Pietenpol-Archive.digest.vol-ke
February 17, 2011 - March 04, 2011
      >jm
      >-----Original Message-----
      >From: Michael Perez
      >Sent: Feb 15, 2011 12:19 PM
      >To: pietenpol-list(at)matronics.com
      >Subject: Re: Pietenpol-List: 3/8" 4130 Rod
      >Thank you sir! Let me know what you find and I'll send you a mailing address.
      >Michael Perez
      >Karetaker Aero
      >www.karetakeraero.com
Subject: Re: Prince A-75 Propeller For Sale
Date: Feb 17, 2011
Steve; please email me off list if you still have the prop. Thanks. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331347#331347 ________________________________________________________________________________
Subject: Re: 3/8" 4130 Rod
Date: Feb 17, 2011
dfwplt wrote: > Pryor, OK...where it was -20F last Wednesday....today's forecast: 70F... > Are you out there making use of this nice weather? -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331357#331357 ________________________________________________________________________________
Date: Feb 17, 2011
I wish!!! Actually working this week....at least I get to work from home this week (and next)! Hope you (and everyone else....) are getting over to the hangar/your project! Jim -----Original Message----- >From: K5YAC <hangar10(at)cox.net> >Sent: Feb 17, 2011 1:04 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: 3/8" 4130 Rod > > >dfwplt wrote: >> Pryor, OK...where it was -20F last Wednesday....today's forecast: 70F... >> > > >Are you out there making use of this nice weather? > >-------- >Mark Chouinard >Wings, Center Section and Empannage framed up - Working on Fuselage > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=331357#331357 > > ________________________________________________________________________________
Subject: to the plans...
Date: Feb 17, 2011
I've been working on my wing.. leading and trailing edges.. I kept thinking the idea of 8-32 screws holding on the leading edge sounded kinda silly.. after roughly shaping it and clamping it in place a few times, it hit me.. i would need at least 28 clamps to hold that thing in place... or DUH.. do it like bernard did.. so i clamped it.. drilled it glued it then screwed it on.. the screws pull it down tight and keep it in from sliding out of place all at the same time.. looks like a wing jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331370#331370 ________________________________________________________________________________
Subject: Moving Axle Centerline
Date: Feb 18, 2011
Having read the Wynne articles in the BPA newsletter concerning landing gear and CG location where he cautions builders not to have the landing gear aft of the wing leading edge, I have the following questions: My fuselage is already built with the white ash cross struts on the floor bottom. I am planning on using the split axle gear with hydraulic brakes. How can I move the axle forward and still use the same fuselage mounting gear location for the landing gear? Can I shorten the forward landing gear tube and lengthen the rear tube? Am I missing something? Tim White (Long fuselage, C-85-12) ________________________________________________________________________________
Date: Feb 18, 2011
Subject: Re: Moving Axle Centerline
Tim: The fuselage attach points need to remain in the same locations as that is where the bracing structure is designed to accept the loads. I am just about to do the same thing that you are suggesting, i.e. shorten the front tube and lengthen the back one. This will actually mean that the front tube is transmitting more of the load to the front fuselage attachment point than before due to the change in moment arm but that has apparently not been a problem for others who have done this. Stinemetze N328X >>> 2/18/2011 9:00 AM >>> Having read the Wynne articles in the BPA newsletter concerning landing gear and CG location where he cautions builders not to have the landing gear aft of the wing leading edge, I have the following questions: My fuselage is already built with the white ash cross struts on the floor bottom. I am planning on using the split axle gear with hydraulic brakes. How can I move the axle forward and still use the same fuselage mounting gear location for the landing gear? Can I shorten the forward landing gear tube and lengthen the rear tube? Am I missing something? Tim White (Long fuselage, C-85-12) ________________________________________________________________________________
Date: Feb 18, 2011
That's what I did with my split gear, moved the axle 3" forward from the plans location. Haven't flown yet so I can't say if its good or bad. On Fri, Feb 18, 2011 at 8:21 AM, TOM STINEMETZE wrote: > *Tim:* > ** > *The fuselage attach points need to remain in the same locations as that > is where the bracing structure is designed to accept the loads. I am just > about to do the same thing that you are suggesting, i.e. shorten the front > tube and lengthen the back one. This will actually mean that the front tube > is transmitting more of the load to the front fuselage attachment point than > before due to the change in moment arm but that has apparently not been a > problem for others who have done this.* > ** > *Stinemetze* > *N328X* > > > >>> 2/18/2011 9:00 AM >>> > *Having read the Wynne articles in the BPA newsletter concerning landing > gear and CG location where he cautions builders not to have the landing gear > aft of the wing leading edge, I have the following questions: My fuselage is > already built with the white ash cross struts on the floor bottom. I am > planning on using the split axle gear with hydraulic brakes. How can I move > the axle forward and still use the same fuselage mounting gear location for > the landing gear? Can I shorten the forward landing gear tube and lengthen > the rear tube? Am I missing something?* > ** > *Tim White * > *(Long fuselage, C-85-12)* > > * > > * > > -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" ________________________________________________________________________________
Subject: Piet outdoors
Date: Feb 18, 2011
I just can't help my self. We pushed it out this afternoon. Gary Boothe you will be proud of me. I built the jury struts 100% from poplar.....really it is from a tulip tree I sawed on my homemade sawmill about 25 or 30 years ago. It looks just like poplar. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331460#331460 Attachments: http://forums.matronics.com//files/jury_srtut_130.jpg http://forums.matronics.com//files/outdoors_1080_686.jpg ________________________________________________________________________________
Subject: Rolling Steel Marbles in My Left Hand
Date: Feb 18, 2011
As most of you recall, I posted a picture of what I thought was a completed set of ribs. Jack Phillips unceremoniously pointed out that I was two ribs short. Knowing that he would never intentionally disconcert the masses, upon reading his post (Could it be?), I ran downstairs in a panic to the garage to recount. I counted that stack 3 times, but the number never changed, and, upon closer inspection, found Ribs #17 & 18 missing. The offending ribs now sit atop the stack. As to the two missing ribs themselves, mistakenly, and in haste, I quickly blamed Jim Markle.that was wrong. Upon more careful consideration, I can now prove, with irrefutable logic and mathematics, that it was the Mess Steward who took the ribs! There must have been a duplicate key, which I can also prove, but I am surrounded by incompetence, as evidenced by the fact that numerous Piet builders have been to my house, and no one has told me I was missing #'s 17 & 18. Had I been allowed more time I could prove that there is a duplicate key to my house (rolling steel marbles in my left hand)..well, of course, I'll be happy to answer any further questions. Gary Boothe Cool, Ca. WW Corvair Conversion, Running! Tail done, Fuselage on gear, RIBS DONE! ________________________________________________________________________________
Subject: Re: Piet outdoors
Date: Feb 18, 2011
He is a Yorkshire terrier 8 months old. We had an outdoor rat and mouse problem before "ABE" came on the scene. PETA would not like him. He kills every one he can find. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331478#331478 ________________________________________________________________________________
Date: Feb 19, 2011
Thanks Tom From: TOM STINEMETZE Sent: Friday, February 18, 2011 10:21 AM Subject: Re: Pietenpol-List: Moving Axle Centerline Tim: The fuselage attach points need to remain in the same locations as that is where the bracing structure is designed to accept the loads. I am just about to do the same thing that you are suggesting, i.e. shorten the front tube and lengthen the back one. This will actually mean that the front tube is transmitting more of the load to the front fuselage attachment point than before due to the change in moment arm but that has apparently not been a problem for others who have done this. Stinemetze N328X >>> 2/18/2011 9:00 AM >>> Having read the Wynne articles in the BPA newsletter concerning landing gear and CG location where he cautions builders not to have the landing gear aft of the wing leading edge, I have the following questions: My fuselage is already built with the white ash cross struts on the floor bottom. I am planning on using the split axle gear with hydraulic brakes. How can I move the axle forward and still use the same fuselage mounting gear location for the landing gear? Can I shorten the forward landing gear tube and lengthen the rear tube? Am I missing something? Tim White (Long fuselage, C-85-12) ________________________________________________________________________________
Date: Feb 19, 2011
If you think ABE might like to spend his summer vacations on a farm....let me know. Jim...on the farm. PETA: People Eating Tasty Animals -----Original Message----- >From: Jerry Dotson <jdotson(at)centurylink.net> >Sent: Feb 18, 2011 9:00 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Piet outdoors > > >He is a Yorkshire terrier 8 months old. We had an outdoor rat and mouse problem before "ABE" came on the scene. PETA would not like him. He kills every one he can find. > >-------- >Jerry Dotson >59 Daniel Johnson Rd >Baker, FL 32531 > >Started building NX510JD July, 2009 >wing, tailfeathers done, fuselage rolling >using Lycoming O-235 > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=331478#331478 > > ________________________________________________________________________________
Subject: Inspired by The Other Jack
Date: Feb 19, 2011
I think it was Jack T. who, a few weeks ago, sent the picture of his rib cutting jig..good idea! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear, RIBS DONE! ________________________________________________________________________________
Date: Feb 19, 2011
Jerry, Not grown on my property, and certainly not milled by me, but I started gluing my struts today (hickory). Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear, RIBS DONE! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jerry Dotson Sent: Friday, February 18, 2011 4:14 PM Subject: Pietenpol-List: Piet outdoors I just can't help my self. We pushed it out this afternoon. Gary Boothe you will be proud of me. I built the jury struts 100% from poplar.....really it is from a tulip tree I sawed on my homemade sawmill about 25 or 30 years ago. It looks just like poplar. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331460#331460 Attachments: http://forums.matronics.com//files/jury_srtut_130.jpg http://forums.matronics.com//files/outdoors_1080_686.jpg ________________________________________________________________________________
Date: Feb 19, 2011
Subject: Routed Spar weight
>From time to time, the question of what spars to use arises. I thought it might be useful to share a bit of data on the amount of weight saved by using routed spars. For Christmas, my family ordered spar blanks from Aircraft Spruce for me -- proving yet again how lucky I am. After several weeks of anticipation, four beautiful Sitka Spruce planks arrived. Each was 1" x 5", 14' long. I deviated from the plans in two respects. One, I decided to take advantage of the extra length and opted to add 9" to each wing. So my outer wing panels, with the attached wing tip bows, will be 14' 0.5" long. This will produce a wing that is 30' 6" from wing tip to wing tip. Two, I also opted not to reduce the spar blanks to a 4.75" by 1" rectangle, but to bevel the top edge of each to match the interior space of the ribs. As a result, my front two spars are 4.75" tall on the forward face and 5" tall on the rear face. The rear two spars are 4.875" tall on the forward face and 4.75" on the aft face. The routed sections, however, ignore the extra material at the top of each spar. That is, were I to shave off the extra area, I would still have the flanges that are specified in the plans. Please keep these deviations in mind, because they will affect the specific weight savings that others might obtain. After much trepidation and construction of a set of simple jigs, I was ready to take my router to the spar blanks. To avoid sharp transitions, I used a bull nose router bit (i.e., shaped like a capital U) to make chamfered half circles at each end of the routed sections, as well as to chamfer the full straight edge that forms the upper and lower flanges. I then used a straight router bit to eat out the wood in the interior of the chamfered race track-like sections. I followed the plans in leaving the section where the strut fittings attach unrouted (18"), the 4.5" triangle-ish outboard section, and the 7" inboard section. I also left a section of about 5.5" unrouted where the jury strut fittings will attach. With that explanation, here are the data: Pre-routed Starboard Front Spar . . . 12 lbs 9.6 oz Routed Staboard Front Spar . . . 9 lbs 10.0 oz Pre-routed Port Front Spar . . . 12 lbs 13.8 oz Routed Port Front Spar . . . 9 lbs 13.6 oz Pre-routed Starboard Rear Spar . . . 12 lbs 5.4 oz. Routed Starboard Rear Spar . . . 9 lbs 6.6 oz. Pre-routed Port Rear Spar . . . 12 lbs 6.4 oz Routed Port Rear Spar . . . 9 lbs 7.4 oz For each spar, the routing saves almost exactly 3 lbs. The reduction is from approx 50 lbs of total spar weight to approx 38 lbs of total spar weight. As for the time involved, it took me about 2 hours per spar to do the routing, plus another 15 minutes or so for each one to vacuum up the mess. There was another 2 or 3 hours of sanding inivolved. I probably spent about the same total time, pondering, worrying, and jig building before I ever touched the router to the spar blanks. Cheers, Ken ________________________________________________________________________________
Subject: Harmonic Vibrations
Date: Feb 19, 2011
I understand the need for jury struts, but was just wondering.Do wood struts have the same vibration problem that metal struts do? Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear, RIBS DONE! ________________________________________________________________________________
Date: Feb 19, 2011
Subject: Re: Harmonic Vibrations
U2FtZSBwcm9ibGVtLCBkaWZmZXJlbnQgZnJlcXVlbmNpZXMuCgpPbiBTYXQsIEZlYiAxOSwgMjAx MSBhdCA1OjA1IFBNLCBHYXJ5IEJvb3RoZSA8Z2Jvb3RoZTVAY29tY2FzdC5uZXQ+IHdyb3RlOgoK PiAgSSB1bmRlcnN0YW5kIHRoZSBuZWVkIGZvciBqdXJ5IHN0cnV0cywgYnV0IHdhcyBqdXN0IHdv bmRlcmluZ4VEbyB3b29kCj4gc3RydXRzIGhhdmUgdGhlIHNhbWUgdmlicmF0aW9uIHByb2JsZW0g dGhhdCBtZXRhbCBzdHJ1dHMgZG8/Cj4KPgo+Cj4gR2FyeSBCb290aGUKPiBDb29sLCBDYS4KPiBQ aWV0ZW5wb2wKPiBXVyBDb3J2YWlyIENvbnZlcnNpb24sIFJ1bm5pbmchCj4gVGFpbCBkb25lLCBG dXNlbGFnZSBvbiBnZWFyLCBSSUJTIERPTkUhCj4KPgo+Cj4gKgo+Cj4gXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KPiBfLT0gICAg ICAgICAgLSBUaGUgUGlldGVucG9sLUxpc3QgRW1haWwgRm9ydW0gLQo+IF8tPSBVc2UgdGhlIE1h dHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKPiBfLT0gdGhlIG1hbnkg TGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKPiBfLT0gQXJjaGl2 ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCj4gXy09IFBob3Rv c2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKPiBfLT0KPiBfLT0gICAtLT4gaHR0cDovL3d3dy5t YXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdAo+IF8tPQo+IF8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cj4gXy09 ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCj4gXy09IFNhbWUgZ3JlYXQg Y29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCj4gXy09Cj4gXy09ICAg LS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQo+IF8tPQo+IF8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cj4gXy09ICAgICAg ICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQo+IF8tPSAgVGhhbmsgeW91IGZv ciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCj4gXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgo+IF8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vY29udHJpYnV0aW9uCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KPiAqCj4KPgo ________________________________________________________________________________
Date: Feb 19, 2011
Kenneth, thanks for the detailed report on this. It agrees pretty well with my calculations on weight savings. I used =BE=94 spars without bevelled tops and routed the rear spars only, using a bullnosed router bit as you described. By my calculations I saved 3.89 lbs by routing the rear spars from =BE=94 down to =BD=94 in the middle. Obviously, using 1=94 spars you saved even more. This is the kind of good hard data that is useful to refute arguments. Jack Phillips NX899JP =93Icarus Plummet=94 Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kenneth Bickers Sent: Saturday, February 19, 2011 7:58 PM Subject: Pietenpol-List: Routed Spar weight >From time to time, the question of what spars to use arises. I thought it might be useful to share a bit of data on the amount of weight saved by using routed spars. For Christmas, my family ordered spar blanks from Aircraft Spruce for me -- proving yet again how lucky I am. After several weeks of anticipation, four beautiful Sitka Spruce planks arrived. Each was 1" x 5", 14' long. I deviated from the plans in two respects. One, I decided to take advantage of the extra length and opted to add 9" to each wing. So my outer wing panels, with the attached wing tip bows, will be 14' 0.5" long. This will produce a wing that is 30' 6" from wing tip to wing tip. Two, I also opted not to reduce the spar blanks to a 4.75" by 1" rectangle, but to bevel the top edge of each to match the interior space of the ribs. As a result, my front two spars are 4.75" tall on the forward face and 5" tall on the rear face. The rear two spars are 4.875" tall on the forward face and 4.75" on the aft face. The routed sections, however, ignore the extra material at the top of each spar. That is, were I to shave off the extra area, I would still have the flanges that are specified in the plans. Please keep these deviations in mind, because they will affect the specific weight savings that others might obtain. After much trepidation and construction of a set of simple jigs, I was ready to take my router to the spar blanks. To avoid sharp transitions, I used a bull nose router bit (i.e., shaped like a capital U) to make chamfered half circles at each end of the routed sections, as well as to chamfer the full straight edge that forms the upper and lower flanges. I then used a straight router bit to eat out the wood in the interior of the chamfered race track-like sections. I followed the plans in leaving the section where the strut fittings attach unrouted (18"), the 4.5" triangle-ish outboard section, and the 7" inboard section. I also left a section of about 5.5" unrouted where the jury strut fittings will attach. With that explanation, here are the data: Pre-routed Starboard Front Spar . . . 12 lbs 9.6 oz Routed Staboard Front Spar . . . 9 lbs 10.0 oz Pre-routed Port Front Spar . . . 12 lbs 13.8 oz Routed Port Front Spar . . . 9 lbs 13.6 oz Pre-routed Starboard Rear Spar . . . 12 lbs 5.4 oz. Routed Starboard Rear Spar . . . 9 lbs 6.6 oz. Pre-routed Port Rear Spar . . . 12 lbs 6.4 oz Routed Port Rear Spar . . . 9 lbs 7.4 oz For each spar, the routing saves almost exactly 3 lbs. The reduction is from approx 50 lbs of total spar weight to approx 38 lbs of total spar weight. As for the time involved, it took me about 2 hours per spar to do the routing, plus another 15 minutes or so for each one to vacuum up the mess. There was another 2 or 3 hours of sanding inivolved. I probably spent about the same total time, pondering, worrying, and jig building before I ever touched the router to the spar blanks. Cheers, Ken ________________________________________________________________________________
Date: Feb 19, 2011
Yes. The only real advantage wood has over metal is that wood is not subject to fatigue as metal is. But if you put the jury struts right in the center of the lift struts you can still set up devastating harmonic vibrations, where if you move the support point a few inches either way it does not allow such harmonics to develop. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Saturday, February 19, 2011 8:06 PM Subject: Pietenpol-List: Harmonic Vibrations I understand the need for jury struts, but was just wondering.Do wood struts have the same vibration problem that metal struts do? Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear, RIBS DONE! ________________________________________________________________________________
Date: Feb 19, 2011
Subject: Re: Routed Spar weight
Jack, thanks. One other way to look at this. Had I used un-routed 3/4" spars that were still beveled on top, the weight would have been just over 37.5 lbs. Mine ended up 38 lbs. The routed 1" spars are somewhat stronger than the 3/4" spars. Not a lot, but some. Cheers, Ken On Sat, Feb 19, 2011 at 6:31 PM, Jack Phillips wrot e: > Kenneth, thanks for the detailed report on this. It agrees pretty well > with my calculations on weight savings. I used =BE=94 spars without beve lled > tops and routed the rear spars only, using a bullnosed router bit as you > described. By my calculations I saved 3.89 lbs by routing the rear spars > from =BE=94 down to =BD=94 in the middle. Obviously, using 1=94 spars yo u saved even > more. > > > This is the kind of good hard data that is useful to refute arguments. > > > Jack Phillips > > NX899JP =93Icarus Plummet=94 > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Kenneth Bickers > *Sent:* Saturday, February 19, 2011 7:58 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* Pietenpol-List: Routed Spar weight > > > From time to time, the question of what spars to use arises. I thought i t > might be useful to share a bit of data on > > the amount of weight saved by using routed spars. > > > For Christmas, my family ordered spar blanks from Aircraft Spruce for me -- > proving yet again how lucky I am. After > > several weeks of anticipation, four beautiful Sitka Spruce planks > arrived. Each was 1" x 5", 14' long. > > > I deviated from the plans in two respects. One, I decided to take > advantage of the extra length and opted to add 9" to > > each wing. So my outer wing panels, with the attached wing tip bows, wil l > be 14' 0.5" long. This will produce > > a wing that is 30' 6" from wing tip to wing tip. Two, I also opted not t o > reduce the spar blanks to a 4.75" by 1" rectangle, > > but to bevel the top edge of each to match the interior space of the ribs . > As a result, my front two spars are 4.75" tall > > on the forward face and 5" tall on the rear face. The rear two spars are > 4.875" tall on the forward face and 4.75" on the > > aft face. The routed sections, however, ignore the extra material at the > top of each spar. That is, were I to shave off the > > extra area, I would still have the flanges that are specified in the > plans. Please keep these deviations in mind, because > > they will affect the specific weight savings that others might obtain. > > > After much trepidation and construction of a set of simple jigs, I was > ready to take my router to the spar blanks. To avoid > > sharp transitions, I used a bull nose router bit (i.e., shaped like a > capital U) to make chamfered half circles at each > > end of the routed sections, as well as to chamfer the full straight edge > that forms the upper and lower flanges. I then > > used a straight router bit to eat out the wood in the interior of the > chamfered race track-like sections. I followed the plans > > in leaving the section where the strut fittings attach unrouted (18"), th e > 4.5" triangle-ish outboard section, and the 7" inboard > > section. I also left a section of about 5.5" unrouted where the jury str ut > fittings will attach. > > > With that explanation, here are the data: > > > Pre-routed Starboard Front Spar . . . 12 lbs 9.6 oz Routed Staboard > Front Spar . . . 9 lbs 10.0 oz > > Pre-routed Port Front Spar . . . 12 lbs 13.8 oz Routed Port > Front Spar . . . 9 lbs 13.6 oz > > Pre-routed Starboard Rear Spar . . . 12 lbs 5.4 oz. Routed Starboar d > Rear Spar . . . 9 lbs 6.6 oz. > > Pre-routed Port Rear Spar . . . 12 lbs 6.4 oz Routed Port > Rear Spar . . . 9 lbs 7.4 oz > > > For each spar, the routing saves almost exactly 3 lbs. The reduction is > from approx 50 lbs of total spar weight to > > approx 38 lbs of total spar weight. > > > As for the time involved, it took me about 2 hours per spar to do the > routing, plus another 15 minutes or so for > > each one to vacuum up the mess. There was another 2 or 3 hours of sandin g > inivolved. I probably spent about > > the same total time, pondering, worrying, and jig building before I ever > touched the router to the spar blanks. > > > Cheers, Ken > > > * * > > * * > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Feb 20, 2011
Wing struts or wing spars Gary? Jim ----- Original Message ----- From: "Gary Boothe" <gboothe5(at)comcast.net> Sent: Saturday, February 19, 2011 4:26:19 PM Subject: RE: Pietenpol-List: Piet outdoors Jerry, Not grown on my property, and certainly not milled by me, but I started gluing my struts today (hickory). Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear, RIBS DONE! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jerry Dotson Sent: Friday, February 18, 2011 4:14 PM Subject: Pietenpol-List: Piet outdoors I just can't help my self. We pushed it out this afternoon. Gary Boothe you will be proud of me. I built the jury struts 100% from poplar.....really it is from a tulip tree I sawed on my homemade sawmill about 25 or 30 years ago. It looks just like poplar. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331460#331460 Attachments: http://forums.matronics.com//files/jury_srtut_130.jpg http://forums.matronics.com//files/outdoors_1080_686.jpg ________________________________________________________________________________
Subject: Re: Inspired by The Other Jack
Date: Feb 19, 2011
Not Jack T, I try to stay away from 1.8meg files. Nice pic though... Jack T DSM Jack Textor Sent from my iPhone On Feb 19, 2011, at 6:28 PM, "Gary Boothe" wrote: > I think it was Jack T. who, a few weeks ago, sent the picture of his rib c utting jig.good idea! > > > > Gary Boothe > Cool, Ca. > Pietenpol > WW Corvair Conversion, Running! > Tail done, Fuselage on gear, RIBS DONE! > > > > ________________________________________________________________________________
Subject: Re: Streamline Tubing
Date: Feb 19, 2011
Yes Gary, I feel I must verify Jack's integrity. He has sworn to not disparage Covair engines for another 28 days and counting and he's done an admirable job so far even though I tried to draw him out today (he's undoubtedly a better man than I). However, he hasn't sworn off declaring the CH750 as "Uglier than the box a sonex was delivered in" and I fully expect to hear about that. And when he finds himself in Australia I hope he will look me up and teach me how to fly that spam can. Back to lurking... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331589#331589 ________________________________________________________________________________
Subject: Gear strap
Date: Feb 20, 2011
Making some headway on the gear. One picture here http://textors.com/IMG_7897_800x533.jpg , others here http://textors.com/PietProject.html I do plan to cut lightening holes in the bottom strap. Still a long way to go! Jack DSM ________________________________________________________________________________
Date: Feb 20, 2011
Vic I am using a Lycoming O-235 C2C off a Yankee. I want to show as much of the engine as I can and it still look pretty good. Does anyone have any pictures of scantily cowled Piets ? I want just enough so it doesn't look UN-cowled. I have been looking on West Coast Piet. I will be running a big ol' ugly muffler on it so minimal cowl and it still looking good will be a challenge. Gary Great you got the ribs done...now put them on some spars. Where do you find hickory? Mr Markle I asked ABE about spending summers in Oklahoma and he said summers too hot. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331604#331604 Attachments: http://forums.matronics.com//files/dsc00333_111.jpg ________________________________________________________________________________
Date: Feb 20, 2011
Struts. I already have fir spars. Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Boyer Sent: Saturday, February 19, 2011 5:53 PM Subject: Re: Pietenpol-List: Piet outdoors Wing struts or wing spars Gary? Jim ----- Original Message ----- From: "Gary Boothe" <gboothe5(at)comcast.net> Sent: Saturday, February 19, 2011 4:26:19 PM Subject: RE: Pietenpol-List: Piet outdoors Jerry, Not grown on my property, and certainly not milled by me, but I started gluing my struts today (hickory). Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear, RIBS DONE! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jerry Dotson Sent: Friday, February 18, 2011 4:14 PM Subject: Pietenpol-List: Piet outdoors I just can't help my self. We pushed it out this afternoon. Gary Boothe you will be proud of me. I built the jury struts 100% from poplar.....really it is from a tulip tree I sawed on my homemade sawmill about 25 or 30 years ago. It looks just like poplar. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331460#331460 Attachments: http://forums.matronics.com//files/jury_srtut_130.jpg http://forums.matronics.com//files/outdoors_1080_686.jpg ________________________________________________________________________________
Date: Feb 20, 2011
