bakerocb
Posted: Fri Feb 10, 2006 7:28 am Post subject: antennas |
Responding to an AeroElectric-List message previously posted by: "bob noffs"
<icubob(at)newnorth.net>
2/10/2006
Hello Bob, Dare I post some heresy? Will the gummint sic its watch dogs on
me? Will the electromagnetic radiation purists on the list rise up in total
fury to slap me down? Well, I'll take a chance.
Suppose that the gummint, in its infinite wisdom, mandated that every
aircraft carry 3 pounds of butter and a container of maple syrup just in
case the survival situation after crashing resulted in a supply of pancakes
as the available food supply. Would you insist on carrying genuine maple
syrup or would an imitation be good enough for you?
Maybe an ELT is a little more useful than butter and maple syrup in a crash
situation, but I sure as hell wouldn't place my entire faith in being found
and rescued in one of the garden variety ELT's that we are mandated to
carry. My point is that obsessing over antenna ground plane details is
wasted time.
Nobody knows exactly what attitude their aircraft will be in when it
finishes crashing. The ELT antenna could end up pointing directly down at,
and a few inches from, the surface of the earth. How much difference would a
perfect ground plane, if one could construct one, make in that situation?
Here is my thinking:
1) To be legal, buy one of the garden variety ELT's that we are mandated to
carry. Install it securely in the proper location in the proper attitude
with regard to its deceleration sensor. Fasten on the wire antenna that came
with the ELT and don't obsess over ground planes or what the antenna's
attitude will be when you finish crashing. Go fly.
2) If you want to take some truly effective steps for rescue after crashing
you can, and probably should to the degree that you are concerned and
considering routes of flight, do some or all of the following.
2A) Always carry a hand held VHF comm radio with a battery supply that you
KNOW to be capable of extended operation.
2B) Always carry a cell phone with a battery supply that you KNOW to be
2C) Purchase and carry a PLB http://www.equipped.com/faq_plb/default.asp
2D) Carry a tough plastic container of water -- size your choice. My
experience with even short time rescued people is that they experienced an
almost mentally debilitating thirst shortly after crashing.
2E) Carry a knife of enough size and sturdiness to punch through / crack
your plastic windows and canopy.
I am sure that other posters will add their favorite / essential crash
survival items, but obsessing over these items falls into the same category
of time wasting like obsessing over ground planes. Take what you deem to be
reasonable precautions to be rescued after a survivable crash and then
proceed to fly worry and guilt free (and legal).
OC
PS: If you have the bank account to afford one of the new 406 Mhz ELT's, go
for it.
<< hi all, I have several antennas to install. My elt requires a ground
plane. Tim at b and
c was very helpful with my questions but i question leads to 5 more. Is
there
any way around a ground plane for the elt? If not, any suggestions on how to
make it in my wood/cloth fuselage? At first i thought numerous strips of
thin
copper way the way to go but that looks like just more fasteners. Can a very
thin sheet be laid down in the fuse. bottom? It wouldnt exactly be flat with
all the woodworking to go around.....skip.....Thanks in advance, bob noffs>>
ruebd(at)skymail.csus.edu Guest
Posted: Fri Feb 10, 2006 9:04 am Post subject: antennas |
OC.
Well, now on the topic of the Maple syrup that we should carry,
even though my own preference would be for the genuine stuff, the
imitation would be more practical due to storage considerations, now, of
course, we know that refrigeration is required for the genuine after
opening, and is even a good idea with the fake stuff, but who can
guarantee that some hungry passenger, or pilot, would not have violated
the seal and had a taste before we had our emergency event. Wow, these
things do get complicated. Good we have the Gummint working on this for
us.
On a serious vein, what is the advantage of the 406 Mhz ones, is
it just the smaller dimensions needed for antenna and ground plane? Or
is there some other factor involved?
Duane Rueb, KF6GYB & PG-12-32627, also Kitfox N24ZM
wjrhamilton(at)optusnet.c Guest
Posted: Fri Feb 10, 2006 7:01 pm Post subject: antennas |
Folks,
In Australia, legislation to mandate fixed ELT in all GA aircraft was
defeated in the Parliament, after a lobbying campaign by AOPA Australia.
We do have legislation for the mandatory carriage of handheld
ELT/EPIRB ( your PLB) on all flights over 50 miles from base.
The statistics are stark, in actual crash scenarios, the failure rate
of fixed ELT is around 95%.
The most common cause of failure is the disruption of the antenna or
the aerial cable from the box to the antenna, for all the reasons you
can think of.
Another common reason is that the aircraft is in the water , 100% of
ELT's do not work under water. Post accident fire, prior internal
failure etc, are common additional causes.
In contrast, in survivable accidents, 100% of hand held ELT have
worked. In non-survivable accidents, all you are talking about is
saving search costs. Given what little information is available in
the US ( I did a lot of work jointly with the Civil Air Patrol on the
subject) the 95% + failure rate holds good in the US ---- As you
might expect, given the causes of failure are inherent in the
design/installation of fixed ELT.
Remember that the US legislation to mandate ELT bypassed all the
usual consultation, cost benefit analysis etc, it was a knee jerk
political reaction to the loss of an aircraft in Alaska, I don't
recall if it was a Congressman or Senator that was lost. There is
absolutely NO evidence to show that the outcome of that accident
would have been any different had the aircraft been fitted with an
ELT, statistically there was a better than 95% failure probability.
Given actual accident, the failure probability was closer to 100%.
In view of phasing out the COSPAR/SARSAT on 121.5/243, in accord with
the latest specifications for new generation ELT, commodity priced
400 mcs GPS/ELT are now available.
Interestingly, because of the low cost of an ELT, their use is
widespread, even Forest Service type organisations ( the name varies
state by state) rent ELT to hikers who do not have their own, most 4
Wheel Drivers carry one now, if they are in a remote area.
In short, fixed ELT are a total waste on money.
Even in three airline accidents ( all Airbus) that we could track
down, where the tail mounted ELT survived in-tact in a largely intact
tail section, all three ELT failed to transmit a useable signal.
Cheers,
Bill Hamilton.
At 21:28 10/02/2006, you wrote:
2/10/2006
wasted time.
OC
for it.
plane. Tim at b and
there
thin
CONFIDENTIALITY & PRIVILEGE NOTICE
W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet
Services and Warbirds.Net. & <wjrhamilton(at)optusnet.com.au>.
This message is intended for and should only be used by the
addressee. It is confidential and may contain legally privileged
information.If you are not the intended recipient any use
distribution,disclosure or copying of this message is strictly
prohibited.Confidentiality and legal privilege attached to this
communication are not waived or lost by reason of the mistaken
delivery to you.If you have received this message in error, please
notify us immediately to:
Australia 61 (0)408 876 526
Dolores capitis non fero. Eos do.
