Commander-Archive.digest.vol-de
October 27, 2008 - November 06, 2008
Date: Oct 27, 2008
I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message -----
Sent: Sunday, October 26, 2008 6:14 PM
Subject: AC-680 FLP Engine RPM Fluctuation
> > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff. > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > ________________________________________________________________________________
Date: Oct 27, 2008
Subject: Re: AC-680 FLP Engine RPM Fluctuation
Tom, did --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff. > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > ________________________________________________________________________________
Date: Oct 27, 2008
Tom, --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff. > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > ________________________________________________________________________________
Date: Oct 27, 2008
Tom, did you replace the lines with ones of the same Inside diameter?- Di d you replace those on both sides of the flow divider (spider), and the fue l servo? - wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff . > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > =0A=0A=0A ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Date: Oct 27, 2008
I got a new set from Mr.RPM himself so I assume they were of the same inside diameter and yes his lines leaked and had to be welded in two places. I just replaced the lines from the flow divider to the cylinders. Tom. C-GISS ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Monday, October 27, 2008 7:59 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Tom, did you replace the lines with ones of the same Inside diameter? Did you replace those on both sides of the flow divider (spider), and the fuel servo? wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation To: commander-list(at)matronics.com Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff. > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Oct 27, 2008
Subject: Re: ebay 224HA
Peter; The youtube you sent is not my airplane, it looks like it has slimline nacelles, not bathtub ones, however the next youtube of a take off, http://www.youtube.com/watch?v=wSe8CKyki7U&feature=related is mine before I got it painted. Back when Chris had the site, I also had one of a low pass at the same airport. No more than I fly mine I probably should sell it but its my Linus's blanket, I can go get a "God's eye" view and "restoreth my soul" and I feel better, so plan on just keeping it. I fly it up to Van Wert, OH. just about every year for a family reunion and take lots of rides. This year took an Amish family (an acquaintance of my brother) for their first and maybe only flight. Maybe someday we can get together. God Bless, Don ----- Original Message ----- From: "Peter Bichier" <pbichie(at)UTNet.UToledo.Edu> Sent: Monday, October 27, 2008 5:16 AM Subject: Commander-List: Re: ebay 224HA > > > Sorry Don, I mixed up... > > Where is this airplane anyways? I can't find it on ebay... is it already > gone? > > I did say, quote: "I think"... the reason being that an "ACA125" user > posted a video commenting that it was "your" 560E and signed as "N224HA > 560E"... > > http://www.youtube.com/watch?v=jeDdTBQlgIg > > anyway, I confused you mixing both 560Es... sorry again! the funny thing > though, is that in Matronics Archives from last year, a certain > "skyhawkc-172(at)comcast.net" signed as "Brent - N224HA" > > http://www.matronics.com/archive/archive-get.cgi?Commander-Archive.digest.vol-ci > > and on other photos of N224HA posted on the web Brent was talking about > his "lost love"... > > so does that mean he bought it back? or that was actually the seller's > email? > > very interesting... > > [quote="dongirod"]Now you've done it Peter. > > NO it's not mine! > > Mine is N2707B S# 555 > > Don > > -------- > 560 Dreamer > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=210464#210464 > > -------------------------------------------------------------------------------- Checked by AVG - http://www.avg.com 8:33 AM ________________________________________________________________________________
Date: Oct 27, 2008
Thanks Tom. - Ive designed a few fuel systems and his symptoms are typical of a flowdivid er/lines on the hot side of an engine. (side downstream of an air cooled en gine)-And-are-more prevalent with Lines that have a lot of volume.- - Im unfamiliar with Commanders, but from the looks of the cowl inlets on som e of them,-it appears the cooling airflow is from bottom to top and then out.- If not then there is a big air-dam that deflects cool air to the to p of the engine and then down.- Either way, cooling appears greatly reduc ed during climbout unless there are some big cown-vents downstream. - As-Ive seen it. 1.- larger dia. lines have a higher vapor/liquid ratio-during operation , and on shut down, cook-off the remaining fuel in the FDV.- they are bet ter, however on climbout as there is less pressure losses and heat absorbed .- Modern FDV's have a purge valve that dumps fuel back to the inlet of t he pump on shutdown.- this immediately drops the pressure at the nozzles to zero... - 2. smaller lines have shorter fill times, quicker starts but are susceptibl e to vapor lock because they absorb heat faster.- At higher flowrates (ri ch) the delta-P loss in these lines may result in a higher vapor/liquid rat o- and thus a poorer spray patter at the nozzle.- This is more of an is sue on climbout on engines with poor cooling for whatever reason (like clos ed cowlvents, or just reduced airspeed (airflow)).- Modern fuellines in t hese situations are insulated (just like grandpas truck). - 3.- for systems with high flowrates (~100 pph or more) the different leng ths of fuel lines from the FDV to each nozzle becomes important.- there a re different pressure losses in each leg. (which makes GAMI's all the more important.-)- If you want to save yourself the recurring cost of Gami i njectors...get your flow divider valve balanced with your set of nozzles. - Just some thoughts. - wer former Pratt-Whitney and Ham-STD - - --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 10:57 AM I got a new set from Mr.RPM himself so I assume they were of the same insid e diameter and yes his lines leaked and had to be welded in two places. I j ust replaced the lines from the flow divider to the cylinders. Tom. C-GISS - ----- Original Message ----- From: willis robison Sent: Monday, October 27, 2008 7:59 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Tom, did you replace the lines with ones of the same Inside diameter?- Di d you replace those on both sides of the flow divider (spider), and the fue l servo? - wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff . > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.m atronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com /contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D =0A=0A=0A ________________________________________________________________________________
Subject: BrightLine Bags Pilot Flight Bag
Date: Oct 27, 2008
Hi Everyone, I just wanted to write and thank everybody who bought a Flight Bag from us a couple of months back. I hope that the bag is working out better than you had hoped. As an FYI, the bags are now black and have a few changes to them. As always, if you have any comments about the bag, I would love to hear them. Thanks especially to John V and Keith G for the support. I have included a link to our online demo and a photo if you are interested. http://brightlinebags.ipower.com/videopage.html. Thanks again for your support!! Bryan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210563#210563 Attachments: http://forums.matronics.com//files/brightline_pilot_flight_bag_686.jpg ________________________________________________________________________________
Date: Oct 27, 2008
Don, We really are all glad you enjoy your bird and that you are planning to keep it; I have indeed seen that take off and the low pass on youtube; what I specially like is the sound track! too often music is added and really empties a lot of the experience... I would love to see and fly in your 560E, I have not flown in an Aero Commander since 1982... even though I fly on light twins for work 3-4 times a year in the tropics. If you want to see a 'young' man in heaven and truly happy, please let me know when you come to Van Wert; a 2 hour drive will be a breeze for such a joy! I sure hope I'll be around! I travel a lot... what time of the year do you visit your folks? Don, just knowing there is a possibility that I fly in an Aero Commander one of these days has lifted up my spirit! I would certainly enjoy meeting you too, Best regards, Peter dongirod wrote: > Peter; > > The youtube you sent is not my airplane, it looks like it has slimline > nacelles, not bathtub ones, however the next youtube of a take off, > http://www.youtube.com/watch?v=wSe8CKyki7U&feature=related is mine before I > got it painted. Back when Chris had the site, I also had one of a low pass > at the same airport. > > No more than I fly mine I probably should sell it but its my Linus's > blanket, I can go get a "God's eye" view and "restoreth my soul" and I feel > better, so plan on just keeping it. I fly it up to Van Wert, OH. just about > every year for a family reunion and take lots of rides. This year took an > Amish family (an acquaintance of my brother) for their first and maybe only > flight. Maybe someday we can get together. > > God Bless, Don > > > > > --- -------- 560 Dreamer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210569#210569 ________________________________________________________________________________
Date: Oct 27, 2008
Well, I am that much more informed, thanks for the info. Tom C-GISS ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Monday, October 27, 2008 11:54 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Thanks Tom. Ive designed a few fuel systems and his symptoms are typical of a flowdivider/lines on the hot side of an engine. (side downstream of an air cooled engine) And are more prevalent with Lines that have a lot of volume. Im unfamiliar with Commanders, but from the looks of the cowl inlets on some of them, it appears the cooling airflow is from bottom to top and then out. If not then there is a big air-dam that deflects cool air to the top of the engine and then down. Either way, cooling appears greatly reduced during climbout unless there are some big cown-vents downstream. As Ive seen it. 1. larger dia. lines have a higher vapor/liquid ratio during operation, and on shut down, cook-off the remaining fuel in the FDV. they are better, however on climbout as there is less pressure losses and heat absorbed. Modern FDV's have a purge valve that dumps fuel back to the inlet of the pump on shutdown. this immediately drops the pressure at the nozzles to zero... 2. smaller lines have shorter fill times, quicker starts but are susceptible to vapor lock because they absorb heat faster. At higher flowrates (rich) the delta-P loss in these lines may result in a higher vapor/liquid rato and thus a poorer spray patter at the nozzle. This is more of an issue on climbout on engines with poor cooling for whatever reason (like closed cowlvents, or just reduced airspeed (airflow)). Modern fuellines in these situations are insulated (just like grandpas truck). 3. for systems with high flowrates (~100 pph or more) the different lengths of fuel lines from the FDV to each nozzle becomes important. there are different pressure losses in each leg. (which makes GAMI's all the more important. ) If you want to save yourself the recurring cost of Gami injectors...get your flow divider valve balanced with your set of nozzles. Just some thoughts. wer former Pratt-Whitney and Ham-STD --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation To: commander-list(at)matronics.com Date: Monday, October 27, 2008, 10:57 AM I got a new set from Mr.RPM himself so I assume they were of the same inside diameter and yes his lines leaked and had to be welded in two places. I just replaced the lines from the flow divider to the cylinders. Tom. C-GISS ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Monday, October 27, 2008 7:59 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Tom, did you replace the lines with ones of the same Inside diameter? Did you replace those on both sides of the flow divider (spider), and the fuel servo? wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation To: commander-list(at)matronics.com Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff. > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www .matronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.c om/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Oct 28, 2008
Well, Next time you fly, once youve leaned for cruise, check the EGTs for t hose cylilnders that had the new lines welded.- If they are running withi n a few degrees of the others, then he did a good job welding.- SS lines with anything less than 130 thou. diam-are extremely hard to weld without causing an "orifice" at the weldsite.- - -Also, I doubt that he-annealed the new weld, which will make the heat affected zone-more brittle than the rest. Ask him how he treated the weld .- (a smoky acetylene torch for- 2 minutes would be sufficient. - Bottom line, Mr.RPM should have is axxx chewed for sending you lousy parts. You shouldnt have to do his Acceptance test procedures on your AC. - wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 2:17 PM Well, I am that much more informed, thanks for the info. Tom C-GISS ----- Original Message ----- From: willis robison Sent: Monday, October 27, 2008 11:54 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Thanks Tom. - Ive designed a few fuel systems and his symptoms are typical of a flowdivid er/lines on the hot side of an engine. (side downstream of an air cooled en gine)-And-are-more prevalent with Lines that have a lot of volume.- - Im unfamiliar with Commanders, but from the looks of the cowl inlets on som e of them,-it appears the cooling airflow is from bottom to top and then out.- If not then there is a big air-dam that deflects cool air to the to p of the engine and then down.- Either way, cooling appears greatly reduc ed during climbout unless there are some big cown-vents downstream. - As-Ive seen it. 1.- larger dia. lines have a higher vapor/liquid ratio-during operation , and on shut down, cook-off the remaining fuel in the FDV.- they are bet ter, however on climbout as there is less pressure losses and heat absorbed .- Modern FDV's have a purge valve that dumps fuel back to the inlet of t he pump on shutdown.- this immediately drops the pressure at the nozzles to zero... - 2. smaller lines have shorter fill times, quicker starts but are susceptibl e to vapor lock because they absorb heat faster.- At higher flowrates (ri ch) the delta-P loss in these lines may result in a higher vapor/liquid rat o- and thus a poorer spray patter at the nozzle.- This is more of an is sue on climbout on engines with poor cooling for whatever reason (like clos ed cowlvents, or just reduced airspeed (airflow)).- Modern fuellines in t hese situations are insulated (just like grandpas truck). - 3.- for systems with high flowrates (~100 pph or more) the different leng ths of fuel lines from the FDV to each nozzle becomes important.- there a re different pressure losses in each leg. (which makes GAMI's all the more important.-)- If you want to save yourself the recurring cost of Gami i njectors...get your flow divider valve balanced with your set of nozzles. - Just some thoughts. - wer former Pratt-Whitney and Ham-STD - - --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 10:57 AM I got a new set from Mr.RPM himself so I assume they were of the same insid e diameter and yes his lines leaked and had to be welded in two places. I j ust replaced the lines from the flow divider to the cylinders. Tom. C-GISS - ----- Original Message ----- From: willis robison Sent: Monday, October 27, 2008 7:59 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Tom, did you replace the lines with ones of the same Inside diameter?- Di d you replace those on both sides of the flow divider (spider), and the fue l servo? - wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff . > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.m atronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com /contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.m atronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com /contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D =0A=0A=0A ________________________________________________________________________________
Date: Oct 28, 2008
I do not yet have engine monitors but they are on the wish list. Well he was out of the business and already sold the STC and as far as I was concerned I was happy to receive the lines from him even if they had to be tweaked by an expensive AME who did in fact anneal the welds, good point. Tom. C-GISS ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Tuesday, October 28, 2008 8:11 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Well, Next time you fly, once youve leaned for cruise, check the EGTs for those cylilnders that had the new lines welded. If they are running within a few degrees of the others, then he did a good job welding. SS lines with anything less than 130 thou. diam are extremely hard to weld without causing an "orifice" at the weldsite. Also, I doubt that he annealed the new weld, which will make the heat affected zone more brittle than the rest. Ask him how he treated the weld. (a smoky acetylene torch for 2 minutes would be sufficient. Bottom line, Mr.RPM should have is axxx chewed for sending you lousy parts. You shouldnt have to do his Acceptance test procedures on your AC. wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation To: commander-list(at)matronics.com Date: Monday, October 27, 2008, 2:17 PM Well, I am that much more informed, thanks for the info. Tom C-GISS ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Monday, October 27, 2008 11:54 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Thanks Tom. Ive designed a few fuel systems and his symptoms are typical of a flowdivider/lines on the hot side of an engine. (side downstream of an air cooled engine) And are more prevalent with Lines that have a lot of volume. Im unfamiliar with Commanders, but from the looks of the cowl inlets on some of them, it appears the cooling airflow is from bottom to top and then out. If not then there is a big air-dam that deflects cool air to the top of the engine and then down. Either way, cooling appears greatly reduced during climbout unless there are some big cown-vents downstream. As Ive seen it. 1. larger dia. lines have a higher vapor/liquid ratio during operation, and on shut down, cook-off the remaining fuel in the FDV. they are better, however on climbout as there is less pressure losses and heat absorbed. Modern FDV's have a purge valve that dumps fuel back to the inlet of the pump on shutdown. this immediately drops the pressure at the nozzles to zero... 2. smaller lines have shorter fill times, quicker starts but are susceptible to vapor lock because they absorb heat faster. At higher flowrates (rich) the delta-P loss in these lines may result in a higher vapor/liquid rato and thus a poorer spray patter at the nozzle. This is more of an issue on climbout on engines with poor cooling for whatever reason (like closed cowlvents, or just reduced airspeed (airflow)). Modern fuellines in these situations are insulated (just like grandpas truck). 3. for systems with high flowrates (~100 pph or more) the different lengths of fuel lines from the FDV to each nozzle becomes important. there are different pressure losses in each leg. (which makes GAMI's all the more important. ) If you want to save yourself the recurring cost of Gami injectors...get your flow divider valve balanced with your set of nozzles. Just some thoughts. wer former Pratt-Whitney and Ham-STD --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation To: commander-list(at)matronics.com Date: Monday, October 27, 2008, 10:57 AM I got a new set from Mr.RPM himself so I assume they were of the same inside diameter and yes his lines leaked and had to be welded in two places. I just replaced the lines from the flow divider to the cylinders. Tom. C-GISS ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Monday, October 27, 2008 7:59 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Tom, did you replace the lines with ones of the same Inside diameter? Did you replace those on both sides of the flow divider (spider), and the fuel servo? wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation To: commander-list(at)matronics.com Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff. > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www .matronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.c om/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www .matronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.c om/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
From: "Don Barry Home" <don.barry(at)sbcglobal.net>
Date: Oct 28, 2008
MR. RPM is out of business?? I wonder whatever happened to that AC they were playing around with the water-cooled Orenda engines. Don Houston TX _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tom Fisher Sent: Tuesday, October 28, 2008 10:46 PM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation I do not yet have engine monitors but they are on the wish list. Well he was out of the business and already sold the STC and as far as I was concerned I was happy to receive the lines from him even if they had to be tweaked by an expensive AME who did in fact anneal the welds, good point. Tom. C-GISS ----- Original Message ----- From: willis robison <mailto:drwer2(at)yahoo.com> Sent: Tuesday, October 28, 2008 8:11 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Well, Next time you fly, once youve leaned for cruise, check the EGTs for those cylilnders that had the new lines welded. If they are running within a few degrees of the others, then he did a good job welding. SS lines with anything less than 130 thou. diam are extremely hard to weld without causing an "orifice" at the weldsite. Also, I doubt that he annealed the new weld, which will make the heat affected zone more brittle than the rest. Ask him how he treated the weld. (a smoky acetylene torch for 2 minutes would be sufficient. Bottom line, Mr.RPM should have is axxx chewed for sending you lousy parts. You shouldnt have to do his Acceptance test procedures on your AC. wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 2:17 PM Well, I am that much more informed, thanks for the info. Tom C-GISS ----- Original Message ----- From: willis <mailto:drwer2(at)yahoo.com> robison Sent: Monday, October 27, 2008 11:54 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Thanks Tom. Ive designed a few fuel systems and his symptoms are typical of a flowdivider/lines on the hot side of an engine. (side downstream of an air cooled engine) And are more prevalent with Lines that have a lot of volume. Im unfamiliar with Commanders, but from the looks of the cowl inlets on some of them, it appears the cooling airflow is from bottom to top and then out. If not then there is a big air-dam that deflects cool air to the top of the engine and then down. Either way, cooling appears greatly reduced during climbout unless there are some big cown-vents downstream. As Ive seen it. 1. larger dia. lines have a higher vapor/liquid ratio during operation, and on shut down, cook-off the remaining fuel in the FDV. they are better, however on climbout as there is less pressure losses and heat absorbed. Modern FDV's have a purge valve that dumps fuel back to the inlet of the pump on shutdown. this immediately drops the pressure at the nozzles to zero... 2. smaller lines have shorter fill times, quicker starts but are susceptible to vapor lock because they absorb heat faster. At higher flowrates (rich) the delta-P loss in these lines may result in a higher vapor/liquid rato and thus a poorer spray patter at the nozzle. This is more of an issue on climbout on engines with poor cooling for whatever reason (like closed cowlvents, or just reduced airspeed (airflow)). Modern fuellines in these situations are insulated (just like grandpas truck). 3. for systems with high flowrates (~100 pph or more) the different lengths of fuel lines from the FDV to each nozzle becomes important. there are different pressure losses in each leg. (which makes GAMI's all the more important. ) If you want to save yourself the recurring cost of Gami injectors...get your flow divider valve balanced with your set of nozzles. Just some thoughts. wer former Pratt-Whitney and Ham-STD --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 10:57 AM I got a new set from Mr.RPM himself so I assume they were of the same inside diameter and yes his lines leaked and had to be welded in two places. I just replaced the lines from the flow divider to the cylinders. Tom. C-GISS ----- Original Message ----- From: willis <mailto:drwer2(at)yahoo.com> robison Sent: Monday, October 27, 2008 7:59 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Tom, did you replace the lines with ones of the same Inside diameter? Did you replace those on both sides of the flow divider (spider), and the fuel servo? wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff. > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > > > 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== ________________________________________________________________________________
Date: Oct 28, 2008
I am not sure that I remember the Orenda story correctly, Don, but folks on this list know a lot more about it than I do. Apparently it ran out of money and / or there wasn't enough push in Canada at the time to complete the job to certification. Perhaps someone could enlighten us, but it is a topic that has been discussed until there was a grove in the ground. :-) Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don Barry Home Sent: Tuesday, October 28, 2008 9:00 PM Subject: RE: Commander-List: AC-680 FLP Engine RPM Fluctuation MR. RPM is out of business?? I wonder whatever happened to that AC they were playing around with the water-cooled Orenda engines. Don Houston TX _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tom Fisher Sent: Tuesday, October 28, 2008 10:46 PM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation I do not yet have engine monitors but they are on the wish list. Well he was out of the business and already sold the STC and as far as I was concerned I was happy to receive the lines from him even if they had to be tweaked by an expensive AME who did in fact anneal the welds, good point. Tom. C-GISS ----- Original Message ----- From: willis robison <mailto:drwer2(at)yahoo.com> Sent: Tuesday, October 28, 2008 8:11 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Well, Next time you fly, once youve leaned for cruise, check the EGTs for those cylilnders that had the new lines welded. If they are running within a few degrees of the others, then he did a good job welding. SS lines with anything less than 130 thou. diam are extremely hard to weld without causing an "orifice" at the weldsite. Also, I doubt that he annealed the new weld, which will make the heat affected zone more brittle than the rest. Ask him how he treated the weld. (a smoky acetylene torch for 2 minutes would be sufficient. Bottom line, Mr.RPM should have is axxx chewed for sending you lousy parts. You shouldnt have to do his Acceptance test procedures on your AC. wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 2:17 PM Well, I am that much more informed, thanks for the info. Tom C-GISS ----- Original Message ----- From: willis robison <mailto:drwer2(at)yahoo.com> Sent: Monday, October 27, 2008 11:54 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Thanks Tom. Ive designed a few fuel systems and his symptoms are typical of a flowdivider/lines on the hot side of an engine. (side downstream of an air cooled engine) And are more prevalent with Lines that have a lot of volume. Im unfamiliar with Commanders, but from the looks of the cowl inlets on some of them, it appears the cooling airflow is from bottom to top and then out. If not then there is a big air-dam that deflects cool air to the top of the engine and then down. Either way, cooling appears greatly reduced during climbout unless there are some big cown-vents downstream. As Ive seen it. 1. larger dia. lines have a higher vapor/liquid ratio during operation, and on shut down, cook-off the remaining fuel in the FDV. they are better, however on climbout as there is less pressure losses and heat absorbed. Modern FDV's have a purge valve that dumps fuel back to the inlet of the pump on shutdown. this immediately drops the pressure at the nozzles to zero... 2. smaller lines have shorter fill times, quicker starts but are susceptible to vapor lock because they absorb heat faster. At higher flowrates (rich) the delta-P loss in these lines may result in a higher vapor/liquid rato and thus a poorer spray patter at the nozzle. This is more of an issue on climbout on engines with poor cooling for whatever reason (like closed cowlvents, or just reduced airspeed (airflow)). Modern fuellines in these situations are insulated (just like grandpas truck). 3. for systems with high flowrates (~100 pph or more) the different lengths of fuel lines from the FDV to each nozzle becomes important. there are different pressure losses in each leg. (which makes GAMI's all the more important. ) If you want to save yourself the recurring cost of Gami injectors...get your flow divider valve balanced with your set of nozzles. Just some thoughts. wer former Pratt-Whitney and Ham-STD --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 10:57 AM I got a new set from Mr.RPM himself so I assume they were of the same inside diameter and yes his lines leaked and had to be welded in two places. I just replaced the lines from the flow divider to the cylinders. Tom. C-GISS ----- Original Message ----- From: willis robison <mailto:drwer2(at)yahoo.com> Sent: Monday, October 27, 2008 7:59 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Tom, did you replace the lines with ones of the same Inside diameter? Did you replace those on both sides of the flow divider (spider), and the fuel servo? wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff. > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > > > 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: AC-680 FLP Engine RPM Fluctuation
