Pietenpol-Archive.digest.vol-nk
March 29, 2014 - May 01, 2014
      > A little droopiness is normal.
      > See attached photo of Bob Poore and me.
      > Greg Cardinal
      > ----- Original Message -----
      > From: danhelsper(at)aol.com
      > To: pietenpol-list(at)matronics.com
      > Sent: Friday, March 28, 2014 4:33 PM
      > Subject: Pietenpol-List: More droopiness
      > Here are a couple more.
      > Dan Helsper
      > Puryear, TN
      > <~WRD000.jpg>
      > This email is free from viruses and malware because avast! Antivirus prote
      ction is active.
Subject: Re: More droopiness
Date: Mar 29, 2014
And still more droopiness -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421244#421244 Attachments: http://forums.matronics.com//files/adrian_and_debbie_flying_7_200.jpg ________________________________________________________________________________
Subject: Rivet Substiution - Wooden Gear
Date: Mar 29, 2014
When I built my wooden gear I didn't feel comfortable with putting rivets through the metal plates at the crouch of the vee. I used number 8 fillister head (countersunk) AN509 machine screws. This made the head flush on the outside but needed a protruding screw end and nut on the inside plate. I found over time that the protruding nut would cut into the shock cord. To solve this problem I tried an unconventional use of some hardware. I countered bored from the inside slightly and countersunk the inside plate and used a NAS1330A08-106 countersunk rivet nut. In case you are confused I didn't pull these rivet nuts I just used then as they came. A flush nut so to speak. You can use keyed nuts and cut a slot in the face of the counter sunk hole and then some lock tight. Alternatively what I did was epoxied the nuts and screws into position as I tighten them up. So once completed you have a fastener that is flush on both the inside and outside and the shock cord likes it. -------- Brian Kenney Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421245#421245 ________________________________________________________________________________
Date: Mar 29, 2014
fattest pilot? On Sat, Mar 29, 2014 at 9:43 AM, pineymb wrote: > > And still more droopiness > > -------- > Adrian M > Winnipeg, MB > Canada > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421244#421244 > > > Attachments: > > http://forums.matronics.com//files/adrian_and_debbie_flying_7_200.jpg > > ________________________________________________________________________________
Date: Mar 29, 2014
Maybe it's just me... but isn't the only real factor affecting elevator position in level flight, the speed? My piet has a pronounced up elevator position... in the flare. Does every time. Pretty sure EVERY piet would have a certain speed where the elevator would be in a neutral position. All these pics are likely taken at different speeds, meaning the elevators would be in different positions. Isn't it really just that simple? Now, if your elevators are somewhat down, and the plane is in trim (no control stick pressure), and this bothers you (since the elevators are not faired, there will be more drag than necessary, so you'll be somewhat slower - maybe not even noticable), you either change the wing incidence, or the horiz stab incidence to take that out. It's a simple matter of rig. Which you do (the stab or wing) is also a matter of rig, and should be based on keeping the fuse angle of attack at a minimum to reduce frontal area, and decreasing drag. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421249#421249 ________________________________________________________________________________
Date: Mar 29, 2014
Is it just me (or the photo), or is Three-One-Lima-Alpha one long-legged airplane? It just looks like the main gear legs are longer than most. (Not being critical, by the way... long legs can be attractive). -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421255#421255 ________________________________________________________________________________
Date: Mar 29, 2014
it might be my sticking the pic into PC Paint and wrecking aspect ratio... those are off-the-shelf J-3 gear.... I have 2 new ones at home that I am covering....practice for building a whole Piet...in the way distant (retired) future. On Mar 29, 2014 11:28 AM, "taildrags" wrote: > > Is it just me (or the photo), or is Three-One-Lima-Alpha one long-legged > airplane? It just looks like the main gear legs are longer than most. > (Not being critical, by the way... long legs can be attractive). > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421255#421255 > > ________________________________________________________________________________
Subject: Re: Corvair Mounts
Date: Mar 29, 2014
Thanks Skip, thatll work for me. Ill let WW know to expect you. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421258#421258 ________________________________________________________________________________
Subject: looking for a cover photo
Date: Mar 29, 2014
Pieters=3B As many of you know=2C we (Contact! Magazine) will be producing an all-Piet issue to coincide with the 85th anniversary of the Air Camper this year. We're looking for a cover photo=2C preferably air-to-air=2C of a Ford A pow ered Piet. Wire spoked wheels will be heavily preferred. Please go through your photos and send me any candidates that you'd like to have considered for this special issue of the magazine. Editor Pat Panzer a plans to attend the dinner at Brodhead this year and I'm sure he'll be ha nd-carrying plenty of copies of the magazine. Subscribers will have alread y gotten theirs by then. For a superb example of what we're looking for=2C look no further than the Jon Apfelbaum photo of Dan Helsper's airplane that he just posted under the topic "More droopiness". It was the October 2012 calendar page from an EA A publication. I sure hope Jon has more of his Piet photos and would consider sending a co uple. Send to taildrags(at)Hotmail.com or editor(at)contactmagazine.com Thanks. ________________________________________________________________________________
Subject: Piet project for sale?
Date: Mar 29, 2014
Strongly considering selling my Piet project if there is interest. Sale is due to having kids and priorities changing over the last 8 years. Since then, and at least for another 5 or so years, there will be no time to work on it, let alone money. Basically have all components for the airframe less hardware and covering materials. Fuselage is 85% complete (long version) End spinach is complete less sanding and finish All ribs complete Wing spars Carlson aircraft struts 4 foot center section about 60% complete All steel, including tubing for landing gear Turnbuckles and cable Altimeter Drawings, corvair books, manuals, etc Probably a few more miscellaneous items that I can't think of. Have about $3000 invested but open to offers if there is interest. Email me at tab1324(at)gmail.com if interested please. Project is located in suburb of Minneapolis, mn. It's more important to me that this thing fly some day than it is that it is me who finishes it. So please, if you have interest, let me know. Tom Brant Sent from my iPad ________________________________________________________________________________
Date: Mar 29, 2014
I didn't know that that being critical is not acceptable...I thought it was perfectly ok. if its not ok my question would be why it aint ok.=0A=0Ahyde =0AOn Saturday, March 29, 2014 11:39 AM, Marcus Zechini <marcus.zechini@gma il.com> wrote:=0A =0Ait might be my sticking the pic into PC Paint and wre cking aspect ratio... those are off-the-shelf J-3 gear.... I have 2 new one s at home that I am covering....practice for building a whole Piet...in the way distant (retired) future. =0AOn Mar 29, 2014 11:28 AM, "taildrags" =0A>=0A>Is it just me (or the photo), or is Three-One-Lima-Alpha one long-legged airplane? -It just looks like the ma in gear legs are longer than most. -(Not being critical, by the way... lo ng legs can be attractive).=0A>=0A>--------=0A>Oscar Zuniga=0A>Medford, OR =0A>Air Camper NX41CC "Scout"=0A>A75 power=0A>=0A>=0A>=0A>=0A>Read this top ic online here:=0A>=0A>http://forums.matronics.com/viewtopic.php?p=421255 #421255=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>============0A >st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List=0A >============0A>http://forums.matronics.com=0A>== ==========0A>le, List Admin.=0A>="_blank">http://www.ma tronics.com/contribution=0A>============0A>=0A>=0A> ================= ________________________________________________________________________________
Date: Mar 29, 2014
Subject: Re: Piet project for sale?
well are u going to sell it or not ??=0A=0Ahyde=0AOn Saturday, March 29, 20 14 5:39 PM, TOM MICHELLE BRANT wrote:=0A =0A--> Pietenpo l-List message posted by: TOM MICHELLE BRANT =0A=0AStrongl y considering selling my Piet project if there is interest.- Sale is due to having kids and priorities changing over the last 8 years.- Since then , and at least for another 5 or so years, there will be no time to work on it, let alone money.=0A=0ABasically have all components for the airframe le ss hardware and covering materials.=0A=0AFuselage is 85% complete (long ver sion)=0AEnd spinach is complete less sanding and finish=0AAll ribs complete =0AWing spars=0ACarlson aircraft struts=0A4 foot center section about 60% c omplete=0AAll steel, including tubing for landing gear=0ATurnbuckles and ca ble=0AAltimeter=0ADrawings, corvair books, manuals, etc=0AProbably a few mo re miscellaneous items that I can't think of.=0A=0AHave about $3000 investe d but open to offers if there is interest.=0A=0AEmail me at tab1324(at)gmail.c om if interested please.=0A=0AProject is located in suburb of Minneapolis, mn.=0A=0AIt's more important to me that this thing fly some day than it is that it is me who finishes it.- So please, if you have interest, let me k ========= ________________________________________________________________________________
Date: Mar 30, 2014
yes if there is interest. so far=2C your'e the first. Date: Sat=2C 29 Mar 2014 21:15:45 -0700 From: jnl96(at)yahoo.com Subject: Re: Pietenpol-List: Piet project for sale? well are u going to sell it or not ?? hyde On Saturday=2C March 29=2C 2014 5:39 PM=2C TOM MICHELLE BRANT wrote: om> Strongly considering selling my Piet project if there is interest. Sale is due to having kids and priorities changing over the last 8 years. Since t hen=2C and at least for another 5 or so years=2C there will be no time to w ork on it=2C let alone money. Basically have all components for the airframe less hardware and covering m aterials. Fuselage is 85% complete (long version) End spinach is complete less sanding and finish All ribs complete Wing spars Carlson aircraft struts 4 foot center section about 60% complete All steel=2C including tubing for landing gear Turnbuckles and=0A cable Altimeter Drawings=2C corvair books=2C manuals=2C etc Probably a few more miscellaneous items that I can't think of. Have about $3000 invested but open to offers if there is interest. Email me at tab1324(at)gmail.com if interested please. Project is located in suburb of Minneapolis=2C mn. It's more important to me that this thing fly some day than it is that it i s me who finishes it. So please=2C if you have interest=2C let me know. Tom Brant Sent from my iPadhttp://www.matronics.com/Naviga= - MATRONI CS WEB FORUMS= &n--> =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Mar 30, 2014
Tom, I will be the first to ask it, as I am sure others are thinking it. Are you sure you want to sell? Plenty of builders have put their projects aside for long periods of time. Ask Kevin Purtee and others about that. Having said that, you have to make your own decision. I wish you the best. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421294#421294 ________________________________________________________________________________
Date: Mar 30, 2014
Thanks Terry=2C I've wrestled with the decision for quite a few years actually. There are sentimental ties to it of course since it was started in 2000 and my extend ed family helped build wing ribs=2C my mother sat in the pilots seat and so did my kids. But knowing all of this actually inspires me to sell it in a way to someone who has new energy to complete it. What a joy it would be for me to see it fly some day=2C knowing all the history I have with it wou ld be combined with someone elses hard work and dedication. My wife has always left the decision to me but reminded me of what's at sta ke with regards to those memories. But she understands my desire to see it completed is stronger than the desire to complete it myself. Also=2C it h elps at this time that it isn't necessarily about needing the money for oth er things as it has been before. Of course the money doesn't hurt though =3B) Definitely not an easy decision but I think the right one is to move on. I ts something I could do again with my kids if they showed interest when the y're old enough. I appreciate peoples comments on it for sure. Tom B. > Subject: Pietenpol-List: Re: Piet project for sale? > From: jarheadpilot82(at)hotmail.com > Date: Sun=2C 30 Mar 2014 11:01:35 -0700 > To: pietenpol-list(at)matronics.com > tmail.com> > > Tom=2C > > I will be the first to ask it=2C as I am sure others are thinking it. Are you sure you want to sell? Plenty of builders have put their projects asid e for long periods of time. Ask Kevin Purtee and others about that. > > Having said that=2C you have to make your own decision. I wish you the be st. > > -------- > Semper Fi=2C > > Terry Hand > Athens=2C GA > > USMC=2C USMCR=2C ATP > BVD DVD PDQ BBQ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421294#421294 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 30, 2014
I hope you find a great home for it, and I hope you are back before you know it! Best wishes. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421308#421308 ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Subject: All sideways on the Western front
Date: Mar 31, 2014
Dawn Pietrol with our young hero chasing down the Red Baron -- who turns ou t to be a manky Scots git in a Sopwith Hamble Baby. Sadly for our hero, the strut-mounted Lewis jams whereas the Baby's Vickers are smooth and true. H ow will he explain it all to Group Captain Macduff? http://youtu.be/MCY4I3IJixg -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Mar 30, 2014
Must be something wrong, Jeff. I didn't see any droop in your elevators! Great video! Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Boatright, Jeffrey Sent: Sunday, March 30, 2014 8:28 PM Subject: Pietenpol-List: All sideways on the Western front Dawn Pietrol with our young hero chasing down the Red Baron -- who turns out to be a manky Scots git in a Sopwith Hamble Baby. Sadly for our hero, the strut-mounted Lewis jams whereas the Baby's Vickers are smooth and true. How will he explain it all to Group Captain Macduff? <http://youtu.be/MCY4I3IJixg> http://youtu.be/MCY4I3IJixg -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine _____ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Subject: Re: All sideways on the Western front
Date: Mar 30, 2014
Pip Pip, Jeffery, Jolly good! Sent from my iPhone > On Mar 30, 2014, at 5:28 PM, "Boatright, Jeffrey" wrote: > > Dawn Pietrol with our young hero chasing down the Red Baron -- who turns o ut to be a manky Scots git in a Sopwith Hamble Baby. Sadly for our hero, the strut-mounted Lewis jams whereas the Baby's Vickers are smooth and true. Ho w will he explain it all to Group Captain Macduff? > > http://youtu.be/MCY4I3IJixg > > > > -- > > Jeffrey H. Boatright, PhD, FARVO > Associate Professor of Ophthalmology > Emory University School of Medicine > > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 30, 2014
Great video! Wife and kids even loved it! -------- Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421328#421328 ________________________________________________________________________________
Date: Mar 30, 2014
.... made my hair stand on end. The suspense. The gore. It unsettled the masses, to be sure. Ken On Sun, Mar 30, 2014 at 6:46 PM, wrote: > Pip Pip, Jeffery, Jolly good! > > Sent from my iPhone > > On Mar 30, 2014, at 5:28 PM, "Boatright, Jeffrey" > wrote: > > Dawn Pietrol with our young hero chasing down the Red Baron -- who turns > out to be a manky Scots git in a Sopwith Hamble Baby. Sadly for our hero, > the strut-mounted Lewis jams whereas the Baby's Vickers are smooth and > true. How will he explain it all to Group Captain Macduff? > > http://youtu.be/MCY4I3IJixg > > > -- > > Jeffrey H. Boatright, PhD, FARVO > Associate Professor of Ophthalmology > Emory University School of Medicine > > ------------------------------ > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). > > > * > > > * > > ________________________________________________________________________________
Date: Mar 31, 2014
Thanks! Great video! Wife and kids even loved it! -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 31, 2014
Beautiful video :-) I am looking forward to a footage from the next sortie! -------- My production of WW1 propellers, trophies and constructions: Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421334#421334 ________________________________________________________________________________
Date: Mar 31, 2014
Loved it! Best thing on a Sunday evening to end the week! Dan Helsper Puryear, TN -----Original Message----- From: Boatright, Jeffrey <jeffboatright(at)emory.edu> Sent: Sun, Mar 30, 2014 7:29 pm Subject: Pietenpol-List: All sideways on the Western front Dawn Pietrol with our young hero chasing down the Red Baron -- who turns ou t to be a manky Scots git in a Sopwith Hamble Baby. Sadly for our hero, the strut-mounted Lewis jams whereas the Baby's Vickers are smooth and true. H ow will he explain it all to Group Captain Macduff? http://youtu.be/MCY4I3IJixg -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 31, 2014
Thanks Dan. It was fun putting it together. -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine From: "danhelsper(at)aol.com<mailto:danhelsper(at)aol.com>" <danhelsper(at)aol.com<m ailto:danhelsper(at)aol.com>> >" > Date: Monday, March 31, 2014 7:28 AM etenpol-list(at)matronics.com> Subject: Re: Pietenpol-List: All sideways on the Western front Loved it! Best thing on a Sunday evening to end the week! Dan Helsper Puryear, TN -----Original Message----- From: Boatright, Jeffrey <jeffboatright(at)emory.edu<mailto:jeffboatright@emor y.edu>> onics.com>> Sent: Sun, Mar 30, 2014 7:29 pm Subject: Pietenpol-List: All sideways on the Western front Dawn Pietrol with our young hero chasing down the Red Baron -- who turns ou t to be a manky Scots git in a Sopwith Hamble Baby. Sadly for our hero, the strut-mounted Lewis jams whereas the Baby's Vickers are smooth and true. H ow will he explain it all to Group Captain Macduff? http://youtu.be/MCY4I3IJixg -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 31, 2014
From: Yahoo! Account Service <skipgadd(at)earthlink.net>
Subject: Re: Corvair Mounts and SnF
John, Where are you in Dayton area? The big show starts tomorrow, Dick and Dave are here and we will be getting the wood shop set up to make a couple sets of Piet floats. Skip -----Original Message----- >From: john francis <Mrkringles(at)msn.com> >Sent: Mar 29, 2014 12:59 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Corvair Mounts > > >Thanks Skip, thatll work for me. Ill let WW know to expect you. > >John > >-------- >John Francis > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=421258#421258 > > ________________________________________________________________________________
Date: Mar 31, 2014
I love it Jeff. Gardiner Sent from my iPad On Mar 30, 2014, at 8:28 PM, "Boatright, Jeffrey" w rote: > Dawn Pietrol with our young hero chasing down the Red Baron -- who turns o ut to be a manky Scots git in a Sopwith Hamble Baby. Sadly for our hero, the strut-mounted Lewis jams whereas the Baby's Vickers are smooth and true. Ho w will he explain it all to Group Captain Macduff? > > http://youtu.be/MCY4I3IJixg > > > > -- > > Jeffrey H. Boatright, PhD, FARVO > Associate Professor of Ophthalmology > Emory University School of Medicine > > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 31, 2014
Great video. Nice landing too Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421347#421347 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Date: Mar 31, 2014
SmVmZuKAlHdoYXQgYSBwbGVhc3VyZSB0byB3YXRjaCB5b3VyIGNyZWF0aXZpdHkgYW5kIGZ1biBQ aWV0ZW5wb2wgcHJvZHVjdGlvbiEgICBZb3VyIGNob2ljZSBvZiBtdXNpYyBhbmQgc291bmQgZWZm ZWN0cyB3ZXJlDQpmYW50YXN0aWMuICAgIFlvdXIgdmlkZW8gd2FzICBhIHJlYWxseSBuaWNlIGRp dmVyc2lvbiBmcm9tIHRoZSBhZ29uaXppbmcgZGlzY3Vzc2lvbnMgYWJvdXQgZWxldmF0b3IgZHJv b3AuDQoNCk1pa2UgQy4NCk9oaW8NCg0KDQpbY2lkOmltYWdlMDAxLmpwZ0AwMUNGNENCRC5EQjEz MkE3MF0NCg= ________________________________________________________________________________
Date: Mar 31, 2014
Very nice Jeff! What did you do to stiffen up the PVC pipe? I shoved a wood dowel in mine. It helps but I still get vibration. When it is cold it is stiffer and I get less vibration. When its warm though it vibrates all over. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421356#421356 ________________________________________________________________________________
Date: Mar 31, 2014
An Old buddy, now deceased, told a funny story of making all of his tent and fly poles for his boy scout group. He made them in the winter and they all worked fine. Then summer camping time came and they were so flexible in the heat that the tents would not stay up. Blue Skies, Steve D On Mon, Mar 31, 2014 at 8:08 AM, Don Emch wrote: > > Very nice Jeff! What did you do to stiffen up the PVC pipe? I shoved a > wood dowel in mine. It helps but I still get vibration. When it is cold > it is stiffer and I get less vibration. When its warm though it vibrates > all over. > > Don Emch > NX899DE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421356#421356 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 31, 2014
Skip, Im about an hour North of you in a small village called Russia. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421369#421369 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: poor man's metal stamping
Date: Mar 31, 2014
Thought I'd tap into the great mass of collective wisdom here. I want to fabricate a prototype sheet metal body shell, something like you'd see on a car from aluminum sheet. There are compound curves, but they nothing too hard. This is probably a one-off project and I can't spend the money to have big expensive stamping dies made, and don't want to take the time to use an English wheel for it all. Does anyone know of a poor man's method to make stampings? I've seen someone take a male and female plaster or bondo mold from a pattern and use a press to "stamp" our some aluminum sheets. Any thoughts are appreciated!! Douwe ________________________________________________________________________________
Subject: Re: poor man's metal stamping
Date: Mar 31, 2014
If you can make a concrete mold of the shape you want, and a piece of urethane padding, you can press the shape in with a simple bottle jack press. (for small pieces only) -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421379#421379 ________________________________________________________________________________
Date: Mar 31, 2014
Go to metalmeet.com and allmetalshaping.com two great resources for metalshaping. -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421380#421380 ________________________________________________________________________________
Date: Mar 31, 2014
Douwe, you can do a poor man=92s version of a process called =93Hydroforming=94 that was used at General Dynamics back in the 70=92s for some prototype parts. I used it to make some dimples in the cooling shrouds on my Pietenpol. I=92ll show how I used it to make the dimples on my cooling shrouds (eyebrows), then describe how the process can be modified. First, I=92ll show what it produced: This photo shows the rear of the right cooling shroud. I put Millenium Cylinders on my engine and the cooling fins stick out further than Continental cylinder=92s fins, so I found I needed to modify the shroud to clear the cooling fins. I determined the shape I needed and carved a female mold in particle board as shown below: Note the black rectangular object sitting in front of the sledgehammer. That is the key to this process. That is a block of hard rubber, 1=94 thick. That is what is used to force the aluminum into the shape of the mold, and takes the place of a male stamping die. The aluminum sheet needs to be located over the mold and pinned in place using clamps or tooling holes of some kind. Then the ribber is placed over the mold area and the sledgehammer is used to pound on the rubber, forcing the aluminum beneath the rubber to conform to the mold, as shown below: At General Dynamics, this procedure was used on pieces as large as an automobile hood. Of course, they used much larger (and thicker) pieces of rubber, and a hydraulic press to form the aluminum. They could form aluminum up to =BC=94 thick. Don=92t know if this was what you had in mind, but if your pieces aren=92t too big and the draw is not too deep, this method works well and is about as low cost as you could ever hope for. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Monday, March 31, 2014 2:29 PM Subject: Pietenpol-List: poor man's metal stamping Thought I=92d tap into the great mass of collective wisdom here=85 I want to fabricate a prototype sheet metal body shell, something like you=92d see on a car from aluminum sheet. There are compound curves, but they nothing too hard. This is probably a one-off project and I can=92t spend the money to have big expensive stamping dies made, and don=92t want to take the time to use an English wheel for it all. Does anyone know of a poor man=92s method to make stampings? I=92ve seen someone take a male and female plaster or bondo mold from a pattern and use a press to =93stamp=94 our some aluminum sheets. Any thoughts are appreciated!! Douwe ________________________________________________________________________________
Subject: any sheet metal guys out there?
