RotaxEngines-Archive.digest.vol-be
May 04, 2013 - October 24, 2013
      airman - Maintenance Rated=0ARotax Repair Center - Heavy Maint. Rated=0AHom
      e 520-574-1080- TRY HOME FIRST=0ACell 520-349-7056=0A=0A=0ARead this topi
      c online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=399904#39
Subject: Re: RotaxEngines-List Digest: 1 Msgs - 05/03/13
Date: May 04, 2013
Wouldn=92t a gascolator and proper sized filter upstream of the engine (between the main fuel tank and the carbs) prevent this problem? Hugh G. McKay III, P.E. Allegro 2000 Rotax 912 UL From: Stan Tew Sent: Saturday, May 04, 2013 9:39 AM Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 1 Msgs - 05/03/13 Another place to look for debris while you have the carb in your hand is the inlet line. Although the id of the fuel line is 1/4 going over the hose barb down at the bottom where the fuel actually flows into the float bowl the orifice is MUCH smaller. Bits of debris can cover the orifice preventing any fuel from entering the float bowl. The other cylinder mayor may not be okay but the engine will not run enough to produce power on 1 cylinder. Check both! I say this from experience. I had to land my Kitfox II in the trees due to such obstruction. I was unhurt but the plane was badly damaged STAN 2 ------------------------------------------------------------------------- ------- From: RotaxEngines-List Digest Server <rotaxengines-list(at)matronics.com> Sent: Saturday, May 4, 2013 2:00 AM Subject: RotaxEngines-List Digest: 1 Msgs - 05/03/13 * Online Versions of Today's List Digest Archive Today's complete RotaxEngines-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RotaxEngines-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 13-05-03&Archive=RotaxEngines Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 13-05-03&Archive=RotaxEngines ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- RotaxEngines-List Digest Archive --- Total Messages Posted Fri 05/03/13: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 07:05 AM - Carb bowl obstruction - Don't be stranded (Roger Lee) ________________________________ Message 1 _____________________________________ Subject: RotaxEngines-List: Carb bowl obstruction - Don't be stranded From: "Roger Lee" <ssadiver1(at)yahoo.com> Hi Guys, Your flying along and the engine looses power to about 3800-4000 rpm and runs rough. It could be a couple of things, but first suspect a carb bowl main jet obstruction. Here is a simple tip that may keep you flying and get your rpm back and if that fails how to do a self rescue and not be stranded and all you need is a screwdriver. You can do this fix and be back in the air in 30 minutes. I have done this and know it works. The debris may never be detected during a run up on the ground. There usually isn't enough fuel flow for a good main jet suction and no sloshing or turbulence of the fuel in the carb bowl. In cruise flight you now have a good fuel flow, turbulence within the bowl and plenty of upward suction to draw that piece of debris right up against the main jet. Here is an in air fix you can try, but there is no guarantee. While you are doing this next maneuver you should be looking for an appropriate landing spot. Either an airfield or a decent road. Your first instinct is to go full throttle to get more rpm.That only holds the debris harder against the main jet, but it is human nature to try for more rpm. Once that fails and providing you have a little altitude pull the throttle back to idle and glide for about 15 seconds with a little side to side "S" turns. When the throttle is back at idle the main jet is not in play and the suction is gone allowing the debris to hopefully fall away and settle to a lower point. The idle jet is separate from the main jet. After your 15 second glide slowly advance the throttle back to cruise rpm and head for an airport. If this in air idle rpm fix doesn't work then continue to a safe landing. Once on the ground then take off the upper cowl. Pop the carb retention spring off, then loosen the carb flange screw and push the carb back out of the rubber flange socket. It's snug so push hard. If you have the older stainless steel fuel supply lines you can now lift the carb upward enough to clear the drip tray to take the carb bowl off. If you have the red Teflon fuel lines all the better because you can lift the carbs and rotate them out towards you to have a little better access to the bowl and bale. If you don't have a drip tray then this is real easy. Now push or pry with your screwdriver the carb bowl bale back towards the firewall. Drop the carb bowl and look for your debris and toss the bad fuel out. Put the carb bowl back in place making sure it fits into its mounting outside edge grove and pull the bale back in place. Be mindful of the bowl gasket. Push the carb back into the rubber flange until you hear and feel it kind of seat in place. You will feel it snap in place and the carb will look like it is in far enough that it can't go any further. Tighten the rubber flange retention ring screw and do the same procedure to the other side. Once both are done put the cowl on and test run at full throttle for about 5 minutes. If you have the stock Rotax airbox then you will need to loosen the airbox side rubber flange and slide it out of the way to push the carb back out of the rubber flange. So both sides of the carb gets the rubber flange loosened. You should now be ready to take off and head for home. It works. http://www.youtube.com/watch?feature=player_embedded&v=JdS7OtbcxwY -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=399904#399904 http://www.matronics.com/Navigator?RotaxEnginp; --> http:======================= ________________________________________________________________________________
Date: May 04, 2013
Stan: Sorry for your "experience" and glad you walked away from it. But why does Rotax have so many stupid design faults? I know it is not your fault, but is there a difference between Rotax experimental and Rotax certified? *Barry* > Subject: RotaxEngines-List: Carb bowl obstruction - Don't be stranded > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Hi Guys, > > Your flying along and the engine looses power to about 3800-4000 rpm and > runs rough. > It could be a couple of things, but first suspect a carb bowl main jet > obstruction. > Here is a simple tip that may keep you flying and get your rpm back > and if that fails how to do a self rescue and not be stranded and all you > need > is a screwdriver. You can do this fix and be back in the air in 30 minutes. > I have done this and know it works. > > The debris may never be detected during a run up on the ground. There > usually isn't > enough fuel flow for a good main jet suction and no sloshing or turbulence > of the fuel in the carb bowl. In cruise flight you now have a good fuel > flow, > turbulence within the bowl and plenty of upward suction to draw that piece > of debris right up against the main jet. > > Here is an in air fix you can try, but there is no guarantee. While you > are doing > this next maneuver you should be looking for an appropriate landing spot. > Either > an airfield or a decent road. > Your first instinct is to go full throttle to get more rpm.That only holds > the > debris harder against the main jet, but it is human nature to try for more > rpm. > Once that fails and providing you have a little altitude pull the throttle > back > to idle and glide for about 15 seconds with a little side to side "S" > turns. > When the throttle is back at idle the main jet is not in play and the > suction > is gone allowing the debris to hopefully fall away and settle to a lower > point. > The idle jet is separate from the main jet. After your 15 second glide > slowly > advance the throttle back to cruise rpm and head for an airport. > > If this in air idle rpm fix doesn't work then continue to a safe landing. > Once on the ground then take off the upper cowl. Pop the carb retention > spring > off, then loosen the carb flange screw and push the carb back out of the > rubber > flange socket. It's snug so push hard. If you have the older stainless > steel > fuel supply lines you can now lift the carb upward enough to clear the > drip tray > to take the carb bowl off. If you have the red Teflon fuel lines all the > better > because you can lift the carbs and rotate them out towards you to have a > little better access to the bowl and bale. If you don't have a drip tray > then > this is real easy. > Now push or pry with your screwdriver the carb bowl bale back towards the > firewall. > Drop the carb bowl and look for your debris and toss the bad fuel out. Put > the carb bowl back in place making sure it fits into its mounting outside > edge > grove and pull the bale back in place. Be mindful of the bowl gasket. Push > the carb back into the rubber flange until you hear and feel it kind of > seat in > place. You will feel it snap in place and the carb will look like it is in > far > enough that it can't go any further. Tighten the rubber flange retention > ring > screw and do the same procedure to the other side. Once both are done put > the > cowl on and test run at full throttle for about 5 minutes. > > If you have the stock Rotax airbox then you will need to loosen the airbox > side > rubber flange and slide it out of the way to push the carb back out of the > rubber > flange. So both sides of the carb gets the rubber flange loosened. > > You should now be ready to take off and head for home. > > It works. > > http://www.youtube.com/watch?feature=player_embedded&v=JdS7OtbcxwY > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > <http://forums.matronics.com/> > ________________________________________________________________________________
Date: May 04, 2013
Hi Hugh, The problem has been that not everyone has a gascolator or a fuel filter far enough downstream. the main hose offenders isn't from hose before the fuel pump because it has a filter screen inside, but from hose past the pump. The fuel hose from the pump pressure side out is a problem at times. Some 912's have the stainless steel lines mounted from the fuel distribution block mounted on the carb balance tube, some don't. Some have the red Teflon fuel line from this point and some have just rubber fuel line right out of the pump to the carbs. Read this and you'll get a better handle on what some of the issues have been. My original post here was to just give you another tool in your mental toolbox for the "just in case" scenario. http://www.rotax-owner.com/rotax-blog/item/21-rotax-5-year-rubber-replacement-the-installation-considerations -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=399964#399964 ________________________________________________________________________________
Date: May 05, 2013
Barry, Debris blocking some portion of the fuel flow through the carb is not a design fault. That can happen to any carb engine. About 4 months ago I had a friend go off the end of the runway at his home airport because a tiny piece of debris blocked the main jet in the carb on his Lycoming engine just as he lifted off. The Rotax 9xx series of engines are fine power plants. They are different than your typical Lycoming or Continental but they are all excellent power plants. There's no difference between the certified Rotax and the uncertified Rotax other than paperwork and application. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On May 4, 2013, at 10:39 AM, FLYaDIVE wrote: Stan: Sorry for your "experience" and glad you walked away from it. But why does Rotax have so many stupid design faults? I know it is not your fault, but is there a difference between Rotax experimental and Rotax certified? Barry ________________________________________________________________________________
Date: May 05, 2013
Subject: Re: RotaxEngines-List Digest: 4 Msgs - 05/04/13
You'd think that a gascolator , fuel filter, and/or very small opening in t he fuel pump diaphragm would catch these particles. That's what I thought. WRONG! I have no idea how those particles got there, but once there, they w ere devastating. They may have actually been part of the fuel line past all those devices. While I can't totally blame ethanol I believe it was a sign ificant contributing factor. Anyway, it doesn't take all that long to clean the system. It takes much longer to repair the damage.=0A=0A-=0ASTAN 2 =0AN29TD=0A=0A=0A=0A________________________________=0A From: RotaxEngines- List Digest Server =0ATo: RotaxEngines-Lis t Digest List =0ASent: Sunday, May 5, 2013 2:00 AM=0ASubject: RotaxEngines-List Digest: 4 Msgs - 05/04/13=0A =0A=0A*=0A=0A==================== ======0A- Online Versions of Today's List Digest Archive=0A= =========================0A =0AToday's complete RotaxEngines-List Digest can also be found in either of the =0Atwo Web Links listed below.- The .html file includes the Digest f ormatted =0Ain HTML for viewing with a web browser and features Hyperlinked Indexes =0Aand Message Navigation.- The .txt file includes the plain ASC II version =0Aof the RotaxEngines-List Digest and can be viewed with a gene ric text editor =0Asuch as Notepad or with a web browser. =0A=0AHTML Versio n:=0A=0A- - http://www.matronics.com/digest/digestview.php?Style=8270 1&View=html&Chapter 13-05-04&Archive=RotaxEngines=0A=0AText Version :=0A=0A- - http://www.matronics.com/digest/digestview.php?Style=82701 &View=txt&Chapter 13-05-04&Archive=RotaxEngines=0A=0A=0A=== =====================0A- EMail V ersion of Today's List Digest Archive=0A=========== =============0A=0A=0A- - - - - --------- -------------------------------------------------=0A- - - - - - - - - - - - - RotaxEngines-List Digest Archive=0A- - - - - - - - - - - - - - - - - - - ---=0A - - - - - - - - - - Total Messages Posted Sat 05/04/13 : 4=0A- - - - - ------------------------------------------------ ----------=0A=0A=0AToday's Message Index:=0A----------------------=0A=0A- - 1. 06:39 AM - Re: RotaxEngines-List Digest: 1 Msgs - 05/03/13- (Sta n Tew)=0A- - 2. 07:25 AM - Re: Re: RotaxEngines-List Digest: 1 Msgs - 05/03/13- (Hugh McKay)=0A- - 3. 08:39 AM - Re: Re: RotaxEngines-List Digest: 1 Msgs - 05/03/13- (FLYaDIVE)=0A- - 4. 03:07 PM - Re: Rotax Engines-List Digest: 1 Msgs - 05/03/13- (Roger Lee)=0A=0A=0A=0A__________ ______________________- Message 1- ____________________________________ Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 1 Msgs - 05/03/13 =0A=0AAnother place to look for debris while you have the carb in your hand is th=0Ae inlet line. Although the id of the fuel line is 1/4 going over t he hose b=0Aarb down at the bottom where the fuel actually flows into the f loat bowl th=0Ae orifice is MUCH smaller. Bits of debris can cover the orif ice preventing =0Aany fuel from entering the float bowl. The other cylinder mayor may not be =0Aokay but the engine will not run enough to produce pow er on 1 cylinder. Che=0Ack both!=0A=0A=0AI say this from experience. I had to land my Kitfox II in =0Athe trees due to such obstruction. I was u nhurt but the plane was badly dam=0Aaged=0A=0A-=0ASTAN 2=0A=0A= 0A________________________________=0A From: Ro=0AtaxEngines-List Digest S erver =0ATo: Rotax=0AEngines-List Digest List =0ASent: =0ASaturday, May 4, 2013 2:00 AM=0ASubject: RotaxEngines-List Digest: 1 Msgs -=0A05/03/13 =0A =0A=0A*=0A=0A================ =0A==========0A-- Online Versions of Today's List Dig est A=0Archive=0A================== =====0A====0A=0AToday's complete RotaxEngines-List Digest can also be found =0Ain either of the =0Atwo Web Links listed below.- Th e .html file includes =0Athe Digest formatted =0Ain HTML for viewing with a web browser and features=0AHyperlinked Indexes =0Aand Message Navigati on.- The .txt file includes t=0Ahe plain ASCII version =0Aof the RotaxEng ines-List Digest and can be viewed=0Awith a generic text editor =0Asuch a s Notepad or with a web browser. =0A=0A=0AHTML Version:=0A=0A- - ht tp://www.matronics.com/digest/digestview.ph=0Ap?Style=82701&View=html&C hapter 13-05-03&Archive=RotaxEngines=0A=0A=0AText Version:=0A=0A- - http://www.matronics.com/digest/digestview.ph=0Ap?Style=82701&View=t xt&Chapter 13-05-03&Archive=RotaxEngines=0A=0A=0A=0A===== ===================0A=0A-- EMail Ve rsion of Today's List Digest Archive=0A=======0A==== ==============0A=0A=0A- - - -=0A-- ------ ----------------------------------------------------=0A- - =0A- - - - - - - - - - -- RotaxEngines-List Digest Archi=0Ave=0A- - - - - - - - - - - - - - - - - =0A- - ---=0A- - - - - - - - - -- Total Messages Poste=0Ad Fri 05/03/13: 1=0A- - - - -- ----------------------------------=0A---- --------------------=0A=0A=0AToday's Message Index:=0A------------- ----=0A-----=0A=0A- -- 1. 07:05 AM - Carb bowl obstruction - Don't be stranded=0A- (Roger Lee)=0A=0A=0A=0A______________________________ __- Message 1-=0A_____________________________________=0A=0A=0ATime: - Don't be stranded=0AFrom=0A: "Roger Lee" =0A= 0A=0AHi Guys,=0A=0AYour flying along=0Aand the engine looses power to about 3800-4000 rpm and runs rough.=0AIt co=0Auld be a couple of things, but first suspect a carb bowl main jet obstructi=0Aon.=0AHere is a simpl e tip that may keep you flying and get your rpm back=0A=0Aand if that fai ls how to do a self rescue and not be stranded and all yo=0Au need=0Ais a screwdriver. You can do this fix and be back in the air in 30=0Aminutes. =0AI have done this and know it works.=0A=0AThe debris may never b=0A e detected during a run up on the ground. There usually isn't=0Aenough fu el=0Aflow- for a good main jet suction and no sloshing or turbulence=0Aof the=0Afuel in the carb bowl. In cruise flight you now have a good fuel flo w,=0At=0Aurbulence within the bowl and plenty of upward suction to draw t hat piece=0A=0Aof debris right up against the main jet.=0A=0AHere is an in air fix you =0Acan try, but there is no guarantee. While you are doin g=0Athis next maneuve=0Ar you should be looking for an appropriate landin g spot. Either=0Aan airfie=0Ald or a decent road. =0AYour first instinc t is to go full throttle to get m=0Aore rpm.That only holds the=0Adebris harder against the main jet, but it is=0Ahuman nature to try for more rpm. =0AOnce that fails and providing you have=0Aa little altitude pull the th rottle back=0Ato idle and glide for about 15 =0Aseconds with a little- si de to side "S" turns.=0AWhen the throttle is bac=0Ak at idle the main jet is not in play and the suction=0Ais gone allowing th=0Ae debris to hopef ully fall away and settle to a lower point.=0AThe idle jet=0Ais separate from the main jet. After your 15 second glide slowly=0Aadvance=0Athe thro ttle back to cruise rpm and head for an airport.=0A=0AIf this in a=0Air idle rpm fix doesn't work then continue to a safe landing.=0AOnce on the =0Aground then take off the upper cowl. Pop the carb retention spring=0Ao ff, =0Athen loosen the carb flange screw and push the carb back out of the rubber=0A=0Aflange socket. It's snug so push hard. If you have the older stainless s=0Ateel=0Afuel supply lines you can now lift the carb upward e nough to clear t=0Ahe drip tray=0Ato take the carb bowl off. If you have the red Teflon fuel l=0Aines all the better=0Abecause you can lift the ca rbs and rotate them out to=0Awards you to have a=0Alittle better access t o the bowl and bale. If you don=0A't have a drip tray then=0Athis is real easy.=0ANow push or pry with your s=0Acrewdriver the carb bowl bale back towards the firewall.=0ADrop the carb bo=0Awl and look for your debris a nd toss the bad fuel out. Put=0Athe carb bowl =0Aback in place making sur e it fits into its mounting outside edge=0Agrove an=0Ad pull the bale bac k in place. Be mindful of the bowl gasket. Push=0Athe ca=0Arb back into t he rubber flange until you hear and feel it kind of seat in=0A=0Aplace. Y ou will feel it snap in place and the carb will look like it is =0Ain far =0Aenough that it can't go any further. Tighten the rubber flange ret=0Ae ntion ring=0Ascrew and do the same procedure to the other side. Once both =0Aare done put the=0Acowl on and test run at full throttle for about 5 minute=0As. =0A=0AIf you have the stock Rotax airbox then you will need to loosen th=0Ae airbox side=0Arubber flange and slide it out of the way to push the carb =0Aback out of the rubber=0Aflange. So both sides of th e carb gets the rubber =0Aflange loosened.=0A=0AYou should now be ready to take off and head for home=0A.=0A=0AIt works.=0A=0Ahttp://www.y outube.com/watch?feature=player_embedde=0Ad&v=JdS7OtbcxwY=0A=0A---- ----=0ARoger Lee=0ATucson, Az.=0ALight Sport Rep=0Aairman - Maintenan ce Rated=0ARotax Repair Center - Heavy Maint. Rated=0AHom=0Ae 520-574-1 080- TRY HOME FIRST=0ACell 520-349-7056=0A=0A=0ARead this topi=0Ac online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=399904# 39=0A==0A=0A________________________________- Message 2- ____________ Kay" =0ASubject: Re: RotaxEngines-List: Re: RotaxEng ines-List Digest: 1 Msgs - 05/03/13=0A=0AWouldn=92t a gascolator and prop er sized filter upstream of the engine =0A(between the main fuel tank and t he carbs) prevent this problem?=0A=0AHugh G. McKay III, P.E.=0AAllegro 2000 =0ARotax 912 UL=0A=0A=0AFrom: Stan Tew =0ASent: Saturday, May 04, 2013 9:39 AM=0ASubject: RotaxEngines-List: Re: RotaxEngines-List Digest: 1 Msgs - =0A05/03/13=0A=0AAnother place to look for debris while you have the carb i n your hand is =0Athe inlet line. Although the id of the fuel line is 1/4 g oing over the =0Ahose barb down at the bottom where the fuel actually flows into the =0Afloat bowl the orifice is MUCH smaller. Bits of debris can cov er the =0Aorifice preventing any fuel from entering the float bowl. The oth er =0Acylinder mayor may not be okay but the engine will not run enough to =0Aproduce power on 1 cylinder. Check both!=0A=0A=0AI say this from experie nce. I had to land my Kitfox II in the trees due =0Ato such obstruction. I was unhurt but the plane was badly damaged=0A=0A=0ASTAN 2=0A=0A=0A--------- ----------------------------------------------------------------=0A------- =0AFrom: RotaxEngines-List Digest Server <rotaxengines-list(at)matronics.com> =0A =0ASent: Saturday, May 4, 2013 2:00 AM=0ASubject: RotaxEngines-List Digest: 1 Msgs - 05/03/13=0A=0A=0A*=0A =0A=0A- Online Versions of Today's List Digest Archive=0A=0A=0AToday's co mplete RotaxEngines-List Digest can also be found in either of =0Athe =0Atw o Web Links listed below.- The .html file includes the Digest =0Aformatte d =0Ain HTML for viewing with a web browser and features Hyperlinked Indexe s =0Aand Message Navigation.- The .txt file includes the plain ASCII vers ion =0Aof the RotaxEngines-List Digest and can be viewed with a generic tex t =0Aeditor =0Asuch as Notepad or with a web browser. =0A=0AHTML Version: =0A=0A- - =0Ahttp://www.matronics.com/digest/digestview.php?Style=827 01&View=html&=0AChapter 13-05-03&Archive=RotaxEngines=0A=0AText Version :=0A=0A- - =0Ahttp://www.matronics.com/digest/digestview.php?Style=82 701&View=txt&C=0Ahapter 13-05-03&Archive=RotaxEngines=0A=0A=0A=== ====================0A- EMail Versi on of Today's List Digest Archive=0A============= ==========0A=0A=0A- - - - - ------------------- ---------------------------------------=0A- - - - - - - - - - - - - RotaxEngines-List Digest Archive=0A- - - - - - - - - - - - - - - - - - - ---=0A- - - - - - - - - - Total Messages Posted Fri 05/03/13: 1=0A- - - - - ----------------------------------------------------------=0A =0A=0AToday's Message Index:=0A----------------------=0A=0A- - 1. 07:05 AM - Carb bowl obstruction - Don't be stranded- (Roger Lee)=0A=0A=0A____ ____________________________- Message 1- =0A___________________________ arb bowl obstruction - Don't be stranded=0AFrom: "Roger Lee" <ssadiver1@yah oo.com>=0A=0A=0AHi Guys,=0A=0AYour flying along and the engine looses power to about 3800-4000 rpm and =0Aruns rough.=0AIt could be a couple of things , but first suspect a carb bowl main jet =0Aobstruction.=0AHere is a simple tip that may keep you flying and get your rpm back=0Aand if that fails how to do a self rescue and not be stranded and all =0Ayou need=0Ais a screwdr iver. You can do this fix and be back in the air in 30 =0Aminutes.=0AI have done this and know it works.=0A=0AThe debris may never be detected during a run up on the ground. There =0Ausually isn't=0Aenough fuel flow- for a good main jet suction and no sloshing or =0Aturbulence=0Aof the fuel in the carb bowl. In cruise flight you now have a good fuel =0Aflow,=0Aturbulence within the bowl and plenty of upward suction to draw that =0Apiece=0Aof de bris right up against the main jet.=0A=0AHere is an in air fix you can try, but there is no guarantee. While you =0Aare doing=0Athis next maneuver you should be looking for an appropriate landing =0Aspot. Either=0Aan airfield or a decent road. =0AYour first instinct is to go full throttle to get mor e rpm.That only =0Aholds the=0Adebris harder against the main jet, but it i s human nature to try for =0Amore rpm.=0AOnce that fails and providing you have a little altitude pull the =0Athrottle back=0Ato idle and glide for ab out 15 seconds with a little- side to side "S" =0Aturns.=0AWhen the throt tle is back at idle the main jet is not in play and the =0Asuction=0Ais gon e allowing the debris to hopefully fall away and settle to a lower =0Apoint .=0AThe idle jet is separate from the main jet. After your 15 second glide =0Aslowly=0Aadvance the throttle back to cruise rpm and head for an airport .=0A=0AIf this in air idle rpm fix doesn't work then continue to a safe =0A landing.=0AOnce on the ground then take off the upper cowl. Pop the carb re tention =0Aspring=0Aoff, then loosen the carb flange screw and push the car b back out of the =0Arubber=0Aflange socket. It's snug so push hard. If you have the older stainless =0Asteel=0Afuel supply lines you can now lift the carb upward enough to clear the =0Adrip tray=0Ato take the carb bowl off. If you have the red Teflon fuel lines all the =0Abetter=0Abecause you can l ift the carbs and rotate them out towards you to have a=0Alittle better acc ess to the bowl and bale. If you don't have a drip tray =0Athen=0Athis is r eal easy.=0ANow push or pry with your screwdriver the carb bowl bale back t owards =0Athe firewall.=0ADrop the carb bowl and look for your debris and t oss the bad fuel out. =0APut=0Athe carb bowl back in place making sure it f its into its mounting =0Aoutside edge=0Agrove and pull the bale back in pla ce. Be mindful of the bowl gasket. =0APush=0Athe carb back into the rubber flange until you hear and feel it kind of =0Aseat in=0Aplace. You will feel it snap in place and the carb will look like it is =0Ain far=0Aenough that it can't go any further. Tighten the rubber flange retention =0Aring=0Ascr ew and do the same procedure to the other side. Once both are done =0Aput t he=0Acowl on and test run at full throttle for about 5 minutes. =0A=0AIf yo u have the stock Rotax airbox then you will need to loosen the =0Aairbox si de=0Arubber flange and slide it out of the way to push the carb back out of =0Athe rubber=0Aflange. So both sides of the carb gets the rubber flange l oosened.=0A=0AYou should now be ready to take off and head for home.=0A=0AI t works.=0A=0Ahttp://www.youtube.com/watch?feature=player_embedded&v=Jd S7OtbcxwY=0A=0A--------=0ARoger Lee=0ATucson, Az.=0ALight Sport Repairman - Maintenance Rated=0ARotax Repair Center - Heavy Maint. Rated=0AHome 520-57 4-1080- TRY HOME FIRST=0ACell 520-349-7056=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=399904#399904=0A =0A=0Ahttp://www.matronics.com/Navigator?RotaxEnginp; --> =0Ahttp:=== =====================0A=0A=0A______ __________________________- Message 3- ________________________________ : RotaxEngines-List Digest: 1 Msgs - 05/03/13=0AFrom: FLYaDIVE <flyadive@gm ail.com>=0A=0AStan:=0A=0ASorry for your "experience" and glad you walked aw ay from it.=0ABut why does Rotax have so many stupid design faults?=0AI kno w it is not your fault, but is there a difference between Rotax=0Aexperimen ubject: RotaxEngines-List: Carb bowl obstruction - Don't be stranded=0A> Fr om: "Roger Lee" =0A>=0A>=0A> Hi Guys,=0A>=0A> Your fly ing along and the engine looses power to about 3800-4000 rpm and=0A> runs r ough.=0A> It could be a couple of things, but first suspect a carb bowl mai n jet=0A> obstruction.=0A> Here is a simple tip that may keep you flying an d get your rpm back=0A> and if that fails how to do a self rescue and not b e stranded and all you=0A> need=0A> is a screwdriver. You can do this fix a nd be back in the air in 30 minutes.=0A> I have done this and know it works .=0A>=0A> The debris may never be detected during a run up on the ground. T here=0A> usually isn't=0A> enough fuel flow- for a good main jet suction and no sloshing or turbulence=0A> of the fuel in the carb bowl. In cruise f light you now have a good fuel=0A> flow,=0A> turbulence within the bowl and plenty of upward suction to draw that piece=0A> of debris right up against the main jet.=0A>=0A> Here is an in air fix you can try, but there is no g uarantee. While you=0A> are doing=0A> this next maneuver you should be look ing for an appropriate landing spot.=0A> Either=0A> an airfield or a decent road.=0A> Your first instinct is to go full throttle to get more rpm.That only holds=0A> the=0A> debris harder against the main jet, but it is human nature to try for more=0A> rpm.=0A> Once that fails and providing you have a little altitude pull the throttle=0A> back=0A> to idle and glide for abou t 15 seconds with a little- side to side "S"=0A> turns.=0A> When the thro ttle is back at idle the main jet is not in play and the=0A> suction=0A> is gone allowing the debris to hopefully fall away and settle to a lower=0A> point.=0A> The idle jet is separate from the main jet. After your 15 second glide=0A> slowly=0A> advance the throttle back to cruise rpm and head for an airport.=0A>=0A> If this in air idle rpm fix doesn't work then continue to a safe landing.=0A> Once on the ground then take off the upper cowl. Pop the carb retention=0A> spring=0A> off, then loosen the carb flange screw a nd push the carb back out of the=0A> rubber=0A> flange socket. It's snug so push hard. If you have the older stainless=0A> steel=0A> fuel supply lines you can now lift the carb upward enough to clear the=0A> drip tray=0A> to take the carb bowl off. If you have the red Teflon fuel lines all the=0A> b etter=0A> because you can lift the carbs and rotate them out towards you to have a=0A> little better access to the bowl and bale. If you don't have a drip tray=0A> then=0A> this is real easy.=0A> Now push or pry with your scr ewdriver the carb bowl bale back towards the=0A> firewall.=0A> Drop the car b bowl and look for your debris and toss the bad fuel out. Put=0A> the carb bowl back in place making sure it fits into its mounting outside=0A> edge =0A> grove and pull the bale back in place. Be mindful of the bowl gasket. Push=0A> the carb back into the rubber flange until you hear and feel it ki nd of=0A> seat in=0A> place. You will feel it snap in place and the carb wi ll look like it is in=0A> far=0A> enough that it can't go any further. Tigh ten the rubber flange retention=0A> ring=0A> screw and do the same procedur e to the other side. Once both are done put=0A> the=0A> cowl on and test ru n at full throttle for about 5 minutes.=0A>=0A> If you have the stock Rotax airbox then you will need to loosen the airbox=0A> side=0A> rubber flange and slide it out of the way to push the carb back out of the=0A> rubber=0A> flange. So both sides of the carb gets the rubber flange loosened.=0A>=0A> You should now be ready to take off and head for home.=0A>=0A> It works. =0A>=0A> http://www.youtube.com/watch?feature=player_embedded&v=JdS7Otb cxwY=0A>=0A> --------=0A> Roger Lee=0A> Tucson, Az.=0A> Light Sport Repairm an - Maintenance Rated=0A> Rotax Repair Center - Heavy Maint. Rated=0A> Hom e 520-574-1080- TRY HOME FIRST=0A> Cell 520-349-7056=0A>=0A>=0A> <http:// forums.matronics.com/>=0A>=0A=0A________________________________- Message S=0ASubject: RotaxEngines-List: Re: RotaxEngines-List Digest: 1 Msgs - 05/0 3/13=0AFrom: "Roger Lee" <ssadiver1(at)yahoo.com>=0A=0A=0AHi Hugh,=0A=0AThe pr oblem has been that not everyone has a gascolator or a fuel filter far enou gh=0Adownstream. the main hose offenders isn't from hose before the fuel pu mp=0Abecause it has a filter screen inside, but from hose past the pump. Th e fuel hose=0Afrom the pump pressure side out is a problem at times. Some 9 12's have the=0Astainless steel lines mounted from the fuel distribution bl ock mounted on the=0Acarb balance tube, some don't. Some have the red Teflo n fuel line from this point=0Aand some have just rubber fuel line right out of the pump to the carbs.=0A=0ARead this and you'll get a better handle on what some of the issues have been.=0AMy original post here was to just giv e you another tool in your mental toolbox=0Afor the "just in case" scenario .=0A=0Ahttp://www.rotax-owner.com/rotax-blog/item/21-rotax-5-year-rubber-re placement-the-installation-considerations=0A=0A--------=0ARoger Lee=0ATucso n, Az.=0ALight Sport Repairman - Maintenance Rated=0ARotax Repair Center - Heavy Maint. Rated=0AHome 520-574-1080- TRY HOME FIRST=0ACell 520-349-705 6=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/vie =- - - - - - - - - - - - - - - -Matt Dralle ======== ________________________________________________________________________________
Date: May 05, 2013
Hi Barry, These things aren't Rotax faults they are human caused errors. They can happen to any engine and any engine can have a mechanical failure. If that wasn't so no engine or machine would need a warranty or ever need a spare part. We make them and we work on them. We are the problem. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=400029#400029 ________________________________________________________________________________
Subject: Hard start 912ULS
Date: May 26, 2013
Starting my 912 has been increasingly difficult. it seems as if the starter has a hard time turning over the engine (it is a high-torque version). I thought it was a weak battery but the problem persists even if I add battery capacity. The last two attempts it sounds like the Bendix is not engaging much at all. Just a gear grinding sound and no prop turns. I suspect the starter motor. Anyone have another idea of something at which I should be looking and/or testing? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401401#401401 ________________________________________________________________________________
Subject: Re: Hard start 912ULS
From: =?iso-8859-1?Q?J=F3hann_J=F3hannsson?= <joeing701(at)simnet.is>
Date: May 27, 2013
Hello John. I had the same experience with my 912 UL starting. It turned out to be the starter like you suspect. Just to make sure, remove the starter and open it up. You will see some burned wire windings. This could happen if you let the started turn for too long. I replaced the starter with the "heavy duty" starter and everything has been working great since. Hope this helps, Johann G. Iceland. Zenith 701. On 27.5.2013, at 03:04, johnelling wrote: > > Starting my 912 has been increasingly difficult. it seems as if the starter has a hard time turning over the engine (it is a high-torque version). I thought it was a weak battery but the problem persists even if I add battery capacity. > > The last two attempts it sounds like the Bendix is not engaging much at all. Just a gear grinding sound and no prop turns. > > I suspect the starter motor. Anyone have another idea of something at which I should be looking and/or testing? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401401#401401 > > > > > > > > > > ________________________________________________________________________________
Date: May 27, 2013
I would highly recomend Sky Tech as a source for your starter.- They adve rtise lower cost, lower current draw, higher torque and lighter weight.- I am very pleased with my Sky Tech starter upgrade which was done to improv e winter time engine start-up. Dave Weaver N912GR --- On Mon, 5/27/13, J=F3hann J=F3hannsson wrote: From: J=F3hann J=F3hannsson <joeing701(at)simnet.is> Subject: Re: RotaxEngines-List: Hard start 912ULS Date: Monday, May 27, 2013, 5:06 AM hannsson?= Hello John. I had the same experience with my 912 UL starting. It turned out to be the starter like you suspect. Just to make sure, remove the starter and open it up. You will see some burned wire windings. This could happen if you let t he started turn for too long. I replaced the starter with the "heavy duty" starter and everything has bee n working great since. Hope this helps, Johann G. Iceland. Zenith 701. On 27.5.2013, at 03:04, johnelling wrote: com> > > Starting my 912 has been increasingly difficult.- it seems as if the st arter has a hard time turning over the engine (it is a high-torque version) .- I thought it was a weak battery but the problem persists even if I add battery capacity.- > > The last two attempts it sounds like the Bendix is not engaging much at a ll.- Just a gear grinding sound and no prop turns.- > > I suspect the starter motor.- Anyone have another idea of something at which I should be looking and/or testing? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401401#401401 > > > > > > > > > > le, List Admin. ________________________________________________________________________________
Date: May 27, 2013