Date: Oct 29, 2008
VGhlIFNUQydzIHdlcmUgcGlja2VkIHVwIGJ5IGEgZ3V5IGluIEZMLiBUaGUgbGluayBzdGlsbCB3 b3Jrcw0KDQpjcmFpZyANCg0KU2VudCB2aWEgQmxhY2tCZXJyeSBieSBBVCZUDQoNCi0tLS0tT3Jp Z2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiAiRG9uIEJhcnJ5IEhvbWUiIDxkb24uYmFycnlAc2Jj Z2xvYmFsLm5ldD4NCg0KRGF0ZTogVHVlLCAyOCBPY3QgMjAwOCAyMzowMDoyNiANClRvOiA8Y29t bWFuZGVyLWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IFJFOiBDb21tYW5kZXItTGlzdDog QUMtNjgwIEZMUCBFbmdpbmUgUlBNIEZsdWN0dWF0aW9uDQoNCg0KVGhpcyBpcyBhIG11bHRpLXBh cnQgbWVzc2FnZSBpbiBNSU1FIGZvcm1hdC4NCg0K ________________________________________________________________________________
Date: Oct 29, 2008
Dick MacCoon's old site is still available (actually the domain is for sale) http://www.mrrpm.com/ it still has a video on the "promissing" (2002) new aluminum V8 water cooled engines which were supposed to be cheaper and fuel efficient... RPM Commander LLC is still in business and selling a couple of 560Fs http://www.rpmcommander.com/ To reach: RPM COMMANDER LLC (For STC services) c/o Paul Gendron 1401 N. Riverside Drive Suite 607 Pompano Beach, FLorida, USA 33062 -------- 560 Dreamer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210930#210930 ________________________________________________________________________________
From: "Robert S. Randazzo" <rsrandazzo(at)precisionmanuals.com>
Subject: AC-680 FLP Engine RPM Fluctuation
Date: Oct 29, 2008
Don- The engine technology was picked up by an outfit called Trace Engines. (www.traceengines.com) They had a stand set up at the races this year at Reno. We stopped by to chat with them- and they brought around a fellow who has purchased the original Orenda certification test airplane. He has a second outfit that he explained was working to STC the 685 with these engines mounted. He claimed that they were "months away from an STC" to hang the V8s on 685s.. That Mr. RPM test bed commander is currently on the ground in Midland TX and according to some sources I checked with- it hasn't been flying in some time.. Like all things in GA- seems to be more heat than energy being generated on that project. ;-) Robert S. Randazzo N414C From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don Barry Home Sent: Tuesday, October 28, 2008 9:00 PM Subject: RE: Commander-List: AC-680 FLP Engine RPM Fluctuation MR. RPM is out of business?? I wonder whatever happened to that AC they were playing around with the water-cooled Orenda engines. Don Houston TX _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tom Fisher Sent: Tuesday, October 28, 2008 10:46 PM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation I do not yet have engine monitors but they are on the wish list. Well he was out of the business and already sold the STC and as far as I was concerned I was happy to receive the lines from him even if they had to be tweaked by an expensive AME who did in fact anneal the welds, good point. Tom. C-GISS ----- Original Message ----- From: willis robison <mailto:drwer2(at)yahoo.com> Sent: Tuesday, October 28, 2008 8:11 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Well, Next time you fly, once youve leaned for cruise, check the EGTs for those cylilnders that had the new lines welded. If they are running within a few degrees of the others, then he did a good job welding. SS lines with anything less than 130 thou. diam are extremely hard to weld without causing an "orifice" at the weldsite. Also, I doubt that he annealed the new weld, which will make the heat affected zone more brittle than the rest. Ask him how he treated the weld. (a smoky acetylene torch for 2 minutes would be sufficient. Bottom line, Mr.RPM should have is axxx chewed for sending you lousy parts. You shouldnt have to do his Acceptance test procedures on your AC. wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 2:17 PM Well, I am that much more informed, thanks for the info. Tom C-GISS ----- Original Message ----- From: willis robison <mailto:drwer2(at)yahoo.com> Sent: Monday, October 27, 2008 11:54 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Thanks Tom. Ive designed a few fuel systems and his symptoms are typical of a flowdivider/lines on the hot side of an engine. (side downstream of an air cooled engine) And are more prevalent with Lines that have a lot of volume. Im unfamiliar with Commanders, but from the looks of the cowl inlets on some of them, it appears the cooling airflow is from bottom to top and then out. If not then there is a big air-dam that deflects cool air to the top of the engine and then down. Either way, cooling appears greatly reduced during climbout unless there are some big cown-vents downstream. As Ive seen it. 1. larger dia. lines have a higher vapor/liquid ratio during operation, and on shut down, cook-off the remaining fuel in the FDV. they are better, however on climbout as there is less pressure losses and heat absorbed. Modern FDV's have a purge valve that dumps fuel back to the inlet of the pump on shutdown. this immediately drops the pressure at the nozzles to zero... 2. smaller lines have shorter fill times, quicker starts but are susceptible to vapor lock because they absorb heat faster. At higher flowrates (rich) the delta-P loss in these lines may result in a higher vapor/liquid rato and thus a poorer spray patter at the nozzle. This is more of an issue on climbout on engines with poor cooling for whatever reason (like closed cowlvents, or just reduced airspeed (airflow)). Modern fuellines in these situations are insulated (just like grandpas truck). 3. for systems with high flowrates (~100 pph or more) the different lengths of fuel lines from the FDV to each nozzle becomes important. there are different pressure losses in each leg. (which makes GAMI's all the more important. ) If you want to save yourself the recurring cost of Gami injectors...get your flow divider valve balanced with your set of nozzles. Just some thoughts. wer former Pratt-Whitney and Ham-STD --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 10:57 AM I got a new set from Mr.RPM himself so I assume they were of the same inside diameter and yes his lines leaked and had to be welded in two places. I just replaced the lines from the flow divider to the cylinders. Tom. C-GISS ----- Original Message ----- From: willis <mailto:drwer2(at)yahoo.com> robison Sent: Monday, October 27, 2008 7:59 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Tom, did you replace the lines with ones of the same Inside diameter? Did you replace those on both sides of the flow divider (spider), and the fuel servo? wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff. > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > > > 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 29, 2008
Well I do hope that they get some traction with this. Adams shutting down, Eclipse not going anywhere fast, are all bad news for GA. A success story would be a nice change. I, for one, would be very hesitant to load up a 685 with family and launch them with Orendas into the night over the Rockies but their STC with the ag planes do show that it can be a reliable powerplant. Having a couple of successful races under their belt can do wonders. _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Robert S. Randazzo Sent: Wednesday, October 29, 2008 6:18 AM Subject: RE: Commander-List: AC-680 FLP Engine RPM Fluctuation Don- The engine technology was picked up by an outfit called Trace Engines. (www.traceengines.com) They had a stand set up at the races this year at Reno. We stopped by to chat with them- and they brought around a fellow who has purchased the original Orenda certification test airplane. He has a second outfit that he explained was working to STC the 685 with these engines mounted. He claimed that they were "months away from an STC" to hang the V8s on 685s.. That Mr. RPM test bed commander is currently on the ground in Midland TX and according to some sources I checked with- it hasn't been flying in some time.. Like all things in GA- seems to be more heat than energy being generated on that project. ;-) Robert S. Randazzo N414C From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don Barry Home Sent: Tuesday, October 28, 2008 9:00 PM Subject: RE: Commander-List: AC-680 FLP Engine RPM Fluctuation MR. RPM is out of business?? I wonder whatever happened to that AC they were playing around with the water-cooled Orenda engines. Don Houston TX _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tom Fisher Sent: Tuesday, October 28, 2008 10:46 PM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation I do not yet have engine monitors but they are on the wish list. Well he was out of the business and already sold the STC and as far as I was concerned I was happy to receive the lines from him even if they had to be tweaked by an expensive AME who did in fact anneal the welds, good point. Tom. C-GISS ----- Original Message ----- From: willis robison <mailto:drwer2(at)yahoo.com> Sent: Tuesday, October 28, 2008 8:11 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Well, Next time you fly, once youve leaned for cruise, check the EGTs for those cylilnders that had the new lines welded. If they are running within a few degrees of the others, then he did a good job welding. SS lines with anything less than 130 thou. diam are extremely hard to weld without causing an "orifice" at the weldsite. Also, I doubt that he annealed the new weld, which will make the heat affected zone more brittle than the rest. Ask him how he treated the weld. (a smoky acetylene torch for 2 minutes would be sufficient. Bottom line, Mr.RPM should have is axxx chewed for sending you lousy parts. You shouldnt have to do his Acceptance test procedures on your AC. wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 2:17 PM Well, I am that much more informed, thanks for the info. Tom C-GISS ----- Original Message ----- From: willis robison <mailto:drwer2(at)yahoo.com> Sent: Monday, October 27, 2008 11:54 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Thanks Tom. Ive designed a few fuel systems and his symptoms are typical of a flowdivider/lines on the hot side of an engine. (side downstream of an air cooled engine) And are more prevalent with Lines that have a lot of volume. Im unfamiliar with Commanders, but from the looks of the cowl inlets on some of them, it appears the cooling airflow is from bottom to top and then out. If not then there is a big air-dam that deflects cool air to the top of the engine and then down. Either way, cooling appears greatly reduced during climbout unless there are some big cown-vents downstream. As Ive seen it. 1. larger dia. lines have a higher vapor/liquid ratio during operation, and on shut down, cook-off the remaining fuel in the FDV. they are better, however on climbout as there is less pressure losses and heat absorbed. Modern FDV's have a purge valve that dumps fuel back to the inlet of the pump on shutdown. this immediately drops the pressure at the nozzles to zero... 2. smaller lines have shorter fill times, quicker starts but are susceptible to vapor lock because they absorb heat faster. At higher flowrates (rich) the delta-P loss in these lines may result in a higher vapor/liquid rato and thus a poorer spray patter at the nozzle. This is more of an issue on climbout on engines with poor cooling for whatever reason (like closed cowlvents, or just reduced airspeed (airflow)). Modern fuellines in these situations are insulated (just like grandpas truck). 3. for systems with high flowrates (~100 pph or more) the different lengths of fuel lines from the FDV to each nozzle becomes important. there are different pressure losses in each leg. (which makes GAMI's all the more important. ) If you want to save yourself the recurring cost of Gami injectors...get your flow divider valve balanced with your set of nozzles. Just some thoughts. wer former Pratt-Whitney and Ham-STD --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 10:57 AM I got a new set from Mr.RPM himself so I assume they were of the same inside diameter and yes his lines leaked and had to be welded in two places. I just replaced the lines from the flow divider to the cylinders. Tom. C-GISS ----- Original Message ----- From: willis robison <mailto:drwer2(at)yahoo.com> Sent: Monday, October 27, 2008 7:59 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Tom, did you replace the lines with ones of the same Inside diameter? Did you replace those on both sides of the flow divider (spider), and the fuel servo? wer --- On Mon, 10/27/08, Tom Fisher wrote: From: Tom Fisher <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Monday, October 27, 2008, 7:34 AM I had the same surging problem on mine. I replaced all the upper deck lines with new stainless steel lines, the new lines also had to be welded in two places, this resolved the surging problem. Tom C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Ray Mansfeld" <hcourier(at)cox.net> Sent: Sunday, October 26, 2008 6:14 PM Subject: Commander-List: AC-680 FLP Engine RPM Fluctuation > > Am having a problem with the left engine on the 680 FLP I fly (Mr. RPM > Conversion). Takeoff is fine but on climb out the left engine RPM is > unsteady, somewhat like a prop that won't stabilize. Here's some info: > > 1. The problem seems to occur primarily during climb as I bring the > turbos up (I've got manual turbos) > 2. The fluctuation is random as to when it occurs and how much the RPM > fluctuates...probably 10-20 RPM. Sometimes it's noticeable as the > aircraft yaws, sometimes it's not noticeable. > 3. Sometimes it seems that leaning the mixture helps a bit but not > always > 4. I've also noticed that sometimes when the problem has occured on a > flight that on shutdown of the engine after landing, it doesn't want > to > stop running with the mixture pulled all the way to lean/idle-cutoff. > 5. Sometimes I the lean the mixture during the 1500 RPM ground check > and the RPM goes up 50 RPM or so, sometimes it doesn't > 6. Once I level off the problem seems to disappear or be almost > un-noticeable. Although tonight I applied full rich mixture while in > level > flight at 4,500' and I could notice a slight RPM fluctuation if I > paid close > attention. > 7. Fuel pressure is normal and turning the fuel pump on or off has no > affect on the engine > > My thoughts: > > 1. I think the problem is in some fuel metering mechanism in the > carburetor that is unsteady > 2. At one point I thought there might be a leak in the turbo pressure > lines causing a fluctuation in turbo air to the engine > 3. Now, with the engine shut down problem (doesn't happen every time) > I think there is a link between the turbo air (as I bring it up on > climb) > and fuel metering. They are probably interrelated. > > I've received help from many of you out there before. Has anyone had this > type problem occur and if so what might be the problem? > > Thank you, > > Ray Mansfield > N91ES > 850-217-5185 > > > > > 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== http://www.matronics.com/contribution http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 29, 2008
Good Afternoon Robert, I have a friend who was involved as a mechanic with that project. He said it was a beautiful running engine and that everything worked just as they had expected it would. Unfortunately, the interest in converting from a Turbine to a piston was just not there. I asked many of my King Air driver friends what they thought. Everyone of them said there was no way they would ever go back to flying a piston. I got the impression that it was an ego thing. They had no interest at all in the economy or performance gains that might be achieved. They just wanted to arrive in a turbine powered flying machine! Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 10/29/2008 8:22:04 A.M. Central Daylight Time, rsrandazzo(at)precisionmanuals.com writes: That Mr. RPM test bed commander is currently on the ground in Midland TX and according to some sources I checked with- it hasn't been flying in some time.. Like all things in GA- seems to be more heat than energy being generated on that project. ;-) Robert S. Randazzo **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
Well, Old Bob, there is the safety of having much less moving parts in a turbine, too. And the moving parts in a turbine just spin, they don't accellerate, stop, turn around, accellerate, stop, turn around, accellerate thousands of times a minute either. Seems to me they have my vote on that. However, going from an ageing Lycoming or Continental to an Orenda would be a favorite for me. Provided they can last and win some races and endurance rallies to increase their knowledge and capabilities of the engines. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Sent: Wednesday, October 29, 2008 11:38 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Good Afternoon Robert, I have a friend who was involved as a mechanic with that project. He said it was a beautiful running engine and that everything worked just as they had expected it would. Unfortunately, the interest in converting from a Turbine to a piston was just not there. I asked many of my King Air driver friends what they thought. Everyone of them said there was no way they would ever go back to flying a piston. I got the impression that it was an ego thing. They had no interest at all in the economy or performance gains that might be achieved. They just wanted to arrive in a turbine powered flying machine! Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 10/29/2008 8:22:04 A.M. Central Daylight Time, rsrandazzo(at)precisionmanuals.com writes: That Mr. RPM test bed commander is currently on the ground in Midland TX and according to some sources I checked with- it hasn't been flying in some time.. Like all things in GA- seems to be more heat than energy being generated on that project. ;-) Robert S. Randazzo _____ Plan your next getaway with AOL Travel. Check <http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001> out Today's Hot 5 Travel Deals! ________________________________________________________________________________
Date: Oct 29, 2008
While there may be a certain amount of ego associated with transitioning to Turbines, Owners will always go with what is most efficient and affordable .- The exception to this was the market shift from turbo-props to light j ets.- None of the operators wanted to trade the efficiency of thier turbo props for the high initial and recurring costs of operating twin jets.- But, given the choice, people (not just pilots) loved flying in Jets!- Wh o cares if the cost of travel went up 20%.- You no doubt have noticed tha t all the regionals (in the black) are running Props again.- - If you have an engine that has a TBO of 3500 to 5400 hrs, it could be made by Briggs and Stratton and would still find a home.- The pilot is the las t opinion heard. - Personally, I prefer a nice Big-Displacement, Geared, slow turning Piston. -(560Fis my favorite)-why?- Efficiency.- There isn't a law that say s you have to fly full throttle.- Use your propeller performance curve an d POH-to tell you- your best cruise altitude and airspeed, and trim for that.- Use MRCP to get in and out effectively and then rein-in your ego. - There's nothing sexy about straight and level flight. - Hoover was cool....but he didnt pay for the plane or the gas. - wer --- On Wed, 10/29/08, nico css wrote: From: nico css <nico(at)cybersuperstore.com> Subject: RE: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Wednesday, October 29, 2008, 12:33 PM Well, Old Bob, there is the safety of having much less moving parts in a tu rbine, too. And the moving parts in a turbine just spin, they don't accelle rate, stop, turn around, accellerate, stop, turn around, accellerate thousa nds of times a minute either. Seems to me they have my vote on that. Howeve r, going from an ageing Lycoming or Continental to an Orenda would be a fav orite for me. Provided they can last and win some races and endurance ralli es to increase their knowledge and capabilities of the engines. - Nico - - From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Sent: Wednesday, October 29, 2008 11:38 AM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Good Afternoon Robert, - I have a friend who was involved as a mechanic with that project. He said i t was a beautiful running engine and that everything worked just as they ha d expected it would. - Unfortunately, the interest in converting from a Turbine to a piston was ju st not there. - I asked many of my King Air driver friends what they thought. Everyone of t hem said there was no way they would ever go back to flying a piston. I got the impression that it was an ego thing. They had no interest at all in th e economy or performance gains that might be achieved. They just wanted to arrive in a turbine powered flying machine! - Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 - In a message dated 10/29/2008 8:22:04 A.M. Central Daylight Time, rsrandazz o(at)precisionmanuals.com writes: - That Mr. RPM test bed commander is currently on the ground in Midland TX an d according to some sources I checked with- it hasn't- been flying in som e time.. - Like all things in GA- seems to be more heat than energy being generated on that project.- ;-) - Robert S. Randazzo Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deal s! href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c =0A=0A=0A ________________________________________________________________________________
Date: Oct 29, 2008
Good Evening Nico, That is my feeling as well, but it just didn't seem to appeal to as many folks as the developer had hoped. The big market was expected to be older Turbine Commanders and King Airs. Those folks wanted nothing to do with it even though the numbers worked out quite favorably. Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 10/29/2008 2:37:09 P.M. Central Daylight Time, nico(at)cybersuperstore.com writes: Well, Old Bob, there is the safety of having much less moving parts in a turbine, too. And the moving parts in a turbine just spin, they don't accellerate, stop, turn around, accellerate, stop, turn around, accellerate thousands of times a minute either. Seems to me they have my vote on that. However, going from an ageing Lycoming or Continental to an Orenda would be a favorite for me. Provided they can last and win some races and endurance rallies to increase their knowledge and capabilities of the engines. Nico **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
Good Afternoon wer, It wasn't the paid pilots that made the observations that I noted, it was the aircraft owners. I agree that somebody hauling freight or other non ego possessing cargo will choose based on economics, but most of the bosses still prefer turbines even when the numbers favor the Chevy knock off! Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 10/29/2008 3:15:45 P.M. Central Daylight Time, drwer2(at)yahoo.com writes: While there may be a certain amount of ego associated with transitioning to Turbines, Owners will always go with what is most efficient and affordable. **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
BobsV35B(at)aol.com wrote: > Those folks wanted nothing to do with it even though the numbers > worked out quite favorably. Wow, I would have never thought I'd disagree with Old Bob on anything, but I have a little different perspective on this one. I suspect that if you took a poll of Turbine Commander and King Air owners that darn few of them have ever heard of the Orenda project, let alone evaluated it as an option. Since (to the best of my knowledge), no STC/certification was ever achieved for those airplanes ,no significant operating history exists, and no advertising was ever done in places where corp owners would have seen it, I don't think the product ever mad it out of the shadows. I also don't think that the engine would have ever gained much momentum without some significant operational experience. Corporate owners don't seem to be the type to pounce on a major unproven powerplant option to me. Nico's point that a few Reno win's would help put them on the map is valid, but they'd need a good test fleet building hours to make it attractive to the target market. I remember hearing that there were some significant problems with the Commander test vehicle, but don't remember the specifics. Anyone else know more than I do? cheers, Chris ________________________________________________________________________________
Date: Oct 29, 2008
EPI, Inc. designed and developed the engine mounting and structural integri ty testing had a lot to do with the demise of the project.- Here is a lin k to thier comments on the engine, etc. - http://www.epi-eng.com/aircraft_engine_conversions/additional_weight_consid erations.htm#examples - willis Robison --- On Wed, 10/29/08, Chris wrote: From: Chris <cschuerm(at)cox.net> Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Wednesday, October 29, 2008, 3:54 PM BobsV35B(at)aol.com wrote: > Those folks wanted nothing to do with it even though the numbers > worked out quite favorably. Wow, I would have never thought I'd disagree with Old Bob on anything, but I have a little different perspective on this one. I suspect that if you took a poll of Turbine Commander and King Air owners that darn few of them have ever heard of the Orenda project, let alone evaluated it as an option. Since (to the best of my knowledge), no STC/certification was ever achieved for those airplanes ,no significant operating history exists, and no advertising was ever done in places where corp owners would have seen it, I don't think the product ever mad it out of the shadows. I also don't think that the engine would have ever gained much momentum without some significant operational experience. Corporate owners don't seem to be the type to pounce on a major unproven powerplant option to me. Nico's point that a few Reno win's would help put them on the map is valid, but they'd need a good test fleet building hours to make it attractive to the target market. I remember hearing that there were some significant problems with the Commander test vehicle, but don't remember the specifics. Anyone else know more than I do? cheers, Chris =0A=0A=0A ________________________________________________________________________________
Date: Oct 29, 2008
That's an excellent point. I spoke to one of my business friend's who happens to be a Texas state senator. Apparently the folks at Trace have some connections with the state gov't here. They (Texas) must have a "herd" of King Airs - there's a study in progress looking at helping out on the STC approval and doing conversions on the state planes. They said the numbers he's seen on this are "compelling", and they like spending their $$$ within the state. How knows? Maybe this will end up going somewhere? Oddly enough, he also said these engines are considerable more quiet than an air-cooled or a turbine. Any truth to that? Don Houston ,TX _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Sent: Wednesday, October 29, 2008 5:48 PM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Good Afternoon wer, It wasn't the paid pilots that made the observations that I noted, it was the aircraft owners. I agree that somebody hauling freight or other non ego possessing cargo will choose based on economics, but most of the bosses still prefer turbines even when the numbers favor the Chevy knock off! Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 10/29/2008 3:15:45 P.M. Central Daylight Time, drwer2(at)yahoo.com writes: While there may be a certain amount of ego associated with transitioning to Turbines, Owners will always go with what is most efficient and affordable. _____ Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Recip vs. turbine