Date: Mar 31, 2014
On another note.. I need a rectangular aluminum box fabricated using aircraft techniques. It needs to look "aircrafty" and have rivet lines. Doesn't need to hold liquid or anything, it's just for looks. Would be 4" thick 42" long by 24" wide. Anybody set up to do that, contact me offline. Thanks! Douwe douweblumberg(at)earthlink.net 805 573 3564 ________________________________________________________________________________
Subject: giblets
Date: Mar 31, 2014
I wonder how my pietie would fly if I didn't cover the fuse....the wood work is nice so im thinking that not covering the fuse I could expose the planes giblets for the world to see. it would also solve the tail heavy issue and save lots of work and money the berlot dint have the fuse covered and it flew fine... sort of... anyone know anyone that has done this??? hyde the pietie captain not the god guy Robert l scott wrote god is my copilot .. I wonder where he stuffed the dude because the P40 only had one seat.. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421396#421396 ________________________________________________________________________________
Subject: Re: giblets
Date: Mar 31, 2014
First off, I like the topic title. I have no Piet, and can't answer the question, but: http://cub.aero/?p=612 It's very true a naked Piet is art. I'll let the Piet people take over from here. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421403#421403 ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Mar 31, 2014
I can answer your question based on actually doing it. OK, I didn't but dad did with my airplane. Maybe 28 years ago. I would not advise anyone to do it. That said, my plane has a C85 cont. The airport elevation is 385 feet and dad only weighs 145 lbs. It barely flew and couldn't reach pattern alt. Enough said about that.DO NOT attempt it. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421410#421410 ________________________________________________________________________________
Subject: giblets
Date: Mar 31, 2014
I am planning to use Oratex fabric. The fabrics come in a small variety of basic colors and require no painting=2C although the initial cost of this f abric is higher than others. The USA Reps. were kind enough to send me a sm all sample of each color. I was surprised to find that the 'Antique White' is almost translucent. I have determined to cover the wings and tail surf aces in Antique White (Navy Blue on the fuse.) hoping that the effect will be to reveal some of the underlying structure. Lorenzo > Subject: Pietenpol-List: giblets > From: jnl96(at)yahoo.com > Date: Mon=2C 31 Mar 2014 15:51:31 -0700 > To: pietenpol-list(at)matronics.com > > > I wonder how my pietie would fly if I didn't cover the fuse ________________________________________________________________________________
Date: Mar 31, 2014
I appreciate the info.- I have been trying to contact these folks for mon ths with no luck. do u have any info on how to contact they? any help would be appreciated and would help to keep the tail light and cq in the proper location.=0A=0Athanks=0Ajim hyde- 817 578 1215=0AOn Monday, March 31, 201 4 8:28 PM, larharris2 Harris wrote:=0A =0A =0AI am pl anning to use Oratex fabric. The fabrics come in a small variety of basic c olors and require no painting, although the initial cost of this fabric is higher than others. The USA Reps. were kind enough to send me a small sampl e of each color.- I was surprised to find that the 'Antique White' is alm ost translucent. -I have determined to cover the wings and tail surfaces in Antique White (Navy Blue on the fuse.) hoping that the effect will be to reveal some of the underlying structure.=0A-=0ALorenzo=0A-=0A=0A-=0A =0A> Subject: Pietenpol-List: giblets=0A> From: jnl96(at)yahoo.com=0A> Date: M ============= ________________________________________________________________________________
Date: Mar 31, 2014
Lorenzo, that should look great. Perhaps you'll name it the SI Swimsuit edition. :) Ken On Mon, Mar 31, 2014 at 10:21 PM, jim hyde wrote: > I appreciate the info. I have been trying to contact these folks for > months with no luck. do u have any info on how to contact they? any help > would be appreciated and would help to keep the tail light and cq in the > proper location. > > thanks > jim hyde 817 578 1215 > On Monday, March 31, 2014 8:28 PM, larharris2 Harris > wrote: > I am planning to use Oratex fabric. The fabrics come in a small variety > of basic colors and require no painting, although the initial cost of this > fabric is higher than others. The USA Reps. were kind enough to send me a > small sample of each color. I was surprised to find that the 'Antique > White' is almost translucent. I have determined to cover the wings and > tail surfaces in Antique White (Navy Blue on the fuse.) hoping that the > effect will be to reveal some of the underlying structure. > > Lorenzo > > > > Subject: Pietenpol-List: giblets > > From: jnl96(at)yahoo.com > > Date: Mon, 31 Mar 2014 15:51:31 -0700 > > To: pietenpol-list(at)matronics.com > > > > > > I wonder how my pietie would fly if I didn't cover the fuse > > *http://www.matronics.com/N======================== > forums.matronics.com/ <http://forums.matronics.com/>" target="_blank" rel="nofollow">http://forums.mat = --> > > > * > > ________________________________________________________________________________
Date: Mar 31, 2014
Jim, Lars Gleitman Better Aircraft Fabric Office. (907) 344-6792 Cell. (907) 229-6792 4621 Caravelle Drive Anchorage Ak 99502 lars(at)betteraircraftfabric.com -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421426#421426 ________________________________________________________________________________
Date: Apr 01, 2014
Learn to use an English Wheel. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421437#421437 ________________________________________________________________________________
Subject: giblets
Date: Apr 01, 2014
Terry Hand sent you the best contact info I have. If you haven't already=2C visit their website=2C betteraircraftfabric.com . You can download a pdf brochure of the Oratex products. Lorenzo Date: Mon=2C 31 Mar 2014 19:21:41 -0700 From: jnl96(at)yahoo.com Subject: Re: Pietenpol-List: giblets I appreciate the info. I have been trying to contact these folks for month s with no luck. do u have any info on how to contact they? any help would b e appreciated and would help to keep the tail light and cq in the proper lo cation. ________________________________________________________________________________
Date: Apr 01, 2014
Gee, Scott! Sounds like it flew just like a Bleriot (or a berlot). Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Monday, March 31, 2014 9:05 PM Subject: Pietenpol-List: Re: giblets I can answer your question based on actually doing it. OK, I didn't but dad did with my airplane. Maybe 28 years ago. I would not advise anyone to do it. That said, my plane has a C85 cont. The airport elevation is 385 feet and dad only weighs 145 lbs. It barely flew and couldn't reach pattern alt. Enough said about that.DO NOT attempt it. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421410#421410 ________________________________________________________________________________
Subject: An all sheet-metal Pietenpol design...?
Date: Apr 01, 2014
Hello good Piet-ple, Things are progressing well on my 1931 Pietenpol, yet this time of year thoughts often turn to "What project next"...?!?! I've been thinking that perhaps the Pietenpol needs updating a bit while still keeping with the designer's original intent. What better way to do that than by creating a sheet metal version of the design - the Sheet-en-pol I've run some numbers and it looks like the RV-8 wing and empennage would work well. These parts are readily available as component kits from Vans. This would allow me to concentrate most of my design work on the fuselage and paint scheme. The canopy from the RV-8 should fit nicely around the tandem seat arrangement which would make the plane useful for a greater portion of the year - especially considering all the rain we get here in Seattle. The canopy feature might even work well in places like Minnesota where the original was designed or Ohio where so many Pietenpols get built for some strange reason. (Maybe cause it is the birthplace of the Wright Brothers or something!) I ran some flow analysis (see image) and it looks like with all the changes the design might actually reduce the drag enough to require the installation of an airspeed indicator. Not wanting to bite off too much by designing both an experimental airframe AND an engine (no one would ever want to do THAT) I would use only a certified automotive conversion. Glad for these early springtime April days to be able to let the mind wander a bit Jake -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421442#421442 Attachments: http://forums.matronics.com//files/pietenpol_airflow_636.jpg ________________________________________________________________________________
Subject: Joseph Jameson's Corvair engine runs
Date: Apr 01, 2014
Builders: We just got back from Corvair College #29, and the high point of the event was the perfect engine test run of the 100HP Corvair built by 16 year old Pietenpol builder Joseph Jameson. We ran a number of builders engine for the first time at the College, but everyone present took notice of Joseph's achievement. The October '13 BPA newsletter carried a nice story about Dan Helsper taking Joseph aloft for his first flight in a Pietenpol. Doc and Dee, Dan and most everyone who has met Joseph comments that he is obviously a bright and thoughtful young man, blessed with a supportive family. A few minutes in his company is enough to make a curmudgeon say something positive about the future of aviation. Joseph has a lot of his airframe built, and is closing in on his PP check ride, but opted to dig into his Corvair engine when Kevin Purtee and Shelley Tumino hosted Corvair College#28 in Texas. You can see Joseph and his father Kelley speaking with award winning Piet builder and flyer Hans Vandervort at the college in this link: http://flycorvair.net/2014/03/13/corvair-college-28-san-marcos-texas/ Joseph got his Corvair underway at #28, but signed up for #29 in Florida to finish and test run it. The engine is a 100HP Corvair, with a Roy, 5th bearing and Falcon heads. It is not a "spare no expense" engine, but it is an exceptionally high quality Corvair with electric start, dual ignition, stainless valves, HD oil cooler and filter and some weight reduction items like a flyweight welded deep sump pan. The engine is a bit lighter than a C-90 or an O-200. When Joseph was done, we pre-oiled it and put it on our test stand. It started in less than 2 seconds of cranking. We put down a 30 minute run to break in the cam and lifters, followed by a second run. I have run several hundred Corvairs on the stand in the last decade, and Joseph's engine ran as well as any of them. It was smooth, didn't leak a drop of oil, and his adjustment of the hydraulic lifters was perfect. A visitor to the college asked what this young man's 'secret of success' was. I said "He actually read the book and he follows the instructions." Hats off to Joseph for his achievement in learning and building, and special thanks to everyone in the Piet community that played a positive role in assisting him. Joseph and his Dad are planning on attending Brodhead this year, if you have not met them, take a moment to do so, they are outstanding people. -ww Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421443#421443 ________________________________________________________________________________
Date: Apr 01, 2014
I have also wondered about the fuselage covering. When I was first getting interested in a homebuilt the Breezy was a very interesting consideration. It apparently works. Also look at the site for the Backyard Flyer ultralight. I have been watching the Flyer at EAA for the last few years. I have been trying to convince myself it might be a good alternative while I slowly work on my Pietenpol. The people at Backyard Flyer told me the uncovered fuselage reduces the wind vane effect in crosswinds which can plague a very light aircraft. I am planning in leaving the cockpit uncovered to emphasize the wood construction. I saw one treated that way at Brodhead many years ago in my early planning stages. Ralph in SD ________________________________________________________________________________
Date: Apr 01, 2014
Subject: Re: An all sheet-metal Pietenpol design...?
Jake, for the Sheet-enpol, you should consider a Vtail so that you can mount a The TJ-100 turbojet engine produced by PBS Velk=C3=A1 B=C3=ADte=C5 =A1 of the Czech Republic. In keeping with keeping it true to the 1930s period. PBS is a large manufacturer rotary machines with roots dating-back to 1814 and therefore could have been used by Mr Pietenpol in 1929. Similar to the Subsonix. Perhaps it could be called the Subsheeetenpol. Ducking and running for cover. Steve D ________________________________________________________________________________
Date: Apr 01, 2014
Jake, Nobody,s biting today. I wonder why???? -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421446#421446 ________________________________________________________________________________
Date: Apr 01, 2014
Jack, I never flew one of those. I'm not that old. Sounds like you know better than I do. How old did you say you were??? Just messing with you. I do bet that it is a good comparison. At least the Piet doesn't have wing warping. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421450#421450 ________________________________________________________________________________
Date: Apr 01, 2014
It's all in good fun...... this is a FUN airplane after all :-) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421451#421451 ________________________________________________________________________________
Date: Apr 01, 2014
Jake, It's a great flight to be on. This list is what I mean. Enjoy the day folks. Off to the airport now. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421452#421452 ________________________________________________________________________________
Date: Apr 01, 2014
Jake, for the Sheet-enpol, you should consider a Vtail so that you can mount a The TJ-100 turbojet engine produced by PBS Velk=C3=A1 B=C3=ADte=C5 =A1 of the Czech Republic. In keeping with keeping it true to the 1930s period. PBS is a large manufacturer rotary machines with roots dating-back to 1814 and therefore could have been used by Mr Pietenpol in 1929. Similar to the Subsonix. Perhaps it could be called the Subsheeetenpol. Ducking and running for cover. Steve D I dun sent this once befor On Tue, Apr 1, 2014 at 9:54 AM, AircamperN11MS wr ote: > Scott.liefeld(at)lacity.org> > > Jake, > Nobody,s biting today. I wonder why???? > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421446#421446 > > =========== =========== =========== =========== > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Apr 01, 2014
Well, no intentional wing-warping anyway! It could be done if you weren't careful, but it's also a static adjustment ;). On Apr 1, 2014, at 11:06 AM, AircamperN11MS wrote: > > Jack, > I never flew one of those. I'm not that old. Sounds like you know better than I do. How old did you say you were??? Just messing with you. I do bet that it is a good comparison. At least the Piet doesn't have wing warping. > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421450#421450 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 01, 2014
Guys, There are a number of Piet pictures and builders on this 2009 web update from our site: http://www.flycorvair.com/hangar1009.html, but if you look about 1/2 way down It has a picture of Don Taylor's all sheet metal, two seat, tandem Fly baby. Wisely powered by a 'certified auto engine.' Don Taylor is a very early EAA guy who was best Known for 'Tinker-toy' a very innovative pusher homebuilt that used a corvair and a belt reduction where the axis of the prop was concentric with the single top longeron of the fuselage. Flew for about 10 years in the 70's -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421455#421455 ________________________________________________________________________________
Date: Apr 01, 2014
I saw Chad Wilie fly the Bleriot at Brodhead a couple of years ago. He never got it out of ground effect, but technically it "flew". Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Tuesday, April 01, 2014 11:06 AM Subject: Pietenpol-List: Re: giblets Jack, I never flew one of those. I'm not that old. Sounds like you know better than I do. How old did you say you were??? Just messing with you. I do bet that it is a good comparison. At least the Piet doesn't have wing warping. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421450#421450 ________________________________________________________________________________
Date: Apr 01, 2014
Sounds interesting but the link does not work...???!!? Just when you think you think of something new it turns out somebody has already done it...! Jake -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421457#421457 ________________________________________________________________________________
Date: Apr 01, 2014
try this link: http://www.flycorvair.com/hangar1009.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421458#421458 ________________________________________________________________________________
Subject: GoPro test
Date: Apr 01, 2014
...test..test.. short gopro test fresh out of the box. Had not looked at proper settings yet. Tried slo-mo, black&white..camera vibration in flt...did nothing w/sound yet, etc.. http://youtu.be/3IiAMQM3uJ0 -------- KLNC A65-8 N2308C AN Hardware Airframe 724TT W72CK-42 Sensenich Standard Factory GN-1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421460#421460 ________________________________________________________________________________
Date: Apr 01, 2014
WW, VERY nice - Thanks...! J -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421461#421461 ________________________________________________________________________________
Subject: mylar covered Jenny
Date: Apr 01, 2014
[cid:image001.png(at)01CF4DAB.2D52A110] [cid:image002.png(at)01CF4DAB.2D52A110] [cid:image003.png(at)01CF4DAB.2D52A110] ________________________________________________________________________________
Date: Apr 01, 2014
William, in the article it showed engine mount tubes beautifully profiled with CNC. Do you know if Don has ever done tubes for a Continental mount for a Piet. Mine is already cut (what a pain), but others may have an interest. Sent from my iPad Jack Textor > On Apr 1, 2014, at 10:26 AM, "William Wynne" wrote: > > > Guys, > > There are a number of Piet pictures and builders on this 2009 web update from our site: http://www.flycorvair.com/hangar1009.html, but if you look about 1/2 way down It has a picture of Don Taylor's all sheet metal, two seat, tandem Fly baby. Wisely powered by a 'certified auto engine.' > > Don Taylor is a very early EAA guy who was best Known for 'Tinker-toy' a very innovative pusher homebuilt that used a corvair and a belt reduction where the axis of the prop was concentric with the single top longeron of the fuselage. Flew for about 10 years in the 70's -ww. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421455#421455 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 01, 2014
Jack, I am pretty sure he does not have it because he tends to serve manufacturers with proprietary designs rather than low volume or one off guys. The prototype cost is about the same as the first 15 tubing sets cost. I have made about 12 or 13 high thrust line Corvair/Piet mounts, but we hand cut them, as the volume was low compared to the numbers on 601/750 mounts. I have worked with Don for 10 years or so, and he remains one of the most impressive people we have met in industry. Canadians ought to be very proud, VR-3 is entirely a Canadian entity down to the software design and tooling. Don does a giant share of the tubing work in light planes, including certified ones, but he also does DOD work and engineering.-ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421467#421467 ________________________________________________________________________________
Date: Apr 01, 2014
Subject: Re: mylar covered Jenny
WOW, Would that cause any problems? IE heat and/or moisture buildup inside the mylar, esp the wing. Blue Skies Steve D ________________________________________________________________________________
Date: Apr 01, 2014
That is a great video. But my personal fav is "Don't Turn Right!". A cinematic masterpiece! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421474#421474 ________________________________________________________________________________
Date: Apr 01, 2014
Douwe, This photo is self explanatory. Maybe it will spark some ideas. Dan Helsper Puryear, TN -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Mon, Mar 31, 2014 1:29 pm Subject: Pietenpol-List: poor man's metal stamping Thought I=99d tap into the great mass of collectivewisdom here I want to fabricate a prototype sheet metal body shell,something like you =99d see on a car from aluminum sheet. There arecompound curves, but they nothing too hard. This is probably a one-off project and I can=99t spendthe money to ha ve big expensive stamping dies made, and don=99t want totake the time to use an English wheel for it all. Does anyone know of a poorman=99 s method to make stampings? I=99ve seen someone take a male and female plaster orbondo mold from a pattern and use a press to =9Cstamp=9D our somealuminum sheet s. Any thoughts are appreciated!! Douwe ________________________________________________________________________________
Date: Apr 01, 2014
I've been thinking that perhaps the Pietenpol needs updating a bit =C3=A2 =C2=C2=93 while still keeping with the designer's original intent. What better way to do th at than by creating a sheet metal version of the design Love you Jake....but seriously? This is a gag, right? BHP would be rolling over in his grave right about now.... Dan Helsper Puryear, TN cc: TC Emeritus cc: Board of Curmudgeons -----Original Message----- From: aerocarjake <flight.jake(at)gmail.com> Sent: Tue, Apr 1, 2014 11:13 am Subject: Pietenpol-List: An all sheet-metal Pietenpol design...? Hello good Piet-ple, Things are progressing well on my 1931 Pietenpol, yet this time of year tho ughts often turn to "What project next"...?!?! I've been thinking that perhaps the Pietenpol needs updating a bit =C3=A2 =C2=C2=93 while still keeping with the designer's original intent. What better way to do th at than by creating a sheet metal version of the design - the =C3=A2=C2=C2 =9CSheet-en-pol=C3=A2=C2=C2=9D I've run some numbers and it looks like the RV-8 wing and empennage would w ork well. These parts are readily available as component kits from Vans. This w ould allow me to concentrate most of my design work on the fuselage and paint sc heme. The canopy from the RV-8 should fit nicely around the tandem seat arrangeme nt which would make the plane useful for a greater portion of the year - espec ially considering all the rain we get here in Seattle. The canopy feature might e ven work well in places like Minnesota where the original was designed or Ohio where so many Pietenpols get built for some strange reason. (Maybe =C3=A2=C2 =C2=98cause it is the birthplace of the Wright Brothers or something=C3=A2=C2=C2!) I ran some flow analysis (see image) and it looks like with all the changes the design might actually reduce the drag enough to require the installation of an airspeed indicator. Not wanting to bite off too much by designing both an experimental airframe AND an engine (no one would ever want to do THAT) I would use only a certified automotive conversion. Glad for these early springtime April days to be able to let the mind wande r a bit=C3=A2=C2=C2=C3=A2=C2=C2 Jake -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421442#421442 Attachments: http://forums.matronics.com//files/pietenpol_airflow_636.jpg ________________________________________________________________________________
Date: Apr 01, 2014
Thanks for the kind words. I have to say, "Don't turn right!" is favored by just about everyone, including me. Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine Sent from an iPad with a spelling problem > On Apr 1, 2014, at 6:23 PM, "tools" wrote: > > > That is a great video. But my personal fav is "Don't Turn Right!". A cinematic masterpiece! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421474#421474 > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Apr 01, 2014
Yes, this is APRIL FIRST after all......!! BHP would hopefully appreciate the humor :-) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421478#421478 ________________________________________________________________________________
Date: Apr 01, 2014
Dag-Nabit Jake! You got me! Dan Helsper Puryear, TN -----Original Message----- From: aerocarjake <flight.jake(at)gmail.com> Sent: Tue, Apr 1, 2014 5:47 pm Subject: Pietenpol-List: Re: An all sheet-metal Pietenpol design...? Yes, this is APRIL FIRST after all......!! BHP would hopefully appreciate the humor :-) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421478#421478 ________________________________________________________________________________
Date: Apr 01, 2014
....but I could make new plans for such a design and then "build it exactly to the plans" Ha! Hope to post some photos in the next few days of my Piet on it's gear...! (OK the wheels are plywood circles until I get my real ones, but it is on it's own gear....!!!!!!) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421483#421483 ________________________________________________________________________________
Subject: Information resource - Sun n Fun
Date: Apr 01, 2014
Builders, If you are looking for another information resource, I have written an index of the 200 most popular stories on our website. They are all related to aircraft building, but even if a builder was not going to use a Corvair, there are still 70-80 stories that will be useful on carbs, oils, wiring, instruments, Piets, welding etc. If you have the time, peruse the titles, you can click on any of them to read the whole story: http://flycorvair.net/2014/04/02/200-stories-of-aircraft-building/ Vern, Lynn and myself are headed to Sun n Fun in a few hours. A number of builders are getting together at the SPA/Panther booth of Friday night for their cook out after hours. I have forums to give On Wed. Fri. Sat. at 12 noon. I will have a spare 24.25" Corvair/Piet mount with us. Looking forward to seeing a number of you there.-ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421491#421491 ________________________________________________________________________________
Date: Apr 02, 2014
I forgot just how flat the world is in that part of the country. What a nice little airport. Carry on, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421495#421495 ________________________________________________________________________________
Date: Apr 02, 2014
Douwe Check out EAA hints for homebuilders video on hrdoforming - very cool video. The link is being attached but is is so weird it may not work If the link is broken just Google tersm EAA hints for homebuilder hydroforming and get this link: https://www.google.com/url?q=http://www.eaavideo.org/video.aspx%3Fv%3D1277219627001&sa=U&ei=eDg8U9KWIIGO2AWmsYG4CA&ved=0CBsQFjAA&usg=AFQjCNFtoV-yxuQBXK5EEL-CI9uyhoa8ww -------- Bob 'Early Builder' Dewenter Dayton OH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421502#421502 ________________________________________________________________________________
Date: Apr 02, 2014
I don't know if a nest of bare tubing would create as much drag as fabric-covered slab sides, but I do know that I use slips to landing a LOT in my airplane. Without flaps, slips are the best way to manage descent profile and I always like to bring Scout in a little high and then slip it down to the numbers. Rarely am I able to nail the airspeed and altitude on final to where I don't have to adjust something (unlike Jeff Boatright, who scared me coming in as close to the treetops as he did after his guns jammed and he had to run back home. It seemed like he was on rails all the way down to the turf). Maybe one of the builders planning to use Oratex can sew in a couple of zippers that would allow the empennage covering to be unzipped to test flight characteristics with bare bones out there? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421506#421506 ________________________________________________________________________________
Subject: Re: It's FINALLY a hangar...
