RotaxEngines-Archive.digest.vol-aw
December 11, 2010 - February 13, 2011
      engine. It is ok for a short look at something and landing setups, but not
      for a constant use. Your engine was specifically designed to run all it's
      life in the 5000's. It was never intended to run in the 4000's and is really
      hard on the engine over time and has much more vibration.
      Be nice to your engine it cost $20K and it is one of the only things keeping
      you in the air and safe.
      Roger Lee
      Tucson, Az.
      Light Sport Repairman - Maintenance Rated
      Rotax Repair Center
      Home 520-574-1080  TRY HOME FIRST
      Cell 520-349-7056
      http://forums.matronics.com/viewtopic.php?p=322924#322924
Date: Dec 11, 2010
From: NEEL Jean Philippe <jeanphilippeneel(at)yahoo.fr>
Subject: Icing: 912S versus 912
Hi all,=0AI flown my europa with a 912 80hp during 1200h/11years.It's a mar k one but with =0AXS engine mounting and cowlings.Majority of flights took place here in the =0AFrench Alps as well in -summer as in winter. I never had icing-issue although I =0Ahad no carb preheater-.The only caution I had ,when descending-,was to keep =0A4500/4800 rpm .-Never in idle po sition.=0AIn the beggining of that year I change-my-912-for a new 912 S 100hp. That new =0Aengine has now about 125h. Yesterday I had for the fir st time a rough running =0Aduring few seconds.Outer Air Temp was negative a t every level and the issue =0Aoccurs at the end of a descent 4500/4800rpm from 8000ft to 1500ft. There was =0Aabout- 8=B0C- of difference at grou nd level betwen OAT and dew point.=0ASeveral time I read on Rotax and Europ a web site discussions about icing issues =0Aand I-kept in mind that 912S should be more sensitive to icing than 912.=0A=0AAs-I know:=0A* -Ca rbs are the same ,except needle diam (2.72 versus 2.70 on S)-and ,may be, =0Amain fuel jet-and diffuser (in accordance with needle)-.Does those difference =0Acould explain more-sensitivity to icing?=0A* Compression ratio and bore-are increased on S--but stroke is the same-. In my =0Aopinion these difference have not thing to do with icing issue.=0A-So here is my question-:-Could some body explain why a 912S should be more =0Aexposed to icing than a 912?=0A=0AJean-Philippe Neel=0AF-PSLH Kit N=B02 73=0AGrenoble France-----=0A=0A=0A ________________________________________________________________________________
Date: Dec 11, 2010
The cooling (isentropic throttling) that makes carb icing happen is a function of the amount of fuel vaporized so with all other things being equal (same atmospheric conditions, engine manifold, carbs, RPM, etc.) you can expect the somewhat greater fuel flow (more power requires more fuel) to cause more cooling and hence a greater propensity to make ice. Obviously the 912 and 912S are =93different=94 engines but those differences are internal and downstream from the carbs. The 914 is less prone to carb ice because the air compressed by the turbo is warmer than the intake air. Thermodynamics rules! Best regards, Rob Housman Irvine, California Europa XS S/N A070 Rotax 914 Airframe complete Avionics soon From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of NEEL Jean Philippe Sent: Saturday, December 11, 2010 12:35 PM Subject: RotaxEngines-List: Icing: 912S versus 912 Hi all, I flown my europa with a 912 80hp during 1200h/11years.It's a mark one but with XS engine mounting and cowlings.Majority of flights took place here in the French Alps as well in summer as in winter. I never had icing issue although I had no carb preheater .The only caution I had ,when descending ,was to keep 4500/4800 rpm . Never in idle position. In the beggining of that year I change my 912 for a new 912S 100hp. That new engine has now about 125h. Yesterday I had for the first time a rough running during few seconds.Outer Air Temp was negative at every level and the issue occurs at the end of a descent 4500/4800rpm from 8000ft to 1500ft. There was about 8=B0C of difference at ground level betwen OAT and dew point. Several time I read on Rotax and Europa web site discussions about icing issues and I kept in mind that 912S should be more sensitive to icing than 912. As I know: * Carbs are the same ,except needle diam (2.72 versus 2.70 on S) and ,may be, main fuel jet and diffuser (in accordance with needle) .Does those difference could explain more sensitivity to icing? * Compression ratio and bore are increased on S but stroke is the same . In my opinion these difference have not thing to do with icing issue. So here is my question : Could some body explain why a 912S should be more exposed to icing than a 912? Jean-Philippe Neel F-PSLH Kit N=B0273 Grenoble France ________________________________________________________________________________
Subject: Re: Rotax E-Learning video on detonation and pre-ignition
Date: Dec 11, 2010
Actually both are correct. Rotax publishes numbers like that, but there are way to many applications in the world for everyone to be spot on, so why try to be at least close. Then the teachings in school aren't right along with the book either. So we try to balance a little. Plus we all have different setups. If you are at least 5000+ on take off and at 5500+ WOT you can sleep well at night. Hi Noel, Setting the rpm on the ground static is just to get close. Pitch angle does no good unless you are talking about two identical planes and props. The only way to really tell after that course static adjustment is to get into the air and get some real flight numbers. Shoot for around 5200 static on the ground and that will get you close enough for a flight test to dial it in where it really needs to be. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322996#322996 ________________________________________________________________________________
Date: Dec 12, 2010
What would you recommend to be a preliminary AOA for the prop? Warp, nickel edge, square tip, 72" on a Kitfox II? Noel -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: December 11, 2010 9:26 PM Subject: RotaxEngines-List: Re: Rotax E-Learning video on detonation and pre-ignition Actually both are correct. Rotax publishes numbers like that, but there are way to many applications in the world for everyone to be spot on, so why try to be at least close. Then the teachings in school aren't right along with the book either. So we try to balance a little. Plus we all have different setups. If you are at least 5000+ on take off and at 5500+ WOT you can sleep well at night. Hi Noel, Setting the rpm on the ground static is just to get close. Pitch angle does no good unless you are talking about two identical planes and props. The only way to really tell after that course static adjustment is to get into the air and get some real flight numbers. Shoot for around 5200 static on the ground and that will get you close enough for a flight test to dial it in where it really needs to be. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322996#322996 ________________________________________________________________________________
Date: Dec 11, 2010
Hi Noel, If you are flying with floats you may want a little flatter pitch for a little better climb off the water with more weight. I have no recommendation for the pitch, but only to set the static at 5200-5300 and go out and give it a try. I know you have been flying your plane, so what is your WOT setting right now and how does it perform? Just a side note* That particular prop from Warp isn't recommended by Rotax because of it's inertia weight. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323017#323017 ________________________________________________________________________________
Date: Dec 12, 2010
You don't say if it is a two or three blade propeller, but for a start with either, try 10 degrees measured at the prop tip. That works out to about 38.5" pitch. Rick Girard On Sat, Dec 11, 2010 at 10:23 PM, Noel Loveys wrote: > noelloveys(at)yahoo.ca> > > What would you recommend to be a preliminary AOA for the prop? Warp, > nickel > edge, square tip, 72" on a Kitfox II? > > Noel > > -----Original Message----- > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger > Lee > Sent: December 11, 2010 9:26 PM > To: rotaxengines-list(at)matronics.com > Subject: RotaxEngines-List: Re: Rotax E-Learning video on detonation and > pre-ignition > > > Actually both are correct. Rotax publishes numbers like that, but there are > way to many applications in the world for everyone to be spot on, so why > try to be at least close. Then the teachings in school aren't right along > with the book either. So we try to balance a little. Plus we all have > different setups. If you are at least 5000+ on take off and at 5500+ WOT > you > can sleep well at night. > > Hi Noel, > > Setting the rpm on the ground static is just to get close. Pitch angle does > no good unless you are talking about two identical planes and props. The > only way to really tell after that course static adjustment is to get into > the air and get some real flight numbers. Shoot for around 5200 static on > the ground and that will get you close enough for a flight test to dial it > in where it really needs to be. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322996#322996 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 12, 2010
>What is the best WOT with the tail tied down? Around what pitch angle is a good place to start? (80 hp 912 UL) Noel< Noel I have my Kiev prop set at 71/2 degrees on my 80hp Kitfox. This gives me 5200 rpm(per the Rotax service bulletin) @ WOT at the start of the take off roll. This prop angle would probably do you no good as you most likely have a different prop. I had to set the angle about 3 times until I got the 5200 I was looking for. Dick Maddux 912UL Milton,Fl ________________________________________________________________________________
Date: Dec 12, 2010
> What would you recommend to be a preliminary AOA for the prop? Warp, nickel edge, square tip, 72" on a Kitfox II? Noel< Noel, I too had the 72" Warp nickel edge prop (although mine was the tapered tip). I removed it and installed the lighter Kiev. That solved my engine run on problems I was sometimes having at shutdown (prop would turn backwards about three revolutions) I suspect the mass of the Warp was causing the prop to flip back at the top of the "dog gears" in the gearbox at shutdown. For whatever reason I now have a much smoother , quieter propeller and NO kickback. But then, I am the only one in the country that has had the kickback problem. Dick Maddux 912UL ________________________________________________________________________________
Date: Dec 12, 2010
The last time I flew the plane it was with a 582 UL with a three blade IVO IFA. I think the 914 and the two blade WARP may be a whole new quintal of fish! Noel -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: December 12, 2010 1:24 AM Subject: RotaxEngines-List: Re: Rotax E-Learning video on detonation and pre-ignition Hi Noel, If you are flying with floats you may want a little flatter pitch for a little better climb off the water with more weight. I have no recommendation for the pitch, but only to set the static at 5200-5300 and go out and give it a try. I know you have been flying your plane, so what is your WOT setting right now and how does it perform? Just a side note* That particular prop from Warp isn't recommended by Rotax because of it's inertia weight. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323017#323017 ________________________________________________________________________________
Date: Dec 12, 2010
Thanks Rick that's where I'll start. Noel From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: December 12, 2010 8:44 AM Subject: Re: RotaxEngines-List: Re: Rotax E-Learning video on detonation and pre-ignition You don't say if it is a two or three blade propeller, but for a start with either, try 10 degrees measured at the prop tip. That works out to about 38.5" pitch. Rick Girard On Sat, Dec 11, 2010 at 10:23 PM, Noel Loveys wrote: What would you recommend to be a preliminary AOA for the prop? Warp, nickel edge, square tip, 72" on a Kitfox II? Noel -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: December 11, 2010 9:26 PM Subject: RotaxEngines-List: Re: Rotax E-Learning video on detonation and pre-ignition Actually both are correct. Rotax publishes numbers like that, but there are way to many applications in the world for everyone to be spot on, so why try to be at least close. Then the teachings in school aren't right along with the book either. So we try to balance a little. Plus we all have different setups. If you are at least 5000+ on take off and at 5500+ WOT you can sleep well at night. Hi Noel, Setting the rpm on the ground static is just to get close. Pitch angle does no good unless you are talking about two identical planes and props. The only way to really tell after that course static adjustment is to get into the air and get some real flight numbers. Shoot for around 5200 static on the ground and that will get you close enough for a flight test to dial it in where it really needs to be. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322996#322996 ========== ="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com ="_blank">http://www.matronics.com/contribution le, List Admin. ========== -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List ========== http://forums.matronics.com ========== -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 12, 2010
Thanks Dick: I wanted to initially set the pitch close to the 5300 as possible so I wouldn't be all over the field trying to zero in... BTW the 5300 instead of 5200 is for two reasons... 1 STOL performance in the Kitfox and 2. The plane is hardly blistering fast in fact it is close to flying a barn door broadside to the wind. A great plane for this area. Noel From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com Sent: December 12, 2010 9:43 AM Subject: Re: RotaxEngines-List: Re: Rotax E-Learning video on detonation and pre-ignition >What is the best WOT with the tail tied down? Around what pitch angle is a good place to start? (80 hp 912 UL) Noel< Noel I have my Kiev prop set at 71/2 degrees on my 80hp Kitfox. This gives me 5200 rpm(per the Rotax service bulletin) @ WOT at the start of the take off roll. This prop angle would probably do you no good as you most likely have a different prop. I had to set the angle about 3 times until I got the 5200 I was looking for. Dick Maddux 912UL Milton,Fl ________________________________________________________________________________
Date: Dec 12, 2010
I'd be a bit concerned that with prop set to 5300 static that it could easily over-rev on climbout. I use 5000 static. Dave ________________________________________________________________________________
Date: Dec 12, 2010
5100 to 5300 work well for me . ----- Original Message ----- From: "Dave Austin" <daveaustin2(at)primus.ca> Sent: Sunday, December 12, 2010 10:21 AM Subject: Re: RotaxEngines-List: Re: Rotax E-Learning video on detonation and pre-ignition > > > I'd be a bit concerned that with prop set to 5300 static that it could > easily over-rev on climbout. I use 5000 static. > Dave > > > ________________________________________________________________________________
Subject: CO detector
Date: Dec 12, 2010
Along the lines of the latest training video, I recall a carbon monoxide detector being installed in our Harvard versions of the NA-16 series SNJ/AT6 etc, on which we trained ab initio in the 50's. The instructors sang the virtues ofg this device which hung low on the instrument panel extreme port sub-panel, out of normal view. It was supposed to assist the maintenance crew to adjust the engine to the proper running at any new altitude AND be a quide to warning the flier of excess CO should he have a head-ache or disorientation in flight. The elevated powers found the device to cause excess cost and complication and disconnected it. Naturally, I got a previously sea- level-sourced machine at Gunnery School and had an exciting armed trip complete with pounding headache and wonderful visions. Yup, not properly prepared, she sent me to the hospital on the prairies for a week of testing before I rejoined the gang. just an observation. Ferg A064 wiring in a Dynon D-100 ________________________________________________________________________________
Subject: What to look for in a good Mechanic
Date: Dec 12, 2010
What to look for in a good Mechanic and How do I know if I already have a good one? This can be a dynamic topic, but there are certainly some markers to look for in finding yourself a good mechanic that you can really trust to keep you in the air, safe and happy. You say you already have a mechanic; well the same properties in looking for a mechanic apply to knowing if you have a good one. Lets take a look at what traits might make up a good mechanic and what you can do to find one. Lets talk about looking for a good mechanic first. Just like in all professions you have marginal professionals and top of the line. Here are a few items to look for when trying to determine if a certain mechanic is right for you. Questions for them and to yourself before selecting this mechanic. (You may want to add a few extra qualifications on your own. These arent all inclusive) 1. Does he come recommended by other people? 2. Do you hear from others that he does a good job? 3. Does he have experience in your type aircraft? 4. Do you hear their name brought up favorably in conversations? 5. When you talk to them are they friendly and helpful before he wants to take your money? 6. Ask them if they have the SBs and all the manuals for your engine and fuselage on site? 7. How many aircraft like yours has he worked on or inspected? 8. Are they willing to show you the issues they found and answer your questions knowledgeably about your plane while in their shop? 9. Whats his philosophy regarding regular and preventive maintenance? 10. Is he an arrogant mechanic or open minded to your ideas, suggestions, concerns and will he research problems? 11 Do they use inspection check list, discrepancy list and do good logbook label entries? (possibly ask to see a couple of his labels and check list) 12. Does he document well? Its for your benefit as well as his and he should know that. 13. Does he give you copies of the maintenance check list or other documents for your personal file? This should be an absolute in case you need it for the FAA, insurance and the re-sale of your plane. Youre paying for the work, get it the way you want it not him. 14. Does he seem to have the proper tools and education for your particular plane? 15. Last, but not least and this item is not a real marker of the mechanics professionalism, but should be kept in the back of your mind. What do they charge? If the price sounds too good to be true then there may be a reason and you may get what you paid for. They may not be able to get much business from failings of the above items and try to low ball prices to drum up more business. Someone in a higher demand or better educated usually gets a little more money. Now I know this is not always true thats why this is last and only something to consider while looking for a mechanic that you will get along with and do a good job for you. A good mechanic will have a large portion and maybe if youre lucky all these traits above. The mechanics motto should be: I knowthere is something wrong with your plane (major or minor) and Im going to find that for you to keep you safe. Due to a planes wear and tear, loosening of attachment items or just sitting for extended periods things change on a plane and its your mechanics job to find these. He needs to be a skilled hunter of problems and an organized repairman for these items. You say you already have a mechanic then you should be able to use these questions to determine if he is good for you. If there are some areas above that you wish your mechanic would do better then sit down with them and explain that you would like these items addressed better in the future. You are paying these people good money and if they arent living up to your expectations then there is nothing wrong with asking them to work on your plane a little different. In many aspects of our life we have choices as to the way we want things, but when we go to a Doctor, a Lawyer or a Mechanic we accept or expect them to tell us what we need or want. WRONG, we should exercise the same options with these professionals and they should be receptive to our needs and you should fully expect help, understanding, your options given and consideration to your own input. You should expect a 100% job and not 50% at a fair price for the service you receive. That said if you go cheap sometime thats all you get. Getting a good professional is not always the cheapest fare in town, but doesnt have to be the most expensive either. Just like buying a new TV or car, shop around and get something that is quality, will last and serve you well. This was a long story and maybe I should have started it Once upon atime, but I hope this helps someone in having a good sound relationship with their mechanic. MERRY CHRISTMAS TO ALL MY FRIENDS HERE ON OUR FORUM! Roger Lee Tucson, AZ p.s. If you have a good one don't forget to give them a hug! :D -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323060#323060 ________________________________________________________________________________
Date: Dec 12, 2010
Thanks for that great information, Roger. I made it a point to fly this morning (wind finally stopped) and got 5,540-rpm WOT in straight and level flight at our pattern altitude of 8300-ft. I am going to leave things right there. Thanks again for the information, Roger JohnF ----- Original Message ----- From: "Roger Lee" <ssadiver1(at)yahoo.com> Sent: Saturday, December 11, 2010 5:55 PM Subject: RotaxEngines-List: Re: Rotax E-Learning video on detonation and pre-ignition > > Actually both are correct. Rotax publishes numbers like that, but there > are way to many applications in the world for everyone to be spot on, so > why try to be at least close. Then the teachings in school aren't right > along with the book either. So we try to balance a little. Plus we all > have different setups. If you are at least 5000+ on take off and at 5500+ > WOT you can sleep well at night. > > Hi Noel, > > Setting the rpm on the ground static is just to get close. Pitch angle > does no good unless you are talking about two identical planes and props. > The only way to really tell after that course static adjustment is to get > into the air and get some real flight numbers. Shoot for around 5200 > static on the ground and that will get you close enough for a flight test > to dial it in where it really needs to be. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322996#322996 > > > ________________________________________________________________________________
Date: Dec 12, 2010
Howdy John, Sounds like you have it locked down in a perfect spot. Mine happens to be set there, too. Special ops may require a little tweaking for some, but for the normal everyday fixed pitch prop it's a good place to be for most of us. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323077#323077 ________________________________________________________________________________
Date: Dec 12, 2010
Subject: 582 Intake silencer
A customer just bought a Kolb Mk IIIX that is very heavy and needs every HP it can get. I'm trying to find just how much the intake silencer is costing him. Rotax has two sets different lines on their performance graphs for this engine, but they are both labeled the same, 582 UL-2V but the difference between the two is 11.4 HP (8 KW) is this the effect of the silencers? Given the difference in jetting specs from the Bing manual it seems plausible, but I don't want to advise him based on guesswork by me. Can anyone point me to a Rotax spec for silencer / no silencer HP? Thanks, Rick Girard -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: Re: 582 Intake silencer
Date: Dec 12, 2010
1 to 2 HP ----- Original Message ----- From: Richard Girard To: rotaxengines-list(at)matronics.com Sent: Sunday, December 12, 2010 4:00 PM Subject: RotaxEngines-List: 582 Intake silencer A customer just bought a Kolb Mk IIIX that is very heavy and needs every HP it can get. I'm trying to find just how much the intake silencer is costing him. Rotax has two sets different lines on their performance graphs for this engine, but they are both labeled the same, 582 UL-2V but the difference between the two is 11.4 HP (8 KW) is this the effect of the silencers? Given the difference in jetting specs from the Bing manual it seems plausible, but I don't want to advise him based on guesswork by me. Can anyone point me to a Rotax spec for silencer / no silencer HP? Thanks, Rick Girard -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Subject: Re: What to look for in a good Mechanic
Date: Dec 13, 2010
Roger, Item 15: I'm glad you left that one open for interpretation, because my partner and I don't charge as much as most mechanics because our overhead is lower, we are both retired and do mechanic work for others because we enjoy helping them and keeping our hands in it. Plus my partner has to stay "actively engaged" to keep his I/A current. We are part-timers and we like it that way so we have an actual retirement life outside of work. If it stops being fun, I'll quit doing it. We stay as busy as we want to with work most A&Ps around here won't touch... experimental aircraft, but also do type certificated airplane maintenance and inspection. We enjoy working on the Rotax and Jabiru engines because they are great engines but largely misunderstood by many A&Ps. I'm in it for the fun and enjoyment of it in my retirement. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323152#323152 ________________________________________________________________________________
Date: Dec 13, 2010
Subject: Re: Icing: 912S versus 912
Excellent point Rob: But I think you have taken it one step further than the Gaggle need to disseminate. Everything said is true but there is one ingredient missing....WATER. No mater how great the isentropic action is ice will not form unless the temperature drops to and below the freezing point of the liquid. The freezing point of Gas is around -95 Deg F (-70 C) and water is +32 F (0 C). So the isentropic action upon gas is not an issue. You did say it but I do not know how well it was received. Ice forms from WATER. The temperature in the carb drops due to a drop in temperature due to the venturi action. Simply put: The speed of the mass of air going through the carb is increased by the carb's venturi. This increase in speed reduces th e pressure in the air flow. The reduction in pressure lowers the temperature . Tests have shown that with an OAT of 70 F (+21.1 C) you can get ICE in the carb. Taking it one step further the question of: Where does the WATER come from has to be addressed? It is present in the AIR and in small quantities in the gas. Even if you sum the tank you will not see the water in the gas. Water gets into gas through condensation and absorption. Anyone using straight Ethanol Gas? If so then due to the Alcohol you have water, as alcohol is Hygroscopic. <-- meaning it adsorbs water. I recall some obscure FAA Reg. requiring that Carb Heat must raise the temperature 100 Degrees F above ambient. I have NEVER heard of that being enforced. I would guarantee that there is not a single RV 6 that could reach that temp. Barry On Sat, Dec 11, 2010 at 6:31 PM, Rob Housman <rob@hyperion-ef.com> wrote: > The cooling (isentropic throttling) that makes carb icing happen is a > function of the amount of fuel vaporized so with all other things being > equal (same atmospheric conditions, engine manifold, carbs, RPM, etc.) yo u > can expect the somewhat greater fuel flow (more power requires more fuel) to > cause more cooling and hence a greater propensity to make ice. Obviously > the 912 and 912S are =93different=94 engines but those differences are in ternal > and downstream from the carbs. The 914 is less prone to carb ice because > the air compressed by the turbo is warmer than the intake air. > Thermodynamics rules! > > > Best regards, > > > Rob Housman > > Irvine, California > > Europa XS > > S/N A070 > > Rotax 914 > > Airframe complete > > Avionics soon > > > *From:* owner-rotaxengines-list-server(at)matronics.com [mailto: > owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of *NEEL Jean > Philippe > *Sent:* Saturday, December 11, 2010 12:35 PM > *To:* rotaxengines-list(at)matronics.com; europa-list(at)matronics.com > *Subject:* RotaxEngines-List: Icing: 912S versus 912 > > > Hi all, > > I flown my europa with a 912 80hp during 1200h/11years.It's a mark one bu t > with XS engine mounting and cowlings.Majority of flights took place here in > the French Alps as well in summer as in winter. I never had icing issue > although I had no carb preheater .The only caution I had ,when > descending ,was to keep 4500/4800 rpm . Never in idle position. > > In the beggining of that year I change my 912 for a new 912S 100hp. That > new engine has now about 125h. Yesterday I had for the first time a rough > running during few seconds.Outer Air Temp was negative at every level and > the issue occurs at the end of a descent 4500/4800rpm from 8000ft to 1500 ft. > There was about 8=B0C of difference at ground level betwen OAT and dew > point. > > Several time I read on Rotax and Europa web site discussions about icing > issues and I kept in mind that 912S should be more sensitive to icing tha n > 912. > > > As I know: > > - Carbs are the same ,except needle diam (2.72 versus 2.70 on S) and > ,may be, main fuel jet and diffuser (in accordance with needle) .Does those > difference could explain more sensitivity to icing? > - Compression ratio and bore are increased on S but stroke is the > same . In my opinion these difference have not thing to do with icing issue. > > So here is my question : *Could some body explain why a 912S should be > more exposed to icing than a 912?* > > > Jean-Philippe Neel > > F-PSLH Kit N=B0273 > > Grenoble France > > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > ** > > ** > > *www.aeroelectric.com* > > *www.buildersbooks.com* > > *www.homebuilthelp.com* > > ** > > *http://www.matronics.com/contribution* > > ** > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RotaxEngines-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > * > =========== =========== =========== ============* > > ________________________________________________________________________________
Date: Dec 13, 2010
Hey Thom: Love the way you think. There should also be a 15A. I lost a job because I told the customer-to-be it would cost him $175 for one hour of my time which included travel; to fix gas leak in a wing. The guy that got the job charged him $2000 and the plane was down for about two weeks. Bottom line... I hope he got KISSED! Barry On Mon, Dec 13, 2010 at 8:51 AM, Thom Riddle wrote: m > > > > Roger, > > Item 15: > I'm glad you left that one open for interpretation, because my partner an d > I don't charge as much as most mechanics because our overhead is lower, w e > are both retired and do mechanic work for others because we enjoy helping > them and keeping our hands in it. Plus my partner has to stay "actively > engaged" to keep his I/A current. We are part-timers and we like it that way > so we have an actual retirement life outside of work. If it stops being f un, > I'll quit doing it. > > We stay as busy as we want to with work most A&Ps around here won't > touch... experimental aircraft, but also do type certificated airplane > maintenance and inspection. We enjoy working on the Rotax and Jabiru engi nes > because they are great engines but largely misunderstood by many A&Ps. > > I'm in it for the fun and enjoyment of it in my retirement. > > -------- > Thom Riddle > Buffalo, NY (9G0) > Kolb Slingshot SS-021 > Jabiru 2200A #1574 > Tennessee Prop 64x32 > > > =93Everyone is entitled to his own opinion, but not his own facts.=94 > Daniel Patrick Moynihan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323152#323152 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Dec 13, 2010
Thom Riddle wrote: > Roger, > > Item 15: > I'm glad you left that one open for interpretation, because my partner and I don't charge as much as most mechanics because our overhead is lower, we are both retired and do mechanic work for others because we enjoy helping them and keeping our hands in it. Plus my partner has to stay "actively engaged" to keep his I/A current. We are part-timers and we like it that way so we have an actual retirement life outside of work. If it stops being fun, I'll quit doing it. > > We stay as busy as we want to with work most A&Ps around here won't touch... experimental aircraft, but also do type certificated airplane maintenance and inspection. We enjoy working on the Rotax and Jabiru engines because they are great engines but largely misunderstood by many A&Ps. > > I'm in it for the fun and enjoyment of it in my retirement. Sure wish both you guys lived near me! In fact, I'm drifting towards going to Rotax school myself at some point out of simple desperation. Right now, if something goes wrong with my 912 that isn't just simple line maintenance, I'm screwed. It'd have to come off the plane and go to Miss. or FL or somewhere. Back when I flew the 503 I was able to do a bit more invasive stuff because I have the entire 2-stroke toolset (minus a couple specific to the 582) but on the 912 there isn't anyone anywhere near here that's qualified to actually work on it. Also, the toolset for the 912 is as much as an engine if you get the entire thing. So that probably makes it even more unusual to find folks who can actually do teardowns on a sick 912. But if I go to school, I'll probably get some of the basic tools.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323163#323163 ________________________________________________________________________________
Date: Dec 13, 2010
Hi Thom, I'm like you, retired and like what I'm doing. Keeps me busy. I also instruct for AZ Homeland Security in between plane maint. I know different parts of the country charge different rates and different people have different overhead. I don't have any overhead either so my rates are a little cheaper. That's why I kind of left #15 on rates open, because there are variables. It was just something to consider while your looking around. By far the other items are more important. I should have added in my little blog that when you find a good mechanic that does a good job for you and you get along with well, be nice to them, sometimes they are hard to come by. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323165#323165 ________________________________________________________________________________
Date: Dec 13, 2010