Jerry, I live in a very small town, but am fortunate to have a local supplier who specializes in hardwood flooring. Additionally, the owner is fond of his memories of helping to build a Pitts, and seems to know what A/C grade wood should be. He personally delivered my spar material after picking them out from a wholesaler. They allow me to sort thru all the wood I need to find the best grain. Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jerry Dotson Sent: Sunday, February 20, 2011 5:51 AM Subject: Pietenpol-List: Re: Piet outdoors Vic I am using a Lycoming O-235 C2C off a Yankee. I want to show as much of the engine as I can and it still look pretty good. Does anyone have any pictures of scantily cowled Piets ? I want just enough so it doesn't look UN-cowled. I have been looking on West Coast Piet. I will be running a big ol' ugly muffler on it so minimal cowl and it still looking good will be a challenge. Gary Great you got the ribs done...now put them on some spars. Where do you find hickory? Mr Markle I asked ABE about spending summers in Oklahoma and he said summers too hot. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331604#331604 Attachments: http://forums.matronics.com//files/dsc00333_111.jpg ________________________________________________________________________________
Subject: Headlines: Wife Sacrifices Room to A/C Project
Date: Feb 20, 2011
A bit cool for Resorcinol glue, so I brought everything in to the only room left un-remodeled (sort of the 'catch all'). Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear, RIBS DONE! ________________________________________________________________________________
Date: Feb 20, 2011
Subject: Re: Gear strap
For my bottom straps I used carpenters framing squares- picked up at a ya rd sale =0A,Bernard used them on one of his ,I figured it would-be-neat , and at-1.00 each =0Awhat the heck...=0A---------- ------------------------- ------------------------- ------------------------- ------------------------- ------------------------- ------------------------- ------------------------- ------------------------- ------------------------- ------------------=0A=0A=0A____________ ____________________=0AFrom: Jack <jack(at)textors.com>=0ATo: pietenpol-list@m atronics.com=0ASent: Sun, February 20, 2011 6:56:14 AM=0ASubject: Pietenpol -List: Gear strap=0A=0AMaking some headway on the gear.- One picture here =0Ahttp://textors.com/IMG_7897_800x533.jpg , others here=0Ahttp://textors.c om/PietProject.html =0AI do plan to cut lightening holes in the bottom stra p.- Still a long way to=0Ago!=0AJack=0ADSM=0A=0A=0A ________________________________________________________________________________
Date: Feb 20, 2011
Subject: Continental A-65-8 for sale on ebay
Here is the item no. 250776562325. Engine in service on Cub now. Under 300 hrs. SMOH. 9 days to go. Of course, this is the no gen., no starter, hand-propping A-65, As of now bids just over $1000. Dallas-Ft. Worth area. I have no skin in the game on this. ________________________________________________________________________________
Subject: Re: Headlines: Wife Sacrifices Room to A/C Project
Date: Feb 20, 2011
Gary, Looks like the exercise machine is in worn out condition. I have a treadmill in same condition. Makes a good coat rack though. Do you expect to fly this year? -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331629#331629 ________________________________________________________________________________
Date: Feb 20, 2011
Yeah, that machine beckons me all the time...but I'm deaf. Think I still got another year. I just finished re-organizing the garage to make room for wings hoisted to the ceiling. Except for a couple loose ends on electric and fuel, the fuselage and tail are ready for cover. Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jerry Dotson Sent: Sunday, February 20, 2011 10:54 AM Subject: Pietenpol-List: Re: Headlines: Wife Sacrifices Room to A/C Project Gary, Looks like the exercise machine is in worn out condition. I have a treadmill in same condition. Makes a good coat rack though. Do you expect to fly this year? -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331629#331629 ________________________________________________________________________________
Subject: Finally got to Fly
Date: Feb 20, 2011
Every weekend for the past month it has been warm enough to fly in an open cockpit, but the winds were so strong that it would just not be enjoyable. For example, last Monday it was 72 degrees, but the winds were 42 knots with gusts to 60 knots, directly across the runway. No thank you. Today after church it finally seemed to be as close to perfect as I=92m likely to see for a while ' temperature 55=B0 and winds 160 at 8 knots (the runway here at Smith Mountain Lake is 5/23). So I pulled the Pietenpol out of the hangar for her first flight since November. The faithful non-Corvair started on the first blade. I back-taxied down the runway to take off on runway 23, enjoying the nice firm braking (I had bled the brakes yesterday and they are the best they=92ve ever been). I took off and set up a nice crab angle to keep me over the runway centerline and cruised out over the lake. I got as high as 800 feet AGL and enjoyed the nice crisp cool air for about 20 minutes, waving to the boat traffic on the lake, before I began to feel cold. So I turned around and headed back to the airport and entered the traffic pattern on a left crosswind for 23. As I made the left turn to downwind, I noticed that the ailerons felt VERY stiff. I tried a turn to the right ' no problem. Another turn to the left ' VERY stiff. I found I could only move the stick about 2=94 past centerline to the left, and that took quite an effort. Sphincter clinch. I needed some left aileron to handle the left crosswind. I went ahead and made the approach, and when I turned final I set up the slip to hold the crosswind. It took both hands to force the stick over far enough to compensate for the wind. I had decided that if I couldn=92t hold the crosswind with the little bit of left aileron I had available, I would go around and land on 5, where the crosswind would be from my right, but I would also have a pretty good tailwind component. Once I got near the ground, and the trees blocked some of the wind, I found I could relax a little of the pressure on the stick and actually made a nice 3-point landing. I immediately pulled into the FBO=92s ramp and got out to see what had caused the problem. What I found was that the front seatback cushion had come loose from its velcro and had fallen forward, blocking the front stick whenever I tried to use left aileron. I now have a bungee cord holding the seatback cushion in place to prevent this. The primary culprit seems to be the fact that I had not flown the airplane in so long. So as spring creeps its way north, and you get ready to fly your plane again for the first time in months, pay extra attention to all the little things that can relax or get loose over a long cold winter. Jack Phillips NX899JP =93Icarus Plummet=94 Raleigh, NC ________________________________________________________________________________
Subject: Re: Finally got to Fly
Date: Feb 20, 2011
Jack so proud you got to fly and put it up with no wrinkles in it. Murphy's law still exists! I am wanting to fly so bad and my plane is at least 2 if not 3 or 4 months away from being finished. I have to tell myself...don't get in a hurry, no shortcuts, etc so the finished product looks like I want it. Are your seat belts removable ? I have been thinking about that and what happened to you is making me think harder. 77 here right now. Just came in for a drink....building rudder pedals. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331640#331640 ________________________________________________________________________________
Date: Feb 20, 2011
Hi Jerry, No, my seatbelts are not intentionally removable. Why would you want them removable? I guess I could unbolt the front ones easily enough, but there's no reason to. Actually, the front seatbelt is usually pulled down tight over the bottom seat cushion, preventing it from doing what the seatback cushion did today. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jerry Dotson Sent: Sunday, February 20, 2011 4:45 PM Subject: Pietenpol-List: Re: Finally got to Fly Jack so proud you got to fly and put it up with no wrinkles in it. Murphy's law still exists! I am wanting to fly so bad and my plane is at least 2 if not 3 or 4 months away from being finished. I have to tell myself...don't get in a hurry, no shortcuts, etc so the finished product looks like I want it. Are your seat belts removable ? I have been thinking about that and what happened to you is making me think harder. 77 here right now. Just came in for a drink....building rudder pedals. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331640#331640 ________________________________________________________________________________
Date: Feb 20, 2011
Hi Jack,I am glad it worked out so you could get it on the ground safely, I have seat belt attach points but still have not figured out how to keep away from my big feet.. Gardiner , --- On Sun, 2/20/11, Jack Phillips wrote: > From: Jack Phillips <pietflyr(at)bellsouth.net> > Subject: RE: Pietenpol-List: Re: Finally got to Fly > To: pietenpol-list(at)matronics.com > Date: Sunday, February 20, 2011, 5:30 PM > --> Pietenpol-List message posted > by: "Jack Phillips" > > Hi Jerry, > > No, my seatbelts are not intentionally removable. Why > would you want them > removable? I guess I could unbolt the front ones > easily enough, but there's > no reason to. Actually, the front seatbelt is usually > pulled down tight > over the bottom seat cushion, preventing it from doing what > the seatback > cushion did today. > > Jack Phillips > NX899JP "Icarus Plummet" > Raleigh, NC > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] > On Behalf Of Jerry Dotson > Sent: Sunday, February 20, 2011 4:45 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Finally got to Fly > > > > Jack so proud you got to fly and put it up with no wrinkles > in it. Murphy's > law still exists! I am wanting to fly so bad and my plane > is at least 2 if > not 3 or 4 months away from being finished. I have to tell > myself...don't > get in a hurry, no shortcuts, etc so the finished product > looks like I want > it. Are your seat belts removable ? I have been thinking > about that and what > happened to you is making me think harder. 77 here right > now. Just came in > for a drink....building rudder pedals. > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > wing, tailfeathers done, fuselage rolling > using Lycoming O-235 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331640#331640 > > > > > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Feb 20, 2011
Jack the only reason I would want to remove them is from looking at cockpit pictures with the belts in a pile on the floor next to the rear rudder pedals. I am not to that point but I want them out of my way when flying solo which will most likely be 90% of the time. Gary the drink is coffee. I learned a long time ago that alcohol heightens the ambitions and lessons the performance. So whilst working on the Piet coffee and water. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331654#331654 ________________________________________________________________________________
Subject: Freaky control jams
Date: Feb 20, 2011
After reading Jack's control jam issue, I wanted to share this. In 2003 two of my sons and flew the Aeronca Sedan down to Kitty Hawk to celebrate the 100th anniversary of flight. On the way home we stopped for fuel at a mount ain strip that was down in a little valley surrounded my mountains on all s ides. My son was PIC and did a run-up and control check at the end of the r unway. He lined-up and gave her the gun. We proceeded down the runway and r ight before lift-off the engine sputtered and quit. After looking around a bit, we discovered that the mixture control had been pulled out. We had (fo r the first time) been using one of those control yoke GPS attachments that clamps onto the yoke tube. When my son was checking the controls for freed om of movement, this attachment had gotten behind the mixture control knob and inadvertently pulled it out without our knowledge. Close call for sure. One of those freaky things that can reach out and kill you................ Be careful out there!! Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Subject: Starting final assembly
Date: Feb 20, 2011
Howdy,finally done with the paint and powder coating,should have her in the air in may,dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331663#331663 Attachments: http://forums.matronics.com//files/2011_02_20_12_07_57_922_183.jpg http://forums.matronics.com//files/2011_02_20_09_52_56_821_820.jpg ________________________________________________________________________________
Date: Feb 20, 2011
Subject: Future Piet flyer
Well I couldn't resist sharing this picture of my 2 yr old "helping" me in the shop, he is sitting in the future "Ernst Kessler", bipe, Like a Piet on ly smaller......and 2 wings....and- has a weird shaped turtle deck. - Shad=0A=0A=0A ________________________________________________________________________________
Date: Feb 20, 2011
Subject: Re: Future Piet flyer
I don't think he has a weird shaped turtle deck. He looks just fine. On Sun, Feb 20, 2011 at 6:43 PM, shad bell wrote: > Well I couldn't resist sharing this picture of my 2 yr old "helping" me > in the shop, he is sitting in the future "Ernst Kessler", bipe, Like a Piet > only smaller......and 2 wings....and has a weird shaped turtle deck. > > Shad > > ________________________________________________________________________________
Date: Feb 20, 2011
Dear group, Since this topic is appropriate to my question, I will "Hijack it". I am building the Sky Scout and the landing gear calls for "Streamline tube No. 1695" for the rear landing "strut". Does anyone know the specifics of this tubing? I ordered Chromoly Streamline tubing from ACS of the correct dimensions (1.5"X3/4") but its wall thickness is only .049, the thickest they carry. This seems rather thin compared to the front tube of the landing gear which is 1.5" X 11 gauge wall thickness. I have the parts cut out but will await your sage advice before welding. Thanks in advance. Thanks and fly SAFELY, Ray Krause Waiex 51YX, Jabiru 3300 (1197), Sensenich wood prop, AeroCarb (#2 needle modified), Dynon D-180, Garmin SL 30 NavCom, Garmin 327 transponder, Garmin Aera 560, nav and strobe lights: 240 hrs., building Sky Scout. ----- Original Message ----- From: "Ken_P" <ken.potts1(at)gmail.com> Sent: Saturday, February 19, 2011 7:54 PM Subject: Pietenpol-List: Re: Streamline Tubing > > Yes Gary, > I feel I must verify Jack's integrity. He has sworn to not disparage > Covair engines for another 28 days and counting and he's done an admirable > job so far even though I tried to draw him out today (he's undoubtedly a > better man than I). > However, he hasn't sworn off declaring the CH750 as "Uglier than the box > a sonex was delivered in" and I fully expect to hear about that. > And when he finds himself in Australia I hope he will look me up and > teach me how to fly that spam can. > Back to lurking... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331589#331589 > > > ________________________________________________________________________________
Date: Feb 20, 2011
I keep my front belts out of the way when solo by twisting the shoulder harnesses around each other a few times, then buckling them to the lap belt, then drawing that tight. Keeps everything out of the way. It wouldn't be safe to fly without these belts secured, but it would be a pain to reinstall them when you wanted to take a passenger, and you might find that happening more often than you think. Ben Charvet Titusville, Florida On 2/20/2011 7:00 PM, Jerry Dotson wrote: > --> Pietenpol-List message posted by: "Jerry Dotson" > > Jack the only reason I would want to remove them is from looking at cockpit pictures with the belts in a pile on the floor next to the rear rudder pedals. I am not to that point but I want them out of my way when flying solo which will most likely be 90% of the time. > > Gary the drink is coffee. I learned a long time ago that alcohol heightens the ambitions and lessons the performance. So whilst working on the Piet coffee and water. > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > wing, tailfeathers done, fuselage rolling > using Lycoming O-235 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331654#331654 > > -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Feb 20, 2011
A good reason to implement the patented "Mike Cuy" removable front joy stick. On Sun, Feb 20, 2011 at 7:17 PM, Ben Charvet wrote: > > I keep my front belts out of the way when solo by twisting the shoulder > harnesses around each other a few times, then buckling them to the lap belt, > then drawing that tight. Keeps everything out of the way. It wouldn't be > safe to fly without these belts secured, but it would be a pain to reinstall > them when you wanted to take a passenger, and you might find that happening > more often than you think. > > Ben Charvet > Titusville, Florida > On 2/20/2011 7:00 PM, Jerry Dotson wrote: > >> --> Pietenpol-List message posted by: "Jerry Dotson"< >> jdotson(at)centurylink.net> >> >> Jack the only reason I would want to remove them is from looking at >> cockpit pictures with the belts in a pile on the floor next to the rear >> rudder pedals. I am not to that point but I want them out of my way when >> flying solo which will most likely be 90% of the time. >> >> Gary the drink is coffee. I learned a long time ago that alcohol heightens >> the ambitions and lessons the performance. So whilst working on the Piet >> coffee and water. >> >> -------- >> Jerry Dotson >> 59 Daniel Johnson Rd >> Baker, FL 32531 >> >> Started building NX510JD July, 2009 >> wing, tailfeathers done, fuselage rolling >> using Lycoming O-235 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=331654#331654 >> >> >> >> >> >> >> >> >> >> >> >> > > -- > Ben Charvet, PharmD > Staff Pharmacist > Parrish Medical center > > -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" ________________________________________________________________________________
Date: Feb 20, 2011
Subject: Aileron lacing
Did you guys rib lace your ailerons? -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" ________________________________________________________________________________
Subject: Re: Starting final assembly
Date: Feb 20, 2011
Wow, you work fast Dave. Only wish the pics were a bit smaller so that I don't have to scroll all over the screen to see what I'm supposed to be looking at. If you need tips on how to resize your photos, feel free to contact me offline at billmz (at) cox dot net. Just type in the email address in the normal format... -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331683#331683 ________________________________________________________________________________
Date: Feb 20, 2011
I've taken the liberty of resizing the images and reposting them... -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331685#331685 Attachments: http://forums.matronics.com//files/dangerdaveresized002_209.jpg http://forums.matronics.com//files/dangerdaveresized001_201.jpg ________________________________________________________________________________
From: "Amsafetyc(at)gmail.com" <amsafetyc(at)gmail.com>
Date: Feb 20, 2011
Subject: Out of town on business back on Monday
Sux being me A few pics to share Aloha John Sent via DROID on Verizon Wireless ________________________________________________________________________________
Date: Feb 20, 2011
Subject: Where's waldo any Piet builders here
80s during the day gosh I like this place Anyone building a Piet here in Hawaii Don Ho rules Aloha John Tiny bibles to all Sent via DROID on Verizon Wireless ________________________________________________________________________________
Subject: Re: Out of town on business back on Monday
Date: Feb 21, 2011
John what in the world are you doing at Pearl Harbor? Never heard of need for a safety man there. You come on home now. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331699#331699 ________________________________________________________________________________
Date: Feb 21, 2011
Hi Ray, A few years ago I had to fabricate a tailwheel bracket assembly for My Aero nca Sedan (legal because there are non available) all made out of various s izes of streamline tubing. I was faced with the same situation as you. The main strut tubing that was used in 1948 was thicker than what I could get. So I noticed that I could order the next size smaller and it would actually slide inside of the thin walled tube, with a little filing/grinding. The e nds were all welded in my assembly so nobody was the wiser. I was assured t hat the final product was as strong or stronger that the original. Don't kn ow if this trick will work for you. If not maybe you could slip some round or square tube in there and weld the two together. Dan Helsper Poplar Grove, IL -----Original Message----- From: Ray Krause <raykrause(at)frontiernet.net> Sent: Sun, Feb 20, 2011 8:06 pm Subject: Re: Pietenpol-List: Re: Streamline Tubing et> Dear group, Since this topic is appropriate to my question, I will "Hijack it". I am building the Sky Scout and the landing gear calls for "Streamline tube o. 1695" for the rear landing "strut". Does anyone know the specifics of his tubing? I ordered Chromoly Streamline tubing from ACS of the correct imensions (1.5"X3/4") but its wall thickness is only .049, the thickest hey carry. This seems rather thin compared to the front tube of the anding gear which is 1.5" X 11 gauge wall thickness. I have the parts cut ut but will await your sage advice before welding. Thanks in advance. Thanks and fly SAFELY, Ray Krause Waiex 51YX, Jabiru 3300 (1197), Sensenich wood prop, AeroCarb (#2 needle odified), Dynon D-180, Garmin SL 30 NavCom, Garmin 327 transponder, Garmin era 560, nav and strobe lights: 240 hrs., building Sky Scout. ----- Original Message ----- rom: "Ken_P" o: ent: Saturday, February 19, 2011 7:54 PM ubject: Pietenpol-List: Re: Streamline Tubing Yes Gary, I feel I must verify Jack's integrity. He has sworn to not disparage Covair engines for another 28 days and counting and he's done an admirable job so far even though I tried to draw him out today (he's undoubtedly a better man than I). However, he hasn't sworn off declaring the CH750 as "Uglier than the box a sonex was delivered in" and I fully expect to hear about that. And when he finds himself in Australia I hope he will look me up and teach me how to fly that spam can. Back to lurking... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331589#331589 -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Re: Aileron lacing
Date: Feb 21, 2011
I rib-laced mine. Dan Helsper Poplar Grove, IL. -----Original Message----- From: Rick Holland <at7000ft(at)gmail.com> Sent: Sun, Feb 20, 2011 8:41 pm Subject: Pietenpol-List: Aileron lacing Did you guys rib lace your ailerons? -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 21, 2011
Yep. They're part of the wing aren't they? Did all the tail surfaces, too. I hate it when you are diving down on the tail of a black and yellow German and suddenly hear the fabric ripping off your flying surfaces. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Sunday, February 20, 2011 9:38 PM Subject: Pietenpol-List: Aileron lacing Did you guys rib lace your ailerons? -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" ________________________________________________________________________________
Subject: Jeff Boatright
Date: Feb 21, 2011
Anyone heard from Jeff lately? JEFF, are you out there? Everything OK? Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear, RIBS DONE! ________________________________________________________________________________
Date: Feb 21, 2011
I finally took the time to patch the slow leak on the port side inner tube (thanks to John Kuhfahl for the tire patch kit!) and took Scout up yesterday. It's been windy here too, but it's good practice to fly when it's less than ideal and it turned out to be fun to go up with some gusty x-winds. Flew over to fuel up at a neighboring field and landed into what must have been a 15-18 MPH quartering headwind, landed so short that I ended up taxiing a quarter of the length of the runway just to get to the turnoff. It was great to be up flying, especially solo with a brisk wind so the airplane really climbs out. The seatbelts and shoulder harness in the front cockpit of my airplane are quickly and easily removable and I wouldn't have it any other way. They just get in the way of your feet when there is nobody up front. And a comment on AmSafety's post: that would be tiny BUBBLES, not tiny BIBLES, that Don Ho sang about. However, Bibles of any shape and size are a good thing too ;o) Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: YouTube video - working on the firewall...
Date: Feb 21, 2011
Hello list, A friend of mine (thanks Ron) took another video yesterday of my Pietenpol project. This one focuses on "engine turning" the firewall. http://www.youtube.com/user/Lakefrontseattle#p/a/u/0/q-EfkzEjQOo For clarification... I stumbled my speaking a bit when talking about the product I used to build the burnishing tool. It's called "Cratex" and is available at places that sell machining supplies. I bought a couple sticks local here in Seattle. The largest size is a 2" x 1" x 6" rectangular bar and it is part number 6168C. (Also available online - for example: http://www.grithappens.com/products.php?m=cratex&mid=25&cat=390) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331718#331718 ________________________________________________________________________________
Subject: Re: Jeff Boatright
Date: Feb 21, 2011
I know that he is alive, but don't ask me how I know. LOL! Surely he'll be around to say howdy. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331727#331727 ________________________________________________________________________________
Date: Feb 21, 2011
Beats the heck out of your CRANK SNAPPIN. Easy Jack. Jack DSM _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Monday, February 21, 2011 6:54 AM Subject: RE: Pietenpol-List: Aileron lacing Yep. They're part of the wing aren't they? Did all the tail surfaces, too. I hate it when you are diving down on the tail of a black and yellow German and suddenly hear the fabric ripping off your flying surfaces. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Sunday, February 20, 2011 9:38 PM Subject: Pietenpol-List: Aileron lacing Did you guys rib lace your ailerons? -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: YouTube video - working on the firewall...
Date: Feb 21, 2011
Thanks Jack.... having' lots of fun - this building a plane thing...! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331782#331782 ________________________________________________________________________________
Date: Feb 21, 2011
Thanks, Dan. But we do not know what the No. 1695 dimensions were, right? What does the Air Camper recommend as far as Streamline tubing goes? Ray Krause ----- Original Message ----- From: helspersew(at)aol.com To: pietenpol-list(at)matronics.com Sent: Monday, February 21, 2011 4:40 AM Subject: Re: Pietenpol-List: Re: Streamline Tubing Hi Ray, A few years ago I had to fabricate a tailwheel bracket assembly for My Aeronca Sedan (legal because there are non available) all made out of various sizes of streamline tubing. I was faced with the same situation as you. The main strut tubing that was used in 1948 was thicker than what I could get. So I noticed that I could order the next size smaller and it would actually slide inside of the thin walled tube, with a little filing/grinding. The ends were all welded in my assembly so nobody was the wiser. I was assured that the final product was as strong or stronger that the original. Don't know if this trick will work for you. If not maybe you could slip some round or square tube in there and weld the two together. Dan Helsper Poplar Grove, IL -----Original Message----- From: Ray Krause <raykrause(at)frontiernet.net> To: pietenpol-list Sent: Sun, Feb 20, 2011 8:06 pm Subject: Re: Pietenpol-List: Re: Streamline Tubing Dear group, Since this topic is appropriate to my question, I will "Hijack it". I am building the Sky Scout and the landing gear calls for "Streamline tube No. 1695" for the rear landing "strut". Does anyone know the specifics of this tubing? I ordered Chromoly Streamline tubing from ACS of the correct dimensions (1.5"X3/4") but its wall thickness is only .049, the thickest they carry. This seems rather thin compared to the front tube of the landing gear which is 1.5" X 11 gauge wall thickness. I have the parts cut out but will await your sage advice before welding. Thanks in advance. Thanks and fly SAFELY, Ray Krause Waiex 51YX, Jabiru 3300 (1197), Sensenich wood prop, AeroCarb (#2 needle modified), Dynon D-180, Garmin SL 30 NavCom, Garmin 327 transponder, Garmin Aera 560, nav and strobe lights: 240 hrs., building Sky Scout. ----- Original Message ----- From: "Ken_P" <ken.potts1(at)gmail.com> Sent: Saturday, February 19, 2011 7:54 PM Subject: Pietenpol-List: Re: Streamline Tubing > > Yes Gary, > I feel I must verify Jack's integrity. He has sworn to not disparage > Covair engines for another 28 days and counting and he's done an admirable > job so far even though I tried to draw him out today (he's undoubtedly a > better man than I). > However, he hasn't sworn off declaring the CH750 as "Uglier than the box > a sonex was delivered in" and I fully expect to hear about that. > And when he finds himself in Australia I hope he will look me up and > teach me how to fly that spam can. > Back to lurking... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331589#331589 > > > " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Chrome Moly 4130 for straight axle?
Date: Feb 22, 2011
Hi all....just to confirm in my head before I place the order. We are using 4130 Chrome Moly tube for the straight axle? Regards Scotty -------- Scotty Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331795#331795 ________________________________________________________________________________
Subject: Re: Chrome Moly 4130 for straight axle?