Date: Apr 02, 2014
Not only is it a hangar, it's being used as one! N2RN is up and flying. Our field is rather varsity, so I took off and flew 10 miles to 9A5 for fuel. Son met me there and we went another 5 miles south to a really nice wide and long grass strip. He is soloed and only has around 10 hours, nearly 2 years ago. Threw him in the back and I jumped up front and off we went. I was REALLY proud of him, did a fantastic job. Flew to another nearby grass strip, hitting 9a5 for a hard surface runway touch and go on the way, dropped him off there and then I brought it home. I'm pretty much gone the next two weeks, but after that should get him soloed again and making progress on his license. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421515#421515 Attachments: http://forums.matronics.com//files/safe_on_deck_169.jpeg http://forums.matronics.com//files/on_the_roll_204.jpeg ________________________________________________________________________________
Date: Apr 02, 2014
Congratulations on getting her flying again! I kow you are Scott are really happy. Good job! -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421519#421519 ________________________________________________________________________________
Date: Apr 02, 2014
I second that! Nice job putting the airplane back together, and what could be better than a Pietenpol flying off of grass! -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421522#421522 ________________________________________________________________________________
Date: Apr 02, 2014
hw much time do u have on the plane now?=0A=0Ajim=0AOn Wednesday, April 2, 2014 9:41 PM, jarheadpilot82 wrote:=0A =0A--> Pietenpol-List message posted by: "jarheadpilot82" =0A=0ACongratulations on getting her flying again! I kow you are Scott are really happy. Good job!=0A=0A--------=0ASemper Fi,=0A=0ATerry Hand=0AA thens, GA=0A=0AUSMC, USMCR, ATP=0ABVD DVD PDQ BBQ=0A=0A=0A=0A=0ARead this t opic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=421519 = ________________________________________________________________________________
Date: Apr 02, 2014
thanks=0Ajim=0AOn Wednesday, April 2, 2014 4:27 PM, taildrags =0A=0AI don't know if a nest of bare tubing would cr eate as much drag as fabric-covered slab sides, but I do know that I use sl ips to landing a LOT in my airplane.- Without flaps, slips are the best w ay to manage descent profile and I always like to bring Scout in a little h igh and then slip it down to the numbers.- Rarely am I able to nail the a irspeed and altitude on final to where I don't have to adjust something (un like Jeff Boatright, who scared me coming in as close to the treetops as he did after his guns jammed and he had to run back home.- It seemed like h e was on rails all the way down to the turf).=0A=0AMaybe one of the builder s planning to use Oratex can sew in a couple of zippers that would allow th e empennage covering to be unzipped to test flight characteristics with bar e bones out there?=0A=0A--------=0AOscar Zuniga=0AMedford, OR=0AAir Camper NX41CC "Scout"=0AA75 power=0A=0A=0A=0A=0ARead this topic online h ere:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=421506#421506=0A=0A =========================0A ====================== ________________________________________________________________________________
Date: Apr 03, 2014
Thanks! It came with about two and a quarter, I think I've put on between 75 and a hundred. It'll be three years in Sep I've owned it. Was down 4 months after the first debacle... down for about a year and 8 months this time. The second debacle occurred about a week after getting it back up the first time! Learning a LOT! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421527#421527 ________________________________________________________________________________
Date: Apr 03, 2014
Good job Tools. Congratulations to you and Scott. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421532#421532 ________________________________________________________________________________
Subject: N2RN
Date: Apr 03, 2014
Congrats on getting N2RN airborne again! Great plane!! Super light. Douwe ________________________________________________________________________________
Date: Apr 03, 2014
Subject: bird nest and mud dobbers
Now is the time in NC that the birds and mud dobbers are busy. I just tore out a nest that had been started in my "C" section before they had a chance to lay eggs. Ted Stone ________________________________________________________________________________
Date: Apr 03, 2014
Search YouTube for; Tinmantech. I am sure you will find what you need there. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421537#421537 ________________________________________________________________________________
Subject: Re: bird nest and mud dobbers
Date: Apr 03, 2014
Funny you should mention that! Just this morning we noticed that a mourning dove has fashioned a nest on one of my workbenches, next to a table saw. With two weeks for the eggs to incubate and another two weeks for the fledglings to leave the nest, I guess I won't be using the table saw till next month ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421539#421539 Attachments: http://forums.matronics.com//files/bird_134.jpg ________________________________________________________________________________
Date: Apr 03, 2014
And all the crap that comes with her! I dont think they are on the endangered list. I would move the nest. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421540#421540 ________________________________________________________________________________
Date: Apr 03, 2014
John Sorry I lost the thread. were you talking about girlfriends or wives? Steve D On Thu, Apr 3, 2014 at 2:19 PM, john francis wrote: > > And all the crap that comes with her! I don't think they are on the > endangered list. I would move the nest. > > -------- > John Francis > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421540#421540 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Apr 03, 2014
thanks jack:-)=0AOn Wednesday, April 2, 2014 11:27 PM, jim hyde wrote:=0A =0Athanks=0Ajim=0AOn Wednesday, April 2, 2014 4:27 PM, ta ildrags wrote:=0A =0A--> Pietenpol-List message po sted by: "taildrags" =0A=0AI don't know if a nest of bare tubing would create as much drag as fabric-covered slab sides, but I do know that I use slips to landing a LOT in my airplane.- Without flaps, slips are the best way to manage descent profile and I always like to brin g Scout in a little high and then slip it down to the numbers.- Rarely am I able to nail the airspeed and altitude on final to where I don't have to adjust something (unlike Jeff Boatright, who scared me coming in as close to the treetops as he did after his guns jammed and he had to run back home .- It seemed like he was on rails all the way down to the turf).=0A=0AMay be one of the builders planning to use Oratex can sew in a couple of zipper s that would allow the empennage covering to be unzipped to test flight cha racteristics with bare bones out there?=0A=0A--------=0AOscar=0A Zuniga=0AM edford, OR=0AAir Camper NX41CC "Scout"=0AA75 power=0A=0A=0A=0A=0A Read this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php ?p=421506#421506=0A=0Ahttp://www.matronics.com/Navigator?Pietenpol-Linbsp ; - - - - -=0Asp; - - - - - - - -Matt Dralle, List A ======= ________________________________________________________________________________
Date: Apr 04, 2014
The side area of a fuselage is part of the design calculations on the yaw stability along the vertical axis which includes the fin area. The area removed would have to be calculated for the loss area of the fuselage sides an added to the fin to keep the stability as designed. Just my 2-cents worth .... WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421554#421554 ________________________________________________________________________________
Date: Apr 04, 2014
ood thanks=0Ajim=0AOn Friday, April 4, 2014 7:24 AM, womenfly2 =0A=0AThe side area of a fuselage is part of the design calculations on the yaw stability along the vertical axis which incl udes the fin area. The area removed would have to be calculated for the los s area of the fuselage sides an added to the fin to keep the stability as d esigned.=0A=0AJust my 2-cents worth .... WF2=0A=0A--------=0A=0A=0A=0A=0A =0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtop - - - - - - - - - - - - - - - -Matt Dralle, L ======= ________________________________________________________________________________
Date: Apr 04, 2014
Below is a response from my buddy the aerodynamacyst. He is also a plane ownerr of some experience. I asked him about effects of drag, slipping and would streamlinig the exposed wood/tubes help. G'day Steve, Yes, the drag will be increased with an exposed fuselage structure. Will it fly? That depends on the available thrust horsepower available. Enough, and it will fly. The next question is: How does not covering the fuselage affect the stability and control as well as the balance of the aircraft? Unknown. Slipping should work. The exposed fuselage may, or may not, have more drag than the covered fuselage in a slip. Streamlining might help the aerodynamics but may not help the structural strength. If left uncovered, the owner will not just be a test pilot for a known design, but an EXPERIMENTAL test pilot for an "unknown" design. Dave Rogers On Fri, Apr 4, 2014 at 4:58 PM, jim hyde wrote: > ood thanks > jim > On Friday, April 4, 2014 7:24 AM, womenfly2 > wrote: > > > > The side area of a fuselage is part of the design calculations on the yaw > stability along the vertical axis which includes the fin area. The area > removed would have to be calculated for the loss area of the fuselage sides > an added to the fin to keep the stability as designed. > > Just my 2-cents worth .... WF2 > > -------- > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421554#421554 > > /Navigator?Pietenpol-List" target="_blank">http://www.matronics.com/Navig > - MATRONICS WEB FORUMS= &n--> > http://ww====================== > > > <http://www.matronics.com/contribution> > > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Apr 05, 2014
Subject: Phishing attack
Folks, It appears that my userid is currently being used as an alias in a phishing attack. Please do not open any email that appears to be coming from me that asks you to open a Google Doc file. I have not sent such an email and apologize in advance for the inconvenience. My best, Ken Bickers ________________________________________________________________________________
Date: Apr 04, 2014
thanks jim=0AOn Friday, April 4, 2014 9:48 PM, Steven Dortch wrote:=0A =0ABelow is a response from my buddy the aerodynam acyst. He is also a =0Aplane ownerr of some experience. I asked him about e ffects of drag, =0Aslipping and would streamlinig the exposed wood/tubes he lp. =0A=0A=0A=0A=0AG'day Steve,=0A=0AYes, the drag will be increased with a n exposed fuselage structure.=0A=0AWill it fly? That depends on the availab le thrust horsepower available. Enough, and it will=0Afly.=0A=0AThe next qu estion is: How does not covering the fuselage affect the stability and cont rol=0Aas well as the balance of the aircraft? Unknown.=0A=0ASlipping should work. The exposed fuselage may, or may not, have more drag than the=0Acove red fuselage in a slip.=0A=0AStreamlining might help the aerodynamics but m ay not help the structural strength.=0A=0AIf left uncovered, the owner will not just be a test pilot for a known design, but=0Aan EXPERIMENTAL test pi lot for an "unknown" design.=0A=0ADave Rogers=0A=0A=0A=0AOn Fri, Apr 4, 201 4 at 4:58 PM, jim hyde wrote:=0A=0Aood thanks=0A>jim=0A>O n Friday, April 4, 2014 7:24 AM, womenfly2 wrote: mail.com>=0A>=0A>The side area of a fuselage is part of the design calculat ions on the yaw stability along the vertical axis which includes the fin ar ea. The area removed would have to be calculated for the loss area of the f uselage sides an added to the fin to keep the stability as designed.=0A>=0A >Just my 2-cents worth .... WF2=0A>=0A>--------=0A>=0A>=0A>=0A>=0A>=0A>=0A> =0A>Read this topic online here:=0A>=0A>http://forums.matronics.com/viewtop ic.php?p=421554#421554=0A>=0A>/Navigator?Pietenpol-List" target="_blank ">http://www.matronics.com/Navig=- - - - - - - - MATRONICS WEB FORUMS=- - - - - - - - - - &n--> http://ww== ======================0A>=0A>=0A> =0A>=0A>=0A> =0A>" target="_blank">http://www.matronics.com/Navigator? Pietenpol-List=0Atp://forums.matronics.com=0A_blank">http://www.matronics.c =========== ________________________________________________________________________________
Date: Apr 05, 2014
Hi John, Got the mount today, looks real good. We will be here for a week after the show is over, which is tomorrow. We will head to WV. We may be heading over to Miamisburg around the 18th. I will email you. Skip -----Original Message----- >From: john francis <Mrkringles(at)msn.com> >Sent: Mar 31, 2014 11:18 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Corvair Mounts and SnF > > >Skip, > >Im about an hour North of you in a small village called Russia. > >John > >-------- >John Francis > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=421369#421369 > > ________________________________________________________________________________
Subject: Re: Question Re: Cabane material
Date: Apr 06, 2014
While perusing the Carlson site, I noticed their Jury Strut extrusions, which would appear to be suitable for cabanes on the Piet. Has anyone used this extrusion for their cabanes? How about the diagonal braces to the firewall? Please chime in... -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421606#421606 ________________________________________________________________________________
Date: Apr 06, 2014
Forgot the link: http://carlsonaircraft.com/struts.html -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421607#421607 ________________________________________________________________________________
Date: Apr 06, 2014
Tom, I used Carlson "small" wing struts. My cabanes are streamline steel, my dia gonals are round steel, jury struts are round steel. Dan Helsper Puryear, TN -----Original Message----- From: tkreiner <tkreiner(at)gmail.com> Sent: Sun, Apr 6, 2014 7:47 am Subject: Pietenpol-List: Question Re: Cabane material While perusing the Carlson site, I noticed their Jury Strut extrusions, whi ch would appear to be suitable for cabanes on the Piet. Has anyone used this extrusion for their cabanes? How about the diagonal b races to the firewall? Please chime in... -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421606#421606 ________________________________________________________________________________
Date: Apr 06, 2014
Beautiful woodwork, especially the wing spars. You must have done that work in your pre-curmudgeon days. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421663#421663 ________________________________________________________________________________
Subject: aluminum cabanes
Date: Apr 07, 2014
Hey Tom, I do not believe I have ever seen aluminum cabanes on a Pietenpol. This certainly doesn't mean it hasn't been done, it just means I've never encountered it. We've all seen aluminum struts though, and they work. I would just go with steel since I can't really think of reasons to go with aluminum (maybe a pound or two, if that"??) If you want to forge new territories then I suppose you'd start comparing material strengths etc and keep digging to see if you can find any that have gone before you. Douwe ________________________________________________________________________________
Subject: Re: aluminum cabanes
Date: Apr 07, 2014
A reason I can think of to research it is that when you buy wing struts, you buy the entire 10 ft length. You can opt to have them send the 2ft left overs or not (as the max length to send is 8ft, which is about the right length for the Piet). It seems they (the left overs) would make excellent cabanes (right term?). Mating aluminum front diagonals to them would make a lot of sense in that case. This is kind of how I leaning towards doing the Piet I'm building as I REALLY like the aluminum wing struts. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421691#421691 ________________________________________________________________________________
Subject: landing practice
Date: Apr 07, 2014
Hey, To help spur on the builders, I want to share yesterday's flight experience. Got another "weather window" and slipped "RE-PIET" out of the hangar at 7:00pm, had an hour before sunset. The winds had died to almost nothing and were right down the runway. Decided to do five or six take-offs and landings. It was a blast!! It was a bit chilly, but that was offset by some hear-stirring cool-air performance. Without a well-calibrated airspeed indicator (I only have a Johnson strut-mounted) I'm leery of really pushing my slow flight approaches. This day, I decided to inch up on it and just keep "feeling the lift" as I slowed up to make sure she was still good. Shot a few and things went really well. I then started experimenting with some pretty aggressive slips, which was really fun also! For me (my own preference for all you "nit-pickers" out there) I find it so much easier than a modern slick airframe. Sure, I slow down some on downwind, but she slows so fast I pretty much find myself landing her like a hang glider, I.E. it feels like I am diving (or slipping) to the runway and then I just slow things up when I get there and plunk her down. Because our runway is long, I've found myself landing a bit fast so I can really grease her on and go easy on the tires and landing gear. I really need to work on my short field landing technique though and this was great practice. Asphalt is sure different, but It's where she lives so I have had to get confident on it. I am still keeping my crosswind component within my comfort zone , but I'm sneaking up on asphalt proficiency. Got to fly formation with a Citabria which was fun, I absolutely love flying with other planes, it's one of my favorite flying experiences. Keep building, it's worth it!! Douwe Ps. I was told that someone had just put their Pietenpol on the airport "waiting list", but he couldn't remember the name. Anyone out there trying to get into Gene Snyder (K62) near Falmouth KY?? Pss. Think I'm about to install some VG's for fun. ________________________________________________________________________________
Subject: It's starting to look like.... well, an airplane...!!
Date: Apr 07, 2014
Hello good Piet-ple, There was a sunny afternoon in Seattle on Friday so I took the opportunity to cleco most of the completed parts on to my Piet for a photo shoot - spend a few minutes contemplating the progress so far. The wheels are the correct diameter plywood until the real ones are spoke-laced and the cabaine struts are just mock-ups. I will be working on the center section and real cabaine struts next. Hope all of you are enjoying the coming of Spring... Enjoying the journey...... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421693#421693 Attachments: http://forums.matronics.com//files/sunny_3a_322.jpg http://forums.matronics.com//files/sunny_1_153.jpg http://forums.matronics.com//files/sunny_2_181.jpg ________________________________________________________________________________
Subject: Re: It's starting to look like.... well, an airplane...!!
Date: Apr 07, 2014
Jake: wait. You're going with a radial on your Piet? Why wasn't I told?!! That is awesome!! It is looking way, way cool! Beautiful work, and I do envy you the round engine. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421702#421702 ________________________________________________________________________________
Date: Apr 07, 2014
Awww, man... I just noticed that you have the external elevator bellcranks and cables, also a la Navratil. Really nice for the old-timey look. Beautiful! -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421703#421703 ________________________________________________________________________________
Date: Apr 07, 2014
Yes, Dick and his beautiful plane have been a real inspiration - as have many other on this message board...... thx. -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421711#421711 ________________________________________________________________________________
Date: Apr 07, 2014
Aluminum has been used but as near as I can remember I have not seen the smaller sized used. The most recent one that comes to mind is Chris Rusch who used aluminum but they look to be the larger extrusion. You'll have to ask him to be certain. http://www.westcoastpiet.com/images/Chris%20Rusch/images/image_153.jpg I know there are more out there but I can't think of them right now. Chris -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421719#421719 ________________________________________________________________________________
Date: Apr 07, 2014
I used the Carlson struts and used the leftover from the wing struts for the cabane struts... I've only had a few flights but they look good to me. I have round steel on the forward diagonal struts to the engine mounts Jeff Faith SDF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421720#421720 ________________________________________________________________________________
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Apr 07, 2014
I just received my struts from Carlson and plan to do the same. Pics please Jeff!!! Scott Knowlton Sent from my iPhone > On Apr 7, 2014, at 1:35 PM, "bender" wrote: > > > I used the Carlson struts and used the leftover from the wing struts for the cabane struts... I've only had a few flights but they look good to me. > I have round steel on the forward diagonal struts to the engine mounts > > Jeff Faith > SDF > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421720#421720 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 08, 2014
Beautiful plane, it's certainly an inspiration for me! and I love the seats :-) Nice job Jake! -------- My production of WW1 propellers, trophies and constructions: Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421762#421762 ________________________________________________________________________________
Date: Apr 08, 2014
Thanks... I have not yet glued on the plywood sides - ha! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421772#421772 ________________________________________________________________________________
Subject: UK Piet G-BYFT
Date: Apr 08, 2014
Inquiry for you UK Pieters: I'm trying to get in touch with Glen Everett=2C owner and pilot of Air Camper G-BYFT=2C which is featured here: http://www .pietenpolclub.co.uk/#/g-byft/4546880083. Steel tube fuselage=2C presently flying with a Rotax 912S engine. I'd like to get his email if anyone can help with that. Thanks! Oscar Zuniga Medford=2C OR Air Camper NX41CC "Scout" A75 power ________________________________________________________________________________
Date: Apr 08, 2014
Subject: Re: UK Piet G-BYFT
Try: On Tue, Apr 8, 2014 at 10:34 AM, Oscar Zuniga wrote: > Inquiry for you UK Pieters: I'm trying to get in touch with Glen Everett, > owner and pilot of Air Camper G-BYFT, which is featured here: > http://www.pietenpolclub.co.uk/#/g-byft/4546880083. Steel tube fuselage, > presently flying with a Rotax 912S engine. I'd like to get his email if > anyone can help with that. Thanks! > > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > * > > > * > > ________________________________________________________________________________
Date: Apr 08, 2014
Woops, sorry about that. Try: glen(at)flyingadverts.co.uk On Tue, Apr 8, 2014 at 10:55 AM, Ryan Mueller wrote: > Try: > > > On Tue, Apr 8, 2014 at 10:34 AM, Oscar Zuniga wrote: > >> Inquiry for you UK Pieters: I'm trying to get in touch with Glen Everett, >> owner and pilot of Air Camper G-BYFT, which is featured here: >> http://www.pietenpolclub.co.uk/#/g-byft/4546880083. Steel tube >> fuselage, presently flying with a Rotax 912S engine. I'd like to get his >> email if anyone can help with that. Thanks! >> >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power >> >> >> * >> >> >> * >> >> > ________________________________________________________________________________
Date: Apr 08, 2014
Dan, Your craftsmanship is very nice. However, "with all due respect"/"bless your heart" etc, I would like to say that the red diagonal cabanes pictured in my story below are a lot stronger than the ones in your pictures. Any tube flattened on the end in the style of a 1960s swing set construction, will fail like cooked spaghetti in compression. http://flycorvair.net/2013/12/20/fuel-lines-and-cabanes-part-2/ >From now on, you can call me the "Cabane Curmudgeon." BTW, new fully aerobatic Decathalons use aluminum struts. There are a number of ways that a guy who isn't good at welding can get better results with bolted aluminum parts from Carlson. I will be glad to share notes on this at Brodhead. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421805#421805 ________________________________________________________________________________
Date: Apr 08, 2014
William, Gonna change my struts to something like those shown... what does the other end look like? Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421806#421806 ________________________________________________________________________________
Date: Apr 09, 2014
I need you guys to pay attention .. look past the passengers.. Aluminum cabanes ..and flying struts Jeff Faith Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421815#421815 Attachments: http://forums.matronics.com//files/almost_173.jpg http://forums.matronics.com//files/candjpiet_144.jpg ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Apr 09, 2014
What airplane... [Wink] -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421816#421816 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Apr 09, 2014
Ah yes, I remember the photo of the naked women in your Pietenpol. I keep hoping you'll bring them to Brodhead (and there's not much room for extra clothing in a Piet). Just kidding. The struts look good, Jeff. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bender Sent: Wednesday, April 09, 2014 8:52 AM Subject: Pietenpol-List: Re: aluminum cabanes I need you guys to pay attention .. look past the passengers.. Aluminum cabanes ..and flying struts Jeff Faith Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421815#421815 Attachments: http://forums.matronics.com//files/almost_173.jpg http://forums.matronics.com//files/candjpiet_144.jpg ________________________________________________________________________________
