RV-Archive.digest.vol-qg
December 12, 2004 - December 20, 2004
Wow, Dan, what a super web site. I hadn't visited it in a while and am
amazed at how it has grown. I have bookmarked this as "must-read".
Personally, I am also leaning toward polished, but am getting scared by
some of the posted horror stories. What I will probably do is fly it for
a while unpainted and unpolished and see just how bad it is. If
reflections are real bad, I will paint just enough to eliminate the
problem areas, then polish the rest.
I don't know if you are old enough to remember WW2 aircraft. These were
all unpainted due to the necessity of rapid production and to hold costs
down. They did, however, paint the top of the cowl from the wind screen
forward.
Jim Hasper - RV-7 just starting empennage (giving new meaning to the term
slow-build)
http://www.rvproject.com
From: | "LarryRobertHelming" <lhelming(at)sigecom.net> |
Just another perspective on painting: I've seen RVs painted both ways --
before assembly & flying and after assembly & already flown AND like Dan's
unpainted. It is a much easier job to paint it before assembly. You paint
in smaller parts and you can more easily do the job yourself rather than pay
out big bucks. With your own paint job, you use the saved money for your
first couple years of insurance payments (if you can even get insurance.)
And you get the pride in saying, I painted it myself just like I built it
myself. JMHO.
Almost done with 3XG. Going to airport next week.
Indiana Larry, RV7 TipUp "SunSeeker"
The sincerest satisfactions in life come in doing and not dodging duty;
in meeting and solving problems, in facing facts;
in flying a virgin plane never flown before.
- Richard L. Evans & Larry R Helming
----- Original Message -----
Subject: RV-List: Re: http://www.rvproject.com
> forward.
> > Bearings come out fairly easy, I didn't like how they fit though within
the
> TW assembly, so I made a spacer for inside, between the bearings much like
a
> stub shaft inside a preloaded steering drive axel commonly used in today's
> cars.
> This allows one to tighten the the tail wheel bolt enough for the bolt to
> not spin.
> But that all said, does anyone know of a valid criteria by which to
> determine of a tail wheel is worn out?
> W
In the case of my RV-3 that I bought with 180 hours on it.....
I could not stand the noise being megaphoned by the tail section. Spinning
the unloaded tailwheel by hand revealed it was very rough running and
wobbly. Really shot. No grease or residue found. Dry as a bone
Subject: | Re: Oil Cooler Location |
Dan,
Do you have any pix of your installation? I would like to see it
as I would think it would preclude baffle cracking. I am going to be
using a IO 360.
Jim
In a message dated 12/11/04 3:37:27 PM Central Standard Time,
tcervin(at)valkyrie.net writes:
> Has anybody been able to cool an RV with a firewall mounted cooler?
Yep- works great. I'll send ya some fotos
Mark
From: | "Aircraft Technical Book Company" <winterland(at)rkymtnhi.com> |
Subject: | fuel metering options |
I've got a stumble in rpm as I throttle up past around 1500 which seems to
be getting worse and does not respond to idle jet adjustments. I also no
longer see an rpm rise at idle cutoff which also doesn't respond to
adjustments. And I've got some play in the mixture control post where it
seats into the carb body.
Sooo... Its probably a good idea to consider having the 'ol MSA overhauled
at the next annual; which may present some options. Certainly a bolt-off /
bolt-on overhaul of the same carb will be cheapest and easiest. However if
there is to be a significant benefit to replacing it with an Ellison or
Airflow throttle body or an RSA injection system, this would be a good time
to make the switch.
So, for anyone whose replaced an MSA with something else - was it worth it?
What real life benefits did you see? Sustained inverted flight is not an
issue for me. And, since this is a VFR airplane that rarely travels in ice
prone conditions, that too becomes just a minor concern.
Considering the extra money and work of changing systems (new bracketry, new
hoses, new control cables, airbox alterations, etc...) I would want to see
some noticeable improvements in power or efficiency. Otherwise, I'll just
keep the MSA and not miss a 3-4 weeks of flying.
Any comments or suggestions?
Andy
In a message dated 12/12/04 11:35:18 AM US Eastern Standard Time,
rv9jim(at)juno.com writes:
> Dan,
> using a IO 360.
> Jim
Jim,
I'm sorry, I don't have at this time. The next time the cowl is off I'll get
some.
Dan Hopper
N766DH
RV-7A (Flying since July -- about 80 hours)
From: | "Alex Peterson" <alexpeterson(at)earthlink.net> |
> which seems to be getting worse and does not respond to idle
> jet adjustments. I also no longer see an rpm rise at idle
> cutoff which also doesn't respond to adjustments. And I've
> got some play in the mixture control post where it seats into
> the carb body.
> MSA overhauled at the next annual; which may present some
> options. Certainly a bolt-off / bolt-on overhaul of the same
> carb will be cheapest and easiest. However if there is to be
Andy, since you don't know what the problem is, why would you not ground it
until you can have the carb overhauled, or at least disassembled and
inspected?
Alex Peterson
RV6-A 561 hours
Maple Grove, MN
http://www.home.earthlink.net/~alexpeterson/
Hey out there,
I have just started to rivet together the rear spar for the horz. stab. The
rivets shown on the drawings aren't long enough to make a proper shop head,
however in the preview plans it specifically states that the rivet size
shown on the plan is correct. I have started to put in the -7 rivets instead
of the the -6 rivets in order to obtain a shop head that passes both rivet
spec test. Anybody run in the same problem and did you use the plan size
rivets or the next larger.
