Pietenpol-Archive.digest.vol-nv
October 29, 2014 - November 28, 2014
http://forums.matronics.com/viewtopic.php?p=432472#432472
With the Stewart System, Spar Varnish from Home Depot will work fine. We did
several tests before we used it just to make sure. We even soaked wood in
fuel (in a sealed jar) for several weeks with no problem
Barry
NX973BP
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Harvey
Plummer
Sent: Wednesday, October 29, 2014 9:44 AM
Subject: Pietenpol-List: Varnish
I am completing construction of my Vertical Stabilizer. Should I varnish the
entire stabilizer? Is there an issue with applying the covering later over
varnish?
Harv, 485PB
http://forums.matronics.com/viewtopic.php?p=432454#432454
Subject: | Re: Ferry tank for Oskkosh |
Oops... Jeff- my humble apologies. Upon re-reading what you wrote, I see that
you correctly stated that the transcontinental flight would only require ONE of
those tip tanks. Good figgerin' on your part ;o)
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power
http://forums.matronics.com/viewtopic.php?p=432481#432481
From: | "Boatright, Jeffrey" <jeffboatright(at)emory.edu> |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From: | Steven Dortch <steven.d.dortch(at)gmail.com> |
Not really needed! the longest leg would be 470 miles from Iceland to the
Faeroe Islands.
So planning 5 GPH and 75 MPH and 500 miles is just under 35 gallons. So
Fill the body shaped tank, fill the wing tank, and the nose tank and maybe
carry 5 more gallons for the 1 hour reserve, in your lap to refill the wing
tank . This will require an autopilot as you stand in the back seat to fill
the wing tank. But what are the chances you will have to use the reserve?
Don;t forget you can take out the padding as the immersion suit will be so
big you can't fit otherwise. And you will have to tie the inflatable raft
under the wing.
I think that the raft requirement can by satified by FILLING THE PLANE WITH
PING PONG BALLS!
Ducking and running for cover.
Blue Skies,
Steve D
Besides the fact that you would be limited to 28 days of VFR/Day only flying when
you get to the UK, I think the biggest obstacle to flying across the Atlantic
in a Pietenpol would be required IFR equipment. How many have IFR equipped
and approved planes?
Mike Salerno
>From the North Atlantic International General Aviation Operations Manual:
Aircraft Instruments and Equipment
Aircraft must be approved for IFR flight, and equipped with the following instruments
and equipment in
serviceable condition.
a) a sensitive pressure altimeter adjustable for barometric pressure;
b) a magnetic compass that operates independently of the aircraft electrical generating
system;
c) an airspeed indicator with a means of preventing malfunction due to icing (pilot
heat);
d) a turn and slip indicator or turn coordinator;
e) an adequate source of electrical energy, and an adequate supply of fuses, if
appropriate;
f) a stabilized magnetic direction indicator or a gyroscopic direction indicator;
g) an attitude indicator;
h) a vertical speed indictor;
i) an outside air temperature gauge;
j) appropriate engine power and performance indicating instruments;
k) a power failure warning device or vacuum indicator that shows the power available
to gyroscopic
instruments for each power source;
l) fuel tank quantity indicators;
m) an alternative source of static pressure for the altimeter, airspeed indicator
and vertical speed
indicator; and
n) if the flight is to be made at night;
- a means of illumination for all instruments used to operate the aircraft;
- when carrying passengers, a landing light; and
- navigation lights
Communications Equipment
Very High Frequency Radio. Sufficient radio communications equipment to permit
the pilot, in the event
of failure of any item of that equipment, to conduct two-way communications on
the appropriate frequency.
High Frequency Radio. An HF radio capable of transmitting and receiving on a minimum
of two
appropriate international air-ground general purpose frequencies.
NOTE-
[1] The route Iqaluit - Sondre Stromfjord - Keflavik - ALDAN - 61N 10W - Benbecula
is
approved for non-HF equipped aircraft..
[2] Aircraft may proceed across the Atlantic without HF radio at FL250 or above
on the route
Goose Bay - Prins Christian Sund (or Narsarsuaq) - Keflavik - ALDAN - 61N 10W -
Benbecula. Operations in MNPS airspace (FL 285 to 420) is not allowed unless specific
MNPS authority is held.
Navigation Equipment
ICAO Annex 2 requires an aircraft to be equipped with adequate navigation equipment
to enable it to
navigate in accordance with the flight plan and the air traffic control clearance.
The CARs require that sufficient radio navigation equipment be installed to permit
the pilot, in the event of
the failure at any stage of the flight of any item of that equipment, including
any associated flight instrument
display.
a) to proceed to the destination aerodrome or proceed to another aerodrome that
is suitable for
landing, and
b) where the aircraft is operated in IMC, to complete an instrument approach, and
if necessary,
conduct a missed approach.
A suitable interpretation of the above would permit an aircraft equipped with VOR/ILS/ADF
and a single
GPS approved for enroute flight to operate on any of the North Atlantic routes.
On Wednesday, October 29, 2014 3:49 PM, Steven Dortch
wrote:
Not really needed! the longest leg would be 470 miles from Iceland to the Faeroe
Islands.
So planning 5 GPH and 75 MPH and 500 miles is just under 35 gallons. So Fill the
body shaped tank, fill the wing tank, and the nose tank and maybe carry 5 more
gallons for the 1 hour reserve, in your lap to refill the wing tank . This
will require an autopilot as you stand in the back seat to fill the wing tank.
Don;t forget you can take out the padding as the immersion suit will be so big
you can't fit otherwise. And you will have to tie the inflatable raft under the
wing.
I think that the raft requirement can by satified by FILLING THE PLANE WITH PING
PONG BALLS!
Blue Skies,
Steve D
Subject: | Request for Latex Paint Projects |
Hi All,
I would like to update the Wiener Dog Aero website with info on your latex projects. I've added a page on my Titan Tornado as an example http://wienerdogaero.com/TitanTornado.php .
Now I would like to add more pages with your info. If you have a Latex painted
airplane and would be willing to share you info, would you please send me:
Airplane Type:
Your name:
Home town:
Year finished:
Materials painted:
Primer used:
Color Paint used:
website if you have one:
Notes on your finish:
and photo(s):
I'm hoping that this will help us all learn more about using Latex paint,
Malcolm Morrison
www.wienerdogaero.com
gliderx5(at)comcast.net
Huh. Did Lindbergh have all that stuff when he made the crossing? He flew it
in 1927, the Piet is a 1929 design, I'm claiming that because they are from generally
the same era, the same rules will apply. Either that or I'll make the
crossing below radar coverage, land in the first suitable cow pasture "over there",
and then cover the US registry markings with UK markings in white duct
tape. I'm going to use "G-BUSH" or something else that doesn't attract attention
;o)
Move over, Steve... I'm ducking into the same foxhole...
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=432508#432508
Subject: | Re: advice on trim mechanism |
From: | "Jeff Boatright" <jeffboatright(at)emory.edu> |
Some more general ponderings about trim and a question.
For most of the around-the-patch flying I do, in level "cruise" flight, I "trim"
with the throttle. If the nose is dipping, I bump up maybe 50 rpm (usually less).
If I detect a slight climb, I pull the throttle back just a little. The
difference in airspeed is usually less than 5 mph. I don't really need a trim
mechanism for this.
Where I would like trim is on climb-out, where I need to push forward on the stick
if the fuselage tank is less than 3/4 full and there is no passenger, and
on base and final, when I've pulled power back to idle and I need to pull the
stick back quite a bit to keep the nose up and maintain 50-55 mph.
For all those who have a trim system on their Piets (Scott, Barry, Gary, and others),
does your trim system work with enough power to, say, maintain a steady
airspeed while on final? I find that final is the most extreme (relative, of
course).
http://forums.matronics.com/viewtopic.php?p=432510#432510
From: | "jarheadpilot82" <jarheadpilot82(at)hotmail.com> |
Not to muddy the waters any more, I saw this Pietenpol at the Hiller Aviation Museum
in San Carlos CA yesterday. The pulleys seem to complicate things and I
have no idea what the top of the trim tab looked like or the cockpit controls
as the airplane was about 15 fett over my head.
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=432515#432515
http://forums.matronics.com//files/image_366.jpg
Terry: is that the museum with the Long EZ on the roof? Friends have told me it's
worth visiting.
I see what you mean about the added complexity with the pulleys. I can only imagine
what this setup would do if the cable broke.
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=432518#432518
Subject: | Re: Request for Latex Paint Projects |
Malcolm;
I don't have a latex paint project per se, but I do have a test setup that I was
working on, in case you want to include a link to it:
http://www.flysquirrel.net/piets/paint/paint.html
I still have the test coupons and I need to set them up outdoors to see what a
year of weathering does to them.
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=432519#432519
One and the same museum. If you are ever in the area you should stop by not big,
but it has some interesting exhibits.
I like the double Bowden cable idea, FWIW.
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=432520#432520
jarheadpilot82 wrote:
> Not to muddy the waters any more, but I saw this Pietenpol at the Hiller Aviation
Museum in San Carlos CA yesterday. The pulleys seem to complicate things
and I have no idea what the top of the trim tab looked like or the cockpit controls
as the airplane was about 15 feet over my head.
Actually, for a retro-fit, the pulley system may be easier to install.
A very similar system is on John Doig's Piet. Photos at WestcoastPiet. Here's the
trim tab:
http://www.westcoastpiet.com/images/WCP_2013_Gathering/IMG_0575.JPG
http://www.westcoastpiet.com/images/WCP_2013_Gathering/IMG_0576.JPG
http://www.westcoastpiet.com/images/WCP_2013_Gathering/IMG_0574.JPG
And the cockpit controls:
http://www.westcoastpiet.com/images/WCP_2013_Gathering/IMG_0598.JPG
http://forums.matronics.com/viewtopic.php?p=432524#432524
You're not related to a fellow named Corrigan are you.
