RV4-Archive.digest.vol-ac
August 26, 2002 - March 05, 2003
      > > terminal it has a round hole for a three pin connector.  I don't have
      the
      > > connector and the pins are not marked so I don't have a clue which pin I
      > > need to connect the 12 volts to in order to turn the Alternator on or
      off.
      > > The Kragan people could not help.
      > > I'm hoping someone out there has already been there and done that.   I
      > know
      > > Vans sells a connector for their alternators and I'm also sending them
      an
      > > e-mail.
      > > Thanks
      > > Tom Rupe
      > > RV4  S/N 62
      > Introducing NetZero Long Distance
      > Unlimited Long Distance only $29.95/ month!
      > Sign Up Today! www.netzerolongdistance.com
Date: Aug 26, 2002
Subject: Re: Alternator Hookup
Tom- If you take it to your local auto electrical establishment they will tell you what each terminal is probably by simply looking at it. There are only a couple of things an alternator needs -- field excitation, ground and output. This is not a big thing to figure out and worst case they can look at it electrically. JBB Tom and Faye wrote: > > Hi, > I wish I had more information. All I know is that it is a Kragen Import > Alternator. All it has is a paper label with their P/N and a barcode. > There is no manufacture info at all. They could sell me a replacement with > the info I have but they can't tell me what it's for or how it gets hooked > up electrically. > I guess their computers don't work that direction. > > I wouldn't mind having your drawing though. It might help. > > Thanks for your response. > Tom Rupe > RV4 S/N 62 > ----- Original Message ----- > From: "flyseaplane" <flyseaplane(at)netzero.net> > To: > Subject: Re: RV4-List: Alternator Hookup > > > > > Mr. Rupe, > > > > Is this the Nippondenso alternator from a Geo Metro/ Chevy Sprint?? > > If so, e-mail me and I will send you a diagram. > > > > Later, > > Linc > > Subject: RV4-List: Alternator Hookup > > > > > > > > > > As part of my rebuild project, I'm putting all new electrical wire in my > > > RV4, and have run into a snag with the alternator. It is a Kragen > Import > > > 60 amp, P/N 30-5088 MPA with and internal regulator. Besides the B > > > terminal it has a round hole for a three pin connector. I don't have > the > > > connector and the pins are not marked so I don't have a clue which pin I > > > need to connect the 12 volts to in order to turn the Alternator on or > off. > > > The Kragan people could not help. > > > > > > I'm hoping someone out there has already been there and done that. I > > know > > > Vans sells a connector for their alternators and I'm also sending them > an > > > e-mail. > > > > > > Thanks > > > Tom Rupe > > > RV4 S/N 62 > > > > > > ------------------------------------------- > > Introducing NetZero Long Distance > > Unlimited Long Distance only $29.95/ month! > > Sign Up Today! www.netzerolongdistance.com > > > > > ________________________________________________________________________________
Date: Aug 26, 2002
This, fellow birdmen, is a mystery wrapped in a conundrum. I took a copy of the original email to my best starter/generator/alternator repair facility and the owner looked up - or rather tried to look up- the possibilities and came up with three which really do not sound like that item initially described. One of the characteristics lacking from the three Nippon possibles is the internal regulator. All of those he located on his discs were three-pin with labels on the pins- typically "F", "P", "E" and they each had a separate post for "Batt". Good luck. ----- Original Message ----- From: <jamesbaldwin(at)attglobal.net> Subject: Re: RV4-List: Alternator Hookup > > Tom- > If you take it to your local auto electrical establishment they will tell you > what each terminal is probably by simply looking at it. There are only a couple > of things an alternator needs -- field excitation, ground and output. This is > not a big thing to figure out and worst case they can look at it electrically. > JBB > > Tom and Faye wrote: > > > > > Hi, > > I wish I had more information. All I know is that it is a Kragen Import > > Alternator. All it has is a paper label with their P/N and a barcode. > > There is no manufacture info at all. They could sell me a replacement with > > the info I have but they can't tell me what it's for or how it gets hooked > > up electrically. > > I guess their computers don't work that direction. > > > > I wouldn't mind having your drawing though. It might help. > > > > Thanks for your response. > > Tom Rupe > > RV4 S/N 62 > > ----- Original Message ----- > > From: "flyseaplane" <flyseaplane(at)netzero.net> > > To: > > Subject: Re: RV4-List: Alternator Hookup > > > > > > > > Mr. Rupe, > > > > > > Is this the Nippondenso alternator from a Geo Metro/ Chevy Sprint?? > > > If so, e-mail me and I will send you a diagram. > > > > > > Later, > > > Linc > > > Subject: RV4-List: Alternator Hookup > > > > > > > > > > > > > > As part of my rebuild project, I'm putting all new electrical wire in my > > > > RV4, and have run into a snag with the alternator. It is a Kragen > > Import > > > > 60 amp, P/N 30-5088 MPA with and internal regulator. Besides the B > > > > terminal it has a round hole for a three pin connector. I don't have > > the > > > > connector and the pins are not marked so I don't have a clue which pin I > > > > need to connect the 12 volts to in order to turn the Alternator on or > > off. > > > > The Kragan people could not help. > > > > > > > > I'm hoping someone out there has already been there and done that. I > > > know > > > > Vans sells a connector for their alternators and I'm also sending them > > an > > > > e-mail. > > > > > > > > Thanks > > > > Tom Rupe > > > > RV4 S/N 62 > > > > > > > > > ------------------------------------------- > > > Introducing NetZero Long Distance > > > Unlimited Long Distance only $29.95/ month! > > > Sign Up Today! www.netzerolongdistance.com > > > > > > > > > > ________________________________________________________________________________
Date: Aug 31, 2002
Subject: Tail wheel instructor
Hi guys..I am looking for a tail wheel instructor with lots and lots of hours preferably but not necesarily with RV time..Said instructor must weigh 180 lbs or less..Must live somewhere realatively close to the bay area and must have 6.5 hours of free time some weekend to go fly around with me in my 150 HP RV4. I am not looking for instruction, just someone to give my hard earned money to so I can satisfy my insurance requirements.You can contact me off line at 510 278 0260 or my cell 510 541 4979..Thanks, Art ________________________________________________________________________________
Subject: Re: Tail wheel instructor
Date: Aug 31, 2002
Not trying to be negative about this, Art, but maybe you should list your TD experience for those instructors? Particularly since you say you "...are not looking for instruction..." Just a thought. ----- Original Message ----- From: "art stavro" <art79(at)pacbell.net> Subject: RV4-List: Tail wheel instructor > > Hi guys..I am looking for a tail wheel instructor with lots and lots of > hours preferably but not necesarily with RV time..Said instructor must > weigh 180 lbs or less..Must live somewhere realatively close to the bay > area and must have 6.5 hours of free time some weekend to go fly around > with me in my 150 HP RV4. I am not looking for instruction, just > someone to give my hard earned money to so I can satisfy my insurance > requirements.You can contact me off line at 510 278 0260 or my cell 510 > 541 4979..Thanks, Art > > ________________________________________________________________________________
Date: Aug 31, 2002
Maby I should clarify, I am looking to fly off mandatory hours for my insurance to kick in. They demanded an RV4 pilot, CFI with 250 hrs tail wheel time 1000 hours TT. I believe I have talked them into a CFI with lots of tail wheel time. I have already had tail wheel instruction and check out and am currently commuting with the airplane but thought it would be nice to have some insurance seeing as how I have paid for it already. Thanks again, Art James Lawliss wrote: > > Not trying to be negative about this, Art, but maybe you should list your TD > experience for those instructors? > Particularly since you say you "...are not looking for instruction..." > Just a thought. > > ----- Original Message ----- > From: "art stavro" <art79(at)pacbell.net> > To: > Subject: RV4-List: Tail wheel instructor > > > > > Hi guys..I am looking for a tail wheel instructor with lots and lots of > > hours preferably but not necesarily with RV time..Said instructor must > > weigh 180 lbs or less..Must live somewhere realatively close to the bay > > area and must have 6.5 hours of free time some weekend to go fly around > > with me in my 150 HP RV4. I am not looking for instruction, just > > someone to give my hard earned money to so I can satisfy my insurance > > requirements.You can contact me off line at 510 278 0260 or my cell 510 > > 541 4979..Thanks, Art > > > > > ________________________________________________________________________________
Date: Sep 01, 2002
Subject: Getting Bounced From Matronics Lists...
Dear Listers, I have two programs I run regularly to purge the various Matronics email lists of bad email addresses. I referred to these as my Email Weasels and there is a daily version that is run automatically every night at midnight and there is a and a monthly version that I run by hand at roughly 30-day intervals. The Daily Weasel grinds through the 8 to 10mb of bounced email that is generated each day looking for obvious things like "user unknown", "host unknown", and other things that usually mean the user's email address doesn't exist any longer. The Daily Weasel has been purging 5 to 10 email addresses each night. The Monthly Weasel gets more serious about the task and sends a single message to each list member with specially generated headers and content information. Any bounces or replies to these messages are considered errors and the email address is eligible for purging. This program is particularly useful for "weaseling out" email addresses that are actually being forwarded to by another email address that is subscribed to a List and otherwise would not be identifiable. The Monthly Weasel purges roughly 100 nonexistent email addresses each month when it is run. To check to see if your address has been removed by either of the Email Weasel programs, you can check the Weasel Status Web Page at the following URL: http://www.matronics.com/unsubscribed If you find your email address on the Weasel List, but are certain that everything is working fine now, simply go the Matronics Subscription page and resubscribe your address. No harm, no foul. The subscription URL is: http://www.matronics.com/subscribe That all having been said, I've noticed that the Daily Weasel may have been getting a little too aggressive in purging addresses recently and a number of people have written asking if and why they'd been dropped from the List. A couple of months ago I rewrote the Daily Weasel program to include a wider variety of errors and more aggressively purge. One of the new purge criteria that I added seems to occur a fair amount of the time (Connection Deferred) even though the address is really okay. As of today, I've removed the Connection Deferred criteria from the Daily Weasel Rule set and this should decrease the number of "false positives" and unnecessary unsubscribed. Again, if you get unsubscribed by either of the Email Weasel utilities, simply go to the subscription page and resubscribe: http://www.matronics.com/subscribe Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Date: Sep 03, 2002
Art; Where are you located and who is your insurance company? I might be able to help. Rob Ray --- art stavro wrote: > > > Maby I should clarify, I am looking to fly off > mandatory hours for my insurance > to kick in. They demanded an RV4 pilot, CFI with 250 > hrs tail wheel time 1000 > hours TT. I believe I have talked them into a CFI > with lots of tail wheel time. > I have already had tail wheel instruction and check > out and am currently > commuting with the airplane but thought it would be > nice to have some insurance > seeing as how I have paid for it already. Thanks > again, Art > > James Lawliss wrote: > > > > > > Not trying to be negative about this, Art, but > maybe you should list your TD > > experience for those instructors? > > Particularly since you say you "...are not looking > for instruction..." > > Just a thought. > > > > ----- Original Message ----- > > From: "art stavro" <art79(at)pacbell.net> > > To: > > Subject: RV4-List: Tail wheel instructor > > > > > > > > > Hi guys..I am looking for a tail wheel > instructor with lots and lots of > > > hours preferably but not necesarily with RV > time..Said instructor must > > > weigh 180 lbs or less..Must live somewhere > realatively close to the bay > > > area and must have 6.5 hours of free time some > weekend to go fly around > > > with me in my 150 HP RV4. I am not looking for > instruction, just > > > someone to give my hard earned money to so I can > satisfy my insurance > > > requirements.You can contact me off line at 510 > 278 0260 or my cell 510 > > > 541 4979..Thanks, Art > > > > > > > > > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > http://finance.yahoo.com ________________________________________________________________________________
Date: Sep 04, 2002
Subject: RV 4 Flaps.....FL 6
Hi again I'm having a little difficulty in deciphering the sketches for the FL 6 assembly. Are there any better prints available other than the three views shown on the bottom of sheet 15? Knew I should have taken blue print reading somewhere along the line...Did get the rest of the first flap constructed and it even looks like the drawings. Ha. Thanks for any additional information. Pat Long Bay City, Michigan (989)684-0581 Working on an RV-4 Email: PGLong(at)aol.com ________________________________________________________________________________
Date: Sep 11, 2002
Subject: Spray can primer?
What are the part numbers and where can I get the spray can primers that are self etching . I just have the flaps and ailerons to prime so don't think I want to do the alodine procedure for just the few parts I need to make to finish up the kit. The rest of the RV 4 has been protected by what looks to be green zinc chromate and could have been done over alodined aluminum. I recall someone talking about a PPG primer that did the etching as long as the metal had been cleaned with MEK or Acetone. Pat Long Bay City, Michigan (989)684-0581 Working on an RV-4 Email: PGLong(at)aol.com ________________________________________________________________________________
Date: Sep 11, 2002
Subject: Re: RV4-List Digest: 2 Msgs - 08/19/02
Subject: Re: Spray can primer?
Date: Sep 11, 2002
Pat, I use a spray can product from Sherwin Williams labelled GBP 988. It is distributed at SW automotive finishes stores. It says on the can it is a self etching primer. The finish is light gray. Sprays easily, and seems to be "fairly" durable. Tom Chapman RV-4- 985 hours Building RV-8-fuse ----- Original Message ----- > > What are the part numbers and where can I get the spray can primers that are > self etching . > Pat Long > Bay City, Michigan ________________________________________________________________________________
From: "Jack Gageby" <jackgageby(at)worldnet.att.net>
Date: Sep 11, 2002
MAR-HYDE Single Stage Pretreatment Primer, Light Gray, No. 5111. Try an automotive paint supply store in your area. ----- Original Message ----- From: <PGLong(at)aol.com> Subject: RV4-List: Spray can primer? > > What are the part numbers and where can I get the spray can primers that are > self etching . I just have the flaps and ailerons to prime so don't think I > want to do the alodine procedure for just the few parts I need to make to > finish up the kit. The rest of the RV 4 has been protected by what looks to > be green zinc chromate and could have been done over alodined aluminum. I > recall someone talking about a PPG primer that did the etching as long as the > metal had been cleaned with MEK or Acetone. > > Pat Long > Bay City, Michigan > (989)684-0581 > Working on an RV-4 > Email: PGLong(at)aol.com > > ________________________________________________________________________________
"RV-List" , , , "Rick-RV-4-Aero/formation ASEW/E32/AC1" <39asew.e32.ac1(at)incirlik.af.mil>, "Pat Perry RV-4 +" , "Dog Fighter-Terry Burch" , "Alex Peterson" ,
Subject: Inverted Valve for Brake Fluid Reservoir... A.K.A. "The Reservoir
Dog"
Date: Sep 12, 2002
Hi Guys & Gals, I hope I ain't bothering you, but Alex Peterson (one of our own aerobatic RV pilots) just perfected his latest/greatest invention... "The Reservoir Dog". This little valve keeps the brake fluid in the reservoir while we are sloshing around, rolling upside down, tossing our tail feathers, etc... If you are interested (and who doesn't want to keep that caustic pink fluid from dripping all over & ruining the valuables inside and outside our engine compartments?, not to mention what it will do to our beautiful paint) just email Alex at alexpeterson(at)usjet.net and he will zip one of these puppies right to you! Believe me you will love 'em, I know I do. Chuck legal disclaimer: I have not, nor will not, receive any compensation for endorsing this item... I just tried one, think it's great!!! and would like to see a good product, new entrepreneur succeed! ________________________________________________________________________________
Subject: Seats
Date: Sep 14, 2002
The response to my alternator question was great. Thanks to everyone. Here are 2 more. 1. Who manufactures the most comfortable seats for the RV4? 2. Does any one have the dimensions for building the seats from scratch. I might try that. Thanks Tom Rupe S/N 62 ________________________________________________________________________________
Subject: RV4 Canopy
Date: Sep 15, 2002
I'm scratch building a sliding canopy on an RV4. Question: Has anyone flown a -4 with a sliding canopy with the canopy open ? What were the results ? Ron -- ronkayr(at)rmci.net ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: RV4 Canopy
Date: Sep 16, 2002
There is one gentleman who had a sliding canopy who made a fairing that he could slide on instead of the sliding portion of the canopy. It covered the rear seat effectively making it an open cockpit airplane. Reports were that it flew just fine. -- Scott VanArtsdalen, MCSE - CCNA Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Ron and Kay Robinson [mailto:ronkayr(at)rmci.net] Subject: RV4-List: RV4 Canopy I'm scratch building a sliding canopy on an RV4. Question: Has anyone flown a -4 with a sliding canopy with the canopy open ? What were the results ? Ron -- ronkayr(at)rmci.net ________________________________________________________________________________
Date: Sep 19, 2002
Subject: Pilot emergency chutes for sale
>2 Pilot Emergency Chutes For Sale. Used in my RV4 for 6 months. Very >compact. > > Chute 1 is a Red 26' foot Micro Softie with Quick release buckles.$550.00 Lowered from $750.00. MFG. June-1988, it is a STRONG Mid Lite 26' canopy >The container is a Micro Softie and was MFG. May 1989. It was used a few >times in 1993 but thats about it except for my occasional use last year. > > > Chute 2 is a Blue with red trim National backpack 360 with sheepskin >padding.>The National 360 was MFG. Dec. 1985. 24' Phantom Canopy. > > WAS $575.00 now $450.00>Both chutes were repacked last year and are in excellent >condition.> > Located in Southern California. I Paid $1450.00 for both, I will sell for >$950 for both. Buyer Pays shipping. Located in Southern California, I can meet possibly half way to pick up depending on distance. > > Contact Will Whiteside 818-359-1106 whiteside(at)aol.com ________________________________________________________________________________
Date: Sep 22, 2002
Subject: Lord mount orientation???
I just got the new J-6230-1 Lord mount bushings from Vans and I have no orientation marks on my conical engine mount to help me install them correctly. Can anyone help me make sure I get them installed correctly? Thanks Greg Hunsicker ________________________________________________________________________________
Date: Sep 23, 2002
" I just got the new J-6230-1 Lord mount bushings from Vans and I have no orientation marks on my conical engine mount to help me install them correctly. Can anyone help me make sure I get them installed correctly?" ----------------------------------------------------- Hello Greg, Last I checked there were no orientation marks for conical mounts. They just go in. What indication do you have that would make you think they need to be "oriented" ?? If you want a picture of mine I will send it to you - - send me an e-mail to my address above, NOT to the list. I'm sending this to the list since I have never heard of orientation marks - - - does anyone else have any idea what could be baffling Greg?? Take Care, Linc ------------------------------------------- Introducing NetZero Long Distance Unlimited Long Distance only $29.95/ month! Sign Up Today! www.netzerolongdistance.com ________________________________________________________________________________
Date: Sep 23, 2002
Subject: Re: Lord mount orientation???
Greg: I don't have a Lord catalog but from your post I assume the J-6230-1 mounts are the "straight" mounts (not Dynafocal). I wasn't aware Van sold them since they are not in my catalog. If you really have these mounts (all 8 are identical and cone shaped), then they have no preferred orientation. However, if you actually have Dynafocal mounts, there is a definite orientation required for them but they can be assembled incorrectly without you knowing they are wrong. Does your steel engine mount have all four engine attach bolts parallel to each other or angled into the center of the engine? Bill Marvel flyseaplane wrote: > --> RV-List message posted by: "flyseaplane" > > " I just got the new J-6230-1 Lord mount bushings from Vans and I have no > orientation marks on my conical engine mount to help me install them > correctly. Can anyone help me make sure I get them installed correctly?" > ----------------------------------------------------- > Hello Greg, > > Last I checked there were no orientation marks for conical mounts. They just > go in. What indication do you have that would make you think they need to be > "oriented" ?? If you want a picture of mine I will send it to you - - send > me an e-mail to my address above, NOT to the list. I'm sending this to the > list since I have never heard of orientation marks - - - does anyone else > have any idea what could be baffling Greg?? > > Take Care, > Linc > > ------------------------------------------- > Introducing NetZero Long Distance > Unlimited Long Distance only $29.95/ month! > Sign Up Today! www.netzerolongdistance.com > -- Bill Marvel Home/office 310 832 7617 P.O. Box 784 Cell 310 293 2013 San Pedro, CA 90733 Fax 310 832 5334 One good deed beats 100 good intentions... ________________________________________________________________________________
Subject: Engine Hanging
Date: Sep 24, 2002
Try this gang, it is good, and should answer most questions. http://www.metronet.com/~dreeves/articles/IllustratedGuideToEngineHanging/enginehanging.htm Good luck!...............Cheers................Gene Smith. ________________________________________________________________________________
Subject: RV-4's at Cooking Lake, Edmonton, Canada
Date: Oct 01, 2002
Hi all, I'm a British RV-4 builder who is soon to be found hanging around Cooking Lake, Edmonton for a month (6th Oct thru 4th Nov) aquiring my Canadian PPL. If any RV-4 folk are in the area - builders, flyers, wannabe's and want to talk -4, please email me direct. Also of interest would be information of a local EAA chapter. Many thanks, Bruce Naylor RV-4 ________________________________________________________________________________
Subject: Fw: Rocket-List: cowl pressure
Date: Oct 02, 2002
Okay, having said that give us the solution that utilizes that lost 70% flow (or a large portion thereof). ----- Original Message ----- From: <LesDrag(at)aol.com> Subject: Re: Rocket-List: cowl pressure > --> Rocket-List message posted by: LesDrag(at)aol.com > > I never have understood why everyone used the top of the cowl for part of the > baffling. It causes all of the cowl surfaces to be providing upward > pressure. (Bernoulli's on the outside top surface, "pressure" on forward 3/4 > of the inside top surface, impact pressure exceeding bernoulli's on the > outside bottom surface, and "vacuum" on the inside bottom surface.) > > It is also very inefficient. In the typical Van's cowl (which is cleaner > than most manufacturers), there is a 70% net flow loss in the air just going > from the air inlet to the engine cylinders. > > JMHO > > Jim Ayers > Less Drag Products, Inc. > > ________________________________________________________________________________
Date: Oct 03, 2002
From: "Richard V. Reynolds" <rvreynolds(at)macs.net>
czech-list(at)matronics.com, europa-list(at)matronics.com, ez-list(at)matronics.com, glasair-list(at)matronics.com, homebuilt-list(at)matronics.com, kolb-list(at)matronics.com, kr-list(at)matronics.com, lancair-list(at)matronics.com, pelican-list(at)matronics.com, pietenpol-list(at)matronics.com, piper-list(at)matronics.com, pitts-list(at)matronics.com, rocket-list(at)matronics.com, rv4-list(at)matronics.com, rv6-list(at)matronics.com, rv7-list(at)matronics.com, rv8-list(at)matronics.com, sonerai-list(at)matronics.com, tailwind-list(at)matronics.com, ultralight-list(at)matronics.com, warbird-list(at)matronics.com, yak-list(at)matronics.com, zenith-list(at)matronics.com
Subject: EAA Chapter 339 Fall Fly-In
EAA Chapter 339 Fall Fly-In Saturday, October 19, 2002, Hampton Roads Exec (PVG), Virginia, 9AM till 7PM Hampton Roads Exec (PVG) is 27nm SW of Norfolk, Virginia (253 radial ?ORF) AWOS 118.375 CTAF 123.0 The weather will be a perfect Virginia fall day! Aircraft parking is off taxiway between Rwy 23 and T-Hangars East of Airport Terminal Schedule of Events Fly-In Begins 9AM Food all Day 10AM ? 3PM Poker Run (Walk Around Field) Project Visits on Field Aircraft Judging 11AM ? 3PM, All Categories, Antiques, Classics, Homebuilts, Warbirds Social Hour 4PM Dinner 5PM ? 7PM, BBQ Sandwiches, Chicken, Drinks Local motels/hotels are available For More Information Frank Toy 757-460-3680 ftoy(at)att.net Richard Reynolds 757-627-8743 rvreynolds(at)macs.net EAA Chapter 339 http://home.earthlink.net/~avyator/ Hampton Roads Exec Airport http://www.hamptonroadsexecutiveairport.com/index.html ________________________________________________________________________________
Date: Oct 03, 2002
Subject: Re: EAA Chapter 339 Fall Fly-In
Sorry I can't make it with my RV4...I live in Bama now, but it's not that far... Rob Ray --- "Richard V. Reynolds" wrote: > Reynolds" > > EAA Chapter 339 Fall Fly-In > > Saturday, October 19, 2002, Hampton Roads Exec > (PVG), Virginia, 9AM till > 7PM > Hampton Roads Exec (PVG) is 27nm SW of Norfolk, > Virginia (253 radial > ?ORF) > AWOS 118.375 > CTAF 123.0 > > The weather will be a perfect Virginia fall day! > > Aircraft parking is off taxiway between Rwy 23 and > T-Hangars East of > Airport Terminal > > Schedule of Events > Fly-In Begins 9AM > Food all Day 10AM ? 3PM > Poker Run (Walk Around Field) > Project Visits on Field > Aircraft Judging 11AM ? 3PM, All Categories, > Antiques, Classics, > Homebuilts, Warbirds > Social Hour 4PM > Dinner 5PM ? 7PM, BBQ Sandwiches, Chicken, Drinks > > Local motels/hotels are available > For More Information > > Frank Toy 757-460-3680 > ftoy(at)att.net > Richard Reynolds 757-627-8743 > rvreynolds(at)macs.net > EAA Chapter 339 > http://home.earthlink.net/~avyator/ > Hampton Roads Exec Airport > http://www.hamptonroadsexecutiveairport.com/index.html > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Oct 04, 2002
Subject: Re: Fw: Rocket-List: cowl pressure
