		docyukon(at)ptcnet.net Guest
				 Posted: Thu May 03, 2007 7:33 am    Post subject: 912f gearbox question |
				Can anyone tell me if a 912f gearbox with a gear  ratio of  2.27-1  has a  22mm wide gearset or the wider 27mm  gearset. I do not have the gearbox part# or serial#  close at  hand.     Thanks       Bill
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Thom Riddle
				 Posted: Fri May 04, 2007 3:39 am    Post subject: 912f gearbox question |
				I believe that will depend upon whether or not you have the slipper
 clutch installed. If you have not modified it since new, you should be
 able to contact Rotax distributor with the serial number to see what
 was originally installed in your gearbox. The only other way I know to
 be sure is to remove the gearbox and measure the gear sets.
 Thom in Buffalo
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