Dave, Is the Sky Tech firm you recommend located at the Rock Hill airport in SC? Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com From: David Weaver Sent: Monday, May 27, 2013 7:31 AM Subject: Re: RotaxEngines-List: Hard start 912ULS I would highly recomend Sky Tech as a source for your starter. They advertise lower cost, lower current draw, higher torque and lighter weight. I am very pleased with my Sky Tech starter upgrade which was done to improve winter time engine start-up. Dave Weaver N912GR --- On Mon, 5/27/13, J=F3hann J=F3hannsson wrote: From: J=F3hann J=F3hannsson <joeing701(at)simnet.is> Subject: Re: RotaxEngines-List: Hard start 912ULS To: rotaxengines-list(at)matronics.com Date: Monday, May 27, 2013, 5:06 AM =?iso-8859-1?Q?J=F3hann_J=F3hannsson?= Hello John. I had the same experience with my 912 UL starting. It turned out to be the starter like you suspect. Just to make sure, remove the starter and open it up. You will see some burned wire windings. This could happen if you let the started turn for too long. I replaced the starter with the "heavy duty" starter and everything has been working great since. Hope this helps, Johann G. Iceland. Zenith 701. On 27.5.2013, at 03:04, johnelling wrote: > > Starting my 912 has been increasingly difficult. it seems as if the starter has a hard time turning over the engine (it is a high-torque version). I thought it was a weak battery but the problem persists even if I add battery capacity. > > The last two attempts it sounds like the Bendix is not engaging much at all. Just a gear grinding sound and no prop turns. > > I suspect the starter motor. Anyone have another idea of something at which I should be looking and/or testing? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401401#401401 > > > > > > > > > > ?RotaxEngines-List" target=_blank>http://www.matronics.com/Navigator?Rotasp; - MATRONICS WEB FO/" ; -Matt Dralle, List Admin========= ________________________________________________________________________________
Date: May 27, 2013
I ordered my Sky Tech starter through Air Spruce.- I do not know where th e compay is located but use of on-line search engine will disclose that.- My 912-UL engine cranks like it is on steroids. Dave Weaver --- On Mon, 5/27/13, Hugh McKay wrote: From: Hugh McKay <hgmckay(at)bellsouth.net> Subject: Re: RotaxEngines-List: Hard start 912ULS Date: Monday, May 27, 2013, 7:00 AM Dave, - Is the Sky Tech firm you recommend located at the Rock Hill airport in SC? - Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com - From: David Weaver Sent: Monday, May 27, 2013 7:31 AM Subject: Re: RotaxEngines-List: Hard start 912ULS - I would highly recomend Sky Tech as a source for your starter.- They adve rtise lower cost, lower current draw, higher torque and lighter weight.- I am very pleased with my Sky Tech starter upgrade which was done to improv e winter time engine start-up. Dave Weaver N912GR --- On Mon, 5/27/13, J=F3hann J=F3hannsson wrote: From: J=F3hann J=F3hannsson <joeing701(at)simnet.is> Subject: Re: RotaxEngines-List: Hard start 912ULS Date: Monday, May 27, 2013, 5:06 AM hannsson?= Hello John. I had the same experience with my 912 UL starting. It turned out to be the starter like you suspect. Just to make sure, remove the starter and open it up. You will see some burned wire windings. This could happen if you let t he started turn for too long. I replaced the starter with the "heavy duty" starter and everything has bee n working great since. Hope this helps, Johann G. Iceland. Zenith 701. On 27.5.2013, at 03:04, johnelling wrote: com> > > Starting my 912 has been increasingly difficult.- it seems as if the st arter has a hard time turning over the engine (it is a high-torque version) .- I thought it was a weak battery but the problem persists even if I add battery capacity.- > > The last two attempts it sounds like the Bendix is not engaging much at a ll.- Just a gear grinding sound and no prop turns.- > > I suspect the starter motor.- Anyone have another idea of something at which I should be looking and/or testing? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401401#401401 > > > > > > > > > > ?RotaxEngines-List" target=_blank>http://www.matronics.com/Navigator?Ro tasp;------------- - MATRONICS WEB FO/" ;-- ------------ -Matt Dralle, List Admin==== ===== href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.ma tronics.com/Navigator?RotaxEngines-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: May 27, 2013
On 06:31 AM 5/27/2013, David Weaver wrote: >I ordered my Sky Tech starter through Air Spruce. I do not know where the compay is located but use of on-line search engine will disclose that. My 912-UL engine cranks like it is on steroids. http://www.skytecair.com/LSA.htm -- Bob Comperini e-mail: bob@fly-ul.com WWW: http://www.fly-ul.com ________________________________________________________________________________
Date: May 27, 2013
The other item that would help is what year engine Mfg is this and its hours? Did you actually try a new battery? Does it sound like the starter whirls, but the engine kind of lags behing or stops turning even when the starter is still turning. If the starter is turning fine then it is your sprag clutch associated with the starter and engine start. If people ever get kick back or turn their props backward it will trash the sprag clutch. The higher torque Rotax starter is gold in color and the older style is black. The black one isn't bad for the UL, but the ULS should have the high torque gold one. Changing the sprag will will encompass removal of the electrical end assembly. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401411#401411 ________________________________________________________________________________
Date: May 27, 2013
Subject: ACS Ignition Switch
During a take off run, following a mag check for normal RPM drop, the engin e miss-fired continuously following rotation and lift off.- I immediately pulled back on throttle and let the 912 XP settle for landing.- I-ran off-the end of runway (2,400 Feet)-with no damage.- Transition-from runway end to-farmer's freshly planted field was smooth (large wheel opt ion on Pulsar).- The problem turned out to be my failure to return the ig nition switch to full right position detente between "left" and "both" posi tions.- Though I initially had full power at the beginning of the take-of f run, vibration may have caused enough of a change in switch contact posit ion to-lead to-the problem.- When the Pulsar rolled to a stop, I sat quietly and reviewed my procedure and discovered the problem with the key p osition.- The problem has not reoccurred since that eventful flight.- I t seems logical that spring loading in the switch, if provided,-should ca use-the selector to-prefer one detente or-the nearest-and not settle on a mi d-position between detentes? Dave Weaver N912GR ________________________________________________________________________________
Date: May 29, 2013
Subject: repair vs new vs overhaul
Roger, My early s/n 912 in a model IV Kitfox shows evidence of right rear exhaust leakage at the head to exhaust pipe. Upon removal of the exhaust system I note that both rear exhaust pipes are sloppy in their fit to the heads, so I suspect an overheat problem, at least right at the exhaust ports?? So I bet I am in for two new heads (ouch $) and two new exhaust pipe ends welded onto the existing pipes. Does this sound right? Oh, the two rear exhaust pipes do not push up into the front head exhaust ports, probably because of a bit of exhaust crud build up on the old pipes, however the pipes do look round to my lay person's eye with a bit of surface crud on the outside where they fit into the exhaust port. I bought the plane about 15 years ago with 60 hours at that time, have flown it another roughly 400 and have never seen any indication of overheating on gauges, no leaking of oil at heads indicating warpage of heads nor has the coolant boiled over at least since I have owned it? So next question, what might be the cause? If I put two new heads on is the problem likely to recur? Any guidance here could be very useful. Since new heads are expensive, what are the rules of thumb about just selling the engine and getting a "factory overhaul" if such exists, or getting aa new engine on exchange from Rotax? I recall hearing that Rotax offered a "good deal" on new engines in exchange for old engines, if the case of the old engine is good? I bet others would be interested in some general guidelines on this from a trained and experienced Rotax specialist such as yourself. Thanks in advance for any guidance! BJ Kitfox IV 1050, Rotax 912 bjones(at)dmv.com 443-480-1023 > > Hi Hugh, > > The problem has been that not everyone has a gascolator or a fuel filter > far enough downstream. the main hose offenders isn't from hose before the > fuel pump because it has a filter screen inside, but from hose past the > pump. The fuel hose from the pump pressure side out is a problem at times. > Some 912's have the stainless steel lines mounted from the fuel > distribution block mounted on the carb balance tube, some don't. Some have > the red Teflon fuel line from this point and some have just rubber fuel > line right out of the pump to the carbs. > > Read this and you'll get a better handle on what some of the issues have > been. My original post here was to just give you another tool in your > mental toolbox for the "just in case" scenario. > > http://www.rotax-owner.com/rotax-blog/item/21-rotax-5-year-rubber-replacement-the-installation-considerations > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=399964#399964 > > ________________________________________________________________________________
Subject: Re: repair vs new vs overhaul
From: Pete Christensen <pchristensen10(at)austin.rr.com>
Date: May 29, 2013
Your not flying enough. ;-) Pete On May 29, 2013, at 11:09 AM, bjones(at)dmv.com wrote: > > Roger, > > My early s/n 912 in a model IV Kitfox shows evidence of right rear exhaust > leakage at the head to exhaust pipe. > > Upon removal of the exhaust system I note that both rear exhaust pipes are > sloppy in their fit to the heads, so I suspect an overheat problem, at > least right at the exhaust ports?? > > So I bet I am in for two new heads (ouch $) and two new exhaust pipe ends > welded onto the existing pipes. Does this sound right? > > Oh, the two rear exhaust pipes do not push up into the front head exhaust > ports, probably because of a bit of exhaust crud build up on the old > pipes, however the pipes do look round to my lay person's eye with a bit > of surface crud on the outside where they fit into the exhaust port. > > I bought the plane about 15 years ago with 60 hours at that time, have > flown it another roughly 400 and have never seen any indication of > overheating on gauges, no leaking of oil at heads indicating warpage of > heads nor has the coolant boiled over at least since I have owned it? > > So next question, what might be the cause? If I put two new heads on is > the problem likely to recur? Any guidance here could be very useful. > > Since new heads are expensive, what are the rules of thumb about just > selling the engine and getting a "factory overhaul" if such exists, or > getting aa new engine on exchange from Rotax? I recall hearing that Rotax > offered a "good deal" on new engines in exchange for old engines, if the > case of the old engine is good? > > I bet others would be interested in some general guidelines on this from a > trained and experienced Rotax specialist such as yourself. > > Thanks in advance for any guidance! > > BJ > Kitfox IV 1050, Rotax 912 > bjones(at)dmv.com > 443-480-1023 > > > > >> >> Hi Hugh, >> >> The problem has been that not everyone has a gascolator or a fuel filter >> far enough downstream. the main hose offenders isn't from hose before the >> fuel pump because it has a filter screen inside, but from hose past the >> pump. The fuel hose from the pump pressure side out is a problem at times. >> Some 912's have the stainless steel lines mounted from the fuel >> distribution block mounted on the carb balance tube, some don't. Some have >> the red Teflon fuel line from this point and some have just rubber fuel >> line right out of the pump to the carbs. >> >> Read this and you'll get a better handle on what some of the issues have >> been. My original post here was to just give you another tool in your >> mental toolbox for the "just in case" scenario. >> >> http://www.rotax-owner.com/rotax-blog/item/21-rotax-5-year-rubber-replacement-the-installation-considerations >> >> -------- >> Roger Lee >> Tucson, Az. >> Light Sport Repairman - Maintenance Rated >> Rotax Repair Center - Heavy Maint. Rated >> Home 520-574-1080 TRY HOME FIRST >> Cell 520-349-7056 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=399964#399964 > > > > > > ________________________________________________________________________________
Date: May 29, 2013
Subject: Touring USA with folding wing plane and RV
Pete, You are right, I don't fly enough. On the flip side of that coin the flying that I do in the Kitfox is pretty unusual and spectacular. Each year I spend several weeks at a time in great flying locations, flying low and slow down in the scenery in Monument Valley, Canyon Lands, Valley of the Gods, Lake Powell, the Florida Keys, the Down East Maine coast line, in the Grand Canyon, along the Texas Gulf Coast playing on those desolate beaches, among many other beautiful spots. For the last ten years or so, I have towed the Kitfox in an enclosed car trailer-mobile hanger-shop behind a slick little motorhome, flying at these great locations when the weather is near perfect and enjoying touring by road in the little motorhome otherwise. (With over a decade of doing this I have learned a lot in terms of trailer selection, protecting the plane while towing, accessing airports or "getting thru the airport gate after 911", quick and easy loading and loading the plane from the trailer, saving on costs and where to enjoy flying. At the suggestion of EAA's Sport Plane representative, Ron Wagner, and EAA's senior magazine editor, Mary Jones, I recently started sharing my love of flying by doing forums at Sun N Fun, Sebring Sport Plane Expo, etc. on "Tips On How To Tow Your Folding Wing Plane and Tour The USA By LSA And Chevrolet". ) Being retired - Life Is Good! BJ Kitfox IV 1050 Rotax 912 80hp > > > Your not flying enough. ;-) > > Pete > > > On May 29, 2013, at 11:09 AM, bjones(at)dmv.com wrote: > >> >> Roger, >> >> My early s/n 912 in a model IV Kitfox shows evidence of right rear >> exhaust >> leakage at the head to exhaust pipe. >> >> Upon removal of the exhaust system I note that both rear exhaust pipes >> are >> sloppy in their fit to the heads, so I suspect an overheat problem, at >> least right at the exhaust ports?? >> >> So I bet I am in for two new heads (ouch $) and two new exhaust pipe >> ends >> welded onto the existing pipes. Does this sound right? >> >> Oh, the two rear exhaust pipes do not push up into the front head >> exhaust >> ports, probably because of a bit of exhaust crud build up on the old >> pipes, however the pipes do look round to my lay person's eye with a bit >> of surface crud on the outside where they fit into the exhaust port. >> >> I bought the plane about 15 years ago with 60 hours at that time, have >> flown it another roughly 400 and have never seen any indication of >> overheating on gauges, no leaking of oil at heads indicating warpage of >> heads nor has the coolant boiled over at least since I have owned it? >> >> So next question, what might be the cause? If I put two new heads on is >> the problem likely to recur? Any guidance here could be very useful. >> >> Since new heads are expensive, what are the rules of thumb about just >> selling the engine and getting a "factory overhaul" if such exists, or >> getting aa new engine on exchange from Rotax? I recall hearing that >> Rotax >> offered a "good deal" on new engines in exchange for old engines, if the >> case of the old engine is good? >> >> I bet others would be interested in some general guidelines on this from >> a >> trained and experienced Rotax specialist such as yourself. >> >> Thanks in advance for any guidance! >> >> BJ >> Kitfox IV 1050, Rotax 912 >> bjones(at)dmv.com >> 443-480-1023 ________________________________________________________________________________
Date: May 29, 2013
Hi BJ, I doubt that high temp issue caused this. The most likely cause is the pulsation from the exhaust causes the tubes to vibrate and move which wears down the metal. Some wear completely through. I would bet your engine is just fine and wouldn't think about a new one or rebuilding. I would however replace the exhaust. The joints should be lubed every couple hundred hours with copper anti seize. Also make sure any nuts, bolts and springs on the exhaust are tight and or up at torque. This will help eliminate the wear. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401548#401548 ________________________________________________________________________________
Date: May 30, 2013
Subject: Re: Touring USA with folding wing plane and RV
Gday, Here's another example of touring the USA with a folding aircraft in a trailer towed behind an RV. http://www.tailwindsplease.com/usa-flyingroad-trip/ A great trip! JG ________________________________________________________________________________
Date: May 30, 2013
You beaut! :) Seriously thats inspiring.... Thanks for sharing! On May 30, 2013, at 10:08, JC Gilpin wrote: > > Gday, > > Here's another example of touring the USA with a folding aircraft in a tra iler towed behind an RV. > http://www.tailwindsplease.com/usa-flyingroad-trip/ > > A great trip! > > JG > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: May 30, 2013
RV
JG, Enjoyed the usa-flyingroad-trip We have a lot of sights and scenery in common. BJ > Gday, > > Here's another example of touring the USA with a folding aircraft in a > trailer towed behind an RV. > http://www.tailwindsplease.com/usa-flyingroad-trip/ > > A great trip! > > JG > ________________________________________________________________________________
Subject: Rotax 912 exhaust pipe repair
Date: Jun 10, 2013
The co-pilot side rear exhaust pipe cracked on me this weekend. I called a few shops to have it repaired (overhauled), but it seems none of them work on the smaller diameter piping. Rotax is 1 1/4 inch? The lead time for a new replacement from the factory (Diamond) is about 10 weeks. I looked thru the Rotax parts manual and saw their are 2 different pipes and some kits. Mine is stainless steel. How are 912 owners fabricating their exhausts? What shops will do this. thanks for any info. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402426#402426 ________________________________________________________________________________
Subject: Re: Rotax 912 exhaust pipe repair
Date: Jun 10, 2013
Try Travis Kobush. Kobushweldingandmachining.com Regards, Damien N48TK Sent from my iPad On Jun 10, 2013, at 4:40 PM, "JohnE" wrote: > > The co-pilot side rear exhaust pipe cracked on me this weekend. I called a few shops to have it repaired (overhauled), but it seems none of them work on the smaller diameter piping. Rotax is 1 1/4 inch? > > The lead time for a new replacement from the factory (Diamond) is about 10 weeks. I looked thru the Rotax parts manual and saw their are 2 different pipes and some kits. Mine is stainless steel. How are 912 owners fabricating their exhausts? What shops will do this. > > thanks for any info. > > John > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402426#402426 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 10, 2013
I just had Precision Welding in Sebring weld new ends (that got into the heads) onto my existing exhaust pipes for a Kitfox IV with early 912. Lockwood apparently has used them for this specific type of job. And the lady welder said she had done "millions" of these end replacements. The ends were Rotax parts from Lockwood. Not sure about fabrication of new exhaust systems. BJ Kitfox IV 912 > > > Try Travis Kobush. Kobushweldingandmachining.com > Regards, > Damien > N48TK > > Sent from my iPad > > On Jun 10, 2013, at 4:40 PM, "JohnE" wrote: > >> >> The co-pilot side rear exhaust pipe cracked on me this weekend. I >> called a few shops to have it repaired (overhauled), but it seems none >> of them work on the smaller diameter piping. Rotax is 1 1/4 inch? >> >> The lead time for a new replacement from the factory (Diamond) is about >> 10 weeks. I looked thru the Rotax parts manual and saw their are 2 >> different pipes and some kits. Mine is stainless steel. How are 912 >> owners fabricating their exhausts? What shops will do this. >> >> thanks for any info. >> >> John >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=402426#402426 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jun 10, 2013
Keep LQQKing John: All you need is a Welding Shop that can do Thin Wall Stainless Steel. AND ask them to put a PATCH over the crack. Do not let them just weld the crack. Weld the crack and Patch for strength. *Barry* On Mon, Jun 10, 2013 at 4:40 PM, JohnE wrote: > > The co-pilot side rear exhaust pipe cracked on me this weekend. I called > a few shops to have it repaired (overhauled), but it seems none of them > work on the smaller diameter piping. Rotax is 1 1/4 inch? > > The lead time for a new replacement from the factory (Diamond) is about 10 > weeks. I looked thru the Rotax parts manual and saw their are 2 different > pipes and some kits. Mine is stainless steel. How are 912 owners > fabricating their exhausts? What shops will do this. > > thanks for any info. > > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402426#402426 > > ________________________________________________________________________________
Date: Jun 10, 2013
Thanks for the info. The crack in this case cut the pipe into 2 pieces. It does look like another section of pipe could be put over it and then welded if thats how they would do it. [quote="BARRY CHECK 6"]Keep LQQKing John: All you need is a Welding Shop that can do Thin Wall Stainless Steel. AND ask them to put a PATCH over the crack. Do not let them just weld the crack. Weld the crack and Patch for strength. Barry On Mon, Jun 10, 2013 at 4:40 PM, JohnE wrote: > > The co-pilot side rear exhaust pipe cracked on me this weekend. I called a few shops to have it repaired (overhauled), but it seems none of them work on the smaller diameter piping. Rotax is 1 1/4 inch? > > The lead time for a new replacement from the factory (Diamond) is about 10 weeks. I looked thru the Rotax parts manual and saw their are 2 different pipes and some kits. Mine is stainless steel. How are 912 owners fabricating their exhausts? What shops will do this. > > thanks for any info. > > John > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402426#402426 (http://forums.matronics.com/viewtopic.php?p=402426#402426) > > > > > > > > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402442#402442 ________________________________________________________________________________
Date: Jun 11, 2013
John, After you get the tube repaired, make sure you do a pneumatic synchronization of the carbs. Unbalanced carbs add a lot of unnecessary vibration to the whole powerplant. Our DA20-A1 has 1100+ hours on its second engine (F3) and no cracks. I check the balance during every annual inspection. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402472#402472 ________________________________________________________________________________
Subject: Hi CHT on the Rotax 912uls
Date: Jun 12, 2013
A lot has been said about the 912uls cooling. I have had CHT temps over 240 degF for over 2 years in the summer. Not to red line but Not Comfortable to fly any distance with. I have over 1100 hours on my Kitfox S7 and my Evans "lifetime" coolant and was ready for a change. I read an article, (I think by Roger) about using 50/50 Antifreeze instead of Evans would reduce bring the temps by 25 to 30 degrees. It works!!!! My CHT and Coolant Temp are down 25 degrees today with the same OAT as when they were in the 240 range. I am ready to take a summer trip again. BTW, I chose Prestone DexCool (Orange). Thanks Roger -------- Rich Little N812RL S-7 912ULS North Idaho Kiev Prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402577#402577 ________________________________________________________________________________
Subject: Re: Hi CHT on the Rotax 912uls
Date: Jun 12, 2013
Your Welcome. Evans isn't a bad coolant it just comes with a temp penalty. I wouldn't use it unless my engine was an open air engine. These newer tight cowled aircraft just don't help out much for cooling. To help keep down radiated and convective heat on the inside of the cowl on all the hoses and wiring you can use some header wrap on the exhaust pipes from the head down and under the springs. Many of us have been doing this for 10+ years without any issues. The header wrap can be purchased from most automotive stores. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402590#402590 ________________________________________________________________________________
Date: Jun 13, 2013
In a related matter, I have a Kitfox IV with 912 that has dual coolant temp sending units and matched UMA gauges. The sending unit mounted in the coolant line (supplied by Lockwood) reads about ten degrees cooler than the sending unit and gauge combination mounted in the cylinder head. I have switched wires between sending units and gauges just to make sure there is not a discrepancy between sending units and gauges. BJ Kitfox IV 80 hp 912 > > A lot has been said about the 912uls cooling. I have had CHT temps over > 240 degF for over 2 years in the summer. Not to red line but Not > Comfortable to fly any distance with. I have over 1100 hours on my Kitfox > S7 and my Evans "lifetime" coolant and was ready for a change. I read an > article, (I think by Roger) about using 50/50 Antifreeze instead of Evans > would reduce bring the temps by 25 to 30 degrees. > > It works!!!! My CHT and Coolant Temp are down 25 degrees today with the > same OAT as when they were in the 240 range. I am ready to take a summer > trip again. BTW, I chose Prestone DexCool (Orange). Thanks Roger > > -------- > Rich Little > N812RL S-7 912ULS > North Idaho > Kiev Prop > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402577#402577 > > ________________________________________________________________________________
Date: Jun 13, 2013
There will be a few degrees difference. One is reading the actual water temp at that specific point and the other the metal temp at a totally different point. Rotax considers anything like your 10 degrees to be more or less the same. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402609#402609 ________________________________________________________________________________
Date: Jun 13, 2013
Thom Riddle wrote: > John, > > After you get the tube repaired, make sure you do a pneumatic synchronization of the carbs. Unbalanced carbs add a lot of unnecessary vibration to the whole powerplant. Our DA20-A1 has 1100+ hours on its second engine (F3) and no cracks. I check the balance during every annual inspection. Hi Thom, Thanks for the advice. I'm using the downtime to send my carbs in for overhaul and then will do a pneumatic synch when I get them back. My engine seems pretty smooth, but in aviation, smooth is relative. :-) Good to hear from another DA20-A1 owner. There are not too many left in the US. -John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402623#402623 ________________________________________________________________________________
Date: Jun 13, 2013
...There are not too many left in the US.... Quite true. Many DA20-A1 owners sold them to buyers in Europe where their excellent fuel economy and Rotax engines are considered virtues. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402624#402624 ________________________________________________________________________________
Date: Jun 14, 2013
Subject: Erratic voltage output
I'm having an erratic voltage output problem on my 912UL powered CH-701.- =0A=0ATo try and fix the problem I have replaced the voltage regulator and verified I have no loose connections in the electrical system.- Even wit h a new regulator I am still getting the same voltage spikes when at full p ower.- At idle and during run-up the voltage reading on my analog VDO vol tmeter is rock solid.- It indicates about 14 volts once up off of idle po wer and my digital voltmeter show about 13.6 Volts.- Once I apply takeoff power the analog voltmeter needle starts to vibrate wildly plus and minus about 1-2 volts and the digital voltmeter becomes unstable.- If I am flyi ng with a light electrical load, the digital voltmeter tops out at just ove r 14 volts but drifts around as low as 13.7.- If I put on my nav and stro be lights the voltage drops to 13.3-13.6 range but the needle on the analog meter continues to vibrate the same.=0A=0AThe only other components (besid e the regulator) in the electrical system I can think of which might be cau sing the voltage spikes are the capacitor or a problem with the actual alte rnator coils.- I thought the problem may have been a bad analog gauge but given that the digital readings are also erratic I believe it to be a legi timate issue and not simply a display problem.=0A=0AI'm pretty good at chas ing electrons but this issue has me stumped.- Anyone have any ideas what could be causing my erratic voltage output?=0A=0ADoug MacDonald=0ACH-701, N orthwestern Ontario ________________________________________________________________________________
Date: Jun 14, 2013
Subject: Re: Erratic voltage output
Doug: 1. Being that your Analog Gauge is vibrating indicates that you may have a Vibration issue... Such as being in need of a Dynamic Prop Balance. 2. For a battery to charge you need 13.8 to 14.2 VDC - Less than that you are not charging. 3. Being that the voltage is correct at idle and fluxuates at cruise speed could be an indication of (a) A heat issue or (b) A vibration issue or (c) Both 4. There are a few funky issues with Rotax and their internal voltage production - Too Bad Rotax has never solved this problem. *Barry* *"Pilots think they are mechanics, because they can buy tools at Home Depot."* On Fri, Jun 14, 2013 at 10:44 AM, MacDonald Doug wrote: > I'm having an erratic voltage output problem on my 912UL powered CH-701. > > To try and fix the problem I have replaced the voltage regulator and > verified I have no loose connections in the electrical system. Even with a > new regulator I am still getting the same voltage spikes when at full > power. At idle and during run-up the voltage reading on my analog VDO > voltmeter is rock solid. It indicates about 14 volts once up off of idle > power and my digital voltmeter show about 13.6 Volts. Once I apply takeoff > power the analog voltmeter needle starts to vibrate wildly plus and minus > about 1-2 volts and the digital voltmeter becomes unstable. If I am flying > with a light electrical load, the digital voltmeter tops out at just over > 14 volts but drifts around as low as 13.7. If I put on my nav and strobe > lights the voltage drops to 13.3-13.6 range but the needle on the analog > meter continues to vibrate the same. > > The only other components (beside the regulator) in the electrical system > I can think of which might be causing the voltage spikes are the capacitor > or a problem with the actual alternator coils. I thought the problem may > have been a bad analog gauge but given that the digital readings are also > erratic I believe it to be a legitimate issue and not simply a display > problem. > > I'm pretty good at chasing electrons but this issue has me stumped. > Anyone have any ideas what could be causing my erratic voltage output? > > Doug MacDonald > CH-701, Northwestern Ontario > > * > > * > > ________________________________________________________________________________
Date: Jun 14, 2013
Hi Doug, This happens when the ground is poor. Try a test. leave the existing ground in place and install a more direct and solid ground from the battery, to the engine to the wiring ground block for the plane. I have had numerous issues like this I cured by installing a much more direct and solid ground. It won't hurt to try it and rule it out as a factor. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402709#402709 ________________________________________________________________________________
Date: Jun 15, 2013
Hi Doug You stated you have no loose contacts, you could have a poor contact. Two years ago I had an intermittent charging problem that took two day to trace. It was in an in-line fuse holder, the rubber coated ones that take ATC fuses. The fuse looked fairly normal but when I cut the holder open it was corroded and burnt. Replaced problem gone. Carl ----- Original Message ----- From: MacDonald Doug To: rotax list Sent: Friday, June 14, 2013 10:44 AM Subject: RotaxEngines-List: Erratic voltage output I'm having an erratic voltage output problem on my 912UL powered CH-701. To try and fix the problem I have replaced the voltage regulator and verified I have no loose connections in the electrical system. Even with a new regulator I am still getting the same voltage spikes when at full power. At idle and during run-up the voltage reading on my analog VDO voltmeter is rock solid. It indicates about 14 volts once up off of idle power and my digital voltmeter show about 13.6 Volts. Once I apply takeoff power the analog voltmeter needle starts to vibrate wildly plus and minus about 1-2 volts and the digital voltmeter becomes unstable. If I am flying with a light electrical load, the digital voltmeter tops out at just over 14 volts but drifts around as low as 13.7. If I put on my nav and strobe lights the voltage drops to 13.3-13.6 range but the needle on the analog meter continues to vibrate the same. The only other components (beside the regulator) in the electrical system I can think of which might be causing the voltage spikes are the capacitor or a problem with the actual alternator coils. I thought the problem may have been a bad analog gauge but given that the digital readings are also erratic I believe it to be a legitimate issue and not simply a display problem. I'm pretty good at chasing electrons but this issue has me stumped. Anyone have any ideas what could be causing my erratic voltage output? Doug MacDonald CH-701, Northwestern Ontario ________________________________________________________________________________
From: "Paul Grimstad" <paul(at)controlapproach.com>
Date: Jun 16, 2013
We have been experiencing wild fluctuations on the amperage meter, running a 912uls with Dynon 180 EFIS engine monitor. The spikes range from +5 to -6. Voltage is also high (high 13's), but then it seems to settle down after takeoff. I thought the high voltage maybe because we just installed a new battery. We also just installed a new voltage regulator and when we grounded the plane and took a look at the condition we found the two power leads going into the regulator were completely melted and the heat was starting to melt the plastic mounting socket on the Ducati voltage regulator. We replaced the spade connectors on the main power leads and replaced the wiring socket plug-in connector as well. We had heard that the Rotax engine electronic system is very sensitive to the requirement of the ground connection, so additionally we ran a 10ga copper wire from the base lug on the voltage regulator to the negative terminal connecting stud at the battery/airframe. This has not solved the problem. I flew 7hours last weekend and near the end of the flight time, I noticed the amp gauge still jumping up and down. I have spoken with several knowledgeable Rotax guys and both asked me if I ran the ground from the base of the voltage regulator directly to the engine block? So, this afternoon I removed the wire socket plug connector and inspected the wire ends and crimped connectors. There was no sign of heat damage, so I reconnected the primary connection plug. I made up another ground wire with soldered wire ends and waterproof shrink tubing. I then installed the new ground wire from the mounting bolt on the base of the voltage regulator directly to the engine block. Tomorrow I will run the engine and see if the problem is solved. Hope this helps, I will let you know how it goes. Paul Grimstad, Team RV12 Portland, OR From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Carl Sent: Saturday, June 15, 2013 1:25 PM Subject: Re: RotaxEngines-List: Erratic voltage output Hi Doug You stated you have no loose contacts, you could have a poor contact. Two years ago I had an intermittent charging problem that took two day to trace. It was in an in-line fuse holder, the rubber coated ones that take ATC fuses. The fuse looked fairly normal but when I cut the holder open it was corroded and burnt. Replaced problem gone. Carl ----- Original Message ----- From: MacDonald Doug <mailto:dougsnash(at)yahoo.com> Sent: Friday, June 14, 2013 10:44 AM Subject: RotaxEngines-List: Erratic voltage output I'm having an erratic voltage output problem on my 912UL powered CH-701. To try and fix the problem I have replaced the voltage regulator and verified I have no loose connections in the electrical system. Even with a new regulator I am still getting the same voltage spikes when at full power. At idle and during run-up the voltage reading on my analog VDO voltmeter is rock solid. It indicates about 14 volts once up off of idle power and my digital voltmeter show about 13.6 Volts. Once I apply takeoff power the analog voltmeter needle starts to vibrate wildly plus and minus about 1-2 volts and the digital voltmeter becomes unstable. If I am flying with a light electrical load, the digital voltmeter tops out at just over 14 volts but drifts around as low as 13.7. If I put on my nav and strobe lights the voltage drops to 13.3-13.6 range but the needle on the analog meter continues to vibrate the same. The only other components (beside the regulator) in the electrical system I can think of which might be causing the voltage spikes are the capacitor or a problem with the actual alternator coils. I thought the problem may have been a bad analog gauge but given that the digital readings are also erratic I believe it to be a legitimate issue and not simply a display problem. I'm pretty good at chasing electrons but this issue has me stumped. Anyone have any ideas what could be causing my erratic voltage output? Doug MacDonald CH-701, Northwestern Ontario href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matro nics.com/Navigator?RotaxEngines-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 17, 2013