Date: Apr 09, 2014
Tools, The EAA book, "The art of welding" has many pages in the back that show do's and don'ts of welded joints with a particular look at the ends of struts and cabanes. I looked on the EAA site, and they have the updated version of the book, but I am not sure it still has the pages in question. If you go to the Steen aero labs site: https://secure.steenaero.com/Store/site/department.cfm?id=B67D0A06-102E-BB20-1620EBE739624319 They have a picture of the book cover of the 1991 edition, which has the drawings. My 1987 version has a green cover with king Paul welding on it. Other than the cover, I am pretty sure the contents are the same. Cheryl, a friend of Grace's runs Steen and is very helpful, you can call and ask about any book. While shopping, consider a "Skyranch engineering Manual" fantastic book on engines. PS: Jeff Faith, you are my hero of the day, I admire your "stripped down" approach to aircraft construction. Please consider giving a forum on this at Oshkosh. It would be welcomed by those of us who find Pappy Boyington a better role model than Rod Marchado. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421820#421820 ________________________________________________________________________________
Date: Apr 09, 2014
I used Carlson on both as well..... -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421832#421832 Attachments: http://forums.matronics.com//files/img_3479_152.jpg ________________________________________________________________________________
Date: Apr 09, 2014
Subject: windshields
I am preparing to make and mount my windscreens. I am going simple. 4 attachment points for a curved windshield. Am I crazy? (let me rephrase that) Do my eyes decieve me? Do I see a lot of Ford powered Pietenpols with no windscreens? I am guessing that the radiator funcitions as a wind block of sorts. -- Blue Skies, Steve D ________________________________________________________________________________
Date: Apr 09, 2014
Beautiful Piet Chris............ Brian SLC-UT -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Chris Rusch Sent: Wednesday, April 09, 2014 12:58 PM Subject: Pietenpol-List: Re: aluminum cabanes --> I used Carlson on both as well..... -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421832#421832 Attachments: http://forums.matronics.com//files/img_3479_152.jpg ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Date: Apr 09, 2014
Steve-I used three 1/8" thick aluminum brackets to secure my windshield. I had to T-88 epoxy (scuff sanded both surfaces) a doubler underneath the aluminum (2024 T-3 0.024") to stiff en the area since I elected to use Lexan which has to be held in place and has some spring-back force. If y ou're using Plexiglas and are forming it or bending it to look like a 3-pce that won't apply to you. Mike C. Ohio [cid:image001.jpg(at)01CF5407.CA7DA590] [cid:image002.png(at)01CF5407.CA7DA590 ] [cid:image003.jpg(at)01CF5407.CA7DA590] ________________________________________________________________________________
Subject: It is possible a AirCamper with a MTOW = 450 kg (992 lb)
Date: Apr 09, 2014
Greetings to all and thanks for the great job done on this forum. I am a wooden boat buldier from Catalonia (Europe). For a long time agou I am a great lover of Pietempols. I want to build a AirCamper ULM with European regulations specifying a maximum take-off mass of 450 kg - 992 lbs. You think this is possible? What is the minimum empty weight can be achieved with a lightweight construction? What advice can you offer me? Furthermore I would like to know which is the empty weight of the Sky Scout? Thank you very much Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421837#421837 ________________________________________________________________________________
Subject: Question to UK Cont. eng builders
Date: Apr 09, 2014
Here is a question to friends across the pond: I have a UK builder interested in rebuilding a Corvair to install in a non-piet homebuilt. He is planning on building a cost is no object engine, although we have 73 planes of his model already flying in the US in the last 10 years with far more modest Corvairs, and they have a track record good enough to qualify for the lowest insurance rate offered by Falcon ins. The UK builder has been told by almighty 'lord Donaldson' that every single nut and bolt must arbitrarily be replaced, including the head studs, although we have specs for testing the head studs, and we have never had one fail in the air, and if it did it would not cause a substantial power loss. I was just wondering if builders using 50 year old Continentals in the UK are also required to replace every stud in their engine? ----------------------------------------------- Just to show I am not without respect for UK aviation, a link to an old story from my website: http://flycorvair.net/2014/02/13/10-elements-of-uk-aviation-to-admire/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421842#421842 ________________________________________________________________________________
Date: Apr 09, 2014
Sounds like Lord Donaldson needs to be arbitrarily replaced. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of William Wynne Sent: Wednesday, April 09, 2014 4:29 PM Subject: Pietenpol-List: Question to UK Cont. eng builders Here is a question to friends across the pond: I have a UK builder interested in rebuilding a Corvair to install in a non-piet homebuilt. He is planning on building a cost is no object engine, although we have 73 planes of his model already flying in the US in the last 10 years with far more modest Corvairs, and they have a track record good enough to qualify for the lowest insurance rate offered by Falcon ins. The UK builder has been told by almighty 'lord Donaldson' that every single nut and bolt must arbitrarily be replaced, including the head studs, although we have specs for testing the head studs, and we have never had one fail in the air, and if it did it would not cause a substantial power loss. I was just wondering if builders using 50 year old Continentals in the UK are also required to replace every stud in their engine? ----------------------------------------------- Just to show I am not without respect for UK aviation, a link to an old story from my website: http://flycorvair.net/2014/02/13/10-elements-of-uk-aviation-to-admire/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421842#421842 ________________________________________________________________________________
lb)
Date: Apr 09, 2014
Hi Nauus, Like most questions in aviation, the answer to your question is "It depends." The maxiumum takeoff weight of the airplane varies by what you put in it - how much fuel, and how heavy is the pilot and other payload. Are you planning this as a single seat or two seat airplane? If using it as a single seater, my own Pietenpol could qualify even though mine is fairly heavy (338 kg or 745 lbs). Adding my 86 kg (190 lbs) would still leave you 26 kg (57 lbs) of fuel, which would be 9.55 gallons or 36.15 liters, enough for a little over 2 hours of flying with a Continental 65 hp engine What engine are you considering using? If using a Continental A65, there are many Pietenpols that have been built with an empty weight of 650 lbs (295 kg) or less. Corvair powered Pietenpols seem to tend slightly heavier. Model A Ford Pietenpols tend to be lighter than 650 lbs, probably because their builders know they don't have a lot of power to waste. So let's say you are building a two seat Pietenpol, with an empty weight of 295 kg. That leaves you with 155 kg for people and fuel. Assuming you need at least an hour's worth of fuel on board, which will be somewhere around 14 kg of fuel, you and your passenger cannot total more than 141 kg. Assuming you weigh about 75 kg (165 lbs), that means your passenger cannot weigh more than 66 kg (145 lbs). This is not a bad solution - it measn that you will be limited to carrying lightweight passengers, which tends to include pretty young women and children. You won't have to give rides to fat old men ("Sorry, I'd love to take you up old chap, but the law forbids it.") If on the other hand you weigh 141 kg by yourself, then I'd say you should look at another design. Good luck! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of nauus Sent: Wednesday, April 09, 2014 3:48 PM Subject: Pietenpol-List: It is possible a AirCamper with a MTOW = 450 kg (992 lb) Greetings to all and thanks for the great job done on this forum. I am a wooden boat buldier from Catalonia (Europe). For a long time agou I am a great lover of Pietempols. I want to build a AirCamper ULM with European regulations specifying a maximum take-off mass of 450 kg - 992 lbs. You think this is possible? What is the minimum empty weight can be achieved with a lightweight construction? What advice can you offer me? Furthermore I would like to know which is the empty weight of the Sky Scout? Thank you very much Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421837#421837 ________________________________________________________________________________
Subject: Re: Question to UK Cont. eng builders
Date: Apr 09, 2014
Jack, Our procedure for testing the Corvair's head studs is to subject the to a specific heavy tension load of 4,000 pounds while measuring the stretch in thousands of an inch to make sure the stud is within it's elastic limits. (The apparatus for doing this is small, about as big as a carton of cigarettes.) To be fair, Lord Donaldson shouldn't be replaced arbitrally, he should be tested. My understanding of English history is that they had a device in the tower of London called the rack, which was used by their governmental authorities of the day to tension test humans to see if they reached their elastic limit at a few thousand pounds. Good enough for bolts, good enough for bureaucrats. ---------------------------- Just Kidding! ...... If any UK builders would like to send a private note, my email is WilliamTCA(at)aol.com. Information will be held confidential, even if I am drawn and quartered. PS, 50% of my DNA was in the UK until 1868. I tease knowing I am making fun of half of myself. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421848#421848 ________________________________________________________________________________
Subject: Re: windshields
Date: Apr 09, 2014
Steve; yes, you are crazy. Well, let me rephrase that: no, your eyes don't deceive you. I have seen photos of older Piets with no windscreens, or with one only on the rear cockpit. I wouldn't leave home without mine! I just made replacements for my curved windscreens, which actually have 5 mounting points each. I cut them both out of a single 24"x24" piece of 3/32" acrylic sheet from Lowe's Aircraft Supply & Lumber. The ones that they replaced were 1/8" thick and a good deal more work to spring into a curved shape than these... but I have not flown with these yet. They don't seem like they will deflect significantly in the airstream as compared with the 1/8" thick ones. I cut them out using an abrasive cutting wheel on a Dremel, smoothed off the edges with a file and sandpaper (and belt sander where it really needed hogging). Holes were drilled with a 3/16" "Plexiglas bit" that I got from Aircraft Spruce, then gently opened up to 7/32" with a step drill bit that came from Harbor Freight Aero Supply. My mounting hardware consists of short AN3 bolts with nylock nuts, and I used thin nylon washers under the bolt head and metal washer and left the nuts just loose enough to permit some movement between the metal and acrylic. The bolts have smooth unthreaded shanks on the part that passes through the acrylic. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421849#421849 ________________________________________________________________________________
Date: Apr 09, 2014
I made mine from 1/8" acrylic and mounted them with 4 aluminum tabs similar to Oscar's method. except I did heat mold mine. I made a bowed plywood frame hat would fit in the oven and laid the rough shaped plexi on it and brought the temp up till it would relax. actually helped it lay down a little with my hands.and shut it off and let it cool down. I will say the clarity isn't as good as I had hoped. there is some distortion. but then I spend more time looking out the side while flying than straight thru the shield anyway.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421850#421850 ________________________________________________________________________________
Date: Apr 09, 2014
Wow Chris beautiful! Love those pipes! Dan Helsper Puryear, TN -----Original Message----- From: Chris Rusch <rmdinfo(at)rmdbenders.com> Sent: Wed, Apr 9, 2014 1:59 pm Subject: Pietenpol-List: Re: aluminum cabanes > I used Carlson on both as well..... -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421832#421832 Attachments: http://forums.matronics.com//files/img_3479_152.jpg ________________________________________________________________________________
Date: Apr 09, 2014
Gotta nice look, Chris! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Chris Rusch Sent: Wednesday, April 09, 2014 11:58 AM Subject: Pietenpol-List: Re: aluminum cabanes --> I used Carlson on both as well..... -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421832#421832 Attachments: http://forums.matronics.com//files/img_3479_152.jpg ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: Piet Date
Date: Apr 09, 2014
Marci and I had our first real Piet adventure together today. I took her on Piet date. She's taken lots of short hops, but this was her first actual trip; 50 minutes each way. Had a nice weather day so we took the afternoon off and flew up to Red Stewart Airfield in Waynesville, OH. It was cold and bumpy on the way up but she was a good sport. The wonderful people at Red Stewart (40 I the letter "I") lent us their car so we could drive into town and have lunch. Had a superterrific lunch then strolled around town checking out the antique stores. Marci found a great quilting shop and stocked up on some fabric. We dawdled because I was watching my home field's weather (asphalt.) and hoping the forecast was right and the crosswind would die away at sundown. Sure enough, it did. The flight home was a gorgeous sunset flight with RE-PIET feeling like she was on rails the whole way home. It wasn't anything huge, but it was our first adventure together and I'm really happy my wife had a great time. Keep building, it's worth it! Douwe ________________________________________________________________________________
Subject: Piet Date
Date: Apr 09, 2014
Great, Douwe! Thanks for sharing. Now bring Marci in Re-Piet over here to Smith Mountain Lake and spend a night or two with us. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Wednesday, April 09, 2014 9:01 PM Subject: Pietenpol-List: Piet Date Marci and I had our first real Piet adventure together today. I took her on Piet date. She's taken lots of short hops, but this was her first actual trip; 50 minutes each way. Had a nice weather day so we took the afternoon off and flew up to Red Stewart Airfield in Waynesville, OH. It was cold and bumpy on the way up but she was a good sport. The wonderful people at Red Stewart (40 I the letter "I") lent us their car so we could drive into town and have lunch. Had a superterrific lunch then strolled around town checking out the antique stores. Marci found a great quilting shop and stocked up on some fabric. We dawdled because I was watching my home field's weather (asphalt.) and hoping the forecast was right and the crosswind would die away at sundown. Sure enough, it did. The flight home was a gorgeous sunset flight with RE-PIET feeling like she was on rails the whole way home. It wasn't anything huge, but it was our first adventure together and I'm really happy my wife had a great time. Keep building, it's worth it! Douwe ________________________________________________________________________________
Subject: Re: Piet Date
Date: Apr 09, 2014
Very Nice! This forum needs a "LIKE" Button. :) Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421856#421856 ________________________________________________________________________________
Date: Apr 09, 2014
Hi What do you men it wasn't anything huge! You and your wife were able to s pend a memorable afternoon together. It even was centered around flying. W hat could be finer than that?! HUGE! Glen Sent from my iPhone > On Apr 9, 2014, at 6:18 PM, "Jack Phillips" wro te: > > Great, Douwe! Thanks for sharing. Now bring Marci in Re-Piet over here t o Smith Mountain Lake and spend a night or two with us. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Douwe Blumberg > Sent: Wednesday, April 09, 2014 9:01 PM > To: pietenpolgroup > Subject: Pietenpol-List: Piet Date > > Marci and I had our first real Piet adventure together today. I took her o n Piet date. She=99s taken lots of short hops, but this was her first actual trip; 50 minutes each way. > > Had a nice weather day so we took the afternoon off and flew up to Red Ste wart Airfield in Waynesville, OH. It was cold and bumpy on the way up but s he was a good sport. The wonderful people at Red Stewart (40 I the letter =9CI=9D) lent us their car so we could drive into town and have lun ch. Had a superterrific lunch then strolled around town checking out the an tique stores. Marci found a great quilting shop and stocked up on some fabr ic. We dawdled because I was watching my home field=99s weather (asph alt) and hoping the forecast was right and the crosswind would die a way at sundown. Sure enough, it did. The flight home was a gorgeous sunset flight with RE-PIET feeling like she was on rails the whole way home. > > It wasn=99t anything huge, but it was our first adventure together a nd I=99m really happy my wife had a great time. > > Keep building, it=99s worth it! > > Douwe > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Piet Date
Date: Apr 09, 2014
Very nice, Douwe!! Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Wednesday, April 09, 2014 6:01 PM Subject: Pietenpol-List: Piet Date Marci and I had our first real Piet adventure together today. I took her on Piet date. She's taken lots of short hops, but this was her first actual trip; 50 minutes each way. Had a nice weather day so we took the afternoon off and flew up to Red Stewart Airfield in Waynesville, OH. It was cold and bumpy on the way up but she was a good sport. The wonderful people at Red Stewart (40 I the letter "I") lent us their car so we could drive into town and have lunch. Had a superterrific lunch then strolled around town checking out the antique stores. Marci found a great quilting shop and stocked up on some fabric. We dawdled because I was watching my home field's weather (asphalt.) and hoping the forecast was right and the crosswind would die away at sundown. Sure enough, it did. The flight home was a gorgeous sunset flight with RE-PIET feeling like she was on rails the whole way home. It wasn't anything huge, but it was our first adventure together and I'm really happy my wife had a great time. Keep building, it's worth it! Douwe ________________________________________________________________________________
Date: Apr 09, 2014
My windshield broke and I flew without it for some time. If wearing goggles, it really wasn't a big deal. Originally, the back seat had a really nice big windshield, didn't like the look of it the best, but it was REALLY comfortable behind it, not requiring goggles for most flying. The Piet equivalent of being behind the windscreen of a big old Honda Goldwing or something! I put the original shaped one back on it. Looks a little better I think, need goggles, but not as good a ones as with without. So, it's really a question of how do you want to fly. No eyewear, snug sunglasses type of thing, or full on RAF or ski style goggles. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421859#421859 ________________________________________________________________________________
Date: Apr 09, 2014
Awesome...! Looks like something you need to Re-Piet often....!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421860#421860 ________________________________________________________________________________
Subject: Re: It is possible a AirCamper with a MTOW = 450 kg (992
lb)
Date: Apr 09, 2014
Thanks for the comment Jack. I'm sorry to say this but it seems the Aircamper is not a design for me. I am a burly rugby player of 220 lb (100 kg) and did not think that in the years following diets work better than now. By your words I can deduce that with me only remain 122 lb (55 kg) for passanger and fuel. I know there are ultralight replicas of the SkyScout (Ragwing, Fisher, Texas Parasol ...) but none has for me the charm of a Pietenpol. I love the wood work in Pietempol's, the wooden cabanes and undercarriage, for me are almost like a beautiful woman. Has anyone thought of a ultralight design for two seater Aircamper ? Greetings and thank you very much Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421862#421862 ________________________________________________________________________________
lb)
Date: Apr 10, 2014
Hi, I am building a Pietenpol GN-1 in the Czech Republic (Central Europe) as an ULLa aircraft. Metal construction of fuselage and tail surfaces. Wooden wing, and it will be equipped with an automobile engine (Subaru with a reduction drive?). I haven't even thought it could be heavier than 450kg with me and a passenger? :) I have 68kg with leather B3 jacket :) ...and I don't expect my passenger to be heavier than some 80kg. That is 148kg humans, 20kg fuel, that is 292kg for the aircraft+engine+other liquids. I hope it should not be a problem to achieve :D -------- My production of WW1 propellers, trophies and constructions: Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421864#421864 ________________________________________________________________________________
Date: Apr 10, 2014
Great shot Chris, as you know I love the paint scheme! How is you testing going? Sent from my iPad Jack Textor > On Apr 9, 2014, at 1:58 PM, "Chris Rusch" wrote: > > > I used Carlson on both as well..... > > -------- > NX321LR > Now test flying!! > Mitsubishi Powered > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421832#421832 > > > > > Attachments: > > http://forums.matronics.com//files/img_3479_152.jpg > > > > > > > ________________________________________________________________________________
Date: Apr 10, 2014
Thanks for the nice comments guys! We had the worst winter in 30 yrs up here, so the pietenpol has been out of my mind for months.....went to the hanger and looked her over last night and she survived the winter! Now im getting the bug again, so testing will resume very soon. I did attempt making a different prop over the winter on my fancy CNC stuff and made scrap out of the first attempt, but now i know what we did wrong, so once I get some more boards glued up, well give her another try. I will keep posting on the list with my test results. PS to fill the void not having a pietenpol to work on every day, i built this motorcycle.......almost done !! -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421871#421871 Attachments: http://forums.matronics.com//files/img_1115_107.jpg ________________________________________________________________________________
lb)
Date: Apr 10, 2014
Who knows WHAT I'm gonna hear for saying this... but do you need LSA or unltralight? There's a experimental balled a Bakeng Deuce. I think it's a really eye pleasing design. Made for 125 to 150hp I think and quite a bit larger cockpits. It's typical cloth covered steel fuse and wood wing, but you could easily put jenny gear on, wood struts, change the shape of rudders and stabs to give it a more Piet like appearance and feel. I'm not a huge fan of changing designs... but if it suits your needs, might be worth considering! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421872#421872 ________________________________________________________________________________
Date: Apr 10, 2014
That is one nice aeroplane. Keith On 10/04/2014 02:00, Douwe Blumberg wrote: > > Marci and I had our first real Piet adventure together today. I took > her on Piet date. She's taken lots of short hops, but this was her > first actual trip; 50 minutes each way. > > Had a nice weather day so we took the afternoon off and flew up to Red > Stewart Airfield in Waynesville, OH. It was cold and bumpy on the way > up but she was a good sport. The wonderful people at Red Stewart (40 > I the letter "I") lent us their car so we could drive into town and > have lunch. Had a superterrific lunch then strolled around town > checking out the antique stores. Marci found a great quilting shop > and stocked up on some fabric. We dawdled because I was watching my > home field's weather (asphalt...) and hoping the forecast was right > and the crosswind would die away at sundown. Sure enough, it did. > The flight home was a gorgeous sunset flight with RE-PIET feeling like > she was on rails the whole way home. > > It wasn't anything huge, but it was our first adventure together and > I'm really happy my wife had a great time. > > Keep building, it's worth it! > > Douwe > ________________________________________________________________________________
Date: Apr 10, 2014
William, I'm very disappointed in you. Instead of your usual highly technical commentary and eye for detail, you went for the decoys that Jeff threw out there. You didn't even notice the rigid aluminum fuel tubing that he's got running down those aluminum cabanes, past the stripped-down airframes in the cockpits. For shame. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421890#421890 ________________________________________________________________________________
Date: Apr 10, 2014
Be nice Oscar maybe he was tired from SunNFun. Keiko Sent from my iPhone > On Apr 10, 2014, at 2:05 PM, "taildrags" wrote: > > > William, I'm very disappointed in you. Instead of your usual highly technical commentary and eye for detail, you went for the decoys that Jeff threw out there. You didn't even notice the rigid aluminum fuel tubing that he's got running down those aluminum cabanes, past the stripped-down airframes in the cockpits. For shame. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421890#421890 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 10, 2014
