		lgold(at)quantum-associat Guest
				 Posted: Thu Apr 26, 2007 9:51 pm    Post subject: Maximum Continuous RPM for a Rotax 503 |
				Hi,
  I am planning to  join a group of  dedicated (i.e., crazy) UL/LSA flyers who want to fly over  8000 foot mountains going from California to Arizona in planes with 503 and  582 engines. Since I will need to climb as fast as possible for 20-30  minutes at a time, I would like to know the maximum sustained RPM that my 503  will tolerate.
  I know that the  Rotax manual states that you can run at 6500 all day but should not  run at the maximum allowed RPM of 6800 for over 5-minutes.  My problem  is that the maximum RPM on my my Challenger II long-wing aircraft is only  6200 due to its prop pitch. Does this mean that the maximum sustained RPM  also goes down? If so, is this decrease in sustained RPM in  proportion to the max speed (e.g., 6200/6800x6200 resulting in a max  sustained RPM of 5926)?
  Thanks for the  help,
  Les
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Thom Riddle
				 Posted: Fri Apr 27, 2007 3:59 am    Post subject: Maximum Continuous RPM for a Rotax 503 |
				Lee,
 No. The RPM limitations that Rotax put on their engines do not care
 what prop you use and they do not change based on what prop you are
 using. They are absolute numbers that refer to limits that the engine
 components are designed for.
   It means your engine can develop only 6200 rpm (assuming this is at
 wide open throttle in straight and level flight) because there is a bit
 too much load on it from the high pitch propellor. This is good for
 economical low density altitude cruise flight as long as your EGTs are
 in normal range. But not good for high altitude operation or for
 extended climb perhormance. At 6200 RPM  your engine is not developing
 its full power and the power it does produce will drop as you climb
 into thinner air and you will probably see the max rpm drop even
 further as you climb. If your engine is turning 6200 rpm at best climb
 speed that is another story and the pitch is probably about right. For
 high altitude flight, if you have a ground adjustable prop, it would be
 good to set the pitch to get close to 6700-6800(max) rpm in straight
 and level flight at low altitudes.
 Thom in Buffalo
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