So, my troubleshooting saga continues.- The first thing I did was run an 18ga ground wire from the regulator body to the negative terminal of the ca pacitor which then goes to the firewall buss bar.- When this did not solv e the erratic output issue I replaced the regulator.- Neither of these st eps helped the problem.- =0A-=0AMy engine ground lead is an 8ga wire ru nning from a lug on the top of the right rear cylinder to the ground lead o n the firewall buss.- From the firewall buss, both the positive and negat ive leads are 8ga wire and go to my main buss which is mounted behind the i nstrument panel.- From the main buss the positive and negative leads are 8ga and run down the passenger side of the airframe to the battery which is located behind the passenger seat.- At the battery the ground wire attac hes to an airframe ground point on the battery mount frame then through an 8ga wire to the negative post.- The positive lead goes to the master sole noid and then to the positive post of the battery (all 8ga).- As per Roge r's suggestion, I have been pulling each of these main power leads one term inal at a time and thoroughly cleaning the connections.- So far I have go tten to the main buss and firewall buss but still need to clean the connect ions at the battery.- While I have found some oxidization, I have thus far found no corrosion which could be causing my erratic output issue.=0A-=0AToday after work I will pull the b elly pan off of the plane and clean all of the connections at the battery. - I also want to pull the connections of the charge lead from the voltage regulator to the-ALT circuit breaker and main buss to verify they are ok ay. -So far , however, I'm not seeing anything that could be the source o f my problem.- My CH-701 is almost three years old and has just shy of 20 0 hours on it.- This voltage issue is has come on gradually over the last few months as the output has been-stable until I noticed the needle gyra tions in about March when my flying hours began to pick up.=0A-=0AOne oth er thing I am going to try is a new capacitor.- Lockwood sells an afterma rket 22000MF cap for $35.00 so I figured I may as well try it.- My capaci tor is about ten years old with an unknown history so it is possible that i s has started to go bad.- I also might try a different ground wire locati on on the engine.- Perhaps the cylinder head is not an ideal ground locat ion.=0A-=0AAny other suggestions?=0A-=0ADoug M=0ACH-701 from scratch=0A aul(at)controlapproach.com>=0ASubject: RE: RotaxEngines-List: Erratic voltage output=0A=0AWe have been experiencing wild fluctuations on the amperage met er, running a=0A912uls with Dynon 180 EFIS engine monitor. The spikes range from +5 to -6.=0AVoltage is also high (high 13's), but then it seems to se ttle down after=0Atakeoff. I thought the high voltage maybe because we just installed a new=0Abattery.=0A=0AWe also just installed a new voltage regul ator and when we grounded the=0Aplane and took a look at the condition we f ound the two power leads going=0Ainto the regulator were completely melted and the heat was starting to melt=0Athe plastic mounting socket on the Duca ti voltage regulator. We replaced the=0Aspade connectors on the main power leads and replaced the wiring socket=0Aplug-in connector as well. =0A=0AWe had heard that the Rotax engine electronic system is very sensitive to=0Ath e requirement of the ground connection, so additionally we ran a 10ga=0Acop per wire from the base lug on the voltage regulator to the negative=0Atermi nal connecting stud at the battery/airframe. This has not solved the=0Aprob lem. I flew 7hours last weekend and near the end of the flight time, I=0Ano ticed the amp gauge still jumping up and down.=0A=0AI have spoken with seve ral knowledgeable Rotax guys and both asked me if I=0Aran the ground from t he base of the voltage regulator directly to the engine=0Ablock?=0A=0ASo, t his afternoon I removed the wire socket plug connector and inspected=0Athe wire ends and crimped connectors. There was no sign of heat damage, so I=0A reconnected the primary connection plug. I made up another ground wire with =0Asoldered wire ends and waterproof shrink tubing. I then installed the ne w=0Aground wire from the mounting bolt on the base of the voltage regulator =0Adirectly to the engine block. Tomorrow I will run the engine and see if the=0Aproblem is solved.=0A=0AHope this helps, I will let you know how it g oes.=0A=0APaul Grimstad,=0A=0ATeam RV12=0A=0APortland, OR----- ________________________________________________________________________________
Date: Jun 17, 2013
Hi Doug, The ground wire on the cyl. head should be just fine. Many of us use it and it seems to work without any issues. I have those capacitors and they are $20. Same as Lockwood or anyone else unless you go to the super-sized model with finger nuts on top instead of soldering the terminals on, but those are about triple or more the price. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402853#402853 ________________________________________________________________________________
Date: Jun 17, 2013
SSB3b3VsZCBwdWxsIGFuZCBpbnNwZWN0IHRoZSBzcGFkZSBjb25uZWN0aW9ucyB0byB0aGUgdm9s dGFnZSByZWd1bGF0b3IuwqAKSm9obiBzdWdnZXN0ZWQgdGhlIGNhcGFjaXRvciBtaWdodCBiZSBh biBpc3N1ZS4gwqBJIGRvbid0IGtub3cgd2hlcmUgdGhhdCBpcyBsb2NhdGVkLiBDYW4geW91IHRl c3Qgd2l0aCBmcmVlemUgc3ByYXk/CgotLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0t CkZyb206IE1hY0RvbmFsZCBEb3VnIDxkb3Vnc25hc2hAeWFob28uY29tPiAKRGF0ZTogMDYvMTcv MjAxMyAgNDowNyBBTSAgKEdNVC0wODowMCkgClRvOiByb3RheGVuZ2luZXMtbGlzdEBtYXRyb25p Y3MuY29tIApTdWJqZWN0OiBSb3RheEVuZ2luZXMtTGlzdDogUmU6IEVycmF0aWMgdm9sdGFnZSBv dXRwdXQgCiAKU28sIG15IHRyb3VibGVzaG9vdGluZyBzYWdhIGNvbnRpbnVlcy7CoCBUaGUgZmly c3QgdGhpbmcgSSBkaWQgd2FzIHJ1biBhbiAxOGdhIGdyb3VuZCB3aXJlIGZyb20gdGhlIHJlZ3Vs YXRvciBib2R5IHRvIHRoZSBuZWdhdGl2ZSB0ZXJtaW5hbCBvZiB0aGUgY2FwYWNpdG9yIHdoaWNo IHRoZW4gZ29lcyB0byB0aGUgZmlyZXdhbGwgYnVzcyBiYXIuwqAgV2hlbiB0aGlzIGRpZCBub3Qg c29sdmUgdGhlIGVycmF0aWMgb3V0cHV0IGlzc3VlIEkgcmVwbGFjZWQgdGhlIHJlZ3VsYXRvci7C oCBOZWl0aGVyIG9mIHRoZXNlIHN0ZXBzIGhlbHBlZCB0aGUgcHJvYmxlbS7CoArCoApNeSBlbmdp bmUgZ3JvdW5kIGxlYWQgaXMgYW4gOGdhIHdpcmUgcnVubmluZyBmcm9tIGEgbHVnIG9uIHRoZSB0 b3Agb2YgdGhlIHJpZ2h0IHJlYXIgY3lsaW5kZXIgdG8gdGhlIGdyb3VuZCBsZWFkIG9uIHRoZSBm aXJld2FsbCBidXNzLsKgIEZyb20gdGhlIGZpcmV3YWxsIGJ1c3MsIGJvdGggdGhlIHBvc2l0aXZl IGFuZCBuZWdhdGl2ZSBsZWFkcyBhcmUgOGdhIHdpcmUgYW5kIGdvIHRvIG15IG1haW4gYnVzcyB3 aGljaCBpcyBtb3VudGVkIGJlaGluZCB0aGUgaW5zdHJ1bWVudCBwYW5lbC7CoCBGcm9tIHRoZSBt YWluIGJ1c3MgdGhlIHBvc2l0aXZlIGFuZCBuZWdhdGl2ZSBsZWFkcyBhcmUgOGdhIGFuZCBydW4g ZG93biB0aGUgcGFzc2VuZ2VyIHNpZGUgb2YgdGhlIGFpcmZyYW1lIHRvIHRoZSBiYXR0ZXJ5IHdo aWNoIGlzIGxvY2F0ZWQgYmVoaW5kIHRoZSBwYXNzZW5nZXIgc2VhdC7CoCBBdCB0aGUgYmF0dGVy eSB0aGUgZ3JvdW5kIHdpcmUgYXR0YWNoZXMgdG8gYW4gYWlyZnJhbWUgZ3JvdW5kIHBvaW50IG9u IHRoZSBiYXR0ZXJ5IG1vdW50IGZyYW1lIHRoZW4gdGhyb3VnaCBhbiA4Z2Egd2lyZSB0byB0aGUg bmVnYXRpdmUgcG9zdC7CoCBUaGUgcG9zaXRpdmUgbGVhZCBnb2VzIHRvIHRoZSBtYXN0ZXIgc29s ZW5vaWQgYW5kIHRoZW4gdG8gdGhlIHBvc2l0aXZlIHBvc3Qgb2YgdGhlIGJhdHRlcnkgKGFsbCA4 Z2EpLsKgIEFzIHBlciBSb2dlcidzIHN1Z2dlc3Rpb24sIEkgaGF2ZSBiZWVuIHB1bGxpbmcgZWFj aCBvZiB0aGVzZSBtYWluIHBvd2VyIGxlYWRzIG9uZSB0ZXJtaW5hbCBhdCBhIHRpbWUgYW5kIHRo b3JvdWdobHkgY2xlYW5pbmcgdGhlIGNvbm5lY3Rpb25zLsKgIFNvIGZhciBJIGhhdmUgZ290dGVu IHRvIHRoZSBtYWluIGJ1c3MgYW5kIGZpcmV3YWxsIGJ1c3MgYnV0IHN0aWxsIG5lZWQgdG8gY2xl YW4gdGhlIGNvbm5lY3Rpb25zIGF0IHRoZSBiYXR0ZXJ5LsKgIFdoaWxlIEkgaGF2ZSBmb3VuZCBz b21lIG94aWRpemF0aW9uLCBJIGhhdmUgdGh1cyBmYXIgZm91bmQgbm8gY29ycm9zaW9uIHdoaWNo IGNvdWxkIGJlIGNhdXNpbmcgbXkgZXJyYXRpYyBvdXRwdXQgaXNzdWUuCsKgClRvZGF5IGFmdGVy IHdvcmsgSSB3aWxsIHB1bGwgdGhlIGJlbGx5IHBhbiBvZmYgb2YgdGhlIHBsYW5lIGFuZCBjbGVh biBhbGwgb2YgdGhlIGNvbm5lY3Rpb25zIGF0IHRoZSBiYXR0ZXJ5LsKgIEkgYWxzbyB3YW50IHRv IHB1bGwgdGhlIGNvbm5lY3Rpb25zIG9mIHRoZSBjaGFyZ2UgbGVhZCBmcm9tIHRoZSB2b2x0YWdl IHJlZ3VsYXRvciB0byB0aGXCoEFMVCBjaXJjdWl0IGJyZWFrZXIgYW5kIG1haW4gYnVzcyB0byB2 ZXJpZnkgdGhleSBhcmUgb2theS4gwqBTbyBmYXIgLCBob3dldmVyLCBJJ20gbm90IHNlZWluZyBh bnl0aGluZyB0aGF0IGNvdWxkIGJlIHRoZSBzb3VyY2Ugb2YgbXkgcHJvYmxlbS7CoCBNeSBDSC03 MDEgaXMgYWxtb3N0IHRocmVlIHllYXJzIG9sZCBhbmQgaGFzIGp1c3Qgc2h5IG9mIDIwMCBob3Vy cyBvbiBpdC7CoCBUaGlzIHZvbHRhZ2UgaXNzdWUgaXMgaGFzIGNvbWUgb24gZ3JhZHVhbGx5IG92 ZXIgdGhlIGxhc3QgZmV3IG1vbnRocyBhcyB0aGUgb3V0cHV0IGhhcyBiZWVuwqBzdGFibGUgdW50 aWwgSSBub3RpY2VkIHRoZSBuZWVkbGUgZ3lyYXRpb25zIGluIGFib3V0IE1hcmNoIHdoZW4gbXkg Zmx5aW5nIGhvdXJzIGJlZ2FuIHRvIHBpY2sgdXAuCsKgCk9uZSBvdGhlciB0aGluZyBJIGFtIGdv aW5nIHRvIHRyeSBpcyBhIG5ldyBjYXBhY2l0b3IuwqAgTG9ja3dvb2Qgc2VsbHMgYW4gYWZ0ZXJt YXJrZXQgMjIwMDBNRiBjYXAgZm9yICQzNS4wMCBzbyBJIGZpZ3VyZWQgSSBtYXkgYXMgd2VsbCB0 cnkgaXQuwqAgTXkgY2FwYWNpdG9yIGlzIGFib3V0IHRlbiB5ZWFycyBvbGQgd2l0aCBhbiB1bmtu b3duIGhpc3Rvcnkgc28gaXQgaXMgcG9zc2libGUgdGhhdCBpcyBoYXMgc3RhcnRlZCB0byBnbyBi YWQuwqAgSSBhbHNvIG1pZ2h0IHRyeSBhIGRpZmZlcmVudCBncm91bmQgd2lyZSBsb2NhdGlvbiBv biB0aGUgZW5naW5lLsKgIFBlcmhhcHMgdGhlIGN5bGluZGVyIGhlYWQgaXMgbm90IGFuIGlkZWFs IGdyb3VuZCBsb2NhdGlvbi4KwqAKQW55IG90aGVyIHN1Z2dlc3Rpb25zPwrCoApEb3VnIE0KQ0gt NzAxIGZyb20gc2NyYXRjaApOVyBPbnRhcmlvLCBDYW5hZGEKClRpbWU6IDExOjEwOjE5IFBNIFBT VCBVUwpGcm9tOiAiUGF1bCBHcmltc3RhZCIgPHBhdWxAY29udHJvbGFwcHJvYWNoLmNvbT4KU3Vi amVjdDogUkU6IFJvdGF4RW5naW5lcy1MaXN0OiBFcnJhdGljIHZvbHRhZ2Ugb3V0cHV0CgpXZSBo YXZlIGJlZW4gZXhwZXJpZW5jaW5nIHdpbGQgZmx1Y3R1YXRpb25zIG9uIHRoZSBhbXBlcmFnZSBt ZXRlciwgcnVubmluZyBhCjkxMnVscyB3aXRoIER5bm9uIDE4MCBFRklTIGVuZ2luZSBtb25pdG9y LiBUaGUgc3Bpa2VzIHJhbmdlIGZyb20gKzUgdG8gLTYuClZvbHRhZ2UgaXMgYWxzbyBoaWdoICho aWdoIDEzJ3MpLCBidXQgdGhlbiBpdCBzZWVtcyB0byBzZXR0bGUgZG93biBhZnRlcgp0YWtlb2Zm LiBJIHRob3VnaHQgdGhlIGhpZ2ggdm9sdGFnZSBtYXliZSBiZWNhdXNlIHdlIGp1c3QgaW5zdGFs bGVkIGEgbmV3CmJhdHRlcnkuCgpXZSBhbHNvIGp1c3QgaW5zdGFsbGVkIGEgbmV3IHZvbHRhZ2Ug cmVndWxhdG9yIGFuZCB3aGVuIHdlIGdyb3VuZGVkIHRoZQpwbGFuZSBhbmQgdG9vayBhIGxvb2sg YXQgdGhlIGNvbmRpdGlvbiB3ZSBmb3VuZCB0aGUgdHdvIHBvd2VyIGxlYWRzIGdvaW5nCmludG8g dGhlIHJlZ3VsYXRvciB3ZXJlIGNvbXBsZXRlbHkgbWVsdGVkIGFuZCB0aGUgaGVhdCB3YXMgc3Rh cnRpbmcgdG8gbWVsdAp0aGUgcGxhc3RpYyBtb3VudGluZyBzb2NrZXQgb24gdGhlIER1Y2F0aSB2 b2x0YWdlIHJlZ3VsYXRvci4gV2UgcmVwbGFjZWQgdGhlCnNwYWRlIGNvbm5lY3RvcnMgb24gdGhl IG1haW4gcG93ZXIgbGVhZHMgYW5kIHJlcGxhY2VkIHRoZSB3aXJpbmcgc29ja2V0CnBsdWctaW4g Y29ubmVjdG9yIGFzIHdlbGwuIAoKV2UgaGFkIGhlYXJkIHRoYXQgdGhlIFJvdGF4IGVuZ2luZSBl bGVjdHJvbmljIHN5c3RlbSBpcyB2ZXJ5IHNlbnNpdGl2ZSB0bwp0aGUgcmVxdWlyZW1lbnQgb2Yg dGhlIGdyb3VuZCBjb25uZWN0aW9uLCBzbyBhZGRpdGlvbmFsbHkgd2UgcmFuIGEgMTBnYQpjb3Bw ZXIgd2lyZSBmcm9tIHRoZSBiYXNlIGx1ZyBvbiB0aGUgdm9sdGFnZSByZWd1bGF0b3IgdG8gdGhl IG5lZ2F0aXZlCnRlcm1pbmFsIGNvbm5lY3Rpbmcgc3R1ZCBhdCB0aGUgYmF0dGVyeS9haXJmcmFt ZS4gVGhpcyBoYXMgbm90IHNvbHZlZCB0aGUKcHJvYmxlbS4gSSBmbGV3IDdob3VycyBsYXN0IHdl ZWtlbmQgYW5kIG5lYXIgdGhlIGVuZCBvZiB0aGUgZmxpZ2h0IHRpbWUsIEkKbm90aWNlZCB0aGUg YW1wIGdhdWdlIHN0aWxsIGp1bXBpbmcgdXAgYW5kIGRvd24uCgpJIGhhdmUgc3Bva2VuIHdpdGgg c2V2ZXJhbCBrbm93bGVkZ2VhYmxlIFJvdGF4IGd1eXMgYW5kIGJvdGggYXNrZWQgbWUgaWYgSQpy YW4gdGhlIGdyb3VuZCBmcm9tIHRoZSBiYXNlIG9mIHRoZSB2b2x0YWdlIHJlZ3VsYXRvciBkaXJl Y3RseSB0byB0aGUgZW5naW5lCmJsb2NrPwoKU28sIHRoaXMgYWZ0ZXJub29uIEkgcmVtb3ZlZCB0 aGUgd2lyZSBzb2NrZXQgcGx1ZyBjb25uZWN0b3IgYW5kIGluc3BlY3RlZAp0aGUgd2lyZSBlbmRz IGFuZCBjcmltcGVkIGNvbm5lY3RvcnMuIFRoZXJlIHdhcyBubyBzaWduIG9mIGhlYXQgZGFtYWdl LCBzbyBJCnJlY29ubmVjdGVkIHRoZSBwcmltYXJ5IGNvbm5lY3Rpb24gcGx1Zy4gSSBtYWRlIHVw IGFub3RoZXIgZ3JvdW5kIHdpcmUgd2l0aApzb2xkZXJlZCB3aXJlIGVuZHMgYW5kIHdhdGVycHJv b2Ygc2hyaW5rIHR1YmluZy4gSSB0aGVuIGluc3RhbGxlZCB0aGUgbmV3Cmdyb3VuZCB3aXJlIGZy b20gdGhlIG1vdW50aW5nIGJvbHQgb24gdGhlIGJhc2Ugb2YgdGhlIHZvbHRhZ2UgcmVndWxhdG9y CmRpcmVjdGx5IHRvIHRoZSBlbmdpbmUgYmxvY2suIFRvbW9ycm93IEkgd2lsbCBydW4gdGhlIGVu Z2luZSBhbmQgc2VlIGlmIHRoZQpwcm9ibGVtIGlzIHNvbHZlZC4KCkhvcGUgdGhpcyBoZWxwcywg SSB3aWxsIGxldCB5b3Uga25vdyBob3cgaXQgZ29lcy4KClBhdWwgR3JpbXN0YWQsCgpUZWFtIFJW MTIKClBvcnRsYW5kLCBPUsKgwqDCoMKgwqAgCgoKCgoKCgoKCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAt IFRoZSBSb3RheEVuZ2luZXMtTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmlj cyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRp bGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAm IERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBt dWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2 aWdhdG9yP1JvdGF4RW5naW5lcy1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgICAtIE1B VFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJs ZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIg U2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPSAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09ICAg LS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KCg= ________________________________________________________________________________
Date: Jun 17, 2013
Hi! Doug. For my experience certainly take the plug and socket to the regulator apart (no matter what type)and inspect the spade connectors and the nylon shrouds . I found mine had a bad connecting spade which had created so much heat the plastic/nylon plug and socket had welded together and started turning to carbon which must have been near to causing a fire. The plug, socket and females are mostly of "Durite" name and part No.0-011-06 ( Six way Nylon) Made by Gordon Equipments Ltd . for UK users. An example of cheep kit doing a lousy job if ever there was one! Regards Bob Harrison Europa 914 Rotax. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 17 June 2013 13:58 Subject: RotaxEngines-List: Re: Erratic voltage output --> Hi Doug, The ground wire on the cyl. head should be just fine. Many of us use it and it seems to work without any issues. I have those capacitors and they are $20. Same as Lockwood or anyone else unless you go to the super-sized model with finger nuts on top instead of soldering the terminals on, but those are about triple or more the price. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402853#402853 ________________________________________________________________________________
Date: Jun 18, 2013
Qm9iICYgT3RoZXJzLMKgCkkgY291bGQgbm90IGFncmVlIG1vcmUsIHdpdGggeW91ciBjb21tZW50 IGFib3V0IGxvdXN5IGNvbm5lY3Rpb24gZGVzaWduLgpCeSBhbGwgbWVhbnMgY2hlY2sgdGhvc2Ug Y29ubmVjdGlvbnMuwqAKVXBkYXRlIG9uIHRoZSBpbnN0YWxsYXRpb24gb2YgYSAxMGdhLiBncm91 bmQgd2lyZS4gwqBJwqB0aGluayB0aGUgZ3JvdW5kaW5nIHdpcmUgYmFjayB0byB0aGUgZW5naW5l IGJsb2NrIGhhcyBzb2x2ZWQgdGhlIGVycmF0aWMgYW1wIG1ldGVyIGlzc3VlLiDCoEkgd2FybWVk IHVwIHRoZSA5MTJ1bHMgYW5kIHJhbiB0aGUgcnBtJ3MgdG8gNGsuIEl0IG5vIGxvbmdlciBzcGlr ZXMgaW50byBuZWdhdGl2ZSByYW5nZS4gSSBkaWQgbm90IGZseSwgc28gdGhlcmUncyBzdGlsbCBz b21lIHJvb20gZm9yIGNvbmNlcm4gb24gbG9uZyBob3QgcnVucywgYnV0IGl0IGFwcGVhcnMgdGhh dCBhIHplcm8gcmVzaXN0YW5jZSBib25kZWQgZ3JvdW5kIGZyb20gdGhlIHZvbHRhZ2UgcmVndWxh dG9yIHRvIHRoZSBlbmdpbmUgYmxvY2sgaXMgYSBtdXN0LgpHb29kIGx1Y2sgYW5kIHNhZmUgZmx5 aW5nLsKgClBhdWwKCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTogQm9i IEhhcnJpc29uIDxwdGFnLmRldkB0YWxrdGFsay5uZXQ+IApEYXRlOiAwNi8xNy8yMDEzICA5OjUy IEFNICAoR01ULTA4OjAwKSAKVG86IHJvdGF4ZW5naW5lcy1saXN0QG1hdHJvbmljcy5jb20gClN1 YmplY3Q6IFJFOiBSb3RheEVuZ2luZXMtTGlzdDogUmU6IEVycmF0aWMgdm9sdGFnZSBvdXRwdXQg CiAKLS0+IFJvdGF4RW5naW5lcy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiQm9iIEhhcnJpc29u IiA8cHRhZy5kZXZAdGFsa3RhbGsubmV0PgoKSGkhIERvdWcuCkZvciBteSBleHBlcmllbmNlIGNl cnRhaW5seSB0YWtlIHRoZSBwbHVnIGFuZCBzb2NrZXTCoCB0byB0aGUgcmVndWxhdG9yCmFwYXJ0 IChubyBtYXR0ZXIgd2hhdCB0eXBlKWFuZCBpbnNwZWN0IHRoZSBzcGFkZSBjb25uZWN0b3JzIGFu ZCB0aGUgbnlsb24Kc2hyb3VkcyAuCkkgZm91bmQgbWluZSBoYWQgYSBiYWQgY29ubmVjdGluZyBz cGFkZSB3aGljaCBoYWQgY3JlYXRlZCBzbyBtdWNoIGhlYXQgdGhlCnBsYXN0aWMvbnlsb24gcGx1 ZyBhbmQgc29ja2V0IGhhZCB3ZWxkZWQgdG9nZXRoZXIgYW5kIHN0YXJ0ZWQgdHVybmluZyB0bwpj YXJib24gd2hpY2ggbXVzdCBoYXZlIGJlZW4gbmVhciB0byBjYXVzaW5nIGEgZmlyZS7CoCBUaGUg cGx1Zywgc29ja2V0IGFuZApmZW1hbGVzIGFyZSBtb3N0bHkgb2bCoCAiRHVyaXRlIiBuYW1lIGFu ZCBwYXJ0IE5vLjAtMDExLTA2ICggU2l4IHdheSBOeWxvbikKTWFkZSBieSBHb3Jkb24gRXF1aXBt ZW50cyBMdGQgLiBmb3IgVUsgdXNlcnMuwqAgQW4gZXhhbXBsZSBvZiBjaGVlcCBraXQgZG9pbmcK YSBsb3VzeSBqb2IgaWYgZXZlciB0aGVyZSB3YXMgb25lISAKUmVnYXJkcwpCb2IgSGFycmlzb24g RXVyb3BhIDkxNCBSb3RheC4KCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tCkZyb206IG93bmVy LXJvdGF4ZW5naW5lcy1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tClttYWlsdG86b3duZXItcm90 YXhlbmdpbmVzLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBSb2dlciBM ZWUKU2VudDogMTcgSnVuZSAyMDEzIDEzOjU4ClRvOiByb3RheGVuZ2luZXMtbGlzdEBtYXRyb25p Y3MuY29tClN1YmplY3Q6IFJvdGF4RW5naW5lcy1MaXN0OiBSZTogRXJyYXRpYyB2b2x0YWdlIG91 dHB1dAoKLS0+IFJvdGF4RW5naW5lcy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiUm9nZXIgTGVl IiAKLS0+IDxzc2FkaXZlcjFAeWFob28uY29tPgoKSGkgRG91ZywKClRoZSBncm91bmQgd2lyZSBv biB0aGUgY3lsLiBoZWFkIHNob3VsZCBiZSBqdXN0IGZpbmUuIE1hbnkgb2YgdXMgdXNlIGl0IGFu ZAppdCBzZWVtcyB0byB3b3JrIHdpdGhvdXQgYW55IGlzc3Vlcy4KSSBoYXZlIHRob3NlIGNhcGFj aXRvcnMgYW5kIHRoZXkgYXJlICQyMC4gU2FtZSBhcyBMb2Nrd29vZCBvciBhbnlvbmUgZWxzZQp1 bmxlc3MgeW91IGdvIHRvIHRoZSBzdXBlci1zaXplZCBtb2RlbCB3aXRoIGZpbmdlciBudXRzIG9u IHRvcCBpbnN0ZWFkIG9mCnNvbGRlcmluZyB0aGUgdGVybWluYWxzIG9uLCBidXQgdGhvc2UgYXJl IGFib3V0IHRyaXBsZSBvciBtb3JlIHRoZSBwcmljZS4KCi0tLS0tLS0tClJvZ2VyIExlZQpUdWNz b24sIEF6LgpMaWdodCBTcG9ydCBSZXBhaXJtYW4gLSBNYWludGVuYW5jZSBSYXRlZCBSb3RheCBS ZXBhaXIgQ2VudGVyIC0gSGVhdnkgTWFpbnQuClJhdGVkIEhvbWUgNTIwLTU3NC0xMDgwwqAgVFJZ IEhPTUUgRklSU1QgQ2VsbCA1MjAtMzQ5LTcwNTYKCgoKClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUg aGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDAyODUz IzQwMjg1MwoKCgoKCgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoCAtIFRoZSBSb3Rh eEVuZ2luZXMtTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZl YXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1 Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2Fk LCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2gg bW9yZToKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/ Um90YXhFbmdpbmVzLUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBh dmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09wqDCoCAtLT4gaHR0cDovL2ZvcnVt cy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBM aXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPcKgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5l cm91cyBzdXBwb3J0IQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09wqDCoCAtLT4g aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKCg= ________________________________________________________________________________
Date: Jun 18, 2013
*Doug:* * * *You explained only half of the wiring system. Here are some basic rules for the Capacitor (CAP):* - *You want to vibration dampen the mounting of the capacitor; Vibration damages the capacitor* - *You want to mount the Cap Up-Side Down - This keeps dirt, oil and water from building on the top which can short out the terminals (High Resistance Short) but remember high resistance means almost nothing to the voltage buildup/stored in the cap.* - *You want a tantalum electrolytic capacitor* - *You want to keep the capacitor close to the voltage regulator (ACU) (Alternator Control Unit), keeping the leads SHORT.* - *You want to keep the leads short - That means both the positive and negative leads.* *Now, when you say "Firewall Buss" and associate it with the Ground - I'm guessing here you are saying that you have a junction block for BOTH the Positive and Negative (Ground). Well that is good and is acceptable. But, is the Firewall grounded to the junction block? You should have two (2) ground points one to port and starboard on the firewall, usually near the engine mounts. * * * *When you say you are using the Cylinder as a Ground point - - That is very questionable. Pick a stud on the engine BLOCK. There is too much vibration, heat and expansion & contraction for that to be a good grounding point. Use TWO (2) points on the engine for ground points. Run each to the port and starboard sides of the firewall. Make sure the engine is grounded to the engine mount. TAKE RESISTANCE READINGS. All the readings should be ZERO (0) ohms. NONE of your wire runs are long enough to have any circuit resistance. If you do then your wires, harness, lugs, crimps or connections are BAD. There is no getting around this - You MUST take resistance readings at the LOWEST scale available on the BEST ohm meter you can borrow. Check out every single wire length and then to ground to find any problems.* * * *You mention a junction block at the battery which is located behind passenger the seat. Are you using Internal Star Washers on ALL these connections? Not split ring washers. Here also check your Resistance.* * * *Are all stacked ring lugs - Stacked in the Locking Direction and topped off with a internal star washer?* * * *You are speaking of corrosion and oxidation as two different things - They are NOT! The smallest amount of "contamination" will cause resistance and that will cause current drops. Current drops cause voltage fluctuation.* * * *After you get done with all the cleaning and resistance checks and re-assembly - You should coat the terminals. You can coat them with chromate paint, primer paint, top coat paint, dielectric grease (good in many areas but will collect dirt & dust). This works as a corrosion protection and as witness marks.* * * *Now for the bad news - I'm learning about Rotax engines and I do not think your problem is external [except for the ground point on the cylinder - change that]. I'm thinking more to the engine and the internal setup and workings of the alternator/generator. Not easy access.* Address each of the areas as mentioned and get back to us. It is NOT a difficult problem. It is just difficult to address via emails. *Barry* On Mon, Jun 17, 2013 at 7:07 AM, MacDonald Doug wrote: > So, my troubleshooting saga continues. The first thing I did was run an > 18ga ground wire from the regulator body to the negative terminal of the > capacitor which then goes to the firewall buss bar. When this did not > solve the erratic output issue I replaced the regulator. Neither of these > steps helped the problem. > > My engine ground lead is an 8ga wire running from a lug on the top of the > right rear cylinder to the ground lead on the firewall buss. From the > firewall buss, both the positive and negative leads are 8ga wire and go to > my main buss which is mounted behind the instrument panel. From the main > buss the positive and negative leads are 8ga and run down the passenger > side of the airframe to the battery which is located behind the passenger > seat. At the battery the ground wire attaches to an airframe ground point > on the battery mount frame then through an 8ga wire to the negative post. > The positive lead goes to the master solenoid and then to the positive post > of the battery (all 8ga). As per Roger's suggestion, I have been pulling > each of these main power leads one terminal at a time and thoroughly > cleaning the connections. So far I have gotten to the main buss and > firewall buss but still need to clean the connections at the battery. > While I have found some oxidization, I have thus far found no corrosion > which could be causing my erratic output issue. > > Today after work I will pull the belly pan off of the plane and clean all > of the connections at the battery. I also want to pull the connections of > the charge lead from the voltage regulator to the ALT circuit breaker and > main buss to verify they are okay. So far , however, I'm not seeing > anything that could be the source of my problem. My CH-701 is almost three > years old and has just shy of 200 hours on it. This voltage issue is has > come on gradually over the last few months as the output has been stable > until I noticed the needle gyrations in about March when my flying hours > began to pick up. > > One other thing I am going to try is a new capacitor. Lockwood sells an > aftermarket 22000MF cap for $35.00 so I figured I may as well try it. My > capacitor is about ten years old with an unknown history so it is possible > that is has started to go bad. I also might try a different ground wire > location on the engine. Perhaps the cylinder head is not an ideal ground > location. > > Any other suggestions? > > Doug M > CH-701 from scratch > NW Ontario, Canada > > From: "Paul Grimstad" <paul(at)controlapproach.com> > Subject: RE: RotaxEngines-List: Erratic voltage output > > We have been experiencing wild fluctuations on the amperage meter, running > a > 912uls with Dynon 180 EFIS engine monitor. The spikes range from +5 to -6. > Voltage is also high (high 13's), but then it seems to settle down after > takeoff. I thought the high voltage maybe because we just installed a new > battery. > > We also just installed a new voltage regulator and when we grounded the > plane and took a look at the condition we found the two power leads going > into the regulator were completely melted and the heat was starting to melt > the plastic mounting socket on the Ducati voltage regulator. We replaced > the > spade connectors on the main power leads and replaced the wiring socket > plug-in connector as well. > > We had heard that the Rotax engine electronic system is very sensitive to > the requirement of the ground connection, so additionally we ran a 10ga > copper wire from the base lug on the voltage regulator to the negative > terminal connecting stud at the battery/airframe. This has not solved the > problem. I flew 7hours last weekend and near the end of the flight time, I > noticed the amp gauge still jumping up and down. > > I have spoken with several knowledgeable Rotax guys and both asked me if I > ran the ground from the base of the voltage regulator directly to the > engine > block? > > So, this afternoon I removed the wire socket plug connector and inspected > the wire ends and crimped connectors. There was no sign of heat damage, so > I > reconnected the primary connection plug. I made up another ground wire with > soldered wire ends and waterproof shrink tubing. I then installed the new > ground wire from the mounting bolt on the base of the voltage regulator > directly to the engine block. Tomorrow I will run the engine and see if the > problem is solved. > > Hope this helps, I will let you know how it goes. > > Paul Grimstad, > > Team RV12 > > Portland, OR > > > * > > * > > ________________________________________________________________________________
Date: Jun 19, 2013
1. Paul: I just read your post and something caught my eye: "I made up another ground wire with soldered wire ends and waterproof shrink tubing." You should NOT solder the wire ends. You should ONLY CRIMP them. Soldering creates what is know as a HARDPOINT and causes the wire to fail due to vibration, right at the END point of the solder to wire connection. Now, to contradict what I just said: I have a method of soldering that is Perfectly Acceptable. The steps are: 1. Clean the wire 2. CRIMP on the lug 3. Using SILVER SOLDER - Solder ONLY - ONLY - ONLY - The END of the wire next to the ring lug. DO NOT keep the heat on the wire for a long time. Only enough time to get a flow of solder between the wire and the lug. If you apply too much heat and too much time the solder will WICK down the wire and create a HARDPOINT. 4. By doing it my way you create a GREAT Mechanical and Electrical connection. 5. After soldering the connection CLEAN the connection with alcohol to remove any flux. 6. I have been doing this for years and NEVER had a failure either mechanically or electrically. ALSO: - Do NOT use SPADE crimp on connectors. Use RING crimp on connectors. - Why? #1 they are NOT approved via AC 43-13. #2 They have a built in design failure point... the SPADE! ALSO #2: 1. Your statement: "so additionally we ran a 10ga copper wire from the base lug on the voltage regulator to the negative terminal connecting st ud at the battery/airframe. " You also have to run that SAME wire to the airframe [Airframe Ground]. 2. Do not rely on a single ground point to do everything. I just posted an in depth How To with Explanations. Take the time to read and understand what I wrote. If you have questions PLEASE post them, I will be happy to explain. *Barry* On Mon, Jun 17, 2013 at 2:09 AM, Paul Grimstad wr ote: > We have been experiencing wild fluctuations on the amperage meter, runnin g > a 912uls with Dynon 180 EFIS engine monitor. The spikes range from +5 to > -6. Voltage is also high (high 13=92s), but then it seems to settle down > after takeoff. I thought the high voltage maybe because we just installed a > new battery.**** > > We also just installed a new voltage regulator and when we grounded the > plane and took a look at the condition we found the two power leads going > into the regulator were completely melted and the heat was starting to me lt > the plastic mounting socket on the Ducati voltage regulator. We replaced > the spade connectors on the main power leads and replaced the wiring sock et > plug-in connector as well. **** > > We had heard that the Rotax engine electronic system is very sensitive to > the requirement of the ground connection, so additionally we ran a 10ga > copper wire from the base lug on the voltage regulator to the negative > terminal connecting stud at the battery/airframe. This has not solved the > problem. I flew 7hours last weekend and near the end of the flight time, I > noticed the amp gauge still jumping up and down.**** > > I have spoken with several knowledgeable Rotax guys and both asked me if I > ran the ground from the base of the voltage regulator directly to the > engine block?**** > > So, this afternoon I removed the wire socket plug connector and inspected > the wire ends and crimped connectors. There was no sign of heat damage, s o > I reconnected the primary connection plug. I made up another ground wire > with soldered wire ends and waterproof shrink tubing. I then installed th e > new ground wire from the mounting bolt on the base of the voltage regulat or > directly to the engine block. Tomorrow I will run the engine and see if t he > problem is solved.**** > > Hope this helps, I will let you know how it goes.**** > > Paul Grimstad,**** > > Team RV12**** > > Portland, OR **** > > ** ** > > *From:* owner-rotaxengines-list-server(at)matronics.com [mailto: > owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of *Carl > *Sent:* Saturday, June 15, 2013 1:25 PM > *To:* rotaxengines-list(at)matronics.com > *Subject:* Re: RotaxEngines-List: Erratic voltage output**** > > ** ** > > Hi Doug**** > > You stated you have no loose contacts, you could have a poor contact. Tw o > years ago I had an intermittent charging problem that took two day to > trace. It was in an in-line fuse holder, the rubber coated ones that take > ATC fuses. The fuse looked fairly normal but when I cut the holder open i t > was corroded and burnt. Replaced problem gone.**** > > Carl**** > > ----- Original Message ----- **** > > *From:* MacDonald Doug **** > > *To:* rotax list **** > > *Sent:* Friday, June 14, 2013 10:44 AM**** > > *Subject:* RotaxEngines-List: Erratic voltage output**** > > ** ** > > I'm having an erratic voltage output problem on my 912UL powered CH-701. > > To try and fix the problem I have replaced the voltage regulator and > verified I have no loose connections in the electrical system. Even with a > new regulator I am still getting the same voltage spikes when at full > power. At idle and during run-up the voltage reading on my analog VDO > voltmeter is rock solid. It indicates about 14 volts once up off of idle > power and my digital voltmeter show about 13.6 Volts. Once I apply takeo ff > power the analog voltmeter needle starts to vibrate wildly plus and minus > about 1-2 volts and the digital voltmeter becomes unstable. If I am flyi ng > with a light electrical load, the digital voltmeter tops out at just over > 14 volts but drifts around as low as 13.7. If I put on my nav and strobe > lights the voltage drops to 13.3-13.6 range but the needle on the analog > meter continues to vibrate the same. > > The only other components (beside the regulator) in the electrical system > I can think of which might be causing the voltage spikes are the capacito r > or a problem with the actual alternator coils. I thought the problem may > have been a bad analog gauge but given that the digital readings are also > erratic I believe it to be a legitimate issue and not simply a display > problem. > > I'm pretty good at chasing electrons but this issue has me stumped. > Anyone have any ideas what could be causing my erratic voltage output? > > Doug MacDonald > CH-701, Northwestern Ontario**** > > ** ** > > * * > > * * > > *href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www .matronics.com/Navigator?RotaxEngines-List* > > *href="http://forums.matronics.com">http://forums.matronics.com* > > *href="http://www.matronics.com/contribution">http://www.matronics.com/ c* > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RotaxEngines-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jun 19, 2013
Greetings Paul, If you want GOOD advice and information on all things aviationelectrical/electronic, check out http://www.aeroelectric.com/ and the aeroelectric-list(at)matronics.com, right here on Matt's server. No affiliation, just a long time subscriber. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 06/19/2013 11:32 AM, FLYaDIVE wrote: > > 1. Paul: > > > I just read your post and something caught my eye: "I made up another > ground wire with soldered wire ends and waterproof shrink tubing." > > You should NOT solder the wire ends. You should ONLY CRIMP them. > Soldering creates what is know as a HARDPOINT and causes the wire to > fail due to vibration, right at the END point of the solder to wire > connection. > > Now, to contradict what I just said: I have a method of soldering > that is Perfectly Acceptable. The steps are: > > 1. Clean the wire > 2. CRIMP on the lug > 3. Using SILVER SOLDER - Solder ONLY - ONLY - ONLY - The END of the > wire next to the ring lug. DO NOT keep the heat on the wire for a > long time. Only enough time to get a flow of solder between the > wire and the lug. If you apply too much heat and too much time > the solder will WICK down the wire and create a HARDPOINT. > 4. By doing it my way you create a GREAT Mechanical and Electrical > connection. > 5. After soldering the connection CLEAN the connection with alcohol > to remove any flux. > 6. I have been doing this for years and NEVER had a failure either > mechanically or electrically. > > ALSO: > > * Do NOT use SPADE crimp on connectors. Use RING crimp on connectors. > * Why? #1 they are NOT approved via AC 43-13. #2 They have a built > in design failure point... the SPADE! > > ALSO #2: > > 1. Your statement: "so additionally we ran a 10ga copper wire from > the base lug on the voltage regulator to the negative terminal > connecting stud at the battery/airframe. " You also have to run > that SAME wire to the airframe [Airframe Ground]. > 2. Do not rely on a single ground point to do everything. > > I just posted an in depth How To with Explanations. Take the time to > read and understand what I wrote. If you have questions PLEASE post > them, I will be happy to explain. > > *Barry* > > > On Mon, Jun 17, 2013 at 2:09 AM, Paul Grimstad > > wrote: > > We have been experiencing wild fluctuations on the amperage meter, > running a 912uls with Dynon 180 EFIS engine monitor. The spikes > range from +5 to -6. Voltage is also high (high 13's), but then it > seems to settle down after takeoff. I thought the high voltage > maybe because we just installed a new battery. > > We also just installed a new voltage regulator and when we > grounded the plane and took a look at the condition we found the > two power leads going into the regulator were completely melted > and the heat was starting to melt the plastic mounting socket on > the Ducati voltage regulator. We replaced the spade connectors on > the main power leads and replaced the wiring socket plug-in > connector as well. > > We had heard that the Rotax engine electronic system is very > sensitive to the requirement of the ground connection, so > additionally we ran a 10ga copper wire from the base lug on the > voltage regulator to the negative terminal connecting stud at the > battery/airframe. This has not solved the problem. I flew 7hours > last weekend and near the end of the flight time, I noticed the > amp gauge still jumping up and down. > > I have spoken with several knowledgeable Rotax guys and both asked > me if I ran the ground from the base of the voltage regulator > directly to the engine block? > > So, this afternoon I removed the wire socket plug connector and > inspected the wire ends and crimped connectors. There was no sign > of heat damage, so I reconnected the primary connection plug. I > made up another ground wire with soldered wire ends and waterproof > shrink tubing. I then installed the new ground wire from the > mounting bolt on the base of the voltage regulator directly to the > engine block. Tomorrow I will run the engine and see if the > problem is solved. > > Hope this helps, I will let you know how it goes. > > Paul Grimstad, > > Team RV12 > > Portland, OR > > *From:*owner-rotaxengines-list-server(at)matronics.com > > [mailto:owner-rotaxengines-list-server(at)matronics.com > ] *On Behalf > Of *Carl > *Sent:* Saturday, June 15, 2013 1:25 PM > *To:* rotaxengines-list(at)matronics.com > > *Subject:* Re: RotaxEngines-List: Erratic voltage output > > Hi Doug > > You stated you have no loose contacts, you could have a poor > contact. Two years ago I had an intermittent charging problem > that took two day to trace. It was in an in-line fuse holder, the > rubber coated ones that take ATC fuses. The fuse looked fairly > normal but when I cut the holder open it was corroded and burnt. > Replaced problem gone. > > Carl > > ----- Original Message ----- > > *From:*MacDonald Doug > > *To:*rotax list > > *Sent:*Friday, June 14, 2013 10:44 AM > > *Subject:*RotaxEngines-List: Erratic voltage output > > I'm having an erratic voltage output problem on my 912UL > powered CH-701. > > To try and fix the problem I have replaced the voltage > regulator and verified I have no loose connections in the > electrical system. Even with a new regulator I am still > getting the same voltage spikes when at full power. At idle > and during run-up the voltage reading on my analog VDO > voltmeter is rock solid. It indicates about 14 volts once up > off of idle power and my digital voltmeter show about 13.6 > Volts. Once I apply takeoff power the analog voltmeter needle > starts to vibrate wildly plus and minus about 1-2 volts and > the digital voltmeter becomes unstable. If I am flying with a > light electrical load, the digital voltmeter tops out at just > over 14 volts but drifts around as low as 13.7. If I put on > my nav and strobe lights the voltage drops to 13.3-13.6 range > but the needle on the analog meter continues to vibrate the same. > > The only other components (beside the regulator) in the > electrical system I can think of which might be causing the > voltage spikes are the capacitor or a problem with the actual > alternator coils. I thought the problem may have been a bad > analog gauge but given that the digital readings are also > erratic I believe it to be a legitimate issue and not simply a > display problem. > > I'm pretty good at chasing electrons but this issue has me > stumped. Anyone have any ideas what could be causing my > erratic voltage output? > > Doug MacDonald > CH-701, Northwestern Ontario > > * * > > * * > > *href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List* > > *href="http://forums.matronics.com">http://forums.matronics.com* > > *href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RotaxEngines-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > > ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * ________________________________________________________________________________