If this is true, why did Nemesis, arguably the most efficient air-cooled airplane engine combo ever built utilize a forced air plenum, downdraft vacuum cowling? I think Van had to compromise for MANY applications, not just speed. If your system works, great, but do you have 3000+ flying examples to brag on? Rob Ray --- "C. Rabaut" wrote: > > > Okay, having said that give us the solution that > utilizes that lost 70% > flow (or a large portion thereof). > > > ----- Original Message ----- > From: <LesDrag(at)aol.com> > To: > Subject: Re: Rocket-List: cowl pressure > > > > --> Rocket-List message posted by: LesDrag(at)aol.com > > > > I never have understood why everyone used the top > of the cowl for part of > the > > baffling. It causes all of the cowl surfaces to > be providing upward > > pressure. (Bernoulli's on the outside top > surface, "pressure" on forward > 3/4 > > of the inside top surface, impact pressure > exceeding bernoulli's on the > > outside bottom surface, and "vacuum" on the inside > bottom surface.) > > > > It is also very inefficient. In the typical Van's > cowl (which is cleaner > > than most manufacturers), there is a 70% net flow > loss in the air just > going > > from the air inlet to the engine cylinders. > > > > JMHO > > > > Jim Ayers > > Less Drag Products, Inc. > > > > > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Subject: Virus attachment
Date: Oct 04, 2002
Hi Guys & Gals, I just got a virus (my software caught & cleaned it) with the sender listed as Larry Bowen and the subject listed as: "Re: RV-list: flying the wing - SLOW FLIGHT". Now whoever is trying to get us, is obviously subscribing to the list and purposely copying folks' name & our subject lines in an attempt to infect our computers. I wonder if I can lure this clown, ID him (or her), and prosecute 'em. The following message is directed to the "hacker".... Okay you little spineless scum, I'm an Lt. on a local PD and I'm looking for alittle challenge (you're about as little as I'm gonna to find). How about you give me your best shot... and I'll see if I can't get YOU!!! Come on let's do this.... my email address is crabaut(at)coalinga.com and I'm set up & waitin' just for you ________________________________________________________________________________
Subject: Re: Virus attachment
Date: Oct 04, 2002
Whoever sent it probably didn't know he (she) did it. Just keep your virus checker current. Sometimes a message to the sender letting them know they have a virus helps, but a lot of the time, the sending e-mail addresses are bogus also, which helps hide the true culpret, whether they are knowing or not. Dave ----- Original Message ----- From: "C. Rabaut" <crabaut(at)coalinga.com> Subject: RV4-List: Virus attachment > > Hi Guys & Gals, > > I just got a virus (my software caught & cleaned it) with the sender > listed as Larry Bowen and the subject listed as: "Re: RV-list: flying the > wing - SLOW FLIGHT". > > Now whoever is trying to get us, is obviously subscribing to the list and > purposely copying folks' name & our subject lines in an attempt to infect > our computers. I wonder if I can lure this clown, ID him (or her), and > prosecute 'em. > > The following message is directed to the "hacker".... > > Okay you little spineless scum, I'm an Lt. on a local PD and I'm looking > for alittle challenge (you're about as little as I'm gonna to find). How > about you give me your best shot... and I'll see if I can't get YOU!!! > Come on let's do this.... my email address is crabaut(at)coalinga.com and I'm > set up & waitin' just for you > > ________________________________________________________________________________
Subject: Bleeding Brakes
Date: Oct 10, 2002
Hi everyone. After having a close encounter with a hangar on our airstrip, I suppose it is time for me do deal with that soft left brake pedal. Unfortunately, I know nothing about how to bleed brakes (except for the obvious need to replace air with brake fluid.) Do I need any special tools to do this? Is the nipple (that looks like a grease fitting) on my brake really a grease fitting, or is it used for bleeding the brakes? ANY tips will be greatly appreciated. Thanks in advance! Steve Mullins, Ph.D. Associate Professor of Economics Drury University 417.889.5609 (home) 417.873.7299 (office) ________________________________________________________________________________
Subject: Re: Bleeding Brakes
Date: Oct 10, 2002
Another question about RV brakes. I noticed Van's sells milspec fluid which is red. The small amount of fluid that was left in my system was not red, more of a light oil color. Should I get the red stuff? Thanks folks... Steve Mullins, Ph.D. Associate Professor of Economics Drury University 417.889.5609 (home) 417.873.7299 (office) ----- Original Message ----- From: "Steve Mullins" <smullins(at)drury.edu> Subject: RV4-List: Bleeding Brakes > > Hi everyone. > > After having a close encounter with a hangar on our airstrip, I suppose it is time for me do deal with that soft left brake pedal. Unfortunately, I know nothing about how to bleed brakes (except for the obvious need to replace air with brake fluid.) > > Do I need any special tools to do this? Is the nipple (that looks like a grease fitting) on my brake really a grease fitting, or is it used for bleeding the brakes? > > ANY tips will be greatly appreciated. > > Thanks in advance! > > Steve Mullins, Ph.D. > Associate Professor of Economics > Drury University > 417.889.5609 (home) > 417.873.7299 (office) > > ________________________________________________________________________________
Date: Oct 10, 2002
Dr. Mullins, Any Mil Spec H-5606 aircraft hydraulic fluid will be fine. You can probably get some from your friendly neighborhood A&P or FBO. That thing that looks like a grease fitting is the bleeder screw. It should be on the bottom of the caliper with the brake line on top. You will be pumping fluid in from the bottom, pushing all the air bubbles out the top, on up to the master cylinder and out the top of the master cylinder. Get yourself a large (at least 16 ounces) pump type oil can and fill it with the H-5606. Loosen the bleeder screw on the bottom of the caliper with a 1/4" wrench (you may need to use the box end to get it cracked loose) and drain all the old fluid into a can or bowl. Pump that side brake pedal a few times to get all the fluid out. Wrap a bunch of rags around the master cylinder to catch the over flow. Use a piece of small hose to connect the oil pump can to the bleeder screw. Have a buddy watch the master cylinder to holler once it is full. Start pumping the oil can quickly to get all the bubbles moved up and out and when your friend yells, then stop pumping and tighten the screw so the fluid doesn't run out. Some H-5606 has more red dye in it, some less. It doesn't matter. It all turns brown after a while because the die deteriorates. Make CERTAIN that the brake fluid now in your cylinders is not glycerin-based automotive DOT3 brake fluid - that stuff will eat all your seals and O-rings. Then you will need to rebuild all the parts in the brake system. H-5606 is petroleum based oil and really isn't much more than light weight motor oil. It is usually very available locally. Good Luck, Linc After having a close encounter with a hangar on our airstrip, I suppose it is time for me do deal with that soft left brake pedal. Unfortunately, I know nothing about how to bleed brakes (except for the obvious need to replace air with brake fluid.) > > Do I need any special tools to do this? Is the nipple (that looks like a grease fitting) on my brake really a grease fitting, or is it used for bleeding the brakes? > > ANY tips will be greatly appreciated. > ------------------------------------------- Introducing NetZero Long Distance Unlimited Long Distance only $29.95/ month! Sign Up Today! www.netzerolongdistance.com ________________________________________________________________________________
Date: Oct 10, 2002
Also make sure your master cyllinders weren't installed upside down, then the procedure below will have to add: remove master cyllinders from pedals, invert and then apply listed procedure... RR --- flyseaplane wrote: > > > Dr. Mullins, > > Any Mil Spec H-5606 aircraft hydraulic fluid will be > fine. You can probably > get some from your friendly neighborhood A&P or FBO. > > That thing that looks like a grease fitting is the > bleeder screw. It should > be on the bottom of the caliper with the brake line > on top. You will be > pumping fluid in from the bottom, pushing all the > air bubbles out the top, > on up to the master cylinder and out the top of the > master cylinder. > > Get yourself a large (at least 16 ounces) pump type > oil can and fill it with > the H-5606. Loosen the bleeder screw on the bottom > of the caliper with a > 1/4" wrench (you may need to use the box end to get > it cracked loose) and > drain all the old fluid into a can or bowl. Pump > that side brake pedal a few > times to get all the fluid out. Wrap a bunch of rags > around the master > cylinder to catch the over flow. Use a piece of > small hose to connect the > oil pump can to the bleeder screw. Have a buddy > watch the master cylinder to > holler once it is full. Start pumping the oil can > quickly to get all the > bubbles moved up and out and when your friend yells, > then stop pumping and > tighten the screw so the fluid doesn't run out. > > Some H-5606 has more red dye in it, some less. It > doesn't matter. It all > turns brown after a while because the die > deteriorates. Make CERTAIN that > the brake fluid now in your cylinders is not > glycerin-based automotive DOT3 > brake fluid - that stuff will eat all your seals and > O-rings. Then you will > need to rebuild all the parts in the brake system. > H-5606 is petroleum based > oil and really isn't much more than light weight > motor oil. It is usually > very available locally. > > Good Luck, > Linc > > > After having a close encounter with a hangar on our > airstrip, I suppose it > is time for me do deal with that soft left brake > pedal. Unfortunately, I > know nothing about how to bleed brakes (except for > the obvious need to > replace air with brake fluid.) > > > > Do I need any special tools to do this? Is the > nipple (that looks like a > grease fitting) on my brake really a grease fitting, > or is it used for > bleeding the brakes? > > > > ANY tips will be greatly appreciated. > > > > > ------------------------------------------- > Introducing NetZero Long Distance > Unlimited Long Distance only $29.95/ month! > Sign Up Today! www.netzerolongdistance.com > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com ________________________________________________________________________________
Date: Oct 10, 2002
Steve, I bleed my brakes by filling them fron the bottom at the calipers. Just loosen the valve a turn or so and feed into the system from there. Now you want to know how right? Well, get yourself an oilcan that you can pump oil out with the trigger, next take a piece of neoprene hose that will fit on the outlet of the oil can and secure it on the can with a clamp or tywrap. Now place the hose on the valve ( you need to have a snug fit here) Remove the resevoir cap.Now just pump the brake fluid in and have a buddy check the brake resevoir to let you know when it is full.(usually when it overflows) Then tighten the valve up and your system will be full. It will pump through the cylinder and reach the fluid resevoir.Do each side. Thats the way I have done it and it works just fine. Put a rag below the resevoir to catch the spilled fluid. DON'T forget to take the rag out of the engine compartment as it could cause problems. Hope this helps,Jim RV-4 # 111 ________________________________________________________________________________
Date: Oct 10, 2002
From: Dave Anderson <DaveAnderson(at)rocketmail.com>
I use a glue syringe, about $1 from a hobby store. --- FLYBOYRV4(at)aol.com wrote: > > Steve, I bleed my brakes by filling them fron the bottom at the > calipers. > Just loosen the valve a turn or so and feed into the system from > there. Now > you want to know how right? Well, get yourself an oilcan that you can > pump > oil out with the trigger, next take a piece of neoprene hose that > will fit on > the outlet of the oil can and secure it on the can with a clamp or > tywrap. > Now place the hose on the valve ( you need to have a snug fit here) > Remove > the resevoir cap.Now just pump the brake fluid in and have a buddy > check > the brake resevoir to let you know when it is full.(usually when it > overflows) Then tighten the valve up and your system will be full. It > will > pump through the cylinder and reach the fluid resevoir.Do each side. > Thats > the way I have done it and it works just fine. Put a rag below the > resevoir > to catch the spilled fluid. DON'T forget to take the rag out of the > engine > compartment as it could cause problems. Hope this helps,Jim RV-4 # > 111 > > > > > > > > Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com ________________________________________________________________________________
Date: Oct 11, 2002
Hey, rob ray, I think I once was party to actually adding auto tranny fluid to a Citabria's brake line a few years back. Ever hear of such a thing? Jim ----- Original Message ----- From: "rob ray" <smokyray(at)yahoo.com> Subject: Re: RV4-List: Bleeding Brakes > > Also make sure your master cyllinders weren't > installed upside down, then the procedure below will > have to add: remove master cyllinders from pedals, > invert and then apply listed procedure... > > RR > --- flyseaplane wrote: > > > > > > Dr. Mullins, > > > > Any Mil Spec H-5606 aircraft hydraulic fluid will be > > fine. You can probably > > get some from your friendly neighborhood A&P or FBO. > > > > That thing that looks like a grease fitting is the > > bleeder screw. It should > > be on the bottom of the caliper with the brake line > > on top. You will be > > pumping fluid in from the bottom, pushing all the > > air bubbles out the top, > > on up to the master cylinder and out the top of the > > master cylinder. > > > > Get yourself a large (at least 16 ounces) pump type > > oil can and fill it with > > the H-5606. Loosen the bleeder screw on the bottom > > of the caliper with a > > 1/4" wrench (you may need to use the box end to get > > it cracked loose) and > > drain all the old fluid into a can or bowl. Pump > > that side brake pedal a few > > times to get all the fluid out. Wrap a bunch of rags > > around the master > > cylinder to catch the over flow. Use a piece of > > small hose to connect the > > oil pump can to the bleeder screw. Have a buddy > > watch the master cylinder to > > holler once it is full. Start pumping the oil can > > quickly to get all the > > bubbles moved up and out and when your friend yells, > > then stop pumping and > > tighten the screw so the fluid doesn't run out. > > > > Some H-5606 has more red dye in it, some less. It > > doesn't matter. It all > > turns brown after a while because the die > > deteriorates. Make CERTAIN that > > the brake fluid now in your cylinders is not > > glycerin-based automotive DOT3 > > brake fluid - that stuff will eat all your seals and > > O-rings. Then you will > > need to rebuild all the parts in the brake system. > > H-5606 is petroleum based > > oil and really isn't much more than light weight > > motor oil. It is usually > > very available locally. > > > > Good Luck, > > Linc > > > > > > After having a close encounter with a hangar on our > > airstrip, I suppose it > > is time for me do deal with that soft left brake > > pedal. Unfortunately, I > > know nothing about how to bleed brakes (except for > > the obvious need to > > replace air with brake fluid.) > > > > > > Do I need any special tools to do this? Is the > > nipple (that looks like a > > grease fitting) on my brake really a grease fitting, > > or is it used for > > bleeding the brakes? > > > > > > ANY tips will be greatly appreciated. > > > > > > > > > ------------------------------------------- > > Introducing NetZero Long Distance > > Unlimited Long Distance only $29.95/ month! > > Sign Up Today! www.netzerolongdistance.com > > > > > > > > Contributions of > > any other form > > > > latest messages. > > other List members. > > > > http://www.matronics.com/subscription > > http://www.matronics.com/photoshare > > http://www.matronics.com/search > > http://www.matronics.com/archives > > http://www.matronics.com/emaillists > > > > > > > > > > > > > Faith Hill - Exclusive Performances, Videos & More > http://faith.yahoo.com > > ________________________________________________________________________________
Date: Oct 11, 2002
Steve, I'm curious - did you see the large number of responses to your questions on the RV-List to the brake bleeding question you posted on the RV4-List? Any message posted to one of the RV model specific list also gets posted to the main RV List. Any responses to the copy of the message that goes to the main RV List only go to the main RV List - they don't go back to the RV model specific list, so I would imagine that the person who asked the original question may never see the flurry of answers. Kevin Horton RV-8 (cowling, wing tip lights) Ottawa, Canada http://members.rogers.com/khorton/rv8.html >--> RV-List message posted by: "Steve Mullins" > >Another question about RV brakes. I noticed Van's sells milspec fluid which >is red. The small amount of fluid that was left in my system was not red, >more of a light oil color. Should I get the red stuff? > >Thanks folks... > >Steve Mullins, Ph.D. >Associate Professor of Economics >Drury University >417.889.5609 (home) >417.873.7299 (office) >----- Original Message ----- >From: "Steve Mullins" <smullins(at)drury.edu> >To: >Subject: RV4-List: Bleeding Brakes > > >> >> Hi everyone. >> >> After having a close encounter with a hangar on our airstrip, I suppose >it is time for me do deal with that soft left brake pedal. Unfortunately, I >know nothing about how to bleed brakes (except for the obvious need to >replace air with brake fluid.) >> >> Do I need any special tools to do this? Is the nipple (that looks like a >grease fitting) on my brake really a grease fitting, or is it used for >bleeding the brakes? >> >> ANY tips will be greatly appreciated. >> >> Thanks in advance! >> >> Steve Mullins, Ph.D. >> Associate Professor of Economics >> Drury University >> 417.889.5609 (home) > > 417.873.7299 (office) >> > > ________________________________________________________________________________
Date: Oct 11, 2002
Hi Jim; Hmmmm, could be. I remember adding something even less hydraulic and more "organic" than that one time in a pinch. Definitely had to purge the brakes when I got home though! The only funny part was watching this old dude passerby as we "relieved ourselves" of brake fluid into a coke bottle and poured it into the Scouts resevoir.... RR --- James Lawliss wrote: > > > Hey, rob ray, I think I once was party to actually > adding auto tranny fluid > to a Citabria's brake line a few years back. Ever > hear of such a thing? > Jim > > ----- Original Message ----- > From: "rob ray" <smokyray(at)yahoo.com> > To: > Subject: Re: RV4-List: Bleeding Brakes > > > > > > > Also make sure your master cyllinders weren't > > installed upside down, then the procedure below > will > > have to add: remove master cyllinders from pedals, > > invert and then apply listed procedure... > > > > RR > > --- flyseaplane wrote: > > > > > > > > > Dr. Mullins, > > > > > > Any Mil Spec H-5606 aircraft hydraulic fluid > will be > > > fine. You can probably > > > get some from your friendly neighborhood A&P or > FBO. > > > > > > That thing that looks like a grease fitting is > the > > > bleeder screw. It should > > > be on the bottom of the caliper with the brake > line > > > on top. You will be > > > pumping fluid in from the bottom, pushing all > the > > > air bubbles out the top, > > > on up to the master cylinder and out the top of > the > > > master cylinder. > > > > > > Get yourself a large (at least 16 ounces) pump > type > > > oil can and fill it with > > > the H-5606. Loosen the bleeder screw on the > bottom > > > of the caliper with a > > > 1/4" wrench (you may need to use the box end to > get > > > it cracked loose) and > > > drain all the old fluid into a can or bowl. Pump > > > that side brake pedal a few > > > times to get all the fluid out. Wrap a bunch of > rags > > > around the master > > > cylinder to catch the over flow. Use a piece of > > > small hose to connect the > > > oil pump can to the bleeder screw. Have a buddy > > > watch the master cylinder to > > > holler once it is full. Start pumping the oil > can > > > quickly to get all the > > > bubbles moved up and out and when your friend > yells, > > > then stop pumping and > > > tighten the screw so the fluid doesn't run out. > > > > > > Some H-5606 has more red dye in it, some less. > It > > > doesn't matter. It all > > > turns brown after a while because the die > > > deteriorates. Make CERTAIN that > > > the brake fluid now in your cylinders is not > > > glycerin-based automotive DOT3 > > > brake fluid - that stuff will eat all your seals > and > > > O-rings. Then you will > > > need to rebuild all the parts in the brake > system. > > > H-5606 is petroleum based > > > oil and really isn't much more than light weight > > > motor oil. It is usually > > > very available locally. > > > > > > Good Luck, > > > Linc > > > > > > > > > After having a close encounter with a hangar on > our > > > airstrip, I suppose it > > > is time for me do deal with that soft left brake > > > pedal. Unfortunately, I > > > know nothing about how to bleed brakes (except > for > > > the obvious need to > > > replace air with brake fluid.) > > > > > > > > Do I need any special tools to do this? Is the > > > nipple (that looks like a > > > grease fitting) on my brake really a grease > fitting, > > > or is it used for > > > bleeding the brakes? > > > > > > > > ANY tips will be greatly appreciated. > > > > > > > > > > > > > ------------------------------------------- > > > Introducing NetZero Long Distance > > > Unlimited Long Distance only $29.95/ month! > > > Sign Up Today! www.netzerolongdistance.com > > > > > > > > > > > > Contributions of > > > any other form > > > > > > latest messages. > > > other List members. > > > > > > http://www.matronics.com/subscription > > > http://www.matronics.com/photoshare > > > http://www.matronics.com/search > > > http://www.matronics.com/archives > > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > > > > > > > > Faith Hill - Exclusive Performances, Videos & More > > http://faith.yahoo.com > > > > > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > http://health.yahoo.com ________________________________________________________________________________
Date: Oct 11, 2002
Hey Jim Lawless, Yes, you can use ATF in a pinch. It will work fine, but it is thinner than H-5606 so it will leak easier if you have a weak O-ring, or a sloppy master cylinder won't pump as hard, but those are WORST CASE scenarios. It shouldn't hurt a thing. > to a Citabria's brake line a few years back. Ever hear of such a thing? > Jim ------------------------------------------- Introducing NetZero Long Distance Unlimited Long Distance only $29.95/ month! Sign Up Today! www.netzerolongdistance.com ________________________________________________________________________________
Date: Oct 12, 2002
Thanks to everyone who provided tips about bleeding my brakes....this list is worth a million bucks!!! Steve Mullins, Ph.D. Associate Professor of Economics Drury University 417.889.5609 (home) 417.873.7299 (office) ________________________________________________________________________________
Subject: 402 Weldments
Date: Oct 12, 2002
It appears that I must trim about 1/4 inch from the skin side of the base plate of the 402 weldments in order to make the sides of the longerons close enough to the skin line to rivet the skin to the longerons and legs of the weldment. This is a very critical area since the engine mount bolts go through these plates. Is there anyone else who is having or who remembers having this problem? If so, how did it work out? Dave Cooke North Idaho Fuselage ________________________________________________________________________________
Date: Oct 13, 2002
Subject: For Sale: new Van's FP-12 spinner kit
For sale. Van's FP-12, 12" spinner kit for wooden prop. Has 12 inch rear bulkhead. New in box. $105 new from Vans, will sell for $80 including shipping. COD extra. Roger ________________________________________________________________________________
Subject: Re: 402 Weldments
Date: Oct 13, 2002
Dave, I just replaced the 402 and 403 old style brackets in my aircraft S/N 62. They fit almost perfect. Check the dimensions of the brackets with the numbers on sheet 34 of the plans, if you haven't already. There may have been a mistake in the manufacture of the brackets. If not that, I would not have a clue. They should just lay right in there. Hopefully some else may have and answer. Tom Rupe S/N 62 ----- Original Message ----- From: "Dave Cooke" <pitot(at)norlight.org> Subject: RV4-List: 402 Weldments > > It appears that I must trim about 1/4 inch from the skin side of the base plate of the 402 weldments in order to make the sides of the longerons close enough to the skin line to rivet the skin to the longerons and legs of the weldment. This is a very critical area since the engine mount bolts go through these plates. Is there anyone else who is having or who remembers having this problem? If so, how did it work out? > > Dave Cooke > > North Idaho > > Fuselage > > ________________________________________________________________________________
Date: Oct 13, 2002
Subject: firewall corners buckling
Has anyone had experience with the lower firewall corners buckling slightly? My RV-4 0-320 150HP had cracks in the motor mount around the lower and middle weldments next to the firewall area. I had gussets welded to this mount and it should be stronger than ever but now do I need to replace the buckled skin in these lower corners or just straighten them back out as best can and put the bird back together? I have inspected inside the fuselage at all 6 bolt areas and find nothing that looks wrong. Any suggestions would be appreciated as it has now been about 30 days since airworthy and I am going crazy sitting here on deck. Greg Hunsicker Sunset Strip Airpark 90KS Berryton, KS ________________________________________________________________________________
Date: Oct 14, 2002
Subject: Re: firewall corners buckling
I have an RV-4 with 1310 hours, 1301 flown with an 0-320 F/P prop. When I bought the aircraft in 1996 it had 525 hours and a 1 " long wrinkle along the (pilot's) left firewall step vertical bend about 2/3 of the way from the top of the step out. At 850 or so hours I had a 1/4 "crack in the engine mount cluster by the left landing gear rod mounting tube - repaired by TIG welding. The 1 " wrinkle never grew or changed. I just reengined with a new mount (conical to dynafocal) 0-360 and C/S prop. I straightened the wrinkle as best possible while modifying the firewall. Bottom line, check it, but don't worry about it. >>> gh2538(at)cjnetworks.com 10/13/02 08:04PM >>> Has anyone had experience with the lower firewall corners buckling slightly? My RV-4 0-320 150HP had cracks in the motor mount around the lower and middle weldments next to the firewall area. I had gussets welded to this mount and it should be stronger than ever but now do I need to replace the buckled skin in these lower corners or just straighten them back out as best can and put the bird back together? I have inspected inside the fuselage at all 6 bolt areas and find nothing that looks wrong. Any suggestions would be appreciated as it has now been about 30 days since airworthy and I am going crazy sitting here on deck. Greg Hunsicker Sunset Strip Airpark 90KS Berryton, KS ________________________________________________________________________________
Date: Oct 14, 2002
For me the buckling of the lower corners of the firewall meant cracked weldments. I assume that you have examined those carefully. ________________________________________________________________________________
Subject: Cracked Engine Mount Weldments
Date: Oct 14, 2002
