jdubner(at)yahoo.com Guest
Posted: Thu May 10, 2007 11:10 am Post subject: Hitachi Alternator |
My O235 Long-EZ has experienced some sort of charging system failure.
It was intermittent at first but now it does nothing -- I flew home
battery only. So I suspect it's time for brush replacement on my
automotive alternator and I'd like to buy some brushes at the local auto
parts store.
The alternator is an internally regulated Hitachi alternator with no
part number (and I didn't install it). The counter-person at the NAPA
and the AutoZone stores gave me that "deer in the headlight" look when I
asked for brushes for a Hitachi alternator. They only understand car
make, model, and year. So can someone help me with a cross-reference?
The alternator appears to be this one:
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-6284&returntopage=80240069.htm
(or try this if that wraps around: http://tinyurl.com/2oaokc)
Joe
Joe Dubner K7JD | 523 Cedar Avenue | http://www.mail2600.com
Long-EZ 821RP | Lewiston, ID 83501 | +1 208 816-6359
mprather(at)spro.net Guest
Posted: Thu May 10, 2007 12:32 pm Post subject: Hitachi Alternator |
Hey Joe,
I'd pull the brush holder out and see if you can identify anything from
that. Maybe take some pics and post them. I found several outfits online
that show brushes for Hitachi alternators. You might also be able to
adapt brushes from a different alternator - they don't seem too tough to
work on.
I might also just call (or head down to) one of the alternator rebuilders
(there might be a local one) and see if they have the brushes.
Huskey Auto Electric in Boise might be able to help you:
(208) 345-2233 - 2301 W Overland RD - Boise, ID 83705
You might also check with Wizard Auto Electric...
(509) 758-6468 - 512 Sycamore St - Clarkston , WA 99403
Matt-
parts store.
Joe
Posted: Thu May 10, 2007 8:32 pm Post subject: Hitachi Alternator |
Thanks, Matt. Heading down to Wizard Electric in Clarkston is "plan B"
but I'm hoping someone on the list who works in the automotive
electrical business can tell me the make and model of the car my
alternator comes from.
This points out a real problem with a homebuilt that uses automotive
parts. When it changes hands somewhere down the line, the new owner may
be in for a tough time when the starter/alternator/whatever goes out
unless it's well documented.
Best Regards,
Joe
On 10-May-07 13:31 Matt Prather wrote:
Hey Joe,
work on.
Matt-
> parts store.
> Thanks,
> Joe
klehman(at)albedo.net Guest
Posted: Fri May 11, 2007 4:51 am Post subject: Hitachi Alternator |
Alternator rebuilders usually only need the part number on the
alternator. Many cars will have several different alternators installed
even in the same model year. Of course simply replacing the brushes may
be a short term repair.
Ken
Joe Dubner wrote:
Best Regards,
Joe
Posted: Fri May 11, 2007 5:36 am Post subject: Hitachi Alternator |
Ken,
That's the problem: there is _NO_ part number whatsoever on the
alternator. Just a manufacturer (Hitachi) and a label that says it's
internally regulated and made in Japan.
I'm headed to the alternator shop today but I'd like to solve this for
once and for all. So, again, I'm hoping someone in the business will
see this and recognize what it's used in.
My original message:
parts store.
Joe
On 11-May-07 05:48 Ken wrote:
Ken
>Best Regards,
>Joe
gmcjetpilot
Posted: Fri May 11, 2007 5:55 am Post subject: Hitachi Alternator |
This is the most likely one (you can get easily):
Alternator - Hitachi, Mitsubishi IR/EF
35 Amp, 12 Volt, CW, 1-Groove Pulley
Used On:
(1980-7 Nissan 620
720 Pickup 2.0L
Nissan Lift Trucks
TCM Lift Trucks
Replaces: Hitachi LR138-01 Mitsubishi A1T22971
Lester Nos: 14231
Key number is Lester # 14231.
