Kolb-Archive.digest.vol-hu
October 11, 2008 - November 03, 2008
      Bill  Varnes
      Original Kolb FireStar
      Audubon NJ
      Do Not  Archive
      In a message dated 10/10/2008 10:22:33 P.M. Eastern Daylight Time,
      gtalexander(at)att.net writes:
      Anyone  want to speculate as to the reason just the left ones seem to be
      affected????
      **************New MapQuest Local shows what's happening at your destination.
      Dining, Movies, Events, News & more. Try it out
      (http://local.mapquest.com/?ncid=emlcntnew00000002)
Subject: Re: Check your carb floats!!
Date: Oct 11, 2008
WhiskeyVictor36(at)aol.co wrote: > > When the Kolb is parked, the rear of the engine is slightly lower than the front and the carbs are tilted toward the rear. Thus the rear floats are sitting in more fuel than the front ones, albeit a very small difference. While the Kolb is sitting in storage, the fuel in the float bowls evaporates and the rear floats are exposed to the fuel longer than the front ones. They get saturated with fuel and then don't float as high as the front ones which are more dried out. I have no idea if this is the case, but it sounds good, don't you think? > > Bill Varnes > Original Kolb FireStar > Audubon NJ > Do Not Archive > > > In a message dated 10/10/2008 10:22:33 P.M. Eastern Daylight Time, gtalexander(at)att.net writes: > > > Anyone want to speculate as to the reason just the left ones seem to be affected???? > > > > > > > Bill: You win the prize... now I have to figure out what it is.... Your theory as to the reason is one that I had thought and also one offered up by "The Man" at THE Rotax Service Center in Central FL. -------- George Alexander FS II R503 N709FS http://gtalexander.home.att.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8296#208296 ________________________________________________________________________________
Date: Oct 11, 2008
Subject: Re: Airport Attitudes
Jack , I Know you have been paying attention . I have been to your web site and know how you Love to explain things.Maybe I could pick your brain a li ttle . Have you ever had a ramp check? and lf so was it before or after the "sport pilot ".If so what was the attitude of the FAA?And what was the edu cation of the agent mean does -he know- a Firefly from a Kolb mkIII? =0A--- Next I understand that you are- using an engine other than t he 447---with an electric starter and only one cylinder.How- do you like it does it instill confidence like the 503 or 447 I flew 10 years in front of a 503 with know fear of my engine quiting. If you have already dis cussed this on your website you can just tell to go there or you can answer here. The reason I want tknow about the engine is being disabled I'm not s ure I can deal with a pull-starter I remember that before I put the electri c start on my 503 it was a job sometimes to start . =0A---- Jack I was interrupted by my grandchildren when I was on your website, I know how thorough you were on your site!I will go back there but as I remember it wa s along time ago that you put that engine on you firefly so maybe you could give us an update.-- Thank you-- Chris=0A=0A=0A=0A----- Original M essage ----=0AFrom: Jack B. Hart <jbhart(at)onlyinternet.net>=0ATo: kolb-list@ matronics.com=0ASent: Tuesday, October 7, 2008 10:15:03 PM=0ASubject: Re: K =0A>=0A>completely.- Unlike in the UK, there is no minimum altitude or di stance =0A>from people for ultralights (save that you can't fly over conges ted areas =0A>at ANY altitude), so we can approach the airport at 200' alti tude or =0A>whatever seems reasonable.=0A>=0A=0ADana=0A=0AAre you sure abou t this?- I remember reading that UL pilots are supposed to =0Aobey all of the rules for airmen.- And one of those rules, if I remember =0Acorrectl y, states that you must remain 750 feet from everything except when =0Aland =========================0A =0A=0A ________________________________________________________________________________
Date: Oct 11, 2008
Maybe you could get a equilivent "Disabled parking permit". :-) If it was me I wouldn't worry about it, and if checked and the over weight was only due to the addition of a starter, I would think that you would have a very good case to defend. For what its worth Larry CO, Oregon ----- Original Message ----- From: chris davis To: kolb-list(at)matronics.com Sent: Saturday, October 11, 2008 9:52 AM Subject: Re: Kolb-List: Re: Airport Attitudes Jack , I Know you have been paying attention . I have been to your web site and know how you Love to explain things.Maybe I could pick your brain a little . Have you ever had a ramp check? and lf so was it before or after the "sport pilot ".If so what was the attitude of the FAA?And what was the education of the agent mean does he know a Firefly from a Kolb mkIII? Next I understand that you are using an engine other than the 447 with an electric starter and only one cylinder.How do you like it does it instill confidence like the 503 or 447 I flew 10 years in front of a 503 with know fear of my engine quiting. If you have already discussed this on your website you can just tell to go there or you can answer here. The reason I want tknow about the engine is being disabled I'm not sure I can deal with a pull-starter I remember that before I put the electric start on my 503 it was a job sometimes to start . Jack I was interrupted by my grandchildren when I was on your website, I know how thorough you were on your site!I will go back there but as I remember it was along time ago that you put that engine on you firefly so maybe you could give us an update. Thank you Chris ----- Original Message ---- From: Jack B. Hart <jbhart(at)onlyinternet.net> To: kolb-list(at)matronics.com Sent: Tuesday, October 7, 2008 10:15:03 PM Subject: Re: Kolb-List: Re: Airport Attitudes > >completely. Unlike in the UK, there is no minimum altitude or distance >from people for ultralights (save that you can't fly over congested areas >at ANY altitude), so we can approach the airport at 200' altitude or >whatever seems 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ------------------------------------------------------------------------- ----- Checked by AVG - http://www.avg.com 10/10/2008 4:08 PM ________________________________________________________________________________
Date: Oct 11, 2008
Larry , thanks for the responce .Sounds like a plan. Are you a lawyer? What are you flying? Thanks again-,Chris=0A=0A=0A=0A----- Original Message -- --=0AFrom: Larry Cottrell <lcottrell(at)fmtcblue.com>=0ATo: kolb-list@matronic s.com=0ASent: Saturday, October 11, 2008 12:17:21 PM=0ASubject: Re: Kolb-Li st: Re: Airport Attitudes=0A=0A=0AMaybe you could get a equilivent "Disable d parking permit". :-) If it was me I wouldn't worry about it, and if check ed and the over-weight was only due to the addition of a starter, I would think that you would have a very good case to defend.=0A-=0AFor what its worth=0ALarry CO, Oregon=0A----- Original Message ----- =0AFrom: chris dav is =0ATo: kolb-list(at)matronics.com =0ASent: Saturday, October 11, 2008 9:52 AM=0ASubject: Re: Kolb-List: Re: Airport Attitudes=0A=0AJack , I Know you h ave been paying attention . I have been to your web site and know how you L ove to explain things.Maybe I could pick your brain a little . Have you eve r had a ramp check? and lf so was it before or after the "sport pilot ".If so what was the attitude of the FAA?And what was the education of the agent mean does -he know- a Firefly from a Kolb mkIII? =0A--- Next I u nderstand that you are- using an engine other than the 447---with a n electric starter and only one cylinder.How- do you like it does it inst ill confidence like the 503 or 447 I flew 10 years in front of a 503 with k now fear of my engine quiting. If you have already discussed this on your w ebsite you can just tell to go there or you can answer here. The reason I w ant tknow about the engine is being disabled I'm not sure I can deal with a pull-starter I remember that before I put the electric start on my 503 it was a job sometimes to start . =0A---- Jack I was interrupted by my grandchildren when I was on your website, I know how thorough you were on your site!I will go back there but as I remember it was along time ago that you put that engine on you firefly so maybe you could give us an update. -- Thank you-- Chris=0A=0A=0A=0A----- Original Message ----=0AFrom: Jack B. Hart =0ATo: kolb-list(at)matronics.com=0ASen t: Tuesday, October 7, 2008 10:15:03 PM=0ASubject: Re: Kolb-List: Re: Airpo t message posted by: Dana Hague =0A>=0A>completely. - Unlike in the UK, there is no minimum altitude or distance =0A>from peo ple for ultralights (save that you can't fly over congested areas =0A>at AN Y altitude), so we can approach the airport at 200' altitude or =0A>whateve r seems =0A=0A=0A3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=0Ahref='3D"http://www.matronics.com/Navigator?Kolb-L ist"'>http://www.matronics.com/Navigator?Kolb-List=0A3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=0Ahref='3D"http:/ /forums.matronics.com"'>http://forums.matronics.com=0A3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=0Ahref='3D"http: //www.matronics.com/contribution"'>http://www.matronics.com/contribution=0A 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=0A=0A=0A________________________________=0A- - Release Date: 10/10/2008 ==========0A=0A=0A ________________________________________________________________________________
Date: Oct 11, 2008
NeilsenRM(at)comcast.net wrote: > Dana/All > > The Sport Pilot rule came about because the rules were SOOOOOO badly abused. Wrong. Believe it or not, the rate of abuse of the exemptions was not terribly higher than the rate of abuse of any other of FnAA's rule sets. You'd be amazed at what's flying around up there among the big iron, pilots with no medicals, some with no certificates, planes out of annual for years and years and CFI's who don't teach. Also, the BFI program brought about one of the largest increases in safety in all of aviation. Inexpensive and proximal training UL's and fat UL's was all over the place. It did more than any program to eliminate the self-taught syndrome with all the attendent bent metal and broken bones. Abuse of the rules had nothing to do with it, as anyone who followed the development of SP rule knows. > > The FAA did a unusually kind thing by allowing Ultralight pilots to be > trained free of their usual regulations. The Ultralight community literally > shot themselves in the foot by flying the so called fat Ultralights as > tongue in cheek trainers. The only surprise was the FAA let it go on for so > long. > Wrong again. FnAA never likes ruling by exemption. They, as much as anyone else, wanted an appropriate rule set to cover fat UL's - they knew part 103 was too restrictive and Experimental was too difficult for many fat UL's, particularly those that were pretty close to 103 compliant. SP was the intended solution, but of course it got completely sidetracked by special interest effort. The UL community did very little to bring this on - it was a foregone conclusion all on its own. > > Your right, there is no specific rule about 500' separation in part 103. > That doesn't mean it is OK. I don't fly under part 103 anymore (it has been > 25 years) but I have stepped down from Private Pilot to Sport Pilot and it > is wonderful. If people do stupid things and start killing people there > surely will be those rules and many more. I think that a airport manager's > concerns if real and not just prejudice should be taken very seriously. > Maybe I should look back in the thread again but I don't see how overflying a runway at 50' is irresponsible? Airplanes do that all the time and it's perfectly fine.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8314#208314 ________________________________________________________________________________
Subject: Looking to buy
Date: Oct 11, 2008
Greetings: I am in the market for a Kolb Mk III extra. My needs are specific and the perfect ship is essential, the Mk III extra will be used for Sport Pilot Flight Instruction and tail wheel endorsements. I am looking for a Rotax powered 912ULS as optimum, the 912UL will also be considered. Please provide all information via my private E-mail as listed with all pertinent information. Thank you. Sincerely, John T. Schmidt, CFI :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8319#208319 ________________________________________________________________________________
Date: Oct 11, 2008
John, And WHERE do you plan on giving flight instruction in the "XTRA" (not extra)?? I'll be your first customer. Mike Welch MkIII CX > Greetings: I am in the market for a Kolb Mk III extra.> Thank you. > Sincerely, > John T. Schmidt, CFI _________________________________________________________________ See how Windows connects the people, information, and fun that are part of your life. ________________________________________________________________________________
Date: Oct 11, 2008
At 05:37 PM 10/11/2008, lucien wrote: >Abuse of the rules had nothing to do with it, as anyone who followed the >development of SP rule knows. The _origin_ of the SP rule came about because of the abuses and the clamoring for an increased UL weight. Then it was hijacked by the aircraft manufacturers who saw a cheap way to get planes into production and became something entirely different, so the final rule looked nothing like what we all wanted. -Dana -- What has four legs and an arm? A happy pit bull. ________________________________________________________________________________
Date: Oct 11, 2008
> The _origin_ of the SP rule came about because of the abuses and the > clamoring for an increased UL weight. Then it was hijacked by the aircraft > manufacturers who saw a cheap way to get planes into production and became > something entirely different, so the final rule looked nothing like what we > all wanted. > > -Dana Dana, Is this your knowledgeable of experience, or are you just stating a WAG (wild ass guess)?? I'm not arguing your point, but it was always "MY" understanding that rather than the UL problems being the reason Sport Pilot was suggested, I thought it was the countless thousands of (much) older regular pilots (VariEZ, LongEZ, GlasAirs, Lancairs, etc., no disrespect intended to the UL crowd) that lobbied the EAA to push the FAA into doing away with the "Medical". Eventually, the FAA's position was IF the medical requirement is dropped, then there WILL be several flight restrictions, aircraft limitations, etc, etc.......... That's just what I was under the impression of. Again, I'm arguing with you. I just wonder if you have a document or two to back up your consensus. Any truth to this basis?? Mike Welch MkIII CX _________________________________________________________________ See how Windows Mobile brings your life togetherat home, work, or on the go. ________________________________________________________________________________
Date: Oct 11, 2008
From: chris davis <capedavis(at)yahoo.com> > Jack , I Know you have been paying attention . I have been to your web site and know how you Love to explain things.Maybe I could pick your brain a little . Have you ever had a ramp check? and lf so was it before or after the "sport pilot ".If so what was the attitude of the FAA?And what was the education of the agent mean does he know a Firefly from a Kolb mkIII? > Chris, If you fly into an airport that is hosting an "Air Show" there is a good chance that an FAA representative will be there. I have attended three or four of these at Cape Girardeau, Missouri. I have never been ramp checked. I believe the primary reason, is that there is an agreement that the FAA will not ramp check because it would greatly reduce the number of ga and experimental aircraft and utralight vehicles that would attend. I believe what is true of Cape Girardeau, is true for many rural areas of the country, in that, there are many ga and experimental aircraft flying that are flown by people with out current medicals, and with out current paper work. These are old guys like me who love to fly, have little money with which to fly, and they do the best they can with what they have. Most of them seem to be responsible pilots, because they know if they mess up it will effect all the rest of us. When I go to a flyin or air show, I do carry "sufficient proof" that my FireFly is legal, and that document can be seen at: http://www.thirdshift.com/jack/firefly/fireflylegal.html > Next I understand that you are using an engine other than the 447 with an electric starter and only one cylinder. How do you like it does it instill confidence like the 503 or 447 I flew 10 years in front of a 503 with know fear of my engine quiting. If you have already discussed this on your website you can just tell to go there or you can answer here. The reason I want tknow about the engine is being disabled I'm not sure I can deal with a pull-starter I remember that before I put the electric start on my 503 it was a job sometimes to start . > The Simonini Victor 1+ engine is a very good engine. Since I have mounted an in the cockpit air/fuel mixture control, I like it even better. I mounted a weed wacker carburetor push bulb on the Bing float bowl as a primer. Two squirts and two pulls over compression to move the fuel into the case and the cylinder, and it will start every time on the next pass of the piston, cold or hot. I would not go back to a 447. I hope this helps. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Re: Looking to buy
Date: Oct 11, 2008
Mike Welch: Thanks, for the xtra, however, I am looking for that extra xtra, something special, a true labor of Love that someone is in need of letting go. I am located in the Charleston and Trenton, SC. Sincerely, John T. Schmidt, CFI Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8333#208333 ________________________________________________________________________________
Date: Oct 12, 2008
the over weight was only due to the addition of a starter, I would think that you would have a very good case to defend.>> Hi all, I just love the different attitude about the law in the US and the UK that shows in the recent posts. We seem to generally accept that the rules are there for everyones protection, and they were introduced for a good reason. That is not to say we are happy with everything or that there isn`t a little bending of the rules here and there. You on the other hand seem to take any rule as a direct challenge and set out to circumvent it in some way.. I don`t think anyone here would think for a moment that `only fitting a starter` would be a `good case to argue`..There is no case to argue. You are overweight and that is that. You may as well argue that `I only fitted a 50 gallon tank for extra safety` I don`t think that there are any `spot ramp checks` here. I have never heard of such a thing. On the other hand all UL must be weighed every 5 years when the have their annual C of A renewal. There is certainly a lot of unscrewing of extra`s to make sure that the weight is correct as the C of A date approaches. I once explained to an American friend of mine the difference in our respective attitudes like this. `We move into Africa or India where the temperature is regularly in the high hundreds plus and we ignore it and continue to dress for dinner. Americans emigrate into parts of the US continent that no sane person would wish to live in. Take a look at the temperature, wrestle it three falls and invent air conditioning` He laughed. Hope you find it as funny. Vive le difference Pat ________________________________________________________________________________
Date: Oct 12, 2008
An aircraft w/ ELSA airworthiness certificate and a training exemption can be used for instruction until it expires in Jan 2010. After that this aircraft cannot be used legally in training except when the(an) owner is being trained. So, you might find such an animal but it is highly unlikely, especially since there are precious few MkII Xtras for sale. Thom in Buffalo ________________________________________________________________________________
Date: Oct 12, 2008
At 09:46 PM 10/11/2008, Mike Welch wrote: > Eventually, the FAA's position was IF the medical requirement is > dropped, then there WILL >be several flight restrictions, aircraft limitations, etc, etc.......... > > That's just what I was under the impression of. Again, I'm arguing > with you. I just wonder >if you have a document or two to back up your consensus. There were several petitions from various ultralight organizations and individuals to codify the rules on 2 seat "trainers", increase the 254# weight, etc. The FAA had also stated that they intended to eliminate "rulemaking by exemption" as they called it. At the same time, there was the push from the other direction to eliminate the medical (something that had been hoped for when the Rec pilot certificate had been proposed). And, there was a real need to streamline the aircraft certification process. All these things met in the middle and nobody got exactly what they wanted. From http://www.sportpilot.org/news/010223.html : >"Sport pilot began its travels through the rulemaking process several >years ago when the United States Ultralight Association (USUA) asked the >FAA to expand Part 103 of the Federal Aviation Regulations to include >two-seat ultralight vehicles. By following the steps in FAR Part 11, >anyone can petition the FAA to change a rule. To get the public's comments >on the petition, the FAA publishes it in the Federal Register. > >"After considering the comments received, if the administrator determines >there are sufficient reasons to proceed, the FAA will begin the rulemaking >process, and the USUA petition followed this route. > >"When developing new rules, the FAA includes industry input from the start >by creating an aviation rulemaking advisory committee (ARAC) whose members >(including EAA) have expertise in the area being considered, light and >ultralight aircraft in this case. After years of hard work, the ARAC >decided to propose a new pilot certificate instead of changing Part 103. >Calling the new certificate "sport pilot," the ARAC drafted the initial >rule proposal and submitted it to the FAA." -Dana -- How is it that 2 teenagers in the back of an original Volkswagen Beetle, in a crowded drive-in theater, can reproduce, yet it takes 2 spotted owls 10,000 acres? ________________________________________________________________________________
Date: Oct 12, 2008
Thom Riddle: Good morning, as a fellow New Yorker I would have expected you to have your facts straight. Please, I truly encourage you and all who post on forums such as this, to check your accuracy of the intended message. Thom, your overall statement is false and misleading, not to mention discouraging to owners of ELSA aircraft. Any properly equipped ELSA aircraft can be used for instruction and the Flight Instructor can be compensated for his/her time. And, I further encourage you to become more familiar with the CFRs they are the rules we must adhere to. Now, as a point of interest, I used the term properly equipped ELSA aircraft for a reason, No instructor is permitted to give flight instruction to a student in a Single-center stick A/C again please ref the CFRs. Thom, congratulations on your Sport Pilot Instructors certificate, now correct me if I am wrong, that was less than 90 days ago, right! Thank you. Sincerely, John T. Schmidt, CFI [Idea] Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8361#208361 ________________________________________________________________________________
Date: Oct 12, 2008
At 07:08 AM 10/12/2008, pj.ladd wrote: >I just love the different attitude about the law in the US and the UK that >shows in the recent posts. > >We seem to generally accept that the rules are there for everyones >protection, and they were introduced for a good reason. That is not to say >we are happy with everything or that there isn`t a little bending of the >rules here and there. > >You on the other hand seem to take any rule as a direct challenge and set >out to circumvent it in some way.. Yes, over here we tend to have an inherent distrust of the government. It came to a head at least once around 1776... >I once explained to an American friend of mine the difference in our >respective attitudes like this. `We move into Africa or India where the >temperature is regularly in the high hundreds plus and we ignore it and >continue to dress for dinner. Americans emigrate into parts of the US >continent that no sane person would wish to live in. Take a look at the >temperature, wrestle it three falls and invent air conditioning` Good one! Here's some interesting trivia, to relate it back to aviation: During the American Civil War, one Thaddeus Lowe was instrumental in creating the Union Army Balloon Corps, flying observation balloons over Confederate positions. Disputes with the Army (over pay and other things), however, resulted in him being forced out, and the Balloon Corps were abandoned not long after. After the war, Lowe invented refrigeration (you wondered where this was coming from, right?), probably after observing that the hydrogen cylinders got cold while inflating his balloons, and made a fortune. His granddaughter was none other than "Pancho" Barnes, early woman aviator and owner of the notorious Happy Bottom Riding Club adjacent to Edwards AFB during the grand days of test flying in the 1950's. She, too, was hassled by the Air Force when they tried to take her land, but in the end she won a substantial lawsuit against the Air Force. -Dana -- Son - you're going to have to make up your mind about growing up and becoming a pilot. You can't do both. ________________________________________________________________________________
Date: Oct 12, 2008
Herr Schmidt: I know the FARS regarding the use of ELSA and SLSA for training. I had to know them for my CFI-SP practical test and was quizzed on this particular issue on July 19, 2008. Since you are disputing my summary of the facts, I suggest YOU look up the FARS (I know they are no longer called that by the FAA) and quote chapter and verse where it says that an ELSA can be used for training (other than for owners as students) after the expiration date which I am pretty sure is Jan 30, 2010 and that it does not have to have an exemption for this which is actually a very specific type of airworthiness certificate. At the end of this exemption period, if the owner does not change it to a regular ELSA airworthiness certificate, it becomes an aircraft that is illegal to fly, not just illegal to instruct in. I have a friend who owns just such an ELSA certificated Sky Ranger that he built (he is the WNY Sky Ranger Dealer), in Chafee, NY. His partner in the airplane is urging him to get the A/W changed before it becomes a lawn ornament in January of 2010. I wish you luck finding the Xtra of your dreams and wish you were correct about the ELSA's being eligible as training platforms after 2010, but you are mis-informed. -------- Thom Riddle CFI-SP Power Plant Mechanic N1208P RANS S6S, Tailwheel, 912UL N197BG FS1/447 -------------------- Scratch any cynic, he said, and youll find a disappointed idealist. George Carlin Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8383#208383 ________________________________________________________________________________
Date: Oct 12, 2008
John Schmidt, The following is NOT a direct quote from the 14 CFR but is a quotation from the EAA publication entitled CFI's Guide to Sport Pilot and Light Sport Aircraft. Experimental Light-Sport Aircraft ....Two-seat E-LSA are eligible to be used for hire for flight training through January 31, 2010.... Please let us all know if you can find a CFR that disputes this. It would make all our lives much easier and there would be no shortage of airplanes eligible for use as SP trainers. -------- Thom Riddle CFI-SP Power Plant Mechanic N1208P RANS S6S, Tailwheel, 912UL N197BG FS1/447 -------------------- Scratch any cynic, he said, and youll find a disappointed idealist. George Carlin Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8385#208385 ________________________________________________________________________________
Date: Oct 12, 2008
What the heck, John, I decided to look it up myself. It is in 91.319, which see: http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgFar.nsf/FARSBySectLookup/91.319 If the previous line is broken, try this http://tinyurl.com/43yhmm Note in particular 91.319(e)(2). This references 21.191, which see: http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgFar.nsf/FARSBySectLookup/21.191 If this line is broken, try this http://tinyurl.com/5x2mgo Note that this applies to ALL aircraft issued an experimental airworthiness certificate, not just ELSA. Apologies accepted :-). -------- Thom Riddle CFI-SP Power Plant Mechanic N1208P RANS S6S, Tailwheel, 912UL N197BG FS1/447 -------------------- Scratch any cynic, he said, and youll find a disappointed idealist. George Carlin Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8386#208386 ________________________________________________________________________________
Date: Oct 12, 2008
Subject: The one and only reason for the Sport Pilot Rule; was Airport
Attitudes No, it wasn't fat ultralights, fat pilots who couldn't pass a medical, bad training, good training, EAA, what the manufacturers wanted or didn't want, or anything else dreamed up on this list.It was, simply, that someone in government asked someone else, "Say, did you know we have around (you can pick a number if you don't like mine) 30,000 aircraft out there for which we have no records, no traceability, and no way to find should we need to?" An audible gasp is heard around the room. This is from Earl Lawrence, EAA's representative to the FAA and member of the ASTM committee that wrote the rule. That some other needs were met, not met, addressed, not addressed, determined with mathematical precision, or guessed at with a divining rod, is completely beside the point. Until 9/11/2001 there was no compelling political driving force to amend the FAR's for a new category of aircraft or airmen. On 9/12/2001 there was. Rick ________________________________________________________________________________
Date: Oct 12, 2008
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > We seem to generally accept that the rules are there for everyones > protection, and they were introduced for a good reason. That is > not to say we are happy with everything or that there isn`t a > little bending of the rules here and there. > > You on the other hand seem to take any rule as a direct challenge and set out to circumvent it in some way.. Those who might seem to have your best interests at heart often have another agenda. An example of "protection" if I might.... The FAA issued, despite public comment to the contrary, an Airworthiness Directive aimed at Bellanca Aircraft's Viking series of craft. There are several models within that series that have different engines, differently speced electrical systems and wholly different layouts of exhaust systems, some with running changes in the middle of a prioduction run. There are 17-30, 17-30a, 17-31, and 17-31tc models. Seems there had been a weld failure in the back of the muffler and would aim exhaust gasses back toward the firewall and the Cannon plug though which the P-leads passed, grounding the p- leads and killing the engine. How many documented times had this happened in the entire life of the aircraft? Three times that I can find. No fatalities, no injuries. Are the 17-31 and 17-31tc aircraft even suseptible to this event? No way in hell. But, the wise Ones at the FAA shotgunned the whole deal and made it apply to everyone that oned a Bellanca Viking. Just exactly whom were the FAA looking out for? Themselves. Stamp Act, Tea Tax, Townshend Acts, Prohibition.......all implemented for "everyones protection". Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 12, 2008
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: I have never been ramp checked. > I believe the primary reason, is that there is an agreement that the > FAA will not ramp check because it would greatly reduce the number of ga > and experimental aircraft and utralight vehicles that would attend. I'm a contractor to the FAA thru Lockheed Martin. Most of the folks I work with fly and don't want their own organization to come down on them, either. My FS II is overweight and carries 10 gal in the "passengers" location. FAA guy at a fly-in says: "Ten gallons, huh?" "Yup" "Single seat, too?" "Yup" "Good." ...and that was it. Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 12, 2008
Thom Riddle: Good afternoon, you have been a Sport Pilot instructor a total of 86 days. 86 days ago you we issued a rating to learn, understand and hopefully understand the complete subject matter. Like I said, Please, I truly encourage you and all who post on forums such as this, to check your accuracy of the intended message Now if you had read and understood the section, the complete section you would of realized my aforementioned statements were and are correct. Thom, its now time to go back to ground school and learn a real lesson of life, you are not the 86 day wonder that you think you are. Please also note the following Sec. 91.319 (h) as listed. The Letter of Deviation Authority LODA The LODA is the path to my previous statement of Any properly equipped ELSA aircraft can be used for instruction and the Flight Instructor can be compensated for his/her time. (h) The FAA may issue deviation authority providing relief from the provisions of paragraph (a) of this section for the purpose of conducting flight training. The FAA will issue this deviation authority as a letter of deviation authority. (1) The FAA may cancel or amend a letter of deviation authority at any time. (2) An applicant must submit a request for deviation authority to the FAA at least 60 days before the date of intended operations. A request for deviation authority must contain a complete description of the proposed operation and justification that establishes a level of safety equivalent to that provided under the regulations for the deviation requested. Now, Thom, ground school is out for today, class is dismissed; your homework assignment is Seek and Ye Shall Find Section 61 Subpart H as titled Flight Instructors Other Than Flight Instructors with a Sport Pilot Rating and then move onto Section 61 Subpart K Flight Instructors with a Sport Pilot Rating. Next ground school class will address correct and proper endorsements, the correct endorsement for a Certified Flight Instructor under section 61 subpart H is CFI ref Certified Flight Instructor, that is if you are certified under Section 61 Subpart H. Sincerely, John T. Schmidt, CFI :o Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8421#208421 ________________________________________________________________________________
Date: Oct 12, 2008
> So, you might find such an animal but it is highly unlikely, > especially since there are precious few MkII Xtras for sale. > > Thom in Buffalo > Jetpilot has a nice looking 912s powered xtra in Florida, he is trying to sell it last I heard. Check it out. Denny Rowe, Mk-3, PA ________________________________________________________________________________
Date: Oct 12, 2008
Subject: carburetor mounting
I had a thought today, while warming up the mighty Cuyuna engine on my UltraStar... especially at idle, seems the carburetor is jumping all over the place. Not surprising, with the carb sticking out from the side of the engine on its rubber boot, and the air filter sticking out even farther. Seems all that shaking can't be doing the carb or the rubber boot any good, and a simple brace to the engine mount tubes on top of the engine would steady it... or it might transmit even more vibration to the carb? Perhaps a support strut with its own rubber isolator, so it'd prevent the large deflections at lower rpm but still isolate the higher frequency motion? Thoughts, anyone? -Dana -- Lottery: a tax on the mathematically challenged. ________________________________________________________________________________
Date: Oct 12, 2008
At 08:10 PM 10/12/2008, Denny Rowe wrote: >>So, you might find such an animal but it is highly unlikely, >>especially since there are precious few MkII Xtras for sale. I know of two MKIII's for sale in my area (one in CT, one in RI), but I think both have 582's, not 912's. One of them, the owner also has a Thorp T-18; the other one's owner just finished building a Kitfox. -Dana -- Lottery: a tax on the mathematically challenged. ________________________________________________________________________________
Date: Oct 12, 2008
Subject: CT MKIII crash
Looks like the MKIII crash last month in CT (prelimnary report at http://tinyurl.com/4cv3pq ) may have been caused by water in the fuel, at least the investigator said there was water in the fuel line. AFAIK the plane had no gascolator, no means to inspect or drain out water. Pilot is home, leg healing nicely but still needing major reconstruction of the shattered ankle. Passenger should be home soon, but with a long period of taking it easy as the cracked (3 places) pelvis heals. Both are looking forward to flying again though the passenger says he'll stick to his gyrocopter! -Dana -- Lottery: a tax on the mathematically challenged. ________________________________________________________________________________
Date: Oct 12, 2008