Clif
Either that or I'll make the crossing below radar coverage, land in the
first suitable cow pasture "over there", > --------
> Oscar Zuniga
From: | "johnnysdrop" <johnnysdrop(at)googlemail.com> |
We let you good Americans fly your N reg aircraft here indefinitely as long as
it is insured and your license is current.
We have N reg aircraft based here permanently and can even obtain a US license
here to fly them!
English Johnny
Still on wing spars
The only way is UP
http://forums.matronics.com/viewtopic.php?p=432536#432536
English Johnny, I have a British Pietenpol question.
Y'all have to build to engineering approved plans. The British approved
plans have one jury strut on the front strut. WHY? In the US, I see jury
struts on both struts. Why the front strut?
Some background, a local with some homebuilding experience is adamant that
putting jury struts on a Piet is a engineering disaster. The "result" will
be the wing being too stiff out to the strut attachment and it will fold up
at that point.
I am putting Jury struts back on mine. First, they were on before and the
wing did not collapse after 20 years of flight. Second, my study of FAA
Pietenpol accidents show Zero wing failures. Indeed Zero structural
failures in flight! (there was one accident where a flying wire broke and
several Gregas has pushtubes fail. causing accidents.) There are
discussions of Struts folding under negative Gs (IE hard landing) and that
is the reason for the Jury struts.
I also understand that the jury struts should not be centered on the strut
as that lends itself to a harmonic vibration.
Blue Skies,
Steve D
Piet under restoration.
On Thu, Oct 30, 2014 at 4:55 AM, johnnysdrop
> long as it is insured and your license is current.
> license here to fly them!
> English Johnny
> Still on wing spars
> The only way is UP
Blue Skies,
Steve D
> Airplane Type: Pietepol Air Camper
> Your name: Steve Dortch
> Home town: San Antonio, Texas
> Year finished: 1975 (under restoration)
> Materials painted: ceconite
> Primer used: Sherwin williams
> Color Paint used: White, Yellow, Red, Blue, Black
rolled some, brushed some, sprayed most with HVLP sprayer.
Blue Skies,
Steve D
From: | "AircamperN11MS" <Scott.liefeld(at)lacity.org> |
Jeff,
I just use my trim to relieve stick pressures during level flight. The stick pressures
change a lot in my plane during fuel burn. I have a 10 gallon nose tank
and a 12.5 gallon center section tank. When the nose tank only has 5 gallons
or lees in it I am very tail heavy. This is when I need the trim the most.
Your question regarding trimming during landing is a definite no. I tend to
not make approaches in a straight line. I will usually be in a turning slip
to final much like you see people do in a Pitts or other Biplanes. I don't even
notice the stick forces during landing. Oh, It's nice to have during climb
out too.
Not sure if that really answers your question, The plane isn't stable enough to
ever let go of the stick anyway.
Scott Liefeld
Flying N11MS since March 1972
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
http://forums.matronics.com/viewtopic.php?p=432554#432554
SGkgU2NvdHQsDQoNClRoYW5rcyBmb3IgdGhlIHJlcGx5LiBJIHdvbmRlciB3aHkgdGhlIFBpZXQg
Y2Fu4oCZdCBiZSB0cmltbWVkIG91dCBvbiBmaW5hbC4gSXTigJlzIG5vdCB0aGF0IGJpZyBhIGRl
YWwsIGJ1dCBzaW5jZSBJIGRvbuKAmXQgaGF2ZSBtdWNoIG5lZWQgZm9yIHRyaW0gb3RoZXJ3aXNl
LCBJIGd1ZXNzIEnigJlsbCBsZWF2ZSB3ZWxsIGVub3VnaCBhbG9uZS4gTWF5YmUgSeKAmWxsIGNo
YW5nZSBteSBtaW5kIGlmIGEgdGFrZSBhbnkgbG9uZyBjcm9zcy1jb3VudHJpZXMuDQoNCkplZmYN
Cg0KLS0NCkplZmZyZXkgSC4gQm9hdHJpZ2h0LCBQaEQsIEZBUlZPDQpQcm9mZXNzb3Igb2YgT3Bo
dGhhbG1vbG9neQ0KRW1vcnkgVW5pdmVyc2l0eSBTY2hvb2wgb2YgTWVkaWNpbmUNCg0KRnJvbTog
QWlyY2FtcGVyTjExTVMgPFNjb3R0LmxpZWZlbGRAbGFjaXR5Lm9yZzxtYWlsdG86U2NvdHQubGll
ZmVsZEBsYWNpdHkub3JnPj4NClJlcGx5LVRvOiAicGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNv
bTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4iIDxwaWV0ZW5wb2wtbGlzdEBt
YXRyb25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPj4NCkRhdGU6
IFRodXJzZGF5LCBPY3RvYmVyIDMwLCAyMDE0IGF0IDExOjAxIEFNDQpUbzogInBpZXRlbnBvbC1s
aXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+IiA8
cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0cm9u
aWNzLmNvbT4+DQpTdWJqZWN0OiBQaWV0ZW5wb2wtTGlzdDogUmU6IGFkdmljZSBvbiB0cmltIG1l
Y2hhbmlzbQ0KDQotLT4gUGlldGVucG9sLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJBaXJjYW1w
ZXJOMTFNUyIgPFNjb3R0LmxpZWZlbGRAbGFjaXR5Lm9yZzxtYWlsdG86U2NvdHQubGllZmVsZEBs
YWNpdHkub3JnPj4NCg0KSmVmZiwNCg0KSSBqdXN0IHVzZSBteSB0cmltIHRvIHJlbGlldmUgc3Rp
Y2sgcHJlc3N1cmVzIGR1cmluZyBsZXZlbCBmbGlnaHQuICBUaGUgc3RpY2sgcHJlc3N1cmVzIGNo
YW5nZSBhIGxvdCBpbiBteSBwbGFuZSBkdXJpbmcgZnVlbCBidXJuLiAgSSBoYXZlIGEgMTAgZ2Fs
bG9uIG5vc2UgdGFuayBhbmQgYSAxMi41IGdhbGxvbiBjZW50ZXIgc2VjdGlvbiB0YW5rLiAgV2hl
biB0aGUgbm9zZSB0YW5rIG9ubHkgaGFzIDUgZ2FsbG9ucyBvciBsZWVzIGluIGl0IEkgYW0gdmVy
eSB0YWlsIGhlYXZ5LiAgVGhpcyBpcyB3aGVuIEkgbmVlZCB0aGUgdHJpbSB0aGUgbW9zdC4gIFlv
dXIgcXVlc3Rpb24gcmVnYXJkaW5nIHRyaW1taW5nIGR1cmluZyBsYW5kaW5nIGlzIGEgZGVmaW5p
dGUgbm8uICBJIHRlbmQgdG8gbm90IG1ha2UgYXBwcm9hY2hlcyBpbiBhIHN0cmFpZ2h0IGxpbmUu
ICBJIHdpbGwgdXN1YWxseSBiZSBpbiBhIHR1cm5pbmcgc2xpcCB0byBmaW5hbCBtdWNoIGxpa2Ug
eW91IHNlZSBwZW9wbGUgZG8gaW4gYSBQaXR0cyBvciBvdGhlciBCaXBsYW5lcy4gIEkgZG9uJ3Qg
ZXZlbiBub3RpY2UgdGhlIHN0aWNrIGZvcmNlcyBkdXJpbmcgbGFuZGluZy4gIE9oLCBJdCdzIG5p
Y2UgdG8gaGF2ZSBkdXJpbmcgY2xpbWIgb3V0IHRvby4NCg0KTm90IHN1cmUgaWYgdGhhdCByZWFs
bHkgYW5zd2VycyB5b3VyIHF1ZXN0aW9uLCBUaGUgcGxhbmUgaXNuJ3Qgc3RhYmxlIGVub3VnaCB0
byBldmVyIGxldCBnbyBvZiB0aGUgc3RpY2sgYW55d2F5Lg0KDQpDaGVlcnMsDQoNCi0tLS0tLS0t
DQpTY290dCBMaWVmZWxkDQpGbHlpbmcgTjExTVMgc2luY2UgTWFyY2ggMTk3Mg0KU3RlZWwgVHVi
ZQ0KQy04NS0xMg0KV2lyZSBXaGVlbHMNCkJyb2RoZWFkIGluIDE5OTYNCg0KDQoNCg0KUmVhZCB0
aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KDQpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmll
d3RvcGljLnBocD9wPTQzMjU1NCM0MzI1NTQNCg0KDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAg
ICAgICAtIFRoZSBQaWV0ZW5wb2wtTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRy
b25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlz
dCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNl
YXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJl
LCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmlj
cy5jb20vTmF2aWdhdG9yP1BpZXRlbnBvbC1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAg
ICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxz
byBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2Zv
cnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENv
bnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBz
dXBwb3J0IQ0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBM
aXN0IEFkbWluLg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRp
b24NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09
PT09PT09PT09DQoNCg0KDQoNCg0KX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18NCg0K
VGhpcyBlLW1haWwgbWVzc2FnZSAoaW5jbHVkaW5nIGFueSBhdHRhY2htZW50cykgaXMgZm9yIHRo
ZSBzb2xlIHVzZSBvZg0KdGhlIGludGVuZGVkIHJlY2lwaWVudChzKSBhbmQgbWF5IGNvbnRhaW4g
Y29uZmlkZW50aWFsIGFuZCBwcml2aWxlZ2VkDQppbmZvcm1hdGlvbi4gSWYgdGhlIHJlYWRlciBv
ZiB0aGlzIG1lc3NhZ2UgaXMgbm90IHRoZSBpbnRlbmRlZA0KcmVjaXBpZW50LCB5b3UgYXJlIGhl
cmVieSBub3RpZmllZCB0aGF0IGFueSBkaXNzZW1pbmF0aW9uLCBkaXN0cmlidXRpb24NCm9yIGNv
cHlpbmcgb2YgdGhpcyBtZXNzYWdlIChpbmNsdWRpbmcgYW55IGF0dGFjaG1lbnRzKSBpcyBzdHJp
Y3RseQ0KcHJvaGliaXRlZC4NCg0KSWYgeW91IGhhdmUgcmVjZWl2ZWQgdGhpcyBtZXNzYWdlIGlu
IGVycm9yLCBwbGVhc2UgY29udGFjdA0KdGhlIHNlbmRlciBieSByZXBseSBlLW1haWwgbWVzc2Fn
ZSBhbmQgZGVzdHJveSBhbGwgY29waWVzIG9mIHRoZQ0Kb3JpZ2luYWwgbWVzc2FnZSAoaW5jbHVk
From: | "Harvey Plummer" <plummerharvey(at)yahoo.com> |
Jack, did you use the Stits epoxy varnish or the urethane varnish?
