dcr(at)fdltownhomes.com Guest
Posted: Thu Apr 19, 2007 8:22 am Post subject: Looking for advice |
Guys:
I’m going through the airworthiness inspection by the local FSDO. The guy is coming next Monday at 0900 to complete the inspection and paperwork. He happened by yesterday because he was in the area and had some time. He did most of the inspection and said to put if back together and be ready to run the engine on Monday. He has since called and said I needed an A&P sign off for installing the Sensenich propeller on the Lycoming (certified) engine. He called again and said that because the engine is certified, it would have to be maintained as a certified engine by an A&P and only certified parts or STC ed parts could be installed. I suspect this guy is more airline knowledgeable than experimental. BTW, he is a nice guy. My question is: does anyone know any FAA regs or materials I can gently suggest this guy to reference? Please, ranting and ravings about the FAA won’t help me, just references/suggestions to help educate this guy. I have more to lose if we get into a pissing contest. Thanks in advance. Dan
Bruce(at)glasair.org Guest
Posted: Thu Apr 19, 2007 9:06 am Post subject: Looking for advice |
The easy solution, if you don't mind a 40 hour test period, is to tell him it's an experimental engine/prop combo and to consider it as such.
If you really want a 25 hour test period, have both the TC's for the prop and engine on hand. Do an AD search on your engine. Note the compliance of each AD. Have an A/P sign off your prop install, and ignore what he said about maintenance, as long as he doesn't try to screw you with a restrictive AW cert. You may still be in a pissing contest.
Next time use an ABDER, they're much more understanding and knowledgeable.
You might also call the EAA and ask the tech support folks for help.
Bruce
www.glasair.org
Posted: Thu Apr 19, 2007 10:12 am Post subject: Looking for advice |
Dan,
The closer I read your message, the more I think you may have a real problem. It's obvious that someone else at the FSDO is feeding this guy worthless and wrong information about experimentals, otherwise he would of told you about the A&P, certified parts, and A&P maitenance requirement (all wrong bye the way) on the first visit. I think he's going to ask/tell you to remove the engine data plate if you want an experimental engine. Don't remove it. Call the EAA, they have some good stuff on their website, if you're a member. They also have an ABDER lookup. See if you can get one and then cancell the FSDO guy. Otherwise I fear you'll have to go over his head.
Bruce
carlosh(at)sec-engr.com Guest
Bruce Gray wrote:
[quote] The easy solution, if you don't mind a 40 hour test period, is to tell
contest.
Bruce
www.glasair.org
Posted: Thu Apr 19, 2007 10:14 am Post subject: Looking for advice |
Meant to type ABDER not ADBER. Sorry for the fat finger typo!
Carlos
Carlos Hernandez <carlosh(at)sec-engr.com>
Structural Engineers, LLC
2963 W. Elliot Rd. - Suite 3
Chandler, AZ 85224
Phone: 480.968.8600
Fax: 480.968.8608
www.sec-engr.com
CONFIDENTIALITY NOTICE
The information in this email may be confidential and/or privileged.
This email is intended to be reviewed by only the individual or
organization named above. If you are not the intended recipient or
an authorized representative of the intended recipient, you are hereby
notified that any review, dissemination or copyingof this email and
its attachments, if any, or the information contained herein is
prohibited. If you havereceived this email in error, please
immediately notify the sender by return email and delete this email
from your system.
T.gummo(at)verizon.net Guest
Posted: Thu Apr 19, 2007 1:15 pm Post subject: Looking for advice |
Just get the paperwork signed, then follow the "correct rules", ie, as an experimental, you can do ALL the work on it, engine and prop included. While it would be nice if you could educate him, it is a waste of time.
My DAR gave me the forty hour fly off time period, "So I could work on the engine and prop."
Tom Gummo
Apple Valley, CA
Harmon Rocket-II
http://mysite.verizon.net/t.gummo/index.html
jpl(at)showpage.org Guest
Posted: Thu Apr 19, 2007 2:24 pm Post subject: Looking for advice |
I could be wrong on this, but I *think* what's going on is that to maintain the certified status of engine and prop, the FAA guy is right.
As I remember, you can decertify the Lycoming by pulling the data plate. You *might* be able to decertify it in the engine logs, I don't know.