Date: Feb 22, 2011
That is correct. Use 4130 for the axle. Greg Cardinal ----- Original Message ----- From: "bubbleboy" <scott.dawson3(at)bigpond.com> Sent: Tuesday, February 22, 2011 4:34 AM Subject: Pietenpol-List: Chrome Moly 4130 for straight axle? > > > Hi all....just to confirm in my head before I place the order. We are > using 4130 Chrome Moly tube for the straight axle? > > Regards Scotty > > -------- > Scotty > > Tamworth, Australia > Building a Corvair Powered Pietenpol Air Camper > > www.scottyspietenpol.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331795#331795 > > > ________________________________________________________________________________
Date: Feb 22, 2011
Thanks Greg! -------- Scotty Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331800#331800 ________________________________________________________________________________
Date: Feb 22, 2011
I used 0.188" wall 4130. I think the plans call for 0.120" wall. The axles extend beyond the bungees for brakes and just to get a little more width on the gear. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331801#331801 ________________________________________________________________________________
Subject: Piqua, OH Airport
Date: Feb 22, 2011
FYI. At last weeks local EAA meeting I learned that this summer the Piqua Airport - Hartzell Field will build a 2400' X 90' grass runway in hopes of attracting more tail draggers. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331804#331804 ________________________________________________________________________________
Subject: Piet outdoors
Date: Feb 22, 2011
Jerry wrote: >I want to show as much of the engine as I can and it >still look pretty good. Does anyone have any pictures >of scantily cowled Piets? You bet. Look here: http://www.rotecradialengines.com/0DickNavratil/15-3DickAtOsh07.htm That's about as scantily clad as Madonna in her infamous book. You knew somebody was going to do that, didn't you? ;o) By the way, I have flown Scout without the engine cowlings on it and I can tell you from personal experience that it changes the glide profile on final approach to basically that of a ship's anchor as it drops. Honestly, it scared me when I pulled the power off. I don't know if Dick's plane drops like mine did but I'll bet it does and I'll bet he has to carry power all the way into the flare or it will turn into a plow. Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Feb 22, 2011
Subject: seat belt and cushions
Another reason not to have seat cushions. :) Kidding Jack-glad you s wapped runways for more favorable control authority. During preflight I make sure my front seat belt is wrapped and buckled arou nd the control cables that run along the right side of the top right longeron to keep it out of my rudder bar area. My front seat bottom is velcro'ed to the frame so as a routine I will pop t hat off to make sure there are no golf balls, beer cans, toy trucks, or snakes sitting down there-plus makes sure the fastners are i n place before flight. Mike C. Glad you got to fly Jack ! We had 3.5" of snow last night after a wond erful thaw where we could even see the GRASS again ! Twas not to last. ________________________________________________________________________________
Subject: Journey to the Groahs'
Date: Feb 22, 2011
Yesterday, Sacramento area Pietenpol builders Mike Weaver, Chris Tracy and I made a 4-hr drive south to Tulare Ca., to see Mike and Vic Groah. Their Piet is just about ready for cover! But when you go to see the Groah's, that just the beginning! To start things off, Mike & Vic's wives fixed a fantastic lunch of BBQ beef sandwiches, potato salad, macaroni salad, etc! Amazed at the loveliness of the corvair engine, Chris is speechless! FYI.We had 'them' outnumbered 3-1!. Mike and his dad are just about ready to dismantle their Pietenpol for cover. Chris & Mike.jpg Near-convert, Chris Tracy, demonstrates the starting procedure on a corvair powered Pietenpol. Starting a Corvair.jpg Vic is a retired HS auto shop teacher. He loves really old cars, and every year, at his expense, he would bring a car to the class to restore. This is a 1912 Kissel, restored 25 years ago, and still gets blue ribbons as you can see.2010 Best in Class! 1912 Kissel.jpg Typical of the generosity of the Groahs', and Pietenpol builders in general, Mike Weaver left with four wing struts (from a Citabria) that were part of a bulk buy that the Mike & Vic lucked upon. They merely wanted to pass their good fortune on to another builder! Gary Boothe ________________________________________________________________________________
Subject: Re: Piet outdoors
Date: Feb 22, 2011
Hey Oscar I have two Piets so I can tell you I really don't notice the difference very much. You are right though, I carry power into landing till I am on the ground. But I do that with my A-65 Piet also. Dick N. ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Tuesday, February 22, 2011 7:46 AM Subject: Pietenpol-List: Piet outdoors Jerry wrote: >I want to show as much of the engine as I can and it >still look pretty good. Does anyone have any pictures >of scantily cowled Piets? You bet. Look here: http://www.rotecradialengines.com/0DickNavratil/15-3DickAtOsh07.htm That's about as scantily clad as Madonna in her infamous book. You knew somebody was going to do that, didn't you? ;o) By the way, I have flown Scout without the engine cowlings on it and I can tell you from personal experience that it changes the glide profile on final approach to basically that of a ship's anchor as it drops. Honestly, it scared me when I pulled the power off. I don't know if Dick's plane drops like mine did but I'll bet it does and I'll bet he has to carry power all the way into the flare or it will turn into a plow. Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Journey to the Groahs'
Date: Feb 22, 2011
Looks/sounds like a good time. Thanks for sharing! -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331831#331831 ________________________________________________________________________________
Date: Feb 22, 2011
Really nice. How did your fuselage door work out? ~ Keri-Ann Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331838#331838 ________________________________________________________________________________
Date: Feb 22, 2011
Jerry, There is a red piet on the westcoastpiet.com site that has a very bare cowl. To continue Oscar's analogy, it's more like a nekkid lady in any issue of Playboy. I kinda like it, but the guy certainly has cylinder temp issues because he doesn't have eyebrows on the engine - you MUST put eyebrows on your slow moving Piet if you don't have a pressure cowl. Heh. I think I just came up with a name for your Piet: Hot 'n Bothered. Here's the plane I'm thinking of: http://westcoastpiet.com/images/Red%20One/images/45_red_piet.jpg This Piet made it to the MAAC Grassroots fly-in this past year and from what I can tell it had either a new engine or it was completely overhauled recently, probably because he burned out the old one. And yes, he still didn't have eyebrows on the cylinders (see attached photo). The only plane with an A-65 that goes fast enough to not require eyebrows or a pressure cowl is the Mooney Mite, and that's because it cruises at 125mph and there's plenty of air moving over the cylinders at that speed. Cheers! Dan On 02/22/2011 07:46 AM, Oscar Zuniga wrote: > --> Pietenpol-List message posted by: Oscar Zuniga > > > Jerry wrote: > >> I want to show as much of the engine as I can and it >> still look pretty good. Does anyone have any pictures >> of scantily cowled Piets? > > You bet. Look here: > > http://www.rotecradialengines.com/0DickNavratil/15-3DickAtOsh07.htm > > That's about as scantily clad as Madonna in her infamous book. > > You knew somebody was going to do that, didn't you? ;o) > By the way, I have flown Scout without the engine cowlings on it > and I can tell you from personal experience that it changes the > glide profile on final approach to basically that of a ship's > anchor as it drops. Honestly, it scared me when I pulled > the power off. I don't know if Dick's plane drops like mine > did but I'll bet it does and I'll bet he has to carry power > all the way into the flare or it will turn into a plow. > > Oscar Zuniga > Air Camper NX41CC "Scout" > San Antonio, TX > website at http://www.flysquirrel.net > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Feb 22, 2011
"Amazed at the loveliness of the corvair engine, Chris is speechless." I too am speechless. For 24 more days. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gboothe5 Sent: Tuesday, February 22, 2011 10:20 AM Subject: Pietenpol-List: Journey to the Groahs' Yesterday, Sacramento area Pietenpol builders Mike Weaver, Chris Tracy and I made a 4-hr drive south to Tulare Ca., to see Mike and Vic Groah. Their Piet is just about ready for cover! But when you go to see the Groah's, that just the beginning! To start things off, Mike & Vic's wives fixed a fantastic lunch of BBQ beef sandwiches, potato salad, macaroni salad, etc! Amazed at the loveliness of the corvair engine, Chris is speechless! FYI.We had 'them' outnumbered 3-1!. Mike and his dad are just about ready to dismantle their Pietenpol for cover. Chris & Mike.jpg Near-convert, Chris Tracy, demonstrates the starting procedure on a corvair powered Pietenpol. Starting a Corvair.jpg Vic is a retired HS auto shop teacher. He loves really old cars, and every year, at his expense, he would bring a car to the class to restore. This is a 1912 Kissel, restored 25 years ago, and still gets blue ribbons as you can see.2010 Best in Class! 1912 Kissel.jpg Typical of the generosity of the Groahs', and Pietenpol builders in general, Mike Weaver left with four wing struts (from a Citabria) that were part of a bulk buy that the Mike & Vic lucked upon. They merely wanted to pass their good fortune on to another builder! Gary Boothe ________________________________________________________________________________
Date: Feb 22, 2011
Date: Feb 22, 2011
The door is wonderful !!! I would not be able to get my six foot three inc h bad back self into the plane without it. I would recommend it to anyone building a Piet. Even if you are young and limber you may want to take mom or dad for a ride. It is the way to go. The weight gain is not great but the convenience is well worth it. Vic 414MV > Subject: Pietenpol-List: Re: Journey to the Groahs' > From: keriannprice(at)hotmail.com > Date: Tue=2C 22 Feb 2011 10:32:39 -0800 > To: pietenpol-list(at)matronics.com > om> > > Really nice. How did your fuselage door work out? > > ~ Keri-Ann > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331838#331838 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Feb 22, 2011
That one belongs to Jack Reber of the Anderson, IN area, an old friend of mine. That plane has been flying for about 40 years with a recover around 1991-92. Jack originally had a Model-A on it and switched over to the Continental in the last few years. He also built a Sky Scout a couple of years ago. He is a really great guy and I almost always run into him at the Pietenpol flyin. I think when he flew to Brodhead for Grassroots it was the first time he had the plane up here. If you get a chance to talk to him it is worth the time. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Feb 22, 2011, at 12:09 PM, Dan Yocum wrote: > Jerry, > > There is a red piet on the westcoastpiet.com site that has a very bare cowl. To continue Oscar's analogy, it's more like a nekkid lady in any issue of Playboy. I kinda like it, but the guy certainly has cylinder temp issues because he doesn't have eyebrows on the engine - you MUST put eyebrows on your slow moving Piet if you don't have a pressure cowl. > > Heh. I think I just came up with a name for your Piet: Hot 'n Bothered. > > Here's the plane I'm thinking of: > > http://westcoastpiet.com/images/Red%20One/images/45_red_piet.jpg > > This Piet made it to the MAAC Grassroots fly-in this past year and from what I can tell it had either a new engine or it was completely overhauled recently, probably because he burned out the old one. And yes, he still didn't have eyebrows on the cylinders (see attached photo). > > The only plane with an A-65 that goes fast enough to not require eyebrows or a pressure cowl is the Mooney Mite, and that's because it cruises at 125mph and there's plenty of air moving over the cylinders at that speed. > > Cheers! > Dan > > > > On 02/22/2011 07:46 AM, Oscar Zuniga wrote: >> --> Pietenpol-List message posted by: Oscar Zuniga >> >> >> Jerry wrote: >> >>> I want to show as much of the engine as I can and it >>> still look pretty good. Does anyone have any pictures >>> of scantily cowled Piets? >> >> You bet. Look here: >> >> http://www.rotecradialengines.com/0DickNavratil/15-3DickAtOsh07.htm >> >> That's about as scantily clad as Madonna in her infamous book. >> >> You knew somebody was going to do that, didn't you? ;o) >> By the way, I have flown Scout without the engine cowlings on it >> and I can tell you from personal experience that it changes the >> glide profile on final approach to basically that of a ship's >> anchor as it drops. Honestly, it scared me when I pulled >> the power off. I don't know if Dick's plane drops like mine >> did but I'll bet it does and I'll bet he has to carry power >> all the way into the flare or it will turn into a plow. >> >> Oscar Zuniga >> Air Camper NX41CC "Scout" >> San Antonio, TX >> website at http://www.flysquirrel.net >> >> >> >> > > -- > Dan Yocum > Fermilab 630.840.6509 > yocum@fnal.gov, http://fermigrid.fnal.gov > "I fly because it releases my mind from the tyranny of petty things." > ________________________________________________________________________________
Date: Feb 22, 2011
Gary=2C Mike and I are so happy you chose to make the long trip to our place in Tul are. It was a great thing for us to have you come. We both cherish the as sociation and friendship that comes from the mutual interest of our joint h obby. We have found the people in the Piet group to be super friendly and a great help to us in our building of this plane. Each person brings ideas and suggestions that make our project better. Even the aircraft engine on ly guys have good ideas. They just don't think out of the box as much. We welcome any of you Piet guys and gals to come and visit our humble shop and effort. We love sharing and hope to come to some of the other guys sho ps in the future. There are other Piet people not too far away that have n ot come=2C at least recently we would like to open the door to. Thanks again to Mike=2C Chris and Gary for coming to Tulare. We loved the visit a lot. Vic and Mike Ps We have more of those used struts available. VG ________________________________________________________________________________
Date: Feb 22, 2011
Subject: contributions
I haven't heard anything on how well the Pietenpol list is contributing to help out at Brodhead. Ted Stone ________________________________________________________________________________
Date: Feb 22, 2011
The other Piet with an "exposed" engine that comes to mind Alan Wise's N3513, which is now housed at the Sun n Fun museum. It leaves a little more to the imagination than the Red Piet previously mentioned, and has (brass) cooling eyebrows. http://www.westcoastpiet.com/images/n3513/images/IMG_1071.jpg Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331850#331850 ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Date: Feb 22, 2011
Are there any plans for the door? If so, how can I get a set? I might be able to incorporate it -- I'm not that far along -- don't have the 1/8th in. plywood on the sides yet. ----- Original Message ----- From: V Groah To: piet list Sent: Tuesday, February 22, 2011 1:48 PM Subject: RE: Pietenpol-List: Re: Journey to the Groahs' The door is wonderful !!! I would not be able to get my six foot three inch bad back self into the plane without it. I would recommend it to anyone building a Piet. Even if you are young and limber you may want to take mom or dad for a ride. It is the way to go. The weight gain is not great but the convenience is well worth it. Vic 414MV > Subject: Pietenpol-List: Re: Journey to the Groahs' > From: keriannprice(at)hotmail.com > Date: Tue, 22 Feb 2011 10:32:39 -0800 > To: pietenpol-list(at)matronics.com > > > Really nice. How did your fuselage door work out? > > ~ Keri-Ann > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331838#331838 > > = Archive Search & Download, 7-Day Browse, Chat, FAQ, &g==================== > _==== > > > ________________________________________________________________________________
Date: Feb 22, 2011
John, Do you have a contact for Jack Reber? If he built a Sky Scout, I would like to ask him some questions. Thanks and fly SAFELY, Ray Krause Waiex 51YX, Jabiru 3300 (1197), Sensenich wood prop, AeroCarb (#2 needle modified), Dynon D-180, Garmin SL 30 NavCom, Garmin 327 transponder, Garmin Aera 560, nav and strobe lights: 240 hrs., building a Sky Scout. ----- Original Message ----- From: John Hofmann To: pietenpol-list(at)matronics.com Sent: Tuesday, February 22, 2011 11:01 AM Subject: Re: Pietenpol-List: Piet outdoors That one belongs to Jack Reber of the Anderson, IN area, an old friend of mine. That plane has been flying for about 40 years with a recover around 1991-92. Jack originally had a Model-A on it and switched over to the Continental in the last few years. He also built a Sky Scout a couple of years ago. He is a really great guy and I almost always run into him at the Pietenpol flyin. I think when he flew to Brodhead for Grassroots it was the first time he had the plane up here. If you get a chance to talk to him it is worth the time. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Feb 22, 2011, at 12:09 PM, Dan Yocum wrote: Jerry, There is a red piet on the westcoastpiet.com site that has a very bare cowl. To continue Oscar's analogy, it's more like a nekkid lady in any issue of Playboy. I kinda like it, but the guy certainly has cylinder temp issues because he doesn't have eyebrows on the engine - you MUST put eyebrows on your slow moving Piet if you don't have a pressure cowl. Heh. I think I just came up with a name for your Piet: Hot 'n Bothered. Here's the plane I'm thinking of: http://westcoastpiet.com/images/Red%20One/images/45_red_piet.jpg This Piet made it to the MAAC Grassroots fly-in this past year and from what I can tell it had either a new engine or it was completely overhauled recently, probably because he burned out the old one. And yes, he still didn't have eyebrows on the cylinders (see attached photo). The only plane with an A-65 that goes fast enough to not require eyebrows or a pressure cowl is the Mooney Mite, and that's because it cruises at 125mph and there's plenty of air moving over the cylinders at that speed. Cheers! Dan On 02/22/2011 07:46 AM, Oscar Zuniga wrote: --> Pietenpol-List message posted by: Oscar Zuniga Jerry wrote: I want to show as much of the engine as I can and it still look pretty good. Does anyone have any pictures of scantily cowled Piets? You bet. Look here: http://www.rotecradialengines.com/0DickNavratil/15-3DickAtOsh07.htm That's about as scantily clad as Madonna in her infamous book. You knew somebody was going to do that, didn't you? ;o) By the way, I have flown Scout without the engine cowlings on it and I can tell you from personal experience that it changes the glide profile on final approach to basically that of a ship's anchor as it drops. Honestly, it scared me when I pulled the power off. I don't know if Dick's plane drops like mine did but I'll bet it does and I'll bet he has to carry power all the way into the flare or it will turn into a plow. Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Feb 22, 2011
Date: Feb 22, 2011
Yes=2C there is a great set of well engineered plans available at a reasona ble cost. I will have Mike post the source for you. I do not have it righ t now. Vic From: cncampbell(at)windstream.net Subject: Re: Pietenpol-List: Re: Journey to the Groahs' Date: Tue=2C 22 Feb 2011 15:41:23 -0500 Are there any plans for the door? If so=2C how can I get a set? I might b e able to incorporate it -- I'm not that far along -- don't have the 1/8th in. plywood on the sides yet. ----- Original Message ----- From: V Groah Sent: Tuesday=2C February 22=2C 2011 1:48 PM Subject: RE: Pietenpol-List: Re: Journey to the Groahs' The door is wonderful !!! I would not be able to get my six foot three inc h bad back self into the plane without it. I would recommend it to anyone building a Piet. Even if you are young and limber you may want to take mom or dad for a ride. It is the way to go. The weight gain is not great but the convenience is well worth it. Vic 414MV > Subject: Pietenpol-List: Re: Journey to the Groahs' > From: keriannprice(at)hotmail.com > Date: Tue=2C 22 Feb 2011 10:32:39 -0800 > To: pietenpol-list(at)matronics.com > om> > > Really nice. How did your fuselage door work out? > > ~ Keri-Ann > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331838#331838 > > = Archive Search & Download=2C 7-Day Browse=2C Chat=2C FAQ=2C &g==================== > _==== > > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Feb 22, 2011
Thanks for the links. I think the more engine that shows the more it looks like and old design. I will make eyebrows for sure. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331872#331872 ________________________________________________________________________________
Date: Feb 22, 2011
I would like to make a journey over some day to see. I have been following the boards here for several years and still never actually seen a Piet. I am out of Colorado, but currently working in Paso Robles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331890#331890 ________________________________________________________________________________
Date: Feb 22, 2011
You REALLY need to see a Pietenpol up close! Your life may never be the same again! It's a short drive for you to Tulare, and you can contact Mike or Vic directly at: vgroah(at)hotmail.com, dskogrover(at)yahoo.com. Have fun... Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of regchief Sent: Tuesday, February 22, 2011 6:11 PM Subject: Pietenpol-List: Re: Journey to the Groahs' I would like to make a journey over some day to see. I have been following the boards here for several years and still never actually seen a Piet. I am out of Colorado, but currently working in Paso Robles Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331890#331890 ________________________________________________________________________________
Date: Feb 23, 2011
Subject: How fast can you build it?
I'm into year 6 on my Piet project. Could you believe it possible to turn out a new B-24 every 55 minutes? Here's a bit of aviation nostalgia to help you kill some time. Stinemetze N328X http://xa.yimg.com/kq/groups/15654030/1604819366/name/bomber_plant.wmv Henry Ford was determined that he could mass produce bombers just as he had done with cars. He built the Willow Run assembly plant and proved it. It was the world's largest building under one roof. even then FORD HAD A BETTER IDEA! This film will absolutely blow you away - one B-24 every55 minutes. ADOLF HITLER HAD NO IDEA THE U.S. WAS CAPABLE OF THIS KIND OF THING. There is no way he could have even guessed. For those who live outside of Michigan, Willow Run is near Bellville, Canton and Ypsilanti, MI It's amazing that one B-24 (built with over 1.225 million parts) came off the assembly line every 55 minutes Take a few minutes to watch this snapshot of history. ________________________________________________________________________________
Date: Feb 23, 2011
I went down to see Mike and Vic's Piet a couple weeks ago. Its was incredibly helpfully. I will be starting the project soon, but the visit changed the entire direction of the build for me and my buddy. The project is beautiful and they are two of the nicest guys you will meet. I was hoping to make it down again last Monday to meet the other California builders but could not make it. Maybe I will see you at Frazier... Mike Prunedale Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331937#331937 ________________________________________________________________________________
Date: Feb 23, 2011
Subject: Good morning off topic
I wanted to share this with all my friends as there is nothing more exciting or stirring to the soul than the view this morning to charge the batteries. Enjoy this with me today John Sent via DROID on Verizon Wireless ________________________________________________________________________________
Date: Feb 23, 2011
Subject: Jake's gorgeous engine-turning aluminum firewall results
and You Tube video EXCELLENT looking firewall Jake and front instrument panel and great tip ab out how you determined what was the best burnishing material and how you fabricated/ assembled your dri ll press tooling for that and fixturing. http://www.youtube.com/user/Lake frontseattle#p/a/u/0/q-EfkzEjQOo Great looking project with your Rotec Radial engine ! Can't wait to see you take a Lindy Award when you bring that thing to Oshko sh ! Mike C. Ohio ________________________________________________________________________________
and You Tube video
Date: Feb 23, 2011
Yep. Certainly looks good, Jake. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] Sent: Wednesday, February 23, 2011 2:48 PM Subject: Pietenpol-List: Jake's gorgeous engine-turning aluminum firewall results and You Tube video EXCELLENT looking firewall Jake and front instrument panel and great tip about how you determined what was the best burnishing material and how you fabricated/ assembled your drill press tooling for that and fixturing. http://www.youtube.com/user/Lakefrontseattle#p/a/u/0/q-EfkzEjQOo Great looking project with your Rotec Radial engine ! Can't wait to see you take a Lindy Award when you bring that thing to Oshkosh ! Mike C. Ohio ________________________________________________________________________________
Subject: Re: How fast can you build it?
Date: Feb 23, 2011
Thats funny- I was just looking a pictures from Willow Run- My grandfather was in charge of B-24 production during the war. I'll see if i can get some picts scanned and posted -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331960#331960 ________________________________________________________________________________
Subject: Just hangin around the airport yesterday
Date: Feb 23, 2011
When this came bombing in. A one of a kind Piranha owned and piloted by M.D. Pinkston. Just passin through the Ozarks with a Harmon Rocket and an RV-8 on thier way back to western Kansas. I asked him, of course, how fast it would go. He said "all depends on how much gas you want to use. Stall speed? About 130 mph. I googled it and found these specs: Lycoming 180 hp, empty weight 900 pounds, gross weight 3200 pounds, g-rated +- 16, fuel cap 60 gallons. Original prototype built by American Electric for the military and only 6 or 7 more were produced, all which were destroyed by the military but since this one belonged to A.E., it survived. I know it has nothing to do with low and slow, wood and fabric, Model A or Corvair but damn....... [Shocked] P.S. I think Pinkston is at least 80 years old and has over 35,000 hrs. None of which were airline hours. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331974#331974 Attachments: http://forums.matronics.com//files/piranha_140.jpg ________________________________________________________________________________
Subject: Re: Continental A-65-8 for sale on ebay
Date: Feb 24, 2011
Wow! I am selling my Franklins to cheap! [quote="timwillis01(at)gmail.com"]Here is the item no. 250776562325. Engine in service on Cub now. Under 300 hrs. SMOH. 9 days to go. Of course, this is the no gen., no starter, hand-propping A-65, As of now bids just over $1000. Dallas-Ft. Worth area. I have no skin in the game on this. > [b] [Exclamation] -------- Blue Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332009#332009 ________________________________________________________________________________
Subject: Re: Jake's gorgeous engine-turning aluminum firewall results
and
Date: Feb 24, 2011
Fun stufffff.... thanks...... Clarification, however, I am using stainless steel for my firewall and instrument panels. It should hold up better and my experiments with burnishing aluminum just didn't look as good.... I know this may add a couple pounds but Piets are know to be tail heavy so weight up front should not be as problematic. I am saving weight in other areas by using 4130 steel-tube instead of wood for my fuselage and I will be using the "improved" gear also to save a few pounds.......... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332010#332010 ________________________________________________________________________________
Date: Feb 24, 2011
My low bid was canceled last night and the engine was reposted with a reserve this time. I am hoping to look and hear at it Monday. Its a flying engine, but 250hrs since major back in 1990. Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332011#332011 ________________________________________________________________________________
Date: Feb 24, 2011
I'm still here! Thanks for asking. I got buried at work with a perfect storm of grant and paper writing and lectures and new experiments and the dog ate my homework and stuff. I've barely been able to fly the Piet since November. Ah well, sometimes you're the bug, sometimes you're the windshield. Note that I'm posting from a gmail account these days. My univ account is getting too full of "professional" cr@p and I was missing Piet list posts! :). On Mon, Feb 21, 2011 at 8:22 AM, Gary Boothe wrote: > Anyone heard from Jeff lately? JEFF, are you out there? Everything OK? > > > Gary Boothe > Cool, Ca. > Pietenpol > WW Corvair Conversion, Running! > Tail done, Fuselage on gear, RIBS DONE! > > > * > > * > > ________________________________________________________________________________
Date: Feb 24, 2011
Subject: Out of the Blue
Listers: I had a unique experience today that I thought I would relate to you. About a week ago our local paper was having a slow news day so they did a front page story about my Piet project in their series covering unusual hobbies. The story was fluff and I am not going to bore you with that. However on Monday a stranger by the name of Robert Bartell walked into my office and said that he had seen my picture and the story about my Pietenpol in the paper and just wanted to meet me and tell me his story. It turns out that his grandfather, one Randy Penner, had an experience with a Pietenpol back in the early 30's. Mr. Penner is a fairly well renouned artist (now deceased) who has a published book entitled "Harvest of Memories." Attached are two pages from the book containing the Pietenpol story and a watercolor of the event by Mr. Penner. Hillsboro is a small Kansas town with a current population of 2,904 - probably more like 1,000 at the time of the story. Mr. Bartell's dad remembers going out to the field with Mr. Penner to watch the big event. Compared with watching the wheat grow this would have been a big crowd pleaser back then. I just wish the story was a little more specific about the date and the name of the aircraft owner. It would be a real hoot to track that plane down and see if it would still be repairable. Note that some liberties have already been taken with the Aircamper design (Oh the Horror!) My eye was immediately drawn to the rounded shape of the vertical stab and rudder. Also, split gear with motorcycle wheels (just like mine) and a Model A engine. Guess he could not afford a Corvair. (Just kidding, the Corvair would not be available until the 60's.) The wing center section has maybe the hint of a flop showing. Enjoy! Tom Stinemetze N328X ________________________________________________________________________________
Date: Feb 24, 2011
Subject: Re: Out of the Blue
Date: Feb 24, 2011
very nice.... thanks for posting....! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332046#332046 ________________________________________________________________________________
Date: Feb 24, 2011
Great story Tom, the picture is beautiful, would like to frame a copy of that. rick On Thu, Feb 24, 2011 at 2:53 PM, TOM STINEMETZE wrote: > *Listers:* > ** > *I had a unique experience today that I thought I would relate to you. > About a week ago our local paper was having a slow news day so they did a > front page story about my Piet project in their series covering unusual > hobbies. The story was fluff and I am not going to bore you with that. > However on Monday a stranger by the name of Robert Bartell walked into my > office and said that he had seen my picture and the story about my Pietenpol > in the paper and just wanted to meet me and tell me his story.* > ** > *It turns out that his grandfather, one Randy Penner, had an experience > with a Pietenpol back in the early 30's. Mr. Penner is a fairly well > renouned artist* (*now deceased)* *who has a published book entitled > "Harvest of Memories." Attached are **two pages from the book containing > the Pietenpol story and a watercolor of the event by Mr. Penner.* > ** > *Hillsboro is a small Kansas town with a current population of 2,904 - > probably more like 1,000 at the time of the story. Mr. Bartell's dad > remembers going out to the field with Mr. Penner to watch the big event. > Compared with watching the wheat grow this would have been a big crowd > pleaser back then. I just wish the story was a little more specific about > the date and the name of the aircraft owner. It would be a real hoot to > track that plane down and see if it would still be repairable.* > ** > *Note that some liberties have already been taken with the Aircamper > design (Oh the Horror!) My eye was immediately drawn to the rounded shape > of the vertical stab and rudder. Also, split gear with motorcycle wheels > (just like mine) and a Model A engine. Guess he could not afford a > Corvair. (Just kidding, the Corvair would not be available until the 60's.) > The wing center section has maybe the hint of a flop showing.* > ** > *Enjoy!* > *Tom Stinemetze* > *N328X* > -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" ________________________________________________________________________________
Subject: ferrules for .090 hard wire
Date: Feb 24, 2011
I'm looking for ferrules for .090 inch hard wire to use for the wing internal cross wires. Any help would be appreciated. Thank you. Stan Peek 822 7th St. #330 Greeley, CO 80631 (970) 352-8611 stan(at)speeklaw.com ________________________________________________________________________________
Date: Feb 24, 2011