Thanks.
Harv, 485PB
http://forums.matronics.com/viewtopic.php?p=432562#432562
From: | "Jack Phillips" <jack(at)bedfordlandings.com> |
I used the PolyFiber Epoxy varnish on top of polyurethane, throughout the
airplane. Polyurethane spar varnish (1 part) is cheaper so I used it for
the first coat, then put on a top coat of epoxy varnish. My landing gear
struts are left just as (epoxy) varnished spruce and have taken a lot of
abuse in the past 10 years, with no degradation of the finish. I love that
epoxy varnish! It is expensive, but not in the grand scheme of things. I
spent about $200 on epoxy varnish for the entire airplane. That's a pretty
small percentage of the $15,000 I spent building it and well worth it to
protect the structure, in my opinion.
Jack Phillips
NX899JP
Smith Mountain Lake, Virginia
Plummer
Sent: Thursday, October 30, 2014 12:01 PM
Subject: Pietenpol-List: Re: Varnish
Thanks.
Harv, 485PB
I was wondering if anyone made some sort of varnish filled 'bath' or container
into which a rib is placed and removed to dry, instead of brushing.
http://forums.matronics.com/viewtopic.php?p=432568#432568
I've seen several photos where the outboard sections of the center section end
ribs and (inboard) wing end ribs are covered with a full size gusset; the Hatz
Classic does it that way. I don't see that on my plans, so wondering if I missed
it or that's just become the norm.
http://forums.matronics.com/viewtopic.php?p=432569#432569
John,
I believe it's good practice to thin the first coat about 50% so you get better
penetration into the wood...I just brushed mine and did a little sanding between
coats. Yes, it's a pain and takes a long time which is what scratch-building
is all about!
John F.
>From: Pocono John <tinmotion(at)yahoo.com>
>Sent: Oct 30, 2014 1:36 PM
>To: pietenpol-list(at)matronics.com
>John
>Read this topic online here:
Airplane Type: Pietenpol Aircamper
Your name: Gary Boothe
Home town: Plumas Lake, CA
Year finished: 2012
Materials painted: Dacron with Kelly Moore
Primer used: Kelly Moore
Color Paint used: Tan & Olive, custom matched
Notes on your finish: Hand brushed
and photo(s):
Thanks, Malcolm!!
Gary Boothe
NX308MB
Sent: Wednesday, October 29, 2014 3:37 PM
Subject: Pietenpol-List: Request for Latex Paint Projects
Hi All,
http://wienerdogaero.com/TitanTornado.php.
painted airplane and would be willing to share you info, would you
please send me:
Airplane Type:
Your name:
Home town:
Year finished:
Materials painted:
Primer used:
Color Paint used:
and photo(s):
paint,
Malcolm Morrison
2nd BFR in my Piet. Word of advice: Make sure your CFI knows that you are
flipping ON the smoke switch.
Gary Boothe
NX308MB
I am finishing up my rudder and stab. I like the simple Ray Allen Trim Servo. Install
it in the elevator just like you would a RC Servo and push rod. For power
if I do not have a starter battery, I will power trim system with a lipo battery
along with my hand-held and GPS.
(On the same subject of controls) I have looked at the geometry of the elevator
system and it does not work out. Do the control cables sag as you change stick
position. If you move the control stick forward 15degs. and back 15 degs., the
cable push and pull is not even. This is because the cable on the back stick
connection comes under the 2" pulley, and the front cable goes over the top
of the pulley. The cables from the bell crank to the elevator do not work out.
they hit the front of the horizontal stabilizer and sag. What can be done to
fix this? Is it something to worry about. The bell crank on the original plans
under controls calls for the bearing to be 9" off the bottom. On the extended
fuse update 7-1/8". In another area it calls out 7". The lower it is the more
it rubs.
Scott
http://forums.matronics.com/viewtopic.php?p=432578#432578
http://forums.matronics.com//files/cable_movement_elevator_controls_573.pdf
I assume he jumped. Where there's smoke, there's fire? Were you able to get his
signature in your log book before he croaked? :)
Scott Liefeld
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
http://forums.matronics.com/viewtopic.php?p=432579#432579
From: | "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov> |
Too funny Gary!!! You alarmed him a bit did you? I'll bet once he k
new it was intentional he liked it.
Smoke on!!!
Mike C.
Ohio
PS-well......did he pass you????? :))))
From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis
t-server(at)matronics.com] On Behalf Of Gary Boothe
Sent: Thursday, October 30, 2014 4:20 PM
Subject: Pietenpol-List: BFR
Gary Boothe
NX308MB
Oscar,
I already have you site linked on my Latex History page http://wienerdogaero.com/LatexHistory.php. You have some great information. Thanks for making it available.
I'm linking the projects off of a "Showcase" page. http://wienerdogaero.com/Showcase.php
Enjoy,
Malcolm Morrison
Wiener Dog Aero
----- Original Message -----
Sent: Wednesday, October 29, 2014 8:42:18 PM
Subject: Pietenpol-List: Re: Request for Latex Paint Projects
Malcolm;
Oscar Zuniga
Medford, OR
A75 power
He was laughing about it by the time we got down...:-)
Gary Boothe
NX308MB
AircamperN11MS
Sent: Thursday, October 30, 2014 1:45 PM
Subject: Pietenpol-List: Re: BFR
get his signature in your log book before he croaked? :)
Scott Liefeld
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
John I sprayed mine 50% first coat and 100% for additional coats...
Jack Textor
> On Oct 30, 2014, at 2:35 PM, John Franklin wrote:
> John,
is all about!
> John F.
>> John
Thank you Jack and John. Finally have rib jig done and gussets/sticks cut, so about
to make ribs and then I'll varnish them.
http://forums.matronics.com/viewtopic.php?p=432591#432591
From: | Scott Knowlton <flyingscott_k(at)hotmail.com> |
I used a nautical product called Epiphanes on my gear legs with very good re
sults. No experience with UV or wear and tear yet but sure looks nice. It's m
eant for canoes and kayaks so I expect it should be quite resilient.
Scott K.
> Sent from my iPad
> Jack Textor
>> John,
etter penetration into the wood...I just brushed mine and did a little sandi
ng between coats. Yes, it's a pain and takes a long time which is what scra
tch-building is all about!
>> John F.
tainer into which a rib is placed and removed to dry, instead of brushing.
>>> John
He was probably wishing he had a parachute. It would be fun to see how fast
he could get out of a Piet.
Cheers, Jim
=C2-
Subject: | Corvair College 32, 27 February - 1 March 2015 |
From: | "kevinpurtee" <kevin.purtee(at)us.army.mil> |
That time of year again. We'll hold CC32 in San Marcos, TX.
Here's the facebook page with information:
https://www.facebook.com/pages/Corvair-College-32-27-Feb-1-Mar-15/320305497999282
I'll let you know when the registration website is up.
Kevin "Axel" Purtee
Rebuilding NX899KP
Austin/San Marcos, TX
http://forums.matronics.com/viewtopic.php?p=432594#432594
From: | "Douwe Blumberg" <douweblumberg(at)earthlink.net> |
Subject: | Ray Allen electric trim servo |
I installed a Ray Allen servo in the elevator under an inspection cover.
The actuator rod exists the bottom and controls an approximately 10" section
of 1" extruded aluminum piano hinge.
Works great, lightweight, simple, unobtrusive and there's just a hidden
switch in the cockpit.
Douwe
From: | Yahoo! Account Service <skipgadd(at)earthlink.net> |
Subject: | Re: advice on trim mechanism now elevator cables |
Scott,
If you just hook up the stick to bell crank the cables will ether be too tight
or too slack. The weight of the elevator when it is hooked to the bell crank will
take up the slack.
As far as the cable hitting the horz stab, just glue a piece of leather in that
place, and don't worry about it.
Skip
>From: namrednos <namrednos(at)yahoo.com>
the cable push and pull is not even. This is because the cable on the back stick
it rubs.
>Scott
Subject: | Re: Ray Allen electric trim servo |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Wonder what the eye bolt on the top of the tail is for???
Jack Textor
West Des Moines, IA
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff
Boatright
Sent: Wednesday, October 29, 2014 8:16 PM
Subject: Pietenpol-List: Re: advice on trim mechanism
Aviation Museum in San Carlos CA yesterday. The pulleys seem to complicate
things and I have no idea what the top of the trim tab looked like or the
cockpit controls as the airplane was about 15 feet over my head.
Here's the trim tab:
I know this is a little off post, but this is a flight simulator our EAA
Chapter just finished. This pic is in my shop and was before the decals
were applied. We used Sherwin Williams latex primer and finish paint. We
also used a short knap roller so we could get a flat
=9Cmilitary=9D look. Found that if you =9Cgo
over=9D the wet paint a second time, it creates a very flat look.