Of course the flip side of this is the guy who pencil whips an annual and hurts everybody involved. Case in point. Customer has his newly acquired aircraft delivered to me for assembly and test flight following ground shipping. I had already pinpointed 7 things that needed to be fixed based on pictures the previous owner sent to the buyer. Not big things. Stuff like wrong tubing used for pulse line from engine to fuel pump, head vent line at low end of engine rather than high end, those kind of little detail things. When plane arrives, we find main spar carry through holes wobbled out so big I'll have to make bushings to correct, drag spar fitting loose and rattling, covering worn through for 12" on wing root where gap cover overlaps, tail wires improperly swaged, carburetor boots severely cracked, plane is overweight by almost 200 lb. from empty weight listed in the logs, and those are just the obvious problems. Since, according to the seller, the wings were off the plane at the time and there is no time recorded on the Hobbs since the "inspection" was performed it's hard to believe these items were missed. Obviously the seller got what he wanted, a good conditional inspection to aid in the sale, the A & P made a quick buck, the buyer gets the bill to return the aircraft to safe condition, and I get some work after I deliver the bad news. Of course the other obvious question is what would have happened had the buyer just accepted delivery, set up and gone flying? Scares me to think about it. Rick Girard On Mon, Dec 13, 2010 at 8:23 AM, Roger Lee wrote: > > Hi Thom, > > I'm like you, retired and like what I'm doing. Keeps me busy. I also > instruct for AZ Homeland Security in between plane maint. I know different > parts of the country charge different rates and different people have > different overhead. I don't have any overhead either so my rates are a > little cheaper. That's why I kind of left #15 on rates open, because there > are variables. It was just something to consider while your looking around. > By far the other items are more important. > > I should have added in my little blog that when you find a good mechanic > that does a good job for you and you get along with well, be nice to them, > sometimes they are hard to come by. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323165#323165 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 13, 2010
rickofudall wrote: > Stuff like wrong tubing used for pulse line from engine to fuel pump > Heh, funny you mention the pulse line. This is such a simple part of a 2-stroke installation that's just amazingly misunderstood. My last exchange over on the Kolb list before leaving was a fight over the pulse line length, it was amazing how aggressive the attacks were when I insisted it needed to be a foot and half long at a minimum (the Rotax spec is 20" at the longest, but that's a maximum value that you don't really want to use for a truly safe installation). I finally had to leave the list because I was even getting PM's about ruffling the feathers of one of the "gurus" on the list. But this is actually the single most neglected and violated safety issue with the 2-strokes. I've seen installations with this line over 2' long, and that was specified by the factory in one case! The owner of that particular plane was constantly having fuel starvation issues, very dangerous. It's often thought that as long as line is made of the right material, the pulse line can be as long as you please. But the limiting factor is the compliance of the air column in the line, not the stiffness of the lines themselves. So even if it's solid steel brake line, you don't want to run more than about 1.5 feet on this line. But I'm still stunned by how hard people fight back on this and still want to run these mile-long pulse lines. It's almost as if they want a safety issue on the plane just because the pump looks so pretty bolted onto a firewall a mile away from the motor ;). So that's another thing that can really frustrate you when helping someone out with their installation, etc. - they'll sometimes really fight you on it.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323173#323173 ________________________________________________________________________________
Date: Dec 13, 2010
Rick, I experienced something similar about four years ago. A customer bought a Challenger from Minnesota without looking at it, because the owner had a recent annual condition inspection and told the buyer he had been flying regularly, at least weekly, for the past year. When it arrived by truck, from a distance it looked good, i.e., the fabric and paint were nice and no obvious corrosion etc. Fortunately, it was structurally sound but had dozens of little things that revealed what a blatant lier the seller was. Tires were flat, the fuel in the tank was the color of molasses, the battery was beyond servicing, etc. The logbook condition inspection entry was obviously done without actually inspecting anything and the time in service since the previous one, well over a year earlier, was about 4 hours. It cost our customer nearly a $1,000 to get it to the point where it was safe and able to fly. He was lucky because it could have been much worse. I don't even know if the guy who signed the condition inspection was a real person with a valid mechanic certificate number, but if he was, he should have his ticket yanked. Caveat Emptor -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323174#323174 ________________________________________________________________________________
Date: Dec 13, 2010
Rob and Barry, =0AMany thanks=C2-for your answers.=0AI well know the proc ess that lead a carb to icing. It's usefull to remember that =0Awater can b e provided by air and by gas itself and the alcohol effect.=0AI also know t hat if I=C2-worry about icing , there are a lot of solutions to =0Apreven t from: hot water circulation on the carb body, hot air admission=C2-.=0A In fact my question was :=C2- Could some body explain why a Rotax=C2-91 2S should be =0Amore exposed to icing than a 912?=0A=C2-=0A=0AJean-Philip pe Neel=0AF-PSLH Kit N=C2=B0273=0AGrenoble France=0A=0A=0A=0A______________ __________________=0ADe : FLYaDIVE =0A=C3 : rotaxeng ines-list(at)matronics.com=0AEnvoy=C3=A9 le : Lun 13 d=C3=A9cembre 2010, 15h 0 6min 44s=0AObjet=C2-: Re: RotaxEngines-List: Icing: 912S versus 912=0A=0A Excellent=C2-point Rob: =0A=0ABut I think you have taken it one step furt her than the Gaggle need to =0Adisseminate.=0AEverything=C2-said is true but there is one ingredient missing....WATER.=0ANo mater how great the isen tropic action is ice will not form unless the =0Atemperature drops to and b elow the freezing point of the liquid. =C2-The freezing =0Apoint of Gas i s around -95 Deg F (-70 C) and water is +32 F (0 C). =C2-So the =0Aisentr opic action upon gas is not an issue. =C2- You did say it but I do not kn ow =0Ahow well it was received.=C2-=C2-Ice forms from WATER. =C2-The temperature in the carb =0Adrops due to a drop in temperature due to the ve nturi action. =C2-Simply put: The =0Aspeed of the mass of air going throu gh the carb is increased by the carb's =0Aventuri. =C2-This increase in s peed reduces the pressure in the air flow. =C2-The =0Areduction in pressu re lowers the temperature. =C2-Tests have shown that with an OAT =0Aof 70 F (+21.1 C) you can get ICE in the carb.=0ATaking it one step further the question of: Where does the WATER come from has =0Ato be addressed? =C2-I t is present in the AIR and in small quantities in the gas. =0A=C2-Even i f you sum the tank you will not see the water in the gas. =C2-Water gets =0Ainto gas through condensation and=C2-absorption. =C2-Anyone =0Ausing =C2-straight=C2-Ethanol=C2-Gas? =C2-If so then due to the Alcohol y ou have water, as =0Aalcohol is=C2-Hygroscopic. =C2-<-- meaning it=C2 -adsorbs=C2-water.=0A=0A=0AI recall some obscure FAA Reg. requiring tha t Carb Heat must raise the =0Atemperature 100 Degrees F above ambient. =C2 -I have NEVER heard of that =0Abeing=C2-enforced.=0AI would=C2-guaran tee=C2-that there is not a single RV 6 that could reach that temp.=0A=0AB arry=0A=0A=0A=0A=0AOn Sat, Dec 11, 2010 at 6:31 PM, Rob Housman wrote:=0A=0AThe cooling (isentropic throttling) that makes carb icing happen is a function =0Aof the amount of fuel vaporized so with all o ther things being equal (same =0Aatmospheric conditions, engine manifold, c arbs, RPM, etc.) you can expect the =0Asomewhat greater fuel flow (more pow er requires more fuel) to cause more cooling =0Aand hence a greater propens ity to make ice.=C2- Obviously the 912 and 912S are =0A=9Cdifferent =9D engines but those differences are internal and downstream from th e =0Acarbs.=C2- The 914 is less prone to carb ice because the air compres sed by the =0Aturbo is warmer than the intake air.=C2- Thermodynamics rul es!=0A>=C2-=0A>=C2-=0A>Best regards,=0A>=C2-=0A>Rob Housman=0A>Irvine , California=0A>Europa XS =0A>S/N A070=0A>Rotax 914=0A>Airframe complete=0A >Avionics soon=0A>=C2-=0A>=C2-=0A>=C2-=0A>From:owner-rotaxengines-lis t-server(at)matronics.com =0A>[mailto:owner-rotaxengines-list-server@matronics .com] On Behalf Of NEEL Jean =0A>Philippe=0A>Sent: Saturday, December 11, 2 010 12:35 PM=0A>To: rotaxengines-list(at)matronics.com; europa-list(at)matronics. com=0A>Subject: RotaxEngines-List: Icing: 912S versus 912=0A>=C2-=0A>Hi a ll,=0A>I flown my europa with a 912 80hp during 1200h/11years.It's a mark o ne but with =0A>XS engine mounting and cowlings.Majority of flights took pl ace here in the =0A>French Alps as well in =C2-summer as in winter. I nev er had icing=C2-issue although I =0A>had no carb preheater=C2-.The only caution I had ,when descending=C2-,was to keep =0A>4500/4800 rpm .=C2- Never in idle position.=0A>In the beggining of that year I change=C2-my =C2-912=C2-for a new 912S 100hp. That new =0A>engine has now about 125h . Yesterday I had for the first time a rough running =0A>during few seconds .Outer Air Temp was negative at every level and the issue =0A>occurs at the end of a descent 4500/4800rpm from 8000ft to 1500ft. There was =0A>about =C2- 8=C2=B0C=C2- of difference at ground level betwen OAT and dew poin t.=0A>Several time I read on Rotax and Europa web site discussions about ic ing issues =0A>and I=C2-kept in mind that 912S should be more sensitive t o icing than 912.=0A>=C2-=0A>As=C2-I know:=0A>* =C2-Carbs are the same ,except needle diam (2.72 versus 2.70 on S)=C2-and ,may be, =0A>main fuel jet=C2-and diffuser (in accordance with needle)=C2-.Does those di fference =0A>could explain more=C2-sensitivity to icing?=0A>* Compress ion ratio and bore=C2-are increased on S=C2-=C2-but stroke is the sam e=C2-. In my =0A>opinion these difference have not thing to do with icing issue.=0A>=C2-So here is my question=C2-:=C2-Could some body explain why a 912S should be more =0A>exposed to icing than a 912?=0A>=C2-=0A>Je an-Philippe Neel=0A>F-PSLH Kit N=C2=B0273=0A>Grenoble France=C2-=C2-=C2 -=C2-=C2-=0A>=C2-=0A>=C2-=0A>=C2-=0A>www.aeroelectric.com=0A>ww w.buildersbooks.com=0A>www.homebuilthelp.com=0A>http://www.matronics.com/co ntribution=0A>http://www.matronics.com/Navigator?RotaxEngines-List=0A>http: //forums.matronics.com=0A> _blank">www.aeroelectric.com .com" target="_b lank">www.buildersbooks.com =0A>="_blank">www.homebuilthelp.com _blank">h ttp://www.matronics.com/contribution =0A>ist" target="_blank">http://www. matronics.com/Navigator?RotaxEngines-List =0A>tp://forums.matronics.com =0A ============ =0A=0A=0A=0A ________________________________________________________________________________
Date: Dec 13, 2010
Hi Guys, You guys just showed me and everyone that wants to get away too cheap or has little to no knowledge about their plane for standards on proper maint. or a proper inspections. Some have someone do the maint. or inspection that really doesn't have a clue, but has A&P or LSRM-A after his name. It really behoofs people to seek out someone that has some knowledge and education to help do the maint. It can and does save you money and horror stories later. May even save your life. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323193#323193 ________________________________________________________________________________
Date: Dec 13, 2010
Hi Jean-Philippe, Does the 912S have the cooling shroud over the cylinders, and perhaps the 912 did not ? Cheers, Nev. -----Original Message----- From: NEEL Jean Philippe <jeanphilippeneel(at)yahoo.fr> Sent: Mon, 13 Dec 2010 18:13 Subject: Re : RotaxEngines-List: Icing: 912S versus 912 Rob and Barry, Many thanks for your answers. I well know the process that lead a carb to icing. It's usefull to remembe r that water can be provided by air and by gas itself and the alcohol effe ct. I also know that if I worry about icing , there are a lot of solutions to prevent from: hot water circulation on the carb body, hot air admission . In fact my question was : Could some body explain why a Rotax 912S should be more exposed to icing than a 912? Jean-Philippe Neel F-PSLH Kit N=C2=B0273 Grenoble France De : FLYaDIVE =C3 : rotaxengines-list(at)matronics.com Envoy=C3=A9 le : Lun 13 d=C3=A9cembre 2010, 15h 06min 44s Objet : Re: RotaxEngines-List: Icing: 912S versus 912 Excellent point Rob: But I think you have taken it one step further than the Gaggle need to dis seminate. Everything said is true but there is one ingredient missing....WATER. No mater how great the isentropic action is ice will not form unless the temperature drops to and below the freezing point of the liquid. The fre ezing point of Gas is around -95 Deg F (-70 C) and water is +32 F (0 C). So the isentropic action upon gas is not an issue. You did say it but I do not know how well it was received. Ice forms from WATER. The tempe rature in the carb drops due to a drop in temperature due to the venturi action. Simply put: The speed of the mass of air going through the carb is increased by the carb's venturi. This increase in speed reduces the pressure in the air flow. The reduction in pressure lowers the temperatu re. Tests have shown that with an OAT of 70 F (+21.1 C) you can get ICE in the carb. Taking it one step further the question of: Where does the WATER come from has to be addressed? It is present in the AIR and in small quantities in the gas. Even if you sum the tank you will not see the water in the gas. Water gets into gas through condensation and absorption. Anyone using straight Ethanol Gas? If so then due to the Alcohol you have water, as alcohol is Hygroscopic. <-- meaning it adsorbs water. I recall some obscure FAA Reg. requiring that Carb Heat must raise the tem perature 100 Degrees F above ambient. I have NEVER heard of that being en forced. I would guarantee that there is not a single RV 6 that could reach that te mp. Barry On Sat, Dec 11, 2010 at 6:31 PM, Rob Housman <rob@hyperion-ef.com> wrote: The cooling (isentropic throttling) that makes carb icing happen is a func tion of the amount of fuel vaporized so with all other things being equal (same atmospheric conditions, engine manifold, carbs, RPM, etc.) you can expect the somewhat greater fuel flow (more power requires more fuel) to cause more cooling and hence a greater propensity to make ice. Obviously the 912 and 912S are =9Cdifferent=9D engines but those differ ences are internal and downstream from the carbs. The 914 is less prone to carb ice because the air compressed by the turbo is warmer than the in take air. Thermodynamics rules! Best regards, Rob Housman Irvine, California Europa XS S/N A070 Rotax 914 Airframe complete Avionics soon From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengi nes-list-server(at)matronics.com] On Behalf Of NEEL Jean Philippe Sent: Saturday, December 11, 2010 12:35 PM Subject: RotaxEngines-List: Icing: 912S versus 912 Hi all, I flown my europa with a 912 80hp during 1200h/11years.It's a mark one but with XS engine mounting and cowlings.Majority of flights took place here in the French Alps as well in summer as in winter. I never had icing iss ue although I had no carb preheater .The only caution I had ,when descendi ng ,was to keep 4500/4800 rpm . Never in idle position. In the beggining of that year I change my 912 for a new 912S 100hp. That new engine has now about 125h. Yesterday I had for the first time a rough running during few seconds.Outer Air Temp was negative at every level and the issue occurs at the end of a descent 4500/4800rpm from 8000ft to 1500 ft. There was about 8=C2=B0C of difference at ground level betwen OAT an d dew point. Several time I read on Rotax and Europa web site discussions about icing issues and I kept in mind that 912S should be more sensitive to icing tha n 912. As I know: Carbs are the same ,except needle diam (2.72 versus 2.70 on S) and ,may be, main fuel jet and diffuser (in accordance with needle) .Does those di fference could explain more sensitivity to icing? Compression ratio and bore are increased on S but stroke is the same . In my opinion these difference have not thing to do with icing issue. So here is my question : Could some body explain why a 912S should be mor e exposed to icing than a 912? Jean-Philippe Neel F-PSLH Kit N=C2=B0273 Grenoble France www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RotaxEngines-List http://forums.matronics.com _blank">www.aeroelectric.com com" target="_blank">www.buildersbooks.com "_blank">www.homebuilthelp.com blank">http://www.matronics.com/contribution st" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List p://forums.matronics.com www.aerww.buildersbooks.com/" rel=nofollow target=_blank>www.buildersb ooks.commatronics.com/contribution" rel=nofollow target=_blank>http:// www.matroatronics.com/Navigator?RotaxEngines-List" rel=nofollow target =_blank>ht --> ======================== =========== - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== ======================== =========== -= - The RotaxEngines-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RotaxEngines-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== ======================== =========== - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== ======================== =========== -= - The RotaxEngines-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RotaxEngines-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== ________________________________________________________________________________
Date: Dec 13, 2010
Having had ownership in over two dozen planes over quite a few years now, I have to agree that finding the right maintainence shop(s) or person(s) with knowlege, experience, training, skills, and ethics to do the maintainence or provde the assistance needed can be a pocketbook and life saver. BJ Kitfox IV N154K PA 39 Turbo N626NR > > Hi Guys, > > You guys just showed me and everyone that wants to get away too cheap or > has little to no knowledge about their plane for standards on proper > maint. or a proper inspections. Some have someone do the maint. or > inspection that really doesn't have a clue, but has A&P or LSRM-A after > his name. It really behoofs people to seek out someone that has some > knowledge and education to help do the maint. It can and does save you > money and horror stories later. May even save your life. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323193#323193 > > ________________________________________________________________________________
Date: Dec 13, 2010
From: Pete Christensen <pchristensen10(at)austin.rr.com>
This one looks good. Saw her on Barnstormers. ________________________________________________________________________________
Subject: Is my hanger door just waiting for me to be complacent?
Date: Dec 13, 2010
Hi All, Is my hanger door just waiting for me to be complacent? (Yes it is!) Another recent incident has prompted me to throw this out for review. Just wanted to touch bases with everyone concerning our hanger doors. Over the last couple of years too many people have shut their hanger doors on their plane. Usually the tail and a few wings. That means we are leaving our planes way too close to the door edge whether it be on the inside, but usually these incidents happen when the plane is on the outside of the door. When I was on the Fire Department there were many door accidents as the truck would pull out. You can imagine what something the size of a fire truck can do to a large garage type door. The cost to the department was hundreds of thousands of dollars. So a policy was written. The door is either on 12" off the ground and open for air movement or it was all the way open. Nothing in between. The truck was either all the way in the apparatus bay or it was all the way out. No one was allowed to touch the close button until the truck was way out of the station or parked inside. Failure to follow these rules led to a one day suspension and damage to another door or vehicle was much longer. The point of this is to make everyone take notice that their plane should never be parked half way in or out of the hanger or very close to any door. If it is an electric hanger door it has a certain amount of angle that it protrudes as it opens. These hanger accidents has cost many thousands of dollars and I hope this little article helps someone from having this type of accident again. Even if the insurance pays for this incident the repair work and logistics is a royal pain. If I have to have something that crosses the door threshold then I trip the electrical breakers so there is no power to the door and it can't move. Don't get suspended keep your attention focused and your plane at a safe distance from the hanger door. [Wink] -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323237#323237 ________________________________________________________________________________
Date: Dec 14, 2010
Roger I do love your posts, and I always learn something with them, but forgive me if I have to make a correction to this last one: - =93hanger=94 is where one can hang something - =93hangar=94 is where we can put our airplanes in Carlos > -----Original Message----- > From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines- > list-server(at)matronics.com] On Behalf Of Roger Lee > Sent: ter=E7a-feira, 14 de Dezembro de 2010 1:47 > To: rotaxengines-list(at)matronics.com > Subject: RotaxEngines-List: Is my hanger door just waiting for me to be > complacent? > > > Hi All, > > Is my hanger door just waiting for me to be complacent? (Yes it is!) > > Another recent incident has prompted me to throw this out for review. > > Just wanted to touch bases with everyone concerning our hanger doors. Over the > last couple of years too many people have shut their hanger doors on their plane. > Usually the tail and a few wings. That means we are leaving our planes way too > close to the door edge whether it be on the inside, but usually these incidents > happen when the plane is on the outside of the door. > When I was on the Fire Department there were many door accidents as the truck > would pull out. You can imagine what something the size of a fire truck can do to a > large garage type door. The cost to the department was hundreds of thousands of > dollars. > So a policy was written. The door is either on 12" off the ground and open for air > movement or it was all the way open. Nothing in between. The truck was either all > the way in the apparatus bay or it was all the way out. No one was allowed to touch > the close button until the truck was way out of the station or parked inside. Failure > to follow these rules led to a one day suspension and damage to another door or > vehicle was much longer. > The point of this is to make everyone take notice that their plane should never be > parked half way in or out of the hanger or very close to any door. If it is an electric > hanger door it has a certain amount of angle that it protrudes as it opens. > These hanger accidents has cost many thousands of dollars and I hope this little > article helps someone from having this type of accident again. Even if the insurance > pays for this incident the repair work and logistics is a royal pain. > If I have to have something that crosses the door threshold then I trip the electrical > breakers so there is no power to the door and it can't move. > > > Don't get suspended keep your attention focused and your plane at a safe distance > from the hanger door. [Wink] > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323237#323237 > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Is my hangar door just waiting for me to be complacent?
Date: Dec 13, 2010
Nothing like having you mother look over your should at 57 years old. [Laughing] [Laughing] [Laughing] [Laughing] It's fixed -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323243#323243 ________________________________________________________________________________
Date: Dec 13, 2010
Roger Lee wrote: > Nothing like having your mother look over your shoulder at 57 years old. [Laughing] [Laughing] [Laughing] [Laughing] > > > It's fixed > > Thanks for watching out for me. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323245#323245 ________________________________________________________________________________
Date: Dec 14, 2010
Subject: 2010 List of Contributors
Dear Listers, The 2010 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and its time that I publish this year's List of Contributors. Its the people on this list that directly make the Email Lists and Forums possible. Their generous contributions keep the servers and Internet connection up and running. You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Bob, Jon, and Andy for their generous support through the supply of great gifts this year!! These guys have some great products and I encourage you to visit their respective web sites: Bob Nucklolls - AeroElectric - www.aeroelectric.com Jon Croke - HomebuiltHELP - www.homebuilthelp.com Andy Gold - The Builder's Bookstore - www.buildersbooks.com And finally, I'm proud to present The 2010 Fund Raiser List of Contributors: http://www.matronics.com/loc/2010.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Re: Losing rpm on takeoff
Date: Dec 14, 2010
Problem solved, although what is actually happening is a subject of some debate. Those who operate the Warp drive taper tip props or have experience with them were exactly right and ignoring static RPM was clearly the way to go. I ended up with a very nice smoooth prop after reducing pitch significantly. It is now pitched to allow 6200 rpm in full throttle climb at 0 deg temp. I expect we will have to revisit this when it warms up. The engine will overspeed quite easily on the ground until speed builds. I have spoken to a few others with the same type of prop and their expereince is similar. Thanks to those who offered asistance, it would have taken somewhat longer to get it right without it. ________________________________________________________________________________
Date: Dec 14, 2010
Hi Occom, I have lots of people ask me what static rpm to set. My standard answer is; the static is only a place to start when putting on a new prop and you have no real idea of an exact pitch and final rpm. I always tell them set a general static rpm and go fly. Flying is the only way to be exact and sure of the final results. This is the only way to dial in a prop/engine rpm to match your plane and local flying conditions. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323340#323340 ________________________________________________________________________________
Subject: Re: Rotax E-Learning video on detonation and pre-ignition
Date: Dec 14, 2010
Any Ideas about the neighbourhood of the AOA for that? Noel -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Dave Austin Sent: December 12, 2010 11:52 AM Subject: Re: RotaxEngines-List: Re: Rotax E-Learning video on detonation and pre-ignition I'd be a bit concerned that with prop set to 5300 static that it could easily over-rev on climbout. I use 5000 static. Dave ________________________________________________________________________________
Date: Dec 14, 2010
[quote="occom"]Problem solved, although what is actually happening is a subject of some debate. Those who operate the Warp drive taper tip props or have experience with them were exactly right and ignoring static RPM was clearly the way to go. I ended up with a very nice smoooth prop after reducing pitch significantly. It is now pitched to allow 6200 rpm in full throttle climb at 0 deg temp. I expect we will have to revisit this when it warms up. The engine will overspeed quite easily on the ground until speed builds. I have spoken to a few others with the same type of prop and their expereince is similar. Thanks to those who offered asistance, it would have taken somewhat longer to get it right without it. > [b] That sounds pretty close to me. On my Kolb/503, I got about 6300 on a normal climbout (tho I don't actually remember that speed offhand), tho that was slightly underpropped for WOT at straight and level IIRC. But like I said, tho I love my powerfin, I wish I could make my 68" taper tip work on my tornado. Once I had the pitch dialed in I was able to do 100mph indicated (about 110mph true) at only half throttle at 10,000' MSL. Plus, I could get a virtually constant 5400rpm on climbout even varying between 65 and 80mph indicated. The static rpm always seemed to settle at about 5200 rpm no matter what the pitch was set at (I went from 13.5 to about 15 degs in the course of the dialing in and the static was always the same)..... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323342#323342 ________________________________________________________________________________
Subject: Re: Rough Running 912
Date: Dec 14, 2010
My Kitfox w/ 912 UL 80 hp came from a 5000' MSL field and is now hangared at sea level. It was rough from around 4000 to 3700 rpm on a digital tach. and has 2 egts running @ 1400 degrees. Carb needles were up at position 2. Makes sense for where the plane used to live. Dropped the clip to normal positions 3, raising the needle and the egts are the same, but now smooth running all rpms. (Thanks, Roger!) I thought it might take dropping to clip position 4 to fully raise the needle or a change of needle and jet from standard as it's now mid 30's when I fly, but the position 3 did it for me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323361#323361 ________________________________________________________________________________
Date: Dec 14, 2010
Position 3 on the carb needle is normal and a good place to be for the majority of us. If you live and fly from high elevations then maybe #2, but be ware if you come down to visit us low landers. #3 is good for most during summer and winter. The more you tinker against what Rotax advises the more chance of making a costly error or a poor running engine. You need to be able to fully understand the Rotax engine and how to accurately interpret engine information on the gauges or test equipment. If you don't then leave it as the factory set it up and you will fly to your TBO without any issues. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323365#323365 ________________________________________________________________________________
Date: Dec 14, 2010
So all of this talk of changing needle positions based on altitude has me wondering. What if you want to fly from sea-level to high altitude? What then??? Ken Ryan Anchorage, Alaska On Tue, Dec 14, 2010 at 12:26 PM, Roger Lee wrote: > > Position 3 on the carb needle is normal and a good place to be for the > majority of us. If you live and fly from high elevations then maybe #2, but > be ware if you come down to visit us low landers. > #3 is good for most during summer and winter. The more you tinker against > what Rotax advises the more chance of making a costly error or a poor > running engine. You need to be able to fully understand the Rotax engine and > how to accurately interpret engine information on the gauges or test > equipment. If you don't then leave it as the factory set it up and you will > fly to your TBO without any issues. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323365#323365 > > ________________________________________________________________________________
Date: Dec 14, 2010
kenryan wrote: > So all of this talk of changing needle positions based on altitude has me wondering. What if you want to fly from sea-level to high altitude? What then??? > > Ken Ryan > Anchorage, Alaska > You shouldn't have to change anything. I live at 7000' MSL (northern NM) and fly usually up to 9999' MSL, even on local messing-around flights. My carbs still have the factory jetting and they compensate fairly well. Mine run a bit rich at low power settings (i.e. between 2000 and 3000 or so on the ground or during approaches) and it's going to idle rich also (if you use the factory 1.5 turns on the idle needle). But at full power it still leans out fairly well, giving EGT's in the 1250 to 1350F range. So shouldn't be a problem... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323383#323383 ________________________________________________________________________________
Date: Dec 14, 2010
I'm with Lucien. leave it alone. You will be a little rich for that flight, but so what it will fly just fine. Making a permanent needle adjustment should mean you are more or less permanently at altitude. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323400#323400 ________________________________________________________________________________
Date: Dec 15, 2010
I could easily be taking off at sea level and then flying to over 14000. Ken Ryan Anchorage, Alaska On Tue, Dec 14, 2010 at 6:11 PM, lucien wrote: > lstavenhagen(at)hotmail.com> > > > kenryan wrote: > > So all of this talk of changing needle positions based on altitude has me > wondering. What if you want to fly from sea-level to high altitude? What > then??? > > > > Ken Ryan > > Anchorage, Alaska > > > > > You shouldn't have to change anything. I live at 7000' MSL (northern NM) > and fly usually up to 9999' MSL, even on local messing-around flights. My > carbs still have the factory jetting and they compensate fairly well. Mine > run a bit rich at low power settings (i.e. between 2000 and 3000 or so on > the ground or during approaches) and it's going to idle rich also (if you > use the factory 1.5 turns on the idle needle). But at full power it still > leans out fairly well, giving EGT's in the 1250 to 1350F range. > > So shouldn't be a problem... > > LS > > -------- > LS > Titan II SS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323383#323383 > > ________________________________________________________________________________
Date: Dec 15, 2010
That example was for flying from a base of 7000 to 9000. I'm talking more about flying from sea level to about 14,000. Same answer? On Tue, Dec 14, 2010 at 8:27 PM, Roger Lee wrote: > > I'm with Lucien. leave it alone. You will be a little rich for that flight, > but so what it will fly just fine. Making a permanent needle adjustment > should mean you are more or less permanently at altitude. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323400#323400 > > ________________________________________________________________________________
Date: Dec 15, 2010
