Dennis.Kirby(at)kirtland. Guest
Posted: Mon Apr 02, 2007 9:13 am Post subject: Cleaning Air Filters |
Kolb Friends -
What's the recommended method for cleaning the K&N air filters on our
Rotax engines?
I have the prescribed K&N air filter oil ready to apply once they're
clean. But I didn't buy their expensive filter cleaning solution. Can
these filters be adequately cleaned using just warm water and a mild
detergent?
Thanks -
Dennis Kirby
Mark-3, 912ul in
Cedar Crest, NM
Paul Petty
Posted: Mon Apr 02, 2007 9:48 am Post subject: Re: Cleaning Air Filters |
Dennis,
I sell the K&N Recharger kit retail for 11.99. comes with a bottle of cleaner and a bottle of oil. probably enough to clean the rotax filters several times.
_________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
Posted: Mon Apr 02, 2007 9:50 am Post subject: Cleaning Air Filters |
Can
| detergent?
| Thanks -
| Dennis Kirby
Dennis K:
I have been using K&N since day one, 1984. I tried the K&N filter
cleaning fluid, soak and water, and was never happy with the results.
Right or wrong, have been washing my K&N filters with gasoline. Let
them air dry. Oil with K&N filter oil for cotton filters, let the
soak over night, and put them back on the airplane. Be careful when
you purchase filter oil. First trip to Alaska I could not find the
correct K&N oil, so settled for K&N foam air filter oil. Really had a
mess on my hands the rest of the flight.
_________________ John Hauck
Titus, Alabama |
Ed in JXN
Posted: Mon Apr 02, 2007 9:54 am Post subject: Cleaning Air Filters |
Hi Dennis,
Precisely. Mild solution of dishwashing detergent in warm water,
and I add to this a few drops of alcohol. Same solution works great to
clean windows.
Just be sure to rinse the filter well in clean water, and they can
be blow-dried with low-pressure compressed air. I let mine stand overnight
wrapped in paper towels, seems to wick the water out.
Ed in JXN
MkII/503
ul15rhb(at)juno.com Guest
Posted: Mon Apr 02, 2007 10:00 am Post subject: Cleaning Air Filters |
I immerse the filter in a bowl filled with water and a few ounces of
liquid laundry detergent (like Tide) and let it soak for 2 days. I
remove it and rinse it thoroughly under warm water. I let it air dry
for 2 days and then oil it. It's best to have two filters. One can be
soaking while the other is on the engine.
Ralph Burlingame
Original Firestar
20 years flying it
Kolb Friends -
Rotax engines?
Can
detergent?
Thanks -
Dennis Kirby
Mark-3, 912ul in
Cedar Crest, NM
________________________________________________________________________
Interested in getting caught up on today's news?
Click here to checkout USA TODAY Headlines.
http://track.juno.com/s/lc?s=198954&u=http://www.usatoday.com/news/front.htm?csp 4
biglar
Posted: Mon Apr 02, 2007 1:28 pm Post subject: Cleaning Air Filters |
I'm not sure just what solvent they use, but I was told that ordinary dish detergent will do fine. Spray it on the outside, let it soak, then hose it off from the inside with a low pressure hose with no nozzle. Do NOT use compressed air, or high pressure water. The way it was explained to me was that the high pressure will separate the fibers in the filter media, creating holes. You don't want holes. You may not see them with the bare eye, but they'll be there. Lar.
On 4/2/07, Ralph <ul15rhb(at)juno.com (ul15rhb(at)juno.com)> wrote: [quote]--> Kolb-List message posted by: "Ralph" <ul15rhb(at)juno.com (ul15rhb(at)juno.com)>
Ralph Burlingame
Original Firestar
20 years flying it
-- "Kirby Dennis Contr MDA/AL" < Dennis.Kirby(at)kirtland.af.mil (Dennis.Kirby(at)kirtland.af.mil)> wrote:
--> Kolb-List message posted by: "Kirby Dennis Contr MDA/AL"
<Dennis.Kirby(at)kirtland.af.mil (Dennis.Kirby(at)kirtland.af.mil)>
Kolb Friends -
Rotax engines?
Can
detergent?