How tall is right for the windscreen? The one old one I have seems awfully short. I like the general shape. Laid flat the bottom edge is straight and it stiffens up when curved. When placed with the old holes it is even with my eyes in the tail down attitude and with my nose in the tail up. It is about 7 inches in front of my nose. I can look over it easily. I have looked at Photos online and they are all over the place. Some tall, some short. I have looked at motorcycles and they are all farther away from the face and most newer ones seem slightly below the eyes. Blue Skies, Steve D On Wed, Apr 9, 2014 at 4:36 PM, taildrags wrote: > > Steve; yes, you are crazy. Well, let me rephrase that: no, your eyes > don't deceive you. I have seen photos of older Piets with no windscreens, > or with one only on the rear cockpit. I wouldn't leave home without mine! > > I just made replacements for my curved windscreens, which actually have 5 > mounting points each. I cut them both out of a single 24"x24" piece of > 3/32" acrylic sheet from Lowe's Aircraft Supply & Lumber. The ones that > they replaced were 1/8" thick and a good deal more work to spring into a > curved shape than these... but I have not flown with these yet. They don't > seem like they will deflect significantly in the airstream as compared with > the 1/8" thick ones. > > I cut them out using an abrasive cutting wheel on a Dremel, smoothed off > the edges with a file and sandpaper (and belt sander where it really needed > hogging). Holes were drilled with a 3/16" "Plexiglas bit" that I got from > Aircraft Spruce, then gently opened up to 7/32" with a step drill bit that > came from Harbor Freight Aero Supply. My mounting hardware consists of > short AN3 bolts with nylock nuts, and I used thin nylon washers under the > bolt head and metal washer and left the nuts just loose enough to permit > some movement between the metal and acrylic. The bolts have smooth > unthreaded shanks on the part that passes through the acrylic. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421849#421849 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Apr 10, 2014
kg (992 lb)
You must mean the European version of ultralight AKA microlight. The US version is tiny. If you are looking at single seat just make a Piet and don't use the front cockpit. For the list. If he were to step up in size but wanted to stay in something similar to a Piet what would you do? Blue Skies, Steve D. > > ________________________________________________________________________________
Date: Apr 10, 2014
Subject: OT if you are looking for a place to go, y'all come visit
San Antonio, IT'S FIESTA
San Antonio is beginning Fiesta. If you are looking for a destination there is a lot going on from April 10-27. It is San Antonio's celebration for San Antonio. www.fiesta-sa.org We have our favorite events. My boys love the rugby tournament. My wife and I enjoy the Zydeco music at a taste of New Orleans, 5 big parades, mariachi concerts, too much to mention. Y'all come visit. -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: OT if you are looking for a place to go, y'all come
visit San Antonio, IT'S FIESTA
Date: Apr 10, 2014
Steve Thanks for the invite . Beautiful city y'all have there. Love River Walk any place that has a river in it needs to take lessons from San Antonio. E verything I saw while visiting there ten years back for son's Air Force basi c training graduation makes me want to go back. Maybe next year Glen Sent from my iPhone > On Apr 10, 2014, at 6:56 PM, Steven Dortch wro te: > > San Antonio is beginning Fiesta. If you are looking for a destination ther e > is a lot going on from April 10-27. It is San Antonio's celebration for Sa n > Antonio. > > www.fiesta-sa.org > > We have our favorite events. My boys love the rugby tournament. My wife an d > I enjoy the Zydeco music at a taste of New Orleans, 5 big parades, mariach i > concerts, too much to mention. > > Y'all come visit. > > -- > Blue Skies, > Steve D > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: windscreen height
Date: Apr 11, 2014
You're right, windscreen heights vary widely and again, there's no right or wrong, it's what works for you. However, IF you don't like the top of your head buffeted by wind all the time, make it an inch taller than mine! Since it's only seven inches away, I'd say even with the top of your head. $.02 Douwe ________________________________________________________________________________
Subject: Vi Kapler hinges
Date: Apr 11, 2014
Hello=2C low 'n' slow flyers- I have a bit of news regarding the aluminum hinges that Vi Kapler used to o ffer for the tail surfaces. Mr. Pietenpol developed the hinges as an impro vement on the bent-and-welded steel ones that are shown in the 1932 plans =2C and he then had Vi Kapler make patterns to have them cast and machined. Vi got out of the business a few years ago=2C but I have spoken with him and have obtained the rights to the cast hinges. I hope to have these hing es available again soon=2C through my little business called "Rogue Air Par ts". I don't remember what Vi was selling them for but if someone will let me know=2C I'll see what the foundry and machining is going to cost and se e if we can hold the price to the same as Vi was asking. I believe the tai l control surfaces require a total of 9 pairs of hinges=2C or three per sur face. Happy Friday! Oscar Zuniga Medford=2C OR Air Camper NX41CC "Scout" A75 power ________________________________________________________________________________
Subject: Re: Vi Kapler hinges
Date: Apr 11, 2014
I purchased my set from Vi in 2005 for forty bucks. Great deal and great hin ges. Glad you have taken the job over Oscar! Now how about those data-plates? Scott K. Burlington Ontario. Sent from my iPhone > On Apr 11, 2014, at 11:55 AM, "Oscar Zuniga" wrote : > > Hello, low 'n' slow flyers- > > I have a bit of news regarding the aluminum hinges that Vi Kapler used to o ffer for the tail surfaces. Mr. Pietenpol developed the hinges as an improv ement on the bent-and-welded steel ones that are shown in the 1932 plans, an d he then had Vi Kapler make patterns to have them cast and machined. Vi go t out of the business a few years ago, but I have spoken with him and have o btained the rights to the cast hinges. I hope to have these hinges availabl e again soon, through my little business called "Rogue Air Parts". I don't r emember what Vi was selling them for but if someone will let me know, I'll s ee what the foundry and machining is going to cost and see if we can hold th e price to the same as Vi was asking. I believe the tail control surfaces r equire a total of 9 pairs of hinges, or three per surface. > > Happy Friday! > > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Apr 11, 2014
The data plates are still available. Info is at http://www.flysquirrel.net/piets/dataplate.html -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421918#421918 ________________________________________________________________________________
Subject: Re: windscreen height
Date: Apr 11, 2014
Mine works fine for me. No buffeting. But I guess it all depends on how tal l you are. (Some have called me a munchkin in the past). Dan Helsper Puryear, TN -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Fri, Apr 11, 2014 7:46 am Subject: Pietenpol-List: windscreen height You=99re right, windscreen heights vary widely andagain, there =99s no right or wrong, it=99s what works for you. However, IF you don=99t like the top of your headbuffeted by wind all the time, make it an inch taller than mine! Since it=99s only seven inches away, I=99d say evenwith the top of your head. $.02 Douwe ________________________________________________________________________________
Date: Apr 11, 2014
From: "Robert S. Edson" <robertse(at)centurytel.net>
Subject: hinges
we purchased our hinges at Brodhead in 2010 for $70.00 and considered it a bargain. Getting ready to pull the piet out of the hanger and get it ready for the season. Bob -- Robert S. Edson ________________________________________________________________________________
Date: Apr 11, 2014
Oscar, I paid Vi 35 bucks for my hinges a while back. Don Harper used to make them also. Cheers, Gardiner Sent from my iPad > On Apr 11, 2014, at 11:51 AM, Oscar Zuniga wrote: > > don't ________________________________________________________________________________
Date: Apr 11, 2014
Subject: Swiss Muffler
Today I finished fabricating and installing a Swiss Muffler on my Piet. Unbelievably quiet. Cheers, Ken p.s. I'll update once the engine is running. ________________________________________________________________________________
Date: Apr 11, 2014
Oscar mine were $60, and I did quite a bit of polishing... Sent from my iPhone On Apr 11, 2014, at 10:51 AM, Oscar Zuniga wrote: > Hello, low 'n' slow flyers- > > I have a bit of news regarding the aluminum hinges that Vi Kapler used to o ffer for the tail surfaces. Mr. Pietenpol developed the hinges as an improv ement on the bent-and-welded steel ones that are shown in the 1932 plans, an d he then had Vi Kapler make patterns to have them cast and machined. Vi go t out of the business a few years ago, but I have spoken with him and have o btained the rights to the cast hinges. I hope to have these hinges availabl e again soon, through my little business called "Rogue Air Parts". I don't r emember what Vi was selling them for but if someone will let me know, I'll s ee what the foundry and machining is going to cost and see if we can hold th e price to the same as Vi was asking. I believe the tail control surfaces r equire a total of 9 pairs of hinges, or three per surface. > > Happy Friday! > > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Date: Apr 12, 2014
You and Douwe seem to sit a lot lower in your Piets than I do. Did you buil d specifically to sit lower? =97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97 =97=97=97=97 Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine Sent from an iPad with a spelling problem On Apr 11, 2014, at 2:11 PM, "danhelsper(at)aol.com " > wrote: Mine works fine for me. No buffeting. But I guess it all depends on how tal l you are. (Some have called me a munchkin in the past). Dan Helsper Puryear, TN -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net<mailto:douweblumberg@eart hlink.net>> onics.com>> Sent: Fri, Apr 11, 2014 7:46 am Subject: Pietenpol-List: windscreen height You=92re right, windscreen heights vary widely and again, there=92s no righ t or wrong, it=92s what works for you. However, IF you don=92t like the top of your head buffeted by wind all the time, make it an inch taller than mine! Since it=92s only seven inches away, I=92d say even with the top of your he ad. $.02 Douwe ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Subject: Re: Swiss Muffler
Date: Apr 12, 2014
Very cool Ken. Those earplugs can get annoying. Can't wait to (not) hear it . Dan Helsper Puryear, TN -----Original Message----- From: Ken Bickers <bickers.ken(at)gmail.com> Sent: Fri, Apr 11, 2014 7:22 pm Subject: Pietenpol-List: Swiss Muffler Today I finished fabricating and installing a Swiss Muffler on my Piet. Un believably quiet. Cheers, Ken p.s. I'll update once the engine is running. ________________________________________________________________________________
Date: Apr 12, 2014
Jeff, No. I built to plans....but it may have something to do with my size. Dan Helsper Puryear, TN -----Original Message----- From: Boatright, Jeffrey <jeffboatright(at)emory.edu> Sent: Sat, Apr 12, 2014 3:41 am Subject: Re: Pietenpol-List: windscreen height You and Douwe seem to sit a lot lower in your Piets than I do. Did you buil d specifically to sit lower? =94=94=94=94=94=94=94=94 =94=94=94=94=94=94=94=94 =94=94=94=94=94=94=94=94=94 =94=94=94=94 Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine Sent from an iPad with a spelling problem On Apr 11, 2014, at 2:11 PM, "danhelsper(at)aol.com" wrot e: Mine works fine for me. No buffeting. But I guess it all depends on how tal l you are. (Some have called me a munchkin in the past). Dan Helsper Puryear, TN -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Fri, Apr 11, 2014 7:46 am Subject: Pietenpol-List: windscreen height You=99re right, windscreen heights vary widely and again, there =99s no right or wrong, it=99s what works for you. However, IF you don=99t like the top of your head buffeted by wind al l the time, make it an inch taller than mine! Since it=99s only seven inches away, I=99d say even with the to p of your head. $.02 Douwe This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Apr 12, 2014
I'm only 5'6", but long torso, so maybe that's the difference. Sent from an iPhone with a spelling problem On Apr 12, 2014, at 1:32 PM, "danhelsper(at)aol.com " > wrote: Jeff, No. I built to plans....but it may have something to do with my size. Dan Helsper Puryear, TN -----Original Message----- From: Boatright, Jeffrey <jeffboatright(at)emory.edu<mailto:jeffboatright@emor y.edu>> etenpol-list(at)matronics.com> Sent: Sat, Apr 12, 2014 3:41 am Subject: Re: Pietenpol-List: windscreen height You and Douwe seem to sit a lot lower in your Piets than I do. Did you buil d specifically to sit lower? =97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97 =97=97=97=97 Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine Sent from an iPad with a spelling problem On Apr 11, 2014, at 2:11 PM, "danhelsper(at)aol.com " > wrote: Mine works fine for me. No buffeting. But I guess it all depends on how tal l you are. (Some have called me a munchkin in the past). Dan Helsper Puryear, TN -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net<mailto:douweblumberg@eart hlink.net>> onics.com>> Sent: Fri, Apr 11, 2014 7:46 am Subject: Pietenpol-List: windscreen height You=92re right, windscreen heights vary widely and again, there=92s no righ t or wrong, it=92s what works for you. However, IF you don=92t like the top of your head buffeted by wind all the time, make it an inch taller than mine! Since it=92s only seven inches away, I=92d say even with the top of your he ad. $.02 Douwe ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 12, 2014
Ah, Ken... you jokester, you! -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421936#421936 ________________________________________________________________________________
Date: Apr 12, 2014
Are you really setting up or are you laying down? Just joking. I have looked at your photos and sat in my plane. The rear deck hits me between the shoulder blades. The cockpit feels much smaller than y'all's looks. I am 5'7.5" and about 193lbs. My front cockpit feels much larger. The instrument panel is at least 6 inches further from me in the front. I am going to make mine several inches taller and incline it up some. At the angle it currently sits, I will hit the bridge of my nose on the edge of the windshield in case of an impact. Changing the angle should help. Blue Skies, Steve D On Sat, Apr 12, 2014 at 7:34 AM, Boatright, Jeffrey wrote: > I'm only 5'6", but long torso, so maybe that's the difference. > > Sent from an iPhone with a spelling problem > > On Apr 12, 2014, at 1:32 PM, "danhelsper(at)aol.com" > wrote: > > Jeff, > > No. I built to plans....but it may have something to do with my size. > > Dan Helsper > Puryear, TN > > > -----Original Message----- > From: Boatright, Jeffrey <jeffboatright(at)emory.edu> > To: > Sent: Sat, Apr 12, 2014 3:41 am > Subject: Re: Pietenpol-List: windscreen height > > You and Douwe seem to sit a lot lower in your Piets than I do. Did you > build specifically to sit lower? > > ---------------------------------------------------------- > Jeffrey H. Boatright, PhD, FARVO > Associate Professor of Ophthalmology > Emory University School of Medicine > Sent from an iPad with a spelling problem > > On Apr 11, 2014, at 2:11 PM, "danhelsper(at)aol.com" > wrote: > > Mine works fine for me. No buffeting. But I guess it all depends on how > tall you are. (Some have called me a munchkin in the past). > > Dan Helsper > Puryear, TN > > > -----Original Message----- > From: Douwe Blumberg <douweblumberg(at)earthlink.net> > To: pietenpolgroup > Sent: Fri, Apr 11, 2014 7:46 am > Subject: Pietenpol-List: windscreen height > > You're right, windscreen heights vary widely and again, there's no > right or wrong, it's what works for you. > > However, IF you don't like the top of your head buffeted by wind all the > time, make it an inch taller than mine! > > Since it's only seven inches away, I'd say even with the top of your head. > > $.02 > > Douwe > > > > > ------------------------------ > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). > > * > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: 3 Pierre's
Date: Apr 12, 2014
Douwe, Jim Kinsella and Jeff faith in front of RE-PIET at a field outside Lo uisville Sent from my iPhone
Subject: Re: 3 Pierre's
Date: Apr 13, 2014
THE Jim Kinsella!? Douwe, did you talk him into flying his beautiful Piet back to Brodhead this year? Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421950#421950 ________________________________________________________________________________
Subject: seat height
Date: Apr 13, 2014
Hey jeff, I'm 5"9' and pretty "standard" (1930's American standard) build. I actually did drop the seat down a bit by making an oval cutout and forming a shallow fiberglass "bowl" to glue into it. Can't see it with the cushions on, but probably drops me down two inches and doesn't interfere with the controls. Douwe ________________________________________________________________________________
Subject: A great Piet-Venture
Date: Apr 13, 2014
Had a great "Piet-venture" this weekend!! Some friends invited me down to "Thunder over Louisville", one of the largest fireworks displays in the country, preceded by a day full of air show acts. I'm about an hour north and the weather looked nice so I invited a friend to fly RE-PIET down with me. Jim Kinsella got permission for me to fly into the strip where he keeps his beautiful Pietenpol. So we took off early, buzzed my friends barn to let 'em know we had arrived and headed to the airstrip where Jim (and his 1943 Indian motorcycle) and Jeff Faith were there to welcome us. The strip was trickier than I had remembered. 1700', sloping, power lines on one end and trees on the other and the old quandary; "do I land into the wind, over the wires downhill?? Or use the better approach over the trees uphill but with a bit of a tailwind??". Add one maxed out Pietenpol and a not super-high time pilot and you get the picture. Third time's a charm and I got her down pretty well much to my relief. I had never met Jeff before and it was great to see Jim again. Jim built his Piet in the nineties and flew it to Brodhead a few times. It's a very pure, Continental powered lightweight plane. We all know Jeff's beautiful Ford powered plane which he built in some record number of months. Sounds like he has the kinks worked out of the engine and will start flying now that the weather is turning. We're all hoping to arrange some flying together. Tied RE-PIET down in the lee of the hangar and spent the day by the river watching the Blue Angels, the F22 Raptor, and a dozen other acts until the most impressive fireworks show I have ever seen. Winds were predicted to REALLY pickup at my home (asphalt) field as the day went on so we lifted off at 7:30. I was nervous about clearing the trees with my big load and the downhill slope seemed to mess with my angle of attack and delay rotation, BUT I cleared them okay (just okay) and we headed east with a howling tailwind. Averaged 54kts groundspeed on the way down, averaged 109 on the way back. Landed fine and headed off to church!! It was really fun to see the guys, stretch RE-PIET's horizon a bit and push my experience level as well. Douwe ________________________________________________________________________________
Subject: Re: aluminum cabanes
Date: Apr 13, 2014
Beautiful cycle...! Love the airplane wheels - ha! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421953#421953 ________________________________________________________________________________
Date: Apr 13, 2014
Oscar, I understand the purist calling for a cast hinge, but an engineer like yourself with CAD skills may want to consider a different angle: In the last 18 months I have gotten an education in affordable small aircraft part manufacturing by watching Dan Weseman build the "Panther" single seat steel tube/Al. aerobatic aircraft. They have now sold about 30 kits, and are heavily into the manufacturing phase. The kit has dozens of small aluminum parts inside that all come pre machined, drilled and piloted for rivets on several axises. They are all very affordably made by selecting available 6061-T6 extrusions and having CNC routers go after them. The parts are actually less expensive than castings, have a perfect surface finish, and are vastly stronger than castings. Vi's work certainly served countless builders, but you could also offer the design produced differently, a little more updated and completed. for a look at the Panther and how the detail parts are made, click on this link: http://flywithspa.com/panther.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421954#421954 ________________________________________________________________________________
Subject: Re: A great Piet-Venture
Date: Apr 13, 2014
Piet-Ventures are he best! Very cool Douwe! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421955#421955 ________________________________________________________________________________
Date: Apr 13, 2014
William; Thank you for the comment. A personal note is coming to you off-list, but suffice it to say that even though the next generation of tail hinges is already in development, I wanted to make sure that the cast ones were available in the meantime. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421956#421956 ________________________________________________________________________________
Subject: hatch fasteners
Date: Apr 14, 2014
Hey Paul, They are called "common sense fasteners" they are pretty standard in the yacht cover industry. This place carries them http://www.restorationstuff.com/index.html as does snyders ford model a catalog. Come in brass, nickel with a few different base styles. Good luck! Douwe ________________________________________________________________________________
Date: Apr 16, 2014
Subject: Matronics Web Server Down for Repair (PLEASE READ)...
Dear Listers, Late Tuesday night 4/15/2014, the Matronics Web server crashed due to a multi-disk RAID 5 failure. The system has complete data backups, but I will likely have to order some replacement disks to rebuild the system. I'll work as quickly as I can to restore the Matronics Web Server. The Matronics EMAIL server is NOT impacted by this issue. All normal Matronics Email List mail will flow as usual. However, the Matronics Web Forums interface will not be available. Also impacted by the Web Server outage will be the AeroElectric web site. I will try to post daily updates on the Web Server restoration status. I apologize for the inconvenience... :-( Best regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 17, 2014
Subject: Matronics Web Server Repaired and ONLINE! (PLEASE READ)
Dear Listers, The new hard drives for the Matronics web server arrived today, Thursday 4/17/2014 and the RAID5 disk array rebuild went very smoothly. Web server is back online and fully functional! No data or files were lost. Additionally, those that frequent the AeroElectric web site will find that it has been restored as well. Best regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Thank You Matt
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Apr 18, 2014
Matt, It is amazing to me that you can keep this site running so smoothly and make the needed repairs or updates so quickly. I am not a computer guy and couldn't fix one if I had too but give me an internal combustion engine. Well you get the point. Kudos to you and you team if you have one. Thanks again, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422052#422052 ________________________________________________________________________________
Subject: Re: Matronics Web Server Repaired and ONLINE! (PLEASE
READ)
Date: Apr 18, 2014
Matt, Thank you Joe R -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> Sent: Fri, Apr 18, 2014 1:33 am Subject: Pietenpol-List: Matronics Web Server Repaired and ONLINE! (PLEASE READ) Dear Listers, The new hard drives for the Matronics web server arrived today, Thursday 4/17/2014 and the RAID5 disk array rebuild went very smoothly. Matronics Web server is back online and fully functional! No data or files were lost. Additionally, those that frequent the AeroElectric web site will find that it has been restored as well. Best regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Re: Thank You Matt
Date: Apr 18, 2014
Ditto.... THANK YOU Matt...! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422067#422067 ________________________________________________________________________________
Date: Apr 18, 2014
Subject: Clip Art
Does anyone have some pietenpol clip art. I am making a business card. Military tour will be ending and I will be looking for work with the unwashed masses. -- Blue Skies, Steve D ________________________________________________________________________________
Date: Apr 18, 2014
Subject: AOPA meeting in San Marcos
I know some of you don't believe in AOPA so if you want to picket, I will be at the meeting in San Marcos, Texas on 26 APR. (a week from now). -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Has Anyone Else Seen The I Flew My Homebuilt T-shirt?
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Apr 19, 2014
Got an email this morning from EAA advertising their new "I Flew My Homebuilt T-shirt". Looks like a Pietenpol in my little iPhone screen. If so, very cool! Can someone confirm on a big screen? -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422092#422092 ________________________________________________________________________________
Subject: Re: Has Anyone Else Seen The I Flew My Homebuilt T-shirt?
