nuckollsr(at)cox.net Guest
Posted: Tue Mar 27, 2007 6:12 am Post subject: Fwd: Re: re: Capacitors for Whelen strobe power supply |
Here's a note I received on one fellows success with
replacing flash-rated capacitors with plain-vanilla
electrolytics.
His confirmation of my past experiences suggests that
the experiment is worth repeating.
| Quote: | Hey, Bob, I'm just a lurker in the archives, but I have replaced the
electrolytics in two Whelen strobe supplies.... Worked fine then and is
working fine now. Some spray-on conformal coating helps cut down on the
high-voltage corrosion in the units.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
frank.hinde(at)hp.com Guest
Posted: Tue Mar 27, 2007 6:52 am Post subject: Fwd: Re: re: Capacitors for Whelen strobe power supply |
Yes I did the same, I had a pair of Aeroflash units in my old Zodiac.
Standard repair for each Aeroflash was $50. Standard capacitor was $10
and 10 minutes with a soldering iron.
I only used to get a couple of years per capacitor but that seemed no
worse than the Caps the Aeroflashers came with.
Cheers
Frank