See the windshield in the picture, it has a fuzzy look, but for our
application, that=99s great. So apply one coat and let it get dry
before applying another one if you want a glossy finish.
This was our first attempt at latex, but after it turned out so good, I
don=99t think it will be our last.
Barry
NX973BP
Sent: Wednesday, October 29, 2014 6:37 PM
Hi All,
please send me:
Airplane Type:
Your name:
Home town:
Year finished:
Materials painted:
Primer used:
Color Paint used:
and photo(s):
paint,
Malcolm Morrison
Hi Steve
I can't answer why we have to fit jury straps at all let alone just one, I agree
they look wrong! I guess there is a good reason connected with the Jim Wills
design wing we use here though looking at photos of G-ADRA which has a solid
Bernie Pietenpol spar that has jury struts also, very confusing.
More weight to carry with these as well as image.
English Johnny
The only way is UP
http://forums.matronics.com/viewtopic.php?p=432612#432612
Subject: | PLEASE READ - Matronics Email List Fund Raiser During |
November!
Dear Listers,
Each November I hold a PBS-like fund raiser to support the continued operation
and upgrade of the Email List and Fourm Services at Matronics. It's solely through
the Contributions of List members (you) that these Matronics Lists are possible.
You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements.
During the month of November I will be sending out List messages every couple of
days reminding everyone that the Fund Raiser is underway. I ask for your patience
and understanding during the Fund Raiser and throughout these regular messages.
The Fund Raiser is only financial support mechanism I have to pay all
of the bills associated with running these lists. YOUR personal Contribution
counts!
This year we have a really HUGE and TERRIFIC line up of free gifts to go along
with the various Contribution levels. In fact, there are over 30 different gifts
to choose from - more than we've ever had before! There's something for everyone,
to be sure. Most all of these gifts have been provided by some of the
vary members and vendors that you'll find on the Matronics Lists and they have
been either donated or provided at substantially discounted rates.
This year, these generous members include:
Andy Gold of the Builder's Bookstore http://www.buildersbooks.com
Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com
Corbin Glowacki of My Pilot Store http://www.mypilotstore.com
George Race of Race Consulting http://www.mrrace.com/
Jon Croke of HomebuiltHELP http://www.homebuilthelp.com
These are very generous guys and I encourage you to visit their respective web
sites. Each one offers a unique and excellent aviation-related product line.
I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous
support of the Lists again this year!!
Please make your List Contribution using any one of three secure methods including
using a credit card, PayPal, or by personal check. All three methods afford
you the opportunity to select one of this year's free gifts with a qualifying
Contribution amount!!
To make your Contribution, please visit the secure web site:
I would like to thank everyone in advance for their generous financial AND moral
support over the years!
Thank you!
RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot
im painting my heath parasol with latex. drop me a note direct at JNL96@ya
hoo.com=0A=0A. =0A=0A=0AOn Friday, October 31, 2014 10:14 AM, Barry Davis <
bed(at)mindspring.com> wrote:=0A =0A=0A=0AI know this is a little off post, b
ut this is a flight simulator our EAA Chapter just finished. This pic is in
my shop and was before the decals were applied. We used Sherwin Williams l
atex primer and finish paint. We also used a short knap roller so we could
get a flat =9Cmilitary=9D look. Found that if you =9Cgo o
ver=9D the wet paint a second time, it creates a very flat look. See
the windshield in the picture, it has a fuzzy look, but for our application
, that=99s great. So apply one coat and let it get dry before applyi
ng another one if you want a glossy finish.=0AThis was our first attempt at
latex, but after it turned out so good, I don=99t think it will be o
ur last.=0ABarry=0ANX973BP=0A =0AFrom:owner-pietenpol-list-server@matronics
.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of glider
x5(at)comcast.net=0ASent: Wednesday, October 29, 2014 6:37 PM=0ATo: Pietenpol
=0ASubject: Pietenpol-List: Request for Latex Paint Projects=0A =0AHi All,
=0A =0AI would like to update the Wiener Dog Aero website with info on your
/wienerdogaero.com/TitanTornado.php.=0ANow I would like to add more pages w
ith your info. If you have a Latex painted airplane and would be willing to
share you info, would you please send me:=0A =0AAirplane Type:=0AYour name
:=0AHome town:=0AYear finished:=0AMaterials painted:=0APrimer used:=0AColor
Paint used:=0Awebsite if you have one:=0ANotes on your finish:=0Aand photo
(s):=0A =0AI'm hoping that this will help us all learn more about using Lat
ex paint,=0A =0AThanks=0AMalcolm Morrison=0Ahttp://www.wienerdogaero.com/
=0Agliderx5@comcast.net=0A =0A =0Ahttp://www.matronics.com/Navigator?Pieten
pol-List=0Ahttp://forums.matronics.com=0Ahttp://www.matronics.com/contribut
ion
Subject: | Larger Pietenpol Drawings |
I bought the complete set of plans for the Aircamper because there a so many excellent
examples of good looking completed projects. I then realized my large
body size, 260 and 6' 3", would not easily fit this aircraft.
I've heard tales about the builder plans having been increased to provide a larger
cockpit and more lift. I cannot find any source to confirm these stories.
Can somebody help me with this problem?
Todd
Subject: | Re: Larger Pietenpol Drawings |
From: | John Fastnaught <fastnaught(at)windstream.net> |
Todd,
My fuselage is 2" wider and 3" deeper from plans. I'm 6' 4" and fit in it reasonably
comfortablely. I've sat in it lots but haven't flown yet so jury is still
out, sort of.
Good luck on your project.
Jack
excellent examples of good looking completed projects. I then realized my large
> Todd
Subject: | Please Make A Contribution To Support Your Lists |
Dear Listers,
There is no advertising income to support the Matronics Email Lists and Forums.
The operation is supported 100% by your personal Contributions during the November
Fund
Raiser.
Please make your Contribution today to support the continued operation and upgrade
of these services. You can pick up a really nice gift for making your Contribution
too!
You may use a Credit Card or Paypal at the Matronics Contribution Site here:
or, you can send a personal check to the following address:
Matronics / Matt Dralle
581 Jeannie Way
Livermore, CA 94550
Thank you in advance for your generous support!
Matronics Email List and Forum Administrator
Photos, please. Thanks!
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=432805#432805
I have a new movie up in which I'm testing a trim system comprised of a bungee
cord and a clothesline tightener:
https://www.youtube.com/watch?v=xfUMSuEMEwc
The movie doesn't show the trim system (I will post pictures later if it really
works out). What the movie shows is that the system will hold my Piet right at
55 mph from abeam the numbers to roll out, with no input from me (other than
a short shot of throttle to clear the fence!). This was a good thing because
the sun was in my eyes and I had very little sight down the runway. The trim system
was sort of "land-o-matic"
So, my Piet is fairly easily trimmed for downwind-base-final-landing.
I played around with it at altitude, and even if I don't use the tightener "valve"
to release the bungee, I can still power up as though to do a go round. It
does require a hefty amount of forward pressure to overcome the bungee, though.
Obviously the idea is to pull the tightener valve to relieve bungee tension
when it's not needed.
I also used the system to play around in slow flight, and spent some time doing
30 degree banked lazy eights and 360s at 45-50 mph. Rock steady (though this
was in the evening, so there were no up/downdrafts and little wind).
The tightener was cheap (under $5 from Ace Hardware) and looks like this:
http://farm8.staticflickr.com/7131/7559033132_e9231e5594.jpg
Imagine the line on the left being a bungee cord hooking to the rear of the control
stick torque tube. On the right, the tightener U-ring is attached to the
control stick just below the control stick hand grip instead of to the eyebolt
in the photo. If you want to trim for "up", pull the bungee cord that sticks
out of the tightener valve. This stretches the bungee and locks it into that length.
The bungee tension holds the stick back. If you want to release that trim,
pull on the valve (it's mouth is shaped like a trumpet or trombone bell).
It's clunky to use right now, so I may optimize it a bit. However, even as it is,
it's meets my main goal of trimming for the pattern.
http://forums.matronics.com/viewtopic.php?p=432827#432827
I would be interested in seeing photos and or drawings too
> On Oct 31, 2014, at 8:37 AM, "Boatright, Jeffrey" wrote:
> Hi Douwe,
> What is the servo base fastened to? Did you glue in a plate or something? A
ny photos of the installation.
> Thanks,
> Jeff
> Jeffrey H. Boatright, PhD, FARVO
> Professor of Ophthalmology
> Emory University School of Medicine
> From: Douwe Blumberg <douweblumberg(at)earthlink.net>
> Reply-To: "pietenpol-list(at)matronics.com"
> Date: Friday, October 31, 2014 at 8:08 AM
> Subject: Pietenpol-List: Ray Allen electric trim servo
> I installed a Ray Allen servo in the elevator under an inspection cover. T
he actuator rod exists the bottom and controls an approximately 10=C3=A2=82
=AC=C2=9D section of 1=C3=A2=82=AC=C2=9D extruded aluminum piano hinge.
> Works great, lightweight, simple, unobtrusive and there=C3=A2=82=AC=84
=A2s just a hidden switch in the cockpit.
> Douwe
> This e-mail message (including any attachments) is for the sole use of
> the intended recipient(s) and may contain confidential and privileged
> information. If the reader of this message is not the intended
> recipient, you are hereby notified that any dissemination, distribution
> or copying of this message (including any attachments) is strictly
> prohibited.
> If you have received this message in error, please contact
> the sender by reply e-mail message and destroy all copies of the
> original message (including attachments).