Paul
Subject: | Re: Wing fairing gap seal |
In a message dated 12/11/04 5:31:25 PM Central Standard Time,
stevea(at)svpal.org writes:
> 1. What should the fairing to fuselage gap be in order to hold the
> rubber seal in place without any adhesive? (I am not planning on using
> adhesive, unless the seal does not stay put in flight.)
Like another lister mentioned, put the seal on the edge of a part and apply
it to a perpendicular surface to achieve the desired radius, then measure.
Speaking from experience, I'd certainly make it narrower than you think you'll
need at first as it is easy to trim more of the fairing away but difficult to
add it back if too much is removed! My second fairings fit MUCH better (don't
ask!)
> 3. What is the easiest way to install the seal? Put the seal over the
> fairing and screw the fairing in place, or screw the fairing in place
> first and then slide the seal in. (Some previous posts on this. Most
> seem to install both at the same time.)
Tape the seal to the fairing every 4 or 5 inches (on the outside of course!)
then install it starting at the rear- cleco then screw like Dan C. sez. If
the seal gets tucked under in places slip a credit card between the seal and
skin and slide it past the tuck to lift the seal into position. No, this should
not debit your account, but you might wish to check anyway. If you want to
freak your friends, tell 'em you just have the wings taped on for the first
couple of flights til you're happy with the incidence angle (or just go ahead and
remove it if this makes your wife nervous...8-)
From The Possumworks in TN
Mark
Subject: | Re: Canopy Question |
In a message dated 12/11/04 7:09:27 PM Central Standard Time,
davercook(at)prodigy.net writes:
> Does the side skirts need any sort of weather-strip adhesive next to the
> Plexiglas for waterproofing and if so what did you use?
I used proseal 'cause I had some extra laying around, and as you know, it
takes days to cure, giving you plenty of time to work with it, clean it off
etc...... They sure don't leak!
Mark -6A tip-up, 133 hours
Subject: | 25 hour Phase One |
I have installed a Superior XP I0-360-M1B6 built by Bart at Aero Sport Power with
the new Hartzell blended airfoil prop. The DAR I plan to use for the inspection
has indicated that I will have to do a 40 hour phase one because the engine
is technically exprerimental. Has anyone been able to get a 25 hour phase
one with this or a similar combination? If so, some documentation I could use
to show my DAR would be helpful.
Steve
MEM
7QB
Subject: | Re: RV-List Digest: 33 Msgs - 12/11/04 |
Bravo Andrew!
On my IP ,Juno, I can opt to NOT send the message that I am
replying
to. Can the rest of us do the same?
Jim George
Subject: | Re: 25 hour Phase One |
My experience as well. According to my inspector......your engine (and mine)
is NOT a Lycoming....it's an 'Aero Sport Power LTD'. 40 hours....go have fun!
Curious.....what's the big hurry anyway? You can learn a LOT about yourself
and your RV in 40hrs.
Rick Gray in Ohio at the Buffalo Farm
http://groups.yahoo.com/group/OhioValleyRVators/
not archive do
with the new Hartzell blended airfoil prop. The DAR I plan to use for the
inspection has indicated that I will have to do a 40 hour phase one because the
engine is technically exprerimental. Has anyone been able to get a 25 hour
phase one with this or a similar combination? If so, some documentation I could
use to show my DAR would be helpful.
Steve
MEM
7QB
My DAR gave me 10 hours within 50 miles of my base airport and then the
remaining 30 hours anywhere in the state excluding some specific controlled
airspace. Try to get something like this in your Operation Limitations and
go have fun!
Jerry Calvert
RV 6 N296JC
Edmond Ok
Subject: Re: RV-List: 25 hour Phase One
mine)
fun!
yourself
> not archive do
Power
because the
hour
could
> Thanks
> Steve
> MEM
> 7QB
If you don't have a lycoming data plate on it, you're not likely to convince
the Feds that it's a Lycoming built under a TC. After all, van's
recommendation is for a Lycoming, not a "xyz....".
The 2nd thing is that prop probably doesn't have the AeroSport power engine
on it's type certificate either, which is what you actually need to prove to
the FAA - That you're using a Type Certificated Engine/Prop Combo. Put a
non-TC'd prop on a Lycoming and you're in the same boat.
Anyway, that extra 15 hrs. is a breeze. Think of it as another weekend or
two of flying!
Stein Bruch
RV6's, Minneapolis
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of
nyman(at)bellsouth.net
Subject: RV-List: 25 hour Phase One
the engine is technically exprerimental. Has anyone been able to get a 25
hour phase one with this or a similar combination? If so, some
documentation I could use to show my DAR would be helpful.
Steve
MEM
7QB
DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws;
s=s1024; d=yahoo.com;
b=WTsPU1dGFfYfe9Th4OuKdsdTr4DmdXq01JdYJKZc4IB2OSCa+JQSpQZ/u3LfzDbGpAVusvamTSbTrTGHFBxTiulMsXygrWeGpFoOVm6sQoWXmofTy/BcgyigYF6Gl+hEVydqdQUYINGG52Bd4z87jzUygnSfQFW8WzoXyek+8Zs;
Paul,
Consider all drawings and plans callout for a specific rivet length as a helpful
guideline and then use the correct length rivet for your application. Continue
to (correctly) rely on a rivet gauge to pass a go/no go spec test. The problem
you cite is certainly not unique to Van's drawings and on a personal note,
was routinely encountered by this retired aerospace worker while referring to
blueprint callouts .... building combat jets for a living.
