tomd
Posted: Sat Apr 14, 2007 5:49 pm Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
I am lucky to have access to a Continental A-65-8 for a very reasonable price, much less than the cost of a typical Rotax 582, VW conversion, Jabiru and the like. I would like to open a discussion thread on the use of this engine on the Kolb Mk III Xtra. I realize I will have to design and build my own engine mount but don't see too many other challenges I can't live with (the -8 version will not accept a starter or alternator, so I hand prop). I appreciate any input from the list both for and against. Thanks.
captainron1(at)cox.net Guest
Posted: Sat Apr 14, 2007 6:50 pm Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
Well, it may work out, but a couple of things. It will vibrate a lot more then any of the alternatives and the kolb cage structure maybe marginal for that. I considered putting a O-200 Conti on my M3X. But again it may just be too much for the frame. Ok it is too much for the frame.
Also 65 hp for that much weight not the best choice. I would buy the motor anyway if the price is real good, but that would be for another project.
jindoguy(at)gmail.com Guest
Posted: Sat Apr 14, 2007 9:01 pm Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
Weight for power, I think is the best reason. You'll have the weight of the heaviest VW conversion with the power of a 582. Not a good trade, in my book.
Why not sell the A65 and either add a bit more to it for a new 582 or get a good used one?
Rick
On 4/14/07, Tom Deiulio <tpd47(at)earthlink.net (tpd47(at)earthlink.net)> wrote:[quote] I am lucky to have access to a Continental A-65-8 for a very reasonable price, much less than the cost of a typical Rotax 582, VW conversion, Jabiru and the like. I would like to open a discussion thread on the use of this engine on the Kolb Mk III Xtra. I realize I will have to design and build my own engine mount but don't see too many other challenges I can't live with (the -8 version will not accept a starter or alternator, so I hand prop). I appreciate any input from the list both for and against. Thanks.
[quote][b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com
Posted: Sun Apr 15, 2007 5:09 am Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
of the
| heaviest VW conversion with the power of a 582. | Rick
Gang:
Kolbs don't perform well with direct drive engines. Rick Neilsen and
John W have had experience with these set ups.
_________________ John Hauck
Titus, Alabama |
Posted: Sun Apr 15, 2007 5:11 am Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
I'm a day late because I've been using the digest but here's my
opinion on the A-65:
The ONLY drawback is the weight. A sturdy engine mounting would have
to be
created. Hard landings (and sudden stops) may overstress the cage
compression
design limits.
Definitely stay with the -8 (blanked accessory case plate, no pads
for starter or generator)
Continental also made -8 versions of the C-85 and C-90 that formula
one racers still use.
A65s prop start very easily.
65 is a conservative rating. At 2600 rpm it will match any rotax.
Mine used to swing a 74" metal MacCauley and climbed out briskly at
2300.
They were rated at 2300 redline which was an ultra conservative
number. They also sold
a version of the same engine with a few extra oil squirt holes and 4
ring pistons
rated at 80 hp, obviously called the A-80. I used the same ones in
mine.
BB, back working on my Kolb, light snow on the lawn this morning
kfackler(at)ameritech.net Guest
Posted: Sun Apr 15, 2007 5:13 am Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
| Quote: | Kolbs don't perform well with direct drive engines. Rick Neilsen and
Why is that? Understand, I'm not challenging your comment, I'm just curious.
-Ken Fackler
Kolb Mark II / N722KM
Rochester MI
Posted: Sun Apr 15, 2007 5:30 am Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
curious.
| -Ken Fackler
Morning Ken:
I don't know. Probably restricted prop size.
Titus, Alabama |
Posted: Sun Apr 15, 2007 6:58 am Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
Tom,
What is important here is torque delivered to the propeller. Searching the
web, I found the following:
The A-65 delivers 148 ft-lbs at 2,300 rpm and the engine weighs in at 170 lbs.
The Rotax 912 delivers 79 hp and 75.9 ft-lbs at 5,500 rpm and weighs 134
lbs. By interpolation of Rotax data and with the 2.273 gear box, the Rotax
will produce 2,300 propeller rpm and 148 ft-lbs of torque at 5,280 engine
rpm at 84% open throttle.
The A-65 has a 36 pound or less weight disadvantage. Some of this could be
resolved by using a light wood propeller.
More snow!
Jack B. Hart FF004
Winchester, IN
Posted: Sun Apr 15, 2007 7:04 am Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
Yes I have said many times that direct drive engines don't perform well on
Kolbs but I guess I need to amend it a bit. Engines that are designed
correctly for direct drive might do well if they aren't too heavy.
Continental and Lycoming engines are designed to produce their rated power
down in the RPM range where it can swing a large efficient prop without
having the prop tips going supersonic.
I have discussed using the small Lycoming and Continental engines a few
times with Kolb and their opinion was NO they are just way too heavy.
Rick Neilsen
Redrive VW powered MKIIIC
Posted: Sun Apr 15, 2007 7:16 am Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
could be
| More snow!
| Jack B. Hart FF004
Jack:
Numbers are great! But.........they do not always equate to the
"real" world.