> ky=C2=B7=C3=A8=C5=BE=C3=9B"=C3=8D=C3=AD=C5=93=C2=A2Z+=C3=93M4=C3=93G=C3=9A
q=C3=A7(=C2=BA=C2=B8=C5=BE=C2=AEw=C2=B0r=B9=C2=AB=B0=C3=C3=93
=C3=A3=C3=A2z=C3=97=C2=A7=C2=B0K=C5-=C3=8BD=84=A2=C2=A8
=C2=A5=16=C5-=C3=AE=84=A2K=1E=C2=B6=17=C5=92j=C3=9A=C3=A8=C5=BE',.+-=15
=C3=C2=AD=C2=BA=C2=B7=C2=AC5=C2=AB=C3=A2=C2=81=C2=ABh=C2=AE=C3=9A=1B=C2=AE
=C5=92,z=C3=98^=84=A2=C2=A9=C3=B2.+-=C2=BA=C3=98=C2=A5=C5-=C3=98=C5=BE=C2
=B2=C3=8B=C5=93=C2=AB=0B=C5-=C3=8BT=C5=B8=C3=B4=C2=AEn=C3=87+=C5-
=BAb=C2=A2p+r=18=C2=AFy'=C5=A1=C2=AD=C3=88C=C2=A3 =C3=A5=C2=A1=C2=A7{
=C2=AC=C2=81=C2=AE=C5=92,x(Z=C2=B4P=10>=1A-=C2=A2=C3=88Z=C2=AD=C3=C2=A7v
k=C5=93-k=C5=93-j+y=C2=A8ky=C3=B8m=C2=B6=C5=B8=C3=C3=83=0C
&j=C3=9A=C3=A8=C5=BE',r=B0=C25=C2=AB=C3=A2=C2=81=C2=ABh=C2=AC=C3=B8
=C5=BE=C2=B5=C3=A9=C3=A9=C2=A2R=C3=A2=C2=B2=C3=98m=C2=B6=C5=B8=C3=C3=83=0C
=C5=BE=C2=B5=C3=A9=C3=A9=C2=A2R=C3=A2=C2=B2=C3=9F=C3=9A0=04=C3=918=C3=92=02I
a=01=14=C3=A4T1$=C5=A1=84=A2=C3=A8+y=C2=AB\=C2=A2{^=C5=BE=C3'=C2=A5=C2=B2
-=C2=AFj)ZnW=C2=AF=B0=C2=ABayg=BA=16=C5-=C3=AE=C5=A1=C3
=86=C2=A1=C2=AD=C3=A7=C3=A1=C2=B6=C3=9A=7F=C3=BD=C3=BA+=C2=BAk&j=C3=9A=C3=A8
=C5=BE',r=B0=C2=A1=C2=B6=C3=9A=7F=C3=BD=C3=BA+=C2=BAk&j=C3=9A=C3=A8=C5
=BE',r=B0=C2h=C2=B8=C2=AC=C2=B4*'=C2=B6=C2=B8=BA=C2=BA=C3=98=C2
=A8=C2=9Dg=BAJ+^N=16=C2=A7=9C*.~=C5-=C3=B2=C2=A2=C3=C3-zw
=C2=AB=C2=A2=C3=AB,=C2=BA=C5=A1h=C2=AE=C3=93=1A=C2=B6=C3=90=C3=ABjY^.+-=01=C3
=99=C2=A2=C2=9D=C2=A8ky=C3=B8m=C2=B6=C5=B8=C3=C3=83=0C&j=C3=9A=C3=A8=C5=BE
',r=B0=C2r=B0=C3=AD=C2=AE&=C3=AE=C2=B6*'-=C3=9Bi=C3
=C3=BC0=C3=82f=C2=AD=C2=AE=B0=C3=A2r=C3=87(=BA=C3=B7(=C5=BE=C3=9A
=C3=A2n=C3=ABb=C2=A2=7F=C3=9A=C3=BD=C2=C3=9F=C2=A2{=7F=C2=C2=B7=C2n
=A1r=C3=BE=1Bf
Jeff;
This is a very interesting development. By all means, keep fiddling with it to
see if it can be made handier to use. I know I would be interested in it, because
(for example) when I fly with the tank topped off (16 gallons in the nose),
I have to hold back stick for the first hour or so till fuel burns off. It
would be handy to trim for a more neutral stick, regardless of whether or not
it was handy enough to use for trimming for approach.
I think 55-57 is the sweet spot for approach speed in smooth air in most Piets,
but 2 or 3 MPH either side of that can make a pretty significant difference in
how the approach goes. It's good to see the number that works for your Land-O-Matic
approach.
Last thing: watch out for the Hun when you're vulnerable like you were on that
approach (sun in your eyes). He'll come down right at you from high overhead
with guns blazing and you won't see him till it's too late and you hear bullets
zipping through the wood and fabric ;o)
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=432835#432835
There aren't any plans in existence for a larger fuselage (unless the UK
plans show a larger fuse, in which case they're not available here
anyways.)
A fair number of people have enlarged the fuse for the very reason you
state, but they are doing on their own. It's more complicated than it
sounds because once you change one dimensions, ten others are effected, but
it can certainly be done if your heart is set on a Piet. You'll also want
to raise the wing a few inches.
Good luck,
Douwe
Subject: | Coming Soon - The List of Contributors - Please Make A |
Contribution Today!
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone
that so generously made a Contribution to support the Lists. Its my way
of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
Please take a moment and assure that your name is on that List of Contributors
(LOC)! As a number of members have pointed out over the years, the List seems
at least as valuable a building / entertainment tool as your typical magazine
subscription!
Assure that your name is on this year's LOC! Show others that you appreciate the
Lists. Making a Contribution to support the Lists is fast and easy using your
Credit card or Paypal on the Secure Web Site:
or by dropping a personal check in the mail to:
Matt Dralle / Matronics
581 Jeannie Way
Livermore CA 94550
I would like to thank everyone that has so generously made a Contribution thus
far in this year's List Fund Raiser! Remember that its YOUR support that keeps
these Lists going and improving! Don't forget to include a little comment about
how the Lists have helped you!
Best regards,
Tried to attach a zipped file but didn=99t work, here are some
shots
Jack Textor
West Des Moines, IA
_____
Amsafetyc
Sent: Tuesday, November 04, 2014 11:30 AM
Subject: Re: Pietenpol-List: Ray Allen electric trim servo
wrote:
Hi Douwe,
something? Any photos of the installation.
Jeff
10=C3=A2=82=AC=C2=9D section of 1=C3=A2=82=AC=C2=9D extruded
there=C3=A2=82=AC=84=A2s just a hidden switch in the cockpit.
Douwe
_____
prohibited.
=93=C3=A3=C3=A2z=C3=97=C2=A7=C2=B0K=C5-=C3=8BD=84=A2
=C2=A8=C2=A5=C5-=C3=AE=84=A2K=91=C2=B6=C5=92j=C3=9A=C3=A8=C5=BE
',.+-=15=C3=C2=AD=C2=BA=C2=B7=C2=AC5=C2=AB=C3=A2=C2=81=C2=ABh=C2=AE=C3
=9A=C2=AE=C5=92,z=C3=98^=84=A2=C2=A9=C3=B2.+-=C2=BA=C3=98=C2=A5=C5-=C3
=98=C5=BE=C2=B2=C3=8B=C5=93=C2=AB
=C5-=C3=8BT=C5=B8=C3=B4=C2=AEn=C3=87+=C5-=BAb=C2=A2p+r=C2=AFy'=C5
=C2=AC=C2=81=C2=AE=C5=92,x(Z=C2=B4P>-=C2=A2=C3=88Z=C2=AD=C3=C2=A7vk=C5
=B8=C5=BE=C2=B5=C3=A9=C3=A9=C2=A2R=C3=A2=C2=B2=C3=98m=C2=B6=C5=B8=C3=C3
=83
=B8=C5=BE=C2=B5=C3=A9=C3=A9=C2=A2R=C3=A2=C2=B2=C3=9F=C3=9A0
_____
=C3=918=C3=92[1]Ia=14=C3=A4T1$=C5=A1=84=A2=C3=A8+y=C2=AB\=C2=A2{^=C5=BE
=C3'=C2=A5=C2=B2-=C2=AFj)ZnW=C2=AF=B0=C2=ABayg=BA=C5
-=C3=AE=C5=A1=C3=86=C2=A1=C2=AD=C3=A7=C3=A1=C2=B6=C3=9A=7F=C3=BD=C3=BA+
=C2=BAk&j=C3=9A=C3=A8=C5=BE',r=B0=C2=A1=C2=B6=C3=9A=7F=C3=BD=C3=BA+
=C2=BAk&j=C3=9A=C3=A8=C5=BE',r=B0=C2h=C2=B8=C2=AC=C2=B4*'=C2=B6=C2
=B8=BA=C2=BA=C3=98=C2=A8=C2=9Dg=BAJ+^N=C2=A7=9C*.~=C5-
=C3=B2=C2=A2=C3=C3-zw=C2=AB=C2=A2=C3=AB,=C2=BA=C5=A1h=C2=AE=C3=93=C2
=B6=C3=90=C3=ABjY^.+-=C3=99=C2=A2=C2=9D=C2=A8ky=C3=B8m=C2=B6=C5=B8=C3=C3
=83
&j=C3=9A=C3=A8=C5=BE',r=B0=C2r=B0=C3=AD=C2=AE&=C3=AE=C2=B6
*'-=C3=9Bi=C3=C3=BC0=C3=82f=C2=AD=C2=AE=B0=C3=A2r=C3=87(
=BA=C3=B7(=C5=BE=C3=9A=C3=A2n=C3=ABb=C2=A2=7F=C3=9A=C3=BD=C2=C3=9F
=C2=A2{=7F=C2=C2=B7=C2n=A1r=C3=BEf
TW9yZeKApg0KDQogDQoNCkphY2sgVGV4dG9yIA0KV2VzdCBEZXMgTW9pbmVzLCBJQSANCg0KIA0K
