		Gilles.Thesee(at)ac-greno Guest
				 Posted: Sat May 05, 2007 12:06 pm    Post subject: Coolant flammability tests |
				Hi all,
 Rotax drivers may be interested in the flammability tests conducted by
 Europa builders Ron Parigoris and Wayne Gutschow on engine coolants and
 fluids.
 http://contrails.free.fr/engine_burn_baby_burn_en.php
 Gilles Thesee
 Grenoble, France
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Roger Lee
				 Posted: Sat May 05, 2007 2:23 pm    Post subject: Re: Coolant flammability tests |
				Hi Gilles,
 How are you?
 If I remember right the big issue was Evans coolant?
 We discussed this a while back. Bottom line is how high the temps have to get to cause it to burn and if it is in any type of fire it is a very limited quanity. Why worry if there is a fire as you have fuel and oil, all the rubber and plastic in the engine that is far worse and burns at lower temps. When you really compare Evans to the other things in the engine compartment that burn it's just at the bottom of the list and you have much bigger problems to worry about if there is a fire. Some things look good by themselves or on paper, but when you include the whole picture it's not worth worrying about. I'm a Fireman and HazMat Tech. by trade for the last 28 years. I have been to, God only knows how many car fires and I have been to aircraft fires. Knowing what is in the general area to burn and at what temps. puts Evans Coolant at the bottom of my list. The only thing hot enoug in our engine is the exhaust manifold. They are worried about Evans, I think they should be more worried about fuel. It will lite off at a much lower temp. and it will burn up to 2000F. All the rubber parts and some plastic will lite off if it falls against the exhaust manifold. There is a lot more of this stuff to start a fire. There is very little coolant in your engine. Tell them to test all the other components in the engine compartment. You may not want to fly then. Human nature usually only carries things out to a certain point and then we quit looking past that point. Follow it past the Evans to everything else and then this single point they make isn't as big. The bottom line is any engine fire reguardless of the cause can be deadly. Good maint. scheduling and checking your equipment can go a long way to saving your hide. Don't be cheap is what I tell people when it coes to parts and maint. . The part may look good on the outside, but it's waiting to bite you on the backside if you neglect it or don't replace it.
 I don't mean to upset anyone in any way, sound like a broken record or a lecturer, but if all I had to worry about was Evans then my life is simple. I have used Evans now for 4 years and have been happy with its performance.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
		rampil
		Roger Lee
				 Posted: Sat May 05, 2007 5:50 pm    Post subject: Re: Coolant flammability tests |
				Hi Rampil,
 No actually I use it because the regualr 50/50 can get into hot spots or poor circulation areas within the heads and get too hot and vaporize. This causes a vapor space and causes overheating in or around the head. This softens the metal and causes leaks and warpping. Regular 50/50 boils around 275F or so, and Evans boils at 375F. This also helps the engine from puking coolant all over the ground when you are stuck on the tarmac for a while idling or long taxi's and poor air movement for cooling. The articles written by several authors say you should use Evans unless you are having an engine over heating problem. Evans can make you run about 30F warmer, but if it doesn't over heat, so what. If I was constantly over heating I might drop back to 50/50. Evans will not leave deposits in the system or corrode parts because it doesn't have any water. You should use it unless you are always over heating to drop the temps. 30F, but you are a head of the game if you do not over heat and you use Evans.
Tucson, Az.
Cell 520-349-7056 |
				 Posted: Sat May 05, 2007 11:50 pm    Post subject: Coolant flammability tests |
				Roger Lee a écrit :
  Hi Rampil,
  No actually I use it because the regualr 50/50 can get into hot spots or poor circulation areas within the heads and get too hot and vaporize. This causes a vapor space and causes overheating in or around the head. This softens the metal and causes leaks and warpping. Regular 50/50 boils around 275F or so, and Evans boils at 375F. This also helps the engine from puking coolant all over the ground when you are stuck on the tarmac for a while idling or long taxi's and poor air movement for cooling. The articles written by several authors say you should use Evans unless you are having an engine over heating problem. Evans can make you run about 30F warmer, but if it doesn't over heat, so what. If I was constantly over heating I might drop back to 50/50. Evans will not leave deposits in the system or corrode parts because it doesn't have any water. You should use it unless you are always over heating to drop the temps. 30F, but you are a head of the game if you do not over heat !
   and you use Evans.
 Roger and all,
 You are right, as long as your are not overheating, using pure propylene
 glycol like Evan's NPG+  won't harm your engine.