Stan, Those acoustical paneled ceilings that you see in most office buildings? Those are supported by 12 ga wire (about 0.080"). Let me know if that's what you're looking for. Gary Boothe From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Stan Peek Sent: Thursday, February 24, 2011 7:53 PM Subject: Pietenpol-List: ferrules for .090 hard wire I'm looking for ferrules for .090 inch hard wire to use for the wing internal cross wires. Any help would be appreciated. Thank you. Stan Peek 822 7th St. #330 Greeley, CO 80631 (970) 352-8611 stan(at)speeklaw.com ________________________________________________________________________________
Date: Feb 25, 2011
Tom, Bore us with the fluff! Do you have a link to the story? Thanks, Jack DSM _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of TOM STINEMETZE Sent: Thursday, February 24, 2011 4:20 PM Subject: Pietenpol-List: Out of the Blue Listers: I had a unique experience today that I thought I would relate to you. About a week ago our local paper was having a slow news day so they did a front page story about my Piet project in their series covering unusual hobbies. The story was fluff and I am not going to bore you with that. However on Monday a stranger by the name of Robert Bartell walked into my office and said that he had seen my picture and the story about my Pietenpol in the paper and just wanted to meet me and tell me his story. It turns out that his grandfather, one Randy Penner, had an experience with a Pietenpol back in the early 30's. Mr. Penner is a fairly well renouned artist (now deceased) who has a published book entitled "Harvest of Memories." Attached are two pages from the book containing the Pietenpol story and a watercolor of the event by Mr. Penner. Hillsboro is a small Kansas town with a current population of 2,904 - probably more like 1,000 at the time of the story. Mr. Bartell's dad remembers going out to the field with Mr. Penner to watch the big event. Compared with watching the wheat grow this would have been a big crowd pleaser back then. I just wish the story was a little more specific about the date and the name of the aircraft owner. It would be a real hoot to track that plane down and see if it would still be repairable. Note that some liberties have already been taken with the Aircamper design (Oh the Horror!) My eye was immediately drawn to the rounded shape of the vertical stab and rudder. Also, split gear with motorcycle wheels (just like mine) and a Model A engine. Guess he could not afford a Corvair. (Just kidding, the Corvair would not be available until the 60's.) The wing center section has maybe the hint of a flop showing. Enjoy! Tom Stinemetze N328X ________________________________________________________________________________
Subject: I need some help please
Date: Feb 25, 2011
Hello, I need some help from you; I need an engine for the Piet I am building. In the beginin I was thinking in a VW bla, bla, bla, but one day I found a website named BARNSTORMERS and I find there a lot of engines like A65 at a very good prices... but I don know how they are. My idea is buy one there in USA (I live in Uruguay) and bring it it here (as an sport airplane engine it do not pay taxes). But the problem is "see the engine" or at least a comment from a therth about the state of it. Supose I found an engine, can I ask you here for someone to see it if it is phisicaly (location) possible, to have some comments about? pros, conts, yes no... could it be? javascript:emoticon('[Wink]') Thank you, and best regards. Mario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332073#332073 ________________________________________________________________________________
Subject: Re: I need some help please
Date: Feb 25, 2011
Mario, I think the A-65 will be a much better choice than the VW. There are some great A-65's out there BUT there is a lot of worn out/rusty junk out there too. Be patient and watch Barnstormer's. Maybe someone on the LIST here will know of a good one. I think the guys on the list would be very trustworthy. A really great bunch of people hang out here. Any of the small Continental engines would be a good choice. A-75, C-85, C-90 & O-200(100) horsepower. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332074#332074 ________________________________________________________________________________
Date: Feb 25, 2011
Mario, Good to hear from you! I'm sure many Piet builder/owners would help with that. I'm not sure of how practical that would be. You would be trusting someone else's judgment as to the quality of the engine. You might consider an AP/IA mechanic to build you an engine. That way you can be sure you have a good engine. For a C65, C75 or C85 you can build one for less than a Corvair conversion. I've been very happy with my engine that Tom Wottreng built for me. Pictures here... http://textors.com/PietProject.html Best to you! Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of giacummo Sent: Friday, February 25, 2011 5:11 AM Subject: Pietenpol-List: I need some help please Hello, I need some help from you; I need an engine for the Piet I am building. In the beginin I was thinking in a VW bla, bla, bla, but one day I found a website named BARNSTORMERS and I find there a lot of engines like A65 at a very good prices... but I don know how they are. My idea is buy one there in USA (I live in Uruguay) and bring it it here (as an sport airplane engine it do not pay taxes). But the problem is "see the engine" or at least a comment from a therth about the state of it. Supose I found an engine, can I ask you here for someone to see it if it is phisicaly (location) possible, to have some comments about? pros, conts, yes no... could it be? javascript:emoticon('[Wink]') Thank you, and best regards. Mario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332073#332073 ________________________________________________________________________________
Subject: sniping tools
Date: Feb 25, 2011
Jack; I use EZSniper for all of my eBay bidding, otherwise I go with the 'Buy It Now'. EZSniper has been very successful in winning the auctions that I bid on. Just ask Gardiner Mason... he drove the truck that I won on eBay a few weeks ago, using EZSniper ;o) I guess what I'm saying is that there are good products out there that don't hijack your personal info and that do work well. Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Feb 25, 2011
Rick: I don't know anything about copyright law but I think you would be safe if you just made one for yourself and did not sell them. I scanned the photo directly from Mr. Penner's book. I am going to try and get a copy of the book myself as this is just one of several stories of life in the 20's and 30's - rural Kansas. I have attached a copy of the back of the book containing the ISBN information should anybody be interested. Stinemetze N328X >>> Rick Holland 2/24/2011 6:21 PM >>> Great story Tom, the picture is beautiful, would like to frame a copy of that. rick ________________________________________________________________________________
Date: Feb 25, 2011
Ooo Jack. You are a glutton for punishment. Here is the link: http://www.mcphersonsentinel.com/features/x1349633460/Interesting-Interests -Tom-Stinemetze The link to the photo on the page appears to be broken so I have attached a copy. This would help scare the mice and birds out of your shop. Tom >>> "Jack" 2/25/2011 4:06 AM >>> Tom, Bore us with the fluff! Do you have a link to the story? Thanks, Jack DSM ________________________________________________________________________________
Subject: Retracing Pietenpol
Date: Feb 25, 2011
I am planning a trip back to my home country. While websurfing for some locations to visit, I found this one; http://www.ijsboerderijoldepietepol.nl/ History reads that this farm orginally was owned by the Pietenpol family an d sold when leaving for America. The current family owns it for 5 genaration now. Odds are likely this was owned by Bernards Parent or grand Parents. Currently operates as a dairy farm / creamery. Hans NX15KV ________________________________________________________________________________
Subject: Re: ferrules for .090 hard wire
Date: Feb 25, 2011
To the best of my knowledge ferrules for hard wire are not available. Making your own might be a problem because the furls consist of spiral wound hard wire but have an oval interior not round. However, I bet some of the antique restoration places have had make them when building Jennies or other old airplanes. You could try one of these shops. If that does not work out, you can always do what most people do, and that is substitute 1/8th inch cable for the hard wire. -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332093#332093 ________________________________________________________________________________
Date: Feb 25, 2011
Tom, Shame on you for not including the article earlier! Great story and picture! You are making some good headway. Thanks! Jack DSM do _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of TOM STINEMETZE Sent: Friday, February 25, 2011 8:26 AM Subject: RE: Pietenpol-List: Out of the Blue Ooo Jack. You are a glutton for punishment. Here is the link: http://www.mcphersonsentinel.com/features/x1349633460/Interesting-Interests- Tom-Stinemetze The link to the photo on the page appears to be broken so I have attached a copy. This would help scare the mice and birds out of your shop. Tom >>> "Jack" 2/25/2011 4:06 AM >>> Tom, Bore us with the fluff! Do you have a link to the story? Thanks, Jack DSM ________________________________________________________________________________
Date: Feb 25, 2011
Date: Feb 25, 2011
Take the wire and on a lath make a long spring by forming it over a round mandrel. Then cut to the length you need. To flatten or oval it, just use a vise to squeeze it. Make sure you adjust the inside diameter before to allow for fitting the two .09 wires in it before you flatten. Any small machine shop could do this for you if you do not have a lath. If you look at some back issues of the Buckeye Pietenpol Newsletter, you can find an article my Dad and I did on this very topic. Good Luck! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332102#332102 ________________________________________________________________________________
Date: Feb 25, 2011
Hello Mario, Very nice photos. Looks like some nice high-quality work. Do you know Santi ago Morete from Santa Rosa, Argentina? Moretesantiago(at)yahoo.ar, He was abl e to attend Brodhead and Oshkosh '08, and we all got to meet him. Dan Helsper Poplar Grove, IL. -----Original Message----- From: giacummo <mario.giacummo(at)gmail.com> Sent: Fri, Feb 25, 2011 5:14 am Subject: Pietenpol-List: I need some help please Hello, I need some help from you; I need an engine for the Piet I am building. n the beginin I was thinking in a VW bla, bla, bla, but one day I found a ebsite named BARNSTORMERS and I find there a lot of engines like A65 at a v ery ood prices... but I don know how they are. y idea is buy one there in USA (I live in Uruguay) and bring it it here (as an port airplane engine it do not pay taxes). But the problem is "see the engi ne" r at least a comment from a therth about the state of it. upose I found an engine, can I ask you here for someone to see it if it is hisicaly (location) possible, to have some comments about? pros, conts, yes o... could it be? javascript:emoticon('[Wink]') Thank you, and best regards. Mario ead this topic online here: http://forums.matronics.com/viewtopic.php?p=332073#332073 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 26, 2011
Vic, The pictures of Jack's project are great, but in person you would be blown away. I had the pleasure to meet Jack and his wife last Saturday on a visit to Des Moines. It turns out my step-daughter lives just around the corner from them. As I' am just getting started it really got me excited to see his project and the quality of his craftsmanship. If only this weather would straighten up so I could get in the shop! Thanks again Jack for the Piet visit and the great advise. Joe Swithin Morris, IL Starting with the ribs soon. ________________________________________________________________________________
Date: Feb 26, 2011
Subject: Florida Flying/Sun-N-Fun
Its hard to believe that its time for my first annual condition inspection. Took the Piet up for 1/2 hour just to warm up the oil, and was comfortable wearing a t-shirt and shorts! I'm planning to have the Piet over at Sun-N Fun for the whole week. Anyone else flying in? Ben Charvet Titusville, Fl ________________________________________________________________________________
Date: Feb 26, 2011
Hey Jack, thanks me, I am presenting you your neighbors ;0) And Dan, about Morete yes I exchange some mails with him; here in Uruguay there is an other constructor (or future constructor) who told me he thought to build a Piet, he went with his son to Brodhead in 09.. and when he saw them, so perfects, and very laborious works, he change his wishes for something easier (Legal Eagle). At home (country) ther is just only one homebuild aircraft, a Mini Max, build it by Pepe Ifran.. I have to go to talk with him, but he lives far away from home/job place... some day Se you on monday, regards Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332150#332150 ________________________________________________________________________________
Date: Feb 26, 2011
Subject: firewall insulating barrier
I'm approaching a point where I'll need to install a firewall. I'm wondering if there is any consensus on the need/desirability of installing a heat resistant barrier (e.g., fiberfrax) between the plywood and the stainless or galvanized sheet metal firewall. Those of you further along or with flying Piets, what have you done? Thanks, Ken ________________________________________________________________________________
Date: Feb 26, 2011
Subject: Re: firewall insulating barrier
Ken >From what I have read that the fiberfrax is not necessary if using stainless on the firewall (but doesn't hurt). I just used the .016 stainless. I have a firewall size piece of fiberfrax if you need some. rick On Sat, Feb 26, 2011 at 12:36 PM, Kenneth Bickers wrote: > bickers.ken(at)gmail.com> > > I'm approaching a point where I'll need to install a firewall. I'm > wondering if there is any consensus on the need/desirability of > installing a heat resistant barrier (e.g., fiberfrax) between the > plywood and the stainless or galvanized sheet metal firewall. > Those of you further along or with flying Piets, what have you done? > > Thanks, Ken > > -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" ________________________________________________________________________________
Date: Feb 26, 2011
Subject: Rudder bar and forward controls
Any issues with using standard cold rolled-tubing for use on the Rudder b ar and forward foot controls?-I need to know if structural tubing is the choice over standard tubing; if so why?-Also, are any of you reinforcing the floor under the rudder bar mount as I find it somewhat flexible. - - KMHeide Hawley, MN=0A=0A=0A ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Date: Feb 26, 2011
Rick: I would be interested in the Fiberfrax. Contact me offline. Rick Schreiber Valparaiso, In ----- Original Message ----- From: Rick Holland Sent: 2/26/2011 3:49:23 PM Subject: Re: Pietenpol-List: firewall insulating barrier Ken >From what I have read that the fiberfrax is not necessary if using stainless on the firewall (but doesn't hurt). I just used the .016 stainless. I have a firewall size piece of fiberfrax if you need some. rick On Sat, Feb 26, 2011 at 12:36 PM, Kenneth Bickers wrote: I'm approaching a point where I'll need to install a firewall. I'm wondering if there is any consensus on the need/desirability of installing a heat resistant barrier (e.g., fiberfrax) between the plywood and the stainless or galvanized sheet metal firewall. Those of you further along or with flying Piets, what have you done? Thanks, Ken ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: HELP
Date: Feb 26, 2011
This year at Sun n Fun in the Wood Shop we are going to build a Pietenpol Fuselage and tail section. We are then going to donate what we build to Brodhead airport to be auctioned or sold at the Pietenpol reunion this summer, for the concrete floor at the new visitors center. Dave Aldrich is going to contribute the wood and I am working on Wicks to contribute te plywood. What we still need are steel fittings, ( bell crank, torque tube, tail brackets and rudder assy bar also the wing fittings). Is there anyone out there that can make a set for us? If you can, please contact me off list? I know this is short notice and we cant pay for them but I appreciate what ever you all can do. Of couse if you can contribute anything else we can use anything (engine mount, wing struts, fuel tank, tail wheel or? ) I"m sure there a lot of things around the hangar floor you've been meaning to sell or use someplace that would be perfect for our plane. Dick N horzpool(at)goldengate.net ________________________________________________________________________________
Date: Feb 26, 2011
Subject: Re: Rudder bar and forward controls
Have you installed the cross-member that runs from the rear ash piece to the top of the rudder bar? Mine felt wobbly until I added that, no need to reinforce the 1/4" floor. rick On Sat, Feb 26, 2011 at 3:39 PM, KM Heide CPO/FAAOP wrote: > > * > * > **Any issues with using standard cold rolled tubing for use on the Rudder > bar and forward foot controls? I need to know if structural tubing is the > choice over standard tubing; if so why? Also, are any of you reinforcing the > floor under the rudder bar mount as I find it somewhat flexible. > > > KMHeide > Hawley, MN > > * > > * > > -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" ________________________________________________________________________________
Subject: HELP
Date: Feb 26, 2011
Dick=2C I have a Model A engine mount and radiator mount that came off of J ack McCarthy's Piet when he converted. I would be happy to donate these to the cause. Gene Rambo From: horzpool(at)goldengate.net Subject: Pietenpol-List: HELP Date: Sat=2C 26 Feb 2011 19:25:01 -0600 This year at Sun n Fun in the Wood Shop we are going to build a Pietenpol F uselage and tail section. We are then going to donate what we build to Bro dhead airport to be auctioned or sold at the Pietenpol reunion this summer =2C for the concrete floor at the new visitors center. Dave Aldrich is goi ng to contribute the wood and I am working on Wicks to contribute te plywoo d. What we still need are steel fittings=2C ( bell crank=2C torque tube =2C tail brackets and rudder assy bar also the wing fittings). Is there an yone out there that can make a set for us? If you can=2C please contact me off list? I know this is short notice and we cant pay for them but I appr eciate what ever you all can do. Of couse if you can contribute anything e lse we can use anything (engine mount=2C wing struts=2C fuel tank=2C tail w heel or? ) I"m sure there a lot of things around the hangar floor you've been meaning to sell or use someplace that would be perfect for our plane. Dick N horzpool(at)goldengate.net ________________________________________________________________________________
Subject: Re: HELP
Date: Feb 26, 2011
Thats great Gene. For that, are you going to SNF or I can also pick up. Dick ----- Original Message ----- From: Gene Rambo To: pietenpol-list Sent: Saturday, February 26, 2011 8:42 PM Subject: RE: Pietenpol-List: HELP Dick, I have a Model A engine mount and radiator mount that came off of Jack McCarthy's Piet when he converted. I would be happy to donate these to the cause. Gene Rambo ------------------------------------------------------------------------- ----- From: horzpool(at)goldengate.net To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: HELP Date: Sat, 26 Feb 2011 19:25:01 -0600 This year at Sun n Fun in the Wood Shop we are going to build a Pietenpol Fuselage and tail section. We are then going to donate what we build to Brodhead airport to be auctioned or sold at the Pietenpol reunion this summer, for the concrete floor at the new visitors center. Dave Aldrich is going to contribute the wood and I am working on Wicks to contribute te plywood. What we still need are steel fittings, ( bell crank, torque tube, tail brackets and rudder assy bar also the wing fittings). Is there anyone out there that can make a set for us? If you can, please contact me off list? I know this is short notice and we cant pay for them but I appreciate what ever you all can do. Of couse if you can contribute anything else we can use anything (engine mount, wing struts, fuel tank, tail wheel or? ) I"m sure there a lot of things around the hangar floor you've been meaning to sell or use someplace that would be perfect for our plane. Dick N horzpool(at)goldengate.net st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List ttp://forums.matronics.com =_blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 26, 2011
Standard tubing is what I used. (.035" wall SS) Agreed... once the top support is in...no wobble. Michael Perez Karetaker Aero www.karetakeraero.com --- On Sat, 2/26/11, Rick Holland wrote: > From: Rick Holland <at7000ft(at)gmail.com> > Subject: Re: Pietenpol-List: Rudder bar and forward controls > To: pietenpol-list(at)matronics.com > Date: Saturday, February 26, 2011, 9:32 PM > Have you installed the cross-member that > runs from the rear ash piece to the top of the rudder bar? > Mine felt wobbly until I added that, no need to reinforce > the 1/4" floor. > > rick > > > On Sat, Feb 26, 2011 at 3:39 PM, KM Heide CPO/FAAOP > wrote: > > > > > > Any issues > with using standard cold rolledtubing for use on the > Rudder bar and forward foot controls?I need to know if > structural tubing is the choice over standard tubing; if so > why?Also, are any of you reinforcing the floor under the > rudder bar mount as I find it somewhat flexible. > > > > > KMHeide > Hawley, > MN > > > > > > > > > > > > " > target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > -- > Rick Holland > Castle Rock, Colorado > > "A Foolish Consistency is the Hobgoblin of Little > Minds" > > > > > > ________________________________________________________________________________
Date: Feb 27, 2011
Subject: Re: HELP
I have a motormount for a Corvair that I built before I decided to use a Continental. I'm sure I'll never use it, so if you think it would help I can bring it. Ben Charvet Titusville, Fl On 2/26/2011 8:25 PM, Dick N wrote: > This year at Sun n Fun in the Wood Shop we are going to build a > Pietenpol Fuselage and tail section. We are then going to donate what > we build to Brodhead airport to be auctioned or sold at the Pietenpol > reunion this summer, for the concrete floor at the new visitors > center. Dave Aldrich is going to contribute the wood and I am working > on Wicks to contribute te plywood. What we still need are steel > fittings, ( bell crank, torque tube, tail brackets and rudder assy > bar also the wing fittings). Is there anyone out there that can make > a set for us? If you can, please contact me off list? I know this is > short notice and we cant pay for them but I appreciate what ever you > all can do. Of couse if you can contribute anything else we can use > anything (engine mount, wing struts, fuel tank, tail wheel or? ) I"m > sure there a lot of things around the hangar floor you've been meaning > to sell or use someplace that would be perfect for our plane. > Dick N > horzpool(at)goldengate.net > * > > > * -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Feb 27, 2011
I put fiberfrax on mine. You don't really need it, if you don't need the firewall. If the engine catches fire, the more insulation the better. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kenneth Bickers Sent: Saturday, February 26, 2011 2:37 PM Subject: Pietenpol-List: firewall insulating barrier I'm approaching a point where I'll need to install a firewall. I'm wondering if there is any consensus on the need/desirability of installing a heat resistant barrier (e.g., fiberfrax) between the plywood and the stainless or galvanized sheet metal firewall. Those of you further along or with flying Piets, what have you done? Thanks, Ken ________________________________________________________________________________
Subject: Re: HELP
Date: Feb 27, 2011
Hey Ben That would be great. I don't know what kind of engine we are going to use. If you don't mind, we could also sell it at Brodhead if we don't use it. You can find me at the Wood workshop all week.\ Dick ----- Original Message ----- From: Ben Charvet To: pietenpol-list(at)matronics.com Sent: Sunday, February 27, 2011 7:46 AM Subject: Re: Pietenpol-List: HELP I have a motormount for a Corvair that I built before I decided to use a Continental. I'm sure I'll never use it, so if you think it would help I can bring it. Ben Charvet Titusville, Fl On 2/26/2011 8:25 PM, Dick N wrote: This year at Sun n Fun in the Wood Shop we are going to build a Pietenpol Fuselage and tail section. We are then going to donate what we build to Brodhead airport to be auctioned or sold at the Pietenpol reunion this summer, for the concrete floor at the new visitors center. Dave Aldrich is going to contribute the wood and I am working on Wicks to contribute te plywood. What we still need are steel fittings, ( bell crank, torque tube, tail brackets and rudder assy bar also the wing fittings). Is there anyone out there that can make a set for us? If you can, please contact me off list? I know this is short notice and we cant pay for them but I appreciate what ever you all can do. Of couse if you can contribute anything else we can use anything (engine mount, wing struts, fuel tank, tail wheel or? ) I"m sure there a lot of things around the hangar floor you've been meaning to sell or use someplace that would be perfect for our plane. Dick N horzpool(at)goldengate.net -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Subject: Slow list day.........How about this idea?
Date: Feb 27, 2011
Hi Pieters, I have been working diligently (and slowly) on rebuilding my "A" since the mishap last Sept. when my timing gear disintegrated. I decided to continue to use my 8-plug head, powered by one crank-driven mag, and a hybrid electr onic ignition/battery ignition system. I bought a 4.4 lb. battery from ACS, which will energize the coil (looks like standard Model A coil) via a smal l electronic ignition module. I am imagining a small solar panel mounted on the fuel tank cover, to charge the battery. OK let the flames begin. (it's OK because I used Fiberfrax) And no smart as s remarks like "What would Bernerd say, Dan?" Dan Helsper Puryear TN., (until tomorrow only) ________________________________________________________________________________
Subject: Re: Slow list day.........How about this idea?
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Feb 27, 2011
I don't know what the output of a solar panel that size would be but I'd be surprised if it was enough to keep the battery up in-flight with steady ignition draw. seems like a small generator driven by a small prop in the slipstream would be a lot cooler looking.but of course heavier. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332232#332232 ________________________________________________________________________________
Date: Feb 27, 2011
I like this. Think of the possibilities of having the small prop on the belly. You can tell people it is a pre-WWII JATO. Or that you are getting your twin rating in the Piet. Or that with the radiator on the top, you needed a way to keep the bottom of the engine cool. Or that, though you have to make several passes, you use it to cut your own strip for off-airport landings. I'm sure others can come up with other possibilities. Cheers, Ken On Sun, Feb 27, 2011 at 5:31 PM, skellytown flyer wrote: > > I don't know what the output of a solar panel that size would be but I'd be surprised if it was enough to keep the battery up in-flight with steady ignition draw. seems like a small generator driven by a small prop in the slipstream would be a lot cooler looking.but of course heavier. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=332232#332232 > > ________________________________________________________________________________
Date: Feb 27, 2011
I like it...anything out of the norm. works for me. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Feb 27, 2011
Dan =93 No flames here! Us auto-engine converters have to stick together! A good weekend, here, too. Got all my spars shaped and rough sanded. Also resolved a long-time headache: How to reduce from a 3/8=9D fuel line to 1/8=9D primer line? Simple answer: Take a block of aluminum and make a =98manifold=99....3/8=9D in...1/8=9D out. Gary Boothe From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Sunday, February 27, 2011 3:09 PM Subject: Pietenpol-List: Slow list day.........How about this idea? Hi Pieters, I have been working diligently (and slowly) on rebuilding my "A" since the mishap last Sept. when my timing gear disintegrated. I decided to continue to use my 8-plug head, powered by one crank-driven mag, and a hybrid electronic ignition/battery ignition system. I bought a 4.4 lb. battery from ACS, which will energize the coil (looks like standard Model A coil) via a small electronic ignition module. I am imagining a small solar panel mounted on the fuel tank cover, to charge the battery. OK let the flames begin. (it's OK because I used Fiberfrax) And no smart ass remarks like "What would Bernerd say, Dan?" Dan Helsper Puryear TN., (until tomorrow only) ________________________________________________________________________________
Date: Feb 28, 2011
Date: Feb 27, 2011
Subject: Re: Fabric-Tape Thickness
Date: Feb 27, 2011
I could use that thickness info as well.... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332254#332254 ________________________________________________________________________________
Date: Feb 27, 2011
Subject: Centerburg OH, Piet Fly-In
Hello Guys, just letting everyone know that I plan on hosting another Piete npol Fly-in on June 17, 18 (Fri and Sat.) at Chapman Memorial OH71-again this year weather permitting.- If you want to fly- in on friday and cam p your welcome to.- And for all you guys (Jack Phillips) with those alumi num go-faster's, you welcome to drop in as well.- I will supply the hotdo gs, and drinks, if you can carry a covered dish etc bring one, there will b e a donation jar to help cover expenses like port-o-potty etc.- Last year was a little lean on airplanes due to weather, but not on fun.- We had 3 or 4 people drive in who are building pietenpols, and Skipp, and Ed flew t heir piets up from WV.- So if you think you might be interested let me kn ow, I will start a roster to make sure no one goes hungry.- - Shad - p.s. With all the rain we got today, you might need some floats to get in h ere! =0A=0A=0A ________________________________________________________________________________
Date: Feb 28, 2011
Subject: Last WWI US Vet has passed
http://www.cnn.com/2011/US/02/27/wwi.veteran.death/ ________________________________________________________________________________
Date: Feb 28, 2011
Ah, the fly-in season is getting started. In anticipation of this we just held "Brodhead South" this past weekend. No flying, just friends, fellowship and flatulence. Ryan Mueller, John Hofmann, Bill Church, Gene Rambo, Rob Busch and Mike Cuy invaded my home in North Carolina. By Saturday morning my wife had had enough and we were forced to adjourn to my hangar at Smith Mountain Lake, Virginia. At least there we could look at my Pietenpol, but it was just a bit too cold to fly it (temps were only in the upper 50's). However we did eat the requisite meal of bratwursts (thanks to John shipping sausages down from Wisconsin) around the Pietenpol, and made plans for Brodhead 2011. A good time was had by all. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of shad bell Sent: Sunday, February 27, 2011 11:38 PM Subject: Pietenpol-List: Centerburg OH, Piet Fly-In Hello Guys, just letting everyone know that I plan on hosting another Pietenpol Fly-in on June 17, 18 (Fri and Sat.) at Chapman Memorial OH71 again this year weather permitting. If you want to fly in on friday and camp your welcome to. And for all you guys (Jack Phillips) with those aluminum go-faster's, you welcome to drop in as well. I will supply the hotdogs, and drinks, if you can carry a covered dish etc bring one, there will be a donation jar to help cover expenses like port-o-potty etc. Last year was a little lean on airplanes due to weather, but not on fun. We had 3 or 4 people drive in who are building pietenpols, and Skipp, and Ed flew their piets up from WV. So if you think you might be interested let me know, I will start a roster to make sure no one goes hungry. Shad p.s. With all the rain we got today, you might need some floats to get in here! ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: Dan, WWBS
Date: Feb 28, 2011
Tisk, Tisk. What would Bernard say!!??? ________________________________________________________________________________
Date: Feb 28, 2011
Hey Dan ... do you have the FSI ignition parts in there ?? they say it will work on 6-16 volts.. i can't imagine the current draw being very high myself but i see this as a good backup... Maybe a good primary ignition with more of a power source.. wind or engine generator.. i noticed the spark advance is wired in place...i can see another lever in the cockpit.... folks today don't get it i leave the keys in my 30 AA all the time.. only old guys know how to start it...fuel on... retard spark...open throttle..choke..step on the right button...fun to drive but you gotta know how jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332299#332299 Attachments: http://forums.matronics.com//files/aa_195.jpg ________________________________________________________________________________
Date: Feb 28, 2011
Subject: Jim Markle/Others Help
Jim, I see you welded aluminum plates on to your aluminum wing struts where they attach to the fuselage. This is the same idea I was thinking of using. I assume you welded a plate to both top and bottom of the strut? It looks to be about 1/4" think, is this correct? How do you like/are you happy with the struts welded this way? My attach fitting will only allow for a single bolt where as you used two, any issues with a single 5/16" or 3/8" bolt? Anyone else have ideas/opinions? Thank for your help. ________________________________________________________________________________
Date: Feb 28, 2011
Subject: Jim Markle/Others Help Clarification
You can ignore my single bolt comment. After looking again at Jim's pictures on West Coast Piet., I see he used steel straps inside the strut. Still, curious to the aluminum welded plates though. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: weekend
Date: Feb 28, 2011