> > Now, Thom, ground school is out for today, class is dismissed; your > homework assignment is ?oSeek and Ye Shall Find? Section 61 Subpart H > as titled Flight Instructors Other Than Flight Instructors with a Sport > Pilot Rating and then move onto Section 61 Subpart K Flight Instructors > with a Sport Pilot Rating. > > Next ground school class will address correct and proper endorsements, the > correct endorsement for a Certified Flight Instructor under section 61 > subpart ?oH? is CFI ref Certified Flight Instructor, that is if you are > certified under Section 61 Subpart ?oH?. > > Sincerely, > John T. Schmidt, CFI Yeah, Mike Bigelow (spelling?), also goes by Jetpilot, lives in Florida which should be close for you. Has a real fine 912S powered Xtra with VGs, and spades. Looks to be well equiped and super clean, plenty of pics in the archives and video links of the plane in flight. You can't miss, this is the bird you want! Denny Rowe, N616DR, registered experimental. ________________________________________________________________________________
Date: Oct 12, 2008
Subject: LSA (Was Airport Attitudes)
Last year down in Frederick, MD for the 16 hours SP repair man course, we were fortunate enough to have a fellow student who is an FAA lawyer, and was heavily involved in drafting the SP / LSA rules. (He's also a CFI and retired military, all in all, a great guy.) Here is his off the record take on how the SP rule came about: USUA and other orgs had requested an expansion of part 103. This was never going to happen, for the simple reason that 103 is illegal (Yes, I did a double take on that one as well). You see, the US code (the actual law passed by Congress that the FAA is suppose to be implementing), requires that all airplanes and pilots in the US be licensed. Calling an "airplane" a "vehicle" doesn't change that fact. Never mind how the original regs got passed. Today, any amendments would never make it past a legal review. So, he predicts the only change we might ever see in 103 is it's repeal, but that since the FAA would like to keep it, their solution is to ignore 103. However, they needed to respond to the requests, so they came up with a simpler, less regulatory complex set of rules that do require pilot licence's and aircraft registrations. Yes, these regs ended up substantially different then some of the original proposals, and how taht happened is a different story. However, how they got started at all, rather then amendinng 103, is interesting in it's own right. Well, that's one person's take on it, second hand anyway. I've pretty much recounted the story as I remember it, and while I'm afraid it is the type of posting to stir up some questions, I'm not likely to be able to answer many of them Chuck Subject: Kolb-List: Re: Airport Attitudes From: "lucien" <lstavenhagen(at)hotmail.com> NeilsenRM(at)comcast.net wrote: > Dana/All > > The Sport Pilot rule came about because the rules were SOOOOOO badly abused. Wrong. Believe it or not, the rate of abuse of the exemptions was not terribly higher than the rate of abuse of any other of FnAA's rule sets. You'd be amazed at what's flying around up there among the big iron, pilots with no medicals, some with no certificates, planes out of annual for years and years and CFI's who don't teach. Also, the BFI program brought about one of the largest increases in safety in all of aviation. Inexpensive and proximal training UL's and fat UL's was all over the place. It did more than any program to eliminate the self-taught syndrome with all the attend ________________________________________________________________________________
Date: Oct 12, 2008
You must be a lovely fellow to take lessons from. :) I had no idea that FAA ratings had TIG like military rank. Most folks would not be interested in pursuing such "deviations" or special letters. Just as most would not want to go through the hassle of getting an STC even though you could get almost anything changed on a standard type certificated airplane with one. Maybe a helicopter rotor on your C-150? The request for a special deviation could be denied too. BB MkIII, suzuki 43250 jet engine mech USAF 1962-66 A&P commercial rotorcraft pilot PP privileges long time On 12, Oct 2008, at 9:54 AM, John T. Schmidt wrote: > > > Thom Riddle: Good morning, as a fellow New Yorker I would have > expected you to have your facts straight. Please, I truly encourage > you and all who post on forums such as this, to check your accuracy > of the intended message. Thom, your overall statement is false and > misleading, not to mention discouraging to owners of ELSA aircraft. > Any properly equipped ELSA aircraft can be used for instruction and > the Flight Instructor can be compensated for his/her time. And, I > further encourage you to become more familiar with the CFRs they > are the rules we must adhere to. Now, as a point of interest, I > used the term properly equipped ELSA aircraft for a reason, No > instructor is permitted to give flight instruction to a student in > a Single-center stick A/C again please ref the CFRs. > Thom, congratulations on your Sport Pilot Instructors certificate, > now correct me if I am wrong, that was less than 90 days ago, right! > > > Thank you. > Sincerely, > John T. Schmidt, CFI > > > [Idea] > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 8361#208361 > > ________________________________________________________________________________
Subject: HKs Twinstar with vg's
Date: Oct 12, 2008
ck: Unbelievable !! A couple days ago I went to do some more test flying but it rained all day. Instead I spent the day making and installing some vg's on my wings as I was unhappy with the twinstars 38-40 mph stall speed. To design and place them, I read all I could find on this list and a bit more, and came up with what I thought looked best (intuitive engineering) Stall went down to 26 indicated !??! The plane will now mush along at 25-27 indicated with no scary tendancies. Yes, my airspeed may be lying when I get that slow, but the improvement is dramatic. I now fly approaches comfortably at 45-50 (instead of 55-60). Now, I need longer gear, as with the plane that slow the nose is high and the tail wants to hit first. Top end speed still seems fine, and with the hks is not an issue. The hks will easily accelerate the twinstar beyond vne. (I'm calling 80mph vne.) Sincere thanks to all those ahead of me who experimented with different shapes and positions, and made my desisions much, much easier. Cheers ! Rob Cannon Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8478#208478 ________________________________________________________________________________
Date: Oct 13, 2008
John, Oh, yes, the DEVIATION paragraph. Yes, I read that four years ago when it was first published. I also called the FAA about that particular paragraph. The guy's initial response was a chuckle, which is an unusual event with most FAA employees. Paraphrasing what he said, the bottom line is that this was intended primarily for gyroplanes because there is no such thing as an SLSA gyroplane. To my knowledge, there are no 2 seat type certificated gyroplanes that meet the weight limits for LSA. So, they had to write a provision by which someone willing to go through the process of applying for a deviation could get permission to use and experimental aircraft as a trainer after Jan 31, 2010. I also asked about getting such a deviation for an airplane. Another chuckle followed by not likely because there are lots of SLSA airplanes to choose from as trainers. Since this phone conversation a couple years ago, more and less expensive SLSA trainers have come on the market, as have more expensive ones. There are also thousands of older type certificated airplanes that can and are being used to train AIRPLANE sport pilots. Now that I know that the DEVIATION route was your intended path, I must ask why you didn't politely say something to the effect of "Yes, Thom, I know about the expiration date of Jan 31, 2010. My intention is to get a DEVIATION after that date." Instead, you chose to assume erroneously that I have not done my research. As a matter of fact, I read the FARS regularly, like some read the newspaper, and have been doing so since 1966 when I earned my private pilot certificate. The tone of your unfounded, unwarranted, unnecessary, unkind, and unappreciated remarks was condescending and arrogant. Since this is my last post on this subject, you may have the pleasure of the last word, if you choose... you pompous ass. -------- Thom Riddle CFI-SP Power Plant Mechanic N1208P RANS S6S, Tailwheel, 912UL N197BG FS1/447 -------------------- Scratch any cynic, he said, and youll find a disappointed idealist. George Carlin Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8486#208486 ________________________________________________________________________________
Subject: Re: HKs Twinstar with vg's
Date: Oct 13, 2008
Like you I installed the VG's a couple weeks ago on my Mark 111/912UL and still amazed at the difference. I did find something to be careful about. I did my first nose over dual with a CFI on board who had never been in a Kolb. I had been use to setting the trim and using it for take offs and landing with out any problems. When I went to full power the nose went over before I could react resulting in some damage to the FG but easy repair other than matching the paint design. I learned real quick to have the trim full nose up both dual and solo. Solo isn't bad but the rate of climb is much higher now so I adjust the trim just after leaving the ground. I would rather spend my time flying and less time on repairs. Like you I have noticed that the tail drops sooner on landing an am glad I have the taller steel legs. Even though I am happy with the results of the VG's I still like to tweak things. I am using the small alum ones with the dual fins. I have them set between every other rib and 10" back from the leading edge and 3 on the gap cover. How do you have yours set? I leaned Saturday how effective they was in a cross wind lands. I took off and lost most of the rudder control do to S hook connecting the tail wheel to the rudder breaking and wrapping around the rudder post binding the rudder. Like I said the take off and climb rate has changed so much I didn't react soon enough and was up and climbing. Knowing I had a problem I landed in a 15 mph wind at 90 deg with out full rudder usage. The VG's gave me more control with the ailerons in cross winds. I had done cross wind landings and take offs in 20-25 mph winds before but never realized how much difference they made until then. -------------------------------------------------- From: "robcannon" <leecannon(at)telus.net> Sent: 2008-10-13 00:52 Subject: Kolb-List: HKs Twinstar with vg's > > ck: Unbelievable !! A couple days ago I went to do some more test flying > but it rained all day. Instead I spent the day making and installing some > vg's on my wings as I was unhappy with the twinstars 38-40 mph stall > speed. To design and place them, I read all I could find on this list and > a bit more, and came up with what I thought looked best (intuitive > engineering) > Stall went down to 26 indicated !??! The plane will now mush along at > 25-27 indicated with no scary tendancies. Yes, my airspeed may be lying > when I get that slow, but the improvement is dramatic. > I now fly approaches comfortably at 45-50 (instead of 55-60). > Now, I need longer gear, as with the plane that slow the nose is high > and the tail wants to hit first. > Top end speed still seems fine, and with the hks is not an issue. The > hks will easily accelerate the twinstar beyond vne. (I'm calling 80mph > vne.) > Sincere thanks to all those ahead of me who experimented with different > shapes and positions, and made my desisions much, much easier. Cheers ! > Rob Cannon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 8478#208478 > > > ________________________________________________________________________________
Subject: Re: carburetor mounting
Date: Oct 13, 2008
Dana wrote: > I had a thought today, while warming up the mighty Cuyuna engine on my > UltraStar... especially at idle, seems the carburetor is jumping all over > the place. Not surprising, with the carb sticking out from the side of the > engine on its rubber boot, and the air filter sticking out even > farther. Seems all that shaking can't be doing the carb or the rubber boot > any good, and a simple brace to the engine mount tubes on top of the engine > would steady it... or it might transmit even more vibration to the > carb? Perhaps a support strut with its own rubber isolator, so it'd > prevent the large deflections at lower rpm but still isolate the higher > frequency motion? Thoughts, anyone? > > -Dana > -- > Lottery: a tax on the mathematically challenged. I tried something similar years ago on my first rotax, a 503 single carb..... Er, I'd recommend leaving it as-is, do NOT try to brace the carburettor in any way.............. The flexing is normal and is already the best solution. Note that, as the engine goes up above idle, the vibrations become much smaller. At flight RPM's everything is nice and still with only a high frequency buzz..... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8500#208500 ________________________________________________________________________________
Subject: Re: LSA (Was Airport Attitudes)
Date: Oct 13, 2008
so we're lucky that they made it a weight and performance limit, instead of (as in the UK even today for example) keeping the original foot launch requirement. >> Hi Dana, Not true. We started like everyone else with hang gliders for which there were no regulations. Progressed to putting engines on them. After a series of crashes the authorities unsurprisingly imposed rules and regs and invented the `microlight`. This was specifically a one or two seater with a MAUW and a maximum wing loading and stalling speed. The TYPE of plane had to be approved for basic design and flying qualities. Individual a/c had to be constructed to type and inspected for build quality. They are signed off as flyable and require an annual check and are registerd. Things have remained like that except that the MAUW has been nudged upwards a couple of times. In all respects `microlights` are treated as aircraft and are entitled to fly as high, as fast and in all the places any regular a/c can fly. In an attempt to get back to absolute basics and to stimulate new design and ideas there has recently been introduced a `sub 115kg` Category and I think that the Firefly is the only commercially available model on the market here which complies although there are several new designs in the pipeline.I don`t know all the details of the requirements for the sub 115k cat. off hand but I put them all on the list at one time and may be in the archive. Wedo not have anything as totally deregulated as your Experimental class but certainly there are no regs requiring a microlight to be foot launched. Cheers Pat There are no unregistered a/c with engines in the UK except PPG`sand all are subject to an annual C of A. Come to think of it I believe that gliders now have to be registered to comply with new EU Regs. Previously they only had a Brit. Gliding Assoc number. ________________________________________________________________________________
Date: Oct 13, 2008
Very interesting guest........ I did notice that I needed more nose up trim on take off, but I hadn't clued in that it was the vg's. I suppose the vg's move the center of lift back, resulting in more nose up trim needed. I have a bungee around the stick trim system(which works great by the way), and was wondering if the bungee had stretched. I made the vg's approx. 3" wide by 1.5 deep with two bent up fins (.25"), and put them between every rib and false rib staggered by 1" on the whole wing. You say the "s" hook broke. Why did it break? I'm using the connector that came with the compression springs from aircraft spruce, and I don't really like the way it atttaches to the stock kolb tailwheel arm ( seems like a bad wear point.) Does your plane have the nose hoop? Rob Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8503#208503 ________________________________________________________________________________
Date: Oct 13, 2008
I do have the nose skid hoop or I would have had more damage. I had thought about removing it before BUT not now..LOL The S hook bent the first time and came off causing the chain and spring to fly forward and wrapping around the rudder post restricting movement of the rudder. I notice when I put the S hook back on the tail wheel that it had weakened from rust under the paint as a result of setting so close to the ground. Then I got back to my main field the end of the S hook had broken off completely. I looked for stainless hooks but couldn't find any the right size so I am going to use the steel again but use a heavy saftey wire as a back up. I do a lot of off short field T/L's which the tail wheel takes a beating at times and I do have the larger tail wheel. I have two springs on my trim which I had to adjust a little shorter mainly for dual. I can fly hands and feet off and the yaw string is down the middle and elevation hold where I set it other than thermals when flying low. I drop my stall 8 mph solo and 10 mph duel and increased the rated of climb to 900 fpm solo and 600-700 fpm dual with 13 gals of gas..10 main and 3 reserve in the nose. Ground roll aprox. solo 125-150 ft duel 200-300 ft Now that the VG's are helping I need to work on the prop pitch for better XC fuel savings with out loosing short field T/L's -------------------------------------------------- From: "robcannon" <leecannon(at)telus.net> Sent: 2008-10-13 10:09 Subject: Kolb-List: Re: HKs Twinstar with vg's > > Very interesting guest........ I did notice that I needed more nose up > trim on take off, but I hadn't clued in that it was the vg's. I suppose > the vg's move the center of lift back, resulting in more nose up trim > needed. I have a bungee around the stick trim system(which works great by > the way), and was wondering if the bungee had stretched. > I made the vg's approx. 3" wide by 1.5 deep with two bent up fins (.25"), > and put them between every rib and false rib staggered by 1" on the whole > wing. > You say the "s" hook broke. Why did it break? I'm using the connector > that came with the compression springs from aircraft spruce, and I don't > really like the way it atttaches to the stock kolb tailwheel arm ( seems > like a bad wear point.) > Does your plane have the nose hoop? > Rob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 8503#208503 > > > ________________________________________________________________________________
Date: Oct 13, 2008
Just exactly whom were the FAA looking out for? Themselves.>> Hi Jim, An interesting take on attitudes. I wouldn`t for a moment suggest that organisations, FAA, CAA, or any other regulatory body is always right but I must ask `In what way did the Viking saga benefit the FAA` Ensured more work for themselves? Hardly necessary. Extra income? possibly but unlikely. It is all very well making statements like yours but to make it worthwhile somebody must end up better off. I don`t see how. Tea tax and Prohibition were introduced as `protection`?. Never heard that before. I thought they were introduced to raise money in one case, and to promote Temperance in the other. And to raise money of course. I would certainly agree that `hidden agendas` do exist, just look at the curtailment of civil liberties which has taken place under the `War on Terror` but that is just the usual tendency of governments to govern, and to govern is to control. Cheers Pat ________________________________________________________________________________
Date: Oct 13, 2008
Rob I forgot to mention one of the reasons I am tweaking things for short fields and fuel, being I live in So Florida. I am planning to fly over to the Bahamas and then do some island hopping. I waiting for the information and permits now and hope to go after the hurricane season is over. The VG's will help a lot with the ocean breezes that blow all the time. I have bought a head mount video camera and hope to get some great footage over the water and islands. I plan to have the new 20 gal fuel tank made and in by then just in case, 23 gals can get most any where over there. -------------------------------------------------- From: "robcannon" <leecannon(at)telus.net> Sent: 2008-10-13 10:09 Subject: Kolb-List: Re: HKs Twinstar with vg's > > Very interesting guest........ I did notice that I needed more nose up > trim on take off, but I hadn't clued in that it was the vg's. I suppose > the vg's move the center of lift back, resulting in more nose up trim > needed. I have a bungee around the stick trim system(which works great by > the way), and was wondering if the bungee had stretched. > I made the vg's approx. 3" wide by 1.5 deep with two bent up fins (.25"), > and put them between every rib and false rib staggered by 1" on the whole > wing. > You say the "s" hook broke. Why did it break? I'm using the connector > that came with the compression springs from aircraft spruce, and I don't > really like the way it atttaches to the stock kolb tailwheel arm ( seems > like a bad wear point.) > Does your plane have the nose hoop? > Rob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 8503#208503 > > > ________________________________________________________________________________
Date: Oct 13, 2008
I am always glad to see reports of guys that have tried VG's and found them to be a huge improvement in their Kolbs. For anyone else out there that has been thinking about installing VG's on their Kolb but are not sure yet, lots of reports like this and the video link below make this choice a no brainer. Adding VG's to your Kolb is the single most important thing you can do to increase its slow flight performance and SAFETY. If your engine quits and you are going to put it in down in a field, would you rather touch down at 40 MPH or 30 MPH, would you rather have a mushy approach at 50 MPH, or have your Kolb fly rock solid at 40 MPH with no mushing and full aileron authority ??? You can see all this at: http://www.vimeo.com/1480667 Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8515#208515 ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Oct 13, 2008
I had my tail wheel springs come off a few times. When I switched to compression springs I installed some "connector links" they are built like safety rings so they can't disconnect. I found them at Aircraft Spruce part number 06-15400 page 250 in the current catalog. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: <smlplanet(at)msn.com> Sent: Monday, October 13, 2008 10:50 AM Subject: Re: Kolb-List: Re: HKs Twinstar with vg's > > I do have the nose skid hoop or I would have had more damage. I had > thought about removing it before BUT not now..LOL > The S hook bent the first time and came off causing the chain and spring > to fly forward and wrapping around the rudder post restricting movement of > the rudder. I notice when I put the S hook back on the tail wheel that it > had weakened from rust under the paint as a result of setting so close to > the ground. Then I got back to my main field the end of the S hook had > broken off completely. I looked for stainless hooks but couldn't find any > the right size so I am going to use the steel again but use a heavy saftey > wire as a back up. I do a lot of off short field T/L's which the tail > wheel takes a beating at times and I do have the larger tail wheel. ________________________________________________________________________________
Date: Oct 13, 2008
Subject: Alternative Tail Wheel Steering System
> > ................. You say the "s" hook broke. Why did it break? I'm using the connector that came with the compression springs from aircraft spruce, and I don't really like the way it atttaches to the stock kolb tailwheel arm ( seems like a bad wear point.) > Rob, I had a similar problem with tension springs breaking and ground looping. Came up with the following system. It may be of interest to you. See: http://www.thirdshift.com/jack/firefly/firefly133.html I have made a few changes since posting the above page. The spoke nuts are shortened to save weight and round throttle stop collars are used to safety the spoke nuts. I will be updating the page in the near future. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Subject: Re: Alternative Tail Wheel Steering System
Date: Oct 13, 2008
Compression Springs also make tail wheel steering much more positive and precise. The centering actions of properly set up compression springs is much better than two springs in tension. I made the conversion on my MK III Xtra and it makes a huge difference in the way the plane handles on the ground. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8521#208521 ________________________________________________________________________________
Subject: Pictures !!! Flying a Kolb Around South Florida...
Date: Oct 13, 2008
Attached are some pictures I took last week on an evening flight around South Florida in my Kolb MK III Xtra. Flight time was 2 hours and I burned about 7 gallons of gas. -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8532#208532 Attachments: http://forums.matronics.com//files/ultralightaerialflorida_37_287.jpg http://forums.matronics.com//files/dsc03164_966.jpg http://forums.matronics.com//files/dsc03144_154.jpg http://forums.matronics.com//files/dsc03048_412.jpg http://forums.matronics.com//files/dsc02954_278.jpg http://forums.matronics.com//files/dsc02948_134.jpg http://forums.matronics.com//files/dsc02854_134.jpg ________________________________________________________________________________
Subject: Nasa info on Vgs
Date: Oct 13, 2008
http://www.nasa.gov/centers/langley/news/factsheets/Micro-VG.html I though this was interesting. They are putting them on the flaps/ ailerons in these test. Has anyone tried them there on a kolb? Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8549#208549 ________________________________________________________________________________
Date: Oct 13, 2008
Subject: Re: Airport Attitudes
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > It is all very well making statements like yours but to make it worthwhile > somebody must end up better off. I don`t see how. Did I, or the other Viking owners, end up being better off? No. Did the FAA, as an organization, end up being better off? No. Did the public benefit? No. Did one or two folks in the FAA's aircraft directorate make a name for themselves? Just look at how many lives we saved today....... > Tea tax and Prohibition were introduced as `protection`?. Never heard that > before. I thought they were introduced to raise money in one case Protection of the British East India Tea company.... > promote Temperance in the other. And to raise money of course. Wilson and other politicians chose to save their political hides by eventually siding with the dry faction of the populace after election, even tho the Temperance folks were a small majority. Less to do with morality than with expediency. > I would certainly agree that `hidden agendas` do exist, just look at the > curtailment of civil liberties which has taken place under the `War on > Terror` but that is just the usual tendency of governments to govern, and to > govern is to control. Not one of my civil liberties has been curtailed...none. Not even privacy. Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 13, 2008
Thom Riddle: Good afternoon, thank you for your permission and the opportunity for the last word. Once again, Please, I truly encourage you, Thom and all who post on forums such as this, to check your accuracy of the intended message. So, it appears you are ducking out on your ground school homework assignment. The subject matter correct and proper endorsements along with proper communications are vitally important. The Flight Instructor Sport rating is very restrictive in nature and completely limited to the arena of Sport Pilots and the aircraft they may be certified to operate. The simple facts are I can give you ground school, however, your limited rating of Flight Instructor Sport prevents you from giving ground instruction to a Recreational Pilot and above, exercising the privileges of their certificates. Your assessment of The Letter of Deviation Authority LODA is completely speculative as stated. The LODA for your edification is the answer to the many individual Letters of Deviation that were assigned to the many aviation organizations, such as the EAA, the PRA and the numinous Ultra-light groups and organizations that had certified BFIs and AFIs as part of their exemptions to conduct flight training. The FAA in the latter part of 2007 canceled all Letters of Exemption and all BFIs and AFIs no longer existed after January 31, 2008. Thom, again your evaluation of the LODA strictly for Rotorcraft Gyroplanes is uninformed and erroneous; also it would be gratifying if Mr. Chuckles from the FAA was identified. If you so choose to discuss the world of Rotorcraft Gyroplanes, as a rated Certified Flight Instructor Rotorcraft Gyroplane I will be more than happy to bring you up to speed, however, your personal assessment of the process of the LODA is completely off the mark of authenticity. Thom, obviously you have no understanding of the path to achieving the LODA. The path is simple, somewhat time consuming, however, extremely rewarding with the achievement of your very own personal FAA Letter of Deviation Authority. It opens the door for flight Instruction for compensation to the CFI that is willing to procure The Letter of Deviation Authority. Thom I would have more respect for you, if you had the ability to simply admit the Truth that you were incorrect from the start and continued to be in error from your very first post until the last. And, yes, you can feed your ego with stories of Mr. Chuckles the FAA guy with no name and basically attempted to spin the subject to save face. All of my posts were direct; they also included Good morning as well as Good afternoon and concluded with thank you and sincerely. You, however, choose, Herr Schmidt, but you are mis-informed, Apologies accepted, not to mention, The tone of your unfounded, unwarranted, unnecessary, unkind, and unappreciated remarks was condescending and arrogant, and of course your eloquent last words you pompous ass Yes, Thom, I truly understand your persona, when the Truth fails you attack every thing other than the subject. Good Luck and thanks for your exercise in futility. Sincerely, John T. Schmidt, CFI Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8561#208561 ________________________________________________________________________________
Date: Oct 13, 2008
At 10:07 AM 10/13/2008, pj.ladd wrote: >Wedo not have anything as totally deregulated as your Experimental class >but certainly there are no regs requiring a microlight to be foot launched.... >There are no unregistered a/c with engines in the UK except PPG`sand all >are subject to an annual C of A... Perhaps I got it wrong. In a UK printed book on paramotoring I have, they speak of the "foot launch exemption" applying to PPG's (and, presumably, PG, HG, and PHG), and said that if you add wheels to your PPG as is commonly done in the US, it would no longer qualify for the exemption. Do even foot launched aircraft require a C of A? I was aware that your microlight category required registration, etc. -Dana -- Do YOU trust a government that won't obey it's OWN LAWS? ________________________________________________________________________________
Date: Oct 13, 2008
Gentlemen: Getting back to the topic, I have received a number of positive leads in my quest for that extra Xtra. I have contacted all leads. And, a very big thanks for all the information that was sent my way and please keep them coming. Sincerely, John T. Schmidt, CFI :D :D :D :D :D :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8567#208567 ________________________________________________________________________________
Date: Oct 13, 2008
Subject: Re: CT MKIII crash
Dana, Looks like we should all have some sort of a gascolator built into ou r-aircraft- especially now that most of us are not counting micro-ounce s to make 254lbs .-Although I will admit I never had that problem till No rm and I did ,but I was a nut about the fuel quality ,but-that is not a l uxury we always have so a possibly wet can of fuel sent through a gascolate r then a fresh fuel line filter which you carry onboard would be far supior to no fuel in the morn. It was after all Water and Bugs that killed Norm - and left me disabled Firefly pilot to be!-- Chris =0A=0A=0A=0A----- Original Message ----=0AFrom: Dana Hague <d-m-hague(at)comcast.net>=0ATo: kol b-list(at)matronics.com=0ASent: Sunday, October 12, 2008 8:55:33 PM=0ASubject: =0A=0ALooks like the MKIII crash last month in CT ( prelimnary report at =0Ahttp://tinyurl.com/4cv3pq ) may have been caused by water in the fuel, at =0Aleast the investigator said there was water in th e fuel line.- AFAIK the =0Aplane had no gascolator, no means to inspect o r drain out water.=0A=0APilot is home, leg healing nicely but still needing major reconstruction of =0Athe shattered ankle.- Passenger should be hom e soon, but with a long period =0Aof taking it easy as the cracked (3 place s) pelvis heals.- Both are looking =0Aforward to flying again though the passenger says he'll stick to his =0Agyrocopter!=0A=0A-Dana=0A--=0A- Lott ===================0A=0A=0A ________________________________________________________________________________
Date: Oct 13, 2008
Mike B: Terribly sorry, but I do not experience what you describe below in my mkIII or any other model Kolb. My mkIII breaks at 30 mph IAS in ground effect. It has flown as slow as other mkIII's with VG's installed on them. Guess I am still satisfied with the way my mkIII flies and don't have a need for VG's. I have demonstrated over the years, miles and hours, my mkIII is safe to fly, as is, in many different and varied weather and geographic conditions. If it was unsafe, I would surely run right out and buy a set of VG's for her. PS: Using Larry Cottrell's email. Makes it a lot faster for me to read and reply to messages this way, rather than using web mail. Take care, john hauck mkIII Rock House, Jordan Valley, Oregon PSS: Many of us have no qualms landing in fields, with or without power. Some of us fly out of cow pastures. These are our home bases. I have been flying out of a cow pasture for 24 years. When one flies out of 3, 4, and 5 thousand ft paved airports, one finds it difficult to land in small fields. Good idea to get as much experience as possible landing out. Never know when you might need to land in a field and wait out weather. That's much better than deviating 70 miles to the nearest airport with good weather. Adding VG's to your Kolb is the single most important thing you can do to increase its slow flight performance and SAFETY. If your engine quits and you are going to put it in down in a field, would you rather touch down at 40 MPH or 30 MPH, would you rather have a mushy approach at 50 MPH, or have your Kolb fly rock solid at 40 MPH with no mushing and full aileron authority ??? Mike ________________________________________________________________________________
Date: Oct 13, 2008
Subject: Letter of Deviation Authority
From: http://www.faa.gov/news/aviation_news/2008/media/marapr2008.pdf FAA Notice 8900.15, available on the FAA Internet Web site, www.faa.gov, explains the process. The notice states, in part: "Training deviations will be issued only for training that cannot be conducted in aircraft holding standard airworthiness certificates. Training such as aerobatics, tail wheel transition, or high performance/complex transition can be conducted in aircraft holding standard airworthiness certificates and are therefore not acceptable. Acceptable training is: (1) Experimental aircraft specific make and model initial training. (2) Experimental aircraft specific make and model recurrent training. (3) Jet unusual attitude and upset training. (4) Aircraft specific instrument competence training. (5) Experimental aircraft specific make and model flight review training. (6) Experimental aircraft specific make and model formation training. (7) Other specific training approved by the General Aviation and Commercial Division, AFS-800" [Editor's Note: Flight Standards Service, Washington Headquarters] From: http://www.faa.gov/about/office_org/field_offices/fsdo/dsm/local_more/newsletter/media/winter2008.pdf Experimental aircraft owners who wish to allow their aircraft to be "hired" for flight training will need to contact the Operations Supervisor at their local FSDO and apply for an Experimental Aircraft Flight Training Letter of Deviation as outlined in FAA Notice N 8900.15. Once that letter is issued, the aircraft owner may receive compensation for the flight training use of the aircraft. Remember that the Letter of Deviation is only required if the owner of the aircraft wishes to rent his experimental aircraft to others for transition training. A pilot may receive flight instruction in his own aircraft (once the initial flight test period is complete) without specific authorization. Also, a person may allow others to use their experimental aircraft for flight training at any time so long as no fee is charged for the use of the aircraft. Rick ________________________________________________________________________________
Date: Oct 13, 2008
Rick N: I use those also. Work good. john h mkIII hauck's holler remote, SE Oregon I had my tail wheel springs come off a few times. When I switched to compression springs I installed some "connector links" they are built like safety rings so they can't disconnect. I found them at Aircraft Spruce part number 06-15400 page 250 in the current catalog. Rick Neilsen ________________________________________________________________________________
Date: Oct 13, 2008
Mike B: I use compression springs also. Wouldn't leave home without them. john h mkIII Compression Springs also make tail wheel steering much more positive and precise. The centering actions of properly set up compression springs is much better than two springs in tension. I made the conversion on my MK III Xtra and it makes a huge difference in the way the plane handles on the ground. Mike ________________________________________________________________________________
Subject: Re: Pictures !!! Flying a Kolb Around South Florida...
