twcroy(at)gmail.com Guest
Posted: Sun May 13, 2007 6:52 am Post subject: Tow Bar |
Folks,
Any recommendations for moving the 601 around to / from its hangar? I
would guess a tow/push bar for the nose wheel would work, but haven't
found one yet. I normally pull / push at the prop hub. Any ideas for
an inexpensive, easy way to do this or make one would be appreciated.
Thanks.
naumuk(at)alltel.net Guest
Posted: Sun May 13, 2007 8:54 am Post subject: Tow Bar |
Tim-
Check larry(at)macsmachine.com
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Sun May 13, 2007 9:11 am Post subject: Tow Bar |
Tim,
I've got a page that describes tow bar and the travel stop for the 601.
I've built a dozen or so
and have drawings on the page that show how to make one. The tow bar can
fit on the shelf and you take it
with you for ground handling at any airport. Both are very light.
http://www.macsmachine.com/images/Itemsforsale/full/travel-stop-and-stear-link.gif
http://www.macsmachine.com/images/Itemsforsale/full/tow-bar-construct.gif
Enough info that you can make one or order them both for $100.00 total.
Larry McFarland
Timothy Croy wrote:
Folks,
Thanks.
Posted: Sun May 13, 2007 9:24 am Post subject: Tow Bar |
Scott made the actual tow bar from a crutch:
http://www.cooknwithgas.com/Towbar.html
The big determination on how you attach the bar is if you have wheel pants
or not.
-- Craig
Posted: Sun May 13, 2007 2:23 pm Post subject: Tow Bar |
Thanks all for the ideas on the tow bar. I'll probably go with the
crutch rig. Tim
daveaustin2(at)primus.ca Guest
Posted: Mon May 14, 2007 6:03 am Post subject: Tow Bar |
I move mine (tricycle) backward by pulling on the rudder spar where it is
open, and steer with the rudder. Pull on the prop for forward. KISS.
Dave Austin 601HDS - 912, Spitfire Mk VIII