Got my wingtips on and ailerons cut out in the last day or so... glued some 1/8 ply to the inboard side of the ailerons... nothing in the F & G manual about what to do there... may add capstrip to the inside of the ply.. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332320#332320 Attachments: http://forums.matronics.com//files/tip_114.jpg ________________________________________________________________________________
Date: Feb 28, 2011
Subject: Seeking Dallas, TX Pietenpol member
Members: Seeking a Dallas, Texas area pietenpol member for assistance. please respond to my email or send me a number I can reach you at. KMHeide Hawley, MN ________________________________________________________________________________
Date: Feb 28, 2011
Subject: Re: weekend
Cap strip and plywood is what I did. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Feb 28, 2011
One quick comment to Michael regarding the rudder bar. You write that you used "standard tubing - .035" wall SS". Just be aware that stainless steel tubing typically has only half the Yield Strength of 4130 - and in this case, the plans specifically mention to use chro-moly tubing for the rudder bar. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332335#332335 ________________________________________________________________________________
Subject: 4 foot center section
Date: Feb 28, 2011
So here's my version of a 4 foot center section. This should allow for a l ot more fuel to burn once my Corvair crankshaft snaps. I haven't figured o ut the actual volume yet - the design is kinda evolving. I had some ideas about it that as I put them together=2C "it was revealed" that my ideas wer e not going to work. I have quite a bit more work to do=2C but I thought I 'd share a couple pics as this stage. I just realized that if my plans fall together (financial plans) by mid sum mer=2C I should have all the major airframe and engine components to put th is aircraft together. If you notice though=2C I didn't mention which summe r : ) Should be ordering my spars soon - the stuff I got from McKormicks just didn't pan out like I thought so I'll use the wood elsewhere. If you think about it=2C for spar material (the stuff that really counts) Aircraft spruce price isn't really that expensive - even if you include the shippin g. They estimated $130 shipping to Minneapolis area - hope that's close. That should leave me with about $400 or so worth in spar material (4 pieces at 12'-6" each). Put those together and that's about hoe much wood I've g ot into this thing in the fuse=2C tail=2C ply etc. - maybe a little more bu t not much. Thought about going to Youngblood lumber and getting some fir for spars but I just don't feel like taking another risk since my last one didn't turn out. Really=2C I got enough for (2) spars which is what I plan ned - the pieces are just not as "perfect" as I'd like. This isn't a slam on Mckormicks at all - It's just once I got the boards home and planed=2C i t uncovered some stuff I wansn't happy with. I could make it work but I'd rather just have the peace of mind of having those critical members be cert ified materials. Call me paranoid I guess. Anyway=2C if anyone is interested in following the 4 foot center constructi on let me know. I can keep posting pics and progress reports. I intend to support it with laminated spruce / ply / spruce cabanes which I just lamin ated not too long ago. Later=2C Tom B. -Fuse framed -End spinach framed -wing ribs completed -working on wing=2C center section and struts =0A 4 foot center section=0A http://cid-49bf7cf4860ada21.skydrive.live.com/redir.aspx?page=browse&resi d=49BF7CF4860ADA21!149&type=5&Bpub=SDX.Photos&Bsrc=Photomail&authke y=E7ex1FbU7rA%24=0A ________________________________________________________________________________
Date: Mar 01, 2011
Hi Jeff, I hope you are right about the current draw. Maybe if it proves to discharg e during flight, I can use it as a back-up like you said, only for T-off an d landing, or other mag failure. Yes the spark advance is wired in place. I already have the Slick mag with the impulse for starting purposes. Bernard didn't used this set-up (or maybe, I better check the "lost" BHP Papers to make sure) but at least it is unique and might be a topic of curiosity at Brodhead. Dan Helsper Poplar Grove, IL. (I'm back) PS Boy wouldn't that be something if I get better performance than the mag? .....nawwww -----Original Message----- From: bender <jfaith(at)solairusaviation.com> Sent: Mon, Feb 28, 2011 8:57 am Subject: Pietenpol-List: Re: Slow list day.........How about this idea? > Hey Dan ... do you have the FSI ignition parts in there ?? hey say it will work on 6-16 volts.. i can't imagine the current draw being ery high myself but i see this as a good backup... aybe a good primary ignition with more of a power source.. wind or engine enerator.. noticed the spark advance is wired in place...i can see another lever in t he ockpit.... folks today don't get it leave the keys in my 30 AA all the time.. only old guys know how to start t...fuel on... retard spark...open throttle..choke..step on the right utton...fun to drive but you gotta know how jeff ead this topic online here: http://forums.matronics.com/viewtopic.php?p=332299#332299 ttachments: http://forums.matronics.com//files/aa_195.jpg -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Re: Last WWI US Vet has passed
Date: Mar 01, 2011
Charles, It is not widely known, But GHW Bush was NOT the youngest WWII naval aviato r. It is in fact my neighbor (still going strong) Capt. Chuck Downey of Pop lar Grove, IL. http://www.meyersaircraftowners.org/index.php?option=com_c ontent&view=article&id=16%3Aa-toast-to-capt-chuck-s-downey&catid=10%3 Ahistorical-information&Itemid=12&showall=1 Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Mar 01, 2011
I know Bill. I am pretty sure the bar can handle the rudder stresses. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com --- On Mon, 2/28/11, Bill Church wrote: From: Bill Church <billspiet(at)sympatico.ca> Subject: Pietenpol-List: Re: Rudder bar and forward controls Date: Monday, February 28, 2011, 6:59 PM > One quick comment to Michael regarding the rudder bar. You write that you used "standard tubing - .035" wall SS". Just be aware that stainless steel tubing typically has only half the Yield Strength of 4130 - and in this case, the plans specifically mention to use chro-moly tubing for the rudder bar. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332335#332335 le, List Admin. ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Date: Mar 01, 2011
Yeah, someone else told me about Mr. Downey. Hadn't heard of him before. Nice writeup even though there are some mistakes. Oh well, maybe his memory is getting a little fuzzy -- like mine! ----- Original Message ----- From: helspersew(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, March 01, 2011 6:46 AM Subject: Re: Pietenpol-List: Last WWI US Vet has passed Charles, It is not widely known, But GHW Bush was NOT the youngest WWII naval aviator. It is in fact my neighbor (still going strong) Capt. Chuck Downey of Poplar Grove, IL. http://www.meyersaircraftowners.org/index.php?option=com_content&view= article&id=16%3Aa-toast-to-capt-chuck-s-downey&catid=10%3Ahistorical- information&Itemid=12&showall=1 Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Mar 01, 2011
Actually, the stresses induced on the rudder bar from the rudder are almost inconsequential. Since the ends of the rudder bar are only connected to the rudder by means of cables (if built to the plans), then only one end of the rudder bar (the end that is pulling on the rudder) can be loaded at a time (you can't push a rope). What you need to be aware of is the potential for the pilot to bend the rudder bar, by inadvertently pushing with both feet. The pilot will undoubtedly have both feet pressing against the rudder bar at all times, and a bit of uncoordinated footwork, or panic can result in an excessive amount of pushing on both sides of the rudder bar at the same time. Probably what you should do is take a scrap piece of the tubing you're using, the same length as the rudder bar, and duplicate the center pivot arrangement, and secure this bar to something solid. Then position yourself in a well secured seat located at the proper distance from the rudder bar, and see how difficult it is to bend the sample rudder bar. You may be surprised how little force it takes to bend the tube. There are very few metal parts in the plans that actually call for cro-moly steel, but the rudder bar is one. Methinks it is specified that way for a reason. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332385#332385 ________________________________________________________________________________
Date: Mar 01, 2011
You know, "what would Bernard say" always comes up. He used the materials and methods commonly available to him... converted 2 different auto engines when they were relatively new to the market... He was an innovator. I don't think he would exactly be one to frown on innovation... -------- Brad "DOMIT" Smith First rule of ground school: This is the ground... don't hit it going fast. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332389#332389 ________________________________________________________________________________
Date: Mar 01, 2011
I understand Bill and I appreciate your input. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com --- On Tue, 3/1/11, Bill Church wrote: From: Bill Church <billspiet(at)sympatico.ca> Subject: Pietenpol-List: Re: Rudder bar and forward controls Date: Tuesday, March 1, 2011, 12:47 PM > Actually, the stresses induced on the rudder bar from the rudder are almost inconsequential. Since the ends of the rudder bar are only connected to th e rudder by means of cables (if built to the plans), then only one end of t he rudder bar (the end that is pulling on the rudder) can be loaded at a ti me (you can't push a rope). What you need to be aware of is the potential for the pilot to bend the rud der bar, by inadvertently pushing with both feet. The pilot will undoubtedl y have both feet pressing against the rudder bar at all times, and a bit of uncoordinated footwork, or panic can result in an excessive amount of push ing on both sides of the rudder bar at the same time. Probably what you should do is take a scrap piece of the tubing you're usin g, the same length as the rudder bar, and duplicate the center pivot arrang ement, and secure this bar to something solid. Then position yourself in a well secured seat located at the proper distance from the rudder bar, and s ee how difficult it is to bend the sample rudder bar. You may be surprised how little force it takes to bend the tube. There are very few metal parts in the plans that actually call for cro-moly steel, but the rudder bar is one. Methinks it is specified that way for a reason. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332385#332385 le, List Admin. ________________________________________________________________________________
Subject: Re: Seeking Dallas, TX Pietenpol member
Date: Mar 01, 2011
What KIND of assistance? I don't have a Piet... I'm in Fort Worth (think of it as one big mess all blurred together, Dallas and Fort Worth and... oh... a dozen plus smaller cities. -------- Brad "DOMIT" Smith First rule of ground school: This is the ground... don't hit it going fast. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332390#332390 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Mar 01, 2011
This is one area where I would not cut corners and would most certainly use the 4130 as the rudder bar is THE most manipulated control device on the entire airplane and is constantly being used both in flight a nd on the ground. Stainless will work harden, fatigue and crack with repeated excessive force on both sides of the rudder bar (which all Pietenpol pilots apply during t ight turns on the ground and in panic, surge situations during a very gusty land ing in a crosswind or to prevent a ground loop. The proper way to fly any airplane (especially a taildragger) is to constan tly apply pressure to BOTH rudders to provide positive feedback to both fee t rather than push one and release the other like you would do in shifting an manual transmission car. I would be more comfortable making the rudder bar out of white ash or some other hardwood (like the WWI airplanes and Curtiss Jenny had) rather than make it out of stainless tubing. Mike C. ________________________________________________________________________________
Date: Mar 01, 2011
I feel comfortable with my rudder bar set up. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com --- On Tue, 3/1/11, Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] wrote: From: Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] <michael.d.cuy(at)nasa.g ov> Subject: RE: Pietenpol-List: Re: Rudder bar and forward controls Date: Tuesday, March 1, 2011, 1:33 PM This is one area where I would not cut corners and would most certainly use the 4130 as the rudder bar is THE most manipulated controldevice on the en tire airplane and is constantly being used both in flight and on the ground . -Stainless will work harden, fatigue and crack with repeated excessive force on both sides of the rudder bar (which all Pietenpol pilots apply du ring tightturns on the ground and in panic, surge situations during a very gusty landing in a crosswind or to prevent a ground loop. -The proper wa y to fly any airplane (especially a taildragger) is to constantly apply pre ssure to BOTH rudders to provide positive feedback to both feetrather than push one and release the other like you would do in shifting an manual tran smission car. -I would be more comfortable making the rudder bar out of white ash or some other hardwood (like the WWI airplanes and Curtiss Jenny had) ratherthan make it out of stainless tubing.--- -Mike C. - =0A ________________________________________________________________________________
From: "Scott Knowlton " <flyingscott_k(at)hotmail.com>
Date: Mar 01, 2011
Ditto to what Bill said but make sure to excite your adrenal glands whilst testing! Scott Knowlton -----Original Message----- From: Bill Church <billspiet(at)sympatico.ca> Date: Tue, 1 Mar 2011 17:47:45 Subject: Pietenpol-List: Re: Rudder bar and forward controls Actually, the stresses induced on the rudder bar from the rudder are almost inconsequential. Since the ends of the rudder bar are only connected to the rudder by means of cables (if built to the plans), then only one end of the rudder bar (the end that is pulling on the rudder) can be loaded at a time (you can't push a rope). What you need to be aware of is the potential for the pilot to bend the rudder bar, by inadvertently pushing with both feet. The pilot will undoubtedly have both feet pressing against the rudder bar at all times, and a bit of uncoordinated footwork, or panic can result in an excessive amount of pushing on both sides of the rudder bar at the same time. Probably what you should do is take a scrap piece of the tubing you're using, the same length as the rudder bar, and duplicate the center pivot arrangement, and secure this bar to something solid. Then position yourself in a well secured seat located at the proper distance from the rudder bar, and see how difficult it is to bend the sample rudder bar. You may be surprised how little force it takes to bend the tube. There are very few metal parts in the plans that actually call for cro-moly steel, but the rudder bar is one. Methinks it is specified that way for a reason. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332385#332385 ________________________________________________________________________________
Date: Mar 01, 2011
Subject: Oscar penned the Firewall Forward of the latest Sport
Av
Forwarded from the CorvAircraft list.... Oscar does a nice write-up of an overview of the small Continentals. Good job Oscar! ---------- Forwarded message ---------- From: Pat Panzera <editor.contactmagazine(at)gmail.com> Date: Tue, Mar 1, 2011 at 2:20 PM Subject: CorvAircraft> Oscar Zuniga Squirrel Net The "Firewall Forward" section of the newest Sport Aviation was authored by our very own Oscar Zuniga. http://www.sportaviationonline.org/sportaviation/201103#pg104 ________________________________________________________________________________
Date: Mar 01, 2011
Michael, do you intend to carry passengers in your plane when it's done? While YOU might be comfortable with your rudder bar setup, how comfortable will your screaming passenger be when your rudder bar fails in flight (or while landing/taxiing) and you have no rudder control? Is this something that you REALLY want to cut corners on? But, it is your plane and you may build it as you see fit... personally, I'll be adhering strictly to what's called out on the plans for critical control assemblies such as this. Just my $.02 -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332407#332407 ________________________________________________________________________________
Date: Mar 01, 2011
I appreciate the concerns, but I question what exactly will go wrong with S.S.? Am I being told that some person may get in the plane and bend the bar in a double footed panic? I do not understand what will work harden...the length of sleeve through the bar where is comes in contact with the bolt? (Greased) Maybe the flat ends of the bar where it comes in contact with the clevis pins? (Double wall thickness here) As noted by one reader, the rudder stress on the bar is relatively small, so how much force will be on those clevis pins? ( I am not saying that is true, it is just what someone said earlier.)Maybe the area where the sleeve through the bar rides on top of the "A" frame support? (Washer) How much movement/stress needs to be applied to even start the work hardening process? No one need get in the plane that does not want to...nor whom is not invited. I'm keeping the bar, anyone who wants to debate it further, feel free to contact me off list...no need taking up space and cluttering up everyones email boxes. Michael Perez Karetaker Aero www.karetakeraero.com --- On Tue, 3/1/11, Billy McCaskill wrote: > From: Billy McCaskill <billmz(at)cox.net> > Subject: Pietenpol-List: Re: Rudder bar and forward controls > To: pietenpol-list(at)matronics.com > Date: Tuesday, March 1, 2011, 3:49 PM > --> Pietenpol-List message posted > by: "Billy McCaskill" > > Michael, do you intend to carry passengers in your plane > when it's done? While YOU might be comfortable with > your rudder bar setup, how comfortable will your screaming > passenger be when your rudder bar fails in flight (or while > landing/taxiing) and you have no rudder control? Is > this something that you REALLY want to cut corners on? > But, it is your plane and you may build it as you see > fit... personally, I'll be adhering strictly to what's > called out on the plans for critical control assemblies such > as this. Just my $.02 > > -------- > Billy McCaskill > Urbana, IL > tail section almost done, starting on ribs soon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=332407#332407 > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Mar 01, 2011
I think Billy made a great point in addition to Bill Church is that you're cheaping out on something that is a critical flight control that 'may' work fine for years and years but then again may not. Remember Mike....my spreader bars were made of stainless and last summer the one ear of my front rudder bar snapped off and dragged under the airplane after landing at a nearby fly-in. Scary ? You bet but thankfully there are TWO spreader bars and the other one held up to get me home safely. In the Pietenpol you only have one rudder bar so you're probably right---it will be fine and I'm glad you are confident that it will be okay but in the grand scheme of things it isn't worth taking a chance when for a few bucks you could have aircraft grade 4130 in there. I'd hate to be turning base to final with my wife or loved one in the front seat and have something like my rudder control fail 80 feet over the tall trees with no chance of recovery and a nice tank of fuel ready to split and catch fire as it flows over those hot exhaust pipes.... I guess that's why we are required to display a placard in full view of the passenger which says that "this airplane is amateur built and does not comply with the same standards that factory built airplanes are required to comply with." (paraphrased) Mike C. ________________________________________________________________________________
Subject: Re: Slow list day.........Bernerd, and his ideas
Date: Mar 01, 2011
I think some of the reason many of us choose this design, is a longing for simpler times, and the ability to maybe travel back in history and stay the re for a few precious moments. We fantasize about how it must have been, an d (mistaking) use the "green grass" theory to imagine that it was a better place. We define in our minds the things that were going on, to a definite day or year, and don't want to inconvenience ourselves to recognize that ti me never stands still............ Please leave me alone in my fantasies!!! I want to stay here!!! Dan Helsper Poplar Grove, IL. -----Original Message----- From: DOMIT <rx7_ragtop(at)yahoo.com> Sent: Tue, Mar 1, 2011 12:20 pm Subject: Pietenpol-List: Re: Slow list day.........How about this idea? You know, "what would Bernard say" always comes up. He used the materials and methods commonly available to him... converted 2 ifferent auto engines when they were relatively new to the market... He was an innovator. I don't think he would exactly be one to frown on nnovation... -------- rad "DOMIT" Smith First rule of ground school: This is the ground... don't hit it going fast . ead this topic online here: http://forums.matronics.com/viewtopic.php?p=332389#332389 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Mar 01, 2011
Until you have a "Viagra Moment" and then realize maybe some of that new-fangled technology taint so bad after all. On Tue, Mar 1, 2011 at 3:31 PM, wrote: > I think some of the reason many of us choose this design, is a longing for > simpler times, and the ability to maybe travel back in history and stay > there for a few precious moments. We fantasize about how it must have been, > and (mistaking) use the "green grass" theory to imagine that it was a better > place. We define in our minds the things that were going on, to a definite > day or year, and don't want to inconvenience ourselves to recognize that > time never stands still............ Please leave me alone in my fantasies!!! > I want to stay here!!! > > Dan Helsper > Poplar Grove, IL. > > > -----Original Message----- > From: DOMIT <rx7_ragtop(at)yahoo.com> > To: pietenpol-list > Sent: Tue, Mar 1, 2011 12:20 pm > Subject: Pietenpol-List: Re: Slow list day.........How about this idea? > > > You know, "what would Bernard say" always comes up. > > He used the materials and methods commonly available to him... converted 2 > different auto engines when they were relatively new to the market... > > He was an innovator. I don't think he would exactly be one to frown on > innovation... > > -------- > Brad "DOMIT" Smith > > First rule of ground school: This is the ground... don't hit it going fast. > > > Read this topic online here: > http://forums.matronics.com/viewtopic.php?p=332389#332389 > > > " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > > * > > * > > -- Rick Holland Castle Rock, Colorado "A Foolish Consistency is the Hobgoblin of Little Minds" ________________________________________________________________________________
Date: Mar 01, 2011
I don't know the answer, but there are few things that occur to me. A points ignition system will draw about 3 amps/hour (I don't know what your electronic module draws). A 12V battery that weighs 4-5 lbs (as per your example) is probably good for 3-4 amp hours (Ah), so with no charging system you probably have about an hour of flight time available through that ignition system. A 5 watt solar battery charger (it's the larger one, about 12"x12", not the skinny one you put on your car dashboard) is going to put out about 0.3 amps in direct sunlight, max. In theory, if you had ten of those on your wing or top of fuselage, etc., then maybe it would be enough juice to keep you flying on your secondary ignition. They do sell flexible skin solar panels now, so this may not be too crazy...if you have the money. Another solution, though, is to treat your electronic module truly as a secondary ignition system, only to be used if your primary ignition failed. In that case, you'd have about an hour of flying available just running on your little battery. If that's too short, return the battery to ACS and buy a 12V 8 Ah battery (available all over the place) that weigh a little over 8 lbs. Now you should have well over 2 h of flying available to get down safely somewhere. Heck, I can't remember the last time I flew my Piet more than 2 h in one flight. To keep the battery charged while your not flying, just use one of those 5W chargers. I use one for the Piet's battery and it easily keeps it topped up. HTH, Jeff On Sun, Feb 27, 2011 at 6:08 PM, wrote: > Hi Pieters, > > I have been working diligently (and slowly) on rebuilding my "A" since the > mishap last Sept. when my timing gear disintegrated. I decided to continue > to use my 8-plug head, powered by one crank-driven mag, and a hybrid > electronic ignition/battery ignition system. I bought a 4.4 lb. battery from > ACS, which will energize the coil (looks like standard Model A coil) via a > small electronic ignition module. I am imagining a small solar panel mounted > on the fuel tank cover, to charge the battery. > > OK let the flames begin. (it's OK because I used Fiberfrax) And no smart > ass remarks like "What would Bernerd say, Dan?" > > Dan Helsper > Puryear TN., (until tomorrow only) > ________________________________________________________________________________
Date: Mar 01, 2011
..." 'may' work fine for- years and years but then again may not." That i s true for any part of any plane...your spreader bar as an example. - Comparing spreader bars to rudder bars is not a good comparison. Spreader b ars are under stress all the time...pushing back on the- tension from the -four 1/8" L.G. cables. The rudder bar is only under stress while someone is in the pilot seat.- How about those forces? Four 1/8" cables trying t o compress the spreader bars, (how tight are those?)compared to...I don't k now... two heavy feet-on the rudder bar? Then there are the forces on the spreaders when actually making a landing...and I would venture a guess, a few HARD landings. I just don't see a comparison here. Different regions of the plane, way different forces. - You used SS tube. You smashed the ends flat. (Induced stress, maybe cold wo rked as well.) Then you bent those smashed ends. ( More stress) Curious...Y ou know when you smash the ends, those really, really tight bends that allo w the two sides of the tube to come together, aren't those bends-IN LINE with the grain? At some point, you put a 1/4" hole in that smashed, bent en d as well and yet got 13 years out of it!- What did you replace your spre ader bars with? I believe you said you used- a heavier wall S.S. tube...y es? I believe you also said that if you have to replace them every 13 years or so, that's cool. - Your story about the broken bar, loved one in the plane, tall trees, fuel, hot exhaust, etc. is entertaining but nothing more then a "what if."-- Your spreader bar COULD have let go at altitude, smashing through the winds hield of a school bus full of kids on the high way, killing the driver, the bus crosses over to in on-coming traffic, smashing another school bus head on, killing everyone in both buses, plus the surrounding vehicles that cou ld not get out of the way in time. Then as you make an unexpected hard land ing, your gear folds on one side, the wing tip drags... then starts the car twheel... you get my drift. - I believe that the 3/16" clevis pins are NOT going to pull through the smas hed ends of the now- .065" wall stainless. I would also bet that there wo n't be enough stress to have that 5/16" bolt at the pivot pull through the entire length of the sleeve and .035" wall tube. (3/4" tube) I guess it is possible that the bar could bend if I were to freak out and press to hard o n both ends.- I guess that is something to be aware of...no more then bei ng aware to make sure the fuel cap is on right. - "...cheaping out"... Saving a few bucks is not the point. Not sure why ever y time a change is made people assume it is money related.- - You are correct about the placard...that says it all. - Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 01, 2011
Hoo-boy, what a response. Michael (as opposed to Mike), your argument is way off base. The spreader bars are NOT under a great deal of stress. The cross brace cables should only have enough tension in them to take up the slack. And in the straight axle gear, the axle essentially floats above the gear, attached by bungees. The point is that the straight axle doesn't impose side loads like the split gear would, therefore, even in a rough landing, there will not be extreme forces transmitted to the spreader bars. Nonetheless, as Mike related, his stainless steel spreaders did fail. The rudder bar, however CAN and WILL be exposed to considerable forces exerted by the pilot. Have you ever had to stop a vehicle suddenly, and find yourself pressing the brake pedal with all your strength? Pressing the pedal harder after the brakes have locked will do no good, yet that is what we do, as humans. In a moment of panic, the rudder bar will very likely be exposed to forces far greater than it should see under "normal" conditions. There are some metal parts on the Pietenpol that can safely be replaced by stainless steel, but unless the wall thickness and/or O.D. is increased appropriately, the rudder bar isn't one. As I pointed out earlier, this is one of the few items that specifically call for cro-moly. If the plans had called for 1020 steel, then st.st. would provide a similar strength, but compared to 4130, st.st. is only half as strong. I realize that you are building YOUR plane, and doing it the way YOU want, and that's your prerogative. The only reason I'm bothering to respond is for the benefit of other builders out there who might be misled by your latest post. I've said my bit, and I'll now bow out of this discussion. Feel free to build as you please. We're only trying to give you a hand, but if you don't want to listen, that's your choice. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332438#332438 ________________________________________________________________________________
Date: Mar 01, 2011
Subject: what to use and what to fly with comfortably--an ongoing
discussion There have been many accounts by very highly educated people of why or why not we might prefer to use various metals and aircraft grade (which are READILY available) hardware or not on a plans-built homebuilt design but I herewith withdraw my desire to test fly the gorgeously-built airplane by Michael Perez. I think if YOU feel comfortable with all the changes you have made in the airplane and bill of materials that you in fact should be the test pilot and I will be there at Columbia Airport cheering you on and being one of the very first to congratulate you on your first test flight but will take no part in flying off the test time nor ever get into your airplane for any subsequent rides or flights thereafter. The plans built airplane is to the utmost the MOST experimental plane in the air today in the United States of America and thank GOD we don't have to go thru the rigors of the PFA or the mess that the other countries prescribe they go thru just to change a nut or bolt here and there. Happy flying to all and to all a Good Night ! Mike C. Ohio ________________________________________________________________________________
Date: Mar 01, 2011
Dan: Would you be interested in selling your side mounted magneto setup? I might be interested if it is available. I've followed your troubles on the list, and I think the gear driven mag could be made to be very reliable with careful setup of gear mesh. I would be concerned that a standby ignition system that is turned off most of the time would suffer from fouled plugs. Brett Phillips Strasburg, VA NX311GP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332443#332443 ________________________________________________________________________________
Date: Mar 01, 2011
Nicely put, Bill. Michael, the question for me is, why would you WANT to use stainless steel? Other than being slightly more corrosion resistant than chromoly (it is NOT rust proof, but is corrosion resistant), it is generally an inferior material. It has less tensile strength, as has already been discussed, is more expensive, work hardens fairly rapidly and is difficult to drill. What possible advantage does it have? It probably will be adequate for the task, but as was mentioned earlier, it would be fairly simple to test it for this application by making a mockup and applying pressure with both feet. But why use it? It will need the ends squeezed flat and welded, just as Mike's spreader bars were done. Stainless steel (particularly the austenitic grades, such as 18-8, or the rest of the 300 series stainless steels) is useful for silverware and hypodermic needles and other applications where corrosion resistance is a key requirement. It is not much used in aircraft work because other materials are better suited. Try titanium. It has better strength, although not as much stiffness as stainless. And it has even better corrosion resistance. I suggest you listen well to Bill Church, since he is an engineer who spends nearly every day designing for stainless steel. He knows his stuff. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Church Sent: Tuesday, March 01, 2011 9:31 PM Subject: Pietenpol-List: Re: Rudder bar and forward controls Hoo-boy, what a response. Michael (as opposed to Mike), your argument is way off base. The spreader bars are NOT under a great deal of stress. The cross brace cables should only have enough tension in them to take up the slack. And in the straight axle gear, the axle essentially floats above the gear, attached by bungees. The point is that the straight axle doesn't impose side loads like the split gear would, therefore, even in a rough landing, there will not be extreme forces transmitted to the spreader bars. Nonetheless, as Mike related, his stainless steel spreaders did fail. The rudder bar, however CAN and WILL be exposed to considerable forces exerted by the pilot. Have you ever had to stop a vehicle suddenly, and find yourself pressing the brake pedal with all your strength? Pressing the pedal harder after the brakes have locked will do no good, yet that is what we do, as humans. In a moment of panic, the rudder bar will very likely be exposed to forces far greater than it should see under "nor! mal" conditions. There are some metal parts on the Pietenpol that can safely be replaced by stainless steel, but unless the wall thickness and/or O.D. is increased appropriately, the rudder bar isn't one. As I pointed out earlier, this is one of the few items that specifically call for cro-moly. If the plans had called for 1020 steel, then st.st. would provide a similar strength, but compared to 4130, st.st. is only half as strong. I realize that you are building YOUR plane, and doing it the way YOU want, and that's your prerogative. The only reason I'm bothering to respond is for the benefit of other builders out there who might be misled by your latest post. I've said my bit, and I'll now bow out of this discussion. Feel free to build as you please. We're only trying to give you a hand, but if you don't want to listen, that's your choice. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332438#332438 ________________________________________________________________________________