Date: Oct 13, 2008
Mike B: Normal fuel burn with a 912uls and a mkIIIx is 5 gph at 5000 rpm. That is under cross country conditions. Diddling around the patch one can cut fuel burn in half. john h mkIII Attached are some pictures I took last week on an evening flight around South Florida in my Kolb MK III Xtra. Flight time was 2 hours and I burned about 7 gallons of gas. ________________________________________________________________________________
Date: Oct 13, 2008
A gascolator is a VERY good idea in any airplane, even an ultralight. In almost all water contamination cases, the gascolator will hold any water that may have gotten into your fuel until you land, and you will be able to catch it before it causes an engine failure. It would take a huge amount of water in the fuel to fill up a standard gascolator, and be sent on to the carbs. When I drain the gascolator, I can easily detect even the smallest amount of water, which would make me investigate where the water came from before I flew anymore... With a gascolator, water is just never going to make it into your carbs unless you are pouring large amounts of water into your tanks, in which case nothing will save you.... I have been been advising people to put in aircraft quality fuel components and fuel systems of accepted aircraft design in their Kolbs for a while now on this list. The weight gain is negligible for the extra safety and reliability it provides. There are always a few people here that are just to good to take advice from someone that is not popular here on this list, and that kind of grade school mentality is what gets people hurt. Aviation does not care who you or who your fiends are, if you make mistakes, you will likely get hurt or die. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8603#208603 ________________________________________________________________________________
Subject: Flying video
Date: Oct 13, 2008
http://www.youtube.com/watch?v=S__jqr3_4FI Did anyone see Crystal's video scaring the family by forcing them to take a ride in the Cessna with her? Poor Mom and Dad [Wink] I enjoyed your video! Looks like the family enjoyed the flying as well. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8604#208604 ________________________________________________________________________________
Date: Oct 13, 2008
Hi John, When I am alone, the Kolb climbs like a Rocket :) My time in climb with the engine at full throttle is very very short. Once at altitude, and on a cross country, I cruise at 4200 - 4300 RPM which gives me 3.5 GPH burn at 70 MPH, more or less. I have my prop pitched for cruise with 5200 RPM at full power climb at 60 MPH. I don't have a fuel flow Gage, but a two hour cross country when I am alone takes just under 7 gallons to fill it back up. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8605#208605 ________________________________________________________________________________
Subject: Re: Nasa info on Vgs
Date: Oct 13, 2008
John Hauck is putting them on his MkIII tonight with a flashlight in one hand. One of these days they will discover that shag carpeting will do wonders on the wing tops. BB On 13, Oct 2008, at 3:18 PM, grantr wrote: > > > http://www.nasa.gov/centers/langley/news/factsheets/Micro-VG.html > > I though this was interesting. They are putting them on the flaps/ > ailerons in these test. > > Has anyone tried them there on a kolb? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 8549#208549 > > ________________________________________________________________________________
Date: Oct 13, 2008
Hi Chris D: I have encountered the same problem with my Kolbs over the years. If I make a concerted effort to check the float bowls at least once a month, I have no problem. All it takes is a small drop of water to get the corrosion started in the "pot metal" float bowls. Then a little speck of trash gets over the main jet well fence, lodges in the main jet, and its forced landing time. I have a home made gascolator that works well. If I drain fuel each day I fly, I do not have a water problem. The two engine failures I experienced in the past 2,500+ 912 hours was caused by fuel contamination. Both times getting fuel from a reliable source, I thought. Take care, john h mkIII It was after all Water and Bugs that killed Norm and left me disabled Firefly pilot to be! Chris ________________________________________________________________________________
Date: Oct 13, 2008
Mike B: Haven't found it necessary to use aircraft quality fuel components and fuel systems designed for aircraft. What I do use is cheap, reliable, and has been proven over many thousands of hours. The two engine failures I experienced be cause of fuel contamination could have been prevented very easily. However, due to pilot error, I did not check the fuel prior to takeoff in both cases. These forced landings were my fault. john h mkIII I have been been advising people to put in aircraft quality fuel components and fuel systems of accepted aircraft design in their Kolbs for a while now on this list. The weight gain is negligible for the extra safety and reliability it provides. There are always a few people here that are just to good to take advice from someone that is not popular here on this list, and that kind of grade school mentality is what gets people hurt. Aviation does not care who you or who your fiends are, if you make mistakes, you will likely get hurt or die. Mike ________________________________________________________________________________
Date: Oct 13, 2008
Bob B: Not true. I have to put new carpeting in the old lake cabin before I put it on the Kolb. ;-) john h mkIII John Hauck is putting them on his MkIII tonight with a flashlight in one hand. One of these days they will discover that shag carpeting will do wonders on the wing tops. BB ________________________________________________________________________________
Date: Oct 13, 2008
At 05:45 PM 10/13/2008, chris davis wrote: >Dana, Looks like we should all have some sort of a gascolator built into >our aircraft especially now that most of us are not counting micro-ounces >to make 254lbs... Some may recall that I started a thread a year or so ago about trying to find a suitable gascolator. Modern aircraft units are too heavy (I'm one of the ounce counters) and expensive and the cheap tractor ones are too, well, cheap, and have no drain provision without removing the bowl. What I really want is the clear glass tube type with drain like I had on my T-Craft, but nobody seems to make such a thing any more. I settled for a loop of clear fuel line (sorry John) at the lowest point in combination with the clear glass inline filter. No drain provision, but I can see if there's anything there... so far nothing. I also always do a full power runup and wait 'til the EGT stabilizes before the first flight of every day and after each refueling. But I'm still looking for that perfect gascolator. -Dana -- Help Wanted: Telepath. You know where to apply. ________________________________________________________________________________
Date: Oct 13, 2008
> >A gascolator is a VERY good idea in any airplane, even an ultralight. ........................ > The weight gain is negligible for the extra safety and reliability it provides. There are always a few people here that are just to good to take advice from someone that is not popular here on this list, and that kind of grade school mentality is what gets people hurt. Aviation does not care who you or who your fiends are, if you make mistakes, you will likely get hurt or die. > Mike, If one does not draw fuel from the bottom of the tank and follows good refueling practices, there is no need for a gascolator on a FireFly. Weight is always a problem with an ultralight. Why not just state your point and leave off the flogging of individuals who you know are not going to follow your advice. Your information is not unpopular but delivery is some what rough. I am sure grade school people appreciate your humor and will accept all blame for ill advice. All of us make mistakes all the time. For many of us that is how we learn. Fortunately I am still around and continue to make mistakes. The last one is probably in the responding to this email. Please lighten up be kind to yourself. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Oct 13, 2008
Dana: I put a "T" in the bottom of my fuel line loop. Dropped another line off the bottom. Then installed a $3.00 Briggs and Stratton plastic fuel shut off valve. Works great. john h mkIII I settled for a loop of clear fuel line (sorry John) at the lowest point in combination with the clear glass inline filter. No drain provision, but I can see if there's anything there... so far nothing. -Dana ________________________________________________________________________________
Date: Oct 13, 2008
Jack H: I agree with you 100%, as far as your Fire Fly is concerned. For all other aircraft, especially the ones I fly, I want a gascolator. I draw fuel from the lowest point of my fuel tank. The reason, so I can get every drop out of there if necessary. I also use clean fuel, and the homemade gascolator and filter should take care of what I miss, unless I duplicate my two serious fueling mistakes I mentioned in an earlier message. As long as I take a fuel sample after fueling, I will know if it is good to go or not. A fuel sample should be taken in a clear glass jar. That is the way I was taught in Army Rotary Wing Flight Training 40 years ago. It still works well today. Take care, john h mklIII If one does not draw fuel from the bottom of the tank and follows good refueling practices, there is no need for a gascolator on a FireFly. Weight is always a problem with an ultralight. Jack B. Hart FF004 ________________________________________________________________________________
Subject: Redrive VW powered MKIIIC Video
Date: Oct 13, 2008
For the first time I tried to video my airplane. There is alot more to it than I figured. I used the seat belt to lash a tripod with the video camera on it in the passenger seat. The vibrations are more amplified than than I notice in the cockpit. I wonder if there are any utilities that can stabilize the video. The end of my runway is narrow so I go slowly through that section and add power slowly till I get in the open. I climb at 3500 RPM and power back to 3200 RPM for cruise. The video doesn't do justice to how much I cut back power for cruise. Check out the video on Utube http://www.youtube.com/watch?v-kMl_yvqo0 Rick Neilsen Redrive VW powered MKIIIC ________________________________________________________________________________
Date: Oct 13, 2008
Dana/All Great Plains Aircraft sells a gascolator that is light has a drain port and is $29.95 or was a few years ago. I purchased a Curtis fuel quick drain valve for mine. The gascolator is located at the low point of the fuel system with the drain valve sticking out the side of the fuselage cage. I sump my fuel system before each flight of the day and after each fueling. There are a number of things like this that are normal for GA aircraft. They have learned the value of gascolators, boost pumps, etc that greatly increase safety. Nothing smart on my part just things that I got used to having in a aircraft I fly. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "Dana Hague" <d-m-hague(at)comcast.net> Sent: Monday, October 13, 2008 8:32 PM Subject: Re: Kolb-List: CT MKIII crash > > At 05:45 PM 10/13/2008, chris davis wrote: >>Dana, Looks like we should all have some sort of a gascolator built into >>our aircraft especially now that most of us are not counting micro-ounces >>to make 254lbs... > > Some may recall that I started a thread a year or so ago about trying to > find a suitable gascolator. Modern aircraft units are too heavy (I'm one > of the ounce counters) and expensive and the cheap tractor ones are too, > well, cheap, and have no drain provision without removing the bowl. What > I really want is the clear glass tube type with drain like I had on my > T-Craft, but nobody seems to make such a thing any more. > ________________________________________________________________________________
Subject: Re: Letter of Deviation Authority
Date: Oct 14, 2008
Rick, Thanks for posting that. Of course, just because it comes straight from the FAA doesn't mean it is not erroneous, misleading, and just plain wrong :-). -------- Thom Riddle CFI-SP Power Plant Mechanic N1208P RANS S6S, Tailwheel, 912UL N197BG FS1/447 -------------------- Scratch any cynic, he said, and youll find a disappointed idealist. George Carlin Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8689#208689 ________________________________________________________________________________
Date: Oct 14, 2008
Subject: Re: Redrive VW powered MKIIIC Video
Rick, Your video link goes to the YouTube Index when I click it, instead of directly to the video you posted. What should we search on to find your video? BTW. I did some video with our Allegro a couple years ago by strapping the video camera to the wing strut with an inch or so of foam rubber between the camera and the strut. Worked great with no noticeable vibration in the resulting video. Thom in Buffalo ________________________________________________________________________________
Date: Oct 14, 2008
http://www.greatplainsas.com/pg28f.html Great Plains Gascolator This Gascolator is a high quality, low cost fuel filter and water strainer. It should be installed at a low point in the fuel system, below the fuel tank to trap any water that may accumulate so it can be drained. The gascolator has a 10 micron fuel filterand an 1/8" pipe thread outlet for a quick fuel drain valve (not included). If you are using a fuel pump, the pump should be installed between the carb and the gascolator. Price . . . $29.95. Curtis Quick Drain Valve for use on Gascolator . . . $11.75. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8693#208693 ________________________________________________________________________________
Date: Oct 14, 2008
Richard the camera itself should be isolated from any hard part of the aircraft by at least an inch of foam-rubber or similar material. That should cure the problem. Probably plastic bubble-wrap would work well, too, and it's cheap and lightweight. You might have to rig a camera-support bracket or even tape the foam-wrapped camera to the tripod head. Would you consider a helmet with the camera munted on the side? Makes aiming lots easier, but you must remember not to swing your head around too much. BTW I found that a camera hard-mounted to Cessna struts had no vibration problems. Wind buffeting was the only thing to watch out for. And falling off the aircraft of course! Nice video! Russ On Oct 13, 2008, at 11:39 PM, Richard & Martha Neilsen wrote: > For the first time I tried to video my airplane. There is alot more > to it than I figured. I used the seat belt to lash a tripod with > the video camera on it in the passenger seat. The vibrations are > more amplified than than I notice in the cockpit. I wonder if there > are any utilities that can stabilize the video. > > The end of my runway is narrow so I go slowly through that section > and add power slowly till I get in the open. I climb at 3500 RPM > and power back to 3200 RPM for cruise. The video doesn't do justice > to how much I cut back power for cruise. > > Check out the video on Utube > > http://www.youtube.com/watch?v-kMl_yvqo0 > > Rick Neilsen > Redrive VW powered MKIIIC > > ________________________________________________________________________________
Date: Oct 14, 2008
NeilsenRM(at)comcast.net wrote: > For the first time I tried to video my airplane. There is alot more to it than I figured. I used the seat belt to lash a tripod with the video camera on it in the passenger seat. The vibrations are more amplified than than I notice in the cockpit. I wonder if there are any utilities that can stabilize the video. > > The end of my runway is narrow so I go slowly through that section and add power slowly till I get in the open. I climb at 3500 RPM and power back to 3200 RPM for cruise. The video doesn't do justice to how much I cut back power for cruise. > > Check out the video on Utube > > http://www.youtube.com/watch?v-kMl_yvqo0 (http://www.youtube.com/watch?v-kMl_yvqo0) > > Rick Neilsen > Redrive VW powered MKIIIC > > Rick: Video looks good. Probably wouldn't have noticed the vibration if you hadn't mentioned it. Won't make an IMAX production, but enjoyable, none-the-less. Don't know why Thom R. couldn't pick it up. (Thom... Rick used " redrive VW powered Kolb " as tags.) Will be nice to capture the fall colors "up there" to look at so when you get down here for the winter and all you have is green from the palm trees, blue green from the waters and light colored sand. :D -------- George Alexander FS II R503 N709FS http://gtalexander.home.att.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8704#208704 ________________________________________________________________________________
Date: Oct 14, 2008
I know I'm going to get beat up for this one. Why do you have to put the gascolator at the lowest point in the system? I bought a gascolator with a plastic bowl designed for JetSkis and I was going to put it right behind my seat so I could actually see it and empty it from time to time. Putting it at the lowest point would probably mean that it would never get looked at regularly. Any water still has to pass through the gascolator no matter where it is. OK, shoot. Tell me how I'm wrong. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8753#208753 ________________________________________________________________________________
Date: Oct 14, 2008
> >I know I'm going to get beat up for this one. > >Why do you have to put the gascolator at the lowest point in the system? I bought a gascolator with a plastic bowl designed for JetSkis and I was going to put it right behind my seat so I could actually see it and empty it from time to time. Putting it at the lowest point would probably mean that it would never get looked at regularly. Any water still has to pass through the gascolator no matter where it is. > Scott, You may want to consider water freezing. It is best if it freezes in the colator rather that some place in the fuel line. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Oct 14, 2008
At 01:42 PM 10/14/2008, olendorf wrote: >Why do you have to put the gascolator at the lowest point in the >system? I bought a gascolator with a plastic bowl designed for JetSkis >and I was going to put it right behind my seat so I could actually see it >and empty it from time to time. Putting it at the lowest point would >probably mean that it would never get looked at regularly. Any water >still has to pass through the gascolator no matter where it is. > >OK, shoot. Tell me how I'm wrong. Because, since water is heavier, it will naturally drain to the lowest point in the system, where it can be drained off via the gascolator. -Dana -- Gun control: The theory that 110lb. women should have to fistfight with 210lb. rapists. ________________________________________________________________________________
Date: Oct 14, 2008
Scott Its aircraft standard practice to put it in the lowest point. I believe water in a system will separate and settle to the lowest point in a fuel system over time. When you sump the system with a quick drain you will get any water out of the system. This is your first warning that water is in your fuel and may need to be drained further. If you don't have your gascolator/quick drain at the low point you will not get any water out till after the water has been pumped to it. I also believe that some water might get through a gascolator if the fuel flow is high or the gascolator over fills with water. Don't worry so much about access to the gascolator but do make the quick drain accessible. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "olendorf" <olendorf(at)gmail.com> Sent: Tuesday, October 14, 2008 1:42 PM Subject: Kolb-List: Re: CT MKIII crash > > I know I'm going to get beat up for this one. > > Why do you have to put the gascolator at the lowest point in the system? > I bought a gascolator with a plastic bowl designed for JetSkis and I was > going to put it right behind my seat so I could actually see it and empty > it from time to time. Putting it at the lowest point would probably mean > that it would never get looked at regularly. Any water still has to pass > through the gascolator no matter where it is. > > OK, shoot. Tell me how I'm wrong. > > -------- > Scott Olendorf > Original Firestar, Rotax 447, Powerfin prop > Schenectady, NY > http://KolbFirestar.googlepages.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 8753#208753 > > > ________________________________________________________________________________
Date: Oct 14, 2008
Now I am confused. On my plane the fuel pickups are on the bottom of the tanks and the fuel is pulled to the top of the tanks. There is no way to put the gascolator at the bottom of my fuel system unless I install fuel pickups in the bottom of my tanks. With my current setup would my plane even benefit from having one? Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8777#208777 ________________________________________________________________________________
Date: Oct 14, 2008
Here is the gascolator I use. It is cheap, 70 bucks, works very well, has a built in screen and weighs maybe 8 ounces. It is light enough to use even on a Firefly. At a weight of 254 pounds, 8 ounces just isn't going to hurt anything even on a firefly. Dont forget to buy the extra gasket if you plan tu use auto gas, the included gasket is not compatible.... Even stock Mark III fuel tanks do not drain from the bottom, they are a similar setup to the fireflys tank, but you should still have a gascolator. Just because you draw gas from the top of your take through a tube is does not mean you do not need a gascolator. Any fuel system on an airplane should have one. Its not just for water, but any larger garbage will be blocked by the screen so that you can drain it out and see it. My guess is that the MK III in the accident had tanks that drew from the top like all stock Kolb MK III's do.... And yes even though he was drawing from the top he still really needed a gascolator. Its myths like this that get spread around by people that don't know any better are things that can get people hurt... John H. I will explain my statement about aircraft quality fuel parts a bit more, I do not mean certified aviation fuel parts, or even fuel components that have been especially built for aircraft. Many marine and auto lines and filters are of equal or better quality than some aircraft components. I mean to use top quality components that would be equal to or better aircraft grade - which I am sure you have in your MK III. What I would most definitely NOT USE is that cheap, easily cut, easily melted semi clear fuel line that goes bad quickly and that is found in so many ultralights. Just because this substandard fuel line has found its way into the ultralight culture does not mean that it is a good idea. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8780#208780 ________________________________________________________________________________
Date: Oct 14, 2008
YES.....cheap insurance.....as they say shit happens and it is a long way down and time to think about what you could or should have done to prevent it. -------------------------------------------------- From: "grantr" <grant_richardson25(at)yahoo.com> Sent: 2008-10-14 15:27 Subject: Kolb-List: Re: CT MKIII crash > > Now I am confused. > > On my plane the fuel pickups are on the bottom of the tanks and the fuel > is pulled to the top of the tanks. > > There is no way to put the gascolator at the bottom of my fuel system > unless I install fuel pickups in the bottom of my tanks. > > With my current setup would my plane even benefit from having one? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 8777#208777 > > > ________________________________________________________________________________
Date: Oct 14, 2008
For those interested in the LODA process, please note that the FAA News item referring to Notice 8900.15, apparently mis-identified the notice. It appears that the correct notice number is 8700.47 and can be found here: http://www.ihsaviation.com/faa/N8700-47.pdf According to this notice, the restrictions placed on the user of a LODA for using an experimental aircraft for training, if they can even get one, are significant. Additionally, IN MY OPINION, the application process is burdensome enough to dissuade mere mortals who are not masochistic. -------- Thom Riddle CFI-SP Power Plant Mechanic N1208P RANS S6S, Tailwheel, 912UL N197BG FS1/447 -------------------- Scratch any cynic, he said, and youll find a disappointed idealist. George Carlin Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8785#208785 ________________________________________________________________________________
Date: Oct 14, 2008
Mike You say stock tanks don't drain from the bottom. Are you sure? My stock Kolb 5 gallon tanks drain from the bottom. I added a finger strainer/shutoff valve to the stock setup when I installed my stock bottom drains to my stock tanks per Kolb instructions. Has this changed? I don't know for sure that a gascolator will work as designed with the top draw system but it seems it would help. I guess this is another argument for the standard practice of bottom drain fuel tanks. Has anyone that has had a bottom drain installed properly ever had a leak? I still don't fully understand why one would use the top draw system. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "JetPilot" <orcabonita(at)hotmail.com> Sent: Tuesday, October 14, 2008 3:35 PM Subject: Kolb-List: Re: CT MKIII crash > > Here is the gascolator I use. It is cheap, 70 bucks, works very well, has > a built in screen and weighs maybe 8 ounces. It is light enough to use > even on a Firefly. At a weight of 254 pounds, 8 ounces just isn't going > to hurt anything even on a firefly. Dont forget to buy the extra gasket > if you plan tu use auto gas, the included gasket is not compatible.... > > Even stock Mark III fuel tanks do not drain from the bottom, they are a > similar setup to the fireflys tank, but you should still have a > gascolator. Just because you draw gas from the top of your take through > a tube is does not mean you do not need a gascolator. Any fuel system on > an airplane should have one. Its not just for water, but any larger > garbage will be blocked by the screen so that you can drain it out and see > it. My guess is that the MK III in the accident had tanks that drew from > the top like all stock Kolb MK III's do.... And yes even though he was > drawing from the top he still really needed a gascolator. Its myths like > this that get spread around by people that don't know any better are > things that can get people hurt... > > John H. > > I will explain my statement about aircraft quality fuel parts a bit more, > I do not mean certified aviation fuel parts, or even fuel components that > have been especially built for aircraft. Many marine and auto lines and > filters are of equal or better quality than some aircraft components. I > mean to use top quality components that would be equal to or better > aircraft grade - which I am sure you have in your MK III. > > What I would most definitely NOT USE is that cheap, easily cut, easily > melted semi clear fuel line that goes bad quickly and that is found in so > many ultralights. Just because this substandard fuel line has found its > way into the ultralight culture does not mean that it is a good idea. > > Mike > > -------- > "NO FEAR" - If you have no fear you did not go as fast as you > could have !!! > > Kolb MK-III Xtra, 912-S > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 8780#208780 > > > ________________________________________________________________________________
Date: Oct 14, 2008
At 04:00 PM 10/14/2008, Richard & Martha Neilsen wrote: >You say stock tanks don't drain from the bottom. Are you sure? My stock >Kolb 5 gallon tanks drain from the bottom. I added a finger >strainer/shutoff valve to the stock setup when I installed my stock bottom >drains to my stock tanks per Kolb instructions. Has this changed? > >I don't know for sure that a gascolator will work as designed with the top >draw system but it seems it would help. I guess this is another argument >for the standard practice of bottom drain fuel tanks. Has anyone that has >had a bottom drain installed properly ever had a leak? I still don't fully >understand why one would use the top draw system. The accident aircraft drew fuel through the top of the tanks and had no gascolator. With top draw, the gascolator will catch water as it flows through the gascolator (which is the most important thing) but it won't pick up water that settles in the bottom of the tank(s) while the aircraft is sitting. -Dana -- I don't trust a government I can't shoot back at. ________________________________________________________________________________
Date: Oct 14, 2008
Rick, The stock fuel system on my MK III takes fuel from the top of the tanks, through a tube. The gascolator will work fine with a top draw system, it would catch any water going through the fuel line. Most bottom draw systems are not perfect, meaning that the fuel is not EXACTLY drawn from the bottom of the tank, many times there is a ridge, etc. around the pickup. This would mean that water would sit in the tank and not get sucked out until flight, so the gascolator would most likely work exactly the same, be it top or bottom draw... I have to go with John H on this one, I like bottom draw better. It is one thing Kolb changed to with the new aluminum 18 gallon tank, this is a really nice and well made tank, I have one that I have just not put in yet :) Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8796#208796 ________________________________________________________________________________
Date: Oct 14, 2008
Good points. I do have a bottom draw tank with finger strainer. So I could put a gascolator at the low point. I'm not convinced that water in the tank would make it to the gascolator from just gravity. At least not with the 1/4" i.d. fuel line. It seems it would only work if there was fuel flowing, not at rest. I'm even less convinced this would work with just a piece of tubing going to a valve effectively trying to make the tubing become a water trap. I'll have to do a test for this. Standard practice is usually right though. P.S. I had the plastic tank with push in rubber bushing at the bottom of the tank for lots of years and it never leaked. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8802#208802 ________________________________________________________________________________
Date: Oct 14, 2008
Scott O: Don't know about you, but it works for me. Gravity pulls the water out of the line when it passes the "T" at the bottom of the loop as it goes under the tail boom. A single line from there to the lowest point of the belly, between the gear legs, collects water and other interesting stuff. Cost about 3.00 for the plastic fuel valve from the mower shop. I know it is not as effective as a real live gascolator, but it works for me, and that is what counts. As long as I don't get lazy and fail to do a good fuel sample each time I fly and when I refuel, I don't think I will ever have another fuel problem cause an engine out. Also have to be religious about checking the fuel filter and the carb float bowls. May not be a proven system or procedure, but it is proven to me. Take care, john h mkIII Rock House, Oregon (Got 5 nice rainbow trout out of the Owyhee River. Larry got 4, but I got the biggest one.) I'm even less convinced this would work with just a piece of tubing going to a valve effectively trying to make the tubing become a water trap. I'll have to do a test for this. Standard practice is usually right though. P.S. I had the plastic tank with push in rubber bushing at the bottom of the tank for lots of years and it never leaked. -------- Scott Olendorf ________________________________________________________________________________
Date: Oct 14, 2008
At 08:36 PM 10/14/2008, John Hauck wrote: > >Don't know about you, but it works for me. Gravity pulls the water out of >the line when it passes the "T" at the bottom of the loop as it goes under >the tail boom. A single line from there to the lowest point of the belly, >between the gear legs, collects water and other interesting stuff. John, how long a piece of line do you have between the tee and the valve? -Dana -- Fugitive from the law of averages! ________________________________________________________________________________
Date: Oct 14, 2008
> > John, how long a piece of line do you have between the tee and the valve? > > -Dana Dana: Probably 2 feet. Maybe 2.5 feet. john h mkIII ________________________________________________________________________________
Date: Oct 14, 2008
It is not necessary to put your fuel pickup at the lowest point in the tank if you are willing to give up a pint or so of usable fuel. Make your pickup/finger strainer a couple inches above the lowest point of the tank, and the sump drain at the lowest point. Instant gascolator. If you drain the sumps just before you take off, and then top up the tank (if it is that critical) then you only have about a pint of unusable fuel. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8843#208843 ________________________________________________________________________________
Subject: Re: Flying video
Date: Oct 14, 2008
Good on Ya, Girl! Da Old Poop! Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8847#208847 ________________________________________________________________________________
Date: Oct 15, 2008
Thanks, George. Keying in the tags you mentioned brought up the video directly. Nice stuff and the vibes are not bad. ________________________________________________________________________________
Date: Oct 15, 2008
Good to know it works. I have a 1 foot piece of tubing coming off of a T that is used to drain the tank also. I've never seen a single drop of water in any samples I've taken from that. I only test it every other month or so. But I always fill the float bowl and check it before each flight. Never found any water in that either. I am now checking it after each flight also since I'm now emptying the bowl back into the tank so I don't have stale fuel in there. I do this if I'm not going to be flying for a week or more. The 10% ethanol fuel left over for 2 weeks in the bowl won't start the engine. It goes bad very quickly compared to regular gas which I used to let go for weeks sometimes. Funny story. I was at the field a few years ago and one of the guys come to fly his Challenger. He took off and came back within 5 minutes. He said his engine was running rough. He suspected that the fuel he just put in may have had water in it. He said "I left it out last night and it rained. I didn't have the spout covered". Which of course he knew as he was filling the tank. That same guy was following me to another airport 10 miles away. His instructor said to him "Follow Scott, he'll show you how to get there". So after 8 miles or so I get a call on the radio from the guy, "I'm right behind you and getting closer. What do I do?" I said, "TURN". A third guy in the group said "He's RIGHT behind you". He was following me all right. I went full throttle all the way through the pattern and landed as far down the runway as I could. Last time I flew with him. lcottrell wrote: > > I know it is not as effective as a real live gascolator, but it works for me, and that is what counts. > > As long as I don't get lazy and fail to do a good fuel sample each time I fly and when I refuel, I don't think I will ever have another fuel problem cause an engine out. > > [b] -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8868#208868 ________________________________________________________________________________
Subject: Quiet Kolb
Date: Oct 15, 2008
As some of you may know, I installed a hks ,3:47, four blade powerfin, in my Twinstar with the attempt to make a plane that my noise sensitive runway owner would accept. I flew it out of my home strip for the first time last night and got the double thumbs up from the runway owner and closest neighbor!!! It has enough power that next flight I will do a reduced power climb and be even quieter! The people watching my take off said it was quieter than the 85 hp Fleet Canuck that flys regularly out of here (my goal was to be as quit as him) I anticipated poor performance in either climb or cruise, and although I realize performance is somewhat subjective, I am very happy with both. It climbs at close to 1000 ' per min. and will accelerate in level flight much faster than I care to go (80mph). Conclusion: I believe the hks is ideally suited for replacing the 503 or 582, and I now feel it would have enough power for a light Mark 3, as my heavy twinstar has abundant power, even with the lower performance of the 4 blade prop. Rob Cannon ps. if anyone has any questions on the hks/kolb install I would be happy to help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8883#208883 Attachments: http://forums.matronics.com//files/aug_08_002_188.jpg ________________________________________________________________________________
Date: Oct 15, 2008
It sounds like about anything will do the job so I think I am going with something like this: http://www.bcchapel.org/pages/0003/pg13.html Simple cheap and effective! I could probably make a better one out of some pvc or galvanized pipe from lowes. using a t fitting to rune 2 fuel barbs and a pipe on the bottom of the T as the sump for the water. Anyone know how gasoline affects pvc? Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8885#208885 ________________________________________________________________________________
Date: Oct 15, 2008
would my plane even benefit from having one?>> Nah!!. Stop worrying. Always leave your fuel tanks topped up and there is no room for condensation to form. Use a water filtering funnel when you refuel, if you are worried about buying fuel with water in it. Empty you carb. chamber occasionally, evry year or so, and you will be right. You can get too hung up on all the little things that can go wrong until you have redundancy built in all over the place. Where are you going to stop?. All this fuss a few weeks ago about fitting an extra fuel pump. What for? Just look at the figurs. How many planes have had trouible with pump failure? There are all sorts of stories about someone who knew someone who had a failure but little first hand reporting. Of course it DOES happen but if it was likely to happen regularly a) the manufacturer would fit two pumps and b) the insurance company would load your premium if you only had one. Cool it and go with the flow, man Cheers Pat ________________________________________________________________________________
Subject: Re: HKs Twinstar with vg's
Date: Oct 15, 2008
If it was unsafe, I would surely run right out and buy a set of VG's for her.>> Hi John, of course you would and so would everyone else. I don`t think anyone has ever suggested that our planes are unsafe without VG`s. Just that with them they are, maybe, just a little safer. "In what way?" I am not even going down that road. Its been done to death Cheers Pat ________________________________________________________________________________
Date: Oct 15, 2008
Not one of my civil liberties has been curtailed...none. Not even privacy. >> Hi Jim, mine has. I lost 2 perfectly good Swiss Army pocket knives because I had forgotten to pack them in my luggage and carried them in my pocket. Which I have done for 70 years.. You don`t think that the government being able to pin point where you made a cell phone call from and who you spoke to is an invasion pf privacy.?. You dont think that the fact that there is CCTV footage of you carrying on your lawful business in the hands of all sorts of agencies is an invasion of privacy? I do. 1984? You `aint seen nothin` yet. (but its all for your protection) Cheers Pat ________________________________________________________________________________
