LloydDR(at)wernerco.com Guest
Posted: Mon Apr 23, 2007 3:53 pm Post subject: RV Advice, one leg flyer |
One thing to keep in mind is that the parking brake by Matco that is
commonly used on RV's is for holding pressure that already has been
applied, IE it is an open and close valve not a pressure piston for
stopping, so you would have to use something to apply the pressure.
Dan
N289DT
RV10E
n616tb(at)btsapps.com Guest
Posted: Mon Apr 23, 2007 4:07 pm Post subject: RV Advice, one leg flyer |
Easy enough with the two lever hand controls.
[quote] --
Posted: Mon Apr 23, 2007 4:36 pm Post subject: RV Advice, one leg flyer |
I agree, just that you could not use the Matco valve to accomplish it,
because it is an open/close valve to hold the pressure that already has
been applied through the pedals.
Dan
jsflyrv(at)verizon.net Guest
Posted: Mon Apr 23, 2007 4:49 pm Post subject: RV Advice, one leg flyer |
I am going to do a flight review this week for a local pilot that has
hand controls in his RV-6, Some of you may have met Carl Hays
or read the articles about him and how he designed the control system
for his RV-6. He is unable to use his legs at all.It has two control bars
that control rudder and brakes pushing both sticks forward controls
brakes, pushing left stick forward is left rudders etc. This operation
is all
done with his right hand.Technically this qualifies for a dual control
system as he does have a joystick installed on the right side and the
rudder brake bars are in the center of the airplane so if need I can
control the airplane.
Jerry
carlbell(at)gforcecable.c Guest
Posted: Mon Apr 23, 2007 4:54 pm Post subject: RV Advice, one leg flyer |
Thanks Bob,
Below the knee you can do toe brakes, above the knee just isn't consistent
or powerful enough. I have been given some really good ideas and advice and
I think I have solved most of the issues for a few minor modifications to
make it work safely with a push-pull rudder control and a neat hand brake
set up from the dune buggy world, but I would still love to find a guy with
an AK and a nose or tail dragger RV and see what they are flying. Regards
Carl
Posted: Mon Apr 23, 2007 5:01 pm Post subject: RV Advice, one leg flyer |
Darrell,
Peg leg sounds like the guy I'm looking for, does he have an email or can
you get his phone number? BTW they call me stump! Where is Taylor Airport?
Thanks Carl
Posted: Mon Apr 23, 2007 5:14 pm Post subject: RV Advice, one leg flyer |
Dan,
I don't know what they use in the Cherokees, but you can pull on it and it
loads both mains, then if you push the button it locks the brake in the
pulled position and acts as a parking brake. If need be I'll get one of
them from Piper. I am not familiar with the Matco, but I will check it out
and see what is available. Thanks for the heads up. Carl
lifeofreiley2003(at)yahoo Guest
Posted: Mon Apr 23, 2007 5:42 pm Post subject: RV Advice, one leg flyer |
Carl,
I will get you two guys together. We can take some
pics and he has the catalog which shows the product he
used... Very nice set-up for sure!
Darrell
Darrell,
Thanks Carl
Posted: Mon Apr 23, 2007 5:45 pm Post subject: RV Advice, one leg flyer |
I just emailed Jim "Pegleg", should hear something by
tomorrow. I have a key to his hanger and if he wants
me to, I will take some pics for you.
Darrell
Darrell,
Thanks Carl
Posted: Mon Apr 23, 2007 5:54 pm Post subject: RV Advice, one leg flyer |
Darrell, where is Taylor ? Thx Carl
Posted: Mon Apr 23, 2007 5:57 pm Post subject: RV Advice, one leg flyer |
I previously owned a Cherokee 140, and it had the brake you are talking
about. The one from Matco is what most Rv'ers use, and it only holds the
pressure after you apply it from the pedals. If you could modify the
Cherokee, or use the sand rail differential braking I think that would
be the best.
My 10 should be up and flying in the next month or so, and shortly there
after I will gladly come down and give you a demo ride, so you can see
the 10 with an Eggenfellner in action.
I am only a short hope away up in PA.
Dan Lloyd
N289DT RV10E
Posted: Mon Apr 23, 2007 6:23 pm Post subject: RV Advice, one leg flyer |
Taylor Texas Airport just outside of Round Rock, Texas
East of town...
Darrell
Posted: Mon Apr 23, 2007 7:01 pm Post subject: RV Advice, one leg flyer |
Dan,
Well I would love to see and fly in the 10 and flying it is a good way to
wring out the little bugs. We have a guest room and hopefully I'll have a
good start on the 7A. Regards Carl
deruiteraircraftservices( Guest
Posted: Mon Apr 23, 2007 11:12 pm Post subject: RV Advice, one leg flyer |
| Quote: | For differential braking, there have been aircraft that were built with a
selector valve of sorts incorporated into the rudder control system and
one
separate brake master cylinder.
the De Havilland DH 104 Dove/Devon has such a system. The brakes however are
pneumatic. Give full rudder in the direction you wish to go and push the
lever on the yoke, it's quite weird at the start as your aircraft sounds a
bit like a 18 wheeler when you release the brakes!
