jlsk1(at)frontiernet.net Guest
Posted: Wed May 09, 2007 5:17 pm Post subject: 582 water temps |
Hi all, have a quick Q.
I was Setting prop pitch today on my newly Overhauled 582 ( I`ve never run one before) & got the RPMs set at 6350, EGT & CHT are running right where I want them, but the water temp guage was about to reach 200 degrees.( EIS) Keep in mind this was a static run, & outside temps were about 83 degrees. Should I expect temps to be within limits once airborne on a similar day because of much increased airflow through the standard radiators? Or should I be concerned about the static temps?
Thanks, Jim
Eugene Zimmerman
Posted: Wed May 09, 2007 5:39 pm Post subject: 582 water temps |
Jim,
You should expect temp to come down once airborne.
Gene
On May 9, 2007, at 9:15 PM, Jim Kmet wrote:
| Quote: | Hi all, have a quick Q.
Thanks, Jim
http://www.matronics.com/Navigator?Kolb-List_-
============================================================ _-
forums.matronics.com_-
jindoguy(at)gmail.com Guest
Posted: Wed May 09, 2007 6:02 pm Post subject: 582 water temps |
Jim, Since I just did an annual on a Cosmos trike that didn't, you do have the head vented properly, don't you?
Rick
On 5/9/07, Eugene Zimmerman <etzim62(at)earthlink.net (etzim62(at)earthlink.net)> wrote: | Quote: | --> Kolb-List message posted by: Eugene Zimmerman < etzim62(at)earthlink.net (etzim62(at)earthlink.net)>
Jim,
Gene
Thanks, Jim
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
Posted: Wed May 09, 2007 6:08 pm Post subject: 582 water temps |
I Think so, its set up just like the blow-up pic in the airwolf cataloge, & just the way it was when I got it, 200 Plus hours on a MK-3.
Posted: Wed May 09, 2007 10:05 pm Post subject: 582 water temps |
The vent on my 582 runs from the mag side vent to a tee in the vent line between the upper tanks of the radiators. It's a small thing to miss. The trike I annualed had been used in three WSC Repairman Inspector classes and no one had written it up as a defect. The trike is a 1997 or 98 vintage and there is no evidence that the head vent was ever put in. Rotax says the vent is a must do for the engine to cool properly. Go figure.
Rick
On 5/9/07, Jim Kmet <jlsk1(at)frontiernet.net (jlsk1(at)frontiernet.net)> wrote:[quote] I Think so, its set up just like the blow-up pic in the airwolf cataloge, & just the way it was when I got it, 200 Plus hours on a MK-3.
airgriff(at)surferz.net Guest
Posted: Thu May 10, 2007 3:27 am Post subject: 582 water temps |
Hi Jim, Rotax also recommends to run a water hose over the radiator during static run ups on hot days, if needed to control temps. Be carefull not to spray too much water through the prop and to secure the hose well.
Fly Safe
Bob Griffin
Posted: Thu May 10, 2007 6:07 am Post subject: 582 water temps |
Makes perfect sense, I just wondered if the high temps that I saw during static run-up were typical, sounds like they are. Thanks, Jim
Posted: Thu May 10, 2007 6:13 am Post subject: 582 water temps |
There is a vent on the forward side of the engine top,, just forward of the front 2 spark plugs, & a vent plug just forward of the 2 rear spark plugs. Rotax sez to use the higher of the 2 vents . This hose routes to a T that return to both sides of the radiator. I assume thats the vent you`re reffering to? Jim
ElleryWeld(at)aol.com Guest
Posted: Thu May 10, 2007 8:36 am Post subject: 582 water temps |
Make sure you have all the air bubbles out of the cooling system also sometimes you have to run it without the Pressure Cap on for a while to remove any air bubbles in the system and do this on the ground even though I dont think you would try this in the air
Ellery
See what's free at http://www.aol.com. [quote][b]
Richard Pike
Posted: Thu May 10, 2007 9:30 am Post subject: 582 water temps |
The cooling system I had on my J-6 was very effective and had a good sized reservoir, and I ran it unpressurized. Never had any trouble, but it did always have a cap on it. Need to keep the coolant in even if you don't keep the pressure in.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