JKL Greg, This is probably all wrong, but something for all of us to think about......you wrote, "cracks in the motor mount around the lower and middle weldments next to the firewall area. I had gussets welded to this mount and it should be stronger than ever." I might suggest that welding the mounts may have caused the "temper" to be changed either softer or harder, which could cause excess movement, or not enough, which possibly could cause the skin in that area to buckle. For a critical area such as the engine mounts, I don't think I would let anyone weld them unless they were a Certified Aircraft Welder, because that heat has to be perfect for that type of metal. There is one other thing to think about......If there were no hard landings, maybe crosswinds during landing or takeoff could be responsible. Crosswinds can cause incredible side loads and torsion on all aspects of our landing gear system and this is transferred throughout the entire attached area of the fuselage......take a look at your tires after a good bout with a crosswind, and think about all the rudder "kicking" that took place to just stay on the runway..........CHEERS!!!!!! jK ________________________________________________________________________________
Subject: Re: Cracked Engine Mount Weldments
Date: Oct 14, 2002
Operation from rough field can add to the stress. As for crosswind landings - work on technique - you ought to ba able to touch down one wing low if necessary to avoid landing in a crab with resulting big swerve/side loads.... Richard RV-4 N144KT ( Rebuilding and installing new canopy) ________________________________________________________________________________
Date: Oct 14, 2002
I had the mount tig welded as per Vans directions. I do appreciate your thoughts though on the subject. In my case I had a couple pretty hard landings doing some very short field practice. For my sake I am glad that my practice has been made perfect. Greg Hunsicker Gene Smith wrote: > >JKL Greg, > This is probably all wrong, but something for all of us to think about......you wrote, "cracks in the motor mount around the lower and middle weldments next to the firewall area. I had gussets welded to this mount and it should be stronger than ever." > I might suggest that welding the mounts may have caused the "temper" to be changed either softer or harder, which could cause excess movement, or not enough, which possibly could cause the skin in that area to buckle. For a critical area such as the engine mounts, I don't think I would let anyone weld them unless they were a Certified Aircraft Welder, because that heat has to be perfect for that type of metal. > There is one other thing to think about......If there were no hard landings, maybe crosswinds during landing or takeoff could be responsible. Crosswinds can cause incredible side loads and torsion on all aspects of our landing gear system and this is transferred throughout the entire attached area of the fuselage......take a look at your tires after a good bout with a crosswind, and think about all the rudder "kicking" that took place to just stay on the runway..........CHEERS!!!!!! jK > > > > ________________________________________________________________________________
Date: Oct 14, 2002
In addition to all that Gene listed below... RV-4's firewalls have a tendency to buckle. ----- Original Message ----- From: Gene Smith <esmith6(at)satx.rr.com> Subject: RV4-List: Cracked Engine Mount Weldments > > JKL Greg, > This is probably all wrong, but something for all of us to think about......you wrote, "cracks in the motor mount around the lower and middle weldments next to the firewall area. I had gussets welded to this mount and it should be stronger than ever." > I might suggest that welding the mounts may have caused the "temper" to be changed either softer or harder, which could cause excess movement, or not enough, which possibly could cause the skin in that area to buckle. For a critical area such as the engine mounts, I don't think I would let anyone weld them unless they were a Certified Aircraft Welder, because that heat has to be perfect for that type of metal. > There is one other thing to think about......If there were no hard landings, maybe crosswinds during landing or takeoff could be responsible. Crosswinds can cause incredible side loads and torsion on all aspects of our landing gear system and this is transferred throughout the entire attached area of the fuselage......take a look at your tires after a good bout with a crosswind, and think about all the rudder "kicking" that took place to just stay on the runway..........CHEERS!!!!!! jK > > ________________________________________________________________________________
Subject: RV-4 Spinner and Prop Extension
Date: Oct 15, 2002
Hello All, I own an older RV-4 (#4) fitted with a wooden prop. The aircraft was built with a metal fixed pitch prop and then converted to the wooden one. A 4" prop extension was installed which created a 1.5 inch gap between the cowling and the spinner. I am looking to purchase (new or used) a 3" extension (6 hole, 7/16" bolt) and 13" diameter spinner. I would like a high aspect ratio spinner, preferably with a fairly sharp pointed nose. If anyone has such a spinner/extension for sale or could lead me to a source, please advise. Regards, Hank Landman ________________________________________________________________________________
Date: Oct 15, 2002
Subject: Re: RV-4 Spinner and Prop Extension
Hank; It sounds like you have a newer Constant speed cowling with a 4" extension for the older cowling. You can still buy a 2" extension drilled for 7/16 bolts from Van's and accomplish the mission. Aircraft Spruce has the spinner you desire.. Rob Ray --- Hank Landman wrote: > > > Hello All, > > I own an older RV-4 (#4) fitted with a wooden prop. > The aircraft was built with a metal fixed pitch prop > and then converted to the wooden one. A 4" prop > extension was installed which created a 1.5 inch gap > between the cowling and the spinner. I am looking > to purchase (new or used) a 3" extension (6 hole, > 7/16" bolt) and 13" diameter spinner. I would like > a high aspect ratio spinner, preferably with a > fairly sharp pointed nose. If anyone has such a > spinner/extension for sale or could lead me to a > source, please advise. > > Regards, > > Hank Landman > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com ________________________________________________________________________________
Date: Oct 15, 2002
Yes, they do, unless you build it with .040 fuselage sides to begin with...check for cracks at the lower corners of the firewall below the ldg gear attch points on your annual... RR --- "C. Rabaut" wrote: > > > In addition to all that Gene listed below... RV-4's > firewalls have a > tendency to buckle. > > ----- Original Message ----- > From: Gene Smith <esmith6(at)satx.rr.com> > To: rv4-list > Subject: RV4-List: Cracked Engine Mount Weldments > > > > > > > JKL Greg, > > This is probably all wrong, but something for > all of us to think > about......you wrote, "cracks in the motor mount > around the lower and middle > weldments next to the firewall area. I had gussets > welded to this mount and > it should be stronger than ever." > > I might suggest that welding the mounts may > have caused the "temper" > to be changed either softer or harder, which could > cause excess movement, or > not enough, which possibly could cause the skin in > that area to buckle. For > a critical area such as the engine mounts, I don't > think I would let anyone > weld them unless they were a Certified Aircraft > Welder, because that heat > has to be perfect for that type of metal. > > There is one other thing to think > about......If there were no hard > landings, maybe crosswinds during landing or takeoff > could be responsible. > Crosswinds can cause incredible side loads and > torsion on all aspects of our > landing gear system and this is transferred > throughout the entire attached > area of the fuselage......take a look at your tires > after a good bout with a > crosswind, and think about all the rudder "kicking" > that took place to just > stay on the runway..........CHEERS!!!!!! jK > > > > > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com ________________________________________________________________________________
Date: Oct 15, 2002
Amen on the rough strip. Mine is 900' long and rough. No mount cracks yet, but my firewall has hairline cracks below the mounts... Rob Ray --- Richard Bibb wrote: > > > Operation from rough field can add to the stress. > As for crosswind > landings - work on technique - you ought to ba able > to touch down one wing > low if necessary to avoid landing in a crab with > resulting big swerve/side > loads.... > > Richard > RV-4 N144KT ( Rebuilding and installing new canopy) > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com ________________________________________________________________________________
Date: Oct 15, 2002
EAA Chapter 339 Fall Fly-In Saturday, October 19, 2002, Hampton Roads Exec (PVG), Virginia, 9AM till 7PM Hampton Roads Exec (PVG) is 13.5nm SW of Norfolk, Virginia (253 radial (ORF) AWOS 118.375 CTAF 123.0 The weather will really be a perfect Virginia fall day! Aircraft parking is off taxiway between Rwy 23 and T-Hangars East of Airport Terminal Schedule of Events Fly-In Begins 9AM Food all Day 10AM - 3PM Poker Run (Walk Around Field) Project Visits on Field Aircraft Judging 11AM - 3PM, All Categories, Antiques, Classics, Homebuilts, Warbirds Social Hour 4PM Dinner 5PM - 7PM, BBQ Sandwiches, Chicken, Drinks Local motels/hotels are available For More Information Frank Toy 757-460-3680 ftoy(at)att.net Richard Reynolds 757-627-8743 rvreynolds(at)macs.net EAA Chapter 339 http://home.earthlink.net/~avyator/ Hampton Roads Exec Airport http://www.hamptonroadsexecutiveairport.com/index.html ________________________________________________________________________________
Date: Oct 15, 2002
I might just make it! RR --- "Richard V. Reynolds" wrote: > Reynolds" > > EAA Chapter 339 Fall Fly-In > > Saturday, October 19, 2002, Hampton Roads Exec > (PVG), Virginia, 9AM till > 7PM > Hampton Roads Exec (PVG) is 13.5nm SW of Norfolk, > Virginia (253 radial > (ORF) > AWOS 118.375 > CTAF 123.0 > > The weather will really be a perfect Virginia fall > day! > > Aircraft parking is off taxiway between Rwy 23 and > T-Hangars East of > Airport Terminal > > Schedule of Events > Fly-In Begins 9AM > Food all Day 10AM - 3PM > Poker Run (Walk Around Field) > Project Visits on Field > Aircraft Judging 11AM - 3PM, All Categories, > Antiques, Classics, > Homebuilts, Warbirds > Social Hour 4PM > Dinner 5PM - 7PM, BBQ Sandwiches, Chicken, Drinks > > Local motels/hotels are available > For More Information > > Frank Toy 757-460-3680 > ftoy(at)att.net > Richard Reynolds 757-627-8743 > rvreynolds(at)macs.net > EAA Chapter 339 > http://home.earthlink.net/~avyator/ > Hampton Roads Exec Airport > http://www.hamptonroadsexecutiveairport.com/index.html > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com ________________________________________________________________________________
Date: Oct 16, 2002
Subject: Re: URGENT BUSINESS PROPOSAL
In a message dated 10/15/2002 8:26:07 PM Pacific Daylight Time, chukwuebuka02uc(at)yahoo.com writes: > chukwuebuka02uc(at)yahoo.com> > > DR.EBUKA D AGUSON > > FEDERAL MINISTRY OF PETROLUEM RESOURCES(F.M.P.R) > > LAGOS NIGERIA. > > ATTN:SIR, > > REQUEST FOR ASSISTANCE- STRICTLY CONFIDENTIAL > > I am Dr EBUKA AGUSON, an accountant in the Ministry of > petroleum Resources (MPR) and a member of a > three-man Tender Board in charge of contract review > and payment approvals. I came to know of you in my > search for a reliable person to handle a very > confidential transaction that involves the transfer of > a huge sum of money to a foreign account. It may > sound strange but exercise patience and read on. > > There were series of contracts executed by a > consortium Multinational in the Oil industry in favor > of Ministry of Petroleum Resources among which were: > > 1. The extension of pipeline network within Nigeria > for crude oil, Down stream products distribution and > subsequent evacuation- US$ 195 Million. > > 2. Contract for the Turn Around Maintenance (TAM) of > the various refineries in the country~ US$ 152 > Million. > > 3. The construction of storage tanks for petroleum > products (Depots) US$240 Million. > > The original values of this contract were deliberately > over invoiced to the sum of US $35.5million American > Dollars which has now been approved and is now ready > to be transferred being that the companies > that actually executed these contracts has been fully > paid and project officially commissioned. > consequently, my colleagues and I are willing to > transfer the total amount to your account for > subsequent disbursement since we are Civil Servant > and are prohibited by the Code of Conduct Bureau > (Civil Servant Laws) from opening operating foreign > account in our names. Needless to say, the trust posed > on you at this juncture is enormous. In return, we > have agreed to offer you 30% of the transferred sum > while 10% shall be set aside for accidental expenses > (Internal & External) between the parties in the > course of the transfer. We will mandate you to draw > up an investment plan for us of which you will > control since we cannot bring our shares back to > Nigeria. We are very interested in investing in real > estate in your country. You must however note that > this transaction is subjected to the following terms > and conditions: > > 1. Our conviction of your transparent honesty and > diligence. > > 2. That you would treat this transaction with utmost > secrecy and confidentiality because of the > circumstances we now find ourselves. > > 3. That the funds would be transferred to an account > over which you have absolute control. Modalities > have been worked out at the highest level of the > presidency at the Central Bank of Nigeria for the > immediate transfer of the funds within 14 working > days, subject to your satisfaction of the above stated > terms. Our assurance is that your role is 100% risk > free. To accord this transaction, the legality it > deserves and for mutual security of the parties > involved and the funds, the whole approval procedures > will be officially and legally processed with your > name or the name of your company you may nominate > as the bonafide beneficiary. Also, be informed that > our main reason of contacting you is for the obvious > reason that we will want to invest these funds in the > real estate. It is our believe that you can be of > immense help in this regards. > > Kindly expedite action so as to enable us include this > transaction into this batch as payment to foreign > contractors is usually carried out on quarterly > basis. > > > Best regards, > > DR.EBUKA D AGUSON > > Hey I am transparently honest....Sure, hot damm....where do I sign up?.....who can I send all my money to? I can take my net worth plus my kids college fund, cash in my 401K, barrow some cash from my sister, fly every other weekend instead of every week, wow! what a deal! This is the best internet offer yet! This must be a true deal because the offer is from a real Doctor with one hell of a title on the RV list...I am so excited now I might be able to really afford my RV-4 and be just like all those guys I fly with, they all have endless amounts of cash and multiple paid off credit cards, this is triple bitchen man! I am ready!...........................lets see! ..........I have $ 139.42 lets get started. I do have just one question.......................Do you need all of that at once or can I make payments. Tim Barnes Meangreen RV-4 ________________________________________________________________________________
Date: Oct 16, 2002
How do you spell, IMCLONE....What does this have to do with RV4's? RR --- "DR.EBUKA D AGUSON" wrote: > AGUSON" > > DR.EBUKA D AGUSON > > FEDERAL MINISTRY OF PETROLUEM RESOURCES(F.M.P.R) > > LAGOS NIGERIA. > > ATTN:SIR, > > REQUEST FOR ASSISTANCE- > STRICTLY CONFIDENTIAL > > I am Dr EBUKA AGUSON, an accountant in the Ministry > of > petroleum Resources (MPR) and a member of a > three-man Tender Board in charge of contract review > and payment approvals. I came to know of you in my > search for a reliable person to handle a very > confidential transaction that involves the transfer > of > a huge sum of money to a foreign account. It may > sound strange but exercise patience and read on. > > There were series of contracts executed by a > consortium Multinational in the Oil industry in > favor > of Ministry of Petroleum Resources among which > were: > > 1. The extension of pipeline network within Nigeria > for crude oil, Down stream products distribution > and > subsequent evacuation- US$ 195 Million. > > 2. Contract for the Turn Around Maintenance (TAM) of > the various refineries in the country~ US$ 152 > Million. > > 3. The construction of storage tanks for petroleum > products (Depots) US$240 Million. > > The original values of this contract were > deliberately > over invoiced to the sum of US $35.5million > American > Dollars which has now been approved and is now > ready > to be transferred being that the companies > that actually executed these contracts has been > fully > paid and project officially commissioned. > consequently, my colleagues and I are willing to > transfer the total amount to your account for > subsequent disbursement since we are Civil Servant > and are prohibited by the Code of Conduct Bureau > (Civil Servant Laws) from opening operating foreign > account in our names. Needless to say, the trust > posed > on you at this juncture is enormous. In return, we > have agreed to offer you 30% of the transferred sum > while 10% shall be set aside for accidental > expenses > (Internal & External) between the parties in the > course of the transfer. We will mandate you to draw > up an investment plan for us of which you will > control since we cannot bring our shares back to > Nigeria. We are very interested in investing in real > estate in your country. You must however note that > this transaction is subjected to the following > terms > and conditions: > > 1. Our conviction of your transparent honesty and > diligence. > > 2. That you would treat this transaction with utmost > secrecy and confidentiality because of the > circumstances we now find ourselves. > > 3. That the funds would be transferred to an account > over which you have absolute control. Modalities > have been worked out at the highest level of the > presidency at the Central Bank of Nigeria for the > immediate transfer of the funds within 14 working > days, subject to your satisfaction of the above > stated > terms. Our assurance is that your role is 100% risk > free. To accord this transaction, the legality it > deserves and for mutual security of the parties > involved and the funds, the whole approval > procedures > will be officially and legally processed with your > name or the name of your company you may nominate > as the bonafide beneficiary. Also, be informed > that > our main reason of contacting you is for the > obvious > reason that we will want to invest these funds in > the > real estate. It is our believe that you can be of > immense help in this regards. > > Kindly expedite action so as to enable us include > this > transaction into this batch as payment to foreign > contractors is usually carried out on quarterly > basis. > > > Best regards, > > DR.EBUKA D AGUSON > > > > > > Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com ________________________________________________________________________________
From: "Murphy, Richard James (Rick)" <rjmurphy1(at)lucent.com>
Subject: URGENT BUSINESS PROPOSAL
Date: Oct 16, 2002
If you guys haven't seen this before it is a big time web scam. New twist on an aold sham. They just want to deposit a large sum of money into your bank account (of course they need the acct number)and you get to keep the interest. Cept when you go back to look at your balance, there is no money there, not theirs, not yours, nothing. They bomb the web with this message hoping to get 1 out of 1000 to respond. Best defense is to hit the delete key. A twist on this scheme is that they pose as the Aviation Minister in Charge of Disposal of Surplus Aircraft for East BumbDiddy and have 10 P51's (or somesuch) in the crate since 1951 to dispose of and need a US import rep. IF you put up the ($10,000) import bond, you get to (keep/have a share etc) in one airplane. Delete, Delete, Delete. Don't even answer these people back. Rick Murphy -----Original Message----- From: rob ray [mailto:smokyray(at)yahoo.com] Subject: Re: RV4-List: URGENT BUSINESS PROPOSAL How do you spell, IMCLONE....What does this have to do with RV4's? RR --- "DR.EBUKA D AGUSON" wrote: > AGUSON" > > DR.EBUKA D AGUSON > > FEDERAL MINISTRY OF PETROLUEM RESOURCES(F.M.P.R) > > LAGOS NIGERIA. > > ATTN:SIR, > > REQUEST FOR ASSISTANCE- > STRICTLY CONFIDENTIAL > > I am Dr EBUKA AGUSON, an accountant in the Ministry > of > petroleum Resources (MPR) and a member of a > three-man Tender Board in charge of contract review > and payment approvals. I came to know of you in my > search for a reliable person to handle a very > confidential transaction that involves the transfer > of > a huge sum of money to a foreign account. It may > sound strange but exercise patience and read on. > > There were series of contracts executed by a > consortium Multinational in the Oil industry in > favor > of Ministry of Petroleum Resources among which > were: > > 1. The extension of pipeline network within Nigeria > for crude oil, Down stream products distribution > and > subsequent evacuation- US$ 195 Million. > > 2. Contract for the Turn Around Maintenance (TAM) of > the various refineries in the country~ US$ 152 > Million. > > 3. The construction of storage tanks for petroleum > products (Depots) US$240 Million. > > The original values of this contract were > deliberately > over invoiced to the sum of US $35.5million > American > Dollars which has now been approved and is now > ready > to be transferred being that the companies > that actually executed these contracts has been > fully > paid and project officially commissioned. > consequently, my colleagues and I are willing to > transfer the total amount to your account for > subsequent disbursement since we are Civil Servant > and are prohibited by the Code of Conduct Bureau > (Civil Servant Laws) from opening operating foreign > account in our names. Needless to say, the trust > posed > on you at this juncture is enormous. In return, we > have agreed to offer you 30% of the transferred sum > while 10% shall be set aside for accidental > expenses > (Internal & External) between the parties in the > course of the transfer. We will mandate you to draw > up an investment plan for us of which you will > control since we cannot bring our shares back to > Nigeria. We are very interested in investing in real > estate in your country. You must however note that > this transaction is subjected to the following > terms > and conditions: > > 1. Our conviction of your transparent honesty and > diligence. > > 2. That you would treat this transaction with utmost > secrecy and confidentiality because of the > circumstances we now find ourselves. > > 3. That the funds would be transferred to an account > over which you have absolute control. Modalities > have been worked out at the highest level of the > presidency at the Central Bank of Nigeria for the > immediate transfer of the funds within 14 working > days, subject to your satisfaction of the above > stated > terms. Our assurance is that your role is 100% risk > free. To accord this transaction, the legality it > deserves and for mutual security of the parties > involved and the funds, the whole approval > procedures > will be officially and legally processed with your > name or the name of your company you may nominate > as the bonafide beneficiary. Also, be informed > that > our main reason of contacting you is for the > obvious > reason that we will want to invest these funds in > the > real estate. It is our believe that you can be of > immense help in this regards. > > Kindly expedite action so as to enable us include > this > transaction into this batch as payment to foreign > contractors is usually carried out on quarterly > basis. > > > Best regards, > > DR.EBUKA D AGUSON > > > > > > Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com ________________________________________________________________________________
Date: Oct 16, 2002
Note: forwarded message attached. Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com Date: Tue, 15 Oct 2002 19:18:11 -0500 From: arvil(at)bellsouth.net Subject: Re: Fwd: Re: RV4-List: Cracked Engine Mount Weldments Rob, under normal or even rough landings the mounts should not crack' The early engine mount brackets at the upper and lower corners were first fused welded by vans supplyer, by that I mean the to parts were layed togather and useing a heliarc welder heated so the metal would melt or fuse togather with no filler rod added this makes for a real perty weld and a week joint at the point where the two metals join togather , Vans has now went to a little thicker metal on the mount brackets and filler weld is added to the bracket as it is being welded, tho this has solved most of the cracking it has not stoped the mount brackets from being damaged from hard landings, to help reduce the damage from accruing angel gusets should be added two to each corner at 90 drgees to each other and a large washer on the inside of the mount bracket to help keep the bolt from dishing the mount face where the bolt go,s through the motor mount bracket ,fire wall and motor mount, I also recommen putting the bolt through the motor mount bracket from the inside so the threads are faceing forward and extend through the motor mount boss this keeps the threads from being in the location of the highest stress point and less likly to snap a bolt on a hard landing Arvil rob ray wrote: > > Note: forwarded message attached. > > __________________________________________________ > Faith Hill - Exclusive Performances, Videos & More > http://faith.yahoo.com > > > Subject: Re: RV4-List: Cracked Engine Mount Weldments > Date: Mon, 14 Oct 2002 19:06:26 -0500 > From: Greg Hunsicker <gh2538(at)cjnetworks.com> > Reply-To: rv4-list(at)matronics.com > To: rv4-list(at)matronics.com > > > I had the mount tig welded as per Vans directions. I do appreciate your > thoughts though on the subject. In my case I had a couple pretty hard > landings doing some very short field practice. For my sake I am glad > that my practice has been made perfect. > > Greg Hunsicker > > Gene Smith wrote: > > > > >JKL Greg, > > This is probably all wrong, but something for all of us to think about......you wrote, "cracks in the motor mount around the lower and middle weldments next to the firewall area. I had gussets welded to this mount and it should be stronger than ever." > > I might suggest that welding the mounts may have caused the "temper" to be changed either softer or harder, which could cause excess movement, or not enough, which possibly could cause the skin in that area to buckle. For a critical area such as the engine mounts, I don't think I would let anyone weld them unless they were a Certified Aircraft Welder, because that heat has to be perfect for that type of metal. > > There is one other thing to think about......If there were no hard landings, maybe crosswinds during landing or takeoff could be responsible. Crosswinds can cause incredible side loads and torsion on all aspects of our landing gear system and this is transferred throughout the entire attached area of the fuselage......take a look at your tires after a good bout with a crosswind, and think about all the rudder "kicking" that took place to just stay on the runway..........CHEERS!!!!!! jK > > > > > > > > > ________________________________________________________________________________
Date: Oct 16, 2002
"Re: RV-List: posting" (Oct 16, 6:40pm) rv7-list(at)matronics.com, rv8-list(at)matronics.com, rv9-list(at)matronics.com, rv10-list(at)matronics.com
Subject: Re: posting (To Forward or Not to Forward...)
