Sent: Tuesday, October 15, 2019 10:51:48 AM Subject: Re: AeroElectric-List: Maintainer's for LiFePo batteries Well, because Earnest asked for a solar powered charger. Did I miss somethi ng? On 10/15/2019 12:08 PM, ashleysc(at)broadstripe.net wrote: Hi Charlie;You have not explained the reason for your focus on "solar." Is it because there is no 110V. electrical system in your hangar?Cheers!=C2- =C2-Stu. From: "Charlie England" <ceengland7(at)gmail.com> To: aeroelectric-list(at)matronics.com Sent: Tuesday, October 15, 2019 9:43:05 AM Subject: Re: AeroElectric-List: Maintainer's for LiFePo batteries That's the general path I'd consider. Perhaps a perusal of hobby sites for a LiFePo charger that operates from a car battery would be a good place to start. Failing that, a small 12V-120vac inverter might get you there in som ewhat plug&play fashion, though it would be a lot of monkey motion and not very efficient. solar panel>charge controller>inverter>charger Or..... https://www.amazon.com/DPJ-LiFePO4-Battery-Controller-SL03-4810A/dp/B07JG2 V7TB/ref=asc_df_B07JG2V7TB/?tag=hyprod-20&linkCode=df0&hvadid=38517 2604940&hvpos=1o5&hvnetw=g&hvrand=16702995601745525769&hvpone=&hvpt wo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014228&hvtargi d=pla-823507823024&psc=1&tag=&ref=&adgrpid=78287727493&hvpone=& hvptwo=&hvadid=385172604940&hvpos=1o5&hvnetw=g&hvrand=16702995601 745525769&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014228&hvt argid=pla-823507823024 generally, https://www.google.com/search?rlz=1C1CHBF_enUS843US843&biw=1920&bih= 975&sxsrf=ACYBGNSHIvwnyBkyd9OPRuYg3iDFSaANlA%3A1571157455562&ei=z_WlXYL HIZHQtAWcwrX4Bg&q=solar+charge+controller+for+lifepo4+battery&oq=solar+ charge+controller+for+lifepo4+battery+&gs_l=psy-ab.1.0.0i30.199155.213105 ..214599...0.2..1.443.10450.1j16j19j9j1......0....1..gws-wiz.......0i71j35i 39j0i22i30j35i304i39j0i8i13i30.YH6jrcsDRBs Charlie On 10/15/2019 11:08 AM, Jared Yates wrote: Can you make one, by using a 100w solar panel, a charge controller, and a 1 2v-powered liFe charging circuit? On October 15, 2019 11:45:24 Ernest Christley wrote: I'm still looking for a solar powered "maintainer" that will work with a Li FePo battery, and would really like a pointer if someone has found a good s olution.=C2- I'm using the Scorpion battery to start my 120Hp Corvair.=C2 - I'm VERY happy with how fast and how long it will spin the Corvair when it is charged, but I've been asking a lot from this battery due to carb is sues that I've been having to work through.=C2- Lots of cranking, without much engine running to recharge. I bought one of the Harbor Freight, solar maintainers.=C2- I put it on an d left it for a few days.=C2- The battery was completely dead when I came back.=C2- The battery was swollen, but I can't be sure if that was from an overcharge or from excessive exhaust heat.=C2- The solar panel says th at it will put out as much as 18V...if I remember correctly...meaning the p anel had the potential to exceed voltage that the battery is rated for.=C2 - Disassembly of the battery found that two of the "bags" were swollen mu ch larger than the the others. I have since added heat deflectors, and repl aced the battery.=C2- (A future investigation is to see if I can remove t he swollen bags, and make a smaller capacity battery out of the remainder.. .to power LED lights in the gazebo in my backyard...not for airplane use.) Getting a slow, battery-friendly charge to an airplane sitting on a ramp i s a PIA.=C2- Charging from a car, with it dumping whatever the alternator will produce or whatever the battery will swallow, works, but is cringe-wo rthy.=C2- The 100mA output from the readily-available $20 panels takes a long time, but WILL top a battery off eventually (18Ahr/100mA =>180hr @ 9 hr/day => 20 days).=C2- I find that acceptable, because my plane tends to sit idle on the ramp for long periods of time anyway.=C2- During that "top off" time, the solar panels are fine on a LiFePo, because the voltage drops below the max whenever there is a significant load on it.=C2- It's that period after the top off, when the panel reaches its open circuit volt age and exceeds what the battery can accept that potentially kills the batt ery (again, I don't know this for a fact). So, the question is, "Does anyone know of a solar battery maintainer desig ned to service LiFePo batteries?" O | | Virus-free. www.avast.com | ________________________________________________________________________________
Date: Oct 15, 2019
Beautiful work, Bill, and I wouldn't change a thing. But, just a suggestio n for other people considering those fuse blocks.=C2- You can get fast-ta bs that have the wire exiting at 90 degrees.=C2- It really cleans up the wiring, and allows the bundle to lie flat. @nc.rr.com> wrote: just some random pics from my RV10 build of some years ago. Fuse blocks and firewall ground Dual Battery tray and wiring with ground On 10/9/2019 7:56 AM, bearhawklife wrote: et> This will my first post on the AeroElectric forum and so I hope my first qu estion won't get me banned for asking the proverbial "dumb question" on top ic that may have already been covered that I have yet to find... I have Bob's book and several others on aircraft wiring. All have been ver y helpful and I have learned much. I am building a Bearhawk 4 Place powered by the IO-540. With the help of N athan over at B&C and Jason Smith at Aerotronics, I have chosen to go with a dual alternator single battery set up. From Bob's book, I have selected to follow the A12M diagram (attached) as a guide. Being that I am a visual person, I get the theory and written concepts, I j ust need to "see it". For example, indicating on a schematic that the main battery ground goes to the ground bus / electrical panel=C3=A2=82=AC=C2 . I=C3=A2=82=AC=84=A2m not sure what that looks like? Or the grou nd from the engine case to the airframe? Other connections are difficult t o imagine as well. I appreciate the routing and wire sizes indicated in th e drawings. Just curious if there is a resource for seeing the actual conn ections. Nathan Bainbridge has suggested searching on www.vansairforce.net or just g oogle =C3=A2=82=AC=C5=93RV-7 builders log=C3=A2=82=AC=EF=BD for va rious builders pics. Which I have but still coming up short. Thanks for your help! -------- Currently building a Bearhawk 4 Place. | | Virus-free. www.avast.com | ________________________________________________________________________________
Date: Oct 15, 2019
Subject: Re: Wiring dsub connectors
At 01:42 AM 10/15/2019, you wrote: > > >I'm replacing a Narco AT150 transponder with a Stratus ES.?? The >wires running to the Narco, which uses?? are 18 gauge wires and >Molex connectors.?? The Stratus specifies 22 gauge and dsub >connectors, but I'm sure bigger wire is OK. > >The problem is crimping the wires.?? I bought a Daniels AFM8 >crimping tool five years ago when I installed a Garmin GNS 430.?? I >have the positioner for 22 gauge wire, but I've lost the positioner >for the 18 gauge wire.?? My question is: should I crimp the dsub >pins onto 22 gauge wire and solder the wires to the 18 gauge wires, >or spend $50 on a new positioner (which one? it's hard to tell from >the catlogs I've looked at) so I can crimp the pins directly onto >the 18 gauge wires? That 18AWG citation for the Narco was overkill. A number of manufacturers have called out some rather 'conservative' wire sizes for their DC input pins . . . a practice that I don't really understand. None the less, upgrade situations like you've encountered do present a problem. I'd splice 22AWG pigtails on the ends of your 18AWG just before they drop into the D-sub. This po' boy's solder sleeve technique works good . . . lasts a long time. https://tinyurl.com/c5v2xvm Bob . . . ________________________________________________________________________________
Date: Oct 15, 2019
Hi Earnest; Well, you're right: Solar appears to be the best alternative [or a very long extension cord (chuckle)]. I'm sorry your aircraft has to sit outside. Cheers! Stu. ----- Original Message ----- From: "Ernest Christley" <echristley(at)att.net> Sent: Tuesday, October 15, 2019 12:47:23 PM Subject: Re: AeroElectric-List: Maintainer's for LiFePo batteries Stu, JNX doesn't have any hangar's available, so I'm parked on the ramp until they build some more. The $26 box may be the best choice, Charlie, except that it looks like overkill and will it run of such a small panel. I might be better off building my own circuit. The idea being to not leave something sitting on the outside of the airplane that I would be too upset about when someone walked off with it. Airplane people are an honest bunch overall, but there is always that one guy. I must say though, that I was hoping that someone had found one of the panels that I could just plug into the always hot cig-lighter socket. Hi Charlie; No; I confess I didn't go far enough back in the e-mail chain to see who the original questioner was. The subject still begs the question: Does Earnest not have access to 110 V. in his hangar? Or does he tie-down outdoors? Or does he want to recharge battery(s) while camping at remote strips? Knowing situs would help determine best choice of hardware. Cheers! Stu. From: "Charlie England" <ceengland7(at)gmail.com> Sent: Tuesday, October 15, 2019 10:51:48 AM Subject: Re: AeroElectric-List: Maintainer's for LiFePo batteries Well, because Earnest asked for a solar powered charger. Did I miss something? On 10/15/2019 12:08 PM, ashleysc(at)broadstripe.net wrote: Hi Charlie; You have not explained the reason for your focus on "solar." Is it because there is no 110V. electrical system in your hangar? Cheers! Stu. From: "Charlie England" <ceengland7(at)gmail.com> Sent: Tuesday, October 15, 2019 9:43:05 AM Subject: Re: AeroElectric-List: Maintainer's for LiFePo batteries That's the general path I'd consider. Perhaps a perusal of hobby sites for a LiFePo charger that operates from a car battery would be a good place to start. Failing that, a small 12V-120vac inverter might get you there in somewhat plug&play fashion, though it would be a lot of monkey motion and not very efficient. solar panel>charge controller>inverter>charger Or..... https://www.amazon.com/DPJ-LiFePO4-Battery-Controller-SL03-4810A/dp/B07JG2V7TB/ref=asc_df_B07JG2V7TB/?tag=hyprod-20&linkCode=df0&hvadid=385172604940&hvpos=1o5&hvnetw=g&hvrand=16702995601745525769&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014228&hvtargid=pla-823507823024&psc=1&tag=&ref=&adgrpid=78287727493&hvpone=&hvptwo=&hvadid=385172604940&hvpos=1o5&hvnetw=g&hvrand=16702995601745525769&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9014228&hvtargid=pla-823507823024 generally, https://www.google.com/search?rlz=1C1CHBF_enUS843US843&biw=1920&bih=975&sxsrf=ACYBGNSHIvwnyBkyd9OPRuYg3iDFSaANlA%3A1571157455562&ei=z_WlXYLHIZHQtAWcwrX4Bg&q=solar+charge+controller+for+lifepo4+battery&oq=solar+charge+controller+for+lifepo4+battery+&gs_l=psy-ab.1.0.0i30.199155.213105..214599...0.2..1.443.10450.1j16j19j9j1......0....1..gws-wiz.......0i71j35i39j0i22i30j35i304i39j0i8i13i30.YH6jrcsDRBs Charlie On 10/15/2019 11:08 AM, Jared Yates wrote:
Date: Oct 15, 2019
My understanding is that the LiFePo batteries have incredibly slow self-di scharge rate. That being the case, is a maintainer charger necessary? Of course is there is current drain via a clock or other drainer the mainta iner may be helpful. Rich -----Original Message----- From: Ernest Christley <echristley(at)att.net> Sent: Tue, Oct 15, 2019 12:18 pm Subject: AeroElectric-List: Maintainer's for LiFePo batteries I'm still looking for a solar powered "maintainer" that will work with a L iFePo battery, and would really like a pointer if someone has found a good solution.=C2- I'm using the Scorpion battery to start my 120Hp Corvair. =C2- I'm VERY happy with how fast and how long it will spin the Corvair w hen it is charged, but I've been asking a lot from this battery due to carb issues that I've been having to work through.=C2- Lots of cranking, with out much engine running to recharge. I bought one of the Harbor Freight, solar maintainers.=C2- I put it on an d left it for a few days.=C2- The battery was completely dead when I came back.=C2- The battery was swollen, but I can't be sure if that was from an overcharge or from excessive exhaust heat.=C2- The solar panel says th at it will put out as much as 18V...if I remember correctly...meaning the p anel had the potential to exceed voltage that the battery is rated for.=C2 - Disassembly of the battery found that two of the "bags" were swollen mu ch larger than the the others. I have since added heat deflectors, and repl aced the battery.=C2- (A future investigation is to see if I can remove t he swollen bags, and make a smaller capacity battery out of the remainder.. .to power LED lights in the gazebo in my backyard...not for airplane use.) Getting a slow, battery-friendly charge to an airplane sitting on a ramp is a PIA.=C2- Charging from a car, with it dumping whatever the alternator will produce or whatever the battery will swallow, works, but is cringe-wor thy.=C2- The 100mA output from the readily-available $20 panels takes a l ong time, but WILL top a battery off eventually (18Ahr/100mA =>180hr @ 9h r/day => 20 days).=C2- I find that acceptable, because my plane tends t o sit idle on the ramp for long periods of time anyway.=C2- During that " top off" time, the solar panels are fine on a LiFePo, because the voltage d rops below the max whenever there is a significant load on it.=C2- It's t hat period after the top off, when the panel reaches its open circuit volta ge and exceeds what the battery can accept that potentially kills the batte ry (again, I don't know this for a fact). So, the question is, "Does anyone know of a solar battery maintainer design ed to service LiFePo batteries?" O ________________________________________________________________________________
Date: Oct 16, 2019
At 03:34 PM 10/15/2019, you wrote: >My understanding is that the LiFePo batteries have incredibly slow >self-discharge rate. That being the case, is a maintainer charger necessary? Yeah, good question. Perhaps you've already mentioned it but what, in your experience, suggests that you need a maintainer on this battery? Bob . . . ________________________________________________________________________________
Date: Oct 15, 2019
On Wed, Oct 16, 2019 at 10:24 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 03:34 PM 10/15/2019, you wrote: > > My understanding is that the LiFePo batteries have incredibly slow > self-discharge rate. That being the case, is a maintainer charger > necessary? > > > Yeah, good question. Perhaps you've already > mentioned it but what, in your experience, > suggests that you need a maintainer on > this battery? > > > Bob . . . > Same question applies to SLAs... Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Oct 16, 2019
1) "Slow discharge" and "No discharge" are not the same thing.=C2- Espec ially when weather extremities are taken into account.2) A topped off batte ry is less of an issue for planes that will kick off within two blades at e very start.=C2- It is more of a concern when you're trying to work throug h carb issues or some other maintenance item the leave you tagged as a "sta rter abuser".3) PM generators have the advantage of being light, simple, an d reliable, but don't generally provide an overabundance of excess charge c urrent.=C2- Have that PM generator driven inline (it spins at engine RPM) , and you have more trouble.=C2- Combine these two with number 2, and you have a frustrating pain in the rear that has you inventing new words on Su nday mornings at the airport when you should've been in church anyhow. I wrote: At 03:34 PM 10/15/2019, you wrote: Myunderstanding is that the LiFePo batteries have incredibly slowself-disch arge rate. That being the case, is a maintainer chargernecessary? =C2- Yeah, good question. Perhaps you've already =C2- mentioned it but what, in your experience, =C2- suggests that you need a maintainer on =C2- this battery? =C2- Bob . . . ________________________________________________________________________________
Subject: food machinery
Date: Oct 19, 2019
What is food machinery ? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491869#491869 ________________________________________________________________________________
Date: Oct 19, 2019
Subject: Soldering to a Solid Wire
I replaced my mechanical tach with a digital one last week and needed to connect some very small wires that came with the new tach to a couple resistors. Decided to solder rather than crimp because of how small the wires are. It was only halfway through that I realized I should have asked around to see if there is a proper way of doing this. I didn't find anything in the AEC or 43-13. Is this good? [image: IMG_20191004_105557.jpg] ________________________________________________________________________________
Subject: Re: Soldering to a Solid Wire
Date: Oct 19, 2019
If youre looking for published standards, you could look at section 19 of this document: https://standards.nasa.gov/standard/nasa/nasa-std-87394 Its title is "WORKMANSHIP STANDARD FOR CRIMPING, INTERCONNECTING CABLES, HARNESSES, AND WIRING" On Oct 19, 2019, at 12:52 PM, Sebastien wrote: I replaced my mechanical tach with a digital one last week and needed to connect some very small wires that came with the new tach to a couple resistors. Decided to solder rather than crimp because of how small the wires are. It was only halfway through that I realized I should have asked around to see if there is a proper way of doing this. I didn't find anything in the AEC or 43-13. Is this good? ________________________________________________________________________________
Date: Oct 19, 2019
On 10/19/2019 11:52 AM, Sebastien wrote: > I replaced my mechanical tach with a digital one last week and needed > to connect some very small wires that came with the new tach to a > couple resistors. Decided to solder rather than crimp because of how > small the wires are. It was only halfway through that I realized I > should have asked around to see if there is a proper way of doing > this. I didn't find anything in the AEC or 43-13. > > Is this good? > > IMG_20191004_105557.jpg The joints look fine. I'd only suggest that you can get by with a lot less bare wire. Multiple ways to do it; twisting like you did (but over maybe 1/4-1/2 inch), or by bending a couple of tiny 'fish hooks', linking them, and then crimping them slightly to stabilize them while you solder. Most texts make a big deal of making a strong mechanical joint and just using solder to make the electrical connection, but reality is that if you can keep the two wires stable while you solder, you can just have them touching and overlapping over a 1/4-3/8" length, the resulting joint would likely survive pulling the resistor apart, pulling on its other lead. Making a mechanically strong joint does more for creating a high quality soldering operation (especially for novice 'iron workers') than for joint strength. Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 19, 2019
Bob's Shop Notes: Soldered Lap Splicing of Wires http://www.aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html Some Bob photos at http://www.aeroelectric.com/articles/In_Line_Resistor/ -------- John Bright, RV-6A 25088, at FWF O-360, 8.5:1, vert sump, dual SDSEFI EM-5-F Z-14 modified for EFI Newport News, Va Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491873#491873 ________________________________________________________________________________
Date: Oct 19, 2019
Sebastien, That looks pretty darned sturdy to me! I think that the resistor will disintegrate long before the joint does. I would have done something much shorter, adapting this technique: http://www.aeroelectric.com/articles/PM_Solder_Sleeve/PM_Solder_Sleeve.html Cheers, -- Art Z. On Sat, Oct 19, 2019 at 12:39 PM Sebastien wrote: > I replaced my mechanical tach with a digital one last week and needed to > connect some very small wires that came with the new tach to a couple > resistors. Decided to solder rather than crimp because of how small the > wires are. It was only halfway through that I realized I should have asked > around to see if there is a proper way of doing this. I didn't find > anything in the AEC or 43-13. > > Is this good? > > [image: IMG_20191004_105557.jpg] > -- https://CheerfulCurmudgeon.com/ *Love the stranger for you yourselves were strangers in Egypt. *Deut. 10:19 ________________________________________________________________________________
Date: Oct 20, 2019
Soldering looks more than fine, but focus should be on mechanical robustness under vibration: 1. make the stiff section as short as possible 2. flexible multistrand wire on either side of this 3. cover with multiple layers of heat shrink. See also: http://www.aeroelectric.com/articles/In_Line_Resistor/ On 19-10-2019 23:59, Art Zemon wrote: > Sebastien, > > That looks pretty darned sturdy to me! I think that the resistor will > disintegrate long before the joint does. > > I would have done something much shorter, adapting this technique: > http://www.aeroelectric.com/articles/PM_Solder_Sleeve/PM_Solder_Sleeve.html > > Cheers, > -- Art Z. > > > On Sat, Oct 19, 2019 at 12:39 PM Sebastien > wrote: > > I replaced my mechanical tach with a digital one last week and > needed to connect some very small wires that came with the new > tach to a couple resistors. Decided to solder rather than crimp > because of how small the wires are. It was only halfway through > that I realized I should have asked around to see if there is a > proper way of doing this. I didn't find anything in the AEC or 43-13. > > Is this good? > > IMG_20191004_105557.jpg > > > -- > https://CheerfulCurmudgeon.com/ > > /Love the stranger for you yourselves were strangers in Egypt. /Deut. > 10:19 ________________________________________________________________________________
Date: Oct 19, 2019
Thanks Art and Alec. I really like that pm solder sleeve idea, looks great and would have worked well here. I'll try it next time. After all, solder costs money. On Sat, Oct 19, 2019 at 3:13 PM Art Zemon wrote: > Sebastien, > > That looks pretty darned sturdy to me! I think that the resistor will > disintegrate long before the joint does. > > I would have done something much shorter, adapting this technique: > http://www.aeroelectric.com/articles/PM_Solder_Sleeve/PM_Solder_Sleeve.html > > Cheers, > -- Art Z. > > > On Sat, Oct 19, 2019 at 12:39 PM Sebastien wrote: > >> I replaced my mechanical tach with a digital one last week and needed to >> connect some very small wires that came with the new tach to a couple >> resistors. Decided to solder rather than crimp because of how small the >> wires are. It was only halfway through that I realized I should have asked >> around to see if there is a proper way of doing this. I didn't find >> anything in the AEC or 43-13. >> >> Is this good? >> >> [image: IMG_20191004_105557.jpg] >> > > > -- > https://CheerfulCurmudgeon.com/ > > *Love the stranger for you yourselves were strangers in Egypt. *Deut. > 10:19 > ________________________________________________________________________________
Subject: Desulfinating trickle charger with Garmin avionics
Date: Oct 20, 2019
I use an Odyssey battery charger for my PC680 to maintain the battery. Occasionally I turn on the Garmin avionics while the charger is connected. I recently heard that the desulfurization circuitry is bad for an internal fuse in the avionics. Does anyone know about this? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491877#491877 ________________________________________________________________________________
Date: Oct 20, 2019
Subject: Re: food machinery
At 07:11 AM 10/19/2019, you wrote: > >What is food machinery ? spam . . . ignore Bob . . . ________________________________________________________________________________
Date: Oct 20, 2019
At 11:52 AM 10/19/2019, you wrote: >I replaced my mechanical tach with a digital one last week and >needed to connect some very small wires that came with the new tach >to a couple resistors. Decided to solder rather than crimp because >of how small the wires are. It was only halfway through that I >realized I should have asked around to see if there is a proper way >of doing this. I didn't find anything in the AEC or 43-13. > >Is this good? I would cover the resistors and their exposed lead wires with heat shrink before crimping the terminals on. Bob . . . ________________________________________________________________________________
Date: Oct 20, 2019
Well yes, but only if you think of it before crimping the terminal on :). Fortunately I have heatshrink that's just the right size to fit over those terminals. I wish I had used clear heatshrink though so I could see what it looked like once everything was bent and attached in position. Sure is nice not having that clunky tach drive going from the engine to the panel anymore. On Sun, Oct 20, 2019, 09:47 Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 11:52 AM 10/19/2019, you wrote: > > I replaced my mechanical tach with a digital one last week and needed to > connect some very small wires that came with the new tach to a couple > resistors. Decided to solder rather than crimp because of how small the > wires are. It was only halfway through that I realized I should have asked > around to see if there is a proper way of doing this. I didn't find > anything in the AEC or 43-13. > > Is this good? > > > I would cover the resistors and their > exposed lead wires with heat shrink > before crimping the terminals on. > > > Bob . . . > ________________________________________________________________________________
Date: Oct 20, 2019
Subject: Re: Desulfinating trickle charger with Garmin avionics
Sent from my iPhone > On Oct 20, 2019, at 7:31 AM, whodja wrote: > > > I use an Odyssey battery charger for my PC680 to maintain the battery. Occasionally I turn on the Garmin avionics while the charger is connected. I recently heard that the desulfurization circuitry is bad for an internal fuse in the avionics. Does anyone know about this? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=491877#491877 > > > > > > > > > ________________________________________________________________________________
Date: Oct 20, 2019
Most desulfurization circuits send an occasional high voltage spike down the charger leads. This only lasts for a few milliseconds. However, the high voltage spike could lead to a couple of milliseconds of high current. This should not damage most fuse/circuit breakers, however, there might be some out there that could be damaged. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of whodja Sent: Sunday, October 20, 2019 6:32 AM Subject: AeroElectric-List: Desulfinating trickle charger with Garmin avionics I use an Odyssey battery charger for my PC680 to maintain the battery. Occasionally I turn on the Garmin avionics while the charger is connected. I recently heard that the desulfurization circuitry is bad for an internal fuse in the avionics. Does anyone know about this? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491877#491877 ________________________________________________________________________________
Date: Oct 20, 2019
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
The high voltage spike to desulfurize doesn't have to produce high current to damage something.=C2- Transistors, for example are two conductors sand wiching an insulator that is modulated by a control voltage to control the current between the two conductors.=C2- If a high voltage spike comes in on the power supply, it leads to one of the conductors and can cause punch through, meaning that it can chip away at it until only a percentage of it left.=C2- That causes the transistor to no function according to its spec ifications and can lead to either a complete failure or partial failure.=C2 - It is these partial failures that cause anomalies in circuits that are hard to troubleshoot. Think of these two conductors and the sandwiched insulator as a PNP or NPN. =C2- Even a diode can get chipped away or totally blown away.=C2- Capac itors also have dielectrics that can be damaged.=C2- There are all sorts of anomaly producers in a typical circuit board. This is one reason why I don't really like the fancy battery chargers.=C2 - I'd rather keep my batteries topped off frequently to avoid sulfurizati on.=C2- And of course I don't have that problem in my vehicles, because t hat dumb regulator does a great job of topping off the battery that never r eally goes below 90%. Henador Titzoff unner.com> wrote: com> Most desulfurization circuits send an occasional high voltage spike down th e charger leads.=C2- This only lasts for a few milliseconds.=C2- However, the high voltage spike could lead to a couple of milliseconds of high current.=C2- This should not damage most fuse/circuit breakers, however, there might be some out there that could be damaged. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of whodja Sent: Sunday, October 20, 2019 6:32 AM Subject: AeroElectric-List: Desulfinating trickle charger with Garmin avionics I use an Odyssey battery charger for my PC680 to maintain the battery. Occasionally I turn on the Garmin avionics while the charger is connected. I recently heard that the desulfurization circuitry is bad for an internal fuse in the avionics. Does anyone know about this? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491877#491877 - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Pmag diode
Date: Oct 20, 2019
Whats a good way to attach a diode to the Pmag connector? The diode has small solid wires that go to screw down sockets #1 and 6 that also get one 18-20 ga stranded wire in each socket . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491886#491886 Attachments: http://forums.matronics.com//files/285ba7c0_e9c5_4c33_8d79_79b2a09170fd_149.png http://forums.matronics.com//files/6f8614c3_9404_46e5_860f_dcd028abed24_119.png ________________________________________________________________________________
Date: Oct 20, 2019
At 12:05 PM 10/20/2019, you wrote: > >Most desulfurization circuits send an occasional high voltage spike down the >charger leads. This only lasts for a few milliseconds. However, the high >voltage spike could lead to a couple of milliseconds of high current. This >should not damage most fuse/circuit breakers, however, there might be some >out there that could be damaged. There are no known techniques for 'breaking up' hard sulfate crystals or recovering a battery that has succumbed to inevitable end-of-life conditions whether by accident, poor maintenance or time in service. Claims to the contrary describe a constellation of electrical stimuli with carefully defined physics. The problem is that every patented desulfation technique has some feature that sets it apart from all others else it could not be patented. I've likened searches for the ultimate desulfation device to be as productive as walking into a health supplements store with 10,000 products seeking the ultimate mitigation of your particular discomfort. The proprietor cannot tell you that any one thing or combination of things will "fix you right up". That would be practicing medicine. What they can do is point you to a book about the size of a NY phone book that offers a one-stop source for claims proffered by every product on their shelves, "here, check it out . . . we got them all!" I've done a site search on 'sulfate' for https://batteryuniversity.com/search/search&keywords=sulfate/P10 Here we are offered 14 articles (out of hundreds on the site) that speak to lead sulfate. There is one article . . . https://batteryuniversity.com/learn/article/additives that speaks to chemical additives that may recover some battery performance . . . but it only works on flooded batteries and is of limited benefit . . . for our purposes it would not make an un-airworthy battery flyable. There are NO articles that speak to recovering significant capacity in a battery that has suffered an infestation of hard lead-sulfate crystals. The ENERGY produced by so-called desulfation pulses is tiny. They pose no risk to any hardware on the airplane that might still be connected to a battery that you're trying to recover with the magic battery charger. By the way, after a series of discharge/ recharge tests with sequential cap-checks on a Battery Minder Plus followed by a 4 month maintenance interval, I find ZERO improvement in battery performance. In fact, the test article's 9-volt/15-second load test value DROPPED from 150A down to 60A. I would not have expected jaw dropping recovery . . . but some degree of improvement would have been tentatively validating of the manufacturer's claims. After more than a decade of observation of and association with the lead-acid battery market, I'm calling the whole desulfation thingy 'snake oil'. If anyone discovers a product backed up with a report of laboratory/field controlled experiments that demonstrate the product's efficacy, I'll be most pleased to eat my words. Bob . . . ________________________________________________________________________________
Date: Oct 20, 2019
Subject: Re: Pmag diode
At 04:17 PM 10/20/2019, you wrote: > >What=99s a good way to attach a diode to the >Pmag connector? The diode has small solid wires >that go to screw down sockets #1 and 6 that also >get one 18-20 ga stranded wire in each socket . Does your tach REQUIRE this diode? Bob . . . ________________________________________________________________________________
Date: Oct 21, 2019
I too have read many articles that both applaud and disprove the desulfurization theory. What I "more or less" believe is the results that many tell about where they get 6 or 7 years from batteries well maintained with with BATTERY MINDER maintainers. In my 50 years of dealing with batteries, I get about 3 or 4 years from flooded batteries and sealed batteries, but I have gotten 5 to 6 with the BATTERY MINDERS. However, I totally agree my experience does not have documented scientific recorded results and maintenance notes to back it up. Overall, I think the BATTERY MINDERS do offer some increased longevity, but I certainly have no proof, just an opinion. Battery chemistry is changing fairly rapidly these days and I am a big fan of Lithium batteries, and I am a real believer that they will smoke and burn if not maintained properly. Boeing has proved that even the best Lithium battery maintenance and equipment cannot guarantee that there will be no smoke and fire. Personally I will not be using a lithium battery in an airplane that I will ride in. The weight and high current capability are very tempting, but not tempting enough for me. .m: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Robert L. Nuckolls, III Sent: Sunday, October 20, 2019 5:02 PM Subject: RE: AeroElectric-List: Desulfinating trickle charger with Garmin avionics At 12:05 PM 10/20/2019, you wrote: > Most desulfurization circuits send an occasional high voltage spike down the charger leads. This only lasts for a few milliseconds. However, the high voltage spike could lead to a couple of milliseconds of high current. This should not damage most fuse/circuit breakers, however, there might be some out there that could be damaged. There are no known techniques for 'breaking up' hard sulfate crystals or recovering a battery that has succumbed to inevitable end-of-life conditions whether by accident, poor maintenance or time in service. Claims to the contrary describe a constellation of electrical stimuli with carefully defined physics. The problem is that every patented desulfation technique has some feature that sets it apart from all others else it could not be patented. I've likened searches for the ultimate desulfation device to be as productive as walking into a health supplements store with 10,000 products seeking the ultimate mitigation of your particular discomfort. The proprietor cannot tell you that any one thing or combination of things will "fix you right up". That would be practicing medicine. What they can do is point you to a book about the size of a NY phone book that offers a one-stop source for claims proffered by every product on their shelves, "here, check it out . . . we got them all!" I've done a site search on 'sulfate' for https://batteryuniversity.com/search/search &keywords=sulfate/P10 Here we are offered 14 articles (out of hundreds on the site) that speak to lead sulfate. There is one article . . . https://batteryuniversity.com/learn/article/additives that speaks to chemical additives that may recover some battery performance . . . but it only works on flooded batteries and is of limited benefit . . . for our purposes it would not make an un-airworthy battery flyable. There are NO articles that speak to recovering significant capacity in a battery that has suffered an infestation of hard lead-sulfate crystals. The ENERGY produced by so-called desulfation pulses is tiny. They pose no risk to any hardware on the airplane that might still be connected to a battery that you're trying to recover with the magic battery charger. By the way, after a series of discharge/ recharge tests with sequential cap-checks on a Battery Minder Plus followed by a 4 month maintenance interval, I find ZERO improvement in battery performance. In fact, the test article's 9-volt/15-second load test value DROPPED from 150A down to 60A. I would not have expected jaw dropping recovery . . . but some degree of improvement would have been tentatively validating of the manufacturer's claims. After more than a decade of observation of and association with the lead-acid battery market, I'm calling the whole desulfation thingy 'snake oil'. If anyone discovers a product backed up with a report of laboratory/field controlled experiments that demonstrate the product's efficacy, I'll be most pleased to eat my words. Bob . . . ________________________________________________________________________________
Date: Oct 21, 2019
A dab of E6000 between the diode and other wires will prevent vibration. Another option is to mount the diode at the tach end of wire number 6. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491891#491891 ________________________________________________________________________________
Subject: =?ISO-8859-1?Q?=D8=B4=D8=B1=D9=83=D8=A9?= =?ISO-8859-1?Q?=D8=D9=86=D8=B8=D9=8A=D9=81?=
=?ISO-8859-1?Q?=D9=85=D9=86=D8=A7=D8=B2=D9=84?= =?ISO-8859-1?Q?=D8=B4=D8=B1=D9=83=D8=A9?= =?ISO-8859-1?Q?=D8=B1=D9=83=D9=86?= =?ISO-8859-1?Q?=D8=A7=D9=84=D8=A3=D9=85=D8=A7=D9=86=D8?
Date: Oct 21, 2019
. (https://roknalamanh.com/cheap-house-cleaning-company-in-najran/) : ... 100% .... : (https://roknalamanh.com/cleaning-company-houses-in-abha/) (https://roknalamanh.com/house-cleaning-company-khamis-mushait/) - . - . - . - . - . - . - . - (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d9%86%d8%a7%d8%b2%d9%84-%d8%a8%d8%ac%d8%a7%d8%b2%d8%a7%d9%86/) .. . (https://roknalamanh.com/%d8%a7%d9%81%d8%b6%d9%84-%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d9%86%d8%a7%d8%b2%d9%84-%d8%a8%d9%86%d8%ac%d8%b1%d8%a7%d9%86/) . (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%a8%d9%85%d8%ad%d8%a7%d9%8a%d9%84-%d8%b9%d8%b3%d9%8a%d8%b1/) . . (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d9%86%d8%a7%d8%b2%d9%84-%d8%a8%d9%85%d8%ad%d8%a7%d9%8a%d9%84-%d8%b9%d8%b3%d9%8a%d8%b1/) : : - . - . - . . (https://roknalamanh.com/apartment-cleaning-company-in-jizan/) (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%a8%d8%b3%d9%83%d8%a7%d9%83%d8%a7/ ) - - (https://roknalamanh.com/) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491893#491893 ________________________________________________________________________________
Subject: =?ISO-8859-1?Q?=D8=B4=D8=B1=D9=83=D8=A9?= =?ISO-8859-1?Q?=D9=85=D9=83=D8=A7=D9=81=D8=AD=D8=A9?=
=?ISO-8859-1?Q?=D8=AD=D8=B4=D8=B1=D8=A7=D8?= =?ISO-8859-1?Q?=D8=B1=D9=83=D9=86?= =?ISO-8859-1?Q?=D8=A7=D9=84=D8=A3=D9=85=D8=A7=D9=86=D8=A9?
Date: Oct 21, 2019
. (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%ae%d9%85%d9%8a%d8%b3-%d9%85%d8%b4%d9%8a%d8%b7/) (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%b3%d9%83%d8%a7%d9%83%d8%a7/) (https://roknalamanh.com/cheapest-pesticide-company-in-jizan/) (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%a7%d8%a8%d9%87%d8%a7/) . - . . (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%a7%d8%a8%d9%88-%d8%b9%d8%b1%d9%8a%d8%b4/) - . - . - . . (https://roknalamanh.com/%d8%a7%d9%81%d8%b6%d9%84-%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%ac%d8%a7%d8%b2%d8%a7%d9%86/) . . : - . - . - . - . . (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d9%85%d8%ad%d8%a7%d9%8a%d9%84-%d8%b9%d8%b3%d9%8a%d8%b1/) (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d9%86%d8%ac%d8%b1%d8%a7%d9%86/) ...... : (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%a8%d9%8a%d8%b4%d9%87/) - . - . - . - . - (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%b5%d8%a7%d9%85%d8%b7%d8%a9/) - (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%b5%d8%a8%d9%8a%d8%a7/) . (https://roknalamanh.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%ac%d8%a7%d8%b2%d8%a7%d9%86/) : - . - . - . (https://roknalamanh.com/) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491894#491894 ________________________________________________________________________________
Date: Oct 22, 2019
At 08:51 AM 10/21/2019, you wrote: > >A dab of E6000 between the diode and other wires will prevent vibration. I think 'the rub' comes from placing two wires of differing qualities under the same screw-n-mash terminal. The smaller wire may not be adequately supported. >Another option is to mount the diode at the tach end of wire number 6. Or in-line with a technique like this: Emacs! But more importantly, that diode (actually a zener) may not be necessary. Quoting from EmagAir's installation data Emacs! Adding the suggested diode depends on the tachometer being incapable of working with the stock, 12v tach signal emitted by the eMag. Adding the diode clamps the 12v signal down to 5v for such cases. Do the Tachometer instructions specifically state that the input signal cannot exceed 5V? Bob . . . ________________________________________________________________________________
Date: Oct 22, 2019
Subject: Desulfators and Lithium
At 01:33 AM 10/21/2019, you wrote: >I too have read many articles that both applaud and disprove the >desulfurization theory. What I "more or less" believe is the >results that many tell about where they get 6 or 7 years from >batteries well maintained with with BATTERY MINDER maintainers. Yup, been using the wall-wart BM and BT maintainers for decades enjoying very good service lives on a constellation of laboratory/test batteries. But those were batteries that lived in a house and were called upon perhaps a dozen hours/year or to jump start a vehicle. >In my 50 years of dealing with batteries, I get about 3 or 4 years >from flooded batteries and sealed >batteries, but I have gotten 5 to 6 with the BATTERY MINDERS. These are maintainers used routinely on often used batteries? >However, I totally agree my experience does not have documented >scientific recorded results and maintenance notes to back it >up. Overall, I think the BATTERY MINDERS do offer some increased >longevity, but I certainly have no proof, just an opinion. There's no contrary argument for the century plus old philosophy for holding a battery at or just above it's nominal open circuit voltage while at-rest. It's never a bad thing and often an essential thing to do for any battery that demonstrates a significant self-discharge characteristic. The external maintainer storage philosophy is endorsed by virtually every battery manufacturer . . . a few of which even offer their own 'flavor' of maintainer . . . which differs in no significant way from other maintainers. The question before us goes to whether or not we have both a justification in the physics of battery operations and a demonstration in experience that says a battery suffering loss of capacity due to sulfation can be recovered by some external means that reverses the condition. >Battery chemistry is changing fairly rapidly these days and I am >a big fan of Lithium batteries, and I am a real believer that >they will smoke and burn if not maintained properly. As will severely abused svla and ni-cad batteries . . . > >Boeing has proved that even the best Lithium battery maintenance and >equipment cannot guarantee that there will be no smoke and fire. The Boeing experience has little relevancy to the OBAM aviation experience with lithium technology. >Personally I will not be using a lithium battery in an airplane that >I will ride in. The weight and high current capability are very >tempting, but not tempting enough for me. The TSO for an airworthy lithium product calls for a demonstration of ability to contain the worst possible failure mode without endangering either aluminum or bones. I witnessed some of the extreme faults testing conducted on True Blue products at Cessna. https://tinyurl.com/yywq4tw9 https://tinyurl.com/yy4yva7f The enclosures are vented overboard and testing demonstrated that enclosure surface temps under worst case failures are benign. Boeing has, no doubt, incorporated similar capability in their aircraft. The Boeing experience is an outlier . . . the procurement specification for their problem child battery was finalize as much as a decade before the battery fire events. A great deal was learned about lithium battery technology in the interval from Boeing's award of contract to the time of the fires. With time-honored, 20/20 hind-sight, I'm sure there are folks at Boeing who wished for better information that would have gone to better decisions. To my knowledge, no lithium offerings to OBAM aviation have adopted such practices. But the probability of serious battery fires with LiFePO4 cells is exceedingly low. Of ALL the Li chemistries, LiFePO4 is the most robust and least reactive to catastrophic degradation. Risks for flying with a thoughtfully integrated lithium product are falling rapidly . . . having said that . . . I'm still wrestling with the question of economics for having replaced SLVA with lithium in a light aircraft. When you take six pounds out of your ship's empty weight, do the fuel tanks get one-gallon larger? Can you now fly over terrain at altitudes previously unsurmountable? Are you now able to depart runways previously too short? Is there value in being able to put 6# more 'stuff' in the baggage compartment? Yeah, light is always good in airplanes, even better in helicopters. But for Joe R.V. Driver, does the cost-of-ownership for installing a top of the line lithium project have a positive return? Given what I've learned and observed so far, I can deduce no positive return on investment for having swapped lithium for SVLA. If somebody has happier numbers to share I'd be pleased to know them. Bob . . . ________________________________________________________________________________
Subject: Re: Desulfators and Lithium
Date: Oct 22, 2019
snipped > Given what I've learned and observed so far, > I can deduce */no positive return/* on investment > for having swapped lithium for SVLA. If somebody > has happier numbers to share I'd be pleased > to know them. > > Bob . . . > I agree that there's no practical justification for lithium at this point. But the one *potential* method to justify it would be an electrically dependent engine, specifically electronic fuel injection, that requires significant current to operate, *and* the decision by the builder to keep his electrical system a simple 1 alt, 1 battery system. In that case, it would be possible to 'upsize' the battery to significantly higher capacity and longer run-time with no gain in weight or size (at considerable expense). Not the path I chose, but I do see it as a potential option. Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 22, 2019
In my case, it wasn't just the #6 saved from the battery switch, but the o ther #6 that I had to put in the opposite end of the plane to balance the b attery. The best decision technique I've found for deciding when to spend more for a product is to set a price for how much you're willing to pay to save a po und.=C2- For me, it is $30.=C2- All else being equal, if two products a re identical, I'm will to pay $30 to save a pound. A typical SVLA is somewhere around $100 (IIRC).=C2- A LiFePo can be had f or less than $200 (SSTZ14S-FP Scorpion Stinger 12v 387 CCA LiFePo4 Extreme High Output Battery).=C2- That is about half of *my* cost-to-weight thres hold for the battery alone, and 1/4 the threshold once the balance weight i s added. And, yes, these sort of modifications can enable more gas in the tank.=C2 - I say that as someone that has had to leave gas on the ground to stay u nder recommended gross.=C2- While just this one mod would only add one ga llon, the weight savings are additive. | | | | $178.00 | | | | | | | SSTZ14S-FP Scorpion Stinger 12v 387 CCA LiFePo4 Extreme High Output Battery In order to ship Priority IATA imposed new Shipping Regulations regarding L ithium Batteries. Lithium Batteries b... | | | wrote: =C2- I'm still wrestling with the question of =C2- economics for having replaced SLVA with =C2- lithium in a light aircraft. When you =C2- take six pounds out of your ship's empty =C2- weight, do the fuel tanks get one-gallon =C2- larger? Can you now fly over terrain =C2- at altitudes previously unsurmountable? =C2- Are you now able to depart runways previously =C2- too short? Is there value in being able =C2- to put 6# more 'stuff' in the baggage =C2- compartment? =C2- Yeah, light is always good in airplanes, =C2- even better in helicopters. But for =C2- Joe R.V. Driver, does the cost-of-ownership =C2- for installing a top of the line =C2- lithium project have a positive return? =C2- =C2- Given what I've learned and observed so far, =C2- I can deduce no positive return on investment =C2- for having swapped lithium for SVLA. If somebody =C2- has happier numbers to share I'd be pleased =C2- to know them. =C2- Bob . . . ________________________________________________________________________________
Date: Oct 22, 2019
Hi Folks; Let's be honest, buying anything that deteriorates (such as a car or a battery) never has a "positive return." It's a cost, not an investment. Concerning LiFePO4 batteries, mine has behaved flawlessly, so far. It stays "topped up" with the maintainer intended for it. (Don't use desulfinator-type chargers.) It weighs 3-1/2 pounds and has surprising power to rapidly turn over and start a 100 HP engine. So far it hasn't burned up anything; hasn't even gotten warm. It remains to be seen how long this battery will last, but "so far so good." Cheers! Stu. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Tuesday, October 22, 2019 10:08:53 AM Subject: Re: AeroElectric-List: Desulfators and Lithium snipped Given what I've learned and observed so far, I can deduce no positive return on investment for having swapped lithium for SVLA. If somebody has happier numbers to share I'd be pleased to know them. Bob . . . I agree that there's no practical justification for lithium at this point. But the one *potential* method to justify it would be an electrically dependent engine, specifically electronic fuel injection, that requires significant current to operate, *and* the decision by the builder to keep his electrical system a simple 1 alt, 1 battery system. In that case, it would be possible to 'upsize' the battery to significantly higher capacity and longer run-time with no gain in weight or size (at considerable expense). Not the path I chose, but I do see it as a potential option. Charlie Virus-free. www.avast.com ________________________________________________________________________________
Date: Oct 22, 2019
I'd like to address this point Bob > I'm still wrestling with the question of > economics for having replaced SLVA with > lithium in a light aircraft. When you > take six pounds out of your ship's empty > weight, do the fuel tanks get one-gallon > larger? Can you now fly over terrain > at altitudes previously unsurmountable? > Are you now able to depart runways previously > too short? Is there value in being able > to put 6# more 'stuff' in the baggage > compartment? About 30% of my flights are at maximum takeoff weight. When at maximum takeoff weight, the fuel tanks are almost never full. So in practice, yes the fuel tanks get one gallon larger in than I can actually carry one more gallon of fuel. While the maximum terrain and available airports remain the same, the wear and tear on the aircraft is slightly reduced by the shorter takeoff and landing distance and the reduced time to climb. The fuel burn itself is reduced by a very small but very real amount. If an aircraft flies 100 hours a year and a lighter battery is $200 more and lasts 6 years, at 15 gal / hour and $5 / gallon the battery pays for itself if it saves 0.4% fuel burn. If it's also saving $5 a year on tires and $5 a year on brakes (I made that up), you now only need a 0.3% improvement in mpg to completely pay for the battery. I doubt the math actually adds up to pay for the battery, but it does reduce the actual cost for airplanes that fly rather than sit in a hangar. As for the value of 6# more stuff in an RV, I fly a couple of well equipped RVs that have a useful load of 40 pounds with 3 hours of fuel (plus reserve) and 2 adults. 6 pounds would be a 15% increase in baggage capacity and very welcome. On the other hand, my friend's super rebel has the battery on the firewall and any decrease in weight up front decreases the useful baggage load. So it all depends on the aircraft I guess. On Tue, Oct 22, 2019 at 10:22 AM Charlie England wrote: > snipped > > Given what I've learned and observed so far, > I can deduce *no positive return* on investment > for having swapped lithium for SVLA. If somebody > has happier numbers to share I'd be pleased > to know them. > > Bob . . . > > I agree that there's no practical justification for lithium at this point. > > But the one *potential* method to justify it would be an electrically > dependent engine, specifically electronic fuel injection, that requires > significant current to operate, *and* the decision by the builder to keep > his electrical system a simple 1 alt, 1 battery system. In that case, it > would be possible to 'upsize' the battery to significantly higher capacity > and longer run-time with no gain in weight or size (at considerable > expense). > > Not the path I chose, but I do see it as a potential option. > > Charlie > > > Virus-free. > www.avast.com > > <#m_-4445247911684786102_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Subject: GPS antenna removal
Date: Oct 22, 2019
I would like to remove the GPS antenna on my airplane. The antenna is shown in the attached picture. The antenna appears to be strongly bound to an aluminum support plate. There are no screws between the bottom of the antenna and the plate that would not be visible in the picture. I removed the 4 screws located at the corners of the plate, hoping that the antenna/support plate assembly would come off the underneath support saddle as a unit, but they are not coming off. The plate is also firmly bound to the saddle. Any suggestions on how to remove this antenna? My preference would be to disconnect the antenna from the plate, but also disconnecting the assembly antenna/plate from the saddle would be acceptable, as long as the saddle under the plate stays in place on the airplane and all the components are not damaged and can be re-used. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491924#491924 Attachments: http://forums.matronics.com//files/gps_antenna_garmin_ga_56_removal_123.pdf ________________________________________________________________________________
Subject: Re: GPS antenna removal
Date: Oct 22, 2019
On 10/22/2019 9:58 PM, Argonaut36 wrote: > > I would like to remove the GPS antenna on my airplane. The antenna is shown in the attached picture. > The antenna appears to be strongly bound to an aluminum support plate. There are no screws between the bottom of the antenna and the plate that would not be visible in the picture. > I removed the 4 screws located at the corners of the plate, hoping that the antenna/support plate assembly would come off the underneath support saddle as a unit, but they are not coming off. The plate is also firmly bound to the saddle. > Any suggestions on how to remove this antenna? My preference would be to disconnect the antenna from the plate, but also disconnecting the assembly antenna/plate from the saddle would be acceptable, as long as the saddle under the plate stays in place on the airplane and all the components are not damaged and can be re-used. > Thanks A jpg attachment would have been simpler to see. :-) The pic makes it look like it's on fabric; what's it attached to? If it's on the outer skin, there's likely sealant between the puck & the plate, and between the plate and the skin. My bet is that there are countersunk screws coming up through the bottom of the plate into the puck. I'd try a plastic blade gently around the edges of the plate-skin interface, to see if it'll peel up. Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 22, 2019
The antenna is attached to the turtle deck that is made of aluminum plate and is covered with fabric, as you pointed out. A saddle, that does not appear to be made of metal, is attached to the turtle deck and provides a flat surface for the installation of a metal plate. This plate is attached with 4 screws with 4 screws and some sort of glue to the saddle. The antenna seems to be attached just with glue to the plate, but it is possible that there are also short screws (that don't go past the saddle inside the turtle) deck, connecting the antenna to the metal plate. As stated in my initial post, I would like to leave the saddle on the airplane, because I intend to install a different GPS antenna. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491928#491928 Attachments: http://forums.matronics.com//files/gps_antenna_garmin_ga_56_removal_211.jpg ________________________________________________________________________________
Date: Oct 23, 2019
What GPS antenna will go with, Argonaut36? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491930#491930 ________________________________________________________________________________
Date: Oct 23, 2019
The new antenna will be a Garmin GA 35 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491932#491932 ________________________________________________________________________________
Date: Oct 23, 2019
Bob and all, After reading the manual on the GRT EIS I conclude that the tach signal should be 12 volts as you surmised. Should have read that first, but then I wouldnt have seen the clever way you installed a diode in-line. That was worth the post. Never in a million years would I have come up with that on my own. The clip from Emagair that you posted points to other issues and the reason for a separate thread. And that is how to configure and connect the EIS and the Pmag for the tach signal. Because the EIS looks for one tach signal per revolution and the Pmag generates two tach signals per revolution, one systems configuration will need to be changed. They are both reconfigurable but I dont know which would be better/easier. Also confusing is that Pmags note #1 says to collect the tach signal from only one Pmag unless your system has provision for two separate inputs. The GRT EIS has only one tach input but two magnetos can be connected to it. Where do you hook up a second Pmag to a GRT EIS if the instructions to connect are in conflict? If magneto #1 is working the EIS will read that signal but if magneto #1 is disabled (as during a mag check), the EIS will read the tach signal of magneto #2. Pmag note #2 states that a disbabled Pmag will still generate a tach signal so you wont lose tach during a mag check. Huh? If a disabled Pmag is generating a signal, how do you not see it? What am I missing? Thanks, Eric Schlanser Tailwind W-10 with dual Pmags Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491933#491933 ________________________________________________________________________________
Date: Oct 23, 2019
At 08:24 AM 10/23/2019, you wrote: > >The new antenna will be a Garmin GA 35 Any chance the old antenna will work just fine with the new radio? Active GPS antennas tend to be rather generic and interchangeable across a broad spectrum of devices that utilize antennas on the far end of a piece of coax. Bob . . . ________________________________________________________________________________
Date: Oct 23, 2019
Thanks, Bob. The new antenna is for the Garmin GDL 82 (ADS-B). I had asked Garmin if my existing antenna would work before purchasing the GDL-82 and they replied that the new GA 35 antenna was absolutely required. Also, apart from the technical aspects, the GA 35 is the antenna listed in the GDL 82 STC with which I need to comply. All this is very unfortunate. This morning I found out that the new antenna is slightly larger than the old one and I will likely need to replace also the saddle that is glued to the airplane. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491935#491935 ________________________________________________________________________________
Date: Oct 23, 2019
> The GRT EIS has only one tach input but two magnetos can be connected to it. > Correction to above: The GRT EIS does have two tachometer connections. > Where do you hook up a second Pmag to a GRT EIS if the instructions to connect are in conflict? I guess Ill need to get help from GRT and Emagair to understand how the connections are to be used since each Pmag will be generating a signal even when disabled. Eric S. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=491936#491936 ________________________________________________________________________________
Date: Oct 23, 2019
At 01:22 PM 10/23/2019, you wrote: > > > > The GRT EIS has only one tach input but two > magnetos can be connected to it. > > > > Correction to above: The GRT EIS does have two tachometer connections. > > > > Where do you hook up a second Pmag to a > GRT EIS if the instructions to connect are in conflict? > > >I guess I=99ll need to get help from GRT and >Emagair to understand how the connections are to >be used since each Pmag will be generating a signal even when disabled. > >Eric S. Just hook up one tach signal. Probability of loosing that signal is exceedingly low and even if you did, it's no big deal. Don't mess the throttle until airport in sight then reduce power for decent. A tach is about the lowest priority flight management instrument on the panel. Broke a tach shaft out in New Mexico on a trip. I knew that I could never over-speed the engine in EITHER climb OR cruise at altitude. So for all practical purposes, the flight from t/o to approach descent could be made at full throttle all the way. Brought the airplane home for repairs in OUR shop. The eMag ignition outputs a tach signal even if in IGN OFF condition . . . I'd just hook up one ign to the tach and call it good. I've designed a couple of electronic tach pickoffs for upgrading Beech products to electronic displays . . . nobody ever worried about the 'single source' driving a 'single instrument'. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2019
Subject: Surplus riveting tools
I have a collection of riveting tools surplus to my needs. Emacs! One hammer, one cleco plier, two micro-adjustable counter-sinks, assorted sets, assorted clecos and one bucking bar. Click here for bigger picture: https://tinyurl.com/y2bhlsoe Thought I'd offer to the List before putting it up on eBay. I'd like to get $50 for the lot. Shipping via priority mail is $20 for a total of $80. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2019
Subject: Re: Surplus riveting tools (correction)
> > >Thought I'd offer to the List before putting >it up on eBay. I'd like to get $50 for the >lot. Shipping via priority mail is $20 for a >total of $70. > > Bob . . . Bob . . . ________________________________________________________________________________
Date: Oct 24, 2019
Bob- I'll buy them. Thank you! On Thu, Oct 24, 2019 at 12:24 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > I have a collection of riveting tools surplus > to my needs. > [image: Emacs!] > > One hammer, one cleco plier, two micro-adjustable > counter-sinks, assorted sets, assorted clecos > and one bucking bar. > > Click here for bigger picture: > > https://tinyurl.com/y2bhlsoe > > Thought I'd offer to the List before putting > it up on eBay. I'd like to get $50 for the > lot. Shipping via priority mail is $20 for a > total of $80. > > Bob . . . > ________________________________________________________________________________
Date: Oct 24, 2019
Hi Bob; Pardon, but I didn't key in on the e-mail (now erased) offering the riveting tools. If you would repeat, I might be interested. Cheers! Stu. ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Thursday, October 24, 2019 10:22:39 AM Subject: Re: AeroElectric-List: Surplus riveting tools (correction) Thought I'd offer to the List before putting it up on eBay. I'd like to get $50 for the lot. Shipping via priority mail is $20 for a total of $70. Bob . . . Bob . . . ________________________________________________________________________________
Date: Oct 24, 2019
Subject: Re: Surplus riveting tools (SOLD)
At 12:15 PM 10/24/2019, you wrote: >I have a collection of riveting tools surplus >to my needs. Sold Bob . . . ________________________________________________________________________________
Date: Oct 24, 2019
I don't want to step on Ashley, but if he passes on them, I'll take them=2E Charlie =81=A3Sent from BlueMail =8B On Oct 24, 2019, 12:43 PM , at 12:43 PM, ashleysc@broadstripe=2Enet wrote: >Hi Bob; >Pardon, but I d idn't key in on the e-mail (now erased) offering the >riveting tools=2E >I f you would repeat, I might be interested=2E >Cheers! Stu=2E > >----- Ori ginal Message ----- > >From: "Robert L=2E Nuckolls, III" <nuckolls=2Ebob@ae roelectric=2Ecom> >To: aeroelectric-list@matronics=2Ecom >Sent: Thursday, October 24, 2019 10:22:39 AM >Subject: Re: AeroElectric-List: Surplus riv eting tools (correction) > > >Thought I'd offer to the List before p utting >it up on eBay=2E I'd like to get $50 for the >lot=2E Shipping via priority mail is $20 for a >total of $70=2E > >Bob =2E =2E =2E > > > >Bob =2E =2E =2E ________________________________________________________________________________
Date: Oct 24, 2019
Hi Charlie; Hi Bob; I beg to correct. Charlie got there first. Go for it! Cheers! Stu. PS: Charlie, if for some reason, you change your mind, I remain as backup. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Thursday, October 24, 2019 11:17:20 AM Subject: Re: AeroElectric-List: Surplus riveting tools (correction) I don't want to step on Ashley, but if he passes on them, I'll take them. Charlie Sent from BlueMail On Oct 24, 2019, at 12:43 PM, ashleysc(at)broadstripe.net wrote: Hi Bob; Pardon, but I didn't key in on the e-mail (now erased) offering the riveting tools. If you would repeat, I might be interested. Cheers! Stu. ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Thursday, October 24, 2019 10:22:39 AM Subject: Re: AeroElectric-List: Surplus riveting tools (correction)
Date: Oct 24, 2019
Stu, If you actually need the stuff, take it; I was buying as spares/ back ups=2E Just let me know=2E =81=A3Sent from BlueMail =8B On Oct 2 4, 2019, 3:09 PM, at 3:09 PM, ashleysc@broadstripe=2Enet wrote: >Hi Charlie ; >Hi Bob; >I beg to correct=2E Charlie got there first=2E Go for it! >C heers! Stu=2E >PS: Charlie, if for some reason, you change your mind, I re main as >backup=2E > >----- Original Message ----- > >From: "Charlie Engla nd" >To: aeroelectric-list@matronics=2Ecom >Sent : Thursday, October 24, 2019 11:17:20 AM >Subject: Re: AeroElectric-List: Surplus riveting tools (correction) > >I don't want to step on Ashley, but if he passes on them, I'll take >them=2E > >Charlie > >Sent from BlueMai l >On Oct 24, 2019, at 12:43 PM, ashleysc@broadstripe=2Enet wrote: > > >H i Bob; >Pardon, but I didn't key in on the e-mail (now erased) offering th e >riveting tools=2E >If you would repeat, I might be interested=2E >Chee rs! Stu=2E > >----- Original Message ----- > >From: "Robert L=2E Nuckolls, III" >To: aeroelectric-list@matronics =2Ecom >Sent: Thursday, October 24, 2019 10:22:39 AM >Subject: Re: AeroEl ectric-List: Surplus riveting tools (correction) > > >
> > >Th ought I'd offer to the List before putting >it up on eBay=2E I'd like to g et $50 for the >lot=2E Shipping via priority mail is $20 for a >total of $70=2E > >Bob =2E =2E =2E > > >Bob =2E =2E =2E > > >
Date: Oct 24, 2019
Subject: Surplus riveting tools (SOLD)
Thank you all for your interest but one of our number e-mailed me direct about 15 minutes after I posted the offer. The box went out on the truck about 30 minutes ago. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2019
Hi Charlie; I, too, was buying for spares, and I apparently can't pass up a bargain. You first, Charlie, I insist. Cheers! Stu. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Thursday, October 24, 2019 2:34:13 PM Subject: Re: AeroElectric-List: Surplus riveting tools (correction) Stu, If you actually need the stuff, take it; I was buying as spares/ backups. Just let me know. Sent from BlueMail On Oct 24, 2019, at 3:09 PM, ashleysc(at)broadstripe.net wrote: Hi Charlie; Hi Bob; I beg to correct. Charlie got there first. Go for it! Cheers! Stu. PS: Charlie, if for some reason, you change your mind, I remain as backup. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Thursday, October 24, 2019 11:17:20 AM Subject: Re: AeroElectric-List: Surplus riveting tools (correction) I don't want to step on Ashley, but if he passes on them, I'll take them. Charlie Sent from BlueMail On Oct 24, 2019, at 12:43 PM, ashleysc(at)broadstripe.net wrote:
