Kolb-Archive.digest.vol-hl
April 21, 2008 - May 05, 2008
      http://forums.matronics.com/viewtopic.php?p=178266#178266
Subject: Re: Monument Valley 2008 Photo Contest
Date: Apr 21, 2008
Rick: What did you do to this yoyo to make him want to kill you on take off? Please notice the highly observant spectators on the other side of the runway. Steven Green is the only one watching the near disastor, while Karen Cottrell and John Hauck are watching Arty Trost untangle her headset cord. john h mkIII-I miss all the fun. Drifter taking aim at..... ME!!! Rick Neilsen ________________________________________________________________________________
Subject: Re: expert in everything
Date: Apr 21, 2008
> I'm not selling them and have never owned one but if it every comes time for me to replace my BRS, it will be with the spring-launched one. > > -------- > Thom Riddle Thom R: How well does the spring loaded lauch compare with the solid rocket launch of the BRS? john h mkIII ________________________________________________________________________________
Date: Apr 21, 2008
Subject: Re: Flew my Kolb Mark II Twinstar for the 1st time this
morning! At 05:40 PM 4/21/2008, cristalclear13 wrote: >I'm using a handheld radio and I was about 2000 ft up and I heard someone >but I mostly heard >static. I hear things fine on the ground at the airport. Do I need an >extension for the antenna maybe? You might... is it ignition noise? Things to try first are adjusting the squelch, turning on the "ANR" function if your radio has it (my Icom does and it helps a lot), and using resistor plugs if you aren't already. I had to do all those things on mine, then I needed to remote the antenna not to eliminate static but to eliminate a horrible feedback squeal when I transmitted using my helmet mike. Oh yeah, congrats! -Dana -- Growing old is inevitable, but we can stay immature indefinitely. ________________________________________________________________________________
From: "John Williamson" <kolbrapilot1(at)tx.rr.com>
Date: Apr 21, 2008
All possible Contestants: The hired Judges from EAA Chapter 34 have asked that a few things be clarified and modified for the Monument Valley 2008 Photo Contest. 1. Submit your photo from past Monument Valley trips to be judged here for the awards of "Best MV Kolb Photo". Three categories have been established: Scenery, Scenery with Airplane and Scenery with Kolbers. Winners will be from each category. If you attended one of our Gatherings at MV, then you are a Kolber. 2. Photos have to be posted in this thread as a reply. 3. Include a short description of the photo. 4. Photos have to have been taken by the submitter or with their permission. 5. You can submit more than one photo to be judged in each of the 3 categories 6. Photos have to have been taken by someone flying at MV or building a Kolb or a Kolber or a family member of a Kolber. 7. Submit photos that are at least 600 pixels wide but not more than 2000 pixels wide. Rules will be strictly adhered to in order for the winners to be declared. Photos submitted before this post to another Topic have been carried over and will be judged. All photos submitted before 2400 hours, 12 May 2008 will be considered. Results of the Monument Valley 2008 Photo Contest will be announced on the Monument Valley Airport flightline Friday, 16 May 2008 at 1700 hours. The bar has been set very high for this Contest folks, so post your best and good luck. -------- John Williamson Arlington, TX Kolbra, 912ULS, 1595 hours http://home.tx.rr.com/kolbrapilot Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178277#178277 ________________________________________________________________________________
morning!
Date: Apr 21, 2008
>>I'm using a handheld radio and I was about 2000 ft up and I heard someone >>but I mostly heard >>static. I hear things fine on the ground at the airport. Do I need an >>extension for the antenna maybe? First, I'd do a search of the Kolb List Archives. There is more info there than you will ever need to get your radio to work successfully. john h mkIII ________________________________________________________________________________
Date: Apr 21, 2008
Subject: Re: UltraStar
HI Ray. Jim here. My UltraStar is in good condition the motor has 175 hrs on a 300 hr rebuild. I have installed a Fire Star nose full instrumentation, ASI dual EGT,CHT,IVSI,ALT, Fuel gauge,slip indicator,Tinny teach, lighted dash.The engine is a Rot ax 503 D.C.SI with a 2.58-1 gearbox turning a 54 in IVO. She has a Quad strobe system (they call me the flying Christmas Tree) She has disc brakes and an unusual differential braking control witch acts as a parking brake.She has 8 inch rims with TUNDRA tires. Some how I have acquired the nickname of the scudd. I have extended the landing gear to give me more prop Clarence but you know how it goes I have increased the prop size to 54 in. ( shouldn't say this but I have done 120 IAS in Straight and level flight not on purpose tho). She is registered as an E.L.S.A and has an airworthiness cert. She will climb at 1000 FPM at 40 Indicated . She fly's like a dream. She has a 9 gallon fuel tank. She cruses at 60-65 at 4700 RPM(what did forget?)????? Jim VanGarsse 2613 M _BelvidereIll(at)aol.com_ (mailto:BelvidereIll(at)aol.com) In a message dated 4/21/2008 3:01:37 P.M. Central Daylight Time, jb92563(at)yahoo.com writes: --> Kolb-List message posted by: "jb92563" What condition is it in? How is the motor? How did you like flying it? Does it still meet Part 103 Ultralight specs? -------- Ray Kolb UltraStar (Cuyuna UL-202) Moni MotorGlider Schreder HP-11 Glider Riverside County, CA Do Not Archive Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178228#178228 **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 21, 2008
> All possible Contestants: > -------- > John Williamson John W: I think your are running a wonderful photo contest! ;-) Here's another early morning shot from the camp ground. john h mkIII ________________________________________________________________________________
Date: Apr 21, 2008
> The hired Judges from EAA Chapter 34 have asked that a few things be > clarified and modified for the ?oMonument Valley 2008 Photo Contest?. > -------- > John Williamson John W: Here's a shot of Steven Green in his MKIII 912ULS powered Kolb right after taking off from Russellville, AR, last year on our second day of flying to MV. john h mkIII ________________________________________________________________________________
Date: Apr 21, 2008
> The hired Judges from EAA Chapter 34 have asked that a few things be clarified and modified for the ?oMonument Valley 2008 Photo Contest?. > John Williamson John W: I RON'd under the nose of Miss P'fer at Love County Airport, Marietta, OK. I have spent the night here about four or five times now. It is a grass strip and has no facilities. This was 2005 I believe, on the way to MV. john h mkIII ________________________________________________________________________________
Subject: Homer Kolb
Date: Apr 21, 2008
The man that started it all, Homer Kolb. Homer had just landed his 1985 Kolb Firestar, the 1985 Oshkosh Grand Champion Ultralight. This aircraft was destroyed by Dick Rahill at Oshkosh in 1989. Dick stalled in a tight turn to final about 25 feet AGL. john h mkIII ________________________________________________________________________________
Date: Apr 21, 2008
> Here's another early morning shot from the camp ground. > > john h > mkIII Made a mistake on this caption. This photo was taken from the airstrip just prior to first flight of the morning. john h mkIII ________________________________________________________________________________
Date: Apr 21, 2008
> The hired Judges from EAA Chapter 34 have asked that a few things be clarified and modified for the ?oMonument Valley 2008 Photo Contest?. > John Williamson On the way home from MV two years ago I RON's at Lone Pine, CA. Slept under the wing and listened to the cows moan and groan all night at the feeder lot across the highway from the airport. john h mkIII ________________________________________________________________________________
Date: Apr 21, 2008
> I RON'd under the nose of Miss P'fer at Love County Airport, Marietta, OK. > I have spent the night here about four or five times now. It is a grass > strip and has no facilities. This was 2005 I believe, on the way to MV. > > john h > mkIII Forgot to attach the photo. ;-) john h mkIII ________________________________________________________________________________
Subject: Homer Kolb
Date: Apr 21, 2008
> Homer had just landed his 1985 Kolb Firestar, the 1985 Oshkosh Grand > Champion Ultralight. Forgot to mention, this photo was taken the day before the Kolb Father's Day Flyin last year. Well..............I ain't perfect! john h mkIII ________________________________________________________________________________
Date: Apr 21, 2008
After all the pictures that have been posted, I find myself waiting for the usual complaining of overloading every ones dial up. Perhaps they all quit in disgust at each and everyone's disregard for their plight? Or perhaps they just gave up and got something better than dial up----------Naw! that doesn't make sense. :-0 forgive me Lord ! LarryC ________________________________________________________________________________
Date: Apr 21, 2008
At 06:59 PM 4/21/2008, KolbFlyerJim(at)aol.com wrote: > My UltraStar is in good condition the motor has 175 hrs on a 300 hr > rebuild. I have installed a Fire Star nose full instrumentation, ASI dual > EGT,CHT,IVSI,ALT, Fuel gauge,slip indicator,Tinny teach, lighted dash.The > engine is a Rot ax 503... I have done 120 IAS in Straight and level... An UltraStar with a 503??? Sounds more like a RocketStar! Isn't Vne for the US only 70? But seriously, did you beef it up at all? Funny, just last night I was browsing some archive messages about an early 5 rib FS with a 503, and many were saying it was overloaded and unsafe with that much power. Seems a US would be even more so. -Dana -- Celebrate Freedom... read a banned book. ________________________________________________________________________________
Date: Apr 21, 2008
this morning! Make sure there is a ground strap from engine to airframe...Herb At 05:41 PM 4/21/2008, you wrote: > > > >>I'm using a handheld radio and I was about 2000 ft up and I heard someone >>>but I mostly heard >>>static. I hear things fine on the ground at the airport. Do I >>>need an extension for the antenna maybe? > > >First, I'd do a search of the Kolb List Archives. There is more >info there than you will ever need to get your radio to work successfully. > >john h >mkIII > > ________________________________________________________________________________
Subject: Re: Homer Kolb
Date: Apr 21, 2008
> > Hi Gang: > > One of Jim's better ideas was to build a pusher with twin tailbooms with > enough space inbetween to swing a nice size prop. This concept could be > single of twin engine. Would bring the thrust line down behind the center > of mass where it belongs. > > > john h > mkIII > John, Ever here of a plane called the Sadler Vampire? Denny Rowe ________________________________________________________________________________
Date: Apr 21, 2008
> Ever here of a plane called the Sadler Vampire? > Denny Rowe Denny: Yes, there was a single and a two place in the UL area at Lakeland this year. The two place flew once during the week. Was roughly built and underpowered. Barely got out of 1500 feet of sod. I remember when Sadler introduced the single place many years ago. I'll stick to my tried and true Kolb. john h mkIII ________________________________________________________________________________
Date: Apr 21, 2008
Hey John H and All contestants, The intent is to judge photos taken in the Monument Valley Area, not on the way there or back to where ever you started. -------- John Williamson Arlington, TX Kolbra, 912ULS, 1595 hours http://home.tx.rr.com/kolbrapilot Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178346#178346 ________________________________________________________________________________
Date: Apr 21, 2008
> The intent is to judge photos taken in the Monument Valley Area, not on the way there or back to where ever you started. > > -------- > John Williamson John W: OK. The gang may enjoy looking at some traveling history then. All the shots at MV look the same, lot of rocks. ;-) john h mkIII ________________________________________________________________________________
Date: Apr 21, 2008
This can fit into the catagory of "picture of Kolb aircraft" (enroute to MV if that counts). Just above my ASI and just below the crest of Sandia Mountain is John Hauck. If you look at the instruments you will notice it's pretty well balls to the wall to get over the mountain in mild turbulance. ________________________________________________________________________________
Date: Apr 21, 2008
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Actually, Larry as a die-hard, dial-up modem gal :>) everything has been coming through great 'cause the photos are all attachments; I see a small thumbnail in the original e-mail and then can download the pics at my leisure. Maybe it doesn't work that way for some of the other folks, but I've been enjoying all the photos tremendously. Arty Trost Maxair Drifter Sandy, Oregon --- Larry Cottrell wrote: > > > After all the pictures that have been posted, I find > myself waiting for the > usual complaining of overloading every ones dial up. > Perhaps they all quit > in disgust at each and everyone's disregard for > their plight? Or perhaps > they just gave up and got something better than dial > up----------Naw! that > doesn't make sense. :-0 > forgive me Lord ! > LarryC > > > > browse > Un/Subscription, > FAQ, > http://www.matronics.com/Navigator?Kolb-List > > Forums! > > Admin. > > > > > www.LessonsFromTheEdge.com "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Date: Apr 22, 2008
HI Dana. I have chatted with Mr Kolb about my plane and he is ok with the 503. Jim In a message dated 4/21/2008 7:55:10 P.M. Central Daylight Time, d-m-hague(at)comcast.net writes: At 06:59 PM 4/21/2008, KolbFlyerJim(at)aol.com wrote: My UltraStar is in good condition the motor has 175 hrs on a 300 hr rebuild. I have installed a Fire Star nose full instrumentation, ASI dual EGT,CHT,IVSI,ALT, Fuel gauge,slip indicator,Tinny teach, lighted dash.The engine is a Rot ax 503... I have done 120 IAS in Straight and level... An UltraStar with a 503??? Sounds more like a RocketStar! Isn't Vne for the US only 70? But seriously, did you beef it up at all? Funny, just last night I was browsing some archive messages about an early 5 rib FS with a 503, and many were saying it was overloaded and unsafe with that much power. Seems a US would be even more so. -Dana -- Celebrate Freedom... read a banned book. (http://www.matronics.com/Navigator?Kolb-List) (http://www.matronics.com/contribution) **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Subject: Sadler Vampire
Date: Apr 22, 2008
John, I agree the Kolb fits our needs better, but your description brought back memories of the Vampire when it first came out in the early eighties. I always thought it would become a lot more popular than it did, but it will never match a Kolb for off airport opps. Denny PS: I hope they get their crap together and have some success with the Vampire as it is a very interesting a bird that has never seemed to fulfill its potential. What engine did they have on it at Lakeland John? > Yes, there was a single and a two place in the UL area at Lakeland this > year. > > The two place flew once during the week. Was roughly built and > underpowered. Barely got out of 1500 feet of sod. > > I remember when Sadler introduced the single place many years ago. > > I'll stick to my tried and true Kolb. > > john h > mkIII > > > -- > Date: 4/21/2008 4:23 PM > > ________________________________________________________________________________
Date: Apr 22, 2008
HI Dana. I have chatted with Mr Kolb about my plane and he is ok with the 503. Jim Jim, The nicest Ultrastar I ever saw was 503 powerd and had beefed up landing gear and I'm sure other mods. I saw it years ago at a fly in in Eastern Ohio, it was built and owned by a fellow named Tom Tchantz (spelling?) and I think he won a major award at Oshkosh that same summer. He later sold it and I always wonder if its still around. It was a true work of art and every Ultrastar owner shoul get a chance to look it over for ideas. Should be some nice layouts of it in old EAA rags. Denny Rowe, ________________________________________________________________________________
Date: Apr 22, 2008
Subject: fuel filter
Somewhere (I'm not sure where) there was a discussion of the Purolator glass tube fuel filters and a mention that they should be safety wired... but I'm not clear how. Does anybody have details? -Dana -- It feels great to wake up and not know what day it is, doesn't it? ________________________________________________________________________________
Subject: Re: Sadler Vampire
Date: Apr 22, 2008
. > What engine did they have on it at Lakeland John? Denny: I don't know. I was not interested enough in it to inquire. The two place looked really shabby. john h mkIII ________________________________________________________________________________
Subject: Re: fuel filter
Date: Apr 22, 2008
> Somewhere (I'm not sure where) there was a discussion of the Purolator > glass tube fuel filters and a mention that they should be safety wired... > but I'm not clear how. Does anybody have details? > > -Dana Dana: I have used the same Purolator fuel filter on my US, FS, and MKIII. Never used safety wire on it. However, after the first glass cylinder cracked the first night it was on the US, allowing all the fuel to leak out of the bottom tank, I replaced the glass cylinder with a piece of .058 aluminum tubing of the appropriate size. I like this filter because I can change elements in the field, easy to carry spares, or as a last resort, clean a dirty element well enough to get me to a place where I can obtain some new ones. john h mkIII ________________________________________________________________________________
Date: Apr 22, 2008
Yeow! Sandia Peak is 10,678 feet, and the Crest is at 9,702 feet... You were at 7,640 and losing altitude? How'd you drill through the rock? :-) -- Robert On Mon, Apr 21, 2008 at 9:36 PM, Steven Green wrote: > This can fit into the catagory of "picture of Kolb aircraft" (enroute to > MV if that counts). Just above my ASI and just below the crest of Sandia > Mountain is John Hauck. If you look at the instruments you will notice it's > pretty well balls to the wall to get over the mountain in mild turbulance. > > -- There are 10 types of people in this world: those who understand binary and those who don't. ________________________________________________________________________________
Date: Apr 22, 2008
Denny Rowe wrote: > > John, > I agree the Kolb fits our needs better, but your description brought > back memories of the Vampire when it first came out in the early > eighties. I always thought it would become a lot more popular than it > did, but it will never match a Kolb for off airport opps. > > Denny > PS: I hope they get their crap together and have some success with the > Vampire as it is a very interesting a bird that has never seemed to > fulfill its potential. > What engine did they have on it at Lakeland John? > > > Not John, but I'll answer. They were running some sort of rotary engine...dual rotor. I never saw them fly it...it looked real heavy (and rough as John mentioned) and not much wing. Was one of those examples of a company I'd never write a check to. If they are so short of capital that they can't make a decent looking demo plane, I fear for getting what I pay for. That being said, I've always thought the Vampire (single place) was a very interesting design. Jeremy > > ________________________________________________________________________________
Subject: Re: MV Photo Contest
Date: Apr 22, 2008
That is a great picture ! Can you post or send a bigger version of it John ? I would like to have one to keep and show friends. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178475#178475 ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Apr 22, 2008
I took this from Dave Rains plane at MV2005. I think Dave should get the award for the most rides given. The smiles on all the kids that got out of his plane after their ride was priceless. I'm not sure I even met that drifter pilot at least not before he took aim at me. What really hurt was his comment...."Wow I almost hit that girl". Rick Neilsen Redrive VW powered MKIIIC ________________________________________________________________________________
Date: Apr 22, 2008
Picture of Rainbow Bridge during a flight from MV Boyd Young Kolb MKIIIC Brigham City Ut. ________________________________________________________________________________
Date: Apr 22, 2008
Balancing rock at Mexican Hat Boyd Young Kolb MKIIIC Brigham City, Ut. ________________________________________________________________________________
Date: Apr 22, 2008
Ok I had to make changes in order to meet the qualifications. Flying formation with Erich Weaver through the rocks. Boyd Young Kolb MKIIIC Brigham City UT. ________________________________________________________________________________
Date: Apr 22, 2008
From: "Kirby, Dennis CTR USAF AFMC MDA/AL" <Dennis.Kirby(at)kirtland.af.mil>
"Flight of Two over MV, May 2007" Photo by Arty Trost. (The wingtip of her Drifter is visible in this picture.) Dennis Kirby Cedar Crest, NM <> ________________________________________________________________________________
Date: Apr 22, 2008
"Who's ready to go Fly Again?" Many of you might recognize this picture. It was featured in the Nov 2007 issue of EAA's "Light Sport Aircraft" magazine, as part of an article one of our guys submitted to the magazine about our annual Kolb event at MV. Dennis Kirby Cedar Crest, NM <> ________________________________________________________________________________
Date: Apr 22, 2008
Hi Ben. I have talked to Homer about this installation at length and he is ok with what I have done I normally cruse at 60 indicated at 4600-4700 rpm. I have had her for 4 years and 100 plus hours a season I need to move up to an all season plane. The 120 was done half way down the 2800 ft runway at 20 foot off the deck just after taking off I didn't do it on purpose just forgot to throttle down after take off. Thanks Jim In a message dated 4/22/2008 1:25:43 P.M. Central Daylight Time, bransom(at)ucdavis.edu writes: --> Kolb-List message posted by: Ben Ransom An UltraStar with a 503 is beyond design spec by a lot -- that plane wasn't even spec'd for a 447. I will acknowledge that a 5 rib original Firestar wing is not a lot different than a 5 rib Ultrastar wing, but again, Dennis of old Kolb made a new wing (7 rib) to accommodate the interest in a 503. But then the E means Experimental, and to each his own. (Any weight needed on the nose to compensate for a 92 lb engine?) Then about the 120 indicated, straight and level. Even if the straight and level was after a fast dive, I just can't fathom anything over 90, unless the wings were missing at that point. Recall that the ultrastar is what Dennis flight tested to destruction, in which a wing drag strut failed coming out of an intentional dive at about 80, and just the dive (let alone the broken wing) frightened even him in his younger invincible life. So, how far from stock are the wings on this thing? Or, am I just flying my Firestar like a little old lady? -Ben FS KXP KolbFlyerJim(at)aol.com wrote: > HI Ray. > > Jim here. > My UltraStar is in good condition the motor has 175 hrs on a 300 hr > rebuild. I have installed a Fire Star nose full instrumentation, ASI > dual EGT,CHT,IVSI,ALT, Fuel gauge,slip indicator,Tinny teach, lighted > dash.The engine is a Rot ax 503 D.C.SI with a 2.58-1 gearbox turning a > 54 in IVO. She has a Quad strobe system (they call me the flying > Christmas Tree) She has disc brakes and an unusual differential > braking control witch acts as a parking brake.She has 8 inch rims with > TUNDRA tires. Some how I have acquired the nickname of the scudd. I > have extended the landing gear to give me more prop Clarence but you > know how it goes I have increased the prop size to 54 in. ( shouldn't > say this but I have done 120 IAS in Straight and level flight not on > purpose tho). She is registered as an E.L.S.A and has an airworthiness > cert. She will climb at 1000 FPM at 40 Indicated . She fly's like a > dream. She has a 9 gallon fuel tank. She cruses at 60-65 at 4700 > RPM(what did forget?)????? > > Jim VanGarsse > 2613 M > BelvidereIll(at)aol.com > > In a message dated 4/21/2008 3:01:37 P.M. Central Daylight Time, > jb92563(at)yahoo.com writes: > > --> Kolb-List message posted by: "jb92563" > > What condition is it in? > > How is the motor? > > How did you like flying it? > > Does it still meet Part 103 Ultralight specs? > > -------- > Ray > > Kolb UltraStar (Cuyuna UL-202) > Moni MotorGlider > Schreder HP-11 Glider > Riverside County, CA > > Do Not Archive > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=178228#178228 > > > ------------------------------------------------------------------------ > Need a new ride? Check out the largest site for U.S. used car listings > at AOL Autos <http://autos.aol.com/used?NCID=aolcmp00300000002851>. > * > > > * **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 22, 2008
Flight line at MV. Boyd Young Kolb MKIIIC Brigham City Ut. ________________________________________________________________________________
Date: Apr 22, 2008
An example of what you can accomplish with a pusher prop: This is "laminar magic" certified record holder with a single boom, pusher engine. 25 hp, 498 lbs gross (including pilot) 126.7 MPH Note Steve Wittman wingtips BB Not much room for camping gear though John. pastedGraphic
Date: Apr 22, 2008
You guys can practice flying thru Monument Valley for free if you download the new GoogleEarth4.3 beta. Just enter "Monument Valley" & it will take you to Golding's Place. Take a tour at: http://earth.google.com/tour.html Some shots prom the program. ________________________________________________________________________________
Subject: Dead Stick Video
Date: Apr 22, 2008
Hello, all. It's been a while but I have busy in the shop with the Waiex. I've logged 750+ hours with the wings and most of the fuse done. Hopefully it will be on the gear in a week or so and flying sometime in the fall or winter. My Firestar still gets plenty of attention and even has a Quickie 1 as a hangar mate (which will be restored when the Waiex is done). I tried to post this video a while back but was unsucessful but then Youtube came along. I forget how high I was but 3000' sounds about right. Anyway, here is some summer quiet flying... http://youtube.com/watch?v=qDrq_VTPtA4 Kip -------- Kip Firestar II (born September 2000) Atlanta, GA N111KX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178570#178570 ________________________________________________________________________________
Date: Apr 22, 2008
Robert, There was some mild turbulence and at the moment I snapped the picture I was descending but that was just for a moment. I had no trouble getting across. Steven ----- Original Message ----- From: Robert Laird To: kolb-list(at)matronics.com Sent: Tuesday, April 22, 2008 8:54 AM Subject: Re: Kolb-List: Re: Monument Valley 2008 Photo Contest Yeow! Sandia Peak is 10,678 feet, and the Crest is at 9,702 feet... You were at 7,640 and losing altitude? How'd you drill through the rock? :-) -- Robert ________________________________________________________________________________
Subject: mark 111 engine thrust line
Date: Apr 22, 2008
Has any one played with changing the thrust ine with the 912UL? Any informa tion to this subject would be a grat help. The more I learn I realize how l ittle I know and am not to proud to ask and then make up my mind as to what to do. When I bought the plane the 582 had been replaced with a 912UL. The plane f lew great and did every thing I had hoped for but the set up was a shade tr ee set up. To meet the inspection requirerments for the AP the factory moun t set up was installed along with several other things. The plane flys okey but not like it use to. They had shimed the engine to change the thrust li ne which gave it a better rate of climb and great on short field take offs and landings. As a rule I take photos before and after ( age has made menor y shorter) but didn't this time as I was pressed for time to get it inspect ed for LSA. > Date: Tue, 15 Apr 2008 14:26:30 -0700> From: firestar503@yaho o.com> Subject: Kolb-List: Kolb wanted> To: kolb-list(at)matronics.com> > --> Kolb-List message posted by: Jon LaVasseur > > Hello from Minnesota.> > I am trying to help a friend find a good used> Kolb Fir estarII or MK3. If you know of any> decent Kolbs out side of regular channe ls like> Barnstormers, please email me.> > Thanks,> Jon LaVasseur> > > Be a better friend, newshound, and > know-it-all with Yahoo! Mobile. Try it now ====================> > > ________________________________________________________________________________
Subject: Re: Dead Stick Video
Date: Apr 22, 2008
Kip, That is a great video, I hope you post many more ! That gyro-copter did some incredible tight turns over the runway, especially the landing... The shot down of the runway between your feet was nest, I would like to see more out of the gyro-copter, and maybe a couple pictures of it, I did not realize how small it was until I saw your feet. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178598#178598 ________________________________________________________________________________
Date: Apr 23, 2008
That gyro is for sale. I saw him fly it last year at a flyin . It was very impressive. http://www.rotaryforum.com/forum/showthread.php?t=16662 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178653#178653 ________________________________________________________________________________
Subject: Shipping a BRS???
Date: Apr 23, 2008
I see a few BRSs that I am interested in however no one will ship them and they are too far away from me to get. How can a used BRS be shipped? If I order a new one I am sure it will shipped to me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178654#178654 ________________________________________________________________________________
Subject: Introduction, and dual time in NC or CO?
Date: Apr 23, 2008
Howdy all! long time lurker/newbie around here. Just wanted to give you all a little background on myself. When I was in junior/senior high school I was actively involved in my local Civil Air Patrol and was able to earn my solo license in a Cessna 172P. Tried to continue on for my private pilots license but the cost of training on a 17 year old's budget just didn't cut it! I joined the Army when I was 19 and have been deployed to Iraq, and am currently finishing up a 15 month deployment in Afghanistan. I'll be getting out of the Army this summer, and will hopefully be starting gunsmithing school in the spring of 2009. Flying has been a long time interest of mine and I would love to get back into it! I've extensively researched all types of ultralights, LSA, etc. and I've pretty much come to the decision that if I do start flying again it's going to be in a Kolb. I currently can not afford to buy one, so that brings me to my question. I'm looking to see if there is anyone located in/near North Carolina, or Colorado, that could give me a little test flight or some dual time? It's been about 6 years since I did any flying so I'd really enjoy to get my feet wet again and actually see a Kolb up close and personal - I've been drooling over pictures for a long time :) I really enjoy reading all the information you all have to offer on this forum. Thanks! -------- "The LORD is a warrior; the LORD is his name." Exodus 15:3 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178655#178655 ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Re: Shipping a BRS???
Grant, the parachute assembly can be shipped any way you like, but the rocket motor has to be shipped by a facility that is permitted to ship explosives. You might consider buying a BRS at a good price and have them ship just the chute. Then buy a new rocket assy. from BRS. That would make sense especially if the rocket is out of date. steve In a message dated 4/23/2008 10:30:58 A.M. Eastern Standard Time, grant_richardson25(at)yahoo.com writes: --> Kolb-List message posted by: "grantr" I see a few BRSs that I am interested in however no one will ship them and they are too far away from me to get. How can a used BRS be shipped? If I order a new one I am sure it will shipped to me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178654#178654 **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
We say that our event is "Unplanned and Unorganized" but have never said is is without some kind of excitement. It is scarier to watch the video than it was to watch it in person. http://video.google.com/videoplay?docid=-1486764191680773505 Back to the Contest: -------- John Williamson Arlington, TX Kolbra, 912ULS, 1595 hours http://home.tx.rr.com/kolbrapilot Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178668#178668 Attachments: http://forums.matronics.com//files/wj7_img_0786_107.jpg http://forums.matronics.com//files/wj1_100_0378_142.jpg http://forums.matronics.com//files/wj6_100_3395_182.jpg http://forums.matronics.com//files/wj8_img_0799_346.jpg ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Wing design and other stuff
Kolb guys, Hey, did I mention I am making MY OWN fiberglass wing tips? I liked the progress report John H had shared with us, on the MkIII Xtra's flight data. It appears that by adding droop tips, the Xtra's stall speed dropped by about 4 mph. To 26 mph!!! Plus, he felt like he had better control authority of the ailerons at slower airspeeds. First of all, it was NOT my preference to make them. I checked with Donnie at TNK, and he said their's may not be be ready to sell for 6+ weeks (maybe more, who knows?). I can't wait. I need them now. I am ready to begin covering my wings, and prefer not to wait. Some background and reasons why they are a good idea: If you take a look at the outer three feet of most MkIII wings (without tips), it seems fairly obvious why this would be an area of concern. Several airflow issues come to mind. I'll explain... First, and most obvious, air will travel the path of least resistance. Duh. Right? So, as air is traveling rearward during flight under the wing, rather than continue inline with all the other compressed air, the air near the tip will prefer to "spill" off. The idea seems kind of intuitive, IMO. If you think about it, as you force a canted airfoil into the wind, air is being compressed as it piles up against the lower surface. Plus, the further rearward you go, the more the compression, due to a combination of accumulated air, from the front....increasing all the way to the back (see lower drawing). In other words, in the front, you have "front" air. In the middle, you have "front and middle" air. At the rear, you have "front, middle, and rear air"....all trying to get past the airfoil (see drawing below to see what I'm getting at). Clearly, some of the air near the outer edge will prefer to "jump ship", and divert out to the undisturbed air beyond the wing. Secondly, the top of the wing has that "rounded off" shape. It, too, appears that as air is trying to go over the top of the wing's outer two feet, there is some preference for the air to "fall" off the bump, away from the wing. By it's design, there is a perpendicular (a sideways) vector component to passing air. It also seems intuitive that if you watched the air (smoke) pass over the outer portion of the wing, some will spill off the top toward the direction away from the wing. And then there's the 1" leading edge tube. This is a fairly large tube to be ramming through the air. It has a large curve that connects the leading edge to the wing's outer side edge. By it's shape, this leading edge "curve" is pushing air away from the wing. How much? Don't know. But, it darn sure is "some". Keep in mind all this diminished airflow is going on near the outer tip. This the place where you DON'T want it to happen!!! You would prefer to keep ALL the air that goes under the wing to remain under the wing, until it passes beyond the aileron. My ailerons are just under 6 feet long. My outer wing panel is just OVER 3 feet wide!! This tells me that over half of my aileron is less efficient than it could be. At the place you want the most air, for aileron control, you are losing some. Undoubedly, this is why some fliers claim their ailerons are "sloppy" at slower airspeeds. Of course, slower air will give less control, but it doesn't help to be giving up some control authority to "losing air". For those of you high on your math skills, you do recall that air's effect (and drag) is determined by it's airspeed. Specifically, by it's square of the velocity. In other words, a wing travelling at 40 mph will have a certain performance level (and, or drag). That same wing will have 1/4th of it's performance at 20!! Or, said another way, as you double the airspeed, you quadruple it's effect, or...as you cut in half your airspeed, you reduce your control to only 25%. This is huge!!! When you couple this concept with the fact you are "giving up" some of your air, due to the wing's design, well, that is not good!! By the way, this math formula applies to MANY MANY other aspect of life, including impacts. An airplane that crashes at 50 mph will have 4 times that impact an airplane at 25 mph has!! If you don't think that is a big deal, try crashing at 25 mph in a plane. I did. As bad as I hurt, there is NO way I would have lived if the impact was 4 times as great. Back to the droop wing tips. By designing a wing tip that is able to keep all this air under the wing, and not produce any negative drag concerns, you can improve the aileron's slow airspeed performance. In essence, all you are doing is placing an aerodynamic "dam" at the wing tip's outer edge. Of course, only a wind-tunnel will show you how effective your particular design is, but for the most part, a basic droop tip should be a huge improvement. Considering the results posted by John H. regarding the new Kolb company's Xtra, I would say that was "huge". Stall speed reduced from 30 mph to 26 mph. That's well over 10% slower stall speed, and that means safety. For any questions, pictures, etc, contact me directly. I am almost finished making the "plugs". (These are my sculpted shapes, once they are finished I will make molds from them). I ordered all the fiberglassing products that I don't have on hand yesterday. Things like wax, gel coat, etc.) BTW, all this wing tip modification required taking off the existing "stock" shape wing tip, and building a special end rib. I now have 13' 7" of straight airfoil, per side, and then the droop tips begin. How did I handle the fact that the 6" tube spar ended at out 30" short?? I built a chromoly truss. Not very heavy and gawd-aweful strong!!! It looks a lot like the tube reinforcements we slid into the spars and boom tubes. Phenominally strong!!! (Plus, of course, all the usual aluminum tubes for triangulation.......) I know this modification isn't for everyone, but I, for one, like the performance, the looks, and the added styling droop tips add. Besides, they purdy! I have kept a fairly detailed photo log of the process. I'm not finished, yet, so if anyone wants any additional information, I will wait until I'm finished before send out stuff, drawings, photos, etc. BTW, I talked to a guy yesterday that makes all the products you'd ever need for fiberglassing work. He has a auction site site on eBay ,just for showing his countless "how to" videos. You want to see tons and tons of demonstration videos on fiberglassing products, check out eBay item #280178620496. Awesome site!!!! Plus, there is a link to photobucket you should look for. This is another place where he has over a hundred displays of his products in action. Worth checking out, if you're interested in your own fiberglassing projects. Next......my custom dash panel that mounts at the lower line along the windscreen, then my overhead panel like Scott built. I already had one of these in aluminum for the Classic, but it doesn't fit, anymore. Next one will be fiberglass like Scotts. Gotta get to work on those droop tips. They ainta gettin' done without me. Mike Welch MkIII CX PS. My droop tip molds are SUPPOSED to be reuseable. We'll see. --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Apr 23, 2008
Steve, I doubt very seriously if BRS would sell Grant just the rocket motor portion of their system. They might, but I doubt it. If they did, I would probably buy just the motor. I have the chute, already, but I didn't get it from them, and it isn't a BRS chute brand. Mike Welch ________________________________ From: N27SB(at)aol.com Date: Wed, 23 Apr 2008 11:44:15 -0400 Subject: Re: Kolb-List: Shipping a BRS??? Grant, the parachute assembly can be shipped any way you like, but the rocket motor has to be shipped by a facility that is permitted to ship explosives. You might consider buying a BRS at a good price and have them ship just the chute. Then buy a new rocket assy. from BRS. That would make sense especially if the rocket is out of date. steve In a message dated 4/23/2008 10:30:58 A.M. Eastern Standard Time, grant_richardson25(at)yahoo.com writes: I see a few BRSs that I am interested in however no one will ship them and they are too far away from me to get. How can a used BRS be shipped? If I order a new one I am sure it will shipped to me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178654#178654 ________________________________ Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. _________________________________________________________________ Make i'm yours. Create a custom banner to support your cause. ________________________________________________________________________________
Date: Apr 23, 2008
Some airplane photos: -------- John Williamson Arlington, TX Kolbra, 912ULS, 1595 hours http://home.tx.rr.com/kolbrapilot Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178688#178688 Attachments: http://forums.matronics.com//files/100_0398_161.jpg http://forums.matronics.com//files/101_0022_947.jpg http://forums.matronics.com//files/img_0760_514.jpg http://forums.matronics.com//files/img_0782_148.jpg http://forums.matronics.com//files/img_0800_621.jpg http://forums.matronics.com//files/img_0801_201.jpg ________________________________________________________________________________
Date: Apr 23, 2008
Some more Scenery photos: -------- John Williamson Arlington, TX Kolbra, 912ULS, 1595 hours http://home.tx.rr.com/kolbrapilot Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178691#178691 Attachments: http://forums.matronics.com//files/100_3399_435.jpg http://forums.matronics.com//files/img_0756_125.jpg ________________________________________________________________________________
Date: Apr 23, 2008
Some Kolber photos: -------- John Williamson Arlington, TX Kolbra, 912ULS, 1595 hours http://home.tx.rr.com/kolbrapilot Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178692#178692 Attachments: http://forums.matronics.com//files/100_3381_118.jpg http://forums.matronics.com//files/mvsunmorn_007_855.jpg ________________________________________________________________________________
Date: Apr 23, 2008
Pictures take by Dave Rains of my FireStar flying over MV **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
Pictures I took flying over MV in my FireStar **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
Hey Will: "Pictures take by Dave Rains of my FireStar flying over MV " They look like they are great photos, but can you repost them at least 600 pixels wide or larger. -------- John Williamson Arlington, TX Kolbra, 912ULS, 1595 hours http://home.tx.rr.com/kolbrapilot Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178704#178704 ________________________________________________________________________________
Date: Apr 23, 2008
Hi Mike, That is what they did for Flycrazy8 (Stephen Baxley) when he purchased an older BRS from me. The BRS had a recent repack but the rocket was out of date. We test fired the old rocket at TNK Homecoming 2005. On the Older rocket packs the fuel cannot be removed and replaced so they will sell a new motor and canister. I would call them and give them the model and S/N. Steve FF#007/Floats FF#040/Floats 2008 Sun n Fun UL Grand Champion In a message dated 4/23/2008 12:37:31 P.M. Eastern Standard Time, mdnanwelch7(at)hotmail.com writes: Steve, I doubt very seriously if BRS would sell Grant just the rocket motor portion of their system. They might, but I doubt it. If they did, I would probably buy just the motor. I have the chute, already, but I didn't get it from them, and it isn't a BRS chute brand. Mike Welch **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
Sorry Mike, just read the end of your post, they probably would not sell one for another brand chute. A BRS is one component I would not get cheap over. In a message dated 4/23/2008 2:58:28 P.M. Eastern Standard Time, N27SB(at)aol.com writes: If they did, I would probably buy just the motor. I have the chute, already, but I didn't get it from them, and it isn't a BRS chute brand. **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
Sorry Mike I just re read your post, they may not sell you one. A BRS is one component I would not get cheap on. "When building your aircraft your best work will barely be good enough" Burt Rutan Steve FF#007/Floats FF#040/Floats 2008 Sun n Fun UL Grand Champion In a message dated 4/23/2008 2:58:28 P.M. Eastern Standard Time, N27SB(at)aol.com writes: If they did, I would probably buy just the motor. I have the chute, already, but I didn't get it from them, and it isn't a BRS chute brand. **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Serial Number
From: N27SB(at)aol.com Date: Wed, 23 Apr 2008 14:54:18 EDT ............... Steve FF#007/Floats FF#040/Floats 2008 Sun n Fun UL Grand Champion ..................... Steve, Am I missing something? I would have thought there were more than 40 FireFlys flying. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
From: "cristalclear13" <cristalclearwaters(at)juno.com>
Date: Apr 23, 2008
Ray, Hopefully your backpack chute instructions are better than the one in this video (check out about 3 1/2 minutes into the video) and you'll see what I mean: http://www.youtube.com/watch?v=Tv55-m1KHAo [Laughing] -------- Cristal Mark II Twinstar Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178724#178724 ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Re: Serial Number
Hi Jack, (gotta be careful where you when you say that) It is #40 from TNK. You have to add up all of Old Kolbs then add about 30 on top of this one. steve In a message dated 4/23/2008 3:35:42 P.M. Eastern Standard Time, jbhart(at)onlyinternet.net writes: Steve, Am I missing something? I would have thought there were more than 40 FireFlys flying. Jack B. Hart FF004 Winchester, IN **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
I always flight=planned with a highway map -- they put the roads thru the lowest pass they can find. Don't recall any problems in 6 trips thru the Rockies -- but went to 13K over Crater Lake once; great experience! On Apr 22, 2008, at 9:02 PM, Steven Green wrote: > Robert, > > There was some mild turbulence and at the moment I snapped the > picture I was descending but that was just for a moment. I had no > trouble getting across. > > Steven > ----- Original Message ----- > From: Robert Laird > To: kolb-list(at)matronics.com > Sent: Tuesday, April 22, 2008 8:54 AM > Subject: Re: Kolb-List: Re: Monument Valley 2008 Photo Contest > > Yeow! Sandia Peak is 10,678 feet, and the Crest is at 9,702 > feet... You were at 7,640 and losing altitude? How'd you drill > through the rock? :-) > > -- Robert > > ________________________________________________________________________________
Date: Apr 23, 2008
Here are Dave's pictures one more time in a larger format. **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
Mike am I to believe that if I buy a BRS chute for 3-4-5 thousand dollars from BRS and keep it till the rocket has reached its" good til date" , That BRS wont sell me a replacement rocket?If that is true then I guess one would have to pay the shipping for explosives . Chris ----- Original Message ---- From: Mike Welch <mdnanwelch7(at)hotmail.com> Sent: Wednesday, April 23, 2008 12:34:34 PM Subject: RE: Kolb-List: Shipping a BRS??? Steve, I doubt very seriously if BRS would sell Grant just the rocket motor portion of their system. They might, but I doubt it. If they did, I would probably buy just the motor. I have the chute, already, but I didn't get it from them, and it isn't a BRS chute brand. Mike Welch ________________________________ From: N27SB(at)aol.com Date: Wed, 23 Apr 2008 11:44:15 -0400 Subject: Re: Kolb-List: Shipping a BRS??? Grant, the parachute assembly can be shipped any way you like, but the rocket motor has to be shipped by a facility that is permitted to ship explosives. You might consider buying a BRS at a good price and have them ship just the chute. Then buy a new rocket assy. from BRS. That would make sense especially if the rocket is out of date. steve In a message dated 4/23/2008 10:30:58 A.M. Eastern Standard Time, grant_richardson25(at)yahoo.com writes: I see a few BRSs that I am interested in however no one will ship them and they are too far away from me to get. How can a used BRS be shipped? If I order a new one I am sure it will shipped to me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178654#178654 ________________________________ Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. _________________________________________________________________ Make i'm yours. Create a custom banner to support your cause. Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Apr 23, 2008
Chris, No, I didn't say BRS wouldn't sell to it's customers parts of an upgrade system. Of course they would. I said I doubt they would sell you JUST the rocket motor. If you had purchased an earlier model from them, and it needed newer parts, sure, they'd sell you new stuff. It's been my experience that many vendors won't go to the trouble of inventing a great system, only to sell parts of it to "anybody". Most of the time, it's either the whole kit, or nothing. In some situations, some businesses may sell you parts of an upgraded system, provided you have their earlier version. Just my thoughts, that's all. Mike Welch ________________________________ Mike am I to believe that if I buy a BRS chute for 3-4-5 thousand dollars from BRS and keep it till the rocket has reached its" good til date" , That BRS wont sell me a replacement rocket?If that is true then I guess one would have to pay the shipping for explosives . Chris Steve, I doubt very seriously if BRS would sell Grant just the rocket motor portion of their system. They might, but I doubt it. If they did, I would probably buy just the motor. I have the chute, already, but I didn't get it from them, and it isn't a BRS chute brand. Mike Welch ________________________________ From: N27SB(at)aol.com Date: Wed, 23 Apr 2008 11:44:15 -0400 Subject: Re: Kolb-List: Shipping a BRS??? Grant, the parachute assembly can be shipped any way you like, but the rocket motor has to be shipped by a facility that is permitted to ship explosives. You might consider buying a BRS at a good price and have them ship just the chute. Then buy a new rocket assy. from BRS. That would make sense especially if the rocket is out of date. steve In a message dated 4/23/2008 10:30:58 A.M. Eastern Standard Time, grant_richardson25(at)yahoo.com writes: I see a few BRSs that I am interested in however no one will ship them and they are too far away from me to get. How can a used ________________________________ Be a better friend, newshound, and _________________________________________________________________ Make i'm yours. Create a custom banner to support your cause. ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Sun N Fun 2008
Date: Apr 23, 2008
The plane in the Photo is the New Kolb's new MKIII Extra with John H flying. Rick Neilsen Redrive VW powered MKIIIC ________________________________________________________________________________
From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
Date: Apr 23, 2008
Wrong again, Larry. Just got tired of asking nicely and getting rude responses. (Don't look now, but your lack of compassion is showing.) Maybe you'd like to call Verizon yourself and find out why we can't get dial-up in this area. That'd at least be more constructive than slinging barbs at those of us who kindly - repeatedly - ask for 'links' to be posted to the pics. Heavens, wouldn't want anyone to go out of their way and learn a technique that's been out there for 20 years. Ed in JXN MkII/503 ----- Original Message ----- From: "Larry Cottrell" <lcottrell(at)fmtcblue.com> Sent: Monday, April 21, 2008 8:01 PM Subject: Re: Kolb-List: Re: Monument Valley 2008 Photo Contest > > After all the pictures that have been posted, I find myself waiting for > the usual complaining of overloading every ones dial up. Perhaps they all > quit in disgust at each and everyone's disregard for their plight? ________________________________________________________________________________
Date: Apr 23, 2008
At 07:25 PM 4/23/2008, WillUribe(at)aol.com wrote: Wow! A giant airspeed indicator painted on the desert floor! :) Is that the "Rock House" I keep hearing about? -Dana -- If vegetarians eat vegetables,..beware of humanitarians! ________________________________________________________________________________
Date: Apr 23, 2008
Date: Apr 23, 2008
----- Original Message ----- From: "Ed Chmielewski" <edchmiel(at)mindspring.com> Sent: Wednesday, April 23, 2008 6:46 PM Subject: Re: Kolb-List: Re: Monument Valley 2008 Photo Contest > > > Wrong again, Larry. Just got tired of asking nicely and getting rude > responses. (Don't look now, but your lack of compassion is showing.) Hi, Actually you are incorrect about the lack of compassion. That is exactly what prompted the email in the first place. When I saw all the photos that was being sent to the list, I was amazed that no one had complained. Perhaps I worded it incorrectly. I of course gave up and went to Satellite, but I still remember waiting and waiting for a picture to finally manifest its self. I guess that I thought that some levity might be in order. Guess not. Larry C ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Re: Sun N Fun 2008
Good picture of John and New Kolb Extra...... Got anymore pic to share of Sun-Fun.....Wasn't able to go this year. Stephen Kolb Firefly Alabama **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
Stephen, just talking about you today. hit me off list steve In a message dated 4/23/2008 10:27:43 P.M. Eastern Daylight Time, Flycrazy8(at)aol.com writes: Good picture of John and New Kolb Extra...... Got anymore pic to share of Sun-Fun.....Wasn't able to go this year. Stephen Kolb Firefly Alabama ____________________________________ Need a new ride? Check out the largest site for U.S. used car listings at _AOL Autos_ (http://autos.aol.com/used?NCID=aolcmp00300000002851) . (http://www.matronics.com/Navigator?Kolb-List) (http://www.matronics.com/contribution) **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
Subject: Re: Monument Valley 2008 Photo Contest
John Williamson wrote: > > We say that our event is "Unplanned and Unorganized" but have never said is is without some kind of excitement. > > It is scarier to watch the video than it was to watch it in person. > http://video.google.com/videoplay?docid=-1486764191680773505 > > Back to the Contest: > > -------- > John Williamson > Arlington, TX > > Kolbra, 912ULS, 1595 hours > http://home.tx.rr.com/kolbrapilot > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=178668#178668 > > > Attachments: > > http://forums.matronics.com//files/wj7_img_0786_107.jpg > http://forums.matronics.com//files/wj1_100_0378_142.jpg > http://forums.matronics.com//files/wj6_100_3395_182.jpg > http://forums.matronics.com//files/wj8_img_0799_346.jpg > John, Thanks for posting you pictures as jpg attachments rather than as part of the main message to the Kolb list. I enjoyed looking at them!!! We user's of the mail dial-up services appreciate not having our web mail locked up by these posting's. Unlike some of our other arrogant and inconsiderate members of this list, you must have a better understanding of the limitations some of us have in our service connections. Thank you !!!!!! Terry - FireFly #95 ________________________________________________________________________________
Date: Apr 23, 2008
I did call BRS up and they did sell me a new rocket for the used BRS unit that I bought from Steve N27SB ... At a very nominal price ( if it had to save my life)..... They did ship it to me with the fuel separate from the actual rocket ( some assembly required) ...... Stephen Firefly Alabama **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 23, 2008
Thanks for the comments. I am supposed to fly with the gyro guy tomorrow, hopefully to make another video. He has not even told me that it's for sale [Shocked] Kip -------- Kip Firestar II (born September 2000) Atlanta, GA N111KX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178863#178863 ________________________________________________________________________________
Subject: Re: Wing design and other stuff
Date: Apr 23, 2008
Mike, I think you are right on about the Wingtips, and you are definitely right on about increasing safety any time you can lower the approach and stall speeds in your Kolb. Are you adding any length to your wings ? What will your total wingspan be ? I am also going to add the wingtips to my Kolb, but I don't have the time or the skill to make fiberglass ones, so I will have to wait for Kolb to start selling them. At the same time I am putting on the new wingtips, I will also add 2 feet of spar to each wingtip to make the wings as long as the new Kolb MK III, that also seems to have helped a good bit. What happened in your accident at 25 mph ? Did you live [Wink] If you could post the details it might help someone avoid the same thing one day. I look forward to seeing the pictures of what you are doing, and especially the truss structure you were talking about for the tips. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178867#178867 ________________________________________________________________________________
Date: Apr 24, 2008
Subject: Re: Internet connection speeds vs. photos
I _do_ have a broadband connection, but I remember what it's like not to... and when I'm on the road using a slow cellular connection, the emails still come automatically. It's much preferable to have the photos come as a link as some people do instead of embedded in the message... how is that done? -Dana -- Drink wet cement, and get completely stoned! ________________________________________________________________________________
Date: Apr 24, 2008
From: william sullivan <williamtsullivan(at)att.net>
Subject: comments
My computer service is screwed up, thanks to AT&T Yahoo switching systems, so these comments are late. First- Congratulations to Cristal on her first solo in her new toy. Hope you have many joyful and safe flights. Next- Everybody keep sending the MV photos. I really enjoy seeing places that I will never be able to see in person. The photo of John in the new Kolb gave a very good look at the new wingtips. Mike- if this is what you are making, good luck. I found your lengthy commentary quite informative. Keep it coming. How are you making the reverse molds exactly, meaning right and left? Templating? Question- If drooping down helps, what about the air coming off the ends at the top? Would "drooping" both down and up help? I have noticed a lot of winglets(?) on the planes flying over the house. What about the same on a Kolb wing? About the new Kolb- Does it have bosses on the wing ends, to change the wing end style? Comments, anyone? Bill Sullivan FS/KX/447 Windsor Locks, Ct. ________________________________________________________________________________
From: "Travis Brown (Kolb Aircraft)" <travis(at)tnkolbaircraft.com>
Subject: Re: Mk III Wingtips
Date: Apr 24, 2008
Bill, We installed a steel rib on the wing end with tabs to attach the tips to.If you wished to change wing tip styles all you would have to do would be to use a hole transfer jig to transfer your hole pattern. Thanks for the interest as we are always looking for new ideas to make a great aircraft even better! John Hauk has been of absolutely great help with changes we have incorporated into the Mk III. His knowledge and experience have truly been priceless to us! Ken Bryant Newest member of The New Kolb Aircraft Co. ----- Original Message ----- From: william sullivan To: kolb list Sent: Thursday, April 24, 2008 10:03 AM Subject: Kolb-List: comments My computer service is screwed up, thanks to AT&T Yahoo switching systems, so these comments are late. First- Congratulations to Cristal on her first solo in her new toy. Hope you have many joyful and safe flights. Next- Everybody keep sending the MV photos. I really enjoy seeing places that I will never be able to see in person. The photo of John in the new Kolb gave a very good look at the new wingtips. Mike- if this is what you are making, good luck. I found your lengthy commentary quite informative. Keep it coming. How are you making the reverse molds exactly, meaning right and left? Templating? Question- If drooping down helps, what about the air coming off the ends at the top? Would "drooping" both down and up help? I have noticed a lot of winglets(?) on the planes flying over the house. What about the same on a Kolb wing? About the new Kolb- Does it have bosses on the wing ends, to change the wing end style? Comments, anyone? Bill Sullivan FS/KX/447 Windsor Locks, Ct. ________________________________________________________________________________
Date: Apr 24, 2008
My apologies for misspelling Mr. Hauck's last name,I was in a rush and didn't check my spelling! Ken at Kolb ----- Original Message ----- From: Travis Brown (Kolb Aircraft) To: kolb-list(at)matronics.com Sent: Thursday, April 24, 2008 10:50 AM Subject: Re: Kolb-List: Mk III Wingtips Bill, We installed a steel rib on the wing end with tabs to attach the tips to.If you wished to change wing tip styles all you would have to do would be to use a hole transfer jig to transfer your hole pattern. Thanks for the interest as we are always looking for new ideas to make a great aircraft even better! John Hauk has been of absolutely great help with changes we have incorporated into the Mk III. His knowledge and experience have truly been priceless to us! Ken Bryant Newest member of The New Kolb Aircraft Co. ----- Original Message ----- From: william sullivan To: kolb list Sent: Thursday, April 24, 2008 10:03 AM Subject: Kolb-List: comments My computer service is screwed up, thanks to AT&T Yahoo switching systems, so these comments are late. First- Congratulations to Cristal on her first solo in her new toy. Hope you have many joyful and safe flights. Next- Everybody keep sending the MV photos. I really enjoy seeing places that I will never be able to see in person. The photo of John in the new Kolb gave a very good look at the new wingtips. Mike- if this is what you are making, good luck. I found your lengthy commentary quite informative. Keep it coming. How are you making the reverse molds exactly, meaning right and left? Templating? Question- If drooping down helps, what about the air coming off the ends at the top? Would "drooping" both down and up help? I have noticed a lot of winglets(?) on the planes flying over the house. What about the same on a Kolb wing? About the new Kolb- Does it have bosses on the wing ends, to change the wing end style? Comments, anyone? Bill Sullivan FS/KX/447 Windsor Locks, Ct. href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronic s.com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 24, 2008
Mike, I don't know how long you're wings are, but mine were built to standard MkIII Classic (there wasn't an Xtra when I built my wings). As you are aware, the trailing edge tube is full length. The leading edge stops about 2 feet short and then begins the "bow" tip. Prior to any wing tip mods, my wings were 13' 7" at the trailing edge (after mods, they still are.) Of course, you don't get the full length of true airfoil on a standard wing, because once you begin the bow tip, you encounter all that loss of "air" I was talking about. My 6" tubular wing spar ended at about 11 feet 8 inches (and then at the front, the bow tip curve began). The trailing edge tube continues for another 23". To make the modification, this entire length is what I kept. First, I removed the bow tip, and all the skinny diagonal reinforcement tubes. (Remember, I don't have fabric, yet. More on this later.) Next, I made an extension to the leading edge tube, to match the length of the trailing edge. I will now have the entire 13' 7" of full shaped airfoil. While I was waiting on the epoxy resin to harden on the droop tip plugs, I began building the truss extension. At first, I began using aluminum. But within minutes I could see it would take me days to go that route. Cutting the shaped tubes, making plates to mount them, etc., etc. No can do!! Then I thought "hey, why not chromoly" Not too heavy. Easy as hell to simply cut web tubes and weld in place. Try it. So I cut the lengths (32 inches each, top and bottom), and cut some web diagonals, and tacked them in place. Fast, fast fast. Welded all the locations, ground them smooth. Best idea, yet. In the "up and down" direction, this SOB is SOLID!!! Slide it in the 6" spar eleven inches, bolt it in place, and it will easily carry just the last two feet of wing. BTW, although I haven't done it yet, I will weld several tabs to this truss, for the diagonal braces. I am very comfortable with the internal structure of the wing extension. It damn sure will get the job done!! Regarding the "last rib". I built it with aluminum stock that I had on hand. I used some angle aluminum. If I were to do it again, I would buy some 1" wide FLAT alum. strap X 1/8" thick. Your end rib can NOT be made of tubes, like all the other ribs. My wingspan was originally close to 30' 2". The only addition is just the tips, about 6" each. With regard to my crash, I restored an older Wizard ultralight. It looks like a Quicksilver. I had "some" pilot training years earlier, and thought that would be enough to allow me to do some crow hops. I was doing fine all day, but not really ever in complete control. As I added power, it climbed. But this scared me, so I held just enough airspeed to stay aloft (riding on the edge of stall all day). Eventually, fate will catch up with that plan! I started drifting away from the runway, and toward some trees. As I tried to turn back to the runway, I just nosed in, into the dirt. Crumpled the nosegear, etc. Hurt so goddamn much I thought I WAS dying!! I wiped out one of the reinforced downtubes with my neck. This twisted my back beyond anything I have ever done before. My pain was in the red, on the "shit-o-meter"!! Analysis. All this was MY fault. The ultralight flew just fine. Good friend and pilot, Lou Wetzel flew it earlier, prior to me. The fault lies with the idiot in the pilot seat not flying the damn plane!!! I don't want to EVER want to hurt that bad again! I have since then gotten my pilot's license. However, I also don't want to ASSUME anything anymore. Even prior to flying my MkIII I will try and find someone who will share some MkIII flying time with me. BTW, how did YOU manage to solo your Xtra? I'll be honest with you, it scares the livin' bu'jesus out of me to think about soloing my plane. I think I'm a pretty good pilot in my Cessna, but I found out what can happen if you aren't correct. Yes, I think you can add droop tips. BUT!!!! With regard to you making the droop tip conversion to YOUR plane. I would NOT alter anything on your present wing. DO NOT CUT ANYTHING. If you do, you'll open up such a shitstorm of grief you won't believe it! It would be easier to build brand new wings, at that point! Once you cut the fabric along the outer edge, the entire wing loses it's tension. That would be so much work I wouldn't even want to think about it! What you CAN do is like I suggested a while back. Build the droop tip design completely around your finished wing. This would be absolutely EASY. But Kolbs droop tips, get some of that aluminum flat strap, etc....build a solid substructure, making it look like you have full airfoil all the way to the end, fabric, paint, slide on tips...you're done. You don't need to add any 6" spar, because your wing isn't carrying any more lift requirement than it did prior to addition of droop tips, except you will no longer have "spilled" air. Put simplistically, you'd build your droop tip addition AROUND your present wing. Cheap, easy and just as effective as if you built them that way in the first place. Plus, NO ONE would ever know you had stock wings inside your droop tip wings. That penalty would be several ounces of aluminum and fabric that were left inside your new shape. Big deal!!!! After working with Poly Fiber recently, I am even more convinced this is the best way. Like I said, if you cut that outer edge fabric, you're in for a total wing rebuild. $$$$$$$$ An expression like "you're screwed!!" comes to mind!! More later, when I can post some pictures.... Mike Welch BTW, With VGs, which are a hellava good idea, I would think your stall could be down to about 22-23 mph, with MORE aileron control (due to the droop tips). You are already getting better aileron control from the VGs. JetPilot wrote: Mike, I think you are right on about the Wingtips, and you are definitely right on about increasing safety any time you can lower the approach and stall speeds in your Kolb. Are you adding any length to your wings ? What will your total wingspan be ? I am also going to add the wingtips to my Kolb, but I don't have the time or the skill to make fiberglass ones, so I will have to wait for Kolb to start selling them. At the same time I am putting on the new wingtips, I will also add 2 feet of spar to each wingtip to make the wings as long as the new Kolb MK III, that also seems to have helped a good bit. What happened in your accident at 25 mph ? Did you live [Wink] If you could post the details it might help someone avoid the same thing one day. I look forward to seeing the pictures of what you are doing, and especially the truss structure you were talking about for the tips. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178867#178867 --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Subject: Re: comments
Date: Apr 24, 2008
Thank you Bill and all who have wished me safe and fun flying. I got to fly Tuesday morning and evening also for just a little while. Wind has kicked up too much around here lately...but I can NOT wait to go again! What fun! Think I'll stay away from humid morning flying though...think I may have experienced a little carb ice Tuesday morning. I had reduced the power some to begin a slow decent and then I noticed the RPM going down even more. It did that a couple times. A friend suggested I put Marvel Mystery Oil in my gas...he had heard that helps. I mix my gas and oil (with my new Ratio-rite measuring cup from Spruce), so I wonder if adding Marvel Mystery Oil as well would be ok. -------- Cristal Mark II Twinstar Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178938#178938 ________________________________________________________________________________
Date: Apr 24, 2008
Good friend Bill, My method for constructing droop tips using urethane carving foam (Aircraft Spruce). Then coat it with that fast-setting joint compound (thanks to whoever suggested the fast setting stuff). The joint compound goes on easily, sand easily, etc. Coat entire surface with epoxy resin, continue dressing up the shape...until it looks pretty good. My droop tip shapes are just by looking at TNK's, and doing the best I can, measuring for simetry. After a finished shape is "perfect, or at least "good enough", coat it with two-three layers of carnuba wax, spray on some layers of PVA liquid film, roll on this guy's Gel Coat I suggested. Wrap the entire outer surface with some fiberglass layers (maybe 6 or so). Wait a day, and voila'!! You have just made a flawless mold for what ever you want to make in fiberglass. Next, with your mold...3 layers of carnuba wax, again. Then the PVA parting agent spray. Then the Gel Coat, again (maybe 3-4 layers)...then the fiberglass cloth and resin (maybe 3-4 layers). Wait a day..and out pops your finished fiberglass part. If there are areas that are too flexible, then add a couple of additional layers on the inside of the piece. For something like droop tips, I do NOT recommend making them. I would not go to the trouble, if I could have a set in a couple of days. The only reason I'm making mine is because I need them now. For the time, trouble and material, it is MUCH easier to just buy them from TNK, when they can get them in. With regard to droop tips going down, and not up. Think about what's actually going on with the air. The air on the underside of the wing is HIGH pressure. As long as you are flying, you want all that high pressure air you can keep, until it passes beyond the back edge of your wing. The air on top, on the other hand, is LOW pressure. You also want to it stay low pressure, as long as it is above your wing. If the air above your wing wanted to "spill" away, it would only get lower. That's even better. What you would most likely have is air from out past the edge of your wingtip wanting to sneak in to the top low pressure area. Although some of this is happening, I don't think it is nearly as important as the lower surface losing air. The winglets on the more expensive type of airplanes are for yaw control and stability, if I'm not mistaken. With the raised tail surface alone, some high speed planes don't have enough yaw control. By adding the winglets you now have THREE vertical surfaces to keep the plane from yawing into the incoming slipstream. With regard to adding droop tips to already finished wings, I have MY opinion how it should be done. You would not alter anything with the finished wing, but, rather, build the droop tip and it's skeleton support around the present wing. Altering the original wing end would only be possible if you haven't covered the wing, yet. BTW, ALL your modifications and changes should be run past TNK for their approval and blessing. I'm only sharing what I have done, and just my opinion, what whatever that's worth...and to some, that ain't much, I'm sure!! william sullivan wrote: My computer service is screwed up, thanks to AT&T Yahoo switching systems, so these comments are late. First- Congratulations to Cristal on her first solo in her new toy. Hope you have many joyful and safe flights. Next- Everybody keep sending the MV photos. I really enjoy seeing places that I will never be able to see in person. The photo of John in the new Kolb gave a very good look at the new wingtips. Mike- if this is what you are making, good luck. I found your lengthy commentary quite informative. Keep it coming. How are you making the reverse molds exactly, meaning right and left? Templating? Question- If drooping down helps, what about the air coming off the ends at the top? Would "drooping" both down and up help? I have noticed a lot of winglets(?) on the planes flying over the house. What about the same on a Kolb wing? About the new Kolb- Does it have bosses on the wing ends, to change the wing end style? Comments, anyone? Bill Sullivan FS/KX/447 Windsor Locks, Ct. --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Apr 24, 2008
Hey John H, What were you pointing at ? David. :-) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178966#178966 Attachments: http://forums.matronics.com//files/fun_n_sun_2008_062crop_650.jpg ________________________________________________________________________________
Date: Apr 24, 2008
It comes from this photo; David Read this topic online here: http://forums.matronics.com/viewtopic.php?p=178967#178967 Attachments: http://forums.matronics.com//files/fun_n_sun_2008_062_849.jpg ________________________________________________________________________________
Date: Apr 24, 2008
In a message dated 4/24/2008 12:51:17 P.M. Eastern Standard Time, d_a_lucas(at)hotmail.com writes: Hey John H, What were you pointing at ? David. :-) The direction he wants the airplane to go Steve FF#007/Floats FF#040/Floats 2008 Sun n Fun UL Grand Champion **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 25, 2008
I just added another video. It's a bit shakey but I'm working on it... http://www.youtube.com/watch?v=y79352Iqk-A Kip -------- Kip Firestar II (born September 2000) Atlanta, GA N111KX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179113#179113 ________________________________________________________________________________
Subject: Wheel pants
Date: Apr 25, 2008
Hey Guy's... I need some help and advice on how to install wheel pants. I have the Matco aluminum wheels and breaks on my Mk111xtra. Any help and pictures of how you fabricated the mounting brackets would be great. Just send them to me off the Kolb list. Thanks.. Bill Futrell ________________________________________________________________________________
Date: Apr 25, 2008
N111KX (Kip) wrote: > Hello, all. It's been a while but I have busy in the shop with the Waiex. I've logged 750+ hours with the wings and most of the fuse done. Hopefully it will be on the gear in a week or so and flying sometime in the fall or winter. > My Firestar still gets plenty of attention and even has a Quickie 1 as a hangar mate (which will be restored when the Waiex is done). > I tried to post this video a while back but was unsucessful but then Youtube came along. I forget how high I was but 3000' sounds about right. > Anyway, here is some summer quiet flying... > > http://youtube.com/watch?v=qDrq_VTPtA4 > > Kip -------- Kip Firestar II (born September 2000) Atlanta, GA N111KX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179119#179119 ________________________________________________________________________________
Date: Apr 25, 2008
Mike I just read your e-mail on the droop wing tips. Thought you might like seeing my wing development and tip fabrication activity. (The photos are compressed because the list rejected the originals) Ron Mike Welch wrote: > Mike, > I don't know how long you're wings are, but mine were built to > standard MkIII Classic (there wasn't an Xtra when I built my wings). > As you are aware, the trailing edge tube is full length. The leading > edge stops about 2 feet short and then begins the "bow" tip. Prior to > any wing tip mods, my wings were 13' 7" at the trailing edge (after > mods, they still are.) Of course, you don't get the full length of > true airfoil on a standard wing, because once you begin the bow tip, > you encounter all that loss of "air" I was talking about. > My 6" tubular wing spar ended at about 11 feet 8 inches (and then at > the front, the bow tip curve began). The trailing edge tube continues > for another 23". To make the modification, this entire length is what > I kept. First, I removed the bow tip, and all the skinny diagonal > reinforcement tubes. (Remember, I don't have fabric, yet. More on this > later.) > Next, I made an extension to the leading edge tube, to match the > length of the trailing edge. I will now have the entire 13' 7" of full > shaped airfoil. > While I was waiting on the epoxy resin to harden on the droop tip > plugs, I began building the truss extension. At first, I began using > aluminum. But within minutes I could see it would take me days to go > that route. Cutting the shaped tubes, making plates to mount them, > etc., etc. No can do!! Then I thought "hey, why not chromoly" Not too > heavy. Easy as hell to simply cut web tubes and weld in place. Try it. > So I cut the lengths (32 inches each, top and bottom), and cut some > web diagonals, and tacked them in place. Fast, fast fast. Welded all > the locations, ground them smooth. Best idea, yet. In the "up and > down" direction, this SOB is SOLID!!! > Slide it in the 6" spar eleven inches, bolt it in place, and it will > easily carry just the last two feet of wing. BTW, although I haven't > done it yet, I will weld several tabs to this truss, for the diagonal > braces. I am very comfortable with the internal structure of the wing > extension. It damn sure will get the job done!! > Regarding the "last rib". I built it with aluminum stock that I had on > hand. I used some angle aluminum. If I were to do it again, I would > buy some 1" wide FLAT alum. strap X 1/8" thick. Your end rib can NOT > be made of tubes, like all the other ribs. > My wingspan was originally close to 30' 2". The only addition is just > the tips, about 6" each. > With regard to my crash, I restored an older Wizard ultralight. It > looks like a Quicksilver. > I had "some" pilot training years earlier, and thought that would be > enough to allow me to do some crow hops. I was doing fine all day, but > not really ever in complete control. As I added power, it climbed. But > this scared me, so I held just enough airspeed to stay aloft (riding > on the edge of stall all day). Eventually, fate will catch up with > that plan! I started drifting away from the runway, and toward some > trees. As I tried to turn back to the runway, I just nosed in, into > the dirt. Crumpled the nosegear, etc. Hurt so goddamn much I thought I > WAS dying!! I wiped out one of the reinforced downtubes with my neck. > This twisted my back beyond anything I have ever done before. My pain > was in the red, on the "shit-o-meter"!! > Analysis. All this was MY fault. The ultralight flew just fine. Good > friend and pilot, Lou Wetzel flew it earlier, prior to me. _The fault > lies with the idiot in the pilot seat not flying the damn plane!!! _ I > don't want to EVER want to hurt that bad again! I have since then > gotten my pilot's license. However, I also don't want to ASSUME > anything anymore. Even prior to flying my MkIII I will try and find > someone who will share some MkIII flying time with me. > BTW, how did YOU manage to solo your Xtra? I'll be honest with you, it > scares the livin' bu'jesus out of me to think about soloing my plane. > I think I'm a pretty good pilot in my Cessna, but I found out what can > happen if you aren't correct. > Yes, I think you can add droop tips. BUT!!!! > With regard to you making the droop tip conversion to YOUR plane. I > would NOT alter anything on your present wing. DO NOT CUT ANYTHING. If > you do, you'll open up such a shitstorm of grief you won't believe it! > It would be easier to build brand new wings, at that point! Once you > cut the fabric along the outer edge, the entire wing loses it's tension. > That would be so much work I wouldn't even want to think about it! > What you CAN do is like I suggested a while back. Build the droop tip > design completely around your finished wing. This would be absolutely > EASY. But Kolbs droop tips, get some of that aluminum flat strap, > etc....build a solid substructure, making it look like you have full > airfoil all the way to the end, fabric, paint, slide on tips...you're > done. You don't need to add any 6" spar, because your wing isn't > carrying any more lift requirement than it did prior to addition of > droop tips, except you will no longer have "spilled" air. > Put simplistically, you'd build your droop tip addition AROUND your > present wing. Cheap, easy and just as effective as if you built them > that way in the first place. Plus, NO ONE would ever know you had > stock wings inside your droop tip wings. *_That penalty would be > several ounces of aluminum and fabric that were left inside your new > shape. Big deal!!!!_* > After working with Poly Fiber recently, I am even more convinced this > is the best way. Like I said, if you cut that outer edge fabric, > you're in for a total wing rebuild. $$$$$$$$ > An expression like "you're screwed!!" comes to mind!! > More later, when I can post some pictures.... > Mike Welch > BTW, With VGs, which are a hellava good idea, I would think your stall > could be down to about 22-23 mph, with MORE aileron control (due to > the droop tips). You are already getting better aileron control from > the VGs. > > > */JetPilot /* wrote: > > > Mike, > > I think you are right on about the Wingtips, and you are > definitely right on about increasing safety any time you can lower > the approach and stall speeds in your Kolb. Are you adding any > length to your wings ? What will your total wingspan be ? > > I am also going to add the wingtips to my Kolb, but I don't have > the time or the skill to make fiberglass ones, so I will have to > wait for Kolb to start selling them. At the same time I am putting > on the new wingtips, I will also add 2 feet of spar to each > wingtip to make the wings as long as the new Kolb MK > --------------------------------------------------------------------- --- > Be a better friend, newshound, and > > * > ============ ============ ============ ============ > > * > ________________________________________________________________________________
Date: Apr 25, 2008
> Hey John H, What were you pointing at ? > > David. :-) Hi David L: I don't know. ;-) Think this photo was snapped during the Manufacurers Showcase. I was flying 30 mph, 45 degrees of flaps, and being very gentle with the control stick at that very low altitude. Did you take that photo David? Was shot from the south back to the north? Looks like the Fly Market Tent in the background. john h mkIII ________________________________________________________________________________
Subject: Re: Dead Stick and other Videos
Date: Apr 25, 2008
That dead stick video motivated me to finally do something I've been thinking about for awhile. Yesterday I flew to a nearby airport that rarely sees traffic and did an overhead approach from about 1800 feet AGL, with the engine off and prop stopped. The factory (Allegro) says that best glide speed is 70 mph so I set up a glide at that IAS, made two complete 360 degree circles and saw that I was going to be a bit high when crossing the threshold and added full flaps, touching down around mid-field. I've done engine off, prop stopped glides before but only on final. What amazed me is the large difference in descent rate with prop stopped compared to idle power glide under same conditions. At idle power the descent rate is 400 fpm but at the same speed with prop stopped it was 700 fpm. Moral of the story, as some have urged on this list before, is that you don't really know how an airplane will perform with the engine and prop stopped until you test it in a safe environment. The advertised glide ratio for the Allegro is 12 to 1 but my testing showed it to be about 8 to 1 (70 IAS on my ASI is about 65 mph TAS). I suspect it will better at higher speeds but won't know for sure until I test it again. BTW, with idle power 400 fpm yields about 14 to 1 glide ratio. I will do this test at various glide speeds with the FS when I finish the rebuild. Obviously, at idle power some thrust (or a lot less drag) is being produced than with prop stopped. There is a theoretical prop/engine rpm that equates to zero thrust for each glide speed and prop ptich. For those interested, I've attached a spreadsheet that calculates this theoretical prop/engine rpm for a given prop pitch and glide speed. Any rpm below this zero thrust rpm will result in more drag and any rpm above this zero thrust rpm will net some thrust. -------- Thom Riddle N221FA Allegro 2000 912UL N197BG FS1/447 -------------------- Believe nothing, no matter where you read it or who has said it, not even if I have said it, unless it agrees with your own reason and your own common sense. - Buddha Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179215#179215 Attachments: http://forums.matronics.com//files/zero_thrust_rpm_calculator_795.xls ________________________________________________________________________________
Date: Apr 25, 2008
Bill, There were quite a few posts recently regarding mounting wheel pants. Most of them were on April 5th & 6th. If you can go back and look at you Kolb inbox on those dates you will find what you're looking for. If you have any trouble pulling them up, let me know. I will forward them to you. Mike Welch Kolb MkIII with newly installed wheel pants!! ________________________________ From: bill_joe(at)bellsouth.net Subject: Kolb-List: Wheel pants Date: Fri, 25 Apr 2008 08:45:14 -0400 Hey Guy's... I need some help and advice on how to install wheel pants. I have the Matco aluminum wheels and breaks on my Mk111xtra. Any help and pictures of how you fabricated the mounting brackets would be great. Just send them to me off the Kolb list. Thanks.. Bill Futrell _________________________________________________________________ Spell a grand slam in this game where word skill meets World Series. Get in the game. http://club.live.com/word_slugger.aspx?icid=word_slugger_wlhm_admod_april08 ________________________________________________________________________________
Subject: Mark11
Date: Apr 25, 2008
You are not going to believe this. I finally made it back into the air today. Two 15 minutes circuits. One b-----y terrible landing and one reasonable one. I crashed the plane 21/07/06 Seeems a long time ago. What looked at first as just a wing rebuild escalated into a new cage and consequent total replacement of all connections and fittings. In fact everything is new except the boom and the tail feathers. The PFA insisted on treating the rebuilt plane as new. Which it was I suppose. By the time the plane was rebuilt and checked out my flying license had expired. Finally got the plane and myself signed off just before Christmas. The check flight was the first time I had flown since the accident. Since then, weather, holidays, weather, weather has kept me confined to taxy trials. Today was grey but the wind was around 5 mph and cloudbase was around 1800 ft. I checked and found that I had only managed about 5 hours in the Kolb before the crunch so I was hardly what you call experienced. Anyway, with a gulp and a little prayer that the various changes of C of G I had made were going to pan out OK away we went. Off the ground easily a slightly lumpy climb out, particularly when taking off the flap (that is a terrible system) and a few minutes trimming and doing a few fairly sedate turns, round the circuit and into an awful landing. As the first solo landing since July `06 I don`t suppose it was really that bad. Another circuit and a much better landing and I tucked her away and rushed off to a Rotary lunch. Away again all next week so next weekend is the next opportunity but anyway I have broken my duck. Hooray The Wx is pretty poor anyway Cheers Pat ________________________________________________________________________________
Subject: Re: Mark11
Date: Apr 25, 2008
Welcome back Pat. Be careful of those buildings in the future. On 25, Apr 2008, at 5:36 PM, pj.ladd wrote: > You are not going to believe this. I finally made it back into the > air today. Two 15 minutes circuits. One b-----y terrible landing > and one reasonable one. > > I crashed the plane 21/07/06 Seeems a long time ago. > > What looked at first as just a wing rebuild escalated into a new > cage and consequent total replacement of all connections and > fittings. In fact everything is new except the boom and the tail > feathers. > > The PFA insisted on treating the rebuilt plane as new. Which it was > I suppose. By the time the plane was rebuilt and checked out my > flying license had expired. Finally got the plane and myself signed > off just before Christmas. The check flight was the first time I > had flown since the accident. Since then, weather, holidays, > weather, weather has kept me confined to taxy trials. > > Today was grey but the wind was around 5 mph and cloudbase was > around 1800 ft. I checked and found that I had only managed about 5 > hours in the Kolb before the crunch so I was hardly what you call > experienced. Anyway, with a gulp and a little prayer that the > various changes of C of G I had made were going to pan out OK away > we went. Off the ground easily a slightly lumpy climb out, > particularly when taking off the flap (that is a terrible system) > and a few minutes trimming and doing a few fairly sedate turns, > round the circuit and into an awful landing. As the first solo > landing since July `06 I don`t suppose it was really that bad. > Another circuit and a much better landing and I tucked her away and > rushed off to a Rotary lunch. > Away again all next week so next weekend is the next opportunity > but anyway I have broken my duck. Hooray The Wx is pretty poor anyway > > Cheers > > Pat > > ________________________________________________________________________________
Date: Apr 25, 2008
Subject: Re: Mark11
pj.ladd wrote: > You are not going to believe this. I finally made it back into the > air today. Two 15 minutes circuits. One b-----y terrible landing and > one reasonable one. Pat, Good on you!!! You will be the better pilot for all of your trouble and determination! Terry - FireFly #95 ________________________________________________________________________________
Date: Apr 25, 2008
Subject: Internet connection vs. photos
Henry, Thank you for the response! I do agree that intentions are not always clear on the internet. My intentions were to have the other members of this list be more considerate of those without the newest and fastest servers available. I thought I had detected a condescending note in some of the post about those with limited access to the Kolb List and their ability to deal with large format pictures. Ergo my post! I live in a beautiful place called Lancaster County, PA where we have many Amish ( Plain people) amongst us. We "English" have to tolerate their driving their horse and buggy vehicles on our roads and there are many that complain loudly about the inconvenience it causes them. To the Amish, even a bicycle is a fast moving object much lest our cars. The benefit of having them among us far out weighs the inconvenience they cause on the roadways! Those of us who live with them have learn to be tolerant of their choice of life style and give them due respect on the roads which sometimes causes delay and safety hazards. I cannot access high speed even if I wanted to. The nearest cable line is 1-1/2 miles away and "they" won't consider running the line my way. Not enough houses, so they say. I also live on the North side of a hill in the woods which precludes satellite reception. All I was asking for is some reasonable consideration from the others on the Kolb List. John W. posting of JPG.s of the Monument Valley group is not a problem and much appreciated which I tried to relayed to him. Others could limit the size of their postings pixtel wise. When I joined the Kolb List many years ago it was a more friendly place than lately. Seems ever year there is a new comer with an attitude, one of which you alluded to in your last post. Hopefully there is room on the list for those of us that don't have the latest high speed capabilities that many enjoy. Hope you allow room on the road for us also!! I do know how to limit the size of incoming mail, I just didn't want to be relegated to the back of the bus on this list. Courtesy goes a long way in all endeavors!!! Lastly, I do agree with your analysis of the FireFly being one of Homer's and Dennis Souder's best creations. Hope to have to opportunity to meet you one day. Any chance of your coming to the Father's Day fly-in at Homer's this year? Terry - Firefly #95 ________________________________________________________________________________
Date: Apr 25, 2008
Subject: Re: Dead Stick Video
Kip, Incredible video. Your "minimalist" Firestar really captures the spirit of flying and I think it's one of the best looking F2s around. The video really does a great job of capturing that same spirit. I saved some photos you had posted of your plane years ago when I was looking for ideas for building my own. I've been interested in Kolbs for about 10 yrs but money and family commitments kept me from building. Last year I finally couldn't wait anymore and after much thought (about 15 min, I think) started seriously looking for a plane. Fortunately found one in time to do the ELSA certification. Keep up the good work Dan G 503 F2 N963DG Tucson, AZ N111KX (Kip) wrote: > >I just added another video. It's a bit shakey but I'm working on it... > >http://www.youtube.com/watch?v=y79352Iqk-A > >Kip > >-------- >Kip >Firestar II (born September 2000) >Atlanta, GA >N111KX > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=179113#179113 > > > > ________________________________________________________________________________
Date: Apr 26, 2008
> Did you take that photo David? Was shot from the south back to the north? Looks like the Fly Market Tent in the background. Yes John, I stood against the fence in the car park in the shade of an RV and took several shots of the passing parade. Got several of the approach/landing phase mainly, some at Take Off and a couple during the slow fly past. Here's one of your slow fly past; David. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179304#179304 Attachments: http://forums.matronics.com//files/fly_past_2_139.jpg ________________________________________________________________________________
Subject: Some Sun'n Fun photo's for the Dial Up folks
Date: Apr 26, 2008
Enjoy ! If you want the Hi Res version, let me know. David. The message is ready to be sent with the following file or link attachments: Fly Past 1.jpg Fly Past 2.jpg Fly Past 3.jpg Fun 'n Sun 2008 059crop.jpg Fun 'n Sun 2008 062.jpg Fun 'n Sun 2008 071.jpg New Wingtip 1.jpg New Wingtip 2.jpg ________________________________________________________________________________
Subject: Fwd: virus alert!!!