If the brush repair does not work.
Get rid of the Hatachi; They are one of the worst
brands of alternators made. Get a:
Alternator - Nippondenso IR/IF Replacement
55 Amp, 12 Volt, CW, 1-Groove Pulley
Used On:
(1988-87) Chevrolet Sprint 1.0L
(1995-86) Suzuki Samurai 1.3L
(1989) Suzuki Sidekick 1.3L
Replaces: Nippondenso 100211-141, 100211-155,
100211-407
Lester Nos: 14684
Smaller, lighter, more reliable. May take new brackets.
If you really want to do it right.
http://www.plane-power.com/
Cheers George
>From: Joe Dubner <jdubner(at)yahoo.com (jdubner(at)yahoo.com)>
| Quote: | Subject: Hitachi Alternator
system failure.
frank.hinde(at)hp.com Guest
Posted: Fri May 11, 2007 6:30 am Post subject: Hitachi Alternator |
George is right,
That baby Nippondenso is a wonderful little machine, I ran one for 400 hours on my old Zodiac, only reason it hiccupped was because the brushes got soaked in oil from the leaking filler cap right in front of it. half an hour hour new brushes installed and it was perfect.
For the RV I went the plane power route after the Toyota camry unit I bought from Autozone confused my avionics...Nice but spendy! But it is a brand new alternator and I was in a hurry and Vans stock them and they are a 15min flight from my home base.
The Plane power unit fitted perfectly, all the brackets are included. If I add up the time I spent making brackets for the Toyota Camry unit I replaced then it was a good deal...In other words it wasn't worth making my own.
Cheers
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of gmcjetpilot(at)yahoo.com
Sent: Friday, May 11, 2007 6:54 AM
To: aeroelectric-list(at)matronics.com; jdubner(at)yahoo.com
Subject: Re: Hitachi Alternator
Used On:
(1980-7 Nissan 620
720 Pickup 2.0L
Nissan Lift Trucks
TCM Lift Trucks
Lester Nos: 14231
Used On:
100211-407
Lester Nos: 14684
Cheers George
system failure.
Posted: Fri May 11, 2007 7:36 am Post subject: Hitachi Alternator |
George,
Thank you! That's what I was looking for (the year/make/model and the
bonus of a Lester number). I don't know how you did it! Anyway, with
that info I'm off to the alternator shop and/or the parts house. And if
neither of those options give satisfaction, I see that Rockauto.com
sells one for under $50 (plus core and shipping). I'm a happy camper!
But I'm keeping my Hitachi (at least for now) in favor of the N-D you
mentioned because I'd rather not do a bracket (and baffling) change,
plus whatever wiring/terminal changes are needed to connect to the "S"
and "L" terminals. My Hitachi is a known quantity: internally regulated
and proven ability to switch off and on in flight. To misparaphrase a
frequently tossed-out saying at (former) work: "Change is bad!"
Thanks again,
Joe
On 11-May-07 06:54 gmcjetpilot(at)yahoo.com wrote:
| Quote: | This is the most likely one (you can get easily):
Used On:
(1980-7 Nissan 620
720 Pickup 2.0L
Nissan Lift Trucks
TCM Lift Trucks
Lester Nos: 14231
Used On:
100211-407
Lester Nos: 14684
Cheers George
>From: Joe Dubner <jdubner(at)yahoo.com>
>system failure.
Posted: Fri May 11, 2007 8:32 am Post subject: Hitachi Alternator |
Just a note of caution Joe,
I suspect that the Rockauto would be a rebuilt unit. There are many
rebuilt alternators which are very poor quality and for $50 I would be
very surprised if that was a good one.
Knowing what I know now (tempered with the fact I fly in IMC so I can't
afford an alt that will confuse my avionics) I would either strip and
rebuild the unit you have now, therby controlling the quality, buy a new
Lester unit (which I believe have a good reputation, or go for a plane
power unit.
Cheers
Frank