My home bases are at sea level in Florida Keys and adjacent to Chesapeake Bay but have flown over Grand Canyon, and around the South West Rockies up to about 10,000 plus a trip Md to Fl at about 10,000 and have not noticed any engine roughness in an early s/n 912. Can't remember going to 14,000 feet though. BJ KF IV N154K > That example was for flying from a base of 7000 to 9000. I'm talking more > about flying from sea level to about 14,000. Same answer? > > > On Tue, Dec 14, 2010 at 8:27 PM, Roger Lee wrote: > >> >> >> I'm with Lucien. leave it alone. You will be a little rich for that >> flight, >> but so what it will fly just fine. Making a permanent needle adjustment >> should mean you are more or less permanently at altitude. >> >> -------- >> Roger Lee >> Tucson, Az. >> Light Sport Repairman - Maintenance Rated >> Rotax Repair Center >> Home 520-574-1080 TRY HOME FIRST >> Cell 520-349-7056 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=323400#323400 >> >> >> >> >> >> >> >> >> >> >> > ________________________________________________________________________________
Date: Dec 15, 2010
kenryan wrote: > I could easily be taking off at sea level and then flying to over 14000. > > Ken Ryan > Anchorage, Alaska > > I still think you'll be ok. By the time you get up there, you're going to be mostly wide open all the time anyway so the carbs should compensate pretty well. I've flown mine at density altitudes approaching 12,000' MSL without any visible running problems. I would make sure that you have the carb vent lines installed correctly first (i.e. going into the aircleaners or airbox). The carbs really do go rich at higher altitudes if the vent lines are just hanging out in the breeze and that could cause problems that high up. LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323419#323419 ________________________________________________________________________________
Date: Dec 15, 2010
Thanks for the inputs! On Wed, Dec 15, 2010 at 8:21 AM, lucien wrote: > lstavenhagen(at)hotmail.com> > > > kenryan wrote: > > I could easily be taking off at sea level and then flying to over 14000. > > > > Ken Ryan > > Anchorage, Alaska > > > > > > > I still think you'll be ok. By the time you get up there, you're going to > be mostly wide open all the time anyway so the carbs should compensate > pretty well. I've flown mine at density altitudes approaching 12,000' MSL > without any visible running problems. > > I would make sure that you have the carb vent lines installed correctly > first (i.e. going into the aircleaners or airbox). The carbs really do go > rich at higher altitudes if the vent lines are just hanging out in the > breeze and that could cause problems that high up. > > LS > > -------- > LS > Titan II SS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323419#323419 > > ________________________________________________________________________________
Date: Dec 15, 2010
Ok, I didn't want to post this, but for the sake of no one messing with their engine here goes. I have friends that have been to 18'K + with their 912ULS and the clip at number 3. Leave your clips alone and your engine will take you any where you want to go. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323436#323436 ________________________________________________________________________________
Date: Dec 15, 2010
Roger, For the case of sea level to 14k'- I agree, CLIP #3, the standard for the 80HP Rotax UL. My experience moving from 5k' to sea level proved that out. You might want to look at the HACMAN for the case of going up high, less than $200 for the install, assuming you didn't need to send out the carbs for the tapping setup. Now, My carb vents are just tucked in the bales from the float bowl. I have the K&N filters, both pancakes, one per side, oriented properly. Should I tap into the back plastic and run the carb vents back to the air filters? Does anyone have a picture of this? It would look just like running the vents to the air inlet manifold on the ROTAX 912s that use a plenum/manifold connected to both carbs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323446#323446 ________________________________________________________________________________
Date: Dec 15, 2010
moosepileit wrote: > > Now, My carb vents are just tucked in the bales from the float bowl. I have the K&N filters, both pancakes, one per side, oriented properly. Should I tap into the back plastic and run the carb vents back to the air filters? Does anyone have a picture of this? It would look just like running the vents to the air inlet manifold on the ROTAX 912s that use a plenum/manifold connected to both carbs. I'd definitely fix this before flying at high altitudes. Soon as I can get out to the hangar with my camera, I'll take some pictures of how I did mine. Basically, you can get a brass double-barbed fitting at Lowes or somewhere (1/8" IIRC), the fitting with barbs on each end and a disc in the center. I.e. looks like then, drill a hole in the back panel of the air filter (remove for this and clean out the scrap rubber completely). Push the barb in till it bottoms out at the disk. Push the carb vent line over the other end of the barb and you're done.... I have the big flat Rotax K&N's which makes this easy. But I'll try to get some pics of what I have... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323459#323459 ________________________________________________________________________________
Date: Dec 15, 2010
Lucien, thanks! I was fine cruising at 9500' msl w/ OAT about 32F/freezing. Your description is great, thanks. I don't think she'll be getting above a couple thousand feet for a while, EGT is 1400 WOT down low now and takeoff. It makes sense to have the carbs as equal as possible, which does not include 2 vent hoses randomly in the airflow, even just tucked against the carb bowl holders/bails. So, with this setup, is there any use for carb drip trays? I don't need them for heat isolation and the carbs can't drip onto my exhaust in my kitfox... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323465#323465 ________________________________________________________________________________
Date: Dec 15, 2010
Howdy Moose, The vent lines need to be in the same general area so they pick up the same pressure to balance the carbs and if the engine were to shake hard for any reason sometimes you can get some fuel down them and that's why you don't want the vent lines on top of an exhaust and having a drip tray under them can help. The drip trays aren't there for the vent lines usually, but for things like a leaking float bowl gasket which can be common. I always keep a couple of float bowl gaskets lying around. Easy to replace. The drip trays provide a barrier between any fuel that comes out of a carb which is usually right above the exhaust. I would leave them alone. If you're flying you won't know the carbs are leaking until after you're on the ground and for many of us you won't know unless you pull the cowl. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323469#323469 ________________________________________________________________________________
Date: Dec 15, 2010
Roger, What is your take on Lucien's idea of running the carb vent lines back into the air filters on a 912 UL? Hugh McKay -----Original Message----- From: Roger Lee Sent: Wednesday, December 15, 2010 4:15 PM Subject: RotaxEngines-List: Re: Rough Running 912 Howdy Moose, The vent lines need to be in the same general area so they pick up the same pressure to balance the carbs and if the engine were to shake hard for any reason sometimes you can get some fuel down them and that's why you don't want the vent lines on top of an exhaust and having a drip tray under them can help. The drip trays aren't there for the vent lines usually, but for things like a leaking float bowl gasket which can be common. I always keep a couple of float bowl gaskets lying around. Easy to replace. The drip trays provide a barrier between any fuel that comes out of a carb which is usually right above the exhaust. I would leave them alone. If you're flying you won't know the carbs are leaking until after you're on the ground and for many of us you won't know unless you pull the cowl. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323469#323469 ________________________________________________________________________________
Date: Dec 15, 2010
hgmckay wrote: > Roger, > > What is your take on Lucien's idea of running the carb vent lines back into > the air filters on a 912 UL? > > Hugh McKay > > -- For what it's worth, I didn't make this up. This requirement on the vent lines is in the installation manual for the 912 series. There's a diagram in there showing the lines being routed to nipples on the airbox for illustration purposes, but without the box you kind of have to invent your method. Like I said, at my altitude my carbs definitely ran too rich before the fix (EGTs in the 1100's !) so I'm convinced! ;) LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323481#323481 ________________________________________________________________________________
Date: Dec 15, 2010
Rotax likes them run into a common area like an airbox with the same pressure gradient going to each carb. If you had let's say one large filter then the lines running in there would be better than into two separate filters. While his is certainly better than many and by no means bad the best would be to put them out of all air streams and setup to a common point. There could be a possible air pressure difference between two carbs, probably small, that could change things slightly. It might be from maybe someone over oiling one filter compared to the other with a K&N or the way the engine is set up under a cowl. Nothing wrong with his setup and there are worse things done to vent lines out there, but if you wanted to tweak it a little better a common airbox is better. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323488#323488 ________________________________________________________________________________
Date: Dec 15, 2010
Lucien, I wasn't in on the discussion on the Kolb forum, but I took the time to read Section 15 and 16 of the installation manual and what it says is that the carb vents must be routed to a vacuum and ram air free zone. The air box supplies this, the air filter does not. Letting them just hang, secured by the float bowl bale is a perfectly acceptable option. Rick Girard On Wed, Dec 15, 2010 at 4:57 PM, lucien wrote: > lstavenhagen(at)hotmail.com> > > > hgmckay wrote: > > Roger, > > > > What is your take on Lucien's idea of running the carb vent lines back > into > > the air filters on a 912 UL? > > > > Hugh McKay > > > > -- > > > For what it's worth, I didn't make this up. This requirement on the vent > lines is in the installation manual for the 912 series. > > There's a diagram in there showing the lines being routed to nipples on the > airbox for illustration purposes, but without the box you kind of have to > invent your method. > > Like I said, at my altitude my carbs definitely ran too rich before the fix > (EGTs in the 1100's !) so I'm convinced! ;) > > LS > > -------- > LS > Titan II SS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323481#323481 > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 15, 2010
rickofudall wrote: > Lucien, I wasn't in on the discussion on the Kolb forum, but I took the time to read Section 15 and 16 of the installation manual and what it says is that the carb vents must be routed to a vacuum and ram air free zone. The air box supplies this, the air filter does not. Letting them just hang, secured by the float bowl bale is a perfectly acceptable option. > > Rick Girard > Not at my altitudes it isn't. Fortunately 15.1 does clarify the issue a bit - it also says: "Pressure differences between intake pressure and pressure in the carburetor chambers may lead to engine malfunction due to incorrect fuel supply." That effectively means the vent lines should be at the same atmospheric pressure (or in the same atmosphere) as the venturis. There is a pressure difference, tho pretty small, between the outside of the airfilter and the inside. So, if you have the choice, the lines really need to be routed to the inside. If you have the airbox, the requirement is very clear, with the diagram, etc. Now, the interesting thing is it doesn't really show up at sea level. My plane was originally in Nebraska; the mixture was fine down there with EGT's up to about 1400 with the lines run down the sides into the bales in the usual way. I guess the effect isn't that significant there. So it's normally not a problem and the carbs still compensate pretty well. But when I got it up here after the ferry mission there was a BIG difference - my EGT's were barely out of the 1100's. And the plugs were starting to get fuel fouled after about the first 20 hours or so after getting it here. I later learned about the correct placement of the lines and after the mod that put the mixture back to practically normal. My EGT's run about 1250 to 1350, a lot closer to where they should be. Still slightly rich but definitely about the expected temps for my altitudes and no more fouled plugs. So in my view, it really is something you want to comply with if you fly at high altitudes. At sea level, yeah, it's probably not that big of a deal.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323500#323500 ________________________________________________________________________________
Date: Dec 16, 2010
FWIW, the standard vent line location for the Bing 94 CV carb on Jabiru engines, similar to the Bing 64 carbs on the 912 series, is to the inside of the K&N filter if the engine is not fitted with an airbox. Mine, and every other Bing 94 I've seen without an airbox, has a 90 degree elbow fitted into the end of the K&N filter with the vent line connected to that. I know Jabiru and Rotax are different, but functionally, the Bing 64 and 94 carbs are essentially identical and require the same venting. Without an air-box, the only way to ensure the proper vent line location (in my opinion) is to route it into the filter. I would suggest it is even more important on a Rotax since they have two carbs with critical balance requirements. I doubt seriously that this would cause rough running symptoms but it is a factor that should be dealt with properly, if for no other reason than to eliminate it from the mix of variables. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323520#323520 ________________________________________________________________________________
Date: Dec 16, 2010
Thom, Lucien: This discussion is very interesting. My 912 UL came new from Rotax with the carb vent lines neatly tucked behind the bowl clip and run down to just above the little pans under the carb bowl. I now have 400+ hours on the engine. I may be mistaken (or just ignorant of the fact) but to my knowledge Rotax doesn't address this issue at all. I fly from a field elevation of 1035 ft. msl, and fly down to sea level on numerous occasions, and then at times up to 8500 ft. msl to cross over the Appalachian mountains. I have not had any obvious engine/carb problems that I know of. However I do notice that when changing plugs they seem to be too "black", and not the nice "brown" color everyone talks about. So Thom, if I am hearing you correctly, in your opinion I should route each vent line back into it's respective air filter. Did you do this on your old 912 UL (The Allegro 2000), and if so how did you do it? Did you ever operate the engine with the vent lines as they come standard from Rotax? Hugh McKay -----Original Message----- From: Thom Riddle Sent: Thursday, December 16, 2010 8:01 AM Subject: RotaxEngines-List: Re: Rough Running 912 FWIW, the standard vent line location for the Bing 94 CV carb on Jabiru engines, similar to the Bing 64 carbs on the 912 series, is to the inside of the K&N filter if the engine is not fitted with an airbox. Mine, and every other Bing 94 I've seen without an airbox, has a 90 degree elbow fitted into the end of the K&N filter with the vent line connected to that. I know Jabiru and Rotax are different, but functionally, the Bing 64 and 94 carbs are essentially identical and require the same venting. Without an air-box, the only way to ensure the proper vent line location (in my opinion) is to route it into the filter. I would suggest it is even more important on a Rotax since they have two carbs with critical balance requirements. I doubt seriously that this would cause rough running symptoms but it is a factor that should be dealt with properly, if for no other reason than to eliminate it from the mix of variables. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323520#323520 ________________________________________________________________________________
Date: Dec 16, 2010
hgmckay wrote: > Thom, Lucien: > > This discussion is very interesting. My 912 UL came new from Rotax with the > carb vent lines neatly tucked behind the bowl clip and run down to just > above the little pans under the carb bowl. I now have 400+ hours on the > engine. I may be mistaken (or just ignorant of the fact) but to my knowledge > Rotax doesn't address this issue at all. I fly from a field elevation of > 1035 ft. msl, and fly down to sea level on numerous occasions, and then at > times up to 8500 ft. msl to cross over the Appalachian mountains. I have not > had any obvious engine/carb problems that I know of. However I do notice > that when changing plugs they seem to be too "black", and not the nice > "brown" color everyone talks about. So Thom, if I am hearing you correctly, > in your opinion I should route each vent line back into it's respective air > filter. Did you do this on your old 912 UL (The Allegro 2000), and if so how > did you do it? Did you ever operate the engine with the vent lines as they > come standard from Rotax? > > Hugh McKay > > -- Yeah, this is a little-known fact of the Bing 64's. Like I said, mis-installed lines don't seem to create a noticeable problem at lower altitudes. Also, since the airbox is often eliminated and filters only are used, it's just one of those installation errors that kind of goes unnoticed. The installation manual is, of course, the oh-so-wonderful translation from German, so a lot of the wording in it just sounds strange and isn't entirely clear. Now why Bing chose to design the carb that way, who knows. It seems kind of silly to me but carbs are kind of black magic anyway so I just follow the instructions and hope for the best ;). BTW, as jetted from the factory, there's a rich spot in the 2000 to 3500 rpm range and the factory idle mix setting of 1.5 turns is, in my experience, overly rich (and WAY too rich at my altitude). So black plugs after an extended idle back to the hangar is kind of par for the course. The thing I look for is a nice, antique white baffle in the exhaust which indicates adequately lean running at full power. I check this with a flashlight at my post-flight every time..... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323541#323541 ________________________________________________________________________________
Subject: Rotax Oil Filters changing, new part number assigned
Date: Dec 16, 2010
Revision #2 New oil filter part number correction by XatorMan under ROTAX PRESS RELEASESRotax has just released the informaiton on the oil filter minor changes. In the release they inadvertently gave out the wrong part numbers. Owners and operators and service providers will be recieving the new filters under 2 different part numbers, depending on the ordering scope. (by bulk or individual) Please note the following change from the release of December 3rd. Part number 825710 and 825712, changed to 825010 and 825012 respectivly. This will be the new numbers the filter will be supplied with. It is worth repeating that all users should check the installaitons and confirm that the small change in the length of the filter, as shown in the drawing supplied from December 3rd, be verified. While it is not anticipated that this will have any ill effects the clearance, especially to the exhaust system on number 2 cylinder, has to be considered. Contact your independent Rotax distributor or independent Rotax Service Centre for any additional information. Drawing is not to scale: No tagsLeave a Commentmore... 3 Dec/10 Revision #1 Rotax Oil Filters changing, new part number assigned by XatorMan under ROTAX PRESS RELEASESRotax; BRP-Powertrain, is making a minor change on the oil filter for ROTAX 912 and 914 Series engines. Production of the current oil filters part no. 825704 and 825706 has been discontinued, once stock is depleted they will be not longer available. The replacement filters will have a new part no. 825710 and 825712, internally they are the same and they have been approved from engineering, however one small change has to be noted. The overall length has increased about 3.5 mm ( .138 ) due to the production process. For detailed dimensions see attached sketch. OEM and end use customers need to check and make sure they have clearance and make any necessary changes to accommodate this new filter. The part will be coming in the first quarter of 2011. New production filter for 9 Series Rotax engines, early 2011 - Image provided as a reference only. Image is not to scale. new oil filter, rotax -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323550#323550 ________________________________________________________________________________
Subject: PROP CONTROL
Date: Dec 16, 2010
I have a Czech made (Woodward type) governor which works fine in the air controlling my C/S Whirlwind prop on a Rotax 914 (almost 600 hrs). But recently I have not been able to get an rpm drop during a pre-TO check at 4000 rpm. Oil is clean and warm. Even a post flight check results in no rpm drop when cockpit control is fully retarded. Any ideas before I start de-cowl and disassemble? ________________________________________________________________________________
Date: Dec 16, 2010
Hugh, We ran our Allegro with vent lines tucked into the float-bowl bail too for the entire time we owned it, with no problems either. It is not essential to change that in any way as long as you don't have any really odd airflow under the cowl and therefore unusual pressure distributions. However, routing the vent line to the inside of the air filter is the way that Jabiru does theirs and it does eliminate any spurious pressure issues that might arise in some installations. As Lucien said, black plugs are common after a few minutes of low rpm running. The only way to get an accurate plug reading on engines with Bing CV carbs is to cut the engine off at altitude at cruise rpm, do a dead stick landing and check the plugs. I am not recommending this, of course, though I have done it myself. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323600#323600 ________________________________________________________________________________
Date: Dec 16, 2010
Thom, Thanks. Based on my operating experience and engine performance to date, I see no reason to start re-routing my vent lines. However, the information gleaned from the input from you and Lucien has been very helpful in better understanding the operating characteristics of the 912 UL. Hugh McKay Maiden, NC Allegro 2000 Rotax 912 UL -----Original Message----- From: Thom Riddle Sent: Thursday, December 16, 2010 4:04 PM Subject: RotaxEngines-List: Re: Rough Running 912 Hugh, We ran our Allegro with vent lines tucked into the float-bowl bail too for the entire time we owned it, with no problems either. It is not essential to change that in any way as long as you don't have any really odd airflow under the cowl and therefore unusual pressure distributions. However, routing the vent line to the inside of the air filter is the way that Jabiru does theirs and it does eliminate any spurious pressure issues that might arise in some installations. As Lucien said, black plugs are common after a few minutes of low rpm running. The only way to get an accurate plug reading on engines with Bing CV carbs is to cut the engine off at altitude at cruise rpm, do a dead stick landing and check the plugs. I am not recommending this, of course, though I have done it myself. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323600#323600 ________________________________________________________________________________
Date: Dec 17, 2010
Subject: Happy First Flight Day
Wilbur Wright invented flight controls, with Orville invented aircraft propeller theory, and developed the first real flight test program. Until 1908 all the others were just jumping off the roof with an umbrella. Happy First Flight Day folks. Rick Girard -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 17, 2010
Thom Riddle wrote: > Hugh, > We ran our Allegro with vent lines tucked into the float-bowl bail too for the entire time we owned it, with no problems either. It is not essential to change that in any way as long as you don't have any really odd airflow under the cowl and therefore unusual pressure distributions. However, routing the vent line to the inside of the air filter is the way that Jabiru does theirs and it does eliminate any spurious pressure issues that might arise in some installations. > > As Lucien said, black plugs are common after a few minutes of low rpm running. The only way to get an accurate plug reading on engines with Bing CV carbs is to cut the engine off at altitude at cruise rpm, do a dead stick landing and check the plugs. I am not recommending this, of course, though I have done it myself. BTW, another way that I mentioned before that you can do without pulling the plugs is just examining your exhaust baffles. What I've found is the high-power mixture will be reflected in a baffle, but a rough gauge of what you're getting at low power settings will collect on inside of the exhaust outlet. I.e. the exhaust pipe will usually have a fair buildup of black soot but the exhaust baffle will hopefully be a light antique white. When I was doing my carb sync after getting my rebuilt carbs back a few months ago, I did a lot of running at idle and 2000 to 3000 on the ground. The baffle inside my exhaust got pretty tarred&feathered with soot. but after going up and doing a few touch and goes the baffles were nice and white when I got back down. The other discovery is that when I finally got the idle mix set on the "knee", the idle EGT's ended up around 1050 to 1100F. I was at about 800 to 900F before, which I didn't know was just slobbering rich.... The idle speed also came up about 50 rpm as I leaned out the mix. Course this is all at my 7000' MSL and the density altitude is usually 8000' or more, so you kind of have to make adjustments like this up here. At sea level, you're pretty much just bolt the motor on and don't screw with it.... Oh PS: the fight I started on the Kolb list wasn't about the 912 vent lines (it was about the 2-stroke pulse line length). LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323650#323650 ________________________________________________________________________________
Subject: Re: Happy First Flight Day
Date: Dec 20, 2010
102 years ago. Phew......Geoff -------- Dual controls. Dynon 180. Icom 210 Garmin 296. Becker transponder. Sigtronics intercom. Electric flaperons. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323903#323903 ________________________________________________________________________________
Subject: Octane degrading with storage time
Date: Dec 20, 2010
Are there any real octane enhansers readily available? I get the impression that the ones generally advertised are pretty much 'snake oil' Second question: what lowering of octane rating can you expect in the real world? In other words, how long is 91-octane 'good' in a 912uls? Thanks for your views. ________________________________________________________________________________
Subject: Re: 912ULS Oil Pressure Sender
Date: Dec 20, 2010
Bump on the topic of Oil Pressure Sender, there are a few threads on this, I chose this one. Have a Rotax 912 UL running the Standard VDO Oil Pressure Sender 360-004, or 29/12 stamping on the hex. W/ a MGL E-1 engine system, I started getting high (100+) and Low (20 ish) oil pressure indications w/ an engine at normal temps. Checked the connections- sender, 1 wire to distro block for MGL, and wire from block. All fine. Got a $15 direct gauge at car parts store, installed (15 minutes) and ground run- all normal. (Old ball pressure regulator, 1994 era 4,152,xxx serial number). Found these ohm values today on the net: pressure sender In my search for info while overcoming the fluctuating oil pressure problems, I managed to obtain the correct resistance readings for the VDO sensor at various pressures. In case they may be of use to others in their trouble shooting I repeat them here. VDO 0 - 10 bar oil pressure sensor, Bar psi Resistance (Ohm's) 0 = 0 = 7.2 0.5 = 7 = 18.2 1 = 14.5 = 28.2 1.5 = 21.75 = 39.2 2 = 29 = 49.2 3 = 43.5 = 68.2 4 = 58 = 87.2 5 = 72.5 = 104.2 6 = 87 = 121.2 7 = 101.5 = 137.2 8 = 116 = 153.2 8.5 = 123 = 160.2 9 = 130.5 = 167.2 10 = 145 = 181.2 Cobbles a set of fittings together to air and rang out the sender from 0 to 8 Bar, all good. Looks like the sender I just ordered for $35 will be my spare. I'll re-install the old sender and add an extra ground ring to a good common ground and see if it was a ground issue all along. You will find guidance to use no thread sealant, threadlocker 243 or thread sealant in different places... I also now have a way to check if the new sender is good when it arrives. Now, for fun, I'll make a shaker to check the sender under vibration- supposedly the reason these senders don't last if the shaking on a plane vs a car, plus the variation in pressures seen and the surge types. Hope this helps someone out! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323954#323954 ________________________________________________________________________________
Subject: Re: Octane degrading with storage time
Date: Dec 20, 2010
Hi John, I wouldn't keep fuel longer that 4 weeks. That's what Rotax recommends. No matter what type of container you store fuel in it will evaporate and or have octane degradation and loose other additives. Don't store any more than you will use in that time and don't fill your plane up if you plan on letting it set for months. If you plan on not flying for a couple of months just drain the fuel at a low point bleed. Octane booster won't work for us and unless you feel like throwing the dice with $10-$12k in rebuild cost then just use fresh fuel. It will drop down to to 87-88 octane before you know it. If that happens either drain and put fresh 91 oct. in or add at least 50% of 100LL. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323978#323978 ________________________________________________________________________________
Date: Dec 20, 2010
Thanks, Roger. I was not looking to increase octane in the mogas (91) but wondered about 'rejuvenating' 91 that has been in the plane longer than I would be comfortable with...says something over 3 weeks. If the weather would cooperate I could keep the gas fresh by simply flying a lot, which is what I want to do, but winds have been so darn bad of late that flying wasn't worth the beating you'd take doing it. I will note your recomendations and follow them. Thank you. John ----- Original Message ----- From: "Roger Lee" <ssadiver1(at)yahoo.com> Sent: Monday, December 20, 2010 7:29 PM Subject: RotaxEngines-List: Re: Octane degrading with storage time > > Hi John, > > I wouldn't keep fuel longer that 4 weeks. That's what Rotax recommends. No > matter what type of container you store fuel in it will evaporate and or > have octane degradation and loose other additives. Don't store any more > than you will use in that time and don't fill your plane up if you plan on > letting it set for months. If you plan on not flying for a couple of > months just drain the fuel at a low point bleed. Octane booster won't work > for us and unless you feel like throwing the dice with $10-$12k in rebuild > cost then just use fresh fuel. It will drop down to to 87-88 octane before > you know it. If that happens either drain and put fresh 91 oct. in or add > at least 50% of 100LL. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323978#323978 > > > ________________________________________________________________________________
From: "Matt Tucciarone" <m.tucciarone(at)hotmail.com>
Date: Dec 21, 2010
?I have been flying a 912S for about 7 years now. I have had gas in the plane for longer than 4 weeks. As soon as I buy gas, I add Stabil to it even if I plan to fly that day. I have never had a problem. I have never seen any varnishing in my float bowls. My engine has never even hiccupped. I learned this at a Rotax seminar taught by Phill Lockwood. -----Original Message----- From: John Fasching Sent: Monday, December 20, 2010 9:56 PM Subject: Re: RotaxEngines-List: Re: Octane degrading with storage time Thanks, Roger. I was not looking to increase octane in the mogas (91) but wondered about 'rejuvenating' 91 that has been in the plane longer than I would be comfortable with...says something over 3 weeks. If the weather would cooperate I could keep the gas fresh by simply flying a lot, which is what I want to do, but winds have been so darn bad of late that flying wasn't worth the beating you'd take doing it. I will note your recomendations and follow them. Thank you. John ----- Original Message ----- From: "Roger Lee" <ssadiver1(at)yahoo.com> Sent: Monday, December 20, 2010 7:29 PM Subject: RotaxEngines-List: Re: Octane degrading with storage time > > Hi John, > > I wouldn't keep fuel longer that 4 weeks. That's what Rotax recommends. No > matter what type of container you store fuel in it will evaporate and or > have octane degradation and loose other additives. Don't store any more > than you will use in that time and don't fill your plane up if you plan on > letting it set for months. If you plan on not flying for a couple of > months just drain the fuel at a low point bleed. Octane booster won't work > for us and unless you feel like throwing the dice with $10-$12k in rebuild > cost then just use fresh fuel. It will drop down to to 87-88 octane before > you know it. If that happens either drain and put fresh 91 oct. in or add > at least 50% of 100LL. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323978#323978 > > ________________________________________________________________________________
Date: Dec 21, 2010