Kevin's right, except for the RV7, RV9, and RV10 Lists. The way its been set up is when someone posts to the RV3, RV4, RV6, and RV8 Lists a copy is automatically sent to the RV-List too. For some reason, the 7/9/10 lists weren't configured that way; probably because I added them later and forgot that about the forwarding. In anycase, for now I've added the forward feature the 7/9/10 Lists to keep everything consistant. However, I don't have a stong preference either way, actually. I can see pros and cons to each. Would people prefer the not-forwarding operation? Sounds like it they might... So let's vote! Drop me an email at: dralle(at)matronics.com with a simple: "Forward" or "Don't Forward" in the Subject Line. I'll added up the votes in a couple of days and announce the new method. Matt Dralle List Admin. >-------------- >--> RV-List message posted by: Kevin Horton > >Gary, > >Sorry, I have to respectfully disagree here. I am a member of Matt's >RV8-list and the RV-list. If I post a message to the RV8-list, I get >two copies - one that comes from the RV8-list, and a copy that comes >across on the main RV-list. > >I just checked my Out Box - my message to Steve was sent to the >RV4-List only. The copy you replied too seems to have come from the >main RV-List. > >Search the RV-List archives for the text " New Specific RV Lists Auto >Forwarded to RV-List" (don't include the quote marks. You'll find >Matt's description of how the system works. I believe it causes >confusion, because a lot of people on the main RV-List don't >understand that they need study the original message to see where it >originated, and send their response to the message to the correct >list. Otherwise, the original poster may not see the response. But, >Matt likes it the way it is, and these are his lists. > >Kevin > >>--> RV-List message posted by: "Gary" >> >>Kevin.....actually, messages posted to model-specific Matronics >>lists do not automatically post to the RV list. You can post to any >>list or combination of lists you like, but you have to send it to >>the ones you want it to show up on. >> >>Gary >> >>From: Kevin Horton <khorto1537(at)rogers.com> >>Subject: Re: RV-List: Re: RV4-List: Bleeding Brakes >> >>--> RV-List message posted by: Kevin Horton >> >>Steve, >> >>.................. Any message posted to one of the RV model specific >>list also gets posted to the main RV List. Any responses to the copy >>of the message that goes to the main RV List only go to the main RV >>List - they don't go back to the RV model specific list, ............... > > >-------------- -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Subject: RV4 Project for Sale
Date: Oct 17, 2002
Have a 4 project partially completed. Hoped to finish it, but life situation changed. If interested, it is drop me a line here or at rv4joe(at)sofnet.com. Located in southwest MO. email pics on request. ________________________________________________________________________________
Subject: FS: RV-4 Project (Southern Coastal Maine)
Date: Oct 19, 2002
Reluctantly, I have decided that I must sell my RV-4 project. It is at the proverbial 90% done, 90% remaining stage; i.e., all the major construction has been finished. The fuse is on the gear, wings are finished and primed, engine hung. The cowling needs to be mounted and the final mating of the wings to the fuse needs to be done. Nothing has been done on the instrument panel, but there are several instruments waiting to be placed into the panel. I have a Vision Microsystem for the RPM/Manifold/Fuel, etc. I also have two brand new orphaned Terra units: the COM and XPNDR (with Mode S mod). The starter/alternator are installed along with the battery and starter solenoids following Electric Bob's instructions. The project is located in Southern Maine, about 70 miles North of Boston or 16 miles North of Portsmouth, NH. With about three to four months of full-time effort, this -4 can be flying. There are some minor cracks (stop drilled) in the canopy (pilot/builder errors, transportation and storage in a hangar while building a house). The local EAA Tech Counselor felt that the canopy was fine, as is, especially to get flying. The new Hartzel prop may need seals checked and the AD checked since it has sat in the shipping container for a few years. Asking $28K, or best offer for plane, prop, engine (O-320-E2D overhauled at Winchester Aero and converted to a -D1A), instruments, and radios, ELT. If interested, I can send photos of the project. It will fit in a 24' U-Haul truck. The project is located in Ogunquit, ME - about 70 miles North of Boston, 16 miles North of Portsmouth, NH. Michael Pilla ________________________________________________________________________________
Date: Oct 19, 2002
Thanks Scott! The votes are still trickling in and its a REALLY, REALLY close race. If you have a preference and haven't yet voted, it so close that one or two votes could actually make the difference. PLEASE only vote once, though! To be fair, multiple votes from the same email address will not be counted. Matt At 07:07 AM 10/19/2002 Saturday, you wrote: >--> RV-List message posted by: "Chris Sudlow" > >Matt, > >You're doing a great job managing this. > >Chris >----- Original Message ----- >From: "Matt Dralle" <dralle(at)matronics.com> >Subject: RV-List: Re: posting (To Forward or Not to Forward...) > > > > --> RV10-List message posted by: dralle(at)matronics.com (Matt Dralle) > > > > > > Kevin's right, except for the RV7, RV9, and RV10 Lists. The way its > > been set up is when someone posts to the RV3, RV4, RV6, and RV8 Lists > > a copy is automatically sent to the RV-List too. For some reason, the > > 7/9/10 lists weren't configured that way; probably because I added > > them later and forgot that about the forwarding. > > > > In anycase, for now I've added the forward feature the 7/9/10 Lists to >keep > > everything consistant. > > > > However, I don't have a stong preference either way, actually. I can > > see pros and cons to each. Would people prefer the not-forwarding > > operation? Sounds like it they might... > > > > So let's vote! Drop me an email at: > > > > dralle(at)matronics.com > > > > with a simple: > > > > "Forward" > > or > > "Don't Forward" > > > > in the Subject Line. I'll added up the votes in a couple of days and > > announce the new method. > > > > > > Matt Dralle > > List Admin. > > > > > > >-------------- > > >--> RV-List message posted by: Kevin Horton > > > > > >Gary, > > > > > >Sorry, I have to respectfully disagree here. I am a member of Matt's > > >RV8-list and the RV-list. If I post a message to the RV8-list, I get > > >two copies - one that comes from the RV8-list, and a copy that comes > > >across on the main RV-list. > > > > > >I just checked my Out Box - my message to Steve was sent to the > > >RV4-List only. The copy you replied too seems to have come from the > > >main RV-List. > > > > > >Search the RV-List archives for the text " New Specific RV Lists Auto > > >Forwarded to RV-List" (don't include the quote marks. You'll find > > >Matt's description of how the system works. I believe it causes > > >confusion, because a lot of people on the main RV-List don't > > >understand that they need study the original message to see where it > > >originated, and send their response to the message to the correct > > >list. Otherwise, the original poster may not see the response. But, > > >Matt likes it the way it is, and these are his lists. > > > > > >Kevin > > > > > >>--> RV-List message posted by: "Gary" > > >> > > >>Kevin.....actually, messages posted to model-specific Matronics > > >>lists do not automatically post to the RV list. You can post to any > > >>list or combination of lists you like, but you have to send it to > > >>the ones you want it to show up on. > > >> > > >>Gary > > >> > > >>From: Kevin Horton <khorto1537(at)rogers.com> > > >>Subject: Re: RV-List: Re: RV4-List: Bleeding Brakes > > >> > > >>--> RV-List message posted by: Kevin Horton > > >> > > >>Steve, > > >> > > >>.................. Any message posted to one of the RV model specific > > >>list also gets posted to the main RV List. Any responses to the copy > > >>of the message that goes to the main RV List only go to the main RV > > >>List - they don't go back to the RV model specific list, ............... > > > > > > ________________________________________________________________________________
Date: Oct 21, 2002
Subject: ivo propeller
has anyone tried the ivo in flight magnum propeller unit on an rv-4? dan carley ________________________________________________________________________________
Date: Oct 22, 2002
Subject: Re: ivo propeller
Hi Dan, I've been flying the Ivoprop Magnum electric prop since Dec. 1995 on my RV-3. Is that close enough to a RV-4? I don't believe Ivo is selling their prop for four cylinder four cycle engines, and engines with certain gear boxes. Check with them at http://www.ivoprop.com Jim Ayers RV-3 N47RV LOM M332A engine 140 HP at 2700RPM and 35"MP (Love that supercharger! :-) ) ________________________________________________________________________________
Date: Oct 22, 2002
As far as the Ivo Prop goes, the LOM inline engine is a great candidate. It seems to run a lot smoother than the Lycomings. I seem to remember talking to a guy in Montana a few years ago that had the Ivo electric prop on an Avid Magnum and was having problems with it. Just to much engine for a flimsy prop design. I love my Warp Drive 72" 3-blade ground adjustable. Lots of Murphy Rebel guys run them on 150-160 HP. Its great for STOL planes, I wonder if anyone has ever put one on an RV???? ------------------------------------------------------ ------------------------------------------------------ I don't believe Ivo is selling their prop for four cylinder four cycle > engines, and engines with certain gear boxes. Check with them at > http://www.ivoprop.com > > Jim Ayers > RV-3 N47RV LOM M332A engine 140 HP at 2700RPM and 35"MP > (Love that supercharger! :-) ) ------------------------------------------- Introducing NetZero Long Distance Unlimited Long Distance only $29.95/ month! Sign Up Today! www.netzerolongdistance.com ________________________________________________________________________________
Date: Oct 22, 2002
Several years ago I seriously researched buying an IVO Magnum for my RV4. I found Four guys who had bought and flown them on RV's and all four had cracks in the gelcoat after 25 hours. I called IVO and asked if the problem was solved and never heard back. There is an RV3 with a LOM engine and IVO electric C/S prop flying, I spoke to him at Van's. I compromised and bought a Catto Composite... RR --- flyseaplane wrote: > > > As far as the Ivo Prop goes, the LOM inline engine > is a great candidate. It > seems to run a lot smoother than the Lycomings. I > seem to remember talking > to a guy in Montana a few years ago that had the Ivo > electric prop on an > Avid Magnum and was having problems with it. Just to > much engine for a > flimsy prop design. > > I love my Warp Drive 72" 3-blade ground adjustable. > Lots of Murphy Rebel > guys run them on 150-160 HP. Its great for STOL > planes, I wonder if anyone > has ever put one on an RV???? > ------------------------------------------------------ > ------------------------------------------------------ > > I don't believe Ivo is selling their prop for four > cylinder four cycle > > engines, and engines with certain gear boxes. > Check with them at > > http://www.ivoprop.com > > > > Jim Ayers > > RV-3 N47RV LOM M332A engine 140 HP at 2700RPM and > 35"MP > > (Love that supercharger! :-) ) > > > ------------------------------------------- > Introducing NetZero Long Distance > Unlimited Long Distance only $29.95/ month! > Sign Up Today! www.netzerolongdistance.com > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > http://webhosting.yahoo.com/ ________________________________________________________________________________
Date: Oct 23, 2002
In a message dated 10/22/2002 7:50:57 PM Pacific Daylight Time, smokyray(at)yahoo.com writes: > There is an > RV3 with a LOM engine and IVO electric C/S prop > flying, I spoke to him at Van's. I compromised and > bought a Catto Composite... > > RR > Sounds like a good choice. Jim Ayers RV-3 N47RV LOM M332A engine Ivoprop Magnum electric prop flown since Dec. 1995 very nervously. I believe Ivo hasn't sold his prop for Lycoming engines for a couple years. Warp drive wasn't successful on a Lycoming, either. Makes me wonder about the new CS props using Warp drive blades. Anyone have any history on the new CS props with the Warp drive blades on a Lycoming? ________________________________________________________________________________
Date: Oct 23, 2002
Jim Ayers - - - Sorry to all that this is the RV list - I have never heard of anyone having problems with their Warp Drive on a Lycoming. That is, the ground adjustable ones. What have you heard?? I know a guy who has one on a 160 HP and has had no problems for the six years that it has been flying (about 800 hours now) Thanks, Linc > RV-3 N47RV > LOM M332A engine > Ivoprop Magnum electric prop flown since Dec. 1995 very nervously. > I believe Ivo hasn't sold his prop for Lycoming engines for a couple years. > Warp drive wasn't successful on a Lycoming, either. Makes me wonder about > the new CS props using Warp drive blades. Anyone have any history on the new > CS props with the Warp drive blades on a Lycoming? ------------------------------------------- ________________________________________________________________________________
Date: Oct 23, 2002
MT and Hoffman both had enough doubts about the hubs on Warp Drive props holding up on Lycomings early on. They invested a ton o' money on research on the crankshaft before they built props for them. Something about Pulse rate frequencies on Lycomings being severe. When you're over trees or water or mountains, you don't need other problems... RR --- flyseaplane wrote: > > > Jim Ayers - - - > > Sorry to all that this is the RV list - I have never > heard of anyone having > problems with their Warp Drive on a Lycoming. That > is, the ground adjustable > ones. What have you heard?? I know a guy who has one > on a 160 HP and has had > no problems for the six years that it has been > flying (about 800 hours now) > > Thanks, > Linc > > > > RV-3 N47RV > > LOM M332A engine > > Ivoprop Magnum electric prop flown since Dec. 1995 > very nervously. > > I believe Ivo hasn't sold his prop for Lycoming > engines for a couple > years. > > Warp drive wasn't successful on a Lycoming, > either. Makes me wonder about > > the new CS props using Warp drive blades. Anyone > have any history on the > new > > CS props with the Warp drive blades on a Lycoming? > > > ------------------------------------------- > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Oct 23, 2002
Rob Ray, "MT and Hoffman both had enough doubts about the hubs on Warp Drive props holding up on Lycomings early on." All the guys I know with Warp Drive Props on Lycomings have the "High Horse Power" blade hub. Maybe "early on" there was an issue, I think Warp fixed it with the HHP hub. Later, Linc ------------------------------------------- ________________________________________________________________________________
Date: Oct 23, 2002
Linc; How are they holding up? Of course MT and Hoffman were trying to sell me a prop, but spoke of cracking/delaminating blades near the hub on the WD as well. The only Carbon Graphite C/S prop/hub arrangement I have seen (So Far) that I really like is the Whirlwind Prop and it uses a Hartzell hub... RR --- flyseaplane wrote: > > > Rob Ray, > > "MT and Hoffman both had enough doubts about the > hubs on Warp Drive props > holding up on Lycomings early on." > All the guys I know with Warp Drive Props on > Lycomings have the "High Horse > Power" blade hub. > > Maybe "early on" there was an issue, I think Warp > fixed it with the HHP hub. > > Later, > Linc > > ------------------------------------------- > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Oct 23, 2002
If the Warp Drive Company is selling their prop for Lycoming's, then they must have fixed their problem. They weren't selling their prop to any four cylinder four cycle engine, at one time. Jim Ayers ________________________________________________________________________________
Date: Oct 24, 2002
Very Interesting...A Hartzell rep told me it took them 30 years to perfect the two and 3 blade hubs they use today... I will testify to the excellent properties of the Composite Catto FP prop, smooth and efficient. RR --- LessDragProd(at)aol.com wrote: > > If the Warp Drive Company is selling their prop for > Lycoming's, then they > must have fixed their problem. > They weren't selling their prop to any four cylinder > four cycle engine, at > one time. > > Jim Ayers > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Subject: Someone from the RV list is sending me a virus...
Date: Oct 24, 2002
Someone from the RV list has been sending me the W32Klez@mm virus for a few days now. The W32.Bugbear@mm just came through today. This must be a new one. Folks, If you don't have Norton Anti-Virus, I strongly suggest you get it. (it's only $20 from numerous places online) I don't want to hear one person come back and say "Well, I have McAfee...." McAfee does not work like Norton Symantec does. I had McAfee installed on my Hewlitt-Packard when I bought it brand new, and the computer slowly began acting up. I installed Norton and it immediately found 28 viruses on my computer. So much for McAfee. Never again! Anyways, I just wanted you to know that my Norton system has been nabbing these viruses from the RV list, so you all might want to go ahead and run a virus scan. I am going to send this same message to the Harmon Rocket list, because it might be coming from there, I haven't determined which list is sending me the virus. Take care all, and happy building! Linc ------------------------------------------- ________________________________________________________________________________
Subject: Re: Someone from the RV list is sending me a virus...
Date: Oct 24, 2002
Linc, "Bugbear Virus" came from the RV-8 list......I got it this a.m...You are right about the Norton system, it expunged it immediately......CHEERS!!!...It seems to be a good system......CHEERS!!!!!!..........Gene Smith. ----- Original Message ----- From: "flyseaplane" <flyseaplane(at)netzero.net> Subject: RV4-List: Someone from the RV list is sending me a virus... > > Someone from the RV list has been sending me the W32Klez@mm virus for a few > days now. > > The W32.Bugbear@mm just came through today. This must be a new one. > > Folks, If you don't have Norton Anti-Virus, I strongly suggest you get it. > (it's only $20 from numerous places online) > > I don't want to hear one person come back and say "Well, I have McAfee...." > > McAfee does not work like Norton Symantec does. I had McAfee installed on my > Hewlitt-Packard when I bought it brand new, and the computer slowly began > acting up. I installed Norton and it immediately found 28 viruses on my > computer. So much for McAfee. Never again! > > Anyways, I just wanted you to know that my Norton system has been nabbing > these viruses from the RV list, so you all might want to go ahead and run a > virus scan. > I am going to send this same message to the Harmon Rocket list, because it > might be coming from there, I haven't determined which list is sending me > the virus. > > Take care all, and happy building! > Linc > > ------------------------------------------- > > ________________________________________________________________________________
Subject: Bugbear virus came from RV-8 list...
Date: Oct 25, 2002
Hello Gene Smith, Yes, I did determine the Bugbear virus came from the RV-8 list as well. The sender was "Sally and George" about cabin heat. I tried to send them an e-mail - it came back as undeliverable. It was an Australian e-mail address. YAY for Norton!! I can't believe how well it works! Later all, Linc ------------------------------------------- ________________________________________________________________________________
Subject: Re: Bugbear virus came from RV-8 list...
Date: Oct 25, 2002
This may be of interest Chuck, You've swallowed one of the better hoaxes pulled off recently (although it is quite old by now). Before you do anything, check out the following website: http://www.symantec.com/avcenter/venc/data/jdbgmgr.exe.file.hoax.html ----- Original Message ----- From: "flyseaplane" <flyseaplane(at)netzero.net> Subject: RV4-List: Bugbear virus came from RV-8 list... > > Hello Gene Smith, > > Yes, I did determine the Bugbear virus came from the RV-8 list as well. The > sender was "Sally and George" about cabin heat. I tried to send them an > e-mail - it came back as undeliverable. It was an Australian e-mail address. > > YAY for Norton!! I can't believe how well it works! > > Later all, > Linc > > > ------------------------------------------- > > ________________________________________________________________________________
Date: Oct 25, 2002
FYI from another source Chuck, You've swallowed one of the better hoaxes pulled off recently (although it is quite old by now). Before you do anything, check out the following website: http://www.symantec.com/avcenter/venc/data/jdbgmgr.exe.file.hoax.html ----- Original Message ----- From: "Gene Smith" <esmith6(at)satx.rr.com> Subject: Re: RV4-List: Someone from the RV list is sending me a virus... > > Linc, > "Bugbear Virus" came from the RV-8 list......I got it this a.m...You > are right about the Norton system, it expunged it > immediately......CHEERS!!!...It seems to be a good > system......CHEERS!!!!!!..........Gene Smith. > ----- Original Message ----- > From: "flyseaplane" <flyseaplane(at)netzero.net> > To: > Subject: RV4-List: Someone from the RV list is sending me a virus... > > > > > > Someone from the RV list has been sending me the W32Klez@mm virus for a > few > > days now. > > > > The W32.Bugbear@mm just came through today. This must be a new one. > > > > Folks, If you don't have Norton Anti-Virus, I strongly suggest you get it. > > (it's only $20 from numerous places online) > > > > I don't want to hear one person come back and say "Well, I have > McAfee...." > > > > McAfee does not work like Norton Symantec does. I had McAfee installed on > my > > Hewlitt-Packard when I bought it brand new, and the computer slowly began > > acting up. I installed Norton and it immediately found 28 viruses on my > > computer. So much for McAfee. Never again! > > > > Anyways, I just wanted you to know that my Norton system has been nabbing > > these viruses from the RV list, so you all might want to go ahead and run > a > > virus scan. > > I am going to send this same message to the Harmon Rocket list, because it > > might be coming from there, I haven't determined which list is sending me > > the virus. > > > > Take care all, and happy building! > > Linc > > > > ------------------------------------------- > > > > > > ________________________________________________________________________________
Date: Oct 25, 2002
Hello Tim Whitman, I don't think Linc, Chuck or myself swallowed anything in regard to this "Bugbear" so called "hoax." The updated Norton system I have (Norton System Works 2003), recognized that msg. from the RV-8 list as a threat, and automatically flew all the warning flags, did the bells and whistles, and etc., and advised me to delete the msg. immediately. In my case all I did was delete the RV-8 msg., and the "jdbgmgr.exe" file never entered the picture, and is still intact. I assume everyone else did the same, and surely no one would ignore those indicators about a problem, hoax or not. Another good source of hoax info is......Search the Web: "hoaxbusters.com" I'm still a novice at this PC thing, but learning every day. We appreciate your info and the Website you suggested, it was very informative......We all have to stick together, it seems anymore we are being attacked from every direction we turn, from cowardly jerks trying to destroy our PC's to snipers and 757/767 missile attacks on our buildings. We are losing our freedoms rapidly. If you have flown lately, just look at all the TFR's we have to put up with that pop-up daily......I apologize for the length of this "dittie."....................CHEERS!!!!!..............Gene Smith ----- Original Message ----- From: "Tim Whitman" <wyvern1(at)attbi.com> Subject: Re: RV4-List: Someone from the RV list is sending me a virus... > > FYI from another source > > > Chuck, > You've swallowed one of the better hoaxes pulled off recently (although it > is > quite old by now). > Before you do anything, check out the following website: > http://www.symantec.com/avcenter/venc/data/jdbgmgr.exe.file.hoax.html > > > ----- Original Message ----- > From: "Gene Smith" <esmith6(at)satx.rr.com> > To: > Subject: Re: RV4-List: Someone from the RV list is sending me a virus... > > > > > > Linc, > > "Bugbear Virus" came from the RV-8 list......I got it this a.m...You > > are right about the Norton system, it expunged it > > immediately......CHEERS!!!...It seems to be a good > > system......CHEERS!!!!!!..........Gene Smith. > > ----- Original Message ----- > > From: "flyseaplane" <flyseaplane(at)netzero.net> > > To: > > Subject: RV4-List: Someone from the RV list is sending me a virus... > > > > > > > > > > Someone from the RV list has been sending me the W32Klez@mm virus for a > > few > > > days now. > > > > > > The W32.Bugbear@mm just came through today. This must be a new one. > > > > > > Folks, If you don't have Norton Anti-Virus, I strongly suggest you get > it. > > > (it's only $20 from numerous places online) > > > > > > I don't want to hear one person come back and say "Well, I have > > McAfee...." > > > > > > McAfee does not work like Norton Symantec does. I had McAfee installed > on > > my > > > Hewlitt-Packard when I bought it brand new, and the computer slowly > began > > > acting up. I installed Norton and it immediately found 28 viruses on my > > > computer. So much for McAfee. Never again! > > > > > > Anyways, I just wanted you to know that my Norton system has been > nabbing > > > these viruses from the RV list, so you all might want to go ahead and > run > > a > > > virus scan. > > > I am going to send this same message to the Harmon Rocket list, because > it > > > might be coming from there, I haven't determined which list is sending > me > > > the virus. > > > > > > Take care all, and happy building! > > > Linc > > > > > > ------------------------------------------- > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 25, 2002
Hey RV Listers, Okay, so I really don't mean to drag this out, but unbelievably, we have a dead heat between "Forward" votes and "Don't Forward" votes! I had no idea the opinion would run so close!! I've gotten a little over 100 votes so far and it is literally a 50/50 split to the vote on which way to go. Over the last week or so, each day I've gotten a couple of votes to Forward, then a couple of votes to Not Forward - back and forth. With this many people on both sides of the fence, no matter which way wins, there's gonna be a lot of disappointed people! And I thought this vote would make it easy for me to decide... I'm going to keep the polls open until Sunday afternoon at 5pm pst, and just go with the method that has the most votes - even if its just 1 or 2 votes. This is just like the Bush/Gore election; I'm down to counting chad... You guys from Florida get your votes in! :-) Here's how to vote - follow closely to make it easiest for me to count: -- To Vote FORWARD -- * This means that you would like to have any messages posted to the RV-specific lists automatically forwarded to the main RV-List. Send an email message to: dralle(at)matronics.com Make the SUBJECT line: "Forward" -- To Vote DON'T FORWARD -- * This means that you don't want messages posted to the RV-specific lists automatically forwarded to the main RV-List. Send an email message to: dralle(at)matronics.com Make the SUBJECT line: "Don't Forward" If you care, here's your chance to make a difference! Get your vote in before Sunday at 5pm pst. I'll announce the winner Sunday night... Hey - and there's only voting one time, you guys! You know who you are... :-) Matt Dralle Email List Admin. ============================================================================== Thanks Scott! The votes are still trickling in and its a REALLY, REALLY close race. If you have a preference and haven't yet voted, it so close that one or two votes could actually make the difference. PLEASE only vote once, though! To be fair, multiple votes from the same email address will not be counted. Matt At 07:07 AM 10/19/2002 Saturday, you wrote: >--> RV-List message posted by: "Chris Sudlow" > >Matt, > >You're doing a great job managing this. > >Chris >----- Original Message ----- >From: "Matt Dralle" <dralle(at)matronics.com> >Subject: RV-List: Re: posting (To Forward or Not to Forward...) > > > > --> RV10-List message posted by: dralle(at)matronics.com (Matt Dralle) > > > > > > Kevin's right, except for the RV7, RV9, and RV10 Lists. The way its > > been set up is when someone posts to the RV3, RV4, RV6, and RV8 Lists > > a copy is automatically sent to the RV-List too. For some reason, the > > 7/9/10 lists weren't configured that way; probably because I added > > them later and forgot that about the forwarding. > > > > In anycase, for now I've added the forward feature the 7/9/10 Lists to >keep > > everything consistant. > > > > However, I don't have a stong preference either way, actually. I can > > see pros and cons to each. Would people prefer the not-forwarding > > operation? Sounds like it they might... > > > > So let's vote! Drop me an email at: > > > > dralle(at)matronics.com > > > > with a simple: > > > > "Forward" > > or > > "Don't Forward" > > > > in the Subject Line. I'll added up the votes in a couple of days and > > announce the new method. > > > > > > Matt Dralle > > List Admin. > > > > > > >-------------- > > >--> RV-List message posted by: Kevin Horton > > > > > >Gary, > > > > > >Sorry, I have to respectfully disagree here. I am a member of Matt's > > >RV8-list and the RV-list. If I post a message to the RV8-list, I get > > >two copies - one that comes from the RV8-list, and a copy that comes > > >across on the main RV-list. > > > > > >I just checked my Out Box - my message to Steve was sent to the > > >RV4-List only. The copy you replied too seems to have come from the > > >main RV-List. > > > > > >Search the RV-List archives for the text " New Specific RV Lists Auto > > >Forwarded to RV-List" (don't include the quote marks. You'll find > > >Matt's description of how the system works. I believe it causes > > >confusion, because a lot of people on the main RV-List don't > > >understand that they need study the original message to see where it > > >originated, and send their response to the message to the correct > > >list. Otherwise, the original poster may not see the response. But, > > >Matt likes it the way it is, and these are his lists. > > > > > >Kevin > > > > > >>--> RV-List message posted by: "Gary" > > >> > > >>Kevin.....actually, messages posted to model-specific Matronics > > >>lists do not automatically post to the RV list. You can post to any > > >>list or combination of lists you like, but you have to send it to > > >>the ones you want it to show up on. > > >> > > >>Gary > > >> > > >>From: Kevin Horton <khorto1537(at)rogers.com> > > >>Subject: Re: RV-List: Re: RV4-List: Bleeding Brakes > > >> > > >>--> RV-List message posted by: Kevin Horton > > >> > > >>Steve, > > >> > > >>.................. Any message posted to one of the RV model specific > > >>list also gets posted to the main RV List. Any responses to the copy > > >>of the message that goes to the main RV List only go to the main RV > > >>List - they don't go back to the RV model specific list, ............... > > > > > > ________________________________________________________________________________
Subject: Thanks Rob Ray
Date: Oct 26, 2002
Hello Rob Ray, You are doing a wonderful job, and we are all very proud of you, and thank you so much for protecting us...We share your frustrations and stress related to this whole mess we are living this day and time, you are obviously closer to it all than we are. If you remember our email discussions about crosswinds and the 360 degree tail wheels, I mentioned I did the same thing you are doing for 22 years, so I know from your end of the stick. Yes, you are right, some of the GA pilots really need to clean up their act, or we might have further restrictions to our privilege to fly. It really doesn't take much effort to find out the rules to go with the situation before we get airborne. Sorry I missed you at Scott Field west of Waco at the last fly-in......I look forward to meeting you and swapping lies over a brew or two! Take care of yourself, and don't try to be a too much of a hero......remember the old Fighter Pilot adage, "one pass, haul ass," and "tomorrow is another day." I'm sure you recite that each time you "roll-in." Thanks again for "putting it on the line" for all of us, we do care and appreciate you!............CHEERS!!!!!!............Gene Smith PS......To all my other RV Comrades out there, I apologize for taking your space and time, but I felt this needed to be said. Rob is right, like building these machines, let's do it right and respect the rules. ________________________________________________________________________________
Date: Oct 26, 2002
Subject: Re: Thanks Rob Ray
Thank you sir! We don't get to hear that very much. --- Gene Smith wrote: > > > Hello Rob Ray, > You are doing a wonderful job, and we are all > very proud of you, and thank you so much for > protecting us...We share your frustrations and > stress related to this whole mess we are living this > day and time, you are obviously closer to it all > than we are. If you remember our email discussions > about crosswinds and the 360 degree tail wheels, I > mentioned I did the same thing you are doing for 22 > years, so I know from your end of the stick. > Yes, you are right, some of the GA pilots > really need to clean up their act, or we might have > further restrictions to our privilege to fly. It > really doesn't take much effort to find out the > rules to go with the situation before we get > airborne. > Sorry I missed you at Scott Field west of Waco > at the last fly-in......I look forward to meeting > you and swapping lies over a brew or two! > Take care of yourself, and don't try to be a > too much of a hero......remember the old Fighter > Pilot adage, "one pass, haul ass," and "tomorrow is > another day." I'm sure you recite that each time > you "roll-in." Thanks again for "putting it on the > line" for all of us, we do care and appreciate > you!............CHEERS!!!!!!............Gene Smith > > PS......To all my other RV Comrades out there, I > apologize for taking your space and time, but I felt > this needed to be said. Rob is right, like building > these machines, let's do it right and respect the > rules. > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Oct 27, 2002
rv7-list(at)matronics.com, rv8-list(at)matronics.com, rv9-list(at)matronics.com, rv10-list(at)matronics.com, rv-list(at)matronics.com
Subject: Re: posting (To Forward or Not to Forward...) (The Final VOTE!)
Dear RV Listers, Okay, its after 5pm pst on Sunday and as promised, I've closed the polls. I've counted the votes and recounted the votes, and even double checked all of the Chad and the totals keep coming up the same. Are you ready for this spread? Here is the official vote count: 95 votes: Forward 96 votes: Don't Forward Unbelievable, I know. The totals ran within 1 to 2 votes of each other the entire voting period. I couldn't believe it either. How could the split be so close? Perhaps I should have turned to the Electoral College for assistance... Or maybe Florida... :-) Much to Gore's delight, the popular vote really did count! So, the people have spoken and as of 5:19pm pst I have disabled the auto forwarding from the RV-specific Lists to the main RV-List. As I mentioned earlier, I really was on the fence about the right way, so thanks to everyone for helping with the decision! Isn't democracy great! Matt Dralle Email List Admin. Hey RV Listers, Okay, so I really don't mean to drag this out, but unbelievably, we have a dead heat between "Forward" votes and "Don't Forward" votes! I had no idea the opinion would run so close!! I've gotten a little over 100 votes so far and it is literally a 50/50 split to the vote on which way to go. Over the last week or so, each day I've gotten a couple of votes to Forward, then a couple of votes to Not Forward - back and forth. With this many people on both sides of the fence, no matter which way wins, there's gonna be a lot of disappointed people! And I thought this vote would make it easy for me to decide... I'm going to keep the polls open until Sunday afternoon at 5pm pst, and just go with the method that has the most votes - even if its just 1 or 2 votes. This is just like the Bush/Gore election; I'm down to counting chad... You guys from Florida get your votes in! :-) Here's how to vote - follow closely to make it easiest for me to count: -- To Vote FORWARD -- * This means that you would like to have any messages posted to the RV-specific lists automatically forwarded to the main RV-List. Send an email message to: dralle(at)matronics.com Make the SUBJECT line: "Forward" -- To Vote DON'T FORWARD -- * This means that you don't want messages posted to the RV-specific lists automatically forwarded to the main RV-List. Send an email message to: dralle(at)matronics.com Make the SUBJECT line: "Don't Forward" If you care, here's your chance to make a difference! Get your vote in before Sunday at 5pm pst. I'll announce the winner Sunday night... Hey - and there's only voting one time, you guys! You know who you are... :-) Matt Dralle Email List Admin. ============================================================================== Thanks Scott! The votes are still trickling in and its a REALLY, REALLY close race. If you have a preference and haven't yet voted, it so close that one or two votes could actually make the difference. PLEASE only vote once, though! To be fair, multiple votes from the same email address will not be counted. Matt At 07:07 AM 10/19/2002 Saturday, you wrote: >--> RV-List message posted by: "Chris Sudlow" > >Matt, > >You're doing a great job managing this. > >Chris >----- Original Message ----- >From: "Matt Dralle" <dralle(at)matronics.com> >Subject: RV-List: Re: posting (To Forward or Not to Forward...) > > > > --> RV10-List message posted by: dralle(at)matronics.com (Matt Dralle) > > > > > > Kevin's right, except for the RV7, RV9, and RV10 Lists. The way its > > been set up is when someone posts to the RV3, RV4, RV6, and RV8 Lists > > a copy is automatically sent to the RV-List too. For some reason, the > > 7/9/10 lists weren't configured that way; probably because I added > > them later and forgot that about the forwarding. > > > > In anycase, for now I've added the forward feature the 7/9/10 Lists to >keep > > everything consistant. > > > > However, I don't have a stong preference either way, actually. I can > > see pros and cons to each. Would people prefer the not-forwarding > > operation? Sounds like it they might... > > > > So let's vote! Drop me an email at: > > > > dralle(at)matronics.com > > > > with a simple: > > > > "Forward" > > or > > "Don't Forward" > > > > in the Subject Line. I'll added up the votes in a couple of days and > > announce the new method. > > > > > > Matt Dralle > > List Admin. > > > > > > >-------------- > > >--> RV-List message posted by: Kevin Horton > > > > > >Gary, > > > > > >Sorry, I have to respectfully disagree here. I am a member of Matt's > > >RV8-list and the RV-list. If I post a message to the RV8-list, I get > > >two copies - one that comes from the RV8-list, and a copy that comes > > >across on the main RV-list. > > > > > >I just checked my Out Box - my message to Steve was sent to the > > >RV4-List only. The copy you replied too seems to have come from the > > >main RV-List. > > > > > >Search the RV-List archives for the text " New Specific RV Lists Auto > > >Forwarded to RV-List" (don't include the quote marks. You'll find > > >Matt's description of how the system works. I believe it causes > > >confusion, because a lot of people on the main RV-List don't > > >understand that they need study the original message to see where it > > >originated, and send their response to the message to the correct > > >list. Otherwise, the original poster may not see the response. But, > > >Matt likes it the way it is, and these are his lists. > > > > > >Kevin > > > > > >>--> RV-List message posted by: "Gary" > > >> > > >>Kevin.....actually, messages posted to model-specific Matronics > > >>lists do not automatically post to the RV list. You can post to any > > >>list or combination of lists you like, but you have to send it to > > >>the ones you want it to show up on. > > >> > > >>Gary > > >> > > >>From: Kevin Horton <khorto1537(at)rogers.com> > > >>Subject: Re: RV-List: Re: RV4-List: Bleeding Brakes > > >> > > >>--> RV-List message posted by: Kevin Horton > > >> > > >>Steve, > > >> > > >>.................. Any message posted to one of the RV model specific > > >>list also gets posted to the main RV List. Any responses to the copy > > >>of the message that goes to the main RV List only go to the main RV > > >>List - they don't go back to the RV model specific list, ............... > > > > > > ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Date: Oct 28, 2002
Bugbear is not a hoax, the JDBMGR.EXE warning chain letter is a hoax. The teddybear icon confuses people. -- Scott VanArtsdalen, MCSE, CCNA Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Tim Whitman [mailto:wyvern1(at)attbi.com] Subject: Re: RV4-List: Bugbear virus came from RV-8 list... This may be of interest Chuck, You've swallowed one of the better hoaxes pulled off recently (although it is quite old by now). Before you do anything, check out the following website: http://www.symantec.com/avcenter/venc/data/jdbgmgr.exe.file.hoax.html ----- Original Message ----- From: "flyseaplane" <flyseaplane(at)netzero.net> Subject: RV4-List: Bugbear virus came from RV-8 list... > > Hello Gene Smith, > > Yes, I did determine the Bugbear virus came from the RV-8 list as well. The > sender was "Sally and George" about cabin heat. I tried to send them an > e-mail - it came back as undeliverable. It was an Australian e-mail address. > > YAY for Norton!! I can't believe how well it works! > > Later all, > Linc > > > ------------------------------------------- > > ________________________________________________________________________________
Subject: Paint
Date: Oct 29, 2002
Hello RVers! I know nothing about paint and need some advice. I am about to paint the steel trusses for a new home I am building for my RV4. Can anyone recommend a good, affordable primer that would work well in this application? The steel trusses come with no paint or primer whatsoever, and I want to protect against rust in often wet and humid Southwest Missouri climate. Thanks in advance for your help! Steve D. Mullins Associate Professor of Economics Drury University 417 873 7299 (office) 417 889 5609 (home) 417 873 7508 (fax) --- Checked by AVG anti-virus system (http://www.grisoft.com). ________________________________________________________________________________
Subject: Re: Paint
Date: Oct 29, 2002
Hello Steve Mullins - I have had excellent results with a self-etching primer from Akzo-Nobel. I haven't used it in 5 years (so I don't remember the part number) but it works VERY well. You may do well to compare prices of all of the two-part self etching primers in your area. (not just Akzo-Nobel) Good luck, Linc "I am about to paint the steel trusses for a new home I am building for my RV4. Can anyone recommend a good, affordable primer that would work well in this application? The steel trusses come with no paint or primer whatsoever, " --------------------------------------------- 1st month Free! ________________________________________________________________________________
Date: Oct 31, 2002
rv7-list(at)matronics.com, rv8-list(at)matronics.com, rv9-list(at)matronics.com, rv-list(at)matronics.com
Subject: How To Wire a "Dual-Rate" Electric Trim System...
Hi Listers, I've recently received a number of requests from builders regarding how to wire up a "dual-rate" system for their electric trim installation. The concept is that in cruse configuration the trim speed would be slow and during flaps down configuration the trim speed would be fast. I've draw up a schematic diagram that shows how to accomplish this using two Matronics Governor MkIII units, a 12v relay, and an extra switch. With the flaps up, the "fast" Governor MkIII is switched in, and when the flaps are down, the "slow" Governor MkIII is switched in. I would recommend using the highest quality, sealed relay available for this installation. Here is the Dual-Rate PDF document: http://www.matronics.com/GovernorMkIII/DualRate-GovernorMkIII-Installation.pdf and here is the Governor MkIII website: http://www.matronics.com/GovernorMkIII If you have any questions on the wiring diagram, feel free to email me directly at: dralle(at)matronics.com Best regards, Matt Dralle Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
"Dog Fighter-Terry Burch" , , "Alex Peterson" ,
Subject: Fw: RV-List: Brake Fluid Reservoir Loc. on a tip-up
Date: Oct 31, 2002
Mark, How ya' doin' down there at "The Possum Works"? Funny ya'll mentioning the brake fluid reservoir. I was just talking/emailing with a fellow pilot about them. That's a good idea of yours, mounting it on the rear of the subpanel (for easy access), but if I might suggest a GREAT little stocking stuffer you could ask Old Saint Nick for.... the "Reservoir Dog" from Alex Peterson. Yep, you'll never have to worry about "why is my sock wet?" ever again. This handy dandy little cap/valve stops that red (pink or clear) caustic chemicals from dripping out; EVEN when you gets upside down. Now some of us don't wanna do flip flops or fancy smancy maneuvers, rolls, & loops, etc... ( though I ain't met that "someone" yet) but you know that even in steep turns and bounced landings that red stuff sloshes. So if ya' looking to keep your bird free from them kinda problems, contact Alex {off list at Alexpeterson(at)usjet.net } and he'll make you one too. Chuck p.s. There're "inexpensive", and I don't get nothin' for sayin' this... I just enjoy the one I installed (can you say 3 minute installation) and I like seeing one of our own list members succeed. ----- Original Message ----- From: Mark Phillips <ripsteel(at)edge.net> Subject: RV-List: Brake Fluid Reservoir Loc. on a tip-up > --> RV-List message posted by: Mark Phillips > > Howdy List- > > Anyone installed their reservoir on the rear of the subpanel so it can > be accessed when the canopy is open? I see one less hole in the > firewall, more space on firewall, easier to check level and detect leaks > (why is my sock wet?) & the vent could be run off with a little tube to > somewhere... Other pros & cons, please! > > From The PossumWorks in TN > Mark > > ________________________________________________________________________________
Date: Nov 01, 2002
Subject: Re: Fw: RV-List: Brake Fluid Reservoir Loc. on a tip-up
I don't know about you, but my brake resevoir is under the cowling mounted on the firewall... RR --- "C. Rabaut" wrote: > > > Mark, > > How ya' doin' down there at "The Possum Works"? > Funny ya'll mentioning > the brake fluid reservoir. I was just > talking/emailing with a fellow pilot > about them. That's a good idea of yours, mounting > it on the rear of the > subpanel (for easy access), but if I might suggest a > GREAT little stocking > stuffer you could ask Old Saint Nick for.... the > "Reservoir Dog" from Alex > Peterson. Yep, you'll never have to worry about > "why is my sock wet?" > ever again. This handy dandy little cap/valve stops > that red (pink or > clear) caustic chemicals from dripping out; EVEN > when you gets upside down. > Now some of us don't wanna do flip flops or fancy > smancy maneuvers, rolls, & > loops, etc... ( though I ain't met that "someone" > yet) but you know that > even in steep turns and bounced landings that red > stuff sloshes. So if ya' > looking to keep your bird free from them kinda > problems, contact Alex {off > list at Alexpeterson(at)usjet.net } and he'll make you > one too. > > Chuck > > p.s. There're "inexpensive", and I don't get > nothin' for sayin' this... I > just enjoy the one I installed (can you say 3 minute > installation) and I > like seeing one of our own list members succeed. > > > ----- Original Message ----- > From: Mark Phillips <ripsteel(at)edge.net> > To: > Subject: RV-List: Brake Fluid Reservoir Loc. on a > tip-up > > > > --> RV-List message posted by: Mark Phillips > > > > > Howdy List- > > > > Anyone installed their reservoir on the rear of > the subpanel so it can > > be accessed when the canopy is open? I see one > less hole in the > > firewall, more space on firewall, easier to check > level and detect leaks > > (why is my sock wet?) & the vent could be run off > with a little tube to > > somewhere... Other pros & cons, please! > > > > From The PossumWorks in TN > > Mark > > > > > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > HotJobs - Search new jobs daily now http://hotjobs.yahoo.com/ ________________________________________________________________________________
Date: Nov 01, 2002
Subject: How to contact Ron Burch
Does anyone have a telephone number for Ron Burch? There is an email link at the following URL, http://www.kitpanels.com/shops.htm however my email bounces. Roger Crandell ________________________________________________________________________________
Date: Nov 01, 2002
Subject: 2002 List Fund Raiser - Please Support Your Lists...
Dear Listers, During November of each year, I have a voluntary Email List Fund Raiser to support the continued operation, development, maintenance and upgrade of the Email Forums sponsored here. Your Contributions go directly into improvements in the systems that support the Lists and to pay for the Internet connectivity primarily dedicated to supporting the Lists. The traffic on the Lists continues to grow and the numbers are nothing short of impressive! Here are some statistics that show much traffic the Lists generated last year alone: 11/01/2001 - 10/31/2002 Web server hits: 8,700,000 (727,000/mo) Incoming Email Posts: 51,259 (4,271/mo) * * This number is multiplied by the total number of email addresses subscribed to the given List. The actual number of email message processed is in the 50,000,000 range for last year!! The new Internet provider, Speakeasy, has been providing extremely fast and reliable service over the last year, and this has certainly been a refreshing change from previous providers! There were a couple of new features added at the tail-end of last year including the new List Browse Feature ( http://www.matronics.com/listbrowse ), and the List Photoshare which have been both very popular. Many people have written to say how much they enjoy the on-line browsing capability of current week's messages. The 184 new Photoshares ( http://www.matronics.com/photoshare ) added over the last year attests to its acceptance and appreciation in the community as well. I have upgraded both the email and web server OS systems recently to the latest - well almost the latest - version of Redhat Linux and Kernel 2.4.19, both of which have been working very well and quite reliably. What does the future hold? Well, something pretty exciting I'm hoping... I am currently evaluating a new, commercially available software package that runs under Linux and provides a complete web-based Email List service akin to what those other guys use. The difference will be that there won't be any annoying advertisements and popup ads on the Matronics system!! The system will continue to be dedicated to furthering Lists activities and not trying to sell you something you don't want. My hope is to keep most if not all of the current functionality in place and add the new software system over the top. Some of the system will be replaced (like majordomo), but the lists will work much like they do today - only BETTER! As I mentioned, I am currently in the evaluation stage of this and have yet to select a final product. Suffice to say some facelifts are definitely on the way! Unlike many of the other "list servers" on the web these days, I have a strict no-commercial-advertisement policy on the Matronics Lists and associated List websites. I have been approached by a number of vendors recently with advertising deals that have been very tempting. However, my commitment to providing a grass-roots, non-commercial environment prevails! Commercialism on the Internet seems to be increasing exponentially every year with more and more SPAM and pop up ads, not to mention the ever increasing Virus attacks. My goal with the Matronics List Service is to provide my members with a commercial-free, safe, and high-performance system in which to share information, ideas, and camaraderie. I recoup my upgrade, maintenance, and operating costs by having a List Fund Raiser once a year during November. During this time, I ask List members to donate a small amount of money to support the continued operation of the Lists over the upcoming year. Contributions in the $20, $30, and $50 range are common. This year I have completely revamped the Contribution website, and have added the ability to use PayPal to make your Contribution in addition to the traditional Visa/MC and Personal Check Options. Its easier and faster than ever before to make your Contribution!! For those who are accustomed to using PayPal to make Internet purchases, will appreciate the ease and speed of using this handy method of payment to make their List Contribution. The best news this year, however, is that I have a couple of fantastic Gift offers to support the List Fund Raiser! Andy Gold of The Builder's Bookstore ( http://www.buildersbooks.com ) will be generously donating a FREE Jeppesen Flight Bag to anyone making a $50 or more List Contribution during the Fund Raiser! This is a great bag and something you'll surely what to get your hands on. Thanks Andy, for this great incentive!! In addition to the great Flight Bag, I will also be offering a FREE Matronics List Archive CDROM for a $50 or greater Contribution! This is a complete set of archives for all Email Lists currently hosted by Matronics. The Archives date back to the beginning of the each List. In the case of the RV-List, for example, this includes archives all the way back to 1990! That's about 133Mb alone! Also included on the CD is a copy of Chip Gibbion's Windows Archive Search Utility and a precompiled search-index for each archive on the CD. Better yet?! You can get BOTH the Flight Bag AND the Archive CD for a Contribution of $75 or more which is actually LESS than the combined retail price on the two items!!! How can you go wrong? Get some great stuff AND support your Lists at the same time! Over the next month I'll be posting a few reminder messages about the List Fund Raiser, and I ask for your patience and understanding during the process. Remember that the Lists are *completely* funded through the generous Contributions of its members. That's it! There's no support from a bloated advertising budget or deep pockets somewhere. Its all made possible through YOUR support! I would like to take this opportunity to thank everyone who supports the List this year. Your generosity contributes directly to the quality of the experience here. To make your List Contribution using a Visa or MasterCard, PalPal, or with a Personal Check, please go to the URL link below. Here you can find additional details on this year's great free Gifts as well as additional information on the various methods of payment. SSL Secure Contribution Web Site: http://www.matronics.com/contributions Again, I would like to thank everyone who supports the Lists this year! Your Contributions truly make it all possible!! Thank you! Matt Dralle Matronics Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 05, 2002
Subject: New List Digest Feature!! [Please Read]
Dear Listers, I've added a new feature to the Digest format of the Lists tonight. At the top of each digest you will find a new Index Listing of all of the messages found within that Digest including the Message Number, Subject, Poster, and Time of Day posted. I've also added a "Message Number" header to each message within the Digest so that its easy to find 'just the message' you were looking for! Sorry for the double posting of the digests tonight - the first time I didn't quite have the code right and a few "bogus" entries made it into the Index. I went ahead and reposted the Digest so that everyone could see how the Index-to-Message mapping really worked. Special 'thanks' to Gary Hall for not only suggesting a Digest Index, but also supplying a few samples on how it might look. Gary, I think you'll be quite pleased with the format! Don't forget that were right in the middle of this year's List Fund Raiser and if you haven't already made your Contribution, you own it to yourself to check out the great free Gifts that are available this year with your qualifying Contribution. The Lists are operated completely though the support of it members, and so its up to YOU to get that credit card out and make that $20, $30, or $50 show of support for the continued operation of the Lists. Won't you take a couple of minutes and make a quick Contribution on the all new, streamlined List Support web site? I've also added a Payment-through-PayPal option this year, and this is proving a very popular method of payment. Don't forget to check out the great free gifts you can get with a qualifying Contribution this year. I can't believe how popular they've been this year! Hurry and get your's today and support the Lists at the same time! Here's the SSL Secure URL for making your Contribution: http://www.matronics.com/contribution Thank you for your Support!! Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 07, 2002
Subject: List Fund Raiser - What Listers Are Saying...
Dear Listers, First, I'd like say *thank you* to everyone that's already made a Contribution to this year's List Fund Raiser! Thank you! If you haven't already made a Contribution, won't you take a movement and show your support for these valuable services? Since there's no advertising or other forms of direct commercialism on the forums to support the Lists, its soley YOUR GENEROSITY that keeps them running!! Won't please take a minute and make a Contribution via the SSL secure web site via Credit Card, Paypal, or personal check. Here's the URL: http://www.matronics.com/contributions This year, I've been getting some *really* nice comments from Contributors and I thought I'd pass along a few of them below. What does the List mean to *you*? Thank you for your support!! Matt Dralle Email List Administrator _________________ What your fellow Listers are saying... _________________ ...great service!! Greg B. They have been a great assistance to me in building my RV-8. Kevin H. ...very much appreciated. Donald M. Great site... Angus F. ...invaluable resource. Ronald C [The List] has played a big part in continuing my project at those times when I got stuck for some reason. Jeff D. Although I am only a reader, I find the list very helpful. Oswaldo F. The lists are a fantastic resource and are helping me very much... Kenyon B. The list is part of my life. Ron C. The CD will free up some hard disk space on my personal PC. Jeff D. ...unbelievably useful. Dan O. ...dependable and valued source of builder information. Jerry C. My daily lifeline! Owen B. ...frequently get questions answered on the List. Billy W. Don't know how any first-time builder could get by without the lists. Rick R. ...great source of information and motivation. Jef V. Super resource! David P. The information presented is very helpful to the building process. James B. Wonderful Service! Wendell D. The lists are great! F. Robert M. ...very valuable to this builder. William C. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: RV-4 Engine Mounts
Date: Nov 10, 2002
Hello Everyone, I have an older RV-4 (1986) powerd by an O-320-E2D. Upon examination of the spinner/cowling alignment, it appears that the engine may have drooped 3/4" or so. Can adjustments be made to the engine mounts to correct the spinner alignment? Any ideas are welcome. Thanks, Hank Landman pukndg(at)mindspring.com ________________________________________________________________________________
Date: Nov 11, 2002
Subject: List Fund Raiser Continues...
Marie Murillo Dear Listers, Just a quick reminder this morning that we're well into this year's Email List Fund Raiser. Response has been great so far and there has been a lot of interest in the Gift options. Speaking of those Gifts, I received a sample of the Jeppesen Flight Bag from Andy Gold of the Builder's Bookstore http://www.buildersbooks.com this weekend, and let me just say that this is an extremely fine quality unit. Its very light, folds down into a very small form for storage, and will hold a whole lot of your "pilot stuff"! For a mere $50 List Contribution, one of these very nice bags could be yours! You'll be the envy of all your friends. Won't you make a Contribution today to support the these valuable Email List Services? Please remember that its YOUR generosity that entirely supports the continued operation and upgrade of the Lists. That's it - no ads, no banners - just good clean fun; that is, with your support of course! Please take a moment and make a generous Contribution today. It only takes a minute using the newly redesigned Contribution Web Site where you can use either a Credit Card, PayPal, or a Personal Check to make your donation. The URL for the SSL Secure Contribution web site is: http://www.matronics.com/contribution And I'd like to say a special "thank you!" to everyone one who has made Contribution so far this year!! I really appreciate your generosity! Best regards, Matt Dralle Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 11, 2002
Subject: Re: RV-4 Engine Mounts
Hi Hank; The first thing is to determine whether you have conical or dynafocal engine mounts (straight or angled). Some early E2D's had conical mounts. Either way, you can order replacement engine mount rubbers from Aircraft Spruce. You then support the engine with a hoist hooked to the loop on the upper crankcase, then remove the engine mount bolts one at a time. Replace the rubber mounts and retighten the bolts per the Lycoming recommendations. I have conical mounts and tighten them until the rubber matches the diameter of the outer washer. You might even notice a bit more smoothness...good luck! RR --- Hank Landman wrote: > > > Hello Everyone, > > I have an older RV-4 (1986) powerd by an O-320-E2D. > Upon examination of the spinner/cowling alignment, > it appears that the engine may have drooped 3/4" or > so. Can adjustments be made to the engine mounts to > correct the spinner alignment? Any ideas are > welcome. > > Thanks, > > Hank Landman > pukndg(at)mindspring.com > > > > Month -- > Gifts!) > Click on the Contribution > Terrific Free Gifts! > Dralle, List Admin. > _-> > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > U2 on LAUNCH - Exclusive greatest hits videos http://launch.yahoo.com/u2 ________________________________________________________________________________
Date: Nov 11, 2002
Hank, Your drooping engine could be from worn out lord mounts. The rubber ages and gets hard. New ones will cut down on vibration and hold it in place better. Hope this helps. Jim RV-4 Serial # 111 ________________________________________________________________________________
Date: Nov 14, 2002
Subject: Said What...?
Dear Listers, Wow, I can't belive some of the nice things people have been saying about the Lists in that little message box on the Contribution form! I've included more of the great comments since the last WLAS. Thank you to everyone that has made a Contribution thus far and for all the great feedback! Please know that I really appreciate the comments and support!! Have a look at some of your fellow members thoughts below and decide if the Lists mean at least that much to you or perhaps even more... Won't you take a moment and make a Contribution to support these Commercial-Free, SPAM-Free, Virus-Free, high-performance List services? Its your direct support through this yearly Fund Raiser that enables all of these valuable services you've come to expect of the Matronics Lists. Thank you for your Contribution!! SSL Secure Web Site - http://www.matronics.com/contribution Matt Dralle EMail List Administrator ===================================================================== =================== What Listers Are Saying - II ==================== ===================================================================== I check this List 4 to 5 times a day... -Bruce B. These are without a doubt among the best managed Lists to which I subscribe. -Terry W. Thank you for providing such a wonderful service. -Roy W. ...fine service! -Christopher A. Best list on the Internet! -Geroge A. Great list with a host of features. -David A. Having built part of a kit... ...I know exactly how much this list means to me and others. -Curtis H. As always... you've got a real cool & very useful service going... -Chuck R. I shudder to think of the trouble I would have had getting this project airborne without this list! -Grant C. ...enjoy everyone's input. -Doug P. I read the [the List] every day... -Ronald S. Whenever I feel like not building on my day off....I open my mail and the [the List] gets me pumped and ready to hit it! -Tom E. The Digest Message subject list is an excellent addition. -Kevin S. Certainly the [the List] has been a valuable source for building support and advice, but there's another benefit,... the wonderful friends that we meet and keep for years and years! -Fred H. What a great forum to exchange ideas and info. -Terry L. The List is my daily RV fix. -Neil H. I always received comments and suggestions when I requested them. -Thomas G. Best resource a builder could ever have. A daily must! -Robert C. Thanks for your gift - these web sites! -Tom P. ...great info. -Richard W. The List empowers all RV builders to achieve success... -Mark G. I've been reading the postings for a month now and decided to take the plunge as a result of the helpfulness and spirit of cooperation I observed. -Tim P. ...invaluable service. -Ford F. I check in at least twice daily for my e-mail "Fix". -John S. Its worth every penny of my contribution. -Paul M. Wonderful web site and it keeps getting better. -Jim H. A valuable list which has certainly helped me. -Andrew G. ...the List helps so many. -Don J. I really appreciate the site and find it interesting to speak to people who are into this type of aircraft. -Larry M. This is a great recreation for me. -Larry B. [The List] keeps me up to date and provides a fantastic resource for information. -Terry F. Lists are a great resource! -Daniel S. ...great service and professional administration of the Lists. -Chris R. I really appreciate the List. -Edward O. Worth every penny, and then some! -Kenyon B. ...great service. -Ralph H. Your unselfish contribution to the experimental aircraft movement is very much appreciated! -Alex M. Great help on the Aeroelectric list. -Bruce B. It helps on a daily basis. -Tim G. Thanks for providing this outstanding service to us! -Michel T. ________________________________________________________________________________
Date: Nov 15, 2002
From: Lieutenant Commander Geoff Winter <geoffwinter(at)earthlink.net>
Subject: Subaru engine for RV4
Hi all, I'm considering an Eggenfellner Subaru for installation into an RV-4. Has anyone out there experience of this combination? If so, what engine mount did you use and what sort of cowl modifications were required? Any advice would be most appreciated. Geoff ________________________________________________________________________________
Date: Nov 15, 2002
Subject: Re: Subaru engine for RV4
Geoff, there is a guy in Atlanta who put a Turbo Subie of his own construction in an RV4. He was flying a turbo subie before Eggenfeller was even in business. It flies great and I have flown formation with him in my 150HP RV4. You can reach him through Mike Stewart, I CC'd him on the email. Cheers... Smokey --- Lieutenant Commander Geoff Winter wrote: > Geoff Winter > > Hi all, > > I'm considering an Eggenfellner Subaru for > installation into an RV-4. Has anyone out there > experience of this combination? If so, what engine > mount did you use and what sort of cowl > modifications were required? Any advice would be > most appreciated. > > Geoff > > > > Month -- > Gifts!) > Click on the Contribution > Terrific Free Gifts! > Dralle, List Admin. > _-> > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Nov 16, 2002
Subject: LOC Coming Soon...
Dear Listers, This year's List of Contributors (LOC) is just around the corner. I'll be posting the LOC on or about December 1. The List of Contributors is a directory of everyone's name that made a Contribution during this year's List Fund Raiser. Its kind of my way of publicly thanking everyone that so generously made a Contribution to support the continued operation and upgrade of these Lists. Support your Lists today and make sure that your name is on the upcoming LOC! Your friends will be checking no doubt to see if YOU make your Contribution because THEY did! :-) Support Contribution Info - http://www.matronics.com/contribution Thank you! Matt Dralle Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 16, 2002
Subject: [ Bob & Lucille Olds ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Bob & Lucille Olds Subject: Our new RV-4, N1191X http://www.matronics.com/photoshare/oldsfolks@aol.com.11.16.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Nov 17, 2002
Subject: [ Rob Ray ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Rob Ray Subject: Rob Ray's "Bandit" http://www.matronics.com/photoshare/smokyray@yahoo.com.11.17.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Nov 19, 2002
Subject: [PLEASE READ] - Why Do I Have A Fund Raiser Each Year?