Date: Oct 15, 2008
Pat You are too used to being protected by your federal air nanny. In the early days of aviation we didn't have the knowledge we have today. There were alot of forced landings and worse. Most of us have learned from these problems and build in some safe guards to protect ourselves and our mistresses er... a... airplanes. Granted we all have to weigh the cost in dollars/uros and weight against the odds but to just say naw just go with the flow is not good advice. When I was flying a $3,000 dollar Weedhopper with a 2 stroking time bomb in front of me it didn't make alot of sense to build in very much redundancy. Now that I fly a Kolb with a bullet proof airframe and a very reliable VW engine it makes sense to me to spend $30 for a gascolator and about the same for a boost pump. I'm also a bit older and not as invincible as I used to think I was. Rick Neilsen Redrive VW Powered MKIIIC ----- Original Message ----- From: "pj.ladd" <pj.ladd(at)btinternet.com> Sent: Wednesday, October 15, 2008 1:29 PM Subject: Re: Kolb-List: Re: CT MKIII crash > > would my plane even benefit from having one?>> > > Nah!!. Stop worrying. Always leave your fuel tanks topped up and there is > no room for condensation to form. Use a water filtering funnel when you > refuel, if you are worried about buying fuel with water in it. Empty you > carb. chamber occasionally, evry year or so, and you will be right. > > You can get too hung up on all the little things that can go wrong until > you have redundancy built in all over the place. Where are you going to > stop?. > All this fuss a few weeks ago about fitting an extra fuel pump. What for? > Just look at the figurs. How many planes have had trouible with pump > failure? There are all sorts of stories about someone who knew someone who > had a failure but little first hand reporting. > Of course it DOES happen but if it was likely to happen regularly a) the > manufacturer would fit two pumps and b) the insurance company would load > your premium if you only had one. > > Cool it and go with the flow, man > > Cheers > > Pat > > > ________________________________________________________________________________
Date: Oct 15, 2008
You are too used to being protected by your federal air nanny. >> Hi Rick, my post was a bit tongue in cheek but I am sure that our `Federal air nanny` as you call our flriendly and helpful CAA and Microlight Association wouldn`t let me do anything that was dangerous. Would they? I must say that if I flew over some of the country that you people do, and provide such great pics. of I don`t think I would take off without two engines (or more) at least Cheers Pat ________________________________________________________________________________
Date: Oct 15, 2008
She, too, was hassled by the Air Force when they tried to take her land, but in the end she won a substantial lawsuit against the Air Force.>> I have heard of Pancho Barnes and her part i the Space programme. Good for her.. I am not suggesting for a moment that the government won`t shaft us but I don`t think they actually set out with that in mind.It sort of happens. Re land tussles. We had a classic case here soon after the war. During the war the Army took over a large estate called Crichel Down with the promise that it would be returned after the war when the army had no use for it. The Army eventually finished with it but the Ministry promptly offered it to another branch of the Services. The owner, who happened to have a lot of money,said, `That wasn`t the agreement` and took the government to court, and won. It took a long time and a lot of money but as a result several highly placed Civil Servants were bowler hatted. Cheers Pat ________________________________________________________________________________
Subject: Re: LSA (Was Airport Attitudes)
Date: Oct 15, 2008
Do even foot launched aircraft require a C of A?>> Hi Dana, perhaps I expressed myself badly. I do not think that PPG, hang gliders etc require a C of A.and you are probably right that the picture changes when you add wheels. Wheels are becoming common here too. Saw a picture this week of a hang glider, with the pilot hanging prone as they do these days but with a pedal operated propellor on the back. I wonder what category that will come in. Pat ________________________________________________________________________________
Date: Oct 15, 2008
Don't use the standard PVC with gas, it will have a reaction in time and cause more problems. I had to install a temporary PVC line in until we could plumb in the steel over head piping and had problems and at $30,000 per hr down time I learned quick. -------------------------------------------------- From: "grantr" <grant_richardson25(at)yahoo.com> Sent: 2008-10-15 10:51 Subject: Kolb-List: Re: CT MKIII crash > > It sounds like about anything will do the job so I think I am going with > something like this: > > http://www.bcchapel.org/pages/0003/pg13.html > > Simple cheap and effective! I could probably make a better one out of some > pvc or galvanized pipe from lowes. using a t fitting to rune 2 fuel barbs > and a pipe on the bottom of the T as the sump for the water. > > Anyone know how gasoline affects pvc? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 8885#208885 > > > ________________________________________________________________________________
Subject: Re: Quiet Kolb
Date: Oct 15, 2008
That looks like a really nice, clean HKS installation ! Your report seems typical for HKS engines, they are expensive but everyone I have ever read about just loves the HKS. They use them in trikes with very good results also. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8948#208948 ________________________________________________________________________________
Date: Oct 15, 2008
The vibration was minimal, great video ! That was wild seeing you take off out a that trench, I have never seen anything so narrow. I sure would like to see a video of what the landings are like :) Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8951#208951 ________________________________________________________________________________
Subject: Gerry Olenik of Green Sky Aviation
Date: Oct 15, 2008
I bought my hks from Gerry @ http://www.greenskyadventures.com/ almost a year ago, and have been very impressed with his service and knowledge. He has been prompt with parts shipment, and very generous with his tech support. I personally recommend anyone who wants to buy a hks engine do so from Gerry. He has years of experience installing different engines on different airframes, and I have found his word to be honest and reliable. The hks is a relatively high performance engine and as such will likely require some custom tuning to your application. The learning curve was steep for me and I was thankful to have Gerry there to help. Dana from flightstar was also a huge help with tech support getting my install running smoothly. Rob Cannon Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8953#208953 ________________________________________________________________________________
Date: Oct 15, 2008
How long before there is a reaction to the PVC? We have been running this setup for a year and everything is still doing fine. http://www.bcchapel.org/pages/0003/FSIITankMods.html Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8957#208957 ________________________________________________________________________________
Date: Oct 15, 2008
At 04:38 PM 10/15/2008, pj.ladd wrote: >Saw a picture this week of a hang glider, with the pilot hanging prone as >they do these days but with a pedal operated propellor on the back. I >wonder what category that will come in. I'd venture the "unsuccessful" category... -Dana -- Canadian DOS prompt: EH?\> ________________________________________________________________________________
Subject: Re: Gerry Olenik of Green Sky Aviation
Date: Oct 15, 2008
robcannon wrote: > I bought my hks from Gerry @ http://www.greenskyadventures.com/ > almost a year ago, and have been very impressed with his service and knowledge. He has been prompt with parts shipment, and very generous with his tech support. I personally recommend anyone who wants to buy a hks engine do so from Gerry. He has years of experience installing different engines on different airframes, and I have found his word to be honest and reliable. The hks is a relatively high performance engine and as such will likely require some custom tuning to your application. The learning curve was steep for me and I was thankful to have Gerry there to help. > Dana from flightstar was also a huge help with tech support getting my install running smoothly. > Rob Cannon Just as a general FYI, I few years ago I had Gerry's son Tom (Olenik) do the 100 hour's on a couple of my 503's. They came back looking and running better than new; he does superb motor work. So I'm sure that by extension all the Olenik's are great folks to deal with. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p 8975#208975 ________________________________________________________________________________
Date: Oct 15, 2008
Patrick: Glad I do not have to follow your advice. I mentioned checking carb float bowls recently. We have had several engine outs because float bowls were not checked. Some of these engine outs resulted in fatalities. One time I got lazy and developed a rough running engine because I did not check mine. Now I check them at least once a month, whether I fly or not. Nothing wrong with redundancy. If you do not want it, fine! Probably not a good idea to advise others that it is not necessary. Checking float bowls every year or so will get you in trouble. Go with the flow, man, but not a good idea to recommend others do likewise. john h mkIII Nah!!. Empty you carb. chamber occasionally, evry year or so, and you will be right. You can get too hung up on all the little things that can go wrong until you have redundancy built in all over the place. Cool it and go with the flow, man Cheers Pat ________________________________________________________________________________
Date: Oct 16, 2008
Glad I do not have to follow your advice.>> Hi John, if I did your sort of flying I woukld have EVERYTHING duplicated, every nut locked, and wired and use only fuel straight from ther best garage in the district and then I would filter it 3 times. Cheers Pat ________________________________________________________________________________
Subject: Re: Airport Attitudes
Date: Oct 16, 2008
"Never ascribe to malice what can be explained by incompetence." >> Hi Dana, I have never heard that but I suppose it about sums up my general attitude. Pournelles Law. Something else of which I have never heard. Would that be Jerry Pournelle SF writer by any chance. I wouldn`t disagree with the `bureaucracy wins` theory.. I just hope, probably against the evidence that my optimism will win through. Cheers Pat ________________________________________________________________________________
Subject: Water in gas
Date: Oct 16, 2008
Back on line now, been in hospital for a week with pneumonia, etc. There is something very simple you can do about this ethanol stuff. Go to Wally World and get some Sta-Bil ethanol Treatment. Made the trip to Kentucky with it in my RV tanks, put it in my lawn mowers, little honda scooter, BMW road bike, and -- used it in my gas of the 912 slingshot. Been using Sta-bil for years and years and it is great on everything. Now, this new stuff is meant for the ehanol deal. Go on the websites about this stuff and read it. Use it or weep later. There are also brands for Marine use which has more water hazard than we do. This is one additive that will mix with oil or not, dont matter. Check it out. You wont be sorry. I think it makes the 912 start better and if you were at the factory, you KNOW it performs. Hope this helps. Check it out!!!! Ted Cowan, Alabama Slingshot 912. ________________________________________________________________________________
Date: Oct 16, 2008
Thought the video was pretty good myself. A few shakes while taxying but pretty smooth airborne. But FYI. there are few software programs that are suposed to help things in this area, like http://www.sundancemediagroup.com/articles/deshaker_guide.htm Never tried it, but it sounds OK. David. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9005#209005 ________________________________________________________________________________
Date: Oct 16, 2008
Subject: Re: Water in gas
Ted, Glad to hear you're back in service, pneumonia is no fun. Good tip on the Sta-bil, thanks. We're lucky, perhaps because of the aircraft industry here in Wichita, we've not been subject to the ethanol swindle yet. Water in fuel, or the fear of it, can still be handled by a 99 cent bottle of gas line drier. Rick On Thu, Oct 16, 2008 at 6:07 AM, Ted Cowan wrote: > > Back on line now, been in hospital for a week with pneumonia, etc. There > is something very simple you can do about this ethanol stuff. Go to Wally > World and get some Sta-Bil ethanol Treatment. Made the trip to Kentucky > with it in my RV tanks, put it in my lawn mowers, little honda scooter, BMW > road bike, and -- used it in my gas of the 912 slingshot. Been using > Sta-bil for years and years and it is great on everything. Now, this new > stuff is meant for the ehanol deal. Go on the websites about this stuff and > read it. Use it or weep later. There are also brands for Marine use which > has more water hazard than we do. This is one additive that will mix with > oil or not, dont matter. Check it out. You wont be sorry. I think it > makes the 912 start better and if you were at the factory, you KNOW it > performs. Hope this helps. Check it out!!!! Ted Cowan, Alabama Slingshot > 912. > > ________________________________________________________________________________
Date: Oct 16, 2008
Pat I googled Pournelle -- here 'tis Pournelle's Iron Law of Bureaucracy states that in any bureaucratic organization there will be two kinds of people: those who work to further the actual goals of the organization, and those who work for the organization itself. Examples in education would be teachers who work and sacrifice to teach children, vs. union representative who work to protect any teacher including the most incompetent. The Iron Law states that in all cases, the second type of person will always gain control of the organization, and will always write the rules under which the organization functions. ________________________________________________________________________________
Subject: Gas and PVC
Date: Oct 16, 2008
From: "Kirby, Dennis CTR USAF AFMC MDA/AL" <Dennis.Kirby(at)kirtland.af.mil>
(NOTE - Subject Line changed to reflect current topic.) "grantr" wrote: << Simple cheap and effective! I could probably make a better one (gascolator) out of some pvc or galvanized pipe from lowes. using a t fitting to rune 2 fuel barbs and a pipe on the bottom of the T as the sump for the water. Anyone know how gasoline affects pvc? >> Grant - Following the advice of someone else on this List, I made a homemade gascolator using PVC. As you correctly observe - simple, cheap, effective! (I'd like to give credit to whoever it was that I copied it from, but I forgot who it was! Was it you, Richard P?) I used a 2-inch long piece of 1-1/4" diameter schedule-80 PVC, with end caps glued on. Drilled two 3/8" holes opposite each other near the top (thru the end cap), and screwed a brass fuel barb into each hole. On the bottom PVC cap, I drilled another hole in the center, and threaded into it a Curtis drain valve. I installed the gascolator so that the drain valve pokes out thru the fabric, on the belly of my Kolb. (Which also happens to be the lowest part of my fuel system.) Easy to take a fuel sample from on preflight. I used fuel-proof thread sealer goop (a Permatex product) on the 3 holes where brass hardware is threaded in. It's been installed for over 3 years now, and I've never had a leak. More details are in the archives - this thread has been discussed before. To answer the question of gasoline vs. PVC - before making this homemade gascolator, I set out to prove to myself that PVC would not be affected by gasoline. I filled a glass jar with gas, and dropped in a short piece of PVC pipe. I let it sit for several months. No discernable degradation to the PVC. Dennis Kirby Mark-3, 912ul Cedar Crest, NM ________________________________________________________________________________
Subject: Re: Redundant Fuel Pumps
Date: Oct 16, 2008
Dennis: Nothing chicken about being prepared. I have a redundant fuel pump system in my MKIII. Never had to use it, but it is there should I need it. I also did not have to ask permission to design and install the system in the airplane I built. john h The flying chicken hauck (hawk) mkIII Call me chicken. Dennis Kirby ________________________________________________________________________________
Date: Oct 16, 2008
At 10:07 AM 10/16/2008, Richard Girard wrote: >...we've not been subject to the ethanol swindle yet. Water in fuel, or >the fear of it, can still be handled by a 99 cent bottle of gas line drier... Which is... ALCOHOL! You sure you wanna do that? -Dana -- I started out with nothing. I still have most of it left. ________________________________________________________________________________
Subject: MarkIIIC strut connection
Date: Oct 16, 2008
The connection at the bottom of the strut has lots of slop in it. The bracket on the fuse has a 9/16" gap and the connector on the bottom of the strut is only 1/4" wide. Do I need bushings to take up the slack or is it supposed to be this way? Thanks for any help. The maiden flight is almost in sight.... Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9086#209086 ________________________________________________________________________________
Date: Oct 16, 2008
No ****. Rotax and HKS both allow 5% ethanol blended gas. 8 ounces in 1280 to 1536 ounces (depending on whether I'm flying the MkIII or the trike) is .625% and .521% respectively. I don't think it's going to hurt anything and I've watched it blend in a water drop caught in the fuel filter almost as soon as it hits the tank, so yeah, I want to do that. Rick On Thu, Oct 16, 2008 at 4:39 PM, Dana Hague wrote: > > At 10:07 AM 10/16/2008, Richard Girard wrote: > >> ...we've not been subject to the ethanol swindle yet. Water in fuel, or >> the fear of it, can still be handled by a 99 cent bottle of gas line >> drier... >> > > Which is... ALCOHOL! You sure you wanna do that? > > -Dana > > -- > I started out with nothing. I still have most of it left. > > ________________________________________________________________________________
Date: Oct 16, 2008
As I understand it, Sta-Bil will do this too, and has other good qualities. Anyone know for sure? On Oct 16, 2008, at 8:10 PM, Richard Girard wrote: > No ****. Rotax and HKS both allow 5% ethanol blended gas. 8 ounces > in 1280 to 1536 ounces (depending on whether I'm flying the MkIII > or the trike) is .625% and .521% respectively. I don't think it's > going to hurt anything and I've watched it blend in a water drop > caught in the fuel filter almost as soon as it hits the tank, so > yeah, I want to do that. > > Rick > > On Thu, Oct 16, 2008 at 4:39 PM, Dana Hague > wrote: > > At 10:07 AM 10/16/2008, Richard Girard wrote: > ...we've not been subject to the ethanol swindle yet. Water in > fuel, or the fear of it, can still be handled by a 99 cent bottle > of gas line drier... > > Which is... ALCOHOL! You sure you wanna do that? > > -Dana > > -- > I started out with nothing. I still have most of it left. > > ________________________________________________________________________________
Date: Oct 16, 2008
At 08:10 PM 10/16/2008, Richard Girard wrote: >No ****. Rotax and HKS both allow 5% ethanol blended gas. 8 ounces in 1280 >to 1536 ounces (depending on whether I'm flying the MkIII or the trike) is >.625% and .521% respectively. I don't think it's going to hurt anything >and I've watched it blend in a water drop caught in the fuel filter almost >as soon as it hits the tank, so yeah, I want to do that. I'm not terribly worried about ethanol, since all I can get here is 10% ethanol gasoline, and I've had no problems other than the need for jetting adjustments, but since the first part of the message referred to concern about ethanol, I was pointing out that drygas IS alcohol (isopropyl, or sometimes methyl). -Dana -- Be wary of strong drink. It can make you shoot at tax collectors-- and miss. ________________________________________________________________________________
Date: Oct 16, 2008
Subject: Re: Gas and PVC
At 03:10 PM 10/16/2008, Kirby, Dennis CTR USAF AFMC MDA/AL wrote: >Following the advice of someone else on this List, I made a homemade >gascolator using PVC.... >...I filled a glass jar with gas, and dropped in a short >piece of PVC pipe. I let it sit for several months. No discernable >degradation to the PVC. That's encouraging. All the chemical compatibility information I've found shows PVC compatibility with unleaded gasoline and ethanol as only "fair"... "good" for leaded, and "excellent" for "high aromatic gasoline" (whatever that is). CPVC (the typical tan plumbing pipe) is listed as worse, only "fair" for all types of gasoline. Makes me leery. -Dana -- Be wary of strong drink. It can make you shoot at tax collectors-- and miss. ________________________________________________________________________________
Subject: Re: MarkIIIC strut connection
Date: Oct 16, 2008
If the connection rattle bothers you or you figure the wear might be excessive, you can squeeze a little RTV in the area. -that is if you don't do a regular wing fold. My grass is so long and soft I don't notice. -ask Thom Riddle. BB On 16, Oct 2008, at 7:06 PM, clrprop wrote: > > The connection at the bottom of the strut has lots of slop in it. > The bracket on the fuse has a 9/16" gap and the connector on the > bottom of the strut is only 1/4" wide. > Do I need bushings to take up the slack or is it supposed to be > this way? > > Thanks for any help. > > The maiden flight is almost in sight.... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 9086#209086 > > ________________________________________________________________________________
Date: Oct 16, 2008
I haven't flown it yet so I don't know if it will rattle. I'll be transporting it to the airfield at least till spring so lots of folding and unfolding. I don't understand the design if thats the way it's supposed to be. There's an extra 5/16" of play in there right now. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9115#209115 ________________________________________________________________________________
Date: Oct 16, 2008
Make for easy alignment of the fittings when setting up. I think John H said he welded bushings to his struts and then bolted them together. But to answer your original question, yep, that's the way they're made. Rick On Thu, Oct 16, 2008 at 8:25 PM, clrprop wrote: > > I haven't flown it yet so I don't know if it will rattle. > I'll be transporting it to the airfield at least till spring so lots of > folding and unfolding. > I don't understand the design if thats the way it's supposed to be. There's > an extra 5/16" of play in there right now. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 9115#209115 > > ________________________________________________________________________________
Date: Oct 16, 2008
There is an equal amount of play at the main spar connection although the aft connection prevents any shift other than normal expansion. The lower (strut) play is exclusively lateral so doesn't change geometry. It usually finds a happy spot to rest and you won't notice. BB On 16, Oct 2008, at 9:25 PM, clrprop wrote: > > I haven't flown it yet so I don't know if it will rattle. > I'll be transporting it to the airfield at least till spring so > lots of folding and unfolding. > I don't understand the design if thats the way it's supposed to be. > There's an extra 5/16" of play in there right now. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 9115#209115 > > ________________________________________________________________________________
Date: Oct 16, 2008
I put two fat nylon washers on each side of the strut to hold it centered. Rob Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9119#209119 ________________________________________________________________________________
Date: Oct 16, 2008
Thanks for your help guys. What a great forum! Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9120#209120 ________________________________________________________________________________
Date: Oct 17, 2008
I made plastic washers to take up the gaps.These have been in place for about 200hrs without any problems.The washers stopped a lot of rattles at idle .Easy to do and cheap. Regards Downunder MK111 c ----- Original Message ----- From: "clrprop" <ktony(at)windstream.net> Sent: Friday, October 17, 2008 12:06 PM Subject: Kolb-List: MarkIIIC strut connection > > The connection at the bottom of the strut has lots of slop in it. The > bracket on the fuse has a 9/16" gap and the connector on the bottom of the > strut is only 1/4" wide. > Do I need bushings to take up the slack or is it supposed to be this way? > > Thanks for any help. > > The maiden flight is almost in sight.... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 9086#209086 > > > ________________________________________________________________________________
Date: Oct 17, 2008
Call me chicken.>> Hi Dennis, wouldn`t drean of it. Thats what I call `learning from experience` or `once bitten twice shy` or something like that. If I was flying a Cessna in the mountains I would have plenty of back ups I think to a great extent it is the sort of country we fly over. Some of the great country you guys have with miles of trees and lakes with nowhere to land or almost uninhabited areas really call for maximum safety, redundancy etc. We just don`t have them. There are parts of Wales or Scotland that I wouldn`t fly over without at least letting someone know where I was and when I was expected at my destination but in general over here you would be very unlucky to go down with no one seeing you. Usually there is somewhere to put a plane down even if it is too small to fly out again. Engine outs in a microlight are usually non events anyhow. Even if it does put the pilots adrenelin level up The amount of stored energy involved in such a lightweight machine is low and even if you hit a hedge there is a good chance you will walk away. Even if you had to walk out for help it is unlikely to be more than a couple of miles. I wasn`t really advocating a total disregard for safety and good maintenance. If you went down that route here you would get no further than your next C of A inspection because your inspector wouldn`t sign the plane out. Some pilots however, we all have them, just cannot resist putting on all the gadgets possible. I was talking to a microlight pilot the other day and he was discussing the relative merits of Artificial Horizons because he intended to fit one. Microlights here are only allowed to fly VFR so what did he need one for? He might suddenly be enveloped in cloud? Alright, it could happen but look at the probabilities. Cheers Pat ________________________________________________________________________________
Date: Oct 17, 2008
Yes, the same... one of my favorite writers. >> Thanks Dana. I like his books. Having been a SF reader since 1947 I have been through all the changes of Astounding to Analog and all the changes of format. Not too many good writers in the field now Ian Banks would be one and Baxter, an English writer whom you may have come across. He did some astronaut training I believe and he writes science articles as well as SF. Very little `hard` sf, about now ,it seems to be mainly fantasy and Dungeons and Dragons. Cheers Pat ________________________________________________________________________________
Date: Oct 17, 2008
I did a test. I took a 2 gallon gas can with a push in bushing connection at the bottom. Just like our tanks. I had a 1 foot piece of hose attached and the end was plugged. I added about a quart of gas to the can and made sure the fuel line was full of gas. Then I poured in 16oz of water to make sure it would cover the push in connector because it sticks up 1/4" from the bottom. When I poured in the water it actually turned into millions of tiny water droplets and looked gel-like. At that point a bunch of these tiny drops did get into the dangling fuel line. I let it set for a few hours and the water eventually combined. Even though the fuel connector was completely under water the amount of water in the line was about 1.5". I think most of this was from the initial tiny droplets. I'm still not sure the water would have made it into the hose if it was added slowing without creating the droplets. So although there was some water in the lowest point of the dangling fuel line I'm still not convinced. And if I drained some fuel out I would have gotten some water out but then I would have started getting gas again. At that point I still had 16oz of water left in the gas can. I guess the thing to do is if you find any water at all then you need to keep draining until you are sure you moved enough fuel to empty the lines completely. And no, I don't obsess over this. I haven't found any water in 10 years. Here is a similar kind of gascolator I was thinking of putting in. SeaDoo PWC Fuel Filter 275500088 MSRP: $21.75 Web Price: $17.35 see attached picture.... -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9165#209165 Attachments: http://forums.matronics.com//files/275500358_161.jpg ________________________________________________________________________________
Date: Oct 17, 2008
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Pat - I couldn't agree with you more on both counts: 1) redundancy can be crucial if the terrain you're flying over is unforgiving, and 2) some pilots just want all the heavy metal stuff while I go "Huh?" But if they can afford it and enjoy it - well, that's fine. A friend of mine who flies a Thundergull put an automatic pilot in it. I don't get it, but he enjoys it. I learned to fly in a Quicksilver and my instructor was adamant that I not rely on instruments. All he had on the bird was an airspeed indicator. Personally, I feel I need my CHT and EGT, as well as my altimeter and RPM indicator. And I love my Stratomaster, which gives me fuel burn, although I could easily do without it.AND my redundant electric pump gives me great comfort. As they say "Different strokes for different folks!" Arty Trost Maxair Drifter Sandy, Oregon www.LessonsFromTheEdge.com "Life's a daring adventure or nothing" Helen Keller "I refuse to tip toe through life just to arrive safely at death." --- On Fri, 10/17/08, pj.ladd wrote: > From: pj.ladd <pj.ladd(at)btinternet.com> > Subject: Re: Kolb-List: Redundant Fuel Pumps > To: kolb-list(at)matronics.com > Date: Friday, October 17, 2008, 4:56 AM > > > Call me chicken.>> > > Hi Dennis, > > wouldn`t drean of it. Thats what I call `learning from > experience` or `once > bitten twice shy` or something like that. If I was flying a > Cessna in the > mountains I would have plenty of back ups > > I think to a great extent it is the sort of country we fly > over. Some of > the great country you guys have with miles of trees and > lakes with nowhere > to land or almost uninhabited areas really call for > maximum safety, > redundancy etc. We just don`t have them. There are parts of > Wales or > Scotland that I wouldn`t fly over without at least letting > someone know > where I was and when I was expected at my destination but > in general over > here you would be very unlucky to go down with no one > seeing you. Usually > there is somewhere to put a plane down even if it is too > small to fly out > again. Engine outs in a microlight are usually non events > anyhow. Even if it > does put the pilots adrenelin level up The amount of stored > energy involved > in such a lightweight machine is low and even if you hit a > hedge there is a > good chance you will walk away. Even if you had to walk out > for help it is > unlikely to be more than a couple of miles. > I wasn`t really advocating a total disregard for safety and > good > maintenance. If you went down that route here you would get > no further than > your next C of A inspection because your inspector wouldn`t > sign the plane > out. > Some pilots however, we all have them, just cannot resist > putting on all the > gadgets possible. I was talking to a microlight pilot the > other day and he > was discussing the relative merits of Artificial Horizons > because he > intended to fit one. Microlights here are only allowed to > fly VFR so what > did he need one for? He might suddenly be enveloped in > cloud? Alright, it > could happen but look at the probabilities. > > Cheers > > Pat > > ________________________________________________________________________________
Date: Oct 17, 2008
I learned to fly in a Quicksilver and my instructor was adamant that I not rely on instruments. >> Hi Arty, I started in gliders and I remember that after 6 or 7 flights the instructor threw his gloves over the ASI and altimeter and said`"Look out of the cockpit and listen" For my microlight License I soloed in a Quicksilver. There was nothing even to keep lined up with the horizon. I think there was a telltale piece of string to show slip and skid and an ASI. Sure some people want all the goodies and are happier cutting holes and designing a new control panel than flying. Cheers Pat ________________________________________________________________________________
Date: Oct 17, 2008
At 09:40 AM 10/17/2008, olendorf wrote: >Here is a similar kind of gascolator I was thinking of putting in. >SeaDoo PWC Fuel Filter 275500088 >MSRP: $21.75 Web Price: $17.35 >see attached picture.... How big is that filter, and what hose size? -Dana -- Give a monkey a brain and he'll swear he's the center of the universe. ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Oct 17, 2008
Arty/Pat My Private Pilot training wet 180 degrees the other way. I was trained to trust the instruments because your seat of the pants will mislead you. Kennedy's mishap is a good example. Part of my flight test for PP yes VFR was to prove that I could fly on instruments. They would have me close my eyes and try to get me disoriented and hand the controls back in a unusual attitude while wearing a instrument only hood. Pilot training and common aircraft building practices have come a long way by trial and error. The ultralight instructors that basically taught themselves to fly and some ultralight/experimental builders have short changed themselves by not learning from the mistakes of the past. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "pj.ladd" <pj.ladd(at)btinternet.com> Sent: Friday, October 17, 2008 12:51 PM Subject: Re: Kolb-List: Redundant Fuel Pumps > > I learned to fly in a Quicksilver and my instructor was adamant that I not > rely on instruments. >> > > Hi Arty, > I started in gliders and I remember that after 6 or 7 flights the > instructor threw his gloves over the ASI and altimeter and said`"Look out > of the cockpit and listen" > > For my microlight License I soloed in a Quicksilver. There was nothing > even to keep lined up with the horizon. I think there was a telltale piece > of string to show slip and skid and an ASI. > > Sure some people want all the goodies and are happier cutting holes and > designing a new control panel than flying. > > Cheers > > Pat > > > ________________________________________________________________________________
Date: Oct 17, 2008
At 02:07 PM 10/17/2008, Richard & Martha Neilsen wrote: >My Private Pilot training wet 180 degrees the other way. I was trained to >trust the instruments because your seat of the pants will mislead you. >Kennedy's mishap is a good example. Part of my flight test for PP yes VFR >was to prove that I could fly on instruments. They would have me close my >eyes and try to get me disoriented and hand the controls back in a unusual >attitude while wearing a instrument only hood. Trust the instruments, yes, especially in IFR conditions... but your training should also have taught you to fly the airplane in VFR conditions WITHOUT needing the instruments. Instruments do fail. -Dana -- The difference between a hero and a fool is the outcome. ________________________________________________________________________________
Date: Oct 18, 2008
.Hi Rick. very interesting. Some training , even self training is useful. Just get plenty of height and sniff around the edge of a LITTLE cloud is fun and couldn`t do much harm, but it is not part of the training syllabus for ultralights. You may be different but here the rule is ONLY VFR and Aerobatics and intentional spins are prohibited. Seems sense, after all our machines are built down to a weight not up to a standard. In fact all microlights here carry a sticker stating that `This aircraft is not constructed to a internationally recognised standard` << I was trained to trust the instruments because your seat of the pants will mislead you. >> They will certainly mislead you if you can`t see the horizon <<. They would have me close my eyes and try to get me disoriented and hand the controls back in a unusual attitude while wearing a instrument only hood.>> All good fun but certainly not a training requirement here. At least not for ultralights. You may well be given some rudimentary instruction for a full PPL.but it would be just to give you some experience, not a requirement.We have an odd sort of `get you home` blind flying certificate in the UK which no one else in Europe has.It gives you enough basics to stop you falling out of the sky if you suddenly get caught out, bad weather, low cloud etc. Its a halfway house between VFR and a full blind flying qualification. It has saved a number of lives over the years when mainly day time fliers have got themselves into trouble. We are fighting hard to retain it but it looks as though it may disappear in the Europewide reorganisation of flying which is taking place at the moment .<< The ultralight instructors that basically taught themselves to fly >> WOW! You mean thast you have uncertified flying instructors? Surely not. Cheers Pat ________________________________________________________________________________
Date: Oct 18, 2008
A Kolb MK III is a big enough airplane, that vapor lock and an engine failure could get you seriously hurt just about anywhere on this planet. Dennis had vapor lock with AV Gas being gravity fed, you have MUCH GREATER risk of vapor lock pulling fuel up to an engine like we do in Kolbs. Having an electric fuel pump at or below the level of the fuel is a huge safety advantage. The electric fuel pump is cheap, small, and light, no reason not to have one in a Kolb. Sorry, but this just does not even compare to putting an autopilot or some other exotic equipment on an ultralight. A facet pump is a small, cheap, basic safety item to keep fuel going to your engine at all times. Accident and near accident reports make it very clear that having a small fuel pump can make a small plane a lot safer. If anyone is wondering, look at the EAA database on how many engine failures are caused by the fuel system and not the engine, the number will shock you. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9304#209304 ________________________________________________________________________________
Date: Oct 18, 2008