Subject: Daul Mags on the 914
Date: Jun 19, 2013
Hello All. I have just replace a mag HT coil on my 914, simple job, but a ridiculous job to do it took my a day because you can not get at the nuts and bolts. However all is well now, I have equal drops of about 280to300 on each . I can understand the more efficient burning on two hence the extra 300 rpm. But when run on either the left or right mag the engine is not as smooth as when on two. WHY?? A car has only one set of plugs and that runs smooth, So at 4000rpm on two smooth 3710 rpms on one not as smooth ?? Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403012#403012 ________________________________________________________________________________
Date: Jun 19, 2013
Subject: Re: Daul Mags on the 914
Alen: The simple answers are: - When you adjust the carb it is adjusted for the spark available. If you had only one spark plug you would adjust the carb for the best run with that one plug. Since you have two spark plugs the burn is better - BUT - You need the two plugs. - Spark Plug Location - When you are talking real estate there are three things that matter - Location - Location - Location. When running on ONE plug in a dual plug system, it is NOT in the best location to give the best spark/burn. A car puts the plug in the optimum location for spark and burn. - Most aircraft engines sacrifice spark plug location for Safety/REDUNDANCY. *Barry* On Wed, Jun 19, 2013 at 5:45 PM, Alan Carter wrote: > alancarteresq(at)onetel.net> > > Hello All. > I have just replace a mag HT coil on my 914, simple job, but a ridiculous > job to do it took my a day because you can not get at the nuts and bolts. > However all is well now, I have equal drops of about 280to300 on each . > I can understand the more efficient burning on two hence the extra 300 rpm. > But when run on either the left or right mag the engine is not as smooth > as when on two. WHY?? > A car has only one set of plugs and that runs smooth, So at 4000rpm on > two smooth 3710 rpms on one not as smooth ?? > > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403012#403012 > > ________________________________________________________________________________
Date: Jun 19, 2013
Thank you Barry. All of that seems to make sense, well it does make sense, i am just surprised the difference in makes, as its about the same roughness on each mag, and as you say much smoother on two. Regards Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403015#403015 ________________________________________________________________________________
Date: Jun 19, 2013
Alan, what were your mag drop figures before the HT coil replacement? Also, did you clearly see on the spark plugs (different colors) that you had an issue with an HT coil? Thanks, Jacques. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403016#403016 ________________________________________________________________________________
Date: Jun 19, 2013
VGhhbmtzIGZvciB0aGUgcG9pbnRzLiDCoEkgYWdyZWUuCgpJIGRpZCBub3QgZGlyZWN0bHkgc29s ZGVyIHRoZSBjb25uZWN0aW9uLiBJIHVzZWQgIm5vIGNyaW1wIiB0ZXJtaW5hbCBodWJzIGRlc2ln bmVkIGZvciBncm91bmQgd2lyZXMuIEkgcHJlc3VtZSB0aGV5IG1ha2UgdGhlc2UgYmVjYXVzZSBv ZiB0aGUgY29ycm9zaW9uIGlzc3VlcyBjb21tb25seSBmb3VuZCBvbiBncm91bmQgbGVhZHMuIFRo ZSB0cmVtaW5hbHMgYXJlIHByZWxvYWRlZCB3aXRoIGxvdyBtZWx0IHRlbXAgc29sZGVyIGFuZCBq YWNrZXRlZCB3aXRoIGhlYXZ5IGd1YWdlIHNocmluayB0dWJlLiBUaGV5IGNvbXBsZXRlbHkgYXNz ZW1ibGUgd2l0aCBhIGhlYXQgZ3VuIG5vdCBhIHNvbGRlcmluZyBpcm9uLiBBcyB0aGUgdGVybWlu YWwgZW5kcyBhcmUgaGVhdGVkIHlvdSBjYW4gb2JzZXJ2ZSB0aGUgc29sZGVyIHR1cm4gdG8gbGlx dWlkIGFuZCB0aGUgc2VtaS1jbGVhciBzaHJpbmsgdHViZSBoYXMgYW4gYWRoZXNpdmUgdGhhdCBs aXF1aWZpZXMgYW5kIHNlYWxzIHRvIHRoZSB3aXJlIGluc3VsYXRpb24uIEEgYml0IHNwZW5keSwg YnV0IEkgdGhpbmsgdGhlaXIgdGhlIHdheSB0byBnby4KSSBoYWQga25vdyBpZGVhIHRoYXQgZ3Jv dW5kaW5nIHdhcyBzdWNoIGEgYmlnIGRlYWwuIEhvcGVmdWxseSB0aGUgcHJvYmxlbSBpcyBzb2x2 ZWQuwqAKUGF1bAoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLQpGcm9tOiBGTFlh RElWRSA8Zmx5YWRpdmVAZ21haWwuY29tPiAKRGF0ZTogMDYvMTkvMjAxMyAgOTozMiBBTSAgKEdN VC0wODowMCkgClRvOiByb3RheGVuZ2luZXMtbGlzdEBtYXRyb25pY3MuY29tIApTdWJqZWN0OiBS ZTogUm90YXhFbmdpbmVzLUxpc3Q6IEVycmF0aWMgdm9sdGFnZSBvdXRwdXQgCiAKUGF1bDoKCkkg anVzdCByZWFkIHlvdXIgcG9zdCBhbmQgc29tZXRoaW5nIGNhdWdodCBteSBleWU6IMKgwqAiSSBt YWRlIHVwIGFub3RoZXIgZ3JvdW5kIHdpcmUgd2l0aCBzb2xkZXJlZCB3aXJlIGVuZHMgYW5kIHdh dGVycHJvb2Ygc2hyaW5rIHR1YmluZy4iCgpZb3Ugc2hvdWxkIE5PVCBzb2xkZXIgdGhlIHdpcmUg ZW5kcy4gwqBZb3Ugc2hvdWxkIE9OTFkgQ1JJTVAgdGhlbS4gwqBTb2xkZXJpbmcgY3JlYXRlcyB3 aGF0IGlzIGtub3cgYXMgYSBIQVJEUE9JTlQgYW5kIGNhdXNlcyB0aGUgd2lyZSB0byBmYWlsIGR1 ZSB0byB2aWJyYXRpb24sIHJpZ2h0IGF0IHRoZSBFTkQgcG9pbnQgb2YgdGhlIHNvbGRlciB0byB3 aXJlIGNvbm5lY3Rpb24uCgpOb3csIHRvwqBjb250cmFkaWN0wqB3aGF0IEkganVzdCBzYWlkOiDC oEkgaGF2ZSBhIG1ldGhvZCBvZiBzb2xkZXJpbmcgdGhhdCBpcyBQZXJmZWN0bHkgQWNjZXB0YWJs ZS4gVGhlIHN0ZXBzIGFyZToKQ2xlYW4gdGhlIHdpcmUKQ1JJTVAgb24gdGhlIGx1ZwpVc2luZyBT SUxWRVIgU09MREVSIC0gU29sZGVyIE9OTFkgLSBPTkxZIC0gT05MWSAtIFRoZSBFTkQgb2YgdGhl IHdpcmUgbmV4dCB0byB0aGUgcmluZyBsdWcuIMKgRE8gTk9UIGtlZXAgdGhlIGhlYXQgb24gdGhl IHdpcmUgZm9yIGEgbG9uZyB0aW1lLiDCoE9ubHkgZW5vdWdoIHRpbWUgdG8gZ2V0IGEgZmxvdyBv ZiBzb2xkZXIgYmV0d2VlbiB0aGUgd2lyZSBhbmQgdGhlIGx1Zy4gwqBJZiB5b3UgYXBwbHkgdG9v IG11Y2ggaGVhdCBhbmQgdG9vIG11Y2ggdGltZSB0aGUgc29sZGVyIHdpbGwgV0lDSyBkb3duIHRo ZSB3aXJlIGFuZCBjcmVhdGUgYSBIQVJEUE9JTlQuIMKgCkJ5IGRvaW5nIGl0IG15IHdheSB5b3Ug Y3JlYXRlIGEgR1JFQVTCoE1lY2hhbmljYWzCoGFuZCBFbGVjdHJpY2FsIGNvbm5lY3Rpb24uCkFm dGVyIHNvbGRlcmluZyB0aGUgY29ubmVjdGlvbiBDTEVBTiB0aGUgY29ubmVjdGlvbiB3aXRoIGFs Y29ob2wgdG8gcmVtb3ZlIGFueSBmbHV4LgpJIGhhdmUgYmVlbiBkb2luZyB0aGlzIGZvciB5ZWFy cyBhbmQgTkVWRVIgaGFkIGEgZmFpbHVyZSBlaXRoZXIgbWVjaGFuaWNhbGx5IG9yIGVsZWN0cmlj YWxseS4KQUxTTzoKRG8gTk9UIHVzZSBTUEFERSBjcmltcCBvbiBjb25uZWN0b3JzLiDCoFVzZSBS SU5HIGNyaW1wIG9uIGNvbm5lY3RvcnMuCldoeT8gwqAjMSB0aGV5IGFyZSBOT1QgYXBwcm92ZWQg dmlhIEFDIDQzLTEzLiDCoCMyIFRoZXkgaGF2ZSBhIGJ1aWx0IGluIGRlc2lnbiBmYWlsdXJlIHBv aW50Li4uIHRoZSBTUEFERSHCoApBTFNPICMyOgpZb3VyIHN0YXRlbWVudDogInNvIGFkZGl0aW9u YWxseSB3ZSByYW4gYSAxMGdhIGNvcHBlciB3aXJlIGZyb20gdGhlIGJhc2UgbHVnIG9uIHRoZSB2 b2x0YWdlIHJlZ3VsYXRvciB0byB0aGUgbmVnYXRpdmUgdGVybWluYWwgY29ubmVjdGluZyBzdHVk IGF0IHRoZSBiYXR0ZXJ5L2FpcmZyYW1lLsKgIiDCoFlvdSBhbHNvIGhhdmUgdG8gcnVuIHRoYXQg U0FNRSB3aXJlIHRvIHRoZSBhaXJmcmFtZSBbQWlyZnJhbWUgR3JvdW5kXS4KRG8gbm90IHJlbHkg b24gYSBzaW5nbGUgZ3JvdW5kIHBvaW50IHRvIGRvIGV2ZXJ5dGhpbmcuCkkganVzdCBwb3N0ZWQg YW7CoGluIGRlcHRowqBIb3cgVG8gd2l0aMKgRXhwbGFuYXRpb25zLiDCoFRha2UgdGhlIHRpbWUg dG8gcmVhZCBhbmQgdW5kZXJzdGFuZCB3aGF0IEkgd3JvdGUuIMKgSWYgeW91IGhhdmUgcXVlc3Rp b25zIFBMRUFTRSBwb3N0IHRoZW0sIEkgd2lsbCBiZSBoYXBweSB0byBleHBsYWluLgpCYXJyeQoK CgpPbiBNb24sIEp1biAxNywgMjAxMyBhdCAyOjA5IEFNLCBQYXVsIEdyaW1zdGFkIDxwYXVsQGNv bnRyb2xhcHByb2FjaC5jb20+IHdyb3RlOgpXZSBoYXZlIGJlZW4gZXhwZXJpZW5jaW5nIHdpbGQg Zmx1Y3R1YXRpb25zIG9uIHRoZSBhbXBlcmFnZSBtZXRlciwgcnVubmluZyBhIDkxMnVscyB3aXRo IER5bm9uIDE4MCBFRklTIGVuZ2luZSBtb25pdG9yLiBUaGUgc3Bpa2VzIHJhbmdlIGZyb20gKzUg dG8gLTYuIFZvbHRhZ2UgaXMgYWxzbyBoaWdoIChoaWdoIDEz4oCZcyksIGJ1dCB0aGVuIGl0IHNl ZW1zIHRvIHNldHRsZSBkb3duIGFmdGVyIHRha2VvZmYuIEkgdGhvdWdodCB0aGUgaGlnaCB2b2x0 YWdlIG1heWJlIGJlY2F1c2Ugd2UganVzdCBpbnN0YWxsZWQgYSBuZXcgYmF0dGVyeS4KCldlIGFs c28ganVzdCBpbnN0YWxsZWQgYSBuZXcgdm9sdGFnZSByZWd1bGF0b3IgYW5kIHdoZW4gd2UgZ3Jv dW5kZWQgdGhlIHBsYW5lIGFuZCB0b29rIGEgbG9vayBhdCB0aGUgY29uZGl0aW9uIHdlIGZvdW5k IHRoZSB0d28gcG93ZXIgbGVhZHMgZ29pbmcgaW50byB0aGUgcmVndWxhdG9yIHdlcmUgY29tcGxl dGVseSBtZWx0ZWQgYW5kIHRoZSBoZWF0IHdhcyBzdGFydGluZyB0byBtZWx0IHRoZSBwbGFzdGlj IG1vdW50aW5nIHNvY2tldCBvbiB0aGUgRHVjYXRpIHZvbHRhZ2UgcmVndWxhdG9yLiBXZSByZXBs YWNlZCB0aGUgc3BhZGUgY29ubmVjdG9ycyBvbiB0aGUgbWFpbiBwb3dlciBsZWFkcyBhbmQgcmVw bGFjZWQgdGhlIHdpcmluZyBzb2NrZXQgcGx1Zy1pbiBjb25uZWN0b3IgYXMgd2VsbC4KCldlIGhh ZCBoZWFyZCB0aGF0IHRoZSBSb3RheCBlbmdpbmUgZWxlY3Ryb25pYyBzeXN0ZW0gaXMgdmVyeSBz ZW5zaXRpdmUgdG8gdGhlIHJlcXVpcmVtZW50IG9mIHRoZSBncm91bmQgY29ubmVjdGlvbiwgc28g YWRkaXRpb25hbGx5IHdlIHJhbiBhIDEwZ2EgY29wcGVyIHdpcmUgZnJvbSB0aGUgYmFzZSBsdWcg b24gdGhlIHZvbHRhZ2UgcmVndWxhdG9yIHRvIHRoZSBuZWdhdGl2ZSB0ZXJtaW5hbCBjb25uZWN0 aW5nIHN0dWQgYXQgdGhlIGJhdHRlcnkvYWlyZnJhbWUuIFRoaXMgaGFzIG5vdCBzb2x2ZWQgdGhl IHByb2JsZW0uIEkgZmxldyA3aG91cnMgbGFzdCB3ZWVrZW5kIGFuZCBuZWFyIHRoZSBlbmQgb2Yg dGhlIGZsaWdodCB0aW1lLCBJIG5vdGljZWQgdGhlIGFtcCBnYXVnZSBzdGlsbCBqdW1waW5nIHVw IGFuZCBkb3duLgoKSSBoYXZlIHNwb2tlbiB3aXRoIHNldmVyYWwga25vd2xlZGdlYWJsZSBSb3Rh eCBndXlzIGFuZCBib3RoIGFza2VkIG1lIGlmIEkgcmFuIHRoZSBncm91bmQgZnJvbSB0aGUgYmFz ZSBvZiB0aGUgdm9sdGFnZSByZWd1bGF0b3IgZGlyZWN0bHkgdG8gdGhlIGVuZ2luZSBibG9jaz8K ClNvLCB0aGlzIGFmdGVybm9vbiBJIHJlbW92ZWQgdGhlIHdpcmUgc29ja2V0IHBsdWcgY29ubmVj dG9yIGFuZCBpbnNwZWN0ZWQgdGhlIHdpcmUgZW5kcyBhbmQgY3JpbXBlZCBjb25uZWN0b3JzLiBU aGVyZSB3YXMgbm8gc2lnbiBvZiBoZWF0IGRhbWFnZSwgc28gSSByZWNvbm5lY3RlZCB0aGUgcHJp bWFyeSBjb25uZWN0aW9uIHBsdWcuIEkgbWFkZSB1cCBhbm90aGVyIGdyb3VuZCB3aXJlIHdpdGgg c29sZGVyZWQgd2lyZSBlbmRzIGFuZCB3YXRlcnByb29mIHNocmluayB0dWJpbmcuIEkgdGhlbiBp bnN0YWxsZWQgdGhlIG5ldyBncm91bmQgd2lyZSBmcm9tIHRoZSBtb3VudGluZyBib2x0IG9uIHRo ZSBiYXNlIG9mIHRoZSB2b2x0YWdlIHJlZ3VsYXRvciBkaXJlY3RseSB0byB0aGUgZW5naW5lIGJs b2NrLiBUb21vcnJvdyBJIHdpbGwgcnVuIHRoZSBlbmdpbmUgYW5kIHNlZSBpZiB0aGUgcHJvYmxl bSBpcyBzb2x2ZWQuCgpIb3BlIHRoaXMgaGVscHMsIEkgd2lsbCBsZXQgeW91IGtub3cgaG93IGl0 IGdvZXMuCgpQYXVsIEdyaW1zdGFkLAoKVGVhbSBSVjEyCgpQb3J0bGFuZCwgT1IgwqDCoMKgwqDC oAoKwqAKCkZyb206IG93bmVyLXJvdGF4ZW5naW5lcy1saXN0LXNlcnZlckBtYXRyb25pY3MuY29t IFttYWlsdG86b3duZXItcm90YXhlbmdpbmVzLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9u IEJlaGFsZiBPZiBDYXJsClNlbnQ6IFNhdHVyZGF5LCBKdW5lIDE1LCAyMDEzIDE6MjUgUE0KVG86 IHJvdGF4ZW5naW5lcy1saXN0QG1hdHJvbmljcy5jb20KU3ViamVjdDogUmU6IFJvdGF4RW5naW5l cy1MaXN0OiBFcnJhdGljIHZvbHRhZ2Ugb3V0cHV0CgrCoAoKSGkgRG91ZwoKWW91IHN0YXRlZCB5 b3UgaGF2ZSBubyBsb29zZSBjb250YWN0cywgeW91IGNvdWxkIGhhdmUgYSBwb29yIGNvbnRhY3Qu wqAgVHdvIHllYXJzIGFnb8KgSSBoYWQgYW7CoGludGVybWl0dGVudCBjaGFyZ2luZyBwcm9ibGVt IHRoYXQgdG9vayB0d28gZGF5IHRvIHRyYWNlLiBJdCB3YXMgaW4gYW4gaW4tbGluZSBmdXNlIGhv bGRlciwgdGhlIHJ1YmJlciBjb2F0ZWQgb25lcyB0aGF0IHRha2UgQVRDIGZ1c2VzLsKgVGhlIGZ1 c2UgbG9va2VkIGZhaXJseSBub3JtYWwgYnV0IHdoZW4gSSBjdXQgdGhlIGhvbGRlciBvcGVuIGl0 IHdhcyBjb3Jyb2RlZCBhbmQgYnVybnQuIFJlcGxhY2VkIHByb2JsZW0gZ29uZS4KCkNhcmwKCi0t LS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLS0gCgpGcm9tOiBNYWNEb25hbGQgRG91ZwoKVG86IHJv dGF4IGxpc3QKClNlbnQ6IEZyaWRheSwgSnVuZSAxNCwgMjAxMyAxMDo0NCBBTQoKU3ViamVjdDog Um90YXhFbmdpbmVzLUxpc3Q6IEVycmF0aWMgdm9sdGFnZSBvdXRwdXQKCsKgCgpJJ20gaGF2aW5n IGFuIGVycmF0aWMgdm9sdGFnZSBvdXRwdXQgcHJvYmxlbSBvbiBteSA5MTJVTCBwb3dlcmVkIENI LTcwMS7CoCAKClRvIHRyeSBhbmQgZml4IHRoZSBwcm9ibGVtIEkgaGF2ZSByZXBsYWNlZCB0aGUg dm9sdGFnZSByZWd1bGF0b3IgYW5kIHZlcmlmaWVkIEkgaGF2ZSBubyBsb29zZSBjb25uZWN0aW9u cyBpbiB0aGUgZWxlY3RyaWNhbCBzeXN0ZW0uwqAgRXZlbiB3aXRoIGEgbmV3IHJlZ3VsYXRvciBJ IGFtIHN0aWxsIGdldHRpbmcgdGhlIHNhbWUgdm9sdGFnZSBzcGlrZXMgd2hlbiBhdCBmdWxsIHBv d2VyLsKgIEF0IGlkbGUgYW5kIGR1cmluZyBydW4tdXAgdGhlIHZvbHRhZ2UgcmVhZGluZyBvbiBt eSBhbmFsb2cgVkRPIHZvbHRtZXRlciBpcyByb2NrIHNvbGlkLsKgIEl0IGluZGljYXRlcyBhYm91 dCAxNCB2b2x0cyBvbmNlIHVwIG9mZiBvZiBpZGxlIHBvd2VyIGFuZCBteSBkaWdpdGFsIHZvbHRt ZXRlciBzaG93IGFib3V0IDEzLjYgVm9sdHMuwqAgT25jZSBJIGFwcGx5IHRha2VvZmYgcG93ZXIg dGhlIGFuYWxvZyB2b2x0bWV0ZXIgbmVlZGxlIHN0YXJ0cyB0byB2aWJyYXRlIHdpbGRseSBwbHVz IGFuZCBtaW51cyBhYm91dCAxLTIgdm9sdHMgYW5kIHRoZSBkaWdpdGFsIHZvbHRtZXRlciBiZWNv bWVzIHVuc3RhYmxlLsKgIElmIEkgYW0gZmx5aW5nIHdpdGggYSBsaWdodCBlbGVjdHJpY2FsIGxv YWQsIHRoZSBkaWdpdGFsIHZvbHRtZXRlciB0b3BzIG91dCBhdCBqdXN0IG92ZXIgMTQgdm9sdHMg YnV0IGRyaWZ0cyBhcm91bmQgYXMgbG93IGFzIDEzLjcuwqAgSWYgSSBwdXQgb24gbXkgbmF2IGFu ZCBzdHJvYmUgbGlnaHRzIHRoZSB2b2x0YWdlIGRyb3BzIHRvIDEzLjMtMTMuNiByYW5nZSBidXQg dGhlIG5lZWRsZSBvbiB0aGUgYW5hbG9nIG1ldGVyIGNvbnRpbnVlcyB0byB2aWJyYXRlIHRoZSBz YW1lLgoKVGhlIG9ubHkgb3RoZXIgY29tcG9uZW50cyAoYmVzaWRlIHRoZSByZWd1bGF0b3IpIGlu IHRoZSBlbGVjdHJpY2FsIHN5c3RlbSBJIGNhbiB0aGluayBvZiB3aGljaCBtaWdodCBiZSBjYXVz aW5nIHRoZSB2b2x0YWdlIHNwaWtlcyBhcmUgdGhlIGNhcGFjaXRvciBvciBhIHByb2JsZW0gd2l0 aCB0aGUgYWN0dWFsIGFsdGVybmF0b3IgY29pbHMuwqAgSSB0aG91Z2h0IHRoZSBwcm9ibGVtIG1h eSBoYXZlIGJlZW4gYSBiYWQgYW5hbG9nIGdhdWdlIGJ1dCBnaXZlbiB0aGF0IHRoZSBkaWdpdGFs IHJlYWRpbmdzIGFyZSBhbHNvIGVycmF0aWMgSSBiZWxpZXZlIGl0IHRvIGJlIGEgbGVnaXRpbWF0 ZSBpc3N1ZSBhbmQgbm90IHNpbXBseSBhIGRpc3BsYXkgcHJvYmxlbS4KCkknbSBwcmV0dHkgZ29v ZCBhdCBjaGFzaW5nIGVsZWN0cm9ucyBidXQgdGhpcyBpc3N1ZSBoYXMgbWUgc3R1bXBlZC7CoCBB bnlvbmUgaGF2ZSBhbnkgaWRlYXMgd2hhdCBjb3VsZCBiZSBjYXVzaW5nIG15IGVycmF0aWMgdm9s dGFnZSBvdXRwdXQ/CgpEb3VnIE1hY0RvbmFsZApDSC03MDEsIE5vcnRod2VzdGVybiBPbnRhcmlv CgrCoAoKwqAKwqAKaHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Sb3Rh eEVuZ2luZXMtTGlzdCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Sb3RheEVu Z2luZXMtTGlzdApocmVmPSJodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9mb3J1 bXMubWF0cm9uaWNzLmNvbQpocmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0 aW9uIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vYwrCoArCoApodHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vTmF2aWdhdG9yP1JvdGF4RW5naW5lcy1MaXN0Cmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNz LmNvbQpodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCsKgCgoKaXN0IiB0YXJn ZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Sb3RheEVuZ2lu ZXMtTGlzdAp0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl9ibGFuayI+aHR0cDovL3d3dy5tYXRy b25pY3MuY29tL2NvbnRyaWJ1dGlvbgoKCgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0gVGhlIFJvdGF4 RW5naW5lcy1MaXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVh dHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3Vj aCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQs IDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBt b3JlOgpfLT0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/Um90 YXhFbmdpbmVzLUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdF QiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUg V2ViIEZvcnVtcyEKXy09Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09 Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09Cl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09 ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09ICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT0gICAtLT4gaHR0cDov L3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoK ________________________________________________________________________________
Date: Jun 20, 2013
Hi Jacques. My mag drops have always been around the 300 mark. I had the same problem under a year ago and ended up swapping coils over left to right to confirm it was a ht coil. I did not make a note and have forgotten which one it was , so it could be the previous new one, and maybe i should have cleaned the connectors first. but its too late now, Can i get a the mag coil tested now its off??? Obvious drop 500 + and rough running and banging , Did all the usual , swapped caps, and plugs, Standard coffee colour , Did note here that the Densol plugs burnt much cleaner the the NGK , WHY ? The plugs in the UK are about 10 each for the 914, and about 2 on the net, so email Densol , are they and different, No universal to the number. Run the engine 1 minute felt the temperature front bottom plugs colder, took them out, looked slightly wet, so guessed that was it. Regards Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403031#403031 ________________________________________________________________________________
Date: Jun 24, 2013
Subject: ground wire
Where should the brown ground wire on a 532 be attached to ? To airframe & engine block ? Am in process of installing a Key West regulator that has a 12Volt DC plug that is labeled to ground. It should probably go to frame & block also, But would it be a good idea to connect it to the brown engine wire also ? Thanks ________________________________________________________________________________
Date: Jun 24, 2013
Subject: Re: Erratic voltage output
I Finally found the source of my erratic voltage readings.- After going t hrough my entire charging circuit from regulator/engine through to the batt ery and verifying there were no poor connection, I tried replacing the VDO voltmeter.- Sure enough, the replacement meter is rock solid through all phases of flight.- I am still seeing a 0.3VDC swing on the digital meter but I am not overly worried about it.- I'm not sure what the problem with the old VDO voltmeter was but a friend had an identical surplus voltmeter for his project.=0A=0A=0AI like it when problems have simple solutions.- Besides it was a good excuse to go through and clean up all of my electrica l connections and install star washers on them.=0A=0AThanks all for the gui dance.=0A=0ADoug M=0ACH-701, NW Ontario, Canada=0A ________________________________________________________________________________
Date: Jun 24, 2013
That VDO .3VDC swing is normal. I wouldn't worry about it. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403359#403359 ________________________________________________________________________________
Subject: carb synch hose sizes
Date: Jun 25, 2013
I'm going to synch my carbs. Does anyone know what size hoses are used to hook into the manifold pressure port? I have a digital manometer (dual) that I'm planning on using. I figure I can get hoses for testing at an auto supply store. The manometer connects to 1/4 inch npt btw. I figure I'll need to get some sort of reducer as well. thanks. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403430#403430 ________________________________________________________________________________
Subject: Re: carb synch hose sizes
Date: Jun 25, 2013
Hi John, I just use vacuum hoses from the auto parts store. Then adapt that to the size you need with a fitting from the hardware store. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403431#403431 ________________________________________________________________________________
Date: Jun 25, 2013
Roger Lee wrote: > Hi John, > > I just use vacuum hoses from the auto parts store. Then adapt that to the size you need with a fitting from the hardware store. Thanks for the reply. That's what I am planning on doing. You don't by chance know what size hose to buy? (saves me a trip to the airport, the auto parts store is close to my house) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403435#403435 ________________________________________________________________________________
Date: Jun 26, 2013
They are the small ones. I think around 1/4" OD and maybe 1/8" or less ID. The hole size should be small and the smaller the better. We don't care about volume just the vacuum. The larger hole sizes will just give you more needle fluctuation to dampen out. I would put a an adjustable needle valve inline on both vacuum lines so you can dampen any gauge needle fluctuation. I'm still old school in on my connection at the cross over. I just pull off the left side of the cross over tube rubber end. Then I know the carbs are separated and not leaking verses if I just pinch off the rubber between carbs. I then just use a barbed fitting and up-size to the hose end I need on the 90 degree fitting (3/8" poly hose) off the top of the manifold and a smooth shank fitting that goes into the rubber end on the cross over tube. (smooth shank= I took a barbed 3/8" barbed fitting and sanded off the barbs) You can certainly use the manifold port screws that are on top of the manifolds to make the connection, but then you still have to separate the carbs by pinching off the cross over tube rubber hose. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403456#403456 ________________________________________________________________________________
Date: Jun 26, 2013
Here's an older picture, but it gets the point across and this works very well. I would use regular vacuum lines and not the clear plastic. The plastic does work. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403473#403473 Attachments: http://forums.matronics.com//files/carb_sync_150_165.jpg ________________________________________________________________________________
Date: Jun 26, 2013
Roger Lee wrote: > Here's an older picture, but it gets the point across and this works very well. I would use regular vacuum lines and not the clear plastic. The plastic does work. Thanks for the picture. Makes sense to me now. How close are you able to get the difference between the carbs? Also, do you make the adjustments to a running engine or do you shut off between adjustments? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403497#403497 ________________________________________________________________________________
Date: Jun 27, 2013
I can get the needles dead on for idle and the high rpm settings. Once you do it a few times it doesn't take long. If you do it each annual or 100 hrs. it's a piece of cake. I always do a running engine. I wear goggles and ear muffs and I give that prop a wide berth. The wheels are always chocked and someone is in the cockpit. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403509#403509 ________________________________________________________________________________
Subject: 914 Electric Fuel pumps
Date: Jun 27, 2013
Hi All. The other day haven flown, I was sitting on the ground engine stopped, I was fiddling with the GPS for about 25 mins, trying to learn how to store a route, I had left both fuel pumps running, ?? Heard the noise but it did not register, Crazy. Any damage or problem I may have caused , pumps running engine stopped on ground about 25-30 minutes. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403538#403538 ________________________________________________________________________________
Subject: Re: 914 Electric Fuel pumps
Date: Jun 27, 2013
Hi Alan, As long as your fuel selector is set for fuel flow and there's fuel flowing through the pumps, they are probably OK. If you ever run a pump without fuel flow through it, it will only last about a minute before it fails. The fuel flow is absolutely necessary to cool and lubricate the pump. How was the flight? Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jun 27, 2013, at 4:59 PM, Alan Carter wrote: Hi All. The other day haven flown, I was sitting on the ground engine stopped, I was fiddling with the GPS for about 25 mins, trying to learn how to store a route, I had left both fuel pumps running, ?? Heard the noise but it did not register, Crazy. Any damage or problem I may have caused , pumps running engine stopped on ground about 25-30 minutes. Alan ________________________________________________________________________________
Date: Jun 27, 2013
That may be if the pump is dry Dave Alberti 262-853-5421 On Jun 27, 2013, at 5:10 PM, Robert Borger wrote: > > Hi Alan, > > As long as your fuel selector is set for fuel flow and there's fuel flowing through the pumps, they are probably OK. > > If you ever run a pump without fuel flow through it, it will only last about a minute before it fails. > > The fuel flow is absolutely necessary to cool and lubricate the pump. > > How was the flight? > > Blue skies & tailwinds, > Bob Borger > Europa XS Tri, Rotax 914, Airmaster C/S Prop. > Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP > 3705 Lynchburg Dr. > Corinth, TX 76208-5331 > Cel: 817-992-1117 > rlborger(at)mac.com > > On Jun 27, 2013, at 4:59 PM, Alan Carter wrote: > > > Hi All. > The other day haven flown, I was sitting on the ground engine stopped, > I was fiddling with the GPS for about 25 mins, trying to learn how to store a route, I had left both fuel pumps running, ?? > Heard the noise but it did not register, Crazy. > Any damage or problem I may have caused , pumps running engine stopped on ground about 25-30 minutes. > > Alan > > > > ________________________________________________________________________________
Date: Jun 27, 2013
Hi Bob. Fuel selector was on, pumps working through out but it did notice a change in tone towards the end, The flight was good, the weather was good, the plane was good, and i was good in talking to Thames Radar, need the practice, Just by coincidence radar asked me to turn East, to avoid traffic, That evening i got an e-mail from the Capitan of the airliner, he had recognized my voice from years ago, and had me on his TECAS , and was watching me out of his window. Small world. right place at right time. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403541#403541 ________________________________________________________________________________
Date: Jun 27, 2013
Hi all. The pumps run continuously in flight, Fuel is going through, but on the ground no air flow around pumps,? Fuel returning to tank, via carbs bowels ? i think? Is there any chance of the fuel getting into the engine,? ie small jet nozzle . Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403542#403542 ________________________________________________________________________________
Date: Jun 27, 2013
Alan, One of the pumps runs continuously in the air. The other should be off. No more air flow around them in the air than on the ground if they are under the baggage compartment as per build manual. They are cooled by fuel flow through them. There's no fuel coming out of the float bowls except through the main jet. The float controls that and if it shuts the fuel off then no more fuel can get into the bowl. Excess fuel returns to the tank via the fuel pressure regulator. There should be no chance of fuel getting into the engine if all is plumbed correctly and the float is operating properly. There is an overflow on the float bowl should excess fuel be introduced but, if all else is correct, that shouldn't happen. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jun 27, 2013, at 5:40 PM, Alan Carter wrote: Hi all. The pumps run continuously in flight, Fuel is going through, but on the ground no air flow around pumps,? Fuel returning to tank, via carbs bowels ? i think? Is there any chance of the fuel getting into the engine,? ie small jet nozzle . Alan ________________________________________________________________________________
Date: Jun 27, 2013
Alan, Brain fart. The 914 float bowl is pressurized and therefore can not have an overflow. The 912 has the float bowl overflow. No fuel gets out of the float bowl on a 914 except through the main jet or starting carb (often referred to as "Choke"). So there should be no fuel getting into the engine with the fuel pumps on and engine not running. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jun 27, 2013, at 7:19 PM, Robert Borger wrote: Alan, One of the pumps runs continuously in the air. The other should be off. No more air flow around them in the air than on the ground if they are under the baggage compartment as per build manual. They are cooled by fuel flow through them. There's no fuel coming out of the float bowls except through the main jet. The float controls that and if it shuts the fuel off then no more fuel can get into the bowl. Excess fuel returns to the tank via the fuel pressure regulator. There should be no chance of fuel getting into the engine if all is plumbed correctly and the float is operating properly. There is an overflow on the float bowl should excess fuel be introduced but, if all else is correct, that shouldn't happen. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jun 27, 2013, at 5:40 PM, Alan Carter wrote: Hi all. The pumps run continuously in flight, Fuel is going through, but on the ground no air flow around pumps,? Fuel returning to tank, via carbs bowels ? i think? Is there any chance of the fuel getting into the engine,? ie small jet nozzle . Alan ________________________________________________________________________________
Date: Jun 28, 2013
Thanks Bob. Float bowls and needle jets ets, its all coming back to me now, this old age is a sod of a thing. I,m glad flying is a bit like riding a bicycle or i would really be stuck. Regards. Alan PS. I just have one enemy up there, the weather, can have a nasty sting in its tail like a wasp, so i treat it like the police and traffic wardens, and avoid it whenever possible. Regards Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403557#403557 ________________________________________________________________________________
Date: Jul 01, 2013
Hi Alan: Well, you just tested the battery and the fuel pumps. Did you shut off the Master before you went home? If so ALL IS WELL! No damage done - No Blood, No foul. *Barry* On Thu, Jun 27, 2013 at 5:59 PM, Alan Carter wrote: > alancarteresq(at)onetel.net> > > Hi All. > The other day haven flown, I was sitting on the ground engine stopped, > I was fiddling with the GPS for about 25 mins, trying to learn how to > store a route, I had left both fuel pumps running, ?? > Heard the noise but it did not register, Crazy. > Any damage or problem I may have caused , pumps running engine stopped on > ground about 25-30 minutes. > > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403538#403538 > > ________________________________________________________________________________
Date: Jul 01, 2013
Subject: Re: RotaxEngines 912uls power loss on takeoff
SSBoYWQgdG8gYWJvcnQgdGhyZWUgYXR0ZW1wdGVkIHRha2VvZmYgdG9kYXkuwqBBZnRlciB0d28g YXR0ZW1wdGVkIHRha2VvZmZzIHdoZXJlIHRoZSBwb3dlciBibGVlZCB0byBpZG9sIEAgMjAlIG9m IHJ1bndheSBhbmQgScKgYWJvcnRlZC4gSSBwdWxsZWQgdGhlIGVuZ2luZSBjb3ZlciBjaGVjayBp dCBvdmVyIGFuZCBsZXQgaXQgY29vbCBkb3duLiBJwqBjYWxsZWQgc29tZSBmb2xrcywgYW5kIHRo ZW4gSSB0cmllZCB0d28gaGFsZiB0YWtlIG9mZnMgd2l0aCBwcmVwbGFubmVkIGFib3J0IHBvaW50 LiBObyBwcm9ibGVtIHdpdGggZmlyc3QgdHdvLCBzbyBvbiB0aGUgdGhpcmQgcnVuIGRvd24gdGhl IHJ1bndheSBJIHBsYW5uZWQgdG8gdGFrZSBvZmYuIEFnYWluIHRoaXMgdGltZSByb3VnaCBlbmdp bmUgYW5kIG1ham9yIHBvd2VyIGxvc3Mgc28gSSBoYWQgdG8gc2h1dCBkb3duIGFuZCBzdGljayB0 byB0aGUgcnVud2F5LiBIaWdoIGRlbnNpdHkgYWx0LiwgMTAxwrogRiB0aGUgcGxhbmUgaXMgdGll ZCBkb3duIGZvciB0aGUgbmlnaHQgYW5kwqBJJ20gZ29pbmcgYmFjayBvdXQgaW4gdGhlIEFNIHRv IHJ1biB1cCBhZ2Fpbi4gQ29uY2VybmVkIGhlcmUsIG5vdCBzdXJlIHdoYXQgdG8gZG8uClBhdWwK Ci0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTogRkxZYURJVkUgPGZseWFk aXZlQGdtYWlsLmNvbT4gCkRhdGU6IDA3LzAxLzIwMTMgIDQ6NTYgUE0gIChHTVQtMDg6MDApIApU bzogcm90YXhlbmdpbmVzLWxpc3RAbWF0cm9uaWNzLmNvbSAKU3ViamVjdDogUmU6IFJvdGF4RW5n aW5lcy1MaXN0OiA5MTQgRWxlY3RyaWMgRnVlbCBwdW1wcyAKIApIaSBBbGFuOgoKV2VsbCwgeW91 IGp1c3QgdGVzdGVkIHRoZSBiYXR0ZXJ5IGFuZCB0aGUgZnVlbCBwdW1wcy4KRGlkIHlvdSBzaHV0 IG9mZiB0aGUgTWFzdGVyIGJlZm9yZSB5b3Ugd2VudCBob21lPwpJZiBzbyBBTEwgSVMgV0VMTCEK Tm8gZGFtYWdlIGRvbmUgLSBObyBCbG9vZCwgTm8gZm91bC4KCgoKQmFycnkKCgpPbiBUaHUsIEp1 biAyNywgMjAxMyBhdCA1OjU5IFBNLCBBbGFuIENhcnRlciA8YWxhbmNhcnRlcmVzcUBvbmV0ZWwu bmV0PiB3cm90ZToKLS0+IFJvdGF4RW5naW5lcy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiQWxh biBDYXJ0ZXIiIDxhbGFuY2FydGVyZXNxQG9uZXRlbC5uZXQ+CgpIaSBBbGwuClRoZSBvdGhlciBk YXkgaGF2ZW4gZmxvd24sIEkgd2FzIHNpdHRpbmcgb24gdGhlIGdyb3VuZCBlbmdpbmUgc3RvcHBl ZCwKSSB3YXMgZmlkZGxpbmcgd2l0aCB0aGUgR1BTIGZvciBhYm91dCAyNSBtaW5zLCB0cnlpbmcg dG8gbGVhcm4gaG93IHRvIHN0b3JlIGEgcm91dGUsIEkgaGFkIGxlZnQgYm90aCBmdWVsIMKgcHVt cHMgcnVubmluZywgPz8KSGVhcmQgdGhlIG5vaXNlIGJ1dCBpdCBkaWQgbm90IHJlZ2lzdGVyLCBD cmF6eS4KQW55IGRhbWFnZSBvciBwcm9ibGVtIEkgbWF5IGhhdmUgY2F1c2VkICwgcHVtcHMgcnVu bmluZyBlbmdpbmUgc3RvcHBlZCBvbiBncm91bmQgYWJvdXQgMjUtMzAgbWludXRlcy4KCkFsYW4K CgoKClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNz LmNvbS92aWV3dG9waWMucGhwP3A9NDAzNTM4IzQwMzUzOAoKCgoKCgoKPT09PT09PT09PT0KLUxp c3QiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1Jv dGF4RW5naW5lcy1MaXN0Cj09PT09PT09PT09Cmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQo9 PT09PT09PT09PQpsZSwgTGlzdCBBZG1pbi4KPSJfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9jb250cmlidXRpb24KPT09PT09PT09PT0KCgoKCgoKXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgIC0g VGhlIFJvdGF4RW5naW5lcy1MaXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNz IExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGls aXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICYg RG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5kIG11 Y2ggbXVjaCBtb3JlOgpfLT0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZp Z2F0b3I/Um90YXhFbmdpbmVzLUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAgIC0gTUFU Uk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxl IHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmlj cy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBT aXRlIC0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09ICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT0gICAt LT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoK ________________________________________________________________________________
Date: Jul 02, 2013
Barry. Yes i did, At the time the pumps where running i was sitting in the plane trying to figure out how two store a flight plan in the sky map 111c. and this noise was going on in the background,and i took no notice of it. then after about 20-30 minutes the penny dropped, and i realized it was the pumps running. I won,t be doing that again, I am hoping to fly today, just a short local. Regards Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403775#403775 ________________________________________________________________________________
Date: Jul 02, 2013
Hello Alan, Can you tell me how you came to the conclusion that you need to replace an HT coil and which one to replace? I seems to have the same issue you had in the past, went to a ROTAX dealer who analysed my engine and told me that the issue is with the carbs and not the ignition. But was not able to solve it... Thanks, Jacques Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403833#403833 ________________________________________________________________________________
Date: Jul 02, 2013
Check for soot on the bottom of one of the carb float bowl! Ira -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403836#403836 ________________________________________________________________________________
Date: Jul 02, 2013
V2lsbCBkby7CoApBbHNvIGFub3RoZXIgOTEyIGJ1aWxkZXIgc3RvcHBlZCBieSBhbmQgdG9sZCBt ZSBSb3RheCBqdXN0IGlzc3VlZCBhIFNlcnZpY2UgQnVsbGV0aW4gZm9yIGZ1ZWwgcHVtcCByZXBs YWNlbWVudC4gSSBmbGV3IDMgaG91cnMgdG8gZ2V0IGhvbWUgYnV0IEknbSB1bm9mZmljaWFsbHkg Z3JvdW5kZWQgdW50aWwgdGhhdCBwdW1wIGlzIHJlcGxhY2VkLsKgClBhdWwKCi0tLS0tLS0tIE9y aWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTogcmFtcGlsIDxpcmEucmFtcGlsQGdtYWlsLmNv bT4gCkRhdGU6IDA3LzAyLzIwMTMgIDQ6MjIgUE0gIChHTVQtMDg6MDApIApUbzogcm90YXhlbmdp bmVzLWxpc3RAbWF0cm9uaWNzLmNvbSAKU3ViamVjdDogUm90YXhFbmdpbmVzLUxpc3Q6IFJlOiBS b3RheEVuZ2luZXMgOTEydWxzIHBvd2VyIGxvc3Mgb24gdGFrZW9mZiAKIAotLT4gUm90YXhFbmdp bmVzLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJyYW1waWwiIDxpcmEucmFtcGlsQGdtYWlsLmNv bT4KCkNoZWNrIGZvciBzb290IG9uIHRoZSBib3R0b20gb2Ygb25lIG9mIHRoZSBjYXJiIGZsb2F0 IGJvd2whCgpJcmEKCi0tLS0tLS0tCklyYSBOMjI0WFMKCgoKClJlYWQgdGhpcyB0b3BpYyBvbmxp bmUgaGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDAz ODM2IzQwMzgzNgoKCgoKCgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgIC0gVGhlIFJvdGF4 RW5naW5lcy1MaXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVh dHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3Vj aCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQs IDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBt b3JlOgpfLT0KXy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9S b3RheEVuZ2luZXMtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oCAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2 YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT3CoMKgIC0tPiBodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIExp c3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09wqAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVy b3VzIHN1cHBvcnQhCl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT3CoMKgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoK ________________________________________________________________________________
Date: Jul 02, 2013
Hi Paul, That bulletin is only a recommendation. You should put a mechanical pump inline and see what the fuel pressure really is and make sure that is the problem, otherwise you may just end up just throwing money at it until you find it. It could be a few other things. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403841#403841 ________________________________________________________________________________
Subject: Engine run on when trying to stop.
