		ddddsp1(at)juno.com Guest
				 Posted: Sat Feb 04, 2006 10:04 pm    Post subject: Fuel sender and Pitot mount question |
				Looking for suggestions on inspecting the fuel senders to verify they are moving freely all the way up and down in the tank.  I have quickbuild wings and did not have the luxury of installing them before finishing the fuel tank.  I believe they are hitting the stiffener and not going up between the fuel vent line and stiffener............thus not going UP completely.  This would show a tank less than FULL.  Any ideas?
 I also have a Dynon pitot mount bracket/pitot.  It is angled to go under the lip of the wing spar with 3 rivots. I am also running angle aluminum 90 degrees to the front lip along the bottom skin spar...........is it recommended to use a doubler plate like the GRETZ model also?  Appears to be very sturdy without a doubler plate.  If any one has pics of their Dynon bracket mounted I would enjoy seeing them.
 DEAN
  Try Juno Platinum for Free! Then, only $9.95/month!
  Unlimited Internet Access with 1GB of Email Storage.
  Visit http://www.juno.com/value to sign up today!
		Tim_Lewis(at)msm.umr.edu Guest
				 Posted: Sun Feb 05, 2006 5:46 am    Post subject: Fuel sender and Pitot mount question |
				I ran a piece of string through a couple of holes (in the access plate,
 as I recall) allowing me to pull the sender up and down (using the
 string).  I had the same problem with limited movement.
 I suggested to Vans that the fuel sender be included with the QB wing,
 and that the sender arm be bent when the tank is being built.
 Otherwise, as you noted, it's difficult (I gave up) to get it adjusted
 so it moves freely without binding on stiffeners somewhere.
 Tim Lewis -- HEF (Manassas, VA)
 RV-6A N47TD -- 830 hrs
 RV-10 #40059 under construction
 ddddsp1(at)juno.com wrote:
  	  | Quote: | 	 		   Looking for suggestions on inspecting the fuel senders to verify they
  ideas?
  90 degrees to the front lip along the bottom skin spar............is it
  DEAN
		LarryRosen
				 Posted: Sun Feb 05, 2006 6:23 am    Post subject: Fuel sender and Pitot mount question |
				This is how I installed the fuel sender into my quickbuild wings
 I bend the rod per the plans.
 I attached safety wire to the rod
 The safety wire was fished through the bottom drain opening (VA-112)
 I connected a multimeter to the fuel sender and measured the resistance
 through the range of the fuel sender using the safety wire to move the
 float up and down.
 I would shine a flash light through the finger strainer (VA-141) on the
 inboard side of the wing and try to look through the drain opening with
 the safety wire to see where the float was hitting.
 Then remove the fuel sender, tweak / rebend the rod, re-install and
 check the range of motion with the multimeter.
 Do this over and over again until you get the full range from the float
 Real pain in the a$$.
 In the end I got resistance reading
 Right tank:  empty 247 ohms, full 29 ohms
 Left tank: empty 246 ohms, full 33 ohms.
 There is a picture of the safety wire through the drain opening on my
 website.  Now I need to add the commentary to have it make sense.  The
 photo is here
 <http://lrosen.nerv10.com/Construct/Log/Wings/FuelLevel/index.html>
 Larry Rosen
 Tim Lewis wrote:
  plate, as I recall) allowing me to pull the sender up and down (using
  the string).  I had the same problem with limited movement.
  _________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