Dear Listers, I got to thinking today that perhaps I should explain why I have a Fund Raiser and also take the opportunity to express why I think the List Services here provide a far better experience than the commercial equivalents. I use the List Fund Raiser each year to offset the costs involved with running a high performance email list site such as this one. With the annual support from the List members through the PBS-like Fund Raiser, I have found I can run the entire site without having to inflect any of the members with those annoying banner ads flashing up all the time trying to sell Toner Cartridge Refills or other garbage nobody wants or needs. From the comments I've received over the years regarding the Lists, the great majority of the members really appreciate the non-commercialism of my List systems and don't mind my 'go-team-go' banter once a year to encourage members to support the Lists. I believe that the Lists services that I provide here offer a great many benefits over the commercial equivalents in a number of ways. The first feature I believe to be particularly significant is that you *cannot* receive a computer v*rus from any of my Lists directly. I've been on a few other List servers and have been unfortunate enough to download infected files people have innocently or not-so-innocently included with their posts. This just can't happen with my Lists; each incoming message is filtered and attachments stripped off prior to posting. I provide a Photo and File Share feature that allows members to share files and bitmaps with other members and everyone can be assured that these files will be prescanned for any sort of v*rus before they are posted. Safe and simple. Also, with this photo and file sharing technique, the Archives don't get loaded up with a huge amounts of bitmap "data" that slows the Archive Search times. Another feature of this system is the extensive List Archives that are available for download, browsing, and searching. The Archives go all the way back to the very beginning of each List and with the super fast Search Engine, the huge size of the Archives is a non-issue in quickly finding the data you're looking for. Another feature of the Archives, in my opinion, is that they have been primarily stripped of all the useless email header data and all the other header garbage that seems to build up in a typical email thread. I have received an extremely positive response from Listers regarding the List Browse feature and the consensus is that the format and ease of use is outstanding. Members report that having the previous 7 days worth of messages online for easy browsing and sorting is hugely beneficial. And again, as with the real time distribution of List email, the messages are stripped of all the unnecessary email headers and potentially dangerous v*ruses. I am currently working on the additional ability to post and/or reply directly from the List Browse interface. More on this upcoming feature in the next week or so. I've been running email Lists and services under the matronics.com domain since about 1989 starting with RV-List and 30 guys who I knew and who where also building RVs. It has grown into over 40 different aviation-related Email Lists and an associated web site that receives over 9,000,000 hits each year!! Additionally, the List email system forwards well over 50,000,000 (yes, that 50 MILLION) email messages to subscribers each year! With all the dot.bombs these days, I think there's a lot of value in supporting a service that has gone the long haul and is still providing and improving a high quality service at a price that's nearly free. I have to admit running these Lists is a labor of love and I hope it shows in the quality of the experience that you receive when you get a List Email Message, Search the Archives, or use the List Browser. The Lists will be here for a long time to come. If you just want to lurk a while for free, that's great and I encourage you to do so. If you use, appreciate, and receive value from these Lists, then please support them during the Annual List Fund Raiser! Thank you, Matt Dralle Email List Administrator ------------------------------------------ The SSL Secure Web Site: http://www.matronics.com/contribution ------------------------------------------ ________________________________________________________________________________
Date: Nov 20, 2002
Subject: Clip Art or graphic of RV-4
I would like to get some Land's End shirts for my partners in our RV-4, but I need a graphic of an RV-4 that I can possibly modify with our paint scheme. Or if I can't find that, maybe a clip art of an RV-4 that is good enough to use. Even better, if someone has already done this and Land's End has image on file, I can use it and save big bucks. Any advice? Thanks Jeff Bertsch noms1reqd(at)yahoo.com --------------------------------- ________________________________________________________________________________
Date: Nov 21, 2002
Subject: Re: Clip Art or graphic of RV-4
The Vans website has the 3 view drawings for each model at the bottom of the "writeup". Just go to the RV4 section, a cool looking RV4 (mine) is seen flying over the ID mountains, scroll down and they are at the bottom, cut paste and voila'... RR --- Jeff Bertsch wrote: > > > > I would like to get some Land's End shirts for my > partners in our RV-4, but I need a graphic of an > RV-4 that I can possibly modify with our paint > scheme. Or if I can't find that, maybe a clip art > of an RV-4 that is good enough to use. > > Even better, if someone has already done this and > Land's End has image on file, I can use it and save > big bucks. > > Any advice? > > Thanks > > Jeff Bertsch > > noms1reqd(at)yahoo.com > > > --------------------------------- > > > > Month -- > Gifts!) > Click on the Contribution > Terrific Free Gifts! > Dralle, List Admin. > _-> > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > http://mailplus.yahoo.com ________________________________________________________________________________
Date: Nov 22, 2002
Subject: List Value?
Dear Listers, We are quickly approaching the end of November and the official end of the List Fund Raiser. If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some lame magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that same amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support YOUR Lists. Contribution Page: http://www.matronics.com/contribution Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 23, 2002
Subject: Fund Raiser Free Gift Shipping Status...
Dear Listers, A couple of people have written asking what the shipping status was of their free List Contribution Gifts. Seemed like some status was in order and I thought I detail where we're at... Flight Bag Requests ------------------- On 11/20/02 I shipped out the first batch of Flight Bag-Only (FBO) gift requests. I shipped all FBO gift requests I had received from 11/1 to 11/19 except for 3 (Sorry guys!) - I ran out of my first shipment flight bags! Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ) is supplying me with another batch flight bags which should arrive in about 2 weeks. By the way, these are REALLY nice Flight Bags. Extremely well built and very professional looking. Folds down into a very small size, but will hold a huge amount of stuff. If you fly, and you've got a lot of stuff, they you WANT one of these guys. Surf over to the List Contribution page for details on how to get one of your own!!! http://www.matronics.com/contribution The Flight Bags have been shipped out US Mail Parcel Post in a large, and I mean LARGE, padded white plastic envelope. According to the Post Office, worse case delivery time would be 8 days to destinations on the East Coast, but indicated it would likely take a lot less time. Archive CDROM Requests ---------------------- The Archive CDROMs will be mastered and burned on or about December 1 and should ship out shortly there after. Shipping will be US Mail, Media Rate in a big padded white envelope. The Archive List data included will be up to November 30th. Flight Bag and Archive CDROM Requests ------------------------------------- These combination orders will ship out when the Archive CDROMs are complete as described above, likely a little after December 1. The Flight Bag and the CDROM will be shipped together in the same Giant white padded envelope! Again, I want to thank Andy Gold of the Builder's Bookstore for providing these awesome Flight Bags to support the List Fund Raiser. Andy has gone way beyond the call of duty with regard to his support of the Lists this year and to show your gratitude I would ask that you have a look at his web site and great media offerings. You'll find some excellent deals on some very useful material. http://www.buildersbooks.com And finally, I would like to thank everyone that has so generously made a Contribution so far this year! Your generosity and kindness is greatly appreciated. If you've been putting off making a Contribution, now's a great time show your appreciation in plenty of time to make it onto this year's List of Contributors AND get your free gift with qualifying Contribution!!! List Contribution Site: http://www.matronics.com/contribution/ Thank you! Matt Dralle Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Date: Nov 25, 2002
Subject: All New List FAQs!
Dear Listers, I got to looking at the Email List FAQs (Frequently Asked Questions) today and realized that they where miserably out of date. I spent a wad of time today completely revising them and adding in documentation on all of the many new features such as the List Browse and Photoshare. Many of the little-known features are documented in there now, too, so even if you're a seasoned List veteran, you might want to give it a read. Never know what you might discover. At the bottom of this message in the Trailer you will find a new link item called "List FAQ" with a URL for this specific List. Just click on it and print it out or read it online. Don't forget that November is the List Fund Raiser month! The "2002 List of Contributors" is just days away and I know you'll want to make sure your name is on it!! Please make your Contribution today to support the continued operation of these List Services! http://www.matronics.com/contribution Thank you! Matt Dralle ________________________________________________________________________________
Date: Nov 25, 2002
Subject: WLAS
Dear Listers, There are only a few days left until the November List of Contributors. I thought I'd take another opportunity to pass along some of the really nice things people have been saying recently about the Lists and how much they mean to them. If you receive value from the Lists in the form of ideas, assistance, comradery, moral support, inspiration, or just plain 'ol good entertainment, then won't take a moment to make a Contribution to support the continued operation and upgrade of them? Secure List Contribution Site: http://www.matronics.com/contribution What does the List mean to you? Here's what some of your fellow contributing List members have said... ------------------------- What Listers Are Saying ------------------------- Great service for aviation types like me. Larry H Best investment I've made. Harley B I've been on this list since around 1996 and used it to help me finish my RV-6A three years ago. I'm still here because I still learn from it and use it to help others like me who may be where nobody else is building a RV. Thanks for your service to our community. It's appreciated. Jim S [List] people are a great break away from politics, religion and other sordid subjects. Robert B This site is a great confidence builder for the amateur builder. Gene L Great service! Barry P Very handy list to have, a good place for a beginner to get great answers from those who already experienced it. ...sure enjoy reading it. Joel R ...valuable service! Chris & Indira K This is the better than any morning paper - the best and most frequent service that I use on the Internet. Great job! This will make building the RV doable for me. Pete E I enjoy all of the ideas, suggestions and humor that comes with this list. I don't think I could build my RV4 with out everyone's help. Ross S GRRRRRRRRRRRREAT! James W The list is a great source of information, motivation, entertainment, passionate debate, and light-hearted back slapping. I wouldn't be without it. Roger H ...would still be looking for plans to hook-up s-tec auto pilot without your service! David S The new [digest] format is good. Graham S Great information you can't get anywhere else. Lots of nice people who have "Been there...done that." George D My normal morning routine: 1 Kiss "the princess" 2 Good cup of coffee 3 Log onto "List" A wonderful means of exchanging ideas, asking questions, gathering information, and sharing experiences. Robert G Great lists. Not only are the lists professionally and efficiently managed, but the *people* on the lists are very helpful, friendly and fun to chat with. Thank you for this wonderful resource. Ihab A Thanks a million, well maybe not a million!!! (: Ken H I need this fix every morning or I get grumpy... Wayne P Very useful lists Paul E This communication medium that you created, nurtured and continue to maintain is the best thing since AN rivets! Jim J The information I gleaned off the list has always been helpful. Kenneth B I've been a subscriber to varied lists for several years now. The knowledge provided has been extremely useful throughout. David P Enjoy everyone's input even though I am not a builder...just a flyer. Douglas P Just laughin' and a scratchin' Dennis N It is a real asset and good for comic relief. Ross S I can't build my plane without your service! Kent H Great info on the lists! Wesley H I'm very new to the List but have already benefited greatly. Jim S The "List" has been my best source for information concerning my aviation projects. Besides, it also brings a bunch of people together to share their interests and knowledge. Thanks for providing a state of the art, easy to use resource tool. David A I have saved a lot of grief and dollars from referencing this site. It is truly an extension of Van's product support. Joseph C Terrific asset this List is to the builder! Scott J Great service! Tony B Look forward to the list each and every day. John B I could not cope up here in this lonely island without the help of the List and all the wonderful helpful people that have the experience of aircraft building and flying for fun. Johann J This list is part of my daily routine. I'm addicted. Terry D Great forum! John H This list is my main interest in the Internet. George R Great list. The best out there on any subject. Kevin H Been on the list since 1998 and I still look forward to reading the list every day. A most valuable tool. I have picked up many useful tips during the construction of my RV-4. Jerry I Thanks for all of your hard work on the lists. It is one of the reasons I bought a CJ-6A. Without the Yak-list, I believe it would have been much more difficult to get all the information that I need for safe operation and maintenance of this fine aircraft. David L The List has been an amazing source of useful information. I consider it one of my best builder tools. Gunter M An excellent channel of information. I have gained a wealth of knowledge on both building and flying Kolb aircraft. Jim B Enjoy the wealth of information that is shared. Richard N Fine service. Beauford T [The] List is the first stop of the day. Made lot of friends from it. Orie S The information I gleaned off the List has always been helpful. Kenneth B Over the 3+ years that I have been building, I check it several times each day. I have learned a lot of very useful tips that have helped me in my building. Richard D Not only is it worth a contribution for the info gleaned from it but the personalities alone are pure entertainment! Stephen F This is great stuff!!! Entertaining, too!! Fast answers from those who really know... Bob R I am building an RV-9A and have received help from the lists and occasionally been able to give help to others. Alden Van W This list has saved me countless hours of work and worry already, and I'm only halfway there! Undoubtedly the most important aid I have yet found in this sometimes intimidating process of building an aircraft. Paul H I've been a member since '96 and have learned so much from the vast knowledge of the listers. Gary Z Outstanding List, exceptionally maintained. David S Thanks for all the improvements you've made this year. The Photoshare feature definitely proves "one picture is worth a thousand words". Richard H I finished my RV6A this year. It is a much better airplane because of the help I found on the RV and Aeroelectric Lists. Dale W Can't imagine building without the list. Larry H The list continues to be a great resource of information and advice. Jeff O ________________________________________________________________________________
Date: Nov 28, 2002
Subject: New Gift Selection Added - List Fund Raiser! [Please Read]
Dear Listers, I've just added a great new last minute Gift Selection to this year's List Fund Raiser line up! I have a very limited number of sets of a wonderful collection of Aircraft Technical books by Jeppesen entitled "The A&P Technical Series Book Set". This is a great opportunity to make a generous Contribution to support the Lists and walk away with a great set of reference manuals at the same time. This set of books normally retails for over $117 PLUS shipping, but you can pick up your set AND make this year's List Contribution for a cool C-note - that's a $100, by the way! :-) I'm thinking "Great Christmas Gift"... There's more information on the books and making your Contribution at the List Contribution web site: Email List Contribution Web Site: http://www.matronics.com/contribution We're coming close to the official end of this year's List Fund Raiser and if you haven't yet made your Contribution, there's still time get your name on that List of Contributors! The percentage of contributors is kind of low this year but I'm hoping many of you are just holding out until the last minute! I want to thank each and everyone of you that has already made a donation to support the continued operation and upgrade of these List Services. As I've mentioned in the past, running these Lists is a labor of love for me and the hours upon hours of code development, system maintenance, and upgrades are MY Contribution to support this great resource for Builders and Flyer's alike. Won't your take a minute and make YOUR Contribution today? I want to thank you for your support both during the Fund Raiser but also throughout the year in the form of kind words and moral support. A nice comment from a List member about how much the lists have helped them is always a sure way to brighten my day! Thank you to all! Matt Dralle Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 28, 2002
Subject: heat muff.
right now i have a heat muff that only goes over 1 exhaust. it's not giving enough heat. i've seen one where it goes over both exhaust pipes. does anyone know who make the dual heater? thank you dan carley ________________________________________________________________________________
Date: Nov 28, 2002
Subject: [PLEASE READ!] "What is my Contribution used for?"
Dear Listers, Some have asked, "What is my Contribution used for?", and this is a valid question. Here are just a few examples of what your direct List support enables. It provides for the expensive, business-class, high-speed Internet connection used on the List, insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine and List Browser. It pays for 14+ years worth of online archive data available for instant random access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, and Photoshare. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements about these days? I will venture to say - next to none... It is YOUR CONTRIBUTION that directly enables these many desirable aspects of this most valuable List service. Please support it today with your List Contribution. Its the best investment you can make in your Sport - BAR NONE! Email List Contribution Web Site: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2002
Subject: List Report...
Dear Listers, This is the last "official" day of the List Fund Raiser. Based on previous year's percentages of Lister's making a Contribution, this year we are nearly 40% behind the normal... And I thought all those great gifts would eke the percentage up past the average a little. Oh well. Maybe people just don't really mind the flashing banner ads for Viagra, and popups for X10 minicams... There's still plenty of time to get your name of the List of Contributors. I'll probably publish the LOC on Monday night after I process the checks from the Post Office. I do want to thank everyone that has so generously made a Contribution so far this year. Your support is greatly appreciated and is what makes the Lists possible. How to support your Lists this month: http://www.matronics.com/contributions Thank you! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 30, 2002
Subject: Re: heat muff.
Dan, before you pay alot of money for the double muff try a "redneck" heat expander. Remove the muff and wrap a bedspring around the pipe inside the muff and reinstall the muff. I have used it on my RV and my Tcraft when I lived in SD. It works great! Give it a try. Rob Ray --- DFCPAC(at)aol.com wrote: > > right now i have a heat muff that only goes over 1 > exhaust. it's not giving > enough heat. i've seen one where it goes over both > exhaust pipes. does anyone > know who make the dual heater? > > thank you > dan carley > > > > Click on the > this > generous > _-> > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/archives > http://www.matronics.com/FAQ/RV4-List.htm > http://www.matronics.com/emaillists > > > > > http://mailplus.yahoo.com ________________________________________________________________________________
Date: Nov 30, 2002
hi rob, thanks for the info on the trim, i was a little concerned about it. rather than going through all the trouble of shimming it it's best to leave it alone. just wanted to make sure it was common in rv's. as far as the heat i did try the spring thing not very good. the heat muff i have on it now is not so good. when i bought the plane it came with it. there are a few cracks in the welds so it's only a matter of time before i need on. i found the dual one robbins wings makes them. 90 bucks not bad well worth it to keep warm. i was out thanks giving 27 degrees out with the wind chill it was 17, then going up to 3000ft it got cold. take care danny ________________________________________________________________________________
Date: Nov 30, 2002
Subject: All New List Digest Format!!
Dear Listers, I've just finished up some awesome code that will completely change your thinking about how email Digests should work and look! Yeah, I'm kind of proud of it, that is true... :-) What you'll be getting in the new List Digest message is the following: The main message will contain the new text-based index I introduced a few weeks back. But here's where things get different... Instead of simply including all of the day's posts in line within the message, there will now be included two enclosures - one with a HTML encoded version of the Digests, and another with the usual text-only version of the Digests. I think you're really going to like the new HTML enclosure of the Digests. All of the Indexes at the top are now hyperlinked to the actual posts and there are hyperlinks at the top of each post that will: o Take you back to the Index o Take you to the next post o Take you to the previous post o Allow you to respond to the LIST regarding the message o Allow you to respond directly to the POSTER regarding the message You'll have to check it out to appreciate the full goodness of the new format! :-) The text-only version is basically exactly the same data that has been normally sent in line within the message. You'll also note that the filenames of the enclosures are such that they can be conveniently placed in a personal "archive" directory for future reference. Hope you enjoy the new Digest format!!! Oh, and don't forget about the Fund Raiser! :-) Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Dec 01, 2002
Yeah Danny, I guess it does get cold up there. I sealed every hole in my canopy and cockpit and made heating it alot easier. I have a very small muff, but I take the intake air off a cyllinder and use a 1" duct hose and 2 bed springs, once the paint burned off the springs, it was fine! RR --- DFCPAC(at)aol.com wrote: > > hi rob, > thanks for the info on the trim, i was a little > concerned about it. rather > than going through all the trouble of shimming it > it's best to leave it > alone. just wanted to make sure it was common in > rv's. > > as far as the heat i did try the spring thing not > very good. the heat muff i > have on it now is not so good. when i bought the > plane it came with it. there > are a few cracks in the welds so it's only a matter > of time before i need on. > i found the dual one robbins wings makes them. 90 > bucks not bad well worth > it to keep warm. i was out thanks giving 27 degrees > out with the wind chill > it was 17, then going up to 3000ft it got cold. > > take care > danny > > > > Click on the > this > generous > _-> > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/archives > http://www.matronics.com/FAQ/RV4-List.htm > http://www.matronics.com/emaillists > > > > > http://mailplus.yahoo.com ________________________________________________________________________________
Date: Dec 01, 2002
Subject: New, NEW List Digest Format...