Rick Galati
Hey out there,
Paul
Van's recommendation has nothing to do with whether you get a 25 or 40 hour
test period. One could use a Continental, a Franklin, or even a P&W and get
the 25 hour since they are certified.
Cy Galley
EAA Safety Programs Editor
Always looking for ideas and articles for EAA Sport Pilot
Subject: RE: RV-List: 25 hour Phase One
convince
engine
to
> two of flying!
> Cheers,
> Stein Bruch
> RV6's, Minneapolis
Power
because
> Thanks
> Steve
> MEM
> 7QB
From: | "Kyle Boatright" <kboatright1(at)comcast.net> |
> Power with the new Hartzell blended airfoil prop. The DAR I plan to use
> for the inspection has indicated that I will have to do a 40 hour phase
> one because the engine is technically exprerimental. Has anyone been able
> to get a 25 hour phase one with this or a similar combination? If so,
> some documentation I could use to show my DAR would be helpful.
> Thanks
> Steve
> MEM
> 7QB
As others have stated, technically you should get a 40 hour fly-off.
Believe it or not, 40 hours isn't that long, and gives you enough time to do
all the things you should do before carrying passengers - get comfortable
with the airplane, check out the systems, perform all expected maneuvers,
expand the W/B envelope to the worst case situations, do extended flights to
check fuel burn, etc. I know of at least one person who spent all 40 "test"
hours boring holes in the air, and got a big surprise when he put people and
bags in the airplane...
KB
b=z9bfNOCBucRc1MUzaJFpyjrIlt9wuDtfBM5ZuQW8CeWP1WDjgC4ROhYTq6U2G9fx1+lz96LsDmIh91rWL3ojytHIy8QflBcFgRpT5wYxeN3hI+0ymRGKUGUhHpGW+2fA3vv6WzMY2UYdyzNZJDvyevgU4dbA6FdjgpDjju2F66M;
Subject: | Oil Cooler Location |
My 2 cents worth.
Don't mount the oil cooler directly to the rear baffle, because it will crack eventually.
It happened to me, and many other RV's have this issue, including Van's
airplanes. Some guy's put extra braces and heaver gage metal to support the
cooler, but this is a band-aid. Some of the older Mooneys, I have seen, use
a clever idea I'll describe below. Also oil cooler installations, whether baffle
mounted or not, are not efficient. They may work but at the cost of higher
cooling drag. I have a few ideas from experience and what I read in Speed with
Economy by Kent Paser, Tony B. and other builders.
If you feel you must mount it to the rear baffle, consider supporting the oil cooler
near the baffle but just off it, using the fixed (not vibrating) engine
mount tubes as an OC support. (You can weld tabs or use Adel clamps and brackets).
Connect the OC, which is now fixed, to the vibrating rear baffle with a short
flexible duct (rectangular like the Mooney) or a round duct with a smooth
ID. This is a variation between the baffle and firewall supported OC. The cooler
can be vertical or horizontal as long as you use a generous radius and no
abrupt transitions in the duct. The less you turn the air the better. The firewall
mount is good but has the draw back of a longer duct, oil lines and firewall
crowding. Regardless of how you mount it, you will have higher drag and less
efficiency if not engineered well. I think the baffle mounted OC is the hardest
to make efficient, regardless of baffle cracking.
Bottom line, if the OC is mounted and supported directly to the baffle, the baffle
will crack at some point, usually 200-400 hours of operation max. I know some
may write they have 10,000 hours on theirs, but the average is LOW. Consider
the weight of an OC and the oil in it, the weight of the oil lines sprung weight
including oil in them, the G factor produced from engine vibration, especially
start/shutdown, fatigue...... It is going to crack and is hard on the oil
cooler.
Internal airflow drag and details are important and ignored. The internal airflow
in the typical oil cooler installation has sharp corners, abrupt transitions
and uses convoluted scat tube for ducts. Also a huge rectangular cutout near
the #4 cylinder that is often used for cooler air is poor, from both a cylinder
cooling standpoint and aerodynamics (cooling drag). You are taking air away
from an already hot #4 or #3 cylinder. You don't need 26 sq inches for oil cooler
air, you need pressure. Making a big rectangular cutout is not the key. For
example look at Van's carb air box, it uses a small inlet area, say 6.5 sq
inches to supply Carb intake air. It takes the high velocity air and converts
it to pressure, by smoothly transitioning to a larger area. (filter is approx
45 in sq). The oil cooler should be similar in concept, of course without the
filter. So a 2.5-3 inch diameter area will be enough, but you can't just go from
a circle to a rectangle with out a diffuser of som
e kind
with out losing efficiency.
Many use a very large oil cooler cutout in the baffle, matching the 26 inch sq
area/dimension as the OC. This also makes the baffle weak. I am not sure what
the actual effective area of the cooler is, but some cutouts are in the baffles
I have seen are 1/2 to 2/3rds the total area of the engine cowl inlets. It works
but is draggy and you risk hot spots and valve problems on you adjacent cylinder
you are taking air from. You are trying to convert air velocity into pressure.