Based on flight comparison, that is side by side flying with my mkIII
and John W's Jabiru powered direct drive 80 hp Kolbra, the Kolbra was
really puny, except in cruise flight, and the 912 powered mkIII and
the Jab powered Kolbra were about equal.
Now, side by side performance comparison with John W's new 912ULS
powered Kolbra and my 912ULS powered mkIII. John W blew me away in
take off, climb, and cruise.
Early on there was a Subaru powered mkIII that could barely fly with
the direct drive configuration.
Titus, Alabama |
Posted: Sun Apr 15, 2007 9:14 am Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
At 10:16 AM 4/15/07 -0500, you wrote:
| Quote: | Numbers are great! But.........they do not always equate to the
"real" world.
John and Kolbers,
So what is the real world? The point is if you use a 4,000 foot hard surface
runway why not use a low torque, light weight, high rev'ing engine with a
small propeller? You can get to and from with the same cruise and the same
gph rate.
The point is that if one can run identical propellers at the same setting,
the performance of the A-65 minus the 36 pound weight increase will be equal
to the 912 up to the point of 84% open throttle. The propeller does not
care if it is gear or pulley or direct driven.
One of the great things about this list is that people are flying engines
other than Rotax. This shows the skill of builders and the strength of
Homer Kolbs and Dennis Souder's efforts that Kolbs are not limited to Rotax
engines. What is important is the fact that we safely fly over and under
weight Kolb knock offs with a variety of engines, reduction units, and
propellers. That is what "experimental" is all about.
If Tom can get his A-65 safely mounted, his MkIII should fly very well. Not
everyone wants or can afford a Rotax. This does not mean that Rotax is a
bad engine, it isn't. It just means that viable alternative engines are
available.
Jack B. Hart FF004
Winchester, IN
Posted: Sun Apr 15, 2007 10:28 am Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
engines
of
to Rotax
under
and
| Jack B. Hart FF004
Hi Jack:
I'm sorry. I left the most important part out of my last post, which
turned out to be a comparison between John W and my airplanes. My
intention was not to push Rotax, although I will not hesitate to tell
you how much I like the engine I fly with.
What I wanted to say was Kolbs do not fly well with direct drive
engines. They do much better with engines, not necessarily Rotax,
that are equipped with reduction drives. Kolbs are super STOL type
aircraft. If you power them other than a reduction drive, you take
away from this capability. The first aircraft that comes to mind that
flies with a reduction drive is the old Helio Curior, a super STOL
aircraft. Part of that spetacular package is the powerful engine that
turn a big prop through a reduction drive to slow it down.
Kolbs were not designed to fly off 4,000 ft paved runways. Rather
more at home on air strips like my little strip, Gantt International
Airport, that started off life in the cow pasture on 600 feet of
unimproved rough sod. Kolbs will land on sand bars in the Tallapoosa
River in Alabama or the Sag River in the Arctic North Slope of Alaska.
Kolbs fly well when they are loaded up to their max gross weight.
Some of us even push that a bit and they still fly well. I was not
knocking anyone who was experimenting with their Kolb or other
homebuilt. I have done and still do a lot of experimenting with my
airplane, and airplanes I have built in the past.
I will say that flying with an engine that is not reliable,
underpowered, and barely flying on the edge, is hazardous to ones
health. I for one do not like that kind of flight and would much
rather have an aircraft that is more comfortable to fly and well above
the danger zone.
I know you are terribly interested in low weight and low fuel burn.
I'd love to have the low fuel burn, but get a lot more enjoyment out
of performance than economy.
When I share my experiences, I am also sharing my desires. I think
that is natural for a person to do that. Don't get me wrong. I am
not trying to convince you or anyone else to build, equip, and fly
like me. If you want to, great! Then we can comfortably fly
together.
Take care,
Winds are 23 mph gusting to 33. Not conducive to good flight testing.
Titus, Alabama |
JetPilot
Posted: Sun Apr 15, 2007 11:04 am Post subject: Re: A Continental A-65 on a Kolb MkIII? Why not? |
| jbhart(at)onlyinternet.ne wrote: |
This is not quite true, if he uses a metal prop that was designed to cruise and be efficient at 100 MPH, it might not do very well in a slower cruising Kolb. A wood prop would probably be even worse, and less efficient. 36 pounds is not that much extra, IF IT HOLDS TRUE when all is said and done.
What would worry me is the prop, having lower power with heavy weight will make it a poorly performing airplane. Having lower power, high weight, with an inefficient prop will make the plane almost not worth flying.
Kolb MK-III Xtra, 912-S |
d-m-hague(at)comcast.net Guest
Posted: Sun Apr 15, 2007 11:33 am Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
At 02:27 PM 4/15/2007, John Hauck wrote:
| Quote: | What I wanted to say was Kolbs do not fly well with direct drive
that are equipped with reduction drives...
There's nothing magical about the presence (or absence) of a reduction drive.