Date: Oct 24, 2019
Looks like neither of us gets to decide; Bob's already shipped the stuff. :-) On 10/24/2019 5:57 PM, ashleysc(at)broadstripe.net wrote: > Hi Charlie; > I, too, was buying for spares, and I apparently can't pass up a > bargain. You first, Charlie, I insist. > Cheers! Stu. > > ------------------------------------------------------------------------ > *From: *"Charlie England" <ceengland7(at)gmail.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Thursday, October 24, 2019 2:34:13 PM > *Subject: *Re: AeroElectric-List: Surplus riveting tools (correction) > > Stu, > > If you actually need the stuff, take it; I was buying as spares/ > backups. Just let me know. > > Sent from BlueMail <http://www.bluemail.me/r?b=15656> > On Oct 24, 2019, at 3:09 PM, ashleysc(at)broadstripe.net > wrote: > > Hi Charlie; > Hi Bob; > I beg to correct. Charlie got there first. Go for it! > Cheers! Stu. > PS: Charlie, if for some reason, you change your mind, I remain as > backup. > > ------------------------------------------------------------------------ > *From: *"Charlie England" <ceengland7(at)gmail.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Thursday, October 24, 2019 11:17:20 AM > *Subject: *Re: AeroElectric-List: Surplus riveting tools (correction) > > I don't want to step on Ashley, but if he passes on them, I'll > take them. > > Charlie > > Sent from BlueMail <http://www.bluemail.me/r?b=15656> > On Oct 24, 2019, at 12:43 PM, ashleysc(at)broadstripe.net > wrote: > > Hi Bob; > Pardon, but I didn't key in on the e-mail (now erased) > offering the riveting tools. > If you would repeat, I might be interested. > Cheers! Stu. > > ------------------------------------------------------------------------ > *From: *"Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Thursday, October 24, 2019 10:22:39 AM > *Subject: *Re: AeroElectric-List: Surplus riveting tools > (correction) > > > Thought I'd offer to the List before putting > it up on eBay. I'd like to get $50 for the > lot. *Shipping via priority mail is $20 for a > total of $70.* > > Bob . . . > > > Bob . . . > > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 24, 2019
Hi Charlie; Well, I didn't get the tools, but did have the chance to encounter a true gentleman. Cheers! Stu. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Thursday, October 24, 2019 4:25:11 PM Subject: Re: AeroElectric-List: Surplus riveting tools (correction) Looks like neither of us gets to decide; Bob's already shipped the stuff. :-) On 10/24/2019 5:57 PM, ashleysc(at)broadstripe.net wrote: Hi Charlie; I, too, was buying for spares, and I apparently can't pass up a bargain. You first, Charlie, I insist. Cheers! Stu. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Thursday, October 24, 2019 2:34:13 PM Subject: Re: AeroElectric-List: Surplus riveting tools (correction) Stu, If you actually need the stuff, take it; I was buying as spares/ backups. Just let me know. Sent from BlueMail On Oct 24, 2019, at 3:09 PM, ashleysc(at)broadstripe.net wrote:
Date: Oct 24, 2019
Maybe you could introduce me to him sometime. ;-) On 10/24/2019 9:31 PM, ashleysc(at)broadstripe.net wrote: > Hi Charlie; > Well, I didn't get the tools, but did have the chance to encounter a > true gentleman. > Cheers! Stu. > > ------------------------------------------------------------------------ > *From: *"Charlie England" <ceengland7(at)gmail.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Thursday, October 24, 2019 4:25:11 PM > *Subject: *Re: AeroElectric-List: Surplus riveting tools (correction) > > Looks like neither of us gets to decide; Bob's already shipped the > stuff. :-) > > On 10/24/2019 5:57 PM, ashleysc(at)broadstripe.net wrote: > > Hi Charlie; > I, too, was buying for spares, and I apparently can't pass up a > bargain. You first, Charlie, I insist. > Cheers! Stu. > > ------------------------------------------------------------------------ > *From: *"Charlie England" <ceengland7(at)gmail.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Thursday, October 24, 2019 2:34:13 PM > *Subject: *Re: AeroElectric-List: Surplus riveting tools (correction) > > Stu, > > If you actually need the stuff, take it; I was buying as spares/ > backups. Just let me know. > > Sent from BlueMail <http://www.bluemail.me/r?b=15656> > On Oct 24, 2019, at 3:09 PM, ashleysc(at)broadstripe.net > wrote: > > Hi Charlie; > Hi Bob; > I beg to correct. Charlie got there first. Go for it! > Cheers! Stu. > PS: Charlie, if for some reason, you change your mind, I > remain as backup. > > ------------------------------------------------------------------------ > *From: *"Charlie England" <ceengland7(at)gmail.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Thursday, October 24, 2019 11:17:20 AM > *Subject: *Re: AeroElectric-List: Surplus riveting tools > (correction) > > I don't want to step on Ashley, but if he passes on them, I'll > take them. > > Charlie > > Sent from BlueMail <http://www.bluemail.me/r?b=15656> > On Oct 24, 2019, at 12:43 PM, ashleysc(at)broadstripe.net > wrote: > > Hi Bob; > Pardon, but I didn't key in on the e-mail (now erased) > offering the riveting tools. > If you would repeat, I might be interested. > Cheers! Stu. > > ------------------------------------------------------------------------ > *From: *"Robert L. Nuckolls, III" > > *To: *aeroelectric-list(at)matronics.com > *Sent: *Thursday, October 24, 2019 10:22:39 AM > *Subject: *Re: AeroElectric-List: Surplus riveting tools > (correction) > > > Thought I'd offer to the List before putting > it up on eBay. I'd like to get $50 for the > lot. *Shipping via priority mail is $20 for a > total of $70.* > > Bob . . . > > > Bob . . . > > > > Virus-free. www.avast.com > > > > <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 25, 2019
Hi Charlie; Should our paths ever cross. Cheers! Stu. Whidbey Island, WA ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Thursday, October 24, 2019 7:48:16 PM Subject: Re: AeroElectric-List: Surplus riveting tools (correction) Maybe you could introduce me to him sometime. ;-) On 10/24/2019 9:31 PM, ashleysc(at)broadstripe.net wrote: Hi Charlie; Well, I didn't get the tools, but did have the chance to encounter a true gentleman. Cheers! Stu. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Thursday, October 24, 2019 4:25:11 PM Subject: Re: AeroElectric-List: Surplus riveting tools (correction) Looks like neither of us gets to decide; Bob's already shipped the stuff. :-) On 10/24/2019 5:57 PM, ashleysc(at)broadstripe.net wrote:
Subject: Headset to hand-held and panel radio at same time?
Date: Oct 27, 2019
Is is possible to utilize a Y cable to connect a headset to a hand-held and panel radio at the same time? The situation would be no intercom panel, Garmin GTR200, Yaesu FTA-550, and twin plugs on the panel for a headset. This topic link indicates OK http://forum.matronics.com/viewtopic.php?t=37809 but it refers to an intercom panel. However, the Audio Systems chapter seems to indicate that either radio would not sense an resistance in the other so the headset would not receive much useful output. My thought is the handheld could function as a back up to the GTR200 and or second frequency monitor if the volume was turned up with out the need to change the headset plugs from one to the other. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=492006#492006 ________________________________________________________________________________
Date: Oct 27, 2019
Good deal for that nice set of riveting tool! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=492011#492011 ________________________________________________________________________________
Date: Oct 27, 2019
Subject: Re: Headset to hand-held and panel radio at same
time? At 04:57 PM 10/27/2019, you wrote: > >Is is possible to utilize a Y cable to connect a headset to a >hand-held and panel radio at the same time? The situation would be >no intercom panel, Garmin GTR200, Yaesu FTA-550, and twin plugs on >the panel for a headset. This topic link indicates OK >http://forum.matronics.com/viewtopic.php?t=37809 but it refers to an >intercom panel. However, the Audio Systems chapter seems to >indicate that either radio would not sense an resistance in the >other so the headset would not receive much useful output. My >thought is the handheld could function as a back up to the GTR200 >and or second frequency monitor if the volume was turned up with out >the need to change the headset plugs from one to the other. You can try it . . . there's no risk of damage . . . it simply would not work as you expect. Adding multiple audio sources together is normally done with an audio isolation amplifier as described in the chapter. As to microphones, the mic in your headset can be connected to only ONE transmitter at a time. You would need a XMTR1/XMTR2 microphone transfer switch. So if you're only needing the HT for backup, you might as well transfer the headphones audio with the same switch. Bob . . . ________________________________________________________________________________
time?
Date: Oct 28, 2019
If it doesnt work, you can build a two input audio amplifier for about $3. But youd have to wire it in to 12v power. On Oct 27, 2019, at 9:41 PM, Robert L. Nuckolls, III wrote: At 04:57 PM 10/27/2019, you wrote: > > Is is possible to utilize a Y cable to connect a headset to a hand-held and panel radio at the same time? The situation would be no intercom panel, Garmin GTR200, Yaesu FTA-550, and twin plugs on the panel for a headset. This topic link indicates OK http://forum.matronics.com/viewtopic.php?t=37809 but it refers to an intercom panel. However, the Audio Systems chapter seems to indicate that either radio would not sense an resistance in the other so the headset would not receive much useful output. My thought is the handheld could function as a back up to the GTR200 and or second frequency monitor if the volume was turned up with out the need to change the headset plugs from one to the other. You can try it . . . there's no risk of damage . . . it simply would not work as you expect. Adding multiple audio sources together is normally done with an audio isolation amplifier as described in the chapter. As to microphones, the mic in your headset can be connected to only ONE transmitter at a time. You would need a XMTR1/XMTR2 microphone transfer switch. So if you're only needing the HT for backup, you might as well transfer the headphones audio with the same switch. Bob . . . ________________________________________________________________________________
Date: Oct 28, 2019
Subject: Re: EAA award and banquet
At 09:53 AM 10/28/2019, you wrote: >Hi Bob, > >congratulation as well on your EAA award very well deserved. > >Cheers Werner Thank you sir! BTW, I'm told that there are 8 chairs at 'my' banquet table. At the moment, there are 4 chairs unclaimed. If any Listers are so motivated/able, I'd be pleased to have them join us. It's the evening of Nov 7th in OSH. Bob . . . ________________________________________________________________________________
Date: Oct 28, 2019
Subject: Fwd: Help with panel design?
P.S. A change I made since the photos were taken, was that I reduced the breakers from 3 down to 2. One for now will be 20 amps and the other 5 amps. They will be the two next to the starter button. In the area of the previously anticipated 3rd breaker, I will have one of the panel attachment bolts. ---------- Forwarded message --------- From: Peter Feneht <peter.feneht(at)gmail.com> Date: Mon, Oct 28, 2019 at 10:40 AM Subject: Help with panel design? Cc: Peter Feneht Apparently I suffer from lack of knowledge, lack of experience changed with being tempted by perfectionism. That is a miserable, stuck situation so I am hoping you Or others in the group can help me. I have decades of hang gliding experience and now I want to build a Xenos motor glider. Some of the factors for locating the instrument panel items included the size of the device behind the panel. For example a bulky item could not be located too low because of the angle of the support structure at the bottom edge. That=99s why smaller switches are on the bottom edge but not th e breakers. Also my plan is to install all instruments switches and devices on a flat sheet of aluminum the exact size of the panel that attaches to the aircraft. I will use a number of bolts to attach the flat, instrument-laden sheet to the attachment points for the instrument panel frame that will be riveted to the Aircraft frame. That way I can just loosen several bolts and remove the whole instrument panel for ease of access for future maintenance repairs or troubleshooting. Perhaps as a result of knowing my inexperience while trying to design something that I will be happy with for a long time after I get more experience, I asked The opinion and advice of many willing pilots in our local chapter, Sonex and at EAA. I think those many opinions have contributed to my confusion and hesitation. So at the risk of getting even more confused, I humbly ask for more advice from you and your group. I hope that the large volume of advice will settle into some kind of consensus with which I will be comfortable in the short and long term. Bob, I did this from my phone so I=99m not sure it will go to the gro up. If it doesn=99t go to your group can you kindly forward it? Thanks! Peter Sent from my iPhone ________________________________________________________________________________
Date: Oct 28, 2019
Subject: Glastar Dipole comm antennae behind doors
>I=99ve got dipoles in the tail, one close behind >bulkhead A, and one in the vertical tail. This >was what was being done in TWTT back in 2006. > >I measured the fraction of reflected energy >(measured in terms of what=99s called =9CSWR=9D) >and the impedance of both antennas a few years >ago. The ideal impedance is 50 ohms (to match >the coax). The ideal SWR is unity. For an >antenna in a free-field (like on a pole), one >would hope for an SWR less than 1.5 over the >full VHF aviation band. For less than ideal >circumstances, < 2.0 or even 3.0 might be considered tolerable. Actually, if one can get 3:1 or less over the entire spectrum of interest, then performance for aviation purposes will be adequate . . . ASSUMING that locality conditions don't add factors un-related to SWR. Emacs! >As you can see in the attached graphs, impedance >is all over the map, and rarely near 50 ohms. >The SWR seems to indicate that the front antenna >is barely tolerable up to 127 MHz, above which >it gets pretty bad. Conversely, the tail antenna >is pretty crappy until 116 MHz, then tolerable right up to 135 MHz. The aft antenna (vertical fin?) does show a smooth curve with pronounced dip at 130MHz. This suggest the antenna is doing a reasonable job of accepting energy from the feedline over the range of interest. Further, it's under 3:1 SWR . . . I'd call it good. The front antenna plot suggests complete lack of resonance at any point in the explored spectrum. I'm assuming this antenna is wrapped around the inside surface of the composite shell with a predominantly vertical polarization. If the SWR scan had been taken lower frequency, I suspect that a pronounced dip in SWR would be discovered . . . the trend of the plot as it approaches 113Mhz suggests this. It makes sense. Close proximity of either/both CONDUCTIVE or DIELECTRIC features tend to lower the resonant frequency of a radiator. Pasting the antenna to the inside surface of the fuselage will lower it's resonant frequency measurably . . . proximity to steel structure inside the fuselage will lower it more . . . perhaps MUCH more. Suggest the ends of the forward antenna be shortened a bit and new scan taken . . . start at some much lower frequency to see if there's a real resonance artifact down there.I suspect that the interaction with conductive structure, such as the cage in front and the tail spar in the rear have more to do with the anomalies than the modest curvature. Not only that, the coax is connected to both antennas directly. Since the coax is an unbalanced=9D conductor, and a dipole antenna is balanced=9D, there is supposed to be something called a balun=9D between them. I don't know if it was ignorance, cheapness, or weight-consciousness behind the absence of a balun, but no doubt that=99s also part of the problem. A BALUN can improve on energy transfer between feedline and antenna but the thing needs to be RESONANT in the range of interest first. I'm fiddling with an dual-band (121.5/406) ELT antenna intended for installation on the inside surface of an RF friendly composite fuselage. Looking at the value of some BALUN options. Discoveries would applied to the VHF comm antenna being discussed here. Get the SWR down and 'centered up' first. Bob . . . ________________________________________________________________________________
Date: Oct 28, 2019
I'd love to....but am too far away and have a conflicting schedule. Bob and the table - enjoy; well deserved!Rumen ----- Original Message ----- From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> Subject: AeroElectric-List: Re: EAA award and banquet At 09:53 AM 10/28/2019, you wrote: Hi Bob, congratulation as well on your EAA award very well deserved. Cheers Werner Thank you sir! BTW, I'm told that there are 8 chairs at 'my' banquet table. At the moment, there are 4 chairs unclaimed. If any Listers are so motivated/able, I'd be pleased to have them join us. It's the evening of Nov 7th in OSH. Bob . . . ________________________________________________________________________________
Date: Oct 28, 2019
Sounds a great night, not available here as well. Enjoy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=492024#492024 ________________________________________________________________________________
Date: Oct 30, 2019
Subject: Brass Current-carrying Calcs
I want to calculate the current-carrying capability of a piece of brass bus sbar. Once upon a time I had a chart that showed something like circular mil & re sistance per foot for brass. I've Googled for about 20 min but not able to find what I want.=C2- (ever ything I'm finding is about copper & aluminum). Any help is appreciated, Thanks, Jeff ________________________________________________________________________________
Date: Oct 30, 2019
From: "r.r.hall(at)cox.net r.r.hall(at)cox.net" <r.r.hall(at)cox.net>
Subject: Re: Brass Current-carrying Calcs
Brass has 28% the capacity of copper but since the runs it will go through are so short and the amperage would be fairly low (<100 amps I am guessing) it is usually not a problem. The question is why not copper? Rodney Hall > On October 30, 2019 at 3:03 PM Jeff Luckey wrote: > > I want to calculate the current-carrying capability of a piece of brass bussbar. > > Once upon a time I had a chart that showed something like circular mil & resistance per foot for brass. > > I've Googled for about 20 min but not able to find what I want. (everything I'm finding is about copper & aluminum). > > Any help is appreciated, > > Thanks, > > Jeff > ________________________________________________________________________________
Date: Oct 30, 2019
From: Lawrence Handberg <stinsonwagon(at)yahoo.com>
I think this is the chart you are looking for=C2-see attached pdf all(at)cox.net wrote: Brass has 28% the capacity of copper but since the runs it will go through are so short and the amperage would be fairly low (<100 amps I am guessing ) it is usually not a problem. The question is why not copper? Rodney Hall On October 30, 2019 at 3:03 PM Jeff Luckey wrote: I want to calculate the current-carrying capability of a piece of brass bussbar. Once upon a time I had a chart that showed something like circular mil & resistance per foot for brass. I've Googled for about 20 min but not able to find what I want.=C2- (e verything I'm finding is about copper & aluminum). Any help is appreciated, Thanks, Jeff =C2- JVBERi0xLjMNMSAwIG9iag08PC9UeXBlIC9YT2JqZWN0IC9TdWJ0eXBlIC9JbWFnZSAvTmFtZSAv SW0xIC9XaWR0aCAxNzAwIC9IZWlnaHQgMjIwMCAvTGVuZ3RoIDM0MzAwNi9Db2xvclNwYWNlIC9E ZXZpY2VSR0IgL0JpdHNQZXJDb21wb25lbnQgOCAvRmlsdGVyIFsgL0RDVERlY29kZSBdID4+IHN0 cmVhbQ3/2P/gABBKRklGAAEBAQDIAMgAAP/bAEMACAYGBwYFCAcHBwkJCAoMFA0MCwsMGRITDxQd Gh8eHRocHCAkLicgIiwjHBwoNyksMDE0NDQfJzk9ODI8LjM0Mv/bAEMBCQkJDAsMGA0NGDIhHCEy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMv/AABEICJgG pAMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQD BQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygp KjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJma oqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/ xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQID EQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RF RkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqy s7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/ APRvB6H+yj67q6aNeAQRzXOeEM/2Xk5wW/CunjIHTtTILS9BS01c4GadQMMUppKDQAtJS0g6UAFJ jilo7UAJigADtS0dqAE2j0o2gdhTqQ0AJgelLijoaWgBpUHtSbF9BT6SkAmB6UcU6igBm0Z6UpUe lLRTAbsGc0FB6U6jtQAzy1446UnlDOcVIaO9AEflryQPwpdgBBxT6KAGlRjpRtxmnUYoAYFAHSl2 gDgY+lOooAbtGelG31FOooAbtGelAUDtS96O9ACbeKaYkI5FSdqKAIWhB+vWkaIYHFTnHekwKAIP JAINNESHPB69KsY/Ojbzn9KAKvlrv6c0/wAoZxk5PapiuSCMUuMnOOR3oAg8vPbGeeKd5Qz29alw aMZ470AMCA9RSmMEccGn460AcUAMK5H1pFj2mpAMdKPwoARlyuKb5YByAB9Kf29aUUANAAOc8mlx S0lACbBnNAUDoKcKKAGgDA4pCgHQU+gUANA4wVxRtHIx1706jFIBNoHAHFNaMN2p9HpTAYU4FIYx 2AqSkoAj2DGO1DRqeCKk5oNAEJiGMYpDGB2qekIyKAIWiBIOOab5YTAPTNTlemTQVBBFAFcxenHP ajy8dsjNTMmeDTtuAB6UAVtnYj9KfsUtgDipQvzA9hS7fwoAjEX5Z7cU2RB0OPY1Pj0/Sjbnk+mK AIQmXORwfSn+X3OCaeBjApQKAI9gyDt5FKyL1NP60UARiPGccGkCck9eKl70Ac0AR+Xgcd6PLGOR TyKXFAEPlYPFLsyOmKkA9aX0pAQtHx7imCMEc9xjFWaTbyaAIPL+X7tOVOxA46VMKMfWgCILjBwO aaI+c9O1T44ox8tAEIUHjj6560pjyKlwAAKMc+1MCDyOQdowDnFAiVTgDGfSp+aMUgIimT05BoaP cMdDUuMGgeh60AVtmXBxThGCQCDkdKlMfzZ/lTsUARiMDsMDpSlAy9KkFGBQBHt68H6U4DmnY5zR QAnXr1oAGMUtAGKYCY9hRjj1p1FIZGUyBik2cjIqWigCPaM+9LsBHSnUUAMKA9qQoM9Me9SUH6UA QmFSCSOOuKaYVzjHFWMUhFAEPlDPIxSGMHnvUmB0NKRnGPWgCuYxjJ6e1IIhngVZwATx1pu3BJ5o ERGNAMFfel8oEEdamxkDNAGPXkUAVjCCQenfk0pjwM96nApduM0AQrH3pGQD5ugqcLxxwaQAgYPf 2oAg2AZAFKFPNSY7HmgL196AIygIFJ5YORgVNtxxilPA5BoAh2e1NMOD61Yxx0z60EEDI+hFAETJ nbkYPrQqY4xkZ61KB8o9acACKAGBMZPOOuKUjLYH6ipOOlJjmgBgj5IJo24JI71JRQMbt4HApCgA xgU+g80CGqMdqNuM5pwAHaigYm3pRgdqXFGKAG7ARTWjGc1IKKBEfljnpzUZiHU9fSrGODRgUAVz CMninCIegzU3sKTaAc0ARCEUhhAAFTbR6c0Y4oAg+zjOD/8ArpGtlGCB0HepyoI5oxgGgCqLZFPA HPXmkMWP5dKtFR0/GgDIGR9KYFTyQe3ehYV5J/KrLLx070oXk8DpQBB5YGMY5FOEYIweuO1SeWev Q05QccigBix4JzTtgxj9afRjFADFQAYo8sU+loAj2DBzzzn3pwUDtTscUg4oATbgn60mwAYFPooA bjPB70hjBGCKfR3oAZsHFDRK3bmnEUtAEQhUHNAgTOcdalowM0AReQo6ZpGgUjipqKQFb7IuQec/ Wj7MpPTHr71ZpKYEKwAc55pTAM9ufapaKAIPIBOcn0pTCCOtTdqTAIoArNbgH1prWy9fyq3jik2/ LjqKBFMW3UH+VSrCCB0471OVzSgYNAyERLgj2pRCOvQmph16UuOKAI1jAABFO2jHAxTsUUAM8sel HljJJ5p+KBQA3YMjHFIIhT6BQA0pnrUPloRvIzknFWBmo2hViM549DigBPKRlHAx2oMK1IqgAAdK XvQBF5Io8lQQcVJS0ARiMDjH0pDCp681JS0CGeWvUgZoEYp9AoGN2DGKXApe9BoAQim7BnOKfiko Ab5YPtS7Rmnd8Ud6BDGiDeopGhUoy84II4qQmlFAzE8J+FNO8H6TJp+mNO0MkxnYzyb23FVB5wOM KKK3V6UUikcN4TYrpigocZ69q6uIA4IPFcp4RP8AxKQc/wAXTvXVJjAOeaZCLa/dFLSL0paBhS9q Sg0AAopRSdqAFzRSUtAAOlJQOlGKAF7UlKKQ0AHelpO9LQAd6DQaTqKAFNFAGKO5oAKSlFIORQAt J0pfSigBKKKKACl70lB65oAU0h60UUAB6UtJ2ooAB1pe9J3paACkNFLQAlFLSUAFFBooAKQilooA Mcc0nel70UAIKWiigApaSigAope9HegBBRS0UAJ3pRR1ozgc0AHakzSijvQAd6B0o70dKBhQaAaD QIKKKKAEooPWloATFFFFACY5opaO1ACUUpooENI5zS9DmlpO1AwA5o/ClooACM96TmlNFIAxS0UU wEFKKTvS0AJiijvQetABRRRQAd6KKWkAlGaWkpgFFFHSgAxRS0UgE7UY5o7UUwCilopAIKKXFFAC UtFFABRRQKYBQaKWkMSiijpQAdqKWk6UAHeilpKADFBFFFAAOlFFFABSUtFACY5NFFFACHHFNxyc 4zT+9JjmgBOg6fhSgAgUpFAoATAopaO1AgpOMUoooGNwM+9LiloFAhuB0zSijv0pfpQMaR8vT8qX gilpABnNAgHNAAFL2oz2oAKM80tFABSYxR3pRQMKTvTqTrQAUdqO9LQAmaKD1pe1ACUUvaigBKQ0 tJQIO9FL3pKYBiigUGgApMYFLRSATFFL2opgIRmjAOKOlFIA6ijHFAGMUopgFJjFLRQACiiloAQ8 0d6UDmjvQAnagiiloAQCjvS5xSUABo7UH070UAFHeg0DrQAdaDRS0AJRRRQACiiigApMcU6koAQ0 UUUCCiiloGJSkUUGgAHSgmij2oAKWjvR3oAT3pRyc0daB1oAOtJS8UdaACk7UtJ2oAOlBoo460AJ S5pKXvQAYpR0ozQOKAEpTQetIaAAcUlLiloAQdaOOaOlHegANKKTigdKAHr0ooXpRSKOF8J8aYMH ndxXUJkSZxXNeEx/xLF+UH5vTpXTr94YpsguLyKWkFLQMKM+lHeigBfxpKWk7e1AC5pO1FL0FAB6 0dqO1HUUAA6YopcUnSgBOppaMc0HrQAd6SlI70exoAByaMc0UDrQAD0oFAHejFAB3ope9JQMTGaO /NFKaBCUdKOtKRzQAlFGKDQAtJmloPFACd6WgUUAJRS0dqACg0lLQAlHalNFACUUUUAFFFA60AFF HelNABRSDrS0AJ3pc80dDRQACiijpQMKQc/SgdaPSgQuaOho4/CkzigA5wM9aXtQSB1I+poFAwHW ijNHagQdKO4oo70AB7UUUUDEopaSgQUUUUABoFFFABRRRQAUd6KKAFpKWikAhpaQ0o6UwCgUUCgA 70UUUgE70UtJTAO9LSDrS0AFJS0UhhR2oooASlooxQIB05pO9LRTAKKKKQwFFAooAO9FFLigApKX FFABR3oooAKMUetHagA7UUdqO1ABRRRQAlLR3ooASiiigAooopAMDfOyk89R9KdTX4IYdqa0u4FY mBfOPXH1pgSYoGaBnAz174oNAhaSlooGFJS0lAC0lLRQAlFFFAB2ooooEFJjml9qKBh3oo7UZyM0 CDoKKKWgYUUdKOetACiko70UAFLSd6XFACGl7UlLQAdqSjtRigA9aSlxRTEFJS4pKACilpDQAUtJ S0gE7UUUUwDrRRRSAO9FFHamAUGjtR2oAKXtSA0ooATNA5NKaTHNAC9DR05oPWjvQMSigcmjBoEF L2pMUo+7QAlHGaUdTQBQAlLR0IoNACUd6WkoAKO1BooAKKO1FABSUtFACUUtHagAFFFFACijpQKO KADtSE0tJ3oAXqKAeKMYxQKBh3zSUvFHegQdqSlHWjpQAntRR3oxQAd6KMdaMflQAuKSilHOKADP NIeaU9aMce9ACc0HrSjpSUAHpS9CaTvR3oAD1FKOlIaUUAOHSigdKKRRxXhPjS+MZ3V0sanOD1rm /CiEaYG4610kZAwzZyaZBdFFA6Cg0DClpKKAFpM0UUAL3oNFBoAMcUgpe1FABmkJpfakxQAHr9aX 0pDTjQAlBPrS9KT0oGFHfFKPekPegABoJGKQUY5oELmjvRRQAdqOv0oFFABxmjPNFHegA7UnelxS d6AFoNFHrQAnfFL3oo60AJ60dqWjAxQAYoNHaigBOPxooIooAKKKKACgUtFABRRj1pKAFoPSiigB KMUtFABiiijvQAD3oxxQO1FABmjFHWjuKAClpMCigYDFHalFJ0pAFFFHemAd6TFLRQISlo7UlABQ KKWgBKKWkzQAd6KKWgBKWkxS0gCjtRRQAmKXtRRTABRRQBQMO9FFFAhKKMd6KAFoNHeikAUUUUAF FFFMAoo70UAHajvR2opAFGaKO1AwooFFAC0UUUAFIKWigAooFHegAzS0mOc0tACdqO1FFAB6UUUY oAKKKKACkpaQ0AFFHaigAooooAKSl6UlAC0UmKWgApKWigApKWkoAKBRR2oAKKKKAD6UUUUAA7UU UtABRRRQAUUDrRQAUUtFABSGlooASjOKXPNFAAKBR2ooAQiilHQ0lMApKUUlAhRQaKSkACilpKAC jtS9qTtQAUUUUAFFFLTASiiloATrS9qO9FABRRR3oGFIRS9MUcE0AApKB1FKTigQmaO1HApcDFAA cUUUdKBimm0p60UAFJRRQIDR2paTtQAUUtJQAUUUUAJS0Ue9ABQTRSEUAKDQaB0oNACj+VIck0tJ g5oAXtQOuKUUnegYY/Kkpe9B4oEFGaBxQRQAlFHvR3oAKWko70AL3oHHFFGKAEPWlo79KSgAz2o7 0vegigBOho70o5pDQAUoGBzSGlBoBDh0ooHSikUcZ4UO7SlHTn866KPJkAH51z/hQn+ylXA68HFd HFkgHjimQWx0GaDQKKBhR0o9qKAFoo/lQKACjtSHrRQAoPFFA6UlACjrQaBQaACjrRnFHNACnFFJ R2oGHeiijvQIB1pRRSE4oAO/NGaWkPWgYd6Pwo96KBBQT3pKU/SgAoHejtQByaACjrS9qb70DFox QBRQIBRRR2oAT0paKQ0ALRQfWigBO1Hal7UhoAWk70tHegBM0tJR3oAXtRRRSGJnilo70UxAKO9H tR1oAM0UAAAD0pB0oAXp2o4oHNHegAo7UHrS0DAUnal6UGkAnpQetFFMAPajvQaKBB3oopKAClpC KKAA5ooNFAC0lFFAC8UUgpetIA70dqKKACiiigYUUUZ70AFHek60tMQd6KTvRQAtGaPrRSAKSl7U GmAUUdqKACjtR2ooAOcUZoopDCiiigApaSloAM0UUUAHGKKKQUALRRS96ACko7ml7UAIKKB0ooAK OooooAKKM0UAFJS0negAooooAKKKKACkpaKACiiigBDS0UUAAooooASilpKAFpKXtSUALRRSUAFF FB4FAC0UnWigBaKKMUAFFGKKAFoopO1AB3paSloAKTNHrRTAPWjmjrRjigAopRSUAJS0UGgQnOfb vRS0lIAooopgFFFFIAoopaYBR1FJS4oASlpKUUAHT60d6Wk7/SgYdeaKDyKOKBARSDrS4o60ABo6 CkNLigBcYpO9FHQ0DDNFBoxQAlLSClxQIDSUUAe1ABRn0pe1JigAoo9qKAEpe1HaigAoNA60daAA UvtSdDS96ADignFFJ3oAXHBpRSUgNAxc0lLmkFAhcUnvQM0GgA70daO9FABR3oFHegAJoH1oxQOl AC9+tHpRgdaPagA7ikzR3zRmgBRR3pPSgUAHWlHWkwKUUAOHSigdKKRRxnhP5tJjwAea6iIYOK5b wg+NMUbeN3WupRgelMgsClpFziigYfSloo70AA6Unal9qM0AHFB46UYoNAAKSgUUAKOlJ60Z5pSK ADvRmkpRQAd6DS96Q0AH40UCj6UAANHaijHFAAKCM0CigAooFBoAQdPeloHNHtQAUd6McUGgBSaS lpOooGGfSkzil78UlAhaTGKKKAFpO1HUCloAKTtS0lABRRRQAtIKWkoAO9L2opKAFoxR2oxxQAUG ijvQAAcUUc0DrQAUYoHWl7UAJjFHeik70AKRzSig+1IOlAxaQ9PagcUtACDmk9KWjrQIOpox1ooo AKQ0vajFABRQKO1ACUUUUALQaKSgApaPeigAoNHeg9KACijtRQAvWkHNA4oFAwo70d6KBCUtIetL QAdaKKKADtSHNLRSAKKKSmAtFFA5oAO1HegGigAoHWijFAwFLSClpAJml9aKKACk5opetAAOlB6/ jR0oyM0AFAozyaKADtQaXtSGgA70CigUAGKKKSgBaKQUtACUUUUAFFFFABRRRQAUUGg0AFJS0UAF FFFACUUUUAL2pKKKAFooooAT2oopaAEopaTvQAtAoo96ACgilpKAF6UUYo6igBKWkxk0poATsaB0 paOgpgJQKWkoAB3ooFBoABSUo6UGgQUlLSUAFFFFABQaKKACjFL2ooAKKKSgApaTvS9qADqKQHml 7UgoAMc0uOOtGc0dKBh0o/GjqKTpigQGl/h60h6UdqAFoo9RRQAdaTtS5ooAQUUUGgAzSjpSUdRQ ACjvRQaACig9aKACiiigAFBpO9KaAFHSk+tHakoAWgUUCgB1NANKaBnsKBiCiijHFAg60oxikFHa gApTSCg+tACd6XFJS96AA0opKBQAp6ikxSntQelACdaMUUdaAE74wcetLQKO/NABQOBQaUHigBw6 UUL0opFHEeEpD/ZqjnG7sK6lGwRjNcn4SJbTSMdG64rqYRnB/UUyC8OlLSA0ZoGFL3pKKAFpAKXt SdaAFzR2oozQAA5FFAo60DAdaDQMUN+tAgPWkxS96DQAH0pOlL3o9M0AAoo7UnegBaM8UUA8UAFG TRSDpQAoooooATvS0UelAB2oPWg80Y5oAWk6UvakNAw70H6UnrS9qBAKTtQKD0oAWkNA9aDQAdaX HFJS0AFJRRQAvWkoooAWg0nvSmgBKUUE8UlAC96KQCjvQAuOBSikHSgUAHeiiigBR0pMUUUAFKBx zSdKUHjmgYCk7e9L2pO1AAKTpil6UnWgQvYUZpDS0AJRS0lAB3pe1JS9qAAnikxS0lAB3oo70UAL R70nal7UAFB5o5oPSkAcUUg5pe1MYUUd6BQAneloo70CDvR3o70lAC96KKPekMO1FBozTEFFFFAB RRRmgAopB0paADtRQKOKQwpaSloASl70UUAFGKKTNAC0HtQKO9AAKKO9HNAC9qSl7UlABSUpooAK KKKACkpaQ9aACg0UGgAooooAKO9FFAB3ooooAKKKKACilpKACkzS0UAJS0naigBaTtRRQAtFHbNF ABRRRQAUUUgoAWlpKWgAo7Ug60tACdKWkNLQAh4FKDR2ooAKDR0ooAQUUUUwCiiigQUlLRQAhopa SgAooooAO9L2pO1HbrQAtHako7UAA4pc0Cg9KADr3oBwKQcmlHWgA6UdaO/40d6BhSHFFHagQp4o 7c0hPGKWgAopD1o6UAB60tBpKAAUd6BR9aAFNJ2oo7UAFFFHegANGc0daKAA9KKO1GaACg0d6DQA Ud6KDQAdKO9LR3oABSg4pOODRkelAwooHSk60CFoPSgUhNAB0oNGeaDQAUHrRRQAUUUooAOtB7Cj HvQBQAlLSdKMYoAPSgdaO9HegAIoHQ0dqUCgBy9KKB0opFHE+ElxpgwuST1JxXUxjoAMY9q5Twkw /s4Zz1rrIW520yCyKKB1ooGGKWkFKaADoKKMcUlAC0HpQaDQAZ4pAOM0uOKKADHNHrRQetACU7vT e+KPpQApoPpR0x60dQKAAc0nfrSg8UnegBfakFLjFGOKADvRR3oxQAdqKXFJ3oAOtHTpR1NKKACk zSUvegAzxRR2pDQADrS0gpetAB7UnalpO1ABS9qSloAKKDRQAlHaig0AFFLSDrQAd6WkxR3oAU8U Un1pcigAo70UcUAJQd2RjGM85paAKBgKBRjmjtQIOaQ9ad2pOp9qADjijFLiigYlL2oxSHpQAlHe ijuPWgQHrS0nej3oAKWk6Up6UAJ3paSloAKO1IaKAF+lJS0nFABS0lLQAZoPSjFHagAFGeKKKBh1 oo6UZoEHWjvR3o70AHejvRRQAd6KKKQwPSkpTRQIKSl9q5fWPiF4W0V5YLjVYpbuPINrbfvZSw/h wv8AFx0JFMDp6WuHb4qaFDGJLmx1u2Q9Gm06RQT2Gfer2j+PtK165ji02z1aaNn8s3AsJBFG2M/M 2MDt+YoA6rtR3rkdZ+JGg6JrM2kXAvpr6LBaK2tmlPKhuMezA1A/xP0NFLmx1vaF3Fv7MlAA75JH agDtRRxXEQ/FXw/dSpDYW2sXsrAny7bT5HYDAOcY9x09au6v49sdEXzb/Stbjtdkbm6+wt5a78YB PUEEgEEdeOtIZ1QFLXI6R8RNH125SHT7TVpg0oiaUWL+XGT0LP0UfWutoAWisLXPFdl4elK31pqZ hEQle5gspJYUXJHzOoIBGOh9RWfpfxF0LWrwW2mx6nctvVWaPT5SqbiQGY4wq5B5PoaAOs7UZ4rk NR+I+i6POYtUtdWsvmZFeewkCOVODtbGGHfjtWjoXi3TvEUu3TrfUTCULrcy2UkcLgEDAdgATz0+ vpTA36M81z3iLxro3hl0gu5ZZ76XHlWNpH5k8mTgYX8+pHSsyP4l6ZG6/wBraPr2iwN9251KwMcR PYblJwT746GkB2nqaKy9G8RaZr7Xf9mXC3EdrII3lQgoxKhvlIPIwcfUGqviLxhpPhkRpeSSTXk2 PIsbZfMnmycDan19cdDQBvdqCa42L4kaeirJqmja/o1uTj7RqOnskSnjAZlLbc571s2ninTNSsb6 802R76GzOHNqvmFztDYQDljzjHrkUAbPeiuM/wCFqeFElkhmuryGeNtjwyWEwdT6EBcg9q6mwvot Rs0uYY7iNGzhbi3eFx9VcAj8qALVJWbrOvWegwLPfJd+SQxMkFpJMEAxy2xTt69T6GqWheMtH8ST NHpbXkwGcymylSMY7byoXPtnNAHQUhrkJvih4Pt5Hjl1V1ZW2n/RZSM5I4O3noefaoF+LXgx2AXU 5iTjbizl+bPodvbOaAO2oNc1p/j3w/qk6w2E15cOzBD5enzsFOcfMdmF+pwB3rfurq2srd7m7nit 4Ixl5ZXCKo9STwKAJqK4yb4oeG4fnB1GW3BYG5isJWiGDjO7HIPPIz0NbWg+K9F8Sxl9Lv45nALN CTtlVc43FDyAexx3oA2e9FJmqWn6vZapLeRWspaSznNvOjKVKOPY9vQ9DQBfpKK5y98d+HNNuHgv r+S2kViv761lQMQcHaSuGGe4yKAOjoqlperWes2xuLJ5HiDbcvC8fOM8BwCRyOelR6vr2laBbrPq t/DaxucJ5jcufQDqT9KANGiuKHxW8KZVpLi9it2AK3MljMI2z2B2/X/vk11enanY6tZrd6ddw3Vu 3AkhcMM+nHQ+1AFrvSUtFACUUtFACUUUUALRRSUALRRQaADPNFFFMAo+tL7UnekAtFFFABRSUvUU AB6UUdqAKADPWijrRQAlGKWkzQAdqKKKYgpKWkpAFFFFMBaSijvSAO1L2opDTAWk7UtJxQACl5xS CloASjvmlpKAF4oPAoozQMB0oOKPoKQ0CDtR2oP1pRQAdqKOBSc5oAX0pD0pe4o60AJRRQetAAKB RjpQOlABQaBR2oAKO9GKPSgAoopKAF70HrR3oNAAOlFL6Ud80AIKDzS8daTigBRRjBxR2xSDrQAo 4o70deKQ0AKPekpetBoATpR1pR0zRQAnrR3o4paAEoB4xR3oHFACmkpeppCKACg0AUHrQAtJzmjm gcmgApfpSGgYxQA8dKKB0opFHE+Edo0wHPeuqjwcMP1rlfCeF00f73FdTEQTk+tMgtCigUUDClzS Uv1oAM0dRR+NFAB70hpemPSkNAC9qQUZPejFACigmkooAOKWkpaAAn+VHpR0o6DmgAHWk70oNFAC 5xikPSgUCgAA5pRRSDrQMWjvSfSg/WgA6cUnJpaKBBRzR60E80AL2pKOgpBQAoxmik+tLQAUnal7 0nagAoNAooAKXoKTtQelAC0lHaigBe1J3paSgANHejrS0AGKBSYpewoAKKKPpQAdTQPWgUCgYoNJ SikPXrQIXNJmjoKQdaAFHpS/SkzzS0DCjIxij1pO1AABiigUHrQIPSg0HtSd6AFpKWkoAKWk70dq AA0UUUAKaSlooAOtFJS0AFHNFHrQAh6cUtJS0DDvQOtFAoEFFFFAB3pKOlKaACiiigApKWkPQ0Ae UfFDxXqLarF4T0dtksyp5zrIys7OcJGCpBGe/qGFdp4R8GaZ4S09Y7aFHvXX/SLtuXkPUgE8hc9B /XmvMLmP7N8e1W6lLF9QjbzAxBw0QKL97nkqPw6dq9xyRSA5L4ng/wDCu9WxtPEX3iQP9alV/hQs Q+Hti6GPLyzM4jJxu81hjnPQAD8Kf8U4xJ8O9RJZlCPA5APX96gwfXrn6gU34TsrfDnTgCCVecNz nnzn96YGt4X8PLocNxc3LRS6vqErT3lwpJ3MTkIpPOxRwOnToK3wTkVwPxFutQ07VvCt9pNuLq/W 9khitv8AnqHTlc5GBgfe7dTwDW0useKSwz4SiGQM/wDE1Tj1/hpAee/BtdvirXQyojrCF2q2SP3r Z7n2r0D4hJv+H+tgYyLYuMkgcEHt9K88+CylfEOtIchkt1DANuGfMYYyeTjB5xzk57V6J8QIjN8P 9dQBifsjtx7c/wBKAML4OKv/AAh1yVK5N9JuCMxCnag7k+mePWvQumASMmvPvg3Ksngd1Uk7L2UH JJ7Kf61e+JV1c2Ohafe2UMc95b6nA8ELAkyOcqFUDqTk8ZHfnsQDofEcYn8L6tEUEgezmGxjgN8h 4Jrz34HKP7H1WQ7S5miUkHJwEyM/me//ANfT1nW/HN1pF9bN4Higje3dZJRq6McFSDtwoOR1rK+B zqdM1hFzhZojyf8AZPv7eg/HsAT/ABuO3w/pTEKVF4SQ7YB/dv713HhOJIfCOjRxhAgsosbBgcoD XDfG+MN4d0tyOl6V646xv/hXc+FXD+ENFdc4axhIz/uCgDzH4d6ra3PxL1q51do49RnLxWpnlJZS JCDEpY8nAUADsDjivYri3gvLaS2uoY5oJFKyRyKGVgexB615l43+Fb6leS6v4ckjgvZH8yW3kkZF d853ow+6xP4d+D1wtD+J+u+GLpdM8VWV3PCmRulj2XK+nJOJB054POcnpQO53/gXw83hufxBZCMp btqG+2IVgrRmNCMZOOMlTjutcR4D1WO8+Keq3OuyQJqLebDbCSX7rBwpRMnrtHGB/e9a9c07UbTV rCG+sLhJ7aZd0ciNkHsfxByCOxFefeO/hcutXUus6HIbfU2IeWENtSZh/EDxtf36HHYkkgHpMiJL G8ciK6OCrKwyGB6giuY8IeH4fDl7r9tbW5htZb0TQYUhdrRqcDJPAbcOAMcV5tonxH8R+EbmPTvF FpdT2ihgDcRbLkAd1ZmxIOnX/vqvZtL1Sy1vTINQ0+dZ7WZdyOv6gjsR0IPINAHlPxk0W4tdQsfE llIInbEDOMqySrlo2zn2I9sCvUtK1m01fSbbUYJY/LnhWXHmKdmRyDg9uR+Bqr4s0NPEfhi+0xkV pJE3Q7jjEi8oc9uQPwJryn4X6b4a1aa/0fXNFsJtTgfekk8YLSDo64PJKsufo1AHo/j3VprPwvPb 6bND/aN9IllbqW/jkO3PBBGASc+1WINEk8PeCjpOgxqLqO38uJ+BmQjBkbkdyWPfiuX0fw7oo+Kk x0nS7a1tdEtQGaGLaGuJc98YOE7dify9JoAxvDnhnTfDGlx2VjAm7avnTFfnmYD7zH+nbPFVvHih vAeugj/lzf8AlXRVz3jpd3gTXQBn/QpDjOO1AHPfB9I18HzOiYka8fecDJ+Vcc9+K3xoE+p+IG1P WmEkNrJjT7JWzEmP+Wzjo0hycf3R055rn/g4V/4QyZQQWF7JnnJ6LjNehGgQA/hXlPxJ8PJ4fltf Fugj7FdxTBJvKACkk5DEZA5I2kd816tXG/FFUb4f6iZJCm1oWAzgMRIvHvQM2vC+uxeJPD1rqSbF kcbJo1YHZIpww4J78jnoRXjcmuar4Z+IOp66sExtZNRltbhVK7ZcHOzGeGxggn8+tdr8G2z4VvEy Ni37bR6fIhP61D4a0TT/ABEnjXR76Nih1h3GAAYmI+V1OAc8HqMfXmgR6Jp2oWuq6fBf2coltp0D o47j/HtXJfEC3SfUPCnmJGVGropLFQQCCcAt67Rx34riPDerX/wx8TS6DrpY6XOdyvGAVBJwJVzg 47MOcfhXaePJImvPB92rBkGrxFGXByGU8jP4UDO66muC8I2Vv4o1S/8AFWqQ+ddJdPa2UUp3Jaxp gfKvIDE8k9fTFd4RkEcjIxxXEfCTavw6sUUEbJJlIPTPmN0+vX8aAO1lhiuIHgmiSWF1KvG6gqwP UEHqK8l0RP8AhDPi5LotoSmmX3AiMnA3KWXC56hsr9K9dryDxBGY/jnp7yOCrvbsoUAkcFcHI45G fxoQHr1LRSUCF7UlLRQMSlpKKBB3paKKBhSUtGaBBRRSCmMUUUtJSAWjikpaAEpaQ89O9HPQUwFo pKO9AC0UHkUn+NACjqaSgdaXFIBKOlFFMQUlLSUAFHaiigBe9J3oooAKXHFJR2oAWk7GjtR2oABS 0gpc8UAJSgc0UY5oAO/40fWil+tACdaO9AoNAAelJ2oNHagBe1Bo6UlAB6UYpaKAE9DS9KSjvQAU dqDR2oAKKKKADvRR3ooASjpQaWmAd6D0pO9KaAAUtIBRSAOwooFKKAEo70vSkHWgAxRSigmgA6kU GgdaQ9aAAUHNHel96AE4ooooAKO9FHbNAB0oPpR3ooAPYUfzoHBooAWgdaOpFHegANJ3oPJpRxmg Bw6UUDpRSKOJ8JgtpwwO9dVGQGAxz7dK5bwjKf7LA9/TmuphOWHvTILI6UUCigYuaTrR1pTQAdKK O1GKAEoPSg0p96AE7cUvUUDpQOaAEzigmlxSGgAPSlPSkpT2oAPrQTRQaAAUd6MdqKADpigUUZoA KKO1HegA7UUCkoAB1paPxpM0AL1ooozzQAdqTFLigUAFApB1paADvR2o7UnagBaO1J6UpNAAelJi g0p6UAJQaWigApM0etAGKAF70d6DxSc0AL60c460UAdqACjNHFBoAPSiijPNABnFHUZo4zR7UAHa k6kU7NN4NADqQCkzTsUDExRml70lAB1NJ3pelHpQIT0paKTvQAtIaUCk70AFGKKO1AC/SkFL2pKA FpOtLzRQAUd6KKACjtRRQAmKXtzR2ooAKBRSA0AL3o70d6O9ABRRRQAUUUUAFJS0UgPJfi14dubW 8tfF+liRZbcqLpkyTGV5SXHoMYY+mPc123g/xjp/jDSlubWVVukAFxbEjfG3c4yflPY/1yK6MgEc 1zOo/D7wxqV4LxtMW2uxk+fZSNbOSTkkmMjJ68nPWgCD4llR8PdWMgO0+UuBwf8AWp0zVT4Stu+H lmoPypNOF4xj96xI6nuTTrv4W6DfhFu7vWrhEJISbUpXXn2YnvzV/R/Amm6DcRSadfavFEjbvs32 5zCx9WToen40AXYbqw1TxLc2skI+3aMyPGxk5xLH94AdvvLz6VtAfNXNar4F0nV9b/tiebUYb3YI /Mtbx4flHQfKR7/mfbFceAbPKMdd8TGVU2GQ6xNub68+vPGB7UwOG+ETq3jLXMD70TNuYgs373nk Hnn+fvXoXj9lTwFru/o1o6DnHJ4H6mqVp8NNC02Uz6dcavZzNnfJBqMgL5Ofmyeeeat6t4IsdctV tdQ1HWJbdY0jMQvnVHC4wXA+83GSTnnmgDC+DZYeDJ1ONq3sgXHptQ11kGoafrGr6hpciQvc6VcR MUZgWBMausgHUfeI/A1naT4E03Qp1fTL7VraPzRI1ut6zROR6q2euBnGOmKNQ8A6RqOvS608+pQX 0oUM9revDwAAANpBxwDSGbmsyCHRNQkYlVW2kYsBkj5T2wa8x+BbsbDWUwNgeBgc88q2e/sO3c8n t17+ArVkdTrviVwwwQ2szY/nUekfDfR9BuRPpV7q1oxKGRUvDtl2HIDgg5HJ/AkdzTEYPxtwfDOm qTjN+Dwef9W/+fxrtfCTbvBuiHjP2CA8f7grL1P4eaXrNy02p6hrN0NzOsb37hIySfuquAOuPpV7 RfCdnoLxfYb7VPJiXYttNePJEBj+62cevGKBmdpviNV+JWuaBc3mQ0cE1pG7jhvLG9V5zyNrY/3j 61q+KtF0fWNCuU1m3jeCGJ3ExCB4eMlkduFPHXp68VBf+CNF1TULvULyKWS7nMbLMspR7couFMTL gqe+c5P0wKzrj4c298oh1DxL4lvLMcNazX48t1zna+FBYfUk0gMv4Mxzr4PuWYzfZ5LxmtzIuMjY u4r2xu3dMjOa17fxGLb4najoNzdBYp7WGa2SR+kvIZVye4AOPYn1rrLe3htbeO2t4kigiQJHGgwq qOAAOwrB1HwTomrarc6lqMElxcTJGiEyFTBsyQY2XDKxJyTnsKANDXNH0vW9LmtNXgiktiuS0mAY /wDaDfwketcJ8GoJYtM1d4pfM0xroLbEjlmAIdvTBHl9O4NbEnw3guYxDd+KPFF1a5Ja3m1HKOCQ cMQoYjgdTxXWafp9ppVhDY2FulvawrtjjQYAH+PfPc0AWa8R8dQzeCfiTaeIbJVENyWuNm8rvccS qT6Hcp+pr26sjX/Dlj4jis470yAWlylymw4yVPQ+x6GgCj4F0i60nwzGb9i2oXsr3t0SuD5kh3EH 3AwPwrpaO9FABXP+OH8vwNrjbip+xScgdOK6Cue8QeFF8Rkpc63q8FocbrS1ljSN8dm+QswPcE4o A5v4N8eELoDBX7a+3pn7q9QCcc+ta9p4m8j4h6roGoTiNZFhl08SMqhsoA6rzkndyB/velM0X4fR +H1aPTfEeuQwM6yPEZIGViPrFkZxg4xmreqeBtG1rWbnUtTh+0SywpFHj5Gg25+ZGGCDz17YoEdL XmvxW1kT2lt4V08m41O+mRmgjOSqAgjdzxk469gT2ral8F6r5bQReONfW1ZQNpMTSDHTEuwN6e57 mr3hvwXpfhmSa5ga4u9QnJMt9eSeZM+cZG7HTgUDH+DvD3/CM+GLTTWZXnXdJO69GkY5P4DOPoKx fAW7/hIPGQUIIRqpwNoD7tvOcHp6cevJ5rrtRspb628mHUbuwbOTLa+XuIwRj51Yd/TPFc3pHw/h 0O8mubLxHryvO6vOHmhcTEHPzZi9yCRg4oAu+MvCNr4v0gWszCK5hJe3nAGUYjGDkH5Txkew9K8d sdV1SC/0jwpqal30vWIWh3kBkAJGz5m+7yCp9OB2r6Frk/FXw90XxddR3V49zbXCIUaW0ZFMq9g2 5Wzjt9TQB1YPzcetcL8JMDwKiDGEuplyMAnDdSATgnr1/TFasPhK6gsBYx+LvEPkBdoy9uXA9N5h 3fjnNM8O+CIfDEYh07W9V+zeb5rwS+QyyHGDk+VuwcDoR0oA6mvIvFUiJ8a9IfeMj7OGztwuWYDv 7/8A669VvbaS7s5IIrye0d8AT2+zevPbcrD9K4uf4WWN1qQ1K48Q689/uD/aBLCG3DoRiLjHb0oA 7yiqthaTWduY59Qub59xPm3Kxhsen7tFGPwzVqgApKWigApKWgUAFJS0GgAoooNAgoFA60AYoGLS d6M0UAHeg8jilpO1AB6UvWiimAetFIOnNLQAetJ3o5BpfagA70nel70lIAooo70xBSYpaKAE70HP YDr60GigAozzR70d6ACjtRS0AGM0dqSjJoABRRS0AANFA5o70AFL3pKM8UAFFAooATtSjoaQnNA4 FAC4oFH40lAC5xSZoPpS9qAEo70Ud6AD0o6CigdKACg9KKXNACdqKKD1oATtS9qMYFFMAHWg0dTR SABRS5pDzQAtFIBhQM9PWg9aADHNKKO1IMUALSdqBR2oAXFJ0paQ9c0AHWg5pRSHrQAUGkFL7UAF KKQ9aTtQAveijNGMigAFHSiigABpR1pO9HegBTRSGlFADh0ooHSikUcX4SI/spRn+I8V00BBPB+b 0Ncv4UYjSFx/e5FdPAvzA802QXaKQUvagYnpS96TrS9KACijNHagBPxpc5oxR9KAEFL0oA4pKAFN JxRQaAA0tJ3o70AL/Oj60c0GgBaT1oHajvQAelAopB0oAX0oNGeaKADHFBo7UGgBO9LSYo6GgBTS d6XrR3oAKOlFHFACd6XNAoxQAnejtRRQAelL1pOoFL70ABoHSikzxQAtB6UlFAC0gpaB1oAQ9aWk 70ueaACg0DmigYcUZpMUvegQmOKUdaO3NA60AAGO9FFANABSd6XNHfFAAcZxS9BSd6CTjgZNAxRS c9jRRQAD3pO9L9aTuKBC0Z70hJ4pe9AB60nSiloABSdqOtL2oAD0pBSnpRQAlL2oo5oAKKB0oxQA GjtSAYH+NB9aADtSmkoNAB3paB1oFAB3oNHej6UAFJS0djQAUCkpaAA0UGjFACUUtJQAUtJRQAdq O9HajvQACjvRRQAtFHaikMKKKO9ABR2paSgAFLSCl70AGKTtSM6xqzuyqijLMTgADuagstQs9TtV utPu7e7t2JCy28gkQkdcEcUAWO1FHaimAUVHPcQWkLTXM0cMS43PIwVRk4HJ9yBUQ1GxaIyi9tjG DguJVwDnHXPqCPwpAWe9FNjdJY1kjdXRwCrKcgg9CDTqACk70tBoAKKKKACiiigBO9L3oNHegAoo ooAKQ0tFAB2opaO1ACUU10WVGR1DKwwQe4p1AB2oooxQAUUUUAFBoo7UAJmlo7UUxB3pBzS0dqBh iiikNADu1JijpS9KQBQaQ9KWmAdqBSdqBQAo70nr9aX1NJQAtJQKKADFHegdKDQIKKKKAEooooAW k70GigAooo7UALxSUUUAFL2pKXtQAUg5o7UUAFLmkxRnigBRQc0D0oPWgA6ijikIooAXFJ3pTzQB QAdqKT0zQelABR3pKXIz0oAKBQetHagA9qWkooAKKXrTaAFPSj0oooAOKKTHNKaAFFNpR0ooAU0l HWjNAC+lHrSUAUAFKKQdaDxQAUY60CloAQUH60ZoPWgA9aXHNN5FLnmgA75oHOaDQDgUAGKKKKAF oI5pB1o5oAWkHWjvRznNACmgdKDQKAHDpRQOlFIo47wmANJGcZ3HmulhBJU4rlvC5YaUgyNu4/Wu mhc8CmQXAc0GgUYoGFL2pOlKaADtyKSl6ijtQAhoxxS0HoKAEzxRmjHFHOKYC0nagdKKQAaCOlHe gnigBaTtS0HpQAelHQ5ozxSck0AKKO1FJ2oAXPIpPSl70d6AD60HnFFBoATqaCKORS0AJ2opewo6 0AAooHSigBO9LSd6WgBB0NHalpDQAtJ2oz2pcdKAA9KOgoNHbmgBKKWk9KAFoFFJigBe9HWkNL3o AMUo6UlA78mgA6Ucc0vemnrQAvbNFJziloAKBR65pMGgB1N53dRjFKaTtQAozxSikpRQMMc9aKBS HigQmKM4xR70d6AF9KDxSE0UAANFHGaM0AHtS0UUAB7UnSg0daAD3paSlxzQAlLR2pfagBKSl4FJ +FAB6Upo6UY/OgAoFGKBQAdDR3pO9L3oAOhoxmjrSUALRR24ooAKKD0ooATNH0oooAWikooAO1FH ajv+FAC0UUUAHaloopDEpaKBQAlJTqSmIAKD1o7UHtQM5D4mawdJ8D3yxsv2q+H2OBT1Zn4OP+A7 q2/DmkRaD4c0/S4U2rbQqpGc/N1Y59yTXI+IN/iL4p6LoqbfsukJ/aNyRkkv/AvoMYU+vzV6EKAE LqpAZlBPQE9aRZY2GVkQj2YVzfi7wLpXjT7EdTkuU+x7/L8hlGd+3Odyn+6KwLD4L+G9O1O0v4br UTLbSpMiu8WCynPOIwcE46YpAehyxxzRtHLGro3BVhkH8K8Z8HaFpL/F/XYZNOtHjt2naBPKXZH8 6gAKBjgMRXtJryLwJJn4weJQpBVmuTwOOJl6H8aAPXAAAAAAB0FLSUUALSGlpO9ABRSYGc456Zpa AA0UUUAFHekpe9AB1o7UUGgBaSiigBaKKSgAHWgUvegUAFFGKSgBTSUtHagApKWkPAoAKO9H1o70 AL3pKWkoAKKKKAFoo70UAJ3paSjtxTAU9KBR25pAOaAFPIoo70HrQAg6mjvxS4waKAEoPWgUHigQ YpKAOc0tACUUUUAFHeijNAB2o7UUcYoAWk7UYoHQ0AFKOKQCloAKTvS96SgApe1IKM80AL0o70Um OaAFopOtL7UAHrSUetKOtABRR0pOooAKD1oxRQAdaO1FFAAOKO1HaigA70UUUAL2pKM8UnWgApTR R1oAMUUCg/SgApKWkoAWj2o70YBoAUYpDRQaAFHXpRSd6OxoAXjNBHWjvSE0AGaO9FHvTAPejvRn JoFAB3ooPWikAdKKOpopgKOaO+KBQOtIAPFC0GgGgY4dKKB0opDON8Jxj+ykGO/rXSRphwAPxrnf CTf8ShOxziuoTJOetNkEoo9KBSmgYnQ0tFGeaAAZxRS9qSgAo7UZ60hoAByKWjPFGaAE5o5xilzQ TQAnvSUp9uTSKW2jeAG7gHIpgOoPSko6UgFo70elBODQAUn0oBo9KAF6GgUY5oFAB2ooo6UAIT2o 6HFA5zRmgBx6GkHWmBAqBQTgdOT/ADpwUhmJcnPQHGBQMUnFH0peKSgQgHNL0FIDzS/WgA7UlFHv QAUpzSUp7UAFHak7UUALSdqU0h6UAFFFAoAXvRR6UUAIKKO1L3oAB/WjqaP8aKAE7UoPpSdqWgA/ Cij2oGaAAUneloOM0AFFHpQOlABxRiik5oAD0o64oHQ0dxQAHtRR9aDTAKXFGRRnmkAUlA60tACG gdKWkoAKWikoAXNJzmlFGKACj3ooPegYdaKKO1Ag60UgpNq79+0bsYzjnFADqO9FHegBKKBSkc0A GaO1JS0ABPFJS0nagApe1J2pc0AJR2paQUAHag9aXtSUAKKKB0ooABS0lLSGFA60UCgA6ikozRTA BzQxCgsxAUDJJ7UVS1jTzq2j3mnC4a3+1QtCZVAJUMMHAPsTSA4v4XhtW/tzxXNlpNUvWERYNlYU 4VeSRgZxgen5ddr2vWPhzTHvb6TgDEUKYMk79kRf4mPpXn8XwTtokZV8Sago7CONFCjJIwPx/Grm k/B+w0zWrLUZdYvrz7LIJFinVSCRyOeowQDx6UAeiQPI8Ebyx+XIygsmc7T3Ge9PoPSjIpgFeS+A UUfFnxTsYYD3HGOuZh/h/wDqr1uuDtfhhZDxDf6xe6leSPdXEsqxWrm2VVc/dZkO9vzAPcUgO7op kMMdtBFBEu2ONQijJOABgcnmn0AFBoo5zQAdqDRQaACjvRRQAUd6KO9AC0lKaKAEOecdaO1HeimA tJSiikAlApaSgBaSlpKAFpO1LSUAHajtS0hoAKKKOlABRRQOuKYBRRQaQBRR3o60ABoPTilopgJ2 oGaOtA6GgBaQ0oPBpD1oAXvmjnFHWgc0AJ3o60UGgQUUUUAJRRzmigApKWigAzRRR2oAMUtIKO1A AOtLmkFA6UAL/Ok60UZ5oAKXtSAil9aAE6UvQ0npRQAUdBRjijFAAetFHNGOaAD0opcdKQ9KACii g0AFHag0dqACiijpQAYoo6UdqACjpSUvagAoNFBoAUUmaAaKACijpRQADrR0o7UD0oAKOaWkHPFA B1opecUg70AFB5o60e1ACUtFHfNMA6c0DNGKBSAXFJR0ooAMUe1ApTQAgHNLQO1HfFAATzQKQ9qU CgBw6UUDpRSKOO8JMTpSDHOa6mPoOc1y3hI/8SlSQCM9a6iIfKKbIJhS44pB0xS0DDvRjik+lKKA DtRS+lJmgAxR2pDR2oAO1H1oo70wDvSmkFB5pAHeg0UdKYBQe1Bo9KQBQetAOKKAFHSk96UCk6Cg Be9FHeigBKMml7UmaAFHeg0gooAWk70tJ3oAXNHajtSdRQAUuDSDk0tACUUCj+GgBaD2pKDQAUue KSjtQAtIeKKPSgAoHWlNFACZpTSd6XNAB2oPSgZxR1oATOfzo70cdaOtABSijBPejuaADNA78mgG jtQAdaOtAo70AJ1NLik9M0vagAHU0UUc4oAT1oz0oFHGaADOTRg5pcUh6UAL0oNHejHrQAnfNL2p O9L7UAB6ZpAaDRigBTSdqKWgAoFHSj6UAHtQaWk/nQAdqDR/OjrQMMcigcUDrQKAA9aKO9FAhKWk zzS0AJS0nel7UABpKWkoAKWkooAWg0UUAJ2oI5oo70ALQRR2ooAO1FApaQwoooNACUUUUxAKDS0h 6igYvejFJjnNLmkAlBpR0opgFFFApAJS0UlABQaKDQAUhFLRTEHpRRRSAKO9Bo70DFpD0paSgA9q KO9J70xDqTHNKKSkMKKKOlABS0dqSgBaQ9aWg9KADvSUtHagAApKKM80wDvQKO/FAORQAd6Diijo KADpR2paSkAdOtLmk+lHamAdjQKXtSDnrQAdj6UYo60dKBCikFLSdqBgKD1oHFBHNAgoooHSgApK WkoADQaKKAAdaWk70Z4oAKO1HagdKAAUvWm07PpQAfWk70ue1JQAvXtRSZpaAA9qQ9aWkNABR25o o7UwFGaQUUA4pAKaTPFKTSYoAKDR1NHrQAUUe9HQUAFGaSloAKKPSkoAXtSUdqKYCig0mec0p6Ug A0UAUUAFJS0hpgL2oHWjtQKQAKO9HejvQAoo6ikFHagANLSDFFAB2NLSDvS0AHekzigUUAGKOaKD 0oAOlFGKKYC0lL/OkzSAPSlFIe1KO9ADh0ooHSikUcb4RDDSFzuxniupizjr+Fcv4ROdHTPrXUxd MAHH0pkEo60UoooGIeKWkNLQAo6Ug60tNoAOtHWl70de1ACdqXNJzijtQAvaigUhoAWkooNAB2o6 UZ5oPUUAA60YpeBSd+aAFFBNApAKAFo+tFJQAY4zQO9L2ooAQUHrRS0AJ2o9cUdqXqaAExRS9qMU AIPWl9aSloAOwpO1FL2oAOtJR1oNAC0dqMUnagBfaiijtQAEUlFAGDQAvaikpe9AB2oAoHWigA6U UYooAQ0ooHvRxnpQAA84FMdmGcDt1608Yo60AIucDPXvRS0negBRR2o70dsUAFBo70lAB2oHWj1o pgLnOKOlJz3POaXPakAnYmlzzR2o70AFA5pO9KOlAAaTPNLSDGKACgijpS9qAD1paSjvQMWkJ4pa T2oEHFHvR29aDQMBRQODR1oEFJ0ozg0tACd6BSiigAooBooAD0pKKWgBKKM0Z4oAWkpaSgA7Ud+a O1BHNAC0UCigAH1paToDS0DDtRRRSAKTrRR2NMBRQaBQetAB2oo60YpAIPu0ZPSlHSkNMBaKD1FJ SAKKWkoAO9HejtR3pgHFFHaigQUUUUhhRRR3piFNFJ9KXOKQwpO9FHamAtJ3pcUnuKQC0nvS0UAB opKO1AC0lLSUAL6UlFFAC96KSloASijNGaYB3oNHSgUCCl7UUnWgYdOKDjFBpSOKAEoFHagHmgBc dqKTrS9KADPNJSj1pO9AC9sUhoHIoPWgAooFH1oEHeko+lFABRRRQAUdqO9HagBcUmaWk7UAApel JR0oAMUUo6mjvQAh/rR2ozS5zQAUnajtS0AIe1KOlIfpS9qADODQetB60A5NAAfakpe9B6UANpe9 FJTAXrR2oxSdqAF70ZpKXtSAKKO9FAB60lKelFACHrS0Y5oNMAFHegUHrSAO9HWikpgLQKBRSAUU h/Wgc0daACjpxR0ooAPwopRmk5zQAcijvRRQAd6UUlAoAU0hpc80UAIOOKOlL9aSgBe4o6Gj04pO 9ACntQMUhHSlHSgBw6UUDpRSKOO8IbTo6Z65711KEfdFcp4TI/shG56muqjAwCP1NNkEw6UelFGO KBhS80lHWgBaOlFIetAC0E8UZpO1ABQOtGaB0oAUUhGM0opO1AAe1FFLQAlHal70h7UAL1oo7Zo4 NABSUuPWkPWgBec0dKKBQAlFFFAAKOKDQKACjvS9qTFABnijORQelHagAzRRS+1ACUdqBR2oAO1F FFAC9KTig0vYUAJQaMe9BxigApc0Ug60AFLSEZpaAEFL2prZAJAyRS5470ALnFHegjNJ3oAUdKAe aSgUALSZ4xR3oxigBR0xSd6O9Gc0AHel5IpM4oFAC0dqBRQACkooxyKAA9aXtSdaM0AL2ozzmjvR 60AHU0dqKO1AAc0gpe1JQAvek7UpFFAATxR2o70e1ABmjrRRQAUdRRRQAnelHejIooAKKO9HegBK KKKAF70UlLigAPSkpaKACkozS0AJ2o7UYooAM4FL3pKO9AC0lLmk60AKBxRRR1NAC0DjNFGKQwpK KMUwFo70c0c5pAHrSZoxRTAP4aKO1B6UAL3pKO9FIA70UUZoABRigelBpgFFICDntg0tIAooo70C CjvQaO9MYUYo70UgDvijFL3pPWgBaTPFLSUwA0daKBQAdqO1FHagBRRSUdqQC96Q0elB6UAGeKKT FL3piDFGOaM80g6mgBe9FFFAB2o7UtJ2oGBpTSUUCDoKBkA0etHWgA7UUUGgYo70lKCKTPpQAUHm lHSkPWgQUdqKKAE70UYooAKO9BooAKO1FHagBaO1FJQAelFA5o6UALxmik6fnR3oAKKWkxQADpR6 UdKOtAB2opKUcCmAHrQOtKaB16UgEIo7Upo6UAJ7ZpO9APNKetMA70duKDijtSABRQOtGeKAA0UY 6UelACUtJS9qYBQTR1NJQAooNAozSAPagUUlAC9KM8UUd6AAdaWko7UAHfmjFAozxQAtBptLQAlL SHrSnrTAO9LSUAmgApOaU8mlxxSATtRRxQaAF780gPNKOaTvQApoHSg9qB3oAcOlFA6UUijjvCH/ ACBk6jDHFdPGGDABhjHNcv4QDLpCYPG7oRXVLnggfnTIJaX0pBS0DDH4UnY0Z4ooAdTaXtR2FACY opaO1ACdqKBwKKAAdKSlHFB6UxCd6XvRiloGJR9aU0h5FIAJ4ooHNHQ0wF5pDSikpALijvRmkyKA ClpD7UtAB2pKM9qU0AJRQe9FAAaM0dqMcUwDjNHNJS+tIAHWjpS0hoAOwpTSY4pe1ACGg0p6UnYU AL2pM96KOaAFpO9L65pOtAAeoo70vQ0GgAo7UAUdRQAZpPWl7UnegAFGaXtSDrQAUZpc0dRQACk4 6UCigAxzS9qQYNHagBRSZo9aXtQAlHpS0ZoAT0oxS0UAHSjFHeigA6UdqKXtQAhptPbkUmaAE5pR 06UUcUAAoo7Ud80AHejtRR2x3oAKMd6MUcGgYnelFGMUDrQIO9GOaO9FABiiijvQAlLSUo6UABpK U0lAAKKKPSgBaSj27UUAHaiijvQAClzRSdKAFHeigc0ZoAO/FHNL3o70DEopaSgBRQeoooPWgAHF IDSikFAC9qQ80uKSgAI5o+tL6UhpAFFL3pKAAUUUYpiDpQaOlFAwo70CigQGjvRRnJoAOlGaDjNK aQxO9A9KXvSYpgLSY/KlzxRmkAlFGc0dRTEGeDQaO1FAwooooAKD0opaQCUd6KO9MAApKXHNFAgp O9LRQAcdaO1FAFAw70UHiigQUUHpRQApANJ2o55pe1Awx2pPwoHU0ZwaAFGaQiilPvQAgFFANHeg QnSilo7UAJR3oooAKOtHagjAoAWk7UvakHFABSjpSUvUYoAMik6GigUAKOtFANFAAaSgUUAJS9qK OxpgHel70lL3pAH1pDzQeTSn2oATpQetFIaYCnpSdqX0oNIAFFA6UZ4oAWk74oPSkoAKKWjvmmAd DQaKQ0gFopBS4oAKQUooNABRijtRQAZpegpKO3NAC0lA6ZoPWgAopQaQ0AJS96SlpgFH0pKXFIAo o6NRQAAUUoo70AJ3pe9Bo4oAQ9qOcHFL6UDgE0AETbo1b1GaKIVKQop6gAUUijkvCg/4ksRx1Jrp oyCBg4rmPCfzaNHjnk9K6SM7QM/SmQWulB6UCkNAwpaQUvGKAAdKKDxijqaACg0h68UGgBRRQOma T8KADtQaKSmIXFB6UZ5opDF+tIelKaQk0AFLSUooATFFKKMjFAAOuKQ9aUcmkoAKKKB1pgFFFGKA DNAo7UY5pALRQelJQAmKUUd6WgApOlHpR1oABS5pKM0ALmkoxR+NAC9qSl6GkNAAKWjpSCgBe4oz 3pM0dcUAHvS44pO9L260AGMUd6Q9aO9ABgigdaUe9J3oAXHOaSgGjNABR1oziigAxxS9qSl7UAJR RRQAoPrSdxRjv1ooAU9RR3pKWgAHSlpCc0maAF75o7UUdqACk4oPSlFACUuKCO1AoAMUvtSd6Oh6 UDDoaD3oPrR1oEHagnig0UDCgd6B1ooEB60d6OhxSd80AHeiilxQAYoo70UABpKU9KKAEooooAWk 6UUtABmko7UUALSdqO1LQADiigUUDDpS0lLQADiko6g0Z7UAKOvtR3FAo70AHegGijFIAo70dqSm Ad6WigdKQCUGiloAQUZ5oopiDtRRQaQwo/Cg0UAFHeg5NFMQd6M8UUGgYCg8UCk/lQIdRQKKBiUd qOlFAg6CjtQTRSGLRSUZ4oAKO1FBpiCg9c0UelAC0g96M80g6UDF9KWkoNAC0lHvRnIoAKOlFFAg HSjt9KO1HagYDgUdaKKAFHek/Cgd6AcUAHbNB60daD1oAMUlOpKBBSdqWk7UAFFKaTvQAdqWk7Ud qAFpOooNAPWgAFKKTvS4oAKQUtJ1oAOlL6Un0ooAKSl70YpgBoHSgjmjtQAHFL2pDR/KkAuRQTnp SHpS9qAE70d6KOKAFPSk7UUdqADpRRRQAUUZ5ooATtS4xRRnNAAOaDzRSGmAtBoopAHFHeiigAoH WigUAFLnPFIKOvNACjikNFHSgAoJpKU0wDPWikpe+KACgGkJxSgc0AJ3paO9FABRjvRQeaQCigda QcUvSgBMc0q0Gj9aAHDpRQOlFIo47woP+JQgUgfNzXTogwOSa5rwiQujx49TmukR1VgM/NjpTILI pO1KKKBgDR2pPSloAKKO1HWgAI6UHpR9KQcKOScDqe9AAOhoNKBxSUAANHrQKDTEFKelJS5pDExz RRRjigA60Z5pe1A9aAExQO9KaTP60AL3FJzml7igCgBMUUUpxQAn86DSUuaYC54pAeaO1FIAzmgd KD0ozQAd6WmjrTulAAOlNpe1HagBaSj0ooAWkPQUvak7UALjmkPbFLzSGgANLRn1pKAF70HqKO9H cUAJilxR0ooAQc0p55pKX0oATrR3oo7c0ALSdqKM0AFHNL1o60AJ3oozyeDQKADpS5opKAClziko oAPxo6UYpTQAlKetJS+tAAOuaOcUnel7c0AB6Unalo+lAAaMUd6PQUAKKTpQOlBoGH1o7UHrRjrQ IT1pe2KTPFLQADg0ZFFHegA70d6OlFACUtHeigBO+aXtSdTS4oAKQ8Anr7UppKAFzkdKTNAooAKK BR2oAO1GaOwooAUUGiigAHSjvR2o70AJS9aWjvQMSg0dqM0AKKKBQTikAYoozmkx3pgL1FIfrSjp SYoAXvSCjvQKACjFFFIA9KTv7UUdDTELQaSloAKKKKQwxS96TvigdaYC0nWlxSGkAY5o9qCaSmIc KSjtRQMKPwoJozQIKKDR2oAKKKKBhSHpS0h6UCFHFHeko70AKKKMUUDCijvQaBBRS/WkoGHejtQe tBxQIO2aB1o9qKADHWig0UAGOaOlA70A5NAB2o70YoI5oAWkHrRRQAGko6CjmgBTSUGjvQAUuKTN HagAoNHejtQAlOFNp1AB3pBnNLSUAGKOtHWloAQijpxQDQetAAaUdKbSjpimAvrSCiikAGgnijtR QAUd6BR3oAUik7UGjtQAUUdqKYB3oGaO9JQAtHekpe1ABjmg0Cg9qQAKDQKKACjvRikpgL6UAc0D pQKQBRmjBwcUnRcnNMBwpDRzR2pABNFHWjFMBKXrRS96QCY5oAAPAx2pe9A5oATvSng0mOaWgA70 mKUCgetACUvegUnQ0AFKOaQ0AUAPHSigdKKRRxvhOOUaLERJwTkAgfzrp44xnL4JPU+tc/4Tx/Yk IAAOSP1roowdw9B+tMgm+lLnmk75oxQMMc0Hml6UUAGelGeKOKMZNAAelIelKelHWgBO1HWgDijH egAHSjGKKU96YCcGg9KSl9KAFIpO1BoPakAUvOaTOKBnNAC0nalzQKADPNJmlAwaTtQAvakNGOKO 9AB9KKKKYg9aUdaTrR3pDF70nag0DFAAOtKRSd6KAFpDRRQAdBR1pcUmelAAehpaDwKTNAC0lHf6 0GgBabS0UAHWlB6UhAz6UoFACdaXoKKD0oATHNKeDQOaD3oATnFAzR0FA4oAM+tFFLQAlGeaUUh6 0AB60AcYo70o6UAA7ikI5ozQKACjnpQOBR3FABQaKDQAtHekoz3oAXvRRjmigBTTDuGcYNOPSkFA Bk4GaXpR3o9aAFB/CkPSkFLQAc5pD3pTyaMUAJ2pcUnocUpoAKBjNApMcmgBT1oNHejvQAnelpOM 0UALQKKKAA0lKelFACUUvakxQAUUYooABR0o7UHrQAZoozgUUAKKOKBR60DDPNFFLigA7UlLSUAK OaD70Cg9aAAYoBoHU0nvQAvakPSlHSkNAC0lLSdqACjrRRSAKQ0UtMQdqSlpDQAtFJ3pe9ACUvej qKO9AwopT2pKQBRQaTHpTAd3pD6Uv86SgAo60tNAoAXtR0FHY0dqACk60tIKBCig0UGgBKKWigAo BopO1AC0E80dMUlADulJRRQAdKCaKDyKADAx1oGcUDpR9KBiUuaOOaOtAg70g60tFAAOBQetHQ0E c0AHeiikoAWkzQfWigAyaDR3oPWgApe1JR0oAM0UUnagBaOaB60ZyKADvQM5xRzmgUAFFGaDTAOK OtGOlBoAQ0vakooAWgUUDrQApo7UHNJSASloFB60AHvR7UUdqAEpaSimAuKTvS0lAAaKO1FAB3pT Sd6U0ALjikpfSkpAFGeaKSgBe1A5ooHWgAHSiiigAzS9jSCjtQAfhS9uaTNHWgA70UdqB1pgL3op KUUgA0dqTvS0AHbik6UopKAFxRn2ozSZyaADtzSj2pD0pR7UAOHSigdKKRRynhI50OHAwcnqPeul XoP51zfhMf8AEkg/Hn8a6VRwKZA6ijpRmgYvajFJiloAKSlooATrS9qOxpPSgA7UdqUHIpMdqAAc 0pFANJ2oACcmg8e9GBkUpxQAmaXANGOaM0AJ3pT1ooNABR+NGKQUALRj3pM8jNL1xQAlFFHSmAna lo6Gl70gE6iiil70AIeAMnmk7U7GQKCKAE60DrQKKACjtRQaAFpOlFFAAaOvNLRQAUhNL2pM0AKa QUtJQAHrTqTHNHWgAPejPFKelIOnNAwHX2ooo70CEHWijrQKAF9eKBR3pOKAFpO9KKQ9aADHcUop KO1AAOtHUUCigAxSelO4zSe9ABS0mKO9AAaXA6Uneg9aAF60DpSYpc9qAA+tJ1oNA4oAXvRiiigB QBSdDQD7UcGgA96SlPWgmgBOwoozSmgBBnNLR+NAoAO9HekFL3oASlpM0ZoAXNFJS0AFFBpO9ABR RQelABRRQaADtR3o7Ud6ADjFFFFACjpR3pBS0AL2ooo70hiZo6iiimIUUd6KO9AxO5opaPSgBB92 il7UlABRR6UZoAO9FJS9qBBSUtJ3oAOcUtJS0AIaXFBpKAHUneg0Z5oAU0h6UppKQwxzR0o70UwF 70lHeigA70CijFAgoo7GigAoooAoAKDRSGgAxxRRRQAtJRR2oAX8aOtFHSgA7UCiigANHaigdKAC igf0oFAw7UtJ3ooAUUnagdTSGgQozQaOc0UDCk7UtFAhOaKWkoAKDR3oNABRRR2oAKKKO1ABRRRx QAUZoooAOM0YwaPSigAoI6UUUwA0dqD0ozxQAetHejp170ZGaACiilpAJQaKDQAUnalpO1MBRzR0 oFFIANHeikpgBooooAKPSl70HpQAA80GjtR3pAFFHvR3oABRmiimACigd6O1IA96KBRxQAnO72pe 9FFMBKXPNHejvQAnenZ60lKKQAaQetBooAM0Ue1FAB6UooFFACUDmilHAoAcOlFC9KKRRy3hQf8A EjgweTnI/GujQn0rm/CZzokPfGePSukj6UyCQc0n0oooGLR2pO9HegBQKKKKAENBpaQngUAA6UCg UdqAFB5pDQKU9KAE70uKTpSnigBKXNHeg4oATNAzRR3JpgL1o7GkzxR60gClFHUiigApKXrSdKAE 70tHegYpgLRSUvFIBKKX0pKADvRQKXvQAgoPNGOKSgBe1FFFMA96PrRS9qQBSY4oxmg0AKKTOKWj jvQAc5o/nQetAoAM5pDS9KTtmgBe1JQaWgAGMe9HNIBSjigBKKWkwKACilpDQADigdKO1KKAD6Ug o9qKADvijHvQO9HegBO1LR6UZoAXtRn2pO9LmgBOpoFA4NKcc0AB6e9IBS0UAA60EEUZo/nQADJF BpPXFO7UAIeuaO1L/Ok70AHAFKaTtR2oGHekFAozzQIBgUtJ3paADNGaO9J+FAB3pe1Hej2oAO1F BpKAFxRRR2oASilpKADtRmjtRQACigUdKAFHSg0Z4ooABS0lAoGHajFFBoEKPajvQOlHekMBmiju aQcUwAUppO1FAC980lLSfjSAKMUd6DTEGKSlpDQAYooo9KAFooo70AFHOaKO9AC+lFHWjpSGFJ35 pTSdjTAWkxSikoAO9J9KUUUCA9KO1HajrQAUlLRQAUhpaQ0ALRRR70AFJ9KBRQAUp60lB60AL3oH SjtR2oGBFLSUdqAAc0d6AOKByTQIPWigd80ZoAUCkPTilHWk+lAwHPWigHAoPWgA60dRR346Ue9A gpKU0goACKMUUpoASg9KO9FABR2o5o7UAIB60vQUUdqYBQKO9HekAUdqKDQAfSkpfaimAhpe1IaX tQAuabS460UAFGKPSikAd6SlFBpgGaKKKQBQKXFJ6UAHek7UvejvTATtiil7UnWgApTSUpoASlNA FB4pAHakpRSUwFAoFHQ0UAHeiiigApKXrRQAAUnSl7mj1oAT1paSl60AHegUnelAoAO9FHFGMUgF pKBQTzQAvpR3pM0DvQAYpR0pDilA4oAcOlFA6UUijlvCmRo1vzxz1+tdImMCuc8JkHQ7c/X+ddGO gpkDh1o/lS4pMUDDrS9KTpS+5oAO1Jil7UlACgjig88UZpDQAo6UhxS0mKADFL3xRmg96AAjpRSd 6DQAp60h6ClNB9DQAg6CloB4zRmgAHvSUD3oH0oAXpRRnJooASjNGaDTAOnWlxzSD0oJpALSd6M0 d6AFNGOKMcUUAJ3o70Uc0AA6UdaO1GKAACjtQOlLQAnrS9qKTtQAdKPSjig0AL3NJzxSgcmk70AG cml6UHFB6+9ACGl7UgFLQADrRnJozSZy1AC54oFJRmgAPWlA6UmKKACjvRTWUOCpzg+hIP5igB3O aXPFIKBQAtH4UnNL1oASk70oo9KADsKOtB7UUAGaXgUdaMc0AHvR2pBSnkUABpKU+tIKAFo4ooPF AB3oBo9aXHNACcZoNGOaDQAdqWk6ijsKBhQKKBQITrSjrik70vegBO9FHejvQAUv0oHpRQAUUUUA FIetLSUALSUuaBQAnajvSikPWgApaTFHSgBR0ooooAKWk70vegYCko7UlADgDS96TvQSM0gDvRQK BTAB0pD1oHSigAPUUDilpBQAdaPWlpKQCUd6PSimIKWig0AFFFFIAo70GjvTAXFB/lRSUDFHPNIa Mc5o96AFpKdTaQB9KT1peKSmIUdKKO1FABR0oPWigAoPSikpABpaSj60wDvS0h60CgA70HrR3oNA C0UUdaAA0dqKKADtR2NAoxQAAdaCMUdqKAAUDrQO9IKAHHijvxSUHrQAhIzil7UY4o6UAIetFFL2 oASlPWg0UAJRjiiigAo7UUUAFFGKKACgdaO9HU+1AB70cZo6Ck70wF96KPSjigBKXt1pOtHagBx7 0g60UdKQC4pDRzR2FAAKCOaUdc0mKAAjFHag0dqACiijtQAUlLRQAlLSHpS5pgHegmkpT0oAM0lL RmkAlKaKBTAKB1o6UCkAA0nWlpO1MBRRRRQAd6KKDQAfhR3o9aKQAcUo6UlHWgA79KD1pT1ooAMU 2nZxSd6AFpO9L3FIetAC4FApKAetADx0ooHSikUcv4RDDQIM4749a6NemPSuc8JgjQ4PbI/WuiU4 wKZA8GjnNFB6UDClxzSelLQAdqKWk7UDCk6iloPFAhO1GTSgZFAHFACdRig8UHrRQAd6U4xSd6U4 oAQk0H2pT7UdsUAJnilopqsrZwQcHHFADhg0nrS9qT1oAM80vekxzSgH1oASg9aKKYB0o7miigA6 ijvR70ufakAUntS9qSgAozmjvR60AFFFFABQaPSg/pQAZo+tB6UdRQAtJS54pO1ABS455pMdaXvQ AEYoxzSE0d6AF+lA6UY5oHSgYHrR9KTvR3oEHpRQPWigAHFAGKOaDQAe1FFJQAtGOKKUdKAAUnaj NHagAHSjnNA9aKAFPajvScZFFAB/Ol6Ck70p6CgBOtFApe3tQAnWl6Uh6UdaAFoNGKXtQAgpc0nr R0oAXpSHpR3pDQAvajpSUfWgBRSCil60AAozQeDQetACd6KM80UAFLzQO9FAB2pKWjHNAADxSUvS igBMUUopKADtRR2ooAKO1Ao7UAKKKB0ooAO1HNLSA80DFopM8dKSgBaXjNA9aD1oAB3pKB1NL3oA QdBR24pe1HagA70lLjNJSAO9FAopiCkNLQetACUpooNACUveikHU0ALQaKM80DFpPel7UhFAC02l +lJ1FAh1HegdKD1oGFJRR2oAKMUdqKBB3oNLSdaACk7UtJ2oAKCaKO9AB1NFFAoAAKM80tIaAFo7 UUdKACgikPSl7UAA/Wkpfaj1oAD3oAxijNLQAg60dKUd6Tr0oGFBo7UY70CAUGlFHagYnSkpe1Hp QITvSmig9aAENHajtR2oAOtHaijtQACikpaADvRmiigBKU0elFMApKX2pO+aAA0vajqKO1ABR6Uv WgGkAmPyo96KMZBoAKTvxSijpTAWkoo4pAFJS8Uds0wCiiigBO1LxRQKACg9qB1oIoAKMUCg0gEF FLSUwCil9KOpoAO1GMikpRQAUlLRjtQAUcUYooABR/FxRxijHNIA+tHalpKADvSntSelFACikPWg elFAC0nel70negApV6UhpRQA4dKKB0opFHL+FGP9iwc8Hn9a6NT69a5vwsB/YtsAeQP610iY2imQ O70UveigYlL24pO1L3oAO1FGc0hoAKDS0lAC0ZFJRQAUp6UgpccUAIe1LnNJ7UdKAFzxQaO1IaAF B4poTDkjv2paOlACjNA70nNA70AKKPrRxR1oAO1JR2oxQAZFFHaj0oAB70GjHFHegBQeBRSdqO1A ABS4xSd6XtQAlGOKU8dKQ5oAKXrRxR2oASlo7ZooASil60ntQAtIOtL0o9qAExRSmg9aAAUe4pDS 9KAAcnmkOd1KKSgA7UDrRR3pgLmko70UgAe9Bo7UEc0AHail4o60AA70dqTrSnpQAnUUUtJQAHtR S5oyDQAme9LQeBQaAEpe1J0NHU80AKewpKXtzSCgBe1FHNAoAWkoGaWgYneg+tHGaDzQIM8Zo7UY ooGFAo6mj60CD0ox3pOM0vGaAE70uKTvSmgAoz2pKWgANFBooAKOtFFABSYpaO1ACdqO9L2pO9AB SU7tSUAHY0tFFAC0UgpR1pDEo+tFGOKYC+1J3pR2pO/NAB60UuKSgBewpOmaOgoNAC55pKU9aSkA UUd6KYgFBoo70AFIaXrSUAKaKSloAKOppO9L3oAPSlNGKP5UDEpAOtLg4zSdDQA7NB9aKSgBaQUv QUmaADtS0naigAooooEFFFIelIAope1J3pgLSCiloASlNJS9qACkFLR2zQAh606kJ5o6g5oAM0dc +tFAHJoASlo6CjvQADrR3oA5oxQMMUGj0oJoEHaiijFAw60YoozQIKSlNBFACUvUUlL2oASjtS96 SgBKX3oFFABQKKTvQAvWij2o7UAH1pKXFB6UwA0dqSl9aAFpBS0nekAdxmlpCOaXtQAlGaFyB8x3 H1oNAADRR3o6CgAFFHaigA70fSjijtQAdqSil6cimADrQaO9BoAMCkpRR3pAFJ0NL2oNMAoFAopA AFAoo6UAL2NJ3oHvRQAUUUdKADnmjoaPWjPNAB1pe1JR1pgLjJoNHekIpAFIKcKTvQAAc0tHSigA oBFGaSgB68jNFA6UUijlvCy7tEtsdge/vXRofyrm/C7f8SS36d8gfWuiTrn2pkE2eKKTGaKBi9aO tHWjHOaAD0oPNGaKADvSEYpetGOaAE7UUueKbTAUUE0tJikAGlNJRwO1MBfakPtS0h6UgDJo6UD0 x+NFMBe2KTHFFHakAuBmjFFAoASlpAOKO1ABx1oo60o9KYBnik4o7UtIA7UnQUUZoAUUUgzml70A JRg0uOKTmgAFBo680HpQApo7UhpaAAUGjmjtQAd80nel6UYoAO9HfHeg4JoxQAZ5o7Yo4xiigBOh opc0c5oASjvSijHNACA8UcetGOaRlDDkZ5zzQAvGKO9FHegAxRR1ooAB1ooooAOlGM0v1pOlAB1p eKSl70AFIOlKaTvQAY5pcZ5pBSigAPpSY96KKAF9KKTPNKMUAHSjqeaKKADpR/OlppoAO1HWlzyK DQAfzo6mk6GlAoAQ9aKKMc0AFH1o6GjvQAd6WkHWloADQKMcUc0AJS/yopMUAKBzRRR3oATtRRRQ ACilHSigAo70Ud+lABSik/GloGFNpRQexoEKDR3pOKXigYZ60nal4pBQAelFKOmaTNACmk70uaSk AUUGjrTEAxQaKSgBe1FJ2paACko70d6AFxR3o9DSHrQAp+tL6iikPSgYtJ3peMYpPWgBR1oozR70 AJRRQOlAAKO1FHagQUDpRR2oABRQetFABSd6Wk70AFHTpRigUAHeg0DrRQAUUUdqAClpKWgA4Iop B0ooAXnFHFFJQA4dDSUL3ooABSmkWg9aBi0nal96BQAn1oFFFAgPJpO9LSelAC0nal7UUAJR70UU AFBpKdigBBRiikoAWl4NJQetAB0oNHQ0e1AB2pKXigUwF70g60YoA5pAHpS54ox6UUAIKO9L1pPW gBevNJ2oo+tACdqWgUdqADvRnmij0pgFFH0pOtACjrQaO9BpAAFHU0Cg0AAoNAooASlFFAHIoAKK B1oNAAOmKKOgoPSgBaQ4zR15oNABR3owKPrTAOlHekpcUAHegj3o70elIA6UtJQaAFHFGeaBRjmg AooPBoFADh0ooHSikUct4aA/sS1B7D+tdChO1a5/wwC2iW/YY7fWuhRcY5PFMglFJS0h5oGGeKXP FGKKAAUdRQKMUAHfijNH40nQ0AAPFHSjtR1NMBRQelJn5u9KelIBMDNL35oPFB5oAD1pKU0hFMAA yaMZoB9KM8mkADrjPNHelHSk6igA5paTvR3oAB1oNFL1oAbS85pKXOKYCmkzyaO1AHvSAM8UdqO2 KOgoAO/WlHWm0tMBRRSZ/KikAd8UppKD0FACnpSdaKWgApDS0ZAoAPWkzjpS0negA9PWlJ7Uh60H gigBcelHagdaMUAHem7h6jrj8acetJtUNu2jPrigBe1ANJ1paAEooFGKAAUd+aKKACgdKPajFABR QKKADtR9aMdaPSgAPagdaDQDQAtJijtR2oAO9KDSDNLQAGikPTFA9KAFpMUuKKACijPWjrQAUdua M4IoNACY496KKKAClBo4NIOKAA9aXvRSd6AF70lA60vFACClo70CgANHag0etABRRRQACiikoAWk pe1J3oAO1LSYpaACiigCkMDS0UUAIKCaKPwpiACjvSjpR3oGICOaXFHekzQAtJ3ozwKDQAvSik/n RSAU0lHejFABRRSHrTEFHSloNABSd6WigA7UnelpO9AC9qMcUHqKDnrQMD160e9A9aM0CFoxxQKT 6UDCjPWl7U0UAL1zRRRQAUDpQKKACk7UtHagQYopKMUAGaKMUdqACiiigA70dqKOlAAaDQetFAAO hoGKKKAFopO1FACjvSZpR1NHfNACjFIQPrR2oPWgAoxQO9FACd6XtR70YFAB3oPWignmgBKOope1 J2oAOlJS4o7UAFFFFAAP1pKWkoAKWiigAHag9aM9KKAE7UvUUlL2pgFHeijjNAB2pT0oIpKQC+lJ RyRR/SgA7UdqXOKTtQAUUDvQaYC8UneiikAdRSd6PalPamAd6D1o+lBoAKDQKKQCUUvUUlMBeooz RQMmkACjmj60E0AFBpR3zSdKACjij2o4xQACjqaKKYCUtHeigA6mig9aD096QAKKBxRxQAooHWik 70AKaUEEUhoHpQMcOlFA6UUhnNeFRjQ7YgDOOfzroQPXmuc8MMRoloP9nv8AU10SE45xTIHikxS0 hoGL260dqQUYoAX04pO1LntSd6AFoNBPSj1oAO1H8qKB70AFB6UlFACnrSHtRQelAB3oORQaCeKY BRikFLmgAoHSjNAPFACgUnNOpKQCYoApe1JQAD9aKBQetMABo9aXjFJ3pALikFL2o7dKAE70opB1 pelACdqM8UUlMBaPSilpAHWjtR2oHSgApO3vS+9BzxQAU3607oDSd6AAdaPwoIGcUc0AHNL2pOaX oKADqQKKToaOlACjrR9aKTvQAdOtFFFACYoHWl70UAHel7UmeaO1ABR2ooOO1AAKPSgdKPSgANHF B6il9xQAnNHvS0daADHNJ2oFL7UAHpSdDQRxR9aAFo60HtSUAFLR+NJzmgBe9JRR60AHUUUClxQA DFIOtLSfSgAP3qD+tHeg0AHajFFGaAFxQKTvS5NAAelHSjtRQAdqSlo7UAJS0UYoAO1J3pe1J3oA KWkPNFACiigdKKAA0vWkzS5oGFJSikNAC9KO9A6Yo70gDHJoHNHXNHWmAmOKKM8Uc0AKRzRSE0op AIaO9BopiCijNBoASlNFBoADmiikNAC0nelo70AGOKMZoooGHegc5ooB60AKKBR2pB0oAU0gAxRR 15oAPpR2oHAo7UAJilHSiigQYpKWigBKXrSGlFABSDpR3ooAM8UUUUALSUtFACGjtRQaACj1oFFA CjoaSiigBR3o7UCjqaAAUHrRmg/rQMPSjmj2o4NAhKUUY5ooAKTvS9qOlAw9aSl7UHpQISjtzR2o oASl7UCjtQACjvQKO9MBKU9KO9BFABRSUZoAWjPFJRQApo70UlAC9e9HOKXAzRnjFIAFJ0NLSUwC jtS8UnagAoo+tA460gDHNHag9eKKYCUelFL0oAKMUlKaAAUHrQOtLikAg60nel96O9MA46UCij3p AHWgGgcUCmAvTtRQOlJ0pABHNBFGO9FAAOM0UUUAHel7UlKKAE5o60Z5o7UAKKTvRRigAxmjvS5o FACU4dKToaUGgBR0ooHSikUcx4ZQnR7fPYHB/GuiRdo61heGR/xIrXnqpP6mt5Rj0pkDhzSUvek7 0DDtS0lFACgUDk0ds0dqAENFBFKelACUc0DiigBaDQKD0oAQ9aO1FLxQAhopaDQAnpR1Jo60uKAE oFHNHtTAAKKME0tIBCOKM0tIRzQAA0YozxijvTAMcZoo5INHekAUdKUjApO1ABS/jSetAoAKOcUC kPWmAU40npSnrSATNLSGl4NABQaOhoNAB3pKXvQOuaACjvR3oNABnmjPFJ1zS4oASlpOhp3b3oAb QBR2pRQAnegCgUCgBRSUUDrQACjtSZ56H60vagAFFAooAMUUtJQAdQKU8UYpKAF6UDrSHrRQACl7 ZpB1paADtzSUp6c0hHegA+tHajNAGaAFoopD1oAWkNLQelACYpRR2pOtABzSjNHcUUAFHU0UAc0A JR0ooxQAvWjFFFAB2pKWg0AFFA6UUAAoo70ZoAO1FHak70AGKDS9KQ9KAFFFAooAO1GKWjvQMQcC gjpS96TA6UALRjmgYoPWgBOeaMEUd6XNAB2pOgpR0pOaAD2ooPWgUAFFHQ0UCAUUUGgANHaikNAC mik70uKACk70tHegAooxnnNFAxRSCjHWk5NAhwo9aOaKQwzzTfWl/nQaYC9qTtmg9KKAA9KKPWjt QAUhpaO1Agx70YpKWgBO9FLjmjtQAUGko9aAClo6UlABS0hpe1ACUtJwaKACjNFHSgBe9FA6mgUA AHHFBo60GgAo6igUUAHOfpRR1NKKAE70Z54oNJjmgBaTsaUdxRjigBKSnUh6UAJS9qSl4pgJ3paT FKKAEpetGKMUAHNHU0UUgEpe1JS54pgFH0oNAoADRR0opAHegD86KDwaAA0dqD60Y4oAOuTRS9aS gBe9IaX3pM0AGOKPrQelB4pgA60HikpTQAdRQetKKT3pAHWjFJRTAWgUlLmgApKUUDvQACjtQKDS ABRQO9FMBKM80tFACU4cUlHFIBe9HWjvRQAnNLSd6CcmgBcUnelFHegANAoNA5NADh0ooHSikUc7 4XD/ANh2ocj7vGO3NboIPPFYnhxMaLaYJ+5n9a21GO/4UyB9FJnmloGJml7UlKaACkpe1A6UAJ1x S0d8UE8UAHb2pOopRyKPegAAoPTFGeKPrQAhpeM0nelPFAAe9JjgUvU0lABSg0ZGKTgGgA7UelAz S9qAE70fjQOKUUAJRRRnNACUopKXimIMcUdKKMc0hi59qTmlPSk7UAFFGeaKADvRxRzQKAAUZozQ RQAGg8ClpM8UAL/Ok9KX0NJmgBaQ5BzS0UAJnvS0mRnGRn0oNAC9KKTNL2oAMc0h60oxmjvQAlAo 60D0oAKKKM0AFHQ0dDSHmgApfWilHSgBKKMUUAFJSig0wA9qDQaUUgEopTSCmAUvek74FLmkAHmj qaD7Uc0AGORQelJS9aAE60tHekPpQAUdqXPNJQADpRmiloAQUdOlL6UCgA+lHQ0hozzQAE80Ud6D 1oAWjmigdKAA0UdKKACg0DvRQAlHbNLigUAJ2o70tJQAuKTtS0UAJS0UUABpaTtS0hiZo5o7UoHa mAUd6KOpzQAYpMc0o6mgCgAHSkNHQcUtACdxQKD1o7UAB60Ud6KBB3oNA60UAFBo70GgA96KKM0A FFFGeaAAcmg0UUDAUnrSigigBRyKSgZFHUUAL096TvR/hQORQAvakHpR1zQeBQAc80dqKKACgnij vR2oEBo68UUd6AEHXFLSd6KAFpKUUUAJijtS4pO1ABRR1o7UAFFFHtQAUUetFAC/SkGc0oo70AAo PUUdRQe1ACUvagUUAA70oFJjmgcUAKaTvStSHigYZ4pO1L2oNAhO9ApRSCgBKWgdaO1AARQOtFHe gAoJoNFAAKDRSd6ACjtSnpSdqYC0d6KKQBwaWkpe1ACUGikNMBe2KP4aM0dqAAdKKBRmgANFKaAT SATtR1NB6UelACUtHc0UwAcUd6AKOlIApO9L2oIoAKAaKO9MA+lA6UoopAFJxiikoAcKQ9KKT2oA UUZ5pPWlPXpQAUtNpwoAOhpOppT70nFAC4pMUo5NJmgBaAeaBR3oAD2FA4pKcKBijpRQOlFIZheG yf7Ds1IPEdbIrI0BsaNZA/8APMVrj2pkC96DQKKBgPelPXrScUp60ABpOaWk7UAFBoxxQeFoAO3v RQOlGPypgAoPWjFBNIA6UE0ZopgHvRRSUAKDR1oo70gDsKKBmjsaADmgdOlHejqaACg8UcUfWmAf SijvR35oAM+lHej6UY5pAL29qTpS9BRQADrRx0pO+aUUAJ6UcUUY4oAPSg0vakoAD0zRR7UY9KAF 5pMUueKT0oAUikzijpmgUAHWilzzSY5oAOKdmkxR06UAHSjOKPSg80AJQOtAozzQAUUUUAFHej60 d6ACgUUueMUAFJQKOtABRRijFMANHU0tHSkAh5oxRSntQAUo6UnajtQAmKAaXHrQByaAE70vag0e 1ABSGjNL3oADSUuaD0NACdqXtR2pCeMUALSd6WigBO9BHNHeloATvSmkFFABS9qD1zRQAtJR2ooA BRR2o60AHvR2oooATtR1o7UtAB0opKKAFooxRQAUtJSg0DE7UewozR+lACijoaPpRQAUUdyaKAEx xSdadximmgQuOaBR6UdqBhRR0oPpQAUHrRR3oEFFFFABR3oooADR3oo70AFFGKMUDFHakz1pelN9 aAHUlL3ptACnoKMUHtRnigBaSlo4oATtQelKaKAEFFHpR70CDtSUvWigA70gPNLSCgBc4pKKKAFp O1LQelACUppKWgBO1FFHagA60vtSUdqAAHmjrSik70ALjmg9qQUUALS9RSdqBigBexpO9FFAAetB 60daCcHmgYCjtR2ooEHvSdqXtQKAEooo7UAGeaKKSgBe9FFBoAO1FGaSmAdqKKKAFoBox6UCkAda Cc8UlLxQAgpaCRmk70wCl6ig0nagBe1FGaO1AB3ozR3ooAXsaTmlpOlIAoJzR1NBpgH0oo7CikAZ oNFHU0AHajHFFHagAHWigUUAKKQml7YpDnFAAKCKSlpgJS96Pal70AJQOOaOlFAAaKOlFIAH1o70 YooAXjNHejNFAAaBnFIaUUAOHSigdKKRRj6F/wAgazO3B8oGtMdazNDONHtBtI/dKOa1Mc0yBRRx S9qDQMSl+lBooAKKOvNHagAPNHakIoPsKADsaX8aQdM0DHWgBcUlLSGgAxzR/KijpQAvt2pDRzmg 9RQAcUCij2pgGeKAe1GOKM0AHSgUjEAZ/ClXOBuAB9jmkAUUdaMUwEpaSl70AHajjP0oo70gDqKK XtSdqACjvR34pT0oAQUdqKMcUAAo6iig9qADBxQM4OcDnsaM0YzQAvvSHpSignigBKBS0cZoAQ0Y oPWg0AFBo7UvbNADaWgCg9SKYAKKBxQKQBRQKPegAFHQ0CigA9KUdKTtRTAWikzS9qQAPSk9KB1o 9KAClpDmjqaAFNJ9KO1GaAFHXmlpB1NFAAeRQOKM4pMmgBaO9Jg9aUUAFFA60UAIaKXmigApKKXt QAgNKOtHegdTQAh60EUuKTrQAY5ooPFAzQAfWloooAO1JSmjpQAnWlpKOwoAXvRQKD3oAO1J3pfS igApKKOaAF60UDpRQAUtJRQMKO1J1o6CgQ4CjvQKCeaBhjmijvR1oAB0pD7etHO2igBTSDmlI5o7 UAFJS0UgEFFFBOKYgoo7UUDCjrRRigBD0o70HtSjrQIMUdqWkoGHegH8qOtIaAFpepoFJQAvWkAp epoxkUABoxxQfu0nb3oAWijk0Z4pAFIelAo7UxBijvR2pKACijNHQ4oAXvSUDNHegBelHQUUdqAE NLSY70tACUY7UueKSgAHeiiigA70UtIPSgAFKaQUpoAO1FFGeMUAH0oHSj1oFAB05oPJFHNJQAp5 oPSl5pO1ACdaOxpcUnTigAoxR2pe31oATrSd6WkpgLRQM0UgCg0CigBKXtmkpelMAoxmgn86KQBj mg0UZxQAUmOaWkpgL6CjtSYpRjFAAKKKKAF70lHeikAY6ml60nQUdcUAHrQaO9KeeKAEz3oNFLQA go70UUAAFA6UUCgA70lKOtHamAA0UCgnPNAB/OjNAPNB60gD1oozR1oAKWm0jyCMruDHccDahb88 DigB560lBpfagApO9LSUAL2oopOpoAO1L0pDwaOSDQA8dKKF6UUijG0RcaPaHGP3S8Z9q1A2azdH x/ZNnzkeUv8AKtJeg4pkDhRkYo70HgUDClPSkoPFAC80UelFAB3ozR0xQcUAIOho9KKKYCig0cUZ pAIaU0GgjFACdqXrSEdKDxigBRjHNIOtGelHegBaTHBoFAoACuce3NA64o70UAHNGOaO1AoAKKOt BFMA7Ud6OlHc0AL2FJSnpSdqQB3o70DrQTQAfSijnFHvTAKO1ANLjgUAIaUdqTtS546UgENB5paM YoAOlIKB3pRyeKAENHejGKXvQAe9JRR1oAO+KWk60UAHpQKKAOaACijFFABiilpO9ABjnFAFLQOK AEoo9aKADGaO9HWj3oAO1HTmg9qKAClNJzijigAoA59qXPNHagBW7UnQ0GgUAJn8qXoMUmR+VLQA DrQfSiigA6UlKTzR1oASijmloABQKKQcmgBepoxzSd6U0AJRR3ooAPSlpO9KKAD6UUGkoAB1opaD QAUnrRR2oAO1LSdhS96AENLSdqKAFFHvQKKQC0daT1paBiUdqBQaYhQaMAH60lKeoxQMM4zSDpQe po7UAA6YoNA6CigA70dqKKADvQaO9FABR3oFFAgoNHakoAWjrxRRnmgAPajPNGM0d6AD2oxQeKWg YgoFFIaBC9qB6HpS4yKQ9aBinrSGiloATsKU0hoJwKAFpO1L60UAJxQelLQaAEB4o6UUv17UAJxm kpeKMUCAUnWlxmg0AFFFJQAUvak70p6UAJ2oFJSigAoooNACj1pKBRQACg0CgmgBaKB0ozxQAufx pBRR6UAGeaQ9aMZOaXigApKKUdKACkpaO1ACCl7UgoxxQACjvR70UAHeijuKKAD0oNJQaACjrRSn pTAKO9HrRigA9KD0o4zRSABRSUvSmAHpR2oo7UAFBoFJigBe9H40UnSgBe1Hej1ooAO9DUDmgigA FHelHApOaQBSUuc0UwDNA60elAPFIAHHNITmlFJntTAUdaCMUg4ooAUCigelKRxSATvSn0pMHFGK ADigHFBxRQAvek60Z5oNAC0lHeigBe9J3paTvQAGlFB5xQOlADh0ooHSikUYujNu0qz6EeUvT6Vq jtg8Vl6MAdJszjJ8pT69q1F9xzTIH0h5paSgYZooxS8ZoABQKWkHSgYUdqDSUCFFJ296B1pe3FAB 70Uneg5oAO9KaTPNKaAEPWjNBoPamAZ4oBooHWgAB70CjvxS9e1IA70nFLSegxQAUcZo9qM0wCij 3o6UAKeRSZ5o7Uc0gF7UlL1FJQAneloHJopgAo7UCigAxQaPSg0gFz8tGOBSdqXtQAdqD0FLntSG gBPWj3pT1NIKAA0HqKDS0AJml7UlFAC0nSjvS/WgBM0o5pKUc0AHek70uMd6TtQAtJz0o/xo70AH NFAoxxmgBaOo5oxRzigBKXvSd80UAHHrS9qQ9aXPrQAUAYNFHegBO5opfeigAPSgUfQUn1oAXAGe OvJ96OlB7CjHFAB1o7UCjoaAD3oNHpRQAg5o96AKXtQAcUUYooATHNL3oFHegBO9L0pO/Sl60AHe j0o/nRQAGig9KDQAZo7UUYoAKSlpKADtRS9qTvQAtJSikoAWiiigBB1p3ekpaBidKTilx1oxQIAa XvSAYpSOaBh60lL3PFFACD7oozQOlLxQAd6SlPUUlABR3pe9JQADpRQKDQIKDR2oNABRR6UUAHaj vRR0oAX0pKX+dIetAwpKUcmjvmgQuKSgUc0DDvRg0AUgzQIdjijpSdqB05oGHelHrRnvSdqACg9K KD0oAOtHTFA7ignBoAOtGTRg0g70CFHWkPJpe9JQAtJmijFAATQDQaO1ABR3pO1KKACig0Y4oABR 7UCkoAWg0dqDQADNL0o7UUAJR0pT1pKAAnJoIpecdKMnigAoo60dqADBpCRil60Y4oAQUtIKcPag BMUg60GgdaAD0oo70d6ACiig9KAEo7UUo6UwDvSd6WjvQAUUUYpAFJS55opgBo7UEUlIBRQRijFH pTADRjigjmkoAO1L/CKO1J1oAXvQelHQ0Hk8UAAGe9BpRRSAQUdDS0negA70A0tJ1oAAKSlopgAo 70d6SgB1GOKSjtSAMnpRR9aOhpgB60ZzQaBQAGlNIetFIA70YoooAUdRSd6B1o7mgBTQKKB0oAcO lFA6UUijG0Y40ey448pf5VqIcqD6+tZminOi2Zz/AMslrTHbvTIHdaPSjqaXPOaBh05o70c0nagA 70ozS9KQGgAPNGOKD79KO1AB2pPxpcZHFJ0oAUdKQn1pQe1IelABQetB60uOc0wD+KkNLnBpPSkA UoxScUZ96ADPNLQKTFAC9xR15o7ik70AFFHWigBO9O75pOtHTNMA9qXPOKQ9DR3pAKelIDS9qbQA v60ZpB1paAAUZ4oopgAGaDQKKQB2pccc0mMDNGeKAFNJ6UuaOmKAAnmk7+1KaTvQAUpFJ3oPWgBS OooORSUtACd6XnNFITQAtJjmlxxQKAEHWij6UZxQAZpO9KKTvTAWgdKBzSjpSAAfWg0gooAPxooz 1zQOooACaM80Gg0wFpDS4oPpSAQdaXPHNA680mO9AC9utGc8Uh7UuaAE70vOKQ8GjnqaAD1pR3op MjJoAXpSHPNL9KDQAnvS84pMdDSn0oAOaQd6Xr1pAMmgBc80d6PWjvQAnel6mjg0maADvS9qKSgB TRR1ozQAdzRR1pKAFFFFHFABSUvaigBO9BpR2oNABR3oHAo96ADrRRSigYgzSgUnaj1oEAFL3pAc dqU9qBid6KXoaSgA7UH60o4FFAB3pBS0nagApaQ0UAGaDQKDQAncUGig0CCg0tFACUvejijoaACj 2oz0oPSgYd6Sl70Z4xQAo6UmOTSijNACUcCl7Ug5FAC9qb2o7UvagQdaB0ooHSgBe1IRxS+1IeBQ MMUUHil60AFA60d6QGgA70HmgGg9KBBijFFGKADvSHrQaO1AB60UetH0oAXtSYoo7UAKKSgUdKAF zSHrRQaAClFJ1pR0oAMc0gpfegdKACkpTQaAD2FJS9aQ8UALSUopOooAO1A6UUvagBOtFLjAxRig BDzS47Ue3vRQAnQUUd6D1pgJ2pecUUdqACjvQaKQB2opfSkNACUUtHemAUlKaBQACjvRQKQBSUtJ TAO1LmkxRQAtBPFFKexpAJQQc0opKAFxSdKKO9AC9aSiigAoo70e9ABRSj1oxxQAmMUd6B1oPWmA lLRR3oAKB1oPWlFIBD1oxS9OtJQACijvQaAF60CikoAU8UDpSUA0APHSigdKKRRh6FJu0WyAIH7o cYrYHSue8NrINJsySCBGAB7f/rzXQIRjjkUyBwzk5xjtQDRQaBhSmkpaAD0pKDyKBQAtB5FJnilz gUAIKMUUcdaAFooHrSEcUAHU0p60GjjNAAevSgj0pPrSnpQACk4zSjjtSd6ADtQKOlA5pgKDzRjm kA5pe+TSAOtJjFB60GgBO9L1oo5pgGOKO9LyBmk78UgFPvSYo/hooAD1pcYpKMnPFAAM0UDpRTAT GcfWlPSjPQ0E5oAO9LjpSdqM8UgClIpOtBNAC9KBSUDrQAvekPWjrSnjtQAnfil7UdjR2NABjmgj mijvQAmaKXqKKAE5oxxR1ooAXtTaXtSd6AFoHSilAxQAd+KTtSig0AJxijigUelAAe1FBpcUAFFB o70AAo6Ck70tAB2o7+tGOKTpQAtJzjFL+FBoATNGMUClPNAB7UUUGgAopOgpT0oAO9HSgUmcUAKe uKO9FFACdDRijPNGOKAClo7iigAoNGaKAE6UY4pfWkPagBaKBSdqACil7Ud6AEBpaO9JQAvajvRR 3pAFHJNFBpgGRQelFHQUAA6UZ5x60tGOc0DDvigUZ5NAoAQdKKOwpDQA6kpaTtQAd6OlFFABk0hp RQRzQIKQ0vag0AGaKKKADOKDyaQ0d6AFNFIaUdOaACk7UopPWgBwzikpe1J3zQMKKKKBBRjijtR2 oAUdKQ0dqMGgA70dqWkJ4zQAvWkIFAPODRQMO9A5oFAoAUUho6GjrQAdqO1FB4FAhKKDR2oAKBSn pR2xQAlFLSUAFFAooAKQ0tFABxS9BSYpe1ABwDSUGloATqKXPOKSl70AHajqKSjtigBc4o7Gikxw aACl4pB1xS+tABQKSgdaAD/Gl780nf8AGgjNAAOlKaQUUAFHbFFHagAooo70AFFHejFACUtJS0wD 60naijtQAoooHekoAWkpaKADtR1o6ijHFAB1oNGaSgBR0ooFB4GKQC0hooNABmijvQOtMA70Cgda PWgBRQaQUGkAA80d6KD0pgGKKAKDQAfSgcUDrR14oADRmjvilpAJRS9etFABSdzS+lJQAGgCg0o6 UAOHSigdKKRRgeHOdEssHP7sGtsAdqxPDh/4kdmcYJjB6Y71t96ZAvfpR70oo70DEPUUucik60tA BSUoOaKADjNB6UCg9KADtRjijqKOtABQelHQZoPUUAHeg0HmjoaAAjnpSGl5J9qTvQAA0ClxxxSD qaAFpOho9KKAFH3qOlGOaKAE7UtJiigAo70DkUd6AF7Ud6CeKTnNAC9qTtS9qSgAHWijvRQAYoI4 FGePajHFAB3oNHf2oFMAz7UtBoI4pAKcGmmlo9MUABpB1pQOoooABzig5oozQAHpQMYo70dqAAdq KO/Sk79KAAZopaKAEFB5oooAQKd2SeOmKXvRSc5pgLSik9qO1IBaTrQKO9AByfaiigdaADvmlooP egBPxo70d6XHIoATPNKelHejrQAHpQKD0o7UAFLSd6KADuaWk9zRnNABnmk5xS55pO1AB2paSjpQ AClo74pB1oAXmjpRQfWgBO9GcUueaQ+1AC0ZoooAXFJR70UAGaKM+1HbFAAKKO9FAB1FHtR24pBQ Ao5FJS5ooABRR2ooGGKKPeloEHUUh6UUdqBiikOc0Dil6mgBPWj0o9aUUAJ1o70vak4oAXHOaSjk d6B04oAKDRmigQDpQaO1BoGLSUdhRQAd6O9FFAhMUd6Wk9KAFxxR1ooxxQMXvSYoFIKBDu1J2pel J9OtAw6Giik7UCF7UdqToKMZoAXtRjiij6UALQelIOlHOKBhiij2o5zQIO9AozzQOlAxQMHmik70 etAC+1JS9qTtxQAhIHUgUppOKO1AgoHejoKKAF7Ud6Qn2oNABRQKKAFpO9GeKDmgBaO1GKBQAGkF LSd6AA0tJ3pT60AFHagd6O1AAKMCjHFJ24oAQU7tTRTgaAExzQDSk0negAopen50lAAKKKQ0wFxx RR2oNIANGKSnCgBD2o60Gg0AJRS96KYCUdqU9BR2oASilpKAFoxRQaACjNHakxQAtBoHWjHFIAxz QeaKKAFxxzSYo60UAAFAHpS5pM0AAo78UZpTQAUhooPNABmg0AUYpgA4FL9aSg80gDoaKKKACijv S0AJ3pf50lAoAXvSUtHegBKUDg0lKKAHDpRQOlFIo5zw2caJaHGRs4z25NbqsTjIxWJ4c40S05z8 nPHua20O6mQPFLSYox60DDvQfWiimAvtQetFGPxpAFBoo7UAA6Uc4o9aM8UAHajNGBmg9KAEzSnp SDOaDzQAp56UlB4ozQAdKO5o7UmcmmA7NIDR3ooAUdaTNKMZpOaQBmlpKXk5oAb0pxpPrQaYBnjr RjmlPTijv1pAHOKTFKaO1ACDrR2oHBopgHWjOKBRQAdqKUUh6ikAdaWijtQAD3pD7UtJQApxSCij qaAA9qXODzSY6UuOKADNFB4oGce9AxOaD1zS9OtBFAhO1A70YpcUAIKKKKAF7U3vSiigBKXtRRQA UGijmgAzR3ooHUUwFPSkoo6ikAUuKTNLmgBKUcduKKM4FAAaSlJpO2KAF69aM0UY4oAB0pB1paB6 0ABHekpT1oOMUAJR2pKdQAnpQKB1pR1oAQdc0p60h60tACUUGigA5pe1J3pc0AFHSg0e1ACdaWij 8KADvRRRigBM8UvejsKTvQAetBpaM+1AAKWk60UhhR3o5petMBMUDrml7UlACg0fhQKMUAJjk0o/ lR0JooATtSEcU7tSUALSUuKToKAA9aKKKBAOaDSUtAB2oooNABxR3o/Cj1oAQ8c0d6U9KTvQApoz xQaOlAwB7UUUg/SgB3pSCl7Umc0AFJ3pRR60CE60UtJ2oAWjFHvSCgBR2oNA6Cg9KADpRnmikNAD ulIvSigc0DF6d6PWikHWgBc5pKOc0UCEP0pcUmKPagAoFLQMUAJRSkUnegAooHWigAHSg0dqDQAv WgUlFABR6UdKABxQAtHek7Up7YoAMnFHWkpe1ABk0g6HiijtQADmlGKQcUvagA6UDk0A0negBf8A GjpSD1o6UAHWiig0AHagdKSlHSmAYo6UvrRikAnWg0elBpgJS96SlNABR2oooABRQKO1IAo6miig A7Uc0dqO9ABQfSig0wDpQaXtSEUgAUd6KOtAB70ZoooABQaKKACjtRRQAue1JQKKADvR/FRxRigA pfekooAKXrSdTQaAFFJxR0oxzQACjvSjtSHrQAUo6UmMUvagEOHSigdKKRRz3hva2iWgHICYwfqa 206dKw/DOW0S0BXB2duh561ur6ZpkDulFGKM0DCjHage9GeuKAFFJ7UvPpSdKAFoNH1pD2oAAKKO 1KMGgAxQQaOtBoATvRRjkUH0oAO9FL9aTGBxQAvWkHWil9aAG0oozRTAOlHejvRnmkAUHIGaPSg8 0AIKWjAxRnApgHal75pMcUDg0gF7UlO7U3pmgAHWl/Gk70ooATtQcml5pKAAUvWk7UooAOBSc0dR R6UALikpTzig/SgBO9Lig/epM0AL3oGBRnmigA9qB0oI4NAoAPpSZNL60nTNAAKWkFLQAgoFLSGg A70d6Wk+lAB0xRR0PNGaACgUCl60AJR6UUd6AA9KM0GjNABS9KTtR6UAHWl7Unel96AA0nOf60va igAxzijFHejHNAAKCOKKU0AJjOKO1LSYoGJ26Upo6Ue9AgHWkHegUo60AJ3pcc0nejnNAC0neiig A6nFLik70tAAaKO1GaACikpaADvRnIo70dOlACdqO9LjikoAXHFJ2o6iigBR0oo7daKADrRmjpRQ AuKTjFL2pvXigY4UHrQKO9ACetHalHej3oAO1JSjkUmOKAFNJig0D0oAKKKKAAUGkBzQeooELRRQ aACjvR6UUAFFFHegBfSk7Gl9KSkMUUlL0po9KYDhRiik5yaAEpaKO1AhDS9qO1FAAaKKKAD0oPSi kPSgApaO1A4NAAOtA70d6BQAo5NJ3xR6UHrQMWkpTSduaAENLSGndaBDe1G0NnIzS4FJQAdqO1HS jNAAOtHWjpRQAo6UhpRSGgBe1JjiiigAoFH0oHUUALSEc0UvSgA7UlL2pORzQAv86THFLQvegBBR 2oFL1FACDrS8ZxSd6UGgBPxoxmjFGDmgAFL3waTvQeuaYAe9A6Ue/vS5oASgGlPWk6kUgA0UUCgA oNGKKYBRQfajPFIA70Ggc0GmAZooooAKSlzxSUAL3oNJ3pTQAUdKPajFIAzRRmimAoo70lHekAUY o70dRQADiilHSkoAKO9H0oPWgA70dKKM+tAB2ozR0oHFAC96KO9JQAvFJRjiigBaO9GOKO9AAetA pO9OHSgBR0ooHSikUc74awNCtPTb/U1vA1h+HVH9h2nA+5/U1tJnA5HvTIJO9J3oxR3oGL3opMc0 tAC9abjindqTtQAlLzRjPNFAAOOtHem7ec5P0zTupoABSGgelK1ACYoNL1NIetADj1pKO9JQAe9H 4UdaB6UwDFGPzpcdqQGgA70vagcmjFIBKO9L/OkxTAT2pcfnR1pT1oAKTil7UnekAuc0n0pSMCko AKXsaTqaO9ABikNKOlHamADgUc4ox0o70gFIxQAaMZ60c0AKaTPtRzR2oAOOcUYBo7kUg60ALgUY oz0o60DDrxyO9GMCg9KB0oATPtR3pfag8GgQlL0o5xQOuKAAdaSlpKAAUfjSjpSY5oABRRRjjNAB 