Paul Petty
Posted: Mon Mar 26, 2007 1:47 pm Post subject: vinyl graphics vs painting |
Hey guys,
First report of how the vinyl graphics went. Love it! Has to be better than painting. Will let you know how well it stays on!
http://groups.msn.com/AerialWorld/kolbra012.msnw?Page=6
_________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
Posted: Mon Mar 26, 2007 2:07 pm Post subject: vinyl graphics vs painting |
| First report of how the vinyl graphics went. | --------
| Paul Petty
Paul:
How do you adhere it to the fabric? soapy water?
Never used that type.
Looks good.
_________________ John Hauck
Titus, Alabama |
MKIIIX040
Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
Posted: Mon Mar 26, 2007 3:06 pm Post subject: vinyl graphics vs painting |
Hey John,
I do vinyl for a part time living.
you can contact me off list if you need anything or more info.
Vic AKA Vic's Vinyl Lettering
912 UL Extra
Maine
_________________ MKIIIX040
912UL |
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Mon Mar 26, 2007 7:37 pm Post subject: Re: vinyl graphics vs painting |
Paul,
I've been wanting to checker board my rudder for a while. Can you give us some more details on where you got the material, how it is applied, cost, etc? Looks great!
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
John H Murphy
Joined: 03 Jan 2007 Posts: 78 Location: Henderson, NV
Posted: Mon Mar 26, 2007 8:42 pm Post subject: Re: vinyl graphics vs painting |
I also would be interested in where to obtain & how well it holds.
Posted: Tue Mar 27, 2007 1:51 am Post subject: vinyl graphics vs painting |
I also would be interested in where to obtain & how well it holds.>>
Hi,
not quite the same but I once covered my glider trailer, about 35 ft long,
with blue woodgrain effect wallpaper. The effect was spectcular but
unfortunately towing to a neighbouring airfield in the rain the whole lot
came off.
Travelling behind were two little old ladies in an ancient car a little
larger than a Mini. The old dears carefully picked up all the wet, sticky,
wallpaper, folded it up and put it in their car. When I stopped a few miles
further on to check the trailer the old girls pulled up and proudly
presented me with this pile of soggy, gluey paper because `they thought I
would want it`.
I thanked them profusely and dumped the lot over the hedge as soon as they
were out of sight.
Cheers
Pat
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Tue Mar 27, 2007 4:37 am Post subject: Re: vinyl graphics vs painting |
We use vinyl graphics on our company pickups and also on our manufactured equipment which goes into some of the worst chemical and process enviorments you can imagine. The stuff we use has held up well for years.
I plan to use them for my N-numbers and some trim.
Rex
Paul Petty
Paul Petty
MKIIIX040
Posted: Wed Mar 28, 2007 7:02 am Post subject: Re: vinyl graphics vs painting |
Paul thanks for the "plug".
You probably ordered from a girl in Fl. because she was, oh say, purtier than me.
Aplication fluid works good for large surface areas. Dry is best on the rest.
I use a clear aplication tape, makes it easier to see what your doing and is good for multiple color registration.
The slickest way to keep your #'s or graphic in place is to tape it in the center. Peel back the aplication tape with the graphic half way and cut the backing paper. Squeege that side and your vinyl won't move from there, then remove the tape you used for positioning and the remainder of backing paper, squeege the other half remove the application tape and Presto your done!
Do not apply in direct sunlight!
I use high perfomance vinyl on GA just because. It's thinner, 3 times the cost, and harder to work with.
The less expensive intermediate vinyl may shrink slightly after a couple years but neither one will will come off. I've put a pressure washer directly against letters on my tailgate and they didn't come off.
I asked Travis about making their logos in different sizes and colors to match different aircraft. He said he didn't have any problem with it.
Quite a while back I even made Kolb mugs for the crew at TNK.
Vic
912 UL Extra
Maine
912UL |