I've heard this "octane degrades over time" story a lot over the years. Several years ago I researched this and found (and lost) a petroleum engineer's explanation of how gasoline goes bad over time. He explained all of this in layman's terms and debunked the "octane degrades" part, i.e. octane does not degrade. However, gasoline does go bad for other reasons. I wish I could find this but have failed to do so, so far but will keep looking. However, I did find the following which I believe to be a reliable authoritative source (but can't guarantee that) which does not even mention octane but does describe how gasoline does go bad over time. http://www.straightdope.com/columns/read/2668/why-does-gasoline-go-stale-so-quickly As this source recommends, I have been adding Sta-bil to my stored gasoline beginning in the late fall when my flying frequency falls off dramatically. It works well in my experience. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Everyone is entitled to his own opinion, but not his own facts. Daniel Patrick Moynihan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324000#324000 ________________________________________________________________________________
Date: Dec 22, 2010
John, I too always add Sta-bil to my fuel and it does help. .In the past I sometimes had run-on at engine shutdown with my 912 when I had "vintage' fuel in my tanks. It acted like an old car with bad gas. As an experiment I added Lucas brand octane booster to the fuel and it stopped that from happening.I have actually done this on a few occasions and for that reason I will say octane booster does work. Some brands contain alcohol so if you were decide to try it be selective as to the brand. Best option of course is to have fresh gas but if I can't fly for awhile ,I would use the booster . There is an unknown here and that is octane booster chenicals and its effect on fiberglas tanks(in my case) Dick Maddux 912UL Milton,Fl ________________________________________________________________________________
Subject: engine burping
Date: Dec 27, 2010
=EF=BB I had a guy tell me that his mechanic said that after he flies his plane, he should run the prop through and burp the engine again just like before flight. He said if you don=99t do it, oil will collect in the cylinders. Has anyone been told to do this? On my plane my oil tank is above the engine. One time, after not flying the plane for about 2 weeks, I took out a spark plug at the lowest point on the engine. Some oil dripped out. I had not run the prop through first like I would if I was going to start it. Is any of this a problem? The mechanic said it is not good for the oil to be there but I didn=99t think it was a problem if you run the prop through to burping before start. Any thoughts? ________________________________________________________________________________
Subject: Re: engine burping
Date: Dec 27, 2010
[quote="m.tucciarone(at)hotmail.c"]I had a guy tell me that his mechanic said that after he flies his plane, he should run the prop through and burp the engine again just like before flight. He said if you dont do it, oil will collect in the cylinders. Has anyone been told to do this? On my plane my oil tank is above the engine. One time, after not flying the plane for about 2 weeks, I took out a spark plug at the lowest point on the engine. Some oil dripped out. I had not run the prop through first like I would if I was going to start it. Is any of this a problem? The mechanic said it is not good for the oil to be there but I didnt think it was a problem if you run the prop through to burping before start. Any thoughts? Usually I don't think enough oil collects in the crankcase for this to happen, but I guess that could depend on the installation. If it does, I don't see why not to burp it after the flight. Is your oil return line in the hole at the lowest point? I.e. if cyls 1-2 are low when the plane is at rest, the oil return line banjo fitting should be in the hole in the crankcase nearest the gearbox.... But yeah this is familar with any flat four. My VW's would sometimes collect oil in the cylinders if I parked it on the side of a hill.... LS > [b] -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324661#324661 ________________________________________________________________________________
Subject: New flywheel hub for 912 series
Date: Dec 27, 2010
Hi all, Rotax has recently introduced a new fly wheel hub with lengthened trigger cams which change the ignition timing during starting. This is described in SI-912-020 R4, section 74-00-00, page 1 and 4. With the new hub, ignition timing during the starting phase will be 3 degrees after TDC instead of 4 degrees before TDC. I am very interested in doing this mod on my 912ULS as it should prevent any possibility of kicking back. However I am puzzled by the dimensions shown on the drawing on page 4. The drawing says the old cams are 22 mm long and the new ones are 29 mm long. I measured the length of the cams on my 6 year old engine: they are 30 mm long! I also did the maths: the radius of the flywheel cams is 78 mm, so 1 degree rotation moves the cam edges 1.36 mm. From 4 to 26 degrees, that is 22 degrees difference, the length should be 1.36x22=29.95. So i believe my hub is good and the Rotax drawing is wrong. I have 2 questions: - to anyone who has access to the back of his engine: could you please remove the 3 screws which hold the plastic cover and measure the developed length of the cams. - to any one who has the new flywheel hub: please do the same. According to the SI, engines fitted with the new flywheel hub start with the following serial numbers: 912S: from S/N 4,923,847 912ULS and ULSFR: from 6,775,360 Waiting for your answers Regards Remi Guerner Europa F-FGKL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324673#324673 Attachments: http://forums.matronics.com//files/new_fly_wheel_hub_156.jpg http://forums.matronics.com//files/new_fly_wheel_hub_987.jpg ________________________________________________________________________________
Date: Dec 27, 2010
From: Dan Billingsley <dan(at)azshowersolutions.com>
Subject: EIS 4000 connections
Hope everyone is having a great holiday break and enjoying the season! As I am home this week I'm finishing up some of my last electrical connections to the 912s. The wiring hasn't been too bad, just tedious as most know. I am using a Grand Rapids 4000 EIS and would like to tap into those who are familiar with the CHT connections.( I called GR, but they are enjoying the week off as well.) The EGT connections are straight forward because each bayonet probe (that goes into an exhaust pipe) has two wires to plug into. There are 2 CHT probes provided on the 912s at cylinders 2 and 3. My question develops due to having two CHT wires (per cylinder head) to be connected with onlyone fast-on connection provided at the engine. So the question is...How is the connection made? The GR manual was very specific indicating that the two (dis-similar metal) wires be used to properly allow the thermocouple to send correct info... My common sence (sometimes not so common :>) tells me one of the wires goes to ground...but I don't want to guess at this. Any help would be appreciated. ________________________________________________________________________________
Date: Dec 27, 2010
The Rotax CHT probes are not thermocouples (with a plus and minus lead). They are resistors whose resistance varies (inversely) with heat (also known as Negative Temperature Coefficient or NTC probes). One side of the resistor grounds through the body of the probe to the head. Check the GRT site for Rotax-specific information or general information on connecting resistive probes, resistive water temperature senders or NTC probes. The same kind of probes are used for oil temperature. -- Craig -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Dan Billingsley Sent: Monday, December 27, 2010 9:43 AM Subject: RotaxEngines-List: EIS 4000 connections Hope everyone is having a great holiday break and enjoying the season! As I am home this week I'm finishing up some of my last electrical connections to the 912s. The wiring hasn't been too bad, just tedious as most know. I am using a Grand Rapids 4000 EIS and would like to tap into those who are familiar with the CHT connections.( I called GR, but they are enjoying the week off as well.) The EGT connections are straight forward because each bayonet probe (that goes into an exhaust pipe) has two wires to plug into. There are 2 CHT probes provided on the 912s at cylinders 2 and 3. My question develops due to having two CHT wires (per cylinder head) to be connected with onlyone fast-on connection provided at the engine. So the question is...How is the connection made? The GR manual was very specific indicating that the two (dis-similar metal) wires be used to properly allow the thermocouple to send correct info... My common sence (sometimes not so common :>) tells me one of the wires goes to ground...but I don't want to guess at this. Any help would be appreciated. ________________________________________________________________________________
Date: Dec 27, 2010
Yes, But is it bad if some oil collects there? As I said, I always burp the engine before start. -----Original Message----- From: lucien Sent: Monday, December 27, 2010 11:23 AM Subject: RotaxEngines-List: Re: engine burping [quote="m.tucciarone(at)hotmail.c"]I had a guy tell me that his mechanic said that after he flies his plane, he should run the prop through and burp the engine again just like before flight. He said if you dont do it, oil will collect in the cylinders. Has anyone been told to do this? On my plane my oil tank is above the engine. One time, after not flying the plane for about 2 weeks, I took out a spark plug at the lowest point on the engine. Some oil dripped out. I had not run the prop through first like I would if I was going to start it. Is any of this a problem? The mechanic said it is not good for the oil to be there but I didnt think it was a problem if you run the prop through to burping before start. Any thoughts? Usually I don't think enough oil collects in the crankcase for this to happen, but I guess that could depend on the installation. If it does, I don't see why not to burp it after the flight. Is your oil return line in the hole at the lowest point? I.e. if cyls 1-2 are low when the plane is at rest, the oil return line banjo fitting should be in the hole in the crankcase nearest the gearbox.... But yeah this is familar with any flat four. My VW's would sometimes collect oil in the cylinders if I parked it on the side of a hill.... LS > [b] -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324661#324661 ________________________________________________________________________________
Date: Dec 27, 2010
Subject: Re: EIS 4000 connections
Dan, See the Installation Manual, Chapter 21 page 127. The CHT sensor is grounded through the engine block. Rick Girard On Mon, Dec 27, 2010 at 11:42 AM, Dan Billingsley wrote: > dan(at)azshowersolutions.com> > > Hope everyone is having a great holiday break and enjoying the season! > As I am home this week I'm finishing up some of my last electrical > connections > to the 912s. The wiring hasn't been too bad, just tedious as most know. > I am using a Grand Rapids 4000 EIS and would like to tap into those who are > familiar with the CHT connections.( I called GR, but they are enjoying the > week > off as well.) The EGT connections are straight forward because each bayonet > probe (that goes into an exhaust pipe) has two wires to plug into. There > are 2 > CHT probes provided on the 912s at cylinders 2 and 3. My question develops > due > to having two CHT wires (per cylinder head) to be connected with onlyone > fast-on > connection provided at the engine. > So the question is...How is the connection made? The GR manual was very > specific > indicating that the two (dis-similar metal) wires be used to properly allow > the > thermocouple to send correct info... > My common sence (sometimes not so common :>) tells me one of the wires goes > to > ground...but I don't want to guess at this. > > Any help would be appreciated. > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 27, 2010
Never ever heard of burping the engine after a flight. Doesn't make any sense. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324693#324693 ________________________________________________________________________________
Date: Dec 27, 2010
Richard,=0A-I have been reading that page, however it does not indicate a nywhere as to =0Ausing just one wire coming from the EIS...and if so, which one? Would I just cut =0Athe second one off? The manual is vague.=0A=0A=0A >=0A>From: Richard Girard <aslsa.rng(at)gmail.com>=0A>To: rotaxengines-list@ma tronics.com=0A>Sent: Mon, December 27, 2010 12:42:15 PM=0A>Subject: Re: Rot axEngines-List: EIS 4000 connections=0A>=0A>Dan, See the Installation Manua l, Chapter 21 page 127. The CHT sensor is =0A>grounded through the engine b lock. =0A>=0A>=0A>=0A>Rick Girard=0A>=0A>=0A>On Mon, Dec 27, 2010 at 11:42 AM, Dan Billingsley =0A>wrote:=0A>=0A>--> Rotax Engines-List message posted by: Dan Billingsley =0A><dan@azshowersolutions. com>=0A>>=0A>>Hope everyone is having a great holiday break and enjoying th e season!=0A>>As I am home this week I'm finishing up some of my last elect rical connections=0A>>to the 912s. The wiring hasn't been too bad, just ted ious as most know.=0A>>I am using a Grand Rapids 4000 EIS and would like to tap into those who are=0A>>familiar with the CHT connections.( I called GR , but they are enjoying the =0Aweek=0A>>off as well.) The EGT connections a re straight forward because each bayonet=0A>>probe (that goes into an exhau st pipe) has two wires to plug into. There are 2=0A>>CHT probes provided on the 912s at cylinders 2 and 3. My question develops due=0A>>to having two CHT wires (per cylinder head) to be connected with onlyone =0A>fast-on=0A>> connection provided at the engine.=0A>>So the question is...How is the conn ection made? The GR manual was very =0A>specific=0A>>indicating that the tw o (dis-similar metal) wires be used to properly allow =0Athe=0A>>thermocoup le to send correct info...=0A>>My common sence (sometimes not so common :>) tells me one of the wires goes to=0A>>ground...but I don't want to guess a t this.=0A>>=0A>>Any help would be appreciated.=0A>>=0A>>====== ======0A>>="_blank">www.aeroelectric.com=0A>>ooks.com" target ="_blank">www.buildersbooks.com=0A>>et="_blank">www.homebuilthelp.com =0A>>="_blank">http://www.matronics.com/contribution=0A>>le, List Admin. =0A>>============0A>>-List" target="_blank">http:// www.matronics.com/Navigator?RotaxEngines-List=0A>>======== ====0A>>http://forums.matronics.com=0A>>========= ===0A>>=0A>>=0A>>=0A>>=0A>=0A>=0A>-- =0A>=0A>Zulu Delta=0A>Kolb Mk IIIC =0A>582 Gray head=0A>4.00 C gearbox=0A>3 blade WD=0A>Thanks, Homer GBYM=0A> =0A>=0A>It is not bigotry to be certain we are right; but it is bigotry to be unable to =0A>imagine how we might possibly have gone wrong.=0A>---G = =0A> ________________________________________________________________________________
Date: Dec 27, 2010
?That is exactly what I thought. I was just wondering if anyone else has heard of this. I try to keep up with procedures. I have been flying this 912s for about 8 years now and never heard that. -----Original Message----- From: Roger Lee Sent: Monday, December 27, 2010 2:46 PM Subject: RotaxEngines-List: Re: engine burping Never ever heard of burping the engine after a flight. Doesn't make any sense. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324693#324693 ________________________________________________________________________________
Date: Dec 27, 2010
Is the person making this recommendation an A & P by chance? As Roger said, it doesn't make any sense. The engine has its own motion to "burp" the engine while it was running. If it were to collect oil in the crankcase tha t quickly after shut down, I'd be suspicious of the condition of the engine o r its installation. While it's remote, their is one thing that might make burping a hot engine dangerous. If there were a hot spark plug, i.e. acting like a glow plug, or a bit of carbon doing the same, the engine could kick back. Like I said the chances are remote, but they aren't zero. Rick Girard On Mon, Dec 27, 2010 at 1:23 PM, Matt Tucciarone wrote: > m.tucciarone(at)hotmail.com> > > =EF=BBYes, > But is it bad if some oil collects there? As I said, I always burp the > engine before start. > > > -----Original Message----- From: lucien > Sent: Monday, December 27, 2010 11:23 AM > To: rotaxengines-list(at)matronics.com > Subject: RotaxEngines-List: Re: engine burping > > lstavenhagen(at)hotmail.com> > > [quote="m.tucciarone(at)hotmail.c"]I had a guy tell me that his mechani c > said that after he flies his plane, he should run the prop through and b urp > the engine again just like before flight. He said if you don=C3=A2=82 =AC=84=A2t do it, oil > will collect in the cylinders. Has anyone been told to do this? On my pl ane > my oil tank is above the engine. One time, after not flying the plane fo r > about 2 weeks, I took out a spark plug at the lowest point on the engine . > Some oil dripped out. I had not run the prop through first like I would if > I was going to start it. Is any of this a problem? The mechanic said it is > not good for the oil to be there but I didn=C3=A2=82=AC=84=A2t thi nk it was a problem if > you run the prop through to burping before start. > > Any thoughts? > > > Usually I don't think enough oil collects in the crankcase for this to > happen, but I guess that could depend on the installation. If it does, I > don't see why not to burp it after the flight. > > Is your oil return line in the hole at the lowest point? I.e. if cyls 1-2 > are low when the plane is at rest, the oil return line banjo fitting shou ld > be in the > hole in the crankcase nearest the gearbox.... > > But yeah this is familar with any flat four. My VW's would sometimes > collect oil in the cylinders if I parked it on the side of a hill.... > > LS > > > [b] >> > > > -------- > LS > Titan II SS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=324661#324661 > > =========== =========== =========== =========== > > -- Zulu Delta Kolb Mk IIIC 582 Gray head 4.00 C gearbox 3 blade WD Thanks, Homer GBYM It is not bigotry to be certain we are right; but it is bigotry to be unabl e to imagine how we might possibly have gone wrong. - G.K. Chesterton ________________________________________________________________________________
Date: Dec 27, 2010
I have heard of folks checking their oil after flight and if OK and as long as they don't see a big puddle under the plane they go flying without checking the oil. Is it possible that's what was meant? Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324707#324707 ________________________________________________________________________________
Date: Dec 27, 2010
I can understand burping the engine say ten minuets after shut down. During this time the engine cools and the air in the engine shrinks causing a slight vacuum that can suck oil back into the crankcase. I believe the only reason a person would do that is to get an accurate oil level check. -------- Ron Lee Tucson, Arizona Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324735#324735 ________________________________________________________________________________
Date: Dec 28, 2010
Matt, You don't need to burp your engine right after you have run it as the engine has already done that BUT if you have a high oil tank as I do, on my Kitfox, the oil will migrate out of the tank back down into the engine over time. You can slow it down a bit by waiting for the engine to cool and the oil to thicken a bit then burp the engine, I usually do this when I am working on other projects in my hanger and do it later in the day. Then instead of a couple of days before the oil level sinks below the min on the dipstick it might take 4 days (as an example) This procedure just decreases the number of revolutions you have to give the prop when you first burp the engine because you have less oil to pump back into the oil tank.(but really...whoopdedoo!) Dick Maddux 912UL Milton,Fl ________________________________________________________________________________
Date: Dec 28, 2010
?Thanks Dick, I agree with you. The mechanic said that the oil that would get back in the cylinders would be bad for the engine. I disagree and it looks like from the response to my post that you and others disagree also. Thanks to everyone for their input on this. Matt From: Catz631(at)aol.com Sent: Tuesday, December 28, 2010 8:19 AM Subject: Re: RotaxEngines-List: engine burping Matt, You don't need to burp your engine right after you have run it as the engine has already done that BUT if you have a high oil tank as I do, on my Kitfox, the oil will migrate out of the tank back down into the engine over time. You can slow it down a bit by waiting for the engine to cool and the oil to thicken a bit then burp the engine, I usually do this when I am working on other projects in my hanger and do it later in the day. Then instead of a couple of days before the oil level sinks below the min on the dipstick it might take 4 days (as an example) This procedure just decreases the number of revolutions you have to give the prop when you first burp the engine because you have less oil to pump back into the oil tank.(but really...whoopdedoo!) Dick Maddux 912UL Milton,Fl ________________________________________________________________________________
Date: Dec 28, 2010
Hi Dan, You use the CHT sensors supplied by GRT. They are thermocouples. Use the red & white wire GRT supplied to connect them to Connector B. The Rotax (VDO) supplied sensors are resistive and could be set up as aux inputs to the EIS if you desire. I just unscrewed each Rotax (VDO) sensors, placed the lug of the GRT sensor under it and rescrewed it in to secure the GRT sensor. I also did a few checks and satisified myself that the GRT sensor indicated the same as the Rotax (VDO) sensor. Hope this helps. Jim Butcher Europa XS 914 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324793#324793 ________________________________________________________________________________
Date: Dec 28, 2010
Thank you all for the info and ideas. I have decided to get the ring thermocouples that fit over the spark plugs. Jim, I'm guessing these are the "connector B" that you used? Thanks all again, Dan ----- Original Message ---- > From: "h&jeuropa" <butcher43(at)att.net> > To: rotaxengines-list(at)matronics.com > Sent: Tue, December 28, 2010 7:30:55 AM > Subject: RotaxEngines-List: Re: EIS 4000 connections > > > Hi Dan, > > You use the CHT sensors supplied by GRT. They are thermocouples. Use the red >& white wire GRT supplied to connect them to Connector B. > > > The Rotax (VDO) supplied sensors are resistive and could be set up as aux >inputs to the EIS if you desire. > > > I just unscrewed each Rotax (VDO) sensors, placed the lug of the GRT sensor >under it and rescrewed it in to secure the GRT sensor. > > I also did a few checks and satisified myself that the GRT sensor indicated the >same as the Rotax (VDO) sensor. > > Hope this helps. > > Jim Butcher > Europa XS 914 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=324793#324793 > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 28, 2010
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
Dan=0Atrouble with these is they are disturbed every time you check the plu gs. Not =0Areliable long term imho=0AGraham=0A=0A=0A=0A=0A_________________ _______________=0AFrom: Dan Billingsley <dan(at)azshowersolutions.com>=0ATo: r otaxengines-list(at)matronics.com=0ASent: Tuesday, 28 December, 2010 15:28:55 =0ASubject: Re: RotaxEngines-List: Re: EIS 4000 connections=0A=0A--> RotaxE ngines-List message posted by: Dan Billingsley =0A=0A=0AThank you all for the info and ideas. I have decided to get the rin g =0Athermocouples that fit over the spark plugs. Jim, I'm guessing these a re the =0A"connector B" that you used?=0AThanks all again,=0ADan=0A=0A=0A =0A----- Original Message ----=0A> From: "h&jeuropa" <butcher43(at)att.net >=0A> To: rotaxengines-list(at)matronics.com=0A> Sent: Tue, December 28, 2010 7:30:55 AM=0A> Subject: RotaxEngines-List: Re: EIS 4000 connections=0A> =0A et>=0A> =0A> Hi Dan,=0A> =0A> You use the CHT sensors supplied by GRT. The y are thermocouples. Use the red =0A=0A>& white wire GRT supplied to conne ct them to Connector B. =0A>=0A> =0A> The Rotax (VDO) supplied sensors ar e resistive and could be set up as aux =0A>inputs to the EIS if you desire. =0A>=0A> =0A> I just unscrewed each Rotax (VDO) sensors, placed the lug of the GRT sensor =0A>under it and rescrewed it in to secure the GRT sensor .=0A> =0A> I also did a few checks and satisified myself that the GRT senso r indicated the =0A>=0A>same as the Rotax (VDO) sensor.=0A> =0A> Hope this helps.=0A> =0A> Jim Butcher=0A> Europa XS 914=0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A> http://forums.matronics.com/viewtopic.php? p=324793#324793=0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A ================== ________________________________________________________________________________
Date: Dec 28, 2010
Subject: Rotax 912 oil system prime and purge
I am completing installation of a Rotax 912UL in a Pipistrel Sinus. The installation includes an oil temperature thermostat. I acquired an oil priming kit from California Power Systems and am following the instructions in the kit, as well as the video on the Rotax Owners web site. See the links below to a couple of photos of my installation. Oil thermostat: http://webhosting.web.com/imagelib/sitebuilder/misc/show_image.html?linkedwidth=actual&linkpath=http://www.pipistrelbuilders.com/sitebuildercontent/sitebuilderpictures/oil_thermostat_12.JPG&target=tlx_pic2orp Oil cooler: http://webhosting.web.com/imagelib/sitebuilder/misc/show_image.html?linkedwidth=actual&linkpath=http://www.pipistrelbuilders.com/sitebuildercontent/sitebuilderpictures/Baffle_seal_1.JPG&target=tlx_picm5rc I have a few questions: I have applied air pressure to the oil tank and turned the prop through until I get oil pressure and oil is coming out of the oil return line. The oil comes out in a slow trickle. Should it be a flow with some real volume? That is, should it gush out, or is a small trickle enough? I don't have my engine instrumentation installed yet, so I am measuring the resistance of the VDO sender to determine oil pressure. I get 8.1 ohms with no pressure in the system, which corresponds reasonably well with some calibration data that appears on this forum awhile back. I get about 45 ohms while turning the prop through, which would indicate something above 30 psi at the sender, so I seem to be getting good oil pressure. Various sources that describe the purge procedure talk about using "appropriate measures" to ensure that the oil circuit through the oil cooler is filled, because the oil cooler is bypassed by the thermostat when the oil is cold. I'm doing the purge at normal room temperature, and the person I spoke with at CPS said that there will always be some oil passed through the oil cooler circuit, even when the thermostat is cool. After achieving the purge conditions described above, I tried pulling the oil hose off of the outlet fitting on the oil cooler, expecting to find both the cooler and the hose full of oil. What I found is evidence that oil is flowing through there, by way of some oil dripping out of the hose, but they certainly weren't full of oil. So, I used a heat gun to warm up the thermostat until is was hot to the touch, then pulled the prop through for a bunch of revolutions. This appears to draw some more oil out of the oil tank, as evidenced by a drop in the oil level, and some more oil came out of the return line -- perhaps a half a cup or so during this step. Then I pulled the hose from the oil cooler again, with the same result as before -- some oil present, but the line is basically empty and full of air. What should I be expecting? Are the cooler and the lines going to fill with oil and remain full? Seems like they should. The purging instructions and the warnings about engine damage all talk about getting rid of all air in the system. Otherwise, if I ran the engine right now, a whole bunch of air is going to hit the oil pump, which will be a bad thing. I realize that by pulling the oil line from the cooler I am breaking the system seal and introducing an air pocket, which will have to be purged out, but until I checked that hose, it appeared to me that I had achieved the objectives of the purge. That is, I had 30 psi of oil pressure and I had oil coming out of the return line. Advice? Regards, Paul Kuntz ________________________________________________________________________________
Date: Dec 29, 2010
Dan, No what I was trying to say is to use the CHT thermocouples supplied by GRT instead of the VDO sensors that came on the engine. The CHT thermocouples came with your EIS if you told them it was for a Rotax 912 / 914 (if you didn't, you need to get them from GRT). They look like a large solder lug and each has a red and a white wire attached. They are to be bolted to the cylinder head at the same place as the Rotax supplied VDO sensor. Either use the VDO sensor to bolt them to the head (strictly as a bolt, not connected as a sensor) or use the metric bolt GRT supplies for that purpose. They are not spark plug gasket CHT thermocouples. Spark plug thermocouples do not work well on a 912/914 since the plug is recessed into the head and therefore difficult to fit a gasket under. There is a diagram on Figure 5b-Connector B Wiring in the EIS manual showing where to connect the red wire and where to connect the white wire for each sensor. Use the crimp on connectors supplied by GRT to make the connections. So, for the CHT sensor on cylinder head 2, connect the red wire from the sensor to the red wire on pin 10. Likewise the white wire for CHT 2 goes to pin 22. For cylinder head 3, the red goes to pin 8 and the white goes to pin 20. There is also a note (page 14, bottom of section 5.2.8) about what to do with unused CHT inputs (in your case CHT 1 & 4). To avoid bad readings, connect the red & white wires together to make a "short". Doe this make sense? Jim Butcher Europa XS 914 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=324904#324904 ________________________________________________________________________________
Date: Dec 29, 2010
Jim, Thank you very much for the detailed response. After quite a bit of searching and scratching for the information, I got it figured out between this group and another site I belong to. My trouble originated due to the EIS being part of the Kitfox kit I purchased from a second party. Not all the parts or information was there, so I had a handicap going into it. What threw me thinking the ring thermocouples went over the spark plugs was the install manual states that. They did not, however, diferentiate this between engine types. Thanks again for the information to all who responded. Dan B Mesa, AZ ----- Original Message ---- > From: "h&jeuropa" <butcher43(at)att.net> > To: rotaxengines-list(at)matronics.com > Sent: Wed, December 29, 2010 7:02:08 AM > Subject: RotaxEngines-List: Re: EIS 4000 connections > > > Dan, > > No what I was trying to say is to use the CHT thermocouples supplied by GRT >instead of the VDO sensors that came on the engine. The CHT thermocouples came >with your EIS if you told them it was for a Rotax 912 / 914 (if you didn't, you >need to get them from GRT). They look like a large solder lug and each has a >red and a white wire attached. > > > They are to be bolted to the cylinder head at the same place as the Rotax >supplied VDO sensor. Either use the VDO sensor to bolt them to the head >(strictly as a bolt, not connected as a sensor) or use the metric bolt GRT >supplies for that purpose. > > > They are not spark plug gasket CHT thermocouples. Spark plug thermocouples do >not work well on a 912/914 since the plug is recessed into the head and >therefore difficult to fit a gasket under. > > There is a diagram on Figure 5b-Connector B Wiring in the EIS manual showing >where to connect the red wire and where to connect the white wire for each >sensor. Use the crimp on connectors supplied by GRT to make the connections. >So, for the CHT sensor on cylinder head 2, connect the red wire from the sensor >to the red wire on pin 10. Likewise the white wire for CHT 2 goes to pin 22. >For cylinder head 3, the red goes to pin 8 and the white goes to pin 20. > > > There is also a note (page 14, bottom of section 5.2.8) about what to do with >unused CHT inputs (in your case CHT 1 & 4). To avoid bad readings, connect the >red & white wires together to make a "short". > > > Doe this make sense? > > Jim Butcher > Europa XS 914 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=324904#324904 > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 29, 2010
Dan, Attached is a pic of the CHT sensor from GRT installed as Jim described. Note the bolt holding the GRT ring terminal on. It looks like one black wire but that is heat shrink, there is a white wire and red wire in there. The existing VDO CHT sensors removed are not wasted. Look at the blue cool ant hose. You see the fitting that I got from GRT tapped into the hose held in with clamps. It is designed to accept one of those VDO CHT sensors for the EIS to measure coolant temp . If you have sensors for a different type of engine installation, call GRT and see if they will do a trade for the proper sensors. Brian Unruh www.701builder.com ________________________________________________________________________________
Date: Dec 30, 2010
Thanks for the pic Brian...worth a thousand words :>) Dan > >From: "ruruny(at)aol.com" <ruruny(at)aol.com> >To: rotaxengines-list(at)matronics.com >Sent: Wed, December 29, 2010 7:29:15 PM >Subject: RotaxEngines-List: Re: EIS 4000 connections > >Dan, > > >Attached is a pic of the CHT sensor from GRT installed as Jim described. Note >the bolt > >holding the GRT ring terminal on. It looks like one black wire but that is heat >shrink, there is >a white wire and red wire in there. >The existing VDO CHT sensors removed are not wasted. Look at the blue coolant >hose. >You see the fitting that I got from GRT tapped into the hose held in with >clamps. It is designed >to accept one of those VDO CHT sensors for the EIS to measure coolant temp. >If you have sensors for a different type of engine installation, call GRT and >see if they will do a >trade for the proper sensors. > > >Brian Unruh >www.701builder.com > ________________________________________________________________________________
Subject: More engine info
Date: Jan 02, 2011
Happy New year to all of you, Hop on over to the www.ctflier.com website under engine's and avionics or whatever you would like. Lots of info and other LSA related chat that goes on regularly. A Rotax 912 is a Rotax 912 no matter what plane it is on. On the CT Flier form they encourage all LSA. You may find so helpful info over there as well as our site here. You can just go as a guest, but can see more and do more as a registered user. Being on more than one forum may help fill in some gaps with not only our engine, but other areas on your craft. Plus everyone over there is very helpful and pleasant. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325288#325288 ________________________________________________________________________________
Date: Jan 04, 2011
Subject: drop of rpm on take off