0ooFBOKACjvQDnmimAUetHejNIAoY4HPSjFBoAAeaXHFIMAYHaigBTikFHal70AH8VJ1paOtAB2p e9IOlHUUDDpRz1pcUhoAOKKKTHGaBAKUc0nWlHSgBO9L3pKXpQAh60Ud6M80AFLSd6U9KAA0YoxR QADij2oNFABSdKWkNACg8Ud6OooNAB3pKWk7UAKKKB0ooAO1LRRSGA6UnrSg5pKYC0HrQKTjNAC9 aTFL60melAC9qD0pO1HagBcCik70dqACijvRSAB0oPWjrR3piCiig0gCjvSUtMAFJ3paMc0AL0pD R3oI70DD6UdqAOaKBDhSd6OlIOcmkMMc0UUCmIKDQaKACk7UvejFABQaKQ9KAFoNAo70AH4UdqXv 7UmRigYtIaUmkNACmk60opMcUAHelpKKBBjg0mM0UZzQAdqMUvakoAUUlGeaBQADpQaX+VBoAKPp RSc4NAB60elFKKAEPWlNFFACdqXPFHagdKADPNJ2NKeRSUAIKcOlJS9KYB3pB19qKKQCnrSE0daO tABk0daKO9AARijtQaO1ABx3o7Ud6M80AKelJjijoKO1ABR3oo6UwA0dqPajtQACl7UlHQUAFGM0 UCgAOKSiigBRRSdKXPTFACiikopAFFHSigAoFFFABRRRTAUUhpQBSdqQB0ooooAOlB5pOtKT2pgH elpKKQAetAooNAC0lHWigBaTvSg0nrQAvejpSUooAcOlFA6UUijnfDY3aHZMG/g6fjW6Bg/0rD8N t/xIbIHGfL4OPettc9+lMgko70Uh5oGLmgjHSkB4pQaAAUcijPPtRyPegAHWg9KKO3NAAOlANA6U nQUAGKU80CgjrQAnQ0o9KQnnNKaYCHg0dcUHrR9KAF6c0nel64o9cUgEGc0d6XpSYpgHel7UgHPW jBpAKKQ0UHk0AA6UlLRTAXPFAHNJRnmkAppORS9qSgA70opO9HagA+lFL2pO1AB2ooB7UvSgA60c 496BxRzQAZ4o6iik78UAL3o70Z60DrQAH1oNLSdqBhwfrRniijmgQdKTvzS0nSgAopRSD0oAXrSU UGgAFHejpRnmgAoFIfalB60AHSiijtQAUA80UD3pgFGKDRSAKPYUUdjQADrS9s0gpe1ACEflS0nS igBTRR0o5oAPWiiigBehpM9aUntSUDAcnNB4oPSjGaADtSDr7Uo60lAgo70Ud6ADvR3oxR0oAKWk FL0FABSYpTijPFABScGlooAOlHY0Z5pDQAdqCOaO1LQAcUY5oo7UAKKKTrS0DEpcUZoFACdKBmjH NH1oAUUHqKBQaAEzyRzR7UAdTS9KADoKQ80vakNAC47UlB6iloATvRRQaACigUGgA7UhoNKaBB70 UYooAKTNLQeooAOcCgig9qM4FAwoJoo7UAL2pB0pcUmeKADkUCjNAoEKaSg9KM0DCiko7UCFzSHp R6UHpQAetL0pKX0oAOaB0oNA96AF74pDQetBoGFGeKU9aQ8UABooOKXtQIQ9KQdaWk60ALR2pKXP NAAO9JSjmkPWgAoNAoI5oAAaXtxRQOlACfzpaSlBoATvS0neg9aAFzR2oxQOlABSetKaSgAoopel ACd6O9LSd+tAB3pf5UnT86D3oAO1B5pRSdKAEpaOMUY4pgHrQBRigH0pAFL7UHpSEcUAHQig9aTv SnrimAHNHag9qM8UAJS8mijFABRxRR7UgCiijtQAUGgdaDQACjrQKKAFpD1o70UAFAo7UZ5oAO9G aBzQaYB2ooHSjgUgCk70d+KUA5pgGOtJ3ope9ACd6UCg0d6AFPWkoJ5oJpAFFHSjpQAp7Ug60vpS DrQAHpSjpikPSlHSgBw6UUDpRSKOd8OIRodqOeV6/jW1FnjNZHh0D+w7MZ48sVtDPAAGMUyB1BpR SYoGHvSmijqKACk96XkCkXJQFl2sRyM5waAFoJoPNBxigYcUnajFAPFAhRSZxS4pDQAdTS+9BpKA FPSijFHpQAcYpOlLSUAKOgpPWl7UmKAFHWk+vSgdc0vWgBOO1GfailoAb3pe9GMUdDTAXtScE0et KOtIApO1KRxR60AIOtLTaUelABR2FBo6CgA7daWkFKetABS8GkNGKBhgAmjjNBozxQIAPegdaM0f SgAPWl9KToeaOO1AxDTqSjPFAg7UnfFLijOTQAnfigcUDpS0AJR2xQBzR7UAFJ3p3GKTHpTAO9FF A6UgCjFFFMAo64FFHekAHqKP5UGjpQAHijHrS4yM0lABnFLSHk0dqAF4oGAKDQMdKADvRQaPrQAZ 60UdjSigBCOMUdqD1pO9AB1PNOpPSl/nQMQdaB1oxQDQITvQaCG4wR154paAEoo70tACd+aU8Une loAKKKKACjtSUuec0AHGaSloxxQAdqO9FHegA7UcZzQPejrQAopO9LxiigYmetLR9aM5oAKQHtRj ikNADvpSHgilHAzR3oAO5zR6UdjR70AA6UlB4AooAU9aQetLQKAE70UUUgCiiimAUUdqKBBRRRig YmaUdRSc0vegQGiiigYUClpMd6AHe9IKWkoAQcUdaMUA4FAg7UUds0ZoASilpKAFpDSikNAC9KT6 UuaTvQADrSjr0ooBoAXNJ3paTuaBhnmiil7UAJ1FBpDS0CCk9eaO1GOKADtSntRjINFAAO9J3oHW gUAKKKT60HGaACjtS4pKAF7UlFFACmk70tJ3oAWk4pe1JjigBaQdDRRQAlL2o70UwA4pBSmkoAWl pMUDrQAegoxRR60gEPSl9qKMcUwFpB7GiikAHtRnmgUE0AGKO9GaDTAOOKD0NBo7UgAUv0pBQaAA 0UtJQAnalzQelJ3pgLQaOpoNIBR0pKO1FABQaKKADtSUvQZoHNAAKPaijHNABR2oFHagBKWgCjtT ATvS5oooAM0CiigAo7UdxSmkAlFAo6mgAFApaTvQAHpSikP6UDke1ADx0ooXpRSKMHw8g/sOzK45 jH41sqTwCO1Yvhv5dBssY/1Y9q2h+FMgfR2oFHagYmeOlLQKMc0ALSUcjFA60DFzxTSBiloNAgHT NJjijtR3xQAuKTtS9eh4pSKAG96O1B5NHSgBTikJ4oJpT0FACUZoxxRxmmAo6dKTNKO1JmkAvXAo HtSDrRQAUvSk7UUAHajqaPpSntTATjBoGKXt7UDk0gFPSkxxRQBkUAJ3pcc5FJRjj3oAXt+NJ0FA 9KMUAL24oPTmkpT2oADQe1HbFGPWgApDSmk6igBcetA4/GjrQPSgAPWkNKOTQTQACjt7UdBR2oAO /NGKBSdTQAY9aUUlLQAgowKX3pO1AB+HFGaWk70AHel7UnU0YoAKB60DpRzigA6c0UZooADS9etJ 1paADHYUUGk70ALnnpRSDrTqAENAHNBGKO9ABRjijNLjvQMb3pe+KQUuaBBilPSk6Gg0AIKX3pO1 L7UAA9KKAMUDk+1ACUtHeigA70UlH0oAWg9KM0elAAaDQaKADtRQKKADFL60mKKBgOlHejtR3oEH 1ooFFAxe1JnrRmlwKAEHWloHFHrQAnWijtSUCFFHfmgUpFAw70h7UDgml70AIOlBpe1J0oAO9FFG aADvRRRQIKDxQKDQMDRRjijvQIMUUGjvQAUDrSUvegAoNFLmgYCkJ9KXHNJzigBRSe1LjpR1oATv QKXrSUCDtQKD0ooAKKM0maAFpO1LR2oAT2paTvS0AIOtKKKQdKAF70GjHSlI9aACkzxSjpSY4oGJ 3pT0pMEmndKBCds0UUUAGe1HWjtR/jQACk6ClB5ooATpR3pcUE0AFFJiigA70vakzzS0AFJmlpKA FHSik7UvagAopKO1ACCl9qTNO7UwEFFA4ozzQAelHfijpS0gEGaMetLSd6AAmiijtTAKPSjBo6mg APtR9aKO1IAoPWig9aYBnpQelBpegpAFJ6UvNIKADPejNGKCKACijFB7UAJSmjHNBoAO9HeijNMA oNAGRRSAO2aB9KO1FACUUdqUUwDFGeKBRSAAaU8Ug6UUAA5o70lL3pgHegUHrRjOKQCnmkooFAB9 KKBQaACl70g60d6AD0FKABSUo6GgBw6UUL0opFGB4eIGi2Q5x5YxxW0nrWJ4cYjQrMtx+7FbSnGB 0NMgkzjtSUvejvQMM0HpQaTcOgNAC/1pBnFKOBRQAGkpc84oIoAB0pO9Hal7UAA4FB6UZzSE5FAA etL70g60pxQAh5IopehpKADPFHeijvQAo60nrS5pKADuKKKUc0AFJ0oGaKAAUd6AaUmgAHQ0nekb d5bbCA2OCwyM/Sl96AFPSk9aXNIelAAOtL2pO/FHb8aAAUHpmig0AIGyORil9KMUGmAUvQYzSYpe 1IAzzQexopDQAuaTPNKaO2aAE5zQeDSmk70AHOaXtQec4o7UAIOKDSijvQAnajvS0lAC5pP5UCig Ao70dRR3oAKBRmj8aAClzxSUZ9qADIo6mjNHpQAUtITRn2oACeaXuKTHNLxQAY5oBxQDg0ZyKAA/ pRQe1J3OKAFPFFFGaADOelFGaOhoAO9H86D1FBoAOlFGcijmgYncUopOhpelAhO9FAo70AFGKKDQ AUtJ9KXtQAdaSl6UUAJziilo70AHSjNGKQ0AL2ozzQOlHegAHIo70A8Ud6Bi9qTNKKSgBTRSZ5pR z9KAE9aDRxSdqAHCjvSCigBQOtJnil5yaTmgBf4aQUc4oPFAB3oxxQetL2oAT6UUUetABQfWiigQ dqDRRQAd6KO1JQApFGeaKM+1ABmijqQaCKBi9KQ0tJQA6kpaSkAnpRS0lMAPSij1ooEIaBS9qQUA Lmg9KKQ0AFFL2pO9AB3oHWilBoAO9FHNHXNABRnmjGKMUABoziig0AAoxSdjzSjpg0AGODRiijtQ Ad6SnZ602gAzQaKX3oABRRijtQAlKe1J3pR0oATFHeilxQAlLR2pOooAKM0UnagApexopaAEo70U UAFLSUUAHsaPSj3opgGKKSl/hoAWikoGc0gA9aXPFIe1GaAClPBpMc0HrTAD2o7UvGKTtQACjNH9 KO1IA70Zo70lMBccUcYo7UelAADzQaB1oNAAKD2o60UgCiijtQAdqO9BopgAooFAoAOtFKOKTNIA xR2ozk0UAFFHrRgZoAD1zQOtGe1FAB3oo70UAA6ijvRnBoPrQADrR3pQaTjNABjmlHApO9KDQA5e lFA6UUijA0Af8SOyGT/qh9K2lPTOc1kaBu/sWyJPHkrgGtcOobBOD70yB+KM0dqKBhSEfNnHTpS5 ooACQBuJAAHJNApSARg9KQ0DCg0d80HpQAnWigdKWgQCkPQ0tJQAGj+VLjtQRQAHrSEY6UpoPT3o ATrijvS4pO9MAxQKKKAAUo60nelzxSAM9qSloNACUY5oo96AF7UnegdKXuaADBopc8U3NABRR1al xmgBKOg60uOKMZFAAM8Uho74pfbNACHpSjjFHY0dRQAh60H3paTvQAp6UCgnmkoAU0HqKO9JxQAD g0o6UlL2oAO9Jnml4FFAATxSZo7UZoAKSlooAOaTvS44o70wEp1J1o7ZpAGKDxS0nagAoo7migAo oo60AFHSil7UAJxS/wANHfmigAP8qQc0p5FJQAY5o60poxQAlLRiigAoooI4NAB2ooIGKM8+1AxM 5pRyTQKQUCDvQetLiigBCKKXoaSgA70vWkpc9KACkpaSgBc0lApaADNHaigdDQAY4pO9L2o6mgA7 Ud6O1FAC+tJ3opR+tAxOtLSAUtIBM0cUvU0lMBQKO9IKD1oAWkBo65ooAXtSGjtR3zQAHrQOQaD1 o6UAFHfFGKM0CCkNLSUAL2oNFBoGJS0UdM0CDvSd6WgjmgBe1FJ3FGeKBi96SjvSYoAf0pO+KO9B oATFFFAoEFHaijtQAUnalooAKQ0tFAB2opKM0AFApRRQAA0Z5ooNAB6UUZooGB5oPSjpRQIB0NAo o96ACgc0GjpQAd6KKMnPNAB1o6Gij8aADvRxRRQAhoFFL0oATrRRRjmgA7UdqO1L2oASil70nFAC UvailxQAduaSjtRQAUZ5oopgFJS0nFABil7UdaM4GKADvR3oPU0vekAnvRS4oPpQAnekPWlx3opg LgUmKDziikAfWjOaB0owc0wA0Cl7UlIA7Unel7UYpgGcUHmijjFIBRSHvSik70AHFL3pDwaTNAC0 CjsKKAEpQaMUYoABzRigUUwD+dHejPNFIApe9N6UvemAYyaKOho7UAB60lKaMUAAooo6GkAvvTe9 O6UhoAKUCkz0pRQA4dKKB0opFGDoJB0SyyWGI16d62QFZcYGDWR4fx/Ytln/AJ5LxithecY6UyBy gjgnIoOaM0UFB2zS9qQ9KUcUAHakzRSYoELnsTR2prruxzjkHilPSgBelAoH3aO1ABQaQHNBNABS nNHeg80AJSmkNGeaACj+dL70mKAACjtS0gpgA60tHekxzSAKU470lBoAPaiijPNMA7UuKB0pO9IB TwtJ24peopOlAB3pTSCjIyR3pgHYUZwM0HpR2pAA6UpPFJ2o7UAGOaUZ4oPSjPFAATzRSd6DQAvH NA5NHekB5oAXPNJ2FAzSmgAxnNGOKM0lAAOtGefag0tACUY5oFAoAKWkoHrQAo5pO/NL3pM0AHel H3TSUDpQAo70daQdKSgB1J3o9qKAA0tJnig0AKeOaQ0Y7UUAHQ0vaj1pO1ACnpSUpFAoAO9IM9KX vRQAUUcUDnigBe9IaOpFBOaBgelFBoPTigAzg4pO9HSgdaBC5o70nQ0d6ADvRR0NLQAh9qWk70Zo ADS4pKXoKAAUlHeigBaTnFFFACjvR0NHak70AL2ooHSg0ALSd6Wk7GgYUtFHfFIA6ik4zS9KQ9cU wFAxSUopOM0AHelxRnJooATtRml7UlAB3FGc0HnFAoAKPaiigQUnvSmigBOaWiigApD1paO9AB7U tNPrS/SgBe9J2ozyKDn8KAFpMUtJxigYvWiik6nNABSdqWkFAhaO1FFABSUuKKADkUnalpO1ACnp SUUGgA+lHalFHWgAHrSd6UcUH2oAO1HagdKBQAUHNFJ2oAUcDmgUUUAB5ooBwDRQADjNHJ70A5NI aAFHSikzxRQAuaWkoz+VACd6XrRjvQPWgA70dDR3pD1oAKO1GaO1AB3oo4pO1MApRSUo6UAFAoo6 mkAvekNA56UHpQAUGj6UGmAYxR2oo7GgBSKQdaCccUDg0gFNJ1NLxxik9KADNBoHWg80wFpD0oo7 UgClNID60d6YASc0Ud6KQB2o7UdqOlMAA5pSKSg5oAPag80o4HvSc0gCg0ZozTAKBR2pRSATOKO9 HU0UAFFA5o7UAA5oxRRTAKO9JS96ADFA96O+aBjvSACKO9GeaM0AFFAooAXvSUZoHegApRRSDpQA 8dKKB0opFGF4dJOiWef+eSjmtheorI0Ej+wbHjjylrXHBpkD6KKO9AwoNFGMjNABijFLnFJzmgAp KX8aGNACZwKBR2oFABxQcUoNJigBc8+9B6UneloAQnpSmj0pKACjvS5oNAAOtJ3/AJUopO9ADs0n U0dTRQAho6GjmimAfzopPxpTQAuMUneloOMmkAn8NHalPSk96AAdaMUdKO9MAFGaAMHPvR39qADr S0lLSAOtGeMYoPtR2oAKM0lKR0oAM0nSlxSd+aADHIoPU0UueaYCc5pTSUUgCgk59qXHNJ3oABRR 04paAE96OlGM0detAB2ooxSd6YC0DpRSikAlFFFABSZpaMc0wEpaMdKKQBRS0lAAMHrS9sCkpe3F AAaBQaQdaADNFL3xSd6AAUvXpSUDNAC896D0xQeTik7cUALxQTxR2o7UAHegetKOlJ3oATvSnrR3 o70AJ3paTHNFAC0UhOaO1ACn1o60dqTpQAtIaXNBoAO1JS0maAF6ijGTSCloABRnmgc0elAC9qKQ dKXvQMMUfzo4ozzQAnaj+dLSHrxQAo6Uh60vUe9FAB3PrSUtAoATqKMZFL2pO9AB3oo70UCDvQDR 3ooAT2o70vSg9aAE7UdqU9KTvQApopO9LQAUvSko70DFpPWg8YpSMCgAFJ60YwaPqaAF6Uhpe9J9 aAD3oFBpooEL0pSeKQ0tAATSdaWkoAWg0UhNABR3o5NHegAoJ9KO9KKADvQelJS0AFGeKKO1ACUp zRR2oAQ0oHFHagUAGM0UdKCaADHNJS0UAJjNLzSClI6UAIOaXtzRQelABQOlJn2oFAAeaDwKKXvQ Amc0dqXvR2oAT2pKXrSUALRjiijmgAooA5oHFABRmgUH+VACUueelJS0wENL2oJpe2aQB60nej2o 96ADvR3oooAMc0Uo7UlAC5xSdqWjtigBOM0vbijGKKAE4xSUvtR2pgBPFGaTtS0AJSntR3pT0oAK Q0tJSAO1GKM0UAHagUdqKAAHmkNKKT3pgLnFGetL24pOaQBR3oo7UwEPWilooAKByaO9AzSAD1ox RjmlzQAg6Ud+aOtHegA4oHXiik70ALmlHNJSigBw6UUDpRSKMDw782hWIzx5S8GtpRyCeuKxvD3G gWOQMeUBW0KZA4UdhQDikPWgYHmlzRR2oADzRR6ZpMUALxRnijvRnjFACAcGlFIOlH0oAWg0CkPS gAPXpQaOtHemApz2pKWkpAHHWg5HNFHQ0wFHBpOtGMmjtigApaB60duKQB1opBRigAxR7UYpfpQA dBQOppO1AoADwKKD0oxQACk3DcFwcnJzjj8/xpcYzS9qAEoAwKKO1AC9qOgpAKCaAFpDR1zR2oAD 2pSaSg0ALxQOTSUd6AA9aXA7Uh5IpelACcZNLjNJwKWgBKO5oooAOvNFHbFAoAAOaKBRQAox0pKX tSHrQADil7UlL2oAQCigUlAC0elAo7igA6UvakI6UUAApaSl60AIOtL2pO9L9KAENFKelJmgBfek 6UUtABnNGfSkpeMUAHeg0dzSUAHelxjik+tLnigYc59KB1pPegUCF70lLSc0AHOaPaiigA70UUva gANJSmigBKKUUhNABiiiigA7UdqO3FGKAClNHek96AFoo7+1FAC8UUYo9zQMQc0daO1GOaAF+lB6 0UnegBeSDSDpS9M80UAAzik70dAKWgBDR2pT1pKACg0UUCCg0Y4o4oAQ0Ype1J3oAWik70vrQAEZ xR/FRR3oAWkPOaDxRxQMXtSdRR06Ug70AOpAaWm/SgBaSl9KQUCDGc0vGKQ0UALRSUdqAF60nOKW kPSgBaSl6mkPWgAzQKBQKAF70GjFB60AHWgniijigBOppT0oOO3WigYUduKMcGgDrQIPWjIpPWlx QAopuad9Kb15oAUUHtRQRQAUHijtQBQAmKOlLxSUALSUuecUh60AFFL2pO1ABRR0NFABRSCloAKK KKAD/Gij6+tFABikNLQetMBPel7UGjsaAFI5o6ikx1peKQCYozS0lAB1o78UgpehpgHegUYzR2xS AOlFHSigBaT0oopgBpTikoGOtIAHWg9aO9BoAXPekPWgUZ5oABRRikpiFxQBRRQMMUUCkoAUUGjH FBoAOtFGfSikAUd6KKADOaWkxS0ABpO1KetJQACjvS96Q0AFFFHegAxQOKKUUAOHSigdKKRRheHm /wCJDZZz/qlrYVgTWH4cGdEsx0/dAcd624xhcUyCSjFIKD1oGFLRRQAA+tJ2petJ3oAKU0GjFAAK TIxS44pMcUAL1pD060Cg4oASlzQaM0wFPXNJ0xSmkxSAKXpSdKXHNABSe1Lx+NJn1oAXHNAzSMqs VLKCVOVyOh/yaOtABS9+aTk0poAT60uRSd6DmmAc0UDpR3oAWkzS0hpAHel60lKOtAAfrRwKKO3W gA6UUnalPagBO2aXtSY60uOKAAnpmgnPSikPagBcc80nelxSAZoAXFGcYpD1pfSgAxRzSZo5Gec0 AGKKX6Ud6AAY70d6TtQOtAC9KTjFLSUAKKTvmijvQAc0v8NJS9RQAgoHSlo4xQAgoo7UY6UAB7Ut Ie1GaACl4pKPrQAD2opR1pKAFJ7Ug70ppKAFPXiijt1ooAMUUUDntQAAdaMcUfSjGKAD60e1J2NO 4xQMTqaMUnejmgQuKKT60tACUUUUAKKKKKACjrRRQAlBpaTFAC9aSlxik7UAKOlJRR3oAUdKSjtR QAo5ooFFACjpRSdRRigYUUcdKBQAClOKMYNIeooAUd6Slz1oPQUAHakzQOlB6UAFHtRRQAd6MUe9 LQIT2o6GikoAKU0dqDQAnpS9KKO9ABR3ooHWgAJoNKaSgYtNHtS96KAF5pBRRQAHtSdKUDnPPIpK BB0pTR2ooAKQ0tJQAdqDS9qO1ACdqMUdqU0AIKO9LjmkA60ALSH9aUdaO1AB2FFAo7UAB4oPTikp TxQAdqO1IelGCKAF9aD6UdsUYoAB0NA4oHegUAApT6UlIetACijNFFAAf1pKKWgANIetBpTwaACk 7c0GjFAB2ooNHagAFFANFABnrQPSgetHegApe1JS9qAE9KCOaKQ9qYB7UvajtQOlAAOvtQKPWgdq QBRRR1oAKDRSd6YC0dqDR2oABR6UD3oNIBaQUCkpgL24oFJS9BQAUEUD60GkAuRSd6AaDQAUUCkp gL6UCgUd6QAKP50UhpgKDSGloNIAo6UCg0wDijvSUuc0AFFKaQdaQBnnmlBopO9AC96Q9aKKAFxx Sd6PSjPNABSikPaigB46UUL0opFGD4dAXQ7IgcNEDWyuM9e1YugY/sOyUH/lkK2UXnJ5pkDx1oI/ OiigYZNL1pKKAHZpuMUvaigBM0vuaKO1AAaQUUCgBRSGgfWg0AHpR60d6U0ABNBo44pO1AC0nNGc CimAo/Wk7UvXpSUgDqRRjmkzg5NLkHBBznuKYCikNH40E0gF4oNIOlGTQAdqOuaMmj1oAXOOKKP4 aD/KgBodd2N659M0oYHO0g4ODzXAaH4d0TWPFPi6XVNKs76dNRQKbqBZCq+UmMbhnHXjpx37dCPA /hIEkeGNHyRj/jxj9/b3oGb2RyAw6460DHqPzrB/4QXwljH/AAjGj/8AgFH/AIUw+BPCJTb/AMIx pGOP+XNM8e+KBHQ5xgEgE+9KR0rnU8A+EEXA8M6TjOebRD/MUDwD4QVAo8M6VgMGGbVCeDnrj26U DOhxx2oByMggj61gHwP4SP8AzLGjf+AMf+FL/wAIP4Syp/4RjRuP+nGP/CgRvZXpuGR70E46kenW uf8A+EE8I8f8Uxo/Ax/x5R/4UL4D8IopUeGtJw3f7IhP544oA6GkJCkZIGeBk9a58eA/CK5A8M6R z/05p6Y9KP8AhBPCW4k+GNIJJBP+hx/4UAb7OisAzqMnAyepxmgSIwyrqQCQSGHBHWsI+CPCZI/4 pjRuOeLGIf8AstIPA3hIY/4pjR+Mf8uUf+FAG4JYjIYxKhcHBXcMg4z0+hH50rzRJw8sanGeWA4H esP/AIQfwlu3f8IxouQMf8eEWPy20v8AwhHhMf8AMr6Lz/04Rf8AxNAG20saHDOin3YCm/aIACfO i2jqd44rGHgnwmP+ZX0Xk/8APhF/8TQfBXhPp/wi+if+C+L/AOJoA1RfWZkaIXduZFzlPNXIx14z 7ilW/szkrd25wMnEq/41lDwZ4UC7f+EY0XHp9gi/+JpP+EL8KZ/5FjRf/BfF/wDE0BobLXMCKS88 SgHBy4GDSG6twObiIckffHX0rI/4Qrwn28L6J/4L4v8A4mj/AIQvwp0/4RjReOn+gRf/ABNAGuLu 22bvtMO0nGfMGDTReWpcqLmEsBuIEgzjnn9D+VZY8FeFP+hY0T/wAi/+JpP+EL8KY/5FfRf/AAXx f/E0AaqX1o+dt1A2Dg4kBx09/cfnTxc2/P7+LjOfnHGOtY//AAhXhTH/ACLGic/9Q+L/AOJoHgrw n/0K+i5/7B8X/wATQBsLc27bttxEcHBw44OAf5EfmKPtMByPPi46/OP896x/+EK8KHgeF9F/8F8X /wATSDwR4URQo8L6LgDHNhEf/ZaANl54YziSaNO3zOB/nqKRrmBRuaeID1Lisf8A4Qrwp1/4RfRf /BfF/wDE0h8E+FNwP/CMaLxx/wAeEX/xNAG0biABszRfL1+ccfWj7RBt3edFtPQ7xg1jHwT4TB/5 FfRP/BfF/wDE0DwT4Txj/hF9F4/6cIv/AImgDa82PP8ArUznH3h1oM0QODKmfTcKxj4K8Kd/C+i5 /wCwfF/8TR/whPhP/oV9Ez/2D4v/AImgDZMsajJkQAAkksO3WgzRKuWlQDG7JYdPWsb/AIQrwoeD 4Y0bA6D7BFx/47TT4G8JFw3/AAjGjZH/AE4x4/LFAG9uHUMD+NG4eo/OsP8A4QnwmD/yK+if+C+L /wCJpo8DeElGB4Z0f/wCj/woA3wfpSMyoCXYKAMkk4rA/wCEF8JAj/imNH49bKP/AAoHgXwj8h/4 RjR/l6f6FH6Y545oGb4IDYyOe2aXA/GufHgbwkOP+EY0frnmxj/wpV8C+EUBx4Y0bk55soz/ADFA G+CAccA4zR15GMVgDwN4RH/MsaPwAP8Ajyj/AMKi/wCEA8IDd/xTWlnJ3Em2U8/l+lAHSdKMcVza +APCCA48NaXyQf8Aj2U/0o/4V94Pzn/hG9N+nkDH5UAdIBzRxnGefSub/wCFfeEN27/hGtLzjH/H stMPw88HEMD4b07k5J8kZ/OgDp8GjvXMn4e+EGbP/CO6eDgDiLH8qT/hXfg8vn/hH7LP+6f8aWoj pse1HevNvAfg3wxqfg+1urvSLW4nd5kkkdTuO2V1weeQABjPbHA6V0Q+HXg8dNAs+DnkHr+dGoHU YoNcwvw78IIePD1kec/MhOfrk8j2pT8PPCDAZ8PWPAwDso1A6bnFHPpXNH4e+ESCP+EfseeoCYpP +Fe+Efm/4p+xG7g4TqPz9qNRnS9sjmj8K5n/AIV34Px/yLtgfrH7Ypf+FeeEeP8Ain7LgYGVP+NG ojpqMHmuZHw88IAEDw9YjPpH1pp+HXhAkE6Da8HP8XP1556CjUZ0/OOhpffFcsPhx4OHP/CP2mfo f8ac3w98IkKDoFn8owPlP+NGojph6YoxXMN8O/CLddBtBxg7dwyPQ4PNB+HnhDcG/wCEfssg5Hyn /GjUDqADS461zH/CvfCJ4OgWWD1+U8/r7Cj/AIV54R27f7AtMYwODwPzo1A6bBpea5f/AIV14Q+b /iQ2g3fewCM/rTv+Fe+Eck/2DZ5IA6Ht+NGozpu3SkANcyfh54Q5z4fsucnGw/40n/CvPB+V/wCK escDp8nA/WjUDqBzRiua/wCFfeEcnHh+xGRggR4B+tA+H/hIcDw/Y8gc+Xz+dGoHSkUY9RXMn4fe EG3Z8O2HOc5i9Rig/D3wgW3Hw5p34Qj0x/n86NQOm7dKMVzH/Cu/B5Of+EdsM4wf3fB4pR8PfCK4 xoFmCOh2nj9aNQOmpO1cwPh34QHA8P2f/fJ/x/zx6Un/AArvwgQf+JDaD6bh/WjUDqfwpK5j/hXf hIZxoVsM9cFgD+tH/CvPCPA/sK24ORy3+NGojp8H0oIPpXLn4d+Eic/2HBz/ALT/AONOPw+8Ktuz o0JLdSXcn891GoHTYPpRg+lcx/wr7wqM7dGiXPXbJIP5N70H4e+FOM6RGfrNJ7f7XsKAOnwc9KMH 0rmD8PvCpA/4lK46/wCuk/P71B+HvhYjb/ZfHtcSj6/xUwOnwcUuDmuXHw88KAYGkqAev7+Tn6/N Sn4feFt2f7KGfX7RL/8AFUAdOc0Y71zH/CvfC52/8S1vlBwBczY5/wCB0N8PvC5GDpzj/duph/J6 Qzp8c9KTBrmf+FfeGNwb+znyB/z9zf8AxdDfD/ww33tPkJ9ftc3/AMXTEdPzSYx2rmf+FfeGQQfs M+QSf+P6fHOP9vnoKRvh74ZY5NjP0xgX04H5b6A1Oox7UgBx0rl1+HnhZTj+znOexu5j/wCz0n/C vPDGD/oM/JzkX1xn89/T2oA6nBxRz6Vy7fDvwu/WwnHXpfTjr9HpB8O/DCptWwuAMY4v7gf+z0gO pP40Y9q5c/D3wyefsVwPpf3H/wAcrE8V+CtB0nwnq2pWVvdxXdtaO8Ui6hcHawGQcF8daYanoeDQ QfSuO034f+H3021lntrp7h4UaRxqNzy23nH7zjkmrB+HXhggA2V1jnH/ABMLjj/yJQGp1ODjpRg5 6Vyn/CufDGADZ3eBwAdSucf+jKX/AIV14Yxj7HdDntqFyD6/89KA1OqAOelHPpXK/wDCufC5AH2K 5wAR/wAhC579f+WlKPh34YAUCyuQF6Aahcf/ABygNTqcHNBGTXLj4d+GQOLS7GeuNSuef/IlL/wr 7w2G3C2vA394alc5/PzKA1OoxzRg4rlW+HfhpiP9HvR8xY/8TK55/wDIn4/hS/8ACvvDfH+j32MY H/EzuuB/38oA6jBowa5f/hX3hwZIgvxu641W659/9ZS/8K+8O7WxFqPzdR/a11z/AORKAOnwaOa5 g+APDx6xaj3/AOYrdd+T/wAtKcPAmggg7NSyAVGdWu+Ae3+t9zQB0vPNGK5n/hAtA3BtmpZAIH/E 2uuBnP8Az09eaP8AhAfD4x+71Hj/AKi11/8AHKBnTYoxg1zZ8CaCwCldSwBgf8Ta74/8iU5vBOjM NrPqxUDaFOsXeMf9/aAOiANBHpXOr4J0VclW1YbuuNZuxn6/vfrSDwRoylT5mrllOQx1i7zknJP+ s9eaAOj5/KjFc2fA2hsct/ahPvrF3x3/AOevrzTT4D0Fid39qMNuzB1e64Gc4/1lAHTY9qOQBxXM jwD4fAZRHqIU9R/a11g/h5lKPAmgrnC6l83X/ibXXP8A5EoEdL+FBBrm/wDhBtD3bidVLep1i7z/ AOjfYUHwLoRI41TgEf8AIXu+/X/lrQM6PtRziueXwVo6JsSTV1Tbt2rrN2Bj/v77mkXwTo6szCXW Mk8n+2bvr/39oEdH+BpOcdK51vBGiuwZn1Yt1ydZuz/7VoPgnSGAHn6yFAwF/tm7x1B/56ewoA6I A46UYNc+ngzSVj8sTawExjA1q8A/9G0v/CHaZwRda2G/vDW7vPXP/PWgDoKTBzXPr4N0xEVRda3h eAP7au//AI5Tv+EQ03/n81zuP+Q3ef8Ax2gDe70prAPhDTj0vNcH01u7/wDjlH/CIadn/j81zp/0 G7z/AOO0Ab3P0o/CsD/hD9PJ/wCP7Xvp/bd36f8AXT8aj/4QuwDA/wBp+IDgEY/tq659/v0AdH+F Azg8Vz48H6eD/wAf+vH663d//HKYfBdiTkar4hHHQa1c/n9+gDo/alxXPf8ACH6eRj7frwOCM/23 d/8Axyo/+EKsd2TqniAnJ/5jVz0Pb79AHSEc0YrnU8F2KKAdT8QN1JJ1m5GTkns49f0FN/4QuyEh b+1vEWCeF/tq5wOn+3n/APXQB0lFc0PBNlgD+1/EXGOf7auef/H+9MPgaxLK39r+It6ggN/bNxnB /wCBew/KgDqOfSjtXOHwZZZP/E18Q4I6f2zc8HHX79N/4Qmy24GseIwfX+2bj/4v/OaYHTc4pMGu aHgqyAP/ABN/ERznrrVzx/4/WD4q0A6DoUN3Y63rzXIvLePdPq07gq0qggruweCR06e9ID0Og9qO 9BoATtS9qM0elMAHWg9KM80E0gFpM+ooB6UUAHSjvRQRQAUc0Ud6AAfWjtR3pKYC9qO9Hag0gDvQ c0YopgHWjv6UCjvQAZ5o6mjvQPWkAp60lBPNGaAAUd6Wk6igAo70UDrQAelAoNAoAevSigdKKRRg eHx/xI7MjqIxxWwvOAe45zWNoJxodljjMSkgd62kPSmQPwOlLRRmgYlLxSHpRjigBaKBR2oASlxx Rzmg+tAAOlJilIxSUALig4HSgGkIx1oAU5zSHrRzSn0oADSc4pT1pDQAYo7mlzSUAHFAGaO9L2oA TvRS+9JmgA7UeuKXrSY96ACikpcd6YCnpSUh4p3GaADqKTPrSmkpAch4P/5GPxhlmJGpgYLZwPLX 15Hf26YArsM1x/g4Kuv+MACXb+1AxctnrGvH4fyxXXUIBc0dqQGlNMAHvR+lFB6UAFBo7UDOKQBj 3oo7UdqAFpKOlFABnvR3o9KX3oAO1IelHXJpetAAaTvRQDQACigUUALSdaKO1AAOlA60CgdaYB3p e3vSHFKKQHnl/d3Xin4nHw751xBpWlw+fdLDKyC5Yhfkcrjj5xxnnDfg0Tt4L+IunaRbSXLaJq8O 1IJpnkWCcE8oWyQCMZGepz6VQ8AAt8VPGEj7/MEsinI4I804/QD04PGccRfFZnXxl4SMaHzBMChQ ZYt5seOPbtwep98oDsr7wi934ztPESa1qEPkKFazWT904APGO2c81geI7+bxB8R9O8KR3U9vYQxt NeeRcGMznbnyztPIwRkH1PTg16LXmGhKf+F769vMjMLQkEjgDEWO3TnHH+NAE99I3gTx3o8FnLIm gaqPIktXlaRIZQcBkDN8mS65xnPPHSp9SvX8R/E5PDUs0kemWFuZp445WU3MhCkI20j5QCD9fwrM +MKg3Xhny2f7T9rIjUHGRlOmASDnbyAf6GxrWka3oPxMHiyy0mTU7CeJY7iK0KmZPl2khTjdjAIx 9OKBkmrPdeBvGekmwuZ20XVpRBLZSSl0ik3AZj3t8ud+SBxwal1vUJvEXxLs/Cq3M9tp1pEbi7EM xjNydufLO1slcMMg+/tXPePdRn8TeK/DOkQafeWc3nCT9+USQByCGAVmZMBGPzAHjpWv4l0LW9H+ I9t4v0rTZtUtSuLm3gcLIvy7DgFhu4we+MfjQIf4heTwD4n0i+0+6uF0jUJRbXVlJK0kUZyPmjDH CEgkk5xwfWvSwQRkcg+leNfEi+u/FV3oGiwaVe2klxKJEW6aOOQk4GdoYlcAtycdGx0r2NFEaKgJ wowCeTQApopcc0n0pgFLmg0dTQAd6O9FH0oAKDQeopKADpSk8UdaOBQAg60Ud6KAA9aXvSd6XvQB yPwzff4Es2ypJluMkD/pu9db3rkvhpuHgOwDDo82Oc5HmsQfxHpXW0AFL1pO9LQAdBSUtHNACUpp O1LQAUUYxSUAHail7UnegAFBo7UUALRRRQAnelHWgdeaXvQAlFFBFACjr1pO9Ao70AHejtR60CgY CilHSobnzBazGFUaXY2xXOFLY4B9qQHnuh3d14+8Uapcy399baJpsnkW1vZ3TwecxBBd2jILdMjD enHrb8J65c2Pi7VfB2pXUtybbEtjc3MgaWWMqGKsScsRng9cA5rP+CqY8MX0hcbnu8FOpUhFGenc YqCNJP8AhoOVkbA+yguoJGR5IHPr2/KmI6nQvDWr6V4o1LUrvxFc39ldbjDaTM5EJLbuAWKjA4GA OPTvT8X+LL6DV7Twv4dVW1u8I3SuoZLaMgkuRnqMZ5BGB9K7bqa8X8B6TqHijxFrXiH+2Z7EvM0b PbojSkHPygurBQAF7dhikM9R0zw/Fp/lyy3uo3l2o+ea4vJGDt3Pl7tij2CgVyP9rXXjL4gTaRb3 V5Z6PpSs1wIJXge4kyFALKQwX72MEZxzTPD+v+IdG8ft4T8Q3g1CKdC9ndmNUbaFLAttABzgg+46 81Q+D+Gv/EjMd8nnIDIxO4jMnrzjv1oEavhfWb3SfHOo+Db69ub+CNRNZXN1lpdpUMVdyfmxnAOO xz6Ve+JCS2fhi61i01DUbS8tvLVDbXTohBkUHKZ2nhjyRnjrXL66FHx70kKyB2SMnJPPyPwflPOB +o5FdV8UYy/w91Ig42mM/dznLqPw6/zoC5peD7cp4csbqS8vbma6topJWurhpPmK5JAY/L17Yrfr H8KKg8I6NsACmyiIx7qK2KYBS8ZzRRjmgBcUGk6UHpQMKDQKKACil7UgNAgxSdqWkoAO1L2o7UUA BrnPHrBPAGullYg2Ui4UZ6jAro65vx8GPgHW9u7ItWPBwcDk84PagDcsSP7OtSN2PJTG7r0HXFT9 qqaUSdHsS3U28ZP/AHyKuHpQAnaiijvQAUClpBQAtFFIaAFooFGaAE7UtIaXpQAhpKWj1oAXGRSd qO1H+NAC0n40oxSdaAFFBoFIetAC0lKKOtACUuOlFHpQAh60HilpKACjtS4pO1AC5pKKKACobu6j srKe6mOIoUaRz7AZNS1BfvcxabdS2cSy3SRM0MbkhXcA4Bxzgmhgef31p8Rb7Tv7et9bisZQjTR6 Otqp2pjIVnOdz4xkYxnpirGleKr/AMU+AtR1KG5k07VdOWXzBDGgV3VNy5EiuQpyM9+Dg1H4Z8Z+ I/Emm3F8q+HrZLR3Fys08qvEB0Zhj5RgN19Kz/B2mXCfDrxRfsuY9SS5e3jG7lQjKCARnn3GTSGa vgq51zxJ4Kk1O68QagLuYsI2S2t0CbTxtXyznPQ5z7VW+G+p634u0S7vNR8Q3qyx3BiVYILdAF2q QcGInOcjrj8uK3gXxRomn/DdILzVrVLvfMgt/O3SszOdoVBySdw+6O+fWqnwe1vSNI8L6ha6hqVr azxXpJimmVXYbEAIXgnJyO5JFAGt4D13VtX1HXJNU125ltNMmxGptoYhLH8/L4Td0UHjb/Srvh3U 9X8d2l7qkGp3Oj2CzmGxjt4omd1UcvJ5ivnJOMKV6d+tcx8NriG5l8Y6W88UGo3sr+XaTFY3yRID 8nXjuMcVvfCjUTHoU3h7UJo4tWsLmUPZthXVC27cF6lSSTn3HYigCTwN4r1S88Qat4a8QSJLqVkz Ok0cexZEDBScYGPvKR65qr4j1TxBYfEXR9DstduFs9SAZx5ELSRjc5OwlMYwO4J4rM0y7srf4r+K fFNxdR2+i2Si2kuWf5TMRGhXjk8oeB7fhB4g8S6Td/F3w5qFnqtk1lbQ7JLlpEEQyX3fO3GcEdD1 460wN7VL3XbL4i6X4fTxHe/Yb6AyFhbQGVSBJ0PlbcZQZyON1HifUde0rxdoWjWWvXnlapJiR2tI JGiAPO35FHOR1zjk89Kr69qFnafGPw5qE91bx2M2nttuWkURtlZed/THzL35yPaqnijWdO1X4peE l07UILj7PJIkpjZSgYlTt35xu9gSRxxk0gOl1G58SapqsuiaBfpZx2EKi71O6t1kaWVlyqoowueh Y44zwOxyvC/izWrTxjP4S8SzJcTjIt7xY9u8hdwBwADlefqCO9dAvjLTY/HD+F5bae3vHUSLO4VY 5jtHAOck44HHbHauf1GCPXfjPpj2LxyppNsTfSIFPlvltqEkH5uenUc9DQBFY6t4gn+KV54ZOvXM mnQQ+aJBbweaPkU4ZvL243E/w+nNXPGvjO68JeLtIJZpdMmgYXcAGSvzgCQcdRk8ZwcEehrEs720 0749ao11d29vHLCEDTMsYZyiYAJ65/PP66/irSbXXviVp+lXqq9vPo9xuGBuQ7sBlz/EM8fQ0Ad8 kkd7ZiS2uAY5kzHPCQ3BHDKeQfUdRXHaU2v3HjnWNLuPEU72FhHBLEFht/Mk8wZw5EeBjawwADhl Oa5/wnrV34C16Twh4luM2Lvu06+cbUwx6eyk4/3WyOhBHTaISfif4rCnjyLPcMr12HHHXpn0HtTE dhXI/Etivg1yASftlrgDGT+/TjmuvFch8SiF8Ihsj5b+0IXGd379OKAOvoo70nagApaKMc0wDvQa O9HSkAUGjvRQAUGj60HrQAdqQU7ikFAAKKBSUwHdqTtRRSAToaXtRyDRTAO9L3pO9GMUgDvRQetH amAdDQaD1o6mkAA0UUnSmA4dKBSelFIBPwI+tL2oPWgUAPXpRQvSikUc/wCH1P8AYtkccGEVtKOR jgelYmggjQ7ILx+6UmtxAcDIpkD88+1FJ0zS9RQMQ9KUdKPSg80AHpQOtFJQAd6U/dpKUmgBD0oN LxRgGgA7UGjvSetABg0pPNJzmlyKAA5zQaCDSEcUAFGKBR3NABQKUAd6O5oATNLmkxS0AJzRxR2z RigA9qD1opemaYDcU7OaTtQOtAAaO1L0FJSA5TwiqrrXi/G7cdX5yc/8sIj/AFNdX2rhtD8QaNpP iHxVDqWq2Fi7akHVbq5SJnHlRjIViDjjG7ofwrc/4TXwp/0NGif+DCL/AOKoQM3cd6DWH/wmvhTp /wAJRov/AIMIv/iqQeNvCZHHijRf/A+L/wCKpgbwpDWH/wAJp4U/6GjRf/A+L/4qj/hNPCn/AENG i/8Agwi/+KoswNwilzwKwv8AhNfCmP8AkZ9F/wDBhF/8VR/wmvhTHPifRf8AwYRf/FUAbtBJzWF/ wmvhT/oZ9F/8GEX/AMVR/wAJr4T/AOho0X/wYRf/ABVKwG7ikxzWH/wmvhT/AKGjRf8AwYRf/FUf 8Jr4T/6GjROf+ohF/wDFUAbh5o6dKw/+E18KZ/5GfRP/AAPi/wDiqP8AhNfCg/5mfRf/AAYRf/FU Abveg9Kwv+E18Kf9DRon/gwi/wDiqP8AhNfCf/Q0aJ/4MIv/AIqgDc6mlrAfxx4TRWY+J9GIUZwt 9GSfoAeaRvHXhIAk+J9HwATxexnp+NAG/wBuTRisIeNvCZz/AMVPo3HX/Tov/iqb/wAJ14SCF/8A hJtHwOwvYyfyzmgLG+KKwH8c+EkAJ8TaPyQMC9jJ5OOgP/6qRvHfhFOvifSDk44vIz2z69Pf8KAO gorAHjnwmcgeJtI4/wCnyP8Ax/yeOtMPjzwiGQHxNpXzEgH7WmOmeTnj8aAOiorAPjnwmCP+Km0c kjIAvYz/AF6+1KPHPhLO3/hJ9HHub2MD88+/8/Q0AYF/o2o6D8SR4os7eS40u8gMOoJbxl5YzgYc IOXGVT7oJHPHNJBo954o+IFp4kubOez0rTodlol0nlzTy5OXKHlUGejYOQOPTfHjnwkWI/4SfRwd 23m9jHbPr09+nbrS/wDCceEt23/hJ9Gz/wBf0ePz3e9AG9XC6xo19o3j+38WWFvNc2s8P2fUYLZN 0gUD5XC5y/bIAJ+XgHtu/wDCbeE8f8jPov8A4Hxf/FUh8b+Ewu7/AISfRsYzxfxZ/LdQBztxp974 x8daXqhtLyx0bRyWje6hMMlxNkHhG+YJ05Kg9R9Op1TxBHp8rQRadqd9d8BIrazkKsT0/ekCMD1J bioP+E48Jlsf8JPo3XH/AB/R/wCNN/4Trwlgf8VPo/JI/wCP2Pt+P/66AMzwv4WvY9cvPFWvFRrN 5lEt43Dx2sXGFB7thQCR7+tb+p65Hpr+UthqV7cNgJFa2bsGJ/6aECNfqzCqp8beEx/zNGi9M8X8 R/8AZqU+NvCeAf8AhKNF/wDA+L/4qgDJ0LwndzeI28WeImA1c5W3tYXzFaxYIC5/ibBOT0yeK7Tt WD/wmvhPOP8AhKNE/wDBhF/8VTU8c+EpBlfE+jcf3r6Nf5mgDforCPjbwnnH/CUaL/4Hxf8AxVKP GvhTp/wk+i/+DCL/AOKoA3aDxWF/wmvhP/oaNE/8GEX/AMVR/wAJt4T/AOho0T/wYRf/ABVAG71F J71h/wDCbeE/+ho0T/wYRf8AxVH/AAm3hP8A6GfRP/BhF/8AFUAbpIoPesIeNfCfbxPov/gwi/8A iqP+E18Kf9DRon/gwi/+KosBu0GsI+NvCgGf+En0X/wPi/8AiqU+NfCh/wCZn0X/AMGEX/xVFmM2 6BWH/wAJr4T/AOho0X/wYRf/ABVKPGnhTn/ip9F4/wCn+L/4qgVjboHBrD/4TXwp/wBDPov/AIMI v/iqU+M/CqnnxNow+t/F/wDFUAUPhvH5PgPT0ySd85JPXPnPmuqrz34feJ/Dun+CLG3u9e0qCdGm LxyXsasMyuQSC2eQQfxrpv8AhNfCn/Qz6L/4MIv/AIqgDdorC/4TTwp/0M+i/wDgwi/+KpR408Kn GPE+i5PT/T4v/iqANwmjtWH/AMJp4VP/ADM+i9M/8f8AF0/76pP+E08K/wDQz6Lj/r/i/wDiqANz tQegrDPjXwp/0M+ij/uIRf8AxVA8aeFcZ/4SfRcf9f8AF/8AFUAbtFYR8aeFR18TaKO//H/F/wDF Uf8ACa+FBx/wlGi5/wCwhF/8VQBudqO9Yh8Z+FlALeJtGAPQm/i/+KpP+Ez8Kdf+En0Xrj/j/i/+ KoA3BQaxP+Ez8LcD/hJtG5OB/p8XP/j1J/wmnhT/AKGfReP+n+L/AOKoA3O1LWF/wmvhQZB8T6Lk df8AiYRf/FUo8Z+Fj08TaN6/8f8AF/8AFUAblLWEPGvhU/8AMz6L/wCB8X/xVKfGnhUDnxNow+t/ F/8AFUhm3zSVi/8ACaeFMZ/4SfRf/A+L/wCKpD418KgkHxPoo+t/F/8AFUwNz0o71h/8Jr4T/wCh o0X/AMGEX/xVH/CaeFTz/wAJPouB/wBP8X/xVAG5RWH/AMJp4U6/8JPov/gfF/8AFUf8Jp4V/wCh m0X/AMD4v/iqLMLG4DkUVhjxp4Vx/wAjNov/AIHxf/FUn/CaeFf+hm0X6/b4v/iqAOT8LW8/w+1b VtM1GG6OkXMwuLC6t7Z5lJ5BR9ikq2AuARzjg84q74S0O+uvFuq+LtVtXtTdARWVvOB5ixYGGYdU JAxt6jnIFdA3jPwqvJ8TaMOcc38XX/vql/4TLwtjP/CS6NgnAP2+Lr/31SA2q830a1l+H3irWheR Tr4evmE1tcxW5kWNyeUfYCUA3YGQAceprrv+Ex8L4Df8JJo+Dnn7dF2/4F7inDxf4ZYEr4i0ghQS SL6LgDufmoEcrpmknxD8TpfFa280Om2kCxWsksRjNzIUIL7XUNtAYgHuRkGmWtgfAvjzVNRlS5Oh 6uhlaaKNpFt5g2drhQSoO5sE8c4rrW8W+GkOH8RaSpAzzexj/wBmo/4Svw2xx/wkGknnGPtsfUf8 C+lAHLeH9Ju9b8f33jC5tZrS0VBb6elzGVkcYCtJsYBkBGcdD83T11PibDJcfD3VIY0eSR/JCogy WPmpwB3rYXxNoDuEXXNMZjn5Rdxk8fjSHxT4eXOdf0oEAsc3kfAHfrQBW8Hvejw5YW15pk9kbe2j j/fFAXIGD8qklRwOuDz0GK6Css+JNBDMp1vTQy5LA3ceRjk55qVdc0hl3LqtiVyRkXKYyOo60AX6 KzR4g0VlLDWNPKjqRdJgfr7ilXXtGcbl1ewK4JyLlCOOPWmBpUGqD63pKHa2qWSkHBBuEHPp1pH1 zSIlLPqtiqhtpLXCDB6Y69eR+dAzQpM81R/trSu2qWXUj/j4TqOveg6xpe5V/tKy3NkKPPXJx170 AX+TSA1X/tGx6fbbbOM/61enr1qI6xpYBJ1KzADFcmdeo6jr1oAu96AaqDVNOIyL+1IGckTLxjr3 7UDVNP27hf2uME585eg6nrQItdqWqb6rp0XEmoWiZIHzTKOpwO/rxSjVNPZWYX9qVUZYiZcAe/NA Fuue8dpv8Ba8uFP+hSn5un3a111KwcfLfWxHPSZT0OD39eK5/wAd31m/gLW1S7gYvZyKAsikt2IH v2+tAHRaf/yDbXkt+5TkkHPA9OPyqx2rPstRsvslsn22AuYVIDSruI2jnGasfbrRl3C6gK5xnzFx n86AJ6O9V/7Qss7ftlvn081fp6+tMOraap51G0HXrOvbAPf3H5igC4KSqv8AamnEg/b7X5gGH75e Qc4PX2P5Gnm+s0IDXdupPTMq8/rQBYoxzVZdQsWDFby3IU7WIlXg8cHn3H508XVs2NtxEc9MOOaA Ju9FV31CyjiMj3lusYIBdpVABJwOc9zThd23a4h64/1g6+lAEvelPpUS3VvISEuImK9Qrg4pRPCx IWaMkdgwoAkPSkpBIm0kOpH1pgubcsyieIsrbCN4yG64+vIouBKaTFN82I4/eJz0+Yc0GaLvKn/f QoAcORS0xZoj92VD9GFLuQDJdQPXIoAd2pD1pPNjyB5iZILAbhyB1P6j86GZRkllAHcnpQA6k5pN y5xvXPpmkMkY5MiDJwMsOtADxRTPMTJHmJ/30KTz4ScedHkdRuFADzRSM6D7zqPqaa0sa43SIv1Y CgB+TRTVkjbADoSeRhhzTgRjgigAo7UEgHkj86QMrKGDAg9CDQAUvakyMA5GPrQWVerKPqaAMe68 I+HL++N9daHp810clpXgUlz6tx8x4GCc47VsKoUAAAAdAO1LijFAGTY+GNB0zUZL+x0ext7yTrNF Aqtz1we2c84xmhfC+hR6udVXSLEagW3/AGnyF37ieWzjg+/WtbHSjFAFOw0qw0vzvsNpDbmeRpZm RQGkckksx6k5J61U1XwtoWt3kV1qel29zcRLsWR15C+nHUfX1rXAPpRg+lAFCXRNKl0g6S2m2n9m kbfsohURgZzwoGBzz9eahtPDOiWNza3NppltFNaQmC3dV5iQkkhfTJY+/NauDQOhoAz9W0PStdtV ttVsLe7hRtyLKmdp9R6fhXn3jA6d4f8AiB4Lw1ppmn24mAwuyOMH2XAUEkAnoN3PGa9Rwary6dZz 3kN5NZW8l1ACIpniUvGD12sRkfhQBT1HRdG8S2du2oWVrfRAeZDI6525wco3UZwOh9Ks6dpdhpFq bbTbK3tIS24pDGEDN0ycdTwOTzVv60YyKAOXtbzwgfHF1aW6Wh8SY3zN9nJkA2gf6wjA+UjgHvWF qfiDSF+LmkE6nYhItPnidzOpCSMRhGPRTgdznnp0z3KaTp6ai2opp9qt8y7WuRAolI9C+M449as+ Snl+X5a+Wf4dox+VAHPeMPCll4y0B7aQRfaAu+1uQqsUbrwT/CeM/wD1hXB/D3xC2l+J9WsPFd6t rqjxwW+66IG8xhgMyE7ScMv+9kHk5J9gAAGB0HGB2pCgZSrAMD1B5oAWuR+I4J8KxquMtqFouTnA zMvXHauuwfSuS+IxP/CMQqXKI+o2ivg4+Xzlz/n2oBHWnrRR3oxigA5xR2o7UUwFpDzR3opALjik oFBoAATQaOlHegAFA60UCgApKUUdRQAUE9aBR60AFHUZHSjNHAzgUAJS980nanHrTATvRRRSADSY 5HtSntRTAO9HWjtR0NIA6UUelHegA6mlANIaUDigBy9KKF6UUijntAKHRLMq4JES5API+v5Vtx5x kjBrE8PbV0KzGORGOTW0nVQOAKZBLSdKUUlAxc0dhSUY5oAU0dulGBxRmgAPrRSdqUjigAFJQOlG KYBQe9L39aCMikAneijvS0AHtR2oJo7UAJSjk0nagdaACjtRRjimAZ5FLSUd6QBmjFFLQAlFFLim AmeaXvSdqXpSAO1GeKKQUAcj4Wjin17xek0MUmNTA3NHngwR/Lk9fp7+9dULeDeZPIi3k5J2DOel c34Qj26j4pby1XdrD/MB9791GPXP/wCv8B1PWgCD7Hak5NrAT0z5YoFpbDkW0I+XZxGPu+n09qmF FAEBsbQnd9kgzgDPlL0HbpSfYLLIb7FbbgAAfKXI/SrHalNAFf7FaA8WkHf/AJZjv17UCwslUAWd uBz0iXv17VOelLQBB9jtQCotoQGGCPLHIpGs7VutrAeMcxjpVjFJQBAbCzZgxs7csCCCYlzwMDt6 AUsdpbQqFjtoUX0WMAdMfyqfPNJjmgCFrS2bJNtCc+sY/wA9zSGxs2YMbSDcAAGMS5AHTtU560dc UAR/Z4dpXyo9uemwUv2eEPvEMe7GNwQZx6U89faigBqxRqQViQEdCFHH+cCnZ+nFAooAOD1A4oAG CMDB6jFHFL3oAQYGOBgdOKOpzgZoHeigBeoGQKTAAxgAemKWkPWiwCKqoAqqAuMAAcClCqCWCqGI AJx2HQfqaKBQAhZY0LNtVFGSTwAB3pqrGY/kVNjfNkAYOeSfxrzdbiw174ualpviFUljtYEj06xu Pmhc43M+w5VnweD1x9OHzWqeHvi1o1loMSWlnf27tfWVsoWL5A2JCi/dPIGehx65pAekcZxx60xo o24MaNxjlRXPXXgqxu/Glt4oe6u1urePYsKsvlt7nIz+Gew9Koa7qMmreNbTwhHcPbWxtWvL1kkM ckyZwsSMpBGeS2OcDrTA65kgkBhZYm45QgHj6U4xR5OY0PGOVHT0rkR8MvDNvrFlqmn2s2n3VrIs m61mKiXBztfOcg98YznnNN8a+LrnSrux0LRI45tc1FgIgxBEKE43sO44b06E9qAOuf7PAv7zyo1Z gPmwAW7fjxTzGhbcUQn12jNc9ofgvTtIRLi7U6pq2Q8mo3w82YtjHys2dijoAMYro6AGhVHRVH4V G1layFC9rAxRtyExg7TjGRxwccVN3ooAjFtbrnbBEMjBwg6U1rO1fYGtYCEOUBjHyn29OtTnoKKA IRa2yDC28Kj2QDtj+VH2W2KbTbw45wNgxz1qU0AUARC1twAPs8WAcgbB19acba3Z95giLkY3FBmp BSH2oAhaxs33BrSBg33sxqc/pQ1natuDW0B3DDZjHIxjB49KnxgUGgCn/ZWnYA/s+0wMDHkL26dq c+m2Eh3SWNq7erQqT/KrWaMjFAFRtM091CtYWrKOQDCpA/T2FM/sbS2xnTLI7RtGbdOBjGOnpx9K u0tAFH+xdKJ50yy6AY+zp/hTP7B0Yyb/AOyLDfx832ZM8dOcVo96SgDh/h7pGmXXgbTpbjTbOWQt MS0luhbIlcckjqOmf5V1f9jaXn/kGWWfX7On+FYXw33/APCAaX5hG7Ep47DzXwPwGK6qgCidE0k7 QdLsSFORm3Tg4x6U9dI01M7dOtBkY4gUcenSrdLQBRGi6TsKf2XY7D1X7OmP5ULo2lJnbplkuc5x boM569u9XjR2oAz20PSJEKPpViyn+FrdCOmPT04o/sPR+n9k2H/gMn+FX6PpQBRbRNIbAbSrEheV Bt044x6egAoGiaSpyNKsQQMZFunTj29h+VX+tIaAM7+wNF3b/wCyNP3Y27vsqZx6dOlObQtIY5bS rAn3tk/wq+KWgDPOhaOxJbSbAk9c2yf4e5/Og6JpO0qdKsdrLtI+zpgj06dK0McUUAZx0DRjgnSL A4BA/wBGTgHg9vSg+H9FbOdH085OTm1Tk4x6elaNFIDN/wCEe0TJP9jafkkk/wCip1OM9vYflS/8 I9ou/f8A2Pp+7HX7Kmf5ew/KtGigCgmh6QgIXSbFR7W6D+lKdG0suWOmWRbGM/Z0zj06VeHU0Y4p gURoekAHGlWIz1/0dOeMenpxT10nTVAVdPtAvoIF/wAKuY6Ud6BlFNH0tBtXTbNRjGBAo46elOGl acucafaDPXEC/X0q3zzQaBFA6JpJVQdKsSFJIzbpx244pF0HR449iaTYKmMbRbIBj6YrQopDM1fD 2ioMJo+nqCMEC1Qf09zSf8I7oe7d/Yunbs5z9lTOfXpXJa1ruqeJvFk3hDw/dfYobZQ2palG2ZIw f4I/RuQN3UHPTHPV6X4c0nRjvs7NRcEENcykyTPnrukbLHJ560xA3hjQGGG0LTGHobOP/CkXwv4f QqV0HSwVOVxZx8H8vaqGh+Ef7E8R6rqy6reXC6gcm3mYlYzuJ457ZIHoKzWuH8ZeKtW0Y31xbaTp PlpNHas8MtzKwJIaQYIQYxhcZJzkjFIDoB4V8PAcaBpQ/wC3KP0x6enFNPhLw2xGfD2knAwM2UXH /jtY+kfD+10HxP8A2tp2qahHblWD2Ek7yRsSCM5LZOOvOar/ABUsI5PBV9qMW+K+tFRop4nZHA3q CMqRxz3z+dMDfPhDwyRg+HNII9DYxfT+7Sf8Ih4Zzn/hHNI/8AYvw/ho8J2NvY+GbDyYyrTW8csp LElnKDJOSf51tUgMX/hDfC+Mf8I1o2PT7BF/8TQfB3hcnJ8NaMT6/YIv/ia2qDTAxT4O8LHH/FNa Mf8Atwi+n92j/hDfC4PHhrRh3/48Iuv/AHzW3jpR3oAw/wDhC/CuP+RY0X/wAi/+JpT4L8Kf9Czo v/gBF/8AE1t5xRigZh/8IX4U6f8ACMaL/wCAEX/xNO/4Q/wuOnhvR+uf+PGLr/3zW0KCKAMT/hC/ CoHHhnRv/ACL/wCJo/4Q3wt0/wCEa0bA4/48Iv8A4mtugdKAuzD/AOEM8K9P+EZ0X/wAi/8AiaX/ AIQ3wsevhnRv/ACL/wCJrbNJQF2Yn/CF+FQOPDOij/twi/8AiaD4N8LHr4Z0Y46f6BF/8TW515o7 c0BdmH/whnhU9fDOi8/9OEX/AMTWB438MeHdP8EazdWnh/R4J47ZikiWUalT04IAIOOh7V3dcv8A EY7fh3rh3Ff9GIyM85I449elILsksvBnhd7G2eTw5osrmJSziwiwxwMn7tWD4M8K4H/FMaL/AOAE X/xNbMQ2wRrjGFAxjGOKcelMLsxP+EL8K4/5FjRef+nCL/4mj/hDPCuc/wDCM6Ln/rwi/wDia26X FAXZh/8ACF+FRx/wjGi4P/ThF/8AE0n/AAhfhQ4/4pjReOn+gRf/ABNbpPNJQF2Yh8GeFSefDOjH 62EX/wATSDwX4VGMeGNF/wDACL/4mtztRQFzEHgvwqOnhjRQcY4sIv8A4mkPgvwoRg+GNFOOn+gR f/E1uigUCMI+CvCmAP8AhF9F/wDBfF/8TQfBXhTPPhfRf/ACL/4mtw80uaAML/hCvCgH/IsaLj/r wi/+JpB4J8Jgk/8ACL6Lkn/nwi/+Jrdo7UAYX/CE+Exn/il9F/8AACL/AOJoHgjwnt/5FjRfr9gi z/6DW7RQBhf8IT4T/wChX0X/AMAIv/iaT/hCfCZHPhfRf/ACL/4mt8dxR9KAOdXwJ4RUHHhjSPxs 09MelOHgbwkuAPDGj5AxzZRn+ldAKDQBg/8ACFeFMf8AIsaLjP8Az4Rf/E0v/CFeE8f8ivov/gBF /wDE1uClPIoAwv8AhCvCf/Qr6Jz/ANOEX/xNJ/whPhMtn/hGNGz/ANeEX/xNb1JQBgL4G8JIAB4Y 0fjHWyjP8xTj4J8J8Y8MaMPcWMQP/oNbtBoAwD4F8In/AJljR+//AC5Rjr+FMTwF4RjyV8M6Vk+t oh/mPaui7UdqAOd/4QLwgQf+KZ0nkY/49E/wpR4E8IqoUeGdJwOmbRD/ADFdDRQBw3iPQfBWg6bG 8nhXSp7i4kEFrbJbRq80jHAGcZAGck84Az2FW9O+H2gi2D6p4d0F7piSRa2QWNAQBtGeTjHXj6Cs H7X/AG58dVtZl3W+jWjGJDkr5hVSXweh/eAA89BW9490/UrrQ7y8tdeu9NhsbSS5CWfyNJIo3Dc+ c7cAjaMcnJPGKALS/D7wep48NaZxnrbKf5il/wCEA8IEj/imtL44x9mX/Cq/hOa48U+A9Pm1Se7E 8gYPPDOYHcgsu7MTD8vUdK5r4QG71O0v7/UtT1K8uLe58iMT30roBsGfkLbT16kflRcZ1jfD3wew x/wjemgHji3Az+VIPh74PVif+Ea00kgjmAHqMVgeHbu58e69rF7c6hewaPYzm1s7SzuZLfeeMyO8 ZBbpwM4GTx6waPrOqeFfiGvhDUtRl1HTrtfMs7m7YtPHu3EKW/iGVZcnvjp0oA6T/hXfg4jH/CN6 d6/6rn86o6p8PPD0dr52meGNIlnjbc0M0ZAlUA5UMPuseMHB6YI5yMfw7q0Hi3xTr1lq2rahbXcN w0VjYRXktoyQrn5tqFQz9zncQMdq6TwRp+s6XZ6nZ6zeXV40WoOttcXLlnlh2oVbJJ9SOMcg0Bcz 9F8KeAdf0xLyy8PWBGdkkckQEkMg+8jgHhh3H48g5Oifhx4NP/Mt6fx6RYrnPDd22mfGLxLosZxb XQF1sG04kKIxJ6H+Ju3pzXpMkYlieNiwV1KkoxU4PoRgg+45oA5sfDrwcAR/wjen4OOPK9sUh+HX g5mGfDlhx/0zrl/CEd5cfEzxBaTazqMthpbYt7SW/lfliCCctlwBkc56jPart/oXivxi8moR+Irr w/ZbyLOziikSUqpwHl+ZSCxyduCMFe4pAbf/AArrwdj/AJF2x56/If8AGk/4Vz4Oxz4dsj/wA/41 heC/Euu26a/o2vxm9vtCiDIYFZ5bhcNwM8uThcHGTuGeag1Lwd47nifVz40lTU0XeLG1R1txj+BR uw3GeWQ5zzRZAdIPh14O2lf+EdsMHr8nXjHrQfhz4OP/ADLtl1z90/41i+HNc1Xx14IS4+3tpk0E kkN7PaoBJJtTK+WTkLncpbjsQMdQ74a+Jr7UPAl5qGqzm4+wyyKsrEb3jWNXG455PzEZOOgzzk0W QGwfhx4OK4/4R2xH0Qj+tH/CuvCBUg+H7M88nBz+ea57wfHqHj2wn13WNavoY3kMMNjpl21vHEow csVwxYknqehH4X7Gx1rQ/HmmWEutX+o6NLZTtF9rcF1kUoMOygb+OQWyeW9KLIDSPw58Hkc+HrI8 5yVP+Nc7408HeHNF0e0vdP0i0t7hNRtAHA7GZcg5yCPUGvSq5H4jKW8N2yZX59StF+bpzMuP1xRZ COu6UmaU9aO9UAlLSetHegBe+aCc0lKRSABRyaBwKM0AAo70d6KACgcUdqMUAA60UAc0daAAUdqK D0oAB60GiimAUd6KKQB3oHejvQKAD0oo70dKACjvRRQAUd6DzRnmgAwaUdKDSDuKAHr0ooXpRSKO e8PK/wDY1nnGPKXB9RW2g75rJ8P/ADaJZEsc+UtbI4pkB9aMUv8AKkoGGKOKPSl4oADjFIDS4pOn FAB1NKaKCDigAB4pKUCkJoAUYxikNHelPAoATg0p6cUnpRzigBcUlFKelACe9GeaBmgUALSA4oHa igAzRRS96ADtSdaOlL0oATNL2pMUUAHY0UHpR3oAXtRR24o7UAct4PjEd94q4wW1uQ9MdYYj2479 a6kCuT8IFzrvi8EOEGqgqSCAT5Mecfp+ldX24oAKKBRQAozQaTvS4oAQnNHail6UAHeg0e9BoASj vRRxmgAo6Ud6D6UAKaQdKOlHagA70d6MZooAO1Hej3oFAC+9JQO9FAC0nSijvQAc0opMc0vagDzb 4j6XZazq+nWWmGRfFIIkha3VcRxZxvmbGRGDn1OTjBzTfAeuyL4n1HS/E0EkPihwB58rjbPGPurG BwoAycLwcseua2L7RtU0nx6/ibTrH+0oLu1FtdW6SJHLHtIwybyFbpyCR9aQaHfa943sPEN7pw0y 306J44o5JVe4nY4wWCFlVBl8DcTz0GaQzsxXnHj7QNatdfsvGPhzzZry0TZPbBS+9M9AoGTkFgQO ehGCK9HrkfE9945g1ONPDOkabcWYiG+W8lwS5JyAA44Ax+JpiKfhn4n6b4h1GDSpdO1Cy1Nwd0Uk JKZGc4I5A4PLAVgrpkeufHPVrbUZLkww2G5FileLK4jG3K4O3943QjJ/Kum8KaZr9zrF34g8VW9r b3zRJb21vbuWWKMZJP3iAST25496j8R+G9Rg8XWHi3QIFnvYx5F5aNKIxcREYyGP8Q468HA9OQDm vEsC/Dfxbo+o6RdXEWn38nk3VgZGlVgCNxXdkg8jpzke+K9b71wuq6LqPjbW9NOo6bcabotgWmeK 4mQyXMhwAu2N2AUDPJOeeld12oQAOtL2pO9HWgAoFHvR3oAOM0tB4oFABRkUUnegBcUh9aU0h6UA HaijHFFABSik70DNAC96MUlL3oA5T4agD4e6QAB9x84UDnzGz0//AF+vNdViuQ+GKsvw/wBPRgw2 yXAG7HQTv6V146UALSY7UA80vpQAHijpQaCeKAEzS0mKKAFozQKKAE7Ud6XHFFACUtFJxQAuOKKK OlABS0lFABQKKAPegBRR3pAOKDQMXvRRRSAQdKQkgEhSSBnA6n86XtRQB5B8L/Ddnr2hajfajNfl 7i5Mc0cdw8CyYAbc2wgscuepIHYCtbwdfanoXj3U/B+o39xf2wi+0WUtw5kdV443EZIwcegKcdat aLpGpeBdf1URWd1qGg37faIzbYd7aTnKmPIJByBlcn5Rmrvh3SNQvfFt94r1S1+x+dEILO0kOZY4 +PmfBIDHHQE49uaAOy5ryfWp9T+HHji/19LK4v8AQdVw9z5Z5ikyepwenOM4BDYyMV6xmuJ1bxN4 yt9UubbTfA8l3aI4WO4kvY081eATt5xznHPTBwKBGl4a8caH4rJTS5ZzOsYkkikgZSgJwMtgr27M ao/FUkfDTWcBSdsX3un+tSrHgjRrmws73UdRsoLPUNTnM8tvCABCvRUyOpAySfUmn/ELT7rVPAup 2VlbtcXMqxiOJerHzFP/ANf8KANfQyT4f00kjJtYs4/3BV81j+GINRtNBs7XUraG3kt4UiVY7gzE hVxljtAycdBn61sGmAtHrSUvvQAUd6CaTFADu4oPI4o7ikNAxfrSGlFJQAvakpTTelAhaTFFFAAe lHajtS84oAK5b4kI7/DrXFQnd9nyMZzwwPaupzXL/ERFb4fa2WjVylszLuAO0+oz3FAHSxbTEhV9 67Rh853D1z3p1RWhJsoD82TGv3xg9O/TmpT0oAXpSdaX2pDQAvekzzS85pAKAFxig0UHmgAozRRQ AUYpDS0AHakpexo7ZoAMcUnQUp6daTPFAAKSnUlAC8UZ5pKXvQAe9IOlL0o7UAHakFHNFAAetBpf ekNAB2o7UUdqAA0dqTNLQB5foaSWfx412OVMfaLTfGxPLDER4J5P8Qx2x7V0/jjXNKsPDeq6fdal awXtxYTGGCWYIz5VgMDOcZ4p3ifQbm4v7DxDpG0avpucRv8AduYTnfEfQkE7T2P6XpZofFPhW+hs ZHia6t5LciZDHJA7Jja6kZUjI4xQBy/gPxT4e0zwTpdre61YW08YdXSa4RSrb2OO3/6sVl/CHVtM tbLUbGbUbJLmfUmaCJpwJJQUQAgE5b+dbGheKNE8LT3Phm+tpNI+xf8AHvLcA/8AExHRpFIUbmJx wMklsDOKtfDXSb3TtAuLi/jlin1C7e68uZcSqpwBv7hiBnB6ZpAc74MvYPA/ijXdC8QSRWP2y5+0 2d3KDFBOCMkKzYGRuHGeuR2q1Lbjxl8VrHUtOEU+kaPCvmXoO6OWXLMFjZThiNwye2Dntn0l40lQ pIiuh6qwyD+dKqLGqoihUUYCqMAD2FMDzDxDZeD/ABdrGs2er3NppGt6dMI47oXAR5E8tWRyDgNg tg9xjqM10vw4uNUuvBNnNq0rTSsz+VNISXki3HYzEknJHrzjFdJJZWkxUzWsEhR/MUvGDhv7w46+ 9QatqsGkWTXMwaRydkMEYy80h+6ijuSfwHU4ANAHntms2ofH3UJfLzDYWqp5mD1Ma8Z6dZDXqHQV zXhDQLnSYb/UNTWMarqty11crG24RZ+7EG7hRxn1zjiuloA868GZHxQ8Z7uu6M4Enuf4ckn68Y9O Qapab4m8Qy+JtR0HXfEtlo91bP8A6MXs0AukyeVLEAnBU4HPJ44NO8L3C2vxb8UlobuRJnEYkitp JER+DhmAIXIPUkDg16TcWdreeWLq2hnEbbk82MNtPqM9DQB5v4e0/U7/AMQ+KfEdlexXtwLRbPTb 7ygiXLqoYkDJUpuVVyOvOCOpi8O+MNQ1TTZptY8ZWGjX9vK6T2E1nGkseDx8rncevYHnjrxXqnQA YwKja3gaZJmhjaVM7HKAsueuD1FFgPO/BKW3hTwZc3Wu39pYz6rcTXMYumFuSpACrtc9cDOB0DAd qqfBi8sH8K3OlzXdsbuS5dhbGVfNaIxp823O4jk8+ua9QljWVGBAyVIzjpmud8DeFU8JeHYbKTyp L5/nu548nzH+pAJAHAzQB5/e+GfFnw2vpb3wmz6hpUxzJbNC0pXqAGQHLYGPnXB9eBz2ngnx9p/j OPy/KW21KFBI0DMGyOhdD3GeD3GRnrWd4b8YDSobuy1uy1K3torq4Npfm0kkimi81sAlQ2G68dMY xUGh6cNY+KM3iaw0u4s9KS3ZftE8Pk/apzwXVCA2MMeSOdtID0muT+IWBoFlyQP7VsuQcf8ALde/ ausGa5L4jADwvC5Gdmo2bYxkf69OtMDre9HpRRTAO1JR2ooAWkNL34oPSgAHSg0CikACigd6KYBm j+dGOPejvSAUdKSlGKbQAtHaiigApKXHNGOKYB2o70goyc0AL3oozQKQC8ZpDR3pce9ABgUnfFLn ikNAC0neiigAzQOlBxSjgUAOXpRQvSikUYXh/aNCsyD/AMsl/lWyDmsLw+6tolkD08pR161txn1G DTIJO+O1J7Cl70UDDsKOlHajtQAtNOTSgZooATFKTxRRjAoAQdOKKUdKPpQAgFB/Sl/nSGmAdTSt nNJ9KDSAU9KQ54o70uOKAE6Uvek64pfWgApBR1peOaAE70tA5NIaADrS5pO9GKAFANIaKWgBO3vS U4kUnegBe1AGKPpQTQB55oPiPSNI8R+Ko766mSaTVCQiwSyDARBnKqQPTGe3QVun4geGh1vZwCM5 NjP/APEfl61X8Gh11vxeCzlP7WyM9MmJDxwO238q60E+tLUDm18feGi20X8u7PQ2cwP/AKBSDx/4 aI4v5j9LKf8A+Irpsn1oyTT1A5r/AIT3w3/z/Tf+AU/H/jnsaP8AhPfDeMi9nIzjIspz/wCyV0pP ucUZo1A5r/hP/DRdVF7OWbhcWM/J/wC+KB4+8NkjF5cHJwMWM5yfT7ldLn3oz70tQOZ/4WB4a4Bv p/X/AI8Z+Pr8nH40o8e+HDn/AEu6G0AnOn3A4P8AwCulyaCTjrRqBzg8deHiSRdXB5A/48Z+/wDw D2NIPHfh5vu3N23OPl0+4PbP/PP0rpc+9N5z1o1A5lfH/h1ztFxehsZKnTbnIHuPLpy+O/D7g7J7 18EDKabctyenSPmulyTRk+9GoHNjxzoecb9RJJwANKuiSeen7vnpSjxxoRXcH1EgnHGlXXt/0z9x +Yro+nc0UwOe/wCEz0jBYx6tgLuP/Emu+nr/AKrp1/Km/wDCbaORuEWrtH/z0Gj3ZUc46+X65/Ku ioPWgDn18Y6Uyb1g1ll9V0W7I9/+WX1/Knf8JjpW7H2fWScZ/wCQLedPX/VVvD0o70Boc/F410iY Axw6w4KhwV0a7PynoeIuhoTxnpMgJWDWCAcHGi3Zx/5CroMmigehgjxhpf8Azw1nrj/kCXnX0/1V IPGOlEA+RrOM4z/Yt5/8arfxml79aA0ME+L9N4ItdbOfTRLz/wCNUi+MdMLFRba3x97/AIkl5wfQ /uq3/wBaO1AaGA3jHSkZFaDWQXO1f+JLecnBOB+69ATTf+Ez0kkhYdYcgZIXRrs44B/55e4rR1DX NL0hlGpaja2YYZDXEoQfiTwPSjTtb0vWN/8AZuoW14FALNBIHA5I6jjqDQBQ/wCEw0sAHyNYwen/ ABJbzn/yFSDxlpJBxFqxAGSf7Gu+B6/6rpV6TX9Jh1mPR5NRtl1GQZS1Mg3kYz0+gzTL/wAS6FpV 19l1HWdPs59ofy7i5SNsE4BwSPQ0CKP/AAm+i79m3Vd+7aV/se7znGenlelIfHOhLCkzPfBGGcjT bhscZwcIcGpW8ceExgf8JPo5+l9Gf61o3ur6ZpqRPf6laWiTHbE1xOsYc+gyeaAMk+OdCUgF9RGQ G50q6HB7/wCr6e9OHjbRSu4f2mVHcaRd4/8ARVdD0zRg+tAHPf8ACbaKJPLxqhctt2jSLsnPp/qq D430REDOdSQHpu0q6HbP/PP3roKWgDnG8d6CG2mW/BwDg6XdDg9P+WftQPHXh/LA3F4NpAbdp1wN v1zHx1FdHk5paWoHM/8ACfeHDjF1dk9eNOuD2z/zz9KcPHvhwgH7XcjPY2FwD/6BXSfjRz60agc4 3jrQEOGmvQcbhnTbnkYzn/V9MUjeO/D6gM096oIB+bTbkdRkdY+4rpATRnH1o1A5s+PfDatg3dwG wDj7BPkZ9tn1oHj3w4VDfbZ9p6E2M4z/AOOda6Qk+tBJ9aNQOa/4T7w3/wA/0w6dbKfv/wAAoHj7 w2Rn7dN/4BT/APxFdLnjqaMnHWmBzI8feGtwX7fLkjPNnP8A/EUv/CfeGVG46i6j/atZh/7JXS5P vQM+poA5r/hPvDIIH9otz/07S/8AxFB8f+GFbB1TBzjHkS//ABPvXS5OetHPPJoA828B+MNC0zwb YWt5qIF1umdlWCRvvSu3ZT2NdJ/wn3hkAf8AEyb5un+jS+mf7tQfDVgfh9pZUyYxIPn65EjA9AOM 5x7V1mT60Ac0PH/hc8DVMn2t5T/7LQPH/hjH/ITPTJ/0aXj/AMdrpQeetLn3oA5oePvDJ/5iTen/ AB7S/wDxNIPH/hhgxGp9OubeXj/x2umzx1pCT60gOa/4T/wuMA6ngkZANvKCfw20Dx/4YOcamTjq Rby4H/jtdLk+tGTnrTA5o+P/AAurKp1TBb7oMEuTxn+76Ug+IPhckj+1BwMn/R5eP/Ha6bJoyeea AOaPj7wwODqnP/XvL/8AE0g8f+FznGp57cW8p/8AZa6bJx3pMn1oA5v/AIT/AML+Yqf2qu49B5Mn P/jtJ/wsDwvgE6ptBOBut5Rk57ZX3H5103PrRz60Ac0fiB4XUEnVOAM5+zy8f+O00fEPwox+XWEb 6RSH/wBlrp8mjn3oA5g/ELwoCB/bCZIyB5UmT/47Sr8QvCpIA1ZST0Ahkz/6DXTZPrRk560Ac0vx B8LMCRqynABOIJOh6fw+9L/wn/hjJH9pnPp9ml/+JrpATRn3oGc4vj7wywyNSyPUW8v/AMTSHx/4 YHJ1Mj/t3lz0z/drpR0oyaQHNf8ACe+GSeNRbpn/AI9pcf8AoPvQfH3hkddRYc/8+0v/AMTXSc5o z70Ac0fH/hhcj+08kYyBbyd/+A0Dx/4XIJGqqQPSGT/4mulycUZNMRzB+IfhUZP9rAAdSYJf/iaX /hYPhXn/AIm6cHH+qk/+JrZ1HWdL0gRnU9Ts7ISZ2G6uFj3Y643EZqxBcQ3UEdxbzpNDIoaOSNwy uD0II4IoA55viF4UUEnWYvl6/u347/3aQ/EPwmoLHWYsDqfLkx/6DW3bavpt7eT2drqVpPdQHE0E U6u8eDj5lByOfWrM08VtBJPPMkUMalnkkYKqqOpJPAFAHN/8LB8KDrrMP08t8/8AoNNf4jeEEBLa 9bAA7SSGxn8q6W3uIbq3juLedJoJFDxyxsGV1PQgjgin5OetIDlz8RfB6nB1+0H4t6fSnf8ACxPB /wD0MFl0z98/4V0+SO5oJPrTFqcx/wALF8HYz/wkNiAO5cj+lA+Ing9gCPEVhz/00rpueOaUn3oD U5o/ELwgCv8AxUWn5PQCXJo/4WH4QAz/AMJFYYxnHmc/lXS8+tHfNA9Tmx8QfCBBP/CR6cNo5zMB /OlX4geEXAP/AAkWnjPTdMF/nXSEmkz9aAObb4heD0YA+I9PByR/rh2//VTv+E98I4/5GXS+c/8A Lyv+NdHmkBNAzAXx34RYZ/4SbSBgA4N5GOv1NRf8LB8HkE/8JLpmB/08LXS5pMk0Ac2/xB8HxjJ8 SaaeM/LOD/Kg+P8AwguM+JdLOc9LlT/I10meaMn1oEc0vxA8HsuR4l0wDj71wo6/WnL4+8IFto8T aVnn/l6XH866PJppCkqSASpyMjoemR+ZoHoc+fHnhHOP+El0rOSP+PpCP5+9Yfjfxf4YvPA+sQW/ iDS55pbZkSGK8jZnPoBnP5c46V3vTgcAdq5n4h5Hw91zk5+ytjBA5yPWgQtp438JxW0UDeJ9I3xR KGJu0GeB71OPHPhIkf8AFT6Pyf8An9j/AMa2bU7rOFgUO6NTlAMHgcjBIx+NTZ4pDOfPjrwlz/xU +j8Hn/TY/wDGlbxz4S4/4qfRuc/8v0f+Nb+eKOmAKYGB/wAJ14S5/wCKn0f5SAf9Nj/x5pE8deEX GR4n0ccA/Nexj+ZroM9utICfWgDBHjrwkTn/AISfR+/W9j7fjSnxt4THP/CUaL/4Hxf/ABVboAGc AAk5PvSnsKAMIeNvCeP+Ro0X/wAD4v8A4qkHjfwkR/yNGi9e9/F/8VW9mgE4oAwj428Jn/maNE/8 GEX/AMVSDxv4TK5HijRef+n+L/4qt0dMYFL70AYX/Cb+EwOfFGi/+B8X/wAVR/wm3hP/AKGjRP8A wYRf/FVuk0h5GCAR70AYR8beE1Un/hKNF9f+P+L/AOKpf+E28JnB/wCEo0X/AMGEX/xVblAAAwAB znAFAaGH/wAJr4UP/M0aJ/4MIv8A4qj/AITXwn/0NGif+DCL/wCKrcHU8detAULnAAJ5OB1oDQw/ +E18Kd/FGif+DCL/AOKo/wCE28J/9DRon/gwi/8Aiq3f60dD0H5UgML/AITXwn/0NGif+DCL/wCK o/4TXwn/ANDRov8A4MIv/iq3AigkhFBPUgdaXNMNDC/4Tbwn/wBDRovP/T/F/wDFUf8ACbeE+P8A iqNE/wDA+L/4qtw4JyQOnpS9RyBigNDCPjXwn/0NGif+DCL/AOKpv/CbeEySP+Eo0Xj/AKf4v/iq 3PLjDbgigg5ztFKqqgwqqo9higRif8Jr4TGM+KNF5/6f4v8A4qj/AITXwn/0NGif+DCL/wCKra2I DnYoPrtFBjTO7YuRxnaM0AYv/Ca+Ez/zNGif+DCL/wCKpP8AhNfCf/Q0aJ/4MIv/AIqttkRlAZFI GMAj06UgijAbEaDccthRyfejUNDFHjTwp/0NGi/+DCL/AOKpf+E18KA8eKNF/wDBhF/8VWr9jttx P2aHLHLHyxyfU1J9ng6+THkf7AoAxT4y8JnhvE2iHnPN/F9f71L/AMJp4U6/8JPov/gfF/8AFVrC ytVYMLWAMFKgiMZAPUfTgflTE0+yVQi2dsqhdgAiUAL6dOnJ/OgDM/4TXwr/ANDPov8A4Hxf/FUH xn4VBx/wk2i/+B8X/wAVWr9jtCVzawEgkj92OCTkn8+aQafZLGI1srYIowFES4A+mKegGX/wmnhT /oZ9F/8AA+L/AOKo/wCEz8Kdf+Em0XjjP2+L/wCKrUNhZFQDZ2+Mg48peo6dqadNsSf+PK27j/Ur 369qNA0M0+NPCmP+Rn0X/wAGEX/xVA8aeFDwPE+i5/6/4v8A4qtFtM0+QMHsLVgzbiDCvJ9TxTHs dKtyrvaWUWcIrNGi59ADj9KA0KA8aeExwPE2iAe1/F/8VR/wmvhT/oZ9F/8ABhF/8VWjHpmmozeV YWYbPzbYVznHfj0xTRZaVNJMn2Wxd0OZV8tCQT/e/wDr0aAUP+E08K8A+J9Fz6f2hF/8VSnxp4VA /wCRn0X/AMD4v/iqvvpOlvtjfT7Jjt4UwIePpjp0pv8AZGkEso02xJAwwECZAxjnj0zSAo/8Jr4U H/Mz6L/4MIv/AIqlHjTwqTx4n0Xrj/j/AIv/AIqro0fSS3Gm2JKALxAmQMHA6ehP5n1oOiaSd2dK sTuG05t05Hp0oApf8Jr4V4/4qfRf/BhF/wDFUHxp4VAGfE+jDPrfxf8AxVXToekZydKsMk9TbJzn 8KF0XSVyU0uxG7qVt05/SgCkPGfhUqSPE2i4HU/b4uP/AB6ub8b+I9D1LRrK2sNc0u5mfUrVhHFe RsWUSqegPTiuyfRNIkUK+l2LKCCA1uhwRznpXKePtMsbPQIHs7G0t5JNStd0kUKq2N4BOQP7vH0o A7o0lBo9qADtR2FHakpgFL0pBSnrQAUUuOKaetIBaO9FFMAo70UCkACijvxR2oAXpRSZooAP50UD ijrTAKO9JSmgA4ooFHTikAv1o7YpD1o60ALjFJ70UUAHel70lHegA9KUUhHNKOhoGhy9KKF6UUhn N+Hlb+ybPJP+rWugUmsHw8+dFs24/wBWOnStxM4G7r7UyESd6Sl9KKBgKWm0YzQA6k5pe1JQMKD0 FLSEUCAdKM0DpikzQADrSnmjHT1oJ56UAHOeaDSHk0GgA70Gj+dB6UwFHHSigc0DvSAPekzS0neg Be9JQOfrS4oATrR3paOKAExS9aTNGMd6AFpKXpQOtABR60vUU3FAHKeCsvfeKpmLbm1uVcH0VIwO Meg966vmuV8EYB8S8YI1253e/wBw/wAiPX+ldXQAmaPSj0o7UwDtQaO1B6UAGM0HtijtQelIAz0p ccUh7UE8UALRRxnNIATQAYoNHelxzQAnalzxRR2oASjvRRQAdaKKKAAdaODRRQAopMUUd6AFPSjt SUo5FAHKfElinw61sjOfIHT/AHhV/wAHWsNn4L0WCAERiyibnPJZQxPPqSazviYN3w51kYBzEvXP Hzr6A1p+ErmG78HaPNAytEbOJQVxjhQCOPcUAWJdA0mfWotZl0+3fUoV2R3JX51HPf8AE/nWZq+g eFrU6jr+tafZ3BKiSea7iE21VAAVQQcdOABkk9zXSD0rzvxLqUGqfE/QvDd6p/s+IG4eNj8lxNtJ jDDGCq7ScepHpQBc0HwZYXOpx6/e6HZ6cVybPTorZI/IGfvylR87kc4PC5x1ya5H4sajqN9qWnaf LoVxFDBfBracyhhd5wMKo5ByR19fwr168vILCATXDFUaRIgQpJLOwVRgepIFee/Fh2hu/Csysi+X qIJZ+gGV6jB44GeP50gJNV+I3iDSbVri98C3VvHvMYeS9jwzH7oAUEkn298dK9DhkMsMcjRtGXUM UbquR0Ncjp8S+MPEKa9Kd+kac7x6dEy8TS/dec5HI7IQexNdhmmAUuOKBQOKAFPSkFKaKADvRnHW jvmkzxQADrSn9aB0ooASjtS55o7UAJ2o9qKOlABRmlFIOaAF70d6O9IzBEZjnAGTQByfwzBHw80r IYFhKxDDpmVzXWDpXM/Dzb/wgGiquMLb7fu7eQSORjr/AJyetdMaADvTqTtRQAEUUdqOaADNJxil pCKAFoo7UUAFJ3o7UUALRSUGgBaO9Ao70AHajrRS0DGilHWjik5zmgQ4UlA9qXvQMSg0uOTSA0AA 6UyWQQxPK2dqKWOOuBT+1VNUga60m8t1Z1aWB0BTO4EqRxjvQI4D4YD+37jWfFeoqs2oXM/2dGcg +VCFBCKv8I+bnnn+a+D5v7B+JfiHwtFKo05sXdrD0ELEKzIo9Pn6D+7T/gwVHhG6hwqyRXrBx/F9 1cZ/z2qHRyJ/jrrzRureVaKjMcH+GLjj8Rz/AExSGdnpfhXRNF1S71LTrEQXd5nz3WRiGydxwCcD n0ArI+IdxNNpVloFscTa5dLZsQMskWMyMPoo/Wuvribfbr/xUubncJLXQbYQxZOV8+TJcrjuFwD6 EDigDsba3jtLSG2hGIoUWNB6ADAqU9aikureCWGKW4ijlnYrCjuAZCBkhQepxzxUtMQUYopcUAFG M0d6PWgAziij2oJ5oAWg8UUYPNAw7Ck9aXrTe2KAFzxSClooEJ3ooooAO1HaiigArmfiGxX4fa5t HJtiM4zjJAz+HX8K6bpXMfERgnw+1okkD7Pg4OOpHH40AdLEnlxJHx8qgcDA4FPPSo4dnkRGPBTY NuPTHFSdqACk70dKKAF70lApaADpSZxS0GgAzmjp0o7UEE0AIetLnikxSmgAxR0o9aQdaADrS4/O jGKKACkpRSUALR1NAoPWgApaTtQOmaACjrzRmjjFACGjvS0GgBKO1Ao7UABpKdSdqAEBpetJS0wD +dHeiikAd6XPFJzS0AIKKKTvQApryVtZ0zSfHmuw+NdKMkN3OqWd7eQebEkP8KLuBwnJJ28A5zXr VcXPNqEt3q+neIfDdzqmjy3JNi6RRy/LtHDLuyOc7WwPqODQwRg33h280b4da5H4NnWa3v777Xam xkJdYGVAyow9Cp6H7vvVOxXwZ430O1020stN0bxDbSRMIGhEMiurAsqtjLAgNxnPIzg81s6X4c1z wl8Mr610lHGsS3HnwQowcxZdAEycqflXJPA5PTrUXifRZ/F95p8tt4bv9M1i2uonlvpXjjWOMMN2 HRz5h67cZIx/DnlDIvEOhRH4taGIry9ikvY5muJlnYPtCudqt/AAPl+XBAJIIPNQaZomnS/E+yvv BXyabbxE6pdwSF4JWIO1AxJ3sQRnBIHB61pfEHQ7268T6FrMeh/2zp9ruiu7VAGcqx6hCwDdTwcj jnirLv4ruPEUup6baT2mi2mnuINPutqG5nAbaAi5Kr93k4PHAwaAML4x6TYSzaDdG1txcz3ggkk2 gM6HHDf3gMDr0z71N8UdSn0Cy0rw/oZj0u2uy5ZrZvI2AFflXBAAy2Wx+OM80PEtv428W2WiS3Hh nyp7a43NbLIAspHJckt8i4CgA5Jy3TArc+KV3aL4IhOs6VaSajO22CEzkiFyPmZZMKTgduM9OaLi Nq0+G/hS2tI7ebSYr5lQKZr0mZz0JOWJ25Iz8uBya4n4WeHtGuNe8RXT2NpcC0vNlmXjVxCokkwy ZJ2ngfTHB6103hjwr4ls9Asop/F9zCwiX9xBbwypEMcKrurEgdM5x6cVk/CJ3kvvFLzXAuLj7YBJ MBt8w7pMtt7AnJ6DrQgPUe1cn8QedDsFzgvq1muc4xmZR1rrK5Xx8udH03LbU/tiy3MDggecvIPY +9MDqu9GaO9JQAvajFGcUdelMA75oNHeg8UgFBpKOKOM0AFHaijvQAUD1oFKOuaAE70GjtRQAUUU GgAFHeilpgJQetFHQ0gAdKBR0NKKAENFHeloASl96KSgBelJ3opfxoAQ9jS9qQ9qUdKAHL0ooXpR SKOa8OjOh2Q5/wBWOldAnQc1g+HDnQ7M9T5YrcQk4PT2pkEueaCaKM0DDNFAFHagBaKTpR2oGL2o OKTvQaBAKOvSjtRzQAAUHvSimmgA9KU+1Heg0AIaPSlxSdKADHpQKKBQAZo70UCmAc8UuOaO9HQ0 gEzR3ooNABjNKTSCjOKAFo7nFJzig9aAHdqTtRikx70Acn4JUrceKMIixnXJyu3qTtTJP4/5xius zxXn3h6TxCupeJTo1jpE0B1mXfJdXUkTlgF3DCxt2xznseDW39q8b4Y/2PoHJ+Uf2lN8o9/3PPp9 aEFjph0o4rmDP46O0DTfDobfy32+cjbnpjyuuB19+lKLnxw/I0rw/GMDAbUJic/hD+FAHTUVzK3X jdVw+k6A7jliuoTKGHPAHknnpyaRLjx2GJfTPDjDJwFv5lwMnGT5R6DGfX26UwsdPQelcybnxz8o /svw9kH5j/aE3I74/c/5zTEuvHrLk6X4dQlcgG+m+U+hxF/nFIdjqu1IT0rljcePsKo07w4GG0u5 vZyG65AHlcdv/r9n/avHOT/xKvD2OMf8TGbj/wAg/wCc0COm9aK5pbnxuD8+leHyM841CYZ9f+WP +c1Gbjx8xymn+G1XA+Vrycn8/LFAWOpoziuSE3xEIQG08L7gRvP2i4ww74Gzj9fx6Uom+IWGzZeG CdoCkXU/3uefudOgx14PNAHW0VyIl+IQcA2fhgjAyftNwOe+Pk/zmleX4h5fZa+FwCvyBri4OD7n Zz+QoA6yjqK5Hf8AEVgii38LIwwXczXDBhzwBtBB6cmkVviOFfcnhRieE2tcDHB5Przj9aAOvFFc iP8AhY3mJz4V2Z+bi4yRz05+g/X2oB+IpRmH/CLBm6KRcfL9Tnn8MUXA64UVyAHxIJA3eFMDG47L jn1xzx/n6UKPiMFJd/CpPYBLjr/31/n9KLgdhSAc1yQX4imRN0vhUJzuxFcE45xj5vpTdvxHyv7/ AMKAEfN+4uPlPGP4+e/pQB1/VuKXiuPYfEYH5ZPCrYx1iuBn1/i+tIR8SQg+bwmWP+xcADj/AHue cUAb3iDR08QaBe6VLKYkuo9hkC5K984qt4b8NQ+G7CO1iv8AULzagQNdXDOAB2VPuqPoM47msv8A 4uSMgHwmeeDi55H9P1pFPxIPLL4TUcfLm4P1Ge36/wBKAOwHvXLeMPAmmeMYomnkltL2HiK7t8Bw Oflb1XJJxxg9CMnLC3xEK4VPCysBySbghj+mP1pCfiJnO3wtyQMbrjj39/p/OgCHTvABi1CzvNa8 QalrZsixt4bsr5ak/wARHJZhzgk+npVzxj4Lt/GUenxXVy0MVpcecyqmfNXoVzkEAjuKgB+InGR4 W9/+Pjnk8fy5/Sms3xH3AqnhUqQM5NxlT/UUAdZBBFbQRwQRpFFGoVEQYCgdABUneuREnxEIUfZ/ C6kEbiZrghuOcfLxz9aFf4jANvt/Crkj5ds1wuDz1+U57UAdd3orkfM+Iiuo8nws6j7x8y4Xd16c HHb1/oHpJ8QerW3hcggYxPcAg9/4DmgDrCaTvXJiX4h7VBtPC5YY3H7RcAH6fJx3qRbjx4iNv03w 7KxyE2X0y7eD1zFz2HagDqaPpXKNc+PsjGmeHDgnd/p03PXp+747fn+SiXx/kE2fhnHH/L1P+I/1 dA7HVCg9a5gTeO8r/oPh0gEb/wDS5hnpnH7s47/T37xvcfEBYWC6d4baUghWF5PhTg8keXyM44BH 9QBY6v2pO1cx9p8dq6g6V4eYY+Yi/mHr/wBMvb9R70NdeOcqw0nw9twCU/tGYt06Z8n1x+RHfNAj p8Zpe1cu9145Zvk0rw8gGB82oTNnpk/6oev6UG78dbHxpHh/cSdp/tCb5eMjP7rnnjt/WgZ1HU0V zAuvHAkQHSfD5UAbiNQmGT3x+646e/Ue9KbzxqxVk0fQlVlHytqUpKnvk+T9OnoaBHS0oNc0t341 ON2jaEDgZP8AacuM8ZP+p9+nsevFJ/aHjRZVz4e0dkPB26q47E55h+g6dT6c0AR/Dnzf+ED0xpkj RmEjBY1wADIxH44OSe5P411R615x4EvfEy+C9MGnaTpM9ptkKSy6jJGSN7/w+Scc8Dk8Y/Do/t/j Ly9//CP6NnGdn9rSZ/8ARGKAOkozxXNve+MzC2zRNDEm0Bc6pKRnHJx5HTtjPamte+NlUH+xNDYk npqcnyjqM5h+o+p9ByDOmozXNrdeNM4bSNB+9nP9pTD5eOP9R168/p6p9u8ZiM50DRS2M/8AIVk9 +MeR/WgDpT1pK50XnjIgf8STRM7hknVJcEcZ/wCWH1/Lv3QX3jIEZ0HRTk441WTjjOT+4/D6igDp KK5tbzxnghtF0PdjgjVJQOnp5FIL/wAZfPnQNGwFyB/asmT7f6jr+QoA6QdKO9c8t74w6NoWi8YG Rq0oDdOR/o/A5P5fnG1/4zUnGg6M2eBjVZODjOTmDp2+vtzQI6WiubF94yBXOg6N7/8AE1k5/wDI FRfb/HGxm/sHRCeSFGpyZ+n+p69vrQFjqhR61zL3vjUK4TQ9E3KOD/akuGPHT9yPU9cdPzIr7xqO JdB0RiW4K6pIoUbc8/uTnnjj/wCvSGdN24oxXMx3vjbc/maJoZUMSoGpyg49M+Seffinf2h4yOSP D2jgEcZ1Z+OM8/uPXj8fxoA6QUlc8b3xkeF0PRAQeS2qykH6fuP84pEvPGQ/1mhaI2Txt1WVcD3z AaYHSDpR3rnReeMSwzomiADqP7Vl5+n7jiozfeNMHGhaJnkgf2rJx14/1H0/OkB03rSdK5lrvxu2 PL0jQEPcvqUzZ44xiH1P6H2NOF7408oZ0PRPMx1/tSXGcenkevv/AI0wOk7c0dK5kXnjfIDaLoJA HONTlG489P3PHaka+8b/ADsuhaIB1VTqchPfI/1Pt7dR74QDV8J3Ola3eal4c1CCxF9hrm1uLYzQ lxn51CuhVjnnnB/LFjwz4TtvDourhpjeaneStLc3kiAM5JzgdSF9Bk/Woze+NRtX+w9EYjG5hqcg B6ZwPJyOp/I+2V+3eMgxB0DRmGcArqsnHHU/uPwoA6TvXmy/DPW4ry7urbxze2z3czTTCGAgMScj /lp26fTiulN/4xXH/Eg0ZsZzt1aTnjtmDimDUvGfJPhvSvUD+1n9On+p68frQBU8M+Cr/R9ZbU9W 8S3mtSrEY4FuFKiHdjcQC7DJwBxiuyrmjqXjAEgeHNKOB1/td/m6dP3HHU9fQ+2V/tHxcI1Y+HNL LHHyjV34+v7j/GgDpKCa5oal4v3EHwzpuAM5GsNz7D9xSf2r4vJOPC2n4xnP9sH8v9T1oA6akPWu cTVPFrEA+GLBfUnVuD06YiPcn8qT+1PF20t/wi1jnso1fk8Z/wCeX4fX25ouB0veiuaGqeL+QfC2 nnGemr+3H/LHv0prax4wViP+ESs2HYrq46Yz3i/D60XA6jvRmuZ/tfxdx/xSdpnOD/xNx6dR+7/D t0pF1jxbjDeErYH/AGdWUjpn/nn68UXA6ek7VzR1bxcFY/8ACKWeVzhRqwy2PT93398Uh1jxbsJH hK3PBO3+1lzx/wAAxzxj9cUXA6bFJXOf2v4rzgeE7fg8k6quO3T5PfvjoaauseLCMt4StwewGrKe 3f5PwouI6XvRXMf2x4t27j4Qt+hyo1Zc8D/rn36fzxSNrXi0ZK+D4Tzx/wATZBxj/c/Ci4HUHpR2 rmG1rxYAdvg+JiCAf+Jsgz7j5On1xSLrXi3OG8HRd+V1ZD2HXKCi4HUHpXM/EIFvh9rgGMi1Y/N0 4INMbW/FwQkeDoiQpJ/4mqckDoPk79unvisPxtqniS58F6zDceFxbQtbkGYaijlffaFyTkDgdcj3 wAd/ZljZW5cKGMS5C5xnA6Z5/Pmpu1cnFrHitUjSLwdDsRQAf7VjAIwOg2fh26H2zIdb8WBcnwbG ev3dWj9OOq/5xQB1FFcudb8WfNjwah2gnnVY/mPPT5f5460HXPFnbwWDzxnVYunP+z/nPamB1HWi uWGueLQxB8GLx1K6rGQenT5c9z1x0PtTl1vxURz4OA+bHOqRdMA56e+PqKAOo60Vyw1zxZty3g0c KTgarEefT7tOOt+Kgv8AyJoJx0GqRf4UAdPRXMNrfioFVXwaG55P9qRAfhxzSDXPFgPPg0d+mqx+ mR/D+FAHUc0dq5ca74q2jd4LI+Uk41SI8jHA45z/AEpTrninaT/whjHA6f2nFzyf8P1HvgA6fHFA 9q5Z9f8AFS52+CZGHb/iZwjP+f8AH8V/t3xUFB/4QzknGP7Ui9evTp3oA6elOc1y41zxVzv8GbVC 5JGqREk46Dj+eOhpRrvinaf+KMbIP/QTh56/4fqKAOn70Vyz6/4oViB4JncDuupQc/TJFO/t3xNu CnwbJyeq6lEQOnX/AD2oA6f60dq5n+3fEwyf+EOkwAT/AMhGLJwM8D3PFKdc8T8/8Ua/t/xMoff/ AA/UUrjOmpBXMf294n8wr/whkpH94alDg0o1zxRtGfBrZJxgalFx7n2oA6bHekHNcx/b3ioA58GH gZ41SI/h0pza54nVTjwc5I6f8TKLB6/4D8/rTA6XFB61y51/xPvZf+EKmO0gZGow4PA5Geo5/Q0f 2/4oOCPBUpzkY/tKEYx65/zxRcR1FHauXfxB4nVC3/CFTcKTj+0Yckjt+NL/AG94m3lf+ELmA7N/ aMGMc+/t+o96VwOno7Vy48Q+JTux4Jufl451CAZ6dOff9DSN4h8TBePBNwTv2/8AIRgxjjnOff8A Si4HU0vauW/4SHxKG+bwTcgAE5GoQHOBn1p39veJeT/whdz/AODCD39/b9RTuB01HeuYPiHxKGIP gi6wCBkahbnPTp83v+hpD4i8RjGPBN6d2duL63/XLcUXA6iiuYXxD4hwN/gq+UYJ/wCP23JyO2A3 elbxDr4TePBl8RtyAbyDJ/Ddn/8AXRcDpvSiuZk8R66rEDwZqL7ThiLqDB4yNvz8j8sUg8R69vZW 8F6gMHAIu7cg8Z/v/h9aAOmpR0rlz4j18HDeCdQHBPF5bnoPZ/8AP5ZX/hJNdYKV8E6lsbBBa6tw QOTyN/B4HHvj6gHTnpSVwP8AwtGH7cbNdIMkwzuCapZkDHXB83HfocHg8cVsJ4m1ohd3gnVhuwBi 4t+uAecyDH1/DrQB0/SgVy7+JtdVFY+CNV4VjIBc2xIIGcLiT5s/hQfEuuhefBOqggZP+k2x9c9J Dnof8kZAsdOPQdKxfFXhiz8W6K2nXkkkXzCSOWIjdG4BAPPUYJBHcGqDeKdaSXYfBGrnHDFZrcj+ Hod+CPm9ex9DiUeJdV2Fj4N1rPOAJLb0z/z19P1460AVtJsvGmiWSaeZNG1aG3VUguZ55reVlA53 jbICe2QazfCHhfxV4c1vVb25fSLmDU5vNlRbiUNG28tlSUOeHYYPXA5FbT+J9VQgf8IXrZIXc37y 2xgdcYlOT6DqeaVvE2rbdyeDNZIz0aW2Bxz28084HT/61Azpa5L4jLu8OWoAYt/aVoFx6+co59B2 /GrB8T6n5gT/AIQzXMjhiHtsA8dD5uCOevt9cc9411m6vtHsobrwxqlqp1K1IkuDCyAiQHnZKT09 sZouI9HP3qSl96SgBD0pc0GimADg0Gk70poAO1BNFHakAGij3zRQAZ4oFHGKBnNACgUUg60UAHvQ TxQOlGKAAUlLQetMQeuKU802l70DDvzQKAOKPakAvQ0nejvR0NABk0dqOaXFACZo70tHegANAooH Q0AOXpRQvSikUc34aBGh2YxwEHJNbyA5rF8OL/xIrPcOREOK2o84Gf1pkEnQ0YBFH0pO1AxaD0pK XtQADOBRnigUe9AABQeaO9HagBOgNLR2oFAAKDxQPUUHqc0AITzR6Ud8UpxxTADSH6UvfmjtSASi lFIaAAc0daXHpSAcUwFzSdqKBSAKKBSigBPaik9aWmAdqKXtR3pAHPA9KSl7UhoA5LwSf9O8VAlQ f7amJAzn7q4J7dAOnpXXVyfghP8ASPFEreWZH1ycEqPmChUwGP6/jXWUIA7UnWl7cUlAB3oNFKel ACUHpS9qT60AFBooz60AFHel7mkFAB0NFHel70AHOKKQ0daADFFHeigAxR3pKWmAlLR1opAFFHSj igAxR2oyMUueKAOG1v4g3um61d6fYeEdV1WO2Ko11aozIXK5K8KeRkZqhafEzV7zWLbSV8EajDeX A3qlzN5WFHVjuThRg811PifxAPD1lElpbrPql/MILK26CSVv4mx/CM5J9Kl8PaCNHgmnuZBc6rdt 5l7dc/vG7KufuoucKvYCgCnc+Kry28Z2+gf8I9fyQTorDUIxmJeDuycYwOO+eenTN3XfEVroQto3 imub28Yx2lnAAXnYDJAJwAB3JIArYryrxfrL+Hvi9o+qajCw0pbTyElK5WMsW3uD0yMrnHO3tQB0 c3izxLZXkCX3ge7+yzOqefZXa3JTJ53IqgjA5z0963Nd8QWmgW8LTJJNc3MghtbWEZknkPRVzwPc ngVPp2t6TrKu2l6nZXojxv8As06ybM9M7ScfjXnvjzVJfDvxJ8Pa5dxP/ZcUJh8zqFdi4fAHOQu0 +/vQB0F74u8Q6ZcRfbfA9+9rI4QS2Nyly65z1RQCOBnPTnrXYjpnp7Gs/S9c0vWPMGnanY3jx8yL a3Ky7AemcdPxrQoAO9HaiimAp6Ugoo70gClzRn2pD0oAUZoFA4o6mgBO9LxSd+KO1AB1FL2pKWgB O9LiikHrQAtHejvSEnnHWgDlfhs5f4f6VlgxVHUkMT0dvX/9XpxXVVy3w3/5J7o53Ft0TNk47ux7 fWuq7UABNHakFLQAGjFFGaACk5zRR0oAO9FFFACjpSd6O1FABS0lFAC0d6BRQAUvekooGHvR2ooF Agpe9HWkJ5oGFFHNHagDkfFvjabwjLGbnRZrm1mO2GeGdfmfGdrKcbe/r0rpLCe6ubRZbu0FrK3P leb5mB7kAc1598ZB5ml6IgkRC1+AN65XO09evH4V6SowoG0LgY2joKBGPqniS3sL8abbW1xqOqGP zRZ2oXcEzjczMQqjPqRntms/QfGcmr65Lo934e1XTLqOPzM3EYaMj/fXI7/Tt1rC+H2rRzeLPFVl fMv9rtetJkgAtEPlCjIDYAA9RyPXn0ekM5vQvGVrr3iDVNIhsL2CTTzhpJ4wFfnBxgnHYjPUHNWt X8S2uk3cNikFzf6jMN0dlZoHk25xvbJARc8bmIFbR9utec+EtUV/ij4stL9lXUHdFg3KBmFAflU9 ehU+/WgRr6P48XUvEY0K80DVdMvWDlPtMa7CF6ncD3xwRke9db3o7ilPWmAUtJmlPegAoPWig9aB gc0d6KU0CDNBowaOaQxM80dBRRnNMQvakFL2pMc0AHakFFFABRRS0AJXOePgzeA9ZC4/49+S3QDI yfwHNdHXNfELA+Huu5Gf9EbA46/jQBuaa/m6XZyA5Dwow/FRVntUVqgis4I1CgJGqjacjgdql7UA FFFH0oAO9FGKOgoAWg0g60d6AF60UlLQAh60402lPSgBKB0pT0pBxQAvUGk+lA70dKAF70Ud6KAE HrS555o7e9B7UAHpR1FHSgd6AEooooACKXpR24NJQAUdqKKADtRR7UUAFGcCkp3agBkjFI3ZUaQq CQi4yx9BkgZ+prldN8e2mq63JpFto+r/AG2LcZ0eKNRDjg7mL468cZrrPxrzfwoCPi/4tyzNhE78 DO0/54/nQBrw/EWyl18aF/Yutx6n5hQwPboMDru3b9u3HOQad4j+JfhvwzqR0+9nnkukx5qW8W/y 8jI3HgZPpXPW7Mf2hboMGIWw+U5PA2J7epPT1/CtzRdd8EabbXNvY6vb3DzyNLdO7GWSVznJkOOv GMHsAKBmxY+MNCv9AfWor9FsouJWfhoznAVl6gk8Ad88UmheLtG8Rzz21jPIt3b58y2uImhlUZxu 2sAcdOe2RnBNef8AgKO1t/ijr2naU6zaK9uLhFGdinKFRgjqC7Ad8fStDwzHj41eLlywPkJjYCAu 4Iec9+h6EHJINAHTv43s3ub+Kw03VNTjsJPKuZ7GFZER+6gFgzkd9qnFcz4s8S2uo22kaq1pqmo+ EZFma4SztyDLIrBU8wHB8vhuDgEkZz2xdNude+Fd3c202nyan4Ye4aT7XbAyOn8OSc4UjaAwbjI6 8mu0uPE+l+Hfhy/iHSraSW0kzNb25yuXkc/LjnaAxOR2ANAjh7/xb8NL7SpoR4R8iV4nWPOmxxFG HAG9D8vJ6jOK6XQdas/AfgPTpdTub7ULSYBxeQI0saFuiDJ3ADHBwByPWqXjU+J4fAI1PVru1uIp Gge+0yO2AjCFwdiyAluu0EknvzT/AIiT2Vz8HIrjTbYQWswtZIYgNu0EggHHXFIZ1N143sbLQ4ta udP1SPT5T8sptwSAcbWKhtwBzwSPrjiqknxM8PQ6SmpXAv4LaXmAyWjgzDOMrjtkY5xVLxpIkPwZ nLbWH2G3Vc+pKAEdOQefw6dqyPE4k/4UFYgxy70s7IkOSSOUyf6+34YpiN6X4q+Gobe3mZr4rKqt IY7YyCAsAQsjLlQ3IyoJIzXY2t1BfWkV3bSrLBKoeN16MD0NcDfWtufgQkYgiWM6XDLtcKBuIVt3 TG7Jz6k+9dD4D3f8IFoW7OTZxk5OSeKAK2s/ELSPD96bTU7XVIJSf3ZFmzLKM4yjDIPX610VhfDU LQXC21zbgsQEuYjG/HfaecV5l8WIvM8WeD1Ico9yEZVJG4ebF+Gfx7ivVzQAVyXxEcL4fsiyK6jV LPcG6Y85a636VyPxGBPhu2QByzanZgBOpPnLQB13eijvRmgBKWk+tBpgKOtBxiig0AFB70D3opAH eg+1HeimAc4oBoo70gFpKKSgBe1Aoo7UAHeg9aOtHegA9xRSUp60wDvQOtJSigA4zRQR81FIBRQP Wik70ALSd8UdaKAAmig9qUUAOXpRQvSikUc74bJOiWfzE/uxnPrW6vNc/wCHQRolm27cpjBJbtW+ g4B7YpkEgo60d6M0DDFBoFFAC03NL1FGKAE96U0EUnbmgAHIo6UdBRQAopDS9MUHrmgBO9GeaMZN KRTASlPSg0nSkAZxR35oNGKYAKXFJQKQC96TuKO9A6UAHWjvQKDQAd6XvTacOtAB25oNHajpmgAN JS5o4oA5XwVIGn8SocB11u43ADA6JjnGCcYrqulcl4IZjc+KQ28KNcnCqxGANqcjjuc11vUUAAGB mkAyKM0MSEO3k4OKADpRUFkZzYwfaU2z7B5gznB+tTmhMAo6UdqKADvQelFHJoAWko70D0oAKKKO aAA46UtIKKACiig9aADHFHQ0UdTQAAUlL3o6UAHQUmKUdzR3pgFHSkpe1AHluuagtv8AHTSTqV2l vYw2bCASuQhZlfLc/KCSQM9TtFd9qmu2ml3lhZSZlu72dYo7eMguFOcyFc52KAcmovEPhTRfFMCR avZLN5YPlSKxSSPPXawOR0HHTiquheBPD3h26+12FkzXYXaLm4laWQDpgFidv4YpAdFXn/xTvrRY NE0i+S2FpqF6q3E8wUmGFSN5TP3WION3YZ9RXoIrL17w9pfiXT/sOq2qzw53KclWRsYypHIPNADp Z9J8OWlpagQWcLusFtbxJgsxPRUXk9cnA9Sa474ranBDZ6TpN3FB9j1C7C3FxJF5jQRDAZk4O18N gNg4z0543tD8CaF4fvI7y1iuZbmJSsUt1cvKYwRghQxwOOOBWlrnh/S/EVmtrqtmlzCrblySrIfV WBBU/Q0AAbSPDNja2cawWcLuIoIIkwZHPZVUZY9zgepPetPvXN6P4E0PRb6O8gjuZ54lCwvd3Lze VxglNxO0kYBx2ArpKADvRS96O1AB1o70nWgDNABml7c0hAzS9qAEpabt+bdk9MY7U4UAFJSnrSdq ACl7UlFAAKBRRQAUveko70Act8OGd/AGlPJI0jFH+Yjt5jY/z/Oup71yXwxQJ8OtIUIyDbKcMcnm Vz/9euu/GgA9qU9KTvS+1A0HakAzSmk/GgQUhpcUd6ADvRRmigBO1Hel7UgoAKKKKAFFJS0cUAH0 oFFAoAKDR/KjGaBgKU4zRzSHrQAtJS0mKAPM/jOxTRtGfOFXUAxOM4wp5r0vOe4J9qxfEfhTS/FU FpDqizPDbSmVUjkKbyVK4JHOOexHStDT9MsdJtFtdPtIbWBeRHEoUZ9T6n3oEcf4w+Hqa9qY1jSt Wl0rWgoQSoxw+B/skMpxxkHp2NL8N5/EV3b6lLrWrC+ihuWtoSIsBivDOGwMrngfQ0/UfhP4V1XU J768gvJLqdzI8hunzuPpzge1dXpWl2ejaZBp1hCsNtAgRFHoO5Pc+9IC5XEeM/h7H4kvotVsNQk0 3V4gAsyMQHA6ZI5VgOAw/HPFdvXD6t8KfDet6ndajeG/N1csXkZbkjk4AwMY4wMf1oAr/D268UXd 7qUOtavBfWunsLZXhjBEkvVsPtBYKMDJGck9cZrvzWfomi2Ph7SIdM06Ix20WcbjlmJOSSe5rQ70 wDtSmkooAWgdTRxR3oAKOp4o6Ud6Bi46UetFGPSkAUme1Ke1J/KmAuaQUvakFABj0o7UUgoEHal7 UnUUtABXMfEMgfD3XMqGBtipB9yBn9a6euX+IpI+HmuYDk/Zj9zr1FAHRWojFrEYtpUopDL0IwMH 8ql7VBYktYWxbqYlJ/IVPQAZooIooAXnNJRR2oAXvSHilpO/FACik7UvpmjtQAlL2oPSigBO1Hfp R2pe9ACUooyKTvQAo60e9ApBQAd6XPNAFBoABRRRQAlFLSUAFB60UUAFB6UUUAFFFFAgozg0CjFA xe1cHe+DdetPGV3rvhzVrS3/ALQULdJeQmTZ90ZQDr93OCR9ea7vtRigDzzTvAOuWXjd/EDeIo5W KKjSTWwkknBVQ+QNojHy8Bc4H45sWvhDWfDPia81HwzLpz2N+S1zZXhaLy23Ejy2RW4+Y8Ef0x3l JQBzWm+Hb7TRqepfarOfxBqLK0ty9tthUKAFQKDuKgDu2Se9cX4TsPELfFjxBfeZp5RHWG/mEUgV htQgRruyGO0cliBk8HpXrNRRW0EEkrwwRxvM++VkQAu2AMsR1OABk+lAXOVtNK8U6WdVgg/si8s7 26nuIVuZpENuJGJ24CMHH8RHy8sRk9ao3nw7urnwfZeGo9cSKwt4Arr9hRjJIGLBwSfl5xxzxnnm u8zS9qLAef3XhHxHqXgu18J3VzpsNrEEikvopHaR4oyNgERQAHAGfmI471t674Ns9X8F/wDCNwsb aCKJFt2AB2MmNpPqOOfqa6XrRQB5teeDvGeseDn0bVNa0xTFEscMVrG4SfbjBmdgTxjoqj3zV288 D6te/DgeF5tUsmkVIkjl+ykLGqEHByxLHjG7A47ZzXd0UWA5Z/Duo3Hw/l8N3M1gJRZpaRT7GdCF ULuKnGG4yME4ODz0qbwxbzeHNN0/QNSubNpljKWphLAzBeW+UjggEdz610nWsHxD4ck1y40+5t9V udNurF3eKa3VWJ3LgghgQRj2oA4X4s7V8U+EC4Cj7SCJCFwCJY+pI9x6CvUrm7t7QRG4lWMSyrEh b+J2OAPxritW+Hl9rd7ZXmoeK7uW4sjut2FnCoVtwbJAGDyq/lVyTwdqV7qmm3mq+KLu8SwnWeO3 W2iijZh0LADk+/bnGKQHX1yPxGDHw7Z427f7Us9xI+7++XkelddXI/EUE+HrNd23Op2gzgn/AJar TA6/qaTijvSUAHY0tHaimAUHijv60GkACg0UYzQAUYo7UGmAYoFFApAHWjtRRTAO1FA6UZpAHeg0 nWl70wEpaKKACik60opAL3pDQaXHFACDrQetHajjFAC0d6TuKBwaAFINIOntSn1oHIoAcvSihelF IowPDh/4kdlg4/dDittegrE8P/8AIDsycf6pfWtsUyBR15paKKBh70Uh6UCgBfak5PWnUnJoAO9H aikoAUdKTGKUdKQUALQfWgGjtQAnfml9KD2oNAC44pOKDSEcCgA9aXrSHpQOtMA70CjFKPSkAd6T FL0NBNACD9aWgUCgBPpR0oxzQetAC5496O5pO1HSgBeoxSGl7UdqAPPfDNtrk2p+KJdO1KwtU/tu cOtzp7zM5CIB8wlTgDHGOueea6A2Hi4k/wDFRaSOvTR34/8AJj/OareB12jxH8pGddujyevK811V A7nOtp3i8qAPEmlLgYyNGfn35noTT/F6sWfxFpLDkbTo7469eJxXRHpSEkKSBkjt60CuYAsfFuT/ AMVDpHOcD+x34z/28dqX7D4u4H9v6Pwef+JPJz/5MVH4S8Q6tr8F7Jqfh240cwS+XEkzNmUYzkbl XgcDIyDR4T8Qatr0d22qeHbjRzDIFiEzk+aMHJGVXpj3HNA7itp3i8kEeJNKGBjA0dvz/wBf1/Ti kGm+MBnPibSzz30ZuP8AyPR4V8Q6xrsl+uq+HJ9HFtL5cbSyFhNyclcqvAwORkHPFO8Na7rOsT6l Hqnh6XSVtZRFE0ku8T9clTtGRwORkc9aABtP8XlWA8RaSpPQjR34/O4/zmkbT/F5zjxJpS5J6aO/ H/kf/OaPDOv6xrN9qdtqnh2fSRaSBIpHcus/LZKkqARwORkc03wz4i1TXL3VIdQ8PXOlRWsgSCSb dicZYZGVHoDxkc9aAHDTfGAlL/8ACS6UVJzsOjNge3+vz+vemvpvjBmJXxPpi56AaM2B+c9S+Htc 1TVr3VYNQ0GfTY7O4MUEsjEi4ALDcuVHGADkZHPWovDGv6vrN9qkGp+H5tLjtJfLgkkLFZxkgkEq M9AcjjmgBP7L8Y7yf+Eq03Bz8v8AYxwP/I1B0vxif+Zq04c540Y/l/rqf4d17V9W1bV7TUfD8+mw 2cuy3uHJK3C5IyMgegPGRz+a6Jr2rajr+q6ff+H59PtbNtsF07lluBuIBHygcqAeCcZwaLiIf7J8 Zc48W6eP+4N/9upW0nxiwOPFlgv00b3/AOu1TaHresajrWqWWo+HpdOt7RgILlpd63AJPI4A6YPB OM4pmja9rF/4m1XTL7w/NZWdoT5F6zEpON2BjIA5HPBOOhouFiMaT4xDE/8ACWWB56HRuBz/ANdq adH8ZEY/4S+yH00YZ6/9das6TrWsXviXVNOvdBks7G1P7i9aQkT8jGBjHIyeCcdDg1FpWu65d+Lt S0m+8PPaWFspaDUBIWSYZG0DKgZIJPBOMYPrRcLEZ0bxkRj/AITCzHHUaMuf/RtL/Y/jHH/I4WnX r/Y6/wDxypdL1vXbvxVqOm3vh5rTT7cEw34m3LNz8uBgdRkkAnHQ+tLp+s67P4xv9Ju9C8jTIY/M h1ESErLyMLjGM8tkZ4xQKxB/Y3jLjPjG0HPbRl5/8iUf2N4ywB/wmNpgf9QZcn/yJU1nrOuzeNbz SrnQjDpMUPmQ6grlhITjA6AZ+9kckYHY5plvruvt43n0e48PlNJCl4tSVyVI25APGM5yMZGP5gWG /wBj+MMD/ir7XOMH/iTr+f8ArKP7F8XAAf8ACYW+Qc5/shOR6H5/5Yp9vrPiGTxtcaTNoQTSEj3x 6grthuBgcjBOeMDp/NI9b8QN47k0iTQiNGEe9dSBOM7cgHtnORgc9KAsNGjeMMEHxfa5PQjR14/8 iUf2N4x5/wCKvtMY4/4ky/8Ax2rMWq643jOfS5dFC6OsHmx6ismQzcfKR2Od35Ckg1jXW8ZTaTLo O3SViMkepibhuBhduOuSeM9OaAsVzo3jHBx4ws+R1OjDj6fvaX+yPGAwT4tszgDj+xxgnPf976VY TV9cbxnJpR0Bl0hIvMGpGYYJx024654xnPemrrOuHxo2knQSNI8veNT804ztzjbjru460BYgGkeM eP8Air7P3/4kw55/660g0fxiOvi+zIAwP+JMvr1P73/CpZNa15PHEWkDw+zaO8Zc6kJMgHbnkYwO eMde/wBHTa1rieNbfSI9AZtJePzH1LzPlHB4xjAO7AwTk8mi47EP9j+MQePF1mc/3tGHH0xL/jR/ ZHjHI/4q+yP10Yf/AB2pr3Wtbg8aWWlQaE8ukyxb5dRDcI3PHoMYHud1Nvdc1y28bWOlQ6C82kTx FpdQBJEbc9cDAxgcHru46UCsMGk+McknxZYnjgf2MMDn/rrSHSPGW3H/AAlth0xn+xufr/rqn1DW 9btfF1hpcHh9rjS7hd0mopKcRHnIZccYwvU8546Gmajruu2ni+w0uDw5Jc6Xc48zUUl4i9dy44xx 1PPOM0XHYaNK8Y8/8VXp5+ujdP8AyNR/ZXjEdPFen9v+YN/9updU13W7Pxdp+l2nh2W6024VTLqC v8sJyQwIxjgBTyRnPFP1TXNasvFmmaXa+H5brTroAzagrnbCctuBABxgBTyRndgdKLhYZ/ZfjENn /hKtOx6f2Mf/AI9Tk07xiEIbxJpROCMnR29ev+vHPb/OaTV9e1uw8Uadpln4dmvdPudplv45OIec NkYwMDB5PPbNO1bX9XsPE+m6ba+G7i8sbvAlv0lwsHPzZGD0GDyRnoM4oAe1j4tbA/4SDSF4xxo7 /nzcVGdM8YFgf+En0wY7f2McHn/rvT9Y1zVtO8R6Vp9roM15Y3jYmvY2JFvzzuAGAMYOSRnn0pmq 69rVl4s03TLTQJbvTrlR518pOITuIOcAjgAHnGc8UDGrpfjFXBPirTmAx8raMcH64mzSrpnjFevi jTG476M3/wAfp2ua7rOma7pdnY+HpNRs7xts1zFIQYOeSRt2gAHIywzgina3rmsabrulWVl4el1C 0vH2z3UcuPs/PJIxjpk8kZ6DmgQLY+Lh18QaQ3Tk6O/b6XHelFj4uHXXtG6Y/wCQRJz7/wDHxUXi TxDq2i6rpVvZeH7jUrW7k2Tz2+4m3GVySAuMYJIyRnB6VL4g13VNK1PSLWw0GfUYLyby7ieMnFsu VG44B7EnkgfL1pDAWXi7OTr2jfT+yJMf+lFAsvFxBH9vaMOc5/siT16f8fFN8R6/qej3ulw2GgXO qxXU3lzyQMf9HGVGTxjoSfmKjjrR4o8QapocunDT/D91qsdxLtna3yTCuRzjHJ5PUgccmgCT7J4s z/yG9F/8FEv/AMk0gtfF3IOs6HwOD/ZMvJ/8CPpUPi3xFqvh6Ozl07w9c6uk0hSZbcsXiGOuApz+ Yo8V+ItU8P2tpNp3hy61fzpNkqQMd0IxnJCqxPcenvyKYXJha+Ld3OtaH/4KZf8A5JpRa+LSOdZ0 QHHbSZf/AJJrcXJUEqVJGSD29qUgHIIBB7GkI8/8E2vikeC9I+xX+j29sbYMsc+nSvIuSTyRMAc9 c4HX8Tv/AGXxnuJOr6BtC8f8Sybk5PX9/wAcY/M+lM+H7u/gDQzJ1FqoHIPAyB09sV0madgMEW3j An5tX0EdOmlTH6/8vFKlr4vwC+saED3C6VKf1+0VvdelHalYZhNa+Le2s6GfrpMv/wAk0gtPFo66 1onr/wAgiX/5JreNBoAwFtvF5ALaxoWcdBpU2M/+BFAtvGGedX0LH/YKm/8Akit4UUWC5hfZfFvb WdEP10mX/wCSaT7L4vycaxoRHGP+JVN/8kVvijFFgMBbbxhgbtY0LPtpUx/9uKalt4w6NrGhdMkj SpTzk5H/AB8DgcV0GOKKBGB9m8X841jQj7HSpv8A5IoFr4vIUnWNCBzyBpU3T/wIrfoosFzC+y+L u2saH176TN0z/wBfHpSfZfF2edY0P/wUzf8AyRW/RQMwDbeL9+BrGhbcdf7Kmzn6faKPsvjDHGsa Fnj/AJhU34/8vH+fasm78b6jZeL7XwzJodu19dp5kUiX5MQX5j8x8rI4Q9jXTapfXlhodzewae15 dwwmQWkL8yMB91TjJ/LJ9O1AFD7L4u4zrOh47/8AEpl/+SaEtPFwADa1ohI7/wBky8/+TFT+GdXv Nc0KHUL/AEmfSriRnDWs+dygMQDyFPIGeQKr+FfE6+KLbUJls2tfsd49oQ0gfeVAO7gcdentQAv2 bxfuGNY0Lb3P9lTZ/wDSj6UfZfF53Z1nQxg/LjSZefr/AKRxW8OlMuJ4raCSeeRYoYkLyO5wFUDJ JPoBQBiLaeLRjOt6KfX/AIlEv/yTR9l8XjAGsaGff+yZv/kj6VmWvi3XdS0STXNO8OW8mmgO8S3G oGK4lRSRuCeUVGcHALCpdL8cR+IPDMeqaLplxdXby+R9jZgnlvjd878hUxzu75Axk4oAuta+LwBs 1jQjzznSphx/4EUfZfF4X/kM6GTjvpMvX/wIqHwf4rfxRb3wudOfT7yxuDbz25k8wAgdQ20A85H4 e9dLQBz7W3jHjGr6CTnnOlzDj/wI+lM+z+NP+gr4fx/2DJv/AI/9agsfE+peIJLx/D+m2ktlbTNA Lq8u2jE7r1KBEb5c45JH0qz4e8Uxa1eX2mXNs1jq9g+y4tHcNkcYdDwWQ5GDgdenSgBpt/Ggb5dV 8PkZ5J0yYf8Atek+z+NsE/2p4eJ44/s6f8f+W9J4d8SalrOr6rZXvh270yGyfbFczbttwNxGVyo7 AHgnr+cmp+JZINY/sXSdObUtTEfnSoZRFFAh6F3wcE9gAT34HNADFt/G38ep+Hh9NOnP/tej7P42 4zqXh7r/ANA6fpn/AK7elR6fr3iN/EEem6n4VNvbuhb7dbXgmiU+hyqkdD6nkcd66encDmDF483c X/hor/15T5/9G0oh8dlf+Qh4bzkcfYZ+nf8A5a101FAXOXEPj7I3X3hnHtZz/wDx2gReP/NUG98M CP8AiYWdxkfQeZ/Wupo70Acr5Xj/ADH/AKb4Ywcb/wDRLjj1x+85/Slki8fBB5V74ZZ8DhrScA8n P/LQ44x+Pp1rqaKAOVSP4gll33fhcKRyVtrg4PPA/ec9ueKaI/iHuGbrwsF7kW1x/wDF/SutopAc kU+IeUxP4WIwC/7i4HOeQPn9O9OKeP8Ays/afDBkHbyLgAj0zv4/I11Q60YBpgckq/EYuA0vhULx kiK4JHr/ABUIvxELJvl8KquRuKxXDHHOcfMPb9a66k4oA5LZ8ROMTeFTwCf3Nx17j736/pQR8RAo Kv4VLY5BS4GTk988cY7etdbSCgRyij4h8B28LAdyFuD69s/T9aZ/xcYkDPhReACcXBwe/HfvXXnm kxQByQ/4WKAM/wDCKHpn/j4Hc5/TH61g+NP+E4HgvVTqR8OmzMGJhbeeJApPO0k4J6fWvSzXLfEg Z+HetYGT5IOP+BrQAiHx/hAU8MqO/wA9wSBz7c9qjVviLxvj8K54yQ9z689vSuu5HB6+1HakByYb 4h/JlPC3ONx33HHJ6DHPb0prf8LF8pSg8KeZj5gTcYzXXYo4pgcpn4g4XMXhcHHzfvLg889Pl+n6 0xG+IpdQ6eFVTI3FXuWP4DArrqKAOTB+IgCAr4VY9WYNcDHsBg/nn8KM/EPahEfhYH+NfMuMfgcf 0rre9IOtAHKbviGWXMXhZR/F+8uD3PT5R7frQH+IRaPNv4WUZHmfv7g8d8fIK6yk7UAcsJPH4GGt fDDE46XNwMev8Bz+lOEnj3fk2XhrZxlftc+ffny/6V0560p6UDOXWXx5/HaeGu3S5n98/wDLP6fr QJfHvObLwyORj/S5+nf/AJZ11AooA5VZPiAAN1p4Yf1xdXC/+0zVKx1vxjf3l3b20XhmdrdgrmOa 52I3dS/l7WbOeByMjI9ZPiRr1zpWiW2n6fN5WoarOtrE4ODGpIDuPTGQM9twraxpfgrwphVMOm6d B0UZYgfzYk/iTSAoeb48OcWnhpRtOP8ASp2w3Y/6sce1Hm+PSR/oPhoDbz/pk5y3b/ll061WvfGe o2XhxfEP/CNyz6a8XnYhuQ06Rnozx7cDjBO1mwM+lM8QfES28O3tjb3OkagUu2ULc7VEO043EHJY 43DjaKYXL4n8c/KTp/hw8Ddi+n5PfH7r6U1pvHZPy2HhvGRwb2fp3/5ZVRm+IT2Op2EGp+GtUsLK /kEdvdzBTknpvRSShyRwecduDje8Q+IbXw7aQzXEVxcSzyiCC2tVDSzOeygkfU80guZpl8fHOLPw yvBwTdTt9P8AlmKRZfH5b5rTwwF2gcXVwee5/wBX09v1qPUvG0nh66tV8Q6NNZWly4jS9hmWeJHP Z+hXjvgj8jVrxL4vj8Lz2qXWmXk8d1KIYZLdosFzjAIZ1IHPWgLkDSfEHACWnhcHIJLXVweM8j/V /r+lHmfEDKH7J4XIzlx9puOmegPl+nf36ccr4g8ZP4W0yHUNW0a5EL7Ub7NNHIVkOflwSueFzn3q 5qPim10XQE1XVYJrbzGCRWoxJLI7fdRQpILH64HPOOaBHP694r8TeGrVLjVbfQYITw0yvdyIrHdt BKwn0H6+1WLDVvHWqRJcW+neH4oGAYGea5UupUEEAxA9+47dqwvipf6vN4AlF9ootUkliO6K7Epi O7OH+UY6Yyu4c16HLLcWGlQtBatePGihkjdVJAHJGTgn2zz60wMhZvHIA3WHhw+pF7OP/aVKJvHO edO8OEen2+cfr5P1pPCfjS38X289zaafd21tA5jeS6KKQwCnG0MSOv6VXh8bXGqWtzfaF4fvNS0+ 3dkNwsqRmcr1MKk5ce/GegoGWRN44wN2neHc8E/6fOPw/wBTSi48bbQDpnh4nHJ/tCf/AOM07SPG Njr+gyappVvczmFts1q4WOWMjqDk7c454PNQ+HPG0XirTZb/AEvRtSMMb+XmYwoWcbcgDzDjhs84 oAkS48bADfpnh4nAzjUZx9f+WBp/2nxpg/8AEp8P5/7Cc3/xioPDfjaDxQLt9P0jUhHasUkeUwgF wM7VxIck8c9ORzSWHjq1v9Y1PTF0nVYpdMUtdu8cbKgwTwEdmYnHAUEmgROLnxoc50rQPb/iZTcf +QKr32r+KtNtGurvTdBjhTG9xqNwwXJxk4tzgepPA6niqlj8RYtRutQsbbw9rLajaSbRaGJA7DBO 5iW2oOO5zyMA5xWj4X8YWvieW+thZXNjeWb7Jra627upGRgnuCDQBHb6l4vu7eK4ttO8OTW8qqyS RarKysD3BEOCP881M114zVWP9jaE54wF1SUH9YPrWPpV0/hfx+fCqD/iUX8JutPQA4t3G4vGDj7p 2swHOPxruu9AGALrxcQP+JNoYOOc6tL7/wDTv9KiN/4xHP8Awj+jnJxgas/Hv/qKibxtGnidfD7a BrAvmi81eINjJg8hvN9iPqKS+8bxWHiS00GTQtXe+u1LwiMQFWUZyc+bwPlJ5oAsC88YZ50PRMHB /wCQrLxx0/1H+c0G88Yjd/xI9EPAx/xNZff/AKYfSrOqeIodPv7XTIbW4vdTuULx2sG0FUGcu7MQ FXIxnJ54AJ4qlp3jS1u/ELeH76wvtM1XG6OK5RSky4JyjoSCMKeuO45wcADheeNN6j+xNDwRyf7U lwD/AN+P8eooW/8AGTuQfD+jouBgnVnPPfpB/Srer+IrbS76306OCe91S6VnhsrYDeVHV2LEKij1 YjPQZPFZ8PjWOPxJa6DqukX2m3t4pa2aRo5IpcdgyMcHg8EfzGQCcX3jEYB0HRTkDJGrScev/LCn G88XqOdD0U5I6atLwP8AwHqTxN4mi8Lac9/dabf3Nqm3zJLURtsydoyGdT1I6DvWPqHxJsdN0a31 KfRdaCTokyxiBGKxMMq7EOVUHBwCQ2QeO9AGkLzxhn/kB6IBnHOrS8/+S/4fWkXUPF5kKnw5pKqD jcdYfB9+IOn4ZrO1T4k6dpUC3kuka1JpjSeUt/HbKImPqNzhtvo2MHBxmug1DXrLT7K3uRvuzdFR aw2gEklxnn5BnkAfMTnAAJJoAzzqPjBdv/FN6U2QM41h+PzgoOoeMc/8i5pOOv8AyF3/AC/1FVL/ AMX6zp0T3E/gfWPsaH5pIp7eRwvrsRyf149a1/DfifS/FWmC+0uZmUYEkUi7ZImIztYev0yD2JoA qxX/AIvkUFvD2kR/7L6w+R19Lc+351znjG68SXFjp1vfaNZW9vJqlpma21BpWH71MDaYl688+1ei iuT+ICk6Rpm0At/bFljjnJlA49+aBo6w9eKSlPXikxQIXtRR0FJTAWgijPNKe1IBKTpS0UwCkoFL QAUgpaMUAAo+tJSkc0AA6UetJSnikAUdKKSmAd6XrSUtACUoFAoHWkAdTS0UlAB1o6Ue9J70AOpK O4o70ABNKORSGlFADh0ooHSikUc9oGTolmB/zyHWtxMkc1jeHQP7EtAP+eYJraXrTJHAUnSlpKAF 60UnaloADSZpT0pOooADSnFJilPSgAxgUA80DpSdKAFBHaigHtRn2oADyeOlLxSZoPWgA74oPSkN AoAXqaTvS9KSgA60CgUUwCjFC9aKQB04oAwaWkoAWkNANLQAnY+tL1/CjNB60AHaignjikHT3oA5 LwIcSeKECgY165JODyTtPPPpj8MV1pNcn4HyJ/FAJTcddnbC44+VMZ/L/wDXXW0IBKSlpKYC9cUU d6DSADmg9KXtQRQAlBNHTpQeKAFz60g60UAUAGaO9LSd6ADvS9qDSUAFFFBoAQcUcnv9KWjpQAve k5oxQKACijtRQAUUYoHFAC0nOPajvS+1ACZo7UdM0ZoAarliQUZQDwTjmn9qQnig80AL2pKKPegA 70vtSDk0UAL7UlHSjmgA6UtHakoAAOaX0pO1LQAUmOKU0lABS9qSjtQACiijrQAd6XvSd6XvQByn w2JPw90fKhcRuoAx0DsM8fSuqrl/hyGHw+0YN18k+n99vSuoNAC55oo70tAxOlBpT9KSgQdqPSj3 pKAClpBRQAtJ0NHajvQAUdqO1FACjpSUtFAHmHiRd3x28LKMf8ezN8xPZZun5fyr0+vKfF11b2Hx s8OXV5cw2tulr8008gRAP3oxkkY5IGfevU4J4bqBJ7eVJYnGVdGDKw9iKQzO1+w1LUtKa30nVTpl 2XUrciISYGeRtPXIryvwNpHiq8ttafRfFVpZMuouk6/YllMkg6uc/dzkcDI/LFe0DrXifhJ7/U5t b8M6czKl1qssmoXSykGC2zghBnhnIIBA6Z9sAHaeBJ/EV5fahcX+vw6xpEZMNvcLaiEySAjeQAMF QcrnJB28VofEdJ3+H2si3J3iEM2Bn5Aylx9Nu6uhsbK206xgsrSJYbeBAkcajhQOlT96AOZ+Hd1H eeAtGeORXCQCIkADBQlSCPwrkvhPayweIfFkkCKumm68uLauF3K7nAGOysvTjkV06eALK0lu/wCy dX1fSLa6O6W0sZ0WIMepUMjFCf8AZI9sVpx+GbG00SDSdNkudNtom3A2cgR29dzEEnPUnr70Acl8 MmX+3vGiKrDGpliTu7tJ6nHbsO/U9vRulef/AA/8L3mn6lrWrXN9diO6vpfLgaQESBWZd8nGSevo PbpXfigR5HYanf8Awt8QS6Xqdmz+GrudpIbyJC5TI9u/AyuM8EjNdP4R0ya98R6t4xnRIo9TCpaR qfmMChQrt6FgoOO2efbM8OWUPjfVfEU/iMm6e3nexi02baRaRHncFHRjjh+vy8Go/hpBNovijxP4 agvGvNLsHjaFi27y3bJK5HAPYj1U0DPTDXktp4lg8H/FPxEviEm2t9RKSQ3UgLDavCYx0XBIJ9Rz XrVec61rEM/xe0vSdWdYLC0h8+1EjALNcMMKenbkAZ6j3oEd/aXtrqFutxZ3MVxC3SSJwynv1FT1 kw+ItLn1pNHs7hbm6ERlkFuQywLxjeQcDOeB1/DmtY0wCl70dqKQBSd6U9KKYAaKKKADqaXtSdMU p6UDDpSUo60gFAC0lL2pKACijFA6UCDtRSUvagBK5f4jEL8PdaJLD9xwV9dwxn29fbNdRXMfEYA/ DzW8sVH2fqPqOPx6UAdJAMW8QyDhB0bPb170+mQKywRq7FmCAEt1JxTz0oAKKKKAFpKKPagBfSk7 0ZoNAC0lLRwKAEPWlpM0poAO1APpR29qSgDyz4kvn4g+D1dyI1mUkFhgZlTkAg+np6V6F4g0y21j QL7T72ZobeeIq8qttMY67snjjGeeOK5v4maJd6jottqenxmW80qcXKxDG50BBYKSDzgA/h64roYb i18UeGPPtJwbbULZgsiDdgMpB4PpzwfSkB5ob7xD4A0tLXVo7XXvBsqeSlzE3zxxPwMnHQg9OR0A btWl8T/JUeETCSoF8giLL8wXKdiCemO31rbXwHLJocOgXniC8udFjRENu8MQdguMKXC/cyOmM/7V aHiTwZY+Jl04TXV3Z/2e5eAWnlhQeMZDIwwNowBigZgfGDCeGtNmxgx6lEQ2cbflbvgn8qzvHNy1 n8WPCd1chxbKoVTkbAzOVbBI/wBpSfYV2viDwtB4l0i30++vrtTBKswnhEYdmAIGQUK9+wFN1nwl aeItCTTdZmluZY/mjvECxSo/94bRgH8Me1AGR8WbeGb4d37y8GF4pEOBwfMUHr7E1yHis3Efw68E y3gb7RHPCzSzbiUAXjcSCem0n3A613J8HXmoCCDXvENzqljBIsq2xt44hIy9PMK8uO+OOQK0vFPh ix8WaI2mXrSRIGEkckOAyMOhGQR3I/GgRy3xnyfAqsBnF2h4I6bWzj8M+tYPxKu5rXXPBlzeN/oi BJJWVyY9wdNx4G37p6jHBPaj4l+G20rwaLi71S91a+edIVnuyv7tMOcIqgAZ4yeScfhXoeteGrDx R4Zi0u/MnlFUeOVQodGA4YZBAOMjGOhNAGB8Ygp+HF6xYgiaEqu7G87xxz14yce1dlp3yaTZlxsx AmQwxt+UevT8a4UfCW2m0s2OoeItYvlGxYvNlBWBARkRqchSQNuewJHSrh+GVp/acFwNf102scaw vZvd7o5Yx/yzPGdh7r0+lAHIfDtLqL4W+KRakiZDLtYA5JEYzgjvjp1wefauy+FE0cnw8sEjcN5M kqPg5w28t6DH3ugq54R8D2/hES+RqV7ctK5d0kKpGG9QqgduxJH0qC38CyaPd3k3hzXbrSobx/Mm tvIjmjVsdU3DKn8SPbpQBzPhCKdPiZ4ygtVb+zQHM8ajcDIWO3Hy4zzJxn88cXfgj5g8FTrJJnZe OojJJaP5VyDwOe/HrXZ6B4csfDlnNBaGaR55TPcTzvukmkOMsx45OOwA61zFp8Mzpl7dLpviXVLH SbqQySWNsETk8YEmMqMZHABxjnIzQBQ+D6mFPEdv5UkRW/3FJDkjIOOdozwOvf0FHg1kX4v+MkWN zkKfMzwCCMjpjnP/AI6a1IvhtBp2q3F1oOtX2jWt0gS4tbNIsEAYGxipKnqc8nk4IqfRvh5a6P4o vNbi1O+Jnb5LdXIXHGfMckvIcjOSaAOW0W8vrL4u+LU07TJL2WVMKN8aqjfJhnYkEL83O3cfY446 jwPpMdnqGt39xq9hf6zdzD7fHZODHbMC2E/vDqfventUsvgmS28W3fiPRdVNhdXcfl3EclsJo36Z YDKkH5R3/nWj4Z8LWfhmO68ia4ubq8k826urhgXlbnrgAYyT+dAHG+OAD8WPBhiH74Md2c427x6A 9t/9a9PNeeRWj+J/i4+pqn/Ev0BPswkyMSTkMWAIPbcM/wC7ivQ6YHneoxt/wvbSXCcHTCCxz0/e 9PfPapPEETn4zeE3UH/j0uMksQMAN09+fxrW8S+DP7c1ew1ix1WfStTs/lW4hjV9y5PykHr1brxz yDWfN8NIrjXdN1WXXtUa5s4yGmLhpZZN2QdzZVV6jaqgfrkAytGmYfHbWkujuke02wFyDhAIyNh7 fxZHrk+tN+KiG38T+DtQtmC3gvPKTHVhuQgEdSMnB5HDH1rq9c8G2uq3VjqNtdT2GsWOBBqEeGcr 0KyA8OpBPX19CQVsPCjrr0et6zqTapqFuhjtSYFijt1PUqoz8x7kn6YoA5TwtOsnxu8Um8YG78oR Wxx/yzG0kDn02/8A1u8/jIH/AIW14MOAPvgFgT39Bznj/HitjxP8P7fXtXi1iy1GfSdUjXabq1XD OOnOCDnHGc9MA5HFcdq2j3WjfFDwk1zqdzqt3M5aW4ujggZwAirwqjJOO5Jzx0AOy+KkZk+Gusrt YkpGcDrxKh/pXOeMWWX4B2btsANpZHCtkZynA/H9M1oXvwvuL+C/t73xZql5DPJ5lvHd/vFt33hi 23IDHaCoGABuJAzWsngKybwW/hi81C/u7UoqpJI6hotuCNm0AYyM4OfTpQBh+IYp/EfhewsdR8vw 9oavELq61SVY5ZCvRY1J+UHHVyp/2a7qDSLC3ntp4oFMltbi3gdju8uP0XPTOBk98D0rmZvAdzqW jWGiaxrS3Wk2RQpHFaeXLKEBCiRy7AjHXaq5ral1yCx8VWHh4xRxJdWjy27BgPmQgFAv+7yMeh9K ANvpXkNqw8KfG2W0s/MWx1MqJIIxhFMgJB2jjIcdccBmr16vJdHtT4v+MV7r1q8Umk6WwjWdSHEj qm0Bcgg8ljkYwMc8igD1rtXKfEEgaHp6tjB1ayBJ6D98p/pXVVyXxD2/2Hp+9Qy/2tZ5z6eatAI6 48E0UvHakFAB2o70dRRmgAPJoPakzSn1pgFFAooAPeiiigAozQOgoFIAAooFB60AAxiigY70cc0A HWkpRR70AHQ0vUUnWjFABQKMUUAB4NLkUh5NFACjrQaSigBfpRSUetAC555oB4pDQKAHjpRQOlFI o53w62dCswMZEa/hwP8AGt1DkA+1Yvh8g6LYjb/yxU5rZRs9R3pkEgoo6U3eu8oGBYAErnkA9P5H 8qBijrQSOaKM8UAONNpc5pKAFNB5o7UUAIKUUDpR9KAACg9DRR1NACDrS5pKD0oAU0noaPpQelAC 5pKUe9J3oAXHSjAxRSUAKKMCik6UAHajrR2oFAAOtBo+lFMBRSfxUCl/ipAHakBo60vXpQBx/gWQ td+Kkwg267Pwr5PKp19PX/8AVXYAH0rgPC+gWmo3/iW4uZ9QSU6zOoS21GeABRjBKxsoyeeTnjHP YdF/wiWmn/l61v8A8Hd5/wDHaB6G5RjgVh/8Ilpuc/ada/8AB3ef/HaQ+ENMLBvtWt8dv7bvOf8A yLQI3cexpTWF/wAIlpv/AD861/4PLz/47QfCWm/8/Otf+Du8/wDjtA9DdpD9Kwv+ES03tda19P7b vP8A47SjwjpuObrWzz/0G7z/AOO0AbvPpxQe1YP/AAiOmE5NzrX463ef/HaT/hENKzxPrPXOf7bv Ov8A39oA38GkrC/4RHTCc/adaz6/23ef/HaP+ER0zr9p1on1Ot3n/wAdoEbvIpec9KwE8HaTGMJN rKj0GtXg/wDavuaRvBukMTmXWGyMHOtXhyPT/W9KAOgIo7Y5rA/4Q/SgcifWc/8AYavP/jtJ/wAI ZpG4nzNXyxyT/bN5z/5FoA38EUd+hrnD4G0MrsI1MrjGG1e7IxnP/PX1o/4QXQQ2dupEnrnVro5/ 8iUAdHgjsaXBPauYPgHw6etve4zkD+0rnAPXgeZ60p8A+HWYM1veEjHJ1K5z/wCjKBanTYPpSYPo a5n/AIV/4cYjdbXjY6btSuWx+cn1pP8AhX3hsgA2l2QBjB1G5/8AjlAanUYNJg56VzH/AAr3wzjH 2K5GeuL+4Gfr+8pB8PvDS5C2dyM8kjULgE9e/me5oDU6nB44pMH0rl/+Fe+GsD/Q7o46Z1G4P/tS nL4A8OKm1be9C5ztGp3IH5eZQGp0+DRg1zLeAfD7qR5V+OMZGqXPH/kSlHgLw+pBEN8CMdNTuv8A 45QGp0mD6UuDnpXMnwD4eZNrQ35GAMHVLroDkf8ALT1oPgHw+R80WoMP9rVbo/8AtT3oA6Ug+lGC K5g+APDpIzBfHHT/AImd1wfX/Wf5yac3gPQHI3Rag2CMZ1W67f8AbSgNTpiDRg+lcyvgHw+NoEWo fL93/ia3Xy/T95x1NOPgXQsbdupYxgD+17vGPTHm9KBnR456UY4rnU8E6Kh+Q6qvT7usXY6dP+Wt L/wg+iF/MP8Aam/IO7+17vOR0583t29KA0OiwaTBrAHg3SEbcsusAk5J/tm85PTP+t9qB4O0vduN zrROcjOtXfy8Y4/e/X86AN85pe3SsH/hENM2gfaNZwOg/tu84/8AItNHg3SQciXWBznjWrzrz/01 9z+dAHQGjBrnk8FaOjFkfVlYjBI1m8HHOP8Alr7n8zTj4O0lvvTawcnPOtXn/wAd9h+VAG/1pO+K wf8AhDtKAC+frO0HIH9tXmAev/PWl/4RDTVAC3OtAD/qN3nT0/1tAG73pawD4P0wtu+1a2Gxjd/b d5n/ANG0v/CJacP+XvWz/wBxu8/+O0BobuM0uKwf+ES07IP2rWx/3G7zn/yLTf8AhD9PLsft2u4P Rf7bu8D6fvKB6HQYxSNu2nbgHHBIyKwh4R04H/j81w/XW7z/AOO0g8H6eOt9rrfXW7v/AOOUBoVP hvg/DzRiM8xMegGPnbjgnp/nHSuq/CvP/A3haxufBmk3L3msr5tsG2R6tcxoMknIVXUD8Bj69Tuj wbYeYHOpeINo/g/tq6wf/Imf1oDQ6PBornn8HaeyFRf68h/vLrd3n9ZDUg8Iabyftet/+Du84/8A