"While there may be a certain amount of ego associated with transitioning to Turbines, " I concede the fuel efficiency to props, be they recip or turbo, but if I am ever in a life threating emergency, give me a high bypass turbojet. They just hang together and produce power, lots and lots of power, push it to the stops and keep it there, it may redline and need changed on the ground but it will get you back to the hanger for the engine change. Seems like I remember being told something like, 'the last 10% of the throttle movement produces 90% of the power', do know, in reverse the difference between 80% and 90% is very amazing on a snow covered short runway, about a thousand feet on a DC-9, at max gross. I have a friend who was on an A-300 with GE engines when they encountered a very severe emergency, involving a 45 degree pitch-up on a go around, airspeed dropped well below 100 knots. The engines were firewalled and all indicator were pegged beyond the red line. Needless to say they survived, but computer readout showed the engines produced almost 100,000 lbs thrust, double the rating. Don't know why the fuel controls let them get this high, maybe the low airspeed, not sure. The engines were borascoped and not even changed. Try that with a recip engine! Personally, I'm glad I was not on the flight, but I have several thousand hours in turbines and have never lost an engine or had an emergency, a few minor problems yes, but never an emergency, more than I can say with recips. A certain Turbo compounded R-3350 comes to mind. I baby my engines as I pay the bills, but also because I am on board, but I have always felt, turbines especially turbojets will take much more abuse, and like the old Timex commercial, 'it keeps on ticking'. Don ________________________________________________________________________________
Date: Oct 29, 2008
Well, the video of the test Commander certainly sounds as if it is a quiet ship. Didn't one of the guys on the list fly the test model for the TV spot? Bill Lieff? I cannot recall exactly. _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don Barry Home Sent: Wednesday, October 29, 2008 4:10 PM Subject: RE: Commander-List: AC-680 FLP Engine RPM Fluctuation That's an excellent point. I spoke to one of my business friend's who happens to be a Texas state senator. Apparently the folks at Trace have some connections with the state gov't here. They (Texas) must have a "herd" of King Airs - there's a study in progress looking at helping out on the STC approval and doing conversions on the state planes. They said the numbers he's seen on this are "compelling", and they like spending their $$$ within the state. How knows? Maybe this will end up going somewhere? Oddly enough, he also said these engines are considerable more quiet than an air-cooled or a turbine. Any truth to that? Don Houston ,TX _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Sent: Wednesday, October 29, 2008 5:48 PM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Good Afternoon wer, It wasn't the paid pilots that made the observations that I noted, it was the aircraft owners. I agree that somebody hauling freight or other non ego possessing cargo will choose based on economics, but most of the bosses still prefer turbines even when the numbers favor the Chevy knock off! Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 10/29/2008 3:15:45 P.M. Central Daylight Time, drwer2(at)yahoo.com writes: While there may be a certain amount of ego associated with transitioning to Turbines, Owners will always go with what is most efficient and affordable. _____ Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 29, 2008
Exactly my sentiments. It's just a shaft with blades on it. _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don Sent: Wednesday, October 29, 2008 4:21 PM Subject: Commander-List: Recip vs. turbine "While there may be a certain amount of ego associated with transitioning to Turbines, " I concede the fuel efficiency to props, be they recip or turbo, but if I am ever in a life threating emergency, give me a high bypass turbojet. They just hang together and produce power, lots and lots of power, push it to the stops and keep it there, it may redline and need changed on the ground but it will get you back to the hanger for the engine change. Seems like I remember being told something like, 'the last 10% of the throttle movement produces 90% of the power', do know, in reverse the difference between 80% and 90% is very amazing on a snow covered short runway, about a thousand feet on a DC-9, at max gross. I have a friend who was on an A-300 with GE engines when they encountered a very severe emergency, involving a 45 degree pitch-up on a go around, airspeed dropped well below 100 knots. The engines were firewalled and all indicator were pegged beyond the red line. Needless to say they survived, but computer readout showed the engines produced almost 100,000 lbs thrust, double the rating. Don't know why the fuel controls let them get this high, maybe the low airspeed, not sure. The engines were borascoped and not even changed. Try that with a recip engine! Personally, I'm glad I was not on the flight, but I have several thousand hours in turbines and have never lost an engine or had an emergency, a few minor problems yes, but never an emergency, more than I can say with recips. A certain Turbo compounded R-3350 comes to mind. I baby my engines as I pay the bills, but also because I am on board, but I have always felt, turbines especially turbojets will take much more abuse, and like the old Timex commercial, 'it keeps on ticking'. Don ________________________________________________________________________________
Date: Oct 29, 2008
On Oct 29, 2008, at 7:09 PM, Don Barry Home wrote: > Oddly enough, he also said these engines are considerable more > quiet than an air-cooled or a turbine. Any truth to that? > if you go to MrRPM's old site: http://www.mrrpm.com/ and click "here" to see & hear the 1200 hp Commander Flight, the video still works! granted the commentator and music and hoop la spoils it but you can still notice how quiet it is, they taxi and also have a clip of a pass over. but if that commander is not flying anymore... ________________________________________________________________________________
Date: Oct 29, 2008
Good Evening Chris, Well, I do not find that I am disagreeing with you! What I stated was that when I asked my King Air and Turbine Commander owner friends what they thought of the Orenda conversion, the universal answer was that there was no way they would trade their turbines for a hopped up Chevy design even if it did perform better and had lower fuel burn. I did not find a single owner who was interested in getting the conversion. I am not sure if it would have met it's claims, but even if it did, my impression was that the Turbine owners I knew would not buy it! Admittedly, mine was a small and probably not significant sample, but I was surprised at the resistance I found. Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 10/29/2008 5:57:43 P.M. Central Daylight Time, cschuerm(at)cox.net writes: Wow, I would have never thought I'd disagree with Old Bob on anything, but I have a little different perspective on this one. I suspect that if you took a poll of Turbine Commander and King Air owners that darn few of them have ever heard of the Orenda project, let alone evaluated it as an option. **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
Modern turbine engines on FADECs, set to-emergency power, the control loo p eliminates all but the EGT probes(TiT).- So the engines would produce a s much power as the turbine section could handle, they would be VERY HOT in deed.- No Inlet control, no torque control....nada.- As the Turbine inl et temp maxed out, then the control would ramp back the fuel servos.- In the meantime, you would get a ridiculous amount of power. - At least thats how its done on PWC and GE engines.- I dont know about RR or BMW but Id guess the control laws are similar. - wer --- On Wed, 10/29/08, nico css wrote: From: nico css <nico(at)cybersuperstore.com> Subject: RE: Commander-List: Recip vs. turbine Date: Wednesday, October 29, 2008, 4:51 PM Exactly my sentiments. It's just a shaft with blades on it. From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of Don Sent: Wednesday, October 29, 2008 4:21 PM Subject: Commander-List: Recip vs. turbine - - "While there may be a certain amount of ego associated with transitioning t o Turbines, " - I concede the fuel efficiency to props, be they recip or turbo, but if I am ever in a life threating emergency, give me a high bypass turbojet.- The y just hang together and produce power, lots and lots of power, push it to the stops and keep it there, it may redline and need changed on the ground but it will get you back to the hanger for the engine change.- Seems like I remember being told something like, 'the last 10% of the throttle moveme nt produces 90% of the power', do know, in reverse the difference-between 80% and 90% is very amazing on a snow covered short runway, about a thousa nd feet on a DC-9, at max gross. - I have a friend who was on an A-300 with GE engines when they encountered a very severe emergency, involving a 45 degree pitch-up on a go around,-ai rspeed dropped well below 100 knots.- The engines were firewalled and all indicator were pegged-beyond the red line.- Needless to say they survi ved, but computer readout showed the engines produced almost 100,000 lbs th rust, double the rating.- Don't know why the fuel controls let them get t his high, maybe the low airspeed, not sure.- The engines were borascoped and not even changed.- Try that with a recip engine! - Personally, I'm glad I was not on the flight, but I have-several thousand hours in turbines and have never lost an engine or had an emergency, a few minor problems yes, but never an emergency, more than I can say with recip s.- A certain Turbo compounded-R-3350 comes to mind. - I baby my engines as I pay the bills, but also because I am on board, but I have always felt, turbines especially turbojets will take much more abuse, and like the old Timex commercial, 'it keeps on ticking'. - Don - - - href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c =0A=0A=0A ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Subject: Wing lost in flight
Date: Oct 29, 2008
This is an amazing YOU TUBE video. Notlandung: Der beste Pilot ever! | chilloutzone.de - free games and free fun Tom C-GISS ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Wednesday, October 29, 2008 6:56 PM Subject: RE: Commander-List: Recip vs. turbine Modern turbine engines on FADECs, set to emergency power, the control loop eliminates all but the EGT probes(TiT). So the engines would produce as much power as the turbine section could handle, they would be VERY HOT indeed. No Inlet control, no torque control....nada. As the Turbine inlet temp maxed out, then the control would ramp back the fuel servos. In the meantime, you would get a ridiculous amount of power. At least thats how its done on PWC and GE engines. I dont know about RR or BMW but Id guess the control laws are similar. wer --- On Wed, 10/29/08, nico css wrote: From: nico css <nico(at)cybersuperstore.com> Subject: RE: Commander-List: Recip vs. turbine To: commander-list(at)matronics.com Date: Wednesday, October 29, 2008, 4:51 PM Exactly my sentiments. It's just a shaft with blades on it. ---------------------------------------------------------------------- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don Sent: Wednesday, October 29, 2008 4:21 PM To: commander-list(at)matronics.com Subject: Commander-List: Recip vs. turbine "While there may be a certain amount of ego associated with transitioning to Turbines, " I concede the fuel efficiency to props, be they recip or turbo, but if I am ever in a life threating emergency, give me a high bypass turbojet. They just hang together and produce power, lots and lots of power, push it to the stops and keep it there, it may redline and need changed on the ground but it will get you back to the hanger for the engine change. Seems like I remember being told something like, 'the last 10% of the throttle movement produces 90% of the power', do know, in reverse the difference between 80% and 90% is very amazing on a snow covered short runway, about a thousand feet on a DC-9, at max gross. I have a friend who was on an A-300 with GE engines when they encountered a very severe emergency, involving a 45 degree pitch-up on a go around, airspeed dropped well below 100 knots. The engines were firewalled and all indicator were pegged beyond the red line. Needless to say they survived, but computer readout showed the engines produced almost 100,000 lbs thrust, double the rating. Don't know why the fuel controls let them get this high, maybe the low airspeed, not sure. The engines were borascoped and not even changed. Try that with a recip engine! Personally, I'm glad I was not on the flight, but I have several thousand hours in turbines and have never lost an engine or had an emergency, a few minor problems yes, but never an emergency, more than I can say with recips. A certain Turbo compounded R-3350 comes to mind. I baby my engines as I pay the bills, but also because I am on board, but I have always felt, turbines especially turbojets will take much more abuse, and like the old Timex commercial, 'it keeps on ticking'. Don href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Oct 30, 2008
That may be true, but the ORENDA project, as conceived by Dick Macoon, was not intended to compete with turbines.? They were replacements for the recip fleet.? The test airplane was a 685, piston Commander, not a turbo Commander..? They were also certified on the single otter, replacing the geared 1340.? jb I am not sure if it would have met it's claims, but even if it did, my impression was that the Turbine owners I knew would not buy it! -----Original Message----- From: BobsV35B(at)aol.com Sent: Wed, 29 Oct 2008 5:11 pm Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Good Evening Chris, ? Well, I do not find that I am disagreeing with you! ? What I stated was that when I asked my King Air and Turbine Commander owner friends what they thought of the Orenda conversion, the universal answer was that there was no way they would trade their turbines for a hopped up Chevy design even if it did perform better and had lower fuel burn. I did not find a single owner who was interested in getting the conversion. I am not sure if it would have met it's claims, but even if it did, my impression was that the Turbine owners I knew would not buy it! ? Admittedly, mine was a small and probably not significant sample, but I was surprised at the resistance I found. ? Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 ? In a message dated 10/29/2008 5:57:43 P.M. Central Daylight Time, cschuerm(at)cox.net writes: Wow, I would have never thought I'd disagree with Old Bob on anything, but I have a little different perspective on this one.? I suspect that if you took a poll of Turbine Commander and King Air owners that darn few of them have ever heard of the Orenda project, let alone evaluated it as an option. Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! ________________________________________________________________________________
Date: Oct 29, 2008
I saw a model plane do that. That took guts and a clear head. I bet he needed new underwear after that. Great stuff, Tom. _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tom Fisher Sent: Wednesday, October 29, 2008 9:03 PM Subject: Commander-List: Wing lost in flight This is an amazing YOU TUBE video. <http://www.chilloutzone.de/files/08102703.html> Notlandung: Der beste Pilot ever! | chilloutzone.de - free games and free fun Tom C-GISS ----- Original Message ----- From: willis robison <mailto:drwer2(at)yahoo.com> Sent: Wednesday, October 29, 2008 6:56 PM Subject: RE: Commander-List: Recip vs. turbine Modern turbine engines on FADECs, set to emergency power, the control loop eliminates all but the EGT probes(TiT). So the engines would produce as much power as the turbine section could handle, they would be VERY HOT indeed. No Inlet control, no torque control....nada. As the Turbine inlet temp maxed out, then the control would ramp back the fuel servos. In the meantime, you would get a ridiculous amount of power. At least thats how its done on PWC and GE engines. I dont know about RR or BMW but Id guess the control laws are similar. wer --- On Wed, 10/29/08, nico css wrote: From: nico css <nico(at)cybersuperstore.com> Subject: RE: Commander-List: Recip vs. turbine Date: Wednesday, October 29, 2008, 4:51 PM Exactly my sentiments. It's just a shaft with blades on it. _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don Sent: Wednesday, October 29, 2008 4:21 PM Subject: Commander-List: Recip vs. turbine "While there may be a certain amount of ego associated with transitioning to Turbines, " I concede the fuel efficiency to props, be they recip or turbo, but if I am ever in a life threating emergency, give me a high bypass turbojet. They just hang together and produce power, lots and lots of power, push it to the stops and keep it there, it may redline and need changed on the ground but it will get you back to the hanger for the engine change. Seems like I remember being told something like, 'the last 10% of the throttle movement produces 90% of the power', do know, in reverse the difference between 80% and 90% is very amazing on a snow covered short runway, about a thousand feet on a DC-9, at max gross. I have a friend who was on an A-300 with GE engines when they encountered a very severe emergency, involving a 45 degree pitch-up on a go around, airspeed dropped well below 100 knots. The engines were firewalled and all indicator were pegged beyond the red line. Needless to say they survived, but computer readout showed the engines produced almost 100,000 lbs thrust, double the rating. Don't know why the fuel controls let them get this high, maybe the low airspeed, not sure. The engines were borascoped and not even changed. Try that with a recip engine! Personally, I'm glad I was not on the flight, but I have several thousand hours in turbines and have never lost an engine or had an emergency, a few minor problems yes, but never an emergency, more than I can say with recips. A certain Turbo compounded R-3350 comes to mind. I baby my engines as I pay the bills, but also because I am on board, but I have always felt, turbines especially turbojets will take much more abuse, and like the old Timex commercial, 'it keeps on ticking'. Don href="http://www.matronics.com/Navigator?Commander-List">http://www.matronic s.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c 3D=========================3 D=================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matr onics.com/Navigator?Commander-List 3D=========================3 D=================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=========================3 D=================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/co ntribution 3D=========================3 D=================== ________________________________________________________________________________
Subject: Orenda Engine Market
Date: Oct 30, 2008
That may be true, but the ORENDA project, as conceived by Dick Macoon, was not intended to compete with turbines.? They were replacements for the recip fleet.? The test airplane was a 685, piston Commander, not a turbo Commander..? They were also certified on the single otter, replacing the geared 1340.? jb I am not sure if it would have met it's claims, but even if it did, my impression was that the Turbine owners I knew would not buy it! Yes, but ... While Mr. RPM was making headway with the Commander 685 installation, the major launch customer was Stevens Beechcraft who was going to re-engine the KingAir 90 fleet.??? The KingAir installation suffered oil foaming and Mr. RPM was able to solve the problem on his Commander before the team working the KingAir test article did.? That was just one of the hurdles towards STC'ing the Orenda as an engine replacement. So yes, the Orenda was to be a turbine replacement.? Mr. RPM and I discussed the improvements it would bring the Turbo Commander, though neither of us thought anyone would really do that, the economics of overhaul cost was very attractive. Judging from the opinions / observations on this topic, Stevens Beechcraft, who projected at least 40 shipsets of engines, couldn't sell the idea in enough numbers to make it work. Was it the delay in certification?? Was it the Ratchet Theory of Aviation (can't go backwards, only forwards)?? Was it turbine ego??? I have to put in with Mr. RPM in his statements that a turbine engine loses power the minute it leaves Sea Level ISA (or its flat rating) where a turbo normalized or supercharged piston engine will maintain Sea Level power well into the 'Teens or Twenties. providing far more power aloft. However, there's something nice about the simplicity of pinwheels spinning on a stick, isn't there? I was hanging around Mr. RPM's test facility in Marina and Salinas, California in the late 70s /early 80s and know that the then Thunder Engine (precursor to the Orenda) flew on a Turbo Commander, had interest from Israel as an engine for tanks and U.S. Customs for interceptor boats, so presumably that market still exists for the Orenda -- but there's one major element we're not discussing. AvGas in a boutique fuel and Jet-A, diesel or rotgut kerosene is global.?? Yes, the Orenda could be set up for Jet-A but that would have been another long process. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Oct 30, 2008
Subject: Re: Wing lost in flight
Um, you are all aware that that was a CGI video, and not real, right? The RC model pilot did a fantastic job though, Nico...I've seen that video and it was great! nico css wrote: > I saw a model plane do that. That took guts and a clear head. I bet he > needed new underwear after that. > Great stuff, Tom. > > > ------------------------------------------------------------------------ > *From:* owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] *On Behalf Of *Tom > Fisher > *Sent:* Wednesday, October 29, 2008 9:03 PM > *To:* commander-list(at)matronics.com > *Subject:* Commander-List: Wing lost in flight > > This is an amazing YOU TUBE video. > > Notlandung: Der beste Pilot ever! | chilloutzone.de - free games and > free fun <http://www.chilloutzone.de/files/08102703.html> > > Tom > > C-GISS > > ----- Original Message ----- > *From:* willis robison > *To:* commander-list(at)matronics.com > > *Sent:* Wednesday, October 29, 2008 6:56 PM > *Subject:* RE: Commander-List: Recip vs. turbine > > Modern turbine engines on FADECs, set to emergency power, the > control loop eliminates all but the EGT probes(TiT). So the > engines would produce as much power as the turbine section could > handle, they would be VERY HOT indeed. No Inlet control, no > torque control....nada. As the Turbine inlet temp maxed out, then > the control would ramp back the fuel servos. In the meantime, you > would get a ridiculous amount of power. > > At least thats how its done on PWC and GE engines. I dont know > about RR or BMW but Id guess the control laws are similar. > > wer > > --- On *Wed, 10/29/08, nico css //* wrote: > > From: nico css <nico(at)cybersuperstore.com> > Subject: RE: Commander-List: Recip vs. turbine > To: commander-list(at)matronics.com > Date: Wednesday, October 29, 2008, 4:51 PM > > Exactly my sentiments. It's just a shaft with blades on it. > > ------------------------------------------------------------------------ > *From:* owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] *On Behalf > Of *Don > *Sent:* Wednesday, October 29, 2008 4:21 PM > *To:* commander-list(at)matronics.com > *Subject:* Commander-List: Recip vs. turbine > > > > > > "While there may be a certain amount of ego associated > with transitioning to Turbines, " > > I concede the fuel efficiency to props, be they recip or > turbo, but if I am ever in a life threating emergency, > give me a high bypass turbojet. They just hang together > and produce power, lots and lots of power, push it to the > stops and keep it there, it may redline and need changed > on the ground but it will get you back to the hanger for > the engine change. Seems like I remember being told > something like, 'the last 10% of the throttle movement > produces 90% of the power', do know, in reverse the > difference between 80% and 90% is very amazing on a snow > covered short runway, about a thousand feet on a DC-9, at > max gross. > > I have a friend who was on an A-300 with GE engines when > they encountered a very severe emergency, involving a 45 > degree pitch-up on a go around, airspeed dropped well > below 100 knots. The engines were firewalled and all > indicator were pegged beyond the red line. Needless to > say they survived, but computer readout showed the engines > produced almost 100,000 lbs thrust, double the rating. > Don't know why the fuel controls let them get this high, > maybe the low airspeed, not sure. The engines were > borascoped and not even changed. Try that with a recip > engine! > > Personally, I'm glad I was not on the flight, but I > have several thousand hours in turbines and have never > lost an engine or had an emergency, a few minor problems > yes, but never an emergency, more than I can say with > recips. A certain Turbo compounded R-3350 comes to mind. > > I baby my engines as I pay the bills, but also because I > am on board, but I have always felt, turbines especially > turbojets will take much more abuse, and like the old > Timex commercial, 'it keeps on ticking'. > > Don > > > > > * > * > > * > > > * > > > > * > > href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * > > > * > > 3D============================================ > href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matronics.com/Navigator?Commander-List > 3D============================================ > href='3D"http://forums.matronics.com"'>http://forums.matronics.com > 3D============================================ > href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution > 3D============================================ > > * > > * > > href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > * > > > * > > > __________ Information from ESET NOD32 Antivirus, version of virus > signature database 3568 (20081030) __________ > > The message was checked by ESET NOD32 Antivirus. > ________________________________________________________________________________
Date: Oct 30, 2008
Subject: Re: auto engines. Was: AC-680 FLP Engine RPM Fluctuation
Good Morning jb, I have no doubt that what you say is true, but it was presented to the Beechcraft world as a replacement engine for the King Air. A couple of my friends have (now 'had'!) Turbo Commanders and it was also discussed in their world. When it was discussed within those groups, the interest was as I reported. No doubt other groups felt differently. Since I am certain I will never be able to afford a King Air, Turbo Commander, or even a non turboed Commander, the whole idea was and is to me, merely an intellectual curiosity. Like most wannabes, I am always interested in new ideas that may provide better motive power than is now available. After watching the development of automobile engine powered aircraft for many years, I have come to the point where I still hope all the new thinkers well, but I fear there is no free lunch. Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 10/30/2008 12:03:57 A.M. Central Daylight Time, yourtcfg(at)aol.com writes: That may be true, but the ORENDA project, as conceived by Dick Macoon, was not intended to compete with turbines. They were replacements for the recip fleet. The test airplane was a 685, piston Commander, not a turbo Commander.. They were also certified on the single otter, replacing the geared 1340. jb **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 30, 2008
BobsV35B(at)aol.com wrote: > After watching the development of automobile engine powered aircraft > for many years, I have come to the point where I still hope all the > new thinkers well, but I fear there is no free lunch. Yup.... exactly. I think the effort made by Honda a few years back was very telling of the realities of aircraft engines. They announced that they were going to undertake a well funded "clean slate" engine design. No preconceptions on any aspect - everything would be evaluated. So, after years of R&D and millions of dollars, what did some of the worlds best engine engineers come up with??? A large bore, direct drive, 360 cid 4 cylinder air cooled opposed engine that made around 180hp. Basicly, a clone of the Lycoming IO-360 but prettier. Says a lot, eh? chris ________________________________________________________________________________
From: "Bill Hamilton" <wjrhamilton(at)optusnet.com.au>
Subject: AC-680 FLP Engine RPM Fluctuation
Date: Oct 30, 2008