But the engine remains certified only so long as it follows all the steps a certified engine must follow. This means an A&P involvement, including what props can be installed on it and how said props are installed.
That's how I understand things, but I'm basing my opinion off memory from reading the books on all this before I even started building a long long LONG time ago. I could easily be completely wrong. Maybe someone on the list can confirm or deny what I've said.
-Joe
On Apr 19, 2007, at 4:10 PM, Tom Gummo wrote:
[quote]Just get the paperwork signed, then follow the "correct rules", ie, as an experimental, you can do ALL the work on it, engine and prop included. While it would be nice if you could educate him, it is a waste of time.
Tom GummoApple Valley, CAHarmon Rocket-II
[quote]---
Posted: Thu Apr 19, 2007 5:26 pm Post subject: Looking for advice |
Amature Built Designated Engineering Represenative, he can inspect,
sign-off, and issue an AW cert just like the FSDO.
Bruce
www.glasair.org
rvbuilder(at)sausen.net Guest
Posted: Thu Apr 19, 2007 6:41 pm Post subject: Looking for advice |
Bruce,
I'm guessing you are actually talking about an AB DAR. Armature Built Designated Airworthiness Representative. Or at least I have never heard of an ABDER. More about the program here (EAA membership required)....
http://members.eaa.org/home/govt/help/ab_dar.asp
Michael
Posted: Thu Apr 19, 2007 7:46 pm Post subject: Looking for advice |
Yes, I was. I'm getting to old for all these acronyms. Heck, I don't even
have an EFIS and fly a plastic airplane.
Bruce
www.glasair.org
Posted: Thu Apr 19, 2007 9:14 pm Post subject: Looking for advice |
Well, I didn't stay at a Holiday Inn last night but ..
This is my opinion and I read some of the book before I ate it.
But if it is a homebuilt aircraft, you may install TSO equipment as well as non-TSO equipment. So if the engine loses it "certification" because you work on it so be it and you don't have to remove the Data Plate. As for the engine and prop, you as the builder or even the owner of a experimental aircraft MAY do ANY and ALL maintenance that you feel qualified to do. For example, as long as the engine is in an experimental aircraft it doesn't have to comply with an ADs. Is that smart, most likely not. Once the inspector leaves, he will have NO control of what you do, just make sure your insurance company is OK with the level of maintenance you plan to do.
Once you remove the engine and or prop and want to sell them to someone as a certified engine, all the ADs have to be complied with, paperwork completed, and maybe even be inspected by an A&P. Until then, go fly and have a good time. It is much easier to get forgiveness than permission.
BTW, other than replace spark plugs, change oil and replace the oil filter, I get an A&P to look over my shoulder while I do the work and definitely have him inspect all the work and sign off the log books. I may hate the dumb rules of the FAA but I am not really stupid (I value my life and any pax I carry).
Tom Gummo
Apple Valley, CA
Harmon Rocket-II
309 hours and loving it a lot. I do work on my engine and prop.
cjensen(at)dts9000.com Guest
Posted: Fri Apr 20, 2007 4:53 am Post subject: Looking for advice |
even have an EFIS and fly a plastic airplane.
Bruce
www.glasair.org
Geez, Bruce, plastic plane and no EFIS? Maybe you have trouble with
acronyms, but here's a word you'll be familiar with--- LUDDITE!!!!!
Chuck Jensen
Posted: Fri Apr 20, 2007 5:11 am Post subject: Looking for advice |
I'll admit that when I went to Aero Engineering school we used slide rules
instead of those new fangled electronic engineering calculators, but we
really saved money on batteries. I still have mine along with the belt
holster for it somewhere. Talk about geekie!
No, I'm not a Luddite but I do belong to the anti-EFIS crowd.
Bruce
www.glasair.org
lifeofreiley2003(at)yahoo Guest
jhstarn(at)verizon.net Guest
Posted: Fri Apr 20, 2007 7:57 pm Post subject: Looking for advice |
As the first EWO uttered when told he was going to be strapped in the back seat of an F-100 to become a target Wild Weasel....YGBSM.
KABONG (Do a search, it's there). Do Not Archive
Bruce
www.glasair.org
Chuck Jensen
