Erich_Weaver(at)URSCorp.c Guest
Posted: Mon Mar 19, 2007 8:24 am Post subject: Extra credit quiz |
I was glad to see anything promoting the Aeroelectric connection, but found the article to have very limited information. What really bugged me was that the pictures of connectors were for ones that are NOT recommended. To be fair, this was pointed out in the caption, but how about showing people what the good ones look like instead of leaving people guessing?
Erich Weaver
nuckollsr(at)cox.net Guest
Posted: Tue Mar 20, 2007 5:17 am Post subject: Extra credit quiz |
At 12:22 PM 3/19/2007 -0400, you wrote:
| Quote: | I was glad to see anything promoting the Aeroelectric connection, but
people guessing?
I think the thrust of the article was about
the seminars, not so much simple ideas.
Did you spot any errors in simple ideas beyond the
terminal illustration?
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
Posted: Tue Mar 20, 2007 10:20 pm Post subject: Extra credit quiz |
Bob said "Did you spot any errors in simple ideas...?"
Okay, now I see what you intended - should have paid more attention to the thread subject line.
Perusing the Kit Planes article once more, the information regarding the correct size fuse or circuit breader for a 60-amp alternator doesnt sound like what I thought I learned in the 'Connection. The article says use 70 or 80 amps to "prevent nuisance tripping because alternator ratings are minimum ratings." I believe nuisance tripping on my Z-13/8 based system with 40 amp alternator is handeled not by oversizing a fuse or breaker on the alternator B-lead, but by using a 5-amp breaker on the alternator field. My B-lead is protected with a 40 amp ANL current limiter which I believe is the correct size for my alternator.
Im also bothered by the "minimum rating" part of the statement, as this would seem to imply that the alternator could easily produce that current for long periods of time. We are supposed to be operating at about 75% of the alternator rating, no?
Is this more on track, or do I get the booby prize and have to go back and read 'Connection yet again until it finally sinks in?
Erich Weaver
This e-mail and any attachments are confidential. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies. [quote][b]
mprather(at)spro.net Guest
Posted: Wed Mar 21, 2007 8:57 am Post subject: Extra credit quiz |
Erich,
Your method of protecting the b-lead is correct as well.
Minimum rating means that the manufacturer is telling you their product
will produce at least a certain number of watts of electrical energy under
certain conditions. Under more favorable conditions (cold temperature)
the alternator likely is capable of producing more power. If you bought a
560Watt alternator (14V*40A) and it only produced 500Watts (while
duplicating the test conditions), you'd be rightly disappointed.
Matt-
70
Erich Weaver
Posted: Wed Mar 21, 2007 4:49 pm Post subject: Extra credit quiz |
At 02:18 AM 3/21/2007 -0400, you wrote:
| Quote: | Bob said "Did you spot any errors in simple ideas...?"
There's breakers, fuses and THEN there are current limiters.
The ANL's trip characteristics are shown in . . .
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
There's no listing for the ANL40 but note that the ANL35 goes
asymptotic to never-trips at about 90 amps! The ANL40 will
be higher yet. Obviously, these critters are NOT intended to
protect for wire overheat but HARD faults. You could use an
ANL40 on a 60A alternator without nuisance tripping.
You COULD go for an ANN40. See . . .
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANN_Specs.pdf
Here the device goes asymptotic to never-trips at 50A. An ANN40
would be solid at about 56A . . . still really good headroom for
a 40A alternator.
Let's consider a MAX40 for your 40A alternator. See . . .
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/MAXI_Specs.pdf
This device doesn't go asymptotic at under 100 seconds
but still takes 60A to open it in about two minutes. But
your 40A alternator will put out 50A or so when it's cold.
Hmmmm . . . starting to push the limits.
Lets look at a 40A breaker like . . .
http://www.aeroelectric.com/Mfgr_Data/Breakers/Potter_Brumfield/W2331_DS.pdf
Note in the calibration data we read: "Will carry 100%
of rating but may trip between 101% and 134% of rating.