Folks, I have had some involvement (automotive) that had a bearing on the problems of the Orenda, and some of the other efforts to "aerofy" automotive engines. Although of different engineering origin, the recent technical (not financial/management) problems of Thielert engines have been related to the auto origins of the engine. There are some interesting and virtually insoluble problems of physics with the traditional firing order of a 90 degree V-8, but if you go to a "flat plane" crank (as per competition V-8's) you get vibration that is uncomfortable in an auto or an aircraft. It's all a while ago, but a fading memory tells me that it is No.5 big end that has a life measured in seconds, with any interruption of lubrication, in the traditional crank/firing order, if we could do an Orenda with a flat plane crank (as I believe might have been tried) and produce a solution to the vibration, so that you didn't destroy the prop. or the surrounding aeroplane, you would have a goer. Again trusting to memory, there was a problem with moving cylinder sleeves in the Orenda, the cost of re-design to eliminate this problem was probably at least one nail in the coffin. Remember, "rules" for Ag. Engines are not quite the same as for a "standard" cat. C.of A aeroplane. Cheers, Bill Hamilton AC-500A ZK-DCF From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Thursday, October 30, 2008 4:00 PM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation That may be true, but the ORENDA project, as conceived by Dick Macoon, was not intended to compete with turbines. They were replacements for the recip fleet. The test airplane was a 685, piston Commander, not a turbo Commander.. They were also certified on the single otter, replacing the geared 1340. jb I am not sure if it would have met it's claims, but even if it did, my impression was that the Turbine owners I knew would not buy it! -----Original Message----- From: BobsV35B(at)aol.com Sent: Wed, 29 Oct 2008 5:11 pm Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Good Evening Chris, Well, I do not find that I am disagreeing with you! What I stated was that when I asked my King Air and Turbine Commander owner friends what they thought of the Orenda conversion, the universal answer was that there was no way they would trade their turbines for a hopped up Chevy design even if it did perform better and had lower fuel burn. I did not find a single owner who was interested in getting the conversion. I am not sure if it would have met it's claims, but even if it did, my impression was that the Turbine owners I knew would not buy it! Admittedly, mine was a small and probably not significant sample, but I was surprised at the resistance I found. Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 10/29/2008 5:57:43 P.M. Central Daylight Time, cschuerm(at)cox.net writes: Wow, I would have never thought I'd disagree with Old Bob on anything, but I have a little different perspective on this one. I suspect that if you took a poll of Turbine Commander and King Air owners that darn few of them have ever heard of the Orenda project, let alone evaluated it as an option. _____ Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! <http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001> _____ McCain or Obama? Stay up to date on the latest from the campaign trail with AOL News <http://news.aol.com/elections?ncid=emlcntusnews00000001> . ________________________________________________________________________________
Date: Oct 30, 2008
Well there have been some sucesses,- Honda and Porsche both produced moto rs that worked well, and were more efficient than current aero motors. they were MUCH more complicated owing to DOHV, variable valve and ignition timi ng as well as the require d reduction unit.- here is an overhead of the P orsche PFM (porsche flugmoter) http://www.mooneyland.com/mooneyposter.jpg - The honda was similar and they both had Specific Fuel consumptions below 0. 4 pph/hp.- I think honda gave up on the piston division to commit to thie r new Honda-Jet. - The real-reason you dont have Honda or Porsche emblazoned on the side of your nacell is that Neither- could make a business model based on 1000 en gines a year. Even if you charged-$40k each....just no money in it for co mpanies-with stockholders,- especially the technically competent ones l ike H or P.-- - Would you fly in a Dodge or Ford (or chevy) powered Commander?.....it would take a SEA-change in personality and capability. - Oh, and my last 2p on design via racing engines.....You cant design a clean slate engine for competition.- You start with a Basic design engine and make incremental modifications to achieve the design goal.- Thats why Por sche was chosen...they already had an air-cooled, multivalve, semi-PADEC (p artial-authority) engine-and only needed a PRU for-the propeller. - As memory serves, Nissan even produced 2000 hp race engines for the Pond te am, and were somewhat successful.--They had cooling problems tho and bu rned up thier only prototypes at Reno.- - - wer- --- On Thu, 10/30/08, Bill Hamilton wrote: From: Bill Hamilton <wjrhamilton(at)optusnet.com.au> Subject: RE: Commander-List: AC-680 FLP Engine RPM Fluctuation Date: Thursday, October 30, 2008, 5:46 AM Folks, I have had some involvement (automotive) that had a bearing on the problems of the Orenda, and some of the other efforts to =93aerofy=94 automotive en gines. Although of different engineering origin, the recent technical (not financial/management) problems of Thielert engines have been related to the auto origins of the engine. - There are some interesting and virtually insoluble problems of physics with the traditional firing order of a 90 degree V-8, but if you go to a =93fla t plane=94 crank (as per competition V-8=92s) you get vibration that is unc omfortable in an auto or an aircraft. - It=92s all a while ago, but a fading memory tells me that it is No.5 big en d that has a life measured in seconds, with any interruption of lubrication , in the traditional crank/firing order, if we could do an Orenda with a fl at plane crank (as I believe might have been tried) and produce a solution to the vibration, so that you didn=92t destroy the prop. or the surrounding aeroplane, you would have a goer. - Again trusting to memory, there was a problem with moving cylinder sleeves in the Orenda, the cost of re-design to eliminate this problem was probably at least one nail in the coffin. Remember, =93rules=94 for Ag. Engines are not quite the same as for a =93standard=94 cat. C.of A aeroplane. - Cheers, Bill Hamilton AC-500A ZK-DCF - From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Thursday, October 30, 2008 4:00 PM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation - That may be true, but the ORENDA project, as conceived by Dick Macoon, was not intended to compete with turbines.- They were replacements for the re cip fleet.- The test airplane was a 685, piston Commander, not a turbo Co mmander..- They were also certified on the single otter, replacing the ge ared 1340.- jb I am not sure if it would have met it's claims, but even if it did, my impr ession was that the Turbine owners I knew would not buy it! -----Original Message----- From: BobsV35B(at)aol.com Sent: Wed, 29 Oct 2008 5:11 pm Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation Good Evening Chris, - Well, I do not find that I am disagreeing with you! - What I stated was that when I asked my King Air and Turbine Commander owner friends what they thought of the Orenda conversion, the universal answer w as that there was no way they would trade their turbines for a hopped up Ch evy design even if it did perform better and had lower fuel burn. I did not find a single owner who was interested in getting the conversion. I am not sure if it would have met it's claims, but even if it did, my impression w as that the Turbine owners I knew would not buy it! - Admittedly, mine was a small and probably not significant sample, but I was surprised at the resistance I found. - Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 - In a message dated 10/29/2008 5:57:43 P.M. Central Daylight Time, cschuerm@ cox.net writes: Wow, I would have never thought I'd disagree with Old Bob on anything, but I have a little different perspective on this one.- I suspect that if you took a poll of Turbine Commander and King Air owners that darn few of them have ever heard of the Orenda project, let alone evaluated it as an option. Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deal s! - - - - McCain or Obama? Stay up to date on the latest from the campaign trail with AOL News. - -http://www.matronics.com/Navigator?Commander-Listhttp:// forums.matronics.comhttp://www.matronics.com/contribution - =0A=0A=0A ________________________________________________________________________________
Date: Oct 30, 2008
Subject:
You young kids have all missed the boat, round engines are the best. Jim Addington Subject: Engines - Rotary vs. Turbine Between A Radial Engine And A Jet Engine Round engines are commonly known as Radial engines. The piston Jugs are placed in a circle. Hence "Round" engines. Turbine engines are known as Jet engines. We gotta get rid of those turbines, they're ruining aviation and our hearing. A turbine is too simple minded, it has no mystery. The air travels through it in a straight line and doesn't pick up any of the pungent fragrance of engine oil or pilot sweat. Anybody can start a turbine. You just need to move a switch from "OFF" to "START" and then remember to move it back to "ON" after a while. My PC is harder to start. Cranking a round engine requires skill, finesse and style. You have to seduce it into starting. It's like waking up a mistress On some planes, the pilots aren't even allowed to do it. Turbines start by whining for a while, then give a lady-like poof and start whining a little louder. Round engines give a satisfying rattle-rattle, click-click, BANG, more rattles, another BANG, a big macho FART or two, more clicks, a lot more smoke and finally a serious low pitched roar. We like that. It's a GUY thing. When you start a round engine, your mind is engaged and you can concentrate on the flight ahead. Starting turbine is like flicking on aceiling fan: Useful, but, hardly exciting. When you have started his round engine successfully your Crew Chief looks up at you like he'd let you kiss his girl, too! Turbines don't break or catch fire often enough, which leads to aircrew boredom, complacency and inattention. A round engine at speed looks and sounds like it's going to blow any minute. This helps concentrate the mind. Turbines don't have enough control levers or gauges to keep a pilot's attention. There's nothing to fiddle with during long flights. Turbines smell like a Boy Scout camp full of Coleman Lamps. Round engines smell like God intended machines to smell. Pass this on to an old WWII guy (or his son, or anyone who ever flew them) in remembrance of the "Greatest Generation". ________________________________________________________________________________
Date: Oct 30, 2008
Subject: Re: mander-List:
Well some of these 'kids' say....Right-on-brother! - (funny...I havent felt like a kid since '69) Maybe thats why I like this Po st...feel like a kid again. - wer --- On Thu, 10/30/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: Commander-List: Date: Thursday, October 30, 2008, 7:29 AM You young kids have all missed the boat, round engines are the best. Jim Addington - - Subject: Engines - Rotary vs. Turbine - Between A Radial Engine And A Jet Engine Round engines are commonly known as Radial engines. The piston Jugs are placed in a circle. Hence "Round" engines. Turbine engines are known as Jet engines. We gotta get rid of those turbines, they're ruining aviation and our hearing. A turbine is too simple minded, it has no mystery. The air travels through it in a straight line and doesn't pick up any of the pungent fragrance of engine oil or pilot sweat. Anybody can start a turbine. You just need to move a switch from "OFF" to "START" and then remember to move it back to "ON" after a while. My PC is harder to start. Cranking a round engine requires skill, finesse and style. You have to seduce it into starting. It's like waking up a mistress On some planes, the pilots aren't even allowed to do it. Turbines start by whining for a while, then give a lady-like poof and start whining a little louder. Round engines give a satisfying rattle-rattle, click-click, BANG, more rattles, another BANG, a big macho FART or two, more clicks, a lot more smoke and finally a serious low pitched roar. We like that. It's a GUY thing. When you start a round engine, your mind is engaged and you can concentrate on the flight ahead. Starting turbine is like flicking on aceiling fan: Useful, but, hardly exciting. When you have started his round engine successfully your Crew Chief looks up at you like he'd let you kiss his girl, too! Turbines don't break or catch fire often enough, which leads to aircrew boredom, complacency and inattention. A round engine at speed looks and sounds like it's going to blow any minute. This helps concentrate the mind. Turbines don't have enough control levers or gauges to keep a pilot's attention. There's nothing to fiddle with during long flights. Turbines smell like a Boy Scout camp full of Coleman Lamps. Round engines smell like God intended machines to smell. Pass this on to an old WWII guy (or his son, or anyone who ever flew them) in remembrance of the "Greatest Generation". - - - - -=0A=0A=0A ________________________________________________________________________________
Date: Oct 30, 2008
Subject: Re: Design Information
Im trying to find any of the original design data for the 500 to 680 series aircraft.- Im trying to locate the L/D curves for any one of these model s. - thanks. - wer=0A=0A=0A ________________________________________________________________________________
Subject: Re:
Date: Oct 30, 2008
GREAT STUFF.? I flew my P&W,?R-985 last night looking at the fall foliage, the start procedures is just like that!!!? I could ad that even the shut down is cool.? Hold the brakes, don't point the prop blast at anything important.? Advance the throttle to about 1500RPM?and slowly move the mix to idle cut off.? Then as the engine winds down,?close the throttle.? This scavenges oil out of the sump, back to the tank after the taxi.? Not a bad idea in a Commander with geared engine ether, they are "dry sump" just like a radial.? jb -----Original Message----- From: Jim Addington <jtaddington(at)verizon.net> Sent: Thu, 30 Oct 2008 7:29 am Subject: Commander-List: You young kids have all missed the boat, round engines are the best. Jim Addington ? ? Subject: Engines - Rotary vs. Turbine ? Between A Radial Engine And A Jet Engine Round engines are commonly known as Radial engines. The piston Jugs are placed in a circle. Hence "Round" engines. Turbine engines are known as Jet engines. We gotta get rid of those turbines, they're ruining aviation and our hearing. A turbine is too simple minded, it has no mystery. The air travels through it in a straight line and doesn't pick up any of the pungent fragrance of engine oil or pilot sweat. Anybody can start a turbine. You just need to move a switch from "OFF" to "START" and then remember to move it back to "ON" after a while. My PC is harder to start. Cranking a round engine requires skill, finesse and style. You have to seduce it into starting. It's like waking up a mistress On some planes, the pilots aren't even allowed to do it. Turbines start by whining for a while, then give a lady-like poof and start whining a little louder. Round engines give a satisfying rattle-rattle, click-click, BANG, more rattles, another BANG, a big macho FART or two, more clicks, a lot more smoke and finally a serious low pitched roar. We like that. It's a GUY thing. When you start a round engine, your mind is engaged and you can concentrate on the flight ahead. Starting turbine is like flicking on aceiling fan: Useful, but, hardly exciting. When you have started his round engine successfully your Crew Chief looks up at you like he'd let you kiss his girl, too! Turbines don't break or catch fire often enough, which leads to aircrew boredom, complacency and inattention. A round engine at speed looks and sounds like it's going to blow any minute. This helps concentrate the mind. Turbines don't have enough control levers or gauges to keep a pilot's attention. There's nothing to fiddle with during long flights. Turbines smell like a Boy Scout camp full of Coleman Lamps. Round engines smell like God intended machines to smell. Pass this on to an old WWII guy (or his son, or anyone who ever flew them) in remembrance of the "Greatest Generation". ? ? ? ? ? ________________________________________________________________________________
Date: Oct 30, 2008
Moderator: - Has anyone else been getting Election SPAM via the Commander-list?- Is th ere anything the 'list' can to do stop it? - - - wer=0A=0A=0A ________________________________________________________________________________
From: "David Owens" <dowens(at)aerialviewpoint.com>
Subject: Re: AC-680 FLP Engine RPM Fluctuation
Date: Oct 30, 2008
DON... where in Houston are you??? Are you flying Commanders now? David Owens Aerial Viewpoint N14AV AC-500A-Colemill ________________________________________________________________________________
Subject: mander-List:
Date: Oct 30, 2008
I had none, Will. _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Thursday, October 30, 2008 9:20 AM Subject: Re: Commander-List: Moderator: Has anyone else been getting Election SPAM via the Commander-list? Is there anything the 'list' can to do stop it? wer D======================== ========= D======================== ========= D======================== ========= D======================== ========= ________________________________________________________________________________
Date: Oct 30, 2008
I have not and glad, besides I have already voted. Jim Addington _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Thursday, October 30, 2008 11:20 AM Subject: Re: Commander-List: Moderator: Has anyone else been getting Election SPAM via the Commander-list? Is there anything the 'list' can to do stop it? wer ________________________________________________________________________________
Date: Oct 30, 2008
I have not gotten any but I did receive a lot of "unable to deliver" spam messages. Tom. C-GISS ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Thursday, October 30, 2008 9:20 AM Subject: Re: Commander-List: Moderator: Has anyone else been getting Election SPAM via the Commander-list? Is there anything the 'list' can to do stop it? wer 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Oct 30, 2008
Thanks...It appears to be a personal email sent from a list member.... - they're now on the spam list. - wer --- On Thu, 10/30/08, nico css wrote: From: nico css <nico(at)cybersuperstore.com> Subject: RE: Commander-List: Date: Thursday, October 30, 2008, 9:33 AM I had none, Will. From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of willis robison Sent: Thursday, October 30, 2008 9:20 AM Subject: Re: Commander-List: Moderator: - Has anyone else been getting Election SPAM via the Commander-list?- Is th ere anything the 'list' can to do stop it? - - - wer 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.m atronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com /contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D =0A=0A=0A ________________________________________________________________________________
Date: Oct 30, 2008
Hi Wilis, I've not been getting anything either. But often what happens is spammers use somebody else's e-mail address (sounds like in this case the Matronics address) - I know this because my Josh Stafford Books e-mail address has been used by spammers. I have had a number of flame-mail replies to my website saying they hate me for sending out spam, will never buy my books, etc. Most unfortunate. Regards, Andrew ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Thursday, October 30, 2008 9:20 AM Subject: Re: Commander-List: Moderator: Has anyone else been getting Election SPAM via the Commander-list? Is there anything the 'list' can to do stop it? wer 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Oct 30, 2008
Gosh, I hope that's the case.- My 'spammer" in this cas,-is a frequent contributor and otherwise has been very helpful with things Commander relat ed. - I didnt know you could hijack someones email like that.- We'll, Ill be mo re careful from now on. - thanks. - wer --- On Thu, 10/30/08, andrew.bridget(at)telus.net w rote: From: andrew.bridget(at)telus.net <andrew.bridget(at)telus.net> Subject: Re: Commander-List: Date: Thursday, October 30, 2008, 10:47 AM Hi Wilis, I've not been getting anything either. But often what happens is spammers use somebody else's e-mail address (sounds like in this case the M atronics address) - I know this because my Josh Stafford Books e-mail addre ss has been used by spammers. I have had a number of flame-mail replies to my website saying they hate me for sending out spam, will never buy my book s, etc. Most unfortunate. Regards, Andrew ----- Original Message ----- From: willis robison Sent: Thursday, October 30, 2008 9:20 AM Subject: Re: Commander-List: Moderator: - Has anyone else been getting Election SPAM via the Commander-list?- Is th ere anything the 'list' can to do stop it? - - - wer 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.m atronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com /contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D =0A=0A=0A ________________________________________________________________________________
Date: Oct 30, 2008
"Has anyone else been getting Election SPAM via the Commander-list? Is there anything the 'list' can to do stop it" I thought that is why my computer has a "delete" button!Don ________________________________________________________________________________
Date: Oct 30, 2008
Indeed, there is a delete button. But sometimes it can be so overwhelming, not to mention the scare it puts into a list operator when that happens (where else did they get into?), that it is a real and expensive pest. I live and die by my emails and receive about 300 emails a day. A couple of years ago I hosted my own email servers and my daily email receipt rate ran in the thousands of about 80% being spam, ugly and less ugly. Eventually I gave up and had my servers moved to a hosted application with spam filtering and staff that does nothing else but keep it up to date, which brought the rate down into the low hundreds; cutting the incidences of spam down to about 10% that still slip past the filters. I could never answer the question of how many legitimate emails are being filtered out that I will never receive; and how many opportunities and business mail were lost. I would never know. To minimize the impact of a spam filter, I style the content of my emails not to contain buzz words that would alarm the spam filter. And if I need information from a vendor or contractor that would of necessity have words similar to those found in spam in it, I have it faxed to me. We're only trying to avoid the robbers that lurk in the bushes as we go about our business, that's the game. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don Sent: Thursday, October 30, 2008 12:10 PM Subject: Re: Commander-List: "Has anyone else been getting Election SPAM via the Commander-list? Is there anything the 'list' can to do stop it" I thought that is why my computer has a "delete" button! Don ________________________________________________________________________________
Date: Oct 30, 2008
Nico; I don't think a political spam is "robbers that lurk in the bushes" and as wer said he did, just put the sender in the blocked email list. I agree, it does not belong on the list, which as I understand it, it is not on the list, but I don't make a big deal out of it. Don ----- Original Message ----- From: nico css To: commander-list(at)matronics.com Sent: Thursday, October 30, 2008 3:46 PM Subject: RE: Commander-List: Indeed, there is a delete button. But sometimes it can be so overwhelming, not to mention the scare it puts into a list operator when that happens (where else did they get into?), that it is a real and expensive pest. I live and die by my emails and receive about 300 emails a day. A couple of years ago I hosted my own email servers and my daily email receipt rate ran in the thousands of about 80% being spam, ugly and less ugly. Eventually I gave up and had my servers moved to a hosted application with spam filtering and staff that does nothing else but keep it up to date, which brought the rate down into the low hundreds; cutting the incidences of spam down to about 10% that still slip past the filters. I could never answer the question of how many legitimate emails are being filtered out that I will never receive; and how many opportunities and business mail were lost. I would never know. To minimize the impact of a spam filter, I style the content of my emails not to contain buzz words that would alarm the spam filter. And if I need information from a vendor or contractor that would of necessity have words similar to those found in spam in it, I have it faxed to me. We're only trying to avoid the robbers that lurk in the bushes as we go about our business, that's the game. Nico ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don Sent: Thursday, October 30, 2008 12:10 PM To: commander-list(at)matronics.com Subject: Re: Commander-List: "Has anyone else been getting Election SPAM via the Commander-list? Is there anything the 'list' can to do stop it" I thought that is why my computer has a "delete" button!Don href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ------------------------------------------------------------------------- ----- Checked by AVG - http://www.avg.com 10/28/2008 10:04 AM ________________________________________________________________________________
Date: Oct 30, 2008
Nico is just referring to spam filters in general.- There is-a tremendo us amount of work done behind the scenes of a web-page or chat portal.- F ilters are just an annoying fact of life. - Do I smell SPAM burning?.... ---------------------------------------------------------- Now for something completely different. - Do I need an Original POH onboard or can one of the 'reprints" offered on t he internet do the job?- Any recommendations? - thanks. - Willis. --- On Thu, 10/30/08, Don wrote: From: Don <dongirod(at)bellsouth.net> Subject: Re: Commander-List: Date: Thursday, October 30, 2008, 1:12 PM Nico; - I don't think a political spam is "robbers that lurk in the bushes" and as wer said he did, just put the sender in the blocked email list. - I agree, it-does not belong on the list, which as I understand it, it is not on the list, but I don't make a big deal out of it. - Don ----- Original Message ----- From: nico css Sent: Thursday, October 30, 2008 3:46 PM Subject: RE: Commander-List: Indeed, there is a delete button. But sometimes it can be so overwhelming, not to mention the scare it puts into a list operator when that happens (wh ere else did they get into?), that it is a real and expensive pest. - I live and die by my emails and receive about 300 emails a day. A couple of years ago I hosted my own email servers and my daily email receipt rate ra n in the thousands of about 80% being spam, ugly and less ugly. Eventually I gave up and had my servers moved to a hosted application with spam filter ing and staff that does nothing else but keep it up to date, which brought the rate down into the low hundreds; cutting the incidences of spam down to about 10% that still slip past the filters. I could never answer the quest ion of how many legitimate emails are being filtered out that I will never receive; and how many opportunities and business mail were lost. I would ne ver know. To minimize the impact of a spam filter, I style the content of m y emails not to contain buzz words that would alarm the spam filter. And if I need information from a vendor or contractor that would of necessity hav e words similar to those found in spam in it, I have it faxed to me. - We're only trying to avoid the robbers that lurk in the bushes as we go abo ut our business, that's the game. - Nico - From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of Don Sent: Thursday, October 30, 2008 12:10 PM Subject: Re: Commander-List: - - - "Has anyone else been getting Election SPAM via the Commander-list?- Is t here anything the 'list' can to do stop it"--I thought that is why my c omputer has a "delete" button!Don- href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c - - Release Date: 10/28/2008 10:04 AM =0A=0A=0A ________________________________________________________________________________
Date: Oct 30, 2008
Good Afternoon Willis, My read would be that you need whatever is listed in the Type Certificate Data Sheet. If you don't have access to the TCDS, your IA should have the information. While I am certainly no expert on such things, if you will send me data concerning your aircraft such as the model number and serial number, I will see if I can find the required information. Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 10/30/2008 3:49:00 P.M. Central Daylight Time, drwer2(at)yahoo.com writes: Nico is just referring to spam filters in general. There is a tremendous amount of work done behind the scenes of a web-page or chat portal. Filters are just an annoying fact of life. Do I smell SPAM burning?.... ---------------------------------------------------------- Now for something completely different. Do I need an Original POH onboard or can one of the 'reprints" offered on the internet do the job? Any recommendations? thanks. Willis. ________________________________________________________________________________