Dear Listers, Okay, so I woke up this morning to an email box full of hate-mail about the new List Digest format. I thought it was cool, but I guess not... Still, it seemed like too much code to just throw out, so I've modified things a little and I'm hoping everyone will be happy with the new, NEW arrangement. Here's how it works now: o The HTML and TXT enclosures aren't sent in the Digest any longer. o URL Links to the HTML and TEXT versions of the day's Digests will be found at the top of the digest email. o The new Digest Index will be found at the top of the digest email following the URL Links. o The full digest text will then be found in the email as before. o All of the previous Digests will now be available on line. The URL for the main digest page is: http://www.matronics.com/digest From here, you can drill into the specific List Digest of interest. o Both the HTML and TXT versions of the Digests can be found here. o The List Message Trailer will contain a Link directly to the given o Right now there's only one Digest shown, but each day there will be another. They will be sorted with the newest at the top. Left-hand column is the HTML version, right-hand column the TXT version. A couple people also complained that some messages in the HTML version were just one long line that went off to the right forever and they hated that. Come to think of it, this is also an issue in the Search Engine, List Browser, and Archive Browser. Some email programs don't included hard Returns at regular intervals and that's what causes this. I wrote a program tonight that will automatically chop these long lines into 78 characters or less and wrap the rest of the line. After tonight's Archive transfer, all of the Searching and Browsing tools shouldn't have the problem any longer either. Woo hoo! So, back to the new Digest format. What people are going to see in the new, NEW Digest is a bit of verbiage at the top of the email describing the URL links to the HTML and TXT on-line versions, followed by the Links, followed by the day's Index, followed by the day's messages just as before. Lines longer than 78 characters will also be automatically wrapped onto the next line. Hopefully this will be a more pleasing arrangement for everyone. Sorry to get everybody so stirred up over the format change! The List of Contributors is coming out tomorrow night... Still time to make that Contribution! http://www.matronics.com/contribution Best regards, Matt Dralle Email List Admin. ________________________________________________________________________________
Subject: paint
Date: Dec 18, 2002
Hi guys! -Has anyone used paint stripper for fiberglass? results,problems? -Has anyone used Randolph water-based polyurethane paint? results, problems? Glenn Wilkinson 654RV Milledgevile, Ga (MLJ) ________________________________________________________________________________
Date: Dec 18, 2002
Subject: Re: paint
Gentlemen, While we're on the subject of removing paint , has anyone removed the sloshing sealer from a fuel tank?What were the results and would you do it again? (I think I know that answer). I am looking down that barrel and I don't like what I see. I am concidering having new tanks made but don't like the price of the tanks,installation costs, painting etc.. If anyone has experienced this I'd like to hear from you. Thanks, Jim Mandeville RV-4 # 111 ________________________________________________________________________________
Date: Dec 18, 2002
Subject: Aileron nose skin
Just been to the school of hard knocks. After clecoing the nose skin on the aileron, I noticed that the skin didn't lay tight against the rear skin. Sooooooooo, I disassembled it and used the Avery roller to slightly bend the edge down. After reassembling with clecos, the problem was worse. I repeated the procedure and was a little more aggressive with the bending. Didn't look real good with clecos, but I reasoned that after riveting it would lay tightly. Guess I'll have to drill out and buy another nose skin or try and fill the edges somehow that are lifted between the rivets. I'm sure that rolling the edge caused the material to stretch causing the excess material to warp between rivets. What can I do to avoid this with the new skin? Pat Long Bay City, Michigan (989)684-0581 Working on an RV-4 Email: PGLong(at)aol.com ________________________________________________________________________________
Date: Dec 18, 2002
Subject: Re: Aileron nose skin
In a message dated 12/18/2002 8:49:43 PM Eastern Standard Time, PGLong(at)aol.com writes: > Just been to the school of hard knocks. After clecoing the nose skin on the > aileron, I noticed that the skin didn't lay tight against the rear skin. > Sooooooooo, I disassembled it and used the Avery roller to slightly bend > the > edge down. After reassembling with clecos, the problem was worse. I > repeated > the procedure and was a little more aggressive with the bending. Didn't > look > real good with clecos, but I reasoned that after riveting it would lay > tightly. Guess I'll have to drill out and buy another nose skin or try and > fill the edges somehow that are lifted between the rivets. I'm sure that > rolling the edge caused the material to stretch causing the excess material > > to warp between rivets. What can I do to avoid this with the new skin? > > Pat Long > Hi Pat, My aileron nose skins laid down well after rolling, but they fit pretty well to begin with. Did you make sure the spar was oriented correctly? 80.5 degree flange angle on top and 83.5 degrees for the bottom flange. (According to preview plans) Hal Benjamin RV-4, Fuselage Long Island, NY ________________________________________________________________________________
Subject: Re: paint
Date: Dec 18, 2002
----- Original Message ----- From: <FLYBOYRV4(at)aol.com> Subject: Re: RV4-List: paint > > Gentlemen, While we're on the subject of removing paint , has anyone removed > the sloshing sealer from a fuel tank?What were the results and would you do > it again? (I think I know that answer). I am looking down that barrel and I > don't like what I see. I am concidering having new tanks made but don't like > the price of the tanks,installation costs, painting etc.. If anyone has > experienced this I'd like to hear from you. Thanks, Jim Mandeville RV-4 # > 111 > > Hi, Jim I removed the sloshing compound from my tanks a couple of years ago. I found it to be a miserable job especially as it was done in the heat of a South Tx summer and the fumes from the solvent (MEK) prohibited working indoors with the a/c on. In any case, it was tedious to get all of it out, but I was determined to never find any in my gascolator again. I had found small pieces for years, but that summer, the pieces were larger and one day I saw a large piece floating in the bay that has the filler hole. Visions of something that big wrapping it self around the pickup tube had me motivated right now! The work was done by cutting access holes through the back of the tanks in the three outboard bays and using the hole for the fuel sender for the inboard bay. Did I mention it was a miserable job? Anyway after it was all removed, I closed up the access holes with .040 aluminum, Proseal and numerous blind rivets.Good luck Ivan Haecker -4 860hrs. ________________________________________________________________________________
Date: Dec 18, 2002
Subject: Re: paint
DO NOT use paint stripper on fiberglass, it will eat the epoxy and ruin the fiberglass! Trust me! -Mike N223RV RV-4 10.1 hours and loving it! ________________________________________________________________________________
Date: Dec 18, 2002
Subject: Re: paint
AMEN! Rob Ray N557RR 890+ hours,48 states, 3 countries and still loving it! --- N8292W(at)aol.com wrote: > > DO NOT use paint stripper on fiberglass, it will eat > the epoxy and ruin the > fiberglass! Trust me! > -Mike > N223RV > RV-4 > 10.1 hours and loving it! > > > > Click on the > this > generous > _-> > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV4-List.htm > Digests:http://www.matronics.com/digest/rv4-list > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Subject: Re: paint
Date: Dec 19, 2002
Rob, I have found paint stripper formulated for fiberglass, according to the manufacturer this is the type I was thinking of trying but was unsure due to the reasons you stated. Any experience with that type? Glenn ----- Original Message ----- From: "rob ray" <smokyray(at)yahoo.com> Subject: Re: RV4-List: paint > > AMEN! > > Rob Ray N557RR > 890+ hours,48 states, 3 countries and still loving it! > > > --- N8292W(at)aol.com wrote: > > > > DO NOT use paint stripper on fiberglass, it will eat > > the epoxy and ruin the > > fiberglass! Trust me! > > -Mike > > N223RV > > RV-4 > > 10.1 hours and loving it! > > > > > > > > Click on the > > this > > generous > > _-> > > Contributions > > any other > > Forums. > > > > latest messages. > > List members. > > > > http://www.matronics.com/subscription > > http://www.matronics.com/FAQ/RV4-List.htm > > Digests:http://www.matronics.com/digest/rv4-list > > http://www.matronics.com/archives > > http://www.matronics.com/photoshare > > http://www.matronics.com/emaillists > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: paint
Date: Dec 22, 2002
Hi Jim, Glad to hear #111 is still flying! You may remember that I built (with your rivet squeezer) and flew a 6-A for four years. I sold it this year to get 4 places (in a Bonanza), and am reconsidering whether that was dumb or not. I'm looking at a 7-A or maybe the -10 when it comes out. Still just in the considering stage though. Hope all's well with you. Say HI to Don for me. Merry Christmas! Tim Whitman ----- Original Message ----- From: <FLYBOYRV4(at)aol.com> Subject: Re: RV4-List: paint > > Gentlemen, While we're on the subject of removing paint , has anyone removed > the sloshing sealer from a fuel tank?What were the results and would you do > it again? (I think I know that answer). I am looking down that barrel and I > don't like what I see. I am concidering having new tanks made but don't like > the price of the tanks,installation costs, painting etc.. If anyone has > experienced this I'd like to hear from you. Thanks, Jim Mandeville RV-4 # > 111 > > ________________________________________________________________________________
Date: Dec 23, 2002
Subject: Re: paint
Hi Tim; nice 35 knot tailwind blowing through AL the other day and a V35 was bragging about his 190 knot GS to approach control when I passed him in my 150HP RV4...oops! You need another RV! RR --- Tim Whitman wrote: > > > Hi Jim, > > Glad to hear #111 is still flying! You may remember > that I built (with your > rivet squeezer) and flew a 6-A for four years. I > sold it this year to get 4 > places (in a Bonanza), and am reconsidering whether > that was dumb or not. > I'm looking at a 7-A or maybe the -10 when it comes > out. Still just in the > considering stage though. > Hope all's well with you. > Say HI to Don for me. > > Merry Christmas! > > Tim Whitman > > > ----- Original Message ----- > From: <FLYBOYRV4(at)aol.com> > To: > Subject: Re: RV4-List: paint > > > > > > Gentlemen, While we're on the subject of removing > paint , has anyone > removed > > the sloshing sealer from a fuel tank?What were the > results and would you > do > > it again? (I think I know that answer). I am > looking down that barrel and > I > > don't like what I see. I am concidering having new > tanks made but don't > like > > the price of the tanks,installation costs, > painting etc.. If anyone has > > experienced this I'd like to hear from you. > Thanks, Jim Mandeville RV-4 # > > 111 > > > > > > > > Click on the > this > generous > _-> > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV4-List.htm > Digests:http://www.matronics.com/digest/rv4-list > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Dec 23, 2002
Subject: Re: paint
Hi Tim, Glad to hear you are also flying, a BONANZA yet! How did you feel selling a plane you built? I would think it was difficult to do. How did you handle the liability aspect of the sale? I am having trouble with the fuel tanks so I won't be flying for a while until the new tanks are built and installed. (no small job). The plane is 13 years old now and needs a few things attended to. I am having Noreast Aircraft Inc. @ plymouth do the work as they are familiar with the RV-4. I can't imagine selling her, I have too much fun . Hope to see you around the patch. Jim ________________________________________________________________________________
Subject: Re: paint
Date: Dec 23, 2002
Hi Jim, It was diffficult parting with 46PH (I kept the rights to the tail number), it's true, but one wheel kept dragging (afraid of a lock up on landing), the (2nd) carb was leaking fuel (afraid of an engine fire) , I was concerned about rust on/in the gear legs(gear collapse?) etc, so I would have needed a lot of time to get it right. I found a fellow who was willing to sign papers assuring he would use the airframe for ground static tests, and never let the parts fly again. The engine, avionics etc. were sold to folks from Florida to California to Canada. I miss the carefree flight and actual construction of the parts. But I fly Coast Guard Auxiliary, some Angel Flights, and personal missions with three aboard fairly regularly now though. I'm blessed either way as I see it and each day I get to fly I am just happy I can fly at all. Hope your bird gets healthy soon. Tim W. ----- Original Message ----- From: <FLYBOYRV4(at)aol.com> Subject: Re: RV4-List: paint > > Hi Tim, Glad to hear you are also flying, a BONANZA yet! How did you feel > selling a plane you built? I would think it was difficult to do. How did you > handle the liability aspect of the sale? I am having trouble with the fuel > tanks so I won't be flying for a while until the new tanks are built and > installed. (no small job). The plane is 13 years old now and needs a few > things attended to. I am having Noreast Aircraft Inc. @ plymouth do the work > as they are familiar with the RV-4. I can't imagine selling her, I have too > much fun . Hope to see you around the patch. Jim > > ________________________________________________________________________________
Date: Jan 01, 2003
Subject: Aileron mounting template
Looking for some more advice. Being the 3rd owner of an RV 4 kit, I don't have access to the original shipping container that had the aileron / flap mounting template marked on it. I'll be ready to mount them before long and am wondering if this jig is really necessary? If it is, could someone make a paper template from theirs and mail it to me? Or, can I get one of these from Van's? Other ideas? Pat Long Bay City, Michigan (989)684-0581 Working on an RV-4 Email: PGLong(at)aol.com ________________________________________________________________________________
Date: Jan 01, 2003
>Looking for some more advice. Being the 3rd owner of an RV 4 kit, I don't >have access to the original shipping container that had the aileron / flap >mounting template marked on it. Pat, I think it can be done without them put they do work very well. I build my RV-6 with ones that I cut from the container but not very carefully. I just finished the wings on my RV-4 and used some quality templates I borrowed from another RV-6 builder. I got a much better fit with the good templates and the installation is easier also. If you can't borrow some templates from a local builder, email me and I will try to copy them to paper. You can use the -4 or the -6 template as they are the same. Ken http://www.mninter.net/~kbeene/ ________________________________________________________________________________
Date: Jan 02, 2003
Subject: [ Fred Stucklen ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Fred Stucklen Subject: RV-6A IFR Inst Panel & Wiring http://www.matronics.com/photoshare/wstucklen1@cox.net.01.02.2003/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Jan 03, 2003
Subject: drilling out pop rivets
Is there a preferred way to drill out pop rivets? CS 4's? Or do you just go at it same as a bucked rivet? Going to replace my aileron nose skin and hopefully get it right this time. Thanks! Pat Long Bay City, Michigan (989)684-0581 Working on an RV-4 Email: PGLong(at)aol.com ________________________________________________________________________________
Subject: Re: drilling out pop rivets
Date: Jan 03, 2003
If possible, drive out the shank first using a punch and some kind of back up. Then it should drill out fairly easily. If it spins sometimes you can grab the back side with vice grips or needlenose pliers. If that's not possible somtimes drilling at a slight angle works. Neil ----- Original Message ----- From: <PGLong(at)aol.com> Subject: RV4-List: drilling out pop rivets > > Is there a preferred way to drill out pop rivets? CS 4's? Or do you just go > at it same as a bucked rivet? Going to replace my aileron nose skin and > hopefully get it right this time. Thanks! > > Pat Long > > Bay City, Michigan > (989)684-0581 > Working on an RV-4 > Email: PGLong(at)aol.com > > ________________________________________________________________________________
Date: Jan 05, 2003
Subject: Conical lord mount problems
I am back in the air now and the J-6230-1 conical lord mounts are not > working well for me. The mounts I had previously used were #71032 > bushings (8) and big washers(8). The expensive new mounts came with no > direction and I am wondering if I installed them wrong because the > engine moves around on a 3 g pull up and I hate the smell of burning > rubber and a nice pulley slot in my bumpout on the cowling. The spinner > is a 1/4" sag to the cowling. I oriented the mounts as Vans sent me a > pic showing the orientation holes since my motor mount did not have the > alignment markings. Their was a smash stop spacer that came with the > mounts and it goes between the two bushings and only allows one to > tighten the mounts just so far and that seems like that could be part of > the problem. I did not use any of the big fender washers that were used > with my old rubbers that did not have washers embedded in them like > these new ones. Any ideas? I really don't notice these mounts being > any smoother than my old mounts and the 71032 bushings could be smashed > together more than these. My engine is a O-320-A2B. Have others experienced this problem? > > > Greg Hunsicker ________________________________________________________________________________
Subject: RV-4 Condition Inspection
Date: Jan 12, 2003
Hello All, Does anyone have a copy of an RV-4 condition inspection checklist? Soft copy would be helpful. Thanks, Hank ________________________________________________________________________________
Date: Jan 12, 2003
Subject: Re: RV-4 Condition Inspection
HI Hank, If you want a condition report format you can follow, the EAA has a generic one for fixed gear single engine. I remember the EAA ran a story on just that a few months ago. Why not give them a call? After you get a copy just customize it for your particular model and accesories. Jim Mandeville RV-4 # 111 ________________________________________________________________________________
Date: Jan 13, 2003
Subject: electric attitude gyro
does anyone have or knows where to get a used 12 volt attitude gyro for sale. thanks dan carley ________________________________________________________________________________
From: "Glenn Bridges" <gbridges(at)altamahaemc.net>
Subject: cd
Date: Jan 14, 2003
dear ;matt, i know it's not your fault. at my age i was able to build an rv-4 and fly it but i can not figure out the archive cd that i got for my donation. any suggestions or shall i donate the cd to goodwill. thanks glenn bridges ________________________________________________________________________________
Date: Jan 19, 2003
Subject: Riveting ailerons
On my ailerons, I'm about to rivet (again) the nose skin to the rear skin. Saw a picture on a website showing the riveter on the floor looking up at the row of clecos and wondering how the individual rivets stayed in long enough to get the gun on them. My holes are slightly oversized due to drilling them out to replace the nose skin. Small piece of rivet tape? Then I wondered if anyone has tried to back rivet this line of rivets? Seems like you could use the corner of a back rivet plate to get started. I'm working by myself so wondered if there was a better way than I did it last time. Blindly holding the bucking bar from underneath and trying to keep the gun on the right spot at the right angle. I do have the swivel head so that should help keep it square. Any tips? ________________________________________________________________________________
Date: Jan 19, 2003
Subject: Re: Riveting ailerons
In a message dated 1/19/2003 8:35:51 AM Eastern Standard Time, PGLong(at)aol.com writes: > My holes are slightly oversized due to drilling them > out to replace the nose skin. Small piece of rivet tape? Then I wondered if > > anyone has tried to back rivet this line of rivets? Seems like you could > use > the corner of a back rivet plate to get started. I'm working by myself so > wondered if there was a better way than I did it last time. Blindly holding > > the bucking bar from underneath and trying to keep the gun on the right > spot > at the right angle. I do have the swivel head so that should help keep it > square. Any tips? > Hi PG, I thought about back riveting the top row but I couldn't see a way to get a straight shot without distorting the skin. So I just did them with a small flat bucking bar in one hand & gun in the other. Riveting tape does help holding them in place while you finagle the bar into position to shoot. Just take it slow. Good Luck. Hal Benjamin, RV-4 Fuselage on Jig Long Island, NY ________________________________________________________________________________
Date: Jan 25, 2003
Subject: [ Ollie Washburn ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Ollie Washburn Subject: RV Tow Bars... http://www.matronics.com/photoshare/ollie-6a@prodigy.net.01.25.2003/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Jan 28, 2003
rv8-list(at)matronics.com
Subject: Re: RV6-List Digest: 0 Msgs - 01/27/03
version=2.40 Do the landing lights recessed into the sheared fiberglass wing tips provide equivalent lighting compared to the lights mounted in the leading edge of an RV6 or any RV for that matter? From a night visibility standpoint, if I choose the leading edge to mount the lights, does it matter if you place them just outboard of the fuel tanks or out next the the wing tip? It would be easier to install at the wing tip. Thanks Roger Crandell ________________________________________________________________________________
Date: Jan 28, 2003
version=2.40 Roger, I have a single Bob Olds light mounted 10" inboard from the left wingtip on my RV4. It utilizes a halogen car headlight with good results in 350+ night landings. It is of excellent construction and I would give it a very high recommendation. I don't know if Bob is still making them though. I have flown an RV6 with JC whitney Halogen car driving lights mounted inside the wingtips that worked equally well. In both installations, you don't see anything on final at night until 100'AGL on striped pavement and 50'AGL above the flare on grass. They are mainly useful in taxiing... I would go for ease and low cost with automotive replaceability and cut the least amount of aluminum...good luck! RR --- Roger Crandell wrote: > > > Do the landing lights recessed into the sheared > fiberglass wing tips > provide equivalent lighting compared to the lights > mounted in the > leading edge of an RV6 or any RV for that matter? > From a night visibility > standpoint, if I choose the > leading edge to mount the lights, does it matter if > you place them just > outboard of the fuel tanks or out next the the wing > tip? It would be easier to > install > at the wing tip. > > Thanks > > Roger Crandell > > > > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV4-List.htm > Digests:http://www.matronics.com/digest/rv4-list > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Jan 31, 2003
Subject: Re: RV 4 rear wing spar
In a message dated 1/31/2003 10:31:48 AM Pacific Standard Time, PGLong(at)aol.com writes: > Hi Experts > > My RV 4 wings have the nose and bottom skins riveted on. To mount the > outboard aileron bracket, I have to cut the rear spar off one inch. This is > > the one inch extra length for mounting to the jig I think. I don't think > the > jig will be needed anymore as one side is completely skinned. Seems like > someone told me not to do this. Am I going to need this one inch extra > length > for anything? The wings are now in a roll around cart, in a nose down > position mounted only on the main spar. Am I looking for trouble if I do > this? > > > If the wing is drilled out and "locked" by the skins then you can trim the rear spar flush with the rib so you can attach the outboard aileron bracket Good Luck Tim Barnes Meangreen RV-4 ________________________________________________________________________________
Date: Jan 31, 2003
You can also reset the jig to grab the newly riveted aileron bracket (which you riveted after you wacked off the tab). Russ > > > >My RV 4 wings have the nose and bottom skins riveted on. To mount the > >outboard aileron bracket, I have to cut the rear spar off one inch. This is > >the one inch extra length for mounting to the jig I think. I don't think > >the > >jig will be needed anymore as one side is completely skinned. Seems like > >someone told me not to do this. Am I going to need this one inch extra > >length > >for anything? The wings are now in a roll around cart, in a nose down > >position mounted only on the main spar. Am I looking for trouble if I do > >this? > > ________________________________________________________________________________
Date: Feb 02, 2003
Note: forwarded message attached. Date: Sat, 01 Feb 2003 13:36:48 -0600 From: arvil(at)bellsouth.net Subject: Re: Fwd: Re: RV4-List: RV 4 rear wing spar It is best to keep the wing in its jiged position till the flaps and ailerons are mounted this can be done by making a diferent bracket just below the aileron bracket so the wing can be held in place from the jig post , this lets you make sure the ailerons and flaps are in aliment with the wing when installed Arvil rob ray wrote: > Note: forwarded message attached. > > __________________________________________________ > > > Subject: Re: RV4-List: RV 4 rear wing spar > Date: Fri, 31 Jan 2003 13:23:31 -1000 > From: "Russ Werner" <russ(at)maui.net> > Reply-To: rv4-list(at)matronics.com > To: > > > You can also reset the jig to grab the newly riveted aileron bracket (which > you riveted after you wacked off the tab). > > Russ > > > > > > >My RV 4 wings have the nose and bottom skins riveted on. To mount the > > >outboard aileron bracket, I have to cut the rear spar off one inch. This > is > > >the one inch extra length for mounting to the jig I think. I don't think > > >the > > >jig will be needed anymore as one side is completely skinned. Seems like > > >someone told me not to do this. Am I going to need this one inch extra > > >length > > >for anything? The wings are now in a roll around cart, in a nose down > > >position mounted only on the main spar. Am I looking for trouble if I do > > >this? > > > > ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: Can't get full elevator travel
Date: Feb 03, 2003
Thought I'd pose this to the REAL builders out there; the RV-4 builders. There is one last item keeping me from my first flight. That is my elevator travel. I can only get about 26 deg up. The elevator horn hits the aft-most bulkhead before I get the full 30 degrees. Anyone else run into this? -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Date: Feb 03, 2003
Hey Scott, I think you're gonna have to re-drill your holes in the horn (both left & right side). Chuck ----- Original Message ----- From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> Subject: RV4-List: Can't get full elevator travel > > Thought I'd pose this to the REAL builders out there; the RV-4 builders. > There is one last item keeping me from my first flight. That is my elevator > travel. I can only get about 26 deg up. The elevator horn hits the > aft-most bulkhead before I get the full 30 degrees. Anyone else run into > this? > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > ________________________________________________________________________________
Date: Feb 03, 2003
How is that going to help? No matter where the holes in the horn are, it still hits that bulkhead before achieving full 30 deg up. I don't even have the pushrod hooked up right now. Why can't anything ever be easy?? -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: C. Rabaut [mailto:crabaut(at)coalinga.com] Subject: Fw: RV4-List: Can't get full elevator travel Hey Scott, I think you're gonna have to re-drill your holes in the horn (both left & right side). Chuck ----- Original Message ----- From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> Subject: RV4-List: Can't get full elevator travel > > Thought I'd pose this to the REAL builders out there; the RV-4 builders. > There is one last item keeping me from my first flight. That is my elevator > travel. I can only get about 26 deg up. The elevator horn hits the > aft-most bulkhead before I get the full 30 degrees. Anyone else run into > this? > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > ________________________________________________________________________________
Date: Feb 03, 2003
Scott, I had the same problem on my RV-4. I ended up hogging out for lack of a better term some of the bulkhead to get the full travel. I then reinforced that area with a piece of angle that also serves as the up elevator stop. Steve Harris N144SH RV-4, 125 hours -----Original Message----- From: Van Artsdalen, Scott [mailto:svanarts(at)unionsafe.com] Subject: RE: RV4-List: Can't get full elevator travel How is that going to help? No matter where the holes in the horn are, it still hits that bulkhead before achieving full 30 deg up. I don't even have the pushrod hooked up right now. Why can't anything ever be easy?? -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: C. Rabaut [mailto:crabaut(at)coalinga.com] Subject: Fw: RV4-List: Can't get full elevator travel Hey Scott, I think you're gonna have to re-drill your holes in the horn (both left & right side). Chuck ----- Original Message ----- From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> Subject: RV4-List: Can't get full elevator travel > > Thought I'd pose this to the REAL builders out there; the RV-4 builders. > There is one last item keeping me from my first flight. That is my elevator > travel. I can only get about 26 deg up. The elevator horn hits the > aft-most bulkhead before I get the full 30 degrees. Anyone else run into > this? > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > ________________________________________________________________________________
Date: Feb 03, 2003
Just so everybody knows... I finally broke down and called the factory. They said that I'm okay at 26 degrees of up elevator travel. If I want more I can file down the rear of the elevator horn to get more travel. What is crucial is to not hit the angle that goes across the top of the aft deck that the vertical is bolted to. My manual was wrong on this (30 deg up and down) so I'll repost here what the elevator limits are: 25 - 30 deg up 20 - 25 deg down -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: C. Rabaut [mailto:crabaut(at)coalinga.com] Subject: Fw: RV4-List: Can't get full elevator travel Hey Scott, I think you're gonna have to re-drill your holes in the horn (both left & right side). Chuck ----- Original Message ----- From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> Subject: RV4-List: Can't get full elevator travel > > Thought I'd pose this to the REAL builders out there; the RV-4 builders. > There is one last item keeping me from my first flight. That is my elevator > travel. I can only get about 26 deg up. The elevator horn hits the > aft-most bulkhead before I get the full 30 degrees. Anyone else run into > this? > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > ________________________________________________________________________________
Date: Feb 03, 2003
Okay, now I've got a better visual picture of what's happening... The only thing I can think is either; 1- replace the horns (I've got a spare set you can have) and position them so the travel you need is there, or; 2- cut your current set and have them welded back just enough to achieve the needed travel.... sorry, with the RV-4's you design and fabricate as you go. But, it's still the Best of the RV's! Chuck ----- Original Message ----- From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> Subject: RE: RV4-List: Can't get full elevator travel > > How is that going to help? No matter where the holes in the horn are, it > still hits that bulkhead before achieving full 30 deg up. I don't even have > the pushrod hooked up right now. Why can't anything ever be easy?? > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: C. Rabaut [mailto:crabaut(at)coalinga.com] > To: Scott Van Artsdalen > Subject: Fw: RV4-List: Can't get full elevator travel > > > Hey Scott, I think you're gonna have to re-drill your holes in the horn > (both left & right side). > > Chuck > > > ----- Original Message ----- > From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> > To: > Subject: RV4-List: Can't get full elevator travel > > > > > > > Thought I'd pose this to the REAL builders out there; the RV-4 builders. > > There is one last item keeping me from my first flight. That is my > elevator > > travel. I can only get about 26 deg up. The elevator horn hits the > > aft-most bulkhead before I get the full 30 degrees. Anyone else run into > > this? > > > > -- > > Scott VanArtsdalen > > Network Manager > > Union Safe Deposit Bank > > 209-946-5116 > > > > > > ________________________________________________________________________________
Subject: Re: Can't get full elevator travel
Date: Feb 03, 2003
I had the same problem and the factory told me to grind the elevator horns. They also said that you could use the angle going across the longerons as the elevator stop. That needed to be made slightly smaller as well. Russ ----- Original Message ----- From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com> Subject: RE: RV4-List: Can't get full elevator travel > > Just so everybody knows... I finally broke down and called the factory. > They said that I'm okay at 26 degrees of up elevator travel. If I want more > I can file down the rear of the elevator horn to get more travel. What is > crucial is to not hit the angle that goes across the top of the aft deck > that the vertical is bolted to. > > My manual was wrong on this (30 deg up and down) so I'll repost here what > the elevator limits are: > > 25 - 30 deg up > 20 - 25 deg down > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: C. Rabaut [mailto:crabaut(at)coalinga.com] > To: Scott Van Artsdalen > Subject: Fw: RV4-List: Can't get full elevator travel > > > Hey Scott, I think you're gonna have to re-drill your holes in the horn > (both left & right side). > > Chuck > > > ----- Original Message ----- > From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> > To: > Subject: RV4-List: Can't get full elevator travel > > > > > > > Thought I'd pose this to the REAL builders out there; the RV-4 builders. > > There is one last item keeping me from my first flight. That is my > elevator > > travel. I can only get about 26 deg up. The elevator horn hits the > > aft-most bulkhead before I get the full 30 degrees. Anyone else run into > > this? > > > > -- > > Scott VanArtsdalen > > Network Manager > > Union Safe Deposit Bank > > 209-946-5116 > > > > > > ________________________________________________________________________________