Date: Apr 26, 2008
Kolbers As far as I can tell, this is a genuine threat > Subject: Virus Alert checked on snopes.com > > I checked with Norton Anti-Virus, and they are gearing up for this > virus! I checked snopes.com, and it is for real!! Get this E-mail > message sent around to your contacts ASAP. PLEASE FORWARD THIS > WARNING AMONG FRIENDS, FAMILY AND CONTACTS! You should be alert > during the next few days. Do not open any message with an > attachment entitled 'POSTCARD,' regardless of who sent it to you. > It is a virus which opens A POSTCARD IMAGE, which 'burns' the whole > hard disc C of your computer. This virus will be received from > someone who has your e-mail address in his/her contact list. This > is the reason why you need to send this e-mail to all your > contacts. It is better to receive this message 25 times than to > receive the virus and open it. > > If you receive an e-mail called POSTCARD or that says "You've > received a postcard (greeting, birthday card) from . . ., " even > though sent to you by a friend, do not open it! Shut down your > computer immediately. > > This is the worst virus announced by CNN. It has been classified by > Microsoft as the most destructive virus ever. This virus was > discovered by McAfee yesterday, and there is no repair yet for this > kind of virus. This virus simply destroys the Zero Sector of the > Hard Disc, where the vital information is kept. > > COPY THIS E-MAIL, AND SEND IT TO YOUR FRIENDS. REMEMBER: IF YOU > SEND IT TO THEM, YOU WILL BENEFIT ALL OF US > > No matter where you go, there you are. > Plan your next roadtrip with MapQuest.com: America's #1 Mapping Site. ________________________________________________________________________________
Date: Apr 26, 2008
OOps! It looks like the images didn't stay attached. See if this works. This is the extension of the spar and the full fibs to the wing tip. If this works I will show the plug mold for the wing tips. Ron Hoyt wrote: > Mike > I just read your e-mail on the droop wing tips. Thought you might like > seeing my wing development and tip fabrication activity. (The photos are > compressed because the list rejected the originals) > Ron > > > Mike Welch wrote: >> Mike, >> I don't know how long you're wings are, but mine were built to >> standard MkIII Classic (there wasn't an Xtra when I built my wings). >> As you are aware, the trailing edge tube is full length. The leading >> edge stops about 2 feet short and then begins the "bow" tip. Prior to >> any wing tip mods, my wings were 13' 7" at the trailing edge (after >> mods, they still are.) Of course, you don't get the full length of >> true airfoil on a standard wing, because once you begin the bow tip, >> you encounter all that loss of "air" I was talking about. >> My 6" tubular wing spar ended at about 11 feet 8 inches (and then at >> the front, the bow tip curve began). The trailing edge tube continues >> for another 23". To make the modification, this entire length is what >> I kept. First, I removed the bow tip, and all the skinny diagonal >> reinforcement tubes. (Remember, I don't have fabric, yet. More on this >> later.) >> Next, I made an extension to the leading edge tube, to match the >> length of the trailing edge. I will now have the entire 13' 7" of full >> shaped airfoil. >> While I was waiting on the epoxy resin to harden on the droop tip >> plugs, I began building the truss extension. At first, I began using >> aluminum. But within minutes I could see it would take me days to go >> that route. Cutting the shaped tubes, making plates to mount them, >> etc., etc. No can do!! Then I thought "hey, why not chromoly" Not too >> heavy. Easy as hell to simply cut web tubes and weld in place. Try it. >> So I cut the lengths (32 inches each, top and bottom), and cut some >> web diagonals, and tacked them in place. Fast, fast fast. Welded all >> the locations, ground them smooth. Best idea, yet. In the "up and >> down" direction, this SOB is SOLID!!! >> Slide it in the 6" spar eleven inches, bolt it in place, and it will >> easily carry just the last two feet of wing. BTW, although I haven't >> done it yet, I will weld several tabs to this truss, for the diagonal >> braces. I am very comfortable with the internal structure of the wing >> extension. It damn sure will get the job done!! >> Regarding the "last rib". I built it with aluminum stock that I had on >> hand. I used some angle aluminum. If I were to do it again, I would >> buy some 1" wide FLAT alum. strap X 1/8" thick. Your end rib can NOT >> be made of tubes, like all the other ribs. >> My wingspan was originally close to 30' 2". The only addition is just >> the tips, about 6" each. >> With regard to my crash, I restored an older Wizard ultralight. It >> looks like a Quicksilver. >> I had "some" pilot training years earlier, and thought that would be >> enough to allow me to do some crow hops. I was doing fine all day, but >> not really ever in complete control. As I added power, it climbed. But >> this scared me, so I held just enough airspeed to stay aloft (riding >> on the edge of stall all day). Eventually, fate will catch up with >> that plan! I started drifting away from the runway, and toward some >> trees. As I tried to turn back to the runway, I just nosed in, into >> the dirt. Crumpled the nosegear, etc. Hurt so goddamn much I thought I >> WAS dying!! I wiped out one of the reinforced downtubes with my neck. >> This twisted my back beyond anything I have ever done before. My pain >> was in the red, on the "shit-o-meter"!! >> Analysis. All this was MY fault. The ultralight flew just fine. Good >> friend and pilot, Lou Wetzel flew it earlier, prior to me. _The fault >> lies with the idiot in the pilot seat not flying the damn plane!!! _ I >> don't want to EVER want to hurt that bad again! I have since then >> gotten my pilot's license. However, I also don't want to ASSUME >> anything anymore. Even prior to flying my MkIII I will try and find >> someone who will share some MkIII flying time with me. >> BTW, how did YOU manage to solo your Xtra? I'll be honest with you, it >> scares the livin' bu'jesus out of me to think about soloing my plane. >> I think I'm a pretty good pilot in my Cessna, but I found out what can >> happen if you aren't correct. >> Yes, I think you can add droop tips. BUT!!!! >> With regard to you making the droop tip conversion to YOUR plane. I >> would NOT alter anything on your present wing. DO NOT CUT ANYTHING. If >> you do, you'll open up such a shitstorm of grief you won't believe it! >> It would be easier to build brand new wings, at that point! Once you >> cut the fabric along the outer edge, the entire wing loses it's tension. >> That would be so much work I wouldn't even want to think about it! >> What you CAN do is like I suggested a while back. Build the droop tip >> design completely around your finished wing. This would be absolutely >> EASY. But Kolbs droop tips, get some of that aluminum flat strap, >> etc....build a solid substructure, making it look like you have full >> airfoil all the way to the end, fabric, paint, slide on tips...you're >> done. You don't need to add any 6" spar, because your wing isn't >> carrying any more lift requirement than it did prior to addition of >> droop tips, except you will no longer have "spilled" air. >> Put simplistically, you'd build your droop tip addition AROUND your >> present wing. Cheap, easy and just as effective as if you built them >> that way in the first place. Plus, NO ONE would ever know you had >> stock wings inside your droop tip wings. *_That penalty would be >> several ounces of aluminum and fabric that were left inside your new >> shape. Big deal!!!!_* >> After working with Poly Fiber recently, I am even more convinced this >> is the best way. Like I said, if you cut that outer edge fabric, >> you're in for a total wing rebuild. $$$$$$$$ >> An expression like "you're screwed!!" comes to mind!! >> More later, when I can post some pictures.... >> Mike Welch >> BTW, With VGs, which are a hellava good idea, I would think your stall >> could be down to about 22-23 mph, with MORE aileron control (due to >> the droop tips). You are already getting better aileron control from >> the VGs. >> >> >> */JetPilot /* wrote: >> >> >> Mike, >> >> I think you are right on about the Wingtips, and you are >> definitely right on about increasing safety any time you can lower >> the approach and stall speeds in your Kolb. Are you adding any >> length to your wings ? What will your total wingspan be ? >> >> I am also going to add the wingtips to my Kolb, but I don't have >> the time or the skill to make fiberglass ones, so I will have to >> wait for Kolb to start selling them. At the same time I am putting >> on the new wingtips, I will also add 2 feet of spar to each >> wingtip to make the wings as long as the new Kolb MK >> ------------------------------------------------------------------------ >> Be a better frie===== >> >> * >> > > * > =========== =========== =========== =========== > > * /9j/4AAQSkZJRgABAAEAlgCWAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AFE4PUc9M1FHQkdbVlFgesyEenBwevmyvJPM//////////////////////////////////////// //////////8BVltbemt674SE7/////////////////////////////////////////////////// ///////////////////////EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIA/IIJAMBIgACEQEDEQH/ 2gAMAwEAAhEDEQA/AKtFFFAC09elMpy0hjqG+7RS9qAIwMikoHFBoAKKKKACkpaKAG0UHrRTEFLS UtAwooopAFLSUtAwooooAQDJp+0Cm96cTQIWimlhTSxoAfQWAqPJNFFguOLUm40lFMQUUUUAFFFF ABRRRQAUUUUAFFGKOKACjFGaKAFozSUUAFFFKFNACUU4LTsCgBgBpQtOopDAACikLCm7jQA+kLCm ZooAcWpuSaKKYgooooAKKKKAClFJSigaFooopDG0tFFMQUUUUgCiiigBaKKKBhRRRQAUtJS0DENN pxpKCWJS4opKYhaM0lFABRTgpNKEHegBlKFJqTAHSilcdhuz1pQAKM0hagB1JmmbjSUWC4/cKQsa bRQIXJpKKKYBRRRQAUUUUAFFFFABRRRQAUUUUAFLSUUAFKKKKAFFLSClpFiUUGigQUUUUAFFFFAB SikpR0oGhaWkpaBBRRRQAUUoBPQU8RN34oAjoHtU4iUdeaeAB0FAEAjY9sfWnCIZ5bNS0tIBgRR0 FOpaKAEopaKAEopaKAEpaKKAEPSo265qQ9KioAQ9ab0p1JTEJnDA1YI5qs3Q1YU5QGkxjflz6CjH Unk9hSkc5pO/1pALjOeDTc/LjHApQcNkUEjOMcUAHHBJxRjIBo6npRg4xTATucUuTgAD60Y69z2o x0oADyeOKMZO3OAKdjBByBTcjJ46+tACggHgdutID+GKXB9P/r0H360AHI5xxSFdwJ9KOn0PWlOM jA4oAhpaWRQG3L9002mIWikzRmgBaM0maM0ALRSZozQAtLTc0ZoAdSg4PFMzUkaFjzwKAHKd7Dkn 1qXAHQUAADAGBRSGFFFFMAooooAKKKKACilooASiiigBaKACaOB15oEJ16UuMfeOKQsTwBik25oA XcB90fjSEE/eNLwKUZzQAnQUlObgU2gAoxRRQAYoopaBiYoxS0UAFFFFABijAoooAKKWigAooxQS B1IoEFFJnPQE0vPsKAFopPzpMUALkUZoooAM0ZoooAOaSlooGJS0UUgExRilopgN20m2n0UCI8Um KlxSYoAi20bal20m2gCEoD2o2kfdYipdtJigBBIw+8Aw9qkV1boefQ1HikKg9qLATUVErMvQ5Hoa kV1PsfQ0gFopaKBiUUtJTAKKWkoAKKKWkAlFLRQAlLRRQAUUUUAJRilooAT8aKWigBKM0tFABRSY ooAKKKKAEpMU6koATFFLSUAGKB70tFABS0UUAFFFFAGbRRRVEi0q9aSikMkpaSgUAMbhjSU5+tMo AWiiigAooooAaetFB60UxBS0lLQMKKKKQBSikoFAC0UUUDENJSmkpkhRRRQAUUUUAFFFFABRRRig AopeKM0AJilxRmkoAWkzRRQAUUYpwU0ANop+0ClpAMCmnBRS0ZoGGAKKaWpNxoAfmmlhTaKYhdxp KKKACiiigAooooAKKKKACilooASlpKKAFopKUUDFooopDEooNFMQUUUUAFFFFIBaKSigYtFFFABS 0lFAwPSm06nBRQSxmCaUIafRRcLCBQKWkLAU0v6UAPpCwphJNJRYLji1Jk0lFMQUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRS0AJS0UUAFFFFACilpBS0i0JRRRQIKKKKACiilAJ6DNA CUoqRYHPXipFhUdTmgZCKcI2ParAUL0AFLQIhEP941II1HQU6ikAUUUUAFFFFABRRRQAUUZpM0AL RSUUALRSUUAFFFFAAelREVL2qNsg0AN+tJSnrSYpiENTRH90KiJqSL/VikxodSYG3jr3paZk56Uh gOM0uSeMDj0oIw3rSnp97PqMUAIwyMk0bcfWl+lBGRkmgQAgkDp7+lJkHK9s/nQpOCABz1Jpehxx 9aYCHg4/OjqMdcUA80oUcnsKAEX5iaXoPXd3o3HHBFIOB0/GgBV4OO1OPK4xx7Uzgg54p2TjpigB CNwweB2qvgg4NTk5HFKcdcc0AQBSegpwib6VLk9uKPmPemIj8r1NOES92p200uygBuyPsTSbU9Kk 2etLgUAR4HZBTthJ6AU+igBoQD3p1FFAwpaSikAtFJRQAtFJRQAtFJRQAuaM0AE9KXCryeTTEIMn oKXgdsmkyTyeBRyaAAk96OMc0AUpAH3jQAfSgKaTd/dX86Q5bqaAHZUe5pCWPtSdKWkMToMUdqWm r0I70AOpPel7Un8Q9qAFFFFLTASilooASloxRuAoEGKXFNyx6DFGwfxGgBdwHfNGWPQY+tKMDoKM 0AJt/vNn6UAAdBRRQAUUUUAFFFFABRRS0AJRS0UAJRS0lABS0UUAFFFFABRRRQAUlLRQAlFLRQAl GKWigBu2k20+igCPBpCPUVLSYoAjBK9Dx6VIGDex9KTbSFaAH0UwMRweacCD0oAWiiigYlLRRQAU UUUgCiiigAooooAKKKKACiiigAooooAKKKKACiiigBMUUtFACUUUUAJRS0lAC0UlLQAlFLRQBm0U UVRItJRS0gHr0pRTU6U6gYj9KjqUjIqOgBKWiigAooooAaaKU0lMQUtJS0DCiiikAUCigUALRRRQ MQ0lONNpiYUUYpcUCEopeKM0AJil4pKKAFzSUUUAFFKATShPWgBtABNSBQKWkMYE9aUKKdSEgUAL RTC/pSFiaAHkimlqbRQIXcTSUUUwCiiigAooooAKKKKACiiigAooooAKKKKACilCmnBRQA3FKFp1 FIdhABS0hYUm4mgANFFFAxDRQaSmIWiiigAooopAFLSUUDFopKWgApaQUtAxDTtwpp6U2gTHFjSZ JpKKZIUUuKXFADaXFLQaAG0UUUAFFFFABRRRQAUUUUAFLSUUAFLSUUAFFLSUAFFLSUAFFLRQAUUU UAFFFKFJoASgU8JS4FIYwUtOwKcImPQYoKIqKsCAfxHNSBFXoooEVQjN0FSrbn+JsVPSUXAasSL2 z9af2pM0UgDHqaWkooAWkoooAKKKKACiiigAooooAKKKKADiiiigAoopaAEopaTj1oAKKMijIoAK Y3T6U7PtTX6UAMoNIaDTEIalj+5UR6VITtQYGaTGOpKaH3dqKQDlJzgde1HANMzg5HapCVb5scGg BDg+wpTnYF/IUmc8DigEdhimAfxYoJG7nntSgDkkkf1oJ44/L0oAORkcfSjHOPzoPK5zzQw6fzoA ME9OnajPTPbtSZTuePSjcpPyqaAAnPHYUE8Y4wetKB6J+tLtz7UANLdBilDf7NOCgUtADQw9DS5H ofypaKADIozRRQAZozRRQAZozRRQAZoyewoooAMt7UnzeopaKAE+b1H5UfN/e/SlooAT5v736UfN /e/Slxmn7QOpoAYAzdG/Sn4Cjk7jQWzwOlNx6CmIUsT7Ck9wPxox60oI7mgAHNO4A5pN2eF49zTc H60ALuJ6cUmPxNHNGfY0ALRik3AdjSeYP7poAdj3ox703zB/dNJ5n+waAH4PrRz6imeYf7lHmN/d H50AP+b2pMn0FN3t6Cje3tQA/J7ijcf7tJuNGf8Aax+FAC7v9mjJ7LS4P96jB/vGgBMZ+8aUYHQU bT/eNG0/3jQAvJ70mKTYf75o2H++1ADsUbaZ5X+21J5I/vNQBJtoxUfkL6mk+zr60AS8eoo49RUX 2daPIWgCTK/3hRuT+8Kj8lfSmuqRjLd+g9aAJtyf3hRuX+8Kj8oY6UnlCgCXcn94Ubk/vCovKHtR 5X0osBJuX+8KXK/3hUPl+wo8v/ZFFgJ+PUUuKreX/s0bCPUUAWcUlQfOOjGjfIP4s/UUAT0VD5r9 wDThN6ofwNAElFMEqd8j6inBlPRhQAtFLikoAKKKKACiiigAooooAKKKKAE60hX0p2KKAG5I6jNO HPSikxjkdaAFopM+vBpaACiiigAooooAKKKKACiiigYUUUUAFFFFABRRRSAKKKKACiiigAooooAS iigkDrQAYpKAQelLQAn40fjRijAoAzqKWkqiQpaSloAVOtPqMdakpDFqI9alHSo3HzUAJRRRQAUU UUAIaSlNJTEFLSUtAwooopAFAoooAWiiigYUlLTaBMXNJRRTEFFKFJpwT1oAZSgE0/AFLSHYYE9a cFApaQsBQAtFML+lISTQFx5IFNL+lNopiFJJpKKKACiiigAooooAKKKKACiiigAooooAKKKKACil ANKFoAbShTTwMUUrjsIFpcUZAppb0oAdSFgKbkmkosFxxam9aKKYgpRSUtAC0UUUihDSUppKYhaK KKACiiikAUUUUDClpKWgAFLSCloGhKbTqSgTAU7FIKdmgEJRQTSZoBi0hpM0UCuJRRRTEFFFFABR RS0AJRRS0AFJS0UAFJS0UAFFFFABRRSgE0AJRTglOCgUDsMCk04JUgRj0FPEXqfypBYhAApwBPQZ qcIo7U6gZCImPXinCJR15p9FIAGF6cUUUUAFFFFABRRRQAUUUUAFFFFABRRRigBMilo/KloASjFF FAC0lFLQAlLSUUALRSUUALmkopMUAFGaXFGKAG0U7FFMBtI3SnYoxQBCaSpigNN8v3oEMUZP0p5a l8s464FKIxQMjz6UYJqXZRsNAiLb605MKGB6GpNlGwetADQvGf50gYeoxT9i+lKAOwpDIgcjoTS/ MTnaPxNS0ZoAi2N/eA+gpfKHck1JmkoAQIo6CnUlFAC5pKKKACiiigAopcUceooASijgd6Mj1p2E FGKNw9aNy+tABiijcPWkLD1oAWim7xSbxQA+jIqPdSbqAJM0ZNR7qN3tQA/JHel3H1qPf7Ck3GgC XJ9aMmotxo3GgCbcaNxqDJ9aXPvQBNml3D0qDPvR+NAE+6k3GoM0UAT5pc1BmjNAE+T60bjUGaXJ oAmzRxUOTRk+tAEuBRgVHk0ZNAEv1NGKjyaMmgCTGOnFKGI681FuNLvPrQBOCD0oqDcfWl8xvWgC aiofMb1pfMb1oAloqLzWpfNPoKAJKKj832pfNX0oEPopvmL70b19aAHVEIy03mP26CpNy+tLketM BKMUtGKAG4oxTqKAG4oxS0UAJiilooATFGKWigBuKTaKfRQAzaKQxg9qkpKAI9mOhIpfnHR/zFPo oAbucdVBpfMHdSKXFFFgAOp6MKdimFQeopNijpkfSlYZJSUzaw6OaX94P4gfqKAHUU3c/dAfoaPM x1VhQA6imiRD/F+dOHPQ5oAKKKKACiiigAooooAKKKKACjNFFABmjNFFABmiiigAzRz7UUUAHPoK Mn0FFFABk+g/OkyfT9aWigAyfSjPtSUUALn2ozSUUgDNGRRRTAKKKKACiiikBTwPSjFLSUARMMGi lfrTaYhaf2plPXpQMcKZJ2pwof7tAEdFFJQAtFFFACGkpTSUxBS0lFAxaKKKQBRRRQAtFFFAwpAC TS0qn5sUAwCetOwB2opCwFAhaKYX9KQkmgLjywFNL+lNooEBJNFFFMAooooAKKKKACiiigAooooA KKKKACiiigAopcE0u31oAbSgE04AClpDGhfWnAUdKaWoAdRkCmZNJQFxxb0pMk0lFMQUUUUAFFFF ABRRRQAUtJS0ALRRSUigNJSmkpiFooooAKKKKQBRRRQMKKWigAFLSCloGgptOptAmANGaKKZIUlL RQAlFLRQAlFLRQAlFLSUALRRRQAUUUUAFFFABNABRTgnrT1TPQZoHYiAJpwT1qcQnuQKeI1HXmkF iuF9BmpBGx7YqYcdBRSuMYIgOpzTgAOgpaKADNFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFLRQAl LRRQAUUUYoAKKMUYoAKKMUuKAEopaKAEoxS0UAJijFLRQAlFLRQAlFLRQAlGKWimAmKMUtFABijF FGR60gCik3D1FN3IO9Ah9FMMq+ppPNHoaAJKKi832pPNPoKAJc0VD5jUm9j3pgT0magyfWjPvRYL k+4Um8etQZ96Mj1pWC5N5g9aTzBUW4etJuHrTsBL5ntR5hqLeKTzBQBN5h9qC5PeofMFJ5ntQBLn NHFReZ7UnmGgCbijNQ+YaTeaAJ80ZqDefWk3H1oET5ozUG4+tGTTAnzRketQAZpcGgCXcPWjcPWo cGjBoAm3A0ZqOP71SUhhmjNFFABmjNFFMAzRmiigAzRk0UUAGTRk0YpCQKAFyaXNIFdug49acIT3 NIBu6jfUohFL5Sj1pgQ7zRvqXYvvQYh60ARiSnBs0GKmmOgQ/JpN3rTMMvSl3/3hQMeDnpS/hQCD 0paQCfhRTqKAG5FHHrTqKAG8etLx60uKTA9KADA9aMe9GB6UbRQAbaNpo2il2e5oATaaNp9KXYez Uvlt/eFACcigE+tId69TmjcfagB24jvS729aZvPoKN3+zQA/zCKXzPYVHuHpRuFAiXzB6UeYvvUW R60vHrQBLvX1pcj1FQ0YpgT0lQ0oY+tAEtFM3n60eZ6igB9FJvX3pQQehoAKKXFFACUUtJQAUUUU AFFFFACEA9QDTTGh7Y+lPooAZsI+67CmySPFgEqxPanyOI1yeSegqqSSSSck0DSuTC5H8SEfSnia I/xY+oqrSVJVi8CD0INLVDA7cU9ZZF6N+dArFuioFuT/ABp+IqRZY36Ng+hoAfRS4pKYgooooAKK KKACiiigAooooAKKKKACiiigBKKWigBKKWigBKKKKACiiigCkXFMLmm0UWAUknrSUUtMQU5KbSr1 pDH0p6YpKUUARUlKetJQAtFFJQAHpSUp6UlMQUUUUALRRRSGFFFFAC0UCigYUmcHilpDQDEJJooo pkhRRRQAUUUUAFFFFABRRiigApcUlFAC0lFFABRRinBTQA2lAzTgBS0h2GhaXAFLSFgKAFoppam5 zQA8sKaWNJRTEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFLiigBaKBRSKENJSmkpiFooooAKKKK AClpKWkMKKKKAClpKWgaCm06m0CYUUUUyQooooAKKKKACiiigAoooxQAUU4ITUqwHvxQOxBgmnBa siFR15p4AHQUrhYrrET0FSCEdzUtFFxjQijoKdSUUgCiiigAopaSgAooooAKKKKACiloxQAlFLij HvQAlFLgUcUAJS0ZozQAUYozRmgAxQASeKTNA46cUwFHHWlpMmkz70gHUUzcB3FG9fWgQ+io/NX3 pPOX0oAloqAzD0pPPPtQBPRVfzz60nnt60wuWqQjNVfPb1pPOb1oC5c5xjtSVT81vWk3mgLlzco7 ikMiDuTVPcakGSKLAT+avoaTzvRf1qLHrQByM96LASecf7oo84+gpHADdKbtBosA7zm9qQyMf4jT dpFFFgELjuTSbxTHGGNJimIk3j0pPM9qZg0YNAD/ADPak8w03Bo2mgB280m80bTRtNABuNG4+tG0 0u2gBMn1pKdso20ANop+2jbQBHRUm2jaKAI6Kk2il2igCKipdoo2igCKipMClxQBFRipcUYoAixS 4NSUUAR4NGDUlFADVHFOxQKWgBMUYpaKAGr98VJTF++Kk25Vvmwe1ACUUgztGetKp2nNAxByMjpT lG5gKaAAOKWgBqnJYHsaWinCNj2x9aAG0AZ6c1KI1H3jmnhlHAFICIRsevFPCKvQZNPyaN1ACfN9 KTB9afmigBmPrR+Jp9JigAyaM+1GKKAAGijFHI6UAIVphjBqTPaloArlCORQHxw1TEUxkBpgOBoq L5kPHIqRWDDikA6iiigApKWgjFACUUUtABS0ClxQAClxSgUuMUAIn3jTqaPvH6U6mITaPQUmxD/D TqKAGeWvvSeUOzGpKKAIjD7j8qQwt6CpqKAIPLYdjTcEd8VaooGVcn1pdx9KsEA9QKaY0PbFAEO7 1FLuBqQxDs1NMR9jQA3j1oxSFCOxFJ+NIB+SOnFKHb1qPJpd1AEvmeopQynvUIIpaBE9FQdOlODs O9MCWkpok9RShge9AC0jMEXc35etKSFUsx4FVXcyNk9OwoGlcRmLsWbrTaWkpGgUUUUgCiiigApC Ae1LSUAKpZfusRUi3Dj7wDVFRQKxbSaNu+D6GpKoEZpVZk+62KBWLtFQLcn+NfxFTI6uPlOaCRaK WimAlFLRQAlFLRQAlFFFABRRRQAUUUUAFFFFABRRRQBmUUUUxBRRRQAtA60CikMkpe9IOlFIBj/e ptSSDoajpgFFLRQAhpKU0lMQUUUUALRRRSGFFFFACiikFLQMKQ0tIaAYlFFFMkKKMUUAFLikooAK KKKACiilCmgBKMU8LS0hjQtKFFOpCRQAUU0t6UhJNADiQKQtTaKBC5pKKKYBRRRQAUUUUAFFFFAB RRRQAUUUUAFFFLigBKKWjNABiikooAWigDNOC0AJRTsCm0ihKSlpKBC0UUUwCiiikAUtJS0DEpaK KAClpKWgaCmnrTqaetAmFFFFMkKKKACelABRUiwse2KkEAHU0DsV6esbN0FWlRV6KKdmlcLEC2/q akWJR2zT6KLjDp04opKKQC0UlGfegBaKbkDvQXHrQA6imeYvrSeYKAJKKiMopDN7UCJqKg876Uec c8d6YXJ6M1XLE96TJoAs5pMDOepqvuPrRub1oAsZozUBJz1oyfWgCbNJvX1qEknvSUAT+YnrSeav vUVFAEvmr6GkMyjtUdNcZAoAkNwOwpv2g+lRbaNtOwiQztTfNY96TbRtFFgDzDSbzTtoowKLAN3G jJp2BS4osBHzRzUlFAEeDRg1JRQAzaaNpp9KBmmBHtNG2pQnrS8DpSAjEZpRGO5p5NISB1oAAAOg paYXHahSWJzQA6gckUYoXqKAJJBnmo+lSuOnvUbAlcg80AKDRikoBxQAjL3ptSgg0FQaAIqKcUIp KYCUUtFACUUtFAhKKWigBKKWigAooooAKKKKACjiiigAxRiiigAxRRS0hiUUtFMBKMUuBRikAlJS 4o5pgJS0UoBboKQCUVIIj3P5U7y1Hb86AIF++Kfg+hqXIHTA+lGfc0DI9rf3TRsb+6akzRmgCPY3 9004RMevFOzS0ACxqv1p2M02jPvSAXYD1o2D3oz70ZPrQAmz/aowR1pdx9aXcaAEpaM+1GfagApa TINHHrQAtFH40UAFFGKKADGaTp16UtLQAlJilxjkflR1HFADCPxqMqQcr1qfFNxTAajbvrT6iZed y9acj7h70gHE/KRjrSUtJQAUo60lOyAOnPrQAU4UwU9aAH0hNBppoAAcNzTxzTO9HFAiSkpoOOKc CD0pgFFFFABRS0UAJRRRQAUUUUAFFFFABQQD1GaKKAGGNT2xTTF6N+dS0UAQGNh2/KmdParVIcHq M0DK+SKXdUpjU+1MMR7HNACZGDRTSjDqMUwSCkFib6imlVPbFND04NQFxpjPY5ppUjqKlyDS5NA+ Yr0VMVU9RTTH6HNBVyOilKkdRSUhhRRRQAUUUUAJRS0lABRjnPQ0UUASJO69fmFTpMj8ZwfQ1UoP NBNi/RVJJHT7p49DU6XCtww2mgViaijtkdKKYgooooAKSlooASiiigAooooAKKKKAMyiiimIKKKK AFoopaQxy9KWmoadQAN901FU3aoqACiiigBKSlpKYgooooAWiiigYUUUUgClpKWgYUGiigBKM0lF MkKKKUKTQAlFPC0oAFIdhgUmnBadQTQAmKWmlhTSxNADyQKQt6UyigQuSaSiimAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUtACYpaSigBc0lFKATQAlFPC+tLjFIdhoU0oUClpCwFADqTIFNLGkoC 44t6UlIKWgYUlLSUCCiiimAUUUUgClpKWgYUUUUAFLSU4AnoM0DQlIetSiJj14p4iQdeaAZXAz0p 6xMevFWBgdBijNFybEawqOvNP3BeigUUmPWgYu8gdeabvahjTQPWiwh29vWk3n1pDikosA7efWk3 H1NFJmgA8z3pN596KSnYQbqMn0opM0AGT6UZNFLigBMmk5p2KKAG4NG2nUUAN2ijGCKdSHpQA+ii jvigYUlLTSKQDyaSkA59qKAFooopgFFFA4OaACkPSloPSgQ2iilpgJRS0UAJRS0UAJRS0UAJRTgh PtTtoHXmkAwDNOCHvxTs46U0mgBcKKCaYXAppcnpSAkJphcU3BNKEp2AQsTSYJp+AKWgBgSlXh6d TWHNAD8j1oBBYYqLaadHw9AFl+30qHevrUz/AHBVXaSaAH7xSbxTdho2GgBS/pT1kqPZTcYoAtBs 0FQarhiKkWSkMCpFJUobNBUGncRFRTipFNpgFFLg+lLsb0oAbRS4NGDQAlFFFABRRRQAUUUUAFFF LQAlFLRQISloooAKKKSgYtKASeKVUzyeBT846UgECgcnmnbvSmk0zdk4UZNAyQt70m6gROfvcU8J t6HFADPmPQUu1/QCn7fc0bPrSAbsb1FGxvUU7b70YNADdje1G1qdzS0AM2t6UYb0p+aWgCPn0ozU lFAEeaM1Jj2pMD0oAbRSkDPTil2+9ADaM0u0+tJg0ALSZo59KSi4WHZ96M+9NoyfSgB+SO9G40zP tS7hQA/d7UZGcjimZHrS/iKYD8g0lNzRmkAbajZSp3L1qTNAb3pgAIZQwoo/AUcelIBKWjApcD1o ASnDijFFADmPy8DJpByD6+lAJHShQM9KBCd6WgjBopjCiiikAuT604EUyigB9FMBx0pwb1FMQtFF FABRRRQAUUUUAFFFFABRRRQAUUUUAJS0VBNJn5F6dz60DQksu75V+7396ixS0Ui0rDdtGWFOpKQW AP604P6Gm4pCtMXKTBqUEGoPmFKH9aBWJ+aQop7YqMPTw9ArjTGR05phGKnHPSlPuM0D5itRUpjB 6GmMhXqKCrjaKKKQwooooASilooASilpKAFVmQ/Kce1TpcA8OMH1qvRQTYvDkZHNLVFWZDlTirEc xK5dePWgViaikBBHBzS0xCUUtFACUUUUAFFFFAGZRRRTEFFFFAC0UUUgFHWn1HUlAxaibhjUopjj BFADaKKKAEpKWkpiCiiigBaKSloGFFFFIApaSloGFFFFACYyacE9aRTzT6BCAAUtIWAppc9qAH0h YCmEk0lFguOLmm0UUxBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUtJQAUUUUAFFKATShaA G0oU0/GKKQ7CBRS0hYCmljQA/IFNLelNoosFxSSaSiimIKWkpaAClpKWkUFJS0lAgooopgFFLT1i du2B70gI6Wp1gA+835VIqovRaBlZUZugp4gP8RxU+aKAGLEg7Zp/A6UUAE9BQAlFO246nFGVHvSA bil2460bzTc0wFNNpc0maBCNyMU3pTjTSCDzQAhoBooxQAUUneloAaetHNKaKYhMUYpaKACilooA SilooASilooASkPSnUUAFB5oHSigYUh4paQ0gFFFAoNABRRRTAKKKKACg9KKO1ACUUUUxBRSgE9q cE9TSAZShSafwOgpC1FwAKB1pcgdBTCwHeml/QUDJCaYWApuGNKE9aLCELntSYY0/AFLQAwLTgAK WimAlFLRQAlFLRQAlFLRQISkH+sFOpv/AC0FIZYb7gqCrB/1YqCgBKKWimAlGM0tFAhhT0puCKlp MZpDGByKlV81GU9KbgigCyDmgKC1QByKkSQbgaQxzE7vYUqMrEqDlqe479jUTRgnI4PqKAFxjg9a dim7+Nsq7h/eHUUGJiMxPuHp3pgO2A0xkweKYZHU4PFIZGJzQIdiikElODA0AJRTsA0baAG0Uu00 lMAooooAKKKKACpFAC5701R7ZNSiI4yx20gGE+tAV36Dj1NSDYvQbjSne3U7RSGNEC/xncaeCq8K R+FIFUe/1pfpQAc+tFFLQAUUUUAFJS0UAJRilpKAEopaKACgUUUAFFFLQAlFLSUAFIaWg0ANpaKK QxMUYFLRTAAKXFAFOxQIaVH92jyl9DTxSP8AcNADPKHZjTHGz+IE0+M9QMY7U5Y1XBxzQBDhiOlA 44qUpjoaY6nORjIoATcBQDmmYPcc1G5K8igLFgH2paRFDxBgT70bD2agQtLTdrexpCGHVTTAfk0b jUYfHXinBxSAezbsdsUZHrSblNJkUAPoptGfegY6ikzRkUALRRmigApdxpKKAHAg0tMo5HSgQ+ik DetLTAKSlooASloooAKKSo5ZNvyr17n0oGJNJ/Av4moaXpRSLSsJRS0lIYUUUUAFFFFACUYpaKAG 7fSjJFOpKBWFD08PUZGabgjpTFylncDS81WDEdaer0E2sSFFb2qNo2HuKkDg9ad9KBplairBCnqK Y0X938qCrkVFKRjrSUhhRRRQAUlLSohdto/GgQsabz/sjrVn2HSgAKoUdBRVEN3E2jqPlPtS7yv3 hx6iiigQ4EEcUtR7RnI4PtShiPvD8aQx9FIDnpS0AFFFFAGXRRRTEFFFFAC0UlLSAKevSmU5KBjx TXHFLQeVNAEdFFFAhKSnU2mAUUUUAFLSUtAwooooAKWkpRSGFFFFAxM4NBJNBpKZAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFLRmgAxRSUUAFFFKATQAlFPCil6UANC0uAKWkLCkMWjIFMLGk oAcW9KTJNJRTEFFFFABRRRQAUUUUAFLRRQAUtKqM3QGpRAf4jikUiGgAk8DNWREg7Z+tP6DjigCu sDnrxUggQdTmpKSgBQAv3QBRmil2mgBKKXA+tG4DoBSAQAntS4A6mmlieppuaYEmQOgpCx9aZmkJ oEOzSE03NITQA7NJuphakL0ASZpM1FvpRJgfd5oAnQA9+nakdstjsKFBIB6GhlJOc0AJgUuwkZFN 2kUcigBdpFJg0u40u/2oAZiin7hRwaAGUtO2ijbTENop2KTFACUUuKMUAJRS0UAJRS0UANooopDC kNLSGgA9KWkzS0AFFBooAKKKUKe/FMBKBzTsAe9G6kAgX1pcAUham7vSmA8tSFgOtM+Y+1G0d6BA X9KPmPtTsUUANCetLgClooAKKKKYBRRRSAKKKKACilopgJRS0UAJRS0UAJSH7606mt1X60gJz/qx UNTj/V1D60AJRS0UwEopaKAEopaKAEoxmiloAjKelNwRUtBGRSAkgl3fI9K6mM+q1WIwaswyhhsk pDEBzSbcHK8GiVDFyOU/lTVfNMCTzDjEihxSeXE/3W2n0NAOaQqDQIR7dl5xkeoqLb6VMGeP7pxT vMR+JE59RQBXywpwlI6ipmhONyHcKZ5TH+GgAEinvin8H3qPyG9P1pPJcdP50ASFBSFMd6ESXPLB RUwVR3yfWi4WIRG56CniJV5dsn0FSHkYzimiPHc0DDJ/hAUUw8+rU/YO9LjHQ0gGhTtyTj2FKAOx P40vNGaADBopaKADNFFGKACiiloAKKKKACiiigBKKWigBKKKKACilooAKKKKACiiigBMUlOoxQAm KKawOSR+FOyDSGKKbyrDv60fP5gx93vTnQPjPamIcpyTxSqu3PJOaB6UtAhAi7t2Bn1obgZNOpDT AYHyRhTt7k1GFCk9z61I1NPIzQMZTSoI6U+n4+SkBDbNtcxnoamK8Gq0nyuGFWs5AagQ3mlBIopK YC5ppRT1FLRQBBPiJlC9DTBL6in3Yyy49Kr0ATiUHvTw/vVWjNAFsNTt1Uw5FSLID3pAWcg0ZqLc aUPQBLmlyKjDUuaBj6M03NLmgBaOnTikBpaAFDHvzSgg9KbSYoAkopgJHehnIX5Rz/KmASPt+Vfv fyqvTsY60lIpISiiikMKKKKBiUUtFACUUtJQAUUUUAFFFFABRRRQAmKQr6U6igQ3cR1p6t+FJjNL TJZIH9aeOelV+lKGpkkxAb7wqJoiOV5FPV/WnjnpSGmVsUlWGUN16+tROhUZ6igq4wAkgDqatIgR cDr3psSbBk/eP6VJQiW7hRRRTEFJS0UAJRRRQAmMcqcU4N68UlFAD6Kjx6EijB9TSGZ9FFFMQUUU UAFLSUtACjpQvBpBR3pDJKWkpRSAiPBopXGGpKYgppp1NPWmAUUUUAFLSUtAwooopAFKKSlFABRR RQUIaSlNJTJYUUUUCCiiigAooooAKKKKACilxRQAlFFFAC0lFFABRShSacFoAZinBadRSGIABS0h YU0sTQA7IFJuptFMQuSaSiigAooooAKKKWgAoooAz0oASlqRYHbtj61IsCj7xzQOxXp6xO3QVZAV fuqBS5pXCxCtv/eb8qkVEXov506igAyaKMZpdvqcUDEopcqO2frRuP0oANvrxRwO2aaTTSaBD934 Um6mZpo4GKAJM0zndntSE0maAHZpCaaWppagB+aQtUeaKAHlqaWNJQelAxM0lFGKZIUUuKMUASRt xjvTwzd6hHBzUo5pDHeYAcNxTgVbuKjK5+oo2igCTZ6UbcUwsVHBponb2oAk20m2kE2eq04SIe+K AEwaMsKk6jjmkx60AM3HuKXcKdik2j0oAAVPejA7HNJtFJt96AHbaTFJ8wpQ7CgAxRijf6il3CgB h60Dg81J8p7j8aNg/wD1UAREAHjpSVLspChoAjpccZpdp5yKAduaAFKk0YA680E8Cm5oAdux0pCa bRQAuaTrRSimAm315pcUtFAgooooAKKKKACiiigAooooAKKKWgBKKWigBKKWkoAKKWkoAKKKKACm v2+tPpr/AHfxoAmXmM1F3NSr/q6j7mgBKKKKACiiloASilooASiilpgJRS0UgGkZFM6cGpaQjNAE sUuBhuRTZYAfni/EVEFbOAM1OhMY60DIEZicAEmrCxtjLELSFqTNICTauOv4mm5A6H8hTMijPoKA HZopMN/dpdr+lMAoo2t6UbW9KACijDelHPpQAvSjJ9aTNGaAHZPrRupvFLSAXdS5FNopgOyPWlyP WmUUAPpfwpmaM+9IB1LTQTShqAFopNw9KXIoAKKOPWjFABRRRQAUUUUAFFFFABRRS0AJS0UoFACU jA8Mvbt607FFADXK8Z5BpoUDoKeSMYxTaAHClzTRRQA6lBplOXk0AOFITilyAKjY5NMQE032opQK QwUYp3WkopiIZlyDToGzHj0oeo4DhyKAJzSUGkoAM0uabS0ARXH31+lQ1LP/AKwfSo6AGkUmKcaS gBuKKdRigByMcVIGBqEcGnhwB05pWGSYpeaiWXnnpUyjcMqc0AJuNOD00gjrRwaAsP3U7NRY9DRy KAJsmjNRB6eGFAD6KbS5NAAQDTTH6GnZpaAISpHUUn0qek+lA7kJGOtJUxAbqKayc5UcUWHcjopc EHpSUhhSUtFACUUtJQAUUtJQAUUUUDCiinBTQISjBp2AKKZAm2kK8GlyKQtTEESho3OcMppQSvXg 0+BAysD19Kayc4oAeHB6076VDjK5HUUquR0NAEuaWmhw3Xg07BFIBaKTNLTAKKKKAEooooAKKKKA CiiigDOooooAKKKKQBS0lKKACiiigZIOlKKavSnUAMk7Gm1I4+Wo6BBTT1p1NNMAooooAKWkpaBh RRRQAUUUUgFooooKA02nGm0EsKKKKYgoopcUAJRS0UAFGaSigAoopwU0ANpcZp4UClpDsMCetOAA paaWFADqQkCmFiaSgLji3pSEk0lFMQUUUUAFFFFABRS05Y2boKAGUtTLbn+JsfSpFiRe2frQOxWC lugzUggbvgVYzjpxRSuBGsKDrzUgwPujFJRQAtFGDRgdzQAUAGl3DsKQsaAFxjrRkDtTM0maAJCx ppNMzSZoAfmkzTM0m6gBxNGajLU0tQBIWpC1R7jSUAPL03JpKKACiiloASlFFFAwoxS0qjLYNAxA BS49ql2gUtBJFtNLs9akoNK4xgUClprNzxT4SNxLcAUIAXg0hG1ic8Gl43HHSnYDDBqhERbPQUzA HWnOjKfm6etNOBSAMimt1p3fNNbrQABiOhqRZ2HXmoqKYiyJlPXinhlboRVOjNKw7l3FJVUSMOhq RZ2780ATAHHPFFIHB7UoIPegBMUhWn0YoAj20YIqSjFAEeWFLvPcU7FGKAE3Cj5T3oKjtSFaAApn oaTyzRg0ZYUAJtNG0+lO3ml3D0oAYCQCAeD1pMVLkHvSbQfSgBlFP20m2mIbRTsUmKACiiigAooo oAKKKWgBKKWigBKKWigBKKWigBKKWkPAoAKKM0ZoAKR/u0uaRuVNAEqfcqPuakj+4aj7mgAooooA KKKKACiiigAooooAKKKKAClC+tOKhfc0lAC59KTNABb7ozThD/fP4CgZGWGcDrTgrHrUoVV+6AKW kBGEx2H407DetOooAZg+tLg+tOpKAE5oyaWigAzRRRQAUfhRRQAmB6UbRS0UAJt96Np9qdRQA3B9 KTPqKfS0AR5FFPI9RSbR6UANpM0/Z70m0+ooATNLmkKn0pMfWi4WHZozTce9HNAWJATRu9ajzRup gS59qOKj3Uu6gCT8aMUzNGaQD6UDNMzS7qAFFL0pM0de9AC0lFJQAUlFFABS0lFAC0ZpKSgBSaSj NJQAtOpopc8UALSZoopiGtUA4mHvU5qCThwaALFIaM8UlABRSUUARTf6wfSmU+b/AFn4VHQAUUCi gBKKKKACiiigANAJU5BwaKMZoAsJcBuJB+NSbVYZFUiKfHIyH29KQFkoR0OabyOtOSQPnb2p9A7k fB60m30NSFQaTYe3NFgGZYUof1o6UEA0XCw8MD3pcVFt9KQMy0ATZpajEmeopwINMQ6ikpaQwpux T2p1JTAj8s80zHtU9B6YpDuQUU8oe1M6UFXCilAzShRQFxuKUL6mnUmaCbigAdKCaTNMJ/GmLccT TS1Jk96UAYpBYTk0uMUClpiFRipDDtU7jcA61WqaF8HYeh6UANbg7h0NNYflUrrgkHoajx2NADae shHHamEUlAFgFWHHWlquCRUqSdjQBJmikxnpRmkAtJS0UwEooooAKWiigDNoqekxSuMhoqbFREYO KAEoFFFMQtL2pKWkMVetOpg60+gBeoqGphUR4Y0AFNNLSGmIKKKKAClpKWgYUUUUAFFFFIBaKKKB hTadSUCYmKWkopiFzSUUUAFFOCmnBQKAGAE04L606ikMMAdKKQsBTCxNADyQKaX9KbRQIXOaSiim AUUUtACUUoBPTmpFgc9ePrQBFS1YECjqc1IAq/dAFA7FZYXbt+dSrbj+JvyqXNFIBFRF6LS5pKKA FpKXbS4FADaXBpc+lIWoAXA7mkz6Cm5pM0AOJpCabmkJoAdmkzTc00tQA/NJmmFqaWoESFqaWqPO aKBji1ISaKTrQADpmkpzenpSUxBRRRQMKKKWkAUUUUDCgUUCgBaVTg5pKBQMkMnoKTcT2o6DPSk5 NIQpY9zikPHXmlCgtjFJJTATPpxSg0zrS57UCuTCnioo+9TLTBjh6VVmAEpVegq2OOTVRyu4nrmk ICPlpppTnvS7SWwKBjKTFSEKBjqabTENoFKaFFADaKcVNNxQBOn3BSnpTY/uU+pKGjjvTgxHeikN ADjIQMkUolU+1Qsc02mItAqehFLiqlKHYdDQBapKhEzDrzTxKD1GKAsPxSYo3p60EE/dYUAJtpNt SYNFMCLbRg1LSYoAjyRS7z3p+B3pMUgE3CjIoK+1JtoAWjbSbT60cigBcUYpNxpd1ACYoxTsijim A2inYoxQIbRS4ooASilooASg9DRQelADaKKUDIJzyOg9aBiUUUUASRfdNNNOi6GmmgQUUUUAFJS0 UAJRS0UAJRS0AE9BmgBKUjoO9SLEf4jTwAvQUDIghPtTwijrzTs0UgDNFFFABRRRQAUUUUAFFFFA CUtFFAABRS9O1GMmgBKKU0lABRRRQAUUUUAFLRRQAUUUUAJS0UUALSUUtACFQe1JsHY06igBm0+t IVPcVJS0DIdoo2e9TUm0UgIdrexpOR2qYr703BFMRHupwalPvTcD0ouFh26lBFM2jsaTafWi4WJQ aXNQ5YUb8UwJs0cVEHpwYUCH496Qg0m4etKPakMQ8Umafk96TAPagBtFO2jsaQq31oASlzTc460Z pgLnmnUyloEBqCXtUxqGWgCYH5RSUD7oooASikooAjl5kNNpz/eNNoASkpaKAEopaKACilxRQAUU vSjBoATFMPWpSMnNIRTAYjFGyKsxyhh71WK4pBkHIpAXwc0VAkwPDcGpgeKAHfWkKA9OKKWgYwqR TaloIBpWGQlQaTBFSlPSmkYpAIshFSBlPtUeAaTaR0p3FYmx6UmfWo1cjjpUgcGmIKKXHHFIeeDx QMCcU0tntSEEUwtQA/NNJpOTTgh70gGk03OelT7VHbNGB6UAQYz1pRUjpnkVHQUgxTcY6U+kpDGg 04UhFOWNtu7tTJaEo6UtJTJLCnzE9xUbDI9xTY32MD271M4wdw6UAQnkZptPIwfY00jFACAZIFPZ Cp54p0K/xH8Kk69eaQEKuVNShlce9NaPuKjwVPFA7E2KKaknZqfj05oEJS0lLQAUUUUwKlLUPmNS +YaVhklNdcik8w+lHme1ICOilpKYhaBRRQAven1HT1PFAxwqN/vVIKbIOM0AMpDRQaYhKKKKACii igBaKKKBhRRRQAtFAopDCkpaMc0AxtKATTwoFLRcVhoT1p2AOlFIWAoAWkJAppYmm0BccW9KQnNJ RTEFFFLQAlFPWNm6CpFtz/EcfSgCGlVS3QZqysaL2z9afn8KQ7Fdbdj94gVIsKDrzT6KAFHHQYoz SUoFACUUuPejigAox60bqTNADuB70mabmkzQA4mkzTc0maAHE0mabuppagB5NJmoy9IWPagCQtTS 9R896KBDixpuaKSmAtJS0oWgBtOxTgAKDjFIdhtGcD3ooxQMSil2n0NLsb+6aYhtFP8ALf8Auml8 p/7tAEdLT/Jk/u/rSiCT0H50hkdFS/Z39qX7M/qKAIaKn+zN3YUotT/e/SgCCgdasfZvVqPs4H8R oHcjbIHrQDxmpDH70bMDFAhg60xuWFTeXml8od6AKzDBpKt+Wp60eUnpQIrBtoFWAwVCx7U7yk/u 0uxcYxxQBAZCynJ69qg6Gr21f7oowv8AdFAFPcTinknt3q1gegooApc+lLg+hq5QTii4WKW1j2NO VW/umrYOT3ozRcLFcI3oaa0RI4XmrWTS5oArRxuFwVp4Rv7tTc0c0hkBjk9B+dN8pz6VYwe+aKAI Ps7eq0fZz/fFT4oA9aYEAt/Vv0pfs4/v/pU/FJketICP7OP7/wClH2cf3/0qTI9aMigCP7Ov98/l SfZ1HRz+VS5o4oAYIyP4zShSOrZp2aTNABSUcUcUwCijAooEFFFLQAmKMClzRQAm0UmxadRQA3Yt Gwe9LRQAm33o2+9OpKAE2+9LtPrS9sk4FMabC5jHy5wWoAV1KAE803PtSI3zPGSSCMgmgtTELx6U cU3dRuoAXC+9G0eppM0bqAF2j1o2j1pM0ZoAemF75oIB703NGaAF2/7QpdvuKbmjNADtp9qTaaSi gBdp9KUIT7U2lHPTmgCQRqOpzTvYUwRnucUvlns1IY6im7G/vUYf1FADqKb+8Hak3N3FAD6KYH9R S7xQA6ik3D1pePWgAooooAKKXFFACUYpcUUAHt2pOppaKACk7UtFACHiilooASilooAKKKKAClpK WgAooooAKOlLRigBKKDxRQAtFFFABSUUlAC0UlFABSEClooAYV9DRtIp1FADKSpDTSAe1IYzApMe 9P20mDTAbyKNxFLSUXFYcHpweoqKLhYmDUuagzShqYifPvSYU9Rj6VGHpwYUAKUz900mCOop2c9K UGgCKopatYB6io3gDfdbH1oGNHQUE0pRgOmfpTM0ALSUUUCGN9402lf7xpKACjFApaAG0uKMc0Z9 KAFo69KMetLQIAKWiimAUUUUAJimMtPooGRU9ZGT3FBXNNIpAWFlB71KhJqjipUnKoVI/GkBbopF IKrg5zS0AFFFBwO9AxpT0ppBHWnFvSmk0ANJ9qbnHenMQajKknigCRXqQOD1qFY8ck0uCOlFwsT/ AENNKAnpimK5FSBgaADGOlFLikoAKKMUUwFpCNwpaKQETJgZzTKsU0qDjIoHcbHHu+Zvu/zqbNIG zx0paBMayBvY1EyFetT0UwKpqeJtwKH8KRowen5VEMq30pCJSOoP4UwDccVMcOm4daanU+tMB3Tp S0lLQAU1lDfWlooAhZCKEcqfapvY1G0fcUhkoIYcUhFQAlTxUySBuvBoEFFPxRigZlUtJRTELRRR QAUUUUAKKKBRSAXtSrSUL1oGPoYZWiloAipDSng0hoEJRRRTAKKKKAFooooGFFFFACiigUUhoKO9 FIaAZISBTS/pTKKLEikk9aSloAz0pgJRUqwue2KkWBR945oCxXp6xO3b86n+VDgAU/5j2oHYhWAD 7zflUgRF6L+dOwfajB9qQBmkpcH1pce9ADaKdj3ox70AJijFLj60bR70AJ0ozTsCjAoAZSc+lSYF GBQBF83YUYb0qaigCHa1Jsap6KAIPLb2o8pz3qeigCv5DH+Kj7MT1arODSYoAr/Zh/ep32Yf3jU3 40ZHqKAIfsyeppfs6e9Sbl9RSb0/vCgBn2eP3pfIj9Kd5if3qTzo/WgA8mMdqXy09Kb56e9Hnr6G gB+xP7tLtX0qLzx/do8/0WgCXC+lLx6VB57f3RR57+goAnozVfz5Pak86T1oAtc0c1V82T+9Sb3/ ALxoAt8+lHNU9zf3jRk+tAFyj8RVL8aMUAXMj+8KQuo/iFVMUYFAFkyD+9TS6+tQYFIQMigCxvX1 o8xPWq+0elIwAosBY85PWjzkqAIMdKNg9KLATeelH2hfSodg9KXaPSiwEv2hfSk+0D0qPAz0pcD0 oAf5+ei0vnH+7VcnDelPByOKAJPOb0o81vSm7Tt3dqSgB/mvR5r0yloAXzH9aN7+tNooAXe3rRub 1oUbmwOtHQkHqKADc/8Aeo3N/eNFFABlj/EaTn1NLSgbmCjqaAEx/tGjHuaUghip6ilIOKYDMe9G PelooATHuaX8TSgUUAJj3NGPc0uKKAEx7mjHuaWigQmPej86WjFAxMe5ox7mnAcUYoENIPqaAD6m nYooAbz6mjn1NLRQAmTuxnilOQfvUjDBU0jtgHjpxQAvzf3qMvuwDnjNIpyooY7cEcUAG6QjIOaR Z3Rs8HtzUZODwakUAoM80AI8m8DPJ70iOQpXse1P2L6Uu1RzigBoyJVNKRhyPQ04ggAkcHoaWQcq 394UAMApdtKOKWgBmKMcdaWigYmPejBpc0hYUCFwfWjB9aAGPal8tsZPSgBOaOaXYaPLI6gigBOa OfSjbRg+tAEqouMs2fapBgDjiq2D60vIoAsUtVwc96d83rSsO5NRUWXxkc0glb+7QBNS4qISkdVp ROvTGKAJaMZ7UzzU9xTg6+tMA2r6Unlr6frTsg9xS0AM8sepo2H+9+lPxRQBHtf1BpcOO1PooAjJ PdaNw7ipKKAI9y+tLwe9PwPQUmxT2oAbRil8se9Gzj71ACUUuH9aTDelABS0mfVaNw9aQBS0ZXsa KACilxRigAopaKAEpaSigBDRSUUALRSUUAFFFFABRSUUAFFFFABSUUUAFFJRQAUlLTaACkIFLSUA IRSU6kNADaKXFJigAoyaSkJ7CgB4enBz61Dj5qk7UASh6UEetQE4pFkzTEWgaDhuozUIenh/WgAM Sn7px7UwxuvbP0qUEGlBoAptyxpKuFUb7wBqNrcHlGx7GgCAUE4pzpIvVcD1poFACcmlHFFLTEJS 0UUAFFFFABRRRQAUUUUAFFFFAxpWmkYqUAnoKcIs9aQEKMVYFeo7VbVyRllwaQAKOBigtSGOLE98 U3NMLUi/OcAimA4tSAM3QVIsar15NPoAjEX9408ADoKWikA0r6UwjFSUUAREA0mCOlSFfSm9KQxV kIqQENUJANJytO4rE5GKKYkvryKkwDyKYhKKOlFIYUUUUAJTt3rSUnfFAD8iikAxS0AFRSr/ABCp M4HNGQeCetMCKJ9rYPQ1I67TkVC67WqaNt6bT1FIQoORmlpg+VsdqfQAUlLSUwCiiigBrKG+tREF TU9IQD1pDGCYgYpfPppjOaPLPpQFijRRS0xBRRRQAUUUtACClpKUUALR3pBSmkMfS0g6UooAjcYY 001JIOhqM0CEooopgFFFFAC0UUUDCiiigAFLSU8KW6DNIaG0GphCf4jiniJB2z9aAKwUnoM1IsDH rgVY6dOKM0CIxCg65NSDj7oxS/hmjJ+lADeaXaTSE0w/jQBKFA6DmioCPc0m33NAXLHHrRkeoqsQ N3PQ0YFAFjcv94Ub1/vVWOAKcylQOmTQBP5if3qTzU9arKfmINOoAn81Pek85fQ1DRQBN5w/umk8 7/Z/WoqKAJfOP90fnSec390VHRQBJ5z+gpDM/tTKDQA/zZPUU0zOP4qbnkCkcd6AHCRyPvUbn/v0 yPqafTACW7uaTn+8aDyKAcigQh4xkml201x3FOX7vNABtFJgDtxTqOKQxmRkcU8gAU3HzY7U7tg0 xDEJp9NUYOTTsj1oAXadobtSUbh60ZHrQMVRuYDpmj2NJketG4etIAopNy+tG4UAOopu8UbxTAdR Td4o3ikA6im7xQGz0GaYDqKUA9xiigBKRulLQaBCKckg8UkmRx2NLwKQsDQMapOcVLTcc0tAhaKk CArnvTCMGgCMZEnPNPI49KCMUoxQBDg5OPzpyhhwelTYApcZHHWgZHRTXLg4bimZpBYloqKlx70D sSUVGF/GnbW7KaBWHUmR60eW57UeS/t+dA7BketG4etHkt6il8g+tAWQm4etG4U7yfel8igNBgcC l80Yp/k+wpfJPoKA0IvMHpRvHoam8lval8p/UUBoQBj/AHTS/N6VL5Td2FHln1FAtCP5qMGn7D6i k2n1FGoaCY96KXB9qTB9qWo9AoxSc0mTQA7FGPembjRmgB/40cZzmo80ZpgSZx3pMj1qPNGTQIeT xigtkYNR5NJk0ASLgDAoI3cUyM/OKkpgMZOeKco25paKAF42A5+bPIpMiiigBd2QATkLwPalLAoF 9Dmm0UCFozRQATQMSgAtwozTvkX7xzS72bhF4oEKsBP3mx7CnhY4+i/jUe1z1fb9KVY1z0LH1NAy TcCMDI96MLjBJP1NIQcY4pAgHbJoAcRxjoKaRnGWJobch+Uke1J5x/iQH6cUCHYGMU0qKUPG/Aba fQ0MrL1HHqKAGFaAKcDnpRQAwqDSYI6Gn4opgND4PPFSZDdTTCAabgr0pASVFt3TEVIrg8GnqoOT 3oAjCkfewaTYoNSY5NIRkUAN2ijBHQ06igBMv/epd8g96XHB9qDQAec46il88d1puKWgB4nX6U4S Ie9VZRzxTgq7emaALIZT3pc+lUQcvgZApybieGxigC7RVUb8ZDU7zJR15FAFiioPPI6rSi4X0xQB NSU0SIe9OBB6GgBNqntSGMdsin0lADNhHRqP3g96kpKBjN/qpBpdwzjPNO5HSkwD1FIBOvSg8UFB 70bWHRunTNMBKKPnB5GRSbhnkYpALRRkUUAFJRRQAUUlFABRRRQAUlFFABSUUUAFJRSUALSUUlAB RSUmc9KAFopBnvRTAQruPNAXFLRQAmOaWlHSkNICNzQg4pCMtin4xQAZpQxFNooAkD09XqCjNAWL QenCqoJpwemIsgkU0ojdRg+oqMPUgbNAEZgP8J3VERjqMVaFBORgjP1oAq4oxU7QqfunHtUbIyfe HHrQAykp1FMBtLS4FGKAG0U8Ie/FPVQO1ICMKTTxGO9OyBSFqAF4FIWqNnA71GXPagCUt61GZPSm YJpwT1oAaSTQDg5FSAAUhXNAD47gjh+RVgEMMg5qiRilVyhyDSAvUVHHKHHPBqSgYlFLSUAFGM9a KKAGlfSm1LSEA0ARFfTrQGKmnlcU0ikMkVwetOI/Kq+COlPSQimSSUUoIbpSEYoGFIv3qDSDhqYE lIaM0dqQgpCoNLRQMjdcio1JVs+lWM1HIgIyOtAEjYYbh3pAeOaZC+Dg9DT2GDigQvXpRTKXJFAD qKbu9qXIoAWiiigAooopgZtFFFABRRRQAUUUtIBKUUlApgLS0lLSGOXpS01O4p1AA/3aiNTEZBqE 9KAEooopiCilxT1idu2KBjKKnWAD7x/KpAqr0FICusbN0FSLB/eb8qlzRQMRY0XoPzp2aKMUCEpa XFFACYpaTNITQA48U0mkzSdKAEOaKKM0xBikoJpKAEbpSAEUpBB6UmaAA9KBxS54xSUAIRj5qTfT m5Q1DQA/zPajzPamUUAP3n0o3mmUUAP3mjeaZRQA7eaN5ptLigA3GnryKaFp4oGFFFFABRS0lABR RRQAUtJS0AFFFFAhJuimoqmk5i+hqGgApaSloAKKKKQxKKKKYhaKVVLdBmpFh/vHHsKBkVPWNm7Y HvUoCr90fjQWJoAaI1XqcmnZwOBikowTQAZpCad5bnuBSeR6v+lIBhYdqQsTU3kL3Yml8lPQn8aB 6FfrRirIjQfw/rShV7KKBEI5Aop7qQ3Tj2pp6dDTAlT7ppGA65xRFyKRzigQhppFG72pM0hig4p4 OajBz0FGcGgCU4YYYZFAjTstMV6eDTAcEA6KKXb7Ck/GmOxTqDj1oAl/Gj8ared7Unmn0pBqWuPW kytVvMak8xvWgLFrcvpRvHpVTefWkLH1phYt+ZSGX3qpmkoEWzMB3pvne9VxS0gJjPSedUBpwoAk 80+lHmGmUUDHb2o3H1ptLQMXJ9aTNFFIAooooAKKKKACiiigBKKKKYBSUtFAgT74qWol4YVL3oAS iiimAUUDnpzTxG3fA+tADKO+KkCKOuWqQIR0XbQBGEPcUbSercegqTAHVifpRvC9AKAGqg/hX8TT sY+834CmlyepppcCkBLlcdM/Wm7t2QOAKh3MzBV6mpgMYUUwFAJNOJEY9TSk7F96qySZPFIBzvk8 1EWpME9aMCmIQ5NKkskf3GwPQ0ZppoAsLLFIeR5beo6GnspTr09RVOnxzPFwpyv900AWaTFCFZBm I4PdDQCM4PB9DQAmKKcaQigBhXNKrlTz+dOA5oK5oAdyRkYNHPpUYJjORyO4qYEMMqaAGk85Ocmk 4qSkKjFADQcZpKCtNwexoAfijFMyRRvNACsoLAmnY2ghRTN1OLd/WgCGMfvhnrmnRjEjijG6bcel OPFwSOhoAUHBAPQ05gOQOlNbt6A1I3egCOjHWnYpQMhvrQBGUHPHek2ehqQ9TRigBgMg6NTvNkHV c4pcc0uPlPrQAgnH8QIp4lQ96Y4+b8KYUHPFAFnINIR3quYwD8pI4pQZF6EGgCcNTqr+cw+8tPWZ TQBLSUgYHoaWgBpRT2pNnofwp9FAyM7x1oyp69akoIB6jNAEeARwabh8/dwPWpPLHbIpNrDpzQAz NFOzz844pMKe+KAEpKcVbtzTDx14pAFFJRQAUlFFABRSUUAIQCaWiigBKKKKACiij3oADTScDNLT PvH2FMQ5B3PenUlFAARTcU6igY2inUYpAND08EGoe9LTETYo5qIMRTw9AEgfBp4cHrUWQaXFAEwO acDVfJFPWQ96AHlFbtj3FRtGR2yPapAwNOoAr7BTgMdOKlIB7YqNo2AyORQAmQKQtURk9KTk0AOL imkk0oQd6dgUAMEee9O2AU7b70mDQAmPailyaM0wEopeKOKBCYphX0qTFGDQMh5BzU0UpHLdKQrm msPlI7CkBcz6UVSRyh55FWFkzyKAJaKRWDfWloGFFFFABSFQelLRSAjIxTSAam69aYV9KLDIwSp/ rUySA8Go6aRjpRcViwV7imlaYkhWpgQ4460xEXI96UN+FOK03FIY4HNFNo57UCHUU3JHWjNAxjja 2R0qVTvT3FNIDDFRoxRqAJKKew43DpTetACUUuKSmAnSlyaSigQ7cfSjd7U2igCiTRRRQAUUUUAF LSUtIApKKKYC0vakpRSGC8GpKaEYngVKI/U0AMFR7CScCrWwKOOTSAkdqAIRD/eOKkWNB0GfrTyR 3pcYHNADRgHgCl60gB607FACYpcUuKOBQAmKXFGfSkzQAvA60bh2FNzSZoAcTSZpuaTNADqQmm5p CaAHZpM00mmlhTEPzSE1GX9KTJNADy+KaGoWNmGQOKesJHU0AIm8/dzxTvM7MuaArIcjp3pAwWUM BkDtQAvyHoSKXaSOOaawBGfWh12NgHIPegBccEGoKtZNIVU9R+VIZWxRUxhB+63500xOO2R7UxEd FLilCmgBtKFJp4UClxSGNC4paCcU0mgBc4oU5OKZTk4YUxElFFGD6UDCilCt6Gl8tvSgBtFP8s+o pfL/ANqgCOipPLHqaXy19KAIqM1NsX0pdo9BQIhPMbCogjHopq2WVf4qaZh2yaAIBDIf4ad9ncdc D8acZWPtTMk+9Aw8sDqw/ClAiH3tx+lJinfWgBUijYEncB2pdkYPAz9aN1NzQA8t2puaaWFJuHek A6nBCfameaB0FIZT6UwJgijqc07IHSq/mGk8xqALO4Um4VW3t60mT60AWt4pPMHrVaikFiwZB60n mioKKYWJvNpDKSCKjoxSHYsw9qSXIyR1FJCelPlHWmxEG5vWk3H1puaM0hi7qTNJRQMUHFPV/Wo6 KBFkNTwfyqqGIqRXpisOeENynB9KgIKnBGDVkHNOIDjDDNILlOkzUskDLyvzCoaAuGaKKKYgpaSl oAUUUUUgEp1NpRTAUUtApaRQUUUUgCiiigAooooAKKWigBKKWkoAKKKBz05pgFJUixOe2PrTxCo6 sT7CgCDoRUwUseBUqp/cTH1pxX+834CgRF5f95gPpTlReyljTsqOi/nQZD6/lQAu1sckKKT5fQmo 9/pTS/vQBN5mOmB9KYXz71CX9KTLGmBKX9aYZPSkCk0ACgQm4mjFLTkXc2O1AD4VwM9zUyjaNx69 qRF3H2pJX/KgZFM/buaiApTyc0UCEpDSmkoAbSgUU5DtcGgBtJipJX8x92AMccU0UAN5ByODU6yi XCy8N2ao8CkYDbnvQBOdyNhhTu2RUMU2F2Scr2PpUpBjOeqmgBwHNO+ooX19acAO9ADGXIzUXzRt lfxqwKay9qAFVhIu5fxowe3WoOY23CrCsHGRQA0jLYFNK4qU/TmkIoAhIptSkU0igBlJTqSgBB1A 9TUkkYXGBzUdOLEjk5oAIxlxnkelSkL1GRUcZw6k1OeTSGRY9DRlsY4p+Ae1JtHY0ANye4pM07aa TBouFgBBz60uKbxSYFFwsPYYJ70Y603J9aXce4zTuKwpGQfpSHnP0o3gg5yKUkHoaAF/hP6VGVBJ yBUh6YpBTAj2AdCRQGdenNSY5xSbaQAJ8feFPWRW6Gm/wge9M8tWzxg+1AFj6UZqth1+63504Ssv 3l6dxQBPmio1mVqkBz0oAKQqD2paKAGbD1BoLEDDCn0UARbEPTg+1NMbdsGpigPbmk2EHIP50AVz x14pKnJP8Q/OkKIeny0DIaKe0bDoN30plABRSUUAFFFJSAKCaM005PSmAhOTgU4DA4oAxS0CCiii gYUUUUAFFFFADStNwalooERUVJtz0pRF6mgCME09Se9SbFA4ppGKQwzSEimk03NAEgapFkIqv1p6 rjvTEWQwNO9xVbOKeslAEjoj/eXn1FRtEV5HIqUMDS9OhoAq0VZZVfqOfUVE0bLyORQBHRmlopgG aM0mKKBC4FJgetFFAwwaOaKM0AGaARS5o4pAMZQaaMqcipcA0m2gBm9g4fPIqwkyvweDUJWmlT6U AXKKro8i4GMipxyM4xSAWiiimMKKKSgBCoP1phBFS0h560gISKFYqacy46U2gCdJA3DdfWnMMVV6 fSpY5MDBORQIcR3pKk6jI6U0igY2jAopaAEx6GmOO9PpOtACwvkbT+FKRg1D91qnB3pnuOtAhM0U lGaBi4pKXNFADaKdgUYoEZ9FFFMAoopQCelIAop4jPfinrGo680DIgCeBThExPSp1C44GKcEoAiE I/iNPAVegp+31pQMdBQAwgt3o+VerU4qD1oCKP4aAGF1/hUmm/O3tU20elGBQBGEx945pxxjilwn tS4X2oAbnFG704p2B7UYHoKAGbqTNSYHoKXA9qAIt1Ju96m49qOPagCDdSZqxx7UZHqKAK2aTPsa tZHqKNw/vCgCoSfQ0h3nopq7uH94Ubs9DQBRKSH+E0nlP/dNX92OppN4/vUwKXkyf3DR5Mn9w1d3 r/eo3r/eoAqLHMOimpAJe8Z/Op96/wB6jev96gCMKx6qRS+Xn+Gn71/vUb0/vUARGHPam/Z2B4qf en96jen96gCLy39P1o8p/T9al3p/eo3p/epAR+U/oPzo8uTt/OpN6etHmJ60AM8tz1Cn8aaYCe2P xqXen96jen96gCE279iKb9mlPdaseYg70eYnrQBX+yP3YU4Wnq/6VPvT+9RvT+9TAhFqvrmnC3Ud hUm9P71G9P71ADfL9xR5Z9RTyyjvSbl/vigBvln+8KTYc8U/cn96kJQ/x0AMK47ik5qT93/epNyd jSAZhqNretP3DuRS5X+8KYEJjkP8QFJ5Dnqwqxlf7wo3L/eFAFf7O3qKPs7+oqcuoOM5oBU/xCgC FYXU5BGaTyWHpU+V9aX5fUUAV/Jf2o8p/arHHqKMD1FICv5T+350nkv6D86s4HqKMD1FAFUwP6D8 6T7PJ6D86t49xRj3FAFT7PJ/d/Wk8iT+7+tXMe4o/GgCn5En939aTyJP7v61ex70YoAo+TJ/do8m T+7V2lxQBS8qT+4aPKf+4auYNGDQO5T8qT+4aPKf+6auYNGDQFyn5bf3TRsb+6at4NGDQFyCIMOq kVI4yOlPwaTBoEU9j/3TRsb+6aufNRzQO5T2t/dNG1v7pq3zRk+tAXKmxv7ppfLf+6atZ9aXdQFy p5b/AN00eVJ/dq1uoz70AQKsg6r+tSDcOop273oz70XFYUZpkkSyc9D607PvRu+lFwsVvIf2pfs7 eoqxu9xRu9qLhYr+Q3qKXyG9RU+aN3tRcCDyG/vCjyD/AHhU+72o3+1AEHkH+8KXyP8Aa/SpxIP7 oo8xc8x8e1MCHyv9qjyh/e/SpvMj7xn8KBLF/wA82/KkBD5Q/vUvlj+9U3mxf3D+VLvi/uf+O0wI PLX+9RsX+9U++L+5/wCO0eZGP+WZ/KgCDYvrRsT1NTean/PJv++aUSp/zyb8hQFyDYnqaXy1Pc1N 5qf3P0FAdj0UAe1AEPlA9jS+SvcmptpP3mxSYRegzSAjEcYPQtTwrAdAopTJjgcUwvmgB+F7ktRu A+6AKhL00vQBKXz1Jpheo91JnNADy9JupAKXFAAAWBOcAUm2pW+UBPTrTKYhMAUUppKADJHSlchn 3AY9RSUUAJU0a7V9zTEXLewqwgyc+lAC/cXHc1WkbJxUsr8E1X9z3oAKKKSgB0ZUH5xkU1sbzt+7 2zSUUAJRRSgUAAFLRRTAKQjNLRQBGamhlCjY/KH9Kjam0gLq/u32E/KehqQ8cVVhkGPLk5U9D6VY XI+Ruo6H1FAD1HOaDzSijGaAImWoxmNtw9eRVg9KiYZoAlBDLkUvUVXibY209DVigBCKYVqWjFAF YjBpO2KmdOc1EaAG0UGjHT0oAVDiQd6nPBxUAxuBFTGgYtJRRSAKKKKAA4pNopaSgBpX3pMH0p+a M0AR0U800qKBjc46UocjtmkKmkNAEgkGckY+lOLAnINVzTOe1FxWLYoqssjr0NSLMT1FO4iTFHrS B1J54pcgng0ANKA9RTQjA/K2PrUlKODzQAzzZF+8ucdxT1mVu+KQA8n9KaUBHIzQBOCD0oqsFI+6 2KcJXX7y5FAE9FRrMrexqQc0ALTSq+mKdSUAM2sv3TmkY54dalooAgMSn7px7Go2jZeSOKslB24p MMvTmgZUpCcVZZUfgjB9RUTW7DlTuHp3oAiGc5paXocHiigAoooIoASloooAKKKOtIAoFOCHvxTg AKYDQCaUKO9LmkzQId0pM0wuBTcselADy2KYXz0oCetOAAoAjOe9JUuKaVoAZShiKCMUlIB4anZz UVKDimBKDinrJioQ1OBoAshgadyORVUHFSLJQA9kVvY+tRMjL15HqKmDBqdyKAKtFTNGpyV4NRMp U4YYpgJRRRQAlFLSUAHail7UUhDelL1oo6UDDOKN9BFGKAGsx7E0iSFGz1p+Kay5oAsowcZFOqmr lDn9KtqwddwpALSUtFMYlFFLQAlNZM9KdRQBERimkdxUxGajIxSAEcqeKsAhxxwaqkUqsQaBE560 mKVHDjDcGlIx1oGMopSMUlADXXIpIn2t7U+o3XByKBEzDHTpTaWJty7T17UdKAGkUUtFAxKKKKAK NKFJpKnVcLTEIsQ/iNPyB0FN6GnYyKQxrNzuNO8wGmkdqZtIoAfv9DS+YfWosGigCTeaN5qPmjmg B+80b6jpeaAJN9JvqOigB++l30yigB+6lD+wqOigCTOe1GfYVHmloAfuHoKNw9KjooAk3D+6KNw/ uio6WgB+4f3RSbh6Cm4pMUwJN4/uijePQVHRQBIJMDGBRv8AYVHRSAk3+wo3D0FR0UwJNw9BRuHo KjopAP3ewo3ewplFAEm6jdTKKYD99G72plFAD93tS76jopAP3D0pdw9KjzRTAk3CjNR5ozQBJuo3 ew4qPNFAEm72FLu9hUdGaAJVkKnIAo3/AOyKiooAl3j+6KN/+yKiozQBLuHTFGR/d/WogaXNAD9w 9KXI9P1qLNGaAJQVB6frRlfSos0ZNAEu5f7p/OjK/wB0/nUWTRmgCUMo/hP50bl/un86izRmgCUM oOcGjcvoajzRmkBJlewNGV9DUeaM0wJdy+hpMr6Go80ZpAS/L6GjK+9R7qN1AEnye9Hy+pqPdRup gSkp6kUYT+8fyqLdRupAS/L/AHj+VHy/3j+VRbqXdQBJ8v8AeNHH96o91G6gCXj+9Rgf3/0qLfS7 6AJNo/56fpRtH9+o99G+gCXb/tijY394VFvo3mgCby29RSeW3qDUfmH2pfNPoKAJPLf1FJ5cnqKZ 5n+yKPM/2R+dAD9j/wD16Nr03zB/d/WjzF9D+dAD9j+1JsfP3Rim+Yv+1+dL5g/vPQAu1v7lGwnA KdaTzMdJG/Kl8w/89fzWgBGUKfu5pDj0p3mN/wA9B+VBkYjBKmgBmRRkU/zGx0WjzDnOxaAG7D6G k2nOMGpPNP8AdoE2Oi0ARY96Me9PzGeqkfjRiI9GYUAR4NHPpUmxD0k/Sjy89HH40AR04I7dFpxj YfxKfxoHmDp+hoAcsJ/ib8BUixgdqj3uOufyo8w45JFMCbFFRF+fvH8qUOBzkmgRJgelBUGo95zy ePanqcjkigBpiX3H400w56OfyqaigCsYH7MD9RTDDN6A/Q1cooGZ5jkHWM0wnHXitOigLmXn3qRP un61dMUbdUFM+zRdgR9DQBWpyY3gnoKlNsOzkUCF0RlDA7vagCI8nJpKeYpB/Dn6GmkMOqkUCEpK MiigAoNLTkGTmgB6Lgcdalb5FxSRjv2HSo5XxmgZFI25sdhTaBRQIKQ0tFMBMUUtFACAUUUUAFFF BoAQn0pKWnylDGAq8n+LPSkBHSEU7FFADSeMVYgkMibCf3i/dNQEU3kEEcEUAaKNuHIww4Ip4qGO TeBIOvRxU4oAQio2FS0hXNAFZ1zUkD7l2nqKGHaocmNwwoAuUtNByAR0oBxQAGoHXmpyajfmgCKk pelIaAEB5qeoO9TdqAFopKKQwooooAKSijNABRRRQAUlBooAKQ0ZpM0wEIBphX0p9FAEeMUop1Ji kAlGfSjFFADhIR704SD8aioouFiypB6GgjFVs4pwlYU7isTY4oxTBKD1FPDA5waAE2KV+YfQ03Yy /cb8DUn8OKKYDBMy/fFSrIrdDTCKYY1PsfUUgLNFVgZE6fMKkWdScHg0AS0UgIPSloAQgHqKbsI+ 6afRQBG2GGHXNRtCD9w/gasdetMKehxQBVIKEhxj0pBzVrnGGHFMaJSModpoGQUDnO3nFSeXs+9y exHSjNADQn94/hTuB0FITSZoEOJppam5zQBzQAFs9OaTDHrxT8YooAaFAp1FFABRRRQAlFLRQAmK QrTqKAIyuKbU1NK5oAjpQcUpUim4pDHhqdUVKDimIlDEVKknY1AGpaALQwelHbB5FV1Yiplkz1oA Y0XdPyqPvg9atY7imsoYYYfjQBXpKkaMryORUdAC0UlLQAUhoooAWiiigApKKKAEZcip4doXapqE 8ioyCDkUAXaKrpcMvD8ip1IcZU5pDFooooASiiimAUdaKKBEbLimVOajZe4pDI8461Yjlzw351BS A4oFYtkYppGKZHLjg8ipSvegCOgjIwacR6UlAyEZRqnOGXcPxqN1yM9xRC+Dg9DTEOopSMUlIYUU UUAUO9WlHyiqtWojuQUxCEUqjHFKSB1OKCcYIoAQik6ilJJFJQAmKGGRxQKX8aBkVFSMAelN2mgB uKKfszR5Z9aAGYoxQfpRn2oEGKKPwozQMMUYozSbqBC4oxSbhRuFAxcUYpN4o3igBaMU3eKXeKBC 0uKbuFLuFAxKKKKACilpKAJYxmNh3BBprDmnQ9WHqKZuBoEGKMUZFIWA70DCik3ijeKBC0Um8Ubh 60AKM0Um4etLuHrQAUuKTeKNw9aAFxRijcPWl3D1oAMUmKdk0ZxQAmKNtBOaKBjguE3DoTil2KG2 kjNIjDBRh8ppCfn4oEPdQGwME+1MK+tB4OfWlBzQA3bRinDjkUvB9qAERQ4YfxAZFKQDGrDvRGdk qt+FOxhHT+63FAEWKMU6koAbijFOooAbilxS0cUANxRTqKAExSU7FGKAG0U7FGKAEowaXFFAxBQA M8nApcUYoEBAz8pzSYpcUtADcUYp1JQAmDRg06koASjBpaWgBuKMGnUUANxRg4zTsUtADMUuDTsU DJIFADcUlS4796QigCOipNtJigBtFO284606MAsB2zQBHRnFKww7L6GnJgHGOTQAwHccDk0Vbdcp 8vDetVwFbpyB3oAZmjNSFRTdooAbmlzSquWAPQ0LHuJGelACbqN1KUxjmk2k9KADcaN1Gxs4oKOo yVwPWgBQc0HFNxRQA7IpwNR0UAS7iec0u8nvUWaM0AS5HrSbh/EOPao80tAD/kPXNSBx6j8qgzRm gCwDnpilfcq5UknNVs0A46HFAE/msOoFKJhjkYqISMO+frQZM/eUGgZP5q+v6U4Op6EVCJx3X9ac JEPf9KBEtFQlcnMbAAjpR++UdzQBNRUHnOv3lp6yZGcfrQBJRTQwpcg96AAgHqM01oY26qKfRQBC bZOxI/GlEJUYDfpUtFADGBC4UZqrIH3ZZCBV3NJQBQyPWir5UHqAajNvGf4cfQ0AVKKsG2H8LEfr TDbuOhDfpTAiopxjdeqGm5FABRRRQAU09adSGgBKKKKQC0lKpw68ZBODSyALMwX7opgNFNIp9LjI pAJDIYpM9j1rQXkAjpWYR2q1Zy/8sz+FAFuiiigCNhnmoXHFWTUTCgBtu3BQ9qlPWq33JAas9Rmg ANNanUw0ARmmnpTzTKAEqYdqhxU3YUAFHU0UUhgKPxpKXBPAFACUAZ6c0uBjpk0FgDzz/KgAA59f 5UhI/GkZySqqASeaZ/FkmgB1FGabmmAuaSikoAKKKKADNJRRSAWkoooATFIaWkNACUlLSUAFJkjo aKSgCRZWHXmpFmB4PGarZpM0xF4HJ4pSMDNUQxHQ4qVZmHWi4Fg845oZQw+YCmLIrfWn5BOPzoAj VWXlDj2NOExU4kXFPpMZyD0oAkVgwypzTqrGMdUO00vmvHxIMj1oAsUU1HVxwadQAGm7R24p1FAD PmWmGNW6HaamppQHpwaAKro68kceopmKtnctNKK4yPlNAyDII5HSgdae0bL2BHqKQDnpQAUUuKKB CUUtGKAEopaKAEopaKAEpKWigBKKWigBKQrmnUUARFcUlTU0rQBHSg4oK4pKQyQNml+lRU4NQImW QipVcN14NVgQacDimBZxio2jDdODSJJipQQw460AVmUqeRSVZIyMEZFRNFjlefagCOkpaKACkpaK AEopaKAEooooAaVBpo3IcjipKKAJI5w3DjB9alqoR6UJK6e49KQFukpEdXGR+VOoGJRRRTEFJS0l ADWXPTrUZGKmpCARQMh6VLHJt+ncVGRg0nSkBZxk705z2oIyM/pUMblTkd+tWBhxuWgRHUbrtORU xFNIyMGgYqHenuKSo0JRqmYdx0oENooooGZ561LC+DjtUR60A4NMRalTeBzyKFGEwaakmeDTzxQB Hu7UoNMPWjNIZJml4NR5pQaAH8ijP4UmaXNAABSPuPTpSilzTAi59KMNU1NZcjAOKBEDOQaTeac8 TDtn6VHQAu4+tJmkooAWikpaACiiigAooooAUUtIKKQx/aikHSloAWikooAkgP75R68VG/yOynsa UHDA+houRidj680xEZYmkooxQAUYpcUUAJRRRQAUUU4IT7UANpQCelPCge9OoAaI/U07AHQUUUAF FIWA96YXJ9qAJOB1NIGycCoqVTg5oAlo70Ag80GgY/qKbyDTh0pCMYNAgBpaCM00GgB/XiiQ5YN3 I5pKUH1GR6UDGYpCKcyEcxnI9PSmB/WpGGD600kiplAboRSmI+lMRCpNO5p/ln0pNp9KBiUoPqM0 bT6UbTSAX5T0JFIUfGVIYUmKOnSmAws69Rik8w1KHYe/1pCEbquPpRcViPzDS+YaUxA/db86aY2H ai4C+YfSjzPao6KYiXzPajzPaoqWgCTzB6UvmD0qKigZL5go3ioqWkBJvFKGBqKlWgCXcO1JvA60 2jNADw6+tODD1qLj0pRRcLEmR60ArnrUZ5FNouFifIzwaXcPUVXoouFifcPWjcKgpaLhYnU8cHml AxyOoqvRRcLFiT5gD1NRjhhUeSO9Svj5SO9NAWkOVquOEdfRqljPFMztmkB5yM4piEzxSGkjycA9 aU0gEXlxUmNjKw681Cx2rkdc8U0uScmi4WLTgFMjjnNMQc5xUazMvQ/nQsrKMZ4oAkYcg+vWnsM2 5/3agMpwMHnvTxNgcc5HSgAUZGB1NKg4wRwKbG/UHAwOKVGy54980wB155oCLtU9zSyOD6885oDg KvI68UgESNWYA5prR7SRmpRguccDNK4O7pTAgMZAzSFWFT43IQe4puM5zSAh5ozUuBuwKRhwOKAI 80Zp5Uc8c9qCmCQexoAbmilKY798UMjL9KAAsSRntRSYPpSZoAfmlDkdDimUUATCY980eYp6qKhp aAJg0fuPpSgD+GT8CKgpaAJwJPYj2NG9l6qagHFOEjjoxoAmEo7nmnbxiofNz95AaA0Z7FaAJgwP Q0bqi2g/dcH60uGA5XPuDQMk3Um/2pgyQSO3UGlzwDQA8txxQDkVHx6ikweDjrSAmBz0pPlbqAfr UOWDHb1pRJznHPQ0wHGCM/w4+hphtv7r/mKfux0/KnhgelAiqYJB2B+hqNgV+8CKvjFLQBnZHrRV 5okbqoqJrVf4SV/WgCsOKKma3kHQhv0qMqyjLKQKYDadTcg96cKAGsKYCVIYdRU2KjYYpAaKMHUE U6qlnITmM9ulWqAA0xhTzTTQBBKuVzUkLbo/pxQwyCKjgO2Qqe9AE1NNOPWkNAEbU004000AJUg6 Co6kXpQAtJ3A6+1A5OAakAAHFIY0gfxc+woPQE/lSPwc01iGdA3QZJpgNd8HGaYST7CkYgmjBNAC 7yGynXGKFXnJP4UoGKWgA60UlFABRRRQAUUUlIBaSikzQAUUlJQAtJRmkoAKKTNJmmIU00nFIW9K bQApNJRRQAtGaKSgBcmnrKy1HRQBaS4B+9xUysCOD1qhSglehoAv96inHIPeo1nI4bkVOsqsOKAG hAzhj8vGM0okkj+8Ny+op/WigBySK44NPqBo1Jz0PqKQO8X3huHqKALFFMSRXHymn0AFNKA9OKdR QBHyp54oOD2/GpKaV7g/hQBGUI5HIplS5I68UFQ444PrQBFRilbKfe/OkyKACil/GjmgBKSnUUAN op1JigBKKXFFACUUuKMUAJSU6koATFNK0+igCIjFJUpGaaV9KBjKcGppFFICTrTlYrUIOKeGz1pi LKyAjmnEelVhxUiSY96AHOgfrwfWomUqeasAhhxSEdj0oArUVI0eOV6elMoASiiigApKWigBKKWi gBKQgGlooAZyhypqVJs8NxTaaVoAtA5oqrl16GpEmzweKQE1JSgg0UwEpKWigBCARzUTLipaDz1o AhpyOVOV/EetDLimdKQF0EOMimEVCjlDuX8R61YLB03CmBBIuRnuKdE+RtNOIqFhsbIoGSkHNHNO VgwyetLlaBGYaKD1ooAUHFKXJGKbRQA7caA1NooAkyDS1HThSGOzSg03NGaAJA1Lmo80uaAJM0ua jBpwNMB4NIyq3UUmaXNICNoB/CfwNRNGy9RVrNG7FAFOirZRH6jBqJrc/wAJzTEQ0U5lK9RikoGJ RS0lAhRRQKKQxy0tNHWnUAFFFFABT7gZEb+optPcZth/smmBBS0UUgCinBD34p2FHvQBEFJ6CniP HU07JpKYgGB0FLSfWkLAdOaBi0HA6mmFyabQIeZPSmlietJRQAUUUUAFFFAFACg4qQHIpgX1pc4p DsSr0p3UUxDT/WmIQ9BSY4zSb1xj0o3r70AGCBntSg1GzFvp6UgbFIdicH3xQyrJ14b1pgYGnA0w ImUoefzoEjL0NTdRg9KjMXdOfakFxyznuKlWVT3qrupM0AXcg0YqnuK9DinrcMOvNMCwVppWkWdT 14qQMG6GkBHt9qTHpU2KQrQBGwXPynI96Bx0p+2m7TQAmQfvIDSGKJuhKmlooAja2b+EhqiZGX7w Iqz9KcJGAwTke9AFOirZETfeTB9RTDAp+4/4GgCvQKkaCReq5HtUfQ0xDqVRlsUlKnDikMdtoxTz SUwG4NKqk0tKnWgAZCKaAcVO9RilYLjHABBAwD2plSSfdFMpDEpaKKACiiigApyn5cenSm0U0BYi OGzjNK//AB8D3U0xe1PlP7yJvwqiRi0Gl6E0Dk0gIpD8wHpTaCcsT60UigozSUUgFzRmkpKYhc0u aZRQBKD704NUAJFPDA/WgCUNyT60NK69RkZzTM0oNFwHeeCuDmlEoIwWGajKKTnpRsUds0XCxKHB pd3BPPBpgRuy4oxjq9FwsPBGBg/eBp2OCfYGog6qcjJNN34BAHBp3CxORhjn+9SNyD9ajEuM5B5O aXeCD83fpQIft59MGm4yfxo3k0bhxn1oATHNGKUsCeDR+tACAd+KQjFSqMx5HJzimsuF96AI6WnF eAfWkC8Zx060AJmjNKACcE4oETMcLj8aACilZCDjGMdaZQA6lUlehIpuaM0ASea+eoNL5gPVB+FR 0UAShl9SKUDj5SDUOaWgCbLf3eaT5WB45PeowzDoxp3mH+IA0AO2g/do24IIyR/Kmhk91P504Zzw wIoAcWK9uB1NKGDHFMJIBypxQWU8kc9M0ASg96Wmbl+mKUGgB2aKSigBGjR+qg1EbZf4WI/WpqKA KxhcdMNUUikDkEVfooAzUfZKrjsea0c8A0x4I36rz6ilRNihckgetAD6Q0UUANPSq7/JIGHY1YPS ophkUASt6009PeiM7oge44pCaAGNSE0pNJ3oASlzgUlHYUAPh5ZjUtRwfdY+9SUARXJwqgd6h5PW ppxkpUdAxAKWiikAUUUUAFFFFABSUUUAFFJRQAUmaM02gBaTNFJTAWkpCcU0nNAhSaaTRRQAlFLi igBKKKWgBKKKKACloooAKKKKACl6UlFAEyTsvXkVOkqv3xVOigDQ7UgODVVJWX3FWEkVyOcGgCJl In5OMnqKek5QkOMgHGaf5ajLEdB0qOIbn56Dk0wLCsGGVOadVdoxnch2t7UomKHEox70gJ6KQEEZ HIpaAAgHrTCmOn5U+igCMN2I4PamPDnmM49jUxAPWmFSDkc0AV8OOCKN571YyGGG596jdXQZxuX1 oGMDil3Ck3Ie1JhD3IoEPzRmmbT2YUYYds0ASZoqPce4pQ4oAdkd6Xj1poYUtAC4pKM0uaAEopaK AEpKdRQAwqDTSuKkooGQ4pKlK5phXFIBAcU8HNMooAlVsGp0kDdaqBvWnA4piLZFRugb2NNSUjry Km4YZFAFYgg4NJVhlBHNQshX3FADKKWigBKKWkoAKKKKAEopaKAEppUGnUUANBZOnT0qVJgevFMp CoNAFjINFVgWXpTxMO4xQBLRQCD0NLigBMVG6Y5qWigCvT0bawP50OuPpTR+tIZaJBwR37Ux1yMV HG+1s/nU7cjK80xFbJXijdUxQE5NJ5a0DKBooooEFFFLQAlFLRQACnU0U6kMQ0lKaSgAyRTg1Mpa YiQUuaYKWkMdmnA1HmlzTAk3UuajzSg0gH0AkU3NLmgB+7PB5ppiRunBoooAjaBxyORURGDzVoMR Slg3DAGgCpS1OYFb7px7VG0Tr1HHtQMZTqbTxyKAEpaKXFAhKkXmJ1/Km8DtmgsTTAQIB94/gKXI H3Riko+tAB1oxTS4HTmmliaBDyQOtNL+lMooAUkmkoooAKKKKACiilAzQAlKBmnBfWl6Uh2GhaX6 UZoHSgYGkoooAkjqSoUqbtTEyBuGNJT5OuajzSGLSUUUxXDNPV+xplFAicGnA9xUAJBqQNQA9lDc nr61A6lTzU+aOoweRSGVzSYqVo+6/lUdACUoOOlFFMQ9ZnXvn61KtwP4hiq9FAy4sit0NOqjTlkZ ehoAubaaVqJZz/EPyqRZkbvj60ABWm4qbrSYpARUYqQrSbaAGglehpSwYfOoajFJigBrRxEZBK0z yGyChDU9hhSaiDEHcDjNAEjAg8jFJTlmYdcGl3xnqMGmA1jkDI5HShetP2BvuODTdjKeRQIlb7oq LualP+r981EfvUAI/wBz8ajqVvuMKipDQUUUUhhRRRQAUlLRTAmToKdN9xT6GmR9BT5RmJvY0yQY fOeKRjiNj36UpOSp9RUUxxgUAR0UmacFY9FNIY2ipBA564FOECj7zZoAgo69KtCNB0XJqQI3ZcUw Kgjc9FNOEB/iYCrXln+JgKMRgkZyR2oEVxCg6kmnCIH7q1NuCj5UH401pWz94AUAM+zyH0H1qMoU ba3WntMO7E0xpQRjGaBihT2pRkVGsmOtTq9KwXI2BPcmo9wq1we1NaJH9j60WC5W3Um406SNo+o4 9RTKAJFbIxTsA9qhqRWz9aYDwMdKRkYKWU5A6ilpyttPFAEIkP1pQ47j8qdNGAN6fd7j0qGgROsm 3gEgHrTxKeOhqvS0XHYnXAPPSl+YqFHI71Chw2OxqZSQGXPy+ooENapFqI9KlWgBWHYdKbjipP4q jPGR70wGkCm4p7dM02kAgUk4FHI60+MYy1B6mgCPNLmnhQc+tIUGBzQAmaM0bG7c03mgB9J1pM0Z oAeGYdDTt+fvKDUeaWgB+VIwCR9acAexBHtUVFAEpbDHOfanBjmog7DjP50odehXH0oAlVgSeKdU K+it+dLllzkY96AJaKjD5A5xTtx79+lADqXNNDUtAC0YpKWgBu2mSKSOBmpaKAK8JwroeMGlY1OR nrUbQg9CRQBCw+bNJT2jdRwNwqPODg8H3oAWg9qKD0zQBJb/AOq+pNS1HB/qVqWgCGfqtRVLP1Wo 6BiUUUUgCiiigApKWkNABSUUlABSE0UhpgFJmimlvSgQpNIWpKKAEpaULTwKAGhaMU40lADcUEUt FADcUlONJQAlFLikxQAUUUUAFFFFABRRRQAUUUUAGaXNJRQBMkxXryKsRyIwIXgmqVOjG5x+tAF6 kPPB5FRqzKeORTwwP1oAb5ZXmI49qcs3O2QbWp1BAZcMMimBIKKr7Hj5jO5f7pqSOVX46H0NICSi iigBGUH2pvKmn0UAQvEr8r8rfpVdyY2w6kVcKelNbDDa4yPSgZU3inBh2NLLbFfmj5X07iq9AFjd 70de1V8ml3Ed6QE2BRj0NRCQ04SeooAk+ajcR1FMEgpwYHvQIdvFLkU2jaKYD80Uzb6GjDCgB+aM 0zJHUUu8UAPpCM0m4UZoARkphFS5oPNIZDSg4pxWm0AOBzTkcrUeKcD60XCxaVw1BFVgcVOkmeGp iGPHjlenpTKskccVG6Z5HWgZDRS4ooEJRRRQAlFLRQAlFLSUAFJS0UAJSEA06koAbtI6GnrMRwwp KKAJldWHBparbfTilDOvQ5oAsfWoXXacilWYdxg1ICGHWgCLqMino+Bgd+tMI2t7Uh45pDLW3PK9 KPLNQrIQMA8Uvmt60xFGiiigApaSloAKKKKAHCnYpBTqkZGetNpxpKYhKWijFMBwpaQUtIYjdKZk ipD0qOhAxwf1pwINRUUxE1LmogxFODigZJmnA1HmlzQBJmimZpc0gHdKcr0wGlyDQA8qjjkflUbR iPkHg9qXHoaHyy4PUUAMyB0FNOTSgGlxjqOKYDaUDnFSjyzjbx9aYRgg0CI2YqxHpTCSetPlH71q joAKKKKACiiigAoopQpNACUoBNPCetLkCkOw0J60vApCaSgYpNFJRQAUUUUAFFFJmgBy9anHSqwP NWF6UxDJh8uahqw4yhqvQIXNLTaUUALRRS0AHen0yn0hi5xTgaZRnFAEtNZA3sfWkDU7rTAhZSpw wxSYqweRg8io2jxyvI9KQEeKKWigBKSnYoxQAlGKWigBQSOhxT1mcdeajooAsLOp65FSBg3Q5qpR igC5ikIqusjr3z9akE3qPyoAHTIwKYYzUwdT3paYFYoRQilnwOTVjbmmtGT060CISueVODnpSiV1 60pjJ6nFNKkHnmgB/ncZ6+opTtYjqpNQkUqE7wDQBKUODgg1EVK9QRUvQ0oYjvmkMg60VOdh+8v5 UnlKfut+dAENFSGF89P1oEJ7sBQMjpKnESDqSad5fHypQBFGeKnPKkeoqLBB5qUdPwpksj6Ae1Ls Vjlhk0owG5GRUhlwOFAoGNVMfdTFP8tj1NRtKePmxUbTAnkk0CJ8ID8zflQWjXopNVTL6CmmRj7U DLfnN2UCmGY93qqST1NJQBOZh9aYZT2AFR0UAOLse9NzmiikAUUUUAFKrFelJRTAnSQH61KGBqnT 1cjrQItg8e1RPADynB9KFfNSA5oApkFTgjBpKtuoYYPNV3jK+4pDHK2frTqh6VIrZHvTAkVsVHLH j50+73HpTqcrYoEQjoKUAlc+lSMm0bl+5/KkTksg/iFIY1R3qVWI/EYp3l5QKvakcgEAdqAGHpUo /XFRGpI+ozTESH734Uxuppx601vvGmAh6Uyn4O2kQZfnoOaQDZCAQmcECkBbHBzUTNuYt6mkoAsR sfNGRinK24jIB5quGI70vmHABAOKALKnODnA5FA5VQCOpqESDjPanBs4wQcUwHbQccdelM2e+PrS klUU570BgRj9aAEKke9J060/I+lP6o2OQKQEWaUGnMq9RSNGRn0oATNLTSCDSZoAeRigMy9Dik3Z 60ZoAfvB+8ufcUowejc+9NI+UN2NJQBIQR94UAn9OKYCV6HFLuHcfiKAJA9ODVEBn7pz7dKUBu4I FAE2aM1ED+Bp271/SgCSkpoalzQAtIVDDkZozRQBE0A/hOP1qN0dVORn3FWc0tAEUP8AqVqSlxRi gCCfjZUdSXJwE+tRUDCkoopAFGaSigBc0pFNzS0ANPWkzSt1phOKYC00mkJooEBNJRTguaQDQM08 LTgMUUwCjoKKQ9aAENJS0UAIaSlNFACGkpTSCgBaKKUUAJikxTqKAGUUppKACiiigAooqRIXfoOP U0AR0oBY4AyasrbqvLHcfSpeFGAAB7UAVltz1c4HpUyxqg+Ude5p2aTNAC004NGaaWoAeGI68in5 BXIPJqDJNHI5BwaALPQCmuiv94c+opizf3x+NSD2OaYDN0kX3/nT1FSowcZU5poNMMYLbozsb+dI CeioUmwdso2t69jU1ABQQCOaKKAGYKnPao5Ikl5+63r61PTWXuKAM90aNtrDmm1fdFkXa/UdD6VT liaI88jsaAI6KWkoAKKKKAFBI704SMO9MooAlEp7inCUGoKUHBoAsB1P8VKQD3qv8tITzmgCfZxS hT61AHYd6esrfWgCTDCjcR1FMEw7inCRT3oAXeKDg0uVPpRtFAyM8UZpxT0NNKkUgFDU4NUfNGaA LKS7evSpuGGRVINUsb7ORTESsoP1qIgg4NWFYOOOvpTSueCKBkFFOYbetJQISilxRQA2ilxRQAlJ TqSgBKKWigBKKKKAEopaKAEwKbtx0OKdRQAByBh+aa57CnYppX0oAaGIFLuNNopAR0UUUwClpKWg AooooAetKelApG6VIxlFFFUIBS0gp1IYoFLihadSAYelRVYI4NQHrTQCUUUUxBRRRQAoNODU2igC QMDTqhpQSKBkuaXNRh/WnZoAeDTgajzRmgCXgim7TSZpQ1ABtowR0p271pc0AOyH5K81G1vvPy4B p+SPpShgaAKTKVbBGDSVfIDDkAiomt1P3TigRVpQpNTGFl6jP0puQKQ7CBcdaXIFNJpKBik0lFFA BRRRQAUUUZoAKM0lFArhSUtJTEFToeKhFSpQA/sagxVg+1QsMGgBmKKdijFACUtJSUALTxTKevSk MWkPSl4pDQAgp4NNpaAJA3rSg1GKUGmA5lDc9DUZBU4NSZpeCMHkUrAQ0U9o8cjkU3FIYlFFFABR RRQAUUUUALmjNJRQAtKGYdDTaKYEomI6jNSLKp9qrhSegJp4hc9QB9TQIsZBpCuaiEWOr/lUg46Z NMBpjBpphPYVMFc9sUvlnuwoAhEZwQxHPf0pQqgAFs4qTEankk0nmAfdTH1oAaBn7qZp4Rz6CkMz diBUZkPqaAJdgAyzUYjHqah39cd6TLGgCx5ijotRySlhjpUe09zSFQKAEHDVOp4qvUy5K8UIGNfo cVDkkcmrDj5vrUJicdsj2oEMxRilPHXiikMbijFOpKAExRilzSZoAKSiigAooooAKKKKACiiigAo oooAUEg8VIsnrxUVFAFtWpSARVVWK1KsmaYhrx4NR8g1ayG61G6Y5HSgY1WyKdUeMcinKc/WgCRW wfanRoAxYcjt7VHTlYqeKBFleBmqkvDYqyzgqCOBVVzuakMUfMufzqVOagQ4PsamjpiJKafvYpxp p60AIehpJDsiY924FKaRx8wU/wAIoArYpalKA00x+lADKKUqRSUDCiiigBQxHQ07zD3ANMooEP3K fapFI2tg1BRQBZYkbuc8UOxwwIyAuagDMOhpwlPOR1GDQBOSC3HXZSKASCQCKYHVic8ZGKcqgMCp 4ApgDR4xg9elM2n0qRy21DjIxzQjAnGSM0ARhuxpQaeVBGOOv500x9SDjmkAZpaaVK5zSA0APpQ7 L349DTQaXIoAkDq33hj6UMCOV5Heo6ASp44oAcrDNPyccGmb8/eXPuKXCk/IR9DQA4GlBpmdp+YY 9qAfTigCTNFNHWlFADgaXNMooAfwaieBTyvymn5pc0AVWjdeq5HqKjyD0q/THhR+SOfUUAU6SpXt 3X7vzD8qh74PB9DQMUU4nApB04H40whu9AgLU2lopDG0oFO20YxQIULS0DpS0wCkpaKAEptKaQ0A BoPSikNACUtFFACGkFKaSgBaWkpaACiikoAKMU9I3f7q/jUywKPvnJ9BQBWAJOAMmpUtmPLnaP1q wMLwowPajNACLHGnKrz6mlJJpM0hNACk0hNMZwOpqJpSelAE5bHU1E0oHSoSxPU0lAEyuGOG61Jj FVaeshXjqKAJ8UUiuGGBS4oASlBK/d/Kg0UASpIG4PBpwqv0Oe1SoDzsx9DQA5sN8rDIpu14slPn T09KVW+bB4b0p44+uKYCxyLIMqfwp1Vo4t0YIO2TJ5p6ykNtlG1ux7GkBNRRRQAhANNIIGDytPoo AqS2/G6Pp6VXxWgVI5X8qjkiWX/Zb1oGUsUlSOjIcMMGm0CG0U7FGKAG0UuKMUAJRRRQAUq8c0AZ oJ7DpQAlFFFABShiO9JRQA8SsKd52eoqKigCXeDRkGoqKVh3JsCgcGocmlDH1oAtIxB461YRw4x3 rPEhqZHz060xFtlyKgdSvbipo5N3B6/zp5AI5oAqZpc0SRFTlelM+b0oGPozTN2OtG6gQ+kxSZpc 0AFFFFACUUtGKAEpKdikxQAlFOxRigBtFLijFADCtJtp9FAFWiiigApaSloAKUCkpwpDHDpTX606 mN1oBiUUUlMQtLSUopDHrTqatOpAL2quasH7pqHGRTAbRS4pKYgpKWigAooooAKKKKAClBpKWgY4 MaUMKZRSAlozUZOOlAf1pgS5pQaYGBpc0ASBqdkHrUWaXNAEnHY07cw681EDTg1ICQOPpQyK45AN MyKUe1ADGtx/A34GomjdPvCrW4jqM04EH7rZ9jQMoUVdeJD95cH1qFrc/wADZ9jQFyCilZGX7wIp MUCuJS0UUxBRS4pcUANxRinUlIBBT1ptOFMZLShh0cbl9KaOlFAhsqeXJgfdPIplTsu+H/aTp9Kg pDExSEU6jFADKcDxSEUUxD80UzNKDSGPooFLQAlLRRQMXNOB4plGaBEoNIyBuRwaaGp6mmBEQQcG jFTEZ4IphiOfk5FICPFFSiI9yBSiJO5JosMgpRz05qyEUfdSnhW+lFhXKoic/wAOPrThD6sPwFWN gH3mpNyAZHNOwEQiQepqRY8fdTFHm+gApplPrQBJsbuwFJhB1bNQGT1OaaZPQUAWd6LnC5oM2OgA qoXNNLH1ouBZaYngnimGQdqgzRmkBKXNIH9ajzS5oAnUoepqQKnZaqZpQxHQ0wLePSk21AJmHXmp FmU9eKAFK0hXipAwboaCMikBXIqRKaynNLGaaBjn60nIp8ozTWJYc0CDdnqM00pGexU+1LRQMjMJ /hYGmMjr1U1PShiOhoAqUVaO1vvKDTTCh+6SKQFelxUphYdOfpTCCOoxQA3FGKWloAbijFOpKAG0 tGKKACiiigApKWigBKWiigB6yEdalV8j1FV8UoJHSmBMy9xTOOtKr+tOCb3A6DqaQCYOKKs7BIee 3T2qu67XIpgKrY4okQAZHSminq2OD0PUUCIanj7VFImzkcqehqROAPehASngZ7AUwnIUjuM09s7S B+NQ79sUeRnigCRRlqb1JPrQGyMAYooAKSloIpgJSFQadRQBGYx2ppQipqKQEGKSrBAPamlAaAIa KeYzTSpFAxKKWikAlKCR0pKKAJBK4GOop6zLuOVwDUFFMRYAUkFT0p25gAPvc1Vp6yMucHg9c0AW CwAY/wC1ikZVLH+lR+cCMMtAKMTg4NMB7IeMHIpmcdeKmG/ZxzimhlOQeMdaAGA0uad5QbpkZphV lGcZHtSAdSYpoNOBpgODMOM8ehpflY/3PpTaKQD9rD3HqKAwNMBIOQcU/crH5l/EUAOB9KXp1pm0 9VO4UBux6+hoAfmgc0gI+lL9aAFBpc03tRQA/IprIrjDDIpOfxpQaAImgIPynj0NREYOGGD71czS FQwwRkUAVsCk2L6VI0BHKH8DURYqcMMH3oADH6GmmNuwzUgYUoIoAhwR1BFAqfPvSbVPVaAIKWpT EvYkU0xN2INAEVJTmRl6qabntQAE02lNJQAUtJS0AIaBQadHG7/dXPvQA2lHPA5NTrbgffbPsKlG EGFGKAIFt3b7x2ipViROcZPqadmkzzQA4nPU00mmk01nAoAkJppbFQmQnpTCSetAErSjtUbOT3pK KAENJS0lACUUUUAFFFFAAOKlSX+9+dRUUAWuDyKDVdXK9KmWQN7H0oAd2pY2wcUYpp9aALRUSpg9 ex9KjDFDtf8AOljfH0qR1DLQA3vkDNIRuXDDINR5aPpyDUgYN0piIt7QNjlo/wCVWFYOu5TkU3NR mPDF4jtb07GkMnoqOOUOdrDa47GpKACkKg0tFAETgMu1xkVWlhMfI+Zf5VeIB60w5X6UAZ9LViWA H5o+D/dqv7UAJRS0lABRjNFKn3vpQAH+6OlNxTqKAG4pKcaSgBKKWjFACUUpFJQAUUUUAFFFFABS g4ORSUUAWEcN161ajlzhW61nA4qZH3cHrQBfIzVWaJly0f4ipIpeit+BqbFAJmd5p70eYvdannt8 /MnXuKqGgZLuT1Ipc+jZqCigRYyaXfVfJHelDtQBY3UZqDf7Uu8UAT5pahD+9KHoAlzRmmB6XdQA /I9KPlpuaOKAHYHrRtHrTaKAKdFFFABS0lLQAU5abT1pDFPSo6kbpUdCBhRRRTEFOFJSikMcnQ06 kTpS0gF7EVEo+X3qUVCeDTAWikzS0xCYpMU6igBtJTqSgBKKWigYlFFLQAUUUUgA0gpaWgAAp2cU 3NFADg1OzUdFAEmaXNRhqcGFMB+acGqOlzQBKGpeDUQNKGoAmBYfdbI9KUOP4hj6VFup2/PWkBJn PQ5FMaFG6jB9qPlPQ4NKd69TkUAQtbsPukNURUr1GKthx34p2cjswoApUtWDCjdPlNCxbUwVDH1o Ar0lTmNT0ytMaJh05+lAEdKKTp1pw5NADk6U5ulNXqRT+oNMQqHbhv0qJ02OVHTtTweKHG6PPdP5 UmBFijFLRQMTFJtp1LQAzbRinUoVj0UmgYlFPEL9wB+NOEI7v+QoAjozUwjjHbP1qQKey4oEVgrH oppwiY9cCrBU5+Y4owg6nNMCuVC9TSDI6cip968jbUTM2OvHpSGKGzTvpUANPDc0xEyspOGHNKZA hxswaZkMKXORtYZH8qADzm70wyH1pHjKjK/Mv8qjpXAeXppY0lFAASfWm0tFACUlKaSgBKKKSgAo oooAKKKKYBRmiikAZooooAUEjpT1lYd81HRTAl83PUU+M85qAVLH0FCAsPyBQq5WkP3AKY0hjxxw aBEhSm7aRZge+KkDA96BkeKMDPPSpcZpNtADGAB4ptP20hBoAb0707ce/NJRQAhSM9sH2pph/utn 607FFICIxuvVeKbVgEjoaMg/eUGmBXpMVOYkPQkUwwsOmDSAixRTyCOoxTTQA2ilpKAClpKKAHUt NpaAEPAq5ChSNQep5NQQJvkyfurVscnJpiAkIPc1XmboO9Syt39Kqt8xzQA7NLUeacDQMeT8uDTk 7AdKibpT4ugoET/wn6VA4/dpip/4TUW3KqPSgAUcU6gcUUAFJS0UwEopaKAEopaKACiiigAoxmii gBpQGmGP0qWikBAVIpKsY9qaUBoAgoqUx+lMKkUDG0UUUgCkpaKYD0kcAgE09ZBghxnNRL0ooAtf fwUbkDFJuIChhjnmq3Q5HBp6zsnX5hRcRN8rq5Ixg0jRMCcHOOaQNFKm3O3Jz+NPcEbyDkEDFMCH OOuRTg1SFvlw4zimFBgFTSAXPFFMwy8kcetKGBoAdyDTt+eGGRTQaKAH4Dfcb8DT9hAHNQmnBip/ pQBLt9aTpQrgn0NNkOG9qAHcZ5FGOBxzSZyBzml/WgA+lOBpvBHFHQ4oAfmkZQwwRkU0dacDQBA9 uRzGePQ1CSQ20jB9DV6kZFYYYZoAp7sU4PSyW7LynzD071D/ADoAmD0oIqDJpdxoAsAnsaCAfvKD UAfFPEnvQAphjPTIqM25/hYH61KGLdBmn49etAFRopF6r+VOSB26/KPerOcdOKTdk9/xoAasUa84 3H1NPLe9MyaTNADs+tDMM8cUwmo2c+mKAJS2OtRtKO1RE5pKAHlyabRRQAUlGaTNAC5pM0lFAC0l FFABRRRQAUUUUAFFFFABRRRQBIkpHB5FTAhhkVVpQxU8GgCyDtP1qzG2RiqayBhg8Gpo2/OgCWRf SoCMHI4PerXDLUTL1pgNVs8GpKrTNgBQeaI58cNx70gLDosg+Yc9j6UwSNEQsvI7NUmQelHUYPIP amA8EEZFFQbXh5j+ZO6+lSxyLIuVOaQDqKKKAGlccrUckaS+zetTUjLn2NAGe6MhwwxTavMAw2uO KrSxGPkcr60DIqcvRvpTaVehoEIKDS0UAJSUUUAFFLRQAlFLRQAlJTsUmKAEooooAXFGKAadQA2i nUYoAejBhhutWopTnY/4GqOKlVsjBoAvkVVuIM/Mg57ipIpcYVz9DUxFAJmUaSrc8OcunXuKqmgY lFFKFzQISinFTTcUAFFFFAC7jS7zTaKAHiSnCSoqKAJ/MFHmCoKKAEooooAKWkpRQAU9elMqRelJ jQjUylY80lABRRQKYhaWkopDJF6U6mr90U6kAdjUBqY8KahpoBKXNJRTEO3UuaZRQA+mnrRRQMKK KKACiiikAUUtFAxKKWigBKKKKAClpKKAFooAzQeBQIN2KUN60yimIlBBpaipwNAEmaUGmZpaBj80 4Nios0uaAJgwPWl2/wB01CDShqQE2WXqKXKH1U+1MWQ+tKCh65H0oAfgkcYYU3aOxIo2Hqpzj0pR Iejc/WgBrBsfMAwpmxeq5B9KlDe+KVl3D196AK3R6eKbKpUgmnCmIaOpFORtrjPQ8Gk6P9aMZoAQ xsGKgHApRE3fAqVcso56cUfKOrUWGM8od2z9BShEHbNP3KKTziD2oAUKey4p2092xUTSk9TTN1AE /wAg6tmk3oDjFQFvSkLGgCfziBgYFNaXIwTUBJpKVwJTJn3pN5qOlouA7JpKKKACiiigBQcGpQc1 DmgNimBYBK9KRo1k5T5W9Oxpiv607PpQIhYFThhg0matZV12yDNV5YGj5HzL/KkMZmkzTetFAC5p KKXFACUUuKXFADaKdilxQAyin4pMUANpaXFJigApKWigBKKKKACpYjUVPj60wLXVaim+4D6VKv3a ikH7thQxEVKDjpTM0ZpDJRKw96kWf14qvmlzTAtrIrd6dkGqVODsOhoAt4FNK1CJiOtSLMD/APXo AXbSYqQMD3owDQBFRUm0UhT0oAjopxBFIRQINx780hVG6j8qXFJigBhhB+6350xonHapqASKBlbp RVonP3gDTDEh6ZWkBBR7Dqak8lucEGn28R3lnGNvQUwJo02IEHXv9aex2j3pFzkk9B+tMd8Ak0CI ZWywSm0zPz5PepO+KAGkUlPPDlTwRTSKQwJytSRD5FPrUXSpIjxTEWB0pnQ0/tTCcHJoAKKU+vai gBKKWj6UAJRTOAwHIYnmpKAEooopgFFFFABRRS0AJRRRQAUUUUAFGM0UUgGlAaYY6mpKAK5Uikqw aayDBNAEeMIG9aMU88Iq/jRikMjpjVKRUYGWoAcowKUMV6HFFJQBKJQwxIuc8ZFO2jGY3z7VBR9O KdwsWlLqoDCgojE44IqFZ3HB+YVIrLIu0HBzmgQ0xuvuPUUgaptxTeefl6e9IyKzBfbORTAYDTs5 pmxgNw5FIGx1pAPNOViBj+dMB5paAHgKRx8p9KDlfvcUynKxHHb0oAeG3NgClOR0FMXbuyp2k9u1 SbiPvDFACE8c9KWjjrSdKAFzgUoNNzRQA+mSRLJ94c+opQcU4GgClJC8f+0vqKiyD0rSphiUEsoA Y96AKixOw/uj1NSLDGvX5j709iR97im5oAfu/AU0mm5prOB3oAfmkLepqFpCelMJJ60ATF/SkDDv UOaXNAycEHoacFY9sioAwFPEnvSsFyTylP3hTTbqfuuR9aUTGniRT1FMRA0Eg6YP0qJlZeqkVdBH Y0uT65oAz6KvMqN95B9RTDbxn7rEUAVKMVObZh90hqY0bL1UigBmKMUtLQA3FJTqMUANopaSgAoo ooAKKKKACiiigAqSJ8Ng9KjooA0Ym5wae471UhfIxnkVcU7hQBTuUwRIPxqDNaDKDlT0NUHQxuVN MB8cpQjuB2q2jq67gaz80qsVORSA0elRvHk74ztf9DTYplYYPBqRtwGF/WmII5dx2sNrjtUlQyKs nDdujUiytGwSbv0b1pDLFFJS0AIRkYNMOVODyDUlIeaAKcsG0bo+R3HpUK9DV8gryOlRSwhgWQYb 09aBlWkpaKBDaWkooAXNFJS0ALSUtFABSGlpKAG0U6kxQAlKKSigB1LTQaWgBaWkooAkVsjBqzFJ jCt+BqlUiNng0AXmHcVUniz8y/iKmik/hbp2pzAqcDvQBnEU9OlSzw8bl6dxUa9KAFNNXlqcelNX rQA4gelN2inGkzQA0rTdpp5NLQBHg0mKloxQBFRUm0UbRQBHtpMU6igBtKKDQKAFHWn01etOPSkM YetJRRTEFAopaQC0lLRQMkHQUtJS0hjX+6aiPSpZOlRmmhDaKKKYgooooAKKKWgYUUUUAFFFFAC0 UCikMKKKKACiinAUANxSgU6jFAhKa1PIphoASjFLRQIKKWigYUuaSloAXNLTaKAHUUmaWgBc0oam 0UwJA1SrLnhgDVfNLmgCfCHocUYI5qEGnh/ekAS5aPHemoeKkDrjBGfenYB+634EUAR+WzfMO1Ic j7wxUpyvXijdTERpggjPWoySDhhg+9TtGjex9qcASuHw49xzQMrZNJU7Qo33MqfeoWBU4YYpAJRR RQMKKKTNAC0lGaM0gEoopKAFzS5ptFMBc0ZpuaKBC5pM0UuKAAMRUitmo8UtMCcNT1cjvVcNT1bF AhzwpJyvyt6djUBUqcMMGpwaccMu1hkUDK2KKe8RXJX5l9fSmUgCiiigAooooAKKKKACiiigBMUY paKAG4opTSUAFKn3qSlHDCmBaTpSEZDD2ojpSPmIoEUx0paOhNFIYUUUUAGaXNJSUAOzS5ptFADw SOhp4lYe9RZo3UAWFm9eKkDg96p7jRupgXuDSYzVQSMO9SCb1FAE22kK0iyqakDA+lAiMikqXik2 0AR0lSFaaVNADee3WplGMCmIOpP4VKowMnrQAknTFVnw/VsAVLK2OlV3XavsTz7UADQyKQcbh7Up GDTVZgflJp/nHoyg0ADHc249fWm0u9D2xTtmehBoAjNOiNIwK0RUAWR0pj9DT16Ux+9ACI2OvSn/ AMqgBqRXxwelAD6KKKAAjPJooooAKKKKAEooopgFFFFABRRRQAUUZpCeetADqSjrS0AFFHYmikAm KRh8v1p1Nc8UAMPLE/hRSDgUtACHpSKvGT3o+82KcfSgBpFIRinij60DI6KfjNIRSAbSN9006mt9 00ACTOnfI9DU6zIxU5KsBiqlFMRdG5ApBypJqQ7HQM38XSqKyMn3Tx6VMJkkRVYbcUwHtEV5U5FN DEHB4NOUkE85FSMVf7woAjBpaQwsBlDn2pobnB4pASU7cQP6GowacaAHggj5flPpT3O0D3qGnAkL yMigB+QRzxScimjB4U/gaUN82Oh9KAHUc/hQDnpQBjI9aAHZpaZSg0AOIBHNQPCRkx/kanpaAMxn bcVYbT6Uma0JIkkGGGapy27x8j5l/lQBFRSUUAFFJRQAUUUtAAGIpwc03FLQA8PTxJ71DS0ATiQ0 4OKrZpdxoAtBhTgx9aqh6cJKAJyFb7yg0wwRnpkU0SU4OKAGG3b+FgajaN16qashhTgT2NAFGkxV 44b7wBphhjbsV+lAFOirLW391gfrUbQyL/Dn6UARUUpGOvFJQAUUUUAFFFFADkba2auxN3qhU0D4 +U/hSAvsMjNV7mPem4feWpo2BGKUjBpgZdLUlxF5b5H3W6VFQA4VPFOR8rfnValoAv8AB6dKXAK7 WGQexqpHKU46iraMHUEfnQIjBaD1aL9VqwrBgCpyDSdOKhKGEl4hlf4koGWKKajrIu5TkU6gAphX HIp9FAFeWISDI4f+dVDwcHgitFl7iopYhKPRuxoGUqSnFSpIIwRSYoEJSikIoFADqSikNAC0UCg0 AFFAooAQ0lOpMUAJSg0lFADs0tMBpc0AOopuaUUASq2Rg1aikyNrfgao96lR89aBFtlxVaSPacjo asRvu+VutKy9j0NAyi3SkWpJU2n2pq9KAENJilooANtJtNOBooAbg0ZOadRQAUUUUxEVKOaVcU/F SUNIAB4qMVPimOncUANWlbpSqMCkekAyiiiqEFLSUtIYo6UL1FFOTrmgB1LRQKQxknamU6T71Npi ExRzRRTEFFFGKACijmjPrQAUUvHrRigYlFFFABS0lLSGFGM0U4dKBABiloooAKWkpRQAU0inE0lA DcUU6jFADaKXFGKACiiikMKKKKAClpKKAFozRRQAuaKSincB1GabmloEOBpwao6XNMCZZCO/Hoad lW7YPtUGaXNAE+w/w80mSp54qINipBKe+GHvSAfuB60oPHWmfI3fbSlWHPUeooARokbtg+1RtA4+ 6Q1SBqcDRYCocrwwxSVdzkYPIqNoUbplTRYCtRUrQOOnzVGRg4PBoGNopaKBCUlOpMUANpc0YpKA HClptLQAtFFFABSg4pKWgB4NPBzUNKGpgTglTxTWiD8p8renY00NTwaBEBBU4YYNJVo7XGGGff0q B4mTn7y+tIYyiiigAooooAKKKKACiiimAlJTqSkAlKKSloAsR05uGFRx1K/Y0xFVxiRqbipZAA5z Tc+gpDGYPpS7T3p2aSgBOKTNOxSYoATNJS4pKACiiigAooooAKXNJRQAuacGI6GmUUATiZh708Tj vxVXNGaYF4OD0petUM4q5ACIstyT0HtQIec5AHfpT3IAxSjgZqvI3IHQmgBMF23du1JKh2dM1KMY wO1FAFeIZzzjikYZiBPDZqZo93Q4IphjbuQaAIDTgxAwDTimOxppGMH35oAC7Y56UsRyTTpihHyc jt7U2Lg0AW06UxhwfpTk6UhoArqcinVGVKH2pwOaBkqtjg9KfUIp6tgYPSgQ+ilpKACiiigApKWi gBKWjFBOKADp1pOpox60E44FMBMjH+NNJxQTSAbjQA9OVp1AAAwKKACiiikAVGxyae5wMd6joAKa x7Cgn0oAxyetAC42rjvS44pKUcUAHbFFFFAxcUlFFAgxTHXCE1J3pJP9S1AFaiiigBKVetJT1HFA DlYqcqcVMJVb74wfUdKgpQCaVxltCF+VefQ0h2yDnr61Am5DkNin7gQB0NO4rCtGy8jkUivUgYgc 96cyI454PamAwEGnZqNkZOeo9aFekBJ+tLu/vDdj86bnNLQA/CMOPzFByvJ5X1pn4496cr4zmgBw 55BpTzTcZGU4J5waASeCNpoAcKdTfrS0ALRRRQBBNbLIdw+VvX1qm6NG2HGPf1rRZwDjvRt3rhwC KAMyirEtqV5j5Hp6VB1oAbRTsU3FAC5pQabRQA+im5ozQA6kozRmgApaSigBc0u402igB4eniT3q GigCwJKcJKrUu40AWgwpwPoaqbqcH96ALJ56gH60wwxMeVx9DTBIacJRQAw2o/hf86ja3kX+HP0N WQ4NKD6UAUSCOoxSVoZz15pjRRt1TH0oApUA4ORVlrZcZVj+IqIxMPegCxE+QCKs/eFZ0ZMbYYYB q7E3agBJEEiFD17VnkEEg9RWow7iql1H/wAtB+NMCtRRSUgHA09HKHK/lUdAoAvpMHX37ing+nSs 8Eg5HBq1FPuABHP86AHMhDeZFw3cdmqWKVZVyOCOo9Kac5BBwPQ0wxktvjbEg9RwaALFLUUUokyC NrDqp7VLQAU1lz0606igCCSMSDB4bsapspVip4IrRZc/WoZIxKMHhh0NAynSU5gVYqRgim0CCiij NABRRRQAUtJRQAUUUUAJSU6kIoAbS0lFAC04U0U4UALQDg5FJRQBMjZ+tWo3Drg9az1OGqwrcg96 ALDrkEGqzJsOO1WlYOvvTHUMCDQBVopSpU4NJTASlpKWkAmKWiimIKKKKBkVSqcioqUNgYqRkmcU wkmjNFAC0jdadTD1oAbRS0UxCCloopDFp6dKZT1+7SGOpRSUdBQIiY5Y0lFFMAooopiCiiigApKW igBMUdKWigAo4oooASloxS4oGJSg8UhpAeaBD6WkHSlpDClzikpCaADOWpab/FTqAClpKWgAoooo AMUmKWigYlFLRikAlFGKKACiiigAooooAKKKKACjNFFAC0tNozTuKw7NLmm0UwHg05Xx0OKjozQB P5mfvDNOAB+63Poar5pQaAJiGXqKA1MWQjoaduB7UAPBpThhhhmo+OxooAGgQ/dJU1E0Lr23D1FT BqcG/OkBT74oq6drD5gDURt1P3Wx9aAK+KTFSNE69RkeoplADaKXFJigBaWm0UAOopM0tAC0UlFA C5xTw1R0UwLAINODEGq6tUgagQ54Q/MfDenrUBBBwwwfSp8047ZBiQfQ+lAytSVJJE0fP3l9aZSA SiloxQAUUcetGRQAlGDS7qaTQAcCjPpTaUUATIamblBVeOrH8NMRBL94GmVJL0BqOkMKKKKQwooo pgFJS0UAJikxTqKBDMUU7FGKAG0UUYoAKKKKBBRRQaYD4Y/MlA7Dk1eXk9OlRwp5UWD1PJqUcKCR gmgBHbFU2bc5P5VJcSYGB1NV1PGKQ0SBiOhp4lI681DSii4ywsoPtTsg96rUo46UXCxYpCoPUVCJ GHeniYdxTFYa8Y7UyP73NTFlYcGox96gCdelBpF6UpFAhhwRjrUTJtOR0o3EMR70oagABzS0wjBy tKDmgZKjY69Kk+lQU9GwcHpQIfRS/wAqKAEpcjJGQSOuKM8UgGe2BQAE56UYxz1NIdw4AXGeTQWx 0oAGNRseKGakUFjkDNACsNqDP3m6ewpUjJ5PAqZ8MQcc0lACAYGBRS4ooAKCQoyfyoJCj39KhZ+c nk0ABOeTTSfSjlvYUoAFACdKWl4ooAAKO9FFAw70UCigQtJQKKAFpJP9S1LSSf6lqAK1FKATwBk1 Mlsx5c7RQBABUyRO/QcepqdY0T7oyfU04nNICAx7evNJmpi1MZc0WHcjzRmkPFNzQA9WK/T0qVZA 5wDg+hqvmkpgXQ5XOaGjV8Y4Pc1XSVl4PzD0qZGDEsp6DgUCGEMhwacGpSc800oMHB+YUwJFbmj3 qIMR1p4NIB2ccin71YbWFNGD14pCOMGgB/KjnketO561GCV6dPSnqwb7p59KAA5zlT+FJv3cDhvQ 07IPBGDQVDDBHFAAqAc9TTqYoKcZJFPzQAVFNbrJyPlb1qWigDOdGjOHGPQ+tNIrSZQwIYZBqpLb lOUyy+npQBXxSEUo5paAGYop1GKAG0UuKMUAJmlzSUUAOzRmm0UAOopuaXNAC0tNzS5oAWiikoAW jcaSigB2+nCT3qOkoAsiQ/WnCT1qnnFODmgC4HBpjjHIqAPTt+aAH7qWNsHFQ5pQ2OaQ2X1O4UjA cg9D1qKJ6nPIpiM2SJo2IxkdjTK0uRTGRG+8goAoUVbNvGehK1G1q4+6QaAIKUGlaN16qabQBchm DEK/WpgMMffpWdVmCfB2v+BoAmkjL4ZTtkHQ06GXzAQRtcdRQ3HAPNNeLfhlO2RejUAT0VHFLvyr Da69VqSgApjrnkdadRQBXkjEq+jDoaqEEHBGCK0WXuKhljEq5H3h0oGU6KUjBweCKSgQUUUUAFFF FABRRRQAUUUUAIRTafTTQAlOFNpaAHUUgNLQAi9alBxUS9akoAmR8EEVY4dciqSnFTxPg+1ADpE3 D3quRirjDPIqCVc/MOtAEFLRRTEFFFFABSUUUDI6KQ0UgFpy/eFNpy0APlGJGx0qI1LJ0U+oqKkM KKWjFACUU7bSYwaACpRwKjUZYVJSGFI/C0tMlPQUCGUUUUxBRRRTAKKKKACiiloASilooAKKKKAA UtJRSAaaSlNFMBwp1MpwOaQwzSE9qXgU3NACjlqdTU9afQAUUUUAFFFFABS0UUAFFFFAwpKWigBM UlOpMUgEopcUmKACiiigAopKKAFpKKSgBc0uabRmmIdmlzUeaXNAElFMzS5pgOzS5ptLQA8GnBqi zS5oAlzRUYNKGoAkBpwY9+ajDUuaAJQw7GkZVf7y5pmacDQAxrcH7jY9jULxOnVePUVazSgkUgKN JV5kR/vL+IqFrbujfgaAK9KDStG6feU02gB2aWm5ozQAtFFFABSg4pKWmBIrU/OahxilDUAThiOl NaINkpwfSkBpRQIgJIJBGCKTJqydsgw457GoZImj5PK+tIZHRRS0DEoNFBoEPRUx86k59DTvJRvu SY9mFIPuCimAvlvEcOOvQiph92oBx0qdORQIilHyGoqsMA3BOM1E8MkfUZHqKQyOlFJS0DCiiikA UUUUwCiim5oELmk5PSgDNOHFAABiilpKADFJilooAbipLaPzJMn7q00+nc1cjQRoEHXqaYh4GTk0 2RsZNPPAqpcP/CD160AQO25iaaKWkoAeKcKYpp9SUgooooGFJS02gQtKOtNzSg8imBZTpTm5bPSm J0p7daZJVf77fWkpZP8AWNSUhhRRQAWOFGTQMcDmlp6RBeX5PoO1NZSv0pkj0fBqTryDVcGnBqAJ envSZOc5ppb3ppagBzMaYWpyIXGe1Sqip0HPrQBEsRPL8CpQABgDFOwTRigBMUUblHemGZRwBQA/ HFNaQL0/Ooi7N1pMUABJNIABS0YoAKKMUvSgAx60UUUAFFH1pMmgBaKM57Yo5JwKACjNPER/iOKc Nqjgc+poAYFY9BxTvLXbtY5HtSls9abuoAeCFGFAA9qQmm5/CmFwKAH7qQn1NRGQ9qaSTQMkMgHS oy5NJSUgCig0UAFFFFAC1JAuWL9h0qInAq0q7ECHg9TQIX19D1o6HOaVeh7HtRxjpTAaf0Pam4I6 VJ/Ax9KYrbWG4/K3H0pgAbtTwc0kijeA3HvTcFSRnOKQEoxik9+9NDetOHNADg/Z/wA6dyo9RTSM dRmgblxjp6UASA0tMBDdOvpS5oAdRRmigBaSiloAgmtxJ8y/K/r61TZWRtrDBrTpjxrIu1hkUAZ1 FSSwtFz1T19KjoAKSlooASjFFLQA3FGKdSUANop2KTFACUUuKTFABmlzSUUALmlzTaKAHUlJmjNA BRRRQAopabS0ALRmiigCSJ+dpq7G2Rg1ndORVqJ8gGgCdhionYo3I4PSp/vCo3TepXv2oAjDqfan ZHY1U3lSQw5FKJB9KALYJ9aY6BudoqMSehpwkPegBhiXPcUwxHsQanYq3sajzikMdFIyfKw69DVk Efw81VDU+OTacHoaEwaJJU34ZDiRehp0MvmA5GHHUelNBLH5aR424kU4kHT39qYieimRSCQejDgg 9qfQAUx1xyPxp9FAFaaPzF3D7w/WqlaDDacjpUE8W4b169x60DK1FFFAgooooAKSlooASloooASg 9KKKAEpKdikIoASnU2igBy9afmoxTgaAHinKcGmClHWgC3E/Y0rDBqupqfO4ZoAruu1vam1O4yv0 qGmAlFLR1oENJpM1OsQxz1pfKWlcZW2e9HlkDrUlLSGQCnClYY/GgUADZOB6UgApc0cUAHHYUuKM gU0nNACk000UHpQA6MdTT6RBhadSAKic5apDwM1CeTTAKKKKAClpBS0xBRRRQAUUtFACUUtFACUU tJQAUUUUAIaSnEU2gBaKSjNAC0nU0daeq4oAUCloopDCilooASloooAKKKKACiiigAooooGFFFFA BRRRQITFJilooAbSU6kIoASkpSKSgAooooEFFFFAwooooAXNOzTKWgB+aXNR5pc0wH0Zpm6nZoAd S5ptGaBEgNLmo80oNAEgNLmowadmgY/dShqjzS0CJgTjg0xo436rz6imA04NQMia1PVGz7GomRk+ 8pFXAc07NICgDS1aaGNuowfUVE1s4+4Q1AEdGaawZDhgRRmgBc0UlFADg2KkVs1DSjii4FgGnKxH HUGoFb1qQGmIHgDDdFwf7tQHg4IwfSrQ65HFKyrKMOOfUUrDKlIakkiaPk8r/eqOgB68oKWiLlT7 UuKYCVLHUeKfHQIcR+8UHpmnszKSQePSmt96h2JoAawE2QRh+qkVWHIqx0INMcbZGHvSC5Hg0u2n U0sBTsFwwKQsB0pCSaTrQAEk0oHrSgYpaAEooooAKKKKACiigAsQo6mgZNbplt56DgVZUd6RFChU HQCnMcCgRHI4UEmqRJYknvUk77m2+nWo6ADFIRTqKAGDg1JTSMUoNIaFpM0Gm4pDFJptKaSmIWgH 5hRSD7woAtpT26imJTm6UxFeUYlNMqdo2kkO0YXHU1IkaR8gZb1NIZEkDNy/yj071MFCjCjApTTS QOtMQhpjGkeSoic0DsKSO1G6m0UgHZpMkd6SloGO3mlEjetMoouIk3knOacSWAy36VDS5NO4WJNo PXmlAFRhqcHoEPxRtH0pA1OBFACeW3bBoXY3G7mng4PWqYGcn3oAtGM9uaaQR1BFRxMwcYPA61O0 uzG7oe9AEdLg4zg1IGRx0BowcYVzj0NAEVKEdmOVwB3pwRg4LDgdxSlqAAIo65Jpd2BxwKaaQn1o AdmkyaYWwAT0PQ+tISc4oAcT6mkZsDNJikf7g+tACEk03FLmkzSGJRRRQAUlKaSgAooqRYXYZI2j 1NAEdKqljhRmrCxIvJyx/Kn5OMdB6CgCJYNrK0hHHO0VOzFznGKbRTEFFJzRmgCSPGSM5zUTqT8u Mc0FgMUjMWoAmVAz5J3ACpGUEYqCNsHNWaAKhUhsCkBxU8q9x1FMYBgDTAFbA9c9RTs1GyFRuHIp A1ICTbzkcGnK2eG600HIxmlI4wfzoAfSg1GCU+8cj1p45oAdRTd2Dg07rQAUUUtACVVmtud0X4rV qigDM9u47UVemgWXno3Y1SdWRtrjB/nQA2lpKWgAoopKACiiigAooooAKTFLRQAmKTFOpCaAEopR RQAlJTsUmKACjNFJQA7NGabS0AOp0bbW9jUdGaANCJu1SMO9U4XyMdxVtDuWgCtdx5/eD6GqtaZA 5B6HrWdKhjkKn8KAG0oYjvTaKAJBIe4pd6n2qKigCXPoaXNQ0uTSsO5ahlwwU9+9Wh7Vm7s9asQT kYUnpTETyRkMJY/vjqP7wp6OJFDL/wDqpmXJO3ofXtTWjMTeZEM/3l9aAJ6KQEMu5TkH0ooAKYRt IxT6CMjFAFOeLBLqOO/tUNXiMHB6VA1sOqN+BoGV6KlaFx2yPaoyCOoxQISiiigAooooASlpKWgA ooooAaaSnGkNABRSgcUlAD1NOFRg09TQA8VNGagp6HmgCaoGGGqY9BUUnWgBtSxpjk9aSNP4jUtA BS0UUhlWl7VCaMmgB7gnAFAUntTVJB4NTOVwMDgigCLAHU0Zx0FJRQAE5pKKWgBKXGaSnLQA+lpB ThSAZIcJj1qKnSnL49KbTAKKKKAAU6minUAFFFLQAlFLRQAlFLRQAlFLRQAlJinUYoAbSYp+KMUA R4pQpqTFFACBcUtLRQAlLRRQAUUUUAFFFFABRRRQMKKKKACiikoELSUUlAC0UlFABRRRQAUUUUwC kxS0UgG4pMU+jFADKKdikIoASilxSUAFFFFABRRRQAUuaSigB2aXdTKKAJAaWowaUGmA+lBpu6ly KAH5pc1HS5oEPzS5pmaKAJM0oJFR5pQaAJN9KHHpTM0UDJQ2R6/Wo2gjbttPtSUoYigRE1u68qQw qIgqcMMH3q2HpxIbqM0rDKVLVgwRt907TUbQOvTDD2oAjpVbFIeDg8GigCUN6U8H3qAZHSpFJx0p gTKxHHUHtUcluD80X/fJoDU4MQcigRDDwzKRg+lSEelS/LLgMMN2NBBQcnj1oAgxSx9alQLjJ59q hAxIRQBM/rUZPzGnt0pnVhz1HWgBD92m3BxKD/eGaeelMuOVjPtigCIsTSUUoFACAZpwoooAWikp aQwpKKKYgooooAKntkwDIep4FQqpdwg71dUdAOg4oAcvTJqGZ9qkmpWOBVKZ974HQUARjJ5PenUg paACiiikAGm06kIpgFKKbThSGIaSnGm0AJQOoo7471MICozJx7UASpTj92mJ2qQ9KYgU/J+NBOBz Td+0YqJnJoAe74qEsTSGkpDFooopDCkpaKACkpaSgAooooAWiiigAooooAMml3Z6jNJUkEYkyWzg dhTEMG0sMZz6UbCM4OathdowgAFIyKfvAUxFWNvKfdjOKldt4MgHy+nvTjEp6HFN2yR5GMqfSgBk