Date: Oct 30, 2008
"Do I smell SPAM burning?...." Not from me! To answer your question indirectly. I believe you can still purchase POH. I have both my original and a "new one" give to me by a friend. Don ________________________________________________________________________________
From: "Robert S. Randazzo" <rsrandazzo(at)precisionmanuals.com>
Date: Oct 31, 2008
Gents- Trace wasn't racing their engine- they merely had one on display and were providing sales support for it. Even with a pair of V8s, the 685 wouldn't give much of a chase in the unlimited heat! Robert S. Randazzo N414C -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Chris Sent: Wednesday, October 29, 2008 3:55 PM Subject: Re: Commander-List: AC-680 FLP Engine RPM Fluctuation BobsV35B(at)aol.com wrote: > Those folks wanted nothing to do with it even though the numbers > worked out quite favorably. Wow, I would have never thought I'd disagree with Old Bob on anything, but I have a little different perspective on this one. I suspect that if you took a poll of Turbine Commander and King Air owners that darn few of them have ever heard of the Orenda project, let alone evaluated it as an option. Since (to the best of my knowledge), no STC/certification was ever achieved for those airplanes ,no significant operating history exists, and no advertising was ever done in places where corp owners would have seen it, I don't think the product ever mad it out of the shadows. I also don't think that the engine would have ever gained much momentum without some significant operational experience. Corporate owners don't seem to be the type to pounce on a major unproven powerplant option to me. Nico's point that a few Reno win's would help put them on the map is valid, but they'd need a good test fleet building hours to make it attractive to the target market. I remember hearing that there were some significant problems with the Commander test vehicle, but don't remember the specifics. Anyone else know more than I do? cheers, Chris ________________________________________________________________________________
Subject: Re: : Commander-List:
Date: Oct 31, 2008
JB- What was that 985 hanging on? I've got a 1340 on the SNJ. I'd go look at foliage this weekend, but we're expecting a bit of a blower and the sage brush just turns from brownish green to brownish brown out here. :-p Robert S. Randazzo N414C From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Thursday, October 30, 2008 9:11 AM Subject: Re: Commander-List: GREAT STUFF. I flew my P&W, R-985 last night looking at the fall foliage, the start procedures is just like that!!! I could ad that even the shut down is cool. Hold the brakes, don't point the prop blast at anything important. Advance the throttle to about 1500RPM and slowly move the mix to idle cut off. Then as the engine winds down, close the throttle. This scavenges oil out of the sump, back to the tank after the taxi. Not a bad idea in a Commander with geared engine ether, they are "dry sump" just like a radial. jb -----Original Message----- From: Jim Addington <jtaddington(at)verizon.net> Sent: Thu, 30 Oct 2008 7:29 am Subject: Commander-List: You young kids have all missed the boat, round engines are the best. Jim Addington Subject: Engines - Rotary vs. Turbine Between A Radial Engine And A Jet Engine Round engines are commonly known as Radial engines. The piston Jugs are placed in a circle. Hence "Round" engines. Turbine engines are known as Jet engines. We gotta get rid of those turbines, they're ruining aviation and our hearing. A turbine is too simple minded, it has no mystery. The air travels through it in a straight line and doesn't pick up any of the pungent fragrance of engine oil or pilot sweat. Anybody can start a turbine. You just need to move a switch from "OFF" to "START" and then remember to move it back to "ON" after a while. My PC is harder to start. Cranking a round engine requires skill, finesse and style. You have to seduce it into starting. It's like waking up a mistress On some planes, the pilots aren't even allowed to do it. Turbines start by whining for a while, then give a lady-like poof and start whining a little louder. Round engines give a satisfying rattle-rattle, click-click, BANG, more rattles, another BANG, a big macho FART or two, more clicks, a lot more smoke and finally a serious low pitched roar. We like that. It's a GUY thing. When you start a round engine, your mind is engaged and you can concentrate on the flight ahead. Starting turbine is like flicking on aceiling fan: Useful, but, hardly exciting. When you have started his round engine successfully your Crew Chief looks up at you like he'd let you kiss his girl, too! Turbines don't break or catch fire often enough, which leads to aircrew boredom, complacency and inattention. A round engine at speed looks and sounds like it's going to blow any minute. This helps concentrate the mind. Turbines don't have enough control levers or gauges to keep a pilot's attention. There's nothing to fiddle with during long flights. Turbines smell like a Boy Scout camp full of Coleman Lamps. Round engines smell like God intended machines to smell. Pass this on to an old WWII guy (or his son, or anyone who ever flew them) in remembrance of the "Greatest Generation". AOL News. ________________________________________________________________________________
Date: Oct 31, 2008
U3ViamVjdDogRW5naW5lcyAtIFJvdGFyeSB2cy4gVHVyYmluZQ0KDQpHUkVBVCBTVE9SWSEhIQ0K DQoNClNlbnQgdmlhIEJsYWNrQmVycnkgYnkgQVQmVA0KDQotLS0tLU9yaWdpbmFsIE1lc3NhZ2Ut LS0tLQ0KRnJvbTogIlJvYmVydCBTLiBSYW5kYXp6byIgPHJzcmFuZGF6em9AcHJlY2lzaW9ubWFu dWFscy5jb20+DQoNCkRhdGU6IEZyaSwgMzEgT2N0IDIwMDggMDY6MTA6MzggDQpUbzogPGNvbW1h bmRlci1saXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBSRTogIFJlOiBDb21tYW5kZXItTGlz dDoNCg0KDQpKQi0NCg0KIA0KDQpXaGF0IHdhcyB0aGF0IDk4NSBoYW5naW5nIG9uPw0KDQogDQoN CkkndmUgZ290IGEgMTM0MCBvbiB0aGUgU05KLiAgSSdkIGdvIGxvb2sgYXQgZm9saWFnZSB0aGlz IHdlZWtlbmQsIGJ1dCB3ZSdyZQ0KZXhwZWN0aW5nIGEgYml0IG9mIGEgYmxvd2VyIGFuZCB0aGUg c2FnZSBicnVzaCBqdXN0IHR1cm5zIGZyb20gYnJvd25pc2gNCmdyZWVuIHRvIGJyb3duaXNoIGJy b3duIG91dCBoZXJlLiAgOi1wDQoNCiANCg0KUm9iZXJ0IFMuIFJhbmRhenpvDQoNCk40MTRDDQoN CiANCg0KRnJvbTogb3duZXItY29tbWFuZGVyLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20NCltt YWlsdG86b3duZXItY29tbWFuZGVyLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFs ZiBPZg0KeW91cnRjZmdAYW9sLmNvbQ0KU2VudDogVGh1cnNkYXksIE9jdG9iZXIgMzAsIDIwMDgg OToxMSBBTQ0KVG86IGNvbW1hbmRlci1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6ICBSZTog Q29tbWFuZGVyLUxpc3Q6DQoNCiANCg0KR1JFQVQgU1RVRkYuICBJIGZsZXcgbXkgUCZXLCBSLTk4 NSBsYXN0IG5pZ2h0IGxvb2tpbmcgYXQgdGhlIGZhbGwgZm9saWFnZSwNCnRoZSBzdGFydCBwcm9j ZWR1cmVzIGlzIGp1c3QgbGlrZSB0aGF0ISEhICBJIGNvdWxkIGFkIHRoYXQgZXZlbiB0aGUgc2h1 dA0KZG93biBpcyBjb29sLiAgSG9sZCB0aGUgYnJha2VzLCBkb24ndCBwb2ludCB0aGUgcHJvcCBi bGFzdCBhdCBhbnl0aGluZw0KaW1wb3J0YW50LiAgQWR2YW5jZSB0aGUgdGhyb3R0bGUgdG8gYWJv dXQgMTUwMFJQTSBhbmQgc2xvd2x5IG1vdmUgdGhlIG1peCB0bw0KaWRsZSBjdXQgb2ZmLiAgVGhl biBhcyB0aGUgZW5naW5lIHdpbmRzIGRvd24sIGNsb3NlIHRoZSB0aHJvdHRsZS4gIFRoaXMNCnNj YXZlbmdlcyBvaWwgb3V0IG9mIHRoZSBzdW1wLCBiYWNrIHRvIHRoZSB0YW5rIGFmdGVyIHRoZSB0 YXhpLiAgTm90IGEgYmFkDQppZGVhIGluIGEgQ29tbWFuZGVyIHdpdGggZ2VhcmVkIGVuZ2luZSBl dGhlciwgdGhleSBhcmUgImRyeSBzdW1wIiBqdXN0IGxpa2UNCmEgcmFkaWFsLiAgamINCg0KDQot LS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KRnJvbTogSmltIEFkZGluZ3RvbiA8anRhZGRpbmd0 b25AdmVyaXpvbi5uZXQ+DQpUbzogSmltIEFkZGluZ3RvbiA8anRhZGRpbmd0b25AdmVyaXpvbi5u ZXQ+DQpTZW50OiBUaHUsIDMwIE9jdCAyMDA4IDc6MjkgYW0NClN1YmplY3Q6IENvbW1hbmRlci1M aXN0OiANCg0KWW91IHlvdW5nIGtpZHMgaGF2ZSBhbGwgbWlzc2VkIHRoZSBib2F0LCByb3VuZCBl bmdpbmVzIGFyZSB0aGUgYmVzdC4NCg0KSmltIEFkZGluZ3Rvbg0KDQogDQoNCiANCg0KU3ViamVj dDogRW5naW5lcyAtIFJvdGFyeSB2cy4gVHVyYmluZQ0KDQogDQoNCkJldHdlZW4gQSBSYWRpYWwg RW5naW5lIEFuZCBBIEpldCBFbmdpbmUNCg0KUm91bmQgZW5naW5lcyBhcmUgY29tbW9ubHkga25v d24gYXMgUmFkaWFsIGVuZ2luZXMuIFRoZSBwaXN0b24gSnVncw0KYXJlIHBsYWNlZCBpbiBhIGNp cmNsZS4gSGVuY2UgIlJvdW5kIiBlbmdpbmVzLiBUdXJiaW5lIGVuZ2luZXMgYXJlDQprbm93biBh cyBKZXQgZW5naW5lcy4gV2UgZ290dGEgZ2V0IHJpZCBvZiB0aG9zZSB0dXJiaW5lcywgdGhleSdy ZQ0KcnVpbmluZyBhdmlhdGlvbiBhbmQgb3VyIGhlYXJpbmcuDQoNCkEgdHVyYmluZSBpcyB0b28g c2ltcGxlIG1pbmRlZCwgaXQgaGFzIG5vIG15c3RlcnkuIFRoZSBhaXIgdHJhdmVscw0KdGhyb3Vn aCBpdCBpbiBhIHN0cmFpZ2h0IGxpbmUgYW5kIGRvZXNuJ3QgcGljayB1cCBhbnkgb2YgdGhlIHB1 bmdlbnQNCmZyYWdyYW5jZSBvZiBlbmdpbmUgb2lsIG9yIHBpbG90IHN3ZWF0LiBBbnlib2R5IGNh biBzdGFydCBhIHR1cmJpbmUuDQpZb3UganVzdCBuZWVkIHRvIG1vdmUgYSBzd2l0Y2ggZnJvbSAi T0ZGIiB0byAiU1RBUlQiIGFuZCB0aGVuIHJlbWVtYmVyDQp0byBtb3ZlIGl0IGJhY2sgdG8gIk9O IiBhZnRlciBhIHdoaWxlLiBNeSBQQyBpcyBoYXJkZXIgdG8gc3RhcnQuDQoNCkNyYW5raW5nIGEg cm91bmQgZW5naW5lIHJlcXVpcmVzIHNraWxsLCBmaW5lc3NlIGFuZCBzdHlsZS4gWW91IGhhdmUg dG8NCnNlZHVjZSBpdCBpbnRvIHN0YXJ0aW5nLiBJdCdzIGxpa2Ugd2FraW5nIHVwIGEgbWlzdHJl c3MgT24gc29tZQ0KcGxhbmVzLCB0aGUgcGlsb3RzIGFyZW4ndCBldmVuIGFsbG93ZWQgdG8gZG8g aXQuIFR1cmJpbmVzIHN0YXJ0IGJ5DQp3aGluaW5nIGZvciBhIHdoaWxlLCB0aGVuIGdpdmUgYSBs YWR5LWxpa2UgcG9vZiBhbmQgc3RhcnQgd2hpbmluZyBhDQpsaXR0bGUgbG91ZGVyLg0KDQpSb3Vu ZCBlbmdpbmVzIGdpdmUgYSBzYXRpc2Z5aW5nIHJhdHRsZS1yYXR0bGUsIGNsaWNrLWNsaWNrLCBC QU5HLCBtb3JlDQpyYXR0bGVzLCBhbm90aGVyIEJBTkcsIGEgYmlnIG1hY2hvIEZBUlQgb3IgdHdv LCBtb3JlIGNsaWNrcywgYSBsb3QNCm1vcmUgc21va2UgYW5kIGZpbmFsbHkgYSBzZXJpb3VzIGxv dyBwaXRjaGVkIHJvYXIuIFdlIGxpa2UgdGhhdC4gSXQncw0KYSBHVVkgdGhpbmcuDQoNCldoZW4g eW91IHN0YXJ0IGEgcm91bmQgZW5naW5lLCB5b3VyIG1pbmQgaXMgZW5nYWdlZCBhbmQgeW91IGNh bg0KY29uY2VudHJhdGUgb24gdGhlIGZsaWdodCBhaGVhZC4gU3RhcnRpbmcgdHVyYmluZSBpcyBs aWtlIGZsaWNraW5nIG9uDQphY2VpbGluZyBmYW46DQpVc2VmdWwsIGJ1dCwgaGFyZGx5IGV4Y2l0 aW5nLg0KDQpXaGVuIHlvdSBoYXZlIHN0YXJ0ZWQgaGlzIHJvdW5kIGVuZ2luZSBzdWNjZXNzZnVs bHkgeW91ciBDcmV3IENoaWVmDQpsb29rcyB1cCBhdCB5b3UgbGlrZSBoZSdkIGxldCB5b3Uga2lz cyBoaXMgZ2lybCwgdG9vISBUdXJiaW5lcyBkb24ndA0KYnJlYWsgb3IgY2F0Y2ggZmlyZSBvZnRl biBlbm91Z2gsIHdoaWNoIGxlYWRzIHRvIGFpcmNyZXcgYm9yZWRvbSwNCmNvbXBsYWNlbmN5IGFu ZCBpbmF0dGVudGlvbi4gQSByb3VuZCBlbmdpbmUgYXQgc3BlZWQgbG9va3MgYW5kIHNvdW5kcw0K bGlrZSBpdCdzIGdvaW5nIHRvIGJsb3cgYW55IG1pbnV0ZS4gVGhpcyBoZWxwcyBjb25jZW50cmF0 ZSB0aGUgbWluZC4NCg0KVHVyYmluZXMgZG9uJ3QgaGF2ZSBlbm91Z2ggY29udHJvbCBsZXZlcnMg b3IgZ2F1Z2VzIHRvIGtlZXAgYSBwaWxvdCdzDQphdHRlbnRpb24uIFRoZXJlJ3Mgbm90aGluZyB0 byBmaWRkbGUgd2l0aCBkdXJpbmcgbG9uZyBmbGlnaHRzLg0KVHVyYmluZXMgc21lbGwgbGlrZSBh IEJveSBTY291dCBjYW1wIGZ1bGwgb2YgQ29sZW1hbiBMYW1wcy4gUm91bmQNCmVuZ2luZXMgc21l bGwgbGlrZSBHb2QgaW50ZW5kZWQgbWFjaGluZXMgdG8gc21lbGwuDQoNClBhc3MgdGhpcyBvbiB0 byBhbiBvbGQgV1dJSSBndXkgKG9yIGhpcyBzb24sIG9yIGFueW9uZSB3aG8gZXZlciBmbGV3DQp0 aGVtKSBpbiByZW1lbWJyYW5jZSBvZiB0aGUgIkdyZWF0ZXN0IEdlbmVyYXRpb24iLg0KDQogDQoN CiANCg0KIA0KDQogDQoNCiANCg0KQU9MIE5ld3MuIA0KDQoNCg= ________________________________________________________________________________
Date: Oct 31, 2008
Subject: Anybody want to trade their P51 for my 500B?
Hi all: - I received this from a friend- many of you may have seen it.- This tribute to the Gray Eagles (WWII pilots) was in conjunction with an ai rshow in Ohio called "The Final Roundup." -It was the last large gatherin g of the remaining P-51 Mustang fighters used during WWII. -There were ab out 120 of the fighters there, all of them in flying condition, of course. -The flyover seen at the end of the video is composed entirely of P51s spelling out the number 51. -It was an event that may never be seen again. http://www.grayeagles.org/video.htm Turn up the sound! I think it is terriffic. - dan - - -=0A=0A=0A ________________________________________________________________________________
Date: Oct 31, 2008
It is on a "homebuilt" Grumman Ag-Cat.=C2- It is now a three place, open c ockpit bi-plane, usually on floats but currently back on wheels.=C2- I lov e the 1340,=C2- flew Ag for 15 years and have many thousands of hours behi nd a 1340, geared 1340 and the 985.=C2- jb What was that 985 hanging on -----Original Message----- From: Robert S. Randazzo <rsrandazzo(at)precisionmanuals.com> Sent: Fri, 31 Oct 2008 6:10 am Subject: RE: Re: Commander-List: JB- =C2- What was that 985 hanging on? =C2- I=99ve got a 1340 on the SNJ=C2- I=99d go look at fol iage this weekend, but we=99re expecting a bit of a blower and the sag e brush just turns from brownish green to brownish brown out here.=C2- :-p =C2- Robert S. Randazzo N414C =C2- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list -server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Thursday, October 30, 2008 9:11 AM Subject: Re: Commander-List: =C2- GREAT STUFF.=C2- I flew my P&W,=C2-R-985 last night looking at the fall foliage, the start procedures is just like that!!!=C2- I could ad that eve n the shut down is cool.=C2- Hold the brakes, don't point the prop blast a t anything important.=C2- Advance the throttle to about 1500RPM=C2-and s lowly move the mix to idle cut off.=C2- Then as the engine winds down,=C2 -close the throttle.=C2- This scavenges oil out of the sump, back to the tank after the taxi.=C2- Not a bad idea in a Commander with geared engine ether, they are "dry sump" just like a radial.=C2- jb -----Original Message----- From: Jim Addington <jtaddington(at)verizon.net> Sent: Thu, 30 Oct 2008 7:29 am Subject: Commander-List: You young kids have all missed the boat, round engines are the best. Jim Addington =C2- =C2- Subject: Engines - Rotary vs. Turbine =C2- Between A Radial Engine And A Jet Engine Round engines are commonly known as Radial engines. The piston Jugs are placed in a circle. Hence "Round" engines. Turbine engines are known as Jet engines. We gotta get rid of those turbines, they're ruining aviation and our hearing. A turbine is too simple minded, it has no mystery. The air travels through it in a straight line and doesn't pick up any of the pungent fragrance of engine oil or pilot sweat. Anybody can start a turbine. You just need to move a switch from "OFF" to "START" and then remember to move it back to "ON" after a while. My PC is harder to start. Cranking a round engine requires skill, finesse and style. You have to seduce it into starting. It's like waking up a mistress On some planes, the pilots aren't even allowed to do it. Turbines start by whining for a while, then give a lady-like poof and start whining a little louder. Round engines give a satisfying rattle-rattle, click-click, BANG, more rattles, another BANG, a big macho FART or two, more clicks, a lot more smoke and finally a serious low pitched roar. We like that. It's a GUY thing. When you start a round engine, your mind is engaged and you can concentrate on the flight ahead. Starting turbine is like flicking on aceiling fan: Useful, but, hardly exciting. When you have started his round engine successfully your Crew Chief looks up at you like he'd let you kiss his girl, too! Turbines don't break or catch fire often enough, which leads to aircrew boredom, complacency and inattention. A round engine at speed looks and sounds like it's going to blow any minute. This helps concentrate the mind. Turbines don't have enough control levers or gauges to keep a pilot's attention. There's nothing to fiddle with during long flights. Turbines smell like a Boy Scout camp full of Coleman Lamps. Round engines smell like God intended machines to smell. Pass this on to an old WWII guy (or his son, or anyone who ever flew them) in remembrance of the "Greatest Generation". =C2- =C2- =C2- =C2- =C2- AOL News. ________________________________________________________________________________
Date: Oct 31, 2008
Can you sell rides in the AG CAT ?? I assume it is in experimental catagory . I'm fighting with myself about going experimental with my 450 Stearman or going to the expense of standard catagory. I would like a wide seat in the front also. Of course my 500 Commander is my favorite go somewhere airplane. Roland Gilliam n Ag-Cat. It is now a three place=2C open cockpit bi-plane=2C usually on f loats but currently back on wheels. I love the 1340=2C flew Ag for 15 yea rs and have many thousands of hours behind a 1340=2C geared 1340 and the 98 5. jb What was that 985 hanging on-----Original Message-----From: Robert S. Randa zzo To: commander-list(at)matronics.comSent: Fri=2C 31 Oct 2008 6:10 amSubject: RE: Re: Commander-List: JB- What was that 985 hanging on? I=92ve got a 1340 on the SNJ=85 I=92d go look at foliage this weekend=2C b ut we=92re expecting a bit of a blower and the sage brush just turns from b rownish green to brownish brown out here. :-p Robert S. Randazzo N414C From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.comSent: Thursday=2C Octo ber 30=2C 2008 9:11 AMTo: commander-list(at)matronics.comSubject: Re: Commande r-List: GREAT STUFF. I flew my P&W=2C R-985 last night looking at the fall foliage =2C the start procedures is just like that!!! I could ad that even the shu t down is cool. Hold the brakes=2C don't point the prop blast at anything important. Advance the throttle to about 1500RPM and slowly move the mix t o idle cut off. Then as the engine winds down=2C close the throttle. This scavenges oil out of the sump=2C back to the tank after the taxi. Not a b ad idea in a Commander with geared engine ether=2C they are "dry sump" just like a radial. jb-----Original Message-----From: Jim Addington <jtaddingt on(at)verizon.net>To: Jim Addington Sent: Thu=2C 30 O ct 2008 7:29 amSubject: Commander-List: You young kids have all missed the boat=2C round engines are the best. Jim Addington Subject: Engines - Rotary vs. Turbine Between A Radial Engine And A Jet EngineRound engines are commonly known as Radial engines. The piston Jugsare placed in a circle. Hence "Round" engin es. Turbine engines areknown as Jet engines. We gotta get rid of those turb ines=2C they'reruining aviation and our hearing.A turbine is too simple min ded=2C it has no mystery. The air travelsthrough it in a straight line and doesn't pick up any of the pungentfragrance of engine oil or pilot sweat. A nybody can start a turbine.You just need to move a switch from "OFF" to "ST ART" and then rememberto move it back to "ON" after a while. My PC is harde r to start.Cranking a round engine requires skill=2C finesse and style. You have toseduce it into starting. It's like waking up a mistress On someplan es=2C the pilots aren't even allowed to do it. Turbines start bywhining for a while=2C then give a lady-like poof and start whining alittle louder.Rou nd engines give a satisfying rattle-rattle=2C click-click=2C BANG=2C morera ttles=2C another BANG=2C a big macho FART or two=2C more clicks=2C a lotmor e smoke and finally a serious low pitched roar. We like that. It'sa GUY thi ng.When you start a round engine=2C your mind is engaged and you canconcent rate on the flight ahead. Starting turbine is like flicking onaceiling fan: Useful=2C but=2C hardly exciting.When you have started his round engine suc cessfully your Crew Chieflooks up at you like he'd let you kiss his girl=2C too! Turbines don'tbreak or catch fire often enough=2C which leads to airc rew boredom=2Ccomplacency and inattention. A round engine at speed looks an d soundslike it's going to blow any minute. This helps concentrate the mind .Turbines don't have enough control levers or gauges to keep a pilot'satten tion. There's nothing to fiddle with during long flights.Turbines smell lik e a Boy Scout camp full of Coleman Lamps. Roundengines smell like God inten ded machines to smell.Pass this on to an old WWII guy (or his son=2C or any one who ever flewthem) in remembrance of the "Greatest Generation". AOL News. McCain or Obama? Stay up to date on the latest from the campaign tra2631/ao l?redir=http://news.aol.com/elections?ncid=emlcntusnews00000001"> AOL N ews. _________________________________________________________________ You live life beyond your PC. So now Windows goes beyond your PC. R0lGODlhDgevBHcAMSH+GlNvZnR3YXJlOiBNaWNyb3NvZnQgT2ZmaWNlACH5BAEAAAAALAAAAAAB AAEAgAAAAAECAwICRAEAOw= R0lGODlh4AaQBHcAMSH+GlNvZnR3YXJlOiBNaWNyb3NvZnQgT2ZmaWNlACH5BAEAAAAALAAAAAAB AAEAgAAAAAECAwICRAEAOw= R0lGODlhsASEA3cAMSH+GlNvZnR3YXJlOiBNaWNyb3NvZnQgT2ZmaWNlACH5BAEAAAAALAAAAAAB AAEAgAAAAAECAwICRAEAOw= ________________________________________________________________________________
Date: Oct 31, 2008
Subject: Sunset
-Landies and Gentlemen: - I was not going to mention this but all the talk about engines changed my m ind. Today was my last day at American Airlines.- I decided to retire early at 58 for many reasons.- Mostly after 31 years at American I want to do a d ifferent type of flying and also if I worked past Nov 1 I would have taken a wack on my retirement.- The engine part is that after 36 years and abou t 18000 hours in jets I have never had an engine failure.- One time in a B52 we shut one down for low oil pressure--WOW only 7 left, that is scary. - IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) - dan =0A=0A=0A ________________________________________________________________________________
Date: Oct 31, 2008
Subject: Re: Sunset
Congratulations, Dan! Please post tales of your upcoming adventures... ak On Fri, Oct 31, 2008 at 6:31 PM, Dan Farmer wrote: > Landies and Gentlemen: > > I was not going to mention this but all the talk about engines changed my > mind. > Today was my last day at American Airlines. I decided to retire early at > 58 for many reasons. Mostly after 31 years at American I want to do a > different type of flying and also if I worked past Nov 1 I would have taken > a wack on my retirement. The engine part is that after 36 years and about > 18000 hours in jets I have never had an engine failure. One time in a B52 > we shut one down for low oil pressure--WOW only 7 left, that is scary. > > IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) > > dan > > * > > * > > ________________________________________________________________________________
Subject: Re: Sunset
Date: Oct 31, 2008
So this means you can go on the cruse with us!!!!!!!!!!!!!!!!!? Yiippee!!? jb ?Landies and Gentlemen: ? I was not going to mention this but all the talk about engines changed my mind. Today was my last day at American Airlines.? -----Original Message----- From: Dan Farmer <daniellfarmer(at)yahoo.com> Sent: Fri, 31 Oct 2008 6:31 pm Subject: Commander-List: Sunset ?Landies and Gentlemen: ? I was not going to mention this but all the talk about engines changed my mind. Today was my last day at American Airlines.? I decided to retire early at 58 for many reasons.? Mostly after 31 years at American I want to do a different type of flying and also if I worked past Nov 1 I would have taken a wack on my retirement.? The engine part is that after 36 years and about 18000 hours in jets I have never had an engine failure.? One time in a B52 we shut one down for low oil pressure--WOW only 7 left, that is scary. ? IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) ? dan ________________________________________________________________________________
Date: Oct 31, 2008
Call me, 360-903-6901.=C2- jb Can you sell rides in the AG CAT ?? I assume it is in experimental catagory. -----Original Message----- From: Nancy Gilliam <amg3636(at)hotmail.com> Sent: Fri, 31 Oct 2008 2:41 pm Subject: RE: Commander-List: Can you sell rides in the AG CAT ?? I assume it is in experimental catagory. I'm fighting with myself about going experimental with my 450 Stearman or g oing to the =C2- =C2-expense of=C2- standard catagory. I would like a wide seat in the fr ont also. Of course my 500 Commander is my favorite go somewhere airplane. =C2- Roland Gilliam =C2- Subject: Re: Commander-List: Date: Fri, 31 Oct 2008 12:05:06 -0400 From: yourtcfg(at)aol.com It is on a "homebuilt" Grumman Ag-Cat.=C2- It is now a three place, open c ockpit bi-plane, usually on floats but currently back on wheels.=C2- I lov e the 1340,=C2- flew Ag for 15 years and have many thousands of hours behi nd a 1340, geared 1340 and the 985.=C2- jb What was that 985 hanging on -----Original Message----- From: Robert S. Randazzo <rsrandazzo(at)precisionmanuals.com> Sent: Fri, 31 Oct 2008 6:10 am Subject: RE: Re: Commander-List: JB- =C2- What was that 985 hanging on? =C2- I=99ve got a 1340 on the SNJ=C2- I=99d go look at fol iage this weekend, but we=99re expecting a bit of a blower and the sag e brush just turns from brownish green to brownish brown out here.=C2- :-p =C2- Robert S. Randazzo N414C =C2- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list -server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Thursday, October 30, 2008 9:11 AM Subject: Re: Commander-List: =C2- GREAT STUFF.=C2- I flew my P&W,=C2-R-985 last night looking at the fall foliage, the start procedures is just like that!!!=C2- I could ad that eve n the shut down is cool.=C2- Hold the brakes, don't point the prop blast a t anything important.=C2- Advance the throttle to about 1500RPM=C2-and s lowly move the mix to idle cut off.=C2- Then as the engine winds down,=C2 -close the throttle.=C2- This scavenges oil out of the sump, back to the tank after the taxi.=C2- Not a bad idea in a Commander with geared engine ether, they are "dry sump" just like a radial.=C2- jb -----Original Message----- From: Jim Addington <jtaddington(at)verizon.net> Sent: Thu, 30 Oct 2008 7:29 am Subject: Commander-List: You young kids have all missed the boat, round engines are the best. Jim Addington =C2- =C2- Subject: Engines - Rotary vs. Turbine =C2- Between A Radial Engine And A Jet Engine Round engines are commonly known as Radial engines. The piston Jugs are placed in a circle. Hence "Round" engines. Turbine engines are known as Jet engines. We gotta get rid of those turbines, they're ruining aviation and our hearing. A turbine is too simple minded, it has no mystery. The air travels through it in a straight line and doesn't pick up any of the pungent fragrance of engine oil or pilot sweat. Anybody can start a turbine. You just need to move a switch from "OFF" to "START" and then remember to move it back to "ON" after a while. My PC is harder to start. Cranking a round engine requires skill, finesse and style. You have to seduce it into starting. It's like waking up a mistress On some planes, the pilots aren't even allowed to do it. Turbines start by whining for a while, then give a lady-like poof and start whining a little louder. Round engines give a satisfying rattle-rattle, click-click, BANG, more rattles, another BANG, a big macho FART or two, more clicks, a lot more smoke and finally a serious low pitched roar. We like that. It's a GUY thing. When you start a round engine, your mind is engaged and you can concentrate on the flight ahead. Starting turbine is like flicking on aceiling fan: Useful, but, hardly exciting. When you have started his round engine successfully your Crew Chief looks up at you like he'd let you kiss his girl, too! Turbines don't break or catch fire often enough, which leads to aircrew boredom, complacency and inattention. A round engine at speed looks and sounds like it's going to blow any minute. This helps concentrate the mind. Turbines don't have enough control levers or gauges to keep a pilot's attention. There's nothing to fiddle with during long flights. Turbines smell like a Boy Scout camp full of Coleman Lamps. Round engines smell like God intended machines to smell. Pass this on to an old WWII guy (or his son, or anyone who ever flew them) in remembrance of the "Greatest Generation". =C2- =C2- =C2- =C2- =C2- AOL News. McCain or Obama? Stay up to date on the latest from the campaign tra2631/aol ?redir=http://news.aol.com/elections?ncid=emlcntusnews00000001"> AOL New s. You live life beyond your PC. So now556/direct/01/' target='_new'>See how = ________________________________________________________________________________
Date: Oct 31, 2008
Subject: Sunset
CONGRATULATIONS!!!!!!!!!!!!!!!!!!!!!! You will enjoy it. Jim _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Farmer Sent: Friday, October 31, 2008 8:31 PM Subject: Commander-List: Sunset Landies and Gentlemen: I was not going to mention this but all the talk about engines changed my mind. Today was my last day at American Airlines. I decided to retire early at 58 for many reasons. Mostly after 31 years at American I want to do a different type of flying and also if I worked past Nov 1 I would have taken a wack on my retirement. The engine part is that after 36 years and about 18000 hours in jets I have never had an engine failure. One time in a B52 we shut one down for low oil pressure--WOW only 7 left, that is scary. IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) dan ________________________________________________________________________________
Subject: Sunset
Date: Oct 31, 2008