OC efficiency is a function of airflow mass across the cooler, which
is a function of the delta pressure across it. The air-inlet for the OC air in
the back of the baffle should have a smooth large radius, like the inlets in
the cowl. Also use a duct with a smooth ID to connect the oil cooler. Wire reinforced
SCAT is a poor choice, and is more critical for a longer duct.
The adapter/transition on the oil cooler, where the duct attaches is important.
It should be like a funnel without abrupt angles. The square shallow "box" bolted
directly to the Oil Cooler, like Vans sells, is a poor transition. This is
very turbulent. If you supply extra air you can get enough cooling but at the
expense of drag. Van's engine cowl inlets are larger than needed for a typical
150-180 hp RV, so you have extra air. Again it works but is not as efficient
as it can be. Key is to have good cooling with the minimum air. Suggest making
you own oil cooler transition out of fiberglass, like other builders. An advantage
of NOT supporting the OC directly by the baffle is you have room to make
the transition from baffle to oil cooler. The oil cooler bolted directly to
the baffle is abrupt. Even if you do bolt directly to the rear of the baffle,
consider using some transition air box, use the min inlet area not max (experiment),
and radius the inlet. Keep Cool G.
Dress up your holiday email, Hollywood style. Learn more.
Subject: | Thicker baffle material for cooler |
Local 8 builder/flyer just had to repair the cracked baffle material after less
than 100 hours TT because of his baffle mounted cooler - like everyone else usually
does at some point.
But he remarked that the replacement baffle material he ordered from Vans was thicker
than the original material. It irked him because he said he called Van's
and told them to begin with that in his opinion the material was too thin to
support the loads. They assured him all would be well. He is a retired aircraft
manufacturing manager for Boeing so he has more than a clue about such things.
Take a look at your baffle material around that area and if it's not at
least .063 call up Van's and see if they don't have new thicker replacement material
or consider making your own with thicker material.
lucky
> My 2 cents worth.
> eventually. It happened to me, and many other RV's have this issue, including
> Van's airplanes. Some guy's put extra braces and heaver gage metal to support
> the cooler, but this is a band-aid. Some of the older Mooneys, I have seen, use
> cooler near the baffle but just off it, using the fixed (not vibrating) engine
> brackets). Connect the OC, which is now fixed, to the vibrating rear baffle with
> a short flexible duct (rectangular like the Mooney) or a round duct with a
> smooth ID. This is a variation between the baffle and firewall supported OC.
> The cooler can be vertical or horizontal as long as you use a generous radius
> and no abrupt transitions in the duct. The less you turn the air the better.
The
> firewall mount is good but has the draw back of a longer duct, oil lines and
> firewall crowding. Regardless of how you mount it, you will have higher drag
and
> less efficiency if not engineered well. I think the baffle mounted OC is the
> hardest to make efficient, regardless of baffle cracking.
> baffle will crack at some point, usually 200-400 hours of operation max. I know
> some may write they have 10,000 hours on theirs, but the average is LOW.
> Consider the weight of an OC and the oil in it, the weight of the oil lines
> sprung weight including oil in them, the G factor produced from engine
> vibration, especially start/shutdown, fatigue...... It is going to crack and
is
> hard on the oil cooler.
> airflow in the typical oil cooler installation has sharp corners, abrupt
> transitions and uses convoluted scat tube for ducts. Also a huge rectangular
> cutout near the #4 cylinder that is often used for cooler air is poor, from both
> a cylinder cooling standpoint and aerodynamics (cooling drag). You are taking
> air away from an already hot #4 or #3 cylinder. You don't need 26 sq inches for
> oil cooler air, you need pressure. Making a big rectangular cutout is not the
> key. For example look at Van's carb air box, it uses a small inlet area, say
6.5
> sq inches to supply Carb intake air. It takes the high velocity air and converts
45
> e kind
> OC efficiency is a function of airflow mass across the cooler, which is a
> function of the delta pressure across it. The air-inlet for the OC air in the
> back of the baffle should have a smooth large radius, like the inlets in the
> reinforced SCAT is a poor choice, and is more critical for a longer duct.
> bolted directly to the Oil Cooler, like Vans sells, is a poor transition. This
> is very turbulent. If you supply extra air you can get enough cooling but at
the
as
> it can be. Key is to have good cooling with the minimum air. Suggest making you
> of NOT supporting the OC directly by the baffle is you have room to make the
> transition from baffle to oil cooler. The oil cooler bolted directly to the
> (experiment), and radius the inlet. Keep Cool G.
does at some point.
But he remarked that the replacement baffle material he ordered from Vanswas thicker
support the loads.Theyassured him allwould be well. He is a retired aircraft manufacturing
Take a look at your baffle material around that area and if it's not at least
lucky
-- RV-List message posted by:
My 2 cents worth.
and no abrupt transitions in the duct. The less you turn the air the better. The
firewall crowding. Regardless of how you mount it, you will have higher drag and
vibration, especially start/shutdown, fatigue...... It is going to crack and is
g). You are taking
key. For example look at Van's carb air box, it uses a small inlet area, say 6.5
45
e kind
is very turbulent. If you supply extra air you can get enough cooling but at the
150-180 hp RV, so you have extra air. Again it works but is not as efficient as
more.
From: | "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> |
Excellent Post! I have decided to go with the firewall mount thanks to many
replies to my question both off and online.
Boy I hate to do fiberglass but believe I can come up with a funnel
type design using metal. How large should the air inlet be... 3" ? Where is
the best baffle location to tap for the air supply and not suffer cool air
to the engine or undue drag?