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Apr 19, 2014
It is! Nice shirt. Scott Knowlton Sent from my iPhone > On Apr 19, 2014, at 9:24 AM, "jarheadpilot82" wrote: > > > Got an email this morning from EAA advertising their new "I Flew My Homebuilt T-shirt". Looks like a Pietenpol in my little iPhone screen. If so, very cool! > > Can someone confirm on a big screen? > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > USMC, USMCR, ATP > BVD DVD PDQ BBQ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422092#422092 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 19, 2014
Yep. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Saturday, April 19, 2014 6:21 AM Subject: Pietenpol-List: Has Anyone Else Seen The I Flew My Homebuilt T-shirt? --> Got an email this morning from EAA advertising their new "I Flew My Homebuilt T-shirt". Looks like a Pietenpol in my little iPhone screen. If so, very cool! Can someone confirm on a big screen? -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422092#422092 ________________________________________________________________________________
Date: Apr 19, 2014
Sigh. I may just have to spend some money at the EAA clothing booth this year. I hate when that happens. In fairness, they couldn't have chosen a better historical example of the breed. Could it possibly be that they are getting back to the "learn, build, fly" philosophy instead of forgetting the first step? Nah. It's probably because copyright laws allowed them to use it for free. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422096#422096 ________________________________________________________________________________
Date: Apr 19, 2014
I agree Dave- I was really surprised it didn't Have an RV on it! -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422108#422108 ________________________________________________________________________________
Date: Apr 19, 2014
For Piet sakes! Sure 'nuff Sent from my iPhone > On Apr 19, 2014, at 6:50 AM, "Gary Boothe" wrote: > > > Yep. > > Gary Boothe > NX308MB > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > jarheadpilot82 > Sent: Saturday, April 19, 2014 6:21 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Has Anyone Else Seen The I Flew My Homebuilt > T-shirt? > > --> > > Got an email this morning from EAA advertising their new "I Flew My > Homebuilt T-shirt". Looks like a Pietenpol in my little iPhone screen. If > so, very cool! > > Can someone confirm on a big screen? > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > USMC, USMCR, ATP > BVD DVD PDQ BBQ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422092#422092 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 19, 2014
Well their marketing people could at least have used some for-real Piet ribs for the photo ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422121#422121 ________________________________________________________________________________
Date: Apr 20, 2014
Howdy, low 'n' slow fliers; First, I'd like to wish you all a happy and blessed Easter. Part of mine was spent at the hangar, on a beautiful Sunday afternoon, but it was punctuated by some less-than-pleasant moments as I attempted to replace the front main seal on my engine and I'll pass over that in the spirit of the season. Suffice it to say that the seal and spring have now been removed, cleaned up again, and are back in place on the crankshaft nose waiting for my patience to return before I attempt to press them back into place. Maddening. Rebuild work on the Stromberg carb went much better, and after getting a rebuild gasket set from Aircraft Spruce and cleaning everything up, I just need to set the float level and the carb will be ready to reassemble and put back on the engine so I can resume testing and compression checks. An update on the hinges. I now have the jigs and tooling from Vi and am trying to get an updated cost and delivery date for more of the rough castings for the hinges. It is my intent to produce a final, higher-quality run of the cast aluminum hinges as a legacy to Vi and Mr. Pietenpol. The inventory will be of a limited quantity (probably in stock till I can't find my way out of a darkened room without assistance), but the hinges will be produced from the same castings and using the same jigging as Vi has always used. The difference will be that we will smooth the parts a bit more and have them reflect the longevity that the Air Camper design has itself developed over the years. A bit more refined finish, I guess you could say... in the final production run of these parts. I'm going to try, anyway. In parallel with this, and to bring things into the 21st century, it is my intent to engineer and produce modern parts using the same geometry and design but in a tougher, stronger, more dimensionally stable, lighter, and more durable material. In doing so, I hope to offer the new parts at about the same cost and with the same reliability as before. Vi tells me that the original hinges load-tested at 700 lbs. static, and he sent me a failed pair of hinges that were used for that testing. He has set the bar for my engineering, and I am confident that I can meet or exceed this parameter while still achieving the other goals of better dimensional stability and reduced weight. In any case, picture 2100 lbs of static (or dynamic) force on any of the three tail surfaces of an Air Camper, such that a single pair of hinges would have to sustain 700 lbs of load. It says a lot for the durability of these airplanes, and it especially says a lot about why no one has ever seen the tail surfaces of an Air Camper fly off. If anyone has evidence to the contrary, I'd be very interested to hear it. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422181#422181 ________________________________________________________________________________
Date: Apr 21, 2014
Subject: Mag needed for an A75
Hello Everyone, I'm in need of a decent used mag and a harness for an A75-8. I have a Bendix Scintilla SF4RN-8 that isn't working. The working mag is a Slick 4230, but a 4333 would be great. I haven't had any luck finding one at Wentworth, Barnstormers, nor eBay. If you know of one, please let me know. gbacon67(at)gmail.com Thanks, -- Greg Bacon Prairie Home, MO NX114D(Mountain Piet) ________________________________________________________________________________
Subject: Re: Mag needed for an A75
Date: Apr 21, 2014
Greg; we'll find you one. I've put out some feelers and I'm sure a couple of other Pieters will take a look around their hangars and see what we can find. Meanwhile, is your dead Bendix Scintilla really dead? They are rebuildable. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422228#422228 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Apr 22, 2014
Greg, if you change a Bendix mag for a Slick mag I think you will need a different drive gear, and they ain't cheap. As Oscar said, you might do better to just rebuild the Bendix. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Greg Bacon Sent: Monday, April 21, 2014 11:30 PM Subject: Pietenpol-List: Mag needed for an A75 Hello Everyone, I'm in need of a decent used mag and a harness for an A75-8. I have a Bendix Scintilla SF4RN-8 that isn't working. The working mag is a Slick 4230, but a 4333 would be great. I haven't had any luck finding one at Wentworth, Barnstormers, nor eBay. If you know of one, please let me know. gbacon67(at)gmail.com Thanks, -- Greg Bacon Prairie Home, MO NX114D(Mountain Piet) ________________________________________________________________________________
Date: Apr 22, 2014
Thanks Oscar. I appreciate the help. Yes, I'm pretty sure the BS is rebuildable. All the parts are there and nothing is locked up. There is a fellow in Dallas (Joe) that can rebuild it. He's the only one I've found that can rebuild them. On Mon, Apr 21, 2014 at 11:53 PM, taildrags wrote: > > Greg; we'll find you one. I've put out some feelers and I'm sure a couple > of other Pieters will take a look around their hangars and see what we can > find. Meanwhile, is your dead Bendix Scintilla really dead? They are > rebuildable. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422228#422228 > > -- Greg Bacon Prairie Home, MO NX114D(Mountain Piet) ________________________________________________________________________________
Date: Apr 22, 2014
Hi Jack. Yes, rebuilding the old Bendix Scintilla is not a bad option. Joe's ballpark quote to rebuild it is $600-$700. My mechanic thought that was very high and suggested I search for a good Slick or a newer model Bendix first. He didn't mention the drive gear nor the wiring harness replacement costs. I'm hoping to find a good deal, maybe do some trading. I do have a rebuildable Corvair I'm willing to part with... On Tue, Apr 22, 2014 at 6:19 AM, Jack Phillips wr ote: > Greg, if you change a Bendix mag for a Slick mag I think you will > need a different drive gear, and they ain=99t cheap. As Oscar said , you > might do better to just rebuild the Bendix. > > > Jack Phillips > > NX899JP > > Smith Mountain Lake, Virginia > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Greg Bacon > *Sent:* Monday, April 21, 2014 11:30 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* Pietenpol-List: Mag needed for an A75 > > > Hello Everyone, > > > I'm in need of a decent used mag and a harness for an A75-8. I have a > Bendix Scintilla SF4RN-8 that isn't working. The working mag is a Slick > 4230, but a 4333 would be great. I haven't had any luck finding one at > Wentworth, Barnstormers, nor eBay. If you know of one, please let me kno w. > gbacon67(at)gmail.com > > > Thanks, > > > -- > Greg Bacon > > Prairie Home, MO > > NX114D(Mountain Piet) > > > *http://www.matronics.com/Navigator?Pietenpol-List * > > *http://forums.matronics.com * > > *http://www.matronics.com/contribution * > > > * > =========== .matronics.com/Navigator?Pietenpol-List> =========== =========== om/contribution> =========== > > * > > -- Greg Bacon Prairie Home, MO NX114D(Mountain Piet) ________________________________________________________________________________
Date: Apr 22, 2014
Greg, call Don Swords at Dons Dream Machines in Griffin Ga. He has mags. Che ers, Gardiner Sent from my iPad > On Apr 22, 2014, at 7:58 AM, Greg Bacon wrote: > > Hi Jack. Yes, rebuilding the old Bendix Scintilla is not a bad option. J oe's ballpark quote to rebuild it is $600-$700. My mechanic thought that wa s very high and suggested I search for a good Slick or a newer model Bendix f irst. He didn't mention the drive gear nor the wiring harness replacement c osts. I'm hoping to find a good deal, maybe do some trading. I do have a r ebuildable Corvair I'm willing to part with... > > >> On Tue, Apr 22, 2014 at 6:19 AM, Jack Phillips wrote: >> Greg, if you change a Bendix mag for a Slick mag I think you will need a d ifferent drive gear, and they ain=99t cheap. As Oscar said, you might do better to just rebuild the Bendix. >> >> >> >> Jack Phillips >> >> NX899JP >> >> Smith Mountain Lake, Virginia >> >> >> >> From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-l ist-server(at)matronics.com] On Behalf Of Greg Bacon >> Sent: Monday, April 21, 2014 11:30 PM >> To: pietenpol-list(at)matronics.com >> Subject: Pietenpol-List: Mag needed for an A75 >> >> >> >> Hello Everyone, >> >> >> >> I'm in need of a decent used mag and a harness for an A75-8. I have a Be ndix Scintilla SF4RN-8 that isn't working. The working mag is a Slick 4230, but a 4333 would be great. I haven't had any luck finding one at Wentworth , Barnstormers, nor eBay. If you know of one, please let me know. gbacon67 @gmail.com >> >> >> >> Thanks, >> >> >> >> -- >> Greg Bacon >> >> Prairie Home, MO >> >> NX114D(Mountain Piet) >> >> >> >> >> >> http://www.matronics.com/Navigator?Pietenpol-List >> http://forums.matronics.com >> http://www.matronics.com/contribution >> >> >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > > -- > Greg Bacon > Prairie Home, MO > NX114D(Mountain Piet) > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Apr 22, 2014
You might try calling Aircraft Systems in Rockford, IL, or Poplar Grove Airmotive (both good shops): http://www.acs-rfd.com/services.htm http://www.poplargroveairmotive.com/Maintenance/index.html On Tue, Apr 22, 2014 at 6:58 AM, Greg Bacon wrote: > Hi Jack. Yes, rebuilding the old Bendix Scintilla is not a bad option. > Joe's ballpark quote to rebuild it is $600-$700. My mechanic thought th at > was very high and suggested I search for a good Slick or a newer model > Bendix first. He didn't mention the drive gear nor the wiring harness > replacement costs. I'm hoping to find a good deal, maybe do some trading . > I do have a rebuildable Corvair I'm willing to part with... > > > On Tue, Apr 22, 2014 at 6:19 AM, Jack Phillips wrote: > >> Greg, if you change a Bendix mag for a Slick mag I think you will >> need a different drive gear, and they ain=99t cheap. As Oscar sai d, you >> might do better to just rebuild the Bendix. >> >> >> >> Jack Phillips >> >> NX899JP >> >> Smith Mountain Lake, Virginia >> >> >> ------------------------------ >> >> *From:* owner-pietenpol-list-server(at)matronics.com [mailto: >> owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Greg Bacon >> *Sent:* Monday, April 21, 2014 11:30 PM >> *To:* pietenpol-list(at)matronics.com >> *Subject:* Pietenpol-List: Mag needed for an A75 >> >> >> >> Hello Everyone, >> >> >> >> I'm in need of a decent used mag and a harness for an A75-8. I have a >> Bendix Scintilla SF4RN-8 that isn't working. The working mag is a Slick >> 4230, but a 4333 would be great. I haven't had any luck finding one at >> Wentworth, Barnstormers, nor eBay. If you know of one, please let me kn ow. >> gbacon67(at)gmail.com >> >> >> >> Thanks, >> >> >> >> -- >> Greg Bacon >> >> Prairie Home, MO >> >> NX114D(Mountain Piet) >> >> >> >> >> >> >> >> *http://www.matronics.com/Navigator?Pietenpol-List * >> >> *http://forums.matronics.com * >> >> *http://www.matronics.com/contribution * >> >> >> >> * >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > > > -- > Greg Bacon > Prairie Home, MO > NX114D(Mountain Piet) > > * > =========== .matronics.com/Navigator?Pietenpol-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Apr 22, 2014
Are there overhaul manuals available for Scintilla mags?I overhauled both of my AM-4 magsand found the manual to be very good. Is it not "legal" to do your own overhaul as a repairman, (assuming you have that certificate for building the plane) on an experimental engine? My point is not to sell one-self short before trying it yourself. If the parts/seals/gaskets are available, it really is quite simple. What you have now does not work, so you can't really make it worse. I have two CASE mags that I will someday rebuild...if anyone can point me to a parts source or overhaul manual for those I would be much obliged. If God is your co-pilot...switch seats. Mike Perez KaretakerAero STILL Building... ________________________________________________________________________________
Date: Apr 22, 2014
Gardiner, Your friend Glenn Morrow has two working BS mags (same model number as what I have) plus a complete wiring harness. I'll be sending him payment for that shortly. Thanks everyone for your quick response and willingness to help with this!! Greg Bacon Garratt Callahan gbacon@g-c.com (573)489-4795 > On Apr 22, 2014, at 8:29 AM, Gardiner Mason wrote: > > Greg, call Don Swords at Dons Dream Machines in Griffin Ga. He has mags. C heers, Gardiner > > Sent from my iPad > >> On Apr 22, 2014, at 7:58 AM, Greg Bacon wrote: >> >> Hi Jack. Yes, rebuilding the old Bendix Scintilla is not a bad option. J oe's ballpark quote to rebuild it is $600-$700. My mechanic thought that wa s very high and suggested I search for a good Slick or a newer model Bendix f irst. He didn't mention the drive gear nor the wiring harness replacement c osts. I'm hoping to find a good deal, maybe do some trading. I do have a r ebuildable Corvair I'm willing to part with... >> >> >>> On Tue, Apr 22, 2014 at 6:19 AM, Jack Phillips wrote: >>> Greg, if you change a Bendix mag for a Slick mag I think you will need a different drive gear, and they ain=99t cheap. As Oscar said, you mig ht do better to just rebuild the Bendix. >>> >>> >>> >>> Jack Phillips >>> >>> NX899JP >>> >>> Smith Mountain Lake, Virginia >>> >>> >>> >>> From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol- list-server(at)matronics.com] On Behalf Of Greg Bacon >>> Sent: Monday, April 21, 2014 11:30 PM >>> To: pietenpol-list(at)matronics.com >>> Subject: Pietenpol-List: Mag needed for an A75 >>> >>> >>> >>> Hello Everyone, >>> >>> >>> >>> I'm in need of a decent used mag and a harness for an A75-8. I have a B endix Scintilla SF4RN-8 that isn't working. The working mag is a Slick 4230 , but a 4333 would be great. I haven't had any luck finding one at Wentwort h, Barnstormers, nor eBay. If you know of one, please let me know. gbacon6 7(at)gmail.com >>> >>> >>> >>> Thanks, >>> >>> >>> >>> -- >>> Greg Bacon >>> >>> Prairie Home, MO >>> >>> NX114D(Mountain Piet) >>> >>> >>> >>> >>> >>> http://www.matronics.com/Navigator?Pietenpol-List >>> http://forums.matronics.com >>> http://www.matronics.com/contribution >>> >>> >>> >>> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >>> tp://forums.matronics.com >>> _blank">http://www.matronics.com/contribution >>> >> >> >> >> -- >> Greg Bacon >> Prairie Home, MO >> NX114D(Mountain Piet) >> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> npol-List"">http://www.matronics.com/Navigator?Pietenpol-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Apr 22, 2014
I just took a good set off the Cub and replaced them with Slicks to get shielded wires. I moved the Cub to our Public airport and really have to start using radios for the traffic pattern to be safe. The engine noise was light, but is an excuse to buy something for the airplanes. LOL I'll look at them tonight and let you know exactly what they are. Barry NX973BP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of taildrags Sent: Tuesday, April 22, 2014 12:54 AM Subject: Pietenpol-List: Re: Mag needed for an A75 --> Greg; we'll find you one. I've put out some feelers and I'm sure a couple of other Pieters will take a look around their hangars and see what we can find. Meanwhile, is your dead Bendix Scintilla really dead? They are rebuildable. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422228#422228 ________________________________________________________________________________
Subject: question for Canadians (off topic)
Date: Apr 22, 2014
A theoretical question for any of you who might be able to help me understand the HST (sales tax). Let's say I buy an airplane from a guy in Ontario. He de-registers the Canadian-registered aircraft and I bring it to the U.S. Forget the registration business... what I'm wondering is, when does the HST come into play? To whom is it paid, and when? If I hand him some money and drive away with the airplane without any further paperwork or action, will U.S. Customs ask me for a bill of sale and proof of payment of HST on the purchase? If a tree falls in the woods and nobody is there to hear it, does it make any noise? ;o) Theoretical, purely theoretical. Thanks. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422285#422285 ________________________________________________________________________________
Date: Apr 22, 2014
Mike; depending on the series of Case magneto, manuals are to be found on eBay. Example: manual for a 660 series mag, $93. Parts are something else again though. I do have a source for magneto repairs, a farm implement outfit in the Midwest that overhauled a Fairbanks-Morse magneto that I'm going to use on the UltraVair engine. They may be able to help with parts for these old mags. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422286#422286 ________________________________________________________________________________
Date: Apr 23, 2014
you don't have to pay hst unless it is from a business and then it should b e refundable at the border. The only taxes you pay should be to your own c ountry. > Subject: Pietenpol-List: question for Canadians (off topic) > From: taildrags(at)hotmail.com > Date: Tue=2C 22 Apr 2014 21:14:57 -0700 > To: pietenpol-list(at)matronics.com > > > A theoretical question for any of you who might be able to help me unders tand the HST (sales tax). Let's say I buy an airplane from a guy in Ontari o. He de-registers the Canadian-registered aircraft and I bring it to the U.S. > > Forget the registration business... what I'm wondering is=2C when does th e HST come into play? To whom is it paid=2C and when? If I hand him some money and drive away with the airplane without any further paperwork or act ion=2C will U.S. Customs ask me for a bill of sale and proof of payment of HST on the purchase? If a tree falls in the woods and nobody is there to h ear it=2C does it make any noise? =3Bo) > > Theoretical=2C purely theoretical. Thanks. > > -------- > Oscar Zuniga > Medford=2C OR > Air Camper NX41CC "=3BScout"=3B > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422285#422285 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Apr 23, 2014
Thanks Oscar. When the day comes that I have the time to do the overhaul, I 'll do some more indepth searching. I did at one point have a contact for m ag parts here in Ohio, a tractor guy.--=0A-=0A=0AIf God is your co-pi lot...switch seats. =0AMike Perez =0AKaretaker Aero =0ASTILL Building...=0A ________________________________________________________________________________
Date: Apr 23, 2014
Subject: Perez's Build Status
Crew, I just wanted to give the list an update as to what is going on with my build. This coming July will mark the 6th year of construction and as of late, I have been slacking in my progress. I can point to the usual culpri ts: life happens, too cold, too hot, holidays, etc. truth is, I have been l azy.- However, I have found my second wind and am as motivated now as I w as during week one almost 6 years ago. =0A=0A=0AMy new plan is to finish th e items I can in my shop. Than move the plane out into the garage for compl ete assembly and an initial W&B. I need it assembled to fabricate the last few items and it will be nice to FINALLY see it all together as one unit! - The first engine run will also take place at some point as well as a ni ce photo shoot of the assembled plane. About the only thing I can think of NOT doing is the covering of the gaps between the wings and C.S. as these w ill be glued fabric and I'll need to disassemble to transport to a hangar.. .once found. I hope to have this all done prior to our next winter. There I S a light at the end of the tunnel!- (something I thought would never hap pen)=0A=0AThe final push is on.=0A=0A=0AIf God is your co-pilot...switch se ats. =0AMike Perez =0AKaretakerAero=0ASTILL Building... =0A ________________________________________________________________________________
Date: Apr 23, 2014
> > A buddy bought new Slick Mags, the only new FAA approved MAGs on the > market, and they cost him $2400! compleate with harnesses and sparkplugs. > Sure did start easy once we got it timed. Blue Skies, Steve D > > ________________________________________________________________________________
Date: Apr 23, 2014
Greg, I've had 2 Bendix SF4's rebuilt by Fresno Airparts. One was a year and a half ago and the other was about 2 weeks ago. Both of them were fantastic. Practically a new magneto when they were done. New bearings, points, gears, everything. Both of them had somewhere around 50 new parts replaced. Fantastic. The one from a year and a half ago is running great with probably 70 hours on it. They overhauled them the day after they arrived and sent them out the next day, so the turn around was terrific. They charge a flat $425.00 each. Plus about $20 shipping. Can't say enough good about them! Fresno Airparts 559-237-4863 No credit card. You'd need to send a check with the magneto. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422297#422297 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: this is what makes this list so valuable
Date: Apr 23, 2014
Right here below. Once every 25 or 30 posts there is a gem like this. Thanks to Don Emch we now ALL have some good, solid information that is als o a great cost savings for what others charge for mag overhauls. I've been dealing with Fresno Airparts for over 18 years and I never knew t hey rebuilt magnetos, let alone had such stellar turn-around times. This is just fantastic info Don----thank you for taking time to post it. Mike C. Ohio Greg, I've had 2 Bendix SF4's rebuilt by Fresno Airparts. One was a year and a h alf ago and the other was about 2 weeks ago. Both of them were fantastic. Practically a new magneto when they were done. New bearings, points, gear s, everything. Both of them had somewhere around 50 new parts replaced. Fa ntastic. The one from a year and a half ago is running great with probably 70 hours on it. They overhauled them the day after they arrived and sent them out the next day, so the turn around was terrific. They charge a flat $425.00 each. Plus about $20 shipping. Can't say enough good about them! Fresno Airparts 559-237-4863 No credit card. You'd need to send a check with the magneto. Don Emch NX899DE ________________________________________________________________________________
Date: Apr 23, 2014
Correction, Don. I bought my new oil pump parts from Fresno Airparts last week and they now have moved into the 21st century and now take credit cards. And I agree about their customer service. I got my parts in 3 days. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Don Emch Sent: Wednesday, April 23, 2014 11:46 AM Subject: Pietenpol-List: Re: Mag needed for an A75 Greg, I've had 2 Bendix SF4's rebuilt by Fresno Airparts. One was a year and a half ago and the other was about 2 weeks ago. Both of them were fantastic. Practically a new magneto when they were done. New bearings, points, gears, everything. Both of them had somewhere around 50 new parts replaced. Fantastic. The one from a year and a half ago is running great with probably 70 hours on it. They overhauled them the day after they arrived and sent them out the next day, so the turn around was terrific. They charge a flat $425.00 each. Plus about $20 shipping. Can't say enough good about them! Fresno Airparts 559-237-4863 No credit card. You'd need to send a check with the magneto. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422297#422297 ________________________________________________________________________________
Date: Apr 23, 2014
Subject: Re: this is what makes this list so valuable
Thanks Mike and Don!! On Wed, Apr 23, 2014 at 11:53 AM, Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] wrote: > Right here below. Once every 25 or 30 posts there is a gem like this. > Thanks to Don Emch we now ALL have some good, solid information that is > also a great cost savings for what others charge for mag overhauls. > I=99ve been dealing with Fresno Airparts for over 18 years and I ne ver knew > they rebuilt magnetos, let alone had such stellar turn-around times. > This is just fantastic info Don----thank you for taking time to post it. > > Mike C. > Ohio > > > Greg, > > I've had 2 Bendix SF4's rebuilt by Fresno Airparts. One was a year and a > half ago and the other was about 2 weeks ago. Both of them were > fantastic. Practically a new magneto when they were done. New bearings, > points, gears, everything. Both of them had somewhere around 50 new parts > replaced. Fantastic. The one from a year and a half ago is running grea t > with probably 70 hours on it. They overhauled them the day after they > arrived and sent them out the next day, so the turn around was terrific. > They charge a flat $425.00 each. Plus about $20 shipping. Can't say > enough good about them! > > Fresno Airparts > 559-237-4863 > No credit card. You'd need to send a check with the magneto. > > Don Emch > NX899DE > > > * > =========== .matronics.com/Navigator?Pietenpol-List> =========== =========== om/contribution> =========== > > * > > -- Greg Bacon Prairie Home, MO NX114D(Mountain Piet) ________________________________________________________________________________
Date: Apr 23, 2014
Wow Jack! I never thought they'd do that! Thanks for the heads up! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422303#422303 ________________________________________________________________________________
Date: Apr 23, 2014
They even answer emails now! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Don Emch Sent: Wednesday, April 23, 2014 1:35 PM Subject: Pietenpol-List: Re: Mag needed for an A75 Wow Jack! I never thought they'd do that! Thanks for the heads up! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422303#422303 ________________________________________________________________________________
Subject: Rudder horns
Date: Apr 23, 2014
Any Piet flyers have rudder horns installed under the horizontal stab? If so, works fine? Any structural considerations? Thanks, builder in Oregon Bill ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: nice Piets for sale
Date: Apr 23, 2014
Hey all, Wow, it's been quiet here. I have another fun adventure to share later. In the meantime.. What Piets are for sale these days? I have a friend whom might be looking for a nice one. Wants a continental-powered, and a nice, flying plane. Douwe ________________________________________________________________________________
Subject: Re: nice Piets for sale
Date: Apr 23, 2014
here's a starting point: http://pietenpols.org/id16.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422311#422311 ________________________________________________________________________________
Date: Apr 23, 2014
Subject: Re: Rudder horns
We have ours at the bottom, no problems so far, 360 hrs or so.- I talked Dad into it when we were building, just thought it looked cleaner.- I Kno w the horn in the middle distributes the torque/twisting load a little more evenly, on the flimsy rudder structure, but she is holding together ok.- The top rudder hinge is-starting to get-a little slop in it now, could be attributed, but it is the same as the outer elevator hinges- (Vi Kapl er cast hinges), so it might have been a hinge line misalignment, or just a design flaw of a steel hinge pin in an aluminum casting.=0A-=0AShad=0AOn Wednesday, April 23, 2014 2:54 PM, flygirl Mason wr otmail.com>=0A=0AAny Piet flyers have rudder horns installed under the hori zontal stab?=0AIf so, works fine? Any structural considerations?=0AThanks, == ________________________________________________________________________________
Date: Apr 23, 2014
what does the word might mean? is he looking for a piet or not? I keep read ing reading might in this news letter. the word might means nothing. a coup le of months ago another fellow thought that he might sell his piet. he sai d that word might several times. I never could figure out what the fucker w as talking about.=0A=0Ajim-=0AOn Wednesday, April 23, 2014 8:06 PM, Bill Church wrote:=0A =0A--> Pietenpol-List message po sted by: "Bill Church" =0A=0Ahere's a starting poin t:=0A=0Ahttp://pietenpols.org/id16.html=0A=0A=0A=0A=0ARead this topic onlin e here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=422311#422311=0A ======================== ________________________________________________________________________________
Date: Apr 24, 2014
Filters, Jim, filters. -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine From: jim hyde <jnl96(at)yahoo.com<mailto:jnl96(at)yahoo.com>> >" > Date: Wednesday, April 23, 2014 at 10:02 PM etenpol-list(at)matronics.com> Subject: Re: Pietenpol-List: Re: nice Piets for sale what does the word might mean? is he looking for a piet or not? I keep read ing reading might in this news letter. the word might means nothing. a coup le of months ago another fellow thought that he might sell his piet. he sai d that word might several times. I never could figure out what the fucker w as talking about. jim On Wednesday, April 23, 2014 8:06 PM, Bill Church > wrote: > here's a starting point: http://pietenpols.org/id16.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422311#422====== ==================http://www.matronics. com/Navigat - MATRONICS WEB FORUMS -<= --> <http://forums.m atronics.com/viewtopic.php?p=422311#422311> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> m/Navigator?Pietenpol-List ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Subject: Re: Perez's Build Status
Date: Apr 23, 2014
Thanks.... I am also finding that I get stalled as well. Seems crazy what little steps seem to stall me - which small things are tough to move past. Such is the case of a long-term project I guess..... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422315#422315 ________________________________________________________________________________
Date: Apr 23, 2014
Doc Martin Clif Lord, grant me the strength to accept what I cannot change, the strength to change what I can and the wisdom to hide the bodies of those who REALLY pissed me off! Filters, Jim, filters. -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine Subject: Re: Pietenpol-List: Re: nice Piets for sale what does the word might mean? is he looking for a piet or not? I keep reading reading might in this news letter. the word might means nothing. a couple of months ago another fellow thought that he might sell his piet. he said that word might several times. I never could figure out what the fucker was talking about. jim ________________________________________________________________________________
Date: Apr 24, 2014
Definition of MIGHT past of may used in auxiliary function to express permission, liberty, probability, possibility in the past or a present condition contrary to fact or less probability or possibility than may or as a polite alternative to may or to ought or should -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422317#422317 ________________________________________________________________________________
Date: Apr 24, 2014
Douwe, Looking forward to hearing about your last Piet adventure. I'll keep an eye open for your friend. Jim, I'm surprised you might have been interested in whether or not that fellow from a few months ago might be selling his Piet. I just assumed you might be building your own based on your posts. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422318#422318 ________________________________________________________________________________
Date: Apr 24, 2014
Oscar has his for sale. There are some Grega's around for sale too but you said Piet. Good luck. It looks like the prices are starting to creep up a little. I have always thought they have been under priced. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422319#422319 ________________________________________________________________________________
Subject: be on the lookout for.......
