		ElleryWeld(at)aol.com Guest
				 Posted: Sat May 12, 2007 6:53 pm    Post subject: Rotax 377 and 477 use same points and ignition? |
				Kent
   according to my CPS book the part numbers for the contact points set is Soldered part number is 983-349
             Threaded part number is 983-343
   these points will fit all engines 277,377,447,503
  Good luck and I hope this helps you
  Ellery do not archive
  See what's free at http://www.aol.com.  [quote][b]
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sat May 12, 2007 7:01 pm    Post subject: Rotax 377 and 477 use same points and ignition? |
				Kent
  one more note the  early engines  prior to 1984 has the soldered  wire on  the condensers   (early) or secured by threaded post (late production)
  Ellery in Maine
		kentk
  Joined: 03 Jan 2007 Posts: 25 Location: College Station
				 Posted: Sun May 13, 2007 5:56 pm    Post subject: Re: Rotax 377 and 477 use same points and ignition? |
				Very good!  Thanks much for the help!
  _________________ Kent Knudsen
College Station, TX
K-IV 1200 / no engine / 25% done |
