swayze(at)europa.com Guest
Posted: Fri May 04, 2007 10:31 pm Post subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
Hi Garey,
I was going through some old emails and came across this posting of
yours. I have a question.
Do you still have this information avaiable? Do you, by any chance,
have an electronic copy that can be emailed instead of a hard copy?
Finally, has your price changed any?
thanks,
Bruce Swayze
RV-7A waiting on wing kit
At 03:26 PM 7/16/2005, you wrote:
> This Information comes from my own research which I
did for
> my RV-8A, which I am building. Information applies
to both Aluminum and Composite aircraft. This is the
3th printing.
> SAVE YOURSELF hundreds of hours of research time and
> building time, by using the comprehensive
> "Guide to Painting & Corrosion Control of Aluminum
> and
> Composite Aircraft"
> This book took over 600+ hours of research time by
> me,
> a fussy RV-8A Builder. Contains 69 pages of the
> latest, practical information - summarized and
> gathered from MIL Standards, Paint Shops, Builders
> like you (what worked or didn't), Airframe Mfgs,
> etc.
> Covers products from PP&G, Dupont, Sherwin W'ms,
> Sterling, Poly Fiber, Deft, Randolph Paints, PRC De
> Soto, US Paints, Aircraft Finishing Systems, 3M,
> etc.
> Some of the Topics covered in the 30 Sections are:
> * Aircraft Paints vs Auto Paints and Other
> Considerations
> * Corrosion Control
> * Spray Guns - selecting, adjusting, using
> and painting problems
> * Brushes / Rollers used with Primers &
> Paints
> * Prep Methods for Painting - Fiberglass,
> Steel and Aluminum
> * Epoxy Primers for Aluminum - MIL &
> Commercial, Solvent & Water Reducible
> * Primers for Fiberglass & Steel
> * Wash Primers & Self Etching Primers
> * Other Primers - Zinc Chromate,Zinc Oxide,
> Enamel
> * Paint Types: MIL & Non MIL Polyurethanes
> Enamel Types
> Acrylics - Lacquers & Enamels
> * Acid Etch / Conversion Coatings (Alodine)
> * Selecting a Paint Shop
> * 3M Cleaning Pads, Liquid Cleaner
> compatibility
> * Paint Booths and their Construction
> * References - MIL Standards & Tech Orders
> * Directory of Aircraft Paint Mfgs, Distrib-
> utors, etc. E-Mail addresses, phone
> numbers, Application Notes
> YOUR AIRPLANE is judged by it's Paint Job and it is
> costly too, so have the latest "Information" in order
> to make good decisions. Contains plenty of "Do's" and
> "Don'ts" that save you time, money and frustration.
> Send a check for $26 to (includes Postage within the
> US) to:
> Garey Wittich RV-8A Builder
> 58 Village Parkway
> Santa Monica, CA. 90405
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