Date: Feb 03, 2003
Yep, this is what they told me too. Did you actually grind some material off of that piece of angle? -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Russ Werner [mailto:russ(at)maui.net] Subject: Re: RV4-List: Can't get full elevator travel I had the same problem and the factory told me to grind the elevator horns. They also said that you could use the angle going across the longerons as the elevator stop. That needed to be made slightly smaller as well. Russ ----- Original Message ----- From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com> Subject: RE: RV4-List: Can't get full elevator travel > > Just so everybody knows... I finally broke down and called the factory. > They said that I'm okay at 26 degrees of up elevator travel. If I want more > I can file down the rear of the elevator horn to get more travel. What is > crucial is to not hit the angle that goes across the top of the aft deck > that the vertical is bolted to. > > My manual was wrong on this (30 deg up and down) so I'll repost here what > the elevator limits are: > > 25 - 30 deg up > 20 - 25 deg down > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: C. Rabaut [mailto:crabaut(at)coalinga.com] > To: Scott Van Artsdalen > Subject: Fw: RV4-List: Can't get full elevator travel > > > Hey Scott, I think you're gonna have to re-drill your holes in the horn > (both left & right side). > > Chuck > > > ----- Original Message ----- > From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> > To: > Subject: RV4-List: Can't get full elevator travel > > > > > > > Thought I'd pose this to the REAL builders out there; the RV-4 builders. > > There is one last item keeping me from my first flight. That is my > elevator > > travel. I can only get about 26 deg up. The elevator horn hits the > > aft-most bulkhead before I get the full 30 degrees. Anyone else run into > > this? > > > > -- > > Scott VanArtsdalen > > Network Manager > > Union Safe Deposit Bank > > 209-946-5116 > > > > > > ________________________________________________________________________________
Date: Feb 03, 2003
Scott; I have 26 degrees up travel as well. In 850 hours I have never needed more, including alot of over the top acro, short field landings and slow flight. I have never approached full up travel in normal operations. If you attack the up limit at slow speed, it simply buffets, until you unload the stick... RR --- "Van Artsdalen, Scott" wrote: > Scott" > > Just so everybody knows... I finally broke down and > called the factory. > They said that I'm okay at 26 degrees of up elevator > travel. If I want more > I can file down the rear of the elevator horn to get > more travel. What is > crucial is to not hit the angle that goes across the > top of the aft deck > that the vertical is bolted to. > > My manual was wrong on this (30 deg up and down) so > I'll repost here what > the elevator limits are: > > 25 - 30 deg up > 20 - 25 deg down > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: C. Rabaut [mailto:crabaut(at)coalinga.com] > To: Scott Van Artsdalen > Subject: Fw: RV4-List: Can't get full elevator > travel > > > > Hey Scott, I think you're gonna have to re-drill > your holes in the horn > (both left & right side). > > Chuck > > > ----- Original Message ----- > From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> > To: > Subject: RV4-List: Can't get full elevator travel > > > Scott" > > > > > Thought I'd pose this to the REAL builders out > there; the RV-4 builders. > > There is one last item keeping me from my first > flight. That is my > elevator > > travel. I can only get about 26 deg up. The > elevator horn hits the > > aft-most bulkhead before I get the full 30 > degrees. Anyone else run into > > this? > > > > -- > > Scott VanArtsdalen > > Network Manager > > Union Safe Deposit Bank > > 209-946-5116 > > > > > > > > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV4-List.htm > Digests:http://www.matronics.com/digest/rv4-list > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Feb 03, 2003
The RV-4 buffets?? That -6 I flew with Mike sure didn't buffet. It got slow and then just dropped! That's good to hear though. I've got 26 deg up right now. I may just leave well enough alone for now. Now if someone can just give me some advice on how to fix a brake leak I'll be happy! It's leaking right at the plastic TEE that comes out of the reservoir. -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: rob ray [mailto:smokyray(at)yahoo.com] Subject: RE: RV4-List: Can't get full elevator travel Scott; I have 26 degrees up travel as well. In 850 hours I have never needed more, including alot of over the top acro, short field landings and slow flight. I have never approached full up travel in normal operations. If you attack the up limit at slow speed, it simply buffets, until you unload the stick... RR --- "Van Artsdalen, Scott" wrote: > Scott" > > Just so everybody knows... I finally broke down and > called the factory. > They said that I'm okay at 26 degrees of up elevator > travel. If I want more > I can file down the rear of the elevator horn to get > more travel. What is > crucial is to not hit the angle that goes across the > top of the aft deck > that the vertical is bolted to. > > My manual was wrong on this (30 deg up and down) so > I'll repost here what > the elevator limits are: > > 25 - 30 deg up > 20 - 25 deg down > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: C. Rabaut [mailto:crabaut(at)coalinga.com] > To: Scott Van Artsdalen > Subject: Fw: RV4-List: Can't get full elevator > travel > > > > Hey Scott, I think you're gonna have to re-drill > your holes in the horn > (both left & right side). > > Chuck > > > ----- Original Message ----- > From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> > To: > Subject: RV4-List: Can't get full elevator travel > > > Scott" > > > > > Thought I'd pose this to the REAL builders out > there; the RV-4 builders. > > There is one last item keeping me from my first > flight. That is my > elevator > > travel. I can only get about 26 deg up. The > elevator horn hits the > > aft-most bulkhead before I get the full 30 > degrees. Anyone else run into > > this? > > > > -- > > Scott VanArtsdalen > > Network Manager > > Union Safe Deposit Bank > > 209-946-5116 > > > > > > > > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV4-List.htm > Digests:http://www.matronics.com/digest/rv4-list > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Feb 03, 2003
Scott; It buffets only if you reef it at very low speed..I mean REAL slow, as in a slow vertical scissors fighting somebody or zero knots over the top. The brake problem is plastic. You might try putting white plumbers tape around the fitting, re-tightening the eyeball fittings or just start over. I ripped all my plastic out this week after five years of pesky leaks. I replaced all of it with braided steel and steel fittings from my local auto parts/parker hose dealer (parker owns cleveland). $85 total cost. No leaks, no runs, no errors. The plastic line was so hard after 5 years it wouldn't bend and was leaking from every fitting in cold weather. I recommend not using it. RR --- "Van Artsdalen, Scott" wrote: > Scott" > > The RV-4 buffets?? That -6 I flew with Mike sure > didn't buffet. It got > slow and then just dropped! That's good to hear > though. I've got 26 deg up > right now. I may just leave well enough alone for > now. Now if someone can > just give me some advice on how to fix a brake leak > I'll be happy! It's > leaking right at the plastic TEE that comes out of > the reservoir. > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: rob ray [mailto:smokyray(at)yahoo.com] > To: rv4-list(at)matronics.com > Subject: RE: RV4-List: Can't get full elevator > travel > > > > Scott; > > I have 26 degrees up travel as well. In 850 hours > I > have never needed more, including alot of over the > top > acro, short field landings and slow flight. I have > never approached full up travel in normal > operations. > If you attack the up limit at slow speed, it simply > buffets, until you unload the stick... > > RR > --- "Van Artsdalen, Scott" > wrote: > > Scott" > > > > Just so everybody knows... I finally broke down > and > > called the factory. > > They said that I'm okay at 26 degrees of up > elevator > > travel. If I want more > > I can file down the rear of the elevator horn to > get > > more travel. What is > > crucial is to not hit the angle that goes across > the > > top of the aft deck > > that the vertical is bolted to. > > > > My manual was wrong on this (30 deg up and down) > so > > I'll repost here what > > the elevator limits are: > > > > 25 - 30 deg up > > 20 - 25 deg down > > > > -- > > Scott VanArtsdalen > > Network Manager > > Union Safe Deposit Bank > > 209-946-5116 > > > > -----Original Message----- > > From: C. Rabaut [mailto:crabaut(at)coalinga.com] > > To: Scott Van Artsdalen > > Subject: Fw: RV4-List: Can't get full elevator > > travel > > > > > > > > Hey Scott, I think you're gonna have to re-drill > > your holes in the horn > > (both left & right side). > > > > Chuck > > > > > > ----- Original Message ----- > > From: Van Artsdalen, Scott > > > To: > > Subject: RV4-List: Can't get full elevator travel > > > > > > Scott" > > > > > > > > Thought I'd pose this to the REAL builders out > > there; the RV-4 builders. > > > There is one last item keeping me from my first > > flight. That is my > > elevator > > > travel. I can only get about 26 deg up. The > > elevator horn hits the > > > aft-most bulkhead before I get the full 30 > > degrees. Anyone else run into > > > this? > > > > > > -- > > > Scott VanArtsdalen > > > Network Manager > > > Union Safe Deposit Bank > > > 209-946-5116 > > > > > > > > > > > > > > Contributions > > any other > > Forums. > > > > latest messages. > > List members. > > > > http://www.matronics.com/subscription > > http://www.matronics.com/FAQ/RV4-List.htm > > Digests:http://www.matronics.com/digest/rv4-list > > http://www.matronics.com/archives > > http://www.matronics.com/photoshare > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV4-List.htm > Digests:http://www.matronics.com/digest/rv4-list > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Feb 03, 2003
You have part numbers for that fancy brake line stuff? I'm an idiot when it comes to that kind of stuff. -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: rob ray [mailto:smokyray(at)yahoo.com] Subject: RE: RV4-List: Can't get full elevator travel Scott; It buffets only if you reef it at very low speed..I mean REAL slow, as in a slow vertical scissors fighting somebody or zero knots over the top. The brake problem is plastic. You might try putting white plumbers tape around the fitting, re-tightening the eyeball fittings or just start over. I ripped all my plastic out this week after five years of pesky leaks. I replaced all of it with braided steel and steel fittings from my local auto parts/parker hose dealer (parker owns cleveland). $85 total cost. No leaks, no runs, no errors. The plastic line was so hard after 5 years it wouldn't bend and was leaking from every fitting in cold weather. I recommend not using it. RR --- "Van Artsdalen, Scott" wrote: > Scott" > > The RV-4 buffets?? That -6 I flew with Mike sure > didn't buffet. It got > slow and then just dropped! That's good to hear > though. I've got 26 deg up > right now. I may just leave well enough alone for > now. Now if someone can > just give me some advice on how to fix a brake leak > I'll be happy! It's > leaking right at the plastic TEE that comes out of > the reservoir. > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: rob ray [mailto:smokyray(at)yahoo.com] > To: rv4-list(at)matronics.com > Subject: RE: RV4-List: Can't get full elevator > travel > > > > Scott; > > I have 26 degrees up travel as well. In 850 hours > I > have never needed more, including alot of over the > top > acro, short field landings and slow flight. I have > never approached full up travel in normal > operations. > If you attack the up limit at slow speed, it simply > buffets, until you unload the stick... > > RR > --- "Van Artsdalen, Scott" > wrote: > > Scott" > > > > Just so everybody knows... I finally broke down > and > > called the factory. > > They said that I'm okay at 26 degrees of up > elevator > > travel. If I want more > > I can file down the rear of the elevator horn to > get > > more travel. What is > > crucial is to not hit the angle that goes across > the > > top of the aft deck > > that the vertical is bolted to. > > > > My manual was wrong on this (30 deg up and down) > so > > I'll repost here what > > the elevator limits are: > > > > 25 - 30 deg up > > 20 - 25 deg down > > > > -- > > Scott VanArtsdalen > > Network Manager > > Union Safe Deposit Bank > > 209-946-5116 > > > > -----Original Message----- > > From: C. Rabaut [mailto:crabaut(at)coalinga.com] > > To: Scott Van Artsdalen > > Subject: Fw: RV4-List: Can't get full elevator > > travel > > > > > > > > Hey Scott, I think you're gonna have to re-drill > > your holes in the horn > > (both left & right side). > > > > Chuck > > > > > > ----- Original Message ----- > > From: Van Artsdalen, Scott > > > To: > > Subject: RV4-List: Can't get full elevator travel > > > > > > Scott" > > > > > > > > Thought I'd pose this to the REAL builders out > > there; the RV-4 builders. > > > There is one last item keeping me from my first > > flight. That is my > > elevator > > > travel. I can only get about 26 deg up. The > > elevator horn hits the > > > aft-most bulkhead before I get the full 30 > > degrees. Anyone else run into > > > this? > > > > > > -- > > > Scott VanArtsdalen > > > Network Manager > > > Union Safe Deposit Bank > > > 209-946-5116 > > > > > > > > > > > > > > Contributions > > any other > > Forums. > > > > latest messages. > > List members. > > > > http://www.matronics.com/subscription > > http://www.matronics.com/FAQ/RV4-List.htm > > Digests:http://www.matronics.com/digest/rv4-list > > http://www.matronics.com/archives > > http://www.matronics.com/photoshare > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > Contributions > any other > Forums. > > latest messages. > List members. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV4-List.htm > Digests:http://www.matronics.com/digest/rv4-list > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Feb 03, 2003
Scott; They are #4 sized braided steel, teflon lines. Take ALL your plastic fittings with you to show them for the threads/fittings. Find a parker hose dealer in your area and measure all the lengths you need, exactly. Tell him it's for you "race car" brakes. On my RV4 I used 2- 24 inch lines(master to T),2-16 inch lines(master to firewall) and 2-50 inch lines (outside firewall to wheels). I used 6X90 degree elbows for the master and wheel cyllinders and 2X90 degree extended elbows with nuts where I went through the firewall. I went out the side of the rudder pedal wells with the 90 degree down on the outside pointing towards the gear leg, 2.5 inches below the top of the "shelf" and 2 inches from the front. The rudder pedal travel is not affected. You can save a few bucks by using aluminum aircraft line or just regular high pressure parker hose for the length of the gear leg where you won't see it. I just wanted good lines EVERYwhere. No more walking up to my airplane with puddles of red fluid under the wheels... RR --- "Van Artsdalen, Scott" wrote: > Scott" > > You have part numbers for that fancy brake line > stuff? I'm an idiot when it > comes to that kind of stuff. > > -- > Scott VanArtsdalen > Network Manager > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: rob ray [mailto:smokyray(at)yahoo.com] > To: rv4-list(at)matronics.com > Subject: RE: RV4-List: Can't get full elevator > travel > > > > Scott; > > It buffets only if you reef it at very low speed..I > mean REAL slow, as in a slow vertical scissors > fighting somebody or zero knots over the top. > The brake problem is plastic. You might try putting > white plumbers tape around the fitting, > re-tightening > the eyeball fittings or just start over. I ripped > all > my plastic out this week after five years of pesky > leaks. I replaced all of it with braided steel and > steel fittings from my local auto parts/parker hose > dealer (parker owns cleveland). $85 total cost. > No leaks, no runs, no errors. The plastic line was > so > hard after 5 years it wouldn't bend and was leaking > from every fitting in cold weather. I recommend not > using it. > > RR > --- "Van Artsdalen, Scott" > wrote: > > Scott" > > > > The RV-4 buffets?? That -6 I flew with Mike sure > > didn't buffet. It got > > slow and then just dropped! That's good to hear > > though. I've got 26 deg up > > right now. I may just leave well enough alone for > > now. Now if someone can > > just give me some advice on how to fix a brake > leak > > I'll be happy! It's > > leaking right at the plastic TEE that comes out of > > the reservoir. > > > > -- > > Scott VanArtsdalen > > Network Manager > > Union Safe Deposit Bank > > 209-946-5116 > > > > -----Original Message----- > > From: rob ray [mailto:smokyray(at)yahoo.com] > > To: rv4-list(at)matronics.com > > Subject: RE: RV4-List: Can't get full elevator > > travel > > > > > > > > Scott; > > > > I have 26 degrees up travel as well. In 850 > hours > > I > > have never needed more, including alot of over the > > top > > acro, short field landings and slow flight. I have > > never approached full up travel in normal > > operations. > > If you attack the up limit at slow speed, it > simply > > buffets, until you unload the stick... > > > > RR > > --- "Van Artsdalen, Scott" > > > wrote: > > > Scott" > > > > > > Just so everybody knows... I finally broke down > > and > > > called the factory. > > > They said that I'm okay at 26 degrees of up > > elevator > > > travel. If I want more > > > I can file down the rear of the elevator horn to > > get > > > more travel. What is > > > crucial is to not hit the angle that goes across > > the > > > top of the aft deck > > > that the vertical is bolted to. > > > > > > My manual was wrong on this (30 deg up and down) > > so > > > I'll repost here what > > > the elevator limits are: > > > > > > 25 - 30 deg up > > > 20 - 25 deg down > > > > > > -- > > > Scott VanArtsdalen > > > Network Manager > > > Union Safe Deposit Bank > > > 209-946-5116 > > > > > > -----Original Message----- > > > From: C. Rabaut [mailto:crabaut(at)coalinga.com] > > > To: Scott Van Artsdalen > > > Subject: Fw: RV4-List: Can't get full elevator > > > travel > > > > > > > > > > > > Hey Scott, I think you're gonna have to re-drill > > > your holes in the horn > > > (both left & right side). > > > > > > Chuck > > > > > > > > > ----- Original Message ----- > > > From: Van Artsdalen, Scott > > > > > To: > > > Subject: RV4-List: Can't get full elevator > travel > > > > > > > Artsdalen, > > > Scott" > > > > > > > > > > > Thought I'd pose this to the REAL builders out > > > there; the RV-4 builders. > > > > There is one last item keeping me from my > first > > > flight. That is my > > > elevator > > > > travel. I can only get about 26 deg up. The > > > elevator horn hits the > > > > aft-most bulkhead before I get the full 30 > > > degrees. Anyone else run into > > > > this? > > > > > > > > -- > > > > Scott VanArtsdalen > > > > Network Manager > > > > Union Safe Deposit Bank > > > > 209-946-5116 > > > > > > > > > > > > > > > > > > > > Contributions > > > any other > > > Forums. > > > > > > latest messages. > > > List members. > > > > > > http://www.matronics.com/subscription > > > http://www.matronics.com/FAQ/RV4-List.htm > > > Digests:http://www.matronics.com/digest/rv4-list > > > http://www.matronics.com/archives > > > http://www.matronics.com/photoshare > > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > > > > > > > > > > Contributions > > any other > > Forums. > > > > latest messages. > === message truncated === ________________________________________________________________________________
Date: Feb 04, 2003
Hello, Anyone out there live in the Bay Area of California??. My name is Ron and I live in San Leandro. I'm new to the RV list and to the concept of building my own plane. Am also considering finding an RV-4 "project" near enough to completion that I'd feel comfortable in trying to finish it up. I would appreciate any leads you all may have for me, including a part-ownership. Thanks, Ron Patterson ________________________________________________________________________________
Subject: Leading Edge Landing Lights Placement
Date: Feb 07, 2003
>, if I choose the > leading edge to mount the lights, does it matter if you place them just > outboard of the fuel tanks or out next the the wing tip? It would be easier to > install > at the wing tip. These have to go in the last section by the wingtip for structural reasons. It is also the best place for ease of service. For effectiveness, they are upgradable to 100 watt bulbs for less than $20. I have heard numerous testemonials from listers on how great they work. Norman Hunger RV6A Delta BC ________________________________________________________________________________
Subject: RV4
Date: Feb 11, 2003
looking for damaged or un-built fuse and canopy frame..will not be used for flight..need for experiment..503-678-3343..please tell me what you have..thanks ________________________________________________________________________________
Date: Feb 11, 2003
Subject: [ Scott Van Artsdalen ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Scott Van Artsdalen Subject: First Flight http://www.matronics.com/photoshare/svanarts@unionsafe.com.02.11.2003/index.html -------------------------------------------- o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photoshare of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to. 2) Your Full Name. 3) Your Email Address. 4) One line Subject description. 5) Multi-line, multi-paragraph description of topic. 6) One-line Description of each photo or file. Email the information above and your files and photos to: pictures(at)matronics.com -------------------------------------------- ________________________________________________________________________________
Date: Feb 13, 2003
Subject: [ Rob Ray ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Rob Ray Subject: What RV's Were Built For... http://www.matronics.com/photoshare/smokyray@yahoo.com.02.13.2003/index.html -------------------------------------------- o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to. 2) Your Full Name. 3) Your Email Address. 4) One line Subject description. 5) Multi-line, multi-paragraph description of topic. 6) One-line Description of each photo or file. Email the information above and your files and photos to: pictures(at)matronics.com -------------------------------------------- ________________________________________________________________________________
Date: Feb 14, 2003
Subject: [ Daniel Carley ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Daniel Carley Subject: Twin Towers http://www.matronics.com/photoshare/DFCPAC@aol.com.02.14.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Feb 23, 2003
Subject: Re: Fw: Van's Aircraft RV Survey
Tim, I'm with you on that one. What a tool for a lawyer in a court against our loved ones in a liability case! Talk about cutting your own ( family's) neck. Good call Timmyboy! Regards Jim Mandeville RV-4 # 111 > ________________________________________________________________________________
Subject: NACA vent in canopy skirt
Date: Mar 04, 2003
I'm going to add some additional ventilation for the back seat of my -4. I noticed the -4 on the EAA's web site Desktop Wall paper for march has 2 NACA vents in the canopy skirt. Does anyone on the list have a NACA vent installed in the canopy skirt just behind the pilot? I'd like to find out how well this works. Any other good suggestions for getting some air to the back? My wife will appreciate any suggestions. Pat Perry Dallas, PA RV-4 N154PK Flies great! ________________________________________________________________________________
Subject: Oil filter drain tool
Date: Mar 04, 2003
I thought I'd share this simple parts list with everyone, this is tool for draining the oil out of a filter before spinning it off and soaking everything between your engine and firewall with oil. This is not an original idea but my own cheap version of somthing I saw for sale for about $50. Parts: (1) 4" C-clamp - make sure it's about 1/2" bigger than an oil filter (1) 1/4" x 1.5" steel roll pin (3')1/4" ID tubing (1) hose clamps to fit 1/4" ID tube (1) 1/4" ID rubber washer To make: 1. grind a flat spot in the arch of the clamp behind the fixed pad of the c-clamp to allow drilling a 15/64" hole through the clamp pad. 2. grind the roll pin end to a very sharp point at about a 30deg angle. 3. Hammer the roll pin point first through the hole in the clamp until the point is about 1/4" through the pad. 4. Place the rubber washer over the sharp end of the roll pin 5. Clamp the 1/4" tube to the bottom of the roll pin. I tried this out last weekend, it took about 20 minutes to make the thing and it cost about $1 using an old c-clamp I had in the shop. It works perfect, by clamping it to the back of the filter it drains the oil out through the tube and keeps the oil off everything else. Pat Perry Dallas, PA RV-4 N154PK Flies great! ________________________________________________________________________________
Subject: Re: NACA vent in canopy skirt
Date: Mar 04, 2003
Pat, I have two naca vents in the canopy skirt on my -4. One near the front edge of the canopy skirt for the pilot, and one just behind the pilot. Both are on the right side skirt. The one for the "pilot" doesn't provide any airflow at all. I never open it. Might have something to do with the fact that the canopy skirt angles toward the firwall just aft of the vent. The vent for the passenger works very well, but is a little on the noisy side when open. A friend with a -4 retrofitted an under the wing naca vent ala RV-8, and it works very well. Tom N153TK 1,002 hours ----- Original Message ----- From: "Pat Perry" <pperryrv(at)hotmail.com> Subject: RV4-List: NACA vent in canopy skirt > > > I'm going to add some additional ventilation for the back seat of my -4. I > noticed the -4 on the EAA's web site Desktop Wall paper for march has 2 NACA > vents in the canopy skirt. > > Does anyone on the list have a NACA vent installed in the canopy skirt just > behind the pilot? I'd like to find out how well this works. Any other good > suggestions for getting some air to the back? My wife will appreciate any > suggestions. > > > Pat Perry > Dallas, PA > RV-4 N154PK Flies great! > > ________________________________________________________________________________
Subject: RV-4 NACA Air Vents
Date: Mar 04, 2003
Pat Perry, I have two NACA vents on my -4 installed like tomrv8(at)gvtc.com has on his -4...I get plenty of air flow through the forward one, but it was mostly going toward the rear occupant, so I took a very thin piece of sheet metal and shaped it very nicely and curved it so that it deflected the air on me up front...I wedged this thin sheet between the plastic scoop and the skirt and no fasteners were required at all. It surprised me that it stays there (it is a tight squeeze!)......if necessary, I suppose you could use some kind of "stickum" to hold it in place............Hope this helps.........CHEERS!!!!!............Gene Smith. ________________________________________________________________________________
Date: Mar 04, 2003
Subject: Cockpit Air Outlet?
Hi All, I've read quite a bit about the air inlets. Where is the air outlet located? To have air "flow", it normally requires an inlet AND an outlet. Jim Ayers RV-3 N47RV PS I know I don't have an air outlet "designed into" my RV-3. Is it expected to just happen? ________________________________________________________________________________
Subject: Air Outlets
Date: Mar 04, 2003
Yes, Jim Ayers you are correct......My canopy on the -4 is not that tight, and I purposely have not used weather stripping, caulking and etc. because of what Van said in the RVator about the smoke in the cockpit the first time he did an airshow after installing a smoke generator in the -4...I have always been concerned about carbon monoxide entering the cockpit, so I live with the built-in ventilation, but the exhaust system is checked for cracks every time the cowl comes off, and the bottom of the fuselage, and the firewall are totally sealed and checked often...............CHEERS!!!!!........................Gene Smith. ________________________________________________________________________________
Date: Mar 04, 2003
I have mine mounted on my forward fuselage just under the cheek cowlings on either side. Makes for pretty decent airflow. -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: 2 at UT [mailto:tomrv8(at)gvtc.com] Subject: Re: RV4-List: NACA vent in canopy skirt Pat, I have two naca vents in the canopy skirt on my -4. One near the front edge of the canopy skirt for the pilot, and one just behind the pilot. Both are on the right side skirt. The one for the "pilot" doesn't provide any airflow at all. I never open it. Might have something to do with the fact that the canopy skirt angles toward the firwall just aft of the vent. The vent for the passenger works very well, but is a little on the noisy side when open. A friend with a -4 retrofitted an under the wing naca vent ala RV-8, and it works very well. Tom N153TK 1,002 hours ----- Original Message ----- From: "Pat Perry" <pperryrv(at)hotmail.com> Subject: RV4-List: NACA vent in canopy skirt > > > I'm going to add some additional ventilation for the back seat of my -4. I > noticed the -4 on the EAA's web site Desktop Wall paper for march has 2 NACA > vents in the canopy skirt. > > Does anyone on the list have a NACA vent installed in the canopy skirt just > behind the pilot? I'd like to find out how well this works. Any other good > suggestions for getting some air to the back? My wife will appreciate any > suggestions. > > > Pat Perry > Dallas, PA > RV-4 N154PK Flies great! > > ________________________________________________________________________________
Date: Mar 04, 2003
I have tried NACA scoops on the canopy skirt, both front and back. Total failure in each case -- no air entry to speak of. They do work well, however, if placed in the lower wing skin. ________________________________________________________________________________
Subject: Re: Oil filter drain tool
Date: Mar 05, 2003
Excellent. This I am going to try. Thanks, Pat! Jim ----- Original Message ----- From: "Pat Perry" <pperryrv(at)hotmail.com> Subject: RV4-List: Oil filter drain tool > > I thought I'd share this simple parts list with everyone, this is tool for > draining the oil out of a filter before spinning it off and soaking > everything between your engine and firewall with oil. This is not an > original idea but my own cheap version of somthing I saw for sale for about > $50. > > Parts: > (1) 4" C-clamp - make sure it's about 1/2" bigger than an oil filter > (1) 1/4" x 1.5" steel roll pin > (3')1/4" ID tubing > (1) hose clamps to fit 1/4" ID tube > (1) 1/4" ID rubber washer > > To make: > 1. grind a flat spot in the arch of the clamp behind the fixed pad of the > c-clamp to allow drilling a 15/64" hole through the clamp pad. > > 2. grind the roll pin end to a very sharp point at about a 30deg angle. > > 3. Hammer the roll pin point first through the hole in the clamp until the > point is about 1/4" through the pad. > > 4. Place the rubber washer over the sharp end of the roll pin > > 5. Clamp the 1/4" tube to the bottom of the roll pin. > > I tried this out last weekend, it took about 20 minutes to make the thing > and it cost about $1 using an old c-clamp I had in the shop. It works > perfect, by clamping it to the back of the filter it drains the oil out > through the tube and keeps the oil off everything else. > > > Pat Perry > Dallas, PA > RV-4 N154PK Flies great! > > ________________________________________________________________________________
"'rv4-list(at)matronics.com'"
Subject: Harmonic Balancer W&B info for RV-4
Date: Mar 05, 2003
I just installed Landoll's harmonic balancer yesterday on my -4. There weren't any instructions so I just put it on they way that looked right. I'm going to try to fly with it either tonight or tomorrow morning. Does anyone have any weight and balance info for it. I believe it weighs 12 lbs. Anyone know what the station of the ring gear on a Lycoming is for an RV-4? PS. I'm going to check the archives now. :-) -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 http://www.w3.org/TR/REC-html40"> I just installed Landoll's harmonic balancer yesterday on my -4. There weren't any instructions so I just put it on they way that looked right. I'm going to try to fly with it either tonight or tomorrow morning. Does anyone have any weight and balance info for it. I believe it weighs 12 lbs. Anyone know what the station of the ring gear on a Lycoming is for an RV-4? PS. I'm going to check the archives now. J -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Date: Mar 05, 2003
From: Greg Hunsicker <Greg(at)furnacesafetyconsultants.com>
Subject: SkyTek light weight starter
I am about to remove a 17 pound starter on my 150 hp O-320 RV-4 and install one of the flyweight 8 pound starters. I did not build the airplane and am wondering if I have any real W&B issues? Is removing 9 pounds from that location going to cause me concern? I run a 12 pound Warnke prop. Greg ________________________________________________________________________________
Date: Mar 05, 2003
I run a Catto wood prop and have the lightweight starter and alternator. I haven't noticed any adverse flying conditions on my -4. HOWEVER, I've only got 6 hours on my plane and I just added a harmonic dampener from Landoll today. I was worried about carrying passengers without it. -- Scott VanArtsdalen Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Greg Hunsicker [mailto:Greg(at)furnacesafetyconsultants.com] Subject: RV4-List: SkyTek light weight starter I am about to remove a 17 pound starter on my 150 hp O-320 RV-4 and install one of the flyweight 8 pound starters. I did not build the airplane and am wondering if I have any real W&B issues? Is removing 9 pounds from that location going to cause me concern? I run a 12 pound Warnke prop. Greg ________________________________________________________________________________
Date: Mar 05, 2003
Subject: Re: SkyTek light weight starter
Hi Greg, Why aren't you doing a weight and balance calculation to determine this for yourself? Jim Ayers
August 26, 2002 - March 05, 2003
RV4-Archive.digest.vol-ac