If you have two engines of the same horsepower and same weight, but one has
a direct drive prop turning at, say, 2500 rpm, and the other one has a 2:1
reduction with the engine turning 5000 rpm, the performance will be identical.
That said, one way to get more power out of a given engine is to turn it
faster. This was less feasible in the 1930's and 1940's when the A-65, for
example, was designed, but modern metallurgy has come a long way, so we can
cruise nowadays at rpm's that would have been way above redline in an older
engine. This is why a 65hp Rotax engine weighs considerably less than a
65hp Continental. However, turning a small prop fast is less efficient, so
we have reduction drives. If the reduction drive assembly weighs less then
the bare engine's weight difference, you get better performance.
Sign... my Ultrastar sits in my fabric garage, as the rain and winds batter
my half rebuilt trailer...
-Dana
My software never has bugs. It just develops random features.
by0ung(at)brigham.net Guest
Posted: Sun Apr 15, 2007 1:11 pm Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
Gang:
John I think the problems that have been noticed by rick and john w is
direct drive on high revving engines requiring a small diameter prop. The
a65 would be a slow turning engine and could turn a much larger diameter
prop and would work well that way, the big disadvantage would be hp to
weight ratio.
Boyd
Posted: Sun Apr 15, 2007 1:22 pm Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
The
diameter
hp to
| weight ratio.
| Boyd
On a Kolb the prop diameter would be limited.
Agree the VW was designed to turn more rpm. But the Jab is an
aircraft engine from the get go, not a converted auto engine.
Titus, Alabama |
Posted: Sun Apr 15, 2007 2:45 pm Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
The Jabiru engine is a aircraft engine but it runs at a higher RPM than most
aircraft engines. Stuart at Power Fin once commented that they, Jabiru, just
didn't understand props. Aircraft engines need to turn their rated power in
the very low 2000 range to be able to efficiently handle a 70-72 inch prop
which is almost necessary to fly a big Kolb very well. Granted with enough
power you can get the same thrust but then you have more weight and use more
fuel.
Even the big WWII engines (Merlin and some of the big radial engines) used
reduction drives to efficiently power the huge props they used. Big slow
turning props produce much more thrust than a small fast turning prop.
Rick Neilsen
Posted: Sun Apr 15, 2007 4:32 pm Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
I guess we won't know until someone actually does it.
Since it wouldn't be on a type certificated airplane there would be
some weight saving options:
clunky mags replaced with electronic ignition
lighter exhaust system
fuel injection (Lar has a spare ready)
A few advantages: no oil cooler, no filter, no water/radiator.
No hoses to leak except fuel
The A-65 was approved for several diameter props, metal and wood.
I can't see any reason not to use a light composite.
Unless I'm missing something, a Warpdrive prop spun by any engine,
redrive or not,
at 23-2600 rpm should yield the same gittup and go.
Sensenich made the most efficient wood.
Parts are still available but I would have that old crankshaft
magnafluxed.
You may have to enclose the engine to get the right air cooling effect
or try to duplicate the J3 Cub scoopers.
Use oil drilled con rods for the higher RPMs
A-50, A-65, A-75, C-75 (not the same engine folks), C-85 all used the
same stroke crank.
Some tapered, some flanged. -A rare few were hollow nosed for prop
control (erk!)
Replace or remachine the oil pump, they were marginal to start with
Good luck, BB
Posted: Sun Apr 15, 2007 4:38 pm Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
John Hauck wrote:
The
diameter
hp to
| weight ratio.
| Boyd
Can I take a shot at this?
Here's one of the better explanations I've seen:
http://www.geocities.com/vjaqua/
Click on 'Propellers'.
Vance Jaqua was a pretty smart guy & could explain things where non-tech
people could understand tech subjects.
It really is all about prop diameter ('disk loading', or 'mass flow').
The Jab or direct drive Sub turns *the prop* too fast (typically
3000-3400 rpm) at rated power to turn a 6' diameter prop like the Rotax;
it must use a smaller dia prop so its efficiency, at low speed is poorer
than a typical a/c engine or a geared Rotax, engine.
The link above has a chart showing various efficiency curves of hp per
sq ft of prop area for various speeds. If you think about the two
extremes, 160 hp can lift a 2 seat helicopter straight up by having a
25-30 ft diameter 'propeller'(a 160hp C-172 staggers into the air), &
there aren't any low speed a/c using a pure jet, because of the tiny
disk area per hp.
If a geared Rotax and a direct drive Continental have the same HP at the
same *prop* rpm, they will have the same torque at the prop and they can
swing the same diameter/pitch prop. The only performance difference
would be due to difference in weight.
Posted: Sun Apr 15, 2007 6:21 pm Post subject: A Continental A-65 on a Kolb MkIII? Why not? |
At 08:32 PM 4/15/2007, robert bean wrote:
| Quote: | Since it wouldn't be on a type certificated airplane there would be
fuel injection...
Hmmm, there's a thought... cooling could be an issue in a pusher
installation like a Kolb, especially on the ground.
Somehow, though, the idea of a fuel injected, electronic ignition A-65 just
seems wrong...
-Dana