ItAG9zSVg/8ACIadkn7ZrmD2/tu84/8AItL/AMIjp23/AI+9b+v9t3n/AMdpAboB70fzrAPg/TyG AvtdGRgH+27vj3H7ykHg/TwMfbtdJznP9t3f5f6ymB0GKTmsAeDtPx/x/wCvf+Du7/8AjlIfB1gQ uNQ19cdca3dc/nJQB0HajvXP/wDCHafgf6fr3/g7u/8A45Sf8IdYZ/5CGvf+Du7/APjlAjoRzR0r nz4O08yZ+368Fx93+27vH1/1maD4P0/cp+369gdv7bu8H/yJQB0IBoI5rnf+EL05oyj3+vSA8EPr V1yPQ/vKePB+n/8AP7rv/g7u/wD45SGX59C0q51eLVbjT4Jr6JBHHNIm5kAJYbc9Dknkc1oVzjeD LE9NT8QLxjjWrr068v8AjTv+ENsNuP7S1/Pr/bV1/wDHKegHQ8+lUNM0PTNFWcabZRW3nyGWUoOX YknJJ57n86zW8G2DKQNR19DtIyNbuuvrzJ1/SkXwZYKHzqfiBt2SCdauvlye2JO3TnPSgNDogKMV zqeC9PA+bUNedsYDNrV1kcD0kHpmnt4P04sf9O10Z4wNbu+P/IlAG/RXP/8ACH6fn/j+17qT/wAh u7/L/WUh8G6YWQ/bNc+Q5A/tq764I/56e9AHQ9qK53/hDbDJP9peIMEYx/bV1x7/AOspf+EO08kf 6fr2B2/tu7/+OUAXL/w3pGpXZu7myAuiuxp4XaKRl9GZCCw46GrGmaRp+jWf2XTbSK2hDFisa9ST kknqT9ayP+EKsBnGp+IMk5J/tq5z9Pv/AOcUg8FWWVP9reIiASSP7aueeMYPz/jQB0vSsjW/DGie IlUavpdvebAQrSJ8yj0DDmqP/CF2YzjV/EPPT/ic3HH/AI9TD4IteMa74lGCCf8AicTc/X5v5UBo auj+H9I8PwNDpOnW9mjtlvKTBY+56mtKuaXwZAo/5DfiJuP4tWm/xpD4KtiGA1zxGM+mrzf40Bod NS1y/wDwhUOePEHiQHB/5ish/nQPBUQJJ8Q+JDnjnVHpCOoowcmuZj8GpGwJ8Q+I3xgDdqLccY9O fxzSL4LjVSreIfEjggA51JgePcAGmB02PWl5zXMDwVGrbl8ReJB7HU3Iz68/X6Uo8G4lD/8ACTeI 8rnAN9xz3xt5/H1oA6c0Yrml8IMox/wk3iI4Pe8X/wCIqN/BjOhUeKfEisW3F1vFBJxj+5j04pDO pFJ/KuZ/4Q58Y/4SnxJjOf8Aj8X34zsz3/QUN4PkYEf8JR4jAJzxeL/8RTA6ekrnD4SmJJ/4SrxC OmP9Ij4x/wBs/wCdM/4Q+TDD/hKfEeD/ANPacemPk/8A1980AdNSVzY8IShmJ8V+Izu6j7THx9P3 fFKPCc/mF/8AhK/EOD/D9oix/wCi6AOk7UVy0fg2ePlfF/iXPHLXMTdPrHTz4RuiAP8AhLvEY5zn zof/AI1QB01ct8SFL/DrXArFT9mJ4zzyOOPXp+NO/wCEQuhk/wDCYeJM+vnQe3/TLHaue8deHLmz 8E6rcN4n166/dKvkzSw7GJYAZ2xggZPJBHvQB6LF/qUyAPlHTp0p3auaPhK7IwfF/iPt0lg/+NUD wldqc/8ACYeI+RjmWA/+0aLBY6Wg9a5j/hELokH/AITHxLwMD99B/wDGuaf/AMIpedf+Ew8RcHP3 7f8A+M0BY6TvRXLnwfckRj/hMfEv7v7p8+HnjHP7rn8c1KfCt2ef+Ev8RZ/66W//AMZoCx0fejvX Nf8ACJ3fX/hMPEeeP+Wtv2H/AFxpf+EVu85/4S/xEOMY8y3/APjNAW8zpaK5v/hFrwHI8X+IckY+ 9bemP+eNOPhi9IH/ABWHiDj0Nt/8ZoCyOi9qO1c5/wAIxfDd/wAVf4g5Oett/wDGKU+Gb05/4q/X +Rj/AJdf/jFAW8zohR0Fc5/wi16V2/8ACYeIcD/ats/n5NKfDN8Rg+MNfwDnj7KP/aFAWOirM07Q rLSLmaXT1a2hnJaS2Q/ui/8AfC/wn/dwD3GaoL4YvVwR4w8QdAOTbH19YfekPha9JyfGHiHO4H71 t/8AGfbpQFjowKK5xvC164wfGHiD72/hrYc49oent0pE8LXqRhB4x8Q4VQg3G2JwPcw5J9+tAHSZ oNc8PDV+OR4w17rnpaH/ANoU0eGb5WJHjDxBySf+XU/+0KBHRdKWueHhm/wf+Kw1/nPa1/8AjFM/ 4Ra9IH/FYeIeDkfNbf8AxmgLFzxH4bsfFGnR2OoNOIEmWYiF9hbGRtJxnBBIOMH3q5pmm2uk2EVl Zq6wRDCh5WkIA4xliT7deOlZA8M3xwT4v1/I/wCvX/4xzQPDF6pVl8X+IAVBABNsR+OYefxoA6Kk I5zXO/8ACLXpUr/wmHiHBx/FbZ49/JpB4WvRt/4rDxD8owMtbe3X9zz070DsdJRXO/8ACMX28t/w mHiDJ/69cfl5FL/wjN/tx/wmGv4Pta+mP+eFAjoaO1c//wAI5qBKt/wl+vZU5+7aemOnkc04eHtQ DFv+Ev13n/Ys8fl5FAWN2l7VgjQNRGP+Ku1zj/pnZ/8AyPS/2BqB/wCZv1z/AL92f/yPQFjdqrqF kdQsZLUXVzaiTAaS2cLJjPIDYOMjjI554IPNZn9gajg48X62D/1ys/8A4xQNA1HIP/CX63np/q7P /wCMUDNLTdNs9I0+GwsIFgtYQRHGpJxk5PJ5JJJJJ6k1bNYf9g6l/wBDdrf/AH6s/wD5HpDoGpZ4 8Xa17/ubP/5HoA3cUGsF9A1UxkJ4w1lW7FoLMgfgIBUa+H9ZGM+MtVPPP+i2nT/vzQI6E0vasA6B qvGPGGsdecwWfT/vx1pDoGrcEeMNYHrm3sz/AO0KYHQYrmNf8D6d4k16w1S9uLxGskwkdvMYskNu B3D5hj/ZIPvxUreH9Z28eM9W3Z6m2tCMfTyab/wjut5AHjTVdnOc21pu59D5XFIDft4EtoI4UMhR BtBkkaRiPdmJJPuTUtc6NA1vHzeMtSJz1FpaDt/1y9f896avh/XgAH8Z6iSMgkWdqM8cf8svXNAH SGsPWvCWkeIL+3u9ThadreJ44037VG4g7gR8wYbRggjHNV28P62c7fGepg8YzaWh9P8Apl9f09OQ eH9dGc+NNSPHH+h2nX3/AHX1oAifwNbzSMtxr3iGezYnNnJqLeWVOflLAB2HPdj710FhYWml2MVl Y28dvaxDCRRrhV5z/PNYZ8P6+VwfGmoeuVsrYH/0XSvoGvMSU8Z6gvsbK1P/ALToA6SuP+I+/wDs PTtr7f8Aia2nRcn/AFoxz2//AFVcGga9tI/4TPUCex+x2v8A8brA8XaTq1va6V9p8RXd+kmr2aLD JbwRjJkHJKID6nikB6IetJn2pc80gpgHajPtR2o70wDvQaO9BpAA6UUDmigBe1JzSikNAB2oFAPa jigAHNLjBpBRQAvak/rS9KQ0AAHrSk0nel7UAIKXIpKXGKAEzzxR2o70ooAPSiijFACD6UUtJQAt JRRmgApR05pDSjpQA5elFC9KKRRz/h5f+JJZnPPlKea20GABisPQFzolkOR+6WttDg7fSmQSUnQ5 pec4ooGBFIaXNHegAB4xSdKUUnSgBe9BpKU9BQAnajtQOlFACg0lLSGgAIo60vGc0GgBMelB5ApT xR0AoATFHelpKAClHQ0ds0lACjOaT6UvejvQAgFFFFABRnmgUUwDtR3ozR3pAGOlHelzxRQBy/gn b5Ou7d3/ACG7zdnpnf24HH58557Dp+lcn4FZD/wkoQEFdeug2QBk/L6e2P8APA6zNCAB0o60o6Ul AAKKOlFMApewooPQUgEo7YooI4FMA9aMUppKQB3FB9qKM0AL70GjpRQAneijvR2oAKPagZoFABQK O9JQAuDSUtFAHB6loXjbWtVvLmLxS2g2Ec5W2t0t0mJRQR5hbI+9knac449BWd4RsvFWqapJLL4x ur7QIH2rOttHEbth1VerBQeN2ecYHrWz4p1A6r4l0/wZCwMF3E1xqm3IYW46KG7byCDjnHTHWuwt reK0tYbWBBHDCixxoOiqBgD8hQBxEms3virxzeeHbC9nsdM0yLfd3NrxLNLnHlhiPlA5zjnKmjSt budA8fP4Qv7ye9t7qIXNhcXLbpUyGzGzHG4fIxB5PY57Y3w1B/4WF4081GEv2hmPTGDK5/oMY/Wm +PnaP4seEmjYBw0QIRF3kGbGC3XBG76c+tIDtG0nxEfGo1L+30GhrHj+zvIGScY5b6/Nn8MYrR13 VYtC0G+1Sb7lrA0mPUgcD8TgfjWiK4f4jyNfponhmNip1i+VJiP+eKfM/wDSmBu+D49RTwnpz6tc yXF/NEJpnk6hn+bb0HTOKi8Zx3qeG76/07Ubqyu7O3kmjMO0hyFzhlZSD0+vvXQYCgBQABwAKxfG K+Z4M1tNoYNYzDB90PT39PegDL+Hd5f6v4XtdX1HVLq7ubjzA6SJGiLhyBhVQY4A7nqetddXFfCb H/CudP8AlAO+UH3/AHjV23SgBO9HGKB1o6dqAFPpSUtIKAFFJRSmgApKXHNHegBKKXvRigBDR2o7 UGgAoFFL3oAO9Nd0jRndwiqCSxOAB60tDKrqysAVIwQRkGgDnfAJiPgHQ/KUKv2NAQGJy2PmOSB1 OTXR9a5n4fSNL4A0VmDg/ZwBubcSASAc5PbFdL1oAXHNFBo7UAFFHaigAoxS0hNABSZ4paTigBe1 JS9qTvQAUGig0AApe9FHegAoHWiigAoAo7UlADhUc80dtBJPK22ONS7nGcADJ6U8UMoYFWAIPUHv SGcP4VuNV8Z6LJrE+t3lhHNO620FlHEvlxggDdvRiWOM9SMHineFPE+r3sniDSdQiS51LRnKrNFG UFyCG2cdAxx2OOa4jUJtR+GHia+Tw7cDUtNMJuLnTfLZvsgIwGbYMKBgfNwSOueGrvfh1baU+hPq 9hcre3eoyGa9ujHsdpOuwjqoXOAMn1yc5oAw5NL+JUGni+vfGWnWkaRGSdZLVAIRjLDcFIO0Z59q 2vBcfiq6Q6jr2stLbPn7Pbi0SIuvZ3+XcoPULwcYz6VRvLiHx345m0EsH0XRNst4m3Inud3yo2eC q4bIxyQfw79QEACgBQMAAYAFAjiPDt/qPji1u9T/ALWutMs0uXhtoLJYwxVf43Z0YknqAMAD161N 4S8QalL4i1jwxq7Jc3WlhGS8RSpmjbld4wAGwRnHB5x0yeP1Zrz4c+M559Bn+3afOhubvR4ySYFw MyEKpCDod+PY5611fw6j0q/tLvxFb3kV7qupMGvpFG3yj1EQXqoUED/axmgDU8PWXiq11PU317VL S9s3fNksEexkXJ4YbRjjHdu/NczJa/FS5ha8j1jRbCOTMv2e4j5hX+6W8s9B3r0iuG16/fxP4sTw haBm0+BRNrEqOR8v8MOR/exz7H60AV/Bk3jHWr57zUdcgfR4XKxPbWyAXuO6kp9zP8Q69sda9B6V Hb28NpbRW9vEsUMShI40GAoHQAVIaYAaWiigApM80vpRQAdBR1NJQaAHd8UnuKKKADvSY4pe9HtQ MWk60vajrQAlFFA4GKAA0fSg9KDQIK5b4irv8Aasvqidgf419x/npk11Fcr8Sv8AknesnBOIVOB/ vrQB1Ee7yk3bt20Z3Yzn3xx+VOpluyvbQsudpQEZxnGPbipDQAUlLSUAFA6Ud6KACiiigAxR2ooo ADS44pDS9RQAmKKO1HagBccUH60dqKAAUgpaO9ACfjS96QUp4oATvRRSjpQAnrQKKKACg0UGgA6m iijtQIKKKPegDhPH2v654Ym0+50y7tpI724FubW4gDlSQPmXBVj0PU9SKk8e61rfhTw1DqVrf20t wsyxPHLbDbKWJPA3AjAHQEnANZvxkQroelXTRt5MF8DLIoBKKVb+uPbp7U34r6rp+o+Blhs76KeW aSK4SOFwXMQJBcgHIXsSeAeKQzotUuPEth4Kl1Jbuz/tS3gNzLGbX91gLlkxvzxzg57CsaXxF4oj +GqeJILjTJLh4jPIssDKqKTgCMBuT6ZPP40+78Q6NefCxk+0xyzT6UUW1JE028Rc5Qc5U8k4GMZO KzoLq3n+BE8KTRSyw2DebH5nzRjewyQOVPynAPGRjoCaALEes+OLvwPH4ltbrS4kSz+0C2mtyzTA DLMzBgFPBIAHI6kGtGTxNq178N4fFNhNaQXCWjyywTW7PHIynBAwwK8qccnr3pPDmF+DMJKuwGmS nDEknAbp3x6e2KwPDqm6+A17EIGkYR3AOI8EneTu6ndjrn2x2zQB01hrWvan4BOvxXmmxzvbPcRq 1k4Qbdx2t+9Pp17enaofDGt+JNb8ES65cXOmw3DrI0KC1YooQsDu/eZOSD3GMd6yfDut6VafBeGO 41CFXa0nt1iDbpC/zfKFBJJwQcenPAqf4ZTwt8NmtHuC8qC43xFlDIMngDOR179ye2KALfgzxB4k 8VeFZNYe40uCZmdIohZSeWCo6kmTnJ9DgY9cipPBOu6/4w8KHVZbzT7SeR2jRYrNmVCpHJzKd2ee hFZHwZu4p/A81oZP34nkYx+Zk7Sq8qDk4z7dc0z4S6rZaR4Jv4tTvIrQ6fdOJo7iQK0Q4HK5yPmJ HueOtMDR8AeJtf8AGFhfXNzd6fCbeUwqILRiCSAQ2TIc47Y49c07w94g8WarrXiDTGm0Zn0h1iQ/ ZZU88ndgswkOz7vZT1/PC+Eeo6dpdt4jgvr22tJY70yMsxEKrGFxnDYI5ByD049at+AtYsp/iJ4s aO6j8q8eOaA7tqyKCQCNwyc7+3HPfIoAm0PxX401zV9c0qGDRUuLGYR+eUlMMQDMpHXLsSOPujgn 2rT8I+KNa1PWtb0HW1sE1GwwUls438pge5DNk4OPTPPpmsz4d/8AI9+OsHAF6MBchfvyjp0zx9et QeF5EHxs8TRKDkwseHOM5jzwfr/nPAM1dC8TeIdR8e6r4fuZdKFtpwDNJFayLJKCVwADKQOGOTz2 45qh4l8WeKvC3iTTdNubjSJLG+dVS8ewkyuWAYECXHGQeOxqDwzJ/wAXy8SqHIVrc4UDIYjys5Pr 1rf+JuhNrfg65aCFZLyyU3EJ/iwB84U+pXPHcgUCOwjEgjUSOryAYLKuAT9MnH51yOn6t4lvPGl/ pK3Wky6dYIhuJ1spFcSPyIh++Izt5LcgccZrnvDuv3N94Fk16fxhewrp8JS6i8q3I8xQMAM6FiWG OpJJbrXT/D/Srmx8OfbtQkkk1PVZDe3TSYyGYDaoAAwAoHHYk0AdX0rk/H+f7P0ULwx1yyw2eVPm jkDPJ9ua6ztXI/ET5dC0+TJBj1azbIOCP3o5FAHXd6KO9GKADtmg0dqPemAgpTSUvagAo7UdhRSA KSl7UdqADFFFGOaAAetJSjpQTTAUUUAUhJpAHUUdqO9FAAKBSdqXNAB35oxzRjmigBcUnelzzSUA GeaKXrSUAHejvQKO9ACntRSGgDNAD16UUL0opFGB4fIGiWXIP7pegrbUZweaxvDq40Ky7fugea2h 1pkC0ppMd6TnNAxTRRmigA7UUdaKBgetIaWkIzQIB0oFGKB0zTAXuKQ0o6UE0gEpe1JS9RQAlHNL 0FJQAo6UlFGOaYC5oGKQUYpAKOtHekHWloATNHeikIpgL2ooo4oAKO9FAHNIBaSg0UAcr4GP/Ixg cbddugV44OQe3qCD+NdVxmuA8J+ING0q78TW+parp1jO2t3MgjuLpI3ZeAG2s2ei9ehGK6P/AITX wnnjxRouf+whF/8AFUJAbnag1h/8Jp4U/wCho0X/AMD4v/iqP+E08Kdf+Eo0X/wPi/8AiqdgsblF YY8a+FT/AMzPov8A4Hxf/FUDxp4U7eJ9Fz/1/wAX/wAVRYLG5S9ulYX/AAmnhT/oaNF/8D4v/iqP +E18Kf8AQ0aL/wCB8X/xVFmFjd5obg1hf8Jp4UP/ADNGi/8AgfF/8VQfGnhT/oZ9F/8AA+L/AOKo sBu+9J3rE/4TXwof+Zn0T/wYRf8AxVJ/wmnhTP8AyM+i/wDgfF/8VSA3KU1hHxr4T/6GjRP/AAYR f/FUf8Jt4T4/4qfRP/BhF/8AFUAbtHasIeNfCf8A0NGi4/7CEX/xVNHjnwkRkeJ9Gxx1vo+/40Ab 3elrBHjbwmRn/hKNF/8AA+L/AOKpB458JFiB4n0bOcc30Y/rQFjdFKK59/HPhKIZbxPo5H+zext/ I0p8c+EkPPifRj9L6M/1oA380Vz58d+EVTcfE+j4zji9jz+WaUeOvCRbA8T6Pn/r9jH9aAOgpO9c 8vj3wgwyPE+k/eK83aDn8+nvSv468IxjJ8TaQR/s3kbfyNAHKeK4tY8M/EO18WWGlXOp2M1sLW6j tFZ5VGf7oPThSDjGQQccGtXTPE2r+LtSs/7K0vUNL0iCbfeXN/Gsck2BkRIvzZBOMt6DGa1l8eeE WQOPE+kYPreID+ROaE8d+EZGcDxPpAKnB3XiL+WTz+FAzAns5vCPxFutdME8mh6tCFuZIkaQ2846 MyqCdpA64wC3UcZjtNNm8XfElPEc1vNHo+lRCKyM8RQzy85YKwDYGevqBj26L/hPPCIJH/CT6Rkf 9PiemfWlbx34RBIPifSMgbuLyM/16+1AjoK8w1zxDJpXxMuL+bw/rV/HZWS2tr9jtmZNzfO7ljgd CBxnofw7EeN/CZGf+Eo0X8b+If8As1B8ceE1VmPifRiE5OL6Mn8ADz+FAHO6f8QNQ8QaxZaXaeHt U0xZZgZru8h2qsYyxUAjBLAFevGSRnFdR4sjeTwdriRqXd9PnVVXqSY24qufHfhLj/ip9I5Ut/x+ x9vx/Snf8Jx4S+U/8JPo3zdP9Oi/+K4oAxvhfFqNl4TtNPvNHurNUDyCWdkG8s5IAQEsBgj7wH49 a7fFYI8ceE2UMPE+jYbGM30YP5Z4pf8AhN/CZ4/4SjRc/wDX/F/8VQFjdHWjrWCfG/hIFc+KNF5O OL6L/wCK4p3/AAmvhMf8zRon/gwi/wDiqAsbp6CkrD/4TbwmR/yNGi/+B8X/AMVR/wAJr4Uz/wAj Pov/AIHxf/FUAblArDPjbwmOf+Eo0X/wPi/+KpB428JkAjxPov438X/xVAG9Sd6wv+E18J/9DRon /gwi/wDiqP8AhNvCf/Q0aL/4Hxf/ABVAG6etL2rC/wCE18J/9DRon/gwi/8AiqT/AITbwpg/8VPo 2Acf8f0X/wAV70Ab1JWGPGvhQj/kZ9F/8D4v/iqQ+NfCnA/4SfRef+n+L/4qiwG73orD/wCE08K4 /wCRn0XHT/j/AIv/AIqj/hNPCn/Qz6L/AOB8X/xVMDc6Gl71hf8ACaeFCf8AkZ9F/wDA+L/4qnDx l4Wdwg8S6MxPAAv4iSfT71ICl8OyW+H+ikn/AJd8fhk4zwOa6euD8DeLvDlr4J0iC71zSLSeOAK0 L3kaMpBPUFs57/jnjOK6H/hM/Cu3J8TaNjpn7fF/8VQFjcNHasP/AITTwrjJ8TaNj1+3xf8AxVH/ AAmvhPH/ACNGi8f9RCL/AOKoA3D0FGOPesQeNPCrcL4n0Un2v4v/AIqkPjTwqOvifRQfe/i/+KoH Y3aT3FYf/CaeFcZ/4SfRsev2+L/4qj/hM/CvbxNo3/gfF/8AFUAbmaTFYY8a+FDjHifReen+nxf/ ABVH/Ca+FMf8jRov/gwi/wDiqBG6OlJ3rDHjXwoBn/hJ9F+v9oRf/FUf8Jp4UJ48T6L/AOB8X/xV AG5R61hjxp4UJGPE+i5P/UQi/wDiqD408KqcN4n0UfW/i/8AiqAN2isP/hNPCm3J8T6LjPX7fF/8 VR/wmnhTJ/4qfRf/AAYRf/FUAblKKwf+E28Kf9DRon/gwi/+Kpf+E18KA8+J9FH/AHEIv/iqQzc7 UCsQ+NPCoAJ8TaMAehN/Fz/49SDxp4UOR/wk+in/ALf4v/iqYG7RWF/wmvhQf8zRov8A4MIv/iqU +NPCuM/8JPo2B/0/xf8AxVFgOO8DX1l4RTVbHxCXstWmvXlknuIWAux2Mb4w4+9hRyOeKufDDRbv TP7dvHhmt9Ov7zzbGCYkMIwWwxQ8rkFevOFHHAro/wDhNfCn/Q0aL/4MIv8A4qj/AITXwp1/4SjR f/BhF/8AFUWA880m/ufhx421yPWdP1CbTNTlEsV9BAZVX5mIztHP3zkdQQOCOa7jw7r2p+I9TmvF 06ex0JI9kH2pAks8ueW29QoHA/H8LZ8a+FAP+Ro0Uf8AcQi/+KoPjTwqOvibRf8AwPi/+KoA5Pwj eW/hbV/EFv4mcWWo3d3563Nw37q4iIwgRz1I5G3rzgDtTvh1pMkPiXxFq9rbPb6NeSAWauu3eM5L BTyBzxnHWurPjPwsBn/hJtGA9ft8X/xVH/CZ+Fuf+Km0bj/p/i/+KpAbdeQ/a7z4e/EfV9Q1Kxvb nStUbd9qt4jIEBbK5I/u5YEdcdM9/Q/+Ez8LE4HibRs/9f8AF/8AFUf8Jn4WHB8T6MD/ANf8X/xV AjN0PxVceK9cV9JtbqHRLZG865uYNguXPCrHnnC8knjsK62sc+LfDYQOfEWkbM43G9jx/wChUn/C XeGd23/hItIz6fbov/iqYGz2pccVkDxT4eYnGvaWcel5H/j7ilk8U+HomKya/paMBkhryMED8/ek BqilrL/4SXQfLEn9t6ZsJwG+1x4P45pY/EWhzE+VrWnSc4+W6Q8+nWgDTozWT/wk/h44/wCJ7pfI 3D/TI+nr1pz+JdBjyX1zTVA67ruMY/X3H50wNT3o5rN/4SPQ9gk/tnTthYoG+1JgkZyOvXg/kaIv EWhzymKHWdOklyRsS6QnI5PGaBmnSdKzR4i0Muq/21pxZgdo+1JzjrjmlOv6LhydY0/CfeP2pPl+ vPFAjSFH0qkus6WV3DUrMrv2ZE643dcdeuCOPemrrmktu26rYnacHFwnH60hl+kqh/bujlsDVrDI 7faU/wAae2r6YoJbUrNcDJzOvT160wLlFUP7d0cpu/tax24zn7SmMfnTl1rSpIy6anZMq5ywuEIG Bk9/SkBdrlviOWHw91oqQP3AzuOARuGR+I4rdGr6Yz7V1KzLYJwJ1zgde9c58Q763PgLWIorqNpT CF2JMAxyy8cHPf8AWgDrIV2QRp12qBnj09uKf0FUF1jT4rSOa5v7OHKjduuVwDtyRuzzxz+tOTV9 MlBMeo2bjnlZ1PTn1oEXaO9Uxq2mkA/2jaYYBl/fryD0PWlbVNOUsG1C1BUZOZl4H50wLXU0VUTV tNkLBNQtG2nBxOpwevrS/wBp6fuZft1rlOGHnLlfrzQBaoqkNZ0tiAup2TZ6YnTnjPr6c09tT09G KvfWqsF3YMyg46Z69KALXXpRVNNX0yQZTUrNhnGVnU8/nTl1TT3VmS/tWCnDETKQD6HmgC1S1VTU bGVwqX1szHOAsqknAye/pT3vbWNwj3UKuTgK0gBzjPT6c0ATdqXpVdb20ZN63UBUnGRIMZzj1pVv LVgCtzCwIyMSA5HrQBOe9H+NQvd2yAlrmFQDjmQDB9KRby1Ysq3UBK/eAkHHGeaAJx1pBxTRLEeR Kn/fQoEsTEBZEJOSMMOcdaAH0UxZomziRCQcH5hwaRp4Vba0sYPoWAoAk+lFR/aIAiuZ4trcBt4w e9IlzBI8iJPEzRna4VwSpxnB9OKAJe1JUJu7YMq/aYct0HmDmg3dsACbiHBAYfvByPX6UATUVGbi AJ5nnxbOfm3jHTPX6A00XlqzYW5hJ6cSD6+vsfyoAmoqIXMBXcJ4iuN2d4xj1+lJ9rttxT7TDuBw R5gyKAJjR2pgliMYcSpsPRtwwaQ3EKuI2mjDkFgpcZwOpx+IouBHe2NpqNo9pfW0NzbyY3RTIGU4 ORwfcA1m6f4R8OaVbzQWOiWEMc67ZgIFPmL/AHWJzkcdDxWuZYwRmROenzChpY04eRF+rAe39RQB h2Pgnw1pkN1HZaLaQC6jMUxRfmdCMFc9cHuBwatx+HdFh0ybTYtKs47OddksMcKqrj3wOT79a0wy 5xuXP1pAyt91gRkjIPcdR+lAGbYeHNI0yzns7KwjhtbgbZYVJ2EYxjBOBwT0pmleF9F0Mzf2bYJb rMMPGrsUI/3SSB07D19a1/xHWk3KG2FhkgnBPOB/+sfnQBhWXgrwzp9xPcWeiWcM84YNIiYYAqVI U/wAgkYXFT2mhaDoFjcG006ysbfyj58kcYQsgByXbqcDPJNa+MH3prok0bI6rJGwKspGQR0IIoAw fCcHhYaWs3heGyFqP3TS28YDMVGMOSNxP+9zUj+DvDcusNq8ui2ct+7bzNJHvO71weM+9aGn6Xp2 kwG306ytbONmLGO3iWMFvoO9W8gA5I4689KAMK58EeGLzWDqtzodnLelt7SPHkM2MZK9CfcjrzU1 v4W0O11i41aPTLc6hcSeY9w6B3DYA+UnO3p0GK2P0pCQOpA+tAGNF4T0ODWH1aDT1hv5JDJJPFI6 M7E5O7B+Yc9DxQ3hLQzqr6qtgseoOxd7mKR45GJ46qR+VbIO4BlIIIyCOhpcHHSgDynQL+ys/jh4 hjurmGKS4QRwGSQAsx8r5BnufT/Zr1RlV0KMMqwwQe4qpBpGnW1/Nfw2MCXc/Mk6xje3/AuuKu96 APELPwzfReOb/wAForLpM11FqUjtuJ+zocqM55ySE5z9yvb+1QfZLZb77X9nhF40fl+dsHmFAc7d 3Xbk5x0zU/PpQAVy3j0p/ZOmB13qdYsgV9f3y9K6nB54rk/iA7ppOlKmAz6xZrkjOP3g/wAOvagD rD1o70UUAHQUUHpR2oAMUHtQMUH3oAKDxRQaACjNFGOaAFBpKOlFAAOlJSikxTAWg+1FFIA6GjvR RQAdTRjmk9aXpTACaBzR3opAH1paSgUAFH1oooAXFFIOtHegANKvQ0h60o6GgBy9KKF6UUijC8Os BoNmf+mS1sqcgGsLw8QNCs8gn90tbiHjpj8aZA+jtRRQMB0oPSjijtQAUUtNoAMcUpPFB60H1oAS gCgYNFACjikPSlyaD0oAQ5oo+lB5NMBTSYwKU5PakNIA680Y60DpSjnNMBMcc0DijtQDjmgAz7UC l70nekAUdqM9qU0AJ2ooNKaYB2pO9GKKADtQKKOg60gOM8F2dvcv4me5to5CdduRiWJT90rg5xXT R6RpcUjSRabZxu33mWBAW4xycVz/AIFdSfEqrkbdeuhtZskfd56nGfwrrcCgCubGzY7mtLcnGMmJ en5UkunWMw/fWVtJzu+eJTzjGenpVmg9KAKq6bYpt22NqNvAxCvH6Uh0rTi/mf2fab+Pm8lc8dOc Vb6gUelAFY6fYlVH2G2wvKjyl4+nFOOn2Wwr9jt9rKFI8pcEDoOnSpzS4wKAIfslt5fli3h2Hqvl jB6dvwH5CmNY2bSeYbS3LkY3GJc49M49hVjvQfSgCsNNsFwFsbUY6YhXjjHpUi2tsgIFvCATkgIO TUvegUAMSGKMKEijUKMDCgYHpQIIVbcsMYJ6kIOen+A/Kn9aCT0osBE1tbsTut4iSQTlBzjp+VPa KN8Fo0JHQlQcf5yfzp1LgYoAZ5MW5G8pMocqdo+U4xx6ccUoVQCAoAPUAU6jvQA0ojOrsillztYj lc9celKAASQACevHWjigUAHU5wPyo/CjvRQAHkcgGiig0AIeQQQCO4IpaBQPpQAxIo4w+yNFDks2 1QMk9SfU04qrYYqpxyDiue8daw+g+C9Uv4f9csXlxdeGc7QeCDxnNW/C+jQ+HvDGn6VCoUQQgPju 55Y/mTQBqrsDEKFDD5iAPXv+lARN3+rTPH8I7Vgv4QsH8Zx+KPtF6LxIvKMQm/dMMYGV9snjOM81 wnxA8VaV/wAJloSJcTb9Hvs3yiKRdg3RnjjD8Z4GeKAPWiqnqoPpxRtDcFQec9K4f/hb/gkqSNTn 6nn7FNyPX7vuK1fGtla6j4M1K5Nuk8sVlLNbSDhkbYSGVuo6A8HtQB0mMfwjrnpTPJi+ceVH85y3 yj5vr61xPwptIP8AhCbO9NvGL2UyrJOVzI6+Y2AzHkjp1Nd1igCN4YpCweKNgw2tuUHI9D7cmnNG jgbkVsHIyBx2pe9GKAGiNAwYIoPqAKje0tZQwktoXBzkNGDnPWpj060UAMEEKnIhjB9Qo/z2H5Un 2eAKVEEYU4yNgqTmjvQAgRVGAi/lUQs7UAD7NCAOn7sf4fT8qnFJQBC1nbE5NtCc+sY/z2FIbG0Z NjWsBXJO0xLjJ6npVg0lAFb+z7LyxH9jt9g6L5S4HGOmPSk/szTwZCLC1zJy58lfn+vHNWs80dqA Kf8AZOm7Sp06z2nOR5C4Pb0pW0rTnDb7C0bd94GFTn68VboFAFJdH0vcWGm2YPqIF/wqFvDujJDI ItG04FgTj7MgBJHf5T/I1p96WgDivAGi6ZceAtFludNsZZmg3GRoVckknnJUHP8A+rmumfQ9IkRk fS7FkOSVa3Qg5GD2rF+HJ/4t5onzbsW+PpgkYPuOldTxigDOTQdGjfemkWCtnduW2QHPr0oGgaMs YjGkaeEyTtFsmOevGO9aPQ0UAUpNG0qRtz6ZZM27flrdCd3HPTrwOfalbSNMcENptmwPJBgU+3pV ztRQBR/sXSQWI0uyG4kn/R05JGD27imLoOjIMLpFgueuLZB/T2FaNJQBSOjaUwGdMsiBnGbdOM4B 7d8D8qBoulBcDS7IDJOPs6dTnJ6e5/Or1HWgDN/4R7RMAf2Np2BnA+yp3OT270q6Fo6NuXSbAH1F sgPXPp681o9qSgDPOg6O5BbSbBsdM2yHH6Un9gaNwP7IsMc8fZk79e1aNFAFFdD0hcFdKsQQSRi2 TjPXt3pqaBoyDCaRp6jJOBbIOT36VojpRSAzj4f0VirHR9PJXoTbJx+nsKafDmhMhQ6LpxQ9VNrH g/pWmaKBmemg6PGQU0mwUjOCLZBjPXt7D8qT+wtHC7f7IsNvHH2ZMcdO1aPUUe1MRS/sfSyysdNs 8qMKfIXgcdOPYflSHRdJIKnS7IqRgg26cj8qvjFJ3oAoroulIQV0yyBXOCLdBjP4Uo0jTBnGm2fP X9wv+HsKumq99e2+m2FxfXcnl21vG0sr7SdqgZJwOTQBAdE0lk2tpViVPUG3TH8qjbw5oZ3Z0XTT uJJzapyT17d68v07x7osHxM1XV7vXZBpFxbqlsX80x52x9ExkHKt2FdrZfE3wdqEzRW2txM6q7YM Ui5VVLMRlfQH64pDN46Do7bc6TYEKMLm2Tj6cUxfD+ioQV0fT1I6YtU/w9q8w03x9oUHxP1bVJdc mOjXFsiwu7SNFv2pnCdRyG7etd3pfxC8J6zqENhp2tQz3UxxHGEddxwTjJAGcA0CNJvDGgHGdC0z vjNnH369qRvC/h5l2toOllT2NnHj+VUdB8IpoGs6rqMeqX901+24Q3Uu5IuSePzx9OK5/UPBDx2d 1q2u+N/EcTIHnn+x3vkwRjGSEQg4HYc80AdSPB/hkNuHhzSAfX7DF/8AE0v/AAiHhnkf8I5pGG6j 7DFz/wCO+wrl/BXhGcXX9u3mq+IXhkw1pa3+oO0mzgh5QpAyf7nIAPOT09BNAGKfB/hjIY+G9HyO h+wxcf8AjtA8G+Fl6eGtGH0sIv8A4mtqloAxD4N8LEgnw1o/AwP9Bi4HX+7TT4K8Kf8AQsaKf+4f F/8AE1uUueaYGGPBvhZSCPDOjZHQ/YIv/iaP+EM8K8j/AIRnRuev+gRf/E1uUUAYn/CF+FP+hY0X /wAAIv8A4mm/8IV4TH/MsaL/AOC+L/4mt00EcUDMP/hC/Cp5/wCEY0X1/wCPCL/4mj/hC/CvA/4R jReOn+gRf/E1uUZwKBGGPBPhTp/wi+if+C+L/wCJpP8AhCvChPPhjRf/AAXxf/E1vUnPSgZh/wDC F+FM5/4RjRc9f+PCL/4mj/hC/CmMf8Ixov8A4ARf/E1uelJ3oEYn/CF+FQOPDGij/twi/wDiaP8A hC/CmP8AkWNF/wDACL/4mt09KSgZh/8ACFeFP+hY0X/wAi/+JrnPH3hfw/p/gTVruy0LSrW5hh3R yxWcSMh3DodvH+eld/XMfENivw+1phnIgyCOx3DB/DrQFyyngnwoqKv/AAjWjNxgk2EWT9flp3/C FeFP+hY0X/wAi/8Aia215RTzggdTk0p6UguYZ8F+FSST4Y0X/wAAIv8A4mk/4Qvwrn/kWNF/8AIv /ia3aSmF2Yf/AAhXhT/oWNF/8F8X/wATR/whfhU4/wCKY0X/AMAIv/ia3KBQF2YZ8F+FScnwxopP /XhF/wDE0f8ACFeFP+hY0X/wXxf/ABNbhooC7MP/AIQvwp/0LGi/+C+L/wCJo/4Qvwp/0K+i/wDg vi/+Jrd4pKAuzDPgrwoT/wAivon/AIL4v/iaP+EK8J4/5FfRP/BfF/8AE1uUY4oFcw/+EK8Kf9Cv on/gvi/+JoHgrwn/ANCvon/gvi/+Jrc7UDFAGGPBPhPt4X0X/wAAIv8A4mkbwR4TZSp8MaLg8cWE Q/8AZa3vWjHSgDC/4Qnwmef+EX0T/wAAIv8A4mmDwN4S37v+EX0bOCP+PGPH5Y9q6CjPNAGAPA/h IZx4X0bk5/48Yz/7LS/8IR4TBb/il9F56/6BF/8AE1vUHrQBgnwR4TKj/il9F/8AACL/AOJo/wCE J8J9/C+i/wDgBF/8TW99aSgDC/4QnwnnP/CL6J/4L4v/AImg+CfCZUj/AIRjRef+nCL/AOJreNJQ BgN4G8JM4c+GNHyAR/x5R4568Y9uvb8aP+EG8JZb/imNG+br/oMf6ccfhW/QaAOfTwN4SQADwxo/ H96yjPbHcUjeA/CLhs+GNI+brizjH5YHH4V0NHagDAPgbwkQR/wjGj/+AMf+FMPgPwhkn/hGNJ5G OLRP8K6KigDmz8P/AAexUnwzpXynIxbKP6c0o+H/AIPBc/8ACNaWSxJObZT+XpXRCloA57/hA/CP P/FM6T3/AOXRO/4e9N/4QDwg2c+G9MwTk/6OoroxR1oA5t/h74Pcgnw1pnrxbqPT0+n8/WkPw88H YIPhvTeep8kZ/Oul70ZFAXOZHw78HDgeHNPxnP8AqqaPhz4OTO3w7YjPHCH/ABrqBQaAOYb4d+Dm 5Ph3Twc5ysWD29PpSN8OPBrZz4csOevyf/X9q6eo7iOWa3aOG4e3dsfvUVWK884DAjOPUGiwHO/8 K68HHr4c08/WKj/hXXg/cxHh2xBbJO1CB6dAa5DwjZ6v4qn8Q2+oeLtdWK2vjGGgZbd2IyAR8vyD A+6ABnk81c8KaxrmmeO73wZrWoS6hAIGktbmTb5oXgjcw5OQT1ycgUgOiPw58HHj/hHbEc54Qg/o aX/hXXhDvoFoc+oP+Nc54cvdSm+Kes6JPqmpzWFhEHgjdwVHKH5mxlupHJPfPStC21W88W+M9X0o XN1aaTpBCP8AZHMbXEhJB3SAhlAw3C46fe6AmgGl/wAK68HjAHh+zAXkYB4/Whfh14Pjzt0C0Geu A3+Nc+NW1Hwb8QbfRr3Ubm90bVSi2a3DebJAx+XBkJBI3YHO44I5yDVnxHq+oXHxG0zw1b6jc29j c226dbMoshb94TlyCVG1B93B9OehoBr/APCufB+c/wDCPWY4xwCP60p+HXhDknQLRs9d24/1qO68 FN5CNpniLxBaXkXMcsmoyTozY/jjkLKw9sCs/wAFeNL6/wBXu/DXiGIJrNqz7ZUTakyqcdiQG5B9 CKLIDUHw68IbSp0G1K+hLEfzrnfGPhDw/o1hpdzp2k29vL/a1ou5CQSDJ06/55r0nrXL+Ojt03Sn 2F9usWRCev75R9O/enZAdQaKO9HegAoo7Ue9MA70H1oFBNIBaSig9aAEopRSd6YCijjNFAHNABRR mjjFAB9aSlo60AFFHejpSAOtGKSl70wA0Z6GigelIAPXil96TvR0xQAuaQ0CigAzQKB1o70AFKO9 FA70AOXpRQOlFIowPDykaBZdA3lDqK2YwQoHHTkisbw+d+g2YB/5ZKMVsxk5wc5FMgkoNHeloGNA pQOaPpQRQAppOoo9KM4oGHegjijvQaBAOnFBpMcUvegAxQaBQetACDrSkGm96dmgBT7UhA4oyKT0 FAB70dc0E4peKAExQADS0mOKAFFHU0gz60o9KAEpT1pKO9AB9KU0mfSimAUYo6ijvSAU9KQUvako A5HwIS0vih8qVOvXIGAc8bRyT/kV19cj4Fz/AMVNnp/b90APb5a609KACjnFAopgL7Uho7UGkAdq O1L60hzigAxRS0hzQAdaB16UvrRQAmKKM80daAFFGO9A4GaSgA7UtIKKADPzEY/GijtR3oAKSlFA oAO1GaKO9AB2ooooA4XxYH1rx34c0CJVdLdjql2r4K+Uh2rkHr83Fd3Xlt5ZfEKx8b6vrWkaLptw l1tgie5mBKwp0wA64yeSK0dJh+IGtaxZL4lgs9O021l+0t9hlw07LgpG2Hb5QTkjodvPuAegV5z8 SST4q8DqmPM/tIEEjOPnj9eP89K9G61wXxD8Oa3r2p+H30ddptZmaS5LqBByhDYPLYwTgA9KARdm nHi/xULKPzH0TSHLXTADy7i7UjbFyPmCcsR03bfStjxY8KeD9aM5IiNjMG2jnlCOPerOjaNZ6DpU Gm2KFYIRgFjlmJOSxPckkk1D4ngurrwrq9tYoz3ctnLHCqkAsxQgAEkY60Ac/wDCYN/wrnTyQBl5 SMenmNXbGuS8AaLrXh/w/Bp2qLYpHHvZVgdnfLNu+Y4VRjJGBuzxz69bQMQHHNLnOaQdaXtQIKQU vaigA4pKD3ooAWkoFBoAKDRRQACjrR2oFABR3o6fWgUAApSMjHajqaQnapPoO9AHKfDQq3w70cqT jy36gg/6xq6yua+HxJ+H+hE9fsaduvFdLQAfWikpetAC0mKKKACk60uelFAB2o7UUlAC9qSjtR3o AO1FFLQACigcUd6QB3o70UvrTGJiijnFHegAFKetApO9ABkc0josiFHUMjAhlYZBHoaX1ooEeW6a lpB8a/Epn8tLOKxEkgkVQgGyJiTkdByc1t+GLJNe12fxZLbtDaAfZ9KgaIIPKAwZsYzl8nB/u+vF Y8nhHUNa+J/iCS7hlt9EuIYllm2DN0oVP3ak5wMod2Owx3Br00KqIqKoVV4AAwAKQHl1jHaH436+ J1gW1hsAzrIg27QkWTg9B1Oa3/DVtFruuS+J0tVg05FMOmRmEIXB+/PjH8XQH+7n1rn77wlq2ufE 7XBKlza6LdwRR3FyvymaMKh8tGx3ZSD7Z9a9SVVRQqKFVRgADAA9KAFrz+7uh4x+Iv8AYolJ0rQ8 XF1Ht4nnH3AT6Ak8eqn2NegGvLL7TfE3gzxzqOvaTpcmr6XqLZlhjfMiknJGAMjDZwcEYPPrQB6m OaO9clok3iTXdYj1LVtObRtOtlf7PZi4LSzOeC0uMDaB0XHXnsK62gApaKKYBikxS0UAHpR3pKO9 ADu9B6Uneg9KBhScmlHWkBNAhaTFOHNJ3oAPT6UZzR0o7UAHajpzQelLnigBK5f4juE+Hut5KANb 7fnAIOWA79+a6iuU+JJx8O9ayxUGFRkDOfnXjHv0oGdLZ/8AHjb8k/ul5IwegqbtR6AUYoEHTrRR R1NACd6KWkoAKDRRigApe1JS9qAENL1pO9LnigBB0oxS9s0CgA9aOaOxooAPakNKvU0negBRwKQn mlApCOaAF70Zoo7UAFJRmigAo74oo70AB6UdqO1GOKACiijrQACjtQKO1AAKB1oooAOlLSd6KAD0 oNFJQAUo6Uhpw6UwPLvhrqtjD4k8U2c91FFc3N/JLDGzBQ6qz7tgz2/lirWlRP4n+LFx4gg+bS9K hNpBPsAWZyPm2t/EAWbkcdOayfhzaaXqF/r9rf6RDdRT37PAGsTNAgUtx5hUoMHoCc816xBBDawR 29vFHDDGu1I41CqoHQADgCkB5h4cy3x58SFcMv2YEuuRjiIbT2P4+nBHIKaZOnhD4u6pBqziC11o NLaXMku2JmLbtp3cbskr+X96otAvIrT43+JXkjuWEgW3XyoJJRvPlkZKqQowCcsRgV6je2NnqVo1 tf2kF1bsQWinjWRDjpkEEUAed+J7eLxb8R9AsrGVri20wtcX8lu25YiCGRGYHAYlcY64OaXWdK8U 3/j6w8R2+gRm2sVWNIZ7yNXcYbJIGQDlzj5v4RXoVjp9lptv9nsLO3tIc7vLt4ljXPTOAAOgH5Vy eseI7jw746KPZ6heaXc2Ubztbo832Vw7qHCDOFI+9gZOAe3IB2MUjSwxu8TwsygmNyCy+xwSM/Qm vItbYn49aeLQM8oMPnKrcj5DuJx6Jg889fWu2k+IegvDnT2u9TusfJa2dnK0hPYEFRtz6tj1rO8H eEL+LXr7xV4hjiTVrtiYreJ94tkP8JYAAtgBepGB15oA7yuT+IWf7CsEUEltWsh0zj98vpz+VdYO lcj8QlQ6TpRcAgazZHk8D96OvtQB131pKceTTcUAHajFLzig0wAdaDSUpoAB70UdqKADvRRR3pAG KKBRQAd8UUCkzTAUUlL2oNACClpKWgBO1LRkYNGe/WgA70Unel7UAGOaO1GKOlIBaSlpKAAdqO9L SDrQApoFB7UdAaAHL0opFGF65opFGD4bUjQbIZwfLH862xj0rF8Oj/iSWYORiNcZFbSjnNMgdSA0 tJQMd7UcUlBNABQOlHOBRQAd6Q0H1pTgigAHSjvQBRwKAA0dqTvSnFACZ5oPFHeg0wClz0opD2pA KP1pD1pRxR3oAQUuetIBzRQAfyo60DrQDQAEgdqKD70UAAzS9e9IO9LxQAUnejtRjBNABRRRQB5/ 4V1+z0ubxDbTWupux1u7fNrps86Abh/FGhGeOme9dD/wmOnAZNnrg/7gl3/8aql4EYtH4jyWz/b1 4OTx94Yx7YrrcmgDnh4y04hSLHXSDg5GiXf/AMbpn/CbaYJRF9h13dtDMP7FuvlB9R5eex/Kukzx SdaAOfHjHTiRmx11c45OiXfH/kOk/wCEz07H/Hhr3UYP9iXfzfT93XQ/ypT2oA5z/hNdMKgrZa4+ eoXRbrgep/d0q+NNPZM/2fr3A6f2LdZ+n+rroqPpQBzreNNNVcmy10f9wW76+n+rpIvGthISG0zx BFjGN+i3Rz+SGuj7ijvQBzo8ZacSAbHXQScc6Jd//G6B4z08rn+ztfBzjB0S6z/6LroqTmgDnW8Z 2AOBpviA+40S6/8AjdJ/wmliVz/ZfiEHI+X+xbnPP/AO1dJ360negDnR40sSoJ0zxCDjODot1ke3 3KG8aWI6aV4hPOONFufz+5XRZpTQBzP/AAm9njP9j+I+nT+xbj8vuUw+OLQKW/sPxKTnoNGnz06/ d/CuoBpaB6HKnx1bCRV/sDxOQRksNGmwPbpn9Kb/AMJ7bq+P+Ed8UkY+8NGmx/Kuro70COUPj22z /wAi74oPuNHm/wAKP+E8tsA/8I74oyQCR/Y03Ht07V1VL24oA5MePbcn/kXPFOPX+x5eP0pE8fQs wB8NeKlB6k6PLx/X8q63tSUAcoPHtudv/FOeKQScHOjy/L9ePwpV8eW5YqfDvigDGdx0eXB9uma6 ottBYnAAyT6VDZX1rqNot1ZXMVzbuSFlicMpwcHBHuDQBzp8dWw5/sDxMfpo03+H+cUq+ObVs50P xKuPXRp+ecf3fxrpnkSJGkkdURerMcAfjWdZ+I9C1C5+z2Ot6bdT/wDPOC7R2/IHNA9DLXxvaFgD oviQAkDJ0afj3+7QPHFp5gX+w/EuCfvf2NPgcf7ufat839mL8WDXduLwp5gtzKvmFM43bc5xkHmn XV5bWFs9zeXMNvbp96WaQIi/UngUBoc//wAJvZ8E6N4jHGTnRrjj6/LQPG9lv2/2P4jHudFuP/ia 3rK/s9Sthc2F5BdwEkCWCUSKSOoyDilub60syn2q7gg3nC+bIE3fTJ5oFoYI8a2Rx/xKPEQzjg6L cf8AxFC+NrJuuj+I0+ui3HoD2T3x+B9s7dtqmn3kpitb+1nkUElIplZgAcE4B9eKt5oHoc2njSxY qG0vxCgPdtFuePySiTxrZImV0nxFIeeF0W5z090HX+tdIOtGeKAObPjWxC5Gk+IjxnA0W5/L7n4U 5PGemNx9i10NnlTot3kf+Q/cV0R6daTPFAjnv+Ez04tj7Br2f+wLden/AFzpreNdPETuNO18lP4R ot1k/wDjmPzxXR0UAc2PGtgPvaZ4gUZ5J0W5wBjr9zp2p/8Awmen8Y07XyD3GiXX5/6uuhzR3oA5 0eNtMKKzWOupuGcNot1/8bpzeMtLCgm11sZ6Z0W79M/8866DvR2oA54eM9MYhVtNbOe40W7I/wDR dA8aaWSwNrrYA7nRbvBH/fv3FdDjnNFAHPf8JrpW4j7NrXHU/wBi3eF6df3fvTB460faS0GsqRnI Oj3WeM/9M/Yn/JrpKATQBzr+ONFiUNIurKpOAW0e7A/9FUL450R2KoNULgcr/ZF3kfX937j8x610 QpaBnn3gvxlo1p4M0i2lF6ssNoiusWmXLqCAM/MsZB6j8x61tSePtBjk8s/2nvzggaTdZB9DmOpP AUvneAtBfOdtlGmTnI2jbjn6V0f40Ac2vjvQXKbW1I7jhf8AiU3fP/kOlHjnRW3YTVjtGWxo93wP U/uq6Pv1pc0Ac0fHWh4U41XDdD/Y93g9On7r3H50reONEQkONVQjqG0e7H/tP2rozzR1zQBzR8d6 CADu1LDZx/xKbvnH/bP2P5Uf8J3oO1ju1LCglv8AiU3Xy9Ov7vjqPzrpcmjNAjnD460JEVmOpgMM rnSbrngH/nn6EfnTG8e6AucvqIwSDnSbrjHXP7uumozxQBy7fEDw8kRcyaiVAJ40q67e/l4p3/Ce aASwD6l8vJ/4lN3wP+/ddL75oyc0Acz/AMJ94fGMy6hzgj/iVXXPAIx+79CKVvHmho7Kw1UFeudI uhjv/wA866Xmj0oA5w+O9CBAJ1MbgSM6Td8gcn/lnTR4+8PEMwl1Aqo3Mf7KuuBnGT+76cj866bt RznvSA5h/iB4djx5k98hxnDaZcg4PQ/6vvnj1p3/AAnvh9d+ZNQXZncDpd1kYOD/AMs/cV0v40vN Azmf+E+8PnpJqJG0tkaVddBnJ/1fsfyNH/Ce6AC679RDRjc4Ok3WVAOOR5fHPFdNk0mfegDmv+E9 8Pl1XzNRLNjao0q6yc9Mfu6cfHWhfNk6mNhwwOkXfH1/d10YNGeaAOa/4T3QAMl9SCnkMdJusHr/ ANM/Y0o8daEQ5B1MhPvY0i7OOcf88vWuiEiM5VZFLDqAeRTsmmBzTePNAThpNRUjsdKuh6H/AJ5+ 4pD498PgkGW/BHJzpd1wOv8AzzrovtVuBzcRDnby46+n60vmoWC+YpbPQNzSA5qT4g+HIlJae+HX H/EsuRnGemY/Y/lS/wDCwfDm1ibm7Xbndu064GMY6/u/cV0Vxcw2sLz3M8cMKDLySOFVR6kngVIr B0DKwZSMgg5BFGojmT8QPDfmbftl1kDP/IPuP/jfuKQ/ELwyDhr25U4yQ1hcDb9fk4rpFnjkZ0jl R2jOHVWBKn0PpQ08avsaVA390sAaNQObX4heGGAIv5hnoDZTjP8A45QPiH4YP/L9P0zzYz9PX7nv XSRTxzKWilWRQSpKMCAR1HFSc56mgDl2+IfhdFJbUZAQM82kw/8AZP0pzeP/AAwjFW1F1YHBDWsw x/45XSkn1NLk0wOYHxC8LEnbqbEKAzEWsxAB9Ts4pf8AhYPhcbs6mflOD/o0vH1+X3H5102cUZPP JoA5kfEDwvvC/wBpksTwPs0v/wATQ3xB8LBiDqoBBwQYJfr/AHfSumz70A+9AHMn4heFlBZtUIUD JY20oH57cUf8LB8LEkf2suRgkCGTIzjHG33FdPk0c+tIZzC/EPwowyNXQjOP9TJ/8T70h+IXhRSV bV1Uj+9DIvv3WunzzijNMRzP/Cw/CYBzrUIA7+W+P/Qff8+KQ/ETwluK/wBtw7hnK7Hzx7bfeuoz Sd898UgOYPxD8Jq206zGGxnHlSZ7f7PuKQ/ETwkpIbW4AR1BR89/b2P5V1OelIM0Acw3xD8JAZbX LdeM/Mrjjp6e1B+InhEJuOuW+MZ+63Tjnp05FdRk4pM470wOXHxG8Ic5162BAJ5DDgfhXP8Ajvxt 4b1LwTq1nY65bSXTxgIiOQSQ49BntXpGa5f4jZPw/wBXA4PlLg4zj515oDUd/wALE8If9B+0Hrkn j9KD8Q/CA3A6/ZgqcMNxyPwx710+cjPPr6UnQH3oDU5n/hYfhBuniGxOe4fik/4WL4PAJ/4SCywP 9o/4V0+eOtHfPfGKAOZPxE8IAAt4hsgDnBLnB+nHPQ0g+Ing/Bx4isTjrh8/0rp++KSgDmR8Q/B7 NtHiKxJPYPSf8LF8H4J/4SGyGOoLEEfhiunGB04o7+maAOa/4WH4QABPiGxXPTc+P5j2NH/Cw/B+ Cf8AhItPI65Eua6XuT60uaAOZPxC8H5H/FSabycD98KP+FieDSm8eJNOxx/y2Gfy6103TpSAAbiF A3ckgdTQBzg+IHhA4/4qPTvm6fvxz7/Tg80p+IHhAbv+Kl0vA64uVP8AWuiAAHFGB6D8qBnPDx94 QLBR4m0ok5I/0pO3405PHnhGRQy+J9IxnHzXkan8ia3yAWBwMjocdKRURC21FXedzYGMn1NAGD/w nXhELu/4SfR8HH/L7H3/ABpf+E48Jbsf8JRo3/gdH/8AFVu7ELKdi5XIBx0z1pRjB4Az1460AYTe OfCSgsfE+jYxni+jJ/Q01/HfhFCc+J9HPBPF7Gf5Gt/g4BA/KkCIoChFAAwAB0oAwf8AhO/CIYj/ AISbSM8j/j8j/wAaQ+PPCKjnxNpB5xxdof69PeuhAAwAAMcdOlIVVs5UHPByKQHNH4heDtxX/hJd MyMj/j4XHAz1/wA+lSr468JMOPE+kdO95GP5mp/FHiCDw3pBvJLdrmeSRYba3TG6WVvugZ/MnnAB ODVnR7S/trHGqXaXN3J80gijCRRn+5GOu0c8tknvQBR/4TnwkTj/AISfRsgZ/wCP6P8Axpp8d+ER nPifSPl64vIz/Wt5okblo1P1UUu0DsPrimBgf8J34S2hv+En0fBBP/H7Hn+dP/4TfwnjP/CUaLj/ AK/4v/iq2Xghc5eKNjkN8yg8jGD9RgflSPa28m4vbwtuOW3IDk4A5/AD8qBGP/wm/hPt4o0X/wAD 4v8A4qj/AITbwnjH/CUaJ/4MIv8A4qtYWdsMYtoflUqMRjgHqOnQ0/yoUwfLjU/dztA/CgDG/wCE 18Kf9DRon/gwi/8AiqX/AITXwmP+Zo0X/wAGEX/xVa/kQlt3kxkkg52DOaU28O4sYYyTnJ2DnOM/ yFAGP/wmvhT/AKGjRP8AwYRf/FUf8Jr4T/6GjRP/AAYRf/FVrNZ2z7N9tC2w5XMYO0+3HFQahp/2 q3YW7RW9yPuTGBZNvIJBB6g456fUHmgDPPjXwmMD/hKNF5P/AD/xf/FUv/Ca+FP+ho0X/wAGEX/x VVvD+o2Gpz3ml3lhZ2+sadJtuLZUXBGAVlQddjAjGeR0PYnbOm2DEsbG1JPcwr/hQBm/8Jp4T/6G jRP/AAYRf/FUn/Ca+FP+ho0X/wAGEX/xVaa6ZYAACwtQBnGIV4z17e5psmkadIRv060YjpugU44x 6elAGd/wmnhT/oaNE/8ABhF/8VSjxr4UH/M0aJ/4MIv/AIqtEaVp65I0+0Gc5xAvfr29hQ2ladIW ZtPtGZxhiYFORnODxTAzv+E18JgYHijRMf8AYQi/+Ko/4TTwp/0M+i/+B8X/AMVXHePp59J8U+GL Ozuo7azv5xDND9kgcKDIgJUupIyHYHHTrXe2+h6Zb2kdsthbNHGgQboUJIHrx+NICl/wmnhQdPE+ ic/9RCL/AOKo/wCE18KdP+En0X/wYRf/ABVcV8QYn0fxP4Yg0v7PapqV15UwFlbsABJFgqXTg/MT 17D0r0IaDpO0eZptnK2CC8luhYjOeeP84oApDxp4Ux/yM+i/+DCL/wCKo/4TXwp/0NGi/wDgwi/+ KrQk0XS5UCS6ZZOgBAVrdCADnI6e5/M1EPD2iAMo0bTgGwGH2VOcHIzx680AVf8AhNfCn/Q0aL/4 MIv/AIqk/wCE18J4/wCRo0TP/YQi/wDiquf8I9o28P8A2Np+4HIb7KmRj8PYUxvDeguWL6JprFup NpGc9Dzx7D8hQBXHjXwmf+Zo0T/wYRf/ABVc94s8R6HqcGjwabrOm3s41izbyra6jkfHmjnAJPp+ FdadA0bYq/2Rp+1FKKPsyYUHOQOOhyfzNcx410rTLG00qe306zhd9asg7R26rvBlGQxA6GgDt+9J S0UwDqKSlPSjNACUUveg0AFFA5opALSGjtmjNABR3o7Ug60AKKMUZozQAYoOKM0UAHSj3oFBoAKD SUvWmAUCilGKQCd6XrR3ozxQACkPWgUtAAO1J3pe9IevFAAeKXqDikPFHbFAD16UUL0opFGB4ef/ AIkFlxg+UowRW0hyo+lYPh35dBsuvES85zW8nQdfxpkDxwaKSg0DDtQOlHelGKAA80DPOfWg9qSg BTSHpQaKAAUtJmjNADu9JxR6UhoAKUikpT0oAOgpPSlNJ6UAHFL3NJigdaAAdaXk0Cj6UAFJ0oxS 0AJnrRRilxQAgoJzRRTAO1GOaX1pOtIBccUGg+lA6UAcj4EJJ8SM8bo7a3OWUvuwcJxXW1x/gF1k fxOVaM/8T25J25/2cZ/AdR/SuxxxihAIKPxoHSjtQAY59qDRQe1MBego7CkPSj0pAGaO1LSGgBcU ncUue9A60AJRzmjvRnJoAU0g6UZPNLmgBOtHSijrQAUCigUAFFFJ0oAUUUUnegDl/iJqMun+Cb5L beby8AsrZY87mkkO0AY78mtvRtNi0fRLHTYQAlrAkQx3wME/icmuX12Fdc+JegWAkZotLik1G4jB wA2QsRPY87veu2JA6kDnHNAHneryR658WrXQdUkWTS7eyM6WUq5iuZj/AHlPDlRk98Y7c11D+DvD kmrQaodFs1voHDxzRxhCGHQnbgE/XNch8TNDtb7V9FksLqa08S3M3kWkkUmwMq8szkcgKCeRzzj6 d5o9hdadYiG81W51KbOWnuFRT0AwAijjjPOTz1NAFKTwjo0nilPErWzf2pGmwSiRgOhGSucE4OK5 eO6fxL8YJbK5J+xaBEZYIShAaYhRvYHqRv8AlPtx1yfRK8w8Jo6fGjxUZIvJJhJCEklgWTDc+vX0 5oAn1yQ+Ffiro13aNHb2OtKYb2FAAJJAcBzxgHLpyDk4rrPGVrHeeDNYgkgWUG0kwpTdztPIHqPW uQ+JCC48Y+DLZRKsrXRKyxnBX54/Y+56HpXY+MnKeCtdIz/x4T5x1xsOSORSAwvhMif8K9sJBHGH Z5tzKuM/vGH9P0rt64r4TqR8OdPyMZeYgYxx5jfnXa9+lMBeho7Ud6QGgAxQMUv40ZoASijPaloA TFA60YoNAC0nSgUUAHaijtRQAUtApKADvS8AHPpR3pCwUFjwAMmgDl/hvx8PdG+Vh+5P3iD/ABHp jt6e1dTiuX+HSyJ8PdFEqkMbfcMrtypYlTj3BBz36109AC8elLSUUAKcUhoNFAB0GaTvQaKAFpMU DOKXtQAUlA6UUAFFFFAC9qB1oFFABS0UlIYo6UnelzxTfWmAoFVdU1CPSdLutQljlkjtomlZIlBd gBnCgkZP41bFBpAeF6D4z03SviH4i1o2GrSwXyApFFb5lU5XJZN3Htn9M4r0DR/iNYeIdVTSbPT9 VtL2WN3Rry3VFUKPvH58ntwPWuc8P6pDpXxL8d6jfuI7S1jDyOATgDGOnBJA6HnPTvXZeGbO7upZ /EOrW3kajejy4oW5NvbKTsTqcMc7mweSR6DAByOq/DfwL4d0VbvVLC41K9YhF/0qRZr2ZsAKqhwC SecDoM+lbXgP4f2HhmE6jPYRRatOWYgP5gtlJOI0Y+gwC3UnPOKpeG75PGPxG1nUJ9slroeLaxib kK7Fg8oHYnZjPoa9EOM4zz6UCOL+I7m+sNM8MxkB9bvUhfkgiFCHkI/ID8a7KKNIYkiiXbGihVHo B0rjLAjXPinqF8MvaaLaLaRN/D575ZyOeoU7Tx/Su160Ac9oXgzS/Dutanqli9152oHdKksgZFOS fl4z1J6k1xvxvsrY+G7O6FpCbk3YQz+WN+PLfjOM44/SvVK8z+NzAeEbJTnm9HI6j5H96AO60Oyt bHRbOO0t44EMKEqkapk7RyQOM1o1T0n/AJA1jzu/0ePnPX5RVzPNMApT0pKU0AFA60Ud6ACjPNH4 UHrQAppMUdDQaBh1pKd3pO1Ago70dqPxoAKO1FHagAPSkxS84oxigAx71yvxJ/5J1rXBP7kdBkj5 15/rXVda5b4jyPF8OtbZASxg2/KexYA/oaAOmiH7mMHb90fdOR07U/FMiXZBGu4thQMlsk8dc96d 2oAXAoIpBSnrQAnegUd6WgBKKKWgAoopAaADvS9RRRQAdjSZ4pfeigA6jNFFBPegAFJjmlzSd6AF H0ooBoNAAKOtLmkoA8z8TXI1T4v+HNIdi1taHz2TGR5ux2GQeDgKv0ya3/iPaW8/gfUriaBHmt4t 8Mm3LRtkcqRyK57xOq6Z8Z/DWoOAkd1GYd5yAz4ZOTjk4kX9K7bxVYS6p4T1axg3edPayIgXqW2n A/HpSA4rR9I0+T4KPObOE3D6fLM07qPMMih9rF+uR2PUCtv4ZWNtB4J0+6jg23F0heWVyWd/mOPm PbHQdK5DTPEd2vw1n8OQ+G9ck1COznjnaS1MccIO4klm5J2nIUAkkYrR0XXNS034VxW0ejayuo+U 1vbMLJzkuxAkwoLAKGDEkDP8OTnAMgTxFeW/xUtNUuyyaNqjS6Zanf8AKfLbaH645c8dyDmq+oeJ NSt/iTZeIXjlGgvcPpET4wjKCNz5PUb8kHuE9jWl4y0K3X4YadpmlQalLLZ+XJZ+VZStKzLwxdQu UJ3E8gc/pU1W2hv/AIL2llFpeqwX1ikKpapYTCVZwPm+UrkqQWOenPXNAG38WrAT+Cbu9a7uYjah NsSSbY2ZpUXcwHLEDOMnAznGcEcVr2g2v/CstJ1OXU9Tudfnjtn0+3kuyzfwApFEvBwuGJxuyMk1 1uopqPjD4S3Fi1rerq6wRGeG4tXheSRGVuBIBndt7Z6+tYVhqC6d4QszoOmPJ41EcVs8dzYzPNEo YBgd4+RAMdwvT2oA7ySylv8A4fxpr8AmvlsPMn8xRuWYR8kY6EHPIrhfB2mRXXwivNTeS+h1FUuZ PtkdzJHL8m7aocNkpwPl6ZB471t6n43v4pL7w7P4fv7nURZAG4tYT9naRo8ucnlUGevJ/Ss7wPNc W/wl1GxuNN1GDybS6kEtzb+WjAgkBcnLZz6dj7ZYir4A8F6Z4l8GST6nJfvctPLHHKt6+2Hn70YB x353Zzj04rf+GGpamy6voGq3L3M2kTLEsr/McEuMFup+7kZ7EVkfDLxPYaP4IS2vEu0mWWR4kWyk Y3GWONhUHzDnKnuCMHgAnqPA2j3lt/aet6lC9teavcGb7K3WCMFtitxy3zHP4dOaQGN4jlOmfGjw 3cxhAL63a3kI2gtyw5OQe645/h4BIxXpFeZeKoDq3xk8MWUTRkWcRuZPkDbcMWwfThRj03A+lemM dqlsE4GcDqaYHn/xetI08HS6rEJY761eMJPE5RgpYAgkEZHOR7496fb6BeX3h7QdIsJbux065sxP qWoW0uy4d/LUKoZsnLHJb5egxxmud8aeL5vFvgm8tbHw9qsEsd0iTrdWx3LhxtCgZy5OMr2G72Jt a9c+KrDwloF7oJ1O3tbOFLW/tltAszjagDpG6Fhj5gSeQcHBGTQBn+ItE1P4Y3tpr2i6xe3WnPLs uoL2437ickgjABG0HB6g/Wt3Vrz/AIS34pR+FnuJ00mwtTcXMUM20XTkKQrFTkqA68cdD7VR1iw/ 4TCwt9L0fW9b1EXEyPcG+gX7Pbopyd5MS4fnAUEk4B96Z4qjv/BvxQj8U2em3V7p95DtuxbxE7cL tZcgHHCowz1IIyKQyv490Sy0Pxr4QbTYVghuL0FrcE+UpWWLLBSdqkggcDnHsK3/ABDqE/iL4iWn g8T3Vpp8MX2m7MDmN7g7chQwOdmCM+pPtXOeM9auPE2veGL3T9H1NrC2uTKpNo3mzANE7MseCdmA AGOATu7DNW/F41Tw148sPG9np1zc2FxEi3cKxt5kXAQhgDgHaRjPGQQfWgQfEDRrDSvF3g82EItl udRQGFGxCCJI+QmMKTu5wOeMjjNb/ii+n1bx5pPhKK7mgs5Imu71raYxyMAG2x7lOQpxyO+Rz2rk fGniSbxNq3hfUNJ0XVXtbO982N3tG33BUozbEAyVULyxxzkdia3fGFteaV4v0XxtZaTcT2qgR30M MX74DDAOVUZJ2sRycfKoOKAF8cWj+BhZ+JPDe60jWZYLuyViLeVCDglMhQeCMjH3q6u+jv8AxHHY rZXcllo9xAJ7ieCXZcPnBSONlJ2jruPXkBT1I5nxpfR+ONOs9A8PB7s3Nyj3F0sTeVaIvzfvGx8r njCkZ4PTiu+sLaHT7K206F8rbQJGoZsttUbQT+VMDn5/h7oEsX7lb61uAMLdW9/MswOOu4scnoec 9KxfBXibULbxLfeDdeuGuLm1dhZ3Un35o15AY5yW2kNnv83JxXoVeR6iLif9oGzSArujRGYrk7UE R3ZwOPvY/EUAeu9q5H4hMi6VpG52XOtWQypwf9aO/b1/CuuFcj8RGC6JpvTnV7MAnHH70Hv/AEoA 672ooPWigA4xQe1JS/zpgAo4IBFA60GkACiig0AFHUUdaBTAOtFBo70gE96XNFFMAoopO9AB3paM migAoPBoxk0HrSAO5oFHegUAHelpD1ozxQAtJQKKAAUvek9KUdSKAE60Y60EYooAev3aKF6UUijn fDvOhWI7eWK3UB7msHw2MaJYn/pkMDOa3h1pkDsfMDk9OlL3pO9L1oGGKKOaOaAF7U3ilx+VHQ0A FHrQaXtQAgAxSdTSjpRQAtNNL2pKAD6UE0Z5ooAU0mO9KetJmgA9qB1opaADoKORQOmKSgBe9Hfi ijFACUpoyMYpD1oAO9L2pOtL3oASj1pTwKKAE6j3opaTFAHJeBI1RfELKrIp1u5AXbtAAIAwMDt9 enrmutzzXA+FtZu7KPV0i8N6ndrJrF4/nWrQbDmQ/wB+RTkdOmMjrW1/wk+pNFvTwZrpBUMoZrZT j3HncH26+wpAdKOKTtXOL4l1M4/4o3XPfD2vv6ze1MXxRqjEqfBeuArt3fPbd+uP3vP+elMDpuKW udXxLfkZ/wCEP18Dtn7L/LzqbF4pvpUVl8HeIRuXdhhbL/OYYPt1ouB0Z6Up6VzjeJtQ25XwdrxO e5tR3wf+W3+fpzTf+Eo1Mybf+EM1zqACXtuR3/5a4ouB0vI+lIa5uXxRqMS7v+EN14gEZwbY8fQT En6U8eJdSbA/4Q7XQdu4/Pa4H/kegDoicHpSVzq+J9RMe5vBuvDjkZtf/j1Mh8TarNk/8IXrajPG 6S1U4+hmFFwOm4oNcwfE+r4BHgrWj3P7224/8i+tPPiTWSse3wXrBcjJzPagA4OefN9cdcUXA6Tt SEYFc3/wkur+YEbwXrOcA8TWpGO/Pm4znHHpzSr4j1k8P4L1ccZO24tD+X74ZouFjo+9Heua/wCE j1ssMeCdWx1JN1aD/wBq/WkbxJrocKngjVDnubu1Hbn/AJa/5/SgLHTUVzY8Q69jnwRqef8Ar8tP T/rr601fEXiDzAJPA+pKmeq3toT+Xm/1oHY6YdaDXLN4l8QiTavgXUiOOTe2o5/7+U4+IvEWBjwN qBPfN9a//HKBWOnpK5pPEXiE43+B9RX/AHb21Pr/ANNB7fn+YviLxDv+fwPqIXI5W9tSceuPM/z6 0BY5u68N/EG38V6vq+jXfh6EX7qv78yMwiTIQf6vg4PPJGa0dH0Dxnda9aXnivVbCWzsw0kVtYMQ Gm6KzAouQAW79cetaTeIvEQ+74H1FvTN9aj/ANqUjeI/EQXjwNqRPob61H/tSiwFHx14R1TW77TN Z0K8it9V05iYxOx2MCQfRsHjHTkHk8CreiWXi69vIbzxNeWdrHAd0djpe8LI2CMysxJYckhRx0J6 VKfEPiDaf+KI1LdngfbbTB49fM9aE8Ra+W+fwPqar6re2pP/AKNFAHTVymreHr228UQ+KNBWJrwx /Z761lbYt1F2w2DtcEDB6HGDUv8Awkevbv8AkSNU245P2u1z/wCjfXP+TSnxDroA/wCKJ1TJ/wCn u09P+uvrQFiCw8PXmoeKx4m11Io5bdDFp1jG/mC3U/edmwAXbngcAY5PbX8TWM+p+F9VsbVI3uLi 1kiiWQ4UsVIGfxxWf/wkWv4OPBGp5HT/AEy05/8AItH/AAkWvb8f8ITqew9CLu1znHp5vr70DsJ4 F0DVPDPh2DTNQvLSYRbii28LLsLMWILE/NyT/CtdPXKxeKdblHHgfWAdxB3T2y8YHrIM8/57CYeI tZZSR4L1fIHQ3FqPm7j/AFvT3/SgVjo+9LXNr4j1luvgrVwf+vi06f8Af6kTxJrbbWbwTq4jPUi5 tSw/DzRRcLHSnikzXPDxFrBIz4M1cDOM/aLT/wCPetJ/wkuphQf+EO1zJXIAe19P+u3+fSi4HRGg iuaHinUnVNvgzXSXOME26gcHOcy8dOpxnj1FDeJ9WW5WL/hC9aIbo3m2x9e/m7R07mgDpRmlrm/+ Ej1ndj/hC9X9/wDSLX8P+WtN/wCEo1QiUr4L107Rgbnthk/9/unTkZoA6bFJXNr4p1AttPg3Xww2 5x9mxyM9fO56f44po8Vai0uz/hDNfxuxn/R+nr/rcdf/ANdFwOmPSiubXxVfMBjwd4hAzj5ltgc8 /wDTbpx1+nrTT4sv1CMfBniHYwPRbckEe3m+x6+3rQB01HeuZ/4S276/8Id4jxkj/VQdv+2tJ/wm F0FLHwd4kABx/qYCenoJc0AdPQxChixAAHJPauYfxhdR53eDfEpwM/LDAf5S1G/jS6aJyngzxMWK EjNvCP5yf0oGWPh8EHw/0IJnb9kTsBk9zx2rpM1574V8UzWPhDRrQeFdfnEdlAqzW9vEY5PkByp8 zp7nH4dK2B40uDnHg7xPwcc20Qzxn/nrQI6o0A5Fcr/wmlxnB8G+J/8AwGh9/wDpr7fyp48X3ZQN /wAIb4kwef8AVW+fy86gZ1BPpSZxXLDxnclyn/CHeJtw7/Z4cHp0Pm+9KfGNyoJPg3xLgH/nhAe3 tLQB1AoPtXLjxhcbSf8AhD/EoxnjyIfb/pr7/ofSgeMLlsY8HeJcEZ5ghHbPeWgDqKK5P/hNrgdf Bvij8LWL0z/z1p3/AAmlwTj/AIQ7xPk/9O0X/wAd9qAOpHSjvXJjxtcnZjwb4nwxwc20QI9P+WlP bxlcrJs/4Q7xMSRuyLeHH5+b19qBWOqpK5Y+NLhcj/hDvE5PHS2i7/8AbWnHxhdKf+RO8S/9+IP/ AI7QFjqBQK5YeM7jZv8A+EO8TYJPH2eHP5ebQ3jO4U4/4Q7xMT7W8J/9q0DOpPWlrkj42mH/ADJ3 ignAbAtI+/8A206+1O/4TW4wSPB3icgHH/HtF/8AHaQHVe9HauWXxncyJlPBviXcRkBoIV+mcyUj eM7pW58G+JiNm7iCE+//AD1/TrTA6sUh61zB8X3S/wDMn+JD9IYP/jvvSjxfdM5X/hD/ABJx/EYY AD/5FoA5u28BX998R9W1XU1WPR3mSZIlkDG6ZQNocc4QEE44ycV6V71zP/CW3fAHg7xHk/8ATO3/ APj1J/wl12FZj4O8RgKM/wCqgJPGf+etAHNS+GvGfhbxFe3/AIVks73Tb2VpX0+6lKiNmO5to4A9 AQe/I4rqND03WXvpdb19rYai0RggtLVz5MERIbBJGS5IGW6cDApjeLrtASfBviTg/wAMVuf5TU3/ AITK5xn/AIQ7xN1x/wAe8P1/560WA5PRtO+J+hxXYtLHw+7XVy1zM1zI7u7sBk5VlGOMYwK6fwva eLJ9WuNS8WNaRPHEIbW1sXPkjJy7sCSS3CgHPAz605vGtwFZh4M8T8A/8u0XOMf9Nff+fpSN43mV N3/CG+KSMZ4tIyfXp5lIDra4j4neHdV8TaDZ2OkwxySi7V5DJIECptYE5698cZ61Ybx5IoJPg3xX wcYFgh9fSSj/AITxtoLeD/Fa57f2epI49nNAjf0e31C206KLUpbSSZFCgWkToigADHzMxP14q/XI L49ZmAHg/wAWc9zpwA7er+9B8fZAI8IeLDnt/ZvTp/te/wChpgdfSmuQPj9FiLnwp4ryDjYNKYno Tnrjtimr8QFbO7wl4tQDPJ0on+RNIDsT14o71x3/AAsBd4A8J+LCOef7KbHAz69+lPbx/GDgeF/F TdORpLjt7mmB1xo6VyDfECIIT/wi3issD90aS+Tx9ce1OTx9C7MG8MeKowpxltJkOevIxnjigDrT 2orkX8fxKSB4X8VtgE/LpL8+3NOfx7Ahbb4b8UyYGfl0iUZ498UhnWDk0c1yJ8fxCPcPDHiot/cG kvn/AA/Wnjx3AWIPhzxQvJGTpEvOO/ApgdZSVyT+PoFAx4a8UtkE8aRJx045+v6UrePYFDFfDnih 2AyFGkSAtxnjOBSA6z1FArkx4+t8ZPhzxSOcYOjy+gOenvj8PTmkTx9CxwfDPipfvcnSJOwyOnr0 H15xTA62jtXInx/CEBPhnxUSc8DSJM1K3jq2GceH/EzY9NHm5/MUAdSa5L4mts+G+tnIH7peT/vr St48t0B/4pzxQSDjA0iU/wBKwPG/jC3v/BmoW66Vr1pI3l7ZLrTJo0BEiH72MAntk8njvQB6X9et BrlW8eWwJx4e8TE5IwNHmPf1xiiTx1bISF8P+J5ABnK6PMP5gUgOqHSjvXLnxxag4/sPxJ7f8Seb nj/dpo8d2zNj+wPEw4JydHm7dunemFmdV3pK5X/hO7fcoHh7xOc5yf7Hl+XA78fhxSt47tVheQ6F 4l+QE7f7HmBIH1GOfr+VAWZ1WKK5keNbQgk6P4iBHb+xrg9vZfwpo8cWe7adG8Rg88f2POen0X8K QWZ1HtSGuWHju08xUOheJQzAkA6RN269vcfnT/8AhN7TnGieJDg/9Aaf0Bz933/Si4WZ0xpeormD 43sgzr/Y/iIlT20a45+ny1J/wmlipYNpevrj/qD3Bz27J9evpQI6PPFIDXNL43sTkHSvEC/3c6Nc fN7jCfzxR/wnFjlh/ZXiHjOP+JNcfMAcZHyUwOm9aQiucPjWxAY/2X4hOOmNFuf/AIj/ADig+NrD H/IM8QHtxotz/wDEfX8qLgdIOhpK50+NbAdNN1884wNGuc/ls+lLJ4z02M4FhrrfTRbofzjFFwOi 6Uelc4/jXTI13tZ64EGcsdFugAADz/q/annxlpu4r9i1zIz00W7/APjdAHQUnaucfxtp6cf2dr5O CQBo1yN3sMpSt40sFbA03X246jRrkZ6eqf5xRcCfxT4di8SaUIBK1ve27ieyulPMMw+63uOxHp74 NW9Kvrm6tmXULN7W8hwswwTGxx96N+jKevqOhANY58eaYHKHTte3Biv/ACCLjt1/g7f0p48b6fkb tM8QKCSATo1zg+n8HekB0ccqzRiRdwU9NylT+R5p2a5keO9LbdtsNdba2040e54bHQ/J16ClPjnS xnbZa42DgY0e5G7jPGUpgdLQeB1rmz430sRlzZ64APXRrrn3/wBXim/8J3o4iDvBrK56A6PddxkD /V4zj3oA6aiuYXx5pDYK22stuJAxpFyckY/2Pemt8QNCVAxTVuV3Af2Tc+3+x70AdQO1ZniWJ7jw tq8McbSyPZzKiIpZmYocAAck5rN/4T3Qwu4jVQuOM6Rdc/T93/nFK3jvQ1ZlK6qGXqP7Iuv/AI3Q Bm/C2HUbLwnHZ6hpt9ZuskkgNyFUEM2QAu7cP+BAV117eLY2r3DQ3E2CAI7eIyOxPAAA9+5wB1JA 5rC/4T3QRyRqgJOADpF1z/5DpP8AhP8Aw+BnzNRwRnP9lXX/AMboAf4e8Ota6rf+IdRSP+2NQbDh cEQRDhIwR94gAZbufpXSfjXLD4h+HCcedqHt/wASu654/wCudKvxB8PHd8+pKoIAY6VdYORn/nn7 0AdRnig1yy/ETw4xx52of+Cq65/8h0v/AAsPw0Bk3F/j/sF3X/xugLHUGj3rlj8QvDgYDztQyTjH 9lXX/wAbpR8QvDmCfPvxjg50u69M/wDPOgLHUE0D2rlT8RfDWVHn35DdCNLusf8Aov3H504fEPw3 gn7TekD00y6PbP8AzzougsdRR2rlX+IvhlELPd3igEA7tNuR16f8s6X/AIWN4YJA+2XYJJHOm3I7 Z/55+1F0Fjqa4rxBHrlp4+07VNH0x76H7C8V4gcRhkDggBm+XeC2QD6MMjOatr8RfDLYP2m+5OP+ QXddfT/V0p+Inhn/AJ+7sg9CNOuSDxn/AJ5+n9aV0BLJ4tdo3isvDuuzX3IEElkYkDD+9K2I8Z7q x9s1R8HeEbrTL+/8Qa5Jbza5qDlnECkR26n+BCTz0XnrwBzjJtD4h+GjjF3d/wDguuf/AI3R/wAL C8NZIN3dAgkHOnXI5H/bOi6GdQOlcp49ZFsNFDkDOt2QB3bSP3g6HOfy7Zp//Cw/DR6Xd3/4Lrn/ AON1i+JfFuiar/YkNnLPcyjWLR9gtJF6P1yygdx3zRdCPQu9GaP50lMBT0oNJ2paYBQaKODSAMUG jvSGmAtFFJzQAvpRR2opAANH0oFHvTAKDQKPagAFFBox3oAKO9HejvQAuKQUUopAIaO1KcZpOKAD nNBNA60d6ADril70elA70AJ2pQODRQKAHL0ooHSikUc94cIOg2IAAPlAmtxRgADpXP8AholtCst3 /PMc10CHpimQOHWjtS0hx2oGHpS0lFADhwKQUDijNACnrSHpilpDxzQMB0ozR2oFAgHWkNOFNNAB xmjBo7j6UuaAA0elITS0AIaB60duKBQAopOtHakxQA7uKSjHIo96ADvQetKOnvSZ/OmACjqfejrR 0PFIBcnBBoHWjJooAOlGeKO1JQByngQk22vKdvya7egdMn95n5sd+fyxXWVyfgRBFBr43F2Ot3ZZ zjLHcOePbFdWOtAC9BTaWjtQAc4pewpKU9KAA8UnWlo7cUAHU/Sg+lBoPSgApM80tJQAc5oo4GKC aAFzzxSH2o7mlzQAnNFLSUAHajrR2oFABR0o4NFAADxRmgUCgBKXOKKMUAZd94gsLC+SwJnuL113 C2tYWldV6bm2jCLz1YgUmmeI9L1a4ltbaaRLuHHmW1zC8Eq5Gc7HAJHuMj3rgH1g+CfizqMutKw0 7W0TyLzlhGFHAJ7AEkEdgVPTNaCIfEXxfg1XS5PN07TbPyLm6iw0ckh3kRhh1I3gkDpgdKQHUHxd oo8Uf8I21y66oVyIjEwDfLu4bGOgrbJAXJIAAySarPplg+oJqD2Ns16i7VuTCpkVeeA2M45Pfua8 y8feI7bUvFVr4XuLu5s9LgcSahJAjM0vy7ggCgtj6DqR6UwO9sfFOnarMqaat3eR7yhuIrZ/JBHU +YQFI+hNbVcv4c8W+HL64OhaaXsri0zEljcW7W7bV7qrAcYHTr6gV1HegA7UUYoNABQO9LQOlAAc YpBSmkAoAXIoooNACd6MYNFGKADvRRR1oATqKUUUdqACgfWjFA6UAHeklUvG6ggZUjkZpcc8U2UZ jcA4+U8/h+FAHPeAGZ/AGglihIsYlGw5GAoA7nnj8+w6DpM8VzXw+ZT8PtCKjA+xoD169zzz/T04 rpO+aAF70tJ3pepoGIaKUj1pO1Ago7UYpDQAtJS0mKADtRRnijrQAYooooAXtRR0FGaAClpOlANI YtJR7UUxAKWgdaa7KgLuwVFGSxOABSGV9Q1Gz0qylvb+5itraMZeWVgqj0/HtiotO1a31UM1qlz5 agESS2zxK4IyCpcDcPccV5VYeJ9I1/xRc+JfEV0VsLEj+ytP2tKR8vzStGqk5yVwxxycZOBXqVnq Gm+JdJlksL0XFrKHhaSByrKehGeCrD8D0NAGHJ8UPBcMjRvr0AdTggRyHn/vn2q9pXjXw5rl+tlp mqR3Vyyltkat0GMknGB1rF1jTvD3h+G00jSPDWm3Oq3mVtYntVcKARmSVvvbBnJOcnoPbR0jw9be D/Dl5LawxNqBheaedI1G9wC2AOAEBJwvAAoAu33izRtOu5bWW4lluIV3zx2ttJcGFfV/LVtg4PXF XtM1Wx1qxS9027jurZzhZIzkZ9PY1w/wdlW58NX15I/mX1xes9zITl3JUEE5+p9aq+D2Ol/FjxNo ts7fYJQblIQxCRv8hbCnofnxx2AoEdxpfibR9bvr2y069We4sm2zqqMNhyR1IweQenpTdU8U6Lok 3lapfC0Y/daaN1RuM8NjafwNT2Gg6Tpd5c3dhpttbXFyczSRRhS/OefxOa4X41xs/hWyZTwLwA5H HMb8n0xQCO/07U7TVrUXNm0jxcFWeF49wIyCNwGRg9RxVzvmqmlIY9IskbqtvGDwf7oq33pgLRSd KU0gDpQTRR3pgJS0UnegBT2oo680GgYc+tJ3p1NoEO+lJ70Yo6UDCk7UtIOlAhR060Z4oPSjtQAd K5T4ktt+H2qtxkCLGQcZ81MdCD1rqzXKfEoD/hXmrhhuBjQEf9tFoA6sHgH1/Cg9KZAGFvGHOWCD P1x9T/M/U080hhSUtJ3piA5zR+NLSDpQAtJRRQAZpaSl+tABmkoNLQAHkUc0CigAzRzR2NBoAAaQ ZpRQKADPHtQetFBoAB60ZNFGetACHrRRnNGKACg0uMCigBKM8UYo7UAHekpcUUAAoyRSd6WgBcnF Jk0UUAGT60pPvSUUALk+tBJ9aSigCrqGqWOk24n1G/trOEttElzMsak+mWIGaj0/XdJ1YyLpurWN 6YgDILa5STaD0ztJxUfiJEl8M6rHKEKNZyhg/TGw9a43wppU/iD4TaFYi9aC3ncm9KOQ8kPmOWjV geNxwp56ZHtQB2lv4g0e71F9PttYsJr1CytbR3KNKCv3gVBzx34rRyfU15r41+HGhweFLm80Syj0 2+0+M3EUsDMuVUZYHHX5QcHrnHOM10fh/Xyfhzaa7qMhcxWJmnc8FtgOT1PJx+dAHQxXdvcSzRQ3 EUkkDBJkSQMY2IyAwHQ4IPNVr/W9L0qSOPUdUs7N5c+WtzcLGXx1wGIz1FeYaBe6p4Y+INpJrcxW PxTAJ3jYYEM5PEf3v4chc+hA7V0/xbwPhrqjEcq0JXnHPmoP60AdCfFPh/7L9q/t7TPs+/yvO+2R 7N+M7c5xnHOKtWOr6bqZlXT9RtbsxY8wW86ybM9M4Jxmubjtoo/hEYIkUp/YhKgjjJhznnPf61l+ BnuLT4Om40+NBcpBcvANpyzKXCkgck5HQegoA6zUPFWgaVdi11DXNPtbjvFNcorLxnkE8D3NXLfV rC7aBba/t5zPG0sXlShw6KQCwI6gbl/OvOvg3qmkz6NPbfaFbXJZGluTOV86cHkMOSzKM9T0J/E9 JH4QgsfiBb6/p9rDBDJazRXQj+XdISpVtvToCCRzwKAOsya5bxy4ji8Pu6hwNctcAnHJJAwcj1rq a5Xx4CdP0fEgTGs2fzYzj96Oe2PzoA6vFJmijvQAnaijnFKaYCd6XtSUpoAB0oNAopAFJTqSgAFH egUUAFJSij6UwFFIaXtSGkAUUdsUdKACj3pKWmAZNHeijFAB3oxzRiikAdTzRR3o6UAFFL1FJ3oA OtKOlHegdDQA4dKKF6UUijmvDWf7BswMfcH866BBjjNYPhkBfD9mevyd/rW8pz3zTIHUv8qO1FAw xR+NAzQeaAA8CiikFAC0fWjrQaADtxRR2pO9AC0meKXHFIetAAaXNIc0dOaYCkc0dKKQ8UgD2oHX mjmjGDQAd8UfjRRTAD1FGKX0o6UgEooo5xTAKKBRQAvUUmeaXNJSAXoKT0oooA5LwE2638QDchZd duw23sdwOD78iuuArkfAm8R+I1YfKuu3YRsH5hlcn35z+VdaDQAtJ2oFHpQAYooGcUUAHXmlPQUn vR1FAC0mM0UHpQAYoByaWkHWgBaTOaO9HQ0AL60DpSdTS84oAO9J3paSgBKKUUAUwAUlLQKQBSUv ajvQAUUdqXtQB55rT/8ACb+NLnwhMsUelabGlzdErmaZyMqEP8AG4ZIGTyM4NZ3hWbUvBHjZPBd1 cC8sLtfOs5G+Vo1CnoMnuuMexI64rtrzwtbza9/btnd3NhqZi8mSWHaVlTsHVgQe3IweBzTrDw1b 2usS6xd3E2oamy+UlzcBQYY852IqgADk84yc8mgDbrzHQ4hB8dNdWXy0d7USRqerAhOVzj3zjPf8 PTqwdc8J2WtX9rqQmnstUtM+Te2pUSAf3W3Ahl9iMcn1oBHIePbNYviR4NvbRfLu7i6EUrRHa7xq y56dQFZ8+1emmsSx8NQ22svq95eXWo6gVMcUtyVAgQ4yqIoCrnAycZPrW33oAM0cUo5ox60AJ3pR 0pB9aXvzQAGkpSOeKSgBe9FJ3pe2KAD1pMUCigA6fSiijsaACiigUAFAoxg0tACd6GJVWbBOATgd TRjmg9CMkcdRQBzngFVXwBoYV9/+hoc5J5IyeoFdGPeub+HwI+H2hfK4Js0J3rg/WulIoAMjNLTe 9KO1ACmk9qU0lABRR05ooAO9JS0negBe1JR2o70AKKKSjGaAF7UDrRmjoaAClpD1ooAKD0o+tFAA OlZ2v/aD4e1MWbFbn7LL5RC7vm2nHHfmtEdKO9Azz74Oxw/8IO4Gwsbl1kXByOBgNkDnH1qj4DtB pXxL8U6ZZKFsYwrFFb5FOQUAXaMYDMD16DHFdNbeDX0e+vJ/D+rTabDeOZJbRolmiEh6uoOCpOPX HtWl4f8ADtp4etZUheSe5uJDLc3U2PMnc9zgAYHQAcAUgOP8BXSa3458VatcuDexyLawxMxLRQAk AAEcAlc8dTnI7n0A3kC362W/9+YzKFwfuggZz06muN1b4Z2l3r0ut6Tq9/ot9LzIbPaEJ7nGB1PJ 5wTzWv4d8I2/h+W5vHvbrUdUuhiW+vWDOQOijGMKPSgDFfwPH4cv9R1vSPEt3otpKpluofKjkhUD kkBhwBz6nn04rF+FmjyX2ral4qnkvZFlkeO1munBeZCeSw2jngDIIHGMYFdXqXg6bxDPGPEOsS3d lFJ5i2NtCIIXPpIMszj2yK6iOKOCFIokVI0UKqqMBQOgFADq8y+NiGXwxYRhQ268x/5DbtXptc34 x8IQ+MbC1s7i8ltooLgTMYlBZhtKlRngHnrg0xGzpRDaPZEMGBt48MOh+UVbrP0fSItGsltorq9u cAAyXdw0rHHTrwPwAFaHegA9KU0lKelAB2ozRR3oADSd6DS96AF70hoPrRQMU031p1JQIXtSdqBR 9aADtRxR2oxzQAhpe1GaKACuV+JLBPh7rBxnMaDGcZy6iuqrkficP+Ldase4WMjkDnzU9aAOrikE sMcgzhlDDPXkU89Kam7y13DDYGRnODTj0oAKO9AoPWgBO9FHel4zQAUlFFAB2ope9JigANKOc0lL QAdjQPWikoAU9zR/PNHajtQAetIDilox3oAB70dDQOKKAAGkpaMGgA/wpO1Bo7UAHelPWgCkNABR 2oo7UAFJS0nagBfSjvRR2oAWkHWjvR3oAKM0UdqACkpR2FJQBwuty+PL2+1jS7XStPGlTQslteNK A+0rzxuOXJJAyFAxknHXJh8DeINU+F8OgaglvY3toxuLVxdmRmcs7bJcLheGxlWbse2D6gaXtQB5 Sng+5uvCiaMvgPTLHVfIW3bVJ/s7RjAwZQUzIX4yPl4J6+vQ6z4evBouieHdPs5J9LtZIXvJDMqm RIznZtJ+bcwBIOBjofTtaO1FgucR8R/Dt94n0qxh02xDX9vOJ4p3kWMRccruzu67TgcZUc8CqnxC utQuPhJf/wBp2Zs75hCkqRuroW8xCSpBPy8Hrg16Ea5vx3oN54k8JXOl2DQi4leMjznKrhXBOSAT 29KAEht5L34ZJa2a75Z9G8uEKR8zNDhcEn3HJP41X+Huna5o3hi207WLS1g8oMyeVcF5MsxYh1C7 QRnqGOat6Tpmv6X4NTTheafJqcFuIraQxOYhtGF35bLdOoxj0OOb+gDWBotuuvG3OpDcJWtj8jfM cEcDtigDgNW+HmleK7ePxL4SvH027kDSIEyiNICeeCDG2cgkflmrfgDxRrB1u88KeI2aW/tkLxzM ASQMZUsPvfeBBx0zk9Kt+HvDni7wpZJbWl7p2pW7Mzta3cskYgJJP7uRUYkHIyCvXOCKteG/CF7a +JLzxRr11bz6vcoYlitA3kQp8o+Ut8xOFAzx39aAOyrk/H242GjKoUs2s2gAIJ535GMd+O+K6vpX J/EE/wDEp0og4caxaFD2B8wdcdsZP4UMEdb3oNAooAOgopKWmAlKelJSmgBQOKQ9aBnNHQ0gA0Gj PFJjmgBccUDrS9qTvQACjtRS0AA6UnagUfjQAd+aXjJoHpSd6AD1oo70HOaYBQPWjqaMUgA0UvfF JjFAB6UE0AUdKAFo70lFAB9aXNB5pOgoAevSihelFIo5jw0x/wCEftM8jbx+ddDHyAf6Vzvhhc6H angNt5H410UefTpTIJOlFGaDQMTvS0dKDQACjOOKOlITQApoPSk60p4oAB0pCPSgdKUCgBOtL60d xRQAUfj0ooPT3oAPSkPvRSmgBKPWlzSGgA4oFFFMAPWlopKQAcUd6KOlAAetHajr9aKYB2pfUUhF HekAvak6UuKSgDgvDMGuXB146Xqmm2cI1q7UpLp7Tvu8zJJYTL6jjbwPwrcXT/F4IJ8RaSfUHR3w en/Tx7frVPwGVMXiEgMM67eE56ffxwcc9K67rQM5x9O8XNkjxJpa/TR2/rPTRpvjEpg+JtLBz1Gj sf8A2v7fqa6TmigRz6af4tVsnxDpLcfdOkPj9LjND6f4uYjHiHSU45A0dzzx63H+c10GecUtA7nO HT/F5YkeJNKAIIx/Y74Ge/8Ar+39aDp3i/YAPEuljHf+x2yfr+/x+QFdEaO2aBXOd/s3xec/8VLp YJ6f8SZuOP8Arv8AjQdN8X548S6WBnP/ACB2546f6/p3/rXRUUBcwPsHi3eWHiHSQD/D/Y74H/kx moX0vxiwOPFOmqSMcaMf6zGulPXNFA7nNDSvGA4/4SrTz7nRv/t1J/ZPjHv4rsO/TRv/ALdXTUtA jmf7K8Yh93/CV6cRgjadG4+v+uzxTTpHjFuni+yHHbRh/wDHa6fvS9KAscv/AGP4wKn/AIq+zBPc aOOP/ItA0fxftCt4utcg53LpCgkccH95j17d66fvS0CscwdG8Wk8eL4QO4/slP0+ekfRvFhUhPGE SsSeTpKHA/77rp653xxr7+GfCN7qUGz7SAI4N+Mb2OAffHJx7UDMmP8A4SS71a40608YRzTW/wDx 8PHo6GOBjyFZjJycfwjJGecZFXjoni87ceM4hgc/8SiPk4/3+nWrHg/T49B8GWazTEsYftdzLIRk u43uSenUnn0rI03xX4l8RadJrGiaLp7acJHSKG7u2SeYKcFvlUqvPY5+vqAaR0XxYTkeMYgD2Gkx 8f8Aj1INE8WgKD4yQ8HcRpMfJ7fxcCsLV/iJqWn+D9M8TQ6VaS215iN4HuHWSKUluAQpDD5SOgP1 B42Ne8Qa7oXhZNaex02UxqrXFuLhxwxAGxyvXJHBH/10BK2ieLiBt8ZQg/8AYIQj/wBDo/sXxacf 8VjEFBz8ukx5I9Dl/wCQFZ0nivxJD4KTxNJpmliHyxO1sbiRXMZxghivB56Ecg9ag/4TjXR4CHiz +ydO8jhvs32t9xjztJ3bMA7u2OnegDX/ALF8X5GPGMGOd2dITP4fPwfrmg6N4u2/L4xhJ7FtIQ4/ JxVKPxX4hn8FSeJE0rTFQRtcLAbuRmaMA9xH97j6fSrWgeMH1HwlJ4l1W3trCwCl0EU7SttBwd3y ryT0AzQBK2j+LiWx4vt1z90DSEwP/IlVNTt/FWm2ZuZfFaNAjEu0eiCRkQ9yBJyB14BNQDxj4jm8 PN4jtfDlq2mBPNWGW9K3LRjGWwEKjA3HBOfywej8OeILLxRosWqWAkELkqUlXDIw6g9u/Y96AMmL TvFN1BFPa+M7N4ZBuV10lGVgemMSfWn/ANjeMuB/wmFpx1P9jLk/+Rax/C92vh/x9q/hJXk+wuft djG2NsO4bmRfQZLED2/P0E0xWOYOj+MWJ/4q6yGc9NHGB6Y/e/zpRpPi/kHxXZfeJH/EoGcen+tr pqO9AWOYXSfGIcsfFliQf4TowwPp+9z+dOGk+L/+hssuuf8AkDjH0/1tdKOtL2zQFjm/7M8X5Ynx PpvOcAaOcD/yNT0sPFq8HxDpLDcSC2kPnGehxcD6V0J6UUFXOdOn+LzgDxFpIGMFv7IfOcj/AKb/ AF/wpjaZ4wYADxRpq9eRo5z195q6T2oP60Bc5z+y/F3H/FUaf1JOdH7en+up39n+L+B/wkWk8Hr/ AGO/P1/0j/Oa6Kk4oEc6th4wBH/FQ6QRnknSH/L/AF/1py2Xi8IAde0Z2Hc6RIM/XFx/SugpetAH PtZ+Ls5XXNFxjGDpEv8A8kULa+LyMNrWhj5j00qU8Z4/5eK36O9AXMH7H4t37v7c0Xbj7v8AZEuP r/x8f1oe08XYJTWtEyOgOkygf+lBrfpOKB3MF7XxcUIXWtEDEHn+yZeP/JimLb+Md0nnaroCxjoV 0yZiRz1HnjHGPWuh70MQFJPTHNAHDeDIvE03gvQ3s9U0iO2NnGEWbTZmdVCgAE+eNx9wAPTits2n i4LxrOhk986TL/8AJFReAXL+AdCJk8zFmi554AGAOQOmMfh3610nrQBz62vjDau7V9BBz82NKmOB 7f6Rz2pwtfF3OdZ0Mc8f8SmX/wCSa3ulHYUgOd+zeM9yf8TfQNp+/wD8Sybj6fv+f0pXtvGQX93q +gMQD97S5lycjH/Lwe2a6KkxQBzq2vjIhg+s6EOQRjS5T9R/rxSpbeMjkyaxoKkEgBdLmIIzwT/p A5x/k9a6GimFznHtvGof5NV8PsuP4tNmHP8A3/NI9v42DDy9T8PMuDktp04OeO3nn3/IevHSdKSg DnZ7fxoqn7Pqnh+RsHG/TZk57dJz/n1p/wBm8X8f8TfQs55/4lU3T/wIrf7UUCOd+zeM/NX/AIm+ glCDu/4lkw2+hH7/AJ/MU9rbxgI/k1fQS/YHSpgPz+0f0rfAoxQBgLbeMcLu1fQQSeQNLmOB7f6R z2qhJf8AiSDVItNk1zQmv5slIIdJmcqgzh3IuPkBxjJ4zwMmt7XdWi0LQb3VJl3JaxF9ucbj2HPq cCsP4d29y/hsaxqBEmpas5up5duMqeI1H+yFAwO2aQy41t4yBBXV9BOWAYHS5gAvqP3/ACfb9aWS 28ZBR5Wr6C7ej6XMv8rg1Vg8WXusz3x8N6Vb6jZ2Uphe4lvfJ82QDLLGNjZxkcttB7E9ayZPiZOn hi419fDk4t7S7a0uYpLgLJGw2gHABBG5sHkY4654AOhW28YFBu1fQQ3cDS5iPz+0Ukdt4x2HzNY0 FWycBdLmORnj/l4FUZfFetReEW8RP4ehWERfaDbnUMS+VjOceXjOOcZ/HPFN0nxdq2s+FX8QW2gQ CDa7xwyX5EjqhIP/ACywDleOcH1FAGilt4w3fPrGhAe2lTHv/wBfHpSSW3jEITHq+gs+OA2lTAE/ X7QareE/GLeJtIn1eWxi0/TomdTNNdAn5cEnG0ALyeSe3THNQQ+MtT1PTH1fRPDrX2lqzCN2uxHN Oqkhmjj2nIyDgFgTjpQBpLa+LiBu1nQwe4GkzH/24pqWvjDad+saECM4xpUxyPf/AEjiobHxhHrn hh9a0C0F75WRPbTSmB0YLllyVILDI9B71V8OeL9V8T6BNq9jodsIlZliikvyHkK9ekRA9ufrigDQ a28Yhl2avoJXJ3E6XMCPTH+kc002/jTaMar4fJzyDpk3TP8A139M/wAveqvg/wAZTeK7S6vm0yOx sbdihme7DEsACeNowADySfw9G2/i7UtXhuLzQPD/ANu0+FyiTy3iwtckEgmNdp49CxXNAF423jDP Gr6Cfrpcw/8AbiovI8cZ/wCQl4cxjr/Z8/XH/Xb1qz4X8Vad4r003diXSSMhLi3lXbJA/wDdYfny ODWHeeONWs/FcXhs+Gkmv5l8yJor8eWUwx3FmQEY2nPHXpmgDReDx0NuzUPDbZ+9usZxj0x++NDQ +OQ7hdQ8OMMArmxnUn1z+9OP1qHX/Gx0m9OnWGiX2salFGJbiGyG5YAegZsdT2GORzxR4X8d2niq O7htrWW11S2zvsrvKH0zuAPGTg8ZB7dMu4E/keONpxqPh3djgf2fPgn3PnUNB45y23UPDh/u5sZ+ fr++4/Ws3TfHl9qPiubw7/wjjwXttkzvJeL5aKMfNkLk53LjjvTrXxzqFx4vbwy/h7yL5F3s8l6D HswDuyqE9DwMdeOKLhcuJF4/83DXfhjy8feFrcZB+nmf1pXi8fBHK3vhpmCkqPsc4y3Yf63gdefb 34o3Pjq+t/FkXhs+Hma/mXfEy3qeWyYJ3ZxkcKeMZ/nTta8d3uh67baTP4cmnmvDi1kt7pWSQ5AO SQCuCecj86AHLqHiy41O50621Xw2b23VXkt5bG4Rgp6MCZPmHbcBjNWvL8e7G/0rwzvzwfs0+CPp v4/WovHVtdnwyNatEWHWdJxdQOrbtuP9YhPG5Sm7I74Fbnh/WIfEGg2WqwqVS5iD7T/CehH4EEUB cyPL8e8g3fhk9AD9lnGOeTjzOeO3qevHKPH4/GfLu/DDDHBNtcD9PMP+fWuqo70Bc5QL8QyuTN4W RienlXDAfjuGe3YUbfiDz++8L8Hg+VcfMMem75eeO+c54xg9XiikBy0S/EDJEsvhgDoGSO4Pfrjd 6ds/j2oZPHwC7J/DLH+LMNwM/T5j711IpKYHMMfHhBKL4aBJGAWnO0d+cc/pTdnj8qv77wwG3HJ8 q4IIxwPvdc/z7YwerpKBHKgfEDJLSeGMdgEuOf14/wA/Utb/AIWFg7P+EX4GOftHJz+nf1rrBQKA OWlPj794Yl8MnpsRmnH1y2P6Uin4gblJTwwQPvANcfN16cfL29e9dV3oNIZyu7x+DjyvDLd93mXC 456Y2n2/zxXP+Nv+ExfwTqiaonh9bQxL5r28s+77y5AUrj2616V1rlPiUu74e6spGcrGBxnnzEoE OMnj4kkW3hkA4wPtE5x6nOzn6YFG7x7tGYfDW4E5Hmz4bn/d44+tdNExaJGIwSoJGc4/GnmgZyof x/uf/RvDG0rhT9ouMq3qfk5Htx9aPM8fjP8Ao/hgnj/l4uBn1/g/zj346qkHUimI5Zn8fbPlt/DO /A6z3GAe/wDBTzJ453f8evhwgHOftM/8tn9f8K6bvRQBy6SePRvL2nho9AoFzOMdckny+e3HHfmg SePstm38MngY/f3Htn+D6811FHegDmXl8dYOyz8N5I/iup+P/IfPb0pxl8cZ4sfDuN3e8n6f9+ut dLSCgZzJm8dbjjT/AA3t7f6dPn/0VTjP44x/yDfDp5HP9oT/AI/8sf8APvXSmg9KAucyZvHOfl0/ w5jjg30/vnnyv938j68Hn+Ofmxp3hzoNv+nz8Hvn9zzXS0vagLnNrceNgG36Z4ePAxjUZxg9/wDl gc02S48dbfk03w4Dx1v5z/7RFdNxSUAc8Ljxrkk6X4f9h/aU3v8A9MPp+R9eENx40wNuleHw3cnU 5j3/AOuHpXRCigDnhc+NPmzpXh/n7uNTm4+v7jn9KR7nxpgY0nQM5Gf+JnMcjv8A8sOO/wD9eujH Sg0COdNx40xxpfh8H1OpTH9PIpiz+NxGobTvDpk/iYahOAfoPJ4/M10poJoGc15/jfI/4lnh3AHP /Ewn/wDjNP8AtHjTj/iVeHz6/wDEzm55/wCuHpXQigc0Ac41x42yNumeHgOc51Gc/T/lh/n2oa48 bMq7dK8PKQ3zbtSmORn2g44+tdHRQBzi3HjYOwbSvDxXjbjUph/7QpftPjQHJ0nQGXuBqcwJ/HyK 6KigRz/2nxjuJOkaDt7D+1Jsj8fs9It14x4zpGg+/wDxNJv/AJHroe1FAHPJdeMcYfR9BJ/vDVZg P/SenG88X5ONF0THGP8AibS//I9b1LxQBz5uvGCp/wAgXQ2bOPl1aX1682/alF34vJ/5AuhjHXOr S8/T/R636KAOfN54u3bRoWi85+b+15MD6/6PmnNeeLQMjQtFbvgavL/8j1vUtAHPveeLUGV0LRnO QMDV5P624pv2/wAW7m/4p7SOM4/4nEnzfT/R/wCddCKO9AHPPfeL1xjQdGbLY+XVpOBnrzb9AKU3 vi4Ln+wdGJyOmrydz/179q36UGiwXOfN94tAYjw/o5wQB/xOJOf/ACXpo1DxfuI/4R3SeDjP9sPz 7j/R/wDOa6LrQKAuc6dQ8X7sf8I5pOM4z/bD/n/qKRtR8YgDHhvSW6HA1h+OnH+o9z+X59H3ooA5 77f4uw3/ABT+kHBwB/bD8+//AB70z+0vF27H/CNaZ16/2w2P/RFdH3paAuc02qeMAf8AkWNMYe2s H/4xTP7T8ZryfDGmMPRdXI78dYewrp6OMUAc3/anjAjI8L6b16f2wc/+ia5/xPd+Irm10aPVdIsb KL+2LPfLDqJkYnzP4V8se3Un6HGR6KOlcr44IEGhZHz/ANt2m3oRncc5B68Z/HFAXOqpO9LRigBK Wg9DRTATvSk5NHeigAHJoNHfijqaADNFA6UlAC9uKBzRRSAO9H40CkpgLRRniikAUGiigA+tB6+1 JRTAXpRR3oA5oAXvSduaU0hpAHfAooHWigBaTvR6cUtACZoopQKAHDpRQOlFIo5nwyCuiW2c9OB7 ZroUrA8L86DaZz93+tdAtMgd9KOtIDzRQMWj+dFLQAmO+aKXHFN70ALQetHajt1oATp0pRR2oA7U AA60hNLjmkIoAD60tJilNAC00mlzQaAEFB60D3oHX1pgKKTFHeigBaTvS9TmkGKQAaM0cUhpgLig 9c0gpx60AJR3o/lQBikAtIDS9vekFAHI+AXZ4vERwfLGvXmwk5yNwOR7c/zrr81yXgFi+m6u4Uqj axdsgK4wPM4/zxjp1BrrDQAfSjoKQE0dqYC0UCl7UgEPTijtS0ntQAUGjvSGmAvtR3oopAB4PFB4 o70dKYB2xS9DSd6XFIBKO9LmkNACV5p8bw3/AAh9iwUFV1BS3HP+rk79q9Mrn/G3h8+JvCd7piKh ndQ8JfoHU5HPbPIz70AbFuqTafEjoGjeFQVYdQR0IryG10TW/Dlg/iXwFqkl1pBMjyaVehjwrbWC qvBPynkbWwAMt0r0TwPqrat4RsZJuLu2T7LdJu3FJo/lYE+pwD+PfrVK2+H9vZ6dNp1pr2uQWM+7 zLdJotp3HLYPl7lzn+Ej2oA5D4i6imr/AAg0nVIrFbRbi6jn8nGAhKycgjHBJzkdc+9dL8RJoj8J 7t94CSwQBMjaTlkwADyD7V0moeG9K1Lw9/YdxaL/AGeI1jSJDt2Bfu7T2Ix1rE034a+H9PtZreb7 ZqKSQmAfb5/N8tCMHYMAIcdwAR2oAoa7OjfBDzFk+/pkIRmG3cxC4+96n888VjvbuP2efLHJNtu9 sednOT/Ot2D4T+H4dPnsmutUngdSsKz3IcWwJ58pSu1ScnnBPvmtvTvBui6Zoc2jRQ3EljPCYZYp 7qSQMpznAJwmck/KByaAOaie3X4C7g6mP+ymGd4UFsHgE9CWrmmjmuf2eI3iDgo4kkHOSqzYPfgD g+mB0ra1/wAA6T4c8D65Lb3GoXKRWsj21vd3PmQ27Y6omAA3ucn3re+G9sknwy0q3uEEsUkUiukq 5DKXbIIPUYOPcUDNTwhPbXPgnR3t5FkgFlGmRzyqhWH4EEfhXF/BS2ZNJ1i5Q/6LLebYgCcZUHJA 6DqPyrfh+G+m2ttPZWWra1aabcMGmsIbseU3qMlS6huh2sMiups7O00uwitLSGO2tYE2pGowqAf5 zmgR5nq0SP8AtBaTs++toHcsOmEl6fp+deq+tef+EdPbWvGmr+M3X/Q5T9m04lceZGoCtKMjODjA OeQTxzXoFAB3opcUfWgANA6UZ5o60ABxjI60nelo70AFBoooATtR1opfegBKDRnmlNACUUUdqADv QKWkoAMjNIx+RuSODyBkilpJCEjdiSFCkkgZNAHOfD+F4Ph9oKNvybNHG9gxw3zDkdsEY9sV0vas HwSAvgXQNq7f+JfASMEc7Bnr79+/Wt3vQAv8WKXtzRRQMQ0UGigQUnalpCKACijvRQAdqO9A6UdT QACjvRRQBxPxZBb4f3aq7qWmhHGMH5xwT2H9cDvit3wgD/whui8KAbKIjaMdVB6evr71N4i0ga94 dv8ASmk8v7TEUWTGdrdVJHcAgcVi/DnUPtHhODTp9sd/pZNlcwEjdGUJAyB0BAyPWkByQ8Pa9ol7 qWqeANWF1ZxXUi3Ol3HI85SA6quAG/AocAAE8VNq+rWHiH4JazqVrpy6d9plzcRcKDN5yBmyBzk+ v0rqIvBd1Yahf3ek+J9TtDfyvNNHIkU0Ycnqisvynt3zx6VoDwjpK+EpfDaxOtjLGyOQcuWY5L5O ctnnJzzQBk6uP+LNzh0C/wDEmAKq24A+WOM9xVfwWxT4O27yNuAsrg53ZwuXwMj2/L8Klsfhjplv EIL/AFTV9WtEQpDZ31zvgi+UqCI8YyAeM5x2AxUWmfC3T9LtpbVda1q5tGRlS0uLrNuhP8RiUBX5 5weD6UDOS0BZn/Z81fyy4fMpYhiSQGXcPpgEfSvQ/h9c2914E0Z7d1ZUgWNtpHDLwwOAOcil8L+C tO8KWUtra3N/dRSgqyXc+9MHriMAIM9zjJ7mqdr4C/suC6stH8Q6tp2n3MjObaExHyt3UROyFk7Y 5457nNAHLeBrWWF/HrxF/wCzvPnjQMeCwDEkDHoQDzxx+Gj8LHMPwrlkYBVVrhw27BIxnPbH+GDX c6Po1hoWmR6dp1uIrePJx1LE9WY9ye5Ncgvw10vRre+mg1LWXstkkv8AZrXZW2LYzyigZHHQ/jmg RzHhETSfBLxIlv5nW58vb1K7FJAA/Hp+ldl8LLmC4+HemCDH7rejBTnDByT/ADz9CKzvgwu3wM52 MM3khy3fhR/9atO08BLpFzdNomv6ppttdOzyWkRjeJCTkmMMh2H35/SgDn/h/aGL4meMmty7WqS7 S2/I3sxP0J4b6dKk1PJ+P+jBfmIsGz0+X5Zf/rfnW7efDvS5/DbaLaXuo2KvN9omubefE1xJ3MjE fNk8/UD0qpF8L9PXWrbVZdY1eS6ghEbSC5KSTMM5Z5B8x4OMAgYAHSgDodNm0GLWtTsNPntv7SLi 4vYkfMmSAAT+AHHbI6ZrjIbaSL493TWqhYnsA91tA5BUDPrnKpXQ3fgmIeJH1/RtRm0vUZYvKnZY kljmHHLK38XA5BHT650tE8OW2jS3V0ZpbvUrxt1zeznMknPCjHCqBwFHGBQBxmjLu+OviHDcCzU/ IBg/JD1/GhIw/wAfpCSP3en7/lbHOwDkd+D/ACroofA9tH4yvfEzajfm4uiv7pJPLQKFQYOOWHyD jOPXNQ+I/AMGua9FrVrqt9pWpIgQzWjAbwMjnvnBx1xjtQBz+oRed8f9MI2t5diSwIHy/JJjv1+Y f56HjbI+LPg1lzkthhwON5xz+f5cVpX/AMLLGe8tr+w1jVbDUYV2veJNvlmPPzOx5JwSOCOOKfc/ DC0utWsdSk1vVvtVt8zz+aDLK+eG3EHb0xtUAAZxjNAHTeKEWTwnrCNtw1lMPnxj7h9eK5v4RmVv h/bGQqVM0vlkPuONx6+nOeKsePp57LwadKs/Mub7UWSxgEmGZ9xwxPT+ENzx61veHNIXQfDthpQZ WNtCEZlGAzdWP4kk0AadL3pM0vemAtIaU0lAwpO1L3o7UCFpAaXtSUDDvSCnAU3pQIKWg0UAFcn8 S+fh5qw56RDhsE/vU6H1rq65H4luV8DXeMgGWAE9cfvVxx3GcD8aAOshQRQRxgEBVC4PXgd8U/tQ etB6UAJ0oPWijvQAdDRR3o6UAGaOtHejHNAC0Ud6SgAPJpe1FHagA7UgpexpMZoAX1pD0pfWg4xx QADvSCgUA8YoAUGkNL14oPWgAFFFFACGil+lFAB2pDS5pDQAClpBS9qAEo7Ucc0DpQAUdqKO2aAD mjHNHagHmgA70UHr+NFACUtGKKYB2ooPSkoAXvR3paQcGkAUGijGKAE60tFJ3pgLSdqU0dqQAMYr lvHIBtdCBzzrlngAZz+8/wAn8PwrqO9cp443tL4aQAMja1ASMZO4biPQY6nqOnGelAHWDj3oo70d +KAA9OlFB6UUABoPFAoPWmADpRzR1oNIAzRR1pKYC0CkpRigApKWjtQACigdKDSAKDRRmgAopPal pgJ3paKKAD3opaTtSAKOKKKAFHajvRQOtAAcUDgE0hoHQ80AOQ5XOCPrRSr0opFHN+GONBtcAfd/ PmugXoK53wwf+JFag9l/rXQqc0yBw60UopDQMXtR3ooFAAe1HvRRjigYnU0E0fSg9KBAOmKKOxox xTAXrSH1pRSdaQBzxmlNITg0GgBe/FJ2oOKM0AHaijNGKYCdOaXnGKKB3oAUUmPelzzRSATHrR3o opgGKO/NA60HrQAYo9aCMUoHNIApBS9BSd6AOV8B7BYayqOp263eqVDZK/vTgEfw8YOPQg966rrX I/D9w8HiIhkYDXrzBRcfxA/j1rrh0oAPSjFH86B1oABS54pOaO1AATxS44FIeKDyKAD6UHp1oPSj tTAM0ZzRjnFA60gDHNKaSloASlxRjJpKACjvRQetAAKKSl70AUI9GsotWfU4FeC5kGJ/KYqk/HBd ehI7Hr74q9SiigApKX6UlAhaKSlFAylq2l2+s6Vdabdb/s91GYpNjYO09cGq+heG9J8N2n2bS7Xy UPUlizNznkk+pJx0rUooAWqWp6Zb6vZ/Y7vzGt2YGSNXKiQf3Wx1U9x3+lXaO9ADI4o4IkiijWON BtVEGAo9AKf0oPQUdKADJoo60GgBe9A6UmKXgCgBOaWgnmgcnNABxRR3ozigBMc0d6KKAA9aKKDQ AUtJR2oACaMUCgUAFMmXdDIu4LlSNx7cU+hm2oTgnA6DrQBheCGRvAnh8oVK/wBnQD5WyOEH+cdq 3a5r4eBR8PdB2HK/ZF9OPXsP8fXmumzzQAc0uaQjNHagYp6UlKeRSUAGaQ9KWk60CFFJR2paAEHS ijtR3oAKD0460UUALjis19FtTrK6tC0lvdlRHM0RAFwg6K4IOcdiMMOmcZFaVFIApaSigYUlLzRT EFFA6c0Hg0DD1qK5gW6tJrdywSVGjYr1AIxx+dS55NFAjnfC/gvTfCUBjsLjUJc5ybi6Zl/79rhM 8Dnbn3roSKXtSdKACijvS9qAEoPNFGeKAMLS/C1rpfiHUdajvL+We/8AvxTTBoo+c/IuBj8Sa3Oh 60tB60AHalooxSAzIdFhTV31S4mnurrlYfOYbbdT1WNQABnueWOOTjitPvRRTADRxkUme1LQAUet HeigAo70vfFJQAo5pOtL0pO9Awoo+lAoEBPFFB6UUAB61ynxIVD4FvmdN+ySBlAXJz5ydP5fjXV1 yXxMJ/4V7qm0kH9z0xz+9TjmgDrT1oPSjrR2oAQ0Z5o6Ud6ACgUd6KAFpO5NLSUAL9aT6UtFACYp elIeopSeKADtQO9FHvQAH3pPalPeigAA60lL3o70AA6UGk7UvegBKKBS9qADGaSjvS+lACUGig9a ADtS9qMiigBDRS5pO1ACU4CmineuKAEo70ZoHJ5oAP8AGgk0f40vegBKSnCg0AJ6UfhRR2oACeKB R60DmgANFHeigBO9GeaKXvTAQmilxR2oABXMeMgm7w68jEBdat+mOpDgdfcj+ldPXJ+PM/Z/D42q Qddsw2RnjeaQI6zHeig0UAFH4UUUAFH1ozzQelMAFB96UUh60gDFFFGaAFpO9GelFACUvWikoAXF BoHFFABQKKKADuaO9JTu9ACUtJ3oFAByaMetHegmgBeKbSjrS980AAo6UUnU0AKaByKD0oxxQA5e lFA6UUijmvDJ3aFa8fwn+ZroV6D6VznhgH+w7Ugfw8/nXQoSR0FMgfRijFFAw70tJxR2oAXik70o 6UdKACg0UHpxQACjFGeKKADFBA5o/Sg0AJxS8Ud6Q0ALRjAo70CgBBQaDR1NMAxmjHBo5pRSAQde aMiijGDTAMcUdqO1HtSASl6UlL2piAZxRk5ozxR3pDFPSmil7UUAcd8PMmx13Kbf+J3d/wAIXIyM f5OK7HHNcf8AD2AW9jrsSj5V1u7UfLgkBgvPr0612HIoAKOgoo7UwDrzR2o7UUgDFB6UUvX6UAJx RS9qO4oATFed/EdfEdjp0ut2uvGxis54xBBANodWKgmUnhuc/LjGPrx6LXnfxa1jTF8GX+mf2lZj US0LC0M6+bjepzsznpz0oAm8XeOLnRvA+k31m0J1PVUhELFcopZQzPtJ6c8cnqOtJ4l0fxFoHh+4 1nSfEmq3WpWsfmzQ3JjeGYDlzsKjbxnAUjgYHPNc74u0ttd+HPh7U9Fa2uv7Fhj+0RxOGKKIl3Dj oVwCV6+3auq1jxtoer+BLufT7uC7uL62kt7exGHleZl2iMx9SckZGOnPSkMo6j8SHh+HOn65apB/ aV/KtqkbqSiygkOSNwO0bT0J5I61Y8Q6LrGjeHp9a0/xPqj6paoZnE8ivbzcgsDFtwoxnGMY4571 y2t/D7VbT4W6RHbwiTVNOma7mgjUMxDnJAxwxUbc8HO3Az0PX3vjvQNS8FyzWt9aXd5eWnlx6crL JM8rrtEZiHJOTyMdM0AT6Tql14y8DW+qRXlxpt6EfebTZjzVyCMOGBXPOP1qj8MZtU1rw9Hrmq61 eXc0sjqI2KLGFHHKqOucn8vel8KxWHgTwPbaZr2p6bY6hcLJPIk9yiFmbtyRuIG0HHcVnfCm80a7 8AW2gz39nJdTeer2Xnr5jIWbPyA7gMc9PemI9G+22m7b9qgzjOPMXPr61594+vdV0zxV4di03V72 3h1S48qeJXUpgMn3cqSpIJ6Z+nXN7/hTfgTAxorDv/x+T8/+P1Q+IMP/ABWPgOJQqxR3wx1yCHiw P0pAP+KFxqfh3wza3ulatfwSieOCRjMCCgR2ycj7xIHIxnpTviJNqGg+B4tT0vV9Qhuo5EAfzg28 PknIYHd7dMevGDW+OBUeELA4XedRQAnkgeXJ0HU9ulWfibE+qfCuWWxheRIjFKRLAyMEU4LbWAIw OenTNAD/ABObvTfht/bNjq+p/bY4I5UlNwW3Fymcrgq3sMcZOMZqa2F7L8Lm1b+2NSa/Ontdicyg fvFjJHyjICkjp+meKy9d8R2ni74fy6Z4b3anffZ4mnjhUkQquGbcxwN3ykAAkk9B1Iq6P400i4+E 76ZbyG61KLS5YZbRYtxjwpVnfA2rGM5y2OOOpxQB0Xw2v7i88Hpq2q6pNcTyuyyPcSYVNrNgAHAH B6jrxXXRalYzFFivbaQucKElU7jgnjB54B/I15v8PtH0nxT8L7bR9UtpZ4IpmlZSkkIJLMVIcY3c HnafrWrJ4J8F+Bon8TwaVcI+mo026KeSRsYwcKzYPBNAGf8AEHUNV0PxDoKafrV5bw6jcMlxGXUq Fymdu5Tt4J57VT8UP4p8PeKvD8Fn4heX7ZcPDDFcBmhEe5dokAO52wx3MT2421leMPF+leK9T8I3 Onx3jWgvFMj/AGYlt25N0S4B3uByQuRyvWtv4oTiPU/CGrtLPa2Md3tkuxFtaDcyHcQ6nBAVjhl7 dO1ADdSOueF/iB4fhj8T3+pLqMpF3bXADKF3AEqij5RhuOOMde1XNYu9YsvinpGiw69eLpmoI0zw AIzKRv4DFchSQO9P0u9sbXx3aWfhiO11dbm3Mmrau1ybmZV/gBk3YXJAO0cdMAAUmtxZ+OPhosyg fYZSuOvAk/z2/nQBX8Y3HibTfG3h600/X3MN7IfKhuEVUDqMEOUUF1O4cev4Gk1V9X8F+K/DaDxL qN/BqU7xXUV8VdCSU+4FXK8njrjgdCcyfEC4trP4heDLi6ube3iWSRnknIVVAKclj06nGT1qP4pX kMWs+DJ2u4orX7eJfOLqFA3R/NuPAGCTnI+tAHQ6/a+IvEGqS6Vpt/NoumwRqZ75Ij5s7sCQkZOM KOMsDnJx61z+h6z4k8NePLbwjrl//atrdKXtrt4tsmMMeSTzyCDnd2wfTX1H4gDSfGFnY3sNuvh+ +iDW+reeBHuwScsTtI4x1B5B5qjf3Fv4k8c2OtWEqXGj+HYJJ57uBTKs0jKT5cRGQxAAJx0yB9GA vxT1LWPD1lZ6ppGs3Vo8k4geLYjxBdpO4gqSOn60z4h3WreFvCVtf6b4hv1nZ1gdnEcgkyGbdyny njqMDGBXN/EnxjpHizwppMmlmZ4jeqZHkiKiNtp+RuDuJBzhd3A9xne+L11byfDqzlVyqvdxeX5i MhJ2P/Cwz+lIDrJ5dVsvD1lb6aJ7vU7shVnu13rCWG5nlK4AVRkADqcD1NRSeE76V2kbxj4gWV+o jeBUB9l8rgcf/Xrb0u6gvdNt5rZnaEoArNGyEgDrhgDj3xVzIpjPOdM8U69oPjYeGPEkqXtvcMPs eoCNY3IY4XfjC9cLwOp716NXlHxnjQ3Hh4xyRxXbTOscjA5HKYOQpOASD/KvVgTtGcZxzigQdqKB R0oAXvSUdaKAD2ooo9qACgYo+lAoAO9NkOInyAcKTg9DTu9MmXfBIuW5QjKHnp296AMLwJx4C0DD 7wLGIZznHyjj8On4V0PrXO+A1KeAtCBTaTZRHGAOqj0A/wA9z1PRUAJnml70YyaOcUALmkoPSigA pKKKAFoNGaSgAqhrWotpWkz3ccD3EygCGBOskhOFX8SR+Gav9qzdfutRstBvbnSrdbi+iiLxRMhY ORyRtBBJxnAB5OKAOG1u3+I+jac+uR+ILS9aFVmn0yOxAQDHzBTncwHXqCRk9QAbdz8S7eH4Zp4o SBftUn7hYGIK/aBkEfeyV4Ldc7ao6V451DVPCh1i88QeG7bh1lsxp8jyhgSAgX7QCWPGBjvXO614 L1e0+DFjF9lLXcN2b+4ijB3RI6tnKkZLLlcjnHPXGaQztdWtPFGn+ErvWrrxRcw6lBbm4kt4LeE2 yYGSgUqXI7Z38/pVK48UeJL/AOEcPia1u7S0vQjtNstfM3AS7AVy2F4BJyG/AVFqfxJ0DX/h/ew2 87tqV1p8qNYQgtJGdhDkngBFGWLE/dHrxVGHbF+zlI0gOPJckdP+Xg+woA0ZrnxddfD1/Eh1+Szl jsEnhght4WEgCqWeRmX7zcnC7QuR97voWPi/WNT8CaPeWNnC2t6nKbaLzATArKWDStt5C4QnHXJA ptvcQTfA8ukyyKmhsGMci8ERHIyOAQR/k1heFPFn/CL/AAb0/UbawfVXjmkW4jtnGYQXdt0hAJHA HJHcc0AT+I73xz4Gkg1e41tdb0ppcXMX2JIhHk+x3AdcHdwcA8dfSrC9i1LTrW+hz5NzEsqZ64YA j+dcT438QadrHguLT7CaK9vtZaFLa0gnVnfLKzcg8AKDk9BXX6Dp76T4f07TpWVpLa2jicqxILKo BxnHH5UCDW4ruTSJ2sb2e0uI0aRGhRHLEKcKQ6sMZx0wfeuJ8M+JNeufh/L4inuJdT1GRmgt7JYo 0j8wuEUnABxk5J3Y25PB6but+NNBtrq90FriSfVhFsFhFCxkkLrwqkjaSQQevA5OMGuI8B+ILu0+ Ed2fD6w3er2MjyGCSFnBBcE/cILHaSRznjHagZp+I4viL4csJdcj8TWmoRQ/vLiy/s9Y0jXI+6eW ZRzn5gcDOc1bvvEWteIfAZ8Q6HqEelww2ck0o8lZJWmTO5PmyqpxnPJOR070YvGV/qngt9Qu/EPh 5JbiJ420+KwlM5c5HlKPtAYue3HfPTmpbK1tfCHwjm0jWL+1t7+ayuJRbTTqGJYE7FU43HoCAOuf rQBr2PibVbv4eaRqFrFHNrGohIYjIv7vzCSDI4GMLhS3HsKwvEcvxB8HWP8AbR1+11i2RgLi2ksV jEYY4BG05IycZyO3viHSfEGpaH8GdPuvDy2N7eWSBruBiZTDGzMclVZSCP6H0zU+qeIrzWfA8ko8 Q6Ddf2hbCNLC1sXNxJI6j92oFwTuGf7px1IxQA/xv4w1TT/Dmi6/o1+0SagyK0JjiljQFSxIOM5z x1xx0FXvH+qax4T8IpqdlrdxJdLIkX7+KArJuJJJAQc46bT278mud+IGkXWk/CbQo5I5C9hLCbkI BhSQc5I6fMQM4PJHrmrnxM8Q6R4g8DS22j6gNSmG24f7Ewk8qNerS7fuDnoRnPbgkAHQ6vc6vp/w +fWIdcuHvorZbnc0MDI5YL8uNg+XrjBzz1PSqtvqmtTfDA+Izq84vxatdbRDAYztz8pGzO0gZPOf cdKztb8XaNf/AAsmt7TUYbm9k01Va3s33vEQAGLgcoo5ySBwPpTtKvra6+BNwsU0Mpg0uVJREcBC A3ynpzjqP555AL3hDVfEviLwjHqMeoW5vriZomaaJfKt1U4LqigFmx0BbHI9xTPAOt69rc/iLSdX 1DfNp84ijvIoUSTlnUnGCn8AI+Xvzmm/Ca/sU8AwrJf24dbiTzA0y5QliQD0wSBkD05qj8Mri2Hi 3xe3mwDzr8eUd4Jf55PunOCPoO9Ai78O9c1vxZaahNqGsOj203kqtvDCONp+Y5UnOefTjoeah8K+ KNYvNf8AEkOr6nI1pokjELDbRhpVBcEPhck4Axt25rL+GuvaT4Yt/ENrrepW1hcRXxPk3Em2QjGM Bc/N06Lk/pUfgLUkj8YeNvszpDqFwxa0s7tgskkgaQgFcjkEjIyCM9utAG7ej4lz6Y+t217Z2kmT Imi/ZA7CMHgGTJJcjqBjrxg8VpeGPHo13wZc6xJZFr60Jjls7bLNJJxt2jkgNkdc4564zWR4Z8Ze I9f028urrU/Dely2UrRXNvc2sgaLAByxM4wPvdv4TVv4WaRNa2GqaxLtWPVbppLdFiaIeUrMFbY3 Khs5GecY5OaBm7HpfiO8iE194hNjMxyYNOt4jHGOeN0qMzHp83A/2RXN3/irxB4G1y3h8TTQ6loV yCseoxQCKWNhj76g7eM84AyBkcjFej9a88+MscUngqHf99b2Py8juQwP6Z/KmI9DDBwrKQQeQQeC KWsPwc8sngzRmmUiT7JGOX3ZGODk+owfxrbNAw96KOBijjr2oAOgoHTNGeKO1AgFIOtLSZxQAp6U dBQelJmgBea5T4kqG+H2qg4AxFyRx/rUrq+1cl8TcH4d6qCM5EQ495UoA609aQ0p60GgApD1paSg A7iiiigBe9B4pOtFACijHFJQD7UABpTSdTS0AJ1FKM0Ue9AAelJjilzR1oABzRSY5pc0AJRS0h60 AHNLmkpaAEooPWj0oAKDRQaAEp3ako7UAFAoo7UAFL2pBRQAd6B1pfekoAKWk6Gg8UAGO/akpc0t ACGjtQfSjPFMApKU9aOhoAOaSl9KPagAo70UGkAGjtRRigArlPHbBbfQCSoP9uWeA2Ofn6cg811Y OK5Xx0M22gjGSdcswBjg/P3+nX6gUAjqj1pKcaaegpgL2o7UnalJzigA70GkpT0oASlxQKO9ABSU tFAB6UDrR2zRSABQPrQKM8UAFBGKKKADvRRRQAmKWkpe9MBB1p1JyKUUgAj0pKDR3oAKKOKO9ACi k70Cl70AIaB0opR3xR0AcvSihelFIo5fwsQdEtRjnb/U10a9cCuc8KHOiW3sO/1ro4+fb2pkIfSG ilNAwxR0NGaQmgBeKKBSUALSHpS9frQelACDmlPFHaigA70Gig8UAHeg0nelIGaAA9aKU4pO3Hag BM80d6B+tA4NMBQcikzRRigA70UdhQKAClHU0nSjpQACjijNGaAFHSkzzR2o/ipAL2pO1L2pOuKA OV8AxxJpGotGIxv1a8YhMYH75gOg/uhfwxXVVwPg/wAV+HNPsdRsbnWNMsng1S7CxTXKRnYZWYY3 EZGD1HpW63jvwiEdz4m0jCkg4vEycegzk/hQgOhFHtXPHx34RGM+JtJ+Y4H+mJ/j096T/hPPCOEP /CTaThxkf6WnH154+hoA6I0Vgf8ACceE8L/xU+jfN0/06P0zz83FL/wm3hPIH/CT6Nn/AK/ov/iq AN7tS9qwB448JsxT/hJtHyDj/j9j57+tMk8eeEYwN3ibSST0CXaN/ImgDoRQfrXPHx54RCb/APhJ 9IxgH/j8TPPtnNC+O/CLsQvibSMg4ObxB/M0AdDWL4n0FfEujHS3kEcUs0TTNgZKK4YgcHkgY/Go f+E78Jnaf+Ek0rDMVB+1J1HXvwPfp055FI/jzwjEAW8TaScjd8t2jHt6H3HH+FAG7Bbw2tvHb20U cMMShUjjUKqKOgAHAFNW0to7prpLaBbhxtaURgMR6E9TWD/wsLweULf8JLpmAM/8fAz+XU0n/CxP Bok2HxLpmd4T/XjGT79Me/SgDpc1ELeGOWSeO3iE7DlwoDNjOAT+J/Oueb4h+DkZ1bxLpuVJBxOC OOeCOv4UD4ieDjGrjxLpuGXcAZwCB7jqD7HmgDITx/Lf6Zq9ldaLqel61HDItvai3eYzNtO0odmD yO4x0OSM42/A2gz+G/B1hply4e4RS8pHQMxLED6ZxUX/AAsbwbsLnxLp2AcY87n8utIPiR4NLBf+ EksMn1cgfnigDqK81+JEc7eL/B8sVldXaQXLSPHbRlmADxnPA46HqR06it//AIWZ4Kzj/hJLH/vo /wCFDfEzwXGcN4jss4zwxP8AIfpQFyXxN4pj0DSLPUZdE1C8aWZVWGKEM8JIPLdccZHHrXSq25Q2 CMjOCMEfWuV/4WZ4LAOfEVmMHHVufpxSJ8TfBcg+XxFZj/e3L/MUCudYc/lTSoKlSoKt1BHB+tcr /wALN8FdP+Ejs/zb/Cj/AIWZ4L/6GKzPGeNx/pQFzqwoVQAAFAwAO1L25rkz8TfBQUMfEVngnH8W fyxSj4leDCf+RjsgOnLEf0oC506wQoIwkUaiMYTCgbB6D0/CnkBlwRkehFcp/wALN8FZA/4SKz5z /e/w4pW+JfgtSB/wkdjkjsxP9KAudTHHHFGEjRY0HRVAArzfxG11bfGXRb1NOvLyCGwKsLWJ3Kbj IMn+Ec49OvNdAfiV4LClv+EjsSBxgOSfwGMmlHxH8GkkDxHY/wDfZ7fhQM6gcqCVIyOQaBgDAGAO grlf+Fl+DMA/8JFZ8njlv8Kd/wALI8G5P/FR2GQu7756Zx6dfbrQB0zwQyQNA8UbQsu0xlQVI9Md KeABgAYA7CuY/wCFi+DsE/8ACSadx/01/l60i/EfwYxIHiTT8jJ5kx0+v0oA6QwQ/J+5j/dtuT5R 8p9R6Hk1h+LfEdp4atbK7u9Lur9WuAifZoQ7RNtb5uSADjI6jqarp8R/BrtgeI7DOccvgfqKX/hY 3g4cjxJp543cS574/wAigCDxqdVb/hHNQ0W0muLqLUUY2+TGXiaN96sTwvHduhx9KsL4601GWG+s dYsrwkr9mk02aRsgkfK0asrA44KkggipD4/8IiLzP+Ej00jOMCcFv++euOeuKIfH3hGZmC+JtLGD j95dKmeSONxGeh5H9RQMwNM0HU/FPjCPxTrttLp9raBf7NsXYeYcHO6QY+XnnHB6Z+7z6ETXPHx5 4RAJPiXShgE/8fSZwPbP/wCvtTD8QPCChj/wkulnaMnFyp/l39qBHRiiua/4WF4P2Kx8SaaAzbQD MM547dR1/n6Glj+IPg+V9q+JdMBJwC84UfmcDt1oA6Q0dq5wePvCBAI8S6Xz63Kj19/apP8AhOPC eSv/AAkuk5C7ji8jxj659xxQBv0tYH/CbeFTyPEujn2+2x5/n702Lx34RnDbPE2kjDlPnu0XJHpk jI9xwaAOgoFYB8ceEx/zM2jHkDi+jPX8ad/wmvhTOP8AhKNF/wDBhF/8VQBu96hvHWOyuHZxGqxM S5zhQAeeCD+tZP8AwmvhQH/kaNF/8GEX/wAVUN54x8LS2NxGniLRZmeJlEQ1GIFyQeM7h16daAJP A+f+ED8Pkhgf7OgPzZz9wetb465rifCPi/w5B4M0SG68R6VFPFYwxyJLexqysEAIILZzkGtn/hNP CvJ/4SfReOT/AKfF/wDFUAbpFHpWGPGfhZuR4m0Y/S/i/wDiqB418Knp4m0YjGc/b4uP/HqANwni jmsI+NfCn/Qz6L/4Hxf/ABVKfGnhYf8AMzaN+F/F/wDFUAblJWH/AMJp4Vx/yM+i/wDgfF/8VR/w mvhTGf8AhJ9F/wDBhF/8VQBu0lYQ8beE+P8Aip9FGRkZv4v/AIqkfxv4UT73ibRvoL6In9GoA3u1 J3rCi8b+FJchfEukZBAwb2MckA8c89e1L/wmvhTr/wAJPon/AIMIv/iqANBdJ01NQOoLp9ot6Rg3 AgUSEem7GauD161z83jjwnDDJK/iXSCqKWIW8jZiB6AHJ6dB1p//AAmnhQEL/wAJPooPob+L/wCK oAoeMNN07TPAniCSy0+0tmks5BIYYVjL5HOSAM9ah+GLKfAVhYy2d1C8CN5iXNs6K26R2BUsoDDG DxnqK1x4z8KHj/hJ9FP/AG/xf/FUDxr4VYFh4n0bA65v4v8A4qkBrpaW8cckaW8SpJneqoAGz1yO 9EdpbRGQx28Keb/rNqAb/r69ayP+E18KAgf8JPovP/T/ABf/ABVIfGvhTP8AyM+i/wDgfF/8VQBo WOi6Vpkjy6fpdlaSSffa3t0jLfUgDNXawz428KKQD4n0b5j2v4j2z/epF8beFG6eJ9FP/b/F/wDF UwNY6fZNdG7a0tzclQhmMSlyo6DdjOOT+dSQQQ2sKQW8McMSAKkcahVUAYAAHTisf/hNfCnbxPov /gfF/wDFUjeNvCigsfE+jHAzgX0ZP5BqQzRj0jTIr+S+j06zS8k+/cLAokb6tjJqr4j0ptZ8P6jZ QrCLm4tZIYpJRwpYY64JA+lQf8Jr4Uxn/hJ9F59b+L/4qj/hNPCv/Qz6L/4Hxf8AxVAizoGg2Ph3 RodNsYVWKNfnbHMjd2Y9yf8A63SprXRtLsbmS5s9Msre4k+/LDbqjv8AUgZNUP8AhNfCmP8AkZ9F /wDBhF/8VR/wmnhX/oZtG/8AA+L/AOKoA2J4IrmF4J4klicYeORQysPQg8GobTTbDT4HgsrG2toX OWjhhVFbjHIAweOKzB418KspI8S6PxkYN9GCccetJ/wmvhQdfE+jcjP/AB/Rf/FUAXIvD+jQWs9r DpFhFb3AImijtkVZAeoYAYP41HrcunaX4bvZb61EmmwwN5tvHEGBTHIC8DH5D1qD/hM/C6kg+JtG 4/6fov8A4qkfxf4WZSkniTRSpGCGvosH/wAeoAboV5oPirw5b3FlYwvpu8hIJrZQqspxwuCOPUVS 8J+CrPQprvUbi2hfVbi6mk8773lxtIxVU4+X5cZwByT6CtBPGPhYghfEmjYUgf8AH9Fj+dB8ZeGA Qf8AhJNG9/8AT4v/AIqgC+2iaVJqa6nJptm1+v3bloFMg/4FjNTW2n2Vi8z2lrDC87tJK0aAF2Jy ST3OazB4x8Ln/mZNG6Z/4/4un/fVK3jDwupIbxJo6kckG+i/+KpgWLnw9ol7ei9utG06e6GCJ5bV GcY6fMRmqHjue+tvBmoXGmSSpew+XJEYiQxKyKdvBGQQCCO4JHerI8W+GjgjxFpB5A4vY+p6fxe4 o/4Szwy+4DxDpBA+8PtsfH/j1AGZaePtKS1iXXGk0jUduJrW7hdMOOuw4IYHtgnNc1rUN/8AE/V7 S2sraaDwxZTCSa6uUaE3TZIPlj7xG3IB46nngV2x8Y+F+/iXR/X/AI/4v/iqf/wlfhzJz4h0njGf 9Nj4zx/epAaltbw2ltFbW8axwRIEjReiqBgCpPWsceLPDh6eIdJPIH/H7H36d6cninw87FU1/S2b JXAvIzz6daBmsKKx/wDhK/DmAw8QaVgjIP22Pkfn7H8qcfFHh9Mlte0sAAEk3kfQ9O9MRr0grOfx BoqEb9Y09TnHNyg9Pf3H50xfEmhOMrremn6Xcft7+4/OgDUpBWX/AMJNoBIA13TMkE/8fcfQde9O bxFoaNtbWtODZxg3SZz+dAGl2pegrM/4SHRMA/2zp2GPB+1Jz+vuKcmv6NISqavp7kddtyh/r70A aJrkviU6J4DvxJjazwKRv25HnJxmto+ItCwp/tnTsN93/Sk5+nNcx8RtZ06TwVqMEGo2ks4aAmOO 5TeB5ynpn/ZP5GgDuQQ3IIIPQignFZx17SFVW/tSyYHAB+0pz+tKmu6RLny9VsXwcHbcocH8/cUA aFFZsniLRISBJrOnJlSwDXSDIHU9egofxDosbOr6zp6smA4N0gK5OBnnjJoA0qB+tZv/AAkOiDk6 xpw5A/4+k6k4Hf1oTxFochKx6zpzMDghbpCR29fWgDTpKzx4g0UsoGsaeSy7wPtScrkjPXpkEfhS trujo+19WsFbGcG5QHHr196ANDtRVD+3NIyF/tWxycAf6SnOenelXWdKYlV1SyJHJAuE6fnQBdNL 71TGraYy7hqNoVxuyJ1xj160r6ppyKxa/tVCkKSZlGCeg698jFAFqnDoapyarpsKkyahaIB13TqP 6+xpy6jYlN4vbYr6iVcfzoAsnoaKrf2hZHGLy2+YZX96vI6+tBv7JX2m8tw3oZVz/OgCyDzSd6rH UrAZzfWowwX/AFy9T0HXqc05by1f7t1A3XpID060AT0d6rNqFkkZka8twg6sZVwM9Oc0PqNjGm97 22VM43NMoGc4xnPrxQBZ7UtVv7QseP8ATLbk4H71f8aZ/amnl9gv7Xdnbt85c5xnHXrigC39aU1Q /tzSfm/4mtj8q7m/0hOB69elSPqenx5339quBk7plGBnGevrQBbpD1qqup6e8aul/asj42sJlIOe mOe9IdU08ZJv7XAXcT5y8D169KALYo7VX+32ecfa7fPPHmr/AI+xoa+tUAL3UAB5BMgHHTNAixQO lQJe2kke9LqB14+ZZAR/P3FKLu22bvtEO318wY/nQMmozxUS3EDY2zRnPTDjmnNPEi7mljVfUsAK AH0fWo/tEO7b50ec4xvGc4zilMsahi0iAKMsSw4Hv6UAP/xopgkjOSJEPOPvDrSvIkYJeRFAGSWY DAoAcKYXYZLLhR0Of50izREBlljIboQw5+n5j86V8vHmMhskdDwRnmgB9LxUYlXBbPyjgk8AU4YY Aggj2NADqQUd+o56e9MMsSxmQyIEUEltwwAOv5UAPNFIGU4wynPIwetNklSIFndVUEAknHJ6D9RQ A6l703cucbl64696XIzwQc9OetAC0dqQEHGCM9Rg0uRg5x1oAK5fxpnHh4cY/tu2yS20DG4/06V1 H1rlPGpiki8OSscwrrds+9cFR97BJweMkDPHUc0AdXnmikxRTAWkpe1GeKADFBo9aCaAFHFJRRSA MUHrR3o6GmAUDrR3o6nNIA70UDrRimAtIaKMcUgDvR0pRSGgAo70Ud6AA8mjpRQMUwDHSig0dKQA aO9AoxzTAU9aQHmlpO9IAOOKKKKAHr0opEzt5opFHMeGht0K1J/u/wBa6CPO7rwB0rn/AAwA2h2h zztPGfc10adBTIH9aSlooGJR3pTSUAL0FFA6UlAC0dqQ+9HagApQKQUtAB3pDS96Q0AL3FBOaSig BeM0UnWlzQAlA70Cj1oAWkHQ0UlADs0n1oxzQOtAB2o9qO2aKYBRRRQIOxo70vak70hi5yKTrR2o FAHg3h23s5bLUJZrOzuZTqVx88tskmRleMkHjn1PXrzWq1lp2RjTdPLZzzaRkDqOPl44rN8Llm0a cnbl7+4cnAAJ3KP/AGX1rXHC8E9QTgiu+jCLgm0eBiq1RVpJSdiI2diAMabpoIPGLKI55/3eRTTZ afgr/ZmmhXIJU2cXOOBn5e2KnJEjgfLnPTv+NIFXGMggehrT2cexh9Yq/wAz+8ijtLBGUrpunqwI wfscXbp0UUfYdPwqtpOllUAGPsUXOB/u1J91gwyP9nipMFsgOpI6jdx+FHJDsL6xV/mf3jEtdPHP 9maWQB0axi5/8dpPsenjC/2ZpwAAOPscfYkjPy9s1JuG8MrL0PQjinHLHgg4JznBzR7OHYr29X+Z /eQra2CbSul6blSGBFnGDxnByF96jFhpyABdL03OQeLKLIx9VqyWyAgZcnkcjHT9KQgsoAIyTznF HJDsHt6v8z+8jWzsFOf7L0wHjkWceeP+A+nH0pwtLLdhdO09ScE4tIhuPIBPHoSKeW3MCMdMdhTS NrcNkcDqKOSHYHXq/wAz+8YLayB40zTwxULkWcY/9lo+zWWAP7PsMDt9kj98H7v1/OpuAdxBBxtD Yz+tNDZwoAOD+OaFTj2F7eqvtP7xPsdkTldPsAd24AWcfy8EDnb2BwKc9tZkDGn6YAMdLKMdOB/D 70KSo4POOp9P8in4K43Zz3z16+55o9nDsNYir/M/vIfItoyCtjYqBgcWyDA9sDjHT6H3pBa2Z3D7 FZIh6AW0fHXH8PvipSRgkHikyDJ85XDA5x9KFCPYTrTvrJ/eQm3t8f8AHnaAdOLdQOMgdvc/macI 4BtxaWnBDYMCdR04x2zSsQOSQc+4GKDkNtypB9/88UckewvazvuxqwwLhktrQMOh8hO34cUixWyr 8ttbDByP3CAA9PSnAgccA9BgcE+/4UighgfTqAOM0+SPYPaz7jlWFdrfZ7XKYCEQLwAMAdOmO1Rm K2wD9mtsgg5FuufY9O2TUnUMu4DPbt/OmdeuM59KXJHsV7Sdt2II4Fwy21suBwViX/D6/nR5duuW W0tMqQR+4TGACPT/ADk07JMZGc0gJUH5gRj8vp+VHLHsL2k+4ghtjJua0tuTk/uEPqOeOnbFAhgY qFtLVjwf+PZDnjAz8vYHFIrkKRlcDptHNVry2nvHigF41vY7S0/kMUkmPaPIPCnOT9PzTilsioVJ SdnKyLxtolAQ2lkec7Whjxz0OMe/FD21tGg/0CyHTG21QDI6EfL+tUJNC0S6svssmlWCREfM0dsi SjHcPjOa5rRtTufD+rPo1/JLLp/neSHkBJgz910yeFIIJHTByB64yai/eSOqnF1Iv2U3ddGdkIrM jBsbJgMEf6MhIIGB2pxtrUsD9jssYGQbZMHGccYPqaQfKSny+xB70u5cEcY9u3H8q25I9jkVWps5 P7xotLUI2ywsAMYA+xx/NjPT5evX9ake2t0Uo2mWKHbyDZR5GBjP3fT+Z9a43Rpo/Efiu9u9RhN3 BBCxghmjVowpcIMq2ecEnjnPpipfCV9cRaje6PNK7W0DsYN2MIQ2Cqk9ARg46cVhGcW/h0O6dOai /fd0rs6s2FsUJ+w2ROVHzW6dhgY+XqBx7Zp7WVuQ26wstuRuQ2sRUYBx8pH1/WuHv/CU1417quoa lb2aGSSQRyRmQqhPy5YMeenAzgnirnhXw6lmBqlyUeSQHyVbkqueGI3HDEE8HoKE25W5QnFRp8yq P/gnTtaWLfe0zTmOeptI+OnGdvTin/2bp6qG/sjTRkAbRZR8dcEcdRk8+1KwbawDbcg8jGVPTPP9 a4a8ibSvF9illc3oZvJed/MLPKzMQ/Tgg8nH1q6nLCz5TLDupVbXO0dtFYWg+aLSbFSqr0so+cdP 4ef/AK9OjsbZVQjS9PGPm3GzjGfTt1Gf1rj/AB1GYGs54Zrje7P8vnZChQMbVAwOSeaqaxZSXmqW 0OnapqGpai0QaeS5uA4gY8jD8BR7ZPIx7VnOaTaUTalSnKCk6jO3Nraj5ksLAMp7WkYPH/AaRbGy dTGNJ01gFH/LlGCuOAenvjnjmnkskYV3DMowztt59T0qhfaR/bDLDfOTp6DIghbaXbuXbuMdAPWt nFJXsjlhUm52c3b5lt7CwjYO+laau7bylnEQQOR/DjtTE07TyBGulaavIIIsowScYHO3P+feuQtE n8LeLv7OV5GspCE8pfmyr42nGR8wJHPHI9K2tR8PJq8cn27UrrzNz/ZxHIPJg6Y+Q5OeBkgjr7Vk pKUXaOp0yjKEkpVHZ+pqNZWMKlJNJ00deHsIvr3WnSaVZM6s2jWL7cAf6CgCgAjBwvp/SuQ8JX80 ktzpN2/mRbGdEkG7DA4ZfmGSCD0PTB9ao2EcbeNGt5Nxt/tEymMt8gADEZU5GBwQPp0xS542T5Ru lVUpLneiv/Wp3402xKFm0XTeEAOdPj6A8cbf/wBdJHptl/rE0XTSEIwVsYyFI4/u/wD1ua4dreI/ EBbWRka3e5UmNvlj5U8bWO3gnp0/lS+LpJtP1WG6t7ucPIhlbMzbchj8uBxjGP8AOafPGzfKJU6j lGPtHqrnbf2Rph5/sTTQu0KCbJB2Jz056/y+tA0fSjIHTR7AgDGDaoVwMk9Rx3Oetcbf2d5J4tS2 0zVL+7lVEee4d22xE5JyVwAuO3uBVrxhFcW3k6hHqF4ly9wFRopmjEShCQqhenI655zRzJpvl2K9 nNSUfaPX+u51cem6W7LHHoumLJ0G21QZOOM8evP4/SntoOmA7jo2nJwPnW1TGGHsOTg9ev5VzGsa hfzeDLW4gkbfcLElzMoOV4x1HIywwc1HpMOm6pa6e2lstpqFtMhubdmK/aQpGTjo4GRg4yOQaHKP NZRFGFXlbc31OqOiaa7gx6FYksNv/HkuCcdcY5z/AJ9aa2k6WXKNpGmNtXC7rWM4GD3x6VxfiNvs 