Hi all, I just subscribed to the list. What a great forum! I have trouble with my 80 hp 912. Maybe someone has a good idea and can give me some help. Background: 912 with 150 hrs. in a Kitfox, no troubles so far, 98 octane auto fuel, alcohol test negative, aircraft parked in heated hangar, properly drained and engine run up, fuel always filtrated, filter visually clean, carbs freshly pneumatically balanced, mag drop ca. 200/300 rpm (has recently deteriorated). What happened: Very cold outside temperature, about -15 centigrade. Max. ground rpm ca. 5000 rpm (should be 5100, has deteriorated somewhat - under cold conditions?), acceleration and take off normal, a couple of seconds after take off sudden drop of rpm to ca. 4500-4600 rpm. After another couple of seconds and the engine catches up and returns to 5000 rpm. At least, so far it always did. No problems in cruise with 4300 rpm. I usually take off and cruise also under these cold conditions without carb heat. I tried a take off with carb heat and a couple of seconds after take off: rpm drop as obove! All this happened four or five times. Next I plan to change the spark plugs, although they still look good and the manual says change after 200 hrs. Any help would be highly appreciated! Thanks, Georg Kitfox, 912 80 hp Germany ________________________________________________________________________________
From: "Simon Lancashire" <simon(at)design24.org.uk>
Date: Jan 04, 2011
Georg, I am new to this forum and have a Pulsar with an early 912. My aircraft is low wing and has a boost pump as the fuel tanks are below the engine. Is it possible that your problem may be due to low fuel pressure due to the angle of incidence at the point of takeoff in the kitfox? (very nose high) The standard Rotax pump can only suck so hard and may be o0n the limit without help. Fuel boost pumps are inexpensive and easy to fit and i use mine always for take-off, landing and fuel tank switching. Good luck! Simon, UK Pulsar XP G-BUZB -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of georg.stiller(at)arcor.de Sent: 04 January 2011 22:30 Subject: RotaxEngines-List: drop of rpm on take off Hi all, I just subscribed to the list. What a great forum! I have trouble with my 80 hp 912. Maybe someone has a good idea and can give me some help. Background: 912 with 150 hrs. in a Kitfox, no troubles so far, 98 octane auto fuel, alcohol test negative, aircraft parked in heated hangar, properly drained and engine run up, fuel always filtrated, filter visually clean, carbs freshly pneumatically balanced, mag drop ca. 200/300 rpm (has recently deteriorated). What happened: Very cold outside temperature, about -15 centigrade. Max. ground rpm ca. 5000 rpm (should be 5100, has deteriorated somewhat - under cold conditions?), acceleration and take off normal, a couple of seconds after take off sudden drop of rpm to ca. 4500-4600 rpm. After another couple of seconds and the engine catches up and returns to 5000 rpm. At least, so far it always did. No problems in cruise with 4300 rpm. I usually take off and cruise also under these cold conditions without carb heat. I tried a take off with carb heat and a couple of seconds after take off: rpm drop as obove! All this happened four or five times. Next I plan to change the spark plugs, although they still look good and the manual says change after 200 hrs. Any help would be highly appreciated! Thanks, Georg Kitfox, 912 80 hp Germany ________________________________________________________________________________
Subject: RE: drop of rpm on take off
Date: Jan 04, 2011
Carb float bowl vents run to bottom of firewall? ________________________________________________________________________________
Date: Jan 05, 2011
Subject: Re: RotaxEngines-List Digest: 3 Msgs - 01/04/11
Georg, Warm air is rich air, cold air is lean air. At -15 C, which very few of us experience, you could very well be getting an extremely lean mixture. This can cause a variety of problems including but not limited to detonation and preignition. My suggestion would be to lower the clip/raise the needle 1 notch to richen the mixture. STAN 2 N29TD ________________________________ From: RotaxEngines-List Digest Server <rotaxengines-list(at)matronics.com> Sent: Wed, January 5, 2011 1:58:49 AM Subject: RotaxEngines-List Digest: 3 Msgs - 01/04/11 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RotaxEngines-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RotaxEngines-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-01-04&Archive=RotaxEngines Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-01-04&Archive=RotaxEngines =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RotaxEngines-List Digest Archive --- Total Messages Posted Tue 01/04/11: 3 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 02:34 PM - drop of rpm on take off (georg.stiller(at)arcor.de) 2. 03:55 PM - Re: drop of rpm on take off (Simon Lancashire) 3. 06:33 PM - Re: drop of rpm on take off (ruruny(at)aol.com) ________________________________ Message 1 _____________________________________ From: georg.stiller(at)arcor.de Subject: RotaxEngines-List: drop of rpm on take off Hi all, I just subscribed to the list. What a great forum! I have trouble with my 80 hp 912. Maybe someone has a good idea and can give me some help. Background: 912 with 150 hrs. in a Kitfox, no troubles so far, 98 octane auto fuel, alcohol test negative, aircraft parked in heated hangar, properly drained and engine run up, fuel always filtrated, filter visually clean, carbs freshly pneumatically balanced, mag drop ca. 200/300 rpm (has recently deteriorated). What happened: Very cold outside temperature, about -15 centigrade. Max. ground rpm ca. 5000 rpm (should be 5100, has deteriorated somewhat - under cold conditions?), acceleration and take off normal, a couple of seconds after take off sudden drop of rpm to ca. 4500-4600 rpm. After another couple of seconds and the engine catches up and returns to 5000 rpm. At least, so far it always did. No problems in cruise with 4300 rpm. I usually take off and cruise also under these cold conditions without carb heat. I tried a take off with carb heat and a couple of seconds after take off: rpm drop as obove! All this happened four or five times. Next I plan to change the spark plugs, although they still look good and the manual says change after 200 hrs. Any help would be highly appreciated! Thanks, Georg Kitfox, 912 80 hp Germany ________________________________ Message 2 _____________________________________ From: "Simon Lancashire" <simon(at)design24.org.uk> Subject: RE: RotaxEngines-List: drop of rpm on take off Georg, I am new to this forum and have a Pulsar with an early 912. My aircraft is low wing and has a boost pump as the fuel tanks are below the engine. Is it possible that your problem may be due to low fuel pressure due to the angle of incidence at the point of takeoff in the kitfox? (very nose high) The standard Rotax pump can only suck so hard and may be o0n the limit without help. Fuel boost pumps are inexpensive and easy to fit and i use mine always for take-off, landing and fuel tank switching. Good luck! Simon, UK Pulsar XP G-BUZB -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of georg.stiller(at)arcor.de Sent: 04 January 2011 22:30 Subject: RotaxEngines-List: drop of rpm on take off Hi all, I just subscribed to the list. What a great forum! I have trouble with my 80 hp 912. Maybe someone has a good idea and can give me some help. Background: 912 with 150 hrs. in a Kitfox, no troubles so far, 98 octane auto fuel, alcohol test negative, aircraft parked in heated hangar, properly drained and engine run up, fuel always filtrated, filter visually clean, carbs freshly pneumatically balanced, mag drop ca. 200/300 rpm (has recently deteriorated). What happened: Very cold outside temperature, about -15 centigrade. Max. ground rpm ca. 5000 rpm (should be 5100, has deteriorated somewhat - under cold conditions?), acceleration and take off normal, a couple of seconds after take off sudden drop of rpm to ca. 4500-4600 rpm. After another couple of seconds and the engine catches up and returns to 5000 rpm. At least, so far it always did. No problems in cruise with 4300 rpm. I usually take off and cruise also under these cold conditions without carb heat. I tried a take off with carb heat and a couple of seconds after take off: rpm drop as obove! All this happened four or five times. Next I plan to change the spark plugs, although they still look good and the manual says change after 200 hrs. Any help would be highly appreciated! Thanks, Georg Kitfox, 912 80 hp Germany ________________________________ Message 3 _____________________________________ Subject: RotaxEngines-List: RE: drop of rpm on take off From: ruruny(at)aol.com Carb float bowl vents run to bottom of firewall? ________________________________________________________________________________
Subject: Re: drop of rpm on take off
Date: Jan 05, 2011
I think the air may be too cold for your carb needle setting. 30 degrees C below standard needs about as much extra fuel as when I moved my plane from 5000' MSL to sea level. My issues were LESS severe than yours. Setting the carb needle clips down from #2 to #3 position (3 is normal) fixed the issue nicely. Hopefully someone like Roger Lee can help you out. I had sync'd my carbs just before finally isolating my issue, after moving the clips the carbs needed only slight rebalance, then it was smiles all around. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325755#325755 ________________________________________________________________________________
Date: Jan 06, 2011
I agree. I think he is running just a little lean so long as the mag drops are fairly equal. Drop the clip one notch from position 3 to 4. Normal clip position is in number 3. Position one is at the top. This will richen the mixture some for your cold dense air. Later when it warms for the summer you can switch back. Double check the carb balance after you switch. Let us know the results. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325783#325783 ________________________________________________________________________________
Subject: trouble shooting an ignition issue
Date: Jan 06, 2011
Hi All, This was posted by a very knowledgeable friend of mine on another forum and is good advise for those wanting to trouble shoot an ignition issue. First of all I just have to say that I love ignition problems, why? Because most of the time they can be quickly diagnosed with some very basic systematic troubleshooting, I have to admit that I have spent some time over the years pulling my hair over ignition issues before I developed a full proof method for diagnosing faults. General things to consider... 1) If one cylinder was not firing at all then when you do your mag drop at 4000rpm you can expect to see a 400-600rpm drop 2) If two cylinders were not firing at all then when you do your drop at 4000rpm you can expect a 900-1100rpm drop Step 1) If you are getting a high mag drop (over 200rpm) you can pretty much rule out it being an issue with your ignition switch ground, in most cases ignition switch issues are never severe enough to cause more than a slight irratic running, 98% of the time ignition switch issues lead to a complete failure of one whole system. To clarify it's going to be one or the other. Step 2) Try switching the black boxes, why? Because it takes all of about 15 min and it will almost immediately rule out the single most expensive part in the system. Step 3) Return the black boxes to there original locations but before doing so, grab a small ice pick and disconnect the red wires coming into the rear of the engine. Then switch these wires a perform a test run. Ask your self does the problem switch sides? These wires are what sends the AC voltage developed by the stator on the rear of the engine to the black boxes to be directed to the spark plugs. If the problem switches sides then it is an issue with the stator ( check wire resistance to ground 3.2-4.5ohms) if the problem doesn't switch sides then the issue is "down stream " of the stator and is either in the black boxes ( which you have already ruled out) or in the secondary coils and plugs. Step 4) After determining that the issue lies in the secondary coils then the next logical step is to check the resistance of both sides of the coils the primary side being fed by the black boxes ( 0.1-0.4ohms) then test the secondary. Step 5) check your triggers, these are located on the back of the engine and tell the black boxes when to fire the spark, there are 4 of them that trigger a respective secondary coil, the resistance should be 220-250 ohms for the new style, these a rarely the problem unless there has been physical damage to them, they are also only replaceable as a set so as much as I would love to sell you a set please be sure that they are not working before ordering... Were trying to be mechanics not parts changers right? Note: the secondary coil is suppose to be between 6.1-6.7 kohms, to get this reading rather than removing both spark plug caps, since this may hide your problem I would leave both caps connected and test from one cap to the other (1&2T...1&2B ...3&4T...3&4B) each cap is rated at 5kohms so your readings should be between 16.1-16.7k ohms the 0.1 ohm per foot of the spark plug cable should not be a factor. After all these test have been performed you should of localized the problem to a specific component. Common issues more or less in order.. 1) loose spark plug caps! 2) Bad grounds ( look for corrosion on central grounding point on #1/3 intake manifold) 3) Bad charging coil, usually as a result of a loose cap or running the engine with out spark plus caps installed with mags on 4) ignition switch ( like I said usually only the case with either very slight mag drops or complete failure 5) charging wires there is a SB on older engines but in the case of most CTs it would most likely be related to physical damage ( shorted or nicked wire) 6) Black boxes ( rarely ever fail but when they do it's almost always related to heat under the cowling 7) Triggers, usually as a result of physical damage, be very suspicious of this if your engine has recently been removed 8) Timing.....oh wait!? It never changes ( this can pretty much be ruled out every time :-) There you go... A&P FCCL Sport Pilot ROTAX MECHANIC -912 OVERHAUL RATED Technical Director & Rotax Warranty Rep. for California Power Systems Nor-Cal Emergency Field Services, LLC -Owner (209)481-5881 Cell (510)247-9653 CPS Shop Mon-Fri Nor_Calefs(at)Yahoo.com -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325785#325785 ________________________________________________________________________________
Subject: Re: trouble shooting an ignition issue
Date: Jan 06, 2011
Excellent Post, thanks to you and the author for making it available to us all. :D Rick -------- 701Driver N35 26.700, W118 16.743 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325803#325803 ________________________________________________________________________________
Subject: Watch Spot Tracker in action
Date: Jan 09, 2011
Hi All, A friend of mine just turned his Spot on in Corning, CA. and will be headed home to Bisbee, AZ. You can click on his Spot link. (Coppercity Aviation) and watch his progress across CA and AZ. He is getting a late start due to fog. If you leave the Spot link open it will automatically update on it's own as he cruises. http://share.findmespot.com/shared/faces/viewspots.jsp?glId=0qvvNclNhjEqYVq4G9piLqngR0uboKroM -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326128#326128 ________________________________________________________________________________
Date: Jan 11, 2011
Subject: Re: Westach probes
Hi Barry, Somehow I got side tracked on this. I am still interested in these probes if you still have them available for sale. Thanks and regards, Paul ________________________________ From: FLYaDIVE <flyadive(at)gmail.com> Sent: Sat, August 28, 2010 8:22:37 PM Subject: Re: RotaxEngines-List: Westach probes Paul: I have a set of four grounded EGT probes with a 90 Deg hard tube bend. They install very nicely and work great on grounded systems. If you go this route I'll sel them at a very reduced price. Barry On Sat, Aug 28, 2010 at 3:15 PM, Paul McAllister wrote: Hi all, > >I was wondering if anyone has ever used these probes with a Grand Rapids EIS ? >They are K type thermocouples and the offer grounded and un grounds tips. If >anyone has experience with these I'd appreciate some feedback. > >BTW. The probes that GRT sell are too long and now bang into the oil tank on >one side and the Intercooler on the other side. > >Thanks, Paul ________________________________________________________________________________
Date: Jan 11, 2011
Hello Paul: Ya know, I forgot about them also. I will pull them out of my goody box and get the info to you. Barry On Tue, Jan 11, 2011 at 8:10 PM, Paul McAllister wrote: > Hi Barry, > > Somehow I got side tracked on this. I am still interested in these probes > if you still have them available for sale. > > Thanks and regards, Paul > > ------------------------------ > *From:* FLYaDIVE > *To:* rotaxengines-list(at)matronics.com > *Sent:* Sat, August 28, 2010 8:22:37 PM > *Subject:* Re: RotaxEngines-List: Westach probes > > Paul: > > I have a set of four grounded EGT probes with a 90 Deg hard tube bend. > They install very nicely and work great on grounded systems. > > If you go this route I'll sel them at a very reduced price. > > Barry > > > On Sat, Aug 28, 2010 at 3:15 PM, Paul McAllister wrote: > >> Hi all, >> >> I was wondering if anyone has ever used these probes with a Grand Rapids >> EIS ? They are K type thermocouples and the offer grounded and un grounds >> tips. If anyone has experience with these I'd appreciate some feedback. >> >> BTW. The probes that GRT sell are too long and now bang into the oil tank >> on one side and the Intercooler on the other side. >> >> Thanks, Paul >> > > > * > > * > > ________________________________________________________________________________
Date: Jan 12, 2011
Subject: FUEL TANK SEALANTS
Hello Gaggle: I have been fighting leaking fuel tans for a while. The tanks are aluminum and sealed with PRO SEAL or the equivalent. Since my engine likes both AvGas and MoGas and MoGas has ethanol I would like a sealant that can stand up to both. Stop - I know about the trick of removing the ethanol from MoGas but that is only about 90% effective. I would like to run straight MoGas. Would anyone out there have any experience in this area? Thank you for the assistance. Barry ________________________________________________________________________________
Date: Jan 12, 2011
How about this ACS part number 09-02566 . I have used it on fibreglass BSA tanks. _____ From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE Sent: January-12-11 12:03 PM Subject: RotaxEngines-List: FUEL TANK SEALANTS Hello Gaggle: I have been fighting leaking fuel tans for a while. The tanks are aluminum and sealed with PRO SEAL or the equivalent. Since my engine likes both AvGas and MoGas and MoGas has ethanol I would like a sealant that can stand up to both. Stop - I know about the trick of removing the ethanol from MoGas but that is only about 90% effective. I would like to run straight MoGas. Would anyone out there have any experience in this area? Thank you for the assistance. ________________________________________________________________________________
Date: Jan 12, 2011
Subject: Re: FUEL TANK SEALANTS
Hi Dave: I saw that one... (09-02566) Do you have any personal experience with that product? Barry On Wed, Jan 12, 2011 at 4:03 PM, Dave wrote: > How about this ACS part number 09-02566 . I have used it on fibreglass > BSA tanks. > > > ------------------------------ > *From:* owner-rotaxengines-list-server(at)matronics.com [mailto: > owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of *FLYaDIVE > *Sent:* January-12-11 12:03 PM > *To:* rotaxengines-list(at)matronics.com > *Subject:* RotaxEngines-List: FUEL TANK SEALANTS > > Hello Gaggle: > > I have been fighting leaking fuel tans for a while. The tanks are aluminum > and sealed with PRO SEAL or the equivalent. > Since my engine likes both AvGas and MoGas and MoGas has ethanol I would > like a sealant that can stand up to both. > Stop - I know about the trick of removing the ethanol from MoGas but that > is only about 90% effective. > I would like to run straight MoGas. > Would anyone out there have any experience in this area? > > Thank you for the assistance. > > * > > > * > > ________________________________________________________________________________
Date: Jan 12, 2011
From: Pete Christensen <pchristensen10(at)austin.rr.com>
Dave, I'm curious that you mentioned that removing ethanol from mogas is only 90% effective. Have you tried it? I am experimenting with removing ethanol from mogas and it works fine so far in my Kitfox/912. If there is a bit of ethanol left in my gas it has not caused any problems. There is little information out there about washing gas. Pete On 1/12/2011 3:03 PM, Dave wrote: > How about this ACS part number 09-02566 . I have used it on fibreglass > BSA tanks. > ------------------------------------------------------------------------ > *From:* owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of > *FLYaDIVE > *Sent:* January-12-11 12:03 PM > *To:* rotaxengines-list(at)matronics.com > *Subject:* RotaxEngines-List: FUEL TANK SEALANTS > > Hello Gaggle: > > I have been fighting leaking fuel tans for a while. The tanks are > aluminum and sealed with PRO SEAL or the equivalent. > Since my engine likes both AvGas and MoGas and MoGas has ethanol I > would like a sealant that can stand up to both. > Stop - I know about the trick of removing the ethanol from MoGas but > that is only about 90% effective. > I would like to run straight MoGas. > Would anyone out there have any experience in this area? > > Thank you for the assistance. > > * > > > * ________________________________________________________________________________
Date: Jan 12, 2011
Dave, What is the root cause of your aluminum tanks leaking? How old are the tanks? Are they leaking at fabricated joints? How long have you had this problem? The reason I ask is, I have aluminum wing tanks in my Allegro 2000 and have not had any problem with leaks since the first flight in 2007. I now have almost 500 hours on the engine and I use 93 octane (ethanol free) fuel as well as 87 octane (10% ethanol). Is your problem the fuel or poor fabrication of the tanks? Hugh McKay From: Pete Christensen Sent: Wednesday, January 12, 2011 3:16 PM Subject: Re: RotaxEngines-List: FUEL TANK SEALANTS Dave, I'm curious that you mentioned that removing ethanol from mogas is only 90% effective. Have you tried it? I am experimenting with removing ethanol from mogas and it works fine so far in my Kitfox/912. If there is a bit of ethanol left in my gas it has not caused any problems. There is little information out there about washing gas. Pete On 1/12/2011 3:03 PM, Dave wrote: How about this ACS part number 09-02566 . I have used it on fibreglass BSA tanks. ------------------------------------------------------------------------- ----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE Sent: January-12-11 12:03 PM To: rotaxengines-list(at)matronics.com Subject: RotaxEngines-List: FUEL TANK SEALANTS Hello Gaggle: I have been fighting leaking fuel tans for a while. The tanks are aluminum and sealed with PRO SEAL or the equivalent. Since my engine likes both AvGas and MoGas and MoGas has ethanol I would like a sealant that can stand up to both. Stop - I know about the trick of removing the ethanol from MoGas but that is only about 90% effective. I would like to run straight MoGas. Would anyone out there have any experience in this area? Thank you for the assistance. ________________________________________________________________________________
Date: Jan 12, 2011
Kreem Weiss is a great tank coating. The entire 1500+ fleet of Flight Design CT's has it's tanks coated with Kreem and most of us use ethanol fuels. 325 of them here in the states. Never an ethanol issue. Some in Europe and South America use up to 18%-23% ethanol and never have any issues. It is pretty much impervious to anything, that's why so many people that coat tanks use it professionally. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326739#326739 ________________________________________________________________________________
Subject: 5th Annual 2011 Page, AZ Fly-In
Date: Jan 12, 2011
5th Annual 2011 Page, AZ. Fly-InI Including Lake Powell, Monument Valley, Bryce Canyon, Zion, Grand Canyon, St. George, Bullfrog Marina Resort... and more! Make those reservations now.. More people, more planes, different flight venue, bigger and better than last year! The Page, AZ. Fly-In date is October 13-16, 2011 We will fly the Grand Canyon, Lake Powell, Monument Valley, Zion Canyon and breakfast at Bryce Canyon, Monument Valley, Bullfrog Marina and resort. We will also be adding St. George this year for breakfast and adding new routes. I managed to block off 45 rooms. We got a great rate of $49 same as last year. I hope to have a record number of CT's and LSA aircraft for our Page Fly-In. Just like last year make the reservations early so you don't miss out and the hotel won't hold all 45 rooms forever. Do not wait this year. Book it now and you can cancel up to 24 hours before Oct. 13th. Get it booked and reserved, then if you have to cancel you can, but if you wait again then you may not be staying with the rest of us and at your own peril for rates and possibly a different hotel. They book darn near the whole town in October. We have a special rate at the same place we stayed last year. Tell them you are with the "CT Group" or Roger Lee to cross reference and the rate is $49 a night. We will arrive Thursday morning, Oct. 13th. and head home Oct. 16th. Sunday or Monday morning. Breakfast is free in the mornings. I talked to the people at the Ranch House Grill and they will cater our evening meals again. We will have evening meals together Thursday, Friday and Saturday. Rose is our contact person. Best Western Arizona Inn 716 Rim View Dr. Page, Az. 800-826-2718 928-645-2466 The AZ. Inn has gone completely non-smoking! We will fly into the Page airport - KPGA. We are staying with Classic FBO and with our group we should get a 30 cent discount on fuel. Classic is not the first FBO next to the runway, but the second one behind them. The Antelope Canyon tour and the Dam tour is open if anyone wants. These are land tours. You guys are welcome to invite other planes that are not CT's and everyone is welcome. Find some more LSA's. I will develop GPS coordinates for all our routes and post them so you can enter them in your own GPS. I have a plan to better deal with all our planes for our flights so they are not crowded in the mornings or evenings. Don't miss this, we always have fun. p.s. I would like everyone coming to shoot me an email so I can put together a roster, make name tags and set up call signs like we did last year. If you attended last year and we had your personal info then just say you are coming. If you did not come last year then I would like the email to include: N#, Names of you and co-pilot, cell phone number, city, state. This is a big help for me to last year to organize our fly outs since we have so many planes and gives old friends and new friends a way to contact each other if need be. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=326742#326742 ________________________________________________________________________________
Date: Jan 12, 2011
Hi Roger: I have tried this sealant. It worked GREAT on a stationary tank. But FAILED quickly when used on a flexible aluminum (aviation) tank and on fiberglass tanks. The stuff dries almost stiff, not really flexible. What might you know about: http://www.hirschauto.com/products.asp?dept=4 Barry On Wed, Jan 12, 2011 at 5:04 PM, Roger Lee wrote: > > Kreem Weiss is a great tank coating. The entire 1500+ fleet of Flight > Design CT's has it's tanks coated with Kreem and most of us use ethanol > fuels. 325 of them here in the states. Never an ethanol issue. Some in > Europe and South America use up to 18%-23% ethanol and never have any > issues. It is pretty much impervious to anything, that's why so many people > that coat tanks use it professionally. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=326739#326739 > > ________________________________________________________________________________
Date: Jan 12, 2011
Pete: You are correct. Yes, I have tried it for two years. It does work pretty well, but if you religiously check your gas on a pre-flight you will find water in it. Barry On Wed, Jan 12, 2011 at 3:16 PM, Pete Christensen < pchristensen10(at)austin.rr.com> wrote: > Dave, I'm curious that you mentioned that removing ethanol from mogas is > only 90% effective. Have you tried it? I am experimenting with removing > ethanol from mogas and it works fine so far in my Kitfox/912. If there is a > bit of ethanol left in my gas it has not caused any problems. There is > little information out there about washing gas. > > Pete > > > On 1/12/2011 3:03 PM, Dave wrote: > > How about this ACS part number 09-02566 . I have used it on fibreglass BSA > tanks. > > > ------------------------------ > *From:* owner-rotaxengines-list-server(at)matronics.com [ > mailto:owner-rotaxengines-list-server(at)matronics.com] > *On Behalf Of *FLYaDIVE > *Sent:* January-12-11 12:03 PM > *To:* rotaxengines-list(at)matronics.com > *Subject:* RotaxEngines-List: FUEL TANK SEALANTS > > Hello Gaggle: > > I have been fighting leaking fuel tans for a while. The tanks are > aluminum and sealed with PRO SEAL or the equivalent. > Since my engine likes both AvGas and MoGas and MoGas has ethanol I would > like a sealant that can stand up to both. > Stop - I know about the trick of removing the ethanol from MoGas but that > is only about 90% effective. > I would like to run straight MoGas. > Would anyone out there have any experience in this area? > > Thank you for the assistance. > > * > > * > > * > > * > > ________________________________________________________________________________
Date: Jan 12, 2011
Only on motorcycle tanks. The fibreglass used on BSA tanks of the sixties doesn't stand up well at all with the crap we call gas these days. This stuff seems pretty much able to stand up to it, which is what they claim for it. It's foul to work with but once hardened seems to stand up well. _____ From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE Sent: January-12-11 3:18 PM Subject: Re: RotaxEngines-List: FUEL TANK SEALANTS Hi Dave: I saw that one... (09-02566) Do you have any personal experience with that product? Barry On Wed, Jan 12, 2011 at 4:03 PM, Dave wrote: How about this ACS part number 09-02566 . I have used it on fibreglass BSA tanks. _____ From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE Sent: January-12-11 12:03 PM Subject: RotaxEngines-List: FUEL TANK SEALANTS Hello Gaggle: I have been fighting leaking fuel tans for a while. The tanks are aluminum and sealed with PRO SEAL or the equivalent. Since my engine likes both AvGas and MoGas and MoGas has ethanol I would like a sealant that can stand up to both. Stop - I know about the trick of removing the ethanol from MoGas but that is only about 90% effective. I would like to run straight MoGas. Would anyone out there have any experience in this area? Thank you for the assistance. ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 12, 2011
Hugh: It is I, Barry that posted the question. The tanks are quite a few years old... About 30 years old. And they are sealed with PRC, as I mentioned. I resealed them with PRC put coatings on top of the PRC. But it still leaks. WAY too much work and expense to disassemble the tanks and start from the beginning. Barry On Wed, Jan 12, 2011 at 5:01 PM, Hugh McKay wrote: > Dave, > > What is the root cause of your aluminum tanks leaking? How old are the > tanks? Are they leaking at fabricated joints? How long have you had this > problem? The reason I ask is, I have aluminum wing tanks in my Allegro 2000 > and have not had any problem with leaks since the first flight in 2007. I > now have almost 500 hours on the engine and I use 93 octane (ethanol free) > fuel as well as 87 octane (10% ethanol). Is your problem the fuel or poor > fabrication of the tanks? > > Hugh McKay > ________________________________________________________________________________
Date: Jan 12, 2011
Barry, You got that right. I do check. I was thinking of "aging" my washed gas in a clean empty glass carboy for a week or so then siphoning the gas off to use. Pete On 1/12/2011 4:49 PM, FLYaDIVE wrote: > Pete: > > You are correct. > > Yes, I have tried it for two years. It does work pretty well, but if > you religiously check your gas on a pre-flight you will find water in it. > > Barry > > On Wed, Jan 12, 2011 at 3:16 PM, Pete Christensen > > > wrote: > > Dave, I'm curious that you mentioned that removing ethanol from > mogas is only 90% effective. Have you tried it? I am > experimenting with removing ethanol from mogas and it works fine > so far in my Kitfox/912. If there is a bit of ethanol left in my > gas it has not caused any problems. There is little information > out there about washing gas. > > Pete > > > On 1/12/2011 3:03 PM, Dave wrote: >> How about this ACS part number 09-02566 . I have used it on >> fibreglass BSA tanks. >> ------------------------------------------------------------------------ >> *From:* owner-rotaxengines-list-server(at)matronics.com >> >> [mailto:owner-rotaxengines-list-server(at)matronics.com] *On Behalf >> Of *FLYaDIVE >> *Sent:* January-12-11 12:03 PM >> *To:* rotaxengines-list(at)matronics.com >> >> *Subject:* RotaxEngines-List: FUEL TANK SEALANTS >> >> Hello Gaggle: >> >> I have been fighting leaking fuel tans for a while. The tanks >> are aluminum and sealed with PRO SEAL or the equivalent. >> Since my engine likes both AvGas and MoGas and MoGas has ethanol >> I would like a sealant that can stand up to both. >> Stop - I know about the trick of removing the ethanol from MoGas >> but that is only about 90% effective. >> I would like to run straight MoGas. >> Would anyone out there have any experience in this area? >> >> Thank you for the assistance. >> >> * >> >> >> * > * > > ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * ________________________________________________________________________________
Date: Jan 12, 2011