Date: Jul 03, 2013
I am putting this out there mostly for Roger but chime in as needed. Rotax 912ULS almost 800 hours on engine. Problem: Engine will continue to run diesel mode when I kill the mag switches when the engine is hot. Symptoms: I have tried one mag at a time, adding a little throttle before turning them off, cooling the engine with a long low power decent, Idle speed is 1800-2000rpm, changed antifreeze, replaced carb balance crossover tube (found a hole), changed spark plugs, checked wires for any pulled out of connectors, grounds are all tight on the top of engine where coils are mounted...... History. No problems last summer. This year the problem started after returning from Sun-N-Fun but it is not even real hot yet here in W TN. I have been running a lot of 100LL in the past year as I fly 30-50 hours a month and need fuel to get home. At first it was intermittent now about 80% of the time. Tried changing spark plugs, drained fuel and now only have 93 pump gas with alcohol, did find a hole in the carb balance tube and repaired it, sometimes the only way to get it to stop is turn off the fuel valve. If it is dieseling I can advance the throttle and it speeds up. On warm up and run up I do get the proper 120-150 RPM drop when doing a mag check. I did a good mechanical carb balance by the book before leaving for Sun-N-Fun and then had the carbs vacuum balance checked by Lockwood when in Florida and they said it could not be any better, but I was not having the problem then. I did watch the online fuels webinar and did not always run the engine above 5000 as they recommended on 100LL. But I do now. Any help Roger or others can give me I will take. This has to be hard on my engine. Thanks ahead of time for the help. Dennis Long -------- Dennis Long Oakland TN 2000 Aeroprakt A20 Vista Cruiser Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar. 700+hours since 1/1/2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403863#403863 ________________________________________________________________________________
Date: Jul 03, 2013
Subject: Re: Engine run on when trying to stop.
Dennis, I always recommend doing the cheap things first 1. Check you mag switch grounds. If you have a key switch like a Cessna, add a dedicated ground. If you can get out the switch easily try grounding the switches when the engine is in diesel mode IF AND ONLY IF it can be done safely. 2. If you have toggle switches for your mags, check to make sure they have not failed internally. Even if you have to replace them to test, you're looking at $10 for a couple at Rat Shack. Rick Girard On Wed, Jul 3, 2013 at 9:42 AM, Thumper wrote: > > I am putting this out there mostly for Roger but chime in as needed. > Rotax 912ULS almost 800 hours on engine. > > Problem: Engine will continue to run diesel mode when I kill the mag > switches when the engine is hot. > > Symptoms: I have tried one mag at a time, adding a little throttle before > turning them off, cooling the engine with a long low power decent, Idle > speed is 1800-2000rpm, changed antifreeze, replaced carb balance crossover > tube (found a hole), changed spark plugs, checked wires for any pulled out > of connectors, grounds are all tight on the top of engine where coils are > mounted...... > > History. No problems last summer. This year the problem started after > returning from Sun-N-Fun but it is not even real hot yet here in W TN. I > have been running a lot of 100LL in the past year as I fly 30-50 hours a > month and need fuel to get home. At first it was intermittent now about > 80% of the time. Tried changing spark plugs, drained fuel and now only > have 93 pump gas with alcohol, did find a hole in the carb balance tube and > repaired it, sometimes the only way to get it to stop is turn off the fuel > valve. If it is dieseling I can advance the throttle and it speeds up. On > warm up and run up I do get the proper 120-150 RPM drop when doing a mag > check. I did a good mechanical carb balance by the book before leaving for > Sun-N-Fun and then had the carbs vacuum balance checked by Lockwood when in > Florida and they said it could not be any better, but I was not having the > problem then. I did watch the online fuels webinar and did not always run > the engine above 5000 as! > they recommended on 100LL. But I do now. > > Any help Roger or others can give me I will take. This has to be hard on > my engine. > > Thanks ahead of time for the help. > Dennis Long > > -------- > Dennis Long > Oakland TN > 2000 Aeroprakt A20 Vista Cruiser > Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar. > 700+hours since 1/1/2009 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403863#403863 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jul 03, 2013
U291bmRzIGdvb2QuIEkgYW0gcGxhbm5pbmcgdG8gY2hlY2sgdGhlIGVmaXMgZGF0YSwgZ2FzY29s YXRvciBtYXliZSBmbG9hdCBib3dscy4gSG93ZXZlciB0aGUgbG93IGZ1ZWwgcHJlc3N1cmUgc3Bp a2VzIGFyZSBteSBjb25jZXJuIGFuZCB0aGF0IHNlbnNvciBpcyBwcmlvciB0byBjYXJicy4KUGF1 bAoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLQpGcm9tOiBSb2dlciBMZWUgPHNz YWRpdmVyMUB5YWhvby5jb20+IApEYXRlOiAwNy8wMi8yMDEzICA3OjU5IFBNICAoR01ULTA3OjAw KSAKVG86IHJvdGF4ZW5naW5lcy1saXN0QG1hdHJvbmljcy5jb20gClN1YmplY3Q6IFJvdGF4RW5n aW5lcy1MaXN0OiBSZTogUm90YXhFbmdpbmVzIDkxMnVscyBwb3dlciBsb3NzIG9uIHRha2VvZmYg CiAKLS0+IFJvdGF4RW5naW5lcy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiUm9nZXIgTGVlIiA8 c3NhZGl2ZXIxQHlhaG9vLmNvbT4KCkhpIFBhdWwsCgpUaGF0IGJ1bGxldGluIGlzIG9ubHkgYSBy ZWNvbW1lbmRhdGlvbi4gWW91IHNob3VsZCBwdXQgYSBtZWNoYW5pY2FsIHB1bXAgaW5saW5lIGFu ZCBzZWUgd2hhdCB0aGUgZnVlbCBwcmVzc3VyZSByZWFsbHkgaXMgYW5kIG1ha2Ugc3VyZSB0aGF0 IGlzIHRoZSBwcm9ibGVtLCBvdGhlcndpc2UgeW91IG1heSBqdXN0IGVuZCB1cCBqdXN0IHRocm93 aW5nIG1vbmV5IGF0IGl0IHVudGlsIHlvdSBmaW5kIGl0LiBJdCBjb3VsZCBiZSBhIGZldyBvdGhl ciB0aGluZ3MuCgotLS0tLS0tLQpSb2dlciBMZWUKVHVjc29uLCBBei4KTGlnaHQgU3BvcnQgUmVw YWlybWFuIC0gTWFpbnRlbmFuY2UgUmF0ZWQKUm90YXggUmVwYWlyIENlbnRlciAtIEhlYXZ5IE1h aW50LiBSYXRlZApIb21lIDUyMC01NzQtMTA4MMKgIFRSWSBIT01FIEZJUlNUCkNlbGwgNTIwLTM0 OS03MDU2CgoKCgpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6CgpodHRwOi8vZm9ydW1zLm1h dHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQwMzg0MSM0MDM4NDEKCgoKCgoKCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8t PcKgwqDCoMKgwqDCoMKgwqDCoCAtIFRoZSBSb3RheEVuZ2luZXMtTGlzdCBFbWFpbCBGb3J1bSAt Cl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UK Xy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24s Cl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwK Xy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPcKgwqAgLS0+IGh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/Um90YXhFbmdpbmVzLUxpc3QKXy09Cl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAt Cl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1z IQpfLT0KXy09wqDCoCAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpf LT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAt Cl8tPcKgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT3CoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC1NYXR0IERy YWxsZSwgTGlzdCBBZG1pbi4KXy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2Nv bnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQoKCg= ________________________________________________________________________________
Date: Jul 03, 2013
This issue can usually be traced back to either a bad or no carb sync or as Rick pointed out the number one cause of dieseling is a bad wire. It may be attached, but not very good. It could as Rick pointed out be a bad switch or a bad wired connection in that link. This is where I would focus my attention first. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403889#403889 ________________________________________________________________________________
Date: Jul 03, 2013
Dennis: For an engine to run it takes four (4) things: 1 - Fuel 2 - Oxygen 3 - Heat usually in the way of a spark 4 - Correct timing For an engine to Diesel it takes any one OR more of the following: 1 - Fuel - YES - Most definitely - BUT, we are not talking about too much fuel or too little fuel - We are saying you must have something to burn for ANY type of combustion to take place. 2 - Oxygen - YES - Most definitely 3 - HEAT - And not a SPARK! Heat as in a HOT SPOT - A glowing carbon spot - A glowing BURR such as a bad spark plug thread hanging into the cylinder - A glowing BURR on the spark plug. 4 - Timing - NO - If the timing was bad you would not have a smooth running engine and your Mag check would be bad. My GUESS is go with #3! Oh! Mag switch? Which make and model Mag Switch do you have? If it is a Bendix with the START position - There is an AD on that switch and it should be checked annually. *Barry* On Wed, Jul 3, 2013 at 10:42 AM, Thumper wrote: > > I am putting this out there mostly for Roger but chime in as needed. > Rotax 912ULS almost 800 hours on engine. > > Problem: Engine will continue to run diesel mode when I kill the mag > switches when the engine is hot. > > Symptoms: I have tried one mag at a time, adding a little throttle before > turning them off, cooling the engine with a long low power decent, Idle > speed is 1800-2000rpm, changed antifreeze, replaced carb balance crossover > tube (found a hole), changed spark plugs, checked wires for any pulled out > of connectors, grounds are all tight on the top of engine where coils are > mounted...... > > History. No problems last summer. This year the problem started after > returning from Sun-N-Fun but it is not even real hot yet here in W TN. I > have been running a lot of 100LL in the past year as I fly 30-50 hours a > month and need fuel to get home. At first it was intermittent now about > 80% of the time. Tried changing spark plugs, drained fuel and now only > have 93 pump gas with alcohol, did find a hole in the carb balance tube and > repaired it, sometimes the only way to get it to stop is turn off the fuel > valve. If it is dieseling I can advance the throttle and it speeds up. On > warm up and run up I do get the proper 120-150 RPM drop when doing a mag > check. I did a good mechanical carb balance by the book before leaving for > Sun-N-Fun and then had the carbs vacuum balance checked by Lockwood when in > Florida and they said it could not be any better, but I was not having the > problem then. I did watch the online fuels webinar and did not always run > the engine above 5000 as! > they recommended on 100LL. But I do now. > > Any help Roger or others can give me I will take. This has to be hard on > my engine. > > Thanks ahead of time for the help. > Dennis Long > > -------- > Dennis Long > Oakland TN > 2000 Aeroprakt A20 Vista Cruiser > Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar. > 700+hours since 1/1/2009 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403863#403863 > > ________________________________________________________________________________
Date: Jul 04, 2013
Paul: Question: Where is the sensor located in relation to the closest fitting in the direction of fuel flow? Why do I ask? Fluid Dynamics 101 - The tap in the feed line must be 7 x the ID BACK from the nearest fitting. I'm not going to get into the complete answer but the simple answer is wave progression with peaks and troughs. If you are too close or at a trough there will be fluctuations and low pressure readings. *Barry* *"Do you know why pilots think they are mechanics? Because they can buy tools at Home Depot.'* ________________________________________________________________________________
Date: Jul 04, 2013
LOVE that quote! Don't forget to research Matt Dralle's fuel accumulator as a potential fix along with the 7x I.d. factoid. John On Jul 4, 2013 5:44 AM, "FLYaDIVE" wrote: > Paul: > > Question: Where is the sensor located in relation to the closest fitting > in the direction of fuel flow? > > Why do I ask? Fluid Dynamics 101 - The tap in the feed line must be 7 x > the ID BACK from the nearest fitting. > I'm not going to get into the complete answer but the simple answer is > wave progression with peaks and troughs. If you are too close or at a > trough there will be fluctuations and low pressure readings. > > *Barry* > > *"Do you know why pilots think they are mechanics? Because they can buy > tools at Home Depot.'* > > * > > * > > ________________________________________________________________________________
Date: Jul 04, 2013
Dennis, I have had this problem for about a year (or more) now. I have done the carbs,gearbox shimming,fuel additives,new plugs,bore scoping cylinders for carbon deposits,high octane boosters/gas,shut down at higher rpms,gone to a lighter prop( which helped a little),etc..you name it I have done it ALL to no avail.( I thought I was the only one in the country with this problem) Now when my engine diesels ,it turns backwards about 3-6 revolutions.( my theory is that the prop stops at the peak of the"dogs" in the gearbox and it flips the prop backwards) As a result ,I have to do the valve check to make sure I don't have any air ingestion in the lifters (I have done it at least a dozen times and can do this check in my sleep now) I have never found any air, at least according to the tappet clearance check Rotax specifies. I thought about using Velcro to attach my cowl as it would come off easier during these checks ! (lol) However, I have not had this problem in the last few months because I have used a different shutdown method and it appears to be working well. I now pull the throttle back to about 1500 rpm,shut off one mag then pull further back to about 1000-1100 rpm then shut off the other mag. This seems to have solved my problem, even with a warm engine (mine never really gets hot in my radial nosed Kitfox) Prior to this method I would shut down at around 1800 rpm and then I might get the diseling on occasion. I know the gearbox doesn't like low rpm's but you are only there for a very short time before the engine quits. Give this a shot and see if it works for you. Please let us know. Dick Maddux 912 UL (400 hrs tt) ________________________________________________________________________________
Date: Jul 05, 2013
I swear, I have never heard of an engine with more reported issues than the ROTAX. I was once told: "It is not the engine, it is the operators." But, even then, shouldn't ROTAX design an engine to be at least somewhat idiot proof? My professor once said: The only way to make something idiot proof is to remove the idiot. But, even then - Fifty million Frenchmen can't be wrong! *Barry* On Thu, Jul 4, 2013 at 11:36 AM, wrote: > ** > Dennis, > I have had this problem for about a year (or more) now. I have done the > carbs,gearbox shimming,fuel additives,new plugs,bore scoping cylinders for > carbon deposits,high octane boosters/gas,shut down at higher rpms,gone to a > lighter prop( which helped a little),etc..you name it I have done it ALL to > no avail.( I thought I was the only one in the country with this problem) > Now when my engine diesels ,it turns backwards about 3-6 revolutions.( my > theory is that the prop stops at the peak of the"dogs" in the gearbox and > it flips the prop backwards) As a result ,I have to do the valve check to > make sure I don't have any air ingestion in the lifters (I have done it at > least a dozen times and can do this check in my sleep now) I have never > found any air, at least according to the tappet clearance check Rotax > specifies. > I thought about using Velcro to attach my cowl as it would come off easier > during these checks ! (lol) > However, I have not had this problem in the last few months because I have > used a different shutdown method and it appears to be working well. > I now pull the throttle back to about 1500 rpm,shut off one mag then pull > further back to about 1000-1100 rpm then shut off the other mag. This seems > to have solved my problem, even with a warm engine (mine never really gets > hot in my radial nosed Kitfox) > Prior to this method I would shut down at around 1800 rpm and then I > might get the diseling on occasion. > I know the gearbox doesn't like low rpm's but you are only there for a > very short time before the engine quits. > Give this a shot and see if it works for you. > Please let us know. > Dick Maddux > 912 UL (400 hrs tt) > ________________________________________________________________________________
Date: Jul 05, 2013
Hi Barry. I tend to agree with you, at 28000 to 30000 I expect better, they seem to have got this wonderful reputation, but they are not so wonderful in my opinion for that sort of money, but I guess there's not a lot of choice out there. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404010#404010 ________________________________________________________________________________
Date: Jul 06, 2013
Dennis here, ease off on the Rotax bashing please. It is not a Rotax part that is bad. As time went on a little more I did not have time to check switches or wiring but the right toggle switch now is the culprit. OR the wiring to it. Now it does not drop RPM on run up, as of yesterdays 8 hours of flying and multiple stops, or even make the engine run rough. So now all I have to do is track that down. Temporarily I just have to hit the primer button once and it stops fine. My only issues has been trying to stop the engine not make it run, the best problem to have. 50+ hours last month, how about you. Guess I fly too much, a good problem to have. Thanks for all of the help, now to find a wiring schematic to guide me on connections. Thanks a lot flyers. Dennis in West Tennessee. 345+ hours since May 5th 2012 on this airplane. Fly Safe and Fly Often my friends. -------- Dennis Long Oakland TN 2000 Aeroprakt A20 Vista Cruiser Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar. 700+hours since 1/1/2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404041#404041 ________________________________________________________________________________
Date: Jul 06, 2013
Hi Dennis, Glad it worked out. Usually that type of issue is a wire or the switch. Nice to see someone taking advantage of lots of flight time. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404047#404047 ________________________________________________________________________________
Date: Jul 06, 2013
50 hours last month, i,m lucky to get 50 a year. Alan. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404057#404057 ________________________________________________________________________________
Date: Jul 07, 2013
Dennis, Glad you are nailing down your problem. I too replaced the wiring in my mag switches and the mag switch itself but that didn't cure the problem. I believe my problem is not the same as yours. In any event my shutdown procedure seems to be working well so I will live with it. My engine starts and runs extremely well and I do like it even though I believe I have worked on it more then any of my Lyc/Cont engines on the 13 other aircraft I have owned thru the years. But then they all take work This group is a life saver for the many problems that crop up. I live in an area that is pretty devoid of Rotax engines so the knowledge here really helps. Dick Maddux 912UL ________________________________________________________________________________
Subject: Dynon EGT D180 Erratic
Date: Jul 07, 2013
One EGT reads in about correct range (+/-) 10-degrees of the other probe, but it 'jumps up and down about 10 to 20 degrees. I am going to replace the probe's connectors that go to the D180 and if that doesn't do it I probably will change the probe, but hesitate to spend the money if it is not really necessary. Any suggestions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404130#404130 ________________________________________________________________________________
Date: Jul 07, 2013
Subject: I Love Left handed drill bits
Let's face it, there are ham handed people in this world who should not be allowed near fine machinery. The fellow who logged that he "cleaned" the carbs on the 912 belonging to my customer is one. He put the fixation screw holding the jet needle in so tight that the screw driver slot just stripped off its ears when I tried to get it out. Soaked it with PB Blaster for 36 hours and no luck. Chucked the piston in my lathe, touched the top of the screw with a center drill and chucked up a left handed drill bit. Took longer to set up than it did for the drill to pull the screw out. As you can see by the picture the needle is quite literally jammed into the bottom of the screw. The carb piston, thankfully, is completely pristeen. Did I mention that I love left handed drill bits? Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jul 07, 2013
Subject: Re: I Love Left handed drill bits
*"THE REASON WHY PILOTS THINK THEY ARE MECHANICS IS BECAUSE THEY CAN BUY TOOLS AT HOME DEPOT."* *Barry* On Sun, Jul 7, 2013 at 3:41 PM, Richard Girard wrote: > Let's face it, there are ham handed people in this world who should not be > allowed near fine machinery. The fellow who logged that he "cleaned" the > carbs on the 912 belonging to my customer is one. He put the fixation screw > holding the jet needle in so tight that the screw driver slot just stripped > off its ears when I tried to get it out. Soaked it with PB Blaster for 36 > hours and no luck. Chucked the piston in my lathe, touched the top of the > screw with a center drill and chucked up a left handed drill bit. Took > longer to set up than it did for the drill to pull the screw out. As you > can see by the picture the needle is quite literally jammed into the bottom > of the screw. The carb piston, thankfully, is completely pristeen. > Did I mention that I love left handed drill bits? > > Rick Girard > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > ________________________________________________________________________________
Subject: Re: Dynon EGT D180 Erratic
Date: Jul 07, 2013
10 degrees is 0.1%!! That's well below the accuracy of the Dynon AD converter! Set your low pass filter to more agreesive filtering and you won't see it bobble. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404143#404143 ________________________________________________________________________________
Date: Jul 07, 2013
Rampil, thank you for the suggestion; now my problem is locate that filter in the Dynon (I guess) ... will have to break out the user's manual... JohnF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404150#404150 ________________________________________________________________________________
Date: Jul 07, 2013
Well, I don't find anything about a filter in the D180 install or user's manual. I am not concerned about the numerical accuracy of the indication, but rather the fact the indicated temperature is jumping up and down while the sensor on the other side of the 912ULS is stable, perhaps moving up/down a degree or two at as slow rate while the 'jumpy" one hops up and down continuously .. I could just disregard it but I keep noticing it and thought to fix it, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404152#404152 ________________________________________________________________________________
Date: Jul 07, 2013
Swap the probe with one from another cylinder and see if the problem follows the probe. That way you know the problem is the probe. Have you made sure you have good grounds for the Dynon. Rick Girard On Sun, Jul 7, 2013 at 2:27 PM, JohnF wrote: > > One EGT reads in about correct range (+/-) 10-degrees of the other probe, > but it 'jumps up and down about 10 to 20 degrees. > > I am going to replace the probe's connectors that go to the D180 and if > that doesn't do it I probably will change the probe, but hesitate to spend > the money if it is not really necessary. > > Any suggestions? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404130#404130 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jul 07, 2013
Hi Rick, It wasn't the mechanics fault. These fixation screws have Loctite on them from Bing and they can strip out if not heated. Once in a while I find one I can remove without over torquing it, but most times I heat them with a heat gun or small butane torch. Once heated they come right out. What were you saying on the other post about Rotax engines, problems and owners? It usually isn't the engine that has the issues, but not having the proper training to maintain them or maintaining them on schedule. They are not Continental's or Lycoming's and treating them as such will only cost owners and mechanics grief and money. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404157#404157 ________________________________________________________________________________
Date: Jul 07, 2013
Dynon considers anything within 15F the same temp. If the EGT, even if it fluctuates, is 0-20 degrees within each other then it should not be an issue. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404160#404160 ________________________________________________________________________________
Date: Jul 08, 2013
Anyone who thinks that this connection needs thread locker clearly does not understand that aluminum has a very high coefficient of friction. In use, there is no external torque that would tend to loosen this connection. Applying thread locker to this connection is unnecessary and a very bad idea. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404178#404178 ________________________________________________________________________________
Date: Jul 08, 2013
Also, Rotax does not even specify EGT monitoring on the 912 series engines in their installation manual. Even the Diamond Katana type certificated airplane with 912-F3 does not have an EGT gauge. Without manual mixture control there is no real need for an EGT since the Bing 64s, when properly maintained, do a good job of maintaining safe and reasonably appropriate mixtures at most density altitudes. Not as good as FI of course which the 912-Si engine results have proven, but good enough for carburetors. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404179#404179 ________________________________________________________________________________
Date: Jul 08, 2013
The most important reason for having EGT's is so that you can watch the trend of the temperatures over time; they are excellent indicators of pending failure if you use them this way. Jay -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Thom Riddle Sent: 08 July 2013 02:30 PM Subject: RotaxEngines-List: Re: Dynon EGT D180 Erratic --> Also, Rotax does not even specify EGT monitoring on the 912 series engines in their installation manual. Even the Diamond Katana type certificated airplane with 912-F3 does not have an EGT gauge. Without manual mixture control there is no real need for an EGT since the Bing 64s, when properly maintained, do a good job of maintaining safe and reasonably appropriate mixtures at most density altitudes. Not as good as FI of course which the 912-Si engine results have proven, but good enough for carburetors. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404179#404179 ________________________________________________________________________________
Date: Jul 08, 2013
John: I have seen some really crazy exhaust systems being used with the Rotax engine... I recall one on a Diamond Moto-Glider that made a 180 Deg turn. The point being is: Variance in EGT between planes of the same type and between cylinders on the same engine is greatly affected by Probe Location. Things like unequal distance from the cylinder head, sharp turns, even simple turns in one stack that are not in the other stack and of course I mentioned; peak and trough of wave formation. But, YES, I would start with the simple checks first; connectors and as Rick said - Swap probes. EGT is a diagnostic tool, whether you have manual control over your mixture or not, it can show trends. If you are use to seeing 1300 F on a regular basis and all of a sudden the temp starts to drop say 200 F that is an indication of a richer (not rich) running system. If you are running dual carbs and you see a difference in one set of cylinders - Your carbs could be going out of sync. Even in a fuel injected engine, if a cylinder is running extra cool or extra rich that is an indication of injector or airflow issues. The real issue with EGT & CHT or for that matter ANY instrumentation is COCKPIT FIXSATION - Not LQQKing out the window. *Barry* On Sun, Jul 7, 2013 at 10:43 PM, Richard Girard wrote: > Swap the probe with one from another cylinder and see if the problem > follows the probe. That way you know the problem is the probe. > Have you made sure you have good grounds for the Dynon. > > Rick Girard > > > On Sun, Jul 7, 2013 at 2:27 PM, JohnF wrote: > >> >> One EGT reads in about correct range (+/-) 10-degrees of the other probe, >> but it 'jumps up and down about 10 to 20 degrees. >> >> I am going to replace the probe's connectors that go to the D180 and if >> that doesn't do it I probably will change the probe, but hesitate to spend >> the money if it is not really necessary. >> >> Any suggestions? >> >> >> ________________________________________________________________________________
Date: Jul 08, 2013
Hi Thom, I comes with a dry blue Loctite from Bing. Either from the factory or if ordered separately. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404233#404233 ________________________________________________________________________________
Date: Jul 08, 2013
Personally I like EGT's. EGT's used properly can give some good info for performance, jetting and engine issues. They tend to read fast and give some indication on what's going on with the burn inside the cyl. CHT's on the other hand are slow and don't indicate as much because they are water cooled. The correct distance for an EGT sensor on a Rotax exhaust pipe is 100mm or 3.9" out from the head. You do need to be able to interpret what gauges are telling you and sometimes need to cross reference one gauge to another to see if what it is telling you is real or a sender only problem. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404236#404236 ________________________________________________________________________________
From: "namedroppers(at)juno.com" <namedroppers(at)juno.com>
Date: Jul 09, 2013
Subject: Engine starts to quit after airborne
I own a Pipistrel Virus motorglider with a Rotax 912 UL. This is a high wing aircraft like a Cessna. After installing a fuel pressure guage by p lacing a T fitting between the fuel pump and the four way distribution b lock and after changing the spark plugs the engine now sputters and want s to quit after lifting off. Before I did this the engine ran fine so I undid what I did. I put the original fuel line back with no T fitting, b lew out all the fuel lines and took the carb fuel bowls off and cleaned them out. The same fuel is in the tanks when it was running ok and I had just taken a 40 minute trip so I doubt it's fuel contamination. I run t he engine on the ground at full throttle with no problems. The only thin g I didn't do was change the spark plugs back to the originals but I wou ld think if that was the problem it wouldn't run ok on the ground. I'm t hinking it might have something to do with the attitude of the aircraft or maybe the ignition system is heating up ?????Any thoughts guys.Giovan ni ____________________________________________________________ New Policy in Mississippi 2012-Drivers w/ no DUIs eligible for up to 50% off car insurance... http://thirdpartyoffers.juno.com/TGL3141/51db6468e022464680383st02vuc ________________________________________________________________________________
Date: Jul 09, 2013
Thom, As Roger noted the Locktite comes applied to the fixation screw in dry form. Also, the use of Locktite 221 is specified for this part in the 912 Illustrated Parts Catalog. Rick Girard On Mon, Jul 8, 2013 at 7:19 AM, Thom Riddle wrote: > > > > Anyone who thinks that this connection needs thread locker clearly does > not understand that aluminum has a very high coefficient of friction. In > use, there is no external torque that would tend to loosen this connection. > Applying thread locker to this connection is unnecessary and a very bad > idea. > > -------- > Thom Riddle > Buffalo, NY (9G0) > > > Don't worry about old age... it doesn't last very long. > - Anonymous > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404178#404178 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Large mag drop
Date: Jul 09, 2013
I have a 912ULS in a RV-12, the plane has just been signed off by the DAR but I have not yet flown it. The engine starts fine right away and has about 2 hours of taxi time on the engine. I get 5050 rpm at wide open throttle and the airport is at ~5000'. The weather here is in the 90+range shortly after 9:00 am. The problem I am having, which has kept me on the ground, is the mag drop. It is about 650 rpm on each ignition and they both run rough. They are close together but that much of a rpm drop seems very unusual. The exhaust pipe is sooted which suggests it is running rich. The plugs also are very black and cleaning them has no effect. All the other temperatures look normal. I tried a five minute run at full throttle and that had no effect either. Any ideas where to look next will be greatly appreciated. Thanks Henry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404353#404353 ________________________________________________________________________________
Subject: Re: Large mag drop
Date: Jul 09, 2013
Hi Henry, 650 is way to high. The good thing is they are almost equal. What rpm are you doing the mag drop at? What is the plug gap? It should be between .023 and .027. Better to be the wider gap for the summer months. Are you running an electric pump with the mechanical all the time? Have you synced these carbs? Did you put a fuel re-circulation line in during the build. The new pumps really need one. Where did you mount the carb vent tubes? These carbs almost sound like they are flooding, but we could use a little more info. It is possible you have a wire connected wrong. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404355#404355 ________________________________________________________________________________
Date: Jul 10, 2013
Looks like you might have a couple of plug caps swapped. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404356#404356 ________________________________________________________________________________
Date: Jul 10, 2013
SGkgSGVucnkuIEFyZSB5b3UgcnVubmluZyBvbiBtb2dhcyA/IE9sZCBmdWVsPyBUcnkgZW1wdHkg eW91ciB0YW5rIC0gcmVmaWxsIGZyZXNoIGZ1ZWwhIEZ1ZWwgb2xkZXIgdGhhbiAyIC0zIG1vbnRo cyBvbmx5IGZvciBsb3dubW92ZXJzIGFuZCB0aGUgbGlrZSEgwqAgSnVzdCBteSAyIGNlbnRzLi4u Li4KCkhhbnMuIEV4IExOLUhKRCwgRXVyb3BhIG1vbm8KCi0tLS0tLS0tIE9wcHJpbm5lbGlnIG1l bGRpbmcgLS0tLS0tLS0KRnJhOiBrcmF6eWRvYzMzIDxnYWxheHlvbmVAanVuby5jb20+IApEYXRv OiAgClRpbDogcm90YXhlbmdpbmVzLWxpc3RAbWF0cm9uaWNzLmNvbSAKRW1uZTogUm90YXhFbmdp bmVzLUxpc3Q6IExhcmdlIG1hZyBkcm9wIAogCi0tPiBSb3RheEVuZ2luZXMtTGlzdCBtZXNzYWdl IHBvc3RlZCBieTogImtyYXp5ZG9jMzMiIDxnYWxheHlvbmVAanVuby5jb20+CgpJIGhhdmUgYSA5 MTJVTFMgaW4gYSBSVi0xMiwgdGhlIHBsYW5lIGhhcyBqdXN0IGJlZW4gc2lnbmVkIG9mZiBieSB0 aGUgREFSIGJ1dCBJIGhhdmUgbm90IHlldCBmbG93biBpdC4gVGhlIGVuZ2luZSBzdGFydHMgZmlu ZSByaWdodCBhd2F5IGFuZCBoYXMgYWJvdXQgMiBob3VycyBvZiB0YXhpIHRpbWUgb24gdGhlIGVu Z2luZS4gSSBnZXQgNTA1MCBycG0gYXQgd2lkZSBvcGVuIHRocm90dGxlIGFuZCB0aGUgYWlycG9y dCBpcyBhdCB+NTAwMCcuIFRoZSB3ZWF0aGVyIGhlcmUgaXMgaW4gdGhlIDkwK3JhbmdlIHNob3J0 bHkgYWZ0ZXIgOTowMCBhbS4gVGhlIHByb2JsZW0gSSBhbSBoYXZpbmcsIHdoaWNoIGhhcyBrZXB0 IG1lIG9uIHRoZSBncm91bmQsIGlzIHRoZSBtYWcgZHJvcC4gSXQgaXMgYWJvdXQgNjUwIHJwbSBv biBlYWNoIGlnbml0aW9uIGFuZCB0aGV5IGJvdGggcnVuIHJvdWdoLiBUaGV5IGFyZSBjbG9zZSB0 b2dldGhlciBidXQgdGhhdCBtdWNoIG9mIGEgcnBtIGRyb3Agc2VlbXMgdmVyeSB1bnVzdWFsLiBU aGUgZXhoYXVzdCBwaXBlIGlzIHNvb3RlZCB3aGljaCBzdWdnZXN0cyBpdCBpcyBydW5uaW5nIHJp Y2guIFRoZSBwbHVncyBhbHNvIGFyZSB2ZXJ5IGJsYWNrIGFuZCBjbGVhbmluZyB0aGVtIGhhcyBu byBlZmZlY3QuIEFsbCB0aGUgb3RoZXIgdGVtcGVyYXR1cmVzIGxvb2sgbm9ybWFsLiBJIHRyaWVk IGEgZml2ZSBtaW51dGUgcnVuIGF0IGZ1bGwgdGhyb3R0bGUgYW5kIHRoYXQgaGFkIG5vIGVmZmVj dCBlaXRoZXIuIEFueSBpZGVhcyB3aGVyZSB0byBsb29rIG5leHQgd2lsbCBiZSBncmVhdGx5IGFw cHJlY2lhdGVkLgpUaGFua3MKSGVucnkKCgoKClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToK Cmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDA0MzUzIzQwNDM1 MwoKCgoKCgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgIC0gVGhlIFJvdGF4RW5naW5lcy1M aXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2 aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0 IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJy b3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOgpfLT0K Xy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Sb3RheEVuZ2lu ZXMtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIE1BVFJP TklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2 aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT3CoMKgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmlj cy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIExpc3QgQ29udHJp YnV0aW9uIFdlYiBTaXRlIC0KXy09wqAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBv cnQhCl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT3CoMKgIC0tPiBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoKCgo ________________________________________________________________________________
Date: Jul 10, 2013
I am aware that Rotax puts the blue loctite on that screw. I am also aware that they have changed their minds on many other things as their customer base's experience increased over the years. As experience grew they have redesigned or changed specs on many things over the years. One original design element in particular that caused all kinds of grief which they eventually changed was the internal Torx type fitting on the gearbox magnetic oil fitting. My experience with aluminum threads, where no in-use external torque is applied in the loosening direction, is that no thread locker is needed due to the high coefficient of friction. Perhaps Rotax will one day realize that loctite is not needed on this carb part. Until then, use it if you want. I remove it from the carbs I disassemble and do not apply new loctite when re-installing. In fact upon reinstallation I torque it only with thumb and one finger because even without loctite it very easy to over torque this part and make the left-handed drills or easy-outs a required part of future disassembly. Been there once and that was enough. -------- Thom Riddle Buffalo, NY (9G0) Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404362#404362 ________________________________________________________________________________
Date: Jul 10, 2013
Hi Roger, By a wire wrong I ASSume that you mean a plug wire? I will check that but it is the same as it came from Van's. The mag check was done at 4000 rpm both before the run at 5000+rpm and after that too. No change. The plug gap is at 0.020", I will open them up to 0.028". There is an electric pump just after the fuel tank and I have run with that on, usually about 5 psi is shown on the fuel pressure gauge. There is a fuel return line to the tank. The vent tubes come down to the drip tray. Every thing indicates flooding or a very rich mixture. With a lycorasuras I would run it close to wide open and lean it out very aggressively but can't or don't know how to do that with the Bings. I have done a mechanical sync. but not yet done a pneumatic sync. I ASSume that the two ignition systems, A & B, each control one set of plugs, upper and lower although I have not yet found in the documentation which one is the upper plugs and which is the lower plugs. Do you make house calls? :) Thanks Henry, Los Lunas, NM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404371#404371 ________________________________________________________________________________
Date: Jul 10, 2013
Hi Henry, The plug gap is way to small. The Rotax specs are .023 (cold weather and .027 hot weather) Do not gap them wider. This will change the mag drop all by itself. Then as Conrad suggest look at the plug wires. The wires are labeled. #1 cyl. is front right, #3 is rear right, #2 is front left and #4 is rear left. Try not running the electric pump. You may be flooding. You absolutely need to do a pneumatic sync. All a mechanical sync does is get you in the ballpark for idle and hopefully close for higher rpm runs, but it can be significantly off. Do all of these things first before the next start. The ignition system chart you are referring to is in the Heavy Maint. manual. After you do these couple of things then try a new mag drop and let us know the results. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404390#404390 ________________________________________________________________________________
Date: Jul 10, 2013
Hi Thom, The reason Loctite is applied here is that these are two different metals and this area gets significant vibration and any loosening would cause a needle change in the jet and possibly a aircraft incident before it was found. I'm sure they have had their reasons over the last 22 years to apply this. It's a better safe than sorry application. Too much Loctite here can be a problem getting it out later. Just the tiniest drop is needed. If it still has some of the old Loctite on the screw it will work just fine. Heating it is no big deal either for removal. Like I said, I take a small butane torch and heat it for a few seconds and they all come right out. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404391#404391 ________________________________________________________________________________
Date: Jul 10, 2013