At 06:15 AM 10/18/2008, pj.ladd wrote: >.<< The ultralight instructors that basically taught themselves to fly >> >WOW! You mean thast you have uncertified flying instructors? Surely not. Well, remember, for a "true" ultralight here, there is NO requirement for ANY training. Of course we all know that anybody who trains himself has a fool for an instructor, but in the early days when all ultralights were single seat, there was a lot of self training or ground supervised "crow hops"... and a lot of accidents. The creation of the BFI program helped a LOT, but that's history now. Loggable training (i.e. hours counting toward any certificate or rating) requires a certified flight instructor, but there's nothing to prevent a guy with just a Sport Pilot certificate from informally teaching his buddy to fly in his 2-seat LSA, then the student goes ahead and solos in a single seat ultralight with no "official" training. -Dana -- Be Politically Incorrect: Support the Constitution! ________________________________________________________________________________
Subject: Re: Kolb-List Digest: 3 Msgs - 10/18/08
Date: Oct 19, 2008
I have all the parts to build a Firestar including a 503 engine. The plane was damaged in a nose over in an off airport landing. Have new powder coated cage and nee boom tube and new gear legs. Parts located in the phoenix area. Vic 623 628-5225 ________________________________________________________________________________
Date: Oct 19, 2008
guy with just a Sport Pilot certificate from informally teaching his buddy to fly in his 2-seat LSA, then the student goes ahead and solos in a single seat ultralight with no "official" training.>> Jeez, A good job that unless you pull it up a violent stall 30 feet up that our low energy machines tend to disintegrate round you and you can walk away with a few minor breakages Cheers Pat ________________________________________________________________________________
Date: Oct 19, 2008
At 12:31 PM 10/19/2008, pj.ladd wrote: >guy with just a Sport Pilot certificate from >informally teaching his buddy to fly in his 2-seat LSA, then the student >goes ahead and solos in a single seat ultralight with no "official" >training.>> > >Jeez, > >A good job that unless you pull it up a violent stall 30 feet up that our >low energy machines tend to disintegrate round you and you can walk away >with a few minor breakages Better than no training at all! And it can be OK if the aircraft are similar, e.g. teaching in an experimental 2 seat Firestar, then the student solos his Firefly, or a 2 seat LSA Quicksilver, then the student solos a single seat ultralight Quicksilver. -Dana -- Place a half full glass of water before a pessimist, optimist and an engineer: The pessimist says the glass is half empty. The optimist says the glass if half full. The engineer says the glass is too large. ________________________________________________________________________________
Subject: Just for Grins - You be the Judge
Date: Oct 19, 2008
Test Your Knowledge of FAA Violations! 1. You can be held responsible if the appropriate logbook entries are not made after a repair, alteration, or inspection. True False 2. You can operate an aircraft outside the United States on the pink copy of an application for registration. True False 3. An unreported drug or alcohol related driving infraction could cause the FAA to suspend or revoke a pilot's certificate. True False 4. If you move and enter your new address on an FAA form (such as an aircraft registration application) you still need to notify the Airman Certification Branch of the change. True False 5. If you rent or borrow someone's aircraft, you are not responsible if you fly that aircraft after it has missed an annual inspection. True False 6. A certified mechanic must replace the battery in your ELT in order for you to avoid suspension. True False Answers next Sunday [Question] [Question] [Question] Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9400#209400 ________________________________________________________________________________
Subject: Re: Just for Grins - You be the Judge
Date: Oct 19, 2008
Test Your Knowledge of FAA Violations! 1. You can be held responsible if the appropriate logbook entries are not made after a repair, alteration, or inspection. True False That's not true. Thousands of logbook entries are not made daily and I'm not responsible for any of them. 2. You can operate an aircraft outside the United States on the pink copy of an application for registration. True False There are lots of airplanes outside of the United States. I suppose that could be true in lots of countries. 3. An unreported drug or alcohol related driving infraction could cause the FAA to suspend or revoke a pilot's certificate. True False If it isn't reported how does anyone know? 4. If you move and enter your new address on an FAA form (such as an aircraft registration application) you still need to notify the Airman Certification Branch of the change. True False I do not need to do this. I may want to but I don't need to. 5. If you rent or borrow someone's aircraft, you are not responsible if you fly that aircraft after it has missed an annual inspection. True False Responsible for what? Washing it? False. 6. A certified mechanic must replace the battery in your ELT in order for you to avoid suspension. True False I don't have an ELT and I'm not suspended so, False. 7. Do you want to anyone answer John T. Schmidt's questions and be thoroughly trounced like Thom Riddle was so John T. Schmidt can sound so knowledgeable and self-important? True False. Bite Me. Answers next Sunday -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9424#209424 ________________________________________________________________________________
From: "James Clayton" <james.clayton(at)quantumwrench.com>
Date: Oct 19, 2008
Good evening, Mr. Schmidt, Perhaps Scott's cleverly composed response will help you understand this is a community that happily welcomes new members desiring to add something useful, and will shun with equal fervor officious, self-important windbags attempting to bully the decent, friendly folks here. You have no idea the range of experience this community brings together. I'll give you a hint: we have experienced pilots from the military, commercial aviation, EAA teachers, and a wealth of experience from non-professional pilots ready to share what they have seen and done, and all just as quick to admit where they are not sure-asking for a hand. What do we have in common? Humility. Many of us with various levels of flying experience can spot a poser not worth reading based on a search for this one simple quality. It is amazing how often the loudest actor demanding to be heard proves over time he should be ignored. I invite you to consider bringing humility to your correspondence by treating this community as the rich resource the diverse experience provides. As a former professional pilot and CFI I have learned more from this community about building, repairing, and flying Kolbs along with understanding regulatory considerations than all my professional flying and teaching. We each have an opportunity to teach and learn here. Most take advantage in a productive way. Otherwise I implore you to choose a different aviation forum upon which to inflict your flaccid attempt at impressing with knowledge and experience. Good day sir, Jim -----Original Message----- From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of olendorf Sent: Sunday, October 19, 2008 8:51 PM Subject: Kolb-List: Re: Just for Grins - You be the Judge Test Your Knowledge of FAA Violations! 1. You can be held responsible if the appropriate logbook entries are not made after a repair, alteration, or inspection. True False That's not true. Thousands of logbook entries are not made daily and I'm not responsible for any of them. 2. You can operate an aircraft outside the United States on the pink copy of an application for registration. True False There are lots of airplanes outside of the United States. I suppose that could be true in lots of countries. 3. An unreported drug or alcohol related driving infraction could cause the FAA to suspend or revoke a pilot's certificate. True False If it isn't reported how does anyone know? 4. If you move and enter your new address on an FAA form (such as an aircraft registration application) you still need to notify the Airman Certification Branch of the change. True False I do not need to do this. I may want to but I don't need to. 5. If you rent or borrow someone's aircraft, you are not responsible if you fly that aircraft after it has missed an annual inspection. True False Responsible for what? Washing it? False. 6. A certified mechanic must replace the battery in your ELT in order for you to avoid suspension. True False I don't have an ELT and I'm not suspended so, False. 7. Do you want to anyone answer John T. Schmidt's questions and be thoroughly trounced like Thom Riddle was so John T. Schmidt can sound so knowledgeable and self-important? True False. Bite Me. Answers next Sunday -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9424#209424 ________________________________________________________________________________
Date: Oct 20, 2008
We fabricated up this motley collection of PVC and plumbing to add a few gallons to the FSII without having to replace the stock tanks. More than a year old and no problems. http://www.bcchapel.org/pages/0003/FSIITankMods.html Richard Pike MKIII N420P (420ldPoops) Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9459#209459 ________________________________________________________________________________
Date: Oct 20, 2008
John T. Schmidt wrote: > Test Your Knowledge of FAA Violations! > > Cool... Here's my whack at this.... > > 1. You can be held responsible if the appropriate logbook entries are not made after a repair, alteration, or inspection. > True > False > > I believe false. An Experimental AB airplane doesn't require a logbook entries at all for any maintenance done. I do think (may be wrong tho) major alterations and annual condition inspections have to be recorded in order for it to maintain airworthiness. Since you (the owner/op) are responsible for maintaining the a/c in airworthy condition, you probably can be popped by FnAA for neglecting this. > Not sure about all this tho. > > 2. You can operate an aircraft outside the United States on the pink copy of an application for registration. > True > False > > I have no idea as to the answer to this. I'd say this is true as the pink copy is basically equivalent to a registration for its duration. > > 3. An unreported drug or alcohol related driving infraction could cause the FAA to suspend or revoke a pilot's certificate. > True > False > > FnAA can suspend your medical for an alki-related infraction for sure, but I don't know about your certificate itself. I'd say they probably could. > > 4. If you move and enter your new address on an FAA form (such as an aircraft registration application) you still need to notify the Airman Certification Branch of the change. > True > False > > No idea, but I think the answer is false. > > 5. If you rent or borrow someone's aircraft, you are not responsible if you fly that aircraft after it has missed an annual inspection. > True > False > > False. As the owner _or_ operator, you're responsible for maintaining the a/c in airworthy condition. If it's out of annual and you flew it, you're responsible. > > 6. A certified mechanic must replace the battery in your ELT in order for you to avoid suspension. > True > False > > Er, suspension meaning what? > Anyway, this is covered in FAR 91.207. Looks like anyone can replace the ELT batteries, but only whoever has the authority to do the condition inspection on an EAB plane can inspect it and make the logbook entry in the last 12 mos. For standard category planes, that's an AnP/IA.. > > Those are my tries at it... > > LS > Answers next Sunday [Question] [Question] [Question] -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9469#209469 ________________________________________________________________________________
Date: Oct 20, 2008
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: Kolb List Re: I'm so disappointed
- Howard- What does your FS II weigh?- My FS I was just under the limit .- I hope to trim some pounds during the re-build. - ------------------------- --------------------- Bill Sulliv an ------------------------- --------------------- Windsor Loc ks, Ct. ________________________________________________________________________________
Date: Oct 20, 2008
Subject: Fouled sparkplug
While flying my MKII 503 SCSI last night I had a plug foul. I suddenly could not maintain RPM and it was running very rough. I was close to the field at the time and just came back in. I checked the plugs out tonight and one was bridged. I replaced both plugs with new ones and the 503 is running like Swiss watch again. I think that I may have done an inadvisable thing when I tuned the Kolb this spring. I put on new wires with suppression caps, AND I used resistor plugs. I just read tonight in the CPS catalog, under maintenance tips, Part 9, page 20, that using both suppression caps and resistor together is a bad idea. I will replace my plugs with non-resistor plugs and keep a close eye on them. Also, I believe that I read somewhere that the plugs should be replaced every 25 hours. I had 30 hours on the fouled plug. Shame on me! This event also showed me the extra level of safety that a dual ignition would bring to the table. Food for thought. I still love this little airplane ! Malcolm Morrison ________________________________________________________________________________
Subject: Re: Pictures !!! Flying a Kolb Around South Florida...
Date: Oct 20, 2008
Here's a few for those of you who live where it's always green, or alternating green and brown. Around here it'll be white before too long, but tonight was THE evening to go flying... -Dana When authorities warn you of the sinfulness of sex, there is an important lesson to be learned. Do not have sex with the authorities. Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9579#209579 Attachments: http://forums.matronics.com//files/dsc01701_872.jpg http://forums.matronics.com//files/dsc01700_368.jpg http://forums.matronics.com//files/dsc01699_199.jpg http://forums.matronics.com//files/dsc01697_193.jpg http://forums.matronics.com//files/dsc01688_210.jpg ________________________________________________________________________________
Date: Oct 20, 2008
Dana Thanks for the photos. I kept waiting for a good frost to bring out the color and now I'm afraid it is past the peak here in central Michigan. Also having no enclosure makes for much better photos. The subject says South Florida but that can't be Florida???? Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "Dana" <d-m-hague(at)comcast.net> Sent: Monday, October 20, 2008 9:07 PM Subject: Kolb-List: Re: Pictures !!! Flying a Kolb Around South Florida... > > Here's a few for those of you who live where it's always green, or > alternating green and brown. Around here it'll be white before too long, > but tonight was THE evening to go flying... ________________________________________________________________________________
Date: Oct 21, 2008
Dana, Ditto on the gorgeous photos! What airport is this? We have light snow forecast for Tuesday night, which will be our first this season. Thom in Buffalo KBQR -------- Thom Riddle CFI-SP Power Plant Mechanic N1208P RANS S6S, Tailwheel, 912UL N197BG FS1/447 -------------------- Scratch any cynic, he said, and youll find a disappointed idealist. George Carlin Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9624#209624 ________________________________________________________________________________
Date: Oct 21, 2008
Subject: Re: Pictures !!! Flying a Kolb Around Connecticut (was
South Florida...) At 07:33 AM 10/21/2008, Thom Riddle wrote: >Ditto on the gorgeous photos! What airport is this? We have light snow >forecast for Tuesday night, which will be our first this season. It's Goodspeed Airport (42B) in CT, on the Connecticut River. A good fly-in destination; the Goodspeed Opera House (musicals) and a fine restaurant are an easy walk, just south of the bridge. -Dana -- In general, liberalism consists of A & B getting together to see what they can make C do for poor old D. ________________________________________________________________________________
Date: Oct 21, 2008
Dana LOVELY PIX! -- thank you On Oct 20, 2008, at 9:07 PM, Dana wrote: > http://forums.matronics.com//files/dsc01700_368.jpg ________________________________________________________________________________
Subject: international flying regulation differences
Date: Oct 21, 2008
WARNING: Not Kolb specific. This discussion about differences in regulations for sport flying between the USA and the UK prompted me to look at the regs of my nearby northern neighbor, Canada. I found the following two links which summarize the Canadian regs for sport type flying. These on the Canadian Challenger Importer's website but are not specific to Challengers, of course. Very interesting stuff. http://www.challenger.ca/faq_regs_registration.html#hiring_builder http://www.challenger.ca/faq_cdn_pilot_licences.html Thom in Buffalo -------- Thom Riddle CFI-SP Power Plant Mechanic N1208P RANS S6S, Tailwheel, 912UL N197BG FS1/447 -------------------- Scratch any cynic, he said, and youll find a disappointed idealist. George Carlin Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9666#209666 ________________________________________________________________________________
Subject: Re: I'm so disappointed......
Date: Oct 21, 2008
On that note. I have a web page for my Firestar and occasionally look at the statistics for it. I see lots of hits to my web page coming from users on FAA's Internet Service Provider. So there ARE people in the FAA that are looking at us. I'm sure there are a few reading these message boards. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9696#209696 ________________________________________________________________________________
Date: Oct 21, 2008
Scott, the guys at FAA have to have something to do along with the donuts and coffee. I doubt they are peering maliciously at us'ins. BB On 21, Oct 2008, at 1:58 PM, olendorf wrote: > > On that note. I have a web page for my Firestar and occasionally > look at the statistics for it. I see lots of hits to my web page > coming from users on FAA's Internet Service Provider. So there ARE > people in the FAA that are looking at us. I'm sure there are a few > reading these message boards. > > -------- > Scott Olendorf > Original Firestar, Rotax 447, Powerfin prop > Schenectady, NY > http://KolbFirestar.googlepages.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p 9696#209696 > > ________________________________________________________________________________
Date: Oct 21, 2008
HShack, I am with you on this one ! Weather your plane weighs 254 pounds or 274 pounds really does not affect anyone... The independent spirit and not liking being told what to do in every aspect of our lives is what this country was built on and what made this country great ! Unfortunately people in this country have no understanding of what freedom is anymore. For those that done believe me, just look at the latest presidential polls as we head towards Socialism. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9704#209704 ________________________________________________________________________________
Date: Oct 21, 2008
Great Pictures Dana ! I always look to see peoples flight pictures and flight videos. I hope more people here start posting pictures. Even though it might seem like the same boring stuff to the person flying, pictures like this will be an inspiration to many people in the building process or that are thinking about getting a Kolb. Its also nice to see pictures from different areas that I never get to see in my Kolb :) Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9707#209707 ________________________________________________________________________________
Subject: Re: Pictures !!! Flying a Kolb Around Connecticut (was South
Date: Oct 21, 2008
Thanks, Dana. The reason I asked is because it looks a LOT like Kingston (20N) on the Hudson near the wonderful Old Rhinebeck Aerodrome, which is a must see for anyone who likes to see antique airplanes, flying. http://www.airnav.com/airport/20N Look at it in satellite view in Google Maps to see the similarity in layout and proximity to a river. -------- Thom Riddle CFI-SP Power Plant Mechanic N1208P RANS S6S, Tailwheel, 912UL N197BG FS1/447 -------------------- Scratch any cynic, he said, and youll find a disappointed idealist. George Carlin Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9714#209714 ________________________________________________________________________________
South
Date: Oct 21, 2008
Thom R: Kingston doesn't sit right on the river bank like Dana's airport does. Bert Howland and I landed there going to and coming from Ole Rhinebeck, 1989. Bert's grass strip in Maryland, NY, was about 75 sm west of Ole Rhinebeck. I might add, Bert and I had a ball the week I spent with him and Ellen. We flew everyday in the local mountains. One of the highlights was flying over Cooperstown, NY, and landing at their long grass airport. Had a little cafe there with good coffee and breakfast. Later, we married up at the Flight Farm, Monterey, NY. Then we would get up early, fly over to Bradford, NY, land on the baseball diamond, the clay part, walk over to the little store/cafe for breakfast and coffee...........Those were, indeed, the good old days. Bert was flying his Honeybee biplane and I was flying my 1987 Firestar. I miss Bert. john h Jordan Valley, OR looks a LOT like Kingston (20N) on the Hudson near the wonderful Old Rhinebeck Aerodrome -------- Thom Riddle ________________________________________________________________________________
Subject: Firestar aileron balance wts
Date: Oct 22, 2008
Hi all I see some Firestars has aileron balance wts on the ends of the ailerons and some don't, the wt I suppose is to reduce aileron flutter is that the purpose? Do they have any other effect on the aileron control like does the stick feel any lighter or not? Thanks -------- GB MNFlyer Flying a HKS Kitfox III Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9895#209895 ________________________________________________________________________________
Subject: Re: Firestar aileron balance wts
Date: Oct 22, 2008
Balance weights are a way to reduce the chance of flutter, if you don't have them I would put them on, its just good design. Flutter occurs at higher airspeeds, some day if you accidentally get going way faster than you wanted to, it is a bad time to find out your ailerons are susceptible to flutter. Balance weights will not lighten the stick forces, will not change your roll rate,or make the stick feel any different. They are only a preventative measure for flutter. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9933#209933 ________________________________________________________________________________
Date: Oct 22, 2008
JetPilot wrote: > HShack, > > > For those that done believe how this country has forgotten what freedom is, just look at the latest presidential polls as we head towards Socialism. > > Mike Mike, while I may somewhat agree with you let's please keep any politics off the board... Thanks Geoff Thistlethwaite Read this topic online here: http://forums.matronics.com/viewtopic.php?p 9942#209942 ________________________________________________________________________________
Date: Oct 23, 2008
I put balances on my MKIIIX. ( flaperons) Only had flutter once and it wasn't from high speed. May have been from a pull up in hot air into a blast of cooler air on a large river. They work but I don't like the sluggish feel or that they wobble between each other on the ground. Don't really notice much difference in the air performance wise. I'd rather put spades where the weights go but I'm no engineer. Vic ________________________________________________________________________________
Subject: wing attachment hardware
Date: Oct 23, 2008
What kind of hardware are you all using for your wing attachment? Most of mine are the clevis pins w/ cowling safety clips. Some are too short to get a washer on underneath the clip. This doesn't look very safe to me. Are these ok or is it better to go with bolts and castle nuts? Keath T Mk III C Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210003#210003 ________________________________________________________________________________
Subject: Re: wing attachment hardware
Date: Oct 23, 2008
Keath That's the way most all are. I personally use the ring type safety clips because long grass has been known to pull the cowl clips off. Others have said the ring clips might work their way out but I doubt it. Some people that don't fold their wings have used bolts with lock nuts. Some even have used bushings/spacers that lock the wing attachments together. There is no reason why you can't use castle nuts. What ever you use be sure it is AN hardware for the pins or bolts. Also always check the safety clips on preflight for wear. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "clrprop" <ktony(at)windstream.net> Sent: Thursday, October 23, 2008 11:25 AM Subject: Kolb-List: wing attachment hardware > > What kind of hardware are you all using for your wing attachment? > > Most of mine are the clevis pins w/ cowling safety clips. Some are too > short to get a washer on underneath the clip. This doesn't look very safe > to me. Are these ok or is it better to go with bolts and castle nuts? > > Keath T > Mk III C > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=210003#210003 > > > ________________________________________________________________________________
Date: Oct 23, 2008
At 11:25 AM 10/23/2008, clrprop wrote: >What kind of hardware are you all using for your wing attachment? > >Most of mine are the clevis pins w/ cowling safety clips. Some are too >short to get a washer on underneath the clip. This doesn't look very safe >to me. Are these ok or is it better to go with bolts and castle nuts? I don't think it's an issue; I've never heard of a failure (has anybody?). I don't have washers under the clips on any of mine. Since I fold the wings every time I fly each connection gets checked anyway. If I weren't folding every time I'd probably go with bolts and locknuts, though. -Dana -- In England, the cops say, 'Halt or I'll say halt again!' ________________________________________________________________________________
Date: Oct 23, 2008
There have been cases where the safety pin has been undone on the tail wire attachment on the bottom of the rudder due to long grass. I use a castle nut with a safety pin on all attachments since I do not fold my wings. If you must fold, I like the key chain type circlips, rather than the safety pin type which are more easily knocked open. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210017#210017 ________________________________________________________________________________
Subject: Kolb MK3X possibly for sell (watercooled VW engine)
Date: Oct 23, 2008
I am seriously thinking about selling my unfinished Kolb. I've lost interest since my partner has bailed out on me. This would be a truely quick build aircraft since the wings, horizonal stab, rudder, elevators, aerons, and flaps are all done except for covering. The cage is set up for the WATER COOLED VW engine which is assemble and included in the deal. I am not looking for any profit on the plane just the actual money I have in it. All the many hours of labor to this point will be free. I haven't added all the reciepts up yet to come up with a cost but I thought I would send this post out to see if anyone would be seriously interested. Hopefully I won't get to many tire kickers here. Rick Lewis (VW Watercooled powered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210045#210045 Attachments: http://forums.matronics.com//files/vw_engine_001_714.jpg http://forums.matronics.com//files/3_341.jpg http://forums.matronics.com//files/12_158.jpg http://forums.matronics.com//files/misc_pics_050_113.jpg ________________________________________________________________________________
Date: Oct 23, 2008
I put spades on my Kolb MK III, they worked well to bring down the control forces and make my ailerons more responsive. They are not heavy enough to replace my counterbalances, I have both. Also spades on the wingtips do not work, the vortex of the air going over the tips make the spades pretty useless there according to someone that has tried it. I beleive it, I have not see any airplane with spades on the wingtips, I copied my spades from a Decathlon, the spade design I used is common on many airplanes. If you want to see pictures and more information, look here. http://forums.matronics.com/viewtopic.php?t=45270&highlight=spades Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210046#210046 ________________________________________________________________________________
Subject: Re: Kolb MK3X possibly for sell (watercooled VW engine)
Date: Oct 24, 2008
Rick I'm very disappointed you are thinking about selling. For those of you that aren't familiar with the VW engine Rick has put on his plane. Rick L please correct any misunderstandings. It is a Great Plains 2276cc engine with light weight Nikasil cylinders and the Valley Series 3 redrive. The water cooled part of this engine is much more than just cooling. The water cooing package included a tuned intake system with carburetor ( bing?), heads, water pump, and radiators. The Performance improvement with this package is spectacular. I think one could conservatively say that this engine would perform along side a 100hp Rotax and likely blow its doors off. For reliability's sake one would want to cruise at lower power settings but the climb rate could be unbelievable. The water cooling would also solve the on the ground over heating issue a air-cooled pusher engine has. With all this said don't run out and try to buy the water cooling package. I was told that manufacturer was so concerned about someone stealing their design that they restricted sales to the USA and failed to get enough demand to stay in business. This is also the first Kolb built VW engine mount. Rick did a great service by working directly with Kolb to get this done. I know of at least two other VW powered Kolbs being built because of his efforts. Rick Neilsen Flying Redrive VW powered MKIIIC ----- Original Message ----- From: "Rick Lewis" <cktman(at)hughes.net> Sent: Thursday, October 23, 2008 7:21 PM Subject: Kolb-List: Kolb MK3X possibly for sell (watercooled VW engine) > > I am seriously thinking about selling my unfinished Kolb. I've lost > interest since my partner has bailed out on me. This would be a truely > quick build aircraft since the wings, horizonal stab, rudder, elevators, > aerons, and flaps are all done except for covering. The cage is set up > for the WATER COOLED VW engine which is assemble and included in the deal. > I am not looking for any profit on the plane just the actual money I have > in it. All the many hours of labor to this point will be free. I haven't > added all the reciepts up yet to come up with a cost but I thought I would > send this post out to see if anyone would be seriously interested. > Hopefully I won't get to many tire kickers here. > > Rick Lewis (VW Watercooled powered) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=210045#210045 > > > Attachments: > > http://forums.matronics.com//files/vw_engine_001_714.jpg > http://forums.matronics.com//files/3_341.jpg > http://forums.matronics.com//files/12_158.jpg > http://forums.matronics.com//files/misc_pics_050_113.jpg > > > ________________________________________________________________________________
Date: Oct 24, 2008
If the pins are too short to put on a washer.... get longer pins. Or go with bolts and nuts,,, remember some areas are not designed to be tightened down with lots of torque on the bolts... I would tighten so that you could still easily rotate the bolt by hand. Boyd Young Kolb MKIIIC >>>>>>>>>>>>>> What kind of hardware are you all using for your wing attachment? Most of mine are the clevis pins w/ cowling safety clips. Some are too short to get a washer on underneath the clip. This doesn't look very safe to me. Are these ok or is it better to go with bolts and castle nuts? Keath T Mk III C ________________________________________________________________________________
From: "KOLB AIRCRAFT" <customersupport(at)tnkolbaircraft.com>
Subject: Re: Brake lines
Date: Oct 10, 2008
JIM, DONNIE HERE, IF YOU HAVE A FAX # SEND TO ME AND I WILL FAX COPIES OF THE NAMES OF THOSE YOU GAVE RIDES TO AT THE FLY-IN. THANKS DONNIE. ----- Original Message ----- From: Jim To: kolb-list(at)matronics.com Sent: Wednesday, October 08, 2008 12:03 PM Subject: Kolb-List: Brake lines Guys, & Gals, I`ve got a set of older matco brakes, that were removed from a MK-3C, going back on a MK-3C. I need new brake lines, & the removed tubing sez," 1/4 inch by .035 Parker Parflex" I've looked in the following cataloges: Aircraft Spruce, CPS, LEAF, Wag Aero, & Lockwood. All I see in any of them is 3/16 brake line. I also would like new compresion fittings. Any Idea where to get this from? Also, Matcos website sez only use the aviation brake fluid, but someone told me that Automatic transmission fluid was what to use. Please, Facts only. Thanks, Jim Kmet Cookeville, TN MK-3C & MK-3C ________________________________________________________________________________
Date: Oct 24, 2008
931-526-6865 Thanks !!! Jim ----- Original Message ----- From: KOLB AIRCRAFT To: kolb-list(at)matronics.com Sent: Friday, October 10, 2008 6:43 AM Subject: Re: Kolb-List: Brake lines JIM, DONNIE HERE, IF YOU HAVE A FAX # SEND TO ME AND I WILL FAX COPIES O F THE NAMES OF THOSE YOU GAVE RIDES TO AT THE FLY-IN. THANKS DONNIE. ----- Original Message ----- From: Jim To: kolb-list(at)matronics.com Sent: Wednesday, October 08, 2008 12:03 PM Subject: Kolb-List: Brake lines Guys, & Gals, I`ve got a set of older matco brakes, that were removed f rom a MK-3C, going back on a MK-3C. I need new brake lines, & the removed t ubing sez," 1/4 inch by .035 Parker Parflex" I've looked in the following cataloges: Aircraft Spruce, CPS, LEAF, Wag Aero, & Lockwood. All I see in any of them is 3/16 brake line. I also would like new compresion fittings. Any Idea where to get this from? Also, Matcos website sez only use the aviation brake fluid, but someone told me that Automatic transmission fluid was what to use. Please, Facts only. Thanks, Jim Kmet Cookeville, TN MK-3C & MK-3C href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics. com/Navigator?Kolb-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Oct 24, 2008
What purpose does the washer provide in this case? The FAA inspector that gave me the airworthiness inspection also recommended I put washers under the cowling pins. I can only assume it would cut down an pin wear if the clevis pin was rotating. I didn't add the washers. I have the cowling pin in my hand twice every time I fly. If it was worn out I'd know it. -------- Scott Olendorf Original Firestar, Rotax 447, Powerfin prop Schenectady, NY http://KolbFirestar.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210130#210130 ________________________________________________________________________________
Subject: Re: Pictures !!! Flying a Kolb Around South Arizona...
Date: Oct 24, 2008
The Southwest has to be one of the prettiest areas in the country to fly over. I hope to fly these areas one of these days, thanks for posting. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210142#210142 ________________________________________________________________________________
Date: Oct 24, 2008
Weather your plane weighs 254 pounds or 274 pounds really does not affect anyone... >> I love it. Unfortunately any country, capitalist,socialist, fascist or what have you which allows its members to pick and choose which particular bits of the law they will bother to obey must inevitably descend into chaos. Enjoy while you can. Cheers Pat ________________________________________________________________________________
Date: Oct 24, 2008
Pat: Tell me what country is NOT 'descending into chaos'. Mine sure is. NOW! -- Kolb-related; how's your Kolb? Russ PS You mean weather, or whether? do not archive On Oct 24, 2008, at 4:42 PM, pj.ladd wrote: > > Weather your plane weighs 254 pounds or 274 pounds really does not > affect anyone... >> > > I love it. Unfortunately any country, capitalist,socialist, fascist > or what have you which allows its members to pick and choose which > particular bits of the law they will bother to obey must inevitably > descend into chaos. > > Enjoy while you can. > > Cheers > > Pat > > ________________________________________________________________________________
Date: Oct 24, 2008
and post some flying pics ...Pat.... Herb At 05:41 PM 10/24/2008, you wrote: > >Pat: >Tell me what country is NOT 'descending into chaos'. Mine sure is. >NOW! -- Kolb-related; how's your Kolb? >Russ >PS You mean weather, or whether? >do not archive > >On Oct 24, 2008, at 4:42 PM, pj.ladd wrote: > >> >>Weather your plane weighs 254 pounds or 274 pounds really does not >>affect anyone... >> >> >>I love it. Unfortunately any country, capitalist,socialist, fascist >>or what have you which allows its members to pick and choose which >>particular bits of the law they will bother to obey must inevitably >>descend into chaos. >> >>Enjoy while you can. >> >>Cheers >> >>Pat >> >> >> > > ________________________________________________________________________________
Date: Oct 24, 2008
The Kolb plans do not call for washers on the pins. I would not put them on due to the washers being free to spin and cause significant wear to the cowl pin. I have seen a washer on a loose bolt spinning at approximately 120 rpm just being driven by the vibration of the machine. It's the hula hoop affect just smaller and faster. I also would not use "key chain" rings as they are not made to any quality standard. I guess I just have a lot of faith in the design that Homer came up with. If I didn't fold and trailer I would probably use AN bolts and castle nuts. Steven Green MK3 912S 560 hrs with washerless cowl pins. But not the same ones, they are replaced at least annually. ________________________________________________________________________________
Subject: Flying the salt river east of Phoenix
Date: Oct 24, 2008
From: "Nelson, Craig" <craig.nelson(at)heraeus.com>
<> <> <> <> Unbelievable flying weather Uncle craig 912ULS MKIII EX don't even think of archiving this ________________________________________________________________________________
Date: Oct 24, 2008
At 07:16 PM 10/24/2008, Steven Green wrote: >The Kolb plans do not call for washers on the pins. I would not put them >on due to the washers being free to spin and cause significant wear to the >cowl pin. I have seen a washer on a loose bolt spinning at approximately >120 rpm just being driven by the vibration of the machine. It's the hula >hoop affect just smaller and faster. I also would not use "key chain" >rings as they are not made to any quality standard. I guess I just have a >lot of faith in the design that Homer came up with. If I didn't fold and >trailer I would probably use AN bolts and castle nuts. I agree, I use the AN pins with no washers, except at one location: The UltraStar plans DO call for a ring cotter (the plans call it a "safety circlip") at one location, the pin that holds connects the elevator horns to the control arm in the back of the boom tube (done differently on the later Kolbs, I believe?). I bought a package from the marine store, but I didn't trust the "tail" that's supposed to make it easy to install, looks like it'd make it easy to come loose, as well... a friend who flies a GT400 gave me some without the tail; that's what I use now. -Dana -- Democracy is three wolves and a sheep voting on what to have for lunch. ________________________________________________________________________________
Subject: Flying the Salt river
Date: Oct 24, 2008
<> <> <> <> <> <> <> Do Not archive ________________________________________________________________________________
Subject: How do I learn to fly Ultrastar? Help please.