Dan- Congratulations on achieving Controlled Flight into Retirement! Many of our colleagues around the industry aren't so fortunate to make it to a position where they can choose the retire or depart the industry on their own terms. We'll pull up another stool to the Voluntary Former Airline Pilots Fraternal and Drinking Association. Of course- since you mentioned wanting to do a "different type of flying" you are now obligated to explain yourself. J Robert S. Randazzo N414C VFAPF&DA Member From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Farmer Sent: Friday, October 31, 2008 6:31 PM Subject: Commander-List: Sunset Landies and Gentlemen: I was not going to mention this but all the talk about engines changed my mind. Today was my last day at American Airlines. I decided to retire early at 58 for many reasons. Mostly after 31 years at American I want to do a different type of flying and also if I worked past Nov 1 I would have taken a wack on my retirement. The engine part is that after 36 years and about 18000 hours in jets I have never had an engine failure. One time in a B52 we shut one down for low oil pressure--WOW only 7 left, that is scary. IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) dan D======================== ========= D======================== ========= D======================== ========= D======================== ========= ________________________________________________________________________________
Subject: Sunset
Date: Oct 31, 2008
Totally envious, Dan. Totally. I'll have to grind till I drop. _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Farmer Sent: Friday, October 31, 2008 6:31 PM Subject: Commander-List: Sunset Landies and Gentlemen: I was not going to mention this but all the talk about engines changed my mind. Today was my last day at American Airlines. I decided to retire early at 58 for many reasons. Mostly after 31 years at American I want to do a different type of flying and also if I worked past Nov 1 I would have taken a wack on my retirement. The engine part is that after 36 years and about 18000 hours in jets I have never had an engine failure. One time in a B52 we shut one down for low oil pressure--WOW only 7 left, that is scary. IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) dan D======================== ========= D======================== ========= D======================== ========= D======================== ========= ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the List services at Matronics. It's through soley through the Contributions of List members that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site ( http://forums.matronics.com ), Wiki site ( http://wiki.matronics.com ), or other related pages such as the List Search Engine ( http://www.matronics.com/search ), List Browse ( http://www.matronics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisments. During the month of November I will be sending out List messages every few days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Your personal Contribution counts. Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include Bob Nuckolls of the AeroElectric Connection (http://www.aeroelectric.com/), Andy Gold of the Builder's Bookstore (http://www.buildersbooks.com/), and Jon Croke of HomebuiltHELP (http://www.homebuilthelp.com/). These are extremely generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site below: https://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years. I know it sounds a little cliche, but you guys really do feel like family. Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Re: Sunset
Date: Nov 01, 2008
Good decision Dan! Now, you'll wonder how on earth you ever managed to find time to go to work. I hope you thoroughly enjoy your "life of leisure". Very Best Regards, Barry ----- Original Message ----- From: Dan Farmer To: commander-list-digest(at)matronics.com Sent: Saturday, November 01, 2008 1:31 AM Subject: Commander-List: Sunset Landies and Gentlemen: I was not going to mention this but all the talk about engines changed my mind. Today was my last day at American Airlines. I decided to retire early at 58 for many reasons. Mostly after 31 years at American I want to do a different type of flying and also if I worked past Nov 1 I would have taken a wack on my retirement. The engine part is that after 36 years and about 18000 hours in jets I have never had an engine failure. One time in a B52 we shut one down for low oil pressure--WOW only 7 left, that is scary. IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) dan 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: Sunset
Date: Nov 01, 2008
Congratulations Dan!!! Robert B. Steele, Treasurer KZF Design Inc. 655 Eden Park Drive Suite 750 Cincinnati, OH 45202-6000 main 513.621.6211 bob.steele(at)kzf.com KZF.COM <http://www.kzf.com> This message (and any attachments) is intended solely for the use of the named individual(s) to whom it is directed. This message may contain information that is confidential, subject to copyright, attorney client privilege, work product privilege, is a trade secret, and/or is exempt from disclosure under applicable law. If you are not the intended recipient, you are hereby notified that any dissemination, distribution or duplication of this transmission, or files attached to this transmission, is strictly prohibited. If you have received this message in error, please immediately notify the webmaster at KZF Design, Inc. at 513.621.6211, or by reply to this message, and delete this message and all attachments from your computer. Transmissions sent to and from KZF Design may be monitored. Internet communications cannot be guaranteed to be secure or error-free, and may be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. KZF Design shall not be held liable for any such eventualities. ________________________________ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Farmer Sent: Friday, October 31, 2008 9:31 PM Subject: Commander-List: Sunset Landies and Gentlemen: I was not going to mention this but all the talk about engines changed my mind. Today was my last day at American Airlines. I decided to retire early at 58 for many reasons. Mostly after 31 years at American I want to do a different type of flying and also if I worked past Nov 1 I would have taken a wack on my retirement. The engine part is that after 36 years and about 18000 hours in jets I have never had an engine failure. One time in a B52 we shut one down for low oil pressure--WOW only 7 left, that is scary. IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) dan ________________________________________________________________________________
Subject: Re: Sunset
Date: Nov 01, 2008
Now you have more time to fly the 500B. On my G---., The dreaded 7 engine approach!!!! :) I will be in COS doing the fuel tank start up at COS Bus. Park on Tuesday and Wed. How about I buy you one at SOLO's on Tues evening??? Call me. Tylor Hall 505-400-8373 Cell. On Nov 1, 2008, at 5:24 AM, Barry Collman wrote: > Good decision Dan! > > Now, you'll wonder how on earth you ever managed to find time to go > to work. > > I hope you thoroughly enjoy your "life of leisure". > > Very Best Regards, > Barry > ----- Original Message ----- > From: Dan Farmer > To: commander-list-digest(at)matronics.com > Sent: Saturday, November 01, 2008 1:31 AM > Subject: Commander-List: Sunset > > Landies and Gentlemen: > > I was not going to mention this but all the talk about engines > changed my mind. > Today was my last day at American Airlines. I decided to retire > early at 58 for many reasons. Mostly after 31 years at American I > want to do a different type of flying and also if I worked past Nov > 1 I would have taken a wack on my retirement. The engine part is > that after 36 years and about 18000 hours in jets I have never had > an engine failure. One time in a B52 we shut one down for low oil > pressure--WOW only 7 left, that is scary. > > IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) > > dan > > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > ====================== > href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.matronics.com/Navigator?Commander-List > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > ====================== > href='3D"http://forums.matronics.com"'>http://forums.matronics.com > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > ====================== > href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > ====================== > ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Contribution Site URL Clarification
Dear Listers, In my List Fund Raiser kickoff email last night, I mistyped the URL for the *initial* Contribution web site and couple of people reported receiving SSL certificate errors. The actual payment entry pages where were correct, however, so there were no certificate issues that impacted payment data. I'm sorry for the confusion. Please use the following URL to start your List Contribution: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Re: Sunset
From: "Deneal Schilmeister (iMac)" <deneals(at)deneals.com>
On 10/31/08 11:19 PM, "Robert S. Randazzo" wrote: > > Many of our colleagues around the industry aren=B9t so fortunate to make it to a > position where they can choose the retire or depart the industry on their own > terms. > Amen to that (don=B9t ask me how I know) and super congrats Dan. DS -- Deneal Schilmeister http://homepage.mac.com/deneals/SL500.htm ________________________________________________________________________________
Date: Nov 02, 2008
Subject: Re: Sunset
We were kind of getting more and more concerned about your immediate situational awareness...forgetting to take that chock out on departure at Oklahoma City!! Congrats Big Boy! Cheers from Oz Russell PS Loved the Wormy Dog!! On 1/11/08 11:01 AM, "Dan Farmer" wrote: > Landies and Gentlemen: > > I was not going to mention this but all the talk about engines changed my > mind. > Today was my last day at American Airlines. I decided to retire early at 58 > for many reasons. Mostly after 31 years at American I want to do a different > type of flying and also if I worked past Nov 1 I would have taken a wack on my > retirement. The engine part is that after 36 years and about 18000 hours in > jets I have never had an engine failure. One time in a B52 we shut one down > for low oil pressure--WOW only 7 left, that is scary. > > IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) > > dan > > > > > 3D========================= > 3D======= > <3D"http://www.matronics.com/Navigator?Commander-List"> > 3D========================= > 3D======= > 3D========================= > 3D======= > <3D"http://www.matronics.com/contribution"> > 3D========================= > 3D======= > > ________________________________________________________________________________
Subject: Re: Sunset
Date: Nov 01, 2008
Congratulations Dan. Did they give you the firetruck arches or have they stopped that for cost reasons. I couldn't agree more about the "IF ITS NOT BOEING" I do like those airplanes, just like I like Commanders. I think Jim A. and I both agree, life is even better, no holiday trips or red eye specials. God Bless, Don ----- Original Message ----- From: Dan Farmer To: commander-list-digest(at)matronics.com Sent: Friday, October 31, 2008 9:31 PM Subject: Commander-List: Sunset Landies and Gentlemen: I was not going to mention this but all the talk about engines changed my mind. Today was my last day at American Airlines. I decided to retire early at 58 for many reasons. Mostly after 31 years at American I want to do a different type of flying and also if I worked past Nov 1 I would have taken a wack on my retirement. The engine part is that after 36 years and about 18000 hours in jets I have never had an engine failure. One time in a B52 we shut one down for low oil pressure--WOW only 7 left, that is scary. IF IT IS NOT BOEING I AM NOT GOING---unless it is a COMMANDER:-))) dan ________________________________________________________________________________
Subject: FUTURE OF AVIATION
Date: Nov 02, 2008
HI KIDS.... I have never before?entered the realm of politics with the Flight Group, but this year is crucial to the future of what brings us together, aviation.? AOPA has for years been fighting the good fight against higher cost and reduced access for GA airplanes.? They may?soon?be dealt a blow that they cant overcome.? As we prepare to vote for president this year PLEASE remember this.? Love him or hate him, George Bush IS NOT RUNNING!!!!!? John Mccain is.? John is a pilot, a naval aviator.? What you may not know is that his wife, Cindy, is also a pilot and the Maccain family operates a GA airplane.? Imagine having both the president and first lady GA PILOTS!!!!!!!!!!!!!!!!? But wait, it gets better.? Sarah Palin's husband, Todd, is also a private pilot with a current third class medical and the Palin family owns and operates a GA airplane, a Super Cub.? Sarah Palin comes from a state the literally survives on the wings of GA airplanes. There are many reasons to vote for an individual candidate, but I cant imagine not voting for a "Dream Team Ticket" like this for GA. The other candidate has PROMISED to raise taxes (and has a voting record to prove it)?on "the rich".? Do you suppose?he considers those who own their own airplane "rich".? Higher fuel taxes (as much as 600%) and user fees would almost certainly be in our future.? Backed by a?majority on both houses, it is likely that GA will be?not exist as we have known it.? He also said "I haven't spent the last six months in hotels and?ON AIRPLANES?to finish second" (paraphrasing). so we know how he thinks of aviation.? PLEASE, VOTE FOR MACCAIN/PALIN, VOTE SOON, VOTE OFTEN (those in Ohio)? Jim Metzger Director, Twin Commander Flight group.? 360-903-6901 ________________________________________________________________________________
Subject: Fwd: FUTURE OF AVIATION
Date: Nov 02, 2008
-----Original Message----- From: yourtcfg(at)aol.com Sent: Sun, 2 Nov 2008 3:32 pm Subject: FUTURE OF AVIATION HI KIDS.... I have never before?entered the realm of politics with the Flight Group, but this year is crucial to the future of what brings us together, aviation.? AOPA has for years been fighting the good fight against higher cost and reduced access for GA airplanes.? They may?soon?be dealt a blow that they cant overcome.? As we prepare to vote for president this year PLEASE remember this.? Love him or hate him, George Bush IS NOT RUNNING!!!!!? John Mccain is.? John is a pilot, a naval aviator.? What you may not know is that his wife, Cindy, is also a pilot and the Maccain family operates a GA airplane.? Imagine having both the president and first lady GA PILOTS!!!!!!!!!!!!!!!!? But wait, it gets better.? Sarah Palin's husband, Todd, is also a private pilot with a current third class medical and the Palin family owns and operates a GA airplane, a Super Cub.? Sarah Palin comes from a state the literally survives on the wings of GA airplanes. There are many reasons to vote for an individual candidate, but I cant imagine not voting for a "Dream Team Ticket" like this for GA. The other candidate has PROMISED to raise taxes (and has a voting record to prove it)?on "the rich".? Do you suppose?he considers those who own their own airplane "rich".? Higher fuel taxes (as much as 600%) and user fees would almost certainly be in our future.? Backed by a?majority on both houses, it is likely that GA will be?not exist as we have known it.? He also said "I haven't spent the last six months in hotels and?ON AIRPLANES?to finish second" (paraphrasing). so we know how he thinks of aviation.? PLEASE, VOTE FOR MACCAIN/PALIN, VOTE SOON, VOTE OFTEN (those in Ohio)? Jim Metzger Director, Twin Commander Flight group.? 360-903-6901 McCain or Obama? Stay up to date on the latest from the campaign trail with AOL News. ________________________________________________________________________________
Subject: FUTURE OF AVIATION??
Date: Nov 02, 2008
I don't know why the first posting got edited???? Sorry.? jb ________________________________________________________________________________
Date: Nov 02, 2008
Politics are such a large factor in our lives, especially in this election, that it is hard to keep it out of our regular discourse, such as the future of aviation and that a pilot may well be our commander-in-chief on Wednesday. Some folks still believe that it will be just business as usual after Tuesday. Regardless of who wins, this country will have to adapt to the threats that stack up against her from the outside and the inside. Forgive me for passing this along on this list, but the Christians among us may want to take a look at this http:www.acu.org/prayerchain.asp. Those who do not believe in Christ, folks, I still love you for the other bonds that keep us together which I cherish and treasure. Having been upfront about what can be expected at this link, you may choose to go or not to go there before you go there. As a wise old farmer once said, sometimes you get and sometimes you get got. This is not one of those. However you guys vote on Tuesday, vote wisely and vote so that you can live with it later. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Sunday, November 02, 2008 3:33 PM Subject: Commander-List: FUTURE OF AVIATION HI KIDS.... I have never before entered the realm of politics with the Flight Group, but this year is crucial to the future of what brings us together, aviation. AOPA has for years been fighting the good fight against higher cost and reduced access for GA airplanes. They may soon be dealt a blow that they cant overcome. As we prepare to vote for president this year PLEASE remember this. Love him or hate him, George Bush IS NOT RUNNING!!!!! John Mccain is. John is a pilot, a naval aviator. What you may not know is that his wife, Cindy, is also a pilot and the Maccain family operates a GA airplane. Imagine having both the president and first lady GA PILOTS!!!!!!!!!!!!!!!! But wait, it gets better. Sarah Palin's husband, Todd, is also a private pilot with a current third class medical and the Palin family owns and operates a GA airplane, a Super Cub. Sarah Palin comes from a state the literally survives on the wings of GA airplanes. There are many reasons to vote for an individual candidate, but I cant imagine not voting for a "Dream Team Ticket" like this for GA. 100000075x1212075880x1200752631/aol?redir=http://news.aol.com/elections?ncid =emlcntusnews00000001"> AOL News. ________________________________________________________________________________
Subject: FUTURE OF AVIATION #2
Date: Nov 02, 2008
I don't know why the first edited the last paragraph, please disregard the first one, sorry? jb ________________________________________________________________________________
Subject: possessed
Date: Nov 02, 2008
Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. ________________________________________________________________________________
Subject: Fwd: FUTURE OF AVIATION #2
Date: Nov 02, 2008
-----Original Message----- From: yourtcfg(at)aol.com Sent: Sun, 2 Nov 2008 4:33 pm Subject: FUTURE OF AVIATION #2 I don't know why the first edited the last paragraph, please disregard the first one, sorry? jb McCain or Obama? Stay up to date on the latest from the campaign trail with AOL News. ________________________________________________________________________________
Date: Nov 03, 2008
Subject: possessed
Or trying to give you a hint, Jim A _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM Subject: RE: Commander-List: possessed Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. ________________________________________________________________________________
Date: Nov 02, 2008
Fellow Commanders- One of the things that makes these United States a wonderful country is that a) we have the RIGHT to speak our mind, b) we have the OBLIGATION to respect other's opinions, and c) we get to vote at the local, state and federal levels to set direction for our nation. Unfortunately, in the age of 24hr media coverage many of us seem to focus on our rights without giving much thought to our obligations. This whole Red State/Blue State, My Guy vs. Your Guy, My Issue vs. Your Issue is creating a country completely polarized around the ends and soft in the middle. The partisanship of the past twenty years has caused an unfortunate majority of people to forget that some of us don't care where you are from, or what God you pray to, or what you think our national agenda should be. Why don't we care? Because you are a fellow American- and at the end of the day all that matters is that you love our country, participate positively in the process and don't close your mind or your ears to viewpoints other than your own. So with that being said, I'd like to politely request that we leave discussion of our national politics to discussion lists set up specifically for that purpose. Last I checked this list was for all of us Commander owners and enthusiasts to share knowledge and our love of the airplane.and "we Americans" aren't the only ones in the room. Whomever might win our election on Tuesday (or however many days afterward that it might take) it will not change the fact that Commander parts are hard to come by, hydraulic pumps will leak, occasionally some of us need sound advice from more experienced commander owners, or maybe we just some good old fashioned camaraderie based around a common interest. If you feel that you must tell the members of this list your political views: Put a McCain or Obama bumper sticker on your commander, and at the next Fly-In everyone will know how you voted. But please- let's leave this list for its primary purpose. Robert S. Randazzo N414C From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of nico css Sent: Sunday, November 02, 2008 4:05 PM Subject: RE: Commander-List: FUTURE OF AVIATION Politics are such a large factor in our lives, especially in this election, that it is hard to keep it out of our regular discourse, such as the future of aviation and that a pilot may well be our commander-in-chief on Wednesday. Some folks still believe that it will be just business as usual after Tuesday. Regardless of who wins, this country will have to adapt to the threats that stack up against her from the outside and the inside. Forgive me for passing this along on this list, but the Christians among us may want to take a look at this http:www.acu.org/prayerchain.asp <http://www.acu.org/prayerchain.asp> . Those who do not believe in Christ, folks, I still love you for the other bonds that keep us together which I cherish and treasure. Having been upfront about what can be expected at this link, you may choose to go or not to go there before you go there. As a wise old farmer once said, sometimes you get and sometimes you get got. This is not one of those. However you guys vote on Tuesday, vote wisely and vote so that you can live with it later. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Sunday, November 02, 2008 3:33 PM Subject: Commander-List: FUTURE OF AVIATION HI KIDS.... I have never before entered the realm of politics with the Flight Group, but this year is crucial to the future of what brings us together, aviation. AOPA has for years been fighting the good fight against higher cost and reduced access for GA airplanes. They may soon be dealt a blow that they cant overcome. As we prepare to vote for president this year PLEASE remember this. Love him or hate him, George Bush IS NOT RUNNING!!!!! John Mccain is. John is a pilot, a naval aviator. What you may not know is that his wife, Cindy, is also a pilot and the Maccain family operates a GA airplane. Imagine having both the president and first lady GA PILOTS!!!!!!!!!!!!!!!! But wait, it gets better. Sarah Palin's husband, Todd, is also a private pilot with a current third class medical and the Palin family owns and operates a GA airplane, a Super Cub. Sarah Palin comes from a state the literally survives on the wings of GA airplanes. There are many reasons to vote for an individual candidate, but I cant imagine not voting for a "Dream Team Ticket" like this for GA. 100000075x1212075880x1200752631/aol?redir=http://news.aol.com/elections?ncid =emlcntusnews00000001"> AOL News. href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com /Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 02, 2008
Subject: possessed
Well, you finally did it. - I could put up with a lot of BS on this website.....just for the sake of gl eaning some Aero Commander wisdom and insight.- - But Your Politics, Religion and Ignorance is too much.--- I quit. - wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A - From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-li st-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM Subject: RE: Commander-List: possessed - Is my Microsoft Word trying to tell me something? - Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. - - - ------- -- Please Support Your Lists This Month --- --------- (And Get Some AWESOME FREE Gifts!)November is t he Annual List Fund Raiser.- Click onthis year's Terrific Free Incentive Gifts!List Contribution Web Site:--> http://www.matronics.com/contributionT hank you for your generous support!------------- ---------------- -Matt Dralle, List Admin. --------- - The Commander-List Email Forum ---> http://ww w.matronics.com/Navigator?Commander-List----------- --- - MATRONICS WEB FORUMS - http://www.matronics.com/contribution =0A=0A=0A ________________________________________________________________________________
Subject: possessed
Date: Nov 02, 2008
I am truly sorry I offended you and others, Will. There is no doubt about who I am and what I stand for. No defense. When the moon is full, I get this way. And Tuesday is full moon. You can quit over my politics and my religion; it's sad but an acceptable reason, but don't mock my ignorance, please. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Sunday, November 02, 2008 6:05 PM Subject: RE: Commander-List: possessed Well, you finally did it. I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight. But Your Politics, Religion and Ignorance is too much. I quit. wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A _____ From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-list-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM Subject: RE: Commander-List: possessed Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!) November is the Annual List Fund Raiser. Click on this year's Terrific Free Incentive Gifts! List Contribution Web Site: --> http://www.matronics.com/contribution Thank you for your generous support! -Matt Dralle, List Admin. - The Commander-List Email Forum - --> http://www.matronics.com/Navigator?Commander-List - MATRONICS WEB FORUMS - http://www.matronics.com/contribution D======================== ========= D======================== ========= D======================== ========= D======================== ========= ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Subject: Re: FUTURE OF AVIATION
Date: Nov 02, 2008
Amen C-GISS ----- Original Message ----- From: Robert S. Randazzo To: commander-list(at)matronics.com Sent: Sunday, November 02, 2008 5:17 PM Subject: RE: Commander-List: FUTURE OF AVIATION Fellow Commanders- One of the things that makes these United States a wonderful country is that a) we have the RIGHT to speak our mind, b) we have the OBLIGATION to respect other's opinions, and c) we get to vote at the local, state and federal levels to set direction for our nation. Unfortunately, in the age of 24hr media coverage many of us seem to focus on our rights without giving much thought to our obligations. This whole Red State/Blue State, My Guy vs. Your Guy, My Issue vs. Your Issue is creating a country completely polarized around the ends and soft in the middle. The partisanship of the past twenty years has caused an unfortunate majority of people to forget that some of us don't care where you are from, or what God you pray to, or what you think our national agenda should be. Why don't we care? Because you are a fellow American- and at the end of the day all that matters is that you love our country, participate positively in the process and don't close your mind or your ears to viewpoints other than your own. So with that being said, I'd like to politely request that we leave discussion of our national politics to discussion lists set up specifically for that purpose. Last I checked this list was for all of us Commander owners and enthusiasts to share knowledge and our love of the airplane.and "we Americans" aren't the only ones in the room. Whomever might win our election on Tuesday (or however many days afterward that it might take) it will not change the fact that Commander parts are hard to come by, hydraulic pumps will leak, occasionally some of us need sound advice from more experienced commander owners, or maybe we just some good old fashioned camaraderie based around a common interest. If you feel that you must tell the members of this list your political views: Put a McCain or Obama bumper sticker on your commander, and at the next Fly-In everyone will know how you voted. But please- let's leave this list for its primary purpose. Robert S. Randazzo N414C From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of nico css Sent: Sunday, November 02, 2008 4:05 PM To: commander-list(at)matronics.com Subject: RE: Commander-List: FUTURE OF AVIATION Politics are such a large factor in our lives, especially in this election, that it is hard to keep it out of our regular discourse, such as the future of aviation and that a pilot may well be our commander-in-chief on Wednesday. Some folks still believe that it will be just business as usual after Tuesday. Regardless of who wins, this country will have to adapt to the threats that stack up against her from the outside and the inside. Forgive me for passing this along on this list, but the Christians among us may want to take a look at this http:www.acu.org/prayerchain.asp. Those who do not believe in Christ, folks, I still love you for the other bonds that keep us together which I cherish and treasure. Having been upfront about what can be expected at this link, you may choose to go or not to go there before you go there. As a wise old farmer once said, sometimes you get and sometimes you get got. This is not one of those. However you guys vote on Tuesday, vote wisely and vote so that you can live with it later. Nico ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Sunday, November 02, 2008 3:33 PM To: commander-list(at)matronics.com Subject: Commander-List: FUTURE OF AVIATION HI KIDS.... I have never before entered the realm of politics with the Flight Group, but this year is crucial to the future of what brings us together, aviation. AOPA has for years been fighting the good fight against higher cost and reduced access for GA airplanes. They may soon be dealt a blow that they cant overcome. As we prepare to vote for president this year PLEASE remember this. Love him or hate him, George Bush IS NOT RUNNING!!!!! John Mccain is. John is a pilot, a naval aviator. What you may not know is that his wife, Cindy, is also a pilot and the Maccain family operates a GA airplane. Imagine having both the president and first lady GA PILOTS!!!!!!!!!!!!!!!! But wait, it gets better. Sarah Palin's husband, Todd, is also a private pilot with a current third class medical and the Palin family owns and operates a GA airplane, a Super Cub. Sarah Palin comes from a state the literally survives on the wings of GA airplanes. There are many reasons to vote for an individual candidate, but I cant imagine not voting for a "Dream Team Ticket" like this for GA. 100000075x1212075880x1200752631/aol?redir=http://news.aol.com/elections ?ncid=emlcntusnews00000001"> AOL News. href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-Listhref="http://forums.matronics.com">h ttp://forums.matronics.com http://www.matronics.com/contributionhttp://www.matronics.com/Navigator?C ommander-Listhttp://forums.matronics.com ________________________________________________________________________________