Date: Apr 24, 2014
two suspicious looking characters seen on the flightline at Oshkosh........ (Don Emch & Larry Williams) [cid:image001.png(at)01CF5F96.D8A5EE80] ________________________________________________________________________________
Subject: a few photos
Date: Apr 24, 2014
Scroll down for more. [cid:image001.jpg(at)01CF5F9A.175C9720] Jack Phillips in Icarus Plummet off my starboard wing enroute to Ripon, WI via Brodhead-Dodge Co. for a weather delay. [cid:image002.jpg(at)01CF5F9A.175C9720] Jack fueling up at Dodge Co. after we had to put down for lowering ceilings enroute to Oshkosh. [cid:image003.jpg(at)01CF5F9A.175C9720] Much of what Illinois and Wisconsin look like during the summer months. T his is just northwest of Aurora, IL. [cid:image004.jpg(at)01CF5F9A.175C9720] After an afternoon rain shower on the flightline at Oshkosh. [cid:image005.jpg(at)01CF5F9A.175C9720] Gary & Shad Bell L, Randy Bush R. [cid:image006.jpg(at)01CF5F9A.175C9720] The Gentleman from Minnesota's airplane, Greg Cardinal. [cid:image007.jpg(at)01CF5F9A.175C9720] Waiting for the weather to lift at Dodge Co. Airport, WI. ________________________________________________________________________________
Subject: Re: be on the lookout for.......
Date: Apr 24, 2014
Ah, Mike... can you imagine what life might be like if we didn't have a little fun sometimes. At least Larry might look a little more suspicious than me.... Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422322#422322 ________________________________________________________________________________
Date: Apr 24, 2014
I worked for a Commander who banned the word "Should". Especially in relation to what we were planning. Should means it ought to happen but implies that you don't think it will. If I said we "Should be ready to load the aircraft at 1200, to go to Iraq!" then he asked why I thought it would not happen. Blue Skies, Steve D ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Date: Apr 24, 2014
But Larry IS more suspicious, so at least thats an honest look for him! ;) -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine On 4/24/14, 10:19 AM, "Don Emch" wrote: > >Ah, Mike... can you imagine what life might be like if we didn't have a >little fun sometimes. > >At least Larry might look a little more suspicious than me.... > >Don Emch >NX899DE > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=422322#422322 > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Subject: Fresno Airparts takes credit cards?
Date: Apr 24, 2014
No kidding Jack? Next thing you know I'll find out the earth isn't flat a nd that there is no Santy Claus! Here's a complete listing of what Fresno carries---they are a great company to deal with. (don't tell Jim Irwin at Aircraft Spruce that Fresno beats them hands down on price and turnaroun d time rebuilding Bendix mags either) http://www.trade-a-plane.com/company-search?id=53087 ________________________________________________________________________________
Date: Apr 24, 2014
Try again with the picture this time=0AOn Thursday, April 24, 2014 5:49 PM, Hans van der Voort wrote:=0A =0AYes, I did, see attach ed picture.=0AThe reason for it; to control the tail wheel.=0ARudder horn a nd tail wheel horn are one piece.=0A-=0AWorks well for me, no issues so f ar 200 or more-landings and take offs mostly on not so smooth grass.=0A -=0AHans=0A-=0ANX15KV=0AWaller, TX=0AOn Wednesday, April 23, 2014 1:54 PM, flygirl Mason wrote:=0A =0A--> Pietenpol-List m essage posted by: flygirl Mason =0A=0AAny Piet flyers have rudder horns installed under the horizontal stab?=0AIf so, works fine ? Any structural considerations?=0AThanks, builder in Oregon=0ABill=0A=0A ================= ________________________________________________________________________________
Date: Apr 24, 2014
Yes, I did, see attached picture.=0AThe reason for it; to control the tail wheel.=0ARudder horn and tail wheel horn are one piece.=0A-=0AWorks well for me, no issues so far 200 or more-landings and take offs mostly on not so smooth grass.=0A-=0AHans=0A-=0ANX15KV=0AWaller, TX=0AOn Wednesday, April 23, 2014 1:54 PM, flygirl Mason wrote:=0A =0A =0A=0AAny Piet flyers have rudder horns installed under the horizontal stab ?=0AIf so, works fine? Any structural considerations?=0AThanks, builder in ======================== ________________________________________________________________________________
Date: Apr 24, 2014
From: Charles Burkholder <born2fly(at)abcmailbox.net>
Subject: Fresh Air for the Pietenpol
Hi guys, I was working on the plane today and decided to give it some fresh air. Haven't worked on it for a while since having been gone to Sun n Fun and a work project..... Took everything outside and put the tail feathers for a moral-boosting photo shoot. The wings are ready to cover and are at a different location so I couldn't include them. Now all I need is some fabric put on it, finish the landing gear, bolt an engine on it and she'd be ready to fly. Now if only it would happen that easy! For all you southerners yes we still have a tiny bit of snow laying on the ground up here in Ontario.... Charles B Visit my new blog @ http://missionmechfund.blogspot.ca/ ________________________________________________________________________________
Date: Apr 24, 2014
I know the feeling...I might have put 20 miles on the airframe, hauling it in and out of the garage for pictures!! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Burkholder Sent: Thursday, April 24, 2014 7:08 PM Subject: Pietenpol-List: Fresh Air for the Pietenpol Hi guys, I was working on the plane today and decided to give it some fresh air. Haven't worked on it for a while since having been gone to Sun n Fun and a work project..... Took everything outside and put the tail feathers for a moral-boosting photo shoot. The wings are ready to cover and are at a different location so I couldn't include them. Now all I need is some fabric put on it, finish the landing gear, bolt an engine on it and she'd be ready to fly. Now if only it would happen that easy! For all you southerners yes we still have a tiny bit of snow laying on the ground up here in Ontario.... Charles B Visit my new blog @ http://missionmechfund.blogspot.ca/ ________________________________________________________________________________
Date: Apr 24, 2014
Hans; May I ask where you got the hinges that you're using on your rudder and elevators? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422355#422355 ________________________________________________________________________________
Date: Apr 24, 2014
u lost me on the filter response jeff=0A=0Ajim=0AOn Thursday, April 24, 201 4 9:32 AM, Steven Dortch wrote:=0A =0AI worked for a Commander who banned the word "Should". =0A=0AEspecially-in relati on to what we were planning. =0A=0AShould means it ought to happen but imp lies that you don't think it will. =0A=0AIf I said we "Should be ready to load the aircraft at 1200, to go to Iraq!" then he asked why I thought it w ======= ________________________________________________________________________________
Subject: Re: Fresh Air for the Pietenpol
Date: Apr 24, 2014
Looks awesome - thx for posting.... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422356#422356 ________________________________________________________________________________
Date: Apr 24, 2014
Jim, The word "filter" and the word you need to filter both start with the same letter - f. You might want to go back and reread your post and see which word he was referring to, if you are confused. This forum is not a locker room nor an airplane hangar. it is a place to discuss building and flying Pietenpols where women and children also read. But I am sure you know all that. Indiscriminate loss of filters will get you banned, Jim. Maybe you did not know that. Jeff was only giving you good advice. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422358#422358 ________________________________________________________________________________
Date: Apr 25, 2014
Oscar,
Those are from Vi Kapler.
Hans
Sent from Yahoo Mail for iPad
Date: Apr 25, 2014
Seems like we had to tolerate Jim's tirades awhile back as well. Remember when our gracious host was seeking donations for this site to cover upkeep? I'm often amazed by the absolute lack of decorum and manners of an otherwise intelligent and accomplished person Just my $.02. Glen Sent from my iPhone > On Apr 24, 2014, at 11:56 PM, "jarheadpilot82" wrote: > > > Jim, > > The word "filter" and the word you need to filter both start with the same letter - f. You might want to go back and reread your post and see which word he was referring to, if you are confused. This forum is not a locker room nor an airplane hangar. it is a place to discuss building and flying Pietenpols where women and children also read. > > But I am sure you know all that. Indiscriminate loss of filters will get you banned, Jim. Maybe you did not know that. Jeff was only giving you good advice. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > USMC, USMCR, ATP > BVD DVD PDQ BBQ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422358#422358 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 25, 2014
Hi Charles, your fuselage looks great. I am a little behind you, My fuselage is coming along pretty well, and I have about got all the material gathered to start my split axle landing gear, I hope to be able to roll it out of the shop soon for a little air and a photo or two. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422399#422399 ________________________________________________________________________________
Date: Apr 26, 2014
Charles; what style of landing gear are you planning to use? And is your fuselage the standard width? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422410#422410 ________________________________________________________________________________
Date: Apr 26, 2014
I am building the split landing gear and yes it is standard width. CB On 4/26/2014 11:43 AM, taildrags wrote: > > Charles; what style of landing gear are you planning to use? And is your fuselage the standard width? > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422410#422410 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > -- Charles Burkholder Visit my blog @ http://missionmechfund.blogspot.ca/ ________________________________________________________________________________
Date: Apr 26, 2014
Subject: Sky Scout with Corvair
Has anyone ever heard or seen of anyone putting a corvair engine on a sky sout. The model T engine and the corvair are about the same weight,considering the radiator and coolant that goes with the Model T. BE ________________________________________________________________________________
Date: Apr 27, 2014
Subject: GN-1 Landing Gear mount fairing
Hi Guys, I am about ready to cover my GN-1 and was wondering if anybody had any ideas about the landing gear mount fairing. I have added some wood stringers under the fuse that stop either side of the gear mounts (see page two of the photos page on the website). Is this area faired or just left as is. Pics would be useful. Cheers Peter Wonthaggi Australia http://repiet.cpc-world.com ________________________________________________________________________________
Subject: Re: Sky Scout with Corvair
Date: Apr 27, 2014
Dick Navrotil is building one to those specs as we speak. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422438#422438 ________________________________________________________________________________
Date: Apr 27, 2014
Would you have Dick Navrotil's user name so I can get in touch with him? I am new to this forum and I don't see a way to search for someone by name. Thanks Much, BE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422442#422442 ________________________________________________________________________________
Date: Apr 27, 2014
Hi Bill Yes, I am building one, although very slowly at this point. Dave Aldrich, Skip Gadd and I just put together a set of floats at SNF this year and I am going to Barnwell SC. this fall to continue work on my engine. I figure I need to have the Corvair for the power to get it off of the water. If you have any questions call me at 651-638-0793. I am north of St. Paul, MN. Dick N. ----- Original Message ----- From: "Bill Emidy" <wemidy(at)cox.net> Sent: Saturday, April 26, 2014 7:06 PM Subject: Pietenpol-List: Sky Scout with Corvair > > Has anyone ever heard or seen of anyone putting a corvair engine on a sky > sout. The model T engine and the corvair are about the same > weight,considering the radiator and coolant that goes with the Model T. BE > > > ________________________________________________________________________________
Date: Apr 27, 2014
Subject: AOPA San Marcos
Flyin at San Marcos was very good. Lots of neat planes. Ron Machado's talk on stick and rudder was on point. Found a Pietenpol being built. Bonanza formation was competitive with T6 formation. -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Trick
Date: Apr 27, 2014
Here's a little trick that cured a VERY frustrating little issue. Just sayin'. :-) Clif ________________________________________________________________________________
Subject: Re: Trick
Date: Apr 27, 2014
Coulda used that trick several times in the past ;o) Got a trick for how to get small brass nuts on the brass screws that are used to mount instruments to the instrument panel? Those @#$%& things are so small and difficult to start on the screws back inside the panel while wrapping your arms around the top cowling to hold the screw head in place... and not able to see any of it (working by feel, dropping the nut and tiny lockwasher). Space is tight back in there around the instruments, too. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422490#422490 ________________________________________________________________________________
Subject: Re: GN-1 Landing Gear mount fairing
Date: Apr 27, 2014
Peter; I don't think I realized that the GN-1 had mounts that ran under the cockpit floor like that. My guess is that the simple way would be to just run fabric over that area and make it taut like the rest. It is quite a wide-open area to cover without some battens to keep the fabric shape though. However, you could also wrap a piece of aluminum over the area and screw it down, which would give you access to the area in the future if it were ever needed to pull the gear back off. Which, knock on wood, none of us ever wants to think about (but I have, and so have you). I'm afraid I can't be of much help since I don't have a GN-1. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422491#422491 ________________________________________________________________________________
Subject: West Coast Piet Fly-In
Date: Apr 27, 2014
I've begun to have my doubts about making it to Frazier Lake. Work has been crazy since about October, with no free time to work on airplane stuff except on weekends. With the coming of spring, my weekends have been taken up with chores related to waking up the yard and garden, repairing damage from the winter, and all that goes with it. Then there was the April 15 tax deadline, the looming April 30 healthcare enrollment deadline, and a host of other time-wasters in between. My carb is going back together and is ready for me to set the float level and finish assembling it. New front main seal is ready to go into place. Engine is ready to start back up again, warm up, and run the differential compression test... then if everything checks out it's out onto the taxiway and runway for some test flights in the pattern if the engine runs up to full power smoothly after the carb overhaul. That's at least two weekends for me. Annual condition inspection has to be done, which is another weekend. With five weekends left between now and the fly-in, I'm going to be cutting it close to undertake a long x-c after all this. We'll see how it goes. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422492#422492 ________________________________________________________________________________
Date: Apr 28, 2014
Oscar, Thanks, I had thought of both of those. I even made an aluminium cover for it was not happy with the look. Perhaps Ill put it on and see how it looks when finished. Cheers Peter On 28/04/2014 1:47 pm, "taildrags" wrote: > >Peter; I don't think I realized that the GN-1 had mounts that ran under >the cockpit floor like that. My guess is that the simple way would be to >just run fabric over that area and make it taut like the rest. It is >quite a wide-open area to cover without some battens to keep the fabric >shape though. > >However, you could also wrap a piece of aluminum over the area and screw >it down, which would give you access to the area in the future if it were >ever needed to pull the gear back off. Which, knock on wood, none of us >ever wants to think about (but I have, and so have you). I'm afraid I >can't be of much help since I don't have a GN-1. > >-------- >Oscar Zuniga >Medford, OR >Air Camper NX41CC "Scout" >A75 power > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=422491#422491 > > ________________________________________________________________________________
Date: Apr 28, 2014
Hi Peter, I am also close to covering my GN-1 fuselage, and I _think_ what Oscar is referring to with the aluminum is like what DJ Vegh did as shown in this link: http://www.imagedv.com/aircamper/log/image-pages/02-19-05.htm I'm hoping that will work as opposed to wood fairings, which would add considerable weight. I did use wood fairings around my top engine mount brackets and will cover them with aluminum panels to allow for inspection and access. See following link: http://s897.photobucket.com/user/az-gold/media/CC%2028%20San%20Marcos%20TX%20%20%20Feb%2028%20-%20March%202%20%202014/DSCF0252.jpg.html Regards, John Franklin GN-1 / Corvair 164cid Prairie Aire 4TA0 Needville, TX -----Original Message----- From: Peter Johnson Sent: Apr 27, 2014 6:32 AM Subject: Pietenpol-List: GN-1 Landing Gear mount fairing Hi Guys, I am about ready to cover my GN-1 and was wondering if anybody had any ideas about the landing gear mount fairing. I have added some wood stringers under the fuse that stop either side of the gear mounts (see page two of the photos page on the website). Is this area faired or just left as is. Pics would be useful. Cheers PeterWonthaggi Australiahttp://repiet.cpc-world.com ________________________________________________________________________________
Date: Apr 28, 2014
Subject: Re: Trick
http://www.aircraftspruce.com/catalog/hapages/instmountnuts.php Oscar, Click on link above. I use these "frogs" when I can. Some old instruments can't accept them. On Sun, Apr 27, 2014 at 10:42 PM, taildrags wrote: > > Coulda used that trick several times in the past ;o) Got a trick for how > to get small brass nuts on the brass screws that are used to mount > instruments to the instrument panel? Those @#$%& things are so small and > difficult to start on the screws back inside the panel while wrapping your > arms around the top cowling to hold the screw head in place... and not able > to see any of it (working by feel, dropping the nut and tiny lockwasher). > Space is tight back in there around the instruments, too. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422490#422490 > > -- John Kuhfahl, Lt Col USAF (Ret), President, KUHLCOUPER LLC ________________________________________________________________________________
Date: Apr 28, 2014
Subject: Re: Trick
That's a funny looking cotterpin????- Just kidding ya, those little trick s are life savers....at least time savers.=0A-=0AShad=0AOn Monday, April 28, 2014 7:43 AM, John Kuhfahl wrote:=0A =0Ahttp:// www.aircraftspruce.com/catalog/hapages/instmountnuts.php=0A=0A=0AOscar,=0AC lick on link above.- I use these "frogs" when I can.- Some old instrume nts can't accept them.=0A=0A=0A=0A=0AOn Sun, Apr 27, 2014 at 10:42 PM, tail drags wrote:=0A=0A--> Pietenpol-List message posted by: "taildrags" =0A>=0A>Coulda used that trick seve ral times in the past ;o) -Got a trick for how to get small brass nuts on the brass screws that are used to mount instruments to the instrument pane l? -Those @#$%& things are so small and difficult to start on the screws back inside the panel while wrapping your arms around the top cowling to ho ld the screw head in place... and not able to see any of it (working by fee l, dropping the nut and tiny lockwasher). -Space is tight back in there a round the instruments, too.=0A>=0A>--------=0A>Oscar Zuniga=0A>Medford, OR =0A>Air Camper NX41CC "Scout"=0A>A75 power=0A>=0A>=0A>=0A>=0A>Read this top ic online here:=0A>=0A>http://forums.matronics.com/viewtopic.php?p=422490 #422490=0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>============0A >br>=0A-List" target="_blank">http://www.matronics.com/Navigator?Pietenpo l-List=0A>============0A>MS -=0A>k">http://forums.mat ronics.com=0A>============0A>e -=0A>- - - - --Matt Dralle, List Admin.=0A>t="_blank">http://www.matronics.com/contr ibution=0A>============0A>=0A>=0A>=0A>=0A=0A=0A-- =0A ============= ________________________________________________________________________________
Date: Apr 28, 2014
Subject: Re: West Coast Piet Fly-In
We will keep on trying to help you mentally get it ready to fly down to Frazier Lake. We are all looking forward to meeting you Oscar. Cheers, Jim B. ________________________________________________________________________________
Subject: Shielded mag switches...
Date: Apr 28, 2014
Quick question, and I know this has been covered before...BUT: Should the shield of the shielded wire from the mags to the switches be grounded on BOTH ENDS, or ONLY ONE END; and if one end, WHICH END? Or does it really matter? Thanks, Ray Krause Still working on SkyScout Sent from my iPad ________________________________________________________________________________
Subject: Re: Shielded mag switches...