DQogIF9fX19fICANCg0KRnJvbTogb3duZXItcGlldGVucG9sLWxpc3Qtc2VydmVyQG1hdHJvbmlj
cy5jb20gW21haWx0bzpvd25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0g
T24gQmVoYWxmIE9mIEphY2sNClNlbnQ6IFdlZG5lc2RheSwgTm92ZW1iZXIgMDUsIDIwMTQgNjoy
MSBBTQ0KVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJFOiBQaWV0
ZW5wb2wtTGlzdDogUmF5IEFsbGVuIGVsZWN0cmljIHRyaW0gc2Vydm8NCg0KIA0KDQpUcmllZCB0
byBhdHRhY2ggYSB6aXBwZWQgZmlsZSBidXQgZGlkbuKAmXQgd29yaywgaGVyZSBhcmUgc29tZSBz
aG90c+KApg0KDQogDQoNCiANCg0KIA0KDQpKYWNrIFRleHRvciANCldlc3QgRGVzIE1vaW5lcywg
SUEgDQoNCiANCg0KICBfX19fXyAgDQoNCkZyb206IG93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZl
ckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcGlldGVucG9sLWxpc3Qtc2VydmVyQG1hdHJv
bmljcy5jb21dIE9uIEJlaGFsZiBPZiBBbXNhZmV0eWMNClNlbnQ6IFR1ZXNkYXksIE5vdmVtYmVy
IDA0LCAyMDE0IDExOjMwIEFNDQpUbzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3Vi
amVjdDogUmU6IFBpZXRlbnBvbC1MaXN0OiBSYXkgQWxsZW4gZWxlY3RyaWMgdHJpbSBzZXJ2bw0K
DQogDQoNCkkgd291bGQgYmUgaW50ZXJlc3RlZCBpbiBzZWVpbmcgcGhvdG9zIGFuZCBvciBkcmF3
aW5ncyB0b28NCg0KIA0KDQpKb2huDQoNClNlbnQgZnJvbSBteSBpUGhvbmUNCg0KDQpPbiBPY3Qg
MzEsIDIwMTQsIGF0IDg6MzcgQU0sICJCb2F0cmlnaHQsIEplZmZyZXkiIDxqZWZmYm9hdHJpZ2h0
QGVtb3J5LmVkdT4gd3JvdGU6DQoNCkhpIERvdXdlLA0KDQogDQoNCldoYXQgaXMgdGhlIHNlcnZv
IGJhc2UgZmFzdGVuZWQgdG8/IERpZCB5b3UgZ2x1ZSBpbiBhIHBsYXRlIG9yIHNvbWV0aGluZz8g
QW55IHBob3RvcyBvZiB0aGUgaW5zdGFsbGF0aW9uLg0KDQogDQoNClRoYW5rcywNCg0KIA0KDQpK
ZWZmDQoNCiANCg0KLS0gDQoNCkplZmZyZXkgSC4gQm9hdHJpZ2h0LCBQaEQsIEZBUlZPDQoNClBy
b2Zlc3NvciBvZiBPcGh0aGFsbW9sb2d5DQoNCkVtb3J5IFVuaXZlcnNpdHkgU2Nob29sIG9mIE1l
ZGljaW5lDQoNCiANCg0KRnJvbTogRG91d2UgQmx1bWJlcmcgPGRvdXdlYmx1bWJlcmdAZWFydGhs
aW5rLm5ldD4NClJlcGx5LVRvOiAicGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbSIgPHBpZXRl
bnBvbC1saXN0QG1hdHJvbmljcy5jb20+DQpEYXRlOiBGcmlkYXksIE9jdG9iZXIgMzEsIDIwMTQg
YXQgODowOCBBTQ0KVG86ICJwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tIiA8cGlldGVucG9s
LWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IFBpZXRlbnBvbC1MaXN0OiBSYXkgQWxsZW4g
ZWxlY3RyaWMgdHJpbSBzZXJ2bw0KDQogDQoNCkkgaW5zdGFsbGVkIGEgUmF5IEFsbGVuIHNlcnZv
IGluIHRoZSBlbGV2YXRvciB1bmRlciBhbiBpbnNwZWN0aW9uIGNvdmVyLiAgVGhlIGFjdHVhdG9y
IHJvZCBleGlzdHMgdGhlIGJvdHRvbSBhbmQgY29udHJvbHMgYW4gYXBwcm94aW1hdGVseSAxMMOi
4oKswp0gc2VjdGlvbiBvZiAxw6LigqzCnSBleHRydWRlZCBhbHVtaW51bSBwaWFubyBoaW5nZS4N
Cg0KIA0KDQpXb3JrcyBncmVhdCwgbGlnaHR3ZWlnaHQsIHNpbXBsZSwgdW5vYnRydXNpdmUgYW5k
IHRoZXJlw6LigqzihKJzIGp1c3QgYSBoaWRkZW4gc3dpdGNoIGluIHRoZSBjb2NrcGl0Lg0KDQog
DQoNCkRvdXdlDQoNCiANCiANCg0KIA0KDQoNCiAgX19fX18gIA0KDQoNCg0KVGhpcyBlLW1haWwg
bnRzKS4NCmt5wrfDqMW+w5siw43DrcWTwqJaK8OTTTTDk0fDmnHDpyjCusK4xb7CrnfCsHLigLnC
q+KAsMOqw5PigKbDo8OiesOXwqfCpuKAsEvFoMOLROKEosKowqXFoMOu4oSiS+KAkcK2xZJqw5rD
qMW+JywuKy0Vw6bCrcK6wrfCrDXCq8OiwoHCq2jCrsOawq7Fkix6w5he4oSiwqnDsi4rLcK6w5jC
pcWgw5jFvsKyw4vFk+KApsKrDQrFoMOLVMW4w7TCrm7DhyvFoOKAumLConArcsKveSfFocKtw4hD
wqMgw6XCocKneyDCrMKBwq7Fkix4KFrCtFA+LcKiw4hawq3DpsKndmvFk+KAoGvFk+KAoGorecKo
a3nDuG3CtsW4w7/Dgw0KJmrDmsOoxb4nLHLigLDCvzXCq8OiwoHCq2jCrMO4xb7CtcOpw6nColLD
osKyw5htwrbFuMO/w4MNCiZqw5rDqMW+Jyxy4oCwwr81wqvDosKBwqtowqzDuMW+wrXDqcOpwqJS
w6LCssOfw5owIA0KDQoNCiAgX19fX18gIA0KDQoNCsOROMOSWzFdSWEUw6RUMSTFoeKEosOoK3nC
q1zContexb7DlsKlwrLigKDCr2opWm5Xwq/igLDCq2F5Z+KAusWgw67FocOGwqHCrcOnw6HCtsOa
f8O9w7orwrprJmrDmsOoxb4nLHLigLDCocK2w5p/w73DuivCumsmasOaw6jFvicscuKAsMK/aMK4
wqzCtConwrbCuOKAusK6w5jCqMKdZ+KAukorXk7Cp+KAnCoufsWgw7LCosOqw6B6d8KrwqLDqyzC
usWhaMKuw5PCtsOQw6tqWV4uKy3DmcKiwp3CqGt5w7htwrbFuMO/w4MNCiZqw5rDqMW+Jyxy4oCw
wr9y4oCww63CribDrsK2KifigKDDm2nDv8O8MMOCZsKtwq7igLDDonLDhyjigLrDtyjFvsOaw6Ju
w6tiwqJ/w5rDvcK/w5/Cont/wqbCt8K/buKAoXLDvmYNCg0KIA0KIA0KIA0Kd3d3LmJ1aWxkZXJz
Ym9va3MuY29tDQp3d3cubXlwaWxvdHN0b3JlLmNvbQ0KaHR0cDovL3d3dy5tYXRyb25pY3MuY29t
L05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdA0KIA0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t
DQogDQogDQo
DQogDQogDQo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Beautiful work, Jack!
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=432964#432964
Subject: | pietenpol project for sale |
i am selling my pietenpol project. this is a very nice project for someone to finish.
here are the details. tail complete, covered and painted, fuselage covered
and has two coats of poly brush, all controls, cables and tailwheel installed.
center section and fuel tank finished. right wing finished with controls
and hardware installed and ready for cover. long cabanes. engine cont 65 low time
less that 100 hours, very nice sench wooden prop. all instruments installed
motor mount fitted. landing gear finished and fitted with matco hydraulic brakes.
enough superflite fabric comes with the project to complete it. finally
the left wing is a little more than 50% finished. strut material included. this
project is exactly plans built with standard fuselage. its a bernie pietenpol
as he intended it to be. price is negotiable with a serious buyer. only serious
craftsmen call.. 817 578 1215..pics avaiable. thanks for reading this.
http://forums.matronics.com/viewtopic.php?p=432987#432987
Subject: | Vi Kapler style hinges |
Howdy, low 'n' slow fliers;
To all who were interested in the Kapler style cast aluminum tail hinges, thank
you for your patience. I recently received a batch of castings from the foundry
and they are quite good. With the small stock of castings that I got from
Vi when I bought his parts and tooling, I now have enough material to produce
about 30 sets of hinges (9 pairs). In the attached photo you can see what 269
pairs of the rough castings look like, but there are a few rejects among them
and I have yet to begin machining them to final shape (all by hand), which may
turn up a void or flaw in a couple more. The foundry and my supplier were
very good to me, so I can continue to offer them at what I think is a reasonable
price: $72 a set plus $3 shipping in the U.S., total of $75 for the nine pairs
of hinges that go in the tail group on an Air Camper. I've found out that
these hinges are nearly identical to those used on the W.A.R. replicas, so there
may be a wider market for them than I originally thought, but I'm not sure
of that yet. My first priority will be to supply Piet builders.