Subject: Re: possessed
Date: Nov 02, 2008
Good grief, don't be silly, it's just a transgression, not worth quitting over. Tom. C-GISS ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Sunday, November 02, 2008 6:05 PM Subject: RE: Commander-List: possessed Well, you finally did it. I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight. But Your Politics, Religion and Ignorance is too much. I quit. wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed To: commander-list(at)matronics.com Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A ---------------------------------------------------------------------- From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-list-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM To: commander-list(at)matronics.com Subject: RE: Commander-List: possessed Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!)November is the Annual List Fund Raiser. Click onthis year's Terrific Free Incentive Gifts!List Contribution Web Site:--> http://www.matronics.com/contributionThank you for your generous support! -Matt Dralle, List Admin. - The Commander-List Email Forum ---> http://www.matronics.com/Navigator?Commander-List - MATRONICS WEB FORUMS - http://www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: possessed
Date: Nov 02, 2008
All, In this day and age of supreme political BS where the candidates will say anything to get elected, you have given me the final reason to vote for McCain and Palin. The previous reason to vote for them was because Obama pledged to raise the taxes on us individuals wealthy enough to own and fly Twin Commanders. On any of the other issues who knows where any of them stand? Don Falik -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of nico css Sent: Sunday, November 02, 2008 9:34 PM Subject: RE: Commander-List: possessed I am truly sorry I offended you and others, Will. There is no doubt about who I am and what I stand for. No defense. When the moon is full, I get this way. And Tuesday is full moon. You can quit over my politics and my religion; it's sad but an acceptable reason, but don't mock my ignorance, please. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Sunday, November 02, 2008 6:05 PM Subject: RE: Commander-List: possessed Well, you finally did it. I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight. But Your Politics, Religion and Ignorance is too much. I quit. wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A _____ From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-list-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM Subject: RE: Commander-List: possessed Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!) November is the Annual List Fund Raiser. Click on this year's Terrific Free Incentive Gifts! List Contribution Web Site: --> <http://www.matronics.com/contribution> http://www.matronics.com/contribution Thank you for your generous support! -Matt Dralle, List Admin. - The Commander-List Email Forum - --> <http://www.matronics.com/Navigator?Commander-List> http://www.matronics.com/Navigator?Commander-List - MATRONICS WEB FORUMS - <http://www.matronics.com/contribution> http://www.matronics.com/contribution 3D======================= 3D==================== href='3D"http://www.matronics.com/contribution"'>http://www.matronics.co m/contribution 3D======================= 3D==================== href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www. matronics.com/Navigator?Commander-List 3D======================= 3D==================== href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D======================= 3D==================== http://www.matronics.com/contribution http://www.matronics.com/Navigator?Commander-List ________________________________________________________________________________
Date: Nov 02, 2008
That thin skinned piss ant is likely one of those jerks that would laugh at the Sarah Palin hanging Halloween Decoration in California and call it art... I certainly hope to not have an Obomination of an election Tuesday! Oops! My spell check worked but I sent it anyway! Nico, I heard you on Rush a while back and you are brilliant. I'm sorry to disagree with you but, I'm NEVER sorry to offend those that need offending. Victor From: nico css Sent: Sunday, November 02, 2008 8:33 PM Subject: RE: Commander-List: possessed I am truly sorry I offended you and others, Will. There is no doubt about who I am and what I stand for. No defense. When the moon is full, I get this way. And Tuesday is full moon. You can quit over my politics and my religion; it's sad but an acceptable reason, but don't mock my ignorance, please. Nico ------------------------------------------------------------------------- ------- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Sunday, November 02, 2008 6:05 PM Subject: RE: Commander-List: possessed Well, you finally did it. I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight. But Your Politics, Religion and Ignorance is too much. I quit. wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed To: commander-list(at)matronics.com Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A ------------------------------------------------------------------------ From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-list-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM To: commander-list(at)matronics.com Subject: RE: Commander-List: possessed Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!)November is the Annual List Fund Raiser. Click onthis year's Terrific Free Incentive Gifts!List Contribution Web Site:--> http://www.matronics.com/contributionThank you for your generous support! -Matt Dralle, List Admin. - The Commander-List Email Forum ---> http://www.matronics.com/Navigator?Commander-List - MATRONICS WEB FORUMS - http://www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.c om/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www .matronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 02, 2008
Nico; You replied to my post about spam and then I basically got asked, " Do I smell spam burning"? I got the email he was referring too, and no it wasn't from me. Skin is kind of thin in my opinion, he can make pointed remarks about me and others and that is OK, but if someone appears to disagree with who he evidently supports, then, "I will take my ball and go home". He is entitled to his beliefs, I don't have a problem with that, we have all seen this in the past, but I can agree to disagree, without calling names, pouting and leaving in a huff. Most of us have disagreed with some posts in the past, big deal, we still remain civil and continue to post. I agree with Chris, many on this list have served this nation in uniform. We fought for our beliefs, and I for one will continue to due so, and that includes my religious beliefs which I hold very dear! Don ----- Original Message ----- From: nico css To: commander-list(at)matronics.com Sent: Sunday, November 02, 2008 9:33 PM Subject: RE: Commander-List: possessed I am truly sorry I offended you and others, Will. There is no doubt about who I am and what I stand for. No defense. When the moon is full, I get this way. And Tuesday is full moon. You can quit over my politics and my religion; it's sad but an acceptable reason, but don't mock my ignorance, please. Nico ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Sunday, November 02, 2008 6:05 PM To: commander-list(at)matronics.com Subject: RE: Commander-List: possessed Well, you finally did it. I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight. But Your Politics, Religion and Ignorance is too much. I quit. wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed To: commander-list(at)matronics.com Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A ---------------------------------------------------------------------- From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-list-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM To: commander-list(at)matronics.com Subject: RE: Commander-List: possessed Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!)November is the Annual List Fund Raiser. Click onthis year's Terrific Free Incentive Gifts!List Contribution Web Site:--> http://www.matronics.com/contributionThank you for your generous support! -Matt Dralle, List Admin. - The Commander-List Email Forum ---> http://www.matronics.com/Navigator?Commander-List - MATRONICS WEB FORUMS - http://www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.c om/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www .matronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ------------------------------------------------------------------------- ----- Checked by AVG - http://www.avg.com 10/28/2008 10:04 AM ________________________________________________________________________________
Date: Nov 03, 2008
BYE..............jb Well, you finally did it. ? I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight.? ? But Your Politics, Religion and Ignorance is too much.??? I quit. ? -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Sun, 2 Nov 2008 6:05 pm Subject: RE: Commander-List: possessed Well, you finally did it. ? I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight.? ? But Your Politics, Religion and Ignorance is too much.??? I quit. ? wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A ? From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-list-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM Subject: RE: Commander-List: possessed ? Is my Microsoft Word trying to tell me something? ? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. ? ? ? ? ?????? -- Please Support Your Lists This Month -- ?????????? (And Get Some AWESOME FREE Gifts!) November is the Annual List Fund Raiser.? Click on this year's Terrific Free Incentive Gifts! List Contribution Web Site: --> http://www.matronics.com/contribution Thank you for your generous support! ????????????????????????????? -Matt Dralle, List Admin. ????????? - The Commander-List Email Forum - --> http://www.matronics.com/Navigator?Commander-List ?????????????? - MATRONICS WEB FORUMS - http://www.matronics.com/contribution ________________________________________________________________________________
Date: Nov 03, 2008
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 03, 2008
Robert, I disagree with you. Too much at stake. Regards, Bob ________________________________ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Robert S. Randazzo Sent: Sunday, November 02, 2008 8:17 PM Subject: RE: Commander-List: FUTURE OF AVIATION Fellow Commanders- One of the things that makes these United States a wonderful country is that a) we have the RIGHT to speak our mind, b) we have the OBLIGATION to respect other's opinions, and c) we get to vote at the local, state and federal levels to set direction for our nation. Unfortunately, in the age of 24hr media coverage many of us seem to focus on our rights without giving much thought to our obligations. This whole Red State/Blue State, My Guy vs. Your Guy, My Issue vs. Your Issue is creating a country completely polarized around the ends and soft in the middle. The partisanship of the past twenty years has caused an unfortunate majority of people to forget that some of us don't care where you are from, or what God you pray to, or what you think our national agenda should be. Why don't we care? Because you are a fellow American- and at the end of the day all that matters is that you love our country, participate positively in the process and don't close your mind or your ears to viewpoints other than your own. So with that being said, I'd like to politely request that we leave discussion of our national politics to discussion lists set up specifically for that purpose. Last I checked this list was for all of us Commander owners and enthusiasts to share knowledge and our love of the airplane...and "we Americans" aren't the only ones in the room. Whomever might win our election on Tuesday (or however many days afterward that it might take) it will not change the fact that Commander parts are hard to come by, hydraulic pumps will leak, occasionally some of us need sound advice from more experienced commander owners, or maybe we just some good old fashioned camaraderie based around a common interest. If you feel that you must tell the members of this list your political views: Put a McCain or Obama bumper sticker on your commander, and at the next Fly-In everyone will know how you voted... But please- let's leave this list for its primary purpose. Robert S. Randazzo N414C From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of nico css Sent: Sunday, November 02, 2008 4:05 PM Subject: RE: Commander-List: FUTURE OF AVIATION Politics are such a large factor in our lives, especially in this election, that it is hard to keep it out of our regular discourse, such as the future of aviation and that a pilot may well be our commander-in-chief on Wednesday. Some folks still believe that it will be just business as usual after Tuesday. Regardless of who wins, this country will have to adapt to the threats that stack up against her from the outside and the inside. Forgive me for passing this along on this list, but the Christians among us may want to take a look at this http:www.acu.org/prayerchain.asp <http://www.acu.org/prayerchain.asp> . Those who do not believe in Christ, folks, I still love you for the other bonds that keep us together which I cherish and treasure. Having been upfront about what can be expected at this link, you may choose to go or not to go there before you go there. As a wise old farmer once said, sometimes you get and sometimes you get got. This is not one of those. However you guys vote on Tuesday, vote wisely and vote so that you can live with it later. Nico ________________________________ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Sunday, November 02, 2008 3:33 PM Subject: Commander-List: FUTURE OF AVIATION HI KIDS.... I have never before entered the realm of politics with the Flight Group, but this year is crucial to the future of what brings us together, aviation. AOPA has for years been fighting the good fight against higher cost and reduced access for GA airplanes. They may soon be dealt a blow that they cant overcome. As we prepare to vote for president this year PLEASE remember this. Love him or hate him, George Bush IS NOT RUNNING!!!!! John Mccain is. John is a pilot, a naval aviator. What you may not know is that his wife, Cindy, is also a pilot and the Maccain family operates a GA airplane. Imagine having both the president and first lady GA PILOTS!!!!!!!!!!!!!!!! But wait, it gets better. Sarah Palin's husband, Todd, is also a private pilot with a current third class medical and the Palin family owns and operates a GA airplane, a Super Cub. Sarah Palin comes from a state the literally survives on the wings of GA airplanes. There are many reasons to vote for an individual candidate, but I cant imagine not voting for a "Dream Team Ticket" like this for GA. 100000075x1212075880x1200752631/aol?redir=http://news.aol.com/elections ? ncid=emlcntusnews00000001"> AOL News. href="http://www.matronics.com/contribution">http://www.matronics.com/c h ref="http://www.matronics.com/Navigator?Commander-List">http://www.matr o nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com ________________________________________________________________________________
Subject: possessed
Date: Nov 03, 2008
Danger Will Robinson - Danger. Good grief - get a grip. ________________________________ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Sunday, November 02, 2008 9:05 PM Subject: RE: Commander-List: possessed Well, you finally did it. I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight. But Your Politics, Religion and Ignorance is too much. I quit. wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed To: commander-list(at)matronics.com Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A ________________________________ From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-list-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM Subject: RE: Commander-List: possessed Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!) November is the Annual List Fund Raiser. Click on this year's Terrific Free Incentive Gifts! List Contribution Web Site: --> http://www.matronics.com/contribution <http://www.matronics.com/contribution> Thank you for your generous support! -Matt Dralle, List Admin. - The Commander-List Email Forum - --> http://www.matronics.com/Navigator?Commander-List <http://www.matronics.com/Navigator?Commander-List> - MATRONICS WEB FORUMS - http://www.matronics.com/contribution <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Nov 03, 2008
You will not be missed. Bill ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Sunday, 02 November, 2008 20:05 Subject: RE: Commander-List: possessed Well, you finally did it. I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight. But Your Politics, Religion and Ignorance is too much. I quit. wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed To: commander-list(at)matronics.com Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A ---------------------------------------------------------------------- From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-list-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM To: commander-list(at)matronics.com Subject: RE: Commander-List: possessed Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!)November is the Annual List Fund Raiser. Click onthis year's Terrific Free Incentive Gifts!List Contribution Web Site:--> http://www.matronics.com/contributionThank you for your generous support! -Matt Dralle, List Admin. - The Commander-List Email Forum ---> http://www.matronics.com/Navigator?Commander-List - MATRONICS WEB FORUMS - http://www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 03, 2008
Well if the jackass wins I want all of you to keep working hard so he can re distribute your income to me cause I'm gonna quit working when everything is provided FREE by the guvmnt. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=212018#212018 ________________________________________________________________________________
Date: Nov 03, 2008
> That thin skinned piss ant is likely one of those jerks that would laugh at the Sarah Palin hanging Halloween Decoration in California and call it art... I certainly hope to not have an Obomination of an election Tuesday! Oops! My spell check worked but I sent it anyway! > > I don't know you but I am pretty certain I would enjoy getting drunk with you. Don't worry pissant if your guy wins you will not need any knowledge about Twin Commanders because no one will be able to afford to own or fly one. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=212021#212021 ________________________________________________________________________________
Date: Nov 03, 2008
Gosh Steve, I thought we had gotten you back on the right track and permanently pulled your head out of your butt. You are having a relapse? Only rumors about gas taxes? How about the candidate himself saying he is going to redistribute income because "it is fair" He himself says we are selfish if we wish to keep what we work for. His running mate has only contributed $3,000 to charity over the last several years out of the millions he has made. And I'm selfish? THIS GUY IS NUTS, HES DANGEROUS, AT BEST A SOCIALIST AND IN ALL LIKELIHOOD A COMMUNIST. READ THESE WORDS HE WILL DESTROY THIS COUNTRY with the help of naieve folks like you and the pissant. ps I won't hold your opinions against your company. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=212028#212028 ________________________________________________________________________________
From: "Moe-rosspistons" <moe-rosspistons(at)hotmail.com>
Date: Nov 03, 2008
Mr. Willis Robison, You sir, are very narrow minded, your judgment of others is a bit hasty, and you are intolerant to the extreme. Why do you feel so threatened by reading the opinions of others? This election will effect Commander owners more than anything that we have yet to discuss. The point here is, that if Obama wins we will have very little to discuss on the forum. Moe Mills N680RR 680Fp Proud Holder of The Golden Pedal Award From: willis robison Sent: Sunday, November 02, 2008 6:05 PM Subject: RE: Commander-List: possessed Well, you finally did it. I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight. But Your Politics, Religion and Ignorance is too much. I quit. wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed To: commander-list(at)matronics.com Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A ------------------------------------------------------------------------ From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-list-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM To: commander-list(at)matronics.com Subject: RE: Commander-List: possessed Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!)November is the Annual List Fund Raiser. Click onthis year's Terrific Free Incentive Gifts!List Contribution Web Site:--> http://www.matronics.com/contributionThank you for your generous support! -Matt Dralle, List Admin. - The Commander-List Email Forum ---> http://www.matronics.com/Navigator?Commander-List - MATRONICS WEB FORUMS - http://www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 03, 2008
Nico, No Apoligy is necessary. Some people can't stand the truth. You are right and he is wrong. Moe Mills N680RR 680Fp Proud Holder of The Golden Pedal Award From: nico css Sent: Sunday, November 02, 2008 6:33 PM Subject: RE: Commander-List: possessed I am truly sorry I offended you and others, Will. There is no doubt about who I am and what I stand for. No defense. When the moon is full, I get this way. And Tuesday is full moon. You can quit over my politics and my religion; it's sad but an acceptable reason, but don't mock my ignorance, please. Nico ------------------------------------------------------------------------- ------- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Sunday, November 02, 2008 6:05 PM Subject: RE: Commander-List: possessed Well, you finally did it. I could put up with a lot of BS on this website.....just for the sake of gleaning some Aero Commander wisdom and insight. But Your Politics, Religion and Ignorance is too much. I quit. wer. --- On Mon, 11/3/08, Jim Addington wrote: From: Jim Addington <jtaddington(at)verizon.net> Subject: RE: Commander-List: possessed To: commander-list(at)matronics.com Date: Monday, November 3, 2008, 5:06 PM Or trying to give you a hint, Jim A ------------------------------------------------------------------------ From: owner-commander-list-server(at)matronics.com [mailto: owner-commander-list-server(at)matronics.com ] On Behalf Of nico css Sent: Sunday, November 02, 2008 6:52 PM To: commander-list(at)matronics.com Subject: RE: Commander-List: possessed Is my Microsoft Word trying to tell me something? Whenever I type Obama my spellchecker suggests Osama. It must be broken. I don't know. -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!)November is the Annual List Fund Raiser. Click onthis year's Terrific Free Incentive Gifts!List Contribution Web Site:--> http://www.matronics.com/contributionThank you for your generous support! -Matt Dralle, List Admin. - The Commander-List Email Forum ---> http://www.matronics.com/Navigator?Commander-List - MATRONICS WEB FORUMS - http://www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.c om/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www .matronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Recent Postings
Date: Nov 03, 2008
Hi All, No doubt if Matt Dralle experiences a large upsurge of new subscribers to our Chatlist, it will be people Worldwide switching from watching NASCAR racing, in order to cure their insomnia. I know you've all got more pressing matters on your minds right now, but a few messages of congratulations to Lewis Hamilton will not go amiss. Best Regards, Barry ________________________________________________________________________________
Date: Nov 03, 2008
And the guy who bet 10 years ago that he would win it, collected 165,000 quid. _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Barry Collman Sent: Monday, November 03, 2008 7:01 AM Subject: Commander-List: Recent Postings Hi All, No doubt if Matt Dralle experiences a large upsurge of new subscribers to our Chatlist, it will be people Worldwide switching from watching NASCAR racing, in order to cure their insomnia. I know you've all got more pressing matters on your minds right now, but a few messages of congratulations to Lewis Hamilton will not go amiss. Best Regards, Barry ________________________________________________________________________________
Date: Nov 03, 2008
Milt, nothing I could say would make you think my head wasn't still up my butt. So I won't try too awful hard. I'm tired of being lied to by both sides. Arguements are pushed to ridiculus extremes. Facts don't matter. And now we pick our news sources that tell us what we already believe. (An email is not a news source.) Pick the most extreme lefty or righty, and knock down a straw man. Our government over the last eight years has been incompetant (and in many ways radical). Genuine old-time conservatives have been abandoning the current policies and party in droves. Most of those conservatives a lot smarter than I am. I don't believe Obama's nuts. I don't believe he's a commie. If he governs from the center, and listens to dissenting opinions, he might just do ok. Steve ----- Original Message ----- From: "N395V" <Bearcat(at)bearcataviation.com> Sent: Monday, November 03, 2008 8:36 AM Subject: Commander-List: Re: FUTURE OF AVIATION > > > Gosh Steve, I thought we had gotten you back on the right track and > permanently pulled your head out of your butt. You are having a relapse? > > Only rumors about gas taxes? > > How about the candidate himself saying he is going to redistribute income > because "it is fair" > > He himself says we are selfish if we wish to keep what we work for. > > His running mate has only contributed $3,000 to charity over the last > several years out of the millions he has made. And I'm selfish? > > THIS GUY IS NUTS, HES DANGEROUS, AT BEST A SOCIALIST AND IN ALL LIKELIHOOD > A COMMUNIST. > > READ THESE WORDS HE WILL DESTROY THIS COUNTRY with the help of naieve > folks like you and the pissant. > > ps I won't hold your opinions against your company. > > -------- > Milt > 2003 F1 Rocket > 2006 Radial Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=212028#212028 > > > ________________________________________________________________________________
Date: Nov 03, 2008
