Thom Riddle
by0ung(at)brigham.net Guest
Posted: Wed May 09, 2007 6:20 am Post subject: battery for kolbs....battery for kolbs.... |
Boyd,
Is this the jump start at Harbor Freight you are talking about?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91045
Or perhaps this one?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38391
Thom in Buffalo
Thom.... the second link shows the jump start with the 17AH battery....
that would be the correct battery to comply with the requirements for the
912.... but the jump start is a bit different than the one I have.... the
overall appearance of the case is the same.
the first link only has a 12 AH battery. If I remember correctly John H.
said that he was using the 12AH battery with the new style starter on his
912s..
I bought my jump starts over 3 years ago when they had a good sale going....
I think what had happened they had got a new supply in and wanted to get rid
of the old stock..... when they ran out of the old stock,,, they
substituted it with the new stock...
I probably forgot to mention.... the jump start also included a very small
air compressor.... along with the battery charger (110V that turns itself
off when charged) the first link shows the 110 v power cord for the charger,
the second link does not show the charging power cord...volt meter, light,
12 v cigarette lighter adapter, 12 v charging port, short battery cables
with clamps, high current disconnect switch. Because it was cheaper than
a battery alone.... I bought 2,, robbed the battery from one for the
plane.... and continue to use one in my business....
If you want to order the battery only order the replacement battery for the
second link.
Boyd
Thom Riddle
Posted: Wed May 09, 2007 6:30 am Post subject: Re: battery for kolbs....battery for kolbs.... |
Boyd,
Thanks for the very helpful info. There is a Harbor Freight store close by so I'm going to see what that have in the store here. I don't even need a battery now but ours is about 3 1/2 years old and behaving itself well but I try to keep good suppliers in mind.
Thom in Buffalo