Incidently the gear and flaps also operate on pneumatics, the only hydraulic
system operates the windscreen wipers!
Posted: Tue Apr 24, 2007 6:07 am Post subject: RV Advice, one leg flyer |
Hi Carl-
Sorry for the 'late' reply; I get the digest version of the list once a
day. Makes things less dynamic but keeps my ISP from freaking out over the
volume of traffic that sometimes occurs.
| Quote: | If there isn't room
going toward the firewall, I'll just put the pulley toward the spar.
I believe that would put you in the position of 'pushing' a cable.
| Quote: | Then
I'm thinking I will omit the toe brakes on my side and weld a tube at
midpoint on the pedal for pushing and a hoop over the top of my foot for
pulling (or maybe the bicycle clip) and 2 hand brakes for stopping by using
them together or independently for differential braking. Do you think this
could do the trick?
Well, it certainly could, but the loop will need to have enough slack to be
able to insert your foot. This same slack will create slop in your control
system. Next, your pelvis is blocked from movement by the seat back when
pushing, but when pulling I suspect you hip will twist to some extent.
This will introduce more slop into the system. Another point is that you
are very much stronger pushing that pulling with your foot. This
differential will cause you some issues. Of course, when pulling, you will
be applying force through a couple additional pulleys. This will introduce
a small amount of additional system friction, or drag, into the weak side
operation. The last item is human factors. You already know how to push
to turn. If your new system requires you to pull to turn, there may well
come a time when things start happening quickly, the law of Primacy kicks
in, and you have a problem. Were it me, I'd really pursue the bike pedal
and push/push option over the push/pull option.
Two hand brakes could work well indeed, but I'd recommend having them
configured such that it'd be very unlikely to accidentally slip and 'drop'
one at a critical time.
| Quote: | Most are saying I should go with a nose dragger and
preferably a 9A which almost lands itself.
How (unfortunately) predictable. I wouldn't listen to the nay sayers.
What is the real issue? Straight and level is straight and level. You
want acro? the 9 is out. All these planes fly much the same until the
wheels touch. The TD's are TD's, but they are on the civil end of the TD
spectrum. Recall all the responses from folks who know of -6's configured
for one or NO legs. I think most would admit that if there is any
difference in ground handling characteristics in RV's, the 6's are at the
sportier end. Get the plane you want, and master whatever you need to
master.
| Quote: | I hate to give up and occasional
roll or loop, but I really need the plane for X country to visit my kids
scattered about the US and of course I love flying and building things
(RC).
7's and 8's are faster than 9's, even upside down.
| Quote: | I will draw this up and send it to Van with all the Caveats' just to make
sure that tying the pedals together won't create a problem with flutter or
something.
What you're proposing won't have any more effect on flutter characteristics
than 2 feet on the pedals. It would be interesting to see what the legal
dept has to say about your ideas, though. Historically the company's
public position has been that mods are highly discouraged. Personally, I'd
seek out independent critique of my plans. There's an awful lot of
credentialed expertise on this list, mostly lurking. As is generally the
case though, those of us who are free with advice are charging precisely
what it's worth!
| Quote: | Any thoughts on nose wheel versus tail wheel?
No. It was always a given for me. ; - ) Since (by definition) it's the
things we don't contemplate that surprise us, I suppose I'd consider ground
handling, like getting the plane in and out of the hangar. Does your
prosthesis impact your ability to drag a plane around? What about cockpit
entry and loading? The TD's sit nose up, and the ND's sit pretty level.
It's a higher step up to the ND's wing from the ground. Things like that
might have a significant impact on the ultimate enjoyment of your creation.
| Quote: | Thanks again for
your advice.
My pleasure. Despite the occasional furball here on the list, we're all
here to learn and share what we have learned.
glen matejcek
aerobubba(at)earthlink.net
Posted: Tue Apr 24, 2007 6:27 pm Post subject: RV Advice, one leg flyer |
I want to thank everyone for there help on this topic, it has been
invaluable. The list ("you all" is how we say it in the south) has provided
me with some great information including:
1) Picture of how two amputees accomplish flying with one leg,
including a castor on a shoe to dual hand brakes and a push-pull rudder, and
an article about a double amputee doing it with some special hardware flying
an RV4.
2) It gave me the sense that I can pick the plane I want and find a
way to modify it to make it work safely.
3) A belief in a great community of builders that will readily share
there experiences
As an outcome I will go fly with a CFI in a tail dragger and a nose dragger
and see which one works for my handicap and order a kit. I know it will be
a 7, with a Lycoming type engine, so I'm almost there and can order some
more tools and the tail kit.
Thanks again, Carl