HI, I think you might be confusing me with FlyDive. I have no aluminum tanks. I am worried a little about my fibreglass Kitfox tanks but so far no problems. I have used this product for vintage BSA fibreglass and it appears to hold up, but I don't think we have alcohol in our gas here in the Maritimes. I sold off all the old bikes, but all my experience with this has been ok. _____ From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh McKay Sent: January-12-11 5:02 PM Subject: Re: RotaxEngines-List: FUEL TANK SEALANTS Dave, What is the root cause of your aluminum tanks leaking? How old are the tanks? Are they leaking at fabricated joints? How long have you had this problem? The reason I ask is, I have aluminum wing tanks in my Allegro 2000 and have not had any problem with leaks since the first flight in 2007. I now have almost 500 hours on the engine and I use 93 octane (ethanol free) fuel as well as 87 octane (10% ethanol). Is your problem the fuel or poor fabrication of the tanks? Hugh McKay From: Pete Christensen <mailto:pchristensen10(at)austin.rr.com> Sent: Wednesday, January 12, 2011 3:16 PM Subject: Re: RotaxEngines-List: FUEL TANK SEALANTS Dave, I'm curious that you mentioned that removing ethanol from mogas is only 90% effective. Have you tried it? I am experimenting with removing ethanol from mogas and it works fine so far in my Kitfox/912. If there is a bit of ethanol left in my gas it has not caused any problems. There is little information out there about washing gas. ________________________________________________________________________________
Date: Jan 12, 2011
I have used KBS- coatings gas tank sealer work for me great go to the web site and check it out Jerry Evans KitfoxII Magalia Calif. N582'er' kitfox 555 --- On Wed, 1/12/11, FLYaDIVE wrote: From: FLYaDIVE <flyadive(at)gmail.com> Subject: RotaxEngines-List: FUEL TANK SEALANTS Date: Wednesday, January 12, 2011, 9:02 AM Hello Gaggle: I have been fighting leaking fuel tans for a while. -The tanks are alumin um and sealed with PRO SEAL or the-equivalent. - Since my engine likes both AvGas and MoGas and MoGas has ethanol I would li ke a sealant that can stand up to both. Stop - I know about the trick of removing the ethanol from MoGas but that i s only about 90% effective. - I would like to run-straight-MoGas. Would anyone out there have any-experience-in this area? Thank you for the-assistance. Barry ________________________________________________________________________________
Date: Jan 14, 2011
Barry, I have aluminum fuel tanks in my Zenith 701 (4) 11.5 gallon tanks. They we re welded at the factory and I haven't had a problem with leaks..... yet. Since you have been having this problem for awhile with leaking tanks, may be a more permanent fix should be made. I'm sure it would be alot of work to get the tanks out, and they are full of old sealant that would make this impossible. My friend has been fixing tabs and threads on his harley engine for awhile now with great sucess. Watch this video and please post any comments. http://www.aluminumrepair.com/video_new.asp Brian http://www.701builder.com Hello Gaggle: I have been fighting leaking fuel tans for a while. The tanks are aluminu m and sealed with PRO SEAL or the equivalent. Since my engine likes both AvGas and MoGas and MoGas has ethanol I would like a sealant that can stand up to both. Stop - I know about the trick of removing the ethanol from MoGas but that is only about 90% effective. I would like to run straight MoGas. Would anyone out there have any experience in this area? Thank you for the assistance. Barry ________________________________________________________________________________
Date: Jan 14, 2011
Brian: I would love to do that.... Problem is the TANK is the WING. It is know as a Wet Wing. And the material is only 0.020" thick. And there is no access to the inside of the wing/tank for ANY type of welding. Some problems are really problems ;-) The main problem is that the sealing compound's chemistry has changed due to the EPA. It is know to be cancer causing in California Rats. WHO CARES! I'm not a California Rat and I don't plan on eating it! I just want a gas tank that does not leak. ;-( Barry On Fri, Jan 14, 2011 at 11:18 AM, wrote: > > > Barry, > > I have aluminum fuel tanks in my Zenith 701 (4) 11.5 gallon tanks. They > were welded at the factory and I haven't had a > problem with leaks..... yet. > > Since you have been having this problem for awhile with leaking tanks, > maybe a more permanent fix should be made. > I'm sure it would be alot of work to get the tanks out, and they are full > of old sealant that would make this impossible. > My friend has been fixing tabs and threads on his harley engine for awhile > now with great sucess. Watch this video and please post any comments. > > http://www.aluminumrepair.com/video_new.asp > > Brian > http://www.701builder.com > > > Hello Gaggle: > > I have been fighting leaking fuel tans for a while. The tanks are aluminum > and sealed with PRO SEAL or the equivalent. > Since my engine likes both AvGas and MoGas and MoGas has ethanol I would > like a sealant that can stand up to both. > Stop - I know about the trick of removing the ethanol from MoGas but that is > only about 90% effective. > I would like to run straight MoGas. > Would anyone out there have any experience in this area? > > Thank you for the assistance. > > Barry > > > * > > * > > ________________________________________________________________________________
Date: Jan 14, 2011
When I did my kitfox 2 wing, I took off the wing and just rolled-the wing -around up down side to side -to get all the KBS coating evenly inside the tank . I have a 13.5 gallon wing -tank. -I did the whole process t hey-sell ya work for me very strong stuff- Jerry Evans KitfoxII Magalia Calif. N582'er' kitfox 555 --- On Fri, 1/14/11, FLYaDIVE wrote: From: FLYaDIVE <flyadive(at)gmail.com> Subject: Re: RotaxEngines-List: Re: FUEL TANK SEALANTS Date: Friday, January 14, 2011, 10:41 AM Brian: I would love to do that....- Problem is the TANK is the WING. -It is know as a Wet Wing. And the material is only 0.020" thick. -And there is no access to the ins ide of the wing/tank for ANY type of welding. Some problems are really problems ;-) The main problem is that the sealing compound's-chemistry-has changed d ue to the EPA. -It is know to be cancer causing in California Rats. -WH O CARES! - I'm not a California Rat and I don't plan on eating it! I just want a gas tank that does not leak. ;-( Barry On Fri, Jan 14, 2011 at 11:18 AM, wrote: Barry, - I have aluminum fuel tanks in my Zenith 701 (4) 11.5 gallon tanks. They wer e welded at the factory and I haven't had a problem with leaks..... yet. - Since you have been having this problem for awhile with leaking tanks, mayb e a more permanent fix should be made. I'm sure it would be alot of work to get the tanks out, and they are full o f old sealant that would make this impossible. My friend has been fixing tabs and threads on his harley engine for awhile now with great sucess. Watch this video and please post any comments. - http://www.aluminumrepair.com/video_new.asp - Brian http://www.701builder.com - - - -Hello Gaggle: I have been fighting leaking fuel tans for a while. The tanks are aluminum and sealed with PRO SEAL or the equivalent. Since my engine likes both AvGas and MoGas and MoGas has ethanol I would like a sealant that can stand up to both. Stop - I know about the trick of removing the ethanol from MoGas but that i s only about 90% effective. I would like to run straight MoGas. Would anyone out there have any experience in this area? Thank you for the assistance. Barry - ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: 5th Annual 2011 Page, AZ Fly-In
Date: Jan 16, 2011
Hi Guys, We have a number of people already reserving rooms. You all real ought to try and come to Page, AZ. This is one really fun Fly-In and a nice bunch of people. Anyone that has ever come to Page for this Fly-In always comes back. There is no place in the country that you can fly the places we go, see the scenery or fly the way we fly at home or at any event. Come join us, you won't be sorry. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327185#327185 ________________________________________________________________________________
Subject: Service Bulletin 912-022
Date: Jan 17, 2011
Hi All, This is my first post on the Rotax List. I usually only monitor the Europa List. I am discovering I may need to do a service bulletin on my 912ULS Ser.No 4425662. It involves replacing the valve spring retainers. I was just wondering if anyone can offer any experience or advice. I looked at the price of the Jig Assembly to aid in getting them off and back on and it is 356.00 best case and the kit itself is around 260.00. I live in NC and a long way from any Rotax Repair Station. Any advice. Thanks. Troy Maynor Europa Monowheel Classic Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327364#327364 ________________________________________________________________________________
Subject: Re: Service Bulletin 912-022
Date: Jan 18, 2011
troy,where in NC are you,D&F aviation in goldsboro NC has did work for me in the past, Dwight Edmundson.Phone # 919-778-8816 he is a factory authrorized dealer repairmen. frank Goggio mod4 speedster kitfox 912 Wilmungton NC ________________________________________________________________________________
Date: Jan 18, 2011
Good suggestion... give Dwight a call. He is very knowledgeable. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327430#327430 ________________________________________________________________________________
Date: Jan 18, 2011
Hi Frank, I am based at Hendersonville, near Asheville. I didn't know Dwight was still doing this. I guess I had forgotten about him. Is he actually on the field in Goldsboro. I will check with him and maybe I'll fly down there one day and have him do it. Thanks. Troy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327444#327444 ________________________________________________________________________________
Date: Jan 18, 2011
troy,no he still works out of the back yard, in his shop,he would be glad to meet you i am sure,he was down doing some work for me a short while ago,hope you get iot stright, frank ________________________________________________________________________________
Subject: Re: Corona, CA airport flood
Date: Jan 19, 2011
John thats terrible. Good luck with getting your plane fixed up. I looked at the photos. # 38 looks like a WESSEX helicopter......Geoff -------- Dual controls. Dynon 180. Icom 210 Garmin 296. Becker transponder. Sigtronics intercom. Electric flaperons. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327539#327539 ________________________________________________________________________________
Date: Jan 19, 2011
I just did some checking. Thats a Westland Wessex. Im amazed to see one here. I was in the Royal Navy for 7 years. I saw a lot of them at that time...Geoff -------- Dual controls. Dynon 180. Icom 210 Garmin 296. Becker transponder. Sigtronics intercom. Electric flaperons. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327540#327540 ________________________________________________________________________________
Subject: 912 S/ULS compression ratio
Date: Jan 23, 2011
On the last issue (April 1st, 2010) of the Rotax 912 series Operator Manual, the compression ratio of the 912S/ULS has been increased to 11:1. See page 1-14. Previously it was 10.5:1. Surprisingly there is no mention of any affected performance figure. Does anyone know whether this is just a correction of a mistake in the documentation, or a real modification of the cylinder head or piston geometry? Regards Remi Guerner Europa F-PGKL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327980#327980 ________________________________________________________________________________
Subject: Re: 912 S/ULS compression ratio
Date: Jan 23, 2011
Hi Remi, Nice catch. I suspect it is a typo, but I'll shoot off an email to Rotax and find out for sure. It may be a day or so being Sunday, but I'll re-post and let you know. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328000#328000 ________________________________________________________________________________
Date: Jan 23, 2011
Hi, I started this thread on January, 4. I should like to thank for the advise and report on my findings: I changed the needle in the carb from pos. 3 to 4 and made some testflights at 5 - 6 centigrade below zero with carb heat pulled. There was no trouble, no rpm drop anymore. Power output is okay. Carb heat is nearly ineffective, however, as I checked the temperature in the air box with a digital thermometer and there was virtually no difference with or without carb heat. So the needle position obviously fixed the problem. I have now a little problem with the warm start of the engine. Seems to be running somewhat rich, a little bit of grey smoke from the exaust when the engine catches. Thanks again! Regards, Georg Kitfox, Rotax 912 ________________________________________________________________________________
Date: Jan 23, 2011
Make sure your idle rpm is set to only 1700-1800, not more it may be hard to start and less it may be hard to start. No throttle on start up is normal. Once in a while a 10% throttle opening can help if your normal rpm is a little too low, but no more than 10%. Make sure that both choke/enricher circuits open fully and not one more or less than the other. Try one or two different start up procedures and I'm sure one will work. Starting is also tied to poor carb balance so make sure they are set. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328039#328039 ________________________________________________________________________________
Date: Jan 23, 2011
I'm now installing a 912 to replace a 582. On the 582 I intentionally set the idle very low so the plane wouldn't drift on touchdown. Once on the ground I had to add throttle to keep 1800 rpm. Is this used with the 912? Noel -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: January 23, 2011 1:51 PM Subject: RotaxEngines-List: Re: drop of rpm on take off Make sure your idle rpm is set to only 1700-1800, not more it may be hard to start and less it may be hard to start. No throttle on start up is normal. Once in a while a 10% throttle opening can help if your normal rpm is a little too low, but no more than 10%. Make sure that both choke/enricher circuits open fully and not one more or less than the other. Try one or two different start up procedures and I'm sure one will work. Starting is also tied to poor carb balance so make sure they are set. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328039#328039 ________________________________________________________________________________
Date: Jan 23, 2011
Hi Noel, You' re going to like your 912. 1800 rpm is not enough to keep you flying and might extend a glide 50', maybe. I have a plane that has a 14:1 glide ratio and can land in 1K feet easily with 2800 rpm. I will use 2700-2800 rpm for all flap settings on normal landings or I can land at idle. It can make a world of difference carrying a little rpm to touch. The rest of this post is on my soapbox and not aimed at anyone single person. If someone can't put their plane down with 1800-2000 idle rpm then they should look at their landing technique and try a few changes. Remember the stick controls speed and throttle altitude. So what ever the rpm pulling back the stick to your desired speed works just fine. Yes I know up to a point it makes a difference, but not at rpms at or below 2000 rpm. Landing with rpm will also give you better control surface authority just before touch down. The controls won't feel mushy and give good solid input. If you can't hit a target landing spot at 1600 rpm then you can't hit it at 2800 rpm and either way that just means more focused practice. RPM doesn't decide where or when the wheels or floats touchdown, you do in your setup and execution of the landing. I can hit my spot at 1700 or 3000 rpm on landing and I can touch down at the same speed. Purposely setting an idle rpm so you may loose the engine is, in my opinion, the wrong way to set up your aircraft. It isn't good for the engine or the pilot as some day it may cost you. The more distractions you throw into a landing the more chance of making a mistake some day. It only takes a second for a normal landing to mess up, keep throwing distractions in your execution and sooner or later you may not be jolly on the spot with a correction. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328117#328117 ________________________________________________________________________________
Date: Jan 23, 2011
Hi All, Here is a link to the ROAN website to watch a fairly new Rotax engine tips video. It covers things like start up, carb sync, prop balance, shut down and proper engine rpm, ect. This video gives proper idle speed. This video is in conjunction with "Service Letter" 0912-016. For those who have argued about idle speed for the 912ULS 100 HP I hope this will clear up any low rpm idle issues. It not only talks about it, but you can see it on the instrument panel. The 912UL with only a 9.0:1 compression can do 1500 idle rpm, but the 912ULS at 10.5:1 compression has too much compression and beats up the engine/gearbox, not to mention the chance of loosing an engine at a 1500 idle approach. Be kind to your engine, it's the only thing that keeps you off the ground and out of the tress. The video will tell you to keep rpms at 1800 + rpm and higher depending on the phase of the engine run. Running a 9121ULS at rpms of 1500-1700 is not good for your engine as we have discussed here before. This is in writing now and I hope alleviates some of the confusion from other sources. http://rotax-owner.c...ning&Itemid=174 -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328118#328118 ________________________________________________________________________________
From: "AmphibFlyer" <SeaRey(at)AbstractConcreteWorks.com>
Date: Jan 24, 2011
Roger Lee wrote: > http://rotax-owner.c...ning&Itemid=174 Thanks, Roger! That link got elided. Here's the whole thing--two links, actually: Videos: http://rotax-owner.com/index.php?option=com_content&view=category&layout=blog&id=8&Itemid=174 Manuals: http://joomla.rotax-owner.com/index.php?option=com_content&view=article&id=108&Itemid=169 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328205#328205 ________________________________________________________________________________
Date: Jan 25, 2011
Hi Roger, I am not convinced by your reply. The change to 11:1 was clearly made on purpose as the writer draw a vertical line on the left side of the text to highlight the change. So Rotax clearly says that the compression ratio is now 11:1. The question is: was the previous figure (10.5:1) true or wrong? If it was true, that means they have made a physical modification somewhere. Remi Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328384#328384 ________________________________________________________________________________
Date: Jan 25, 2011
I emailed Rotax and got a reply. It is a typo and nothing more. They just missed it. Chalk it up to a poor proof read. jacking that up from 10.5 to 11.0 would have been a really big deal to them and us. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328392#328392 ________________________________________________________________________________
Date: Jan 25, 2011
Ok, thanks Roger, I suppose they will make a correction on the next edition of this manual. Wait and see! Remi Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328421#328421 ________________________________________________________________________________
Subject: unsteady oil pressure
Date: Jan 25, 2011
The last two flights my oil pressure after hot has begun to jump around. At the top end it is the same as it has always been, at 58 PSI hot. It stays there most of the time but occasionally it will bounce from 49-55-58 and then sit on 58 for a while. I know the senders have a tendency to go bad. Any suggestions of a more durable, cheaper one to use? Any suggestions of any other mechanical problems that would cause the problem. -------- Ron Lee Tucson, Arizona Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328461#328461 ________________________________________________________________________________
Subject: Re: unsteady oil pressure
Date: Jan 25, 2011
Hi Ron, Haven't heard from you in a while. Hope everything is good. I would recommend the new parts for the oil pressure regulation. This could be a gauge issue, but the swings are still close enough not to be. Here are the part numbers for the new Rotax parts. It takes 5 minutes to install. This has stabilized many an oil pressure as that is what it was originally designed for and it may raise your pressure 5 psi or so. I have installed these in at least 20 aircraft. These parts cost about $75 Rotax parts: cap screw 841-983, Spring 838-122, and oil pressure regulator cone 857-230 Stop on by Ryan some time. We all fly at least twice a week and head out for our breakfast runs all over AZ. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328464#328464 ________________________________________________________________________________
Date: Jan 25, 2011
I had a similar problem and it turned out to be bad ground connection. Pete Kitfox III, 912 Leander, TX On 1/25/2011 1:20 PM, ronlee wrote: > --> RotaxEngines-List message posted by: "ronlee" > > The last two flights my oil pressure after hot has begun to jump around. At the top end it is the same as it has always been, at 58 PSI hot. It stays there most of the time but occasionally it will bounce from 49-55-58 and then sit on 58 for a while. I know the senders have a tendency to go bad. Any suggestions of a more durable, cheaper one to use? Any suggestions of any other mechanical problems that would cause the problem. > > -------- > Ron Lee > Tucson, Arizona > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328461#328461 > > ________________________________________________________________________________
From: "Duncan & Ami" <ami-mcfadyean(at)talktalk.net>
Date: Jan 25, 2011
I have 400 hours on one of these: http://www.aircraftspruce.com/catalog/inpages/microflight1000.php although the sensor is 'remotely' mounted. Anyone want to buy an unused Rotax sender?! Duncan McF -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of ronlee Sent: 25 January 2011 19:21 Subject: RotaxEngines-List: unsteady oil pressure The last two flights my oil pressure after hot has begun to jump around. At the top end it is the same as it has always been, at 58 PSI hot. It stays there most of the time but occasionally it will bounce from 49-55-58 and then sit on 58 for a while. I know the senders have a tendency to go bad. Any suggestions of a more durable, cheaper one to use? Any suggestions of any other mechanical problems that would cause the problem. -------- Ron Lee Tucson, Arizona Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328461#328461 ________________________________________________________________________________
Date: Jan 25, 2011
Grounds certainly do cause gauge swings, but usually they are a little wider apart than Ron's. Ron you can try to tighten all the grounds, but I don't think that will cure this, but who knows. Grounds are considered loose until you put a wrench on them. Remember finger tight, wrench loose. I would still put the other Rotax parts in no matter what you find. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328503#328503 ________________________________________________________________________________
Date: Jan 26, 2011
> I would recommend the new parts for the oil pressure regulation. This could be a gauge issue, but the swings are still close enough not to be. Here are the part numbers for the new Rotax parts. It takes 5 minutes to install. This has stabilized many an oil pressure as that is what it was originally designed for and it may raise your pressure 5 psi or so. I have installed these in at least 20 aircraft. These parts cost about $75 < These parts caused my oil pressure to fluctuate all over the place from what was previously a pretty steady indication so I went back to the old original ball /spring which works fine. I guess the old adage of "if it ain't broke ,don't fix it " applies in my case But then I also have a weird 912 Ul of the early 90's vintage . It does lots of things different from anyone else's 912 Dick Maddux Milton,Fl ________________________________________________________________________________
Date: Jan 26, 2011
I put these parts in a 2006 Rotax 912ULS today and the plane has a nice steady 55 psi oil pressure, not to mention another 500 hrs onto the TBO. Rotax parts: cap screw 841-983, Spring 838-122, and oil pressure regulator cone 857-230 -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328647#328647 ________________________________________________________________________________
Date: Jan 27, 2011
Roger, I think this question has been asked before but I couldn't put my finger on it. We have a 914ul in a Europa XS. Is this a desirable upgrade for it...and does it extend the TBO on a 914? Hal Carpenter, Amarillo, TX -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: Wednesday, January 26, 2011 9:54 PM Subject: RotaxEngines-List: Re: unsteady oil pressure I put these parts in a 2006 Rotax 912ULS today and the plane has a nice steady 55 psi oil pressure, not to mention another 500 hrs onto the TBO. Rotax parts: cap screw 841-983, Spring 838-122, and oil pressure regulator cone 857-230 -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328647#328647 ________________________________________________________________________________
Date: Jan 27, 2011
If you are already at 1200 hrs. you don't get any more time. If you are 1000 hrs. you may get 200 hrs more if you qualify. Here is the SB for the 912 and 914. http://legacy.rotax-owner.com/si_tb_info/serviceb/sb-912-041-ul.pdf -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328744#328744 ________________________________________________________________________________
Date: Jan 28, 2011
Subject: Fwd: Photo Booth (Thanks Edna)
____________________________________ Subject: It's a tad long but it's made me laugh.... I'l bet you watch it till the end. . . THIS IS REALLY CUTE!!!: Click on below site.... _http://www.wimp.com/photobooth_ (http://www.wimp.com/photobooth) ________________________________________________________________________________
Subject: rumor I heard
Date: Jan 30, 2011
This is directed to Roger Lee or anyone else who might know. I read the following on another list this morning and would like to know if there is any truth in this. THis is rumor until I see it. There is a kit coming out to reduce the compression ratio of the Rotax 912S from 10.1:1 to something lower. It is rumored that there will be bigger jugs and pistons to try to raise the displacement from just over 1300 CCs to something closer to our 2200 CCs. It will raise the HP from 98 to around 110 HP. More displacement= more torque and less need for high octane gas. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328973#328973 ________________________________________________________________________________
Subject: Re: rumor I heard
Date: Jan 30, 2011
Hi Thom, I have not heard that, but I know just who to ask. I'll keep in touch. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328977#328977 ________________________________________________________________________________
Date: Jan 30, 2011
Subject: Re: Fwd: Photo Booth (Thanks Edna)
CUTE! CUTE AS HELL... I PISSED IN MY PANTS! FUNNY! On Fri, Jan 28, 2011 at 6:06 PM, wrote: > > > ------------------------------ > *Subject:* *It's a tad long but it's made me laugh.... I'l bet you watch > it till the end. . . * > > > THIS IS REALLY CUTE!!!: > > > Click on below site.... > > http://www.wimp.com/photobooth > > > * > > * > > ________________________________________________________________________________
Date: Jan 30, 2011
Hi Thom, Got my email back. Pure BS. Let them run with it and sit back and smile, it's all garbage. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329001#329001 ________________________________________________________________________________
Date: Jan 30, 2011
Thom, That's going to be some trick to accomplish. The bore of a 912 ULS is 84mm (3.31")and the stroke is 61mm (2.40"). Leaving the stroke alone, to ge t a displacement of 2200 cc the bore has to increase to 107mm (4.22"). I don' t think you can get there from here. Rick On Sun, Jan 30, 2011 at 8:19 AM, Thom Riddle wrote: m > > > > This is directed to Roger Lee or anyone else who might know. > > I read the following on another list this morning and would like to know if > there is any truth in this. > > THis is rumor until I see it. > > There is a kit coming out to reduce the compression ratio of the Rotax 91 2S > from > 10.1:1 to something lower. It is rumored that there will be bigger jugs > and > pistons to try to raise the displacement from just over 1300 CCs to > something > closer to our 2200 CCs. > > It will raise the HP from 98 to around 110 HP. > More displacement= more torque and less need for high octane gas. > > -------- > Thom Riddle > Buffalo, NY (9G0) > Kolb Slingshot SS-021 > Jabiru 2200A #1574 > Tennessee Prop 64x32 > > > Don't accept your dog's admiration as conclusive evidence that you are > wonderful.=94 > =97Ann Landers > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328973#328973 > > =========== =========== =========== =========== > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jan 30, 2011
EFI has been in the works for a couple of years. My guess it will be about a $6K option. It is part electronic and part mechanical from what I hear. I hope it comes out this year, but who knows for sure. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329011#329011 ________________________________________________________________________________
Date: Jan 30, 2011
Rick: Companies do some pretty stupid things but this sure sounds like a hoax. If you consider that 1300cc produces 98 HP that is .075HP per cc. With 2200cc @.075 HP/cc you would expect to see something like 165HP but figure something like 75% efficiency so that would be 124 HP. So, where do they get 112 HP? Kind of defeats the purpose? Why do ALL that changing and work for ONLY a 12 HP gain. It would make more sense to increase the compression to gain the HP. Example: a Lycomming went from 150 HP @ 7.5:1 to 160 HP @ 8:1. So there saw a gain of 6.25%. If Rotatx went up ONLY 6.25% that would be 104HP and if they went to 11:1 that would be 110 HP with ONLY a piston change. NOW, these are only paper numbers, there very well could be a greater increase. BUT! Could the cylinders handle it? Barry On Sun, Jan 30, 2011 at 1:04 PM, Richard Girard wrote : > Thom, That's going to be some trick to accomplish. The bore of a 912 ULS is > 84mm (3.31")and the stroke is 61mm (2.40"). Leaving the stroke alone, to get > a displacement of 2200 cc the bore has to increase to 107mm (4.22"). I do n't > think you can get there from here. > > Rick > > On Sun, Jan 30, 2011 at 8:19 AM, Thom Riddle wrote: > >> riddletr(at)gmail.com> >> >> This is directed to Roger Lee or anyone else who might know. >> >> I read the following on another list this morning and would like to know >> if there is any truth in this. >> >> THis is rumor until I see it. >> >> There is a kit coming out to reduce the compression ratio of the Rotax >> 912S from >> 10.1:1 to something lower. It is rumored that there will be bigger jugs >> and >> pistons to try to raise the displacement from just over 1300 CCs to >> something >> closer to our 2200 CCs. >> >> It will raise the HP from 98 to around 110 HP. >> More displacement= more torque and less need for high octane gas. >> >> -------- >> Thom Riddle >> Buffalo, NY (9G0) >> Kolb Slingshot SS-021 >> Jabiru 2200A #1574 >> Tennessee Prop 64x32 >> >> >> Don't accept your dog's admiration as conclusive evidence that you are >> wonderful.=94 >> =97Ann Landers >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=328973#328973 >> >> >> >> >> >> >> >> ========== >> -List" target="_blank"> >> http://www.matronics.com/Navigator?RotaxEngines-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhapp y. > - Groucho Marx > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Subject: 914 partial power failure
Date: Jan 30, 2011
Hello all, I have a 914 fitted to a mono wheel Europa. a couple of weeks ago I suffered a partial power failure on take off and had to land immediately. After changing the fuel filters and cleaning out the carbs she ran fine for three hours and five take offs and then failed again and now has symptom's on ground runs which are:- starts well and runs smooth till 2800ish rpm can be made to go to 5000plus but runs rough and mag drops 600 I have checked the following:- Replaced the whole fuel system except pumps, selector valve and tank fittings but removed and checked them all. Done Rotax fuel flow check at plus 0.5 bar simulated air box pressure giving 10psi fuel pressure and delivering 70litres/hour on each pump. Checked airbox pressure v fuel pressure when engine running 4psi Checked float bowls for dirt, blown out jets, checked needle valves and float level- all appear ok. Checked slide and diaphragm for leaks and smooth operation. Checked all small air pipes for leaks and blockage and carb mounting rubbers for splits. Checked plugs- all look OK with light brown deposits slightly white but am running Avgas at the moment. (she runs the same on Mogas) and swopped the top two plugs with each other at both sides. When run to 5000rpm, airbox pressure rises to 1.1b and fuel increases to 1,4b. TCU lights normal on power up and servo can be heard operating.I will check waste gate arm moving tomorrow. I could use some ideas from the wealth of experience out there. Regards, john. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329052#329052 ________________________________________________________________________________
Date: Jan 31, 2011
Subject: Re: 914 partial power failure
