a.s.elliott(at)cox.net Guest
Posted: Tue May 01, 2007 5:25 pm Post subject: Brake cylinder locations |
Gang:
Because of the way my gun-drilled Grove gear is set up, it would be a much cleaner installation if the right brake line came from the co-pilot side right pedal and the left brake line from the pilot side left pedal.
Does anyone see anything wrong with putting the master cylinders on the inboard pedals and the slave cylinders on the outboard pedals? Each pilot position would have one master and one slave cylinder, instead of putting the masters on one side and the slaves on the other.
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD/QB, Corvair, building...
Gig Giacona
Posted: Wed May 02, 2007 5:39 am Post subject: Re: Brake cylinder locations |
Seems like it could result in some uneven braking.
601XL Under Construction
N601RT
Joined: 25 Feb 2006 Posts: 31 Location: Hillsboro, Oregon
Posted: Thu May 03, 2007 6:44 am Post subject: Re: Brake cylinder locations |
Andy,
Brake cylinders with the fluid reserve on the inside rudder pedals feeding brake cylinders without the fluid reserve on the outside rudder pedals has been working fine for the four years N601RT has been flying. Since both master cylinders have the same bore, the pressure generated from the cylinder is the same with or without the built in fluid reserve. This configuration allows more direct and shorter brake line routing.
Roy
N601RT: CH601HDS, nose gear, Rotax 912ULS, All electric, IFR equipped, 710hrs, 837 landings
rickpitcher
Posted: Thu May 03, 2007 7:50 am Post subject: Re: Brake cylinder locations |
[quote="a.s.elliott(at)cox.net"]Gang:
N601GE (reserved)
If you haven't already bought the master cylinders with the built-in reservoir (MCMC-5?), you might want to consider using a single remote reservoir and installing the "slave cylinders" (MCMC-4?) on all 4 pedals. It takes a couple more pieces of plastic tubing, but it's a helluva lot easier to check and fill.
Besides, that brushed aluminum Matco remote reservoir filled with bright red hydraulic fluid looks really cool on the firewall!
http://www.matcomfg.com/catalog/index.php?file=catalog&prod_pcategory=66040&clist=0,66040&uid=2192&gpoid=
Rick
601HD
carlossa52(at)gmail.com Guest
Posted: Thu May 03, 2007 7:51 am Post subject: Brake cylinder locations |
Sounds like a good idea. Have you verified with ZAC?
Carlos
CH601-HD, plans
Montreal, Canada
________________________________________
N601GE (reserved)
planecrazydld(at)yahoo.co Guest
Posted: Thu May 03, 2007 11:37 am Post subject: Brake cylinder locations |
I can only see one possible issue with the proposed plan. Unless someone flies in the right seat and uses the brakes with some frequency I can see that teh brake refilled from the master on the passenger's side might get soft.
Carlos Sa <carlossa52(at)gmail.com> wrote:
[quote][b]Sounds like a good idea. Have you verified with ZAC?
Carlos
CH601-HD, plans
Montreal, Canada
Does anyone see anything wrong with putting the master cylinders on the inboard pedals and the slave cylinders on the outboard pedals? Each pilot position would have one master and one slave cylinder, instead of putting the masters on one side and the Ahhh...imagining that irresistible "new car" smell?
Check out [url=http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-]new cars at Yahoo! Autos.[/url] [quote][b]