3i5Y47h4bdmhkkiiZgnzYJJVcDJ5z/OpvEd1FaeKbKDUIHk0aCOPFrEchlwd3BAUtwPwQfWk5RV/ dHGnUly++9Vc61tM01EkRtJ09FK4ZfsaDtgfw+35jNIukac7caLpwZSCNtoikYHXgD3/AJ1m6ZaK 11eajoc0UlpdwIsCEuywTL1BU5IGH6ep64HOX4j8MSWNidViu7576HBmmmmLMy5A3KcZXGR68Gqc la6iiIxk5csqj/E6X7BpwYn+ydK3Hg4sY/px8vt/OgaVp7rk6Np/KhQTZIeAOB92s/QtVm1bS/Ou WD3MZ2SOqhQcdCffGMnufrXNeK49muiK1Yw+dAgZInILsWOScDGT0/DvTlKKipKIoRqyqum5vQ68 aXpSsSdJ0/OMYa0QdAe2KX+ytL3lRpGnlWOW/wBEQdu2F4/yetTxJGkKxQoFRUCjj/6wqnfae2ou sM19Pb2QGWitJNjStn+I4OR7YH1q3GNtImEKtRytKbS+ZNNpWnbV8zSNOBPAIs4wenqF5oGj6aWY HR9NyRxizj5/Dbj1/wD11xkRuvC3iWOzS5kms5CqlCWIeNuASDxuU9wO3oaTxHCtv4mggiMttbyr EH+zkxs2WILcYG76/nWPPG1+XU6/ZVOdJVHZq52g0vTgWZdG07dgbgLNRxj0x0//AF0h0fTg5U6J YAqegs0Unt2UY6+3r1FYniy2gj0Vp4sxTRSJGsiDDFOmM+nP6VDpVvBN4MllKBp3imPnNksrqWCk Mc8jGc9smq93mtymS9o4KfO97HSSaTp6j99o2nYJz81lH16YyF9qlGj2M8aH+xdOfkKALFCemB0X OMemBXHeDxJKmozLMHudqIkkoZlXOSeD1ycenSn6/wCHDZ2h1a01W/kuoCpmeaf5mOcBkYAEYJHB z7E1N1y3UTXkkqnJKo/xOnTStJw4/snTCCQG/wBEjBxk+369an/snTAVkOiaavQbhZqpB5weAMZx /nNY2jXGpeINBjX7ZHDKGNtc3MYfzNirkYAH3yCAST7jmsbxBpVx4Tnsb/S7+8iM4dCZnySyhTzg cg7sHOelEpRtdR0FCFRycHUd/mdauk6VI6oNJ01WbK5+xRtjjH9w1meKtPtrTSJb23srS2lRo0Xy rSHZtJ2kEFT04xjBzWf4r1110KzSynMf2+IyuyEqdoAyvB9T+OKTU9Ls9M8HAWBmRnWF5d7E+eWI PzrnaCDjBHIxjJom07qKKpKpHllOb1exf8MWVnc6Kl7e2VlczTu6kyWce1QpKhQNgAPfjPWttdH0 1gHTQ9ObA3ZFhH78n5cdDj8K5nSNROl+BTdQRLLNE7hVKcBmcgE98D/PFXPDkGl6npZuLoJqd42P tbXIDyI3QAEjIXHTHT8KcXGyjbUmp7S8p8zsn0Ng6bpsWUOj6YDg/fsYgR2/u8dvpQLHTjgHStLy e5soicYAxyvTArIt7O4svFy/8TC+ntDZyC3juJ3l8o5AKZ6Adx3+tbS8Hk4I/LpWsIxe6OatUqQa UZt3IG0rS85bStNwQelpHxkY9KT+y9KJz/ZOn9QeLVAc/UCrPBJ6DC+v/wBalGNm44PPc1XJDsZK vVf2n95TGlaQIyF0nTc8432qEjPHpR/ZGkgELo+np/u26+hHU1b7g45pCTgEKD6nufY0ezj2H9Yq /wAz+8pHSdIOG/sjT+mObZT2x6YpP7J0cDjSLAANn/UAHPvjr/k1bIyvIAPqKZnnAP4kdKPZw7Ce Iq/zP7yA6TpDIAdH04nGB/o65H6Y/wDrk0n9i6PjB0mx6nkQDIz/AJ/rVpThQGAz0pQwOMnr6Uez h2H9Yq/zP7yBtE0dwxOjadgjoIEG04x6DHT+dINH0Y53aNp5UknHkAenfrjj+vWrBwdwzgg9RUob cy5PI9RR7OHYXt6r+0/vKg0XRThW0bTnxwoaH9BgjHr/APrpq6HopUqdJsTuGOYR/n169/er33iV BzzyBS85AGB34o5I9h+3qfzP7yidB0M5f+xdPHU5WAAgnpjn6Uf2JoucHRNO4Jb/AFQGfarzfdwD 9cc0pb5yRgdCOuKOSPYTr1P5n95QGgaHgZ0ayOPWIHPUfXv+fNKfD+hMGzolkT2Bj4Ax/nmr+cqQ Bx9KAQzD06cCjkj2D21Rfaf3lD/hH9CyCdFsML28oDI/D6f5NIdA0LodGscY5Jjx2/8A1mtAEnOQ PxHWgnAJxjAxk9qfJDsL29X+Z/eZ3/CPaGQf+JLY5Bznywcfr9aRtA0LOBotgB2AiyMfj9a00IyB gZHbpnFNyg+6AvHVVI/UUuSPYft6n8z+8yW0DQy2To1n2/g+uOKX/hHtB24/sSyJI5wnH860yQxz nn/aNMyAMNjdn06UckOwOvV/mf3lAaDoIdW/sSwJPDARjB4/T/PNL/wjug8MdGsuOP8AVkhh6Gry sBnpxyBjpS7+hyMDv2o9nHsL6xVX2n95nL4f0EZY6PZAknjys9vrmsnxLomkWWgT3Frp8FvLGybZ I155YDA7dD+ldKH+Y8Y5546e9Yvi1w3hu4VuC0kQyD0O8cVFSEVF6G1CtUdRJyZZPh3Qj10e23d9 6gtz6mhfD2gAAf2LZMe26PIrQlZmkc5yM01GIJBA6VSpxtsZzxFRS0kyl/wjuhAbf7HsRnPzBDn2 70reHdDK4/sWxBPIATGPwq6FweVAI6k1IX5HOOPTHNP2cOwvb1f5n95mnw7oeMLo1lnG3ITB/Q0p 8OeHwTnR7LGMZZc46c/z/OtAknqSfqeaeHQkYH0J6fT9Kfs49ifrFW/xP7zPHh3QfLb/AIk1kBx0 QDPHt1oHh3QHJ/4klirHoBHitAYAIHGR9M0rP84B++Ccmj2cOw/rFX+Z/eUG8PaC0n/ICsMZ4Pln H8/881Gvhnw+wwdEs8Y52qR/WtMMCuQCSOpPrzTOfmJ/wxR7OHYPrFb+Z/eZzeGfD20k6HZ7WXC7 V59M/WlPhnw8zhjoliB2CoR/9etEEEdvU+tOBAA6k49B1o9nDsH1it/M/vM4eGvDzlmGh2m45GAp wM8dCf8AOKVvDHh7gnRLInpyp/p1781oghcKFxzyMChiMjnoOwHfFL2cOw/rNX+Zmb/wjXh45zod lznIIPf8e1N/4Rbw8SVXQ7LjJHB/xrSLDPIGf7uKGOWBY4z3xR7OHYPrFX+Z/eZi+F9Aw+NDtWAO PlU5H68Ug8MeG8rjRLTIH+0Sx9eTUN3pGqX8b3Davf2d4FZYLe0uWEceM4DEAEknqeOCKoeGdfvd QgntZ3Et7EheGe5Y5cZAw55LEZ/L1rG8eazidaVR0+aNRu25rDwt4f2qf7FtgoBBIz7evemHwxoJ cMui2p64IUn+v5Vj65YavYWZ1GDxHfTSI22X980eAcD5ApwF56Yq7p+oz6t4Zubh7iUX0McgaeGU xMrqMhsqQeR2/T1ScbtOJTVTlUo1G1sXP+EX8PHDDRrQLyuSpwCfx6j/ABpW8N6ACR/Y1jkDGRH+ HrWJ4bu7rUNP1SW8v9SklSMeU5vpi6EqxGBu/vAZNJ4SvdQ1GW6kvNU1GeSOICMz3MkiqxzztJIz 6ZoUou3u7hOFSKk/aPT+u5tnw7oCsrHRLEj12nBz+NA8NeHyMf2JZ8dwvNc7pk2pjxZc6TD4hvkh LTJ5s7GUbQM7sMcKcfxDpUnh681i61WZF1a7vrJFdfOuppHQnOFYAnGfpSU4N25SpUakYuXtHtf+ tTePhnw8CS2jWgJypyO+Ow69v1pB4a0Bj/yBLQqB0VT3GO351gXt7rGleIrO2Os311HI8bPFLM3l vuOGAQZCjOT0BGal8S6k9rrtrBO90unIod0glZDKCeSWGM46fnTcoJO8RKFVuPLUdmrm03hjQVXn R7Q4JDHZ2+ufb+dMXwvoR3EaNbMeMnBPT8celM09Jhqr3NvqU15o80TeX51y8ohYEfKu45AA9ckC srStQm8Q+IJ5Zbq4jsLdS0NvFM8YbnAJxjJ6nnnge9HNHT3dyeWpeXvuyNf/AIRfQXAX+yLUkdTg 5/Hnr/jTv+EX8Pncf7HtwFxkEHgeh5+lYum3d6njIWD39y9pbvNGkU1wx+UA4B5+bGBjOegpviO8 1HT9et0s9QvbdJY42CC5kERLMQfl3YwcYIwBx+NDlDlvylqFXn5PaPa/9am6PCvh3O7+xbfIBHO7 oefXGf8APvS/8It4eBwui2nH90E54+tc7rs+p6Fr9s661d3BkUSSC4kJiJ3FSuwYG3j0yPatjxRr r6THFFZsqzXDMRcDB8tARyuO/P6UJw1vHYmUazcVGd7lgeFvDw2/8Se3G0Y3c56cdTUsnhTw44Zf 7FtkXGRtyM8DHOfY1N/Z48uKWDVtVLtGDFef2g7l+nzckqwPGVxjt71V8Ptf51FNRvPtNxFc+WXL ZB+UDIHYd+O/vVqMXZOO5nKdRJtTehJ/winh1X3DRLQ9cBt2ORjpn8RSf8It4b2g/wBj25Byf9Y3 U++fXmtUlnJ3gnaMAZzTerZAYEnjI7d609lDsc7xNbpJmWfCXhvzWf8AsWIswww3sAvGMjnjsc+t H/CJeGiuP7GttuCvyswJz36mtXLYy2fx4/LNJ9N3pyc0exh2F9brfzMyh4R8OhgzaNbjA+XDsB0A 6Z9s/wD66VvB/hznGjQHqfvMOv49u1apyMEk5HXJ6U5clvukZH5Ch0YdhrFVtuZmOvhPw2WVv7Eh zg/KGfaOMdM0xfB/hxTtGkRscYOZH5HHvnsfzrZHAGRwB17/AP6qaCwIYkUexh2D61W/mZkt4Q8N KONHU5DAkzMep6+xHP500eEfDhcn+x4sMpwPMfjt69q1w4CjA5xx16UoGHJwPQccdKPYw7B9brN/ EzJbwj4eAA/siHgYB3OCP19s9O9J/wAIj4dJONHgC5wBvfPA57/X/IrYxgHC5OeQOcUmSc9ODyMc g0exh2K+tVv5mY48H+HAQ39jx9x/rHxgjHTPHPNPHg7w0VwdJUNtPzCZjzz2J6dPyrWGNg+9z6E+ tO4J24GPWj2UOwvrNbfmMUeD/DmFJ0tCcYIMj47AcZqpqHh7StLn0aTT9PMbtqUMZfzM5+YEYLcA 9OO/NdMpCr16/lWZrkigaJGFw7avAwZCQQBxx+Ldazq04xi2kdGFr1JVEmz2+ignmgVwnsh2oopK Yxe/FBoHBoPWgA6UUAYo70gCg9aBRQAfWjvxRxigdaAAUUUCgAFBo+lB6UAAJoNHajtQAZ4oNJSk c0wDtQMUdTRigA75ozR0Io70AAPFGaMUUgFFGeaSl70ABxQOlJSjpQA4dKKB0opFHLeFvl0S1x3U 9Pqa6OMkjmua8LjGiWx574/OuljzjmmQPHNLiikNAxaMUgyOtLQAdqM0UDpQAYB60H0oooAQdKB0 o7UA0AKKTHWlxSUAAxS44pO9FAC0h7UuTR9aAEHWge1FAODxQAdaKOpooAWk70uaTvQAdaDRQTTE IKXikooAXOKO+aDRigAzQOtHajpSA8I8M7Rp17yzbNSnHzkkgbhjsMfhWuwDZJHH0xWf4fRk0y78 85calcgsCpB+YHOR1Bzn0q+zEk+5PfgV6NH4EfO41/vpAjZXaGHXnI/z7VIpxg7uoyMg/p+VNKh3 wFIHYHtSshGF+YBRxk5Ga0OeN0BDEucZwT7/AK0g+UgMOep6DjqKDg8AHngc803ABHzEEYHHT+dA Nj8rwSR+I7UDaQRxgHg47f5FHGOScHoCc8ds01gNzHnAyKA1BmwV5I64+XNLvHYZA7mmKAVJyRxw KcAc4AyAOcUxXZJxjBHK8YA/nTc4YjnjknH9KCDnAxz79qQjcTkY45JNIofkHgDI9h0pvPAzwPQZ prADIHbjmn/LwQ3A9+1AhTtClcEc46DpSqRyTnkdNuB70wsT9QMDNPXaq5GMHrn/AD9aAW4hA5GC AB1A70jKA5IUk+/8VKcZIKjP60nTJYn056+3egGriAKV7jvgCkLruwWIz14FOHUYwBjB+n+TSBQB 7Yx0xg59c+9DGtRozwAGPseTSDjP3unUijkHBP0B5oUAsxyD2PHT/OKADcwXKknB9Bz9aVWUkqc4 9SOe3bpTWjYjHTsaaCBH2x7dvegLgSBwTg+4yKCoz9/jr0oKrnGOfWj5QBnIxnPHSkOwmc9Bzg9q Z5kck/k78y7fMKAc7M4z+Bx+dOOTjOd5P8QrIvtMvLnXLS+trqK2W2g2ZeMuJGLElSo5x69OoqZN paF0oRk2pOxsrgopAII6cdTniuA8UQte+LJra1LGWZ44VHOdxVRj8/0Fdhcza35TQ21hpKTMoBuG u2dV9wmwHPB9RzVXRPDcOjzC+nnN1qB37pVBCR56lRjJPXk/kKxqXqWSR2Yflw6c5SXoixfajfza m9hpUMDXqxiWae7b93GvQcDliSeeOODS6VqV3NrL6LqiW8N9HF5izWqs6TKQBnB5zkg9Pwptzpt3 FrMeqaY1vJIYjBPbXUjKrqDkFWGcHtz0P5UWdjdnWJNa1L7OLgoIre3hO5IEHJzkfeyT0/vHvR7/ ADdf0sNul7O7tt87nN+Bht1S7Ukg+RtbcCMHevOO2MY59aboaF/Gc7KzPjzy749T3wemfrW9baJc 6Prcuo6ZFDcQ3CMkltLN5bhsh8qdu3GV79s/WpNE0P8AsaGeaaWOW7uv9YIT8iDJO0Ej6c47d+tR GD0Vtma1K0LSmnujK1O5bUvF1tpDnNlBMvmxcqJCBuIbrn0z0/nXXqJGXcqgADACqMDHpj8K5XWf Dd/LrP8AaekSKshYOVMhjeN17q3vj8PxrS0/S9QM632uagbq6iBWCKLAii3cFuFGWPsB1xVwclJ6 bmVaNOVKLUtlt5mxJKYVaRo5WKKWAiTezd8Adz7etcD4lu1l8SWk/kX0C7YT5c9sUk4Y9E7+g9Tn 1zXoBXtkEYJ4Hb3qn/ZsCa22sSO7XCxCNOwjwTkj1yD+HPrV1YOSSRlha0KTbkjJ8W2lzrOnW89r BPJLC7O1uVIkIYDsM5IwOlQ3KapNa6VBof27TjHEPtSrbyQIh6kszAbzkkY56nrmum25AAGCRxnr 0pS3JwSyZxz69D9KJUbu9whi3GPLbYZKW2/N8xPPHeuX8QaHNPrNnqcNnJfIoRLmCNDISoPXavLD B5wO1dU+OTgABf5f41HzzycHtj0q5w5lYxpVnSnzbnMRaJHceLEvbawlstLiClP3bwb3C5BAYdNx NWPt2sWfiVEvDO+kyv8AI8VqzxoSMjBVS2eMEc564ronOQ2d27PUnOaZuZYx8xHvk9ay9jpozd4u 795aWscvoWkXdvqN3qN1HJCspkEdu+5XAZs5Zew4HByfpVOazvNP8a/bP7P1C4t3lLK9tG0u4uh+ UHGM89CRjFdg2Nwxk8YpSzFSuWCkYJB9qfsfdSTGsW1NykrpqxxqwaivjSHUrnSLyOAXCO/lW0ki oNoI+ZRycYqz4y0u+vnt7iztLi5jjjKOIFLOOc/dA6dema6rCgqcKSDnA4z0zSEBNwyfu5GOxI9a So6NXCWN96Mktjnp21C51Cyj8MyzWenGNRPH9iMMSHPO7K5kOOoGf61X8aXsM1nDHHFcqyztkyWz onQ/dZhhvqD0rrCSz5Ks2AD9P0qjqekxau9oLiTMFvL5rREZEnBAXPYc88UOi1FpMcMVBzTkrWM+ 0vj/AMIfZva2bXO1UieH7OxEwJ+dQCPmzznsO3SsufR7eXxBaTaAtwsBcSSqYJNlocglWLKOSN3G TyCK7ZnBYsTkknqc8elPaQ+UFLueCQpJI/z7elDoXtdiWMUeay3ucJ4rtr248QtNHZXUkflx5lgt mYLgcnKqRnAzW5rVxbXF/wDZb+xaXSmh3i7S2kH2ZjnqwUspIHQjjv7TX8PiJvEEDWF4E0wIvmgN 8oyTu3DGSTgcj19zWuxYHIYsfb8qSpttmk66hGD8u5xeg6NdeRrMSvcQ206eTbyyq0YlIOVfBwRg Ac/7Q4qCKzaHQbm0m0m8l1dZCqMIZWbZn74YAoV4xnOK7hSzMWLMWHUE80nRcbuOpHb3xT9gu5n9 ebbbXY5YPqHhXQLdIrAXU8kpe5B3sIiew2dOABk55rO8Qwavfan9rfS72KLy0IWCGSTy0z/EQMbv XpXdgqAwAJyuDgckdxx16U0AvlySSRlmJ9+5odFtWuOGNSfM46kUckbKrxuzIfusylT+IPIrI169 1+wME2lRySW+CJ1ig81zyDgjGQMDqPX3rd2luCeR09PzpFZg25WcHrwec1rKPMrHNSqKE+Zq5yl/ YT67r9rcR29xDZwopNxPE8W/5twChgMnntxz171W8VWl3L4hinhs7y4Tykw1tE8mMMx6jv7ZzXZy HhixLDr83P1rE1CPxD/a1u2nXqwaewAlUnIBB+bcOpyMcD09awnTaj3Z20cQnNLZJdyr4su4m0Z4 ytyXaRGV/s7hfUfMRwcdjz7VH4en8/wnPZqsxl8ucKrI4DAg42noTk4OD9evLp7HxHqWnTademAy PMrrcF1WNUHsPmz3xitiCyn0/QxYWM5M0MTCGQnb+8OTuOM98dPaklKUuYcpQhTUE9b9/wATn/Ct vf2cOoxPbXdpdyRK0QubeRUOAxByV4OcYPvUy6tq13oep6fqVpeyagyLHBGlg/zA8MTtXHBGcnvj Ga1tGi12K3b+27kTNkeVFlWZBjnJHHpx1zmtfzG24ZnCA59uv+TThTbitRVcRGNR3V9vwOXPhq7T witrAz/2isousJKQecDZkYAwpH4is6fSjqmiaVZ2enyjUst9rlaGVTGOg3M2FLHrx1wOTXc7eDn5 QBnp6+mKA7MAzdh1PJ+tU6C6MzjjX1Wu5zfibRHvdHsvskTyz2S+WQrli8eB0GMk5GfU59etXUdQ v9U8LraQ6RqRmVYluWe0cL8nAVcZ3HgHkcYrrggZ8KcEEgHPX3pxkY7N0jhVO/Ddj7U3Ru9HYUMZ ypKcb22Od8PwRt4Uey1JHhVjIZo7qN4QiZBVtxAHuCD2rH1Dwtq2i3hvdNuHmWJiyPA5EyKe5GOR gckZ9xiuy1WOS80i9t8yO727oi7up2kAc/hVW0/tews4YLm2h1F4kCJNbTiInGPlcNjBGQMgnIHQ GonTWif3mtLEO8pR6vYpeF/Etzq0ctreEG6jTd5ioF3JkAkgYwQev1rezlevzZ5FY+i6NNYXt7qF 7JCLq7ZsxQjKxKTk/NgHP4VrsgIzuGc8jvWtJPl1OXFuHtG4DsMGIO0egzmmrIQpBwfrz9P5UMBj 1OMDjnNNAPVu54welaHOhQ5yBxhucYpOf9n86O/GTjsM0jr+728YPXcaAAkDrjPQ9/8APembWH3S PSnEOFJwxIGT701x8oYH5geo6igGtBN27jsOvvUuBx84wB0B45pjHDEt+QH50oLDack+oPXvQCQ5 V28Ejk9uadh1b5j+n/16Zkly2DgjpTgpX7pbGOOOlMLIA6KykMQTjoPrSk8bSu3HOc8/560Kcvg7 sZ5IHOBSlfmADEr9AKBJCYB5LA5PbkUJwMqB079qTGSck+mO9O2bWxl1+jfnRcXL1EB5BYYBOTwe lPbADdjxxx/jQQpGWJx6D0pSuWBGdp5JPPpQFhGIXdkhhnr/AIUHbgtkZAyCaXHfdjGe31oGAqhm OQOOPzoQ7AG4btx2NNbbzzyOtOO0ZYE5xk4HSmn+Hjg8EUAMK8ZOMeoo2tj73P060oxnrzz2xSjk dwc+lAyPHzLkjH6ClYBT8vIJ7/54FNUsfvbgOnSnLyfbv2/lQToNJBJz1FYvi5yvhy4wQAskZBJ4 zu9OlbZyzt1yPfrWN4sOPDF1liQXjyTnkbx6VFR+6zfD/wASPqa+Pm2kbcAcMS3b1PWl4znv/KiY 5mYkHJI5APJ79eefejGerH05prYzluw4zkc9sEYpVK5G0YBHpSEt1znj8qXOAOu7/PSqIuOZeQT1 9DwCfajaEJLZ46jAFOG4j74HT8aQKzewPVs8UXHYXPPzHIxkZA44oA4wWAI5x09KDlyOWz9aTLBA p79TQIHG4nnr6dAOtBI6DuOR/jSlduc9Rx1yDS85Xpt68mgYiEbjk5BPbtTc4UjA680/BBbk+gyc 9f8A9dG3KZJ5zjP/ANei4WvoNySSSPryOKfghSTyO3TimqQclSfenchOWHPcnrTuSkIeT2wPpQFX o2SpPI70m48gkk46Ubt3AJAz+BpDTOSs3udN1m8g17UNQ+yCNnt3e8njjfDcbDuAJIyMH0Pel8L6 Zcww6hfLC4leMraxSpt3jkg+vX8664SyBdofK5A2kZ461GzPu3FyT3JOT1/OsFRs9zvljHKNrdjk P7dl1Hw5qcGposd8FCRRJbtHJNuI52k84wc4HTGe5q/pGk3Fh4euIJAPtU6SN5Z6oSMAHrz9K6JZ ZQgUSPgADBqIr83Dc59P60RpO92yZ4lNWira3OG8OXi2ttf2v2S7lunjAWFYmJzghiwwMAcc545q bwW4t7i5jlDxySRp5SuhXdgnOMjn1rtHZ2GN3A4ANOMkjgBpG57HP8qUaLVnfYupi4yUko7nD3Fr BbeN5G1MTW9hLO7h3U7GU5wCQeh4Bye/StjTL7VZdTvDNMjaJb7vKMdsI49oPy7CEDMAuPXrW/FJ JESUYj2H+fp+VKr4Cjv24xj/ADxTVGzvcUsWpRs10scFrt/aXHiexuredXiVoQXVGGCG54IB9a29 bn0+7vray1KMrZywmSK72tHJC2ejFuikgdR1rTk0mK48Q/2ncnzSkKrDEVDAOCcucjr0x9fpV8SO oI3EBjkk85+uRzUqnLW5bxEI8tuiON8MW1xDqWpW8Vw02m4KtMoIWVs4DKe5xnkVX0Jn8N69Lban G8cMiGPzfIZlODlWUhcnoen6YrtyWKDc+fb0pFkZMbWYZOS2OQaaotJWexP1xOT5lozitLZJfHks ys8aSSzMA6YbBUnGO36U3xazpr9vLtkO2CNmO0kABznoOmD39fetCOw1W18YXOpSWEklo8sreZE6 ElSCAcZzXTh2ThDgZ7Hn0qIQcoteZtVrqnUjLfQ4vxpIZNUtLi2TzY/IyrQLvGNx5JGf/wBWK6TW tKh8Q2CYuEMqEmG4j+ZSxxlSeTg49cjHetTfKhO0kddwHes7V4764trX+zQhu47tJUMxwigK27cc dDnHbr61o6drt63MIYjmcIrS3U4xX8QeEpSp3R27uAQw8y3kPoCRgHk9MGu50zUYNWslvYogkj5S dNvKOOgz3GMEZ7Gobi+ubnT7i1GhXzSzRMnlhUaHJH3hIcgjPT+LpwOtLoWlNpOlC3do5JpGMspX sTgYB9AFH61NJOMrLY1xM4zpXkrSNI5yeCO/IpG4TvgnkYPWhS245wOD1HWgnuNoye/5V0nmajiS BtLEkHHQ0hZscFTnHakR+Tlee5pSwBUYxmmhaC5JJ2qwx0yD0pQCBliPl74pgyv8JbPGc8f560pZ sAdR1Jxn8aA2FOWyVKgD+GmMfl46Z4pfUKNp7c44pU9ZDz9M0CauMyGC46Y9Keu7aO/PGc80AcDg EED+GnD7uR0I44ouNRGqjhgeeepxx+dGNo479gMU4YGMjPTH/wBaggMeh5Pcd6VyuXQaw+6QTwPX 3pw4U9c54PNNABC8Hp0POPwqVCN2MBRn7oPb8Kd9BW1Gqfl4PTpke9Z2ubFk0VpJfLB1SLc24Lge o79v1rQJ4+YbG7+9Z2tzOv8AYm2Rk3avbt8jkY59B16f4VnW1gzpwelaKPbz1oopK80+gClpKWmA c0elFBpDCg0Cg0AFHej8aTvTAUgUo4pOtGaQBSCl7Ug60wFpe1GOKSkAUhopfrTAQcUtIKU9aADv QOaO9L9KQCd6KD1o9KAFHFJS0lAAB0oPWl4pO9AB25pR0pDS9qAHDpRQvSikUcp4WYnQ7Zc8KOv4 10kWcc81zvhVP+JHAcnnNdIgx/8AWpkDxSGl9qTtQMWgUAYooAOtFL24pKACg0ncUtAB2pMUY44p aACigUhoAXuKDxSUHigBT1pDgiig9qADtQetHf2o60wAGjPFAFGOKQAKO9AHNBHNAB2oNAoNACUv ekFLTEGKKO1HekMO1HelpKBHg2mXkelnU7a6stTSf+0bht0VhI6tluowMe3B9KtrrdgmCYNTXJ/6 Bswyfy9a9uGfWjJ9TWsa0oqyOWpg6VSXNI8RXXrXBzb6u4zwyaZKQCT3yAcDIPTPIxmj+27PJH2f VgcDLHTJunvx+Pevbs+5oyfU1Xt5kfUKPY8R/tmw/jg1OPjjdpc2P0B/z60xdasZPL8uDVG3HHGm S9e/Qdv5/nXuOT60ZPrR9YmH9n0ex4mNasWPEeqOFyTjTJsDHXt/nP4UxNat2YEWur7c43Lpkpwf yr22RPMTaWYD/ZYg/mKdk+po9vMPqFFnif8Aa1ouf9G1YHGNo0ufn1x8v+c0qanaO2fs+r/7J/sq Y/yWva8n1NJk+po+sTD6hR7HizazaBtzQap14xpc2Tzj+6O/8qRdWtH3L9k1jGcFl0qUhTgdePev a8n1NGT6mj28w+oUTxL+2LXcQLXWSM7eNNm5I4P8P0/OgalAEXdZa1zkgf2VNyvcjjnHfpXtuT60 c0e3mH1Cj2PFW1W3ETyjT9dZFGS40mX3Hfj06mnT6rb2se6ew1lVyAS2kTKOcY5IHXnivaO9JS9v MPqFDseNi+7rpPiDBIyP7GmJB9OnrxS/bicbdC8TMD3Giy+/H1yB+f1r2Oij28+41gaC6fieMLfk cnw94qGDtP8AxJH6f99UqagGVcaH4lOSR/yBZOw7ckHnPevZqMZo9tPuP6lQ/l/Fni4vJGTI8PeK 1PIAbRX544PB9aT7axOG8PeKucEZ0R+T6fe68V7T170Ue3qdw+pUP5fxZ4u19IAQvh3xYV55/sRu fp83H/1qPtjiMZ8O+Kjxgj+xH49+v+c17R2pMdffrS9tPuP6nQ/l/FnizX7lAT4b8WBc7cNozD8f vHr/AJzTYr2QoCfDnigttyM6NIFY49QSf/117XgkUYOKftp9xPBUP5fxZ4qLlsEDQfErMCc7dHlw P/rkEEUn2twCDoPiQNk4/wCJRLyB/n0r2vBz3xQfxo9vPuL6jQ7HiqXrSRZXRfEgYcEHSJSQeMjj 6n8j+J9sfIUaB4nCt66LJyMdcZ+g/H8a9q2n1/Olo9tPuH1Kj2PFH1AbCV0PxIVAzxo8mRweevAy MUG/CKCNI8Q4LYz/AGRLgD/H/PFe144pe+aPbz7h9Ro9vxPFTfRNGGNhrqh87QdImJIx9MHrjr6+ 2Q3yIoaTS/EESnG0nR5Rn8fWvace5oIz3NHt5i+o0ex4o1/GrsDp2uKepJ0ibkdCR7DI6j+dPOpx pKA2n64pHGG0mYZGM9Mele0Yox+lHt5j+o0ex4p/bNpgBrTV1LYxu0qbvjA6euR35pW1qzSYL9m1 cdSGOlzduuOM/p9a9rOfWjJx1NHt5g8DRPETq9ix2iHVSw5x/ZkxI9/u+vH1pTq9rEVBtNZJfHB0 qYE59OOa9tyfWjmn7eYvqFHseJPrFusQf7FrHfK/2XMccZxnGP1I49Ka2sWi4ItdWzgnH9my8gdT 0P8Ah/T2/wDGjJ9aXt5j+o0Tw1tYs9gcQ6njOMnTZfTk9OlMOtWIVl8rUfl6n+zpv/ia91OfU005 xjJ/Oj28xfUaPY8ObV7FAWKagAOGb+zpxj8lx696Y2u2C5Ij1L2I06Xk+nT1r3EhuPmOfrTiWI+8 RR7eY/qNE8Oj1vTWUGMXzbvmU/YJgD/47/jTm1zTlYCT+0PTJ0+fA9M/Ln26da9u+bP3jjHY05Sc dT+dHt5i+o0ex4c2saaDuBvypxwNOnz/AOg4/XtTjrmlFj/yEBgDDHTpsHse2f0r3A5Pc/nS5Pqa PbzD6hR7Hhja/pOAVlvmO7B/4l82Rxn+7Tzr2jhghlvSckEDT58dB6rnv6fzr3DJ9TRk+pp/WJh9 Qo9jxAa7pCvl5r1Vzyx06f5fXPydsCkGv6UoL7r/ACeUA0+b58eh2/X8q9wyfU0ZPqaXt5h9Qonh g17Sjlke7IB2kjT5uDjP93r09KX+3tN3bN19kemnTdMDH8Oc9a9y59aOfU0e3mH1Cj2PDV17TAMM 95GzHAQ6fPnPBwPk64yfwpf7f0xdyGa+Ax/BYT/yK17ic+tJk+po9vMFgaKPCm1/TUzh74nAIH9n zBs9Mfdpy+INKMvl+feH5hwbCf8A+J9j2r3TJ9TTRnJ5OKPbzD6hRPCP7e0wcM94CRnB0+bkdx93 t3oOvaSVBWW8Oc4xYzYPB6fLmvdju4O49aQk5HzH/Gj28w+o0Twxdc0osdkl445yUsJufp8o9cc4 p39u6WpChr3OcMPsEwxnOMfLXuRB4wx9etKM9Sxz9aPbzD6jRPDP+Eg0xUZ0N8QOwsJs/wDoOP19 aH8RaRtLGa7CZwWNlNx2/u+vFe68juaM+9Ht5j+o0jwr/hINJ5ImumIGcJYTZPGf7vrSt4j0Xesc lzcbjgYFjKCcg8fdyT1/I17pk+tHXBNHt5iWAoniI1vTAvEt67A5wNNuMH0x8vWmtrmmDBZ70ADd zp0+cAcjBXk9+v417hk+poyfWj28w+oUTxE67pBkKrJeHK5z/Z05K56cbPb+f1pT4g0rB3SXoJPO dOnxjPHJX/Jr27n1pCeetHt5h9Qonh413TVY4F8PlyQNOmJB9D8vrTZNd0xQ2Hv+BubGnTYxj3X6 /lXuXPqaPxNH1iYfUKJ4e+uaWoPzagT0GNOmH81pkfiDSy7Avdk5IwLCf/4nr7V7nk46mkOeuTR7 eYfUKJ4Yde0lQrF71TjnOnz9f++aQ+INKK48y8Axkk2Ewx79PavdcnPWm8gdTR7eYfUKJ4XL4i0k DCXN3u7KLKbJ4z3XHXikXXtIZWxcz7ieNtlMc/iF969xYt5g+Y/4U8A+p5o9vMPqNI8LbxHo8YDS XUwB/wCnSX0zjlfrTl8Q6Q7hGvJQCBki0mxj2+X2r3EFv7xpctn73FHt5h9RpHhj+I9EUAPfMrEb lzaTZ9iPk/Cnt4j0LeudQBOcFTazZH4ba9y56ZpCNwwwBGc4NHt6gfUKJ4anifQGl3f2oeSuM28v zZPb5aF8T6AwLDUsnjGbeUgj2wntXufU5IGaXmj28w+oUTwoeKPDqEf8TNRnkf6NLk89cbf8/WnL 4n0Erzqag98wSgDpwfk4617n070c56mj28xfUKJ4cPFPh0Kkg1ZNo25xDJ36dV/r2pv/AAlXh0bQ NYiO45wIpODj/dr3PJ9aOeeaPbzH9QpHhsvinw/tbOsxnj5SIpecc/3en6ZpP+Ep8Ohyo1iAjqCY pMEf98/zr3P0pPWj28w+oUvM8NXxP4dYAjWLfcTjayuc8gdNvPX9KafFXh87T/bFuSMnG1+2P9nn /wCtXutIAB2H5U/rExf2fS8zwk+KfDwXjWLcDk5KuOnpx0oHijw/vCf2vDyf7j9P++e/avdccg96 MAdOPoKXt5h9QpeZ4O/ibw8gZhrMBUdMK+T+nanDxR4eUE/21b7RnjD547/dr3Yg8c0FFYYKgj3F P6xMX9n0fM8IPifw/vIGswkDjdhwP5f54rL8Sa7pF3oU8FrqdvLK0iARpuJOGyT0+tfRRUdgOTnp 3pNgySUUkkZOBzik682rMqOBpRkpK54XL4t8PSMWOrW67/n2APgH06dvej/hJtAB+bWbbOM7WD/o cc17rsAcsFAYjG4AZ/zyaTHfg/hQq8weApeZ4Y3ibw+Iix1q2z7Bv/iac/iXw51Ot2edpyMPwR2+ 719PXmvc8ZyCQaU80/rExf2fS8zwseKfDpALa1aDI67Xz+W3/PNI3ijw7zjWbfI77X9P938K90KK SpKgleRkdDSgYGOg9qPrEw/s+lbqeFDxR4fGQNZgY4wcK+D75x096d/wkvhzYd2tWmQCNpD5H4Yr 3IqrKAyhgCCMjuO9OPPB6UfWJi/s6j5nhX/CU+HgxD61bFQDhgG5/MU4eJfD4mw2uWJ4yGO7B+nF e5kZIpoVVztUDOScDrR9ZmH9nUu7PDv+Eq8PsoJ1y0OR3LdvqKafFHh1csNbsj1wAW4/T+Ve6Yyc kDPrikMaFslFzxzgZ46UfWJh/Z9Luzw8+JvDxUKddssdAAzc/pTR4l8PsMf27Zfd/iZh+HSvcwAB wB7cUioqIEVFVR0AGAKf1mYnltF9WeHt4l8PHlddsuCAcs3+FNbxL4ebGNcssNk/ebA6+1e4mKMy eYY03/3toz+dI0UbgBo0bBBGVBxjpR9YmP8As6j5nh6+JvDxY51yyzuAyxbp+VJ/wkvh4sf+J1Zg 4wcsfT6V7mEVV2hVCjsBxTRDGAB5aDHoopfWJh/Z9JdWeHf8JH4dwT/bdmOvRm5/TpTm8R+HwpYa 7YHB+6HbOM9fu17d5MarhY0GBwAo47UeUh6RoO5+UdaPrEx/UKXdnh3/AAkugqMtrll3GAzZ/l60 g8SeH97D+27QAYAJZsH15xXuQhjJB8tARxnaOnpTljVSSqqp6HCin9YmL+z6XdnhZ8TeHgm4a3aN x0+Y9+/FPPibw9vI/tuzxnGQzf1XmvcQigEBVAJycAc00Qxckxx5PJO0c0vrEx/UKXmeHjxH4fBJ /tuzU91YkH6YxwaY3ibQNwB1q0PGfvNjPQ9ute6CKNQFEaBR0AUYFIYIiwYxRlgMAlRkD0o+sTD+ z6Xdnhp8ReHxgf23Y9CT85/wol8ReHxvH9uWR2k42uef0/zivchBEMgRptOcjaMHNNNrb7mb7PFl iCx8sc46Zp/WJi/s+l3Z4aviPQFAJ1uzJ+8SHJz+n1p58R6BuP8AxOrEZ6jefUD0r3A20H/PGPn/ AGB7f4D8qXyo8EeWmCMH5RR9YmH9n0u7PDx4h0EZ/wCJ3Ykn+7Jx/LP6U7/hI9ABU/21Y8g5/ee9 e1JY2kQAjtLdMHI2xKMH8qU2lvuz9nhyDwfLHt/gPyo+sS7B/Z9LuzxMeIvDr5Y63ZBjk/M/Pt2/ ClHiPQcc6zZfXzOCa9sSztUXaltCq5JwIwBk9f50CztQ2RbQZ6Z8sf4UfWJh/Z9LuzxQeI9AZd41 ux5PRpMHnHbFO/t/QSP+Q7p3U4/f8/yr2IaPpaytKum2YkbhnFumT9Tin/2Xp27d9gtN2MbvIXPX Pp60fWZ9g/s6l3Z40PEGgEE/29p/HP8ArCMjr6f0oGv6AcY1zTznrmfBH+f84r2ZdOsV+7ZWw+bd xCvX16daVbCzQkraW6564iUf09z+dH1mYv7Opd2eLHxDoJjz/bdgdvAAk5zj6frTz4h0CNiP7d04 4z0lyDj04r2UadYiPy/sVts2hCvkrgqO2MdKQaZp46WFqPl28Qr09OnSj6zPsH9nUu7PG08Q6ATt Gt6epALAtNjgDOP8KT+39BZR/wATnTuTg/vgMf8A1v8AEV7OdPsinlmztig/h8pcflimf2Xp/nCb 7BaeaAQH8ld3JyecepNH1iY/7Opd2eNjXtEYjGt2HOc/vxxgZP6d6cde0QbP+J5pm3DDiYH/AD+V ewJo2lxuzpplkrtjcy26AnHTPFK2kaY2C2nWZIxjMCf4UfWZC/s6l3Z40Ne0LOP7asR8vH73Pb6U 9tf0P5iNc084PaYeg5HtXsg0zTwoUWFqFB3AeSuAfXpSJpWnIWKafaLvGGxAoz9eKPrMx/2fS7s8 d/t/QyV/4nunDK55mHHtj6Uv9u6HgAa3p249vPXp7npmvXDoOjGMxnSLAxkglTbJgkdDjHanNomk u25tLsWbcrZNuhOV5U9OoPT0o+szD+zqXdnkH/CQ6Iyn/idWPHzDEoHYdKpaprOkvc6K9vq9pO8W pwSFIZVc7c5PB4HbJPT869r/ALD0goEOlWO0HcB9mTGeeenufzNPj0jTISDFp1nHjpsgUep9Pc/n UyrykrMungqdOSmm9C7SUtJWR2BS0nal70DAUHtQetBoACaKSl7UAJSmijvQIKKDSCgYtAoFHNIA HSiij+VABRRQaACjHNFKOppgJRRQCKQB170o9aOKSgBe9BFApM0AKKTvml70Z5oAQjkUvrQetA6U DHL0ooHSikM5rwuQdBtQBjC9fxNdCvOMdK53wsANBtSB1X+tdCuRxTIHd6KMUYoGH40vakPSlzQA UUUUAJS0tJ2oAO1B6UDpR3oAMUhFOHrTT1oAKU0lKc0AJQaKKAAUfSjrS0AHpRg4o70ZoAPSkJxy TjFAHNI8aOpV1DKexGRQAvUUYo+lLQAlHvR3oNMQcijuaDQOtIYvam06koASlpBS0xCUtJRQAtHa jrRSADSUtFABSUtBpgHSkFL1o6GkAUelFKetACGjrRiloATHNJS9KKADpR3oo96AExRSiimAlFFF ABS9qSikAUUtJigAopaSmAUtHpRSAKMUd6PxoAKBR3oFAAaTFONJQAUGiigAozR0o70AFJS4ooAa Rk0vtRRigAxRS0UAJS0d6U89qAG9DS4o9aKYBRRj2paQBSGlpKACkpaKAEopaKAE7Ug6U6k70AHF FLRQAUYo7UZoAKKWjoaBiUUUdqBCgUmKUZAoPBFAwxzQKO9JQAdqKO1FAhKWig0AM6vkdBxS4xml xgcUUAJj8qXHPailoABR3ooNABR3paD6UDExRS0d6AsGKSlooASilpKBC0lL70lABSUtFAWENFLR QFgpO1LRQAUmOKWjtQAlFLijHNABRRRQAY5ooooABRS4ooASg80Uc0AAooHSgdaADFFHUUdqACij k0UAJSmig0AJiloooASiiloASig9aMUAFLSUtACUUUUwCl7UgpcUgCkpaSmAUUUtACUUUtACUUGl 7UAJRS+tAoAKDQaO1IBKKKKYC9qTtRS0AFGaKD1pAJ3opcUlMAooooAKU8Cj3oNAwo7UCkoAWjpR QetAB2oFA9KO9AABmjNKKSkAA0GgdeaDQAdaKOBQaAEpaSl70wDvS0nQ0UgDvSkUnejrQAopKXnN JQAvNJS96SgApRxSGlHQ0AOHSihelFIo5jw0NuhWmGYDbwfTk10SHIHPauc8MkNodoQcnbjH410a Aj6UyB9A6UUUDEZVdSrDKkYINIihF2qAFHQDtS96XFABRRnpSCgBRRzQaKAAZwaT+dLSUAGec0po oI4oAQ0vFIeTSn2oAD1pOopTwaQ0ALSd6WigA4NJjvS/0pDQAHg0v1pMUe1ABQKTtS0wEFGcClxz RjPSgA5xmjvS9qTPNIA7UUuKT6UAAAzRRjmj3oAO1IelLmkyM49KYC0HpR2opAH1o9KKO2KADrQa D6UUwCk707ikpAFB60UUAHOaXPFJS8YoATvRRxR3oABS+tJ0oHXigAxQKWk/CgApKXpSUxC0UlL2 pAFFJS9KACkpaKYBRRjpQaQBmjt0oooGFA6UCl7UAIeAMnApe/SvHviHqFxpXxCs7vXdLOp+G1hA igeLzIgx4ZgCQvmA9N3b06jX0w6J/wAI3mHxfFa6Bd6g7k3NwYpimxf9H8x2BXDA9OduBnqSXGel YpDwR6mvDbGSy8LfFDT4fDetG70jUJ0DwwXPnqu7KFG9wSDyScYz79X438A28+gX2r/ar661u3V5 1uZLh/uglmjVAdqjbkAKAenWgR6RyaOfSvFJtYudV+CctzcTSyX1jdpAt15hWUKXUj5hk8qwXnGf rjOV4gluIPhR4Wu7a4u0uJ5J/OmWaQSSHBHLZyR8g69gKQz6A5pCPavI/iRbiy+Hnhy5tpLuFopI lzFPKv34yzMeclsr1Y5GT61ladpuqeIPE3hy70fVtXu1SCGTU9QmncwRyqMvGpA2lsfKQM9Rk5yS CPcfwNJxXjHxTW48M+IdJ1nT77UVupmlklkNwduFKYUL90ABiMY575OTTviNq8+l/EfS7rXNPkvf DkCbobcxBo3YqwY4Pys4OCAccAdM5LA9m6HHejFeVS61beG/h9quo6DqUl9Bf6iFsphIZHtg6ICj bzkbdrADnqvuaxPsBX4QWfiWznnh1mO4L3F+JHW4lDSNGV3jkryuATjA9aQHuFKPpXkOvahdw/Bj QNQiu9QguwYB5yySRuwIO4MwIJU469/l9a5zxPDe6T4J8K+IYdS1JtWlXJnkuZMBQm5FVScAYHXH POSc8sD6AHWlxXl3xI8SGO+8M2l211a6JfMJ75opGQyR8AoSnzYAbJA6irHiXwvpeq+DLzUfBl1N A/kMyppE7eXdgA5jdFOGYgnnG7PXPSi4HpBYBgD3pe1VdOD/ANmWnmKVfyE3KQQQdoyOea8qW4nb 46NpZur3+zvOJ+yNdSCIn7OH+5uwRu529Mdu1AHr/akwewrx/wCHV7d3XxG1qC6vb64gtRcm3hku pJI49swQbVLbR8pwOOlZnh2eTxxN4u1LVzJczQ2G6yKyFRb/AHyuwAjaflXkeh9TQB7nijmvCbPx Vf6p8JtUjuLy4/tLS5rcxXazskqxu6qPmXHIyy8nnr2p2pX94vwd0fU49S1QX0l8ySXIvZDI4BkG CwOSPlGATxz3pAe6UYNeJ+Ob6+0/4c+E7mx1K/guriINNPBeygyM0Yc7mDZb5s4yeO1L8TL2+0/S /DM2kanf2n2mzfe0F5KhkP7sgswb5sbzyfXrg0BY9rwcdKPwrxzxxcXun/EPw9ZWmoajBY3ENsJI Uv5ovMPm7Tv2nqVABOMn607XtQu7P416fp0WoXcdhI8Ba1ju5RGSck5QNjJIBxjnv1NMD2Ac9OtL zXk3ifVJtX+LumeHbk7tIgkQSWpJ2TSFN+5gB8w5UYORwfU03whq82kfFXV/Dcc0zabNLKIIJZCw gZRv+QHoMEjA7Y9KAPXAD6UYrlIvBFnfvLdeJZW1i8kdmXzHZYYUz8qJGDtAAxzjJPJrgvE93qfw w8WWs+lXN5NolzFvNjc3TSp8pAdU3klTypB/2u/SkB7RRyagtLuK+sre7gO6GeNZYz6qwyP0NeX/ ABQvrzT/ABdoHkX97bW1zhZo4LuSJZQJFByFYDOG6/SmB6v+FGK8m8f61PJ410bwmLiSLSXeAXUa yMGmDPjaWHzEY9+frSw6p/wifxibRbNXj0i+WNPsgcmOORlyHRei8g5Ax1PtSA9YpcZ7Vn65JeQe H9Sl05C96lrI1uoXJMgU7QB3OccV4t4X1PTtZtrfSL6a7sPE/wBrWQ6g9w6i7PmK3lSNknJUYCkY BUEelAHvOOvFJXlvi+10LV4NYbUfGenjV4ywsYV1QQx2uw8KY9/3yRhicn0xgUvw21LUfFXg670q bU7uJ7WWNPtanMphYZ2B+zcEbuSAR3waYHqODik7V4p4wspfhv4v0/WdJuLsafcHdLBJdPJuKkeY pLEkggg855+gxb8V39yPi5pNnBqN/Hp9yLcyW8F3LGj72bJKggcgDp1pAewc01jgdcE15NZ3l8Pj vNpv9oXv2GMlltDeSeUB5IYfIGK9TnHT2HbFvL+40r4rapZ3nibVrKwAfzJftW59vlBwFDAqCScK AvfA5oA90zwM8ZoPWvLvhzoOvy2epyapf6xb6deBVthPdP8AaMb2Yvz9wspALDB9MYBrP+F+qaw2 o+JrFLqa58iJntobiVpFEoZgPmYkgHAHXmgLHsPPvS/hXz7o2q2mqWuoaXrVxc2PimaYmPVJ72SN A/XynIbKDAKYAIwR0OK6TxZdXdl8YdHtIdT1CGyuWtnmgS9lEbkuVPyhsHO0Z4ouFj14ZpTXhT+I raL4j61b+NBexoXWC0lhlkjFkoY7ZFwwIDDB3rnn2NdnFpUcWg6XpmueL4v7NEMkplTUTHLeszsV Yyk5KBWB4PXGSQBkCx6Fj2o714p4F1a40rxvdeFbjWH1HSrktHBMt47bSBvRkcHjcDggEDP05S61 fWvht8QE/tTUdQvdEnJK+ddyT/uSeuHJw6HGcdR9aBntnWivFPiBdXll4806Cx1fVYNPvYoZCsOp Tqp3SEEqN/GRjoPwr2eCBLaJYYzIUXoZJGdvxZiSfxNMRJ9KK43xR4N1DXor24Ovagl0oLWFvaSm CGMryu4ZO9ierEj2ArifDniS/wBX+HHiO1vdQvTfaVB5sFxHdyJPyCQGcEFsMp6k9aQz2jmkrynw tc3d/wDCrXL+a/1KS8iNwUlN7PuXYgIwS+Rj2NVvB9zeXvwv8R38+patJexiYJPLqEzFdqBl2fN8 uCe3Xv6UxWPYKK8t+Gqalr3hO/kbXNRS5kuvJe5luZJ2SIKpIjDkqjZP3sN/KsTxSl/8N/F1je6b q2pXFlc4klt7m7aUyYOHUgnnIIwSMgk80Ae2c5pe1cD4p0OTXk1E3viY2M6AnToIL4wRxgAHMqjB LE5BPIAxjBznkvC/jvVbXwB4kNzdNc3mnhDbSyOZGHmkrjcT820gkHJ4+lID0Dx5rereG9EOqadJ YbUdEaG6gdy5Y44ZXXHHbB6Vb8GanquteGrbU9WFos1zl0S1jZVVM4AO5jk8Z7da8lutNZ/g4mtz 32pTX11e75fNvJCrjzCoDKSVb7oYHGeevrq3uv6j4f8AgvoJ0yY273cjQPOq/OilnJKcAAnHB+mM 9aYHsppK4KDw3pet+Hl1DwprN7BfGPMd6uoSuXfrtmBZs89QRkVu+BmlbwRpBuHlab7OBIZWJbcC c5J96QHQUEYrkPiSssPgrUb21u7y2uoVTZLb3UkRX94oPCkA8E9ao/Cl5b7ww1/d3t/dXX2mWJpL m8llBAxjCscD8vWmB3tB61xf/C2PBmxWOqygMM/8eU/H/jnrWX8WprnT9HstQsNQvrOaS5EbGG7l jBUoxxsDAZ4HbP60AekdKSue8DLv8H6XePcXNxNcWqPJJcXMkxZscn5yccntV/XkvJ9PEFnexWXm SBZrh22skX8ZjPTfjoTwOvagDUxSdq8U1bULr4e+Oba4s9dur7Sbw5lhnuXusLlQ4I3Z3A8huT25 5FX7u6uo/jhBpQ1XUUsJZA5tmv5lTJhL4xu/vdsAdsYoA9dAorypdYl8X/FiTR7i6uY9HsRKFtYp WjWd0wCXKsCcNyAfQe+YfCF/qQ+KupaJLq2pz2dmtwkEM8zOFXcCCxYksRnAJyaVwPWu9BzXg1tr GrpqHi6wn8W6nDBbpJ5TNLvkeVZCiKhPKlj1CYz2x29G+GMXiGPwy7eIWuzJJMWtxeOzTCPA+9u+ Yc5wDz9KdwO0pO9eO+Ppr+w8fWGnWOtava216ITKkV7IQpaUqSo3fLwOnSvXoIEtohEhkKjODJIz t/30xJNAElHWijtQAoFJ3pRSUAHSg0Ud6ACiiigAoo+lFAgo70Ud6BhR2oo7UAFFBo7GgBKUUlL2 oAPWgUCgfSmAGiiikADmiig80AIaUdKSl7UwCjiiikAlLmg0dqYBRRRxQAGk5xS+lHrSAKO9GKKY gPWik70tAxKKO1FAB1pTSDrRQAvYUUCk70ALSUvekoEL2oHWgUCgYCigfrQaAAdaDQOlFIAxSmko NAAetGOaTrS98UwCgUZopABPNHNB60vSgBOlLSfWigBaO9GKSgAPajqKDS9BQA5elFC9KKRRzPhd caLbHjkZzXRK2TWD4cAOhWTAY+Tn35rdTPfn8KZA/vSYpRSUDF6dKDSUtAC44xSUuOlIaADmg9KK PrQAUgPWj8aAKADrQfal6UUAIaXPNJznNKaAE70GjoaU9KAAUnejsKXPFABSAcc0daUd6ADvRxRj tSZ5oATHFLR2opiAUd6O1BpDF7GgdaCOKM4NAB2pKWk7UAFBxiijvQAd6SlooAQdadSUZ4oADQcC jmj9aADPNFB6UUAFJS0lMBT05ooNApAAo7UUvagBKXNIaABmgBaQUoo60AJxR70ZooAO1JSikpgL R2oNLSASg0DNBoEAo70AUdxQMDRQRRQACg0ZooAMc0tJ3oPNAHKeItE1vUNVke2GmXukT2a28+na g8iqzhnO9SqsFPK87Sfl7YBrDT4VI/w+fw/c6gGvTcm7S6VMrHJtCgYPJXaMHpnrXo/WjpRYDiY/ Cus6t4o0nWNfuLKOLS4gIbSzZpBJLjl2ZlXAzghQD0HNZq+B/E9hrXiOWy1O0ubTWY5FVrqaRXgL knOwKVbAJA5GfavSKWlYDjH8AQR/Dq48LWt0yySKH+0OM7pgQ2SOy5Ue4FcjJ8MfFl74WsNEudR0 aGGwlZohGJpC+8tuYscYIBwFAx156V7DRjmiwHE6/wCDLvxB4As9FmktbfUrNI/LeMlot6Ls6ldw BBPbIOOTjnOTwDqepXfhp9V+w2iaHCqbrK5klNztK7VKsihR8pycsTkjHevR+9JRYDxr4m6d4k1r VtE06a3sjNcS3MdobSV8bT5ZBkLAbcAZOM98DjnstT0LxBfajDJLFpN/p09gkF9p13cSiMyjJ3xn YwByR8xXJAHQ4rqpLC0mvob54Ea6hVkjlI5VW6j8cD8qsetFgPOtK+GJt/h/d+Hr29jNzdT/AGrz o03pBIMAbM4J4XBPBOTXO67oniTw38Kzo1/c6RHZQzgh7eaQyThpNwQKVUAgksTk8L06mvaKy/EO gWniXR5dMvWkWGRlbfHt3KVORgsDj0+hNAHEJ4cvfEnwZ0bS9NltkuDHFJvuCQhAJJ+6GPP/AOv0 qLXfh9r2reBdC0GKXTIbnTW+d2uJGRgEKgj92CDyeMcepr0DRNJXRNLg05Ly5uooFCRNc7NyoBgL 8qqMAe2a0O9MDjdc0zSNR07Q/DXiG32XV0rRW01qwIheNM5Vyq4yBwNuDjGK8y1bQvEHwp1K11Oz vxcWrysEMe9VlIAPlzIOMkA4xn7pPGK9k8QeF9P8SNZvfNcLJZu0kEkEzRtG5xhgR3BAIqlL4Kj1 G8tZ9d1a+1iO0lMsFvcpCkQbsWEaLvIHrx7c0AdJBIZYIpGQozoGKMMFSR0Nef634M8Qj4gDxToE 2ks5Qfu79pBtby/LP3VOePQjvXonelxQB5v4M8D+IPD3jO+1jUZdLuYrxZQ7QyOrhmcPuClMc46b uM9Tjltj4D1bwzquttoZsriy1SAxx/ap2je2Ylj0VCGUbuOQen1r0oikxQB5zY/DN7L4c3+hLPbt ql4FeSc7vK3oQUXjnaMdcZ5zg4xWSPh54uuvBUXhu4udGt4rKZp4JI2dzM5OQGOwbAN78gEnjtkn 1yk7UWA8i1b4f+NdZ8L6Xo011oUENgu1USSY7+MBixXrg4xjGcnPQDV8Z+AdW8T+F9Fs4HsIr2wj 8mRZJXMbIVAJDhM5+UHG3HJ9K9JpKAPKda8DeMtX1PStbe40M6jYNGFg3SCPajKykvt3MSwbIwMD pmpbvwP4r1Hx/Z+J7yTRnELxObZJ5U2hM4UN5ZzgnOeM88CvUR0FFAHDeIvBN3deONM8V6VLbNcW zKJ7a5ZkWRQCAysoYhsNjBGOB+LPDXgm+g8Zah4q16aCS9mdjbQwMWWFWG3ltq5IUbenT1JrvaQj Iwc8+hxSApaTq1nrelwahYzCS3nXKnuCDgg+4OQfpXlPxpuWvNZ0TSLUrLebJGWBV+YtIQqc57lT x+Nd1ZeCRo8Ji0bXdW0+M5Z4keOZGc/efEqOQSeeCB7VY0TwXpejapcasXub7VpyfMv72TfKQeww AqjHGABwMdKANTQ9OOkaDp+ms+9rW3SItknJAAOM9q8v+Ks11J4z8OW4t7eUxSFoIhIzGUM8XDgJ 8uWUjgtwM8dK9XvrOLULC4sp9/k3EbRPsYq21hg4I6HmuT0D4aaRoV1Zym5u7+Ox3NZRXZQiB2bc zDaoyc4xnpyRyc0xkHizwPfa3quleIdPktLfWrNojJDM7GCQK27G8Lu4ORnHI7CnWfg69vvH8vir WhaxeUiLa2lvKZcMFxudiq88ngevX17mikA19xiYI21yp2tjOD2NeW3/AMOta8QTaM+rR6dFdW2x L2/t7yV5LmNQMfKUH7zr8xbjPft6oKOhpiOFl8I6vpXjPU9e0A2TrqFqUaO6lZDHOSP3gwjAg7QS OKrWHw6vNM+Hl7otrqax6ve4kmukJVHYY+TIG4JgYyOeT9K9D9aTrSA80bwL4h1220Cw8R3Vp9m0 ncZZ4pmmluicbR8yKFAAAJOTU/jDwVq+oeM9L8RaMLGQ2ixh7e5laPcUYsuCFPrj64r0XtSUwPM9 P8E+KIviOniq/n0iUOf3qQTSIVBj2HAMZzgepGevFWda8G6nb/EKDxbpMNjeIBma0nfym3hNmVba QTjnnGCO/b0PFIwyCKQHBeFvCWv+Fxql5HdQXt7fThltLi8l8mKMFj/rNhJfBA+4BxXJ/CWDVV8V apdwWlvJYyFo7m48whFbeWxGQCHPtxxgnGRn2kDH4VU07TrTSrKKxsYFhtogQka9snJOepJJzk0A eYa34B1/xLa6fDqdrp0d+kmLjVUuCzNB2Vl2gs4G0ZOR8vUZrT8S+Fb7UfiRouqW19pyraxxFba4 uSs8ixuSxVdhyOeua9HxXK6j4F0/UfG1l4ne6u47q2C4jjK+WxXOM5GR1OeeeOlAXMTxT4Y13XBq lndWFpqVvNPv0u6N0YpLElVHzDHKZyeCScH5TxVO7+Gd/Bovhd7JrO51XRJN8oeRkWZd/mbEcgkA HgZGOT06V6kBxRQM4bQPB12vjm+8WaskEMkg22lpE24xAqFLOQAN2BjjPXrmuO1i6uviD8Tf+Eau 5wmj2lxIoSFV3jy1O5t/JyTx6Y7ZGa9rrlNV8AaXqGvprttcXmmaqhLfabJ1G9tu3LK6sp4yOgzk 5zQB5h430Oy0Dx3oun6XHOkCpbmKM3MkpT98QAN7EqM9AMDrXvXeuK1L4bWurarb6pfeINZkvoAo jmX7OmNrFl4EQHBNdhbRSQwqktzJcOM5kkVQT+CgD9KBHG6hpvi+y8fHWtNnOoaRLF5bac94YlRt uMhSCvUA5GDye1VdH8A3eleBdcsJbiF9W1ZHMr+Y3koxBCgHg7Rnk4zyfQV6CKztd0iHX9CvdKnl miiuozGzwthh9P6juMigZ59puh6x4V+F+u2Nzb2s/mpNL5qXhMflvGQSPkzkYBxjBz1rP+Gdpfah 8O9d0+2hiVLkzRpcPcEfvTGqgbQpwP8Aaz+Fblp8JbWwiVLbXtSG61ltJVchkZJM52pwFIz9OBxX UWfhHS9P8Jy+HLRZIrOWF45HDDzGLjDOTjlufTHQYwMUCON8N+D/ABJZeBNW0NbqCzu7pvNt76zu SyHhQUJxuX7uMqO/ty0eDfEniIeGYPECRxQ6UrG7mlufOkuGJBwMdQQqgliDy3Xiux8HeE4PB2jv p1teT3KPKZSZcAKSAMKAMAcfnk10FAHneo+CJ7Px/N4lstLstTtbuEpcWc23esm3hl3/AC4JVc85 AJwDSeHfhsbTwdq1nqckK6nqynzjCP3cHJKKnTgHn6/SvRaKAPHk8HeNW8DSeFGsdOVEufOF216c OoYHaqhCRzzk44/Kt+00CCy+Gln4e8V2wybgW6PBKH2ySSHY6scYILen5ivQvoKyPEfh+HxLp0Vj cTzQwrPHMxhO1jtOQA3VeccjmgDxzWvB+v8Aw1ujrmk6k0tqGUPMqsu0En5ZUBKsvQZyOT0Br2vQ 9SbV9BsNReLymuYElMf90kcisO98GXOrWY03VvEd/eaYGVmh8qKOSUKQQJJFXLDgZwFJ9a6iCCK2 t47eCNY4YlCIijAVQMACgDmfiRt/4V9q4Y4BRBn3MigfrWT8HgR4KkyODeyEc5zwtdX4j0RPEeg3 OkyzyQR3GwNJGoLAK4bjII5xjOOKreH/AAdonhmJRp1qRKF2meVy7tnqcngZxzgAUwAeCPCgBH/C M6Pg9jYx/wDxNcp8ZsL4U09FwoN8oHGAAEfv2r0isDxX4TtPF9nbWd7cXEMEE3nH7OVDMQCAMkHA 5PbPvQAeB93/AAguhllKk2cZwc+nvTfG3hkeLPCt1pavEk7FZIHlXKq6nIz7HkZ960NG0HTPD9oL bTLUQx7VUksXZgOmWJJOMn860c0AeTn4d3uu3Ohw32kWuk2enxBbx1aNpLxxjONg5B2jlsEZPBqv qCg/tDWS9OVPDEEYt29Pp0x0r2GuSu/AdrceNB4pi1K9gvgyEIojMfCbCMFScFcjr3pAYFx4U1/Q viO/iPRrKDUbK43tLB54gdS4ORzwRkA59zx3rA8Hme4+NuozXcUUV1/pBkjjcuqHCggNxnHA5GOv sa9qArkNP8BQ6Z4tufEVtql0Li5kdpYXjjMZVmyVHGR0HOaAOck8HavpPjrW9Vg057+z1KGXyZrS WNJ7SR+6mR1wevzKeh/Cul8E6dqnhvR4bPxHq8t5qF7cN5QlneYqQhbYHbk/KjN2HXFdbWJ4m8On xFbWSJqNxYTWdytzFNAqlgwBH8QI70wPOPiXh/iVoaYByturfMR1mbHIOR3/ACr1uS9tor+GyeUC 4nR3ij5yyrjcfw3D864vUfhzNrGrW2q3/iW8kvrbZ5UiW0SKNrFhlceprY03wxd23iQ63qGuXGoT i3NvHG8EcaRqSCcBR1JH8vSgDo80UppO9AC0maB1NFAB2oNApTQAlFFLigBKO1FHpQAZoPWig0AH SjtR2o7UAFHSjFFAAKBxRR2pgLSd6PegdaQAKD3oo4oABQaKO9MBOKXtR2o7UALSAUUgoAUmig80 dqAFApD1oopAFGeKKOooAO1FHajAoABjNHWgUH2oATtRRSjFMBO9KaO9L1pAIKQ9aWg0wDvR3oNJ QAtJS0AUAFJSjrR1NAAKD7UUGkADrR70UGmAZo70n0paADvQBR0NA460AGcGjOTRR3oAbJk7Rtz8 3PPQU4miikAoNAPNFGKAEPWloxSUAPXpRQvSikUcz4Ycnw/ZkjkJjrnvXQrnvXN+FsjQbMk/KU6H tzXRpnuaZA/vRRR0oGGKWgUGgBc9KbmlxiigAxjmkNKRzQaAExxRQOlLQADk0lLSYoAO4pTzR0NB 60AJmjOKXjFJ0FABnNHtRSUwFxwKOtGaUCkAc5o4zSDOaUdaACg9KTvSmgBOtAPtQOtB4NABzR3p c0nfigANB6UdqSgBe9L0pKWgBM0dqOKMUAFFHag9qAAUYo+lL2oAQ0UZoPNAB3poYN90gjpwadSA AcCmAuaKO9GKADNKPSkPBpetIBKPpS96MYoAQcDrQBR2ooAB1NHFAopgHFFAo70gDvS9qTml7UAJ RQOlBoEHajtRSUDHdhSd6KO9ABig0etFAB3pfakxSigAIxSUpFIO9AC/SjFJnmlPFACUUZ60UAFF FL2oATtR2opaAG96UUd6KACiiigApegpKKAF70UUUABoo6iigBKKO1GKAAUUUUAHaikFL3oABRxm kpaAAUUoooAKB1oxxS0hiUUopPemIKXvRQetAxMdaKUd6SgQDik9qWigApO1LSUAJ3oFLRikAUGi jGaYBnilzSdqU0AFHejpRQAGjvR6UHrQAc8UUtIetAwxSUoHNJQIXtSUtA60AIKKKO1AAaBS9qKA CiigdKADtSGl5oxxQAUnWlpOlAC96SlpKACl70UGgA96O1FFACZpaSloATtRRS0AHY0lFAoAKKXv SUALSGlpDQAUdqWjoKACkHSiigA6Ud6O9FABijtRS9qAEooooABS0gpT0oAPak70YIooAOtGOaKK ADoKOtFGKAE7UuOtJzil7UwDpRS4xSDk0gCij0o7UAFFHajoaYBRR6UdqQB60dqBR1oAOgozR3ox QAdqKO1FACd6U0nU0ppgFHejtRSAKM0UlMBaKKPSkADmjkUd6ByKAAdKKOlHagA70Uc0GgAxQaOn ejqaACgUUD2oAOhoxQTmigBfakxSig9aACjvRRQAGjtSelHagB69KKF6UUijlvDJ/wCJFaBTkhcd PeukTBOa5vw1/wAgK155xx+ddHGeM+tMgkpBSjrRjigYDpmiiigAo70A0ZoAOtITniijtQAoozSD pS0AFBpKDQAd6XvSd6U0AB4pD0o6npR2oAO1HejpRTAUUhpc4FHakAgzml7UDk0CgAxxRnnpR0pM 4NAAOtHvQKXqaAE7UtHakxzQAtJjilozQAgpR1pOKKAAUUUZznnOKACg0ClIoAPekpaKACkNL7Um DigBaSj3o/SgAxS9DSd6O9AC9RQaM9qSgBe3NFB7UUAGeKO9JjIpRQAAikpRzSZ9qACg0daSmAtH aigZpAFHejvSUCFFHFFJQMU0ppDQetAC9KQ9aM0daAAUDilooADmkpaQUAB60tGfSjOOKADFHagU vtQAlBo70nrQAvak/GilxQAlFKOtFABjmik70ueaAEJxg/hS9aTvS5oAD1ooxzR7UAGKSlpM0ALQ aSjk0AL60lFHagA7UlL2o70AFHWiigApe9FFAC0UlL3pDEBxQemKXtSe9MQo7UUCg9qQxMcmilop gIPSk+lLxR7UCDvRRRSAQ0UppKYBRQKD1oAKWiigApenNJR3oGLikPWl9KTndQAHtQcClPWkPSgA pBTu1NoELxRR6UZoAPpRmikA96AFoNHaigA7UUUYoAKO3FFGOKAA0d6KKADNIaUjmkoAUUmcml70 nAoAWigUUABoNJ3paAAUUCkoAX60lL0pKAFpKKB1oAWg0go70ALR2oo6UAJ7UUYoFABSgdzRQTQA UHpRmjqKACjFH4UdqAEGKXNIKO1AC54pBS/hSZNAB34oxyaWigBPpQetFBHFAB2pe1JR2oAXvzSY 54o70cZoADSdqXHrRxTASijpSnrQAUUlL2pAFFAooAKTpS0YpgHakpc8UdaAEHWlNA60pzxQAgoo oFIAo5pepzSetAC8GkooHNAAKOlGKKYB1FJS0UAFGeaB1pKAF+tB60HrR1oAKB1opRSATvS0HNJQ ACjg0d6DyaAFAxQOtGeaTvQApozQaPWgBy9KKF6UUijmPDWDoVpgD7vp710MY4Fc74W3DQbQg9V7 /U10a5zk0yB460hoooGL2o7UmM0vegA4xR25opKAF7UlHalPSgBB70po7YpO2KADFKaQdaCKAA5J pTSe1L3pgFFFJ0pAFL/Ogc80hoAMUopKO1ACrwaOTR3ooATNKetFB5oASij+tBoAM44I60vejHFH SgA9qQ07HekxQAlLSZzS96AE7UZ4oFHQ0wCjtRzQaQB2o7UZpewoAKT60tGKAExgcUDrzRjmgGgA 70d6O9FABS4pPaloAMdKM4o70etACDpSjpSDpR3oABRR3ooAXtSUtJQAUvak4poRd+/HzEYz7UAO 70YwKBR2oAKMdKKM80AB7UUHrR3oAKKOlBoAB60vakFKKAA+tFKe1IKADNHBoxxRjmgA5o5o7cUd KAF4NNPSjvS9aAE7UvakpeooASlFHeigBO/NLxmjvzR60AJS0lFACk0UhpwoASkxSkUUAJRRS4oA TFHrR3ooAWko7Ud6ACigetHWgBRR1oFHegANLRmikMQdaKXPNIecUwAdsUp60AUHg0AHeij1pM96 ADtR2o6CigQE0UUdqACkpaTvmgAooooAWikpSKACjvRRQMKO9LSd6AAjig0vtSduaAAUhpe9JQId Te9KaDQAlFFFAB2pcjFHakxQAUtIBS0AHajoKWg9KBiUUUdKBBSCloGKACiikxyaAFo7UUY4oASl pKWgA7Gik7UtAB60nag0UALSdDSikoABQetFKaADtR2ozR0FAB3pO9LRQAh5ozilpCORQAvaj8KM 0dqAEoxxSjpSDjrQAdKWkpaAAUZ5oGMUUAHSk60Y6UpoATuKD1o+lHegBKU9KKO1MAxzR3oopAHW iiigA60UlL15oAD0o/ho7UY4oABQPpR0o7e9AB3pKXvRQAnalo7UUwDvQx5xR3oNACg4pDRRSAKO 1FHemADrQOtLikBNIABoHNA60UALSetAzQaYBQetHQ0d6AAGg9aSlPXNABRRQOlACk80daTNGKQC 4pO9L0pKAAdqD1paQdaAAjilA4IpD1pRnmgBy9KKF6UUijnPCoH9g2uf7v8AU1vjpXPeFn/4kVpx /D1/GuhHNMgcKCeKTp9aMUDAUpxSZpfpQAduKSl7UUAJ3paKRjhSTQAtHSmqSVBIwSOnpS+9AAKM Z5peKQ0AFLSDml9qAEIo7Cg0daAAdKPeigdaYCjtSYFH0oxikAvekpR1oxQAlFFGMmgAo70vOPpR 3oAPegetFJigBT2pO1KOlGKAEo70AZNL0oAQelB6UdqO1ABRRR3pgJg0tKaQdKQB9KD0ozjtQe1A C0lH9aBQAHij3oPNGaAF7UdhSUp6UAJ3pcUUd6AEozzRnFLxQAgNFHajJ6UwAdaKKKQB3oHSgUvT igBKKUYpMUAFJS0UwDuKOhpKWkAUUHpRQAUopB1peKADqKQUvTrSDrQA40lJ360vNABmikpe1ABS UHrQaAFPSgdKSigAFL2pKWgAB5opO9LQAnelNJS4zQAcUUh4NKKAA0lKcUUAJ0pc8UlL2oATiijF HNABRR2ooAO1GKKKAFHNLSUZOQMUhhS0Ud6ADrSUtJmmAvag0vammkAvTrR1o7mjNMBO1Hal96Qm gAo7UUUCCiikoAWk6ml7UnegBaDR2FBoAQmlz6UmKXvmgAzR3paTHNAwNGaXFJ0oAO9HrRzmj1oE KaaKWk9qACigjoKKAF6Cik7Up6UAFAoo7UAL6Uh6UelB4oAM0UdqKADvSUpHNJQAtJRRQAUUd6KA ClNFFACUtFIKACjFLnOaORQAlFLSfhQAUGilNACAcUUvaigBMYoHal60negApT1o70GgA6UdqCO9 HagApO1KKTqKAClpKXjFACY96O3FLikHXAoAPSlpKDQAUlLRTAQ0dqKXtQAd6MUE0UgFNJQe1HFA CdeaWjtiimAGgdKKSgBaKKBSAO9FBooACeKKSlPSmAd6Pejg0HigBaQUUUgAYoNAFIetMBQaBRQO hoABRRnvSUAL3opetIaQCd6KUUdKYCUp60lKaADvS9qTvQOtAC+lGaTvQelIA60UUd6AF70d6KKA A9qB0NB7UY4oAcOlFC9KKRRzPhjnQrMZPCflzXQp0rnvCwb+xLXdyNvHsM10SkHp0pkCjg0dDS45 pO1Aw70uKKKAD+VHWgUUAB60h7UpooASgUDGDQDQAtIaWkPWgA70UlKT2pgB60A8UppO9AAKOppa TFIA9qUdOaSgdDQAopKXvSUAFFFHegBeO9HU0maXvmgAPFHtRmk70AL0FA560UnagA70GjFKelAC UdqBRQAdqOlAoI6UAFL2pDR2oAKD0FBoz2oAKBQaBQAvejijtR70AIBzSjpS9qTHFAB3oNHejvQA gpaQUc0ALxmk60d6KYBRzml+lJ6UgFNJ2pc+1IOaAAUUvrSUAAooFHvQAUZo60GgAoooFABxml7U DFJQAppMc0HNA9utABilz6UlL2oAB9KQZpc0lAC9ziijvQaAE7UpozkUcUAITRSigGgA5o6GjvRz mgBB1pe2TSUuetACE80oHFGBnNFABQaXNIaAEopfekoAKKKKADtRR2ooAUdKSiigBRR3ooHWgBaB R3o+lIYUhpc5FJnNMBRijikFKfvUAHXNFH0o7UAJ/DSU7oKSgQUlKaKAEopTR3oASiijvQAvaig0 UAHbmgmijvQMKO9BPPFFAC5pCcijPOKOgoAM0lLxn1pKBCmjtmlzSUAApD1ozRQAvajGBR296O1A BQBRRQAuKQjilpD0oGHWij6Ud6BB9aTHFKaTPFAC0lHejvQAppKWigBOtLSUtABikpc8UUAFJS0l AC96TJpaTtxQAClNIKWgApKXHegUAJS8GijFAB3ooo7/AIUAHajPFHajoKACkJ4pe9J2oABS/wCN NFOoAKBRwDSCgAxSnpSdBRnIxQADpQaOlB60AFHQUGg9KADigUetAoAKO1FFABQaSimAGl4xR70d qAD+VHSgUDpSAKPSgnmigANHWjsaO1AAOtB5pBSmmAUp9aKD0pAJmjijtiigA/nQODRnjFJQAvaj tmigd6AD1o7UdRQaYBQaKD1oAO1HrSdqWgBO9LjFHcUvegBMUuKQ9aXNIBOaWk7UUAHel70dxSd6 AClHIpKUdDQCHDpRQvSikUc/4XQjQrMnHMf9TW4ABxWF4aZf7CsuQf3fY+9bq9BTIHUh7UvSjtQM Sl7Uc0DpQACgdaKBwKAAgUh6Ud6XtzQAgo60YopgAoJ60UGgBKWkpaBBS4xxSHmlJ45pDE60DvSU vSmAUUvpSUgF7ikPeilHSgA6daQUtBHpQAnalo6dqQ0AFGOaXtSdM0AKRSZHpS9qQ0AGeaXvSY5o pgLSdKOaO1IBAMep5707tSUc8UAB78UHpS5pDQAZopcYpDQAd6OtFL60AITS5ppI4pcAHjvQAvaj OaO9HPPFACd6XjPWjvRjmgBAKUdfajFIKAFx1pAaBS4FABikpelJ3oAKXtSd6WgBB3pe1JR2oAKT NL2pKYC56UHmkxS0AFFHaikAd6OlJS0ALSCl7UgoAXvRRjnmlNACdqKKOlAC96TmijNACdDS0mBi jFABSigUdzQAHrSn0pOaO9ACdaKd0NJjmgAoo70d6ADtSUpooAKTFHSigAoFFFAB2zRR2ooABQaU UGgAHSigUe9ABS0lLxQMBSe9L2pM0AAJpSeaKD1oAT8KKB3o9KADtRR2pD60CF6UlL3ooASig0UA LRR6UHigAIoPSig0AAo70UdTQAUZozRjmgYuO9IRxS9MUhoAMcUntTqSgQvakoooAM4NJmloFAB2 ozxR2ozxQAUvakOcUYwKAF9KQ0tIckUDF7ZpD1FGM9aDmgQZpKKOlAC0Gj0ooATriloooASlpMUt ACClpKXigAzSUUvSgAHNIOtLSUAKKDSUGgBaDRiigBBSn2pOlAPOKAFoPWikNAB0o6jNLxik7UAL SdqOtA6UAApetJ3o7UAHWigUDrQAtJ0paQ0AGaOtAoNAB2FHakzS9qYBRQO9A60gDNFBHSjFACUt J3peM0wCkpTR2pAHFFFHagA70cUUlABS0Y4oxTATvSmjvQeKAAUtIKD2NIBTSd+lLSd6AF78UgpR 1oGBQAnSilxSHigA+lBpRSUAFIaOtBpgFLRR0oATvS0d6KACj8KD2o9KQCUtHejvTABR0NHejvSA DmlzxSHtQKAHr0ooXpRSKOc8N/8AIBs88/uwP1reXp0x7VheHR/xIrI5Ayg/nW6nT3FMgeOaD2xQ KOcdKBiAUpoFHWgApO1Opp60AFBJpaO1AAOlApM8UvQUAJjig0dqKAAdaD1o70Ee9MBaTg0HrRSA OKWkoHU0ALSc4pRxzQOlAB34o70HrR36UAFJng0e1LQADrR2pKKAFxxRntSZ4oHWgBecUlLSYoAT vS0ClFACdKKO1AoAPSlpBQaAA9M0UdqOtAB3oPal4pOvNAC0nWlNJ3oAMd6U8mk70uKACj3oIooG GaToaXuKPwoEJzijvSjpmk70AAoFLQBQAUlL0pKADr9aUUncYpaADvSZ9aXFIaACilpO9AAaOaO1 J1oAUUUUlMAp1JQKQC80lBooAWl7UlHagAoozRQAY4o60HnpQaAE7UvbpScYpaADGBQOc0UD60AA xmlJ5pO9HU0AHWij+KigA70dqM8il6UDENHalNNoEFFFHagAFBoooAKKO1FAC54oFJxR9KAF9aKB 0ooGFLR3opAJij+VKKTNMBRQaQUvegBKO1HHNHagA7UGgc0lAAetLQaSgQUtJRQAtIeooBpTQAUE UGigYdCKU0ntQaAAijvQTjFFACmk9aO2aD04oAKTtSg0ZoEL6U3vTqSgAFFHSkoAU+1FB4ooAKKP xozxQAUpoxxSDpQMWk74ooxzQAd6ODRSCgQd6KWkoAXvSUtFACdKWkNKaADikoozigApaQUZ5oAU UmKWkoAXtSUtIaAF7UCik+lAC0CgelHtQAGg0HtSd6AF60mOKXpR2oAO1IO9Lmk60AGeaXFJS9Rm gBKMGl9RSUALx3pOvel4o9qAEoxR6UlMApego7UdqAAd6MYo7Uc0gDvRmlpKACiij2oAKMcUhpRQ AYpaT1ooAM80Yo70YoAOlFB6Ud8UwAdaDQOtBFAAOlGaBxQaQBRmjrRxTAU9qQc0vakHBpAL3pvN L3opgAFB5oFHrSABQDQKKYAeaOtJSjrQAdDQKQ06gA70nfijvS96QCfjR9aKO9AC+lIaOhpaAEPa gCilHSgBw6UUDpRSKOe8NY/sOyPJ/djr+Nbi4PTpWF4b50SzAAI8sZx9a3gMUyB1BoxmkoGFKKTr 1penFABmgetFJ0NABQaOtJ2pgOHIo5xR2pM8UgDFBHeilPSgBB1oPSiigBcc0lLSHmgA4oFL1pO/ FMBR0oFIKB3pAFLmjjNJ1oAKDS4pMZoAAaM0d6MUwF7UnejpQODSAU9KT+GjtR2oAKKTvSmmAdqK AKKADtRRQeaQBS9qTNLQAGkOM0vekPNAC470lL2pB1oAUUdDSZ9KX60AGaKM1FdJNJZzx20oiuGj ZYpGXIRiODjvg0ASjk0EflWF4P03WtI8PR2mv6kNQvxI7NMGLAKTkLuIBOPce3auW8SPfWvxE0HT Idc1VbTU5JJJ4BKoVQvOEIAYDIx16HigD0UE0tRRqtrbRxtKxCKqeZK2S3bJPcmhbiA4IniIJAGH HJ9KAJe1Fcl8RoZU8HajqNtqGoWVzZQNJG9pOyZPHDAHB6deo5xUngCF38KWOpTXl7cXN9Ak05ub lpRvI5Kg8KPYADAH1oGdVg03mlFcFreh+JPGFxczWuvX+gWduzRWkMSNE85HBkchg20t0HoM96BH e96XpXnHgbU9Zh1vVvBXiW8N1c2sCyw3SysJHjbg/Pw3cEHqOeeBUXhS0uP+Fm+ILKXWtWubXTBG 1vDPqMjgFwCdy5wwGSOenHU8gGelUuOK4RdRuPG3irVdJtb67sdH0giKeSzkMU1xcEkEBxyEXaeB gk98YrM0S91LQPio/hYapf6lp01oJt2pS+bJGwUnKtwcZ4/H2oEem9KK8st5vFL/ABN1Pw6PEsgD 2K3HnyQLiIErkQx/dzkkZbPA5yRUmhXfiaz8Z+I/Ctvq8uopDbia2vL9N5t5GC4DMMA8MflA7A4A zQB6ee1Fed+Eb/WLP4ia94cvtWuNTtIIlnjluAu9GbaccAcfPjA6YGAK9DIBHOfwoAWjmvNfDEd8 3xG1vSJte1i4s9MWKSBZ7kEkvtYh+AWHYegqPT11AfF270Jtd1mTT7a2F6kbXIPzEp8rHGSnzEY/ +vQB6dg0vTtXlZfUYvjGmgDW9YfTpIPtPl/afuNtJ6nnZ8nT3r1SgANJzivL9VGop8YdP0KLXdXT Try1a6liW6xhv3vyqSMhfkXj9aseJ5dU0/4haBptprupW9lqjsZ4zNGRleyFgSOoyOnpRcD0nvRX F61beKfEF9c6XpOqjR9PtFWOS9aHfPcy7QxC4K7VAZcsMHOcVk+Cte1/SvFUvgvxPKLm5ERntLsM XaRMkncxPIwOOMjBBoA9KyMUda4z4k69e6N4eEOklv7TuGLx7CAyRxjzJHxnkBVx/wACrf8ADmtw eI/D1jq1uybbmIMyo2Qj9GXPscj8KANQ+1cxcazrerT3EPheHTjBbyGKS+vnZozIpwyKiYJx0JJA z0ziud019Wm+Leo6I3iDUv7Ps7dbxIfMjJLHy/lJKZKfM3H05pviXwcukm71G08eX3h+2u52kaF5 SYvMYlmEahlO4nJwMnjvSA0LnxL4q8O6zpltr1jpd5ZaldR2kVzp5eIxyMe6OzZGATxiu7I4ryTw oms3HjyyQ+I4PElpZW7vPLNDsa0D7lTbkk+YwUZJ52k8/Nk+t9qYBigVxfiCw8VeJNWnstL1c6Dp tntBuUi3y3MpUMQPmGEAYDryQeorM8H+JNb0zxXL4K8V3MV1e+UJbO8Q/wCtXBJU5AJOAccfwtkn g0AejnrR3rzj4r6rrXhnSYNX0nXLq3MtwLdrfy4XjGUZtw3ISD8nqetReM9T8ReELrQHtNba7gmu xB5N0samcHBPmS4AAycZCjA55oA9LorzXXdQ8VeFvEvh5pNc/tRNUuvIl09baONQDtDeX/FgA5BL cY5OCa9K70AHelrz+61ttc+Il54am1e50eLT1je3FtKkcl5IQGYNuByoBGFAHcnPGLkFz4m0ZPEE UhudXljkhi0kzRKolLIBligHAY/O3H3ScDNAztDSV5Pr9h8RvDNsfEieI4tRaIF7qyERWGNep2qT 8yjJ5+VgK6geJ9R8Q+GdLn8N24jvtUViJbgAx2iowEjMM/MQThQOpIJ4zSEdhR3rybWtS8U/DTVb TUtS1yTXdDu2EU6zRBZIj1JRQQAcA45x1BHQ1oeKLvV7Hxxoem2fiLU47XWHcyR4tz5QByAhKFh1 PUHsMnswPSRQa838c3OtaJqnh+207xJqMQ1O6jtZA8cDhQCilxlAdxySeoyeAOlN8U6l4s0HxP4b trLVY7iG9le3S2nRQJNoUb5XC5JJYsQqgDGBnrQFj0rPFHevNtT1LxR4Z8a+HrabW11SHV5mimtT bJGsQBQFk2/NgBiec/dOabJqvinR/iRoVjf6rDcQ6sjtNYqiLHb4B4jY/M2MDk9cNxzgID0sClrz vWfERvviJL4ZuNbl0Oyt7VZhNDPFE9zK20hdzqeAC3A5OPatTS21nQtb1aPWdTub7R7axS4huriJ Ewd0m8FlABYAD8McDNMDsKWvPdDGq/ELSBrkuu6lpFpNK4s7XT2jj2ojMu6RirFmJHIyBx0pngPx Bresv4i0C5vle50mZYYNQkhBd1LOuWUNgthM59+c90M9Epa8s8EXXinxVpmrQza/JbpDqDob5ERp jjb8iJgqijGf4s7sdsm34I8X6mdM8U2uru9/deHmYiUgK86APtBxxn92eff8wD0f2oNeZeD5dU8Y +HzrkHjC8i1tt5azRojbQMCwRWi2k7SMHOckHOc13nh+W+n8PadLqaOl+9rGblXABEm0bsgcDnNM DSHNIetec/FTUtV0CDTdR0vWLu0ea5W3eJWj8vbhiTh1Pzfjin/EafVfC3hNdUsPEOp/a4XWFTII GSTc2cuCgHAHBGKAPQ/WjtXAa1r9/wCFvC2mQWt5Lf65rEkcVrJesjLG7BdzHaF+UZ9Dyw7UzxLp uv8AhbR5/EWn+Jb+/urT97cW1+Ua3mTgMAihdmOowe3vQB6F2pM5rzHxt4iu7z4d2vi7Q9Vv9PeQ Ii28bRlCWfa27IJyCCMg9unJrU8VRapongGS/t/EOpLe2aLL5jmJvMLMoKtlMEDnHQ89T0oEd1RX npGqJ8L31tvEWrfbmsf7Q8wGE7X8vOwDZjYTjjr71m2N5rjfCR/E8/ifUTfiF50x5HlgqzKFxsOc 8Zyc54GKAsep55xS1wWhW2o6l4Ci1S88Vaslzc24unlQwARYVjtX5MBeRnJz8o5HNRfDmbWfEvg4 anqOv6l5907IjIsAEYV/vLmMjJwQc54zwCOALHoVL3rzP4e6zqV2mtXWt+ILu4h0id4nEnkhGULy zBU3cFSQd2PyNWvDt1rHxA0q51ldavdGgeaSKxgs1iICKeGk3qxZs9QCo4/GkOx6FzRXn3g/x7cX FhrNn4hT/ia6ErG5eAL/AKQqlhlVz97K4I4GWHTOBDfWHxIu9Nm1qPXIdPu1Bkj0WO1R12gnCtKS csR17Z446gA9HNFcx4C8Vnxh4Zi1CWNI7tHMVwifd3DnKjJOCCDz7/WtPxDqF1pukvLYQLPfSOkN tE+dpkcgAtj+EZ3H2BpgahorynXR8SfClr/b0uvWerWsA8y6tFt1jVQSMgcZKjJ+bIIGOOuLXxA8 VanZeB9N8UaHqc9k12IgLdo4pEIdS2TvUnIxjIOMdu9ID0wCiuE8bf2x4a8H3OsWnibUTc2gUkTR W7JJukUYI8sf3uMH86kvP7WT4btqza/qSXy2n24uEt/veWG8vATBTPbOf9qgLHbd6WvP9D8W3Gnf DD/hLNcv5b+aRGYRMscYLiRkVE2KOuBnO7HJpf7P8UXHhJdeg8SXq6q9t9sWyEcRtskbxEF27sc7 c7s0Ad/1FJ2rziX4nSXPwtu/E9lY7L+B1gaJvnjjkJXDEgj5cMPxOK0Ra64dJtNY0PxZdakkzxPL HPBDIkiM6h9mxQUIG7jLdMdeaYjtqMUprzj4l6nrvhbTI9R0nXrpZLm58oQTRW7RoNpPy5QN/D3J 6mgD0foKK5bxJrr+BvBM19eXj6heoNkTzqq+bK3QYUABRycdcDqTzWZqFn4ts/Cza5b+Irh9UjhF 1LYvbwm2PGWjUBd4AHAO89OvNIZ3nsaO1YXhHxLB4s8PQ6pDE0LMTHLG2DtcdcEdR3Hsao/ETxNd eFPCUt/YorXUkqQRM4yqFs/MR3wAePXFMR1lIelcTc2viC00uw1HRPE13q8MksHnJPDC4khZ1DNG URSCASeSeM9wKi1u68W+JNRvLPwre22mWenyiGa7uEJeaYYJVOCNgBAJIBzx0pDO76Ud6868HeJv EFr4om8IeLNk16sRmtryMDEqD1wBnjODgHgg1PeJ438TxXN9o2r2uj2SyEWELW4kkukAxvd8kKGO SML0xn3Yjvu9JXnvh/xXqniPwvrUV3LJpmtaMzCeW3RCrlQxHDgjBKkEe3BGam8A3ms+K/CA1S+1 27juZ5GRfJggVI9rcFQUOc9Dk/TB5pDO9pDXm3w81nxN4l0C91KXV0luo7g28aTWqCEABSXKphmI BOFDKM/nVbwhrHjfxn4fuWh1mws2t7hoxe/ZRI8x4IUJwqqAevzE/qWI9Sorzrwz4i8T+MvCHmWt 1a6dew3EkU181uJEdVAI2qWxkk4J6DBwORh3hvx7qF78LL/xJeW8ct5ZCVR5aYWUqAVJGeByM89j QB6HRXnLXnia58CL4p0jxE9zdtb/AGiSye1iaHj78cYVdwZfmAyzZIwfUSfEPWdb0HUdHk0vV5IY 9QuBBJbPBDIF+7ymQDnk5yT1HSkB6FRXD+M/E82gXeh6Gt81u2oSbJ9UmEeYo1IBIzhQxz1K4HPF XguvaT4j0uBtVfUNGufNWeS6hjEsTKjMp3oFXacd14wOeaYHV0lec303xD8RGXUvDt5YadpgY/ZI J4/31yg/jYsrBcnOBxxjPrWt4C8W3XiS0vLTVrdLbWNNl8q6jTgNnOGA7dCCMnkZ70gOxpBXnt7e +Ibf4lWfh5Nfn+wXtu9xu+ywGWHAY4DFcEZA6qeOPevQqYC9aDXF6lf+J/EWo31j4Xu7TTrOxbyZ r+4h81pZwMlI1zjauQGLDqTgHFZ3g7xVrzeJ77wh4lEcl9bxs8V7CoXevByQeDwwIIHsRxQB6Lzi krzvQdS1+7+JesaFca7LJp+nIkq7YYN752kK52+jEHAHQcju3xhqHiXR/FmgafYa7N9l1m5Mbq9v CzQAOpOw7RwFYj5t3TmkB6NSjpXC/EC51bwz4UfWNO1+6W4tikZSeKF0n3SAZI2DBGeowMDpnmrk Gp6tZeENPmhmbVNY1QRm1W6CRqjvGGO7Zj5FAZjjJxxk9aYHXUV5Z4g1Dxx4EeHXNQ1y11fSHmRb uAWghMIJx8mCT04znrjI6mup8S3fiG/ni0nwt5NvMUS4uNRuhmOKMk7VQc7nbaeMYAHPUUAdVQeK 8stPE/i7wd4qsNI8YTQ6hp+oN5Vve28QDBs4GcAeoyCCeQQTg53L/wASX2rePx4S0e6FpHbW5uNQ u0jVpU+7tWPdlc/MucqeDxSAk1/xNrmmeL9H0Ozs7CYamXKySM4MaqDnIGc4GDnvgjjrXYRh/KTz CvmYG7b0z3x7V5hqdnd6b8XPB9ve6hcapBsuWhe4jQSofLwclNoYA4I+XIGevbVl8RXeu/ES/wDC tvqkukw2VsH3wpGZrmQgE4LhgFCsOAuepzimB3nSlHSuc8PSa9FrGq6drE4u4LZYGtLsQCIzK+8s WxxuBGDgAYAOOa1tV1KHSNLnv51dkhXIRBlnY8KoHqSQPxoAuCivL9SuPizaW51stpKwp+8fSoF8 xkTqQxI+Ygddr/Sr+r+KtQ1T4YjxXod4+n3EKeY8BjSVWw4VlO4Z9SCCODz7AHoJPNFcML7XJfhm PEEetyJfixa+ObaJoydhbYFA+72Bzn3NangW81LVfDVrqup332iW7Td5YhREjwzD5dvJyMdSenbO KAOl9KDXnfxE1rX/AAstneWGskQ3l15JgksUkEQIyCrcdMHhiSc+1dzYW13awmO8v3vZC2RI8SoQ MDjCgDGcn1570AW+1Haiudji8VjxzJJLcWJ8M/Z8JEi4l38cnPO7Oec7cAcZoA6LvRXn+pXfjzxB c3M/hi407T9Lt5GjhkuBukvCvBcZVlCE5A6Z65xineB/GGo65JqPh3XVWz8QWSsGeJB8w6FwOVyp Kn0OQQMZoA76iuB8H6t4g1Pxbrum3+rJPb6PKsXy2aoZ92/liDwRtHTg1dOsal4n8QanpOh3/wDZ 1npZEV1e+Qsksk5zlIwxKhVA5JGc9OOaAOworz7QvEfiC2+IF/4Q1G6g1XyLQ3MV4YRbvuwhCsFy uPmxkDPeo9K8ReMtR8X69oKnSt1kY8XJhcRwAjIwm7dIWHbcACCfai4Ho1FedeH/ABP4suNe8ReH riKzv7vTighvFjMKDewALruOQFJbAIJ2kZ5BF/wP4h1jUtc8R6Pq89vdPpc6pHcQQeUGBLjBXJ/u fqeTxQB21FAFHegBcUnTmjtR2FAAaO1FFMA6UHpR0oPrSABRR9KO9AB2o4zzS0mKYB3o70ClHpSA TvRzR0NJ1pgLSGl7UUAAoPIo9aKAEpetJj1pR1oAMc0Zo6mgUAL70lB60UgCjIopKYC0c0AUHrSA KUdKbTgaAQ5elFA6UUijnfDTFtEtMDGEx9ea3xzWB4Y/5AVpxjKZ/Wt5enNMgd3o7UUZ9aBidqXt Sd6WgA6/hR1FHPWjpQAUmMClPtR2yaADtikFL1oxxQACkNL70lAAaKD1opgBzR2pT1o9KQCUZ5oF HfpTAP50dKO9GKQCikxilFBHNACUvc+lJniigBKUdaKO9MA7Ud6U9KTHNIBaTFKRwDSdqACj1ozR QAZ4pKWigBBS9qO1H8qACl6Cg0hJxQAEdDR1paTFAC0nQ0dKAaACjrS9KOlABR60daB0oAAa858X OY/i14MOwEHzVyTgcg+34+/HSvRa818dRXj/ABG8Kz2dje3rW26aSK1jUkLvAyWbCr1xyR+HWgDv dY0iy13SrjTNRiMtpcACRA5XIBB6gg9QK5i0+Evgqxv4by30hlmhdXjzdSsAynIOCxzyB144rrrZ 55LdXuIVhkOcor78DPGTgc4//WetTCiwHN/EIE/D3XwCcmzfoevFHw+Zm+H2hbipP2RB8voOB+OO vvT/AB4rv4D1tI42kdrR1CKpYnPHAHeq/wAP4NRsvB+mWV9pslkbeDYRNIpcnOR8q9Bg98EdMd6A OqxivMtS8V6/YeObzSNY1ex0LTHQtp97Labo5ehAZ2IXdjOenI9xXplDAMNrAMPQjNAHnvhm2m1P 4iXWuLqn9p2lrpwsvtyRKkc7M4cKhThwo6nPUgU/wwXHxd8ZqAu1o7ZiSefuDGOOnXvXoBrzPQb7 7N8ZfE8bW94UuliRXjtXeMMqoPmYDC9TyeODz0yDMnT9aj+GvxB16DXo54NK1e4a5t7zYWjDZLde p4bBxkggdjmiw1u31v462l/YrL9kksmjSV0KCUBW+cA87SeATjPHtXr7xpLGUkRXU9VYZBrynUrt LP4+RXDwXcqJYhSLa2aUglGAyFBIHPXtnsKQiDX47eH41u+p6nc6NYXWnon2tZvs4nKkExiXHHIG cEHjrzz0vh3xHpFvrOr6bplhp1n4fsEWWTVY7hRFLIQoO5sYZuxYsTxzzXavHFcwhZYldDg7ZEz7 jg96cYozEYzGpjIwU2jGPpTC55Xoeu6WfjXrVymq6ebK6s1jimFyhSWQeUAqt0Lfe4Br1btx+dcz YeD7SDxjqfiO5jhluLhkW1G0HyVVFBIyOHJB5B6Y966egGeVLrdj4U+MmvS61cJZWl/aRyQzzKQH Kqg4OPZh9RWdYeLbKT40f2o0V1ZW13Y+QBc25DycAoQq5IDbQRnGRz3r2GW2gnaNpoIpWjbchdAS h9RnoaFghS5e4WGNZ5FCvKEAZgM4BPUgZP50AeU6tqkOmftAWUs8wSJ7AQsNpZjlXIAABOScYGOc 162DkZrnG8UaTD49Xw4bWZdVnthL9o8ldjIMkKXzuPftiuj7UAeWeNrqPQPi/wCGdev3+z6abZrZ 7hvuhv3mQT2++v6+lUfFfi3SdR8eeD76CUrp1tcyD7dMoWCbOzPlk8nbjBOMZI5r16aGKdAk0SSL kHa6hhn15prW0DzpO0ETTIMJIUBZR6A9RQB59rvjLXNO8e22jSXGnadot8oa11Ge1d8nbkqWMirn cCOmRkcc5qGwhutY+J1pqR1HT9RttItHS6vra3MUYdg22PPmOGZdxPUbQfU16Le2FnqMH2e/tILq HOfLnjEi5wR0Ix0J/OnpbQRW4t44Y0gA2iJUAXHpjpSA5LQLuPxH4x1rVo7m1n061i/syBFcMSQQ 0rcfwsSo687OnSuV+Hes2Phvxlrfg06paSaeJTNp7+cp5OMx5zy2CvGOqtXqcNhZ20rSwWkEUjKF Z44wpIHQZA6Un9maeCCLG1BByP3K8H8qYzzP+2LHRvj7qT6hcrElxpyxREgn5/3ZA4B5wGqvrfiS yf4z6HcLqtvPp0Aa0dGdglvP84JO75Qx3KARycY7c93F4j0JPHk+gR27R6zLbrLLOLcASKOil+pw CTzx1Gc8V0E0UdxC8M8ayRONrI6hlYehB60hHnGqRzT/ABx0uXR8s8Nl/wATR4m+QRkttV8ZG7oQ COcD8PSfpVWx02w0yIxafY2tpGeStvCsYP4AD1NWjTA871vxl4g0z4iJoMsukabpVyga0vr22kcO doyuRKqlt2Rjjt6jNQxXd58UrXWLrUNPubXQ7GSS9vbOGSGNQVfERHmSAsAxfjBwec8V6ReWNpqN s1ve2sF1A3WKeMOp+oIxS21pbWdqtta20MFugwsUUYVAPYDigDxX4p+N9D8U+ELJdGuHnKXazPJt 2CA7ZFVXz0LfMR7Lmtb4t6impeFtD1XTJfNt4dQVzcqAY4zt4LE8Yzjnoa9NGj6WsEduumWQgjl8 5IxbrtWT++BjAbk89eauOiyoySKrowIZWGQR6EUAcDJf6d4c8U6LDZxzeINW1nejX816ryxQDD5V QNoTBJAUKp2888139U7HSdN0wt/Z+nWlpu6/Z4FjzznnAHerh60AedeJbLwn4q8ZXHh3WbeK01KK 3iltr+O5WOaTJPyKD1IweCG4OcCqug6r4wsfCHiOO026vNo961tYTzxtK11GhAZcKVZio75OTkc4 r0G80XSdRaQ32l2N0ZAocz26OXC52g5HOMnHpmrcEEVtDHBbxJFDGoVI41CqoHQADoKQzy+38a3+ q/D+bWL7WtAVJI5YZdP+wO0ruMjygPtI+Zh0GAcMKdp+sXXwr+Gmkf2ppU1y0kr+YsMgAg3kuAxY +/0z+voiaLpSX51BNMslvW63K26CQ/8AAsZ71cdFdGR1DIwwysMgj3piPO/ibdRa94atNA03F1qO qyxNBDGysUQYYyNz8q4/i96o+OwNE8ReBNTuzHDa2sv2eeYk7Iz8nU9MY3EfQ16NY6RpulmU6dp1 nZmU5kNvAse8++0DPU1Pc2tve2z291BFPBIMPHKgdW+oPBpAePfFDxfpV5eaDJpd5Hc/2ffLK13E d0Ct8pC+YDgnAyQDx3xWr8TL+GWfwhrNpfiKyTUGU6hGAyQhio35OV6KxGQQcfn6MNL08C2H2C1/ 0Ulrf9yv7knunHy/hVmSNJo3jkRXRxhlYAgj0INAHn1vqmj6D400vStOgfXNT1RCbjVZLtZpoo/v AtgHCdwo2rwMCofGV7at8SvBE0NxbMY5p1kbzFKqCFHPPB5OPc131hpOm6UjLp2nWlmrYDC2gWMH BJGdoHqfzNc1qvw+0rV/E9je3Gn2Q0+2hk3wJEq+dKzZG8bfmUfMevU+5pgZniu18MeKfGEfhrWo I4JnsVurTUY7hY5GJcqUXPDcAEA5HB4qj4estduLPxj4Tl1X+17GC2MFpeSNvcySRk7CxJyRkZBP HHQcV6Hc6HpF6D9r0qxuAUWI+bbI/wAgOQvI6A9BVm0tLWwtUtrO2htreMfJFDGERe/AHApDPKfh v480bw/4Y/sHxDctpt/p7upjuEYFgSWwBjORnGPpjrVj4Vzibxr4zdIZYEnmim8q4AEqEtIcMAT0 z0zxXpcmm6fLfJfSWNs93GMJcNCpkUegbGRXl/w0uI4viB4wSTz3kluyiSLAzKdskmQWUELjK9SO tAFz4P3iMniS2EkZjXVHeM+YCxzweM5/hHOOc9+yfDiWBPiP4+hWVA7XcZVN/Jw02cDrgZH0r0Nd J0xbtbtdOtBcrkrMIF3jOejYz3P5mlOlac12Ls6faG5Vt4mMK7w3ruxnPJ596APHr3SNAvPDt140 8L6v/wAI7qcETyTWlvdrsDpn92yjGCccAccjg5r1vQri+utA0+41GIRXslujTIOzEc/T6dqE8PaI lxDcpo2nLNAMRSC1QNGMk/KcZHJJ47mtH3pgec/Ge3uW8I2l9boWWxvknlwM7Vwwz9MkVlfEzxho ev8AgCa3068F1JIIZpPs7b1gG4HEjDhTk4x1z24NetMqupVgGVhggjIIqsul6fHbxW6WNqsETiSO IQqFRh0YDGAfcUAeVeNvO1LwT4Z8U6XKL59I2STfZxkcqhY8ZxtKAH0yc9DXUeJfE+kar8Obua2v IJpNRtDFb28MqySSSuuBGqjlmBOCB0wa7fnNVItMsILp7uGxtY7mT78yQqHb6sBk0CPKtf8ADN/p PwEXTrqISXVqyXEiIc+UDJub64DHP49q0PEvjDR/EPw4kstNuReahdWYdrW0Ad4dgDOXGfkUbT15 PYGvT+owelVbLTbDTEdLCxtrRXbc628Kxhj6nA5oA8w/4THRLr4OrYJqMUuovpbW32aEh5VZUIJZ RyqgAnccDFN8K3MWtfA+80mzlFxfRWdwpghJZ873KjHqRjj3HrXpg0TSVW6VdLslF4pW52wKPOB6 78D5vxq5FFHBCkMSLHEgCqiAAKB0AA6CkB5f4L8aaOnw8s7CW9RtVjR7NNPjYG4kfJCgJkHkEc8A c5Iwaj+F/ivS9G8Ef2Zql7Db31jcyQrZbwbiQlgQFjyWY7mIwB1r0qLSdOt7yS8gsLSK6kz5k8cC q7ZOeWAyeefrQulaeuonURp9oL/G37UIV80jGMb8Z/WgDyf4eyW2qv410GW4+zz6jPIscEp/eruE m7KgnGOM+/fpWt8IdU+x2WoeFNQxb6jps5bypCFLKx5IBOSAe4GMMvrXo9pZWtjG0dnawWyOxdlh jCAsTkk4HUnvUd/pGm6oY/7R0+0vBGcx/aYFk2H23A46D8qAPPfCVs0njrxV4usrO4fSHV4oBGdz XUiEeYYxnDAsjYOcZOOMGuj8OfEDSNf8O3etSbtPgs3K3C3UiZTAzngnrnGDg5yK6pUSONURQqKA FVRgAegrPm8P6Jc3/wBvn0bT5bzIP2h7VGkyOh3EZ4oGcl8JdLurDw1d3Vxa/Zkv7trm3jbIfyiA FyCTjp0rofGOp6to/hi71HRre3nurcBzHOrMCmfmwFIJIHPXtW93o70CPMZPE+o6x8NrjXJ9c0D7 JNbOktuunuzBypHlZ+0feOcDjPIOKzPGeiXdn8B9Otbm123Nj5MkqISfLBJBznnjdz6fQV6dF4e0 SG/+3xaNp0d5kt9pS1QSZPU7sZ5yfzrQljjmjeKVEkjdSrI4BDA9QQeooGeYeO/FWka98OZrDTb2 O+vbmCOZ47VxI0CRskjtJz8gAUjnkkgDNSP4u0a7+EP2db6C4vX0nymtIGEkoIj2sSgOVAxkk4wK 9A07R9M0eF4dM0+1s4nbc6W8KoGPqcDmmRaBottHcxwaPp8SXIIuFS1RRKD2YAfN+NAHktpbDxZ8 C4dMsriC41TT2M4tYJNzgJK3BUEnJQnHqcV3ngbxRYaj4CtNQmuI4FsYfJuzI4HlNGNpJyeAcZ55 5rq4IYreFIYIkiiQYVI1CqoHQADpWfL4c0Ke/N/NoumyXm4P9oe0jMm4d9xGc0wPO/BNi2h/DTXt U1vTTPY3Ze8W0k5aSEKMZU9CcZH4dKqNoUfgdtI13wfrc01nqN1DE+nTziRZ1kIHy4xkgN1OSOuf X164t4bu3kt7mGOaCVSskUihlcHqCDwRVG28O6HZXf2u00bTre5yT50VqiPk9TuAzzSA0q8u+M1/ aN4dshFdQvcW+oKxVJAWTCtnIBBB/Ku/8Qa1H4e0S41Sa0u7qG3AZ47VAzhc4LYJHA6n0GTXl3jQ eGvGWnaU3hmLS5dX1K7RphAkRugjKSxk25YbcgtnOMUxG/8AFKyfxN4AafTDFdSWc6zyLBJ5hUBS HC7epG7OPQGtvTvGOkan8P21+ScfZUtT9pVXDOjgYKdfvE9ATk5HrXQWGmWGlWxg0+ytbOItuMdt Csalu5wvfiqzeHtEbURqLaNpxvgwYXJtU8zI4B3YzmkM5T4Q6Jf6L4LAv4jC91L9oSNjyEKqBnng 8ZxXSeLW02PwpqMur2Yu7COLfNCcZKg9RnoR1B65HFbXNR3FvBdwNBcQxzRNjdHIoZT35BpiPJpd DufAeoaHe+E9fmvNJ1K9SBtPmlEsbh+rpt4OAM568DJNbN74t8TQfEWTwy7aPY28y+ZY3NzBI/nL xxxIoLZyO3I6ciuys/D2iafeNd2Wj2FvcsSTNDbIr89eQM81LqOkaZq8aJqWnWl6iHKLcwLIFPsG BxSGcFZWOraj8Xre9ubnT7n+y7Ix3c1ijxqrPvCxsC7fNznHpjIHFdNoXjPTte1TVdNSG4tLnTJC ky3WxSRkjcoDE7eOpA6ituy0+y02DyLCzt7WHO7y4IljXPrgDGarX/h/RdUuVuNQ0bT7udQAstxa pIwH1IJoA4PwPprapeeONUto1Wy1W4eC0dsqsm3zAzccFSWHI96qfDDxbpGieDv7M1a7jtdQtbyS H7IxLTyMTkBY+WJySOB1FeroiRosaIqIowqqMAD0AqmmjaXHqL6imm2a3z/euRAolb6tjNAjzj4J 6jb/ANk6hpj3MS3aXbSLbtJ+827VBO36jkjvWX8MtNW80XW7O/1K8gtrC7c3GmQSCHf8uDvbO7b8 pGAyjg5zXr9jp1jpkHk2FlbWkROdlvEsa5+gFVL3w3oWpXRur/RdOu7gjHmz2qOxHpkjNAGV4K1q w13wjFNaaS+lWQ3wxW77QCq90I4I56+oP1rlfhHPHD8Mb5bqDzooZrgmB8ESKEUlQCSMc89ua9C1 LRdN1KxWC60uyu0hUmCK4gR1Q4wMBgQPSuf8DeBLDwvoMcVxZ28upTR4u5mRXzkYKA4+5x070AcP c6faaBo1v42+Ht/cxRXE0Ql0kyebHIXIUIUBOGBboScZOCMVrfF66FvaeGLq4jWN474SsHwQuApI zn/OOtd9a+GNAsbtLu00PTYLqPhJ47VFdeMcMBnpxVDxZqnhjTP7O/4SWK2k86fZa+dAJdrEcnGD gcjJ9xQBS8ZTeFtX0bTl1fyLrTb668iG9imXEDlWw4kzgDK7Tz35z0rE8O2OreDfHtn4ZtdVuNU0 O6tnnKXI3vaBQQPmBwoJAA4weeAea9CvNNsNShSK9s7a6iU5VJoldRkFeh46Ej6GotN0XS9GEo0z TrSyEpBkFvCqbsdM4HbJxQBwug+L/Fev67quj/8AEi069sHx5FzFKzyrz8ygODjhefRh+NHwrqS6 X4j8U+Kde1Cxh0+eaG0W6iV1imlUYOwEkkDpnnv2Br0bUPD+jatMs2paRp97Ko2q9zbJIwHplgTi n3GjaXdaaum3Gm2ktioAW2eFTGoHTC4wMUDPMr7xXo0vxl0XUI76FNPWzlga+kkCwSfK5+VyQCAc Ln+9x1FesxyJLGksTrJG6hlZTkMD0IPcVTi0bSoJYJIdLskeBDFCyW6AxoeSqnHA9hV6mI5y38Z2 Evjabwo1neQ3scfmLLIqLFKu0HKndk9cdOx9KwIIv7V+Nkt/p4WS202wFtezK/AmYsQnUZIGM9cY 5wcV2eo6JpOsrGNU0yzvfLzsNxAshTPoSOPwqezsLPTbZbawtLe0gUkiKCNY1BPXgDFAHmek6taa d8d/EUV7dw2/2u3iSLfIEWRwsYUcnlsZ4HvUnxB1KzXxv4HuIrm1fyL6QTP5q/u1JjzuORjgk88V o6x4/wDBXhrxDeJNZMdUR1ju5oLIbgCANzOcZGCB1J6YBrG1nw94d1zxz4Zs/Dun6O9nFvu9Qaxh j8togU2CTYMENhgAc5ye2aQzZ+LVxbXfwtvZ4J4ZopJIDHIjhlb96vQj8asWfjWy0j4a6ZrTCTUo 4beCK5FlIkrRttAJY7sDB65PU1peI5fC/hjwoRqthbJoySIotktgybi2RhMY68+lbdhcWmoaVbT2 mx7OeFWiwoClCOBj6dqBHGfEHUrPWfhpsgAkm1pYVsLdyoeR2dSOM9upI6Yqn4o8U694Il8O6XFH p62M9vFbyXt2sjrFKCqklgwyMEHnBPPPWu2sPDeg6Xc/adP0XTrS45Hm29qiNg9RkDNXL6xs9Stm tb+0gurdiC0U8YkQ46ZBBFAzzLxva+IdTv8AQtGvLjSry7a/juY4LG2lR0jTO6Ry0jBU5xz1J46V TGoR+CPjXqM2sTG203V48xXEh+Qk7SCSTwAwI9sjtzXqenaNpWjiRdL0yzsRJjf9lgWLdjpnaBmp L7TbDVLfyNQsra7hzny7iJZFz64IoBu55R4u8W6PJ8SvCOo2lzbzWdtLJDLeMR9n+cqp2vkA7Ack 5IGR3yK2/EeheE/GvioabLm21Y2cd7balZSoGnQllxn+PG0evHQiu1/sHSFksnXS7NWsci12wqBD nk7ABx0B4pmo+HdE1eQy6jo9hdykBTJPbI7YHQZIz3NMRzXw+vNbW817Q9WvTqMWkTxw29+ykNLl SzKzZO4qNue4J5J4rq9XnvLXRry50+3W5vIYmkigbP7xgM7eO56D3qSx0+z0y2FvYWsNtCCW8uFA oyepwO59asg0AeeeHfGGv+JdBl1qObw5a2kTuJ4pmkLQKv8AfIOBxzyOhrD0LQ7mD4Ea3BewzxtN FNdRInJIChkwvOASvIwDj0r0ibwp4duL172bQNLkuXJLzPaRlmJ7kkcn3rW2gqVIBUjBBHBHpQB5 jF4n0g/BhLP7dBcXraO9sLWBvMl3LFtOUBJAUYLE8Ac8V0vw2dm+Hmj7sZEbLx6B2A/QU3X/AA/o mjeEPEVxp2l2NhJJp06vJbQJGSPLPGQPauX8O+MrXw18NfD11ujmtluzbX/lqS0CuZSDwflIYKTn tnjkUhkvxrQDQtHm+86X+BGRw2UY8/kB1HWvUD1rxr4r+KvDmu+HNOTTdYsrqYXocrHLllTY4JI7 cleuK67X/iVoVmsFto+raff6lc3UEMcUT+cuHkUMSVIAwu7v1xTEdsaO1B9KBQB57aeNfEd/4w1D wwmm6baXluGkhe6kkCzxg43KAM85B+mfSq3h6x1K8+Lt/q1xDaAW1gttdy2bMYjMcEICwBZgoGew wM88V3OqeH9H1po21PS7O8eMEI08Kuyg9QCRkCrVnZWmnWqWtjawWtumdsMEYRFz1wAMUAee+BSV +KHjhUi/dmZCz7Rw25uM++Sfw9qzPAusWHgzxV4l8O63drZiS6a5t7m9KxiVckZLHA5G0jA/vfSr fg26s4vi74vjlnhS4lcLErfKz4JyBk89BnA9+O/oOp6Do+tGNtU0uyvWi/1ZuIFkK+wyOnt3pAec aJqFpqvx6vL2wcTWz6ayrMi/LJt2KWB/iXIwCMg49qisbe+Pxt8Sabb30mmm8gSbzo4FZ3QBPuF+ ATk87W5B7ipVls9O+P4R2htYP7OEUK7dig7Fwo6AdDjH0r0XVPD2ja0ytqel2l3Ig2pJLEC6jOcB uoH0NMDn/B1xo8Gva5oulaXeLNZSAXmpTkSG5kP96Qnczck88DnpnnJ8Cb4/iX44QRMYzOjGQnod z4H45P5V2y+HdESwk09NH09LKRgz262yCNmByCVAwTxXLeGvh7Zab4m1fWLywtlzeZ06KP7sUYA+ baDjcST1GRjI60Ad5RQKM0AHejNFHWgBKX2o6UHkUwAGik70tACjikopKQC8Ud6KDTABRzmgUo5p AJ3o70UCmAEGiiikAUGjGaKYBR0oPWjvQAdDRR1opAFFB7UHrQADmk70tGKYBSUp60ZoAKBR6Uq0 gHDpRQOlFIo5vwzxoVnjn5OOO2TXQCsDws2dDtBg/c4JOe9b4pkDgaTpS4zRQMSl70lKeKADrQaQ HFLnNAAaO1J3o+lAB06d6M5o7UvegBOelBpaDQA3vSmjvRmmAtIeBQfWikAYwBR3pccUY5oASgUv cUdKACjpQM0UAJ+FKc0ntS/jQAmKXtSdKO9MBcUnrRR3NIBc8UntS5pMUAIKdxSUvFACUUCjtQAU UY6UGgAoqnqerafo1mbvU7yC0twQvmTOFBJ6DnvVK88XeG9PNuLzXtNgNyiyw77lBvRujg5+6ex6 UAbVJmkVldAyMGVgCGByCKzb7xFoelz+RqOtadZzYz5dxdJG2PoxBoA0+5oFZM3inw9bJHJca9pk KSglGku41Dj1BJ5FE/inw9b2f2uXXNOW2wSJftKlTjHAOeTyOBzyPWgDWPWlJ6ZqnYapYarEZdPv YLuIY+eGQOvPuOKzH8beGUnEUmtWiBmKrKz4iJHUCQ/IT+NAG9S9qjeWOKJpZHVY1XcWJ4A9azLf xV4evZfJtNc064lzjy4rlHYfUA5HSgDXorEbxh4aS4S3Ov6YZ2YKI1ukZs9eQDkfU1tA5GQcg9KA Cl75rJvvE2h6Xcm31DVrOzm4wlxKIyc9MZ6/hSXPifRLN7JLnVLaFr5gtssj7TIc44HXrxzQBrd6 Kwh418MHVv7LGvaeb3f5fleeud/TbnpnPGOueKsP4n0KLW10WTVrNdTbGLYyjfk9Bj1Pp1oA1aKp apq+m6JafatUvoLODOA88gUE+gz1PsKg0fxHouvh20nVLW92AF1hkBZQc4yOo6HrQBqHrQB1IHXr WH/wmGgHUBYHUVF8Tt+ymNxLn3TbkflSy+MPD0FyLWbV7eO6LbBbuSspPP8AARuxx1xigDbowMlg BuIxnHNY1z4t8P2N59ku9Xtbe5JCrFK2xmJ6bQevUdK10kWWJJEOVYAg47GgB1JVHVtc0rQbYXOr ahbWUROFaaQLuPoB1J9hUekeIdH1+B5tJ1K3vEj+/wCS4Zk64yvUZwcZHNAjSorEi8YeHZ7o2ser 2xug+w25YrLn/cPzY98Yp7eLPDyXC2za1Yi4ZtogM6+Zn/c+929KBmyKSsuPxJokusvoyaraHUl6 2vmjf0zgDucc461q0CECjfvwN2MZxzil7Vl33iTRNLnaHUdVtLJx2uZREDxngtgH8Kt2GoWepWwn sbmK4hOPnjbI5AP8iPzoGWaKwJ/HHhi3uGhm1q0Qq/ltIWPlK390yY2g+ozxW7G6Soskbq8bgMrK chgehB7igBxpetNd1jRndlVVBJZjgAeprHtfF/hq+vVs7XxBpk9y52rHHdIxY+gweT7CgDaHNIc1 Fc3NvZWstzdTxwQRLueWVwqqPUk8Cs3SPFWga8/l6VrFldygbvKilBfHHO3rjkdqANXYnmeZsXfj buxzj0z6U49KyZvFXh63uTbXGuabDcBihhlukR8gkfdJz1FFz4o8PWU/kXWu6ZBLwfLmu40bkZHB OeQQfxoA1u2KKzjr+jjULbT/AO1bI3lyoeGATqXkUjIIGc4IBIPeorPxT4f1G+aws9b064uwSPJi uUZyQMnAB5x7UAa9J61mW/iLRLrVJdLt9XspL+Nij2yzqZAwGSNucnHOfTBzUl9rel6XMsN9qFvB K6llidxvZR1O3rj3oAv+9L3rKtfEmhX0c8tprFhOluoado7hWEQOcbsH5eh606x8SaFqVwLew1rT buY5xHb3SSN69ASfWgDS70VjzeLPD1vLJFNrdijRMUkLTLtjYdVZuin2Jq3Fq+mT6V/akeoWradt LfavNXysA4J3ZxgEEUAXaWs3Ttf0XV5mi0zWNPvZEXcyW1ykjAdMkKTxyKl1DVtN0iNZNS1G0skc 4VrmZYwT7FiKALppDVKw1jS9XVzpupWd6I/vm2nWTb9dpOOlXaACise18W+HL3UFsLTXtNnu2+7D FdIzMfQYPJ46dan1DX9G0mQR6lq+n2UjDIW5uUjJH0YigDQpay5fEmhW9rFcz61psUEpIjle7jVH I64YnBxkdKW08RaJfCU2es6fcCJPMlMN0jhF9Tg8CgDTorJt/FPh+8uktbXXNNuLh22iKG6R2z9A SadqfiTQ9FuIoNU1eyspZRlEuJ1QkdM8np79KANSio7a4gu7eO4tp454JBuSSJwysPUEcEVlv4t8 Nx3rWb+INKW6V/LMLXkYYNnG3GeueMUAbFJHGkQIjjVASWIUYyT1P1p/WuG8ba34X1DwzqlvJqem T3UVvMYP3qsyTBTwjZ4f2BzSGdxR3rz/AOFFpY2ngKDVHjgjmfzfNu3ZSfLWRgAX67RjoenNdKvj LwyzAf2/pqbjtQvcook6fdJPzDkcjPWgDboFFUtS1fTNGhWbU9RtbKJztVrmZYwx9Bk8mmIuijvV Sx1bTtSsmvLHULW6tlJDTQTK6KRyckHAqrB4o8PXd0LW217S5rgtgRR3kbOT0xgHNAzVo7VkxeKf D012LSLXtLkuWbasK3kZcn0C5zmpLXxBo19qk2mWuqWc99DnzLeOZWdcdcgHt39KBGl1FJS9qxpv FfhyC4e2m1/S450O1onu41YH6E5oA2KT6Gsm48UeHrW4+z3Gv6XBPx+6lvI1b8ic0yfxX4dtHCT+ INJgcgMFlvI0JB5BwTQBs0daoS61pUM9rBNqlhHNdAG3je4QNMD0KDOWz7VFF4l0KXUDp6a3prXw cxm2F2hk3jqu3Oc+1IDVpaz/AO3dIGr/ANknU7MajgH7KZl8znp8uc/hVyeeG1gkuLmaOGGNSzyS MFVQOpJPAFMCSg1l2niTQdQuFtrLW9NuZ25EUN2jsfwBzV+4uILS3kuLmeOCCMbnllcKqj1JPApA S0Y5rNsfEGiarcG307WNPvJ1G5ore5SRgPXAOcVpd6YB2pPSs+813R7C4Nve6tYW0wG7y5rlEbHr gnNMbxJoSLEza3pqrKu6Mm7jw455HPI4P5GgDUorPOvaOsdrIdWsAl22y3Y3KYmbphDn5jyOBSPr 2jpqv9lNqtiuo8f6KbhRLyMj5c56c/SkM0e9JVa/1Kw0u3+06je29nBnHmXEqxrn0yTS2d9Z6jAL ixu4LqA9JIJA6n8QcUxFmkFKKpPrGlxC68zU7NPsiq1zunUeSG+6X5+UHtnrQBcxkVVtdL0+xkeS 0sLW3dyS7QwqhYnqSQOaTT9U0/VoWm02/tb2JTtaS2mWRQfTKk80X+rabpMayalqFpZRscK1zMsY J9ixFAFvFLVezv7PUbYXFjdwXUB4EkEgdT+IOKoeJ9YbQfDd5qEMYluI0C28RBPmSsQqLgcnLEdK ANfmjoK4vQ/BWp2OrWes6h4r1i6u1jJuraSUGB3YchVxhVBxgD0HNdp1FAC0nOK4+y8ULq/i690w 6vbacljc/Z47PdH9ovGCgscNkhOoG0ZPJyOlbreJNCWUxNremiRTgobuPI/DNIZp0d6iiuIJrdbi KaOSF1DLIjAqR6g9MVRtPEehahdC2sta065uDkiKC6R3468A5piNOkoqOaaK2heeeVIoUG55JGCq o9ST0oAkoqjp+taVq+7+zNUsr3Z977NcJJt+u0mpptQsrW6htri8t4rifPkxSSqryY67QTk/hQBY oxWdZ+INE1K6a2sdY0+6uFzuigukdx9QDmpp9V061vYLK4v7WG7uDiGCSZVeT/dUnJ/CgC2elQz2 tvdGP7RbxTeW29PMQNtb1Geh96rQ63pVxeTWUGqWMt3AC0sEdwjPGB1LKDkfjTV17RnC7dX09gxw uLlDk+g5oA0aKz/7e0Ycf2vYdSv/AB8p1HBHX3FLLrWkwSSJNqljG8efMV7hAUx1yCeKAL9Hemo6 SxrJG6ujAMrKcgg9CDVe+1Kw0yNJNQvba0jdtqvcTLGGb0BJGTQBa70Vn22vaPerI9pq1hcLGnmO 0VyjhVzjJweBkEZqWPVdOmuI7eLULSSeVS8cazKWdQMkgZyRgj86ALfaijtVG51vSbS6Nrc6pYw3 AXcYpbhFcD1wTnHIoAk/svTmluJjYWnm3I2zv5K7pR6McfN+NLY6dY6ZB5On2VtaQ/8APO3iWNfy AFSLdWz2v2pbiI220v5wcbNo6nd0xVPT9f0XVpWh03WNPvZVGWS2uUkYD1IUmgC9Pbw3ULQ3EMc0 TfeSRQyn6g0sUUcMUcMSLHGihURRgKBwAAOgqtd6pp9hNBFe39rbSXDbYUnmVDIfRQTyeR09atsQ ilmIVVGSScACgBcUh4PvVCy1zSNSneGw1Wxu5UJDRwXCSMuOuQDxVme8tbaWGO4uYIZJ32RLJIFM jf3VB6ng8D0oAm7Uvas6117Rr68eys9XsLi7TO6CG5R5Fx1yoOeKs3F7aWbQpdXUEDzuI4VlkCmR z0Vc9T7CgCf0oFULHXdH1OZ4NP1awu5U+8lvcpIy/UA8U+XVtNgd45tRtI3Q4ZXnVSp685PFAFwU uOKz/wC29JwD/aljym8f6QnKgbs9emATn0q5HPFNCJopUeI8iRWBXHrmgB/WlHX2rPsdc0fVJ5IN P1WxvJohl47e4SRlHTkKSRV15I4YnlldUjQFndjgKByST2FADbi3huoHguIo5oZAVeORQysPQg8G lihighWGGKOOFRhY0UBQPQAVXsNU07VUdtOv7W8RG2u1vMsgU+h2k4q3QA0xo3VFPXqopGijc/NG h5zyoPPWmfbLX7b9j+0w/agnmeR5g37c43beuODzUdtqWn3s0sVpfW1xLF/rEhmV2TnHIB45oAtH rmikNV01GycDbeW7bjtGJVOT6detAFmjvVeO/s5rme2iu7d7i3wZollUvHnkbhnI/Gks9RsdRDtY 3ttdCNtrmCVX2n0ODwaAC306xsri4ntbO3gmuW3zyRRKrSt6sQMk/WrNQW15a3isbW5hnCHaxikD bT6HHQ1Heanp+ntGl7f2ts0mSizzKhbGM4yeeo/OgByadYx38l+llbLeyKFe4WJRIwHQFsZIqyet Ry3EMEfmTTRxx/3nYAfnUX9o2O6RftttuiGZB5q5QYB5544IP4igCzR2qE3dsuN1xCAQSMyDkDJz +QP5UwalYnaBe2xLkKoEq/MfQc89RQBZoxxR70ZoAO9B4NFHagA6UE0cYpKYC96U0nU0HOKQATSU 78KTrTABzRRQaQAOlKOlIKX0oATvQaAaO9AAemCKDR096OtABR0pO/NL0pgAo70Ue9IAPWjNB5oH WmAelFFFIAoPpQOKDQAdcUd6MHNAoADQKDSgZoAcOlFA6UUijmfC+RoVmwHGzgD610K9OmM1z/hg 40OyPzf6sdfrXQqc96ZAoo+lFB4oGFLQDk0GgAxSYx0o60CgAA70etLSdqADtR2o6CloAKCeDRR+ FACHrS0nfmlPrQAh60daXvTaYC0ZJNHSjPNIBehxSY5oHXNFAC0lKBRigBKOKO/NGetAAKOlFL1o ATtRRiimAp6UgPFBPAopAHej2o70ZpgGKKOKKQB6UdqKKAON+KFrDJ4C1O6aKNp4Yh5bt1TMiZx6 E4Fcj9k0/VvhvYeHtC062vtcuoLdp5IQGW2cYJkmlwQpABAGc9lGK9M8R6OviDw7faU8hj+0xFVf +63VT+YFcU2heLrrwLb+EvsVvZzRhI31NLvERjVskqqjeWwAMEAH1oA7fw9pbaH4b03SmkEj2ltH Czr0ZlUAke2c1wvxnc/2ToMRbEUmppvJPH3T15A7nuOlejWkLWtlb27zPM8USo0r9XIGNx9z1rmP iJ4VuvFnhlbWweFL2CdbiAzHCkgEEZAJHDH8QKAKPxg48AT4LD/SIwceme/t0qT4l4/4VZqAVioM UIXAx/GmPwqnrPh7xf4x8MSWmrjTNPlRY3hgilaQSSr94yPj5VPOAuSMjJOKg1rR/HfiXwbd6ZqF rpFs3lKqRW8pZp3VwQSWyETb25YkdQDikMzfGOr3Fl8D9Ajs2ZBe21tbSOjFSqeVllGOudu0jPIJ rvtU0HTrrwPc6L5MVvYmzKKqqFWPC5DDPAIPOfWsePwVeaz8P4/DfieWxLwxRx28ljGxMJRdqtuc nc2OpAXgkd6jji8ew+Gv7D+y6dLfiLyF1Zrr93twRvKbd28DAxgjPPSgBvwf1K51DwDAtwzP9kme 3jdu6LgqOp6A4/AVU8Abf+Fh+OgAAftaYx0+8+f1q43h7xR4V0jSNM8FyaY9vBvF2uohvnZud+Vw cZzx16deaqeGPCfi3QPE2t6kbnTLmG+cO/nvJvmYc8EDEa5ZgOGIAAx3pgMjQD9oOVg2M6QGIAxz kDB9fWvSs15Ej6+3xwedNMsPtiaYBLGt7IYdvYmQQ5B6cFfx6V62u4qNwAbuAc80AecfE1h/wkvg ZZGHlnVV3KwBUjdH1BPpmovjHb2MOjaVcyRQoZdZt/tLlVHmIFf75PUAZ6njNHxRMw8S+CfIG6Qa kGVNwGSGQ/lXS+PvC0/i3w4LK0njgvILhLq3eTOwuuRhsA8YY9jSA5rxFolp46GkaN4esvs2k2F0 J5r5LcwwBPmBSHKgSEnnK/KMDk5pfiVY2Vrd+D1W3RbdtdjMqbCwcswLFh/ETg9c5zWlf6J4o8T6 noUmo+TpNvpsxmuDZ3rs87gDBQbcBTz97nBP45HxP/4SGe50FLfTLOSSPV0lsRBdM0shVWI3KYwE GBkncQPfrQB12pabo/8AwkX9s63e2ri3iVLWC6dVjtjklnAY43scDdjgKAK4LX9H0nRfiP4W13w/ LZRw3l6lpNDaFCoZuMhVP8Sk5I4BAPet3xZ4I1LXdU0jxJa2mkrq9quy5srpmlgnTnC79gyRkj7o 69eBmxZeDbi78U2Or3ml6PpFpYkyw2tggaSWUjG6R9ijAycADrzmmBBpbE/HjXFLA/8AEojwMnIG 5Pw7/r9arXbhf2hLHfl86SUQFSdh/eHIPQDr1z16dxpa94c8QW3jeDxR4ZNjJJLbi1vba8kZFdQQ QwKjrgd84x0NZeq+C/GEmr2Hiyz1HTn8RwqUntzuW1MfQRxnG4jBOdx5LZBHSkBP46bHxH8Cgldp uJeGAIzlMe+a9FrzHV/C3jrWNc0LWZLvSY72zkeQxjf9nt1+XCgY3uzYO45A6AYxk+mRiQRIJWVp Ao3Mi7QT3IBJwPbJpiMSbS9O/wCEkk1jUrqCaWKJY7WKfbi1XqzLn+Jj/FxwAK4PVLPS/D/xT8O6 j4emt4o9RlNpeW1mV2cgYJVTgZ3Bsf7IOM1teM/Ak2qeJbDxLpdppt1eQDZc2moLmO5TBA5wcMAS OeOnpVjTPCEkvim11q90XRtLgso2NtbWADSNK4wzyOEUcDoADzzngUAZdnGf+GgL9lGT/ZQc55x/ qx68dqjuQP8Ahoi0OTk6WSOp7P8AlWlr/hrXrbx3b+LfDwsrh2t/st1a3UhjBXsQwB9AfwHXtztn HqKfHew/tW4huL02DecbddsceUchUH3sDI5bk5/AAGj420+z03xZ4CitYEt7eO/ICRrxkunJHc5J 568k9zXp3evKvHY8QXHjDwoq6dYtPHeSS2qQ3jMZFUoxLlogE4Hbd16HFeowGZoUNwkaTEfOkbl1 B9iQCR+AoA89+NihvAcZOPlvoiMnHUMP5E1qfEzU7jRvh5ePZmWOaUJbq8AIMQYgE9tvGQD6kVz/ AMYZtX/4Q+Zbmz06OyF4hjlS7d5HwTtBQxADI6/Mce9drcaTP4l8NXWl+ILW3gS4XYPslwZsDAIc M8a4YHnoe3JpDE03R7C88BWWkeWjWE+nJFhAACrIPmHvznPrXLfBi+uJvDF5plwzyDTrowxu2SAh UHaD7Hdx2BFaGmQeOtG0IaIlrpd5NAnlWepPcFEEYwE82MLuLAf3eDj8Tt+EPDcfhXw9DpomM8xZ pricjHmStyx+nYZ5wBTEXNb06PVdNaxnl8u1ldRcDcR5kYOWTORwwG0+xNcR4/8ABnhqbwle3um2 mnWF3ZoZUktESLdsGTGdo5yOg65xXVeM/DaeK/C93pJaJJZMPDJKm8I6kEHH5j6E1wsXgXVLrQE0 KXwr4csbtVEM2uLFE++POC0aBN3mEdzjnnIPQGjpNAsk8aeGdBvtZC3NqltlrVxmOaYHbvdc4YAL kA8ZYnsK5X4q6FZ+GY9J8VaHa21jd2d2iMsMYRZBglflGASMEdshjzwK6jxR4S1l9E0iDwlqz6fP pONkJlaOO4UAcPt6nI7jByc9adqGi6z4xvNLTWbG30/SLOUXM1q0gmluJlHyj5flEfJ7knHIGaQG D4jl8747eEcnahsi4DepEpx9eBV/x8kU3jzwLDMgeM3crFWGQSNmPyODVrxt4Y1m88QaP4m8OJZv qWmh0eK6cqJUPQAgdtz9SOtZGveG/H2u61oequdEimsZTLHbiR/KhwVbDNt3OzYAOMAbeOuaAIPH Oj6DaePfCq30NlBplw95NePcsFWRiASXduvJHBJ9MAVdj0S28SeO9F1jRNMSx0fSVbfdm38kXZP3 VjTAJVST83AO44zitTxb4b1nU7/w7rVktncX2kyF57V2MaT7gu4IxBwcrxu9fblItK8Raz4/sdev Fl0rTLC2ZFsmuhIZ5GDAllQlFxuHPJ+UfgAYmt6NYaN8XPBbafZw2kckc8Z2IoD4Vj9S3znJPJz9 aXxDe6j4F+IV94qn0mbUdHv7aOF5rYnfaKm0HcCMYzyMkA56jnLfFlz4gk+IvhEjRYJLm2M8kcVt eM6sjbVZmZolCADGevXH16m+fxTZ+K/t1tpyX2kyafHFNapeAMswaQlow+FPBAJO3I2+mKAF8LTa Jq+pX/ijR7xZ/wC0o4Ipo1A3QtHv+8ByCQw6+gOcEVj/AAlRxoWuncnmNrNx8wYN/CmM4/ka1PBH hy40e61nUJrKDTF1KdJI9Nt5A6W6quMkgBdzEknHHA5rP+HPh7xJ4fk1NdTFnHYXV09xHGsheUMS RyANoBAU5yTxyOeADm/DHiY/D62/4RXxlpcsEMkkrLqP+shudxy2QQCw55xuPIyBXaWfgzSn0fRt PeeK90S0R5Y7c4MdwzsGRm52uoDHA5GSDWSLHxTP4cv9E1fw/Bq3nzXAtbma8UrGjs+wybvmBXIw UycYxgiqviT4Z3mo+CNBsbS5gl1bRYAifaAGin4XcnI4GVG3IxgYI5yARV+JnhOy0CxtPFXh6ytr C8024RpBboIkdScAkDAyCQO2Qxz2rsPHcwl+HGsygYElizAfe6rnt/OuYk8Fv4g+xWs3grRtAto5 lkvp41gaWZVOdkWxThWIGSSDjjnJq34gsPH2pW2u6QsGjyaVNG/2SSNmSVkIbbFgnbn7oJOBgnGc 8A/Q3Ph0Ih8PdEEIIT7MCQf72Tu/XNaWv6Qde04ac8xjtJZF+1qpIaWIZzGCORuOAfbI71neBNK1 rRPDVrpusfYd1um1PspYnGSfmJAGeQOB261b8WaTf614duLPS9Rm0++bDQzxStHyDnDMvIU98f8A 1qYjkfiL4D0MeELq+0vTrTT7ywQTJJbIsOVXqCRjtnB9cVQ+IV2+pfBfT57gt58qWskjP6leTuIx nr/k1sXNp4t8QeGYPDd/pq2ZliSDUdSkukkEiDhjGqncWYD+IKBuNW/iB4Wu9c8DxaFo0Ue5ZYER XfYqRrxk+wHPAzxwDSA3byUxeEJWUhG+wHaVTeFPlnHHTH1rl/g7th+G1s5AGZpmPl/MThsdB3wO lat63iG38KtDcWVhcTfY3S5eC+eIIAmNy7oyT3PbHHWuf+DU94fBltA1ggsd8pW5E4JLb+VKY+vO aAK/wvZW8a+OWkVPNN9lT0faZJeo6joOD+VdVZ+BdIkgml1yyttU1K6Znubq4jDtkk4VGIyqqDtA GOAKw/CPhjxJonjHX9Tlj06PTtTvGkKtIzSlAzMrAAYGd56n8Ktafp/ivw14k1SUNea/pN4d9tG9 4A9s5Odp8xgAo6ZXPbjrQBzngWy1DSdc8XeDbPUzDDFtktpj96Hc2CwB7lSvbGQD3rrNT+GPhW/0 KXTINLtbefy2Ed0qAzKx/iZurc9c1FY+BGvbLxFPr00Z1PX1Ec7W/KQIowipkDOOuSOcD0rntB8E 6joulPpF34L8O6tdo7/Z9UmEewqTnM25TISMn7oPAA7ZIMxLzxJqsfwLW3nuHFw18dLecNz5QySC T7Dbzg4r0zxPp2mw/DTU7OK3hNjBpshgVUDKu1CVZe2QcEH1rPm+HFpJ8Nh4WRoROB5wnKfKLjOS 2Bjjkj2FY1vpXxKvPDN1oGpf2ZHAlu8Aulk3TXS7SAgJyBu4G8gEDtnmgCv4c0a81/4Af2VpssQu 7jzAMOVB/wBILMpb3XI9OcGn6Zrul+LdPsvCWv2L6JrNk1u1utzFgMyEf6vdggkAjGOjcFq1PDvh zxTpHw11DRp3tkvDbymwFjMyyJI4ZgC5ChSGPb86dqGj674ouNAGqaJbWd3pl1Fc3GoC4VlcIcsk IXL/ADEA4YAAD1oA9ArBuPCelahrNzqurWsGoSsFjgW6jDpbxhRlVU5HLbiTjPOO1b/rXm3irwLP N45h8UWmkWOsQNEEvNPuioMjBdoZd4Kk7dvBI5Uc80AUYNJTwR8YbFdLjMela3FJHJbomFR1Uv8A KOAQML0zjLDuKt+ES7/GHxm74OEiA4CkDC/w9egHP+Nafhrwi0Pig+IZ9D0vRUS2MFrYWaIXUsfm eRkAXcQAABu4PXrUFx4f8Q6F8QrzX9CsrS/tNVRY7mKe6MTROAPn3bT8vHQZPJAHAoAradGrfHnW GyvzaYvRtrZIiHTr0HX6VT1PT7Ww+N3hRLOCO2t1snQIg2dEl7d+MD+dJ4cTUU+N2orqV1FNeHTA 03krtjUny8IuRnaMjnqep9Kh19tbl+MHhyddIja8htmYx294zoIzvXc7mIbFyTng56DnGQD1onAz /KvNNQIf49aO7dBpz7d3DZ2y9AeTx6V6TGXMSmRVVyBuVW3AHvg4GfyrhfFvhvWz4v0rxX4ejt7m 6tYzBPa3EvliRDno3QcMw/Lr0oEZnjVhP8UvBYZWaMStkOCo3BuCM4z07e1WfHW2fx14GjdVbbeS lvMIQf8ALMjaTjJyOg/rVPWPDfjnV/Fuh61JDpEb2bM4iErGKBc52s2NzsR3AA/nWt418Pa5rGo+ GbrTYbV59PneaV5ZTHEpzGQOhbB2noD2oGYHxR0/SodX8PXNxBEqXOo7r2eQn5kGwYLnkADOFBwK lv8AQ9N8SeJ9AHhSwt4rHSZlnutRig2RMqspWNH6yN8rdMgZ5PNbfjvwpqniXRtOltDZHVbCYT+T LnyZScbk5B4yB1HI44zS3Nj4m8QeKtGvTHcaHpmnktcQ/bFZrhuPlCxkgrx1Y9OwoAwvHekaZpni LwbPY2cEMrarmRtoDS5dCSzHljkk8nua1dfuZdT+Lmh6BdTf8SuO3N4bbcAJpl3Fdw6sF2ggdMjP asj4jzazca54agXRd0sV+ZLVbe6V3uAu0ngoNnAGSeB3rX8W+Fte1G/0nxbokNvbeIbIbZLSSfKS Jk4UsAMnBIIyBgnngZAIfiva2zXXhW5aGDzv7Wii81gFYJnON3UCm+Irsax8YvD+gXY36bBC915D thZZtrlSykfNt2cD6msXxnN4tu18NXWuWlhZzDU4Bb2ML78ydS7v0AyMBR0BOSeDXYeMvB99qOsW HiXQJoYdc08gKs7FY548nKkgEg4LD6MQcdQAZHxit/J0iw1y1/c6lp90nl3AXawVt3G70yBwD/Ov QdNvDqGlWd6V2m4gSUqM8blB7/WuP8QaZrXjm3stKu9HbStNW4Se9e5uI3eQLn93GI2bIJ7tt+ld 0AFAVVCqBgADgCgDzj4sRwynwwJkjMY1WNXMnA2nqNxHA45+lO+NCq/gqEssTBb+EkS8AjDZ5I4r V+IvhvU/EGkWcmjPCNR0+6W6hSY4VyAePTPTGePcVzXi/SvHfjXw5DDNpFlp+2aJ1tVuBJKX5BkZ vuogBztG5v5UATfFbR9MVdDuvskKTSarbwySt8uIgCNu7qqjHQYGcnrVXxF4b0TxTf6Zp3hDT7Rf s9ys97qtlGipGg4x5uP3kmecAnBXmt/xl4a1/wAUeE7KNk01dXtLlbnyTIzwSbQRgkoM5z0IA7e9 O1C28U+IdZ0T7Na3fh+wsJfNvC12n+kDI/dqsTEMvB+/t4PSgDUuvBum6zq13f6/a2+oM2IrSOUb lt4gvQZ/iLbmJ69MHiuN0LS4/B3xjbS9PEiaZqlo8yQsdqowJJAH8WCpA74b256HU7HxVpvj1Nc0 6S41PRZ4hFcaYLlVMRAxujRyqdQDndnlvarWj6Lf3fiy58U6vbmzmNuLOzsxKshjizks5HG4nspI A7nrQB1Mscc0LxSxrJG6lXRl3BgeoI715N4D8P6XdeOPGkM9jAbO1u4/Ks/KAhHzS7SY8YOAOMjj Oetet5715/4Y0DXdB8ea/qM1lG2matLvUxTKXQhiVLKccYZs4yfagDO8M29rpfxt8SWlrDbWlqbO IpBEojGdsR4UYHXcfxNWfAV4niPxn4m1q+8ua6tJVt7IMp3W0GXHygjjdjnuec1bttB1rTvizqXi JLATaZfQJATHOokUhEG4qxHGU9c80kfhvVPCPjK81vQ7Rr/StT+a9sImRJY3ySHj3FVYZLcEg/Me tAGShTwx8dFgs2CWmuw+ZcRsMASYfBGB13J/4+atfEW31DxTPc6NpMpVtHtRqEuwks07E+UgxyCF WRh3yVrVsNC1G98a3Pi/VbDyTBb/AGbT7FWjaULzl3bO0OckDDYwxGfW54NsNVsRq0+s2Aiv768e 5aWOVZFZCAEjDZ3fKoxgjA7egALfgvX4fEvhLT9RjlEkpiVJwTysqjDA/jz9CDW/2rzrwpoviTw3 4q1WRNKhXQNRuWlWGOdPMtyejbcgYx1APpjpz6L2pgYh8IaEfEq+Ijp6f2qP+W4ZuTjbkrnGccZx 3ri/iDaRSfEnwPLLDHIskzoQyg52uhGc8cbs16fyB6+1eReNb3Vrrxz4LM2hyQ3ENzI0UAuY5DKA 0e7BH3RgZycfoaQGp8RtRM/iXwx4bkbZpl7crJeq3AmXeAqZPbOcj3WtH4l+G7PUvBc08UawXWkp 9os5IVCtHsGSq4GQMDoMcgHtU3ivwvdeLtDsrtFOm69Yt9otdzLII5OCUYjgglV5HoPpVbV28VeK fD39hnQpNJuLsCO+vJZ4nhjj/j8rY5ZiRwAQOvJoEdD4S1OXWfCWlajO6tPPbK0jL0LYwf1Bpmte HU8Q6hZpqQjn0i3BkazYZE038Jf1VRnjuTz0rT06xg0vTrWwtgRDbRLEgPXCjFch8Q/CV7ryafqO lRxzX1hKGa1ml2R3MWQSjcYPIHXjBagDm/H3huz8HXWn+LfD0EenS29ykU8MMYSJlbPOBjr90jOM H2qfxnoGkH4o+E2OnWIiv3nF0PKVROQAQWwPmJz365q9c+El8QXNnbjwdaaFaRTpPeTuIGklKHPl xiPPBPVmxx2qD4jPep498FvpyLLerLO0cbuEVvuZUntkZFAFX4s6Dp+m6Pa6/pVrFY6jZXKKJYIh GCMcZwOcED8OKoeN7bTb3xL4G1OS3hiXVZFmvGZ9jEHyiMv94AAkAZwO2K6vX9M1bx21hpt3o9xp WkwzrPeNdTRNJMV4CIEZxjk5Jx24o+Ifg+71waLe6Xa29xJpcuTYylQksR25UBgVz8oHPGPwoGZM WjaVq/j/AEO+8G2lrb6dpXmG/vbKJY4ZiwAWNWXiQ8HOMgBhzR4eghPx38Ts6QNJ9kVkYBcrxED0 7/r610Udv4g1jxjp2omG/wBF0mxgdZbWWeMm6kbgDZGzrtGOpwfT1rI1HRtf8P8AxHuvEui6ONWt dRt1ingS4SFo3AUZ+bt8oOfc/iCIpILeX4+o0qwyMul5Tcoyjcj0znbn8D17UeLLW2ufjH4PM0Ub AxStlzj5k3MvbqCOPXpmo9R0bxrB4n0/xhHYWt3dqrRXGmW9xs8uHkKm9sCRvmJJOACBgYqHWtJ8 bat4z0HXRodjDJaZYQi5BEaZGUklwcsctjauAD3NAHqoAUYAwB0ry/xTfan4R+I48VXuny6hor2f 2VHhQFrToWyccZIJyTg7iM8Yr06IyGFWlVUlKguqtuAPcA4GR74Fc7rV1rVnr8MlrpU2p6S1o6XU EToG3buCodgrcZBGeQR1xTAqeFk0HWdfu/FehzwkXdskFxEsWyQSBixZx1yRge+OprI+GFtFb694 0Ecccf8AxMyNsYAAAaTHQVe8B+H5tN1vXdWTSzo+n6kYDbWDhA6BFOSyoSE5b7ue5zTPBeja9pHi jxHNdWEUem6hePNHI1wN+Az4IQA53bh1IwB0oA7yvL/i3bwzat4RMkMTZ1AIzOP4SyZHTpx+gr0X VGv00q6fS0ge/ETG3SfPls+OA2CDjPvXlfiPTfH3in+wbu50G2trqyn3iBZ1Kb1O4yO2TtB2qAoz 3yTkUAbfiq4TVPid4f8ADV6E/shUN3JC5AWeXD+WpH8QBT7vQ59qT4uaYkPhu38QWSLBqmkzxvBc Rx/Mq527c44XJB54496u+KfCur6xJpXiHTxa2fiPT3z5YnLRSR5yYy+wEnGQDgD5m9c1H4htdb8d aTDoraHc6RZzSo19PeSxEhUOSkaozFiSPvEKMc96QzG+I1np2s/C258Srp8J1G6gtHEsi73iUugK Ix5VeT0wDknvXUxaEniHwr4dsr3y5dLFrFLdQlyfPIjXYue67juPIyVXqCaxfi3JJB4EvLCPTFTT QsAW4SVEVCJVAQR9ew6cflTpbDxVrfw40lNJa40TVLKOF0jklCC4CIBhtuSoJ6KfxHoAZnxG8I6X 4dsrLxVoFhFYXWm3cUkotYwivHuA5AHY46di2c9ovHGiaZJ8UvCfl2sMaX7O08lsRG8pBByXGCc5 xnOcHA7V0+sWut+Mrew0y50WbS7EXEU+oSXM8TeYI2DeVGsbtkFh95sYAHB7QeM/Dus6h4y8N63p tol1FphZpkaZY2OSOFzwSQDTAwfiN4e0nQr/AMJXej6ZZ6dIupxxmW2iWI8lcbsLz0PJ9/Wk+Iei aY3xL8Hb7K3C31w63OIxmbDp97jkfNjmuk+IOhar4isNFk0yxD3FpfJdPHNMibVUcjOSCScDuK5r 4mz38/i7wY1jbmLUhJI8EFwy/K++PAYqSMHHXJ4pASfFjwrpuk+H4fEmi2cGnX2nTJ89pGIsqzBR naOSDtx04zT/ABrFb6t4s+HT3iW5+0ymWTagIY4jYDLDO3PY/wA62fEFhrfjmOw0q40WXSdNWdJ7 97uWJzIF58uMRs2QT/E2O3FTfELwzqWrx6Rquhxo+qaPciaGIyeX5iEqWUHpn5V68Yz60CMj4wWy XK+GYHhjkhl1NVkBAyRjBGeo4z+VP8dXbXnjjwx4VZxHo10/nXUSYC3GGO2M8fdyvI77vaqHjKz8 b+LYdIki8OxWSQ3SypA9yryo4B+d2HyqvTjBP8q6Lxf4S1HX49N1uzNvZ+JNMfzIlSUvFKAc+WXK qecDnA6kdDmgZU+KukW6+FotXs44bbUNLmie3nQBHRN23apHOPmzj2q/aab/AMJ3pehahrQjl042 azyWWSFmuGx8zjGCqgHA7ljxwM1/Ef8AbvjPRn0GHw/daYtwyC8ub6WLZGgIYiPy3YuSRgcAeuKt eJdJ8RWkehyeEpxHb6YwWbTwyqLiIbQFG75SQoYckdc5BFMDkvFug2ngTxf4f8R6BHHZRT3QtLq3 TIVwx5wMEYK7sjsQpAzk168RiuF1LTNS8ba3orXuk3OmaLp832yRbpovOmlXGxQEZsL1znBPI44N d0eaBHkninRNJg+LGgpLHFb211bzPdzmdoml+WQt5kg5IIwME8j5elWtD8P6fc/FCDXPC9jHaaHa WzRy3EC7ILuQhlxGAAGA4JYZXKDvWl448N3194r0HXYNLXVbKxDrd2YMe9lzkFVk+Vup44PHBBOR d0yHX9T8bR6w0d1pfh+Cy8iKwnkAadySd5iXhMDHU7uBxycAHY15R4fsoH+PPid3ggKLaBkYKOG/ c8jjrnv1z9a9Yry3w+B/wv3xI6nObIKwA6H91/gPxNAGPFoHh60+Mep2t5FbJosemrK6yz4iJAj/ ANaScPyCx3k5PJzWp4V8KxXnjnWda0m3+xeFrq2Nqix5gFwSFDGNQBhMhvm46/L6i/4g8N3tr8SY vFI0Rdc0+S3EUtuqxtLA69HVZCAeg5Bzya1NAt/EyeINe13UhfCxuAostHeaN3XaByPn2ITzxu5z yeBSGc34Ys7XSvjv4gs9Ptre0sxpy7IIV2KTiE8ADHXdn8feulf4caPrEc934ks0vdVu8madZXIi z91IjxhVGAOOcZPWuP0jUbn/AIX3qtyNGv8AzZLRYpLdTCzQjZCQztv2gfL2YnkDnOKuweE7vQte 1JdT0G88Q6TcOGsHt7gPJb5Y/Iyu6bRyORwMD8ARL8PoJdH1nxP4LvpGvbKy2y24n5Xy2HK4PABB XgcZ3etO+CNhZr4HlnFrCJ5buRZX2AkgBQBnA4x25HJPetrwN4Sl0W61fVb2zt7S41KVdlpC2/7P