q7Nkicbu1AmIPIzQ+Xx2A7GkRTv5oAlWUZ64+tSbgRyM1GoDuySDp3plpkswxnt7UATFFb7pIphi dTkEN9KjbdERhvvdqUTMO1AD32hQpYkDoCMYpi7TuBzz0x608XIx8wp58pl3YwPUUAQ84APUUkpw q+9TGH+62ajmjfC/KcCgCGilApwXmkMbil21MkDHr8o96kEcadcsaAKwjZzhRmpBbgcyN+AqUuSM dB7UlMQLtT7i49zQTnrzSGigBaKaTSbqAHHFNLDpmkOSOuKcSDEFC4xzQAmc9KTGetOBwKO9ACY4 opc05eDtOCDQA08EN69amjbPBpgGUZaYpKnB6igC0RkVEB1XuOalU5GaRhjkUARqdpPoaa6ZOVpz jHI6fyp4ORjvQBWBIPNSq2cZ6Ujrn61HyDTAm+nIpMbSCpx7U1Wwaf8AepAKDu+vpSg4NMp2d3Xg +tAEgOaKYOPanA5oAWlpKKACmuiupVhkU6igChNCYeeqevpUdadVJrYgl4+ndaAK9FFFACUUtFAC UUUUAFFFHsKAAn0pMUvSigAooooAKKKKAEpKdSUANpaKKACilooAFbawNXYn/KqWKlhbB2n8KAL5 5FV7iPzI8j7y9KlibIwaU8GgDMpKnuY9j7h91qgoAKKKKACiiigApwNNpaALlvNk7T1NT5JJ2kBf Ws0EggjqKuRSLIvPWgBT+4ben+qP3h6e9TgggEHINNA656elRA+QwH/LFuhP8JoAnooooAQjIqPo eRUtNYZ57igBmaCc9eaQgsOOvaoxIfrQA8xxt1XH0qM24P3Wx9aeJB3FODA0AVzbyDtn6VGVI6gi rv0oyfrQBRoq4Y0bqv5VGYFP3WI+tAFeipTA46YNMKsOoNADaQ0tIaAHAcU0inDpQRQAynKabSg4 oAlFKKYrU9eSKAJ34QUxV3HcelObnApydKAFpaKKQwooooAo9jTaWgUAKKliAkUoThv4ahFBoAUg gkEYI60UZJ5NJQAUopKUUAFOXpTe9PFADhSk4BNAHyE55B6UyY8BfWgCLrzRSUtAgooooGA606mi n0AFFFLQAlLRRQAUUUUAFFFFABRRRQAUUUUAFLRRQAUUUUAFFFFABRRRQAUUUUAFFJRQAtJRSUAL RSUUAFFFFABRRSUALRRRTAKKKKQBRRS0AJS0UUAFJS0lABikxS0UANxSU+kxQA2inYpKAEooooAK KKKACiiigBaXNNooAeDSg0yjNAEmaWo80oNMB+aXNM3UoNAD80uaZS5oEPzRTM0uaAH0U3NLmgB4 bFODcCo6KAJThuGGajMCH7vy0ZNO3+tAEZjdRwufcVGSe5q0GFB2t94A0AVN2KkBz0pz24b7rEfW oWiljOcZHqKBkvBqRXKja3IqukgPHQ+lSg0CJCo6p0qFv9bTxkcqcUkxBKMOvegB3WiIfKfrigdM 0sZ27x6mgBjjHFRyjMA9mqVu9MIzC49CDQBCBilpKWkAlFFFMYUUUUCFpKWikAlFLSY3MFHc0wLF su1C/dun0qwOBmmjqAOgpXNAEM8m1OOtVBT5W3OfQU0UAKKKKKACiiigAoopaAGkUA0tCIzthBn3 pAITT44Hk5+6vqasR26R8t8zfoKkJJ60DGxxpF90c+ppJeQKUkDqahlkyMUwFTrT6jj6CpKBEU3G 2oiakuOi1BQMXNOplOHSkAUtLijFAxKKXFGKAEpKdijFACUlLiikAlFLRQAUUUUAFAJHQ4oopgSL M496eJlPUEVBRRcRbBB+6RTgSPaqVPWR16GmFi516jNRtCrdCVNRrcY+8tSLKp6N+dAhrRydsH3p il4Mheh7GrGRS54oApYLEk9qa3WrjKrdF/EUxoAeh/CgCrinA4iZfXpUhgdTwM/SlW3cjDnap7da AHKcoD0PpT1L9uadhV6DOPWjNAAVDD5wDQML91QBSZ4pCQQB3oAXOaQ4PWkJpucUAP4pM88UzdTT z3oCw4tTS9Jg0lADWY06F1UFW7nINMNMNAF0DcOe1M6VXV2ToePSplkRxg/KaAJVCkYYYPrTKkfl V9qb2oAYp9R0p6vg8de1J3ox6c0ASOMJyceuKZJjII7CnMfkUA9OuaYeDQBJG3P1qeqgODx+FWI2 3CgBccFT0qIkjipiKQjPNADGGRmo2Gal6HFMYYNAEXSlVqkXCnkc0jxcbk6+nrQAoPFL0qENjj9K lDZGDQAoJBweR/Kne/b1puPSgEgcD8KAHhsdadUfB6fiKUEj6UAPooBB5ooAKKWigCvNbiT5l+Vv 51UIKsVYYI7Vp1HLEsq4bqOh9KAM+inSI0bbW/A+tNoAKKKRvSgBCfSlFAGKWgBKKKKACiiigAoo ooAKSlooAbSU40lABS0lLQAtAOKSloAsxvwDVn7wrPjba2O1XI27UAK6B1KnvWeVKsQeorTYd6q3 SZHmDr3pgVKKcabSAKKKKACiiigAp6sVbIplFAGjE6unB/OnMAQVf7p7VQjk2Nnt3q+pyob7xoEM jZo3ELnI/hb1qaonTzRgnBHKn0NLE5cFX4deo/rQMkpKKKAGsvO4fjUE6Z/eJ+IqzTCNp9jQMpBz ThJRNH5b8fdPSo6BE4k96cJKrUucUAWhIKcCDVQORThJQBao5quJPeniSgB5RG6qKja3Q9CRTxJ6 0oZTQBCYGHQg0xlYdVNWhz0NLyKAKJFJirpVW6qKYYEPTIoArCpFU43dhTvs7BuoIqdQANvakAg5 UGnCmIfLfa33TUu0g+ooASilJB60n40DCloooAz2GDikzStwxpvegQ4dKKWm0DHLSUClbrQAlKKS lFADhThTRTlGTigB54Qe9V2O5iamlODioTQAlFFFABRRSgUAIKfQBiloAKKKKACiiigAooooAKKK KACiiloASloooAKKKKACiiigAooooAKKSigAoopKAFpKKKACiiigApKWimAUUUUgCiiloASilooA SloooAKKKKACkpaSgApaSigAooooAKKKWgBKMUtFADcUmKfRQAykp+KQigBtFLiigBKKKWgBKWii gAooooAKWkooAcGNOBplLQMfRTQaM4ouKw/NLmmBgaXNMQ7NLmm5ozQA+lzTAaXNADqUMRTc0ZoA kDU7djpUWaUHFADmVH++oNROoQfLmpMg0GgCIHOPrRIS7eYeO2KcVB+tNYN1J4FAEin5KUYL4Ppm mp0pXONp/CgAfrTF+7IPUUuSRihOWI9jQBAOlFA6UtIBKKKKYBRRRQAtFFFABUlsMylv7oqKprf7 rH3oGWUqKdtsZ9akj+7Ve7P3FoEVwKdRRSAKKKKYBRRQeKAFoHJwBk+gqRIGblvlWrKKsYwgxQMh S34zKf8AgIqcYwAowPSkNMZwKBDiQKY0mKjaTmoSSaBj2l9KjJzSGkoAsRnKrUvf2qGL7gNTUCIb j7g+tQVYn+5+NQ0DEp46UypB0pAFKKSkJINAEmBSbRSjkZoxQAm2jbS0UAN20m00+igCPaaMH0qS igCLFFS0lAEdJTzTSRQMKKTcKTdQIdRTMmkosFx+RRkGmYpyqzHCgk+1AXJFJHRqkE5HUChbVurt t9hUyxon3Rk+poAEcsOhA96fxTS2e+aaTTEO3Y9qbupD60maAFyaM+lNJpM570AOZs9aQtRgUhWl cdhpakpStABpXGJijFSBD3p20CmIiANPVAR81OxRjvRYCN4V/hJqExntzVqmlPSmBUII6ikqyQRT SqnqMUrhYjSV06HI9DU6So/B+U1EYvQ00ow7U7isWz93GPoaUZLjuMVUSV4+h49DU6TI3B+U0AOz hdoPGabk9KdtI+nrQRnnvQAhGRTo2waQ9MCkPysPfrQBaByKKjibtUtAEIUqWHUDkUO4WMuw5HSp DmqV1JvfaD8q/wA6YCRTdVl6Hv6VaDYA5yuO1Z9PilaI8cr6UgLrqsgB6H1qE5RsNwe3vUqurgGM 5Hel4dcMMg9KYDVan9uKhZTF15X1pVakBL70ucnHf+dICGGBRQAo46U8HNRhsnB/OnUAPopoNOoA KKKKAGuiupVhkGqMsLQn1Tsa0KQgEYPQ0AZhOKQVPPbmPLJyncelQj2oAKKSloASloooASilooAS iiigAooooASkpaKAG0tFFAC0tJRQAtTxPkY7ioKVW2nNAGgpyKQjqD0NRRt0qc8jNAGfKnluV7dq jxV6ePfHkfeXpVLrQA2inYpMUAJRS0lABRRRQAVPbS7WCE8VBRQBpE8jA/CmurNiRRiRe3qPSore XPB+8P1qwOOnNAhUcSIGXof0pahbML+bj5G++PT3qagYUEAjBoooAiZNwKN+FU2BUkHqK0GGee4q GSMSjjhx096BlSig8Eg8EUZoEFFFFABS5xSUUAODEUvmY60yjuKAJgxpwkI70wUtAEgk9aduB4FQ gEnAqZV2igBaQmnYpcUDIW5HNLHKV+VuRUuB6U0xqetAhxUMMqaQccYqPYycqaUSnO1lyaBji2KN 9IGT+LrS5jpAUjyaAKcabQAtJS0UAIKc3QU3FO6rQA2nAUgFOoAUVJGOrelRinO21NvrQBGxyc00 0ufSjHrQA2lApwFFACAU6iigAooooAKKWkoAKKWigBKKWigAooooAKKKKACiiigAopKKAFpKKKAC iikoAWkoooAKKKKACiiimAUUtFIBKKKWgApKWigAooooAKKM0UAFFFFABRRRQAUUUUAFJS0UAJS0 UUAFFFFABRRRQAUUUUAFFFFABikxS0UANxSYp9JQA2ilxSYoAKKSigBRS0lLQAUUUUDCnD0ptFIA IxSbiKdnPWmlfSmJocrcc04MDUQ6UopgS0UwNTg1ADs0uabmigQ/NLmmZozQBJmlBqPNLmgB/FIe RikzS5oAE+XgjNOxuGMYFNp248e1ACGFl4Xke9NB2sNwK1LvPal3+vNAEDwjloiGHpUXfHeruR2F I8aSfeHPqKAKdJU7WzfwMGqFlKnDAikMKKKKYhKKWkoADU9v/qm+tVzU9oeHU/hQMnQ9Kgu/9Yn0 qZSAcYximXa5RW/unFAitS0UUAFFGCTgDJParCW4HMnJ9BQBDHG0n3Rx61ZjhSPn7zetP6+1IWx0 oGKfU00tjpUbvUTOT0oAe8lRFs0hNNJpAKTTSaM0lABRRQBkgUATw/cH1qaowecelSCmIjl5iNQV ZdSyFVGTVYgqcMMH3pDCnDpTaeOgoAKQ08EUuPagBiNg4NSU3avpThQAUlLRQAlFLSUAFJS0xjk4 oAN4oJPpTORRTEKfc00ilooAbiinqjOcKpNTLbDH7x8H0FAFWpkt5H5xtHqasr5cY+Rce9IXJ6mg BFto15Ylj+QqTcAvy8Co6M0AOLc8UmfWm5oLbRk0ALmjNRNKOwqMuzNjPFAE5cCoy5pKSlcdhd2e tGaSigB241Ih3Hk4qKkzQMuKq9acAPSqQYjocVIJ2HUZ+lAi1ikK8VEs6nvj61KGz7/SmIbtxSYx UlGKAIqMc1Jim7KAGYppT0qTBo+tAEBGKTmpyB0phT0pDIzg9RTTGp6cVIVxTcUAIvmR/dOR6VIs qsMONh/SmUfXmi4WJsd+3qKawzTFO37vFSBwev507isIhwfcVZVtwqsw43DnFSRvgj0oAmNUruPa wkHQ9avUxlDAq3Q0AZlJTnQxuUPam0AOR2jbchwatRyiXg/K/aqdFAGkrdm61E8RX5k6d1qOG46J L07GrAYqeenY0wIleplYEYNNePd86Y3enrUSt26EdqQE5GKTdt4bp60K+etOI49RQAtKDjrTM4+l OB49qAH0U0cUooAWiiigAqnPbYy8Q+q1cooAygc0tW7i33/On3vT1qln8xQA6ikzS0AFFFFABRRR QAlFLS4oAbSU6koAbRSkUlABS02loAWlpKWgCSJsHaauRtkVnirMb9DQBYPBqpPHsfI+6audRTHU OpU/hQBRNNNOIIJB6ikoAbSU40lACUUUUAFFFLQAoJByOtXYpN0Y/WqNPjfY2e3egC91BB70yImN vJY8H7h/pTkO9cg0OgkQr0I5B9DQIkoqOGTzY8n7y8GpKBhTGGORT6KAK88QlXeo+cdfeqdaByre 9V7iLI8xRj+8KBlfNGaKSgQ7NGabRQA+k70maB1oAlD0oOTgVF7Vbhi2DJ6mkA5E2j3p9FLQMSlo ooAKKKKACjABz3oooAQgHqKTavoKWigCjupOtNpRQAtFJnmlBoELmlFNpV60DFAxRTjQo70ACEUw nccmnSY4A602gBaKKWgAooooAKKKWgAopKKAFooooAKKKKACiiigAoopKAFopKKACiikoAWkoooA KKKWgBKXFGaKAEpaKKAEpaKKACiiigAooooAKKKKACiikoAWkoooAKKKKAFopKWgAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKTFLRQAmKTFOooAZS0pFA6UAJRS0UhiUUt IaAAUoNNooAdgHpTSMUtL1oAbRmgjFJTEBNKrGkAzTtoHWi4WHhs0tM3elJk+tFwsSUtRhsdacGF MB+aXNMooESA0oNRg04GgB9GabmlzQA4HFKGpuaKAJN2KXeMc81FmjNADmhjbsVPtUbW7j7p3D8q fTgT69KAKjAqcMCD70lXQ+RhhmmNBGw4+U+1ICmakt22Sj0PFOe2kXphh7VFjB54NMC4eCSPxpwA dSh6Go433jJ69xTgdvI7/pQBVKlGKt1FGCSAOp6VakRZ1GDhx0psMRRyWwTjjHakBJFEIhgcsepp 2cUGo5G2DkUwFZgKhZ6jL5puaBik5pCaQmm0gFJpKKXFACUUuKKAEpR1FJRTAsD71SjpUX8VSjpQ IbJny2x1xSLIWiXeA496ewypUdTxUMY2rtPUcUAOMMbfcbYfQ800xOg+ZePUU40AsnKnFAEOfepE bP1p5dX/ANYmf9petMMJ+9C28dx3FIY6kpqyAjmn0AFFFFABRRntTTnOAaYDqiPU07dzihY3c/Kv HrSEMoxk4HWpxAq/6xs+wqQMFGEAUUAQLbufvYUe9SrFEnYufegknrSUwHlyRgcD0FNzSUUAFFGa Q5oAM4pM0n40cfWgBGLfSoyDUuaTFAEWKRfvVIQKanekMWlopKQxaKKKACkNLRQA2ilpKYAaQEry DilpDQIkFw4681Ktyp65FVKSmI0VkDdCDT81mU9ZnXo3HvQBoUhFVluh/Ev4ipkmR+jfnQA4qMUm 007NLmgCMj1FMK+lT0m0c+9AFcrTcVZK8Uxo/SkMhxSVIRikxQA0EqeDTkbn9aTFJj0oAtxtkYNO IqvG3T2qwDkUxFe6i3puH3l/UVR61qkVA8MJPI2k+lAFGirLWh6o4PsaheJ0+8tADKlimKDaw3J6 elRUUAX0bjKHK0rKsoyPvDvVKORo2yv4j1q1HIG+ZePagBoJVtrDBFSo+KVgsq89e1QncjYb8D60 AWcccU3lckDjvTUfFS9RkUAJ2oJIHHJppBBytOBB6flQA4HIpaZjnI6inCgBaKKKACq9xbiQbl4f +dWKKAMkggkEYI6ijOKvzwCUZHDjoaoMpVirDBHagBQaWmUuaAHUUm6kLE0AOzSk0zNLmgAooooA KQ0tFADTRS0lACilpop4oABT0bB9qbRQBcibtTyKqxP29KtKdwoArXKZAkH41XrQI7HoetUZEMbl fypgNptOopANpKU0UAJRRRQAUoNJSjk4FAE0Emw47dqsSt8g55PpUKRhBz941IhwcEfShCECNH+9 UdOo9RVgEMAynIPSmg85PSmJ+5k2n/Vv932NAyaiikoAGGR71HnuRx3HrUtMcY5oGU5Y9jcfdPIN R4q6yB12HjP3aqEEEg9RQIZiinUYoAZT0GTSEVZt4sDc3foKQCww7fmPWpqKWgYlLRRQAUUUUAFK KSigAJpKKSgApKCaTdQBRpRSUtACUtJS0xBUgHFNQZOakpDDFDHApajY5OOwpAJ15paKWmAUUUUA FFFFABS0lLQAUUUUAFFFFABSUUUAFFFFABRSUUALSUUUAFFFFAC8UZ9qSloAKKKKAEpaKKACiiig AopaSgAooooAKKKKACiiigApKWigBKKWkoAKKWigBKWiigAooooAKKKKACiiigAooooAKSlooAKK KKYBRRRSAKKKKACiiigAooooAKKKKACiiimAUg6UtIKQBRS0UhhSUtFADcUU6koASiiigBc0bRnN JS0AITSZp2M01gR0oAM0UynUxC0lFFAC5I6Uok9aYaKYEwYHvS1XFPBYUCJs0uajDeopwNAx+aXd TM0ZoESZozTM0uaAHUufWmZpQaAH0oYimZpc0ASBx9KU4cYYA/Wos0uaAAwgHMZII7VGWwfm4NSh iDmnb1YYdaAIxz0NOBZec8UnlI33SVNIyMkecbmz+GKAHiQd1ps8ZlClCOO1M3D6UoNAFd1ZD86k U3NXRIR159jTfLhY5Zdp9jxSGU6KttaqeUfHsaruhjbawwaAG4paKWgBKSlpKAEooooAsD7w+lSi oV/h+lSr0piF6c1CpyTU/HOagjOSaYDjSYoNFIA4oj+WZWHGeD70UHAHPXtQAyVds0g9803mprgA TnPcCoyQKQxyjAFPpio55xj61NtUdTuNAEWCT8oyad5JP3ztqTcR04+lNzTEKAifdXJ9TQXJ70lJ QAZozRSF1XvmgBcZoOAeTUZlJ4HFNOepouBIrbicdqXimw/dY07OBQAc9qQ8daC1NLUALn2pCaaW ppNADt1IWptJQMUninJ92mHpUi/dFIBaSlpcUDG0U7FLiiwhlFOxSEUDEpKdSUgG4pKdmkyKYhhF JTzTKYgooooAKKKKAHLIy/dYipluWH3lBqvRQBdW4Q98fWpQQehzWbSgkdDigDSoqktw69cH61Ml 0p+8CKAJ8UwxjqDSrIrD5WBp1AEDDFNqwy5FQlOaQxqnBqxG3ODVcpTkJHBoQMtVG67hj05FPQ5F KwpiK6Ag5z3pQxJIPQU2fKDeBkdCKcCGiB79qAI3UEbiOtRGNT04qwRxjtTWTmgZXMTduaaN0bZH BqfGKTNILEkUocZHDjt61KSrrtcYqqVU9sH1FSq+4gMc9s07isIwMZGTlT0NSI+KUc/JjK9xUbL5 ZyDlPX0pgWeGGRTWU5yODUaPipwQwpANBz9fSlBpGXnI60D360AOBpaQUtABRRRQAVDPAJl9GHQ1 NRQBlMpVirDDCm1pTwiZfRh0NZ7KVYqwwRQA2ilpKAEopaKAFzRmm0UAPopoNLQAUlLRQAlOFNpQ aAHUUlFACg7Tmrcb1TqWJsHBoAunkZqGdN6ZH3l6U+NsjFOPBoAzqKlnj2Pkfdao6AG0lOpDQA2i lo68CgAAycDrVmOPy+Ty38qSKMIMn738qfQAvWkI49xSSKzw5TqDyBRGWKfOOaAJkbcvvQyh0KN3 /SogdrZ7HrUw6ZApiEicsCrffXg+9SVDJlSJV+8vX3FSghgGHQ0hi0n1paSgCMjt37VFOu4eYOv8 Qqw43DjqKj6Hdj5TwaAKdFPlTy3x27U6GLecn7ooAWGLd8zdOwqzR2paQBRRRQMKWkpaAEopaKAE oNFIaAEzSE0uaYaAA0UlJQBVoAzShSaeBigCOlHuKcRzSYoEPUjHFOFRYpwYigYrHApgFLyTk0tA BRRRQAUUUUAFLRRQAUUUlAC0UlFABRRSUALRRRQAlFFLQAlFLRQAlFLRQAUUUUAFFFFABRRRQAUU UUAFFFFABS0lLQAlFFFABRS0lABRRRQAUlLRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUlFAC 0lFLQAlFLRQAUUUUAFFFFABRRRTAKKKKACikpaACiiigApBS0lIBaKKKBhRRRSAKKKKAEooooAKM UUUALRRS0AMKim49KkYU0CgBtGKcaQ0xCYo204dKXFA7CAUuKWikAlLSUUAOzS5plLTCw+ioyaUH 1ouKxJmim5FLTAdSg03NLmgQ7NFNpc0ALS03NLQAtOVio4NMpc0APOx+GGD6im+QOqNj2pKUHFAD SGUcjNIGXPXBqUORRhWYEgZBzQA2MHzcnnA6e9RiVmGJVDD09KmaMs29Ww1Hlbx+8Az6qcUAQmEM QyHCn26VE6NGcMMe9XEJXgoVUdO9BKuuG+YUrDKNFTyxRgssZIYckGq9ACUUUUATxY3IT0xUqdKg T7q1OnSmIcKqxHDke9Wqr4w7eoNADu9B60q8j19qeIz34HvQBH6Gl2lwQozxUgCr2z9aC/GO1ACS Rh3VmbouCBQFRfuj8aTNFAC5yeaM0lHTrQAZpBSbhSbs5ANADiQOpphk9BTDmkoAUsT1NJRSZpCF pc8UzNJmgCdGxHj1pC1MzwKKChSaTNJS4oASinbfWk4HegBMUuKN3oKDnFAriN1AqUCol5YVNQAd KKWimAlFFFABRRScUAKQDTSBRmjdQA0rTSKeTmm0DGmm089KZQIKKKKACiiigAooooAKKKKAClpK WgAp6yuvRvzplFAFlbr+8v5Uvmqeh/OqtLQBaDilOCODVUGlDkUhlyJualDbiRjpxVOJ8tjvVqNu MUxCsOtRqpH9KmIzTehx2oAjxRUmKQigCJlzUZXFWNvvTSuaAIMUlSFaaRSGCtg8n8anyNvrnqKr 4pVYrwen8qdxWHMuzlfu/wAqcjEdKd1Xjn1qJl2cj7p7elMC0rBhQRVdHI5FWFYMKQCA8470+msM 0DjrQA6iiigAooooAKinhEq+jDoalooAyiCrFWGGFJWhPCJV9GHQ1QIIJVhgjrQA2ilpKACkpaBQ AUUtJQAtFIDTqAG0UtJQAopabSigBaWkpaALET5ANWB8y1Rjba3satxtzQAOm9Cp/CqWCCQeorQY Yqvcp/y0A+tMCvSUtJSATFTxxhBk/e/lSpHs5P3v5U6gAooooABwcjg0daKKAEfIicjtTreQOmCe RQp2tkU3ADblABoAsD9Kjj/dSbP4G5X2NODblzSMu9CvfsfQ0wJKKZG+9OfvLwafSAOlMdcHPY0+ gjIxQBAyCTCngipQABgdqY3ByOoqQcqD60AFFFFIYUv1pKWgAooooAKSikoAKaaU00mgBCc0hNBN NJoAM0ZpKSgBtGaaM+tLSADzRRRTAKMUUtACUUtFACUUtFABRRSUALSUUUAFFFFABRRRQAUUUUAF FFFABRRS0AJRS0UAJS0UUAFFFFACUUtFACUUUtACUUtFACUuKKKAExRS0lABRRRQAUUUtACUUtFA CUUtFABRRRQAUlFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRTAKKKWkAlFFFABRRiigAooo oAKKKKACiiloASk706kIoAKKKKQwFFA60UAFFFFACUUtJQAUUUUAFKKSigBxPFA5FIaUUxDWHNJt NOPWnJ0oAaBxRUmKQrSGMopcUlABRRSE0ALRTSaSgBxIppNFJTELk0oJHekooAeH9acGBqKigCal zUIYinB/WmBLRmmAg9DS0CHg0uaZmlBoAfxg0Cm5paAFzS02lzQA4Hil3nFM+lGaAJQ2R6H0oKq2 CRyDnIqPNGaAEeBixdXyT6ioJoyjn5Tt9atb6cG460AZ1FXnhifOVwfUVC9ow+4wb2pDGR/cH1qZ KiRWUFWGDmpI+9MRL7d+1M8lQ2XYknqBSsdozTC3NAEm4AYUYFNJJ603NFAC0lHA6mk3DsKAF5NB IHU0hJMRJ65pnQc0AOZz24qMknrRnJoJoASijNIWoAXoKTNJmkpALmkoooAKKXFGKAAHjmlyKMdq dtwOlAXG5PYUvzGl6d6QkUCDb6mjABxik3HtxR1oAd09KTI+tIBShTTAF+8Kl6U0KBS5zQMWjNJQ TjpQAv6UmQOlNzSGgBSaM0lFABmikooAKKKKAGt0ptOPWkoASiiigAooooAKKKKACiiigApaSloA SiiigAopaSgBc0tNpaAFyQQR1FW43yAwqnUkL7W2noaANEHIpGFMjbtUtAERYAgE4z0p1NljEiFD +B9KorJJGSu4gjtQBoZpKqrdN/EoNSrcRt32/WgCRhkVEyFelTA56YP0o68UAVs0lTPH3FRFakoE baeehqXI7c1DilVip9qaYmhWGw5HTuPSno2DkUDBOe1NZcfMvTuKYiyrBh70pGarI3QirCsGFAC9 KWikoAWiiigAooooAKguIBKuRw46Gp6KAMnuQeCOooq9cweYNy/fH61RoASilpKAA0lLSUAFGaKK AFzRSUUALQKSloAcKWmg0tAC1NG2RjvUNKp2kGgC+h3LikIByD0PWo42wc1Kw70AUJF8tip/Cpkj 2DLfeP6VLIgcA45FMHNACUlONJ17UAFFJRQAtFIaUUAFFFFACodj47GpSKgPIxUsTcYPUUCEf5HE o6dGqX37Uh7g85pkRKMYj9VoGSUUUDk0ANcdxTQcPjpSSSrnA7UjcgEde1AEtFIjblzS0hhRRRQA UUUlAC0lFIaACmGnZxTDQA2mk0pNMJyaADrRzS4oxQA2iiigAoopaACiiigAooooAKKSigAooooA KKKKACiiigAooooAKKKKAFpKWigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKSgAoopaA EopaSgBaKSigBaKSigBaSiigAooooAKKKKACiiigAooooAKKKKACiiigAoopaAEoopaAEooooAKW kpaACkpaKAEoopaAEopaKACiiigAooooAKKKKAEA4opRQaBid6KO9FIA7UUGigApKWigBKKWkoAK KKKAA9Kf1plPHQUxCEcU5eBQadQAUUUtADGppPpT3+7UdACEU2n0mKQxtFOxSYpgJRRRQIKKKKAC iiigApKWigApQ5FNooAkDjvTwfSoKAcUwJ6cDioQ5HWnBwaBEoal4qOloAfyKM03NGaAHijNNzS0 ALS9KbS0AOBpwbt3qPNFAEj5dcDqKhj6GnA801eCfrQA8gFDn61Fgdziph6Uxo92W/CgBhdR0+Y0 qOSpyOPSmlOemKF4yOtACHGcjignjNBzTSSKAJI+Y5PbmonJ/CpLfpKPVajGcCgaG7qTNOKg0m00 gsJmkpdp9KXafSmIQUYpwU04KaAGD3pwFLspQg+tIBuKKftP0pCvvQFhlHNOIxTgB6UwI8GlCGpK M0ANCUoAFGaTNAC0ZpKSgBc0ZpKKACiiigAooooAKSlpKACiiigAooooAMUhWnUUAMxSVJSEUAMo pxWm4xQAlFLRQAlFFGKACiilxQAlFLSUALSUUUAFLRRQAhooNFAFqGTKj1HWranIrMRtjA/nV6N8 Y9DQBMwqpdxZHmjqOtW+oppA5B6HrQBmUU+WMxSFe3UUygADFT8pI+lTLcyDrhvrUFFAFxbpD94E U4lWGVYGqNLQBazRVYO3rThIe9KxVyccU8Zxx3qESCnrJtORQhMGUrkr07inI/IIp45AK1Gy8llH 1FMRZVgw96dVVH7irCsGHvQA6ikozQAtFFFABRRRQAVVuLfcd8Y+buPWrVJQBmtG6/eUimVpNleR 071GRFJnK8+tAFCirZtVP3WI9jUTW0i9s/SgCGkpxBU4IxQelADaKWkoAKKKKAClBpKKAH5pajpc 0ATxNzj8qtRNkYNVkj2jLdTUiNg+9AEx4NRuNrA9jUv3lppG5Sv5UARUlL7HrQRQAlJRRQAUUlKK AClpKBQAtN3bWB/OgnIIzjNNWNADmT5u3FAFvgrnPFQzSLgFT8y8g0xVIXDHml2AUwJ1dWQOOhqK WbIwnSmhMcZOPSgjikAkaA4J6VL06VGhp5ORx19aAFB2N9etSds9qrlT3p6BjwelICbFFFJQMKTN FIaADNITQTTc0wAmmk0E1GxpAITk0AUAU6gAooooEMooooGLSUUUAFFFFABSUUUAFFFLQAlFLRQA lLRRQAUUUUAFFFFAC0UlFAC0UlLQAlFFLQAUUUUAFFFFABRRRQAUUUUAFFJS0AJS0UUAFFFJQAtJ RRQAUUUUAFFFFABRRRQAUUUUAFFGaKACilpKACiiigApaSigAooooAKKKXFACUtFFABRRRTASilp KQBS0UUAFFFFABRS0UAJRS0lABRRRQAUUUUAFFFLQAgoNFFAxMUUtJSASlpKWmAUUUUgCkpaSgAo oooAKen3aZT0+7TEKaAeaWgUALRRRQAjcio6kPQ1HSASlpKUUDCkpaKAExSYp1FADMUU7FGKAG0U uKSmIKKSloASiiigAooooAKKKKAFBI6U4SetMooAmDA96dVelDEUwJ80uaiEnrTwQaBDwaXNMozQ A+lpgNLmgBaMDOaTNOFAChiOmBTu2OtMozTAf9R9KaVQ5z1NGaARSATyj0U5qNk9RipsUc0ARwL+ 9x1BWkeEpjHIqTHNPUqP4cZoAqYzTggqdokc5VsGmmJ17Z+lKw7kew+tGw+tPzRQAzafWgqQOTxT 6bJ9w0AIFFL0oHQUcDmgBDxTSwFNZifpSdB70AIWzTx0qM9M1L2FMQUlFFABRRRQAUUUUAJRS0lA BRRRQMKKSloEFJRRQAUUUooASlFFApDCilpKACiiigAooooATFJtp1FADMUlSUhFADKWgjFFMQUl LSUAJRS0lAC0UUUgEopcUlMAqe3fB2n8KgoBwcjrQBpo3AzTzVaGTcoIqyDkUAQXEfmR8feXkVRr UPHNUrqPY+8fdb+dAFeilpKACiiigAooooAKUEjpSUUASJKUbJ5HcVbU5+ZfunvVCpIZTEfVT1FA Fp1ABZB15oR+4NOBBwyHimunHmR9O4oAnVtwpSPSq6P0IqdWDCgAB7GnU1hmgHsetADqSjNFAC0l FFABUDJ5bEjoanpCMjFAEPbNJudVHck04qVOPypKAHFgeoBqNoYXPTB9qdikx82aAImtD/C2R71E 8Lp1U1byRShz9aAM+krQYRucMBmmG1Rh8pxQBSoqw1rIBkYNQMpX7wIoASrMUYX5m6/ypIowvzN1 /lUtACUwuFfHenHIHy9aJYo3O9HIPcEUATRt2NPbjmqynBx6VYU7lxQAyQfxj8aZU3T6VCw2tigB DSU4jjI6U2gBKKWkoAKBRQOtAAeBSxp/Ew57U4Lk5PSpKAG4oC04DNOxQAzbRtzT6MUAReXTwtPo pDExS0Ud6AEpKWkNABTSaCaQ0ABppPFBNMY0wEZqYKOtKKQCiloopiFopKKAGUUUlIYtJRRQAUUU UAFFLRQAUUUUAFFFFABS0UUAJS0UUAJS0UUAFJRS0AJS0UUAJS0lLQAUUUUAFFFFABRRSUALRSUt ABRRSUALSUUUAFFFLQAUlLRQAUlLRigBKKKKACiiigAooooAKKKKAAUUUUAFFLSUAFFLRQAlFLRQ AUUUUAFGKKKACikpaACiiigApaKKACiiigAooooAKKKKACiiigAooooAKKKKAE70Gg0GgYUUClpA Jikp1BFADaKMUUAFFFFACUUUUAFPTpTO1PT7tMB1AooFAhaKKKADtUVS1GetADaWiikMKKKKACii igA70UUUAFJilooAaRSYp1GOKAG0lOxSEUxCUUUUAFFFFABRRRQAUUUUAApwNJRQA8MadvFRUZoA mBBpc1XzThIaYE+aM1GHBp+aBDwaXg1HmlzQA/FFNBpwagAzS5o4NJj0oAdmim80uaAFoBK9DSZp aAHFw33lzTdin7jY9jRSYoARkde2R6imMco1SgsvQ0pYN99QaQECn5RQx4xT/JH/ACzfHsajdJV+ 8v4igZGaG60Fs0dcUAI54wKk/gU1FjJwKkHCgUxBRRSUALRSUUALRRSUAFFFFABRRRQMKSlpKBBR RS0DCiiigBKdSUtABRRRSAKSlooASilooASilooASilpKAEPSm049KSgBKSlopiEooooAKWkooAW koooADSU6koAfC/lv/snrV1WwQc8Hg1n1ZgckYPUUAXOopjoJEKHoacrAilIoAy2UqxVuopKuXce 5A46r1+lU6AEooooAKKKKACiiigAooooAkilMTZ6r3FXc8CRTkHtWdU0EvlNg/cP6UAWJEAy6dDy RQj8ginEkMW7Ux02jen3e49KYFhWDDNIw71Cj4II6d6sKQwyKQDQ2eO9LSMMcigHIoAdRSCloAKK KKAEYbhimY5qSkIoAjxSVJikxQAzHGaTFP20hFADMc5ppYRrz3p7/KhbHSquSW3E5pgTq8nLE8D+ Gpd4PUVUjbEwJ6d6tSBMZB60gE2xt0PNBjPY0z5Q33hxS5wM5wKAEKkdRSVIrnPOD7ijch6igCE1 LG1BjU9DTRGynjkUATnpmmONy5HUUqE9DSn5eaAIQw2kGo2kkhmweh7etOfG4gdKcXLDDYNMBGOT nHWmk4GTS0q7QTvGVIpAMDBuhp8aZ5PSkjhUPkMSKsCgBMUYpcUtACUUtFABRRRSGFLRSUAJRQel J2oAKSikNMBDSE0U0mgBGNRk5NDHJoApAAFLS0UCCiiimAUUtFICKilooGJS0UUAFFFFABRRRQAU UtFABRSUtABRSUUALRRSUALRSUUALSUtJQAtFJS0AFFFJQAtFJRQAtFFFABRRRQAUUUUAFJS0lAC 0UUUAFFFFABRRRQAUlLRQAUlLRQAUlFFABRS0lABRRS0AJRS0UAFFFFABRRRQAUUUUAFFFJQAtFF FABRRRQAtFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAhoPSlo7UAIKWigUDDvQaKWkAl IRinUdKAGUU4im0AFFFFACGpF6VGelSL0piFoFFAoAWiiigAqNupqSmP1oAZS0UUhhRRRQAUUUUA FFFFABRRRQAUUUUAJQaKKAExSYp1FMQyin4zRtoAZS0pGKSgAoo60tACUUUUAJRRRQAYopaSgBaA SKSigCQSHvTgwPeoaKYFijNQhiKeH9aAJA1LupgIPSloESZo61HmnZpgO57GjNJmlzSAXNLmm49K KAHYowaTNLmgA4oBYdDR1ooAGCP99AfcVH9mH/LN/wADUlFAFd0aPqhHvTF5bNXQ5HekKxv95ce4 oArd6MVM1uesbZHoajYFPvAigBmKMU4EHoaOPWgBuKTFP49aMUAMxRin4pMUANop2KTA9aAEopeP WjK+tACUUbhRu9BQAUtNyaMmhAAp1IBS0AFFFFIYUUUUAFFFFABRRRQAUUUlACNSUrU2gAooopiC iigUAIaKU0hoAKKSloAKKKKACnK21gw7U2loAuxtyMfdNTjkVQib+E/hVyNsigBx4PtWfNH5UmP4 TyK0TUU0fmxle45FAGfSU769aSgBKKKKACiiigAooooAKKKKAJ7ebYdjfdPf0q1/qzx9w1nVatZh ny36dqBD5E2Hcv3O/tSxvt4FPBwSG6GopE8s99h6e1MZaBBFRkYJI4pkb4xUxwwpAICCOKUGmH5W yKXORQA+img0tAC0UlFACHijNLVWZpIGGDmM9M9qALNJioFuVP3lx9KlWRG+6wNADv5VC0CliynH tUhHfml47UAVHjZTjFMIIPIq8TgYIzTCqntigCtH96pGLJKAfrStAcgowoO8feU8UANlcpLuXjdy RSI+5wG6Uj5Y5NMxigCzIyxjOevakWTJPP0qv2pMZIFMC35nPIpxKuNpNV8Be5olDR7STlW6GgCX yvQ/nTSrDqKSISMm5OnpSiVhk45FACU5V3n29aSNjK3TI71OAAMCkAYwOKWiigAoopaAE6UUtFAC UtFFIYhpKWkoAKQ0UhNMBCaaaU5ppNACE1GxpWbFNFIAAp1AooATvS0UUxBRRRQMWiiikBHRRRQA UUtFACUtFJQAtFFFACUtJRQAtJRRQAUUUUAFFFFABRS0UAJRS0lABRRRQAtFFFACUtFJQAtFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUlLSUALRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RS0UAJRS0UAJRS0UAJS0UUAFFFLQAlFLRQAUUUUAFFJS0AJRS0UAJRS0UAJRS0UAJRRRQAUUUUAF Ao6igdaBgaUdKQ0dKQB3paTvS0wDFIeRS5FJ60gG0U49AKbigBDUi9BUZqRelMQtAooFADqKSloA SmPT6a/QUAMooopDCiiigAooooAKO1FHagAooooAKKKKACiigCmISnAc0oGKBQAAUdzTqb3NAARm omGDUtMb71A0IBRinngikOKBDKDSn2pMUAFJS0lABRRRQAUUtJQAUUUUALS02nUAFKGIpKSgCQOO 9OBqKjNFwJs0uaiDGnBxTAkBpd1MzS5oEPzS0zNLTAdRmm5pc0AOzRSUUgFopM0uaAF6dOKcH9aZ RQArQxSDpg+oqJrVh9xgfY1JS7yKAKkismNy4po6VoBgR7e9RtBE3IG0+1AynRU7Wzj7pDfpULAq cMCD70gEoHWilHWmAuB6U2nU00CEpyikp4oAKKKKQwooooAKKKKACiiigAooooAKKKKACiiigBrU 2lakpiEpaSloAKUUlKKAENIadSGkA2iigdaYDsUYpRS0ANopcUmKAFqxFJwD+BqvSo21ueh60AaK nIoPXNRRtgAVN1FAFO6j2t5g6Hg1XrRZQVKnoeDVB0MblD2oAZSU40lACUUUUAFFFFABRRRQAUUU UAXLeQSqUf7386m9Ufpj86zgSpDDgir0cnnLuHUdfagQxlMbY7HoakjfHHal4kUqRUPKNtbrTGWi ARmm02N+1SMO4pANNOHNNHoaTJBzQA+iiigAprqHUq3Q06jpQBmuhjco3UU2r88XnR5X7w5FUKYD 1ldejVKt0f4lB+lVqKQF1Z4274+tSAA9Dms6lVipyDigDQGBTs1SW5cdcMPepVuUbhgV96AJioPU UxogelL5sQI+b60okjbo9AELQEVGUK8+lXMp2cUm1T0INAFdgHVWU4I60kpHlBe/Wpvs49Me2aQw YzkHNAEcM/lJtK5x3zTAGnlOOM9aVoiTjBUn1FWkQRrtUUAKqhFCjpS0UUAFFLRQAlLRRQAUUUUg Ckpc02mMKSlpCaAENNP1pTTTQAE1GxxSsajJyaADqaUUAUtIAoopaYCUUGigApaSigQUUUUhjaKK KAEpaKKACkpaKACiiigApKWigBKKWigAooooAKKKKACiiigAoxRRQAUUlFAC0lLRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUtFACUlLiigAooooAKKKWgBKKKKACiiigAooooAKKWigBKWiigAoo ooAKKKKACiiloASiiigApaSloAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACkpaKAEooooAB QRSUtIYZ9aD0oIo7UAAHFAPrSimnrQAo5JNL2oHSigBDSdTTu1J3oGIVz0pwGKB1paZIUDrRQOtA C0UUUAFI/SlpG+6aAI6KKKQwooooAKKKKACiigA0AFFO20uMUxDKXFK3SloAZ0PtTsijpTWAHSgY uS3HalHShelHSgBaQUgO6loEFMb71PqOgaHtyKQLmgE+lOHvQAmAKMUtJQIaRTSKd3oIzQMZS07H NJigQlJSmkoAKKWkoAKdTadQAUYo7UZpDEop1N70wFooxRQAAkU4P60yloEShgaXNQ0oYincLE2a XNRB/WnBgaBEmaXPrTM0ZpgSYpWbcAMdKjBpc0AOXrz0pc00Gl/HNAC0UlKM5xSAMClBIpM0UASB h9KXqOeRUVLnFACPbxtyAVPtURtnU/KQw/KrAfNOFAFE5X7wI+tFXjyMHkVE1uh+7lTQBV20VM0D r0+b6VEeDg8H3oGJS0UUgCiiigAooooAKKKKACiiigAooooAKKKKAGtTaeRmmEYpiEopcUlAC0tN paAFpDSg0hoASkpaKAFFLSUtIBaKKKYCYpKdRQBLA+cL3HSraNWdyDkdRVuN8gEd6AJyKguY98e4 feX9RVgHIppGDkUAZvUUhqxPGFfIHyt0qErQAyilNJQAUUUUAFFFFABRRRQAU6NzG4YfiPWm0UAX wRIodDzTmCyoOx7e1UoJTE/+yetXmOAGHOetMRApKsQeCKsRtkUyRN4z3HT3qNGxQBYYY5pM9vyo Rt3BoIxSGCnBwelKeAeM4ppAcYNOGcc9RQA0MMjnhuhpJCcbQM5obCnB+636GkTLSBj2oAkQbVA9 Kq3cOD5q9P4qt0nUYI4PWgDLoqSeIxSY/hPQ1HQAUUUlAC0UlFAC0UlFAC0UUUAO3t/eNPSWXcFR iTUQBJwOSavwQiJc/wAR60XAeu4KAzbj3OKWjFFABS0UUAFFFFABS0lLQAU00ppKBiGiikoACcU0 mlzTT0oACaYTQTTGPagBGOeKAKQCnUgCilpKYC0lLRQIQ0UUUAFFFFAwooopANooooAKKKKACiii gAooooAKSlooAKKKKACiiigAooooAKKKKADNJS0YoASloxS0AJRSmkoAKKKKAClopKAFpKKKACii igAooooAKKKKACiiigAopaSgAooooAKKKKACiiloASilpKAFooooAWkpaSgBaSiigAooooAKKWig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAEopaQ0AJSikoFIY6g 0UmeKAFHSmt1FKOlI3UUAOooooATtRQaSgY8dTS00dadTEJR3oopCFooopgFB6GiigCKiiikMKKK BzQAUoGaRe1OH3mpgG0YpV6Up6Ui/dFAhaDRQelADTzS0DpRQAhHFNftTs5OKa/3hQNDh0obpRTW 6UAC9KdTRnHSlx60CYhJPApQvrS0UBcKKKTPpQAUUY9aQmgBM0tJSjigYA9qKPpRjFAhMZo206lo AjxTalNMxmgBKWjFOxQA09KbT2HFM70AOpDTqSgYHpS9qQ9KKQBiilooAbRRS0xBSGikbpQA4ORT xJ61FRTAsBs9KXNVgaeHIoET5oBqMOD7U4GgB+6nA81HRmmBLjikpoNLmgB2aUGmUtADvpRnFNzS 5pAPDetLkYqPiloAkoOGGGGRTA3rThzQBG1uh+6StRNDIvbcParVGaAKJ64PB96KukBuGANRNbr/ AAsR7HmkO5Xop7RSL/DkeoplACUUUUAFGaKKADNLSUUALRSUUwFpKWikA3FNxT6KBDMYpKeRTcUw EpaMUUAJSikp1ACUUUUgFpaSlpgFLRRQAlPhfD4J4NMNNNAF+NqlPIqpFJuHPUdasocjFAhrLuUo e/Q1V5BIPUdauMOKguV48wduGoGQFQaYUIqQEGloAr0VMVBphT0oAZRRiigAooooAKKKKACrNtLx 5bfhVaigDRxg4PTtTZUJ+cfiKIJBLH/tDrT1J6N94UxEEbY78ZqyDkYNQSLtO5eFNOjbPHQj9aAH MMU772OelL1FNBwcUhisu6mrnODwy/qKd05oIzjHbpQA6iiigBksYljKn8DWcQVJU9RWpVe7i3L5 ij5h1+lAFKkp2KSgBKKKKACloooAKligaTnovrUkNtn5pOB2FW6QEccSx/dHPrUlFFMAoopD6CgB c80UUUAFFFFABQaKSgYUhpaSgBDSGgmm0AKaYxpSeKYxwKAEY0wUdTThSABS0UUCCkpaKYwooooE JRS0lABS0lLQMKKSikA2iiigBKWkooAKWkpaACiiigAooooAKKKKACiiloASiiigAooooAKKKMUA FFFJQAtFJS0AFFFFABRRRQAUUUUAFFFFABRRRQAUtFJQAtFFJQAUUUUAFFFFABRS0UAAoopKAFoo ooAWikpaAEopaSgApaSloAKKKKACiiigAopKWgAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooATvQaUikzmgBO1ApTSUhi9KCM0DkUdKYCUh5p1GM0gFHSikHBxS0wEpOh5paG 5GaQCjrS0g6iloAKBRRTELRRRSAKKKSmAwjBoxxT6RvumgBMcD1pMfhSt90UirnrSKFQZOewpV6m lpF7/WmIU9DSL90UHoaF+6KBC0hpaSgBu7HBoLelBGWpQAKBiJwKRvvilLAdKbgmgBxPvQMUBRS0 CCignFJzQAUZ9KQ8UZNA7C49aKARRn0oEBNNA65pf1NLj1oGIPalx60tFAhKSlJpKACjNGKWgQnW lFFFMBD0paRu1L3pDFNNK06ikMbim1JTe9ACGkPSnEc0jCgBuaUUg60tMQUlLSUALSHpS0lACUUG igAooooAUUoOKQUUAPDnvTwwNQ0UwJ6WoQxFOD+tAEmaXNMDA9DS0CHg0uaZS5oAfS0zNLmmA7NL kUzNLQA/djtmnZqOjNICWiow1OyDz2oAdSMqv95QaKBQBE1sp+42PrzUTxSJ1XI9RVujOKAKGRRV 5kR/vKDULWw/gbHsaQyvS05o3Tqv4im5BoASiiigAopaKAEopaSgAoxRS0ANxSYp1JmgAxiilopi G0lOpDQAlLSUopALS0lFMBDSUtJQA5G2MD271bRsDiqdSwt/CfwoAvA7hTSOx6HrTUbn6080AUJI /KkK9uopAxHWrc0fmR4H3l5FUxzQA8EGimYpQSKAAimFafkUGgCPaaNtOozSGN20mKcTSE0CEooo pgORzG4YVeBDKHTlqz6mtpNj7T0NAFvgjJ6HqKiI8tvbsalbjk/jQRuXB6HpTEIr8Z/MU9h3FVwS pINTq2foaQwFAOOKDwQaCKAH0lIpzx6UucUALRSZ4zSOSFODg9qAKVxF5T5H3W6e1RVokCaLB7/o aoFSrFW6igBuKTFPxUkduznJ+VaQEABJwBk1dhtxH8zct6elSJGkQ+Uc+tLknoKAHUUUUwCig0nT 60ABPbvS0gGKWgAooooAKKWkoASg0UlAwpDQaQ0AIaTNITzTSaAAt3qInNNd8tgdKeBQACnUUUgC iikpiClpKWgAooooAKSjvS0AJRSGl7UhhRRRQAyilooASilooASilooAKKKKACiiigAooooAWikp aAEooooAKKKKACikpaACiiigAooooAKKKKACiiigAooooAWiiigAoopKAFooooASiiigAooooAKW kpaACiiigBKWiigAooooAKKKKAFooooASlpKUUAFFLSUAFGKKWgBKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiloASilooASilooAKKKKAEpDTqKAG5ooIo6UAIMjpSD1p1JSKFFLTc8UooEL1 ooBozigBO5paTvSnpQAdxS00dqdQAUd6KSmIdRRSUAFFFFABTW6U6kb7tACMCQMU4cU1jjFOpDYU i96Wmr0NMQp6GkDAAUp6Um0UDE3GkwT1p9JQFwAxQRmijpQIMYopM56UuPWgAyKTn6UtFABikJoJ puD1NABS4o+lLj1oGJgfWlxS0dKBB0opM0nJoAXNJkmlxRTEJilpaKAEopaSgAooooAD2oHWkPUU opDFooopDCkxg0tFABSHmlooAj280/FLijHFAhmKTFOoxQMbRS4oxQAw0UppKYgooooAUUUUUAFF FFABRRSUALmnByKZRQBKH9afmoKXNMCfNGajDGnBqBD80tMzSg0APzS5pmaXNMB1KccYptGaAHBj 0p27FMB5BHalyScmgB4YZpe1R/Sl6UgH0tMDGlyKAHZprIjn5l59aXPWjPpQBC1t/cb8DULI6feU getXaM0AUM5pattHG/VfyqNrY/wNn2NIZBRSsjp95SKb16UAFLSUtAAaaadSGgBKKBRQAUUUGgBt FOxTaYC0pNNBoJoEFFFFAC04cdKaKcKALCNkA1OjZFU0baeehqdCR9aAJW4Oaq3CbW3j7rdfrVvq KaVDAq3Q0AUaKUqUYqeopKAExSU6koATNJmlIpCKAE60uKSlBpAJikp1FADaKXFFMC3byB49jH5l /UU8ZB2MfpVFSVIZeoq8CJUBHXt7UADoSMjqP1qNDipgdwyeo6io5R824DimBLncPekBwaYjU8+1 IBSMHI6U7JxkCmjpjsaUDacdj0oATIHTof0pAN/Xp6UAckHof0py5xz1oAXpxUM8JkKsvB71NSH3 oAZHCsfufWpDRSUAIVDHn8qX9KWigAooooAKXbSDAps0vlAEqSCeSO1AD8UlCOrjKnIpaACikozQ AUlBozQMO1NJpabnigAJptHemk0ADGoZH7ClkfH1qAmgBV5YVOKhj+9U9IQUlLSUAFFFFMYUtJS0 gEpaSimAUtJS0AJS9qSlpAJRRRQA2iiigAooooAKKKKACiiigAooooAKWkoxQAUUUUAFFLSUABpM 0tFABRRRQAUUUUAFFFFABRRRQAUtJRQAtFFJQAtFJS0AJS0UlAC0lFFAC4pKU9KSgAooooAKKKKA FooooAKKKWgBKKWigAooooAKKKKACgUUUABoooxQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU tACUUtFACUtFFABRRRQAUUUUAFFFFABRRRQAUhFLSUANpaCKTpQAUA0vWkpDHdeaTmkU+tLkk8UA GeOOppMUUDpQMX0xTqbTqBMKO9FJ3oEOooFFMBKKKKACkb7tLSN0oARhkCkDYpzDOPSm/QUihwIN IDgYpvX60pzwB1piFB7UtIeCKMk9BQAtITRj1NGMUCE5PtRwKGOB70nSgYUu7FJg0YH1oAXPoKDR zRQIPpxRiikzQAtGaSjFABmilxRTEGKKWigAooooAKKKKAEopaSgAooooAQ9aVaQ9aUdKQxaKKKQ wooooAKKKKACg0UhoAKKKKACiiigBh60mKU9aKYhtFOpMUAFFGKKACiiigApKKKACiiigApRSUtA C5pQabS0APDUoao6XNAEmRS1FmnA0wJM0oao91LmgRLxRk0ylDUAPDc0uaZnNANMCQGjrTd1ANAD s4pc880naigB+eOKKZilzSAdS03NLQAuaY0UbHlcH1FOooAga2YfcYH2NRFWX7ykVdozQBR60Vbe KN+owfUVE1uw+6wPsaQyCilYMv3lIpKACiigUAJTSKeaafagBtFO2OeimnCGU9ENAiOlqUW0v93H 40otZO5ApgRinVKLVh/GPypwtvV/0oAr1LG2R7ipPsy93NI0Qjw65OOtAEsbdqewqBDg+1TqcigC C4Tcm8feX9RVbOelXzwaBjtxQBRwT0BpfLc/wmr2aKAKfkynov60fZpD6D8auUlAFUWjd3A/ClFp 6v8AkKs0UgIBap3YmnC2j9z+NS0tFgIhBEP4f1pwijHRBTqKAGvGCuAACKiRihz69RViopEz8w/G gYxiQd4GSOv0p+Ay+xpinBpw+Rsdm6UxEfKt7ipM0sq5G4dR+tRoeMflTAk6cCnqc8dxUYP50ucY PcUgJPrRSMQMH1oPHNAC0UUme1AB39qWgUCgAoJwKWigBM8ZpOtBGabuOwkDJHagBf6UB+cUmQ6b lyM9j2owRz3oGPAA6DFLTQccZ60poEFJS0lABSUZpDQMQ0nWgmkJ4oAQnFRu20UrNgZNV3bcaAEJ yaSiigQ+LqamqKIcVLSAKSlpKYwooopCAUtFFMYlFFFAAKWminUCA0lLSUhhRRRQA2iiigAooooA KKKKACiiigAooooAKKKKACilFFACUUUUAFFFLQAUlLRQAlFLSUALSUUYoAKKXFFACUtFGKAEopaK ACiiigAoopKAFo4zSUooADiiikoAWikpRQAYooooAKKKKAClpKWgAooooAKKKKACiiigAooooAKK KKACiiigAooooAKBRRQAUUUUAFFFFABRRS0AFFFFABikpc0UAJS0UUAFFFFABRRRQAUUtJQAUUUU AFFFFABSEUtFADOlL1pSKbjBoACKaKd1pKQ7iig9KTmlFAxRTqb2p1AmFJS0hpiHCigUUAJRRRQA UjfdpaRvu0AI3amr3p5GRTce1IoAMUZozScfWmAdsinA5FN6L9aNp7UAPppOOB1oxjqaOfpQITHr Sj2oxS0BcTHrS0maTNAhc0maMUuKBCUYpaWmAlFLRQAUUUUAFFFFABRRRQAUUUUAFFFFABSUtJQA h60o6UnendqQwooopDCiiigAooooAKQ0tIaAEpaKKACiiigBlFLSUxBRRRQAvajFHaigBuKD0pRQ elADRRSgYooASiiigApaSloAKWkpaACiiigAooooAXNGaSigB4al31HRmgCYEGlB4qENTg1MRJmn ZqPdSg0ASbqXNR5pQaYEgNLmo80oagCQYPWjOM4NMzS5oAfmjtTaMkUAPopoPApc0gFpc0lBFADq iaCNu2D6in0ZoArtbsPukN+lNSJ2YgjaB1Jq3mkJ9aAGrDGvbPuaf06UCg8DmgBc0U3PGecUv0oA WkoooAKKKKACj60UUAQFdj7T0PSnxtT3XeuO/Y1ApIPuOCKALJ5FN6HHY0Iw6UrCgApaaDk+/pTq ACiiigAooooASilooASiiloASiiigCGRdp46GnAhxz1qQgEYPSojGw6c0hjlbg+o4qJ12N7dRTvn 6YNIcng9qdwsANO4qMcU4GgQ8YKkflR8xjDZ5Hak/pTm6bvzoAcrAjg0tQnjG3p7VIrbgPWgBaXN JR060ALSE0mcmjHY0AHNIWI+7wTQW5wKAMc0DEJYjJxQxwAM80MaAM8mgBUXHJ60/vSClpCEpKDS E0wDrTSaUmmmgAJphPFBNQyP2FAxsj7jTKWl20CG0Gl20hoAli+7T6ag+UU6kAUUUUxhRRRQAUtJ RSAKQ0tJTABTqQUtIBKKKKACiiigBtFFFABRRRQAUUUUAFFJS0AFFFFABRRRQAUUtFABRRRQAUUU UAFJRRQAUUUtABRRRQAUUUUAFGaSigAooooAWikpaACikooAWiiloAMUmKWigBMUUUUAFLSUUAFF FLQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABS0UlABRS0UAJS0lLQAUUUUAJS5ooo AKKKKACkpaKACiiigAoopKAFooooAKKKKACiiigAooooAKQilooAYRSU/FNIoASlPI4oFGPSkMM5 FPpmadQAtBoopiFFFAooASiiigApr9KdTX6UAKTgU1eeTSnHekz6CgYEUYA60cmjAFAXDOegpcet JmkzQIWjNJRQAZo5NLilpgNxS4paKBBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FADe9LSUHkUhi5paYM5p9IAFFJ75oNAxaKKKACkNLSUAFFFFABR2ooPSgBtFJS0xCUUtJ3oAGoHT ihqB0oAKKKKACiiigBMUUtFADaWlApcUAJRRiigAooooGFFFFAgooooAKKKKAEozS0UAANOBplGa AJQ1KGqLNKDTAmzRmos04NQIkpc1Hup2aAHg0uajzTs0wH5pc5NR5pc0ASUueajBpwNADsilpuc0 vH40AKvOaXHrSRHlh3BqSkA2o5OMHPFS4FIRQBDglt4Y7fTtUig4PpS4wMAcUUAFFFFABS0lAoAK KKKACo5V/jHbqKko70AQqen6VODuFV2XY2B909KfG1ADm4OfSnUpGRTCwU4PegB1FFLQAlLSUtAB RRSUAFFFFABRRQKAFooooAKZIu4e4p9FAFY0nSppE53D8ahNAxwNPBxn3qKnZoEPManlSVPpSbWA wRkeooDYp4YH2NACfM3QU054J6U85A9qTHXJ60AIZVVgGGAehpzE4pASAAACB60AksNwxQAYxz3p C2OtDH3oAJ6igYKO5/CnigUtIApDRSZpiAmm9qCeKQ8CgAzimNSk1HI+BQMbI+OBUNBOTRQIKWii gBc0jCijuKAJV6UtA6UUgCiiimMKKKKQC0lFFABQaKKAEFLRRQIDSUE0CgYUUlFABRRRQAUUUlAC 0lFLQAUUUUAJS0UUAFFFFAC0UUlAC0UlFABRRRQAUUUtACUtFFABRRRQAUlGaKACijFFABRRRQAU UUUAFFFFACiiiigAooooAKKKWgBKKWigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKWgB KKWigBKKWigAooooAKKKKAExRS0UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA0ikBp9NIoAMA0tN6U6gApe9JRQA4UGkFFABSUUUAFIRmijNACYFLSZpKAFJpM0Yp cUCExRinYopgJiloooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gBtFL2pKQwpc0lFIYClPWkpaAFoppOKAc0CHU2ndqbQMWikooAWg9KKD0oAbRRRTEFJRRQAHk0UU UAFFFFABRRRQAUUUUAOFOpo6U6gBMUhFOooAbikxT6MUAR0tLijFADaKDRQAUUUUAFFFFABSYooo AKWkooAWjNJRQA4GnBqjozQBKGpwNQ5pQaYE2aWot1ODUCJM0ZpmaXNMB4NPDVFmlzQA/o4Ydf50 8OahBxTs0ATBqdmq4PIpwY8e1AE3WjFMDAge9KGpAKRSU4NmjAoAjIz9KdS4x0pucdaAFozSZpaA CiiigBGUMpU//qqDJQkHqOtT7hTXXzFyv3h096AHowPGaGUEcjioEOOR2qwp3CgBinB2E/SnUOuR SA9QeooAWiiigAooooAKKDRQAUtJS0AFFFFABRRSGgAzTGRW9j607rSUAQEFThvzpalPI5/KmFOf l6elADaVT1NIeDg0YoAkVh0NOxjryKhBwaUNwQKAJCePpSM+O9MLZGMU5E7t+VAxVUk7j+FPFLii kAUlLSUxCdKQ+1BpCaAA0w0ufzpjHHWgYjNtFV2OTSu2402gApaKKBBRRRQAUD7wopV+9QBLRRRS GFFFJTAWiiikIKKKKYwooooAO1FFFIBDQKD1oFACcUZFGKMUAFFFFABSUtFABRiiigAooooAKKKK ACiiloASiiigAoopaAEooooAKKKKACilpKACilpKACiiigAooooAKKKKAClxSUtACUtFJQAtFJSi gAoopaACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKWkpaAEooooAWiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiloAKSlooASiiigAooooAKKKM0ALSUZooAKKKKAC iiigBCKb0p9JQAUhoIpCaAHA0UmcdKTk0ALmkzRijFACZNGKdiimITFGKWigAooooAKKKKBhRRRQ IKKWkoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAEHSkpe1JSGFFFFIY UUUUAJSqOeaKKAF7UlFFABRRRQAtB6UUhoAbRRRTEFFFFABRRRQAUUUUAFFFFABRRRQA9elLTQad QAUUUUAGcUUUUAFGKKWgBuKQinUUAMxSU/FJigBtFOxSYoAbRS4pKAFpKWkoAKKWkoAKKKKAClpK KAFpc0lFADgaXdTKKAJN1OBqLNFO4E2aUGoQxFODjvQIlzTgaiDelKD60wJKCT9aZmlzQA/d68U8 N71HnP1o4/8Ar0AThqXg1ACfrTg/vQBJsGaQgilDUuc0gGcjtTZDhcj8amppUGgCuxbChX2jvT0+ 91+tPCFTkGkI9qAEkTJ3L17imxsQafnBznFMZe4696AJ+opGUH+lRI+04PSpuooAYMgfN+dGehwc etI2ARmmDzDLkMdvpjigCQEHoaWmr3XHSnUAFFJ+NLQAUtJS0AFFJRQAjMFGTTeW78UpUMckZIpa AE+lHelxS4oAbgnijpwD9TQTnhfzpwGBQAzHtxSbBmlmVzGfL+9SRyNIcOm1h196AGOuOnWgIx61 PgUvSgBqRhB7+tLS0hpAFJRRTAKaTQaQ0DA00ml68UxjQAMciq8j5OBT5CccVCRQAUUUtAgooooA KKKKAClT71JTo+poAkooopDCkpaKYBQKKKACiiikAUUUUAFFFFACHrQKTvSigBaKKKQxtFFFMQUU UUAFFFFABRRRQAUUtJQAUUUUAFFLRQAlFLRQAUUlLQAlFLRQAlLRRQAUUUUAFJS0UAJRS4ooAKKK SgBc0UUdKACkpaKAEpaKUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABS0lLQAUlLRQAUUU UAJRS0UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUtACUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAlGKWkoAMUYoooASjFLRTAKKKKACiiigAooooAKKKKACkpaK BBRRRQMKKKKBBRRRQAUUUUAJRS0UDEoopaBCUUUUDCiiigQUUUUAFFFFABQelFB6UAJ2pKKKkoKK KKACiiigAooooAKKKKACilpKAFpDRQaAEpKKKYgopaSgAooooAKKKKACiiigAoopKAFHtTgfWkxR imIdS0zkU4HNAx1JRRSAKWkooAKWkopgFFFFIApMUtFADSKTFPoxQBHRTttIRQA2ilxRQAlFBooA KKKKAClpKKAFooooAKKKKACiiigAJxQJCKaaSmInEgPtTgarUoJHSgC1mlBqBXJIFScjrQA+lzxT MkUuaYDx7GnBiKjzS5P5UATLJmn5qvn1FKCR0NAFiioRJxyKeHB6GkApUGmFDzUmaWgCuynvSpJt PNTEA0wx5/8Ar0AKyrIOaaEIQpnio9skZ6Ej2pyyqw680APVdowKRuKUNntS8GgCMuR90A+uaVT6 dKcFA7UABcntQAtFMTnJPU0+gApCcdaRmxURYk8UwJN4FIZQPSoiM9absFAE4kB6EU7BYcnj0FVf LFJtZeVNAFwDHFLVRLh04YbhViORJPunn0NICSikpaACikY4GaQUALRQaQ0AFNJ96D7UhoAKQnik 9jSMaAAmo2cCldtoquTk0DJRzS4B61EMjpTxJ60gAx+lMKkdamBB6UtMCvRUpQHpTChFAhtFFFAB T4+lMNPT7tIB9FFFAwooopgJS0lLSAKKKKACiiigAooooAbThTaXGKAFooopDG0UUUxBRRRQAUUt JQAUUUUAFFLRQAlLRRQAUUlLQAUlLRQAlFFLQAUUUUAFFFFABRRRQAUUUZoAKSlooAKSlooAKKKS gBaKKKAClpKKAFooooAKKKKACiiigAooooAKKWkoAWkpaKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiimAUUUUgEpaKSgAooopgFFFFABRRRQAUUUUAFFFFABRRRQAUUUUCCiiigYUUUUAFFF FABRRRQAUUUUAJRS0UAJS0UUCEopaSgYUUUUCCiiigAoNFB6UDEo70UVICYopaaxPbpQMWimq3rT 8UwEooopAFFFFAC0lLSUALSGlpDTAbS0UUCA0lFFABRRRQAUUUUAFFFFABSUtA60AOopaKYhKQin UUAICR1pwOabSY9KAH0U0N607NIYUdKKKACk70tJTAWiiigAooopAFGKKKYCYpMU6ikAwikxT6MU AMop2KTFACUlLiigBKKWkoAKWkooAWiikoAaaKKKYgooooAWpEmI4PIqKloAs70b2pcehzVWlDEH INAE+cUoNRrL/eFPGH+6efSmA7NKKYQR1FGaAJM0uQaYDSjrnNADwSOh4pwk9R+VRDI60oagCdXB 6GnZqvwaUFh0NAE+4U1kSThgDTA/Yj8qdlW6GgBhhZfuP+BpNzA4Zeakww+6aaQWI3D8qAASD6U5 huC46d6j2HBPWnJ8q8mkA/pTWbHWmgtIxCEADuRnNNkUrjJzmmAhOaSiloASkpcUYoEFFFLQA0qD 1qJ0K8j86npSpaFtv3hQAkcxRgk2ORw1Tng1UkBmiV+44IpbebGInPHQH0pDLR5pPakztODR070A GaOlJnFITQAEim8nPtQTTcmgYuRjmmMcA5pc+tQO2T7UAIx3GgCgUtAgxRS0lACdOlODkdaSigCU MDS1BinByKAHlQaYYyOnNPDg06kMrkYpVyKmIB60m3HQ0CEHNFH4YooGFLSUtMAooopAFFFFABRR RQAUHpRSHpQAgp1NFOoAKKKWkMZRRS0xCUUUtACUUtFACUUUUALRSCigBaKKKACiiigAooooAKKK KACilooASilpKACiiigBKKWigBKWiigAooooASloooAKKKWgBKWkpaACiiigBaKKKAEopaSgAooo oAWikpaACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigBKKWigBKWik pgFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFIelLSHpQAgoGKBSDk0hi0hXHIpaGOBxQIZgdRT1x2pnGPQ05euaAFJ56ZoHNHQ49aDwRS GJRSnrSUAFFFFAC0hpRSHrTAQ0lLRQISiiigAooooAKKKKACiilzjpQAlA60Uq9aAHUUtJTEFFFF ABRRRQAU3BHSnUUAIG9admkwKTGOlAx1FNFOpAFFFFACUtFFABRRRQAUUUlMBaKKKACiikpABFJi nUUAMxSVJimkUAMop2KTFACUh6UtIaAEooopiCiiigAooooAKWkpaACiiigCRZnXvkehqQSRPwwK H1HSq9FAFvym6xkOPamZI+8MVApKnIOCO4qVbmQcNhh70wHg+lLmgSQv1BQ/nTvLJGVIYe1ADfoa XdyaaeDgjBoB9KAJA3el61HmgGgCT6cUbmHemhqXNADt7YI4puPU5paOKAFViMYpZuSn50mKRzlh 9KAG0UooHFAB2oopTQIbS0UUAGKBweKKKAE+lRSRh84OCKnA5p+QVOQM0ARROWQq330/UU/PFV5A YZ1ccip265HQ80hhmkJopD9cUDENJQTUbvgYFACSNngUyilAoEFLRRQAUUUUAFJS0UAJRS0lACYp QxFFFADxID14p9QYoBI6UAT0mKYJPWnhgaQxuMUCnZo4NACUUdDTgwoAbRT+DSFcdKAGUUUUALSH pS0jUAApaQUtABRRRQAlFJRQAUUUtACUUtFACUUuKKACiiigApaSigBaKSigApaSigBaSiigBaKS loAKSlpKACiiigAooooAKKKKACiiigAooooAKKKKACloooAKKMUUAFLSUUAFFFFABRiiigAooooA KKXFGKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAopKKAFopKKAFopKKAFopKKAFopKKACi iigAooooAKKKWgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAEpaSigBaKKKACiiigBK KWimAUlFFABRRS0AJRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABSHpS0h6UAIKT0FKKMVIxaTtS0UAN60opaKAEIPUGkBzyRSkc8n8KMbenSgQh60UppKBhRRR QAtNNOptMAopKWgQGkpaSgAooooAKKKKAClpKKAClXrSU5aAHUUUtMBKKWkoAKKKKBBSUtFABSUt FACUnIp1FAxM0tIRScikA6ikBFLTAKTNFGKAFopKM0ALRRRSAKKKKADFJ0paKADNFGKKYCYpMU6i gBuKYRzTzwKbQIbSU4ikxQAlFLiigBKKKKAClpKWgAooooAKKKKAClApKXNIAoBK8g4+lFNNMZOt 04GHAce9PDQP0JRveqtFMRcMTjkYYe1N74PBqurMhypIqdbpukihxQAtLmgGGT7rFG9DSmORewYe 1IBM4pwbNR5H0NLTAeWoznBpmaKQEtFC8qDS9ulACYpMjn26+1PHH9aTGyTcMEN1oEJRQBjilFMB KKXFJQAlLmnFCDTelADZF3IR+VNjbMYz1HFSDrUQG1nHvmkMf7000uaYzbRQMR2xUXU0E5NAoAUU tFFAgooooAKKKKACkpaSgAooooAKKKKACiiigApOnSlooAAxHWnbsjg02kxQBIvPfmlx61FyKcJD SGS8qPY0zJJpNxzz0qQYIoAZRTyvpTSCKAEpDS0negBRS0Cg0AJRRRQAUUUUAFFFFABRRRQAUUUU AFFFLQAlFFFABS0UlAC0UUlAC0lFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFGaKACiiloAKMUUUAL RSUUALRSUtABxSUGigAopKWgAooooAWjNJS0AGaSiigAooooAKKKKACiiigAooooAWkoooAKKKKA CiiigAooooAKKKKACilpKAFpKWkoAKKKKACiiigBaSiigAooooAWiiigAooopgFFFFIAooopgFFF FIAooooAKKKKACiiigApKWigAooooASloooAKSiigAoopaACiiimAUlLSUALSUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUtACUUUtACUUtJQAUUtFIBKKKKYBSN0paRulIBB1paSg96QxaKYGpx6UAL RSdqAaAD+PmkGTk5pxGaQjjHQUCA0lKaSgYUUUUALTTTqbTASiiigQUUUUAFFFFABRRRQAUUUoFA BinKMUAU6gAooooAKKKKACkpaKYCUUtJQAUUUUCCiiigAooooAaRRkjrTqSkMBS03HpRn1oAdSUU tACUtJRQAtFJS0AFFFFMAooooASilpKAEbpTaVqSgQUYopwFACbaaRUlGKAIsUVIRTSKAG0UuKSg AooooAKKSloAKKKKACkpaSgAooooAKWkpaACnJIyfcYim0UAWBc7hiVA3uKeEjf/AFcmD6GqlFAF pkkT7y5HqKaGB71Gk8icBuPQ1KJ45P8AWpg+opgPjP8AD69KkqHydy5ifNSoxIw64cdR6+4pALx1 70nanUnWgA6UdxR2o/CgQxfmm7cdjSJnLDtUm1Cckc+tIECZ296AFyfWg80UlMBKY33z9KkxTHxv J9KBjGOOahZtxod8mmikMUUtFLQIKKKKACiiigAooooAKSlooASilpKACiiigAooooAKKKKACiii gApMUtFACAkU8OPoabSYoAsbhtGOtJyahBK9KesgPXikO48qKYVINSA56UUARjig08gGkK+lADKK WigBKWkpaACiiigAooooAKKKKACiiigAooooAKKKKACiiigAopaKAEopaKAEopaSgAooooASlooo AKKKKACiiigBaKKKACiiigAooooAKKKKACiiigAooooAKWiigAoopKAFpKKKACiiigAooooAKKKK ACiiigAooooAKKWkoAKKKKACilpKACloooASloooAKSlpKACilooASiiigAooooAKKKKAFooopgF FFFABRRRQAUUUUgCiiigAooooAKKKKACiiigAooooAKKKKACiiigBKKKKAClpKWgAooooAKKKKYB SUtFACUUtFACUUtJQAUUUUAFFFLQAlFLRQAUUUUAFFFFABRRRSAKKKKACkpaKYCUjdKWkagBtKea SlqRjMYNP/hpuD604dKYg/hoFFIOvFIYuaXNI3QimKTTEPNJSmkpDCiiigA7UlL2ptMAooooEFFF FABRRS0AJRS4pQM0AIBTgKUCloAKKKKACiiimAUUUUgCiiigAooopgFFFFIBKKWimAlFFFAgoooo AKQilooAbS5oxRigYUtN5FLmkAtJRRQAtFFFABRRSE4pgLSZppOaX+GgQlAFKAMU6gBoWnYpacrA LigBlFSHZimYNACUmKcRikoAbikK0+koAjxSYqXFNIoAZRTiKTHFACUUuKSkAUUUUAJRQaKYBRRR QAUUUUAFFFFABS0lFACg4ORwamFzIFIzn0J7VBS0AaEciTLkYDdxS1nA4OR19asx3Jxh+femBYpO /WhXDdKXrzSASilxRQAlFLjikLBRyaAEPyjNVZHzwKdLLu4FQ0wCilxS4pAJmlBpMUlADqWmUuaA HUUmaWgAooooAKKKKACiiigBKKKKACiiigAooooAKKKKACiiigAooooAKTFLRQAgJXoakWT+9xTK SgCcHPSlquMjpT1k9aQyWikBBHWjI9aAGUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFLQA UUZooAKSlooASilooASloooASilooASilooASilooAKKKKAClpKWgBKKWigBKWiigBKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApaKSgAoopaACikooAWikooAWkoo oAKWkpaACkoooAKKKKAClpKKACiiigApaSimAtJRRSAKKKKACilpKYC0UUUgCiiigAooooAKKKKA EooooAKWkooAWikpaAEopaSgBaKKKYBRRRQAUUUUAJRS0lAC0UUUAFJS0UAFFFFABRRRQAUUUUAF FFFIAooooAKKKKACiiigBKRqdTWoAbTqbThSGFFFFACDpR3oAo5zQAH3pnGafSbfagQvakpT0pKB hRRRQAdqbTj0ptABRRRTEFFFLQAUGilC0AAFPAoAooAKKKKYBRRRSAKKKKACiiimAUUUUgCiiigA oopCaAFooooAKSlopgJRRRQAUUUUCCiiigBKQj0p1JQAmfWloxSYI6UDFpaaDQW7CgBScUwmkooE FOFJRQA4Gl3U2igB2aUGmZpc0APoPNNpc0ABNJmoySDShqAJKKbmlzQAtJS0UANpQKDSCgBMckUY pTxzS0AMxSYqSjFICLFJUhWkIoAZRQRRTAKKKKACiiigAooooAKKKWgAooooAUMR0qVbhx71DRQB aFz6ij7R7VVoouBO05NRs5NMpRRcYUoFKBS0CEpaKKAEoxS0UANxSU+kxQA2lzRiigBQaKbRQA+i m5pc0ALSUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUlLRQAmKMUtFAD6KKKQwo oooAKKKKAClpKWgApKWkoAKKKKACiiigAooooAKKKKAFooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKAClpKWgApKWkoAKKKKAFooooASiiigAooooAKKKKACiiigAooooAKWkpaAEooooAKKK KACiiigBaKKKACiiigBKKKKAFpKWkoAKKKKAFooooASiiimAUUUUgCiiigAooooAKKKKYBRRRQAU UUUgClpKWmAUUUUgClpKWmAlFFFABRRRSAKSlpKACiiigBaKKKACgUUCgBaSlpKYBRRRSAKKKKAC iiigAooopgFFFFIAooooAKKKKYBRRRSAKKKKACiiigAooopgFFFFIAprU6kagCOnDpTacOlIYtFF FABRRRQAUUUUAIaSlNJQAUUUUAB6U2nHpTaYBRRRQIWkpaSgBwp4pgp4oAKKKKAClpKWgBKKKKYB RRRSAKKKKACiiigApaSloAQ03vSmk70AOooooAKKKKACkpaSmAUUUUCCiiigApKWkoAKKKKAEamU 9qZQAUUUUALRRRQAtJS0lAC0UUUALS0lLQA00w080w0AKKfTBT6ACnU2nUAIaQUppBQAvY0g+7S9 jSD7tABSim0ooAdTWp1NakAztTad2ptMAooooAKKKKACiiigApaSloAKKKKACiiigAooooGFOFNp wpCHUUUUwCiiigAooooAKKKKAEooooASkpaSgAooooAUU6minUAJRRRQAUUUUAFLSUtABRRSUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAD/2Q= ________________________________________________________________________________