Date: Apr 28, 2014
Ray Ground it at the Mag end only . If yoy ground it at both ends it will set up edy curents and cause more noise. Dale ----- Original Message ----- From: "Ray Krause" <raykrause(at)frontiernet.net> Sent: Monday, April 28, 2014 12:20 PM Subject: Pietenpol-List: Shielded mag switches... > > > Quick question, and I know this has been covered before...BUT: > > Should the shield of the shielded wire from the mags to the switches be > grounded on BOTH ENDS, or ONLY ONE END; and if one end, WHICH END? Or does > it really matter? > > Thanks, > > Ray Krause > Still working on SkyScout > > Sent from my iPad > > > --- This email is free from viruses and malware because avast! Antivirus protection is active. http://www.avast.com ________________________________________________________________________________
Date: Apr 28, 2014
Mine are not grounded at the switch either. I clipped off the braid at that end and then used a little heat-shrink tubing to cover that part of the wire. I had heard the same thing about the possibility of circular currents. I have not yet had a chance to operate my handheld in the cockpit to see if the grounding scheme and shielded harness have taken care of ignition noise, but I'll soon find out. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422523#422523 ________________________________________________________________________________
Date: Apr 28, 2014
no brainer.. you can not over shield so why think about it .. just shield i t=0AOn Monday, April 28, 2014 3:58 PM, taildrags wr tmail.com>=0A=0AMine are not grounded at the switch either.- I clipped of f the braid at that end and then used a little heat-shrink tubing to cover that part of the wire.- I had heard the same thing about the possibility of circular currents.- I have not yet had a chance to operate my handheld in the cockpit to see if the grounding scheme and shielded harness have ta ken care of ignition noise, but I'll soon find out.=0A=0A--------=0AOscar Z uniga=0AMedford, OR=0AAir Camper NX41CC "Scout"=0AA75 power=0A=0A =0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/view ========= ________________________________________________________________________________
Date: Apr 28, 2014
Ok Dick.I will call you in a few weeks. Are you using the plans supplied by The Pietenpol family? Are they the same ones that are printed in the Flying and Gliding Mag reprint from 1933. Or are they actual plans with a little more detail to them? I have not ordered the plans yet. I have a couple of engines that I'm working on dismantling for at least one good one. Are you going with traditional wood or Steel tubing? Thanks much, BE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422527#422527 ________________________________________________________________________________
Subject: High quality PIET construction
Date: Apr 28, 2014
Check out the nice work on www.stoinoff.com/piet. -------- Planes&Bikes Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422530#422530 ________________________________________________________________________________
Date: Apr 28, 2014
Thanks, Dale. That what I will do. Sure is a great way to get a quick answer. Ray Krause Sent from my iPad > On Apr 28, 2014, at 11:17 AM, "Dale Johnson" wrote: > > > Ray > > Ground it at the Mag end only . If yoy ground it at both ends it will set up edy curents and cause more noise. > > Dale > ----- Original Message ----- From: "Ray Krause" <raykrause(at)frontiernet.net> > To: > Sent: Monday, April 28, 2014 12:20 PM > Subject: Pietenpol-List: Shielded mag switches... > > >> >> Quick question, and I know this has been covered before...BUT: >> >> Should the shield of the shielded wire from the mags to the switches be grounded on BOTH ENDS, or ONLY ONE END; and if one end, WHICH END? Or does it really matter? >> >> Thanks, >> >> Ray Krause >> Still working on SkyScout >> >> Sent from my iPad > > > --- > This email is free from viruses and malware because avast! Antivirus protection is active. > http://www.avast.com > > > > > ________________________________________________________________________________
Date: Apr 28, 2014
Oscar, Please let me know how the ignition shielding works. Ray Krause PS: sure hope you make it to our FLYIN! Sent from my iPad > On Apr 28, 2014, at 1:51 PM, "taildrags" wrote: > > > Mine are not grounded at the switch either. I clipped off the braid at that end and then used a little heat-shrink tubing to cover that part of the wire. I had heard the same thing about the possibility of circular currents. I have not yet had a chance to operate my handheld in the cockpit to see if the grounding scheme and shielded harness have taken care of ignition noise, but I'll soon find out. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422523#422523 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: High quality PIET construction
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Apr 28, 2014
Your link doesn't work. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422534#422534 ________________________________________________________________________________
Subject: Re: Trick
Date: Apr 28, 2014
That is brilliant. FWIW, I use modeling clay for in places like you mention. Started using heavy grease in auto applications, and morphed to the clay which works better and in more places. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422535#422535 ________________________________________________________________________________
Date: Apr 28, 2014
Hey Ray When something is grounded it electrically doesn't matter the shielding is there the to prevent the magnetic flux from radiating any further than the shielding. Grounding to the same ground as the Mag is great make sure that all grounds are common. Engine, fuel system . Metal cowling, I'm probably going to kick the hornets nest on this but anything made of metal needs to be grounded. Any metallic object and a lot of plastics can radiate rf energy and cause static probs. just my $.02 Sent from my iPhone > On Apr 28, 2014, at 10:20 AM, Ray Krause wrote: > > > Quick question, and I know this has been covered before...BUT: > > Should the shield of the shielded wire from the mags to the switches be grounded on BOTH ENDS, or ONLY ONE END; and if one end, WHICH END? Or does it really matter? > > Thanks, > > Ray Krause > Still working on SkyScout > > Sent from my iPad > > > > ________________________________________________________________________________
Date: Apr 29, 2014
Check it out, outstanding quality, makes mine look average! Sent from my iPad Jack Textor > On Apr 28, 2014, at 8:16 PM, "planes&bikes" wrote: > > > Check out the nice work on www.stoinoff.com/piet. > > -------- > Planes&Bikes > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422530#422530 > > > > > > > > > > ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Apr 29, 2014
Oscar, Shame, Shame. When there is a will there is a way. I still expect to see you there. I will be VERY surprised if you don't show. I think the weather will be the most challenging part, It always is for me that time of year. I'm going to keep believing that you will be there. I want to meet you and see your wonderful flying machine. Keep plugging away at it. Cheers and see you in June, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422544#422544 ________________________________________________________________________________
Date: Apr 29, 2014
Very high quality... just look how tight the fit is between the rib pieces. And he don't need no stinkin' nicopress! Wrapped and soldered cable ends. But what's with the highly finished wood parts that will get fabric covering? Don't you get a better adhesion to bare wood? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422566#422566 ________________________________________________________________________________
Date: Apr 30, 2014
Magnificent construction. I envy the workmanship. But I wonder about the ad ded weight of those layers of finish needed to get that glistening shine. Lorenzo ________________________________________________________________________________
Date: Apr 30, 2014
Wow....! It'll be a shame to cover it..... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422594#422594 ________________________________________________________________________________
Subject: Wood gear legs.
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Apr 30, 2014
Those who are operating on wood gear legs.... Did you glue the spruce legs t o the ash blocks or did you rely on the steel fittings and bolts to make the connection? Yes I know, small work space but it's warm, dry and ten steps from the kitch en! Scott Knowlton. Sent from my iPhone ________________________________________________________________________________
Subject: Re: Wood gear legs.
Date: Apr 30, 2014
I dowelled and glued mine, but I'm not sure it matters. Gary NX308MB Sent from my iPhone > On Apr 30, 2014, at 12:54 PM, Scott Knowlton wrote: > > Those who are operating on wood gear legs.... Did you glue the spruce legs to the ash blocks or did you rely on the steel fittings and bolts to make the connection? > > Yes I know, small work space but it's warm, dry and ten steps from the kitchen! > > Scott Knowlton. > > > > > > > > > > Sent from my iPhone ________________________________________________________________________________
Date: Apr 30, 2014
Scott-I glued that junction with T-88 after scuff sanding the mating pieces . With my landings I could use all the help I can get on the undercarriage strength! Mike C. Ohio [cid:image001.jpg(at)01CF648F.06F20920] ________________________________________________________________________________
Date: Apr 30, 2014
I glued the spruce and ash together Subject: Pietenpol-List: Wood gear legs. From: flyingscott_k(at)hotmail.com Date: Wed=2C 30 Apr 2014 15:54:53 -0400 Those who are operating on wood gear legs.... Did you glue the spruce legs to the ash blocks or did you rely on the steel fittings and bolts to make t he connection? Yes I know=2C small work space but it's warm=2C dry and ten steps from the kitchen! Scott Knowlton. Sent from my iPhone ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Apr 30, 2014
I relied on the steel fittings and the bolts. Over 300 hours, hundreds of landings (including one forced landing that ended in a groundloop) and no problems at all with the wooden gear. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Scott Knowlton Sent: Wednesday, April 30, 2014 3:55 PM Subject: Pietenpol-List: Wood gear legs. Those who are operating on wood gear legs.... Did you glue the spruce legs to the ash blocks or did you rely on the steel fittings and bolts to make the connection? Yes I know, small work space but it's warm, dry and ten steps from the kitchen! Scott Knowlton. ________________________________________________________________________________
Date: Apr 30, 2014
I glued mine. If I hadnt I would have needed five hands to hold it all together to drill the metal fittings. Scotty -------- Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Tail and Ribs built...Building fuselage & undercarriage...Corvair engine at Roy's Garage waiting to be modified. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422618#422618 ________________________________________________________________________________
Date: Apr 30, 2014
Subject: Seat cushons
Gentlemen, and Oscar, I have the old seat worn out and ugly seat cushions and may use them for my first flights. However, I have enough Pleather to have a new set made. I would appreciate your thoughts on: Design, Just enough to go under my seat and back with some wiggle room. Should It be wider? Cushion padding materiel (I am thinking firmer memory foam) Thickness. What I have is VERY thin and barely . But I don't want to get too thick and push myself toward the instruments. Shape. I am probably going to copy what I have, but do y'all have any modifications you suggest. Attachments, The old ones have push snaps on some pads none on others. How about Velcro or simply tucking tabs in? Or is it needed at all? I hold it in from the back seat. Thanks in advance for the guidance. -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: Seat cushons
Date: Apr 30, 2014
Make it like Scott Liefield's! It's like sitting in an easy chair! Gary NX308MB Sent from my iPhone > On Apr 30, 2014, at 4:59 PM, Steven Dortch wro te: > > Gentlemen, and Oscar, I have the old seat worn out and ugly seat cushions a nd may use them for my first flights. > > However, I have enough Pleather to have a new set made. I would appreciate your thoughts on: > Design, Just enough to go under my seat and back with some wiggle room. S hould It be wider? > Cushion padding materiel (I am thinking firmer memory foam) > Thickness. What I have is VERY thin and barely . But I don't want to get t oo thick and push myself toward the instruments. > Shape. I am probably going to copy what I have, but do y'all have any modi fications you suggest. > Attachments, The old ones have push snaps on some pads none on others. How about Velcro or simply tucking tabs in? Or is it needed at all? I hold it i n from the back seat. > > Thanks in advance for the guidance. > -- > Blue Skies, > Steve D > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Apr 30, 2014
Link to photos? On Wed, Apr 30, 2014 at 7:09 PM, Gary Boothe wrote: > Make it like Scott Liefield's! It's like sitting in an easy chair! > > Gary > NX308MB > > Sent from my iPhone > > On Apr 30, 2014, at 4:59 PM, Steven Dortch > wrote: > > Gentlemen, and Oscar, I have the old seat worn out and ugly seat cushions > and may use them for my first flights. > > However, I have enough Pleather to have a new set made. I would appreciate > your thoughts on: > Design, Just enough to go under my seat and back with some wiggle room. > Should It be wider? > Cushion padding materiel (I am thinking firmer memory foam) > Thickness. What I have is VERY thin and barely . But I don't want to get > too thick and push myself toward the instruments. > Shape. I am probably going to copy what I have, but do y'all have any > modifications you suggest. > Attachments, The old ones have push snaps on some pads none on others. How > about Velcro or simply tucking tabs in? Or is it needed at all? I hold it > in from the back seat. > > Thanks in advance for the guidance. > -- > Blue Skies, > Steve D > > > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Apr 30, 2014
I glued and stapled. The glue really doesn't do much, the staples DO add quite a bit of strength. The glue doesn't do much, BUT the penalty is NIL. It does add a little, in that it might prevent a LITTLE movement, so there's no reason not to. While the staples do add strength, not much in the big scheme of things. They did, however, hold it all together VERY well while I got the metal pieces all bolted in there. I used 2" long 1/4" crown staples. FWIW, the bottom end is FAR from the weak link. It's the other end that's important. Make sure it's fitted well. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422650#422650 ________________________________________________________________________________
Date: Apr 30, 2014
Don't forget that the strut bracket goes from the outside to inside plates across the fuselage bottom between the fuselage and your nice new legs. I see a tent in the backyard. Soon. :-) Clif Counting days! :-) Those who are operating on wood gear legs.... Did you glue the spruce legs to the ash blocks or did you rely on the steel fittings and bolts to make the connection? Yes I know, small work space but it's warm, dry and ten steps from the kitchen! Scott Knowlton. -------------------------------------------------------------------------------- > > -------------------------------------------------------------------------------- > > > Sent from my iPhone -------------------------------------------------------------------------------- ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: May 01, 2014
John, Thanks, its not so much the wing fittings etc but the area under the fuse where the gear framework is fitted. This is a link to a photo of the original frame i.e. No fairing at all, no additional stringers either. http://repiet.cpc-world.com/images/DSC00140_JPG.jpg Cheers Peter On 28/04/2014 9:18 pm, "John Franklin" wrote: > >Hi Peter, > >I am also close to covering my GN-1 fuselage, and I _think_ what Oscar is >referring to with the aluminum is like what DJ Vegh did as shown in this >link: http://www.imagedv.com/aircamper/log/image-pages/02-19-05.htm > >I'm hoping that will work as opposed to wood fairings, which would add >considerable weight. I did use wood fairings around my top engine mount >brackets and will cover them with aluminum panels to allow for inspection >and access. See following link: >http://s897.photobucket.com/user/az-gold/media/CC%2028%20San%20Marcos%20TX >%20%20%20Feb%2028%20-%20March%202%20%202014/DSCF0252.jpg.html > > >Regards, >John Franklin >GN-1 / Corvair 164cid >Prairie Aire 4TA0 >Needville, TX >-----Original Message----- > >From: Peter Johnson > >Sent: Apr 27, 2014 6:32 AM > >To: pietenpol-list(at)matronics.com > >Subject: Pietenpol-List: GN-1 Landing Gear mount fairing > > >Hi Guys, >I am about ready to cover my GN-1 and was wondering if anybody had any >ideas about the landing gear mount fairing. I have added some wood >stringers under the fuse that stop either side of the gear mounts (see >page two of the photos page on the website). Is this area faired or just >left as is. >Pics would be useful. >Cheers >PeterWonthaggi Australiahttp://repiet.cpc-world.com > > ________________________________________________________________________________
Date: May 01, 2014
Peter, My GN-1 has the cross braces but not the "N" shaped tube bracing. I think the plans call for two thin wood strips on the bottom of the fuselage (like the ones on the side) as well, but I'll have to check tonight. I was thinking that the thin wood strips on the bottom would be interrupted by the cross braces but I had planned to bridge the gaps on the wooden strips with aluminum "U" channel. I hope I'm making this clear and perhaps when I get that far along I can send pix as well. I think it's a good idea to reinforce the gear area as my mentor Jim Sury actually cracked his GN-1 fuselage on one of his first few flights. At his suggestion, I added some extra wood bracing in that area of the inside of the fuselage. Regards, John -----Original Message----- >From: Peter Johnson <vk3eka(at)bigpond.net.au> >Sent: May 1, 2014 1:42 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: GN-1 Landing Gear mount fairing > > >John, > >Thanks, its not so much the wing fittings etc but the area under the fuse >where the gear framework is fitted. This is a link to a photo of the >original frame i.e. No fairing at all, no additional stringers either. > >http://repiet.cpc-world.com/images/DSC00140_JPG.jpg > > >Cheers > >Peter > > >On 28/04/2014 9:18 pm, "John Franklin" wrote: > >> >>Hi Peter, >> >>I am also close to covering my GN-1 fuselage, and I _think_ what Oscar is >>referring to with the aluminum is like what DJ Vegh did as shown in this >>link: http://www.imagedv.com/aircamper/log/image-pages/02-19-05.htm >> >>I'm hoping that will work as opposed to wood fairings, which would add >>considerable weight. I did use wood fairings around my top engine mount >>brackets and will cover them with aluminum panels to allow for inspection >>and access. See following link: >>http://s897.photobucket.com/user/az-gold/media/CC%2028%20San%20Marcos%20TX >>%20%20%20Feb%2028%20-%20March%202%20%202014/DSCF0252.jpg.html >> >> >>Regards, >>John Franklin >>GN-1 / Corvair 164cid >>Prairie Aire 4TA0 >>Needville, TX >>-----Original Message----- >> >>From: Peter Johnson >> >>Sent: Apr 27, 2014 6:32 AM >> >>To: pietenpol-list(at)matronics.com >> >>Subject: Pietenpol-List: GN-1 Landing Gear mount fairing >> >> >> >>Hi Guys, >>I am about ready to cover my GN-1 and was wondering if anybody had any >>ideas about the landing gear mount fairing. I have added some wood >>stringers under the fuse that stop either side of the gear mounts (see >>page two of the photos page on the website). Is this area faired or just >>left as is. >>Pics would be useful. >>Cheers >>PeterWonthaggi Australiahttp://repiet.cpc-world.com >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: May 01, 2014
From: Douwe Blumberg <douweblumberg(at)earthlink.net>
Subject: cushions
Hello good people! There seem to be two "basic" foam-types regularly available to us. Open and closed cell foam. Think of open cell foam as a sponge. It's a matrix of cavities in the sponge material which are all interconnected and link to the outside so when compressed, the air is forced out leaving just the sponge material supporting you. Closed cell is more like a piece of swiss cheese where the bubbles are not connected to eachother or the outside and when compressed, act as little balloons making the foam material AND the compressed air in each little bubble provide the support. Closed cell is a bit heavier but doesn't squash down as much and loose it's cushioning ability when compressed. Memory foam is like this. My cushion is made of a couple 1/2" layers of fairly firm closed cell foam with a cut up memory foam neck pillow I found on amazon for $14. It even had a nice wedge shape which works well. longest flight yet was a 2.5 hr leg from Brodhead home and my butt wasn't sore when I landed. (other things were sore, but NOT the bottom!) Douwe ________________________________________________________________________________
Date: May 01, 2014
Steve, Attached is a side view of mine. I assume you guys are talking about the pilots seat. The top of my seat back cross member is moved two inches to the rear. That makes it a little reclined. The cushions I have are actually Cessna 150 seat cushions. It may be tricky to do if you fuse is already built. We did this modification to mine back in the 1980's. Like Gary said, it is very comfortable. The front seat lower cushion is that expensive triple layered/density foam about 3 inches thick and the seat back is just a one inch single density foam. The only down side to the lower cushion is that it is as hard as a rock when it is cold out. When cold out I put it in my truck with the heater blowing on it during pre-flight to soften it up. So, there you go. Maybe this helps. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422660#422660 Attachments: http://forums.matronics.com//files/piet_105_126.jpg ________________________________________________________________________________
Date: May 01, 2014
Good second picture but the first "seat" picture sure looks like a tailwheel...!! LOTS of wonderful information in that fuselage side view - thanks...! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422665#422665 ________________________________________________________________________________
Date: May 01, 2014
Funny you commented about the tailwheel pic. Both of those pics were scanned together and are now one attachment. Consider it to be a bonus Pic. BTW, I changed out that tailwheel assembly because it made the plane handle like a Pitts when landing. The new assembly makes it a pussy-cat to land now. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422666#422666 ________________________________________________________________________________
Date: May 01, 2014
That Photo (the sideview, not the tailwheel) motivates and inspires me to make it like your rear seat.It also gives me ideas for the front seat. Thanks for posting them. BTW Looking at your steel tube fuselage. It has a very different feel than the Wood frame. Man that looks like a generation newer technology. radio mounts fittings attached to metal tubes. Also are the front to rear bracing wires on the left side of the front seat standard? I have not seen that on any Piets or Gregas. Thanks again, I learn and am often motivated by almost every photo of a Piet I see. Blue Skies, Steve D On Thu, May 1, 2014 at 8:32 AM, AircamperN11MS wrote: > Scott.liefeld(at)lacity.org> > > Steve, > > Attached is a side view of mine. I assume you guys are talking about the > pilots seat. The top of my seat back cross member is moved two inches to > the rear. That makes it a little reclined. The cushions I have are > actually Cessna 150 seat cushions. It may be tricky to do if you fuse is > already built. We did this modification to mine back in the 1980's. Like > Gary said, it is very comfortable. > > The front seat lower cushion is that expensive triple layered/density foam > about 3 inches thick and the seat back is just a one inch single density > foam. The only down side to the lower cushion is that it is as hard as a > rock when it is cold out. When cold out I put it in my truck with the > heater blowing on it during pre-flight to soften it up. > > So, there you go. Maybe this helps. > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422660#422660 > > > Attachments: > > http://forums.matronics.com//files/piet_105_126.jpg > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: May 01, 2014
Steve, Yes the cross wires are on the left side on my plane. We put a door in for the front seat on the right side of the plane. The door is on the R/S to allow for no disruption of the throttle linkage on the L/S. Most Piets have the cross wires on the right hand side. There are also some Piets out there without any cross wires. My forward diagonal cabane supports are not very large in diameter and I feel better having the cross cables for the extra support in a sudden stop. If that makes any sense. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422674#422674 ________________________________________________________________________________
Date: May 01, 2014
Steve; the seat cushions and coverings in 41CC are minimalist; naugahyde over conventional "hobby store" foam (and not much of it), wrapped around the plywood pieces and stapled on the back. I doubt if any of the foam was more than an inch thick when it was new. The seat back really doesn't matter, because I find myself leaning forward in flight anyway, to get out of the slipstream. The back does need padding, but I don't recline and I don't notice the seat back much anyway, so getting fancy wouldn't make a difference. The front seat is similar. The main mission of this airplane can be captured and summarized by the in-flight vignettes on Mike Cuy's video. You preflight, launch, go enjoy the countryside and the air and the view, then you let the airplane teach you some stick and rudder lessons as you get back in the pattern and shoot some landings. After you put the airplane away and look back on your flight, comfort isn't one of the main factors upon which you rate the experience you've just had. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422675#422675 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: what seat cushions? (or Walmart)
Date: May 01, 2014
Steve, I've never had seat cushions in my Pietenpol and it has been fine but then again I am a full-figured girl so don't need any extra padding. If you want a quick replacement right now is a great time to buy seat cushi ons at Walmart. They only have about 60 different kinds and a bunch you can order in different colors, have them shipped to a store nea r you or to your home directly. http://www.walmart.com/browse/patio-garden/cushions-pillows/5428_1102183_10 32001/?_refineresult=true&povid=cat1102183-env498421-moduleB050213-lLin kFC7Cushions_Pillows Mike C. Ohio [cid:image001.png(at)01CF653D.1080CA40] ________________________________________________________________________________
Subject: Re: what seat cushions? (or Walmart)
Date: May 01, 2014
Mike, You must be one tough cowboy. Do you ride horses bare back during the week to stay toughened up for the Piet?????? I couldn't handle that for more than just a few minutes. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422679#422679 ________________________________________________________________________________
Date: May 01, 2014
Ahahha, well Scott I'm not a cowboy but I simply followed the seat slant/ angle suggestions made by my Uncle Tony in his books and that proved to be nice and comfortable. (I angled the bottom of the seat back out an inch forward) Tony also has some good seat cushion advice for back and m uscle comfort but of course the newer foams make these suggestions even nicer. I always said that the only 3 things I needed to build my Pietenpol were a phone, a credit card, and the Bingelis books and that is true today as much as it was when I started building 20 years ago. Mike C. Ohio ________________________________________________________________________________
Subject: and for the record
Date: May 01, 2014
Tony Bingelis isn't my uncle but I always envisioned him as like this Mafia type Godfather of good homebuilding advice and because he was Italian. I guess I just like calling him my Uncle Tony too because he was ALWAYS the re on the end of the sofa on my little lamp table in the form of his books waiting to answer all of my questions when I would need a break from buildi ng or screw something up doing it my way instead of the way an experienced homebuilder would do it and do it in an airworthy fashion that would be app roved by the FAA. Uncle Tony always gives 2 or 3 ways to do a task too un less there is only one right and sound way to do it----then he makes that very c lear and I didn't want to deviate and go experimenting on my own only to fi nd out later that my big idea was a dangerous and possibly deadly one. Good sou nd advice always from my Uncle Tony. Good sketches and diagrams too and I learn far better visually than I do simply reading text. Thanks Uncle Tony. Mike C. Ohio ________________________________________________________________________________
Date: May 01, 2014
Subject: Re: and for the record
Mike, Despite your eloquent preamble, I have a burning family question for you. Among the folks who have dropped by my hangar over the past few weeks to kick the tires on my Piet project have been two who referenced your uncle Tony but pronounced his last name in dramatically different ways. One emphasized the first syllable. Another the second syllable. The latter's pronunciation of that syllable was how one would indicate the tribe of Gauls subdued by Julius Caesar. So how is Bingelis pronounced? All these years I've seen it spelled. I didn't know what I didn't know, which was how to pronounce it. Cheers, Ken On Thu, May 1, 2014 at 11:59 AM, Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] wrote: > Tony Bingelis isn=99t my uncle but I always envisioned him as like this > Mafia type Godfather of good homebuilding advice and because he was > Italian. > > I guess I just like calling him my Uncle Tony too because he was ALWAYS > there on the end of the sofa on my little lamp table in the form of his > books > > waiting to answer all of my questions when I would need a break from > building or screw something up doing it my way instead of the way an > experienced > > homebuilder would do it and do it in an airworthy fashion that would be > approved by the FAA. Uncle Tony always gives 2 or 3 ways to do a task t oo > unless >
March 29, 2014 - May 01, 2014
Pietenpol-Archive.digest.vol-nk