Date: Oct 24, 2008
I have a nice Ultrastar and no motorized flying experience (years of paragliding). My Kolb is mid 80's, good condition, Cayuna, no flaperons, etc., no nose cone, rigid gear. What 2 place aircraft would be best to learn in, and does anybody know an instructor/aircraft combo in the Northwest or in the West? (I am in NE Oregon and willing to travel.) Any peculiar flying/ground handling aspects to the Ultrastar---good or bad? How are they at take off and landing? Any problems to look for? Any upgrades important? Do fairings on struts make a diffference, or kinds of tires make much of a handling difference? Also looking for a BSR, etc chute for it. Thanks!! Peter Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210201#210201 ________________________________________________________________________________
From: "Wayne McCullough" <blackbird754(at)alltel.net>
Date: Oct 25, 2008
Dana, This is great......I pledge allegiance to the U.S. republic (see U.S. constitution or Articles of Confederation of the republic) which ended in 1865.....after the north(federals) took the south(confederates) by force. South Carolina withdrew from the union.........Lincoln in his memoirs wrote that he would make the south fire the first shot. As the union troops withdrew from Fort Sumter in Charleston Harbor. The south gave the northern soldiers a ride out to the U.S. navy who were blockading the harbor. When the gunboats fired a warning shot (practice at sea at the time) the navy sank and destroyed the little flotilla including their own men who were evacuating the fort. The rest is history..............Slavery was the political point............You know us Bad southerners( no one agrees with slavery), but North and South were trading with slaves and cotton. I'm off my soapbox now.......LOL Wayne McCullough Kolbra 004 (building) I love history and HATE the democracy ( and politics) we have, but I still love our country for what it is worth. My father (who served in WW2) cannot believe where our morals have gone). He is 84. I'm 53. ________________________________________________________________________________
Subject: safety pins
Date: Oct 25, 2008
I have seen both the round safety rings and the pin type wear out, disappear, etc. I use a small nylon tie strap and put it through the loop on the pin type or thru the ring and around the bolt, pin or whatever you are using on your struts and then snug it up. It holds it from moving and if it cant move, it cant wear out. It is easy to check on pre flight, if it is there, go. I fold occasionally and renew the ties and have NEVER had one fall off or break even after a year or so in the sun. Black seems to hold up better. Quick, easy and effective. I also use one between the ball and the bell on the ail rad. rod where you disconnect to take up the space. Good for what you paid for it. Ted Cowan, Alabama, Slingshot 912. ________________________________________________________________________________
Date: Oct 25, 2008
Subject: Re: Flying the salt river east of Phoenix
Craig, Seems like all of the beautiful places to fly over require a lot of faith in the machines that take you there.Nice picts. no not archive ----- Original Message ---- From: "Nelson, Craig" <craig.nelson(at)heraeus.com> Sent: Friday, October 24, 2008 7:33:40 PM Subject: Kolb-List: Flying the salt river east of Phoenix <> <> <> <> Unbelievable flying weather Uncle craig 912ULS MKIII EX don't even think of archiving this ________________________________________________________________________________
Date: Oct 25, 2008
Subject: Re: Flying the Salt river
Craig, What brand of aircraft were you flying when you took these picts? no not archive ----- Original Message ---- From: "Nelson, Craig" <craig.nelson(at)heraeus.com> Sent: Friday, October 24, 2008 8:51:26 PM Subject: Kolb-List: Flying the Salt river <> <> <> <> <> <> <> Do Not archive ________________________________________________________________________________
Date: Oct 25, 2008
Subject: Re: How do I learn to fly Ultrastar? Help please.
At 02:25 AM 10/25/2008, petebarry99 wrote: >I have a nice Ultrastar and no motorized flying experience (years of >paragliding). My Kolb is mid 80's, good condition, Cayuna, no flaperons, >etc., no nose cone, rigid gear. > >What 2 place aircraft would be best to learn in, and does anybody know an >instructor/aircraft combo in the Northwest or in the West? (I am in NE >Oregon and willing to travel.) Well, another Kolb is best, of course, but you'll have a tough time finding anybody instructing in one. Second best is any other ultralight (er, "ultralight like" LSA), e.g. a 2 seat Challenger, Hawk, or Quicksilver. Third best is any light GA airplane (preferably a Cub, T-Craft, or the like), but if you take this option even one or two rides with somebody in an ultralight like LSA is HIGHLY advisable to get a sense of the differences. If you do your flight training in a nosewheel airplane then at least an hour or two of tailwheel time is a good idea. I came to my UltraStar from PPG... but some 15 years earlier I had plenty of GA time, most of it in a T-Craft. A friend checked me out informally in a 2-seat Quicksilver for a couple of flights, I flew it maybe 10 hours solo, then had no problems in the UltraStar. >Any peculiar flying/ground handling aspects to the Ultrastar---good or >bad? How are they at take off and landing? The US is a great flying airplane. It's light like the ultralight it is, but handles like a "real" airplane... a Quicksilver is a pig compared to any Kolb. >Any problems to look for? Any upgrades important? Do fairings on struts >make a diffference, or kinds of tires make much of a handling difference? There is a wing drag strut reinforcement that was added later and is a good idea. The list archives have lots of good information; here are three in particular I bookmarked: http://tinyurl.com/5u6r9w http://tinyurl.com/5lmwja http://tinyurl.com/5krl9m There is also a Yahoo group devoted to the UltraStar; it's not as active as this group but the group files section contains the UltraStar drawings, manual, and the Cuyuna owner's and service manuals: http://groups.yahoo.com/group/KolbUltrastar/ -Dana -- I do not feel obliged to believe that the same God who endowed us with sense, reason and intellect has intended us to forgo their use. -- Galileo Galilei ________________________________________________________________________________
Date: Oct 25, 2008
Subject: no subject
Hope you guys are doing well. We are getting ready for Halloween party Friday. I guess you are at the Razorback game today. Have fun. Hope they win. tell Tara hi and have fun. Mom ________________________________________________________________________________
Subject: Re: safety pins
Date: Oct 25, 2008
tc1917(at)bellsouth.net wrote: > I have seen both the round safety rings and the pin type wear out, > disappear, etc. I use a small nylon tie strap and put it through the loop > on the pin type or thru the ring and around the bolt, pin or whatever you > are using on your struts and then snug it up. It holds it from moving and > if it cant move, it cant wear out. It is easy to check on pre flight, if it > is there, go. I fold occasionally and renew the ties and have NEVER had one > fall off or break even after a year or so in the sun. Black seems to hold > up better. Quick, easy and effective. I also use one between the ball and > the bell on the ail rad. rod where you disconnect to take up the space. > Good for what you paid for it. Ted Cowan, Alabama, Slingshot 912. Ted, be careful as you are trusting your life to a plastic tie wrap. I have used stainless marine safety rings for years. The clevis pins don't seem to wear out even though they do move around. Ralph -------- Ralph B Original Firestar 447 N91493 E-AB 21 years flying it Kolbra 912UL N20386 0 years flying it Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210242#210242 ________________________________________________________________________________
Date: Oct 25, 2008
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > Please keep it Kolb-related. This is going to be a test. I'll present the scenario and we'll see who comes up with the solution that eventually solved a rather perplexing problem on a friend's Kolb. Some of the data below may be indirection so be careful. Kolb FS I , Rotax 377, points ign. Engine ran fine the year prior which is the last time it was flown. Otherwise, engine started and run once or twice a month but only up to temperature and only up to 1/3 throttle to keep it lubricated. Fuel system required all hoses to be changed including primer line. Simplified system by taking out the primer bulb but left the primer pump. Fuel pump rebuilt, neoprene connector between carb and intake manifold replaced. When started and run up the engine failed to make full power hitting about 5800 rpm full throttle static and showing signs of being too lean since choke improved the situation but didn't make full power even then. Suspected the filter, replaced, same result. Re checked pulse pump, operating normally and providing sufficient fuel as indicated by the choke application. Float bowl clean, no debris. Jets were the same as before (remember, operated fine before) so no change. Jet needle change made no difference.Carb disassembled, all orifices blown out, floats checked good, float level checked good. Timing cheacked good as did plug gap and points and condenser. Still the same low power production aided with choke. Let's see if anyone can figure out what the problem really was. It was a funky solution but worth passing on....... Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 25, 2008
How was the EGT, CHT, plugs? Jets could need to be changed even if it ran good before if the weather's different. Also could be crankshaft seals, cylinder base gaskets, fuel blockage upstream somewhere, or bad gas if that's what was sitting in the tank for a year. -Dana At 10:15 PM 10/25/2008, Jim Baker wrote: > >X-SpamReason %%SpamReason%%: > > > Please keep it Kolb-related. > >This is going to be a test. I'll present the scenario and we'll see >who comes up with the solution that eventually solved a rather >perplexing problem on a friend's Kolb. Some of the data below may be >indirection so be careful. > >Kolb FS I , Rotax 377, points ign. Engine ran fine the year prior >which is the last time it was flown. Otherwise, engine started and >run once or twice a month but only up to temperature and only up to >1/3 throttle to keep it lubricated. Fuel system required all hoses to >be changed including primer line. Simplified system by taking out the >primer bulb but left the primer pump. Fuel pump rebuilt, neoprene >connector between carb and intake manifold replaced. > >When started and run up the engine failed to make full power hitting >about 5800 rpm full throttle static and showing signs of being too >lean since choke improved the situation but didn't make full power >even then. Suspected the filter, replaced, same result. Re checked >pulse pump, operating normally and providing sufficient fuel as >indicated by the choke application. Float bowl clean, no debris. Jets >were the same as before (remember, operated fine before) so no >change. Jet needle change made no difference.Carb disassembled, all >orifices blown out, floats checked good, float level checked good. >Timing cheacked good as did plug gap and points and condenser. Still >the same low power production aided with choke. > >Let's see if anyone can figure out what the problem really was. It >was a funky solution but worth passing on....... -- Question Authority and the authorities will question you! ________________________________________________________________________________
Date: Oct 25, 2008
At 10:15 PM 10/25/2008, you wrote: > >X-SpamReason %%SpamReason%%: > > > Please keep it Kolb-related. > >This is going to be a test. I'll present the scenario and we'll see >who comes up with the solution that eventually solved a rather >perplexing problem on a friend's Kolb. Some of the data below may be >indirection so be careful. If the holes in the bottom of these lines get clogged - the engine will never run right. ________________________________________________________________________________
Date: Oct 25, 2008
I'll bet on a air leak at the primer shaft ----- Original Message ---- From: Jim Baker <jlbaker(at)msbit.net> Sent: Saturday, October 25, 2008 10:15:59 PM Subject: Re: Kolb-List: Re: I'm so disappointed...... X-SpamReason %%SpamReason%%: > Please keep it Kolb-related. This is going to be a test. I'll present the scenario and we'll see who comes up with the solution that eventually solved a rather perplexing problem on a friend's Kolb. Some of the data below may be indirection so be careful. Kolb FS I , Rotax 377, points ign. Engine ran fine the year prior which is the last time it was flown. Otherwise, engine started and run once or twice a month but only up to temperature and only up to 1/3 throttle to keep it lubricated. Fuel system required all hoses to be changed including primer line. Simplified system by taking out the primer bulb but left the primer pump. Fuel pump rebuilt, neoprene connector between carb and intake manifold replaced. When started and run up the engine failed to make full power hitting about 5800 rpm full throttle static and showing signs of being too lean since choke improved the situation but didn't make full power even then. Suspected the filter, replaced, same result. Re checked pulse pump, operating normally and providing sufficient fuel as indicated by the choke application. Float bowl clean, no debris. Jets were the same as before (remember, operated fine before) so no change. Jet needle change made no difference.Carb disassembled, all orifices blown out, floats checked good, float level checked good. Timing cheacked good as did plug gap and points and condenser. Still the same low power production aided with choke. Let's see if anyone can figure out what the problem really was. It was a funky solution but worth passing on....... Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 25, 2008
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > I'll bet on a air leak at the primer shaft That was one of our thoughts as well so took the primer line off and capped the barb...no change. Good try tho.... Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 25, 2008
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > How was the EGT, CHT, plugs? EGTs and CHTs were a bit low, plugs nice and tan. >Jets could need to be changed even if it ran > good before if the weather's different. Weather essentially the same. This engine has a history of over fifteen years of very consistent operation. Forgot to mention that it's only got about 300 hrs total. Overhauled last year and ran fine afterwards. Not a carbon problem. Ring end gaps all within spec as was the cylinder choke. Outer seals replaced, inner seals tested fine on vacuum test. All applicable gaskets new. > Also could be crankshaft seals, See above. > cylinder base gaskets, See above. > fuel blockage upstream somewhere Ran a fuel line from the pump inlet directly into the gas tank by- passing all other lines...no change. > or bad gas if > that's what was sitting in the tank for a year. Remember the fuel lines were all new and the tank was fine, new fuel and oil. This will just kill you when I tell you the outcome...... Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 25, 2008
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > If the holes in the bottom of these lines get clogged - the engine > will never run right. If you're thinking of the vent line, new hose and open vent hole. But that's not it either..... Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 26, 2008
I give up. Let's blame it on Obama or Bush. That's what everybody else does . Seriously, I would say it's because you fixed something that wasn't broken in the first place. The bane of all ultralight & light plane fixers. My pals below say it ain't their fault either. Darfur Janjaweed killers. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Subject: pins
Date: Oct 26, 2008
In reply to Ralph B. You dont seem to understand that I use the Pin type safety pins on my clevis' and then the tie strap to keep the safety pin from moving. I believe you think I dont use any safety pins, only the tie straps. I may be crazy but I aint suicidal. I ADD a point of safety, not remove it. ted. ________________________________________________________________________________
Date: Oct 26, 2008
Black snake in muffler. On Oct 25, 2008, at 10:15 PM, Jim Baker wrote: > > X-SpamReason %%SpamReason%%: > >> Please keep it Kolb-related. > > This is going to be a test. I'll present the scenario and we'll see > who comes up with the solution that eventually solved a rather > perplexing problem on a friend's Kolb. Some of the data below may be > indirection so be careful. > > Kolb FS I , Rotax 377, points ign. Engine ran fine the year prior > which is the last time it was flown. Otherwise, engine started and > run once or twice a month but only up to temperature and only up to > 1/3 throttle to keep it lubricated. Fuel system required all hoses to > be changed including primer line. Simplified system by taking out the > primer bulb but left the primer pump. Fuel pump rebuilt, neoprene > connector between carb and intake manifold replaced. > > When started and run up the engine failed to make full power hitting > about 5800 rpm full throttle static and showing signs of being too > lean since choke improved the situation but didn't make full power > even then. Suspected the filter, replaced, same result. Re checked > pulse pump, operating normally and providing sufficient fuel as > indicated by the choke application. Float bowl clean, no debris. Jets > were the same as before (remember, operated fine before) so no > change. Jet needle change made no difference.Carb disassembled, all > orifices blown out, floats checked good, float level checked good. > Timing cheacked good as did plug gap and points and condenser. Still > the same low power production aided with choke. > > Let's see if anyone can figure out what the problem really was. It > was a funky solution but worth passing on....... > > > Jim Baker > 580.788.2779 > Elmore City, OK > > ________________________________________________________________________________
Date: Oct 26, 2008
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > > Black snake in muffler. I wish it had been...simple to see, easy to remedy. Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 26, 2008
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: > > This is going to be a test. > > Let's see if anyone can figure out what the problem really was. It > > was a funky solution but worth passing on....... The operative word here is "funky". What else could it be but the fuel system? Somehow it had changed in some small way. So..... Took the carb apart again. All components were correctly oriented (needle jet emulsion tube, needle capture plastic cup in the slide on top of needle, etc.)...there was just nothing wrong and all passages had been blown out with 100 psi compressed air. What could withstand that? Here's what it was. If you've ever taken the bowl off and let it dry and have seen some white, powdery stuff sticking to the bowl sides you'll want to check the main jet as well. This stuff had built up over time inside the jet orifice and had slowly reduced the effective opening of the jet to something less than the optimum. I had even used a jewelers loupe to look through the jet to ensure that it wasn't damaged by ham handed cleaning. The bore was smooth and shiny. But, it finally dawned on me that it didn't look particularly metallic, either. Clipped the end of a Ty-Wrap so that it would fit snugly into the jet and twisted. Gad, what a little pile of crap emerged on the end of that plastic piece! It had withstood 100 psi and solvent. Geez.... Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Subject: Bahama bound
Date: Oct 26, 2008
May we, as ultralight fliers, make the hop to Grand Bahama Island? I've got a friend who can pick me up, if I can refuel there, then fly to Walkers Cay. -John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210389#210389 ________________________________________________________________________________
Date: Oct 26, 2008
Subject: Re: Bahama bound
At 04:49 PM 10/26/2008, you wrote: > >May we, as ultralight fliers, make the hop to Grand Bahama Island? >I've got a friend who can pick me up, if I can refuel there, then >fly to Walkers Cay. -John What are you flying & who's going to pick you up if your engine quits? ________________________________________________________________________________
Date: Oct 26, 2008
Possums Sounds like a great trip! -- hope it comes off. Wondering what the Bahamian Gov't will charge for such a trip? Yachts have to pay a several-hundred-dollar 'cruising permit' to enter the Bahamas. I'm an interested bystander! On Oct 26, 2008, at 6:09 PM, possums wrote: > > At 04:49 PM 10/26/2008, you wrote: >> >> May we, as ultralight fliers, make the hop to Grand Bahama Island? >> I've got a friend who can pick me up, if I can refuel there, then >> fly to Walkers Cay. -John > > What are you flying & who's going to pick you up if your engine quits? > > ________________________________________________________________________________
Date: Oct 26, 2008
haha, mouse nest in muffler? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210433#210433 ________________________________________________________________________________
Subject: More Flying pictures
Date: Oct 26, 2008
Here are a few pics I took today whilre flinyg at my home base ACJ Americus. We have a nice 6000 foot runway. I have been using the grass between the taxiway and the runway for takeoff and landings. The wind was varying between 340 and 300 and the runway is 23 and 5 so this was a direct cross wind at 8 to 10 kts all day until about 5 it calmed to 4 to 5 kts so I got in a hour flight around the fields in the 4th picture out in the right side of the photo. All of the planes in the airport photos are junk ag (crop duster)planes. I am still chasing egts. I raised my needle one notch and am still getting right at 1200o but then engine runs just as well as it did before the adjustment. I am going to read the plugs next time I get the the airport. I really think the gauge is off since the old one reads different. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210436#210436 ________________________________________________________________________________
Date: Oct 26, 2008
When you say Ultralight if you mean no N number, I would expect not. You would need to check with the Bahamian government but I believe few countries allow that. I know Canada does not. Even with an N-numbered experimental you are supposed to get prior permission by the destination country and must have 12-inch N-numbers. I believe you also need a transponder and VHF radio crossing the ADIZ back into the US. Jim N. Idaho -------- Jim N. Idaho Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210438#210438 ________________________________________________________________________________
Date: Oct 27, 2008
I think you also must carry a rubber raft. Several of us were thinking of making the same trip in our FS II's. We eve n had available two "fast-boats" to be stationed at 25 mile intervals. Too many problems to overcome. Howard Shackleford FS II SC In a message dated 10/26/2008 11:06:16 P.M. Eastern Daylight Time, jim@tru-cast.com writes: When you say Ultralight if you mean no N number, I would expect not. You would need to check with the Bahamian government but I believe few countries allow that. I know Canada does not. Even with an N-numbered experimental you are supposed to get prior permission by the destination country and must have 12-inch N-numbers. I believe you also need a transponder and VHF radi o crossing the ADIZ back into the US. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
If you mean true Part 103 ULs, I doubt you would be welcome since to the best of my knowledge, the USA is the only country in the western hemisphere that permits any kind of flying machine that is not registered. If you mean Exp Amateur Built, and you have required equipment which includes radio and transponder w/ altitude encoder, floatation equipment etc. then there is no reason I know of that you can't. If you mean E-LSA, not sure. If you are a Sport Pilot, maybe not, depends on whether Bahamas recognizes Sport Pilot. I know Canada does not. Call the Bahamas aviation agency (whatever it is called) and ask them to be sure. Thom in Buffalo ________________________________________________________________________________
Subject: Just for Grins =?ISO-8859-1?Q?=93?= You be the Judge, and the
Answers Are
Date: Oct 27, 2008
Just for Grins You be the Judge and the Answers Are Test Your Knowledge of FAA Violations! - Score 100% You got 6 out of 6 1. You can be held responsible if the appropriate logbook entries are not made after a repair, alteration, or inspection. True According to FAR 91.405 "each owner or operator...(b) shall ensure that maintenance personnel make appropriate entries in the aircraft maintenance records indicating the aircraft has been approved for return to service." 2. You can operate an aircraft outside the United States on the pink copy of an application for registration. False The pink copy is good temporary authorization for operation within the United States only. 3. An unreported drug or alcohol related driving infraction could cause the FAA to suspend or revoke a pilot's certificate. True FAR 61.15 requires that a pilot report to the FAA any drug or alcohol related "motor vehicle action" taken against them and the report must be made within 60 days of the motor vehicle action. 4. If you move and enter your new address on an FAA form (such as an aircraft registration application) you still need to notify the Airman Certification Branch of the change. True FAR 61.60 requires a certificate holder to notify the Airman Certification Branch in writing (or online) within 30 days of the change. 5. If you rent or borrow someone's aircraft, you are not responsible if you fly that aircraft after it has missed an annual inspection. False As PIC, you may be subject to enforcement if you fly an aircraft that has missed a required inspection. 6. A certified mechanic must replace the battery in your ELT in order for you to avoid suspension. False A certified mechanic or the person installing the battery must make the appropriate logbook entry. My sincere apologies for being a day late and thanks for all the positive contributions. Sincerely, John T. Schmidt, CFI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210716#210716 ________________________________________________________________________________
Date: Oct 28, 2008
WOW! What posh hangars. I must put a pic of mine up one day just to show how the lower half of the social scale operates. Cheers Pat ________________________________________________________________________________
From: "cristalclear13" <cristalclearwaters(at)gmail.com>
Date: Oct 28, 2008
pj.ladd(at)btinternet.com wrote: > WOW! > What posh hangars. I must put a pic of mine up one day just to show how the > lower half of the social scale operates. > > Cheers > > Pat Pat, The airport just built those. I attached a picture of what we WERE using. When it would rain it would wash our chocks away and the hanger would fill up with inches of rain...very corrosive environment. I couldn't afford to stay in these new ones if I wasn't sharing. I may not be able to stay anyways because neither one of us can afford the Million dollars of liability insurance that is required to stay there. We are trying to see if they'll reduce that requirement. If not I may be sharing space with my goats in their shed! [Laughing] -------- Cristal Waters Kolb Mark II Twinstar Rotax 503 DCSI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210761#210761 Attachments: http://forums.matronics.com//files/n193y_right_side_422.jpg ________________________________________________________________________________
Subject: Tree landings
Date: Oct 28, 2008
I though this would be another good topic to bring up. Tree landings scare me! Luckily I have mostly open fields where I fly but one end of our runway has trees and some other obstructions. Pine trees in particular do not have many branches and the few they have are located at the top of the trees. So if you had to make a landing in the pines it's a good chance your airplane will fall right through the trees and plummet to the ground some 50+ feet. That would be very bad! So what do you do if you have a tight road with possible power lines crossing that you can't see and road signs in close? Take the trees or attempt the road? Not sure if our light planes would takeout a power line without losing control. Have any of you had a tree landings? I guess if you had a brs it would help in a tree landings since the chute would get tangled in the trees. I don't have a brs. Grant Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210808#210808 ________________________________________________________________________________
Date: Oct 28, 2008
Subject: Re: Tree landings
Don't know if it will help, but here's an account of a friends' crash: http://www.texas-flyer.com/RicksCrash/ On Tue, Oct 28, 2008 at 12:14 PM, grantr wrote: > > I though this would be another good topic to bring up. Tree landings > scare me! Luckily I have mostly open fields where I fly but one end of > our runway has trees and some other obstructions. > > Pine trees in particular do not have many branches and the few they > have are located at the top of the trees. So if you had to make a > landing in the pines it's a good chance your airplane will fall right > through the trees and plummet to the ground some 50+ feet. That would > be very bad! > > So what do you do if you have a tight road with possible power lines > crossing that you can't see and road signs in close? Take the trees or > attempt the road? Not sure if our light planes would takeout a power > line without losing control. > > Have any of you had a tree landings? I guess if you had a > brs it would help in a tree landings since the chute would get tangled > in the trees. I don't have a brs. > > Grant > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=210808#210808 > > ________________________________________________________________________________
Subject: Re: More Flying pictures
Date: Oct 28, 2008
Here are more pictures a friend took of me with my plane around the airport. [ 2 Stroke smoke! Ready to taxi Just taking off Wave to the camera! about to turn cross wind leg downwing leg 1000 agl Landing approach 65mph approach Landing taxing back. Just anther landing approach Landing More pictures here http://s340.photobucket.com/albums/o353/grant31781/Souther%20feild%2010-4-08/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210809#210809 ________________________________________________________________________________
Date: Oct 28, 2008
Thanks for sharing that. A single line of trees would definitely not be good. Really amazed that he wasn't hurt. It looks like he could have landed in the field on the other side of the road. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210825#210825 ________________________________________________________________________________
Date: Oct 28, 2008
He's gone over and over the whole thing in his head a thousand times, and, in 20-20 hindsight, there were lots of options, but as it was happening, I guess tunnel vision tends to restrict it to what you see ahead of you. He also freely admits that he had yet to practice any engine-outs in -that- plane, so he was unfamiliar with how fast it would descend, and that reached up an bit him. As for being unhurt, I'd say it was mostly luck, but, the Buccaneer is a sea-plane, and sea-planes are usually built much more robustly than land-planes, and that may have had a lot to do with it. -- Robert On Tue, Oct 28, 2008 at 2:19 PM, grantr wrote: > > Thanks for sharing that. A single line of trees would definitely not be good. > > Really amazed that he wasn't hurt. It looks like he could have landed in the field on the other side of the road. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=210825#210825 > > ________________________________________________________________________________
Date: Oct 28, 2008
Good story. -also a lesson to not diddle getting to the best spot, if any. Too high is much better than too low. When close enough for confidence you can do all the other stuff like flaps, dump slipping, S-turns. Have to admit I didn't use my flaps going into the high alfalfa this spring, but then I was low and slow to begin. The last good thing to avail is the high drag a kolb has. Just push the nose down toward your best spot and head right there. If you are looking at a fence coming up don't bother with a stall, plant it. Just before you hit that barbed wire do a ground loop. -done it all, not much damage. BB On 28, Oct 2008, at 1:20 PM, Robert Laird wrote: > > Don't know if it will help, but here's an account of a friends' crash: > > http://www.texas-flyer.com/RicksCrash/ > > > On Tue, Oct 28, 2008 at 12:14 PM, grantr > wrote: >> >> >> I though this would be another good topic to bring up. Tree landings >> scare me! Luckily I have mostly open fields where I fly but one >> end of >> our runway has trees and some other obstructions. >> >> Pine trees in particular do not have many branches and the few they >> have are located at the top of the trees. So if you had to make a >> landing in the pines it's a good chance your airplane will fall right >> through the trees and plummet to the ground some 50+ feet. That would >> be very bad! >> >> So what do you do if you have a tight road with possible power lines >> crossing that you can't see and road signs in close? Take the >> trees or >> attempt the road? Not sure if our light planes would takeout a power >> line without losing control. >> >> Have any of you had a tree landings? I guess if you had a >> brs it would help in a tree landings since the chute would get >> tangled >> in the trees. I don't have a brs. >> >> Grant >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=210808#210808 >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 28, 2008
JetPilot wrote: > The Southwest has to be one of the prettiest areas in the country to fly over. I hope to fly these areas one of these days, thanks for posting. > > Mike Speaking of flying in the southwest, I took this from my titan, but I would have loved to have done this in the FS II. This is on final approach to the Los Alamos airport, where you can only approach from the east. I took this last winter and it was about 15 degrees in the cockpit at the time. If you don't have the runway made and there's a problem, you have no escape whatever. It's down into the cliffs with surely lots of unexploded ordinance down there from Los Alamos National Labs' activities. (LANL is visible directly to the left of the runway in this picture. Note also the smoke, there was a fire going on in the town at the time). LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210839#210839 Attachments: http://forums.matronics.com//files/dsc00074_109.jpg ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Date: Oct 28, 2008
A friend of mine's 80 year old dad crashed his Kolb (seems like it was a firefly) in a tree. I think it was in a woods not a single tree. It was in the UP of Michigan were there aren't many single trees. Any way, he didn't get hurt and I don't think the plane was hurt much either. He did sprain an ankle climbing down to the ground. The next time he flew the plane, he crashed the Kolb in a river. Again he wasn't hurt. Another story recovering the plane from the river After that he was grounded from flying so there were no more crashes. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: "Robert Laird" <rlaird(at)cavediver.com> Sent: Tuesday, October 28, 2008 3:48 PM Subject: Re: Kolb-List: Re: Tree landings > > He's gone over and over the whole thing in his head a thousand times, > and, in 20-20 hindsight, there were lots of options, but as it was > happening, I guess tunnel vision tends to restrict it to what you see > ahead of you. He also freely admits that he had yet to practice any > engine-outs in -that- plane, so he was unfamiliar with how fast it > would descend, and that reached up an bit him. > ________________________________________________________________________________
Date: Oct 28, 2008
Why ground the guy hes 80 for crying out loud if he likes to fly let him do it! :) Were the crashes pilot error or other? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210849#210849 ________________________________________________________________________________
Date: Oct 28, 2008
John when are you planning no making the crossing? I plan on going but waiting for information and what is needed for permits to fly over in the Bahamas. M111C/912 -------------------------------------------------- From: "2danglico" <john.tempest(at)basf.com> Sent: 2008-10-26 16:49 Subject: Kolb-List: Bahama bound > > May we, as ultralight fliers, make the hop to Grand Bahama Island? I've > got a friend who can pick me up, if I can refuel there, then fly to > Walkers Cay. -John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=210389#210389 > > > ________________________________________________________________________________
Date: Oct 28, 2008
At 01:14 PM 10/28/2008, you wrote: > >I though this would be another good topic to bring up. Tree landings >scare me! Luckily I have mostly open fields where I fly but one end of >our runway has trees and some other obstructions. Here's one with a 20 mph crosswind landing, flipped him up, over and upside down into the trees before he ever touched down in. Four of us made it down before him and he was dragging behind everybody because of his floats. We were actually eating lunch at the other end of the runway (couldn't see him) when we first heard his engine go from normal to this God awful "full throttle/chain saw" sound. You might notice that his "nose" never touched the ground. Got a Wrecker to pick his plane up and put it on the runway. He towed it home - one less Possum. Another one of us landing into our home field with a almost new Firestar II. Missed the downwind turn, totaled the plane, in the woods big time, EMT's Ambulance, Sheriff's deputies, FAA the next day, etc. Tore the wings off coming through the trees full throttle back 300 ft in the woods.. All he did was break his arm and wouldn't have had that if he had keep his arm inside the cockpit. He was still strapped into the cage and mumbling about something or other. Later he said he couldn't remember anything after he hit the first tree. There used to be big trees where these houses are. http://video.google.com/videoplay?docid=263159682459782825&hl=en ________________________________________________________________________________