Subject: Re: Wing design and other stuff
Date: Apr 26, 2008
Yep, Ron, The photo came through. I'm interested in seeing youu plug molds. Mike Welch _________________________________________________________________ Make i'm yours. Create a custom banner to support your cause. ________________________________________________________________________________
Subject: Re: Sun N Fun 2008
Date: Apr 26, 2008
Just out of curiosity, and sorry if this has already been discussed, but is this new version intended for SLSA/ELSA certification? Or is it just a new version of the mark III intended for EAB like usual? That is one kick ass looking plane.... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179329#179329 ________________________________________________________________________________
Date: Apr 26, 2008
Or is it just a new version of the mark III intended for EAB like usual? > > LS Lucien: This is an updated version of the MKIII Extra intended for EAB. It has turned out to be the beginnings of a pretty good airplane. TNK is in the process of taking some of the excess weight off the airplane. We still have some tweaking to do. The Morse Cables for the aileron control work well. The 45 degrees of flaps increase the capabilites and safety of the aircraft. Looks like cruise speed will be about like most good MKIIIs, around 85 mph. Hard to take the Kolb out of a Kolb. Don't think we will be seeing 120 mph any time soon. Hopefully, I can find time to return to London before Oshkosh to do some more work. I want to raise the nose of the X about 6 more inches to get an idea of how much this will improve take off and landing configuration. When I get agressive on takeoff and landing, I bump the tailwheel. Slow speed flight is good. For those that want to hover, get a helicopter. ;-) john h mkIII ________________________________________________________________________________
Date: Apr 26, 2008
This photo is the plug mold in development for both wingtips. The plan is to split the wing tips apart after casting. I plan on using a vacuum mold process. > Yep, Ron, > > The photo came through. I'm interested in seeing youu plug molds. > > Mike Welch > > /9j/4AAQSkZJRgABAAEAlgCWAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AFE4PUc9M1FHQkdbVlFgesyEenBwevmyvJPM//////////////////////////////////////// //////////8BVltbemt674SE7/////////////////////////////////////////////////// ///////////////////////EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIA58HVQMBEQACEQEDEQH/ 2gAMAwEAAhEDEQA/AK1ABQAUAFABQAUAFABQAUAFABQAUAFAC0AFABQAUAFABQAUAJQAtABQAlAC 0AJQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAU AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAJQAUAFAAelAD aAA0AJQAUAFABQAUAFABQAtABQAUAFABQAlABQAUAFABQAUAFABQAUAFABQAUAFABQAUALQAlABQ AUALQAlABQAUAFAC0AJQAtABQAlABQAUAFABQAUAFABQAtABQAUAFABQAUAFABQAtABQAUAFABQA UAFABQAUAFABQAlABQAUAFABQAlABQA6gBKACgB1ABQACgBDQAlAEgGBSAQ0AJTAQ0AJQA/tSAZT AKAFoADQAlAC0AFABQACgBaACgBBQAo60ADdKQAtAAaAAUwHdqQxhpiCgAoAKACgAoAKACgAoAKA CgAoAKAHL0pAFAxKBCigANAxKYhKACgAoAXNABmgBR1pDHN0oAZQISmAUAFABQAtABQAUAFABQAU AFACUAOoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACg AoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAEoAD0oAbQAGgBKACgAoAK ACgAoAWgAoAKACgAoASgAoAKACgAoAWgBKACgAoAKACgAoAKACgAoAWgAoASgAoAKAFoAKACgAoA KACgAoAKACgAoASgAoAWgAoASgBaAEoAWgBKACgAoAWgAoASgAoAWgAoAM0AGaADNABmgBc0AJQA uaAEzQAZoAKADNACUAFAC0AFABQAtACGgAoAUGgBaAAUAIaABRk0ASUhjTQIbTADQAlAD+1IBtMB KACgBaAEoAKACgBaAAUALQAUAIKAFFIAagAWgANAAKAHdqBjaYhKAAUAFABQAUAFABQAtADaACgB aACgBw6UhgaAEpiFFIANACUwEoAKACgAxQAuKAHLSGDUANNAgpgFABQAlABQAtABQAUAFABQAUAF AC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAC0AJQAUAFABQAU AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQA UAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAJQAdqAG0ABoASgAoAKACgAoAK AFFABQAUAFABQAlABQAUAFABQAtACUAFABQAUAFABQAUAFABQAtACUAFABQAUALQAUAFABQAUAFA BQAUAFABQAUAFABQAUAFABQAlABQAUAFAC0AJQAUAFAC0AFACUAFABQAUAFABQAUAFABQAUAFABQ AUAFABQAtABQAtACGgAoABQA6gAoAQ0APQYFIBTQMaaBCUwENAAOtADj0pAMpgLQAlAC0AJQAUAF AC0AAoADQAmaAFFADhSARqYAKQAaAAUAOPSgY2mIKAEoAWgBKACgAoAKACgBKACgBc0AFADx0pDE NAhKAFFAAaAExTASgAoAKAFoAKQD1oGI1ADaBBTAKACgAoABQAUgCmAUgCmAUAFACUAOoAKACgAo AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBaAHKm4ZzigY7yvegAMXoaQDTGwpi GkEdaACgAoAKAEoAWgBKACgBaAEoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgA oAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBpoABQAlAAaAEo AKACgAoAKACgBRQAUALQAUAJQAlABQAUAFABQAUAFABQAUAFABQAUAFAC0AFABQAYoAKACgAoAKA CgAoAKACgAoAKACgAoAKACgAoAWgAoASgAoAKACgAoAKACgAoAKAEoAKAFoASgAoAKACgAoAKACg AoAKACgAoAKACgAoAWgAoAKAFFACGgAoABQAtAC0AIOTQBLSGIaAGGmIKAG0AKvWgBzdKQDaYBQA lAC0AJQAUALQAUAKKAENADaAHCgBwpANPWmA4dKQCUAC0APPSgYymIKACgBKACgAoAKACgAoASgA oAWgAoAfSGIaAEoEOFAxKAA0ANpiCgAoAWkAUAPHSkMaaYCUxBQAUAJQAUALSAKYBQAUAFACUALQ AUgFpgFABQAUAFABQAUAFAC0AGKAEoAWgAoAKACgAoAKACgAoAKACgAoAKACgAoAki+6aQx9ABQA UAN3GkA1/u0wI6YgoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKA CgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBp60AJQAUAB oASgAoAKACgAoAKAFoAKACgBaAEoASgAoAKACgAoAKAFoASgAoAKACgAoAWgAoAKACgBaACgAoAK AEoAKACgAoAKACgAoAKACgAoAKACgBaACgAoAKAEoAKACgAoAKACgAoAKAEoAKAFoASgAoAKACgB aAEoAKACgAoAKACgAoAKAFoAKACgBaAEoAKAAUALQAtACoO9IB9AxDQAw0xBQA2gBy0ADUgEpgJQ AUALQAlAC0AFABQAooAQ0ANoAcKAHCkA09aYDu1IBKYCikAp6UDGUxC0AFAAaAEoAKACgBaAExQA UAFAC0AFADqQxDQIKAFoASgBKAEpgFABQAopALQMf2pAMPSmA2mIKACgAoAKAFoAKACgAoAKACgA oAKAFoAKACgBaACgAoASgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBaAEoAWgCSLvSGPpAFMA pAMoARvummBHQIWmAlABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAB QAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFACUANNABmgAoADQ AlAC0AJQAUAFABQAtABQAtABQAlAAKAFIxQAlACUAFAC0AFACUAFABQAUALQAUAFAC0AFABQAUAF ABQAUAJQAUAFABQAUAFABQAUAFABQAUAKKACgAoAKAEoAKACgAoAKACgAoAKACgAoAKACgBKACgA oAWgAoAKACgAoAKACgBKAFoAKACgAoAWgBKACgBQKACgBaAHgYFIYtACGgBh60xCGgBKAHLSAGpg JQAlACmgBKACgBaAEoAWgBRQAhoAbQA4UAO7UhjaYh3akMbTEKKQDm6UDGUxC0AJQAtACUALQAUA JQAUAFABQAUAKKAHUhiGgQUAFABQAhoASmAUALQAUgFFAxx6UgEPSmA2mIKACgBKAFoAKQBTASgB aACgAoAWkAlAC0wCgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAFoAKACgB8XU0 hklAB3oAKQDKAA9DTAipiCgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAK ACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAGHrQA UAFAAaAEoAKACgAoAKAFoAKAFoAKAEoAKACgAoAKAEoAKAFoAKAEoAKACgAoAWgAoAWgAoAKACgA oAKACgAoASgAoAKACgAoAKACgAoAKACgBaACgAoAKACgAoASgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAKACgAoAKACgAoAKACgAoAWgBKACgBaACgBw5NIB9AwoAQ9KAGUxCGgBKAHLSARutM BKAFNACUAFABQAtABQAUALQA00AJQA4UAO7UgG0wHHpSAbTActIBWoGMpiCgAoAKACgAoAWgBKAC gAoAKAFoAB1oAdSGIaBAKACgBaBjTQISmAUAKKACgBV60hjjSARqYDaYgoAKACgAoAKQCUwCgBaA CgAoAWkAlAC0wCgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBaAEoAWgAoAKAHxfeP0 pDJKACgAoAZSAD0NMCOmIKACgAoATNABmgAzQAtACUALQAlABQAUAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAN NACCgAoADQAlABQAUAFABQAtABQAtABQAlABQAUAFABQAlABQAtABQAlABQAUAFAC0AFABQAtABQ AUAFABQAUAGKACgBKACgAoAKACgAoAKACgAoAKAFFABQAUAFABQAUAJQAUAFABQAUAFABQAUAFAB QAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAtACUAFAC0AKKAHqMCkMWgAoARulADBTEIaAEoAe OlIBp60wCgAoAKACgBKAFoAKACgBaAGmgAoAcKAFPSkA0UwFNIBBTAcKQAaBiUxCUAAoAKACgAoA KACgAoAKACgBaAAdaQDqBiUCAUAFAwoAQ0CEpgFABQAtADkpDF70gEbrTAbTEJQAtABQAUAFIApg FABQAUAFABQAUgFpgFABQAUAFABQAUALQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFADov v0hktABQAUAN70gEpgR0CCmAlABQAhoASgAoAcKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAQ0 AGOKAG0ABoAKAEoAKACgBaACgBaACgAoASgAoAKAFoAKADFABigBeKAAgUANxQAUAJQAUALQAUAF AC0AFABQAUAFABQAUAFACUAFABQAUAFABQAUAFABQAUALQAUAFABQAUAJQAUAFABQAUAFABQAUAF ABQAUAFABQAUAFACUALQAUAFABQAUAFAAKACgAoAKAFoASgAoAKAHjpSAfQMKACgBr9KBDKYCGgA oAeOlIBvemAUAFABQAUAFABQAUAFAC0ANNABQA4UAKaQCCgANACCmA4UgENABTAKACgAoAKAEoAD QAlADu1ACUAFABQAq0gHUDG0CFFABQAUAIaAEpgFABQAUASL0pDAdaAGseaAEzTEFABQAUAFABQA UAFIAoAKACgApgLSAWmAUAFABQAUAFACUAFABQAUAFABQAUAFABQAtACUAFABQAUAFABQAUALQAU AOj++KQyWgAoAKAGnrSASmBH3oEJTAWgAoAaRQAmKAFxQAoFABQAUAFABQAUAFABQAUAFABQAUAF ABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUA FABQAUAFACUANoADQAlABQAUAFAC0AAoAWgAoAKAEoAKAFFAAaACgAoAcBQA00AANAC4pAIRTASg AoAKACgAoAWgAoAKACgAoABQAUAJQAUAFABQAUAFABQAUAFABQAUALQAUAFABQAUAFACUAFABQAU AFABQAUAFABQAUAJQAtABQAUAFABQAUAFABQAUAFAAKACgAoAWgAoASgAoAWgB6jikA6gYUAFADH oENpgJQACgB/agBlADhQAlABQAUAJQAUAFAC0ALQA2gAFADhSADQACgANMBBQA4UgENACUwFoASg AoAKACgBDQAUALmgAoAKACgBy0gCgYlAhaAEzQAZoAKYCUAFABQAtIB46UhgKAGN1piEpgLSAKYB QAUAFABSAKYBmgAoASgAoAdSAKYBQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUALQ AUAFABQAqffFAyakAUAFADT1oASgCM9TQIKYBQAUAJQAUAFABQAUALQAlABQAUAFABQAUAFABQAU AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQA UAFABQAUAFACUANoADQAUAJQAUAFAC0AAoAWgAoAKAEoASgBwoAKACgBaAHdqAGUAAHNADqQCGgB ppgFABQAUAFAC0AFABQAUAFABQAZoASgAoAKACgAoAKACgAoAKACgAoAWgAoAKACgAoAKAEoAKAC gAoAKACgAoAKACgAoAKACgAoAKACgAoAKAFoASgBaAEoABQAtABQAlAC0AJQAUAAHNAEuRSGG4UA G4UAGRQA1uTTEJQA2gBR1oAcelIBlMBaAEoAKACgAoAKACgBaAFNADaAAUAOFAAaAAUgENMAFADq QCGmAlABQAtABigBKACgBDQAUAFABQAtABQA5aQBQMSgQtACUwCgBKACgAFAC0AFIB/akMB0pgMP WgQUwCgAoASgAoAWgAoAKAEoAWgAoABSADQAtMAoAKACgAoAXjtSASmAUAFABQAUAFABQAUAFABQ AUALQAlAC0AFABQAUAFABQAq/eH1oGTd6QBQMKBDT1pAJQBGeppiCmAUAFABQAlABQAUALQAUAJQ AUALQAlABQAUALQAUAJQAUAFABQAUALQAlABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAF ABQAUAFABQAUAFABQAUAFABQAUAFABQAlADaAA0AFABQAlABQAtABQAtABQAlABQAlADhQAUAFAC 0AFACUAAoAdSAaaYCUAFABQAUAFABQAtABQAUAFABQAUAFABQAUAFACUAFABQAUAFAC4oAM0AGaA FyKACkAuKAExTASgAoAMUAJQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAC0AFABQAlAAKAFoASgA oAWgBBQAtABQAUAFABQAUAFACnpQA2gBR1oAc3SkAymAUAFABQAUAFABQAUAL3oAU0AMoAUUAOFA AetAAKQCGmACgB1IBDTASgAoAKAFoASgAoAQ0AFAC0AFABQAUAOHSkAUDEoEKaYCUAFIBKYBQAUA LQAo60hjj0pAHamAw0xCUALQAUAFABQAUAFABQAYoAKAFAycCkA8Rn1oGIYzQA2mIKACgAoAKACg AoAKACgAoAKACgAoAKAFoASgAoAWgAoAKACgAoAKACgAoAB1H1oGTmkAlIBaAGnrQAlADG+8aYhK YBQAUAFABQAUAFABQAUAFABQAUAFABQAUAJQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAlADaAA0AFABQAlABQAUALQAt ABQAlABQAlADhQAtABQAGgAoASgAoAdSAaaYCUAFABQAUAFAC0AFACUAGaADNABmgAzQAUAFABQA UAFABQAUAFABQAUAFABQAUAFAChqAHUgCgBpFMBKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKA CgBaAEoAKAAUALQAlABQAtACUAFACigBaAEzQAE56UAGaAEoAXtQAlACrQArdKQDaYBQAUAFABQA UAFAAKAFHWgANACUAKKAFFACHrQAopAIetMAFADx0pDGmmISgBaAEoAKACgAoASgAoAWgAoAKACg Bw6UgFoGJQIDQAlABTASgAoABQAtIBV60DHGkAHpTAZTEJQAtABQAUAFABQAUAFAC5pAFAADg0AS BqQxwNAENUIKACgAoAKACgAoAKACgAoAKACgAoAKACgBaACgAoAKACgAoAKACgAoAKADuKQyegAp AFMBGpANpgMb71AhKYBQAUAFABQAUAFABQAUAFACUALQAUAJQAUAFABQAtACUAFABQAUAFABQAtA CUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAhoAbQ AGgAoAKACgAoAKAFoAKACgAoASgAoAUUALQAUAFABQAhoASgB9IBppgJQAUAFABQAUAFABQAUAFA BQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFACg4oAdmkA0mmAlABQAUAFABQAUAFABQAUA FABQAUAFABQAUAFABQAUAFABigBcCgBcCgAxQAmKADFABQAlAC0AFACUAOQZagBGOWNACUAOQZbB oAHG1iKABaQA1MBtABQAUAFABQAUAFABQAooADQAlAC0AOFADaAFpANNMBRQA/tSGMpiCgAoAKAC gAoADQAhoAKAFxQAUAFABQA7tSGLQAgoEFACUABpgJQAUAAoAWkA5aBinrSARqYDaYgoAKACgAoA KACgAoAKAEoAKAFFIAJoAcGwKAEpgFABQAUALQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUA FABQAUAFABQBP6UhhQAUAI1IBtADH+9TASmIKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgA oAKACgBKAFoAKACgBKAFoASgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgBKAG0ABoAKACgAoASgBaAFoAKACgBKACgAoAUUALQAUAFABQAhoABQA6kAhpgNoAK AHYoAQjFACUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAF ABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAuaADNAC7qADIoAOKADAoAMUAJigA6U AJQAUAL0oAVzuINAAOlACNQAlABQAUAFABQAUAFABQAUAFABQACgB3agBKAF7UgG0wFFADqQDaYB QAUAFABQAUAFACGgAoAWgBaAEoAKAH0hiGgAFAgoAKAENACUwCgAFAC0gHrSGHemAjUCG0wCgAoA SgBaACgAoATNABQAUALQAopANNMBM0ASUAFABQAUAFABQAlAC0AJQAUAFAC0AFABQAUAFABQAUAF ABQAUAFABQAUAFACUAWB0H0pDCgAoARqQDaAGv1FMBtMQUAFABQAUAFABQAUAFABQAUAFABQAUAF ABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFACUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAUAFABQAUAJQA2gANABQAUAFABQAUALQAUAFACUAFABQAooAWgAoAKACgBKAAUAOpAI aYDaAFHWgB1ADW60AJQAUAFABQAUAFABQAUAFABQAUAFACUAFABQAtABQAUAFABQAlABQAUAKKAC gAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAWgAzQAuaA DNABkUAHFABigA20AKBQAhFACYoATFABigAoAKAFxQAYoAMCgANACUAFAAKAHHpQAgoAU9KQDaYC igB/akAymAUAFABQAUAAoAKAA0AJQA4UAJQAUAA60APpDENAgoASgAoADQAlMAoAWgApAPHSkMQd aYA1AhtMAoAKAEoAWgBKACgAoAXFACsu2gBKAFFIBpHNMA2mgB1ABQAUAFABQAUAFABQAUALQAlA BQAtACUALQAUAFABQAUAFABQAUAFABQAUAFAEy/dFIYtABSAQ9KAG0ANftTAbTEFABQAUAFABQAU AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAJQAtACUAFABQAUALQAlABQAUAFABQAUAF ABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAlADaACgAoAKACgAoAKAFoAKACgBKACgAoAUUA LQAUAFABQAlAAKAHUgENMBtAAOtAD6AGtQAlABQAtABigBKACgAoAKACgAoAKACgAoAKACgAoASg AoAWgAoASgAoAKAFoAM0AGaACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgA oAKACgAoAKACgAoAKACgAoAKAFoAM0ALmgAzQAuRQAcUAGKADFADSKAEBoAM0AGaACgAoAKAFFAC npQA0daAHHpQA2gBVoAeelIYzNMQZoAWgBKACgAoAKACgBKAFFABQAUAA60APpDENAgoASmAZoAQ 0AFABQAooAWkA7tSGC0wGt1oEJTAKAEoAKACgBaAEoAWgBQDSAcQTQABaYxQBSAWgAxQBHTEFABQ AtABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQBMn3BSGLQAUAIelIBtADX7 UwG0xBQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAB QAUAFACUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFACGgAxQA2gAoAKACgAoAKAAU ALQAUAJQAUAFABQAooAWgAoAKACgBDQACgB1IBDTAbQAooAdQA1qAEoAKAFoASgAoAKACgAoAWgB KACgAoAKACgAFAC0AFACUAFABigAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACg AoAKACgAoAKACgAoAWgAoAKACgBKACgAoAKACgAoAKACgAoAKACgAoAWgAzQAUAFACUAGKACgAoA WgBKAFFACtQAgoAU0ANoAVaAHN0pDGUxBQAUAFABmgBaAEzQAUAFABQAuaACgBR1oAdSGIaBBTAS kAUwENACUAAoAdQAo60hjj0oAF6UANagBKYgoAMUAGKAFCGkA7ZQMAgoAcABQAh6UAA6UALmgAzQ AZoAM0AMpiCgAoAKAEoAKAFoASgBaACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAlT7gpD HUAFAAelIBtADX6CmAymIKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAo AKACgAoAKACgAoAKACgAoAKAEoAWgBKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoASgBt ABQAUAFABQAUAAoAWgAoASgAoAKACgBRQAUAFAC0ALQA00AAoAdSAaaYCUALQAZoACc0AJQAUAFA BQAUAFABQAUAFABQAUAFABQAlAC0AFABQAUAFABQAUAFABQAUAFABQAlACigAoAKACgAoAKACgAo AKACgBcUAJQAUAFABQAUAFABQAUAFABQAtABQAlAC0AJQAUAFABQAUAFABQAUAFABQAUAFABQAUA LQAUAJQAUALQAUALxQAhGKABaABqAAUAKaAG0AOWgBW6UhjcUxBigAxQAmKAAUALQAlABQAUAFAB QAZoAXNAC7qAAHNACmkAlMAoAQ0AJQACgBaAHLSGK1ACjpQAFSaAE8umA4KBSAdikMSgBc4oEG4U wFyKADjtQA1lJ6UALsIAzQAm2gA20AJtoATFADaYgoAKACgAoAKAFoAKACgAoAKACgAoAKACgAoA KACgAoAKACgAoAKADBoAcFz7UDF8v/aoAeo2jGc0gFoAKQAelADaAGv92mAygQlAwoEFAwoEGaAF pgFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAJQAU AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFACGgBtABQAUAFABQAUAAoAWgAoASgAoAKACgBaA CgAoAKADNACUAKKADNABQAlAC0AFACUAFABQAUAFABQAUAFABQAUAFABQAUAFACUALQAUAFABQAU AFABQAYoAKACgAoAKACgAoAWgAoASgAoAKACgAoAKADFADgaAG96ACgAoAKACgAoAKACgAoAKAFo AKACgAoASgAoAKACgAoAKACgAoAKACgAoAKACgBaACgAoAKAEoAM0ALQAdKADNACigBD1oABQAGg BKAHLQAr0gGUwFoAXBoASgAoAWgBMUAGKADFABigBMUAFABQAUAOWgBGoASgAzQAUALjPagBQh9K AHCM0DHBQKQC4FAC0AFAABmgBcUAGKADFACUgGkUxiEHtQITDUAKN4oAeCRQAoJoAMigA4oAOKAI aYgoAKACgBaAEoAWgAoAKAEoAKAFoAKACgAoAKACgAoAKACgAoAOtADunA5NIY4D15pgLQAUgFoA UdKAFpDEPSgQ2gBr/doAjpiCgYUCCgYUAFABQIWmAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQA UAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFACUAFABQAUAFABQAUAFABQAUAFABQAUAFACNQA 2gAoAKACgAoAKACgBaACgAoASgAoAKACgAoAKADNAC0AFABQAUAFABigAxQAUAFACUAFABQAUAFA BQAUAFABQAUAGKACgAxQAYoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoABQAZoAKADFABigAxQ AYoAXFABQAtACYoAMUAGKACgAoASgAoAKACgBaACgAoAKACgBKACgAoAKACgAoAKACgAoAKACgAo AKAFoAKACgAoAKAEoABQAtABQAUAJQAooADQAlADlpAD0ANpgLmgAzQAlABQAtACsoAGDQAKpbpQ Auw0AG0+tABt96AF20AGz1oATaKQChaBgVHrQITYKYBtFADhtHakMXd7UAG6gA3UAG6gA3GgAyaA DJoAMmgBMn1oAMn1oAMmgBcmgBMmgBc0AJmgAoAUUAFABQAUAFADKYgoAKAFoAKACgAoAKACgAoA KACgAoAKACgAoAKACgAoAKACgB3TgdaBjlGBQAtIAoAWgBKAHjpQAUgCgBlACN900AR0wEoEFABQ MKBBQAUDCmIWgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACg AoAKACgBKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAQ0ANoAKACgAoAKACgAoAWgAoAKAEoAKAC gAoAKACgAoAKACgAoAKACgBaADNABmgBaADFACYoAMUAGKADFAC4oAMUAFABkUAGRQAmaAEoAKAC gAoAKAFoASgAoAKACgAoAKACgAoAKACgAoAKAAUALQAUAFABQAUALQAUAFABQAUAFABQAlACUAFA BQAUAFAC0AFABQAUAFACUAFAC0AJQAtACUALQAUAFABQAUAFACUALQAUAFABQAUAJQAUAFABQAoo AQ9aAFxQAlABQAoOKAEJzQAUAFABQAUAKKACgAoAfD96kA5jk+1AxKACgBc+lACUAFABQAUAHSgA NABQAUAFABQAUAFABQAdaAF7UAJQAUAGKACgAoAKACgAoAWgAoAKADFACUAJTEFABQAlAC0AJQAt ACUALQAUAJQAtABQAUAFABQAUAFABQAUAOUYGe/agY5Rge9AC0AFIAoAM0AFADgT0oAXFACgY70A MIPpSGJjPFAChBTEBQGgBDEOxoAaYmHTmgBuxvSgA2N6UAIQR1GKAEoAKYC0CCgAoAKACgAoAKAC gAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBKACgAoAWgBKACgAoAKACgAoAK ACgAoAKAEoAM0ANNABQAUAFABQAUAFABQAtABQAUAJQAUAFABQAUAFABQAUAFABQAUAFABQAUAGa ADNAC5oAM0AGaACgAoAM0AGaAEzQAUAGaADNABQAUAFABQAUALQAlABQAUAFABQAUAFABQAUAFAB QAUAFABQAtABQAUAFABQAUAFABQAUAFABQAlABQAUAFAC0AFABQAUAFABQAUAFACUALQAUAFABQA UAFABQAUAFABQAUAFABQAUAJQAUAFACUALQAUAKKAEoAcOlACUAJQAUALQAlABQAYoAXFAByaAF2 E0AOCGgByrtOaQxKAFoAKACgBKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAWgAoAKACg AoAKACgAoAKACgBlMQUAFABQAtACUALQAUAFABQAUAFABQAUAFABQAUAFABQAqruPtQMfSAWgBKA FxQAYoAKACgBR1oAcKADmgBaAE4NABQAtABQAUAFACYoARl3DrQBEYmHTmgCRMAYIoAf+FAEcifx L+VAEVMQUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAJQA UAFABmgBMigA3UAG6gBN1ABk0AGTQAmaACgAoAKACgAoAKACgAoAKACgAoAWgAoAKACgBKACgAoA KACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAFoASgAoAKAC gAoAKAFoAKACgBKACgAoAKAFoAKADFAC4PpQAYPpQAYPpQAYPpQMMH0oAMH0oEGDQAYoASgAoASg AoAKAFoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAEoAKACgBKAFoAKAFH SgBKAFzQAlABQA5aAAgk8CgBQhNADhH6mgBdgpDDA9KAFoAWgAoAQ0ANoAKACgAoAKACgAoAKACg BetACUAFABQAUAFACigBKACgBaAEoAKACgBRQAUAFABQAUAFAC0AFABQAUAR0xBQAUAFAC0AJQAU ALQAlAC0AFABQAUAFABQAUAFABQAoGTQMk6DAoAKACgAoAKACkAUAFACFtp5oAcGB70AB6mkA2gB y0wHUAGT3FAC5oAKACgAoAKACgCIUAPVs9aAHUAMcH8KAIaBBTAKACgAoAKACgAoAKACgAoAKACg AoAKACgAoAKACgAoAKAEzQAZFABuFACbqADdQAm40AGTQAZNACUAFABQAYoAMUALigAxQAYoAKAC gAoAKACgAoAKACgAoAKAEoAKACgBaACgAoAKAEoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAK ACgAoAKACgAoAKACgAoAKACgAoAMUAFAC0AABPQUAO8tz/CaAF8l/wC7QAvkP6CgBfs7eooAX7Of 7woAUW/+1+lAC/Z1/vGgYvkJ6mgBfJT0NAC+TH/doAPKT+7QAvlp/dFAC7V/uigA2j+6KAFwPQUA FABQAUAFABQAUAFACUAGKADA9KAE2r6CgA8tP7ooAb5SelACeQnvQAnkL6mgBPs47N+lAhDbnsRQ Ahgf2oAaYnH8NADSrDqDQAmKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBKACgAoAKACgAo AUA0ALsY9qAHCM0AL5Q9aBiiNRQA4ACkAUAFAC0AFACUAFABQAUAIaAEPBoASgAoAKACgAoABQAt ACUAFAC0AJQAUAFABQAo4oAKAEoAKAFoAKACgAFABQAUAFABQAUALQAUAJQAUAMpiCgBaACgAoAK ACgAoAKACgAoAKACgAoAKACgAoAAMnFAEg4GBQMWgApAFABQAUAFABQAUAMftQA2gCUfcFACUhig gHmgB9MQhoARic9aQCc+tMBymgBaAFoAKAGlDnIoAaQRQA9TmgBaAEwD1GaAGmJe3FADTEe3NAhv lt6UwF8tvSgBhBHWkAUwCgCYIuBxQMGCrjIpXAjbb2GKAG5HpQIXd6AUAJn1pgFACc0AJk0AJk0A KMnpQAux/Q0AJtb0NACbT6UAGKADFABigAxQAYoAMUAFABQAUAFABQAUAFABQAUAFABQAUAFABQA UAFABQAUAFABQAUAFABQAUAFABQAlABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAGKAF2n 0oAXY3oaAF8p/wC6aAF8l/SgBfs7+350AOFu3cigBfs3q36UDFFuv940AKIE96AHeSnpQAvloP4R QAoVR0UUAL9KADmgAoAKACgAoAKACgAoAKACgAoAKACgAoAKQBTAKACkAUwCgAoAKQBTAKACgAoA KACgAoAKACgAoAKACgAoATHtQAhRT1UUANMSHtQAhgXsSKAGm39GoEMMLj3oAaUYdRQA2gAoAKAC gAoAKACgAoAKACgAxQAbT2FADhG1ADhF6mgBREtAx2wCkAuKAFx70AGKADFACUAFACUALQAlABQA UAFABQAUABoAaetABQAlABQAUAFABQAUAFABQAUAFABQAUAFAB1oAKACgAoAWgAoAKACgAoAKACg AoAKACgBaACgAoAZTEJQAUALQAUAFABQAUAFABQAUAFABQAUAFABQAAZOBQBIBgUDFpAFABTAKQB QAUAFABQAUABAPWgBNo9KAF6UAFAA3Q0ARZIPBoAejljg0AOagApDFWmIdQAZxQAm4DvQAbxQAoc GgBTj0oATOKAEzQAZoAOfWgBQeeaAFKg0AMaIHoaAI2jcds/SmIjOR1GKALS8ov0pDGSgYHOD6UA RYPoaYBsY/wmgBwic9qAFETe1AC+Se5AoAXyf9r9KAF8le5NAB5Ke9AD1AUYUYoAXNABmgAzQAfh QAhUH+EUAJsQ/wAIoATyk9KAE8lPegBPIX1NACeR/tUCE8g+ooATyX9qAEMTj+GgBpVh2NACYoAK ACgAoASgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAEoAKADFAC7T6UAKI2PRTQ A4Qyf3aAHC3f2oAUW57sKBii3Hdv0oAd9nX1NAC+QnvQAvkx/wB39aAF8tB/CKAF2qP4RQAuPQCg AoAKACgAoAKACgAoAKACgAoAKAFoAKACgAoAKACgAoAKACgAoAKAEoAWgBKAFoAKACgAoAKACgAo AKACgBKAFoAKAEpAFMApAFMAoAKACgAoAKACgAoAKACgBKQBTAKACgAoAawGMlc0AMKRnHUE0AIY PRqBEZicdqAGkEdRQAlABQAUAFADxgdqQDgw9KBi7hQAuaADNAC0AGaADNABQAZoAM0ALmgAoATF AC4oATFABQAlMAoAKQBQAhoAQ8mgBKACgAoAKACgAoAKACgANABQAUAFAB0NABQAdqACgAoAKAFo AOlABmgAoASgBaACgAoAKAFoAKACgAoAjpiCgAoAKACgAoAWgBKAFoAKACgAoAKACgAoAAM9KAJA MCgYtABQAUgEoAWmAUgCgAoAKADp9aACgAoAKACgA7UAR7DQA5F2tnNADjzQAUAHfigAZivJFIA3 Buh59KYCEEmgBQvqcUAKMDoDTAX5uwpAJtPpTAXafSgBdpoANvvQAu2gAxQAtABQAHnrzQAUAFAB QAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFACbQewoATYv90UAJ5SelAD TCvYkUAIYPRqAGmFvY0CGmJx/DQAhUjqDQA2gAoAKACgAoAKACgAoAKAFCk9AaAHCJz/AAmgBwhf 0oAX7O3qKAFFv6t+lAxwt1/vGgBRAnuaAFESD+GgBwRR0UUALgegoAKAFoASgAoAKACgAoAKACgB aACgBKAFoAKACgAoAKACkAUAFMAoAKACgAoAKACgAoAKACkAUwCgAoAKQBTAKACgAoAKACgAoAKA CgAoAKQBTAKACgApAFMApAFMAoAKAEpAFMApAFABQAUwCkAUwCgAoAKQBQAUwCgAoASgAwKADn1o AOvWgBhjQ9vyoAYYP7poERtGy9RQAygBw5FABjFIYtABQAuaAF3UAG6gBdwoAXNABQAUALQAUAFA BQAUAFABmgBKACgAoADQA09aAEoAKACgAoAKAEoAWgAoAKACgAoAKAA9aACgAoAKADNABmgAzQAG gAoAO1ABQAUAKKACgAoAKAFoAKACgCOmIKACgAoAKACgAoAKACgAoAKACgBaACgAoAkAwMd+9Axa QBQAlABTAWkAUwCkAUAFAB0+tABQAUAFABjNAC9KAEoAKYBg0AOCGgBdnvQAeX70AHlKeuTQAqxq vQUALgelAC0AFABQAUAJQAtABQAUAFABQAUAFIApgJQAUAFABQAUAFABQAUAFABQAUAFAC0AFABQ AlABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAGAe1ADfLU/wAIoATyUPbFACeQvqaAF8lP egBREg/hoAXYn90UALtUfwigBfwoAOaACgAoAKACgAoAKACgAoAWgAoAKACkAUwCgAoAKACgAoAK ACgAoAKACkAUAFMAoAKACgApAFMAoAKACgAoAKACgAoAKQBQAUwCgApAFABTAKACgAoAKACgAoAK ACgAoAKACgAoAKAEzQAUAFABQAtABQAUAFABSASgAoAKACmAUgCmAUAFIAoAKACmAUAFACUAFABQ AUAFADWRW6igCNoB/CaAI2jZeooENyaAFzSAXNAwoAKACgAoAMmgBd1AC7qAF3CgAzQAtABQAZoA KACgAoAKAENACHrQAlABQAUAFABQAUAFABQAUAFACUAKKACgAoABQAGgBKAFoASgBaACgAoAKAD8 KAFz7UAGT6UAJz6UAGT6UALk+lAAN1ABhqAGUxBQAUAFABQAUAFABQAUAFABQAUAFABQBIq4GT1o GOoAKQBTAKQBTAKQBQAUAFABn0oAKACmAUgFAzQAuCegwKYChPU0AKEH1oAXAHagBaACgAoAKACg AoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgApAFMAoAKACgAoAKACgAoAKQBTA KACgAoAKACgAoAKAEoAKACgBaACgAoAKACgAoAKACgAoAKACgAoAKAFoAKACgAoAKACgAoAKQBTA KACgAoAKACkAUwCgAoAKACgAoAKACgAoAKACgAoAKACkAUAFMAoAKACgAoAKACgAoAKACgApAFMA oAKACkAUAFMAoAKACkAUwCgAoAKACgAoAKACgApAJzTAMUALQAUAFABQAUAFABQAUAFABQAUAFAB QAlABSAKACgAoAKACmAUgCgApgFIAoASmAUgCmAUAFADWRW6igCNof7poAjKleooEFABSAKACgBM 0AGRQAUDF5oASgBc0AKGNACg5oAWgAoAKACgAoATnNABzQAYPpQAmDQAuDQAc+1ABg+tABj3oANv vQAbfegA20AGKAFwKADAoAMCgAwPSgAwPSgAwPSgAwPSgAxQAYoAWgAoASgBaADNABmgA3H0oAN1 ABu9qADd7UAG72oAipiCgAoAKACgAoAKACgBM0AGaADdQAbqAE3UASRjJyegoGSUAJSAWmAUgCgA oAKACgAoAP5UAFMBQCe1AChKAHBBQAuMUALQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAF ABQAUAFAC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFA BQAtABQAlABQAtABQAUAFABQAUAFABQAUAFABQAUAFACUgCgBaYBQAlABQAUAFABQAUAFABQAUAF IAoAKYBQAUgDPpQA1nVTg9aAFGT2xQAtMAoADwM+lAACDj3oAKACgAoAKACgAoAKACgAoASgBaQB TAKAEoAKACgAoAKACkAUAFABQAUwCgBKQBTAKACgAoAKACgBhjU+1AEbRsOnNAhlACUAFADSKAAU AOzQAm6gA3UgFyKADj1oAMH1oAXLCgYm40CHIcnmgY5+OlADd1AC5FABmgBaACgAzQAUAFABQAUA FABQAUAFAC0AFABQAUAFABQAYoAMUAGKADFABigAoAKACgAoAMUAGKACgCHIpiEzQAbqADNABk0A Jk0AFABQAUAFABQAUASJHu5PAoAk6DA6UDFpAFMApAFABQAUAFABTAXaTQA4J60AOAA7UALQAUAF ABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUA FABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABzQAtABQAUAFABQAUAFIApgFA BQAUAFABQAUAFABQAUAFABSAKYBQAUAFAC0AJQAtIApgFABSAKYBQAlAC0AFABQAUAFIApgFABQA UAFABQAUgCgBKACmAtABQAUAFABQAUAFABQAlIApgFIBaAEoAKACmAUgDPpQA1mAOOp9KAABz94g D0FAAw24KgYzzmmA+gBKACgBD83GcDvQAfex6CkAtMAoAKACgAoAKACgApAFABTAKACgAoAKQBTA SgAoAKACkAUAFABQAUAJQAtABQAlMApAFMAoAKQBTASgBCAeooAY0X900ARMpXqKBDTQAg60AKel ADaACgAoABQA7NABuNABuoAUMKQClge9AwGKADFABQAmaAF3UALuoAXdQAZFAC5oAKAFoASgAoAK AFoAKACgAoAKACgAoAKADNAC5oAM0AFAC0AFABQAUAJQAUAVqYgoAKACgAoAKACgAoAWgAoAKAJE TPJ6UDJDSASgBaACmAUgCmAAE9KAHBD3oAdsHegBQMdBQAUALQAUAFABQAUAFABQAUAFABQAUALQ AUAFACUAFABQAtABQAUAFACUAFABQAUALQAUAFACUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAt ABQAUAFABQAUAJQAtABQAUAFACUALQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUALQAUgCmA UAFIBKYBQAUAFABQAtACGgBaQBQAUwCgAoAKQCUwFoAKACkAUwCkAUAFABTAKACgAoAKQBQAnWmA tIApgFABQAUAFABQAUAFABQAUAFABQAUAFIAoATNACfX8qADBPXgelAApHIXt1oAdTAQjIxQADpS AKYATQAmM9fyoAWkAUAFABQAUAFABQAUwCgAoAKACkAUwCgAoAKACgBKACgAoAKQBQAUAFABQAUA FMApAJQAUAFABTAKACgAoAKAEoAY0QPTigCJo2XtkUCGN0oAbQAUAFAAKAFoASgAoAKACgAzQAuT QAu6gA3UgF4oAKACgYUAFAC5oANxoELuoGLuFAC5FABmgBaACgAoAKACgAoAKACgAoAKACgAoAWg AzQAZoAKAFzQBVpiCgAoAKAFoAKACgAoAKACgB6Lu+goAl/lQMKACgAxnpQA4IaAFCepoAcFA7UA LQAUAJQAtABQAUAFABQIKBhQAUAFAC0AFABQAUAFACUALQAUAFABQAUAFABQAlABQAUALQAUAFAB QAUAFACUAFABQAtABQAUAFACUALQAlAC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUA FABQAUgCmAUAFABQAUAFABQAUALQAUAFABQAUAFIAoASgApgFABQAtABQAUAFABQAUAFABQAUAFA BQAUAFABSAKYBQAUAFABQAUgCgApgJQAYoAWgAoAKQBTAKACgApAFMAoAKACgAoAKACgApAFMBOt ACD2596AAEbiB1HWkA6mA1eC1IB1MAoAQcGkAmc8D86YCgYoAKQBQAUAFMApAFABTAKACgAoAKQB TAKACkAUwCgBKADNABQAUAFABQAUAFABQAUAFIAoAKACgApgJSAKACgApgFABSASmAUAFADWRW6i gCJoSORzQIiIIoASgBRQAGgBKACgAoAKACgAoAKAAUALmgBKADJoAXcaAF3UAGRSAXimAUAFIAoA M0ALuPrQMXcaAF3UALuoAKACgBaACgAoAKACgAoAKACgAoAKACgCCmISgBaACgAoAKACgBwRiMgc UAIQR1FADkTdz2oAk9hQMcEJ9qAHBB35oAdgDtQAtABQAUAFABQAlAC0AFABQIKBhQAUAFABQAUA LQAUAFABQAUAJQAtABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQA UAFABQAUAFABQAUAFABQAUAFABQAUAFIApgFABQAUAFABQAUgCmAtABQAUAJQAtABQAUAJQAtABQ AUgCgApgFIApgJQAUALQAUAFABQAUAFABQAUAFABQAlAC0AFABQAUgCgApgFABQAUAFABQAUAFIB KYBikAtMAoAKACgAoAKQBTAKQBTAKACgApAFMAoAKAEJpAIfU0ALyevT0pgLQA08MG/CkA6mA0Z3 n0pAOpgISAMmkAnJ68D0pgLSAWmAUgCgBKACgApgFABQAUAFIAoAKYBQAUAFACUAFABikAtMApAF MAoASgAoAKACgAoAKACgApAJQAUAFABQAUAFABTAKACgAoASkAUwCgBGUN1FAELwkcryKBEXTrQA UAJigAxQAUAFABQAUAFABQAUAFABQAUAFABQAUAKOtAD6Qxu6mIUc0gCgYUCCgA5FABuNAC7qBhu oAXdQAu4UALmgAzQAUALQAUAJQAUAFAENMQUAFABQAUAFABQBaHCAe1IYwHtnP1oAcqE9eBTAkAA 6UAFAC0AFABQAUAFABQAlABQAtABQAUAFABQAUAFABQAtABQAUAFABQAUAFABQAUAFABQAlAC0AF ABQAUAFABQAUAH0oAKACgAoAKACgAoAKACgAoAKACgAoAKQBTAKACgAoAKQBQAUwCgAoAKACgAoA KACgAoAKACgBaACgAoAKACgAoAKACgAoAKACgBKAFoAKACgAoAKACgApAJQAUwFoAKACkAUwCgAo AKACgAoASgAoAWgAoAKACgAoAKACgAoAKACgAoAKACkAnWgBaYBQAUAFIApgFIAoAKYBQAUgCgAp gFIAoAKACmAmecCkAdOnJoAMevJpgLSAKYCN0oAB0FIANAATj3PpTAQDnLdf5UAOoAKQBTAKACgB KQBTAKACgAoAKACgApAFMApAFACUAGKYC0AFABQAUAFABQAlABQAUgCmAUAFABQAUAFIAoASgAoA WgBKACgAoAKYBQAlABSAKYBQAUANZQ3UUAQvCRyORQIj6UAJQAUAFABQAUAFABQAUAFABQAUAFAB QAUAKvWgB56UhkdMQ9OlIAegBlMAzQAu6gBd1ABkUAHFABQAUgCgBc0AG40ALuNAxd1AC7qADNAC 0AQ0xBQAUAFABQAUAOQZcCgZa70AIqheepoAdQAUAFABQAUALQAUAJQAUAFAC0AFABQAUAFABQAU AFAC0AFABQAUAFABQAUAFABQAUAJQAtABQAUAFABQAUAFABmgAx60AFABQAUAFABQAUAFABQAUAF ABQAUAFABQAUAFABQAUgCmAUAFABQAUAFABQAUAFABQAtABQAlAC0AFABQAUAFABQAUAFABQAlAC 0gCmAUAFABQAUAFIAoASgApgLQAUgCmAUAJ3oAWgApAFMAoAKAEoAWkAUwCkAUwCgApAFMAoAKAC gAoAKACkAnWgBaACgApgFABSAKACmAUAFIApgFABQAUgCmAUgCgBOv0oAB6D86YC9KQCNnacHBpg CklAT170ALQAUAIO9AAT2HJoAAMc9/WgBaACgAoAKACgApAFMApAFABQAlABTAKACgApAJ1oAWgA pgFABQAUAFABQAUAFABSASmAUgCgApgFABQAUgCgAoAKAEoAKACgApgFIAoAKYBQAlABSAKYBQAU AFADWRW6j8aAIHiK8jkUCI6ACgAoAKACgAoAKACgAoAKACgAoAKAHLSAVulAxlMQ9elIBHoAbTAK ACgAoAKAAUALQAvagAzQAZoAOKADFABigAoAKAFzQA2gAoAKACgAoAKAJYByT6UDJ6AFoAKACgAo AKACgAoAKACgAoAWgAoASgBaACgAoAKACgAoAKAFoAKAEoAWgAoAKACgAoAKACgAoAKACgAoAKAC gAPtSAAMUwCgAoAKACgAoAKACgAoAKACgApAFABQAUAFMAoAKACgAoAKACgAoAKACgAoAMUAFAC0 AFABQAUAFABQAUAFABQAUAFABQAUAJSAWgAoAKACmAUAFABQAUgEPAoAPrTAWgAoAKQBTAKACgAo AKACkAlMAoAWgAoAKACgApAFABQAUAFABTAKACgApAJ1oAWmAUAFIAoAKYBSAKYBSAKYBQAUAFAB QAUgCmAUAJ1+lAB19hSAXHFABTAKQDU4yPSgB1ABTAbnJIH4mkAoAA4pgLQAUAFIAoAKYBSAKACm AUAFIAoAKAEoAKACgBOnWgBaACmAUgE6UwFoAKACkAUwCgAoAKQBTASkAUAFABQAUAFABTAKACkA lABQAUAFABQAUwCkAUAFMApAJimAUAFACcigBaQBTAY8at7GgCB4yvWgQygAoAKACgAoAKACgAoA KACgAoAetIYjUCG0wJB0pANamA2gBKAFoAKACgAoABQA/tQA2gBKACgAoAXNABk0ALmgAyKAEoAK ACgAoAKACgCxCMJ9aBklAC0AFABQAUAFABQAUAFABQAUALQAUCEoGLQAUAFABQAUAFAC0AFACUAL QAUAFABQAUAJQAtABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFIApgFABQAUAFABQAUAF ABQAUAFABQAdaACgAoAKAFoAKACgAoAKACgAoAKACgAoAKACgAoAKAEoAWgAoAKACgAoAKACkAUA FACe9MBaACgAoAKACgAoAKQBQAUwCkAUAApgFABSAKYBQAUAFABQAUAFIApgFABQAnU0gFoAKYBQ AUgCmAUgCgApgFIApgFABQAUAFABQAUAJ157UgDr9KYC0AMcfvYyCfp60gH0wCgBp4bNIB1ADc7u F6dzQAoGOlMBaACgAoAKACkAUwCgAoAKACgApAFABQAlAB1oATPpTAAMcnk0ALQAUAFABQAUAFIA oAKYBQAUAFIApgFACUAFABSAKACgAoAKYBQAUgEoAKACgApgFABSAKYBSAKYBQAlABQAUAFABQAU AJ7UARvEDyv5UAQkEHBoEJQAUAJQAUAFABQAUAFABQA8dKQxGpiGigCQdKQDG60wEoAKACgAoAKA CgBRQAGgBKACgAoAKACgBaACgAoAKACgAoAKACgAFAFsDAA9qBi0ALQAUAFABQAUAFABQAUAFAB3 oAKACgBaACgAoAKACgAoAKACgBaAEoAWgAoAKACgBAQc47UAFAC0AFABQAUAFABQAUAFABSAKYBQ AUAFABQAUAFABQAUAFABQAUAFABQAUALQAlABQAUAFABQAdaACgAoAWgAoAKACgAoAKACgAoAKAC gAoAKACgAoAKAEoAWgAoAKACgAoAKQBQAUAFACdaYC0AFABQAUAFABQAUAFIAoAKYCUAKBQAUgCg ApgFABQAUAFIApgFABQAUAFACHngUgFFMAoAKACkAUAFABQAUAFMAoAKACgAoAKACgApAJ15PQUw EBLn2oAdQAUAIRn6jpQAKcrz1oAWgBCM0gEyWyOgHFMBw4GKACgAoAKACkAUwCkAUwCgAoAKACgA oAKQCZoAOnWgA60AFMAoAKQBQAUwCgAoAKQBTAKACgApAFABTAKQCUAFABTAKACgAoAKACgAoAKQ CUAFABQAUAFABQAUAJQAUALQAlABTAKACgBKAFoAKAGsoYcigCF4ivI5FAhlACUAFABQAUAFABQA UAP7UhjD1piEHWgCTtSAY3WmAlABQAUAFABQAUAKKAA0AJQAUAFABQAtABQAUAFABQAUAFABQAUA KODQBOr7mB/CgZJQAUALQAUAFABQAUAFABQAUAFABQAd6AFoAKACgAoAKACgAoAKACgBaACgAoAK AENABQAtABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAtABQAlABQAUALQA lABQAUAFAC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQAlAC0AFABQAUAFIApgFIAoAKYCdaQC0w CgAoAKACgAoAKACgApAFMBKAFFABQAUAFIApgFABQAUAFIApgFABQAUABpAAoAKYBQAUgCgApgFA BQAUAFIAoAKYBQAUAFIAoATrQANz8vrTAPlReSAKAFoAKQBTAaOGIpAOoAbnd06UAOpgFIApgFAB QAUAFIApgFABSAKYBQAUAFIBKAEJx05NAC47nrQAUwEJOeF4+tAC59qADPtQAfhQAUgCgAoAKACm AUAFABQAUAFIAoASmAUAFABSAKACmAUgCgBNwNAC0wCkAUAJQAUAFABQAUAFACUAFAC0AJQAUwCk AUwCgAoAKAEoAY8YbpwaAISpU4NAhKACgBKACgAoAB1oAfSGMNMQDrQA/PFICM9aYBQAUAFABQAU AFADqAEoASgAoAKACgBaACgAoAKACgAoAKAFoASgBaAHIcODQBZoGAoAKAFoAKACgAoAKACgAoAK ACgAoAWgAoATNAC0AFABQAUAFABQAUAFAC0AFACUAFABQAtABQAUAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAUAFABSAKYC0AJQAUAFAC0AFACUAFABQAlAC0ALQAUAFABQAUAFABQAUgCmAUAFIApg FABQAUAJQAtABQAUAFABQAUAFIAoAT2oAWgApgFABQAUAFABQAUAFABQAUAIKAFoAKACgAoAKACg AoAKACkAUAFMAoACaAACgAoAKQBTAKACgAoAKACgAoAKQBQAUwCgAoADSATr9KAFPApgIB69aQDZ l3JnGcUAPH3V+lMAoAKAE6ODQAjfNwOnekA7GBgUwCgAoAKACgAoAKQBTAKQBTAKACkAUwCkAnX6 UAJnP3aAFAxTAWgApAJQAUwCgApAB9KACgAoAKACgApgFABQAUAFABQAUAJQAUAFABSAKYBSARuo HrTAMgcZpAAweVNABTAWgApAJQAUAFABQAUwCkAhoAKAFoAKAEoAKYBSAKYBQAUAJQAEAjBoAheM jkcigRHQAUAFABQACgBTSGNpiCgAoASgAoAKACgAoAKAFFAAaAEoAKACgAoAKAFoAKAFoAKAEoAK ACgAoAKACgBaALKnKA0DHUAFAC0AJQAtABQAUAFABQAdqACgAoAKAFoATvQAtABQAUAFABQAUAFA BQAtACUAFABQAUAFAC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAC0AFA BQAnWgBaAE6CgBAO5oAdQAUAFABQAUAFABQAUAFABQAUgCmAUAFABQAlAC0AFABQAUAFABQAUAFA CGgAoAWgAoAKADvQAUAFABQAUAFABSATrQAtABTAKACgAoAKQBQAUwCgAoAKACgA6UAIKQC0AFAB QAUAFABQAUwCkAUwCgAoAKACgAoAKQCdaAFoATq3sKAFoAOoxTARPu49OKAFpAFMBp+fgdO5oAd9 KACgAoAKACgAoAKACgAoAKACgApAFMBCcUAHXk9KQCHJ+lACgY6UwAsF6mgBN6+tIA3CmAufY0AH PpSAKYB0pAApgFABQAUgCmAUAFABSAKYBQAUgCgBKYBSAKACgAoAKAGv1FMBScGgAwp+vtSAMY70 wCgBaQCUAFABQAUAFABQAlABQAUALQAlMAoAKACgAoAKACgBKACgBjRg8jrQBERjg0CEoAKAAUhg aAEpiCgAoASgAoAKACgBKACgBRQAUAJQAUAFABQAUALQAUALQAlABQAUAFABQAtABQAlAE8JyCtA yWgAoADQAUAFAC0AFABQAUAFABQAUAFABQAUALQAUAFABQAUAFABQAUAFAAKACgAoAKACgBaACgA oAKACgAoAKACgAoASgBaACgAoAKACgAoAKACgAoAWgBKACgBaACgAoATqfagAoAKAA88UAFABQAt ABQAUAFABQAUAFABQAUAFABQAUAFIBKACmAtACUALQAUAFABQAUAFACUAFAC0AFABQAd6ACgAoAK ACgAoAKACkAUwCgAoAKQBTAKACgApAFABTAKACgBOppALQAUAFABQAUAFABQAUwCgAoAKQBQAUAF ABQAh5pgLQAhOB79qQCjgUwCgAoATo/saQC0wEPzZUdO5pAKMAYHSmAUAFABQAUAFABSAKYBSAKY BQAUAFIBCcUAJ05NAAMnk/lTAdQAUgCgApgFABQAUgEoAQc89u1AC0AFABTAKQBQAUAFMAoAKQBQ AUwCgApAJQAUAFMApAFAARmgBM8UAHBpgHNIAoAWmAUgEoAKACgAoASgBaAENABQAUAFABTAKACg ApAAIIyKYBQAUAJQAUAIyhhzQBCylfpQIbQA4dKQxpoAKYgNACUAFABQAlABQAUAFAC0AJQAYoAX