Cowqlu7HJLYJBIFYPhaz8W+CZb/w9a+HzqFnJcPLY3n2hEhjU4GX/iHY7euQcZ60ASfDHTbKPxF4 wkXT7WN4tTeKJkgC7E3ONoOMAdsCjwTYWDfFTxrO1vbm5hljELYGVUk7sfiFyfb3pNB03xZ4M8Sa yo0Y65BqsouFu4J0hUSZYtvVjlR8x9egxnNTeENI8V6d461u/v8AT7X7NfuvnTCcouRzmNcMWA3E DO3p26UwPSc0vbFJmigAo7UUdqADtRQaKAADmg0UvagBBSng0DikoAKKBRmgAFFFFMA9qCKKOpoA M80h4pRRigAzRmig8UAFGaO1FACHrS5ozSigBO9FB4NBpAGaO9AFBoAO9HfmlpO9ACmkFBFAoAeO lFA6UUijmvDBzodltXjy+/XrXQqKwPDK48P2OCw/dA9etb6jHHpTIQv1oNL3pMUDClPFAFJ1oAXt SZpfSmhgSwH8JweKAFoxxS0h9qAFFJ9KB0ooAO9FBoNMAFB6UDigigA70elFHSkAHIoooxzTAB70 DjNHagdaQCg4xR3pMHIpelACHmgUUtACUoNNpcUwFpDR2o70gF7UnalOaBQAg60cijvR3oABR2op O1ACjpR0o60HoKAA9KOgoo7e9AAc0UEc0dqACjFBFFABQOtFL6UAJ1Nc3r+ia3Prmn6zomriF7ZT HLYXBb7PcITk525Kt6HB6D3z0tHUUAc7pXhpbXxHqHiK9ZZNSvFWJRGxKQxKBhVz1JxknA9gO/QU tAoA47xt4OvfFV7os9nqMVidPnMxlaMuwPylSoBHOVHcV1dpHcRWscd1cC4nC4eURhAx9dozipqO 9ABxVeaytrm5trmaFXmtmZoXPVCRgkfhVgUUAKOaQGgCjvQAUUelFAB60UUUAFJ3paSgQVxGpeCt TuviGniey1W2tBHbCFQ1uZXJ2sp43KOhyDzz1GK7fFFAyH7LEbiK5dFa5jjMSy452sVLD6Eqp/AV S8QaXc6zolxYWmp3OmTygbLq2OHQg59Rx64IPvWnRQBxjeFtZ1mLRrXxLeWN3b6bcLcyNCjbrt0U hN6kYXqSQCQfbpXadqSlHNABRRQKAFPSg0mMUUAFFL3ooAQ80Gl6GkNAAelHvRXJ+KviHo3hK5W1 u4b67uSgd4rKEOYlOcFiSAM4PfPFAHT/AGWH7aLvZ+/EZiDZ/hJzj8wKlHUmobS4S9s4LqLPlzRr Iu7rhhkZ/OphQAueawvDNv4lt4rseJb6xupGmzbm0QqFjx0bIHP5/Wt3vR3oASjFB60UALRSUvag ANJRRQAdqx/Elvr1zpRXw7e2tpfiRSHuo9yFc8joccex/DrWxSdKAOGtND8b2emX2ky6vYajDdoR Hf3LyLPblxh/k2kOBklRlffjgdLoGiWvhzQ7XSbJCILdAobnLt1Zj7kkn8a1KD1pAYGi23iiHW9T fWL6wuNLkcmxSBCskYzwG49Pc/4dBSDHrRnnFMBR0xR0oooAUUVyt545isPE1v4fk0LV2vbkM0Gz 7PskUbvmDGXgfKTg4PtXURsXjR2jaNmAJRsZX2OCRn6GgBwzQKPpQOtAwyaTPFKaQigQooNA6UGg ZxsfhTV4viXeeJob+zis54EhMLxvI7ABN3QqFPycH5vpXULp9supvqIj/wBKkhWAuWJ+QEkADoOW PTr+Aqz3NFAg7UGjtRQAlYOtW3iSTV9Ll0fULODT0k/06GdPmkXI+6dp5xkdvr6bxpOMGgA/DNAA zwO1A4P9aBjtQBC9nBLfQXboTPArrG24/KGxu46HO0das/zpBS+1AHJ+NvDOoeI20U6dcWkLWN8t 073IZgAvTCrjdz2yv1rprZbhbdRdyxSzjO54ozGp54wpZiOPc1LiloGHejAzRSGgQelBo44o70AL SUp60nagBaTrRmj1oAUUlLSd6ACiigUAL2oo6Uds0AFHakzxQMgc0AYPivTvEF9aWknhzVIbK8tp xKY7hcxTr0KOQCQME9P8CKK+G73VvGFn4g1uK1g/s6Ex2ttbztKDI33pGYqvToBjtmut9KD0pAFJ 3ope9MBO9HaiigBK4zxf4V1fW/FHh/VtMu7OAaWzs32gO2SSvRVxngHPK9ua7SigBkQkEaCVkaTH zMilQT7DJx+dPApKWgAoooPFABSUopKADPFFFFAC1heHk8UJdakPEMunSW5mzYm0DBgmTkOCPTb6 8568VuiigAoNHalNACfWlHFHWkFAFTUtLtNXtVtryMyQrLHNt3EAsjBlzjqMgcVcpO9L1FACUppD RQAVw/jPwlrGu+K/D2q6ZPZwpprM7tcFjzvQ4Cr1yAe4+oruO1HagBkAlECCd0kmCje8aFFJ7kKS SB7ZNP7UUdqAAUo6UlFAAaKWk6mgAooo7UAHekpaKAErz6x8JeILH4n6t4kgfThZXgEQEjMZCmI8 naBjPyHv6V6D2ooAKWikoApWek2VhfX97bw7bm/kWS4kJyXKqFUewAHT3PrV6kpc0AJS0ZpKYC9q OtGaOopAA5oo7Ue1ABQfrRmigAo7CgniigAPWg0UH9KAFHSkIzRRQAYNJS5opgAoFGaKQBRQKKAD ijtRSUAHel6mge9JTAKKKXvQAfSijvS4pAIetHajvS9uKADvSHrSjrSHrQAtGMmk9KO9AAetKOlI aUdKAHDpRQOlFIo53wwR/YFkcqP3Y6Ct1WVmOD04NYXhkH+w7Lg4EYxk1u5H3uPrTIHg80dKYnzM WAIBx1GM/hTupoGL2pB+lLmkzk0AJJGsq7WzjIPBI6HPamwxJDEI0Hygnqcnk55Pc+9SDkUZoAKT PFLSdqAAUfyo+lFAC9qQjvRzQc4oAAaO+aO9B60wA0elL2pM8UgACjvRmjvTAUUdKQUD2pAKKOtJ S0AJS0nWlHAoAQUDrQOlGOaYAKX+KjtSd6QCnpSZNGaCPegAFHek6UtABQaKSmAtFGaM0AFH0o+l L2pAJ+NBoo6mgA71HP5/lH7OYxJ28wEr+lSY5o70Acb4W8Yan4j13VdNl0uzs/7KlMVw63bSl23M vyrsXj5Sck+nHPFm68S3uo+IbrQfDSWclzZIr3l5dlmhhJOBGFTln4OQSuPfpXP/AA9QW/xD8dwh wwN2khxnGWZyepPrj8KreBHTRvil4v0a6mAuLqY3MO5+ZF3FwBnliFkH/fJ9KAN7SfGl7B4qXwr4 otbS01OSES21zaykwXQJOAob5lbg8EnO0+2e05rzbx1aJcfEzwQYXP2vz3Z1RsHykIfJ68feH4nm vSc8dKAPPZfHPiN/HB8NQeH7KOf7OZFE94cEnlXLBfugZyApOccin6T461az8WxeGPF+n2tre3PN pd2TN5Euc4HznPJGPrgYFU7gRW/7Q1oQRvudHOcH+IF+D+Ce1M+Jtut94z8E2sIkN214WPlMQ6Rh 4yWyM4xtJzjsaANoeMNS/wCFgjwmbCxDmEXH2r7S3MfoE2/e68bqfqfi7UtP8daf4Z+w2TLfgyRX ZuGBVBuyDHjJb5fXB9qwrryLf9oezaTaj3GlEISSNzfMBjjk4U9+34UeI5rM/G/wt5M8b3SQyRXC Rvlk+Vyob0zuJx/9agDd13xXqukeK9J0KK10+c6nkRzNK6tFjqWQA5HocjPOcYzR4y8Ta94TsjqK aTaahpyFfOkSZ43hBxyy7WyvuD3HHesrxpGqfFPwPMEyzPMhKZDYGMZI7Dcf1rv7xrWOxuHvXiS0 Ebec0pAQJjnJPGMUAcd4k8c3GjjRbjT007UrHVplt4ZBOybHOBnIDblyeeARjFdtGJPKTzdvmYG7 Z0z7Zr561fSH0iysL6N7lfDj6/G2nWF0rCby/mZ2UHlUOOOMkYJwTz9EGgDnPEWsa3Dcx6b4bsLW 81Fk82V7qXbFbpkAFgOSW5wOM7WPasTw7471VvEx8MeLNLi07VJFL20sGTDOMDgZJ64Y5z2wcHrp 634sGi+LbDQ4dIaa61NN0Vx5gjRipIKscE5AA9eo6Vz3iyLUtS8Z+CTcadHbTR37uBHcea/lqFZi QFGF4wT6/qAbdt4o1ebx3N4We108NBbi7e6WV+YyyjAjI4bn+8RUF/4r1qy+INh4XW306Rb2IzLc ZcMigMeU9fkbvzx0rN+0raftA+Xs/wCP3SPKznqwO/P5Jiodae2/4X94eMMyNOLGRJ0VslDtkI3e hw3txikBsXXi7XtN8T6Ra6lpVlb6Xqdw9rE4mZp1cHCswwFAbggDJweueK7evPfih5Cz+EJZiAE1 2DPX7v8AF0/CvQj1xTAhurmCytZbm5lSKCJC8ju2FVQMkk1y/gzxtD4k8M3Gp3r29rNaSOLpN21Y 0GSrHccgbe57hvSpvF8kd3No/h5ohL/al2DKp6eTF+8fPsdqr/wI9K4HUdFGk/FGXQwqxaH4l8uR 1yyKdjF3jUgY5IYEekg6UAd14D8Zp4x0y7neNYbq2uGjkhUEbUJJQnPtwfdTwKl8QeKJbHWLDQNK it7jWL9XaMTSYjt1UZ3yBfmwcHA4zjGRXNzLH4S+MVtKirFp3iG3ELjO1VnXhfYk/KPX5/zrakF0 v4/aZc3SsINQtfKgkZiFD7WXAyME5AGAf4x60AbVx4y1PwvrVrY+LotP+x3zsttqNiWREII4lR2J XrnIJHP1NW9a8VarpHizTNEFjYzJqjsLe489laMLjO+Pac9eCGGfasL42JDL4NtIim68kv40tk/i LFWBA9eP6U3xXEtl48+HksjfMGaA5JBzhQPbq3oDSA3vE/izVPDeq6TZrp1ldrqc628bm5aIxsSo 5XaxIy3UflUfizxdrfhCGO6uNDtrzT2YLJdw3Lr5GccunlnAyTggnOOxIFZXxLkt38UeCYDMnn/2 pGTCHxJsLoNwxyBkYz69677VVsH0u7TVTANPaNhcG4YCPYRzuJ6CmBzOu+Mb3StS0KK1tbC8s9al SK2uftTJtLAYJG07gdwxg+1dhHv8tfM2+ZgbtvTPfFeB2FhcaXeeG5RKzaA3iHZpUd1lJgpyGYk9 E3AEDqcZ4zz77QBxfijxpqPhzxDpdh/Y4mtLyRgssbmSWUKoyqRgDDEkAZOP5inf+NfEegeIdITX dJ0230nU5BAnkXLSTwuSOXJUA9RkAfj2J4/WNPGXgWZiNw1FkAzg/NtH88VR+MUsdoPC99LH5i2+ pq7KJNhZRhioPbO3r2pDOv8AEviYaJcadp9tAl1qmpSmK1gaTYowMl3IBIUd8Amuf1Lxl4g8GzQS +LrLTptMuZfKS60kvuhbGfnSTqMZ5B7HjtWT45Z9H+L3hXXbmTZpzoLYyswCxncwbJJwBiRTn0U+ ldH8Vkgb4cam06xkRmJ1344YSL09+o/GgDqbq/trPTJtRmlQWsURmaQMMbAM5B6dK4z4XajBrWma trG9TqN5fO90pOXjX/lkh5PyhMAdB973qO/hkl8K+DPC88bF7/7NHeQhusEMYeUE9cEqqnGPvY71 SuRH8P8A4nw3UaxQaH4iHlzDdtSG4X+LHQAkjn/ab0oEenZrH8SareaHot5qtvbQXUdpC00kMkxi YqoycNgjOB0xzWwawfGsSzeBdfRyoX+zpzlhkDEZOf0pgV/DOv6r4l8NDWE0+ztvPUm1ga5ds7WK ne2wbc47A/j0rL8M+OdT8S+Ir7SBpNlanTpGS7kN60h+Vip2L5YzyOpI/GrPwtmaf4b6OxBDKskZ yc/dkYf0rmPhqFh+JXjWAHP7+Qg5P/PeQ9/979KBnq/euen1fXYvGttpiaCZdFmhLPqIlx5bAdx9 cDHU5yOhroaKBHDT+OdYj8aL4dj8MgzPAZovMvVG4Z4ZiAQq/K2cbjnGB6tsPHmoWnjCLwz4n0qC yurnm1uLW48yKQEttyGAIzt256k9gDVbUD9l+POkyGQKLvSHiwWIyVZzjrz0HHtmo/iRGk/i3wRF Cy/bPt5KqrlW8vchY8A8fL1+tIZsa34n1+S9urLwlocepSWeFuLi4mEcQkOD5aHI3MB15G3oeeKZ 4O8e/wDCVSX2nT6c2m6zZgmW3lfcvBxns3BxnjjI5OasweKrKPxDqHh3TNCvZLmyPnSiBYI423kM zLukGSS+Tx1PPWsazWSb41G5S0msnfRSbqGVo2LfvAqsdjMOcAdjhKANHRfF2q6p4uv9Ak0qxgbT tpuZ1vmk3Kw42L5Y55GckYo1zxZq2jeItL0Yabp9zLqRYQSm9aIKQedy+WxA5GCOvPpWV4YiW1+M 3jCJeRJBBLn0yFJH5tTfG0Sw/E/wReHALyyRHDYJAKgfq/8AOmBteNfFd94P0RNWawt72DzFjljW domUkE5B2nIyMdAav6j4guNG0SG4u7JZ9TuGWO3sLOXeZZD0VWYDIA5LYAABNcr8bIfP+Hkj4BMN 3G2Oc5wy8f8AfVdXf63oelabYatrF5bQIygQ3EpySXUZ2kDuO47UCOYPxD1vQdVt7fxj4bTTLK6l KRXsN0JEQcY3fnycjjJ28Guh13xHeW1zDp/h/Tl1bUpIxOyecscUMOfvO/YtyFHfBPQVkfFeGzuf hpfzSmFynlSWz8nc+8Y2465UkfjSQ+LbLw9faNok2i6hPrV7YW+6SCOEGUhSArO7oSQQ3B6Z96AE 8NfEO7u/EX/CO+JtHOj6oy7ocvmOb2BPrg4IJBxjOa17/wAS3k/ihvDmh29tJeRW/wBoubq6c+VA pICrtXl2Oc7SVGB1rm/F8st54t8GXT6Jd2VwuoiPfO8OWQgErmN2PGM4PHX1qDwpMNI+NHirTrt1 E2obZ4GLn5gPmCjP+y//AI4cUhle+m1OT44eFo9Zt7KKeK3kCtBIzRygxyncAwG05/h55H3jxXXS +JdR1TxRqegaEtgkumRxtcT3hdg7OpIVFTHTABYtxnocVzPia5tH+N/hWS3uoJp4keCeKJ/niyHx uPQZ3njrwfUVf8SeChqHiyXV/C+sjTPEkKxyzRMD5UynIUsAM87SCeQcdM80AdP4f1u/1K81Sz1P T4bG6sJUQpFcGYSKy7g4YqvynkDjPBziti5uoLK1murqZIYIkLySOcBVAySTXLeBfEuo65BqFlrV olvq+mTCC68sYVyckMB9B6kHqODir3jm1mvfA2tW9uu+V7V9q4PzY5xx64oAybbxB4u13T4tZ0HS tJGmyZeKC9ncXFwgJ5BUbYyccZ3decVZ0P4g6Vq/hq+1iVWtG07d9ttWcM8JGemOoODg9yCO1SfD fU4tV+H+kSx4DQwC2dAwYq0fy8+mQA2PRhXIeD9Jsbr4keOLONBPpMo8qWN+Vd3OXXIx0JYeoBFA HSP4j8Tf8IyPEsGl6XPZG1N0LIXUgm8vbuDeZs2lsZym3twxpnifx5eeHPDOn+IBpdtc2l2ke5Dd NE8bOm7+424cEdj/AE5d9J1r4c6UfEHhTVv7V8OELcS2F0MsIjg7kcex64GOpDYq78XZk1X4W2Wp QLsjaaC4RD1wyMAMf8CH5UAb3izxjqvhTRxqEmiwXMcYRrmRbsJGNzEBYyRudh1PA45+lTWvH+ra Bp9nrGoeG0i0i4mVCwvN08aEZDMgTaMgcDcfQ4qP4uL9p+F08rMAyvBICTzksBxjjoxqrq8VjPou lap45v4l0lXi+xafasWjfcoAaZiAzkAknGFAHfuAelRSpNCksZ3I6hlOOoPIrmtX8SXX/CTReGdH FompPb/anmvSTGkecYVFIZ36nGVAHOT0rpgVZAVwVI4xXF+MfB+m+INWsp4dUl0rxEsbGzuIXwXV CCcjgnG/sQfm7jigRestc1s+J5dC1GysIpFsvtUNzDK7LN84X7pUFPcZbqOTVPw14v1HxDr+q6XJ ptnajSZRFcyLdtKXJLgbBsHGV7nioPB2v68dfvPC/ieO3k1Oyt1njvbfO2eMkDkEDnJHIA6Yxxk5 /gEGH4iePrclTm6ikG3gAEyZ4/EUDPSDxx1rh9Q8YeI5JbuTw54TbUdPtXKm5kuRGbgqSG8lcZYA gjPOewNduT8wwP0rjtB8bWWrSXdjonh7Uz/ZrCF41W2iWPBYAAGUcfKR0oESeGfHaeKdGvJ7HTpP 7TtCFl09plDZPQhjjC/e6gH5TxWRoHj3xT4l0q8vNL8MWczwXBTy3v8Ay8DAO3kcvyRk7R09xSeD bZo/iv4uljsGs4Wit2aJiuVdhuOdjMuSct1zyOOab8H0WCy8Q2ihFEGqOoRW+6MYHy9hx+OPagZs eHfiDD4k0i5lstMmbV7ZgkumiVdwJOAwY4+TPVsZGDx61tD8da54i02aXTfCoe5t5XimEl+qQ5HQ K23cW9toA455rL8EWw/4W54wntNzWS4VnB+UyswLD6gh/oKr/D+DXriHWtP068s7S0XWLgXNyAWm TpgQxnKrkg8sWx6HFAG9afER9Q8G3XiG20pP9AkZL21luwpTAB+RtpDdR12/0OjH4k1SfwTL4jj0 2xOLY3UcAvWYGMLuOX8v73B4xj3FYCQ+HV+DmrxeGpnazjhmDyy58xpV+8Xzg7iQPwxir2keVJ8F ESOVMHSJE3NLkB9jDG4nj5uMdunagDT8OeItS8TeH/7XtdNtIY5dwtUkvGJcqzK28iPCjKjGN2Qe 1N8F+LLnxdbXN2+nRWUMEpgKi581y4AJ6KABz6nPtVH4SSI3w301VkVjHJOr4cHafNc4PpwQcehB 71nfBxRHoeswrIsixapIodTkN8q8jsM+1AHfanqNrpOmXGoXsnl21vGZJG9h6e9cqninxBP4ZPiW 00ewuLFo2mS0W7In8ofxbgpUt1JTtjG4niusv7K21HT7iyu4/Mtp42jkT1UjnpXlAsPEPw40l9X8 N6lFrfhhgtw9rcqTJGjEZZCuO3JPAHJK9aAOq8QeOrnw94b0/X5NMguLK7ji3CO72ujuu7ABTDD3 yD7V19qbhrdGu44o5yPnSKQuo+jEDP5CvM/i1cw6j8KrLUrQGOBpoJ4oydvyspwDg443fpXqC7to 343YGcdM0AYPiXX9Q0WFn0/Rnv8AyoHuJ3eXyY441xkb9py55IX0BNVF8YPd+A4/FOnWMckIieWW C4nMTKEJDgMFIJBU46A+orW8Sx+d4V1eMvsDWUwLenyHmuA8NKZ/2fJ03kMtpeA4bkYkkOD1xx+h oA6208S6jdeCj4j/ALKt0zCbpLb7WWLRBc5LbMBsA8YI9/SHQ/Gw1PwnP4ku7EWlmpKwRrN5skzA lcAbQCWbCqATkn14ql4elhvfgtD5bEJ/ZMkLFjjDKrIw/wC+gayPB2radofwasNU1S0kvILS4clY 1EjI/wBoYKwDEBcEg9R196ALOofErW9Blgn8QeDbiy0ydgFuEulkZAfUAY3d9pIPXritjxh46Hhf R7TWILCPUtOuiAksdzsOSpZTypBUgHnP4Gqev683iLwFqEieGNTexubJpY5pXtdgGNyuQJt3BAbg Z4rkfFlu7fs/aGzhvkWBzgk8FWA6/wC8OPwHagD0TxB4kv8Aw74abW5tPs7iKMK0yQ3hGAzBQUYx 4b7w67aWfxJfweDl8RDTbZ0EH2mSAXhyIsbshtmC2O3A96zviKsN18K74xnETQwyR5PJAdGA4PJw PX8abcPD/wAKULM6xxnRVGS2AD5YGM59eMZ9qAL9p4yWTwhD4hu7Hy0ucfZLSCbzppyxwqAYUbzz wM4weeDWLd/EjUtC1CCPxR4Tn0qxnfYl2l2k6j67Rj3xnOASAcVHo3iHS/Dfws8OaxqdtczrAPLi 8pRI6Od65GWwONw68A49qm8XasNf8AX7T+HNVispbX7RHcyPa7UIG5XwJ93XHGM9RQB2d5dXA077 VpcVteEqHQSXPlo6YzkOFbt04x71y2kePrvWfCVx4it9AeS3iLjyIbtWk+XlidwUYx6En2rQ8KRS J8N9MS4lEZOnDMknyhAUzk88ADv7VzfwdQTfDaW3L9LiaMkHOMgdMc96BF3SvHmta/4ej1HRvC/2 qUBzMrXYjjUhiAiMVzI20A8AAZxnPFa2h+ONO1fwbL4jdWt4rZH+1QkhmidRyvbOeMdM5HSsj4OO G+HVpGjEtFPMjEtuGd5PrwMEccfrWL8M7CxvPh94g03U2Z7P7ZMlwTnhQi5YcnpjP4d6AOkuPFXi CDw0fEaaLYz6f5BuRAl6fPEWNwYnYVJx1UH6E03V/H8ujjT7mbQ5m066aNGuhOoyzoH/AHaYy4Gc Z4yQcVy62fib4eaUuoabqMPiHwiFDvbSLukSBjksnbGDyc7ec7cc1o/E66tp/DPhvUYebU30MyIG CZQxsQOuBx78UAal/wCPr/Rb6xbWfDc1npl9J5UVwLlWdGJ48xMALnOcbicZ64Iq7rnizUbbUJtO 8PeHp9au7YA3LLMsUUWRkLvPV8YO0diKo6vbW769pF34z1a2gX7TjTdMt93led/CzueXYZHZQCcc 97cfjKwi8Tah4csdCv5dRgYzTJbpbxh8hTvBaVck7gfWgYvhTxx/wlP9oWY019P1ewK+daXMnHJP Q43dufl4yOuad4a8XXniW71C3j0qG2+wSNBOz3gc+aCQAFC5KnHU4+lZlmXm+MEN2bG60+SbSJBN FcPETIFkUKf3bt69/Sq/wzwmr+MYFaQ7NTZsOSSTufnJJz0FAja0Xxhd6x4m1LRF0u3ik01gtzK1 7nIJwCihMnpznGOPWlh8W3z+M28NTaTBHOsInMwvdyGPuQNmSRxwQO/PTPN+DWii+L/jOBuJXCuv f5QRnv8A7Q7VbZEh+PIYtzNpJwCx4bPbPsp4GemaAPRM4rjtZ8Zarb3l5b6D4YutYSwYLdXPmrFG DjJVM8uw7gdK7DJxxiuN07xppX9qX2g6NoupXE9jK5mjt1hVQxkO5hukGcsST9aYF3wj42svFcVw gt5bG/tTtubS4Yb0PqO+MgjkA+1ZOrfEDVYI7i80fwje6hpdvIY5L1plRXw20sijczJx97GMZrN0 m1Sb4zak50y5she6OZLiGd13/M6ruykjDnb2PboOp73RtQ0i9s/J0e6tZ7e1/cGO3cN5W3jaR26d 6QGZaeMrbVvCEniDRokukijaSW2lmEbx7QSynAYBsDIB4IIOcHNL4d8S33ifw8NYtNJiiil3/Z4p bz5pNpKnJVCF5BHfpXF+EbJbK3+Itla4jsYZZUiReAh2PwMNwANvYVv/AAmkjf4Y6epdRs89ZD5m Qp8xjzzxwQccdaYEmhePbrxD4cn1iw0IyJHMYVgF4m/IXcWY42qMepznHHNV9K+IOpa74YXWNH8N G68tHN0j3gjWNlz8isVy524boBzjOeKyfgvEkvgPVIC/3ruRWcHsYkAPX6+lUvhxDq958Mns4ruD TdNVphPqAJefb/EEXopxn5yTjsvekB11v48k1Tw1Dq+h6JPfMySvLE06RpD5ZAZWk5BY5yoAORk8 Vas/HmlXHgRvFkwkhtY0Jli4Lq4OCi9iScAHjOR0o0i10KH4evD4dZW0s2swjkVixY4YMSepOc5/ LiuP8AWGma38GLrTtWKxWSSTedKrDMeMPv5zgjIP4dOaYHW3PiPX7PSItWk0K1mtJRG5SC9LSwI+ PmYbNrAZBJB4GeoGaPFXjC58M6pptp/ZSXSajKIIJRdbNr7lGHGw4HzA5Geh4rj2t/E3wzgi8+6T xD4TkkWKZJUJlt424GMkjbyPUHpgZBrQ+LEcQ1XwdcGTbLHqiqqliBgshLdccEL78/WkB1er+JX0 3UNK0eOCCTV9RDFEknKQoFGWJfaSeeAAuSfTrUdrr2rReJoNE1XSYIftMcksF5b3RkjcJjK7SgIb DDj61neOvB2m+J7zT2N//Z+tpu+xTj+Mr8+0gEZx94YII5PIyKpeHdc1+HxND4W8aWtnNeyW7S2W oW2MSgAh89MHGfuqvHUc5oAm1r4garazTPo3hLUNT0+3kKS3i8I+0kP5YGSwGMbumQfrXReF/FWm +LdKN/prOArGOWGTAeJvQ4JHTkEEj9axvD3jrTtV08LoGgarLa2rJblIY4EEPAwu0yAgAegxwayf hvapaeL/ABnFDbS2kCTwFLZ2X92WDsVwjMvGexpjOgPiu8XxqnhhtIjWdoDcic3g2NFnGQNu4nOR ggdDyRzXU9T7V5/Lsi+PMBDcy6IQRuz83mHt2+Va9AHrQI5TXPGN7Z3txaaF4du9bktMfa3hkEcc LEA7ATku+CCVUcAj6VJ4X8aW/iqC8jt7OW01O0+WWyu2CEN9Rk4yCDxkHqOmYrbxppH9tX+g6Zp9 9cXtm8kk0NvEi87wXYFmAOWf9awbC3QfHA3cVlc25utKaeVJ8Ag7gmcKxwDtXr3yaQzoPDfi+fxL d6jBDpkdu2nTNBOJbsMfMGQNoVTlcqRk49cGotM8aXWo6tq+nnRgkmkZN0EuhI78HHlIFy5OD129 R61kfDMLF4h8bWylsx6qzYJ4wWcDv/sntUfguWFfit41iE8jSFkZVDjZgE7uM9QWHbjJoEdBpHjN r3xZceHNR0e50y9SHz4fNlSRZU4zyp4PPbI4PPHPU155NAsHx6tpAzkz6OWZWPAIZl459F9D3r0O mBycPjK5m8azeFzpCJdRR+eZmvF8to/l5Hy7s/MOMevYZpR4uu18bf8ACMS6Okc7RNcRzm8Uo8PZ gAu7OcjBHY845rnrVFt/2gr3O5RcaaGUbsBmwg6Z9FP+eallHlfH2H5jibSclQ2cH5sZGfRT0z1H 1oA1Nd8dXdnqFzY6D4bv9clsyFu3hOyOJjtwgbB3N8wJAHA5PQ4t+EPG1t4x0+6ktbV7a/tTsls7 hwCrY4ORk7SeM7cgg8Vs6fcaUJrqx0+5tmngkZ7iGKUM6O5LEuM5BJJ61wGkWqW/7QGtG2clZNN8 yfAyFZjF8pPYnAbvQB0Wg+MLzXdc1LShootpdNbZctJeKRuO7btAXJB29TjAPfpRo/jG61jxHqWi ppEcU2nMVnke8G0jOAVAXcc47gcVi+B2WH4m+ObcsxZ5opANwI/iz/6EO3194/CoEfxp8XxkDe0M bgk8gEIePzFAG7aeMri78a3XhdNIQXVpGJppjdjywh2HK/LuJxIOCBz371oeL/E8HhHQH1SeEzYl SNYgwBYsefyUMfwrjtDAh+P3iIENmWwQgngfdh4HPPQ/kfetPX4LfxP40k0WaZjaWmmyeZGwbYLi bKoTxgMqByD6E4xzQB0HibxNZ+HPC82tuVnjCKYFVxiZm+4A3oc5zzxk81o6XqMGsaPZ6lbBhDdQ pMgbGQGGcHGRkdDXlfgLT7/XAnh/W41Fp4cimtZYi+7zJpGZEZR0wiCQAnpkY9t74WT3NhZan4Uv 5Ue60W6aOMjgvCxJVsZJxnPpwQKAPQqQ9KO1FABRjvRR6UABzijHFHrQcdKACjtR3oNAC9qSlA4p O9ABRiiimAdqByaDSjNIBO9FHWjFABSUtHFABmjsaTHNFMAFLikpe9ABilBpO9KOlIA70e1BNJQA d6KKMcUAA7UveijvQAhpQeKQ0ooAcOlFA6UUijnvDbsdCsAVbiEcjGK21Bc5YYA6D+tYfhf/AJAN iOeIgOfxreHFMgdSUUlMYtLik59KWkAUUdetJQAtIRxS0h6UAAoxxQDxRQAuaTPFFBzQAGlpvelP TimAveg0npR1pAHYUZyaOpoHWmADij1o5zSg8UgAdelGB1FHegdfagA7UlGKKYBR9aPY0YFIAo6d KUjikpgHail7cUnakAneloFBpgFFFJQAvaijNBpAFFFGM0AFGKKKADvWNdz6X4gnu9Cj1WeK8tij zpZ3DQzRjgj5hzg+3rWz3rBvfBuh3+sHV5LaaHUGTy3uLS6lt3demGMbDPQdfQelAHGfD7RxP4s8 U36z6klvBqQihkM77bgxlg25if3gz1z04rtNZ8JaVrN9HqDie01OJdsd/ZSmKZR6Ejhh7MCOvHJr VsbC10yyisrK3jt7aJdqRoMAD/H371YoC5j6b4bs9O1KXVJJ7m+1KSMRNd3bhnCA52qFAVBk9FAr YooFAHlev2Meq/HSyt5JbiHZpG4T28xR4iGkIYEd8nowKkdQc13el+GrHTL+XUTJdXuoyp5b3l5K ZJNmSdqjhUXJJwoA5pl74O8Palrf9sX+mRXV7sEe6cl02jp8hO3uecZrbAAGAAB6CgDn/Eng3S/E 8ttcXL3VrfWp/cXtlN5UyD0Den8u2Mmqsnw48My3NpcSWk7vag+WWupMlidxdmB3M2fUmurHtRQB zmteHfDWq6rpA1YRG5tw4sbZrgxhiNpJCAgvgKOORg8ip9T8JaVrECW92Lv7KioqW0N3JFEoXGPk RgD0HXOMcVYv/Dekapq9jqt5ZLLe2BzbTbmBT8AcH15zitQUAeZfF6GRrHwxbxyvk6pGgd3xzjAL Hr+I6flXpvesvW/DmkeJIIIdXslu4oJfNjRmYANgjJAIzwTweKvWtnbWFtHbWdvDbwJwsUKBFX6A cUAZuu+GNL8RLbtfwyC4tmLW9zBK0UsDHHKupBHQe3FSaX4fstLuGu1e4ur14xE13dzGWUoOdoJ+ 6pPJCgAnnFalL2NAHPeIvBuleJ5rW5uzcwXtpnyLuzmMUseewYfn7fnXEXWkWeifGbwvaWSssAtJ XO+Uu5dvOJZmYknPv6V6uKxNS8I6DrGsRarqWmQ3d3FEIkM43oFBJHyH5ScseSO9AHM+MPA0mtal pAsr3Vo1e+NxcT/bpHW3AUkMisxVDnAG0cZ9K7ixs1sLKG1Sa4mWJdokuJWkkb3ZjyTU8caRxpHG ioiAKqqMAAdABS0AY914bs7nWo9X+0X8d6nyq0d5IECcbk8skptbaMjHJAPUA1W1jwXpOuapDqF+ b57iDmDZfSxrC395ArAKeByPSuiNHegDndX8G6ZrwsW1KbUJXsgPJdbt4yrj/lp8pHz5Gd1Tap4V 0vW9Lt7DUVmuBbMGhuGlInjYfxCQcg+9bePSjnHNAHP2PhCytb63vby81HVbq1J+zyahceYIeMZV QAuf9ogtz1qXxN4WsfFVpbQXklxC1tMJ4Z7aQxyxsAeVbsenUHp64I3O9AoA5S5+HWgXa232lL2Z 4ZfOaZ72QyzOAApeTO87cZABAB6VPqvgnTdZtUtLq51JbJAALWK7ZI+DnkD73PPOa6SgdaAOA+IG 9dd8DIC0jjWEy5OCQAASccd/T8s135FY+u+F9I8SvaHV7QXKWjmSONidpJGPmA6j26VqW8ENpbxw W0McMMa7UjjUKqj0AHAoAy9d8Mab4jks5L/7SJLJzJbvBcPEUfj5vlI5GBiofEHhDS/FFlaWurG5 mW1bejJMY2LYxuO3GTW8KKAMS+8KaVq2jjS9Xjk1GEMXWS6fMqnOcq4wVPbjtxUUXhKAS2pvdU1T UYrSRZbeC7mUojrypO1VLkHBG8tjAroSKQigDJk0CKTxBHrRvr4XEaGNIxKPKCHG5duMYJVST1yB zxVbxH4O0rxVJbnVTdOlvkxRxTmNVJ6t8uDnp37Vv9qKAIbS3+yWcduZ5p/LTb5s7BnYDuxwMn3r jfFtxp2v+BtU1qw1+4axSxlQLayjyZG2nhxjPUgEZHFdxXMW3w+8O2heOC1uEspHMklh9qkNq7nH LRFtpHH3cbfbgYAKfw10S50rwhp0lxdXu+eDzDaTMoSEuS3ygDIJznBPGeg6Vzfw3ZZfiZ40ljZ2 Vp5ME4wR5789ee+PavUbq0hvLVraYN5TAAiN2Q4HPVSCOlYlt4G8NWVyLmz0tLafvJBK8bHnPJVh nn1oA6HvRSUtAHlfiixTU/jfo1nLdTW27Sy0ctvIEkjYGYgqT3yOmCCMggjNd1pXhq303U59UlvL y/1GaPyTc3jqWWPOdihVVVXPOAB0pmp+D9D1nW4NW1GzNxdQRCKPdKwQDJP3QcE/MetbqgBQAOAM AUAc9q3g7T9U1iHWYri807VIht+12Miozr6OGVlYfUVf0vRLPSWnli82a6uDme6uH3yy4zgFvQZO FGAOwFaRooA4+fSvCul+Mn1a71RotXv5UjCSXxjBIVdq7FIBGFXAbOfyrmvFWiTnx74V0+LWdVnm kaWQyNKjSWyALl1+TC529SCD0+vV3/w58L6nqF9fXenmS5vdpkfzWUqR/EmD8p9SOtaul+H7HSZn uIjPNdyRrE1zdTNNJsXooZug74GMnk5PNICj4g8O6Zq/hldO1vULj7FC6PLcSSojPtPG9toAzkdM H3qS68H6JfeHhodxaPNp4KlEe4kZlIGFIcksMDgc9KseIvDWl+KdM/s/VoDNbiQSgK5Qqwzggj2J FacEKW9vHBHu2RoEXJycAYHNMDn7XwbaI1ib7UdR1OKx2/ZYL10McTLwrbURdzDHDNuIqzr/AIW0 /wARtaS3ZniurNy9rdW0myWFj3B5B6DggjitrHNHegDI0/w7FZ6h9vub++1K8VPLilvXU+UpxkIq KqqTgZOMnA5rO8U+ANG8W3UN3ePd215CmxLm0kCSbQ24DJBHB6HGRk11NFAHIj4a6D5mnPuv86eZ HjK3bqzyPjdIzjDljgdGA4xjFXrjwpG+ttq9nq2o2N01ulqfJaNk8tSSBtkRsnJzk5P5kHoelFID N0XRoNEtpoopp7iW4naee4uGDSSu3ckADgAKAAMAAVp0hooGcsngSxs5rx9I1HU9IS8O6aGxmURk nqVVlbYT6rg+lbWjaNY6Dp62VhDsj3F3Zjl5XPV3bqzHuTV+k7UxHK2/gGyh0hdHOq6tLpOfnspJ k2OOpUsEDhSeSoYDtjHFYXxrzF8PRFEmIzdRoVUcBQrEcfUCvSBWZrugaf4jsBYapE8tsJFkMayM m4jpkqQcc0DJL3TbPW9Fewv4xcWlxGokXO3cOCCCvTkA5FY1v4F0+P7Al3fajqFtpziSytruVSkD D7p+VVZsdBvLVu6bptlpFhHY6fbpBbRDCRr2/E8k+5q0OlAg6isfWPDsGr31jfG9vrO6sd/kyWsg XG/GchgQ33RwRitjtRigDI0zw/Bpt9dX7XFxeahdBVlurkrv2L91AFAVVHXAAyTk1mab4V8OxeJd V1O1uZZ9TknWS6QXpIibhlVkUgY4yAwNdVWHpHhLSND1bUNTsIHS6v23Ts0rMDzngE4HJNIDa71z j+CtPj1u41fS7u+0m9ugftLWTptm92R1Zc55yADkn1rpB1xQRQBQ0jR7XRLX7NaeYd8hklllcvJL I3V3Y9Sa8x+HOgNft4jmttY1PTj/AGhJC32R0AZevR1bBGeGwCPXqK9dIBGCOO4NYWheDdD8OzyT 6daMk0rMWkeRnIyegBOAO3AoAvaLodhoGnCzsIyqFi8judzyufvO7d2Pc1kHwPbQXN/LpWr6rpMe oMXuYbOVNjOc5dd6MUY55KkdB6CuoooGZWmeG9K0nw+NDtbUCwKNG6NyZA33ix7k561gaT8NdP0u SCNtX1i9063fzIdOu7gNAr5yCVCjODyAeAeetdpRQBxlj8NtM0+5Yw6nq/8AZzTecdL+0gWxb0Kh QWXp8pODjnNaXh3wdpvhma5ms576WS4kaR/PuGK5b0QYTjAGcZxxmuho70xB2xXIWXgGOz0FNCGv 6tJpQG17ZzD865yU3CPcEPPAPQ4BArryKSgDA8U+FtN8TaHFpd9K9taRzRuvklU+7wFGQcA5xx7f StPTNMt9Is1tLVrgxL08+4eZhwB95yTjjp0qn4l8Mab4t0n+ztUSVoPMWQeVIUIYfoe/X19ea1Yo 1hhSJAQiKFXPoOKAMXxbp9ze6FePbajfWzR2k2YbZI2E+U+6wdGJ6YG3B5NZfw+8M3WieEoLTU7m WdZ4stYywoscIf5mTGMscs2cnvjAxXZUUAcLpnwx0q00+Sz+36y2nTKWXT57lTHCzd9qjDEHBAbc ARnmtPRPAWhaHo0+lxJdXFtcoUnS5uXdZM9TsyEB4HKgGumo7UAcpa+BY4LNNNl1vU7jRomzFp0h jEezORGzBN7qD0BboMHIrZ1/QbDxHos2lahGTbygYKYDRkdGUkHBFafak7UAclD8PdONi1nqWoal q0P2cW0SX0qMIFxjcgVQA+ONxyfeqtn8MbC3019Pn1rWbu08uRIoLiZGjh3Z+ZU2YLDOQTnB6AV2 9LQBydl8PNCtPDUugS/bL2ylwSLq4ZthBJBQDCockn5QMk85pbTwNDDYW2m3mtapf6XbMDHZXDRh GC8qHKoGcA4IBOOBkHFdWRSUActqXgSx1XxM2tXOo6p+8jWOWzS4xbyAdmXHKnuucHvTvCvgbTfC NvNFZXN/MZvvmefK9MZCABM8Dnbn3rp8UUAc/wCFfCcHhGz+xWOpX89mCWWC5aNlRj1IKoG/M45P FVNG8C22hWl7aWmram1teGRpoZvJZSzqVJGIwRjjvjiuq6UtAHF2vgAw6NDok3iLVLjR4sD7K/lg uo6xs4XJjJz8vpx0rd1/w3p3iTSDpl8jrCCGjeBtjxMvQqexxkVrig0AcvD4MSfUNPvda1W81eXT iWtVuEjREY4+YhFBZuBySfXFS6r4OtL/AF+HXrW9u9M1WNfLa4tCn71eBh1dWDccfl6DHR0UAZmm aJDpl3eXf2m6u7u7K+bPcuCxVc7VAUBVUbm4AHU1g3vw9tptevNX0/WdV0qW9ULcpYyIiyep5UkM euexzjrXY0UAcTefDXS3v7e90q/1LRZ4UERaxmAMiDP3iwJJ55JJz3yaIfhnpUOsQ6l/aOrGWGMI CLnY8jfNueSRQHYtu55/TAHamjtigBMc5/SuZu/Bdu3iN9e0u/utK1CVdlw1usbJOvGdyupG7gcj 0rp6KAM/StGg0pZnSWa4up333F1cFTLKegztAAAAAAAAAHSsS18CQ6Xd3smjaxqGmQXztJcW9usJ Xcc8oWQlOp6fpwa6scE0tAXM/SdFsNG0mPTLSAC2UEMJPmMhP3ixP3icnJNcrpXwt03SbmQRatq7 aY0vnf2YZwLdjjo6gfOOBweuOc13VFAHMeFfAmm+EoJI7W5vrgyEl/tE52HIwf3a4Q8DqQT71Xt/ h7a6fBqFnpWr6hp2m35ZprOBYSqlhg7GdCVBHGM8dsV2FFAHN33h1LHwwlhpN9eadaWVtIqw2qRP 5o25w29GJOc9ME7j7Y5/wJ4Pu4fh/wDYdS1C7SHULSRfsXlRqLdZe/3SxfB/iJAyRjivQ8UCgLnK xeCmFhZaZca7qN3pdnLFIlvOsRaTy2DKsjhBuQEDjAPA5qfxb4W03xONPTUr64tVt7jfCIJVjZ5M cAMQTnj+Eg10lc94h8Hab4k1PSdQvZLpJ9Ll86DyXChjuU4YEHIyo6YPWgYuq+FYtTXSRHqeoWba ZKZoZYpRJIWKlfmeQMWGCQc9Qeadp/hr7PrCazqOoz6jqSQG3jkkjjjSJCcnaqqME8ZJJ9sDit2j tQI5U+CUs9au9T0PVbvSWvjm8hgVJElbJO8B1O1uTyOPbrlt/wCANPuvDJ0aG/v7UvdC7mvIZQJ5 pc5LOwGCT9OMD0rrKOaAOHT4YaUmrQakNU1kXMUHlNMt2VmmbLEvJIAGY4IHUDCgYxXcUlFAHM3v gu2fxKfEWmXtxpmqOhjmeFVaOZTjO9GB5+VeRjoM5rS0jQrbSJbm4WWa5vrpt1zd3BUyS4+6DtAA UDgAAAfXJrVoxQBxtz8PYX1+91XT9d1fS/7QH+mQ2cqhZT/eBYEqfcdMnGMmsHwTZi3+Ivi+zs2e 3tkjSKPbgmPHAI3ZJP3jk8E8nORn0/rXOWngjSbTXr7WDJezXV5Ms7K9wRGrKdygIuAQDz827pRY DnT4Y1mT4ow3qateSW9rYIs17PBAHO5pMRpiMKfUnBIBx349FpaSgDl/EPguLW9cs9btdVvtL1K1 TyxNa7SHTJOGDA55P0IyCD25Sx08aX8bLO0jnmuWXS3M1xcANJIzFmyWGOfw4AAAwBj1OufvPBul 33ica/PJefaxCIQkU5iTA3ddmGP3j1JHtQBBP4Lgj8RT67pF/Ppd/dJ5d0Y0WSOYZByUYEB+ByPy Oa09H0K30YXMiSST3d3J5t1dTbfMmbGATtAUADgAADj1yTqijFAHK2Hgews/Fl94gTUL9ru5l3SR JMEjA4IUhRlhx0J/Cm6x4Gjv/E0ev6fq15pN95JgnazVMTr/ALQIOTjuc9F7qKv6N4VstD1vWNVt 7i6kn1WVZJklcFVIz93Az3PUnjArdoA8n8LaXbWHxu1m3t3bZb6fgGVt0rM3lFmZmyWJJJz7iu30 zwr/AGbPqE0mrXl419L58hnjhzv2qoOVQdAuAOg+vNRjwPpR8Vz+I2mvjfSgDCXBjRcDHRMEgjGQ SRxXS0AcnovgwaZqkmsRa5qhu7oL9sSTyTHMQcnKiMYPJGRzg1JZeC47HxdeeJI9Y1D7TdtiWHEQ iZOMKRszwR1BBx+JPTKgVmYZy2MjtTqAAUdOaBRQAd6M0EYo4oAO1FIaWmAUHtSUp6UAHOaMHNFB pAHNGOtHtQaADNAoo+tAAKDR3oJoAO1JS9aDTAQ0UUUCFo6Gk60UDFoBo7UcUgDqRxRR3opgApe9 JRSAXNIOtLSdDQAHrS0h4pRQA4dKKB0opFHPeGio8P2OOG8oc+tbo5rA8NDdoNj6eUK316CmQO70 lFFAwpTQKSgBQD1zSAUo6UdqADpQaO9IelAAOho5xQKBTAO9B60UHrSAMc4oNHfilamAhoPSg5zQ egoADz0oFHaigBaSilwaQAOtGaO9J1oAOtFFKfWgBOtL3pMUUAL2NJ1NHajvQApHHFJ2oooAAKWm 0uaAAUAcUdqSgApT2FJS+lMAopGztIQgNjjPSvOv7T8QaP8AFLRtEutde+tr+1eaeJ7aNEVgHx5e 0bgAVGASTjqTSA9G60V5fc3niuD4uR6OmvYivdP84qbYGGFQXH7tCxJYbepIyeoIAFTaRca5pXxa l0FNcvNX06Sz+1XX2sK5t3OdoBUAJ91cLjGG6d6APSqKR22qzYJwCcLyT9K4DUPDfjPxFajUl8Uz 6NdNmW306CPEcSkHakrA5ZuRuPIBzgHAoA9Bx60neuH+G/iy+8Q2F9p2soRrGlSCC5YJtD9QDjP3 sq2eAOmB2Gc51KD4uQ+G/wC3NT/smXTze+Q0wJ3biuBJjftyM4yD744oA9JFLXk8kvik/GBtCTxL dfZzZeerPEhVEIAJCKApbcCAWzjOeec29Ml1Xwz8Wbbw5Jruoapp19YvcKt+4keN/m53AD/nmcDp hulAz000d6801qfXtE+Ivhovr1xOmqTyRzWm0C3VAeAijnIDdSScjOccUnie98R2XxN0G0ste2rq AlVbVrfMEUY7sAwLtgZzkcjsCRQI9LH0ory+Ua74f+KGjWMXiLU9Yg1GNje20wUrCAOXAXCoOQQA M8Hrmpvi5PfaLotnqelarqNnczXqW7iK4by2VlY8qcgcqOQO/egD0qg1yuqaXqt0IdA0u+vdPsxH 5l3qTSvLMQcjy4nck7s8knG0Yx145ESeJvhz4q0m31DXp9Z0HVbgWxkvCWkhcnA5J46g5yQQG4HF FwPWRXA+K9b1zSfGugaZZamiWmqylXWW2RjHgrwrZXqD3yfrwKsXV9deI/Htx4diubq00zTLdZrt raRopLiVsFUDqQyoFOTggk+1c54k0gaV8UfByw319LbzzMUjurp5/KK43bWfLYbI6k/lQM9WiRo4 URpGlZVAaRgAWPqcADJ9hT815xqdtLL8YrHSY9S1iOyn09724gi1GYRswcgYAbKDIHCkDoMYzVXx HDexfFPRdHtdV1a3sNQi82dI7+Y7ipckAknYMBR8uOvagD1DtRXmvxEjurTW/DNtYaxqtkmpXiWl x5F7JymUGQDuAbBPPGSec10WsaZq+oyw6Jp1/e6Xp8NuGn1BX3zS5yqojtk7htyzE55HrkAjqOaK 8mhuPE/w+8ZaPpmpa5PrWi6tMIUkugTJHISF6kkjBK9yCM8Crfie51/wz4v8NXLa/d3Canf/AGe4 tVjUQLGXUBUjwSDg/eJJyPfFAWPTjR3pD1rldatdf17V5tOs9SuNF022RC11BFmW5dgflRm4VVwu SMk5xxQB1Rpa8r0W68UeDvHVl4b1nU59Z0vU1Y211KpLowBP3iSeCACCSMEEY5FWTb30/wAXjoX9 s6qNJi077d9nF5ICWJ2Y3g7sZOcE0BY9K70V5jrH21Pi3o+gQ6vqyabeWrXNxCl4/JBkOA33lGUU YBHHSvRprKO5iWN5bhVGBmKd0Jx7qQaALNJgEg+leVfDOfUNc1/X31LV9UuE024jjt0e5KjAeT7w XAb7o65B/KvVhQAUtZ2u6dcatod3YWmoS6dcTptS7hzviOeowQf1Fcp4istc0P4ZXKS+Jbue6srd 2e8jjEc0vPyjdklQAeT944zkc5AO77UV5RrD6+fhja+KpPF95BdW9vFcRpBGkcUhOBiQEZdjnnJ2 5/hrpUm8Ua1oujWMczabdT2MdxqV+1ud0ZI+5EPu+YSDkH7o7cigDs8UhryeS68V/DjXdMGsa+2s eH764W3ee5jO6Ek9Sc5B5z1IIU8DArsfiBLcWfhC/wBSs726tLm0jLxvbuBySB8wPBH1/nQB1HQU V5br0mt23wjh1qHxDfpczWcNxcy8eZI8m3CrjAiUFz90BuBzwcxeKf8AhIrf4d23iebxddrexQ28 sMNjEsMMjPtB3DkyE7s8kDjhR0oGer45o9qqaW9zLpNlJejF08CNMAu3DlQWGO3OeK4n4qahqPh3 w8db0rVby0uhJHBsVkaNl+Y/ccEbvcc8DsKBHoNJ3rz7x1/bWifD99Q07XrtHs0ildgFeSdy6A5Z hwoBJ2gc59ODleNZvFOj+GLPxGni2Rb0SRrHZQ26JHN5mAFVCCXfHOCT0bAFID1bNFeceKbzWrLx J4Tii1m9tBq8oivYF2bFwEyE3KSpO4jrR8SbrVdCttG/snW720kvLxLNyzK6lSvDEspKnIHI65Oe 1MD0fNArh/E+tXOn6poXhHSdTli1PUJN0l3MFleKAbiW+YYLNggcY+U+1Zniy61X4dPZa1aapqGo 6VLOItQtb6XzjyMh4ycFCcNwPlzjjFAHphpK83+I+oX9lFoV5o2u3dmupXkUBZGVo9jDIbBUnPT8 O1aHjG01nSvCl/c2Gv3VtFYW5mjIAkmmkDZPmO+flxwAoGM+gAoA7iiuSs9a1q68D6Lc2sKXGsaj FGolaM+TExQsZJNvRQFPA6sQO/HLeKIPGfgazTxBa+J7nWYI3QXlrdwoEwcLuUDoCQBgcgnOTzQB 6qeDR+NcjqFxq/iiO1tdDvJdKtJbaK8m1HytxZX5WKIngnAJY54G0fxcc1Fe+LfA3i7RdN1fXBrG h6iwt0uJ4grxtjjLZzuyRyxbIz3FAHqfGM5pfWvNr7xJaXfj3VvD+uaxc6JY20KG2Au/sxndhkv5 obPGRtXIHXIJ4HSeHNP1jR9R1aDU9Wur/TlEJspbsJuUYbeC4xuOdvJAoA6UUUxZopFUpKjBum1g c15va+IIPEnjfXdG1rV7nShZSrbWFnDetaNKeQZNysGkY/KQvQAjg9aAPTO1GK8+1TUvE3hDwT4k u7qe41K6trnbYXEsaZ8hljAdggAwpL5JHJU54qJ7afV/Dbap4R8XX91rCQozqL1JUkc4JV4mykRI z90LjHQ90M9Go71xniPXLm+8Y6d4P0u/exmlja6vbqNVLpEAcIm4Ebye5HA59qzPEupXnw61bS76 LULu50K9n8i9hvpnuDCcAh43Y7hwGJBJHHA9AD0ajtXP+MxLF4U1K+gvbu1ns7eS4ie3k2ncqngj ow9iD69RWH4Svdbm+H9pqiXE2p61qQIRrl/3MTbmALBBhVUDnAyTx3FMDvKO9eWeJNM8ZeDdPl8R 2Piy61QwlXvLW8iHlOv3coi/dGTkgEcc5OOfSNLv49U0qz1CJSsd1CkyqSCQGAOOPrQIt96K85+K V9qegafZX+laze2c1xdpbMN6tGAVY52spwenPtUnxIa88M+CDqOm6xqcd3auiLIZ9/mBm53hgQev YDt24oA9B7UVwPixb7Rvhq2qW2tamt9bQRuZvOBMpdkB3AgjvxgDHaup8ORSx+H7Fri7mu55YEkk mmbJZioJx2A9hQBq0mcDNYfi9ZE8M397BeXNrcWVtLcRPBLt+dUJG4Hhh7EEfjisXwIt9r3ga2vt T1m/uLi/3M0qMIjGFcgBQoAH3efXJ7UgO1wMgUucV518NJtS8R+H7y+1XXNQnka6lt0G9YyiAD+6 B82TnPaj4dzahrljrNzqetancsl3JZRq0qp5aKAQw2AfPz976YoA9F3D19qXPOK838OPrF74+8Qa PeeINRks9KMTQRbowzCQZG9ggY4AHfv1NPtW1RPi5Nora7qD6bHZC7jgMqnncvysSMkZJ/lnigD0 aik7V538ULzVtDtdP1HSdZvbSWe8W3ZQUaIAoeSrKe4/X6UDPRfSivNPiNda94Y0rTLrT9euAq3k cQEqpukYq5JkbHKnA4CgD06YXxfceKfD+o6LfxeIXuJ7y+S1OmxwIkTBjkhQct2+8SSM9s0AelHq KPSvOvGl3q+l+MPDtjp2u6hbW2sXEkdwoWKQJgpjZvQlfvnvxgUvju91zRtV8ORafq0otrq+jhNu QFL7dvDS4LYJznjoenqAeiUeteX+LZfEnhG70nWn8Tz3ZuL1ba4tWgRLbYxJwqDJGBxuJLdOe1dl rkmt3l6mk6NJ9gBjEtxqckAkEa5wEjU8M5wc54UepIoA3qSvLjq3ijwN4z07TdZ1U6xouqymOGeW NVliYsBzgdi6+ox0xjFbvxJub7RPCV9ren6td2l1bCMIqFCjZkVSCrKRnDHnrwPpTEdrSV594mm1 bQPhsusw+ItRkv7eOKQyMISsrSMgIIKY2jJxjnnvWra3esW/gzTp4Hm1LWdRiiCySjEaSOm4uwUY VFGSQBzjHU0AdZR2rzHxSnjfwdZDxBB4mOrQRsgvLSezjjTbkjK7eVGWwcc9CScV6HpWoRavpNpq MAKw3UKyoG6gMM4OO9AFw9KKgu7Zru1eFbia3LdJISA6/TII/SvPvAWpaxr3iDXo9R129ubXTLhY reIpFGHG5xlyiLu+4OOnPSgD0igdKM1598VNX13Q9FgutK1NbVJrhLcqsKl+QxJ3En0A4AI559AD 0Gg1574n07xboNhceItO8Tz3c9v++ubGaFBbyIMbhGvVAFHqScHnJ5z/ABn4tvn+G9l4r0fUrmwl udsZhjMboCdwYfMpOQQRlcHikB6jR3rg/GP9raD4Al1a18Qah9vtEjk8wiJllLMoIZfLxjk4wBis zxdfeJNH+G1vrFt4hk85Y7eaSYxpvld8Aj7oUIMjgDJ7n1YHp/agV5d40v8AxTomg2viSLxKiXEk kSpp0duohfeB8o3ZZ275OOM4C9K9MgaV7eJ54xFMyAvGGztbHIz3waAJaK848Y3mqWHjfw7p9lrm oW0OqzkTxoY2VAu0DZuQlc5PsevUU/x1e6noN5oken6/qEP9pXqW0qsIXCpwCV3RkhuRznHtQB6J WPrWvDSri0sraymv9RvCRDbRMFwo+87seFQevPJAANcx8QbrxD4c8MSanp2tmGOxeIAPEsr3O5gr eYzDjk8BQOAeeRi9qHh6TxRpek6wdXudK1WO2V/tVocKqugLrg/wk4PJ4xSAqXmpfEnTo59Ql0rw 9dWsUe82ttcSiUAcn5mGCQB7e2a6nw9rMfiHw/Z6tFBLAl1HvEcg5XnHXuOOD3GDXkWqvqEWly6f a/E8au93sgitZbZQk+W2484sQR/eIPIz6jPYfES51Lwx4Uhv9I1N7G4jeG3EMEUXkHPB+RlJAA6Y PAA9KAO/yMUVwnjoar4b8EzanbeI9SN7ZiNQ5WHbKzSKpLLs/wBo4A6cVJDc+Il8L6Tb6fetd61q sAna+vVBgtxtVmOFUDvhVx1OT0NMDt+3NGRXk+uX3jj4f3Fvquoa/FrmivMsdwrWqxOu484UcjgH BDHnqK2PiPqWq6HZ2Go6TrlxbLc3K27qVikjCsrHeNyEg8A5Bx7UAegDmgfyqG0ga1tkge5muWQY M023e/udoA/ICuJ+KWqan4f8PJqul6tdWk5lWAIqxtGchjkh0PPA5yKAO9FLiuE8eS6n4c8ETarp /iK++02mzEkiQOJg7hTuHl46NkYA6VBqtxrNn8LF12PxBejUhZx3Ty7ISrs4XK7dmAOeMYPuaAPQ qM1geDJLy68Kaff39/Ne3N5Ak7vKqKFLKDtUKqgD8PxrQ1W11C8tVh07UPsEjP8APcCJZHVcH7ob K5zjqDxnvQBf/GjHFcD4E8Valc+G9cufEFwl1JpFxLG88UYTzVRdxOBgeuOBxineHF1XxxoDa1da 1f6dHdvJ9jtrJ0UQIrFVLNty7ZBzk49u9AHd96U9c15/4U8aXkba7o3ieaOXUtEV5nuYUA+0Qjkt tHAIyvHH3hx1qx4fGq+NNEj1y61e+0xLpna0tbIoohQMQpclTvY4yc/Lz070AdxSVxHhHX7zV59Z 8M6vdMNW0uUx/aoQsbzxZ+WQKMgN0zjj5h61leHrvXr/AOJGs6HJ4kvm0vSVRljeODzZSQuAzeXk r97J69OaAPTM80dBR3rM16OdtHuZba+uLSaGJ5Ekg2E5Ck4IdWBH4UAaVL2rjfhvcapq/hi11vVt XuLye7DkRlY1jQBiowEUc/L3J712VABR3rldZbxJrWoXOm6BfwaTb2oVZ76W382R5SoYJGpIXaFI yxzy2B0NYnh3xD4k0fxjD4W8VywXTXMZe1vY9q7iASMgY67WHTOR3BzQB6LkZ680E1xWoWvi3xHJ LdaRr0ehWUbNHbR/ZVme5KsR5jlvuKccAZ4OT1xVHwZ4j1bX31Twxr1w9prenMM3NrsV5FzgsAQR wcc7cEMOBQB6FRXnHw11HWvFFnqd7qevXrmC4e1hRY4U2jaDvIEfLZPGcjjpR4UvvE2q6p4jtX18 zvpd4LW3E0ESoRuYF32ICxCjIAKgkYOM5AFj0eivM/Cl3408RQ61YT+I7aD+z9QltDepZo87MvGA OEC+5Uk5I4xmpvCuq+LvEnhGZW1G1trm1u5oDqgiVvPSNRtZFwUILkguOMLwCTkAWPRhS9TXn/hz xnqVx8JpvEt5HHe31vHMSsK7d5QkAsBwPU47c8dKg0s6zr/gttc0fxhcy6w1uZHhSOKSBZcZ8nyi mV6YBznnPNAWPRqWuT8Q+IdRsrjR9B0yNH1zUwf3sw/d26KMySMB1PXA6E/kcTxlPr/gvT7XVbTx Pd3gku0ilttQghaN8g8goilR8vQH1/EA9GpTXnnxF1zxFoOoaKdM1KCKC8vUh8j7OAWGV4aRiwAJ J6KOD7c1PGOo+MvCdpZa7P4gtpEkuUiudPjtFECAjPyufnI+U8kjrnjpQB6dR1FcR428VS6Tr2g6 Kt6NMt9RkY3GolVJiRcYVdwKgsSBuIOAc4q5Y2Wv6d4ntANYudT0G5gkZzcRxl45QF2/Oir8pGce 49xQFjq6KBmigAPNFHcUZ5oAQ9KXvR2oFMAHJoNGOaD2oAAM0Y96UZxSEUgCgmikpgLRSGl7UgCj pigUUAFJ2paKYhKUijtQc0AJ2NL35pKWgYlKKD1oPWgBe9FIetA/SkADrS9qTvR14oAUUd6B1zSd TQAGlFIaX6UAOHSigdKKRRzfhlNug2RBOTEDjOa6BeOtYXhkn+wrHpjyhW6KZA7vSZopOnWmMdR1 NJ3pTxSAX2pvU0tAoAQ0UE80GgAH3aO1A4zRjmmAvakNKM4pCeaQBjmlyBRkZprDPcjBoAWjPSjp R6UwDPNLxmkFHQUgAdaUd+aARxSetAC9aKBSd+aAFHSkooPNMAz1o70CigA4GaODQRxQOppAL2pO 1L2pKADvRijvR3oAKPrQKSgBaKSloARmCgsxAA5JPavJde8R6I/xg8O6jDrdlJZRWrxzTRXUbRxk +YBubOF6jr7V60Rmubn8JwXfji21y5itpLaysVhtICv+rm3sxfGMcDaB756YFAHG+LIkHxc8PajN qEtppeo2BtI7y2mVdx+dtoc/d3B1wV+bnKkHkbfhjVYYfH2qeHNIsIG0u3tlnuNQRjLJJcErxJIW O4kFuvzcHsK7e5tbe9tntru3huLdxh4pUDow9CDwaW3t4LS3SC2gjghQYWOJAqqPYDgUAPbdtbYR uwcZ6ZryzQ/E2t3F9qWneKPE0OgahZvhVaCGNZo8H51Mg+YZGcjjGPWvVPWoZ7S2ujGbi3hmMTB4 zIgbYw6EZ6H3oA8y8P6rb+Ff+Eg8Xa/NdrZanqEdvaSyWm2SWNQcSlVUYU8kHA4HTkCqcvi/T5/j Pp2qb500yTTHt7eVYmb7R8zHeFAzt3BlBxztz0Oa9bnhiuYWhniSWJxh0kUMrD3B608KqtuCKGxt yBzj0+lFgPLrzUIbL9oK2ee7SGKbSAgLkIDksQCTjnI4xk9KZ4k1G3sfj1oEt5OtvbpYFPMlcIu5 vNxycDkkDrXqjRo+dyKcjByOopc8fzoA8n8ceJtCuvGXhCa31mwlis70m5ZJ1IiBKcseijg9fSpv iFcwSeJvBespqDx6Q8skLX9o67Y/M2gNvIKqOvPoDiuw1zwtDrviTRr+8EUtnpyysYJF3b5G2heD xgYJ+oFdCyq6FGUFCMFSMgj0oA4G01vT9L8Yw6X4dtrW9s2t5LjV79JHuJo8AlN8uSWPBABJPPGM c8d8R/HGmeMfBVk2ji4aJb9DO0kRVom2uFTHdmBJ4J4HOM17ZbwQWsQit4Y4YwchI0Cj8hSR2tvE oWO3iRVfeAqAAN6/X3pWA878VeJdatptI1LSry8tvDNwBFdz/wBnFpbfn/WkOmQuCOSCODj3qa2s HijVtA0vTfE91r6pfxXlwFWB4YIk3ZZ5IYwVY9ACe59q9UoHoBgelFgPJdcvrjwH8W5vEF7bu2h6 tAsUtwiFhCRtBJwOCCoPuG4yRiqvibxbp2seOPB2qQxXLaVDcyLFcCJw05+TLLHjeVDYHTnnA9fZ CAVKkAg9QaTABBAHAwOOgosB5l4t1Gz0L4neGfEupLJDpkllJAZmiYGJznG8YBXh8YOT14GKyPFX imOTxl4e8WLa3q+HLKU2/wBt8hh5rNncVHUpjbgkDOGAzivZcA/eAPfmjqMHp70AeNfEPxfpWqXH hq+08S3dlb6gjNciBwrYKORGTgs2FIOOmcdTXReLfEms2Go6Lqlnd3UHhi7UJdyJYZltzk/vDvQl QQV6r/D716FsXj5V+X7vHT6UvamB5dfWx8R+IfD9pp3iafXorK/TULmZfs5it0Qkrl40X5mOABk8 AnAqn8T/ABPo0mq+Hha6pbTS6bqiyXUUcgLRhSpOT2xtx6164qqihVAVR0AGAKw9b8ORa5rWi3dy Ue302R5/KbJ3yEAIce2CfrikBq2l7bajZRXlnOk9tMoeOWM5DA+lcJ4p1nxDo3jWxW41J7PwteAK 91FbIxtn2kfO7qVUFtpyexPpXoXWkIBBBxg8Y9aYHmJs/wDhJvGuhG08QnX7PTJGubmfy4THF8q7 EDxoFZmYZxngDt3XXtXg8K/GS01XVWe20290s2ouW+4HDFjk44Hyrx6sD616aqhECIAFUYCgYAHo KR40kXbIquPRhkUWA8mm12DWPjf4cvbLzjYtZPHFI6GMTZE3zKDglOmDjnBxxXrgryvxNP8AY/jn oN3JYz3EMWnEYtrd5XBJmAOAOxI+nWtu08a3WlSapba1omvStbXkxhnt9NeSOSAsWTDAYyqkKc+n U0AYvwpfzPFfjkgkAahwp9DJN/8AXr1MV498PNTl0PVvEVxqeka1Gt9ch4XGlTszAM5O4Kpxjev5 16F4V1e71uDUry5s7u0iF60dtDdxeXIIhHHyVIyMtuPPrQgOgrA8bWVxqHgnWLW1RnnktX2IoJLE DOBjkk46VvUdqAPHLXV9G034cWmuJPDqmu2qRw2tlqE4cQT7wu1IBjDDBIIG/A+9W9438SeJNDGi alGXstJuI1GpFbZZmtGOOSTwB8xHJxlffnvRYWYvPtgtLf7Vgjz/ACl34PUbsZqxjIoA8m8S20vi ebRdItfFY1zzr5J3+y28TLBCuQ0jtH0HVRk4JOO1WvG/j/QtS8M+JdEt5Lkajbs1s8LQEEbWGZM9 AgweTj6cjPpVvbW9qjJb28UKElisaBQSTknj3pJrO1nSZJbaGRJxtlV4wRIMYw2evHrQB5fDqMfi f4HyWGmLdSXtrYQo0axOzZjYDg4w2QmcAkgEcdKgXWdE0b4fWHiOO+Gsa3HBElla391v8mfCqUSJ cAFeeQu7A+9zXrvbiqq6Xp8d616lhardsSWnEKiQ5xnLYz2H5CgCa1lee0glkjMbyRqzIf4SRkiu B+NCj/hX0rZbIuI/f+9/ia9Czk15z8a1Z/AsaLk7r2MFQCS2VfA4PrigDQ+IavcfCbUTGJJCbWJz xliAyEk49s5rnr3WdM0LQNJ13TZx4l1y7aJLKK6uPOaPIAcQxoMIQBtO0A5PJPQ+laPdR3ml200U M0SeWoCTQPERwONrAEU620rTrK4luLTT7S3mmJMkkMKoz5OTkgZPPNAHAfE2ddM1bwjrV0J4rG01 AtcyqC3lA7DzjPGEPTrz1Jrn/ij4u0nUrbSH0u6eeG2vlke+jQvArAfcVicM4HOB0HUjNezTQRXM MkE8SSwyKVeORQysD1BB4Ipn2O1CQr9mh2w/6oeWMR8Y+X04JHFAHmPjdUh17QPiFpsNxeWFqSl4 YIyZFiBb5gGxxguD07c85q38RtXtvEfh+08O+H7i01C+1eVNnlzb/KjB3eYcZwOAMnHU+leldOlV bPTLDTjKbKxtrUzNukMEKpvPXJwOTyfzoA8z+LcUOieG/DZSWQLZX8Sq5bLbUjPIHTPyjoK3/G3i PRZfAuqAalbxy3llN9minfy3m6r8qPgnnpx9K1vFfibSfC6adc6pazTedc+TA8UKuY3IPOSRjjI4 5Oehqx4o0d/EHhjUNNhMKy3UBjR5lyEJ79M8UgOL0HxYuifCKzvtMtBq1xYQqt1bR3Ch4MsclwNx A7gYzjngA1Z8b+JLDV/h4Y9NdLu+1mBEs7OGQPIxYgn5Qf4cHJxwRXcaVpdnoumw2FhbxwQRKFCx rtz6k+pPUmnWum2GnmRrKxtrZpW3SNDCqFz6nA5NAHnfiDUfEPgy48N2MV9HbaC0MFpcXcluJPIk GVYszHCqRtOTnofSm67p9/rPiPw1pyeJU1Rob1b2ZbeGJDbxIM+YSpOMkgDPXPHSvTSiujRuisrD DAjII9MVFZ2Fnp0Pk2Npb2sX9yCJUX8gPrTA4jxHbeG/FPim88M69DDFcrZxTWl0HEcxDMwYKx64 IHy4I5PFU/BWlNrGkeIvD2p31zq2hQXH2SzumlH7yMfMyhgcnacDOMdgccD0C60vT71JEu7C1uFl CiRZYVcOBnGcjnGTj6mp4IIreFIIYkiiQbVRFCqo9ABwKAOLsPhJ4R0y/tb61tblZ7aRZY2NyxAd TkHB47dOlVfElp4X8V65q2ga3Lb2d/axRPbXIkWOQxsu4nJb5sFTkEYAIPfI9C7VUvNJ03UEaO+0 60uldgzLPArhiBgE5HJxxSA4Lwvrl/p/ww1jUL+Q6pDp8twttNITtuoE4BDHJZc7hnnp1PWsTX9N 0jShpvinwFqaW99dTxJFptvJviuwThk8tckYA+YdBtPAbmvYZIYpoGhliR4mG1kZQVI9CPSoItM0 +C+lvYbC1ju5v9ZOkKiR/qwGT0FAzzvxWtx4U+Jum+LZVnbRJIPst7LGhfyM5AL9wuShz/s49BTv iQlr4z/sHw7pVzDdT3N2J5pLdhJ5FsFIaQkZCg7hgnqeBXplVbHTLDTI3Swsba0SRt7rbxLGGb1I AGT70AcD4s8daBcaH4j0C1aebUrKCS2Fr5ZBc7CCw7MqAEknj5c9xml4O8YHTPhEk9jazatfaaje bbqrIArStg7tpBAU5wMnA7DmvTpLK0maYy2sEhmjMUpeMEun91s9R7GpsccdqYjgPEfjDTda+HL/ AGCSO4v9XtfJtbCJ1llMjgAqVB/h3ZbPTHPpXYaFYPpfh/TbCQgvbW0cLEDAJVQD/KrNvY2dpLLL b2kEMkzbpHjjClz6kgc9T19an70DPO/jNbXUvguK7t1cpZXkc8zR/fRMFcj6Fh/PtWL8TvGWja/4 EubfR5nvSWieWaJCY7cbhjex43E8BRk969e9ahjtreKLyo4Iki3btioAuc5zj1zzQI8/8X6raat8 F9QuLaR2jW3hjZpY2TDBo8/eAz9Rxmup8I6tbax4YsLi2dn2wRxyEoVw4UZHIGcH04qXxPrNjoHh +41LUraW5tItpeOOISE/MADgkAAHBySAMVfsb2LUtPtr6Dd5NxEsqbhzhhkZ/OkBmeMMHwZrgJxn T5+v/XNqxvhTIX+HOjjnhZB8wAP+tf07VreNXEfgfXSSAPsE3J/3DWH8Kr6G58C6fbxRTRyQI28t bukZJkcjaxG1/faTjPOOlAGN8GtUsjo95pKz772K9klZVQlShwAQwGMfKe9VvBXirR/CuoeI9D12 9+wzR6jLcRvcDCupOMDqSflz7gjFd14S8Q6V4l0qW40i2ltYYJmgaGWFY2Vhz90EjHP8881svZWs l5FeSW0L3UQKxzNGpdAeoDYyOp/OgDy3w54l03TPiZ4mudTZtIi1O3t7m2F+VhBUKMk843HdkDk9 QeQRRZ+KNOuPjRFftJc21rc6f5Fv58RQzMzDawU/NtbbwcDOM9K9Qu9MsL+SKW8sbW5kiOY2mhVy h9QSOPwqZbWBbp7oQRC4dQrShBvYDOAT1IGT+ZoAW4uIrS1luJ3CRQoXdvRQMk14x8TPHOjeJPC2 nSaRcSypHdrNPII9pt8KwCsGwN55wO+09q9s6VWh06wtlCwWVtEqyGUBIlUBz1bgfeOTz15oGeaf Fe/g1nwBZ6rpsjy2sV/HI0qKcoAGBIB9CevT3rQ1G+0/w9quiXNjL/b+sarcpGs11ciWVLd8lniV flRcd1Cqcc5r0Ss+w0LR9KleXTtJsLOR+He3tkjLfUqBmgDifiKSvjTwG4BOL9+g56xe9R/Fe7hs 9Q8ISzypEiaors7OF2qCueSQMetJ8S7lLXxp4FkkaQKl1M7CKMyMQDF0UAk/QA16JtgvbdGkhDxu A4WaLBHflWGQfYjNAHnPxqnhPhDTZlulSI36MJUIJxsbleRyOvWui8ReNYfDt9osTWrXVjqUvktf rMojhPAGT0Oc56jgHGcV0os7ZbdbdbeEQAYEQQbR+HSmf2dZfY5LM2dv9lkBDweUuxgeuVxg0AcJ 44aLxB4l8N6Jp7LPcwXiX1y8XzfZ4VIOWPbd2z1xWZ478caF4k+HusW2k3Iu5Q6pIm3HlqsiEyEH +Hpg9yRXptjp1jpkIhsLK2tIv7lvEsa+vQD3P50w6RppNwTp1mTcsrz5gX96wIILcfMQQCCfSgDz 7xHqtnrPwKnms7mOZVtbVJDwdrB48g+/9a09M8XQ2XwttdWsIm1NrC1hS4hhk+ZSAFbJwcbRkn2F dJ4nvNK07w1e3WtWy3GmwoDNCYRIGG4YG08HnH069qvadewajptre2u77PPEskYK7TtIyOO3FAjj PFnivT734aNcQHzJ9ZtRFaWkZEkjyOMbQo64J5xXT+GdMm0bwzpum3Dh5ra2SORh03Ac49qms9D0 nT7h7iy0uytppDueSC3RGY88kgZPU/mavimMQjcMZPPHBrzT4YknxT42OwKDfL91cL9+b9a9Mryj 4cXV5a+LPFCf2RfzQXV8R9ojjVYoyskm7LOVyPmHC5PtSA9Xrzn4z5XwdaPx8uoRsT/EAFY/KDwT xXo1ec/Ggj/hDrMEOQdQiGEzuOVfge/pQI1PGPiHTpfh7PNbyrdtqtsYbKJAHe4dxgAKOpGecdMV yvi/w3daP8C7fTtgaW0aOe5x/BlyWxz2L4+gJr0Ow0/w/fSjWrPSbQTyncLprERSsR3yyhvxrYNA zyvxp4w0HU/hrcafp2oG+uZrWIlYhvaFQVJabGQnTGCc5IFL4k1Cz174GSvp06XTQWltvUNuKMrJ ncB3ADflzXocGhaRbQzwW+lWMUM5BljS3RVkIOQWAGDzzV5EWNVSNQqKMBQMAD0AoEeaajqlhoWh aJ4hcy+ItUvmhWyjupkLJuUb/JRRgHHBIBbJGSa9NrNtPD+i2N415aaPp9vdNnM8NqiOc9fmAzWl TA81+Jsg03xN4N1mcBLO1vWWebOCuSpAJPGMBj+FUvH/AIg0zWNS8NrpdyL2O31ONpLm2XzYVJI+ QSDgtgZ2jPHXHGfUbm1t723e3u4Ip4HGGjlQOrD3B4NedfE1bHSLfwvGkUVrZx6qkjJDGFACjsqj 09KQFv4s6jpx8DapprahZrfHymW2aZfMP7xTkJ16ZNYvinxJpb/CG30231u0S+lsYU8kTKWbaEDp kHAPqK6/xZ4cg8YaAy2kMMVzO0Si6ng8uVIhIC+NybgcA4HHbtW7pWkWGiWEdlp9tHBBGAAEUAk4 xknuTjkmgDzjxYdPv/gnpj2YSWXyrVbBUIaUyAqCqbf4sBuB6dKv/Eiz1K5+FEZmV5b63W3muePm yuN5wvHBJJ7cGu4g0bS7a8e8g0yyiunJLzx26K7H1LAZNXsZ60AeU+PPGeg678NrqCw1GOa5uooZ DADveICRGPmYJCHjuepHrTrvxpf6V8OtB1bw9JZXdrBDHb6iZ4jK0JCKMkK64IIIIJ7ivRIdD0i3 t5beDSrGKGVt8kaW6BXbqCRjk1cSNEjESoqxgbQgGAB6Y9KAPM/HP9rav4NXTk17SNQfVmiFpBbW DJLOA6sWQ+c3AAyTtwO5FS/FmJLDwXpsKyuFhvYUWRvmYBUb5scZPFd1Y6HpGlyPLp+lWFpI/wB5 7e2SMt9SAM1xXxiKf8IzpqysojbUow2fTa/SmB6L0euB+MVvJN8P7iWIAiGeKSQnnaoJGR+JH4Zr t7O9g1C0ju7Zi8Eo3IxQqSPoQDUzosiMjqGRhgqwyCKAPLvHfi7RtY+Gt1b2F9FqN1LBC8ixfN5K 70LNIATs9Bk5ycDPNXJNQsr/AOBs/wBjvbe5NvpKxTHcGEbiNcqQvQjsO3Ga7e30LRrS0ktLbSbC G2kx5kMVsio+DkZUDB55qDxBqGj6B4auLrVIYxpUKKkkQh3rgkKF2YxjJA9KQGd8O9Ssr/wRpUVr dRTyW9rHFMsbgmNgMYPoeOlb97qNjpkAm1C9t7OIttEk8qxqT1xljjoDTdJu7K+0m0utN2/YpYw0 O1Ng29sDtU9xa293GI7mCKaMEMFlQMMjocHvTA8r8C/ZNVtfHGjQXtoHv7y5+zKkqsrIykblAOSo yMkcc1q/CzVGtNGu/DWrslrqmkyuZIHdRiJvn3Ljqo3HntxzW/4U8JWnhyC4mMMJ1G6leSeZB2LE qi8DCgEDAArXv9G0vVWibUdNs71ouYzc26yFPpuBx0H5UAeb6RoP/CVeMvGetWssY066tTp9pOBu jnZokVnBBwygp26k9eK1PhnrUVpoM3h3V5VtNW0eSRJ4p5QMoWLKy5/gwwGenTsRXfxRR28KQwxp HEg2oiKFVQOwA6VU1DRdK1V431HTLK8aIERm5t0kKZ643A4zikM8/wDDUVk3jrxL40nvIbfSSwt7 a5kISKcYUO4kbggFMAjg881X8M6xpsfxi8UONTtxb3MUXlv5y+XK4EYwG3YYgnAHuw7V1epeKNB0 vXofDGq2q2lvNbh4JriNFtH5I8sEnAIx0I/pnnvCHh7TtV8YeKNXbTrG40eSWOKyPkI8TlVw7R8E YyMZHGSfSgD0vtVLVyRot+cA4t5Dg9D8pq7VDW8jQNSIwT9llxu6fdNMRznwpff8M9F68JIvIx0l cV2WeK8/+El7cN4I06yl03UIliV/9ImjVIzltwC5IZgQ2cgEcHntXoPagDz/AFnxV4isfiLbeHg+ mWOnXyg2d3cWkkpdgvKnEqjO4EevI9c1UvbTUNU+Kfh+2u7/AE+7l0yOW5uGs7J4jCpA2q+ZH5JA xyOCeua9BvbCz1K1a2vrSC6t2OWinjDqT2ODTbHTLDS4jFp9jbWkbHJS3hWME+pAAoAw9D8a2ete Itb0RoHtbrSpCG8xwRIgJG8eg6df7wrB8GWq6p8SPE/imBgbB9lpbSIp2T/Km51OcEfIORwc5rtb /Q9I1WaOXUtLsrySIERtcW6yFB7Eg46Vbt7eC0t0t7aGOGGNQqRxoFVR6ADgUAeU/DnxDpHh2LxN Z61qdnZXMGqSu8cjqhYdPlHVjlSMDPb1FWvhxrdi/i3xZDPOlrdXd+JILW5xFMwJkONhOSR3GOO9 ehTaHpNzfpfz6XYy3seNly9ujSLjphiMipoLCztJZpbe0ghlmYtK8cYVnJOSWIHPJJ5osB5l4P0o anrHjO2vdVuILWPWZnurO2YQiVWPDO/3wpCnhWXODkkV1vg7xFYal4Ps75bWHRrVvMS3gkZUURqx AK84IxjPvn61q6h4c0TVblLrUNJsbqdF2iSaBWOPTJHIp13oWlXenR2c2k6fPBAuIIJrdGjj44wp GAOnQUAcL8KL+1g+GjJuSWeJrmR7dmCh8HOFGPuYK9upNY2r6DZ6To8HxE8FXg055Y45fsOR5UoY jMSgd88bORnpjiu58F+CbDwx4fht5LK2bUJYAl7NjeZSeq7iPudsYA4rUh8KeHLe4jnh0DS4pY2D I6WcalWHQjA4IwMGkBxPj3UJfDfjvwx4nuIpF0xY3trhtm7yS2eOAcEhu3Xbiq/xP8T6PrHhiG30 u9ivmS6jnkkt/wB4kKgNjew4RjyADycHjivUriCG6t3t7iGOaGQbXjkUMrD0IPBrzn4naXpOk+DL eC1sLCxs5NShadYo1hUjDZPyjrj2PGaYB8XFCnwxcFljWPVEBc9RyG4/75/lVn4ysF8ER7gn/H9F gt2+8ePfAP512DQaR4jsYZZrW2v7U/PEbiAOvpkBh6Z59KkOjaWdPSwOm2ZsozlLYwL5a9ei4wOp /OgDG8XW2iamdI0vW7KO4ttQnaKKUybWik8tmXaRzztI4Pp1zXP+GNM1Hwh47Xw5Hq1xf6NPYPcx QyrlrQq4AHHCqQWxjAPTHGa7KTw3oL2SWTaLpxtUJZYPsqbFJGCQMYBxxmpNM0TStFiePS9OtbNZ CC/kRBS+OmSOuM8Z6UWA0OlJS9eKKYAeKKM0dwKQCUvTrR2opgFBoHWg0gF70UdqTNAAKKO1FMAF A60UCgAoozRnNIAGKKBR2oAKCaB1oPWgBKWijjFMBKUUd6Mc0ABooPWg5NIBRijFA9aOtAAetAoo 70AJnmlBpKUdKAHDpRQOlFIo53wuQdAshz/qgP1reXrXP+GTjQrIYx+6HHpzXQKAKZA7vRR3o60D D6Uh7mlzR+FACA5J9KXOBSkgYyRSUAB60lH40pHFACdqOnNGOKOtMAz6UlFKTQIO9GeaD1pM0DHG kPNB5owaQB70d6MmloAOKSijtQAd+KX+dHTmkoAKWk7UvY0AJ2oxRRTAU9KQelHajoaQCjpSY4pa OlACd6U0lH0oAO1FJ2o7UwF9KKO1B6CkAUdKKqXWqadYzw295qFrbzznEMc0yo0h9FBOT+FAFsUG s8a9pB1dtJGqWX9orjNr56+ZyCcbc5zgZx6VoGgAOc0CsifxX4ctbiS3uPEGlQzRkq8cl5GrKR1B BOQRV+x1Cz1KyS8sbmG4tnztmicMpwcHB/CgCwetGaxrXxd4bvr0Wdrr2mzXJO1YkukLMemAM89O 1bPOaACjoKa8iRRvJK6pGgLM7HAUDqSewrP0/wAR6Jq101rp2sWF3cICTFBcI7YGOcA5xyOelAGl nmkOc9M/0rLvfE2g6XcG31DW9OtJx1juLpI2/IkGmSeLvDcIQy6/pkYddyM92ih19VJPI9x6UAbG eKBWO/izw5FBFPJrumxwyjMcklyiq/0JODSP4t8Ox2L37a5p4tFJBl+0KVJHYc8n6UAbPeisS58Y +GrO7htLnXLCKedVaNHmAyG6H2z71c1PWtM0dUbUr2G0R/uvM21e38R4HUdfWgC/QapaZq+nazbN caZewXcKttLwtuGfTNUbrxh4asb5rO717TYLhSQySXKrtPocnAPsaANwYpOopkUsc8SSwyJJHIoZ HQgqwPQgjqKhOoWa6imnNcxrePGZlgLYZkBwWA7jNAFkUH1oqve31pptnJd311DbW0Yy8szhFX6k 0AWKTvWLN4w8NQWdtdza9p0dtdf6mRrhQH5xxz2PB9O9a1vcQXdvHc200c0Eqho5Y2DK4PQgjgig CWiqWo6vp2kqj6jeQ2kb5AeZtq/ix4H41Dp3iLRdXuZLfTdVs7yWNd7LbzCTA9cjjvQBp0lZWo+J 9C0mUw3+sWVvKCA0bzDcuRnLDqBjnJ4q7ZX9lqdqtzYXcF3btkLLBIHQ464I4oEWOAcgcnrS9qKx 7rxXoFjdNb3OsWUUiHbLulGIj6OeiZ7biM0DNjt1orJm8UeH7eCCefXdNhhuBuhkkukVZBkjKknk ZB5FR/8ACXeHBBHO2vaakMhYRyvcoqOVIDYJODyR0oA2qBWQPFfh1rVroa9pZtlYIZvtkewMRkDd nGeD+VMHjDwy0bTL4h0oxKdpk+2R7Qf97OKANvvR/KsceK/DjW7TjxDpJhRtrSfbI9oOM4JzjNWr DWNL1UyLp2p2V4Y/vi2nWTb9dpOKAL3Sg9KyLnxV4es71rO617TILlDhopbtFZT6EE8Hnoa1EkSW JZI3V43AZWU5DA9CD3FAD88UYqnqGqadpMKzalf2tnETtD3EqxqT6ZJqmnizw5JbzTx69pkkMCK8 rJdIwjViAC2DwDkdfWgDYFIVB6gHHIrIi8V+G50meHxBpMiQp5krJexkRrkDLYPAyQMn1FS6f4i0 PVbg2+nazp15MF3GO3ukkYD1wCeORQBp5pPWlrKu/EugWN21pd63psFypAaGW7RXGemVJzQBqUUd 6y08S6DJqA09Nc01r0v5Yt1u0Mm7+7tznPtQBqd6Kz9Q13R9IkRNS1axsncZVbm5SIsPUbiM1BJ4 s8NxQxSyeIdJSKUExu17GA4HXB3c0Aa5GRyAe/NBrK/4SbQBapdHXdM+zyOY0l+1x7GYAEqDnBOC OPepJde0eDVF0uXVrGPUGIC2rXCCUkjgbc5ycjHrQBo0dqo3Gs6Xa38VhcalZw3swBjt5J1WR8nA wpOTk1PeX1pp1o91fXUFtbp96WeQIq/UnigCeisiz8U6BqFyttaazYTXLBiIVnXzML1O3OcYGenT npSReLPDc9xHbweIdJlmkYKkaXsbMxPQABsknjigDY7UVn6lrukaPsXUtTtLRnBZFmmVWYDqQCck Dvin6drOl6usjaZqdnfLGQHNtOsgUnpnaTjoaAL3GKQ1m23iPQ7y8+xWutabPd5I8iK6RnyOvyg5 q5dXVvY2z3F3PFbwRjLyzOERR7k8CgCbtS1l2HiTQtTuBbWGtabdzkZEVvdxyMR9ASa1KAClrMuf EWh2V99hutZ06C7yP3Et0iyc9PlJzzU+oatpukRLLqeoWllG7bVe5mWIMfQFiMmkMt9qSshfFnht 4GnXxDpLQq20yC9j2g4JxnOM4BP4U+DxNoF1FPNb67pk0cC75nju42Ea+rEHgfWmI1aO9V7HULLU 7VbmwvLe7t2JAlt5VkQkdeQcU66u7ext3ubu4it4Ixl5ZXCKo9yeBQMlHU0tZEHivw5ciVoPEGlS iFN8hjvY22LkDJweBkjn3p1l4m0DUrkW1hrmmXU7DIigu45GP4A5oEahAYYYAg9Qe9IAAAAAAOgF Z2peIdF0aSOLVNWsbKSTlEuJ1QkeuCenv0q7BcQ3Vuk9tNHNDINySRsGVh6gjgigCQgMCD09KMAL jpj0oJxWVN4m0G2t3uJ9a06KFJfJaR7lAokxnbnPXBzigDUChckADucDrTqrWeoWWpWwubC8t7u3 bgS28okQkdeQcVVvPEWiadc/Zb7WdOtbng+TPdIj89OCc0gNPvRntSK24Ag5B6H1rGl8X+GYJ3im 8Q6VE8Z2sHvI1we4yT1Hp1FMDboNVP7T0/7TBbfb7X7RcLvgi85d0q4zlRnLDAJ49KZBrWk3d/LY W2qWU17ET5lvHcI0iY65UHIoAvUd6gu7y10+2a5vbqG1t1+9LNIEUfUniodO1nS9YRn0zUrO9Vfv G2nWTb9dpOKBltkUurlQWXIViORnrinUGqWoavpmkLG+p6jZ2SSHCNczrGGPtuIzQBd70Go4LiG6 gSe3mjmhcZSSNgysPUEcGs668T+H7G4kt7zXdMtpoyA8c13GjKeuCCcigDVzSVSTWtKeS2jTU7Jn ul3W6i4QmUeqDPzDg9PSi31jS7y9lsrbUrOe7i/1kEU6s6fVQcigRceNJUZJEV0YYZWGQR9KVUWN FRFVVUYVVGAB6ClqlqGs6XpOz+0tSs7LzM7PtM6x7sYzjcRnqPzoAuGimxSxzxJNDIkkTgMjowIY HuCOoqpe61pOmyrFf6pZWsj42pPcJGTnOMAn2P5UAXqO1Vr3UrHTY0e/vba1RztRp5VQMcZwMnng Zqkvijw88bumvaWyIwV2F5GQpIJAJzwSAfyPpQM1uhprxpJtLorbTuXcM4PqKz4vEOiXBlWHWdOk MS75Al0h2LxycHgcjn3qS51rSrKK3lutUsoI7n/UPLcIol7/ACkn5uvagC99aQ9KrXmp2GnQJcX1 9bWsLsFSSeZUViegBJwSanMsYh80uvlhd2/d8uOuc+lAh1FZEfizw3JtEfiHSXLMFULexnJPAA+b rUlx4k0K0nlhudb02GWE7ZY5LuNWQ9cEE5H40AafcUVVudTsLK0W7u761t7ZvuzSzKiHIyMMTjpz UNjr2j6nKIdP1awu5SpcJb3KSMVHBOATx70AaFMaKN5EkaNGeMkoxUErkYOD2qrdaxplldJa3epW cFw4ysMs6o7DnkAnJ6H8quMQoJJAA65oAWjtWVH4m0CVkWPXNMdnIChbuM7iegHPNavagBKWql9q en6YiPqF9a2iudqNcTLGGPoMkZNSveWqWZvHuYVtQu8zmQBNvru6Y96AJqTvWdB4h0S6lEVtrOnT SlDIEjukYlQMlsA9AO9NHiXQSoYa3ppBGQftcfI/OgDTqOW3hn2edFHJsYOm9Q21h3Geh96qz6zp VvI0U+p2UUirvZHuEUhcZyQT0xzU8N7aXFmt5BdQS2rDImSQMhGcZ3A4oAsc0VUsdUsNSEpsL62u hE22QwSq+0+hwakury1sIDcXlzDbQg4Mk0gRR+J4oAnxTJoYriJopokljYYZHUMD9QaZa3dtfQ+d aXENxFnG+Fw65+opt7qNjptv9ov7y3tIc48y4lWNc+mScUAWFQIgVVCqBgADAAoryePTPD9/8YLa K0S1uNMm09roRQzb7d5dx+YKDtPQkgcZwepr0m/1jR9FSJdR1KxsFcERC4nSIMBj7u4jpx0oAv47 0VVsdTsNUiaTT761u41IDPbzLIASM8lSe2KfeX1pp1sbi+u4LWBSAZZ5AignpyeKALB60VmxeINF naJYdY0+RpSFjCXSEuT0A55z2qzfajY6ZAJ9Qvba0hJwJLiVY1zjOMkjsDQA+4tre7hMN1BFPEes cqBlP4GpEjSOJY40VEUAKqjAAHYCo7W6tr62S5tLiK4gcZSSFw6sPYjg1LzigBetJ2qlf6xpmlFB qGpWdoX+4LidY9303EZqe2u7a9jMlpcw3EYYqXikDgMOoyO9AE3WgHiqlvqdhdTmC3vrWaVRkxxz KzAfQHNLcajY2kyQ3N7bQyuMoksqqzD1AJ5oAtd6Kr2t9Z3u82l1BceW2H8mQPtPocHiobrWNMsL qK2vNSs7e4mbbHFLOqs59ACcnqPzFAF2imzTRW8LzTyJFEgLO8jBVUepJ6VBPqNhbeR9ovraL7Qc Q+ZMq+acZ+XJ549KALNFRz3NvahDcTxQiRxGhkcLuY9FGep9qkoAKOaDXG+IINQ8V6vd+HbPUrnT LK0gjkubm2XDvI+dse7IO3bycdcgZ4IIB2dArI0e3i0DSbPSrzVjdXEUZ/fXUoEkoByTgnoM++Bi ry6hYl0UXtsWckIBKuWI6455xmgCzUVxa2115f2i3im8pw8fmIG2MOhGeh96ab60ELTG7gESY3OZ V2jPTJz3oe+s4p4YJLu3SadS0MbSqGkAGSVGckD2oAnpKrTanYW1yLae+tYrgoZBFJMqvt/vYJzj 3pba/s71pFtLu3naIgSCKVXKZGRnB4yOaALHel7U13WNDI7KqKCWZjgADqSahjvrOWQRx3du7nkK sikn8M0AWBRRRQAdKKDzRQAdqKO1HamAlKaTFKelAB2oPSgUUgDvQaKSmAvagdaM0UgAUUCjpQAC igUUAFHSiigA9aBR3ozTAKBzQDzQKQBS0EUnT60ALjJpKXgUgoAO+KUUd6OtACE0oNIaBQA8dKKB 0opFHNeG0dtBsSHA/dj3710K+lYfhhdugWK448ofzrcHB70yBfajvSnnpTdp3ZLHHp6UDF6il60g FL36UAB7Ug4UUvB60HpQAneg0e1KaAEGMUdKBRTAUdqQnGRRjikoAU9RRxSZ4p3pQAd6TPFB60dO lAB2opO1AoAUdaPWgGgUgFzyKO1Jj3pfWgBKXHNJ7UvagBBzRijvQKYC4HrSUUdzSAXPFJ1Bo7Ud BQADrR3pKWmAdqSl7UdqQBRQDRQAGvIvjFpljBPo98YQr3V8q3M7Pg7QAAMk/KuMnAwOp969drkv iF4Yu/FHh+GDTnhW+tLpLqHzSVDFcgruH3c5689B9QAczr+j23i7VNBt/B0EUdrpVx5kupwDy4I1 LAlI3H+sfIyduQCeSCa9TJriL/SvEPifxBodzdW7aNZaZMLmZVvN7XDgghAqfLt+XBLc4Y8V29CB nmvxbRFk8L3LKSyamqZ9QSpI9f4RVr4s389vo+lWCvItvqWox210EbaXhOSy564OAD2xkHrWX8TH 127n0O3ksrKCM6qotvLvXZ5WzhS48sBARnPLYz7Gut8S+GpvGPhVrHUUhstQV/Ot3t52kWKVchTu 2qSCDg8DqcUhkvjLw7aa34LvdL8iNVjhL2wGFEToPlI449OMcEjIzVL4Y6jc6p4A06e6MjSJvhDy ZLOqMVBJJJJwMZ9qhZvHOoaK2j3Om2FrczReRLqkd6SiqflZ0QDfvxkgZAzjkV0+i6Ra6DolnpVk G+z2sYjUsclvUn3JyfxpiKPiPR4NaS0g1C5jTS45DLd27sVFwAMKrHI+UMQSDwcAVwPxG0Dw9pej r4i8OfYLDV9MmjmX7HtUONwXDKpHr19iO9db8RPBq+MvDwt4TGl/ayefavIOCwBBUnsD/MA9qyH8 L6prtra6VqPh3R9Js9yvf3NlMpefHJWNRGNoZsEknOM96QGZ8RbyW5PgK/QOks15FJuVRkFvLOO/ PtyOKufG/cPCemMv3hqiHOM8eVKT/L9K2fiB4Vvtd0rTH0R4Yr/S7pLi3jkYrG4X+E447KRkdscZ rK8V+GPFvjbw4Yr06dYXEMwlgsopTIjkAjLybc7ueABj1zngGXfi63/FtL7cRgvCCSOg8xecetZv xLtLab4VLqD2kYvEgtQsskYMijI+UtjI+8fzPqal8RaJ448V+Dn069i0uynBizHBOzCcgjcWYjCJ 3wNxyBz63tX8KeINY+GTeHri70w6ltiVHiSSKEKhX5ScsSflPIAHP3RQBn+I9E0yL4J3SQ2aRb7S O7LONzmYhSXZupbnBPpx04qz4jleb4FNLsfc+lQNh/vchOuO9a+oaFquq/D+40GVbO0u3tlt42hu HkjwABkkopHQ8YP1rF8Q22qaR8G7/T9SW0D2VhHbxy2szt5gXaoYgqu04A4BPegCpqGsXWi/Aiyu 9PZ453tIYvOTgoX4Z+gOSSecZyc+9dhoek6dJ4KsNONvFJZz2SCRWTiTcoLFs8kkkkk85PrWb4f0 K01n4Uabo92D9nudOjVzGNpUkA5GR1B56dRVXQ7Hxp4Z0hdDgtNM1SK3ylpfS3jw7Yz90SR7GJ2+ x6YHagRR+Edzc29nrnh65mEo0e+MMTHPCHIxyBxlGP4kdAKw/EN/e219bfEu2EsttBfNarC2Qpss bd3TgMwcg9PnXg4rr4PCWraN4Iu9K0ee2bWNQ8yS8v55nT99J991IUnjJ29MYB9a1tS0W5vPA02i QW9pFM9mbaNDO3lR4XCncEBOMA9B0pjN2ORZokljO5HUMp9QeQap6nptvqEAM0YaSEO8DEZ8tyjL uA6E4Y/nWN4E0fWvD3h6HSNXe0mFtlYZoLh5CykkhSGQYwOBgn8K6Zl3Ky5xkYoEeM+CrnTP+Fd3 elWllHqmv3iTxNDbx5cgkhTI7ACNBwRuIHpzXofgTw/deGPCNppl7Kkl0hd5CjEqCzE4BIHQGub0 zw34t0TwheeFbSDT5BMZVi1P7WyhEkJyWTbu3AE9Ce3Peuz8NaL/AMI94fstK+1zXRt02maZssxJ JP4c8DsMUAWNXj8/Rb+LGfMt5Fx65UiuI+Fl55HwsW6RGkaJrmTZnliGJxXT+KbrVbTSbiXT4rAw rbymeW6uXhMeF4K7UbPfrjtXLfCP+1F8H2cclpbrppMpWV7h/OY7j/AUxt6jO7/CgCT4RuL/AMO3 2tzrv1HUL2R7mdhktwuFUnogzwO3NUPD8reHPjDq2gwCX7BqKm5SIZKxybVbfxwoPzLn2UelaGj+ HNd8C315BoFpDqui3biZIbi6EEtvJjDfNtO9SAMdMYHuTreHPDd5beINS8R6y1sdSvwqLDbszpbR jjaGYAkkBcnAGRwKQHVHkEA4OOD6V5B4e1p/AFlP4Y8a6RKNOlnkP9p+SZbeYPziTg5yc+/IBHGa 9f71w1va+LodGvtIu9J0/UoZ5ZhBLPqDYSJ3Yqsg2EnaCMbe2BximCOe8fWNppPwXtrPT7tLqxE6 NFMo3K8bMzrggnpkDPfHvXTfEIbvhZfAJn9xDhT/AL6U3VPAkk3wuj8K2dwpuYYIxHJK7bTIrbjk 9QpOQPQEelVJdE8aeJvDcuj60NK02HydhNszStOygbQc8ImQCSMt6YpAW9UYt8FJCFyf7CU4bk/6 oevf9awrLbJ+zrwpJWzkwCATuWU/1FSw6R8QbvwRceG76102JY7M20dylxuknABVV9FyMZY84zxk 5G14c8J6pB8P5PDWtTWQR7ZoYxaq5MW7cSWdm+c5IPAUDBHPWgZTtT53wHnLZP8AxJrg/P7I+Ov0 FYmnarPof7PMd9Yq0Vw8bqjRDOwtMy7jnOOP19Kney8a6b8NtR0i+i0+3s7LT7kNeJKZJZogjFUV MYUnoWJPB4Ga1PAek2+vfBqx0y7Z/KuIpUZkb5lImfBU+xAx9KAN3RfD+jXfgLT9MNpbzafNZocF AQ5dMl+f4jknPXJrnPg7e3C6Lqeh3DM50u6Mcbl9w2HPyj0wVY/8C9qu6PH418O6GuiLpdnqbWim KzvjeiNWjHCeYhXdkDAIHXHXvW34P8MJ4V0ZrZpzc3dxK1xdTkY3yN1wOyjGAP8AGmBP4tQSeC9c UgHNhPgHHXy2x1rnvhHIZPh1aAkttlmXls8bj/jXaXVul3aTW0ufLmjaN8dcEYP864LwdonjHQNM Xw68VjFZRTMy6mLgySGMnOEiK4DdcFjgZ6NjBAG/BYFfBl0nzYXUJAAxBwNielP+D4C+HdXjVdip q8yhMAbQEj4wKt/DTw9rnhvSri01VLOOKWdpkSNy8mTtHzH7o4XtnOevHK/Dvw/rvh2DU4NTS0S2 uLyS5iEcjPLlsDngKBhQeMnntjlAddffaDp9yLSWKG5MbCKSUZRGxwWHcA1yMvw18JS6TNZ3NtE9 zLkzagWH2hpGO4vvOeSTnB47Yrrr2zg1CxuLK5XfBcRNFIvqrAgj8jXluj+CL7w5bXOly+CtD179 6z22pTtEPlPQSB1LcdeM9Tj3YFz4exapqngHUtBmu5YZrS+eyNxwSsWVMiqTn5sFwCRxlaueLfhz 4d/4Q68Gm6TbW97Z25ltpoxtfcg3YLdWztxznr+Nalh4Mk07wJcaFZ3/ANkvrkPLJd225AszHJ2g EEKMBQBj5RWfaW/jW58MJ4c1CziE7xNa3GsNeB/3ZyN6qBuZ9mAM45OSaBHHeItWvNa+AWn3t3vk nFysTSygZcKzqGyT3AALdSc+prr/AImZb4SXeC2RHbZPyn+NOST257fyq/rvgmO5+HR8M6YQrW8U f2ZpGIy6HdliP73OT/tZxxWBrWg+OfEHgb+ybiCwtXSK3h8mO48xrkofnd3IAReFIVcnOcntSArf EuxtB8MbXUxZIbwQWkSyOoLxoPm2g/w8nkrjPGeKh8R6NpXiXRdP0nwVYwTajG6zSajbkbbb+8ZJ x96Qkg4BLZGfeum8QeFNY1z4atodxNZ/2nHHEYjbl0iJQL8pJ55wwzx2OKh1DSPEniGx0LTpIJtG WzmjlvLmK9Ubwg6RhMk5PPzBQOOtAHP/ABl0mxsPDFvfx26/b5tQjM14R+9bELj7x5A+UEAHGRXQ +PrTWodT8P6/pmny6nFpUjvNZoQXbcAN6jqzYyOASCQcdaxfjW+ozeHre1e0txbSX6rBJHcs00je W+B5ewAdSOGP0rq9QbxXeW2iX9hYwW11DO011ZS3hCvF5bKEZgv3ssDjBAYA54oGZ3h/WPDnjfxH Z67p0z2ur2MUiXNrIgWV42G3D4PzBWwR1wTzgmodKUJ8ddeOTmTTI24xz/qhzj6d6v2egXuoePIv E95py6YtraNbxxCdZJJ2Jb5nCgqAAxxg5yevGKij0HxFD8Vb3XbeOxGlzwR27PPId5QBS2xV75GP mI9ee4IwrvUtb8AeOdc1vVdMudR0TUtp+12iB2gVOEUjI2gBiOcAnkHqK3tO0fStX0TV5/DGqQpY a5cRvK1vhTCMKJVXrh2GeCBgtmtQv4hsfE+oXC2TX2jzRxCKKK4UTJIAdxVXIXaeM/MDkdDWBpvw 9nfwZr2mXzwW1xrFw10sUPzJancGjTPGcFRnHHXHrQAviP4Z+GLjQTHpdvb6dqFspNrcxSbG3rkg M2eec89R17VufDzWrjxB4F0vULpme4ZDHI7dXKMU3H67c1yWkeDtUg0WDR7jwb4dW9jHktrLLDIN mceYE2bmcL0DYyeSeorfm0/xdok2l6R4Zi0r+w4bUW5muS3mxOMDzCBgNxyAOpznHFAyn8KUEVn4 jhRSsceszIowMAAKMceldxqK3j6bcrp8sUN4YyIZJhlEbHBI74rjfh94d8Q+HJtVh1E2psbi7knj cyF53Y4G5sDaMgA9Sc54Fdfq+m2+taRd6Zd7vs93E0MhUjIBGMjPegDl7r4X+FLrR2sJLMLO/wAz 36sPtLOSCXLnOckdDkcniuV0y5vbj4NeKdO1KZppNLkntFkc8lECsASSemcY7DA7VPovgjUNA06X SW8G+H9WnSVjbapcbNpUn5TIGUvkdwvqAK6mw8Dpp/gC98OxzRfaL2OUzTCPEZlcdQo6KOAAOwFA EOlCWT4MRKwLO2iMFGA2R5RxwOvGKzfhdpthrHw10ddQto7pLe4ndI5l3IG3uM7TweGPXuaq2dn4 z034d3miajb2Vrb2NjMhvvPM7yxBGwiRjG0gYG5m6D7vpb+FsmoR/C/SzptpaXEvnTbxcXLQjHmv yCsb5PQYx+PagBfg6AnhvU4xuCx6nIoViOPlT04/+vmvRO9eWfBy51JrTVI300LZSXkkzXhmPMhC goqlfmAx97I+lep55oA87+DPy+DJwS24X0mQ2OMqpH6GqfgK8fTdF8bahHbl3t9RuJFULneVXIGF 5/8A11a8K+H/ABb4VutR0u1g02bTLi586G9mmbdEMAEGIZLfKAANw6cnnAn8EeF/EOjT6umqvp0l he3LSMrK0k0wIKktyFUEbTjkDkYFAhfhMVvPCUurTkS6hqF1LJdysPmZgcAEnsB0HQZqn4QDaB8U PEHhm1dhpbx/bYoMYWFm2EhR2B3kcelWtI0TX/A1xqFrpOnrrGizyefbR/axFNA2MMh38MOBjBHT 3rX8NeHr2z1fUvEGryRNqepbVMEJJS2jXO1AxxuOMZOByOPcA6K6tLa9ga3u7eK4gfG6KVA6tg5G QeOvNea/DLRNLkTxFO+nWjypqktupeJW2xgDCgdAOecf/q9P6le3evKPANzrVlqHiSe108ajpsuq zI0cE4WWOUH7wDkKVIKg85GM0AP8P2snhz4uaxoelFo9PurU3iW7f6qOQgENgHgZyvGDjA7A1vJ8 M/DM+kyRX1rHdXlxlrnUSR5zStyXU9BycgYx04qzoHhu6Gsah4j11Iv7S1CNYRbRkMlrAP4A2BuY jG49MjjiuV0PwPceGBd2EvgzSvEMTT77a+meJWCEABXDqWGCMnGe/HqDJPCllq03hbxf4PW+Ml1Y u1vazNL0R0+Ve+0YHbpk9MVT0/X7W48Kv8PvFlo2hXjQG0t5Z4QIHIICFTnBYHacj5SeQRkV3fhX wx/wjmjXUJ8pbq8le4mW0UJHGzDhI+BhV6Dp68ZrBvdL8ReJPBNv4c1vRCL1xGkuoi5ieOIAj96v zby+ByMYOT81AGR8R9E0yx1HwpI6Ik8t5HBc3QcRyyRgRoctkEDA7HjJ9ebdzodhrvjPw/d+ErOG Gz0tybnUbVVSBlG3EaED94cb1OOBnBNbXxC8MajrkGkXOlxwXEumXQna0nfaJ0yMqGOQD8vfjk1I bDXtd8W6VqTpeaJpmmoxa2eeNmu3bjaVjZl2AAcsc+gHJoAy9JlXxP8AFrWW1Bd8WhRpFZW7EFUZ id0mM/eO3g46EZ7Zh1+3W3+Onhi4hiSNri2kWZ1AUyYSTqf4sDH5D2pdZ8MeJdB8dv4o8KW8N9He DbeWMkqxZ6ZwTgc4znqDk85xWddSavP8YvCcmuxWkE7wyOtrbtvEI2S4DNxuOcHI4HbPUgHrlcu/ gnTdT1W91LxBbQalcTsYoFmG5IYBnaqqeh5JJ9a6ivMtQ8Dz2Hju81xdBtfEOm3ysXtZvK8y3kOD uUSYUgkeoPJznuAP8LaVJ4N+Jd54fspZW0a+sjexQyc+S4fBAPfqeeuNoPQGj4jRxjxt4HmKRgm9 KNIQM4DxEDPXGSfz96ntPC+qafcav4h0rRNL0zU2tRb6dYRbAgH3maQoAGdjx1wMdT1rN1nRvHni PUvDeqXGm2FvNYzb5LU3I8tCCjF2YZPzEEBQG27Ryc0AR/E3RdKi8U+G7ye3iSO8vSL6d32llBiA BYnIAAOACMZJ7nNi40Cx1bxvomoeDbO2t7ewP+mX9snlwOgK4RCow527lO3scE8YrY8eeGtX1230 S9skilvNNuBNNbLIFEqkqWCFxjPy8bsDGatC013WfGGmakY77R9KsI3EtpNcITdOwIHyRMy4HByz ewHU0AdfiuTXwPpOq32oahr0Fvql5cSFAX+ZbeIEFI19DjBJ6kk9q6yvLpfA76H4z1DVB4dj8R6X fgyCCQwmS2mY5JAlwpBPcHIB745ADwzY3/hHxzrHhXS7hZrKaxN9Yx3DMUgk3YAbHQZJBx1AB61s /wDCrPDl3pbx6lam51Kfc89+zkymVskkH0BPAIxgDOan8LeExYapea5NYW2lXFzELeGys0QLbxgk 5JUYZycEnp0GKg0ZvGXh+2vtPvLK41+TzmexvTcwopU9pdzBhg+itwcDoKAOa0u5uZ/hH4m0i9MU 0uiyS2yuWBBVCGU/hjA+g6V1mgQwN8IrRDDC0baTkoyAq37s9R3qSx8HyWngvVNJa6RtR1RZ5bm4 CYTzpQc4HZRwB3wKw/Ddl43tvCn/AAjdzpVvZC3hkjGofaUkMqndtWNB0bkDc3AHOD0oAx/B+l2G o/BW6e8tLedrYXbxGZAVVgrYPPXGTjPQ9KpabB4euvhdaW8+mxar4ku4Xit4IwJblQJHEbDkmONc DJ4XAx7V1/gbwzreneBZ9D1OK2s2nilCtHMZHVpB/ENoUYz2JrM0XTPFmi+ALjwxa6BNFqZd411K C6hjiw7Z83du8zIBxwmeByOwBZvPB8Vn8MXbXoLa91aw0yRI5ZBvEGNzALnoRkDIxwoHSqMtlrGt /A7S49LY3M8QUywNyZ4o3YGPA69BxkZ2/hW94oGr6R4CuNN8iXVI49MdLjUpLlUk3BSCxU/e9ev5 1meG28RS/CWCDStPkt72NYWs5HnVftAMwZiQOVXGevJU0CEHiLw947S10m8A0XxFZzxSQwXsAV45 FZWKxk4OGxjGQxHam/EW2gPxA8EStBGWluzHJIyA5AeMge/JP51pa1pV54x1TRlufD9xpklhcrcT X0ssTYUDPlxlHLMGYDkhcYBxnineOdE1zVfEvhe80izt500+eSaZp5RGinMeMnlux6A0AUvHMura F4w0fxIumtqWjWsRgkghG54WYnMgX1xjB6cEcZzVrQptA8S63N4p8KXVoNQFnJb3FvJH5Zd2KlGl xzwVIzg5HQ8Vr6zL4jtvEOjXVhp7X1klvOt9DDcLHlj5e0qHYBiCDjPYtyKzdH8MteeKtU8Qz6bL pEN7afZDZsyF5iT80rhSVU4wAMnPU0AK/wALPD11pElvfwtealLlpdTl/wBc8hyd3HGB2XpgYqH4 X3t+NP1TQtRnNxLo921skpByUycAkknscDsCKxdC8GXXhu2vNO1HwZaeIsSl7O/8yAllPRZDKQy4 /wBkMOTx67MOk+IfBvh2H/hH9KstQ1G7vTPfwK/lRRhgfliGQFUYVQT9cHPABCmnWKfHJ2FrbBm0 kTnEYyJN+3d7HAHNeiV55baN4vHxGh16a2sXgksxDMrzbVgUnJjQgFnK4HzEAHJ6dvQ6AOSn8B6Z rV5dX/iS3jv7yV2SLDsFt4QTsVOmDjBJ9Se2K5z4cy3Wh+Lda8EyXH2ixsU8213MGKLvzg46Eh1J GOoPTNbsC+KtE8T6xPNbXWu6XfFZLRYLiNWtCM5QrIygKc9VJ+70yaseFPDt1Z6rqfiPV0iTVtUZ d0ERDLbRgALHuGNx4GT6jj3AOf8AhZZ2sd74omSCFZI9SeJQip8iBmwBgDHU/gBTLrTdPf47Wqta 24Dab5+3yl/eSDeuTxycfj8o9KteDdK8U6JfeIJ59KthbXl5JcxrLdgSufmIwFUrg5XkkY9KyptR 1iT4vw3C6CrX8Wllfsn22MgKSfm34469PT60wLfxigg/snRZ3ghZ01BUDtGpYLtJIBPQfKCR0OBX Wa94dHiG6tLS+EZ0ODMs1qCQbiTogbH8C8tjPJx2HOL8StA1bxHoemQaXZmWdLsSyRtMiqg2N94k 88kDjNX/ABVbeK7rSLC70SaO31K1m864tIp/knXBygZlGe3UL36HFIDjvHfhux8E3Ol+JfDkZ0+W O6SGaGHOyVTk9Mg9AVIzggjiu41DwhZ+INf/ALS1pBe2cMSpZWUiny0J5d3U9WJwPYD16VNT06/8 Z3Nla32kz6ZpNrOt1MLqSJpbhlztjCozgLzkknPYDvWZ4q8JX9x42svEMOnDWbEJ5V3pzTqh+6wD Ir4U4yDy3Xp6gAoxaHH4A+JmjR6VNPFo+teZHJZb2ZVkVeMDvyykE5IAbnHFXPCk/wDwknxI8Q6l fMJX0oi0sYyg2woXcMy/7RKcn/a9MVY0Xwkk/iuz1pdBTQ7GxjPkWz+W0s8jKV3uFJCbR0G4kk5O Ko3nh/xH4X8f3Ou+HNMGq2Woq32i2a4SIo55PLdBuAIOD1YY5BoAkuLeG1+Pdg0MEUX2jTGeTYgU u/z5Y8cnAHPsKoza5deBPHOt6h4i0m5n0zUWTytThTzFhjBIVGJ6DB5XOeMgHPF99A8XTfESw8Rt a2LhLQxvHJc4jttwYbFIUs5GQSxAySQNo6bS3PiKx8Ua4JtEutT0W4aI2vlXMRZCIlDgJI6gISPX rk854Bk/g2y0O3h1K78O3VpLpt9ciZIbUAJAwjVWXAPGSN2MDG7pXTEBgAQD9a5bwR4dm0G01CWa FLU6hdtcrYxkFLRTwEBHBPrjjsMgZre1K5vbW1EljYfbpt4Bi85YsDucn+VMR598NbCyh8X+M0jt LZDBeqse2NQUUvKcDjgcD8h6Va8E3Q8SeMPEuqaisUlxaSiytYmBJtogzg8HpuK89+PTisz4f32o /wDCXeKnj0nzPP1FFusXKD7P88oJ6fPj0Hoe/XXg0HWvCvjjUNV0uzbUtH1UmS4tYZI0mhlxncN5 UMCxb+LgMfxAM29K+DPi/p66evk6frqBbi1jAVDLkrvA6ZztJOM8t616j2rjrXRLzXPGcHiTVrA2 MdhA0NnaSSJJIWJ5lcoSo44C5PrmuxoA8nj1g+CPG2vt4p0xzpurTGSLU0j8yNY84CNwTjBAI9QO MHI6XTfD1pdeFpbPQL6CLSNRvHuGks/l/cN95EwOCSNvsCcYwBSi716z1vxBDf8Ah+81TRriVDam GWGT5fKRXUpI6/KSDxzyW9c1g2/w61GX4d32ko66dd3N+b63tvP3JbLkYiLqD/COSuefUZpAO8Y/ DLSbXQpdV8NW39larp0Znhkt3Zd4Xkg9TnAOCMc9eM1H4yvn134Frqt3HE9zNDayu2wDkzICR6Z5 pkHha8n8P22lyeCobfVWhW3uNTmlheFMDYZlCuXdsZbBVeTya0PiJpsejfB6XTLYs0NqtrApOAWC yoMnjvjNMCG81ebw38E7G+00RpcyWdtEJQmMFwql+CPmA5ByecVsWfhfRj4E2Taba3Us9kJ5prmJ XkmlKbt7uRktk9TyKrR+HF8UfCHStKMnlStYW7xSbcbZFVSMjnAOMH2JrN0m/wDHkHh9tDu/Dsdu ba2MR1Sa6DKEVcZCDJd8DjnGcZxSAzvDVtb6z8EbuTUBJeNZwXhiF1IXRWCkqcZwcDGD25xis6G0 8NXnwxtbSS0Gp+Jbm1ZbaNUa4uRskIXGCTHGOO4XGevNdF8NdNa8+D9xZwSET3guox5vCxswKAZH UcA59zUWkaX4k0/wBJ4ds/D9xp2sSuYn1GGeBEKl/wDWl1O7IXj7u7jj2YFnU/BkA+FZj1+2S81P TtLkEblmbymXLjbjvwoJHULjOK6TwDNJP4A0SSWQyP8AZVXcT1AyB+gFZviZ9U0XwHcacbWfVETS ZIrnUpLhEIIjKlmViWJPXv8Aian+Gdzcz+BtNjnsJrZIoFWKWRlInXn5lAOQPqBntkc0AdXPPHa2 0s8zbYokLu3ooGSfyrynw1rd1pnjiC+vSItM8YRm6txIhVonX7iE5P8AAV9juHTFdp43ttW1LRRp Wl2srrdSot3NHKkZSDcDIq5YEsw+UDpgnJFU/iDoF3r/AIUgtdKsj9tgnjltgHSLyCox17YBwMd8 UAV/jBawXHw11OSS3ilkh8t42dATGfMUEg9uOPccU7xHo9g3wiuoIbG2ZItNE0YECgBggO8ADAPG eKsazpmt+Kfhxe6XqFqttq80KqypMojeRWDZVhnCnb0OOuPesYr4v1L4ey6LP4c+xyxad9neSedJ muGChQqIpOCw53McA+vUIDD1Pw7pkvwJtL+KwTz4LFHTgKuTIheQgcFiF6nPXHc03U9J0K/+Hek6 dp1nFqPiq7tLV4QnzzR5CkszZ/dRAZwCQvQAV1Nv4a1u++Esnhy+tYLS8WzSKFUut5dlwfn+TC5I AwC3B61m22m+IT8P7Xw3o+g3mhaqwijur+N4oo1K43Sb0cuxIHYE/SgZY+I+mmH4Uxf2jFDd6hbL apJcuNzb9yqzBuvJJ/PpV7R9QsfCfwm0/VIrOGKQ6fCVSGMfvpnUbAdo6sxGT7mk+KgeH4ZzxTTL K++3R3cYMhDrk8dCSM1neFwfEMvh3S2bz9L0LTra5uSV+V7pox5KHPPyIS31257UwE+Huo3Wna1q vgvxDP596JGuIjIAyyhvmkwSATktu5HPzelavgzS9Ng8V+K54dMtYJ4r4RpIkKghSiscHGRknJH0 Pesj4q2lzpGp6L4x08KsljMEuGBwWX+EHHUHLKef4hW74InivNa8VXsDbobi+jeNh0ZTCpBHA60A dnR3oFHegQGjFBpCQoz2FAC9qQ0fw80vamAlKeaSloAOKD1oFFIApKX2pKYAKKdSCgAHWigUY4pA A6UlLik70wFAooPXig0AGO9FHrR3oATpSijijpQAdxR1peppKQC0lLSd80ALSDrRRQAHtSg0negd +KAHjpRQOlFIowfDBzoFic/8shxW1WD4XZjoFiTx+6A/Wt5CSBnH4UyBaDS4pKBi5o6mgfyozQAE c0dqCfSkFAC46UhPFKTxSccUAHaijtRQADrQaKDTASlx0zRiigAo6YpeKTpSACaKMYo70AJQKXij HFMQvGaB60nU0vekMKT2oooAKDRRTAO1Heg0ZoAXtSUdutFIAA5oo70UAGfSkoFHamAUUUtAB70d qO1HakAVkeJ9O1PVdBntdI1R9Nvjhop1A6j+E8EgH1HP16HXoNAHHjw3quuavpGoeJRp8Z0ob44r ORpVnmI5di6LtAIBCjPPeuw6UUE5oAO9L0NJijvQAdKKWjoKADpSUZ5ooAKBRS9zQAVieL9HuPEH hS/0q0ljinuUCK8hIUfMCc4BOMA9q26SgDJ8NaXe6LoVrpt7ew3jW8axrJHAYsgDv8xyffitbpS4 zSdaADPNKCccUnelHpQAnc0dqUCigBKD7HFAoIoA4az0DxlZx6hpEus2uoaXdArFe3bP9qgVwdw2 gYbGeMsAOO3FdToejWvh/RbTSrIMLe2TYpc5Zj1LE+pOT+NaFFABnNJS0UAHeiijtQIMcUUUdqBi mk7UUdqAMzxLps+seGNU0y1dI57q1khRpDhQWUgZ4PH4Vm+BvD+qeGfDdvpeo3tpciEHYIIWXZkk kbifmGSedq10tLnNACUUvtSdqAFxQaDRnpQAd6xvDEHiG30po/Et3Z3V95zFZLQEJ5ZxgfdXkc9u mOTWyKBQMO9GOaOpoHWgQmKQ07vSdqACigUUAFFLSYoAp3ulWeoz2c13CJJLObz4CSRtfaVzjvwT 1+tXMcdaKSgBaxbWDxGviq8lubqwbQWiUW0KI3nq+BkscYxnd3PbgVt0lABRS9qSgApRSUtABjii lopDEoH1ooxzTAo61Zy6loWoWMLIktzbSRI0mdoLKQCcfWsLwF4d1fwxoEem6jeWU6xlmRbaFhgs 245cn5uSf4R+NdX7UY4oEVdN02z0jT4bCwgWC1hBCRr0GSSfxJJOferWKBQetAAKTFFFAB2oo7UG gAP0rivBnhjXvDt/qxubvTTY3l490kccbvJlj3Y7QOAOMH612veigBODRj2pe9GKACjgUUtACUuO 1Hag0AFcXr3hbV7/AOIGk+IdPuLCGOyt2iY3Ku7ZO8cIMZ4frvH+PaUHrSAagbYu8gtj5iBgE/Sn d6KM80wCjpQaQigYtFApKBC+1A96KPagAo7UUCgA7UUc4ozxQMDR2paTtQBV1LT4NV0y50+6BaC5 jaKQKcEqRg81YVFjRURQqKMKoGAAO1OpO1IQVh6oviX+39NfS5NOGkg4vknDGUgnqmOOnv1PQ1uU d6YBRRRQAUUUUAFHalooATFFFHagDg5rP4lHUherqOjG3huSRYJuVZoTjhpChIYc9vxPStPTfDdw /jGbxTqQihumthaw2sMnmLGmclixUZY+gGB6mupooAxtdPiBTYnQhYFfPAuxdhs+V3KYPX6+1bGB mlNHegAHWiikoAUDpQaBzRzQACl96TvS9qAA1ybxeNrDxFfXED6dqmkT4+z2s0xt5Lc4H8QjIK9c 5yeR6c9WaKAMLwr4dPh+1vGmmWa9v7p7y5dFwgdznavfaOgzz/Kt480Y9aT2FAARR2paD0oADSZ4 pTSdqAErmvH2hXviTwjcaZp6wG4lliZfPYqg2uGJOAfT0rpaWgDF8L6fqWk6FaafqL2jvbwJEDbB sEgYJOfw7DvWhqUMlxpl3BCAZZIXRMnA3FSB+tWj60dTQBxnw68Oa14W0JNN1NrAoC0g+zs7MHYg 4JIAx9K7OiigCtf2UOpWE9lcAmG4jaKQA4ypGCM/SrAwOAAPQClo70CGkZPSnDpSGloGFA60UelA BR6UUUAcv408P6h4p0mTSYJrO2tnMchnlDO+5WJxsGBg4Xnd68Va8I+HF8MeH4bFpVnuj89xOq7f Mf8AwAwB7Ct6k70AU9X0u21rSrnTrpFaG4jZDuGdpI4YehB5B9RXJ+AvCet+D/tdtdXFhdWc8u4N Gzq6AAgHBBBz8vGRjnk13PvR2oABRmkpaAEJxk9qhib7TiUH9yOU/wBr/a+np+fpUcpN7IYVyLdD iVhkbyP4R7ev5euLeKADtQaTtS0wCg0DrQaQBRR3pPwpgKM0lLRmgAzxQKKKQAKKBzRmgA70Gj3o oAM0UYopgGKP50dKKAExzS80dDRjJoAM80GkpTzQAUUDrQRSAKKB2pcZNAAeKQHig0o6EYoAcOlF A6UUijm/DDD+wLIgLxGORW+uDyDmsDwzn+wLHjJ8oA1vRjCgYxTIJBQTxR3pCKBhzQeKKXFAB2ox RSDpQAHmgkACjHoaD05oAKBR2o7UwCg0UGkAlKfajHFFMQlL1AooNAxMUo70CkoAXHNHagdaO2KA F7ik5zRQMmkAc0uKDxSZ9aADBoNFA5pgHUUvrmk5opAHTBopTwKSgA70d6KM0wAUGjFJ2oAXsKKO 1FIA7UelFB6UAHYUY4o7UUABpBSmjpTABRyKU0UgDHWgjmkpcDFACUd6KBQAdqBRiigBe9JSikAo AUcUlKBxSdKACgdKPeloABRjNBpO1AB0oxxS9qQ0AHeijHSj1oAKO9FBoAO9FHeigQUUdaBQMKMU d6WgBBS46UnSlHNAB3pKU4zRQAho6Up4oxxQADpQOlApBmgA6Uvejrz2ooASl5pO9LQAlGOnNLSU ALSUvak7UAFFAoNABRRQeaAF7UlLR3oABRQPSkNACjijvQOBRQMTBpcGjmloEIPpQTQOlFAAKDSi k70DDFJS0UCDtSUo6UlAAaKWkoAOtFLSUAAo70UvegA7UHmilIpDExR3paTvzTAMUd6KO9Ahe9Ia D60HmgYUlL7UnegQtGMUvbiigYlGKD/KlzQAlFKelJ2oAKKMUD3oAKDS0h6UCEooozQAUCiigAoo ooAWkpeMUlABRRRQAUmPzpe1FABzRRRQACk60o60dKAAUtJR3oAUUnalooASiilFAAaTPNKaTjNA C5o7UmaUdKACk7UvFJQAlL2xSUtACUDrRQOtMApaKKQCUGjpS9TTEJS9qDQOlAwxRRQKQAaDR3oo ABQetHGaOtMA70duKM4opAAqtM7XDGCJyoHEkin7vsD/AHv5D8Kldi5McZwf4m/u/wD16ckaxxhE 4A9TnP8AiaYBGiRRLHGioijAVRgCnZooFIAoNBpKYC96DSDrSmgA7UUdqD1pAJmiiimIWgUUGkMM 0cYoFHWgAFBNHeg0AHag80DrzQeKAE6HFKOtBo70wDvSg+tJ3xQKQB3pfcUHrSUAFHc0uaOlABSd KX0pBnNAAecUDpQeuaUHrQA4dKKB0opFHOeF2H/CP2R4zs9evNb6DA5Oa57wsMeH7Enps9fc10I6 9KZA78qDRSZoGFByF4Az7mjrS4oAOtHagcYoNAAaQ+9FHUUAGKTtSg8Uc0wDt9KCaUdKQ0AB7UlL QaADtRngUvoaQ8dKACjFAoJoABwKOaB2opAGOaM80d6KAClo6CigBKMelHSjvmgAo6Up9aSgBe34 UdqMdKDQAgoozzRQAUdqKKYBnpQe1FJQAtFHvRSAO1BooPNAB3o70dzRnmmAp7Cik6n3pcc0gDtR Sd6WgBOlLik6HFGcmgAAoxmgUZoAOlA6UA0dKAFA4pKUdKQdaAFxRSfjSjpQAd6O1AOc0c4oAOcU mOlL60npQAdKKO9FABQaKKADvR70d6O1AAaOtGeKB1oABzSmijHvQAmKXGKKO9ABijjFFBHHWgAx kYpcUmeKCeKBi0go9KBQAe1HejgGjvQITvS0lFAB3pfrRRQAh6UUp6UlABRS0nagAxS0CkoAUdKO 9A6Ud6ACiiigYoFFA9aM0gDmijvR70AJ2oo7UUxBijvS0h60DCgUUUCDqKSl7UlABRRRQAvvRSUt ABRSUtABn1opDS0DA0tGaSkAGjvSkUnemAtIaWkNAAKQ9aXPNB9qBC0dsik7UGkMU0goyKOoNMBS RSdqM8UdqACjtS0nagA7UHpRmigQUlLSd6AFxSdKKKACiig0AFLSUtACGijNLmgBO1A4NHY0UABo oNFAAKKPWgUAA6UppKU0AHejrR0oxQAdKUUnejvQAHmiijgmgBBzS8Yo5P0oxxQAUnalxzRQAlGO KSl7UAFAoooAO9H1o70UAJR0oopiDvS9qSl7UDCjGDRSLnv+FIBTRRR1oABSUvQ0GmAVHIxGEX77 Hj296c7BQB3PQDvQgIBLfePpSAWNFjQKM4HcnJNLS0lAB3oo6Ud6ADtRQelJQAtBooNMBe1IaX3p KQBRQOaD1oAKKKB1oAKKQc0vamAdqKBRmkAUdqM01JElUPG6uh6MpyDTAcc5o4zRQRzSADwaAe1F HpTADnNHajvmgikADrQaACOaKYBijvS+lIBzSADxSgUlKOhoAcOlFA6UUijnPC//ACL9j0+52+tb 6jGBWD4XwfD9jzkiP+preHamQLxmj2pe9J6UDAUvWk/Cl6UAB7UlL1ooAMc0EUelB6UAIOBRxRji gYpgLSGjFJikAvoKCaSlNMQZ4ooIxRQMOlGKMdKO9ABSdRSijrQAcUd8UA80GkAUc96O1HagAzR3 pMdKXHpTAWjvRnik+tIBe1Jmg9KOtACd6ceaTvRjrQAdqKKKACigc0UAFFFHagAoNLTcUALzR2o6 CloAQUppKXqeKAEFL0FG33oPNACdTRjk0Dr0oxxmgA7UAUDk0tABSUe1AxQAtJ3pe9JQAY+alFA4 NKOlACUdKKBQAnSgdaXFJQAGig0d6ADvRRRigAo7UYooAKB1o60UABooo7UAL+NHaij1oAPxoNAp euaAEzkdKXtSDpR2oGHegetAJ6d6D70CDvR0NJ0NLQAneilpKAClo70UABpO1KTxRQAUnbFLSUAF L2oo60AHbpR3ozxSd6AF7UfWgdKKBi9uKQUdM0vWgAopBS+tACCg0v0pKAAUd6Wk70gDFJS96TrT EL2pKXtXPS6DqTeNIdbXXLgWCQmNtN+byycEbuGwTnB5H/1gDoKO1cNqegeJvE97cyt4jvdDtIJ2 jtYLOPaZFHHmO24Fs9h09u9VPCGva7pmrax4c8SM97NptuLqC4jG+SePnPA5bPGBjIOQSeKAPRKK 85vvCHjDV7I6jJ4wvbHV3j3R2NsfLtos8iM45JHQuc/Sqmn+JNS8RfC/UtTubu4ttX0oTIZLeXyt zqoILAcHggEEYzngUgseo9BR1rz7w3bXeo/DdNUudY1U6hcWzzee96wCMu/aQAQoXoSMc8ZzWHod 9rmrfC2/15vEV/HdIsxdmdGOyMZAQgKEJIGWIJxnGM5pjPXaWvKLZtf1H4WL4kufFt/by29s88KQ rGoOwsB5r7SXJAHoPUVbu7jxPqfw0j1q81O40uSDTWuHS2AimlmUnaXJXhCoU7QByx7YpAemd6O/ SvNtV8Wa/b/Byz12DaNUnSMSTgKRGC2DJjBUZGOowC34VMmnvqejadqnhbxXq935c1v9oja9E3nJ 5iFw4/gcDJOMZAK4OaAPQ+9HeuKv9cutf8bN4X0e/ezgsojLqV1DsMhJxtiTOcdeTjI6cVm69cah 4X8c+GbWw1bUJrbVJTDPbXcwmXClBuXcCwJ3EnmgD0eg15l4s1HxFZ/EnRtK03XJkivwXSKRIykZ +cNwFy4AGQCeoHPcM1RtX8FeMvDkcfiLVNTttWnaG4hvpY2A+ZBlAFGPv9vSgD1AUHNebeJPEcf/ AAsePQtY1i60bSEtlljkhnFuJ5D/AHpB8wXqOq8it3QNM1jTvFl8ZtUv9Q0WS0RrN7iZXCtuO5Tg Ak9CCexxnigDretFVNRjvJbGSPT50guGKgSsM7BuG4gEEZ25xkYzjPFcJ4Un1weLfFugDWrm6htF RoLi+VZHikkGegxx1wvA44AzQB6LigCvLvCcniDXdc8TaXL4ovUtLK7CmVEiM5JLjCHBWNflBxtP oMc0eErzWLz/AIS/TrnXLy9stNci1v1bEm8B8gMBzjaMjpnpRcR6ie9L2rgPAf8AaGvfD+DU9R1v UpLq5Vz5iyxgxhHdRtwoHbJ3Zzjnjisz4dXniHxZ4Zu7q61+688zi283Mf7uParMUCqBv5wC2cUD PUTRniuC+HWrajdaj4j0i/vp71dLuhFDNcFGcqWkHzFQMn5R1rupY/NiePc6hgRuQ4I+hoAf6Uhr zYjUW+KJ8ODxDqp037ILkxieMOpxjbu27yOncHnrWtreuXl/41tPCOmXbWg8k3F/dRFfNRMcImc4 J4ycZAYEUAdnR3rzbxdf6n8PrzTtVttSvb3Sp5fIurS8lEu3jOUY4YHAbq2M46CvRopUmiSaM5R1 DKfUEZFMQ/vRXLa7b+I9b1V9O0u/fRdPgQGW9EAeSeRhkLHngKo+83XJAHeub03VPEfhHxtZ+HvE GpnVNP1QFbS8ZQrhwMY9uwIyfvA55xQB6bRXnGmnUh8VbvQZNe1KTTra0W7jiknXcWO0YJ27mXk8 E02/m1KL4sWGgxa5qY0+6tmnli81TjiQ4DbcgZRe/rigD0mlrzbxfeahZeO/DemWesahBb6lKftK LMvIBGNuQSvfp14qPxRP4i0/x54e03S9fuAt6sgSOcI0abV5LALuk45+Y9R1GaQHplFea3U2seEP HPhq0Ov6hq1vrLyx3MN3twjDaSyYUbRl+B2Axk0vj+81PTPEvh+207XNQtk1a5MM0UbRkKu5BlNy kg/N+lAHpNFcZ4q8RT6Tf6H4Z0yZxqGoyLGbmQb2hhBwX54LnBxkEdSffN8YjWvBekRa5put6heJ byIl1bXrJIkqsdu7O0FDkjpgc9BTA9Fo4qhaaxZ3miRawjlLKS3FxucYKpjdz7gVw/gTxlfar4l1 DTtVjmj+1xrqGnpJg7IG6Lx/slT35Dc0Aej96B1pK5LxxDra6TqGo2OtSafBZWZmjjgC7pJFyW3l lPy7QMAYySc0AddSnnmuJTU73VvhWmtPeXFpfpYPcebCQCZFVhkgDBGRnGMVHoJv9T+Gq6rdaxqH 26e2e584uqlCA23AUBdvQ4xzxmkB3VArhPAn9oa34Eh1XU9a1GW7u1dvMSVF8sK7KNgVQvYHnOe/ HFZPgC91vxH4MvdavvEOoi6jaRIjH5BUBY1OdvlkE5J60xnqFLjmvK/Alv4j8aeDo7rUfFOoW0Yl k8p7MossjZ6u5U/KCSAox069ANr4VeINS1/w3c/2pP8AaJ7O6NuJzjc6hVPzY4zzQI7qg+1Z2vJd vol2tldraTeW378puKDByV5ADehOQDyQeleb+Ejr/ir4eS3+peLL2yggEvly2xRJDtGd0spBJAOR gbeByT2BnrXak6iuO+Ger6trXgyC71hJPP8AMZY5pOs0fBD9B6kZ74zXRavbfaNOlYXd1amNGYPb vtIO0888HHoeKALxorz74U32o69oUms6pqV9czmdoUWSRfL2BVOQqqBnJIyeeKf4e1O48fajq14u pXdro1pMba0js5PKM3GfNZh82cEEDIHPI9QR3tLXAeH9c1TSfHt34Q1i8nv43jE+nXcyorlMFirY A3Hhhn/YPTt39ABRXA3Gl+M/Eol1K28RyaJaytus7AW6lwgXAMrEblZjyRztz603wl4w1WXStasd YtTNrWijayR8mcnO0EgYByMZxjBB9aAPQPejPvXnGpaD4+tdJn1ceMS+owoZmsYrVPs5UclFJXJO BwSOenGc1Wn8W3ev/C6bxPYalc2OpWA8uVLcJ5RlDLnKuDkFWBHPGfWgD0+iuEsp7+b4Wf25Jrl+ t82nG9MxMeA4jY4C7Mbc9sdh9ayLa58Taj8K314+Jp4pzbT3c0nkR78xkhUj2gKikIc8EknqBxRc D1KlryOe68RP8M4/Ftx4wnsp4rUGKKOJPLkAYDD5BLSNjhhgDPTGcz6/qfjGD4djxNdam2mTwQW7 JaQxqrOzFFZptyHByx+RcDHXngFwPVaAK818X+M9RtfBXhrUbd5bJdVaA3l3CFbyEZAzBcgjJycH H8Jrahsr9rrRdS0DxLeahpk1x/pSTSJNHJEVclgwXIIOBgHHTpii4HX0tefX91qyfFey0CLXL5NN ubNrySILESrZcBVbZuC/KOMmodX8UO3xQbQNR1ebRtKitBJDIjrD9omO3q7L0wzAAEcr3PFFwPR6 azAHaOW6/QVy0EeteHp9XeW7v9Zs1tYnsIpEUyeZmQGPcqjd0T5j0BGemawtS8O/EO3tp9XtvGET 3yr5p06OyAg7FkUsST0wCRk+ozRcD0ZV25YnLHqad2rmfBviH/hNPBsV9IRBcSh4J/s5K+W44JUn kcEEdcZ74rB8D3Or6h4p8R2d9r2oXNvpV5sijcRASAs/3yEBPQcAgc9OlAHonbk0vFIOnNGOKACi j8aKACijHFJTAXvQaSlNABRR6UdqAADNJ0pc4FFIAo6GigfWgABoNFITTAUUdqBSGgBfqKQDAwBg Dpil9qWkAnY0cmik6mmAtHvRS0gENHajvR1oAKX3pB0o9qADvS96Me9J3oAD2oyNp5oNKKAFXO3n rRSjpRSKOb8K/wDIAs9xP3O/1roAMVz/AIY2Dw/ZHj/V8/nXQLTIQveg8YoBpaBiZ5pCGLgh8KBy uOv40vQ5paAAccUhpRRmgAFBpDR2oABR0o7cUdRTAM80GgCj1oAD1pe1IcUUABozS0h7UgDpRR2o HWgAoHNHSkFMBR1oIo75ozQAUCgCgcUAA60uOaSg9aQC0Y5oo4zQAHpSUuaDQAnelPekoNACClPS iigA7UHmig0AFGeKOgo7UALSdqXvSUAKcUnU0UDg0AB9qUcUg4paADNL2zSd6KACg0Z5pPegA70d 6McUZoAKKPrRigBcUnQ0Y4o60AHB6Uo6UlKOAc0AAoNA5pOaAFzRRSdcUABoooNABRRRQAd6O1JS 0AHTmgUvQUlAAeuKM0UEUAKOBR0pOlHSgBe9Bo7UHrQAYFLjk0mOKXFAxD1oHNHejp9aAE70vc0m ecUtAg70lHfmg0AFLSd6XuKACkpTSUAFFApfagAooxRzQAY4oxijtQaAAZxQaB65oPWgYvQUUUd8 0AHejvRRSAQdKKXtSHpTABQetA6UtACd6KKSkIO1Jml7UUwPMrrxRrWneML/AErXtdh0axyGsLqW 0VklUscBpD8oOPp0PpVrwxDqGpeKtW8RrNJewR2X2Oznlt/IW6bJYlRk5QEABuM5PXGa9CIHQgEe lFIZw2g/EiyuLO6/4SRIdD1K1l2Np8shMrrtBBVMBmzk/dBqnofhvUE+HfiMS2siX2stc3MVpIMP GGB8tGBON3QkcYzg9K9FxznA3Dv3paBHkvhbxjYR/D+Pw8sV3LrsFtNbyWMdsyGM/PguzYVFxySW 9fpTPAYkvfhDq+mW1rdNdGG4Ma/Z3RZN65XY5+Vj9Dn9M+ukblKsMg8EHvQAAoUAADgAdqBninh/ VNFs/AEFzf3YvPEenF0tdHvpTmKYORGq2wILHkHcQW5PzDGB1/irxDEfhvcw61c2Ona1e6Yz/YXn CvuYdArYbrx9cjtXc+RD5ok8pPMGcNtGeevNUPEOnT6r4d1HT7Zo0nuYGiRpMhQSO5AzigDjfDXi HTrf4Swyu1tqAsbVVu7RSsjBS+NrKCeSvQHrxnFYLadoVv4p0bVfAGtNLPd3cS3enWt1vUW/VmZf vIB3D8DOBg16lomj22iaJa6bbwxpHCgDBBwzd2PqSec1obQGLAAMepx1oA8t1fUR4C+KN3repQzL oerwqhuY0LLFIFUfMAf9gnpk7jgHBqr4g8RWPiLx94HvdK+0NZi4kVbtonRJiSmVVWwTjHJxj5u+ DXrbKGUqyhlPUEZBrzD4lztZ+NvB1yDKBHMzbYY2d2AdNwCqCx47fzoAZ431K30r4w+Fbu7u47S3 SBhJLIcKFJcckkDHPXt17UvxQ1C0g8R+Bb1riEW32t5PtBcbNm6E7t2cYxg5r1CGVZ4UlRXVXGQJ EKt+IPI/GnbVwBtHHTjpQBwHivU/B2ravaaT4gNl9kvLI3FpqfmqoU7iMCUH5RjkZ+Unjk8VF8Mr S80+61iyttUfVPDcDRpY3TkMGfblwhBI2jIHAxkcY5r0HyYgTiNBlQpwo5A6D6cn86eAAAABgdh2 oEQ3l7aadaPdX11Ba20eN808gRFycDLHgckD8a848H+INOl+J3irGp2bx37QfZGWdWWbYpGEOcE8 8ge9endRgjNYGk+G4rHxLrGuzrG93fSKsTLk+XCqKNvI4JIJOOvFAzz3TYdP07x14p0zxLqk2l2d 1P8AaYkkuRbRXiEseZMhjgMPlVgDyGHFdZ4OvJtd0bWLSLSLbTNHV3g02W2Tak0Z3AuF4zzg54B3 fjXZvGj43orAHcMjOD607OaAPMPh34nstJ8KJ4duBJJrlhNNC2mwRFpSd7N6kY55YkAdyOMw/B7U 7PT/AANe3OoX8FtbrfYMtxKERMomBuY4616dc7IbaeQIMhGY4UZPHP8AKvMvgtLC3h+8tXink33R lR2t3aEgKoyJCuzOe2c9aBC/DzXdP/4TjxXb/wBoWzC/vfNs8TKVlAZ87OeeoPAr0+aeK2gknnlS KGNSzySMFVQOpJPQVg+HPC8eiX+r6jKyyX2p3Tyuy9ETcdijj0IJ9/pUHiTxjD4b1uws9R0+caVd qRLqRH7mFycKrHoO+cn8+aBnIDxNoyfGZ9RGs6aunNp3lNdfbEaNm64zuwDnt1/OrfiJJ/DfxHs/ GOySbQrmAQXk8IMnkgrgMQOicIc+x9s3NGg/t74p6h4gs/Km0i3s1tI7kDck7kAny2HDAcgnn0r0 BgGUqwBU8EHoaBHm/jq6sPHFlY+HdAvbfULia6SWaWzmWVbWJc7nYg4HXABOT2r0SGFLe3igjG2O NAigdgBgUsUMUCbIY0jXOdqKAP0p/tTA4Hxf4n1vQfFFjbSXNpp+g3QA/tF7NpfKk/uu28KATjkg cE88ZrNVLjxb400Iw6xb6vaaRK9zcX1paGONTxtjDhyGJIyQOmOa9PZVdSrAMp6gjINIkaRoEjRU QdFUYA/CkB5jqOtW3hP4wz3+su9pp2oaesMNy6sYy6kZGe3TnHqM4zmqOr+JrS3+Jeh+KLqK9tdA Ns8Ed7LCQkhw4yFzuUEsPvDJxnGOa9cZEfG9FbacjIzg0SRpKpSVFdTg7WGRxQB5H4o8R2V98QPC GqWC3U9ohkCzW9u7NKMgNsUfMyjPUAg5OM1p+N9UtdN+I/gy7ursWcCrP5kkp2AKwUfNkjA55z0r 0rYu8PtXcBjOOcelKR7CgDzH4g6nZ2njXwDqMt5DHaefO32neNmxvKGd2QNuCOemDmk+It3FL4r8 A3NvOskD3xZZIzvVwXhwRg4Ir0uW3hmZGlijcxnchZQdp9Rnoa8x+KtxHaeIfBmAV2XjOBEpZsB4 sgKOTxnp6UAWviNpl9Y6/o3jGygkuItNYLeRRgsyxBslwARngsD+B6dH+Ndf0vxX4Om0nw7qFtqe o6iYRb29rMrOMOrkuM5QAA5LYx0r0C3nS6t0mjWQI4yBLE0bfirAEfiKWOCKEERRpGDydigZ/KgD gtbnstI0DRfBD6tapdXQitrgtMEZYAMyNgsCNwUqOcndxnFZvxTnh8O6n4f8TW1xHBfWsxhMJYAz Q4zjBYcDlf8AgfNentBE5LNGhJ7lQaDFGX3sis2Nu4qCcelMCvpmq6frVkt7pt5BdWz9HhcMAcA4 OOh5GQeRWD471nSrPwvq9jd6lZwXc9jKIreWdVkkypA2qSCefSuoSNYxhEVR6KMVn65pzapoeoWU OxJ7q2eASMOm4Ec8e9AHGaHf21x8FZ1t7uOeW20uZJFWQM0Z2thW+YlTjsTVrwHdrrHwuhs7dJ3m js3gPmQtGGJDBQGPB4xyCevOK6MQaf4W8JvGlszWGn2jFoo0DF1VSW4J5J56nkmpPDuvWnibQrbV rFJkt5wdomj2MMEg8ZI7diRQB578P/Gmn2PhKHw3cx3smvWrSwnThbsJWJckDJOFHzYyxXGPoTH8 Jr8P8PdTtHjvPMBmmV2gfayGNekmNrHOe4PtXrJjQliUXLDDHHJHoaFVVQIqgIBgKBwB6UgPN/gv qtjN4PjsVv7Z75JJJGtg481UJGCRknHI59wKqfBnU9PNtrFit5CLqS/eWO2aUGQx7RyBnJA6Z9q9 V75xzSKqqAAoAHTApgRXkbS2NxGihneJlCk4ySDxXiPg2XQbPwjqEHiW7DalYySFNF1K58tHcKGX 9yT+8LNxyG6cAd/dKQqCwJAyOhIoGZXhm+1HUvDlne6tYfYL6ZSz22CNg3HbweQduDg8jPal17Wt K0ixkXUtRsrRpon8pLm4WIyYHIGSM9R09a1R71xH/CwNLkm1rTtYhfSLu08xIo7wgNdJggNFn7xP 90Zzkdc0gMf4M6pYN4PXSpNQtTe+fIy2vnATbCAc7c7vXn/9dQ+B5ovh7quq+HPEFwllbSyG4sLy 6cRxToPlIDFsBsbTt69fat/4V6JfaJ4Lji1FHimnmadYXzmJSAApzyD8uce9dnLFHPGYpo0kjPVH UEH8DTA8/soh4m+Kya/p05m0jTLPyPtKsDFNMQ3yxkHDACTJbkZGK9CFIqhVCqAFUYAAwAPSnUCP M7Hxprn9s6lpXiHVtA0Ce1f9y1zZuq3CZI3IzzqGHA6f/Wqbwlb6k2o+JvFxj+2/ak22CJE0Iugi /eRWZiqsQAM9evevQpIYpXR5Ikdk+6WUEr9PSnd6LAcJp3xM0e98Mz3WptFY6nH5kcuktLi4Lg4C KnDknI7DnPTFYWneEtW0z4JanYS27vqF2pufsyqd8S5T5OSckKhOOOTjryfVRFGJfN8tPM6b9ozj 60/pzQB5NpPjfRJ/hUulWs9xe6hFpDQzW8ELbosREMzE4UKB33c9snirHhy6fVvgldWFks818ljO rL5cqbixZhtYj5sqR0JznFemC2txFLEIIhHKSZFCDDk9cjvnvmpaLAeKaXrGjW3w902+e5/t3WbZ 0W20ee7I8mQORgQqOSBuO5wTjuBxXR/EvXIn+GNxaX1xa2Wt3Vvbytp5ul85SZELADOWAwwyPQ16 GtvAkzzJDEs0hBeQIAzEDAyep44rH8YaA3iXw1caVE0SNPJCWd8j5FlR2GRznapx057jrQBzX/CT aJF8M9FmvEs9Q01ltbO+XIdYMoMkgZwVIBx1HXqKxNKsrXQPiFpUXgTW477TL8ub+xW7+0RQRrj5 sjOOM7cnOQBkgnHq8Fla2tpBawwIsFuoWJMZCADAxn24p8NvDBuEMUcQdizeWgXcx6k46mgDzbX9 Vt9M+OWkPdPIIzpflqscTyEszSYwq89cDIB7fhpeM7vwpqGsDw74lFpBvtBcW93PP5JQlnVhv4x9 1SAThucjiti/8U6TpnjCz0KS3nOq30IMcqQgqVy+FZs5xkMcAEDOeK3fs0LxlZY45N3D70B3fX8z +dAHmngca1p9r4ntNHv49W0/T0EWkzTDeskgQtsUhhlRwpxgZ6HrUmk/EC5vNEN3qviPRNKv4maO 402TT3FwjAnAVGm3EkY/hPp616YAFAVQAB0A7UxYIEmaZYY1lb7zhAGP1NFgPNPCviCw+HvhjTLL xTLNZXWpyTXUcf2Vz5QLDCEDcd3IOO2cEcZLfhrq0c/jHxbFJDcwTXV2ZkikgfKAM5Ic8qpG5eCR 1716iyqxViASvQkdKakaRoyxoqKWLEKMZJOSfqSSaAH0lAoNABRjFBooADwKKD0pKAClNJ3paYAK O9FBpAFHegcijvQAAUUooHWgBtLR0NLxigBKKB1ooAKKCKPWmAetBGDR0zS0AJ9KX0oNApAIetA6 0vek9qAF70nelpKADvRnBpR1FJ3oADQB1oNKvegBw6UUDpRSKOb8Lkf2BZYU/wCr54963149awvC px4dsgB/yz/rW8oIABOTjrTIFpeooFH40DE70pzSH2oPNAC9qTtS/jSUAGaD60GjHFABQKO1FMAF B5FLSZ4pAJS0UH0pgFHajFJ2FAC4yKMUdaO9ABjmjtS5pKQAM0Cl70nSgApT1FIKXmgBMUe9Hfmi gAo70Ud6AFH6UfTpQelIOlAAKXvSc0DmgAxRR2rDi8Z+GpdTGmx63ZNel/LEPmfNv/u/X2oA3O1F UdQ1vStI2f2nqdlZb/ufap1i3fTcRmorjxHolpbw3Fzq9hDBNny5pLhVR/oxODQBpnpSn7tY9x4q 8P2lgl9PrVhHaSNsjmM67HPopz83XtWnDNDc28c8EqSwyKHjkjYMrqeQQR1BoAk7UHpTZZY4YWlm kWOJFLO7nAUDkkk9BWBF468LzFca3axh/wDVtOTEsnT7hcAP1/hzQB0PegdazLrxHoVjdG1vNb02 2uB/yxmukR/T7pOa0kdXQOjBkYZBByCKAHZ5oPWqWqatp2iWhu9TvYLS3H8czhQT6D1P0qpo/inQ vELyR6TqttdyRjc6Rt8wHTODzj3oA1+tHrWVrXibRPDqx/2vqdtZmXPlrK/zNjrgdTT9N8QaPrFh Le6dqMF1bxZ8x4m3bMc8jqKANLPIpfWsq08S6FqE/k2OsWN5KASY7adZWUDqSFJIHuaLfxLoN5cv bWutafPOmS8cVwrMgHUsAeAPegDUxxQKwR438LG3uJxr+nGG3cJK4nXAY5wB69D0z0NS2vi3w9ea