		beachyjeff(at)juno.com Guest
				 Posted: Tue Mar 13, 2007 6:12 am    Post subject: Oil Pressure Switch |
				Anyone use the oil pressure switch from Lockwood for their Hobbs meter?
 If yes, how is the wiring hooked up?
 Jeff Beachy
 CH701
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Tue Mar 13, 2007 10:34 am    Post subject: Oil Pressure Switch |
				Hello Jeff
 "Anyone use the oil pressure switch from Lockwood for their Hobbs meter?"
 I am not flying my Europa with 914 yet, but did purchase a Hobbs with
 extra contact. I have a relay where I am using NC set of contacts to run
 hobbs, when oil pressure goes low and contacts make, it energizes coil on
 relay and stops hobbs.
 Ron P.
 BTW the sender does not have a brass ring on it, I am remote mounting it
 using -3 teflon hose (will fill with oil so no air can compress and have
 moisture squeezed out).