FACYoAMUAFABQAUAFABmgAoAKACgAoAKACgAoAfGdrCgCxQMWgAoAKACgBaAEoAWgAoASgBaACgA oAKACgBaACgAoAKACgAoAKACgAoABQAUAFABQAUAFAC0AFABQAUAFABQAUAJQAtABQAUAFABQAUA FABQAUAFABQAUALQAUAFIBKYBQAtACUAFABQAtABQAUAFABQAUAFIApgFABQAUAFABQAhpAApgLQ AlABQAtACUALQAUAFACdaQBTAWgAoAKACgAFABQAUAFABQAdKAAUAFABQAUAFABQAUAFABQAUAFA BQAUAIeaQCimAUAFABSAKACgAoAKYBQAUgCmAUAFIAoAKYCE0gDpQAtADR83PQD1oAdTAKQBTAa/ QH0NACn5jgfd9fWgBRwMDpQAUAFIApgFABQAUAFABSAKYBQAUAFACE0gDpyaAEAz1oAdTAKACkAU wCgApAFMBOgyaAE6nJ/AUgFpgFABQAUgCgApgFIApgFABQAUgCgApgFACUAFABSAKACgAoAQ8cim ADGdwPBoAOQeeRSAD0oAKYC0AJQAUgCgApgFIAoASgAoASgBaACgAoAKAAjNACE0AGfamAUgCmAU AFABQBE8fdfyoAb2pANNAgpgFACUAFABQAUAFABQAUAFAC4oAKQBTAKACgBMUAGKADFACYoAKACg AoAKACgAoAKACgBaAJo3yMHrQMkoAWgAoAKACgAoAKAFoASgBaAExigBaACgAoAKAFoAKAEoAWgA oAKAA9KAEoAWgAoAKACgAoAWgAoAKQBTAKACgAoAKAEoAWgAoAKACgAoAKACkAUwCgAoAKACgBaA EoAKACgBaACgBKAFoASgBaAEoAWgAoAKQBTAKACgAoAKACgAoAKAEFAC0AFABQAlAC0AJQAUAFAA aACgBaACgAoAKACgApAFABTAKACgBOpoAWgApAFMAoAKACgAoAKACgAoAKACgANIAAoAKYBQAUAF ABQAUAFABSAKACgAoAKYBQAUABNIBAKAFoARvu0wIpEYf7Q7e1ADoCQNhycd6QElABQA0/Mcfw/z oAd7UAFABTAKQBQAUwCgAoAKACgApAFABQAhNAB05PWgBAMnJoAdTAKACgApAJmmAUALQAhIFACY ycnr6elADqQBQAUAJQAUAFABQAUAFMAoAKACkAUwCgApAJQAUAFMAoAKQBTAKAExg5HT0pAG4UAB 56UALTAKQCUwCgAoAKACkAUAJQAUAFABQAUAFABQAUwDFIBKADmgApgAoAKACkAUwGMmenWgCEgg 80CEoAKACgAoAKACgAoAKACgBKADNAC5oAM0ALmkAUwCgAoATNABmgAoASgAoAKACgAoAKAFoAKA AZzxQBYRsjnrQMdQAtABQAUAFABQAUAFAC0AFABQAd6ACgAoAKACgBaACgAoAKACgBKAFoAKACgA oAKAFoAKACgAoAKACgAoASgBaACgAoAKACgApABoAKYBQAUAFABQAUALQAlABQAtABQAlIBaYBQA UAFACUAFAC0AFABQAUAFABQAUAFABQAlAC0AFABQAUAFABQAlABQAUAAoAKAFoAKACgAoAKACgAo AKQBQAhpgLQAUgCmAUAFABQAUAFABQAUAFABQAUAIOeaQC0AFABQAUAFABTAKACkAUwCgAoAKACg AoAKQCd80AL9aYCDk0gDq+D0FMCOZpASc4XtSAk27XDDuKYC0AIfmJA6dzQAvbA6UAFIApgFABSA KACmAUAFABSAKACmAUgEJoAOByTQAmM8mgBScDJpgGSRwpoAOfagA59aADFAC0AFACZ9OTQAAY9z QAtABQAUAFACUgCgAoAKACmAUgCgApgFIBMigAoAWgBKACmAUAFIBM0AHJpgLSAKYBQAUAFACUAF IAoAKACmAUgCgBKACgAoAKYCUgFzQAUAFABTAKAEpAGaAAe9AC0wEoAKQBQA1lDDmmBCyletAhtA BQAUAFABQAUAFABQA00AFADqAEoAM0AFABmgAzQAlABQAUALQAUAFABQAUAFAC0APEfrQA8ADoKB i0AOBzQAtAC0AFABQAUAFAB2oAWgAoAKAAUAFABQAUAFAC0AFABQAUAJ2oAWgAoAKACgAoAKACgB aACgAoAKAEoAKAFFABQAUAFABQAUAFABQAUAFIApgFABQAUAFABQAUAFABQAUALSAKACmAUgCgAp gFABQAUAFACUALQAUAFACUALQAUAJmkAtMAoAKACgAoASgA6mgAoAWgAoAKACgAoAKACgAoAKACk AgpgLQAUgCmAUAFABSAKYBQAUAFABQAUAIetIBaYBSAKYBQAUAFABSAKYBQAUAFABQAUAFABQAnW kAtABQAUAIOpoAUjcpB70wEU8YPUUgAk52r+PtQAoAAwOlMAoAKQBTAKACkAUAFMApAFABTAKQBT AQmkAn3Rk9aAAc8mgB1MApAFMApAFMAoAKAEJ7CgAAxSAWgAoAKACgAoASgAoAKACgApgFABSAKY EZClgWyW7e1IBRnoNx+tMAGQ2KQDqAFoASgBM4oAOaAFHFMApAFABTAKQBQAUAJTAKQBQAUAFABQ AUAJQAUAFABQAUAJQAtABQAUAFABQAUAFABQAlMApAFABTAQjI5oAhdNvI6UAMoEFABQAUAFABQA UANoAUUALQAlACUALQAtACYoAKAEoAKAFoAKACgAoAKACgCWMcZoGPoAKQBQAdKYDwc0AFAC0AFA BQAUAFAC0AFACUALQAUAFABQAUALQAUAFACUAFAC0AFABQAUAFABQAUAFABQAUAFABQAUALQAUAF ABQAUAFACUALQAUAFABQAUgCmAUAFAB0oAKACgAoAWgAoAKACkAUAJTAWgAoAKACgBKAFoAKACgB KAFoAKACgBO9ABSAKACmAtABQAh9KACgBaACgAoAKACgAoAKACgAoAKAEpALTAKACkAUwCkAUwCg AoAKQBQAUwCgANABQAUAFABSAKYBQAUAFABQAUgCmAUAFABSAKAENAABgUALQAlAC0AIPvEUwFpA ITg8cnv7UwFAxQAUgCmAUAFIAoAKYBSAKYBQAUAFABQAhNIBOnJ60AAGeTTAdQAUgCgApgFABQAU AJ1+nrQAtIAoAKACmAUgCmAUgEoAKYBQAUgCgApgFIApgJjB470gDJ9KYABzk9aQC0AIaAE6/SgB cUAFABQAUAFABQAUAFABQAlABQAUwCkAUAFMApAFACUAFABQAUABoASgBaACgAoAKYBQAUgCgBKA CmAUAFABQAlAETx91oAjoEFABQAUAFACGgBKAFFAC0AJQACgAoAKACgAoAKAEoAWgAoAKACgAoAW gCVT8oxQMdQAUgCgAoAAcUwHigAoAWgAoAKACgBaACgBDQAtABQAUAFABQAUAFABQAUAFAC0AFAB QAUAFABQAUAFABQAUAFABQAUALQAUAFABSAKACmAlAC0gCmAUAHegAoAKACgAoAKACgAoAKAFoAS gAoAKAA+lABQAUALQAlABQAUALQAUAFACCgBaACgAoASgAoAKAD8KACkAUwEFAC0ALQAUAFABQAU AFABQAUAFABSAKYBQAUAFIApgFABQAUAFIAoAKYBQAUAJ3pALTAKACgAoAKACgAoAKACgAoAKACg AoAKAEpAA9aACgBaAEoAWgBCPSmAfN7CkAoAHSmAUAFABQAUgCmAUAFIApgFABQAUAFACE0AJ0G4 9BSAQfNz2oAfTAKACkAUAFMAoAOlIBOv09KAFpgFABSAKACgAoAKACmAUAJSAKACgApgFIApgFIA pgFABQAhPagAA9aQBTAKQBQAUAFABQAUAFABTASkAUAFABQAUwCgApAFABQAlABQAUAFABTASkAU ALQAUwCgApAFMAoAKQCUAFABTAKACgBKAGPHnkdaAIelAgoAKACgBKACgAoAKACgAFABQAUAFABQ AUAJQAtABQAUAFAC0AFAEijC0ALn8KQxcmgAzQAuaAG0AKrYODTAkoAKAFoASgBaACgAoAKAFoAK ACgAoAKACgAoADQAUAFAC0AFABQAUAFABQAUAFABQAUAFABQAtABQAUAFABQAUAJQAtABQAUAFAB igAoAKACgAoAKACgAoAKACgAoAKACkAD1pgFABQAtACUAFABQAtABQAhoAWgApAFABTASgAoAKAC gQUDEPJpALTAKAFoAKACgAoAKACgAoAKACgBB60ALQAUAFABQAUAFIApgFABSAKYBQAUAIaQC0AF MAoAKACgAoAKQBTAKACgAoAKAEoAKBBQMOpoAWkAlMBaQBQAUAFABTAKACgAoAKACgAoAKACgAoA KACgAoAKQCDn6UANI3tg/dHWgB/bFMApAGaAEzTAKQC0wDIHWgBAM8mkAtMAoAKACkAUAFABQAUw CkAUwEpAFABQAUAFMApAFABQAUwE6/SkAAYoAWmAUgCmAlIANABQAUAFABQAUAJQAUAFABQAUwCk AUAFABQAlABQAUAFABQAUAJQAUALQAUAFABTAKQBQAlABTAKACgApAFACUwGugb60AQlcUCExQAU AJQAUAFABQAUAFABQAUAFABQAUAJQAtABQAUAFAC0APRM9aAJOooGJjigQ3ae1AxwB70AB+lIBKA E/iFADwfemA+gAoAO9AC0AFABQAUAFABQAtIBKYC0AFABQAUAFABQAtABQAUAFABQAUAFABQAUAF ABQAUgCmAtABQAUAFACUAAoAWgAoAKACgAoAKACgBBQAtABQAUAFABQAUAFABSADzxQAUwCgApAF MAoAKAFoAKAEpAA9aAFpgFABQAUgEpgFABQAUAFACCgBaAFoAKACgApAFMAoAKACgAoAQ88UALQA UAFABQAUAFABQAUAFABQAUgCgApgIPWgBaACgAoAKACgAoAKACgAoAKACgBKACgQUAB4pDAcUwCg AoAWgAoAKACgAoAKACgAoAKQBQAUAFABTAKACgAoAKAE6/SkANnGAcUAKOOKYDfmz1wKAFAx70AA GOlAC0gCmAE45pAIAep6/wAqYC0gCmAUAFABSAKACmAUAFIAoASmAjNjgUAJk4zzmkA4GmAUgCgA oAKAEJxQAYz1oAWgApgFABSAKAEoAD0oAD0NACDJGTwaAAHNMBaACkAlABQAUAFABQAUwCgApAFA CUAFABQAUAFAARQAgoAKADNAC0AFABQAlABQAUAFABTAKQBQAUAFMBKQDWXcPemBEQQeaACkAYFA hNtMBMGgAxQAlABQAUAFABQAUAJQAUALQAUAFABQAvSgCWM8UDH5oAKACgApAJQA2gBCcGgA3A9q YD1bPFAD6ACgBaACgAoAKACgAoAKACgA70ALQAUAHegAoAKACgBaACgAoAKACgAoAKACgAoAKACg ApAFMAoAKAFoAQ0ALQAUAFABQAnegBaACgBDSAWmAUAFABQAUAFIApgFABQACgAoAKACgAoAKACg AoAKAA0gCmAtABQAUAFABQAlABQAUgE6mgBaYBQAtABQAUAHegAoAKACgAoAKQCCgBaYBQAUAFAB SAKYBSAKYBQAUAFIApgIfSkAtMApAFMApAFABQAUwCkAUwCgAoAKACgBKADpQAg9aAFoAMUALQAU gCmAUAFABQAUgCgApgFIApgFIApgJmgAoAKACgAPoKQB0IXvQAuMCmAUAFIAoAKACmAdKAEGeppA LTAKACkAUAFABTAKACgAoAKQBQAUwGbgCdoLHPT0oAG3cZP4UgHUAFABQAUAIT6UAAFAC0AFMApA FMApAJQAUAFACA9j3pgIilcjtnikAp6j1pgLQAlABSAKACgAyKACgAoAKACgAoASgAoAKACgAoAK AExQAlABQAoNABQAUAFABQAUAFABQAUAFABQAlMApAFMBGGaAIiOeaQBigBOaADNABQIQ4oATFMA xQAlACUAFABQAUALQAUAFABQAUAPjPUUAPBpDFJpgJzQA4L6mgAZgo4pAMByM0AIaBCjGKYBxQMe rZ4oAfQAtABQAUAFABQAUAFABQACgBaACgAoAKACgAoAKACgBaACgAoAKACgBKAFoASgBaACgAoA KACgAoAO9ABQAtABQAUAFABQAUAJ3oAWgAoAKACgAoAKACgAoAKACgAoAKACkAUwCgAoAKACgApA FMBaAEoAKACgApAFADQSx3dF6AetMBx4pAIOKYC0ALQAUAFACE4oABQAtABQAUgCgBOpoAWmAUgC mAUAFABSAKACgApgFABSAKACmAgpALTAKACkAUAFMApAFABTAKQBQAUwCgAoASgBDycUgFpgAoAW gAoAKAA57UAJ+NAC0gCmAUAFABQAmfagAzQAUAFAgoGFAgoGBOKAGu3lpkfeNIBio5OSce9MCQIB 6n60AOxSAKACmAUAB4oAQc8mgBaACgApAFMApAFABQAUwCgApAFMAoAKAGjcoxjPvQAAc5JyaQC0 AFMApAJ1oAUDFABQAUAFABQAUAJQAUwCkAUAFMBMUgDFAC0AJQAUAB6UAHfFABj2pgJ06c0ALSAK ACgAoASgAoAKACgAoAO9ABQAhoATFABQAo5oAWgAoAKAEoAKACgAoAKACgAoASgAoADwKAGsu4cU wI+lABmkAUAJxQIQ0AJTAKACgBKAEoAKACgBaACgBaACgBKAFU4IoAlI4yKAEFAyRRjk0ANZsUhE ROaAHL0oADQACgBaBgeBmmA9G3AetAD6AFoAKACgAoAKACgAoAKAFoAKAEoAWgAoAKACgAoAKAFo AKACgAoASgBaAEoAWgAoAKACgAoAKAAUAFABQAUAFAC0AFIBDQADpTAWgAoAKACgAoAKACgAoAKA CkAUwCgAoAKQBTAKACgAoAKACgAoAKQBQAUAAoAYcycA4QdT60APoATqaAFpgLQAUAFABSAQc8n8 KAFpgFABQAUAIelAABgUALQAUAFABSAKYBSAKYBQAUAFABQAUgEPpQAtMAoAKACgApAFMAoAKQBQ AUwCgAoAKACgBCcCkAD19aAFpgFABSATHrTAWgApAFMAoAKQBTADQAlABQAUCCgAoGFABQAdqAAe p6CgBq/OdxGAOgpAPpgFABQAUAFACHpQAD1NAC0AFABSAKACgApgFIApgFIApgFIApgFABSASgAo AKACgBOtACjigAoAKACgAoAKACgBKACmAUgCgBKACgAzQAtABQAlAAe1MBG+8vOKQC0AIeCD2PFM A6MRSAWgBKADNABmgAoAKACgBKACgBaACmAUgENMBo60gHUAFABQAUAFABQAUAFMApAFABQAlABT Aj5QnH3aAFYBxkdaAIuRQIM0AGaAA0AJQAUAFABQAlACUAFAC0AFABQAtACUAFAEqH5aAFUc0DHH 1pCIT1NABTAUZ7UALz3pAIOtADqBjW64oEOzjpTGSq2RQAtABQAUALQAUAFABQADpQAUAFABQAUA LQAUgCmAUAFABQAUALQAUAJQAUAAoAWkAUwCgAoAKAA0AFABQAUAFAB3oAWgBKACkAtMBKAFoAKA CgAoAKACgAoAKACgAoAKQBTAKQBTAKACgAoAKACgANIAoAKACgBrZf5QcL3NACnCL04HQUAA4Xnq eaAFHSmAUAFAC0AFACHk4oAWgAoAKACgAoAb1NADqACgAoAKACgAoAKACgAoAKQBQAUwCkAg9aAF oAKACmAUAFABQAUAFIApgFABQAUgCmAUAN6t7UgFoAKAFpgFIAoAKACmAUAFIApgFACd6ACgAoEF AwoEFAwoAKADqcUgDOTgc460AKOlMAoAKAEZgoyfyoATLEdMfWgAPHXk0gFA5yetMBaQBTAKACgA oAKQBTAKACgApAFABQAUAFABQAlABQAUAJ1NAC0wCkAUAFABTAKACkAlABQAUAFAAelACHjBoAGz xtoAWgBvvQAvWgApgFIBpHzKewoAdmgBGG4DPGDmgBMguSPpQAtABQAUAFABQAUAFACUAFAC0AFA BQAUwGnrSAKAFoAKACgAoAKACgApgFIAoAKAEoAKACmAzbjkUANYBhnoaAI6BB3oAU9aAEoAKACg AoAKAEoAKACgAoAKACgAoAKAJYxxQA8cCgY0nJxSAjI5oEFMBRSACx6UAApgOpANHJJoAWgYoODk UwJVbIoAWgBaACgAoAKAEoAWgAoAKACgAoAWgAoAKACgAoAKACgAoAKACgANAC0AFABQAUAFABQA negBaACgAoAKACgAoAKAAdaAFoASgBaACgAoAKACgAoAKACgAoAKACkAUwCgAoAKACgApAFMAoAK ACgApANPzcL07mgB3AHoBQA0fMdx6dhQAvU0wFoAKACgAoAKQAP50wFoAKACgAoAQ9KQAKAFoAKA CgApgFABSAKYBQAUAFIAoAKYCHnigBaACgApAFMApAFMApAFMAoAKACgApAFABQAhoABwPrQAUAF ABQAUAAoAWgAoAKACgAoAKYBQAUAJQIKACgAoGFAAelIBrZ24HU0AOUBRgUwFpAFABQAUAITigAH 1oAWgAoAKACmAUgCgApgFABSAKACmAUAFIAoAKAEoAKYBSATrQAtABQAUwCkAUAFMAoAKQCUwCgA pAFABTAO1ADVGBt9KQCj0oAOjfWgBDwc+tAC0AFACZoAQg9uKYCbOeTmkA4AAYFABQAUAFABQAUA FABQAlABQAtABQAUAFADTQAUAAoAdQAlABTAKACkAUAFABQAlABQAUAFABTAaVzz3oAjcd+/egBl AC0hhxQAYoFYTFMLCUCFoAKACgBKACgAoAKACgBaAJV+6KBimkA3vQA00CCmAUgFxQAUABOBQADg UAFAwoAUHFMCRTmgB1AC0AFABSATtTAWgAoAKACgAoAKAFoAKACgAoAKACgAoAKACgANAC0AFABQ AUAFABQAgoAWgAoAKACgAoAKACgAHSgAoAWgAoAKACgAoAKACgAoAKACgAoAKACkAUwCgApAFMAo AKACgAoAKQCcnigBeg9qAG/e+n86AHE0AIKYC0CCgYUAFAAelIApgFAC0gCmAUAN6mkA6mAUgCgA oAKYBSAKACmAUAFABSAKYBSAQetAC0AFMApAFMApAFABTAKACgApAFABQAUwCgBvU0gHdaAEoAWg AoATFAC0wCgAoAKACgApAFABQAUwEoAKBBQAUDCgBO+aAFHrQAtABSAKACmAhOKQAB3NMBaACkAU AFABTAKQBQAUwCkAUAFABTAKACkAUAFACUwCkAnWgBaACgAoAKYBQAUAFABSAKAEoAKACgAoAKAE 70AI3BDfnTAVuBuHakAjEbA3uMUAEn3fxoAUnFACcmgAoAKACgAoAWgBKYBQAUgCgAoAKAEoAKAC gBaACgAoASgBKAFoAKACgAoAKYBSAKAEoAKADNABQAUAFABQAUwGsM896AImGKACkUJigAoEHNAB kd6ADA7UCsJimFhaQhtMAoAWgAoAKACgCbOAKAG5zSGB6UCG0AFAC0AFAxaBDTywFMB1IYlAgoAK AFBwaYyRWzQA6gAoAKADtQAtABQAUAFABQAUAFABQAtABQAUAFABQAUAFAB3oAKACgAoAWgAoAKA EHSgBaACgAoAKACgAoAQ9RSAWmAUAFABQAtABSAKYBQAUAFABQAUAFABQAUAFABQAUgCmAUAFABQ AUAFABSAaTuO0HgdaAHUAIfSgBaYBQAlAC0gCmAHsKACgAoAKAFoASkACmAtABQAUAFABSAKACgA oAKYBQAUAFACH0pALQAUwCgApAFABTAKACgAoAKQBTAKQBQAUAIxoAMcUAApgLQAUgCmAUgCgApg FABQAUAFABQAUgCgAoAKYCUAFACc0gFHP0pgLQAUAFABSAOlMBOvNIBaYBQAUAFIAoAKACgApgFA BSAKACgAoAKACgApgFACUAJ1NIBaACgAoAKACgAoAKACgAoASgAoAKACgAoAKAAigBM9iOKYCR5A KscjoPpSAT5VQL1xzQAct14FAC0AFABQAtABQAlABTAKQBQAUAFABQAUAFMBKQBQAUAGaAFoASgB KACgAzQAZoAKAFoASgAoAKACgAoAKACgAoAKACgBKYCMuaAIiMGkUJQAUAFABQIMUBYKADJoASmS JQAtABQAUAFAEhGKACkAhoAaKAFoAWgAoGLQIRR3oAWgYUAFAgoGJQAo4pgSK2aAHUAFABQAtABQ AlAB1oATrx2oAdQAUAFAC0AFABQAUgCgApgFAAKACgAoAKACgBaQCGmAtABQAUAGaACgBKAFoAQd aAFoAKACgAoAKACgAoAWgBKAFoAKACgApAFMAoAKACgAoAKACgAoAKACkAUwGk5+VT9TSAUDAwKA EX5n3fwjgUAA5JNMB1ABQAUAFABQAfxD2oAKACgAoAWgBp5NIBaYC0AJQAtABSAKYBQAlAC0AFIA oAKACgBo65oAdTAKACgAoAKACkAUAFABQAUAFABTAKACgBvfJpAKOaADFMBaACgApAFABQAUAFMA pAFABQAUAFMAoAKAEoAKACkAz5s9eTQA7B7tTAXFAC0AFAB0oAQcnJ/CgBaQBQAUAFABQAUAFABT AKQBTAKQBQAUAFMApAFABTASgBOpxSAUcUAFMAoAKQBQAUAFMAoAKQBQAlABQAUAFABTAKACgAoA aeeBSAAAKAFoASgAFAC0AJQAUAFABQAUwCkAUAFABQAUAFACGgBKAFoAO9ABQAUAJQAUAFABQAtA BQAUAJQAUwCkAUAFABQAUAFABQAUAJQA11yPemMipAORd1AwKjPWgQ0qRQFhOaAFoGFACUyAoAKA CgAoAKAJTQMSgBD0pCI80wHBqAFDCgB2RSGIx4wKBDhgACmMOKQBxQAUAGKADFABQAUwHq2aAHUA HagAoAWgAoAQDFACZ2tjtQAtAhaBhQAUALQAUAFABQAUAFIAFMAoAKACgApAFMA70ALQAUAJQAg5 oAWgAoAKAAUALQAUAFABQAUAFABQAdqAAdKAFoAKACgAoAKACgAoAKACgAoAKACgAoAKAEJPQdaQ AowMUAI3zHaPxoAVuAAOBQACmAtACUALQAUgCmAg7n1oAWgApAFMApAIPWmAtABQAUAFIApgFIAo AKACgBaAEpgLQAhpALQAUwCkAUwCkAUAFMAoAKACgApAFMApAFADWPFABjjFAC0ALTAKACgAoAKA CkAUAFMApAFABQAUwCgAoAKACkAlACMcD2FAABzuPWgB1ABTAKACkA3qeaAHUAFABQAUAFMAoAKA CgAoAKQBTAKQBQAUwCkAUAFACUAJ7CgBQMUALTASgApAFMApAFABQAUAFMBKACkAUAFMApAFMApA ITigBOtAC0AFACUALTAKQCUAFABQAUAFMAoAKQBQAUAFABQAUAFACUAFABQAUAFACGgBKAFoAWgA oAKAEoAKACgAoAKACgAoAKACgBKACgAoAKAI3XvQNCx96AY3uaYhAaBDuo5pDuBXjNA7jKBiUyAo AKACgAoAco5oAdQMKQhjUwG0AFABQAtABQAZNABk0AGTQAbjQAbjQAbjQAZNABk+tABk0ATJJng9 aBklABQAUALQAlABigAAA6UALQAUAFABQAUALQAUAJQAUALQAUAFABQAUAFAB3oAKACkAdKYB9KA CgAoAD0oAWgAoAKQBTAKACgAoAKAA0AFIApgLQAUAFABQAUgCmAUAFABQAUAFABQAlIAAoACcfWg AAwP50AJ/FQAtMAoAXFABSAKAEPJwOnc0wFoAKQBTAKAA0AFABSAKACgAoAKYBSAKACmAUgCgAoA WgBB1oAKYBQAtIBKACgBaACgAoAKYBQAUAFABQAUAM6mkA6gBKYC0ALQAUgCgAoAKYBSAKYBQAUg CgAoAKYBQAUAIaAEz8xHoOaQAOW56UAOpgFABQAhOKADGetAC0AFABSAKACgApgFABQAUAFABSAK ACmAUAFABSAKAEoAQmgBQMUALQAlMBaACgBKACkAUwCkAUwCgBKQBQAUwCkAUAFACE9hQAY/OgAo AKACgAoAKYBSAKACgBKACgAoAKACgAoAKACgAoAKYBSASgBKAFoAKACgAoASgAoAKAFoAKAEoAKA CgAoAKACgAoAKACgAoASgBKAFoATGRimBFuKEigLihxSAAAe9AC44oAc3CUDRFQMbTIFoAKACgAo AUEigBwOaAFpAMagBtMAoAKAFoAKAEoAKACgAoAKACgAoAKACgAoAljk7NQMmoAKACgAoAKAFoAK ACgAoAKACgAoAKACgAoAKAFoAKACkAUwCgAFABQAUAFACDqaAFoAKACgBaACkAUwCgApAFABTAKA CgAoAKACkAUwCgAoAWgAoAKACgAoAKACgAoASkApIAyaAGrz8x70AOoAaOSTTAWgBaACgAoARjgc dTQAAYGKAFoAKACgAoATvSAWmAUAFIApgFIAoAKACgAoAKYBQAUAB6UgAcCmAUAFABSAWmAlIAoA WmAUAFABSAKACgAoAQnAoAQdM+tAC0AFMApALQAUAFMAoAKACgAoAKACkAUAFABQAUAFMBOlADFB Bx68mkA8HPSmAtABQAmaACkAtABQAUwCkAUwCgApAFMApAFMAoAKQBQAUAFABQAlMApABoAQetAD qYBSAKYCUgCgAoAKACmAUgCgAoASgAoAKACgAoAQnPSgAAxQAUAFABQAUAFABQAUAFACUwCkAUAF ABQAUAGaACgAoAKACgAoAQ0AJQAUALQAUAFACUAFABQAtABQAlABQAUAFABQAYoAKAEoAMUAFABT ASkAtACUwGOoJzQBGVoEJgigBQxFA7jt+RikFxM0DuNpki0AFABQAUAFACg4oAXdQA0nNACUAFAB QAooAKAEoAKACgAoAKACgAoAKACgAxQAuDQBIjFeD0oAlBB6UDFoAKACgBaACgAoAKACgAoAKACg AoAO1ABQAtABQAUAFABQACgAoADQA3bltx/KgB1ABSAKYCd6AHUAFABQAUAFABQAUAFABQAUAFAB QAUAFABQAUAFABQAtABQAUAFABQAUgGffb/ZX9aAH0AMcn7o6n9KAHDAFMBaACgAoAKAE6ufYUgF pgFABSAKACgBBQAtMAoAKACgAoAKQBTAKQBQAUAFABTATqaQC0AFMAoAKQBQAUwCkAUAFABTAWkA UwCgApANbk4oAWgAxQAUwCgBaACgApAFMAoAKACgAoAKACgApAFABQAUwGmkADpTANoJzQAY460g FwKYC0AFIAoAKYBSAKACgApgFABQAUAFABSAKYBSAKACmAlABQAdBQAg5+lIBaAFoASmAUAFIApg FIApgFIAoAKACgBKACmAUgCgBOtAB0oAWgBKACgBKAFoAKACmAUgEoAKACgBKAFoATNABzQAuKAC gApgFIAoAKACgBKAEoAKAFoAKAEoAKACgAoAKACgApgFIAoAKACgAoAKACgBKACgBKACgAoARulM BmaQBTAQgUCEK0AN2mgAoAWgAoAWgAoAKACgAoAbigBaAEoAKAHEYFABk0AGaADNABn2oAMj0oAM j0oAMj0oAM+1ABmgAzQAmTQAZoAKAHKxU0ATKwYcUDFoAWgAoAWgAoAKACgAoAKACgAoAKACgBaA CgAoAKACgBBQAtABQAUAFABSAKYCetIBaYBQAUALQAUAFABQAGgApAFMAoAKACgAoAKACgAoAKAC gBaACgAoAKQDHy3yj8TQA4DAwKABm2jP5UANC469T1oAdTAWgAoAKQBTARerfWgBaACkAUwCgBDS AWgApgFABQAUAFIAoAKYBSAKYBQAUAFIBB60ALQAUAFMAoAKQBQAUAFMApAFABQAUALTASkAg9aA FpgFABQAYoAKACgBaACgApAFACUALQAUAFABQAUAFMBDSATqaAFoABTAKQC0wCgApAFMApAFABTA KQBQAUwCkAUAFABQAUAFABTAKQCUAFMBOppAKKAFpgFIApgJQAUAFIAoAKACmAUgCgBKACgApgFI BKADpQACgAoAKYBSAKACgAoAKAEoAKACgAoATNABQAtABQAUAFABQAUAJQAUAFAAaAEoAKACgAoA KACgAoAKACgAoAKACmAUgCgAoAKACgAoASgAoASgANABQAjfdNMCGgQZoAXdSAXNAxcigCOmIWgA oAKAFoAWgBKACgAxQAUAJigBQMUAIaACgAoAKACgAoAKACgAoAKACgAoAKACgAxQAoyDQBMrZ+tA x1AC0AFAC0AFABQAUAFABQAUABoAKACgAoAKACgAoAKAFoAKACkAUwCgAzQAgpALQACmAtABSAKA CgApgIe1AC0AFABSAKACmAUAFABQAUAFABQAUAFABQAUgDGKYBSAQctuP4UAC8kmmAo4oAWgApAF ABQA1e/1pgOoAKACgAoATvQAtIAoAKACgAoAKACmAUgCmAUgCgAoADQAUAFABQAUAFMAoAKQBQAU AFABQAUAFMBaQDWoAUUwCkAUwCgAoAKAEoAWkAUALTAKQBQAlABQAUAFABQAUwA0gEHSgBaAAUwC gApAFMBaQBTAKAEoAKQC0AFABTAKQBQAUAFACUALQAUAFACUwENIBQMUALQAUAJTAWgApAJQAUAF ABTAKACkAlABQAtACUAJ1oAKACgAzQACgAoAKYBSAKACgAoASgAoASgAoAWgAoAKACgAoAKAEoAK ACgAoAKACgBKACgAoAKACgYlABQIKAFoAKACgAoAKACgAoAKACgBKACgAoAaTQAgOc0AKOlACHoa YENAgoAKACgAoAKAFoAKAFoAKACgBaACgBR0oATFIAxTATpQACgAoAOKADigAwKADAoAMCgAwKAD AoAOKQBxTAOPSgAoAM0gCmAUAFAEqv2NAx+aAFoAKAFoAKACgAoAKACgApAFMAoAKACgAoAKBBQM WgAoAKQBTAKAENIAFMBaACgBaACgApAFABTATvQAtABQAUAFABQAUAFIAoAKYBQAUAFABQAUAFIA oAQ/Mdv50AK3SgAHSmAtIAoAKACmAUgGr9360wHUAFIApgFACCkAtMAoAKACkAUwCgApAFMApAFM AoAKQCd6YC0AFABQAUgCgApgFIAoAKACgApgFABSAKAE6mgBaACmAUAFABSAKYBQAUgCmAUAFIAo AKACgAoAKACgAoAQ8nFABTAWgAoAKACgAoAKQBTAWgAoAKQBQAlABQAtMApAFABTAKQBTAKQBQAh NACAUALQAtABQAUAJTAKACkAUAFABQAUAFACUALQAlACdaACgAoAKACgAFABQAUwCkAUAFABQAlA CUALQAUAFABTAKACkAUAFACUAFABQAUAFABQAhoAM0AFABQAhoGFACUCFFAB3oAWgAoAKACgAoAS gAoAKAEJoATNACE0wEzQIRePqaQDqBiN900wIc0CDNAC5oAKACgBaACgAoAWgBaADFABQAUAKKAC kAUAIfSgBaAEoAMUAGKADFABigAxQAYoAMUAGKADFABigAoAMUAFMApAFABQA5Xx16UxkoIPSgBa ACgBaACgAoAKQBTAKQBTAKACgAoAKACgAoAWgAoAKACgAoAQ0gFpgFABQAUALSAKYBQAUAFIA6UA JuFMAyfSgAyfSgAzQAtIApgFACUgFoAQnAyaAEG7dk8DsKAHUAFMApAITgcdTQAoGBQAhoAWmAtI ApgFABSAax/hHXv7UwF6CgBaACkAUAIelAC0wCgAoAKQBTAKACkAUwCkAUAFABTAKAEFIBaACgAo AKACgApgFABQAUgCmAUAFIAoADwKAEUcUALTAKQBTAKQBQAUwCgApAFABQAUAFABQAUAFMApAFMA oAQetIBaYCUALSAKACmAUgCgAoAWgApgFIBKACgApgFIBaAEoAKACgAoAKYBQAnWkAo6UwCkAtAC UAFABQAUAFABQAUAFABQAUwEpAFMBOp9qQC0AFABQAUAJQAUAFABQAUAFABQAlMApAFABQAUAFAB QAUAFMBKQBQAUwCkAUAFABQAUABoAbQAUAFAC0DEoEB60AFABQAUAFABQAUAFABmgBM0AJmgANAD M84piAHtQAg60AOJFACZpDGs2eKYhlABQAUAFABmgB1ABQAUALQAtABQAUAFACjrQAtIYh4FAhFH emAtIYUCCgAoAKACgAoAKACgAoAKBhQISgAoAKACgAoAKACmAoYigCVWDCgY6gAoAWkAUwCgAoAK ACgAoAKAEJwM0ALQAUAFAC0AFABQAUAFACHtQAtABQAUAFIAoAWmAUgEJwOaYByfagAwPSgApAHe gBaYCDpQAdOlAC0gCgBB0oAOnPagBAMnce3SgB1ADSxztXr/ACoAVRtXGc+9AC0AIPWgBaAE/ioA WmAUAFABSARssdoOB3oAAABgUwFoAKAFoAKAEoAWgApAFABQAUwCgAoAKACkAUAFABTAQ0gFpgFI AoAKACgApgFIAoAKACgAoAKACgApgIfSkAtMApAFABQAUAFABQAUAFABQAUAFMApAFABTAKACkAU AIaACgBaYBQAUAFIApgFIAoAKACgAoAKACgAoAWgAoAKACgAoAKACmAlACE0gFA4oAKYC0gCgBKA CgAoAKACgAoAKACgAoAKAEoATrQAtACUAA6UALQAlABQAZoAKACgAoASmAUgCgAoAKACgAoAKACg AoAKAEoAKACgAoAKACgAoAKACgBtABQAUAFABQAGgBKADNABnjNAC0AJQAUAFACZoAM0AJmgBM0A JxTATIHSgQhNACZoAC2elADaACgBxAxQA2gAoAKAH0AFABQAUAFABQAUALQAvvQAtIBv3j7UwHUg EoAKBhQAUCCgAoAKACgAoAKBhQIKACgBKACgAoAKACmAUAFIABwc0wJVfP1oGPoAKACgBaACgAoA KAEoAWgA68UANQ8Y9OKAF70ALQAtABQAUAFABSAQ9aACmAooAKACgAoAKACkAmeQe2cUAKaYC0AI OppAHcUwFpAIO/1pgBoAXpQAh+7SABwKADr9KADnPbFACMxztX7xoAFG0e9ADqAGnk47d6AHUANB 3En+HtQAq+tMBaACgAoAKAEXq31pALTAKQBQAUALQAlAC0wCgApAFABTAKACgAoAKQBQAUAFACDr QAtMAoAKQBQAUwCgApAFABQAd8d6YBSAKACmAUgEHUmgBaYBSAKACgAoAKACgApgFIAoAKYBSAKA CgAoAKACgApgIOTSAKYC0AFABSAKACgAoAKACgAoAKACmAUAFIBaACgApgFIAoAKACgBDQA3qaAH UALTASgApAFMApAFABQAUAFABQAUAFMApANPXFAC0AFABQAlABmgApgJikAUAHagApgGaQBQAUAF ABQAUAFABQAlAC0wCkAUAFABQAlABQAUAFABQAUAFADT1oAKACgAoAOlABQAlACUAN3fLQA4dKAE Ldu9MBN1IAzQAmTQAE0CE3UwCkAYpgGKAGlaAEwRQAlABQAUAFABQAUAFAD6ACgAoAKACgAoAKAC gBRQAdetADqACkMKBCUAFABQMKBBQAUAFABQAUAFABQAUAFACUAFABQAUAFABTASkACmBIr+tAyT NAC0AFAC0AFABQAUAFABQA0cSH3FAC96AFoAKAFoAKACkAUwE/ioAKAFoAKQBTAKACgAIyMUAB5G KAE7c/nQA6gBP4vwoAD1BoAWgBBzn60ADfdJpAHWmAnUAe9IBaYBSACccd6AEVcEk8k0AKTgEmgA zhQSOT2oAAMD3oAQ/Mdv50AKfunHSgAHAoAWgApgFABSAQfeP0pgLQAUAFABQAGkADpQAUwCkAtM AoAKACkAUwCgAoAKACkAh6UAAoAWmAUAFABQAUgCgAoAKYDSSeFxnufSkAeWoYMM7h3pgOpAFABQ Ah4FAAOlAC0AFABQAUwCgApAFMAoAKQBQAUAFABTAKACgApAFMBCeKQAOlAC0wCgApAFABTAKACk AUAFABQAUAFABQAUwCkAUwCgBaQBTASkAUANPWgBQKAFoAWgBKYBSAKYBQAUAFIApgFIApgFIAoA Q0AIKAFoAKACgBKAE5oAWgAoASgA6UAJ1oAXpQAUAFABQAUAFACUwCkAtABQAUwEpAFABQAUAFMA pAFABQAmaACgBDQAlABQAUALQAlACZoAQng0AMUcZNMQpagBMigBN1ABk0AJyaAHBaAFwKQC0AFA woAKAEpgIVBoEIUoAaVIoASgAoAKACgB9ABQAUAFABQAUAFABQAq9aAA8HNIBc0AFABQAUDCgAoA KBBQMKBBQAUAFABQAUAFABQAlABQAUAFABQAUwEoAKAFoAVXx9KBkwORxQAtABQAUALQAUAFADCx VjnketAAx4DDsaAHd6AFoAKAFpAFMAoAKAE70AFAC0AFABQAUAFABQAUAFACDpQAvegANAC0AJQA HkEUAGPSgBhbp7UgHqcjimAMcDmkA1V53HrQA+gBo+Y7j0HSgBe+aAFPA460AIo2jFACHtQA6mAU AFABQAUAIpzk9ulAC0AFIApgFACHtQAtABQAUAFABSAWgAoAKYBSAKYBSAKYCGkADpTAWkAUwCkA UwCgApAFACMcD3PSmAh+Tyx6nBpAOpgFABQAUgGnk4oAdTAKQBQAUAFABQAUAFMApAFABQAUAFAB QAUwCgAoAKQDf4sUAOoAKYBQAUgCmAUAFABSAKACgAoAKACgAoAKACgAoAKYBQAtACE4pAITQAD1 oAWgApgLSASmAUgCgAoAKYBSAKACgAoAKAEPFACCgBaACgAoAKAEoAKACgAoASgBOv0oAWgAoAKA CgAoAKAEoAOlAC0AFABTAKQCUALQAlABQAUAFACZoAKAEzQAUAIaACgAoAKADNADSaAEzQA0tTEN LE0AFABQADk0AIcg0ASL0FIBaACgYUAFMAoASkAUCCgYtAgpjEwKBDSooAaVoASgB9ABQAUALQAU AFABQAUAA60AONIBuMUALTAKQBQAUDCgAoEFABQAUAFABQAUAFABQAUAFABQAUAJQAUAFMBKACgB aQDaYDlYqaAJlYMOKBjqAA0AFAC0AFACdaAI3XbwvU9qAHR9KAH0AFABQAtABQAUgEHU0wCgBaAC gApAFMAoAKACgAoAO5pAGKYB0pAGaAFpgFABQBG4BIz64pAKvyMwPQUACjcdxoAfigBrcnb270AO 9qADtQAg55oAWgBv8VADqYBQAUAITjp1pAJtz1OaAHUwCgAoAKACkAnVqAFpgFABQAUAFABSAKAF oASmAtIAoAKYCdTSAWgApgFABSAKYBSAKYB0pAIOfmPfpQA2X/VZ9CDQBIetMBKQBTAKQDV6k0AO pgFIApgFIAoAKACgAoAKACgApgFIApgFABSAKACgAoAavrQA6gApgFIApgFABQAUgCgApgFIAoAK ACgAoAKACgAoAKACgApgGc0gGnrQA4CgApgFABQAUgCgAoAKACgAoAKYBSAKAEoATqc0ALQAUAFA CUAFABQAUAFACUAJ1NAC0AFABQAUAFACE4oAAM0ALQAUAFABQAUAFABQAlMApAFACZoAKACgBpbF MBMc5NIAZsYoAKAAnFACZ70AGaAEJoAaWFMQ0kmgAoAUDNACNxQA2gBQcGgAJyaAJB0FIBaYwoAK QgoGFABQIKBhQISgYtACUCENACGmA2gB9ABQAUAFABQAUAFABQACgB1IAoGJigAoEFABQMKBBQAU AFAwoEFABQAUAFABQAUAFABQMKBCUAFMAoASgAoAWgBMUAGKAFHByKAJlbNAx1ABQAUALQA1t3ag BEXByeTQAo4JoAdQAUAFABQAUALQAg70AFAC0AFABQAUAFIAoAKYBQAUAFABQAYoAKACkAZoAYAW cE9BzQA8gE5NABQAjHA96AFAwPegBaAGt8zbfxJoAd9KAEx70AIvUmgB1MAoAKAE/iP0oAWgAoAK ACkAUAFMBB3oAWgAoAKQBTAKACkAUAFMAoAWgAoASkADuaAFoAKACmAUgCgAoAKAG5DHHYdaAHUw Gv8A6tqQAoOS56kY/CgB1ABTAQnApAA4AFAC0AFABQAUwCkAUAFABQAUAFABQAUAFMApAFABQAUA I3TFABQAtABQAUAFMAoAKACkAUAFMApAFABTAKQBQAUAFMApAFABQAUAHQfWgBF9aAFoAKACgAoA KACmAUgCgAoAKACgBKACgBDzwKAFoATrQAZoAKADFABQAUAFACUAJ1+lAC0AFABQAUAFACE4oAAM 8mgBaACgAoAKACmAlABQAUAFIBKACgAoATNADWOBmmAdRQA1eppAD84pgAPFIBPrQAFgKBDSxpgJ QAYoAcFoAUDFAC0DI360CG0AFAAKAJe1AC0DCgBKQgoAWgAoGFABQAUAJQIKYxD1oEIaAG0APoAK ACgAoAKAEoAKAFoAKAHUhhQAUAFABQAUAFAhKACgYUAFAgoAKACgAoAKACgApgFIBKACgApgFABQ AUAFACUALQAUAFAEivng0DJBQAUAFAC0AJQAd6AFoAKACgAoAKACgBBSAdTAKACgAoAKACgAoAKA CgAoAKACgApAFABTAD0NIAHSgAoAKAEHJ3H8KAFoACcDJoARRgc96AHUAMc/wjqRn8KAFXpQA6mA UgCmAnQ0ALQAUAFIApgFAAelIAHSgApgFABQAUAFABQAUAFABQAUgCgAPSgAHSmAtABQAUgEoAWg AoAQnA9+goAAMDFAC0wI2+cDPTPApASGmAUgCgBp5OKAFoAWmAUgCmAUgCgAoAKYBQAUAFIAoAKA CmAUAFABQAUgG9W+lAC0wFpAFABQAUwCgAoAKACgApAFABQAUAFABQAUAFABQAUwCkAnXigBDycU AO7UAFABQAUAFMApAFABQAUwCgAoAKQBTAQnikAgHegAoAWgAoASgAoAKACgAoAb3wKAF4FABQAU AFACUAHSgAA7mgBaACgAoASmAUAFIAoAKAEoAM0AFACZpgIWweaAGq3J9KAEY54oAM0gEzQA0tz6 0xCFjQAmaACgAAzQA8LQAvSkAtMYUAFAiNutADaACgBR1oAlpAFAwpgFIQUwEpDCmIKQBTAKQwpg FACDvQIaaAEoAfQAUAFABQAUAFABQAUALQA6kAlABQMKACgAoAKAEoAKBBQAUAFABQMKBBQAUAFA BQAUAJQAUAFABTAKACgAoAQ9aACgBaACkAUwHq+OD0oGSg0AFAC0AFACd6QBTAWgAoAKACgAoAQU ALQAtABSAKYBSAKYBQAUAFABSAKYBSAKYBQAUAIelIBaYBSAQ8nHYdaAFoAWgBv3m9hQAtABnAye goAYAeXPfoKAHjpTAWgAoAKQCHpQAo5FABQAUwCkAUAIaAFpgFABSAKYBQAUAFABQAUAFIApgFAC GkAtMAoAWgApAJTAKQC0ANHzHPYcCgB1MBv3jjsKABv4QPWkA6mAUAFIBo+8TQAtAC0AFABTAKAC kAUAFABTAKQBQAUAFABTAKQBQAUAHSgBo6fWgB1MAoAKQBQAUAFABTAKQBQAUwCgBKAFoAKACgAo AKQBQAUAFMBOgoARepNIB1MAoAKQBTAM0AGaAEzQAtIAoAKACgBKACgBOtAB1oAWgAoASgAoAKAC gAoAQnigAAwKACgAoAKACgBKAAepoAKAFoASgAoAKACgAoAKAEoARjigBCedo9OaADouKYDQQBQA 0/MaBBkKKQDd3oKYCbjQAlABQAuKADaaAHBRQAuKQBQAtMAoGFIQUxkTdaBCUAFACr1oAlpAJQMW gQlABQAUAFABTAKQBTAKAA9KAE6CgBhoAKAJKACgBKACgAoAKACgBKAFoAf2oGJSAKYBSAKBBQMK ACgBKACgQUAFABQMKACgQUAFABQAUAJQAUAFMApAFMAoAKAENABQAtABSAKYCGgByOV+lAEwII4o GLQAUgDvTAKAFoASgBaACgApAAoAWgAoAKACmAUAFIApgFABQAUAFABSAKACmAUAIeopALTADSAA MdKACgAPSgA6CgAoAa3zHaOnegBT6UAKOlMBaQBQAUAFMBvRvrSAdQAUwCkAUAJ3oAWmAUgCgAoA KACgAoAKACmAUgCmAUAIKQC0AFABQAUwCkAUwEbpgdTSAWmAh54/OgBaAD+IewpALTAKQCHpQAi9 KAHUwCgAoAKQBTAKQBQAUAFABQAUAFABQAUwCgApAFMBG6YpAAoAWmAUAFABSAKACgAoAKYBSASg A5pgGaQC0wCkAUAFABTAKQBQAlMBGNIBRwMUALQAUwEJwCaAGh1PUEUAOBHagBaQCbRTAMY6GgA5 pAFABQAUAIx7UAHQUAAoAKACgAoAKAEoAKACgBB6mgAzmgBaACgAoASgBOtAC0AFABQAUAFACZoA M0AGaAEJ5FACZ5xTAQnmgBqHlifWkAFuKYDaQgoGI3SmIbigBcUALigBQooAdSGFMQUgCgYUwCgB KQBQAUxEZ60AJQAuDjNAAv3qAJKQBQMKACmAZpAFMAoAKQgpgFABSAQ0wENADaACgB+aACgBKACg BwUmgBdtABtoGLtFABgelIA6UAJQAUAFABQAUAFABQAlABQAUCCgYUAFAgoAKACgYUCCgBKACgAo AKACmAUgCgBKYC0AFIBucnimAUAFABQA5WKmgCZWBFAx1IBP4qAHUwCgAoAKACgApAA6UwCgAoAK AFoAKACkAUAFMAoAKACkAUwCkAUwCkAn8VMBaACkAUAFMApAFAATtHuelAABtX+dADT1xQA6mAtA BSAKACgBrDcR7HNADqACgAoAKYCd6QC0AFABTAKACkAUAFMApAFABTAKACkACgAoAKYBSAKACgAo AQckn8KAFJ9OtABjFMBaQCD7xoAWgAoAa/TFAC9qAFpgFIAoAKACmAUgCgAoAKACmAUgCgAoAKAC gAoAKAG/xUALQAtABQAUAFABTAKACkAUwCgAoAKQBQAlMAoAWkAUAFMApAJTASkADr9KAHUAJnjP agBAwPt9aAHUAJQAm0Z44oAXke9ABuGcdKYC0gEoAKYCA5yO4oAU0ANHXNIBepoAKACgBKACgAoA KADNACH0oAKACgAoAKACgBDQAvQUAFACUAGaAA0ANzgc0AHDCmAmcMBSAdxQAhIzzQAw8nNMBC2K AEzQISkAooAWgYhGaADbQIToaBjqACgBaACgAoAKACgBKACgAoEFMCM0AJQA4NgYoAE60APoAKBg TikAzNMQooAcKQwoAKYBQIKQBQAE4oAYaYCUAFAD6ACgBKAFHWgCTNAxN1IA3UAGaAEzQAhPFAC0 CCgYUCCgAoAKBhQIKBiUCCgAoAKACgAoAKACgAoAKAEoAKACgAoAKACgApgAoADxQAwmgBKAHjkU AJQAUALQAoJB4oAlR8/WgY7vQAtABkUALSAKYBQAHpSAB0oAKACmAUAFABQAtIApgFABQAUgCmAU AFABSAKAEHU0ALTAKQBTAKACkAUAJ1OfTpQAtACD71ADqYCE4GTSAFz1PfoKYBSAKACmAtIApgFA BSAQUwFpAFABTAKQBQAUAFABQAUwCgApABoAB0oAKACmAUAFABSACcCgBANq9aYCj170AFABQAi9 CfegBaAFpANPLD25oAWmAUgCmAtIAoAKACgAoAKACgAoAKACgAoAKACgApgFADRSAdQAUAFABQAU AFACUwFpAITgZoAQHPYigB1ABQAUAFABTAKACgAoAKQCdKYCE0gFHAoAOtAC0AIQD1oAMelABzQA ZoAMigAIzQAYA6UwDmgApAI3DKfXigAb0pgHSkAUAFACUAGaACgBM0AFABQACgAoAKACgAoASgA7 0AFABQAmTQAgbNAAGBPFABQAZoAQtQAxiD1pgJuoATNAgpAFAAKAHUDCgBaACmIa1ACigYCgBaQB QAUwCkAUAFMBKQgoAKYEdACUAFADk60APpAIeKYxpNAgUUAPpAJQMWgAoAKBBTAKAGnk0AIaAEoA KAH0hBTAKBijrQAtIYUAFAhKACgBD0oAcOlABQMKACgAoAKACgAoEJQMKACgQUDCgQUAGD6UDF2m gA2mgAK4GaBDaACgAoAKACgAoATrTAdjFADSaAGmgBKAFWgBaAFxQAYoAWgAoAer9M0DJM5oAXA9 KADHoaADmgABoAU9KQAOlABQAUwCkAUwCgBaQBQAUwCgAoAKACkAUwCgAoAQUgFpgFIAoAKACgBD 1xQAvQe1ADGzJwOB3NACqOeO1MBdwoAMZOT27UALSAKACmAUAFAC0AFACGkAL0pgLSAKYBQAUAFI AoAKYBQAUAFABQAhpALQAUAFABQAUAFACHkgenNMBetABQAUgGsSwIXp60AOAwoA7CmAUAFIBB1J /CgBaACgAoAKACmAUgFoAKACmAUAFIBKACgBaACgApgFACHpSABQAtABQAUAFABQAnSgAoAWgBKA A80AGPSmAZpALQAUAFABQAUAFABQA00wExkgfjSAXcCfpTAWkAtABQAUAFABQAmKADHpQAUwCkAU ANbkj2oAByc0ALQAhbHHWgBM0AIWxQA0sRQA4NmgBaACgANABQAUAFABQAlABQAUAGaAGlgKYCBt wpAKKAGj5aAEL0wGljQITNACUALQAUgCgAoABQA6gYtABQAUAIelMBBSAWgBaACgAoAKYBSEFMYU AFIBD0NMRFQAUAFAD0oAcaBjCaBAo7mgB9IAoGIaYC0gCgQUDCgQjGmA2gBDQAUAFAElIQhoAKYx R1oAWkAlAwoAdj3oAMUABXigBMYFABQAUAFAgoGFABQAUAFACUAFAgoAKBh3pgPzQAtABQAUgIiM HFAgoAKADNABzTAApPWgB3ApAMZqYDc0AGaAEoAUUALigB1ABQAUAFABQA5WI69KBkgYGgB1AAaA CgA7UAKOlABQAUAFABQAUgCgApgLQAUgCgApgFABSAKYBSAQdKYC0AFIApgFIApgFIBCuepzQAdB QAgGc+lAC4A6CmAc0AG72oAXIoAKACgAGe9ABQAUgBulAAOlMBaACgApAFABQAUwCgAoAKQBQAUw E/ipALTAKACkAUwCgApAIO596AFpgFADfvfSgBT2ApALQAUwCgBF6UgFoAKACgAoAKACgApgFIAo AKYBQAUgCmAUgCmAUgCgAPWgAoAWgAoAKACmAUgEPp3oAMjOM80wDIpAHP0oAKACgAoAKACgBaAC gApgFACHpSAQ0AIO/vQA4AUAGBQAY96YBkigBNwoAcOaQBj3oAMUAIc9qAACgAzQAUANb0oAB0oA KAG4znn86AEPGKADHOTQAEKWoAUCgBaAAnAoAQUALQAUAJQAUAGaAEzQAmce9ACE0AJx0oAaXx0o AQsTTENoAKACgAoAWgApAFABQAUALQA4UDCgAoAKACgBp4NMQtIYUALQAUwCkAUAFABTEFAxG6UC IqACgAoAenAoAQmgAAzQA+kAUAFMBDQACkMWmAUCF6D3pAMPSmAlACUAFABQA+kIQ0wFFAxRQAUg DIoAMigBc0xhSAXNABmgBeDQAmKACgBKACgAoAKACgAoASgAoAKADvQA6gAoAM0AGaAGnk0CFC+9 ABgetAw+UdqYhN3tQMQmkIQmmA2gAxQAYoAXFAC4oAWgAoAKACgBaACgAoABxQBIGzQMXPOfyoAd QAdqAAUALQAUAFABQAUAFABQAUAFABQAtABQAUAFACHpSAWmAUAFABQAUAFIAoAKAEPSgAXpTAWk Ah457UALTAMD0pAN288HFMB1ABQAUAFIBDQA6mAUgCmAUAFABQAUgCmAUAFIApgFIBB1NAC0wCkA UAFABQAh4BoABwKYC0AIck4oACQopACknBIxQAtMApAI3SgBaYBSAKACgAoAKACmAUAFIAoAKACg AoAKACmAUAFABSAQdzQAtABTAKQBQAUAFACA5Jx270wA+3U96QCYK/d4H86AHA5+tABQAUAFABQA UAFABQAtMBDwM+lIANADCcDPrQAq4z70AOoAKAEzk4H50AKFFAC8elACbVByBQAcDoKAFyKAE3Cg BN2T1pgFABQAzOTikA6gAoAikz2pgCOM4PekA/PpQAgwKAHUAFACE4oAB0oAKAEzQAZoATNACFgK YEe4k0CFzSAKACgBh60wCgAoAKAFoAKQBQAUAFABQAtAAOtAx1AC0AJQAUAFACMKYhBSGLQAtABQ AUwCgAoASgAoEI3SgBlACUAFAC54oAUDNAD8UgCgAoAKYwoEJ3oGLQAo9aBCdeaAGt1oASgBKACg BcUAKTSEJTGKKAHUAJQAhoAaaAAUAP5FABuoAN1AC5pALk0DF3UwFyKQBxQAmBQAY96ADb70AG33 oEGB60AJgetAxcCgAGKAFI9KAEoASgQlAAaAEpgJkUAG4UAJmgAoAKACgAoAWgBaACgAoAKACgAo AWgAoAKACgAoAcG9aBkg5Oc0AKaAAUALSAKACmAUAFABQAUAFABQAUAFAC0gCmAUAIelAC0AFABQ AUgCmAUgCgAoARulACjpTAKACkAgAGcd6AFpgFABQAUAFIApgJ/EKQC0wCkAUALQAUAFABTAKQBT AKACkAGgBF6UALQAUAFABTAKAEbsKQC0AIaYBwozQAgHO4gUgFHrTAWgAoAQ/eFIBaACgApgFIAo AKACgAoAKACgApgFIAoAKACgAoAKAA8CgBBQAtMAoAKQBQAUAFMBAflpAKKACgAxQAdKACmAUAFI ApgFIBaAEoAD0NAAaAGHofagByjA5oAMUAISSdo/E0AOHpigABz24pgFIAoASgAxmgAwKYBSAKAE oAao5JoAdQAUAMYZFACBcY9qAHH0FABQAUAGaAGk/LQAuaAEJoAaWFMBpkFAhhcmgBM5oActAC0h i0CCmMYetAgoAKACgBaACkAUAFAC0AFABQAo60DFoAWgBKAELCmAm6gQbhQAnegB1IYtABTAKACk AUCCmMKQhr9KYDKAEoAKAFUZoAkAxSAKYBSAKBhTAKBCHrQMUDvSADz9KYgpANpgJQAYoAKADNAC UALQA4CgBaACgBDQAnUUAJ0oAXtQAhNACZoASgBQxFAC76AF3CkAu4etABkUAGaAFzQAZoAMigAy KYC5FIAoAKACgYlAgoARjgUAMJzTASgAoAWgBaACgBcUAGKAFoAWgAoAKACgAoAKACgAoAKQBTAK ACgBwOKBjwcigBV6UALQAUALQAUAFABQAUAFABQAUAFABSAWgAoAQ9qAFpgFABSAKACmAUAFABSA a3agB1MAoAKACgAoAKACkAUAFMAoAQfepALTAKACkAUwCkAUAFAC0AFMApAFACNQAo6UAFMApAFA BQAUAJ3pgLSAKYDRyckcdqQCnpTAXtQAUgCgBo60AOoAKYBSAKACgApgFIAoAKYBSAKACmAUgCgA oAKYBSAQ9hQAtABTAKQBQAUAFMAPSkAnpQAtABQAUAFABQAUAFABQAUAFABQAH09aYCNSAa33Rju c0APoARj2HU0AKBgYoAWgBKAE6dTQAZz9KYBgelIAoATOfagAoADQAjHC0wEX7tIBaACgAoASgBc etACUAIWFADS1ADC4pgNMh7UCGlie9ACUAFABQACgCRelIBaBhQAUwGUCCgAoAWgApAFABQAtAwo AKACgBR1oAdQAUARk80xDc0AFABQACgB4pDFoAWmAUAFABQAUgCgQ1+gpgMoASgAoAlXpSAWmMKQ goAKYBSASgAxmmMGOOBQACgBDQITHFACUAFABQAYoAXFAChaAFNABQAUAIaAG9KAEoAXtQAlABig BMUAFABQAUAFABQAUAFABQAUAFABQAZNAC7j60AOV/WgB24UAJuFADWbNADaACgBaAFoAXFABigB cUALQAUAFABQAUALSASgApgFAwoELQAlABSAWmAUDCgBQ2Dz3oAkBoAWgAoAWgAoAKACgBOfpSAM kdqYCgg0AFABSAKAFoAQ9RQAtMAoAKACkAUwCgAoAKAGn7wpAOoAKACgAoAKACmAUAFIAoAKYCDq aAFoAKQBTAKQBTAKQBQAUAFAC0AFACGgBaACgApgFIAoAKAEHegBaAEPJx270ALTAQ9hQAtIApgI aQCL0NADqYBQAUAFIAoAKYBQAUAFABSAKACgAoAKACgAoAKAE6t9KAFoAKACmAUgCgAoAQ9KAF7U AFABQAUAFMApAFABQAUwCkAUAGeKYCD1pAIf50ADdM+gpgCnESk9aQCgY69T1oAdQAhOO2aAGgsf 4QPxoAXHrigAoAPxpgNHzHcDxSAdQA1n2nGMmmA35m5Jx7CgBGPGKQDsErgUAAPFABmgBCaAAsB3 oAYZKYDC9AhpY0AJk0AJQAUAFABQAUAFACigCSkMKACgAoAZTEFAC0AFIAoAWgYUAFABQAUAFACr QA6gAoAhpiCgAoAKACgB1ABQAuaAFzQAZoAM0ALmkAUDGPTENoASgAoAmHSkAUDCgApgFABQAAUg ELelMQ3qaAHZxQMaTQIBQAYoASgBc0AJmgCTFABQAGkAlMAoAKAEIzQA3BoAMGgAC0ALigAxQAmK AExQAYoATFABQAUAFABQAUAFABQAUAFACjrQArCgAWgAYYNACYoAWgBaAFoAMUALQAUALQAUAFAB QMKBBQAUAFABQAUDCgQUDCgAoAKACgQ1+lIBFcrTAmVw1Ax1AC0AFAC0AJ3ApALTAKQCEZpgLQAU AFIAoAD1oAKYC0AFIApgFABQAUAFADf4qQDqYBSAKYBSAKACmAUAFABQAUAIvegBaQBQAUwCkAUw CgAoAKACgAoAWgBO9IBaACgAoAKACgAoAQdKADpQADpQAtACfxUwFoAKAGk0gAcLQAtABQAtABQA UAFMApAFABTAKQBQAUAFABQAUAFABQAg70ALTAKQBQAUAFABTAQ8gikADgCgBGXNABkjqPxpgLuG cZpALTASkAUwDmgA3D3oAWgApANPJ9hQAp6UAJ3oAXtQAgGD3IHSgBc+i0wEwx+8aQC4HpQAUAFA CZ5oAOxoAagwgHIoAWgBCcemfegBA4YZ2kfjTACOSaQBkDpQA3cAMUANL0wGFjQIaSTQAlABQAUA FABQAUAFABQAUAFADkHNAD6QwoAKADtQAymIKAFoAKQBQAtAwoAKACgAoAKAHCgBaAEPQ0ARUxBQ AUAFABQA4dKACgBMUALzQAUAGaAFoAM0AFAC4FABtFADdooAdSAXNMYUgCmAUhBwOtACE560wGnr QAUAHWgAIoAKAANQAuM0ANIxQAlAE1AwoEJQAlABQAUAFABQAUAFABSAKYBQAYoATFACbaADFACY oAMUAJigAxQAYoAMUAGKADFABigBw6UANHWgBx6UAJQAUALQAooAdQAUAFAwoEFABQAUDCgAoAKA CgAoAKACgAoEFAwoEFAwoAR/u0hEdMAzQBIsuODQBKpB6GgY6gAoATvSAB6UwFoAKACgBRQAUgCg BP4qAFpgFAC0AFABSAKACmAlACfxUgHUwCgAoAKACgApAFMAoAKQB2oAQdKYC0gCmAUAFABSAKAC gAoAKYBSAKYAOtIBaYCUAFIAoAWmAh6UgCgAPUUALQAlAAOpoAWgBKAGtQA7HtTAWkAUAFABQAUA FMAoAKACgApAFABQAUAFABQAUwEPSkADoKAFoAKACmAUAFABQAUAIvTGMUgFoAKAEwKADGOlMAzS AKAFoASgApgNJJU44pAKgwgFACmgBB3NACjpQAUwCkAUAFACZoATNABQAmc8UAJkDvQAm8UANLDr imAm+gBC1AhpY0AJQAUAFADaACgAoAKACgAoAKACgAoAKAFoAkUYFIBaBhQAUAIelMBlAhaACkAU ALQAUDCgAoAKAFoAKAFFAC0AI33TQBFTEFABQAUAFADx0pAFMAoAKACgAoAKACgApAFMBaAEoAKA DNABmgBaQBQMXrQAmKYg20gDbTATFIYYoEJimAmD6UAKCRQA7INIBCtMB9ACUAFABQAUAFABQAUA FABQAUDCgAoEFABQAUAJQAUAGKADFABigAxQAYoATFAC4oATFACEUANxQApoABQAtAC0ALigBaAC gAoAKACgAoGFABQAUAFABQIKACgAoGFAgoAKACgYUAI/3aBEdACUAFAChiOlAEqSZ60DJQc0AB60 ABPGaAA8YPY0AKaACgAoAWgAoATvSAWmAUgCmAtIAoAKYBQAUgGr1NADqYBQAUAFABQAUAFIApgF IAPSgAHSgAoAKACgAoAKACgAoAKYBQAUgCgAFABTAKACkAUAFAAeooAWgBKYBQAhOB7mgAQELyck mkAtMA4FADTyR9aQDqYC0gCgAoAKAEpgLQAUgEoAKAFpgFIAoAKACgAoAKYCGkAUALQAUAFMBKQC 0AFMAoAaAAxI79aQDqYAeKQBQAUAFABQAlMBNw+tIAxnrQAvagAoAQ0AA6UALQAmaYBmkAnFABQA maAELAUwGFiaAEpANJpgJQIKACgAoASgBaACgBKAEoAKAEoAKACgAoAKACgAoAKAHqMmkA+gYUAF ABQAjdKYDKBC0gCgBaAAUDCgBaACgAoAKACgBRQAtADX+7QBHTEFABQAUAFADxQAUAFABQAUAJQA tACUALQAUAFABQAUAGKADFAC0DCgBaQBQIMUAGKACgYUCFwKAFpjFpAJgelAC4oAbTEJQAUDCgAp AFAgpgFABQMKACgAoEFABQAYoGFAgoGFABQAUCCgAoAKACgYUhCUwDFACbaADbQAuKADFAC4oGFA BQAUAFABQIKACgYUCCgYUAFIQUwCgYUgCmIKACgAoGFABQIRvu0gI6YBQAlABQAUAPVyKAJVcGgY 4Y/A0gFAwuM/SmAA5FAB/SgBaACgBaAE7mgBaACgAoAKACkAUALTAKAGikA6mAUgCgApgFABQAUA FIAoAKAEpgLSAKACgAoAKACgAoAKYBQAUAFIAHSmAUAFABSAKYBSAP4qACgAoARs7cDqeKADGAT1 NMBegoAKQBQA3+PHpQA6mAUAFIAoAKYBSAKACgAoAKYBSAKAFpgFABQAUAFADT1pALQAtMBKQC0A FACUAGKACgBCdo4FACgg0ALmgAxQAUwEz6c0AHNABigA6UgCgAoAQ/WgBDjFACZ4oAXNMBM0gE3U ANLUwGmQUAML0CE3GgABPrQAtABQAUAFABQAUAFABQAUAIaAEoAKACgAoASgAoAKACgAoAUCgCQD ApDFoAKACgAoARulADKYhaACkAtAwFABQAtABQAUAFABQAooAWgBr9KAI6YhaAEoAKACgB2aAFzQ AUAFABQAYoAMUAFABQAUAFIAxQAuKYBQAUAFAxaQCE4piDcKAFyKADNAC0DDFIBcUAFAC0AFABQA 2mIKAEoGFAgoAWgYUCEoAKAFoGFABQAUAFABQIKACkAlMYUCCgBaACgAoGFABQAlAgoAKACgYUCC gAoGFABQIKBhQAUAFABQAUCCgAoGFABQAUAFABQIKBhQIKACgAoGI33TSER0wCgBKACgAoAKAAHF AEqSHpQBKGB9qBijHagAPHNIAz+VMBaAAUAHc0AFAC0AFABQAUAFABQAUgEFADqYBSAKACmAUgCm AUAFABSAKACmAUgCgAoAKACmAUAFABSAKACgANAAOlMAoAKACkAUAFACD7xoAWgAoAQcnNAAeSBQ AtMApAIaYCL1JpAOoAKACgAoAKYBSAKACgAoAKACgAoAKYBQAUgCgApgNHU0gHUAFABQAUAFABQA c+maACgAoASgAxxQAYoAXFABQAUAFMApAJmgAzQAmaYDTzSAQntTAQtSAazYpgMLmgQ3NACUAFAD gKAFoAKACgAoAKACgAoAKACgBKAA0AJQAUAFABQAUAFACUAFACgUAPUdzSAdQMWgBKACgBaAGt0o AbTEFABSGLQACgBaACgAoAKACgAoAcKACgBr9BQAymIWgBKACgBQpoAQg0AFABmgAzQAuaADdQAZ oAXNABmkAUwFpALTAKBhQAUhBQAlMBG6UANoAKAFoAXNAChjSAN9MBwakAuRQMXIoAKAG0wCgQlA woAKAFoASgAoEFAC0AFAwoAKACgAoEFABQAUAFAwoEFABQMKACgAoAKAEoAKACgAoAKACgQUgCmA UAFABQMKBBQAUAFIYUwCgQUDCgAoAKBBSAKYBQAUAFACHoaAI6ACgBKACgAoAKACgBU+8KAJaBih vWgB4bJoAUjigAB7GgBaAAdaACgAoAWgAoASgAoAWgAPSkACmAUgFpgFIBKAFoAKYBSAKACgApgF IAoAKACgAoAKACgAoAKACgApgIaQC0wCgAoAKACgApAIOrfWgBaAA88UAHSmAg9aQC0wCgBD0oAR en40gHUAFABQAUAFMAoAKACkAUAFABQAUAFABTAKQBQAHgUANXpQA6mAUgCgApgFABSAKACmAUgC gAoAKACgBKADNABmgBM0AJmgBCaYDS1ADS1ADd9AhC9ADSc0AJQAUAKBQAoFAC0AFABQAUAFABQA UAFAB3oAKAEoADQAlABQAUAFABQAUAFACgUAPC+tIB1AwoAKACgAoAKAGv2pgNpCCgBaBhQACgBa ACgAoAKACgAoAdSAKYDH7UANpiFwaQChaAHcUDCgAoAMA0ANKUxCFSKAEoAKACgAoAKADNAC5oAX NABmgAyaADJoAXNIBCaYCMaAEFABQAtABQAUAFABQAUALSAKAH0wG5yaQxaYBQIKBhSAKYBQIKAF oGFABQAUCCkMKYgoGFIQUwCgYUAFABQAUAFABQAUAFAgoGJQIKACgYUCCgYUAFABQAUAFAgoAKBh QAUAFAgoAKBhQIKBhQAUAFABQAUCA9DSAipgFACUAFABQAUAFACr94UAS0AFAADQMcGIoAdnI4oA dmgBvRsUgHUwFoAKQBTAKACgApAB6GgAFABQAUwCkAUAFABTAKACgApAFMBaQBTAKQBTAKACgAoA KQBQAUwCgBD1pALTAKQBTAKACkAUAIPvGmAtIAoAQ9cUALQAUwCgBppAKvSgBaACgAoAKACgAoAK ACgApgFIA/GgAoAKACgAoAKAGucCgBV+7QAtABQAUAFABQAUAFABQAUAFACZoAM0AJmgAoAM0wGl hSAaWpgMMlAhpcmgBuTQAlAC0AFABQAYoAUCgBaACgAoAKACgAoAKACgAoAKACgBKACgBKACgAoA KACgBcUAKFpAOCUAKABQAtAwoAKACgAoAKACgBr9RQIbQAtABQMWgBBQAtIApgFABQAtABQAtABQ A1hk0AAFAhaBhQAUAFAAaYCA5pAOoAKAEwDQAhT0piGlSKAEoAKACgAoAKACgAoAKAFzQAZoAQ0A FABQAtABQAUAFABSAKACmAUAOLZpDEFMB1AgoGFABQAUAFIQUAFAxaYBQAUCCgAoGFABSAKYgoGF AgoGFAgoAKBhQIKBiZoAKACgQUAFAwoEFABQAUAFABQAUAFAwoEFAwpAFABTEFIYUwCgAoAKBBQM KACgA7UhEVMAoASgAoAKACgAoAVeooAloAKBhQAUALQAob1oAXOX+tIBwNMBc0AGaAFoATNAC0AF ACHpSAUUAFMAoAKACgApAFABTAKACkAUAFABQAUAFMBaQBTAKQBTAKQBQAlAAetAC0wCgApAFABQ AUwE/i/CkAtAAeBk0AIOeelAC0wEJxQAtADWpAKOgoAWgAoAKACgAoACQOppgN3Z6CkAvzHjp70A Jj1NAC7RQAYFABj3oAOfrTAAc96AFpAFADJOooAcOgoAKAFoAKACgAoASmAtIBKADNACfjQAUAGa YDdwpAIXpgML0AMLGgQ3NABQAUAJQAUAKKAFoASgBwHFAC0AFABQAUAFACUAFABQAUAGaAEzQAUA FABQAUAJQAUAKBQA8L60gHYoGFMApAFABQAUAFMApAFABQAUANcZNACAUALigAxQAUAA70AFIApg FAC0AFABQAtIApgJQAUAFABQAUAFAAaABR6UAKeBQAZzTAO9IBfpQAUABUGmAxkx0NAhlABQAUAF ABQAUAFABQAhoAWgAoAWgAoAKACgAoAKACgAoAKQxRTAfQAlAgoGFAC0AFAhKBi0CCgAoGLQAUAJ QAUAFABQIKBhQAUCCgYUCCgYUAFAhKQwpgFAC0AFABQAUhCUwCgAoGFAgoAKACgAoAKACgYUhBTA KACgAoAKBhQAUAFABQIiNABQAlABQAUAFABQADrQBNQAUDCgAoAKACgBaAHBqAHZoAWgAoAKAFoA KAEPSkAo6UwCkAUAFMAoAKQBTAKACgAoAKQBTAKQBQAUAFABTAWgAoAKACkAUwE70gCmAUAFAC0A FABSAQ9qYBnJwOlIA6njpTAWgBKACgAoARulIB3agApgFIAoAKAG5J6fnQABQPfNADqACmAUAFIA pgITgE+goAF+6PpSAMZoAAcHBoAWgCN/v0APpgFAC0gE57CgApgFIAzQAmaACgBM0ANL+lMBpegB pb3oAQtQITNACUAFABigBMUAFABQAlACigAoAKAHjpQAUABoAKACgAoASgAoATNABQAUAFACUALQ AlABQAUAOAoAeBikMWgApgFIAoAKACgAoAWgAoASgAoAWgBp60AFABQAUALQAmKADFIApgFABQAU AFIBaYBQAYoAMUAFABQAUAFABQAY9KAE2n1oANvpQIUA+tAC9KBiFsUAJkmgBKAGUxBQAUAFABQA