Thanks -
Dennis Kirby
Mark-3, 912ul in
Cedar Crest, NM
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
JetPilot
Posted: Mon Apr 02, 2007 6:38 pm Post subject: Re: Cleaning Air Filters |
Thanks for the warning about high pressure water Lar, I would have surely opened up some holes For the Drying, a regular house fan blowing on the filter will accelerate the process, probably be ready in a couple hours with a good airflow over it.
Where is the best place to buy the K&N air filter Oil ?
Kolb MK-III Xtra, 912-S |
joe
Joined: 24 Mar 2007 Posts: 16 Location: Broken Arrow, Ok
Posted: Tue Apr 03, 2007 4:24 am Post subject: Re: Cleaning Air Filters |
I've used these filters on cars for years. I also wash them with any mild detergent, but always use the K&N oil. The supplies have always been available in any auto parts store, it would be the same stuff. You get quite a few applications out of a can.
Joe
Posted: Tue Apr 03, 2007 7:28 am Post subject: Cleaning Air Filters |
"JetPilot" << Where is the best place to buy the K&N air filter Oil ? >>
Almost any motorcycle shop.
$8. for a 6-oz can - that'll probably last a dozen applications.
Dennis K.
frank-margie(at)worldnet. Guest
Posted: Tue Apr 03, 2007 7:19 pm Post subject: Cleaning Air Filters |
I read somewhere (some years back) that it's best to not oil the K&N's, the backflow from the engine (2 strokes) will do the oiling. Seemed to work better that way on the old 377, mine and a buddys (easier starting, faster run up). Haven't oiled one in a long time now, only clean them. (Dish soap and water, low pressure water rinse from inside.) Anyone else remember reading that info?
Frank Clyma
Orange Park, FL
d-m-hague(at)comcast.net Guest
Posted: Wed Apr 04, 2007 3:11 am Post subject: Cleaning Air Filters |
At 11:14 PM 4/3/2007, frank & margie wrote:
| Quote: | | I read somewhere (some years back) that it's best to not oil the K&N's, the backflow from the engine (2 strokes) will do the oiling. Seemed to work better that way on the old 377, mine and a buddys (easier starting, faster run up). Haven't oiled one in a long time now, only clean them. (Dish soap and water, low pressure water rinse from inside.) Anyone else remember reading that info? |
I would think if you're not taking off and landing in a dusty environment, it's might be OK (but not optimum). Lots of older planes had no air filter at all, so that any unlucky bug in the vicinity took a trip through the engine. Of course those old engines didn't have tiny needle bearings that a single grain of sand could lock up, either.
I'll keep on oiling mine.
-Dana
The citizens of the United States are getting the government they deserve. The problem is that I'm also getting the government they deserve. [quote][b]
Posted: Wed Apr 04, 2007 3:53 am Post subject: Cleaning Air Filters |
environment,
| it's might be OK (but not optimum). |
| -Dana
Dana:
Lots of folks labor under the misunderstanding that once they break
ground and get up into clean air, they don't really need an
aircleaner. Might be surprised how much crude is in the air, at all
altitudes, that one can not see. Check it out. Fly all day on a
cross country. That evening check the leading edge of wings, prop,
struts, etc., and see how much crude is packed on the airplane.
Another point. Most marine applications do not use aircleaners, only
flame arrestors. Bet the air on the lake, river, and coast is full of
contamination too.
I'm going to keep using K&N filter oil on my filters also.
Titus, Alabama |
Posted: Thu Apr 05, 2007 4:37 pm Post subject: Cleaning Air Filters |
REF:
environment,
| -Dana
Dana:
contamination too.
Guess I'll take another look at oiling filters. Maybe the dual carb engines (which I now have) have enuf more filter area to avoid the problem I saw on the single carb 377. (Can't believe, with the depth of experience on this list, that nobody else ever experienced the same effect.)
Thanks everybody for the feedback.
Frank Clyma
russ(at)rkiphoto.com Guest
Posted: Thu Apr 05, 2007 5:10 pm Post subject: Cleaning Air Filters |
A small point of correction? you say "most marine engines don't use air cleaners -- true for the smallies, but the big ($40-50 thou each) ones sure do! Lots of crud at real low altitudes, over land or water.
On Apr 5, 2007, at 8:37 PM, frank & margie wrote:
| Quote: | REF:
environment,
| -Dana
Dana:
contamination too.
Frank Clyma
