longg(at)pjm.com Guest
Posted: Wed Mar 21, 2007 11:23 am Post subject: Glideslope Antennas |
I have found very little in the way of GS antennas on the market. I am
looking for a solution for a fiberglass airplane. Perhaps one of you
have crossed this path and found a good solution? I already have a built
in VOR antenna in the wing, two COM dipole antennas attached internally
to the fuselage, a transponder antenna through the floor and a beacon
copper strip antenna on the floor. I would like to avoid the cat whisker
arrangement found throughout GA aircraft.
frank.hinde(at)hp.com Guest
Posted: Wed Mar 21, 2007 11:51 am Post subject: Glideslope Antennas |
Why not use a splitter for your VOR antenna then you don't need a
separate antenna or cable
Frank
Posted: Wed Mar 21, 2007 1:05 pm Post subject: Glideslope Antennas |
Frank,
I thought about doing just that, however I only have one VOR
antenna and two NAV radios. I have seen a splitter which will allow for
both but I am hesitant to use it for fear of signal degradation.
BobsV35B(at)aol.com Guest
Posted: Wed Mar 21, 2007 1:19 pm Post subject: Glideslope Antennas |
Good Evening longg,
I think you will find that at least ninety percent of the certified airplanes that have had a radio installation in the last twenty years will use one set of blades or a V antenna to feed two nav radios and two Glide Slope receivers. As 'Lectric Bob has noted, at the ranges we use, a wet string would probably be adequate.
A set of blades is elegant and work very well, but even the cheapest V antenna when spilt with a four way splitter will give every bit of signal any modern receiver can use.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 3/21/2007 4:07:43 P.M. Central Daylight Time, longg(at)pjm.com writes:
| Quote: | Frank,
Posted: Wed Mar 21, 2007 1:32 pm Post subject: Glideslope Antennas |
I have an Archer wingtip VOR antenna with a splitter and it works very
well..Could you use a second wingtip job and split that signal instead,
i.e two antennas and two splitters?
I'm not sure how the signal would degrade if you used a single antenna
to two radios?
Frank