Date: Oct 28, 2008
At 01:14 PM 10/28/2008, grantr wrote: >So what do you do if you have a tight road with possible power lines >crossing that you can't see and road signs in close? Take the trees or >attempt the road? Not sure if our light planes would takeout a power >line without losing control. > >Have any of you had a tree landings? I guess if you had a >brs it would help in a tree landings since the chute would get tangled >in the trees. I don't have a brs. I think the trees would be a better choice than power lines. If you hit the lines at one point it'll snap you around fast; with luck trees you'll hit both wings and absorb some energy. Going full into the trees is a better choice than a tree lined road that's narrower than your wingspan. About a month ago I related my friend's tree landing in his MKIII, due [apparently] to water in the gas. Probably shouldn't call it a landing though, it was the classic stall/spin scenario through trying to turn back to the airport after an the engine failed on takeoff. The better choice, in retrospect, would have been to go into the water straight ahead. From the point where he hit the treetops to point of impact was about a 45 angle. Surgery to try to rebuild his shattered angle is Thursday; his passenger is sore but recovering from a pelvis cracked in three places. -Dana -- The Definition of an Upgrade: Take old bugs out, put new ones in. ________________________________________________________________________________
Date: Oct 29, 2008
I have no itinerary. I have a former Marine buddy working there and from our time in Okinawa, he knew I enjoyed snorkeling alot. I'd been telling him about my Firestar and how much fun I was having flying it around, when he suggested I fly it over and bring my snorkel gear. I'm not sure if he knew I'd try to take him up on it. I can make 170+ miles with my new "5 gal tank". Freeport doesn't seem to be more than 60 or 70 from the Fla coast. I'm just not sure if they'll allow an unregistered UL to fly over. But, who knows? Let me know what you can find out. If they'll let me come over, we'll go at your convenience. -John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210946#210946 ________________________________________________________________________________
Date: Oct 29, 2008
I looked into this once, a long time ago... my memory may not be complete, but I do remember that ULs would definitely -not- be allowed... they only accepted registered aircraft, and certified pilots, plus they had a lot of other requirements (insurance, fees, paperwork, raft, etc.) -- Robert On Wed, Oct 29, 2008 at 7:25 AM, 2danglico wrote: > > I have no itinerary. I have a former Marine buddy working there and from our time in Okinawa, he knew I enjoyed snorkeling alot. I'd been telling him about my Firestar and how much fun I was having flying it around, when he suggested I fly it over and bring my snorkel gear. I'm not sure if he knew I'd try to take him up on it. I can make 170+ miles with my new "5 gal tank". Freeport doesn't seem to be more than 60 or 70 from the Fla coast. I'm just not sure if they'll allow an unregistered UL to fly over. But, who knows? Let me know what you can find out. If they'll let me come over, we'll go at your convenience. -John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=210946#210946 > > ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Non-Moving EGT's
> ............................... >I am still chasing egts. I raised my needle one notch and am still getting right at 1200o but then engine runs just as well as it did before the adjustment. I am going to read the plugs next time I get the airport. > Grant, If you raise the needle and the EGT's do not move down, it may indicate that the main jet is limiting fuel flow. Try increasing your main jet to the next larger size. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Six Gallon Tank
Kolbers: Due to some other factors, I had not dragged the Fly out of the trailer for about two months. I did so on Sunday and found something interesting. The six gallon tank obtained from TNK a little over a year ago has developed noticable bulging and sagging in the bottom half of the side walls. It contained about five gallons and when pressed it felt "flabby" and a lot more flexible than it did when first installed. I will replace it with a standard five gallon thick-wall tank before I will be willing to fly the airplane again... In its present condition, this tank looks to me as if it could easily split open. I called Travis and asked if he had heard of anything like this with the sixes... He said they were certainly of thinner material than the fives, but he had not heard of anyone reporting problems with bulging or unusual softness in the lower sides like mine. He asked me to put out a call on the List and see if anyone else had observed a similar problem with the six gallon tanks... Any takers...?? beauford FF076 Brandon, FL ________________________________________________________________________________
Date: Oct 29, 2008
From: william sullivan <williamtsullivan(at)att.net>
Subject: Kolb List re: six gallon tank
- Beauford- Just out of curiosity, if it was in a trailer, what kind of t emperatures have you had in the last couple of months?- Could it have got ten too hot in the trailer? - ------------------------- ----------------- Bill Sullivan ------------------------- ----------------- Windsor Locks, Ct. ________________________________________________________________________________
Subject: Re: Six Gallon Tank
Date: Oct 29, 2008
Bill Seems like Travis was showing us at Homecoming a newer 6 gallon tank that was more like the 5 gallon in thickness. Travis, Is this the case? Rick Neilsen Redrive VW Powered MKIIIC ----- Original Message ----- From: beauford T To: Kolb List Sent: Wednesday, October 29, 2008 3:29 PM Subject: Kolb-List: Six Gallon Tank Kolbers: Due to some other factors, I had not dragged the Fly out of the trailer for about two months. I did so on Sunday and found something interesting. The six gallon tank obtained from TNK a little over a year ago has developed noticable bulging and sagging in the bottom half of the side walls. It contained about five gallons and when pressed it felt "flabby" and a lot more flexible than it did when first installed. I will replace it with a standard five gallon thick-wall tank before I will be willing to fly the airplane again... In its present condition, this tank looks to me as if it could easily split open. I called Travis and asked if he had heard of anything like this with the sixes... He said they were certainly of thinner material than the fives, but he had not heard of anyone reporting problems with bulging or unusual softness in the lower sides like mine. He asked me to put out a call on the List and see if anyone else had observed a similar problem with the six gallon tanks... Any takers...?? beauford FF076 Brandon, FL ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Re: Non-Moving EGT's
At 03:41 PM 10/29/2008, Jack B. Hart wrote: > > >............................... > >I am still chasing egts. I raised my needle one notch and am still getting >right at 1200o but then engine runs just as well as it did before the >adjustment. I am going to read the plugs next time I get the airport. > >Grant, > >If you raise the needle and the EGT's do not move down, it may indicate that >the main jet is limiting fuel flow. Try increasing your main jet to the >next larger size. Is this full throttle EGT? The needle should be completely out of the jet and have no effect at full throttle, no? -Dana -- Can I deduct last years taxes as a bad investment? ________________________________________________________________________________
Date: Oct 29, 2008
Mine deform slightly too. Jim Kmet ----- Original Message ----- From: beauford T To: Kolb List Sent: Wednesday, October 29, 2008 12:29 PM Subject: Kolb-List: Six Gallon Tank Kolbers: Due to some other factors, I had not dragged the Fly out of the trailer f or about two months. I did so on Sunday and found something interesting. The six gallon tank obtained from TNK a little over a year ago has develo ped noticable bulging and sagging in the bottom half of the side walls. I t contained about five gallons and when pressed it felt "flabby" and a lot more flexible than it did when first installed. I will replace it with a standard five gallon thick-wall tank before I wi ll be willing to fly the airplane again... In its present condition, this tank looks to me as if it could easily split open. I called Travis and asked if he had heard of anything like this with the sixes... He said they were certainly of thinner material than the fives, b ut he had not heard of anyone reporting problems with bulging or unusual so ftness in the lower sides like mine. He asked me to put out a call on the List and see if anyone else had obs erved a similar problem with the six gallon tanks... Any takers...?? beauford FF076 Brandon, FL ________________________________________________________________________________
Date: - - - , 20-
Rick The tanks you saw here in Sep. are the same 6 gallon tanks I have always used. It could be some of them are thicker material. I will check ours in the MIII Xtra Thursday . Travis @ home Richard & Martha Neilsen writes: > Bill > > Seems like Travis was showing us at Homecoming a newer 6 gallon tank that was more like the 5 gallon in thickness. > > Travis, Is this the case? > > Rick Neilsen > Redrive VW Powered MKIIIC > ----- Original Message ----- > From: beauford T > To: Kolb List > Sent: Wednesday, October 29, 2008 3:29 PM > Subject: Kolb-List: Six Gallon Tank > > > Kolbers: > > Due to some other factors, I had not dragged the Fly out of the trailer for about two months. I did so on Sunday and found something interesting. > > The six gallon tank obtained from TNK a little over a year ago has developed noticable bulging and sagging in the bottom half of the side walls. It contained about five gallons and when pressed it felt "flabby" and a lot more flexible than it did when first installed. > > I will replace it with a standard five gallon thick-wall tank before I will be willing to fly the airplane again... In its present condition, this tank looks to me as if it could easily split open. > > I called Travis and asked if he had heard of anything like this with the sixes... He said they were certainly of thinner material than the fives, but he had not heard of anyone reporting problems with bulging or unusual softness in the lower sides like mine. > > He asked me to put out a call on the List and see if anyone else had observed a similar problem with the six gallon tanks... > > Any takers...?? > > beauford > FF076 > Brandon, FL > > > ________________________________________________________________________________
Date: Oct 29, 2008
FWIW, over many years and many planes, I've yet to see a plastic tank that hasn't developed bulges with time--just like a few of us. Jerry ________________________________________________________________________________
Date: Oct 29, 2008
Might this be caused by a pressure build up or a chemical reaction from our new blended fuels? Haven't looked at my tank, now I'm scared to look although mine is a 10 gal Challenger tank. Than's for alerting us to this Beauford. jerb At 05:13 PM 10/29/2008, you wrote: >Mine deform slightly too. Jim Kmet >----- Original Message ----- >From: <mailto:beauford173(at)verizon.net>beauford T >To: Kolb List >Sent: Wednesday, October 29, 2008 12:29 PM >Subject: Kolb-List: Six Gallon Tank > >Kolbers: > >Due to some other factors, I had not dragged the Fly out of the >trailer for about two months. I did so on Sunday and found >something interesting. > >The six gallon tank obtained from TNK a little over a year ago has >developed noticable bulging and sagging in the bottom half of the >side walls. It contained about five gallons and when pressed it >felt "flabby" and a lot more flexible than it did when first installed. > >I will replace it with a standard five gallon thick-wall tank before >I will be willing to fly the airplane again... In its present >condition, this tank looks to me as if it could easily split open. > >I called Travis and asked if he had heard of anything like this with >the sixes... He said they were certainly of thinner material than >the fives, but he had not heard of anyone reporting problems with >bulging or unusual softness in the lower sides like mine. > >He asked me to put out a call on the List and see if anyone else >had observed a similar problem with the six gallon tanks... > >Any takers...?? > >beauford >FF076 >Brandon, FL > > >p://www.matronics.com/Navigator?Kolb-List > >ics.com > >matronics.com/contribution > > ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Re: : Kolb-List:: six gallon tank
Brother Sullivan... Fair question, sir... It is an enclosed trailer, but well vented and has a light colored roof... The Fly has been in this same trailer in the same place since 2001... with the same 5 gallon tank installed. That tank is now sitting in the garage and, aside from a good bit of staining and discoration, appears structurally to be in the same condition it was in in 2001. It does get right warm in the trailer, but I have noticed no deterioration with anything else in there over the years...and another Kolb with two five gallon tanks sat next to it in a similar trailer for three years or so with no adverse effects on the tanks... I think it is just a case of the manufacturer blowing the six gallon jobs without enough material in them... When it arrived new, I immediately noticed that it was significantly less robust than the five gallon version. beauford FF-076 ----- Original Message ----- From: william sullivan To: kolb list Sent: Wednesday, October 29, 2008 3:47 PM Subject: Kolb-List: Kolb List re: six gallon tank Beauford- Just out of curiosity, if it was in a trailer, what kind of temperatures have you had in the last couple of months? Could it have gotten too hot in the trailer? Bill Sullivan Windsor Locks, Ct. 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Oct 29, 2008
- Beauford- That's why I asked, to see if it could be age, comparative th ickness, sunlight deterioration, etc.- Maybe there is a common factor, if someone else had a problem.- Good luck. - ------------------------- ----------------------- Bill Sullivan ________________________________________________________________________________
Subject: Re: Kolb List re: six gallon tank
Date: - - - , 20-
Good point Bill. At $25 per tank replacing the tank yearly might be a good idea especially with todays fuel we are using. I know the new fuel is driving the antique car guys crazy Especially the cars with the old original vacuum fuel tank pump set up. Travis william sullivan writes: > Beauford- That's why I asked, to see if it could be age, comparative thickness, sunlight deterioration, etc. Maybe there is a common factor, if someone else had a problem. Good luck. > > Bill Sullivan ________________________________________________________________________________
Date: Oct 29, 2008
Full throttle EGTs are 1200 to 1225. 5300 to 6000 one is right on 1200 the other is right under it so I say around 1180. Before I installed the new Dual egt the reading on the single EGT gauge was 900o at 6000rpms See in photo below. Nothing was changed prior to the gauge switch. I am still using the same sender EGT probe the old gauge used on the PTO cylinder. When I checked/ changed the plugs after the gauge change the plugs were light brown. I dont know why the 2 gauges read different on the egts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211099#211099 ________________________________________________________________________________
Date: Oct 29, 2008
Subject: In Flight Video
Quality is lost in going to YouTube, but here is my FSII roaming the local area. http://tinyurl.com/55sw7g Bill Eslick ________________________________________________________________________________
Subject: Re: In Flight Video
Date: Oct 29, 2008
Hi Bill That was a cool video. I really like the airport you are flying out of. Looks like a estate. Its a darn shame your Kolb is way in the heck out in Texas. Would like to do a little Kolb formation flying sometime. Have Fun and Lots of it! Carlos Grageda Walla Walla WA ----- Original Message ----- From: Bill Eslick To: kolb-list(at)matronics.com Sent: Wednesday, October 29, 2008 8:46 PM Subject: Kolb-List: In Flight Video Quality is lost in going to YouTube, but here is my FSII roaming the local area. http://tinyurl.com/55sw7g Bill Eslick ________________________________________________________________________________
Subject: Required structural modification needed
From: "Jean Pillaudin" <jean.pillaudin(at)gmail.com>
Date: Oct 30, 2008
Hi all, I am new here, I am from France, 45 years old, glider pilot and hang-glider pilot too. I just find a used Kolb Ultrastar who was buy in 1987 (kit) an finished in 1990. I 'll get it and see it for the first time on mid november. I want to ask if there is required structural modification (ie wing drag strut) since this date of built to check the plane and see if I need to make re-inforcement. Thks in advance. Have fun fly. Jean Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211137#211137 ________________________________________________________________________________
Date: Oct 30, 2008
Subject: Re: Required structural modification needed
At 05:02 AM 10/30/2008, Jean Pillaudin wrote: >I just find a used Kolb Ultrastar who was buy in 1987 (kit) an finished in >1990. I 'll get it and see it for the first time on mid november. > >I want to ask if there is required structural modification (ie wing drag >strut) since this date of built to check the plane and see if I need to >make re-inforcement. Jean, From the UltraStar manual: "The UltraStar was successfully flight tested to 5-1/2 G's without this brace. To obtain this loading requires a steep (about 45 degrees) high speed full power dive to 90 mph and an abrupt pullout. For normal flying the brace is not necessary. With this in mind you can decide whether or not you want to add the brace." My UltraStar does have the brace, but if it didn't, I wouldn't hesitate to fly it anyway, and add it at such time as the plane needed to be recovered. You can see the brace if you cut a slit in the fabric of the wing root and shine a flashlight in there. This is a good idea anyway, to inspect the inside of the wing and make sure everything is as it should be. There is a Kolb UltraStar Yahoo group <http://groups.yahoo.com/group/KolbUltrastar/>, and in the files section of the group is the UltraStar manual. In the manual, between "ailerons" and "tail", is a description of the brace, as well as a drawing, so you know what to look for. -Dana -- We're bored, We're heavily armed, We're off our medication, Is the post office still hiring? ________________________________________________________________________________
Subject: Re: Pictures !!! Flying a Kolb Around South Arizona...
Date: Oct 30, 2008
aircraft sit outdoors at the mercy of rain,>> Hi Russ, mine is inside but still, as it is on a farm, subject to bird droppings, mice, voles, bugs up the pitot, rabbits or badgers digging up the floor etc With VG`s on wing coverings have to handled gently too. The only drawback. Cheers Pat ________________________________________________________________________________
Date: Oct 30, 2008
From: "Jean PILLAUDIN" <jean.pillaudin(at)gmail.com>
Hi Dana, Ho you don't know as I am feeling light!!! It is a very good new. Now I can check if this modification is done or not. And if it is not modified I just fly gently as I know the VNE speed of 75 Mph. Acrobatic is not my goal :) Just another question about the best glide ratio of this Plane: Even if there is difference between each Ultrastar, what is the best glide ratio speed on it when engine is off? Happy flying! Jean 2008/10/30 Dana Hague > At 05:02 AM 10/30/2008, Jean Pillaudin wrote: > > I just find a used Kolb Ultrastar who was buy in 1987 (kit) an finished in > 1990. I 'll get it and see it for the first time on mid november. > > I want to ask if there is required structural modification (ie wing drag > strut) since this date of built to check the plane and see if I need to make > re-inforcement. > > > Jean, > > From the UltraStar manual: "The UltraStar was successfully flight tested > to 5-1/2 G's without this brace. To obtain this loading requires a steep > (about 45 degrees) high speed full power dive to 90 mph and an abrupt > pullout. For normal flying the brace is not necessary. With this in mind > you can decide whether or not you want to add the brace." My UltraStar > does have the brace, but if it didn't, I wouldn't hesitate to fly it anyway, > and add it at such time as the plane needed to be recovered. > > You can see the brace if you cut a slit in the fabric of the wing root and > shine a flashlight in there. This is a good idea anyway, to inspect the > inside of the wing and make sure everything is as it should be. There is a > Kolb UltraStar Yahoo group <http://groups.yahoo.com/group/KolbUltrastar/>, > and in the files section of the group is the UltraStar manual. In the > manual, between "ailerons" and "tail", is a description of the brace, as > well as a drawing, so you know what to look for. > > -Dana > > > -- > We're bored, > We're heavily armed, > We're off our medication, > Is the post office still hiring? > > * > > * > > ________________________________________________________________________________
Date: Oct 30, 2008
From: =?ISO-8859-1?Q?No=EBl_Bouchard?= <noelbou(at)vif.com>
Subject: Kolb Twinstar MK II for sale
Hello Kolbers, I was not really decided but now i am : Selling my Kolb Twinstar MK II / Rotax 503 DC - Built in 1990. Both wings rebuilt anew in 2002 (about 200 Hrs) - Total time on plane about 600 Hrs - Engine rebuilt recently with about 125 hours. - Skis available. - Some minor work to be done (new lexan wind shield ...) Asking $8000.00 The plane is located near Montreal, Canada Please contact me directly at my email address noelbou(at)vif.com Best ... Noel Bouchard ________________________________________________________________________________
Date: Oct 30, 2008
I just see the picture in the Kolb Manual on Yahoo group, it is clear! Thank's again Dana for your input. Jean 2008/10/30 Jean PILLAUDIN > Hi Dana, > > Ho you don't know as I am feeling light!!! It is a very good new. Now I can > check if this modification is done or not. And if it is not modified I just > fly gently as I know the VNE speed of 75 Mph. Acrobatic is not my goal :) > > > Just another question about the best glide ratio of this Plane: > Even if there is difference between each Ultrastar, what is the best glide > ratio speed on it when engine is off? > > Happy flying! > > Jean > > > 2008/10/30 Dana Hague > > At 05:02 AM 10/30/2008, Jean Pillaudin wrote: >> >> I just find a used Kolb Ultrastar who was buy in 1987 (kit) an finished in >> 1990. I 'll get it and see it for the first time on mid november. >> >> I want to ask if there is required structural modification (ie wing drag >> strut) since this date of built to check the plane and see if I need to make >> re-inforcement. >> >> >> Jean, >> >> From the UltraStar manual: "The UltraStar was successfully flight tested >> to 5-1/2 G's without this brace. To obtain this loading requires a steep >> (about 45 degrees) high speed full power dive to 90 mph and an abrupt >> pullout. For normal flying the brace is not necessary. With this in mind >> you can decide whether or not you want to add the brace." My UltraStar >> does have the brace, but if it didn't, I wouldn't hesitate to fly it anyway, >> and add it at such time as the plane needed to be recovered. >> >> You can see the brace if you cut a slit in the fabric of the wing root and >> shine a flashlight in there. This is a good idea anyway, to inspect the >> inside of the wing and make sure everything is as it should be. There is a >> Kolb UltraStar Yahoo group <http://groups.yahoo.com/group/KolbUltrastar/>, >> and in the files section of the group is the UltraStar manual. In the >> manual, between "ailerons" and "tail", is a description of the brace, as >> well as a drawing, so you know what to look for. >> >> -Dana >> >> >> -- >> We're bored, >> We're heavily armed, >> We're off our medication, >> Is the post office still hiring? >> >> * >> >> * >> >> > ________________________________________________________________________________
Date: Oct 30, 2008
At 08:27 AM 10/30/2008, Jean PILLAUDIN wrote: >Just another question about the best glide ratio of this Plane: >Even if there is difference between each Ultrastar, what is the best glide >ratio speed on it when engine is off? I've never seen it published, nor have I tried to measure it, but like most ultralights it should be pretty slow. -Dana -- When authorities warn you of the sinfulness of sex, there is an important lesson to be learned. Do not have sex with the authorities. ________________________________________________________________________________
Date: Oct 30, 2008
=0A=0ABill, I have about 500 hrs in a Firestar KXP with a 503- and your v ideo comes as close to what flying a firestar is like- as I have seen . T he take off and the ability to climb like a homesick Angel is very clear an d really moved me . Thanks Chris=0A=0A=0A________________________________ =0AFrom: Bill Eslick <wgeslick(at)gmail.com>=0ATo: kolb-list(at)matronics.com=0AS ent: Wednesday, October 29, 2008 11:46:05 PM=0ASubject: Kolb-List: In Fligh t Video=0A=0AQuality is lost in going to YouTube, but here is my FSII roami ng the local area.=0A=0Ahttp://tinyurl.com/55sw7g=0A=0ABill Eslick=0A=0A ====================== =0A =0A=0A ________________________________________________________________________________
Date: Oct 30, 2008
I purchased the 6 gal tanks from TNK last winter and have since used them for about 40 flight hours. I too have encountered some sagging (caving in) of the bottom sides, at all fuel levels. However, I would not characterize it as severe and I have not had any indications of it becoming a problem. I have used only unleaded ethanol-free fuel in them until about one month ago, due to a change in its availability. So, in my case, ethanol was not a potential contributor. Gary Siegrist Mark IIIc _____ From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of beauford T Sent: Wednesday, October 29, 2008 2:29 PM Subject: Kolb-List: Six Gallon Tank Kolbers: Due to some other factors, I had not dragged the Fly out of the trailer for about two months. I did so on Sunday and found something interesting. The six gallon tank obtained from TNK a little over a year ago has developed noticable bulging and sagging in the bottom half of the side walls. It contained about five gallons and when pressed it felt "flabby" and a lot more flexible than it did when first installed. I will replace it with a standard five gallon thick-wall tank before I will be willing to fly the airplane again... In its present condition, this tank looks to me as if it could easily split open. I called Travis and asked if he had heard of anything like this with the sixes... He said they were certainly of thinner material than the fives, but he had not heard of anyone reporting problems with bulging or unusual softness in the lower sides like mine. He asked me to put out a call on the List and see if anyone else had observed a similar problem with the six gallon tanks... Any takers...?? beauford FF076 Brandon, FL ________________________________________________________________________________
Date: Oct 30, 2008
Wow! That is a cool video. -------- Jim O'Day Fargo, ND Former Firestar II Builder/Pilot Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211317#211317 ________________________________________________________________________________
Subject: not kolb
Date: Oct 31, 2008
Can anyone tell if this is real? <http://www.chilloutzone.de/files/08102703.html> BB ps, a real heartbeat stimulator whatever ________________________________________________________________________________
Date: Oct 31, 2008
Subject: Re: not kolb
From: robert bean <slyck(at)frontiernet.net> Date: Fri, 31 Oct 2008 10:02:37 -0400 Can anyone tell if this is real? <http://www.chilloutzone.de/files/08102703.html> Bob, It looks real and demonstrates that if you have enough power and remaining control surfaces, plus some luck you can fly anything. Some time back I watched a video of an Israel jet that landed with most of the right wing missing. He had to fly with afterburner to keep it in the air. Jack B. Hart FF004 Winchester, IN ________________________________________________________________________________
Date: Oct 31, 2008
I know it's possible in RC at least. seen here: http://www.youtube.com/watch?v=ZaXMrFh3n7M Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211356#211356 ________________________________________________________________________________
Date: Oct 31, 2008
Subject: Firestar rebuild
- I have been stripping down the Firestar wings for salvage and scrap.- I have 2 sets of wings, the original clipped wings with a "flashing" leadi ng edge, and I believe the other full length wings are-from a KX version. - The original wings had the flashing to eliminate the "starving horse" l ook.- The KX wings are signed and dated.- I can't read the signature, b ut they are marked "wing closed 1/21/89", San Angelo, Texas.- The name is "Mark" something, and about 3 other names.- I found that he had used wha t appears to be electrical tape for an interferance layer between the steel root rib, and the trailing edge.- He also used it on the "H" brace insid e the wing main tube.- It seems to have worked nicely, and maintained a s nug, cushioned fit.- Has anyone ever heard of this?- Neat trick, no sig n of electrolysis. - The original wings used a brushed on green primer for this. - ------------------------- ------------------------ Bi ll Sullivan ------------------------- ------------------------ Wi ndsor Locks, Ct. ________________________________________________________________________________
Subject: Kolb factory
Date: Oct 31, 2008
Went by the factory Wednesday 10-29-2008. At 5:00 p.m. they were closed. I know should have called, but I was traveling fast. Wow what a drop on the end of the runway. LOL.... What pretty country. Went out on the runway to capture this shot. Wayne McCullough (Kolbra 004) -------- Wish I lived in the American REPUBLIC!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211388#211388 Attachments: http://forums.matronics.com//files/kolb_factory_190.jpg ________________________________________________________________________________
Date: Oct 31, 2008
It sure looks real to me too. I've never seen a large RC aerobatic plane that doesn't use wing tubes. The plane in the vid didn't have them. I think it's incredible that he got into that spin and was able to recover from it and go on to land, whether it was RC or full-scale ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211409#211409 ________________________________________________________________________________
Date: Oct 31, 2008
At 10:02 AM 10/31/2008, you wrote: >Can anyone tell if this is real? > ><<http://www.chilloutzone.de/files/08102703.html>http://www.chilloutzone.de/files/08102703.html> > >BB > >ps, a real heartbeat stimulator whatever Maybe it is, or this flyer is sure ruining his reputation. http://www.jamesandersson.com/video01.html ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the List services at Matronics. It's through soley through the Contributions of List members that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site ( http://forums.matronics.com ), Wiki site ( http://wiki.matronics.com ), or other related pages such as the List Search Engine ( http://www.matronics.com/search ), List Browse ( http://www.matronics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisments. During the month of November I will be sending out List messages every few days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Your personal Contribution counts. Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include Bob Nuckolls of the AeroElectric Connection (http://www.aeroelectric.com/), Andy Gold of the Builder's Bookstore (http://www.buildersbooks.com/), and Jon Croke of HomebuiltHELP (http://www.homebuilthelp.com/). These are extremely generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site below: https://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years. I know it sounds a little cliche, but you guys really do feel like family. Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Kolb factory
Date: Nov 01, 2008
Kolb closes at 4 PM if I remember correctly. Its to bad you missed them, you could not find a nicer bunch of people anywhere. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211479#211479 ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Contribution Site URL Clarification
Dear Listers, In my List Fund Raiser kickoff email last night, I mistyped the URL for the *initial* Contribution web site and couple of people reported receiving SSL certificate errors. The actual payment entry pages where were correct, however, so there were no certificate issues that impacted payment data. I'm sorry for the confusion. Please use the following URL to start your List Contribution: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 01, 2008
Hi GrantR, Great pictures, I looked at the ones on Photobucket also ! What kind of performance do you get with 2 people on board ? I also notice your large trim tab on one aileron, are you aware that there is a way to adjust the incidence of the wings so that the trim tab will not be needed ? Given the angle of that trim tab, you might get a nicer flying airplane and a little better performance out of your kolb by fine tuning the incidence of the wings rather than trimming the ailerons that much. Kolb sells adjustable U joints for the rear attachment of the wings in which you can adjust the incidence with washers. I did this with my Kolb and it worked very well. On the EGT's, 1200 is right on the upper edge, much higher and you will start seizing things in the engine [Shocked] . You are correct to suspect the accuracy of the temperature readings, sometimes they can be way off. The big question is though, which was correct, the 900 or the 1200 degree readings ? Reading the plugs will help you diagnose this. I would suggest you call Lockwood aviation technical support, Kerry knows these engines very well and could give you some very good advice, and its a free call :) One thing I found, pitching the prop a bit more so that you run a couple hundred less RPM's will result in a large reduction of EGT's. Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211645#211645 ________________________________________________________________________________
Date: Nov 01, 2008
Mike, I don't know what the numbers are on the climb with 2 people on board. When i was taking lessons in my plane My instructor and I weighed in at about 325# together and the plane performed fine. We had a 3600 foot runway and we would be about 350 feet by the end of it. Takeoff roll was about 600 feet on asphalt. We also used the grass from time to time that was 2500 feet long and it was enough to clear 40 foot trees by a good margin. It climbs much better than a C 150. Flying solo here at my home base I am using the grass along the runway and it is 950 feet long. The plane is up in about 400 feet on the rough grass. Landing is about the same with no brakes. I use the whole runway and its a 6000 foot runway. I am at right around 950 when I pass the end of the runway. This is starting my climb shallow 65 IAS until about 100 agl and climbing 55 to 60 the rest of the time. I wish I could find a cheap VSI just to see what the climb rate is. My plane weights about 450# empty. Cruise rpm with 2 was 6K now solo its 53 to 5500 rpm. I weigh 155# and I have 20# ballast flying solo. The 503 on the MKIII seems to be a good match. Thanks Mike No I didn't know about the adjustable U joints. I will look into that. I think I have the egt issue resolved. I should have checked the jets 1st. the needle and the idler jet were the right size however The carbs had #145 main jets when it should have had #158s. I didn't have any jets on had so I drilled those out with a 1/16 drill bit and now egts are around 1100o. The engine is running just as good with the change. Spark plugs were not very brown from the last flight before the change. They were more of an off white color. I personally like my 2 stokes to run on the slight rich side. I put up some pictures of the egt reading from today on photobucket http://s340.photobucket.com/albums/o353/grant31781/Engine/ I am going to try those vgs that you have and see how that changes things on my plane. She handles great now but if I can get it better why not try it! Grant Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211707#211707 ________________________________________________________________________________
Subject: South LA Flying Pics - Nov 1
Date: Nov 02, 2008
Flew to DeRidder, La for the Wings and Wheels Fly-in. Took a few pics. Sorry about the haze, south Louisiana constant. Better than snow I guess. Need to get back in XC shape. Butt started hurting at two hours. -------- Thanks too much, John Bickham Mark III-C w/ 912UL St. Francisville, LA "NO FEAR" - If you have no fear you did not go as slow as you could have !!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211756#211756 Attachments: http://forums.matronics.com//files/img_1030_524.jpg http://forums.matronics.com//files/img_1032_144.jpg http://forums.matronics.com//files/img_1040_198.jpg http://forums.matronics.com//files/img_1042_688.jpg http://forums.matronics.com//files/img_1044_133.jpg ________________________________________________________________________________
Subject: Looking for input on Kolbra...flap, wing, leading edge...