Date: Mar 01, 2011
Subject: you make your choices---you take your chances
Mike-- I'm not here to debate the stresses of the spreader bars vs. the rudder bar, all I am saying is that with such a PRIMARY control you should reconsider using non-4130 grade tubing for your rudder bar but hey....that's the beauty of homebuilding---you can use whatever you want... just count me out as ever being your test pilot or passenger. Period. As long as YOU feel comfortable with your choices then YOU can do the test flying. Mike C. NX48MC ________________________________________________________________________________
Date: Mar 01, 2011
Michael P., Just how much tailwheel time do you have, and how long have you been flying? Although I don't have a tailwheel endorsement on my license yet, it seems to me that the single most important control in a taildragger airplane is the rudder. I could be wrong on this, but I don't think so. But is this REALLY the place where you should be substituting inferior materials in your Perezenpol "just because"? If you decide not to use the SS tube, I have some leftover 1/2" type L (soft) copper plumbing pipe here I'll donate to you, it's probably lighter than the SS... With as much deviation from the plans as you have re-designed into your plane, it will hardly be recognizable as a Piet. I personally cannot figure out why you are going to such great lengths to re-engineer as much of the plane as possible when the existing design works just fine. You seem to ask a lot of questions, which is a very good thing. In my opinion and 20 years of experience as a professional firearms instructor, there's no such thing as a dumb question. However, you seem to ask your questions only in order to get validation for your sometimes rather strange or perhaps even dangerous ideas rather than to get honest answers from those who have engineering degrees, A&P certificates, and/or actually successfully built and flown their own planes. These people offer their opinions and ideas based on practical experience, and then you summarily dismiss them and do it your own way anyhow after all is said and done. I think Bernard got it pretty durn close 80 years ago, and I think most on the list would agree with me. I think the point of all of these warnings by the very generous and very knowledgeable people on this list who know better is that NOBODY wants to see you get hurt (or worse), or hurt someone else (or worse). I think it's a lot better to play the what-if game BEFORE something goes wrong than after. "What if I had only used 4130 for that rudder bar, then my plane might not be a pile of burning rags, splinters and inferior stainless tubing in that smoking hole in the weeds next to the runway." Sorry if I might have stepped on your toes, that's not my intention here. We all wish you the best and just want to see you build a SAFE airplane that won't kill you or somebody else, and the Piet as built to the plans IS ALREADY a proven, safe design that doesn't need massive re-engineering. In the words of Forrest Gump, "that's about all I got to say about that," stepping off my soapbox now. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332457#332457 ________________________________________________________________________________
Date: Mar 02, 2011
Subject: Re: Rudder bar and forward controls
That must be why I have TWO rudder bars! :-) Clif .What you need to be aware of is the potential for the > pilot to bend the rudder bar, by inadvertently pushing with both > feet. The pilot will undoubtedly have both feet pressing against > the rudder bar at all times, and a bit of uncoordinated > footwork, or panic can result in an excessive amount of pushing > on both sides of the rudder bar at the same time. > > Bill C. ________________________________________________________________________________
Date: Mar 02, 2011
Hi Brett, That plug fouling thing has some merit. I had not thought of that aspect. I am not sure if I want to sell that side mount mag set-up, until things pan out. Thanks for your input. Dan Helsper Poplar Grove, IL. -----Original Message----- From: Brett Phillips <bphillip(at)shentel.net> Sent: Tue, Mar 1, 2011 9:10 pm Subject: Pietenpol-List: Re: Slow list day.........How about this idea? t> Dan: ould you be interested in selling your side mounted magneto setup? I might be nterested if it is available. I've followed your troubles on the list, and I hink the gear driven mag could be made to be very reliable with careful set up f gear mesh. I would be concerned that a standby ignition system that is urned off most of the time would suffer from fouled plugs. Brett Phillips trasburg, VA X311GP ead this topic online here: http://forums.matronics.com/viewtopic.php?p=332443#332443 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Mar 02, 2011
Every single person on here=2C most with a LOT of experience=2C have said i t is a bad idea. If you are going to do it anyway=2C enough with the justi fications and somewhat insulting remarks. Just do it and let's move on. Gene Rambo Date: Tue=2C 1 Mar 2011 17:26:08 -0800 From: speedbrake(at)sbcglobal.net Subject: RE: Pietenpol-List: Re: Rudder bar and forward controls ..." 'may' work fine for years and years but then again may not." That is true for any part of any plane...your spreader bar as an example. Comparing spreader bars to rudder bars is not a good comparison. Spreader b ars are under stress all the time...pushing back on the tension from the f our 1/8" L.G. cables. The rudder bar is only under stress while someone is in the pilot seat. How about those forces? Four 1/8" cables trying to comp ress the spreader bars=2C (how tight are those?)compared to...I don't know. .. two heavy feet on the rudder bar? Then there are the forces on the sprea ders when actually making a landing...and I would venture a guess=2C a few HARD landings. I just don't see a comparison here. Different regions of the plane=2C way different forces. You used SS tube. You smashed the ends flat. (Induced stress=2C maybe cold worked as well.) Then you bent those smashed ends. ( More stress) Curious.. .You know when you smash the ends=2C those really=2C really tight bends tha t allow the two sides of the tube to come together=2C aren't those bends IN LINE with the grain? At some point=2C you put a 1/4" hole in that smashed =2C bent end as well and yet got 13 years out of it! What did you replace your spreader bars with? I believe you said you used a heavier wall S.S. t ube...yes? I believe you also said that if you have to replace them every 1 3 years or so=2C that's cool. Your story about the broken bar=2C loved one in the plane=2C tall trees=2C fuel=2C hot exhaust=2C etc. is entertaining but nothing more then a "what i f." Your spreader bar COULD have let go at altitude=2C smashing through t he windshield of a school bus full of kids on the high way=2C killing the d river=2C the bus crosses over to in on-coming traffic=2C smashing another s chool bus head on=2C killing everyone in both buses=2C plus the surrounding vehicles that could not get out of the way in time. Then as you make an un expected hard landing=2C your gear folds on one side=2C the wing tip drags. .. then starts the cartwheel... you get my drift. I believe that the 3/16" clevis pins are NOT going to pull through the smas hed ends of the now .065" wall stainless. I would also bet that there won' t be enough stress to have that 5/16" bolt at the pivot pull through the en tire length of the sleeve and .035" wall tube. (3/4" tube) I guess it is po ssible that the bar could bend if I were to freak out and press to hard on both ends. I guess that is something to be aware of...no more then being a ware to make sure the fuel cap is on right. "...cheaping out"... Saving a few bucks is not the point. Not sure why ever y time a change is made people assume it is money related. You are correct about the placard...that says it all. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 02, 2011
Subject: Re: what to use and what to fly with comfortably--an ongoing
discussion Understood. I had reached that same conclusion Mike, no need for anyone else to get into the pilot seat of my plane. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 02, 2011
Subject: Re: you make your choices---you take your chances
Noted and I concur. Period. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com --- On Tue, 3/1/11, Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] wrote: From: Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] <michael.d.cuy(at)nasa.g ov> Subject: Pietenpol-List: you make your choices---you take your chances Date: Tuesday, March 1, 2011, 11:20 PM SPACE CORP]" Mike-- I'm not here to debate the stresses of the spreader bars vs. the rud der bar, all I am saying is that with such a PRIMARY control you should reconsider using non-4130 grade tubing for your rudder bar but hey.. ..that's the beauty of homebuilding---you can use whatever you want... just count me out as ever being your test pilot or passenger.- Period.- --As long as YOU feel comfortable with your choices then YOU can do the test flying. Mike C. NX48MC le, List Admin. ________________________________________________________________________________
Date: Mar 02, 2011
I agree there are people here who actually know what they are talking about .-- As I have said I appreciate the comments and concerns by most here and I do think and rethink my position after reading such posts. I DO NOT a ppreciate the soap opera story telling just to suit ones own position nor t he degrading name calling.- I want to use SS here because that is what I want. I feel that even after reading these posts, knowing what material I u sed, how it was assembled and how it will be installed, I am comfortable us ing it as my rudder bar. I will keep an eye on it as with the rest of the p lane. True, the ends are squeezed and drilled, but they are not bent and I still feel the landing gear sees more abuse then a rudder bar. Mike got 13 years out of that bar, I bet I will get at least that out of my rudder bar. Seems most feel that a rudder failure of some sort is a death sentence. Rea lly? Is it imposable to make a landing without a rudder? I would rather not argue, but at times I feel some people just throw out wo rds, numbers and stories that are not true. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Mar 02, 2011
Hi, i'm new to this site, but not new to the field of aviation. I've been an army pilot for over 14 years, and flew many combat hours in Afghanistan. I"ve been following this thread, and i think i should throw in my two cents, so here it goes, If it calls it out in the prints, there's probably a good reason for it. Hey, if your going to subsitute Aircraft grade 4130 for SS, you might as well use yellow pine instead of spruce for the fuselage and spars too! Don't fly over southeast georgia. thanks. jt On Wed, Mar 2, 2011 at 8:52 AM, Michael Perez wrote: > I agree there are people here who actually know what they are talking > about. As I have said I appreciate the comments and concerns by most here > and I do think and rethink my position after reading such posts. I DO NOT > appreciate the soap opera story telling just to suit ones own position nor > the degrading name calling. I want to use SS here because that is what I > want. I feel that even after reading these posts, knowing what material I > used, how it was assembled and how it will be installed, I am comfortable > using it as my rudder bar. I will keep an eye on it as with the rest of the > plane. > > True, the ends are squeezed and drilled, but they are not bent and I still > feel the landing gear sees more abuse then a rudder bar. Mike got 13 years > out of that bar, I bet I will get at least that out of my rudder bar. > > Seems most feel that a rudder failure of some sort is a death sentence. > Really? Is it imposable to make a landing without a rudder? > > I would rather not argue, but at times I feel some people just throw out > words, numbers and stories that are not true. > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > * > > * > > ________________________________________________________________________________
Date: Mar 02, 2011
12,000 hours of experience tells me I would not want to lose my rudder control. Aileron, pitch, power and trim can all be dealt with. No rudder on a tailwheel aircraft? The best one can hope for is a violent ground loop on landing. Try your next approach with your feet on the floor through touch down and roll out. Let me know how it works out. Scott Knowlton -----Original Message----- From: Michael Perez <speedbrake(at)sbcglobal.net> Date: Wed, 2 Mar 2011 13:52:21 Subject: RE: Pietenpol-List: Re: Rudder bar and forward controls I agree there are people here who actually know what they are talking about. As I have said I appreciate the comments and concerns by most here and I do think and rethink my position after reading such posts. I DO NOT appreciate the soap opera story telling just to suit ones own position nor the degrading name calling. I want to use SS here because that is what I want. I feel that even after reading these posts, knowing what material I used, how it was assembled and how it will be installed, I am comfortable using it as my rudder bar. I will keep an eye on it as with the rest of the plane. True, the ends are squeezed and drilled, but they are not bent and I still feel the landing gear sees more abuse then a rudder bar. Mike got 13 years out of that bar, I bet I will get at least that out of my rudder bar. Seems most feel that a rudder failure of some sort is a death sentence. Really? Is it imposable to make a landing without a rudder? I would rather not argue, but at times I feel some people just throw out words, numbers and stories that are not true. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 02, 2011
Interesting.I just Googled, "Aircraft Stainless Steel Failures.".quite a bit of reading. Gary Boothe ________________________________________________________________________________
Date: Mar 02, 2011
Billy, no toe stepping felt here. Like the old saying, "It's not what you s ay, it's how you say it."- I'll answer your post in order of questions. I have about an hour or so tail wheel time. No landings and No take offs. I have about 20 min. of on ground slow taxi practice. (basically no time) -I disagree on the rudder being the single most important control. "...hardly be recognizable as a Piet." That sounds like one of those over t he top, no merit stories. Sure I have made changes...who hasn't? Most cosme tic, but none changes the overall look of the plane. My rudder bar still lo oks like a rudder bar. The fuselage, gear, wings, tail..all Pietenpol. Not sure where this idea of not being recognized comes from. I mainly ask questions to see if anyone else has tried, or knows someone wh o has tried, the same thing. However, I did not ask if my rudder bar is OK to change.- It was brought up by another person from another post. If som eone could HONESTLY tell me that a SS rudder bar has failed in a Pietenpol, I would reconsider. ..."These people offer their opinions and ideas based on practical experien ce..."- Not always true. Most of the time yes, but not always. Sure, the plane as drawn works fine. People have made changes over the year s and I bet most of those were frowned upon at first. I understand the gene ral concern here, but it seems that if a persons plane is not built to the plans, not built the way others have already done it or not built to the li king of everyone else, then there is a big upheaval. ..." I think it's a lot better to play the what-if game BEFORE something go es wrong..." Your assuming something is going to go wrong. However, I agree with this statement, so I ask the questions you may find strange on this l ist. But when I do, the upheaval begins. It's difficult to inquire about "a lternatives" knowing your going to get hammered for it. But I do so anyway, because I want to know..not to start a fight. ""What if I had only used 4130 for that rudder bar, then my plane might =0A not be a pile of burning rags, splinters and inferior stainless tubing =0Ai n that smoking hole in the weeds next to the runway." Good story, here's another: After countless hours of flight time, bad weather, bad landings, crosswind landings and panicked feet, the SS rudder bar has performed flawless to thi s day and will continue to do so for many, many years to come. "... doesn't need massive re-engineering." Agreed. To some, my changes may be considered mass re-engineering, but I believe that may be a little extre me. I do not consider the changes massive. All in all I have read all the comments and I have a decision to make about the rudder bar. My apologies to those who do not agree, and get upset. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com - ________________________________________________________________________________
Subject: Re: Slow list day.........How about this idea?
Date: Mar 02, 2011
I'm glad to hear that you haven't completely given up on the side drive. Keep in mind that you could always find a WICO model X that plugs into the distributor hole. They are not the prettiest thing in the world but as the old folks used to say, "Pretty is as Pretty does". They turn up on Ebay frequently, and parts are available from Standard Magneto Sales in Chicago. Brett Phillips Strasburg, VA NX311GP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332490#332490 ________________________________________________________________________________
Date: Mar 02, 2011
Subject: Wing Strut Fuse. Attach.
If memory servers, the plans show the steel wing strut being bolted directly to the fuselage fitting. The strut slips over the fitting and gets bolted through with a single 5/16" bolt. I would like to use that same attaching method with my aluminum strut. My plan is to weld onto the aluminum strut, aluminum plates to beef up the bolt hole area. My question is how thick do these plates need to be and how large? (area over the strut) If you go to the West Coast Piet. site, Jim Markle's pictures, page 4, second to last picture, you will see what I mean. The difference being that I plan to bolt directly to the fitting..no straps. My math: 1/4" plate X2 plus the .119" wall of the tube = .25(2) + .119"(2) = .738" .469" edge spacing X .738 = .346" sq. .346"sq. X 11,600PSI (shear for the strut tube) = 4,013 lbs. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 02, 2011
Subject: Re: Wing Strut Fuse. Attach.
On 3/2/2011 11:05 AM, Michael Perez wrote: > My plan is to weld onto the aluminum strut, aluminum plates to beef up the bolt hole area. You do know that welded aluminum takes on the structural properties of cheese? 6061-T6 will eventually return to about the T4 condition, but at best it's much less strong than after proper heat-treating, which is beyond amateur capabilities. 2024 is generally considered not to be weldable. You can stick two pieces together, but don't expect them to remain that way under stress. The Honey Bee and Pegasus ultralights, with fuselages made of welded square aluminum tube, only look like they disprove the above. The guy who designed them sized the tubing so it would be strong enough for use in a small, lightly stressed airplane even after welding. Then he made sure to keep the heat-affected zone as small as possible. Considering the above, the notion of welding plates onto your struts worries me. I believe the usual technique is to bolt a piece of square aluminum stock inside the airfoil strut, and then bolt through the square stock to the strut fittings. FWIW Owen ________________________________________________________________________________
Date: Mar 02, 2011
I was aware of some softening, but I did not know to what degree. I know some use the aluminum insert threaded for a fork end, there is that option as well. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 02, 2011
Michael: 6061 aluminum has an ultimate tensile strength of 45,000 psi in the T6 condition. The as-welded UTS of material within the heat affected zone can be as HIGH as 24-25,000 psi if proper procedures are used with strict adherence to interpass temperatures. In short, it really does turn into bubble gum once it is heated. After naturally aging for a long period of time, the T4 condition MAY be achieved, which would give ~40,000 psi. I'm an AWS welding inspector, and I like bolts for this application. Brett Phillips Strasburg, VA NX311GP > I was aware of some softening, but I did not know to what degree. I know some use the aluminum insert threaded for a fork end, there is that option as well. > > Michael Perez > > Karetaker Aero > > www.karetakeraero.com > > --------------------------------------------- This message was sent using Shentel WebMail. http://WebMail.Shentel.Net ________________________________________________________________________________
Date: Mar 02, 2011
Thats the way all float fittings are done-bolted. I would not weld anythin g aluminum that is structural. Doug Dever In beautiful Stow Ohio > Date: Wed=2C 2 Mar 2011 11:33:27 -0500 > From: owen5819(at)comcast.net > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Wing Strut Fuse. Attach. > > > On 3/2/2011 11:05 AM=2C Michael Perez wrote: > > > My plan is to weld onto the aluminum strut=2C aluminum plates to beef > up the bolt hole area. > > You do know that welded aluminum takes on the structural properties of > cheese? 6061-T6 will eventually return to about the T4 condition=2C but a t > best it's much less strong than after proper heat-treating=2C which is > beyond amateur capabilities. 2024 is generally considered not to be > weldable. You can stick two pieces together=2C but don't expect them to > remain that way under stress. > > The Honey Bee and Pegasus ultralights=2C with fuselages made of welded > square aluminum tube=2C only look like they disprove the above. The guy > who designed them sized the tubing so it would be strong enough for use > in a small=2C lightly stressed airplane even after welding. Then he made > sure to keep the heat-affected zone as small as possible. > > Considering the above=2C the notion of welding plates onto your struts > worries me. I believe the usual technique is to bolt a piece of square > aluminum stock inside the airfoil strut=2C and then bolt through the > square stock to the strut fittings. > > FWIW > > Owen > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 02, 2011
Keep in mind that you must desing to yeild strength=2C not ultimate. Only NASA designs to ultimate strength. Doug Dever In beautiful Stow Ohio > To: pietenpol-list(at)matronics.com > From: bphillip(at)shentel.net > Subject: Re: Pietenpol-List: Wing Strut Fuse. Attach. > Date: Wed=2C 2 Mar 2011 18:44:16 +0000 > > > Michael: > > 6061 aluminum has an ultimate tensile strength of 45=2C000 psi in the T6 > condition. The as-welded UTS of material within the heat affected zone ca n be as > HIGH as 24-25=2C000 psi if proper procedures are used with strict adheren ce to > interpass temperatures. In short=2C it really does turn into bubble gum o nce it is > heated. After naturally aging for a long period of time=2C the T4 conditi on MAY be > achieved=2C which would give ~40=2C000 psi. I'm an AWS welding inspector =2C and I like > bolts for this application. > > Brett Phillips > Strasburg=2C VA > NX311GP > > > > I was aware of some softening=2C but I did not know to what degree. I k now some > use the > aluminum insert threaded for a fork end=2C there is that option as well. > > > > Michael Perez > > > > Karetaker Aero > > > > www.karetakeraero.com > > > > > > --------------------------------------------- > This message was sent using Shentel WebMail. > http://WebMail.Shentel.Net > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: HINT videos - caveat emptor
Date: Mar 02, 2011
The recent discussions about material substitutions got me thinking. Michael, you are offering for sale a series of "HINT" videos that cover the construction of your plane. And you have discussed here on the List some of the changes that you have incorporated into your particular project. There may be other changes that you have not shared with the List. As I recall, from your posts, this is the first aircraft that you have built. I was wondering whether you make it clear in your videos that the changes you have made are variations from the plans, and are unproven. I use that word "unproven" because there have been several times where you have described how you have varied from the plans, and standard aircraft building practices or engineering advice. Based on those criteria, many of your changes will really remain unproven until they have been demonstrated to work in actual flight conditions and stand the test of time. I just can't help but wonder about the sensibility of offering "instructional" videos documenting a number of changes that are not backed up by technical data and/or practical aircraft building experience. Your website states that you give reasons for the changes that you made, and the processes used, but do you provide any science or data to back up your new designs? Luckily, you are not offering plans for any of your changes. Hopefully anyone purchasing your videos is aware of the situation, and is using them for entertainment purposes only. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332520#332520 ________________________________________________________________________________
Subject: Re: HINT videos - caveat emptor
Date: Mar 02, 2011
Hear Hear! -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332523#332523 ________________________________________________________________________________
Date: Mar 02, 2011
ABSOLUTELY! Brett > > Keep in mind that you must desing to yeild strength, not ultimate. Only > NASA designs to ultimate strength. > > Doug Dever > In beautiful Stow Ohio --------------------------------------------- This message was sent using Shentel WebMail. http://WebMail.Shentel.Net ________________________________________________________________________________
Date: Mar 02, 2011
Hey, this conversation sounds familiar... Oh, I know why. See this thread from a few years ago: http://forums.matronics.com/viewtopic.php?t=46368 Let's see, 40 percent reduction from 45000 would be about 27000 - yup, looks like the science hasn't changed in the last three years. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332532#332532 ________________________________________________________________________________
Date: Mar 02, 2011
That's it... I'm scrapping my control horns. :( -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332548#332548 ________________________________________________________________________________
Date: Mar 02, 2011
Yes Bill. The videos are more of a video log of my building process and not so much- instructional videos. I should be more clear about that on the website...thanks for the heads up. Michael Perez Karetaker Aero www.karetakeraero.com - ________________________________________________________________________________
Date: Mar 02, 2011
Hey guys, how about getting Michael to come to brodhead and giving a forum on how to reinvent the wheel. I am happy with how my plane flies and handle s. Another subject--- anyone- out there interested in having a rendevoux at TRIPPLE TREE AERODROME to their fly in the week after Labor Day? I plan on going as it looks like a very neat place to camp out. It is just SE of F ountain Inn SC --- On Wed, 3/2/11, Michael Perez wrote: From: Michael Perez <speedbrake(at)sbcglobal.net> Subject: Re: Pietenpol-List: HINT videos - caveat emptor Date: Wednesday, March 2, 2011, 5:52 PM =0A=0A=0A=0AYes Bill. The videos are more of a video log of my building pro cess and not so much- instructional videos. I should be more clear about that on the website...thanks for the heads up. Michael Perez Karetaker Aero www.karetakeraero.com =0A=0A-=0A ________________________________________________________________________________
Date: Mar 02, 2011
Subject: Re: with all the fuss--
I had an even better Idea to save weight and un-complicate the rudder bar. - I am thinking of just putting stirups on the ends of the rudder cables, strap them directly to my feet with some leather staps, and a buckle, I wo uld have a very good feel for the rudder that way, -that should be good.. .....................right. - - Just Kidding Y'all, - Shad=0A=0A=0A ________________________________________________________________________________
Date: Mar 02, 2011
Mike, Thank you for that elegant reply. I followed the rudder bar thread yesterday and was concerned that things were getting a little testy. This forum is so much more civil than some I have followed, and left. I think it is important that you pointed out Mike Perez's background. There is no substitute for actual hands on experience, feeling the materials and knowing their limitations. This forum represents a lot of talent. I know because I have seen some of the flying examples up close. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332582#332582 ________________________________________________________________________________
Date: Mar 02, 2011
Subject: Oscar's articles
Oscar, I just read your engine article in Sport Aviation. I had previously read it in Contact, but again thoroughly enjoyed it in SA. Congratulations on a well-crafted piece. Jeff ________________________________________________________________________________
Subject: Light-weight alternator/generator?
Date: Mar 03, 2011
Hello All, I would like to keep going forward with this electronic ignition/batt syste m idea. Buying a larger amp/hour batttery to extend the flying time to two hours would work, but then I am still left with a dead battery at the end o f the flight which would I'm sure become a real pain quickly. So maybe I wi ll keep my 4.4 lb. battery and use the extra weight allowance by installing some mini alternator? I found one in the Pegasus Auto Racing catalog (6 lb s) that puts out a whole 50 amps for $279.00. A bit pricey I thought but ma ybe I could bite the bullet. I know Ken Perkins installed a (I think it was a Kabota) small alternator on his Model A. Does anyone know more about thi s? I looked at my engine briefly last night and it looks like installation of such a thing would not be so hard. Just mount to the side, and in-line w ith the water pump drive belt. How much power do these types of set-ups rob from the engine? Any help or opinionated feedback would be appreciated. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Mar 03, 2011
Thanks to all who commented on my article on Continental engines. I love these engines and I love to write, so it was an easy and fun piece to research and write about. I also fly behind one of these engines, so it's more than just a labor of love... it's sort of like a marriage in that I depend on my engine, I have to trust it, care for it, and respect its limitations and weaknesses. And obviously, it relies on me for its care and attention. To those who have a leaning towards, or away from, certified "real" aircraft engines or converted automobile engines, let me just say that these are all just machines that are made by humans using other machines and materials. They have strengths and weaknesses. What I have found about the Continentals that we use on our airplanes is that the vast majority of them have been around for a very long time and very few of them have an impeccable service history. Even with all the logbooks and the proper pedigree, very few of them are exactly in the form that their certification requires. There will be a technical article coming up in our EAA Chapter 35 newsletter by my friend R.B. "Doc" Hecker, in collaboration with A&P Mark Julicher (who did the last annual on my Piet and who loves these old airplanes as much as anyone I've met), about just how spooky the inside of some of these engines can be. When the article comes out, I'll post the link here for the benefit of others. The article will have all the makings of a good mystery novel: good intentions gone bad, things going 'bump' in the night (daytime, in this case), lots of money, vile cursing, and surprises at every twist and turn. The culprits are found and brought to justice, but getting there isn't pretty and lives hung in the balance ;o) Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 03, 2011
Dan have you looked at the Gennipod from Great Plains? At $250.00 it is pr icey=2C but its wind driven so the install would be easy. I saw plans for a home made one using a R/C model starter=2C but I can't for the life of me find the web site. Doug Dever In beautiful Stow Ohio Subject: Pietenpol-List: Light-weight alternator/generator? From: helspersew(at)aol.com Date: Thu=2C 3 Mar 2011 07:10:56 -0500 Hello All=2C I would like to keep going forward with this electronic ignition/batt syste m idea. Buying a larger amp/hour batttery to extend the flying time to two hours would work=2C but then I am still left with a dead battery at the end of the flight which would I'm sure become a real pain quickly. So maybe I will keep my 4.4 lb. battery and use the extra weight allowance by installi ng some mini alternator? I found one in the Pegasus Auto Racing catalog (6 lbs) that puts out a whole 50 amps for $279.00. A bit pricey I thought but maybe I could bite the bullet. I know Ken Perkins installed a (I think it w as a Kabota) small alternator on his Model A. Does anyone know more about t his? I looked at my engine briefly last night and it looks like installatio n of such a thing would not be so hard. Just mount to the side=2C and in-li ne with the water pump drive belt. How much power do these types of set-ups rob from the engine? Any help or opinionated feedback would be appreciated. Dan Helsper Poplar Grove=2C IL. ________________________________________________________________________________
Subject: Re: Light-weight alternator/generator?