Gaggle: >From a Test Engineer viewpoint; Thom is quite accurate with aluminum threads not requiring a liquid locking agent. There are a few questions that would have to be asked though: 1 - What type of aluminum is the part made from? 2 - What temper is it brought to? 3 - Was the tempering done before or after the threads were cut? 4 - Were the threads cut or rolled? 5 - What type of thread is being used? 6 - What material is the part being threaded into? And then a repeat of all the questions above about the mating threaded part: 7 - What type of aluminum is the part made from? 8 - What temper is it brought to? 9 - Was the tempering done before or after the threads were cut? 10 - Were the threads cut or molded <-- Since this is a internal thread. 11 - What type of thread is being used? <-- This should be the same as the mating part - BUT - Sometimes one company makes part A and another makes part B and little things like percentage of thread is different. Now if both parts are aluminum and ESPECIALLY if they are not ANODIZED, There is a very high possibility of galling and/or fretting. Some methods of prevention are: Shoulder Seat - To limit force/torque on threads - This is something Roatx really should consider. Maybe in the next generation of engineering changes. Lock washer - I guess none was used in this situation. Nylon Stop Plug Teflon Tape - Not for this situation. Untrained users. Teflon Paste - HMmmmm much better idea - But 99.9987% of the users tend to OVER APPLY it and cause catastrophic problems. Liquid Locking Compound - Well this would be BLUE Loctite but there is a problem with this -- They advertize a holding strength of 8.5 Nm (~6.2 Ft/Lbs). Well this is WAY too much holding force for such a small thread and material. So, again I hope Rotax makes some changes. AND when Loctite did this testing and came up with the 8.5 Nm, they did NOT test it on aluminum threads. Holding force is VERY argumentative. They TRY to be scientific but in the long run it is a shot in the twilight. Last point: It truly is a good idea to use SOMETHING on the threads. Not really needed too much for holding but for thread protection. If aluminum threads are not protected they will gall/frett and LOCK-UP! From an FAA standpoint they and you need some reassurance that the thing will not vibrate free in flight AND should be easy to remove for inspection/repair/replacement. Just think there are companies that have made entire fortunes on just doing that - Loctite! *Barry* On Wed, Jul 10, 2013 at 8:05 AM, Thom Riddle wrote: > > > > I am aware that Rotax puts the blue loctite on that screw. I am also aware > that they have changed their minds on many other things as their customer > base's experience increased over the years. As experience grew they have > redesigned or changed specs on many things over the years. One original > design element in particular that caused all kinds of grief which they > eventually changed was the internal Torx type fitting on the gearbox > magnetic oil fitting. > > My experience with aluminum threads, where no in-use external torque is > applied in the loosening direction, is that no thread locker is needed due > to the high coefficient of friction. Perhaps Rotax will one day realize > that loctite is not needed on this carb part. Until then, use it if you > want. > > I remove it from the carbs I disassemble and do not apply new loctite when > re-installing. In fact upon reinstallation I torque it only with thumb and > one finger because even without loctite it very easy to over torque this > part and make the left-handed drills or easy-outs a required part of future > disassembly. Been there once and that was enough. > > -------- > Thom Riddle > Buffalo, NY (9G0) > > > Don't worry about old age... it doesn't last very long. > - Anonymous > > ________________________________________________________________________________
Date: Jul 10, 2013
I may agree about aluminum, but from the Bing and Rotax guys it's a liability issue. Adding a little heat as far as they are concerned is no big deal for peace of mind. Should be peace of mind for you now too. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404416#404416 ________________________________________________________________________________
From: "Clive Richards" <s.clive.richards(at)homecall.co.uk>
Subject: 912UL Will not start on UL91
Date: Jul 12, 2013
Hi all A fellow pilot has found his 912UL will not start on UL91 avgas now the temperature is high 21 to 29 C. after checking every thing he eventually changed one tank to 100LL and it starts ok, changing to the tank with UL91 it runs very rough. Our 0-200 runs on the UL91 from the same pump with no problem, we have our own problem of high oil temperature. Originally he used 100LL but UL91 became available in the winter and he has used it until now but the weather has become hot. Hopefully Roger will know if it is the carb needle that requires adjustment. Clive G CBDG 601HD 0 200 590 Hrs. Helping build a 701 ________________________________________________________________________________
Subject: Re: 912UL Will not start on UL91
Date: Jul 12, 2013
Hi Clive, The temps should have not made any difference between the two fuels. Something else is going on. I would pull the carb tops off and check the needle positions. The clips should be in the #3 slot. Third slot down from the top. If it is in the #2 position it could cause rough running depending on elevation or altitude. It would be a little lean. Those OAT's aren't an issue. That's 70F to 84F. While your checking the carbs double check the bowls and make sure it has had a carb sync. Make sure the plug gaps are at .023 - .027. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404585#404585 ________________________________________________________________________________
Subject: Mag plug extraction
Date: Jul 13, 2013
Hi there all during the 100's hour visit I tried to verify the mag plug as per the manual but couldn't extract it: when unscrew it turns but not exits! can't screw it either, turns fool. Probably over torqued during las t visit... Then I deposed the gearbox to have a look and tried to push it from inside when unscrewing. No success. Any suggestion first to put it out and then to put a new one? Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 450 hours F-PLDJ DynAro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1550 heures -------- Max8992 Europa XS #560 F-PMLH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404606#404606 ________________________________________________________________________________
Subject: Re: Mag plug extraction
Date: Jul 13, 2013
There is a video on Rotax-Owners.com that describes how to take out and replace the mag plug with a new one. There is an extractor tool that you can buy to help take it out. Regards, Damien ----- Original Message ----- From: "max8992" <mcointe(at)free.fr> Sent: Saturday, July 13, 2013 1:52 PM Subject: RotaxEngines-List: Mag plug extraction > > Hi there all > during the 100's hour visit I tried to verify the mag plug as per the > manual but couldn't extract it: when unscrew it turns but not exits! can't > screw it either, turns fool. Probably over torqued during las t visit... > Then I deposed the gearbox to have a look and tried to push it from inside > when unscrewing. No success. > Any suggestion first to put it out and then to put a new one? > Max Cointe > mcointe(at)free.fr > F-PMLH Europa XS_TriGear > Kit #560-2003 912ULS/AirmasterAP332 450 hours > > F-PLDJ Dyn?TAro MCR 4S > Kit #27-2002 912ULSFR/MTProp MTV7A 1550 heures > > -------- > Max8992 > Europa XS #560 F-PMLH > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404606#404606 > > > ________________________________________________________________________________
Date: Jul 21, 2013
From: "Ralph K. Hallett III" <n100rh(at)sbcglobal.net>
Subject: Re: RotaxEngines-List Digest: 8 Msgs - 07/10/13
A quick question for you all. I have a 912S in a Rans S7. Out of the blue the oil pressure gauge is rapidly swinging from high to low followed by a pause at the correct oil pressure. Then more of the same. This only happens after flying for 20 min or so in 70F weather. I figured it must be the sender unit which is attached to the block near the oil pump. I got the same readings on the next flight. Reducing the engine to idle causes the gauge to settle down. However, here's where it gets interesting, I noticed that all the gauges, tach, oil temp, oil pressure and voltage are stable at the beginning of the flight but when the oil pressure starts to swing wildly the other gauges too have started to vibrate, not to the extent of the oil pressure. I'm starting to become suspicious that the voltage regulator is getting ready to crap out. Thoughts? Ralph Reno, NV ________________________________________________________________________________
Date: Jul 21, 2013
Subject: Fuel distribution banjo fittings
Okay, the airplane I am working on was built without a fuel return line. I am trying to figure out the correct banjo fittings for getting fuel from the pump, a line to each carburetor, and a return line. The IPS is clear as mud. I want to use a 851327 clamp block with a 840518 allen screw and a 641733 slotted head screw and a 230150 gasket ring Can I use two double hose nipples # 956602, one for the line from the fuel pump and the return line with a 963820 pilot jet in it, and one for going to each carb? Do I need two banjo bolts or one? (p/n please) What is in the 941785 banjo bolt assy? All of the above minus the clamp block and its hardware? Much thanks to anyone who can lead me through this morass. Rick Girard It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jul 21, 2013
Subject: Starting carburetors
The airplane has ~500 hours on it and the 912 ULS. Except for one logbook entry for carburetor cleaning it appears that this was the first carb rebuild. The needle valves in both carbs failed and both would overflow within three to four blade cold cranking. The starting carburetors, which had worked flawlessly seemed to have failed, the engine was hard starting. I rebuilt one carb at a time to always have a complete carb for reference and to avoid mixing parts. I started with the right carb (overflow tube pointed outboard. When I pulled the starting carb housing I found the inboard end of the shaft was stamped "L". Staining on the disk seemed to indicate that the slot was properly positioned so that when it was rotated the slot was moved over the port connected to the float bowl. The rebuild was a complete overhaul, all gaskets, o rings, diaphragms and floats were replaced, as was the needle and needle jet. I located the dot on the outboard end of the starting carb shaft so that it pointed toward the cable and lightly tightened the four screws of the housing. Disassembly of the left carb (overflow tube pointing inboard) revealed that the starting carburetor shaft was stamped on the inboard end "R". Again, staining on the disk showed that the slot uncovered the port from the float bowl when it was rotated. At this point I was beginning to doubt my sanity. I considered that German for Right starts with and "L". It doesn't. I thought perhaps Rotax directed right and left as seen with from the prop end of the engine. From what I could find in the Installation Manual, right and left are relative to the pilot looking forward with the engine mounted in a tractor installation. Since the history of the engine seemed to show that the starting carbs were working until recently, but had stopped working (I should add that there was no sign that the starting carbs had been opened before I did) I decided to put the disk assembly with the shaft stamped "R" in the right carb and put the "L" disk in the left carb. Because the airplane's owner wants to overhaul the fuel system to include a fuel return line to control fuel pressure, we did not attempt to start the engine when I re-installed the carbs today. The possibilities seem to be; A. Both starting carbs were miss assembled with a right shaft mated to a left disk and vice versa. B. I have misinterpreted the Installation manual and right and left orientation are relative to the prop end of the engine. C. These carbs were originally installed in the Twilight Zone. Comments? Advise? Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: Starting carburetors
Date: Jul 22, 2013
Hi Rick, The chokes were marked and on the correct carb. If you switched them then switch them back or they won't work. The center punch dot on the end of the choke shaft should be facing the tube that looks like it is molded in the choke assembly. Tighten the 4 screws well so there I are no leaks and they are supposed to have blue Loctite. (Medium strength) -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405061#405061 ________________________________________________________________________________
Date: Jul 22, 2013
Hi Ralph, I'm with Rick. Sounds like a poor ground. It could be a loose ground or a corroded one. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405063#405063 ________________________________________________________________________________
Subject: Re: Fuel distribution banjo fittings
Date: Jul 22, 2013
Parts needed. >From IP manual dated Sept. 2011 rev 2 page 21-2 The number is the schematic number in the picture that corresponds to the actual part number for ordering. The fuel return line comes off #7. # 5 : 840518 6 : 950143. Need 5. Copper gaskets 7: 956312 banjo with restrictor for the recirculation line 8: 851327 9: 941785 11: 230150 12: 641733 fuel pressure line to gauge 13: 940872. Fuel in from pump and out to carbs (double banjo bolt) -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405065#405065 ________________________________________________________________________________
Subject: Off topic - Roger Lee
Date: Jul 22, 2013
Roger Are you going to Oshkosh. I am and if you are would like to give you a call. Cheers Peter -------- Peter Armstrong Auckland, New Zealand DynAero MCR-4S (Do not shoot me :) ). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405093#405093 ________________________________________________________________________________
Date: Jul 22, 2013
Subject: Re: Off topic - Roger Lee
pestar a crit : > > Roger > > Are you going to Oshkosh. I am and You lucky guy ! Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Jul 22, 2013
Hi Peter, Sorry not heading to Oshkosh. You're still welcome to give me a call. In Utah for the next week. 520-349-7056 -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405096#405096 ________________________________________________________________________________
Date: Jul 22, 2013
> In Utah for the next week. 520-349-7056 What, you do house calls? In Utah? I'm in Park City, UT. While I don't have any immediate needs I'm sure I will ;-) -- Craig ________________________________________________________________________________
Date: Jul 22, 2013
I'm on vacation in Marysvale, UT. Will be here another week quad riding the mountains. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405141#405141 ________________________________________________________________________________
Date: Jul 23, 2013
Subject: Re: RotaxEngines-List Digest: 8 Msgs - 07/22/13
Thanks all, I will check all the ground straps. Ralph On 7/23/2013 12:00 AM, RotaxEngines-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-07-22&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-07-22&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Mon 07/22/13: 8 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:24 AM - Re: Starting carburetors (Roger Lee) > 2. 06:25 AM - Re: RotaxEngines-List Digest: 8 Msgs - 07/10/13 (Roger Lee) > 3. 06:49 AM - Re: Fuel distribution banjo fittings (Roger Lee) > 4. 01:35 PM - Off topic - Roger Lee (pestar) > 5. 01:38 PM - Re: Off topic - Roger Lee (Gilles Thesee) > 6. 01:46 PM - Re: Off topic - Roger Lee (Roger Lee) > 7. 02:28 PM - Re: Re: Off topic - Roger Lee (Craig Payne) > 8. 09:23 PM - Re: Off topic - Roger Lee (Roger Lee) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: RotaxEngines-List: Re: Starting carburetors > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Hi Rick, > > The chokes were marked and on the correct carb. If you switched them then switch > them back or they won't work. The center punch dot on the end of the choke shaft > should be facing the tube that looks like it is molded in the choke assembly. > Tighten the 4 screws well so there I are no leaks and they are supposed to > have blue Loctite. (Medium strength) > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405061#405061 > > > ________________________________ Message 2 _____________________________________ > > > Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 8 Msgs - 07/10/13 > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Hi Ralph, > > I'm with Rick. Sounds like a poor ground. It could be a loose ground or a corroded > one. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405063#405063 > > > ________________________________ Message 3 _____________________________________ > > > Subject: RotaxEngines-List: Re: Fuel distribution banjo fittings > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Parts needed. > >From IP manual dated Sept. 2011 rev 2 page 21-2 > The number is the schematic number in the picture that corresponds to the actual > part number for ordering. The fuel return line comes off #7. > > # 5 : 840518 > 6 : 950143. Need 5. Copper gaskets > 7: 956312 banjo with restrictor for the recirculation line > 8: 851327 > 9: 941785 > 11: 230150 > 12: 641733 fuel pressure line to gauge > 13: 940872. Fuel in from pump and out to carbs (double banjo bolt) > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405065#405065 > > > ________________________________ Message 4 _____________________________________ > > > Subject: RotaxEngines-List: Off topic - Roger Lee > From: "pestar" <peter(at)reivernet.com> > > > Roger > > Are you going to Oshkosh. I am and if you are would like to give you a call. > > Cheers Peter > > -------- > Peter Armstrong > Auckland, New Zealand > DynAero MCR-4S (Do not shoot me :) ). > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405093#405093 > > > ________________________________ Message 5 _____________________________________ > > > From: Gilles Thesee <Gilles.Thesee@ac-grenoble.fr> > Subject: Re: RotaxEngines-List: Off topic - Roger Lee > > > pestar a crit : >> Roger >> >> Are you going to Oshkosh. I am and > You lucky guy ! > > Best regards, ________________________________________________________________________________
Date: Jul 26, 2013
Subject: Auto Response
I am UNAVAILABLE. I'll respond after the sixth of August. ________________________________________________________________________________
Date: Jul 31, 2013
Subject: Bing 54 starting problems
Have a new Rotax 532 with new Bing 54 carbs. Engine will not start without injecting a few CC's of gas through a carb. Carbs have manual enrichers (chokes), but they do not seem to help starting. After injecting fuel into crankcase it fires on first pull. When running it idles fine ( so don't think idle jets are plugged ) When running , activating the chokes bog the engine & lower EGT's quickly. Ideas ? ________________________________________________________________________________
Subject: Rotax engine parts
Date: Aug 01, 2013
I'm looking for recommendations for getting parts for a 447 Rotax. Thanks, Dave Kulp Bethlehem, PA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405784#405784 ________________________________________________________________________________
Subject: Rotax 912ULS Stumble below 4000 RPM on final ONLY**
Date: Aug 01, 2013
Hello all. I've got a Zodiac 601 XL-B with a Rotax 912ULS and a warp drive three blade. It's set at 15 degrees pitch, giving me 5500 RPM CLIMB OUT, 5200-5300 static. This engine runs flawlessly on the ground. It has only 175 hours on the engine. New plugs, carbs synced, oil changed. Fresh fuel lines. All parameters are well within margins. Climbs and runs like a top, and is happy at 5500 cruise. The airplane does 100-110kts straight and level at 5500 rpm. Fuel burn is approximate at 3.5-4.1 gal/hr. I fly my pattern at 90kts, with 70-80 on final. When I pull the power back gradually to slow it for flaps and turning base, anything under 4k and it shakes and thuds. Maybe that speed unloads the prop? I don't know. Like I said, runs like a top on the ground. It's only running like a bag of hammers in the circuit pulling back under 4k. It is a slipper clutched plane. Any help is appreciated! Thanks in advance! Chad -------- C-GYXQ. 912ULS. 601XL-B Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405795#405795 ________________________________________________________________________________
Date: Aug 02, 2013
Thanks Roger I passed the information on. The owner arranged for a Rotax maintenance engineer to come to the airfield & he found the starter sprag clutch causing the starting problems and that the soft start had not been connected. No explanation was found as to why it ran rough on the UL91 but runs fine on 100LL & UL91 now so will run on the UL91 to protect the engine from the lead. Clive ----- Original Message ----- From: "Roger Lee" <ssadiver1(at)yahoo.com> Sent: Saturday, July 13, 2013 5:37 AM Subject: RotaxEngines-List: Re: 912UL Will not start on UL91 > > Hi Clive, > > The temps should have not made any difference between the two fuels. > Something else is going on. I would pull the carb tops off and check the > needle positions. The clips should be in the #3 slot. Third slot down from > the top. If it is in the #2 position it could cause rough running > depending on elevation or altitude. It would be a little lean. Those OAT's > aren't an issue. That's 70F to 84F. While your checking the carbs double > check the bowls and make sure it has had a carb sync. Make sure the plug > gaps are at .023 - .027. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404585#404585 > > > ________________________________________________________________________________
Date: Aug 02, 2013
Subject: Re: Rotax 912ULS Stumble below 4000 RPM on final ONLY**
Chad, Sounds to me like you have one of your throttle cables hanging up. By that I mean the internal cable on the outer shroud. I had this happen on my Kitfox during approach throttle reduction. Lubing the cables helped for awhile but then I finally replaced them and that solved my problem. Dick Maddux 912UL ________________________________________________________________________________
Date: Aug 02, 2013
Dick, Thanks for the reply. Makes sense but at the same time doesn't ? It doesn't do it on the ground. Maybe because I'm not going from very high throttle down to 4000 on the ground? Good point though, I'll have to check. Chad -------- C-GYXQ. 912ULS. 601XL-B Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405811#405811 ________________________________________________________________________________
Date: Aug 02, 2013
SnVzdCBhIHN1Z2dlc3Rpb24uICBIYXZlIHlvdSBjaGVja2VkIHlvdXIgY2FyYiB2ZW50IHBpcGVz LiBNYWtlIHN1cmUgdGhleSBhcmUgYm90aCBjb25uZWN0ZWQgdG8gdGhlIHBsZW5udW0gY2hhbWJl ciBhbmQgdGhhdCBuZWl0aGVyIGlzIGJsb2NrZWQuDQpQZXRlIEplZmZlcnMNCg0KLS0tLS1Pcmln aW5hbCBNZXNzYWdlLS0tLS0NCkZyb206IFNJREVTTElQDQpTZW50OiAwMi8wOC8yMDEzIDAyOjM1 DQpUbzogcm90YXhlbmdpbmVzLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUm90YXhFbmdp bmVzLUxpc3Q6IFJvdGF4IDkxMlVMUyBTdHVtYmxlIGJlbG93IDQwMDAgUlBNIG9uIGZpbmFsIE9O TFkqKg0KDQotLT4gUm90YXhFbmdpbmVzLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJTSURFU0xJ UCIgPENoYWQyMDA3QHJvZ2Vycy5jb20+DQoNCkhlbGxvIGFsbC4gSSd2ZSBnb3QgYSBab2RpYWMg NjAxIFhMLUIgd2l0aCBhIFJvdGF4IDkxMlVMUyBhbmQgYSB3YXJwIGRyaXZlIHRocmVlIGJsYWRl LiANCg0KSXQncyBzZXQgYXQgMTUgZGVncmVlcyBwaXRjaCwgZ2l2aW5nIG1lIDU1MDAgUlBNIENM SU1CIE9VVCwgNTIwMC01MzAwIHN0YXRpYy4gVGhpcyBlbmdpbmUgcnVucyBmbGF3bGVzc2x5IG9u IHRoZSBncm91bmQuIEl0IGhhcyBvbmx5IDE3NSBob3VycyBvbiB0aGUgZW5naW5lLiBOZXcgcGx1 Z3MsIGNhcmJzIHN5bmNlZCwgb2lsIGNoYW5nZWQuIEZyZXNoIGZ1ZWwgbGluZXMuIEFsbCBwYXJh bWV0ZXJzIGFyZSB3ZWxsIHdpdGhpbiBtYXJnaW5zLiBDbGltYnMgYW5kIHJ1bnMgbGlrZSBhIHRv cCwgYW5kIGlzIGhhcHB5IGF0IDU1MDAgY3J1aXNlLiBUaGUgYWlycGxhbmUgZG9lcyAxMDAtMTEw a3RzIHN0cmFpZ2h0IGFuZCBsZXZlbCBhdCA1NTAwIHJwbS4gRnVlbCBidXJuIGlzIGFwcHJveGlt YXRlIGF0IDMuNS00LjEgZ2FsL2hyLiANCg0KSSBmbHkgbXkgcGF0dGVybiBhdCA5MGt0cywgd2l0 aCA3MC04MCBvbiBmaW5hbC4gDQoNCldoZW4gSSBwdWxsIHRoZSBwb3dlciBiYWNrIGdyYWR1YWxs eSB0byBzbG93IGl0IGZvciBmbGFwcyBhbmQgdHVybmluZyBiYXNlLCBhbnl0aGluZyB1bmRlciA0 ayBhbmQgaXQgc2hha2VzIGFuZCB0aHVkcy4gTWF5YmUgdGhhdCBzcGVlZCB1bmxvYWRzIHRoZSBw cm9wPyBJIGRvbid0IGtub3cuIExpa2UgSSBzYWlkLCBydW5zIGxpa2UgYSB0b3Agb24gdGhlIGdy b3VuZC4gSXQncyBvbmx5IHJ1bm5pbmcgbGlrZSBhIGJhZyBvZiBoYW1tZXJzIGluIHRoZSBjaXJj dWl0IHB1bGxpbmcgYmFjayB1bmRlciA0ay4gSXQgaXMgYSBzbGlwcGVyIGNsdXRjaGVkIHBsYW5l LiANCg0KQW55IGhlbHAgaXMgYXBwcmVjaWF0ZWQhDQoNClRoYW5rcyBpbiBhZHZhbmNlIQ0KDQpD aGFkDQoNCi0tLS0tLS0tDQpDLUdZWFEuIDkxMlVMUy4gNjAxWEwtQg0KDQoNCg0KDQpSZWFkIHRo aXMgdG9waWMgb25saW5lIGhlcmU6DQoNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3 dG9waWMucGhwP3A9NDA1Nzk1IzQwNTc5NQ0KDQoNCg0KDQoNCg0KDQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAg ICAgIC0gVGhlIFJvdGF4RW5naW5lcy1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1h dHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBM aXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUg U2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hh cmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9OYXZpZ2F0b3I/Um90YXhFbmdpbmVzLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAg ICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVu dCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExp c3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVy b3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFs bGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRy aWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0NCg0KDQoNCg= ________________________________________________________________________________
Date: Aug 02, 2013
Subject: Trouble starting a 912 ULS
Folks, I've gradually had trouble starting a ULS with the 912 Rotax high torque starter. First it did not like starting when it was cold. Then the sprag seemed to come disengaged without turning the engine over enough to start. Finally I started getting a gear-grinding noise. Then eventually the gears never engaged; just a grinding noise. I checked the starter alignment between the two ears for the bolts. Perhaps a 0.010" difference between the gaps of the two ears and no way to adjust that I could see since the ears of the starter flange are threaded as are the bolt holes on the engine. I removed the Rotax starter and found the gear surface was a little rough as was the mating gear teeth inside the engine. Probably from the grinding... I replaced the starter with a Skytec, aligned as best I could to exactly the same position as the Rotax starter (off about 0.010" between the top and bottom ears of the starter flange and the engine surface). The Skytec starter does exactly the same thing - grinds the gears without really engaging. Anyone have any ideas? Anything I should check before I start taking apart the engine to get to the starter gears and clutch? John ________________________________________________________________________________
Date: Aug 02, 2013
Folks, One more data point on the trouble starting: It is not the battery current. I've connected a truck battery in parallel with the plane's battery (so the ignition is switching more amps) and not solved the problem. John ________________________________________________________________________________
Subject: 914 Alternator Options
Date: Aug 02, 2013
I am building a Europa with a Rotax 914 engine. It has become clear to me that my electrical power needs are unlikely to be met from the internal alternator. The alternatives are the Rotax belt driven alternator, or the B&C SD20 alternator driven off the vacuum pad. The belt driven alternator goes where I would really like my air intake hoses to go, so the SD20 looks like an attractive option. However when I look at my vacuum pad, it has a blanking plate, so I assume that I would have to install the vacuum drive gear shaft. Is this correct and can anyone advise me as to how difficult this is? Is it something that I can do myself or, as it seems to require opening the gearbox, is this a Rotax service center job? Thanks. Jerry Fisher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405824#405824 ________________________________________________________________________________
Date: Aug 02, 2013
Subject: Re: 914 Alternator Options
N6ZY a crit : > > I am building a Europa with a Rotax 914 engine. It has become clear to me that my electrical power needs are unlikely to be met from the internal alternator. The alternatives are the Rotax belt driven alternator, or the B&C SD20 alternator driven off the vacuum pad. The belt driven alternator goes where I would really like my air intake hoses to go, so the SD20 looks like an attractive option. However when I look at my vacuum pad, it has a blanking plate, so I assume that I would have to install the vacuum drive gear shaft. Is this correct and can anyone advise me as to how difficult this is? Is it something that I can do myself or, as it seems to require opening the gearbox, is this a Rotax service center job? Thanks. > > Jerry, Have you considered this option ? http://contrails.free.fr/elec_second_alternateur.php Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Aug 02, 2013
And there is this: http://www.flygas.info/en/kit-double-alternator-for-rotax.html Better as a 10A backup than additional power it seems to me. Jan de Jong On 8/2/2013 8:09 PM, Gilles Thesee wrote: > <Gilles.Thesee@ac-grenoble.fr> > > N6ZY a crit : >> >> I am building a Europa with a Rotax 914 engine. It has become clear >> to me that my electrical power needs are unlikely to be met from the >> internal alternator. The alternatives are the Rotax belt driven >> alternator, or the B&C SD20 alternator driven off the vacuum pad. The >> belt driven alternator goes where I would really like my air intake >> hoses to go, so the SD20 looks like an attractive option. However >> when I look at my vacuum pad, it has a blanking plate, so I assume >> that I would have to install the vacuum drive gear shaft. Is this >> correct and can anyone advise me as to how difficult this is? Is it >> something that I can do myself or, as it seems to require opening the >> gearbox, is this a Rotax service center job? Thanks. >> > > Jerry, > > Have you considered this option ? > > http://contrails.free.fr/elec_second_alternateur.php > > Best regards, ________________________________________________________________________________
Date: Aug 02, 2013
Hi! John, Where is your battery situated ? How far from the starter ? I had untold problems with the Jabiru 3300 six cylinder until I put two Odessey 13Ah batteries in parallel within 18" of the starter and used welding cables for the leads. Bingo not so much as a problem since. Regards Bob Harrison G-PTAG Europa now with 914 Rotax. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Elling Sent: 02 August 2013 18:08 Subject: RotaxEngines-List: Trouble starting a 912 ULS --> Folks, One more data point on the trouble starting: It is not the battery current. I've connected a truck battery in parallel with the plane's battery (so the ignition is switching more amps) and not solved the problem. John ________________________________________________________________________________
Date: Aug 03, 2013
Chad: Three things come to mind: 1 - You have a prop/engine balance issue and it shows up at a a particular RPM range. 2 - You have a gear train issue - Someone else can comment on this. 3 - You have a control surface rigging/flutter issue. <-- This is low on my guess factor list. *Barry* On Thu, Aug 1, 2013 at 9:35 PM, SIDESLIP wrote: > > Hello all. I've got a Zodiac 601 XL-B with a Rotax 912ULS and a warp drive > three blade. > > It's set at 15 degrees pitch, giving me 5500 RPM CLIMB OUT, 5200-5300 > static. This engine runs flawlessly on the ground. It has only 175 hours on > the engine. New plugs, carbs synced, oil changed. Fresh fuel lines. All > parameters are well within margins. Climbs and runs like a top, and is > happy at 5500 cruise. The airplane does 100-110kts straight and level at > 5500 rpm. Fuel burn is approximate at 3.5-4.1 gal/hr. > > I fly my pattern at 90kts, with 70-80 on final. > > When I pull the power back gradually to slow it for flaps and turning > base, anything under 4k and it shakes and thuds. Maybe that speed unloads > the prop? I don't know. Like I said, runs like a top on the ground. It's > only running like a bag of hammers in the circuit pulling back under 4k. It > is a slipper clutched plane. > > Any help is appreciated! > > Thanks in advance! > > Chad > > -------- > C-GYXQ. 912ULS. 601XL-B > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405795#405795 > > ________________________________________________________________________________
Date: Aug 03, 2013
Subject: Re: Trouble starting a 912 ULS
John: 1 - What does the gear engagement points look like? If the gears are too new to show ware take some blue Dykem and coat the ring gear teeth and the starter gear teeth. Then try starting. You will have wear marks showing the gear contact - If they are not straight and even from face to face you have an alignment issue. 2 - If the gears are not engaging - Could the mounting system be totally incorrect? Am I to assume at one point and for a long time there were NO starting issues? If so... What changed? 3 - Any hard landings? *Barry* On Fri, Aug 2, 2013 at 12:00 PM, John Elling wrote: > jelling(at)newmexico.com> > > Folks, > > I've gradually had trouble starting a ULS with the 912 Rotax high torque > starter. First it did not like starting when it was cold. Then the sprag > seemed to come disengaged without turning the engine over enough to start. > Finally I started getting a gear-grinding noise. Then eventually the > gears never engaged; just a grinding noise. > > I checked the starter alignment between the two ears for the bolts. > Perhaps a 0.010" difference between the gaps of the two ears and no way to > adjust that I could see since the ears of the starter flange are threaded > as are the bolt holes on the engine. > > I removed the Rotax starter and found the gear surface was a little rough > as was the mating gear teeth inside the engine. Probably from the > grinding... I replaced the starter with a Skytec, aligned as best I could > to exactly the same position as the Rotax starter (off about 0.010" between > the top and bottom ears of the starter flange and the engine surface). The > Skytec starter does exactly the same thing - grinds the gears without > really engaging. > > Anyone have any ideas? Anything I should check before I start taking > apart the engine to get to the starter gears and clutch? > > John > > ________________________________________________________________________________
Date: Aug 03, 2013
Brand new prop. Brand new hub. Brand new extension. Smooth as silk at full throttle. When I mean runs rough below 4000, I mean its only firing on half the cylinders. It's THAT sputtery. Although yesterday I flew it and brought the power back REALLY slowly, and it didn't seem to do it hardly all the way to idle. I let it idle, as I lost altitude, then smoothly smashed it to the firewall. ZERO hesitation and took me from 50kts DIRECTLY to 100kts! Stuffed me in the seat. I was pleasantly shocked. The slipper was checked by a Rotax tech only 20 hours ago. It was good. The throttle cable thing sounds legit to me.... -------- C-GYXQ. 912ULS. 601XL-B Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405847#405847 ________________________________________________________________________________
Date: Aug 03, 2013
ONLY**
It is difficult to play doctor over the internet. You have to be a bit more accurate in your description and what you have already checked. "Smoothly Smashed" is an oxymoron. Either you smoothly advance the throttle or you smashed the throttle. You say "I mean its only firing on half the cylinders. It's THAT sputtery." What jumps into mind is: Condition of Spark Plugs Condition of Spark Plug Wires Mag output Fuel Pump - Fuel Flow Have you checked these issues? And YES, you can have a good spark and running condition at High RPM and lousy at low. *Barry* On Sat, Aug 3, 2013 at 6:48 AM, SIDESLIP wrote: > > Brand new prop. Brand new hub. Brand new extension. Smooth as silk at full > throttle. When I mean runs rough below 4000, I mean its only firing on half > the cylinders. It's THAT sputtery. Although yesterday I flew it and brought > the power back REALLY slowly, and it didn't seem to do it hardly all the > way to idle. I let it idle, as I lost altitude, then smoothly smashed it to > the firewall. ZERO hesitation and took me from 50kts DIRECTLY to 100kts! > Stuffed me in the seat. I was pleasantly shocked. The slipper was checked > by a Rotax tech only 20 hours ago. It was good. > > The throttle cable thing sounds legit to me.... > > -------- > C-GYXQ. 912ULS. 601XL-B > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405847#405847 > > ________________________________________________________________________________
Date: Aug 03, 2013
Jerry, to answer your specific question about opening the ROTAX gearbox to install an alternator on the vacuum pad, I consider it to be the work of a ROTAX specilised mechanic. Nothing really complex, but this is not really easy to open the gearbox if you don't have the right tools and don't know how to do (have followed the ROTAX maintenance course). Concerning adding an extra alternator, I have myself a 914 powered Europa. I added an alternator on the crankshaft based on Jim Butcher informations (see the link from Gilles). That works very well. In fact, you have the following options: - extra alternator of ROTAX is NOK as doesn't fit under the Europa cowling. - 20A B&C on the is a good option but adds weight and you need to open the gearbox. The added weight is fully in the front, that just add on top of your airmaster (I would expect that you use a good constant speed prop with a 914). Also 20A extra could be limited if you have a 2 axis AP, lights, a decent panel and a pitot heater... - 40/60A B&C on the crankshaft is the way to go if you are consuming much power and are not willing to be dependable on the ROTAX/DUCATI. regulator. It is a bit heavy but works very well. Well, if you have your engine already installed, this is not really easy to install the whole setup - the flygas solution that Jan mentioned was also on my short list but I removed it based on cost (around 1000EUR) and the low output power 10-14A. - ROTAX 912is second alternator on the crankshaft. This is a solution similar to the one of flygas but coming directly from ROTAX. The output is about 30A from 2000RPM. Don't know about price (likely not cheap, but ROTAX quality), but that would be my prefered solution if I had to do it again today. You can find more infos in the 912is illustrated part catalog: http://www.flyrotax.com/portaldata/5/dokus/d05447.pdf and the 912is installation manual http://www.flyrotax.com/portaldata/5/dokus/d05455.pdf Hope this helps, Jacques. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405867#405867 ________________________________________________________________________________
Date: Aug 03, 2013
Well, I just reviewed the 912is part catalog and I found out that you need to replace the whole original generator setup of the 914 with a new one from the 912is to get 2 generators and 2 regulators. As this is also where you have the pick-up coils, I would think that it is way more difficult than what I first thought. So it was an interesting but not really feasible as it seems. Jacques. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405870#405870 ________________________________________________________________________________
Date: Aug 03, 2013
Hi Jacques. The 912iS alternator is oil cooled and needs the 912iS engine block, so that option seems definitely out. Jan de Jong ________________________________________________________________________________
Date: Aug 03, 2013
It sounds like you may have lost your sprag clutch that engages the engine with the starter then releases as soon as the engine speeds past the starter rpm. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405877#405877 ________________________________________________________________________________
Date: Aug 03, 2013
91 oct or 100LL should have had no affect on starting alone. Something else had to be involved and masking the issue. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405878#405878 ________________________________________________________________________________
Date: Aug 03, 2013
Carb sync, I hope mag drop is fairly equal and gearbox checked to see if it needed re-shimming? Even with only 175 hrs. if a plane has been around years things like the Bellville washers in the gearbox get crushed and need to be re-shimmed or replaced. I could easily be throttle cables not moving perfectly in sync as you throttle up and down, especially down. Going up should be smooth. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405879#405879 ________________________________________________________________________________
Date: Aug 08, 2013
Subject: Rotax 912 UL alternator drop-out
I have a homebuilt Pipistrel Sinus with a Rotax 912 UL that I flew to Oshkosh and back last week. The panel has a dual Dynon Skyview display with two-axis autopilot, plus radio and transponder. The total electrical load with everything running is 7 to 8 amps. Occasionally it can go to 10 amps if I'm charging cell phone and iPad en route. I'm pretty confident that I have the electrical system wired so that the ammeter is measuring the total electrical load. The alternator dropped out once on the outbound trip, but came back after removing the iPad charging load. The symptom was a voltage drop from 13.8 volts to 12.5 volts. On preflight the voltage may read that high for a minute or so on a freshly-charged battery, but it quickly drops to 12.2 or 12.1 volts. In flight, the voltage would drop to 12.5 volts and stay there for several minutes. I would think that if the alternator had failed, I'd see the voltage drop to the same 12.1 volts that I see on preflight, and keep dropping slowly. I can't see why it would drop to 12.5 volts and stay there, unless the voltage regulator is failing in a way that I'm not familiar with. The alternator dropped out (same symptoms) a few times on the trip back, but by reducing the load to 3 amps (one Skyview display, radio and transponder), it stayed on line except for awhile when it seemed that the mid-day sun shining on the dashboard was adding extra heat behind the panel. That time we brought it back by directing cool air from a fresh air vent forward toward the spot where the voltage regulator is mounted inside the cabin on the back side of the firewall. So the problem seems to be heat-related. Does this make sense? The Rotax alternator is supposed to be rated for 18 amps, and able to handle a steady load of 14 amps easily. Does the Ducati regulator have a thermal self-protect cutout? Do I perhaps have a regulator that is ready to fail completely, or should I just put an avionics cooling fan behind the panel to get the air moving?Any other ideas? Regards, Paul Kuntz ________________________________________________________________________________