It may very well be in ignition this time, wires mags breaking down, moisture in mags, and even mechanical issues valves floating, sticking etc . . yes I know you had fuel issues too and you looked at the plugs but you may have multiple intermittent problems on multiple systems that are more difficult to isolate. Don't get hungup on any one idea. Keep an open mind and try to force a failure and then isolate that failure. Fix it and then see if there is another problem . . could be. As I said you may have multiple things failing under temp and pressure and then they heal up when the stress is relieved. Make sense? The difficult porblems are also the fun ones. Also don't forget to check carb heat . . . carb icing can cause you to pull your hair out plus it can be damned dangerous. Yeh I know it ain't sposed to happen on take off . . . shit happens though. Do you have the same mag drop on both mags or more on just one mag? Mag drops don't indicate a fuel problem but more of Ignition and or mechanical. Roughness can be fuel, ignition, air or mechanical or worse case . . all of the above. Try to isolate with mag check first as much as possible then use compression test and temperature stress test. By doing these tests, you may see a pattern or a common cylinder that is losing power (loss of power is indicated by a lower temperature hence the CHT temp test or EGT test or both) If you have quad temp like I do, you can analyze it from the cockpit in flight or on the ground . . . what's four temps among friends, right? Don't let multiple intermittent problems confuse you like it does a lot of people. Just because you had a fuel issue doesn't mean you don't still have problems in other systems. Have you had a lot of weather? This is what separates the men from the boys in trouble shooting. You will need to make the culpret(s) break down if possible by putting the engine under stress (load) and temperature. Better on the ground than in the air. You may need to do a compression test after the engine is warmed. Do you know how to do that? Do a comp test early on before getting too deep. A comp test will show valve and ring problems usually unless valves are floating, it won't show that. Is malfunction on same cyls all the time? Run engine up with cowling off under load and high RPM to achieve maximum roughness and then monitor temps of each cylinder as follows. Let engine heat up and then check differential cyl temperature or if you have four egt's record them, is it aircooled? If yes use a temp wand to immediately check temp on all four cyls after shut down or have someone check cyl temps while running under load . . . caution about spinning prop. I don't know if a 914 is aircooled or watercooled. Watercooled is more difficult to trouble shoot by temp. Use temp wand or photopyrometer on individual exhaust pipes if water cooled. You may be able to detect a difference in temp right on the sparkplug. Compare apples to apples, check all top and compare or all bottom and compare. Good luck and let me know . . . Bruce On Sun, Jan 30, 2011 at 9:48 PM, john firth wrote: > firth942(at)btinternet.com> > > Hello all, I have a 914 fitted to a mono wheel Europa. a couple of weeks > ago I suffered a partial power failure on take off and had to land > immediately. After changing the fuel filters and cleaning out the carbs she > ran fine for three hours and five take offs and then failed again and now > has symptom's on ground runs which are:- > starts well and runs smooth till 2800ish rpm > can be made to go to 5000plus but runs rough and mag drops 600 > I have checked the following:- > Replaced the whole fuel system except pumps, selector valve and tank > fittings but removed and checked them all. > Done Rotax fuel flow check at plus 0.5 bar simulated air box pressure > giving 10psi fuel pressure and delivering 70litres/hour on each pump. > Checked airbox pressure v fuel pressure when engine running 4psi > Checked float bowls for dirt, blown out jets, checked needle valves and > float level- all appear ok. > Checked slide and diaphragm for leaks and smooth operation. > Checked all small air pipes for leaks and blockage and carb mounting > rubbers for splits. > Checked plugs- all look OK with light brown deposits slightly white but am > running Avgas at the moment. (she runs the same on Mogas) and swopped the > top two plugs with each other at both sides. > When run to 5000rpm, airbox pressure rises to 1.1b and fuel increases to > 1,4b. > TCU lights normal on power up and servo can be heard operating.I will check > waste gate arm moving tomorrow. > I could use some ideas from the wealth of experience out there. > Regards, john. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329052#329052 > > ________________________________________________________________________________
Date: Jan 31, 2011
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
John=0ADo you have a radiation pyrometer? I have one but maybe a bit far aw ay in =0ADerbyshire. Quick way to check EGT/CHT=0AGraham=0A=0A=0A=0A=0A____ ____________________________=0AFrom: john firth <firth942(at)btinternet.com> =0ATo: rotaxengines-list(at)matronics.com=0ASent: Monday, 31 January, 2011 5:4 8:56=0ASubject: RotaxEngines-List: 914 partial power failure=0A=0A--> Rotax Engines-List message posted by: "john firth" =0A =0AHello all, I have a 914 fitted to a mono wheel Europa. a couple of weeks ago I =0Asuffered a partial power failure on take off and had to land imme diately. After =0Achanging the fuel filters and cleaning out the carbs she ran fine for three =0Ahours and five take offs and then failed again and no w has symptom's on ground =0Aruns which are:-=0Astarts well and runs smooth till 2800ish rpm=0Acan be made to go to 5000plus but runs rough and mag dr ops 600=0AI have checked the following:-=0AReplaced the whole fuel system e xcept pumps, selector valve and tank fittings =0Abut removed and checked th em all.=0ADone Rotax fuel flow check at plus 0.5 bar simulated air box pres sure giving =0A10psi fuel pressure and delivering 70litres/hour on each pum p.=0AChecked airbox pressure v fuel pressure when engine running 4psi=0AChe cked float bowls for dirt, blown out jets, checked needle valves and float =0Alevel- all appear ok.=0AChecked slide and diaphragm for leaks and smooth operation.=0AChecked all small air pipes for leaks and blockage and carb m ounting rubbers for =0Asplits.=0AChecked plugs- all look OK with light brow n deposits slightly white but am =0Arunning Avgas at the moment. (she runs the same on Mogas) and swopped the top =0Atwo plugs with each other at both sides.=0AWhen run to 5000rpm, airbox pressure rises to 1.1b and fuel incre ases to 1,4b.=0ATCU lights normal on power up and servo can be heard operat ing.I will check =0Awaste gate arm moving tomorrow.=0AI could use some idea s from the wealth of experience out there.=0ARegards, john.=0A=0A=0A=0A=0AR ead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php? ======= ________________________________________________________________________________
Date: Jan 31, 2011
Thanks Bruce, I did compression check and got just one cylinder down by 5psi, others at 130psi engine was warm. looks like i need some temp measuring devices but panel on my plane is very full. Cheers, john. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329060#329060 ________________________________________________________________________________
Date: Jan 31, 2011
Hi! John Have you checked that :- a) The choke cable is allowing both levers to return to disused position? b) The ignition grounding hasn=99t any glitches anywhere (intermittent short out through the odd single strand of wire) c) Did you check the electric pump thimble filters for crud.(be very carefull when getting them out to inspect and returning them after since it is impossible to get replacements without buying a new pump!) Regards Bob Harrison G-PTAG From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of GRAHAM SINGLETON Sent: 31 January 2011 08:39 Subject: Re: RotaxEngines-List: 914 partial power failure John Do you have a radiation pyrometer? I have one but maybe a bit far away in Derbyshire. Quick way to check EGT/CHT Graham _____ From: john firth <firth942(at)btinternet.com> Sent: Monday, 31 January, 2011 5:48:56 Subject: RotaxEngines-List: 914 partial power failure Hello all, I have a 914 fitted to a mono wheel Europa. a couple of weeks ago I suffered a partial power failure on take off and had to land immediately. After changing the fuel filters and cleaning out the carbs she ran fine for three hours and five take offs and then failed again and now has symptom's on ground runs which are:- starts well and runs smooth till 2800ish rpm can be made to go to 5000plus but runs rough and mag drops 600 I have checked the following:- Replaced the whole fuel system except pumps, selector valve and tank fittings but removed and checked them all. Done Rotax fuel flow check at plus 0.5 bar simulated air box pressure giving 10psi fuel pressure and delivering 70litres/hour on each pump. Checked airbox pressure v fuel pressure when engine running 4psi Checked float bowls for dirt, blown out jets, checked needle valves and float level- all appear ok. Checked slide and diaphragm for leaks and smooth operation. Checked all small air pipes for leaks and blockage and carb mounting rubbers for splits. Checked plugs- all look OK with light brown deposits slightly white but am running Avgas at the moment. (she runs the same on Mogas) and swopped the top two plugs with each other at both sides. When run to 5000rpm, airbox pressure rises to 1.1b and fuel increases to 1,4b. TCU lights normal on power up and servo can be heard operating.I will check waste gate arm moving tomorrow. I could use some ideas from the wealth of experience out there. Regards, john. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329052#329====== ================== Search <http://forums.matronics.com/viewtopic.php?p=329052#329052> & =========== ________________________________________________________________________________
Date: Jan 31, 2011
John=0A4 EGTs would be good, 2 CHT OK. Do you have an engine monitor?=0AGra ham=0A=0A=0A=0A=0A=0A________________________________=0AFrom: john firth <f irth942(at)btinternet.com>=0ATo: rotaxengines-list(at)matronics.com=0ASent: Monda y, 31 January, 2011 10:21:57=0ASubject: RotaxEngines-List: Re: 914 partial irth942(at)btinternet.com>=0A=0AThanks Bruce, I did compression check and got just one cylinder down by 5psi, =0Aothers at 130psi engine was warm.=0Alook s like i need some temp measuring devices but panel on my plane is very =0A full.=0ACheers, john.=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp: //forums.matronics.com/viewtopic.php?p=329060#329060=0A=0A=0A=0A=0A=0A=0A =================== ________________________________________________________________________________
Date: Jan 31, 2011
Roger Lee wrote: > EFI has been in the works for a couple of years. My guess it will be about a $6K option. It is part electronic and part mechanical from what I hear. I hope it comes out this year, but who knows for sure. Hopefully carbs will still be available and the FI will remain just an option? I'd rather stick with carbs on my next 912. EFI is great until it breaks. Then there's no hope of ever figuring out what's wrong with it or being able to afford the repairs (if it's going to be anything like auto EFI). Carbs are just so much simpler to debug and fix, so I'd rather just stick with em.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329067#329067 ________________________________________________________________________________
Date: Jan 31, 2011
Bob, I have checked the choke levers and they're ok and the thimble filters look clean visually but i could'nt get them out. The pumps are flowing over 100litres an hour each with no back pressure so not too suspicious there and fuel pressure stays good while running up to 5000 rpm 3-4psi above airbox. I am now starting to delve into the wiring. Graham, a radiation pyrometer would be very useful, if I cannot source one nearby I will take you up on your kind offer. Regards, john. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329090#329090 ________________________________________________________________________________
Date: Jan 31, 2011
John, did you get my first response I sent you? I'll resend it to you. They are also called Photopyrometers or infrared temp indicators. You can get them at Harbor Freight and most home suppy stores. You can also find a stick type thermomenter in Martha Stewart ware or your napa auto store. Walmart probably has both types too. It doesn't have to be precise, you are looking for difference as opposed to absolute. Bruce Here is a copy of my first response to you. I pretty much covered all the bases for you, Fule Air, Ignition, Mechanical, if you are interested, I didn't hear back. *b d to rotaxengines-l. * *show details 12:07 AM (12 hours ago) * *It may very well be in ignition this time, wires mags breaking down, moisture in mags, and even mechanical issues valves floating, sticking etc . . yes I know you had fuel issues too and you looked at the plugs but you may have multiple intermittent problems on multiple systems that are more difficult to isolate. Don't get hungup on any one idea. Keep an open mind and try to force a failure and then isolate that failure. Fix it and then see if there is another problem . . could be. As I said you may have multiple things failing under temp and pressure and then they heal up when the stress is relieved. Make sense? The difficult porblems are also the fun ones. Also don't forget to check carb heat . . . carb icing can cause you to pull your hair out plus it can be damned dangerous. Yeh I know it ain't sposed to happen on take off . . . shit happens though. Do you have the same mag drop on both mags or more on just one mag? Mag drops don't indicate a fuel problem but more of Ignition and or mechanical. Roughness can be fuel, ignition, air or mechanical or worse case . . all of the above. Try to isolate with mag check first as much as possible then use compression test and temperature stress test. By doing these tests, you may see a pattern or a common cylinder that is losing power (loss of power is indicated by a lower temperature hence the CHT temp test or EGT test or both) If you have quad temp like I do, you can analyze it from the cockpit in flight or on the ground . . . what's four temps among friends, right? Don't let multiple intermittent problems confuse you like it does a lot of people. Just because you had a fuel issue doesn't mean you don't still have problems in other systems. Have you had a lot of weather? This is what separates the men from the boys in trouble shooting. You will need to make the culpret(s) break down if possible by putting the engine under stress (load) and temperature. Better on the ground than in the air. You may need to do a compression test after the engine is warmed. Do you know how to do that? Do a comp test early on before getting too deep. A comp test will show valve and ring problems usually unless valves are floating, it won't show that. Is malfunction on same cyls all the time? Run engine up with cowling off under load and high RPM to achieve maximum roughness and then monitor temps of each cylinder as follows. Let engine heat up and then check differential cyl temperature or if you have four egt's record them, is it aircooled? If yes use a temp wand to immediately check temp on all four cyls after shut down or have someone check cyl temps while running under load . . . caution about spinning prop. I don't know if a 914 is aircooled or watercooled. Watercooled is more difficult to trouble shoot by temp. Use temp wand or photopyrometer on individual exhaust pipes if water cooled. You may be able to detect a difference in temp right on the sparkplug. Compare apples to apples, check all top and compare or all bottom and compare. Good luck and let me know . . . Bruce* * * On Mon, Jan 31, 2011 at 9:42 AM, john firth wrote: > firth942(at)btinternet.com> > > Bob, I have checked the choke levers and they're ok and the thimble filters > look clean visually but i could'nt get them out. The pumps are flowing over > 100litres an hour each with no back pressure so not too suspicious there and > fuel pressure stays good while running up to 5000 rpm 3-4psi above airbox. > I am now starting to delve into the wiring. > Graham, a radiation pyrometer would be very useful, if I cannot source one > nearby I will take you up on your kind offer. > Regards, john. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329090#329090 > > ________________________________________________________________________________
Date: Jan 31, 2011
Hello Bruce, I did respond but got a undeliverable mail message from postmaster. anyway here is a copy :- Thanks Bruce, I did compression check and got just one cylinder down by 5psi, others at 130psi engine was warm. looks like i need some temp measuring devices but panel on my plane is very full.-: Also Graham Singleton has offered to lend me his. Regards, john. > John, did you get my first response I sent you? I'll resend it to you. > They are also called Photopyrometers or infrared temp indicators. You can get them at Harbor Freight and most home suppy stores. You can also find a stick type thermomenter in Martha Stewart ware or your napa auto store. Walmart probably has both types too. It doesn't have to be precise, you are looking for difference as opposed to absolute. > > Bruce > > > Here is a copy of my first response to you. I pretty much covered all the bases for you, Fule Air, Ignition, Mechanical, if you are interested, I didn't hear back. > > b d to rotaxengines-l. > show details 12:07 AM (12 hours ago) > > It may very well be in ignition this time, wires mags breaking down, moisture in mags, and even mechanical issues valves floating, sticking etc . . yes I know you had fuel issues too and you looked at the plugs but you may have multiple intermittent problems on multiple systems that are more difficult to isolate. Don't get hungup on any one idea. Keep an open mind and try to force a failure and then isolate that failure. Fix it and then see if there is another problem . . could be. As I said you may have multiple things failing under temp and pressure and then they heal up when the stress is relieved. Make sense? The difficult porblems are also the fun ones. > > Also don't forget to check carb heat . . . carb icing can cause you to pull your hair out plus it can be damned dangerous. Yeh I know it ain't sposed to happen on take off . . . shit happens though. > > Do you have the same mag drop on both mags or more on just one mag? Mag drops don't indicate a fuel problem but more of Ignition and or mechanical. Roughness can be fuel, ignition, air or mechanical or worse case . . all of the above. Try to isolate with mag check first as much as possible then use compression test and temperature stress test. By doing these tests, you may see a pattern or a common cylinder that is losing power (loss of power is indicated by a lower temperature hence the CHT temp test or EGT test or both) If you have quad temp like I do, you can analyze it from the cockpit in flight or on the ground . . . what's four temps among friends, right? > > Don't let multiple intermittent problems confuse you like it does a lot of people. Just because you had a fuel issue doesn't mean you don't still have problems in other systems. Have you had a lot of weather? This is what separates the men from the boys in trouble shooting. You will need to make the culpret(s) break down if possible by putting the engine under stress (load) and temperature. Better on the ground than in the air. You may need to do a compression test after the engine is warmed. Do you know how to do that? Do a comp test early on before getting too deep. A comp test will show valve and ring problems usually unless valves are floating, it won't show that. > > Is malfunction on same cyls all the time? Run engine up with cowling off under load and high RPM to achieve maximum roughness and then monitor temps of each cylinder as follows. Let engine heat up and then check differential cyl temperature or if you have four egt's record them, is it aircooled? If yes use a temp wand to immediately check temp on all four cyls after shut down or have someone check cyl temps while running under load . . . caution about spinning prop. I don't know if a 914 is aircooled or watercooled. Watercooled is more difficult to trouble shoot by temp. Use temp wand or photopyrometer on individual exhaust pipes if water cooled. You may be able to detect a difference in temp right on the sparkplug. Compare apples to apples, check all top and compare or all bottom and compare. > > Good luck and let me know . . . > Bruce > > On Mon, Jan 31, 2011 at 9:42 AM, john firth wrote: > > > Bob, I have checked the choke levers and they're ok and the thimble filters look clean visually but i could'nt get them out. The pumps are flowing over 100litres an hour each with no back pressure so not too suspicious there and fuel pressure stays good while running up to 5000 rpm 3-4psi above airbox. > I am now starting to delve into the wiring. > Graham, a radiation pyrometer would be very useful, if I cannot source one nearby I will take you up on your kind offer. > Regards, john. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329090#329090 > > > > > > > > ============= gines-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List ============= lank">http://forums.matronics.com ============= Dralle, List Admin. get="_blank">http://www.matronics.com/contribution ============ > > > > > > > > ________________________________________________________________________________
Date: Jan 31, 2011
with the right temptation you might entice me towards Burn airfield, is ot =0Anearer than Sherburn in Elmet?=0AHaven't seen any of those people in 20 years!=0AGraham=0A=0A=0A=0A=0A________________________________=0AFrom: john firth =0ATo: rotaxengines-list(at)matronics.com=0ASe nt: Monday, 31 January, 2011 17:42:38=0ASubject: RotaxEngines-List: Re: 914 firth" =0A=0ABob, I have checked the choke levers and they're ok and the thimble filters look =0Aclean visually but i could'n t get them out. The pumps are flowing over 100litres =0Aan hour each with n o back pressure so not too suspicious there and fuel pressure =0Astays good while running up to 5000 rpm 3-4psi above airbox.=0AI am now starting to d elve into the wiring.=0AGraham, a radiation pyrometer would be very useful, if I cannot source one =0Anearby I will take you up on your kind offer.=0A Regards, john.=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forum ================= ________________________________________________________________________________
Date: Jan 31, 2011
Hello Graham, not much difference in distance between Burn and Sherburn from yours. My aircraft is actually at Barnsley at the moment. I will give you a call when I know my movements this next few days but I am working until saturday. Regards, john. On 31 Jan 2011, at 23:38, GRAHAM SINGLETON wrote: > with the right temptation you might entice me towards Burn airfield, is ot nearer than Sherburn in Elmet? > Haven't seen any of those people in 20 years! > Graham > > From: john firth <firth942(at)btinternet.com> > To: rotaxengines-list(at)matronics.com > Sent: Monday, 31 January, 2011 17:42:38 > Subject: RotaxEngines-List: Re: 914 partial power failure > > > Bob, I have checked the choke levers and they're ok and the thimble filters look clean visually but i could'nt get them out. The pumps are flowing over 100litres an hour each with no back pressure so not too suspicious there and fuel pressure stays good while running up to 5000 rpm 3-4psi above airbox. > I am now starting to delve into the wiring. > Graham, a radiation pyrometer would be very useful, if I cannot source one nearby I will take you up on your kind offer. > Regards, john. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329090#3290====== ==================http://forums.matron ics.comhttp://ww==================== == > > > > > > > ________________________________________________________________________________
Date: Jan 31, 2011
As much as I like carbs I always thought the EFI was easier to work on... Each part can be individually tested and or replaced. I've even been able to replace coils in Chev Cavalier ECUs. With the EFI it works yes or works no... If it works maybe then the problem is wiring. Carbs can require a lot more tinkering and when you get them to work they impart a feeling of accomplishment. Noel -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of lucien Sent: January 31, 2011 10:12 AM Subject: RotaxEngines-List: Re: rumor I heard Roger Lee wrote: > EFI has been in the works for a couple of years. My guess it will be about a $6K option. It is part electronic and part mechanical from what I hear. I hope it comes out this year, but who knows for sure. Hopefully carbs will still be available and the FI will remain just an option? I'd rather stick with carbs on my next 912. EFI is great until it breaks. Then there's no hope of ever figuring out what's wrong with it or being able to afford the repairs (if it's going to be anything like auto EFI). Carbs are just so much simpler to debug and fix, so I'd rather just stick with em.... LS -------- LS Titan II SS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329067#329067 ________________________________________________________________________________
Date: Feb 01, 2011
My oil pressure was 38-42 at 5200 RPM. Actually, it was less at higher rpm's. I just installed the parts Roger recommended and was pleased with the result. A pretty solid 55psi overall. It was 13degF when I tried it today and I was startled when the startup pressure was 83psi. This went down below 65 by the time it got to 120deg. Caused me to recheck the op manual. Thanks Roger. -------- Rich Little N812RL S-7 912ULS North Idaho Kiev Prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329167#329167 ________________________________________________________________________________
Date: Feb 01, 2011
Monitoring Oil Pressure as well as Oil Temperature should be one of a pilots main concerns. On Cold Days, On Start Up you will ALWAYS see high oil pressure. If you don't you either did a real good job on Pre-Heat or you have something wrong. Each plane and engine has small differences but the Rules of Thumb are: 1. Cold Conditions = High Oil Pressure and Low Oil Temperatures. 2. Hot Conditions = Low Oil Pressure and High Oil Temperatures. 3. If you see High Oil Pressure and High Oil Temperatures - Something is wrong - One of the two gages is bad. More than likely the Oil Temperature Gage. 4. If you see Low Oil Pressure and High Oil Temperatures - LAND - You have something REALLY wrong. Compare your CHT's. This will help you determine your PUCKER FACTOR. 5. If you see Low Oil Pressure and Low Oil Temperatures - You forgot to put oil in your dry engine. Check your oil and gages. 6. Rule to remember: As Temperature - CHT, EGT, OAT and Oil Goes UP the Oil Pressure will go DOWN. How much it goes down YOU have to learn you plane. Barry On Tue, Feb 1, 2011 at 5:53 AM, Rich L wrote: > > My oil pressure was 38-42 at 5200 RPM. Actually, it was less at higher > rpm's. I just installed the parts Roger recommended and was pleased with > the result. A pretty solid 55psi overall. It was 13degF when I tried it > today and I was startled when the startup pressure was 83psi. This went down > below 65 by the time it got to 120deg. Caused me to recheck the op manual. > Thanks Roger. > > -------- > Rich Little > N812RL S-7 912ULS > North Idaho > Kiev Prop > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329167#329167 > > ________________________________________________________________________________
Date: Feb 01, 2011
I wouldn't believe the static compression test I've seen them lie too many times.. Best to do a differential test. Noel From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of john firth Sent: January 31, 2011 7:28 PM Subject: Re: RotaxEngines-List: Re: 914 partial power failure Hello Bruce, I did respond but got a undeliverable mail message from postmaster. anyway here is a copy :- Thanks Bruce, I did compression check and got just one cylinder down by 5psi, others at 130psi engine was warm. looks like i need some temp measuring devices but panel on my plane is very full.-: Also Graham Singleton has offered to lend me his. Regards, john. John, did you get my first response I sent you? I'll resend it to you. They are also called Photopyrometers or infrared temp indicators. You can get them at Harbor Freight and most home suppy stores. You can also find a stick type thermomenter in Martha Stewart ware or your napa auto store. Walmart probably has both types too. It doesn't have to be precise, you are looking for difference as opposed to absolute. Bruce Here is a copy of my first response to you. I pretty much covered all the bases for you, Fule Air, Ignition, Mechanical, if you are interested, I didn't hear back. b d to rotaxengines-l. show details 12:07 AM (12 hours ago) It may very well be in ignition this time, wires mags breaking down, moisture in mags, and even mechanical issues valves floating, sticking etc . . yes I know you had fuel issues too and you looked at the plugs but you may have multiple intermittent problems on multiple systems that are more difficult to isolate. Don't get hungup on any one idea. Keep an open mind and try to force a failure and then isolate that failure. Fix it and then see if there is another problem . . could be. As I said you may have multiple things failing under temp and pressure and then they heal up when the stress is relieved. Make sense? The difficult porblems are also the fun ones. Also don't forget to check carb heat . . . carb icing can cause you to pull your hair out plus it can be damned dangerous. Yeh I know it ain't sposed to happen on take off . . . shit happens though. Do you have the same mag drop on both mags or more on just one mag? Mag drops don't indicate a fuel problem but more of Ignition and or mechanical. Roughness can be fuel, ignition, air or mechanical or worse case . . all of the above. Try to isolate with mag check first as much as possible then use compression test and temperature stress test. By doing these tests, you may see a pattern or a common cylinder that is losing power (loss of power is indicated by a lower temperature hence the CHT temp test or EGT test or both) If you have quad temp like I do, you can analyze it from the cockpit in flight or on the ground . . . what's four temps among friends, right? Don't let multiple intermittent problems confuse you like it does a lot of people. Just because you had a fuel issue doesn't mean you don't still have problems in other systems. Have you had a lot of weather? This is what separates the men from the boys in trouble shooting. You will need to make the culpret(s) break down if possible by putting the engine under stress (load) and temperature. Better on the ground than in the air. You may need to do a compression test after the engine is warmed. Do you know how to do that? Do a comp test early on before getting too deep. A comp test will show valve and ring problems usually unless valves are floating, it won't show that. Is malfunction on same cyls all the time? Run engine up with cowling off under load and high RPM to achieve maximum roughness and then monitor temps of each cylinder as follows. Let engine heat up and then check differential cyl temperature or if you have four egt's record them, is it aircooled? If yes use a temp wand to immediately check temp on all four cyls after shut down or have someone check cyl temps while running under load . . . caution about spinning prop. I don't know if a 914 is aircooled or watercooled. Watercooled is more difficult to trouble shoot by temp. Use temp wand or photopyrometer on individual exhaust pipes if water cooled. You may be able to detect a difference in temp right on the sparkplug. Compare apples to apples, check all top and compare or all bottom and compare. Good luck and let me know . . . Bruce On Mon, Jan 31, 2011 at 9:42 AM, john firth wrote: Bob, I have checked the choke levers and they're ok and the thimble filters look clean visually but i could'nt get them out. The pumps are flowing over 100litres an hour each with no back pressure so not too suspicious there and fuel pressure stays good while running up to 5000 rpm 3-4psi above airbox. I am now starting to delve into the wiring. Graham, a radiation pyrometer would be very useful, if I cannot source one nearby I will take you up on your kind offer. Regards, john. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329090#329090 ============= gines-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List ============= lank">http://forums.matronics.com ============= Dralle, List Admin. get="_blank">http://www.matronics.com/contribution ============= D======================== ========= D======================== ========= D======================== ========= D======================== ========= ________________________________________________________________________________
Date: Feb 02, 2011
I agree with Noel. A static compression test is fine for an automobile, but not an aircraft engine. Rotax wants a differential leak test, and that's what the A&Ps also want to see to help solve your problem. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329332#329332 ________________________________________________________________________________
Subject: Valve Spring Retainer Tool Loan
Date: Feb 02, 2011
Hi All, I have a 912S that needs the (new valve spring retainer) SB 912-022 done. There are a couple of different types of tools that are needed to compress the springs to remove the rockers and retainers etc. I was wondering if anyone has these or know where I can rent or borrow them. One style costs $541.00 USD new and not sure of the alternate one that I found on the net. It was a simple bar bolted to the head and a piece that is shaped like the two retainers side by side and can be connected to a 3/8" breaker bar as a lever, the valves being held in place with cord packed into the cylinder through a spark plug hole. Any thoughts or ideas from anyone. Thank you in advance for any help available. Troy Maynor Europa Monowheel Classic 912S Warp Drive Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329358#329358 ________________________________________________________________________________
Subject: Re: Happy First Flight Day
Date: Feb 02, 2011
Their historic flight was actually in 1903. Troy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329360#329360 ________________________________________________________________________________
Date: Feb 02, 2011
Differential are fine, and isolate a problem if there is one but dynamic tests, which are what auto test are, is better than doing nothing and will give one a pass or fail real quick. They work fine and are acceptable for a quick test to see if there is a problem or not. I carry one with me because no compressed air is needed in the boonies. I'm an old A&P. More information is better than less. Bruce On Wed, Feb 2, 2011 at 12:55 PM, rampil wrote: > > I agree with Noel. > > A static compression test is fine for an automobile, but not > an aircraft engine. Rotax wants a differential leak test, and that's what > the A&Ps also want to see to help solve your problem. > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329332#329332 > > ________________________________________________________________________________
Date: Feb 03, 2011
So it is writen, must be true ________________________________________________________________________________
Subject: Re: Valve Spring Retainer Tool Loan
Date: Feb 03, 2011
Troy Maynor wrote: > ... the alternate one that I found on the net. It was a simple bar bolted to the head and a piece that is shaped like the two retainers side by side and can be connected to a 3/8" breaker bar as a lever, the valves being held in place with cord packed into the cylinder through a spark plug hole.... Troy, the alternate method worked fine for me about ten years ago. The tool and the rope came with the new retainers. =Don Maxwell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329440#329440 ________________________________________________________________________________
Subject: JBM Rubber Carburetor Sockets For 912?