bc=2C i agree. kudos to mr hamilton on a job well done and w/ class. gmc From: nico(at)cybersuperstore.comTo: commander-list(at)matronics.comSubject: RE: Commander-List: Recent PostingsDate: Mon=2C 3 Nov 2008 07:14:14 -0800 And the guy who bet 10 years ago that he would win it=2C collected 165=2C00 0 quid. From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of Barry CollmanSent: Monday=2C November 03=2C 2008 7:01 AMTo: commander-list(at)matronics.comSubject: Commander-List: Recent Postings Hi All=2C No doubt if Matt Dralle experiences a large upsurge of new subscribers to o ur Chatlist=2C it will be people Worldwide switching from watching NASCAR r acing=2C in order to cure their insomnia. I know you've all got more pressing matters on your minds right now=2C but a few messages of congratulations to Lewis Hamilton will not go amiss. Best Regards=2C Barry href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Commander-List">http://www.matroni cs.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: FW: An Obituary printed in the London Times
Date: Nov 03, 2008
----=_NextPart_000_0016_01C93D38.D9B94370-- ________________________________________________________________________________
Subject: Re: Recent Postings
Date: Nov 03, 2008
Well, anyone who placed such a bet when Lewis was aged just 13 must have had a crystal ball. I can only imagine what must be going through the guy's mind when Lewis lost the necessary 5th place only to retrieve it again, with a matter of just a few hundred yards to go, in the last of a season of 18 races that totalled over 3,120 miles. If the script for this season's F1 Championship had been a movie, everyone would say it was too far-fetched. A truly amazing end to the F1 Championship. Best Regards, Barry ----- Original Message ----- From: nico css To: commander-list(at)matronics.com Sent: Monday, November 03, 2008 3:14 PM Subject: RE: Commander-List: Recent Postings And the guy who bet 10 years ago that he would win it, collected 165,000 quid. ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Barry Collman Sent: Monday, November 03, 2008 7:01 AM To: commander-list(at)matronics.com Subject: Commander-List: Recent Postings Hi All, No doubt if Matt Dralle experiences a large upsurge of new subscribers to our Chatlist, it will be people Worldwide switching from watching NASCAR racing, in order to cure their insomnia. I know you've all got more pressing matters on your minds right now, but a few messages of congratulations to Lewis Hamilton will not go amiss. Best Regards, Barry href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 03, 2008
"With Class" - You're so right Mason. He is truly a role model to all youngsters and a credit to his family and Country. If only they were all like him, instead of the knife-wielding mindless thugs who prevail nowadays, the World would be a far nicer place. ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list(at)matronics.com Sent: Monday, November 03, 2008 3:28 PM Subject: RE: Commander-List: Recent Postings bc, i agree. kudos to mr hamilton on a job well done and w/ class. gmc ------------------------------------------------------------------------- ----- From: nico(at)cybersuperstore.com To: commander-list(at)matronics.com Subject: RE: Commander-List: Recent Postings Date: Mon, 3 Nov 2008 07:14:14 -0800 And the guy who bet 10 years ago that he would win it, collected 165,000 quid. ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Barry Collman Sent: Monday, November 03, 2008 7:01 AM To: commander-list(at)matronics.com Subject: Commander-List: Recent Postings Hi All, No doubt if Matt Dralle experiences a large upsurge of new subscribers to our Chatlist, it will be people Worldwide switching from watching NASCAR racing, in order to cure their insomnia. I know you've all got more pressing matters on your minds right now, but a few messages of congratulations to Lewis Hamilton will not go amiss. Best Regards, Barry ________________________________________________________________________________
Date: Nov 04, 2008
Milt, I usually put my foot in my mouth up to the knee but Obama does not scare me, he terrifies me. The damage his thinking and with the help of his friends will destroy the country. He has said he would side with the Muslims if it came down to it. That should be enough but then when he has said he will reduce the military which would tell the world we are weak. He plans to take the money from people that have worked hard and worried and sweated to make and give it to people that are too lazy to work. I have seen several clips where groups of people have been ask what he has accomplished and no one could come up with any thing. He would rarely vote for anything unless it was extremely liberal and the rest of the time he would just vote here. He won't put his hand over his heart when the pledge of allegiance is said and will not wear an American flag on his coat. Sorry I got wound up but when it comes to my country I do real fast. I spent my time in the Air Force and although I am too old now I would still do what I could to protect this country. Jim A -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of N395V Sent: Monday, November 03, 2008 7:36 AM Subject: Commander-List: Re: FUTURE OF AVIATION Gosh Steve, I thought we had gotten you back on the right track and permanently pulled your head out of your butt. You are having a relapse? Only rumors about gas taxes? How about the candidate himself saying he is going to redistribute income because "it is fair" He himself says we are selfish if we wish to keep what we work for. His running mate has only contributed $3,000 to charity over the last several years out of the millions he has made. And I'm selfish? THIS GUY IS NUTS, HES DANGEROUS, AT BEST A SOCIALIST AND IN ALL LIKELIHOOD A COMMUNIST. READ THESE WORDS HE WILL DESTROY THIS COUNTRY with the help of naieve folks like you and the pissant. ps I won't hold your opinions against your company. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=212028#212028 ________________________________________________________________________________
Date: Nov 03, 2008
Actually I think our founding fathers would be quite satisfied with how things are working. We're still here, after 232 years. Not Rome yet, but we're still chugging along. The Constitution is still our governing document. We're still (barely) managing to maintain the separation of church & state. And no matter how bad things are, the guy in charge can only continue it for a maximum of 8 years....and then he's ineligible to run for office again. Obama wins and you don't like it? No problem, we can vote him out in 2012. Or he's gone for good anyway in 2016. There is ALWAYS a "sky is falling" mentality, and the media perpetuates it. In 1985 when I got my first car loan, the interest rate on it was 12.5% through a major lender. Fallout from the Carter era? The last great socialist who won the office on a platform of "Change?" He lasted one term and we hastily voted him out on his ass. Clinton was going to ruin the country too, I recall. He did institute the assault weapon ban, which really upset many competitive shooters like myself, but when he left office we had a budget SURPLUS....which GWB spent in about a year. This never ends. Go back a ways....how'd Calvin Coolidge do? His policies essentially resulted in the Great Depression. And wow, we survived that too. I'm a fiscal conservative. I'm a registered Republican. I own my own business, and it's probably going to be a target of Obama's tax policies, so I have that to look forward to. GA is going to suffer as well. But 4 years from now, there will still be capitalism, still be airplanes, and still be pilots, rich and poor. The only change will be who occupies the oval office. I also view the mainstream media as mildly entertaining fiction. Good for an hour of yuks at night, but that's about it. Weather the storm. VOTE. And be vocal on the local and state level where the people who need YOUR votes might actually be able to do something. This will be my only opinion post. I'll continue to judiciously use the delete button on my Commander List emails for the ones that don't interest me. This will also be my only plea to get everyone to VOTE TOMORROW. Regardless of what anybody tells you, your vote STILL DOES MATTER. Cheers, /John Jim Addington wrote: > > Milt, > I usually put my foot in my mouth up to the knee but Obama does not scare > me, he terrifies me. The damage his thinking and with the help of his > friends will destroy the country. He has said he would side with the Muslims > if it came down to it. That should be enough but then when he has said he > will reduce the military which would tell the world we are weak. He plans to > take the money from people that have worked hard and worried and sweated to > make and give it to people that are too lazy to work. I have seen several > clips where groups of people have been ask what he has accomplished and no > one could come up with any thing. He would rarely vote for anything unless > it was extremely liberal and the rest of the time he would just vote here. > He won't put his hand over his heart when the pledge of allegiance is said > and will not wear an American flag on his coat. > Sorry I got wound up but when it comes to my country I do real fast. I spent > my time in the Air Force and although I am too old now I would still do what > I could to protect this country. > Jim A > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of N395V > Sent: Monday, November 03, 2008 7:36 AM > To: commander-list(at)matronics.com > Subject: Commander-List: Re: FUTURE OF AVIATION > > > Gosh Steve, I thought we had gotten you back on the right track and > permanently pulled your head out of your butt. You are having a relapse? > > Only rumors about gas taxes? > > How about the candidate himself saying he is going to redistribute income > because "it is fair" > > He himself says we are selfish if we wish to keep what we work for. > > His running mate has only contributed $3,000 to charity over the last > several years out of the millions he has made. And I'm selfish? > > THIS GUY IS NUTS, HES DANGEROUS, AT BEST A SOCIALIST AND IN ALL LIKELIHOOD A > COMMUNIST. > > READ THESE WORDS HE WILL DESTROY THIS COUNTRY with the help of naieve folks > like you and the pissant. > > ps I won't hold your opinions against your company. > > -------- > Milt > 2003 F1 Rocket > 2006 Radial Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=212028#212028 > > > ________________________________________________________________________________
Date: Nov 03, 2008
Subject: Re: Please Make a Contribution to Support Your Lists...
Hi Matt Please remove me from your list I no longer own a commander. I have enjoyed all the info that i reviewed while I owned a commander. Thanks Rocky In a message dated 11/3/2008 12:19:36 A.M. Pacific Standard Time, dralle(at)matronics.com writes: --> Commander-List message posted by: Matt Dralle Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! ________________________________________________________________________________
Date: Nov 03, 2008
Great post, John. I sat in church yesterday and the pastor preached pretty much the same thing. Oh, I won't quit because of this. Sorry about that. Nico -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vormbaum Sent: Monday, November 03, 2008 8:53 AM Subject: Re: Commander-List: Re: FUTURE OF AVIATION Actually I think our founding fathers would be quite satisfied with how things are working. We're still here, after 232 years. Not Rome yet, but we're still chugging along. The Constitution is still our governing document. We're still (barely) managing to maintain the separation of church & state. And no matter how bad things are, the guy in charge can only continue it for a maximum of 8 years....and then he's ineligible to run for office again. Obama wins and you don't like it? No problem, we can vote him out in 2012. Or he's gone for good anyway in 2016. There is ALWAYS a "sky is falling" mentality, and the media perpetuates it. In 1985 when I got my first car loan, the interest rate on it was 12.5% through a major lender. Fallout from the Carter era? The last great socialist who won the office on a platform of "Change?" He lasted one term and we hastily voted him out on his ass. Clinton was going to ruin the country too, I recall. He did institute the assault weapon ban, which really upset many competitive shooters like myself, but when he left office we had a budget SURPLUS....which GWB spent in about a year. This never ends. Go back a ways....how'd Calvin Coolidge do? His policies essentially resulted in the Great Depression. And wow, we survived that too. I'm a fiscal conservative. I'm a registered Republican. I own my own business, and it's probably going to be a target of Obama's tax policies, so I have that to look forward to. GA is going to suffer as well. But 4 years from now, there will still be capitalism, still be airplanes, and still be pilots, rich and poor. The only change will be who occupies the oval office. I also view the mainstream media as mildly entertaining fiction. Good for an hour of yuks at night, but that's about it. Weather the storm. VOTE. And be vocal on the local and state level where the people who need YOUR votes might actually be able to do something. This will be my only opinion post. I'll continue to judiciously use the delete button on my Commander List emails for the ones that don't interest me. This will also be my only plea to get everyone to VOTE TOMORROW. Regardless of what anybody tells you, your vote STILL DOES MATTER. Cheers, /John Jim Addington wrote: > --> > > Milt, > I usually put my foot in my mouth up to the knee but Obama does not > scare me, he terrifies me. The damage his thinking and with the help > of his friends will destroy the country. He has said he would side > with the Muslims if it came down to it. That should be enough but then > when he has said he will reduce the military which would tell the > world we are weak. He plans to take the money from people that have > worked hard and worried and sweated to make and give it to people that > are too lazy to work. I have seen several clips where groups of people > have been ask what he has accomplished and no one could come up with > any thing. He would rarely vote for anything unless it was extremely liberal and the rest of the time he would just vote here. > He won't put his hand over his heart when the pledge of allegiance is > said and will not wear an American flag on his coat. > Sorry I got wound up but when it comes to my country I do real fast. I > spent my time in the Air Force and although I am too old now I would > still do what I could to protect this country. > Jim A > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of N395V > Sent: Monday, November 03, 2008 7:36 AM > To: commander-list(at)matronics.com > Subject: Commander-List: Re: FUTURE OF AVIATION > > --> > > Gosh Steve, I thought we had gotten you back on the right track and > permanently pulled your head out of your butt. You are having a relapse? > > Only rumors about gas taxes? > > How about the candidate himself saying he is going to redistribute > income because "it is fair" > > He himself says we are selfish if we wish to keep what we work for. > > His running mate has only contributed $3,000 to charity over the last > several years out of the millions he has made. And I'm selfish? > > THIS GUY IS NUTS, HES DANGEROUS, AT BEST A SOCIALIST AND IN ALL > LIKELIHOOD A COMMUNIST. > > READ THESE WORDS HE WILL DESTROY THIS COUNTRY with the help of naieve > folks like you and the pissant. > > ps I won't hold your opinions against your company. > > -------- > Milt > 2003 F1 Rocket > 2006 Radial Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=212028#212028 > > > ________________________________________________________________________________
Date: Nov 03, 2008
Nico, you have no need to apologize, especially to me. Ive followed your comments in the past and have no problem with them, per se. However. I shouldn't have signed off so bluntly, and without explaining myself. For that I owe you an apology. The following is a more apt description of my intent. "Victor". I could care less about your opinion. I didn't sign up to listen to you Bull-Shit about politics, religion or anything else for that matter. This is probably the only forum you have that will allow you vent your spleen. I don't care if you are baptist,Muslim, Hindu or catholic. I don't care if you are Rush Limbaugh's Valium connection I don't care if you vote for McCain, Obama, Anglea Davis or Adolph Hitler. IMHO, as a nation, we are in deep Sununu, regardless of candidate, and Ill still stand to defend it. I also don't care what you ate for breakfast for that matter. It irrelevant to This Forum. What I do care about, is that you've chosen to debase the value and integrity of the Commander List and insulted everyone intelligence. Every time you espouse your "beliefs", ridicule or denigrate the efforts of others trying to provide, improve and maintain a wholesome a beneficial forum such as this, You are slowly destroying the thing you say you defend. Yeah, I'm pissed off. I was pissed off IN Vietnam and IN Korea. I get pissed off, every time people say they are patriotic out one side their mouth, and then simultaneously set about to destroy the freedoms (like the commander-list) simply to make themselves look good in the 'eyes' of others. You are a sycophant obfuscating the good nature of these people, just to make yourself feel good. I could care less. Thin- skinned. YOU BET , I AM and tired of defending twits who work thier Mouths more than thier Backs. I encourage you to vote. Just keep the results and your opinion to yourself. If you want to voice your political believes, find a forum for that. Hell, Call Rush, I'm sure he'd be glad to hear his palaver read back to him. If you want to voice your relilgious beliefs....go to church. If you just want to rant.....rant to your wife (or significant other, if you are of that persuasion) or just kick the dog. Just keep it out of the list. If the moderator had any Huevos, he would have cut off the discussion as required by the by-laws. Instead, by allowing your little "Freedom of Speech" He's allowed the list to become polarized. In the future, I hope he does a better job at filter out the crap. Gentlemen, if you have any questions regarding the health, maintenance or improvement of anything Aero Commander Related, it would be a pleasure to share that information with you. Willis E. Robison, Ph.D., P.E. Aerospace former USAF, 803rd Combat support Group and 555 Tactical Fighter wing. Ret. Hamilton Sundstrand/PWC "That thin skinned piss ant........... offend those that need offending. Victor " Read this topic online here: http://forums.matronics.com/viewtopic.php?p=212162#212162 ________________________________________________________________________________
Date: Nov 03, 2008
WER, You made this forum what it is currently by your adverse reaction to an opinion written by a member. I think your reaction was initially very succinct and honest. When others disagreed with your position you chose to get typically nasty, as many with your views do. Then, you chose to get angry, say not so nice things about someone and then be untruthful about the "I don't care ifs..................." . Of course you do! You care about all things that are not of your side of the aisle. Thank God (who is still among US) for Victor and the others who voiced their opinions regarding your resignation from the Commander Group. Since this is still a free country Victor exercised the same rights you did.....You chose to leave and he chose to stay. Pretty simple to me! I'm 75 years of age and I can tell anyone that Korea and Vietnam are not strange places to me. But your diatribe on this subject seems like you think this country is a one-view place. Victor and I are entitled to our views and opinions, regardless of how others see things. I don't know Victor but I'm certain he is capable of expressing his views in many "forums". In your name-calling paragraph you left out the most commonly used term to describe someone who is not of your political leaning....hypocrites. This is used quite often by your folks to describe my folks whenever you cannot achieve a sophisticated communicative term that you hope you spell correctly. Now, here is my position in all this. I love God I love my Country I love my Commanders I love that I get to vote tomorrow I love that you get to vote tomorrow I think our forum is just fine and it really suits me, since I have the mechanical aptitude of a post. I am also happy to know I can call you whenever I need to have a solution to a pending problem. Respectfully, Buddy A. Plaster, Ph.D, MS, MA, In a message dated 11/3/2008 3:31:44 P.M. Pacific Standard Time, drwer2(at)yahoo.com writes: --> Commander-List message posted by: "drwer2" Nico, you have no need to apologize, especially to me. Ive followed your comments in the past and have no problem with them, per se. However. I shouldn't have signed off so bluntly, and without explaining myself. For that I owe you an apology. The following is a more apt description of my intent. "Victor". I could care less about your opinion. I didn't sign up to listen to you Bull-Shit about politics, religion or anything else for that matter. This is probably the only forum you have that will allow you vent your spleen. I don't care if you are baptist,Muslim, Hindu or catholic. I don't care if you are Rush Limbaugh's Valium connection I don't care if you vote for McCain, Obama, Anglea Davis or Adolph Hitler. IMHO, as a nation, we are in deep Sununu, regardless of candidate, and Ill still stand to defend it. I also don't care what you ate for breakfast for that matter. It irrelevant to This Forum. What I do care about, is that you've chosen to debase the value and integrity of the Commander List and insulted everyone intelligence. Every time you espouse your "beliefs", ridicule or denigrate the efforts of others trying to provide, improve and maintain a wholesome a beneficial forum such as this, You are slowly destroying the thing you say you defend. Yeah, I'm pissed off. I was pissed off IN Vietnam and IN Korea. I get pissed off, every time people say they are patriotic out one side their mouth, and then simultaneously set about to destroy the freedoms (like the commander-list) simply to make themselves look good in the 'eyes' of others. You are a sycophant obfuscating the good nature of these people, just to make yourself feel good. I could care less. Thin- skinned. YOU BET , I AM and tired of defending twits who work thier Mouths more than thier Backs. I encourage you to vote. Just keep the results and your opinion to yourself. If you want to voice your political believes, find a forum for that. Hell, Call Rush, I'm sure he'd be glad to hear his palaver read back to him. If you want to voice your relilgious beliefs....go to church. If you just want to rant.....rant to your wife (or significant other, if you are of that persuasion) or just kick the dog. Just keep it out of the list. If the moderator had any Huevos, he would have cut off the discussion as required by the by-laws. Instead, by allowing your little "Freedom of Speech" He's allowed the list to become polarized. In the future, I hope he does a better job at filter out the crap. Gentlemen, if you have any questions regarding the health, maintenance or improvement of anything Aero Commander Related, it would be a pleasure to share that information with you. Willis E. Robison, Ph.D., P.E. Aerospace former USAF, 803rd Combat support Group and 555 Tactical Fighter wing. Ret. Hamilton Sundstrand/PWC "That thin skinned piss ant........... offend those that need offending. Victor " Read this topic online here: http://forums.matronics.com/viewtopic.php?p=212162#212162 **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! ________________________________________________________________________________
Date: Nov 03, 2008
Subject: Apology to all
BudPlaster,- You are so right.- I owe you (and the list members) an apo logy.- I should have not taken the list rules so literally and I should h ave shown more patience in responding.- I'll not do that again.- Must h ave had too much Geritol. - again....sorry for the headaches. - drwer2 - -=0A=0A=0A ________________________________________________________________________________
Date: Nov 03, 2008
Thank you, Will. This list's members are a small band of brothers (no sexism intended) who have transcended their differences. I apologized early on, having been slapped into humility on many occasions; the same humility that keeps us alive in the cockpit. Welcome home. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Monday, November 03, 2008 6:43 PM Subject: Commander-List: Apology to all BudPlaster, You are so right. I owe you (and the list members) an apology. I should have not taken the list rules so literally and I should have shown more patience in responding. I'll not do that again. Must have had too much Geritol. again....sorry for the headaches. drwer2 D======================== ========= D======================== ========= D======================== ========= D======================== ========= ________________________________________________________________________________
Date: Nov 04, 2008
Subject: Props for sale: HC-93Z20-2C1/10151-8R
Howdy gentlemen=2C Am trying to help a friend of mine move some props so he can continue on a twin-bo project=2E (No accounting for taste=2E) Mena Aircraft Propellers of Arkansas 0 timed these HC-93Z20-2C1/10151-8R props in May of 2007=2E They are currently with him in the Dallas area=2E Never installed=2C still packed=2E He=92s looking for =2416=2C000 for the pair=2C so if anyone out there is ready to do Jim=92s STC=2C there=92s no waiting involved=2E I can=92t say I=92m just being a good friend here=2C once he sells his p rops he=92ll be able to buy some parts I have that he wants! I can be contacted at 907-223-1841 or cjoens=40gci=2Enet Thanks guys=2C Chris Joens ________________________________________________________________________________
Date: Nov 05, 2008
Subject: List Fund Raiser
A couple of years ago I implemented an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, he or she will instantly cease to receive these Fund Raiser messages for the rest of the month! Its just that simple. Don't you wish PBS worked that way! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site like this. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 05, 2008
Subject: 680F cruise performance
Gentlemen, - Are there any active members that own a AC 680F?-- Im estimating a ferr y flight and need the best altitude/fuel burn and could really use your exp erience. - thanks. - wer - -=0A=0A=0A ________________________________________________________________________________
Subject: James Bond
Date: Nov 05, 2008
Has anyone seen the Commander in the James Bond movie trailer Quantum of Solace? It appears very briefly in the background of one of the scenes. ________________________________________________________________________________
Subject: Re: James Bond
Date: Nov 06, 2008
With winglets no less!!? jb Has anyone seen the Commander in the James Bond movie trailer Quantum of Solace? It appears very briefly in the background of one of the scenes. -----Original Message----- From: nico css <nico(at)cybersuperstore.com> Sent: Wed, 5 Nov 2008 10:03 pm Subject: RE: Commander-List: James Bond Has anyone seen the Commander in the James Bond movie trailer Quantum of Solace? It appears very briefly in the background of one of the scenes. ? ________________________________________________________________________________
Subject: Re: 680F cruise performance
Date: Nov 06, 2008
Above 10K, 200kts @55GPH.? jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, ? Are there any active members that own a AC 680F??? Im estimating a ferry flight and need the best altitude/fuel burn and could really use your experience. ? thanks. ? wer ? ? ________________________________________________________________________________
From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net>
Date: Nov 06, 2008
I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH. jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, Are there any active members that own a AC 680F? Im estimating a ferry flight and need the best altitude/fuel burn and could really use your experience. thanks. wer > _____ ________________________________________________________________________________
Date: Nov 06, 2008
Thanks Randy, JB.- Thats- sounds reasonable for a low-level flight. - Do you guys every fly on oxy?- I would think your economy would be much b etter at a higher altitude.- And with oodles of power to get there quickl y, it should be a snap.- I guess with the Time to climb and then let down , that may not be cost-effective. - wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA <rcdettmer(at)charter.net> Subject: RE: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 6:29 AM I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. - Randy Dettmer, AIA, NCARB 680F / N6253X - - Dettmer Architecture 663 Hill Street San Luis Obispo, CA - 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com - From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM Subject: Re: Commander-List: 680F cruise performance - Above 10K, 200kts @55GPH.- jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance
October 27, 2008 - November 06, 2008
Commander-Archive.digest.vol-de
