jack(at)comconn.com Guest
Posted: Sun Apr 22, 2007 11:26 am Post subject: 582 Oil leak? |
I hadn't flown my fox in a bit, and on visiting the hangar,
noted a bit of oil under the plane. Something new?
It appears as though the 2 cycle oil is making it through the
rear carb, soaking the air filter, and dripping on through.
This is a gray head, ~160 hours. No sign of oil in the coolant,
and the oil pump bottle is right on the mark. It's not a lot of oil,
maybe a 1/2 oz. or so, but I'd rather be safe than sorry.
It's been a month since I flew her, and that's the longest it's
ever been.. has anyone seen this before?
-Jack
thesupe(at)hotmail.com Guest
Posted: Sun Apr 22, 2007 5:17 pm Post subject: 582 Oil leak? |
A friend of mine has a 582 on a powered parachute that did the same thing.
It was a rotary valve shaft seal leaking. Jim
Quote: | From: Jack L Bell <jack(at)comconn.com>
Subject: 582 Oil leak?
Date: Sun, 22 Apr 2007 14:24:34 -0500 (CDT)
-Jack
MSN is giving away a trip to Vegas to see Elton John. Enter to win today.
http://msnconcertcontest.com?icid-nceltontagline
Guy Buchanan
Posted: Sun Apr 22, 2007 5:38 pm Post subject: 582 Oil leak? |
At 12:24 PM 4/22/2007, you wrote:
Quote: | It's been a month since I flew her, and that's the longest it's
I have some oil leaking from the carb side as well. I'm fairly
certain it's the injection oil, as the rotary oil looks good. I'm
told there's a check valve in the oil pump that can get particulates
in it and thereafter pass oil under gravity feed. I'm trying to confirm.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
davef(at)cfisher.com Guest
Posted: Mon Apr 23, 2007 2:45 am Post subject: 582 Oil leak? |
Jim ,
I run Bombardier Mineral oil in injection and it is amber coloured.
In RV bottle I use Castrol super 2 stroke which is blue so I can see the
level easier.
Both of these oils are API-TC rated which is what is reco'd for 582s. Don't
be using outboard motor oil.
Maybe try changing one oil so you can see which one it is
Dave
Fox5flyer Guest
Posted: Mon Apr 23, 2007 3:53 am Post subject: 582 Oil leak? |
As I recall, Pennzoil Outboard Premium Air-cooled is the recommended oil for
the Rotax 582.
Deke
level easier.
Don't
xfire
Posted: Mon Apr 23, 2007 4:16 am Post subject: Re: 582 Oil leak? |
[quote="Fox5flyer"]As I recall, Pennzoil Outboard Premium Air-cooled is the recommended oil for
the Rotax 582.
Deke
Aircooled outboard ?? Been alot of years since I have seen one. I think the outboard and the aircooled are two different oils.
Description: |
Filesize: |
157.9 KB |
Viewed: |
465 Time(s) |
Posted: Mon Apr 23, 2007 4:18 am Post subject: 582 Oil leak? |
Deke,
Pennzoil for Aircooled yes with a API-TC rating.
Outboard oil will have a TW3 or TC W3 rating and it API-TC is not listed
then it is not the same.
Totally different operating conditions -- ie outboards run a contanst
supply of 80F or cooler water. just to name one .
582s in Aircraft need a better oil
Dave
Float Flyr
Posted: Mon Apr 23, 2007 3:37 pm Post subject: 582 Oil leak? |
Dave:
I thought it was recommended to use the same oil in the RV as in the
injector pump. You are saying it really doesn't matter that much as long as
both oils are API-TC rated.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dafox(at)ckt.net Guest
Posted: Mon Apr 23, 2007 6:40 pm Post subject: 582 Oil leak? |
Hello Jack,
When I had my 582 in my kitfox before my 912 UL, the very same
thing happen'd. Oil leak coming fom somewhere, traced it to the Air filter,
and it was saturated, Rotory valve tank still full, not coming from there, and
i remembered that when installing a new air filter, you don't have to pre-oil
as it will get lubricated from the Carburators. I suspose it accumalates after
each shut down from unburned oil and gas mixture. It happernd twice in
four years to me. I wouldn't worry about it.
David