Date: Feb 03, 2011
Has anyone used the rubber flange type carburetor sockets for the Rotax 912 engines using the Bing model 64 carburetors made by JBM Industries in Kent, Ohio? These sockets are made in the USA and are considerably less money than the Rotax sockets (big surprise). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329463#329463 ________________________________________________________________________________
Date: Feb 03, 2011
Subject: Re: JBM Rubber Carburetor Sockets For 912?
On 09:45 AM 2/3/2011, Goodone wrote: >Has anyone used the rubber flange type carburetor sockets for the Rotax 912 engines using the Bing model 64 carburetors made by JBM Industries in Kent, Ohio? These sockets are made in the USA and are considerably less money than the Rotax sockets (big surprise). I have not used their 912 sockets, but have used al their 2-stroke sockets. Those are MUCH better than the Rotax ones, and last a long long time. -- Bob Comperini e-mail: bob@fly-ul.com WWW: http://www.fly-ul.com ________________________________________________________________________________
Date: Feb 03, 2011
I use JBM "rubber" parts on all my Rotax and HKS engines (same as 912 sockets). Their formulation seems to resist hardening and cracking better than Rotax parts. Nice folks to deal with, too. Rick Girard On Thu, Feb 3, 2011 at 11:45 AM, Goodone wrote: > > Has anyone used the rubber flange type carburetor sockets for the Rotax 912 > engines using the Bing model 64 carburetors made by JBM Industries in Kent, > Ohio? These sockets are made in the USA and are considerably less money than > the Rotax sockets (big surprise). > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329463#329463 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 03, 2011
I use JBM sockets. They are very good quality and much more sturdy than the Rotax sockets. I have had several failures of Rotax $102.00 sockets, ( 4 to be exact ) and none with the JBM sockets. --- On Thu, 2/3/11, Goodone wrote: > From: Goodone <goodone41(at)verizon.net> > Subject: RotaxEngines-List: JBM Rubber Carburetor Sockets For 912? > To: rotaxengines-list(at)matronics.com > Date: Thursday, February 3, 2011, 9:45 AM > --> RotaxEngines-List message > posted by: "Goodone" > > Has anyone used the rubber flange type carburetor sockets > for the Rotax 912 engines using the Bing model 64 > carburetors made by JBM Industries in Kent, Ohio? These > sockets are made in the USA and are considerably less money > than the Rotax sockets (big surprise). > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329463#329463 > > > > > > > > RotaxEngines-List Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Feb 04, 2011
The JBM Sockets are TOP QUALITY parts. I've been using them for a number of years and to date I've had no failures. Cant say that about the Rotax Factory parts. Rick -------- 701Driver N35 26.700, W118 16.743 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329575#329575 ________________________________________________________________________________
Date: Feb 05, 2011
Thanks for the information. Sure sounds like JBM is the way to go! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329733#329733 ________________________________________________________________________________
Subject: Cracks in Crankcase
Date: Feb 06, 2011
Has anyone heard of the Crankcase cracking on a 912uls? SB-912-029 makes it sound like it can easily happen. Or is that CYA? -------- Rich Little N812RL S-7 912ULS North Idaho Kiev Prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329884#329884 ________________________________________________________________________________
Subject: Re: Cracks in Crankcase
Date: Feb 06, 2011
Hi Rich, Maybe a little CYA, plus in includes some people that don't follow Rotax engine maint. recommendations, inspections or use after market parts and maybe even a few that want to use baling wire to hold things on. [Laughing] I have not personally seen a cracked crankcase, but I'm sure it would not have been posted by Rotax unless something had happened. I sounds as if it is fairly rare, but something they wanted people to take notice about. I don't think I would be alarmed especially if you follow Rotax instructions. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329886#329886 ________________________________________________________________________________
Date: Feb 07, 2011
> Has anyone heard of the Crankcase cracking on a 912uls? SB-912-029 makes it sound like it can easily happen. Or is that CYA?< I heard about this happening in one of my recent 912 classes. Apparently too much pitch on the prop can over load earlier cases and create stresses leading to case cracking thus the min 5200 static (WOT) Rotax calls for in their bulletin. Dick Maddux Milton ,Fl ________________________________________________________________________________
From: Joe and Joan Kimbell <jnjkimbell(at)hotmail.com>
Subject: ethanol
Date: Feb 07, 2011
Appreciate some info concerning fuel seperation. I have CH701 with the 100 hp riotax. I live in a high humedity area and have not been flying much la tely. I use 10% ethanol fuel and last time I started to fly (fuel had bee n in A/C over a month) and checked the lowest drain=2C I found cloudy fuel =2C not water=2C but did not lood good. I continued to drain fuel until it was clear=2C probably a half an ounce. Was this cloudy fuel on the point o f seperation? I did go ahead and fly with no problems=2C but after thinkin g about it=2C what would the list's ideas be. Very glad it kept running=2C though an both tanks the fuel seemed to come out of only one tank. No ext ernal fuel pump. Gravity feed. =========== =========== =========== > > > ________________________________________________________________________________
Date: Feb 07, 2011
Hi Dick, Now that you mention that I do remember them talking about that in class. Just another good reason for people to follow Rotax recommendations and not branch out on their own and experiment. Rotax has many thousands of hours of experience and knowledge from a world's worth of 912's and 20 years of time not to mention their own testing. I think I'll defer to their wisdom and and keep my engine strong right up to TBO and beyond. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329964#329964 ________________________________________________________________________________
Date: Feb 07, 2011
Subject: Re: ethanol
Joe: There are a few things that would cause your fuel to go cloudy: Contamination in the tank. Hygroscopic action of the alcohol Temperature (low) causing the water to freeze Being that you found only 1/2 ounce I would also consider: The drain plugs as being contaminated due to oxidation How clean was the inspection tube that you were using When you say 'separation', are you referring to the water separating out from the fuel due to saturation? If yes, then YES you could be seeing the water above what the alcohol would hold in suspension. A 1/2 ounce... I would not worry about. But why use gas with ethanol - Do the separation procedure that has been discussed here on line and you will reduce the chances of water. Barry On Mon, Feb 7, 2011 at 10:10 AM, Joe and Joan Kimbell < jnjkimbell(at)hotmail.com> wrote: > Appreciate some info concerning fuel seperation. I have CH701 with the > 100hp riotax. I live in a high humedity area and have not been flying much > lately. I use 10% ethanol fuel and last time I started to fly (fuel had > been in A/C over a month) and checked the lowest drain, I found cloudy fuel, > not water, but did not lood good. I continued to drain fuel until it was > clear, probably a half an ounce. Was this cloudy fuel on the point of > seperation? I did go ahead and fly with no problems, but after thinking > about it, what would the list's ideas be. Very glad it kept running, though > an both tanks the fuel seemed to come out of only one tank. No external > fuel pump. Gravity feed. > > ========= > > > > > > > > * > > * > > ________________________________________________________________________________
Date: Feb 07, 2011
I too remember reading Rotax 912 information about dragging the engine down by over propping as being the cause of cracking crankcases. I believe the MINIMUM required on wide open throttle is 5400 rpm. I believe some have a tendency to want to run our engines at lower rpm then they were designed for. Maybe we feel they Will burn less fuel and or last longer. If anyone has different info please post. -------- Ron Lee Tucson, Arizona Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330023#330023 ________________________________________________________________________________
Subject: ethanol
Date: Feb 07, 2011
Barry=2C Sorry=2C I meant to say one half pint. Have no idea what Hygroscop ic action means. Live in central FL and keep A/C in hangar. Un likly temp ever went down to 32 in hangar. Yes=2C I mean separating due to saturation . I am aware of the separation discussed and felt that someone who had don e this would know if there was a period of cloudy looking just prior to sep aration. Thanks=2C Joe Date: Mon=2C 7 Feb 2011 12:59:23 -0500 Subject: Re: RotaxEngines-List: ethanol From: flyadive(at)gmail.com Joe: There are a few things that would cause your fuel to go cloudy: Contamination in the tank. Hygroscopic action of the alcohol Temperature (low) causing the water to freeze Being that you found only 1/2 ounce I would also consider: The drain plugs as being contaminated due to oxidation How clean was the inspection tube that you were using When you say 'separation'=2C are you referring to the water separating out from the fuel due to saturation? If yes=2C then YES you could be seeing th e water above what the alcohol would hold in suspension. A 1/2 ounce... I would not worry about. But why use gas with ethanol - Do the separation procedure that has been discussed here on line and you will reduce the chances of water. Barry On Mon=2C Feb 7=2C 2011 at 10:10 AM=2C Joe and Joan Kimbell wrote: Appreciate some info concerning fuel seperation. I have CH701 with the 100 hp riotax. I live in a high humedity area and have not been flying much la tely. I use 10% ethanol fuel and last time I started to fly (fuel had bee n in A/C over a month) and checked the lowest drain=2C I found cloudy fuel =2C not water=2C but did not lood good. I continued to drain fuel until it was clear=2C probably a half an ounce. Was this cloudy fuel on the point o f seperation? I did go ahead and fly with no problems=2C but after thinkin g about it=2C what would the list's ideas be. Very glad it kept running=2C though an both tanks the fuel seemed to come out of only one tank. No ext ernal fuel pump. Gravity feed. ========= > > > ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 07, 2011
Joe: A half pint is only 8 ounces... Not much in the scheme of things. What does concern me is the cloudiness. When I was renting I have drained over a gallon from one wing. And then I kept draining a second gallon just to make sure. I gave ALL of it back to the FBO :-) BUT - None of it was cloudy. How did you seal the tank? What material did you use? >From what you say Temps are not your problem. I would Drain ALL the fuel. Strain it through some cheese cloth as you drain to see if there are any contaminates Remove the sump drains Inspect them for corrosion and proper height when fitted into the sump drain threads Flush the tank You can use water followed by a rinse with gas. Since you use MoGas I'd bet dollars to donuts that you did not filter the gas prior to, or while filling the tank. Not knowing what you put in... Only leads to not knowing where the contamination comes from. Separation due to saturation would only reveal WATER. As long as the gas was clean to start with and there is no contamination from the tank. Barry ________________________________________________________________________________
Subject: ethanol
Date: Feb 07, 2011
You can get cloudy looking fuel if you used additives in your fuel. Some things when mixed with water will cloud up when agitated, It's possible that the stuff sank with the water into your sump. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE Sent: Monday, February 07, 2011 5:35 PM Subject: Re: RotaxEngines-List: ethanol Joe: A half pint is only 8 ounces... Not much in the scheme of things. What does concern me is the cloudiness. When I was renting I have drained over a gallon from one wing. And then I kept draining a second gallon just to make sure. I gave ALL of it back to the FBO :-) BUT - None of it was cloudy. How did you seal the tank? What material did you use? >From what you say Temps are not your problem. I would Drain ALL the fuel. Strain it through some cheese cloth as you drain to see if there are any contaminates Remove the sump drains Inspect them for corrosion and proper height when fitted into the sump drain threads Flush the tank You can use water followed by a rinse with gas. Since you use MoGas I'd bet dollars to donuts that you did not filter the gas prior to, or while filling the tank. Not knowing what you put in... Only leads to not knowing where the contamination comes from. Separation due to saturation would only reveal WATER. As long as the gas was clean to start with and there is no contamination from the tank. Barry ________________________________________________________________________________
Subject: Re: 912ULS integrated alternator question
Date: Feb 07, 2011
Last time up i had a low voltage warning light show on the ems. low end threshold of 12v. it seemed to only appear when i keyed the radio mic and / or cycled the elec fuel pump on. took me a while to realize the correlation here. from this thread it would seem to be a blown regulator.. i have not had a chance to go in with a volt meter and check for voltage to the reg. the plane was up for almost 2 hrs in this condition. no warning light but for when using radio which is really the only draw other then the ems. seemed to be getting worse to the end of the flight so proly battery was getting down...Q= will engine continue to run with dead battery, assuming the generator fields are working? will engine run without generator but a full battery? i use a photo cell charger to keep battery topped up between flights so always had full charge to start. battery is 2 years old and only fair condition, on schedule to be replaced. question... am i on the right track... what is the problem with the master/alternator switch off sequence... one first then the other and what happens if wrong one is switche first..? -------- Ross Aalexander: CH701 driver 912ul 450tt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330079#330079 ________________________________________________________________________________
Subject: ethanol
Date: Feb 07, 2011
If you really, really have to fly on ethanol fuel then you have already broken the first cardinal rule. Never leave fuel in your plane for an extended period of time. If you have high humidity, as you said, it will absorb some of the moisture and when that happens it, not only gets closer to a phase separation but becomes very corrosive.... It may eat your tanks if they are anything but stainless steel. It will probably start to eat your fuel system including the carb body and the fuel lines. Best not to leave it in the plane and only fly on fresh fuel. BTW you will know when you have a phase separation happening... you will get something just over 10% of the quantity of fuel in your tank showing up as water. So if you have left say 15 gal of fuel in your plane then if it separates you will get 1.5 gallons of water/ethanol solution (mostly water) hitting your carb or injectors. A little good news is if you are using a paper filter it will try to block the water from passing... unfortunately there won't be anything else but water to pass. The milky substance you did find is probably something the ethanol started to eat. The second point is as Barry mentioned remove the ethanol form your fuel by adding enough water to cause a phase separation. Then siphon the clear ethanol free gas off the top of the water ethanol solution that will form on the bottom of the container. Be careful though, to let the gas sit for about twenty minutes so all the water can settle out before siphoning the gas. And always use a good chamois or felt to strain your gas... either of those products will pass gas but not water. If you remove the ethanol from your fuel then it won't hurt to leave the gas in your plane between flights for periods of up to I guess a month or so. Noel From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE Sent: February 7, 2011 2:29 PM Subject: Re: RotaxEngines-List: ethanol Joe: There are a few things that would cause your fuel to go cloudy: Contamination in the tank. Hygroscopic action of the alcohol Temperature (low) causing the water to freeze Being that you found only 1/2 ounce I would also consider: The drain plugs as being contaminated due to oxidation How clean was the inspection tube that you were using When you say 'separation', are you referring to the water separating out from the fuel due to saturation? If yes, then YES you could be seeing the water above what the alcohol would hold in suspension. A 1/2 ounce... I would not worry about. But why use gas with ethanol - Do the separation procedure that has been discussed here on line and you will reduce the chances of water. Barry On Mon, Feb 7, 2011 at 10:10 AM, Joe and Joan Kimbell wrote: Appreciate some info concerning fuel seperation. I have CH701 with the 100hp riotax. I live in a high humedity area and have not been flying much lately. I use 10% ethanol fuel and last time I started to fly (fuel had been in A/C over a month) and checked the lowest drain, I found cloudy fuel, not water, but did not lood good. I continued to drain fuel until it was clear, probably a half an ounce. Was this cloudy fuel on the point of seperation? I did go ahead and fly with no problems, but after thinking about it, what would the list's ideas be. Very glad it kept running, though an both tanks the fuel seemed to come out of only one tank. No external fuel pump. Gravity feed. ========= > > > ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: ethanol
Date: Feb 08, 2011
GENTLEMEN: Thank you for your input. I have found a source for 90 oct. et hanol free fuel for about 50 cents a gal. over pump price. sounds like a g ood deal to me. After following all of the excellent suggestions. I am sw itching to the ethanol free fuel. Wish it was available for everyone. T hanks again=2C Joe From: noelloveys(at)yahoo.ca Subject: RE: RotaxEngines-List: ethanol Date: Mon=2C 7 Feb 2011 22:53:28 -0330 If you really=2C really have to fly on ethanol fuel then you have already b roken the first cardinal rule. Never leave fuel in your plane for an exten ded period of time. If you have high humidity=2C as you said=2C it will a bsorb some of the moisture and when that happens it=2C not only gets closer to a phase separation but becomes very corrosive.... It may eat your tank s if they are anything but stainless steel. It will probably start to eat your fuel system including the carb body and the fuel lines. Best not to l eave it in the plane and only fly on fresh fuel. BTW you will know when yo u have a phase separation happening... you will get something just over 10 % of the quantity of fuel in your tank showing up as water. So if you have left say 15 gal of fuel in your plane then if it separates you will get 1. 5 gallons of water/ethanol solution (mostly water) hitting your carb or inj ectors. A little good news is if you are using a paper filter it will try to block the water from passing... unfortunately there won=92t be anything else but water to pass. The milky substance you did find is probably some thing the ethanol started to eat. The second point is as Barry mentioned remove the ethanol form your fuel by adding enough water to cause a phase separation. Then siphon the clear et hanol free gas off the top of the water ethanol solution that will form on the bottom of the container. Be careful though=2C to let the gas sit for a bout twenty minutes so all the water can settle out before siphoning the ga s. And always use a good chamois or felt to strain your gas... either of those products will pass gas but not water. If you remove the ethanol from your fuel then it won=92t hurt to leave the gas in your plane between flig hts for periods of up to I guess a month or so. Noel From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengin es-list-server(at)matronics.com] On Behalf Of FLYaDIVE Sent: February 7=2C 2011 2:29 PM Subject: Re: RotaxEngines-List: ethanol Joe: There are a few things that would cause your fuel to go cloudy: Contamination in the tank. Hygroscopic action of the alcohol Temperature (low) causing the water to freeze Being that you found only 1/2 ounce I would also consider: The drain plugs as being contaminated due to oxidation How clean was the inspection tube that you were using When you say 'separation'=2C are you referring to the water separating out from the fuel due to saturation? If yes=2C then YES you could be seeing th e water above what the alcohol would hold in suspension. A 1/2 ounce... I would not worry about. But why use gas with ethanol - Do the separation procedure that has been discussed here on line and you will reduce the chances of water. Barry On Mon=2C Feb 7=2C 2011 at 10:10 AM=2C Joe and Joan Kimbell wrote: Appreciate some info concerning fuel seperation. I have CH701 with the 100 hp riotax. I live in a high humedity area and have not been flying much la tely. I use 10% ethanol fuel and last time I started to fly (fuel had bee n in A/C over a month) and checked the lowest drain=2C I found cloudy fuel =2C not water=2C but did not lood good. I continued to drain fuel until it was clear=2C probably a half an ounce. Was this cloudy fuel on the point o f seperation? I did go ahead and fly with no problems=2C but after thinkin g about it=2C what would the list's ideas be. Very glad it kept running=2C though an both tanks the fuel seemed to come out of only one tank. No ext ernal fuel pump. Gravity feed. ========= > > > ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines- Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?RotaxEngines-Listhttp://forums.matron ics.comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 08, 2011
>I believe the MINIMUM required on wide open throttle is 5400 rpm.< Ron, If you check the service bulletin you will see the minimum is 5200. Dick Maddux Milton,Fl ________________________________________________________________________________
Subject: Engine Life - "On Condition"
Date: Feb 09, 2011
I am compiling some information for a presentation at an LAA (Light Aircraft Association UK) meeting being held in a couple of weeks which may determine the future of running "On Condition" in the UK If anyone has any examples of engines that have exceeded their TBO and are operating successfully (or not) I would like to hear from you so I can support the case for running past TBO. Any info you are willing to provide would be useful, but I will need engine type, model, original TBO limits, total hours to date & age of engine. Can be any type of engine -Rotax, Jabiru, Lycoming, Continential, HKS, UL Power etc etc. If you want to why not post the info below for all to see. Engine type Manufacturers TBO, Hrs/Years Aircraft type Fuel type used Long periods of storage? (specify) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330248#330248 ________________________________________________________________________________
Subject: Re: Engine Life - "On Condition"
Date: Feb 10, 2011
Conrad, I have no statistics for you but except on type certificated aircraft or SLSA which REQUIRE replacement of some parts on a calender time basis, I use "on condition" replacement for most parts. The exception are those subject to high stress and high probability of fatigue failure over time or those parts which are difficult(expensive) to get to and I have current easy access to them. A good example of this is a Jabiru 2200 solid lifter engine with a little over ten years in service. Last week we did a thorough engine inspection while it was off the airframe during and engine mount replacement due to damage in an accident. The rubber socket that connects the Bing 94 carb to the intake manifold is supposed to be replaced on a two year calendar basis, according to Jabiru. After ten years in service (but only about 200 hours) one end is beginning to show some minor cracks from aging. I ordered a new one. If it had been replaced every two years, it would not need replacement now, but the owners would have been out an extra $250 or so for unnecessarily replaced parts. Successful on-condition replacement requires proper and timely inspections but it can save the owner significant amounts of money over the long term without sacrificing safety. In fact, it can sometimes improve safety for two reasons. One, a part already proven in service will not suffer what I call bad-new-part syndrome. Two, mechanics are not perfect and sometimes make mistakes when replacing parts. If proper inspection of a part can be done without disassembly then not replacing a good in-service part can reduce the risk of mechanic error. I'm not preaching against replacement of parts on a calendar basis but tell customers that is is optional when it is legal to do so. Thom Riddle http://sites.google.com/site/riddletr/a&pmechanix -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Tennessee Prop 64x32 Don't accept your dog's admiration as conclusive evidence that you are wonderful. Ann Landers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330409#330409 ________________________________________________________________________________
Subject: bowden cable "grab point" on 912 UL.
Date: Feb 10, 2011
Hello, I have purchased some length of throttle cable from Aircraft Spruce. I need to replace the cables between my throttle "rocker arm" and each carb on my 912 UL (mounted on CH 701). As the throttle application is "pull only", there is a single "grab point" on each of the old cables where the rocker catches when pulling the throttle back. This grab point looks like a little billet of lead. How can I add such to the new cable? I have looked through Aircraft spruce and have found no item that seems to be intended for this. What have others done. Thanks for your help. -------- Ernest Jessee N4931M Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330449#330449 ________________________________________________________________________________
Subject: Re: bowden cable "grab point" on 912 UL.
Date: Feb 10, 2011
Ernest, I'm not a CH701 fellow so I don't know for sure about your installation. But from my experience with my Europa, I think that what you see on the end of the cable is the equivalent of the Nicopress Stop Sleeve. See: http://www.aircraftspruce.com/catalog/appages/nicopress.php at the bottom of the page. It's not really a "grab point" as much as a device to prevent the cable from completely pulling loose should the tightening screw of the cable holder on the carb become loose. If the cable holder should become loose, this stop sleeve allows you to retain enough control of the engine to get safely on the ground. You Rotax and CH701 folks chime in if I have this wrong! Blue skies and tailwinds, Bob Borger Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232 http://www.biplaneforumgallery.com/index.php?cat=10046 Europa Flying! 3705 Lynchburg Dr. Corinth, TX 76208 Home: 940-497-2123 Cel: 817-992-1117 On Feb 10, 2011, at 10:11, ejessee wrote: > > Hello, > I have purchased some length of throttle cable from Aircraft Spruce. I need to replace the cables between my throttle "rocker arm" and each carb on my 912 UL (mounted on CH 701). As the throttle application is "pull only", there is a single "grab point" on each of the old cables where the rocker catches when pulling the throttle back. This grab point looks like a little billet of lead. How can I add such to the new cable? I have looked through Aircraft spruce and have found no item that seems to be intended for this. What have others done. > > Thanks for your help. > > -------- > Ernest Jessee > N4931M ________________________________________________________________________________
Date: Feb 10, 2011
Bob i think you are right, I have put some heat shrink on my cables for exactly that reason, regards Ivor On 10 February 2011 16:32, Robert Borger wrote: > > Ernest, > > I'm not a CH701 fellow so I don't know for sure about your installation. > But from my experience with my Europa, I think that what you see on the end > of the cable is the equivalent of the Nicopress Stop Sleeve. See: > http://www.aircraftspruce.com/catalog/appages/nicopress.php at the > bottom of the page. > > It's not really a "grab point" as much as a device to prevent the cable > from completely pulling loose should the tightening screw of the cable > holder on the carb become loose. If the cable holder should become loose, > this stop sleeve allows you to retain enough control of the engine to get > safely on the ground. > > You Rotax and CH701 folks chime in if I have this wrong! > > Blue skies and tailwinds, > Bob Borger > Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop > http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232 > http://www.biplaneforumgallery.com/index.php?cat=10046 > Europa Flying! > 3705 Lynchburg Dr. > Corinth, TX 76208 > Home: 940-497-2123 > Cel: 817-992-1117 > > On Feb 10, 2011, at 10:11, ejessee wrote: > > > > > Hello, > > I have purchased some length of throttle cable from Aircraft Spruce. I > need to replace the cables between my throttle "rocker arm" and each carb on > my 912 UL (mounted on CH 701). As the throttle application is "pull only", > there is a single "grab point" on each of the old cables where the rocker > catches when pulling the throttle back. This grab point looks like a little > billet of lead. How can I add such to the new cable? I have looked through > Aircraft spruce and have found no item that seems to be intended for this. > What have others done. > > > > Thanks for your help. > > > > -------- > > Ernest Jessee > > N4931M > > ________________________________________________________________________________
Date: Feb 10, 2011
As the throttle application is "pull only", here is a single "grab point" on each of the old cables where the rocker catches when pulling the throttle back. This grab point looks like a litt le billet of lead...... Earnest, Here is what they look like on my 701 scroll down to the 9th and 10th pic. http://www.701builder.com/engine19.htm I'm sure you can use the stop sleeves swaged on that Bob mentions. Maybe 2 on the end for extra security. The cables Zenith provided can be found in a bike shop. Brian ________________________________________________________________________________
Subject: regulators
Date: Feb 12, 2011
i have a 701 /912 with a ducati reg on it. got a low voltage warning last time out. checked resistance of two leads coming from engine coils shows 7.2 ohms. @ rotax manuel. the 12v dc side of the reg has a red wire out of firewall to first / next contact on reg. labeled alternator switch. the next contact is jump wired to first and 4th contact. 4th also has wire to 12000mfd capacitor and from there to solid ground. checked fuse panel and found a blown 15amp fuse on a wire labeled alternator. what was the builder trying to do with this fuse. i have been told by others if you shut off alternator loads while engine is running it will fry the reg. i have two switches on panel labeled master and alternator and was told always on shutdown one first then the other , never in the opposite order with threat of dire consequences. could this fuse be an over voltage / draw protection for the rest of the buss or has it somehow protected the reg from me fumbling with the panel switches. i have changed the fuse but not been able to test run engine and see if this fuse holds, due to howling blizzard here. hanger-ed but open into the wind today . -------- Ross Aalexander: CH701 driver 912ul 450tt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330780#330780 ________________________________________________________________________________
Date: Feb 12, 2011
Subject: Re: regulators
Ross, Suggest you review Section 17, pages 107-111 of the Rotax 912 Installation Manual. Rick Girard On Sat, Feb 12, 2011 at 12:43 PM, dashwood wrote: > dashwoodlock(at)hotmail.com> > > i have a 701 /912 with a ducati reg on it. got a low voltage warning last > time out. checked resistance of two leads coming from engine coils shows 7.2 > ohms. @ rotax manuel. the 12v dc side of the reg has a red wire out of > firewall to first / next contact on reg. labeled alternator switch. the next > contact is jump wired to first and 4th contact. 4th also has wire to > 12000mfd capacitor and from there to solid ground. checked fuse panel and > found a blown 15amp fuse on a wire labeled alternator. what was the builder > trying to do with this fuse. i have been told by others if you shut off > alternator loads while engine is running it will fry the reg. i have two > switches on panel labeled master and alternator and was told always on > shutdown one first then the other , never in the opposite order with threat > of dire consequences. could this fuse be an over voltage / draw protection > for the rest of the buss or has it somehow protected the reg from me > fumbling with the panel switches! > . i have changed the fuse but not been able to test run engine and see if > this fuse holds, due to howling blizzard here. hanger-ed but open into the > wind today . > > -------- > Ross Aalexander: CH701 driver 912ul 450tt > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330780#330780 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Feb 12, 2011
thanks. i was not able to find the pages i needed before. i think the fuse i have blown is the 25A after the reg terminals. the capacitor is in place and should have protected the reg as/per manual. when you close 16(master) then 19 relay pulls on the battery supply to fuse bus. i have an endurance fuse bus as well. somehow an alternator disconnect that draws minimal power only from battery to supply minimal flight requirements. i assume to guard against over voltage (failed reg). i don't see this in the diagram. not sure if master has to be shut off first to stop feedback( blowing the 25A fuse). i just want to understand what is happening so i can fix or not have happen in flight again. -------- Ross Aalexander: CH701 driver 912ul 450tt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330827#330827 ________________________________________________________________________________
Date: Feb 13, 2011
Ross, Pay special attention to the capacitor. It's the protection for the regulator. The proper size can be had from B & C Specialties, Mouser, Allied, or others but you really should upgrade to the 25000 mfd min. size. Rick On Sat, Feb 12, 2011 at 8:12 PM, dashwood wrote: > dashwoodlock(at)hotmail.com> > > thanks. i was not able to find the pages i needed before. i think the fuse > i have blown is the 25A after the reg terminals. the capacitor is in place > and should have protected the reg as/per manual. when you close 16(master) > then 19 relay pulls on the battery supply to fuse bus. i have an endurance > fuse bus as well. somehow an alternator disconnect that draws minimal power > only from battery to supply minimal flight requirements. i assume to guard > against over voltage (failed reg). i don't see this in the diagram. not sure > if master has to be shut off first to stop feedback( blowing the 25A fuse). > i just want to understand what is happening so i can fix or not have happen > in flight again. > > -------- > Ross Aalexander: CH701 driver 912ul 450tt > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330827#330827 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx
December 11, 2010 - February 13, 2011
RotaxEngines-Archive.digest.vol-aw