Tom in Ohio
Subject: RV-List: Oil Cooler Location
> My 2 cents worth.
> crack eventually. It happened to me, and many other RV's have this issue,
> including Van's airplanes. Some guy's put extra braces and heaver gage
> metal to support the cooler, but this is a band-aid. Some of the older
> Mooneys, I have seen, use a clever idea I'll describe below. Also oil
> cooler installations, whether baffle mounted or not, are not efficient.
> They may work but at the cost of higher cooling drag. I have a few ideas
> from experience and what I read in Speed with Economy by Kent Paser, Tony
> oil cooler near the baffle but just off it, using the fixed (not
> vibrating) engine mount tubes as an OC support. (You can weld tabs or use
> Adel clamps and brackets). Connect the OC, which is now fixed, to the
> vibrating rear baffle with a short flexible duct (rectangular like the
> Mooney) or a round duct with a smooth ID. This is a variation between the
> baffle and firewall supported OC. The cooler can be vertical or
> horizontal as long as you use a generous radius and no abrupt transitions
> in the duct. The less you turn the air the better. The firewall mount is
> the hardest to make efficient, regardless of baffle cracking.
> the baffle will crack at some point, usually 200-400 hours of operation
> max. I know some may write they have 10,000 hours on theirs, but the
> average is LOW. Consider the weight of an OC and the oil in it, the weight
> of the oil lines sprung weight including oil in them, the G factor
> produced from engine vibration, especially start/shutdown, fatigue......
> It is going to crack and is hard on the oil cooler.
> rectangular cutout near the #4 cylinder that is often used for cooler air
> is poor, from both a cylinder cooling standpoint and aerodynamics (cooling
> drag). You are taking air away from an already hot #4 or #3 cylinder. You
> don't need 26 sq inches for oil cooler air, you need pressure. Making a
> big rectangular cutout is not the key. For example look at Van's carb air
> box, it uses a small inlet area, say 6.5 sq inches to supply Carb intake
> air. It takes the high velocity air and converts it to pressure, by
> smoothly transitioning to a larger area. (filter is approx 45 in sq). The
> oil cooler should be similar in concept, of course without the filter. So
> a 2.5-3 inch diameter area will be enough, but you can't just go from a
> e kind
> inch sq area/dimension as the OC. This also makes the baffle weak. I am
> not sure what the actual effective area of the cooler is, but some cutouts
> are in the baffles I have seen are 1/2 to 2/3rds the total area of the
> engine cowl inlets. It works but is draggy and you risk hot spots and
> valve problems on you adjacent cylinder you are taking air from. You are
> trying to convert air velocity into pressure. OC efficiency is a function
> of airflow mass across the cooler, which is a function of the delta
> pressure across it. The air-inlet for the OC air in the back of the baffle
> should have a smooth large radius, like the inlets in the cowl. Also use
> a duct with a smooth ID to connect the oil cooler. Wire reinforced SCAT is
> important. It should be like a funnel without abrupt angles. The square
> shallow "box" bolted directly to the Oil Cooler, like Vans sells, is a
> poor transition. This is very turbulent. If you supply extra air you can
> get enough cooling but at the expense of drag. Van's engine cowl inlets
> are larger than needed for a typical 150-180 hp RV, so you have extra air.
> Again it works but is not as efficient as it can be. Key is to have good
> cooling with the minimum air. Suggest making you own oil cooler transition
> out of fiberglass, like other builders. An advantage of NOT supporting the
> OC directly by the baffle is you have room to make the transition from
> baffle to oil cooler. The oil cooler bolted directly to the baffle is
> abrupt. Even if you do bolt directly to the rear of the baffle, consider
My DAR made me find a TCDS with the engine AND prop together which I could
do because of a Lyc data plate and normal Hartzell. With a Superior and new
Hartzell just accept the 40 hrs and ask for the largest test area you can
get. I was the first locally to ask for and get a 200nm radius around a
local VOR exclusive of Class B&C. Subsequently others have gotten even
larger areas. The DAR has little or no discretion on the hours but does have
on the area... But you have to ask.
Greg Young
> Aero Sport Power with the new Hartzell blended airfoil prop.
> The DAR I plan to use for the inspection has indicated that I
> will have to do a 40 hour phase one because the engine is
> Thanks
> Steve
> MEM
> 7QB
I went to the -7 also but I had the pneumatic squeezer, I might not have if
I didn't though. I also ran out of -7 and had to borrow some because of
that so you might want to check how many you have first.
Greg
> Hey out there,
The
head,
instead
> Thanks,
> Paul
I just finnished up the wings and was checking out
motion ect.. and wanted to ask , any of you others
I was moving the alierons back and forth and it
seemslike its kinda binding ever so slightly on the
skin are those suppose to be rubbing?> it will go
past the point but its rubbing although
nothing is scratching the alieron skins it seems too tight
of tolarence whats the story on that.. once it
breaks over past on the down swing its very hard to pull
back up through the tight spot.. any idea? solutions ?
what is the degree of movement needed I got a message about
15 to 17 degree's the problem is when it goes fully up past
the skin at the gap flairing..
Danny..
For what it's worth, here's a photo of the oil cooler setup on my old Mooney
201. It's exactly what "gmcjetpilot" described.
http://images.rvproject.com/m20j/images/engine/firewall.jpg
This one shows the "duct" built into the baffles.
http://images.rvproject.com/m20j/images/engine/baffle.jpg
I did not use this method on my RV-7 & IO-360-A1B6. I used the bandaid
method (mounted on the baffle with lots of reinforcement) and am happy with
it. ;-) I wasn't content with the idea of the engine moving around and the
oil cooler mount/duct being stationary. Just my personal perspective on it.