UAFABQAlAC0AFABQAtABQAUAFABQAUgFoAO9AxwGKYBQIKACgYtAgoAKACgYUAFABmgQUAFAwoAK ACgAoEFACUAFAC0DCgAoAKQCUwCkIKYxaACgAoEFABQMKQCUwCgAoEFABQAUDCgQUAKMd6AA+1Ax KACgAoAKACgAoEFAwoAKQiI9aYBQAlABQAUAFABQADrQBNQAUDCkAUwCgAoAKACgBQcUAODUAOBo AXNABSAKYAaQAKYC0AFABQAUgCgAoAKACgAoAKYBSAKACgAoAKACgAoAWgApgFABSAaOtAC0wCgB aACgBKAFpAIRkYoAPagA6UwCgAoAKACgBrUgH0AFABQAh4GTQAn3uTwPSgB1ACUwFpAJQAZwCfSg AX7o9+aADPOO9ACPxG30oAXoAPamAtIBq8gk9zQAoPODQA1h82aAHUAFABQAZoATNABmmAmaQCFh 9aAGlqAGlgOppgRlyenFAhuaAFzQAtABQAUAFABQAUAFABigBKACgAoABQA8dKQBTAKQBTAM0AJm gBKACgAoAKAEoAKACgAoAKACgBRQBIg70gHUxhSAKYBSASgAoAWgAoAKACgBKAFoAKAGnqaAEyKA FoAKACgBaACgBaAExQAYoAKACgAoAKADNABmgAoAKAFoASgBaACgAoAMimAhNIBOtACHmgAoAQ9K AG0xBQAUALQAUAJQAUAFACUALQAUALQAUAFABQAUAFABQAUASAYpDCgQlMAoAKACgAoAKBhQIKAC gBaAEoAWgYUAFABQAUAFABQIKBhQIKACgYUAFABQAUAFAgoGFABQAUAFIQUwCgYUAJQAUAFABQIK BhQIKBhQAUAFABQAUALQAUAFABSERHqaYCUAJQAUAFABQAUAAoAmoAKBhQAUAFAgoGFAgoAKAEIo AAxXrzQA4SCgY8NQAoNAAehpAA6UwFoAWgAoAKACgAoAKACgAoAKQBQAUAFABQAUwCgApAFMAoAW gApANHWgB1MAoAKACgAoAKACkAn6UwDpQAUAFABQAUANPWkA+gAoAKYDfvHP8IpAOoAKAGqcg/Wm AtABSAR/u49eKAHUAJQAj9FHqaAHHrQAxycADq1MBwGAAO1IANABQAUAGaAEzTATNACbqQDd1MBM +tADS4FAhhcnpxQA2gAoAKACgAoAXNAC0AFABQAUAFABQAUAGKAExQACgB/agAzQAmaACgBKACgA oAKACgAoASgAoAKACgAoAKAHAZOKQEtAwpgFIAoAKYBSAKACgAoAKYBSAKACgAoAYe9ADDnNMQ8G kMWgAoAKADNAC5oAWgBaACgBvFABQAUAJQAUAKBQAtACYzQAuKACgBC3pQAhOaAEoAKADvQAUAFA DT0oASmIKACgAoAKACgAoAKAEoAKAFoAKAA0AAzQAtABQAUAFABigCSgBrHHFACigAoAKACgAoAK ACgYUAFAhaACgAoAKACgAoAKBhQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFACUAFAgoAK ACgAoAWgYlABQAUAFABQAUAFAC0CCgBKQEbdTTASgBKACgAoAKACgAoAm7CgAoGFABQAUAFABQAU AFAgoASgBCvpSAQErTAcJPWgY8NQAqkUAOzQAv40AHNABQAtABQAUAFIAoAKYBSAKACmAUAFIAoA KYBSAKACgAoABQAUwFoAKACgBKACgAoAKACgAoAKBBQMKAG/xCkA+gAoAa390dTQAvQYFAC0AFAD V4ZvzpgLSAKAEPLKPxoAWgBaAGdZPZRQA6gBu396X7Y4oAdQAUAJQAhIoATdQAhamA0896QCFgKY hhk9KAGliaAEoAKACgAoAKACgAoAKACgAzQAoNAC0AFABQAUALQAUAJQAUAFABQAUAFABQAUAFAB QAUAJQAUAFAC4oAMUAJ3oAlQd6QDqYwoAKACkAUwCkAUAFMApAFAAaACgAoAWgBlACEUAGMUAFAC 0AFABQAUAGcUALk0AJQAtAC0AJQAlABQA4UALQAmQKAG7jmmAlIAoAPagAoAKACgBKAEzQIQ0wEo AWgAoAKACgAoAKACgBKAFoAKACgAoAWgAzQAZoAUnNAAMUAGPQ0gHM2PrTAjzmgB9AC0AFABQAUD CgQUALQMKACgAoAKBBQMKQgpjCgQUDCgQUDCgAoAKACgAoAKACgAoEFAwoAKACgAoAKACgAoAKAC gBKACkIKYBQAUDCgAzQAUCCgAoGFAC0AJSAKBEbdaYCUAJQAUAFABQAUAFAEw6CgAoGFABQAUAFA goAKBhQIKBhQAUCEIzQAwjFACA4oAeH9aAHbxnigY4NQA4GkAuaAFpgLSAKACmAUgCgAoAKACmAU AFIAoAKACgAoAKACgAFABTAKACgAoAWgBKADn1oAKAFoASgAoEFAwoAb/EKQDqYC0gGryS34UALQ AUwAdAaQB/Fj2oAKACgBB99j26UwFpAFADY12rg9TyaAHUAJmgBCaAELUAITnvTAQ49aQDCwHemA 0yelAhpYmgBKACgAoAKACgAoAKACgAoAKACgAoAKACgAzQAuaAFzQAUAFABQAUALQAUAFACUAFAB QAUAFABQAlABQAUAKOtAC0gCgBO9MCVRhaQC0xhQAUgCmAUAFIAoAKACgAoAKACgAzQAZoAaRmgB OR70AGaAFoASgAoAWgAoAQigBaACgBRQAUAFACUAKOfpQAE46UANyT1oAKACgAoAB1oAPWgA7UAI TQAhbNAhKYBQAUAFABQAUAFABQAUAFACjrSAcRTAZQAUALigYmKBC4oATFABQAtABQAUAD/epACj JpgPoASgAoAXNAxKBC0AFABQAUALQAUDCgBaACgAoAKBBigAxQAUDCgAoAKAEoEFAwoAKACgApAF MAoAKBBQMKBBQAUDCgAoASgApAFMQUAFABQAUAFABQMKACgAoAKACgQxutADaAENABQAUAFABQAU ASr90UALQMKBBSAKYwpCCmMKQBTAKACgQUAFAwpCGlfSgBlMAoAUEigBwfFADw9AxwNADgaAFzSA KYC0AFIAoAKACmAUAFIAoAKYBQAUgCgANACCmAtABQAUAFABQAUAFABQAUAFABQAUAFADR96kA6g BGPGO54oAUdBQAUwFpANT7v0oAP+Wg+lAC0AI7bUJ70ACjaoBOTQAtAB0oAQtimA0tSAbyaAEJx1 NMBpcUCGlz2oAaSTQAlABQAUAFABQAUAFABQAUAJQAtABQAUAFABQAUAFABQAUAFACg0ALmgBaQB TAKAEoAKAFoAKAEoAKACgAoAMUAFACUAKtAC0gCgAoAlHQUxhSAKACgAoAKYBQAUgFxQAlABmgAo ASgAoAKACgAoAMZoATb6UAJyKACgBaACgA70AFABQAZAHNACFvSgAHPJNACigANACHigAoAKAAUg CmAZFACFvSgQ0mmAUAFABQAUAFABQAUAFABQAUAFABQAq9aAHUAJikAhFMBBQAvWgYUAA60hCmgB hpgGaACgCRhluKAFAwOKAENABQAUAFAC0AFABQAUDCgQUALQAUDFoAKACgAoAKACgAoAKACgAoAK AEoAKACgQUAFAwoAKBBQMKBBQAUhhTAKACgAoAKQhKYBQAUAFABQAUAFAwoEFABQAUAFADH60ANo AQ0AFABQAUAFABQBKv3RQAtAwoAKQgpgFABQAUDCgAoAKACgAoEFABQMQgGkIYRimAlABQAUAKGI oAeJKBjwwoAcDQAuaQC0AFMBaQBQAUwCgAoAKACkAUAFMAPSkAgpgLQAUAFABQAUAFABQAUAFABQ AUAFAAaAGj7/AOFIB1ACDlyew4FAAOuKAFoAO9ADU/iB9aYC4+cN6DFIBaADigBMigBC9MBhNIBK AGNJ6UxDSxPU0ANoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAD NACg0AOpAFABQAUAFACUALTAKACgBRzQAlIBCKYAtADqQBQAg60ATUDEJwM0ALQAUAFABQAlACE4 NACg0AGaAEoAKACgAoAKACgAoAWgAoAKAAgGgBNpoAaeOtAAOtAC0AIc0AGOaADFAC0ALjAoASgB KACgAoAQsKAGliaYhKACgAoAKACgBaACgAoAKACgAoAKACgAoAKAHLQAtAAaACgBpFACCgBetAwF AhaAGmgBKAEoAnoGFIQhpgJQAUAFAC0AFABQAUAFAxaQBTAKACgBaACgAoAKACgAoEFAwoAKACgA oASgAoEFAwoEFAwoEFAwoAKACgQUgCgApjCgQUDCgQlIYUwCgQUDCgAoAKACgQUgCgApgNegBlAC GgAoAKACgAoAKAJE+7QA6gYUgCmAUAFAgoGFABQAUCCgAoAKBhSEFMAoGJSENK+lADaYBQAUAFAB nFADg5FADw9Ax4agBc0AOBoAKQBQAtABTAKQBTAKQBQAnagBRQAUwCgAoAKACgAoAKACgAoAKACg BOlAAaAEH3jSAdQAifcHvzTAD6+lIBaACgBAuCST17UAGRQAhamA0tSATNMBpIFADS/pQIaWJoAb QAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABmgBQ1A Ds0AFIAoAKACgAoAKACgApgLQAAUgCgBDQAL1oAlHSgYEZFAC0AFACZpgGaAE5pAFABQAUAA4oAW gA/CgBKAAUALQAUAFABQAUALQAUABxQA07fSgBKACgAoAKACgA60AFADScUAIW9KBDSSRTASgBaA CgAoAKACgBaACgAoAKAEoAKACgAoAWgAoAKAHLSAWgYtMBKQgoGNIpiAUDDFIBaBDTTASgAoAmHQ UDCgQ00gCmAUAFABQAtAwoEFABQAUALQMKBBQMWgAoAKACgAoEFAwoAKACgAoAKACgAoAKAEoAKA CgAoAKACgAoAKBBSGFMAoAKACgQUDEoAKBBQMKACgAoEFABQMKQgpgNekA2mAhoASgAoAKACgAoA kT7tADqBhQIKBhQAUhBTGFABQAUAFIQUxhQAUCCgYUAFABQAhGaQhhGKYCUAFABQAUAFACgkUAOD +tADhIKBjw1ADgaAFzQAZoAKQC0AFABTAQ9KQAKAFpgFABQAUAJQAtABQAUAFABQAUAFACUAIvU0 gFP3T9KYAv3F7cUAL2xSAahxlfSmAFz2pANyaAEJ96AGlxTAaXoENLE0AJQAlABQAUAFABQAUAFA BQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAoagBc0ALSA KBhQAUAFABQIKAFoAM0ABFMBB1pASr90UDFpgJQAHNIBO9AC96AAk9uKACgAoAKACgAoAKACgAoA MUAFAC8UAFABQAhIFACFqAEoASgBaACgAoAKAA0AIWAoAYWJpiEoASgAoAWgAoAKACgAoAKACgBa ACgBKACgAoAKAFoAKACgAoAM0AGaBihqAHdRQIaTigYmaADNAgzQA7tQA00AJQAUASp92gBaAENI BKYBQAUAFABQAtABQAUAFABQAUDFoAKAFoAKACgAoAKACgApCCmMKACgAoAKACgAoAKACgAoASgA oAKACgAoAKBBQMKACgAoAKACgQlABQMKACgQUAFAwoEFADWpANpgIaAEoAKACgAoAKAJI/u0AOoA KACgAoGFAgoAKBhQAUAFAgoGFABQAUAFABQAUCCgBCRQAw47UAJQAUAFABQAUAFABQAoYigBwegY 8PQA4NQAuaAFzQAuaACgANIAFMBaACgAoAKACkAUwCkAUwCgBKAFoASgApAJnBNAC5pgJmkAhIFA DGcZz3pgMMh7cUCGlie9ACUAFABQAUAFABQAUAFABQAlABQAUAFABQAUAFAC0AFABQAlABQAUAFA BQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAZoAcDQAuaQBQAtAwoAKACgAoAM4oAUE UALmmIWgYUgFoAQmmAZFAC0gCgAoAKAA8UwCkAtABQAUAGKACgAOBQAhI7UwG5zSAKAEoAKACgAo AWgAoAOccUANKmgQm00wE2n0oATFABQAUAFABQAUAFABQAUAFABQAUALQAUAFACUAFABQAUAFADq BiUAHFAhyntQAMKAGYFABgUAGKAHjpQAhoAbQAUASp0P1oAWgBpoASgBaACgAoAKACgAoAWgAoAK ACgBaAAUDCgBaACgQUDCgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoASgAoEFABQMKACgAoE FAxKACgAoAKBBQMKBBQAUANbpSAbTAQ0AJQAUAFABQAUASR/doAdQAUAFIYUwCgAoAKACgAoAKBB QAUAFAxMigQm6gA3UAJk0AJmgAoASgAoAKACgAoAKACgAoAKACgAoAcGIoAcHoAUP70DHhqAFBoA XORSAAaYC0AFIApgFABQAUgCgAzQAUwCgBM0AJuoAM0AN3D1pABbFMBhkJoEMJJoASgAoAKACgAo AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAEoAKACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgAoAKACgAoAKACgBQaAHA0AFIYtABQAUAFABQAUALmgBwNAC0wGnrSAMUCFWgB1Awo AKADAoAQKBQAtABQAUAJupgJupAN60AFABQAUALQAUAJQAZxQAg5NADqAFoAKACmAUAJikAbR6UC EKCgBNnvQAmw0wE2mgAwaAEoAKACgAoAKACgBaAEoAKACgAoAKACgBc0AGaBhQADg0CHnkUARkUA JQAUAPWgANADaAFwaAHp3oAdQA1qAEoAKACgBaACgAoAKAFoAKACgAoGFAhaBhQAUALQAUAFABQA UAFABQAUAFAgoGFAgoGFABQAUAFABQAUgCmAlABQAUAFABQAUCCgYUgEpiCgAoAKACgAoGFABQAh 6UCGUAIaAEoAKACgAoAKAJI+hoAdQAUAFABQMKACgQUDCgAoEJ0oATdQAmTQAmaACgAoASgAoAKA CgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAFBIoAUPQA8PQMcGFAC7qAFzQAuaQBmgAzTAM0AGaA E30ANMgoAaZKAGmQ0AJuNAhMmgAzQAZoAKACgAoASgAxQAYoAKACgAoAKACgAoAKACgAoAKACgAo AKACgAoAKACgAoAKACgAoAKACgAoASgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoA KACgBc0AKDSAWgYtABQAUALQAUAFABQAvFACgUAOoAWgAoASgBaACgAJx1oAaWpgNJJpAJQAUAFA BQAUALQAUAJnPSgBaAGmgBRQA6mAUAFIApgFABQAUAFABSAKACgBKYgxSATaKBhtFAhCuBmmAygA oAM0APVMjJoAaRzQAmKACgAoAKACgAoAM0AGaAHqaAA0AJQMKBCjrSAMUAGKAFpgKv3jQAtADW6U ANoAWgAoAKAFoAKACgAoAWgAoAKACgAoAKACgBaBhQAtABQAUAFABQAUAFAgoGFABQAUAFABQAUA FABQAUAJQAUAFABQAUAFABQAUgCmAlAgoGFABQAUAFABSAQ9KBDaYCGgBtABQAUAFABQA+PvQA+g YUCCgYUAFAgoAKACgBKAEbpSAZTAWgAoAKAEoAKACgAoAKAEoAKACgAoAWgAoAKACgAoAKAFxxQA pxQA00AJQAtABQAUAGaAF3GgBd5oAXzDQAeYaADzDQAm80AJuPrQAZNACUAGaACgAoAKACgAoAKA FoAKACgAoAKACgAoAKACgAoASgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgB KACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAFoAKADFABigAoAM0AODUgFoGFABQAtABQAUAFAC 5oAcDmgBaACgBaYCbqAGlzQA05NABSAKACgApAFMAoAQsM0AGaADrQAvSgAoAO9ACigBaYBQAUgC gApgFABSAKYBSAKACgApgJQAUAFACP8AdoERUAFABQBOOIxSAZigBMUwCgAoAMUAJigA20AJigAx QAoyDQA88igBu2gBQKQC0AFMApAFAAv3j9KYDqAGt0oASgAoAWgAoAKACgAoAWgAoAKQC0xhQAUA JQAtABQIWgYUAFABQAUAFABQAUCCgYUCCgYUAFABQAUAFABQAUAFACUAFABQAUAFABQAUCCgBKBh QAUAFABQAUAFACHpQIbQAh6UANoAKACgAoAKAHx96AH0AFABQAUAFABQMSgAoEFADXoAbQAUALQA UAJQAUAFACUAFABQAuKAF20AGKADFABQAlABQAUAFACqcGgAJ5oATNACUALQAUAFABQAUAFABQAU AFACUALQAUAFACUALQAUAFABQAUAFABQAUALQAUAFABQAUAFABQAUAFABQAUAFABQAlABQAUAFAB QAUAFABQAUAFABQAUAFABQAUAFABQAUAFACYoAKACgAoAKACgAoAKACgAoAKACgAoAWgAoAKACgA zQAUAFACUAKDigBd1ADgQaQxaADFABQAUAFAC9KAHqc8HrQAGgBhP5UAFACUAHagBKAFoAO1AASB QA0v6UWENJJpgC9aAF70AL0oGL1pAKKACgB1MApAFABQAUAFABTAKQgoGFABQIKYwoASkAUAFMBr 9KBEdABQAUATtwoFACUAFACYoATFACUAFABQAUALQAYpALTAKACkAUAFMAoGFAgHD/hQA6gBrdKA EoAWgAoAKAFoAKACgAoAWgAoAKBhQAUAFAgoGFAC0AFABQAUAFABQAUAFABQIKBhQAUAFABQAUAF ABQAUAFABQAlABQAUAFABQAUAFAgoGFABQAlABQAUAFAAelAhlACHpQA2gAoAKACgAoAcnWgB9AB QAUAFABQAtAwoASkIKYDW60ANoAKACgBKACgAoAKAFoAOKAFoAKADNAC5oAQmgBM0AJQAUAFAC0A FABQAlAC0AFABQAUAFABQAUAFABQAUAJQAtABQAUAJQAUAFAC0AFABQAUAFABQAUAKDQAUAFABQA UAFABQAUAFABQAUALQAmKACgAoAKACgAoAKACgAIoASgBKAFFABQAUAFABQAUAFABQAUAFABigBK ACgAoAKACgAoAKACgAoAWgAoAWgBKAEoAKACgAoAKACgAoAKAHBiKAHg5pDFoAKAExQAUAKDg0AK WzQA00AFABQAUAFACbgOaAGlyaYgKH60ANwaAFCk0ALjFACrQA4igY2gBRQAtIBaAFoAKACgAoAK ACgQUxhQAUAFABSASgAoEFMYUAMftQIZQAUAKOooAmfsKBiUAFABQAlIQYpgJigAxQAuKACgYUCC gAoAKACkAUwCgApAA5bimA6gBDQAmKACgBaACgAoGLQIMUDFxQAlABQAUAGKAFoAKACgAoAKACgA oAKAFoASgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBKACgAoAKACgQUAFAwoEFAwoEJQAUAFA BSAZTAD0oAZQAUAFABQAUAOTrQA+gAoAKBhQIKACgAoAKACgBrUANoAKAEoAKACgAoAKAFoASgBQ aAF5xQAmKACgBKACgAoASgBaADNAC0AFABQAlABQAUALQAUAFABQAUAFABQAlAC0AFACUALQAlAB QAUAFAC0AFABQAUAFABQAZoAXNAC0AFABQAUAFABQAUAFABQAUAFACUAFABQAUAFABQAUAFABQAU AFABQAUAJQAtABQAlAC0AFABQAmKADFACUAFABQAUAFABQAtABQAUAJQAUAFABQAUAFABQAUAABN ADgnrQA8KBSAWgYUAFABQAUAFABQAlABQAZFADS/pQIaSTTASgAHWgCegYlADSaAEAoELikA4Uxj WFACA0AOFIBRQA4CmAhpAFMAoAKACgAoAKAEpCFoGJQAUAFMApAFADH60xDKACgBU+8KAJm+9SGJ TAKACkAUwEoAKBBQAUgCgAoAKACmAUgCgApgFIAoAdjFMYUCGnmgBaACgAoGFABQIWgYUAFAC0AF IApgLQAUgCgQlMYUAFABQAUALQAUAFABQAUAFABQAUAFACUAFABQAUgCmAUAFABQAUAFACUAFABQ AUCCgYUAFABQAUAFABQAlABQIbQAh6UAMoAKACgAoAKAFTrQBJQAUAFABQAUAFABQAUAFACNjFAD KACgBKACgAoAKAFoASgAoABQAuaAEoAKACgAoAKACgAoAKACgAoAWgBKACgBaAEoAKAFoAKACgAo AKACgAoAO1ACUALQAlABQAUAFABQAUALQAUAFABQAUAFABnFADs0ALQAUAJQAUALQAlABQAUAFAB igAoAKACgBKAFoASgAoAKACgAoAKACgAoAKACgAoAKACgAoATNABmgBKACgAoAKACgAoAWgAoASg AoAKACgAoAKAAAmgB4T1oAcFApALQAUxi0AFABQAUANfhaBDA/rQA4MKQxcj1oAQsBQA0saYhtAB QAUAFACr94UASmgYhNACAZoEOpABFACUALTAawoAaDQMlUcUgAmgABzQAtACYoAKYBQAUgCgAoAS gAoAKYBSAKACmBG/WgQ2gAoAdH98UASdzSAKYwoASkAUAFMApAFAgoAKYBSAKACgAoAKYwpCCgAp jHUCEJpAJTAWgYUCCgYtAgoGFIApgLQAUAFAC0AFABQAUAFABQAlABQAUALQAZoAKACgAoAKACkA UwCgBKACgAoAKACgAoAKACgAoAKAEoAKACgBaACgBKACgAoAKACgAoASgAoENNACdqAGUAFABQAU AFACr1oAkoAKACgAoAKADNACbqAE3UANyaAEoAKACgBaACgBKACgAoAKAEoAWgAoAKAEoAKACgAo AKAFoAKAEoAWgAoAKACgBaACgBKAFoAKACgAoAKACgAoAKAEoAWgBKACgAoAKACgAoAKACgBaACg AoAKACgAoAUGgB2aACgAoAKACgAoAKACgAoAKQBTASgAxQAUAFABQAUAFABQAUAJQAUAFABQAUAG aAEzQAlABQAUAFABQAUAFABQAUAFABQAUAFABQAYJoAcEPegBwUCkAtAC0wCgYUAFABQAtACUAFA DZOgoER0AFABQAUAFABQAUAFABQAqfeoAkNAxOpoAcKQC0AFMBCKAEpCCmAKvNIB7HHAoGRk0xCB sUAPDUALmgYtIBMUAFABTAKACkAUxCUDFpAJQIKYyNutAhtABQAqHBoAfmgAzQAUAFAC0AFABSAK YBQAUhhTEFIAoAKACgApjCgAoAWkIKACgApgLQMKACgAoAKAFoAKAFoASgAoAWgAoAKAFpAFABQA lMApAFMAoAKAFoAKAEpAFMAoAKQCUAFMApCCmMKACgApAFMAoAKACgQUDCgAoAKAEoAKACgAoAKA CgBKBBQA00gEpgNoASgAoAKACgBV+8KAJKACgBM0AJmgAzQAlACUAFACUAFABQAUAFACigAoASgA oAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAWgAoAKACgBKAFoAKACgAoAKAEoAWgAoA SgAoAKACgAoAKACgAoAXNABQAUAFABQAUALQAoNAC5oAWgApAFABTAKQBQAlMAoAKQBQAUwCgAxQ AUAFACUAFABQAYoAKAEoASgAoASgAoAKACgAoAKACgAoAKACgAoAKADGaAHBKAHBQKQC0AFMBaAC gYUCCkAUwCkMKYBSAKACmA2TtQIjoAKACgAoAKACgAoAKACgBydaAHGgYoFIQ6gYUwCgApAIRTAA OaQDidvSmAwmgQlADTQADrQA7BFADgfWgAPI4oGOoAMUgExTASgAoAKACgApAFMCI9aBCUALjigA FADqACgBaACgAoAKACkAtABTAKQBTAKACgAoAKQBTAKACgBaBhQIWgYUAFAgpDCmAUALQAUAFABQ AUALQAUAFAC0AFABQAUgCmAUAFABQAUAFABQAUgEpgFABQAlABQAUAFABQAUAFABQIKBhQAUAFAB QAUAFABQAlABQAUAFAgoGJQAUgGnrQIKYDDQAlABQAUAFACr1FAElADc0AFACYoAKAEoAKACgAoA SgAoAKACgAoAWgAoATFAC0AFABigAxQAYoAMUAGKAEoAKACgAoAKACgAoAKAEoAWgAoAWgAoAKAE oAKAFoAKACgAoAKACgAoAKAEoAKACgAoAKACgAoAKACgAoAXNABQAUAFAC0AFABQAo60AOzQMKQC 0AFABQAlAgoGFABQAUCCgAoAKYCUgCmAUAJmgBuaACgAoASgAoAKACgAoAKACgAoAKACgAoAMUAO CmgBQoFADqACgAoAKACkAUwCgAoAWgAoGFABSEFMAoAKBjJO1AhlABQAUAFABQAUAFABQAUAOSgB w60DHCkAtMApAFABTAKQCn5Rz1pgMJoEJQAvagBpoAQcUAPBpDFpgFAByKAFzQAuaACgBMUAJQAU gCmA0mgQw0AJQAUAKtADqACgAoAWgAoAKACkAtABTAKACkAUAFABTAKQBQAUAFMB1AwoEFAwoAKA CgAoAWgAoAKACgBaACgBcUAFABQAUALQAUAFIBKYBQAtIBKYC0AFACUAFACUgCmAUAFACUAFABQA UAFABQAUAFABQAUAFABQAUAFABQAUAFACUAFABQAUAJQA09aQgpgMNACUAFABQAUAKvUUASUAMPW gBM0AOzmgAxQAlACUAFABQAUAFACUAFABQAUAFAC0AFABQAUALQAZoATNACZoAKACgAoAMUAGKAD FABQAUAFACUAFAC0AFAC0AFABQAUAFABQAUAFABQAUAFABQAUAJQAUAFABQAUAFABQAUAFABQAtA BQAtABQAlAC0AKDigBVNADqQwoAMUAFABTAKQBQAUAFABTATIoAaWoEJmgBKACgAoAKACgAoASgA oAKAFoASgAoAKADBoAULQA4KBQAtAC0gCmAUAFABQAUAFABQAUgCmAUALQMKACgAoAKACgBknWgQ ygAoASgBaACgAoAKACgAoAcvSgB4oGLQAtABQAUAFAB0Ge9ADScmgQoGKQARQMSmIbQAhFAADQA4 GgYUAG6kAuaYBSAXNAgGASfWmA6gYhAoAbgigRGx5oASgAoAKAHLQAtABQAUAFAC0AFABSAWmAUA FIAoAKACgYUCCmMKBBSAKAHUxhQAtABQAUAFABQAUAFABQAtAgoGFAC0AFIApgLQAUAFABQAUAFA BQAUAFABQAUgEpgFACUAFABQAUAFACUAFABQAUAFABQAUALQAlABQAUAFABQAUAFACUCCgAoGFAC UAIetIBKYhhoASgAoAKACgAHWgCSgBpFACUAFADgaACgBKACgBKACgAoAKAEoAKACgAoAKACgBaA CgBKACgAoAKAF2nHNAC4oAMUAFABQAUAGKADFACYoASgAoASgAoAXNAC0AFABQAlAC0AJQAUALQA UAFABQAUAFABQAlABQAUAFABQAUAFABQAUALmgBaACgBKACgBaACgBQ1ADwaQxaACgAoAMUAFADS wFMBu80CEyaAEoAKACgAoAKACgAoAKACgAoASgAoAKACgBQtADgooAWgAoAKAFoAKACgAoAKACgB KACgBaACgAoAKACgYUCCgYUCCgYtAEb9aBDaACgBKAFoAKACgAoAKACgBy9KAHikAtMYtABQAlAB mgBCaBCgYpALQMKYCGgBoFAgoAQigBOlACg0DF60AJ0oATNAC5oAM0AKGoAUNQIdmgZC3U0CEoAK ACgBQaAHUALQAUgCmAUAFABSAWgAoAKACmAUAFABSAKYBSAAM0AFAD6YwoAKACgAoAKACgAoAKAF oAKAFxQAUAFABQAtABQAUAFABQAUAFABQAUAFIApgFIBKYBQAUAJQAUAFABQAUAFABQAUAFACUAF AC0AFABQAlABQAUAFABQAlABQAUAFAgpDGt1oASmIaetACUAJQAUAFABQA7dQAm6gBKACgBaAFBo AWgBKACgBKACgAoAKAEoAKACgAoAKACgBaAEoAKACgBRQApJPWgAoAWgAoAKACgBKACgAoAQigBK AEoAKACgBaACgBaACgAoAKACgBKAFoAKACgAoAKACgAoAKAEoAKACgAoAKACgAoAKACgBQaAFoAK ACgAoAKAFFADlbJwaBj6QDScUAIXpgNLE0CG0AFABQAUAFABQAUAFABQAUAJmgAzQAUAFABQAUAL QAuaAFBoAWgAoAKAFpAFABTAKAEoAKACgAoAKACgBaQBTAKACgAoAKACgYUhEb/eNMBKACgAoAKA CgAoAKACgAoAevSgBwoAWkMKAFoAbTEITQAoHekA6mAUDCgBDQIRaQC0AIRQAlMBpFABmgBc0DDG aBCYoAMUAJQAZoAXdQA00AFABQAUAFABQA4NQA4GkAUAFABTAWkMKYgoAKQwoEFMApAFMApAFACq cUAFAwD/2Q= ________________________________________________________________________________
Subject: error
Date: Apr 26, 2008
Kolbers, my apologies. I've just found out that the POSTCARDS virus threat is a hoax. Also, Matt pointed out to me that this sort of info shouldn't be posted on the List Guilty on both counts; sorry Russ Kinne do not archive ________________________________________________________________________________
Subject: Re: Sun N Fun 2008
Date: Apr 26, 2008
John, what is the empty weight of this current version? BB On 26, Apr 2008, at 10:57 AM, John Hauck wrote: > > > Or is it just a new version of the mark III intended for EAB like > usual? > > >> LS > > > Lucien: > > This is an updated version of the MKIII Extra intended for EAB. > > It has turned out to be the beginnings of a pretty good airplane. > TNK is in the process of taking some of the excess weight off the > airplane. > > We still have some tweaking to do. > > The Morse Cables for the aileron control work well. > > The 45 degrees of flaps increase the capabilites and safety of the > aircraft. > > Looks like cruise speed will be about like most good MKIIIs, around > 85 mph. Hard to take the Kolb out of a Kolb. Don't think we will > be seeing 120 mph any time soon. > > Hopefully, I can find time to return to London before Oshkosh to do > some more work. I want to raise the nose of the X about 6 more > inches to get an idea of how much this will improve take off and > landing configuration. When I get agressive on takeoff and > landing, I bump the tailwheel. > > Slow speed flight is good. For those that want to hover, get a > helicopter. ;-) > > john h > mkIII > > ________________________________________________________________________________
Date: Apr 26, 2008
Subject: Re: Some Sun'n Fun photo's for the Dial Up folks
D Lucas wrote: > Enjoy ! If you want the Hi Res version, let me know. > > David. David, Thanks for the pictures! Terry - FireFly #95 ________________________________________________________________________________
Date: Apr 26, 2008
Bob B: 680 lbs with BRS. A lot of weight can be saved by redesigning the fiberglass seats. This is in the plans. There is no other equipment on board. Very basic. So if you start adding radios and other equipment, weight will head back up. john h mkIII John, what is the empty weight of this current version? BB ________________________________________________________________________________
Date: Apr 26, 2008
Subject: Four New Email Lists At Matronics!!
Dear Listers, I have added four new Lists to the Matronics line up today. These include the following categories: Citabria-List Citabria, Decathlon, Scout, and Champ Zenith601-List Zenair Zodiac CH 601 Zenith640-List Zenair Zodiac CH 640 Zenith701801-List Zenair STOL CH 701 and CH 801 All services are enabled and now available including Search, Browse, Digest, Archives, Forums, Chat, etc., etc. etc...: Citabria: http://www.matronics.com/navigator?citabria-list Zenith601: http://www.matronics.com/navigator?zenith601-list Zenith640: http://www.matronics.com/navigator?zenith640-list Zenith701801: http://www.matronics.com/navigator?zenith701801-list To subscribe, go to the Matronics Email List Subscription Form: http://www.matronics.com/subscribe To check the new Lists out on the Matronics Forum go here: http://forums.matronics.com Enjoy the new Lists!! Don't forget me during the Fund Raiser! :-) Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Wing design and other stuff
Date: Apr 26, 2008
Nice looking wingtip Mike, looks like a great solution to modify a standard wing to accept the tips. Your idea about just building over the original wingtips on my Kolb makes a lot of sense, easier is always better :) Keep the pictures coming, I look forward to seeing your progress. Did you see how forward did the counterweights for the ailerons with the droop tips ? I have detailed pictures of that if you need them. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179507#179507 ________________________________________________________________________________
Subject: It's an airplane again
Date: Apr 27, 2008
I just got my airplane back together finally. It was a long road. All I intended to do was replace a broken stringer and wound up replacing the stringer, the windshield, instrument panel and fuel tank. I found two rotted steel tubes on the cage which were repaired. Then recover and repaint the cage and fuselage tube. The fuel tank I had ordered was going to hold 8 gals but since the tank doesn't sit level it only hold a little over 7 gals before in starts coming out of the filler neck. I may be able to put a hose over the neck if I ever want to fill it past 7 gals. I've attached a pic here but you can see some better ones at my web site. http://kolbfirestar.googlepages.com/myplane -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179571#179571 Attachments: http://forums.matronics.com//files/rebuild1_109.jpg ________________________________________________________________________________
Subject: Re: It's an airplane again
Date: Apr 27, 2008
> I just got my airplane back together finally. > -------- > Scott Olendorf Scott O: Brings back a lot of memories looking at your FS. Glad you got it back together again. Hope to see you at Homer's in June. john h mkIII ________________________________________________________________________________
Subject: Re: Dead Stick Video
Date: Apr 27, 2008
Thanks guys. I knew that I had less than 5 minutes on my video card so I had to be efficient. :o Kip -------- Kip Firestar II (born September 2000) Atlanta, GA N111KX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179655#179655 ________________________________________________________________________________
Date: Apr 27, 2008
Subject: Droop tip progRess
Sorry about the typo. Must be all the toxic fumes I'm inhaling. Mike --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Apr 27, 2008
Subject: Droop tip progress
Kolb people, I thought I'd share a couple of photos of my wing's "droop tip project". Before anyone comments, if you can see it in the picture, so can I! Keep in mind, these items you are looking at are "Plugs"! These are the mock-ups you make, to be able to make a mold around them. Once your mold is made, these will likely get destroyed. A couple of pointers. I am NOT happy with my choice of materials. The foam/joint compound worked okay for a basic shape, but I encountered all kinds of crap trying to come up with a truely decently smooth finished set of plugs. IF I were to do it again, I would choose a different method to come up with finished shapes. I have a few spots (bumps) that I just cannot seem to fix. I think I've work on them for two days. No matter what I do, the locations continue to bulge! Screw it, I'll fix the problem in the molds! The first few photos deal with the shaping portion. I think it is the first photo that shows how I made Magic Marker lines to show the contour lines.The last couple reflect the PVA coating on the right tip. (The left one already has the PVA coating, and two coats of gel coat). Remember, the order of events are: shape the item, paint it to achieve a smooth finish, release wax (2-3 coats), then PVA (2 coats), then 3 coats of gel coat epoxy, followed by 5-6 layers of glass/epoxy resin. This creates your mold. Wait a day, and then pop it it out, and repeat the process in reverse, for your finished project.....wax, PVA, gel coat, 3-4 layers of glass/resin, wait a day...pop out finished gel coated item!! Oh BTW, this a hellava lot of work!! Much easier to buy them, but like I said, I need them now, not later. Besides, it's a lot of fun, about as much fun as digging a septic system by hand! (I'd rather being putting Poly Fiber on my wings.) Sorry if these photos are hard on the dial-up folks. I only know much to attach these photos like this. Mike Welch MkIII CX --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Apr 27, 2008
Subject: More droop tip photos
Kolb People, Some more pics to look at. Note on photo #11 the black line on the rough one. That represents the droop tip edge cut line. You'll also notice on photo #01 the red line representing the front curve. To achieve a fairly simetrical set of tips, I drew a red line between them on the table. Each tip was set EXACTLY 3" back (as measured parallel to the bottom of the wing rib). I then placed a ridged piece of aluminum plate right in the center, standing as a "wall" between them. (If you look closely in photo #01 you can see the aluminum straight-edge separating the two tips). I shaped and shaped and shaped the first one, until I was satisfied with it's profile, put it back on the table, and transferred the dimensions to the rough one. One real nice feature of using laminated foam is that the white layer lines will be the same, if you've done a good job being simetrical. (as seen in photo #02, but note the top layer is one 2" thick foam, rather than two 1" thick foam layers) As a side by side comparison, they are as gnat's ass close as I care about. One last thing to note, for those that have ANY intention of actually making their own droop tips. If you'll notice on those close-up photos of the Yellow Xtra that David took, the factory tips allow for the captured air to slip past the ailerons. Although these nice droop tips do appear to "catch" the air trying to escape the underside of the wing on it's outer edge (and that is good), it appears to me this style will allow that air to just exit the rear of the wing, but not affect the ailerons. My style will be a two piece tip, where the front piece attaches to the main wing, as usual, and the rear piece attaches to the aileron, becoming an extension of the droop tip all the way to the rear of the wing. This style will insure that all the captured air a) remains under the wing, and b) all that capured air will also affect the aileron, before exiting the wing. This aileron droop tip extension will also incorporate the aileron's balance spade. This NOT meant to be a criticism of the Kolb droop tip on the new Xtra. Their style is fine for what they wanted it to do, and they do make the plane look awesome. It definitely augments the wing's performence. I am simply pointing out that since I have to build my own, I am incorporating "additional" features. That's all. Mike Welch PS. I have more photos, if anyone wants to see them, email me directly. --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Apr 27, 2008
Subject: Last one of droop tips
One last photo. I just sprayed the PVA on this one. (Yes, I saw the runs and brushed them out). Mike --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Subject: more droop tip photos
Date: Apr 27, 2008
Mike, commendations for the ambition and nice work. I'm too lazy to make molds for just one application. Rude and crude is my way. I wanted a fairing for that ugly radiator sticking up front. First bang out a metal shell. I made it just a little too snug so some amendments had to be banged out. Then epoxy foam board externally. File to shape. Epoxy glass externally using the hi tek garbage bag and duct tape method. It will take SOME bondo and sanding to finish for paint but ought to look better than before and cut some drag. DSCN1556.JPG DSCN1558.JPG first the dog wanders in front DSCN1559.JPG then my knee. I give up DSCN1560.JPG
Date: Apr 27, 2008
Subject: Re: Sadler Vampire
John Hauck wrote: > > > . >> What engine did they have on it at Lakeland John? > > > Denny: > > I don't know. I was not interested enough in it to inquire. The two > place looked really shabby. > > john h > mkIII It had a Rotomax 2 rotor charge-cooled rotary engine, rated at around 120 hp. They supposedly had a 1 rotor in the single-seat, but it was still on the roof of their trailer when I visited. The guy I talked to knew very little about the engine, & not much more about a/c design (he tried to tell me that the 2-seat with 120 HP was good for up to a 1000 hp V8 (not a typo) that would 'blow away anything else out there'. The 1 rotor engine might be worthy of consideration for UL type planes; it's around 60 hp & should be almost as light as a 2 stroke with the same or slightly better fuel burn. I tried talking to the Rotomax people, but the only guy in the tent at the time was their gyro pilot. All he knew was that the 2 rotor made plenty of power for the 2 seat gyro he flew. The engines are descended from the OMC snowmobile/outboard rotaries. Charlie ________________________________________________________________________________
Date: Apr 27, 2008
Scott, Dang, that baby looks Great! I hope I can finally get back to Shreveport this year and also make Homers. Hope to see you there and get a better look at your bird. Denny ________________________________________________________________________________
Subject: Who's going to Monument Valley?
Date: Apr 28, 2008
What's the count to MV this year? -------- Dave Rains N8086T Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179764#179764 ________________________________________________________________________________
Date: Apr 28, 2008
My wife and I are departing to the West from Dallas on Weds May 14th, if it 's as windy then as it's been the last few weeks we might stop short of MV or else we should be there by the end of the 15th.> Subject: Kolb-List: Who 's going to Monument Valley?> From: RangeFlyer72(at)yahoo.com> Date: Mon, 28 A e posted by: "Dave Rains" > > What's the count to M V this year?> > --------> Dave Rains> N8086T> > > > > Read this topic onlin e here:> > http://forums.matronics.com/viewtopic.php?p=179764#179764> > > -======================== ==> > > ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Subject: Re: Who's going to Monument Valley?
Date: Apr 28, 2008
I will be there on Friday. I will be driving. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "Dave Rains" <RangeFlyer72(at)yahoo.com> Sent: Monday, April 28, 2008 6:24 AM Subject: Kolb-List: Who's going to Monument Valley? > > What's the count to MV this year? > > -------- > Dave Rains > N8086T > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=179764#179764 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 28, 2008
> I will be there on Friday. I will be driving. > > Rick Neilsen Morning Gang: Hope to arrive Thursday afternoon. john h mkIII ________________________________________________________________________________
Date: Apr 28, 2008
I will be driving, and my wife and I will be there Saturday morning. She teaches school and it's near the end of the school year. No way can she get off early. Mike Welch Richard & Martha Neilsen wrote: I will be there on Friday. I will be driving. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "Dave Rains" Sent: Monday, April 28, 2008 6:24 AM Subject: Kolb-List: Who's going to Monument Valley? > > What's the count to MV this year? > > -------- > Dave Rains > N8086T > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=179764#179764 > > > > > > > > > > --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Apr 28, 2008
Subject: Re: more droop tip photos
Brother Bob, Yeah, I gotta make some kind of radiator shroud, combination engine cowling, too. My plan is to have it begin at the leading edge of the wing, and flair back toward the sides of the engine. I haven't spent too much time thinking about the specifics, but I kinda know what I want....I think mine is referred to as a "nacelle". (like Uncle Craig's) Mine will have two inlets. The usual for the radiator, and the other other one is for the air inlet for the turbo ducting. Oh, BTW, in one of my droop tip photos you can see my complete engine package sitting under my work bench. Jeesh!! I can't wait until the day I can bolt it back on, 'cause that'll mean the fuselage is finish! Gotta get to work on those tips, adios!! Mike Welch robert bean wrote: Mike, commendations for the ambition and nice work. I'm too lazy to make molds for just one application. Rude and crude is my way. I wanted a fairing for that ugly radiator sticking up front. First bang out a metal shell. I made it just a little too snug so some amendments had to be banged out. Then epoxy foam board externally. File to shape. Epoxy glass externally using the hi tek garbage bag and duct tape method. It will take SOME bondo and sanding to finish for paint but ought to look better than before and cut some drag. --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Subject: Kolb Droop Wing Tip And Aileron Counterblance Photos
Date: Apr 28, 2008
Here are some pictures of the new Kolb wingtip and Aileron counterbalance design on their MK III Xtra that was at Sun And Fun. The pictures are reduced in size for posting on the list. If anyone wants the large, full sized pictures ( 2.5 MB Each ) let me know and I will email them to you. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179822#179822 Attachments: http://forums.matronics.com//files/sunandfunairshowfloridalakelandairplanes04_11_2008_084_385.jpg http://forums.matronics.com//files/sunandfunairshowfloridalakelandairplanes04_11_2008_082_194.jpg http://forums.matronics.com//files/sunandfunairshowfloridalakelandairplanes04_11_2008_081_157.jpg ________________________________________________________________________________
Date: Apr 28, 2008
"What's the count to MV this year? Dave Rains N8086T" Hi Dave, you and Will won't be lonely at MV. Even I am going so we can talk about helicopters and Kolbs also. do not archive Dave is getting close to finishing it, just waiting on the main rotor. **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 28, 2008
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: April 15 Spot Pilot NPRM
Have any of you taken a close look at the April 15 Sport Pilot NPRM changes? Any thoughts on any of the 22 proposed changes? I'll be really glad about the change to allow us to fly 2000' AGL, even if that takes us above 10,000'. The biggest omission that I see - no mention of allowing the use of ELSAs as trainers. In my area (northwest Oregon and southwest Washington) there are no longer any flight instructors for fixed wing ELSAs, formerly "fat" ultralights. That means that folks who are intrigued by Hawks, Quicksilvers, Kolbs, Challengers, etc. have no where to go to get flight training...unless they travel 4+ hours. Any other thoughts about any of these proposed changes? Arty Trost Maxair Drifter Sandy, Oregon www.LessonsFromTheEdge.com "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Subject: Re: April 15 Spot Pilot NPRM
From: "John H Murphy" <mailjohnmurphy(at)gmail.com>
Date: Apr 28, 2008
ELSA cannot be used to train in???? That's news to me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=179949#179949 ________________________________________________________________________________
Date: Apr 28, 2008
Subject: Re: Balance Master ( Prop Balancer)
In a message dated 4/28/2008 6:50:42 P.M. Central Daylight Time, planecrazzzy(at)yahoo.com writes: I'm running two blades on my IVO...Last year it seemed to run just fine... Didn't like the shaking/vibration , so I ordered the Balance Master for Props....( Mercury inside ) Mike, I had a similar experience with my 2- blade IVO. I never figured it out until I did a de-carbon. When I took off my prop the little ear on the cam of one blade had broken off and the pitch on that blade was different than the good blade. You might want to check that out if you havent. I ordered a new blade with the knurled plates and have had no more problems. Ed (FF# 62 ) **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 28, 2008
At 07:09 AM 4/25/2008, N111KX (Kip) wrote: >I just added another video. It's a bit shakey but I'm working on it... Here's another. Nothing much, but as you can see there aren't too many emergency landing places around here... unless I add floats and use the river (the airport has a ramp). And I've _got_ to do something about that helmet chin strap! http://www.youtube.com/watch?v=8QFuEA_NpJs -Dana -- Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. ________________________________________________________________________________
Date: Apr 28, 2008
Subject: Re: Pennzoil 2 cycle oil best prices?