Date: Mar 03, 2011
Thanks Doug, Maybe this is the way to go. It's more "Pietenpol-ish" anyway. I'll look at it for sure. Dan Helsper Poplar Grove, IL. -----Original Message----- From: Doug Dever <chiefpepperhead(at)hotmail.com> Sent: Thu, Mar 3, 2011 8:03 am Subject: RE: Pietenpol-List: Light-weight alternator/generator? Dan have you looked at the Gennipod from Great Plains? At $250.00 it is pr icey, but its wind driven so the install would be easy. I saw plans for a home made one using a R/C model starter, but I can't for the life of me fin d the web site. Doug Dever In beautiful Stow Ohio Subject: Pietenpol-List: Light-weight alternator/generator? From: helspersew(at)aol.com Date: Thu, 3 Mar 2011 07:10:56 -0500 Hello All, I would like to keep going forward with this electronic ignition/batt syste m idea. Buying a larger amp/hour batttery to extend the flying time to two hours would work, but then I am still left with a dead battery at the end o f the flight which would I'm sure become a real pain quickly. So maybe I wi ll keep my 4.4 lb. battery and use the extra weight allowance by installing some mini alternator? I found one in the Pegasus Auto Racing catalog (6 lb s) that puts out a whole 50 amps for $279.00. A bit pricey I thought but ma ybe I could bite the bullet. I know Ken Perkins installed a (I think it was a Kabota) small alternator on his Model A. Does anyone know more about thi s? I looked at my engine briefly last night and it looks like installation of such a thing would not be so hard. Just mount to the side, and in-line w ith the water pump drive belt. How much power do these types of set-ups rob from the engine? Any help or opinionated feedback would be appreciated. Dan Helsper Poplar Grove, IL. st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank>http://www.matronics.com/contribution -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Mar 03, 2011
From: "bradandlinda tds.net" <bradandlinda(at)tds.net>
To Dan Helsper re long lasting battery. look up Odyssey batteries. They have the unique quality of having both heavy cranking and deep cycle. The military uses them for vehicles that are in storage for long periods of time. Great for trolling motors. I have one in my Piet. Brad Williams NX29NX> On Thu, Mar 3, 2011 at 8:01 AM, Doug Dever wrote: > Dan have you looked at the Gennipod from Great Plains? At $250.00 it is > pricey, but its wind driven so the install would be easy. I saw plans for a > home made one using a R/C model starter, but I can't for the life of me find > the web site. > > Doug Dever > In beautiful Stow Ohio > > > ------------------------------ > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Light-weight alternator/generator? > From: helspersew(at)aol.com > Date: Thu, 3 Mar 2011 07:10:56 -0500 > > > Hello All, > > I would like to keep going forward with this electronic ignition/batt > system idea. Buying a larger amp/hour batttery to extend the flying time to > two hours would work, but then I am still left with a dead battery at the > end of the flight which would I'm sure become a real pain quickly. So maybe > I will keep my 4.4 lb. battery and use the extra weight allowance by > installing some mini alternator? I found one in the Pegasus Auto Racing > catalog (6 lbs) that puts out a whole 50 amps for $279.00. A bit pricey I > thought but maybe I could bite the bullet. I know Ken Perkins installed a (I > think it was a Kabota) small alternator on his Model A. Does anyone know > more about this? I looked at my engine briefly last night and it looks like > installation of such a thing would not be so hard. Just mount to the side, > and in-line with the water pump drive belt. How much power do these types > of set-ups rob from the engine? > Any help or opinionated feedback would be appreciated. > > Dan Helsper > Poplar Grove, IL. > > > * > > st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > * > > * > > * > > ________________________________________________________________________________
Subject: The Latest Buzz on Rudder Bar Material
Date: Mar 03, 2011
Since I'm on a self-imposed moratorium (for 18 more days) on noting the dangers of using a Corvair to power an airplane, I've enjoyed the discussion about rudder bar materials. However, I want to point out that we are getting dangerously close to being as unfriendly, unhelpful and downright mean as the RV-10 List has gotten. I think a lot of us (myself included) felt that Michael Perez had asked what materials people had used on their rudder bars, and then, when reasons were advanced why stainless steel should NOT be used, he announced that he would use it anyway. This was often the behavior of The Fisherman, of years past, who would propose to do something and ask if there was a problem. Several people would go to the trouble of explaning exactly why this might be a problem, and then he would announce that he would proceed with his way anyhow. He was not looking for advice, but for validation for his choice. However, this was NOT the situation on the rudder bar discussion. In this situation, Ken Heide initially asked about using cold rolled tubing (?) for the rudder bar instead of "structural tubing". Mr. Perez indicated that he had used .035" wall stainless steel for his ALREADY CONSTRUCTED rudder bar. He was neither asking for advice or validation. As he said repeatedly, in several emails, " I feel comfortable with my rudder bar set up." I think we owe Michael an apology. It is absolutely his choice what materials to use. It is our choice whether we would fly in such an airplane or not. That's the beauty of Experimental Aviation. I suspect that after all the hoopla over his choice of materials, Michael will make it a point on his preflight inspections to check the rudder bar for cracking. Stainless steel is not so bad a material that it will fail catastrophically without yielding and with no warning. The great thing about this List (and I really feel that the Pietenpol List is unique in this) is that people feel welcome to ask questions and offer advice. There is no "credentialing" to determine who is able to offer advice, so it takes a while to figure out who knows what they're talking about and who doesn't. I don't think any of us want to see this list get so vitriolic that people are afraid to ask questions or offer advice for fear of being publicly ridiculed. Remember, "We're all Snowflakes". No two Pietenpols are identical, and we've all made changes to the design (horror of horrors, Dan Helsper is now adding electronic ignition, and an electrical system to support it, to his pristine Model A Pietenpol). I myself had a forced landing in my Pietenpol because I used stainless steel (there's that word again) wool in the heat muffs for carb heat. Even a reliable old Continental can't run very well when it ingests a wad of stainless steel. Thank goodness the crankshaft didn't snap. Let's try to keep it friendly and remember that as much as we love these airplanes, the really valuable thing about being involved with Pietenpols is the friendships we gain through this airplane. Some of the people I've met on this list I now count as my very best friends. Only 141 more days until Brodhead. Jack Phillips NX899JP "Icarus Plummet" (which plummeted through trying to digest stainless steel) Raleigh, NC ________________________________________________________________________________
Date: Mar 03, 2011
From: Gerry Holland <gholland@content-stream.co.uk>
Doug Here is a PDF with some detail. Gerry ________________________________________________________________________________
Subject: Re: Jim Markle/Others Help
Date: Mar 03, 2011
I would not do it that way again. I would do the struts exactly the same way Larry Williams did his. Two bolts, spaced a bit apart and no doubler plates. Someone mentioned that the welding process can possibly introduce a tiny bit of localized weakening in the integrity of the material. And that got me to wondering if it was actually worth the trouble. Honestly, part of my motivation was to have my brother, a master craftsman with anything welding related, be a part of the project. I've actually considered grinding them off but have decided to just leave well enough alone. I did the math (with some help from a couple smart guys here on the list) and I'm comfortable with the Carlson struts. Just wouldn't go to the trouble of doubling up for the bolt holes. I don't remember the thickness of the plates we welded on but would be glad to go measure if you want to know. I would also use something a bit thinner if I was going to weld on those plates again. JM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332630#332630 ________________________________________________________________________________
Date: Mar 03, 2011
Subject: Re: The Latest Buzz on Rudder Bar Material
Thank you jack. Your post hits on a lot of very key points. Maybe coming from you, they will get noticed. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 03, 2011
I agree Jack, well said. =0A=0AI enjoy reading Michael's contributions and the following debate/discussion but =0Ait seemed it has taking a turn for t he worse latley. =0A=0A=0A=0ARyan M=0A=0A=0A=0A____________________________ ____=0AFrom: Jack Phillips <pietflyr(at)bellsouth.net>=0ATo: pietenpol-list@ma tronics.com=0ASent: Thu, March 3, 2011 9:59:23 AM=0ASubject: Pietenpol-List : The Latest Buzz on Rudder Bar Material=0A=0A=0ASince I=99m on a sel f-imposed moratorium(for 18 more days)onnotingthedangersof =0Ausing a Corva ir to power an airplane, I=99ve enjoyed the discussion about rudder =0Abar materials.=C2- However, I want to point out that we are getting da ngerously =0Aclose to being as unfriendly, unhelpful and downright mean as the RV-10 List has =0Agotten.=0AI think a lot of us (myself included) felt that Michael Perez had asked what =0Amaterials people had used on their rud der bars, and then, when reasons were =0Aadvanced why stainless steel shoul d NOT be used, he announced that he would use =0Ait anyway.=C2- This was often the behavior of The Fisherman, of years past, who =0Awould propose to do something and ask if there was a problem.=C2- Several people =0Awould go to the trouble of explaningexactly whythis might be a problem, and then =0Ahe would announce that he would proceed with his way anyhow.=C2- He w as not looking =0Afor advice, but for validationfor his choice.=0AHowever, this was NOT the situation on the rudder bar discussion.=C2- In this =0As ituation,Ken Heide initially asked about using cold rolled tubing (?) for t he =0Arudder bar instead of=9Cstructural tubing=9D.=C2- Mr. P erez indicated that he had used =0A.035=9Dwall stainless steel for hi s ALREADY CONSTRUCTED rudder bar.=C2- He was =0Aneither asking for advice or validation.=C2- As he said repeatedly, in several =0Aemails,=9D I feel comfortable with my rudder bar set up.=9D=0AI think we owe Mic hael an apology.=C2- It is absolutely his choice what materials =0Ato use .=C2- It is our choice whether we would fly in such an airplane or not. =C2- =0AThat=99s the beauty of Experimental Aviation.=C2- I suspe ct that after all the hoopla =0Aover his choice of materials, Michael will make it a point on his preflight =0Ainspections to check the rudder bar for cracking.=C2- Stainless steel is not so bad =0Aa material that it will f ail catastrophically without yielding and with no =0Awarning.=0AThegreat th ing aboutthis List (and I really feel that the Pietenpol List is =0Aunique in this) is that people feel welcome to ask questions and offer advice.=C2 - =0AThere is no=9Ccredentialing=9Dto determine who is able t o offer advice, so it takes =0Aa while to figure outwho knows what they =99re talking about and who doesn=99t.=C2- I =0Adon=99tthi nk any of uswant to see this list get so vitriolic that people are =0Aafrai d to ask questions or offer advice for fear of beingpublicly ridiculed.=0AR emember,=9CWe=99re all Snowflakes=9D.=C2- No two Pieten pols are identical, and we=99ve all =0Amade changes to the design (ho rror of horrors, Dan Helsper is now adding =0Aelectronic ignition,and an el ectrical system to support it,to his pristine Model =0AA Pietenpol).=C2- I myself had a forced landing in my PietenpolbecauseI used =0Astainless ste el (there=99s that word again) wool in the heat muffs for carb heat. =C2- =0AEven a reliable old Continental can=99t run very well when it ingests a wad of =0Astainless steel.=C2- Thank goodness the crankshaft didn=99t snap.=0ALet=99s try to keep it friendly and remember that as much as we love these =0Aairplanes, the really valuable thing about being involved with Pietenpols is the =0Afriendships we gain through this airplane.=C2- Some of the people I=99ve met on this =0Alist I now c ount as my very best friends.=0AOnly 141 more days until Brodhead.=0AJack P hillips=0ANX899JP=C2-=9CIcarus Plummet=9D=C2- (which plumme ============ =0A=0A=0A=0A ________________________________________________________________________________
Date: Mar 03, 2011
Thanks Jim. Sounds like a good plan. By the way, I have looked at other pictures of yours on the WCP site...very nice. Michael Perez Karetaker Aero www.karetakeraero.com - ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Mar 03, 2011
Subject: good post Jack
Good post Jack and your points are very well taken. There was an Pietenp ol built by a gent in Ohio out of white pine (years ago) and Elmer's glue and it flew just fine for years until he had a stall-spin accident and put it into the trees at Brodhead. Only then were the inferior grades of lumber and glue discovered but until that point it flew just fine. My posts in this thread were to illuminate the simple fact that critical (a nd I think we could all agree that having any kind of flight control system trouble isn't desired under any circumstances and the rudder of course is even a cr itical ground control as well.) flight controls should be made of the best materials and assembled with standard AN hardware, period. Anything less is the builder's choice but should something happen in the future (God for bid) where an inferior material caused an accident, injury, or death I don't wan t to be the one on the list who didn't say something to the builder, whoeve r it is and I voice my opinion about not test flying Mike's airplane on the list be cause I want it to be publicly noted that just because some of us have lots of Pietenpol hours we should seriously consider the risks of just jumping in t o test fly a new ship that another person built unless you are very intima te with the materials used, the level of craftsmanship, and any modifications that deviate from the plans that are non-cosmetic in nature. This is a wonderful list and there are a group of fantastically knowledgeab le people on here with some incredible credentials and I for one as a techn ician (not an engineer by degree) look for solid, sound advice even now just to s oak up this knowledge that is so freely shared among us. I believe that t his discussion deviated from the simple facts to an emotional pissing contest a nd for that I apologize for my part in the drama that is not normally part of the list HOWEVER when I am asked by a builder to point out anything that looks slightly non-airworthy or questionable and I voice my thoughts (based on so und aircraft construction practices as outlined in all of the Tony Bingelis boo ks and elsewhere) and the advice is ignored, discarded, and dismissed I ten d to realize, as you said so well Jack that the builder has already made up his mind and I shouldn't waste my time in the future voicing concerns or thoughts about how to improve an assembly or make it safer or more reliable. Carry on all and keep making sawdust and fittings. There is NOTHING more e xciting than to see a new Pietenpol arrive on at Brodhead like we witnessed last year with Kevin Purt ee and Dan Helsper's planes making their debut and I look forward to guys like Gene Rambo and Mike Perez making first time app earances there too in addition to anyone else who might be closing in on the 8th and 9th innings of the building process ! Mike C. ________________________________________________________________________________
Date: Mar 03, 2011
"Thank goodness the crankshaft didn=99t snap" It's just soooooooo hard to stay away from that subject. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Mar 03, 2011
I have a Piper Cherokee that my wife loves to fly and I used to belong to a Cherokee board similar to this one. The nastiness, name calling, and political diatribes made it pretty much useless for anything except archive searches for a specific issue. I no longer visit it. The Pietenpol movement, and this board in particular, have been mostly immune from that sort of negativity and is one of the reasons I'm building one. Thank you Jack for reminding us of the need to read carefully and respond civilly and intelligently. Now back to making spruce sticks for Sun n Fun... Dave Aldrich Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332640#332640 ________________________________________________________________________________
Date: Mar 03, 2011
The Corvair guys sometimes use a John Deere alternator. It's light and puts out like 18 amps. Start thinking EFIS!!! Dave Aldrich Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332644#332644 ________________________________________________________________________________
Date: Mar 03, 2011
Dan go to ebay and search for: Permanent Magnet Alternator Kubota This is what I am going to use. It weighs maybe 3 pounds. I have a regulator that fits a lawn mower with a 15 amp under the flywheel. It is about the size of a book of gopher matches. I will make a temporary mount and an electric motor to test it all out before I mount it on the engine. If my memory is right Gardiner has one on his Piet. It is only a 15 amp output but that will take care of anything that I would ever want to do. Those Odyssey batteries are great. I have seen a PC-680 start an O-540. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332645#332645 ________________________________________________________________________________
Date: Mar 03, 2011
T25seSAxOCBtb3JlPyBJIHRob3VnaHQgaXQgd2FzIGF0IGxlYXN0IDI1ISAuLi5ob3cgdGltZSBm bGllcy4uLg0KDQpHYXJ5DQpEbyBub3QgYXJjaGl2ZQ0KU2VudCBvbiB0aGUgU3ByaW50riBOb3cg TmV0d29yayBmcm9tIG15IEJsYWNrQmVycnmuDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0t DQpGcm9tOiAiSmFjayBQaGlsbGlwcyIgPHBpZXRmbHlyQGJlbGxzb3V0aC5uZXQ+DQpTZW5kZXI6 IG93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tDQpEYXRlOiBUaHUsIDMg TWFyIDIwMTEgMDk6NTk6MjMgDQpUbzogPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+DQpS ZXBseS1UbzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbVN1YmplY3Q6IFBpZXRlbnBvbC1M aXN0OiBUaGUgTGF0ZXN0IEJ1enogb24gUnVkZGVyIEJhciBNYXRlcmlhbA0KDQpUaGlzIGlzIGEg bXVsdGktcGFydCBtZXNzYWdlIGluIE1JTUUgZm9ybWF0Lg0KDQo ________________________________________________________________________________
Date: Mar 03, 2011
what Bill said about what Jack said...... P.S. Anyone building, already completed, or even interested in a Pietenpol, no matter the material or engine choice, is welcome at "the world's smallest airplane factory" in Issaquah, WA... I appreciate the friendly nature of this "community" which is one of the reasons I chose the Piet design...... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332657#332657 ________________________________________________________________________________
Date: Mar 03, 2011
Subject: Very sad news to report
Friends, I am in Murfreesboro TN at the moment and thought I would call in to find out how Gene Pennington was doing. I learned from his wife Tammy a few minutes ago that Gene had Gone West yesterday morning. I asked if she minded my sharing the word with the group she said she would appreciate it if I did. I am not certain what more can be said or done only to Gene has gone west from beautiful Tennessee to the beautiful peace and presence of the Lord. Rest in Peace Gene, safe travels my friend. John ________________________________________________________________________________
Date: Mar 03, 2011
I am so sorry to hear this news, but I feared it was coming. I had tried to call him a couple of weeks ago and talked with his wife, Tammy. She said he was too weak to talk and had not been able to eat anything for 3 weeks. Apparently the remission he reported just before Christmas was just God's way of allowing him to enjoy one more holiday season. Gene was diagnosed with leiomyosarcoma (http://en.wikipedia.org/wiki/Leiomyosarcoma) a little less than a year ago and fought it tooth and nail, refusing to give up until the very end. I've never known a braver, more spirited man. He was a good pilot and a good friend. I will miss him. Please say a prayer for Tammy (Gene doesn't need your prayers as he is flying better now than he ever has before). Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AMsafetyC(at)aol.com Sent: Thursday, March 03, 2011 2:51 PM Subject: Pietenpol-List: Very sad news to report Friends, I am in Murfreesboro TN at the moment and thought I would call in to find out how Gene Pennington was doing. I learned from his wife Tammy a few minutes ago that Gene had Gone West yesterday morning. I asked if she minded my sharing the word with the group she said she would appreciate it if I did. I am not certain what more can be said or done only to Gene has gone west from beautiful Tennessee to the beautiful peace and presence of the Lord. Rest in Peace Gene, safe travels my friend. John ________________________________________________________________________________
Date: Mar 03, 2011
Jerry, I have the John Deere alternator and the Subaru starter. I am very pleased with both. Gardiner Ditto on the PC680 battery --- On Thu, 3/3/11, Jerry Dotson wrote: > From: Jerry Dotson <jdotson(at)centurylink.net> > Subject: Pietenpol-List: Re: Light-weight alternator/generator? > To: pietenpol-list(at)matronics.com > Date: Thursday, March 3, 2011, 11:43 AM > --> Pietenpol-List message posted > by: "Jerry Dotson" > > Dan go to ebay and search for: > > Permanent Magnet Alternator Kubota > This is what I am going to use. It weighs maybe 3 pounds. I > have a regulator that fits a lawn mower with a 15 amp under > the flywheel. It is about the size of a book of gopher > matches. I will make a temporary mount and an electric motor > to test it all out before I mount it on the engine. If my > memory is right Gardiner has one on his Piet. It is only a > 15 amp output but that will take care of anything that I > would ever want to do. Those Odyssey batteries are great. I > have seen a PC-680 start an O-540. > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > wing, tailfeathers done, fuselage rolling > using Lycoming O-235 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=332645#332645 > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Date: Mar 03, 2011
The Latest Buzz on Rudder Bar MaterialJack Phillips, amen and AMEN to your 9:59 AM post. I have never seen, much less flown, an airplane with a rudder bar. All my time (68 years this past January) has been in planes with rudder pedals and toe brakes. So I couldn't comment on rudder bars if I wanted to. Some of the comments did get a bit testy. ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Thursday, March 03, 2011 9:59 AM Subject: Pietenpol-List: The Latest Buzz on Rudder Bar Material Since I'm on a self-imposed moratorium (for 18 more days) on noting the dangers of using a Corvair to power an airplane, I've enjoyed the discussion about rudder bar materials. However, I want to point out that we are getting dangerously close to being as unfriendly, unhelpful and downright mean as the RV-10 List has gotten. I think a lot of us (myself included) felt that Michael Perez had asked what materials people had used on their rudder bars, and then, when reasons were advanced why stainless steel should NOT be used, he announced that he would use it anyway. This was often the behavior of The Fisherman, of years past, who would propose to do something and ask if there was a problem. Several people would go to the trouble of explaning exactly why this might be a problem, and then he would announce that he would proceed with his way anyhow. He was not looking for advice, but for validation for his choice. However, this was NOT the situation on the rudder bar discussion. In this situation, Ken Heide initially asked about using cold rolled tubing (?) for the rudder bar instead of "structural tubing". Mr. Perez indicated that he had used .035" wall stainless steel for his ALREADY CONSTRUCTED rudder bar. He was neither asking for advice or validation. As he said repeatedly, in several emails, " I feel comfortable with my rudder bar set up." I think we owe Michael an apology. It is absolutely his choice what materials to use. It is our choice whether we would fly in such an airplane or not. That's the beauty of Experimental Aviation. I suspect that after all the hoopla over his choice of materials, Michael will make it a point on his preflight inspections to check the rudder bar for cracking. Stainless steel is not so bad a material that it will fail catastrophically without yielding and with no warning. The great thing about this List (and I really feel that the Pietenpol List is unique in this) is that people feel welcome to ask questions and offer advice. There is no "credentialing" to determine who is able to offer advice, so it takes a while to figure out who knows what they're talking about and who doesn't. I don't think any of us want to see this list get so vitriolic that people are afraid to ask questions or offer advice for fear of being publicly ridiculed. Remember, "We're all Snowflakes". No two Pietenpols are identical, and we've all made changes to the design (horror of horrors, Dan Helsper is now adding electronic ignition, and an electrical system to support it, to his pristine Model A Pietenpol). I myself had a forced landing in my Pietenpol because I used stainless steel (there's that word again) wool in the heat muffs for carb heat. Even a reliable old Continental can't run very well when it ingests a wad of stainless steel. Thank goodness the crankshaft didn't snap. Let's try to keep it friendly and remember that as much as we love these airplanes, the really valuable thing about being involved with Pietenpols is the friendships we gain through this airplane. Some of the people I've met on this list I now count as my very best friends. Only 141 more days until Brodhead. Jack Phillips NX899JP "Icarus Plummet" (which plummeted through trying to digest stainless steel) Raleigh, NC ________________________________________________________________________________
Subject: Re: Very sad news to report
Date: Mar 03, 2011
Amen to that, too! ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Thursday, March 03, 2011 3:40 PM Subject: RE: Pietenpol-List: Very sad news to report I am so sorry to hear this news, but I feared it was coming. I had tried to call him a couple of weeks ago and talked with his wife, Tammy. She said he was too weak to talk and had not been able to eat anything for 3 weeks. Apparently the remission he reported just before Christmas was just God's way of allowing him to enjoy one more holiday season. Gene was diagnosed with leiomyosarcoma (http://en.wikipedia.org/wiki/Leiomyosarcoma) a little less than a year ago and fought it tooth and nail, refusing to give up until the very end. I've never known a braver, more spirited man. He was a good pilot and a good friend. I will miss him. Please say a prayer for Tammy (Gene doesn't need your prayers as he is flying better now than he ever has before). Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AMsafetyC(at)aol.com Sent: Thursday, March 03, 2011 2:51 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Very sad news to report Friends, I am in Murfreesboro TN at the moment and thought I would call in to find out how Gene Pennington was doing. I learned from his wife Tammy a few minutes ago that Gene had Gone West yesterday morning. I asked if she minded my sharing the word with the group she said she would appreciate it if I did. I am not certain what more can be said or done only to Gene has gone west from beautiful Tennessee to the beautiful peace and presence of the Lord. Rest in Peace Gene, safe travels my friend. John http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Subject: Gene Pennington
Date: Mar 03, 2011
I can't stop thinking about the pilot that the Pietenpol world lost yesterday. Here is Gene as he was last July, when I picked up his Pietenpol to ferry it to Brodhead for its new owner, Ryan Mueller: And here is the view that he loved so well, looking out of his Pietenpol at the rolling hills of west Tennessee passing beneath him: At least now he's free of the body that failed him. Tomorrow I'll take my RV-4 up and do a few aerobatics, as I did with him last July, (to his great delight) after I returned from Brodhead. I think he'll be there with me, just off my left wing. We'll do a couple of formation rolls... Fly well, my friend. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC ________________________________________________________________________________
Subject: A great deal on Barnstormers
Date: Mar 03, 2011
On Barnstormers right now, there's a really nice Pietenpol project, ready for cover, with a bunch of new parts, complete with a 0hrs SMOH C85 for sale, all for about the value of the engine. Looks like a great opportunity for someone. Go to barnstormers.com, and search "pietenpol". Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332692#332692 Attachments: http://forums.matronics.com//files/barnstormers_piet_111.jpg ________________________________________________________________________________
Date: Mar 03, 2011
Thanks John, for conveying that very sad news, I never actually got a chance to meet Gene in person. After Jack let us kno w of his rally in December, Gene and I wrote each other about the possibili ty of getting together with our wives, after Denise and I were to move down there this spring. As fate would have it, we missed it by a few weeks, as we are virtually ready to make the move this weekend. God has his reasons f or everything, "His ways are not our ways"...................... Gene Penni ngton, rest in peace....................My prayers go out to his wife Tammy . Dan Helsper Poplar Grove, IL ________________________________________________________________________________
Subject: firewall insulating barrier
Date: Mar 03, 2011
Actually, fiberfrax isn't an insulator. It's a firewall material that Stops fire the same as metal. I can attest that heat goes through it! Having said that I have put 1/8" of the stuff under my firewall. It Would make a great stuffing for through fittings. Clif I put fiberfrax on mine. You don't really need it, if you don't need the firewall. If the engine catches fire, the more insulation the better. Jack Phillips ase Date: 03/03/11 ________________________________________________________________________________
Date: Mar 03, 2011
Subject: look what a friend of mine found
--- On Thu, 3/3/11, scott swear wrote: From: scott swear <sswear01(at)gmail.com> Subject: Fwd: FW: Lawrence Harrod's new airplane project Date: Thursday, March 3, 2011, 8:30 PM ---------- Forwarded message ---------- From: Hockin, Paul <Paul_Hockin(at)steris.com> Date: Thu, Mar 3, 2011 at 9:20 AM Subject: FW: Lawrence Harrod's new airplane project Thought you might find this interesting. =C2- From: SHARON HOCKIN [mailto:shocking2(at)bellsouth.net] Sent: Thursday, March 03, 2011 1:02 AM Subject: Fw: Lawrence Harrod's new airplane project =C2- =C2- =C2- ----- Forwarded Message ---- From: Dee & Betty Gilliland <deebetty(at)comcast.net> Sent: Wed, March 2, 2011 2:31:50 PM Subject: Lawrence Harrod's new airplane project I=99m sure everyone will enjoy seeing Col. Harrod=99s new airpl ane project. Looks like he will have a great time rebuilding and flying thi s one! =C2- From: Mary Harrod Sent: Wednesday, March 02, 2011 9:45 AM Subject: pientenpol =C2- Dear Dee, =C2-=C2-=C2-=C2- Terry Kerby and I found this Pietenpol in an old b arn in Fayetteville.=C2- It had been there five years.=C2- The man who built it and flew it down from St. Louis died.=C2- The fabric is absolute ly perfect but has 1/4 inch of dirt on it.=C2- We got it for $1500.=C2- All we have to do is clean it up and Terry will completely over the Contin ental 65 and we have to put a prop on it.=C2- So now I own one and 1/2 ai rplanes.=C2- The cockpit was perfectly preserved because it had a special cover made for it.=C2- The leather seats and the leather around the pane l just need to be saddle soaped and will look like new.=C2- Please send o ut to the members.=C2- Lawrence =C2- =C2- ________________________________________________________________________________
Subject: Question wing strut barrel
Date: Mar 03, 2011
Hi guys hope everyone is well I am about to start building again over here in the west I am hoping the container with the Piet in it arrives safe today. But in the meantime can anyone tell me how wide these barrels are? http://www.aircraftspruce.com/catalog/graphics/05-05900.jpg Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332703#332703 ________________________________________________________________________________
From: "Amsafetyc(at)gmail.com" <amsafetyc(at)gmail.com>
Date: Mar 03, 2011
Subject: Re: Gene Pennington
Jack I wish we had enough willing souls to do a fly by tribute missing man formation for Gene. I had spoken with him a number of times and had e mail communications also. When I learned of hid diagnosis I introduced him toy boss who to was diagnosed Two years prior and was in remission from a rare form. Gene wasn't sure about what to expect. I put the two together in hopes my bosses experience could be shared along with his attitude. The two spoke a couple of times it gave Gene some hope and reassurance that experimental programs are available and working. I was hoping that my bosses attitude would somehow give support to Genes spirit attitude and optimism to keep him going through the dark days of his treatment. Gene appreciated the time and support. My boss Brian was able to give. I spoke with Gene later and he was looking at getting into the air and maybe building another Piet we spoke I bought his tail wheel. We had good conversations. I was fearful that one day I would be thinking of him call and learn he had gone. My worst fears were confirmed today. I thought of him yesterday and wanted to call then. Having almost met him three years prior we never did meet face to face something I wish we had. I did tell him I got his tail wheel mount built and bolted to my project. It was during Buildapalooza 2010 he was glad to hear it was mounted and asked for pics I never sent. I didn't feel I had anything worthy of sending although he would have liked seeing the pics. My boss is still fighting his battle even after loosing his wife to cancer last spring. He still has his attitude an optimism in tact although I am nt sure how he will take the news about Gene our mutual friend. I have no idea why i am sharing this with you now I just felt the need John I contacted jack yesterday for His number I got free from my meetings today only to learn of his passing. Sent via DROID on Verizon Wireless -----Original message----- From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Fri, Mar 4, 2011 00:02:28 GMT+00:00 Subject: Pietenpol-List: Gene Pennington I can't stop thinking about the pilot that the Pietenpol world lost yesterday. Here is Gene as he was last July, when I picked up his Pietenpol to ferry it to Brodhead for its new owner, Ryan Mueller: And here is the view that he loved so well, looking out of his Pietenpol at the rolling hills of west Tennessee passing beneath him: At least now he's free of the body that failed him. Tomorrow I'll take my RV-4 up and do a few aerobatics, as I did with him last July, (to his great delight) after I returned from Brodhead. I think he'll be there with me, just off my left wing. We'll do a couple of formation rolls... Fly well, my friend. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC ________________________________________________________________________________