 What is surprisingly not well known by magazine editors, is that
 nucleate boiling is a normal phenomenon in any liquid cooled piston
 engine. It helps reject tremendous amounts of heat from  the engine.
 Phase change from liquid to vapor absorbs many times more heat than just
 raising the coolant temperature another degree, and helps convection.
 This was clearly established by NACA researchers on liquid cooling
 during the '40s.
 See Contrails
 http://contrails.free.fr/engine_liquide_refroid.php (only in French at
 the moment)
 Scroll down to the NACA reports.
 Also some gneral info at :
 http://www.tpub.com/content/doe/h1012v2/css/h1012v2_62.htm
 Please note that we are speaking of nucleate boiling, and not of  the
 "boiling crisis", which is the transition from nucleate to "film
 boiling". It is film boiling which tends to isolate the hot walls from
 the coolant. It can happen
 So the "no boil" argument put forth by propylene glycol sellers is not
 so valid.
 Also it is not water that leaves deposits, but wrongly formulated
 coolants with no inhibitors.
 Even the Evans (no water) contains a corrosion inhibitor.
 Best regards,
 Gilles
				 Posted: Sat May 05, 2007 11:55 pm    Post subject: Coolant flammability tests |
				Roger Lee a écrit :
  	  | Quote: | 	 		   How are you?
  We discussed this a while back. Bottom line is how high the temps have to get to cause it to burn and if it is in any type of fire it is a very limited quanity. Why worry if there is a fire as you have fuel and oil, all the rubber and plastic in the engine that is far worse and burns at lower temps. When you really compare Evans to the other things in the engine compartment that burn it's just at the bottom of the list and you have much bigger problems to worry about if there is a fire. Some things look good by themselves or on paper, but when you include the whole picture it's not worth worrying about. I'm a Fireman and HazMat Tech. by trade for the last 28 years. I have been to, God only knows how many car fires and I have been to aircraft fires. Knowing what is in the general area to burn and at what temps. puts Evans Coolant at the bottom of my list. The only thing hot enoug in our engine is the exhaust manifold. They are worried about Evans, I think they should be more !
 Hi Roger,
 What is interesting in Ron's report is, he made experiments.
 Of course many engine fluids burn, especially oil and fuel. But Ron and
 Wayne's findings help us sorting out the coolant flammability issue by
 providing hard facts.
 Best regards,
 Gilles
		Roger Lee
				 Posted: Sun May 06, 2007 6:13 am    Post subject: Re: Coolant flammability tests |
				Hi Gilles,
 I agree that when a liquid changes phase from the let's say water or coolant to vapor it has absorbed more heat, momentarily. The problem with that is we can't circulate vapor and it can and does leave dead spots in the head. Now we loose the cooling in that spot. Rotax heads are cooled by the coolant and the cylinders are air cooled. Get a dead vapor spot in the head and the temp. probe may or may not pick up the heat problem because the spot is isolated and we don't usually monitor all 4 head temps. Rotax has pictures to demonstrate this problem. Engine MFG's. try real hard not to have vapor areas in their engines.
Tucson, Az.
Cell 520-349-7056 |
				 Posted: Sun May 06, 2007 11:32 am    Post subject: Coolant flammability tests |
				Hi Roger,
 Thank you for responding.
  	  | Quote: | 	 		   The problem with that is we can't circulate vapor and it can and does leave dead spots in the head.
 Nucleate ebullition does help liquid cooling and is present in the
 majority of internal combustion engines when at working temperatures.
 It is this phenomenon which provides the near constant temps.
 Tiny bubbles are created at every hot spot in the engine, cool the area,
 then are entrained in the general coolant flow. As soon as they leave
 the hot wall, they collapse, due to the coolant temp being lower than
 the overheating spots.
 When the coolant flow slows, the proportion of nucleate ebullition
 rises, helping cooling in adverse conditions.
  	  | Quote: | 	 		    Now we loose the cooling in that spot.
 If and when the heat flow through the engine wall exceeds the cooling
 capacity of nucleate ebullition, then yes "film cooling" develops and
 the heat transfer is impaired.
  	  | Quote: | 	 		    Engine MFG's. try real hard not to have vapor areas in their engines.
 Of course I'm not talking of boiling off the coolant, but things are
 more subtle than commonly perceived at first glance. A certain amount of
 ebullition really helps keeping temperatures under control.
 The provided links to the NACA studies on engine liquid cooling, and on
 thermal dissipation will shed some light on the phenomenon (and in much
 better English
 Evans also gives a clear explanation on nucleate ebullition.
 Best regards,
 Gilles