)_( Dan
RV-7 N714D
> My 2 cents worth.
including Van's airplanes. Some guy's put extra braces and heaver gage metal
to support the cooler, but this is a band-aid. Some of the older Mooneys, I
have seen, use a clever idea I'll describe below. Also oil cooler
installations, whether baffle mounted or not, are not efficient. They may
work but at the cost of higher cooling drag. I have a few ideas from
experience and what I read in Speed with Economy by Kent Paser, Tony B. and
other builders.
oil cooler near the baffle but just off it, using the fixed (not vibrating)
engine mount tubes as an OC support. (You can weld tabs or use Adel clamps
and brackets). Connect the OC, which is now fixed, to the vibrating rear
baffle with a short flexible duct (rectangular like the Mooney) or a round
duct with a smooth ID. This is a variation between the baffle and firewall
supported OC. The cooler can be vertical or horizontal as long as you use a
generous radius and no abrupt transitions in the duct. The less you turn the
air the better. The firewall mount is good but has the draw back of a longer
duct, oil lines and firewall crowding. Regardless of how you mount it, you
will have higher drag and less efficiency if not engineered well. I think
the baffle mounted OC is the hardest to make efficient, regardless of baffle
cracking.
the baffle will crack at some point, usually 200-400 hours of operation max.
I know some may write they have 10,000 hours on theirs, but the average is
LOW. Consider the weight of an OC and the oil in it, the weight of the oil
lines sprung weight including oil in them, the G factor produced from engine
both a cylinder cooling standpoint and aerodynamics (cooling drag). You are
taking air away from an already hot #4 or #3 cylinder. You don't need 26 sq
inches for oil cooler air, you need pressure. Making a big rectangular
cutout is not the key. For example look at Van's carb air box, it uses a
small inlet area, say 6.5 sq inches to supply Carb intake air. It takes the
high velocity air and converts it to pressure, by smoothly transitioning to
a larger area. (filter is approx 45 in sq). The oil cooler should be similar
in concept, of course without the filter. So a 2.5-3 inch diameter area will
be enough, but you can't just go from a circle to a rectangle with out a
diffuser of som
> e kind
inch sq area/dimension as the OC. This also makes the baffle weak. I am not
sure what the actual effective area of the cooler is, but some cutouts are
in the baffles I have seen are 1/2 to 2/3rds the total area of the engine
cowl inlets. It works but is draggy and you risk hot spots and valve
problems on you adjacent cylinder you are taking air from. You are trying to
convert air velocity into pressure. OC efficiency is a function of airflow
mass across the cooler, which is a function of the delta pressure across it.
The air-inlet for the OC air in the back of the baffle should have a smooth
large radius, like the inlets in the cowl. Also use a duct with a smooth ID
to connect the oil cooler. Wire reinforced SCAT is a poor choice, and is
shallow "box" bolted directly to the Oil Cooler, like Vans sells, is a poor
transition. This is very turbulent. If you supply extra air you can get
enough cooling but at the expense of drag. Van's engine cowl inlets are
larger than needed for a typical 150-180 hp RV, so you have extra air. Again
it works but is not as efficient as it can be. Key is to have good cooling
with the minimum air. Suggest making you own oil cooler transition out of
fiberglass, like other builders. An advantage of NOT supporting the OC
directly by the baffle is you have room to make the transition from baffle
to oil cooler. The oil cooler bolted directly to the baffle is abrupt. Even
if you do bolt directly to the rear of the baffle, consider using some
transition air box, use the min inlet area not max (experiment), and radius
Hi All,
I will hopefully be buying an ECI IO360 if I recover from the Crossflow experience. I am planning ahead and am seriously considering the Emag setup as opposed to conventional mags or electronic ignition. www.emagair.com
Is anyone out there using these yet? It almost appears to be too good to be true.
This is nearly a wash cost wise with conventional mags with not BS factor involved
in installation.
Darwin N. Barrie
Chandler AZ
Subject: | Re: aileron travel |
Oh its an rv9a I am building
> Danny..
> _-
> _-
> _-
In a message dated 12/12/04 2:52:31 PM Eastern Standard Time,
RGray67968(at)aol.com writes:
My O-360 has a Lycoming data plate but the engine is from AeroSport Power.
Have Hartzell C/S prop matched to Lycoming O-360. Still got 40 hours!
Dale Ensing
It's really up to the DAR... I had an O320 and wood prop and I got 30
hours...
-Bill
no not archive
Dale Ensing
Have a look at the Matronics aeroelectric list recent archives. There has
been some discussion there - mostly quite favorable.
Terry
true. This is nearly a wash cost wise with conventional mags with not BS
factor involved in installation.
Darwin N. Barrie
In this case you obviously have a rebuilt/overhauled/new lycoming built by
AeroSport power. The ones in question are his new "Experimental" Engines
which are NOT new/rebuilt/overhauled Lyc's.
Aerosport Power builds both overhauled/rebuilt Lycs as well as full
Experimental engines. Two totally different things in the eyes of the feds.
Stein.