Date: Apr 29, 2008
Try here; http://www.pennzoil.com/service.html I got mine from SOPUS in Selkirk, NY. They wholesale but will sell direct if I show up with cash. It was a good price because there was no shipping cost. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180011#180011 ________________________________________________________________________________
Date: Apr 29, 2008
Thanks! My Napa store had 17 bottle for $1.99 each. The pennzoil link would not take my zip code for some reason. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180016#180016 ________________________________________________________________________________
Date: Apr 29, 2008
Try your local NAPA auto parts store. some have it, or they can probably order it for you in case lots. Dwight Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180009#180009 ________________________________________________________________________________
Subject: Pennzoil 2 cycle oil best prices?
Date: Apr 29, 2008
Where do you all buy your Pennzoil air cooled 2 cycle oil from? I need to buy a case of 16 ounce bottles. Its hard to find locally. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180008#180008 ________________________________________________________________________________
Subject: Re: 50 foot paint job
Date: Apr 29, 2008
Larry C: Good for you. Did you get any hawk or falcon feathers in the paint? Must be this Spring weather. I got some work done on my bird and have a bit more tuning, maintenance, and cleanup to do before I am ready to fly West. Yesterday I replaced the original 912 tach, after 14 years and 2,500+ hours. It was worn out. Still operational, but the innards were worn loose as a goose. The new tach is nice and smooth operating, with a good dampening system. Did a tach check on the new one and it was right on with my little GloBee prop tach check meter. I picked up the prop tach from an RC dealer some years ago for about 25.00. I also replaced an hour meter I purchased from Aircraft Spruce when I installed the new 912ULS last year. It wasn't what I thought it was or wanted but did not have time to get another. Darn thing was ugly, but operated ok. I started a search for VDO hour meters and found one on Ebay for 20.00. I took a few days to run it forward to 186 hours, then stuck it in the MKIII. The new hour meter with Caterpiller yellow logo looks great. I haven't flown the MKIII since my return from London in March. It is covered with barn dust and bug crap. The carpenter bees have been hard at work trying to cut the hanger down. The 912 needs a carb sync and the Warp Drive needs a little pitch removed. We had the prop set light on the new factory MKIIIx. It climbed at 5400 and leveled out at 5500 rpm. After an oil and filter change, a little flight testing and pilot reorientation, I'll be good to go. Times a wasting. Two weeks until departure for MV. john h mkIII Well I have finally breathed the last of the paint fumes again. Larry C ________________________________________________________________________________
Subject: Re: Droop tip progress
Date: Apr 29, 2008
Mike I had the same problem with the foam and adhesive. I used crack insulating foam in a can for the adhesive to join things together and it compresses when sanded. I ended up roughing it out and using sheet rock joint compound to smooth over the low spots. Ron Mike Welch wrote: > Kolb people, > A couple of pointers. I am NOT happy with my choice of materials. The > foam/joint compound worked okay for a basic shape, but I encountered > all kinds of crap trying to come up with a truely decently smooth > finished set of plugs. IF I were to do it again, I would choose a > different method to come up with finished shapes. I have a few spots > (bumps) that I just cannot seem to fix. I think I've work on them for > two days. No matter what I do, the locations continue to bulge! Screw > it, I'll fix the problem in the molds! > ________________________________________________________________________________
Date: Apr 29, 2008
> I'm flying my trusty C175B, Will and I are picking up Dennis Kirby at Double Eagle on the way. > Dave Dave R: Thought Dennis K was closer to Sandia East. You gonna make him drive all the way across Albuquerque? ;-) john h mkIII ________________________________________________________________________________
Date: Apr 29, 2008
> http://ill-eagleaviation.com/snf_2008.htm > > -------- > Scott Scott: Thanks for posting the S&F photos. The MKIIIx would have gotten off the ground quicker, but the tailwheel was in the way. Same, same landing. Still, Rahill was not getting off much quicker than me. john h mkIII ________________________________________________________________________________
Date: Apr 29, 2008
16 oz bottles? That has to be old stock if so....Advanced Auto carried it for a while...I bought all of their stock so as to drive their inventory program...Later a friend in Glasgow,Ky found a supplier there and I was able to buy it for 36 bucks and change for 24 16 oz bottles...but that was a year and a half ago...Herb At 10:38 AM 4/29/2008, you wrote: > >Thanks! My Napa store had 17 bottle for $1.99 each. > > >The pennzoil link would not take my zip code for some reason. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=180016#180016 > > ________________________________________________________________________________
Date: Apr 29, 2008
I'll pick him up wherever he wants, he mentioned Double Eagle. Looking forward to seeing the whole gang. Dave -------- Dave Rains N8086T Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180096#180096 ________________________________________________________________________________
Date: Apr 29, 2008
planecrazzzy wrote: > > Here's a copy & paste from the guy talking about the oil & ball bearing method... > . > . > The idea of dynamic (fluid) balancing had been used as far back as 1908 by German scientists and improved by Americans in the early 1940's using steel ball-bearings in tubes filled with oil. So Chris, being an amateur-inventor familiar with such things, took the idea one step further by creating the Balance Master using liquid Mercury. It is now another of his 15 widely-diversified patented inventions. > > . > . > . > Gotta Fly... > Got two of them working on my Firefly. Prop Balancer and also the flywheel pulley Engine Balancer at the other end. Seems to be working fine for me! Yes, they are both made with a small amount of mercury in sealed tubes. Don't let the word out about the mercury of I will be banned from most places!! It's right up there with nuclear material in todays world of over zealous people. I've got several pounds of it if your interested. Terry - FireFly #95 ________________________________________________________________________________
Date: Apr 29, 2008
Hey Mike W: > You recently (and again just now) mentioned the tailwheel touched when you take off and land in the new Xtra. Only when making agressive take offs and landings, at air shows. Normal operation is ok. >You said you would try to "work on it" the next time you get a chance. I >am curious about your adjustment >appraoch. > Did you plan on raising the leading edge of the hor. stab, or did you > consider shortening the tailwheel rod, or both? Neither. I plan on stretching the main gear legs. The tailwheel hits the ground because there is not enough altitude in the main gear to allow the aircraft to rotate agressively on take off and land in a nice 3 point stance. The main gear are longer than the old ones, but still not enough for me. john h mkIII ________________________________________________________________________________
Date: Apr 29, 2008
At 09:08 AM 4/29/2008, grantr wrote: >Where do you all buy your Pennzoil air cooled 2 cycle oil from? > >I need to buy a case of 16 ounce bottles. Its hard to find locally. I've been buying it from Advance Auto Parts (though in 8oz bottles). In the past I was buying it from http://oil-store.com/ , which I should do again now that I have the plane flying. -Dana -- If it were truly the thought that counted, more women would be pregnant. ________________________________________________________________________________
Date: Apr 29, 2008
Grant, I don't want to start an oil war with others on the list, but perhaps you would be open to using a different brand. Specifically Yamalube-2. This is a two-cycle grade of oil sold by most Yamaha motorcycle and snowmobile dealers. It can be used as a premix, or in the autolube pump systems. Yamaha has been selling this oil for many years and it has a proven track record. And, if you don't think that grade of oil is suitable, they also sell Yamalube-R which was created for use in the racing bikes under extreme conditions. It costs a little more. If you have a Yamaha dealer near you, check it out. Bill Varnes Original Kolb FireStar Audubon NJ In a message dated 4/29/2008 3:51:44 P.M. Eastern Daylight Time, grant_richardson25(at)yahoo.com writes: --> Kolb-List message posted by: "grantr" Where do you all buy your Pennzoil air cooled 2 cycle oil from? I need to buy a case of 16 ounce bottles. Its hard to find locally. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180008#180008 **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Subject: Re: 50 foot paint job and trailer for sale!
Date: Apr 29, 2008
Sent: Tuesday, April 29, 2008 6:52 AM Subject: Re: Kolb-List: 50 foot paint job Larry C: Good for you. Did you get any hawk or falcon feathers in the paint? Gang, The new legs actually do make the plane look better than I expected. I don't need a booster seat to get in, but close. They have unfortunately created another problem, because it is now too tall to get into the trailer. I don't need the trailer any more since I have my own hanger and runway, so it is for sale if anyone would like one. It is 25 feet long, full drop down door, a nifty lifting boom support. The roof has been foamed so that it does not build up moisture and drip all over your plane. The trailer with a plane inside weighs less than 1800 lbs. I hauled it with a 91 Subaru most of the time. I can supply pictures and weight empty as well as measurements for anyone who might be interested. $1800. would take it. As for the falcon she laid three eggs this year. Going to have to find her a boyfriend I guess. Larry C ________________________________________________________________________________
Date: Apr 30, 2008
planecrazzzy wrote: > I had some shaking/vibrating ( wings off ) when I started my plane > last weekend... > > I'm running two blades on my IVO...Last year it seemed to run > just fine... > > Doubt the balance master would help much, never heard of a case where it did help very much. A much cheaper option is to make sure the blades have the same pitch. This is the trick to a smooth IVO in 2-blades - with the hub bolts at full tightness, the torque rods can be slightly "clamped" and won't move on their own when you're in the region of natural pitch. You can see this by, say, cranking the pitch adjust in a turn or two from natural pitch and then back it out. You'll likely notice the screw unscrews very easily, which means the cams are stationary while the screw moves through the "play" between the cam and its big groove. If that's happening, make sure when you're doing the pitch adjust to start, say, overly coarse and only rotate the bolt in the fine direction until the right pitch is achieved. DON"T back it out at that point, lock it down right there. I ran the IVO in 2 blades for years on my trike with very smooth results as long as I made sure of the above...... in 2-blades it's superb on a fast plane..... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180259#180259 ________________________________________________________________________________
Date: Apr 30, 2008
lucien wrote: > > > planecrazzzy wrote: > >> I had some shaking/vibrating ( wings off ) when I started my plane >> last weekend... >> >> I'm running two blades on my IVO...Last year it seemed to run >> just fine... >> >> >> > > > Doubt the balance master would help much, never heard of a case where it did help very much. > > A much cheaper option is to make sure the blades have the same pitch. This is the trick to a smooth IVO in 2-blades - with the hub bolts at full tightness, the torque rods can be slightly "clamped" and won't move on their own when you're in the region of natural pitch. > > You can see this by, say, cranking the pitch adjust in a turn or two from natural pitch and then back it out. You'll likely notice the screw unscrews very easily, which means the cams are stationary while the screw moves through the "play" between the cam and its big groove. > > If that's happening, make sure when you're doing the pitch adjust to start, say, overly coarse and only rotate the bolt in the fine direction until the right pitch is achieved. DON"T back it out at that point, lock it down right there. > > I ran the IVO in 2 blades for years on my trike with very smooth results as long as I made sure of the above...... in 2-blades it's superb on a fast plane..... > > LS > > -------- > LS > FS II > As I said before, I found them to help. Even Rotax must have some faith in them, they have something similar, a hydro dampener, on their larger two strokers. Adjusting the pitch on a wood prop is a bit dicey! Yeah, they won't make up for a poorly balanced prop, but will give that final tweak to smooth things out. Don't condemn that which you haven't tried, Terry - FireFly #95 ________________________________________________________________________________
Date: Apr 30, 2008
Guys, I hate to start a panic here but Pennzoil has discontinued production of this product, the only supply out there is what is in circulation. It has something to do with Shell buying the product line. Lockwood is testing several new products as a replacement. Lockwood recently bought the last 500 cases available. No one knows about this yet so it is a good time to stock up. Lockwood seems to think that the replacement will be as good or better. Lockwood originally did the testing for Rotax and Penzoil. Steve B Firefly 007/Floats Firefly 0040/ Floats 2008 SnF Grand Champion do not archive In a message dated 4/29/2008 8:01:55 P.M. Eastern Daylight Time, d-m-hague(at)comcast.net writes: >Where do you all buy your Pennzoil air cooled 2 cycle oil from? > Steve B Firefly 007/Floats Firefly 0040/ Floats 2008 SnF Grand Champion do not archive **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Subject: 50 foot paint job and trailer for sale
Date: Apr 30, 2008
Gang, Sorry, I should have mentioned that I am in the Southeastern part of Oregon. Unfortunately the trailer will not accommodate anything larger than a Firestar II. My asking price is $1800.00. Photos available. Larry C ________________________________________________________________________________
Date: May 01, 2008
> > s I said before, I found them to help. Even Rotax must have some faith in them, they have something similar, a hydro dampener, on their larger two strokers. Adjusting the pitch on a wood prop is a bit dicey! > Yeah, they won't make up for a poorly balanced prop, but will give that final tweak to smooth things out. > > Don't condemn that which you haven't tried, > > Terry - FireFly #95 > You're quite right that I only have 2nd hand info, so indeed my opinion isn't authoritative on it by any means. Yes, the 582 has a balancing device on the flywheel similar to the balance master, but you have to remember that's a much higher rpm situation and the imbalances it's used for are generally smaller than a prop spinning at 2500 rpm. I do, however, have years of 1st hand experience with the IVO running in 2-blades and, in that experience, I havn't found a relatively expensive solution like the balance master thingy to be necessary for smooth operation. Again, the typical problem with the IVO is mismatched pitch on the blades rather than imbalance. IVO does pretty good getting their props balanced out of the box (tho occasionally they mess up). The pitch adjustment, however, ain't so grand with the play in the pitch adjust screw and the tendency for the torque rods to sieze slightly in their holes when the hub is tightened down to spec. So... I'm merely suggesting that before you go out and spend a bunch of money on a balancer, set up the prop correctly FIRST - it's a zero-dollar solution anyway so it's the most sensible place to start. THEN check the balance THEN try the more expensive solutions..... Just my experience, worth what you paid for it, LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180494#180494 ________________________________________________________________________________
Date: May 01, 2008
At 11:15 AM 5/1/2008, lucien wrote: >Yes, the 582 has a balancing device on the flywheel similar to the balance >master, but you have to remember that's a much higher rpm situation and >the imbalances it's used for are generally smaller than a prop spinning at >2500 rpm. Is the 582's device a radial balancer, or just a harmonic balancer that damps out the torsional pulses? I would think the latter, protecting the gearbox. >So... I'm merely suggesting that before you go out and spend a bunch of >money on a balancer, set up the prop correctly FIRST - it's a zero-dollar >solution anyway so it's the most sensible place to start. >THEN check the balance THEN try the more expensive solutions..... Agreed. No point in band-aiding a problem that can be properly fixed. It should also be remembered that a balancer like the balancemaster can only help with radial weight imbalance, which causes motion in the plane of the propeller. If your blade pitch is mismatched, that creates an angular vibration or shaft wobble that a radial balancer can do nothing about. -Dana -- Refuse Novocain... Transcend Dental Medication. ________________________________________________________________________________
Date: May 01, 2008
I had a lot of vibration in my Ivo prop after it had run smooth for 600 hours. When I took it off, I saw that one of the cams had worn where it contacted the groove. I replaced that cam and the vibes disappeared. The worn cam had caused that blade to have a different pitch than the other. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 21 years flying it Kolbra 912UL N20386 0 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180523#180523 ________________________________________________________________________________
Date: May 01, 2008
Subject: Re: UltraStar Belt redrive ratio
At 04:45 PM 5/1/2008, jb92563 wrote: > >Does anyone know what the standard UltraStar belt drive redrive ratio was >for the Cuyuna UL II-02? Mine's 2:1, and I have no reason to believe it's not original. -Dana -- Hit any key. With what? ________________________________________________________________________________
Date: May 01, 2008
Subject: Re: Pennzoil 2 cycle oil OUT OF PRODUCTION
IN CASE YOU MISSED THIS POST UNDER THE OLD TITLE steve In a message dated 4/30/2008 9:26:15 P.M. Eastern Daylight Time, N27SB(at)aol.com writes: Guys, I hate to start a panic here but Pennzoil has discontinued production of this product, the only supply out there is what is in circulation. It has something to do with Shell buying the product line. Lockwood is testing several new products as a replacement. Lockwood recently bought the last 500 cases available. No one knows about this yet so it is a good time to stock up. Lockwood seems to think that the replacement will be as good or better. Lockwood originally did the testing for Rotax and Penzoil. Steve B Firefly 007/Floats Firefly 0040/ Floats 2008 SnF Grand Champion do not archive In a message dated 4/29/2008 8:01:55 P.M. Eastern Daylight Time, d-m-hague(at)comcast.net writes: >Where do you all buy your Pennzoil air cooled 2 cycle oil from? **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Date: May 01, 2008
Subject: Flawless Firestar possibly for sale soon.
Kolb guys, and wanna-be Kolb guys, I had a chat with my good buddy that has been building a beautiful Firestar. He's a retired corporate pilot, and doesn't do email, therefore he is not a member of the Kolb-list. It is virtually finished, and has been registered ESLA. As far as I know, all the paperwork and registration is completed. The airplane is of exceptional quality. It is the style that has no nosecone/windscreen. The reason he is contemplating selling it is because of all the crap he's had to go through from that loser that makes the Hexadyne engine. He has been waiting for more than a month for a replacement ECU computer for this brand new engine. Oh, BTW, THIS engine is a replacement for a previous model Hexadyne that he was having problems with. These engines were brand new, straight from the Hexadyne owner. Crap product, and even worse, crap company. (I told him he should have bought an HKS, he says "yeah, I know"!) If he can get the new engine computer anytime soon, it may very well be a great flying plane, but as of this moment, it has never lifted off the ground. I have seen him do some fast taxi-ing, raising the tailwheel, and all that kind of stuff. 60 HP on a Firestar makes for a brisk performer!! Anyway, he says he's getting quite despondent about the whole plane! So, if you know anyone looking for a completely fully built, fully registered, awesome plane, send me an email and I'll check with him to see if he's finally made the commitment to get rid of it. To give you an idea of the kind of dedication this guy gave his Firestar, he bought an $8000 custom-made aluminum enclosed trailer to haul it in. Like I said, it isn't officially for sale, yet, but if he knew there was someone interested in taking it off his hands, he may just give up on it. Mike Welch --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: May 01, 2008
From: william sullivan <williamtsullivan(at)att.net>
Subject: Firestar project
I went to the airport to switch the wing struts side to side, and found out that there is a right and left. That corrected a slight negative dihedral. A full power engine run-up produced 6500 rpm. I only held it for about a minute, and CHT was only about 250. Low speed taxi tests went very well, doing S-turns, straight, and U-turns to both sides. Very easy to handle, and very predictable. Best taxi rpm was 2700, and much below that the engine would load up during extended running. I made about 8 round trips on a 900 foot runway. I stopped to talk to someone, and we noticed that both of the landing gear legs were bent. They were brand new, and apparently the previous owner had made some legs. Looked good, fit good, but soft as butter. I have the originals- only slightly bent- and will straighten and re-install. I think I'll pick up some spares. The other spare bent legs that came with the plane also show signs of not being made by Kolb. They are going right in my scrap pile. I have to bring a drill and pop rivets for the pitot tube boss. I had used some epoxy paste to secure the tube to the mounting plate, and it stuck the plate to a decal under it. The decal, however, wasn't stuck to the nose too well. I intend to do about 8 hours of ground tests to thoroughly shake out any other problems. Bill Sullivan FS/KX/447 Windsor Locks, Ct. ________________________________________________________________________________
Date: May 01, 2008
Steve, Do mean Pennzoil is phasing out Air-cooled Two stroke oil, or ALL two stroke oil? Could they be replacing it with their snowmobile oil? It is rated TC and TCW3. Says on their website that it is Rotax approved. There are a lot of air cooled Rotax powered snowmobiles out there. I wouldn't think they they would want to give up on the entire two stroke market, but stranger things have happened. -------- Roger in Oregon 1992 KXP 503 - N1782C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180630#180630 ________________________________________________________________________________
Date: May 01, 2008
Roger - Pennzoil air cooled isn't TC rated - and isn't compatible with Pennzoil's regular 2-stroke TCW3 oil. (According to Phil Lockwood.) Arty Sandy, Oregon --- "R. Hankins" wrote: > > > Steve, > Do mean Pennzoil is phasing out Air-cooled Two > stroke oil, or ALL two stroke oil? Could they be > replacing it with their snowmobile oil? It is rated > TC and TCW3. Says on their website that it is Rotax > approved. There are a lot of air cooled Rotax > powered snowmobiles out there. I wouldn't think > they they would want to give up on the entire two > stroke market, but stranger things have happened. > > -------- > Roger in Oregon > 1992 KXP 503 - N1782C > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=180630#180630 > > > > > > > > > browse > Un/Subscription, > FAQ, > http://www.matronics.com/Navigator?Kolb-List > > Forums! > > Admin. > > > > > www.LessonsFromTheEdge.com "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Date: May 01, 2008
Arty, Pennzoil air cooled is rated API Service TC. (You may have thought I meant NMMA TC-W vs TC-W3) Pennzoil snowmobile is rated NMMA TC-W3 and also API Service TC. I've attached the manufacturers documentation below. -------- Roger in Oregon 1992 KXP 503 - N1782C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180638#180638 Attachments: http://forums.matronics.com//files/2_cycleaircooled_197.pdf http://forums.matronics.com//files/advancedperformancesnowmobile_104.pdf ________________________________________________________________________________
Date: May 02, 2008
Subject: Pennzoil 2 cycle oil OUT OF PRODUCTION
Roger, I am surprised that nobody is picking up on this topic except you. PENNZOIL AIR COOLED 2 STROKE OIL IS GONE. Only existing stock at retailers is left. Lockwood Aviation bought the last 500 cases. according to the nice lady at the Lockwood booth at SnF it has to do with Shell buying the Pennzoil line. I used to buy my oil from a Pennzoil quick change oil place. He would sell it to me at cost. A few months ago he could not get it any more. He said he was told it was out of production. Lockwood Aviation confirmed this at SnF and was surprised I knew. I was just trying to give you guys a heads up. NOBODY KNOWS ABOUT THIS YET. Steve In a message dated 5/1/2008 11:45:17 P.M. Eastern Daylight Time, rphanks(at)grantspass.com writes: Steve, Do mean Pennzoil is phasing out Air-cooled Two stroke oil, or ALL two stroke oil? Could they be replacing it with their snowmobile oil? It is rated TC and TCW3. Says on their website that it is Rotax approved. There are a lot of air cooled Rotax powered snowmobiles out there. I wouldn't think they they would want to give up on the entire two stroke market, but stranger things have happened. -------- Roger in Oregon 1992 KXP 503 - N1782C **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Subject: 100LL long term in 912
Date: May 02, 2008
Hi all, I asked this over on the titan yahoo list also, but since there're long-term 912 operators here I'll ask the same thing here. I'm sort of thinking ahead about the possible arrival of alcohol laced mogas here in NM (don't know if the bill passed but if it did, this'll start this coming january) and at that point I'll have to make a decision about my 912. I'm considering just running 100LL when that happens as I (as well as Rotax) doesn't want 10% alcohol in the motor (corrosion is really my main concern 0 BTDT with alkeehaul). My question is, does anyone, i.e. john h and john w., with long experience with the 912ULS know what the long term effects are of steady diets of 100LL? If it does whack a chunk of time off the TBO, how much would that be? I understand the slipper clutch and sprag clutch could be affected by it as well. I looked through the archives and some of this has been discussed before, just wondering about field experience with long-term 100LL usage. PS: and off topic: I might be getting one of my 503's back from the guy I sold it to, so it may need a project - perhaps another Kolb! LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180660#180660 ________________________________________________________________________________
Subject: Re: Firestar project
Date: May 02, 2008
There was a sailor named RED who LEFT the PORT! Left=Red=Port.>> Hi, we usually use `There is a little drop of RED, PORT, LEFT. When I sailed the rule was RED CANS to PORT entering harbour with the tide. In the States I have found them using the same rule but LEAVING port. Very confusing, I wonder where the system changees over? Pat ________________________________________________________________________________
Date: May 02, 2008
I emailed Pennzoil directly about this and got the following reply. Dear Mr. Thom Riddle; Thank you for your interest in our products. The Pennzoil 2-Cycle Oil for Air Cooled Engines is still avalable in 8 ounce bottles. (Part# 4053) Please contact the distributor in your area, phone number 716-693-0150 for help in locating this product. Sincerely Product Technical Service -------- Thom Riddle N221FA Allegro 2000 912UL N197BG FS1/447 -------------------- Believe nothing, no matter where you read it or who has said it, not even if I have said it, unless it agrees with your own reason and your own common sense. - Buddha Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180663#180663 ________________________________________________________________________________
Date: May 02, 2008
In the States > I have found them using the same rule but LEAVING port. Very confusing, I > wonder where the system changees over? > > Pat Patrick: Don't try to confuse us. ;-) For as long as I can remember it has always been, "Red Right Returning". However, this is not always true when one is confronted by the Intercoastal Waterway. There is a rule for that which is determined whether one is sailing clockwise our counter-clockwise on the Intercoastal. Since I am flying my Kolb, and not sailing, I am not really concerned with my seamanship anymore. My boat has been landlocked, high and dry, for many years. Makes good lawn art. john h mkIII ________________________________________________________________________________
Subject: Re: 100LL long term in 912
Date: May 02, 2008
> My question is, does anyone, i.e. john h and john w., with long experience > with the 912ULS know what the long term effects are of steady diets of > 100LL? > > LS LS: 100LL is hard on the 912's due to lead residue. Rotax says run a semisynthetic oil and change it often. I do that. I also run Marvel Mystery Oil in the fuel. Does it help? I don't know for sure, but would like to think it does. If it makes me happy, then it is ok with me. My 912 ran much colder and was prone to lead fouling sparkplugs. Haven't had that problem with the 912ULS which runs much hotter. At home I run 93 octane mogas, with or without alcohol. I noticed this last mogas I bought at the country store and at Wal-Mart's has alcohol added. I'll have to be diligent with fuel samples now to see if I get a water problem. Only time I run 100LL is on cross country flights when I can not get mogas. When I change the oil, I also flush the oil tank with fuel, then take it apart to insure I get all the lead out. I have never put more than 1200+ hours on the previous two 912's I have owned and operated. However, they were still in top notch shape when I sold them. john h mkIII ________________________________________________________________________________
Date: May 02, 2008
My boat has been landlocked, high and dry>> Hi John, sold my cruising cat. a long time ago but it really had me worried a few years back, watching orcas around Vancouver Island when the guy piloting this massive 30knot twin outboard outfit started for home apparently down the wrong side of the buoys. Cheers Pat ________________________________________________________________________________
Date: May 02, 2008
with long experience with the 912ULS know what the long term effects are of steady diets of 100LL? If it does whack a chunk of time off the TBO, how much would that be? I understand the slipper clutch and sprag clutch could be affected by it as well. >>>>>>>>>>>>>>>>>>>>>>>>>. I don't use enough 100 ll to know nor have I spent the time to research the affect on the slipper clutch and sprag clutch, the first things to happen is the time between oil changes and spark plug replacements reduces to 1/2. Also the choice of oil has to be one that will hold the lead deposits in suspension better. The synthetics seem to lubricate better when the engine is running.. but the mineral oil seems to protect from corrosion better when it is not running. I guess I try to get the best of both worlds by using a synthetic / mineral oil blend. Boyd ________________________________________________________________________________
Subject: Fw: AirVenture 2008
Date: May 02, 2008
For anyone camping at AirVenture, this is good news!!! See the following. I read it that, they will be adding some sanitation equipment to our camping area at AirVenture. Maybe we can get more Kolbs attending this year. Both John H and I E-Mailed Timm Bogenhagen (EAA's operations manager for the Ultralight/LSA area) and he (Timm) was dead set against doing anything for us. I also petitioned the Ultralight/LSA council with a even more direct NO!!!! Sometimes it pays to go to the top. Rick Neilsen Redrive VW Powered MKIIIC ----- Original Message ----- From: Steve Taylor Sent: Friday, May 02, 2008 10:12 AM Subject: RE: AirVenture 2008 Richard, Thank you for clarifying the location. We will be adding two port-o-lets and a dumpster to that location. Steve From: Richard & Martha Neilsen [mailto:NeilsenRM(at)comcast.net] Sent: Monday, April 28, 2008 12:30 PM Cc: Steve Taylor Subject: Re: AirVenture 2008 Steve & Tom The area of concern is the airplane camping area north and a bit west of the area you are talking about. Again If one of the port-o-lets and a trash can could be located in the airplane camping area or maybe that port-o-let grouping and dumpster could be moved to a more central location on the north end of that camping area. Thanks Richard Neilsen ----- Original Message ----- From: Tom Poberezny To: NeilsenRM(at)comcast.net Cc: Steve Taylor Sent: Monday, April 28, 2008 12:49 PM Subject: RE: AirVenture 2008 Richard, Please read the following note from Steve Taylor. Steve manages all of our facilities. If you could let Steve know if the area you're talking about is the one he's mentioned, or direct him in a different location. Steve's e-mail: staylor(at)eaa.org Tom -----Original Message----- From: Steve Taylor Sent: Monday, April 28, 2008 9:07 AM To: Kathy Phillip Subject: RE: AirVenture 2008 As I read the gentlemen's request, I wonder if I'm thinking of the right location, according to the information I believe that he is referring to the camping area on the southern side of the ultra light runway. If that's the case there are 6 port-o-lets located right in the middle of the camping area which is approximately 1.8 acres in size. I'd like to understand more details about his request to ensure that were on the same page here. Steve -----Original Message----- From: Tom Poberezny Sent: Wednesday, April 23, 2008 4:45 PM To: 'Richard & Martha Neilsen' Cc: Steve Taylor Subject: RE: AirVenture 2008 Richard, Don't have all the details regarding your request. I'm sharing this e-mail with the appropriate people so we can discuss this internally. You will receive a response soon. Regards, Tom -----Original Message----- From: Richard & Martha Neilsen [mailto:NeilsenRM(at)comcast.net] Sent: Wednesday, April 23, 2008 11:19 AM To: Tom Poberezny Subject: AirVenture 2008 Tom I would really like to have a port-o-let and a trash can (just one each) in/near the ultralight/LSA plane campground for AirVenture. I have been trying to get some sanitation facilities closer to this campground for a number of years. I have contacted everyone and possibly irritated people with my persistence. I really don't understand the resistance. If a opening in the fence needs to be a foot wider to get a truck thru then could that be done? If that is too much to ask then maybe just one of the many Port-o-lets and a trash cans could be moved to the north end of the of the Ultralight/LSA camper/trailer campground? I have been flying from Lansing Michigan to AirVenture for a number of years. The Ultralight/LSA campground was once a popular place to camp but over the last few years I have been practically camping there by myself. We need to make it more welcome to visitors. I have had my private license for 20 years and my VW powered Kolb MKIIIC has been a licensed experimental since before its first flight. I have written a few articles for the EAA's LSA magazine. The last article was in the April 2008 issue. Please help you are my last hope. Richard Neilsen EAA# 0156743 ________________________________________________________________________________
Subject: Re: Fw: AirVenture 2008
Date: May 02, 2008
Rick: Thanks for doing the footwork. I have a feeling Tom P and Taylor don't know where the UL/Lt Plane camping area is. Hope they are not thinking of the GA area. Our area is west of the UL/Lt Plane airstrip, north of the UL Camping area. Thanks again, john h For anyone camping at AirVenture, this is good news!!! ________________________________________________________________________________
Date: May 02, 2008
The reason that the 8 oz bottles are still available at the distributor is because there is less demand for that size. The price per oz is much higher than the 16 oz. If you dig deeper I think that you will find that Pennzoil is not packing any new ones. If you like this product I suggest that you buy whatever 16 oz stock you can find to hold you over until Lockwood has a new recommendation. Just trying to give the List a Heads Up. Steve B Firefly 007/Floats Firefly 0040/ Floats 2008 SnF Grand Champion do not archive In a message dated 5/2/2008 9:33:56 A.M. Eastern Daylight Time, riddletr(at)gmail.com writes: I emailed Pennzoil directly about this and got the following reply. **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Date: May 02, 2008
Did I mention your local Wal-Mart usually has it? Dennis ----- Original Message ----- From: "Thom Riddle" <riddletr(at)gmail.com> Sent: Friday, May 02, 2008 9:30 AM Subject: Kolb-List: Re: Pennzoil 2 cycle oil OUT OF PRODUCTION > > I emailed Pennzoil directly about this and got the following reply. > > Dear Mr. Thom Riddle; Thank you for your interest in our > products. The Pennzoil 2-Cycle Oil for Air Cooled Engines is still > avalable in 8 ounce bottles. (Part# 4053) Please contact the distributor > in your area, phone number 716-693-0150 for help in locating this product. > Sincerely > Product Technical Service > > -------- > Thom Riddle > N221FA Allegro 2000 912UL > N197BG FS1/447 > -------------------- > Believe nothing, no matter where you read it or who has said it, not even > if I have said it, unless it agrees with your own reason and your own > common sense. > - Buddha > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=180663#180663 > > > ________________________________________________________________________________
Date: May 02, 2008
Well, that response doesn't really answer the question.... "still avalable [sic]" doesn't specifically mean that they are producing the oil, only that some 8 ounce bottles are still available. Maybe a pointed question would be more helpful and get an answer that would tell us if the specific air-cooled 2-stroke oil is or is planning to be discontinued? -- Robert On Fri, May 2, 2008 at 8:30 AM, Thom Riddle wrote: > > I emailed Pennzoil directly about this and got the following reply. > > Dear Mr. Thom Riddle; Thank you for your interest in our products. The Pennzoil 2-Cycle Oil for Air Cooled Engines is still avalable in 8 ounce bottles. (Part# 4053) Please contact the distributor in your area, phone number 716-693-0150 for help in locating this product. > Sincerely > Product Technical Service > > -------- > Thom Riddle > N221FA Allegro 2000 912UL > N197BG FS1/447 > -------------------- > Believe nothing, no matter where you read it or who has said it, not even if I have said it, unless it agrees with your own reason and your own common sense. > - Buddha > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=180663#180663 > > -- There are 10 types of people in this world: those who understand binary and those who don't. ________________________________________________________________________________
Date: May 02, 2008
I'm still trying to decide what oil to use in my 912UL. Mark G, the previous owner, used Valvoline Duralube semi-synthetic because he used 100LL strictly. Maybe I'm a doubter, but the Valvoline oil may not be the best for gear lubrication. I plan on using autogas and 100LL if I cannot find autogas. Some 912 users have switched to Honda GN4 motorcycle oil as it's designed for gear lubrication as well as the engine. I would like to use Honda's HP4, a semi-synthetic oil. Rotax says that motorcycle oil can be used with either type of fuel. If I could, Mobil 1 synthetic would be good, but Rotax states not to use it with autogas. Is anyone using motorcycle oil in their 912? Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 21 years flying it Kolbra 912UL N20386 0 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180718#180718 ________________________________________________________________________________
Date: May 02, 2008
At 08:04 AM 5/2/2008, N27SB(at)aol.com wrote: >Roger, I am surprised that nobody is picking up on this topic except >you. PENNZOIL AIR COOLED 2 STROKE OIL IS GONE.. The product labeled "air cooled 2 stroke" is gone, replaced by "2 cycle outdoor" which is the same thing. Whether the "outdoor" product is being discontinued I don't know, but this may be the source of the confusion. We're a tiny market, but with the number of ATV's, dirt bikes, chainsaws, and weed whackers out there I can't seem them abandoning this segment of the market. -Dana -- Sometimes it is easier to beg forgiveness than get permission. ________________________________________________________________________________
Subject: Oil Supply
Date: May 02, 2008
I just purchased two cases of 16 oz size Pennzoil for air cooled engines at $39+. They did not have the 8 oz, but had the 16 oz size. This was from the Oil Store on the internet. Jimmy Hankinson N6007L, Firefly From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Dana Hague Sent: Friday, May 02, 2008 1:02 PM Subject: Re: Kolb-List: Pennzoil 2 cycle oil OUT OF PRODUCTION At 08:04 AM 5/2/2008, N27SB(at)aol.com wrote: Roger, I am surprised that nobody is picking up on this topic except you. PENNZOIL AIR COOLED 2 STROKE OIL IS GONE.. The product labeled "air cooled 2 stroke" is gone, replaced by "2 cycle outdoor" which is the same thing. Whether the "outdoor" product is being discontinued I don't know, but this may be the source of the confusion. We're a tiny market, but with the number of ATV's, dirt bikes, chainsaws, and weed whackers out there I can't seem them abandoning this segment of the market. -Dana -- Sometimes it is easier to beg forgiveness than get permission. ________________________________________________________________________________
From: "John Williamson" <kolbrapilot1(at)tx.rr.com>
Date: May 02, 2008
Hi all you 912 and 912S flyers, You can't go wrong by using an oil from the Rotax list of oils for the operation you are planning. See SI-912-016 at http://www.rotax-aircraft-engines.com/pdf/dokus/d04286.pdf Rotax does make changes to the list, so you have to stay current. -------- John Williamson Arlington, TX Kolbra, 912ULS, 1595 hours http://home.tx.rr.com/kolbrapilot Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180743#180743 ________________________________________________________________________________
Date: May 02, 2008
Ok, the consensus I'm getting over on the titan list is that the alkie is less harmful than the lead in 100LL - the reverse of what I thought. Also, that the alki containing gas appears to be ok out in the field, as long as the usual precautions are taken against water contamination, etc. That's exactly the info I was looking for...... So I'll just run the alki containing stuff when it finally shows up here. As for the oil, I know slightly more about that than gas, which I know next to nothing about ;) I follow the listing of recommended oils in the Rotax bulletin, even tho the brands/formulas they list are the European versions (the US versions of some of these have a different formulation, tho who knows which of them do). After that, I follow the service grade and weight requirements. The manual says an API spec of SF or SG so I make sure the stuff I use at least meets that grade. For what it's worth, most of the automotive oils around these days meet API SL/SM, which exceeds the specs of most motorcycle oils I've seen (they're usually SG. later API specs are all backwards compatible and the later ones meet more stringent standards as well), so they're probably actually better lubricants. If an oil is on the not recommended list from Rotax, I don't use it no matter what grade it is ;) Right now I run the valvoline durablend semi-synthetic at 10W40 weight, API service grade SM. LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180759#180759 ________________________________________________________________________________
Date: May 02, 2008
In a message dated 5/2/2008 12:08:37 P.M. Central Daylight Time, d-m-hague(at)comcast.net writes: The product labeled "air cooled 2 stroke" is gone, replaced by "2 cycle outdoor" which is the same thing. Whether the "outdoor" product is being discontinued I don't know, but this may be the source of the confusion. We're a tiny market, but with the number of ATV's, dirt bikes, chainsaws, and weed whackers out there I can't seem them abandoning this segment of the market. -Dana If you look on the back of both bottles you have mentioned you will find that they BOTH have the same stock # which is 4130 . The 4130 is located just above the bar code. It is the same # on the " Air Cooled 2 Stroke" AND "Multi-Purpose Outdoor". Penzoil also offers yet another multi- purpose oil but it does not have the 4130 # on it. That is the one that is available at my local Wal-Mart. I just bought a case from LEAF about a week ago and as of then they still had it. Ed Diebel ( FF# 62) **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Subject: Re: Excellent service from Daryl @ Warp Drive, Inc
Date: May 02, 2008
> Sent him all three blades. Asked him to repair the damaged blade and trim 1" off all three for noise. Went from 72" to 70". He did all that, cleaned and rebalanced the blades. He even got the south Louisiana bug guts off that I couldn't. I can't tell which blade was repaired. All three look brand new. > John Bickham John B: Daryl is number one in my book, and so are his props. Been flying with them for 15 years. They have taken me to some exciting places and brought me home again safe and sound. I repitched my Warp Drive, 3 blade, 70 inch prop yesterday. Wanted to take a little pitch out of it and turn a little more rpm. I dropped one degree. This brought my climb rpm to 5300 to 5400 rpm. Straight and level it will turn 5500 to 5550. Engine is much crisper. Seems to have really freed it up. 5000 rpm cruise is 85 mph on the button. I picked up a steady vibration on my test flight yesterday. Not bad, but noticeable. Went through the entire repitch process today. One blade was about an 1/8" (bubble) out. Got all three blades singing off the same sheet of music. Flies slick as a turbo today. Getting ready for MV, john h mkIII ________________________________________________________________________________
Date: May 02, 2008
There are two (or more) Pennzoil 2 stroke oils. The one that the UL community has had such good luck with is now packaged with a blue bar on the bottle. The important thing is that on the back it is rated TC. The other 2 stroke outdoor Multipurpose oil has been labeled with a brown bar on the front and on the back it is rated TC3 or TCW or something like that. (I'm to lazy to look it up right now) Bottom line is the TC rating is the one that was tested many years ago and was praised so highly for AIR Cooled engines. TC3, TCW etc is primarily for water cooled 2 strokes, IE: Jet Skis, outboards, maybe 582s but not as good as TC rated oil for aircooled 2 strokes. Water cooled engines do not develop the hot spots that an aircooled engine does thus they dont need as high a quality base stock to make their oil. Apparently Penzoil figured their Multipurpose oil was good enough for weedeaters, chainsaws, etc since they say it is also for aircooled engines. When my weedeater seizes up I say screw the lawn work and go in the air conditioning and have a beer. If my 447 seizes thats a whole different matter :^( When the supply of the true Pennzoil Air cooled 2 stroke oil (TC) dries up, then I guess we'll have to run what ever is available, but dont be confused thinking that the "multipurpose" oil is the same thing or just as good. It isnt.... Dwight Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180826#180826 ________________________________________________________________________________
Date: May 02, 2008
Subject: Re: 100LL long term vs. alkie
Lucien - I'd like to share this info (alkie less harmful than the lead in 100LL) with my club. Can you either summarize the reasoning from the Titan list, or tell me how to access the thread on that list? Thanks - Arty Trost Maxair Drifter Sandy, Oregon --- lucien wrote: > > > Ok, the consensus I'm getting over on the titan list > is that the alkie is less harmful than the lead in > 100LL - the reverse of what I thought. Also, that > the alki containing gas appears to be ok out in the > field, as long as the usual precautions are taken > against water contamination, etc. > > That's exactly the info I was looking for...... So > I'll just run the alki containing stuff when it > finally shows up here. > > As for the oil, I know slightly more about that than > gas, which I know next to nothing about ;) > > I follow the listing of recommended oils in the > Rotax bulletin, even tho the brands/formulas they > list are the European versions (the US versions of > some of these have a different formulation, tho who > knows which of them do). > > After that, I follow the service grade and weight > requirements. The manual says an API spec of SF or > SG so I make sure the stuff I use at least meets > that grade. > > For what it's worth, most of the automotive oils > around these days meet API SL/SM, which exceeds the > specs of most motorcycle oils I've seen (they're > usually SG. later API specs are all backwards > compatible and the later ones meet more stringent > standards as well), so they're probably actually > better lubricants. > > If an oil is on the not recommended list from Rotax, > I don't use it no matter what grade it is ;) > > Right now I run the valvoline durablend > semi-synthetic at 10W40 weight, API service grade > SM. > > LS > > -------- > LS > FS II > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=180759#180759 > > > > > > > > > browse > Un/Subscription, > FAQ, > http://www.matronics.com/Navigator?Kolb-List > > Forums! > > Admin. > > > > > www.LessonsFromTheEdge.com "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Date: May 03, 2008
Subject: Firestar Project
I started measuring all the spare legs I have, and the I called Travis at TNK. I got a surprise- none of the legs are a size that he has heard of. First- all of them are 1" diameter. Travis said there are only 3 stock diameters; Firefly is 1 1/8", Firestar is 1 1/4", and Mark lll is 1 3/8". All are the same length- 28 1/2". I have spares of 3 different lengths, but all are shorter. My axle end is 3/4", and Travis said all of the ones he knows about are 7/8". He said he has heard of somebody putting a piece of pipe in the "A" frame to bush it down,and I will look for it next trip. I have to look and measure before ordering, so I will be out to the field next week. He also commented that I may have some type of proto-type from the Old Kolb Co. That might explain all the odd dimensions and no serial number. I described the bent legs from taxi testing, and he said that some people will make their own legs using 6061 aluminum. They are supposed to be 7075 T-651. The 6061 legs will bend just like I described. Bill Sullivan FS/KX/447 Windsor Locks, Ct. ________________________________________________________________________________
Subject: Re: Firestar Project
Date: May 03, 2008
Bill S: Original Firestar Gear Legs were 1". The Old Kolb Company put a aluminum tube bushing in the gear leg socket so it would fit. The old Twinstar, the first two place Kolb, used an 1 1/8" gear leg. Same socket with no aluminum bushing. I bent the 1" gear legs on my FS the first time I taxiied it on my grass strip. Called Little Mike at Old Kolb to send me some Twinstar 1 1/8" legs. They worked better, but my type flying called for something better. Thus, the experimentation and use of heat treated 4130 legs on my Kolbs since 1987. I don't think you have a prototype Kolb. The first Kolb I got with a serial number was my MKIII in January 1991, M3-011. The old Kolbs did not have serial numbers. I think the individual that built and/or modified your Kolb is responsible for the odd dimensions. john h mkIII I started measuring all the spare legs I have, and the I called Travis at TNK. I got a surprise- none of the legs are a size that he has heard of. First- all of them are 1" diameter. Travis said there are only 3 stock diameters; Firefly is 1 1/8", Firestar is 1 1/4", and Mark lll is 1 3/8". He said he has heard of somebody putting a piece of pipe in the "A" frame to bush it down He also commented that I may have some type of proto-type from the Old Kolb Co. That might explain all the odd dimensions and no serial number. Bill Sullivan ________________________________________________________________________________
Date: May 03, 2008
Subject: Poly Fiber question
I've got a quick question for you Poly Fiber experts. I'm getting ready to start my main wings/ailerons, and flaps on my MkIII. I only have 1 quart of Poly Tak left. (actually, it's just under a quart). Does anyone have an idea how much Poly Tak it takes to cover just the wings, flaps, and ailerons. All other surfaces (complete tailfeathers and fuselage) are finished. Just the wings. I can't recall how many quarts of Poly Tak I started with, to know much it took to get to this point. I think I may have used one quart so far, but I can't remember. I don't want to get in the middle of doing the wings, and run out. I'd rather have it on hand, if I need it anyway. Thanks, Mike Welch --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: May 03, 2008
Larry C: Keep it up. Looks like you are getting good at building FS's. Looks good. Have you flown it yet. john h mkIII things seem kind of slow, so here are the pictures of Dart. Larry C ________________________________________________________________________________
Date: May 03, 2008
Yes, I have flown it twice, no problems, no difference other than being a bit higher up in the air when I touch down. Larry ----- Original Message ----- From: John Hauck To: kolb-list(at)matronics.com Sent: Saturday, May 03, 2008 1:46 PM Subject: Re: Kolb-List: 50 foot paint job Larry C: Keep it up. Looks like you are getting good at building FS's. Looks good. Have you flown it yet. john h mkIII things seem kind of slow, so here are the pictures of Dart. Larry C ------------------------------------------------------------------------- ----- Checked by AVG. 5/2/2008 4:34 PM ________________________________________________________________________________
Subject: show and tell day
Date: May 03, 2008
Still whittling away on the radiator shell. Some more fillo and sanding and it gets painted hides-all-sins white. that will be it for this year, time for some flying! BB DSCN1565.JPG
Date: May 03, 2008
Subject: Grey Baron
(I'm sending this note for my father who has been hospitalized for two weeks with an episode of what is presumed to be paraneoplastic dermatomyositis.) "The Grey Baron is still hospitalized, with some progress, mainly he's able to lift one heel about 1/8" while bedridden. Rudder travel limit! He's moving to an excellent rehab connected with hospital next week, and may get a laptop. Email off list a58r(at)verizon.net " Bob N. http://www.angelfire.com/rpg/ronoy ________________________________________________________________________________
Date: May 03, 2008
At 09:59 AM 5/2/2008, you wrote: > >I have never put more than 1200+ hours on the previous two 912's I >have owned and operated. > > >john h I completely agree with John, I have a 503 Rotax and try as I might, I have never put 1200 hours on mine either. Hell - I never thought it would get to 600 hrs without me having to have it rebuilt. Now I'm thinking I can get to 800 hrs. BTW: at 800 hours I'll just buy a new 503. Good deal - 10 years for $4,400 I have, however, put way over 700 hours on it without using PENNZOIL AIR COOLED 2 STROKE OIL at all. I use DOT 3 - Walmart oil. Not because of the price, but because I used Pennzoil for 30 hours just to see. It made the plugs dirtier faster. Oil is a cult/religion - so............do what makes you feel good. ________________________________________________________________________________
Date: May 03, 2008
Looks good Larry! I will be taking lots of pictures of your gear legs when I get there. I did the break-in procedure on the 503 today and did 6 touch and goes with long full power climbs. Brought it home, took off the cowl and re-torqued the head bolts. I also installed the carb kits and rechecked the fan belt tension. Things look good for the Rock House trip. I'll try to put in a couple of hours of airtime tomorrow in close proximity to the airport. I hadn't flown in almost two months, a record for me since the first flight of my firestar. -------- Roger in Oregon 1992 KXP 503 - N1782C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=180987#180987 ________________________________________________________________________________
Date: May 03, 2008
At 09:50 PM 5/3/2008, possums wrote: >I have, however, put way over 700 hours on it without using PENNZOIL AIR >COOLED 2 STROKE OIL >at all. I use DOT 3 - Walmart oil... DOT3 is brake fluid, not motor oil. -Dana -- "If you're not a liberal at 20, you have no heart. If you are not a conservative when you're 30, you have no head." -- Winston Churchill ________________________________________________________________________________
Date: May 03, 2008
At 10:08 PM 5/3/2008, you wrote: >At 09:50 PM 5/3/2008, possums wrote: >>I have, however, put way over 700 hours on it without using >>PENNZOIL AIR COOLED 2 STROKE OIL >>at all. I use DOT 3 - Walmart oil... > >DOT3 is brake fluid, not motor oil. > >-Dana > >-- > "If you're not a liberal at 20, you have no heart. > If you are not a conservative when you're 30, you have no head." > -- Winston Churchill I use the WalMart Super Tech 2 cycle oil dot3- ?? You may be right about the "dot3" I'll look at the bottle tomorrow.. ________________________________________________________________________________
Date: May 04, 2008
Subject: Gear Legs
General Question to all; Have A MkIII X with the aluminum gear legs. On occasion the plane wants to nose over, especially when loaded with a couple of fairly big guys (175 +200). I know there were some problems like this when the MKIIIx came out but I haven't heard about any lately. Is this do to the new steel gear legs that has moved the wheels forward. I am considering installing them but would like to get some feed back on the pro's and con's of the new legs. Thanks Larry Tasker **************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001) ________________________________________________________________________________
Date: May 04, 2008
Subject: Re: Gear Legs
Larry, I'm not sure what you've read recently (last three months), but the subject of steel gear legs has been discussed extensively. I decided to make my own steel gear legs, like a few others have done, and one of them (John Bickham) was kind enough to supply me with sizes, measurements, drawings, pictures, etc. I had enough useful information to be able to tackle the job of making my own, fairly easily. Brian, at TNK tech support, was VERY helpful in informing me of all the ramifications of the gear leg changes. He gave me some the background information, plus made some measurements for me (of the new yellow Xtra's wings, hor. stab., etc.) The result: I could not be happier! My MkIII now sits up almost 6" taller at the fuselage. The wheels sit about 3" to 4" further forward, and maybe 12" wider overall stance (not exactly sure about the stance, it's just a guess, because I didn't actually measure the old stance---I'm just going by what it looks like) In MY opinion, if you made the change to the steel legs, I believe you'd wonder why you had not done it a lot earlier. The wheels will sit a few inches further forward, a little wider stance, and best of all...taller. The New Kolb sells the steel legs, as I am sure you are already aware. The factory legs will significantly alleviate the ailments you mentioned, no doubt. But, if for some reason, you want the wheels to be even more forward than the factory's legs, then you could make your own, as I did. If you want the wheels to be even more than 3"-4", let me know. I can tell you how to fix it so that if you make your own, you can do that. Whether you go with the factory legs, or go to the trouble of making your own, I'm certain you will like the improvement!! But, realize there a couple of minor modifications you'll also need to include in your project. First of all, when adding the longer steel legs, your plane's wings will have too high of a "rake", in the taxi position. In other words, there's too much incidence in the wing's mounting angle. The high angle works for the shorter aluminum legs, but if you go to the taller steel legs, you'll need to drill new holes on the wing's mounting tabs, to take some of the incidence out of the angle. (For more details, contact me off-list). Secondly, by adjusting the main wing's incidence, this will cause the angle of the horizontal stabilizers to be off, too. For the aluminum legs, the front edge of the hor. stab's are mounted quite high at their front mounting spot on the boom tube. If you go to steel legs, that front mounting height has to be lowered a couple of inches, or so. The enclosed attachment is something I put together from some nice gents who were kind enough to make some measurements for me. Again, for more information, contact me off-list...I can help decipher it for you). I hope this information is a little helpful. I've also enclosed a picture of my steel legs installed. Although I do NOT have an Xtra, you get the idea of what I've built. You may note that I haven't adjusted the wing's incidence, yet. For those that care, I'm almost finished with my fiberglass droop tips. More on that later. Larry, like I said, if you decide you absolutely just have to build your own steel legs, rather than buy them, I have a compendium of information, to help make the process painless. Mike Welch Kolb MkIII CX Cat36Fly(at)aol.com wrote: General Question to all; Have A MkIII X with the aluminum gear legs. On occasion the plane wants to nose over, especially when loaded with a couple of fairly big guys (175 +200). I know there were some problems like this when the MKIIIx came out but I haven't heard about any lately. Is this do to the new steel gear legs that has moved the wheels forward. I am considering installing them but would like to get some feed back on the pro's and con's of the new legs. Thanks Larry Tasker --------------------------------- Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: May 04, 2008
Larry, I'm not sure what you've read recently (last three months), but the subject of steel gear legs has been discussed extensively. I decided to make my own steel gear legs, like a few others have done, and one of them (John Bickham) was kind enough to supply me with sizes, measurements, drawings, pictures, etc. I had enough useful information to be able to tackle the job of making my own, fairly easily. Mike, I have been wanting the steel legs for some time. I had thought last year that I had a source for the steel legs, but it didn't pan out, and TNK hadn't offered theirs at the time. Terry Davis had a extra set that he kindly let me have at a very reasonable price. I do like them a lot. The weakest part of the old Kolb design was the legs. Due to the angle forward that they set, if something goes wrong then that leg stabs into the ground causing substantial problems. However I understand why it was designed that way, but I would prefer to take my chances with sturdier legs. I question that you would need to change the wing incidence However, when the plane is up on its gear the wing incidence is the same whether the legs are long or short. In the two flights that I have made with mine since my last completion, I can find no difference at all in any of the flight charactistics. Thanks for the offer Larry C ________________________________________________________________________________
Date: May 04, 2008
Subject: Gear legs, and wing incidences
Larry, Regarding the wing's incidence with steel legs, yes, you are probably correct, when changing the legs on the Firestar. I think what I may be confusing is my conversation with Brian, @ TNK tech support, when he explained to me that when they were doing the flight testing on the newly invented Xtra, that they found they had to lower the incidence on the flying surfaces (front and back) due to the wedge shaped nose, and its' tendency to "plow" into the air, causing a nosedown pressure. IIRC, tho, it seemed as though this also tied in with the steel leg mods, too. Whatever the other Larry decides to do regarding his new gear legs, he should run it past Brian, for sure. Thanks for the correction. Mike Welch --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: May 04, 2008
Larry, my $.02 worth on Mike's behalf; The incidence change has more to do with airflow change than longer legs. Since he has reconfigured the nose ala Xtra there is more downthrust forward of the CG. I believe the factory Xtra also has the different incidence. I am going to give it a try on my modified MkIII too even though it doesn't have as wide a nose as the Xtra. The stock MkIII nose bowl, having a large radius front enables the air to easily flow to a lower pressure area- a very good design. My plane, although modestly powered, exhibits an uncomfortable and nearly indescribable sensation over 70 MPH. You can feel a sort of struggling oscillation going on that makes you want to slow back down. At 65 no problem. I attribute this to the pointy nose and very wide, transitioning to nearly flat, windshield creating a lot of downthrust (that doesn't occur with a stock nose and windshield) Just my opinion but when I do lower those leading edges I'll give a report on what happened. BB On 4, May 2008, at 1:59 PM, Larry Cottrell wrote: > > > Larry, > > I'm not sure what you've read recently (last three months), but > the subject of steel gear legs has been discussed extensively. I > decided to make my own steel gear legs, like a few others have > done, and one of them (John Bickham) was kind enough to supply me > with sizes, measurements, drawings, pictures, etc. I had enough > useful information to be able to tackle the job of making my own, > fairly easily. > > > Mike, > I have been wanting the steel legs for some time. I had thought > last year that I had a source for the steel legs, but it didn't pan > out, and TNK hadn't offered theirs at the time. Terry Davis had a > extra set that he kindly let me have at a very reasonable price. I > do like them a lot. The weakest part of the old Kolb design was the > legs. Due to the angle forward that they set, if something goes > wrong then that leg stabs into the ground causing substantial > problems. However I understand why it was designed that way, but I > would prefer to take my chances with sturdier legs. > > I question that you would need to change the wing incidence > However, when the plane is up on its gear the wing incidence is the > same whether the legs are long or short. In the two flights that I > have made with mine since my last completion, I can find no > difference at all in any of the flight charactistics. > Thanks for the offer > Larry C > > ________________________________________________________________________________
Subject: gear legs
Date: May 04, 2008
for comparison: a locally based MkIII (with steel factory legs) DSCN1166.JPG my duck-billed creation: welded steel tube windshield posts more foot room on the rudder pedals. It all comes apart with 10-32 screws DSCN1158.JPG copy
Date: May 04, 2008
Subject: Re: marvel oil
I would not worry about any wash down of oil by ethanol. Ethanol is a very poor solvent when it comes to Petroleum based oils. Gasoline is a much more effective solvent for washing the oil off. I have already tested that and found that its very hard to remove Petro oil with ethanol, almost on par with trying to remove the oil with water, but very easy to do with gasoline. I suspect that the only reason E-85 washed the oil off at all was because of the 15% gasoline in it. Ron (now in NC) Is there any Kolb active group in NC, today would have been a good day to visit. ============================ ---- tc1917 wrote: ============ was wondering, with the advent of the alky in our gas of late, could we ofset the cylinder 'wash-down' of oil from alcohol by adding marvel oil to our gas. I know it says not to put additives into our gas but it might help a little. what do all you experts think? Ted Cowan, Alabama Slingshot 912 UL -- kugelair.com ________________________________________________________________________________
Date: May 04, 2008
Subject: Re: q
At 07:59 PM 5/4/2008, Russ Kinne wrote: >However I THINK I will need some sort of approach-to-stall warning >when I start flying a Kolb. >Opinions? Learned to fly in 150's that had stall horns, never had one in my T-Craft, or the Quick I flew for awhile, or my US... and never missed it. If you practice stalls, know your plane, and know that an imminent stall feels like, you won't need a horn. -Dana -- Why are there Interstate highways in Hawaii? ________________________________________________________________________________
Subject: FireFly flight instructions???
Date: May 04, 2008
Gents, I was asked awhile back to write down flight instructions for the Firefly I built sometime back for the fella who bought it from its current owners. Upon reflection, and remembering how many questions I had in my own mind about flying a Kolb before I was helped out by a friendly Kolb owner, I thought I would post the doc here, simply for new prospective owners. Now I am sure some with more journalistic talent than I, and better pilots than I, might want to add their own comments...go ahead. I am not the first word or the last on this subject. This is simply for the archives. Kolb FireFly SN098 Flight instructions (R447 power) Starting: Set Wheel chocks Set Throttle to Idle Turn on electric fuel pump and wait for 10 seconds Turn on ign switch Pull primer/enrichener lever (over left side seat) Place left foot on tirePull recoil. Hold plane and manually caress throttle up until engine smoothes out. Close enrichener lever/circuit. When engine seems warmed up enough to lower throttlePull chocksjump in..Strap inand taxi. Turn off electric fuel pump. (personal pref) Take off: When aligned on runwaygently ease throttle up to max as ground speed increases. DO NOT increase throttle to fast, or due to high thrustlinecraft will nose over . This will simply have to come by experience as airspeed indicator wont be working yet. You dont want to have too little groundspeed that the elevators are not effective enough to hold the nose up or the tail down. In the first stages of feeling this out, You will find that if enough speed is attained to raise the tail ,then lower it, (tail control I call it) you will have enough elevator to keep it down at full throttle. IF you cannot lower the tail after bringing it up, you are on the edgewait for groundspeed to pick up more or lower throttle if the nose is going overso if you can bring the tail up, and then lower ityou can be at full throttle. This all happen very quicklyand will become a fluid practice after a few tries. I would estimate from idle to full throttle will be 5 or 6 secondswheels off will be aprox 3 or 4 seconds later..maybe 5 if heavy My technique isSet flaperons to then increasing throttle and groundspeed evenly until I can raise the tailthen full throttle and lower tail back to ground or slightly above.let it fly off. Airspeed will be working by now, and after breaking ground hold airspeed to 55 -60 mph and climb.make sure rpms are at or above 6000if much below, say 5800abort takeoff and see why engine is not coming up to speed. (fuelProp etc..) I usually have flaperons back to neutral by pattern altitude. If angle of climb is to great for your tastethen let speed go to 65 or 70(grin) After good familiarity with aircraftclimbouts can be accomplished at 45 to 50 mph indicated easilybut, the angle of attack is so steep, you will be accused of showing off or flying recklessly if you do this at fly-ins or air shows Unless of courseeveryone there is a Kolb driver..then no one will think a moment about it! For methese speeds worked well (your mileage may vary) Climb out = 55/60 indicated Cruise = 70/75this greatly influence by weight but engine likes 56 to 5800 rpms. Max speed..85/90 mph at 6500 rpms .cautionwhen operating here, or anywhere above 6200 rpms..fuel goes thru engine at an alarming rate. My estimate is 10 /12 gph. Approach =60 Stall = 30 LANDING: As with any very light weight craft, 098 will loose airspeed very quickly when power is removed. For this reason, Until you get alot of experience in it, Landing should be flown with some power at all times, until the moment of touchdown. For your first few landings: Fly the pattern at 601/2 flaperons on base leg, (Notice pitch effect!!)!.maintain 60 on finaland even over the numbers,, then at 10 to 15 feet, slowly lower throttle and altitude, (throttle can be left at 3000 rpms and it will come down ) When wheel touchcut power. This would be best accomplished on a long runway, as to see how fast airspeed goes away at lower throttle setting. If you get in troublethe FireFly will Fly away very quickly and resume a climb with full power . It is very easy to reverse Vertical speed with power and attitudedont force a bad landing There is nothing in the air that will bend a Kolband she loves to flyso if the cross wind has you askewor for whatever reason you dont think it is gonna be a pretty landinghit the gas and fly awayjust remember when you apply throttle quicklythere will be a strong pitching moment of the nose down and the tail up..(that high thrustline)..so have a little backpressure on the stick as you push the throttle forwardand be ready for it. Also remember, these numbers and speeds quoted above are for Kolb FireFly #098 Other single seat Kolbs will no doubt have slightly different numbers. My last word of advice, if you are a pilot, and have basic piloting skillsthen DO NOT try and get the feel of the airplane by taxing it around with the tail up and all that jazzyou probably will never get to enjoy flying it if you do, just the joy of repairing it. All you need to know about an airplanes ground handling is which pedal makes it go which way, and how to hold the upwind wing down in a crosswind.. You get the Feel for an aircraft in the air. If , after you have taken off for the first timeyou are intimidated about landing itthen go back to altitude and play with itstall ittake steep turns. Fool around with slow flight and watch the airspeed and Vertical Speed and get the feel of the ailerons at low speedsand the flaperon settingscheck the feel of the stick///its different with flaperons deployed than withoutand has different effectiveness Then..pick a long runway and FLY the aircraft down to 10 ft or less of altitude at an airspeed you already know works, and slowly remove the power and let it come downas soon as the wheels touch.. cut the power and if you have timego and take off again and do this again. If you concentrate to hard on getting a flare the craft will likely end up ceaseing to fly to high and plop down the last few feet due to lack or inertia. This is how the gear get bent. A lot of typical GA pilots do this in a Kolb, they stop flying the plane and pull the stick back and just freeze, waiting for it to settle. Dont do this..Fly it all the way to touchdown. Remember, as I said, there is nothing in the Air that will Bend an aircraft, but just about everything on the ground will. So I have adopted this strategy for over 30 years of flying, when an airplane is movingkeep its time on the ground at an absolute minimum. This is when it is most vulnerable to damage. I dont claim to have never bent an aircraft..in fact I have bent severalI guess thats how I know this rule works the best. -------- Don G. Central Illinois Kitfox IV Speedster Luscombe 8A http://www.geocities.com/dagger369th/my_firefly.htm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=181119#181119 ________________________________________________________________________________
Subject: Re: q
Date: May 04, 2008
> But does anyone have a stall-warning horn or light? > Russ Kinne Russ: That is what I use my ASI for. john r ________________________________________________________________________________
Date: May 04, 2008
Subject: Re: q
At 08:38 PM 5/4/2008, you wrote: > >Hey Possum, > > That was odd watching the stall where you pulled the stick back > >to make it stall more..... I noticed you never had to really push the stick > >forward to recover.... I noticed that too, now that you mentioned it. But I don't really think about what I'm doing anymore, I've been in the same plan so long. The plan picks up enough speed on the break without me having to add any - I guess. The controls used to be sloppy at 30mph - before I added the VGs. But I know you don't need them if you don't want to add them. ________________________________________________________________________________
Subject: Re: Dead Stick and other Videos
Date: May 04, 2008
Added another. Duct tape makes for a nice camera mount... [Wink] -------- Kip Firestar II (born September 2000) Atlanta, GA N111KX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=181153#181153 ________________________________________________________________________________
Date: May 04, 2008
At 10:36 PM 5/4/2008, you wrote: > >Added another. Duct tape makes for a nice camera mount... [Wink] > >-------- >Kip Where ? ________________________________________________________________________________
Date: May 05, 2008
In the third video I used a piece of wood to bolt the camera on via the tripod mount hole and then taped the rig to the boom as far back as possible... Possums wrote: > At 10:36 PM 5/4/2008, you wrote: > > > > > > > Added another. Duct tape makes for a nice camera mount... [Wink] > > > > -------- > > Kip > > > > > > Where ? -------- Kip Firestar II (born September 2000) Atlanta, GA N111KX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=181194#181194 ________________________________________________________________________________
Subject: Re: q
Date: May 05, 2008
I noticed that when I fly a J-3 cub with the doors open I have a built in stall warning. The lower section of the door folds down. When you are just beginning a stall the air flow will lift the door up. This happens just a second or two before I can feel the stall. I wonder if a ribbon tied on your strut might do the same thing? Nice and cheap! Rex Rodebush Read this topic online here: http://forums.matronics.com/viewtopic.php?p=181234#181234 ________________________________________________________________________________
Date: May 05, 2008
Arty Trost wrote: > Lucien - > > I'd like to share this info (alkie less harmful than > the lead in 100LL) with my club. Can you either > summarize the reasoning from the Titan list, or tell > me how to access the thread on that list? > > Thanks - > > Arty Trost > Maxair Drifter > Sandy, Oregon > > Hi Arty, Actually, the thread continued on a while (though we devolved into a discussion of ethanol production and kind of went off on a tangent) and there still seem to be divergent opinions. I got a PM that outlined some carburettor damage that was apparently traced to ethanol, something I'd consider very dangerous and that I hadn't given a lot of thought to. So I don't think I can offer anythiing conclusive. But with a little more research having been done, I'm swinging my opinion back the other way, where I think I'd be better off with 100LL and just accept a possibly reduced TBO and/or damage to the slipper clutch over time. Those are preferable to me than rust on the innards and the sound of silence due to carburettor rubber part damage. Or I could just go back to flying a 2-stroke, which can run on 100LL without problems (in my experience). I'm going to have to make a decision quick, tho, as they're already spiking the gas in my area (but not marking the pumps as such)...... It's probably going to just be 100LL, which is the only non-alcohol containing gas in my area..... LS -------- LS FS II Read this topic online here: http://forums.matronics.com/viewtopic.php?p=181235#181235 ________________________________________________________________________________
Date: May 05, 2008
I am think Auto Gas containing Alcohol is much better for the 912-s than 100 LL. I have a fuel sump, and always check for water no matter what kind of fuel I am using, so water is not an issue. Possible carburetor damage, almost everyone is being forced to buy ethanol now and reports will be coming in and I will know what to look for in the carbs long
April 21, 2008 - May 05, 2008
Kolb-Archive.digest.vol-hl