I am not ready to start taking orders yet, but I wanted to report that I do have
the raw stock to start putting hinges back in the supply pipeline as I get sets
finished and I hope to do that soon. Those who have already contacted me,
I have your names on the list. I appreciate it, and I hope to be of service
to builders if I can produce hinges equal to those that Vi has been supplying
for years. I will also be load-testing a random hinge to destruction and will
report on my findings when I'm done.
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power
http://forums.matronics.com/viewtopic.php?p=432989#432989
http://forums.matronics.com//files/hinge_small_787.jpg
Subject: | Re: Vi Kapler style hinges |
Good news! We exchanged emails about this earlier this year. If I'm not already
on your wait list, please add me (L. Harris, Tellico Plains, TN). Well done for
this valuable service.
Lorenzo
http://forums.matronics.com/viewtopic.php?p=432996#432996
Oscar,
You are a good man. Keep it up buddy.
Three Cheers for Oscar,
Scott Liefeld
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
http://forums.matronics.com/viewtopic.php?p=432999#432999
Subject: | A Great Film Showing Grassroots Aviation |
The EAA just posted the following short video on YouTube -
http://youtu.be/wvXAX0C2q5c
It is a short video based on a longer video that was released to all EAA chapters
this morning. It is a video by Brady Lane highlighting Corvair College last
November in Barnwell SC. Hats off to our very own P.F. Beck and his team for
hosting the Corvair College. They do an awesome job supporting everyone. The EAA
felt strong enough that this is a great example of grassroots aviation that
they made the film and seni it out.
Seeing some of our very own, like P.F., Dick Navratil and Bob Dewenter is great,
but seeing the camaraderie of the builders is the story. Seeing a grandson and
his grandfather hug as they watch their engine run on the test stand is just
not to be missed. No matter what aircraft you are building or what engine you
are using, if this video doesn't motivate you, then as they say, "you just ain't
right!"
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=433007#433007
Subject: | She DID IT in a Piet! |
Take a look at this young lady...
http://www.eaa.org/eaa/eaa-news-and-aviation-news/eaa/2014-11-06-student-now-a-pilot-thanks-to-gathering-flight-training-scholarship
Hope she's able to go all the way to space!
Tom Kreiner
http://forums.matronics.com/viewtopic.php?p=433013#433013
From: | Ray Krause <raykrause(at)frontiernet.net> |
Subject: | Re: She DID IT in a Piet! |
Tom,
My 17 year old grandson just soled this last Tuesday, but in our Aeronca. Too bad
my SkyScout was not ready! Now I have a good reason to get it finished. He
sure loves flying, hope he can stay focused on both school and flying...right
now flying is his passion. Hope it replaces girls for a while! He just got an
$88,000 scholarship to attend the University of Portland to study engineering.
He will be able to show me how to build the next PIET!
Ray Krause
Rigging the wings next week, then fabric work.
> Tom Kreiner
Subject: | Re: A Great Film Showing Grassroots Aviation |
Bravo, Bravo! Bravo Zulu to P. F. Beck and crew; William Wynne and his
supporting cast! The wife still talks about the ride P. F. gave her in
his Pietenpol!
EAA felt strong enough that this is a great example of grassroots aviation that
and his grandfather hug as they watch their engine run on the test stand is just
you are using, if this video doesn't motivate you, then as they say, "you just
ain't right!"
> Semper Fi,
> Terry Hand
> Athens, GA
Perfect timing, too. The College is once again convening in Barnwell this weekend!
Congratulations to all who were involved in the production of this great
video. Very inspiring. Also good luck to those who will be attending the College
this weekend!
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=433019#433019
Awesome - just great to see all the Piet folks and WW. I did not know the events
were so big. Very cool.....
Jake Schultz - curator,
Newport Way Air Museum (OK, it's just my home)
http://forums.matronics.com/viewtopic.php?p=433023#433023
Subject: | Please Make a Contribution to Support Your Lists... |
Dear Listers,
Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution
today to support the continued operation and upgrade of these great
List services!! Pick up a really nice free gift with your qualifying Contribution
too!
The Contribution Site is fast and easy:
581 Jeannie Way
Livermore CA 94551-0347
Thank you!
From: | Jim Markle <jim_markle(at)mindspring.com> |
Subject: | Rib stitching question |
2 1/2" spacing pulls the fabric up against the ribs in the under camber area on
the bottom of the wing. 3 1/2" spacing leaves a little gap between stitches.
Is it worth making that area 2 1/2" spacing to avoid that gap?
Sent from my smartphone.
Subject: | Re: Rib stitching question |
Pics of that rib stitching gap...not the best pics but will hopefully give you
an idea of the gap....anything to worry about?
http://forums.matronics.com/viewtopic.php?p=433111#433111
http://forums.matronics.com//files/image_667.jpg
http://forums.matronics.com//files/image_994.jpg
HI Ray,
Congratulations on your grandson's solo in the Champ. Glad to hear he=C2-
is going into engineering. He picked a good career choice for broad opport
unities within engineering.
=C2-
He will probably help you reeingineer the Piet!
Jim B.
Can you let me know when you start selling? I'll buy a set.
Thanks!
http://forums.matronics.com/viewtopic.php?p=433126#433126
From: | Steven Dortch <steven.d.dortch(at)gmail.com> |
Oscar, Put me on the list to buy. I don't need them now but would like a
set on the shelf.
Blue Skies,
Steve D
> thank you for your patience. I recently received a batch of castings from
> the foundry and they are quite good. With the small stock of castings that
> I got from Vi when I bought his parts and tooling, I now have enough
> material to produce about 30 sets of hinges (9 pairs). In the attached
> photo you can see what 269 pairs of the rough castings look like, but there
> are a few rejects among them and I have yet to begin machining them to
> final shape (all by hand), which may turn up a void or flaw in a couple
> more. The foundry and my supplier were very good to me, so I can continue
> to offer them at what I think is a reasonable price: $72 a set plus $3
> shipping in the U.S., total of $75 for the nine pairs of hinges that go in
> the tail group on an Air Camper. I've found out that these hinges are
> nearly identical to those used on the W.A.R. replicas, so there may be a
> wider market for them than I originally!
> thought, but I'm not sure of that yet. My first priority will be to
> do have the raw stock to start putting hinges back in the supply pipeline
> as I get sets finished and I hope to do that soon. Those who have already
> contacted me, I have your names on the list. I appreciate it, and I hope
> to be of service to builders if I can produce hinges equal to those that Vi
> has been supplying for years. I will also be load-testing a random hinge
> to destruction and will report on my findings when I'm done.
> Oscar Zuniga
> Medford, OR
> A75 power
Blue Skies,
Steve D
Aren't you using Stewart System glue? I glued my ribs to the fabric
prior to applying the reinforcement tapes and rib stitching.
Ben
Ben Charvet, PharmD
Staff Pharmacist
Parrish Medical center
Look at the rib stitching and hi-speed tape starting at 1:08 of this video. It's
a good reminder (to me, anyway), of how much force is pulling on that fabric,
which in turn is pulling on those stitches. Gentle climbing turn, under 70 mph:
https://www.youtube.com/watch?v=ZdcKXbX8eVw
I'd stitch closely (2.5" vs 3.5") and follow other instructions from the fabric
system manufacturer. This may be being overly cautious, but separation of fabric
from structure has occurred, and with deadly outcomes:
http://www.ntsb.gov/aviationquery/brief.aspx?ev_id 001207X03218&key=1
http://forums.matronics.com/viewtopic.php?p=433130#433130
Thanks, Jim. He's a good kid, willing to work. Not too common these days.
Ray
> On Nov 7, 2014, at 8:58 AM, Jim Boyer wrote:
> HI Ray,
> Congratulations on your grandson's solo in the Champ. Glad to hear he is g
oing into engineering. He picked a good career choice for broad opportunitie
> Cheers,
> Jim B.
3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3
D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
Should the lower portion of the wing be stitched BEFORE shrinking?
Ray Krause
Building SkyScout
Like many factors in building the answer is"it depends".
I used the PolyFiber process and in their process if I remember correctly (I
did this over 10 years ago), they had you glue the fabric to the ribs, then
heat shrink at 250 degrees, then rib stitch, then do the 300 and 350 degree
shrinks.
Read and FOLLOW the manual for whatever process you are using. If they
manual doesn't cover how to do undercambered wings, call their customer
support line and ask them. Use their resources, not someone on an email
list that may or may not be familiar with their process.
Good Luck!
Jack Phillips
NX899JP
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause
Sent: Friday, November 07, 2014 4:51 PM
Subject: Re: Pietenpol-List: Re: Rib stitching question
Ray Krause
Building SkyScout
you an idea of the gap....anything to worry about?
Thanks, Jack. Great advice on all points. I will be using the Stewart System and
will follow all their directions. I am still on schedule to start covering in
December. Looking forward to it.
Ray Krause
> shrinks.
> Good Luck!
> Jack Phillips
> NX899JP
> Ray Krause
> Building SkyScout
> Sent from my iPad
Subject: | A Great Day in Barnwell |
Just got home from being at Corvair College. I was only able to be there today
but it runs Friday through Sunday. The Pietenpol contingent was well represented.
-congrats to Chuck Campbell for running his engine.
-congrats to Keith Goff who got the last run of the day on his engine
-John Francis got much accomplished on his engine and is not too far off from running
his engine
-it was great to see Bob Dewenter volunteering his time to help fellow builders.
-Got to see two Southern gentlemen, P.F.Beck and Don Harper and their hospitality
-Tim Hansen working on his engine
-Bob Lester flew his Piet up from FL, yelling "I NEED COFFEE!" as he shut down.
(it was COLD in Barnwell in the morning!)