Subject: Re: Rotax 912 UL alternator drop-out
Date: Aug 09, 2013
Hey, read this. Regards, Damien Sent from my iPad On Aug 9, 2013, at 12:42 AM, Paul Kuntz wrote: > I have a homebuilt Pipistrel Sinus with a Rotax 912 UL that I flew to Oshk osh and back last week. The panel has a dual Dynon Skyview display with two- axis autopilot, plus radio and transponder. The total electrical load with e verything running is 7 to 8 amps. Occasionally it can go to 10 amps if I'm c harging cell phone and iPad en route. I'm pretty confident that I have the e lectrical system wired so that the ammeter is measuring the total electrical load. > > The alternator dropped out once on the outbound trip, but came back after r emoving the iPad charging load. The symptom was a voltage drop from 13.8 vo lts to 12.5 volts. On preflight the voltage may read that high for a minute or so on a freshly-charged battery, but it quickly drops to 12.2 or 12.1 vo lts. In flight, the voltage would drop to 12.5 volts and stay there for sev eral minutes. I would think that if the alternator had failed, I'd see the v oltage drop to the same 12.1 volts that I see on preflight, and keep droppin g slowly. I can't see why it would drop to 12.5 volts and stay there, unles s the voltage regulator is failing in a way that I'm not familiar with. > > The alternator dropped out (same symptoms) a few times on the trip back, b ut by reducing the load to 3 amps (one Skyview display, radio and transponde r), it stayed on line except for awhile when it seemed that the mid-day sun s hining on the dashboard was adding extra heat behind the panel. That time w e brought it back by directing cool air from a fresh air vent forward toward the spot where the voltage regulator is mounted inside the cabin on the bac k side of the firewall. > > So the problem seems to be heat-related. Does this make sense? The Rotax alternator is supposed to be rated for 18 amps, and able to handle a steady load of 14 amps easily. Does the Ducati regulator have a thermal self-prot ect cutout? Do I perhaps have a regulator that is ready to fail completely, or should I just put an avionics cooling fan behind the panel to get the ai r moving?Any other ideas? > > Regards, > Paul Kuntz > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 09, 2013
Hi Paul: Sounds like you have a gorgeous plane. For a standard and 99.976% of the different types of batteries to charge you MUST keep the charge voltage between 13.8 to 14.2 VDC. Over 14.2 you start to overheat the battery. Under 13.8 the voltage is not there to remove the oxides for the battery plates. One thing you mentioned perked my ears up - Dual axis autopilot... Now, that is probably the highest single current draw in your plane. Were you in A/P? Did you hit and air bumps? When an A/P has to recover from an air pump the instantaneous current draw goes up sharply. The power is or should be drawn from the battery followed by the replenishment by the charging system. Now, from my reading Rotax has the worst charging system next to Banlon sock rubbing on a wool carpet. But, I would check things such as you mentioned - COOLING - It may be easier to install a small air scoop with a hose or fans (caution- fans have their own current draw) to blow air directly onto the ACU. This is done in quite a few planes where forced air is blown directly onto the radio stack. The other thing I would check is wire gauge size. First off it should be 'Teflon' wire and it is always better to go UP in size. IF the alternator output is rated at 18 Amps the wire size should be no smaller than a 10 AWG and I would use 8 AWG. This is one case where bigger is better. And weight for such a short run is not an issue. That takes care of the charging requirements. You will have to address the wire sizes for the other electronic equipment. Keep in mind Teflon wires allow you to use smaller gauge sizes. But, HEAT, forces you to use larger gauge sizes. >From my Rotax readings - I would say Rotax is not supplying the advertized 18 Amps and it is not in a smooth DC waveform output. Power Reduction Sequence: Least needed First - Cell Phone ;-) iPad ;-) LIGHTS A/P Second Comm Radio Second Nav/GPS The only reasion I mention this is because an IPad under charge would be only about 1 Amp for a dead battery. A cell phone under charge - 0.1 Amp (100 mA). The other items sure can have high draw. Another thought - How warm/hot is the firewall? IF the firewall is warm/hot or if there is dead air under the dash, you may benefit by placing the ACU on stanchions or placing it on a heat sink. A TRICK that I did on my plane: I covered the glareshield with black speaker carpet. This created a heat shield for radio stack by creating a low heat transfer barrier, aluminum and thin leatherette passes the sun's rays/heat very easily. It also added some class to the plane. Good luck, *Barry* On Fri, Aug 9, 2013 at 12:42 AM, Paul Kuntz wrote: > I have a homebuilt Pipistrel Sinus with a Rotax 912 UL that I flew to > Oshkosh and back last week. The panel has a dual Dynon Skyview display with > two-axis autopilot, plus radio and transponder. The total electrical load > with everything running is 7 to 8 amps. Occasionally it can go to 10 amps > if I'm charging cell phone and iPad en route. I'm pretty confident that I > have the electrical system wired so that the ammeter is measuring the total > electrical load. > > The alternator dropped out once on the outbound trip, but came back after > removing the iPad charging load. The symptom was a voltage drop from 13.8 > volts to 12.5 volts. On preflight the voltage may read that high for a > minute or so on a freshly-charged battery, but it quickly drops to 12.2 or > 12.1 volts. In flight, the voltage would drop to 12.5 volts and stay there > for several minutes. I would think that if the alternator had failed, I'd > see the voltage drop to the same 12.1 volts that I see on preflight, and > keep dropping slowly. I can't see why it would drop to 12.5 volts and stay > there, unless the voltage regulator is failing in a way that I'm not > familiar with. > > The alternator dropped out (same symptoms) a few times on the trip back, > but by reducing the load to 3 amps (one Skyview display, radio and > transponder), it stayed on line except for awhile when it seemed that the > mid-day sun shining on the dashboard was adding extra heat behind the > panel. That time we brought it back by directing cool air from a fresh air > vent forward toward the spot where the voltage regulator is mounted inside > the cabin on the back side of the firewall. > > So the problem seems to be heat-related. Does this make sense? The Rotax > alternator is supposed to be rated for 18 amps, and able to handle a steady > load of 14 amps easily. Does the Ducati regulator have a thermal > self-protect cutout? Do I perhaps have a regulator that is ready to fail > completely, or should I just put an avionics cooling fan behind the panel > to get the air moving?Any other ideas? > > Regards, > Paul Kuntz > > * > > * > > ________________________________________________________________________________
Date: Aug 09, 2013
Jerry Our 914 Europa has dual GRT EFIS, GRT EIS, GNS430, GMA340 & GTX327. Also AeroLED pos & strobes. 914 so TCU & fuel pumps. Typically we see about 8-10 amps load. The Rotax alt handles this with ease. There is a simple mod for the Ducatti regulator to address it's potential failure but if you make sure it is cool, it works fine at 10 amps. We originally had a B&C 60 amp alt driven off the rear of the engine. There is a photo earlier in this thread. The coupling failed after 250 hours and we decided to try just the Rotax alt. So far another 250 hours and no problems. We did replace the original Whelan lights with AeroLED when we swapped. The Whelans draw a lot of current. I'd suggest try just the Rotax alt. You can always add a B&C pad mount. If you take off the blanking plate you may discover you have a vac pump drive already. If not, it is easy to add, only requires removal of the gearbox. Lockwood shows a retrofit package for $750. You can do it yourself or send out the gearbox. Hope this helps. Jim Butcher N241BW 475 hours and loving it! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406298#406298 ________________________________________________________________________________
Date: Aug 09, 2013
Your system can handle 16 amp continuous load. With this jumping around like this my first pick for the problem is a poor ground. Most of the time on the LSA I work on I find loose grounds. They may be hand tight, but wrench loose. Put a wrench on all your grounds. I have found that this solves 80% of the electrical issues on LSA especially where composite aircraft are concerned. Depending on where you live corrosion can be a factor too. You may want to do a real time amp check too. It is possible you may be pulling a little too much. Also check for a loose wire on a connection. It may be ready to pull out or hanging by a strand. Rotax advertises 20A, but max is 18 intermittent and continuous is 16 amps. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406311#406311 ________________________________________________________________________________
Date: Aug 09, 2013
Hi Jim "There is a simple mod for the Ducatti regulator to address it's potential failure" Can you provide any more information on this mod? Thx. Ron Parigoris ________________________________________________________________________________
Date: Aug 09, 2013
Ron, Supposedly the failure occurs when the regulator gets hot. If you look at a schematic of the regulator, it is a bridge rectifier with two SCR and two diodes. Supposedly, the diodes are poorly mounted from a thermal point of view and that is what fails. The solution is to put two external diodes in parallel with the originals. This can be done by connecting them between the yellow wires and R. I'm away from my data but I found a bridge to do this. A bridge is better than diodes because it provides a mounting surface that is not at R voltage. I have not incorporated this but have the parts and will do this Fall. I can email you the PN of the bridge later if you wish. Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406365#406365 ________________________________________________________________________________
Date: Aug 09, 2013
Hi Jim Yes please E-Mail info. I plan on adding a diode in series with the sense wire to raise the voltage of the regulator. 14.2 to 14.4 is what Odyssey is happy seeing, Ducati is set way low. Ron P. "h&jeuropa" > > > Ron, > > Supposedly the failure occurs when the regulator gets hot. If you look at > a schematic of the regulator, it is a bridge rectifier with two SCR and > two diodes. Supposedly, the diodes are poorly mounted from a thermal > point of view and that is what fails. The solution is to put two external > diodes in parallel with the originals. This can be done by connecting > them between the yellow wires and R. I'm away from my data but I found a > bridge to do this. A bridge is better than diodes because it provides a > mounting surface that is not at R voltage. > > I have not incorporated this but have the parts and will do this Fall. > > I can email you the PN of the bridge later if you wish. > > Jim > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406365#406365 > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 09, 2013
Subject: Rotax part 966726 ignition modules
I recently had a hair-puller-outer problem with a 912 ULS that would not start. Since both carbs leaked fuel out the overflow tubes and they had not been rebuilt ever, I did that. In studying the aircraft's fuel system and studying the Rotax manual I found the fuel system had no return line. Having not crafted a fuel system for a 912 before, and finding the schematic in the IPC clear as mud, I contacted Roger Lee off list for some advice. Like many on this list I've learned a lot from Roger and having him take the time, while on vacation mind you, to give me the part numbers to order is a testimony to his character, but that's an aside to this story. All plumbed up, no joy on getting the engine to fire. Did all the diagnostics and it boiled down to the ignition modules. Fortunately, there is a message on the Rotax.com forum about ignition modules that would not fire below a certain rpm and advised sending them to Lockwood to be tested. Last Monday I called Lockwood, they emailed a work order and I forwarded it to my customer so he could mail them out for testing. In talking to Aaron, he said this was a known problem. Some 966726 modules go south and will not fire until some elevated rpm not reachable with a starter. With their test system Lockwood can spin them up and determine the point where firing begins. They have found that once they do fire, the modules sometimes return to the correct firing rpm for awhile but when allowed to set for a day or two will redevelop the defect. Bottom line of this missive is that if you have a problem with engine starting and you have done all the trouble shooting to make sure that an ignition is not inadvertently grounded out at the switch or the wiring, it may be worth your time to send them to Lockwood for testing. I don't know if L.E.A.F. or CPS can do this test, the fellow who sent the message used Lockwood so I did too. There's an upside to this story. The new modules, p/n 966727 have the capabilities of the 'Soft Start Module" built in. Rotax, aware of the problem with the old moduels has a special price for the new modules, $913, that is less than half the cost of the old modules and if you order them from Lockwood they waive the cost of testing the old modules so you save a further $50, too. Rick Girard It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Aug 11, 2013
Thanks to all who responded to my original post about Rotax alternators. I think that I will try using just the Rotax generator at first. I was put off by the Rotax statement that the fuel pumps etc can take up to 8 amps, but it appears that this is too pessimistic. Jim, your set up sounds very similar to mine. Have you also fitted an autopilot, as these can take quite a bit of power when operating? I would also be interested in the diode mod to the Ducatti regulator. Could you please either post it here, or email it to me? I will probably cover the regulator with a cooling shroud as well. Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406447#406447 ________________________________________________________________________________
From: Kevin Klinefelter <klinefelter.kevin(at)gmail.com>
Date: Aug 11, 2013
Consider mounting the regulator on the passenger footwell front, inside the plenum for the air filter. Should stay nice and cool in there. Kevin On Aug 11, 2013, at 8:37 AM, "N6ZY" wrote: > > Thanks to all who responded to my original post about Rotax alternators. I think that I will try using just the Rotax generator at first. I was put off by the Rotax statement that the fuel pumps etc can take up to 8 amps, but it appears that this is too pessimistic. Jim, your set up sounds very similar to mine. Have you also fitted an autopilot, as these can take quite a bit of power when operating? > > I would also be interested in the diode mod to the Ducatti regulator. Could you please either post it here, or email it to me? I will probably cover the regulator with a cooling shroud as well. > > Jerry > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406447#406447 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 13, 2013
Right you are Roger: And when it comes to "INSPECTION" of electrical connections - Especially Grounds - LQQKing at them is NOT inspecting. You must Remove them, Clean them and Replace the Star Washer. And then if you are really good, Coat them with Dielectric Grease or Paint... This keep moisture from starting the corrosion process all over again. You cannot see the corrosion all the time but, you sure can see the effects. *Barry* On Fri, Aug 9, 2013 at 10:07 AM, Roger Lee wrote: > > Your system can handle 16 amp continuous load. With this jumping around > like this my first pick for the problem is a poor ground. Most of the time > on the LSA I work on I find loose grounds. They may be hand tight, but > wrench loose. Put a wrench on all your grounds. I have found that this > solves 80% of the electrical issues on LSA especially where composite > aircraft are concerned. Depending on where you live corrosion can be a > factor too. You may want to do a real time amp check too. It is possible > you may be pulling a little too much. Also check for a loose wire on a > connection. It may be ready to pull out or hanging by a strand. > > Rotax advertises 20A, but max is 18 intermittent and continuous is 16 amps. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406311#406311 > > ________________________________________________________________________________
Date: Aug 14, 2013
The bridge I selected is a 36MB120A, 35A 1200V bridge. It needs to mount on a heat sink. Wakefield 403K fits nicely. Both available from Newark Electronics. Jerry - I noticed on the GRT website that their two servos are powered from a 2.5 amp supply. I certainly have 2.5A available on my 914 Europa. Jim Butcher N241BW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406692#406692 ________________________________________________________________________________
Date: Aug 14, 2013
Hi Jim Thx. for providing us with the bridge information for 914 regulator: "I selected is a 36MB120A, 35A 1200V bridge. It needs to mount on a heat sink. Wakefield 403K fits nicely. Both available from Newark Electronics." Ron Parigoris ________________________________________________________________________________
Date: Aug 18, 2013
Subject: Rotax Owner videos not working
I haven't been able to view Rotax Owner videos in the last two days. For instance, this one generates a web page with a black window where the video should appear, but then it just sits there: http://www.rotax-owner.com/all-videos/expanded-video-instructions/39-exp-si-27-010 Anyone else having this problem? Paul Kuntz ________________________________________________________________________________
Subject: 912uls cooling
Date: Aug 18, 2013
Hi Guys I have a zenair ch701 which has a 912uls engine..I recently put this aircraft on full lotus floats and it gets off and flies good however it seems that the oil temperature is going higher then normal,,I sometimes see the temperature a 230 and more after take off It has the air scoop for the oil cooler on the passenger side and I widened the scoop for more air The guide says 190 to 230 is the most favourable operating temperatures. I consider it to be high as I usually see temps in the 200 =93210 area..also when I check the oil and follow the test of rotating the propeller and listening for the gurgle in the header tank I do not hear it..I am using the mobile MX 4T racing oil as suggested... what is the oil filter part number and which is the best suggested replacement filter to use..what does the group consider normal temperatures for the 912ULS engine all advice and suggestions would be appreciated Happy flying AJ Rose ________________________________________________________________________________
Date: Aug 18, 2013
Subject: Re: AeroElectric-List: Re: Rotax 912 UL alternator
drop-out
Several inputs suggested checking the connections on the leads coming from the alternator, and checking the system ground connections. I checked the faston-type alternator lead connections, which were clean and tight. I checked all of the ground connections, which were also tight. Yesterday I went up for a test flight and confirmed the symptoms under varying system loads. The normal system voltage with alternator on line is 13.8 volts, which is consistent with what others are reporting for the Rotax Ducati regulator. I see a max load of 10 amps with everything running, so I am satisfied that the total load is well within the standard Rotax system capacity. I also observed that the system voltage drops to 13.5 volts at the 10 amp max load, which seems abnormal. Under this max load, the alternator dropped out after a few minutes, indicated by system voltage dropping to around 12.5 volts -- consistent with fully charged lead-acid battery. When I reduced the load to 3 amps, which is my practical minimum (one Dynon display, radio and transponder), the alternator came back and stayed there, with system voltage at the normal regulator set point of 13.8 volts. I repeated this experiment a few times for various loads, finding that a total load above 5 or 6 amps will cause the alternator to drop out after a few minutes, and that it will come back when the load is reduced to 3 amps. I am pretty well convinced that my voltage regulator is bad. I did learn from comments on this issue that Van's includes a voltage regulator cooling kit with its lighting kit for the RV-12, consisting of a length of plastic tubing that connects from the air intake duct to a shroud over the regulator, providing a direct blast of cooling air to counteract the increased electrical load of the lighting. So there is certainly indication that the Ducati regulator is susceptible to overheating under load. The RV-12 regulator is on the engine side of the firewall, however, and mine is on the cabin side. At 10 amps with the regulator mounted in the cockpit environment, I'm thinking the regulator should be able to handle the load without supplemental cooling. Others have noted the not-so-good reputation of the Ducati regulator, but there are thousands of them in service on Rotax engines worldwide, so rather than tackle a reconfiguration of my regulator and wiring installation at this point , I ordered a replacement Ducati from Lockwood Aviation and will see how it goes. I also ordered a overvoltage protection module from B&C, since the Pipistrel electrical system does not include one. I'll install it with the new voltage regulator. I'll report my findings after installing the new regulator. Paul Kuntz On Sat, Aug 10, 2013 at 10:21 PM, Paul Kuntz wrote: > Thanks for the tips, everyone. I concur with Bob that my Ducati regulator > is done for and should be replaced. I will take a look at the > Schicke unit that Peter mentioned. > > Cheers, > Paul Kuntz > > > On Friday, August 9, 2013, Robert L. Nuckolls, III wrote: > >> --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" < >> nuckolls.bob(at)aeroelectric.com> >> >> At 12:55 PM 8/9/2013, you wrote: >> >>> Thanks for the tip. I'll check this cooling shroud idea. I'm also >>> wondering if my regulator has already been compromised. Any opinions on >>> what my repeated fail/recover situation indicates? I would guess that it >>> cycled between failed and recovered 8 or 10 times before we established a >>> state where it stayed on line, limited to a total current draw of 3 amps. >>> >> >> If your regulator can't carry 10A without cooling, it's >> probably broke. A functional part should be capable of >> rated output for the alternator which is on the order >> of 18A. I've not heard of any mass-movements to forced >> air cool these regulators. >> >> >> >> >> Bob . . . >> >> >> >> >> ________________________________________________________________________________
Subject: Re: 912uls cooling
Date: Aug 18, 2013
SGkgQUosDQpBbmR5IEN1bGx1bSBmcm9tIFVLLg0KSSBvd24gYSBSb3RheCA5MTJ1bHMgRXVyb3Bh IFRyaSBnZWFyIHBvaXNlZCBmb3IgdGVzdCBmbHlpbmchDQpJIHN1Z2dlc3QgeW91IGNvbnRhY3Qg TG9ja3dvb2QgQXZpYXRpb24gaW4gdGhlIHN0YXRlcywoSSdtIGFzc3VtaW5nIHlvdXJlIHN0YXRl c2lkZSEgKWFzIHRoZXkgaGF2ZSBvaWwNCkZpbHRlcnMgZm9yIHRoZSA5MTJ1bHMgaW4gc3RvY2ss dGhleSBhcmUgZ2VudWluZSBSb3RheCBvbmVzLGRvbid0IGJlIHRlbXB0ZWQgdG8gdHJ5IGFuZCBn ZXQgY2hlYXBlciBhdXRvbW90aXZlIG9uZXMsYXMgdGhlIG1vdW50aW5nIHRocmVhZHMgYXJlIHNp bWlsYXIgYnV0IG5vdCB0aGUgc2FtZS4NClRoZXJlIHdhcyBhbiBpbmNpZGVudCBpbiB0aGUgVUsg c29tZXRpbWUgYmFjayB3aGVyZSBhIEV1cm9wYSBoYWQgYmVlbiBmaXR0ZWQgd2l0aCBvbmUgb2Yg dGhlc2UgYXV0b21vdGl2ZSBmaWx0ZXJzLGhlIGxvc3QgYWxsIHRoZSBvaWwsb3ZlciB0aGUgRW5n bGlzaCBDaGFubmVsLGFuZCBtYWRlIGFuIGVtZXJnZW5jeSBsYW5kaW5nIG9uIFNhcmssaGUgd2Fz IG9rLA0KQnV0IHRoZSBhaXJjcmFmdCB3YXMgc2FkbHkgd3JlY2tlZC4NCldoZW4geW91IHRyeSBh bmQgYnVycCB0aGUgZW5naW5lLGhhdmUNCllvdSByZW1vdmVkIHRoZSBmaWxsZXIgY2FwPw0KSWYg eW91IGRvbid0LHlvdSB3b24ndCBoZWFyIHRoZSBndXJnbGUsDQpBbHNvIHBhdXNlIGJldHdlZW4g Y29tcHJlc3Npb25zLGFzIHRoaXMgYWxsb3dzIGFpciB0byBlc2NhcGUuDQpJIGZpbmQgaXQgbm9y bWFsbHkgdGFrZXMgYWJvdXQgMjUtMzAgY29tcHJlc3Npb25zIHRvIGdldCBteSBlbmdpbmUgdG8g Z3VyZ2xlLg0KQmVzdCByZWdhcmRzDQpBbmR5IEN1bGx1bS4NClNlbnQgZnJvbSBteSBpUGhvbmUN Cg0KT24gMTggQXVnIDIwMTMsIGF0IDE2OjI3LCAiQUpSIiA8YWpyb3NlY2FAbmYuc3ltcGF0aWNv LmNhPiB3cm90ZToNCg0KPiBIaSBHdXlzDQo+IEkgaGF2ZSBhIHplbmFpciBjaDcwMSAgd2hpY2gg aGFzIGEgOTEydWxzIGVuZ2luZS4uSSByZWNlbnRseSBwdXQgdGhpcyBhaXJjcmFmdCBvbg0KPiBm dWxsIGxvdHVzIGZsb2F0cyBhbmQgaXQgZ2V0cyBvZmYgYW5kIGZsaWVzIGdvb2QgaG93ZXZlciBp dCBzZWVtcyB0aGF0IHRoZSBvaWwgdGVtcGVyYXR1cmUNCj4gaXMgZ29pbmcgaGlnaGVyIHRoZW4g bm9ybWFsLCxJIHNvbWV0aW1lcyBzZWUgdGhlIHRlbXBlcmF0dXJlIGEgMjMwIGFuZCBtb3JlIGFm dGVyIHRha2Ugb2ZmDQo+IEl0IGhhcyB0aGUgYWlyIHNjb29wIGZvciB0aGUgb2lsIGNvb2xlciBv biB0aGUgcGFzc2VuZ2VyIHNpZGUgYW5kIEkgd2lkZW5lZCB0aGUgc2Nvb3AgZm9yIG1vcmUgYWly DQo+ICAgVGhlIGd1aWRlIHNheXMgMTkwIHRvIDIzMCBpcyB0aGUgbW9zdCBmYXZvdXJhYmxlIG9w ZXJhdGluZyB0ZW1wZXJhdHVyZXMuDQo+IEkgY29uc2lkZXIgaXQgdG8gYmUgaGlnaCBhcyBJIHVz dWFsbHkgc2VlIHRlbXBzIGluIHRoZSAyMDAg4oCTMjEwIGFyZWEuLmFsc28gd2hlbiBJIGNoZWNr IHRoZQ0KPiBvaWwgYW5kIGZvbGxvdyB0aGUgdGVzdCBvZiByb3RhdGluZyB0aGUgcHJvcGVsbGVy IGFuZCBsaXN0ZW5pbmcgZm9yIHRoZSBndXJnbGUgaW4gdGhlIGhlYWRlciB0YW5rDQo+IEkgZG8g bm90IGhlYXIgaXQuLkkgYW0gdXNpbmcgdGhlIG1vYmlsZSBNWCA0VCByYWNpbmcgb2lsIGFzIHN1 Z2dlc3RlZC4uLiB3aGF0IGlzIHRoZSBvaWwgZmlsdGVyDQo+IHBhcnQgbnVtYmVyIGFuZCB3aGlj aCBpcyB0aGUgYmVzdCBzdWdnZXN0ZWQgcmVwbGFjZW1lbnQgZmlsdGVyIHRvIHVzZS4ud2hhdCBk b2VzIHRoZSBncm91cA0KPiBjb25zaWRlciBub3JtYWwgdGVtcGVyYXR1cmVzIGZvciB0aGUgOTEy VUxTIGVuZ2luZQ0KPiBhbGwgYWR2aWNlIGFuZCBzdWdnZXN0aW9ucyB3b3VsZCBiZSBhcHByZWNp YXRlZA0KPiBIYXBweSBmbHlpbmcNCj4gQUogUm9zZQ0KPiANCj4gDQo+IF8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQo+IF8tPSAg ICAgICAgICAtIFRoZSBSb3RheEVuZ2luZXMtTGlzdCBFbWFpbCBGb3J1bSAtDQo+IF8tPSBVc2Ug dGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCj4gXy09IHRo ZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQo+IF8t PSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCj4g Xy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCj4gXy09DQo+IF8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JvdGF4RW5naW5lcy1MaXN0DQo+IF8t PQ0KPiBfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQ0KPiBfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0N Cj4gXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1 bXMhDQo+IF8tPQ0KPiBfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQo+IF8t PQ0KPiBfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQ0KPiBfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0 ZSAtDQo+IF8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQo+IF8tPSAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCj4g Xy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj4gXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cj4gDQo ________________________________________________________________________________
Date: Aug 18, 2013
SGkgQUosDQpBbmR5IEN1bGx1bSBmcm9tIFVLLg0KSSBvd24gYSBSb3RheCA5MTJ1bHMgRXVyb3Bh IFRyaSBnZWFyIHBvaXNlZCBmb3IgdGVzdCBmbHlpbmchDQpJIHN1Z2dlc3QgeW91IGNvbnRhY3Qg TG9ja3dvb2QgQXZpYXRpb24gaW4gdGhlIHN0YXRlcyBhcyB0aGV5IGhhdmUgb2lsDQpGaWx0ZXJz IGZvciB0aGUgOTEydWxzIGluIHN0b2NrLHRoZXkgYXJlIGdlbnVpbmUgUm90YXggb25lcyxkb24n dCBiZSB0ZW1wdGVkIHRvIHRyeSBhbmQgZ2V0IGNoZWFwZXIgYXV0b21vdGl2ZSBvbmVzLGFzIHRo ZSBtb3VudGluZyB0aHJlYWRzIGFyZSBzaW1pbGFyIGJ1dCBub3QgdGhlIHNhbWUuDQpUaGVyZSB3 YXMgYW4gaW5jaWRlbnQgaW4gdGhlIFVLIHNvbWV0aW1lIGJhY2sgd2hlcmUgYSBFdXJvcGEgaGFk IGJlZW4gZml0dGVkIHdpdGggb25lIG9mIHRoZXNlIGF1dG9tb3RpdmUgZmlsdGVycyxoZSBsb3N0 IGFsbCB0aGUgb2lsLG92ZXIgdGhlIEVuZ2xpc2ggQ2hhbm5lbCxhbmQgbWFkZSBhbiBlbWVyZ2Vu Y3kgbGFuZGluZyBvbiBTYXJrLGhlIHdhcyBvaywNCkJ1dCB0aGUgYWlyY3JhZnQgd2FzIHNhZGx5 IHdyZWNrZWQuDQoNClNlbnQgZnJvbSBteSBpUGhvbmUNCg0KT24gMTggQXVnIDIwMTMsIGF0IDE2 OjI3LCAiQUpSIiA8YWpyb3NlY2FAbmYuc3ltcGF0aWNvLmNhPiB3cm90ZToNCg0KPiBIaSBHdXlz DQo+IEkgaGF2ZSBhIHplbmFpciBjaDcwMSAgd2hpY2ggaGFzIGEgOTEydWxzIGVuZ2luZS4uSSBy ZWNlbnRseSBwdXQgdGhpcyBhaXJjcmFmdCBvbg0KPiBmdWxsIGxvdHVzIGZsb2F0cyBhbmQgaXQg Z2V0cyBvZmYgYW5kIGZsaWVzIGdvb2QgaG93ZXZlciBpdCBzZWVtcyB0aGF0IHRoZSBvaWwgdGVt cGVyYXR1cmUNCj4gaXMgZ29pbmcgaGlnaGVyIHRoZW4gbm9ybWFsLCxJIHNvbWV0aW1lcyBzZWUg dGhlIHRlbXBlcmF0dXJlIGEgMjMwIGFuZCBtb3JlIGFmdGVyIHRha2Ugb2ZmDQo+IEl0IGhhcyB0 aGUgYWlyIHNjb29wIGZvciB0aGUgb2lsIGNvb2xlciBvbiB0aGUgcGFzc2VuZ2VyIHNpZGUgYW5k IEkgd2lkZW5lZCB0aGUgc2Nvb3AgZm9yIG1vcmUgYWlyDQo+ICAgVGhlIGd1aWRlIHNheXMgMTkw IHRvIDIzMCBpcyB0aGUgbW9zdCBmYXZvdXJhYmxlIG9wZXJhdGluZyB0ZW1wZXJhdHVyZXMuDQo+ IEkgY29uc2lkZXIgaXQgdG8gYmUgaGlnaCBhcyBJIHVzdWFsbHkgc2VlIHRlbXBzIGluIHRoZSAy MDAg4oCTMjEwIGFyZWEuLmFsc28gd2hlbiBJIGNoZWNrIHRoZQ0KPiBvaWwgYW5kIGZvbGxvdyB0 aGUgdGVzdCBvZiByb3RhdGluZyB0aGUgcHJvcGVsbGVyIGFuZCBsaXN0ZW5pbmcgZm9yIHRoZSBn dXJnbGUgaW4gdGhlIGhlYWRlciB0YW5rDQo+IEkgZG8gbm90IGhlYXIgaXQuLkkgYW0gdXNpbmcg dGhlIG1vYmlsZSBNWCA0VCByYWNpbmcgb2lsIGFzIHN1Z2dlc3RlZC4uLiB3aGF0IGlzIHRoZSBv aWwgZmlsdGVyDQo+IHBhcnQgbnVtYmVyIGFuZCB3aGljaCBpcyB0aGUgYmVzdCBzdWdnZXN0ZWQg cmVwbGFjZW1lbnQgZmlsdGVyIHRvIHVzZS4ud2hhdCBkb2VzIHRoZSBncm91cA0KPiBjb25zaWRl ciBub3JtYWwgdGVtcGVyYXR1cmVzIGZvciB0aGUgOTEyVUxTIGVuZ2luZQ0KPiBhbGwgYWR2aWNl IGFuZCBzdWdnZXN0aW9ucyB3b3VsZCBiZSBhcHByZWNpYXRlZA0KPiBIYXBweSBmbHlpbmcNCj4g QUogUm9zZQ0KPiANCj4gDQo+IF8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09DQo+IF8tPSAgICAgICAgICAtIFRoZSBSb3RheEVuZ2lu ZXMtTGlzdCBFbWFpbCBGb3J1bSAtDQo+IF8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1 cmVzIE5hdmlnYXRvciB0byBicm93c2UNCj4gXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1 Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQo+IF8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25s b2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCj4gXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNo IG11Y2ggbW9yZToNCj4gXy09DQo+IF8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v TmF2aWdhdG9yP1JvdGF4RW5naW5lcy1MaXN0DQo+IF8tPQ0KPiBfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPiBfLT0gICAgICAg ICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCj4gXy09IFNhbWUgZ3JlYXQgY29udGVu dCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQo+IF8tPQ0KPiBfLT0gICAtLT4g aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQo+IF8tPQ0KPiBfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPiBfLT0gICAgICAg ICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQo+IF8tPSAgVGhhbmsgeW91IGZv ciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQo+IF8tPSAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCj4gXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gDQo ________________________________________________________________________________
Date: Aug 18, 2013
Here's another thought. I have a similar issue in my 912s, at manifold pressures from 22 down to 18 inHg, the engine gets rough. If I advance the prop to more FINE, the rough range narrows. This would speak for overloading the engine or lugging, not under loading as initially suggested. Over the years I've have several conversations with Phil Lockwood, Dean Vogel, Bud Yearly and others. The most likely, but still unproven in my case, is Bud's thought that in-flight one of the carb slides sticks. Bud has seen a carb replacement cure the issue. I may try it myself when I fly down to Sebring for my ten year maintenance. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406972#406972 ________________________________________________________________________________
Subject: Re: Rotax Owner videos not working
Date: Aug 18, 2013
Paul, First chance to test and, sure enough, just a black screen where the video is supposed to be. There's a "Contact Us" at the bottom of the page. I suggest you send them a note as I just did. Bob Borger, Europa XS Tri, Rotax 914, Airmaster C/S prop. On Aug 18, 2013, at 9:48 AM, Paul Kuntz wrote: > I haven't been able to view Rotax Owner videos in the last two days. For instance, this one generates a web page with a black window where the video should appear, but then it just sits there: http://www.rotax-owner.com/all-videos/expanded-video-instructions/39-exp-s i-27-010 > > Anyone else having this problem? > > Paul Kuntz ________________________________________________________________________________
Date: Aug 18, 2013
Thanks for the confirmation, Bob. I did send them a note. Paul On Sun, Aug 18, 2013 at 11:08 AM, Robert Borger wrote: > Paul, > > First chance to test and, sure enough, just a black screen where the video > is supposed to be. > > There's a "Contact Us" at the bottom of the page. I suggest you send them > a note as I just did. > > Bob Borger, > Europa XS Tri, Rotax 914, Airmaster C/S prop. > > On Aug 18, 2013, at 9:48 AM, Paul Kuntz wrote: > > I haven't been able to view Rotax Owner videos in the last two days. For > instance, this one generates a web page with a black window where the video > should appear, but then it just sits there: > http://www.rotax-owner.com/all-videos/expanded-video-instructions/39-exp-si-27-010 > > Anyone else having this problem? > > Paul Kuntz > > * > > * > > ________________________________________________________________________________
Subject: Pausing on Compression.
Date: Aug 18, 2013
Hi AJ, Sorry I must have mis-read some script. Pausing on compressions just makes it Easier,when all the oil has been pumped out of the crankcase up to the tank,the gurgle is heard,with air now being drawn through. Best regards Andy Cullum. Sent from my iPhone ________________________________________________________________________________
Date: Aug 18, 2013
It will most likely get fixed tomorrow. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407002#407002 ________________________________________________________________________________
Date: Aug 18, 2013
Since you just put your plane on floats make sure your prop pitch is setup for the extra drag. You may want to set your prop pitch to achieve at least 5600 -5800 rpm at WOT flat and level. Adding the drag will automatically increase the oil temp. No big deal as 230F isn't an issue. If you fly in the Southwest US 230F is an everyday norm during the hot months. Up to 240F doesn't bother me, but mine seems to be good at around 230F - 235F in climb and around 220F for cruise (OAT 95-100F). My prop can achieve 5600-5650 rpm WOT flat and level. Use the correct oil filter. Rotax Part #825-012. Many years ago the difference from an automotive filter to a Rotax was negligible, but not when they came out with the latest oil filter. The automotive filter by pass pressure is only 12-15 psi and years ago the Rotax was 13-16 psi. Now days the Rotax by pass pressure is 18-22 psi, the filter has a check valve in it not found in an automotive filter and a much softer better designed anti drain back membrane. It still has a paper element, but there are now significant difference so stay with Rotax. Of course there are those that say I have had an automotive filter on for a while. This is like smoking cigarettes. One cigarette or even one pack won't kill you or cause a disease, but a life time is deadly and causes debilitating diseases. You own an expensive engine and an expensive one to repair treat it right and don't cause yourself any avoidable long term headaches and wallet strains. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407004#407004 ________________________________________________________________________________
Date: Aug 19, 2013
drop-out
Good report Paul. A practical approach has prevailed. Now since you know 10 Amps will overload the system and 5 to 6 Amps is borderline for an overload. The next thing to do is COOL the unit and apply 5 to 6 Amps and see if it stays online. If it stays online you now know cooling is required. Barry On Sun, Aug 18, 2013 at 11:57 AM, Paul Kuntz wrote: > Several inputs suggested checking the connections on the leads coming from > the alternator, and checking the system ground connections. I checked the > faston-type alternator lead connections, which were clean and tight. I > checked all of the ground connections, which were also tight. Yesterday I > went up for a test flight and confirmed the symptoms under varying system > loads. The normal system voltage with alternator on line is 13.8 volts, > which is consistent with what others are reporting for the Rotax Ducati > regulator. I see a max load of 10 amps with everything running, so I am > satisfied that the total load is well within the standard Rotax system > capacity. I also observed that the system voltage drops to 13.5 volts at > the 10 amp max load, which seems abnormal. Under this max load, the > alternator dropped out after a few minutes, indicated by system voltage > dropping to around 12.5 volts -- consistent with fully charged lead-acid > battery. > > When I reduced the load to 3 amps, which is my practical minimum (one > Dynon display, radio and transponder), the alternator came back and stayed > there, with system voltage at the normal regulator set point of 13.8 > volts. > > I repeated this experiment a few times for various loads, finding that a > total load above 5 or 6 amps will cause the alternator to drop out after a > few minutes, and that it will come back when the load is reduced to 3 > amps. > > I am pretty well convinced that my voltage regulator is bad. I did learn > from comments on this issue that Van's includes a voltage regulator cooling > kit with its lighting kit for the RV-12, consisting of a length of plastic > tubing that connects from the air intake duct to a shroud over the > regulator, providing a direct blast of cooling air to counteract the > increased electrical load of the lighting. So there is certainly > indication that the Ducati regulator is susceptible to overheating under > load. The RV-12 regulator is on the engine side of the firewall, however, > and mine is on the cabin side. At 10 amps with the regulator mounted in > the cockpit environment, I'm thinking the regulator should be able to > handle the load without supplemental cooling. Others have noted the > not-so-good reputation of the Ducati regulator, but there are thousands of > them in service on Rotax engines worldwide, so rather than tackle a > reconfiguration of my regulator and wiring installation at this point , I > ordered a replacement Ducati from Lockwood Aviation and will see how it > goes. I also ordered a overvoltage protection module from B&C, since the > Pipistrel electrical system does not include one. I'll install it with the > new voltage regulator. > > I'll report my findings after installing the new regulator. > > Paul Kuntz > > > On Sat, Aug 10, 2013 at 10:21 PM, Paul Kuntz wrote: > >> Thanks for the tips, everyone. I concur with Bob that my Ducati >> regulator is done for and should be replaced. I will take a look at the >> Schicke unit that Peter mentioned. >> >> Cheers, >> Paul Kuntz >> >> >> On Friday, August 9, 2013, Robert L. Nuckolls, III wrote: >> >>> --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" < >>> nuckolls.bob(at)aeroelectric.com> >>> >>> At 12:55 PM 8/9/2013, you wrote: >>> >>>> Thanks for the tip. I'll check this cooling shroud idea. I'm also >>>> wondering if my regulator has already been compromised. Any opinions on >>>> what my repeated fail/recover situation indicates? I would guess that it >>>> cycled between failed and recovered 8 or 10 times before we established a >>>> state where it stayed on line, limited to a total current draw of 3 amps. >>>> >>> >>> If your regulator can't carry 10A without cooling, it's >>> probably broke. A functional part should be capable of >>> rated output for the alternator which is on the order >>> of 18A. I've not heard of any mass-movements to forced >>> air cool these regulators. >>> >>> >>> >>> >>> Bob . . . >>> >>> ====**==============================**= >>> -List" target="_blank">http://www.matronics.com/** >>> Navigator?AeroElectric-List >>> ====**==============================**= >>> http://forums.matronics.com >>> ====**==============================**= >>> le, List Admin. >>> ="_blank">http://www.matronics.com/**contribution >>> ====**==============================**= >>> >>> >>> >>> > * > > * > > ________________________________________________________________________________
Subject: Best way to ship a Rotax 503.
Date: Aug 22, 2013
What is the best way to package a Rotax 503 for shipping? I'm sending engine, gearbox and carbs. The guy who is overhauling it recommended a 30 x 17 x 17" 350 lb. Double Wall Corrugated Box with plywood and 2x4's on the bottom with the engine bolted to the 2x4's and then cushion with styrofoam sheeting. The box is rated to hold 150lbs and the sides are rated to take 350lbs of sidewall pressure. Others have said build a crate. If you recommend building a crate can you offer any design advice? Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407255#407255 ________________________________________________________________________________
Date: Aug 22, 2013
Subject: Re: Best way to ship a Rotax 503.
