Dennis Johnson
Posted: Sat May 12, 2007 6:10 am Post subject: GS Air Strobes |
Hi Terry,
I also have the GS Air strobe light and LED position light combos. After 50 hours of flying, they're working great. I wired them using a 10 amp fuse off the main bus and 16 AWG wire for the power and grounds (composite airplane). I think the 15 amp fuse specified in the instructions is way overkill. The 16 AWG wires fit in the connectors fine.
Good luck,
Dennis Johnson
Lancair Legacy, now flying and Phase 1 flight test completed
nuckollsr(at)cox.net Guest
Posted: Sat May 12, 2007 7:35 am Post subject: GS Air Strobes |
At 07:08 AM 5/12/2007 -0700, you wrote:
| Quote: | Hi Terry,
Any chance you could get us a current measurement on this
system? Preferably with an analog ammeter. The current is
going to be jumping around each time it flashes. It would
be useful to have a max and min reading as best as you
can visually capture it.
( "Physics is like sex: sure, it may )
( give some practical results, but )
( that's not why we do it." )
( Richard P. Feynman )
Dennis Johnson
Posted: Sat May 12, 2007 4:12 pm Post subject: Re: GS Air Strobes |
| Quote: | Any chance you could get us a current measurement on this
system? |
I'll take the measurements and post the results next time I'm at the hangar, which will probably be Tuesday.
I'm pretty sure I can get a peak current measurement using my digital VOM. I bought a cheap analog meter based on the recommendation in the Connection, so I should be able to eyeball and average using that.
Best,
Dennis Johnson