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of DWENSING(at)aol.com
Dale Ensing
In a message dated 12/12/2004 4:53:46 PM Central Standard Time,
sportypilot(at)stx.rr.com writes:
once it
Make absolutely sure it is NOT the aileron bellcranks or pushrod end bearings
or the pushrods themselves touching anything- also check clearances where the
pushrods go through the rear spars and the rods from the sticks where they go
through the seat ribs and side skins... On a -6A these clearances are very
tight- if you are building something else, your mileage may vary....
It took quite a while in a very quiet hangar to find out that a rivet in my
Navaid servo rod bearing was barely brushing the bellcrank mounting angle- time
well spent IMHO!
From The PossumWorks in TN
Mark
From: | "Albert Gardner" <spudnut(at)worldnet.att.net> |
On the RV-9A: Aileron travel is limited by the positive stops. They will
only limit up travel so until you get the wings hooked together through the
stick you won't have any limit on down aileron. Also, the amount of total
travel is usually greater than the stops will eventually limit it to, so
until the stops are installed you may be seeing more travel (and therefore
some binding) than you will end up with.
Albert Gardner
RV-9A 872RV
Yuma, AZ
>> Danny..
From: | "Eustace Bowhay" <ebowhay(at)jetstream.net> |
Subject: | Autopilot istallation instructions |
Just received my servos from TruTrak and included is all the hardware and installation
instruction manual with some excellent pictures and as has been mentioned,
the drawings for a RV 7 installation in the left hand wing.
A couple of questions come to mind, the WD421 L is not the same as the one shown
in the 7 drawing. The difference being their is a difference in the divergence
of the two arms, looks like around 4-5 degrees and also the arms look like
they are about 1/4 inch longer.
The other is all the info pertains to a left hand installation. I realize that
the right hand installation is probably a mirror image of the left, did I miss
something when I ordered them. What would be the advantage of a right hand installation?
Eustace Bowhay Blind Bay, B.C.
Subject: | Re: Autopilot istallation instructions |
It may not be of much significance but having the servo in the right wing
would help balance the pitot installation in the left wing both from a
weight and complexity standpoint.
Dick Sipp
#40065
Subject: RV-List: Autopilot istallation instructions
> installation instruction manual with some excellent pictures and as has
> been mentioned, the drawings for a RV 7 installation in the left hand
> wing.
> shown in the 7 drawing. The difference being their is a difference in the
> divergence of the two arms, looks like around 4-5 degrees and also the
> arms look like they are about 1/4 inch longer.
> that the right hand installation is probably a mirror image of the left,
> did I miss something when I ordered them. What would be the advantage of a
If YOU cannot prove that all ADs are complied with, that the engine and prop
meets the TCDS, the DAR should give you 40 hours even if you have the data
plate and prop. One thing that causes many engines in homebuilts to not
meet the TCDS is the removal of a mag and installation on an EXPERIMENTAL
ignition system.
Gary A. Sobek
1,610 + Flying Hours So. CA, USA
http://SoCAL_WVAF.rvproject.com
----Original Message Follows----
Dale Ensing
From: | "Maureen & Bob Christensen" <mchriste(at)danvilletelco.net> |
Darwin,
I too am considering Emag . . . I also monitor the AeroElectric list
mentions . . . there was some general discussion a while back but not much
"personal experience" that I recall?!
I am also interested in any feed back!
Bob Christensen
RV-8 Builder - SE Iowa
Subject: RE: RV-List: EMag
> Terry
setup
be
> Darwin N. Barrie
Paul,
I can think of two things which may cause the rivets to seem too short. One
would be if all the pieces were not laying flat together, if there are several
layers to rivet through. Another thing would be if the hole(s) were
oversize, possibly due to drilling out the rivet and redoing it. The rivets
themselves enlarge the holes when they are driven, even if you do a perfect job
of
drilling them out. If you have drilled a rivet out, you may well have to use a
longer rivet to fill the hole, and get a good shop head. Sometimes its better
to accept a less than perfect shop head to avoid getting into this situation.
Experience will help make that decision for you.
Dan Hopper
RV-7A
In a message dated 12/12/04 1:24:31 PM US Eastern Standard Time,
rice737(at)msn.com writes:
> Hey out there,
> Thanks,
> Paul
clamav-milter version 0.80j
on zoot.lafn.org
Actually, it will help balance the PILOT that is in the left seat. One
person in the airplane instead of 2 significantly changes the balance of
the airplane.
Dave -6 So Cal
Richard Sipp wrote:
>...would help balance the pitot installation in the left wing...
Subject: | Re: [GRT_EFIS] Re: Autopilot GPS source switch |
From: | "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net> |
Lucky,
I asked this same ? to John Stark and he said you can split 3 times with
out any concern for appreciable signal degradation on a serial split.
I have had to split on several devices.
S8 Wiring.
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of lucky
Subject: RV-List: Re: [GRT_EFIS] Re: Autopilot GPS source switch
That's only part of the solution, as Sam points out, and why I asked the
question to the list in the first place because I couldn't see the
switch solving the other part of the problem. I want the autopilot to
be driven by two different sources but also wanted the switch to serve
as a "T" for the Lawrence GPS seriel output to drive the GRT all the
time. But I had some coffee and realized that if I tie the GRT's GPS
seriel in line to the same pole that the Lawrence GPS output signal is
connected to then that pole acts as a always hot "T" to allow the GPS
signal to always find it's way to the GRT all the time. That can be
accomplished by putting both systems' wires into the same connector
before crimping (or solder contact before soldering).