ZPqVvrVi9lBgTTCdQsfpuz0z2z1oA2e9FZuja/pHiCF59I1G3vI0OH8lwSp7ZHUdD1qm/jXw6jzA 6mnlQSeXNcLG5gibptaULsU59WoA3uetHeqsGqWFxpS6nFeQtYtH5ouN4CbPXPYVhr8QvCjOoOsx RozbEmljeOJznHyyMoQ/gaAOm5BzSnpWTrPifRPD9pHc6rqltbRSjMe58tIOOVUZLdR0B61TvfHf hfTb2O0vNatoZ5FVgH3YAbBGTjCnBBwSOOelAHRUVUv9TstLsJL6+uore1QAtLI2F56fXPYDrWXB 4z0Ce+gsjfNBdXBAghubaWBpc9NokUZ+ooA3hRzmgc1iDxl4ae8urQa7YedaKXnBmAEYBAOT04JG eeKANvPaisfRvFeg+IpJI9I1W2u5YhueNG+YDOM4POM961ZpVhheVwxVASdiFjj2AyT+FAD6Kwz4 v0Bb4WB1OH7cTgWmG87Pp5eN2e+MVoalqljpFk17qFylvbrgF37k9AB1JPoOaALnegVhaf4x8Pap qA0+11OM3hGVt5UaKRh7K4BPQ9PStygQtHes/V9d0nQbUXOrahbWcTHCmZwNx9AOp/Cq+i+KtC8R tKukapb3bxDLohIYD1wcHHv0oGbHelFY+s+KtC8PSRpq+qW9o8gyiSN8xHrgc4461YtNd0q/0s6n Z38E9kM7po2yq4659Md89KANDrRisyy8R6JqRkGn6tZ3hiXdJ9lmEuwep25x+PofSo7XxT4fvp5I bPW9PuJI0LyCG4V9ijqWIPA+tAGx0pCawl8a+F3s5rtfEOmm3hbY7i4XAJ6Dr3/WrMPiTQ7jRpNX i1azfTojiS5Ey7EPHBPY8jg88j1oGafalqlper6brlkLvS72C7tyxXzIXDAMOoPoazZfG3hqGSRZ dXgRI5DE8zBhCrjqplxsz7ZoEb+eaWsmXxNoVtaW15cavZQWt0m+CaaZY0kHszYH4devpVhtY02P S31N76BbBV3G5LgR47EN0IORjHXIxQMu/Wj2rBh8aeHJrqK1GqwpczFBDDMGieXecKUVgCwJPBGR VjWPFGheH2RdW1W0tHcbljkkG8j1C9ccHnFAjVo96p6Xq2na1Z/a9MvYLu33FTJC4YAjsfQ/41Be +JNC065+zXutada3GM+VPdIj4zgfKTnrxQBp0elMhmjuIllhcPGwyrA8EetU9W1vS9CtftOq38Fn D2aZwNx9AOp69qANA9KSszSPEejeIEkbStStrvyziRYnyyemV6j8qa3ijw+t59jOuaaLvO3yDdIJ AfTbnOaQGrRWVeeJ9B01il/rNhaOM/JcXCxtwcHgkEjPFTT65pNraJd3OpWkFq33Z5ZlRD/wInHf 8aYGhRVWx1Kw1SHztPvba7i/56W8qyL+YOKy4vG3hefU102HX9Pe7ZgixrODlj0UHoTnjGc5oA3u 1HeoLy9tdOs3u765itraPG+WZwqLk4GSeByRWVpPjDw7r12bXS9YtbqcLu8tH+Yj1APX8KANykV0 fO1lODg4OefSqmpatYaLafatRu47aDcFDSHqx6ADqT7CvIfiZfeH9S1bRZLM2ouBcEXaTWxicglN pkDKGKcN1BFAHtQORkEEHpS1l3uraP4dit7aaWO2Dgrb20MRZmA67I0BJAyOg703TPE+iazctbaf qUE9wqlmhBw64ODlTyCD1B5pDNaiisPUPGXhvSdQ+wahrdlbXXGY5JQCufX0/GgDc7UlUrvWdNsL KO9u7+3htJACtxJIBGQeh3dMH61Xh8S6Lc6e2oQ6nbvZLndcq37pcHBy/Qc+/cetAGqKDWP/AMJZ 4e+wy3w1vT2s4vv3C3CmMH03A43e3X2q1pesadrdmLzTL2C7tycb4XDAH0PofY0AXqSoby5Wzsri 6ZGdYI2kKoMs20E4HvxXJ+BfENtr6PPJ4gjvtTkiEs1nCdsdsp6Kq4ycdCcnn8KYjsu1Fc/J448N xs4OqIYkcRvcrG7W6MeMNMF8tT9WqS88Z+GrCyt7y61uyiguVDwsZRmRT3Cjkj3xQBuevakrBufG 3hm01gaRc61axX+QpidsYJ6AnoDyOM1d1DX9I0lwmp6la2W4ZVrmQRK30ZsAn2BzQBpZ5orLn8Sa Ja20dzc6tZwW0v8Aq55pQkb/AO6xwD+B6c1bsNQtNTtVurG4S4gYnbIhyrfQ9x70AWaKx5/Ffh20 uGt7vXdNtp1OGhuLpI3B/wB1iD/jWpDPFcxiSFw6Hoy9DSAlopKzbXxFo19qdxptrqdrNe23+tgS QFlx149uh9O9MDTNFZKeKfD8tvdXEeuac8NoQLiRblCsWeBuOeMkEfgas6ZrOma1btcaXf297Crb GeCQOA3oSKQy6aTAznuOlYDeOPDCORJrVrGmSomkYrExGcgSEbCeDwDWnNq2nW+nx6hPf20NlIoZ biWUIhB6HceOaYi7RVHT9a0rVgx03U7O9C9TbTrIB9SpNZn/AAnfhT7a1mfEOnCdWKlWnAAYHGMn jPHTNIZ0OKTtS5zVSDU7K41C5sIbmJ7u2CmaEH5kDDIJHoaYi5SYopskkcMbSSuscajLO5wFHqTS GOoFYemeMvDesXgtNP1q0nuG+7Gr/M2PTPX8K077ULPTLR7u/uoba3T70kzhV9hz39qYFkgEHPek ACrtAAHYCqGk69pOuwvLpWo214qY3+TIGKZ6ZHUdD1qOTxNoEV4bOTXNMS6DBPJa7jD7j0G3Oc+1 IDUNIQCCCMgjkGgMpTcGG3Gc54xVbTtTstXskvdOuorm2fIWSJsjjrTEWqQ9KWsu98R6Jp13HaXm rWUFzIwVYnnUPn6ZyB7nikBp0ViaZ4w8N6zdm007W7G5uB/yzjlBJ+nr+FWLrxJoVjdfZbzWtOtr j/nlNdIjfkTmmBp0Vl3fiXQbBkF5rWnWxcbkE1yibh0yMnmhvEehx3EFu+tacs85Ahja6QNJk4G0 ZyeeOKANSisy38RaJdaidOt9YsJr0FgbeO4RpAV6jaDnjBzWn2oAKK4u/wDE8Q8cNpN5rKaVbW6x eXEQA95I+f4mBwg4HGCT34rrL+9i07Trm+nOIreJpXPsoyaQFjGaY0UbSrK0aGRAQrlRlQeuD2rz vQ/BR8RSab4t1vVNTGoSOLtLaOfEUaE7kjwVzgDrjGcmu2OvaMNUGmHVrEagTtFr9oTzc4zjZnPS mBo0Vm33iHRdLuBb6hq9haTEAiO4uEjYg+gYjNXYLiC7gWe3mSWF/uyI25W+hHWgCSiqtpqVjfXF 1Ba3UU01o/l3EaNlo27AjtUd/rWlaTj+0tTsrPd937TcLHn6biPQ0AXs80e9Zz6/o0enjUX1awWx LBRcm4QREnp82cVbtLy2v7WK6s7iG4t5RmOWJw6t24I4NAE/Bo/HNYZ8Z+Gk1JtOfXbBLtWCmN5g vzHoMnjPtmr2p6zpmi2zXGpX9vaRKMlpZAufoOpPsKAL1GKwrnxp4Zs7+GyuNdsY7mZVZI2lHIbl TnoMggjPY1oajrOl6Pa/adS1G1tIezzShc9+M9TweBQBeozzXNP8QPCEVwkD+I9OEjqGA88EYPTJ 6A+x5rXvda0rTYEnvtTs7WGQApJPOqKwPTBJwaALx4NJ3rLbxNoK2X246zYfY8gfaPtCmPJOB82c dat2epWGpW32mxvra6gx/rYJldPzBx2oAtUdq5z/AIT3wn54hPiCwBLFA5lxGWHbf93P410PmIYf N3r5e3dvzxjrnPpQA40grDtPGXhq/wBQWxtNd0+e5Ztixxzg7j6A9CfpW4elACUtFVrTULK+e4S0 uoZ3tpDFMsbgmNx1Vh2NAFnFHeqttqVjeXV1bW13DNPaMEuI0cFoiRkBh2qW4uYLO3e4upo4IIxu eWVwqqPUk8AUASUVh6b4z8NavepZ2OtWc1y4ykW/azjr8oON3HPHaruoa5pGkuqalqtjZM4youbh Iyw9txGaBF+iq9lf2eowCexu4LqE9JYJA6n8RxTNQ1XTdJjWXUtRtLKNzhWuZljDH2LEZoAt0vas q58TaBZyRR3OuaZC8yq8ayXcal1boRk8g9j3rUVldAykFSMgg5BFMYtNZsHaoy3YVV1HVLDSbY3G oXlvaxZA8y4lWNcnoMk+x468VDo+taTrUTy6XqdpfbceYYJQxTOcZAOV6HAPpSAvCJfNErANIMhW 2/dB6gfkM1J7VHPPDa28txPIsUMSl5Hc4VFAyST2AFJbXMF5bRXNrMk0Eqh45Y2DK6noQR1FAEva iqJ1nShfvYnVLIXcaGR7c3CeYqjqxXOQB61FaeI9C1ETNZa1p1yIV3SmG6R9i9MnB4FAGnQOlZdt 4n8P3rlLTXdMuGUbisV3G5A9eD0pLfxR4evLgWttr2lz3BO0RRXkbPnOMYBz1oA1aO1FFAAeaOlH tQRQAnailoNMApDS96DQAUUUZpAFGaBRQAtIKBxSjrQAme1FKOtGRQAgoOKO9LQAnfmlx1pCfajI J4IP9KADBo6Gig84pgFAo70o60gEPWlpO9FABRRiigBRxSe1LSUAHel6ZpDSjgGgBw6UUDpRSKOa 8Kc+HbPAyNn9a6FSccjFc54SAbQLTI4C9Me9dGMCmQh1J1pRSGgYdKXPWkI70vegApKUUmKAA0E0 UnamAvako7UdqAFFBoHWg0AFB60h60uKAA5o470d6DSAOKKKM0wCgDigUUAKOtGM0mcfWl5zSAO9 JSgUlAB3o7UlLTEL2pO+KXtSDrSGL2pOopT0pKADvRQOtFAGX4g0xtZ0iTTvtjWsVxmOZkxuZCCC oz6nGfbIrlPGXw98O3/he7XT9NtLK8t4meFrSFVZyq52sF5YHA9TnFdJ4r8N2/izQJdLuJXhDMJE kUA7XHTIPBHtXHWvw9ul0OHR59B8KCVV8qXVhbh5TH0DLGYh+9x3LEA8/NyKBo57xbfXeq/Bjw5e 3skrzm8jViQFL4WRckd+n4113xaL/wDCsrkuQrb4NwRiR94d+Mir/ifwNHqvgSHw7pcqWpsxGbRp VDLuQEDfx3yckDPOeelcn8QU8XnwDenX59JgjRolRdNL/vG3cl2ccLgcKoznqccUgN7xHplpc/C6 W/ms4p7yPRVWKZ0LMmEB+Xd905/E8ZzitX4cjHw90THKm3Bz3ySc+v8AP8qzfGMmov8ADicW9vZr p7aWGne4uGSWP5AcKqIynt3HP51c+Go1RPBNjDqNkLRIkCW4Zj5jx5OGZSo29sDnjrTEWfiBod94 i8GXunadIVuH2sE3bfNCkEpn3A/PGeK4rT/Fdl4o0+18H+KbKXRNXAiNuZ4DErSq3yFAeh4x2B5A POK9C8VWOp6l4ZvbXRro22ouo8iUStHtYMD95eRkAj8awdW8P654oGk2+s2Wl25srmO4lvLa5eRy V5IiDRjbuI5ByAPU9ADJ8Wbv+FyeGBvKFoV5BxnDSHH0PSvTRnvXEeJfCmtap490jXNMubKCKyiC u1yGc53MThFxnhu7Cu1j8wRqJGVnAG4qu0E9yBk4/M0Ac/e+GtP1PxLJqmrm2vYYLdYYLOdQ8cPJ ZpCrZG88DOBwBXn/AIw0qy8LeMvD+veHDDAJ7tbaa3tYQ6AtgcIuB8wPIyMnBHNdJ4y+Hn9t+I7L xHp62Et/AFjltNRTdb3EYz1wCQcE9iOnpViw8C27eILLVrvSdG0xbBi9va6XGDvcjG+SQomcdlCj B5yelFhmrB4Q0+W+v77WbSy1O7upiyyXFur+VEAAsa7s4AxnjqSTXDaFYP4S+NN1pGmJjTtQtDOI iPlQ8kDOflAKtjg8HGO46lvD3iHTPGtzrum6l/aFneRMkun6hdvGkLZBUx7UYYGCMbcjJ5OavaL4 akg1y68R6s0Mus3UYhxCMxW8Q6IhIDEnuxxn0HSkByfwpRk8ReNVZjvTUSrZAOTvk5zknsaXw1YR XfxW8bQXkImt2SMNFLEGRw2Dg9iOOh6/gauab4S8UeG/E2szaFPo503VZ/tDNeCQywMWJOFXAYfM wALDoOR0Nrw14M1fQvFusau+rW80OoSqXWaIySuo5zuXYqHJbgKwAx1oA5HwtcaNoXxJ8WtNZLLc QTYsILa182QctlYlUEjjAOMAdyBXR+BvA8llc6prOtabbJNqF158NgyrILUByynPI35Y9OmBz6XL LwvrXh7xjq+raO9hd2erfvJobyV4XilyT8pRGBXk9QD78czeHPC2reFtHvmt72HUNXvrj7RL9qkd IFYnkLgM3c9evHSgDl/h3ZNN4m+IVmHERe5eEbU4XLSgEfT0qn4c8Q3/AMOrA+GfFugzR6buKRX9 vEXjffnO49GJ9BzjqK0Phjaa5H4n8S3bW9oum3N9IZpwGAlkV5OIR/dBbkn0x9Nm28OeKm8IzeGt R/sW8hkRo0u5ppZGjQnIzGU+YqCcHcMYX0oA5/xpClroPgzw1Zah/wASW+uUja4jTIliyNgO35WB DZPrjNdV8UkCfDfUlQIiIIsLjgASLwB9Kb4i+HdrrfhjStLhvp7a50iJEs7kAHlVC/OMcg7QeMc/ lXOeNrPxcvw81E+I9VsHjiSNQumwENO3mKN0hcfjhAvPfFAFXxzGsXwK0Hyo0CiO1YYj2kZiJJ29 j6/jW74506ysfhBcw2thBDF5cEhWOJV+YsgLd/mx35PvVnVfCjeMPhhoul292lowt7aVZHi3DAjx jaD6H1rT13w9qfiHwLcaHdTWcN5IqIJY9zRnaVOcEAjODxz9aBHKa54Z1bXvhh4WfSlimubCK3uf sxG1Zl8scYPBIOODjPPIq3pPi/TvGOr6bpmsadLpHiCwnW4jt7uI/MwU5CZxjIJOCPcZxkas+geJ z4a0exgu9OTUNLuIHjuC8nlzJGhU71C5yc4IB75yOlWn0DU9W8R6NrGrJY2r6WJCq2krTGZnG3BL Iu1QOccnJ6jGSDOp4IIPI714/qFtoumfGqOO7trWPT49PR4bcWnmAychQkYGd2SSNoJz9a9grktQ 8NalD45j8U6NLaySyWv2S6tbpjGrpnIZXVWIbIHUHpTEjO0Xw/fah8Q7rxlcWh062aHyLe3mT99K MAGRwD8hwOAecYziu+zXM6H4bu7PxLqniDUL0Pc34VBawFvJhRcActyzcDnC9+K37z7ULSU2Swtc 4/didiqE+5AJA+goA84hiP8Aw0DdMvlnGnh/nHIyqjg9j/Qn1qLxHdyXvxw8PaZcZ+y2sXnQo/zI ZSrsHx6jaAD2xVezXxAfjJqrwxacNRGmr5itJIYApMY4ON2eB29fTnrvEvg99Y1Gw17T7lLXXtPX 9zI4LQyjk7HHXbktyOcMetIDB+M+lef4Yt9Zj+W4064U+YDhlRjjg4zw209R3Nd5ot1Pe6Fp93cD E09tHK42bcMygkYyccnpk1zGseFtX8Yx2Np4jexttPt5BNNDYSPI1y4BA+Z1XYvJ4wx5612i4CgA YAGAB0pgc3e6PpFz4kn1DWrmwutkKRW1pdhCtsPvMwDE/M3c4HCiuK1fS9K0f4leF9X8PvbRpfT/ AGeaCz2FB0yQF4GQ3P0z1rd8WeAJNV8U2XifShYPfw4Se11JN0EygEA8KSGwcdxwD25u6Z4LjHiC 11i+0/SLF7Iv9ltdMiwuWGN0jlVLkDoAoAOevZAXrXwfp8txe3uuWVjqd9eSlnkmtw4SMcJGobOA oA6YycnrXI+BdHbwx8TfEWi2m77A1vHcRhlwACwIGfUbmHvt9q3otA8S6L4nv9S07UhqtjeqSbPU 72SMW8mQcptRxt6jAC4GBzitLw54cbTL2/1jUZI7jWdSKm5liGI0VRhY4887QMcnknk+wM574RxA aLq8wKMX1WZCdmGwuMAnuOcgdsn1rJ+Gun22p6343iv7eK4ja/CPFOgYbRJIVGCOV4HB44Fa+h+F fF3hm+vrTStQ0Y6Nd3bXPmXMcjTxbhyFQYU9FAy2OM45xVjwP4M1nwvq2sXV1qdrNb39wZfKWNmc gMxDFvlVWIbnCnpwaAOL+HN9o2n6l4huru3jvNT+2MlpbRWokuiPmDBB1CnIBzhRjk10/gLwDLpF rcy61Y2bi7uBcR2kmH+y4zgYxtJGexwMDFXNC8Ma/wCD7/WRpP2C/wBP1C4+0xR3Nw8DW7knIwsb AjGORg/KOKuaB4f1vwr4dW1tLiDVb6a5a4umvrmSNF3KAVjIV2wMDGfc8ZwCwHJ/DvTrrUfh74qt LVooLi6uriGN1BUq5jXALD+HkYx05qloviVPCegP4N8baJcafZkSQR3q25eCQEEnJH3jzwVz2yAQ TWt8G31Q6JeRNpyR6XJcySpeNMR5jkKpVExnaCp+YnqfY1oy+G/FereBl8Ma0ukSsyLE+orcySMi g8MIzGMuBgD5hk8k9qAKXxB0+DR/g5bWMTx3EVr9nSOeNduQCMSDBxkjv7k1Z8ZaDreq+CdDfSIo LibTmiuWsnGY7hVTgFeAecfL05PPArZ8YeEptf8ABKeH7OZFdDCqzXDHhUIyTgcnAPHHJ6irl3p/ iAeFo7WzvbF9XheFkkMbwQOEdSVYAu2CoIODzntQBydr4n0fx5qWnaZqttPo+vafdx3UdvdRlWZl wSq5AyGGflODxkZxXRweE9Hmub6912PT9Wvbudm825hRvKjBwkSBs4CgdupyTzUMugajruv6Nqmr 2tnZSaUzPvtJzI8zkYC5KLtj5Y4JJPHArEm+G32DxjfazZ6VomrWN+S81lqSBWhkJzujbY4xkkng cetAFfwhpyeF/itq2i6e0r6bc2IvEDEEL8y4wfQFmHr0z0zVv4kpnxP4IZdizNqQUEpu/jjI9OAe 2R1rR03wddaRbatqemwaTYa/exCOKK3jxaQBT8oGFDHPBZscnGBxWXqPhPxprl54e1LUdR0mO9sL jzHihjcwRAFWDbc7pHJUA/MoHbHJLEekDOeQPzrCuPCtlqHiKfV9Tihvh5KQ28E8QdIACSSA2RuL HrjoBW3EsghQTOjyhQHZFKqW7kAk4Htk/U1yusaFr6+LrTX9G1NpIFTy7nS7m6eOGQYIDJtBG7kd R26igDl73R18JfF/Q5tHiFrY6wjRSwQoAhK8sMdhyrcAc/jVmTI+Pm6Pyg/9lg4k/iPtgHBx344B FdLZeHru88SReIteFsLu2hMNnaW7GSO3ViCzl2UFnPTOAAOOetZ8/hbW/wDhZsviWyutPgtGs1tz 50bSu3rhQVxyBzu/CkBl/F5S6+GVDhA+prHuIzjOOeOvTpW78TS//CttXJA3BI2IB6YkQ1yvxJbX J9R8ORXNpYxIdVUWxt7yRmdtyhd+YhsHTpu+hxXYeJdI1rxL4Fv9LdLG21K5wFCTu8QAkB5YoD90 f3etMZBo2jNqvw40XTftPlWkttbvMyAq7xYDlAVI2k8AtzwW7nIy/iB4C8PyeCr+ex0uzsLiyhae OW2hWMkKMlW2jJBGfx5rW/4RjWp/Ai6DNri2t7FDFHBeaekkJj2AdTvy2cYJG3r0qsdE8V6t4Zh8 O6xNYQwNEsF7qFvdSSzzxgYO1WjAVmHBZiep4ORhAV/Denx+KvDXhq/15oLizt7PKWk6cSy8KJHB JDYAwOOrbuDgDlvidoelaCbDxR4aW0tLq0uVWWO1ChAeSrFV4B3DB45zz0rrfGXw6g17TtKOmC0i vdJVUtUvIhJBJGNvySDB4+X09fWmp4Bg1DULSS/0Dw7ptnaukxj02IO88i9nYxJiP/ZAJOBk9qYG c7y678b7SG7VfI0zThcwQyHK72xlgCPvZYf98A0nxUtVl8QeDpdqeZJqCwHcu4MDJGRkdx149zWp 4n8F6tceKrTxT4av7eDU4hslhvd3kSLtK5+UZzjAP0B4I5oaz4P8Y+IJdF1C91PTItRs7kSmKFX+ zQqCGUhCN0jEqMksAOMY5JQEfipdf8L+Pz4us9MfVdPntVtZooEZ5YVBycAdBxndyOSDjg1r+FL7 w94q8TXHinR7pvtRs1tbq0kQLInzbgzD1425GQcDnitS/tvE8OtWl9pzWF1AtqYru3nmkgEj5BDo ArhT1HOeDjPek0Dw7NZeINX168WGG71Iopt7Zy0aIgwCSVG5z1Jx6DnGSAbl8k8mn3KW1yttO0bC Odk3iJscNjjOOuK5R/AXhQ6CtjcRWhndQTqW1BcSSHJ8zf1JJJPORziutvLWG/sp7O5QPBPG0cik dVYYIrzXR/hrc6BBd2EWj+GNXhaTfa3uowfvYgQMq6iM78dsMvfkcCgDN8Om5T4PeK9OuGaRNNlu IIiy4+6A3Y56nPt/Le8ICRPgt8so2mwuHSRcowJMh5+nqPyroLTwbYWngy58NROVhuY5FlmVQCXf O5go4HJ4HYACuRk0Lxdo3gW80e/v9MTRrKznzPZq/wBpmQKSqcgKuSeTye3uQDQ+FNjbXnw80d7i 3jlEUsskRdPuv5jjOOhOO/8A+uqnwhgEKeJAuwBdTaPYBjaFz26457+9XPh2+qJ8L9HbSre1ll8y UFbyZohs81+hVG5zjtVT4TW+qwjWpJbGGLTp72V0m3tueQNtIUFRlBg/Mcc9vRiPS8Vz9x4R02HT NXi0WztdOvdRt3ja4ijCncwOCcdsnPFdBSH7pzSA8c8P+I7jwLpaeFPGOhSwad5jwrfpEWgdGySG YfePXpzjGQME0fEnTLTTPhx4dtLWRLiBJo4kuYVCmRNjFSMcHOc/jmunfw74qvvBb+GtVGk3e+Mx LqDzyO6L/CxjMfzOB33DJ9Kk8XeCLrVvDWjaVpFzAjaXJGyNeE/OqLtAJVTyeM8UDMf4q6fBpvwz NtBY28MUdzEdsKYGTncTjue5yT9apfFUMvgDw2WlDMssY3qSoJ8o8iur8beGtW8ZeDhpxNjZ3xnS UjzXkjAGejbAc4P92o/E/hPU/FPgmHSZpbSwvrZ0kiaGRpI3ZFKjJKqVByegOOOtAGZ8XhKvw7xP tylzDv8ALPy9CDjpjn2ruNEWRNC05WKsVtYhlRgfcFeVfExPFEngEv4ll0yIJPEI4tPDMXfDZZ2c cDGcBe/evWLC4iNraQFwk7WyyCFmG8LgAnHsTjNMR5t8QYV/4Wp4TkPBkMa89CVmz/X+VerjJHzY z7V5Z48UL8VvBshy2XVdox/z0HP6/pXp8lxBDLFFLNGkkzFYkZgC7AEkKO5wCeOwNICbtWQnhfQo 7m+uE0m0E1+Cty3lj96D1B9ieSB175rW9KDTA8U8OzaHovxP8TzXUNqBbSYs7dIgZC27pDGB8zDp wOM9ua19D8B6g2jeK7lLcaXLrcckdnp7EL5MeWKb9vCk7sYBOB1rcs/DWteH/HGr61pyWl9ZartL RSzmGSF88n7rAr19+nHerWi+F9X0/Q9cS61aSXU9UaaRCLiRo7UsDtCE8jBPLAA8DjikM4vS/FNj F4cHgLxnp50WXyDapLKhETL0VwTkZzzu+7kZyK9D1i2Nh8P7+1jk3m30uRA6jG7bERn9K56/8O+J fEvhGDw9rlnpizBIhJqaXbSMu0jcyqYwfMIBH3scnkjip9Z0jxvfz6ppVtd6VDoM1uY4JNsn2lRs xszkjk8Fjng5AzxQBneB9JOr/BzT9OW+FrFeSSieVQd7R+e+5AcjBYDbnngnir3i/wAA+GLvwvfR 2Ol2NneW1u0kElrGkbgqM4OMZBxg59T35qHTPh/qM/w3bwrrl5ZBSN0LWsJZoX8wyZZmOH5JBAVe CRnnNVLP4fXZ0FdGvPDvhQTBRC+rRxAymPoXVDF/rcdy2MkHnpTA2fAmuMnwssdW1H5Y7W1cs20g mOMsAeepKqOe9cZpy6j4R8XaH4gvi2zxHEy3hmXiGaRt4QnPygZQZOeFbjtXb6t4Yvo9B03w7oVv Y/2PDJGblbu5dXljVwxTiNh8x6k9QSMc074geG9R8WeHYrCzS0S5WVJvNluXjETD02xsWyCw/h7H 2pAdeM45xWNr+hw68bKC9nH9nwy+dPakfLckfdVueVBOSCDkgVY0NdVj0mCLWVtvtkaBHe2maRZM DG7LKpBPpz9TWH8QPBh8ZaNFBDOkF5ayebA8i7kJxgqwweD9D06GgDlfib4N0uw0P/hIdDgg0+80 1kZks4lRWG8AHCjhlJBz6Zz2x1NvoCeKLjStb11ba8t0sUMNk8e6MSuqs8jA8E9hxwKyT4AXVora 11Dw54c0qBSDdTaYgM0+3+FD5S+WjdzknGR3zWt4i8P67Jrulav4f1Joks/km0ua5eK2nj7YCggN yRyCPu9McsDj9a0ePwZ8VdBvNH2W1vq0vkvbIpCD5lDgADgHcDjsR6Vp6kSfjrogdUMh08nbuOA2 2Xp+vauht/D17qviaDX9fSCNrNNlhZQTGRYycFpHJABfOAMDAx1ParqnhjWrr4jWniCxuLGG3gtP JJuFeRsnfnailexHJb8DQBpeMbmQ6XDpFuzLd6vMLONk6opBMj+vyoGP1xXK/DaSbQdf13wdcb/9 GkNzal8/NEcDjtjBU8dyfw6gaZrUvjkarcxWDabDbG3tlFy5kjLHLSbDHjccKvDcAdTWTr/h3xLP 46sfEejLpkYtYvJkWa7kDXEeSSpAjIXqccnnB7UgO6ryXx7p9mPif4UEdjbb7mXdMPKH74h1xvx1 wM8mvVojK0KNMiJIR8yo+4A+gJAz+QrzD4htdf8ACyvCAsNjXY3GNJWwh+cdSASAQDzg496BDfjF o9rBolr4jgiWDULKZFEkTBeCcg9iSGHGPU/g/wAaBr7xJ8O7m6gjE01zmQBeM/u2wc++eM8c9a6L U9B1XxXd6emtQ2lnpdrKLl7eC4M0k0qnCqxaML5eMk9zkdKXxx4a1HWzpOoaRJbLqelXPnxLckiO QHG5TgH+6uP6UAYPxYjaZ/ColVMNqSowJJTJ28E4z6/rWZ8U7LTrXxJ4bnntbaIXV2zXczEKrqGi ++3XAGfYAmtrxD4W8W+JP7Gubi7062ubS7EzQRu7W8ajkEggNI+RjqowePWtTxb4V1PW49Gvra7t W1bSpxMAytFDOMqSuMuV+6uM7qYznr/RIvFPibQJ/DenR2VhpTb5b+KLyoJVDKQkJABkA+fDAbfm PPNeo1yf9ka7rXibTNW1GRtKtbBGIs7W9aQzyNj/AFnyhdoAx3J9q62gRlXvhrRdR1aDVbzToZr6 32+VMwOVwcj2OCe9YXjkPrktj4PtZvKm1LdNcygbjDbx85x/tPtUfj6V2R6VzGi6XrUXizVdX1WL T/LuooorfyLh3eFEz8uGjUclskg9e1IDH+Fuo3I0zUPDV8gF5oU/kMR0ZGLFTn6q34YrA8b6TZaX 458FW2n2sFtGbkYVRtDMJVPLYJPLHk5610s/h/xJD8Rm8R6fFpKWkkAtp4ZLuVXnUE/OcRYDD5cd eBjPPHN+ObjW/wDhP/C7HSbaa7hkd4La2unl81Q65LkxqE6Zz8wGCaBl/wCK0Zm13wYmUUSX5X5u gJaL2Pv2rvfEGrJoeg32puob7PEWRD/G/RV/FiB+Ncx4y8Ma74ju/DdzZy2VtLYTGa48x3eMNlGG AAC4yp67fw7X9Z0vxBqV/oytHpU9jaTrcXW6aSJpnUHbtTa4CqxDYLHJUdKBHF+H7e68DfEe3s9V v3kTXrXfJJI3DXWckenDEgezCuh+L67vh3eHaG2TRNlj935wM/rVjx/4a1fxLFYLpC2MVxZ3C3Ed zczupUjsFWNgeQp5PbpR4v0TX/FPgeXTGh0+DUZZYiRHdO8WFYEncUBHTOMH60AFtomm3/gTT5rq 0iu5Y9I2QSSjzNoaMHIBOM8Lz7da574c6fd6t8JhYQXK2yXFxKjyqSWWIsN4Hox5GewOfSulktfE Wm+DFspF0m7litTHPJ50kARBGB8vyvvbhuTtHTiuZ8AadrWr/CltKUz6OjhmstQjnZZmJk35CAAq h6Z3ZIzjg5oA1vGHw80CXwhd/wBm6Xb2F1ZwtLDJbRbWbaCdrY5YHnrk85rjvEJF/wDATSr+4tIn uIQkUU7oDIirIVGD2BUDnNdxa6V4yufDC+HtSaxUtF9nuNV+2PNLJGepRDGMtg7csRzz81S+LfBE mp/D+PwzobQQCExiM3DlVIU8liqnJPXpyaYGZ4q0HTbf4OXMMFtboI7WG4EkUfLyDad+cZJPIz6G sPxTbxyfAXS7qSC3MkMFqY5SuXUEgEKTyOuOvTNdtrGhaxrfw/utElSxt794o4o2Fy8kZ2lDuLGM EHg/wntz6cn42sdR0f4MxaZqK28bWrW0O6znZxKA3JIZFI6ZxzQM6eXwxp+ofC6HSjbwBBYpLG0a KuJQgbeOwJPU9wT6155p2oXWofs/6utw8ksdncpFbFhlggeJgMjsNx5PQfSu9s7fxfqXgy20uaPS onuLNYnvxO7YiZcZ8rYP3m3/AGtuef8AZq/feBrGT4fzeE7F5IIfKAjlJG5pAwcM5A5ywG7joTjH FIDLKKPgRIMl1GhOwLcnPlEj8v6Vzviq5lsPgbolvDK1vBeJbRSyx5DCMqXbOOmcYOOuT61uQeHP G0/gyTw5eXOjW8CWD2qSW7O0kzYIQMWTCqRgMQCTg4xni/8A8ILNqXgCPwxrt/FJ5KotvPaQlWi2 fdJLE7j2PC8E/WmBr6n4a0+98Ivon2ZPs8cG23UJgowHysPRs81wHw3tJPFvw3OjXc7rZ218FlCu SZohh/Kzn5VJIH0z611lvB43tdD/ALIaLS7q5WAwxao17ImcDAd02E78YPDHJzyKJfA0lr4Ci8Oa Jrd5p88LCQXqOweR8ktuKkHBJPAPHHXugML4m+CNFj8H3Gp6Zp9pp93YbZQ9rEItyA4KnaB65HoR 7mu48NX1xqXhjTL642+bcWscpIJ+bKg59j+dYF5o3ijxHo8Gh6y1laWbIi6hd2lyzy3OACQimNQg YgZJzxkYPWuxghjtreOCFAkMShEQdFUDAH5UxFPWtTj0XQ77U5MbbaBpQp/iIHC/UnA/GvItCvdR +G/ia8h1qVZ21XTzfAszDzLkZPlgnqxYsvryvrz6N4k0vWNY1DToIYNPfR4LhLi5WW6kSWVkOVUA RkbQ21uTzjHHWs3x34Y1zxDqOj3OkR6akmmzCdJru4kUk5B27FQjHyjkmkwOc8PQan4O+JVrbarc rI3iC1aW4fJWM3W4sVU9CQeB7MKu/EK4mv8Axt4U0GUD7FJcx3EseSRKRIBgj2AP/fR9K1vGnhvX PFFlpc1nBYWeqWF356SSXj7VAwflKx5OSF6gY2+9SeKfCN/4ostNvvMtrDX9OkEsLI7Swkhg20na rYyoPTj3oApfF7TRdeCjqK+at1psyTQyQkhkBYKx46YBBz2x25rE8d6jPqvwW03ULv8A1s/2aR2G cFiDz/Xv1rqdY0nxH4r05NH1OKy0yxlYfbprS8eSSRQc7YgUUAMRg7uxPBrJ+L1rBafDdLWFRDDH cQpGijgAAgD/ADmgZ3WjQtb6Hp8DOrtFbRIWXoxCgZFcd8XNMspvA+oajLapJeW6RJDKV3GMGZM7 f7ue5HOK7i1EotYfOUpJ5a71LBipxyMjr9azPFmgf8JN4YvdIFwbdp0GyQDIDBgwyO4yADTEeWfY tP1r4Z6d4d8PaZDeatei3e4ubVNyWzAg7riUZ2sF3DbkkA8DGK9Z0TT20fQrDSFmMz2sCRNKQOwx XFx6J4tvfB2meGYtmjSWjRJc39pfHLRL12bVB3HqQcDpyc8eiwxCCBIgzsFGNztlm9ye5oBmFeeE rDV9e/tDV4ob+GCLyrW1njDxxk8vIwbILngZxwFFcD4k0SPwN4/8PazoEBhtdQuBbS20e4xhmIUg AdiGyAOhXgV0nizwCNV8U2fiSyt9OuZ4kEV1Y38Y8q6QZwS21vmAOOQei9NvL9O8D20niSw1mfQ9 H0mGxQvBaWMas0krD70rBFHyfwgZ553dKQy745hm1azsvDNtcrBNq8xSV+pW3Rd8hA79EX/gdZvw tvbpNKv/AA3fKq3Wh3LW55OWjJJU89uGx7AVv6dZ6sfE15qWpWtgkbwJBbNBcvI8aAlmBDIACzHJ IPIVQc7QawB4a8Q2XxKuvEumW+mrZ3MYhuYZr1w0w4+cAREKflXjJ6HnngA5G6sPDekfGdrW+ttP ttKgsg6xzgCNpNoIzn7zEk+pJ7E10fh7RrrVfife+L7a2ksdJMflRmZXjkvDtA3BDjC5Gfm64Bxz kaWreF9UtvH0Hi/SBDeN9nMFzYzy+USMYDRttIz0yG9OvPF7QtG1tPFWqa7quoSrBdIsdtpq3TSR wLhckggKHyv8IPU8nNAGH8NYok8TeODGEXGqsgVT0UM+OPqTUXw/jB+IXjiXCblugvfIBkkP64/Q VYsPDXinwz4n1mbRF0q6sNWlM/mXkjo9s5LNghQd6gseBgnjkc1B8N1ePxd42jknkndbxA00ihSx 3S54HGM+lAHpFHtR0opiF+tJR1o+lACUUdqWmAnelPWikNAC4oNFGaQBSGlpKBC9qBRQKBhR2oHF LQAAUfzoHSigBOaKDxS/pQAlFGOCaKADmgCjpRzQAueaSjvR70AANHejvR3oAWkHU0vfikoAXvQK Q9aQsqqWYgKBkkngCgCQdKKFIIyORRSKOZ8Jf8gCz5H3PX3rohya5vwmv/Ehteuduf1rpB2pkIcP rRR+FJmgYdKXAxSUtAAOlJ2pe1J2oAO9FGaCQBmmAUn1pE3FF3D5sc/WndqAAUHpQOtBoAKKKXvS ATrSnGKQ4zQecUAAGaCOeKKMc0wFFJmlByKOMUgDjjijnNFIKAAdKKBS0AJRRmg0AGeDR70vak70 AKTxSUvajtQAnU0CjoaO9ABSdqWgUAFc3458P3fibw02m2U0MUrSqxeXOAOc9Pr+Wa6TtR2oAw9P 0KX/AIRv+xdcuodTiMQhcrAYQyAAYIDHPTrxW2FCIFUYAGAKXtRQAUUUHpQBjajB4ifxBp0unXlk mkLn7bDLGTK3X7p/L0x79tml4pO9ABR9KO/NFABS0lU9W1Wz0TS7jUb+YRW0C7nbufQAdyTwB3Jo AuHNFcv4X8Yv4k1C+tJNA1bTGtvmVr2AoHUnA6jhu+OfrXUUAAoAoHSj1oAitrW3s4fJtoI4Y8lt sahRk9TgdzUtHWigBawPGWhT+JfC13pNtNHDLOU2ySjKjDhjwPYVvfSigDJ8N6Td6Hottp91qRv/ ALPGsUb+QsQVFGAMAk9O5J6fnr0lFABS0nFLjAoASiiigArl/EOga9c61a6zoOvtazQRGNrC63Pa Tjk5ZVIwecbuTwMYxz1FFAHP6P4ckste1DXb+6jn1K9RIj5EZjijjXooBJJPqSfwFb9HGaSR0jjL yMqooyWY4AoAWg/WuTbxpdXjZ0Dwxqmqwf8APy222if3QykF+nUDHvUnhzxzY69eNplxZ3ml6uqm RrC9iZHKDHzKcYIOfrwe3NAjqDzRRRQAUtFFAw7UUCl70AFHrRQKAKun6dZ6TYRWNhAkFtFnZGnQ ZJJ/Uk1ayKSgCgDH8SWmv3lhEnh3U7awuRMpkkng8wFO4A9e/TnHUVrQrIsMYmcPKFAd1XaGbHJA 7c08UZ5oGGKDR3ooEJRRR3oAOtFFFACGuN8R+H/GGtapMtj4ni0vSwI5LcQQkzCRcZDHjK9TjPPA IxXZ0UgOOj8MazrGoaJfeJ7uxL6STKkViHxNL2di2MAAKdoXrnnHFdDr0WrT6Lcx6Hc29tqRA8mW 4TcgORnIweoyOh61oUEUwKumRXsGmW0WpXMdzeqgE00cexXbvgdhVrFLikoAUdKSlA4o70AHag9K BSfSgBaWikpDCiiimISqer2bajot9YoUD3Fu8Sl+gLKRz+dXeMUlAHLeBvDGpeFNFi0681eO8hjD FI0g2BCx3H5iSSASew69K6W3t4bSBILeJY4k+6qjgd/51IKO9AB3NFFFABSe9L2ooAKTGaWkoA5X x74Wn8XeH49Mtp4rdvtSStJKCQFGQ2ABycNwOPrVeXwp4idtKuLfxVHb3VhA9uzLp+6OZGCDBQyY 6pnPqfQYrsu9cZH8R7C78Q2umafpWrXttPKY11GC2JtyRwSrfxKDkFugx3pAUdT8Aa7rGtadq954 otHu9PIMONJ2qcMG+Yebz+n9a118O+ILnxBpuo6l4itZoLGRpUtbfTjEGZkZCSxkY9GP511Qx1z1 pT1FAC0GijNMYlLRQetAhPSloIpBQAtJ16UtAoAKTNLRjmgAozRR3oAOtHaiigYdqxGtvEf/AAl0 c6X1n/wj/kYe2MZ87zMHkHHTJHftjHc7fag+tIAoFFFABXF+KvCOp654s0XVrG/tbVNPDEmaJpSW 3AgbQVyOPUV2lIaYhkSyLEgmdHlA+ZkUqpPsCTge2TTsc0tHegBO9Ao70tAAKTvS0UAFGKKKAEqq +m2cmqRak9ujXkMTRRynqqk5IFW8UUAYevweI5p9POg3tlbRLNm8FzEXLR8fdx36+nUc8VuVFcSS RQM8MDTyDpGrBSfxJArA8O+Lk8SXN1Db6VfW32OUwXL3DRbUkHVRtdt3Tr9KAOj6isfxLDr82jsn hy5tLfUN6kNdLlCvcdDz+Hatg0tAFOK1ln0pbbU2inleDy7ny1Ko5Iw2B1APNTW1tDZ2sNtbxrHD CgjjReiqBgAfhU3ekoAB0pTRR3oAO1cz498O3finwu+l2UsEczTxvvmJ2hVbJ6A84rpqKAMzQdPv tM0mCzv72G7eBFjR4rcwjaqgAEFmyeOvH0rTFFLQAnWl70UUAFB6UgJwcgD8aXtQAUnalpKACikr G8S+KdP8LWcc96JppZW2wWtsoeaYjrtXI4A5JJwPqQCAbVJWX4e1628S6NFqdpDcwxSMy+XcoFdS pIOQCR27E1qUAFcp8QfDd74q8OJpljJBHKblJGebOFUZyeOc8iuro7c0CKGi22o2mk28Gq3kN3do iq80URjDYAHQscn34z6CrhbzOFyF/vev0pf9YMfw/wA//rU7FAwACqAAAPaiiigBc0CiigAoo6UH rQAClz7Ugozg0ALwK4fw94T13RvFmuap9v05LLUboyeQIHkdk3sR82VCNhj/AHhzXb/WgdMUAAoo HWl7UAJRQaKAAijFFHvQADrQTSd6U0AFFGKKACkpaKAAdKUUlA4JoAWgdMUDikHWgBRwOlJ0pe3W kOMGgAGelKRSUUAH1oozRQAd6Wk70UAHeg0fSg9M0AA60HrQKD1oAWk6ml4NJQAGkOCpBGQeo9aU UDmgB68jpiigdKKRRzPhDB8P2nVfk/LmujHWuc8KqreHLEhsHy8cHvk10S/rTIFoxR1PNFAwo6UZ 9aCeaAFz7Unal7UnrQAmaUjiikpgAGF4pe1A6UetAB2oNA60GgAo96O9BoAD1pT2pD1o7UgCgUUu M0wEo5xRR7UgCil9KTHNAAOlFFLigBKDnNFJ3pgO7UmeaD0o70gFzxSdqXtijtQAnejGKKOnSgAo o96OtACUtFFAgrm/G+ratoXhy41bSpdOUWql5Y72J23jsFKuuDnsc5z2rpK5v4gxRz/D3X0kIAFl Iwyu75lGVGPqBQMp6Fq/iTWPAkWttc6TDeTxGeNTZyGJUAPyn97kk4B3ZGM9DVfwH4g8S+LfD0ur Xcml2wkZ47dI7OQ4YY+ZiZfmGcjaMdPvVY8CMsvws0tWGV+xMhBGMgbh/Ssv4LOG+HkSgfcupQSB 1yQc9B6+/wDQAF/wVr3iPX77Vhqbaalvpt7JZH7NayKZnQkEhmkIA6HGD161J4+8cDwbDp5jgW4l nuF82PusAPztx0OSoHbJqn8NbgPf+MrXaQ0ev3MmeOQzkfX+A1FNocfjqbxbLOFMLqNM0+VkzsMf zM656jzSOR12e1IDS8f+Nl8I6NbXNugmubiVCkZGQYgQXY9wNvGfVhXWQTxXVtFcwOHhlQSRsDkM pGQfyryj4bWB8U+HdUtdckSaW1t/7FWBs74I1yxJz0JbAyB/yxX043vhNqstz4Xl0a8dvt2i3DWc iP1CKcJ26Dlf+A0xne1534r8Q2EnxI8N+HLwpLaCQzTxk5HnsCIQ4xzg8gepU9hXoUsqQRPNK6pG ilnZjgKBySa8vj8Kt4y+Hmsag8SrqetXLahavIvzIqnECgkEgbBwR2c460MR6Rqct7FYSHToI57w 4WJZW2oCTjcxHO0dTjniuT8H+J9b1XXNe0HXUsI77TSm2WxV9hDZ5+Yn/Zq98PvEh8UeEre7myL2 3JtrtduMSqBk49wQfbOO1Yfhlgnxm8ZRYP7yC3fJ7YVRj/x6gC1omv8Aie98e6n4fu59INrpqRyS TQ2cgeUMAQOZCFOCeeenT03PGOvN4b8L3l/EFa72+XaxtzvmbhQB39cegNc1oV1HD8bfE9owxJcW cEinPB2KoP8A6HWnfoNd+JFjZmMyWuiW7XU+c7fPlG2MehIUOf8AgQ96QGx4V12PxJ4YsNVjxuni HmhQQFkHDgZ9GBFcvq3iHxHZ/EWy8L2uoad5GoRNcJNLZM0sCjf8vDhW+51wOvtWZ4KkXwb8RdY8 HSu4tLxhd6cG4UZBJUAYA4yOP7lT+JPJh+OvhWZn2O9o8ZyOD/rQo+pLEflQBa8aeMvEfhGa2v2s NPbSHuxamN2YzyDBJdSDtUHDYB3dBnBOBr+J/E02n6/onh+ykigudVds3UyFxCijsvALE8DJwO4P SsH43op8EWrFSSmoxsOP9h/8/lWz430Xw/4j/srSdZgnWa8kdLK6gwrQuE3EZPqF6YI4+hpjLVkf Edpr7aXfalBeWs9lLNDdiz8uSKRWRcNhtpGHyOATg+lZeg634kvfHWqaDdXtg9tpaxtJNHZMjzbw Dj/WELxkZAPSmeFYvEXhfxKvhnVb59Y0+4t5LizvHJ8yFUKhlfIPBLjHzH2x0Ffw3cQwfGfxda+W EM0EEgbAAyoQH8zIPrSAvw65qPifxTrOk6TqsemR6Qyxsfs6zPO5HJIbgKCMccnmrVn4h1fT9C1a TXLZLq+sbz7LbpZQsn2vKoYyFJOCxfnBwOfSud17wdpvibxfqs2g313o/iOwWF5Zo/lilLqSCQOe QAD06cg1NpvjrWLXwfr15rGlR3uoaBc/ZpXgJSO4KkAuCV4IBycD0OBnFAirq3iP4k+F4/7a1bT9 GutJGwzwWhbfCCQMZJ65OM/MO+PTvra//wCEg8PQ3+j3awm6iEkMzx7wp9GXIz3BGR3rk38Sap4g 8BXOqXOj6NFpFzaSmVptUk3Ioypyv2cjIweOeas+ANQs9H8C6LY6pdwWV6tm1w1tczqsgiDMd+0n IXaM+3PvQBB4A8Sa/wCLZLu61C5soorG4Nu9va2jBZTj729nJ69gO3vXb3cdxLayJa3At5iPklMe 8Kf93jNeZ/Bi4t2ttfjQoGa/Mig8OVIOAR14wePrXqY60wPPPA/iPxF4vh1SWa/sLb7JcNbqIbFi CccNlpPXt+tVNC1TXfHF54m8N6pe2KWFoXs5prO1dJJgzMpIZnKrwvoetM+EskVrJ4ut5tsL2+pM 0u/C7F+Yc9hjaaj+Gt3by+NvHE8MivbS3QlWZsAbd8nQ+nP6UgJZbH4oaPbRwp4g8OywR/JF56iJ nUdB9wAHGBj9a0PBg1bU7/xFf6pBbRaqG+xwarbEyQsgz8kakDKo4yT3JIONuBm+DobXxP418Xy6 /aWuoXNvcLDbpdRpIIoAXGEU5wCMZx1zVj4cvLZeI/FmiWu59FsbwtbNzshcklolGMYHp7e+aALn hjxF4l1jxJrul3lxpKRaVIIBLb2UuZWbdtJzJgYC8j3x707QPEXiXUvG+raDdXGkeTpZRnlgspQ0 qtggDMuEPP8AtVU8EbYviV47gdVEjzwSAg9Rhvb/AGhR4eMdt8bPFULBEkuLaGSMNwWAVM7fbnn6 fkAWtK8R+Jbn4jXnhm5n0hraygW4kmhs5VeRTs+UAykKfn689Onp3M8jRW8kqRNKyIWEaY3OQOgz gZPvXm3h66trn46eIXtp0uEbTwC8Z3BWUxKy5Hoc/l7V6bTA810rxZ42vfEut6IdN0uS9t1jePMz JBbKQT8xALuSCvGB0PTpWn4O8Ua1e+I9W8NeIYLP+0NORZPtFluEcitggEHocMP8OKxIE1OT4x+J rTSL22s55rSF3uLiAzMiBVHyLlRnLDqSOOh7dL4Ul0CHX9d0vT1u5dVtHjOoXt2N0k5Zfl/edwMY C4AGDgYpDOqmljtreSeVtscaF2PoAMmuG0HWfFHjDQ11/SdQ0yzid3WLT57R5B8pIAkkDg5PXKjA BHWu7eNJo2jkRWRxtZWGQQeoIrx2Lwtd2Vo3iv4davJb2hklefT7x9sQCMQygAEEAgjnnHRulAjY 8XePfEGheFtG1WHTrSM3Ah+1GXcf3pVmeNE6gDYRlj/EMA84Txd448WeFDp2r3um6ZDo882x7QSs 90AVLfM2AgOB0GQCOpBrP+J92fEPwj0fW/J8kvNBdNGQRt3RsCBkZIywwe45rW8QSWdhZ6Xrfjad tTt5LmNbLTrC2xbwyMpwxVjmUgA8n14QZoGTeIfFHiXSvHumaDa3Gjm11PmNpLSR5YRk/eUSjI44 PGefTmXxR4h8UaH4i0LT7abRng1SVYPMltJd8b5UMcCX5h82QOMYwT3qp4+McPxE8BzPnJupI8dj kxgfqaX4gXlq3jPwZapPE93FqaNJCp3MisVAJA6Z7Z9D6GgD0KESrBGJ3R5goDtGhRWbuQpJwPbJ +tcN448YeIvCUy6iumafJoMcywymSVvtEmVzuXHCgHI53EkHgCu8NedfG2Pf8PHJJBW6iIGAc/eG Onvn8KYiz498Z6v4V/s+7tLO0fTZZ0SV5CzTSggsVjTgDgdSepHHU1V1/wAaeKfDV7pt9q2mabFo d5OIGhhd5LuLcCRu6LuHcAMMgjPINZ3xnZR4C0eYoTtu4mUMMnPlPwcg/ljmtbWVtLbUdDvvF9zJ qL3FyI9Ps7OzP2WGRhw7ISWdh2JPfhRzSGGreJvFNl8Q9P8ADVvNozQX8bTRzPZytJCg3n5lEoz9 3rxnJ4GKj1nxV4p03x9pfhmGfRZBqCCQTNYzbo1+bOQJcH7h7j3x1o8WJFb/ABc8F3kjlfMW4hwT gZxhecc5MnT6VQ8UvB/wu3wm6SJJKimGaJScocORnHQ4kBx6Y7HNAGxq3i3xLo2v6Ol5punppF/e ix++5uSxbaJNoO1VP3gPmOOpBNd5XAfE4bJvCMhQuV1634wTnrxwDn+dd9TEcz4h8QatDqA0bw1p 0V9qvledM9yxS3tUOQpcjkliCAo54J6CsHQPHutW3iiPwz4z02CzvrjH2a4tifLkJHCnk9cHkHrg YHWtLX/Gj6D4ttNGh0L7RcahGhiuTMIlkO4qEJ2nOM5743D1rn/F51rU/E3g5b3RoLO4j1RGi8m9 892QENISoRcKoVSTnvSA6XWNa8T3uo3Nj4Rs9NkFngXF3qTOImkxnyownVhxk5wM461R8IeN9S8R XGp6Df2tvpviKxB3ExtJC2GwWCbgcDK8budwINb9h4h0JvEd74csiY9RgJnnhW2ZFy2GZ923ByWB J7lh1zXJrbmT9oF5rNTsh0wfbWiG0ZYEKHPfOEI78D0oGWPBPifxX4pu9XjuJNHt4dPmNuskVjMw lf5hkEygYBCnHXBxxwaj0HxZ4q1LxZrWkSrpU6aTnPkW8kbXBJwq7mkIT1Jw2MHANVfhSfJ8S+Nr B4nWaPUfMLHuC0gx09s++fzZ4BuLe4+K/jKa3kjmimCPHLGcqVzzg9D1FAE/h/xt4x16+1rSLbTd Ge/sJin2oyyLbRjJGD1ZySpxjbx1xjmXwx428Sa3BrGmf2fYS67p92tv5sZYWoUlhvY5ycFG4GM5 GAOcYvhK21eP4j+NdL02+hsZJblZ5Z54Gmk2b3YbBwuSJOrE9sA9R2XgOXw95OqWmgw3G+1vHivL m5j/AHlzNkkuX6Pnn0xnoARQBB4J8bXWt2mtprUNtDd6NMyXD2u7y3UbuVDcjGwjqemeM1W0bW/F 3ivw2PEOkXWkQLK0nk6dPbO/CsVCtKHHJxnhe4rP+HMEZ8dfEK3dBLFJeIWDocMGebIII98e9ZEn he+0Cym8W+AtYmTToTJPNpl0zCM+WzCRcDhgNpAB544bpQB3Fx40Ol+AbHXdQtGfULqKNY7GFGVp bhh/q1BBI5z68Dv3z/EGreNfDujjxBPNoktvAoa704RSIVBIACS7m3NyBkqBx0rE+IeqSX/g/wAI eJWs5lhS7gu54FjLBAVzg8evA6Zz71vfELWdJ1D4aX7w6nbFbyANbYkBMpBVsBep9/TqaAI/GXjP WNJ8F2mv6ZbafHFdQxt/pMjtIjyDICoFwcDPJI6dPWvr3iPxtpfh6PxIsOkpp0KxPLaSB2nlRtoJ 3KSqkk5AGcDqT0qh40RJfgDZO+EK2lmwGMZPyDHI9zXQ+LV8/wCEN6WUpnTEfBByCApxj8KBEniP xp/Zvh3SL2zjjWfWJIooHnP7uDzFzvcjqF9OM0lxN4t0PWdLSe/stU028ult53azMcsGQxyNjYwc AZPTiqcunaNrPwr0K11uFxbz29pFG8YHmRSybUVlz0OW546Z4NZekw+J/AHijTNHutRfWdB1KY28 DSljLAQuR2OAMdMkYBOFoA9RrzbxN4r8VeGPE2mabNdaQ9hqEgWO8lspA0eWCkMBIFJGQc8de1ek 1yHxL8OjxF4Lu40Um6tQbiDau4llByowCeRkcd8UAdXCsqW8azyCSUKA7qm0Me5A5x9K4+21DxPP 44udFW/sHsLSKOee4Fg4cbjxDnzNu4qMlsd+AO2N4X1W/wBU8CDXp/GF7bxWkTLdL9kt28soOeTH k5GD+PWuj8AWdzH4d/tK/wB51DVZWvJ2kUByG4jBx0wgXjoOcUAdSa503Hir/hOlgFlZ/wDCNeRk 3G/97vx0xnOd3GMYxznPFdHSdRzTA4z4oa82heCbtYW/0u9/0WEBiCNwO5hj0UH9K3/Djad/wjOm HSQF077On2cZPC46HPf1965uWyg8S/Ey6F5bG507RbHyAkqZjNxNy+OzER7QfTI9az/h1NLoGsav 4Fu1cmxka5sZT0kgY5x+GQfxI4xSAs3fjDxHo/ivRrPWNP0yDTtWkaOJYpZGnhI2j52ICE5YcD35 9bfjPX/EGhaxo6afJpzWepXSWhFxaSSPCxIG7KyLuByewxjrzWX8TVVfEPgqV4ywXUsYxnq0fbHP T9KufEri98Itz8uuQ8AZH40wO4Vzb2Ye8nizGmZZseWnA5bBJ2jqepx61yfgTxxH4vbVI3WOOe2u CYo1BBa3b/Vsc9z3/wDrirPjycyaHFosRf7TrNwlkojGSI2OZW46ARhznBxxkYrmfE8aeB/iBoni K2Hl6ZeoNOvo1UBUCgBG468AduBHjPNIZs/EfxPrPhDSItU05tOeEyCF4bqB2YsQxyGVwMcdCPxq XWtV8Xad4fNzYw6VdXMdu13NcyxSQwhAM+Wqb2cv16lR+PFZPxti8zwCDxlLyMg/UMP611V+UufA V0Tgxy6Wx56YMVAGfpfjiG88A23iSe3xLMDGlrCSTNMGKhI8jJLEcdf0rA1nxf468LiHVtb0fSP7 FeVRNFZs8lxArdFLEhS3bONpPHGaj+HmoaXpvwgs9S1iAG2064kkEjW5kKN5pw6jGcjfjI6c89a6 TxfqGnX/AMMdT1FpB9iuLAyxs64yWAKcNjncVx70AUfGXjTU9F0ew1bSbWxuNPvXiVLiR3eT5xu4 iAGeAcfP1PSqfibxf4w0Cyi16TStKg0XzUV7WaR2vNrNgE4wqsR2G7Gfrjm/E9nNYfAXQku0KyxT wymNlOcMXIU+hw1dj8Xow/w21MllUh4SobufNUY/WgA8f+MdX8NaDbarpFrYTW1wyKsty0hbLAsP 3YA4wOu/8Kpax4k8d6Dp66/d6fosuk5VprSJpBPAjMAMuTtJwRk4wD2wM1m/EcLc/BbSpFbotow7 fwY/rXWeJLy2b4W311M4igl0vIMmOrJhR6ZJIHHc8UAZPivx1qNh4P0/xRocmnvZ3Wxfs93byM+5 g3RlcDgjBBHY89qveKtZ8TeG/CDaz9s0aWaDZ50b2Mqq291Ubf3uRjd3zn2rhNe0i7tf2fdOW4Vh Kk63LpISCiyO+0AEAj768Y45rrfiHe2dz8IZGE0cIvIbZrdJHG5zvRtoHGTgHp6E0AaJ8XT6J4Fi 8Q6/JaTTXESPBb2cLxF2dQVjAdmJPvxx24qPUdS8Z6Pox12ZdIuoo186501IZI5I48chJSx3MOM5 QZwcYrkvHdtPefCHw3qMCMYrOOCSVMZ4Me0MeD0OPbmvRr7ULHVvBV5qEckbWVxYSSBn4G0oevpj vQBVufF6N4Z03VNLsJr241PYtpaA4O5hk7yM7VXB3Htiucu/GnivwlqlovjGw0o6XdNsF3pnmYib j7289hk4wM4OCcVB4L1XS/B/wu0PUvEKiEs0ot5BCZHAkZm4wuVyoz6HA5rT+Lqw3PgGSHKm5luI RaxMhLySFvuqo53YJ7etAHejBAI59xXHePde17wvpT6vp76bJao6I8NxbuXG443bxIAeccbfxro9 Gikg0LT4ptwljto1cMSTuCgHOec5rlfi4m/4b6iCP44cHHA/eL1pga9lrN1Y+Ef7c8Q3NmR9nFy3 2WFolVSoIT53O5snAPGcjisqHVfGOp+HBr9iulQLJGZ4NMuLaVnaPqA0ocYYjnhMdBz1NHxdbTaj 8FovsyOu2ytpmiAJJRdjMPwAz07VveAdQg1HwJo00LoRHbrE4Vs7WQbSD6Hj9aQFjwl4ps/F+hpq VqpjO7ZNAxyYnHUE9+xB9CK0dV+3jT5W0ya1hulG5Wuomkj47EKyn8QfwNef/CNQz+JLm3MxsJr4 m2ZlwjgFvmU4weMA4PYdK9KkXzI3Tj5lK8jI/KmI4LwV4r8S+JdDuNVeDS59svkQ2tvG8W5vl+dp HdsKMnICk8cc8VW8P+LvGniTSbxLHTNHGoWk7Qy3U0ki2xIIwqKMszdcnIHQ55xSfBUAeCZVC9L6 TJ7H5V9qoeBrLVbxfEdlZX8VhYjVrj7TcRIzXTE4GI8/KnA+8dx9hjNIZueGPiKuq+EbrVNRszHe 2cnkPBbqSJ5T9xYs5yWyBtySD7Yqlq/i3x34bjTVtX0PSG0hnAeC2mczw7shQz/dznGSFwenGaue Hdb8D2fgc6jYW5h0WxuBmWe1JZpRjEnQlmyR83X6Vq+JtS0vUfhxqWomcNp9xYs0cjIRnIwnDDru xj3oAk1rxlY6Z4XtdbgT7UL3y1soA20zu/3Vzg49+O1Zmu694o8J2EWsamulX+nq6reQWcMkUsIY gAo7OwcAnuq59u3D+IrO60nwJ4D1W7SQLp06tNGyncodg6g56YC4/GvT/Fklne+AtXnaRHtJNPkl VyNykbMq38jQBZe8uNb0C3vvD19bRNOFliluYDIjL3VlDKR6HnIrnfAHirWPE2kXOsatNpcNnDI8 RS3t5FIKhSWLs5GOTxt/GpPh1NHpngDTINRnjtphBLcmOeTayw+Yx3lWwQoBHPTkc1yvgeP7V8Iv EtjauZJRLdAMN2XygIIAweR2/wD1UAdZous+JvFVpLq+mPpdhprSMtlHd2sk0k6rkb2ZZFCAkcYB 49e+D8Ll1B9I8TCCW2j1A6m2XmDTRh8DdnBUsOvOR1BrW+F+uWFx8O7YmWOL+zVeO5zhRGAS24+x Ug59c1U+FUsc0vip4WEkTau8iSjOHDZxjj+p60xF3wR4j1/xHeamNRl0hLfTrhraRbW3lBlYZ+ZX Z8AcDsfwqK+8Q+NtSiuNQ8K6Vpb6VFkQtfmQzXgHV41UgbTj5cnLDBHWofhoi/afGFu53t/a8u7J JBBJHf6H1rqPD2vaHrFvJb6DOjxWBWBo1iaMRYGFXDAccY/CkBm+GfHtlr/hq71WWJrWWxJS7gOS Q2MjaMZOegGM5yPrzmpeMfiJpsK6xN4Wso9GJEjQfPJcxR99+G+U45ztwvfpUfhr7NYP8QNYFh/a Wnx3wlijCAiVoyzsVLDB2sc5ycEdu+/p/i3U/Enh9dQtPDAfTblHUvPqEafKCytkYPHBoA3tI1pf E3hmHVNIljja5jJjM6FxG44IZQQTggjgjNc74R8ReJtb8R6tp+otpEcOkyiKf7Pby7pmbfjaxkwv 3QTkN1xVP4PKLHwRbQ3DiGS9uZpbWOaQb5UAX5lGBkcZ4z6554b8Or2zu/G3jd7SZJkluopUkjOV dfnGR+PfvnimB6M8ixI0kjBUUFmYnAAHU157qfifx5c28mq+HdAsX0ldzQ/at73FwgziRYwy4U9Q v3jx61315t+w3G+3+0L5TZh27vMGPu4756Vxvh7x1qXiW2nl0vwwwFtL5MsdxerEyNjOMbT04FAD 9O8bS+JvBd7q+i/ZbO+sgxuIL5GkRSqlsZBQ4I6N9eKd4T1fxP4l8Jxaw93o8ElyHMMYsJSqbXK/ MTMCc7e2Me9YHhCwmlg+IIFiYI7iV4kgVg0Qfy33KpAAJDNg49AO1anwnv7UfC60kadI0tGnE8jn Cod7OSTxxhgaBlTwb4y8W+KNButTW10yV1n+ywwRW8ka7yFPmO7SHCLu5AUk9q3/AAL4pvfEtpqM eo29tFe6fdtayvasxikIPVc8j8z698DmvgZsHg68jQlgt8xB9iiY47Hg/nV74aDbrHjSMHI/tmVt 2PVm4/DFAHfzSx28Ek0rbY41LMfQAZJriNC8Q+J/Fegya7o76NDbvI4trG5t5WkKqcYeUSAKxwTw hABHWu5IV1KsAykYIPQ148nhPUtIhl8UfDrVyli7SvLplxkIdhKsgHIJBVgM4I7NSA6HW/Get2fw 7s/Fdqumwl0jM1pcQyP8zuFwrB1xjPOQc47V1Xhq51O+0C0vdVe0NxdRJMFtYWjWNWUHadzMSRk8 8fSuG8e6oPEXwRGrC3MH2oW8xjIzsJkXP4ZPXvn3rufC8kc3hHRpIgRG1jAVBbOBsHGe9MDWrgfD PiDTtf8AiPrjOYmubWJYNOcc7oFJErKehy/Ug8gD0JPQ+L9WOi+Fr66jLfaWTyLVUzuaZ/ljAx/t EVwninQT4C03wx4j01S8mhKlpdqi8TRPkOxPbLM34vntQI7vxLf65aWjDQrK2muFjeZ5rxmEKKuM r8vJdgTgcDg5PY1dA8RXnivwdFqemGzttQfchSZWliV1OCCAVYAjBHcBhwe+6k9vqelC4tZRLb3M O+ORQSGVhwR3715/8EZN/giYYOVvWDZORkoh49OvvQBqfD3xPrXi/Tn1O+GnwWySvAbeGCQSbgAc 72bGOcY2/j2qbxv42g8JPpkbLHK1zcL9oVyf3dvnDPx05Ixng8isf4NRLb+HNWtlPzRarMhAJwMB QAAenT3q9YWDeKbnxHqoYRO8v2LS7kxg+UIf+Wi7gQf3pY5/2R6UgO2Zmlty1vJHuZCY3I3Lkjg8 EZHToa4Pw94o8S6r4n1TTLo6MItIbFybeGUyT5Jx5al8LwvOSeccVN8K9bk1Lwr/AGbdxSQ6hpD/ AGS4SUktx0Jz0PUY5+7VLwKYo/iT46i48x54nAOc4y+f1IP40wLtp4u12DxxY6HrenafbQalA01q beZ3kjIBOyQlQCcAjgAe5q1H4g1fXfEesaTocun2aaSUSaW8heZpXbJwFVk2rwRnLE+grH8TskPx l8Is6yNuhlX5M5BIYA8dsnn9eKi8QeDV1bxRqWp+D9Zk0rxFaFBeR5ZYpmZQy7iPUAZ4ZTjkZyaA NrR9c8TX9trtnejSbTVdKnVDKkMkkDqYw+dpdW5BHfjPQ1U8BeMdY8R6Bea/rB0+GwtzIvl21vIr nYqsX3M5GOWGMdutWPBmv3uvaPrFtq2nraaxYyG2vXRflmcJjdx1OAOASMYxwQBk/BNYbn4dzW7p uUXcsUqk5zlV49uCKBmpY634s1/w3D4g0ZtDWGYl47G4ilZtikggzK+N/B42YB4ycZMzeL9Rl8Oa FJpunwX+vatarOtsHMUUQ2AvIxOSEVmUYJyc4BrkINB1fwzpn/CT+AtZe70Qo00mlX27CoD84UH+ IbSOzcHluh3774i2GnQeHNRj8PTs+twBYn+SMxjK4j3NjIy2RyBjmkBXsviFr2jeJbfR/GmkW1ot 44S3urPdsySAM5LZGSATkEdxjmrninxF4x8J+Vfz22k3+jiVVnkt4JlliUnkldzADHAbOM9etZnx Dm1HUtL0r7d4de0mXVoFt5PtEcrEknIATJxgZI9vavS722tryyntr2KOW1kQrKkoyrL3zQBnyX8u q6JDqPh7ULERyjzVnuYGlRkwcjAdCDnHJ6YPFc38PfFOveMLSXUbptKhs4ZvIaK3hkLyNsVshi+F HzrwVJ69K5bwbqz+H9Z1nw9bG91vw+WItrywiku47ckZ2EoCBndyB3BPfNavwMfd4Mv1wo26i33Q ehiiPemB6dk0d6KDQIPrRSUvWgBKM0UppgJ3pTSUpoAKCKKKQB2ope1NNACikzS0UwDrR9aBRSAU GkpRSUALn1pCKMc0uaAEopM0uM0wA9aBRSUALRRRQADFFHeg8UgFxzSY5o7il70AB6UgoIpRQA4d KKB0opFHL+FAT4dshn+D8OtdInTGOlc14SB/4R+y9NvT8a6RfrTIHZ7UdqKDQMKSlopgHpRRnjFA pAH1oNHag0wE7UvbFKOlJQAUHNGKO1AB3oNHpig9qAF4NIRij3oxSAOveiiimAA4oo9KP6UALnOK M80maX0pAJmjNHYUGgBKXvSClpgAPrQOpo9aO9IBaSlpM9KAA9aKBQKADtQelAooAPTFHaiigA7V zXxC2f8ACvde3puH2OTjBPOODwD3xz2rpar39lb6lp9xY3cfmW1xG0UqbiNykYIyOelAHJfDueCX 4ZafHHPHI8Vq6yBHyUO5uD6dD+VZHwTu7VvBb2yzo1yt1I8kRkBcDCYOOuOnNegWOlafplmbSws4 LW3OcxwIEBJ6njv71Do+gaT4ftjBpOnwWiN98xr8z+7MeWP1NAGPouh+D5NT1W90hLebUGuJlvZo 52aWOR2beM5zGc7sYx3xWpo/hrS9BspbLTIp7e2lzmP7VK4UnOSu5jtJyTlcc89am07RdN0me8ms LRIJLyUzXDKSTI5JJJyfc1fzQBgab4K0LSNRfULC3uYLqU7pZBfTnzjknMgL4c5JOWz1o07wToGk 6s+qWNtcRXsjFpZvts7GUk5O8FyH55+bNdB3o70AUtW0iy1zT5LDUI3ltZPvxpM8e4ehKEEj26Uy 10WystIGlW32mO0VdiKLqXei9gr7tygYwADwOBWhS0Actb/DzwvaCcWunzQC4GJhDezoJR1+YB/m OTwT0rL8P/Dqy0zxfqesuk6RrKi2EQunIVQi7mJ3ZbLFhhs4x06V3tJQByo0nwXqHjW6ke30+78R RRpLMkjeY8ajAVtpJCkZXkDPI9RWjp3hfStK1S41KzS6S6uTund76eQSHGAWVnIOB0yOO1XIdI06 DVrjVYrKFL+4QRy3AX53UYwCfwH5CrtAGBd+CfDuoak2pXenCW9LbhcNNJ5inttbdlcdgMY7VV1q 08F3HijT4tbjsJ9Yki8u0iuvnJUHPCnIznoSMnnFdTVK40jTrvUrXUbiygkvbXPkTsgLx564NAHI eNPhzp/iJ7V7aAwTSXcX2qZJD8sKqwO1CducYHA/PFbr+CvD0mm2eny6cJbazkMsAklcsrkEFi2c k89z6egrfo70AZ2m6Fp+kySy2sUpmlAV5p7iSeQgdBvkZjgZ6ZxWRb2Hg298ZX0kVvY3PiCDZLcF wZHiwAFI3ZCnhfu4rqc5qlBpGm2+q3OqQWUMd/cqEmuFXDuB0BP4D8hQBRuPCejXOqXOpmC4ivrl VWa4tryaB2VRgDKOOOnHfAq9Z6VY6fp5sLa1jS1bdujI3B933i2clicnJOSe9Xe9HagDnrfwP4at ZmeDSYkRpBIbcO/kbx0byc+Xn321NqfhPQNZ1S01LUdKt7m8tABDK4PAByAR0YA5IByB2rao7igD I0rwvoWiXElxp2l20FxKWLzhMyNuOTlzk4z2zWtSmigRzd74C8K6jrB1W70K0lvGOWdgQHPqyg7W PuQa4rwW+n/8LH8baffNaYu7gxpazFf343PuUKfvcdRg9fSvWDVGy0fTdOuLq4s7GCGe6kMtxKiD fIxOcsep6n86Bmb/AMIR4bjmSa10qKxlUMPM092tGYE5IYxFSw46HIrT0zSbDRbFbLTbWO2twS2x B1J6kk8kn1PNXe9BoEcvp2m+DrrxPqVzZW+n3OtQTBrqQjzJYZMYGCc7emPlxyPWptb8D+G/EN+t 9qmlrNdKmzzUleNmXphthG4YOOe1alpo2m2F9dXtpYwQXN2264ljQBpD7n6kmr1AzyzS20rQvjhf 2wa3sLdtLSK2iAEabiYztAwBzg8eteqd6yh4d0ka9LrbWUL6jIqL58ihmQKCBtJ+7wecda1e9AGP qPhbR9U1FNRuLV0vkXYLq2uJLeXb/dLxspI56E1Po+g6boMMyafbeWZ5DLNI7tJJK57u7Esx57k1 o0d6AFHFc2ngTw9FbyW8Ntdx20rM8tvHqFwsUhY5bcgfa2e+R046V0neg0AVLjS7G70xtNuLOCWx aMRm3ZBs2joAOgAwMemKyrfwToNvNaTfZZ5jZsGtVubyadICOmxHcquMDGBxiugzxRyKBmVrvhvS PE1mtrq9klzEjb0yxVkb1VlII/A1wfjHSNI8O6j4Mjs4IrO3/tlHlkLHc2MYLucs31J+teojFZ2p 6FpWttbHU7GG8Fs5eJJl3KCRgkqeD+INAi/G6TIskbq6MMqynII9jXD+PvAkXiS38yySVdQuJ4Ul mM7GNIgcFjGW28DPQZz9TXcgBcKAABwAB0ooAxYvCukR+HX0KW3e7sJB+9S7maVpDxyWJznIB4xj tiorbwZolreWt0ILmeS05thd3k1wkB9UWRyFPTkegrfooAx/EHhfRfFFrHb61YrdRxMXT5mRkPfD KQRnuM81514lstO8PfErwXa2witLOFmcmSQ/eZiCzM3LMxxkkkmvXaz7vQtKv9TttRvLCC4u7VcQ SSru8vnOQDwDnv1oA4vxV8OrPW7/AEyTT1uo0uL5ri+ukvZG2IVZiUDMVUlsAFRxn0rutN0+DS9P hsrXzPJiGF82VpG9TlmJJ5NWscUUAZmteHdJ8RWqW+rWSXMcbb48kqyN6qykFT9DSaf4d0zTLtru 3ime7ZPLNxc3MlxJt4+UNIzEDgcDitTvQaAMfUfCmi6rqUepXNoyX8a7Vu7aeS3l24xgvGykjnoT VjSdC0zQ45U060WEzNvmkLF5JW9XdiWY8nkk1o0UAc3q/gHwvrupHUNQ0pJLpgA8iSPH5gGOHCkB ug656VLbeCvDdnq0upxaRb/bH2HzHBfZtxt2BiQmNoxtAxgelb+eKO9AGLe+E9Gv9TfU3gngv5E2 SXNpdS20kijGAxjZdw4HXPSlj8LaLDocujRWIisZX3yJHI6s7ZB3M4O4nIGSTk1sig0AcJ4O+H8G ha1qWs3PnfaJbuUWsRuGZY4dzBC3J3MQScsTgHsc1qj4f+HlinhWG9FvPIZJrcajcCKRictujD7T k9ciumFFIZWfT7OTTzp8lpA9kYxF9naMGPYOAu3pj2rz7xV4G8MeGPBPiG90nSo7a5ltShl3vIwB PIXcW25zzjHvXpNV7+wtdTsZbK9hWe2mG2SNujD0NAjm/D2n6T4i+HGk6fdrDfWZs4FljEmRuVVO CQeoOOK1YvDOkQ6JNowtnfTpgQ8E08kq49BuYlRx0GBWjaWdtYWyW1nbQ29ugwsUKBFUewHFTdqY GCPBuhHRG0Y2szaazIxtnu5mQbTuUAFjtGQDgYHFTWXhfSbC+ivY4ria5hUrFLd3ctw0QOM7PMZt ucdq2BR3pAHejvmiimB4wPDGoWvxB1PwjZsE0LVjHfXK5YbLdWJZVOeMt8hx1GOmK9lACjAGABgA dqaYIjcCcxRmYJsEm0bguc4z1xntUlAAecUySMSRNG2QGBUlWKn8COR9RTyKTt70AZOkeGtL0F7h tNhnia4bfLvupZA792IdiNx7t1Pc1RuvAnh681U6rPaXLahnIuRfzh1PbaQ/yjnoMYHFdKaKAPPN f+G1lqniHSZLYXMNoJpZ76T7bKzMflKqoZjtLHPK4IA+lbus6N4V+yaTpmshDClyq2MNzcuS8uCA Blstwe+R0rpRVO/0nT9UltJb21SaSzmE1uzZzG47jFAGfdeD9EurqzujbzxS2KGO1+z3csKwKRgh FRgoyODxyOtSa94U0bxMkcesW0lzFGcrF9pkRM+u1WAJ9/c1tUUDOW1/R/Cll4VSy1+Qro8cyFRd 30p+f+FdxbcR/s5xx04pureDtFu/DL22n2JVI4JXtI7K4eFXdk4J2MofOAPmJGPatvWdD03xBY/Y tVtI7q23Btj5GCOhBGCD1/M1diijghSGFAkcahUVRgKAMACkByPgzwNaaB4aW0vFkuLi6gK3iTSl o/m5ZFTO0DtkDJxyauQeAfDcH2dBZTSQW0nmQW015NJBG3qI2cp156V0hA645FLTAzdc0HTPEdgL DVrY3NtvEnl+YyZYdOVIPeobjwvpV3oDaHdxT3OnsQTHPdSu3DBgN5bdgEDjNbFFIDy/4n6RaaF8 Mns7ATpbi6hCRyXMkoTHAA3scLx0HFb+k+DPDV9pOmyvbveRQokkcMl7LNBG+0crGXKDr6d66LVd HsNbsxaalbrcW4dZPLYkAlTkZweR7HirNta29nbJb2sEUECDCRxIFVR6ADgUwEvbO21Gyms7yFJ7 eZSkkbjIYGuah+G3hKC2uII9KIS4Ty5C1zKzFNwbaGLEgZAOARXWdqQe9IRnWPh/R9M019OstMtY bORSskIiBWQHruz978c1mw+A/DtvB9njtLgWed32I3s5tjk5OYS+wjPOMYrpKB0pjKWoaRp+q6Y+ m31nDPZOoUwsvy4HTHpjsR07Vm23g3Q7W4tpzbz3Mlp/x7G9u5bkQe6CRmCngcgZ4HpW/RSEVdS1 C20nTbjULxyltboZJGClsKPYV538RodL1fwJJr9hPczS3vkLbYvZVjkJcADyi2zPttzkZ7V6ZJGk sTRyIro4KsrDIYHqCKwdP8EeHNK1Bb6y0uOKdHLxne7LGxGCUUkquQewFAE3h3w/b6FpkVvGblma FFlWe7knXIGDtDsQo6/dAFUm8A6BulEEV3aQTMWmtbO9lhglz13RqwX8gM109JQBBZ2dtp9nHaWU EUFtENscUShVUewFTNnBxjOOKX3pKYHmfwVnhPhW6Tzk8571mMZfJ+4hzj8a6lvAuhfari5t4bqz e5INwLK9mgWbr98IwBPJ5681o6L4d0nw9a/Z9LsYrderMoyzHAGSx5J4FaQyPpQBnWmg6TZaP/ZF tYW8enFChtgmUYHrn1z6msyDwF4etxCgtbiS3hfzIrWe9mlgjbJOREzFep9K6XijvQBBeWdtqFpL aXkEc9vMu2SKRdysPQisGLwF4eiihg+y3MlpC26KzlvZpIEbOciNmK9e2MDsK6WigDD1PwjoWta1 aavqGnrPfWgxE7OwGAcjKg4bB55BpNF8HaB4enefTdPSOdyWMzu0j5OehYnHXtW5S0AcpL8N/CM2 qnU30dPPZtzBZXEbHOeUB2nnnGMVf07whoelalc6laWCLfXMzTSXDku+4k5wT90fMeBjrW5RQBy2 haJ4Uj1jUb/SFtp9RW4f7VIJzI8UhJJBBJ29W7DvS3PgrTX1eS7tI5rH7WWN+1pdywm464BVWC9W Yluv5mtfTtD03Sbi+uLG0jhmvpfOuHXOZH9efqePc+taNAFSw02y0ywSxsbWK3tEGFhjXCgHrx71 iReAfDsAmjgtLmC2mcvLaQ3syW7k9cxBwmPbGMdq6YUCgDnNX8CeGtdlsZNQ0tH+wpst0jdo0Rcg 7dqkDHHSnWPgbw3p2ryapb6ZEt27BgxJKx4AACr0UDAxgcdq6GigArn7nwVolxqFxfxx3VndXRH2 l7K8lt/Oxn76owB6nnGeetdB2pe1AFeysrXTbOO0sreK3t4hhIolCqvOTx9STWBbfD3wpa6iL2DR o0l8wSBfMfygw6MI92wH8K6f1pO4oA8m+EEVtqfhDUbO6um/f3pfbBdtDKflBzmMhhnB78gHtW94 L8Cf2LquoavdXF6JpbycwW7XLlRFvYKz8/OxBJyxPDeua6fRvDejeH4mTStPgtt/33UZd/8AeY5J /E1q96BiCubPgbRQGSE6jbwSM7TW8GozpFMWJLblDY5JOcYz0PFdJS9qBGFr+k6DN4Wk0/VhFa6N Ese4CXyUjCsCo3AjAyBVnQtL0fS9MiTRIYEspFDo0L7w644O7J3D3z3qbVtJsNc06XTtTtUubSXG +NsjODkHI5Bz3FT2lpb2FlBZ2sYjt4I1jiQEkKoGAOfagDP1fw5puuS28t+t0zW7iSHyryaII4PD bUYDcOxIzT9a0Cx8QWK2Woi4kts/PElw8Yk9m2kEjIB/CtKl7UMDmo/BWmWWliwsptVgtYmMkUEO pzoF4Pyghs7STnGetZvw48HN4Y0KCW7mvBfzpunt3uCYoiccBB8u7AUFuTnPOOK7ek60WA5Tw94e 8JtbXd5oDpL9qaRJr21u2dyWbLAOD8p6dMdvatnS9DsdGsWsbA3MdswO1HuZJNmcklSxJHJJ60mh +HdK8OWsltpNottDJIZHUMWyx46knsAB7CtM9aAOd0zwTomj6g2oWUd7HdyHMsrX87+cck/OC5Dc knkd6hsvDnhF/FN/qFulpca15gkuAbjzHhbII+TJ2cgHpkGuoFZll4e0nTdWvNUs7KOG9vf9fKpO X5z9ByecdeKAOO1L4eLf+NdNnS71aOwtLYu851KZ5WkLcIruxKjHJ2kcV01x4Q0641G51FZ9Stru 4RI5Jba+liLKqlVBAOGwCeSCQTkEVvUvaiwFDTNGstI09rKzjZY3LPLIzlpJXb7zu55Zj6nn8qxv CPh3wlpluLzwzHbujBozcRXBlJ5G4FsnngfkK6dgHUqwDKRggjgis7RNA0vw7ZNZ6RZpa27SNKyI ScsepyST0AHsABQBlweAtFtbX7FC+pLYlSr2n9oTGKTJJbK7u5JJAwDk5HJrT1Xw9pOtaWmmX9kk lnGVMcSEx7NowNpUgrgccVpk0tAGJZeFtMs7xL1xdXt1F/qZb+4e4aAdPk3k7T7jk9yazPiXZajq HgW/g01WeQgNLGmdzxA5ZRjqSB078jvXXUh69aAOD+GWraPN4BtbazurWOe1iYXcQZUeNgSCzDH0 +Yisn4FyZ8K6jGFKhb3cFx0BiT/69egX3h7RNSm86/0fT7qX+/Pao7fmR7VHZ+F9A068W8sdE061 uUUqstvbJGwB68gUAa3SijHWigAooooASl7UUZpgJRR3oNAC0n1pccUUgDvR3oooAOlFGKKADGaO lA4o4zQACgdM0o60ntQAdM0UdqPamAfWjvR1zRjBoAKKDwaMUAFFBopAGeaO9FGBmgBaSigdaAAm lFIaUdKAHDpRQOlFIo5fwjg6BZgkgbeMcd66Qc1zPhNlGgWgA/hwfzrpkNUQhRRimSzRQKGmkVFJ CgsccmpDSGJ6UdeKM+lHfpQAUYpfxptAC9KSl5zR7UwDoKTpS0DpQAoPFIaOhxRikADqKDSd+KU9 aYB3xijHTFKaTNIAoFH0pe2aAAdeaMdaSloAQHmijvxRjmgA+lLxmk7UUAApetIOhxR1oAXFJ3pe MGk70AL2pPWj0o5oAB1petJ1o6GgAxRRQaACijpR2oAKBmg9KKACjrRnmue8QeFv7d1jSNQ/tW9s /wCzpfM8q3fas3zKcN7fLj8TQB0BBJHpS+1eY/EK1vdDvNH8Qx6vftL/AGskbxrOyRiFjkRiMfKR hcEnk5Oc8YPigog17wqY7m5tlvtTjgu2jupI1eLcgIIVgMcn396APTsZpe/SvLvizp1vo/hO1uNM 8yymF1FbeZbzyRt5ZD5HysN3OOuc109/4cub77HotpeXmm6JbxCSWW0nKzTtniMOcsq8EsepyB60 AdTzS9uBXkU1rqvwv8WaOYtXvb7wzqM62sqX1xvMLsTySQFUc7sjGcMD2rqPijYQXHgbUL4iRLuy j8yCaJmV0+YA8qQcEZBoA7Sl59K4/wAC6Zptx8PNLDQrMt3ao9y8h3NJJ1bc3U4bIHpiuX+HukW0 ni3xlbM8xSyuvJtczMTApaTOwknacADI5xQB6xj2pOnWvGvh/oI13XPFtrqWpapLZ22ohGtnuX/f 7WkA8xj85HHTIB75rZ+HZuNN8V+MdESe6ns7GVWtYJpy4jBLHau48du/1oA9MAJorz+++Gp8S2Zv dd1jURrUqCRDDPtgs3wfkjQfwjIBJ5OM5GaX4T61qeoaNqWmaxO897pN2bVpHOWIAxgsepDBhk89 KAPQO9IfvAd+tUdYOojTJF0kR/bXZUjeQZWPLAFyM87QScd8V5z4l+GQ07SLvXdJ1vXpdctUa4E0 l3uMxBDEEADsDgDHbrQB6qBzRjFeRa/qr+IPgVDr91Ej6oiIn2lV2ujCYIzKwwV3Yyccc13/AIa0 iwt/B9jaraQmK4tY2uAyA+cxRdzPn7xPqc0Ab2PajnFeR+A9Jtbnxz4whBkiawuDFYjzDILYFnXc ivkAjAxwQOKu+GbNdL+NOtafbXF21sNNErJNcSS73LRHeS5PPLfmelAHp1GOa4jUfAx8Xz3F34hv tTtxveO0s7S6CRwxq3ySYAIMjAEknIAbGPlBrL8DXet6Hr3iLwte3M+qjToVnsTK/wA7qRkLub1y o5OAQQOKAPS8H0ox2rzfUPhcNaspLu+17Vf7dmUy+b9pPlQyEcKqAcIDxxzjvTvAd1J4o8Ialo3i FDPe6fNJYzPKMybccHJ5yCDhiAcqD1FAHo2COtJjp6V5d8LEnHw/u9Stbf7ZrLTSwxS3Byx4UKpd jnywcEj2OBmp9X+FTXVnLeWviPWG18gyLdS3hWN5Djjao+VeMAL0GOuKAPShQK5H4b+IbzxH4RS4 1A7ry3me2mfABcrg5IHfBGenOa6PUdMsdWtvIv7SK5j5IDrkqcEZU9jyeRzQBbIPFLj0rzX4SaXb NoMuqT+bcXgvJY45bqQyPEq/KFUknHU5x1z6YqTw1JF8Q9Q13UtTV5tKguTY2VkZW8oBRlpGUYBZ twIJyRnA9aAPRqOleWWF5e+D/iynh1bm7m0TUog1vFczNL5LYJ+QsScZUjGe4r1OgAFLzXnvxXvt SPh6XTNII88wPe3TBiHjt4ipJUg8EsV/ANVLxT4ju/EngO1tfDjxTXN9pzXl2BJmSGFF+YDafvl/ k98N6cAHp+KMdawPBetx+IfB+l6kj7meBUmz1Ei/K4/MGuc8JrF8QLfUNb12J5oftT21pZ72EEUS dGCg4ZzuOXPoMYxQB6DinEEivK9GuZfDXxXufCU1zeXWkahbebZxXMzTCE7d2BuP3flkHf8Ah9zU ukWEB+M2q6ezStZWdmlxb2hmcxRORFyELYzye3egD08DnpScZry/x7plvZ+KvCwtpbm1h1G+8m8S 3upI/OBePAOGAxknpzzx0r0u2tobO3S3t4xHEgwqjtQMloNc94n0rVNda00y1vpbDTZN7X9xbsFn YAALGhIOMkkk46L71wOu6dqnww1TTNX0zW9SvNGnuRDeW+oXBkRNxyWzwFBGfmxkFRkkEikI9e59 KPzryvxfYQr8XfDdvGZ4rfUEc3UUMrxpKV3EE7SASSBn8M1N8Q7KKPxN4St4ZLmCC/vBBdRw3Mka zIGjADBW54JGevPWmB6dkZAPWl+leRfFzTrnRdIt9esNW1KG7iuY4LeOG4ZIoY/LYYVQep2jJJ56 dOK9aibzIY3PVlB6Y6j0oAf2xSEGuH8ca3Odb0TwpY3rWkuqSZuZ4XKTRQg/wMPus2GAOD901l+O vDr+GNDbxF4XvLywu7SSJ5okuHaK5UsFzIhJDtlgSx685pAemgUlea+Nozrvw6bxN9vvIm+xwXNr BbztEkLMV3E7Tl2+bHPTHABJJ7fw5cTXfhXSLq4kMs01lDJI56sxQEn8TTA1OtGKw/Eltql/Da6d p0r2sdzKVu7yP/WQQhST5Zzw5IUA4OMk4yBXnvizw5qfw9s4/E3hzW9YuVgmDXlne3TTRSAjG5hx nJ65yfmBGMUAeu+1Lj2rktSs77xgbe2Fze6ZorWsdzJNaShJbh3yRGG6qqgZPGTuHTBzx7WGpfDf x3oNvZ6xqN7oWqSfZ3hvZ/M2uSF9AByykEAE4INAHruOKOa8nOlWt38cZNNkjc2ENiJxbJI4j3bQ PmXdjHzHt6cc0nifTLX/AIXJ4c01Ldo7G+iea6iilZEndRI3zrnacYHbJzj0oGes4PpQa8gvNMu4 PjHDolprmrwQ32ns80ouSWUEuSIwflXG0AYHy9ueat6Hp9xZfFTVLDw9qN9JpS2RW8eW5e4jtrk8 AfPkM4IBwTnlvTFIR6piivMdFtzoHxkm0m2u7+a1uNL86X7VcPLuk3D5zk4zwT/wIgY6VVn1rSZ/ iRrmmeO44Y7UJGmlC9GLdY+dzAngMx2nd/skZGOQZ6x2pAK4CZD8NfC3ibVYpHuo2nWWy+0TNKSr KiqrEnO0OW7/AHe+ataf4QtNY8OwXfiGS4vNUuoVnku2lZXgZhkCIA4jC54A6kZOTQI7WlOfSvKP CL3/AIi+Dk897q+oG5iFy0cq3TIx2odqsw+YqOuCefpS+BvCVr4p+G+nTaxfX86yJMYUW5dFhbzX +fg/O+e7ZAwAAOcgz1XvS49q8p8J65rtx8Er28s5573VrcSxwuT5koAIwecliFJIB9AKqaTD4S8a eCfsGkvFbeJhbNhnmMV08+07i0gO6RWOc9Rg8gY4Yj2DtR26VBYwtb6fbQN96OJUPOeQAOtebfEG zuLfxj4ZurbVdQhnvL4RDy5jthQbFwicrzkk7gc5544oA9QOc0gOa8j1TRItI+JWgReG7/UrnUnl Emqo1zJN+6BGZJTnC7hng4HTAHGfWiAwwQCKQDyD6GmnjNeW/ELSbG08Q+GFtIZLVb++8q7FtM8Q lQumQwUgHJPWtnxrqb+G9L0jRNFkWyl1O8W0SYAu0EbHDOuT94FhjPrQB3YHfFB61534x8HW2neF LvU9EnvLHVLCPzvtaXcnmTBeWEhLfOSMnnvjtxXSeCNdfxH4RsNSmObh0KTnGMyKSrHpjkjP40wN u6uoLGzmu7qVYreFC8kjHhVAyTWH4a1DUfEEC63cbrOwnU/Y7HZhymcCSViM5OMgLgAHkt2534w3 00fhW20iEoP7WuktpCVJYICGyMEdwo+hNdzIp03SmSztmnNtBthgDYL7V+Vcn1wBk0gLdHQ151e/ Da/1PT/tdx4o1eLXWzKphumjtoZD/AiDlUHTg54zntVPQviHqMXwy1jVNUSKTV9Ik+zsr4G9yVVC 6g+pIOMZ2nFMD1HGfWkritI8IW2s+Hra+164ub3VbyETvdCd4zCWGQIlU4QKCMYHUZPWuc8JXmp6 18HtRu7zV9RN1bGdo51uSsh2R5UFx82M89cnHpQB6zj2oryzwT4XTxX8ObCfVNT1CRnWf7PsupEE T+bJ+8OG/ePnu3GMAAck3Ph3reu6j8MPtSOb/U0naCB7hy5wWUBnJILBdxJ5yQKQz0fFHavLfEng HUNM0W71zTfFGuS61bp58skl0ypMF5YBFxgYHC8jjBzXZ+DNefxN4RsNVkVVmlRllVem9WKk+wOM 49CKYHQUmKhurWC9tntrmMSRPwy5I/UcivM/AkE8Vr4q1C0+1X1/Y3k9tp9vcXUjooUHaoDNgZJ5 /pSA9SoHSvO9R+Gd5fW8t9/wles/26w3rILplgV+6qi4ZU6gc5HHXoTwVd6h458Htba3dXdvNaXT W9w1u5hlmCqMBmU5B+b5sYyQPfIB6JR2rz34fahq0/wvhkty91fLO8ETXRL4XzdoZuQSFU5xkZ24 qlrnw81HTtLl1jS/FfiC41i1j87M90XWbbyVCgcZ5wMkdiDQB6fScivK9f1m51z4L2/idbm6ttRh CnzLWeSHLecIn4QjIPPrjPFa2o6ekfwne9iub1bxdOF19qa7mMu/ywWO7fnn0zj2NAjv6Q9K4bQd KtL/AOGsFzdzXlzNdWPnzTyXkrOX2HoxYkYyeBxWb8MNOi13wK82rPdXU1xNJHI8tzIzbVIwAd2R jtj3oA9Lowa8t+FUFzqvg/ULmTUr77dJcNbi7kmeR0QKn3Q5IzycHHB9elO8FRzW/jzxd4dlvLu5 02IIypczvKwLY53k5BIbnucD0oA9Qwc0c15d4PtRefEPxRa3d1fTW2nTILSJ7yZkiyW6AvjIx6dz il0i3YfGPWdLkvNQfTbW2S4htGvJmjVyIzkLux1LHB9aAPUMZ5o71wF14Iv/ABUjapq2uatp19KN 1vaWc/lxWij7isByzDqxyOSQMACqvgTxBrwsde0HUc32t6McQ73JMwOQoZjyRkD5jzhvamB6Tiiv PNY+HeoX1pcakPE+snXijSR+TdGO3V8Z8tEAyqdupPrmtP4b+J7rxR4XE9+uL62lMEzbdu8gAhsd jgjPuDQB1560tZWv2+p3lnFZ6ZcfZTcSbJ7offhi2klk5+/nAB5xnOOK848UeFNU8Caf/wAJJ4c8 QazcG2cNdW15cGZZEJwSQAAepzkHrkEYoA9c5oAPpXlHxBeK6XwtqFnJc2p1i7h88w3UsZdGVMA7 SBwD1xn071e+JtiNO0LTv7MuLyymkvIrPzYLqYN5bbuuG+Y5PfJoA9IzR7V5/wCP9Blg8K315a6v qFqLCIPaxQ3UiAHcCzO24tIx6Ak8Z+prqPCd7LqPhHR7ydy801nE0jsclm2jJP1oA2RR0qOaFLiG SGTJR1KMFYqcH3HI/CvMvAdqkfirxU17qF/NDpE6x23n3szrEgMhPBbB4AHI9fU0AeoiivO/COz4 h295r+rPdtb/AGpobGzWZ4Y4Y1wVfCN/rPmOWycdsU3wjq2oaV8QtY8H3t9dX1rGvn2ct05kkRSF baXPLDD9+m2gD0egVHMsjwSLFJ5UjKQsm3dtPrjvXmukWU3h/wCMY0uHVNRurW60z7RKt5ctJufJ G7HTPy+nGSBgUAend6TBrgIbs+NvHmsaVcTyJouiqsZtoZmj+1TNnJkK4JVdpG3OM8nPQZ2oTyfD /wCImi29lLdHQtWXyHtJZ2kSJ9wUGPeflwXUnnkFvbAB6j3o6V57calL4s+Jt14YaaVNG0u3E1zH C+37VKdvyOQclBv5XjJU5yKytVmn+HPj/R47G4um0DVf3MlrPO8kcT7wCU3E7cblOO4z+AM9Xxnt Sdq8o+JmmQ2OveG2spLy3OoX5iuUgupVWQM8eflVuDz2x+gx6NNe6P4etYLe6vrSwibKwi5uAm7u QC5yev60CNHBo7Vlw6pofiBZLO01WzvTtDulpeAuoBGDlGyOcc1xnw6t2u9Z8TT3d5fXD2WpS2tu s17NIsUYJGAGY84A5OTwKAPRwKK8t8L2Ju/ip4ktp7vUGtdLCC1g+2zGOPeFP97rwePc+nDdFglu fjLrWlyalqX9n6fAk0Vob+coWKxEMQX5+8eOntQB6pg0Y5rzXXrZ/wDhbeh6d9u1JLC+glkntor6 eNGZVkOflcAcheBjp71B4/gfT/F3hOOy1DUbWPUbtYblYb6dRKoeJecN12nGevOfegD1Cl61ly6x oulOtjc6vZ28yKMRXN4vmYxxne248dzVi2v7DVbZ2sry3u4cmNnt5g4BxyMqeDg/rQBboJ6HrmvJ vD1lNJ8XfEOkjUdUWy0+3DWsf26Zo4WcRkcFsEDJ+U5HHfFJ4b0y+1Lxf4w0abxJq6afayxGUi4P myclv9Z0jHBDBAuRgcAUAet4+tHavNfh7a3ct74n06TUb+/0OC6WK0uZbuQsWXO5UcEHA+UHBxn8 af8ADe2ub3TdfM2tatNLDqlxZQXEt48jJGuzBCyblz3yVJ5NAHo/J5xRzXkXw60268QxeIYtS1rU 5LaPUWjkQXLpLKQpHzSAghcH7qheRzkcVs/D+7vbPUfF2kPc3V9baVcD7Kk8hkkwfM+Xcck52r/g KAPRPwpe1ee3vgXXNetP7Sv/ABRqtjrbxlo7exujFa27EcIAvJxwC2cnn2FW/hp4lu/EPh+e01UM NT02U21yzMNzehODnPUE9ypOfQA7bHPSlx7V5R4ftp5/jJrmmSahqzabp8Imht21G4ZA7CM5OX5+ 8/B659BUsCST/Gy80eXUtTXT4rP7RHbJqU4RpMJ94b/9pjgY7fiAepelIeK5DVfDuqeLL67j1DVL /StJhcx20Gny+VJcDaMySNzkbiQFwOmTnisXwhqGtaB47vPBusXlxf2zxG5sLqclm29cbm5IxkdT grxxQB6TSZpaKYAetIBS0lAC0cUhooAXvQelGeaDSAOlBo7Zo7UAH1oopO9AC0c0UCgA7UvFIKKA AUUvU0EDFACZ5pTSZ7UtACdM0ZNHrR3pgBoFGKBSAKO9B60UALSUoFIaAD0o/GgdRRjmgApR0pKU UAOHSigdKKRRyvhJA3h61yCTj1966VeMfSue8Hj/AIp60/3f610YGMUyBskUco2yxo6g5AYA4NON LSdhQMKX2pOtHNAC0mKWk+lABQaXtSGgAHSjvxR2o6GmAo6Uh60d6DyKQAaDRQaYAcjGaOtHWgig A4xSYpQOM0negBaKOoooAO/WlpB70d6QC9qSjilzQAnajrRR3zQAY4o70Y4NA6mgAxkUdqKO1AB9 KKKP50AFFLSYoASlNFFABRR3ooAKDRQeRQB5X8V9f0660m0soriUT2mqxNOGgljCqocHDlcHnpgn PUZo+Jd2dT0nw54l0uGe/wBO0/URcTiFGDbVI5wQDjKkZx3Feg61olvrn2BLsbobS7W68s9HKqwU H2BYH8K0x196QHjfxL8Rr4t8K2X9hWl7cWP2+LNx9nkTzZCHAjjXblyCDk4wDtAyem94z1fxFa3G kazp0+q23h6ZRHqEUFrGbiAZOJCrozDg88cbexNejH6mjNFgueVT2sHjjVdGtdO8RarrWn2t2t5d zXEEIgRUBwuRCm5mJAxk4GcjpSeMPHcWveHPEeh2Ok6kl1b+ZFO80JWNI1PL5B74wB156Yr1fNBJ oHc8v0DxxF4Y8N+HdKu/DfiDzHt/KytmSWlAyQFOGOST2/Mc1X+Gl1dL418VfbtMu1uL28y00cTN DEVLlkLkAZGQO+T045r1fPSjNOwjzT4eRTaX4v8AF8d/a3lub7UWltpJ7aSOOZd7nKsRtP3h3546 0vhdbmw+KPiya7sr2GK8kjW2ne1mMchGR9/btA98/SvSuTRzRYDz/RfiBe2KX1p4zsHsdUglPkRW lrK63KEceXjcCc8dfrjmtDwDod7YW2qavqsHk6lrN493JExy0MZ+5GT7DPHbNdhn3pKAKGuvq0Wi XcmhxW82pKmYI7gnYx9DgjtnHI5xXGWnxBuL/wANPaS6ZcjxY6NCdNjtpV2yZ2hixBCpyGyWwB3r 0Ol56UAeXeKPD7eGvgW2jr5k00CReY0YyWkaVWbp1GSfwq9B46m8PeHfD6XnhHX/AC5YFgby4FZk ZEUD5d2eTnG7aeCcV1niXVb3RNBuNQ0/S5tTuYtu20hzufLAHGATwDngHpV3TbyS+0q0vJbaa1kn hSRreYYeIkAlWHqOlIZ5X4Cv7yz8b+LLy90PVY0upi7SJbtIsO1mJQkfePzAYQN7cc0tp4g06D43 317NHehLjTlhgV7CcSmTMZIEZTf0DHO3oOteuVj2fh23s/FOp6/5he5vo4osEf6tUGCAfc4J+goC 5zqeMtV0fxZf2PimzjtdJcF9NvLe3lfzBuACsV3fNg5xgcg+opvh/TL3VvEHiTxMIrjTxqMIs9PM yGOZURceaVYfKC2CuQTxyPXvBR1piPIdM1PVLFLi08Y614qtNVt3JijtIEeO7Xt5RSI5J6YJGM9u cdX4C8OTaLp2p399HIl/qt1JdP5zbpUjJOxHP94AknHcmuz5pr/6tvUg0Bc8t+F1td3Xww1S2025 a0vGu5hBcA5w+xCpOQRjOAeDxVPTNYvodOkh8Sa14ug1+GRkNhaQIxuCD8piIhKkHOPvY/DFb3wl tNT03w5NYajpN7at9oeYTXKqgfIUABSd+eD1UfjXoJ+poC5yvw/8Oz+GvDAtrs/6XcTPdTgNnDPj joOQAAcDqDW5qGqW+miP7Ql44kJA+zWc0/5+WrbevfFXsVxdn4r1201PU7LXvDl2nlEtYTabbyXC XCEkKpYAqrcdWKjnkDGSB1Mb4SapbRaLcWDR3Qlk1Kcq5tJijAgH5pCu1W4IwTnj3qDw4Yvhn4m1 mw1h5YtIv3FxZ6jIh8ktzmNiMhW+b0Gdv0Fdf4F8P3XhvwtDZ3siPeSSPcT7GJVXds4H0GPxzXSq T9KQHnNpZt4w+Jtr4mt42OhabbCO3uHV4/tMp3HcgIG5Rv69MjvXokkixxtI27agLEKpY8egHJ+g p+MnNJimBx/ht4NS1zxBr1xZ3UTybbaFZ7ORHNqi53KGGWDsWOB6LXNfC22Hh7WtX0y5stQSJ5RH YX1xBMkcsILMsa70AU5Z26/MTwOM16tnmigDzHwDPL4f8Ta7oEkGotpE1152n3clpMIwW6x7iu0c 8A8AlTycik8J3I+G0+o6D4hX7PYSXJubLUgrNDKHwuxiFwjAKMg46ntgn1CjoKQHnem6d/wlXxPP iwQzrpFjZJBYzSK0X2iQ5YuqsASgEjDOACcYzzSaY2348a0hDZfS0wcHHWL8h19K9EJrybX7rxJ4 d+JWta5pHhy41OBrKJGba6pj5M7Tj52yuMLnHXsaYE3jnX7G98UeETA12Ta6niZWsp0JAZM7cp85 yOi5r0uwv7fUrRLq1LtC+dpeNozwcH5WAI5HpXF3kM/jXxZ4evrOG8ttL0h3nuHu7d4GeX5dqKrg EkFTk9Bzg5rvaQHDfEe+8R6VHpmoaNLdrp8MrDUls4Y5JfLO35lDqRkAP+JGeK5rVkg8bNpujaX4 g1jXLaS8jkvxPDHHFbwryxZ1hUhzjAGeueK9e70GgZ5p8QwdJ8Y+EvEU8czaTZSvFcGFGbyNw4Yh QTj/AOJx3qj4v11NZ8U+Crq1trhdOGoI0N3MjR+eS8eQqH58DjkgZzxxzXq/Q1wHxHtb+XWfCdzZ 6de30dpf+dKlpEWICshGTkKOh+8QPemIxvjbrFpN4aGlRTut2l5G7oYnUEbHIw5Xb1weD2r0vSNQ ttU0m1vLRnaCWNWRnRl3DHUbgCR796zde8Px+LLLTEvkkt47e7jvJbaQKxbaGGwlSQOT1BPSugoA 4D4haJqP9q6P4q0qykv59Lf9/aRNiSWIMG+UdyMMMf7XQ4xVfxZ4q0vxd4Xk0Tw9LJfanqJjjSGO Ngbf5gxaXONgG09f1FekUUgPN/HVzpmgfDm58MxSyR3MVlEsSi3k2uAygneBt5wc8966HwFrFjqv g/TEspjK1raQwzfu2UK4QAgEgBuQRkZHFaXiPRF8RaBdaTJO0EdxsDOoydoYMR1HUDH41oW1vFaW kNtboEhhRY0QfwqBgD8qAOV+IjeKYNAS88KTSLcQOWnhiiSSSWPH8IZWyQcHAGev0PJ6rfQeLNEO iaV4s1q/vr/y42tZrWELbgkMzTFYFKhQD/ECSOK9b4ooGcXres6n4NuNChjs4pPDSRrb3t3sdpLf ACqxweF6c4P4cZzdRubbx/4q8PNoskk+naVP9turwI6REjaUjUkDc2RkjsK9G6CkOT1piPLvEUw8 J/Fu38S6hZ3DaPdWnkNdwqzrDJjGXVQSeFAx/tZHQ1Q1jWp9V+KnhbVItH1Q2MMchjQWrCV1O5fM K4+VckY3YOMk4BFewjpxQaQHkvjWyW2+KOka1q63dvoM1obWa6hmkjEbYchXaNgUBLL3wefQ10Ph jWDLr+qW+kWduPCFlbqYLi1tyA833n2EZ83OTkqDyB1J57kUUDPIJfE+l/8AC67fUWlmFrJpvkLu spg5fJ4CEBj9dpH8xu+JtR8Mavqt/oni6GOK0txC1ldyRSRkM6Esok6BhgHHGcgYODXUw+HoY/F9 34hdw801rFbRoV/1QUsWOc85yv5e9bNAjyfSfC+pap8ItX0WNrpke6d9LNySjywoytHkNygYqcZC 9c1Y8LfEG7XSYvD0/h/VX8RWkYtxCIcJJtyocuThR8vJPGema9PprqJI2Rs7WBBx6UAeXfDJGl+D 1/BCrvJ/pSKqZZixXgDHfnsK2/hb5sPgKz0u5tb6zvbUSLJHdW7xMN0jsGG5RkYPbNVPhDFqWn+F hpt/o9/aFJXlWe4QIrgkcBSd4PB6rj35FehmgDyrwFeXnh74ZanBNZ31lqlolzcRreWcqqxCllIy ACOOgPY1leJF0DxTpsGo6HaXdn41cxOsFtBLFIJCw3FwFxgAsd/HTr2r2odMUZPegBkQkEEYlIMm 0byOhOOcV578VbG4kGg6oLe6nstPu992LQsJFQlPmG35hjaeRyM9q9F7UnQimB5vpeqwr4w06w8F WNtNpMqvJq16IHLMfmK75m5LdSMkk5NejY455+lPzk/Suf8AF+qa1o2i/btD0kanOkq+bB8xby+5 UKMk9OmcZzg4pAcN8Qtcs7jxF4TMS3xFtqJMqtZzJnDx/d3J8/TouT+da3jzS7vxZoGnax4cDy3W nXJniikjeF5ACNygOBhgyA8jnH5rqEE3jnxD4ZuILO/tLTTZDd3hvbaW3Kt8pWJdyje25DnHAA68 gH0GgDz7V/HOl+IPBt7Z6c00us3ls0A02KNmnjlYbSGBA2gE8scDg10fgzQD4a8KWOmyZNwqmSfL bv3rHcwB9ATgewFb2TnqcUdaAPOPjLHNH4f0zUkjeSGxv0kmCZBC4ODntzgZPciu7uXm1DRJZNKu UjnuLctazkZVWZflYjuOQadqmm22saVdadeIXtrmMxSAHBwfQ9jWL4WbVNMhTQNZiLy2qBbW+iDN HcwrwNxx8sgGMqevUZGcAHEaN4o1G0iuLPxh4l1zStYikbZbx2UBFwvUeUTA2/nI4PpVix8CX158 NNfhYTLqmtTG8VLkKsmFcPGj4woY45xgAufSvVeaO9Azy/wn8RWj0eHQLrRdUbxFZRLAtosBHnYB AbceEHAyWwOeM1V+G/m3Pwc1mCFZJZsXSIqAszMYxgKB7noK9Z+uSO9ed/CGC/0/w5JY3ujahZkz vN5txCsSnO0BQpbfnjqVx70AW/hbKYfh9Zac8c9vfW6yl4biFkcBpHZWAYDIII6Z9Kwvhvc6rpHw 4vrC202ddetzJNDZ3sMkQlyBgjcFyOvAPbqM16v6UUAebH4j2mqeC7iBopT4lkt5IH0mC3kaUS4K /dxkL3zngd810/gXQJfDHg6w0u4INyil5sHI3sxYj8M4/CuiyaSmI5nX/HFl4c1y00y70/UpXuo2 aGW3ty6SOOka+rHp7ZGcA5HHeAb3VJF8VaVFaXdnqFxdzzQ3ZjLwQykH5WcjbwQPXOelesZopDPJ dI8T3i2bweLvEuu6TrdvIwa0itLfEwHIMYEDFxg46kEj6VueCs+FfDkl3rxuoJ9Vv5LhIngZ5E3c qHWNcBsDJ4A5xXfD60h5BGTg8cHFFgPKPBesXVx8ONR07w7dBtetZZ5Yh5RIwZiwB3LgFlJABwab Y+MA2hM994r1+LX0jYS6SLO3WXzRn5VQwEhT2JPA6nivRPDmhW/hzQ7fToNrGMEyyhNplcnJY8k5 J9Sa1s0CPNNT8Mahp/wOfRoUke/igSeWPO47hKJXVcenOAPSoIvE9v4o+Hf9geH47m61X7AsE8TR MBCFXDbnYYJOCAASSWHoSPUqTn1oGeV+HfG1o3gRNCtrLUrjW7W0kt5rLySHh2qRudmwFXp3z0GC at/B6THgk2zW97GTJJL5ssJSNg2MFGIwf16GvSqZI2yJmCs20E7VGSfYUCPKvg/q0Nh4PvI7mG+S KOZ5xObWRoymFHykLgnOeBzUPhfxBpkfxe8RPJdSKNRESWoMbjzDhTjaV3A+5wAM9q7/AMKeIJ/E 2kG9n0m80thKYxDcqQWAxhhkDjn07U/R/DsWl65rWrNIs11qcyuX2YMcaoFVM5OehPbr7UAcBp2r 2ngr4l+J/wDhIBcW6am6y2kywu8coGW2rheW+YD6qR3pvh3VJZfjRq97LpmpwpdWsUax/Z2YxZWM r5u0EJkAnk8Zwea9cpB1NAHk9j4i1jT9Uv8ATvG3ifUNJliYGzkgtIBHdJzkqxifcfu8DB5xjNa3 g/S75LjxL4liW5nuL87LD7eoiadEHDuqqgUM3T5QcAetehgUlAHB6L8Src6c8fiG3ez16F2jbTYI XaSYgAgxpyec46kZHWrvw40K+0Tw5I+pxCG9vbh7qSEHPlhuin3/AMa6/vmlpgcv4+uPEVn4ae78 Mkm7gcPIixq7PEAd2A3Ujg8c8cVxmsa5H4h8Ovp2j+KtY1PU7+NYhpy28ClC33vOKwgooBOTkdO9 et0HvSA8u+I2iS6R4Q0GeyiknTRZ4mlCJksqqBuOMf3Rzx1qn8QPFWneIND0260ZLq4tF1KF3vFj MKEjdhAWwxPB5UEDHJ7V6724rz74vW97P4VtBp9tPcTpfxsscERkbIVsfKAe+KYFj4na1p0HhXVd LmmK3k1uDHGYWIb5h/Fjb2Pfir3w61O0v/BWmQ205le1to45chuGAxjJGD0PTOKvajaN4t8LT2jx XWnLd4R0uEAkCBxuBAbjcAR1zzWxb28NpbRW1tGsUEKhI41GAqgYAFAHP+I/Gtj4X1OwtL6y1CQX ofy5raDzF3L0TAOSx9AD+WSOO+H0zTeKPF9re2V7H9vuSjGOJmijP7wspcDaGAdRyeeMV6tRjr78 0AeV+BLyP4ffbvDHia4Wz2Sm4tL2d9sE8ZABCsThTkZ29ea0/DltJ4g+JGpeLY4XXSo7ZbSxldCh uDgbpFH8S/eAY9cjHTj0AqMYIyOuMUpoAZK6xwu7hiqgkhULHA9AOT+FeVT+JdJ/4XJY6h58otJt L8gboJFLMSxUbCoZs/Q16xWOnh61/wCEul8QyhZLo2qW0G5eYQCxYg56ncBwBwPegDhTDN8PviHf azqLTN4c1UMWuk3FLWVm3ASIue5IDEfxduam1dLXx/448OnR2e40vTC9xeXsOViY7kKRh8YY7kGQ Ome2K9NpKAPL72zm8EfFGbxPdBjoGqjyZp4zhbSRtuDIM/dLKTu6Dd9Mya/bx/EDxpoS6Qwn0rTH M95fxDEbncpWNJB945XnaTjPXNem/SsDxhq+saHoq3ujaSdUnSZBJbru3eWfvFQoJJ6duM57UgPP viTrWm3HiXwrJA8xa01HdcJ9lkRuHi5yVGSAvbJ6V3upaB4b8c6fZ3d7aNdwLueBi0sLDOATgFW/ hHX0rntUtm8feI/DVzZR3VvYaY5u7p7mB4XR8oViAYDLEockZAx15GfQ6YHO6F4F8OeG79r3SbB7 ed4zEzG5lcFSQcEMxHYVy3wiO1vFMIyAmqMQpfO3ORj9Ovf8K9MxyK80+GjXtnqviGzuNGv4Y5tR llW4aLbEAC3G5jlj0HAI6e5oAqeG7xrX4y+KomsryeG4aOLzoYmeOJtqkB8AgZyeSR0PHNN1G+tv AvxiutX1iRoNJ1ey2RzqrMiOvljDAL1+T3xvHvjtNO8UyX/jDUdAfR7u2Fom9byQHyph8v3Tjr8/ qeldGDgUAePa/wCIIU8d+GvFt3Y6haeH0Mluly8bKH3BsSFOqKSwPPLBSQCKb441611nxL4Ov7CC 9ksorsypcRW7hp1EkRfYmN7KAOuMHPGa9iI3DnB9KMDcDjkdDQFzkbzwD4U8R3n9tXulTNcXCo3z SzW7KMcAoCuD65Gc1Uu7zwz8L7W1sf7O1COwv7hiZkD3EcT4H3izEgnjAUHODxxXc0jDKkHBB4II 4IoA8e8JalJdfFvXr650rU447yCONV+zM6wBhGyCUKCEYqAeTx8wPNMji0zT/ih4lsPFN1cafp+o hZbcyXBtra5VcHaW43Y3dA2PvA5JxXsuKMD0FAHIeBdXuNWh1Axada2ugwXHlaTJBGYxNECcttJ6 dCDgA5NZnwmbzNP8RrIBvXXLjcM+yn7o4XnPSvQhjj0rz34XTXkMGsWN1YaiitqVxcx3MsOyAqzA BUJOTkhjwCOvPIyAVPhQBaT+IbS+hntrybUGdI7tDG0qYz8oIGehzjPapPBdx9g+IPjGG5SaF7u6 BtBOrRxzlS5IQkYJ+YdOcevNelUZoA4LQfiRF9luoPF0MOi6xay7DaFmLTKRuDIuMkdRwW6ZzyBW VoOtR+DNNuvEmvWWoRJ4j1J51SKHf9kjYkxiQA8E7ieATz0zXqec45pMDFAHkHhXW5J/jDrV+dP1 QWl7AqJtgdljBCFGkVVO0sFJG7GMkHnNW1vRpfx61SeSK8uI5tPSI/ZreSbyiVjI3BQcA7Dz05+t eqVgr4mz40k8OHSr5MW/nC+ZP3L9DgH8x9QRjvQBlXvjK70Xxy+na7a22n6DLButNSklwryAAlWY 8KcEjacH5eCc1U0mP/hKPiY/ii1SQaTYWP2KCdgVFzKWJLJx8yAMRn1Ax3x3xxjHWgnNAB3pKKXF MApKUUUgA0gpaO4oAQcmlNA60GgA7UGjFJ0NAC0UUlABSjrQBQOtMAozR3opAANAoooAO9KaSjPF AATyaKPWg9aYAaB9KKBSAPSijpRQAd6DQKWgBKO9LSetABRnCkgZx29aD2pR0oAcOlFA6UUijl/C JA0C0Gcnb/WukrlvCJVtDth6DPX3rqFOaogfikpelJSGFB9KKO1AC5x2pKXsKQUAFHalpO1ABij6 0Ue9MBRyaSjODR2pAFBpKXvimAHr1oo70HtQAUYyaKTvQA7HNJjNA5ozSAKO9H8VKKAEHWjFL2pO aACjFApaAE7UYpeOaOOaADHWkzS0nagAHWlPWk70d6ACigUUAFFGOKz9Z1zTPD9gb7Vr6Gztg20P IercnAHUnAPA9DQBodaKw9A8YaB4o3jR9SjuXjUO8YVlZR0yQwB6/wCeaavjLQW1RtLF5KdQXrai 1l80e+3bnHfPTHPSgDeNFYNz4y0K01L+zZ7uVL7JC232SYyPjPKqEyw4PIyOOtO/4THw7/bkeiDV rc6jI2xYBkncOqk4wG/2Sc0AbaurFtrK204ODnB9KWuS8Xo3h+3l8VaYqR3FuVa+jGFW8gyAQ3+0 vBVuvG3ocV0en39tqmnwX1nKstvOgeNx3B/kexHY0AWs9KO9Rzzw2ttLcXEqRQQoZJJHbCooGSSe wArmdN+JPg/V9RFhZa5A9wz7EV1ZA7dAFZgAST055oA6qjtWLrfizRfDkkaavdta+bgRsYJGVz0w GVSM+2c03UPGGiaTaw3Ooz3FnBNwklxZTxrnngkp8p4PBwTQBu96QisKfxhotrpEeqzzXcVhIwVZ 3sZ1XnGGOU4U7hhjwexqKXx14ag0z+0p9TENowzHJNDJH5w9Ywygyf8AAc0AdEKK5W9+I/hXT0tm udSKieNJcCCRjErjKmQBfkyCOGwea29Q1my0zTDqVzJJ9jCeY0sMLyhUxncdgJC45z0oAv0Vl6L4 h03xDbtc6XNLPbg4Ept5I0bnB2sygNyO2az7jx3odvJPta+uILdmSe6tbGaaCJl6hpEUjjvjOO9A HS03vVfT9QtNVsIb6wuI7i1mXcksZyGH+e1VtR1yx0q/02xuXcXGozGG3VULZIUsSfQdBn1I9yAD SpaTODVe/wBQtNMspLy+nWGBMBnb1JwAAOSSSAAOtAFiisnQvE+keJLKe70i5a4ihcxyfunRgw7b WAP6VW07xnoerai+nWU9zNdxMUli+wzqYT/tkoAnQ9cUAb+aBWBa+M9EvNZOkQS3bagv37drCdWj HHLZT5V5HzHjnrSL400N9YbSEmuzqCnDW/2Cfco4+Y/JwvI+bpjvQB0BpK5eT4i+FY724tTqqlra NpJnWJyi4YLjIHJJIwBnPbtVnQfGWi+I726srCaYXdrzJBcQPC4XOA2GA46e4yMgZoA6D1pO9HQV zS/EDwvJd3tsurRlrKMSTPtbZgsF+VsYY5IGBnORjNAHS0EfpWLofi7Q/Ec00Gl33mzwjMkTxPE6 jOM7XAOM1tUCDpUEd7aTXU1rFdQyXMABlhSQM8YPTco5GfesLxjqstpZWWm2tw1veavdpZRTJjdE rZLyAeoUHB7ErR4e8C+HvC94bzSbOSK5eHyZJnuHcuMgkkMSMkqDwBQM6TvS1jan4n0vSrkWkss0 96V3fZLOF7iYL/eKICQPc4FSaN4l0fxD5w0y+SaSA7ZoSCksR9GRgGXnjkdqANTtTsc1HNNFbwPN PIkUUalnkdgqqo5JJPQVy6fEnwnM9ylvqouHt13FYYncv14QAZfoc4yB3oA6ykPSsbw/4r0TxTHM 2kXonaAgTRlGR4yc/eVgD2P5VT134geFvDd79i1XWI4boYJhRHkZcjIyFBxwc80AdLS9qp6Xqlhr Vgl9pt3FdWr8LJGcjI6j2PsazLjxt4ftdU/sya8lXUCSFtfskxkbGTlVCZYcHkcHFAG9S1z/AIg8 beHfDCW51fU0tnnAaOEozSEHODsA3AcEZIAzx1q7o3iDSfEFi17pN9FdwKcMY87lPoV6g+xFAGkB R3rnn8c+HY9RXTWvZRqDdLT7JN533d3+r2bunPTpVjVfFei6IEOq3jWavja88EioxIzgMVxnHbOR 3oA2cUVVs9Rtb60N1A0ggHO+aF4uMA5G8DIwevSsOX4geGoY1ne9mFkz7BfCzmNqWzjiYLsPIIzn GaAOm96M0iOkiK8bq6MAyspyCD0IPpUF9fWum2E17ezpBawIXkkc8KooAs0VzyeNdEae3gle+tnu XEdv9p0+eITEkAbSyAHORx1pZ/GmgW2qf2XNeuuoZwLX7NKZG6/dULlhweRkcUgN/vR1rD1DxjoO lXyWN7evDdybfLgNtKXkz02ALlj24zzx1pdR8X6HpAhOo3UtoJlDRme1lQNkZwMr971XqO4pgblJ XP3vjbQNNe3S/u57R7j/AFKXFlPG0nOMAMgJPTjryPUU/U/GWhaJBDNql3LZxzpvjae1lTd145X7 3H3evtQBvY4pO9UJdb0630VtXubkW1gq72muVaLAzgZDAEZOAOOcjHUVQg8Z6Fcalb6ebm4t7q5H 7hLuzmt/N/3TIig/hQBvD3o70vasfW/FOi+HXiXV70WglUsjyRvsbHbcBjPtnNAGxRWJfeLdG0uy hvNQuJ7S2mJCyT2kyAYOMNlPlJ7A4z1GRS3PivR7TTRqVzNcQ2R/5byWcyoBxgklOAdwwTwe2aQz apMc9apaXq9lrNt9psJJJYCAVlaF0Vwe6lgNw9xmrNxcQ2lvJcXEqRQxrueRzgKPUmmIkorlLD4l +D9T1JNPtNbie4d/LQGN1Vm7AMVAOe3PNb2ravYaFpsuoandR21rF96SQ9+wHcn2FAF0UVzegePv C/ia4FtpWrRTXJG4QujRuw74DAbse2amvfGehafqi6bdXM8d8xxHb/Y5i8nugCHeOvK56UgN6isL UfGOh6TdQW1/czQT3AHkRtZzZlJxwmE+ZvmAwMkE461FP468NWuqx6ZPqsUd46lzG6svlALu/eEj 92cc4bBpgdF2pOK57TPHfhnWNUXTLHVY5bxxuSNo3TzBjOVLKAwwD0PapbHxl4e1LWm0iz1OOa+C lvLVGwwHUhsbT0PQ0AbmOc0Vkap4m07Srv7JILq4vPLEv2aztpLiQITjcVQHAz3NR6f4s0fVRfGw muJ2sdv2mMWkwkjLZwNhUMTweACfakBt9etHesbSPFmi67cSQaXdtdPGcSFLeTbGfRmK4B46E5qr L440KN7jE11LBbsUmu4LOWS3jYdQZFUrx35wO+KAOk70Vkp4l0eTw9/b32+NdK2lvtUgKKQG29wD yeB69qz9F+IXhXxDeiz0zWIpblvuxujxl/8Ad3Abj3wOaYHTdKU1n6rrVhodr9q1GZobf+KXynZE /wB4qCFHucUmk67p2uwNPpk7Twrj96InVG/3WYAN07ZxSA0aO9RXNzBZWslzcypDBEpaSRzhVA6k nsK5rT/iR4P1TURY2mu27XBfYodWRXb0VmAB/A80xnU0vesjWPE+jaDLHHqt59lMn3C8T7XPoGAw T7ZzUV/4v0LSoILjULuS0hnXdHJcW0sannGCSuAeOh570CNz0orBvfGvh3TbaK4vtSFqkp/dieKR GYf3tpXdt/2sY962oZoriCOaCRZIpFDo6HIYHoQfSkMkpKhvL2106ylvL24jt7aIbpJZWCqo9zWG vjfQhcQwTy3lpNcSCOBLuwnhMrE4G3cgzTEdJSYrDvfGGhafqQ067vWivWOEtzbyb5OcfIAvzDPc ZzW2jB0VhkBhkZBB/I0DDvS1w/jDxRZ6b4gtNJ1LVptJsHtzPJPDkSTMXCqgYKdqj5ixGD93kc57 WWWOCGSaZ1jijUu7McBVHJJoEEk0URQSyohdtqBmA3H0Hqaeelef6X4N0rxZBbeKNYN3NqF1ILqA m4IFtHu3RxqBwAAFz1y2455rprnxd4etNaTR59XtU1CRgog35YMegOOATkcHHWkBs5pc1lax4k0j w+Yv7WvVtFlzseRG2nHbcBjPPSrllewahbLcW5kMTfdMkTx59wGAJHv0pgWKKpxarYz6rcaXHco1 9bIsksI+8qt0NM1bWdP0Oz+16lcfZ7YMAZSjMqk+pAOPxoAv0GsZfFmgtpEurHUok0+M7TcyBkRj 6KSBu/4DmrWka1puvWC32lXkV1bMSu+M9COoIPIPsaAL9Fc7N458PW8ck0t5MLWNijXYtJjb7gSC POCbDyMdetWLzxboen2Nrf3d+sFndIHhnkjcIwIyPmxgEjseaQG1RWVF4k0ibRJNZF6qadGMtcSo 0a9sfeAJzkYx1JwKpL440EXMFvcT3VpNcPsgS8sZoDKScDbvQZ7UAdFRWLr3izQfDIj/ALY1KG2a QEpGcs7Adwoyce/rVzSdZ03XbL7Xpd7DdwbipeJs7T6EdQfY0wL1FYmoeL9C0q9Wyv7029yxwkck EgMnOPk+X5+SPu5rYilSeFJUzsdQy7lKnB9QeR+NAD8cUVS1PVbLR7Q3WoT+Rbg4aUoxVfdiAdo9 zxUOka/pmvRPLpV2LqJDgyIjbM+gYjBP0oA0qK5if4h+FbZj5mqjyQ5jNwsEjQBhxjzQuzPPrXSR TRzwpNDIkkTqGR0YFWBGQQR1GKAJBRWT4m1WbRPDWoalbxpJNbQl0WTO3Pqcc4HU/SqnhC+0/UdN lnsNcn1ljKRPcStyHwOAmAEXGMAAevJyaAOhFBrmYPiH4RuNRawj1+088NtyxKoTzwHI2npjr1rf u721sLN7u8uIre3jGXllcKqj3NAFiiub0fx74X1+7W003VopbhyQkbKyF8f3dwG78Ktan4s0TRrx LTUb77PcSf6tHhk/edB8ny4bkgcZ5OKANnvxRWLqPizRNIW3bUrxrNbhA0bTwSID7ZK8N/snn2ps /jLw/aTWMFzqccE97j7PFKjI7gkgHaRkAkYBIANAG7R3rAtfG3hm+1kaTba1ay3zEhY1YkMeeFbG 0ng8A1PD4q0G51z+xodVtpNR+YCBWySVzuAPQkYORnIwfSgDXpe1Zupa7p+kPFFdSStcTAtHb28D zyuB1IRAWwO5xgZqtYeK9H1S5u7eznmkltIxJOhtpFZBkjBUrnOQeMZ6+hwAbWaKxtM8V6JrN49p p18LmdCRIqRP+7I7McYU/XFNufF2i21zcW5uJpWtiRcPb2ks0cBAyQ7opVT7EjFAG3R1rNtNf0m9 0b+2IdQg/s0ZzdO2yMYODktjHPFZ2j+PPDGu6j/Z+m6vDPdZIVAGHmYGTtJADcZ6eh9KAOjpO9Vr /ULXTLV7q8kMcCfecIzBR6nAOB79Kr6Tr+l64rPpd2t1GvWSNW2DnGN2MZ9utAGjRRXMn4h+EBqB sTr9mJwwXljszkj7+NvUetAHTUdzWfquuaboMKT6pdC1gY7RLIrbAfQsBgdeM9agtvE2kXmmvqNr dNPZocGaKCRh+GF5HHUcCmBr0Vi6Z4t0LW5hFpeox3rdzAjOq9fvMBheh6kUWvi7Qr3UP7Ptr8TX gO1oI4nZ0OcfONvy/jigDborC13xh4e8MyJHq+qw20rrvWI5ZyvrtUE4649cH0NaOl6vp2t2S3mm XkN3bElfMibIBHY+h6cGkBcNHFc7qPjvwrpWpnTb3XLSG7X76FidnsxGQp9iQa34ZYriCOeCRJYp FDpIjBldSMggjqCO9ACSzwwbDNNHGHYIu9guW9BnvTY7q3mlMUVxE8gG4ojgkDOM4+tcvq3izwxq OkXkD3UdzbOjw/aGtne13lSMGbaY+/8Aeqj8IILNPh5Yy28MKTNJN57xqNzN5jY3EdTt2/gBQB3l JXP3Hjjw5bXM1udQaWSBtk32a3lnWI5xh2RSFOeOTV7TPEWja1I0WmalbXciJvdYX3FBnHzD+E+x waANPNHPWjFFABRRSUwF6UUUGkAd6DRSUALRR3ooAKO9ApO9MBRSUoozQITvSmkHWl7UDEzS9jQM UlACgc0vam0poACOKCM0UEc0gCjvR3oFMBaSjvQOTSAWk70dKOM0AHWl9jRSd6AA9KOQhx+tBoB4 xigB69KKFAAwKKRRyHhIhdBtiSADmuqTpntXKeEgf7AtCOBg/wA66teVBzTIQ+ko6UUDD0ooo60A LRR2pKADFFFKTxQAnagUCigAxRQKQ9aYhcc0d6TvSmgYHtSUtB5FABikpR1oPBoAMUdqKBQAd6UH pR1pM80gFpPrRRQACgYzzRRTAXHFIODR2NHekAtJRRQAUcZoFFAAKKKO1ABXPalFocevLf61f2Hm QwhLWC6kVRDknc4DHlmwBnHAXA6nPQ1xnizwbd6nr+m+JNFuLaHV7HCbLtSYp4snKkgErwzDIB6/ QgA5PxYmi2HjXw1rvhm5sXu5b1ILi20+ZCZVb+Lap7jIJx3HtV2FGH7RVwSrHOm7gRn+4o59q6o+ H7/WdbsdR15bOGHTn821s7OVpVMxGPMd2Rc4/hAUYPOTWb4j8J68/jS08VeG7yw+1pbG1lt9S3+W U5IKlAT1PT9e1IDL18k/Hvw38rkf2e3ODgH99+FT+OrTTh4o8GrOxs0S/aWEQRZEsvmxNtIHQsST n1+tZMlvfWnxy0FtTvorq7nsiZfLQpHEdsvyRqckLj3yTk+1L8QRr8/i/wAIo+n2E0qag8lpDBdM TIFZGBkLJ8gwMnAPegD03XIln0DUonB2SWsqt9ChzXJ/CKeSbwDAJGJEdxKqZPIXdn+prY8X6pJp PgLUry7MMdz9jKEISyeay7QFyMkbjxxUfw+0efQ/BOnWd0NtwVaWRf7pclgPwBApgXvEljpl/a2c WsXUMVkl0sjxTuFjuCFbEbZIDDOGxznZ0rjPiJD4Q13wneC2v9FOpW0W61aG4i8wEc7Bg5wQCMf4 V1fjXwrF4x8OS6XLIsL71lhlZdwSRemR3BBIPsayR4d8T6p4at/D2sT6bb2wRIrm7sZHaWeNf4VQ xqsZIABOWxzxzwAcr4/vLi6+F/gy9mBaSW4tJJPmYlmMLHOQwPPXr+NdH8ZGx8N70biMyxAc9fmH BrQ8beCx4k8L2+madLHZT2EiS2WRiNSg2hWAB+XB7egrK1XwZ4o8ZaPLZeKdX0+124a3j0qNzGz/ AN6Xfy3sBjrmkBp+NufhVqJwyYsFYAPgqRtI5rmdRcn9nWAxYRvsUAAUMMnzF6ZJOTWre+F/G2ue FbnSNW1nS4SIBFD9hRwJyMYMzMCQODlUA5744qY+BdVk+HL+FrnW4Lh9kSRSta7ViVWBxgHLdMZ4 6DigZC9jbJ8BTFBbxLGdDFwUCkAuY/MLdc53c9aqaJI5/Z8feWJ/su4jBcH7vzqB16YwB/kV0MXh 3VLjwBP4avZrGOT7ELKKeBWZSoXaGZTjBwBwDj3rJl0HUvD3wk1bRbqa1kjtNOm8ueFmBcfOzBlI 4GOOCfwoEZ+jX9xpv7P/ANrtAY50s5QrruBTMjKXHU8A549O1dD8L0hHw20ZYlG0wnfweWLHd168 1F8N7a31D4VaZZ3MYlglglikRxkMC7g9ulGgeGfEPhGxbSdJvrC803zC8D3wdZbcN1XC8SAdR93k ke4YGJ8LUk0vxX4v0GFydPtbrfCg3ERkswwM+wGfXFUfG+n3fiKz1nxTZzyf8SW5RdP2MxBWL/Xu AOMFj1xn9z1xXa6R4Sn8OeHrqz0i8jbU7yVprm/vIy5kdurbQQeOwz9c5ObmnaPc6Z4Pj0eGKxMs MBgUfMIpOMFm4yC3JPXknk9aALegaxBr+gWWq277kuIgx4xtbowx2III/CtIqrYDKDg5GRnmuU8D +FdQ8H6a+mS6nBfWW9pI8W7RujHGRy7Db1Pbk+9dFfC/Nr/xLpLZLjcOblGZcd+FIOaAPPPhep/4 Srx05DDOpnBYMDjfLgYPHAx270fD9t3xI8cnaOLkAE5J++/c9uDxUHwut9UTXfFE6xWi2EupyeZc BW/eurMCIhnhQSTkk9cY7jf8O+CtQ0LxXrOs/wBrxGDUrhpWtUtj93cWHzFuD8xHT/6yAytCH/F9 vEp44sEzwc/8sarFCf2h0YgfLp+QcHP3CPp3ravvBmsweOLjxLoGs21q15CsVzDd25lXjaMrhh2U fj9eKlp8PtYtPHR8RL4iEhMARnuIPMklYgh+MhUXptAzj09QCvZW6SfH7Unkhhcx6WsqMy7ijfux kE9DgkcdjTb6Mx/tC6a0agedpZaQsM5/1g4yR/dXpmt1vCeo2/xDufFVle2jLc2y2z200bgqoKZI YHk/L3GKbqfg++m+INt4ssb22SSC1+z/AGaeJiH4YZLBuPvenb3oA7HqPWvItVntNL+OcM72Ukkc NgDHFb2zyuW2EKEVc8jpzgDn6164udo3Y3Y5x61x2r+E7/8A4Tm28V6RPbtOsJt57S7ZlRxgjcrq GKnpxjHFMEQaH4cvLr4g3vi7UIorJ2t1hhsVlDyqCAN0235QSF4UEj34ruegJ5rlfDvha6sPEOp+ I9UuYZNU1FVjeK1DCGJFwABu5Y8DJwO+AK6O8F0bOUWLQrc7cRtMCUB9SByfpSA8v8baVd+Nr3X5 rBpD/YEMcdi0cjYe5BLzBcDBYLtX1DAdOa7jwf4hi8T+FbLVI8+Y6bZl9JV4YdTwTyOehFM8L6Fe eHfDh08y2s1yrPJ5wVgJpGJJZwSSMn07CsXwV4R17wlqF6GudNn069lErQxmRDbt82QgIIYY2jkj p7cgFX4TSvqena1rt0WfUbvUCkskhJYIEVkTknAXecAAenYVL4f5+NHizcE3C1t8MAc42pxUdl4E 1/wz4juL3wtrFjFp99IWubW+t2YRjJxsCkbsBuOV981H4MtZLD4q+K7aa8mvZRbWzPcT/fYlQTwA BjnoOmAKAPSs8V5r4HjSH4reN0EYDBomUgYwGJY/mSDXpOOOteSeGBrSfFHxlNpQ0+fE6rNDdu8W 5ctjawDEEf7pBzximAuq2yaV+0Jo7WCCI31t5lyEyA7ESgkgHn7gP1GTXVabdeBdK0uXTTreiXCz MzXTXN3C7XDn7zSZPJ579Bx0qzovhe5TxJc+Jdcltp9VljEECQKTFaxDPCFuSxycnjqeOaxtD8G+ IPB2vanLoM+m3elag3mGC9kkieBsnG0qrBgAcc4zgdOtIDP+HEFnpfj7xXpukXEdxpRWG4gMEheK Pdk7Qckd8cdlHNJ4kXd8ffDOVYg2XYE8/vyO/HQ1vv4Z8Q2+kard6dqlnD4o1GdJZrsxEwhEICxK CGIUL6gkkn14yx4C8ST+N9P8T3Wt6cbqCAeafsrOvmfOpRE3DCBW4YtknJxQBuwT+FtM1LUrm/1v SZtSuJWWeS4niDxqOBDgn5VUDGO5yTyTXI+HI7DTPjTcQeHTby6Te6YJZBZsGiiOeDkHGcqcf7/T vW6ngvU9B8aXXiHw62mzR367buzvN0PzcEukiK2CWGSCuOT7Y2NM0K9t9S1HX7w2kmt3UAgjSLd5 MMaklE3EbjknLNgZwMKMcsZymoBU/aH0k7Pv6aTkZ67Zhnr6DHft+Gj8ZVV/hvfbsbhLEUJGSDvH T3xn8M1zU415/jdayiDSH1OHTcuiTyCIjDjlthYNhhwFxjHNXfjA+snwhcreR6ZHp3nQ+UUmkaZn 5yMFQuOp69AaBGj8T9Qu7P4VYtRJuulhgkkTOUQjJyQeAcBc5/i966230+x1PwhBpxjBsLixSIIc 8IUAHv0x3zVK40KfxF4Ql0fXo4IDKiqptJTLsC7SrZZR8wI9MVS0rTfGelaJFoqTaNIkC+RBqTPJ 5ixAYUmHZtZwMfxgH9SAZfwauLk+E7qyn8x0srx4o5CwK4KqxReS3BJPIH3hjPONz4heHL3xR4Sl sNPlRLtJEmjVzgOV/hz269fatLwz4ds/C2hw6XZF2RCWeWTG+Vz1Zsd/8BTPFmmajrHhq6s9JuYr bUGMb280pIVHSRXBOAf7voaAOOtfGkOs3Ft4X8a6LeaVqjXEfluF/cyyo6lCjjJGWGOMjH8XNO1x pB8evDK5DKdPl+Ufw8Tc+n9316Vr6t4b1jxVc6UmtwaXbWlhdLdF7Wd5pJio4XDRqEUk5PLdAPem eLvCWq6j4l0fxJoM9imo6fuRo77cI5EIPdQTkbmH4+3KGUPiASPG3gQE5H258KD1OY+T9Px/xq/G URvYaAkyM8Z1IBlUZJGOcDIyas614L8VayNO1l9YsE8QWNwZYoAjfZEXPCg43k8DLHr2AxS6z4P8 X+JJNKu9R1TSra5sr0TrFbxu8MaAAggHDSOSMEEgYPHPUEM+Ku5dT8HOiGRhq6YUAknlTxgj0qt8 dWZfB9kBnBvhxg8nYxxwR6VveNPCGo+KNF07yryyXWNPuFuI5XgKwSEdVK5YgdD1PT344X4rWviP /hGLC68QXmntIl2oS0sEYRfdbLF3+ZmPHA2gAHr1oA6Px7eyS+O/BumP54s2uVnZFBw7h02bvmGc Yzz0znmtj4p2cF38PdTaccwBJY2zgqwdeh9+n41b8aeEf+EqtLR7e8Njqenzi4s7kIHCOCDhlPUZ Cn6gdehq6zoHiDxXp8ek6xLYWNgXV7qSwnkeS5CnOwKyKIwTyeX6Y96YGr4Nvp9S8GaRd3Qbz5LV C5cnLEDG4555xn8a4z45u0fg+yZS3N8qlQSAfkY84x3A716VbW8Vpaw21ugSGFFjjQfwqBgD8q5z x74SHjLw21hHKkN1HIJbeV87VYcHOOxBIpAY/wAY3/4txck5UmaLAPUHOevY8VZ8XAN8HbvsP7Nj I3D0Ckd6zvEHgzxj4s8Ox2er61paXCyofKtIpFhKgkM7E/M74IwuFUc+xG7qvhvVdS+H1zoEl/ay XzwrEk4haKPClcZXLHoOfr0FAy54IIbwNohG/Bs48bgwPT/aJOPx6dOKf4mt9IuLO2GuX8NrYJcC SSO4mWOK4IVsRvuIDLn5tvfbU3hvTL3RtCtNPvbuC5a2hSFGhhMYCquBnLMSffj6CqPjfwnD4y8O vprzeRMjiaCXGQrgEcjuCCQfrQBy3xEPgzW/CV6sWpaKdQtod9q0FxF5gK87AAckEDGP/rVveHtJ XWtI8N6vqimY2+nRmO3lG9VlKjMvJOWx0J5GTzzUY0DxFqvhmPw9rdxp9va+UsNxcWLu8twg6gBl URkgDJ+fqcAdQ7xR4PutRbRbrQ71bO50dwbe3kLCCRQV+VtvI4XGcH0xQBz3xO0q303VfD3iPT7U LqQ1KKJhCdjXGTkDjqTgrn0Y54p3jJiPjF4P54wR/EP4m75AP0/PtXTt4f1DXNY0+/8AEH2OOHTZ POtbSzkaRWlxjfI7KucdQAowc5Jqn4y8Iahq+saTr2h3drb6rprHYLtWaKRT2O3kd+nr7CgRT8et t8ZeBsAsTqD4AGeyVnfEM6bZeOPCEt5b232YSzvMggMhb7p3FFGTznHXknirmq+BPEms6zo2sXfi G1N5Zy+a8Qgb7NFjBAjj3ZY5BBZmBIx0xitfxL4W1LVtS0TWLHULePUdJZmWOWNxDMWxuzhiVzj3 980DM6bSb3xj4z0bXZbNtO0rSwZYDcJtubtie6g5RBgEbsHk8c8VNfijh+M3g+OGFURbWZQsaEbQ FfA4I4HPsM9K2IPCmp3vja38U6xcWkU1pbG3t7SzZ2Qkg5Z2bGfvHgL2HpXM6tD4ml+K2gy/ZdNl 1CCykYCJpfJjQl0LuxXP8X3RznjPOaBFvxHbeJfC3jq48V6Tpp1fT7q3WK5t0djLEFA6D8MjAPVs gda6PwdrOieJpL3XtJWeO4uDHBdwzYDIY923IBIyQx5ycgAdqWfTfEdr4oudV0xtMmt7m0hhktrm WSMmRC/zBgrY+90wc+2OZ/DXh6TSb3VtTuvsy3mqTpNLFaAiKIKuABnlieSWwMk9BQM5b4RRH/hH 9aiyyE6nIm8ZDY2Lzz35rH0TXdS+F3m6N4h0m4n0UzGSDUrNN6/Mf4uxzjJH3h6HIrrfAfhHVfCU FxDd6naXEE8xnMEVuwMb9Mhy3IwF4K//AF4LLw94psvDd54eZdEvLK485Y5ZZ5UaJZGZiCmxg+N3 HzL0x70AT2+neE4NM0SR9VtRosJnurOG5mVY5Xdi+/5iM7Az4UjjPPIFc38Sb3wvc6VFrOi6lpMu tWN1C8Ys5o2llG8fKdpyQMk/ga3db+HA1DwroenWd7HFqGiKptbiWEMrsAMhl9CVB79O/fTm0jXN f/s+38QR6ZBa28qXE6WUry/aZEOVX50UImeSPmJwBkdaALXjYk+BNdIGD9ilOD1Hy+1Ufhhn/hXG j5Ur8shwT/01fms3VfDXjjWoNc0+813ThplyGNosURWXvtR2C/Kp43Y3E4IGMmug8HaHqHh3w9ba ZqF7bXPkRhUEEBjCckkElju5PXC8DpQBL4ms9Mvra0j1i/ht9PS4EksM0oRLnCkhGyRlc4YjnO3m uO+I0Xg7WvCN+0F9o39pW0W+B4Z4vM+T5tgwckEZGPfOK6rxp4StfGWgtp87+VMjiS3nILeW474y MgjI/H1rNXQfE+q+HI9A1t9LtrcxrFc3VjI7yTxjAKqrIojJAwWy3U4HoAcd8RLya7+FPha7nZ5Z pDE7b2OZD5LE5IPfr1re+N7FfAaHJA+2x5wcZ+V62/G/gtfE3hmHTNPkhsprR1ktN0eY12qVCEDo MHHQ49DXC/FK08Sv4MgufEN3YAx3UccdtYhijEowaR2cAk56AAAe/YA9A8d20DeB9en+zxCZ7I7m ZV3HbkqCfYkkeh6VP4H/AORD0LOf+PGLr/uis/4itqg8KaqttFZGw+xuZ5Zp3WRfXaoUgjHqwq94 Hi1CDwbpcGpW0dtLFboixrJvO0KAC3AAJ64GcepoAqfEPw/qfiHw4kWkSot7bXCXMccmNshTOF54 znGM8etYdp4qsvE93a+GvF+lz6RrUVxFPCXUCOSWNwy+WxzgnGMc5BIDHNdd4r0vUNY0CS00u4ht 7zzoJY5ZgSq7JUc8DrwvTv0461k6h4e1fxLqWjSa1b6baw6bcC6L2ly80krgcKA0ahFJwTyx4A96 AMPxpj/hbvg3J67uE+91OM89Ov69a9NrifE3hHV9X8baLrmnXtlbx6ehB+0RtIdxJ6ICMjB/vCu1 TcEG4gtjkgYBP0pgVb/StO1RY01GwtbtY23ILiFZAp9RkHBrn/HU8lxY2Xh+2Z1udauRbko2GWBf mmb6bARn/aHrXVda5m10nWm8eTazfJpzWItja2yxzOZIl3bixBTBLEDOCMADrjkAxPh3eyaVqer+ DLwy79PmeWyaVsl7cnjH0yD/AMC7Yqt8XIIbLQtMubaKOKRdUWU+WAm9irEk47kqOTV/W/C3iO58 e2fiXS5dMiW1QReVLK4M6fNuDEIccNx1wRmsj4oJr95Y6Xay2WnlZNSjW3EN07SO5VgFIMYAHvn8 KBGh8aMjwGWDEFbuMjH0au0S8jsdBW9umZY4LYSyMTkgBcn8a5vxp4Z1jxh4VgsC9jaXn2pZZMSv JGqjcMA7QWOCOoH4VY1rSvEl9pFppyPpNynnRteMfMtlkiVgfLVMScHABJPTIxzSGcTHHf8AhbxL oXi2/L/8Tx2hvo92BEZGLRgg9Aqbe/VDXoPjVlTwTreXC/6FLyf901V8c+Hr/wAVeF/7MtxaRTyS I7SyyNiEqQSUwuSeo/h6/hSS6X4h1HwRfaPqbaeNRltWt47iKZ2SQlcbnygKn1xuoAPAEMM3gPQX eBWMUZaMyKGKHLDcM9Mgnp2OK5n4dWMl74X8V2MDi3ae+uIYmAwI8oFGAOw9sV02h6Z4i8P+GLPT 4m0m9uLfagUmS3RUwc/MA5Y577VrmfhPHqbWOq77O2GnTXszGdZzl3+6VjAH3QQfmJ/CmBR0bxLP 4J0yPwj400mSGyw8EN/CvmQyISc59RyeevTK9TV/4n2Nvpvwps7G0meW3t5LeOKUsGLKqnByMA8D tWkPD/iq78Er4Y1ODRZ1MC27XzXkrsFHRxGYuWAxj5xyM5qz4x8GXOt+CrLw/plxEn2Z4QJLpjyi KV/hHJ6ccD6UgGeMvD2o+I/A1pb6Wyx3duYbmOJm4cov3M+vpnjI/Gs6w8XWPi/ULTw74j0y70jW 7edLmNW2hWljIOEY88jPGOmcE9a6HWdH12+8LLZQ39jJqsc0EsVwYXhi/dyK3KhnPRT35z2qC+0L VvEGs6Nc6vZaZaRaZP8AaRLa3TzSu2OEBaJNqk4Ldc4A96AJkt/DFtf391qN/pl1ezyMssl3LGWj QdIgCflVR29ck8muV0NNN0b4wG28PSwyaZqdiZZorSYNFC4yQcDgDjj/AHzjjitZvBeoaV44ufEW ijT7qO+DC6tL53jwTg5R1Vu4zyvrV4eHNWM2o61HJp9trstp9lsURS8FogJI+baC5JwSdoA4GDg5 AMb4glv+E/8AAJUZ/wBLmx82P4oa9HrzO/8AB/jfVtT8P6re6porXumyMWVY5DEBlSGC4BZjg55U cLjvXpSBxGokZWcAbiowCfYZOPzNAGP4vz/whmt7Tg/YZsH/AIAa89v9Ru9N+AentaSSRSTIkBfI DBGc5xz3Ax9D+XR6xoXjjVm1uxbWNLTSLuN1tVETCZeOEYgYCkn5m+Y4HAGak0vwXdTeAj4Y8RXF nLGIwkTWUTKYsHKtuY/MwOOdq9Oc5piNTw/Z2l14C0yxMKm0m02OMoQMEGMZz1Fct8F7ueTwvd2k kzS29pdGO3LdlI3EA9xkk/jWvo2m+LtD0CLRUXSLkQK0Ntf+e6NGnOxni8sgkDHAbnp71reFPDFp 4T0GLTLVjKQS8s7LgyuerEduwx6CgDbeNJYnjkRXRwVZWGQwPUEdxWBqHh3SotFOm2/kaTp0k6yT pbKsKyjI3ISMYDAAHHOBiuhrE8V+G7fxZ4fn0q5kMQch45Qu4xuOhx3HqO4J5HWgDnvFum+DtR8K XlpH/Y6TW9q7Wot3jRo2UEgLtI4z26HNJ4R0weJvBHhiXVCZ7W1Rma3l+YTMrFYmbBwQoGcEHnHp y6x8NeJE8L2+gTJokAjj+zNqEDO0hh2lcrH5ahXxjneRnnnobPiPwVc3XhrTdN8O6pLpk2lFTbAy MI5NoAAk28npnOD345pDMD4v6DZWugQ+ILGGK11CyuI8SQgRlxu4z0yQcEdxz70/4hM9x4o8BPJG yyNdFmjDfdYvAcZBxxz3rodR8P6p4qmsofEEOn22nWswuWt7SdpzcSL91WLxqFTk5ABJz1GOWePf CN34mTS7zS54IdT0y486D7QSImBKkhtoJ/hU8en4gEZnxgONA0kck/2pFhR3+Vjj9KqfF+G1httD d4olSXVUaciIEyYXHzevAx+XpU+v+DvGHie1sH1HVtLS7t7tZvIgRxbRqB94AgtI+fUqMZrY8WeE 9S8SaRp2NRt11XT7gXMb+SyQSsOgK7mK9ucsRzxzQMz9T0+Txfqvh7+yLB7LSdIvEuTdz23k71TB EcKEBtvHJIC8DGcVm/EOBLfxz4ChtIFRUujtiiAQACSL06Dk9OtdFd+Htb17xPo2p6q9rYWmls0w trK8kmM8h4G7ciAAfQk5I4zXKeNxr918QfCiHTrOWeCaSa2hgu2IcK6Ely0Y2cAZwG6H0oA0/F1p 4h8PeNovGOj2j6patbC2u7RSS6Rg5OwDnHQ8ZwckjFbXhXW9C8V6rPrenSXEV/HbraXNpOqo6KGL KWHJyCWAIbHJHXpPeWPiZfEdlq1k+nSRLZmC7tJZ5I1di2QysEbGPUjnnpSeH/DMtj4j1jxDfJaR 32peWhhtSXSJUGPvlVLM3BJwBwOOMkAw/h1t/wCEs8c7XJA1EcZBAO6XpWLpmqan8J7i+sNZ0q9v tDluGng1O2UORuP/AC06DJJHUjkHAINdV4W8L63oXifXb6e8sG0/Ubp5xEiO0uMsV+YkBfvcjDdO oqS203xLY22qWC2ukXthdXE7wLPdyR+TG5P7sr5LAjv+JHTmgBiaL4avNHsAmpW8mhPdy3ywSOnk 3DMxYL2+RWJO31AB6VzPxL07wpc+G5dQ0u80q21ew2vE1pNGjuFI+XC8kgYx6cfQ6l98L0ufhtp3 hpL2MXtgxniunjyplJYkY6hSWx68DrirN94a1zxNpcela3aaPZQlozeXVm5lkuduGIQGNfLBI5JJ PUY70Ab9hevq3gi3vpVIe604SuCwP3o8nnA9axPhGWPw201m3nc0xG45/wCWjdP89c1Le6Z42u9S 