Kurt.Schumacher(at)schumi Guest
Posted: Mon May 14, 2007 2:28 pm Post subject: Just two links... there is not much room left for your safet |
This is not a Zenair - just another, well-designed light aircraft - a
Partenavia P68C.
Start here. Carefully watch the video.
http://www.youtube.com/watch?v=7wY3Sb-C1BE
There is no abrupt change of flight path visible. The records later say 8
degrees...
http://www.ntsb.gov/ntsb/brief.asp?ev_id 001214X44523&key=1
THE PLT WAS EXECUTING A HIGH SPEED PASS OVER THE RWY AT ABOUT 250 FT AGL.
THE PLT THEN BEGAN A RAPID PULL-UP & BOTH WINGS SEPARATED JUST OUTBOARD OF
THE ENG NACELLES. RECONSTRUCTION OF THE SEQUENCE FROM A VIDEOTAPE REVEALED
THAT THE ACFT'S SPEED AT THE TIME OF THE WING SEPARATIONS WAS 220 KTS. VNE
FOR THE ACFT IS 193 KTS. IT WAS CALCULATED THAT, AT 220 KTS & AN 8 DEG
NOSE-UP PITCH, THE 'G' LOAD AT THE TIME OF THE WING SEPARATIONS WOULD HAVE
BEEN 8.3 G'S.
Pilots are killing pilots. Engineers and designers don't do it.
-Kurt.