I will stop naming names as I know I will leave someone out. No offense if I did.
Best of all was William Wynne and Grace Wynne providing a setting for all types
of builders to make great progress on their projects. A great aviation weekend.
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=433191#433191
Subject: | Trombone bungee trim |
From: | "Jeff Boatright" <jeffboatright(at)emory.edu> |
Works well!
http://forums.matronics.com/viewtopic.php?p=433192#433192
Subject: | Re: Trombone bungee trim |
http://forums.matronics.com/viewtopic.php?p=433193#433193
http://forums.matronics.com//files/img_0415_108.jpg
Another photo
http://forums.matronics.com/viewtopic.php?p=433194#433194
http://forums.matronics.com//files/img_0418_125.jpg
Fourth photo
http://forums.matronics.com/viewtopic.php?p=433195#433195
http://forums.matronics.com//files/img_0422_109.jpg
Fifth photo
http://forums.matronics.com/viewtopic.php?p=433196#433196
http://forums.matronics.com//files/img_0434_177.jpg
Sorry, I was having trouble interacting with the Matronics site last night. Here's
the original message that the photos above are a follow-up to:
http://forums.matronics.com/viewtopic.php?p=433216#433216
From: | "Charles N. Campbell" <charlescampbell1924(at)gmail.com> |
I just returned from Corvair College #31 in Barnwell where the video was
made last year. I ran my Corvair engine for the first time Saturday
morning. Unless you have experienced the thrill of seeing and hearing the
engine that you built up with your bare hands you just can't imagine what
it felt like when William pushed the starter button the first time and the
engine roared to life. What a thrill. Tears came to my eyes -- I couldn't
help it. Everyone should build up an engine even if you are never going to
fly behind it. It's an experience you will never forget. Chuck
On Thu, Nov 6, 2014 at 4:57 PM, jarheadpilot82
wrote:
> jarheadpilot82(at)hotmail.com>
> chapters this morning. It is a video by Brady Lane highlighting Corvair
> College last November in Barnwell SC. Hats off to our very own P.F. Beck
> and his team for hosting the Corvair College. They do an awesome job
> supporting everyone. The EAA felt strong enough that this is a great
> example of grassroots aviation that they made the film and seni it out.
> great, but seeing the camaraderie of the builders is the story. Seeing a
> grandson and his grandfather hug as they watch their engine run on the test
> stand is just not to be missed. No matter what aircraft you are building or
> what engine you are using, if this video doesn't motivate you, then as they
> say, "you just ain't right!"
> Semper Fi,
> Terry Hand
> Athens, GA
Jim, I was thinking the same thing. I am considering gluing the fabric to
the ribs before tautening and rib stitching. What says the experts who
have already been down this road? Chuck
On Fri, Nov 7, 2014 at 7:27 AM, Jim Markle
> area on the bottom of the wing. 3 1/2" spacing leaves a little gap between
> stitches. Is it worth making that area 2 1/2" spacing to avoid that gap?
Well, it's simple alright! Seeing your handheld and radio stuff in the cockpit
reminds me of what a pain mine is. I've got to do something different, because
it's driving me nuts. Mine is a little Icom IC-A23 and what I do is clip it
to the map holder down by my right calf using the belt clip on the back of the
battery case. Well, that's fine until I pull the radio out to change frequencies.
If I'm not real careful, the battery case snaps off and my radio is dead.
Then I get to do the stick-between-my-knees shuffle, pull off one or both
gloves and hope they don't fly out, fumble around for the battery and clip,
get everything back together, power up the radio, and then pull the airplane out
of a screaming, diving left corkscrew spiral ;o) I've got to find my Bill
Rewey "handy details" and bend up one of his radio brackets to hold it up where
I can see it and get to the buttons easier.
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=433229#433229
The Air Camper worked its magic for me again yesterday. We've had some gray and
drizzly mornings lately, but it usually breaks up after lunch and we get a couple
of hours of sunshine. Gambling on that happening, I went out to the hangar
after lunch and prepared for flight. As I was preflighting, the sky was clearing
and by the time I was ready to roll the airplane out, it was beautiful
with calm winds and almost no traffic.
I had been correcting the camber on my axles, because it had been uneven from one side to the other and I had used washers to shim the axles out rather than the proper tapered shims. There are a couple of pictures of the shimming here: http://www.flysquirrel.net/piets/axle.html . I also replaced a tire and tube on one side, but everything was done and the airplane was ready to fly. So was I!
Interesting little 'chat' with the ground controller, as he said my call sign was
incorrect. "November Xray Four One Charlie Charlie", I repeated. "One Charlie
Charlie, Is that what's painted on your tail?" he asks. "Four One Charlie
Charlie, roger." That ended that little discussion, but I bet he went to find
out about that NX- tail number.
Beautiful day, smooth flight, on runup the RPM drop was textbook perfect on carb
heat and both mags, and off we went. I've finally started listening to you
pilots who suggest just letting it fly itself off. I'd always been taught to
hold forward stick to bring the tail up, hold it, then rotate when the airspeed
was good. Nahh... there is no need. Scout needs considerable forward stick
force to pick up the tail early, so yesterday instead of forcing it, I just
tried letting it do what it wanted and that worked great. We lifted off and climbed
out like the airplane knew what it was doing.
A very nice bit of sightseeing in the autumn air with autumn colors everywhere,
then some power on and power off stalls (non events), then back to the field.
I must say that the landing was the best that I have made in a very, very long
time. One of those where you roll out from base to final with the runway centerline
stripes just falling in perfect alignment with the center of the prop
and then not budging. Down the glideslope with out even stirring the stick,
down into ground effect, ease the stick back... back... back- and I was down
without even knowing when it happened.
This is why we fly Piets.
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=433230#433230
From: | "Chris Rusch" <rmdinfo(at)rmdbenders.com> |
Jack, we are on the same page, I did mine exactly like yours...
NX321LR
Now test flying!!
Mitsubishi Powered
http://forums.matronics.com/viewtopic.php?p=433233#433233
http://forums.matronics.com//files/image_475.jpg
it to the map holder down by my right calf using the belt clip on the back of
the battery case. Well, that's fine until I pull the radio out to change frequencies.
dead. Then I get to do the stick-between-my-knees shuffle, pull off one or both
out of a screaming, diving left corkscrew spiral ;o) I've got to find my Bill
I use Ram cell phone mounts. Not the cheapest, but I find they are versitile and
do not fail.
Put several more landings in yesterday and today using the very simple trim system.
About a dozen so far since installation. Rock solid at 55 mph from downwind
to base to final to landing. No doubt such a Rube Goldberg solution is not
to everyone's taste, but works for me. If problems arise I'll let you all know.
http://forums.matronics.com/viewtopic.php?p=433234#433234
Subject: | A List Contribution - It's Your Personal Squelch Button... |
There is an automatic "squelch button" of sorts for the Fund Raiser messages.
Here's how it works... As soon as a List member makes a Contribution through
the Matronics Fund Raiser web site, their email address is automatically added
to this year's Contributor List and they instantly cease to receive further Fund
Raiser messages for the rest of the month! Its just that simple! :-)
I really do appreciate each and every one of your individual Contributions to support
the Lists. It is your support that enables me to upgrade the hardware
and software that are required to run a List Site such as this one. It also goes
to pay for the commercial-grade Internet connection and to pay the huge electric
bill to keep the computer gear running and the air conditioner powered
on. I run all of the Matronics Email List and Forums sites here locally which
allows me to control and monitor every aspect of the system for the utmost in
reliably and performance. Your personal Contribution matters because, when combined
with other Listers such as yourself, it pays the bills to keep this site
up and running. I accept exactly ZERO advertising dollars for the Matronics
Lists sites. I can't stand the pop-up ads and all other commercials that are
so prevalent on the Internet these days and I particularly don't want to have
it on my Email List sites.
If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email
Lists, please make a Contribution to keep it that way!!
581 Jeannie Way
Livermore, CA 94550
Thank you!
[Note that there are certain circumstances where you might still see a Contribution
related message. For example, if someone replies to one of the messages,
when using the List Browse feature, or when accessing List message via the Forum.
The system keys on the given email address and since most of these are anonymous
public access methods, there is no simple way to filter them.]
Subject: | Re: Pietenpol-List Digest: 7 Msgs - 11/09/14 |
Seems like attaching the fabric to the ribs after the initial shrink is comm
on. I was able to work the Stewart Systems down through the fabric while us
ing weights to hold it down against the ribs. No more gaps between the stit
ches.
> On Nov 10, 2014, at 2:00 AM,
> Subject: Re: Pietenpol-List: Rib stitching question
> From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
en
> ________________________________ Message 4 ______________________________
_______
> Subject: Pietenpol-List: Re: Trombone bungee trim
> From: "taildrags" <taildrags(at)hotmail.com>
ckpit
cause
t
the
uencies.
ne out
here
> Oscar Zuniga
> Medford, OR
> A75 power
> ________________________________ Message 5 ______________________________
_______
> Subject: Pietenpol-List: Saturday flight
ay and
couple
r
learing
to fly. So was I!
ign was
arlie
ind
n carb
u
to
speed
ck
st
nd climbed
here,
ld.
ong
enterline
k,
wn
> Oscar Zuniga
> Medford, OR
> A75 power
> ________________________________ Message 6 ______________________________
_______
> Subject: Pietenpol-List: Re: Ray Allen electric trim servo
> From: "Chris Rusch" <rmdinfo(at)rmdbenders.com>
> NX321LR
> Now test flying!!
> Mitsubishi Powered
> ________________________________ Message 7 ______________________________
_______
> From: "Jeff Boatright" <jeffboatright(at)emory.edu>
ockpit
cause
of
requencies.
r both
ne
ill
here
le and
> do not fail.
m system.
d
now.