1Cziv9ItPD8qeXAYo2+0xqF+6vG1cngk5wOgqfwHoGs+GtAg0vU7uwlihDeUltG+VLMWOXJ+bkn+ EUxGxrumS6zpMmnx3b2qzOgldPvNFuBdQexZcrntmsHxd4N0G68GXttHplpbG1tHa2khhVWiKgsA DjOCRyO+T9a3tf0qTWtDu9Nivp7F7hNq3NuxV4zkHPBBxxgjIyCRXORaT4wfwynh+4uLBQYjbzas tzJLMY8kEiNkHzlSBkucHJ57gGBYXBv/ANnyZ7tSQllMsZmw24I5EeOvTCgZwcgY7Guz8Cn/AIoT QMBl/wBAh4PX7oqDVvChPw7m8L6K6xYtRbwvM5A6jJYqO/OcDvTdD03xL4f8NadpqLpF/LbRrESZ pbYKoUAYOyQuc55wvHbngAwfhCsIsfEQt4hFCuryoiKchVABCjjoAcVW8Jbj8cPFrA5XyMNluc/u scY6fj+dHwmfUV/tyNbOwW1OsTGdkuyTG21fljQR4ZcgANuHHb11dI8I61YfEzWPEZnsVsrwbFRg 8kpT5MgYIC8p3z9KAN608I6VHc317fWVtfX19Kzzz3EQc7c/Kg3ZwqrtGB6ZrgPDGnTaH8TvFHhz T5XstOmsHmiIbetuTs2P14xvfAPOAK6yz0PxNovivVtQtLuDU9O1EiT7Pe3ckRtnyeE+SQFcHHG3 txxU2keDIo5ta1HV/Km1PWlaO5aEkrDCRt8qNmGSMAZJAyQOBikBBJ4S8DR6H/Y7xaUuYtn2l/K8 /djHmbyMl++a85s9Z1XR/hJ4g01bmRzaaidPjuEKlVRgN6qfz6E43jGODXbeFPCGv+FNKk0v7JoO oxJIxtbmV2jdFOT86iI7uST97vjIFaQ+Hlg3gm68P3E7Sz3bmee/VNryTltwfGT0OBjPTigZf0az trf4eWlrbxbbc6YMJtxndHk5HqSST9a4/wAE/an+B14NLE32sw3XlYbncc42YHXHsPmz9auaL4Z8 fWOjLoNxq+jx6XHE0cc9ushutuPlQFhtUds4JA6c4Na/gXQNZ8JeHxYapeWM8EKtIqW0TBlYks2X YjcPqoPPoKYGX8I/Eej3vhOz0e2dIdQtEPmwMwDS88yL/eByM+hOD2z1Vv4ft7PxZda1bxrGbu1E U6oMB3VshyO5IOM+wrktX8BaJ4+srTxLpU82mX11Glyk6AfMSARvUHhhjGVYEH1p/wAOfEGstqOp eFPEUvnalpiqVmLBi6cDlurdVO4jPzc80CPRAKTvR2pT0oATvSUppKYC9qSlxRQAUGjvQRxSAOfw pKXNFABRRR1oAKSlFJQAZooopgApTiig9aADvSmko96QBQetIetLTAO9HUcUYo70AHejpQOtBpAH oaKMYOKKADPIopfakoAOKUHikNA6UAPHSigdKKRRyHg3nQrcYwcc/nXVjtXKeETjQbbAGcEfXmur WmQhaWjNJQMWjOTSZpTigAoopKAAmig0GgAFFAopgGeKQ0tBpAJilPNJn5gMfjSnpTAO9FBFHekA maWg0fjTAKKKOtIAHWijFFABnPFGKMUcGgA6mgmijFACdqXHNFLgZoAKTrS0mPzoASl70CigAo60 ZooAKKKKACjtR070UAcdrfgy81Tx3Y+I7bV/sX2S1EIRYBIxbL5PzcYIcjp2rqns7aS4guZYIpLi AERTOgLpuGG2nHGe+Kn70GgDCv8Aw7/bOrQXWqz+baWcvmWtlHxGzY4eXP32B6AYA963epzRR3oA OtHfmjNBoAKKKWgBM0daWigBKz9d0xta0G/0xbg27XcDwiULu27hjJHceo71oUvGaAOd8H+GJfCm ixaa2qz30cYO0SRoipkknaAN3UnqxroaXNJQAtIaXqKQ9cUALzijoKTNA9aAIre2t7SNktoIoUZ2 crEgUFmOWbA7k8k1kaPompafreq315r1zf2146tb2sqgLbAZ4GOPQcAdOck1uCl7UAApO9LSUAFJ QaWgQlFLRQMSg0CgjNAhDnjFGPypccUUAIBXKweD7mDxzqXiOLWZYkvVjVraOFT8qKoILNng7ewB 5PNdX6UHNAB2rktF8Fz6R4v1fXV1hjHqMoka1S3UAAcgFjk9SemK66igYd6KWgjg84oASl5pO1Ln igAHFc14j0HWdR1PTtT0XXXsJrItutpVZ7e4U9nVWGf84wa6XijHWgDj5PBVxeLqt7d6u0Wt6lbp btd2MRiW3VCCBGCxYZI5O7nAxioIfCGs6pBp9p4q1Wzv7PT5lmjEFu6SXLKCFMrMxBHOSAOT39e2 70vGaAE/nR60UHpQApo9KSloAKTvSmigBPal6UUUAFcn498GP420q1sFvxZrDceaz+XvyNpGAMjn nvXWUUAQWkU0FpHHcXLXMyj55mRVLH6LwKmNL2zQKACjmiigArN1+z1DUNCu7TSr4WF7Km2K527v L55OPpkZ7ZzWlRSArafFc2+m20N5cC5uo4lWWfbt8xwOWx2yas0UUwEooooAKDRRQAUUUUAIRkVH 9mgF0bryI/tBTyzNtG8pnO3PXGecVL2opAJ3pMYNKQaXFAGL4b0zWNLtbmLWNY/tR3uGkhlMewoh x8h9cHP8ulbNLRQAh6f4UtAopgAopaDSADRR3opgFcv488KzeMNCi0yG6jtitykrSOhb5QGBwAeT 836V0/0pe4oAz7TTpP7JWy1W4XUyRtkaWFQrgYxleR2zznmtDrRRQMKTvR34o70CMLUNM16fxVp9 9Za2tvpUSYubJoQ3mnnkHtnjvxit6gUUDCkFLQO9AB2qKW1guJIZJoUkeB/MiLLko2CMj0OCR+NS npQOlAGH4psdevtLSPw7qkWnXqyhjLLEHVlwcr0OO3btW1GGWNFd97hQGbGMnucU6igQVna5bahd 6JeW+lXi2d/JGRDOwyEb34P/ANatGk60gKOjQX9to9pDql0t1fpEBPMqgB27nGKsWtpb2UC29rDH BCmdscahVXJycAe5NTUUwCsXxNZa5faUsOganDp14JVYyyx7wUHVf5VtUUAMiDLGqu25wAGYDGT6 47U+jFFABRRRQAUUd6KADtRR2xRQAmBiilooAKSloxQAUHrRQaAD0pcUlLQAnH40oooFAB1qBrO2 e+jvWgja6ijaNJivzKrEEgH0JAqboaXnNAB2ooNFAGJoVjr1neao+s6rBewTz77NI4dhgTn5T68b fyPPNbVLSdqACkope1ABikpaO9ABSHrS4ooAyvENtq13oN1Bod5FZ6i4AinlXcqfMN3GDztzjjri uZ07RPH2kXkrjxDp2qR3Sq0v2+ORfs8vG4xqvBXr8uUHTpyT3VFFgMXwr4Ys/CWgRaVZM8gUl5Zn wGlc4yxx04AAHYAU3TLPxFD4j1W51DU7WbSJdv2K1SLEkWMZy3Hvx82cg5GMHcpaACgdaDRQAGg9 M0E0dBQAZpsqs8TqrbWKkBsZwfWne9FAHH6D4T1rwvpMOnaV4kSaCOMDZqVkZgrY58spIhVCf4SW x2PrpeHvC8Wh3V/qE1097qeoOr3Vy8aoDgYCoo+6o9Mn61vY4o7UAA6Up7Cj+VJn2oADRS9aT60A GKKCaDQAUdqPalPFABjiko+lFABSUvek70wFx2oooHWkAlFL3opgAoz7UDig9aQB3oPWijFMAoPW jtR1pAB9KAKKMUAHejFKetIOKAF70h60daDQAemaB1oFL3oAQ0DoaOtKOhoAcOlFA6UUijjvB2Do dv8AMOM8fjXWIcjNcn4O50CAd8nB/GusjGBTIQ+jpRRQMKSgHFKOnNABSA8Ud6UdKAEpT1o9KSgA 7Unal7UdBQADpR1FHWg0AHeg9KO9BpgGc0UZo9KQB1ooo60AAoFKKQUAH0NAoHWgcUAHajFA6UGg Ao+tA4opgFGOaO1FIBTSdqCeKBQAUd6KM80AA6UdqB1ooAKKO1FAAelHaiigAxSUoooEFGKBRQMK D2o70HrQAdqWkoFABnmjvRS0AJ2oFA6UoNABSdqMc0c0AL0FJ1NGKMc0AFL2pO1HagBRSZ7Uciig BaSjHpR6UAB6UUd6KACigCigBKU0elHXigBO1HalooEJmlpBS0DE7e9L2oooAXNGOtJQaAClxQOl HOKAAdKBzRR0oATvS96O9FACd6DzQKWgAo7UHmjsKAA9KKO1GKADijqKT2oz2oAU0g6UtHagA6ij PNHag0AHWigUUAHaijNHegYe9LSdaKQBSUtJTEA6UUooPWgBKKKKAFxSUvakoAKKKKACjvRiloAS jvRR3oAD7UuaOlHGaAA0UUZNABSd6U4NA60DA0dqWjvxQAmOaQ06kPSgAAoA5paT3oEHSjml60go GHajpR0FHagAo7UUCgApKWjtSEJS+9JS0wCkoFAoAWkoFFAB3ooooAKKKWgBP6Ud6KM0AFFFFABQ KKKADvR3oFGaACloHrRQAUdhSUvpQAdDQaDR1oATsaX+GjpR0oASilpMUAJS9qOlFAASRk9fajrR RnFABQaKKAEopaSmAdqWg0E0AHagHmgmjHNIBe+aCaQ0poAQdaDRQTzQAvTpSdqXPNJ16dKAF7Zo oxR2oASjHNKByaQjFAB2NJSmkpgL3oPSk60GgBelFAoPNIAFFHSigA9KTvS0CmAD0opaTFIAHNBF LmkoAM0c0GjmgAoPWijvQAtBpO9FAB3pevFHekoAMUd6XvSUAKOtHegUd+aAE5pRyKQ9aWgBw6UU DpRSKOO8HHbokHTvz+NdavQVx3g1t2iQg9Q3UV2KjimQhR1paTvQaBh9KKM0tAADiijikoAXNJ2p aD0oATtR2oooAO1Bo6UUAJSmg8mkpgKRiiig9KQB2ozzSdaX1pgGaWkFApAL3pPSlooATvRmjGBR TAKO9Ao70AFLSUZpAKaSijFABR3oooAKKKKAAUUUUAHal6ikoPSgA6UGig0AFFHagdaADvS0melF AB3NFLjvQaAEPWl96O9ID2oAMcUCilFACDpRS55pO1ABRj3paMUAFHQUDrijtQAgyRzS9qPakzxQ AUZ5oo70ABooNFABRRRQAd6KO9HqKBBSCijpQAd6WkzS9qAClpKKBgetLRR2oAOgoJpOtLxigA6i jOaOtFAAOtHejrR3oAO9JmlpMUALRzSY54p3egBD0o6UGjigAHFIelO60lACdKWjNAzigAxSdTS9 qTvQAvSigUUAAooHSj60gD6UUUUDDpSdqWkzxTEKKD1oo70AIOpope9FACdqKXtSUAB7UUHtQKAD vS0lHekAUUUUwFoxSUtABR3opMg5welAxaO9HaigBaQ8UtBxSAOtNp1IaYBjiilo70AJSgUZpKQC 0dqTtS0AJ2oFB6UdqYBQelFBpAFJ3paQ0xC0lLSUALSUUUAFFHaloASlpKKACiiigAooxRjigAoo FHWgAFBpcUd6ACijvRQAdaMYo9qUUAIRR3oPWg0DA4oPSgUdqBBRjikzxR2oAQHP/wBel7UUvagB KKKO9ACd6WjtRQAUdaKM0AJS44oo6UAHc0UvU0CgBKU0h6UdqAAdaCOeKPeg0AKe1IOBQaO1ABS0 UUAHek60tJgmgA7Ud6KM80AA680UdTQeBQACg0CgigAo+lHaimAUCgUUgDmjpQKODQAUZpR0pPWg APJooFBoAKXvSDmloATvSjrQKTnNAC9aBR34ooAQUuKTpS5zQAUlLSdDQAtGaQ8dKUdKAHDpRQOl FIo4vwbxokIBzyTya69M7ec5964/wb/yBocnoTXYJwKZCHj9aM0mcmloGApKWkoAXmko7e9HU0AL SUUdqACigcCimAueKQ0CkpALQaKDyO4pgFJQAQAMk4HU96U54pAFJS0UwAUZ9qO/FFIBaOhpB1pe aAEooHJooASg0uKSmIXtSUvajGKBhRRnijtSAO9GKXvSGgAFH0ozgUdKAAUUUc0AKelJ2o9aO1AB RRQaAFpBQTRQAUUfhR7UAGaXtRR2oAB1o4/GjvSd6AF7A0UnalHrQAUZpOaUUAFJS9aT2oAOvWlA o4xQPu0AA6mk7UvrSZ4oAKKM9qKADtRRQetABQRRRQAUUUUCA0lLSUAFKaT1paBhiiiigBe9IeaB R35oAD2paQdOlLQACigCjNAB3pe9N6mloAT60tJ1pfWgApab3pT0oAUik70p6c0mKADtR70YooGF Jml7UlAhe1J3xSjpSd6AFozSGigBaMc0UUAFFFFABSUdaKAFFFFIetAC0naiigBfxpCaO1FABRRS E80ALRRRQAUUUGgAxS0g6UUALzQaBRQAY4o6UZo70DDmlopKQC96KQdaKYC0lLSUAFAoBoHSgANL 2pDmjpQAdaBQKKAFpO1FJSELRRSUAFFHejNMAooooAWko70UAFFFHagAooooAKDRSUAKOtFFA60A KOaDQKSgBe1HaiigYEUDpRg5NA4oEFHejrR9KBhR2NJS/WgQUlLmk7UAFLSCg0AAoFFA60AFBooo AQUtJRQAvak7UUDpTAXoaO9HejvSAKO1HOKKAClNJR3oAWkJo70YoAUGkNAoNAC9aSkpe9MBKWk7 GlxQADrQfekpT0pAFB4oFH1oAKKSigBRQDRQKACiijtQAc0GlHNIaACijNGaYAKXPNJ2o5pALQOl J0ooAXvSUvekPSgBaT2pe9IetABQOtGM0CgANA6UGgdKAHjpRQvSikUcV4MI/sWLIH3jXXxZx/jX H+CwP7HXION1djH90ZpkIdRnmijHNAxc8UfWkoNAC8Unel7UnbigANB6ClPSkoAO1FHWigBR70na ig9KADvQaO9FMAo9KO9B5pAHejNANHemACij6Uc0AFGKXvSUgDOBR3o7UYoAKM0Ud6ADtRnml6ik xzQAvbFJ0FL2pKAEFL3o70UAFGKB0ooAKDRS9qAEo7UUdqADrRR1ooAKSlo/CgBaSjvS0AJSjpR3 ozQAGjPNGMmj1oATvSij2ooATvS9qO9FAABR3o5xik9KAFooo7UAFJkAgdzzSgUGgBKOlFFABRRz R2oAKKKKADNFGKO1Ag60lLSfSgBaSl60UDEpaKKAAGjtSFQzAknjoKWgAzxS9qSloAM0CjmgUAJ3 pe9B5+tFACUc9DS96Oc5oATHNL2FHfFA4oAWk9qUnik5NAxQKTpRntRQBDd/avs7CzMIn42mYEr1 5zjnpXlFt8UPEd54r/4R6PT9IWdrx7QTGSVkDJuBPYkZXI6envXrFzcw2ltLc3MqxQQoZJJGOAqg ZJJr5qTUpdA8fQ69qVhdJE10dSELKvmNDLuKnGcZAbpnqMcUCPpKyF2LRRfGBrjJ3GAEIRnjAJJ6 YqprsmrQ6dJLpH2Hz41LkXgcoQBn+E5zV+GaO4t4p4mDRyqHVgeCCMg1BqbbNLvHJYBYHOUxn7p6 Z70gPNfCfxM13xbrK6bBp2mWrtC0weSSRgQCOMADnkflXpVz9v8AsB+yG1+2YH+uDeWT36c+uK8H +D0wXxvAvlmTfYyqCWH7v7p3fpjj+9X0F6UwPJ9P+KOv6p4ot/D8WlaZb3L3EkEkrzSMoZA2SBhT /Ca9Ut/P+zR/aTGZ9o8wxghd3fGecV8/+FZFX41JnMgOp3gBzjkiTn+tfQUkqQxPLI4SNFLMx6AD kmkBxnjXx9F4U1bR7IeQ/wBpl3Xm/rDBnG4cjBJPU8YU12qsGAZSCpGQR0NeBeNdJ1DWfD3/AAnN 0joLq5KpC/VbNsCAkAcHucn+P8K9H+F3iM694RiimdWvLAi2mG7JKgfIxHuP1BpgVPHXjTXvBlxb SfZ9Lu7O6d1iX94kqhQDzyQevX6cVs+Ctb1nxJpEGr3yafDa3Cv5cUAcyKVfbyScfwt29K4/44ti y0QZxmaX8flFdN8LCG+HWlYWMcSj5DnnzH6+9AE3jfXtb8MaZJq9lDp1xZQlBLDNvWT5mC5DDI6k cEf4Gj4F8Wa94wikvZrbTbSxgm8l1Xe8jnbng5AXGV6g5zT/AItIH+Hl7naNs0B5OP8AlotUPgww bwfdYGMX78+vyJQB1Hi7xVaeENAl1S6QzMCEhgVgrSuewJ7YySfQGs2xk8e3umRX32jw9A8qCVLV 7WZtoIyFaQSdemSF69u1Vfin4YvvEvhmL+zlElxZTGfyM8yrtIIXjluRgV574V+K+qeHCNL122uL y1gGwBl2XUHoDuI3DHY4PvSA9G8LeKdd8Rza9aXFlaaZfafLFEkUgaRVJzuLEFSwO04wAMEda5q1 +JXiW78Wf8I4thpEd0bx7UT5kZAVJBO3Iz0Jxmu88PTaNqoufEOkTecNTEfnNuHDRrtCkdmAODXj eitn43jA3/8AE3uRlgCf+WnvQB6n4p8Yz+F7Gwtjbx32uag5htoogUiL5A3Nk5C5ZfX696kY+PYE Wbd4dvWQAyWkcU0DPxyFkZ2AOehK4POcVy3xc8L6hqSWWuaZFcTy2cZjmjiOWRM7ldFHJIOc49vS snwt8ZpINtr4kh+0KCqC+tgNyj1kXODjuR+RoA6zTvHt3cfDzUvE93Ywwz200kaWu5gAQ4VUYnnd lsE4HPYVb0jUfH2pWC3c+k6JY+YMxwXE0vmY/wBraCBnj3Hcdq1rPSdGu9OcQeVd2N3dG/BDh43k LB9wI4I3DNcx4q8XSeF/iNpSypeXVpd2JjktbfLsG8z5XVM8nt0zj1xigDKs/inr154ji0D+xtMW 9a6a1Mn2lygdSQTjbkjj/PbZ8YeLvFHg60iupdN0y8t5cR+dE8qiKT/aGDweccj0+vmWhXKz/GC3 nEMyrJrEriOdTG67i3DKeQRnp6iveNfi0278O38GrypDp0kDLPI7AbB/eye4OMe+KAKOh+Jm8WeG E1LRFt47onY8N1uKxOOqkryfUHvkVxek/FDX9X8Tw6AmmaVb3Ek0kPmvNIyZQMTgAAnO04/CuJ+H 2salofiSa80nS9U1bTWxFdrbQM5K/wADHHAcdcHHBNL4DkVvivp7Is6Brq5KrLgOP3chw3v6igD6 Kg877PH9o8vzto3+Xnbu74zziuB8Z+OvEHg67TztDsrmxuCRb3CXLr8w52v8pwxGMfQ9ccegA5rE 8XW+k3fhTUIdcuI7ewMX7ydv+WZ/hYf7QbGB3PHegCPTvEMviXw1b6p4e+yNNJw8N07ARsAcoxUZ BBx26c9xXH+G/ibrnivVjp1jo2m283ktKPtF45Hy4BHCdckfrXHfDjWtV0HWLiWysNT1bRXYpcmz tmcbgDskVTjDeo64PPQVL8JJWk8fFt0mDazsdx9WXr70AeueKvGFh4Q0lLm/KvdSDENpE43ytxnG f4Rnk9h7kA42j6n4+1/TBqkCeHrC2uF8y0guIppZCh5XewdQM+oH4V5j8Ubh9S+Id7btIxWFYbZA WGEyoJxg8ctnnBr6GjRYo1jRQqqAqgdAAOBQBwPhr4kNd6/J4c8R2cWnarHI0QljkPkyuDwBu5BI wRnOfXJArvz3rwP4vK1t45eWB2ilks4pQ6HaQwLAHI7jav5CvctMuhfaVaXYJPnQpJ8xUnlQf4eP y4pgc9408WX3hyXTLPS9IbUr/UGkEcQYgAIAScAE/wAQ9gM5I7xajrHjHS9HutUutM0IQ28BmaFb 2UuMDJGfLwT/AJz3rqGsLdtSj1BkJuY4mhRtxwqMQTx0ySo59q8t1/xd5Vx468M3cV9M7I0lvLCh lWJGhT5WIzsGe+McnOKQzZ8HePNb8YalLDDpdjaW9rGj3DvO7sdxIAUYGOFbrntW5qPiLUZtXm0b w7p0V3dwJme7upGjtbdiAQhZVJZ8EHaMYBHNcP8ABJy9xr2Vb7tsd2eP+WvGK9eHemJHnmr+IvHv ha2XUtXsNC1DTVYLMuneckqA9GJckAZ9vy611PhnxTpvivTBd6fKN64E8DH54W9GH54PQ1a123ju tA1G3mGY5LWRW5A4Knv2rxP4P3ksfjNEViUubNlkDMOi4ZT79+nrSA9Vk8YQWnjxvDd75UQlt0lt Zi2NzkkFDk9Tjjp6V0F59q+yv9iMIuMDZ5wJTr3xz0zXjHxS0u9u/Euo6lbbpIdPtrYThH+eIOXw wA5wCMk9RnPTp2Hw28cf8JHZHTL+Qf2raoDuP/LeMcbxyckcbvqD34YFzRPEHijXLi+RNN0m2Sxu XtZd9zK7O6jquEHHKn8/Xjmn+K2sQeIP7FutDsILhboWryNdvsUkgbvuZxzn6Guw8IkfbPEwBJxr EvJOf+WcdcB8ZNBEGoWmuxAhLkfZ7gqcYkAyjfioIz/sigGeuZvzpx4thf7Om5jEH+vXFc74X8Ra 34gurs3Gm2NvZWtw9s00dy7mV04JQFANue5P8q4q0u7zUPANvqlv4s8QtqbyiyjthPBg3LHaAfk3 Fed3JJC89q9S0fTIdF0i00233eVbRiNSzbifUk9yTk0gMXxlrur+GtJn1a0hsLi1g8vfHM7o/wAz hTgjIOdw7DHv0qj4M8Xav4viluhp9ja20E/lSDz3d243ZX5QOARwffpUvxSbb8OtVPPWAZH/AF2S sT4Mv/xT+pA54vcc/wDXNaYHaeJfEdl4W0WTU73cyKQiRJjdI56KM/n9ATWFp19491XTYtShTw5b x3AEsFpMk5fyzyA0gIAbHohFL8TdAvfEHhPZpwZ7m1lFwIVJBlUKwZQB1ODwK868JfFPUNARdM1a 3kvbO3HlqANtzDj+E7iA2OmDg+9AHo/h3xXq+v3+uafJp9rp97pvlosUkrSgud24kjHy4Axgd+/S udPxQ1tfFC+H20bTTdfahaGUXbhC+cZ+5nHtXcaHPpOrSza/pdys4vYoopNrA7Sm4gEDo3z4IPoK 8bjYf8Lu4Zh/xOSP9Zj9T/L8BSA9V8SeLZvC+l2S3EMF5rF9L5NtbQuUR2zjOWyQoyuT6ketV1l+ I1vB9pmh8OXe0B3s4RNHIRjJVXJK57DIwfWud+MuiX97Y6ZqlnE8kFh5q3AjJ3oHKbXA9ipyRyMj 8M7wv8ZDDCtv4iikmVQAl7aoCcZPMi7ufqv5UAdLY/EW4uPh9rHimbT40+yXLRQ2wYg4yiqHJ/iy /OB+FaOl6p461CzS5m0HRrTzDlYbi9lWRV4xuCxsAevv7DFaFloGkz2LyRStd2d1fDVIz5mU35DD GOq5GcHNYHivxWnhfx9oZuBdS2l1bTRSRW4LEMXTa+wH5jxjAGcE4z0pgY0fxU1qfxHHoY0XTo7p rz7G0pu3ZNwfaSPlBI447/yrW8W+NPE3g+KGe50XTbm2mOwXENzIFR8Z2sCnGecHPOO3SvLtNukP xRt7hRKUbW2YBwY2+aU9Q2CDzyCPavf9btdOvdBv7bVjGLB4m893OAi9d2exHBB9RQBm6D4pPizw z/aGjJbpeq3ly29yzbYnHUEqM4xyDj+uOV0n4l65qvihfDq6Hp0V4Z5IWlN65jUxhi3RMn7pxXBe DNT1XQPE81zoNvqetaYkhiuRa2zsJY+drEcAPjkZx3Her/gqcXHxjSYLNEZby7fZMoV1yshKsOcE dMUAe9W3n/ZovtPl+ftHmeVnbnvjPOKyNd8QnTLq302xspL/AFa6UvDbq21VQEAySP8AwoMjnBJ6 AGtoZx707v05oA4u8k+JUMEtxbr4WkKlmFsEuCxXrtD5ALdvugfTseD/AIk6Z4rlFlJBJp+p4z9n lOQ/XOxu+McggGu06V82+Lt+j/E/UJYFIe31GK5jAA+8QknH4t+tAM9d8b+LtX8HxQ3gsLG7spp/ JQGdo5Adpbn5SD91v0q14K8Qaz4p09NWurSytLCRpESKNmeQlW27txwMZDDGPTmuc+NbA+HdK+Zt pvv4XGCPLft3rX+E0vmfD6zQpKvlzTLufo/7xjlfbnH1BoA6zUXvYrNn09bZp1523DMqEd+VBI/I 15t4a+KWseLdXj0yy0nT7OWWJpElnuXkACjOMBRk8+o4zV/VfGLaR431vRZ4dQuori0ikga1haf7 MxQqcovIB4PA6/XNeffCBR/wnVmChJSzlKnPAOFGf5/nQB6j4z8Wa14PtLe/ew0+8tppVh2LO8bq 5XcedpBHyt6dqn8FeKtT8WWB1ObT7OzsRK8WPtDSSfKBz90DGaxPjSzL4VsMfdN+oOGx/wAs5O3e rHwcwfA7gKw/02XJJyG4Xkeg7fUGgC6niDxL4jga68J2OnQ6eG/dXmr+aPtS4+8kagMFz/Ex57Cs rUvHXijwbeWy+LdK0+5sro7UutIMg2EdQVk6nHOMjPbODj0gAAAAYHYCuJ+LFt5/w8vpA21reSGU c4z+8VSPyY0AdKNasp/D0mtWU8dzaCB50kU/KwUEn6cgg9xXL+HfFHjLxHp0eoQ+GdNs7WVN0Ru9 QdWk9GAEROPrjI6Vy/wcP9paT4i0S6DS2LCMshbjEqurgemQldj4+8Q/8Ilp+jakqv8AZotQWOWC I7d8ZikBXHQ44YD1UUAc3rXxW1bQNam0i98O2TXUWzLw6izI24AgjMWR16EZr0fTTqRtv+Jolok+ elq7MuMD+8Aeua+efHOqW2p+PrvULQz+S/k482JoW+VQDw4BHT0r6D1jWtO0HT5L/U7qO2tkONzH 7x9AOpPsOaAMbxp4k1LwppjatBY2t5ZxtGkiPM0cgLNtyCFIxyv61T8E+MdU8YpNd/2dZWtnBP5E gFy7yE7A2QNgGPmXr71y/jrx1pniXwHqMOmWmrPCZIgL1rJ0twVlQkF+3THPcgVe+Cn/ACLOpADB /tFstx/zzjoA0x4x1zxD4ivdK8J2mniDTpPLur/UGZkY9AERCCeVcZzjiqmv+NfFfhWa1tdU0rTJ 2vJkjgv7ZpRCBvAZXQjIYrkgBj+ODXnUjeIPhR4qfy2klhbKrJPuMF6hyQTg/fH5g56g8+i6d4t0 H4lWK6LcNPpuoGSK4ELlSWMbq/7p+h6Y5AOCTikB6P04oFJ15pccUwA9eKB2oooAUnsK42fxRq+t apf6Z4QtdPlNgypcX+oSsIQ55Maqg3MR3ORggiuunSR4JEifZIyEI/8AdOODXz94C8YSeA9XvNO1 i2uPKmcJdIF3zRTLxuxn5gQTnGSeCPcA77w/418Wt4kuNF8ReG1R0gkmWa0jdUAQZ6sWDhjgAg9T 09HfD34jXnjPWdQs7nTIreKGLzo2iZm8v5gNjk9W5z0HQ8V3tjeRX9lDd2/mCKZQ6+ZGyNg+qsAR +NTn60AeeeM/iJqfgrUYLe60mzu450kljaO6ZCFU4AIKHnkfrXXaJca1dQLcarb2VussSukUDuzx k8lWJAB6joB0715P8cmP9r6UuW5s5uh/2lr2TTZfP0u0mO0+ZCjfKQRyoPBHBFAFmg+lH0pe9ABS GjvigigA7UGiimADrQaO9BxSAKDRRQACg9aO1FABSCl60DrQACjp1oBoNAC0h6UZoIoAMc0uDikP WjvQAYoPWjrRQAYoHAoPXrRQAHtRQetFAB34oo6GigBfSigUUAJ6UopOlIclGA64oAkHSihelFIo 4nwUSdITqRu612KdB0/CuN8G/wDIIC4z8x612EP3PemQiWg0CkoGGfSlo+lIaAF9KSjPAoB4oAMc 0EUv4UUAIDgUUo6UlAAMUUd6U0AN70tGOaUjmgBD1ooPWg9BQAe9IKXFHegA6GjtRQBQAUUvcUmK ACiij3oAOlHeijvQAUtJS0AFHWikzQAd6XvSd6XvQAlFHWjigA7UGjsKKAA0tJRQAYoNHWjpQAUD rS0negAPBpcUnelNACUueKTpS0AIaUHrSUvegBKXPpQOlIOtAC5pDRzSnp15oAUUnOaO2aB+lAB7 0DgYNJ3pc+goAKKKO1ACZoo69qPSgA7UUHtRQAUUUUAFFHejtQAGkpTRQIKSjoaO9AC0GgUUDDpQ TQaKACl7cUlLQAUCiigA70dDSY5pe9ACfSlBpOtBoAXvS00+tO9KBgelGaCaTFAB2owKKKBHG+KJ 117xDp/hCFkeF8Xuqrwf9HQgrGf999oI67c9jWb8WfC0GqeGm1eFVjvNLjLDCgeZDkbkPsOo/Hjm urXwj4aSbz18O6SJd27eLKPdn1zjrV6/0rTtViWLUbC1vI1OVS5hWQA+uGBpDPMfg14qE9tL4avJ 4/NhHmWe4/NIhyWXJPJXr04HsK6fw54vi8S6HqyXEtvHf2s89s8MTBW2gkIwDEnkdzxkH0rXTwd4 YjlSaPw5pCSIcqyWUakH1GBSSeDvDE0ryy+G9Gkkdizu1jESxPUk7eTQB4f8IZtnjyxUNGN9tKrb yM4254z3yB05xn3r2LTPF0Wr+OrzRLCW0uLO1s1leeKQMfNLYKgg4IA68ZB71cPgrwpnJ8MaN+Nh Ef8A2Wnx+EPDMQkEfh3SUWQbXVbKMBh1wRjmgR4Z4cuI2+MkEsEqCN9WuCrOVXIJk98c5wPXNer/ ABG1NRZaf4ajkQXGuXSWrgvtKwEjeR9eF/Gtr/hCvCmP+RY0X/wAi/8Aiac3g7wu7hm8N6OzAABm sYieOnO2gNC3qWjWepaJNo8sQS1li8kKgxsA+7j0xgEfSvD/AIZarN4Z8ey6Nduuy8ZrOXLjAlQn Y3XHPzDjP3hXux02wOn/ANnmytjZbdn2YxL5e3024xj2rM/4Qvwr0/4RjRf/AAAi/wDiaAOC+OTo umaKjuqyG4kIUuBxt5479Rz2z71e8EavLpPwWbU4Y0mksY7mRYy3Bw7EA46da7GTwh4alffJ4c0d 2wBuaxiJwOAPu06Dwr4dtRILfQNKh81Cj+XZxruU9QcDkH0oA4/x9ruk+IPhVdX1jfQOjtA6p5iF g3mKShGeGAzkDniqPwi1PT9N8H389/f2tpCL5jvnnVB9xB3xjmu6HgvwqDn/AIRnRc/9eEX/AMTQ fBfhUnnwzop/7cIv/iaYHLzeO7+5+Gl74rskgzBekRJjAkgEwXByThip9uenpV3WdO8G+OvC8msz yWvlCEudSi2iWDaMkFsZ47qfyrqYdG0u3sBYQadaQ2YcSfZ4oVSPcGDA7QMZyAfwrOvvBPhfUrxr u80DT5rhslpGgUFyepbHU+5pAcT8E7C9h0bU7qZWFjcTobZmGBJtBDOAex+Xn2PpXFafcJF8ZllW ddo1qUb3k6hmZTz+OK+gLrTLC9shZXdjbT2gAAglhV4+OnykYrNPg3wvtx/wjej4/wCvCL/4mgDK 8b+KJfCP9iXjuFs5L7ybtcA7oyh5BPTBwfwrE8e+H/Cer+Eb3xLCbJJ0iM0d/aSKqztnhWxw5J45 55xmu+XSNORLVEsbZUs2L2yJGFWJiCCVA4HBP51kDwF4TW9F2PDmmCYNuz9nGM+u3p+lAHL+Bzqe i/CG4u5Q8MiQ3F1ah13FVwSvynsTzj0NaXh680nxNf6V4uGo2Zu49P8Asj25KBopmILck5B+8Meh 49+0eGOSIxSRK8TKUZCoKkYxgj0x2rH/AOEM8LbsHwzon/gvi6f980AeJRTIvxn82CRSn9uNhnkG DlyDz75OPwFel/FnT7698EzLZxySCCaOeeNCcmJc5JHfBIOPbPauiHgzwtnH/CMaLj20+L/4mta0 srawgS3s7eG2gQfLFDGEVfoBwKAPOPgzqlhL4bk06O4t/tqXLyPFvUOykAhwM5IHTPtXn3hSRk+L Nkbclj/acw5bcSp3g8854Jr3a68JeG7yaSa68PaTPLIcvJJZxl2PqTjJpo8GeFlxjw1ooI/6cIv/ AImgDcHP1HrXmvxn0+9u/D1jc28cstvaXDPcIibtoKkBzjnA5/76r0eKGOCGOGGJI4kUKiIuAoHQ ADoKk5z6UAcD8ItWs7zwVbWUMsRurR5FmiVxuwXLBsZ6EN+ea88+FeYviTFEvAEdwhWRwGGO3Xk8 Dge57V7M/g7wxK5kk8N6Qzk8sbGLP57ab/whPhUqqjw1pAAxgiyjBGPfGaAPOvi74PvGv/8AhJdP hMsTRKl4sSZdGXhZMDqMYB9MDt09G8I+IbfxN4ZtNTjmhaVox9oWNwfLkA+YHnj1wexFbccaQxpH GoVEAVVAwAB0FYt54O8NX90bm60HTpJi+93NuoLn/awPm/HNAzxzxBFL8R/iTdW+iAzW6Klu9yv3 EjU4Zyc46ltvrivebW2js7SG2hGI4Y1jTPoBgVHYadY6Xb/ZtPsrazg3FvKt4ljXJ74UAZqz60xH O+MfEx8K2Wn3zIjW0l7HBcFh92Ng2SORyMA9+M1l67a2CeDvFuo2N7Fdx6rC9wrxOGHEKpgMD8w+ XPtnFdbf6Xp+qwLBqNjbXkKtvEdxEsihsYzhgRnk1k/8IL4T8/zf+EZ0fcV24+xR7euc424z70hn nPwTlA1bWoQ6/NbwuF3DszAnH4iuu0bxzbnxtrfhzVLyKKWK5H2JpXRA6lU/djplskkcEkHrxW6v g3wxHIrx+HtLidWDBorREII9wBx7VYm8O6Ncw3UVxpdpPHdSebOssQfzHxjcc98dPTtTAxPHvizT /D/hu8RruD7dPCY4IN6liWyu4r12jnn2xXJfCLwleWc8uv39s8EbwCKzSRcMwJO58HkDAGPUHPTr 3Fh4B8KaXeLdWeg2ccy8qxTftOQcgNnBGOCOldE6LIjK6hlYYYEZBFIRy2nXFvc/EHxHZgwyYs7Q SoXBOf3uQV7jDLn6j1FeV+N/C914F8RW+q6RI0NjJMHtZFOPIk5JjOMZU849uD0r2RPB/hmOUSp4 d0lJAdwkWyjDA9c5xmtK9sLTUbVra+tILq3YgtFPGHQ45GQeOtAzifhdq39s2ut3ziJLi4vhNJEj 52kxoCcZJCkqcZ9Pauo8SaJD4h8P3mlzDiZPkP8AdccqR9CBSW3hTw7Z3C3FroGlwTIQVkis41ZS PQgcVrUAeLfCbQ72fW7i6u8pbabKwNuX+7dbduSvspYZ969Z1y+fS9A1C/j2eZbW0kq+Z90lVJGe Rxx6irVvZ21o07W1vFCZ5DLKY0C73IALHHU8DmnzQxXELwzxpLFIpV43UMrA9QQeooEef+L9atPE XwivL+3ljfzYoXaOKQMY38xCVOD1HcVnfCS9tLHQ9XjubiG3WG5V5XmlVQCVAOQegHAyepzXbf8A CE+FNxI8M6OCe4sowR9Djig+CfCvP/FM6Mc/9OEWf5UAc3L46vL/AMF+I9b0lYFGnXRS2k6iWJWU kkE8EqTj+VXNQ0vwf8QNGbVd9qf3e77fC6rLBgAkOR6dw1dFF4d0eCwlsINLs4bOZg8lvDCER2BB BKjAPQfXFZ954C8LahePd3OiWrTyAK5VSgYD1CkA/j6CgDivgtbXQtdXutxNk8kaRkcCR1zuYe2C v+RXI306W/xkknEiIiayhZ3Iwo3AEk9PWvezpVh/Z39nixthYgbRbLEojxnONvTrWb/whXhUq4Ph nR/m6j7DH/hQBS8ZeJ28Iw6TeSnFpLeiG64H+rKNzzjGCAfwrnvHvhjwrqHhS88Q2jWVtcJH50V5 buqxzn+62PlYtnGeuSOe1d22haSYrWL+zbUQ2rl4IhEAkbHOSF6Z5P51ljwB4SF79rHh+wEu4MAI sIDjGQn3QfwoA5f4fDU9E+F19ezIIwonurNJs8IFyMjsCwJx6GtTw7ead4tutF8U/bbX7VZ2bwTW vylopXK5PJyv3Wx6hq7SSCKWB4JIkeJl2tGygqVIxgjpjHasN/A/hNnVj4Y0bcvTFlGB+IxzQB4b EcfFRdnX+3W6vj/lue4r1b4s6fd3/ghxa28s5guo5pI4gxbYMgnaOoGQfbGe1bx8E+FcH/imdHGS DxYx8fTjjpWta2VtYWyW9nBHBChO2ONQoGeTx9aYHm3wX1izk0G50v7VAt0l20iRb1DyIVU5Azk4 ORmuQ8Pu0fxo2whNx1S5Vg7fwkyZ698V7Jc+DvDN5L5tz4e0qWYvvLtaR7mPfJxz+NKPBnhYNuHh rRg2cgixiBz/AN80AbgGO1cRr/jWPw58QtP0/UrpLfSruyOXkwFSXedrE9QOMHPHIPY12dvbw2tv HBbxrFFGoVEQYCgdgKr3Gk6fdXEs11ZwztLCIHEy71ZASdu08YyaQCalq+n6Rpz39/dwQWqjPmO4 AbjgD1JxwO9eJeGdGufH3xAm177I8OlC9F1K8i7Qdv3Ix2LHau7HTn2z6kfhx4Ma5FwfDenhw24A R4XPX7v3ce2MV0lvbQWlukFtDHDDGMJHEgVVHoAOBQB5t8bJEHhvTI2kIdr7cEB+8BG+T+GR+dUf CeuXXhz4L3WrW0UEkttdMVViGBDTKpyAwIOCepB6HBHX0a78MeH7+5e5vNC0u4nflpZrON2b6kjJ qJfBvhdUZV8N6OFcYdRYx4bnPI288gUwKOj3Gg6idS8S6dfwTnUII0k+ZMw7EPyHuDzyDXjvwfZv +E608KFObWUNz0G3t+IFe3f8IV4Uz/yLGi5/7B8X/wATR/whXhXj/imNFGPSwi4/8doGcr8aBnwf Zkg8X6d8fwP1qL4UXEg+Gt+yuoMNxcbGQjK/KG598k9e2K7O48I+G7pg1x4f0uZgoUNLaIxAAwOS M9KfbeGNBsmZ7PRNOtXZSrPb2qRsQRgjKgHkUhHPfDnxzaeKvDtslzqEDazEgW5iZkV3PA3hQfun I5A6nFYXxZ8WaZNoh8OWF1Hd6hdTorxWzeYY9jg7WCn7xIAC9fau4vfB/hzUbO2tLzRbKaG1jEUA eIZjQdFVuoH407R/CXh7QH8zStGs7WXkeakQ8zB6jefmx7Zpgc98MPC114c8OyTX6bL+/cSvCSf3 SgYRD78kn0Jx2qLw/rNp8QNK0yfULixi1DS783FzaLtYEoHRTtLEgfMCGyeV4rvqwT4H8Jnk+GNG znP/AB4x/wCFAHi/xVYD4h3ckThy0EDD5gVzt/8A1V1fxvs79rPS79VkOnW5kFxtbKJI20IxH/fQ De+OM897/wAIR4T5/wCKY0XBGP8Ajwi/+JrTsNLsNKiaGws4LWNm3FIUCgnpnA+lAHkE+uabd/AI 2Ud/ateQxxI9rFKFkXFwoyVznB4Ynvmtj4JEnQNXXcpxfA43ZIzGvbsOP51203gvwtPcefL4c0h5 CSSzWUZ3E9SeOT9amtPC3h+wuVubLQ9Otp1IIkgtUjYYz3AHqaAOYsPEun654q8QeENfNlP5VyBa W9yqYmQqCVwepU5I78+1cL4o8HwaN8S9FsvDCv8AaJ5Euha+aG+zbHyW5OQmATgnsQPQew33hnRN SglhvdLtZ0ll85/MjBPmdNwbqDgAZB6UmjeFdC8PO8mlaXbWsjrtaVVzIw9C5yxHA4zQBr0tJR25 oELRnmjrRmgYteFReLV074y3d94ikl+zW089tF5iki1U8IwUZ4IHUf3ia90rM1Pw5omtSpLqek2V 5KgwrzwKzAZzjJGcZ7dKAKOi+LrTxJqc0OjQvdafbgibUQwWLzOCI1B+Zjg5JxgetdDUNra21jbR 21pbw28CDCRRIEVR7AcCpsc0AeKfHPYNW0csdubWYbj0+8tejeC9ej1jQbFEtL2JorWMSSTWzxx7 gApCs33unUZHvWtd6Hpd/qNtf3lhBcXVqCIJJUDGPJB4zxnIHPUVoHmgBBR24o7dKOlAB3ozRnmj FAAelHajtR2pgFBFA9KD0pAL2pOgoooAMUUUd6AAUCigGgAFGKB+tGKAF4oPNJmg0AHrRRzmlIoA T6Uvek6UUAHU0vekNAoAO9FB60Z7UAA5o7UopDQAuKQUtJQAGlHekpR0oAcOlFA6UUijh/BgP9lL 06nNdlGPlHauN8Fc6QnXhq7OPhaZCH96M80UUDCjrSd6KAFzSdqWk70ALmkOMUpNJ2oAWko7UdKA Cg9KM0HgYoAKDRmgmmAUYzS0nakAUDrS0meaAFApOKXNJQAtJmijtQAe9FAoJxQAUd6O9HWgA7c0 UUdzQAtIaXtSUAHU0UnelFACikPSgUfSgAo9KOlHpigAooo7UAL3pDRRQAvc0g5ooHWgBaDSHrSm gA70UmaXtQAnWloyM0mcmgAHSgUDpS0AA4FJS0nWgBccUmcUopO9AADSjpSUooABSHpS5o7UAFIe tLRjpQAneiiigAooo70AFHrRRQAGkFLRQAUlLRQAlLSUvWgQUUUduaBh2ooHSg0ALSUopPwoAPal 70neloATvR3ozzS96ACgUdM0tAAaSg80dKADFFGRijk0AAo6UUe9AB2pMdaXtSUAFFFFABS0lFAB S0lKKQCUlOpKYAKKKO9ABijtR3ooAO1HajtRQAlFLQKAExyKQjPPf3pe9FIBMDNL0PNHNHGaYBig 0tFABRRRQAUtJR3oAWjtRRSAKSlpByKYDqTtQKDQMOlFKKSgAxxQaDS0AJR2ooHFABQelFHakAlL RR1pgJRS0lAgope1JikAnQ0uKKKYBSYpehooATqM5ox60vaigAoo7UmKADFLR60UAFLSdqWgBMUt JRmgAxRS+tJ6UALQaTNFAC0najnFHagANHajpR2oAKMUd6KACkpaTvQAtJS0UAIMUtJSmgQlFFL2 oGGKKKM85oAKCKCelFACUpFFJmmAvWjGKDRSAM8UdDQKOtABRRR7UAJ2pRR2pKYCjrR2ozQelIAx RSimkmgB3Sk70daOnNABQBRRQAYxRmiigAo7UUCgAFHNL3pKACg9aM0d6YBS+lJilpAB60mKKXrQ ACjrRjFIaAD0paKTvQAHigdDQaB0NHQB46UUDpRSKOG8FEDTAMcbjiuzjORxXGeCADpWcfxdq7OP ke9MhD6XtRR7UDEpR0xSd6DQAvbIptOpMUAFFLSGgBcZpO1A6UdsUAAo60ZooAKDQetHegAoPSij PFACg8UnegUDrQAUUAUUAHejFFA60ABoNFHegAFHejvRQAdqKDQAM0AHajFL2ptAC4waKO9HegAo oo6UAFBFFHUUABHFBHFBpaAE96KXtSE0AHvRQaKADvSmj2pPrQAdWpTR2o70AJ3ozS0nFAC9BR3p M8UDNAC5zSZxSjrRxmgA6daTvS/hSd6ADkUo6UopB0oATvQaUUlACjpSUCjvQAUUHrRQAUUUUAHe iijtQAUUGigApDwKM+lA96BAM96XvSUpoGFGKKKAAUUdqXNACUtIKUc0AHeigcUe1ACDrQDzS4oo ADR2o70vegANFB6Umc0DADmjsaOtJ2oELzikz1pRRQAdqTvS9qTvQAUUtFACUUtIaAFooopAFJRR TAWigUUAJRS0UAJ2opaSgAxRil70UgEpOlLRTASjvS4zRQAUUUdqAClJpO9FABS96SgelACkUUUU gAUYozRzTGAo60ZopALQKKTPFAC0UmaXtQAnelooFABSdqWg9KAEo7miigAooopgFJS0e1AhKKWk oAKDRS0AJ2ooooAKKKOKAAUdKM89KOtAAOtBxRml/nQAlLigUdqAA96TtSmgUAJR3peBS96Bidet B6UfWigQUnaloPSgBBR2oFLQAlAoo70AFFFFABR3opOtABSikpaYAaQUtHekAlLmijjFACd6KKO9 MBe9HQUtIelIA96AcDNJS9sUAKetJR3ooAMcZoozxRTAO9KTxmkoNIAoI70CjNABRSjpSUAFAFHe igBBS96PakzTAUUYoFHSgAHFHvQCM0YpAFHegUtACHNKKKKADvSYpe4oNACCilHSk70AFHegZyKM c0ABpR0pKUHrQCHDpRQOlFIo4bwSQNLx/t9K7KEDGa4vwfJEdNjWJZDz85bGAfb26V2cGNnHSmQi Wj3o60vegYnWiil4xQAZAFJmlxRQAnejsKKKAF4ooFJQAYoNAoNACZ5pSeKTvS0wD0pKU4xSUAL0 pabS96QBmijFFABS96O9JQAUGiigAozQOlHegA7UUUd6AFpO9KKQmgAHWigdaM0AFLSCigAz+dBo 70daACjmg9KO1AB3oOKKKAD6UUUDmgBR1ozSYpTigAHtSD3pcYoPSgAzz1o4o7UnegAHSlpM0A80 AKKSgUtABSDg0uKT0oAWgdKOtGARQAetHagUmKACjHNKOlJ6UAB60d6M0UALSGig0AFLSUUAB6UZ NHaigAoNJS0AAopKWgAopKWgAo7UUc0AA4NLSUooAPWjvQeeKXvQA3vS9jRgetJQAU70pKPSgAOa Ogpc/lQaAE7UHigd6OgoAKO1FHagA6ikpfpSY5oAUUnejtSmgAooHSikAlKDSUtMApKKKAFoPWig 9aACijvRSAOlJRRTAWkoooAKKKKQBR70c0nOfamAUtFGKACjvRRQAtFJRQAveiig9KQxBnnIA545 pfWk70CmIdSCijmkMWkxQKOaYC0dBmk7UvakAUCk7inUAJQelFB6UAJRnml70mOaACiijtTAKKPS g0gCkoopiCijvS0AJRR2ooAM0UtIaAFHWk70tHegBBzS+lFB9qACjtRQKBgetHejFFABR/EKKO9A Bmg0UmePxoELR2oo7UAIOKPeij2oAKO9FHQ0AFHOfaijAznvQAUZpKXrQAUDoaSl7UwCijNHSkAU c0E/nRQAd6O9JRTAXHeikpe1AAMUUCgcUAHeilpO9IA7Gj0oNHJpgHQ0HrRSkcUgAUh60oHFBHeg BKOhoxRTAO9A60d6QUALnmkopcUAIKXoKAOKSgAHWlNFGOKAE707jNNpe9AB3pfpSUDrSAUnmjHN H1pOaAFFJRRQAvejvR3o70AJ1xSjpSd6UDrQA4dKKB0opFHBeCzjTCcdW5NdpblSmQa4nwXn+zyF XjcOprt4OFximyES0tFBoGJ36UDvRRjBoAU0maWigBO1Hal60GgBKKXtSUAJSmigmgBKWkpe1MAo 70UlAC96WkxmgdaQAKPWgUUAA7UE0opKADtRRRQAUUUtABQaT1o70AL2pKKKAAUYxQOtFABRij0p KAFoPakpaAA0dqCKDQAfWg9KKDQAtJR60UAHelpO9LQAdqO1J3pf5UAIaXHNJ1pTQAlFA9aO9ACg 0CgelIKAF96M9KMUnOaAF/io9qTFLjigAFFA4NBoAO1J3oo9KAA0UYoNABRR3oPFAB60UdTRzQID zRRRQMKKMUUAJS0UgoELSClooGHA6UUdvejFAB9KKKKAF74oPSjvR3oASiig+9ABTh0HNNFLQApp KDWR4h8S6V4XsPteqXKxBsiOMEb5SOyjv/Id8UAa/NFefaN478Q+Ld0vh7w1ElkrbGutRu/LXdg5 ACKxJ+70yB/LI1n4s6z4e1SfTNR8O2RubfHmGG+Yq2VDAjMfoR1/SgD1iiuf8L6jr2r2kOoala6f a2dzAssMUErSSDIBG5sBcHk8eorkNK+JXiTxBrN7a6J4Uhvba2ldfOa88pQoOFJYrjJ64GTz6c0A en9qTvXB6v4r8aaHo8+p3vhbTmggAZ/K1MllXIHTy+etYfh/4q674j1mHSrPRNNFxKhbdLeOijHJ /gJPHYUAesUVzmqXXiux0r7VbRaLPLDC0lxG7SxhiMnCHnsAOe/tXAaZ8ZNY1i/tdOtdBsEubyVY 4XlvG2KT/ewmT+FAHsYoqnpp1E2Y/tVbRbnPItWYpj/gQBp96b37K32AW5uMjH2gsEx36c0gLFFe Sa18XNZ0DVbrSr7w7ZfarY4Z475ijZAII+TOCDnHXmu50HUPEWq6KL+6ttLtWuLdZbWNJHk2kjI3 nA4xjgUwOioryrxF8T9f8Kaw+l6lo+m3MwjWVZLe5kVSrZx1UkHiul8F6/4g8T6fb6tdW+lwafMX ASJpGlO0lc88DkdPSgDsKWuG8Q+PLiDxJF4X8N2MV/rMn35Jn2wW/G47sckgdRxjI5J4q3dS+PrG CK5RNA1QrzPZwRS28jD0jkZ2Un/eApAdb3ozXC+DviBL4u8R31gNNawhtLcM0c5/feZvwQewA6Yx mk17x1et4mTwx4TtLW+1UZM81yx8iAAZOdpBJHcDp05NAHd0cVyV23j+yhS4i/sDU9vzS2kcMts7 D0jdnYZ/3gKo+FfHl94r13VLCPTRp62dsCI7oEyLNuKkPg9OBwBnrz0pgd3RXkOt/FLxP4Z1ifSt S0XTJJ4lVlkhmkVHU45GQT6j2P0rs/BniDWPE2mx6rdwabBZSqRGltK8km4HB3ZAC9Dxz9aAOror F8R3mtWGnyXmkRafMsEbSTJdu6EgDPylQecA9fzrF8D+Kdf8VQNqV9pdnYaUFwj+Y/mSMOrAFQNn b6jv2QHaUV5boXxJ8T+KLm4g0XwxZzLFnM73jLGnpltvJPXA5xWzqfiPxto+l3Oo3vh3SDb20Rkl 8vUXLYHXA8ugDuAeME/jRXk2h/FrWNe1q20q08PWPn3JIQyXzKqgAsSf3Z7A9BXoVzrkWh6GL/xD cWdoUB8wxyEoTyQqbgCzEDpjJoA2OtFcIdf8da0qXGg+H9PsbJ+Y5dZlbzJFz97y0wV/HnkVk6r4 58aeEnt5fEuhaXNZSOymfT5HAPoBuJwf97Gc9sGgD1HODR3rB8NeLdJ8WWIuNOn/AHif663kwJYj /tD09xxVjxLqk2jeGtR1O3WJ5rWBpVWTO0kdjgigDXorI8O+IrLxNpEWo2LZjb5XQ9Y3HVT7ir92 br7HIbIQm5x+788kJn3xzQMno964O18W+K7nxRP4dOg6bHeW8QmluGvJPJKHGCv7vJzn9CO1dtLc R2to9zdSRwxxIXlZn+VABknJxwPWmBOKK4eDxP4p8SI1x4Y0awh07LCG91aZ1E4HG5Y0G7HuTzWD P8RvFXhvWY7LxVpFgiMN4a0DDenQshLsDg4yDg+3NID1agVWsL+21SwgvrKUS206B43HcVZoAU9K KKDQAd6O3FHWgUAFHaijtQAd6TvSk8UUAFIKKBQAUetFFACUtFHagBO9KaKKYg7UlLmkoAKU9KQd MUtABjFJ3paKADAo60dqD1zQAYoHSgUdqACj0ope9ACE0UdzRzQMPejtQaXtQAnakzxS9aTHFAgF L/Wk70uDigBKTvTs0negAHWjiiigAo70UUAJSikpe1ABRR3o70AHekpaBigBM0tJS59aYBR2oo7U AJS9aKPekAuaSl6UlABQOtHbNLTATvQRxRjmg/WkAvSg8UvSk60AAxSYyaM0UAHagHilpOtABQKB R3oATtRSgdqMYODTAOvWg0hOD/WloAKMc0CjNAC96QGilzSASjFLkZozQAgozR3oNAC9xRjvRQKA EzSjvSUo6Ghghw6UUDpRSKPPvBjH7AwAP3q7mHAQVxHgkD7Exx/FXbw9D0pshEoooHWg0DFpKKMe 9AC0dqSl7UAGKDR1oPSgAHpSCgUUAFFGaKAExS0d6KYgzRR3paQxKKOoo6GgA70UCigAzRS0lABR 3o6YooAKKKU9aAE7UD3oo70AL1o4oNJQADrQKBQKACjtR2ooEHpRRQeKBgTR2pKXtQAe9FFBFABR 7UtJ0oAOOlLkik70ueaAEHTpS9OtHej8aADoaTvRS/SgBPajvRQKAFpBmlHejtQAZpDnNKaTpQAv OaOaM0dqAEHXilPrQBiigBM0dxRQRQAdxRR0ooADRR0o96AAUdqKWgBOaKKO9AgoNFBoGFBoooAT NLSc0tACUoPFFFABQKO9FAB/FSnPaj60d+tACUvrzSd6WgAFLSUelAAetfLvjDxBLrniTUdTmaR4 1dordHGPLjUnaAOcE8k+pNfUTDIwQCO4NfJOpW7Wd5fWZhbdbTyR7JevysRg4x2HagGfUug2EWle H9PsYY1jSGBFwoxk4+Y/UnJJ7k14J8VTjx9qy5zmOI844PlKO3bp1r6Espxc2FtOoAEsSuACD1AP bivnv4pKv/CxNWG0DKwn/wAhLSBnuegtJc+C9MMEnlyS6dFsfg7WMYwfwNQRaanhXwNNaaaI45LO ydlkCABpQhJcjoSWGTmrPhRi3g/RGb7xsICfr5a1Y1jy30LUVZiUNtKrFeSPlOfxoA4jW9ci8T/B C61GOQTSy2SCYInImBXcu3t839CM8V598KHLfEWz+QY8ib/gPy9R/nvT9L8E3sfwrv8AxBc6pqNq ktuZ4tPgn2QzKNu1pBg7s+mOmORVf4UyFPiLYbduHimU5Iz9wnjP07UAfQl2Ea1mSQ7VaNgT6DFf M3gVwnjbw+NoZftaKN348/Wvp6RVdCrDIIIPNfL/AIIPl+ONCCqCReIOcHg8fSgD6i9a57Sdf+1e Ktf0KeQG4snilhGAMwvGp4xycNnOf7wroOQP515VfeCLjxL8U9Y1E399p1larCn2izl8uZ5DCvyo 2DgAEE/UfgAef/EooPH+tMGzlkJ6DH7tRjj6V9BeGj/xS2kkqF/0KHgdvkFfOvj3Tl0rxdqVl9qv bsIqYnvZvNmfMan5m79cD2Ar6H8MuW8KaOz/AHjYwk4/3BQB4p8YQq+PmxuO6yiJz0zlulenfCtw 3w50o+X5YHmDn+L943PQf59a8z+MWD49wpOTYRFuf9p69K+FUjyfDnTBIwbaZVBBB4EjY6d6YHjl jr2p+C/HF9e+UZbmK5lS5hn4MyM+Tz2JwCD9Oor3Lw1470HxSoSxvFiu/wCK0nISQe4H8Q9x+lZH jX4d6f4uknu7G5ittajwjuCCr/KMLIo5HGCD16dRXjWveFdf8I3CSahZywqjAw3tsxMYOeCHGCrZ 6ZwaAPfrPw+9l49vtchjjW3vbJI5QpwfNV+u3Hde/tXhNlrmoeDPHF3erGZbiC5mjnik+Xz1LnIJ wcZwCD7V6z8L/G1x4l0+ew1OQSalZYPm7QPOiPAY8/eBGDwOo96seNPh/pvjBpLm0njtdZhGwypg q52gqsoxnpjB6gHuKQGl4Y8f6F4pjVbS5FvedDZ3LBJc+wz8w9xS2Xh2Wx+IGo67EkX2W/s0jfBw yyq3PGOhXHOeoNeCa54S8QeFbhXvrKSJUcNHf27ExKcjBEgxsOemcGvX/hd4zn8R6fLp2pSF9Ss1 B844BmjPAJ5yWHQnAHT1pgU/jDoX2rR4NdgjAn09tspHUxMQP/HTg/ia434ceIfEsNzNoGgvo+Jy 1xGupl1UMMbgpTkkjnHtn1r3m9s4NQsZ7O6QPbzxtFIp7qRg18ySpe+CvGW0oftGl3QKkZ+dOD/4 8p/WkB6V4pv/AB80VroF63h5JdZf7Kv9mm4Myr1ZstwoC9Tz1r0hrA2mgPpunfuvKtjBb8424TC8 /lXIeGZ4vGHjm68UwxN/Z9lbLZWZm27hIfmkYAZxwwGc56iu/HX60AYvhHRP+Ee8K6bpbKBLDEPO Ktu3SnlznvyTTPGYz4M1wE8fYZvT+4fWt6sfxXtHhLWC4yospSRxz8h454oA8I+GMqp8RNHyVAYS qMtj/lk2PqfavoO70+0vvKF3axTrG4lQSIGCuMgMAe4ycV89fDFivxC0fAwP3gPzAHHlN69f519F S3MELwpLNHG0rbIw7hS7Yzhc9TgE4HpQCJc/jVDW9Mh1rRLzTJv9XdRNGTgHaSODj2OD+FXzjg9q aWVPmZlUDkk9AB1oA+XdA1658Oa7baxC2WibE6K+FljPDKecEdx6EA9q988dTg+ANbkDMqmzY9QD j0/XFfO80Zv72WK3QtLdTskQU9SzHaOvTkV9BeMoDbfDfW4WO4x6a8efXCYzTEjxvwt4rvvBmvvJ iQ27OqX1owBLAdwMjDgHj9a+h9O1Kz1XToL6wuI7i1mXcjowI+nHQjoR2NeV+P8AwS9/otn4k0+3 JvI7WL7dCg5dAg+cD+8vf1A9qxPhr42XQL5NN1C5YaRdHMbsci3lJHJJPyoec+5z3NIZ6Vpsxb4t a6hxhdMtQOOSNznjnkfN1qP4rXLw+BbiFMg3c8NuWDAAAuCck9sAjj1p2ncfFzWQqqFfSbZi4Xlj vYDn0x/IelVvi3x4I34B23luwyM4O70PX6UAd3HHHDEkUahI41Cqq8AAcAV5r8ZAF0zSJQcMLlly eBgrzz+A/WvTe9eafGYZ0HS8A/8AH76cfcbrQDL3wknMvhKWLzd6Q3Tqq8fKCAxHHuTXe1538H2z 4XvFy/F2eW6Z2L0r0PtQC2FNFHajNAw+lLQOlFAB2oNLSGgAzRQaM0AJRR2o7UAGKKKKACiijrQA hpaSlpiEpaSjtQAUdqBQaAAUdaKWgBB0pSKAaCeaAFxxSdqXNJ2oGFANGTzRQIKKPpS0DG0vaij2 oEHtR2o6UnagA9KKAaKAFIpB1paTvQAd6KKDQAYozSCg8mgBTQOhpKWmAYo70UUgD0oNFB6UAFJ3 paKYBQaCcCjqKQBRnmijjNAC4pKXqaSgA7UlKaKYB3pT0pO9BoAUc0dqQCl9qQB9aO9FJ3oAXFIK PxpRQAneigdc0dqAAc0UDFBoAMZzR0o+tKelACcUd6KO9ABQBR3o6YoAO9HSg0vagBM0UUdKAFz6 0gPNLnpSd6AD0NKORSUo6GhgOHSigdKKRR5/4MLGzbb0zXb24+XnrXD+CGP2B/8AeruYOVBz+Rps hEtGKKO9AxKXFApSaADvR0o60ZoAQ+tKaKKAEpKXtQOlAADzQaO9FACUUpoNMAJpO1LRxSAKKKB1 oAKSlpQKACk9KOnSigA7UDmjtR3oAKO9FFABjijFL2xSd80AHOKKXtScUAFFA60UAFBoooEHWijt RQMMcUdqDR2oAKKKKACjrS0negBaKQ9aWgBM0ppKXHFACUvrRjmjqKAEHSlxSdBSjrQACko70AUA GMgUh3ZHAI7nNOzzR0oAbTutGKM8UAFFHrSdqAFFIaUUnegAozjig0d6ACiijrQAUUUUAHaig0UC Cg0UUDA0d6KKAA0nGOKCKCOuOtAC0dqQdKWgAoooAxQAdaXvR3ooABSCijvQAd6XtRiigAPpXl/x J+HV1rN6Nc0KJHvSuLq3aTYZgAArJnjcBnOSAQB36+oUfWgDynwP8R7LSdGTRPFsk+mXtkqpG15A 0fmRHOwc85GCOQMgDqc15/8AEbWNK1LxrfXtjqFrcW8kcWJInznCAH+VfSrqrqVdVZT2IyKXgHIA 546UgOV8A65pGo+FNJtbHUrSe5gsYhNBHKpkQhQG3LnI57muOHj3TfDXj3xNoGtALpl5dCRZVGTG zxIG34b7hx1AyCTnrx60UUuH2ruAwGxzTWijdgzRoSp3Akd8Yz+XFAzzTxV4y8Hf8K81DSdJ1ywy tn9ntoY5MkAAAAZ56Y/yK8z+HOsaZp/j7Trm7v7aCBfNVpppFVVzGwHJ4GTx+NfTCxooXaijAwMA cClIBUqQCpGCCOKYjFuvFnh+0shdSa9piRPG0kTm6QiQA4yvzfMM8cd+K+bPDGpWlv4s0a5up7aG JLyJ5HJARRuHJz0HvX1SsEK4KwxgjJGFHGTk/rTlUKSwC5PBOBk/5zSA85+IHiux0uXw3rlrPDe2 ltqTpObaZHHMZBX72N2DkZPYdK0LL4m+BZ4TcprNrbS3BBlWVDHJuAwN3HJAAGcnp1rtI7eGNNqR Rquc4VABn1pViRMbEVcdMKBigD5k+IOr6VqXjXU73Tr2C4tpVjYSoeCfLVT+oNe6+Edf0a68I2DR atYyG0sYvtOLhD5OEAO/n5cYPWupAA6AD8KYYoy5cxpuIwW2jJHpQB86/FXWdM1HxoLiw1G1vIVs 44y9vKJFDAsSMjjv616N8J9b0hvBenab/admNQMkwNr5yCTO9m4TOT8vPT1r0XaoUKFAA5AxwKb5 MRKN5aZQYU7Rlfp6UwPM7vxBdeFviprdxPZXtzotxbW73UttC0gtSEwsjAdBhWyfQD0xW9rPxB8F /wDCP3M02s6bfW7xsptUmV3lyCNuzqM+pFdesUayNIEUO4AZgOWA6ZPfqfzqqmj6ZFdSXUWm2aXM o2yTLboHYccE4yRwPypAecfBzwrdafYTa/eo0Ml7GI4IWXBEYOdxzyMnp7YPerF34guPC/xQ1mWa 0v7nR7q2gkupba3aVbRwuA7bei4U578D0r0ymqiK7OqKHbG5gOWx0z60Achqnj/wQ2g3E1xrmn3d q8ZVraKVXkkB4wI85z9cVznwb8N3Wn2N3rd3C0IvFSO2jkHz+WCTuPHfI+uK9Jj0rT4Z3uItPtEm kGHkSFQzDjgnGT0H5VbxQAnavH/jH4blnutP1qxgd5pnFlMq55Yn92fzJGfpXsNRywRTqEliSRQw YB1BAIOQee4PNAGV4V0OPw34bstKTBaFMyNx8zk5Y5AGeSfwxWv3p1FACDNcz451fTLPwxqtnd39 pDczWUgiglnVHfIKjCk5PPFdPimNDG8gdo0LjoxUEigD5k8Aalp1l460e4vby3igjZwzySqqqTGy gkkgAZNes/E7Uc+G9Kv9ImW6uItWha2Nv++DyAN8vynJ9MDmvQHhjbkxoTjHKjpURsbPbEv2SDET +ZGPLXCPz8w44PJ596AOX0T4iaLqEIh1ScaLqkYHnWmpD7O2ccldx5XOcd/UVz3jn4l6cbCfRfDl 2uoaldL5RmtT5iRq3B2kfeYjgAZ5NekXen2eowGK+s7e6iOMpPErqcHI4IPemWemWGnKq2Vha2yD osECoB9MAe9AHm3w5+HU2mXEOua5CiXKpm1tDyYs/wAb5HD+gB4zzz06L4kazplh4N1ayur62iu7 q1aOK3aZBI+7jIUkEj/A12WOh7UxoInfe0UbPjG5lBIHpn0oAwfCmu6XrehWDadqFvPLHbRiSGOV S8ZAAIZckjn1ryn4neCF0K7fWLCJRpVw376NV4t5D6+iN29Dx6V7oIIg5kSJFkPG5VAJH1pzIjqV YAjuCOv1FAHhHwt8TWFr4qkTU9WjjElkLaB7iRQPlbIVmJ7A4Ufh6V13xb17R18K/Yv7TtmvvtMM i28VwvmAA7iSM5A25x7kV6LJZW0yKsttBIEztDRqQufTihLG0jkWSO1gRlACssSgjAx1x6cUAQ6V q+na1aLdabe29zEVBJilV9uexwTg9ePavMvjDrOk3FlpNtHqto8y3DSGNJVYgbcZODwMnH/6jXq0 Nrb27O0EEURkO59iBdx9TjrSLa2yoyC3hCHqoQAH8KAPM/g9rGnf2df6eb+2F4bkOsPmAMylVGQv fkY4r1Ko2t4JNu+CJtpDLlAdpHQipBzTAWiiikMKXpSc0vagAFB6UUnagAoooJ5zQAUUd6KYBRRR QAUdqKKQCUtJS0xCUUUUAFFFFAC45o70lHegA7UGloNAB6UdqKKBhnmiig80AFH1o/Ggj1oAO1Ha jtQOlABR2oooEIKWkpelACd6O9Lmk70AFHaiigApKWigBKKKXtTAKKO9HekAUUUYoAAKTvS96DQA lL2ooHSgAFB60UGgAopcc0nagANBo7UhpgHWl9qBQaADtQaUdKDikAmeKO9FHTigAo70ox3pBQAU d6BRQAo61EzyBWYxEkE4VWBJH44qXtTWXehXJGeDigARg6BlOVYZBpeelApe1ACUGijHPNAAetL2 pOpo6GgA6mloJxSYx0oAKKOtFAB6Uvek9KO9AARQOhpfagd6AHDpRQOlFIo868FhRaNg45rurbhM c1wngs/uHHfNd5AMelUyETiigUUhhRRS0AFIPWlpKAClPSjtSGgAFFHajFACj0pDQOaKACj0oooA KOoooPagA9qXvSUtABSDpQOlFACmkpRSUAFGKMUd6ADpR3pO9LQAZ4ooxxR3oAKDR26UUAJS96QU tABR2oooAOtFHaigAIxRQaKAMLVPFFtYaiNLtbS71PUtodrWyRWManoZGYhUB/2iM9s1T1LxxDoY t5Nc0XVdOtZpBELqQQyxox6bvKkZh09K5jxX8O/EV34qn17wxrUdlLdKv2hZJpIWUqAOGQHcpwDh hxjvXH6t4e8caTrWhW2tXcXiBbm6HkWcly9zGWXAJdZFHAVid3bkn3QH0ACCMjkGgV5t4/8AHHiH wfqsMNpBps9ncRNJEZIJN6lTgqcPg9VOQB16VF448beKvByaWyf2Pc/bInLs9pJGFdcHj98eMMPy PPOAwPTs0vavPvEfijxNo3gXT9dt30ie5lETXEbWsoXEgG3YBITkE4OTz146F+heLfEd74An8UXF ppl44WSSOztt8JCIWDZYl9zcdMD60Ad7S5xXk/hvx7428WW2p/2XpeircWpVg8zuIlBz8nykl3OO uVUY962vAHxCk8V2M9teW8ces20ZcwxsFWceqgkkckA5454PoXA73NLXlGlfFDxBN4wvtAutBtbi dJJYraGzm2nfGTkM8hAK4B+YAdOhzirfhD4lanq3iXUdH17S7ayNpHLI7wOW8kxnDK/UHv8AMCOn SgD0sdKM15n4n8Y+ONO0tde07RNOi0UgNtuy8lyEJ+V3VWUKDkcAkjv3rY0/xZqPizwf/anhUWSa lEds9nfRs4DgAlAVdcdchjkH25wXA7Wk7V5d4E+KN3rWtvpXiKG0tLiUhLUwxOmZBndG25mwemOn celO8f8AjbxR4Ju7VIpdGuobpHZPNs5VddpHBIlweCOePpQB6f70Vi+F7jWL7Q7W/wBZlsmnuoUl WKziKpGGGcbizbjgjnp6Z61d1W8nsLEzW1lLe3BZUjgj43MTjlsYVR1JPAoAu9KXPFeSa54/8a+D 9ct18Qabo8thcZZEsmfcUH3sOxHzDcucrg9sVt+PvGGs+HNK07WtGl0yfTrxkjCXEDu2WVnDhlcA ggdP1OeAD0D1o6iuCtvE3iqb4fQ66trpUl3NbS3bSHfHBbxKuQGXczOxAPQgD8OU+Hvj+78XWOoJ d2cCahZhX227FUmVgcY3Z28jHJNAHe0d68r0v4keJn8XX3h280OxurxC6QJZzNGAy8/O8h5XHcAH 2OeLfg74g6z4i8UaloWoWNpYXMMTtDtVn8tkYKVfLDf17behoA9J+tHevKvDvj7xVqvjw+HLxdHh WGaVJXS1k3ERk5x+9IBOOvOM96Yvjrxh/wALEHhWc6PCHuDCLgWcmdu0uGAMvUjHrQB6xRXlOs+P fFWm+PV8MpJooSWaKNLqWzlG0SYwcedyRnHbJ9K63WdW8SS3E2n+GbGzmu7RUa5utQ3pAxIyEjC8 s5HJyQFBGSc0AdT3orzfwN8Rr3V9an8P+I7aC01RCyxGIFA7L95CpJ+bgnIOCPTvV1rx14p074hx eGYToxhuJokinks5SyrIeMgS8ke2AcduwB6kaTNeWeJfHnirSPHqeHLVdF8qd4VhnuLeUYEmBlsS f3s9u1dVr+reJ0nNh4d0aK6uoolkmu7vdFbnIb5I+QWbgHg4GRk5oCx1XeivMPBXxPvtW8RNofiK witL2RjHEYImQCRc7kdWYkHjg10N54suLzxe3hbQhai8hj827uroF44l4+VUVlLvyM8gDPfpQB1w o71594m17xl4P0Oe+kh07WrZYSPtEMT28lu5zh3TcwdAcZwVP867q2kaS1hkkxuaNWYr0yRk4oAm 7UgPXIxXF/EDxlqng62t7i10y2uoLhvKE0kzAxy4LYKBeQVHHzDn9cK78c+NY/CVl4li0jSV08rH 9pWUuZWBODIqhsKmeBkseckYoCx6l1FL2rhLvxtd3vw6l8U6IttFLbxlp7a9iaTDKQGUbXXHXIPO QRwM1leHvHHinXPCPiDWmGiJJpsZMMSwyfMyqHYt+94G3IHTnnPBBQHqHejNeb/D/wAbeIvFS6nN ewabiyVAlpaxOksjsCRlnkKqPl9Dnnpjmt4f+JWvaj4j1PRp9Dtrm6gZ0t4rKXaAyNtbfI5xt/2g oPsc0wPUaWvOvAXxEv8AxTr17pOo6VHaTQxNKpikJ27WClWz3y3Ueh4r0GVnWGRok3uFJVc/eOOB QBUXV7KTV30uOYyXkab5UjRmEQPIDsBhSRyASCRV+vGvhN4u1I6t/wAItdaYGkIluLq6ywmSXJLN KD2OUQfQde25pnjbxH4svdV/4RyLRoYrLHkWuoCQ3Fyv9/5WARTxjg9eaAPSRR0riNM8Z6lqPhbT 7qLSjLrt9NPGliDsWHy5GVjKxPyqoCgnqSRgc4GJpnxL1rTfFf8AYXjTTrSzdyqpLaA7VLEBCSXO VPPI5HcDBpDPUqK88+I/jLxD4Pu7J9Pj0yWzulcAXEMhkV1xnkOAQdw7djWXrvxF8XaRpujas2i6 XDY36giGWV3mbgHsQEyCSPv++DxQB3viXX28NaUdSawku7eNgJfLlRCmSAp+YgEZIHXjNV/Cvi2P xbDPc2um3VtaxP5fmXDR5Z8AlQqs3QEcmsrx5qEeo/Ci61GBB5VzBbTosnPDSRsAfzrivBGqeLbL wDfz6Bp+myR2s8k0kt27s0uEUlEjTHzYA5LDPTHegD2yiuJ8H+Nbnxn4buntUtbTXLYbWimDNET1 DgAhtp6dcqfXvi/D7x94j8ZaxJb3MWlW9tBb+bIY4JN7k8ALmTAweT16ds5AI9Q7UleVab498WX/ AI9/4Rh00WPZcSwvcC3lORGGO4L5o6gAYzxnvSyeO/Fn/Cft4Vhj0VmNx5QuhbSsoXbv3FfMHIXI IzjPegD1UUleZfEbx94g8G6rHDZRaZPbTQGZPPt5Ny44wSJAG5BPAHUD3MvjTxn4k8I2OkXQGk3i 3iN5uLaRArjB+U+aeCrYwfQnPOAwPSBR61yQ13xC/hjTJLHT7bUdY1C388MimC1gBAOXLMx43AAA 5bB6AHHMaZ8UNZsfE40PxZpEFtK0ix+bbfL5ZbGCQzsGQ5+8CPpwaQHqlFcvr+teIGvZNN8KafaX F1AFa4ub5ysEZPIjG05Z8ckcYBU96xvAvxAv9d1y+0HX7GGz1SDLIIgVVtpw6kMxO4ZBGCcgnpjk A9BpB3qnqaam9qRpVxZwXAyc3cDSI3HT5XUj68/SvNPB3j/xb4t11tOU6FaKkLTPJ9llkOAQMAea M5J9aYHrFQ3d1b2NnNd3Uyw28KF5JHOAqjqalXO0ZILY5IGBWX4m0NfEnh290h52t1uUC+aq7ipB BBx35ApAZ1r4pvtSthdab4X1Sa2cBo5JnhgEg9VDPnH1AzVrQ/Fen67eXVjDHdW1/Z4NxaXcOySP PT1B+oJrzFPhz8RrVY7a38URRQIfLi2ardIAgHACAYHbgdPpWv8AC2119LHxC06W6ztcmKG9uYzI ZpVyHLtw0iA4wd3rQM9ToryzwX458VeKPEd3pVw2jWwghkculpKTuBCjAMo4yc89hjjOQ7wh458U 694ufRrz+xIorcymdo4Jd7rG20hcycEkjk9OeDigR6jRXlV1448ZW/jxfC+NALNcJGLj7NNjayhg dvm5zg9PXvjmvSdSN8NOmOnPAt4qEx+fEzoSOxAZTz9fzoAuUn0ry/wD498SeMNYltbj+x7aGG38 59ltJvJPAxmXpk5P5d8iKx8d+L7vx8fC5j0QmO5eOS4W3kA2KMlgDL1x2zxn2oA9WHSg0g9K5Twz 4zj8Qa9rmnERr9hn225AwZIx8rEjJyQ4b04K0AdZ2pMZrk/HfjQeDrLT5lijme5uQrRsefKHLsOR yBjnkZIzXVq6uqujBlYAqwOQQaAFA4NUbzVrKwu7e1mnX7XckiC2U5kkx1IX0Hc9BV49K8c8ReKd U8IfFK8kTThfi9ECW6zE72QgbkhxwDu7Y7c+tAHsJ4xjpSgg1wuseOLweN7fwro0Vily65lur1iy RvtLbAikbmwOzdSPQ1p+Hdc1m613U9I120tLa5s4YJIzbMzLcBi4aRd3O35VGOoOck5FAHTnjHNH FcJ8QfFmveEvsdzYw6bLZ3D+Uyzo5kVwCezAYIHpxjvni9ZeKpbLwPF4j8RyWi+bCsyR2SkbgwG1 BuY7mJ9wPyzQB1o+tL0rzJfHPio+E5fFg07TP7PS42LYlZPOaLcE3iUMVzuP9zGATmulXxZJqXhm HVtAsvtpnSR8Tv5aQbAdyuVBOcjaAAc+oHNAHUigfSuI8CePj4ts7w3dj9lubJUeUxHejq2cFR97 PynIwe3JzWd4i8beMNJjj1WHw1BFonG4XTn7Rz0LBT+6B44IbHfBOAAekClrldH8UyeJvB76ppSw W98isrw3OXSOReSDsOSCOhHPIOO1cx4T+IvibxRJd29toFnJOkYeN/NaOGLOeJGO45JAwAOeegGa APUe1FcR8P8AxxceLLe+h1C0it7+yKl/JP7t1bcAQCSQQVIPXt64GNcfE3W/+ExTQLbw/btKlybe RBcM7SHBOVbChR0OSDxnigD0+lzxXnEHj/W9I8WJoXivS7SL7QyCG4sHYooc4XO85YZyCRjGOlSf EHxrrvhHULZLS30+W0uImdWmRy6spG4EhgOh4/8ArUAeiUhrzTxL488ReHdM0K9NnpcyahAZJP8A WLsbAYKOf7rDnnkHpXSQ+KfsHgO38Ra49vvkgE2y1UqGLDKooZiS3QdfU8CgZ1FJXm03jfxPb+FE 8VvZaU+nST7Vso/MMoiLFQxlBKg5xxtxjuDwOrTxdpj+FI/EIZ2tnVcRRDzJDITtEYUdX3Hbj19K AN7vRnNcu1x41v4Tc2Vro2nIyK0VvfGWWUnuHKFQhx2G+saw+ItzYa8dD8Waaun3Rk2pdW7FoHB+ 6fm5AJ4zz74waAPQaSlrlfHevar4a0iPU9PWykiWQRzR3CMSd3ClSGGMHqCO/UdwDqulJXB2Hi7x FN4GuvEcun2EzYdoLeJmjCIhYM8jMxyPl4AAP55GbpnxT1O+8N3d6vhe4ubmzwZ5LaRRAqnndyd+ QOoAPTJIFAj06g1w/hf4gT6/4fuLw6LNJfQTrb/ZrV1IlYjcCCxAUY6ljxjv0rBvviZ4l8Oa2Lfx J4et4bRvnUW7EsE9VfJVyO4wv4UAerdqK4fxt4w1Hw3aWGo6alheWN2Qi+ZuDZILBgQcEEe3HXnp Wz4Q1TUtZ8PwanqYtEa6HmRR26MoRDwASxOTxnIx1/GgDforzLxJ498SeH/FQ0UWmmTLM0Zhl2yA 7ZG2jI3dQQR19+Olavi3xdr3hrTRLDo0V00Hkrc3bFo4S7dRGvLEe+cDI64NMDuaSuX0rxmureEF 1u10y5kuC/kixQgu8ucbQ3Tb33HGACTjFcjqfxI8WeGdXjh8QeHbSK1kwwNvIzEr32vnDEehA6e+ aAPV6DXO33ifdYWJ0G2Go32oxebaQl9irHgZkkP8KjIB7knAGa5Gz+JWs6Z4r/sXxbpEFmJHCxyW 2TtDEbWJLEMnXLDGMdBgigD1DPaivN/iD471/wAGapBHBb6bcWlzG8kRkRw6bdoIOGwfvZzx6ds1 qeIfEuv6B4c0aQWun3mt39yluYIdwjZmVj8nOeMLkk469M8AztM0ueK4mS4+IsOmT3c8fheOSJDI Il+0PkAEkE5HP51geEPiB4m8Ya79ihh0izgWHznd4pJWABAwB5i8kn8PegD1TFL1NJ681g+M9cuf DfhO91azhimng8sKkpIX5pFXJx6bs/hSA3qO1cv4B8SXvirw69/fwwxTrcPDiBSFIAHIySe9dRim AUVj65rj6Yba0srQ32qXZItrQSCMELyzsxztVR1ODyQACTXCRfE3W9G8SHS/FujQW0TOAJbUkbVY gK2XbDrk8sMYweOCKBHqXeivOfHvj7WfBmrRW8Vpp91BcxGWIuXV02nDK2Cc5yMHjr0OKu+JvFuv eGPCumavNbadPLM6pcwDegBcblCNk9ACDnqeRjpQB3PagV5N/wALN8US+Dl1yLw/ZJFFP5FxO8zF GbcB8kY+bHIGSeD2OK7TRvFUut+Df7ctLAPcIrCS2M20Fk+8FbB9MjIGeM4oA6WjpXlnh34leJPF eoXVvpGgWeBCJIjLcHbHk4zI3HthVXPXnitbwN8RG8Q38uiaxapZazFuwiE7JdvDAZJIYHPGTwMg 9cAHe9qDzXCXHju41XxavhrwtDazTxlmub+6y8EarjcEVGBc5IHUYP44seGfG0up+ItS8N6rbxW+ r2bvsMBLRSoMcgnkEZHB7H8KAOypRXlni74h+JfB+pvY3Vlo90ZIvOgliaRMISw+ZSTyCvY8/wAu 1n1m40bwndavrT2heGIzYtQwQ5+4gLckkkDPGc9BQBvGiud0zW73xB4MttW0o2sd5LCHKXCM8YkH 3kO1gRyCAcnHXB6VB4L1nXPEOmjU9Ti0+3t5CViht9zMcYBYsWwOd3y4z05oA6k0UHpRQAlFKKQ9 aYCmjtR2oHFIAHPSlpKKADvRR70elAAelFHak60wDvSmk70p6UALQaBzSd6QB0ozR1oPWgBc4pKU YApO9AB0NH0oFFAAOlFKDSUAFHQ0DilNACUZooxzQAHGaKD1ooAXqRSUHrSnpQAnQ0dKOtBoAOuD S0DrR0NAB0ozgGk70DvQA8dKKB0opFHnXgpcwOeetd3b4IrhvBLYtXHcmu5tznJ/SmyET0UCigYU E0UGgBe1IOlFL2oAOMUlFHagA7UUDmigAApaB1pCOaADvS9KTvRQAHrRQaKADtR3oo60ALRR2pKA DvQKO9FAC9qSiigA6UUlLQIO1HeiigYvakpaSgAo6GjvRQAUUdaSgBaDRQaAEpT0pKD0oA8e+Mur asmraXo8NxPa6dPHvkaN2QTMX2lWI6gDt0+YE+1H4ik+BfGWmXvhqMac8tt++itlCxzbWx80Y4PB 647D0r0TVPhv4W1i9mvL7T5ZbiZi7P8AbZ1AY9SFD4HQdB2oh+H+kf27FrOoT32q30KhYXv5g6xg dMIoVeOe3Uk9eaAOD+NxMl1owxhmt5ztI5HKVD8aplaz8OxuUE4gldo9w3KCqDJHXGQRn2r1HxN4 R0jxZbRwapC7GIloponKOmeoB9DjocishvhV4PmhgS506a4eJQpmlu5fMfAA+ZgwJwAMDoOwFIDC +IGZPg1YlQcbLMkEYIGF6/mKk8GMY/gfOxVzttb4jaMk4MnStPx3H4f0TwPHb63a399pyzxpFCty xkL8lQXLA4AB6mmaTHorfC7UrjQftcOmzWNxttricuYGCuGAJLY5z3I70Ac38CGAg10Y2DfAwB7D D9+/T+dY/wAJVkn+Jmp3FuSIFiuWchRhlaUbV9ueePSj4R+G9P8AEdlrX2qS8jcLFDvtb14SyMGL KwUjIP8AtA/zr2Hw94W0bwvZtbaPZrbq5Bkcks8hHdieT39uaAPD9Cgvn+M1/b2N7BbXr3t9Gs8k Bfy8+ZlgmVGcDjnv0Ndt8PtQ0C0vfEGjeHtOvhq9skkkl5qA3NdspxluQV+c/d+XIOeucddeeBtD u9d/tuOGez1M53XNnO0TN7sAcE+5HPetHSPD2l6EZ3sLbZNcNuuLiR2klmPq7sSx/OgDzTRPF3iD x34R8QyXsug2sFpCyzRSWUjAqUJzuM3y4wecdRU/wKt5k0LVLtlkEM06LHnO1tqfMR+eCfb2rr7n 4e+Hbq6vJhb3FvHfDF5bWty8MNz7uikDPJ6Yzk5zW/Z2Ntp1jHZWMEdvbxJtjijUBV/CgDwb4n2+ lyeNopfDd4ZtYllAuLezLF0uFI2spXgPkcgcgrk1D8SL/WNR0/QDrulTWN/DbTJK8pTE5BQblAYk epBA68ZpfCyDwR8T7dPE0ZtQGljW5nZRHvcZEm4ggg5PQgjdyeCDd+MupaPf6npdxY6jZ3biCWOQ 29wjgAMMA4Jwev5H0oA9o8OOZPC+kOwwzWUJIxjnYKTxFr1r4a0O51e9WV4LcDKxLuZiSAAPxI61 F4Ture88J6RJbTJKn2KHlXDEfIODjv8AgK0L6wtNTsprK+t47m2mXbJFIuVYUwPIfirreleIvAGi a3Zo37y9KRmQYdBsfepGfVV6ZHHvUHjm3uLH4N+E7W7h8uRJ4g6NwVPlSYH5f/XxXolh8OfC2mzQ SQaYz/Z5GlgjnuJJo4mOMlUdioPA5xniqPxQuvD9n4cgl8Q6VPqUQuR5MUTvHh8EZLqRt4J6nn+S AZ4aJPwVgOOmkyj7oHRW7CuP+Bm5bzXFAHMMB9e7106eHfC/iT4cRXVhZ6j9jSznezhN3O0kZIIK hQ53crwPmHoMHmH4YeABodlDreoiZdWuEyIhKQkKEcAheCx6nOcdsYoA4e0hvZvjhdw6beJbXLXt yqztGZvLGxtx25HOM4ycD07V2nw0vvD9vrmr6Dpmk3kF9bM5uL67IeS5KvtYseq/MchenfrXU3/g Tw/qGtR6y1pJbalG+83NpM0DOcEfNtIz169fw4q9o3hrSdBaeTT7QJPcHdPO7mSWU5JyzsSTyT3p gePeCJFX416kqocNc3wBJDFfmY8sf6UljeW15+0CLmzmjuIXu2AdMOpPkYOD9QeRXp2pfDrwrq+p yajeaVuuZTmRo55IxITwSyqwBJ78c96TUvhv4U1O4juJdJWKWJBGjWsrwYUcAYQgcDvSA8y1+5gu /jtaPbzxyKLu0jZ4iG2uMAjjuDwfT8K7HVPGPieH4mx+FrWLTYrS4CvFcTWkkrBChJJAlUH5gR2r Zb4Z+EftMNzDpH2aeHZ5clrcSQlCvQ/Kw+bjr1PetXWPC+k669rNewyfarU5t7qGVopoz7OpB/Dp QB5Vb2OoS/HpBIyXE9s4nubi2tjFGF8nBypZ8ZyBnPJPFM8UsE+PenEqoLXFngkA9cDPIPP+HHNe taT4a0rRJrmeytiLm6O64uZZGkllP+07En8OlVPEPgnQPE8sc+p2Je5iXbHPFM0TgdRypGcHpnOM mmB5d43uFT436W0eJWjmslIByd3mZxx35H516ZqPjrRtL8WWvhy5a4+23ATa6x/u0LnChjnIJPoD Xk/iHTtK8O/GHR7S08q0to5rN23SZwS/LMWOST1JNeveIPBmi+Jrm2u76KVbu3IMVzbTNFIADkDc vUA8j0PTGTSA851q3Q/tBaeLYkyF4pZlAztIjOen+yAeayfGGm654H8c3XiCxaWO2upzLDdjLply C0cmT69AeD26cev6R4T0rRL24v4I5JtQuWJlvLqTzZjkdNx6DjoMVkyeKba28dal4d1ueAWk8ED2 nnRgR5bcGjYkYyxGRnr0FAGN4e+IuleLrSXQPEEa2d3dwtCSTiK4DDaQpP3WOeh/AmvR4oxDBHEr ErGoUE9SAMc14X8TPCej2es6dbeG0Eeq374Om27jAB+7Io6IMjHp6YxXukQYQoshy6qAxz1OOaAP Lfjgf+JBpQyf+P4ng/8ATNu1LdGM/s9oQ4Zfscce/PGRKB/Pt+FP+OO1PDWlyMwA+34JJAH+rep/ CvgPw3rvgzSpbiOaSOSFJJ4INRfyZJQPvMqEKGx1wAeTnJ5oA5zwysv/AAorxQ4jbZJJO8ZKj5lC RhiPUDDfkaX4f3MMXwv8ZmQxCJFlP70/3oMAH1zgDHevYYtNsY9P/s5bKBbEReT9n8seXsxgrt6Y x2rl7T4VeErV5ythO6TdYpLqQovBAwucZGTgnJHagDkfgVzFrny/MrW3zFRyMPxu7/Tt+Nc94Vt9 Sl+Ker2mk3cVndyyXifa3iabyRvySFyAWzx82Rn14r2Hw74L0XwtLK2kx3UXmoFlWS5d1fHQlSSM 9sjFR3fgPRrjXG1u1+1adqrklrqym2FieDlCChz3yvPU80Acz8LdR8Ni+1LSdK03UotRiLPdXl+F aScB8fOwPynJPy4A+pzXp1ZOjeHNL0E3D2FuRcXLb7i4ldpJZm9WdiSfp0rWximADqeOT+tfO+s+ Gb3w5P8A8JZ4SvpLjS455MSxKVks2WQgxyL/ABJxjPcdRjk/RFcgfhvo32a7tYbvVbe0vZXmu7eG 8KxzlmJOR/COcfLtyAM5oA5XVfipqdh4K0DXrXTLPffvLHdLKHCiRDjK4PRsMec8Y64Nc78UrXWb 650KS8jsJdQvoWjt10+3kVzypVSWY7uWOAMY5PevZbjwzot34eXQJ9PifS0QItvkgKB0wQcg++c1 W07wbpVhqEGoubm9vbaPyrae8mMhgjxgKo4HTPJBY55JpAef/HFWW38PgsS6if5sdTiOqXxLYHwR 4KwowYFIBPI/cp2r1DxH4Q0bxW1odXgkmFqW8sJM0f3sZyVIP8IqG+8C+H9T0zT9OvrSa4ttPBFs GupQyA443BgTwAOSeBQBzHiIofgJblhgf2bYkZ4x80WO4/nUPwtuktfhtq0zOsQguJ2Z8fdxGrZN drJ4U0qbwsPDcq3MmmhUXY9y7PtVgwG8ndjIA68DgYFZsvw50Qw3VrbSX9jYXmPtFlaXJSGQgYzt 525AAO0jOOaBnnfwTs53k1u4jjdYTaLB5pUkeZycDjBIByRz1HHNM+BWRr2pDGQbGM5/4F/n8q9l sNH0zRtK/s6wtIrWyVSDHGMA5HJJ6k+55rzr4Zv4Mv8AWbp/DWn6np89rGCxluneOeJumVLEcHtg Y7E80Ac7oTtF+0FKrgKXv7sfNycGJyMfUYp2Y/8AhocGMrt+3HlWBG77Pg/jnIPvmvS9X+H2hazr setTC8gvVIZntLp4fMIwATtOQcDGRg479MV4vhh4TttRj1C0sZ7W5icOjw3cq7WHQ43Y/wAe/U0C OA+OsONS0udjkPZzJtP+ywOf/Hv0FT/GORZNK8MI8kfmeTJIyjg42xjIHbv+Vem+JfCWkeLbOO21 aF3ELFopI5CjoTwcEevocivJvip4a0jw1baMLdbmR5ml86We5LyyqoQKu9s4AHAAGAO1AHenxppf hDwT4bn1Yz4urWJFEK7yMRgknpwOPzHFcN8ZoYdQ1nQ5bGF57i8tSibUyJQWHlgY5J+ZuPy716Hb +GdJ8UeA9EtdSgaWNLOFoZVfbJGfLHzKw7/oataX4H0fTNRh1FhcXt9bxLBbz3kvmNBGowFQYAHf nG7k5NAHL6r4x8Tab45sPCdtb6YguYofKubmN2Jyp3khWUHBVhgYrFtrG/f4+27TSW01zFH5909p EVRR5JTkMTjOVHXvXp2teGtN117Wa6SRLqzbfbXUEhSWE+xHb2OR7UaN4a07Q5rm5t1nlvLrb9pu 7mZpZZdowMsegA7DAoGaznahYKWwCQB3rwj4Lt/xV9z+7bJsH5HAHzpxXqHhvxnp2r2t2t1f2cF7 Z3U0E8TTKpUK7BWAJzgqBz659K8p+Dt1a2/iu5eW7gSMWDKrPMq8l0x1PfFAj34VW1GW4g025ltI fOuEiZoo/wC8wHA/OsHSPF1vrfjC/wBJ0+e3ubOytUeSeE7szMxyobOCAMdB179q3NT0y01iwksb 6NpLeTG5VkZDwQRhlII5HY0AeN/Di0tvGdx4jv8AxOU1GcQoB9tAIgD7ySm7Pl4x2HGK1Pgrrmp3 kF7pNxI9xZWccbxTSOXMZbjy8nthcgdsGusT4Z+G7VZV0+O/05Zl2Ti0v5UEq+jZY8fTHWt7RdB0 rw5p62Ok2UVrbg5ITksfVmPLH3JoA8f+ETJD481lWyirby5MhHAWUZzx79qX4XyLL8S9Xlj+eOWK 5ZXDhsgzKQdw6/XmvQrv4ZeFbzVZNRlsJRLMxaVI7mRI5M9cqDjB6kDr+dTaZ8P/AA3oeopqGmWc 9rcKTzFeTbSDyVKltpX2xjgUAeb6sM/tB25Kgn7VBjnP/LAf/Xr0/VPFegW0Gq202rWguLOBmngE w8xRjpjueg47kVxWq3fgtviwbK703Uk1qSWJRqEN3IirKUGwbQ4wNuBnBHtjmupPw38LHXJdYk05 nupHMmGlbYrkYLBQcAnk/U5FAHnfwPO3WtUXb/y5R8+nzn/P4U3w8Gj+PF4rJJLm7ueeGK5Q857D txXpmieA9C8Nah9s0e3ubVyhR0F3I6SDtuVyenauNs5fBV38VLizt7DVbbW/tMjC+W6ZVaYKS6hd /wB0gH+HByR0xQB3HjPVZdK8L3L2m5r6fFtaKoyzSyHauPcZJ/CvHfDkc/gb4rxaYwDr54s3kbI3 xyY2vj1+6e/evT57iLXviTa6fHIsltocBuptj5xcvlEVvou449+a47406HDBdWGvpIUllItZQGAJ wCyMO+RgjP0oAyviDb3XiCK78Vqs7WFtetp8SEZVYl+UycdjLuGfcV6D8K9dbWPB0VtKB5+nMLVs d1AGw/lx9RTvCX9neMfhdbWBjRIGtzZzxIM+W6cZHvkBhz3FecfDPVT4d8fyaVcS/u7pns3APy+a hO0/iQR/wKgD33g+9NZEYqWUEqcqSOn0p2KQg+vPbNAHlPxF8Fx69rU99oku7XLeBJbmyHymWPJC SI2PvjaR15wOnGXfDnxzNcQaja+I544jpkKt9suiUdU3bSkjNySDjqck+prtdT8I2Wpas+rfa9Rt NRMKwrPZ3JjKorFsbfusCTyGDDgYxVVPAGhpoOoaS0dxImoP5l1cyS5mkfduDbsYBB5AAx7UAcT8 YNasL3TdGs7S5iuGkka6DRPuATaVU8euT+RqPxlFJJ8GvDsyA+VEtq8oA4CmMqCfbJH512EXww8K xaKmliynMAlEzv8AaXDyvjGWYEZHtwPat2x0Cy0/Rv7IRZLix2GPybqQzAJjG35v4cdqAPOLeZIv 2eWY7iCkkXyjJDNdEDPoMmtH4XRSx/Du7mYYhlnneIseqhQCecgDcrdu1bT/AA20KS3Fh5mpLpQk 83+zVvW+z7/X+/15xuxntWnq3h6xutJjtfNu7S2tIGWOK1u5IExtwNwQjcBjv7+tAHm3wPYJc6yX Taq20DPKeiYL8Z7dz+HtXXN4s0Dxp4R8QJZPIy21pJ5q3ERT5cNtcexK5HcdwDWR8LPBEtjZW+v6 jLeRXUyBorRZWjVVwQGkAPzE5JAPAB6Z6bzfDTQBcXhtnv7O2vQFurS3udsUyht2CCCVGePlK8Ej gE0Acn8KYLo+FfEM4GyOZNsbupwWWNs9+xIyKr/BAKNU1VfLwfssGHz0G5uOvfj8vz9Zg0mxt9J/ su3tkt7LyjEIovlAUjB5HOcd+tZGh+BdD8N6h9s0lLq3cx+U6fandJB7hieR2xQB5/8ABhsa1rYV Dt8hDknB++2BgVnW2f8AhehJQN/xNZB90N/A3P4evbHevUdC8C6J4avnu9LF3DI6GN1e5eRXXqMh ienavJ3s4b34zy2dz5hSTVXBCylCPlLAqykEEcEYOc0wL3xejlu/Glhawo8sslpGiRfe3M0jYGKt /GwBr7RlIfP2ef0x1TH4132k+AtG0vVf7Vdr3UdRGNlzqFyZ3TAxxn/PpV3xL4T0vxXZxW+opIDC ++KWFgrp2IBweD3HsPSkFjyz4kSpJ4W8GDCo/wBiLmLgFR5cfb061e8YwyyfB7wzIIyI4hbmQbT8 oMRAPbvjr611Z+FXhaSCCOeC8neIYM0t5IZHUDAUtn7oA4AwBXR2ug6fbaEmjGH7RYJH5QiuW83K dlJbqB2z6CgDzeW5WL9n6IY2+YohXaOp+0EZPPsc1s/CK0ni8HyvcRlYp7x5IQ69Vwo3D8VP5VeP wy0N4IrKS61V9KhcyR6a163kIx6/7Z78Fj1PqaseMNXPg3w3aXVhEiW1tcwxPAqD5oc4ZVyRg46e 4oGdXXkPxnsoxd6RfbTvkSWB+OCBtZf5tXp+l63pus6ct/p97DPbEZLq4+T1Df3SO4NeQ+Nb+Tx/ 4xtdJ8PH7bFaRkebGAUDMRvct02gKv17ZzTQnsei/Dq9nvvAWlSXAYSIjQ5YH5lR2RTySeiis34t c+B355F1Dx6/Niur0TSINC0S00u3d3itk2B5DlmPUk/Uk1yvxa/5EZ85/wCPqH8PmpAZvh5n/wCF I3IUFGW1vNpUEH7znPHP41xngy3u73wl4gjN79l0aECa/wDsibruZQh/dpk7VUgHk5/nXpnw2WOb 4eWCMFkUmdXVvmBzK/BHPbt70RfDXR7W4uW0+/1ewtbnAnsrW72QyD0xgsAenBBwcAgUAZvhzxn4 U0fwJLf2VjeWVhaziBoWjDSSysAeCGIYnPUkdO1ZXxWvLDWPBWi6xasskck5MMhGGCMh3DHblRke orvR4P0AeHv7BXTYhpudwiBOQ2c7t2d27/azmsmy+Gmh2ptFupr/AFKCy3G0tr6YPHAWIJIAUZ6D 72cUAcP42imtPhf4St7iMxyKy743DAqfKbAOehwen+Fd14S1ew07wJ4cOoXtvaefbpFF9olVN7Ad Bk4Jqv8AE2bQotCtW1y2vLpTcbYIrSby3Ztpzk5Hy4Bz+FV7bwT4a8V+DtIQSak9gi+baNLLtljR uqHIOQcY74/hIGKAOH+It9Bd/Em3ezkjuGi+zRttO9d4kzt4+o49c16J8VWK/DzVAAOXg5/7bJT7 j4Y+Fp5reVLSe2NvEkcX2W4eILtOQ3ynlvc81l/EXwuJfDU9xBc6xdXxaCKGA3shSRiyoMx/cyRy Tgdz70AUvh5rcHhz4X3WrX8b/ZYb18eSm52DMqjuOdxxz2pPiVq2m+IPhrZ6xZSl4DeIYyRtIOGV gwPQjnj2rc8K/D6z0zww+narJc3rXcY+1W8s5MEbHBIjQHCkHHzj5sjIIp1n8MNBtVigmn1G8sYZ 2uIrG5uA0KyNj5sAAt043Ejk+poA5CHxXrXgbwD4XEGl20yXcU/+u3qVJfdGPlHdTk9z7YrN+Ktv rV3qGiDUo7Bru6ikhgisxKSxLLhSHA5y2Ox65xXsesaDpuv6adO1K2WW2yCqqSpQgYBUjBBGe1Z9 j4L0611eHVru4vtU1C3QRwXF/KHMK4xhQoVc/wC0QWPrTA82+OG4XmiLI5eRbSfccYBOU5x26fy6 163b2FvcjTL6aIC4tYcRBJGKIXUBsDoeBgEjIBPqa8l+OS7dS0hiQN1pOAPoyf416N4j8QHwx4Ut NT2L5SS2yTK4MhEbMofBB5YAkg89O9AHN6l4zt9I8Z+J9Fv3umgntY5YWjieUROYgrLgZwDlCOAM k561yHwXR08ZTjarBNNcFgOn7xOleiJb6Ky+I/EFrq1rdf2vbfLKsiYjjSLbtBz6qSeO2D92vPfg tMn/AAl8waUeZJpzDBPLEOh498Z4oA7DWtC+JtzrF5LpfiOwh06SYtbxM21kTsD+5J/U1zvjPwz4 hg8ALfeJtajur3TrljGsRLrMkrRKoYkJypDHoe1e0DiuN+K2f+Fb6od21Q0BPuPOTikB5T4d8KW9 94Rv/EV3r93pttazshjtwSXYBegDjLHIUV7F8PdMvtI8E2NvqKst22+V1kJLrvYsA5JOWAIHt07V xXwu8N3Go6bDeaor/wBm2l009jbuo2yzHgyt6hcAL2zk+hr1ymBwfxF8aan4Om02WzsrS4huRKrt OHBVhtIAYccgnjvj2rg/i3a69PcaL/a0emtcTpLBAlgrkuxZMBi3uRge7V7Preh6d4h019P1SAzW zkMVDshBHcFSCO/51lad4H0ux1G21G4mvNSu7SPyrSS/lEn2dB0CgADP+0QW96QHl/xqSUappEUp TcmnspCZPzbsHBPOOBXU/FhlPw7sN0JjZriDCcLs+RjggccDIxXOfG1W/t/TyX4Ni4XBGQdx59f/ ANVeo6roGleMPD9nb3wnezPl3EeyYhj8vGWHJ4JzTA8tt5H/AOGfr0bdp+243CM/vB56nOe+ORn/ AGcdq6H4WvIPh/q4cMiC5n2MB28pc4yfXPFdRD4C0SHw5PoAW6bTppRKY2uWJVgQ3yt1GSBnn+dO s/DNh4Z0DU7bTftJgljklMU0xkw2wgkFskZAHqOKQHmfwQUpr2ooY9+LJMyqMhfn4Gffr0/ho8ME XPx0upbVMxrd3bsyqGAGGBbPYEnHHc+lZvwt0CHXr+/imu9Vs5ltUZLqwnaFlG4blLg4+bj5SDnB ORjn2Tw34N0bwpDKumwv5s2POnlfdJJjOM9h16AAUwPI/hha3Vp8VLm1vYgl3BDcrMAOA+9ckZ7H PHsRVi1jnuP2g5mtEYmO8Z5GRMhUEO1yeeMk4z6njnivUtV8H6dqepx6tHLdadqqDb9tsZBHI64x tcEFWHTqCeBTvD3hDSfDLXE1kk8t3c/8fF5dTNLNLznlj7+mM0gPKfjW2fEtoApydO47g5d88da6 vx8t5rOl2/hyxt/KMentqVyFhICrGuI4tv8ADubOBk42d+a5P407W8V2yAqSNOVWG7nmR+vp616Z 4MgW6XVfEJlM39r3G6Inp9njGyMAZPBwzf8AA+lMDz/4Pa7tl1HRsDF1EbmBskfMqgMCSe4K4x02 mu8+GjI3gWzVY9jK8of5SOS5PUgZ4IGRxkY7V5P4isJ/AnxEM1pmG3Ev2y0VWwrRE4dOuccsuOOM V6z8NPL/AOEC0/ysbd0w4/66sP5YoA62ijpRQAlFFLmmAUUUds0gCj0ooPIoAKO9FFAAeRQKDSUA L3o5oHWg/pQADrxR0NANBoAO2KKBzRQAvOOlIOetL3pBQAZxRn2peKSgAFH1pRSGgAFFGKOlAAPS lzmk5pemKAEoHNHeigBaSjoKAKACg8UCigApc0YpOlAAaAODRR264oAeOlFA6UUijznwWo8lg2cg g13VuNv0PrXEeDMeS/1ruYPemyET0lKKDQMO1A9aPSg0ALSClpKAFx6UGkpSRQAlFKKSgBRSGlpD QAtJRzRQAppPrS5GaQ0AFFAoHvQAueKTpQKKAFoo70UAJ2o70GjNACGl6UdaO9ABRS0negAFFLSU AFHejNFABRR2ozQAdqDR2ooAKO1Bo7UAJQfpS9aKBBR+FGKO9AyC8sbTULY299awXUDEExTxh1JB yDg8cGkisbS3shYw2kEdmEMYt0jAjCnqNoGMc9Ksd6M0AZln4c0PT7lLmy0XTra4QFVlhtY0cA9Q CBkVqUlL2oATGaDRilNACDpS0YwKKAIZraC6UJcQRzKOiyIGHp3qquh6QoO3SrEfS3T1z6evNaFF AFSx0uw0xXFhY21qHxv8mJU3EdCcDn8atd6WkoAXpVe7srXULZra9tYbmBiC0U0YdTg5GQeODzU/ HFLigBqIsaBEVVRQAqqMADsAKWlFIfSgAoxS4pO9ABRQaKAA0nSlooAT60dulFL/ACoApXekabfu XvNOs7liNpM0CuSPTkVbVFjRURQqqMKAMAD0p1HHagBOtV5dPs5xOJbO3kFwoWcPEreaB0DZHzAZ PWrNJ1FAFDT9E0rSGc6ZpdjYmT75trdI9312gZq8Bilz7Zo60AV7uxs72JEvLSC5RW3qs0YcK2CM gEdcEj8abZafZadG6WVnbWqyNvcQRLGGb1OByferX8qQjigQYFL9KTv7Up6GgYmBuz3pelHGaWgQ nel+tHeigYUUUUAFL2pBSmgApKXtRQAme1LRRmgAqlYaPpulmZtP0+1tWmYvKYYlQufViBzV6koG HaijFFAgHSqeoaTpuqoi6jp9peKmdguYVkC5643A4q52ooAgtLK00+1S1sraG2t0ztigjCIuTk4A 4HJNT0dqKQwpDS0UCMebwn4cuZWln8P6TLI7Fmd7KNix9SStNk8I+GpQFk8O6Q4HQNYxH/2Wtqig Chp+iaTpTs+naXZWbsu1mt7dIyV9DtA4q/RiigYlLR3NHWmISjFLRSApSaRpsmpJqMmnWb3yDCXT QKZVHI4fGR1PfvVyiimAEZqmukacmpNqSafaLfuNrXQgUSsMYwXxnpx1q5S0gMqPw3oUN8L6PRNN jvA+8XC2kYk3eu7Gc+9PvvD+jancC4v9I0+7mChRJcWySMB6ZIJxWjQaBmba+HdDsPMNno2nW/mo Y5PJtUTep6qcDke1Vj4N8LYx/wAI1o3XP/HhF/8AE1uUhoARVVFCqAqgYAAwAKKWjvQISilooASk wOvPFOo96AGkDHrRjinUYA+lACBcHJoxzmlBooAKTH50tFMBMA5zWVceF/D95cvcXWh6ZPM7bmkl s42Zj6kkZJrW60UgGRxpDEscaqqIAqqBgADoBT6KWgYGjpRR2oASobq0trxUS5gimWN1kQSIGCup yGGehHrU9FAGLqPhLw7q119p1DQ7C4uM5MrwKWbjHzHGW+hzV+w06y0u2Ftp9nb2kI6RwRBF/IVb 70lABVe8sLPUbc299aQXUBIJinjDqSOhwRirNJ0oEU7DSNM0kONN02zsxIcuLaBY92PXaBmrlLRQ MSiilpiKt9p1jqdqbfULO3u4MhvLniEi5HQ4IqSG3itoUht4kiijUKkcahVUDsAOAKl7UUgEI9el HWlopgIBiloo60AFFLSUAUb/AEXSdWaNtS0uyvWiz5ZubdJCmeuNwOOg/Kg6JpLaWultpdk2nr0t DApiHOfuYx156Ve79KWgDCPgvwqcn/hGNFz72EX/AMTT08IeGUdXTw5pCupyGWxjBB9QdtbPrRSH cO9V76wstTtWtb+0gurdiC0U8YdCQcjIPHWrPeimIZDDHBCkMMaRxIAqIihVUegA6Cn0dqKACk60 tJQBn3+h6Rq0iSalpVjeui7Va5t0kKj0BYHAq1a2ltYWsdtZ28NvbxjCRQoERR7AcCpqXoKAEpro kiNHIqsjAqysMgg9QadxRQBk2nhbw9YXSXNnoGlW06H5JYbONHX6EDIrWFFFABRRR3oAwz4M8LMS zeG9Hdj1ZrGMk/iVrXt7eG0t47e2hjhgjXakcShVUegA4AqU0daAM/UtD0nWDEdT0yyvTFnyzcwL IUzjONwOM4H1xTbDw9oul3Hn6dpFhZy7Spe2t0jJBxwdoGegrS7UUAHeiiigApKWkoAWjHFFFABR 2oFFAB3o7UY5ooABR3o7UGgA70HpRRigAoxRijvQAUlO6UhoAXrSdKUZpKAD60vSko9qACilFFAC UGjOTR3oAKDQetGKACg0HrxRQAHiilNJ2oAOtBoo70AAo70oo70AIaXtSHrQehoAeOlFA6UUijzz waMQOc967mDp0rhfBo/0dvrXc24+XH9apkIsCiig0hhRkd6XtSCgBe1JS0goAUYzQaSg/WgBR0pK XPFJQACg0tIaACg460UpoAMUho9KU0AJijPNFL3oASjGaWkFAB6UtFJ7UAFFHSl70AJ0opeKTigA xS0UlABRS0lABRQKKADtSUtJQAtFFBoAKKO1FABSUtFAg7UClpO9Awooo70AHelooNABSZooxzQA UZ5paB1oAOppO+KXPNJjNAC45/GkPpS5ozQAlL/DSUooAOlJ70tGeKACkNL3ozzQAlHel9KSgANF L2pKADvRRiigANNIDKV7exp1J3oAXpSe9LRQAUdKKOaAA0nBpRxRQAh70fUUcGloAbjBpaDS0AJ+ FLRR3oAKKOhpaADik9KO9KKACig0UAFGeKOhoHWgA74ooxSmgYnYUc5pR0pO9ABRRniloAQd6KX/ ABpKQBRS9aTvQAdqDRRTABRRR3pAHc0UUUwDpRR2o60CE70UveigBKWiikAUnelFFMAoooNIYUne ilNAhKKKO9MA7UUtJSAO9FFFMAAo70tFIBKKXNJQAUdaKWgAo7UGjNAwooozQACiiigA70lL3oFA BR60Ud6ADtRRRQAhoopaYgpKKWgAFBpKO1ACikoFFAC0Ug6UtABR2oo5oAKKM8UUAFFFIT6UDFox R2o7UCD2pO1LSUAFL2pO9KaAEoozRQAd6WikNABijvRQTQAdqO1J2pc8UAFFFFAB3oozRQAlFFLQ AUlLR2oAOBRQKAaADuKM0Ud6AEpaM8UZ4xQACg9KSlNACjikPWgUcUAA5o6Gj8KKAFpAKWkoAWk6 UA0tAAM0hNA70duaADpRQKMYNABQaBQaYBQOfrQcUCkAY5oPWijNABR3paSgBaMnNGOKTpQAHk0c UUDvQA9elFA6UUijzvwdzCwwc5Ga7mD7vFcR4Nx5D9Qc13EB4qiET0UUUhhS8UlFAC+lJilHSjNA CdRRSgAYA4FIaADFHajGaM0AFBpfSkNABRRS4BoAKCeKDQaAExmlzR2ozQAlFFFAC55pKUdaQ0AL SYoxRQAUd6KD1oAU4pKO1HegBe1JRRQAUUUUAFFAooAKKOc9sUUAFHGKKKAA0UUHpQAUd6KSgBaK OppeMigBM0UcUvagAzRSdaXoaADrR2NFJ3oAdx+NBHFIOtHbigYlHelNJ3oELQOlJ1peo9KACigU GgBB1pcYNFJmgAPaijFHegAoPFLRQAlFA60UABpKDycfrS9Pc0AFHIoooAKKKO9AB3oxRmigAooF HagApByaXoaQdaAFxzS0lKetACUUUfyoAXvRiiigAooooAD0oxRRQAHigUtJmgYdqO9HOKO9AAKK KMUALRQKBSAKPWiigBOMUUUdqYAKD1oHSjvSABS0nrR2pgFFHaigQUYoopDDvRR3zRQACg0UGgAo oooASloooASlopKAFNJS0lACYyRS9KKQg44/WgQ6kpaSgYtAopKACl60najHFAgyKUdKKKBhRRR2 oAKKKKADvQKKKYBRRRSAKKKKADvQelFFAB2pKKKYgxRR2oPHNAC9TSUUUAL2oNJS0AHaijNRu7bG Kqcj170hklJTTliAMgdz600xssodXcjGCmRj60xEuQaQcmjnPtS45pDCjtQTRTEFJQaXtQAnelpO ppccUAHekHWjpRQAdDQaPSigA7UYpDS0AJR2ope1MApOcjpjvmilpAHXFJS96DQAYpKCCRgHmjpQ AtJQR6UZ4oAWjGKQjIwRxQBjjt2oAWiikJ7CgAJABycfWkVldAyMGU9CDkGl+vWlxzTAO9B6UUGk AUdKPpQaACiiigAoBo5FKKAEzzRmjoaTtTAdR3pMcZoNIBaQ9KByaXFADaXpSUuOaYBQKMUUgD3o FLRjmgA9qTvR7UCgBaO9HcUnegA9BS44OPwpPSgd6AHjpRQOlFIo878HMPs7jPfIGa7e2bOeK4Lw c/yuB09K7y1z7VTIRbFFAopDCiijrQAtJil+lJQAppO+aXrSHmgAxR9KOlFAC0h6UtIaADuKDRR6 UAKaOgoIpKADvS/jSUtAB3pBS0CgA70lLSY5oAKKKWgBBRRQeKAFo70meKM80ALSUtJQAd6OlIOt L70AFFFFAB2oooNAAaKKKADFFFFABRR3zRxnNAB3ooPWjvQACl7UnFL0oAKKO9HfHagA79aQdaKU GgA70UZxSZoAUdKTilyKSgBcUcUY5ooAKM8Ufyo96ACk9KWjvQAE0lB7UUAA+tLSCloATvS0h4pa AEIGaBS0lABRRRQAUUUd6ACiiigAo60lLQAUCigUAFHfpxRS96AEozS0YoAKBSUtAB2opaSkMBR3 oAoPIpgLScUdqPWgBaTvRR3oAB0ozS9qSgBR70UdaKQBRRRQAlH0paSmAUUClNIBKOtLSd6YB2oo 6CjNAC0lFFIAooooAKM0UGgAoNFFABRRRQAGig0UAFFNDMZCuwgDo3Y0H64+lAC0UZ5xRQAtFFFA BSUUtAB2ooooAKKKKAFpKKKACjNFFAB1ooooAKD1oooAKKKM8UAJS0lL2oAKSlozTEJS0maWgAFB 6UUUAFJRzmg0DAUY4NLRSAQDCgUooopgHejvRQRzQAUH3oo7c0AFIOmKWk70hBmjtRQMjOenamAt J3oxgn60DrQAZopaQ0AB7UUdqSgAxS0GjHFADVO4ZGce4xTqKB1oADRzSUUALRRSd6AEBIzuwOeP pS0gHQkc0o6UAKPajtRRQAUUppKAEozRijtTAO/NKelFGKQB0GaDRS0AHWkpenFJ2oAKO1LmkxQA dKSl7UdqADmjpSjpRjmgBOhoPWg0lMBaOc0lKaACiilpAHejNGeaQ0AApe9IKOlAC0meaWkoAKXH Wko7HFADx0ooHSikUeX+CzuLAk16HajC5Fec+CziRgfwr0a1x71TIRaHvRQKKQwoxRjmigAFH0pe KQcUAB/DH1o7ZopT0xQAc4pBzR1FAoAUUhoxzQelAB3oPWilFACHil7UUmOKACilpKAFFJiloFAB RSd6XvQAHpR3oI9KSgA7UdaM0d6ADtR3oOaO9AC0nrS9qKAE70tJQKACiiigAo9KBRQAUdqKKACi iigBaSlpO9AB3oPPajvQaAD3pelANHagAFHejvxQaAE+lKBmkFLQAdDzSUtJmgAozyKXtSUAHFLS UtABmjHFGKO1ABSHrS0nGaAClpKWgBKWkooAU0lLSdKAA0Cg9KOlAB3ooooAKDRR3oAKKKKBBRRR QMKKAeaKAAUUdKWgBKKKKAClo60dqAA0UUUAJmlzR3o70AFH0ooyMUDDtRQOlGOaBAM0ppB6UtAw 9qKM0UgDoKOpoziigApO1FFMBaQ0tFIA70UUlAB2ope1JQAd6KKKACiiigA7UUUGgANFGaDQAYoo ooAKKKKAEJ9qPehsnocUHkc8UAFFIMgdKWgQtFFFAwoopKAFooooAKKKKACiiigAooooAKKAaKAC iij1oAM0UUUAFHakpTQAlApe1IKYhaTpS9qKBh1pBSikoEFLQOlHegA7UA0UUDCiijGDQIDRQaO9 Awo7UUHpQAhz2IHNHb1paTtQIB/kUtJS0AIaKWkoAWkNAooABRRQetACGlo7UnagBaKO1FACDrRS 96KAAUlLRQAhzQOnQil60dqACik5pe1ABRS0lACdqWijNABQc0d6CaAD60Gjmg9aACgnBA9TR2pM d/SgBSaBR9aO4oAOc0dqMZ60d6AAUetHbFGKAExQadSHrTAKOhooJzQAd6WkB5oFIA70UUdqAAdK KBQaADvR3pewpOpoADS9QaQ9qOxoAeOlFA6UUijyrwf989BxXolkcLzwT1rzrwexDtx1r0WzXPPW qZCLw6UUgpaQwopaO1ABSUtIKACjtQaDQADjpQKMcUAcUAFJSj60etABR2oPWlxQAUhpaQigBc0l AooAO9LnrSCl60AHekpaKADpRmjrSd6ACigUtAAelIM0tJ3oAWjviikzQAUtIOtFABRR0oPSgAoo ooADRRRQAUUYo6UABpaSj3oAO+aKOhpe1ACUvakpe1AAKMUAUUAGeKOaQUvegAB7UlLikoAUd6TF L3o6UAHSjPFFAIxQAetHaijtQAlHel70nNAC55o6UdBRQAUlLSUAFFHel7UAIaKDRQAUUDrSmgBK KKKACiijtQAUUUUAFAoooAM0UCjvQAUUUUALRRRQAGig9KKAAUHrR2o7UAH0pPal9xSmgY0dKU9a AKQjvQIWigetLQMO1GaKKQBRRRQAdqT60vWkNAC9KO9JQetABR2opaAE7CjvR2opgGeRR3oxzQKA A0UUUgAdKKKM0AFFFFABRSFsUue1AAaKQ0duaAF6UmfX8KWgigBAc54ooAxS44oAKKKKAEpRRmko AWiijNABRRRQAUUUHigApKWigAopPalFMAooopAFFHaigAooopgFFHSigA7Ue1FFABRnjigCjvQA e1FFBpAGeaKO1HamAUUUDNAgo70daD1oGFHajtR2oAKT2oNLxQIQUvakHWloASjFLSUALRSUtACd qPSjoaDQAhpcgcZGT0pKaYIzKJigLhduSOcen6CgB9FFHegAxSEAjBGQe1OzzSEUAApKUUUAJ0pa Owo6UAGPWgUdTRQAY5oo60daADtSUtJTAXvQaTvTiKQAKQ9c0o68UcUAJ7GilpOtAB6Ue9KBxR3o ATnt196KKKAFpM80Ud6AA9TR9KBRigApcUnaj+VABigUE5NKKAE70tJ3oxQAo60lFFAC96O9FB6c UAIRRQaO1ADx0ooHSikUeUeED+8OPTtXo9kMKOvTvXnHg/iY454r0ezPoOMVTIRcpaKKQwzRnmij FAC9aTtS0dqADsKDRmkoAKB19qKWgA4FHSkFBoAKU80UUAB5NFFHagBBR3petIaAFoFJml9aADvR ijqaSgBTR3pPel96AEFLzRRQAdKKKT+KgBelJSnpR2oAQGlpO9L3oAQUdKBxRQACiiigApaSg0AL SUUUAFAooFAC0nfFHeloASl6cUnel7UAGKO9IPWlHXNABikpaTvQAtIaWgdKAAUUUlAB6UvalpBQ AZ5oo7UEccUAHWjHSgUZ5FAAaTr0pSelFABSUpooAQdaDS+1HagBDR2oooAKKKKAFpKWikAlFFHW mAUZoo6DpQAUUUUAFHejvR3oAWikzzR70ALS0neikMQ0tKaTtTEA6UUUUDCilpO9IAAo70vak70w F7UZ4oFFAAKKByKOtIAooooAKTvS0gFMBRQeooFHfFIBPWlpP8aKACgmgdKMUAFGe1FFABRSAY70 tABQetFBoAKKO1HSgAppB5wxpQMdyaBQAFQwAbmkIJyAccdRS45zTNrFzyQAQeO9ADj1BJ5x0oU5 HQjtg06igApKWkoAWjFFFABQKKBQAGijrR2oAKKKKACiijtQAUUUUAFFFA6UAHeiiigANFFHUUAH ejOKMcUUALxikHSjtRQAZooooAB1o70D3pQKAEoooPBpgFHal60nSkAdqKKBTAKD7UUvfNACUEcU UGgQY4pKU9KKAEFL2pBS/WgBO1Apcc0g60AHalxSelHegAoPWig9aAA0vagijtigBO9LRSUABo7U YooAB1oNFFABRS+lJigBaTPFLSUALSUZpeKAE7UUdjSUALQaKD0oAPagUvX60mKADvR3oPSigA60 AZoHWgdaAF6Uh6UdaB0oAM0etAooAOlLik70E0AAo70Cj3oAO9KKKBQAHrRRR15oATpSYpaKACl6 0ZpKACl7HFIeoo7GgB46UUDpRSKPJvB7YuM8dK9Js+nbpXnHhFc3DAdAK9GtBxVMhF0Z7mlpBxRS GLQKKKAFo7UlFABmjtRQaAF7UgoFGKAD3oxRjil60AJ3oxR3pT1FACHrR7UE80Z4oAMYo70UUALi jrQKKADHNFFGeKADFJS0UAANFJ0paACijtR3oAO1IDkf0oYEjg4NLigBO9LSd6WgBKSlooAB0o7U UUAFFBpOaAFooooEHegdaO9H86BgeTS0neloAO1Hajr1o6CgAFHSkxzS0AHY0CkpaAEA5opc80UA LSUA9aPWgAzxQOlJS9qAAUUtJnigYCjHSij0oEB4xQelIetKaACjFJmlzQAlFL3pKAFPSkoo7UAL SUd6KACiiigAo7Ud6KADFFFFABRRS0AJ3oopaAENHNBo6igBaO1JS4oAWkoNFAwzQelJS0AIVJZS HIweQMc/Wl6UCjOaAAdKD1oFBxQAo5pKWk70ALRQKBSAKO9FFAB2pKWk9qAFFFJkZxkZ64paACii koAKKO1FMANAoNFAB3ooooAMUdaKDQAYoxxzR2oNIAIBxnFLSUUABpKU0UAFFFFABRRSUALRRRQA UUd6KACiijtQAdqO1FFABRRRQAUUUd6ACiijFABRRRigAooo7GgAopKU0AFAo/CigAooozQAUd6K O9MAooz7UGgApTSdKXrSATtmgGk9aXjFMBTikPWg/wBaO9AB1FHaik7GgBcUduaB1ooEIKXtSClo AKTvSik5oAO/40vFFGKADoKSijrQAc0HpR+NHagAoz6UetA6igA70tBpKACiijvQAtIOlB6UCgA9 aKKKAA0Ud6P50AHUUUlL2oAO9GKKCKAFFIBgdfxopaACkwKO1HQ0AHagUUDrxQAUdqBxRzQAopO2 KUZpKAD60HrQBR3oAOlHeilNACHrSikA5pRxQAGig/epDQAooo+lJnmgBeppPWjpSigANHY0HtSH 7pxQMeOlFA6UUhnlPhHidsjmvRbTGBivAtG+J9lpc7GbQ7qQH/nncqMc+6816j4O8dnxdDey6Zor RR2jqh+0XIVmyCRwqkdvWmyEd0KKxX1XVoycaCzj1S6B/wDZarP4i1ZOvhi7P+7KD/SgZ0dFcw3i rUAgP/CL6mW9Btx+f/1qRvF14D8nhfVSB3ZVH+NAHUe1HFcz/wAJbdbDjwzq+8HoUXGPrn+lI3i2 7D/L4Y1Yr2JVQfyzQB1FFcx/wll38uPDGr++UXjp05+tCeK7v5vM8MauB/DsRWz9ckY7etAHT44o rmv+EsuSTjwxrWM8fu1yR/31SDxTfknHhfVMZ4yFzSA6WiubPifUMH/il9T3duFxTl8S3pHzeGNV HPYIePzpgdF3pa5z/hI9RO3b4Y1LOOclRg/nTh4i1L+LwzqH/AXQ/wBaAOhoNc9/wkOpnH/FMX/v l0/xoGv6oQc+Gb4en71KAOgHSjvWD/bmqZIHhu8P1lQUra3qu5tnhu6IzwWmQcfrQBuimx7wi7yC +PmKjAJ+nNYn9tax28OT/jcIKP7Z1n/oXJcf9fK/4UAb3ejvWENZ1bjPhyfPtcLR/bWrY/5Fy4z/ ANfCUAblLWD/AG1rH/QtzY7f6Sv+FKNY1k4/4pyT/wACl/woA3OKDWKNV1k/8y8w+t2v+FL/AGpr R/5l/wD8nF/woA2ugo71jf2lrR/5gI/G8X/CnDUNa/6ASD63q/8AxNAXNjikyCT7VlfbdZ/6AsQ+ t6P/AImlF3rBGf7Jtsdv9N/+wpBdGnS1nfadW/6Blv8A+Bf/ANhSfadX/wCgXbf+Bp/+IouBo0Vm i51fvpdt/wCBp/8AjdKbjVyONMtc+94f/jdO4GjRWb9o1nPOmWn1F6f/AI3SG61kgf8AEqtc4/5/ Tj/0XQBp0VlG71zn/iUWh+l8f/jdMa+14fd0O2P/AG//AP2ukBsUVhPqWvBcf8I/Hzxxfj/4imNq 3iEPx4cQoOv+mjJ/8couB0FHWue/tvXP+haf/wACx/8AE0w6/rvbwvIT/wBfQ/8AiaYHS96K5ceI teIBPhSYAjn/AEoZH/jtNk8Ta2ke4+FZRjqWusD89lK4HUjuKX2rlT4l1wY/4pS4z/18f/YUp8Ta 3kY8KXGO/wC//wDsKAOpoFcufEuuYyPCk5573GP/AGSmDxLr+OfCcvXtcn/43RcDq+3NA71yw8S6 8QP+KUm/8CT/APEUv/CSa/j5fCsn43RH/slFwOo7UYrlv+Ei8QZG3wo3vuuyP/adH/CQ+Isf8ip+ V4f/AI3TA6kUVy48Q+Iz/wAyoPxvT/8AG6Ua94jP/MqoP+34/wDxugDp+lA5rmxrfiM/8yxEM/8A T+f/AI3TxrHiLH/Itw/+B/8A9roGdDQOlYA1XxEenhyD8dQ/+107+0/Ef/QvWw/7iP8A9rpAb1J9 axBqHiInnQbQfXUT/wDG6eL3xCeui2I+uot/8aoEa9LWT9q149dJ08f9xB//AI1TvtGvHH/Et04e v+nOc/8AkKi4GpSYrO87W8n/AEHTwMcf6Y/X/v3TjLrPazsB/wBvT/8Axui4F+lrO8zWe9pp+f8A r5f/AON1HFd6u8jRPaWKSKMkfaXII9QdnNAGoaKoF9XI4trEHP8Az3fp/wB8Uvmavj/j2sf/AAIf /wCIpgXsc0VRMmrY4tbIH3uX/wDiKDJq+Di1sQex+0v/APEUgLwpazXfWjny7fT19N07n/2QUvma 1/z66f8A+BD/APxFMDQo61Q83WOP9BsD/wBvjj/2lTTNrWP+QfYE/wDX6/8A8apXA0aKy2uddHTS 7Bv+39h/7SphvNf/AOgNYk/9hBv/AI1RcDX70Vim+8Qg/wDIDsj9NRP/AMapn9peIwefD9qR3xqJ /wDjdAG7RXPnV/EIfb/wjkJ4ycX/AOX/ACzph1rxGP8AmWIvwvz/APG6AOjormv7c8RD/mV1P/b8 f/jdH9u+Isf8iuuf+v0//G6YHSg56Clrmf7f8QA/8iv/AOTh/wDjdIfEHiHHHhYf+Bh/+N0gOno/ CuY/t/xEf+ZVGP8Ar9P/AMbo/wCEg8Rf9CsP/Aw//G6BnT9qO9cv/wAJB4iH/Mqg/wDb6f8A43SH xD4ixx4V7f8AP4f/AI3QI6nvR3rlh4i8R9P+EU/8nT/8bpf+Eh8R4/5FQf8Agaf/AI3TA6jtR1Nc v/wkPiMD/kVV/wDA0/8Axuk/4SDxHn/kVVx/1+n/AON0hnU0Y5rlv+Eh8R/9CoP/AANP/wAbpf8A hIfEfbwoM/8AX6f/AI3TEdSKO9csPEHiTH/Iqp/4HH/43Thr3iP/AKFdP/A4/wDxukM6fpRXN/25 4j4/4pmP3/00/wDxulXWfER/5lqIf9vx/wDjdAHR0hFc+NW8RH/mXYPxvz/8bpTqniPqPD9t+N+f /jdAHQUVgjU/Eh/5l+1/HUD/APG6Uah4lPXQbLr/ANBE/wDxugLm53NLXPzXPiyTH2fT9Kg9fMuH lz+SrSwz+K1P76z0iT/cnkT/ANlNAG8OlFY7T+IyPksNMX63Tt/7IKFufESqA2maa7dyL11H5eWf 50XEbFHasj7V4gzzpWn/APge/wD8apftWv4P/Ep0/P8A1/v/APGqLga1FZP2rX8/8grT/wDwPf8A +NUv2rXv+gTYf+B7f/GqANUCjHNZP2rX+2k2H/gwb/41Sfa9f/6BFh/4MG/+NUXA16Kx/tniH/oC 2H/gxb/41S/a/EB66PYf+DFv/jVFxmvRWT9r1/P/ACCLD/wYN/8AGqT7Xr5/5hFiPrqDf/GqANei sg3XiAj5dK09T6m+Y/8AtMU77Xr2f+QTY/8Age3/AMaouBq0Vlfate/6BVh/4Ht/8apv23XfM2f2 TY9M5+3t/wDGqANekrIW58QgnfpensO2L1xj/wAhmlN1r+0/8SuwH/b65/Ty6ANeisZrnxGVO3Td OVuxN27D8tgpftniDp/Y9jn1+3t/8boA2KBWL9t8Qc/8SayI/wCv8/8Axul+3a//ANAS0/8ABgf/ AI3QBs0VinUNf/6Adr/4Hn/43Sf2hr//AEAbX/wYH/43QBt0Vif2j4gx/wAgG19/+Jgf/jdC6lr7 Ej+w7X3/AOJgeP8AyHQBuUlYn9oeIP8AoBWv/gwP/wAbpq6nrzBsaHbZU4P+nMP5x0Bc3aKxRqOv 5/5AVr/4Hn/43Sf2jr+SP7Ctv/A//wC10Bc26BWIdR1//oBW3/gf/wDa6P7R1/8A6AVt/wCB/wD9 roA26KxP7Q8Qf9AO0/8ABgf/AI3Thf6/nnRLX/wPP/xugDZorF+3+IB/zBLM/wDb+f8A43S/bvEB H/IEs/8AwYH/AON0CubNFYv27xDuz/Ytlt9Pt5/n5dBv/EH/AEA7TH/X+f8A43QM2sUVi/b/ABAM /wDEks8/9f5/+N0f2h4gA/5Adpx/1ED/APG6BG1RWIdR8Qc40K1+v9oH/wCN0z+0/EBJ26FanBwf +Jgf/jdAzeFFYX9p+Isn/iQWpHbF+f8A43Sf2n4hz/yL8A/7f8/+06AN6g1gjVPEBGf+Eftz9L// AO10v9qeID08Pwfjf/8A2ugDexxSGsMan4h/6F+3/wDBh/8Aa6X+0vEOP+QBa/8Agw/+10AbZ9qU YrDOo+IeR/YFr/4MD/8AG6P7R8Q/9AC1/wDBj/8Aa6ANul4rEGoeIe+g2n/gxP8A8bo/tDxD20Kz /wDBif8A43QFza96PesX7f4h/wCgHZ/+DE//ABqj7f4g/wCgFaf+DA//ABugDao7c1jfbvEH/QDs /wDwYH/43Qb7X/8AoCWf/gwP/wAboA2BS8VjC+8QY/5Adp/4MD/8bo+3a/8A9ASz/wDBgf8A43TE bPqKTvWQL7X+P+JJaD/uIH/43S/bNe4/4k1nn/sIH/41QM1+worJF5r2f+QPZj/uIH/41Thda6f+ YVYj/t/b/wCNUAanWjvWYLjW8DOm2Gf+v5v/AI1ThNrBHOn2I/7fWP8A7SoA0DQOlUPO1f8A58LL /wADW/8AjVHnavj/AI8bL/wMb/41RcDQ70H0qh5urZ/48bL/AMDH/wDjVHm6t/z5WX/gW3/xugC9 0paoebq2f+PGy/8AAx//AI1R5ur5/wCPGy/8DH/+NUXEXhxQRVDzdW/58bL/AMDH/wDjVHnav/z4 WX/ga3/xqi4GhikAqj5ur4z9hsc/9fj/APxqo/tGt4/5Blj/AOB7f/GqLjNLpRWd5+tHOdOsf/A5 /wD41SefrQP/ACDbHHr9ub/41RcRpGlrN+0ayP8AmG2R/wC35v8A41S+frHfTrL2xet/8aoA0O1F Z/2jWe2nWWO/+mt/8aoE+sd9Os/wvW/+N0XA0KD1rPFxq/8A0DrP/wADW/8AjdBn1jtp1mfresP/ AGnQBojFJis37RrXH/Ess/8AwOb/AONUn2nWv+gVZ9f+f5v/AI3QBqCg1mfadaP/ADC7T8b4/wDx ul+0azn/AJBtn/4Gt/8AG6ANEUA4rO+0az/0DbPP/X63/wAao+0az/0DbP8A8Dm/+NUAaI60tZ/n 6v8A8+Fp/wCBjH/2nR52rf8APjZ/+Bbf/G6ANDtSHpVHztW/58bP/wAC2/8AjdBl1Yj/AI8rL/wL b/43QBezR1qiJdW5/wBCs/8AwLb/AON0CXVu9lZ4/wCvtv8A43QBdpT1qj5uqdrK0/8AApv/AI3Q JdV/58rP/wAC2/8AjdFwL3vS1R8zVf8Anzs//Apv/jdAl1X/AJ8rL/wLb/43QMu4oql5uq/8+Vn/ AOBbf/G6PN1QHmzs+eB/pTf/ABui4i9SEVT8zU/+fS0/8CW/+N0nmap/z6Wf/gU3/wAbouOxe/lR 9Ko+bqnT7HZ/+BTf/G6US6p/z52f/gU3/wAboAuemaOxqoJNSzza2mP+vlv/AIinK18xIeC3RTxl ZmYj8No/nRcC4OlFC9KKQz4oxzXuPwFH/Es1v/rvF/6CaKKGR1PYgBS4HpRRUjDAo2j0FFFABgUm 3vRRQAuBmjAoooAMYHFGB6UUUALRRRTAKWiigYUUUUAFJRRQAUtFFABSUUUAFFFFABRRRQIKWiig YUmMDAoooAWkoooAKWiigAooooASiiigAxRRRQAYHpRgelFFACEgHnqaSNlkjDLkg8jcMUUUAPxR iiigBMUtFFACYooooAMUtFFACYooooAWjFFFABRRRQAUUUUAJS0UUAJS0UUAIahngMqqytslXlH9 D/hRRQILe483KONkyffT+o9R71NnnFFFACKQ3I5FLRRQAUveiigYUUUUAFJRRQAUUUUAIvTJ70tF FABRRRQAtGKKKAG7037Nw3YztzzilxRRQAtGKKKADFJiiigAxRiiigAxRiiigBcUmBRRQAtFFFAB RRRQAUUUUAFFFFABRRRQAUlFFABS0UUAFFFFABSUUUALRRRQAUgz3oooAWmqvzFick/yoopAOooo oAMUUUUAJRRRQAUUUUAFFFFABRRRQAUUUUAFGKKKACiiigAooooAWkoooAKMUUUwDFNwAQcc5xRR QA4YpGO0fpRRQIUc0YAoooGFLRRQAlFFFAC0UUUAFJRRQAtJRRQAUtFFABRRRQAUUUUAJRRRQAUt FFABRRRQAUlFFAC0UUUAFFFFABRRRQAUUUUAJS0UUAFFFFMAooopAFFFFMAooopAFFFFABRRRQAU UUUAFFFFMAooopAIx2gn0paKKACkJA60UUALRRRQAUUUUAKKKKKYz//ZZW5kc3RyZWFtDWVuZG9i ag0yIDAgb2JqDTw8IC9MZW5ndGggNDcgDT4+DXN0cmVhbQ1xIDYxMi4wMCAwIDAgNzkyLjAwIDAu MDAgMC4wMCBjbSAxIGcgL0ltMSBEbyBRDWVuZHN0cmVhbQ1lbmRvYmoNMyAwIG9iag08PA0vVHlw ZSAvUGFnZQ0vTWVkaWFCb3ggWzAgMCA2MTIgNzkyXQ0vUGFyZW50IDQgMCBSIA0vUm90YXRlIDAg L1Jlc291cmNlcyA8PA0vUHJvY1NldCBbL1BERiAvSW1hZ2VDIC9JbWFnZUIgL0ltYWdlSV0NL1hP YmplY3QgPDwNL0ltMSAxIDAgUg0gPj4NID4+DS9Db250ZW50cyBbIDIgMCBSDV0NPj4NZW5kb2Jq DTQgMCBvYmoNPDwNL1R5cGUgL1BhZ2VzDS9LaWRzIFsgMyAwIFJdDS9Db3VudCAxDT4+DWVuZG9i ag01IDAgb2JqDTw8DS9UeXBlIC9DYXRhbG9nDS9QYWdlcyA0IDAgUiAgDT4+DWVuZG9iag02IDAg b2JqDTw8IC9DcmVhdG9yICgpDS9DcmVhdGlvbkRhdGUgKCkNL0F1dGhvciAoKQ0vUHJvZHVjZXIg KCkNL1RpdGxlICgpDS9TdWJqZWN0ICgpDT4+DWVuZG9iag14cmVmDTEgNw0wMDAwMDAwMDAwIDY1 NTM1IGYgDTAwMDAwMDAwMDkgMDAwMDAgbiANMDAwMDM0MzE5OSAwMDAwMCBuIA0wMDAwMzQzMjk2 IDAwMDAwIG4gDTAwMDAzNDM0ODMgMDAwMDAgbiANMDAwMDM0MzU0MSAwMDAwMCBuIA0wMDAwMzQz NTkyIDAwMDAwIG4gDXRyYWlsZXINPDwNL1NpemUgNw0vUm9vdCA1IDAgUg0vSW5mbyA2IDAgUg0+ Pg1zdGFydHhyZWYNMzQzNjg4DSUlRU9GDQ= ________________________________________________________________________________
Date: Oct 30, 2019
Subject: Re: Brass Current-carrying Calcs
At 02:45 PM 10/30/2019, you wrote: >Brass has 28% the capacity of copper but since the runs it will go >through are so short and the amperage would be fairly low (<100 amps >I am guessing) it is usually not a problem. The question is why not copper? Excellent question. Consider: https://tinyurl.com/y333wjru https://tinyurl.com/y3w7swc3 https://tinyurl.com/y5uy46v8 What size(s) are your proposed bus bar(s)? I may have some pieces in my 'good scrap' that would suffice. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2019
Thanks Rod & Bob for your responses. The short answer to the question of "why not use copper?" is that I've go a whole bunch of brass in my scrap-metal pile. I did the math using the values for copper then adjusted for brass and the voltage drop at rated current is 37 mV, which I think I can live with ;) Thanks for the input, -Jeff I wrote: At 02:45 PM 10/30/2019, you wrote: Brass has 28% the capacity ofcopper but since the runs it will go through a re so short and theamperage would be fairly low (<100 amps I am guessing) i t is usuallynot a problem. The question is why not copper? =C2- Excellent question. Consider: https://tinyurl.com/y333wjru https://tinyurl.com/y3w7swc3 https://tinyurl.com/y5uy46v8 =C2- What size(s) are your proposed bus =C2- bar(s)?=C2- I may have some pieces =C2- in my 'good scrap' that would suffice. =C2- Bob . . . ________________________________________________________________________________
Subject: Re: Slobovia Pumpkin Drop time! (cancellation)
Date: Oct 30, 2019
Unfortunately, we've had to cancel the Pumpkin Drop for this year. Three months of drought, then almost 10" of rain in the last 10 days. Too wet to safely park planes, even if the runway could handle them. So 'save the date'; 1st Saturday in November, 2020. Charlie On 10/3/2019 9:53 PM, Charlie England wrote: > Hoping y'all can make it out on Nov 2 for our annual Pumpkin drop at > Slobovia Outernational (MS71), just north of Jackson MS. Flyer > attached; bring family & friends for some great Cajun food followed by > our Pumpkin Bombing competition. > > Charlie, for the Lower Slobovia Garden Club > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Glastar Dipole comm antennae behind doors
Date: Oct 31, 2019
Thanks, Bob! It had never occurred to me to step back and see the obvious: that that front antenna was simply peaking well below the av band. I will experiment with trimming it I will also look forward to your balun. Thanks, -Lou Read this topic online here: http://forums.matronics.com/viewtopic.php?p=492066#492066 ________________________________________________________________________________
Subject: ADS-B for combined satellite/ground using a dipole
Date: Oct 31, 2019
I am currently equipped with ADS-B meeting the 2020 US mandate. However, I do fly frequently in Canada, and am starting to thing about getting ahead of the game for that. The currently available "diversity" solutions (which alternately ping a top and bottom-mounted antenna) are pretty expensive, and would require ditching what I have now. So...I've been wondering if, given that I have a composite airframe, I could mount a vertical dipole, tuned for 1090 MHz in the tail cone, and have it work with both satellite and ground ADS-B stations. I do understand that I might be cutting the power available to ping either type of station by half -- or arguably a bit better than that, since the dipole might be more efficient than a quarter-wave with a limited ground plane. Thoughts? Thanks, -Lou Read this topic online here: http://forums.matronics.com/viewtopic.php?p=492067#492067 ________________________________________________________________________________
Date: Oct 31, 2019
I am currently equipped with ADS-B meeting the 2020 US mandate. However, I do fly frequently in Canada, and am starting to thing about getting ahead of the game for that. The currently available "diversity" solutions (which alternately ping a top and bottom-mounted antenna) are pretty expensive, and would require ditching what I have now. So...I've been wondering if, given that I have a composite airframe, I could mount a vertical dipole, tuned for 1090 MHz in the tail cone, and have it work with both satellite and ground ADS-B stations. I do understand that I might be cutting the power available to ping either type of station by half -- or arguably a bit better than that, since the dipole might be more efficient than a quarter-wave with a limited ground plane. Thoughts? Thanks, -Lou Read this topic online here: http://forums.matronics.com/viewtopic.php?p=492069#492069 ________________________________________________________________________________
Date: Nov 01, 2019
Subject: PLEASE READ - Matronics Email List 2018 Fund Raiser
During November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages.
October 15, 2019 - November 01, 2019
AeroElectric-Archive.digest.vol-pd