Must trip within one hour at 135%." Things change pretty
quickly in the range of 135 to 200% and drop to seconds
of trip time.
These are but a few examples of how much variability you can
find in characteristics of the various circuit protection
products when compared with their RATINGS.
My writings have suggested the fast devices like fuses and
breakers have healthy margins over the ratings of the
alternator. Again, b-lead protection is for taming HARD
faults (read many hundreds of amps) and not enduring low
level overloads.
Bottom line is that you probably can't have b-lead
protection that is TOO big when selecting breakers and/or
fuses. Anywhere from 1.5 to 3x the alternator rating
would do the hard fault protection job and be free of
nuisance tripping.
On the other hand, current limiters are offered with those
headrooms already built in. They're much more robust with
respect to ratings than their faster cousins.
| Quote: | Im also bothered by the "minimum rating" part of the statement, as this
You want to plan no more than 75% of rating for continuous
loads by your ship's equipment as defined by the various
operating conditions in your load analysis. See:
http://www.aeroelectric.com/PPS/Load_Analysis/Revised%20%20load_analysis.xls
or if you want to do one by hand see:
http://www.aeroelectric.com/PPS/Load_Analysis/Blank_Form.pdf
The idea behind alternator de-rating is to leave some stuff
left over for RECHARGING the BATTERY. You don't want to launch
in some condition that needs 100% of alternator output and
leave your battery unattended.
| Quote: | Is this more on track, or do I get the booby prize and have to go back and
Hmmmm . . . here's a chance to redeem yourself. How
accurate was he with respect to quotation of mile
stones in voltage readings?
Actually, his piece was pretty accurate for someone
who is attempting a good critique of an activity that
was not his particular field of experience. We romp
along pretty fast in those seminars and we know it's
tough to be 100% retentive in the best of circumstances.
I'm working on the power point presentation for a
seminar next Saturday in North Carolina. My seminar
format is in transition in preparation for offing
audio/slide and ultimately video versions off the
website. This will allow us to reach many more
individuals than those opportunities offered at
6-8 seminars a year.
Posted: Thu Mar 22, 2007 6:01 pm Post subject: Extra credit quiz |
Bob wrote: "Hmmmm . . . here's a chance to redeem yourself. How
stones in voltage readings?"
Well that narrows it down quite a bit, ensuring complete and immediate public humiliation upon any further displays of my electrical ineptness : )
Then again, I didnt have far to go to reach that state anyway, so for the purposes of List entertainment, I will go forward with my second answer to the quiz.
The article states "A fully charged, healthy battery will show 12.5 voltes, and a fully discharged battery will show 10.5 volts." Fair enough. But shortly thereafter, it goes on to state: "Where do you want to set you low voltage warning? How about 13.9 volts, which indicates hat the alternator isnt charging and you're running off the stored battery charge."
Setting the warning at 13.9 volts seems a tad high to me - I would expect battery-only operations to exhibit a voltage significantly less than this, especially if there was any load at all. Heck, voltage may well drop to below this value just from going through the bridge rectifier to my e-bus. How about a setting more like 13.0 volts or so?
Regardless of quiz results, I am so pleased to have been able to do my electrical wiring myself. I pretty much stuck with the Z-13/8 schematic, because time after time I have seen people overthinking it with "improvements" that just plain arent. Plus, even if I'm issing the nuances of breakers vs. current limiters, Bob has my rear covered. Thanks for the 'Connection and this list Bob.
Erich Weaver
Posted: Thu Mar 22, 2007 7:25 pm Post subject: Extra credit quiz |
At 10:00 PM 3/22/2007 -0400, you wrote:
| Quote: | Bob wrote: "Hmmmm . . . here's a chance to redeem yourself. How
the quiz.
BINGO! You win the six pac . . .
| Quote: | Regardless of quiz results, I am so pleased to have been able to do my
You're most welcome. Couldn't do it if it wasn't fun.
( EVERY day . . . )