Date: Mar 03, 2011
Doug I have an Odessy battery in my Rotec piet. Cranks that radial over just fine. Dick N. ----- Original Message ----- From: bradandlinda tds.net To: pietenpol-list(at)matronics.com Sent: Thursday, March 03, 2011 8:41 AM Subject: Re: Pietenpol-List: Light-weight alternator/generator? To Dan Helsper re long lasting battery. look up Odyssey batteries. They have the unique quality of having both heavy cranking and deep cycle. The military uses them for vehicles that are in storage for long periods of time. Great for trolling motors. I have one in my Piet. Brad Williams NX29NX> On Thu, Mar 3, 2011 at 8:01 AM, Doug Dever wrote: Dan have you looked at the Gennipod from Great Plains? At $250.00 it is pricey, but its wind driven so the install would be easy. I saw plans for a home made one using a R/C model starter, but I can't for the life of me find the web site. Doug Dever In beautiful Stow Ohio ------------------------------------------------------------------------- --- To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Light-weight alternator/generator? From: helspersew(at)aol.com Date: Thu, 3 Mar 2011 07:10:56 -0500 Hello All, I would like to keep going forward with this electronic ignition/batt system idea. Buying a larger amp/hour batttery to extend the flying time to two hours would work, but then I am still left with a dead battery at the end of the flight which would I'm sure become a real pain quickly. So maybe I will keep my 4.4 lb. battery and use the extra weight allowance by installing some mini alternator? I found one in the Pegasus Auto Racing catalog (6 lbs) that puts out a whole 50 amps for $279.00. A bit pricey I thought but maybe I could bite the bullet. I know Ken Perkins installed a (I think it was a Kabota) small alternator on his Model A. Does anyone know more about this? I looked at my engine briefly last night and it looks like installation of such a thing would not be so hard. Just mount to the side, and in-line with the water pump drive belt. How much power do these types of set-ups rob from the engine? Any help or opinionated feedback would be appreciated. Dan Helsper Poplar Grove, IL. st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List ttp://forums.matronics.com =_blank>http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ttp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 03, 2011
Here's the file again with the pictures (I hope) I can't stop thinking about the pilot that the Pietenpol world lost yesterday. Here is Gene as he was last July, when I picked up his Pietenpol to ferry it to Brodhead for its new owner, Ryan Mueller: And here is the view that he loved so well, looking out of his Pietenpol at the rolling hills of west Tennessee passing beneath him: At least now he's free of the body that failed him. Tomorrow I'll take my RV-4 up and do a few aerobatics, as I did with him last July, (to his great delight) after I returned from Brodhead. I think he'll be there with me, just off my left wing. We'll do a couple of formation rolls. Fly well, my friend. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC ________________________________________________________________________________
Date: Mar 03, 2011
Jack I agree whole heartedly. Dan Yokum and Gary Boothe will attest to the way my attitude has gotten. There have been a couple of topics that I have felt qualified to offer up advice on but didn't because of fanning the flames. I consider us to be a fraternity of builders that very few builders get to experience. I have been wanting to build a Piet over 40 years and this glorious Internet came along and we can share pictures and ideas freely. While I don't agree with some posts I try not to flame the poster. I may ignore it! While my rear rudder pedals are 4130 my front pedals are stainless tubing but I would fly one with the pedals made from 1/2" EMT conduit. My opinions: Welding 4130...... Tig or Oxy-Acet makes very little difference. Quality of the weld is what matters. I have both and used both on my airplane. Close places I prefer the torch over TIG. I have not made the engine mount yet but I would guess it will have both. Any TIG welds on it will be stress relieved. Finish....... with today's fabric dope, auto paint, latex house house paint, oil based house paint.......all will work. My Piet will have Rustoleum oil base on it. The 1/4 scale Fleet in my avatar is 11 years old, is covered with Dacron, has sat in the sun several days in that time span and has over 100 hours in the air. I am comfortable using the Rustoleum because of its performance on that model. It still looks nearly new. Engine selection.......I won't get too deep into it. Auto conversions are OK if done right. I like the reduction drives to get prop efficiency and take the gyroscopic forces off the crank. I prefer certificated engines because they need no conversion, most have no head gasket to blow, have individual stand alone cylinders so you can repair just the one that gives you problems. I also like wooden props over metal as they are kind to your engine and look good to boot. Welding and engines are my life's work. Certified gas pipeline welder at 18 years of age then did maintenance on stationary engines of 2000 to 15000 horsepower for 41 years. I worked part time in a FAA approved repair station 4 years to help support my flying habit. I did engine work for them and helped with some annual inspections. Does this experience make me a welding and mechanical guru? No. Not by any means but I have seen the innards of a lot of engines. Anyone wanting personal opinions one on one feel welcome to email me or call. The pictures show the big ones break just like a small one. I bent the rod in 1975 starting the engine. It had water on in the cylinder(now we know why you pull inverted and radials through before starting). It has 12" journals on the crankshaft. That rod cost $18000. The other one with the broken piston skirt was because management chose to buy aftermarket(cheap)cylinder liners and it failed. That engine has a 16" bore and 22" stroke I get off the box now. I hope I have not offended anyone. It was not my intent. I am trying to promote harmony. We have a good bunch here and let us have fun. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332715#332715 Attachments: http://forums.matronics.com//files/bent_con_rod_931.jpg http://forums.matronics.com//files/16_inch_bore_328.jpg ________________________________________________________________________________
Date: Mar 03, 2011
I throw this out there not because it has anything to do with me, but because it has a few precious seconds of Gene as he was when I met him. The video does not do justice.....he was a gregarious, tremendously warm man, and I was blessed to be able to know him for a very short time. Godspeed Gene, Ryan http://www.youtube.com/watch?v=DulYH6AuMzc On Thu, Mar 3, 2011 at 9:13 PM, Jack Phillips wrote : > Here=92s the file again with the pictures (I hope) > > > I can=92t stop thinking about the pilot that the Pietenpol world lost > yesterday. > > > Here is Gene as he was last July, when I picked up his Pietenpol to ferry > it to Brodhead for its new owner, Ryan Mueller: > > > And here is the view that he loved so well, looking out of his Pietenpol at > the rolling hills of west Tennessee passing beneath him: > > > At least now he=92s free of the body that failed him. Tomorrow I=92ll ta ke my > RV-4 up and do a few aerobatics, as I did with him last July, > > (to his great delight) after I returned from Brodhead. I think he=92ll b e > there with me, just off my left wing. We=92ll do a couple of formation r olls=85 > > > Fly well, my friend. > > > Jack Phillips > > NX899JP =93Icarus Plummet=94 > > Raleigh, NC > ________________________________________________________________________________
Date: Mar 04, 2011
Date: Mar 04, 2011
Dan - You'll have plenty of power for the moving map on your new GPS-capable IPAD with all the VFR/IFR worldwide charts, approach plates, etc. I use the John Deere alternator/regulator, too. Has worked good for 180 hours. Kevin -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332734#332734 ________________________________________________________________________________
Date: Mar 04, 2011
Subject: Re: look what a friend of mine found
That is very cool! Had the pictures not been attached, I would not have bel ieved the "Found in a barn" bit. Heard a lot of that around the classic car world... Great find, GREAT price!- Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Subject: brakes now
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Mar 04, 2011
Well after getting my carb back from D&G and getting it mounted I find that once again I am without brakes. I had a brainstorm yesterday that I might be able to pull the drums out of my 1947 hayes 6" wheels and bolt in the discs from the 5" wheels and make custom mount plates for my calipers and have some brakes but then reality set in and I discovered that the bolt circle in the bigger wheels won't let that happen. so i guess I will once again fill and bleed the critters and hope for a little stopping power.have any of you tried running the old expander bladder I guess they would be called brakes with success? I expect they are from similar old Piper service since they bolted right up the the Cub gear but they seem to have very little expansion with the newer style master cylinders-maybe the small piston just doesn't displace enough fluid to move the segmented shoes out.I don't want to have to re-design the system or go back to the 5" wheels and tires I took off because the runway I use is very rough but it may come to that. money is an issue. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332750#332750 ________________________________________________________________________________
Date: Mar 04, 2011
Jack=2C I do not want to sound in any way critical=2C but you mentioned th e C word again. From: cncampbell(at)windstream.net Subject: Re: Pietenpol-List: The Latest Buzz on Rudder Bar Material Date: Thu=2C 3 Mar 2011 17:42:57 -0500 Jack Phillips=2C amen and AMEN to your 9:59 AM post. I have never seen=2C much less flown=2C an airplane with a rudder bar. All my time (68 years th is past January) has been in planes with rudder pedals and toe brakes. So I couldn't comment on rudder bars if I wanted to. Some of the comments did get a bit testy. ----- Original Message ----- From: Jack Phillips Sent: Thursday=2C March 03=2C 2011 9:59 AM Subject: Pietenpol-List: The Latest Buzz on Rudder Bar Material Since I=92m on a self-imposed moratorium (for 18 more days) on noting the d angers of using a Corvair to power an airplane=2C I=92ve enjoyed the discus sion about rudder bar materials. However=2C I want to point out that we ar e getting dangerously close to being as unfriendly=2C unhelpful and downrig ht mean as the RV-10 List has gotten. I think a lot of us (myself included) felt that Michael Perez had asked wha t materials people had used on their rudder bars=2C and then=2C when reason s were advanced why stainless steel should NOT be used=2C he announced that he would use it anyway. This was often the behavior of The Fisherman=2C o f years past=2C who would propose to do something and ask if there was a pr oblem. Several people would go to the trouble of explaning exactly why thi s might be a problem=2C and then he would announce that he would proceed wi th his way anyhow. He was not looking for advice=2C but for validation for his choice. However=2C this was NOT the situation on the rudder bar discussion. In thi s situation=2C Ken Heide initially asked about using cold rolled tubing (?) for the rudder bar instead of =93structural tubing=94. Mr. Perez indicate d that he had used .035=94 wall stainless steel for his ALREADY CONSTRUCTED rudder bar. He was neither asking for advice or validation. As he said r epeatedly=2C in several emails=2C =94 I feel comfortable with my rudder bar set up.=94 I think we owe Michael an apology. It is absolutely his choice what materi als to use. It is our choice whether we would fly in such an airplane or n ot. That=92s the beauty of Experimental Aviation. I suspect that after al l the hoopla over his choice of materials=2C Michael will make it a point o n his preflight inspections to check the rudder bar for cracking. Stainles s steel is not so bad a material that it will fail catastrophically without yielding and with no warning. The great thing about this List (and I really feel that the Pietenpol List is unique in this) is that people feel welcome to ask questions and offer a dvice. There is no =93credentialing=94 to determine who is able to offer a dvice=2C so it takes a while to figure out who knows what they=92re talking about and who doesn=92t. I don=92t think any of us want to see this list get so vitriolic that people are afraid to ask questions or offer advice fo r fear of being publicly ridiculed. Remember=2C =93We=92re all Snowflakes=94. No two Pietenpols are identical =2C and we=92ve all made changes to the design (horror of horrors=2C Dan He lsper is now adding electronic ignition=2C and an electrical system to supp ort it=2C to his pristine Model A Pietenpol). I myself had a forced landin g in my Pietenpol because I used stainless steel (there=92s that word again ) wool in the heat muffs for carb heat. Even a reliable old Continental ca n=92t run very well when it ingests a wad of stainless steel. Thank goodne ss the crankshaft didn=92t snap. Let=92s try to keep it friendly and remember that as much as we love these airplanes=2C the really valuable thing about being involved with Pietenpols is the friendships we gain through this airplane. Some of the people I=92 ve met on this list I now count as my very best friends. Only 141 more days until Brodhead. Jack Phillips NX899JP =93Icarus Plummet=94 (which plummeted through trying to digest st ainless steel) Raleigh=2C NC href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Mar 04, 2011
I merely mentioned that I was still on a moratorium (for 17 more days now). Or were you referring my use of the work Crankshaft as a "C" word? I realize there are many areas of concern for Corvair owners - it's difficult to stay away from all of them. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of V Groah Sent: Friday, March 04, 2011 11:54 AM Subject: RE: Pietenpol-List: The Latest Buzz on Rudder Bar Material Jack, I do not want to sound in any way critical, but you mentioned the C word again. _____ From: cncampbell(at)windstream.net Subject: Re: Pietenpol-List: The Latest Buzz on Rudder Bar Material Date: Thu, 3 Mar 2011 17:42:57 -0500 Jack Phillips, amen and AMEN to your 9:59 AM post. I have never seen, much less flown, an airplane with a rudder bar. All my time (68 years this past January) has been in planes with rudder pedals and toe brakes. So I couldn't comment on rudder bars if I wanted to. Some of the comments did get a bit testy. ----- Original Message ----- From: Jack <mailto:pietflyr(at)bellsouth.net> Phillips Sent: Thursday, March 03, 2011 9:59 AM Subject: Pietenpol-List: The Latest Buzz on Rudder Bar Material Since I'm on a self-imposed moratorium (for 18 more days) on noting the dangers of using a Corvair to power an airplane, I've enjoyed the discussion about rudder bar materials. However, I want to point out that we are getting dangerously close to being as unfriendly, unhelpful and downright mean as the RV-10 List has gotten. I think a lot of us (myself included) felt that Michael Perez had asked what materials people had used on their rudder bars, and then, when reasons were advanced why stainless steel should NOT be used, he announced that he would use it anyway. This was often the behavior of The Fisherman, of years past, who would propose to do something and ask if there was a problem. Several people would go to the trouble of explaning exactly why this might be a problem, and then he would announce that he would proceed with his way anyhow. He was not looking for advice, but for validation for his choice. However, this was NOT the situation on the rudder bar discussion. In this situation, Ken Heide initially asked about using cold rolled tubing (?) for the rudder bar instead of "structural tubing". Mr. Perez indicated that he had used .035" wall stainless steel for his ALREADY CONSTRUCTED rudder bar. He was neither asking for advice or validation. As he said repeatedly, in several emails, " I feel comfortable with my rudder bar set up." I think we owe Michael an apology. It is absolutely his choice what materials to use. It is our choice whether we would fly in such an airplane or not. That's the beauty of Experimental Aviation. I suspect that after all the hoopla over his choice of materials, Michael will make it a point on his preflight inspections to check the rudder bar for cracking. Stainless steel is not so bad a material that it will fail catastrophically without yielding and with no warning. The great thing about this List (and I really feel that the Pietenpol List is unique in this) is that people feel welcome to ask questions and offer advice. There is no "credentialing" to determine who is able to offer advice, so it takes a while to figure out who knows what they're talking about and who doesn't. I don't think any of us want to see this list get so vitriolic that people are afraid to ask questions or offer advice for fear of being publicly ridiculed. Remember, "We're all Snowflakes". No two Pietenpols are identical, and we've all made changes to the design (horror of horrors, Dan Helsper is now adding electronic ignition, and an electrical system to support it, to his pristine Model A Pietenpol). I myself had a forced landing in my Pietenpol because I used stainless steel (there's that word again) wool in the heat muffs for carb heat. Even a reliable old Continental can't run very well when it ingests a wad of stainless steel. Thank goodness the crankshaft didn't snap. Let's try to keep it friendly and remember that as much as we love these airplanes, the really valuable thing about being involved with Pietenpols is the friendships we gain through this airplane. Some of the people I've met on this list I now count as my very best friends. Only 141 more days until Brodhead. Jack Phillips NX899JP "Icarus Plummet" (which plummeted through trying to digest stainless steel) Raleigh, NC href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List ttp://forums.matronics.com =_blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 04, 2011
Jack, Very well stated. I did ask the simple question, "cold rolled" or "structral". I read postings with amazement as this grew a life of its own. In my 20 years working in the medical profession, my medical instructor taught me one very valuable lesson ~ Ask the right question(s), listen with both ears, and your patient will tell you everything you need to know! In this case, Michael Perez responed with stainless steel for his rudder bar. I agreed with many of the reponses it is my opinion in keeping with the structural tubing as the plans call for. I was just asking a simple question. What has me flaming is the demeanor used by some to tear down the person beyond the written responses as to why he should not use a particular material. Make the point, state the reasons or examples of why you back your point, and convience based on real situations or vaild logic. In closing, as a member of this list for several years, I find this the best group of concerned people anywhere in any listserve! Besides, where else can you enjoy laughs, friendships, and great advice without attacking others opinions and questions? This is one village idiot who believes laughter, personalities, and corvair running engines make the world go round! Need I digress.... KMHeide Fargo, ND (Where your FAA written test comes from!) --- On Thu, 3/3/11, Jack Phillips wrote: > From: Jack Phillips <pietflyr(at)bellsouth.net> > Subject: Pietenpol-List: The Latest Buzz on Rudder Bar Material > To: pietenpol-list(at)matronics.com > Date: Thursday, March 3, 2011, 8:59 AM > > > > > > The Latest Buzz on Rudder Bar Material > > > > > Since Im on a self-imposed > moratorium (for 18 more > days) > on noting the dangers of using a Corvair to power an airplane, > Ive enjoyed the discussion about rudder bar > materials. However, I want to point out that we are > getting dangerously close to being as unfriendly, unhelpful > and downright mean as the RV-10 List has > gotten. > > I think a lot of us (myself included) felt that > Michael Perez had asked what materials people had used on > their rudder bars, and then, when reasons were advanced why > stainless steel should NOT be used, he announced that he > would use it anyway. This was often the behavior of > The Fisherman, of years past, who would propose to do > something and ask if there was a problem. Several > people would go to the trouble of > explaning exactly > why this might be a > problem, and then he would announce that he would proceed > with his way anyhow. He was not looking for advice, > but for validation for his choice. > > However, this was NOT the situation on the > rudder bar discussion. In this > situation, Ken Heide > initially asked about using cold rolled tubing (?) for the > rudder bar instead of structural tubing. Mr. Perez indicated that he had used > .035 wall stainless steel for his ALREADY > CONSTRUCTED rudder bar. He was neither asking for > advice or validation. As he said repeatedly, in > several emails, I feel comfortable with my rudder bar set > up. > > I think we owe Michael an apology. It is > absolutely his choice what materials to use. It is our > choice whether we would fly in such an airplane or > not. > Thats the beauty of Experimental > Aviation. I suspect > that after all the hoopla over his choice of materials, > Michael will make it a point on his preflight inspections to > check the rudder bar for cracking. Stainless steel is > not so bad a material that it will fail catastrophically > without yielding and with no warning. > > The great thing about this List (and I really feel that the > Pietenpol List is unique in this) is that people feel > welcome to ask questions and offer advice. There is > no credentialing to determine who is able to offer advice, so > it takes a while to figure out who knows what theyre talking about and who > doesnt. I dont think any of > us want to see this > list get so vitriolic that people are afraid to ask > questions or offer advice for fear of > being publicly > ridiculed. > > Remember, Were all Snowflakes. No two Pietenpols are identical, and > weve all made changes to the design (horror of > horrors, Dan Helsper is now adding electronic > ignition, and an electrical > system to support it, to his pristine > Model A Pietenpol). I myself had a forced landing in > my Pietenpol because I used stainless > steel (theres that word again) wool in the heat muffs for > carb heat. Even a reliable old Continental > cant run very well when it ingests a wad of > stainless steel. Thank > goodness the crankshaft didnt snap. > > Lets try to keep it friendly and remember that as > much as we love these airplanes, the really valuable thing > about being involved with Pietenpols is the friendships we > gain through this airplane. Some of the people > Ive met on this list I now count as my very best > friends. > > Only 141 more days until > Brodhead. > > Jack Phillips > > NX899JP Icarus Plummet (which plummeted through trying to > digest stainless steel) > > Raleigh, NC > > > > > > > > ________________________________________________________________________________
Date: Mar 04, 2011
Subject: Re: Light-weight alternator/generator?
Jerry, I don't know if my post went through. I am using the John Deere alternator and Subaru starter. Also the Odyssey PC680 battery. --- On Fri, 3/4/11, airlion wrote: > From: airlion <airlion(at)bellsouth.net> > Subject: Re: Pietenpol-List: Re: Light-weight alternator/generator? > To: pietenpol-list(at)matronics.com > Date: Friday, March 4, 2011, 8:31 AM > --> Pietenpol-List message posted > by: airlion > > > > --- On Thu, 3/3/11, Jerry Dotson > wrote: > > > From: Jerry Dotson <jdotson(at)centurylink.net> > > Subject: Pietenpol-List: Re: Light-weight > alternator/generator? > > To: pietenpol-list(at)matronics.com > > Date: Thursday, March 3, 2011, 11:43 AM > > --> Pietenpol-List message posted > > by: "Jerry Dotson" > > > > Dan go to ebay and search for: > > > > Permanent Magnet Alternator Kubota > > This is what I am going to use. It weighs maybe 3 > pounds. I > > have a regulator that fits a lawn mower with a 15 amp > under > > the flywheel. It is about the size of a book of > gopher > > matches. I will make a temporary mount and an electric > motor > > to test it all out before I mount it on the engine. If > my > > memory is right Gardiner has one on his Piet. It is > only a > > 15 amp output but that will take care of anything that > I > > would ever want to do. Those Odyssey batteries are > great. I > > have seen a PC-680 start an O-540. > > > > -------- > > Jerry Dotson > > 59 Daniel Johnson Rd > > Baker, FL 32531 > > > > Started building NX510JD July, 2009 > > wing, tailfeathers done, fuselage rolling > > using Lycoming O-235 > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=332645#332645 > > > > > > > > > > > > > > > > Email Forum - > > FAQ, > > - MATRONICS WEB FORUMS - > > List Contribution Web Site - > > -Matt > > Dralle, List Admin. > > > > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Mar 04, 2011
Gardiner, Thanks for the feedback. I just came in the house from testing my alternator and I looked up the pictures I got the day I visited with you. Your John Deere and my Kubota appear to be identical. My regulator does not look the same. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332762#332762 ________________________________________________________________________________
Subject: Re: A great deal on Barnstormers
Date: Mar 04, 2011
Eh.... where ya'll from gene??? let me guess them moonshine hills of kentucky or them swamps of Louisiana. I reken you might fancy to come up to theese parts and show us fellers how to build them flyn' machines Read this topic online here: http://forums.matronics.com/viewtopic.php?p=332763#332763 ________________________________________________________________________________
Subject: Re: brakes now
Date: Mar 04, 2011
Yes, I had the expandable bladder type brakes on a PA22 TriPacer that I converted to a PA20 taildragger. They worked really well, in fact they saved the plane when I was checking the guy out in it when he bought it from me. He said he was tail-wheel qualified but on our first takeoff (he was flying from the left seat and I was in the right seat -- fortunately I had put toe brakes on both sides) the plane almost got away from him on takeoff. I jumped on the right brake and got it straightened out before it ground looped. The brakes worked fine. We went to a field with wider runways and spent about 2 hours having him make takeoffs until he could handle the plane with no trouble. If having bladder type brakes is a solution to your problem, I recommend them. Chuck C. ----- Original Message ----- From: "skellytown flyer" <skellflyer1(at)yahoo.com> Sent: Friday, March 04, 2011 11:15 AM Subject: Pietenpol-List: brakes now > > > Well after getting my carb back from D&G and getting it mounted I find > that once again I am without brakes. I had a brainstorm yesterday that I > might be able to pull the drums out of my 1947 hayes 6" wheels and bolt in > the discs from the 5" wheels and make custom mount plates for my calipers > and have some brakes but then reality set in and I discovered that the > bolt circle in the bigger wheels won't let that happen. so i guess I will > once again fill and bleed the critters and hope for a little stopping > power.have any of you tried running the old expander bladder I guess they > would be called brakes with success? I expect they are from similar old > Piper service since they bolted right up the the Cub gear but they seem to > have very little expansion with the newer style master cylinders-maybe the > small piston just doesn't displace enough fluid to move the segmented > shoes out.I don't want to have to re-design the system or go back to the > 5" wheels and tires I took off because the! > runway I use is very rough but it may come to that. money is an issue. > Raymond > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=332750#332750 > > > ________________________________________________________________________________
Date: Mar 04, 2011
Jack, you're going to shoot me when I show up at Brodhead (probably next year) with a Corvair without the 5th bearing. I want to use the stock oil system and don't know how I would get oil to a fifth bearing. Chuck ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Friday, March 04, 2011 12:03 PM Subject: RE: Pietenpol-List: The Latest Buzz on Rudder Bar Material I merely mentioned that I was still on a moratorium (for 17 more days now). Or were you referring my use of the work Crankshaft as a "C" word? I realize there are many areas of concern for Corvair owners - it's difficult to stay away from all of them. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of V Groah Sent: Friday, March 04, 2011 11:54 AM To: piet list Subject: RE: Pietenpol-List: The Latest Buzz on Rudder Bar Material Jack, I do not want to sound in any way critical, but you mentioned the C word again. ------------------------------------------------------------------------- ----- From: cncampbell(at)windstream.net To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: The Latest Buzz on Rudder Bar Material Date: Thu, 3 Mar 2011 17:42:57 -0500 Jack Phillips, amen and AMEN to your 9:59 AM post. I have never seen, much less flown, an airplane with a rudder bar. All my time (68 years this past January) has been in planes with rudder pedals and toe brakes. So I couldn't comment on rudder bars if I wanted to. Some of the comments did get a bit testy. ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Thursday, March 03, 2011 9:59 AM Subject: Pietenpol-List: The Latest Buzz on Rudder Bar Material Since I'm on a self-imposed moratorium (for 18 more days) on noting the dangers of using a Corvair to power an airplane, I've enjoyed the discussion about rudder bar materials. However, I want to point out that we are getting dangerously close to being as unfriendly, unhelpful and downright mean as the RV-10 List has gotten. I think a lot of us (myself included) felt that Michael Perez had asked what materials people had used on their rudder bars, and then, when reasons were advanced why stainless steel should NOT be used, he announced that he would use it anyway. This was often the behavior of The Fisherman, of years past, who would propose to do something and ask if there was a problem. Several people would go to the trouble of explaning exactly why this might be a problem, and then he would announce that he would proceed with his way anyhow. He was not looking for advice, but for validation for his choice. However, this was NOT the situation on the rudder bar discussion. In this situation, Ken Heide initially asked about using cold rolled tubing (?) for the rudder bar instead of "structural tubing". Mr. Perez indicated that he had used .035" wall stainless steel for his ALREADY CONSTRUCTED rudder bar. He was neither asking for advice or validation. As he said repeatedly, in several emails, " I feel comfortable with my rudder bar set up." I think we owe Michael an apology. It is absolutely his choice what materials to use. It is our choice whether we would fly in such an airplane or not. That's the beauty of Experimental Aviation. I suspect that after all the hoopla over his choice of materials, Michael will make it a point on his preflight inspections to check the rudder bar for cracking. Stainless steel is not so bad a material that it will fail catastrophically without yielding and with no warning. The great thing about this List (and I really feel that the Pietenpol List is unique in this) is that people feel welcome to ask questions and offer advice. There is no "credentialing" to determine who is able to offer advice, so it takes a while to figure out who knows what they're talking about and who doesn't. I don't think any of us want to see this list get so vitriolic that people are afraid to ask questions or offer advice for fear of being publicly ridiculed. Remember, "We're all Snowflakes". No two Pietenpols are identical, and we've all made changes to the design (horror of horrors, Dan Helsper is now adding electronic ignition, and an electrical system to support it, to his pristine Model A Pietenpol). I myself had a forced landing in my Pietenpol because I used stainless steel (there's that word again) wool in the heat muffs for carb heat. Even a reliable old Continental can't run very well when it ingests a wad of stainless steel. Thank goodness the crankshaft didn't snap. Let's try to keep it friendly and remember that as much as we love these airplanes, the really valuable thing about being involved with Pietenpols is the friendships we gain through this airplane. Some of the people I've met on this list I now count as my very best friends. Only 141 more days until Brodhead. Jack Phillips NX899JP "Icarus Plummet" (which plummeted through trying to digest stainless steel) Raleigh, NC href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-Listhref="http://forums.matronics.com">h ttp://forums.matronics.comhref="http://www.matronics.com/contribution"> http://www.matronics.com/c st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-Listttp://fo rums.matronics.com=_blank>http://www.matronics.com/contribution http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 04, 2011
This may be helpful: http://iowamotorparts.com/kubota_alternators.htm they do show up on ebay now and then at about half that price. Michael in Maine ----- Original Message ----- From: "Jerry Dotson" <jdotson(at)centurylink.net> > > Gardiner, > Thanks for the feedback. I just came in the house from testing my alternator and I looked up the pictures I got the day I visited with you. Your John Deere and my Kubota appear to be identical. My regulator does not look the same. > > -------- ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Mar 04, 2011
Subject: I have to say it-- I can't hold this in any longer.
The C word..... Continental ! Thank you...I feel much better now. :) Happy Friday good people ! Mike C. [cid:image001.jpg(at)01CBDA78.1A35DF60] ________________________________________________________________________________
Subject: Re: The Latest Buzz on Rudder Bar Material
Date: Mar 04, 2011
You will make it to Illinois. Then you will have a visit from this "gentleman." http://gallery.me.com/johnnyskyrocket#100026 John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com
February 17, 2011 - March 04, 2011
Pietenpol-Archive.digest.vol-ke