Date: Nov 02, 2008
Hello Folks, I am Nick Cassara, in Palmer, Alaska. I bought the "prototype" Kolbra fuselage and wing kit that Jim Kmet was selling. Jim was kind enough to return everything to Kolb for me. Travis and crew went through and inventoried the kit, power coated some parts, and add few things and ship it a North to Alaska! Travis could not have been more patient, understanding and Helpful! I hope someday to visit Kolb. I am a student LSA pilot. I have over a thousand hours in the back seat of a supercub, doing wildlife surveys.not flying. I also work out of R-44's and C-185's, but I mostly know cubs, and cup pilots and P. A."s. I plan to add flaps to my wings, build the wing out so it flies to the end, and add 1/16" aluminum sheeting to the front of the wing, forcing all air to flow over the top ribs and support the fabric on the leading edge from contacting brush on the ground. VG's will also be on. I know that most of you folks will have some input on these changes.I have seen the photos of Miss Dixie, what a plane. but have been unable to contact Paul.Mike Welsh is going to send pictures of his wing mods.please give me your input . Thanks, Nick up North ________________________________________________________________________________
Subject: Re: Looking for input on Kolbra...flap, wing, leading edge...
Date: Nov 02, 2008
Nick I don't have a Kolbra but I built and have flown a MKIIIC for a number of years and the MKIII has the same wing. I'm not sure I understand exactly what you are planning to do to that wing but these are my thoughts and they are worth what you paid for them. Flaps are well worth putting on your plane. The benefit to landing is nothing short of incredible. Be vary careful using full flaps. I wouldn't even consider using them at the max till you are very familiar with the plane. If you build them with more notches or electric where you can work into full flaps gradually that would be even better VGs will help also. A number of people have put aluminum on the leading edge of the wing and have only had reduced performance due to the increased weight. If you are doing this for protection from brush that's fine but that is all it will do. I'm don't know what "build the wing out so it flies to the end" means. If you are talking about different wing tips you might want to look at the new MKIIIX wing tips. I understand they work well. Wing tips are a bit of black science and not very many custom wing tips help and most make things worse. Rick Neilsen Redrive VW powered MKIIIC ----- Original Message ----- From: Nick Cassara To: kolb-list(at)matronics.com Sent: Sunday, November 02, 2008 12:07 PM Subject: Kolb-List: Looking for input on Kolbra...flap, wing, leading edge... Hello Folks, I am Nick Cassara, in Palmer, Alaska. I bought the "prototype" Kolbra fuselage and wing kit that Jim Kmet was selling. Jim was kind enough to return everything to Kolb for me. Travis and crew went through and inventoried the kit, power coated some parts, and add few things and ship it a North to Alaska! Travis could not have been more patient, understanding and Helpful! I hope someday to visit Kolb. I am a student LSA pilot. I have over a thousand hours in the back seat of a supercub, doing wildlife surveys.not flying. I also work out of R-44's and C-185's, but I mostly know cubs, and cup pilots and P. A."s. I plan to add flaps to my wings, build the wing out so it flies to the end, and add 1/16" aluminum sheeting to the front of the wing, forcing all air to flow over the top ribs and support the fabric on the leading edge from contacting brush on the ground. VG's will also be on. I know that most of you folks will have some input on these changes.I have seen the photos of Miss Dixie, what a plane. but have been unable to contact Paul.Mike Welsh is going to send pictures of his wing mods.please give me your input . Thanks, Nick up North ________________________________________________________________________________
Date: Nov 02, 2008
Nick, Rick N is correct on all counts. More info on leading edge tin: for performance the unadorned stock Kolb leading edge probably has the best lift characteristics because the valleys help keep the airflow linear and attached. I wouldn't have put it on my left wing except for the fact that the already built right wing had it under a perfectly good cover. I can say that it doesn't add enough weight to be a factor and the wing is more rash-resistant. Use real T-6 aircraft aluminum, not roofing flashing. I pre-bent it at the front to take out the fight and attached it from the leading edge tube (fabric rivets to reduce the bumps) to the area over the spar. Internally a bead of clear silicone sealer alongside all the ribs keeps everything snug. BB On 2, Nov 2008, at 12:07 PM, Nick Cassara wrote: > Hello Folks, > > I am Nick Cassara, in Palmer, Alaska. I bought the =93prototype=94 > Kolbra fuselage and wing kit that Jim Kmet was selling. Jim was > kind enough to return everything to Kolb for me. > Travis and crew went through and inventoried the kit, power coated > some parts, and add few things and ship it a North to Alaska! > Travis could not have been more patient, understanding and Helpful! > I hope someday to visit Kolb. > > I am a student LSA pilot. I have over a thousand hours in the back > seat of a supercub, doing wildlife surveys=85not flying. I also work > out of R-44=92s and C-185=92s, but I mostly know cubs, and cup pilots > and P. A.=94s. > > I plan to add flaps to my wings, build the wing out so it flies to > the end, and add 1/16=94 aluminum sheeting to the front of the wing, > forcing all air to flow over the top ribs and support the fabric on > the leading edge from contacting brush on the ground. VG=92s will > also be on. > > I know that most of you folks will have some input on these changes=85 > I have seen the photos of Miss Dixie, what a plane=85 but have been > unable to contact Paul=85Mike Welsh is going to send pictures of his > wing mods=85please give me your input . > > Thanks, Nick up North ________________________________________________________________________________
Subject: Re: South LA Flying Pics - Nov 1
Date: Nov 02, 2008
Looks like your Kolb attracted more attention than any other plane on the ramp ! Mike -------- "NO FEAR" - If you have no fear you did not go as fast as you could have !!! Kolb MK-III Xtra, 912-S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211856#211856 ________________________________________________________________________________
Date: Nov 02, 2008
Howdy: Probably the high time Kolbra, until it crashed last May, with over 1600 hours, was John Williamson's. Probably the high time mkIII with 2,800+ hours, is mine. Neither John W or I saw a requirement to change Homer Kolb's wing. John W., like myself, did a lot of long cross country flying in all kinds of winds and weather. I feel obligated to voice my opinion, especialy when it comes to one inexperienced Kolb builder/pilot, following suit with modifications made by other inexperienced Kolb buider/pilots. For my own Kolbs, nothing was ever changed from the original plans until I had sufficient time flying and testing the aircraft to determine if I "really" needed to make a change. Making changes for changes sake might get you hurt, or worse. How do you know what you need if you have no experience flying a Kolb model? john h mkIII hauck's holler remote, Morgan Hill, California PS: My lap top went tits up the day I left Alabama, a month ago. Internet is far and few between for me. ;-( -------- John Hauck MKIII/912ULS hauck's holler, alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211887#211887 ________________________________________________________________________________
Date: Nov 03, 2008
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Dead Stick and other Videos
Date: Nov 03, 2008
Here's a nice pic from yesterday. Kind of big but has some nice color. New vids are coming soon... http://msirull.brinkster.net/images/kip_uncropped.jpg Regards, Kip -------- Kip Firestar II, N111KX Waiex, N111YX Quickie 1, N111QX Atlanta Read this topic online here: http://forums.matronics.com/viewtopic.php?p=212004#212004 ________________________________________________________________________________
Subject: MK III Climb performace with rotax 503
Date: Nov 03, 2008
I found out my gps keeps a lot of information that can be downloaded to my computer. I can overlay my flight track on google earth and print out an excel spreadsheet with speed, altitude, and heading. Anyway I just calculated the numbers and my average full power climb rate according to the gps during takeoff was 658 feet per minute at an average ground speed of 43.5 miles per hour. Gross weight full fuel on takeoff 735 pounds Temperature was about 65 degrees and the field elevation is around 460 MSL My average speed on my trip during cruise was 54 mph. Grant Read this topic online here: http://forums.matronics.com/viewtopic.php?p=212067#212067 ________________________________________________________________________________
Date: Nov 03, 2008
Small version... -------- Kip Firestar II, N111KX Waiex, N111YX Quickie 1, N111QX Atlanta Read this topic online here: http://forums.matronics.com/viewtopic.php?p=212076#212076 Attachments: http://forums.matronics.com//files/kip_uncropped_108.jpg ________________________________________________________________________________
Subject: Scratches in Lexan Windshield
Date: Nov 03, 2008
From: "Kirby, Dennis CTR USAF AFMC MDA/AL" <Dennis.Kirby(at)kirtland.af.mil>
Kolb Friends - I have some fairly significant scratches on the polycarbonate windshield of my Mark-3. Not so much deep scratches, but many swirls of scratches. Similar to what you'd expect if you took sand paper and wiped it across the surface. Do I need to replace the whole windshield, or can these be buffed out? I've seen products designed to remove scratches from Plexiglas. Would these same products work for Lexan? Many thanks - Dennis Kirby N93DK, 912ul, "Magic Bike" Cedar Crest, NM ________________________________________________________________________________
Subject: Re: Scratches in Lexan Windshield
Date: Nov 03, 2008
Hi Dennis, The best way to get rid of scratches would be to replace the lexan. That being said you might try "Plexis" which comes in a aerosol can. It is formulated for cleaning Plexiglas and will hide most minor scratches pretty well. An el-cheapo substitute is "Lemon Pledge" although I have heard it will cause problems with lexan over time. This is what I have been using and so far so good. Polishing and buffing will eventually remove the scratches but it takes time and if done wrong will create more problems than it will solve, dull hazy view, distortion etc. There are kits available from aircraft supply houses, "Micro Mesh" is one that comes to mind. Hope this helps Carlos G. ----- Original Message ----- From: "Kirby, Dennis CTR USAF AFMC MDA/AL" <Dennis.Kirby(at)kirtland.af.mil> Sent: Monday, November 03, 2008 12:39 PM Subject: Kolb-List: Scratches in Lexan Windshield > > > > Kolb Friends - > > I have some fairly significant scratches on the polycarbonate windshield > of my Mark-3. > Not so much deep scratches, but many swirls of scratches. Similar to > what you'd expect if you took sand paper and wiped it across the > surface. > > Do I need to replace the whole windshield, or can these be buffed out? > > I've seen products designed to remove scratches from Plexiglas. Would > these same products work for Lexan? > > Many thanks - > > Dennis Kirby > N93DK, 912ul, "Magic Bike" > Cedar Crest, NM > > > ________________________________________________________________________________
Date: Nov 03, 2008
At 03:39 PM 11/3/2008, Kirby, Dennis CTR USAF AFMC MDA/AL wrote: >I have some fairly significant scratches on the polycarbonate windshield >of my Mark-3. >Not so much deep scratches, but many swirls of scratches. Similar to >what you'd expect if you took sand paper and wiped it across the >surface. > >Do I need to replace the whole windshield, or can these be buffed out? > >I've seen products designed to remove scratches from Plexiglas. Would >these same products work for Lexan? Yes, they will work on any clear plastic. It takes a fair amount of elbow grease, though. Just the other day I used Meguire's Plast-X from the local auto parts store to make the clear face shield on my flying helmet usable again... took about a half hour of vigorous polishing. It might be easier with an electric drill with a buffing pad, I didn't try that. One thing, don't ever use paper towels to clean your windshield! Paper is abrasive and will make the kind of scratches you describe. Use only a soft cotton cloth. -Dana -- The man who would be fully employed should procure a ship or a woman, for no two things produce more trouble" - Plautus 254-184 B.C. ________________________________________________________________________________
Subject: Experimental aircraft for sale
Date: Nov 03, 2008
General: * This plan was completed from a factory kit in 2002. * It is a single place heavy ultralight which has been licensed as "Ex perimental" with an FAA "N" number. * As a "Arrow" model, it has heavy, covered wings top and bottom, a curved windshield, a curved overhead (which gives more head room), streamlined struts and larger than normal wheels and tires. * All coverd areas are covered in a Dacron material. * The CGS Hawk is purported to be extremely strong, well designed and among the most responsive of all the ultralights. It has won several ultralight flight competitions. Power System: * The engine is an extremely reliable four stroke cycle, 3 cylinder , 1998 Suzuki. * The engine develops 62 HP according to Raven Redrive specs. * The engine has 23,000 land miles on it and 34.9 hours on the plane's meter. * Most of the 34.9 hours were on the ground while installing and calibr aating the electronic fuel injection system. * A Raven Redrive reduction system is installed. * A 72", ground adjustable, IVO propeller is installed. Aircraft Specs: * Empty weight with fuel, water in radiator, oil is 500 Pounds. * Gross weight allowed 800 pounds. * The C.G. is 33.6%. The factory recommended C.G. is 32-39%. * Takeoff speed is 35 MPH. * Stall speed is 30 MPH. * Approach speed 45 MPH. * Landing speed 40-45 MPH * Climb speed is 60 MPH. * Cruise speed is 65-70 MPH. I have all the maintenance and flight logs. I also have the plans, the construction manual and annual imspection forms for this plane. I am 77 years old. My health and family concerns are my reason for selling this aircraft. I have proof that I have spent over $20,000 on this plane. I am asking $15,000, or make an offer. Phone (269)-324-5803 Call or e-mail me for more photos. R0lGODlhlgAiAPcAAIB/g4uKjpaVmKCfoqJqqqmpq7GGt7KytLu7vcTDxcWoyszMzdTT1djF29vb 3OPj4+TX5urq6+0bLe49R+9VXO/o8PBobvHx8vJ5fvOIjPSWmfWjpvavsfe6vPjFx/j4+PnQ0fr3 +vva2/zk5P3t7v729v/jrf/rxP/uz//y2f/14//47f/89v///wAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACwAAAAAlgAiAAAI/wBbCBxI sKDBgwgTKlzIsKHDhxAjSpxIsaLFixgzJqzwkGPDCx4vaDQIQiRBBCBGOqwwwcIEjygwULBAIWVE EBIkTLCZcEJOngYhAAgwtKjJkQiKBggg8gKAoyoV4vwp0EJOCRYm4vQJ1CBLnRwSLgigYAEICCAW eNSYFOUFEAJSVgDQNerBrRJS4rWAQqvPnQsnCK470AEAuwUBIEAIwAFiqVdB4JWwViAHEGERXk6r c8LAtBzMfv7Lk+NaEHQfCwSw4G5q1Xd15nWpU8NAFBp8ytbAE/dVwaRbYNCdE3AL4DZbtrQpFOrA CwsQCECwWCCKBQIKaGjdYgH3wq0VM/9+Kx3lZ+kCNBwVHb319enVIRfXnXWg1au/7eP/LaGvhv05 QfDVBGERx9NYlQ1EAAAaIKABgwIRhYACAhzWQoVQiZeUAAnOpUEADS6Y0lgEOEiUSQ0uAIAArQVA wAIKuLgQXn95NtB/PllgAo4SYNDCXhrwCJhkfYFgVUvHCVYBbRKYQJBTFQqwFEJjoeDUQSgE8N1Y zA0lQIYBEMTaQekJtCF3CIRpXQDxxSZbcALRd2Nxx+VUXwv/6XSjBhhoQFtWf9E2gW0EodagAg4i 5NRbrxVEgAADCQDpcx+K92OjFZRZ0AWSCvShTU59h6eaCNEom48toADnj8UZWdtoOqH/AIJg/E1A QZJv3jmQUAphJ2UAKS0lgGMEqTjQmAVdN+aiBE1HaYUBTCrdQGNNN50GUsonAQdHSmCbqlx91tms 4Q6EnG4T9HkfoLLZmSCXB8WoWFpPCTQWABAKVAGw3VlIJgEgNdoCiD9GucAF2HpKqooONowoZD79 +BdldSJZ1V8oHHlnbjqZkONAFegEqGDdolpYvQWhFh8I/BL04HedFjDpQWn2hbJAzlZIkAGEpvlZ AH09NFVeeOZ3X7ogcIyVcMVZkLScV/FGrgQEVOyqT6KiVhcCVT93c6Qzq3jBiwlxzShQZZJ9owEK ey0qQ3glFyiuE0ccZ92yVfXmmykh/1excS00Z1DNAnEKLHTNtimpAEHj+aSlX+dMaAtpSksq5Tdz qq1NQy9NXHHfXUDrb999/uqAYc16FXcqLjjUgq0RAKIAJT7VOs8yEqQAAAqATFS0RE06l6gE747t o52OWlCUlbZ5EG+T/wi9TUFWf9CO1qdc/WU3Jv1Z0pIV7h0C3kVnEnWsC5TWdG+vBhUKEKAPFQJQ HWyvg60hHnj7EKToHGwAHMmHAkjAAgIQOi0zoAIXiJGhRI+BEIygQ/6HEAQQyyBfkqAGJbiAErHI INiqAMIouMESImY7CTGAewxAGII0zoUmjKFDzDYQrgFLRXSBFtkSBZcLDaUs8HKgDI2HqBChLAYC k2Ic+VK1GM1JCgXU+RHOBtiCen2QiFjcFLYehqcFoHCEmdqXejLoRfT0jmXHc14Ws8ia6pBviVDs C/uiAynNXchZVUzVGvcIozJmKi22ueIHjTW8FuwLBFzTVHouUJY9YpGO1UEkGYPmAEhB0Uw1JJ93 jlKeFzryk6AMpShHScpSmlKDAQEAOw= /9j/4AAQSkZJRgABAgAAZABkAAD/7AARRHVja3kAAQAEAAAAPAAA/+4ADkFkb2JlAGTAAAAAAf/b AIQABgQEBAUEBgUFBgkGBQYJCwgGBggLDAoKCwoKDBAMDAwMDAwQDA4PEA8ODBMTFBQTExwbGxsc Hx8fHx8fHx8fHwEHBwcNDA0YEBAYGhURFRofHx8fHx8fHx8fHx8fHx8fHx8fHx8fHx8fHx8fHx8f Hx8fHx8fHx8fHx8fHx8fHx8f/8AAEQgAbwB4AwERAAIRAQMRAf/EAJoAAAEFAQEBAAAAAAAAAAAA AAADBAUGBwgCAQEBAAIDAQAAAAAAAAAAAAAAAAIEAQMFBhAAAgEDAwIEBAUCBAcAAAAAAQIDABEE EgUGITFBIhMHUWFxFIGRobEyUpJCM1MWwdFigqKyFREAAgIBAwEHAQgBBQAAAAAAAAECAxEhMQQS QVFhcSITBTLwgZGx0UJSFKHB4SMVBv/aAAwDAQACEQMRAD8A6poAoAoAoAoAoAoAJA7m1AMc7fNq wVLZOSkdvAkX/KspNkJ2Rju8FY3H3P2qIlMONsh+wb+K/mev6VsVLKVnyNa21IGf3A5HPJqgtFGv mKomo6R1NywNbFVFFWXNtk/SsF9h5Rsr4EGY2UoimUEP1Iva5vYeFV8HXjNNZJLGyIMmCPIgcSQy qGjcdiD2NYTJilAFAA7CgCgCgGuZueFhqGyJQmplRQT3eRgiKPmzMAKjKWE33GUssbT72I1cJAzy qt0jLBdR+F+tc+XyUYvDTLD4zxkgW9wrNoOAYpLHySyaTcdxbTVKXzmHhwx9/wDsc2V7i8NEfu/u RlYWMJ3iijD9IkDFnc26BR0rZT8pOzSMVnzJVznY8RRnPKPdLmsaEyRJFG4JVCZB0+BMbIf1rr13 plyzhPGrZE8D90Nm3DdjtfJMCCLNyW04WcDKYmc/xjk9SRypPgb2qdk7cZi1grQ4VDymvX4l+fkm JgeoJWwNvMRtplWFWNulhrF68+/keU21rleBUhHpeMf4FoeYR5u5NtBzYU3ExhhiIYw7IwvcKoFx aoS5vJUep5x5G19Q5+0bGEYx0GhB5QD2JFj0qs+fbL9zNeWOePbtnx7th4bTSLjlgiw6m02va1r9 qscS+x2RTk2s95Oux5waPXpS2FAA7CgCgI7d9+wdrhaXIboovpHUn6CspZIzkopt9hiXMvcKfM5N tkWNEyYxzMctrPfTMrDoPmKzbU1F+RUq5sZySS0ybGkbJqaZ1bV2RVso+pPU15/OPraf3aHecs6I hd82bZsqM7hkxPPkwrpgSNtJPjY271okq2nn6iEuJG6SjLTxKb/tbHfd03DJYt6SBcbEv5Ix4sR8 WNQr9CR2IceuL9KSPHJuMYuXiv6w6gEqPh0qzG1p5JSrU0c38kw1x8+WFBcKxBYdB0PcGu7x7OqJ 53lVdMsDdGy98xGTNyPU3GFyqTytdnj8NRPe1JT6HoYhW5oi8iXcdozYszHyHjz8BkOPIXbSoBuL X6hfkOlJdNkdtzXODj6WdV8b59jbvxfZNxukcOfEUDWu/wByvSQXHgT1F68/z+IqoR6VpkjybK4x ikiz7Mwlz8Z2AZonW0nx6+FUOPP/AJY9mpUTzJM0SvYlwKAB2FAFAZ37rYc7YYnjJAXqbURiSysG I8gl9PJwssG2mSOQH5hgatWaxOBQuizHczo/PyAkEgbugv8AhXjORPRo9rTDMkVzJzIs7cTsxa2N CqSzsDboCGUah2uap8efVLpe0Tqwqddfu/ueUiv7zj8ji5fFm7UDl7XkI33cTWsrL2KN4KfEVbtl jLS/RoxVHRdTx+Yw5XyHFx8XW03pkDzRsbsB+HhVOu7qehdjDC1MJ5hvG25UzTwEXBsB8W/6a9Hx JOK1OF8glN6EpwXE2lsUQ5+hMmYki41Gx7X+lQt5HVJm2mhQglux3zf21aPGxdzimGTjzyLFJEos 2k9rmlXJaTRG3iqbTFfZzl+x8TzN64xy5hj4kjrPDLKpZIpR0UXHmW6sPCulx5QurxL6ZHB+S40o TaXYbpsRx8iSDLhzlyIS4EDxkGNkBuNLLXm7qlC5R/i9yvBxfmanXqC0FAA7CgCgITl23rmbRMhF yFNqA5o5ZAyYksJ6NC5t8h3FWK3mJx+XDptz3nQG9P6u0DJRwrtCDb+oOtyP+NeL5i0Z7PgS9aT2 Mp4dvGfvGTvePkyrEsciSLIti7hPJpN73QhR2+NUuNXHKTe+56jnVqKg4rwJblfNYoMWXZdri05s 62hEXQqpFrMv+Fj1rozzHKaxDvORGl5TesjIeRcbyYdySHa5XkcpbMAdnAJ/xn4P8etvlSu+CXqw u4zPiznL0Z8e7zMw3OHdf9ySbXkY/wBvlYxJjW2pzfqG/pt411oyh7fXnMWcqddnvOvGJI1rivD9 u3LjGDuu4sVyEkC5MCjVdUfo+hTqHzNU1Z0JuOpclT1tKRpPNkxBxrE2vjfpzbhI8SbdADpQyagS WI7AKDetEL62/A2OuxJ95VN09ht4n23H3qSaDcuaDLfI3J8kn7DJhlNvRZLXGhfKpro8flxWiWIn Iu4cpNtyy2Otl4nufA+drt+FlOeJ7jAMnAidzIcSYMPUxyT8Ceh8RWPkVCcVKO+TicmuUHiWkvzO m421Rq3xAP5iuoti0eqyAHYUAEgUA2y2V4HS1wRagKDl8G4rkzySZe3meR+rCZ5AP7UKCsqTRrnV GeMrYndMZhSH0ozEgCohUEAAWt1v4VXfGre8UWI2yjs8DLH2DYcZzJjbVhwOb3aLHiQm/fqFrH9S r+EfwRtfNuaw5y/FjaXhvE55Xmk2jG9WX/MlRPTc/wDcmk1l8atrDisBcy3+TPMPAOJR3+1wjilu pMDt+zlxVO34iieuGn5/qXa/m+RFYymvL9MHNnvHwHcNs94tvY5vqYu5xCTEmiXTJEsflZZF7Gx8 fGjpjx6HHdGv+67eQpyfSW3iHGs/j75+fl4zT4FgVZnKxL0vIXVdTKR/SRXLlcotaZPRVwi01J4k X7iW17ckT8meIJGI2+xjI0rHHa7OFP8AEt+1V6lluXYa+TJ6Q/E++1m5cl5NxzN31t0jyNsGTPBi YQjUaYYzdWZx1LC/T5V0J8eUEsPs1ONVzIzsaa/doxTmSfdYWPnRiMZULAxyWPqBWsSi/C56G9Yn Y/ba8UU/nKGqs9zNd21zJt2LIe7wxsfxUGu9D6UUo7IcVIkA7UAzyJ2Z9CmwH8jQDD7qSRnjUsIr HS1/EeNYBVuUcq3jY0jeLAO5RuwVwl0Kg+NwHX9Kh7iTw9Cvbc4dmSrY3vttcir620Sq5LAqkkTA BTYklgnjW3DNX91dzJOD3d2bIQtjbRn5BU2KxQq36gkVL22ZXMT2jI+N7n5MkkkeFxfcJniXXIHC xALa97sDejrJq+T2iyKT3Y3ncc9MXbcXDhgdlX1ZpXZ+pAZQhCDUpPape01uI3uT0Kz7tyrNy3j+ ZllhiyQ5EBzEUlo/N0UAeLX8tcT5ZNxwvwNtkZJKaWiYcT2TK3XJLGeVNqdF1RFiBMsZ0q0v9THT e/jXA6ZN9OfM9zxuTX7XWll/6lo57uKQ8dbZMFwmZuK/Z4aqfMC4sSPotzVyqSW20Sq4OTee0zT2 nyuRcWy9z4ZnTBMN5lyoio0rIQNB0/kNQrPyPK64Jx0T3NXxnxrqtmpa4Xpf27S5crTPx9p9EZDG CJ1eKMWvYtfSWtci5rbx03S13FX/ANDl0trTvN245I0mwba7CzHGiuPnoFd+l5gvI4Ff0oka2Ezy 5tHf5UBEyObSHx61gCcwWHED9rWuflesswyBztxnT/Ig9QE2u3RVuL+a/W3hcdqpWdWdO01Ob2SI afYuO5WWu4ZO3wSZukqX0gixHVSOx/GrcF0o2KiOctajr74JaKNAijwXoLfQVLqN6gPcLOZlaO/n AuhbtesMNFF5fi7PmQTbrj4y4274jkOyCzepGQSr6bahbqDU67HsYu463F9247uu8bTt32+O+QRA 2sgXOpmv+dc3nVylNYWTofHW1quSm1qRfBOIe5m2y5Wzy7ZLHtp6YmXK0emNB4AF9Rb8K5vI4Nuc wW+5SXKspk4w9UM/ZHqb2i9xJubY++NpfHw4zHBHLLFpvJ0ZwFNwQPiKz/RudXT04b8UWKfk7PeU pr0rsLHuftBuW6mKWdIYMmNCROkhDCUfxYWBpH4216PB1/8AuYJ6ZwLZntXyjctphxc3KxBMI9E7 K8hBI7EHQKu08GcItZRzfkubC+tximmzRuN7ZPtWw4G3TyiabEhWJ5VvZiotcXroVRcYpPsORXHp ikSVbCYnL/lH6UBDyHqy/G4/OsA+bm6rtbueoVQSPxrJhmcSb/LkSrGHDQyX9MdipRrMp+l6rvR5 IcNtzafcQOZ7ibPt+LtmOJXlzs97ooUlfM5U3bt0PSp9Ta03R0HFdWuzJ0rnvMkqqBqU+Q/HwrHT LOSfVFLBV33L3Ai5SMLFSCLa5LNNkzC5APcKAw6/hW2McLV6mJ4bWF6RDdsrNwt73SF7zLnDHnjA 7XFoXHX5WpWvUauTPFbwbLwk32bDN7+U/vUnuVIbFvHasEgoAoAoAoAoD44upFAQuXGQxt3rAEM4 q2BIjDppJtWTDMN3Oabb90RvSlRWZBGrAhQGB1kWve5t9PGoyg2n3FOqTjdFrv8AzJDi+HjT7Lhp Pji8UnqY7uvfUSWZb3t5r1oy0/M69NnUm+7P5lpyN623EcLNPHG3wZgCB8xVyMG9kam13iUubj5S fcYciOP6r6lI7+FQkmtDZDbwKbzdHiytvyAt48kyKHvYEKFuAP1qUEU+VN5S7DYOBtq2PBaxF0PQ 9+9YZmOxch2rBIKAKAKAKAKAKAZZkBPnUXNARebMgx5LqAyqT+QoGYlkZPJdy5Pk4W1SM0SOJZVk YCJUYWJbUD08NIFTSWNSqpWZWGXaUTrhxHJZHylQCV410oW8bDwFa5JF+vPac985xeS4fJMqOJpp oJ3MkLRgt5D2uQT2rerpJaPQh7WXtqWjYt+n2fiuPtzK0m67nIYoVPSxlOlmci3ZaxY86liFbitV hF35nNCux7THIgOjIaMN4DVHc/tWK8FHlp6PxNL4GQdkwrCw0n96g9yUNi5DtWCQUAUAUAUAUAUA EA96Ah9/hVcCd1HXQ1/pagMc2LLMbbvIsYEnqxwI3i3Qnqfq1TSeCFEEm2TuZOBAy3uygVrkWomd 7zjY8m7rkqbOkbxv8WDWP6FahHfB0OH9f3DFdux59x2zIJsmE5kZ9VrDpYW8bsK37ZNvMWYrzJXn u+4v/wAjBiVlOrK1KT46FP8AzotjiX9hsHtpMs3HMF17aT+9QIovY7UMhQBQBQBQBQBQBQCGXF6k ZHe47d6ApWTwvZUkmaLFbGaaRZZDAx0ll6X0NcDt4VlSaC0IfduGvkxskG4PAW6kvCX/APUrWGzY plel9sc50cNuyMxHlc40lx/5VhLBvp5PRJPAhj+1M6alfd3Ia1wmKw7fNmtU5SybeRzvciklgdH2 U2DNyMabcDl5xxr+nFLKIYSWPUlYgG8PjTqeMHPlq8mqcd2aLbsWPHhjWKGIBY4kGlVUeAFRBPUA UAUAUAUAUAUAUAG3jQCUiQH+RUfUigG7wYR7un5igEzj4H+pH/cKA+jHwP8AUj/uFALxxYg7Mp/E UAuoQDy2/CgPVAFAFAFAFAFAf//Z ________________________________________________________________________________
Date: Nov 03, 2008
Also don't rub in circles. Rub in straight lines up and down that way if it scratches which it will over time it will not be as hard to see through. Use only a soft cotton cloth to clean. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=212163#212163 ________________________________________________________________________________
Date: Nov 03, 2008
Dennis I use Kit paste car wax after I have cleaned mine. I usually wet a towel and lay it on the windshield for a while to soften the bugs and not have to scrub too hard. You might check with Travis, He had Mark 3 lexan on sale at one time. Overstock I think. I keep a chamois in the plane for anytime that I have to dry the windows. Steven Green ________________________________________________________________________________
Date: Nov 03, 2008
Plexus! I love it so much I should buy the company... Kip :P --------
October 11, 2008 - November 03, 2008
Kolb-Archive.digest.vol-hu