Mike, I've shipped two engines pretty much as you describe except I made a base of plywood with a 2 X 2 frame to which the engine was bolted, then put the box over the top and screwed it to the base. Both times the box was ripped off by the shippers. If I were you I'd ship it in a wooden crate. It won't weigh that much more and that's about the minimum that has a chance against an idiot with a fork lift. Rick Girard On Thu, Aug 22, 2013 at 3:09 PM, mike91911 wrote: > > What is the best way to package a Rotax 503 for shipping? I'm sending > engine, gearbox and carbs. The guy who is overhauling it recommended a 30 x > 17 x 17" 350 lb. Double Wall Corrugated Box with plywood and 2x4's on the > bottom with the engine bolted to the 2x4's and then cushion with styrofoam > sheeting. The box is rated to hold 150lbs and the sides are rated to take > 350lbs of sidewall pressure. Others have said build a crate. If you > recommend building a crate can you offer any design advice? > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407255#407255 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Aug 22, 2013
In a message dated 8/22/2013 4:19:19 P.M. Eastern Daylight Time, aslsa.rng(at)gmail.com writes: It won't weigh that much more and that's about the minimum that has a chance against an idiot with a fork lift. Hey, I trucked for a living a few months when I made the Big Mistake of getting out of commercial aviation. You're correct, there's plenty of idiots in the trucking and fork lift fields of employment. I once saw a man & wife trucking team with asses so wide they overlapped an eight foot bench! True story! ________________________________________________________________________________
Date: Aug 22, 2013
I shipped my 582 in a plastic Tupperware "crate" I bought at K-mart. Plywood base with 2" styrofoam under, 2" styrofoam insulation from Home Depot cut to fit tight so if the box turned over the plywood base would rest on it, and lots of duct tape. I also did the corrugated box successfully the same way: standard corrugated box doubled up with some extra cardboard, raised plywood base, (2" styro under,) 2" styro box over it with shaped support well taped together, lots of fiberglass packing tape and duct tape. I also "made" lots of handles so the morons wouldn't be tempted to forklift. (Cut holes in the box and reinforce them with fiberglass tape.) The main thing is to shape the styro supports so the engine is safe resting in any position. Of course you'll mark it "This end up" anyway, but we know how that works. (Digression: I flew to Belize once for a bike trip. We boxed our bikes, but didn't do it too carefully, figuring "what could happen?" Well, when we got to Belize City we stood waiting in the customs line out on the tarmac outside a small building and watched in horror as they unloaded the plane by pushing the baggage out the baggage door of the 767 and letting it drop to the ground. I estimate the drop at about 8-10'. Fortunately the bikes survived.) Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. ________________________________________________________________________________
Date: Aug 22, 2013
I have shipped two 503's from Washington to AZ. I built a create out of OSB with 2x2 skids on the bottom and also used 2x2 stock to frame the inside of the box. Both boxes worked great and the engines were returned in the same boxes I built. On one of them I made rope lifting handles and the second one I just cut holes. I cut 1x2 stock and drilled holes in them to except the mounting studs on the bottom of the engine then screwed them to the bottom of the box when I had the engine in a position I liked it. I used board foam to cushion the engine sides and egg foam on the top before securing the box lid on. It may sound like overkill but I didn't want anything to happen to my engine. I didn't have an issue with either of them shipping. Hope this helps. I have seen engines shipped in less and do fine also. Vance. On Aug 22, 2013 1:14 PM, "mike91911" wrote: > > What is the best way to package a Rotax 503 for shipping? I'm sending > engine, gearbox and carbs. The guy who is overhauling it recommended a 30 x > 17 x 17" 350 lb. Double Wall Corrugated Box with plywood and 2x4's on the > bottom with the engine bolted to the 2x4's and then cushion with styrofoam > sheeting. The box is rated to hold 150lbs and the sides are rated to take > 350lbs of sidewall pressure. Others have said build a crate. If you > recommend building a crate can you offer any design advice? > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407255#407255 > > ________________________________________________________________________________
Subject: Running 582 Engines LOP
Date: Aug 26, 2013
I have a Rotax 582 with a warp comp prop in a Pulsar. The engine has the oil injection system fitted. Because of the slippery Pulsar profile (5000rpm and 90 knots at 12 litres/hour) EGTs tend to nudge the maximum limit when in fast cruise descent - because of the low load on the fast revving engine. I prefer the keep the engine away from red line limits, and can reduce EGTs by either throttling back even further so the engine is developing minimal power, or by slowing the plane down and applying flaps to make the plane more draggy. Neither of these options is ideal, and I wondered if it is possible to safely reduce EGTs (at cruise power) by running the 582 engine lean of peak (LOP) eg by using a hacman type device to weaken the mixture. The normal cruise mix seems fine (plugs noses mid to deep brown) so I don't want to raise the carb needle and richen this setting. Any thoughts/experience on running a 582 injected engine LOP appreciated - good and bad. Thanks Bob P -------- BobP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407485#407485 ________________________________________________________________________________
Date: Aug 26, 2013
Subject: Re: Running 582 Engines LOP
On 8/26/2013 4:37 AM, BobP wrote: > Neither of these options is ideal, and I wondered if it is possible to safely reduce EGTs (at cruise power) by running the 582 engine lean of peak (LOP) eg by using a hacman type device to weaken the mixture. The normal cruise mix seems fine (plugs noses mid to deep brown) so I don't want to raise the carb needle and richen this setting. > Well. As far as I know there's no such thing as LOP for a 582. Or if there is, the peak is well beyond what the engine will handle. So you always live rich of peak, but constantly bump up against it, since the EGT limit gives you best power and fuel economy. (That said, I have run too lean by long descent with a lean mixture through "peak" until the engine quit. The engine was at idle, however, so I never noticed an EGT "peak".) Your idea of using a Hacman for EGT control is a good one, though. I used one all the time I had my 582 (4 years, 500 hours) and loved it. I only had to change mains a couple of times, in Utah and Idaho, when I was spending a lot of time at altitude and wanted to "re-center" my mixture control. (My home port was at 1500'.) The Hacman gave me about 80F EGT range, which seems small, but is quite useful. What Hacman will /not /do is give you enough control to go downhill any way you want. If your mains are set correctly you'll /always /be able to redline the EGT going down hill. You just have to get used to either very long or very short or stepped descents. (There was another system on the market which screwed the mid-range needles in and out that might have given more control. Don't know what happened to it.) I highly recommend the Hacman. (Easy to install, too.) Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. ________________________________________________________________________________
Date: Aug 27, 2013
Subject: Re: RotaxEngines-List Digest: 2 Msgs - 08/26/13
Bob,=0A=0A2 strokes run on a very fine line between "just right" and "too l ean". When the mixture gets too lean the cylinder is subject to pre-ignitio n. This is disastrous. If you need proof I can post a photo of a 582 piston with a .5 in hole in the center of the piston crown.=0A=0A=0A-=0ASTAN 2 =0AN29TD=0A=0A=0A=0A________________________________=0A From: RotaxEngines- List Digest Server =0ATo: RotaxEngines-Lis t Digest List =0ASent: Tuesday, Au gust 27, 2013 2:00 AM=0ASubject: RotaxEngines-List Digest: 2 Msgs - 08/26/1 3=0A =0A=0A*=0A=0A=================== =======0A- Online Versions of Today's List Digest Archive=0A =0A=0AToday's complete RotaxEngines-List Digest can also be found in either of the =0Atwo Web Links listed below.- The .html file includes the Diges t formatted =0Ain HTML for viewing with a web browser and features Hyperlin ked Indexes =0Aand Message Navigation.- The .txt file includes the plain ASCII version =0Aof the RotaxEngines-List Digest and can be viewed with a g eneric text editor =0Asuch as Notepad or with a web browser. =0A=0AHTML Ver sion:=0A=0A- - http://www.matronics.com/digest/digestview.php?Style=8 2701&View=html&Chapter 13-08-26&Archive=RotaxEngines=0A=0AText Vers ion:=0A=0A- - http://www.matronics.com/digest/digestview.php?Style=82 701&View=txt&Chapter 13-08-26&Archive=RotaxEngines=0A=0A=0A== ======================0A- EMai l Version of Today's List Digest Archive=0A========== ==============0A=0A=0A- - - - - ------ ----------------------------------------------------=0A- - - - - - - - - - - - - RotaxEngines-List Digest Archive=0A- - - - - - - - - - - - - - - - - - - ---=0A - - - - - - - - - - Total Messages Posted Mon 08/26/13 : 2=0A- - - - - ------------------------------------------------ ----------=0A=0A=0AToday's Message Index:=0A----------------------=0A=0A- - 1. 04:39 AM - Running 582 Engines LOP- (BobP)=0A- - 2. 07:52 A M - Re: Running 582 Engines LOP- (Guy Buchanan)=0A=0A=0A=0A______________ __________________- Message 1- _____________________________________=0A gines LOP=0AFrom: "BobP" <matronics(at)panth.co.uk>=0A=0A=0AI have a Rotax 582 with a warp comp prop in a Pulsar. The engine has the oil injection=0Asyst em fitted.=0A=0ABecause of the slippery Pulsar profile- (5000rpm and 90 k nots at 12 litres/hour)=0AEGTs tend to nudge the maximum limit- when in f ast cruise descent - because=0Aof the low load on the fast revving engine. I prefer the keep the engine away=0Afrom red line limits, and can reduce EG Ts by either throttling back even further=0Aso the engine is developing min imal power, or by slowing the plane down and=0Aapplying flaps to make the p lane more draggy. =0A=0ANeither of these options is ideal, and I wondered i f it is possible to safely reduce=0AEGTs (at cruise power) by running the 5 82 engine- lean of peak (LOP) eg=0Aby using a hacman type device to weake n the mixture. The normal cruise mix seems=0Afine (plugs noses mid to deep brown) so I don't want to raise the carb needle=0Aand richen this setting. =0A=0AAny thoughts/experience on running a 582 injected engine LOP apprecia ted - good=0Aand bad.=0A=0AThanks=0A=0ABob P=0A=0A--------=0ABobP=0A=0A=0AR ead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php? p=407485#407485=0A=0A=0A________________________________- Message 2- om: Guy Buchanan =0ASubject: Re: RotaxEngines-List: Run ning 582 Engines LOP=0A=0AOn 8/26/2013 4:37 AM, BobP wrote:=0A> Neither of these options is ideal, and I wondered if it is possible to safely=0Areduce EGTs (at cruise power) by running the 582 engine- lean of peak (LOP) eg =0Aby using a hacman type device to weaken the mixture. The normal cruise m ix seems=0Afine (plugs noses mid to deep brown) so I don't want to raise th e carb needle=0Aand richen this setting.=0A>- - =0A- - Well. As fa r as I know there's no such thing as LOP for a 582. Or =0Aif there is, the peak is well beyond what the engine will handle. So you =0Aalways live rich of peak, but constantly bump up against it, since the =0AEGT limit gives y ou best power and fuel economy. (That said, I have run =0Atoo lean by long descent with a lean mixture through "peak" until the =0Aengine quit. The en gine was at idle, however, so I never noticed an EGT =0A"peak".)=0A- - Your idea of using a Hacman for EGT control is a good one, though. =0AI us ed one all the time I had my 582 (4 years, 500 hours) and loved it. =0AI on ly had to change mains a couple of times, in Utah and Idaho, when I =0Awas spending a lot of time at altitude and wanted to "re-center" my =0Amixture control. (My home port was at 1500'.) The Hacman gave me about =0A80F EGT r ange, which seems small, but is quite useful. What Hacman will =0A/not /do is give you enough control to go downhill any way you want. If =0Ayour main s are set correctly you'll /always /be able to redline the EGT =0Agoing dow n hill. You just have to get used to either very long or very =0Ashort or s tepped descents. (There was another system on the market which =0Ascrewed t he mid-range needles in and out that might have given more =0Acontrol. Don' t know what happened to it.) I highly recommend the Hacman. =0A(Easy to ins tall, too.)=0A=0AGuy Buchanan=0ARamona, CA=0AKitfox IV-1200 / 912-S / Warp ================= ________________________________________________________________________________
From: "Joe & Jan Connell" <jconnell(at)fmwildblue.com>
Date: Aug 27, 2013
I=99ve been doing a bit of reflecting about running Lean of Peak (LOP) on Rotax 2-cycle engines. Four-cycle engines have have an oil pump to distribute oil for lubrication. In the two-cycle engine, it is the air/oil mixture that provides the cylinder-to-piston lubrication. It would seem somewhat risky to get excessively lean as this might lead to seized pistons. Can someone qualify this issue a little more fully for me? Thanks... Joe Connell Subject: RotaxEngines-List: Running 582 Engines LOP From: "BobP" <matronics(at)panth.co.uk> I have a Rotax 582 with a warp comp prop in a Pulsar. The engine has the oil injection system fitted. Because of the slippery Pulsar profile (5000rpm and 90 knots at 12 litres/hour) EGTs tend to nudge the maximum limit when in fast cruise descent - because of the low load on the fast revving engine. I prefer the keep the engine away from red line limits, and can reduce EGTs by either throttling back even further so the engine is developing minimal power, or by slowing the plane down and applying flaps to make the plane more draggy. Neither of these options is ideal, and I wondered if it is possible to safely reduce EGTs (at cruise power) by running the 582 engine lean of peak (LOP) eg by using a hacman type device to weaken the mixture. The normal cruise mix seems fine (plugs noses mid to deep brown) so I don't want to raise the carb needle and richen this setting. Any thoughts/experience on running a 582 injected engine LOP appreciated - good and bad. Thanks Bob P -------- BobP ________________________________________________________________________________
Date: Aug 27, 2013
In a 2-cycle there's no cooling cycle and no oil bath on the back side of the piston so max EGT's are much lower. (1250F versus 1600F) If you seriously exceed the EGT limit on a 2-cycle you generally melt a hole in the top of the piston which reduces your compression somewhat. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 8/27/2013 10:28 AM, Joe & Jan Connell wrote: > Four-cycle engines have have an oil pump to distribute oil for > lubrication. In the two-cycle engine, it is the air/oil mixture that > provides the cylinder-to-piston lubrication. It would seem somewhat > risky to get excessively lean as this might lead to seized pistons. > Can someone qualify this issue a little more fully for me? ________________________________________________________________________________
Date: Aug 27, 2013
Just wanted to check with the group before I begin my carb rebuilds. I hav e a 912uls on a Zodiac 601XLB that has started to be hard starting =2C in f act it will not start now unless I spray starting fluid into the air intake . Only did it once to convince myself it was a fuel issue. the engine star ted and would restart after an hour. However=2C if I leave the plane for a week or so it will not start. The engine acts like it is not getting fuel. I've pulled the carb bowls and all looks fine. Fuel in bowl and fuel is about 1/2 inch from top. Engine has 450 hours without a carb rebuild. A ny other ideas what it could be? All input appreciated ThanksGeorge ________________________________________________________________________________
Subject: 912uls hard starting
Date: Aug 27, 2013
Sorry about the confusion in the title From: gfmjr_20(at)hotmail.com Subject: RE: RotaxEngines-List: Running 582 Engines LOP Date: Tue=2C 27 Aug 2013 17:19:08 -0400 =0A =0A =0A Just wanted to check with the group before I begin my carb rebuilds. I hav e a 912uls on a Zodiac 601XLB that has started to be hard starting =2C in f act it will not start now unless I spray starting fluid into the air intake . Only did it once to convince myself it was a fuel issue. the engine star ted and would restart after an hour. However=2C if I leave the plane for a week or so it will not start. The engine acts like it is not getting fuel. I've pulled the carb bowls and all looks fine. Fuel in bowl and fuel is about 1/2 inch from top. Engine has 450 hours without a carb rebuild. A ny other ideas what it could be? All input appreciated ThanksGeorge =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Subject: Re: 912uls hard starting
Date: Aug 27, 2013
1/2" below the rim of the carb bowl is way too low. Double check the float arm height above the carb rim. It should be 10.5mm. The carbs have to be off and upside down to check this. 450 hours is nothing, but how old are they? -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407619#407619 ________________________________________________________________________________
Date: Aug 29, 2013
Here is one last ignition module check. Place an ice bag on top and or around the ignition modules for 15-20 minutes and try a start. If it starts right up buy new modules. Yours are defective. Not kidding about the ice. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407697#407697 ________________________________________________________________________________
Subject: 582 compression
Date: Aug 31, 2013
My 582 greyhead is showing 80 psi compression on both cyl according to my new compression guage. I think the recommended psi is 100. The engine runs well and is strong. Any suggestions on where else I need to check to see if there are problems. Thanks EG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407826#407826 ________________________________________________________________________________
Date: Sep 01, 2013
Subject: Re: 582 compression
None, fly and have fun. I had both the 503 and the 582 with well over 1,000 hours each with no problems other than de-carboning & plug changes at about 150 hours. Used Pennzoil air-cooled oil. The 300 hour recommended overhaul is B.S. Started with Cuyunas in '80 then went with Rotax in about '85 or whenever they first came out. Great motor...the Rotax I mean. In a message dated 8/31/2013 9:39:54 P.M. Eastern Daylight Time, egp8111(at)aol.com writes: --> RotaxEngines-List message posted by: "egp8111" My 582 greyhead is showing 80 psi compression on both cyl according to my new compression guage. I think the recommended psi is 100. The engine runs well and is strong. Any suggestions on where else I need to check to see if there are problems. Thanks EG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407826#407826 ________________________________________________________________________________
Date: Sep 07, 2013
Subject: Re: RotaxEngines-List Digest: 3 Msgs - 07/09/13
It took awhile to track down what was causing the large mag drops. For the sake of accuracy i should refer to them as ignition modules not mags. Just after I last wrote the Dynon Skyview display failed and needed to be returned to Dynon for repair. A number of other things happened, to me and not the plane, at the same time causing further delays. The ignition wires were connected to the correct cylinders, according to the wiring labels and the cylinder markings. BUT the cylinders were mis-marked on the left hand side! (I take the "fifth" on who did the marking! ) Correcting that cleared up the the large RPM drop and all appears to be normal although it still looks like it is running rich based on the plugs and the exhaust pipe. After more than 60 years around auto engines I am surprised that a four cylinder engine will run at all with two plug wires reversed. Thanks for all of the suggestions. Henry On Wed, Jul 10, 2013 at 1:01 AM, RotaxEngines-List Digest Server < rotaxengines-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of > the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-07-09&Archive=RotaxEngines > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-07-09&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Tue 07/09/13: 3 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 07:47 AM - Re: Re: I Love Left handed drill bits (Richard Girard) > 2. 08:44 PM - Large mag drop (krazydoc33) > 3. 11:06 PM - Re: Large mag drop (Roger Lee) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: Re: RotaxEngines-List: Re: I Love Left handed drill bits > From: Richard Girard <aslsa.rng(at)gmail.com> > > Thom, As Roger noted the Locktite comes applied to the fixation screw in > dry form. Also, the use of Locktite 221 is specified for this part in the > 912 Illustrated Parts Catalog. > > Rick Girard > > > On Mon, Jul 8, 2013 at 7:19 AM, Thom Riddle wrote: > > > > > > > > Anyone who thinks that this connection needs thread locker clearly does > > not understand that aluminum has a very high coefficient of friction. In > > use, there is no external torque that would tend to loosen this > connection. > > Applying thread locker to this connection is unnecessary and a very bad > > idea. > > > > -------- > > Thom Riddle > > Buffalo, NY (9G0) > > > > > > Don't worry about old age... it doesn't last very long. > > - Anonymous > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=404178#404178 > > > > > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > ________________________________ Message 2 > _____________________________________ > > > Subject: RotaxEngines-List: Large mag drop > From: "krazydoc33" <galaxyone(at)juno.com> > > > I have a 912ULS in a RV-12, the plane has just been signed off by the DAR > but I > have not yet flown it. The engine starts fine right away and has about 2 > hours > of taxi time on the engine. I get 5050 rpm at wide open throttle and the > airport > is at ~5000'. The weather here is in the 90+range shortly after 9:00 am. > The problem I am having, which has kept me on the ground, is the mag drop. > It > is about 650 rpm on each ignition and they both run rough. They are close > together > but that much of a rpm drop seems very unusual. The exhaust pipe is sooted > which suggests it is running rich. The plugs also are very black and > cleaning > them has no effect. All the other temperatures look normal. I tried a five > minute > run at full throttle and that had no effect either. Any ideas where to look > next will be greatly appreciated. > Thanks > Henry > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404353#404353 > > > ________________________________ Message 3 > _____________________________________ > > > Subject: RotaxEngines-List: Re: Large mag drop > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Hi Henry, > > > 650 is way to high. The good thing is they are almost equal. What rpm are > you doing > the mag drop at? > What is the plug gap? It should be between .023 and .027. Better to be > the wider > gap for the summer months. Are you running an electric pump with the > mechanical > all the time? Have you synced these carbs? Did you put a fuel > re-circulation line in during the build. The new pumps really need one. > Where did > you mount the carb vent tubes? These carbs almost sound like they are > flooding, > but we could use a little more info. > > It is possible you have a wire connected wrong. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404355#404355 > > ________________________________________________________________________________
Date: Sep 08, 2013
Hi Henry, Glad the problem is solved. As far as the rich part, do not base any rich conclusions on black dry soot on the plugs when it has been run at idle. You need to run the engine over 4000 for 5-10 minutes and then shut it down. It is normal to have dry sooty plugs from idle, but that goes away at the higher rpms. Not everyone has it or does it happen to the same plugs all the time. I would fly it a time or two before making any solid conclusions. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408226#408226 ________________________________________________________________________________
Date: Sep 08, 2013
Hi George, 12.7V should have been fine to start the engine, but I would double check my wire size and length. If the size is too small or the wire too long for its size it will have too much resistance. So when the battery dips a little and the voltage is down just a little it won't start unless the battery is completely full. If the wire is good then 12.5 should start that engine. I know this isn't really taught, but rotating the prop for the gurgle will help a marginal start up be easier. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408227#408227 ________________________________________________________________________________
Date: Sep 17, 2013
Subject: "Mil Spec" Rotax 914
There is a guy selling a military spec 914 fuel injected engine on Barnstormers. I think it is off a predator drone. One modification I can see is the turbo is top-mounted. Does anyone have any info on what if anything is modified as a military spec? Does anyone know how they implemented fuel injection on these engines? The engine has 1000 hours on it so it is about to 1200 TBO. What is a run-out 914 worth. ________________________________________________________________________________
Subject: Re: "Mil Spec" Rotax 914
Date: Sep 17, 2013
You might check the real hours. I have a friend and he said they run those through one TBO. It is possible it has a lot more hours on it so double check and many of these military engine weren't supposed to make the civilian market, but some have. It may be a tired engine. I wouldn't buy it unless it has it's paperwork in order since new. These engines are buyer be ware, but some have worked out. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408767#408767 ________________________________________________________________________________
Date: Sep 18, 2013
Subject: Prop pitch lower rpm limit
A customer's purchased airplane, a Just Aircraft Highlander, with a 912 ULS and Kiev prop is set for 4900 rpm in climb. I believe he'd be happier if it were set at 5200. Certainly he would get better climb and the airplane is not a speedster so I'm not that concerned about what he'd lose in cruise flight. I'm also concerned about case cracking. I've been through the archives and through the Service Bulletins and cannot find any reference to a lower limit and a link cracking. Is it myth, legend, rumor or documented by Rotax? Rick Girard -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: Prop pitch lower rpm limit
Date: Sep 18, 2013
Case cracking is very real and has happened to several people. It usually happens to the older cases from roughly May 2006 and previous. They all came from too much stress from too much prop pitch. So long as your friend can see at least 5500 (5600-5650 is would be better) he most likely won't ever have an issue. 4900 in climb has a few variables, but should be around 5500 WOT in flat and level flight. People with the older engines only seeing 5200+/- rpm WOT in flat and level flight are playing Russian roulette. They may win for a long time, but one day may be it. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408828#408828 ________________________________________________________________________________
Subject: Diameter of Fuel line on a 914.
Date: Sep 20, 2013
Hi All, Just a quick question. Europa with a Rotax 914 engine. What is the rubber fuel line diameter, need the fittings for a Floscan Fuel sender, is it 1/4" or 6mm or 8mm hose used. regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408905#408905 ________________________________________________________________________________
Date: Sep 21, 2013
From: GRAHAM SINGLETON <grahamsingleton(at)btinternet.com>
Subject: Re: Diameter of Fuel line on a 914.
Floscan uses -6 AN fittings. You might persuade David Joyce (photographer). to send you a picture-of a manifold installation we did.=0AGraham=0A=0A_ _______________________________=0A From: Alan Carter <alancarteresq@onetel. net>=0ATo: rotaxengines-list(at)matronics.com =0ASent: Friday, 20 September 20 13, 20:36=0ASubject: RotaxEngines-List: Diameter of Fuel line on a 914.=0A @onetel.net>=0A=0AHi All,=0AJust a quick question.=0AEuropa with a Rotax 91 4 engine.=0AWhat is the rubber fuel line diameter, need the fittings for a Floscan =0AFuel sender, is it 1/4" or 6mm or 8mm hose used.=0Aregards.=0AAl an=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics. ============== ________________________________________________________________________________
Date: Sep 21, 2013
Hi Alan, 914 fuel system uses 8mm hose. Cheers, Nev -----Original Message----- From: Alan Carter <alancarteresq(at)onetel.net> Sent: Fri, Sep 20, 2013 8:37 pm Subject: RotaxEngines-List: Diameter of Fuel line on a 914. l.net> Hi All, Just a quick question. Europa with a Rotax 914 engine. What is the rubber fuel line diameter, need the fittings for a Floscan Fuel sender, is it 1/4" or 6mm or 8mm hose used. regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408905#408905 ________________________________________________________________________________
Date: Sep 21, 2013
Hi Neville Graham. Parts for Aircraft sold me two of the 1/4" Kits, So I need two of the 8 mm kits for Europa pipe work. See link. http://www.parts4aircraft.com/floscan-fuel-flow-computer.html Regards. Alan Will get them to change the kits if that correct. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408934#408934 ________________________________________________________________________________
Date: Oct 17, 2013
Subject: 447 problem and expense
Hello Rotax wizards, I'm searching for answers while I still live and breathe and have some money left. I'll try to give all the pertinent info to see if someone on the list can come up with an answer no small engine mechanic I spoke to in my area was able to diagnose. I have a FireFly which was damaged when Hurricane Sandy blew through. Last winter I removed the wings and took them to a builder for some rather minor repairs. I didn't get them back until well into the flying season, but my 447 was safely fogged before shutdown. A couple of months ago when I got the wings back and mounted I set the FF up and started the engine. It seemed to run pretty good after setting for so long, but the front cylinder wasn't warming up at the same rate as the rear. After both cylinders were within operating temps I revved it a while, then tied the FF off and gave it full throttle to check max static RPMs. I was looking for the 6200 I had before the Hurricane, but could only get 5800, so I shut it down and put the carb at defualt settings. I started it up again and ran it up to max, still 5800, and left it work for less than two minutes, hoping if a ring was stuck, etc. it would loosen up and run right. At WOT the engine shut down and pulling the exhaust manifold revealed a scored front piston. Since no one could give me a definitive diagnosis of why it seized and since the piston had to be replaced, etc. I bought two 1 over piston sets, the gasket packet for an overhaul, sent the jugs to be bored to accept the 1 voer pistions, and had a good motorcycle mechanic put it all together (one who builds motorcycles). Put the engine back on, along with a new EGT thermocouple to replace one I had to butcher to get out of the manifold, and started it up. It started easily but idled rough needing the enricher to be halfway out and it wouldn't take any throttle, so I removed the carb and took it to the mechanic who cleaned it and replaced the needle and jets. Put the carb back on and started it up. It now idled smoothly and took fuel beautifully but the one EGT didn't begin to rise for quite a few seconds. It did, however come up to the other cylinder temp and the CHTs were pretty similar in their rise, so I thought with new bores, pistons, carb, it must be the response of the new EGT thermocouple. I ran it up and down, up and down, then tied it off to check max static. It got up to over 6100, so I was satisfied that a new tight engine may have to break in a tad before it would reach the 6200 it had before. I taxied down to the end of the runway, which is downhill, turned around and taxied back up the hill where I could give it quite a bit of throttle without taking off. It sounded smooth and beautiful, so I taxied all the way to the top of the runway to give myself all the runway I could since I had to analyze any effect of the repaired wings before going out. Ran it up against the brakes almost to tail-up, released the brakes started my roll, giving it full throttle as soon as I had horizontal stab authority. It took off beautifully, the handling was accurate and neat so I pulled the stick back and said goodbye to the world for the first time in almost a year. It was a euphoric few minutes, the engine sounded fantastic, so at about 1000' AGL I throttled back and leveled off. Within seconds it got very quiet and knowing I couldn't do a 180 and land back at the strip I looked for a place to set down. Nice field next to a road so I set my glide path for it. I thought it was a soybean field, which it was, and that soybeans grew low, which they don't and quickly learned that landing in a soybean field in October is only slightly better than landing in a forest. A man who saw me going in took me back to the airstrip where I got my cycle and rode back to the FF to remove the radio, GPS, etc. My analysis was, since the engine and carb were virtually new, it must be electrical or fuel starvation. I flipped the ignition switch, pulled the starter and it fired up on the first pull. Advanced the throttle and it wanted to fly. Next day I returned and disassembled the plane and removed the engine, wings and all the little stuff, walked them out the path through the 2' high tangle of soybeans to my pickup and returned them to my hangar. Last Thur. a couple of friends went with me and we carried the plane out of the field. I brought the engine, chute, etc., home and a few days ago I removed the exhaust manifold to make sure the pistons were OK. They weren't; the front piston had seized again. Ever see a grown man cry???? Before I go any further with repairing the engine or the FF I want to be pretty sure of what I'm looking at, so if any of you experienced Rotax wrenchers have an educated theory, I'd just love to hear it. Any and all thoughts are welcome and will add to the data bank. Thanks, Dave Kulp Bethlehem, PA FireFly 11DMK ________________________________________________________________________________
Date: Oct 17, 2013
Subject: Re: 447 problem and expense
Dave, I am very sorry to hear about your troubles and that the Flag Fly is down again. It sounds like you have an air leak on the front cylinder. You might have a front seal that's gone bad, a leak in the gasket at the intake manifold front cylinder, or a leak at the exhaust manifold. Does your mechanic know how to do a crankcase pressure test? You might have to get a little fancier than and include both manifolds, but I think that might be where to start. Let me tell you a story. I have a Shovelhead Harley. When I first got it I had an S & S Super B carb that was worn out so I got the latest and greatest, the S & S Super E. The engine ran great, except every time I looked at the plugs I had a white front plug and a dark brown rear plug. I must have changed O rings and intake clamps a dozen times. I tried rubber band seals instead. I even tried a high bred system that used both O rings AND rubber bands. I was really stumped and then a buddy of mine suggested I try an SU carb. I did and the problem went away. I sold the S & S carb to a buddy. He put it on and within a week he called to say he had a dark front plug and a white rear plug. I was just insane and drove right over to his house. We looked at the carb and intake manifold, had a couple of shots of good single malt scotch, and then I had an idea. I asked Charlie for his dental mirror and went looking for the mark on the intake manifold that tells you it's right side up (even though it's symmetrical). Sure enough he had put the intake with the mark on the bottom, I always had it on top. All that time I'd been fighting the wrong battle. The intake manifold had a small porosity on one leg, hence the color of the plugs changed from Charlie's engine to mine, when the porosity moved from front to back. My point is that the problem with your engine may not lie in an obvious direction. Don't give up. Rick Girard On Thu, Oct 17, 2013 at 2:29 PM, David Kulp wrote: > > Hello Rotax wizards, > > I'm searching for answers while I still live and breathe and have some > money left. I'll try to give all the pertinent info to see if someone on > the list can come up with an answer no small engine mechanic I spoke to in > my area was able to diagnose. > > I have a FireFly which was damaged when Hurricane Sandy blew through. > Last winter I removed the wings and took them to a builder for some rather > minor repairs. I didn't get them back until well into the flying season, > but my 447 was safely fogged before shutdown. > > A couple of months ago when I got the wings back and mounted I set the FF > up and started the engine. It seemed to run pretty good after setting for > so long, but the front cylinder wasn't warming up at the same rate as the > rear. After both cylinders were within operating temps I revved it a > while, then tied the FF off and gave it full throttle to check max static > RPMs. I was looking for the 6200 I had before the Hurricane, but could > only get 5800, so I shut it down and put the carb at defualt settings. I > started it up again and ran it up to max, still 5800, and left it work for > less than two minutes, hoping if a ring was stuck, etc. it would loosen up > and run right. > > At WOT the engine shut down and pulling the exhaust manifold revealed a > scored front piston. Since no one could give me a definitive diagnosis of > why it seized and since the piston had to be replaced, etc. I bought two 1 > over piston sets, the gasket packet for an overhaul, sent the jugs to be > bored to accept the 1 voer pistions, and had a good motorcycle mechanic put > it all together (one who builds motorcycles). > > Put the engine back on, along with a new EGT thermocouple to replace one I > had to butcher to get out of the manifold, and started it up. It started > easily but idled rough needing the enricher to be halfway out and it > wouldn't take any throttle, so I removed the carb and took it to the > mechanic who cleaned it and replaced the needle and jets. > > Put the carb back on and started it up. It now idled smoothly and took > fuel beautifully but the one EGT didn't begin to rise for quite a few > seconds. It did, however come up to the other cylinder temp and the CHTs > were pretty similar in their rise, so I thought with new bores, pistons, > carb, it must be the response of the new EGT thermocouple. I ran it up and > down, up and down, then tied it off to check max static. It got up to over > 6100, so I was satisfied that a new tight engine may have to break in a tad > before it would reach the 6200 it had before. I taxied down to the end of > the runway, which is downhill, turned around and taxied back up the hill > where I could give it quite a bit of throttle without taking off. It > sounded smooth and beautiful, so I taxied all the way to the top of the > runway to give myself all the runway I could since I had to analyze any > effect of the repaired wings before going out. > > Ran it up against the brakes almost to tail-up, released the brakes > started my roll, giving it full throttle as soon as I had horizontal stab > authority. It took off beautifully, the handling was accurate and neat so > I pulled the stick back and said goodbye to the world for the first time in > almost a year. > > It was a euphoric few minutes, the engine sounded fantastic, so at about > 1000' AGL I throttled back and leveled off. Within seconds it got very > quiet and knowing I couldn't do a 180 and land back at the strip I looked > for a place to set down. Nice field next to a road so I set my glide path > for it. I thought it was a soybean field, which it was, and that soybeans > grew low, which they don't and quickly learned that landing in a soybean > field in October is only slightly better than landing in a forest. > > A man who saw me going in took me back to the airstrip where I got my > cycle and rode back to the FF to remove the radio, GPS, etc. My analysis > was, since the engine and carb were virtually new, it must be electrical or > fuel starvation. I flipped the ignition switch, pulled the starter and it > fired up on the first pull. Advanced the throttle and it wanted to fly. > > Next day I returned and disassembled the plane and removed the engine, > wings and all the little stuff, walked them out the path through the 2' > high tangle of soybeans to my pickup and returned them to my hangar. Last > Thur. a couple of friends went with me and we carried the plane out of the > field. I brought the engine, chute, etc., home and a few days ago I > removed the exhaust manifold to make sure the pistons were OK. They > weren't; the front piston had seized again. Ever see a grown man cry???? > > Before I go any further with repairing the engine or the FF I want to be > pretty sure of what I'm looking at, so if any of you experienced Rotax > wrenchers have an educated theory, I'd just love to hear it. Any and all > thoughts are welcome and will add to the data bank. > > Thanks, > > Dave Kulp > Bethlehem, PA > FireFly 11DMK > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: fuel filter
Date: Oct 21, 2013
I was re-reading the 912 installation manual and noticed that it recommends a 30 micron fuel filter in the unpressurized section of the fuel system and then a 15 micron filter in the pressurized section. My Kitfox only has a gascolator. Can someone recommend a filter to install in the pressurized section? Where exactly would one put it? A filter with replacement cartridges that are easy to buy in Europe would be a plus. ________________________________________________________________________________
Subject: Terminal Block.
Date: Oct 22, 2013
Hi.All. Just a quick question to those electrical nerds out there. I have just installed a terminal block in my Europa, the two bolts that hold the terminal block are bolted through the fibre glass on the inside of the instrument panel, nothing can touch the heads of these two bolts on the inside as they are insulated. I want too make use of there threaded length as extra terminals so my eye let connectors can fit down them. Odd maybe, but it would be useful if I could use them, fibre glass is a none conductive material , is there Any reason this would not work, Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411147#411147 ________________________________________________________________________________
Date: Oct 22, 2013
Subject: Re: Terminal Block.
Alan: What kind of terminal block do you have? Here is a link to what I think you are referring to: https://www.google.com/search?hl=en&site=imghp&tbm=isch&source=hp&b iw=1274&bih=898&q=terminal+blocks+electrical&oq=terminal+blocks&gs_ l=img.1.2.0l4j0i5l6.1843.6298.0.10217.15.12.0.3.3.0.100.824.11j1.12.0.... 0...1ac.1.29.img..0.15.846.PmNwcMhs4AE#facrc=_&imgdii=_&imgrc=hJIlSYK 4bCtOSM%3A%3BNW7ZZ7CTMeNseM%3Bhttp%253A%252F%252Fwww.monumentalelevatorsupp ly.com%252Fimages%252Fproduct_images%252FTerminalBlock.bmp%3Bhttp%253A%252F %252Fwww.monumentalelevatorsupply.com%252Findex.cfm%253Ffuseaction%253Dshow Entity%2526entityID%253D238%2526catID%253D289%3B433%3B237 Here is also a picture - But, I don't know if it will come through. So, I gather that you are referring to the mounting holes to the left and right. Well, the question is: What material do the bolts go through? If it is fiberglass than they would be insulated. If it is metal than they would NOT be insulated and could be used for a GROUND point. But, NOT for the B+ (positive side of the circuit) . As a side note: It is recommended that you do NOT use more than 3 ring lugs (stacked) on a single screw of the insulated terminal strip and 4 ring lugs on a single point ground. Of course the argument is : I'm experimental I can do anything I want. And I have seen a solid inch (1") of screw stacked with ring lugs, I think there might have been 20 ring lugs. Did it work? Yes. Is it safe? NO! *Barry* *=93Chop=92d Liver=94* NJ has taken the next step. They are identifying cars with bad drivers. You will notice some cars with a large red "R" on them. That is to identify the drivers as "R"estricted. Restricted is just a polite way of saying Bad Drivers. Be cautious around them. On Tue, Oct 22, 2013 at 6:17 PM, Alan Carter wrot e: > alancarteresq(at)onetel.net> > > Hi.All. > Just a quick question to those electrical nerds out there. > I have just installed a terminal block in my Europa, the two bolts that > hold the terminal block are bolted through the fibre glass on the inside of > the instrument panel, nothing can touch the heads of these two bolts on t he > inside as they are insulated. > I want too make use of there threaded length as extra terminals so my eye > let connectors can fit down them. > Odd maybe, but it would be useful if I could use them, fibre glass is a > none conductive material , is there Any reason this would not work, > Regards. > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411147#411147 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Oct 23, 2013
Hi Alan, It will work. Flight Design and a few others do it just this way. Make sure the main bolt with the ground wire in the engine compartment that goes through into the instrument panel with the other main ground wire is nice and tight. A less than tight bolt can make your instruments jump around. Some use a long bolt and just put the ground wire eyelets over them and nut it down, you could use two bolts with a jumper if you have too many wires and Aircraft Spruce sells a ground block that you can use that has spade push on connectors. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411178#411178 ________________________________________________________________________________
Date: Oct 23, 2013
Hi Barry, Rodger. I have posted photo so you can see what I am doing. Basically I am fitting a Fuel flow meter to the aircraft, my plan is for me to make up the gauge panel plus some illuminated switches and do all the cosmetic work plus fitting all the components in place like the 2 senders and get it wired up, keeping the plane flyable so as I can use it. Then at a later stage get my inspector to come over, and finish off, do the fuel pipe line work, flow tests, and sign it off. As you can see lots of grounds wires from the switch LEDs, etc, I can make about 4 or 5 lugs per terminal, this is why I want to make use of the terminal blocks fixing bolts, and use them as extra terminals, And yes they do fix into Fibre Glass, I am thinking it will be all OK , but just to be sure but this post in. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411226#411226 Attachments: http://forums.matronics.com//files/cimg1110_652.jpg ________________________________________________________________________________
From: "Clive Richards" <s.clive.richards(at)homecall.co.uk>
Date: Oct 23, 2013
Alan Not clear what type of terminal block you mean but if you are using the fixing bolts make sure you clamp the ring terminals between nuts not against the fiber glass. As you are in UK Parts for aircraft sell busbar blocks with 5, 8 & 10 terminals. & aircraft grade wire http://www.parts4aircraft.com/PBSCCatalog.asp?ActionID=67174912&PBCATID=1543515&PBCATName=Sockets,%20Plugs%20and%20Bus%20Bar Are you using coloured aircraft or pvc ? ----- Original Message ----- From: "Alan Carter" <alancarteresq(at)onetel.net> Sent: Wednesday, October 23, 2013 5:47 PM Subject: RotaxEngines-List: Re: Terminal Block. > > > Hi Barry, Rodger. > I have posted photo so you can see what I am doing. > Basically I am fitting a Fuel flow meter to the aircraft, my plan is for > me to make up the gauge panel plus some illuminated switches and do all > the cosmetic work plus fitting all the components in place like the 2 > senders and get it wired up, keeping the plane flyable so as I can use it. > Then at a later stage get my inspector to come over, and finish off, do > the fuel pipe line work, flow tests, and sign it off. > As you can see lots of grounds wires from the switch LEDs, etc, > I can make about 4 or 5 lugs per terminal, this is why I want to make use > of the terminal blocks fixing bolts, and use them as extra terminals, > And yes they do fix into Fibre Glass, > I am thinking it will be all OK , but just to be sure but this post in. > Regards. > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411226#411226 > > > Attachments: > > http://forums.matronics.com//files/cimg1110_652.jpg > > > ________________________________________________________________________________
Date: Oct 23, 2013
Hi, Its a 10 pin terminal block, and yes I would bolt the eyelets up between the nuts. I can see no reason why this should not be fine, all bolted up tightly together. But I had this thought in my head. It was just a thought that maybe not using the terminal block itself, but using the fibre glass of the instrument panel may induce some electrical charge into it, and make it more sensitive to a lighting strike, most probably not , but just wanted to check it out. As you mentioned "Parts For Aircraft", I like to give credit where credit is due. I find Parts for Aircraft a very helpful and honourable company to deal with, and would recommend them for any parts you may need. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411265#411265 ________________________________________________________________________________
Subject: RE: fuel filter
Date: Oct 24, 2013
Hi Listers, does no-one know the answer to the below? Any help would be greatly appreciated! Sacha Kitfox IV, Rotax 912, Italy I was re-reading the 912 installation manual and noticed that it recommends a 30 micron fuel filter in the unpressurized section of the fuel system and then a 15 micron filter in the pressurized section. My Kitfox only has a gascolator. Can someone recommend a filter to install in the pressurized section? Where exactly would one put it? A filter with replacement cartridges that are easy to buy in Europe would be a plus. ________________________________________________________________________________
Date: Oct 24, 2013
Subject: Re: RE: fuel filter
Hello Sacha: The Pressurized Vs Unpressurized locations is dependent on the installation set-up you have. Basically the Unpressurized side is coming from the fuel tank and the Pressurized is everything after the Fuel Pump. Do you have a Electric Boost Pump installed? That is usually installed 'upstream' - Before the mechanical fuel pump so - - The unpressurized is now BEFORE the electric boost pump, which may have its own built in filter (Faucet). I really do not see any reason why there should be two different micron size filters. There are three requirements: 1 - What ever filter you chose it MUST be able to handle TWICE the maximum fuel pressure. 2 - The micron size should be small enough to catch the smallest size particle that could cause a problem. Since there is a suggestion/requirement to use a 15 micron filter, I would use that size in both locations. Why pass on a dirt particle from one filter and part of a system further down and maybe into a difficult to reach part of the system. 3 - Fuel flow is dependent on a few factors: Fuel Pressure Fuel Line Size - Both Diameter and Length
May 04, 2013 - October 24, 2013
RotaxEngines-Archive.digest.vol-be