Now it's a day later and when I look at this I don't even see the need
for the DP as Paul points out. I think this would work with a SPDT
switch like Paul does.
The main ? now is that if I have the switch in the position where the
Lawrence is feeding both systems the GPS signal out of the same wire and
power source, by splitting it's output what am I going to do to the
signal quality and ultimately reliability? Probably none with these
modern systems and short wire runs and minimal conductor exposure in low
RFI environments.
But anyone know for sure?
> Real easy Lucky - a simple DPDT mini toggle switch with the serial
> lines hooked up to teh "outside" contacts and the autopilot serial
> lines connected to the middle poles. (I actually only switched the
> single serial line and not the grounds, as I am using a common signal
> ground for all of the serial lines in the system, so I could have
> gotten by with a SPDT switch - but then again, I'm an aeronautical
> engineer by training, and not a EE...what do I know about electrons?
> LOL...)
> Paul Dye
> --- In GRT_EFIS(at)yahoogroups.com, luckymacy(at)c... wrote:
> > I don't have my GPS yet (not sure if that actually would help) but
> I want to buy a switch that will let me select between my Lowrance
> GPS and the GRT EFIS output to drive my Trio autopilot and I saw this
> on someone's website. If I have the Lowrance driving the autopilot I
> still want it to also feed the EFIS. Can't find it now.
> > What switch type am I looking to purchase and what's actually going
> to be wired up?
> > Thanks,
> > Lucky
> http://us.click.yahoo.com/Q7_YsB/neXJAA/yQLSAA/jrDrlB/TM
> <*> To visit your group on the web, go to:
> http://groups.yahoo.com/group/GRT_EFIS/
> <*> To unsubscribe from this group, send an email to:
> GRT_EFIS-unsubscribe(at)yahoogroups.com
> http://docs.yahoo.com/info/terms/
switch solving the other part of the problem. I want the autopilot to be
driven by two different sources but alsowanted the switch to serve as a
"T" for the Lawrence GPS seriel output to drive the GRT all the time.But
I had some coffee and realized that if I tie the GRT's GPS seriel in
line to the same pole that the Lawrence GPS output signal isconnectedto
then that pole acts as a always hot"T" to allow the GPS signal to always
find it's way to the GRT all the time.That can be accomplished by
putting both systems'wires into the same connector before crimping (or
lowRFI environments.
LOL...)
Paul Dye
GPS a
to be wired up?
Lucky
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
GRT_EFIS-unsubs
You may have already figured this out, but they probably sent you hardware
for installing in the right wing while you have install documentation for
the left. That is what happened to me. Now after installing it in the
left, I think it is better to install in the right because of the pitot.
When I contacted Tru Trak/Tru Trac, they happily sent me the left wing
install bracket with no questions. That is good customer support after the
sale. They could of saved me a few hours however by sending the correct
documentation for the bracket they sent me in the first place however.
installation instruction manual with some excellent pictures and as has been
mentioned, the drawings for a RV 7 installation in the left hand wing.
divergence of the two arms, looks like around 4-5 degrees and also the arms
that the right hand installation is probably a mirror image of the left, did
I miss something when I ordered them. What would be the advantage of a right
hand installation?
I am very satisfied with the M-mag and the P-mag I have
installed on my RV4. I don't think you can go wrong with
their product or the company. They have made several changes
since mine that make installation even easier.
Stewart
Subject: | Re: Aircraft Insurance: USAA |
USAA is a broker just like NationAir, Falcon, and anyone else whom you'd
talk to about aviation insurance (except AVEMCO the direct writer).
JT (former Army officer and USAA member)
Subject: RV-List: Aircraft Insurance: USAA
> Just an FYI for USAA insurance members (ie, qualified current &
ex-military members). I was on their web site this morning and saw they do
provide Aviation service. Their minute blurb is copied below. They probably
don't do the underwriting but it's at least worth looking into if you
haven't already. If their airplane insurance is anything like their car
insurance it probably can't be beat now that Phoenix is out. Since just
about every military officer is a usaa member, they surely have dealt with a
LOT of pilots and pilot questions/demands. I'll call Monday myself and let
you know what I find out.
> If anyone's already insured by them on the list, would you mind sharing
what you know?
> Thanks,
> Lucky
> USA Toll-Free 1-800-343-1547
> Monday - Friday, 7:30 a.m. - 6 p.m. CT
> Aviation Insurance
> The Sky's the Limit
> >From coverages for hull damage and liability to medical payments, the
USAA General Agency can provide competitive quotes, personalized attention,
and a highly trained staff of professionals. We understand your needs as a
pilot. Contact Us.
> Before purchasing aviation insurance, it is important to look at some of
the contract coverages that are not always so obvious. Besides comparing
hull and liability coverage and premium, these are some questions to ask
when you shop for coverage:
> Can other pilots fly my aircraft? If so, what are the requirements?
> How much expense reimbursement will the policy allow for other pilots
flying the aircraft?
> Does the policy provide coverage for the use of a non-owned aircraft?
> Does this company provide legal representation if I'm sued?
> What rating has A.M. Best assigned to this insurance company?
> Is there premises liability coverage for the hangar or tie-down space?
> Just an FYI for USAA insurance members (ie, qualified current ex-military
provideAviation service. Their minute blurb is copied below. They probably
what you know?
> Thanks,
> Lucky
> USA
> Toll-Free
> 1-800-343-1547
